<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.025" unitdist="inch" unit="mm" style="lines" multiple="1" display="no" altdistance="6.25" altunitdist="mil" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="no" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="no" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="no" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="no" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="no" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="no" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="no" active="yes"/>
<layer number="108" name="fp8" color="7" fill="1" visible="no" active="yes"/>
<layer number="109" name="fp9" color="7" fill="1" visible="no" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="no" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="no" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="no" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="no" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="no" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="no" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="no" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="no" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="no" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="no" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="no" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="no" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="no" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="no" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="no" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<wire x1="-87.63" y1="2.54" x2="12.045" y2="2.54" width="0" layer="20"/>
<wire x1="12.045" y1="2.54" x2="12.045" y2="101.905" width="0" layer="20"/>
<wire x1="12.045" y1="101.905" x2="-87.63" y2="101.905" width="0" layer="20"/>
<wire x1="-87.63" y1="101.905" x2="-87.63" y2="2.54" width="0" layer="20"/>
<rectangle x1="165.735" y1="41.275" x2="174.625" y2="50.165" layer="1"/>
<rectangle x1="-66.675" y1="34.29" x2="-60.96" y2="40.64" layer="1" rot="R180"/>
<rectangle x1="-66.675" y1="42.545" x2="-60.96" y2="48.895" layer="1" rot="R180"/>
<rectangle x1="-66.675" y1="50.8" x2="-60.96" y2="57.15" layer="1" rot="R180"/>
<rectangle x1="-66.675" y1="59.055" x2="-60.96" y2="65.405" layer="1"/>
<text x="-53.34" y="55.245" size="1.9304" layer="1" rot="R180">2
1
4
3</text>
<text x="6.35" y="75.565" size="2.54" layer="1" rot="R180">1</text>
<text x="-57.15" y="95.885" size="2.54" layer="1" rot="R180">2</text>
<text x="-81.28" y="29.845" size="2.54" layer="1" rot="R180">3</text>
<text x="-2.54" y="17.145" size="2.54" layer="1" rot="R180">4</text>
<rectangle x1="-23.495" y1="58.42" x2="-20.955" y2="63.5" layer="1" rot="R180"/>
<rectangle x1="-27.305" y1="58.42" x2="-24.765" y2="63.5" layer="1" rot="R180"/>
<rectangle x1="-31.115" y1="58.42" x2="-28.575" y2="63.5" layer="1" rot="R180"/>
<rectangle x1="-34.925" y1="58.42" x2="-32.385" y2="63.5" layer="1" rot="R180"/>
<rectangle x1="-63.5" y1="91.44" x2="-60.96" y2="96.52" layer="1" rot="R180"/>
<rectangle x1="-78.74" y1="25.4" x2="-76.2" y2="30.48" layer="1" rot="R90"/>
<rectangle x1="-13.97" y1="8.255" x2="-11.43" y2="13.335" layer="1"/>
<text x="-20.955" y="67.31" size="2.54" layer="1" rot="R180">4  3  2  1</text>
<rectangle x1="-45.085" y1="44.45" x2="-38.735" y2="53.34" layer="1"/>
<text x="-15.875" y="10.16" size="2.54" layer="1" rot="R180">3 2 1 4</text>
<rectangle x1="0.635" y1="74.93" x2="3.175" y2="80.01" layer="1" rot="R270"/>
<text x="119.38" y="5.08" size="2.54" layer="1" rot="R180">3 2 1 4 +4.2V</text>
<text x="169.545" y="16.51" size="3.4" layer="1">1
2
3
4</text>
<text x="42.545" y="88.9" size="3.4" layer="1">+</text>
<text x="37.465" y="89.535" size="3.4" layer="1">-</text>
<text x="109.22" y="52.07" size="1.9304" layer="1" rot="R180">2
1
4
3</text>
<text x="147.955" y="60.96" size="1.6764" layer="1" rot="R180">4 3 2 1
bazisok</text>
<rectangle x1="48.10125" y1="94.77375" x2="61.11875" y2="100.965" layer="1" rot="R180"/>
<rectangle x1="126.365" y1="41.91" x2="128.27" y2="43.815" layer="1" rot="R180"/>
<rectangle x1="125.73" y1="36.195" x2="127.635" y2="38.1" layer="1" rot="R180"/>
<rectangle x1="113.665" y1="55.88" x2="115.57" y2="57.785" layer="1" rot="R180"/>
<rectangle x1="104.775" y1="68.58" x2="106.68" y2="70.485" layer="1" rot="R180"/>
<rectangle x1="58.42" y1="52.705" x2="60.325" y2="54.61" layer="1" rot="R180"/>
<rectangle x1="58.42" y1="49.53" x2="60.325" y2="51.435" layer="1" rot="R180"/>
<rectangle x1="69.5325" y1="39.6875" x2="71.4375" y2="41.5925" layer="1" rot="R180"/>
<rectangle x1="68.2625" y1="42.8625" x2="70.1675" y2="44.7675" layer="1" rot="R180"/>
<rectangle x1="134.9375" y1="58.7375" x2="136.8425" y2="60.6425" layer="1" rot="R180"/>
<rectangle x1="152.7175" y1="63.1825" x2="154.6225" y2="65.0875" layer="1" rot="R180"/>
<rectangle x1="152.7175" y1="68.2625" x2="154.6225" y2="70.1675" layer="1" rot="R180"/>
<rectangle x1="152.7175" y1="72.7075" x2="154.6225" y2="74.6125" layer="1" rot="R180"/>
<rectangle x1="65.7225" y1="40.3225" x2="67.6275" y2="42.2275" layer="1" rot="R180"/>
<rectangle x1="62.5475" y1="39.6875" x2="64.4525" y2="41.5925" layer="1" rot="R180"/>
<rectangle x1="53.975" y1="52.07" x2="55.88" y2="53.975" layer="1" rot="R180"/>
<rectangle x1="48.26" y1="59.69" x2="50.165" y2="61.595" layer="1" rot="R180"/>
<rectangle x1="118.11" y1="33.02" x2="120.015" y2="34.925" layer="1" rot="R180"/>
<rectangle x1="111.76" y1="33.02" x2="113.665" y2="34.925" layer="1" rot="R180"/>
<rectangle x1="135.89" y1="39.37" x2="140.335" y2="41.275" layer="1" rot="R180"/>
<rectangle x1="141.605" y1="65.405" x2="146.05" y2="67.31" layer="1" rot="R180"/>
<rectangle x1="99.06" y1="75.565" x2="103.505" y2="77.47" layer="1" rot="R180"/>
<rectangle x1="124.93625" y1="66.3575" x2="126.84125" y2="68.2625" layer="1" rot="R180"/>
<rectangle x1="43.18" y1="83.02625" x2="45.085" y2="84.93125" layer="1" rot="R180"/>
<rectangle x1="151.765" y1="42.545" x2="153.67" y2="44.45" layer="1" rot="R180"/>
<rectangle x1="109.855" y1="60.325" x2="111.76" y2="62.23" layer="1" rot="R180"/>
<text x="107.95" y="60.325" size="1.4224" layer="1">G</text>
<text x="146.685" y="66.04" size="1.4224" layer="1">G</text>
<text x="46.355" y="97.79" size="1.4224" layer="1">G</text>
<text x="22.86" y="97.79" size="1.4224" layer="1">G</text>
<text x="24.765" y="73.025" size="1.4224" layer="1">G</text>
<text x="59.055" y="38.1" size="1.4224" layer="1">G</text>
<text x="50.165" y="53.975" size="1.4224" layer="1">G</text>
<text x="42.545" y="77.47" size="1.4224" layer="1">G</text>
<text x="173.355" y="57.15" size="1.9304" layer="1">1
2
3
4</text>
<text x="152.4" y="47.625" size="1.4224" layer="1">G</text>
<text x="133.985" y="39.37" size="1.4224" layer="1">G</text>
<text x="93.98" y="27.305" size="1.4224" layer="1">G</text>
<rectangle x1="95.885" y1="27.94" x2="97.79" y2="29.845" layer="1" rot="R180"/>
<text x="73.025" y="24.765" size="1.4224" layer="1">G</text>
<text x="28.575" y="31.75" size="1.4224" layer="1">G</text>
<text x="25.4" y="46.355" size="1.4224" layer="1">G</text>
<rectangle x1="81.28" y1="48.895" x2="83.185" y2="50.8" layer="1" rot="R180"/>
<text x="118.745" y="47.625" size="1.9304" layer="1">D</text>
<text x="79.375" y="50.8" size="1.9304" layer="1">D</text>
<text x="88.9" y="62.865" size="1.9304" layer="1" rot="R180">5V</text>
<text x="75.565" y="15.875" size="1.9304" layer="1" rot="R180">5V</text>
<text x="52.07" y="63.5" size="1.9304" layer="1">5V</text>
<text x="46.355" y="59.69" size="1.9304" layer="1">1</text>
<text x="150.495" y="72.39" size="1.9304" layer="1">1</text>
<text x="150.495" y="68.58" size="1.9304" layer="1">2</text>
<text x="52.07" y="50.165" size="1.9304" layer="1">2</text>
<text x="151.13" y="63.5" size="1.9304" layer="1">3</text>
<text x="62.23" y="41.91" size="1.9304" layer="1">3</text>
