<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.0.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="1" y1="38" x2="1" y2="5" width="0.4064" layer="24"/>
<wire x1="24" y1="5" x2="1" y2="5" width="0.4064" layer="24"/>
<wire x1="1" y1="38" x2="24" y2="38" width="0.4064" layer="24"/>
<wire x1="24" y1="38" x2="24" y2="5" width="0.4064" layer="24"/>
<wire x1="24" y1="5" x2="47" y2="5" width="0.4064" layer="24"/>
<wire x1="47" y1="5" x2="47" y2="38" width="0.4064" layer="24"/>
<wire x1="59" y1="5" x2="59" y2="38" width="0.4064" layer="24"/>
<wire x1="59" y1="38" x2="82" y2="38" width="0.4064" layer="24"/>
<wire x1="82" y1="5" x2="59" y2="5" width="0.4064" layer="24"/>
<wire x1="82" y1="38" x2="82" y2="5" width="0.4064" layer="24"/>
<wire x1="82" y1="5" x2="105" y2="5" width="0.4064" layer="24"/>
<wire x1="105" y1="5" x2="105" y2="38" width="0.4064" layer="24"/>
<wire x1="105" y1="38" x2="82" y2="38" width="0.4064" layer="24"/>
<wire x1="24" y1="38" x2="47" y2="38" width="0.4064" layer="24"/>
</plain>
<libraries>
<library name="74xx-eu">
<description>&lt;b&gt;TTL Devices, 74xx Series with European Symbols&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Texas Instruments &lt;i&gt;TTL Data Book&lt;/i&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;Volume 1, 1996.
&lt;li&gt;TTL Data Book, Volume 2 , 1993
&lt;li&gt;National Seminconductor Databook 1990, ALS/LS Logic
&lt;li&gt;ttl 74er digital data dictionary, ECA Electronic + Acustic GmbH, ISBN 3-88109-032-0
&lt;li&gt;http://icmaster.com/ViewCompare.asp
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL28-6">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.6 inch</description>
<pad name="1" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90" stop="no"/>
<pad name="17" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
</library>
<library name="74ac-logic">
<description>&lt;b&gt;TTL Logic Devices, 74AC11xx and 74AC16xx Series&lt;/b&gt;&lt;p&gt;
Based on the following source:
&lt;ul&gt;
&lt;li&gt;www.ti.com
&lt;/ul&gt;
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<pad name="1" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="E$1" library="74xx-eu" package="DIL28-6" value="" x="12.7" y="30.32" rot="R90"/>
<element name="E$2" library="74xx-eu" package="DIL28-6" value="" x="35.29" y="30.32" rot="R90"/>
<element name="E$3" library="74xx-eu" package="DIL28-6" value="" x="70.69" y="30.32" rot="R90"/>
<element name="E$4" library="74xx-eu" package="DIL28-6" value="" x="93.28" y="30.32" rot="R90"/>
<element name="E$6" library="74ac-logic" package="DIL08" value="" x="53" y="28"/>
<element name="E$7" library="74ac-logic" package="DIL08" value="" x="53" y="14.9"/>
<element name="E$5" library="74ac-logic" package="DIL08" value="" x="53" y="31"/>
<element name="E$9" library="74ac-logic" package="DIL08" value="" x="53" y="12"/>
</elements>
<signals>
<signal name="S$247">
<via x="18.91" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$248">
<via x="21.45" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$246">
<via x="23.99" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$249">
<via x="16.37" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$250">
<via x="13.83" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$251">
<via x="8.75" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$244">
<via x="11.29" y="8.51" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$259">
