<root>
<document schema='101' license='-1,88263627,K38DMR' title='' description='' target='PIC.16F.16F1939' >
	<config data='!0,9e4!10,1533%0,4%3,0%5,1%6,1%7,1%8,1%9,0%b,1%c,0%d,0%10,3%14,3%18,1%19,0%1a,1%1c,1%1d,0' clkspd='32000000' simspd='4' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='255' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
		<dll_webhelp enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='c855a64a-cdc0-4400-9122-9e55c55fa0ae' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='count' type='u8' description='' isconst='0' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='Main' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='native' title='C kód' ccode='osccon = 0xF2;' language='C' />
						<command class_type='call' title='Komponens makró hívása' component='gLCD_ILI9341' macro='Initialise' />
						<command class_type='loop' title='Ciklus' type='0' exp='1' >
							<flowline >
								<command class_type='calculation' title='Számítás' >
									<exp exp='count = count + 1' />
								</command>
								<command class_type='call' title='Komponens makró hívása' component='gLCD_ILI9341' macro='PrintNumber' >
									<argument exp='count' />
									<argument exp='20' />
									<argument exp='2' />
									<argument exp='0' />
								</command>
								<command class_type='decision' title='Feltételes elágazás' exp='count = 200' swap='0' >
									<flowline >
											<exp exp='count = 0' />
										</command>
									</flowline>
									<flowline />
								</command>
							</flowline>
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='bc0a0612-ef85-48fb-8960-5e78f4083df1' vmin='8' vmaj='1' codename='gLCD_ILI9341' x='-80' y='8' z='0' xsz='25' ysz='25' zsz='25' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='1' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pixel_height' data='320' />
					<value target='pixel_width' data='240' />
					<value target='monochrome' data='0' />
					<value target='foreground_colour' data='16777215' />
					<value target='background_colour' data='0' />
					<value target='colour_bit_depth' data='16' />
					<value target='red_bit_depth' data='5' />
					<value target='green_bit_depth' data='6' />
					<value target='blue_bit_depth' data='5' />
					<value target='dataout_pin' data='$PORTC.1' />
					<value target='clock_pin' data='$PORTD.2' />
					<value target='chip_sel_pin' data='$PORTD.1' />
					<value target='dc_pin' data='$PORTC.3' />
					<value target='reset_pin' data='$PORTD.0' />
					<value target='led_pin' data='$PORTB.5' />
					<value target='UseBacklight' data='0' />
					<value target='DisplayMethod' data='000' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='bc0a0612-ef85-48fb-8960-5e78f4083df1' vmin='8' vmaj='1' codename='gLCD_ILI93414' x='-40' y='40' z='0' xsz='25' ysz='25' zsz='25' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='dataout_pin' data='$PORTB.0' />
					<value target='clock_pin' data='$PORTB.1' />
					<value target='chip_sel_pin' data='$PORTB.2' />
					<value target='dc_pin' data='$PORTB.3' />
					<value target='reset_pin' data='$PORTB.4' />
					<value target='UseBacklight' data='1' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
			<component class_type='ref' guid='fc04a65f-f03d-40c8-9f69-0d23d2daac29' vmin='1' vmaj='1' codename='pcb_switch1' x='-32' y='24' z='3.9' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='1' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pin' data='$PORTE.0' />
					<value target='polarity' data='001' />
					<value target='debounce' data='' />
					<value target='operation' data='000' />
					<value target='color' data='6908265' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='9737364' img='' style='0' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='25' />
	</panel3d>
	<layout >
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAAHwYAAAcDAAA' zoom='75' scrollx='0' scrolly='35' flags='0' />
	</layout>
</document>
</root>