<text x="135.255" y="60.96" size="1.9304" layer="1">4</text>
<text x="66.675" y="44.45" size="1.9304" layer="1">4</text>
<text x="79.375" y="40.005" size="1.9304" layer="1">T4</text>
<text x="75.565" y="40.005" size="1.9304" layer="1">T3</text>
<text x="109.855" y="55.88" size="1.9304" layer="1">T4</text>
<text x="100.965" y="68.58" size="1.9304" layer="1">T3</text>
<text x="128.5875" y="40.005" size="1.9304" layer="1">T1</text>
<text x="60.96" y="52.705" size="1.9304" layer="1">T1</text>
<text x="64.77" y="49.53" size="1.9304" layer="1">T2</text>
<text x="127.15875" y="37.1475" size="1.9304" layer="1">T2</text>
<text x="126.84125" y="66.3575" size="1.4224" layer="1">12</text>
<text x="118.11" y="31.115" size="1.4224" layer="1">12</text>
<text x="111.76" y="31.115" size="1.4224" layer="1">12</text>
<text x="40.64" y="83.185" size="1.4224" layer="1">12</text>
<text x="27.305" y="99.695" size="2.54" layer="1">-</text>
<text x="31.75" y="92.075" size="3.4" layer="1">+</text>
<text x="22.86" y="86.36" size="2.54" layer="1">-</text>
<text x="27.94" y="86.995" size="2.54" layer="1">-</text>
<text x="18.415" y="4.445" size="2.8" layer="1">kovidivi
2017.01.22
Lithium-ion cella teszter</text>
<text x="57.785" y="10.16" size="2.54" layer="1" align="bottom-right">+</text>
<rectangle x1="59.055" y1="83.02625" x2="60.96" y2="84.93125" layer="1" rot="R180"/>
<rectangle x1="42.38625" y1="75.565" x2="44.29125" y2="77.47" layer="1" rot="R180"/>
<rectangle x1="144.4625" y1="86.0425" x2="146.3675" y2="87.9475" layer="1" rot="R180"/>
<rectangle x1="78.105" y1="74.13625" x2="80.01" y2="76.04125" layer="1" rot="R180"/>
<rectangle x1="92.075" y1="67.15125" x2="93.98" y2="69.05625" layer="1" rot="R180"/>
<rectangle x1="62.865" y1="88.9" x2="78.74" y2="100.33" layer="1"/>
<rectangle x1="74.93" y1="74.77125" x2="76.835" y2="76.67625" layer="1" rot="R180"/>
<rectangle x1="81.915" y1="77.94625" x2="83.82" y2="79.85125" layer="1" rot="R180"/>
<rectangle x1="92.71" y1="77.31125" x2="94.615" y2="79.21625" layer="1" rot="R180"/>
<rectangle x1="53.34" y1="69.69125" x2="55.245" y2="71.59625" layer="1" rot="R180"/>
<rectangle x1="57.15" y1="70.96125" x2="59.055" y2="72.86625" layer="1" rot="R180"/>
<text x="68.58" y="81.915" size="2.1844" layer="1">+</text>
<text x="68.58" y="79.375" size="3.81" layer="1">-</text>
<text x="67.945" y="84.455" size="2.1844" layer="1">fan</text>
<rectangle x1="88.9" y1="35.56" x2="90.805" y2="37.465" layer="1" rot="R180"/>
<rectangle x1="120.65" y1="47.625" x2="122.555" y2="49.53" layer="1" rot="R180"/>
<rectangle x1="125.095" y1="47.625" x2="127" y2="49.53" layer="1" rot="R180"/>
<rectangle x1="-86.995" y1="34.925" x2="-76.835" y2="41.275" layer="1"/>
<rectangle x1="-86.995" y1="42.545" x2="-76.835" y2="48.895" layer="1"/>
<rectangle x1="-86.995" y1="50.8" x2="-76.835" y2="57.15" layer="1"/>
<rectangle x1="-86.995" y1="58.42" x2="-76.835" y2="64.77" layer="1"/>
<rectangle x1="81.12125" y1="48.895" x2="83.02625" y2="50.8" layer="16"/>
<rectangle x1="68.42125" y1="42.545" x2="70.32625" y2="44.45" layer="16"/>
<rectangle x1="69.37375" y1="39.6875" x2="71.27875" y2="41.5925" layer="16"/>
<rectangle x1="65.7225" y1="40.3225" x2="67.6275" y2="42.2275" layer="16"/>
<rectangle x1="62.5475" y1="39.84625" x2="64.4525" y2="41.75125" layer="16"/>
<rectangle x1="58.42" y1="49.53" x2="60.325" y2="51.435" layer="16"/>
<rectangle x1="58.26125" y1="52.86375" x2="60.16625" y2="54.76875" layer="16"/>
<rectangle x1="53.34" y1="52.07" x2="55.245" y2="53.975" layer="16"/>
<rectangle x1="48.10125" y1="59.69" x2="50.00625" y2="61.595" layer="16"/>
<rectangle x1="53.18125" y1="69.69125" x2="55.08625" y2="71.59625" layer="16"/>
<rectangle x1="57.30875" y1="70.64375" x2="59.21375" y2="72.54875" layer="16"/>
<rectangle x1="42.38625" y1="75.40625" x2="44.29125" y2="77.31125" layer="16"/>
<rectangle x1="43.18" y1="83.02625" x2="45.085" y2="84.93125" layer="16"/>
<rectangle x1="59.055" y1="83.02625" x2="60.96" y2="84.93125" layer="16"/>
<rectangle x1="74.93" y1="74.77125" x2="76.835" y2="76.67625" layer="16"/>
<rectangle x1="78.105" y1="74.13625" x2="80.01" y2="76.04125" layer="16"/>
<rectangle x1="81.75625" y1="77.94625" x2="83.66125" y2="79.85125" layer="16"/>
<rectangle x1="92.86875" y1="77.31125" x2="94.77375" y2="79.21625" layer="16"/>
<rectangle x1="92.075" y1="67.46875" x2="93.98" y2="69.37375" layer="16"/>
<rectangle x1="113.665" y1="55.88" x2="115.57" y2="57.785" layer="16"/>
<rectangle x1="109.855" y1="60.96" x2="111.76" y2="62.865" layer="16"/>
<rectangle x1="104.775" y1="67.945" x2="106.68" y2="69.85" layer="16"/>
<rectangle x1="124.93625" y1="66.04" x2="126.84125" y2="67.945" layer="16"/>
<rectangle x1="135.09625" y1="58.7375" x2="137.00125" y2="60.6425" layer="16"/>
<rectangle x1="143.1925" y1="65.405" x2="145.0975" y2="67.31" layer="16"/>
<rectangle x1="124.93625" y1="47.625" x2="126.84125" y2="49.53" layer="16"/>
<rectangle x1="120.65" y1="47.625" x2="122.555" y2="49.53" layer="16"/>
<rectangle x1="126.20625" y1="41.91" x2="128.11125" y2="43.815" layer="16"/>
<rectangle x1="135.73125" y1="39.37" x2="137.63625" y2="41.275" layer="16"/>
<rectangle x1="125.73" y1="36.195" x2="127.635" y2="38.1" layer="16"/>
<rectangle x1="117.95125" y1="32.385" x2="119.85625" y2="34.29" layer="16"/>
<rectangle x1="111.60125" y1="32.22625" x2="113.50625" y2="34.13125" layer="16"/>
<rectangle x1="96.04375" y1="27.46375" x2="97.94875" y2="29.36875" layer="16"/>
<rectangle x1="89.05875" y1="35.8775" x2="90.96375" y2="37.7825" layer="16"/>
<rectangle x1="91.91625" y1="14.12875" x2="93.82125" y2="16.03375" layer="1" rot="R180"/>
<rectangle x1="94.13875" y1="17.145" x2="96.04375" y2="19.05" layer="1" rot="R180"/>
<rectangle x1="96.67875" y1="14.12875" x2="98.58375" y2="16.03375" layer="1" rot="R180"/>
<rectangle x1="99.3775" y1="13.49375" x2="101.2825" y2="15.39875" layer="1" rot="R180"/>
<rectangle x1="102.07625" y1="17.62125" x2="103.98125" y2="19.52625" layer="1" rot="R180"/>
<rectangle x1="104.29875" y1="13.97" x2="106.20375" y2="15.875" layer="1" rot="R180"/>
<rectangle x1="106.9975" y1="13.49375" x2="108.9025" y2="15.39875" layer="1" rot="R180"/>
<rectangle x1="109.855" y1="17.145" x2="111.76" y2="19.05" layer="1" rot="R180"/>
<rectangle x1="111.91875" y1="14.12875" x2="113.82375" y2="16.03375" layer="1" rot="R180"/>
<rectangle x1="114.6175" y1="13.49375" x2="116.5225" y2="15.39875" layer="1" rot="R180"/>
<rectangle x1="117.475" y1="17.145" x2="119.38" y2="19.05" layer="1" rot="R180"/>
<rectangle x1="119.6975" y1="14.12875" x2="121.6025" y2="16.03375" layer="1" rot="R180"/>
<rectangle x1="151.765" y1="42.545" x2="153.67" y2="44.45" layer="16" rot="R270"/>
<rectangle x1="152.55875" y1="63.1825" x2="154.46375" y2="65.0875" layer="16" rot="R270"/>
<rectangle x1="152.7175" y1="68.2625" x2="154.6225" y2="70.1675" layer="16" rot="R270"/>
<rectangle x1="153.19375" y1="72.23125" x2="155.09875" y2="74.13625" layer="16" rot="R270"/>
<rectangle x1="144.4625" y1="85.88375" x2="146.3675" y2="87.78875" layer="16" rot="R270"/>
<rectangle x1="138.27125" y1="89.69375" x2="140.17625" y2="91.59875" layer="1" rot="R180"/>
<rectangle x1="136.525" y1="86.36" x2="138.43" y2="88.265" layer="1" rot="R180"/>
<rectangle x1="100.33" y1="75.565" x2="102.235" y2="77.47" layer="16"/>
<rectangle x1="54.2925" y1="96.67875" x2="56.1975" y2="98.58375" layer="16"/>
<text x="17.78" y="17.145" size="1.778" layer="1">RX
TX
GND
5V
RST</text>
<rectangle x1="22.38375" y1="27.6225" x2="26.035" y2="29.36875" layer="1"/>
<rectangle x1="22.38375" y1="24.92375" x2="26.035" y2="26.67" layer="1"/>
<rectangle x1="24.13" y1="22.38375" x2="27.78125" y2="24.13" layer="1"/>
<rectangle x1="24.13" y1="19.685" x2="27.78125" y2="21.43125" layer="1"/>
<rectangle x1="24.13" y1="17.145" x2="27.78125" y2="18.89125" layer="1"/>
</plain>
<libraries>
<library name="My_Eagle_library">
<description>Maxim DS1307 (DIP-8)
