<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="100" name="help" color="7" fill="1" visible="no" active="yes"/>
<layer number="101" name="DOC" color="7" fill="1" visible="no" active="yes"/>
<layer number="102" name="bot_pads" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="S_DOKU" color="7" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="7" fill="1" visible="no" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DPACK">
<description>&lt;b&gt;DPAK&lt;/b&gt;&lt;p&gt;
PLASTIC PACKAGE CASE 369C-01&lt;br&gt;
Source: http://www.onsemi.co.jp .. LM317M-D.PDF</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="2" x="0" y="2.38" dx="5.8" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<smd name="3" x="2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
</packages>
<symbols>
<symbol name="78XX">
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<text x="2.54" y="-7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-4.318" size="1.524" layer="95">GND</text>
<text x="-4.445" y="-0.635" size="1.524" layer="95">IN</text>
<text x="0.635" y="-0.635" size="1.524" layer="95">OUT</text>
<pin name="IN" x="-7.62" y="0" visible="off" length="short" direction="in"/>
<pin name="GND" x="0" y="-7.62" visible="off" length="short" direction="in" rot="R90"/>
<pin name="OUT" x="7.62" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="79XX">
<wire x1="-5.08" y1="-2.54" x2="5.08" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="5.08" y1="5.08" x2="-5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-2.54" width="0.4064" layer="94"/>
<text x="2.54" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="6.35" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="2.794" size="1.524" layer="95">GND</text>
<pin name="GND" x="0" y="7.62" visible="off" length="short" direction="in" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="78XX_SMD" prefix="IC">
<gates>
<gate name="G$1" symbol="78XX" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DPACK">
<connects>
<connect gate="G$1" pin="GND" pad="2"/>
<connect gate="G$1" pin="IN" pad="1"/>
<connect gate="G$1" pin="OUT" pad="3"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="79XX_SMD" prefix="IC">
<gates>
<gate name="G$1" symbol="79XX" x="0" y="-2.54"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="GND" pad="1"/>
<connect gate="G$1" pin="IN" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="CT3216">
<description>&lt;b&gt;TANTALUM CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-1.651" y1="0.559" x2="-1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.559" x2="1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="0" x2="-1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="-0.97" y1="0.26" x2="-0.97" y2="-0.3" width="0.2032" layer="51"/>
<smd name="+" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="CT3528">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-1.637" y1="-1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="1.016" x2="1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-0.68" y1="0" x2="-1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.3" x2="-1" y2="-0.33" width="0.2032" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="CT6032">
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.932" y1="-1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-3.073" y1="1.067" x2="-3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="-2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="1.067" x2="3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="2.957" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-1.18" y1="0" x2="-2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="-1.8" y1="0.63" x2="-1.8" y2="-0.64" width="0.2032" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="CT7343">
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-3.592" y1="-2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-3.734" y1="1.143" x2="-3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="-3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="1.143" x2="3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="3.582" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-2.04" y1="0" x2="-3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="-2.55" y1="0.52" x2="-2.55" y2="-0.52" width="0.2032" layer="51"/>
<smd name="+" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="B45181A">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="B45181B">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="E1,8-4">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="E15-5">
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-4R">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.27" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.6" diameter="1.778"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.9304" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.9304"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-4">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E25-10">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.7" diameter="2.1844" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.7" diameter="2.1844"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E30-10">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16">
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-16">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18">
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30">
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5R">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E7,5-16">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB20D">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB25D">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB30D">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="085CS_1R">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012">
</package>
<package name="153CLV-1014">
</package>
<package name="175TMP-0808">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 reflow solder&lt;/b&gt;&lt;p&gt;KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 reflow solder&lt;/b&gt;&lt;p&gt;KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 reflow solder&lt;/b&gt;&lt;p&gt;KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="TT2D5L">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="E2,5-6E">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="SMC_A">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-1.45" y1="0.75" x2="1.45" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.75" x2="1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.75" x2="-1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.75" x2="-1.45" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1.6" y="0.975" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.4" y2="0.6" layer="51"/>
<rectangle x1="1.4" y1="-0.6" x2="1.6" y2="0.6" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="-0.75" x2="-0.8" y2="0.75" layer="51"/>
</package>
<package name="SMC_Z">
<description>&lt;b&gt;Chip Capacitor&lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194&lt;br&gt;
<wire x1="-0.9" y1="0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="-0.9" y1="0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<smd name="+" x="-1" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="-" x="1" y="0" dx="1" dy="1.2" layer="1"/>
<text x="-1" y="0.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.45" x2="-0.9" y2="0.45" layer="51"/>
<rectangle x1="0.9" y1="-0.45" x2="1" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-0.9" y1="-0.6" x2="-0.5" y2="0.6" layer="51"/>
</package>
<package name="SMC_P">
<wire x1="-1.675" y1="0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.675" y1="0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.575" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.575" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.275" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.45" x2="-1.7" y2="0.45" layer="51"/>
<rectangle x1="1.7" y1="-0.45" x2="1.8" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-1.65" y1="-0.75" x2="-1.075" y2="0.725" layer="51"/>
</package>
<package name="SMC_B">
<wire x1="-1.6" y1="1.35" x2="1.6" y2="1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.35" x2="1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.35" x2="-1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.35" x2="-1.6" y2="1.35" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="2.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-1.1" x2="-1.55" y2="1.1" layer="51"/>
<rectangle x1="1.55" y1="-1.1" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.6" y1="-1.35" x2="-0.95" y2="1.35" layer="51"/>
</package>
<package name="SMC_C">
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="SMC_D">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="SMC_E">
</package>
<package name="SANYO-OSCON_9E">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt;&lt;p&gt;
Source: e_os_all.pdf</description>
<wire x1="-3.55" y1="0" x2="-2.8" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9" width="0.2032" layer="21"/>
<pad name="-" x="-1.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.8" diameter="1.27"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SANYO-OSCON_9F">
<wire x1="-4.55" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9" width="0.2032" layer="21"/>
<pad name="-" x="-2.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_A">
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.4064" layer="51"/>
<circle x="0" y="0" radius="1.9" width="0.2032" layer="21"/>
<pad name="-" x="-1" y="0" drill="0.7" diameter="1.1"/>
<pad name="+" x="1" y="0" drill="0.7" diameter="1.1"/>
</package>
<package name="SANYO-OSCON_A'">
<pad name="-" x="-0.75" y="0" drill="0.6" diameter="1"/>
<pad name="+" x="0.75" y="0" drill="0.6" diameter="1"/>
</package>
<package name="SANYO-OSCON_B">
<wire x1="-1.9" y1="-0.4" x2="-1.9" y2="0.4" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.4" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_B'">
</package>
<package name="SANYO-OSCON_C">
<wire x1="-2.2" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.05" width="0.2032" layer="21"/>
<pad name="-" x="-1.25" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_C'">
<circle x="0" y="0" radius="3.0504" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_C6">
<pad name="-" x="-1.25" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.7" diameter="1.27"/>
<text x="-1.905" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.15" y="-2.1" curve="-41.039434"/>
<vertex x="-3" y="0.1" curve="-41.67409"/>
</polygon>
</package>
<package name="SANYO-OSCON_D">
</package>
<package name="SANYO-OSCON_E">
<wire x1="-3.5" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9003" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_E'">
</package>
<package name="SANYO-OSCON_E1">
<wire x1="-3.55" y1="0" x2="-2.75" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_E12">
<vertex x="-2.65" y="2.7"/>
<vertex x="-2.65" y="-2.75" curve="-41.038922"/>
<vertex x="-3.8" y="0" curve="-41.675057"/>
</polygon>
</package>
<package name="SANYO-OSCON_E13">
</polygon>
</package>
<package name="SANYO-OSCON_E7">
<pad name="-" x="-1.75" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-2.65" y="2.8"/>
<vertex x="-2.65" y="-2.8" curve="-41.039891"/>
<vertex x="-3.85" y="0" curve="-41.675747"/>
</polygon>
</package>
<package name="SANYO-OSCON_E9">
</polygon>
</package>
<package name="SANYO-OSCON_F">
<wire x1="-4.5" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_F'">
<wire x1="-3.55" y1="0" x2="-4.4" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9002" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_F0">
</package>
<package name="SANYO-OSCON_F13">
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.4" y="3.45"/>
<vertex x="-3.4" y="-3.4" curve="-41.039359"/>
<vertex x="-4.85" y="0" curve="-41.674636"/>
</polygon>
</package>
<package name="SANYO-OSCON_F8">
<pad name="-" x="-2.5" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-3.6" y="3.2"/>
<vertex x="-3.6" y="-3.25" curve="-41.039474"/>
<vertex x="-4.85" y="0" curve="-41.675359"/>
</polygon>
</package>
<package name="SANYO-OSCON_G">
<wire x1="-4.5" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="6.15" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_H">
<wire x1="-7" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="7.9001" width="0.2032" layer="21"/>
<pad name="-" x="-3.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="3.75" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_SMD_A5">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt; SMD type with conductive polymer electrolyte&lt;p&gt;
<wire x1="-2.05" y1="2.05" x2="1.25" y2="2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.05" x2="2.05" y2="1.25" width="0.2032" layer="21"/>
<wire x1="2.05" y1="1.25" x2="2.05" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="2.05" y1="-1.25" x2="1.25" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-2.05" x2="-2.05" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-2.05" x2="-2.05" y2="2.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.85" width="0.2032" layer="51"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="51">
<vertex x="-1.2" y="-1.35"/>
<vertex x="-1.2" y="1.35" curve="44.759919"/>
<vertex x="-1.8" y="0" curve="39.027281"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_B6">
<wire x1="-2.55" y1="2.55" x2="1.75" y2="2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.55" x2="2.55" y2="1.75" width="0.2032" layer="21"/>
<wire x1="2.55" y1="1.75" x2="2.55" y2="-1.75" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-1.75" x2="1.75" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="-2.55" x2="-2.55" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-2.55" x2="-2.55" y2="2.55" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.35" width="0.2032" layer="51"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.6" y="-1.65"/>
<vertex x="-1.6" y="1.65" curve="35.983944"/>
<vertex x="-2.3" y="0" curve="42.321615"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_C6">
<wire x1="-3.2" y1="3.2" x2="2.4" y2="3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.2" x2="3.2" y2="2.4" width="0.2032" layer="21"/>
<wire x1="3.2" y1="2.4" x2="3.2" y2="-2.4" width="0.2032" layer="51"/>
<wire x1="3.2" y1="-2.4" x2="2.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-3.2" x2="-3.2" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-3.2" x2="-3.2" y2="3.2" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.95" width="0.2032" layer="51"/>
<smd name="-" x="-2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="+" x="2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="1.9"/>
<vertex x="-2.2" y="-1.9" curve="-39.18521"/>
<vertex x="-2.85" y="0" curve="-36.094684"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E12">
<wire x1="-4.05" y1="4.05" x2="2.95" y2="4.05" width="0.2032" layer="21"/>
<wire x1="2.95" y1="4.05" x2="4.05" y2="2.95" width="0.2032" layer="21"/>
<wire x1="4.05" y1="2.95" x2="4.05" y2="-2.95" width="0.2032" layer="51"/>
<wire x1="2.95" y1="-4.05" x2="-4.05" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4.05" x2="-4.05" y2="4.05" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-2.95" x2="2.95" y2="-4.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="3.85" width="0.2032" layer="51"/>
<smd name="-" x="-3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<smd name="+" x="3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<text x="-3.81" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.6" y="-2.75"/>
<vertex x="-2.6" y="2.75" curve="44.955417"/>
<vertex x="-3.85" y="0" curve="45.23973"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E7">
<vertex x="-2.7" y="2.65"/>
<vertex x="-2.7" y="-2.65" curve="-47.290335"/>
<vertex x="-3.8" y="0" curve="-44.001093"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F12">
<wire x1="-5.05" y1="5.05" x2="3.95" y2="5.05" width="0.2032" layer="21"/>
<wire x1="3.95" y1="5.05" x2="5.05" y2="3.95" width="0.2032" layer="21"/>
<wire x1="5.05" y1="3.95" x2="5.05" y2="-3.95" width="0.2032" layer="51"/>
<wire x1="3.95" y1="-5.05" x2="-5.05" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.05" x2="-5.05" y2="5.05" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-3.95" x2="3.95" y2="-5.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="4.8" width="0.2032" layer="51"/>
<smd name="-" x="-4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<smd name="+" x="4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<text x="-5.08" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="-3.65"/>
<vertex x="-3.05" y="3.65" curve="48.708973"/>
<vertex x="-4.75" y="0" curve="43.982679"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F8">
<vertex x="-3.05" y="3.65" curve="41.376652"/>
<vertex x="-4.75" y="0" curve="43.010397"/>
</polygon>
</package>
<package name="UD-10X10_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 10 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="4.3" x2="5.1" y2="-4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-4.875" y1="0.85" x2="4.875" y2="0.85" width="0.1016" layer="21" curve="-160.259855"/>
<wire x1="-5.1" y1="0.875" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="4.875" y1="-0.85" x2="-4.875" y2="-0.85" width="0.1016" layer="21" curve="-160.259855"/>
<smd name="-" x="-3.95" y="0" dx="3.6" dy="1.3" layer="1"/>
<smd name="+" x="3.925" y="0" dx="3.6" dy="1.3" layer="1"/>
<text x="-5.08" y="5.715" size="1.016" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-4.05" y="2.8" curve="69.465624"/>
<vertex x="-4.05" y="-2.825"/>
</polygon>
</package>
<package name="UD-4X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 4 x 5.8 mm&lt;p&gt;
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1.3" x2="2.1" y2="-1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.875" x2="1.75" y2="0.875" width="0.1016" layer="21" curve="-126.263848"/>
<wire x1="-2.1" y1="0.9" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="1.75" y1="-0.875" x2="-1.75" y2="-0.875" width="0.1016" layer="21" curve="-126.263848"/>
<circle x="0" y="0" radius="1.9527" width="0.1016" layer="51"/>
<smd name="-" x="-1.425" y="0" dx="2" dy="1" layer="1"/>
<smd name="+" x="1.425" y="0" dx="2" dy="1" layer="1"/>
<text x="-1.905" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-1.55" y="1.175" curve="72.275472"/>
<vertex x="-1.55" y="-1.175"/>
</polygon>
</package>
<package name="UD-5X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
<package name="UD-6,3X7,7_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 7.7 mm&lt;p&gt;
</polygon>
</package>
<package name="UD-8X10_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
<package name="C0402">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603">
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1005">
</package>
<package name="C1206">
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C1210">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310">
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608">
</package>
<package name="C1812">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825">
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
</package>
<package name="C3216">
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225">
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564">
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="2.1844" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="2.1844" shape="octagon"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="0.8" diameter="2.54" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="0.8" diameter="2.54" shape="octagon"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-154X316">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
<package name="HPC0201">
<description>&lt;b&gt; &lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<smd name="1" x="-0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<smd name="2" x="0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<text x="-0.75" y="0.74" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.785" y="-1.865" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.305" y1="-0.15" x2="0.305" y2="0.15" layer="51"/>
</package>
<package name="C0201">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<smd name="1" x="-0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.1" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.1" layer="51"/>
</package>
<package name="C1808">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
<package name="C3640">
<wire x1="-3.8322" y1="5.0496" x2="3.8322" y2="5.0496" width="0.1016" layer="51"/>
<wire x1="-3.8322" y1="-5.0496" x2="3.8322" y2="-5.0496" width="0.1016" layer="51"/>
<smd name="1" x="-4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<smd name="2" x="4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<text x="-4.647" y="6.465" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.647" y="-7.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.57" y1="-5.1" x2="-3.05" y2="5.1" layer="51"/>
<rectangle x1="3.05" y1="-5.1" x2="4.5688" y2="5.1" layer="51"/>
</package>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1005">
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
</package>
<package name="R3225">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
</package>
<package name="R5025">
</package>
<package name="R5025W">
</package>
<package name="R6332">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" diameter="2.1844" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" diameter="2.1844" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" diameter="3" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" diameter="3" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="RTRIM3304W">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS&lt;p&gt;
0,1W 25%</description>
<wire x1="-1.9" y1="1.9" x2="1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="1.9" x2="1.9" y2="-1.1" width="0.254" layer="21"/>
<wire x1="1.9" y1="-1.1" x2="1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="-1.9" x2="0.65" y2="-1.9" width="0.254" layer="51"/>
<wire x1="0.65" y1="-1.9" x2="0.65" y2="-1.1" width="0.254" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="-0.65" y2="-1.1" width="0.254" layer="21"/>
<wire x1="-0.65" y1="-1.1" x2="-0.65" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-0.65" y1="-1.9" x2="-1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.9" x2="-1.9" y2="-1.1" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.1" x2="-1.9" y2="1.9" width="0.254" layer="21"/>
<circle x="0" y="0.4" radius="1.2" width="0.1016" layer="51"/>
<smd name="1" x="-1.25" y="-1.9" dx="1.4" dy="1.4" layer="1"/>
<smd name="3" x="1.25" y="-1.9" dx="1.4" dy="1.4" layer="1"/>
<smd name="2" x="0" y="1.6" dx="2.5" dy="1.4" layer="1"/>
<text x="-2.29" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.545" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1" y1="0.2" x2="1" y2="0.6" layer="51"/>
<rectangle x1="-0.2" y1="-0.6" x2="0.2" y2="1.4" layer="51"/>
</package>
<package name="RTRIM3165W">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; MEGGIT</description>
<wire x1="-1.125" y1="1.75" x2="-1.875" y2="1" width="0.254" layer="21"/>
<wire x1="-1.875" y1="1" x2="-1.875" y2="-1.375" width="0.254" layer="21"/>
<wire x1="-1.875" y1="-1.375" x2="-1.875" y2="-2.25" width="0.254" layer="51"/>
<wire x1="-1.875" y1="-2.25" x2="-1.625" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-1.625" y1="-2.5" x2="-1.125" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-1.125" y1="-2.5" x2="-1.125" y2="-1.625" width="0.254" layer="51"/>
<wire x1="-1.125" y1="-1.625" x2="-0.25" y2="-1.625" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-1.625" x2="-0.25" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-2.5" x2="0.25" y2="-2.5" width="0.254" layer="51"/>
<wire x1="0.25" y1="-2.5" x2="0.25" y2="-1.625" width="0.254" layer="51"/>
<wire x1="0.25" y1="-1.625" x2="1.125" y2="-1.625" width="0.254" layer="51"/>
<wire x1="1.125" y1="-1.625" x2="1.125" y2="-2.5" width="0.254" layer="51"/>
<wire x1="1.125" y1="-2.5" x2="1.625" y2="-2.5" width="0.254" layer="51"/>
<wire x1="1.625" y1="-2.5" x2="1.875" y2="-2.25" width="0.254" layer="51"/>
<wire x1="1.875" y1="-2.25" x2="1.875" y2="-1.625" width="0.254" layer="51"/>
<wire x1="1.875" y1="-1.625" x2="1.875" y2="1" width="0.254" layer="21"/>
<wire x1="1.875" y1="1" x2="1.125" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.125" y1="1.75" x2="-1.125" y2="1.75" width="0.254" layer="51"/>
<circle x="0" y="0" radius="1.3806" width="0.1016" layer="21"/>
<smd name="1" x="-1.35" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="0" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="3" x="1.35" y="-2" dx="0.8" dy="1.6" layer="1"/>
<smd name="4" x="0" y="1.8" dx="2" dy="1" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.125" x2="0.25" y2="1.125" layer="21"/>
<rectangle x1="-1.125" y1="-0.25" x2="1.125" y2="0.25" layer="21"/>
<hole x="0" y="0" drill="2"/>
</package>
<package name="RTRIM3202">
<wire x1="-1.6" y1="1.4" x2="-1.6" y2="-1.4" width="0.254" layer="21"/>
<wire x1="-1.6" y1="-1.4" x2="1.6" y2="-1.4" width="0.254" layer="51"/>
<wire x1="1.6" y1="-1.4" x2="1.6" y2="1.4" width="0.254" layer="21"/>
<wire x1="1.6" y1="1.4" x2="-1.6" y2="1.4" width="0.254" layer="51"/>
<wire x1="-1.6" y1="1.4" x2="-1" y2="1.4" width="0.254" layer="21"/>
<wire x1="1" y1="1.4" x2="1.6" y2="1.4" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-1.4" x2="0.3" y2="-1.4" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.6" dx="1.6" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.75" dx="0.9" dy="1.3" layer="1"/>
<smd name="3" x="0.95" y="-1.75" dx="0.9" dy="1.3" layer="1"/>
<text x="-1.99" y="-2.39" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.26" y="-2.39" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.2" y1="-1" x2="0.2" y2="1" layer="51"/>
</package>
<package name="RTRIM3314J">
0,25W, 20%&lt;br&gt;
Source: &lt;a href="http://www.bourns.com/pdfs/3314.pdf"&gt; Data sheet&lt;/a&gt;</description>
<wire x1="2.15" y1="2.15" x2="2.15" y2="-2.15" width="0.254" layer="51"/>
<wire x1="2.15" y1="-2.15" x2="-2.15" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="2.15" width="0.254" layer="51"/>
<wire x1="-2.15" y1="2.15" x2="2.15" y2="2.15" width="0.254" layer="51"/>
<wire x1="2.15" y1="-0.8" x2="2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.15" y1="2.15" x2="1.2" y2="2.15" width="0.254" layer="21"/>
<wire x1="-1.2" y1="2.15" x2="-2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="-2.15" y2="-0.8" width="0.254" layer="21"/>
<wire x1="0.95" y1="-2.15" x2="-0.95" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-0.5" y1="-0.9" x2="0.9" y2="0.5" width="0.1016" layer="21"/>
<wire x1="-0.85" y1="-0.55" x2="0.55" y2="0.85" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="1.1" width="0.1016" layer="21"/>
<smd name="3" x="-1.8" y="-2" dx="1.3" dy="2" layer="1" rot="R180"/>
<smd name="1" x="1.8" y="-2" dx="1.3" dy="2" layer="1" rot="R180"/>
<smd name="2" x="0" y="2" dx="2" dy="2" layer="1"/>
<text x="-2.64" y="-2.99" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-2.99" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM4G/J">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY</description>
<wire x1="-2.4" y1="2.4" x2="-2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="2.4" y1="2.4" x2="-2.4" y2="2.4" width="0.254" layer="51"/>
<wire x1="-2.1" y1="-2.4" x2="-2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="-2.4" x2="-2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="-2.4" y1="2.4" x2="-1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="2" y1="-2.4" x2="2.4" y2="-2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="-2.4" x2="2.4" y2="2.4" width="0.254" layer="21"/>
<wire x1="2.4" y1="2.4" x2="1.25" y2="2.4" width="0.254" layer="21"/>
<wire x1="-0.25" y1="-2.4" x2="0.25" y2="-2.4" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.85" width="0.1016" layer="21"/>
<smd name="1" x="-1.15" y="-2.115" dx="1.3" dy="1.3" layer="1"/>
<smd name="3" x="1.15" y="-2.115" dx="1.3" dy="1.3" layer="1"/>
<smd name="2" x="0" y="2.115" dx="2" dy="1.3" layer="1"/>
<text x="-2.875" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.045" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.3" y1="-0.2" x2="1.35" y2="0.2" layer="21"/>
<rectangle x1="-0.2" y1="-1.35" x2="0.2" y2="1.3" layer="21"/>
</package>
<package name="RTRIMCVR42A">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; AVX</description>
<wire x1="-1.9" y1="1.9" x2="-1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-1.9" x2="1.9" y2="-1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="-1.9" x2="1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="1.9" y1="1.9" x2="-1.9" y2="1.9" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-1.1" x2="0.6" y2="-1.1" width="0.8128" layer="51" curve="-302.779081" cap="flat"/>
<wire x1="-1.9" y1="-1.15" x2="-1.9" y2="1.9" width="0.254" layer="21"/>
<wire x1="-1.9" y1="1.9" x2="-1.35" y2="1.9" width="0.254" layer="21"/>
<wire x1="1.9" y1="-1.15" x2="1.9" y2="1.9" width="0.254" layer="21"/>
<wire x1="1.9" y1="1.9" x2="1.35" y2="1.9" width="0.254" layer="21"/>
<smd name="2" x="0" y="1.8" dx="2.3" dy="1.5" layer="1"/>
<smd name="1" x="-1.15" y="-2.05" dx="1.3" dy="1.4" layer="1"/>
<smd name="3" x="1.15" y="-2.05" dx="1.3" dy="1.4" layer="1"/>
<text x="-2.29" y="-2.69" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.51" y="-2.69" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.65" y1="-1.15" x2="0.65" y2="-0.75" layer="51"/>
<rectangle x1="-1.05" y1="-0.15" x2="1.05" y2="0.15" layer="21"/>
</package>
<package name="RTRIM3214W">
SMD Cermet trimmer</description>
<wire x1="-2.3" y1="-1.85" x2="-2.3" y2="1.85" width="0.254" layer="51"/>
<wire x1="-2.3" y1="1.85" x2="2.3" y2="1.85" width="0.254" layer="51"/>
<wire x1="2.3" y1="1.85" x2="2.3" y2="-1.85" width="0.254" layer="51"/>
<wire x1="2.3" y1="-1.85" x2="-2.3" y2="-1.85" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-1.85" x2="-2.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="-2.3" y1="1.85" x2="-1.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="2.3" y1="-1.85" x2="2.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="2.3" y1="1.85" x2="1.3" y2="1.85" width="0.254" layer="21"/>
<wire x1="-0.4" y1="-1.85" x2="0.4" y2="-1.85" width="0.254" layer="21"/>
<circle x="1.2" y="0.65" radius="0.7" width="0.1016" layer="51"/>
<smd name="1" x="-1.275" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="3" x="1.275" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0" y="1.45" dx="2" dy="1.6" layer="1"/>
<text x="-2.54" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="0.55" y1="0.55" x2="1.85" y2="0.75" layer="51"/>
<rectangle x1="-1.8" y1="-2.1" x2="-0.75" y2="-1.95" layer="51"/>
<rectangle x1="0.75" y1="-2.1" x2="1.8" y2="-1.95" layer="51"/>
<rectangle x1="-0.75" y1="1.95" x2="0.75" y2="2.1" layer="51"/>
</package>
<package name="RTRIM3224G">
Side Adjust</description>
<wire x1="2.25" y1="2.15" x2="2.25" y2="-2.15" width="0.254" layer="51"/>
<wire x1="2.25" y1="-2.15" x2="-2.25" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-2.15" x2="-2.25" y2="2.15" width="0.254" layer="51"/>
<wire x1="-2.25" y1="2.15" x2="2.25" y2="2.15" width="0.254" layer="51"/>
<wire x1="-0.5" y1="2.05" x2="-0.5" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="1.35" x2="-1.9" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-1.9" y1="1.35" x2="-1.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="-1.2" y1="2.15" x2="-2.25" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.25" y1="2.15" x2="-2.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-2.25" y1="-2.15" x2="-2" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-2.15" x2="0.3" y2="-2.15" width="0.254" layer="21"/>
<wire x1="1.2" y1="2.15" x2="2.25" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.25" y1="2.15" x2="2.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="2.25" y1="-2.15" x2="2" y2="-2.15" width="0.254" layer="21"/>
<circle x="-1.2" y="1.7" radius="0.2" width="0" layer="21"/>
<smd name="1" x="-1.15" y="-2.6" dx="1.27" dy="1.27" layer="1"/>
<smd name="3" x="1.15" y="-2.6" dx="1.27" dy="1.27" layer="1"/>
<smd name="2" x="0" y="2.6" dx="2" dy="1.27" layer="1"/>
<text x="-2.49" y="-3.205" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-3.205" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.65" y1="2.25" x2="0.65" y2="3" layer="51"/>
<rectangle x1="-1.6" y1="-3" x2="-0.7" y2="-2.25" layer="51"/>
<rectangle x1="0.7" y1="-3" x2="1.6" y2="-2.25" layer="51"/>
</package>
<package name="RTRIM3224J">
<wire x1="2.4" y1="2.3" x2="2.4" y2="-2.3" width="0.254" layer="51"/>
<wire x1="2.4" y1="-2.3" x2="-2.4" y2="-2.3" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-2.3" x2="-2.4" y2="2.3" width="0.254" layer="51"/>
<wire x1="-2.4" y1="2.3" x2="2.4" y2="2.3" width="0.254" layer="51"/>
<wire x1="-0.5" y1="2.2" x2="-0.5" y2="1.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.5" y1="1.6" x2="-1.9" y2="1.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-1.9" y1="1.6" x2="-1.9" y2="2.2" width="0.1016" layer="51" style="shortdash"/>
<wire x1="1.4" y1="2.3" x2="2.4" y2="2.3" width="0.254" layer="21" style="shortdash"/>
<wire x1="2.4" y1="2.3" x2="2.4" y2="-2.3" width="0.254" layer="21"/>
<wire x1="2.4" y1="-2.3" x2="2.2" y2="-2.3" width="0.254" layer="21"/>
<wire x1="-2.1" y1="-2.3" x2="-2.4" y2="-2.3" width="0.254" layer="21"/>
<wire x1="-2.4" y1="-2.3" x2="-2.4" y2="2.3" width="0.254" layer="21"/>
<wire x1="-2.4" y1="2.3" x2="-1.4" y2="2.3" width="0.254" layer="21"/>
<wire x1="0.2" y1="-2.3" x2="-0.2" y2="-2.3" width="0.254" layer="21"/>
<circle x="-1.2" y="1.9" radius="0.1414" width="0" layer="21"/>
<smd name="3" x="1.15" y="-2" dx="1.3" dy="2" layer="1"/>
<smd name="1" x="-1.15" y="-2" dx="1.3" dy="2" layer="1"/>
<text x="2.74" y="2.405" size="1.27" layer="25" rot="R270">&gt;NAME</text>
<text x="-4.01" y="2.405" size="1.27" layer="27" rot="R270">&gt;VALUE</text>
<rectangle x1="-0.6" y1="2.4" x2="0.6" y2="2.5" layer="51"/>
<rectangle x1="0.7" y1="-2.5" x2="1.6" y2="-2.4" layer="51"/>
<rectangle x1="-1.6" y1="-2.5" x2="-0.7" y2="-2.4" layer="51"/>
</package>
<package name="RTRIM3224X">
Top Adjust</description>
<wire x1="-2.25" y1="-1.6" x2="-2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="1.6" x2="2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="1.6" x2="2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="-1.6" x2="-2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-1.6" x2="-2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.25" y1="1.6" x2="-1.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="1.25" y1="1.6" x2="2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="1.6" x2="2.25" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-0.4" y1="-1.6" x2="0.4" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.2" y="0.6" radius="0.5" width="0.1016" layer="21"/>
<smd name="1" x="-1.27" y="-2.54" dx="1.32" dy="1.9" layer="1"/>
<smd name="3" x="1.27" y="-2.54" dx="1.32" dy="1.9" layer="1"/>
<smd name="2" x="0" y="2.54" dx="2" dy="2" layer="1"/>
<text x="-2.64" y="-3.455" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-3.455" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.7" y1="-2.85" x2="-0.9" y2="-1.7" layer="51"/>
<rectangle x1="0.9" y1="-2.85" x2="1.7" y2="-1.7" layer="51"/>
<rectangle x1="-0.65" y1="1.7" x2="0.65" y2="2.85" layer="51"/>
<rectangle x1="0.75" y1="0.5" x2="1.65" y2="0.7" layer="21"/>
</package>
<package name="RTRIM3103">
<wire x1="-1.45" y1="1.75" x2="-1.45" y2="-1.65" width="0.254" layer="51"/>
<wire x1="-1.45" y1="-1.65" x2="1.45" y2="-1.65" width="0.254" layer="51"/>
<wire x1="1.45" y1="-1.65" x2="1.45" y2="1.75" width="0.254" layer="51"/>
<wire x1="1.45" y1="1.75" x2="-1.45" y2="1.75" width="0.254" layer="51"/>
<wire x1="-1.45" y1="-0.4" x2="-1.45" y2="1.75" width="0.254" layer="21"/>
<wire x1="-1.45" y1="1.75" x2="-0.85" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.45" y1="-0.4" x2="1.45" y2="1.75" width="0.254" layer="21"/>
<wire x1="1.45" y1="1.75" x2="0.85" y2="1.75" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.15" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.3" dx="1.3" dy="1.3" layer="1"/>
<smd name="1" x="-1" y="-1.225" dx="1.2" dy="1.25" layer="1"/>
<smd name="3" x="1" y="-1.225" dx="1.2" dy="1.25" layer="1"/>
<text x="-1.905" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.175" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.15" y1="-0.15" x2="1.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-1.15" x2="0.15" y2="1.15" layer="51"/>
</package>
<package name="RTRIM5W">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
abgedichtet nach &lt;b&gt;IP67&lt;/b&gt;</description>