<via x="41.408" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$260">
<via x="43.948" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$261">
<via x="46.488" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
<via x="49.028" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$262">
<via x="38.868" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$263">
<via x="36.328" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$264">
<via x="31.248" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$265">
<via x="33.788" y="8.5" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$252">
<via x="67.407" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$253">
<via x="69.947" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$254">
<via x="72.487" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$255">
<via x="64.867" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$256">
<via x="62.327" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$257">
<via x="57.247" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$258">
<via x="59.787" y="8.499" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$266">
<via x="90.405" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$267">
<via x="92.945" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$268">
<via x="95.485" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$269">
<via x="87.865" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$270">
<via x="85.325" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$271">
<via x="80.245" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$272">
<via x="82.785" y="8.498" extent="1-16" drill="1" diameter="1.9304" shape="square"/>
</signal>
<signal name="S$273">
<wire x1="49.67" y1="9.1" x2="49.67" y2="9.11" width="0.6096" layer="16"/>
</signal>
<signal name="S$1">
<wire x1="84.71" y1="13.82" x2="84.44" y2="13.82" width="0.6096" layer="16"/>
<wire x1="84.44" y1="13.82" x2="79.83" y2="9.21" width="0.6096" layer="16"/>
</signal>
<signal name="S$2">
<wire x1="82.8" y1="9.3" x2="82.8" y2="10.5" width="0.6096" layer="16"/>
<wire x1="82.8" y1="10.5" x2="84.7" y2="12.4" width="0.6096" layer="16"/>
<wire x1="84.7" y1="12.4" x2="87" y2="12.4" width="0.6096" layer="16"/>
<wire x1="87" y1="12.4" x2="97.8" y2="23.2" width="0.6096" layer="16"/>
<wire x1="97.8" y1="23.2" x2="97.8" y2="24.2" width="0.6096" layer="16"/>
<wire x1="97.8" y1="24.2" x2="100.1" y2="26.5" width="0.6096" layer="16"/>
</signal>
<signal name="S$3">
<wire x1="100" y1="21.3" x2="97.5" y2="21.3" width="0.6096" layer="16"/>
<wire x1="97.5" y1="21.3" x2="87.3" y2="11.1" width="0.6096" layer="16"/>
<wire x1="87.3" y1="11.1" x2="85.8" y2="11.1" width="0.6096" layer="16"/>
<wire x1="85.8" y1="11.1" x2="85.1" y2="10.4" width="0.6096" layer="16"/>
<wire x1="85.1" y1="10.4" x2="85.1" y2="9.3" width="0.6096" layer="16"/>
</signal>
<signal name="S$4">
<wire x1="87.9" y1="9.3" x2="87.9" y2="10" width="0.6096" layer="16"/>
<wire x1="87.9" y1="10" x2="96.8" y2="18.9" width="0.6096" layer="16"/>
<wire x1="96.8" y1="18.9" x2="100" y2="18.9" width="0.6096" layer="16"/>
</signal>
<signal name="S$5">
<wire x1="90.4" y1="9.3" x2="90.4" y2="10.8" width="0.6096" layer="16"/>
<wire x1="90.4" y1="10.8" x2="93.4" y2="13.8" width="0.6096" layer="16"/>
<wire x1="93.4" y1="13.8" x2="100.1" y2="13.8" width="0.6096" layer="16"/>
</signal>
<signal name="S$6">
<wire x1="86.6" y1="29" x2="96.6" y2="29" width="0.6096" layer="16"/>