&lt;br&gt;
&lt;a href="http://jayakody2000lk.wordpress.com"&gt;jayakody2000lk.wordpress.com&lt;/a&gt;</description>
<packages>
<package name="ATMEGA328">
<wire x1="3.505" y1="3.505" x2="3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="3.505" y1="-3.505" x2="-3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="-3.505" y1="-3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="3.505" y2="3.505" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<circle x="-2.7432" y="2.7432" radius="0.3592" width="0.1524" layer="21"/>
<text x="-2.7686" y="5.08" size="0.8128" layer="25">&gt;NAME</text>
<text x="-3.0226" y="-1.27" size="0.8128" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5466" y1="2.5714" x2="-3.556" y2="3.0286" layer="51"/>
<rectangle x1="-4.5466" y1="1.7714" x2="-3.556" y2="2.2286" layer="51"/>
<rectangle x1="-4.5466" y1="0.9714" x2="-3.556" y2="1.4286" layer="51"/>
<rectangle x1="-4.5466" y1="0.1714" x2="-3.556" y2="0.6286" layer="51"/>
<rectangle x1="-4.5466" y1="-0.6286" x2="-3.556" y2="-0.1714" layer="51"/>
<rectangle x1="-4.5466" y1="-1.4286" x2="-3.556" y2="-0.9714" layer="51"/>
<rectangle x1="-4.5466" y1="-2.2286" x2="-3.556" y2="-1.7714" layer="51"/>
<rectangle x1="-4.5466" y1="-3.0286" x2="-3.556" y2="-2.5714" layer="51"/>
<rectangle x1="-3.0286" y1="-4.5466" x2="-2.5714" y2="-3.556" layer="51"/>
<rectangle x1="-2.2286" y1="-4.5466" x2="-1.7714" y2="-3.556" layer="51"/>
<rectangle x1="-1.4286" y1="-4.5466" x2="-0.9714" y2="-3.556" layer="51"/>
<rectangle x1="-0.6286" y1="-4.5466" x2="-0.1714" y2="-3.556" layer="51"/>
<rectangle x1="0.1714" y1="-4.5466" x2="0.6286" y2="-3.556" layer="51"/>
<rectangle x1="0.9714" y1="-4.5466" x2="1.4286" y2="-3.556" layer="51"/>
<rectangle x1="1.7714" y1="-4.5466" x2="2.2286" y2="-3.556" layer="51"/>
<rectangle x1="2.5714" y1="-4.5466" x2="3.0286" y2="-3.556" layer="51"/>
<rectangle x1="3.556" y1="-3.0286" x2="4.5466" y2="-2.5714" layer="51"/>
<rectangle x1="3.556" y1="-2.2286" x2="4.5466" y2="-1.7714" layer="51"/>
<rectangle x1="3.556" y1="-1.4286" x2="4.5466" y2="-0.9714" layer="51"/>
<rectangle x1="3.556" y1="-0.6286" x2="4.5466" y2="-0.1714" layer="51"/>
<rectangle x1="3.556" y1="0.1714" x2="4.5466" y2="0.6286" layer="51"/>
<rectangle x1="3.556" y1="0.9714" x2="4.5466" y2="1.4286" layer="51"/>
<rectangle x1="3.556" y1="1.7714" x2="4.5466" y2="2.2286" layer="51"/>
<rectangle x1="3.556" y1="2.5714" x2="4.5466" y2="3.0286" layer="51"/>
<rectangle x1="2.5714" y1="3.556" x2="3.0286" y2="4.5466" layer="51"/>
<rectangle x1="1.7714" y1="3.556" x2="2.2286" y2="4.5466" layer="51"/>
<rectangle x1="0.9714" y1="3.556" x2="1.4286" y2="4.5466" layer="51"/>
<rectangle x1="0.1714" y1="3.556" x2="0.6286" y2="4.5466" layer="51"/>
<rectangle x1="-0.6286" y1="3.556" x2="-0.1714" y2="4.5466" layer="51"/>
<rectangle x1="-1.4286" y1="3.556" x2="-0.9714" y2="4.5466" layer="51"/>
<rectangle x1="-2.2286" y1="3.556" x2="-1.7714" y2="4.5466" layer="51"/>
<rectangle x1="-3.0286" y1="3.556" x2="-2.5714" y2="4.5466" layer="51"/>
<smd name="32" x="-2.778125" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="31" x="-1.984375" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="30" x="-1.190625" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="29" x="-0.396875" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="28" x="0.396875" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="27" x="1.190625" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="26" x="1.984375" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="25" x="2.778125" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="8" x="-4.524375" y="-2.778125" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="7" x="-4.524375" y="-1.984375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="6" x="-4.524375" y="-1.190625" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="5" x="-4.524375" y="-0.396875" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="4" x="-4.524375" y="0.396875" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="3" x="-4.524375" y="1.190625" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="2" x="-4.524375" y="1.984375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="1" x="-4.524375" y="2.778125" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="24" x="4.524375" y="2.778125" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="23" x="4.524375" y="1.984375" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="22" x="4.524375" y="1.190625" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="21" x="4.524375" y="0.396875" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="20" x="4.524375" y="-0.396875" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="19" x="4.524375" y="-1.190625" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="18" x="4.524375" y="-1.984375" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="17" x="4.524375" y="-2.778125" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="16" x="2.778125" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="15" x="1.984375" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="14" x="1.190625" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="13" x="0.396875" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="12" x="-0.396875" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="11" x="-1.190625" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="10" x="-1.984375" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="9" x="-2.778125" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<smd name="P$1" x="-4.524375" y="3.81" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="P$2" x="-3.81" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="P$3" x="-4.524375" y="5.23875" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="P$4" x="-5.23875" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<rectangle x1="-5.23875" y1="3.889375" x2="-3.81" y2="5.23875" layer="1"/>
<smd name="P$5" x="4.524375" y="3.81" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="P$6" x="5.23875" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="P$7" x="4.524375" y="5.23875" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="P$8" x="3.81" y="4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<rectangle x1="3.81" y1="3.889375" x2="5.23875" y2="5.23875" layer="1"/>
<smd name="P$9" x="-4.524375" y="-5.23875" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="P$10" x="-3.81" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="P$11" x="-4.524375" y="-3.81" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="P$12" x="-5.23875" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<rectangle x1="-5.23875" y1="-5.159375" x2="-3.81" y2="-3.81" layer="1"/>
<smd name="P$13" x="4.524375" y="-5.23875" dx="1.778" dy="0.381" layer="1" roundness="53"/>
<smd name="P$14" x="5.23875" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R90"/>
<smd name="P$15" x="4.524375" y="-3.81" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R180"/>
<smd name="P$16" x="3.81" y="-4.524375" dx="1.778" dy="0.381" layer="1" roundness="53" rot="R270"/>
<rectangle x1="3.81" y1="-5.159375" x2="5.23875" y2="-3.81" layer="1"/>
</package>
<package name="SWITCH_SMD_RESET_HEZ">
<wire x1="-4.826" y1="0.254" x2="-4.826" y2="0" width="0.4064" layer="1"/>
<wire x1="-4.826" y1="0" x2="-3.556" y2="0" width="0.4064" layer="1"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="0.254" width="0.4064" layer="1"/>
<wire x1="-3.556" y1="0.254" x2="-4.826" y2="0.254" width="0.4064" layer="1"/>
<wire x1="-3.302" y1="1.524" x2="-3.302" y2="0.508" width="0.254" layer="1"/>
<wire x1="-3.302" y1="0.508" x2="-3.556" y2="0.254" width="0.254" layer="1"/>
<wire x1="-3.302" y1="1.778" x2="-3.302" y2="-1.524" width="0.4064" layer="1"/>
<wire x1="2.794" y1="-0.254" x2="4.318" y2="-0.254" width="0.4064" layer="1"/>
<wire x1="4.318" y1="-0.254" x2="4.318" y2="0.508" width="0.4064" layer="1"/>