<wire x1="2.25" y1="1.6" x2="-2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="1.6" x2="-2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-1.6" x2="2.25" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.25" y1="-1.6" x2="2.25" y2="1.6" width="0.254" layer="51"/>
<wire x1="-1.25" y1="1.6" x2="-2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.25" y1="1.6" x2="-2.25" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-0.3" y1="-1.6" x2="0.3" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.55" y="0.95" radius="0.4" width="0.1016" layer="21"/>
<smd name="1" x="-1.25" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<smd name="3" x="1.25" y="-1.45" dx="1.3" dy="1.6" layer="1"/>
<text x="-2.625" y="-2.19" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.845" y="-2.19" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="1.15" y1="0.85" x2="1.95" y2="1.05" layer="21"/>
</package>
<package name="RTRIM5X">
<wire x1="2.35" y1="2.35" x2="-2.35" y2="2.35" width="0.254" layer="51"/>
<wire x1="-2.35" y1="2.35" x2="-2.35" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-2.35" y1="-2.35" x2="2.35" y2="-2.35" width="0.254" layer="51"/>
<wire x1="2.35" y1="-2.35" x2="2.35" y2="2.35" width="0.254" layer="51"/>
<wire x1="1.25" y1="2.35" x2="2.35" y2="2.35" width="0.254" layer="21"/>
<wire x1="2.35" y1="2.35" x2="2.35" y2="-2.35" width="0.254" layer="21"/>
<wire x1="2.35" y1="-2.35" x2="2.05" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-2.05" y1="-2.35" x2="-2.35" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-2.35" y1="-2.35" x2="-2.35" y2="2.35" width="0.254" layer="21"/>
<wire x1="-2.35" y1="2.35" x2="-1.25" y2="2.35" width="0.254" layer="21"/>
<wire x1="0.25" y1="-2.35" x2="-0.25" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-1.1" y1="2.25" x2="-1.1" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.1" y1="1.6" x2="-2.05" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-2.05" y1="1.6" x2="-2.05" y2="2.25" width="0.1016" layer="21"/>
<text x="-3.175" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.445" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIMTSM53YJ">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; VISHAY&lt;p&gt;
<wire x1="-2.25" y1="1.6" x2="-1.15" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="-1.6" x2="2.25" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.25" y1="1.6" x2="1.15" y2="1.6" width="0.254" layer="21"/>
<circle x="1.3" y="0.65" radius="0.7" width="0.1016" layer="51"/>
<smd name="2" x="0" y="1.45" dx="1.8" dy="1.6" layer="1"/>
<rectangle x1="-0.3" y1="1.7" x2="0.3" y2="1.9" layer="51"/>
<rectangle x1="-1.6" y1="-1.9" x2="-1" y2="-1.7" layer="51"/>
<rectangle x1="0.95" y1="-1.9" x2="1.55" y2="-1.7" layer="51"/>
<rectangle x1="1.2" y1="0" x2="1.4" y2="1.3" layer="21"/>
</package>
<package name="RTRIMTSM53YL">
<wire x1="-0.35" y1="-1.6" x2="0.35" y2="-1.6" width="0.254" layer="21"/>
<smd name="1" x="-1.25" y="-1.9" dx="1.3" dy="2" layer="1"/>
<smd name="3" x="1.25" y="-1.9" dx="1.3" dy="2" layer="1"/>
<smd name="2" x="0" y="1.9" dx="1.8" dy="2" layer="1"/>
<text x="-2.59" y="-2.555" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.86" y="-2.555" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3" y1="1.7" x2="0.3" y2="2.55" layer="51"/>
<rectangle x1="-1.55" y1="-2.55" x2="-0.95" y2="-1.7" layer="51"/>
<rectangle x1="0.95" y1="-2.55" x2="1.55" y2="-1.7" layer="51"/>
</package>
<package name="RTRIMTS63X">
<description>&lt;b&gt;Trimm resistror&lt;/b&gt; VISHAY&lt;p&gt;
seales container, solder immerson IP67</description>
<wire x1="3.3" y1="2.4" x2="-3.3" y2="2.4" width="0.254" layer="51"/>
<wire x1="-3.3" y1="2.4" x2="-3.3" y2="-2.4" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-2.4" x2="3.3" y2="-2.4" width="0.254" layer="51"/>
<wire x1="3.3" y1="-2.4" x2="3.3" y2="2.4" width="0.254" layer="51"/>
<wire x1="0.8" y1="2.4" x2="3.3" y2="2.4" width="0.254" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-0.8" y1="2.4" x2="-3.3" y2="2.4" width="0.254" layer="21"/>
<wire x1="-3.3" y1="2.4" x2="-3.3" y2="-2.4" width="0.254" layer="21"/>
<wire x1="-1.75" y1="-2.4" x2="1.75" y2="-2.4" width="0.254" layer="21"/>
<wire x1="4.3" y1="2.25" x2="3.4" y2="2.25" width="0.1016" layer="21"/>
<wire x1="4.3" y1="0.85" x2="4.3" y2="1.35" width="0.1016" layer="21"/>
<wire x1="4.3" y1="1.35" x2="4" y2="1.35" width="0.1016" layer="21"/>
<wire x1="4" y1="1.35" x2="4" y2="1.75" width="0.1016" layer="21"/>
<wire x1="4" y1="1.75" x2="4.3" y2="1.75" width="0.1016" layer="21"/>
<wire x1="4.3" y1="1.75" x2="4.3" y2="2.25" width="0.1016" layer="21"/>
<wire x1="4.3" y1="0.85" x2="3.4" y2="0.85" width="0.1016" layer="21"/>
<smd name="1" x="-2.55" y="-2.25" dx="1" dy="3" layer="1"/>
<smd name="2" x="0" y="2.25" dx="1" dy="3" layer="1"/>
<smd name="3" x="2.55" y="-2.25" dx="1" dy="3" layer="1"/>
<text x="-3.69" y="-3.34" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="6.06" y="-3.34" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="2.5" x2="0.25" y2="3.35" layer="51"/>
<rectangle x1="2.3" y1="-3.35" x2="2.8" y2="-2.5" layer="51"/>
<rectangle x1="-2.8" y1="-3.35" x2="-2.3" y2="-2.5" layer="51"/>
</package>
<package name="RTRIMTS63Y">
<wire x1="3.3" y1="2.35" x2="-3.3" y2="2.35" width="0.254" layer="51"/>
<wire x1="-3.3" y1="2.35" x2="-3.3" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-2.35" x2="3.3" y2="-2.35" width="0.254" layer="51"/>
<wire x1="3.3" y1="-2.35" x2="3.3" y2="2.35" width="0.254" layer="51"/>
<wire x1="0.75" y1="2.35" x2="3.3" y2="2.35" width="0.254" layer="21"/>
<wire x1="3.3" y1="2.35" x2="3.3" y2="-2.35" width="0.254" layer="21"/>
<wire x1="1.75" y1="-2.35" x2="-1.75" y2="-2.35" width="0.254" layer="21"/>
<wire x1="-3.3" y1="-2.35" x2="-3.3" y2="2.35" width="0.254" layer="21"/>
<wire x1="-3.3" y1="2.35" x2="-0.75" y2="2.35" width="0.254" layer="21"/>
<circle x="-2.15" y="1.5" radius="0.6" width="0.1016" layer="21"/>
<text x="-3.74" y="-3.69" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.21" y="-3.69" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7" y1="1.4" x2="-1.6" y2="1.6" layer="21"/>
<rectangle x1="-0.3" y1="2.45" x2="0.3" y2="3" layer="51"/>
<rectangle x1="-2.85" y1="-3" x2="-2.25" y2="-2.45" layer="51"/>
<rectangle x1="2.25" y1="-3" x2="2.85" y2="-2.45" layer="51"/>
</package>
<package name="RTRIMTS63Z">
<wire x1="-3.3" y1="3.3" x2="-3.3" y2="-3.3" width="0.254" layer="51"/>
<wire x1="-3.3" y1="-3.3" x2="3.3" y2="-3.3" width="0.254" layer="51"/>
<wire x1="3.3" y1="-3.3" x2="3.3" y2="3.3" width="0.254" layer="51"/>
<wire x1="3.3" y1="3.3" x2="-3.3" y2="3.3" width="0.254" layer="51"/>
<wire x1="-0.75" y1="3.3" x2="-3.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="-3.3" y2="-3.3" width="0.254" layer="21"/>
<wire x1="-1.75" y1="-3.3" x2="1.75" y2="-3.3" width="0.254" layer="21"/>
<wire x1="3.3" y1="-3.3" x2="3.3" y2="3.3" width="0.254" layer="21"/>
<wire x1="3.3" y1="3.3" x2="0.75" y2="3.3" width="0.254" layer="21"/>
<wire x1="-2.95" y1="3.45" x2="-2.95" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="4.1" x2="-2.4" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-2.4" y1="4.1" x2="-2.4" y2="3.85" width="0.1016" layer="21"/>
<wire x1="-2.4" y1="3.85" x2="-1.8" y2="3.85" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="3.85" x2="-1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-1.8" y1="4.1" x2="-1.25" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-1.25" y1="4.1" x2="-1.25" y2="3.4" width="0.1016" layer="21"/>
<smd name="1" x="-2.55" y="-3.15" dx="1" dy="3" layer="1"/>
<smd name="2" x="0" y="3.15" dx="1" dy="3" layer="1"/>
<smd name="3" x="2.55" y="-3.15" dx="1" dy="3" layer="1"/>
<text x="-3.84" y="-3.44" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.16" y="-3.44" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3" y1="3.4" x2="0.3" y2="4.4" layer="51"/>
<rectangle x1="-2.85" y1="-4.4" x2="-2.25" y2="-3.4" layer="51"/>
<rectangle x1="2.25" y1="-4.4" x2="2.85" y2="-3.4" layer="51"/>
</package>
<package name="RTRIM3296P">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS&lt;p&gt;</description>
<wire x1="4.15" y1="4.35" x2="-5.1" y2="4.35" width="0.254" layer="21"/>
<wire x1="-5.1" y1="4.35" x2="-5.1" y2="-4.35" width="0.254" layer="21"/>
<wire x1="-5.1" y1="-4.35" x2="4.15" y2="-4.35" width="0.254" layer="21"/>
<wire x1="4.15" y1="-4.35" x2="4.15" y2="4.35" width="0.254" layer="21"/>
<wire x1="4.25" y1="-1.45" x2="5.6" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="5.6" y1="-1.45" x2="5.6" y2="-2.3" width="0.1524" layer="21"/>
<wire x1="5.6" y1="-2.3" x2="5.2" y2="-2.3" width="0.1524" layer="21"/>
<wire x1="5.2" y1="-2.3" x2="5.2" y2="-2.75" width="0.1524" layer="21"/>
<wire x1="5.2" y1="-2.75" x2="5.6" y2="-2.75" width="0.1524" layer="21"/>
<wire x1="5.6" y1="-2.75" x2="5.6" y2="-3.65" width="0.1524" layer="21"/>
<wire x1="5.6" y1="-3.65" x2="4.25" y2="-3.65" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.6096"/>
<pad name="2" x="2.54" y="0" drill="0.6096"/>
<pad name="3" x="0" y="2.54" drill="0.6096"/>
<text x="-5.48" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-2.17" y="-3.45" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM3296W">
<wire x1="-2.25" y1="4.35" x2="2.25" y2="4.35" width="0.254" layer="21"/>
<wire x1="2.25" y1="4.35" x2="2.25" y2="-4.35" width="0.254" layer="21"/>
<wire x1="2.25" y1="-4.35" x2="-2.25" y2="-4.35" width="0.254" layer="21"/>
<wire x1="-2.25" y1="-4.35" x2="-2.25" y2="4.35" width="0.254" layer="21"/>
<circle x="0" y="-2.55" radius="1.1011" width="0.1524" layer="21"/>
<pad name="2" x="0" y="0" drill="0.6096"/>
<text x="-2.65" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.95" y="-4.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.15" y1="-3.6" x2="0.15" y2="-1.5" layer="51"/>
</package>
<package name="RTRIM3296X">
<wire x1="-1.1" y1="4.4" x2="-1.1" y2="5.6" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="5.6" x2="-0.25" y2="5.6" width="0.1524" layer="21"/>
<wire x1="-0.25" y1="5.6" x2="-0.25" y2="5.1" width="0.1524" layer="21"/>
<wire x1="-0.25" y1="5.1" x2="0.25" y2="5.1" width="0.1524" layer="21"/>
<wire x1="0.25" y1="5.1" x2="0.25" y2="5.6" width="0.1524" layer="21"/>
<wire x1="0.25" y1="5.6" x2="1.1" y2="5.6" width="0.1524" layer="21"/>
<wire x1="1.1" y1="5.6" x2="1.1" y2="4.4" width="0.1524" layer="21"/>
</package>
<package name="RTRIM3296Y">
<circle x="0" y="-2.55" radius="1.1011" width="0.1524" layer="51"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6096"/>
<pad name="2" x="-1.27" y="0" drill="0.6096"/>
<pad name="3" x="1.27" y="2.54" drill="0.6096"/>
<rectangle x1="-0.15" y1="-3.6" x2="0.15" y2="-1.5" layer="21"/>
</package>
<package name="RTRIM74W">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;</description>
<wire x1="2.15" y1="-3.1" x2="2.15" y2="3.1" width="0.1524" layer="21"/>
<wire x1="2.15" y1="3.1" x2="-2" y2="3.1" width="0.1524" layer="21"/>
<wire x1="-2" y1="3.1" x2="-2" y2="-3.1" width="0.1524" layer="21"/>
<wire x1="-2" y1="-3.1" x2="2.15" y2="-3.1" width="0.1524" layer="21"/>
<circle x="1.3" y="2.25" radius="0.5522" width="0.1016" layer="21"/>
<pad name="1" x="-1.25" y="-2.5" drill="0.6096"/>
<pad name="2" x="1.25" y="0" drill="0.6096"/>
<pad name="3" x="-1.25" y="2.5" drill="0.6096"/>
<text x="-2.3" y="-3.15" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.7" y="-3.15" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="0.8" y1="2.1" x2="1.8" y2="2.4" layer="21"/>
</package>
<package name="RTRIM74X">
<wire x1="0.75" y1="-3.15" x2="0.75" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="0.75" y1="-3.7" x2="1.15" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.15" y1="-3.7" x2="1.15" y2="-3.5" width="0.1016" layer="25"/>
<wire x1="1.15" y1="-3.5" x2="1.45" y2="-3.5" width="0.1016" layer="25"/>
<wire x1="1.45" y1="-3.5" x2="1.45" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.45" y1="-3.7" x2="1.85" y2="-3.7" width="0.1016" layer="25"/>
<wire x1="1.85" y1="-3.7" x2="1.85" y2="-3.15" width="0.1016" layer="25"/>
</package>
<package name="RTRIM3224W">
<wire x1="2.3" y1="1.6" x2="2.3" y2="-1.6" width="0.254" layer="51"/>
<wire x1="2.3" y1="-1.6" x2="-2.3" y2="-1.6" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-1.6" x2="-2.3" y2="1.6" width="0.254" layer="51"/>
<wire x1="-2.3" y1="1.6" x2="2.3" y2="1.6" width="0.254" layer="51"/>
<wire x1="1.3" y1="1.6" x2="2.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="2.3" y1="1.6" x2="2.3" y2="-1.6" width="0.254" layer="21"/>
<wire x1="2.3" y1="-1.6" x2="2.1" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-2.1" y1="-1.6" x2="-2.3" y2="-1.6" width="0.254" layer="21"/>
<wire x1="-2.3" y1="-1.6" x2="-2.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="-2.3" y1="1.6" x2="-1.3" y2="1.6" width="0.254" layer="21"/>
<wire x1="0.35" y1="-1.6" x2="-0.35" y2="-1.6" width="0.254" layer="21"/>
<circle x="1.2" y="0.65" radius="0.65" width="0.1016" layer="51"/>
<text x="-2.59" y="-2.255" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.86" y="-2.255" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.7" y1="1.7" x2="0.7" y2="1.95" layer="51"/>
<rectangle x1="0.85" y1="-1.95" x2="1.65" y2="-1.7" layer="51"/>
<rectangle x1="-1.65" y1="-1.95" x2="-0.85" y2="-1.7" layer="51"/>
<rectangle x1="0.6" y1="0.55" x2="1.8" y2="0.75" layer="51"/>
</package>
<package name="RTRIM3339P">
Cermet MIL-R-22097</description>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.4199" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.6096"/>
<pad name="2" x="0" y="-2.54" drill="0.6096"/>
<pad name="3" x="2.54" y="0" drill="0.6096"/>
<text x="-2.515" y="4.205" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.515" y="-5.605" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.016" y1="-0.254" x2="1.016" y2="0.254" layer="21"/>
<rectangle x1="-0.254" y1="-1.016" x2="0.254" y2="1.016" layer="21"/>
</package>
<package name="RTRIM64P">
<wire x1="-4.15" y1="4.8" x2="4.8" y2="4.8" width="0.254" layer="21"/>
<wire x1="4.8" y1="4.8" x2="4.8" y2="-4.8" width="0.254" layer="21"/>
<wire x1="4.8" y1="-4.8" x2="-4.15" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-4.8" y1="-3.9" x2="-4.15" y2="-3.25" width="0.254" layer="21"/>
<wire x1="-4.15" y1="-3.25" x2="-4.15" y2="3.25" width="0.254" layer="21"/>
<wire x1="-4.15" y1="3.25" x2="-4.8" y2="3.9" width="0.254" layer="21"/>
<wire x1="-4.8" y1="3.9" x2="-4.8" y2="4.15" width="0.254" layer="21"/>
<wire x1="-4.8" y1="4.15" x2="-4.15" y2="4.8" width="0.254" layer="21"/>
<wire x1="4.95" y1="-2.25" x2="6.15" y2="-2.25" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-2.25" x2="6.15" y2="-3.05" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-3.05" x2="5.7" y2="-3.05" width="0.1524" layer="21"/>
<wire x1="5.7" y1="-3.05" x2="5.7" y2="-3.6" width="0.1524" layer="21"/>
<wire x1="5.7" y1="-3.6" x2="6.15" y2="-3.6" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-3.6" x2="6.15" y2="-4.45" width="0.1524" layer="21"/>
<wire x1="6.15" y1="-4.45" x2="4.95" y2="-4.45" width="0.1524" layer="21"/>
<wire x1="-4.8" y1="-4.15" x2="-4.8" y2="-3.9" width="0.254" layer="21"/>
<wire x1="-4.15" y1="-4.8" x2="-4.8" y2="-4.15" width="0.254" layer="21"/>
<text x="-4.75" y="-2.65" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-1.65" y="-3.2" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM64W">
<wire x1="2.52" y1="-4.8" x2="-2.03" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="-4.8" x2="-2.03" y2="4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="4.8" x2="2.52" y2="4.8" width="0.254" layer="21"/>
<wire x1="2.52" y1="4.8" x2="2.52" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="3.2" x2="2.27" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="3.2" x2="2.27" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="-3.2" x2="2.52" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="-3.2" x2="2.52" y2="-4.8" width="0.254" layer="21"/>
<circle x="-0.58" y="3.3" radius="1.1" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6" diameter="1.9304"/>
<pad name="2" x="1.27" y="0" drill="0.6" diameter="1.9304"/>
<pad name="3" x="1.27" y="2.54" drill="0.6" diameter="1.9304"/>
<text x="-2.62" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.35" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.78" y1="2.25" x2="-0.38" y2="4.35" layer="21"/>
</package>
<package name="RTRIM64X">
<wire x1="-1.83" y1="4.95" x2="-1.83" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.83" y1="6.15" x2="-1.03" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.03" y1="6.15" x2="-1.03" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-1.03" y1="5.7" x2="-0.48" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-0.48" y1="5.7" x2="-0.48" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-0.48" y1="6.15" x2="0.37" y2="6.15" width="0.1524" layer="21"/>
<wire x1="0.37" y1="6.15" x2="0.37" y2="4.95" width="0.1524" layer="21"/>
<pad name="2" x="1.27" y="0" drill="0.6096"/>
<text x="-2.43" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.07" y="-3.4" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM64Y">
<wire x1="1.05" y1="-4.8" x2="-3.3" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="-4.8" x2="-3.3" y2="4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="4.8" x2="1.05" y2="4.8" width="0.254" layer="21"/>
<wire x1="1.05" y1="4.8" x2="1.05" y2="3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="3.2" x2="0.8" y2="3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="3.2" x2="0.8" y2="-3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="-3.2" x2="1.05" y2="-3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="-3.2" x2="1.05" y2="-4.8" width="0.254" layer="21"/>
<circle x="-1.9" y="-3.35" radius="1.1" width="0.1524" layer="21"/>
<pad name="2" x="-2.54" y="0" drill="0.6096"/>
<text x="-3.84" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.75" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-4.4" x2="-1.7" y2="-2.3" layer="21"/>
</package>
<package name="RTRIM64Z">
<wire x1="-3.1" y1="4.95" x2="-3.1" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-3.1" y1="6.15" x2="-2.3" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="6.15" x2="-2.3" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="5.7" x2="-1.75" y2="5.7" width="0.1524" layer="21"/>
<wire x1="-1.75" y1="5.7" x2="-1.75" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-1.75" y1="6.15" x2="-0.9" y2="6.15" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="6.15" x2="-0.9" y2="4.95" width="0.1524" layer="21"/>
<text x="-3.65" y="-4.9" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.69" y="-4.92" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIM3059Y">
waschfest MIL-R-22097</description>
<wire x1="-16.37" y1="2.2" x2="-16.37" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-16.37" y1="-2.2" x2="-6.69" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.81" y1="-2.2" x2="15.36" y2="-2.2" width="0.254" layer="21"/>
<wire x1="15.36" y1="-2.2" x2="15.36" y2="2.2" width="0.254" layer="21"/>
<wire x1="15.36" y1="2.2" x2="8.81" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.81" y1="2.2" x2="8.71" y2="2.1" width="0.254" layer="21"/>
<wire x1="8.71" y1="2.1" x2="-6.59" y2="2.1" width="0.254" layer="21"/>
<wire x1="-6.59" y1="2.1" x2="-6.69" y2="2.2" width="0.254" layer="21"/>
<wire x1="-6.69" y1="2.2" x2="-16.37" y2="2.2" width="0.254" layer="21"/>
<wire x1="15.46" y1="1.35" x2="16.91" y2="1.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="1.35" x2="16.91" y2="0.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="0.35" x2="16.41" y2="0.35" width="0.1524" layer="21"/>
<wire x1="16.41" y1="0.35" x2="16.41" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="16.41" y1="-0.35" x2="16.91" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="-0.35" x2="16.91" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="16.91" y1="-1.35" x2="15.46" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="-6.59" y1="-2.1" x2="-6.69" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.71" y1="-2.1" x2="8.81" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.71" y1="-2.1" x2="-6.59" y2="-2.1" width="0.254" layer="21"/>
<pad name="1" x="-6.35" y="1.27" drill="0.9"/>
<pad name="2" x="3.81" y="-1.27" drill="0.9"/>
<pad name="3" x="8.89" y="1.27" drill="0.9"/>
<text x="-16.32" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.49" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIM70Y">
</package>
<package name="RTRIM3374">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; BOURNS</description>
<wire x1="-1.9" y1="2.35" x2="1.9" y2="2.35" width="0.254" layer="51"/>
<wire x1="1.9" y1="2.35" x2="1.9" y2="-2.35" width="0.254" layer="51"/>
<wire x1="1.9" y1="-2.35" x2="0.6" y2="-2.35" width="0.254" layer="51"/>
<wire x1="0.6" y1="-2.35" x2="0.6" y2="-2.15" width="0.254" layer="51"/>
<wire x1="0.6" y1="-2.15" x2="-0.6" y2="-2.15" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-2.15" x2="-0.6" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-0.6" y1="-2.35" x2="-1.9" y2="-2.35" width="0.254" layer="51"/>
<wire x1="-1.9" y1="-2.35" x2="-1.9" y2="2.35" width="0.254" layer="51"/>
<wire x1="-0.25" y1="-2.15" x2="0.25" y2="-2.15" width="0.254" layer="21"/>
<wire x1="-1.9" y1="-1.15" x2="-1.9" y2="2.35" width="0.254" layer="21"/>
<wire x1="-1.9" y1="2.35" x2="-1.2" y2="2.35" width="0.254" layer="21"/>
<wire x1="1.2" y1="2.35" x2="1.9" y2="2.35" width="0.254" layer="21"/>
<wire x1="1.9" y1="2.35" x2="1.9" y2="-1.15" width="0.254" layer="21"/>
<circle x="0" y="0" radius="1.65" width="0.1524" layer="51"/>
<smd name="2" x="0" y="2.1" dx="1.98" dy="2.17" layer="1"/>
<smd name="1" x="-1.25" y="-2.5" dx="1.5" dy="2.2" layer="1"/>
<smd name="3" x="1.25" y="-2.5" dx="1.5" dy="2.2" layer="1"/>
<text x="-2.2" y="-2.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.55" y="-2.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.3" x2="0.25" y2="1.3" layer="51"/>
<rectangle x1="-1.3" y1="-0.2" x2="1.3" y2="0.3" layer="51"/>
</package>
<package name="RTRIM3299W">
<wire x1="-2.78" y1="4.35" x2="3.07" y2="4.35" width="0.254" layer="21"/>
<wire x1="3.07" y1="4.35" x2="3.07" y2="-4.35" width="0.254" layer="21"/>
<wire x1="3.07" y1="-4.35" x2="-2.78" y2="-4.35" width="0.254" layer="21"/>
<wire x1="-2.78" y1="-4.35" x2="-2.78" y2="4.35" width="0.254" layer="21"/>
<circle x="-1.23" y="2.75" radius="1.1011" width="0.1524" layer="21"/>
<text x="-3.38" y="-4.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.77" y="-4.5" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.38" y1="1.7" x2="-1.08" y2="3.8" layer="21"/>
</package>
<package name="RTRIM43P">
<wire x1="-9.2" y1="2.2" x2="-9.2" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-9.2" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="-2.2" x2="8.1" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-9.2" y2="2.2" width="0.254" layer="21"/>
<wire x1="8.2" y1="1.35" x2="9.65" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="1.35" x2="9.65" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="0.35" x2="9.15" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="0.35" x2="9.15" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.15" y1="-0.35" x2="9.65" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-0.35" x2="9.65" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.65" y1="-1.35" x2="8.2" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.9"/>
<pad name="2" x="0" y="-1.27" drill="0.9"/>
<pad name="3" x="5.08" y="1.27" drill="0.9"/>
<text x="-9.15" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-6.3" y="0" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIM3006P">
<wire x1="-10.6" y1="2.25" x2="-10.6" y2="-2.25" width="0.254" layer="21"/>
<wire x1="-10.6" y1="-2.25" x2="8.25" y2="-2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="-2.25" x2="8.25" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.25" y1="2.25" x2="-10.6" y2="2.25" width="0.254" layer="21"/>
<wire x1="8.35" y1="1.35" x2="9.8" y2="1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="1.35" x2="9.8" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="0.35" x2="9.3" y2="0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="0.35" x2="9.3" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.3" y1="-0.35" x2="9.8" y2="-0.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-0.35" x2="9.8" y2="-1.35" width="0.1524" layer="21"/>
<wire x1="9.8" y1="-1.35" x2="8.35" y2="-1.35" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="1.27" drill="0.6096"/>
<pad name="2" x="0" y="-1.27" drill="0.6096"/>
<pad name="3" x="5.08" y="1.27" drill="0.6096"/>
<text x="-10.7" y="2.7" size="1.27" layer="25">&gt;NAME</text>
<text x="-10.05" y="-1.65" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIMT18">
abgedichtet nach IP67</description>
<wire x1="-10.75" y1="2.2" x2="-10.75" y2="-2.2" width="0.254" layer="21"/>
<wire x1="-10.75" y1="-2.2" x2="8.1" y2="-2.2" width="0.254" layer="21"/>
<wire x1="8.1" y1="2.2" x2="-10.75" y2="2.2" width="0.254" layer="21"/>
<text x="-10.2" y="-1.65" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RTRIMT93XA">
Cermet, abgedichtet nach IP67</description>
<wire x1="2.15" y1="-4.75" x2="2.15" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.15" y1="4.75" x2="-2.55" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="4.75" x2="-2.55" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.55" y1="-4.75" x2="2.15" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-0.3" y1="4.9" x2="-0.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.3" y1="6.05" x2="-1.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="6.05" x2="-1.1" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.1" y1="5.85" x2="-1.5" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="5.85" x2="-1.5" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="6.05" x2="-2.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-2.3" y1="6.05" x2="-2.3" y2="4.9" width="0.1524" layer="21"/>
<text x="-3.04" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.01" y="-4.89" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="RTRIMT93XB">
<wire x1="2.35" y1="-4.75" x2="2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="2.35" y1="4.75" x2="-2.35" y2="4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="4.75" x2="-2.35" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-2.35" y1="-4.75" x2="2.35" y2="-4.75" width="0.254" layer="21"/>
<wire x1="-0.1" y1="4.9" x2="-0.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.1" y1="6.05" x2="-0.9" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="6.05" x2="-0.9" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-0.9" y1="5.85" x2="-1.3" y2="5.85" width="0.1524" layer="21"/>
<wire x1="-1.3" y1="5.85" x2="-1.3" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-1.3" y1="6.05" x2="-2.1" y2="6.05" width="0.1524" layer="21"/>
<wire x1="-2.1" y1="6.05" x2="-2.1" y2="4.9" width="0.1524" layer="21"/>
<text x="-2.79" y="-4.89" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="RTRIMT93YA">
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="21" curve="-311.390901"/>
<wire x1="-0.75" y1="2.6" x2="-0.3" y2="3.3" width="0.1524" layer="51" curve="48.609099"/>
<rectangle x1="-1.45" y1="2.5" x2="-1.15" y2="4.4" layer="21"/>
</package>
<package name="RTRIMT93YB">
<circle x="-1.05" y="3.45" radius="1.0049" width="0.1524" layer="21"/>
<rectangle x1="-1.2" y1="2.5" x2="-0.9" y2="4.4" layer="21"/>
</package>
<package name="RTRIM3314G">
<wire x1="2.15" y1="-2.15" x2="2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="2.15" y1="2.15" x2="1.3" y2="2.15" width="0.254" layer="21"/>
<wire x1="-1.3" y1="2.15" x2="-2.15" y2="2.15" width="0.254" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="-2.15" y2="-2.15" width="0.254" layer="21"/>
<wire x1="0.1" y1="-2.15" x2="-0.1" y2="-2.15" width="0.254" layer="21"/>
<smd name="3" x="-1.15" y="-2.75" dx="1.3" dy="1.3" layer="1" rot="R180"/>
<smd name="1" x="1.15" y="-2.75" dx="1.3" dy="1.3" layer="1" rot="R180"/>
<smd name="2" x="0" y="2.75" dx="2" dy="1.3" layer="1"/>
</package>
<package name="C025_050-025X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<pad name="3" x="3.81" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-063X106">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.6" diameter="2.1844" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.6" diameter="2.1844" shape="octagon"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050_075-032X103">
<wire x1="-4.3815" y1="1.5875" x2="2.4765" y2="1.5875" width="0.1524" layer="21"/>
<wire x1="2.4765" y1="-1.5875" x2="-4.3815" y2="-1.5875" width="0.1524" layer="21"/>
<wire x1="-4.6355" y1="1.3335" x2="-4.6355" y2="-1.3335" width="0.1524" layer="21"/>
<wire x1="2.4765" y1="1.5875" x2="2.7305" y2="1.3335" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.6355" y1="1.3335" x2="-4.3815" y2="1.5875" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.4765" y1="-1.5875" x2="2.7305" y2="-1.3335" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.6355" y1="-1.3335" x2="-4.3815" y2="-1.5875" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.5715" y1="0" x2="-0.6985" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6985" y1="0" x2="-0.6985" y2="1.0795" width="0.254" layer="21"/>
<wire x1="-0.6985" y1="0" x2="-0.6985" y2="-1.0795" width="0.254" layer="21"/>
<wire x1="-1.2065" y1="1.0795" x2="-1.2065" y2="0" width="0.254" layer="21"/>
<wire x1="-1.2065" y1="0" x2="-1.2065" y2="-1.0795" width="0.254" layer="21"/>
<wire x1="-1.2065" y1="0" x2="-2.6035" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.6035" y1="0" x2="-2.9845" y2="0" width="0.1524" layer="51"/>
<wire x1="5.2705" y1="1.3335" x2="5.2705" y2="-1.3335" width="0.1524" layer="21"/>
<wire x1="5.0165" y1="1.5875" x2="5.2705" y2="1.3335" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.0165" y1="-1.5875" x2="5.2705" y2="-1.3335" width="0.1524" layer="21" curve="90"/>
<wire x1="3.1115" y1="1.5875" x2="5.0165" y2="1.5875" width="0.1524" layer="21"/>
<wire x1="5.0165" y1="-1.5875" x2="3.1115" y2="-1.5875" width="0.1524" layer="21"/>
<wire x1="2.7305" y1="1.3335" x2="2.7305" y2="1.0795" width="0.1524" layer="21"/>
<wire x1="2.7305" y1="-1.0795" x2="2.7305" y2="-1.3335" width="0.1524" layer="21"/>
<wire x1="2.7305" y1="0.5715" x2="2.7305" y2="-0.5715" width="0.1524" layer="21"/>
<wire x1="2.0955" y1="0" x2="2.6035" y2="0" width="0.1524" layer="51"/>
<wire x1="2.6035" y1="0" x2="3.1115" y2="0" width="0.1524" layer="21"/>
<wire x1="3.1115" y1="0" x2="3.6195" y2="0" width="0.1524" layer="51"/>
<wire x1="1.0795" y1="0" x2="-0.5715" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-3.4925" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<pad name="3" x="4.1275" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<pad name="2" x="1.5875" y="0" drill="0.7" diameter="1.6764" shape="octagon"/>
<text x="-4.3815" y="1.9685" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.3815" y="-3.1115" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0204/7">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.6" diameter="1.778" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.6" diameter="2.1844" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.6" diameter="2.1844" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.7" diameter="2.54" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.7" diameter="2.54" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="P128-50">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.667" y="0" drill="0.6" diameter="2.1844"/>
<pad name="-" x="2.667" y="0" drill="0.6" diameter="2.1844" shape="octagon"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="E2,5-7">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.6" diameter="1.9304"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E35-14">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="0.8" diameter="3.81"/>
<pad name="-" x="17.78" y="0" drill="0.8" diameter="3.81" shape="octagon"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="EB22,5D">
grid 10.16 mm, diameter 22.5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="0.8" diameter="4.5974" shape="octagon"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="CPOL">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<text x="1.143" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<text x="1.143" y="-4.5974" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="C-EU">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="R-EU">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="R-TRIM">
<wire x1="0.762" y1="2.54" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="2.54" x2="-0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-1.8796" y2="1.7526" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="-0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-2.54" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.286" y1="1.27" x2="-1.651" y2="2.413" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-3.048" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-2.032" y2="-1.524" width="0.1524" layer="94"/>
<text x="-5.969" y="-3.81" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="E" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="S" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="CPOL-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="CPOL" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCA" package="SMC_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCZ" package="SMC_Z">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCP" package="SMC_P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCB" package="SMC_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCC" package="SMC_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCD" package="SMC_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCE" package="SMC_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_9E" package="SANYO-OSCON_9E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_9F" package="SANYO-OSCON_9F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_A" package="SANYO-OSCON_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_A'" package="SANYO-OSCON_A'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_B" package="SANYO-OSCON_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_B'" package="SANYO-OSCON_B'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C" package="SANYO-OSCON_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C'" package="SANYO-OSCON_C'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C6" package="SANYO-OSCON_C6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_D" package="SANYO-OSCON_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E" package="SANYO-OSCON_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E'" package="SANYO-OSCON_E'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E1" package="SANYO-OSCON_E1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E12" package="SANYO-OSCON_E12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E13" package="SANYO-OSCON_E13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E7" package="SANYO-OSCON_E7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E9" package="SANYO-OSCON_E9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F" package="SANYO-OSCON_F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F'" package="SANYO-OSCON_F'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F0" package="SANYO-OSCON_F0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F13" package="SANYO-OSCON_F13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F8" package="SANYO-OSCON_F8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_G" package="SANYO-OSCON_G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_H" package="SANYO-OSCON_H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_A5" package="SANYO-OSCON_SMD_A5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_B6" package="SANYO-OSCON_SMD_B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_C6" package="SANYO-OSCON_SMD_C6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_E12" package="SANYO-OSCON_SMD_E12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_E7" package="SANYO-OSCON_SMD_E7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_F12" package="SANYO-OSCON_SMD_F12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_F8" package="SANYO-OSCON_SMD_F8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-10X10" package="UD-10X10_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-4X5,8" package="UD-4X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-5X5,8" package="UD-5X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-6,3X8,8" package="UD-6,3X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-6,3X7,7" package="UD-6,3X7,7_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-8X10" package="UD-8X10_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1005" package="C1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HPC0201" package="HPC0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0201" package="C0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1808" package="C1808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3640" package="C3640">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050_075-035X103" package="C050_075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="R-TRIMM" prefix="R" uservalue="yes">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="R-TRIM" x="0" y="0"/>