<wire x1="96.6" y1="29" x2="98.5" y2="30.9" width="0.6096" layer="16"/>
<wire x1="98.5" y1="30.9" x2="102.5" y2="30.9" width="0.6096" layer="16"/>
<wire x1="102.5" y1="30.9" x2="103.1" y2="30.3" width="0.6096" layer="16"/>
<wire x1="103.1" y1="30.3" x2="103.1" y2="13" width="0.6096" layer="16"/>
<wire x1="103.1" y1="13" x2="102.1" y2="12" width="0.6096" layer="16"/>
<wire x1="102.1" y1="12" x2="95.3" y2="12" width="0.6096" layer="16"/>
<wire x1="95.3" y1="12" x2="92.5" y2="9.2" width="0.6096" layer="16"/>
</signal>
<signal name="S$7">
<wire x1="84.9" y1="26.5" x2="83.4" y2="28" width="0.6096" layer="16"/>
<wire x1="83.4" y1="28" x2="83.4" y2="30.5" width="0.6096" layer="16"/>
<wire x1="83.4" y1="30.5" x2="83.7" y2="30.8" width="0.6096" layer="16"/>
<wire x1="83.7" y1="30.8" x2="92.6" y2="30.8" width="0.6096" layer="16"/>
<wire x1="92.6" y1="30.8" x2="93.9" y2="32.1" width="0.6096" layer="16"/>
<wire x1="93.9" y1="32.1" x2="104.2" y2="32.1" width="0.6096" layer="16"/>
<wire x1="104.2" y1="32.1" x2="104.4" y2="31.9" width="0.6096" layer="16"/>
<wire x1="104.4" y1="31.9" x2="104.4" y2="11.3" width="0.6096" layer="16"/>
<wire x1="104.4" y1="11.3" x2="103.8" y2="10.7" width="0.6096" layer="16"/>
<wire x1="103.8" y1="10.7" x2="96.6" y2="10.7" width="0.6096" layer="16"/>
<wire x1="96.6" y1="10.7" x2="95.5" y2="9.6" width="0.6096" layer="16"/>
<wire x1="95.5" y1="9.6" x2="95.5" y2="9.3" width="0.6096" layer="16"/>
</signal>
<signal name="S$8">
<wire x1="63.9" y1="26.5" x2="65" y2="25.4" width="0.6096" layer="16"/>
<wire x1="65" y1="25.4" x2="65" y2="13.5" width="0.6096" layer="16"/>
<wire x1="65" y1="13.5" x2="64" y2="12.5" width="0.6096" layer="16" curve="-90"/>
<wire x1="64" y1="12.5" x2="57.2" y2="12.5" width="0.6096" layer="16"/>
<wire x1="57.2" y1="12.5" x2="57.2" y2="9.4" width="0.6096" layer="16"/>
</signal>
<signal name="S$9">
<wire x1="63.9" y1="28.9" x2="66" y2="28.9" width="0.6096" layer="16"/>
<wire x1="66" y1="28.9" x2="66" y2="13.4" width="0.6096" layer="16"/>
<wire x1="66" y1="13.4" x2="64.2" y2="11.6" width="0.6096" layer="16" curve="-90"/>
<wire x1="64.2" y1="11.6" x2="59.8" y2="11.6" width="0.6096" layer="16"/>
<wire x1="59.8" y1="11.6" x2="59.8" y2="9.3" width="0.6096" layer="16"/>
</signal>
<signal name="S$10">
<wire x1="77.5" y1="26.5" x2="66.9" y2="26.5" width="0.6096" layer="16"/>
<wire x1="66.9" y1="26.5" x2="66.9" y2="13.2" width="0.6096" layer="16"/>
<wire x1="66.9" y1="13.2" x2="64.4" y2="10.7" width="0.6096" layer="16" curve="-90"/>
<wire x1="64.4" y1="10.7" x2="62.3" y2="10.7" width="0.6096" layer="16"/>
<wire x1="62.3" y1="10.7" x2="62.3" y2="9.4" width="0.6096" layer="16"/>
</signal>
<signal name="S$11">
<wire x1="77.5" y1="21.4" x2="74.9" y2="21.4" width="0.6096" layer="16"/>
<wire x1="74.9" y1="21.4" x2="68" y2="14.5" width="0.6096" layer="16"/>
<wire x1="68" y1="14.5" x2="68" y2="13.4" width="0.6096" layer="16"/>
<wire x1="68" y1="13.4" x2="64.2" y2="9.6" width="0.6096" layer="16" curve="-90"/>
</signal>
<signal name="S$12">
<wire x1="77.5" y1="18.9" x2="76.8" y2="18.9" width="0.6096" layer="16"/>
<wire x1="76.8" y1="18.9" x2="66.9" y2="9" width="0.6096" layer="16"/>
</signal>
<signal name="S$13">
<wire x1="70" y1="9.3" x2="74.5" y2="13.8" width="0.6096" layer="16"/>
<wire x1="74.5" y1="13.8" x2="77.5" y2="13.8" width="0.6096" layer="16"/>
</signal>
<signal name="S$14">
<wire x1="62.3" y1="13.9" x2="55.3" y2="13.9" width="0.6096" layer="16"/>
<wire x1="55.3" y1="13.9" x2="55.3" y2="6.3" width="0.6096" layer="16"/>