<wire x1="2.794" y1="-1.524" x2="2.794" y2="-0.254" width="0.4064" layer="1"/>
<wire x1="2.794" y1="-0.254" x2="2.794" y2="0.508" width="0.4064" layer="1"/>
<wire x1="2.794" y1="0.508" x2="2.794" y2="1.778" width="0.4064" layer="1"/>
<wire x1="4.318" y1="0.508" x2="2.794" y2="0.508" width="0.4064" layer="1"/>
<wire x1="-3.556" y1="0.508" x2="-4.826" y2="0.508" width="0.4064" layer="1"/>
<wire x1="-4.826" y1="0.508" x2="-4.826" y2="-0.254" width="0.4064" layer="1"/>
<wire x1="-4.826" y1="-0.254" x2="-3.556" y2="-0.254" width="0.4064" layer="1"/>
<wire x1="4.318" y1="0" x2="3.048" y2="0" width="0.4064" layer="1"/>
<wire x1="3.048" y1="0" x2="3.048" y2="0.254" width="0.4064" layer="1"/>
<wire x1="3.048" y1="0.254" x2="4.318" y2="0.254" width="0.4064" layer="1"/>
<wire x1="-3.175" y1="1.905" x2="2.54" y2="1.905" width="0.127" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="0.635" width="0.127" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.127" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-1.905" width="0.127" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="-3.175" y2="-1.905" width="0.127" layer="21"/>
<wire x1="-3.175" y1="-1.905" x2="-3.175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="0.635" width="0.127" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="1.905" width="0.127" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-5.08" y2="0.635" width="0.127" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-3.175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="2.54" y1="0.635" x2="4.445" y2="0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.445" y2="-0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="2.54" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="0.635" y2="-0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.635" y2="0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="0.635" x2="-1.27" y2="0.635" width="0.127" layer="21"/>
<smd name="1" x="-3.81" y="0" dx="1.778" dy="0.9144" layer="1"/>
<smd name="2" x="3.175" y="0" dx="1.778" dy="0.9144" layer="1"/>
</package>
<package name="LCD2004">
<wire x1="0" y1="-60.96" x2="98.7425" y2="-60.96" width="0.127" layer="21"/>
<wire x1="98.7425" y1="-60.96" x2="98.7425" y2="0" width="0.127" layer="21"/>
<wire x1="98.7425" y1="0" x2="0" y2="0" width="0.127" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-60.96" width="0.127" layer="21"/>
<wire x1="10.795" y1="-42.545" x2="10.795" y2="-19.05" width="0.127" layer="21"/>
<wire x1="88.265" y1="-42.545" x2="88.265" y2="-19.05" width="0.127" layer="21"/>
<wire x1="10.795" y1="-19.05" x2="88.265" y2="-19.05" width="0.127" layer="21"/>
<wire x1="10.795" y1="-42.545" x2="88.265" y2="-42.545" width="0.127" layer="21"/>
<hole x="1.905" y="-1.905" drill="2.8"/>
<hole x="96.8375" y="-1.905" drill="2.8"/>
<hole x="96.8375" y="-59.055" drill="2.8"/>
<hole x="1.905" y="-59.055" drill="2.8"/>
<pad name="P$1" x="10.4775" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$2" x="13.0175" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$3" x="15.5575" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$4" x="18.0975" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$5" x="20.6375" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$6" x="23.1775" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$7" x="25.7175" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$8" x="28.2575" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$9" x="30.7975" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$10" x="33.3375" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$11" x="35.8775" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$12" x="38.4175" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$13" x="40.9575" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$14" x="43.4975" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$15" x="46.0375" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<pad name="P$16" x="48.5775" y="-1.905" drill="0.8" diameter="1.778" shape="long" rot="R270"/>
<wire x1="1.27" y1="-12.065" x2="97.155" y2="-12.065" width="0.127" layer="21"/>
<wire x1="1.27" y1="-49.53" x2="97.155" y2="-49.53" width="0.127" layer="21"/>
<wire x1="1.27" y1="-49.53" x2="1.27" y2="-12.065" width="0.127" layer="21"/>
<wire x1="97.155" y1="-49.53" x2="97.155" y2="-12.065" width="0.127" layer="21"/>
</package>
<package name="TO92_">
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.1359" y1="-0.127" x2="-1.1359" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.4041" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-1.1359" x2="-2.0945" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.1359" y1="-0.127" x2="-1.4041" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.4041" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.4041" y1="-0.127" x2="1.1359" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.0945" y1="-1.651" x2="2.4242" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="GND" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5V" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="DATA" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SWITCH_NEGYZET_GOMB_FURATSZERELT">
<pad name="B1" x="-2.54" y="-2.54" drill="0.8" diameter="1.778"/>
<pad name="B2" x="0" y="-2.54" drill="0.8" diameter="1.778"/>
<pad name="B0" x="2.54" y="-2.54" drill="0.8" diameter="1.778"/>
<pad name="A0" x="-2.54" y="3.81" drill="0.8" diameter="1.778"/>
<pad name="A2" x="0" y="3.81" drill="0.8" diameter="1.778"/>
<pad name="A1" x="2.54" y="3.81" drill="0.8" diameter="1.778"/>
<wire x1="-4.1275" y1="-3.4925" x2="4.1275" y2="-3.4925" width="0.127" layer="21"/>
<wire x1="4.1275" y1="-3.4925" x2="4.1275" y2="4.7625" width="0.127" layer="21"/>
<wire x1="4.1275" y1="4.7625" x2="-4.1275" y2="4.7625" width="0.127" layer="21"/>
<wire x1="-4.1275" y1="4.7625" x2="-4.1275" y2="-3.4925" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="burr-brown">
<description>&lt;b&gt;Burr-Brown Components&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT223">
<description>&lt;b&gt;Smal Outline Transistor&lt;/b&gt;</description>
<wire x1="-3.124" y1="1.731" x2="-3.124" y2="-1.729" width="0.1524" layer="21"/>
<wire x1="3.124" y1="-1.729" x2="3.124" y2="1.731" width="0.1524" layer="21"/>
<wire x1="-3.124" y1="1.731" x2="3.124" y2="1.731" width="0.1524" layer="21"/>
<wire x1="3.124" y1="-1.729" x2="-3.124" y2="-1.729" width="0.1524" layer="21"/>
<smd name="1" x="-2.2606" y="-3.1496" dx="1.4986" dy="2.0066" layer="1"/>
<smd name="2" x="0.0254" y="-3.1496" dx="1.4986" dy="2.0066" layer="1"/>
<smd name="3" x="2.3114" y="-3.1496" dx="1.4986" dy="2.0066" layer="1"/>
<smd name="4" x="0" y="3.1496" dx="3.81" dy="2.0066" layer="1"/>
<text x="-2.54" y="4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-5.842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.524" y1="1.778" x2="1.524" y2="3.302" layer="51"/>
<rectangle x1="-2.667" y1="-3.302" x2="-1.905" y2="-1.778" layer="51"/>
<rectangle x1="1.905" y1="-3.302" x2="2.667" y2="-1.778" layer="51"/>
<rectangle x1="-0.381" y1="-3.302" x2="0.381" y2="-1.778" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C1210">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="V235/17">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="R0805_CUSTOM">
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<smd name="P$1" x="-1.27" y="0" dx="1.524" dy="0.889" layer="1" rot="R90"/>
<smd name="P$2" x="1.27" y="0" dx="1.524" dy="0.889" layer="1" rot="R90"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO-214AC">
<description>&lt;b&gt;SURFACE MOUNT GENERAL RECTIFIER&lt;/b&gt; JEDEC DO-214AC molded platic body&lt;p&gt;
Method 2026&lt;br&gt;
Source: http://www.kingtronics.com/SMD_M7/M7_SMD_4007.pdf</description>