</gates>
<devices>
<device name="3304W" package="RTRIM3304W">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="E" pad="3"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="3165W" package="RTRIM3165W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3202" package="RTRIM3202">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3314J" package="RTRIM3314J">
<connects>
<connect gate="G$1" pin="A" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="4G/J" package="RTRIM4G/J">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CVR42A" package="RTRIMCVR42A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3214W" package="RTRIM3214W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3224G" package="RTRIM3224G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3224J" package="RTRIM3224J">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3224X" package="RTRIM3224X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3103" package="RTRIM3103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5W" package="RTRIM5W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5X" package="RTRIM5X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TSM53YJ" package="RTRIMTSM53YJ">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TSM53YL" package="RTRIMTSM53YL">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TS63X" package="RTRIMTS63X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TS63Y" package="RTRIMTS63Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TS63Z" package="RTRIMTS63Z">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3296P" package="RTRIM3296P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3296W" package="RTRIM3296W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3296X" package="RTRIM3296X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3296Y" package="RTRIM3296Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="74W" package="RTRIM74W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="74X" package="RTRIM74X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3224W" package="RTRIM3224W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3339P" package="RTRIM3339P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="64P" package="RTRIM64P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="64W" package="RTRIM64W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="64X" package="RTRIM64X">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="64Y" package="RTRIM64Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="64Z" package="RTRIM64Z">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3059Y" package="RTRIM3059Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="70Y" package="RTRIM70Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3374" package="RTRIM3374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3299W" package="RTRIM3299W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="43P" package="RTRIM43P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3006P" package="RTRIM3006P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T18" package="RTRIMT18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T93XA" package="RTRIMT93XA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T93XB" package="RTRIMT93XB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T93YA" package="RTRIMT93YA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="T93YB" package="RTRIMT93YB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3314G" package="RTRIM3314G">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
 &lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
</packages>
<symbols>
<symbol name="+5V">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+5V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="-5V">
<wire x1="-1.27" y1="1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="1.27" y2="1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="-5V" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="GNDA">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<wire x1="-1.0922" y1="-0.508" x2="1.0922" y2="-0.508" width="0.254" layer="94"/>
<pin name="GNDA" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="0V">
<text x="-1.905" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="0V" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="GND">
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+5V" prefix="P+">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="+5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="-5V" prefix="P-">
<gates>
<gate name="1" symbol="-5V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GNDA" prefix="GND">
<gates>
<gate name="1" symbol="GNDA" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="0V" prefix="GND">
<gates>
<gate name="1" symbol="0V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" prefix="GND">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="sorkapocs">
<packages>
<package name="3-AS">
<wire x1="3.4925" y1="-6.35" x2="-9.8425" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="6.35" x2="-9.8425" y2="4.445" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="4.445" x2="-9.8425" y2="-3.0163" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="-3.0163" x2="-9.8425" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="2.6988" x2="-6.6675" y2="2.6987" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="2.6987" x2="-6.6675" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="2.6988" x2="-0.3175" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="-6.0325" y1="2.6988" x2="-6.0325" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="0.3176" y1="2.6988" x2="0.3176" y2="-2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-6.0325" y1="2.6988" x2="-6.0325" y2="-2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-6.6675" y1="-2.6989" x2="-6.6675" y2="2.6987" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-0.3175" y1="-2.6988" x2="-0.3175" y2="2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-6.0325" y1="2.6988" x2="-6.6675" y2="2.6988" width="0.127" layer="21"/>
<wire x1="-6.0325" y1="-2.6988" x2="-6.6675" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="4.445" x2="3.4925" y2="4.445" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="6.35" x2="-7.62" y2="6.35" width="0.127" layer="21"/>
<wire x1="-7.62" y1="6.35" x2="-7.62" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-7.62" y1="4.9213" x2="-5.3975" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-5.3975" y1="4.9213" x2="-5.3975" y2="6.35" width="0.127" layer="21"/>
<wire x1="3.4925" y1="6.35" x2="1.27" y2="6.35" width="0.127" layer="21"/>
<wire x1="1.27" y1="6.35" x2="1.27" y2="4.9213" width="0.127" layer="21"/>
<wire x1="1.27" y1="4.9213" x2="-0.9525" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-9.8425" y1="-3.0163" x2="3.4925" y2="-3.0163" width="0.127" layer="21"/>
<wire x1="9.8425" y1="-0.3175" x2="9.8425" y2="1.5875" width="0.127" layer="21"/>
<wire x1="9.8425" y1="6.35" x2="9.8425" y2="4.445" width="0.127" layer="21"/>
<wire x1="9.8425" y1="4.445" x2="9.8425" y2="-3.0163" width="0.127" layer="21"/>
<wire x1="9.8425" y1="-3.0163" x2="9.8425" y2="-6.35" width="0.127" layer="21"/>
<wire x1="9.8425" y1="-6.35" x2="-3.4925" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="2.6988" x2="-0.3175" y2="2.6987" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="2.6987" x2="-0.3175" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="6.0325" y1="2.6988" x2="6.0325" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="6.6675" y1="-2.6988" x2="6.6675" y2="2.6988" width="0.127" layer="21"/>
<wire x1="0.3175" y1="2.6988" x2="0.3175" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="6.6676" y1="2.6988" x2="6.6676" y2="-2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="0.3175" y1="2.6988" x2="0.3175" y2="-2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-0.3175" y1="-2.6989" x2="-0.3175" y2="2.6987" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="6.0325" y1="-2.6988" x2="6.0325" y2="2.6988" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="6.6675" y1="2.6988" x2="6.0325" y2="2.6988" width="0.127" layer="21"/>
<wire x1="6.6675" y1="-2.6988" x2="6.0325" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="0.3175" y1="2.6988" x2="-0.3175" y2="2.6988" width="0.127" layer="21"/>
<wire x1="0.3175" y1="-2.6988" x2="-0.3175" y2="-2.6988" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="4.445" x2="9.8425" y2="4.445" width="0.127" layer="21"/>
<wire x1="-1.27" y1="6.35" x2="-1.27" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-1.27" y1="4.9213" x2="0.9525" y2="4.9213" width="0.127" layer="21"/>
<wire x1="9.8425" y1="6.35" x2="7.62" y2="6.35" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.35" x2="7.62" y2="4.9213" width="0.127" layer="21"/>
<wire x1="7.62" y1="4.9213" x2="5.3975" y2="4.9213" width="0.127" layer="21"/>
<wire x1="5.3975" y1="4.9213" x2="5.3975" y2="6.35" width="0.127" layer="21"/>
<wire x1="5.3975" y1="6.35" x2="1.27" y2="6.35" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="-3.0163" x2="9.8425" y2="-3.0163" width="0.127" layer="21"/>
<wire x1="-5.3975" y1="6.35" x2="-1.27" y2="6.35" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3.012" width="0.127" layer="21"/>
<circle x="-6.35" y="0" radius="3.0162" width="0.127" layer="21"/>
<circle x="6.35" y="0" radius="3.012" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3.0162" width="0.127" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="1.016" diameter="3.2"/>
<pad name="2" x="0" y="0" drill="1.016" diameter="3.2"/>
<pad name="3" x="6.35" y="0" drill="1.016" diameter="3.2"/>
</package>
<package name="2-ES+2DB_STAB">
<wire x1="6.6675" y1="-0.3175" x2="6.6675" y2="1.5875" width="0.127" layer="21"/>
<wire x1="6.6675" y1="6.35" x2="6.6675" y2="4.445" width="0.127" layer="21"/>
<wire x1="6.6675" y1="4.445" x2="6.6675" y2="-2.3813" width="0.127" layer="21"/>
<wire x1="6.6675" y1="-2.3813" x2="6.6675" y2="-6.35" width="0.127" layer="21"/>
<wire x1="6.6675" y1="-6.35" x2="-6.6675" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="6.35" x2="-6.6675" y2="4.445" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="4.445" x2="-6.6675" y2="-2.3813" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="-2.3813" x2="-6.6675" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="3.6513" x2="-3.4925" y2="3.6512" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="3.6512" x2="-3.4925" y2="-1.7463" width="0.127" layer="21"/>
<wire x1="2.8575" y1="3.6513" x2="2.8575" y2="-1.7463" width="0.127" layer="21"/>
<wire x1="3.4925" y1="-1.7463" x2="3.4925" y2="3.6513" width="0.127" layer="21"/>
<wire x1="-2.8575" y1="3.6513" x2="-2.8575" y2="-1.7463" width="0.127" layer="21"/>
<wire x1="3.4926" y1="3.6513" x2="3.4926" y2="-1.7463" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-2.8575" y1="3.6513" x2="-2.8575" y2="-1.7463" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="-3.4925" y1="-1.7464" x2="-3.4925" y2="3.6512" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="2.8575" y1="-1.7463" x2="2.8575" y2="3.6513" width="0.127" layer="21" curve="-169.916337"/>
<wire x1="3.4925" y1="3.6513" x2="2.8575" y2="3.6513" width="0.127" layer="21"/>
<wire x1="3.4925" y1="-1.7463" x2="2.8575" y2="-1.7463" width="0.127" layer="21"/>
<wire x1="-2.8575" y1="3.6513" x2="-3.4925" y2="3.6513" width="0.127" layer="21"/>
<wire x1="-2.8575" y1="-1.7463" x2="-3.4925" y2="-1.7463" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="4.445" x2="6.6675" y2="4.445" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="6.35" x2="-4.445" y2="6.35" width="0.127" layer="21"/>
<wire x1="-4.445" y1="6.35" x2="-4.445" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-4.445" y1="4.9213" x2="-2.2225" y2="4.9213" width="0.127" layer="21"/>
<wire x1="-2.2225" y1="4.9213" x2="-2.2225" y2="6.35" width="0.127" layer="21"/>
<wire x1="6.6675" y1="6.35" x2="4.445" y2="6.35" width="0.127" layer="21"/>
<wire x1="4.445" y1="6.35" x2="4.445" y2="4.9213" width="0.127" layer="21"/>
<wire x1="4.445" y1="4.9213" x2="2.2225" y2="4.9213" width="0.127" layer="21"/>
<wire x1="2.2225" y1="4.9213" x2="2.2225" y2="6.35" width="0.127" layer="21"/>
<wire x1="2.2225" y1="6.35" x2="-2.2225" y2="6.35" width="0.127" layer="21"/>
<wire x1="-6.6675" y1="-2.3813" x2="6.6675" y2="-2.3813" width="0.127" layer="21"/>
<circle x="3.175" y="0.9525" radius="3.012" width="0.127" layer="21"/>
<circle x="-3.175" y="0.9525" radius="3.0162" width="0.127" layer="21"/>
<pad name="P$1" x="-3.175" y="1.5875" drill="1.016" diameter="3.2"/>
<pad name="P$2" x="3.175" y="1.5875" drill="1.016" diameter="3.2"/>
<hole x="-3.175" y="-5.08" drill="1.2"/>
<hole x="3.175" y="-5.08" drill="1.2"/>
</package>
</packages>
<symbols>
<symbol name="3-AS">
<wire x1="-3.81" y1="-5.08" x2="3.81" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="5.08" x2="-3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="5.08" x2="-3.81" y2="-5.08" width="0.4064" layer="94"/>
<text x="-3.81" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="0" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="0" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="0" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="2-ES">
<wire x1="-3.81" y1="-2.54" x2="3.81" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="5.08" x2="-3.81" y2="-2.54" width="0.4064" layer="94"/>
<text x="-3.81" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="3-AS">
<gates>
<gate name="G$1" symbol="3-AS" x="0" y="0"/>
</gates>
<devices>
<device name="" package="3-AS">
<connects>
<connect gate="G$1" pin="3" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="2-ES+2DB_STAB" prefix="SK">
<gates>
<gate name="G$1" symbol="2-ES" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2-ES+2DB_STAB">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
<connect gate="G$1" pin="2" pad="P$2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply2">
<packages>
</packages>
<symbols>
<symbol name="AGND">
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<text x="-2.667" y="-3.175" size="1.778" layer="96">&gt;VALUE</text>
<pin name="AGND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="AGND" prefix="SUPPLY">
<gates>
<gate name="G$1" symbol="AGND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pinhead">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="1XNAGY">
<pad name="P$1" x="0" y="0" drill="2" diameter="5"/>
</package>
<package name="1X01">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" diameter="2.1844" shape="octagon"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
<package name="1X04">
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<text x="-5.1562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
</package>
<package name="1X04/90">
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-5.715" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.985" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
</package>
<package name="1X05">
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="0.6" diameter="1.778" shape="long" rot="R90"/>
<text x="-6.4262" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
</package>
<package name="1X05/90">
<wire x1="-6.35" y1="-1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.985" x2="-5.08" y2="1.27" width="0.762" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="6.985" x2="-2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="6.985" x2="0" y2="1.27" width="0.762" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="6.985" x2="2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.985" x2="5.08" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-6.985" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="8.255" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.461" y1="0.635" x2="-4.699" y2="1.143" layer="21"/>
<rectangle x1="-2.921" y1="0.635" x2="-2.159" y2="1.143" layer="21"/>
<rectangle x1="-0.381" y1="0.635" x2="0.381" y2="1.143" layer="21"/>
<rectangle x1="2.159" y1="0.635" x2="2.921" y2="1.143" layer="21"/>
<rectangle x1="4.699" y1="0.635" x2="5.461" y2="1.143" layer="21"/>
<rectangle x1="-5.461" y1="-2.921" x2="-4.699" y2="-1.905" layer="21"/>
<rectangle x1="-2.921" y1="-2.921" x2="-2.159" y2="-1.905" layer="21"/>
<rectangle x1="-0.381" y1="-2.921" x2="0.381" y2="-1.905" layer="21"/>
<rectangle x1="2.159" y1="-2.921" x2="2.921" y2="-1.905" layer="21"/>
<rectangle x1="4.699" y1="-2.921" x2="5.461" y2="-1.905" layer="21"/>
</package>
<package name="1X05_ICSP">
<pad name="1" x="-5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="3" x="0" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="0.6" diameter="1.9304" shape="octagon" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="PINHD1">
<wire x1="-6.35" y1="-2.54" x2="1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="2.54" x2="-6.35" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="2.54" x2="-6.35" y2="-2.54" width="0.4064" layer="94"/>
<text x="-6.35" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD4">
<wire x1="-6.35" y1="-5.08" x2="1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD5">
<wire x1="-6.35" y1="-7.62" x2="1.27" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-7.62" width="0.4064" layer="94"/>
<text x="-6.35" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="5" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="1XNAGY">
<description>furat: 1,5mm  átmérő:3,81mm kör</description>
<gates>
<gate name="G$1" symbol="PINHD1" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="1XNAGY">
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X1" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X01">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X4" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X04">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X04/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X5" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD5" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X05">
<connects>
<connect gate="A" pin="5" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X05/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ICSP" package="1X05_ICSP">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
<package name="DIL08@1">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO99">
<description>&lt;b&gt;Metal Can Package&lt;/b&gt;</description>
<wire x1="-4.572" y1="0.508" x2="-5.334" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-0.508" x2="-5.334" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-0.508" x2="-4.572" y2="-0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="4" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="8" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="6" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="1" x="-1.778" y="-1.778" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.778" y="-1.778" drill="0.8128" shape="octagon"/>
<pad name="5" x="1.778" y="1.778" drill="0.8128" shape="octagon"/>
<pad name="7" x="-1.778" y="1.778" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-5.969" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL08">
<pad name="1" x="-3.81" y="-3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.6" diameter="1.27" shape="long" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="OPAMP">
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="0" width="0.4064" layer="94"/>
<wire x1="5.08" y1="0" x2="-5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="3.175" x2="-3.81" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="94"/>
<text x="2.54" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="-IN" x="-7.62" y="-2.54" visible="pad" length="short" direction="in"/>
<pin name="+IN" x="-7.62" y="2.54" visible="pad" length="short" direction="in"/>
<pin name="OUT" x="7.62" y="0" visible="pad" length="short" direction="out" rot="R180"/>
</symbol>
<symbol name="PWR+-">
<text x="1.27" y="3.175" size="0.8128" layer="93" rot="R90">V+</text>
<text x="1.27" y="-4.445" size="0.8128" layer="93" rot="R90">V-</text>
<pin name="V+" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
<pin name="V-" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
</symbol>
<symbol name="555">
<wire x1="-7.62" y1="-10.16" x2="7.62" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="-7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="-10.16" width="0.4064" layer="94"/>
<text x="-7.62" y="10.922" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-12.827" size="1.778" layer="96">&gt;VALUE</text>
<pin name="TR" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="Q" x="10.16" y="7.62" length="short" direction="out" rot="R180"/>
<pin name="R" x="-10.16" y="2.54" length="short" direction="in" function="dot"/>
<pin name="CV" x="-10.16" y="-2.54" length="short" direction="in"/>
<pin name="THR" x="10.16" y="-2.54" length="short" direction="in" rot="R180"/>
<pin name="DIS" x="10.16" y="2.54" length="short" direction="in" rot="R180"/>
<pin name="V+" x="10.16" y="-7.62" length="short" direction="pwr" rot="R180"/>
<pin name="GND" x="-10.16" y="-7.62" length="short" direction="pwr"/>
</symbol>
<symbol name="2NUL">
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="3.8862" width="0.1524" layer="94"/>
<wire x1="0" y1="5.0546" x2="0" y2="2.6162" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.6162" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-3.9116" x2="-2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="2.54" x2="2.6162" y2="1.3208" width="0.1524" layer="94"/>
<text x="2.54" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="1.27" y="3.175" size="0.8128" layer="93" rot="R90">ON1</text>
<text x="3.175" y="2.54" size="0.8128" layer="93" rot="R90">ON2</text>
<text x="1.27" y="-5.08" size="0.8128" layer="93" rot="R90">OPT</text>
<text x="-1.27" y="4.445" size="0.8128" layer="93" rot="R90">V+</text>
<text x="-1.27" y="-5.715" size="0.8128" layer="93" rot="R90">V-</text>
<pin name="ON2" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="ON1" x="0" y="7.62" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="OPT" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="V+" x="-2.54" y="7.62" visible="pad" length="short" direction="pwr" rot="R270"/>
<pin name="V-" x="-2.54" y="-7.62" visible="pad" length="short" direction="pwr" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="TLC2272" prefix="IC">
<gates>
<gate name="A" symbol="OPAMP" x="0" y="7.62"/>
<gate name="B" symbol="OPAMP" x="0" y="-7.62"/>
<gate name="G$3" symbol="PWR+-" x="20.32" y="0"/>
</gates>
<devices>
<device name="" package="SO08">
<connects>
<connect gate="A" pin="+IN" pad="3"/>
<connect gate="A" pin="-IN" pad="2"/>
<connect gate="A" pin="OUT" pad="1"/>
<connect gate="B" pin="+IN" pad="5"/>
<connect gate="B" pin="-IN" pad="6"/>
<connect gate="B" pin="OUT" pad="7"/>
<connect gate="G$3" pin="V+" pad="8"/>
<connect gate="G$3" pin="V-" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="*555" prefix="IC">
<description>&lt;b&gt;TIMER&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="555" x="0" y="2.54"/>
</gates>
<devices>
<device name="N" package="DIL08@1">
<connects>
<connect gate="A" pin="CV" pad="5"/>
<connect gate="A" pin="DIS" pad="7"/>
<connect gate="A" pin="GND" pad="1"/>
<connect gate="A" pin="Q" pad="3"/>
<connect gate="A" pin="R" pad="4"/>
<connect gate="A" pin="THR" pad="6"/>
<connect gate="A" pin="TR" pad="2"/>
<connect gate="A" pin="V+" pad="8"/>
</connects>
<technologies>
<technology name="LM"/>
<technology name="NE"/>
<technology name="SE"/>
<technology name="UA"/>
</technologies>
</device>
<device name="D" package="SO08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="OP07*" prefix="IC">
<description>&lt;b&gt;OP AMP&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="2NUL" x="5.08" y="0"/>
</gates>
<devices>
<device name="H" package="TO99">
<connects>
<connect gate="A" pin="ON1" pad="1"/>
<connect gate="A" pin="ON2" pad="8"/>
<connect gate="A" pin="OPT" pad="5"/>
<connect gate="A" pin="OUT" pad="6"/>
<connect gate="A" pin="V+" pad="7"/>
<connect gate="A" pin="V-" pad="4"/>
</connects>
<technologies>
<technology name="A"/>
<technology name="C"/>
<technology name="D"/>
<technology name="E"/>
</technologies>
</device>
<device name="R" package="SO08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="N" package="DIL08">
<connects>
</connects>
<technologies>
<technology name="Z"/>
</technologies>
</device>
<device name="" package="DIL08">
<connects>
</connects>
<technologies>
<technology name="CQ"/>
<technology name="DQ"/>
<technology name="EQ"/>
<technology name="Q"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="DPACK">
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="2" x="0" y="2.38" dx="5.8" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<smd name="3" x="2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" diameter="1.6764" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" diameter="1.6764" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" diameter="1.6764" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="N-MOSFET">
<wire x1="0.762" y1="0.762" x2="0.762" y2="0" width="0.254" layer="94"/>
<wire x1="0.762" y1="0" x2="0.762" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0.762" y1="3.175" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="2.54" x2="0.762" y2="1.905" width="0.254" layer="94"/>
<wire x1="0.762" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0.762" y1="-1.905" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="-3.175" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="0.762" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.81" y1="0.508" x2="3.81" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="3.81" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.54" x2="3.81" y2="2.54" width="0.1524" layer="94"/>
<wire x1="4.572" y1="0.762" x2="4.318" y2="0.508" width="0.1524" layer="94"/>
<wire x1="4.318" y1="0.508" x2="3.81" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.81" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="94"/>
<wire x1="3.302" y1="0.508" x2="3.048" y2="0.254" width="0.1524" layer="94"/>
<circle x="2.54" y="-2.54" radius="0.3592" width="0" layer="94"/>
<circle x="2.54" y="2.54" radius="0.3592" width="0" layer="94"/>
<text x="-11.43" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="-11.43" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="S" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="G" x="-2.54" y="-2.54" visible="off" length="short" direction="pas"/>
<pin name="D" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<polygon width="0.1524" layer="94">
<vertex x="3.81" y="0.508"/>
<vertex x="3.302" y="-0.254"/>
<vertex x="4.318" y="-0.254"/>
</polygon>
<vertex x="1.016" y="0"/>
<vertex x="2.032" y="0.762"/>
<vertex x="2.032" y="-0.762"/>
</polygon>
</symbol>
<symbol name="IGFET-EN-GDS">
<wire x1="-2.54" y1="-2.54" x2="-1.2192" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="0.762" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0" y1="3.683" x2="0" y2="1.397" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="1.905" y1="-0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.397" x2="0" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.143" y1="2.54" x2="-1.143" y2="-2.54" width="0.254" layer="94"/>
<pin name="D" x="5.08" y="2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="S" x="5.08" y="-2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="G" x="-5.08" y="-2.54" visible="off" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="IRLR3410" prefix="T">
<description>N-Channel HEXFET 100V, 17A, 0,105Ω</description>
<gates>
<gate name="G$1" symbol="N-MOSFET" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="DPACK">
<connects>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="G" pad="1"/>
<connect gate="G$1" pin="S" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IRF840" prefix="T">
<description>&lt;b&gt;N-Channel Enhancement MOSFET&lt;/b&gt; (HEXFET); 500V; 8A; 0,85Ohm</description>
<gates>
<gate name="G$1" symbol="IGFET-EN-GDS" x="0" y="0"/>
</gates>
<devices>
<device name="1" package="TO220">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="TO220V">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="MINIMELF">
<description>&lt;b&gt;Mini Melf Diode&lt;/b&gt;</description>
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="SOD323R_INFINEON">
<description>&lt;b&gt;Diode Package&lt;/b&gt; Reflow soldering&lt;p&gt;
INFINEON, www.infineon.com/cmc_upload/0/000/010/257/eh_db_5b.pdf</description>
<wire x1="-0.8" y1="0.55" x2="0.8" y2="0.55" width="0.1016" layer="21"/>
<wire x1="0.8" y1="0.55" x2="0.8" y2="-0.55" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-0.55" x2="-0.8" y2="-0.55" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="-0.55" x2="-0.8" y2="0.55" width="0.1016" layer="51"/>
<smd name="C" x="-1.25" y="0" dx="0.8" dy="0.6" layer="1"/>
<smd name="A" x="1.25" y="0" dx="0.8" dy="0.6" layer="1"/>
<text x="-1.65" y="0.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.55" x2="0" y2="0.55" layer="21"/>
<rectangle x1="-1.25" y1="-0.15" x2="-0.8" y2="0.15" layer="51"/>
<rectangle x1="0.8" y1="-0.15" x2="1.25" y2="0.15" layer="51"/>
</package>
<package name="TO220ABS">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
3-lead molded, vertical</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="A1" x="-2.54" y="-2.54" drill="1.016" diameter="1.778" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.016" diameter="1.778" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-2.54" drill="1.016" diameter="1.778" shape="long" rot="R90"/>
</package>
<package name="SMA-DO214AC">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="-2.2225" y1="1.27" x2="2.2225" y2="1.27" width="0.127" layer="51"/>
<wire x1="-2.2225" y1="-1.27" x2="2.2225" y2="-1.27" width="0.127" layer="51"/>
<wire x1="0.3175" y1="0" x2="-0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0.4763" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="-0.4763" x2="0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-1.1113" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="1.1113" y2="0" width="0.127" layer="21"/>
<smd name="A" x="-2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<smd name="K" x="2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<text x="-3.175" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-2.8575" size="1.27" layer="27">&gt;VALUE</text>
<wire x1="-2.2225" y1="-1.27" x2="-2.2225" y2="-0.47625" width="0.127" layer="51"/>
<wire x1="-2.2225" y1="1.27" x2="-2.2225" y2="0.47625" width="0.127" layer="51"/>
<wire x1="2.2225" y1="1.27" x2="2.2225" y2="0.47625" width="0.127" layer="51"/>
<wire x1="2.2225" y1="-1.27" x2="2.2225" y2="-0.47625" width="0.127" layer="51"/>
<rectangle x1="-2.54" y1="-0.635" x2="-1.27" y2="0.635" layer="51"/>
<rectangle x1="1.27" y1="-0.635" x2="2.54" y2="0.635" layer="51"/>
</package>
<package name="DO35Z10">
diameter 2 mm, horizontal, grid 10.16mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO41Z10">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-5.08" y="0" drill="0.8" diameter="2.54"/>
<pad name="A" x="5.08" y="0" drill="0.8" diameter="2.54"/>
<text x="-1.905" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="C1702-15">
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.1176" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
<rectangle x1="4.572" y1="-0.5334" x2="5.9436" y2="0.5334" layer="21"/>
<rectangle x1="-5.9436" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="DO13M">
diameter 6.35 mm metall, horizontal, grid 20.32 mm</description>
<wire x1="-7.239" y1="3.175" x2="-7.239" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-3.175" x2="1.905" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.175" x2="-7.239" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-1.27" x2="7.239" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-3.175" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0" x2="8.636" y2="0" width="0.9144" layer="51"/>
<wire x1="-8.636" y1="0" x2="-10.16" y2="0" width="0.9144" layer="51"/>
<wire x1="-4.191" y1="0" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-1.778" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.5842" x2="-1.778" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.5842" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.4572" x2="-3.302" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.4572" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="21" curve="-86.050132"/>
<wire x1="2.794" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21" curve="86.050132"/>
<wire x1="7.239" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="7.239" y2="-1.27" width="0.1524" layer="21"/>
<pad name="C" x="-10.16" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="10.16" y="0" drill="1.1938" shape="long"/>
<text x="-7.239" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.239" y1="-0.4318" x2="8.7122" y2="0.4318" layer="21"/>
<rectangle x1="-8.7122" y1="-0.4318" x2="-7.239" y2="0.4318" layer="21"/>
<rectangle x1="-6.731" y1="-3.175" x2="-6.096" y2="3.175" layer="21"/>
</package>
<package name="SOD57Z10">
diameter 4 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-1.143" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.016" x2="1.397" y2="-1.016" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.286" y1="1.016" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1938" shape="long"/>
<text x="-2.286" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.8354" y1="-0.4064" x2="-2.286" y2="0.4064" layer="21"/>
<rectangle x1="2.286" y1="-0.4064" x2="3.8354" y2="0.4064" layer="21"/>
</package>
<package name="DO34Z7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.127" y1="0.508" x2="-0.127" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
<package name="SOD64Z10">
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-2.54" y1="1.397" x2="-2.54" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.397" x2="2.54" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.397" x2="1.397" y2="-1.397" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.54" y1="1.397" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.397" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.397" x2="2.54" y2="-1.397" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.6002" shape="long"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.397" x2="-1.397" y2="1.397" layer="21"/>
<rectangle x1="2.54" y1="-0.6604" x2="3.3274" y2="0.6604" layer="21"/>
<rectangle x1="-3.3274" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="SOD64Z12">
diameter 4.8 mm, vertical, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="1.3716" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<rectangle x1="2.54" y1="-0.6604" x2="4.572" y2="0.6604" layer="21"/>
<rectangle x1="-4.572" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="TO236">
3-lead smd</description>
<wire x1="-1.4" y1="1.15" x2="-0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="1.15" x2="-1.4" y2="-0.2" width="0.2032" layer="21"/>
<wire x1="-0.3" y1="-1.15" x2="0.3" y2="-1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="-0.2" x2="1.4" y2="1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-0.7" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-0.2" x2="-1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.15" x2="-0.3" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="0.3" y1="-1.15" x2="1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.15" x2="1.4" y2="-0.2" width="0.2032" layer="51"/>
<smd name="C" x="0" y="1" dx="1" dy="1.2" layer="1"/>
<smd name="A" x="-1" y="-1" dx="1" dy="1.2" layer="1"/>
<smd name="NC" x="1" y="-1" dx="1" dy="1.2" layer="1"/>
<text x="-1.397" y="1.794" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-3.064" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2" y1="0.6" x2="0.2" y2="1.25" layer="51"/>
<rectangle x1="-1.2" y1="-1.25" x2="-0.8" y2="-0.6" layer="51"/>
<rectangle x1="0.8" y1="-1.25" x2="1.2" y2="-0.6" layer="51"/>
</package>
<package name="F126Z10">
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
</package>
<package name="F126Z12">
diameter 3 mm, horizontal, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="0.8128" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.016" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.016" shape="long"/>
<rectangle x1="-4.8514" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="4.8514" y2="0.4064" layer="21"/>
</package>
<package name="ZDIO-10">
<description>&lt;b&gt;Z DIODE&lt;/b&gt;</description>
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-3.556" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="3.556" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-2.54" y2="-1.27" width="0.254" layer="21"/>
<text x="-2.4892" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZDIO-2.5">