<wire x1="55.3" y1="6.3" x2="71.5" y2="6.3" width="0.6096" layer="16"/>
<wire x1="71.5" y1="6.3" x2="73.1" y2="7.9" width="0.6096" layer="16"/>
</signal>
<signal name="S$15">
<wire x1="28.6" y1="29" x2="34.2" y2="29" width="0.6096" layer="16"/>
<wire x1="34.2" y1="29" x2="36.2" y2="31" width="0.6096" layer="16"/>
<wire x1="36.2" y1="31" x2="36.2" y2="32.4" width="0.6096" layer="16"/>
<wire x1="36.2" y1="32.4" x2="47.7" y2="32.4" width="0.6096" layer="16"/>
<wire x1="47.7" y1="32.4" x2="47.7" y2="10.8" width="0.6096" layer="16"/>
<wire x1="47.7" y1="10.8" x2="47.1" y2="10.8" width="0.6096" layer="16"/>
<wire x1="47.1" y1="10.8" x2="47.1" y2="9.2" width="0.6096" layer="16"/>
</signal>
<signal name="S$16">
<wire x1="28.6" y1="26.5" x2="33.4" y2="26.5" width="0.6096" layer="16"/>
<wire x1="33.4" y1="26.5" x2="38" y2="31.1" width="0.6096" layer="16"/>
<wire x1="38" y1="31.1" x2="44.9" y2="31.1" width="0.6096" layer="16"/>
<wire x1="44.9" y1="31.1" x2="46.3" y2="29.7" width="0.6096" layer="16"/>
<wire x1="46.3" y1="29.7" x2="46.3" y2="12" width="0.6096" layer="16"/>
<wire x1="46.3" y1="12" x2="43.5" y2="9.2" width="0.6096" layer="16"/>
</signal>
<signal name="S$17">
<wire x1="42.2" y1="13.7" x2="42.2" y2="10.4" width="0.6096" layer="16"/>
<wire x1="42.2" y1="10.4" x2="40.9" y2="9.1" width="0.6096" layer="16"/>
</signal>
<signal name="S$18">
<wire x1="38.9" y1="9.3" x2="38.9" y2="15.3" width="0.6096" layer="16"/>
<wire x1="38.9" y1="15.3" x2="42.2" y2="18.6" width="0.6096" layer="16"/>
</signal>
<signal name="S$19">
<wire x1="42" y1="21.4" x2="36.9" y2="16.3" width="0.6096" layer="16"/>
<wire x1="36.9" y1="16.3" x2="36.9" y2="9.2" width="0.6096" layer="16"/>
</signal>
<signal name="S$20">
<wire x1="34.3" y1="9" x2="34.4" y2="9.1" width="0.6096" layer="16"/>
<wire x1="34.4" y1="9.1" x2="34.4" y2="16.1" width="0.6096" layer="16"/>
<wire x1="34.4" y1="16.1" x2="40" y2="21.7" width="0.6096" layer="16"/>
<wire x1="40" y1="21.7" x2="40" y2="26.5" width="0.6096" layer="16"/>
<wire x1="40" y1="26.5" x2="42" y2="26.5" width="0.6096" layer="16"/>
</signal>
<signal name="S$21">
<wire x1="28.5" y1="13.8" x2="31.9" y2="10.4" width="0.6096" layer="16"/>
<wire x1="31.9" y1="10.4" x2="31.9" y2="9.1" width="0.6096" layer="16"/>
</signal>
<signal name="S$22">
<wire x1="21.3" y1="18.9" x2="22.4" y2="16.8" width="0.6096" layer="16"/>
<wire x1="22.4" y1="16.8" x2="22.4" y2="11" width="0.6096" layer="16"/>
</signal>
<signal name="S$23">
<wire x1="22.4" y1="10.9" x2="23.4" y2="9.9" width="0.6096" layer="16"/>
<wire x1="23.4" y1="9.9" x2="23.4" y2="9.1" width="0.6096" layer="16"/>
</signal>
<signal name="S$24">
<wire x1="21.3" y1="26.5" x2="23.7" y2="24.1" width="0.6096" layer="16"/>
<wire x1="23.7" y1="24.1" x2="23.7" y2="11.7" width="0.6096" layer="16"/>
<wire x1="23.7" y1="11.7" x2="24.8" y2="10.6" width="0.6096" layer="16"/>
<wire x1="24.8" y1="10.6" x2="25.7" y2="10.6" width="0.6096" layer="16"/>
<wire x1="25.7" y1="10.6" x2="26" y2="10.3" width="0.6096" layer="16"/>
<wire x1="26" y1="10.3" x2="26" y2="6.6" width="0.6096" layer="16"/>
<wire x1="26" y1="6.6" x2="20.9" y2="6.6" width="0.6096" layer="16"/>
<wire x1="20.9" y1="6.6" x2="20.9" y2="7.8" width="0.6096" layer="16"/>
</signal>
<signal name="S$25">
<wire x1="19.5" y1="13.8" x2="19.5" y2="9.1" width="0.6096" layer="16"/>
</signal>
<signal name="S$26">
<wire x1="16.4" y1="9.3" x2="16.4" y2="19" width="0.6096" layer="16"/>