<wire x1="-2.15" y1="1.3" x2="2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="1.3" x2="2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.3" x2="-2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-1.3" x2="-2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-1.035" y1="1.3" x2="1.025" y2="1.3" width="0.2032" layer="21"/>
<wire x1="1.025" y1="-1.3" x2="-1.035" y2="-1.3" width="0.2032" layer="21"/>
<smd name="C" x="-2.025" y="0" dx="1.8" dy="2.4" layer="1"/>
<smd name="A" x="2.025" y="0" dx="1.8" dy="2.4" layer="1" rot="R180"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.825" y1="-1.1" x2="-2.175" y2="1.1" layer="51"/>
<rectangle x1="2.175" y1="-1.1" x2="2.825" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.065" y1="-1.225" x2="-0.39" y2="1.225" layer="21"/>
<rectangle x1="-1.75" y1="-1.225" x2="-1.075" y2="1.225" layer="51"/>
</package>
</packages>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="B25P">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
Beckman Helitrim 25</description>
<wire x1="3.175" y1="3.429" x2="-3.175" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.429" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-3.429" x2="3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-3.175" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.524" x2="3.429" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.254" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.429" x2="-3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="3.175" x2="-3.429" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-0.254" x2="-3.429" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-1.524" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.762" x2="0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.143" x2="0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="-0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.286" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.143" x2="-0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.762" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="1.778" y1="-1.397" x2="2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="2.3876" y1="0.381" x2="2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="1.778" y1="2.032" x2="2.032" y2="2.286" width="0.3048" layer="21"/>
<wire x1="0" y1="2.7178" x2="0" y2="3.0988" width="0.3048" layer="21"/>
<wire x1="-1.905" y1="2.032" x2="-2.159" y2="2.286" width="0.3048" layer="21"/>
<wire x1="-2.3876" y1="0.381" x2="-2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.762" x2="-0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.048" x2="1.016" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.429" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-3.429" x2="2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.429" x2="3.175" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-1.016" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-3.048" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<circle x="0" y="0.381" radius="2.032" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1496" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.413" y="-2.794" size="0.9906" layer="21" ratio="12">3</text>
<text x="-2.921" y="-2.794" size="0.9906" layer="21" ratio="12">1</text>
</package>
</packages>
</library>
<library name="pinhead">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="1X02">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
</package>
<package name="1X04">
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-5.1562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="buzzer">
<description>&lt;b&gt;Speakers and Buzzers&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;Distributors:
&lt;li&gt;Buerklin
&lt;li&gt;Spoerle
&lt;li&gt;Schukat
&lt;/ul&gt;
<packages>
<package name="F/CM12P">
<description>&lt;b&gt;BUZZER&lt;/b&gt;</description>
<wire x1="3.175" y1="3.048" x2="4.445" y2="3.048" width="0.254" layer="21"/>
<wire x1="3.81" y1="3.683" x2="3.81" y2="2.413" width="0.254" layer="21"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="3.81" y="3.048" radius="1.27" width="0.1524" layer="21"/>
<pad name="-" x="-3.81" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<pad name="+" x="3.81" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="2.54" y="6.985" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-small-signal">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,0">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 3.0 mm with drill center</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="39"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="43"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="40"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="41"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="42"/>
<circle x="0" y="0" radius="1.6" width="0.2032" layer="21"/>
<text x="-1.27" y="-3.81" size="1.27" layer="48">3,0</text>
<hole x="0" y="0" drill="3"/>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/4">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-10.0838" y1="6.223" x2="0" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="-6.223" x2="-4.4958" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4318" y1="0.254" x2="-0.4318" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="-6.223" x2="-0.4318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4318" y1="-6.223" x2="0" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-6.223" x2="-5.5118" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-6.223" x2="-4.4958" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-9.5758" y1="0.254" x2="-9.5758" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-6.223" x2="-9.5758" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-9.5758" y1="-6.223" x2="-5.5118" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="-4.318" x2="-0.4318" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="-4.318" x2="-4.4958" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4318" y1="-4.318" x2="-0.4318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-4.318" x2="-9.5758" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-4.318" x2="-5.5118" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-9.5758" y1="-4.318" x2="-9.5758" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="-3.683" x2="-0.8128" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="-3.683" x2="-4.1148" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="-3.683" x2="-4.1148" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.8928" y1="-3.683" x2="-5.8928" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.8928" y1="-3.683" x2="-9.1948" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-9.1948" y1="-3.683" x2="-9.1948" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-9.1948" y1="-0.508" x2="-8.8138" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.8928" y1="-0.508" x2="-6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-4.1148" y1="-0.508" x2="-3.7338" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8128" y1="-0.508" x2="-1.1938" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-10.0838" y1="-6.223" x2="-10.0838" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="0.635" x2="-10.0838" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="3.175" x2="0" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="3.175" x2="-10.0838" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="3.429" x2="-4.4958" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="5.969" x2="-0.4318" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4318" y1="5.969" x2="-0.4318" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4318" y1="3.429" x2="-4.4958" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="3.429" x2="-5.5118" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="3.429" x2="-9.5758" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-9.5758" y1="3.429" x2="-9.5758" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="5.