<wire x1="-0.254" y1="0.762" x2="-0.508" y2="0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.762" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.762" y1="-0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.762" y2="-0.762" width="0.254" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="-0.762" x2="-0.762" y2="-0.762" width="0.254" layer="21"/>
<wire x1="0.508" y1="0.254" x2="0.508" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.254" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.254" y2="0" width="0.6096" layer="51"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.3462" y="1.0668" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZDIO-5">
<wire x1="1.27" y1="0" x2="1.651" y2="0" width="0.254" layer="21"/>
<wire x1="-1.651" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="ZDIO-7.5">
<wire x1="1.27" y1="0" x2="2.794" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.4892" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="ZDIO12.5">
<wire x1="1.27" y1="0" x2="4.699" y2="0" width="0.254" layer="21"/>
<wire x1="-4.826" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="C" x="-6.35" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="6.223" y="0" drill="0.8128" shape="long"/>
<text x="-2.6162" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P1Z12">
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.1176" shape="long"/>
<text x="-3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
</package>
<package name="SOD80C">
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOT23">
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.1524" x2="-1.4224" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.4224" y1="0.6604" x2="-0.8636" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="0.8636" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.277" y1="1.778" x2="3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-1.778" x2="-3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-1.778" x2="-3.277" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="1.778" x2="3.277" y2="1.778" width="0.2032" layer="21"/>
<smd name="1" x="-2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="2" x="0" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="3" x="2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
</package>
<package name="SMB">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
<package name="DO35-10">
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.6" diameter="1.4224" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.6" diameter="1.4224" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DO35-7">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<pad name="C" x="-3.81" y="0" drill="0.6" diameter="1.4224" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.6" diameter="1.4224" shape="long"/>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="ZD">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<text x="-1.778" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.778" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="D">
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="DD">
<wire x1="-3.81" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<circle x="0" y="0" radius="0.127" width="0.4064" layer="94"/>
<text x="0.762" y="2.0066" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.826" y="-3.4544" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="A2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="C" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="SCHOTTKY">
<wire x1="1.905" y1="1.27" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="1.016" width="0.254" layer="94"/>
<wire x1="0.635" y1="-1.016" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<text x="-2.286" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="SMZ" prefix="D">
<gates>
<gate name="G$1" symbol="ZD" x="-2.54" y="2.54"/>
</gates>
<devices>
<device name="" package="MELF-MLL41">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4148" prefix="D">
high speed (Philips)</description>
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO35-10" package="DO35-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO35-7" package="DO35-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MINIMELF" package="MINIMELF">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD323" package="SOD323R_INFINEON">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="STPR1020" prefix="D">
<description>Dual Ultra Fast Diode</description>
<gates>
<gate name="G$1" symbol="DD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO220ABS">
<connects>
<connect gate="G$1" pin="A1" pad="A1"/>
<connect gate="G$1" pin="A2" pad="A2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT46" prefix="D">
<gates>
<gate name="G$1" symbol="SCHOTTKY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MINIMELF">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ER1M" prefix="D">
<description>super fast rectifier, 1000V, 1A, 75ns</description>
<gates>
<gate name="G$1" symbol="D" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="SMA-DO214AC">
<connects>
<connect gate="G$1" pin="C" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZENER-DIODE" prefix="D" uservalue="yes">
<description>Z-Diode</description>
<gates>
<gate name="G$1" symbol="ZD" x="0" y="0"/>
</gates>
<devices>
<device name="DO35Z10" package="DO35Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO41Z10" package="DO41Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1702-15" package="C1702-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO13M" package="DO13M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD57-10" package="SOD57Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO34-7" package="DO34Z7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-10" package="SOD64Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-12" package="SOD64Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO236" package="TO236">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-10" package="F126Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-12" package="F126Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-10" package="ZDIO-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-2.5" package="ZDIO-2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-5" package="ZDIO-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-7.5" package="ZDIO-7.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-12.5" package="ZDIO12.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-Z12" package="P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-12" package="P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD80C" package="SOD80C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT23" package="SOT23">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="C" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT223" package="SOT223">
<connects>
<connect gate="G$1" pin="C" pad="4"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="SMB" package="SMB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-pnp">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT23-BEC">
<description>&lt;b&gt;TO-236&lt;/b&gt; ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
</packages>
<symbols>
<symbol name="PNP">
<wire x1="2.086" y1="1.678" x2="1.578" y2="2.594" width="0.1524" layer="94"/>
<wire x1="1.578" y1="2.594" x2="0.516" y2="1.478" width="0.1524" layer="94"/>
<wire x1="0.516" y1="1.478" x2="2.086" y2="1.678" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="1.808" y2="2.124" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="0.508" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.905" y1="1.778" x2="1.524" y2="2.413" width="0.254" layer="94"/>
<wire x1="1.524" y1="2.413" x2="0.762" y2="1.651" width="0.254" layer="94"/>
<wire x1="0.762" y1="1.651" x2="1.778" y2="1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="1.778" x2="1.524" y2="2.159" width="0.254" layer="94"/>
<wire x1="1.524" y1="2.159" x2="1.143" y2="1.905" width="0.254" layer="94"/>
<wire x1="1.143" y1="1.905" x2="1.524" y2="1.905" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="E" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="C" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MMBTA92*" prefix="Q">
<description>&lt;b&gt;PNP Transistror&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="PNP" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="SOT23-BEC">
<connects>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="E" pad="E"/>
</connects>
<technologies>
<technology name="LT1"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<description>TO-236 ITT Intermetall</description>
</package>
</packages>
<symbols>
<symbol name="NPN">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BC817*" prefix="Q">
<description>&lt;b&gt;NPN Transistor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<technology name="-16"/>
<technology name="-16LT1"/>
<technology name="-25"/>
<technology name="-25LT1"/>
<technology name="-40"/>
<technology name="-40LT1"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="forrszem">
<packages>
<package name="NAGY_SZEM">
<pad name="P$1" x="0" y="0" drill="3.2" diameter="6.4516"/>
</package>
</packages>
<symbols>
<symbol name="NAGY_SZEM">
<pin name="1" x="-5.08" y="0" visible="off" length="middle"/>
<wire x1="-4.445" y1="0.635" x2="-0.635" y2="4.445" width="1.016" layer="94" curve="-77.905243" cap="flat"/>
<wire x1="4.445" y1="0.635" x2="0.635" y2="4.445" width="1.016" layer="94" curve="77.905243" cap="flat"/>
<wire x1="4.445" y1="-0.635" x2="0.635" y2="-4.445" width="1.016" layer="94" curve="-77.905243" cap="flat"/>
<wire x1="-4.445" y1="-0.635" x2="-0.635" y2="-4.445" width="1.016" layer="94" curve="77.905243" cap="flat"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="H" prefix="H">
<gates>
<gate name="G$1" symbol="NAGY_SZEM" x="0" y="0"/>
</gates>
<devices>
<device name="" package="NAGY_SZEM">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
<packages>
<package name="SO-08">
<description>&lt;B&gt;Small Outline Narrow Plastic Gull Wing&lt;/B&gt;&lt;p&gt;
150-mil body, package type SN</description>
<wire x1="-2.9" y1="3.9" x2="2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="3.9" x2="2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="-3.9" x2="-2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-2.9" y1="-3.9" x2="-2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-0.635" size="0.4064" layer="48">IPC SO8</text>
<text x="-1.905" y="0.365" size="0.3048" layer="48">JEDEC MS-012 AA</text>
<rectangle x1="-2.1501" y1="-3.1001" x2="-1.6599" y2="-2" layer="51"/>
<rectangle x1="-0.8801" y1="-3.1001" x2="-0.3899" y2="-2" layer="51"/>
<rectangle x1="0.3899" y1="-3.1001" x2="0.8801" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="-3.1001" x2="2.1501" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="2" x2="2.1501" y2="3.1001" layer="51"/>
<rectangle x1="0.3899" y1="2" x2="0.8801" y2="3.1001" layer="51"/>
<rectangle x1="-0.8801" y1="2" x2="-0.3899" y2="3.1001" layer="51"/>
<rectangle x1="-2.1501" y1="2" x2="-1.6599" y2="3.1001" layer="51"/>
<rectangle x1="-1" y1="-1" x2="1" y2="1" layer="35"/>
</package>
<package name="SO-14">
150-mil body, package type SL</description>
<wire x1="-4.895" y1="3.9" x2="4.895" y2="3.9" width="0.1998" layer="39"/>
<wire x1="4.895" y1="-3.9" x2="-4.895" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-4.895" y1="-3.9" x2="-4.895" y2="3.9" width="0.1998" layer="39"/>
<wire x1="4.305" y1="-1.9" x2="-4.305" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-4.305" y1="-1.9" x2="-4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-4.305" y1="-1.4" x2="-4.305" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.305" y1="-1.4" x2="-4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.305" y1="1.9" x2="4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.305" y1="-1.4" x2="4.305" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="4.895" y1="3.9" x2="4.895" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-4.305" y1="1.9" x2="4.305" y2="1.9" width="0.2032" layer="51"/>
<smd name="2" x="-2.54" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="-2.54" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-3.81" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-1.27" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="0" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="-3.81" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="-1.27" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="0" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="2.54" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="2.54" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.27" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="3.81" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="1.27" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="3.81" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-4.572" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.842" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-3.81" y="0.365" size="0.3048" layer="48">JEDEC MS-012 AB</text>
<text x="-3.81" y="-0.635" size="0.4064" layer="48">IPC SO14</text>
<rectangle x1="-4.0551" y1="-3.1001" x2="-3.5649" y2="-2" layer="51"/>
<rectangle x1="-2.7851" y1="-3.1001" x2="-2.2949" y2="-2" layer="51"/>
<rectangle x1="-1.5151" y1="-3.1001" x2="-1.0249" y2="-2" layer="51"/>
<rectangle x1="-0.2451" y1="-3.1001" x2="0.2451" y2="-2" layer="51"/>
<rectangle x1="-0.2451" y1="2" x2="0.2451" y2="3.1001" layer="51"/>
<rectangle x1="-1.5151" y1="2" x2="-1.0249" y2="3.1001" layer="51"/>
<rectangle x1="-2.7851" y1="2" x2="-2.2949" y2="3.1001" layer="51"/>
<rectangle x1="-4.0551" y1="2" x2="-3.5649" y2="3.1001" layer="51"/>
<rectangle x1="1.0249" y1="-3.1001" x2="1.5151" y2="-2" layer="51"/>
<rectangle x1="2.2949" y1="-3.1001" x2="2.7851" y2="-2" layer="51"/>
<rectangle x1="3.5649" y1="-3.1001" x2="4.0551" y2="-2" layer="51"/>
<rectangle x1="3.5649" y1="2" x2="4.0551" y2="3.1001" layer="51"/>
<rectangle x1="2.2949" y1="2" x2="2.7851" y2="3.1001" layer="51"/>
<rectangle x1="1.0249" y1="2" x2="1.5151" y2="3.1001" layer="51"/>
</package>
<package name="SO28W">
<description>&lt;B&gt;28-Lead Plastic Small Outline (SO) &lt;/B&gt; Wide, 300 mil Body (SOIC)&lt;/B&gt;&lt;p&gt;
Source: http://ww1.microchip.com/downloads/en/devicedoc/39632c.pdf</description>
<wire x1="-8.1788" y1="-3.7132" x2="9.4742" y2="-3.7132" width="0.1524" layer="21"/>
<wire x1="9.4742" y1="-3.7132" x2="9.4742" y2="3.7132" width="0.1524" layer="21"/>
<wire x1="9.4742" y1="3.7132" x2="-8.1788" y2="3.7132" width="0.1524" layer="21"/>
<wire x1="-8.1788" y1="3.7132" x2="-8.1788" y2="-3.7132" width="0.1524" layer="21"/>
<circle x="-7.239" y="-3.1496" radius="0.5334" width="0.1524" layer="21"/>
<smd name="1" x="-7.62" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="2" x="-6.35" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="3" x="-5.08" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="4" x="-3.81" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="5" x="-2.54" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="6" x="-1.27" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="7" x="0" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="8" x="1.27" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="9" x="2.54" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="10" x="3.81" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="20" x="2.54" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="19" x="3.81" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="18" x="5.08" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="17" x="6.35" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="16" x="7.62" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="15" x="8.89" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="14" x="8.89" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="13" x="7.62" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="12" x="6.35" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="11" x="5.08" y="-4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="21" x="1.27" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="22" x="0" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="23" x="-1.27" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="24" x="-2.54" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="25" x="-3.81" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="26" x="-5.08" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="27" x="-6.35" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<smd name="28" x="-7.62" y="4.78" dx="0.65" dy="1.7" layer="1"/>
<text x="-8.509" y="-4.064" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="11.557" y="-4.064" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-7.874" y1="-5.2626" x2="-7.366" y2="-3.7386" layer="51"/>
<rectangle x1="-6.604" y1="-5.2626" x2="-6.096" y2="-3.7386" layer="51"/>
<rectangle x1="-5.334" y1="-5.2626" x2="-4.826" y2="-3.7386" layer="51"/>
<rectangle x1="-4.064" y1="-5.2626" x2="-3.556" y2="-3.7386" layer="51"/>
<rectangle x1="-2.794" y1="-5.2626" x2="-2.286" y2="-3.7386" layer="51"/>
<rectangle x1="-1.524" y1="-5.2626" x2="-1.016" y2="-3.7386" layer="51"/>
<rectangle x1="-0.254" y1="-5.2626" x2="0.254" y2="-3.7386" layer="51"/>
<rectangle x1="1.016" y1="-5.2626" x2="1.524" y2="-3.7386" layer="51"/>
<rectangle x1="2.286" y1="-5.2626" x2="2.794" y2="-3.7386" layer="51"/>
<rectangle x1="3.556" y1="-5.2626" x2="4.064" y2="-3.7386" layer="51"/>
<rectangle x1="4.826" y1="-5.2626" x2="5.334" y2="-3.7386" layer="51"/>
<rectangle x1="6.096" y1="-5.2626" x2="6.604" y2="-3.7386" layer="51"/>
<rectangle x1="7.366" y1="-5.2626" x2="7.874" y2="-3.7386" layer="51"/>
<rectangle x1="8.636" y1="-5.2626" x2="9.144" y2="-3.7386" layer="51"/>
<rectangle x1="8.636" y1="3.7386" x2="9.144" y2="5.2626" layer="51"/>
<rectangle x1="7.366" y1="3.7386" x2="7.874" y2="5.2626" layer="51"/>
<rectangle x1="6.096" y1="3.7386" x2="6.604" y2="5.2626" layer="51"/>
<rectangle x1="4.826" y1="3.7386" x2="5.334" y2="5.2626" layer="51"/>
<rectangle x1="3.556" y1="3.7386" x2="4.064" y2="5.2626" layer="51"/>
<rectangle x1="2.286" y1="3.7386" x2="2.794" y2="5.2626" layer="51"/>
<rectangle x1="1.016" y1="3.7386" x2="1.524" y2="5.2626" layer="51"/>
<rectangle x1="-0.254" y1="3.7386" x2="0.254" y2="5.2626" layer="51"/>
<rectangle x1="-1.524" y1="3.7386" x2="-1.016" y2="5.2626" layer="51"/>
<rectangle x1="-2.794" y1="3.7386" x2="-2.286" y2="5.2626" layer="51"/>
<rectangle x1="-4.064" y1="3.7386" x2="-3.556" y2="5.2626" layer="51"/>
<rectangle x1="-5.334" y1="3.7386" x2="-4.826" y2="5.2626" layer="51"/>
<rectangle x1="-6.604" y1="3.7386" x2="-6.096" y2="5.2626" layer="51"/>
<rectangle x1="-7.874" y1="3.7386" x2="-7.366" y2="5.2626" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MCP1501">
<pin name="VDD" x="-15.24" y="7.62" length="middle" direction="pwr"/>
<pin name="NC" x="-15.24" y="2.54" length="middle" direction="nc"/>
<pin name="SHDN" x="-15.24" y="-2.54" length="middle" direction="in"/>
<pin name="GND1" x="-15.24" y="-7.62" length="middle" direction="pwr"/>
<pin name="GND2" x="15.24" y="-7.62" length="middle" direction="pwr" rot="R180"/>
<pin name="GND3" x="15.24" y="-2.54" length="middle" direction="pwr" rot="R180"/>
<pin name="OUT" x="15.24" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="FEEDBK" x="15.24" y="7.62" length="middle" direction="in" rot="R180"/>
<wire x1="-10.16" y1="10.16" x2="10.16" y2="10.16" width="0.254" layer="94"/>
<wire x1="10.16" y1="10.16" x2="10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="-10.16" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-10.16" x2="-10.16" y2="10.16" width="0.254" layer="94"/>
<text x="-7.62" y="11.43" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="MCP4922">
<pin name="VDD" x="-15.24" y="15.24" length="middle" direction="pwr"/>
<pin name="NC1" x="-15.24" y="10.16" length="middle" direction="nc"/>
<pin name="CS" x="-15.24" y="5.08" length="middle" direction="in"/>
<pin name="SCK" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="SDI" x="-15.24" y="-5.08" length="middle" direction="in"/>
<pin name="NC2" x="-15.24" y="-10.16" length="middle" direction="nc"/>
<pin name="NC3" x="-15.24" y="-15.24" length="middle" direction="nc"/>
<pin name="LDAC" x="15.24" y="-15.24" length="middle" direction="in" rot="R180"/>
<pin name="SHDN" x="15.24" y="-10.16" length="middle" direction="in" rot="R180"/>
<pin name="V_OUT_B" x="15.24" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="V_REF_B" x="15.24" y="0" length="middle" direction="in" rot="R180"/>
<pin name="VSS" x="15.24" y="5.08" length="middle" direction="pwr" rot="R180"/>
<pin name="V_REF_A" x="15.24" y="10.16" length="middle" direction="in" rot="R180"/>
<pin name="V_OUT_A" x="15.24" y="15.24" length="middle" direction="out" rot="R180"/>
<wire x1="-10.16" y1="17.78" x2="10.16" y2="17.78" width="0.254" layer="94"/>
<wire x1="10.16" y1="17.78" x2="10.16" y2="-17.78" width="0.254" layer="94"/>
<wire x1="10.16" y1="-17.78" x2="-10.16" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-17.78" x2="-10.16" y2="17.78" width="0.254" layer="94"/>
<text x="-7.62" y="19.05" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="PIC18F2620">
<wire x1="12.7" y1="35.56" x2="-12.7" y2="35.56" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="35.56" x2="-12.7" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-35.56" x2="12.7" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-35.56" x2="12.7" y2="35.56" width="0.4064" layer="94"/>
<text x="-12.7" y="36.83" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-38.1" size="1.778" layer="96">&gt;VALUE</text>
<pin name="MCLR" x="-17.78" y="33.02" length="middle"/>
<pin name="RA0" x="-17.78" y="27.94" length="middle"/>
<pin name="RA1" x="-17.78" y="22.86" length="middle"/>
<pin name="RA2" x="-17.78" y="17.78" length="middle"/>
<pin name="RA3" x="-17.78" y="12.7" length="middle"/>
<pin name="RA4" x="-17.78" y="7.62" length="middle"/>
<pin name="RA5" x="-17.78" y="2.54" length="middle"/>
<pin name="VSS" x="-17.78" y="-2.54" length="middle" direction="pwr"/>
<pin name="RA7_OSC1" x="-17.78" y="-7.62" length="middle"/>
<pin name="RA6_OSC2" x="-17.78" y="-12.7" length="middle"/>
<pin name="RC0" x="-17.78" y="-17.78" length="middle"/>
<pin name="RC1" x="-17.78" y="-22.86" length="middle"/>
<pin name="RC2" x="-17.78" y="-27.94" length="middle"/>
<pin name="RC3" x="-17.78" y="-33.02" length="middle"/>
<pin name="RC4" x="17.78" y="-33.02" length="middle" rot="R180"/>
<pin name="RC5" x="17.78" y="-27.94" length="middle" rot="R180"/>
<pin name="RC6" x="17.78" y="-22.86" length="middle" rot="R180"/>
<pin name="RC7" x="17.78" y="-17.78" length="middle" rot="R180"/>
<pin name="VSS2" x="17.78" y="-12.7" length="middle" direction="pwr" rot="R180"/>
<pin name="VDD" x="17.78" y="-7.62" length="middle" direction="pwr" rot="R180"/>
<pin name="RB0" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="RB1" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="RB2" x="17.78" y="7.62" length="middle" rot="R180"/>
<pin name="RB3" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="RB4" x="17.78" y="17.78" length="middle" rot="R180"/>
<pin name="RB5" x="17.78" y="22.86" length="middle" rot="R180"/>
<pin name="RB6" x="17.78" y="27.94" length="middle" rot="R180"/>
<pin name="RB7" x="17.78" y="33.02" length="middle" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP1501" prefix="IC">
<description>High-Precision Buffered Voltage Reference</description>
<gates>
<gate name="G$1" symbol="MCP1501" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SO-08">
<connects>
<connect gate="G$1" pin="FEEDBK" pad="7"/>
<connect gate="G$1" pin="GND1" pad="4"/>
<connect gate="G$1" pin="GND2" pad="5"/>
<connect gate="G$1" pin="GND3" pad="6"/>
<connect gate="G$1" pin="NC" pad="2"/>
<connect gate="G$1" pin="OUT" pad="8"/>
<connect gate="G$1" pin="SHDN" pad="3"/>
<connect gate="G$1" pin="VDD" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MCP4922" prefix="IC">
<description>12-bit Dual Digital-to-Analog Converter</description>
<gates>
<gate name="G$1" symbol="MCP4922" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SO-14">
<connects>
<connect gate="G$1" pin="CS" pad="3"/>
<connect gate="G$1" pin="LDAC" pad="8"/>
<connect gate="G$1" pin="NC1" pad="2"/>
<connect gate="G$1" pin="NC2" pad="6"/>
<connect gate="G$1" pin="NC3" pad="7"/>
<connect gate="G$1" pin="SCK" pad="4"/>
<connect gate="G$1" pin="SDI" pad="5"/>
<connect gate="G$1" pin="SHDN" pad="9"/>
<connect gate="G$1" pin="VSS" pad="12"/>
<connect gate="G$1" pin="V_OUT_A" pad="14"/>
<connect gate="G$1" pin="V_OUT_B" pad="10"/>
<connect gate="G$1" pin="V_REF_A" pad="13"/>
<connect gate="G$1" pin="V_REF_B" pad="11"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PIC18F2620" prefix="IC">
<gates>
<gate name="G$1" symbol="PIC18F2620" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SO28W">
<connects>
<connect gate="G$1" pin="MCLR" pad="1"/>
<connect gate="G$1" pin="RA0" pad="2"/>
<connect gate="G$1" pin="RA1" pad="3"/>
<connect gate="G$1" pin="RA2" pad="4"/>
<connect gate="G$1" pin="RA3" pad="5"/>
<connect gate="G$1" pin="RA4" pad="6"/>
<connect gate="G$1" pin="RA5" pad="7"/>
<connect gate="G$1" pin="RA6_OSC2" pad="10"/>
<connect gate="G$1" pin="RA7_OSC1" pad="9"/>
<connect gate="G$1" pin="RB0" pad="21"/>
<connect gate="G$1" pin="RB1" pad="22"/>
<connect gate="G$1" pin="RB2" pad="23"/>
<connect gate="G$1" pin="RB3" pad="24"/>
<connect gate="G$1" pin="RB4" pad="25"/>
<connect gate="G$1" pin="RB5" pad="26"/>
<connect gate="G$1" pin="RB6" pad="27"/>
<connect gate="G$1" pin="RB7" pad="28"/>
<connect gate="G$1" pin="RC0" pad="11"/>
<connect gate="G$1" pin="RC1" pad="12"/>
<connect gate="G$1" pin="RC2" pad="13"/>
<connect gate="G$1" pin="RC3" pad="14"/>
<connect gate="G$1" pin="RC4" pad="15"/>
<connect gate="G$1" pin="RC5" pad="16"/>
<connect gate="G$1" pin="RC6" pad="17"/>
<connect gate="G$1" pin="RC7" pad="18"/>
<connect gate="G$1" pin="VDD" pad="20"/>
<connect gate="G$1" pin="VSS" pad="8"/>
<connect gate="G$1" pin="VSS2" pad="19"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="5032-SMD">
<wire x1="-2.54" y1="-1.5875" x2="-2.54" y2="1.5875" width="0.127" layer="21"/>
<wire x1="-2.54" y1="-1.5875" x2="2.54" y2="-1.5875" width="0.127" layer="21"/>
<wire x1="2.54" y1="-1.5875" x2="2.54" y2="1.5875" width="0.127" layer="21"/>
<wire x1="-2.54" y1="1.5875" x2="2.54" y2="1.5875" width="0.127" layer="21"/>
<smd name="1" x="-1.905" y="0" dx="2" dy="2.4" layer="1"/>
<smd name="2" x="1.905" y="0" dx="2" dy="2.4" layer="1"/>
</package>
</packages>
<symbols>
<symbol name="Q">
<wire x1="1.016" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="-1.524" width="0.254" layer="94"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.254" layer="94"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="1.524" width="0.254" layer="94"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.254" layer="94"/>
<wire x1="1.016" y1="1.778" x2="1.016" y2="-1.778" width="0.254" layer="94"/>
<wire x1="-1.016" y1="1.778" x2="-1.016" y2="-1.778" width="0.254" layer="94"/>
<text x="2.54" y="1.016" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.159" y="-1.143" size="0.8636" layer="93">1</text>
<text x="1.524" y="-1.143" size="0.8636" layer="93">2</text>
<pin name="2" x="2.54" y="0" visible="off" length="point" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-2.54" y="0" visible="off" length="point" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="SMD-5032" prefix="Q">
<gates>
<gate name="G$1" symbol="Q" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="5032-SMD">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="tekercsek">
<packages>
<package name="34X11MM_TOROID_áLLó">
<wire x1="8.255" y1="-20.32" x2="8.255" y2="11.7475" width="0.05" layer="21"/>
<wire x1="-8.255" y1="-20.32" x2="-8.255" y2="-2.54" width="0.05" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-8.255" y2="11.7475" width="0.05" layer="21"/>
<pad name="1" x="-8.255" y="-4.1276" drill="1.6" diameter="3.81" shape="long" rot="R90"/>
<pad name="2" x="8.255" y="-4.1275" drill="1.6" diameter="3.81" shape="long" rot="R90"/>
<wire x1="-8.5725" y1="-20.32" x2="-8.255" y2="-20.32" width="0.2" layer="21"/>
<wire x1="-8.255" y1="-20.32" x2="8.255" y2="-20.32" width="0.2" layer="21"/>
<wire x1="8.255" y1="-20.32" x2="8.5725" y2="-20.32" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-19.3675" x2="8.5725" y2="-19.3675" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-18.415" x2="8.5725" y2="-18.415" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-17.4625" x2="8.5725" y2="-17.4625" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-16.51" x2="8.5725" y2="-16.51" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-15.5575" x2="8.5725" y2="-15.5575" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-6.0325" x2="8.5725" y2="-6.0325" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-5.3975" x2="8.5725" y2="-5.3975" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-4.445" x2="8.5725" y2="-4.445" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-3.4925" x2="8.5725" y2="-3.4925" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-2.54" x2="-8.255" y2="-2.54" width="0.2" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="8.5725" y2="-2.54" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-1.5875" x2="8.5725" y2="-1.5875" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-0.635" x2="8.5725" y2="-0.635" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="0.3175" x2="8.5725" y2="0.3175" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="1.27" x2="8.5725" y2="1.27" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="2.2225" x2="8.5725" y2="2.2225" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="3.175" x2="8.5725" y2="3.175" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="4.1275" x2="8.5725" y2="4.1275" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="5.08" x2="8.5725" y2="5.08" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="6.0325" x2="8.5725" y2="6.0325" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="6.985" x2="8.5725" y2="6.985" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="7.9375" x2="8.5725" y2="7.9375" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="8.89" x2="8.5725" y2="8.89" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="9.8425" x2="8.5725" y2="9.8425" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="10.795" x2="8.5725" y2="10.795" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="11.7475" x2="-8.255" y2="11.7475" width="0.2" layer="21"/>
<wire x1="-8.255" y1="11.7475" x2="8.255" y2="11.7475" width="0.2" layer="21"/>
<wire x1="8.255" y1="11.7475" x2="8.5725" y2="11.7475" width="0.2" layer="21"/>
<wire x1="-8.255" y1="-20.955" x2="-7.9375" y2="-20.955" width="0.2" layer="21"/>
<wire x1="-7.9375" y1="-20.955" x2="7.62" y2="-20.955" width="0.2" layer="21"/>
<wire x1="7.62" y1="-20.955" x2="7.9375" y2="-20.955" width="0.2" layer="21"/>
<wire x1="-7.62" y1="-21.59" x2="-7.3025" y2="-21.59" width="0.2" layer="21"/>
<wire x1="-7.3025" y1="-21.59" x2="6.985" y2="-21.59" width="0.2" layer="21"/>
<wire x1="6.985" y1="-21.59" x2="7.3025" y2="-21.59" width="0.2" layer="21"/>
<wire x1="-6.985" y1="-22.225" x2="-6.6675" y2="-22.225" width="0.2" layer="21"/>
<wire x1="-6.6675" y1="-22.225" x2="6.35" y2="-22.225" width="0.2" layer="21"/>
<wire x1="6.35" y1="-22.225" x2="6.6675" y2="-22.225" width="0.2" layer="21"/>
<wire x1="-6.35" y1="-22.5425" x2="-6.0325" y2="-22.5425" width="0.2" layer="21"/>
<wire x1="-6.0325" y1="-22.5425" x2="5.715" y2="-22.5425" width="0.2" layer="21"/>
<wire x1="5.715" y1="-22.5425" x2="6.0325" y2="-22.5425" width="0.2" layer="21"/>
<wire x1="-5.715" y1="-22.86" x2="-5.3975" y2="-22.86" width="0.2" layer="21"/>
<wire x1="-5.3975" y1="-22.86" x2="5.3975" y2="-22.86" width="0.2" layer="21"/>
<wire x1="5.3975" y1="-22.86" x2="5.715" y2="-22.86" width="0.2" layer="21"/>
<wire x1="-5.08" y1="-23.1775" x2="-4.7625" y2="-23.1775" width="0.2" layer="21"/>
<wire x1="-4.7625" y1="-23.1775" x2="4.7625" y2="-23.1775" width="0.2" layer="21"/>
<wire x1="4.7625" y1="-23.1775" x2="5.08" y2="-23.1775" width="0.2" layer="21"/>
<wire x1="-8.255" y1="-20.32" x2="-7.9375" y2="-20.955" width="0.05" layer="21"/>
<wire x1="-7.9375" y1="-20.955" x2="-7.3025" y2="-21.59" width="0.05" layer="21"/>
<wire x1="-7.3025" y1="-21.59" x2="-6.6675" y2="-22.225" width="0.05" layer="21"/>
<wire x1="-6.6675" y1="-22.225" x2="-6.0325" y2="-22.5425" width="0.05" layer="21"/>
<wire x1="-6.0325" y1="-22.5425" x2="-5.3975" y2="-22.86" width="0.05" layer="21"/>
<wire x1="-5.3975" y1="-22.86" x2="-4.7625" y2="-23.1775" width="0.05" layer="21"/>
<wire x1="8.255" y1="-20.32" x2="7.62" y2="-20.955" width="0.05" layer="21"/>
<wire x1="7.62" y1="-20.955" x2="6.985" y2="-21.59" width="0.05" layer="21"/>
<wire x1="6.985" y1="-21.59" x2="6.35" y2="-22.225" width="0.05" layer="21"/>
<wire x1="6.35" y1="-22.225" x2="5.715" y2="-22.5425" width="0.05" layer="21"/>
<wire x1="5.715" y1="-22.5425" x2="5.3975" y2="-22.86" width="0.05" layer="21"/>
<wire x1="5.3975" y1="-22.86" x2="4.7625" y2="-23.1775" width="0.05" layer="21"/>
<wire x1="-4.7625" y1="14.9225" x2="-4.445" y2="14.9225" width="0.2" layer="21"/>
<wire x1="-4.445" y1="14.9225" x2="4.445" y2="14.9225" width="0.2" layer="21"/>
<wire x1="4.445" y1="14.9225" x2="4.7625" y2="14.9225" width="0.2" layer="21"/>
<wire x1="-5.3975" y1="14.605" x2="-5.08" y2="14.605" width="0.2" layer="21"/>
<wire x1="-5.08" y1="14.605" x2="5.08" y2="14.605" width="0.2" layer="21"/>
<wire x1="5.08" y1="14.605" x2="5.3975" y2="14.605" width="0.2" layer="21"/>
<wire x1="-6.0325" y1="14.2875" x2="-5.715" y2="14.2875" width="0.2" layer="21"/>
<wire x1="-5.715" y1="14.2875" x2="5.715" y2="14.2875" width="0.2" layer="21"/>
<wire x1="5.715" y1="14.2875" x2="6.0325" y2="14.2875" width="0.2" layer="21"/>
<wire x1="-6.6675" y1="13.97" x2="-6.35" y2="13.97" width="0.2" layer="21"/>
<wire x1="-6.35" y1="13.97" x2="6.35" y2="13.97" width="0.2" layer="21"/>
<wire x1="6.35" y1="13.97" x2="6.6675" y2="13.97" width="0.2" layer="21"/>
<wire x1="-7.3025" y1="13.335" x2="-6.985" y2="13.335" width="0.2" layer="21"/>
<wire x1="-6.985" y1="13.335" x2="6.985" y2="13.335" width="0.2" layer="21"/>
<wire x1="6.985" y1="13.335" x2="7.3025" y2="13.335" width="0.2" layer="21"/>
<wire x1="-7.9375" y1="12.7" x2="-7.62" y2="12.7" width="0.2" layer="21"/>
<wire x1="-7.62" y1="12.7" x2="7.62" y2="12.7" width="0.2" layer="21"/>
<wire x1="7.62" y1="12.7" x2="7.9375" y2="12.7" width="0.2" layer="21"/>
<wire x1="-8.255" y1="11.7475" x2="-7.62" y2="12.7" width="0.05" layer="21"/>
<wire x1="-7.62" y1="12.7" x2="-6.985" y2="13.335" width="0.05" layer="21"/>
<wire x1="-6.985" y1="13.335" x2="-6.35" y2="13.97" width="0.05" layer="21"/>
<wire x1="-6.35" y1="13.97" x2="-5.715" y2="14.2875" width="0.05" layer="21"/>
<wire x1="-5.715" y1="14.2875" x2="-5.08" y2="14.605" width="0.05" layer="21"/>
<wire x1="-5.08" y1="14.605" x2="-4.445" y2="14.9225" width="0.05" layer="21"/>
<wire x1="8.255" y1="11.7475" x2="7.62" y2="12.7" width="0.05" layer="21"/>
<wire x1="7.62" y1="12.7" x2="6.985" y2="13.335" width="0.05" layer="21"/>
<wire x1="6.985" y1="13.335" x2="6.35" y2="13.97" width="0.05" layer="21"/>
<wire x1="6.35" y1="13.97" x2="5.715" y2="14.2875" width="0.05" layer="21"/>
<wire x1="5.715" y1="14.2875" x2="5.08" y2="14.605" width="0.05" layer="21"/>
<wire x1="5.08" y1="14.605" x2="4.445" y2="14.9225" width="0.05" layer="21"/>
<wire x1="-8.5725" y1="-14.605" x2="8.5725" y2="-14.605" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-13.6525" x2="8.5725" y2="-13.6525" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-12.7" x2="8.5725" y2="-12.7" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-11.7475" x2="8.5725" y2="-11.7475" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-10.795" x2="8.5725" y2="-10.795" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-9.8425" x2="8.5725" y2="-9.8425" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-8.89" x2="8.5725" y2="-8.89" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-7.9375" x2="8.5725" y2="-7.9375" width="0.2" layer="21"/>
<wire x1="-8.5725" y1="-6.985" x2="8.5725" y2="-6.985" width="0.2" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="TOROID3">
<wire x1="2.2225" y1="-5.715" x2="4.445" y2="-5.715" width="0.254" layer="94" curve="-181.082723"/>
<wire x1="0" y1="-5.715" x2="2.2225" y2="-5.715" width="0.254" layer="94" curve="-181.082723"/>
<wire x1="-2.2225" y1="-5.715" x2="0" y2="-5.715" width="0.254" layer="94" curve="-181.082723"/>
<wire x1="-4.445" y1="-5.715" x2="-2.2225" y2="-5.715" width="0.254" layer="94" curve="-181.082723"/>
<wire x1="4.445" y1="-5.715" x2="5.08" y2="-5.715" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.715" x2="5.08" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-5.715" x2="-5.08" y2="-5.715" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.715" x2="-5.08" y2="-6.35" width="0.254" layer="94"/>