<wire x1="16.4" y1="19" x2="18.9" y2="21.5" width="0.6096" layer="16"/>
<wire x1="18.9" y1="21.5" x2="19.6" y2="21.5" width="0.6096" layer="16"/>
</signal>
<signal name="S$27">
<wire x1="14.5" y1="9.2" x2="14.5" y2="12.3" width="0.6096" layer="16"/>
<wire x1="14.5" y1="12.3" x2="14.9" y2="12.7" width="0.6096" layer="16"/>
<wire x1="14.9" y1="12.7" x2="14.9" y2="29.2" width="0.6096" layer="16"/>
<wire x1="14.9" y1="29.2" x2="14.8" y2="29.3" width="0.6096" layer="16"/>
<wire x1="14.8" y1="29.3" x2="5.8" y2="29.3" width="0.6096" layer="16"/>
</signal>
<signal name="S$28">
<wire x1="6" y1="13.8" x2="7.4" y2="13.8" width="0.6096" layer="16"/>
<wire x1="7.4" y1="13.8" x2="11.3" y2="9.4" width="0.6096" layer="16"/>
</signal>
<signal name="S$29">
<wire x1="7.7" y1="8.5" x2="5.6" y2="8.5" width="1.016" layer="16"/>
<wire x1="5.6" y1="8.5" x2="2.2" y2="11.9" width="1.016" layer="16"/>
<wire x1="2.2" y1="11.9" x2="2.2" y2="14.6" width="1.016" layer="16"/>
<wire x1="2.2" y1="14.6" x2="4.1" y2="16.5" width="1.016" layer="16"/>
<wire x1="4.1" y1="16.5" x2="2.3" y2="18.3" width="1.016" layer="16"/>
<wire x1="2.3" y1="18.3" x2="2.3" y2="34.6" width="1.016" layer="16"/>
<wire x1="2.3" y1="34.6" x2="2.6" y2="34.9" width="1.016" layer="16"/>
<wire x1="2.6" y1="34.9" x2="80.4" y2="34.9" width="1.016" layer="16"/>
</signal>
<signal name="S$30">
<wire x1="2.5" y1="24" x2="2.6" y2="23.9" width="1.016" layer="16"/>
<wire x1="2.6" y1="23.9" x2="4.1" y2="23.9" width="1.016" layer="16"/>
</signal>
<signal name="S$31">
<wire x1="26.7" y1="24.1" x2="24.1" y2="26.7" width="1.016" layer="16"/>
<wire x1="24.1" y1="26.7" x2="24.1" y2="34.8" width="1.016" layer="16"/>
</signal>
<signal name="S$32">
<wire x1="26.5" y1="23.9" x2="25.2" y2="22.6" width="1.016" layer="16"/>
<wire x1="25.2" y1="22.6" x2="25.2" y2="16.9" width="1.016" layer="16"/>
</signal>
<signal name="S$33">
<wire x1="49.6" y1="9.1" x2="51.6" y2="11.1" width="0.6096" layer="16"/>
<wire x1="51.6" y1="11.1" x2="53" y2="11.1" width="0.6096" layer="16"/>
</signal>
<signal name="S$34">
<wire x1="53.1" y1="27.1" x2="53.1" y2="15.7" width="0.6096" layer="16"/>
</signal>
<signal name="S$35">
<wire x1="62" y1="24" x2="58.3" y2="27.7" width="1.016" layer="16"/>
<wire x1="58.3" y1="27.7" x2="58.3" y2="34.5" width="1.016" layer="16"/>
<wire x1="62" y1="24" x2="59.7" y2="21.7" width="1.016" layer="16"/>
<wire x1="59.7" y1="21.7" x2="59.7" y2="17.1" width="1.016" layer="16"/>
<wire x1="59.7" y1="17.1" x2="60.4" y2="16.4" width="1.016" layer="16"/>
<wire x1="60.4" y1="16.4" x2="62.1" y2="16.4" width="1.016" layer="16"/>
</signal>
<signal name="S$36">
<wire x1="53.1" y1="34.8" x2="53" y2="34.7" width="1.016" layer="16"/>
<wire x1="53" y1="34.7" x2="53" y2="32" width="1.016" layer="16"/>
</signal>
<signal name="S$37">
<wire x1="80.5" y1="34.9" x2="81.1" y2="34.3" width="1.016" layer="16"/>
<wire x1="81.1" y1="34.3" x2="81.1" y2="27.7" width="1.016" layer="16"/>
<wire x1="81.1" y1="27.7" x2="84.7" y2="24.1" width="1.016" layer="16"/>
<wire x1="84.7" y1="24.1" x2="82.6" y2="22" width="1.016" layer="16"/>
<wire x1="82.6" y1="22" x2="82.6" y2="17.1" width="1.016" layer="16"/>
<wire x1="82.6" y1="17.1" x2="83.4" y2="16.3" width="1.016" layer="16"/>
<wire x1="83.4" y1="16.3" x2="84.6" y2="16.3" width="1.016" layer="16"/>
</signal>
<signal name="S$38">
<wire x1="25.2" y1="16.8" x2="26.7" y2="16.4" width="1.016" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