969" x2="-9.5758" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.9956" y1="4.0849" x2="-0.9399" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.937" y1="4.1656" x2="-0.9492" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.0894" y1="5.0038" x2="-0.935" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0386" y1="5.0546" x2="-3.8949" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.0894" y1="4.445" x2="-1.0414" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-3.9624" y1="4.318" x2="-0.9144" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-6.0756" y1="4.0849" x2="-6.0199" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-9.017" y1="4.1656" x2="-6.0292" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-9.1694" y1="5.0038" x2="-6.015" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-9.1186" y1="5.0546" x2="-8.9749" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-9.1694" y1="4.445" x2="-6.1214" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.0424" y1="4.318" x2="-5.9944" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-9.5758" y1="0.254" x2="-9.0678" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.8928" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-5.8928" y1="0.254" x2="-9.0678" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-10.0838" y1="0.635" x2="-9.0678" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-9.0678" y1="0.635" x2="-5.8928" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-5.8928" y1="0.635" x2="-4.1148" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.635" x2="-4.1148" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.4318" y1="0.254" x2="-0.9398" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.4958" y1="0.254" x2="-4.1148" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="0.254" x2="-0.9398" y2="0.254" width="0.1524" layer="51"/>
<wire x1="10.0838" y1="6.223" x2="10.0838" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="6.223" x2="10.5918" y2="6.223" width="0.1524" layer="21"/>
<wire x1="10.5918" y1="6.223" x2="10.5918" y2="1.397" width="0.1524" layer="21"/>
<wire x1="10.5918" y1="1.397" x2="10.0838" y2="1.651" width="0.1524" layer="21"/>
<wire x1="10.5918" y1="-5.461" x2="10.0838" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-5.207" x2="10.0838" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="10.5918" y1="-3.81" x2="10.0838" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-4.064" x2="10.0838" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="10.5918" y1="-3.81" x2="10.5918" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-6.223" x2="5.5118" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.5758" y1="0.254" x2="9.5758" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-6.223" x2="9.5758" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="9.5758" y1="-6.223" x2="10.0838" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="-6.223" x2="4.4958" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="-6.223" x2="5.5118" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0.254" x2="0.4318" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="-6.223" x2="4.4958" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-4.318" x2="9.5758" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-4.318" x2="5.5118" y2="0.254" width="0.1524" layer="21"/>
<wire x1="9.5758" y1="-4.318" x2="9.5758" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="-4.318" x2="0.4318" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="-4.318" x2="4.4958" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="-4.318" x2="0.4318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="9.1948" y1="-3.683" x2="9.1948" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="9.1948" y1="-3.683" x2="5.8928" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.8928" y1="-3.683" x2="5.8928" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1148" y1="-3.683" x2="4.1148" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1148" y1="-3.683" x2="0.8128" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8128" y1="-3.683" x2="0.8128" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.8128" y1="-0.508" x2="1.1938" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1148" y1="-0.508" x2="3.7338" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="5.8928" y1="-0.508" x2="6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="9.1948" y1="-0.508" x2="8.8138" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0" y1="-6.223" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="1.651" x2="10.0838" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="0.635" x2="10.0838" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="0" y1="3.175" x2="10.0838" y2="3.175" width="0.1524" layer="21"/>
<wire x1="0" y1="3.175" x2="0" y2="6.223" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="3.175" x2="10.0838" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="3.429" x2="5.5118" y2="5.969" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="5.969" x2="9.5758" y2="5.969" width="0.1524" layer="21"/>
<wire x1="9.5758" y1="5.969" x2="9.5758" y2="3.429" width="0.1524" layer="21"/>
<wire x1="9.5758" y1="3.429" x2="5.5118" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="3.429" x2="4.4958" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="3.429" x2="0.4318" y2="3.429" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="3.429" x2="0.4318" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="5.969" x2="0.4318" y2="5.969" width="0.1524" layer="21"/>
<wire x1="9.012" y1="4.0849" x2="9.0677" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="6.0706" y1="4.1656" x2="9.0584" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="5.9182" y1="5.0038" x2="9.0724" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="5.969" y1="5.0546" x2="6.1127" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="5.9182" y1="4.445" x2="8.9662" y2="5.08" width="0.1524" layer="21"/>
<wire x1="6.0452" y1="4.318" x2="9.0932" y2="4.953" width="0.1524" layer="21"/>
<wire x1="3.932" y1="4.0849" x2="3.9877" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="0.9906" y1="4.1656" x2="3.9784" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8382" y1="5.0038" x2="3.9924" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.889" y1="5.0546" x2="1.0327" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8382" y1="4.445" x2="3.8862" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9652" y1="4.318" x2="4.0132" y2="4.953" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0.254" x2="0.9398" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.4958" y1="0.254" x2="4.1148" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.1148" y1="0.254" x2="0.9398" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0" y1="0.635" x2="0.9398" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="0.635" x2="4.1148" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.1148" y1="0.635" x2="5.8928" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="0.635" x2="9.0678" y2="0.635" width="0.1524" layer="21"/>
<wire x1="9.0678" y1="0.635" x2="5.8928" y2="0.635" width="0.1524" layer="51"/>
<wire x1="9.5758" y1="0.254" x2="9.0678" y2="0.254" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="0.254" x2="5.8928" y2="0.254" width="0.1524" layer="21"/>
<wire x1="5.8928" y1="0.254" x2="9.0678" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0" y1="-6.223" x2="0.4318" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-0.9398" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="6.223" x2="0" y2="6.223" width="0.1524" layer="21"/>
<pad name="1" x="-7.493" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="4" x="7.493" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-10.0838" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.0838" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.525" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="-4.445" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<text x="0.635" y="1.27" size="1.27" layer="21" ratio="10">3</text>