<circle x="0" y="0" radius="3.4925" width="0.8128" layer="94"/>
<text x="-3.81" y="8.9916" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="4.699" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="-11.43" visible="off" length="middle" rot="R90"/>
<pin name="1" x="-5.08" y="-11.43" visible="off" length="middle" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="34X11MM_TOROID_áLLó" prefix="L">
<gates>
<gate name="G$1" symbol="TOROID3" x="0" y="0"/>
</gates>
<devices>
<device name="" package="34X11MM_TOROID_áLLó">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor-power">
<description>&lt;b&gt;Vitrohm Power Resistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HUZAL_18X10MM_KELVIN">
<text x="-4.445" y="4.7625" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0925" y="-6.6675" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<wire x1="-9.2075" y1="-3.175" x2="-9.2075" y2="3.175" width="0.127" layer="21"/>
<wire x1="-9.2075" y1="3.175" x2="0.9525" y2="3.175" width="0.127" layer="21"/>
<wire x1="0.9525" y1="3.175" x2="9.2075" y2="3.175" width="0.127" layer="21"/>
<wire x1="-9.2075" y1="-3.175" x2="9.2075" y2="-3.175" width="0.127" layer="21"/>
<wire x1="9.2075" y1="-3.175" x2="9.2075" y2="3.175" width="0.127" layer="21"/>
<wire x1="-7.62" y1="4.1275" x2="-7.62" y2="-4.1275" width="0.4064" layer="21"/>
<wire x1="7.62" y1="4.1275" x2="7.62" y2="-4.1275" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="4.1275" x2="-7.62" y2="6.0325" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-4.1275" x2="-7.62" y2="-5.08" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-5.08" x2="-7.62" y2="-6.0325" width="0.127" layer="21"/>
<wire x1="7.62" y1="4.1275" x2="7.62" y2="5.08" width="0.127" layer="21"/>
<wire x1="7.62" y1="5.08" x2="7.62" y2="6.0325" width="0.127" layer="21"/>
<wire x1="7.62" y1="-4.1275" x2="7.62" y2="-6.0325" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-5.08" x2="-4.445" y2="3.4925" width="0.8128" layer="21"/>
<wire x1="0.9525" y1="3.175" x2="-1.27" y2="-3.4925" width="0.8128" layer="21"/>
<wire x1="4.445" y1="-3.4925" x2="7.62" y2="5.08" width="0.8128" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8" diameter="3"/>
<pad name="2" x="7.62" y="0" drill="0.8" diameter="3"/>
<pad name="1A" x="-7.62" y="4.1275" drill="0.6" diameter="1.778" shape="square"/>
<pad name="2A" x="7.62" y="-4.1275" drill="0.6" diameter="1.778" shape="square"/>
</package>
</packages>
<symbols>
<symbol name="R-4_WIRE_KELVIN">
<wire x1="-3.81" y1="-0.889" x2="3.81" y2="-0.889" width="0.254" layer="94"/>
<wire x1="3.81" y1="-0.889" x2="3.81" y2="0" width="0.254" layer="94"/>
<wire x1="3.81" y1="0.889" x2="-3.81" y2="0.889" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-0.889" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="6.35" y2="0" width="0.4064" layer="94"/>
<wire x1="3.81" y1="0" x2="3.81" y2="0.889" width="0.254" layer="94"/>
<wire x1="-6.35" y1="0" x2="-3.81" y2="0" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.3716" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="6.35" y="0" visible="off" length="point" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-6.35" y="0" visible="off" length="point" direction="pas" swaplevel="1"/>
<pin name="1A" x="-6.35" y="-2.54" visible="off" length="point" direction="pas"/>
<pin name="2A" x="6.35" y="-2.54" visible="off" length="point" direction="pas"/>
<wire x1="-3.81" y1="0" x2="-5.3975" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-5.3975" y1="-2.54" x2="-6.35" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="5.3975" y2="-2.54" width="0.254" layer="94"/>
<wire x1="5.3975" y1="-2.54" x2="6.35" y2="-2.54" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="HUZAL_4WIRE_KELVIN" prefix="R">
<gates>
<gate name="G$1" symbol="R-4_WIRE_KELVIN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="HUZAL_18X10MM_KELVIN">
<connects>
<connect gate="G$1" pin="1A" pad="1A"/>
<connect gate="G$1" pin="2A" pad="2A"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="IC1" library="v-reg" deviceset="78XX_SMD" device="" value="7805_SMD"/>
<part name="IC2" library="v-reg" deviceset="79XX_SMD" device="" value="7905_SMD"/>
<part name="C10" library="rcl" deviceset="CPOL-EU" device="E2.5-5" value="100uF/16V"/>
<part name="C13" library="rcl" deviceset="CPOL-EU" device="E2.5-5" value="100uF/16V"/>
<part name="C11" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C4" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C15" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C14" library="rcl" deviceset="C-EU" device="C0805" value="1uF"/>
<part name="C12" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C8" library="rcl" deviceset="C-EU" device="C0805" value="1uF"/>
<part name="CS1" library="sorkapocs" deviceset="3-AS" device="" value="+/-9V"/>
<part name="P+1" library="supply1" deviceset="+5V" device=""/>
<part name="P-1" library="supply1" deviceset="-5V" device=""/>
<part name="SUPPLY1" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY2" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY3" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY4" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY5" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY6" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY7" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY8" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY9" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY10" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY11" library="supply2" deviceset="AGND" device=""/>
<part name="C35" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="SUPPLY18" library="supply2" deviceset="AGND" device=""/>
<part name="IC4" library="linear" deviceset="TLC2272" device=""/>
<part name="P-2" library="supply1" deviceset="-5V" device=""/>
<part name="P+4" library="supply1" deviceset="+5V" device=""/>
<part name="IC5" library="linear" deviceset="TLC2272" device=""/>
<part name="IC6" library="linear" deviceset="TLC2272" device=""/>
<part name="P+5" library="supply1" deviceset="+5V" device=""/>
<part name="P+6" library="supply1" deviceset="+5V" device=""/>
<part name="P-3" library="supply1" deviceset="-5V" device=""/>
<part name="P-4" library="supply1" deviceset="-5V" device=""/>
<part name="C20" library="rcl" deviceset="CPOL-EU" device="E7.5-16" value="1000uF/63V"/>
<part name="C21" library="rcl" deviceset="C-EU" device="050-075X075" value="2,2uF/63V"/>
<part name="GND6" library="supply1" deviceset="0V" device=""/>
<part name="IC3" library="linear" deviceset="*555" device="D" technology="NE"/>
<part name="R11" library="rcl" deviceset="R-EU_" device="R1206" value="470"/>
<part name="R12" library="rcl" deviceset="R-EU_" device="R1206" value="470"/>
<part name="R13" library="rcl" deviceset="R-EU_" device="R1206" value="470"/>
<part name="R14" library="rcl" deviceset="R-EU_" device="R1206" value="470"/>
<part name="R15" library="rcl" deviceset="R-EU_" device="R0805" value="47k"/>
<part name="T10" library="transistor-fet" deviceset="IRLR3410" device="" value="IRFR024N"/>
<part name="D13" library="diode" deviceset="SMZ" device="" value="SMZ18"/>
<part name="D14" library="diode" deviceset="SMZ" device="" value="SMZ15"/>
<part name="C22" library="rcl" deviceset="CPOL-EU" device="E2.5-6" value="100uF/25V"/>
<part name="C23" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND7" library="supply1" deviceset="0V" device=""/>
<part name="GND8" library="supply1" deviceset="0V" device=""/>
<part name="GND9" library="supply1" deviceset="0V" device=""/>
<part name="GND10" library="supply1" deviceset="0V" device=""/>
<part name="C27" library="rcl" deviceset="C-EU" device="C0805" value="10nF"/>
<part name="D16" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D15" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D17" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="T12" library="transistor-pnp" deviceset="MMBTA92*" device="SMD" technology="LT1"/>
<part name="T13" library="transistor-pnp" deviceset="MMBTA92*" device="SMD" technology="LT1"/>
<part name="T16" library="transistor-npn" deviceset="BC817*" device="SMD" technology="-25LT1"/>
<part name="R16" library="rcl" deviceset="R-EU_" device="R1206" value="1,2k"/>
<part name="R17" library="rcl" deviceset="R-EU_" device="R1206" value="1,2k"/>
<part name="R18" library="rcl" deviceset="R-EU_" device="R1206" value="1,2k"/>
<part name="R19" library="rcl" deviceset="R-EU_" device="R1206" value="1,2k"/>
<part name="D22" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D23" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D24" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="C25" library="rcl" deviceset="C-EU" device="C0805" value="1uF"/>
<part name="GND11" library="supply1" deviceset="0V" device=""/>
<part name="RS1" library="rcl" deviceset="R-EU_" device="0414/15" value="0,1"/>
<part name="RS2" library="rcl" deviceset="R-EU_" device="0414/15" value="0,1"/>
<part name="R20" library="rcl" deviceset="R-EU_" device="R0805" value="27k"/>
<part name="R24" library="rcl" deviceset="R-EU_" device="R0805" value="12k"/>
<part name="C24" library="rcl" deviceset="C-EU" device="C0805" value="330pF"/>
<part name="D19" library="diode" deviceset="STPR1020" device=""/>
<part name="GND12" library="supply1" deviceset="0V" device=""/>
<part name="D18" library="diode" deviceset="BAT46" device=""/>
<part name="C26" library="rcl" deviceset="C-EU" device="C0805" value="1nF"/>
<part name="R26" library="rcl" deviceset="R-EU_" device="R1206" value="10"/>
<part name="R25" library="rcl" deviceset="R-EU_" device="R1206" value="10"/>
<part name="T11" library="transistor-fet" deviceset="IRF840" device="" value="IRF3710"/>
<part name="D20" library="diode" deviceset="BAT46" device=""/>
<part name="D21" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="R21" library="rcl" deviceset="R-EU_" device="R0805" value="470"/>
<part name="R22" library="rcl" deviceset="R-EU_" device="R0805" value="2k"/>
<part name="C28" library="rcl" deviceset="C-EU" device="C0805" value="220nF"/>
<part name="GND13" library="supply1" deviceset="0V" device=""/>
<part name="C29" library="rcl" deviceset="CPOL-EU" device="E7.5-16" value="1000uF/50V"/>
<part name="C30" library="rcl" deviceset="CPOL-EU" device="E7.5-16" value="1000uF/50V"/>
<part name="C31" library="rcl" deviceset="C-EU" device="050-075X075" value="2,2uF/63V"/>
<part name="C33" library="rcl" deviceset="C-EU" device="102-043X133" value="10nF/3000V"/>
<part name="H1" library="forrszem" deviceset="H" device=""/>
<part name="T15" library="transistor-fet" deviceset="IRF840" device="" value="IRL540"/>
<part name="R27" library="rcl" deviceset="R-EU_" device="R0805" value="100k"/>
<part name="D25" library="diode" deviceset="ER1M" device=""/>
<part name="R64" library="rcl" deviceset="R-EU_" device="R1206" value="10"/>
<part name="R65" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R69" library="rcl" deviceset="R-EU_" device="R1206" value="820"/>
<part name="R68" library="rcl" deviceset="R-EU_" device="R1206" value="820"/>
<part name="R67" library="rcl" deviceset="R-EU_" device="R1206" value="820"/>
<part name="R66" library="rcl" deviceset="R-EU_" device="R1206" value="820"/>
<part name="D28" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D29" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="R61" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="R62" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="C41" library="rcl" deviceset="C-EU" device="C0805" value="1nF"/>
<part name="C39" library="rcl" deviceset="C-EU" device="C0805" value="1nF"/>
<part name="R72" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="R51" library="rcl" deviceset="R-EU_" device="R0805" value="22"/>
<part name="R59" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R52" library="rcl" deviceset="R-EU_" device="R0805" value="8,2k"/>
<part name="R60" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="P3" library="rcl" deviceset="R-TRIMM" device="64W" value="5k"/>
<part name="P4" library="rcl" deviceset="R-TRIMM" device="64W" value="1k"/>
<part name="P+7" library="supply1" deviceset="+5V" device=""/>
<part name="P-5" library="supply1" deviceset="-5V" device=""/>
<part name="SUPPLY20" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY21" library="supply2" deviceset="AGND" device=""/>
<part name="GND14" library="supply1" deviceset="0V" device=""/>
<part name="GND15" library="supply1" deviceset="GNDA" device="" value="SGND"/>
<part name="C42" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C43" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND16" library="supply1" deviceset="GNDA" device="" value="SGND"/>
<part name="SUPPLY22" library="supply2" deviceset="AGND" device=""/>
<part name="D30" library="diode" deviceset="BAT46" device=""/>
<part name="R54" library="rcl" deviceset="R-EU_" device="R0805" value="15k"/>
<part name="R56" library="rcl" deviceset="R-EU_" device="R0805" value="2,2k"/>
<part name="R48" library="rcl" deviceset="R-EU_" device="R0805" value="100"/>
<part name="R47" library="rcl" deviceset="R-EU_" device="R0805" value="180k"/>
<part name="R46" library="rcl" deviceset="R-EU_" device="R0805" value="22k"/>
<part name="C40" library="rcl" deviceset="C-EU" device="C0805" value="1nF"/>
<part name="C38" library="rcl" deviceset="C-EU" device="C0805" value="100pF"/>
<part name="GND17" library="supply1" deviceset="GNDA" device="" value="SGND"/>
<part name="C44" library="rcl" deviceset="C-EU" device="050-075X075" value="2,2uF/63V"/>
<part name="C45" library="rcl" deviceset="C-EU" device="050-075X075" value="2,2uF/63V"/>
<part name="C45/2" library="rcl" deviceset="C-EU" device="050-075X075" value="2,2uF/63V"/>
<part name="C46" library="rcl" deviceset="C-EU" device="050-025X075" value="100nF"/>
<part name="CS4" library="pinhead" deviceset="1XNAGY" device="" value="Uki(-)"/>
<part name="CS3" library="pinhead" deviceset="1XNAGY" device="" value="Uki(+)"/>
<part name="R23" library="rcl" deviceset="R-EU_" device="R1206" value="33k"/>
<part name="R70" library="rcl" deviceset="R-EU_" device="R1206" value="220k"/>
<part name="C32" library="rcl" deviceset="C-EU" device="102-043X133" value="10nF/3000V"/>
<part name="D27" library="diode" deviceset="ZENER-DIODE" device="SOD80C" value="3V3"/>
<part name="D26" library="diode" deviceset="ZENER-DIODE" device="SOD80C" value="3V3"/>
<part name="R53" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R49" library="rcl" deviceset="R-EU_" device="R1206" value="1k"/>
<part name="R75" library="rcl" deviceset="R-EU_" device="R1206" value="100k"/>
<part name="SUPPLY19" library="supply2" deviceset="AGND" device=""/>
<part name="C37" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND1" library="supply1" deviceset="GNDA" device="" value="SGND"/>
<part name="P2" library="rcl" deviceset="R-TRIMM" device="64W" value="50k"/>
<part name="P1" library="rcl" deviceset="R-TRIMM" device="64W" value="10k"/>
<part name="IC9" library="linear" deviceset="OP07*" device="R" technology="C"/>
<part name="P-6" library="supply1" deviceset="-5V" device=""/>
<part name="P+10" library="supply1" deviceset="+5V" device=""/>
<part name="P5" library="rcl" deviceset="R-TRIMM" device="64W" value="22k"/>
<part name="P+11" library="supply1" deviceset="+5V" device=""/>
<part name="P6" library="rcl" deviceset="R-TRIMM" device="64W" value="10k"/>
<part name="R38" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="D3" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="C1" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="SUPPLY12" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY14" library="supply2" deviceset="AGND" device=""/>
<part name="C16" library="rcl" deviceset="C-EU" device="C0805" value="10nF"/>
<part name="IC10" library="linear" deviceset="OP07*" device="R" technology="C"/>
<part name="R39" library="rcl" deviceset="R-EU_" device="R0805" value="8,2k"/>
<part name="P8" library="rcl" deviceset="R-TRIMM" device="64W" value="5k"/>
<part name="C17" library="rcl" deviceset="C-EU" device="C0805" value="10nF"/>
<part name="R41" library="rcl" deviceset="R-EU_" device="R0805" value="27k"/>
<part name="R42" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="D4" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="C18" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="P7" library="rcl" deviceset="R-TRIMM" device="64W" value="22k"/>
<part name="SUPPLY15" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY16" library="supply2" deviceset="AGND" device=""/>
<part name="P+14" library="supply1" deviceset="+5V" device=""/>
<part name="SUPPLY17" library="supply2" deviceset="AGND" device=""/>
<part name="TP1" library="pinhead" deviceset="PINHD-1X1" device="" value="ref. fesz"/>
<part name="TP2" library="pinhead" deviceset="PINHD-1X1" device="" value="ref. áram"/>
<part name="IC7" library="microchip" deviceset="MCP1501" device=""/>
<part name="IC8" library="microchip" deviceset="MCP4922" device=""/>
<part name="P+2" library="supply1" deviceset="+5V" device=""/>
<part name="C2" library="rcl" deviceset="C-EU" device="C0805" value="2,2uF"/>
<part name="C3" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="R1" library="rcl" deviceset="R-EU_" device="R0805" value="1k"/>
<part name="R2" library="rcl" deviceset="R-EU_" device="R0805" value="51"/>
<part name="C5" library="rcl" deviceset="C-EU" device="C0805" value="2,2uF"/>
<part name="P+3" library="supply1" deviceset="+5V" device=""/>
<part name="C6" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C7" library="rcl" deviceset="CPOL-EU" device="B/3528-21R" value="10uF"/>
<part name="SUPPLY23" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY24" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY25" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY26" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY27" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY31" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY32" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY33" library="supply2" deviceset="AGND" device=""/>
<part name="P+8" library="supply1" deviceset="+5V" device=""/>
<part name="SUPPLY34" library="supply2" deviceset="AGND" device=""/>
<part name="IC11" library="microchip" deviceset="PIC18F2620" device="" value="PIC18F2523"/>
<part name="P+9" library="supply1" deviceset="+5V" device=""/>
<part name="C9" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND2" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="SUPPLY30" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY35" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY36" library="supply2" deviceset="AGND" device=""/>
<part name="GND3" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="GND4" library="supply1" deviceset="0V" device=""/>
<part name="GND5" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="GND18" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="C19" library="rcl" deviceset="C-EU" device="C0805" value="22pF"/>
<part name="C34" library="rcl" deviceset="C-EU" device="C0805" value="22pF"/>
<part name="HMI" library="pinhead" deviceset="PINHD-1X4" device=""/>
<part name="GND19" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="C36" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="SUPPLY28" library="supply2" deviceset="AGND" device=""/>
<part name="SUPPLY37" library="supply2" deviceset="AGND" device=""/>
<part name="C47" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="SUPPLY38" library="supply2" deviceset="AGND" device=""/>
<part name="GND20" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="GND21" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="Q1" library="crystal" deviceset="SMD-5032" device="" value="10MHz"/>
<part name="ICSP" library="pinhead" deviceset="PINHD-1X5" device=""/>
<part name="P+15" library="supply1" deviceset="+5V" device=""/>
<part name="GND22" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="ENCODER" library="pinhead" deviceset="PINHD-1X4" device=""/>
<part name="GND23" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="P+17" library="supply1" deviceset="+5V" device=""/>
<part name="TP3" library="pinhead" deviceset="PINHD-1X1" device="" value="4,096Vref"/>
<part name="TP4" library="pinhead" deviceset="PINHD-1X1" device="" value="mért fesz."/>
<part name="TP5" library="pinhead" deviceset="PINHD-1X1" device="" value="mért áram"/>
<part name="C48" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C49" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="C50" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND24" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="D1" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="D2" library="diode" deviceset="1N4148" device="SOD323" value="1N4148"/>
<part name="SUPPLY13" library="supply2" deviceset="AGND" device=""/>
<part name="C51" library="rcl" deviceset="C-EU" device="C0805" value="100nF"/>
<part name="GND25" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="P+12" library="supply1" deviceset="+5V" device=""/>
<part name="C52" library="rcl" deviceset="CPOL-EU" device="B/3528-21R" value="10uF"/>
<part name="GND26" library="supply1" deviceset="GND" device="" value="DGND"/>
<part name="P+16" library="supply1" deviceset="+5V" device=""/>
<part name="P+13" library="supply1" deviceset="+5V" device=""/>
<part name="P-7" library="supply1" deviceset="-5V" device=""/>
<part name="L1" library="tekercsek" deviceset="34X11MM_TOROID_áLLó" device="" value="100uH"/>
<part name="RS5" library="resistor-power" deviceset="HUZAL_4WIRE_KELVIN" device="" value="0.1"/>
<part name="SK1" library="sorkapocs" deviceset="2-ES+2DB_STAB" device=""/>
<part name="R9" library="rcl" deviceset="R-EU_" device="R1206" value="0"/>
<part name="R28" library="rcl" deviceset="R-EU_" device="R1206" value="0"/>
<part name="JP2" library="pinhead" deviceset="PINHD-1X1" device=""/>
<part name="JP3" library="pinhead" deviceset="PINHD-1X1" device=""/>
<part name="SUPPLY39" library="supply2" deviceset="AGND" device=""/>
<part name="R35" library="rcl" deviceset="R-EU_" device="M0805" value="10k"/>
<part name="R36" library="rcl" deviceset="R-EU_" device="R0805" value="82k"/>
<part name="R50" library="rcl" deviceset="R-EU_" device="R0805" value="4,7k"/>
<part name="R34" library="rcl" deviceset="R-EU_" device="R1206" value="10k"/>
<part name="R58" library="rcl" deviceset="R-EU_" device="R1206" value="22"/>
<part name="R57" library="rcl" deviceset="R-EU_" device="R1206" value="4,7k"/>
<part name="R55" library="rcl" deviceset="R-EU_" device="R1206" value="2k"/>
<part name="R5" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R6" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R7" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R8" library="rcl" deviceset="R-EU_" device="R0805" value="10k"/>
<part name="R3" library="rcl" deviceset="R-EU_" device="R0805" value="100k"/>
<part name="R4" library="rcl" deviceset="R-EU_" device="R0805" value="100k"/>
<part name="R29" library="rcl" deviceset="R-EU_" device="R0805" value="22k"/>
<part name="GND27" library="supply1" deviceset="GND" device="" value="DGND"/>
</parts>
<sheets>
<sheet>
<plain>
<text x="124.46" y="-27.94" size="1.778" layer="91">fesz.</text>
<text x="83.82" y="86.36" size="1.778" layer="91">áram</text>
</plain>
<instances>
<instance part="IC1" gate="G$1" x="-140.97" y="36.83" smashed="yes">
<attribute name="NAME" x="-147.32" y="40.64" size="1.778" layer="95"/>
<attribute name="VALUE" x="-142.24" y="40.64" size="1.778" layer="96"/>
</instance>
<instance part="IC2" gate="G$1" x="-140.97" y="6.35" smashed="yes">
<attribute name="NAME" x="-146.05" y="12.7" size="1.778" layer="95"/>
<attribute name="VALUE" x="-147.32" y="1.27" size="1.778" layer="96"/>
</instance>
<instance part="C10" gate="G$1" x="-162.56" y="34.29" smashed="yes">
<attribute name="NAME" x="-161.417" y="34.7726" size="1.778" layer="95"/>
<attribute name="VALUE" x="-167.767" y="38.5826" size="1.778" layer="96"/>
</instance>
<instance part="C13" gate="G$1" x="-162.56" y="11.43" smashed="yes">
<attribute name="NAME" x="-161.417" y="11.9126" size="1.778" layer="95"/>
<attribute name="VALUE" x="-167.767" y="3.0226" size="1.778" layer="96"/>
</instance>
<instance part="C11" gate="G$1" x="-153.67" y="34.29" smashed="yes">
<attribute name="NAME" x="-152.146" y="34.671" size="1.778" layer="95"/>
<attribute name="VALUE" x="-155.956" y="37.211" size="1.778" layer="96"/>
</instance>
<instance part="C4" gate="G$1" x="-153.67" y="11.43" smashed="yes">
<attribute name="NAME" x="-152.146" y="11.811" size="1.778" layer="95"/>
<attribute name="VALUE" x="-154.686" y="2.921" size="1.778" layer="96"/>
</instance>
<instance part="C15" gate="G$1" x="-130.81" y="11.43" smashed="yes">
<attribute name="NAME" x="-129.286" y="11.811" size="1.778" layer="95"/>
<attribute name="VALUE" x="-134.366" y="2.921" size="1.778" layer="96"/>
</instance>
<instance part="C14" gate="G$1" x="-123.19" y="11.43" smashed="yes">
<attribute name="NAME" x="-121.666" y="11.811" size="1.778" layer="95"/>
<attribute name="VALUE" x="-124.206" y="2.921" size="1.778" layer="96"/>
</instance>
<instance part="C12" gate="G$1" x="-130.81" y="34.29" smashed="yes">
<attribute name="NAME" x="-129.286" y="34.671" size="1.778" layer="95"/>
<attribute name="VALUE" x="-133.096" y="37.211" size="1.778" layer="96"/>
</instance>
<instance part="C8" gate="G$1" x="-124.46" y="34.29" smashed="yes">
<attribute name="NAME" x="-122.936" y="34.671" size="1.778" layer="95"/>
<attribute name="VALUE" x="-125.476" y="37.211" size="1.778" layer="96"/>
</instance>
<instance part="CS1" gate="G$1" x="-177.8" y="22.86" smashed="yes" rot="R180">
<attribute name="NAME" x="-173.99" y="17.145" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-173.99" y="30.48" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+1" gate="1" x="-116.84" y="39.37" smashed="yes">
<attribute name="VALUE" x="-115.57" y="41.91" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P-1" gate="1" x="-116.84" y="3.81" smashed="yes">
<attribute name="VALUE" x="-115.57" y="2.54" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY1" gate="G$1" x="-168.91" y="22.86" smashed="yes" rot="R90">
<attribute name="VALUE" x="-165.735" y="20.193" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="SUPPLY2" gate="G$1" x="-162.56" y="26.67" smashed="yes">
<attribute name="VALUE" x="-165.227" y="23.495" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY3" gate="G$1" x="-153.67" y="26.67" smashed="yes">
<attribute name="VALUE" x="-156.337" y="23.495" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY4" gate="G$1" x="-140.97" y="26.67" smashed="yes">
<attribute name="VALUE" x="-143.637" y="23.495" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY5" gate="G$1" x="-130.81" y="26.67" smashed="yes">
<attribute name="VALUE" x="-133.477" y="23.495" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY6" gate="G$1" x="-124.46" y="26.67" smashed="yes">
<attribute name="VALUE" x="-127.127" y="23.495" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY7" gate="G$1" x="-162.56" y="16.51" smashed="yes" rot="R180">
<attribute name="VALUE" x="-159.893" y="19.685" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY8" gate="G$1" x="-153.67" y="16.51" smashed="yes" rot="R180">
<attribute name="VALUE" x="-151.003" y="19.685" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY9" gate="G$1" x="-140.97" y="16.51" smashed="yes" rot="R180">
<attribute name="VALUE" x="-138.303" y="19.685" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY10" gate="G$1" x="-130.81" y="16.51" smashed="yes" rot="R180">
<attribute name="VALUE" x="-128.143" y="19.685" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY11" gate="G$1" x="-123.19" y="16.51" smashed="yes" rot="R180">
<attribute name="VALUE" x="-120.523" y="19.685" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C35" gate="G$1" x="53.34" y="106.68" smashed="yes">
<attribute name="NAME" x="54.864" y="107.061" size="1.778" layer="95"/>
<attribute name="VALUE" x="54.864" y="101.981" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY18" gate="G$1" x="53.34" y="97.79" smashed="yes">
<attribute name="VALUE" x="50.673" y="94.615" size="1.778" layer="96"/>
</instance>
<instance part="IC4" gate="A" x="69.85" y="85.09" smashed="yes">
<attribute name="NAME" x="72.39" y="88.265" size="1.778" layer="95"/>
<attribute name="VALUE" x="72.39" y="80.01" size="1.778" layer="96"/>
</instance>
<instance part="IC4" gate="B" x="69.85" y="107.95" smashed="yes">
<attribute name="NAME" x="72.39" y="111.125" size="1.778" layer="95"/>
<attribute name="VALUE" x="72.39" y="102.87" size="1.778" layer="96"/>
</instance>
<instance part="IC4" gate="G$3" x="-161.29" y="57.15" smashed="yes"/>
<instance part="P-2" gate="1" x="-161.29" y="46.99" smashed="yes">
<attribute name="VALUE" x="-160.02" y="45.72" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+4" gate="1" x="-161.29" y="67.31" smashed="yes">
<attribute name="VALUE" x="-160.02" y="69.85" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC5" gate="A" x="39.37" y="-50.8" smashed="yes" rot="R180">
<attribute name="NAME" x="36.83" y="-53.975" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="36.83" y="-45.72" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC5" gate="B" x="39.37" y="-71.12" smashed="yes" rot="R180">
<attribute name="NAME" x="36.83" y="-74.295" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="36.83" y="-66.04" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC5" gate="G$3" x="-149.86" y="57.15" smashed="yes"/>
<instance part="IC6" gate="B" x="41.91" y="-90.17" smashed="yes">
<attribute name="NAME" x="44.45" y="-86.995" size="1.778" layer="95"/>
<attribute name="VALUE" x="44.45" y="-95.25" size="1.778" layer="96"/>
</instance>
<instance part="IC6" gate="G$3" x="-139.7" y="57.15" smashed="yes"/>
<instance part="P+5" gate="1" x="-149.86" y="67.31" smashed="yes">
<attribute name="VALUE" x="-148.59" y="69.85" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+6" gate="1" x="-139.7" y="67.31" smashed="yes">
<attribute name="VALUE" x="-138.43" y="69.85" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P-3" gate="1" x="-149.86" y="46.99" smashed="yes">
<attribute name="VALUE" x="-148.59" y="45.72" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P-4" gate="1" x="-139.7" y="46.99" smashed="yes">
<attribute name="VALUE" x="-138.43" y="45.72" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C20" gate="G$1" x="-120.65" y="-27.94" smashed="yes">
<attribute name="NAME" x="-119.507" y="-27.4574" size="1.778" layer="95"/>
<attribute name="VALUE" x="-127.127" y="-40.1574" size="1.778" layer="96"/>
</instance>
<instance part="C21" gate="G$1" x="-113.03" y="-27.94" smashed="yes">
<attribute name="NAME" x="-111.506" y="-27.559" size="1.778" layer="95"/>
<attribute name="VALUE" x="-116.586" y="-36.449" size="1.778" layer="96"/>
</instance>
<instance part="GND6" gate="1" x="-120.65" y="-35.56" smashed="yes">
<attribute name="VALUE" x="-122.555" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="IC3" gate="A" x="-55.88" y="-30.48" smashed="yes">
<attribute name="NAME" x="-63.5" y="-19.558" size="1.778" layer="95"/>
<attribute name="VALUE" x="-63.5" y="-43.307" size="1.778" layer="96"/>
</instance>
<instance part="R11" gate="G$1" x="-101.6" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="-101.6" y="2.3114" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-102.87" y="-5.588" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R12" gate="G$1" x="-96.52" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="-96.52" y="2.3114" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-95.25" y="-8.128" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R13" gate="G$1" x="-91.44" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="-91.44" y="2.3114" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-88.9" y="-8.128" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R14" gate="G$1" x="-86.36" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="-86.36" y="2.3114" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-83.82" y="-8.128" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R15" gate="G$1" x="-101.6" y="-15.24" smashed="yes" rot="R90">
<attribute name="NAME" x="-102.87" y="-12.9286" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-102.87" y="-15.748" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T10" gate="G$1" x="-97.79" y="-21.59" smashed="yes">
<attribute name="VALUE" x="-93.98" y="-20.32" size="1.778" layer="96"/>
<attribute name="NAME" x="-93.98" y="-17.78" size="1.778" layer="95"/>
</instance>
<instance part="D13" gate="G$1" x="-101.6" y="-29.21" smashed="yes" rot="R90">
<attribute name="NAME" x="-102.362" y="-26.035" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-102.362" y="-30.861" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D14" gate="G$1" x="-90.17" y="-30.48" smashed="yes" rot="R90">
<attribute name="NAME" x="-88.392" y="-24.765" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-85.852" y="-43.561" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C22" gate="G$1" x="-95.25" y="-30.48" smashed="yes">
<attribute name="NAME" x="-95.377" y="-35.0774" size="1.778" layer="95"/>
<attribute name="VALUE" x="-101.727" y="-42.6974" size="1.778" layer="96"/>
</instance>
<instance part="C23" gate="G$1" x="-85.09" y="-30.48" smashed="yes">
<attribute name="NAME" x="-83.566" y="-30.099" size="1.778" layer="95"/>
<attribute name="VALUE" x="-83.566" y="-35.179" size="1.778" layer="96"/>
</instance>
<instance part="GND7" gate="1" x="-101.6" y="-34.29" smashed="yes">
<attribute name="VALUE" x="-103.505" y="-36.83" size="1.778" layer="96"/>
</instance>
<instance part="GND8" gate="1" x="-95.25" y="-38.1" smashed="yes">
<attribute name="VALUE" x="-97.155" y="-40.64" size="1.778" layer="96"/>
</instance>
<instance part="GND9" gate="1" x="-90.17" y="-38.1" smashed="yes">
<attribute name="VALUE" x="-92.075" y="-40.64" size="1.778" layer="96"/>
</instance>
<instance part="GND10" gate="1" x="-85.09" y="-38.1" smashed="yes">
<attribute name="VALUE" x="-86.995" y="-40.64" size="1.778" layer="96"/>
</instance>
<instance part="C27" gate="G$1" x="-74.93" y="-35.56" smashed="yes">
<attribute name="NAME" x="-73.406" y="-35.179" size="1.778" layer="95"/>
<attribute name="VALUE" x="-73.406" y="-40.259" size="1.778" layer="96"/>
</instance>
<instance part="D16" gate="G$1" x="-68.58" y="-8.89" smashed="yes" rot="R270">
<attribute name="NAME" x="-74.93" y="-9.6774" size="1.778" layer="95"/>
<attribute name="VALUE" x="-78.74" y="-12.4714" size="1.778" layer="96"/>
</instance>
<instance part="D15" gate="G$1" x="-68.58" y="-3.81" smashed="yes" rot="R270">
<attribute name="NAME" x="-73.66" y="-2.0574" size="1.778" layer="95"/>
<attribute name="VALUE" x="-78.74" y="-4.8514" size="1.778" layer="96"/>
</instance>
<instance part="D17" gate="G$1" x="-62.23" y="-8.89" smashed="yes" rot="R270">
<attribute name="NAME" x="-57.15" y="-5.5626" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-65.8114" y="-5.08" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="T12" gate="G$1" x="-54.61" y="7.62" smashed="yes" rot="R180">
<attribute name="NAME" x="-49.53" y="11.43" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-57.15" y="7.62" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T13" gate="G$1" x="-26.67" y="7.62" smashed="yes" rot="R180">
<attribute name="NAME" x="-24.13" y="12.7" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-21.59" y="15.24" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T16" gate="G$1" x="49.53" y="-17.78" smashed="yes" rot="R90">
<attribute name="NAME" x="50.8" y="-8.89" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="62.23" y="-12.7" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R16" gate="G$1" x="-92.71" y="12.7" smashed="yes">
<attribute name="NAME" x="-96.52" y="14.1986" size="1.778" layer="95"/>
<attribute name="VALUE" x="-96.52" y="9.398" size="1.778" layer="96"/>
</instance>
<instance part="R17" gate="G$1" x="-82.55" y="12.7" smashed="yes">
<attribute name="NAME" x="-86.36" y="14.1986" size="1.778" layer="95"/>
<attribute name="VALUE" x="-86.36" y="9.398" size="1.778" layer="96"/>
</instance>
<instance part="R18" gate="G$1" x="-72.39" y="12.7" smashed="yes">
<attribute name="NAME" x="-76.2" y="14.1986" size="1.778" layer="95"/>
<attribute name="VALUE" x="-76.2" y="9.398" size="1.778" layer="96"/>
</instance>
<instance part="R19" gate="G$1" x="-62.23" y="12.7" smashed="yes">
<attribute name="NAME" x="-66.04" y="14.1986" size="1.778" layer="95"/>
<attribute name="VALUE" x="-66.04" y="9.398" size="1.778" layer="96"/>
</instance>
<instance part="D22" gate="G$1" x="-11.43" y="31.75" smashed="yes" rot="R90">
<attribute name="NAME" x="-12.7" y="35.0774" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-10.16" y="37.8714" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D23" gate="G$1" x="-5.08" y="34.29" smashed="yes">
<attribute name="NAME" x="-6.35" y="38.5826" size="1.778" layer="95"/>
<attribute name="VALUE" x="-6.35" y="35.7886" size="1.778" layer="96"/>
