--https://www.youtube.com/watch?v=emxTfvF0Hbk WIFI_SSID = "TP-LINK_EDD49A" WIFI_PASS = "123456789" MODBUS_ServerPort = 502 MODBUS_ServerMode = net.TCP RS485_BaudRate = 2400 RS485_DataBits = 8 RS485_ParityBits = uart.PARITY_NONE RS485_StopBits = uart.STOPBITS_1 RS485_TxOn_Pin = 6 gpio.mode(7, gpio.INPUT, gpio.PULLUP) gpio.mode(8, gpio.OUTPUT) gpio.write(8, 1) gpio.mode(RS485_TxOn_Pin, gpio.OUTPUT) gpio.write(RS485_TxOn_Pin, 0) Bits = RS485_DataBits + 1 if (RS485_ParityBits ~= uart.PARITY_NONE) then Bits = Bits + 1 end if (RS485_StopBits == uart.STOPBITS_1) then Bits = Bits + 1 elseif (RS485_StopBits == uart.STOPBITS_1_5) then Bits = Bits + 1.5 else Bits = Bits + 2 end ByteTransmitTimeUs = RS485_BaudRate / Bits ByteTransmitTimeUs = 1000000 / ByteTransmitTimeUs wifi.setmode(wifi.STATION) wifi.sta.config(WIFI_SSID, WIFI_PASS) wifi.sta.connect() local wifi_status_old = 0 local MB_uart_rx_buff = "" local MB_tcp_rx_buff = "" local MB_wait_rx = false local MB_wait_rx_time = 1000 local MBtranId = 0 local MBserver = nil local MBsock = nil function uart_setup() node.output(function(str) end, 0) uart.alt(1) uart.setup(0, RS485_BaudRate, RS485_DataBits, RS485_ParityBits, RS485_StopBits, 0) end function process_crc(aData) local crc = 0xFFFF for i = 1, #aData do crc = bit.bxor(crc, string.byte(aData, i)) for j = 0, 7 do if bit.band(crc, 1) > 0 then crc = bit.rshift(crc, 1) crc = bit.bxor(crc, 0xA001) else crc = bit.rshift(crc, 1) end end end return crc end function modbus_rtu_rx() if (MBsock ~= nil) then local answer = string.sub(MB_uart_rx_buff, 1, #MB_uart_rx_buff - 2) crc = process_crc(answer) if (string.byte(MB_uart_rx_buff, #MB_uart_rx_buff - 1) == bit.band(crc, 0xff)) and (string.byte(MB_uart_rx_buff, #MB_uart_rx_buff) == bit.rshift(crc, 8)) then local head = "" head = head..string.char(bit.rshift(MBtranId, 8)) head = head..string.char(bit.band(MBtranId, 0xff)) head = head..string.char(0x00) head = head..string.char(0x00) head = head..string.char(bit.rshift(#answer, 8)) head = head..string.char(bit.band(#answer, 0xff)) answer = head..answer MBsock:send(answer) end end tmr.unregister(5) modbus_tcp_frombuff() end function RS485_send(paket) gpio.write(RS485_TxOn_Pin, 1) uart.write(0, paket) tmr.delay(ByteTransmitTimeUs * #paket) gpio.write(RS485_TxOn_Pin, 0) MB_uart_rx_buff = "" uart.on("data", 1, function(data) MB_uart_rx_buff = MB_uart_rx_buff..data if (#MB_uart_rx_buff > 256) then MB_uart_rx_buff = "" end tmr.alarm(6, 5, tmr.ALARM_SINGLE, function() modbus_rtu_rx() end) end, 0) end function modbus_tcp_frombuff() MB_wait_rx = false if (#MB_tcp_rx_buff > 0) then modbus_tcp_rx(MB_tcp_rx_buff) MB_tcp_rx_buff = "" end end function modbus_tcp_rx(paket) uart_setup() local rtu_body = string.sub(paket, 7, #paket) MBtranId = (string.byte(paket, 1)*256) + string.byte(paket, 1) crc = process_crc(rtu_body) rtu_body = rtu_body..string.char(bit.band(crc, 0xff)) rtu_body = rtu_body..string.char(bit.rshift(crc, 8)) RS485_send(rtu_body) MB_wait_rx = true tmr.alarm(5, MB_wait_rx_time, tmr.ALARM_SINGLE, modbus_tcp_frombuff) end tmr.alarm(0, 5000, tmr.ALARM_AUTO, function() print("tmr0 "..wifi_status_old.." "..wifi.sta.status()) if wifi.sta.status() == 5 then if wifi_status_old ~= 5 then print(wifi.sta.getip()) MBserver = net.createServer(MODBUS_ServerMode, 30) MBserver:listen(MODBUS_ServerPort, function(c) c:on("receive", function(sock, payload) MBsock = sock if (MB_wait_rx) then MB_tcp_rx_buff = payload print("remember") else modbus_tcp_rx(payload) print("sent") end end) end) else end else if (MBserver ~= nil) then MBserver:close() MBsock = nil tmr.unregister(5) MB_uart_rx_buff = "" MB_tcp_rx_buff = "" MB_wait_rx = false end wifi.sta.connect() end wifi_status_old = wifi.sta.status() end)