<text x="5.715" y="1.27" size="1.27" layer="21" ratio="10">4</text>
<rectangle x1="-8.8138" y1="-2.54" x2="-6.2738" y2="0.254" layer="51"/>
<rectangle x1="-3.7338" y1="-2.54" x2="-1.1938" y2="0.254" layer="51"/>
<rectangle x1="1.1938" y1="-2.54" x2="3.7338" y2="0.254" layer="51"/>
<rectangle x1="6.2738" y1="-2.54" x2="8.8138" y2="0.254" layer="51"/>
</package>
<package name="AK300/2">
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="CHIP-LED0805">
<description>&lt;b&gt;Hyper CHIPLED Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
LB R99A&lt;br&gt;
Source: http://www.osram.convergy.de/ ... lb_r99a.pdf</description>
<wire x1="-0.625" y1="0.45" x2="-0.625" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.625" y1="0.45" x2="0.625" y2="-0.475" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.05" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="0" y="-1.05" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.27" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.675" y1="0" x2="-0.525" y2="0.3" layer="21"/>
<rectangle x1="0.525" y1="0" x2="0.675" y2="0.3" layer="21"/>
<rectangle x1="-0.15" y1="0" x2="0.15" y2="0.3" layer="21"/>
<rectangle x1="-0.675" y1="0.45" x2="0.675" y2="1.05" layer="51"/>
<rectangle x1="-0.675" y1="-1.05" x2="0.675" y2="-0.45" layer="51"/>
</package>
</packages>
</library>
<library name="con-jack">
<description>&lt;b&gt;Jacks&lt;/b&gt;&lt;p&gt;
Power Connectors&lt;br&gt;
Phone Connectors&lt;br&gt;
Cinch Connectors&lt;br&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DCJ0202">
<description>&lt;b&gt;DC POWER JACK&lt;/b&gt;&lt;p&gt;
Source: DCJ0202.pdf</description>
<wire x1="1.65" y1="2.6" x2="-1.65" y2="2.6" width="0" layer="46"/>
<wire x1="-1.65" y1="2.6" x2="-1.65" y2="3.6" width="0" layer="46"/>
<wire x1="-1.65" y1="3.6" x2="1.65" y2="3.6" width="0" layer="46"/>
<wire x1="1.65" y1="3.6" x2="1.65" y2="2.6" width="0" layer="46"/>
<wire x1="5.3" y1="1.4" x2="4.3" y2="1.4" width="0" layer="46"/>
<wire x1="4.3" y1="1.4" x2="4.3" y2="-1.4" width="0" layer="46"/>
<wire x1="4.3" y1="-1.4" x2="5.3" y2="-1.4" width="0" layer="46"/>
<wire x1="5.3" y1="-1.4" x2="5.3" y2="1.4" width="0" layer="46"/>
<wire x1="1.4" y1="-3.5" x2="-1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-3.5" x2="-1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-2.5" x2="1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="1.4" y1="-2.5" x2="1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-4.3" y1="-10.4" x2="4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="4.3" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="3.9" x2="-4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="21"/>
<wire x1="4.3" y1="3.9" x2="2.7" y2="3.9" width="0.2032" layer="21"/>
<wire x1="-3" y1="-10.275" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-10.3" x2="3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-3" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="-0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="0.9" y1="-9" x2="0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="0.9" y2="-9" width="0.2032" layer="51" curve="166.57811"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="-2.45" width="0.2032" layer="21"/>
<wire x1="4.3" y1="2.3" x2="4.3" y2="3.9" width="0.2032" layer="21"/>
<pad name="1" x="0" y="3.1" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="3" x="0" y="-3" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="2" x="4.8" y="0" drill="1" diameter="2" shape="long" rot="R90"/>
<text x="-3.81" y="5.08" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-10.16" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HC49/S">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.159" x2="3.048" y2="-2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="3.048" y2="2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-1.651" x2="3.048" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.651" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.762" x2="0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.762" x2="-0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.762" x2="-0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.762" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.762" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="-3.048" y2="-2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="-2.159" x2="3.048" y2="2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="-3.048" y1="1.651" x2="-3.048" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="3.048" y1="-1.651" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="180"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.445" y1="-2.54" x2="4.445" y2="2.54" layer="43"/>
<rectangle x1="-5.08" y1="-1.905" x2="-4.445" y2="1.905" layer="43"/>
<rectangle x1="-5.715" y1="-1.27" x2="-5.08" y2="1.27" layer="43"/>
<rectangle x1="4.445" y1="-1.905" x2="5.08" y2="1.905" layer="43"/>
<rectangle x1="5.08" y1="-1.27" x2="5.715" y2="1.27" layer="43"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="U$1" library="My_Eagle_library" package="ATMEGA328" value="ATMEGA328_SMD" x="71.755" y="59.69" rot="R180"/>
<element name="IC1" library="burr-brown" package="SOT223" value="REG1117-5.0" x="60.96" y="93.345" rot="R270">
<attribute name="OC_NEWARK" value="14P6981" x="-8.89" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="REG1117" x="-8.89" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="-8.89" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="1097566" x="-8.89" y="24.765" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="U$3" library="My_Eagle_library" package="SWITCH_SMD_RESET_HEZ" value="reset" x="49.53" y="34.925" rot="R180"/>
<element name="C1" library="rcl" package="C0805" value="100nF" x="55.245" y="58.42" rot="R270"/>
<element name="IC2" library="linear" package="SO08" value="LM358D" x="134.62" y="35.56" rot="R90"/>
<element name="IC4" library="linear" package="SO08" value="LM358D" x="105.41" y="32.385" rot="R270"/>
<element name="R1" library="rcl" package="V235/17" value="1ohm" x="-73.025" y="53.975"/>
<element name="T2_CELLA3" library="transistor" package="TO220" value="BD649" x="-70.485" y="24.13" rot="R270"/>
<element name="R7" library="rcl" package="R0805_CUSTOM" value="1k" x="143.51" y="46.99" rot="R90"/>
<element name="R9" library="rcl" package="R0805" value="680" x="147.955" y="44.45" rot="R180"/>
<element name="D1_CELLA1" library="diode" package="DO-214AC" value="ss34" x="-35.56" y="13.97" rot="R270"/>
<element name="R13" library="rcl" package="R0805" value="100k" x="147.955" y="48.895" rot="R180"/>
<element name="D2_CELLA3" library="diode" package="DO-214AC" value="ss34" x="-43.18" y="13.97" rot="R270"/>
<element name="R3" library="rcl" package="R0805_CUSTOM" value="680" x="114.935" y="70.485" rot="R270"/>
<element name="R4" library="rcl" package="R0805_CUSTOM" value="1k" x="118.745" y="68.58"/>
<element name="R5" library="rcl" package="R0805" value="100k" x="121.92" y="70.485" rot="R270"/>
<element name="IC3" library="linear" package="SO08" value="LM358D" x="118.745" y="64.77" rot="R270"/>
<element name="T3_CELLA2" library="transistor" package="TO220" value="BD649" x="-66.04" y="85.09" rot="R180"/>
<element name="T4_CELLA4" library="transistor" package="TO220" value="BD649" x="-9.525" y="20.32"/>
<element name="R10" library="rcl" package="R0805_CUSTOM" value="1k" x="133.35" y="46.99" rot="R90"/>
<element name="R11" library="rcl" package="R0805" value="680" x="138.43" y="45.085" rot="R180"/>
<element name="D3_CELLA2" library="diode" package="DO-214AC" value="ss34" x="-39.37" y="13.97" rot="R270"/>
<element name="R12" library="rcl" package="R0805" value="100k" x="138.43" y="48.895" rot="R180"/>