</instance>
<instance part="D24" gate="G$1" x="5.08" y="29.21" smashed="yes" rot="R180">
<attribute name="NAME" x="7.62" y="32.5374" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="12.7" y="27.7114" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C25" gate="G$1" x="-36.83" y="-40.64" smashed="yes">
<attribute name="NAME" x="-35.306" y="-40.259" size="1.778" layer="95"/>
<attribute name="VALUE" x="-35.306" y="-45.339" size="1.778" layer="96"/>
</instance>
<instance part="GND11" gate="1" x="-36.83" y="-48.26" smashed="yes">
<attribute name="VALUE" x="-38.735" y="-50.8" size="1.778" layer="96"/>
</instance>
<instance part="RS1" gate="G$1" x="-39.37" y="2.54" smashed="yes">
<attribute name="NAME" x="-43.18" y="4.0386" size="1.778" layer="95"/>
<attribute name="VALUE" x="-43.18" y="-0.762" size="1.778" layer="96"/>
</instance>
<instance part="RS2" gate="G$1" x="-39.37" y="-1.27" smashed="yes">
<attribute name="NAME" x="-44.45" y="-4.8514" size="1.778" layer="95"/>
<attribute name="VALUE" x="-38.1" y="-4.572" size="1.778" layer="96"/>
</instance>
<instance part="R20" gate="G$1" x="-49.53" y="-10.16" smashed="yes" rot="R90">
<attribute name="NAME" x="-43.18" y="-7.8486" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-44.45" y="-10.668" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R24" gate="G$1" x="-29.21" y="-33.02" smashed="yes" rot="R90">
<attribute name="NAME" x="-22.86" y="-30.7086" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-24.13" y="-33.528" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C24" gate="G$1" x="-29.21" y="-40.64" smashed="yes">
<attribute name="NAME" x="-27.686" y="-40.259" size="1.778" layer="95"/>
<attribute name="VALUE" x="-27.686" y="-45.339" size="1.778" layer="96"/>
</instance>
<instance part="D19" gate="G$1" x="-26.67" y="-19.05" smashed="yes">
<attribute name="NAME" x="-25.908" y="-17.0434" size="1.778" layer="95"/>
<attribute name="VALUE" x="-31.496" y="-22.5044" size="1.778" layer="96"/>
</instance>
<instance part="GND12" gate="1" x="-29.21" y="-48.26" smashed="yes">
<attribute name="VALUE" x="-31.115" y="-50.8" size="1.778" layer="96"/>
</instance>
<instance part="D18" gate="G$1" x="-60.96" y="-53.34" smashed="yes" rot="R90">
<attribute name="NAME" x="-61.214" y="-48.895" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-58.674" y="-63.881" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C26" gate="G$1" x="-55.88" y="-54.61" smashed="yes">
<attribute name="NAME" x="-58.166" y="-51.689" size="1.778" layer="95"/>
<attribute name="VALUE" x="-55.626" y="-59.309" size="1.778" layer="96"/>
</instance>
<instance part="R26" gate="G$1" x="-49.53" y="-52.07" smashed="yes" rot="R180">
<attribute name="NAME" x="-48.26" y="-48.4886" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-48.26" y="-53.848" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R25" gate="G$1" x="-41.91" y="-45.72" smashed="yes" rot="R90">
<attribute name="NAME" x="-43.18" y="-45.9486" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-38.1" y="-44.958" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="T11" gate="G$1" x="-39.37" y="-57.15" smashed="yes" rot="R270">
<attribute name="VALUE" x="-43.18" y="-66.04" size="1.778" layer="96"/>
<attribute name="NAME" x="-40.64" y="-54.61" size="1.778" layer="95"/>
</instance>
<instance part="D20" gate="G$1" x="-44.45" y="7.62" smashed="yes" rot="R180">
<attribute name="NAME" x="-48.006" y="9.525" size="1.778" layer="95"/>
<attribute name="VALUE" x="-41.656" y="9.271" size="1.778" layer="96"/>
</instance>
<instance part="D21" gate="G$1" x="-16.51" y="5.08" smashed="yes" rot="R270">
<attribute name="NAME" x="-22.86" y="3.0226" size="1.778" layer="95"/>
<attribute name="VALUE" x="-25.4" y="-1.0414" size="1.778" layer="96"/>
</instance>
<instance part="R21" gate="G$1" x="-16.51" y="20.32" smashed="yes" rot="R90">
<attribute name="NAME" x="-10.16" y="21.3614" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-11.43" y="18.542" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R22" gate="G$1" x="-6.35" y="7.62" smashed="yes" rot="R90">
<attribute name="NAME" x="-7.62" y="9.9314" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-7.62" y="7.112" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C28" gate="G$1" x="-2.54" y="-5.08" smashed="yes">
<attribute name="NAME" x="-1.016" y="-4.699" size="1.778" layer="95"/>
<attribute name="VALUE" x="-1.016" y="-9.779" size="1.778" layer="96"/>
</instance>
<instance part="GND13" gate="1" x="2.54" y="11.43" smashed="yes">
<attribute name="VALUE" x="0.635" y="8.89" size="1.778" layer="96"/>
</instance>
<instance part="C29" gate="G$1" x="-15.24" y="-34.29" smashed="yes">
<attribute name="NAME" x="-14.097" y="-33.8074" size="1.778" layer="95"/>
<attribute name="VALUE" x="-20.447" y="-42.6974" size="1.778" layer="96"/>
</instance>
<instance part="C30" gate="G$1" x="-6.35" y="-34.29" smashed="yes">
<attribute name="NAME" x="-5.207" y="-33.8074" size="1.778" layer="95"/>
<attribute name="VALUE" x="-12.827" y="-45.2374" size="1.778" layer="96"/>
</instance>
<instance part="C31" gate="G$1" x="1.27" y="-34.29" smashed="yes">
<attribute name="NAME" x="2.794" y="-33.909" size="1.778" layer="95"/>
<attribute name="VALUE" x="-2.286" y="-42.799" size="1.778" layer="96"/>
</instance>
<instance part="C33" gate="G$1" x="8.89" y="-46.99" smashed="yes">
<attribute name="NAME" x="4.064" y="-51.689" size="1.778" layer="95"/>
<attribute name="VALUE" x="10.414" y="-51.689" size="1.778" layer="96"/>
</instance>
<instance part="H1" gate="G$1" x="16.51" y="-43.18" smashed="yes"/>
<instance part="T15" gate="G$1" x="36.83" y="-2.54" smashed="yes" rot="R90">
<attribute name="VALUE" x="40.64" y="6.35" size="1.778" layer="96" rot="R180"/>
<attribute name="NAME" x="38.1" y="8.89" size="1.778" layer="95" rot="R180"/>
</instance>
<instance part="R27" gate="G$1" x="15.24" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="13.97" y="-0.2286" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="12.7" y="-3.048" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D25" gate="G$1" x="22.86" y="-2.54" smashed="yes" rot="R90">
<attribute name="NAME" x="29.21" y="-1.7526" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="30.48" y="-5.3086" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R64" gate="G$1" x="39.37" y="-20.32" smashed="yes" rot="R90">
<attribute name="NAME" x="37.8714" y="-24.13" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="42.672" y="-24.13" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R65" gate="G$1" x="49.53" y="-27.94" smashed="yes" rot="R90">
<attribute name="NAME" x="48.26" y="-25.6286" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="46.99" y="-28.448" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R69" gate="G$1" x="57.15" y="-20.32" smashed="yes" rot="R90">
<attribute name="NAME" x="55.6514" y="-24.13" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="60.452" y="-24.13" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R68" gate="G$1" x="57.15" y="-29.21" smashed="yes">
<attribute name="NAME" x="53.34" y="-27.7114" size="1.778" layer="95"/>
<attribute name="VALUE" x="53.34" y="-32.512" size="1.778" layer="96"/>
</instance>
<instance part="R67" gate="G$1" x="57.15" y="-33.02" smashed="yes">
<attribute name="NAME" x="53.34" y="-31.5214" size="1.778" layer="95"/>
<attribute name="VALUE" x="53.34" y="-36.322" size="1.778" layer="96"/>
</instance>
<instance part="R66" gate="G$1" x="57.15" y="-39.37" smashed="yes">
<attribute name="NAME" x="53.34" y="-37.8714" size="1.778" layer="95"/>
<attribute name="VALUE" x="53.34" y="-42.672" size="1.778" layer="96"/>
</instance>
<instance part="D28" gate="G$1" x="34.29" y="-25.4" smashed="yes" rot="R180">
<attribute name="NAME" x="34.29" y="-19.5326" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="34.29" y="-21.8186" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D29" gate="G$1" x="34.29" y="-34.29" smashed="yes" rot="R180">
<attribute name="NAME" x="34.29" y="-30.9626" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="34.29" y="-35.7886" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R61" gate="G$1" x="34.29" y="-29.21" smashed="yes" rot="R180">
<attribute name="NAME" x="29.21" y="-27.7114" size="1.778" layer="95"/>
<attribute name="VALUE" x="35.56" y="-32.512" size="1.778" layer="96"/>
</instance>
<instance part="R62" gate="G$1" x="34.29" y="-38.1" smashed="yes" rot="R180">
<attribute name="NAME" x="31.75" y="-41.6814" size="1.778" layer="95"/>
<attribute name="VALUE" x="36.83" y="-41.402" size="1.778" layer="96"/>
</instance>
<instance part="C41" gate="G$1" x="38.1" y="-43.18" smashed="yes" rot="R90">
<attribute name="NAME" x="37.719" y="-41.656" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="42.799" y="-41.656" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C39" gate="G$1" x="38.1" y="-63.5" smashed="yes" rot="R90">
<attribute name="NAME" x="37.719" y="-61.976" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="42.799" y="-61.976" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R72" gate="G$1" x="54.61" y="-90.17" smashed="yes">
<attribute name="NAME" x="52.07" y="-88.6714" size="1.778" layer="95"/>
<attribute name="VALUE" x="54.61" y="-93.472" size="1.778" layer="96"/>
</instance>
<instance part="R51" gate="G$1" x="76.2" y="-68.58" smashed="yes" rot="R180">
<attribute name="NAME" x="72.39" y="-67.0814" size="1.778" layer="95"/>
<attribute name="VALUE" x="74.93" y="-71.882" size="1.778" layer="96"/>
</instance>
<instance part="R59" gate="G$1" x="55.88" y="-57.15" smashed="yes" rot="R180">
<attribute name="NAME" x="53.34" y="-55.6514" size="1.778" layer="95"/>
<attribute name="VALUE" x="54.61" y="-60.452" size="1.778" layer="96"/>
</instance>
<instance part="R52" gate="G$1" x="55.88" y="-63.5" smashed="yes" rot="R180">
<attribute name="NAME" x="53.34" y="-62.0014" size="1.778" layer="95"/>
<attribute name="VALUE" x="57.15" y="-66.802" size="1.778" layer="96"/>
</instance>
<instance part="R60" gate="G$1" x="76.2" y="-57.15" smashed="yes" rot="R180">
<attribute name="NAME" x="73.66" y="-55.6514" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-60.452" size="1.778" layer="96"/>
</instance>
<instance part="P3" gate="G$1" x="66.04" y="-57.15" smashed="yes" rot="R90">
<attribute name="NAME" x="62.23" y="-56.261" size="1.778" layer="95"/>
<attribute name="VALUE" x="66.04" y="-55.88" size="1.778" layer="96"/>
</instance>
<instance part="P4" gate="G$1" x="66.04" y="-63.5" smashed="yes" rot="MR270">
<attribute name="NAME" x="66.04" y="-64.389" size="1.778" layer="95" rot="MR180"/>
<attribute name="VALUE" x="62.23" y="-64.77" size="1.778" layer="96" rot="MR180"/>
</instance>
<instance part="P+7" gate="1" x="48.26" y="-57.15" smashed="yes">
<attribute name="VALUE" x="49.53" y="-54.61" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P-5" gate="1" x="83.82" y="-63.5" smashed="yes">
<attribute name="VALUE" x="85.09" y="-64.77" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY20" gate="G$1" x="81.28" y="-71.12" smashed="yes">
<attribute name="VALUE" x="78.613" y="-74.295" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY21" gate="G$1" x="62.23" y="-80.01" smashed="yes">
<attribute name="VALUE" x="59.563" y="-83.185" size="1.778" layer="96"/>
</instance>
<instance part="GND14" gate="1" x="57.15" y="-3.81" smashed="yes">
<attribute name="VALUE" x="55.245" y="-6.35" size="1.778" layer="96"/>
</instance>
<instance part="GND15" gate="1" x="81.28" y="0" smashed="yes">
<attribute name="VALUE" x="85.09" y="-1.27" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C42" gate="G$1" x="81.28" y="-26.67" smashed="yes">
<attribute name="NAME" x="82.804" y="-26.289" size="1.778" layer="95"/>
<attribute name="VALUE" x="81.534" y="-31.369" size="1.778" layer="96"/>
</instance>
<instance part="C43" gate="G$1" x="88.9" y="-26.67" smashed="yes">
<attribute name="NAME" x="90.424" y="-26.289" size="1.778" layer="95"/>
<attribute name="VALUE" x="89.154" y="-31.369" size="1.778" layer="96"/>
</instance>
<instance part="GND16" gate="1" x="88.9" y="-34.29" smashed="yes">
<attribute name="VALUE" x="92.71" y="-35.56" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY22" gate="G$1" x="81.28" y="-34.29" smashed="yes">
<attribute name="VALUE" x="78.613" y="-37.465" size="1.778" layer="96"/>
</instance>
<instance part="D30" gate="G$1" x="92.71" y="-66.04" smashed="yes" rot="R90">
<attribute name="NAME" x="87.884" y="-64.135" size="1.778" layer="95"/>
<attribute name="VALUE" x="89.154" y="-70.739" size="1.778" layer="96"/>
</instance>
<instance part="R54" gate="G$1" x="100.33" y="-46.99" smashed="yes" rot="R270">
<attribute name="NAME" x="98.8314" y="-49.53" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="103.632" y="-48.26" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R56" gate="G$1" x="100.33" y="-59.69" smashed="yes" rot="R270">
<attribute name="NAME" x="99.06" y="-56.1086" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="99.06" y="-58.928" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R48" gate="G$1" x="125.73" y="-58.42" smashed="yes" rot="R270">
<attribute name="NAME" x="128.27" y="-51.0286" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="130.81" y="-55.118" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R47" gate="G$1" x="133.35" y="-58.42" smashed="yes" rot="R270">
<attribute name="NAME" x="139.7" y="-56.1086" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="139.7" y="-58.928" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R46" gate="G$1" x="133.35" y="-48.26" smashed="yes" rot="R270">
<attribute name="NAME" x="131.8514" y="-50.8" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="136.652" y="-49.53" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C40" gate="G$1" x="100.33" y="-67.31" smashed="yes">
<attribute name="NAME" x="101.854" y="-66.929" size="1.778" layer="95"/>
<attribute name="VALUE" x="100.584" y="-72.009" size="1.778" layer="96"/>
</instance>
<instance part="C38" gate="G$1" x="125.73" y="-72.39" smashed="yes">
<attribute name="NAME" x="120.904" y="-72.009" size="1.778" layer="95"/>
<attribute name="VALUE" x="118.364" y="-77.089" size="1.778" layer="96"/>
</instance>
<instance part="GND17" gate="1" x="107.95" y="-67.31" smashed="yes">
<attribute name="VALUE" x="111.76" y="-68.58" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C44" gate="G$1" x="121.92" y="6.35" smashed="yes">
<attribute name="NAME" x="123.444" y="6.731" size="1.778" layer="95"/>
<attribute name="VALUE" x="118.364" y="-2.159" size="1.778" layer="96"/>
</instance>
<instance part="C45" gate="G$1" x="134.62" y="6.35" smashed="yes">
<attribute name="NAME" x="136.144" y="6.731" size="1.778" layer="95"/>
<attribute name="VALUE" x="131.064" y="-2.159" size="1.778" layer="96"/>
</instance>
<instance part="C45/2" gate="G$1" x="147.32" y="6.35" smashed="yes">
<attribute name="NAME" x="147.574" y="6.731" size="1.778" layer="95"/>
<attribute name="VALUE" x="143.764" y="-2.159" size="1.778" layer="96"/>
</instance>
<instance part="C46" gate="G$1" x="156.21" y="6.35" smashed="yes">
<attribute name="NAME" x="157.734" y="6.731" size="1.778" layer="95"/>
<attribute name="VALUE" x="157.734" y="1.651" size="1.778" layer="96"/>
</instance>
<instance part="CS4" gate="G$1" x="177.8" y="-83.82" smashed="yes">
<attribute name="NAME" x="171.45" y="-80.645" size="1.778" layer="95"/>
<attribute name="VALUE" x="171.45" y="-88.9" size="1.778" layer="96"/>
</instance>
<instance part="CS3" gate="G$1" x="181.61" y="8.89" smashed="yes">
<attribute name="NAME" x="175.26" y="12.065" size="1.778" layer="95"/>
<attribute name="VALUE" x="175.26" y="3.81" size="1.778" layer="96"/>
</instance>
<instance part="R23" gate="G$1" x="2.54" y="19.05" smashed="yes" rot="R90">
<attribute name="NAME" x="8.89" y="21.3614" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="7.62" y="18.542" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R70" gate="G$1" x="57.15" y="3.81" smashed="yes" rot="R90">
<attribute name="NAME" x="55.6514" y="0" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="60.452" y="0" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C32" gate="G$1" x="8.89" y="-34.29" smashed="yes">
<attribute name="NAME" x="10.414" y="-33.909" size="1.778" layer="95"/>
<attribute name="VALUE" x="10.414" y="-37.719" size="1.778" layer="96"/>
</instance>
<instance part="D27" gate="G$1" x="57.15" y="-77.47" smashed="yes">
<attribute name="NAME" x="55.372" y="-75.565" size="1.778" layer="95"/>
<attribute name="VALUE" x="55.372" y="-80.899" size="1.778" layer="96"/>
</instance>
<instance part="D26" gate="G$1" x="52.07" y="-77.47" smashed="yes" rot="R180">
<attribute name="NAME" x="53.848" y="-74.295" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="53.848" y="-79.121" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R53" gate="G$1" x="76.2" y="-63.5" smashed="yes" rot="R180">
<attribute name="NAME" x="73.66" y="-62.0014" size="1.778" layer="95"/>
<attribute name="VALUE" x="77.47" y="-66.802" size="1.778" layer="96"/>
</instance>
<instance part="R49" gate="G$1" x="118.11" y="-58.42" smashed="yes" rot="R90">
<attribute name="NAME" x="118.11" y="-53.5686" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="116.84" y="-56.388" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R75" gate="G$1" x="166.37" y="-11.43" smashed="yes" rot="R90">
<attribute name="NAME" x="164.8714" y="-15.24" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="169.672" y="-15.24" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="SUPPLY19" gate="G$1" x="-109.22" y="27.94" smashed="yes" rot="R180">
<attribute name="VALUE" x="-106.553" y="31.115" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C37" gate="G$1" x="55.88" y="85.09" smashed="yes">
<attribute name="NAME" x="57.404" y="85.471" size="1.778" layer="95"/>
<attribute name="VALUE" x="57.404" y="80.391" size="1.778" layer="96"/>
</instance>
<instance part="GND1" gate="1" x="55.88" y="77.47" smashed="yes">
<attribute name="VALUE" x="59.69" y="76.2" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P2" gate="G$1" x="133.35" y="-69.85" smashed="yes">
<attribute name="NAME" x="139.7" y="-70.739" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="138.43" y="-73.66" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P1" gate="G$1" x="100.33" y="-35.56" smashed="yes">
<attribute name="NAME" x="105.41" y="-36.449" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="105.41" y="-39.37" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC9" gate="A" x="77.47" y="33.02" smashed="yes">
<attribute name="NAME" x="78.74" y="36.195" size="1.778" layer="95"/>
<attribute name="VALUE" x="80.01" y="27.94" size="1.778" layer="96"/>
</instance>
<instance part="P-6" gate="1" x="74.93" y="22.86" smashed="yes">
<attribute name="VALUE" x="76.2" y="21.59" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+10" gate="1" x="74.93" y="43.18" smashed="yes">
<attribute name="VALUE" x="76.2" y="45.72" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P5" gate="G$1" x="85.09" y="41.91" smashed="yes">
<attribute name="NAME" x="91.44" y="46.101" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="91.44" y="39.37" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+11" gate="1" x="92.71" y="41.91" smashed="yes" rot="R270">
<attribute name="VALUE" x="96.52" y="44.45" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P6" gate="G$1" x="93.98" y="25.4" smashed="yes">
<attribute name="NAME" x="97.79" y="24.511" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="97.79" y="21.59" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R38" gate="G$1" x="97.79" y="38.1" smashed="yes" rot="R90">
<attribute name="NAME" x="102.87" y="42.9514" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="101.6" y="38.862" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D3" gate="G$1" x="-128.27" y="109.22" smashed="yes">
<attribute name="NAME" x="-130.81" y="110.9726" size="1.778" layer="95"/>
<attribute name="VALUE" x="-134.62" y="104.3686" size="1.778" layer="96"/>
</instance>
<instance part="C1" gate="G$1" x="-130.81" y="120.65" smashed="yes" rot="R90">
<attribute name="NAME" x="-128.524" y="125.349" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-127.254" y="117.729" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY12" gate="G$1" x="-135.89" y="109.22" smashed="yes" rot="R270">
<attribute name="VALUE" x="-139.065" y="111.887" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="SUPPLY14" gate="G$1" x="-135.89" y="120.65" smashed="yes" rot="R270">
<attribute name="VALUE" x="-139.065" y="123.317" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C16" gate="G$1" x="88.9" y="11.43" smashed="yes" rot="R90">
<attribute name="NAME" x="96.266" y="13.589" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="93.726" y="8.509" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC10" gate="A" x="143.51" y="57.15" smashed="yes" rot="R90">
<attribute name="NAME" x="140.97" y="60.325" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="148.59" y="59.69" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R39" gate="G$1" x="157.48" y="54.61" smashed="yes" rot="R90">
<attribute name="NAME" x="163.83" y="55.6514" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="163.83" y="52.832" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P8" gate="G$1" x="157.48" y="67.31" smashed="yes" rot="R180">
<attribute name="NAME" x="160.02" y="66.929" size="1.778" layer="95"/>
<attribute name="VALUE" x="161.29" y="64.77" size="1.778" layer="96"/>
</instance>
<instance part="C17" gate="G$1" x="166.37" y="59.69" smashed="yes" rot="R180">
<attribute name="NAME" x="167.894" y="62.611" size="1.778" layer="95"/>
<attribute name="VALUE" x="167.894" y="57.531" size="1.778" layer="96"/>
</instance>
<instance part="R41" gate="G$1" x="140.97" y="43.18" smashed="yes" rot="R90">
<attribute name="NAME" x="139.7" y="45.4914" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="139.7" y="42.672" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R42" gate="G$1" x="143.51" y="77.47" smashed="yes" rot="R90">
<attribute name="NAME" x="149.86" y="79.7814" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="148.59" y="76.962" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D4" gate="G$1" x="-130.81" y="140.97" smashed="yes">
<attribute name="NAME" x="-132.08" y="145.2626" size="1.778" layer="95"/>
<attribute name="VALUE" x="-134.62" y="142.4686" size="1.778" layer="96"/>
</instance>
<instance part="C18" gate="G$1" x="-130.81" y="133.35" smashed="yes" rot="R90">
<attribute name="NAME" x="-128.524" y="138.049" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-127.254" y="130.429" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P7" gate="G$1" x="132.08" y="64.77" smashed="yes" rot="R90">
<attribute name="NAME" x="135.89" y="68.961" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="133.35" y="60.96" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY15" gate="G$1" x="140.97" y="35.56" smashed="yes">
<attribute name="VALUE" x="138.303" y="32.385" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY16" gate="G$1" x="-135.89" y="140.97" smashed="yes" rot="R270">
<attribute name="VALUE" x="-139.065" y="143.637" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="P+14" gate="1" x="132.08" y="72.39" smashed="yes">
<attribute name="VALUE" x="133.35" y="74.93" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY17" gate="G$1" x="-135.89" y="133.35" smashed="yes" rot="R270">
<attribute name="VALUE" x="-139.065" y="136.017" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="TP1" gate="G$1" x="93.98" y="116.84" smashed="yes" rot="R90">
<attribute name="NAME" x="90.805" y="110.49" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="97.79" y="120.65" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="TP2" gate="G$1" x="93.98" y="93.98" smashed="yes" rot="R90">
<attribute name="NAME" x="90.805" y="87.63" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="99.06" y="97.79" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="IC7" gate="G$1" x="8.89" y="116.84" smashed="yes">
<attribute name="NAME" x="1.27" y="128.27" size="1.778" layer="95"/>
<attribute name="VALUE" x="1.27" y="104.14" size="1.778" layer="96"/>
</instance>
<instance part="IC8" gate="G$1" x="8.89" y="74.93" smashed="yes">
<attribute name="NAME" x="1.27" y="93.98" size="1.778" layer="95"/>
<attribute name="VALUE" x="1.27" y="54.61" size="1.778" layer="96"/>
</instance>
<instance part="P+2" gate="1" x="-19.05" y="132.08" smashed="yes">
<attribute name="VALUE" x="-17.78" y="134.62" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C2" gate="G$1" x="-19.05" y="121.92" smashed="yes">
<attribute name="NAME" x="-17.526" y="122.301" size="1.778" layer="95"/>
<attribute name="VALUE" x="-17.526" y="117.221" size="1.778" layer="96"/>
</instance>
<instance part="C3" gate="G$1" x="-13.97" y="121.92" smashed="yes">
<attribute name="NAME" x="-12.446" y="122.301" size="1.778" layer="95"/>
<attribute name="VALUE" x="-12.446" y="117.221" size="1.778" layer="96"/>
</instance>
<instance part="R1" gate="G$1" x="30.48" y="129.54" smashed="yes" rot="R90">
<attribute name="NAME" x="28.9814" y="125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="33.782" y="125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R2" gate="G$1" x="38.1" y="129.54" smashed="yes" rot="R90">
<attribute name="NAME" x="36.6014" y="125.73" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="41.402" y="125.73" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C5" gate="G$1" x="38.1" y="139.7" smashed="yes">
<attribute name="NAME" x="39.624" y="140.081" size="1.778" layer="95"/>
<attribute name="VALUE" x="39.624" y="135.001" size="1.778" layer="96"/>
</instance>
<instance part="P+3" gate="1" x="-21.59" y="102.87" smashed="yes">
<attribute name="VALUE" x="-20.32" y="105.41" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C6" gate="G$1" x="-13.97" y="92.71" smashed="yes">
<attribute name="NAME" x="-12.446" y="93.091" size="1.778" layer="95"/>
<attribute name="VALUE" x="-12.446" y="88.011" size="1.778" layer="96"/>
</instance>
<instance part="C7" gate="G$1" x="-21.59" y="92.71" smashed="yes">
<attribute name="NAME" x="-20.447" y="93.1926" size="1.778" layer="95"/>
<attribute name="VALUE" x="-20.447" y="88.1126" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY23" gate="G$1" x="-6.35" y="106.68" smashed="yes">
<attribute name="VALUE" x="-9.017" y="103.505" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY24" gate="G$1" x="24.13" y="106.68" smashed="yes">
<attribute name="VALUE" x="21.463" y="103.505" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY25" gate="G$1" x="26.67" y="80.01" smashed="yes" rot="R90">
<attribute name="VALUE" x="29.845" y="77.343" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="SUPPLY26" gate="G$1" x="-13.97" y="85.09" smashed="yes">
<attribute name="VALUE" x="-16.637" y="81.915" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY27" gate="G$1" x="-21.59" y="85.09" smashed="yes">
<attribute name="VALUE" x="-24.257" y="81.915" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY31" gate="G$1" x="-19.05" y="114.3" smashed="yes">
<attribute name="VALUE" x="-21.717" y="111.125" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY32" gate="G$1" x="44.45" y="123.19" smashed="yes" rot="R180">
<attribute name="VALUE" x="47.117" y="126.365" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY33" gate="G$1" x="44.45" y="57.15" smashed="yes">
<attribute name="VALUE" x="41.783" y="53.975" size="1.778" layer="96"/>
</instance>
<instance part="P+8" gate="1" x="27.94" y="64.77" smashed="yes" rot="R270">
<attribute name="VALUE" x="30.48" y="63.5" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="SUPPLY34" gate="G$1" x="24.13" y="54.61" smashed="yes">
<attribute name="VALUE" x="21.463" y="51.435" size="1.778" layer="96"/>
</instance>
<instance part="IC11" gate="G$1" x="-81.28" y="97.79" smashed="yes">
<attribute name="NAME" x="-93.98" y="134.62" size="1.778" layer="95"/>
<attribute name="VALUE" x="-93.98" y="59.69" size="1.778" layer="96"/>
</instance>
<instance part="P+9" gate="1" x="-55.88" y="92.71" smashed="yes">
<attribute name="VALUE" x="-54.61" y="95.25" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C9" gate="G$1" x="-55.88" y="87.63" smashed="yes">
<attribute name="NAME" x="-55.626" y="88.011" size="1.778" layer="95"/>
<attribute name="VALUE" x="-55.626" y="82.931" size="1.778" layer="96"/>
</instance>
<instance part="GND2" gate="1" x="-55.88" y="80.01" smashed="yes">
<attribute name="VALUE" x="-58.42" y="77.47" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY30" gate="G$1" x="-13.97" y="114.3" smashed="yes">
<attribute name="VALUE" x="-16.637" y="111.125" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY35" gate="G$1" x="38.1" y="144.78" smashed="yes" rot="R180">
<attribute name="VALUE" x="40.767" y="147.955" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY36" gate="G$1" x="30.48" y="137.16" smashed="yes" rot="R180">
<attribute name="VALUE" x="33.147" y="140.335" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND3" gate="1" x="-109.22" y="12.7" smashed="yes">
<attribute name="VALUE" x="-111.76" y="10.16" size="1.778" layer="96"/>
</instance>
<instance part="GND4" gate="1" x="-85.09" y="-38.1" smashed="yes">
</instance>
<instance part="GND5" gate="1" x="-60.96" y="85.09" smashed="yes" rot="R90">
<attribute name="VALUE" x="-58.42" y="82.55" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="GND18" gate="1" x="-101.6" y="95.25" smashed="yes" rot="R270">
<attribute name="VALUE" x="-104.14" y="97.79" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C19" gate="G$1" x="-107.95" y="85.09" smashed="yes" rot="R270">
<attribute name="NAME" x="-111.506" y="80.391" size="1.778" layer="95"/>
<attribute name="VALUE" x="-111.506" y="77.851" size="1.778" layer="96"/>
</instance>
<instance part="C34" gate="G$1" x="-107.95" y="90.17" smashed="yes" rot="R270">
<attribute name="NAME" x="-111.506" y="95.631" size="1.778" layer="95"/>
<attribute name="VALUE" x="-111.506" y="93.091" size="1.778" layer="96"/>
</instance>
<instance part="HMI" gate="A" x="-49.53" y="57.15" smashed="yes" rot="R270">
<attribute name="NAME" x="-41.275" y="63.5" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="-57.15" y="63.5" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND19" gate="1" x="-46.99" y="67.31" smashed="yes" rot="R180">
<attribute name="VALUE" x="-44.45" y="69.85" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C36" gate="G$1" x="-110.49" y="110.49" smashed="yes" rot="R90">
<attribute name="NAME" x="-106.934" y="106.299" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-106.934" y="115.189" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY28" gate="G$1" x="-115.57" y="110.49" smashed="yes" rot="R270">
<attribute name="VALUE" x="-118.745" y="113.157" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="SUPPLY37" gate="G$1" x="-101.6" y="115.57" smashed="yes" rot="R270">
<attribute name="VALUE" x="-104.775" y="118.237" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="C47" gate="G$1" x="35.56" y="95.25" smashed="yes" rot="R270">
<attribute name="NAME" x="35.941" y="93.726" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="30.861" y="93.726" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="SUPPLY38" gate="G$1" x="27.94" y="95.25" smashed="yes" rot="R270">
<attribute name="VALUE" x="24.765" y="97.917" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND20" gate="1" x="-115.57" y="90.17" smashed="yes" rot="R270">
<attribute name="VALUE" x="-118.11" y="92.71" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND21" gate="1" x="-115.57" y="85.09" smashed="yes" rot="R270">
<attribute name="VALUE" x="-118.11" y="87.63" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="Q1" gate="G$1" x="-102.87" y="87.63" smashed="yes" rot="R90">
<attribute name="NAME" x="-97.79" y="89.154" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-97.79" y="83.82" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="ICSP" gate="A" x="-80.01" y="146.05" smashed="yes" rot="R90">
<attribute name="NAME" x="-88.265" y="139.7" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="-69.85" y="139.7" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="P+15" gate="1" x="-86.36" y="135.89" smashed="yes" rot="R90">
<attribute name="VALUE" x="-88.9" y="137.16" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="GND22" gate="1" x="-80.01" y="135.89" smashed="yes">
<attribute name="VALUE" x="-82.55" y="133.35" size="1.778" layer="96"/>
</instance>
<instance part="ENCODER" gate="A" x="-31.75" y="100.33" smashed="yes">
<attribute name="NAME" x="-38.1" y="108.585" size="1.778" layer="95"/>
<attribute name="VALUE" x="-38.1" y="92.71" size="1.778" layer="96"/>
</instance>
<instance part="GND23" gate="1" x="-41.91" y="105.41" smashed="yes" rot="R270">
<attribute name="VALUE" x="-44.45" y="109.22" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="P+17" gate="1" x="-50.8" y="118.11" smashed="yes">
<attribute name="VALUE" x="-49.53" y="120.65" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="TP3" gate="G$1" x="-16.51" y="140.97" smashed="yes" rot="R270">
<attribute name="NAME" x="-13.335" y="147.32" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="-21.59" y="147.32" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="TP4" gate="G$1" x="93.98" y="139.7" smashed="yes" rot="R270">
<attribute name="NAME" x="97.155" y="146.05" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="88.9" y="146.05" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="TP5" gate="G$1" x="93.98" y="58.42" smashed="yes" rot="R90">
<attribute name="NAME" x="90.805" y="52.07" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="99.06" y="52.07" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="C48" gate="G$1" x="-41.91" y="92.71" smashed="yes">
<attribute name="NAME" x="-40.386" y="93.091" size="1.778" layer="95"/>
<attribute name="VALUE" x="-40.386" y="88.011" size="1.778" layer="96"/>
</instance>
<instance part="C49" gate="G$1" x="-46.99" y="92.71" smashed="yes">
<attribute name="NAME" x="-45.466" y="93.091" size="1.778" layer="95"/>
<attribute name="VALUE" x="-45.466" y="88.011" size="1.778" layer="96"/>
</instance>
<instance part="C50" gate="G$1" x="-52.07" y="92.71" smashed="yes">
<attribute name="NAME" x="-50.546" y="93.091" size="1.778" layer="95"/>
<attribute name="VALUE" x="-50.546" y="88.011" size="1.778" layer="96"/>
</instance>
<instance part="GND24" gate="1" x="-46.99" y="85.09" smashed="yes">
<attribute name="VALUE" x="-49.53" y="82.55" size="1.778" layer="96"/>
</instance>
<instance part="D1" gate="G$1" x="62.23" y="-90.17" smashed="yes">
<attribute name="NAME" x="63.5" y="-86.8426" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="67.31" y="-91.6686" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="D2" gate="G$1" x="69.85" y="-92.71" smashed="yes" rot="R90">
<attribute name="NAME" x="74.93" y="-91.9226" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="80.01" y="-94.2086" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="SUPPLY13" gate="G$1" x="69.85" y="-97.79" smashed="yes">
<attribute name="VALUE" x="67.183" y="-100.965" size="1.778" layer="96"/>
</instance>
<instance part="C51" gate="G$1" x="-55.88" y="127" smashed="yes" rot="R90">
<attribute name="NAME" x="-52.324" y="131.699" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-49.784" y="124.079" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND25" gate="1" x="-48.26" y="127" smashed="yes" rot="R90">
<attribute name="VALUE" x="-45.72" y="124.46" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="P+12" gate="1" x="-118.11" y="137.16" smashed="yes">
<attribute name="VALUE" x="-116.84" y="139.7" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="C52" gate="G$1" x="-40.64" y="66.04" smashed="yes" rot="R90">
<attribute name="NAME" x="-35.433" y="69.3674" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-34.163" y="63.0174" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND26" gate="1" x="-33.02" y="66.04" smashed="yes" rot="R90">
<attribute name="VALUE" x="-30.48" y="63.5" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="P+16" gate="1" x="-43.18" y="76.2" smashed="yes">
<attribute name="VALUE" x="-41.91" y="78.74" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="P+13" gate="1" x="133.35" y="54.61" smashed="yes" rot="R90">
<attribute name="VALUE" x="130.81" y="50.8" size="1.778" layer="96"/>
</instance>
<instance part="P-7" gate="1" x="153.67" y="54.61" smashed="yes" rot="R90">
<attribute name="VALUE" x="152.4" y="55.88" size="1.778" layer="96"/>
</instance>
<instance part="L1" gate="G$1" x="-16.51" y="-50.8" smashed="yes">
<attribute name="NAME" x="-17.78" y="-50.6984" size="1.778" layer="95"/>
<attribute name="VALUE" x="-20.32" y="-58.801" size="1.778" layer="96"/>
</instance>
<instance part="RS5" gate="G$1" x="72.39" y="8.89" smashed="yes">
<attribute name="NAME" x="68.58" y="10.2616" size="1.778" layer="95"/>
<attribute name="VALUE" x="68.58" y="5.969" size="1.778" layer="96"/>
</instance>
<instance part="SK1" gate="G$1" x="-133.35" y="-27.94" smashed="yes" rot="R180">
<attribute name="NAME" x="-129.54" y="-33.655" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-129.54" y="-22.86" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R9" gate="G$1" x="35.56" y="-11.43" smashed="yes" rot="R270">
<attribute name="NAME" x="37.0586" y="-7.62" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="32.258" y="-7.62" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="R28" gate="G$1" x="62.23" y="-7.62" smashed="yes" rot="R270">
<attribute name="NAME" x="63.7286" y="-3.81" size="1.778" layer="95" rot="R270"/>
<attribute name="VALUE" x="58.928" y="-3.81" size="1.778" layer="96" rot="R270"/>
</instance>
<instance part="JP2" gate="G$1" x="177.8" y="-74.93" smashed="yes">
<attribute name="NAME" x="171.45" y="-71.755" size="1.778" layer="95"/>
<attribute name="VALUE" x="171.45" y="-80.01" size="1.778" layer="96"/>
</instance>
<instance part="JP3" gate="G$1" x="181.61" y="0" smashed="yes">
<attribute name="NAME" x="175.26" y="3.175" size="1.778" layer="95"/>
<attribute name="VALUE" x="175.26" y="-5.08" size="1.778" layer="96"/>
</instance>
<instance part="SUPPLY39" gate="G$1" x="170.18" y="-3.81" smashed="yes">
<attribute name="VALUE" x="167.513" y="-6.985" size="1.778" layer="96"/>
</instance>
<instance part="R35" gate="G$1" x="63.5" y="30.48" smashed="yes">
<attribute name="NAME" x="60.96" y="26.8986" size="1.778" layer="95"/>
<attribute name="VALUE" x="60.96" y="24.638" size="1.778" layer="96"/>
</instance>
<instance part="R36" gate="G$1" x="88.9" y="17.78" smashed="yes">
<attribute name="NAME" x="85.09" y="19.2786" size="1.778" layer="95"/>
<attribute name="VALUE" x="85.09" y="14.478" size="1.778" layer="96"/>
</instance>
<instance part="R50" gate="G$1" x="55.88" y="-68.58" smashed="yes">
<attribute name="NAME" x="52.07" y="-67.0814" size="1.778" layer="95"/>
<attribute name="VALUE" x="52.07" y="-71.882" size="1.778" layer="96"/>
</instance>
<instance part="R34" gate="G$1" x="63.5" y="35.56" smashed="yes">
<attribute name="NAME" x="60.96" y="39.5986" size="1.778" layer="95"/>
<attribute name="VALUE" x="60.96" y="37.338" size="1.778" layer="96"/>
</instance>
<instance part="R58" gate="G$1" x="71.12" y="-48.26" smashed="yes">
<attribute name="NAME" x="67.31" y="-46.7614" size="1.778" layer="95"/>
<attribute name="VALUE" x="67.31" y="-51.562" size="1.778" layer="96"/>
</instance>
<instance part="R57" gate="G$1" x="55.88" y="-48.26" smashed="yes">
<attribute name="NAME" x="52.07" y="-46.7614" size="1.778" layer="95"/>
<attribute name="VALUE" x="52.07" y="-51.562" size="1.778" layer="96"/>
</instance>
<instance part="R55" gate="G$1" x="107.95" y="-59.69" smashed="yes" rot="R90">
<attribute name="NAME" x="114.3" y="-58.6486" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="113.03" y="-61.468" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R5" gate="G$1" x="-113.03" y="130.81" smashed="yes">
<attribute name="NAME" x="-116.84" y="132.3086" size="1.778" layer="95"/>
<attribute name="VALUE" x="-116.84" y="127.508" size="1.778" layer="96"/>
</instance>
<instance part="R6" gate="G$1" x="-55.88" y="110.49" smashed="yes" rot="R90">
<attribute name="NAME" x="-54.61" y="117.8814" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-57.15" y="108.712" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R7" gate="G$1" x="-50.8" y="110.49" smashed="yes" rot="R90">
<attribute name="NAME" x="-50.8" y="115.3414" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-50.8" y="107.442" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R8" gate="G$1" x="-46.99" y="110.49" smashed="yes" rot="R90">
<attribute name="NAME" x="-43.18" y="115.3414" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-46.99" y="107.442" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="R3" gate="G$1" x="44.45" y="64.77" smashed="yes" rot="R90">
<attribute name="NAME" x="42.9514" y="60.96" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="47.752" y="60.96" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R4" gate="G$1" x="44.45" y="115.57" smashed="yes" rot="R90">
<attribute name="NAME" x="42.9514" y="111.76" size="1.778" layer="95" rot="R90"/>
<attribute name="VALUE" x="47.752" y="111.76" size="1.778" layer="96" rot="R90"/>
</instance>
<instance part="R29" gate="G$1" x="-53.34" y="137.16" smashed="yes" rot="R180">
<attribute name="NAME" x="-49.53" y="135.6614" size="1.778" layer="95" rot="R180"/>
<attribute name="VALUE" x="-49.53" y="140.462" size="1.778" layer="96" rot="R180"/>
</instance>
<instance part="GND27" gate="1" x="-45.72" y="137.16" smashed="yes" rot="R90">
<attribute name="VALUE" x="-43.18" y="134.62" size="1.778" layer="96" rot="R90"/>
</instance>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="C13" gate="G$1" pin="-"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="-162.56" y1="6.35" x2="-153.67" y2="6.35" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="IN"/>
<wire x1="-153.67" y1="6.35" x2="-148.59" y2="6.35" width="0.1524" layer="91"/>
<junction x="-153.67" y="6.35"/>
<pinref part="CS1" gate="G$1" pin="1"/>
<wire x1="-177.8" y1="20.32" x2="-168.91" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-168.91" y1="20.32" x2="-168.91" y2="6.35" width="0.1524" layer="91"/>
<wire x1="-168.91" y1="6.35" x2="-162.56" y2="6.35" width="0.1524" layer="91"/>
<junction x="-162.56" y="6.35"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="C10" gate="G$1" pin="+"/>
<pinref part="C11" gate="G$1" pin="1"/>
<wire x1="-162.56" y1="36.83" x2="-153.67" y2="36.83" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="IN"/>
<wire x1="-153.67" y1="36.83" x2="-148.59" y2="36.83" width="0.1524" layer="91"/>
<junction x="-153.67" y="36.83"/>
<pinref part="CS1" gate="G$1" pin="3"/>
<wire x1="-177.8" y1="25.4" x2="-168.91" y2="25.4" width="0.1524" layer="91"/>
<wire x1="-168.91" y1="25.4" x2="-168.91" y2="36.83" width="0.1524" layer="91"/>
<wire x1="-168.91" y1="36.83" x2="-162.56" y2="36.83" width="0.1524" layer="91"/>
<junction x="-162.56" y="36.83"/>
</segment>
</net>
<net name="-5V" class="0">
<segment>
<pinref part="IC2" gate="G$1" pin="OUT"/>
<pinref part="C15" gate="G$1" pin="2"/>
<wire x1="-133.35" y1="6.35" x2="-130.81" y2="6.35" width="0.1524" layer="91"/>
<pinref part="C14" gate="G$1" pin="2"/>
<wire x1="-130.81" y1="6.35" x2="-123.19" y2="6.35" width="0.1524" layer="91"/>
<junction x="-130.81" y="6.35"/>
<pinref part="P-1" gate="1" pin="-5V"/>
<wire x1="-123.19" y1="6.35" x2="-116.84" y2="6.35" width="0.1524" layer="91"/>
<junction x="-123.19" y="6.35"/>
</segment>
<segment>
<pinref part="IC4" gate="G$3" pin="V-"/>
<pinref part="P-2" gate="1" pin="-5V"/>
</segment>
<segment>
<pinref part="IC5" gate="G$3" pin="V-"/>
<pinref part="P-3" gate="1" pin="-5V"/>
</segment>
<segment>
<pinref part="IC6" gate="G$3" pin="V-"/>
<pinref part="P-4" gate="1" pin="-5V"/>
</segment>
<segment>
<pinref part="R60" gate="G$1" pin="1"/>
<wire x1="81.28" y1="-57.15" x2="81.28" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="P-5" gate="1" pin="-5V"/>
<wire x1="81.28" y1="-60.96" x2="81.28" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-60.96" x2="81.28" y2="-60.96" width="0.1524" layer="91"/>
<junction x="81.28" y="-60.96"/>
<pinref part="R53" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="IC9" gate="A" pin="V-"/>
<pinref part="P-6" gate="1" pin="-5V"/>
</segment>
<segment>
<pinref part="IC10" gate="A" pin="V-"/>
<pinref part="P-7" gate="1" pin="-5V"/>
</segment>
</net>
<net name="+5V" class="0">
<segment>
<pinref part="IC1" gate="G$1" pin="OUT"/>
<pinref part="C12" gate="G$1" pin="1"/>
<wire x1="-133.35" y1="36.83" x2="-130.81" y2="36.83" width="0.1524" layer="91"/>
<pinref part="C8" gate="G$1" pin="1"/>
<wire x1="-130.81" y1="36.83" x2="-124.46" y2="36.83" width="0.1524" layer="91"/>
<junction x="-130.81" y="36.83"/>
<pinref part="P+1" gate="1" pin="+5V"/>
<wire x1="-124.46" y1="36.83" x2="-116.84" y2="36.83" width="0.1524" layer="91"/>
<junction x="-124.46" y="36.83"/>
</segment>
<segment>
<pinref part="IC4" gate="G$3" pin="V+"/>
<pinref part="P+4" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="IC5" gate="G$3" pin="V+"/>
<pinref part="P+5" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="IC6" gate="G$3" pin="V+"/>
<pinref part="P+6" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="R59" gate="G$1" pin="2"/>
<pinref part="R52" gate="G$1" pin="2"/>
<wire x1="50.8" y1="-57.15" x2="50.8" y2="-59.69" width="0.1524" layer="91"/>
<pinref part="P+7" gate="1" pin="+5V"/>
<wire x1="50.8" y1="-59.69" x2="50.8" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="48.26" y1="-59.69" x2="50.8" y2="-59.69" width="0.1524" layer="91"/>
<junction x="50.8" y="-59.69"/>
</segment>
<segment>
<pinref part="IC9" gate="A" pin="V+"/>
<pinref part="P+10" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="P5" gate="G$1" pin="S"/>
<pinref part="P+11" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="P7" gate="G$1" pin="S"/>
<pinref part="P+14" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="P+2" gate="1" pin="+5V"/>
<pinref part="C2" gate="G$1" pin="1"/>
<wire x1="-19.05" y1="129.54" x2="-19.05" y2="124.46" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="-19.05" y1="124.46" x2="-13.97" y2="124.46" width="0.1524" layer="91"/>
<pinref part="IC7" gate="G$1" pin="SHDN"/>
<wire x1="-6.35" y1="114.3" x2="-8.89" y2="114.3" width="0.1524" layer="91"/>
<wire x1="-8.89" y1="114.3" x2="-8.89" y2="124.46" width="0.1524" layer="91"/>
<pinref part="IC7" gate="G$1" pin="VDD"/>
<wire x1="-8.89" y1="124.46" x2="-6.35" y2="124.46" width="0.1524" layer="91"/>
<wire x1="-13.97" y1="124.46" x2="-8.89" y2="124.46" width="0.1524" layer="91"/>
<junction x="-13.97" y="124.46"/>
<junction x="-19.05" y="124.46"/>
<junction x="-8.89" y="124.46"/>
</segment>
<segment>
<pinref part="IC8" gate="G$1" pin="VDD"/>
<wire x1="-6.35" y1="95.25" x2="-6.35" y2="90.17" width="0.1524" layer="91"/>
<pinref part="C6" gate="G$1" pin="1"/>
<wire x1="-13.97" y1="95.25" x2="-6.35" y2="95.25" width="0.1524" layer="91"/>
<junction x="-13.97" y="95.25"/>
<pinref part="P+3" gate="1" pin="+5V"/>
<wire x1="-21.59" y1="100.33" x2="-21.59" y2="95.25" width="0.1524" layer="91"/>
<wire x1="-21.59" y1="95.25" x2="-13.97" y2="95.25" width="0.1524" layer="91"/>
<pinref part="C7" gate="G$1" pin="+"/>
<junction x="-21.59" y="95.25"/>
</segment>
<segment>
<pinref part="IC8" gate="G$1" pin="SHDN"/>
<wire x1="24.13" y1="64.77" x2="25.4" y2="64.77" width="0.1524" layer="91"/>
<pinref part="P+8" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="P+15" gate="1" pin="+5V"/>
<pinref part="ICSP" gate="A" pin="2"/>
<wire x1="-83.82" y1="135.89" x2="-82.55" y2="135.89" width="0.1524" layer="91"/>
<wire x1="-82.55" y1="135.89" x2="-82.55" y2="143.51" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="-55.88" y1="115.57" x2="-50.8" y2="115.57" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="115.57" x2="-46.99" y2="115.57" width="0.1524" layer="91"/>
<pinref part="P+17" gate="1" pin="+5V"/>
<junction x="-50.8" y="115.57"/>
<pinref part="R6" gate="G$1" pin="2"/>
<pinref part="R7" gate="G$1" pin="2"/>
<pinref part="R8" gate="G$1" pin="2"/>
</segment>
<segment>
<pinref part="IC11" gate="G$1" pin="VDD"/>
<wire x1="-63.5" y1="90.17" x2="-55.88" y2="90.17" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="1"/>
<pinref part="P+9" gate="1" pin="+5V"/>
<junction x="-55.88" y="90.17"/>
</segment>
<segment>
<pinref part="P+12" gate="1" pin="+5V"/>
<wire x1="-118.11" y1="130.81" x2="-118.11" y2="134.62" width="0.1524" layer="91"/>
<pinref part="R5" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="HMI" gate="A" pin="1"/>
<wire x1="-44.45" y1="59.69" x2="-44.45" y2="66.04" width="0.1524" layer="91"/>
<pinref part="C52" gate="G$1" pin="+"/>
<wire x1="-44.45" y1="66.04" x2="-43.18" y2="66.04" width="0.1524" layer="91"/>
<wire x1="-43.18" y1="66.04" x2="-43.18" y2="73.66" width="0.1524" layer="91"/>
<junction x="-43.18" y="66.04"/>
<pinref part="P+16" gate="1" pin="+5V"/>
</segment>
<segment>
<pinref part="IC10" gate="A" pin="V+"/>
<pinref part="P+13" gate="1" pin="+5V"/>
</segment>
</net>
<net name="AGND" class="0">
<segment>
<pinref part="CS1" gate="G$1" pin="2"/>
<wire x1="-177.8" y1="22.86" x2="-171.45" y2="22.86" width="0.1524" layer="91"/>
<pinref part="SUPPLY1" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C10" gate="G$1" pin="-"/>
<pinref part="SUPPLY2" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC1" gate="G$1" pin="GND"/>
<pinref part="SUPPLY4" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C8" gate="G$1" pin="2"/>
<pinref part="SUPPLY6" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C11" gate="G$1" pin="2"/>
<pinref part="SUPPLY3" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C12" gate="G$1" pin="2"/>
<pinref part="SUPPLY5" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C13" gate="G$1" pin="+"/>
<pinref part="SUPPLY7" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C4" gate="G$1" pin="1"/>
<pinref part="SUPPLY8" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="GND"/>
<pinref part="SUPPLY9" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C15" gate="G$1" pin="1"/>
<pinref part="SUPPLY10" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C14" gate="G$1" pin="1"/>
<pinref part="SUPPLY11" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C35" gate="G$1" pin="2"/>
<pinref part="SUPPLY18" gate="G$1" pin="AGND"/>
<wire x1="53.34" y1="101.6" x2="53.34" y2="100.33" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="R51" gate="G$1" pin="1"/>
<pinref part="SUPPLY20" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="SUPPLY21" gate="G$1" pin="AGND"/>
<wire x1="62.23" y1="-77.47" x2="59.69" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="D27" gate="G$1" pin="C"/>
</segment>
<segment>
<pinref part="C42" gate="G$1" pin="2"/>
<pinref part="SUPPLY22" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="D3" gate="G$1" pin="A"/>
<pinref part="SUPPLY12" gate="G$1" pin="AGND"/>
<wire x1="-133.35" y1="109.22" x2="-130.81" y2="109.22" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C1" gate="G$1" pin="1"/>
<pinref part="SUPPLY14" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="R41" gate="G$1" pin="1"/>
<pinref part="SUPPLY15" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C18" gate="G$1" pin="1"/>
<pinref part="SUPPLY17" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="D4" gate="G$1" pin="A"/>
<pinref part="SUPPLY16" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC7" gate="G$1" pin="GND2"/>
<pinref part="IC7" gate="G$1" pin="GND3"/>
<wire x1="24.13" y1="114.3" x2="24.13" y2="109.22" width="0.1524" layer="91"/>
<pinref part="SUPPLY24" gate="G$1" pin="AGND"/>
<junction x="24.13" y="109.22"/>
</segment>
<segment>
<pinref part="IC7" gate="G$1" pin="GND1"/>
<pinref part="SUPPLY23" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C6" gate="G$1" pin="2"/>
<pinref part="SUPPLY26" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C7" gate="G$1" pin="-"/>
<pinref part="SUPPLY27" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC8" gate="G$1" pin="VSS"/>
<pinref part="SUPPLY25" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C2" gate="G$1" pin="2"/>
<pinref part="SUPPLY31" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC8" gate="G$1" pin="LDAC"/>
<wire x1="24.13" y1="59.69" x2="24.13" y2="57.15" width="0.1524" layer="91"/>
<pinref part="SUPPLY34" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C3" gate="G$1" pin="2"/>
<pinref part="SUPPLY30" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C5" gate="G$1" pin="1"/>
<pinref part="SUPPLY35" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="R1" gate="G$1" pin="2"/>
<pinref part="SUPPLY36" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C36" gate="G$1" pin="1"/>
<pinref part="SUPPLY28" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="IC11" gate="G$1" pin="RA2"/>
<pinref part="SUPPLY37" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="C47" gate="G$1" pin="2"/>
<pinref part="SUPPLY38" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="D2" gate="G$1" pin="A"/>
<pinref part="SUPPLY13" gate="G$1" pin="AGND"/>
</segment>
<segment>
<pinref part="JP3" gate="G$1" pin="1"/>
<pinref part="SUPPLY39" gate="G$1" pin="AGND"/>
<wire x1="179.07" y1="0" x2="170.18" y2="0" width="0.1524" layer="91"/>
<wire x1="170.18" y1="0" x2="170.18" y2="-1.27" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="SUPPLY33" gate="G$1" pin="AGND"/>
<pinref part="R3" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="SUPPLY32" gate="G$1" pin="AGND"/>
<pinref part="R4" gate="G$1" pin="2"/>
</segment>
<segment>
<pinref part="SUPPLY19" gate="G$1" pin="AGND"/>
<pinref part="GND3" gate="1" pin="GND"/>
<wire x1="-109.22" y1="25.4" x2="-109.22" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GNDA" class="0">
<segment>
<pinref part="C43" gate="G$1" pin="2"/>
<pinref part="GND16" gate="1" pin="GNDA"/>
</segment>
<segment>
<pinref part="C37" gate="G$1" pin="2"/>
<pinref part="GND1" gate="1" pin="GNDA"/>
</segment>
<segment>
<pinref part="GND15" gate="1" pin="GNDA"/>
<wire x1="81.28" y1="6.35" x2="81.28" y2="2.54" width="0.1524" layer="91"/>
<pinref part="RS5" gate="G$1" pin="2A"/>
<wire x1="78.74" y1="6.35" x2="81.28" y2="6.35" width="0.1524" layer="91"/>
<wire x1="58.42" y1="30.48" x2="58.42" y2="13.97" width="0.1524" layer="91"/>
<pinref part="R35" gate="G$1" pin="1"/>
<wire x1="58.42" y1="13.97" x2="81.28" y2="13.97" width="0.1524" layer="91"/>
<wire x1="81.28" y1="13.97" x2="81.28" y2="6.35" width="0.1524" layer="91"/>
<junction x="81.28" y="6.35"/>
</segment>
<segment>
<pinref part="GND17" gate="1" pin="GNDA"/>
<pinref part="R55" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="IC4" gate="B" pin="-IN"/>
<wire x1="62.23" y1="105.41" x2="60.96" y2="105.41" width="0.1524" layer="91"/>
<wire x1="60.96" y1="105.41" x2="60.96" y2="101.6" width="0.1524" layer="91"/>
<pinref part="IC4" gate="B" pin="OUT"/>
<wire x1="60.96" y1="101.6" x2="77.47" y2="101.6" width="0.1524" layer="91"/>
<wire x1="77.47" y1="101.6" x2="77.47" y2="107.95" width="0.1524" layer="91"/>
<pinref part="R46" gate="G$1" pin="1"/>
<wire x1="133.35" y1="-43.18" x2="133.35" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="133.35" y1="-27.94" x2="104.14" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="104.14" y1="-27.94" x2="104.14" y2="107.95" width="0.1524" layer="91"/>
<wire x1="104.14" y1="107.95" x2="93.98" y2="107.95" width="0.1524" layer="91"/>
<junction x="77.47" y="107.95"/>
<pinref part="TP1" gate="G$1" pin="1"/>
<wire x1="93.98" y1="107.95" x2="77.47" y2="107.95" width="0.1524" layer="91"/>
<wire x1="93.98" y1="114.3" x2="93.98" y2="107.95" width="0.1524" layer="91"/>
<junction x="93.98" y="107.95"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="IC4" gate="A" pin="-IN"/>
<wire x1="62.23" y1="82.55" x2="60.96" y2="82.55" width="0.1524" layer="91"/>
<wire x1="60.96" y1="82.55" x2="60.96" y2="78.74" width="0.1524" layer="91"/>
<pinref part="IC4" gate="A" pin="OUT"/>
<wire x1="60.96" y1="78.74" x2="77.47" y2="78.74" width="0.1524" layer="91"/>
<wire x1="77.47" y1="78.74" x2="77.47" y2="85.09" width="0.1524" layer="91"/>
<wire x1="100.33" y1="85.09" x2="93.98" y2="85.09" width="0.1524" layer="91"/>
<junction x="77.47" y="85.09"/>
<pinref part="P1" gate="G$1" pin="E"/>
<wire x1="93.98" y1="85.09" x2="77.47" y2="85.09" width="0.1524" layer="91"/>
<wire x1="100.33" y1="-30.48" x2="100.33" y2="85.09" width="0.1524" layer="91"/>
<pinref part="TP2" gate="G$1" pin="1"/>
<wire x1="93.98" y1="91.44" x2="93.98" y2="85.09" width="0.1524" layer="91"/>
<junction x="93.98" y="85.09"/>
<pinref part="P1" gate="G$1" pin="S"/>
<wire x1="105.41" y1="-35.56" x2="105.41" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="105.41" y1="-30.48" x2="100.33" y2="-30.48" width="0.1524" layer="91"/>
<junction x="100.33" y="-30.48"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<wire x1="-133.35" y1="-27.94" x2="-125.73" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="-27.94" x2="-125.73" y2="-25.4" width="0.1524" layer="91"/>
<pinref part="C20" gate="G$1" pin="+"/>
<wire x1="-125.73" y1="-25.4" x2="-120.65" y2="-25.4" width="0.1524" layer="91"/>
<pinref part="C21" gate="G$1" pin="1"/>
<wire x1="-120.65" y1="-25.4" x2="-113.03" y2="-25.4" width="0.1524" layer="91"/>
<junction x="-120.65" y="-25.4"/>
<junction x="-113.03" y="-25.4"/>
<pinref part="R11" gate="G$1" pin="2"/>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="-101.6" y1="2.54" x2="-96.52" y2="2.54" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="2"/>
<wire x1="-96.52" y1="2.54" x2="-91.44" y2="2.54" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="2"/>
<wire x1="-91.44" y1="2.54" x2="-86.36" y2="2.54" width="0.1524" layer="91"/>
<wire x1="-113.03" y1="-25.4" x2="-113.03" y2="2.54" width="0.1524" layer="91"/>
<wire x1="-113.03" y1="2.54" x2="-101.6" y2="2.54" width="0.1524" layer="91"/>
<junction x="-101.6" y="2.54"/>
<junction x="-96.52" y="2.54"/>
<junction x="-91.44" y="2.54"/>
<junction x="-86.36" y="2.54"/>
<pinref part="T12" gate="G$1" pin="E"/>
<wire x1="-86.36" y1="2.54" x2="-57.15" y2="2.54" width="0.1524" layer="91"/>
<pinref part="D19" gate="G$1" pin="C"/>
<wire x1="-26.67" y1="-16.51" x2="-57.15" y2="-16.51" width="0.1524" layer="91"/>
<wire x1="-57.15" y1="-16.51" x2="-57.15" y2="2.54" width="0.1524" layer="91"/>
<junction x="-57.15" y="2.54"/>
<pinref part="RS1" gate="G$1" pin="1"/>
<wire x1="-57.15" y1="2.54" x2="-44.45" y2="2.54" width="0.1524" layer="91"/>
<pinref part="RS2" gate="G$1" pin="1"/>
<wire x1="-44.45" y1="2.54" x2="-44.45" y2="-1.27" width="0.1524" layer="91"/>
<junction x="-44.45" y="2.54"/>
<pinref part="SK1" gate="G$1" pin="2"/>
</segment>
</net>
<net name="0V" class="0">
<segment>
<wire x1="-133.35" y1="-30.48" x2="-125.73" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="-30.48" x2="-125.73" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="C20" gate="G$1" pin="-"/>
<wire x1="-125.73" y1="-33.02" x2="-120.65" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="C21" gate="G$1" pin="2"/>
<wire x1="-120.65" y1="-33.02" x2="-113.03" y2="-33.02" width="0.1524" layer="91"/>
<junction x="-120.65" y="-33.02"/>
<junction x="-113.03" y="-33.02"/>
<pinref part="GND6" gate="1" pin="0V"/>
<wire x1="-113.03" y1="-33.02" x2="-113.03" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="-113.03" y1="-62.23" x2="-74.93" y2="-62.23" width="0.1524" layer="91"/>
<pinref part="C27" gate="G$1" pin="2"/>
<wire x1="-74.93" y1="-62.23" x2="-66.04" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="-74.93" y1="-40.64" x2="-74.93" y2="-62.23" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="GND"/>
<wire x1="-66.04" y1="-38.1" x2="-66.04" y2="-62.23" width="0.1524" layer="91"/>
<junction x="-74.93" y="-62.23"/>
<pinref part="T11" gate="G$1" pin="S"/>
<wire x1="-41.91" y1="-62.23" x2="-55.88" y2="-62.23" width="0.1524" layer="91"/>
<pinref part="C26" gate="G$1" pin="2"/>
<wire x1="-55.88" y1="-62.23" x2="-55.88" y2="-59.69" width="0.1524" layer="91"/>
<junction x="-55.88" y="-62.23"/>
<wire x1="-55.88" y1="-62.23" x2="-60.96" y2="-62.23" width="0.1524" layer="91"/>
<pinref part="D18" gate="G$1" pin="A"/>
<wire x1="-60.96" y1="-62.23" x2="-66.04" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="-55.88" x2="-60.96" y2="-62.23" width="0.1524" layer="91"/>
<junction x="-66.04" y="-62.23"/>
<junction x="-60.96" y="-62.23"/>
<pinref part="SK1" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="D13" gate="G$1" pin="A"/>
<pinref part="GND7" gate="1" pin="0V"/>
</segment>
<segment>
<pinref part="C22" gate="G$1" pin="-"/>
<pinref part="GND8" gate="1" pin="0V"/>
</segment>
<segment>
<pinref part="D14" gate="G$1" pin="A"/>
<pinref part="GND9" gate="1" pin="0V"/>
<wire x1="-90.17" y1="-35.56" x2="-90.17" y2="-33.02" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C23" gate="G$1" pin="2"/>
<pinref part="GND10" gate="1" pin="0V"/>
<pinref part="GND4" gate="1" pin="0V"/>
<junction x="-85.09" y="-35.56"/>
</segment>
<segment>
<pinref part="C25" gate="G$1" pin="2"/>
<pinref part="GND11" gate="1" pin="0V"/>
</segment>
<segment>
<pinref part="C24" gate="G$1" pin="2"/>
<pinref part="GND12" gate="1" pin="0V"/>
</segment>
<segment>
<pinref part="GND13" gate="1" pin="0V"/>
<pinref part="R23" gate="G$1" pin="1"/>
</segment>
<segment>
<pinref part="GND14" gate="1" pin="0V"/>
<pinref part="R70" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="R15" gate="G$1" pin="1"/>
<pinref part="D13" gate="G$1" pin="C"/>
<wire x1="-101.6" y1="-20.32" x2="-101.6" y2="-24.13" width="0.1524" layer="91"/>
<pinref part="T10" gate="G$1" pin="G"/>
<wire x1="-101.6" y1="-24.13" x2="-101.6" y2="-26.67" width="0.1524" layer="91"/>
<wire x1="-100.33" y1="-24.13" x2="-101.6" y2="-24.13" width="0.1524" layer="91"/>
<junction x="-101.6" y="-24.13"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="T10" gate="G$1" pin="S"/>
<pinref part="C22" gate="G$1" pin="+"/>
<wire x1="-95.25" y1="-26.67" x2="-95.25" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="D14" gate="G$1" pin="C"/>
<wire x1="-95.25" y1="-27.94" x2="-90.17" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="C23" gate="G$1" pin="1"/>
<wire x1="-90.17" y1="-27.94" x2="-85.09" y2="-27.94" width="0.1524" layer="91"/>
<junction x="-95.25" y="-27.94"/>
<junction x="-90.17" y="-27.94"/>
<junction x="-85.09" y="-27.94"/>
<wire x1="-85.09" y1="-27.94" x2="-85.09" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="R"/>
<wire x1="-85.09" y1="-15.24" x2="-62.23" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="-62.23" y1="-15.24" x2="-49.53" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="-49.53" y1="-15.24" x2="-36.83" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-27.94" x2="-68.58" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="-68.58" y1="-27.94" x2="-68.58" y2="-43.18" width="0.1524" layer="91"/>
<wire x1="-68.58" y1="-43.18" x2="-45.72" y2="-43.18" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="V+"/>
<wire x1="-45.72" y1="-43.18" x2="-45.72" y2="-38.1" width="0.1524" layer="91"/>
<pinref part="C25" gate="G$1" pin="1"/>
<junction x="-45.72" y="-38.1"/>
<wire x1="-36.83" y1="-38.1" x2="-45.72" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="-36.83" y1="-15.24" x2="-36.83" y2="-38.1" width="0.1524" layer="91"/>
<junction x="-36.83" y="-38.1"/>
<pinref part="D17" gate="G$1" pin="C"/>
<wire x1="-62.23" y1="-11.43" x2="-62.23" y2="-15.24" width="0.1524" layer="91"/>
<junction x="-62.23" y="-15.24"/>
<pinref part="R20" gate="G$1" pin="1"/>
<junction x="-49.53" y="-15.24"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="R15" gate="G$1" pin="2"/>
<pinref part="R11" gate="G$1" pin="1"/>
<wire x1="-101.6" y1="-10.16" x2="-101.6" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R12" gate="G$1" pin="1"/>
<wire x1="-101.6" y1="-7.62" x2="-96.52" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="1"/>
<wire x1="-96.52" y1="-7.62" x2="-95.25" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="1"/>
<wire x1="-95.25" y1="-7.62" x2="-91.44" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-91.44" y1="-7.62" x2="-86.36" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="T10" gate="G$1" pin="D"/>
<wire x1="-95.25" y1="-16.51" x2="-95.25" y2="-7.62" width="0.1524" layer="91"/>
<junction x="-101.6" y="-7.62"/>
<junction x="-96.52" y="-7.62"/>
<junction x="-95.25" y="-7.62"/>
<junction x="-91.44" y="-7.62"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="C27" gate="G$1" pin="1"/>
<pinref part="IC3" gate="A" pin="CV"/>
<wire x1="-74.93" y1="-33.02" x2="-66.04" y2="-33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="IC3" gate="A" pin="TR"/>
<wire x1="-66.04" y1="-22.86" x2="-68.58" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="-68.58" y1="-22.86" x2="-68.58" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-68.58" y1="-17.78" x2="-39.37" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-39.37" y1="-17.78" x2="-39.37" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="THR"/>
<wire x1="-39.37" y1="-33.02" x2="-45.72" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="-39.37" y1="-33.02" x2="-33.02" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="C24" gate="G$1" pin="1"/>
<pinref part="R24" gate="G$1" pin="1"/>
<wire x1="-33.02" y1="-33.02" x2="-33.02" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="-33.02" y1="-38.1" x2="-29.21" y2="-38.1" width="0.1524" layer="91"/>
<junction x="-39.37" y="-33.02"/>
<junction x="-29.21" y="-38.1"/>
<pinref part="D16" gate="G$1" pin="C"/>
<wire x1="-68.58" y1="-11.43" x2="-68.58" y2="-17.78" width="0.1524" layer="91"/>
<junction x="-68.58" y="-17.78"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="D15" gate="G$1" pin="C"/>
<pinref part="D16" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="IC3" gate="A" pin="DIS"/>
<pinref part="R24" gate="G$1" pin="2"/>
<wire x1="-45.72" y1="-27.94" x2="-29.21" y2="-27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="D19" gate="G$1" pin="A1"/>
<wire x1="-31.75" y1="-19.05" x2="-31.75" y2="-24.13" width="0.1524" layer="91"/>
<wire x1="-31.75" y1="-24.13" x2="-21.59" y2="-24.13" width="0.1524" layer="91"/>
<pinref part="D19" gate="G$1" pin="A2"/>
<wire x1="-21.59" y1="-24.13" x2="-21.59" y2="-19.05" width="0.1524" layer="91"/>
<wire x1="-21.59" y1="-24.13" x2="-21.59" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="-21.59" y1="-50.8" x2="-24.13" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="T11" gate="G$1" pin="D"/>
<wire x1="-36.83" y1="-62.23" x2="-24.13" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="-24.13" y1="-62.23" x2="-21.59" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="-24.13" y1="-50.8" x2="-24.13" y2="-62.23" width="0.1524" layer="91"/>
<junction x="-24.13" y="-62.23"/>
<junction x="-21.59" y="-24.13"/>
<pinref part="L1" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="T12" gate="G$1" pin="C"/>
<pinref part="R19" gate="G$1" pin="2"/>
<pinref part="T13" gate="G$1" pin="C"/>
<wire x1="-29.21" y1="12.7" x2="-57.15" y2="12.7" width="0.1524" layer="91"/>
<junction x="-57.15" y="12.7"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="T12" gate="G$1" pin="B"/>
<wire x1="-52.07" y1="7.62" x2="-49.53" y2="7.62" width="0.1524" layer="91"/>
<pinref part="R20" gate="G$1" pin="2"/>
<wire x1="-49.53" y1="7.62" x2="-49.53" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="D20" gate="G$1" pin="C"/>
<wire x1="-46.99" y1="7.62" x2="-49.53" y2="7.62" width="0.1524" layer="91"/>
<junction x="-49.53" y="7.62"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="R19" gate="G$1" pin="1"/>
<pinref part="R18" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="R18" gate="G$1" pin="1"/>
<pinref part="R17" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="R17" gate="G$1" pin="1"/>
<pinref part="R16" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="R16" gate="G$1" pin="1"/>
<wire x1="-97.79" y1="12.7" x2="-97.79" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-97.79" y1="5.08" x2="-68.58" y2="5.08" width="0.1524" layer="91"/>
<pinref part="D17" gate="G$1" pin="A"/>
<wire x1="-68.58" y1="5.08" x2="-62.23" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-62.23" y1="5.08" x2="-62.23" y2="-6.35" width="0.1524" layer="91"/>
<pinref part="D15" gate="G$1" pin="A"/>
<wire x1="-68.58" y1="-1.27" x2="-68.58" y2="5.08" width="0.1524" layer="91"/>
<junction x="-68.58" y="5.08"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="IC3" gate="A" pin="Q"/>
<wire x1="-45.72" y1="-22.86" x2="-41.91" y2="-22.86" width="0.1524" layer="91"/>
<pinref part="R25" gate="G$1" pin="2"/>
<wire x1="-41.91" y1="-22.86" x2="-41.91" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="-41.91" y1="-40.64" x2="-44.45" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="-44.45" y1="-40.64" x2="-44.45" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="-44.45" y1="-45.72" x2="-60.96" y2="-45.72" width="0.1524" layer="91"/>
<pinref part="D18" gate="G$1" pin="C"/>
<wire x1="-60.96" y1="-45.72" x2="-60.96" y2="-50.8" width="0.1524" layer="91"/>
<junction x="-41.91" y="-40.64"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="C26" gate="G$1" pin="1"/>
<wire x1="-55.88" y1="-52.07" x2="-54.61" y2="-52.07" width="0.1524" layer="91"/>
<pinref part="R26" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="R26" gate="G$1" pin="1"/>
<pinref part="T11" gate="G$1" pin="G"/>
<wire x1="-44.45" y1="-52.07" x2="-41.91" y2="-52.07" width="0.1524" layer="91"/>
<pinref part="R25" gate="G$1" pin="1"/>
<wire x1="-41.91" y1="-52.07" x2="-41.91" y2="-50.8" width="0.1524" layer="91"/>
<junction x="-41.91" y="-52.07"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<pinref part="RS2" gate="G$1" pin="2"/>
<pinref part="RS1" gate="G$1" pin="2"/>
<wire x1="-34.29" y1="-1.27" x2="-34.29" y2="2.54" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="2.54" x2="-34.29" y2="7.62" width="0.1524" layer="91"/>
<pinref part="D20" gate="G$1" pin="A"/>
<wire x1="-34.29" y1="7.62" x2="-41.91" y2="7.62" width="0.1524" layer="91"/>
<junction x="-34.29" y="2.54"/>
<wire x1="-34.29" y1="2.54" x2="-29.21" y2="2.54" width="0.1524" layer="91"/>
<pinref part="T13" gate="G$1" pin="E"/>
<wire x1="-29.21" y1="2.54" x2="-16.51" y2="2.54" width="0.1524" layer="91"/>
<junction x="-29.21" y="2.54"/>
<pinref part="D21" gate="G$1" pin="C"/>
<pinref part="R22" gate="G$1" pin="1"/>
<wire x1="-16.51" y1="2.54" x2="-6.35" y2="2.54" width="0.1524" layer="91"/>
<junction x="-16.51" y="2.54"/>
<pinref part="C29" gate="G$1" pin="+"/>
<pinref part="C30" gate="G$1" pin="+"/>
<wire x1="-15.24" y1="-31.75" x2="-6.35" y2="-31.75" width="0.1524" layer="91"/>
<pinref part="C31" gate="G$1" pin="1"/>
<wire x1="-6.35" y1="-31.75" x2="1.27" y2="-31.75" width="0.1524" layer="91"/>
<wire x1="-16.51" y1="2.54" x2="-16.51" y2="-31.75" width="0.1524" layer="91"/>
<wire x1="-16.51" y1="-31.75" x2="-15.24" y2="-31.75" width="0.1524" layer="91"/>
<junction x="-15.24" y="-31.75"/>
<junction x="-6.35" y="-31.75"/>
<junction x="1.27" y="-31.75"/>
<wire x1="8.89" y1="-31.75" x2="1.27" y2="-31.75" width="0.1524" layer="91"/>
<wire x1="-6.35" y1="2.54" x2="15.24" y2="2.54" width="0.1524" layer="91"/>
<junction x="-6.35" y="2.54"/>
<pinref part="R27" gate="G$1" pin="2"/>
<wire x1="15.24" y1="2.54" x2="22.86" y2="2.54" width="0.1524" layer="91"/>
<junction x="15.24" y="2.54"/>
<pinref part="D25" gate="G$1" pin="C"/>
<wire x1="22.86" y1="2.54" x2="22.86" y2="0" width="0.1524" layer="91"/>
<pinref part="T15" gate="G$1" pin="D"/>
<wire x1="22.86" y1="2.54" x2="34.29" y2="2.54" width="0.1524" layer="91"/>
<junction x="22.86" y="2.54"/>
<pinref part="C32" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<pinref part="T13" gate="G$1" pin="B"/>
<pinref part="D21" gate="G$1" pin="A"/>
<wire x1="-24.13" y1="7.62" x2="-16.51" y2="7.62" width="0.1524" layer="91"/>
<pinref part="R21" gate="G$1" pin="1"/>
<wire x1="-16.51" y1="15.24" x2="-16.51" y2="12.7" width="0.1524" layer="91"/>
<junction x="-16.51" y="7.62"/>
<pinref part="R22" gate="G$1" pin="2"/>
<wire x1="-16.51" y1="12.7" x2="-16.51" y2="7.62" width="0.1524" layer="91"/>
<wire x1="-6.35" y1="12.7" x2="-16.51" y2="12.7" width="0.1524" layer="91"/>
<junction x="-16.51" y="12.7"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<pinref part="D22" gate="G$1" pin="C"/>
<pinref part="D23" gate="G$1" pin="A"/>
<wire x1="-11.43" y1="34.29" x2="-7.62" y2="34.29" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<pinref part="D24" gate="G$1" pin="C"/>
<wire x1="2.54" y1="24.13" x2="2.54" y2="29.21" width="0.1524" layer="91"/>
<pinref part="D23" gate="G$1" pin="C"/>
<wire x1="-2.54" y1="34.29" x2="2.54" y2="34.29" width="0.1524" layer="91"/>
<wire x1="2.54" y1="34.29" x2="2.54" y2="29.21" width="0.1524" layer="91"/>
<junction x="2.54" y="29.21"/>
<pinref part="R23" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<pinref part="R21" gate="G$1" pin="2"/>
<wire x1="-16.51" y1="25.4" x2="-11.43" y2="25.4" width="0.1524" layer="91"/>
<pinref part="D22" gate="G$1" pin="A"/>
<wire x1="-11.43" y1="25.4" x2="-11.43" y2="29.21" width="0.1524" layer="91"/>
<wire x1="-11.43" y1="25.4" x2="-2.54" y2="25.4" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="25.4" x2="-2.54" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="C28" gate="G$1" pin="1"/>
<junction x="-11.43" y="25.4"/>
</segment>
</net>
<net name="N$42" class="0">
<segment>
<pinref part="C33" gate="G$1" pin="1"/>
<wire x1="8.89" y1="-39.37" x2="8.89" y2="-43.18" width="0.1524" layer="91"/>
<pinref part="H1" gate="G$1" pin="1"/>
<wire x1="8.89" y1="-43.18" x2="8.89" y2="-44.45" width="0.1524" layer="91"/>
<wire x1="11.43" y1="-43.18" x2="8.89" y2="-43.18" width="0.1524" layer="91"/>
<junction x="8.89" y="-43.18"/>
<pinref part="C32" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$43" class="0">
<segment>
<pinref part="R64" gate="G$1" pin="2"/>
<pinref part="T16" gate="G$1" pin="C"/>
<wire x1="44.45" y1="-15.24" x2="39.37" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="35.56" y1="-16.51" x2="38.1" y2="-16.51" width="0.1524" layer="91"/>
<wire x1="38.1" y1="-16.51" x2="38.1" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="38.1" y1="-15.24" x2="39.37" y2="-15.24" width="0.1524" layer="91"/>
<junction x="39.37" y="-15.24"/>
</segment>
</net>
<net name="N$44" class="0">
<segment>
<pinref part="T16" gate="G$1" pin="B"/>
<pinref part="R65" gate="G$1" pin="2"/>
<wire x1="49.53" y1="-20.32" x2="49.53" y2="-22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$47" class="0">
<segment>
<pinref part="R68" gate="G$1" pin="1"/>
<pinref part="R67" gate="G$1" pin="1"/>
<wire x1="52.07" y1="-29.21" x2="52.07" y2="-33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$48" class="0">
<segment>
<pinref part="R67" gate="G$1" pin="2"/>
<pinref part="R66" gate="G$1" pin="2"/>
<wire x1="62.23" y1="-33.02" x2="62.23" y2="-39.37" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$49" class="0">
<segment>
<pinref part="R65" gate="G$1" pin="1"/>
<wire x1="49.53" y1="-33.02" x2="49.53" y2="-39.37" width="0.1524" layer="91"/>
<pinref part="R66" gate="G$1" pin="1"/>
<wire x1="49.53" y1="-39.37" x2="52.07" y2="-39.37" width="0.1524" layer="91"/>
<pinref part="D30" gate="G$1" pin="C"/>
<wire x1="92.71" y1="-63.5" x2="92.71" y2="-43.18" width="0.1524" layer="91"/>
<wire x1="92.71" y1="-43.18" x2="49.53" y2="-43.18" width="0.1524" layer="91"/>
<wire x1="49.53" y1="-43.18" x2="49.53" y2="-39.37" width="0.1524" layer="91"/>
<junction x="49.53" y="-39.37"/>
</segment>
</net>
<net name="N$50" class="0">
<segment>
<pinref part="D29" gate="G$1" pin="A"/>
<pinref part="R62" gate="G$1" pin="1"/>
<wire x1="36.83" y1="-34.29" x2="39.37" y2="-34.29" width="0.1524" layer="91"/>
<pinref part="D28" gate="G$1" pin="A"/>
<pinref part="R61" gate="G$1" pin="1"/>
<wire x1="39.37" y1="-34.29" x2="39.37" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="36.83" y1="-25.4" x2="39.37" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="39.37" y1="-25.4" x2="39.37" y2="-29.21" width="0.1524" layer="91"/>
<pinref part="R64" gate="G$1" pin="1"/>
<wire x1="39.37" y1="-34.29" x2="39.37" y2="-29.21" width="0.1524" layer="91"/>
<junction x="39.37" y="-25.4"/>
<junction x="39.37" y="-29.21"/>
<junction x="39.37" y="-34.29"/>
</segment>
</net>
<net name="N$54" class="0">
<segment>
<pinref part="D29" gate="G$1" pin="C"/>
<pinref part="R62" gate="G$1" pin="2"/>
<wire x1="31.75" y1="-34.29" x2="29.21" y2="-34.29" width="0.1524" layer="91"/>
<wire x1="29.21" y1="-34.29" x2="29.21" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="29.21" y1="-38.1" x2="29.21" y2="-43.18" width="0.1524" layer="91"/>
<pinref part="C41" gate="G$1" pin="1"/>
<wire x1="29.21" y1="-43.18" x2="35.56" y2="-43.18" width="0.1524" layer="91"/>
<junction x="29.21" y="-38.1"/>
<pinref part="IC5" gate="A" pin="OUT"/>
<wire x1="31.75" y1="-50.8" x2="29.21" y2="-50.8" width="0.1524" layer="91"/>
<wire x1="29.21" y1="-50.8" x2="29.21" y2="-43.18" width="0.1524" layer="91"/>
<junction x="29.21" y="-43.18"/>
<junction x="29.21" y="-50.8"/>
<pinref part="IC6" gate="B" pin="+IN"/>
<wire x1="29.21" y1="-50.8" x2="29.21" y2="-87.63" width="0.1524" layer="91"/>
<wire x1="29.21" y1="-87.63" x2="34.29" y2="-87.63" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$52" class="0">
<segment>
<pinref part="C41" gate="G$1" pin="2"/>
<wire x1="43.18" y1="-43.18" x2="46.99" y2="-43.18" width="0.1524" layer="91"/>
<pinref part="IC5" gate="A" pin="-IN"/>
<wire x1="46.99" y1="-43.18" x2="46.99" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-48.26" x2="46.99" y2="-48.26" width="0.1524" layer="91"/>
<junction x="46.99" y="-48.26"/>
<pinref part="R57" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$55" class="0">
<segment>
<pinref part="C39" gate="G$1" pin="1"/>
<pinref part="IC5" gate="B" pin="OUT"/>
<wire x1="35.56" y1="-63.5" x2="31.75" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="31.75" y1="-63.5" x2="31.75" y2="-71.12" width="0.1524" layer="91"/>
<wire x1="31.75" y1="-63.5" x2="25.4" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="25.4" y1="-63.5" x2="25.4" y2="-29.21" width="0.1524" layer="91"/>
<pinref part="D28" gate="G$1" pin="C"/>
<pinref part="R61" gate="G$1" pin="2"/>
<wire x1="31.75" y1="-25.4" x2="29.21" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="29.21" y1="-25.4" x2="29.21" y2="-29.21" width="0.1524" layer="91"/>
<wire x1="25.4" y1="-29.21" x2="29.21" y2="-29.21" width="0.1524" layer="91"/>
<junction x="29.21" y="-29.21"/>
<junction x="31.75" y="-63.5"/>
<wire x1="31.75" y1="-71.12" x2="31.75" y2="-92.71" width="0.1524" layer="91"/>
<pinref part="IC6" gate="B" pin="-IN"/>
<wire x1="31.75" y1="-92.71" x2="34.29" y2="-92.71" width="0.1524" layer="91"/>
<junction x="31.75" y="-71.12"/>
</segment>
</net>
<net name="N$56" class="0">
<segment>
<pinref part="C39" gate="G$1" pin="2"/>
<pinref part="IC5" gate="B" pin="-IN"/>
<wire x1="43.18" y1="-63.5" x2="46.99" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="46.99" y1="-63.5" x2="46.99" y2="-68.58" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-68.58" x2="46.99" y2="-68.58" width="0.1524" layer="91"/>
<junction x="46.99" y="-68.58"/>
<pinref part="R50" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$58" class="0">
<segment>
<pinref part="IC5" gate="B" pin="+IN"/>
<wire x1="46.99" y1="-73.66" x2="49.53" y2="-73.66" width="0.1524" layer="91"/>
<wire x1="49.53" y1="-73.66" x2="49.53" y2="-77.47" width="0.1524" layer="91"/>
<wire x1="49.53" y1="-73.66" x2="118.11" y2="-73.66" width="0.1524" layer="91"/>
<junction x="49.53" y="-73.66"/>
<wire x1="118.11" y1="-73.66" x2="118.11" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="D26" gate="G$1" pin="C"/>
<pinref part="R49" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$59" class="0">
<segment>
<pinref part="R59" gate="G$1" pin="1"/>
<pinref part="P3" gate="G$1" pin="E"/>
</segment>
</net>
<net name="N$62" class="0">
<segment>
<pinref part="P3" gate="G$1" pin="A"/>
<pinref part="R60" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$66" class="0">
<segment>
<wire x1="60.96" y1="-48.26" x2="66.04" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="P3" gate="G$1" pin="S"/>
<wire x1="66.04" y1="-52.07" x2="66.04" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="R58" gate="G$1" pin="1"/>
<junction x="66.04" y="-48.26"/>
<pinref part="R57" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$63" class="0">
<segment>
<wire x1="62.23" y1="11.43" x2="62.23" y2="6.35" width="0.1524" layer="91"/>
<wire x1="62.23" y1="6.35" x2="62.23" y2="0" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-48.26" x2="76.2" y2="-24.13" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-24.13" x2="76.2" y2="0" width="0.1524" layer="91"/>
<wire x1="76.2" y1="0" x2="62.23" y2="0" width="0.1524" layer="91"/>
<pinref part="C42" gate="G$1" pin="1"/>
<wire x1="76.2" y1="-24.13" x2="81.28" y2="-24.13" width="0.1524" layer="91"/>
<pinref part="C43" gate="G$1" pin="1"/>
<wire x1="81.28" y1="-24.13" x2="88.9" y2="-24.13" width="0.1524" layer="91"/>
<junction x="76.2" y="-24.13"/>
<junction x="81.28" y="-24.13"/>
<wire x1="54.61" y1="11.43" x2="62.23" y2="11.43" width="0.1524" layer="91"/>
<wire x1="54.61" y1="11.43" x2="54.61" y2="35.56" width="0.1524" layer="91"/>
<wire x1="54.61" y1="35.56" x2="58.42" y2="35.56" width="0.1524" layer="91"/>
<junction x="62.23" y="6.35"/>
<pinref part="RS5" gate="G$1" pin="1A"/>
<wire x1="66.04" y1="6.35" x2="62.23" y2="6.35" width="0.1524" layer="91"/>
<pinref part="R28" gate="G$1" pin="1"/>
<wire x1="62.23" y1="-2.54" x2="62.23" y2="0" width="0.1524" layer="91"/>
<junction x="62.23" y="0"/>
<pinref part="R34" gate="G$1" pin="1"/>
<pinref part="R58" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$46" class="0">
<segment>
<pinref part="IC5" gate="A" pin="+IN"/>
<wire x1="46.99" y1="-53.34" x2="100.33" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="100.33" y1="-53.34" x2="107.95" y2="-53.34" width="0.1524" layer="91"/>
<wire x1="107.95" y1="-53.34" x2="107.95" y2="-54.61" width="0.1524" layer="91"/>
<pinref part="R54" gate="G$1" pin="2"/>
<wire x1="100.33" y1="-52.07" x2="100.33" y2="-53.34" width="0.1524" layer="91"/>
<pinref part="R56" gate="G$1" pin="1"/>
<wire x1="100.33" y1="-54.61" x2="100.33" y2="-53.34" width="0.1524" layer="91"/>
<junction x="100.33" y="-53.34"/>
<pinref part="R55" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$69" class="0">
<segment>
<pinref part="R56" gate="G$1" pin="2"/>
<pinref part="C40" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$70" class="0">
<segment>
<pinref part="R48" gate="G$1" pin="1"/>
<wire x1="118.11" y1="-53.34" x2="125.73" y2="-53.34" width="0.1524" layer="91"/>
<pinref part="R47" gate="G$1" pin="1"/>
<wire x1="125.73" y1="-53.34" x2="133.35" y2="-53.34" width="0.1524" layer="91"/>
<junction x="125.73" y="-53.34"/>
<pinref part="R46" gate="G$1" pin="2"/>
<junction x="133.35" y="-53.34"/>
<pinref part="R49" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$71" class="0">
<segment>
<pinref part="R48" gate="G$1" pin="2"/>
<pinref part="C38" gate="G$1" pin="1"/>
<wire x1="125.73" y1="-63.5" x2="125.73" y2="-69.85" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$72" class="0">
<segment>
<pinref part="C44" gate="G$1" pin="2"/>
<pinref part="C45" gate="G$1" pin="2"/>
<wire x1="121.92" y1="1.27" x2="134.62" y2="1.27" width="0.1524" layer="91"/>
<pinref part="C45/2" gate="G$1" pin="2"/>
<wire x1="134.62" y1="1.27" x2="147.32" y2="1.27" width="0.1524" layer="91"/>
<pinref part="C46" gate="G$1" pin="2"/>
<wire x1="147.32" y1="1.27" x2="156.21" y2="1.27" width="0.1524" layer="91"/>
<junction x="134.62" y="1.27"/>
<junction x="147.32" y="1.27"/>
<wire x1="147.32" y1="1.27" x2="147.32" y2="-83.82" width="0.1524" layer="91"/>
<pinref part="C29" gate="G$1" pin="-"/>
<pinref part="C30" gate="G$1" pin="-"/>
<wire x1="-15.24" y1="-39.37" x2="-6.35" y2="-39.37" width="0.1524" layer="91"/>
<pinref part="C31" gate="G$1" pin="2"/>
<wire x1="-6.35" y1="-39.37" x2="1.27" y2="-39.37" width="0.1524" layer="91"/>
<wire x1="-11.43" y1="-62.23" x2="1.27" y2="-62.23" width="0.1524" layer="91"/>
<wire x1="1.27" y1="-62.23" x2="1.27" y2="-52.07" width="0.1524" layer="91"/>
<junction x="-15.24" y="-39.37"/>
<junction x="-6.35" y="-39.37"/>
<junction x="1.27" y="-39.37"/>
<pinref part="C33" gate="G$1" pin="2"/>
<wire x1="1.27" y1="-52.07" x2="1.27" y2="-39.37" width="0.1524" layer="91"/>
<wire x1="8.89" y1="-52.07" x2="1.27" y2="-52.07" width="0.1524" layer="91"/>
<junction x="1.27" y="-52.07"/>
<pinref part="C28" gate="G$1" pin="2"/>
<wire x1="-2.54" y1="-10.16" x2="-2.54" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="-15.24" x2="15.24" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="15.24" y1="-15.24" x2="22.86" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="22.86" y1="-15.24" x2="22.86" y2="-52.07" width="0.1524" layer="91"/>
<wire x1="22.86" y1="-52.07" x2="8.89" y2="-52.07" width="0.1524" layer="91"/>
<junction x="8.89" y="-52.07"/>
<pinref part="R27" gate="G$1" pin="1"/>
<wire x1="15.24" y1="-7.62" x2="15.24" y2="-15.24" width="0.1524" layer="91"/>
<junction x="15.24" y="-15.24"/>
<pinref part="D25" gate="G$1" pin="A"/>
<wire x1="22.86" y1="-5.08" x2="22.86" y2="-15.24" width="0.1524" layer="91"/>
<junction x="22.86" y="-15.24"/>
<wire x1="1.27" y1="-62.23" x2="1.27" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="1.27" y1="-83.82" x2="92.71" y2="-83.82" width="0.1524" layer="91"/>
<junction x="1.27" y="-62.23"/>
<pinref part="D30" gate="G$1" pin="A"/>
<wire x1="92.71" y1="-68.58" x2="92.71" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="147.32" y1="-83.82" x2="92.71" y2="-83.82" width="0.1524" layer="91"/>
<junction x="92.71" y="-83.82"/>
<wire x1="147.32" y1="-83.82" x2="175.26" y2="-83.82" width="0.1524" layer="91"/>
<junction x="147.32" y="-83.82"/>
<pinref part="CS4" gate="G$1" pin="1"/>
<pinref part="L1" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<pinref part="R52" gate="G$1" pin="1"/>
<pinref part="P4" gate="G$1" pin="E"/>
</segment>
</net>
<net name="N$61" class="0">
<segment>
<pinref part="R51" gate="G$1" pin="2"/>
<pinref part="P4" gate="G$1" pin="S"/>
<wire x1="71.12" y1="-68.58" x2="66.04" y2="-68.58" width="0.1524" layer="91"/>
<wire x1="66.04" y1="-68.58" x2="60.96" y2="-68.58" width="0.1524" layer="91"/>
<junction x="66.04" y="-68.58"/>
<pinref part="R50" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$57" class="0">
<segment>
<pinref part="D26" gate="G$1" pin="A"/>
<pinref part="D27" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$60" class="0">
<segment>
<pinref part="P4" gate="G$1" pin="A"/>
<pinref part="R53" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$67" class="0">
<segment>
<pinref part="P2" gate="G$1" pin="E"/>
<pinref part="R47" gate="G$1" pin="2"/>
<wire x1="133.35" y1="-64.77" x2="133.35" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="P2" gate="G$1" pin="S"/>
<wire x1="138.43" y1="-69.85" x2="138.43" y2="-64.77" width="0.1524" layer="91"/>
<wire x1="138.43" y1="-64.77" x2="133.35" y2="-64.77" width="0.1524" layer="91"/>
<junction x="133.35" y="-64.77"/>
</segment>
</net>
<net name="N$77" class="0">
<segment>
<pinref part="IC9" gate="A" pin="ON2"/>
<pinref part="P5" gate="G$1" pin="A"/>
<wire x1="85.09" y1="35.56" x2="85.09" y2="36.83" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$78" class="0">
<segment>
<pinref part="P5" gate="G$1" pin="E"/>
<pinref part="IC9" gate="A" pin="ON1"/>
<wire x1="85.09" y1="46.99" x2="77.47" y2="46.99" width="0.1524" layer="91"/>
<wire x1="77.47" y1="46.99" x2="77.47" y2="40.64" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$80" class="0">
<segment>
<pinref part="IC9" gate="A" pin="+IN"/>
<wire x1="69.85" y1="35.56" x2="68.58" y2="35.56" width="0.1524" layer="91"/>
<pinref part="R34" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$83" class="0">
<segment>
<pinref part="P6" gate="G$1" pin="A"/>
<wire x1="93.98" y1="17.78" x2="93.98" y2="20.32" width="0.1524" layer="91"/>
<pinref part="R36" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$65" class="0">
<segment>
<pinref part="IC9" gate="A" pin="OUT"/>
<pinref part="P6" gate="G$1" pin="E"/>
<pinref part="P6" gate="G$1" pin="S"/>
<wire x1="99.06" y1="25.4" x2="99.06" y2="30.48" width="0.1524" layer="91"/>
<wire x1="99.06" y1="30.48" x2="93.98" y2="30.48" width="0.1524" layer="91"/>
<junction x="93.98" y="30.48"/>
<wire x1="93.98" y1="30.48" x2="93.98" y2="33.02" width="0.1524" layer="91"/>
<wire x1="93.98" y1="33.02" x2="97.79" y2="33.02" width="0.1524" layer="91"/>
<junction x="93.98" y="33.02"/>
<wire x1="93.98" y1="33.02" x2="85.09" y2="33.02" width="0.1524" layer="91"/>
<pinref part="R38" gate="G$1" pin="1"/>
<pinref part="C16" gate="G$1" pin="2"/>
<wire x1="93.98" y1="11.43" x2="99.06" y2="11.43" width="0.1524" layer="91"/>
<wire x1="99.06" y1="11.43" x2="99.06" y2="25.4" width="0.1524" layer="91"/>
<junction x="99.06" y="25.4"/>
</segment>
</net>
<net name="N$74" class="0">
<segment>
<pinref part="R39" gate="G$1" pin="2"/>
<pinref part="P8" gate="G$1" pin="E"/>
<wire x1="157.48" y1="59.69" x2="157.48" y2="62.23" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$75" class="0">
<segment>
<pinref part="P8" gate="G$1" pin="A"/>
<wire x1="152.4" y1="72.39" x2="157.48" y2="72.39" width="0.1524" layer="91"/>
<pinref part="C17" gate="G$1" pin="2"/>
<wire x1="166.37" y1="64.77" x2="166.37" y2="72.39" width="0.1524" layer="91"/>
<wire x1="166.37" y1="72.39" x2="157.48" y2="72.39" width="0.1524" layer="91"/>
<junction x="157.48" y="72.39"/>
<pinref part="P8" gate="G$1" pin="S"/>
<wire x1="152.4" y1="67.31" x2="152.4" y2="72.39" width="0.1524" layer="91"/>
<wire x1="152.4" y1="72.39" x2="143.51" y2="72.39" width="0.1524" layer="91"/>
<pinref part="IC10" gate="A" pin="OUT"/>
<junction x="152.4" y="72.39"/>
<pinref part="R42" gate="G$1" pin="1"/>
<wire x1="143.51" y1="72.39" x2="143.51" y2="64.77" width="0.1524" layer="91"/>
<junction x="143.51" y="72.39"/>
</segment>
</net>
<net name="N$76" class="0">
<segment>
<pinref part="IC10" gate="A" pin="+IN"/>
<pinref part="R41" gate="G$1" pin="2"/>
<wire x1="140.97" y1="48.26" x2="140.97" y2="49.53" width="0.1524" layer="91"/>
</segment>
</net>
<net name="FESZ-KI1" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RA0"/>
<wire x1="-99.06" y1="125.73" x2="-125.73" y2="125.73" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="125.73" x2="-125.73" y2="133.35" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="133.35" x2="-125.73" y2="140.97" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="140.97" x2="-125.73" y2="152.4" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="152.4" x2="93.98" y2="152.4" width="0.1524" layer="91"/>
<pinref part="C18" gate="G$1" pin="2"/>
<junction x="-125.73" y="133.35"/>
<pinref part="D4" gate="G$1" pin="C"/>
<wire x1="93.98" y1="152.4" x2="143.51" y2="152.4" width="0.1524" layer="91"/>
<wire x1="-128.27" y1="140.97" x2="-125.73" y2="140.97" width="0.1524" layer="91"/>
<junction x="-125.73" y="140.97"/>
<pinref part="R42" gate="G$1" pin="2"/>
<wire x1="143.51" y1="152.4" x2="143.51" y2="82.55" width="0.1524" layer="91"/>
<pinref part="TP4" gate="G$1" pin="1"/>
<wire x1="93.98" y1="142.24" x2="93.98" y2="152.4" width="0.1524" layer="91"/>
<junction x="93.98" y="152.4"/>
</segment>
</net>
<net name="FESZ-BE1" class="0">
<segment>
<pinref part="R75" gate="G$1" pin="2"/>
<wire x1="166.37" y1="-6.35" x2="166.37" y2="24.13" width="0.1524" layer="91"/>
<wire x1="166.37" y1="24.13" x2="146.05" y2="24.13" width="0.1524" layer="91"/>
<pinref part="IC10" gate="A" pin="-IN"/>
<pinref part="R39" gate="G$1" pin="1"/>
<wire x1="157.48" y1="49.53" x2="146.05" y2="49.53" width="0.1524" layer="91"/>
<pinref part="C17" gate="G$1" pin="1"/>
<wire x1="166.37" y1="57.15" x2="166.37" y2="49.53" width="0.1524" layer="91"/>
<wire x1="166.37" y1="49.53" x2="157.48" y2="49.53" width="0.1524" layer="91"/>
<junction x="157.48" y="49.53"/>
<junction x="146.05" y="49.53"/>
<wire x1="146.05" y1="24.13" x2="146.05" y2="49.53" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$81" class="0">
<segment>
<pinref part="P7" gate="G$1" pin="A"/>
<pinref part="IC10" gate="A" pin="ON2"/>
<wire x1="137.16" y1="64.77" x2="140.97" y2="64.77" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$85" class="0">
<segment>
<pinref part="IC10" gate="A" pin="ON1"/>
<wire x1="135.89" y1="57.15" x2="127" y2="57.15" width="0.1524" layer="91"/>
<pinref part="P7" gate="G$1" pin="E"/>
<wire x1="127" y1="57.15" x2="127" y2="64.77" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="IC7" gate="G$1" pin="OUT"/>
<wire x1="24.13" y1="119.38" x2="26.67" y2="119.38" width="0.1524" layer="91"/>
<wire x1="26.67" y1="119.38" x2="26.67" y2="124.46" width="0.1524" layer="91"/>
<pinref part="IC7" gate="G$1" pin="FEEDBK"/>
<wire x1="26.67" y1="124.46" x2="24.13" y2="124.46" width="0.1524" layer="91"/>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="26.67" y1="124.46" x2="30.48" y2="124.46" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="30.48" y1="124.46" x2="38.1" y2="124.46" width="0.1524" layer="91"/>
<junction x="26.67" y="124.46"/>
<junction x="30.48" y="124.46"/>
<junction x="38.1" y="124.46"/>
<pinref part="IC8" gate="G$1" pin="V_REF_A"/>
<wire x1="38.1" y1="124.46" x2="38.1" y2="95.25" width="0.1524" layer="91"/>
<wire x1="38.1" y1="95.25" x2="38.1" y2="85.09" width="0.1524" layer="91"/>
<wire x1="38.1" y1="85.09" x2="24.13" y2="85.09" width="0.1524" layer="91"/>
<pinref part="IC8" gate="G$1" pin="V_REF_B"/>
<wire x1="38.1" y1="85.09" x2="38.1" y2="74.93" width="0.1524" layer="91"/>
<wire x1="38.1" y1="74.93" x2="24.13" y2="74.93" width="0.1524" layer="91"/>
<junction x="38.1" y="85.09"/>
<pinref part="IC11" gate="G$1" pin="RA3"/>
<wire x1="-99.06" y1="110.49" x2="-105.41" y2="110.49" width="0.1524" layer="91"/>
<wire x1="-105.41" y1="110.49" x2="-105.41" y2="149.86" width="0.1524" layer="91"/>
<wire x1="-105.41" y1="149.86" x2="-16.51" y2="149.86" width="0.1524" layer="91"/>
<wire x1="-16.51" y1="149.86" x2="26.67" y2="149.86" width="0.1524" layer="91"/>
<wire x1="26.67" y1="149.86" x2="26.67" y2="124.46" width="0.1524" layer="91"/>
<pinref part="C36" gate="G$1" pin="2"/>
<junction x="-105.41" y="110.49"/>
<pinref part="C47" gate="G$1" pin="1"/>
<junction x="38.1" y="95.25"/>
<pinref part="TP3" gate="G$1" pin="1"/>
<wire x1="-16.51" y1="143.51" x2="-16.51" y2="149.86" width="0.1524" layer="91"/>
<junction x="-16.51" y="149.86"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="R2" gate="G$1" pin="2"/>
<pinref part="C5" gate="G$1" pin="2"/>
</segment>
</net>
<net name="OUT_A" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="V_OUT_A"/>
<wire x1="24.13" y1="90.17" x2="44.45" y2="90.17" width="0.1524" layer="91"/>
<wire x1="44.45" y1="90.17" x2="44.45" y2="110.49" width="0.1524" layer="91"/>
<pinref part="C35" gate="G$1" pin="1"/>
<wire x1="53.34" y1="110.49" x2="53.34" y2="109.22" width="0.1524" layer="91"/>
<pinref part="IC4" gate="B" pin="+IN"/>
<wire x1="62.23" y1="110.49" x2="53.34" y2="110.49" width="0.1524" layer="91"/>
<junction x="53.34" y="110.49"/>
<wire x1="44.45" y1="110.49" x2="53.34" y2="110.49" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="1"/>
<junction x="44.45" y="110.49"/>
</segment>
</net>
<net name="OUT_B" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="V_OUT_B"/>
<wire x1="24.13" y1="69.85" x2="44.45" y2="69.85" width="0.1524" layer="91"/>
<wire x1="44.45" y1="69.85" x2="44.45" y2="87.63" width="0.1524" layer="91"/>
<pinref part="IC4" gate="A" pin="+IN"/>
<pinref part="C37" gate="G$1" pin="1"/>
<wire x1="62.23" y1="87.63" x2="55.88" y2="87.63" width="0.1524" layer="91"/>
<wire x1="44.45" y1="87.63" x2="55.88" y2="87.63" width="0.1524" layer="91"/>
<junction x="55.88" y="87.63"/>
<pinref part="R3" gate="G$1" pin="2"/>
<junction x="44.45" y="69.85"/>
</segment>
</net>
<net name="CS" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="CS"/>
<wire x1="-6.35" y1="80.01" x2="-29.21" y2="80.01" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RC2"/>
<wire x1="-99.06" y1="69.85" x2="-105.41" y2="69.85" width="0.1524" layer="91"/>
<wire x1="-105.41" y1="69.85" x2="-105.41" y2="52.07" width="0.1524" layer="91"/>
<wire x1="-105.41" y1="52.07" x2="-29.21" y2="52.07" width="0.1524" layer="91"/>
<wire x1="-29.21" y1="52.07" x2="-29.21" y2="80.01" width="0.1524" layer="91"/>
</segment>
</net>
<net name="SCK" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="SCK"/>
<wire x1="-6.35" y1="74.93" x2="-31.75" y2="74.93" width="0.1524" layer="91"/>
<wire x1="-31.75" y1="74.93" x2="-31.75" y2="54.61" width="0.1524" layer="91"/>
<wire x1="-31.75" y1="54.61" x2="-99.06" y2="54.61" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RC3"/>
<wire x1="-99.06" y1="54.61" x2="-99.06" y2="64.77" width="0.1524" layer="91"/>
</segment>
</net>
<net name="SDI" class="0">
<segment>
<pinref part="IC8" gate="G$1" pin="SDI"/>
<pinref part="IC11" gate="G$1" pin="RC5"/>
<wire x1="-63.5" y1="69.85" x2="-6.35" y2="69.85" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="GND2" gate="1" pin="GND"/>
<pinref part="C9" gate="G$1" pin="2"/>
</segment>
<segment>
<pinref part="IC11" gate="G$1" pin="VSS2"/>
<pinref part="GND5" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="IC11" gate="G$1" pin="VSS"/>
<pinref part="GND18" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="GND19" gate="1" pin="GND"/>
<pinref part="HMI" gate="A" pin="2"/>
<wire x1="-46.99" y1="64.77" x2="-46.99" y2="59.69" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C34" gate="G$1" pin="2"/>
<pinref part="GND20" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C19" gate="G$1" pin="2"/>
<pinref part="GND21" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="ICSP" gate="A" pin="3"/>
<pinref part="GND22" gate="1" pin="GND"/>
<wire x1="-80.01" y1="143.51" x2="-80.01" y2="138.43" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="ENCODER" gate="A" pin="1"/>
<pinref part="GND23" gate="1" pin="GND"/>
<wire x1="-34.29" y1="105.41" x2="-39.37" y2="105.41" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C50" gate="G$1" pin="2"/>
<pinref part="C49" gate="G$1" pin="2"/>
<wire x1="-52.07" y1="87.63" x2="-46.99" y2="87.63" width="0.1524" layer="91"/>
<pinref part="C48" gate="G$1" pin="2"/>
<wire x1="-46.99" y1="87.63" x2="-41.91" y2="87.63" width="0.1524" layer="91"/>
<pinref part="GND24" gate="1" pin="GND"/>
<junction x="-46.99" y="87.63"/>
</segment>
<segment>
<pinref part="C51" gate="G$1" pin="2"/>
<pinref part="GND25" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="C52" gate="G$1" pin="-"/>
<pinref part="GND26" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="R29" gate="G$1" pin="1"/>
<pinref part="GND27" gate="1" pin="GND"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RC6"/>
<wire x1="-63.5" y1="74.93" x2="-60.96" y2="74.93" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="74.93" x2="-60.96" y2="72.39" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="72.39" x2="-52.07" y2="72.39" width="0.1524" layer="91"/>
<pinref part="HMI" gate="A" pin="4"/>
<wire x1="-52.07" y1="72.39" x2="-52.07" y2="59.69" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RC7"/>
<wire x1="-63.5" y1="80.01" x2="-58.42" y2="80.01" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="80.01" x2="-58.42" y2="74.93" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="74.93" x2="-49.53" y2="74.93" width="0.1524" layer="91"/>
<pinref part="HMI" gate="A" pin="3"/>
<wire x1="-49.53" y1="74.93" x2="-49.53" y2="59.69" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RA7_OSC1"/>
<pinref part="Q1" gate="G$1" pin="2"/>
<wire x1="-99.06" y1="90.17" x2="-102.87" y2="90.17" width="0.1524" layer="91"/>
<pinref part="C34" gate="G$1" pin="1"/>
<wire x1="-102.87" y1="90.17" x2="-105.41" y2="90.17" width="0.1524" layer="91"/>
<junction x="-102.87" y="90.17"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RA6_OSC2"/>
<pinref part="Q1" gate="G$1" pin="1"/>
<wire x1="-99.06" y1="85.09" x2="-102.87" y2="85.09" width="0.1524" layer="91"/>
<pinref part="C19" gate="G$1" pin="1"/>
<wire x1="-102.87" y1="85.09" x2="-105.41" y2="85.09" width="0.1524" layer="91"/>
<junction x="-102.87" y="85.09"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="MCLR"/>
<wire x1="-99.06" y1="130.81" x2="-107.95" y2="130.81" width="0.1524" layer="91"/>
<wire x1="-99.06" y1="130.81" x2="-99.06" y2="138.43" width="0.1524" layer="91"/>
<pinref part="ICSP" gate="A" pin="1"/>
<wire x1="-99.06" y1="138.43" x2="-85.09" y2="138.43" width="0.1524" layer="91"/>
<wire x1="-85.09" y1="138.43" x2="-85.09" y2="143.51" width="0.1524" layer="91"/>
<junction x="-99.06" y="130.81"/>
<pinref part="R5" gate="G$1" pin="2"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="ICSP" gate="A" pin="4"/>
<wire x1="-77.47" y1="143.51" x2="-77.47" y2="135.89" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RB7"/>
<wire x1="-77.47" y1="135.89" x2="-63.5" y2="135.89" width="0.1524" layer="91"/>
<wire x1="-63.5" y1="135.89" x2="-63.5" y2="130.81" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="ICSP" gate="A" pin="5"/>
<wire x1="-74.93" y1="143.51" x2="-74.93" y2="138.43" width="0.1524" layer="91"/>
<wire x1="-74.93" y1="138.43" x2="-60.96" y2="138.43" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="138.43" x2="-60.96" y2="125.73" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RB6"/>
<wire x1="-60.96" y1="125.73" x2="-63.5" y2="125.73" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RB0"/>
<wire x1="-63.5" y1="95.25" x2="-55.88" y2="95.25" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="95.25" x2="-55.88" y2="97.79" width="0.1524" layer="91"/>
<pinref part="ENCODER" gate="A" pin="4"/>
<wire x1="-55.88" y1="97.79" x2="-46.99" y2="97.79" width="0.1524" layer="91"/>
<wire x1="-46.99" y1="97.79" x2="-34.29" y2="97.79" width="0.1524" layer="91"/>
<wire x1="-46.99" y1="105.41" x2="-46.99" y2="97.79" width="0.1524" layer="91"/>
<junction x="-46.99" y="97.79"/>
<pinref part="C49" gate="G$1" pin="1"/>
<wire x1="-46.99" y1="95.25" x2="-46.99" y2="97.79" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RB1"/>
<pinref part="ENCODER" gate="A" pin="3"/>
<wire x1="-63.5" y1="100.33" x2="-50.8" y2="100.33" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="100.33" x2="-41.91" y2="100.33" width="0.1524" layer="91"/>
<wire x1="-41.91" y1="100.33" x2="-34.29" y2="100.33" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="105.41" x2="-50.8" y2="100.33" width="0.1524" layer="91"/>
<junction x="-50.8" y="100.33"/>
<pinref part="C48" gate="G$1" pin="1"/>
<wire x1="-41.91" y1="95.25" x2="-41.91" y2="100.33" width="0.1524" layer="91"/>
<junction x="-41.91" y="100.33"/>
<pinref part="R7" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="IC11" gate="G$1" pin="RB2"/>
<wire x1="-63.5" y1="105.41" x2="-55.88" y2="105.41" width="0.1524" layer="91"/>
<wire x1="-55.88" y1="105.41" x2="-55.88" y2="102.87" width="0.1524" layer="91"/>
<pinref part="ENCODER" gate="A" pin="2"/>
<wire x1="-55.88" y1="102.87" x2="-52.07" y2="102.87" width="0.1524" layer="91"/>
<pinref part="C50" gate="G$1" pin="1"/>
<wire x1="-52.07" y1="102.87" x2="-34.29" y2="102.87" width="0.1524" layer="91"/>
<wire x1="-52.07" y1="95.25" x2="-52.07" y2="102.87" width="0.1524" layer="91"/>
<junction x="-52.07" y="102.87"/>
<pinref part="R6" gate="G$1" pin="1"/>
<junction x="-55.88" y="105.41"/>
</segment>
</net>
<net name="N$40" class="0">
<segment>
<pinref part="IC6" gate="B" pin="OUT"/>
<pinref part="R72" gate="G$1" pin="1"/>
</segment>
</net>
<net name="N$51" class="0">
<segment>
<pinref part="R72" gate="G$1" pin="2"/>
<pinref part="D1" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$53" class="0">
<segment>
<pinref part="D1" gate="G$1" pin="C"/>
<pinref part="D2" gate="G$1" pin="C"/>
<wire x1="64.77" y1="-90.17" x2="69.85" y2="-90.17" width="0.1524" layer="91"/>
<wire x1="69.85" y1="-90.17" x2="186.69" y2="-90.17" width="0.1524" layer="91"/>
<wire x1="186.69" y1="-90.17" x2="186.69" y2="154.94" width="0.1524" layer="91"/>
<wire x1="186.69" y1="154.94" x2="-58.42" y2="154.94" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RB3"/>
<wire x1="-58.42" y1="154.94" x2="-58.42" y2="137.16" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="137.16" x2="-58.42" y2="127" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="127" x2="-58.42" y2="110.49" width="0.1524" layer="91"/>
<wire x1="-58.42" y1="110.49" x2="-63.5" y2="110.49" width="0.1524" layer="91"/>
<pinref part="C51" gate="G$1" pin="1"/>
<junction x="-58.42" y="127"/>
<junction x="69.85" y="-90.17"/>
<pinref part="R29" gate="G$1" pin="2"/>
<junction x="-58.42" y="137.16"/>
</segment>
</net>
<net name="N$64" class="0">
<segment>
<pinref part="R70" gate="G$1" pin="2"/>
<pinref part="T15" gate="G$1" pin="S"/>
<wire x1="39.37" y1="2.54" x2="48.26" y2="2.54" width="0.1524" layer="91"/>
<wire x1="48.26" y1="2.54" x2="48.26" y2="8.89" width="0.1524" layer="91"/>
<wire x1="48.26" y1="8.89" x2="57.15" y2="8.89" width="0.1524" layer="91"/>
<junction x="48.26" y="8.89"/>
<wire x1="48.26" y1="29.21" x2="48.26" y2="8.89" width="0.1524" layer="91"/>
<pinref part="D24" gate="G$1" pin="A"/>
<wire x1="7.62" y1="29.21" x2="48.26" y2="29.21" width="0.1524" layer="91"/>
<pinref part="RS5" gate="G$1" pin="1"/>
<wire x1="66.04" y1="8.89" x2="57.15" y2="8.89" width="0.1524" layer="91"/>
<junction x="57.15" y="8.89"/>
</segment>
</net>
<net name="N$45" class="0">
<segment>
<pinref part="R69" gate="G$1" pin="1"/>
<pinref part="R68" gate="G$1" pin="2"/>
<wire x1="57.15" y1="-25.4" x2="62.23" y2="-25.4" width="0.1524" layer="91"/>
<wire x1="62.23" y1="-25.4" x2="62.23" y2="-29.21" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$88" class="0">
<segment>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="35.56" y1="-6.35" x2="38.1" y2="-6.35" width="0.1524" layer="91"/>
<wire x1="38.1" y1="-6.35" x2="38.1" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="T15" gate="G$1" pin="G"/>
<wire x1="38.1" y1="-7.62" x2="39.37" y2="-7.62" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$87" class="0">
<segment>
<pinref part="R69" gate="G$1" pin="2"/>
<wire x1="62.23" y1="-15.24" x2="57.15" y2="-15.24" width="0.1524" layer="91"/>
<junction x="57.15" y="-15.24"/>
<pinref part="T16" gate="G$1" pin="E"/>
<wire x1="54.61" y1="-15.24" x2="57.15" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="R28" gate="G$1" pin="2"/>
<wire x1="62.23" y1="-15.24" x2="62.23" y2="-12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$89" class="0">
<segment>
<pinref part="CS3" gate="G$1" pin="1"/>
<pinref part="C46" gate="G$1" pin="1"/>
<junction x="156.21" y="8.89"/>
<wire x1="156.21" y1="8.89" x2="179.07" y2="8.89" width="0.1524" layer="91"/>
<pinref part="C45/2" gate="G$1" pin="1"/>
<wire x1="147.32" y1="8.89" x2="156.21" y2="8.89" width="0.1524" layer="91"/>
<junction x="147.32" y="8.89"/>
<pinref part="C45" gate="G$1" pin="1"/>
<wire x1="134.62" y1="8.89" x2="147.32" y2="8.89" width="0.1524" layer="91"/>
<junction x="134.62" y="8.89"/>
<pinref part="C44" gate="G$1" pin="1"/>
<wire x1="121.92" y1="8.89" x2="134.62" y2="8.89" width="0.1524" layer="91"/>
<pinref part="RS5" gate="G$1" pin="2"/>
<wire x1="78.74" y1="8.89" x2="121.92" y2="8.89" width="0.1524" layer="91"/>
<junction x="121.92" y="8.89"/>
</segment>
</net>
<net name="N$90" class="0">
<segment>
<wire x1="181.61" y1="8.89" x2="185.42" y2="8.89" width="0.1524" layer="91"/>
<wire x1="185.42" y1="8.89" x2="185.42" y2="0" width="0.1524" layer="91"/>
<wire x1="185.42" y1="0" x2="181.61" y2="0" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$91" class="0">
<segment>
<wire x1="177.8" y1="-74.93" x2="181.61" y2="-74.93" width="0.1524" layer="91"/>
<wire x1="181.61" y1="-74.93" x2="181.61" y2="-83.82" width="0.1524" layer="91"/>
<wire x1="181.61" y1="-83.82" x2="177.8" y2="-83.82" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$92" class="0">
<segment>
<pinref part="R75" gate="G$1" pin="1"/>
<wire x1="166.37" y1="-16.51" x2="166.37" y2="-74.93" width="0.1524" layer="91"/>
<wire x1="166.37" y1="-74.93" x2="166.37" y2="-77.47" width="0.1524" layer="91"/>
<wire x1="133.35" y1="-77.47" x2="166.37" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="P2" gate="G$1" pin="A"/>
<wire x1="133.35" y1="-74.93" x2="133.35" y2="-77.47" width="0.1524" layer="91"/>
<junction x="133.35" y="-77.47"/>
<pinref part="C38" gate="G$1" pin="2"/>
<junction x="125.73" y="-77.47"/>
<wire x1="125.73" y1="-77.47" x2="133.35" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="C40" gate="G$1" pin="2"/>
<wire x1="100.33" y1="-72.39" x2="100.33" y2="-77.47" width="0.1524" layer="91"/>
<wire x1="100.33" y1="-77.47" x2="125.73" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="JP2" gate="G$1" pin="1"/>
<wire x1="175.26" y1="-74.93" x2="166.37" y2="-74.93" width="0.1524" layer="91"/>
<junction x="166.37" y="-74.93"/>
</segment>
</net>
<net name="N$82" class="0">
<segment>
<pinref part="IC9" gate="A" pin="-IN"/>
<pinref part="R35" gate="G$1" pin="2"/>
<wire x1="68.58" y1="30.48" x2="69.85" y2="30.48" width="0.1524" layer="91"/>
<pinref part="C16" gate="G$1" pin="1"/>
<wire x1="86.36" y1="11.43" x2="83.82" y2="11.43" width="0.1524" layer="91"/>
<wire x1="83.82" y1="11.43" x2="83.82" y2="17.78" width="0.1524" layer="91"/>
<pinref part="R36" gate="G$1" pin="1"/>
<wire x1="83.82" y1="17.78" x2="69.85" y2="17.78" width="0.1524" layer="91"/>
<wire x1="69.85" y1="17.78" x2="69.85" y2="30.48" width="0.1524" layer="91"/>
<junction x="69.85" y="30.48"/>
<junction x="83.82" y="17.78"/>
</segment>
</net>
<net name="N$94" class="0">
<segment>
<pinref part="R54" gate="G$1" pin="1"/>
<pinref part="P1" gate="G$1" pin="A"/>
<wire x1="100.33" y1="-40.64" x2="100.33" y2="-41.91" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$68" class="0">
<segment>
<wire x1="53.34" y1="49.53" x2="53.34" y2="46.99" width="0.1524" layer="91"/>
<wire x1="53.34" y1="46.99" x2="-125.73" y2="46.99" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="46.99" x2="-125.73" y2="109.22" width="0.1524" layer="91"/>
<pinref part="IC11" gate="G$1" pin="RA1"/>
<wire x1="-125.73" y1="109.22" x2="-125.73" y2="120.65" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="120.65" x2="-99.06" y2="120.65" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="2"/>
<junction x="-125.73" y="120.65"/>
<pinref part="D3" gate="G$1" pin="C"/>
<junction x="-125.73" y="109.22"/>
<pinref part="R38" gate="G$1" pin="2"/>
<wire x1="53.34" y1="49.53" x2="93.98" y2="49.53" width="0.1524" layer="91"/>
<wire x1="93.98" y1="49.53" x2="97.79" y2="49.53" width="0.1524" layer="91"/>
<wire x1="97.79" y1="49.53" x2="97.79" y2="43.18" width="0.1524" layer="91"/>
<pinref part="TP5" gate="G$1" pin="1"/>
<wire x1="93.98" y1="55.88" x2="93.98" y2="49.53" width="0.1524" layer="91"/>
<junction x="93.98" y="49.53"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