<element name="D4_CELLA4" library="diode" package="DO-214AC" value="ss34" x="-31.75" y="13.97" rot="R270"/>
<element name="R14" library="rcl" package="R0805" value="680" x="127.635" y="62.23"/>
<element name="R15" library="rcl" package="R0805" value="1k" x="130.81" y="60.96" rot="R270"/>
<element name="R16" library="rcl" package="R0805" value="100k" x="127.635" y="58.42"/>
<element name="R17" library="rcl" package="R0805_CUSTOM" value="6k8" x="123.19" y="40.005"/>
<element name="R18" library="rcl" package="R0805_CUSTOM" value="6k8" x="108.585" y="65.405"/>
<element name="R19" library="rcl" package="R0805" value="6k8" x="106.68" y="58.42"/>
<element name="R20" library="rcl" package="R0805_CUSTOM" value="6k8" x="123.19" y="37.465"/>
<element name="R21" library="rcl" package="R0805" value="10k" x="95.25" y="34.925" rot="R90"/>
<element name="R22" library="rcl" package="R0805" value="10k" x="95.25" y="31.115" rot="R270"/>
<element name="C2" library="rcl" package="C0805" value="100nF" x="97.79" y="31.115" rot="R270"/>
<element name="R23" library="rcl" package="R0805" value="1k" x="99.06" y="26.67" rot="R180"/>
<element name="R25" library="pot" package="B25P" value="1k" x="118.11" y="15.24" rot="MR0"/>
<element name="R26" library="pot" package="B25P" value="1k" x="102.87" y="15.24" rot="MR0"/>
<element name="R27" library="pot" package="B25P" value="1k" x="95.25" y="15.24" rot="MR0"/>
<element name="R28" library="pot" package="B25P" value="1k" x="110.49" y="15.24" rot="MR0"/>
<element name="R29" library="rcl" package="R0805" value="510" x="115.57" y="8.89" rot="R90"/>
<element name="R30" library="rcl" package="R0805" value="510" x="110.49" y="8.89" rot="R90"/>
<element name="R31" library="rcl" package="R0805" value="510" x="97.79" y="8.89" rot="R90"/>
<element name="R32" library="rcl" package="R0805" value="510" x="102.87" y="8.89" rot="R90"/>
<element name="R24" library="rcl" package="R0805" value="8k2" x="167.005" y="74.295" rot="R180"/>
<element name="R33" library="rcl" package="R0805" value="2k2" x="171.45" y="74.295" rot="R180"/>
<element name="R34" library="rcl" package="R0805" value="8k2" x="167.005" y="69.215" rot="R180"/>
<element name="R35" library="rcl" package="R0805" value="2k2" x="171.45" y="69.215" rot="R180"/>
<element name="R36" library="rcl" package="R0805" value="8k2" x="167.005" y="64.135" rot="R180"/>
<element name="R37" library="rcl" package="R0805" value="2k2" x="171.45" y="64.135" rot="R180"/>
<element name="R38" library="rcl" package="R0805" value="8k2" x="167.005" y="59.055" rot="R180"/>
<element name="R39" library="rcl" package="R0805" value="2k2" x="171.45" y="59.055" rot="R180"/>
<element name="U$7" library="My_Eagle_library" package="LCD2004" value="LCD_420_2004" x="151.765" y="81.915" rot="MR0"/>
<element name="SG1" library="buzzer" package="F/CM12P" value="F/CM12P" x="65.405" y="11.43" rot="MR0">
<attribute name="OC_NEWARK" value="unknown" x="65.405" y="11.43" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MPN" value="" x="65.405" y="11.43" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MF" value="" x="65.405" y="11.43" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="65.405" y="11.43" size="1.778" layer="28" rot="MR0" display="off"/>
</element>
<element name="Q1" library="transistor-small-signal" package="SOT23" value="AO3400" x="64.77" y="76.2" rot="R270"/>
<element name="JP1" library="pinhead" package="1X02" value="" x="66.675" y="81.915" rot="R270"/>
<element name="D5" library="diode" package="DO-214AC" value="ss34" x="62.865" y="81.915" rot="R270"/>
<element name="R40" library="rcl" package="R0805_CUSTOM" value="1k" x="51.435" y="72.0725" rot="R90"/>
<element name="R41" library="rcl" package="R0805" value="100k" x="60.96" y="76.2" rot="R90"/>
<element name="H1" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="-80.01" y="9.525" rot="R180"/>
<element name="H2" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="5.08" y="94.615" rot="R180"/>
<element name="H3" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="-80.01" y="94.615" rot="R180"/>
<element name="H4" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="5.08" y="9.525" rot="R180"/>
<element name="Q2" library="transistor-small-signal" package="SOT23" value="AO3400" x="73.66" y="19.685" rot="R90"/>
<element name="R43" library="rcl" package="R0805" value="1k" x="81.28" y="19.685" rot="R90"/>
<element name="R44" library="rcl" package="R0805" value="100k" x="77.47" y="19.685" rot="R270"/>
<element name="R42" library="pot" package="B25P" value="470" x="139.7" y="87.63" rot="MR0"/>
<element name="R45" library="rcl" package="R0805" value="22" x="106.045" y="76.2" rot="R90"/>
<element name="Q3" library="transistor-small-signal" package="SOT23" value="AO3400" x="99.695" y="81.28" rot="R270"/>
<element name="R46" library="rcl" package="R0805" value="1k" x="93.98" y="81.28" rot="R270"/>
<element name="R47" library="rcl" package="R0805" value="100k" x="96.52" y="81.28" rot="R90"/>
<element name="X1" library="con-ptr500" package="AK300/4" value="GND-k" x="161.29" y="46.355" rot="MR270">
<attribute name="OC_NEWARK" value="unknown" x="161.29" y="46.355" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="MPN" value="" x="161.29" y="46.355" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="MF" value="" x="161.29" y="46.355" size="1.778" layer="28" rot="MR270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="161.29" y="46.355" size="1.778" layer="28" rot="MR270" display="off"/>
</element>
<element name="X2" library="con-ptr500" package="AK300/4" value="4.2V" x="161.29" y="26.035" rot="MR90">
<attribute name="OC_NEWARK" value="unknown" x="161.29" y="26.035" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="MPN" value="" x="161.29" y="26.035" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="MF" value="" x="161.29" y="26.035" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="161.29" y="26.035" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="X3" library="con-ptr500" package="AK300/4" value="V+ meas" x="161.29" y="66.675" rot="MR90">
<attribute name="OC_NEWARK" value="unknown" x="161.29" y="66.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="MPN" value="" x="161.29" y="66.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="MF" value="" x="161.29" y="66.675" size="1.778" layer="28" rot="MR90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="161.29" y="66.675" size="1.778" layer="28" rot="MR90" display="off"/>
</element>
<element name="C3" library="rcl" package="C1210" value="10uf 1210" x="49.53" y="92.71" rot="R90"/>
<element name="C4" library="rcl" package="C0805" value="100nF" x="53.975" y="94.615" rot="R90"/>
<element name="R50" library="rcl" package="R0805" value="220" x="111.76" y="76.2"/>
<element name="LED1" library="led" package="CHIP-LED0805" value="" x="116.205" y="76.2" rot="R270"/>
<element name="X4" library="con-ptr500" package="AK300/2" value="" x="40.64" y="95.25" rot="MR0">
<attribute name="OC_NEWARK" value="unknown" x="40.64" y="95.25" size="5.08" layer="28" rot="MR0" display="off"/>
<attribute name="MPN" value="" x="40.64" y="95.25" size="5.08" layer="28" rot="MR0" display="off"/>
<attribute name="MF" value="" x="40.64" y="95.25" size="5.08" layer="28" rot="MR0" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="40.64" y="95.25" size="5.08" layer="28" rot="MR0" display="off"/>
</element>
<element name="D6" library="diode" package="DO-214AC" value="ss34" x="45.72" y="87.63" rot="R180"/>
<element name="T1_CELLA1" library="transistor" package="TO220" value="BD649" x="-5.715" y="81.28" rot="R90"/>
<element name="R2" library="rcl" package="V235/17" value="1ohm" x="-73.025" y="61.595"/>
<element name="R8" library="rcl" package="V235/17" value="1ohm" x="-73.025" y="37.465"/>
<element name="R53" library="rcl" package="V235/17" value="1ohm" x="-73.025" y="45.72" rot="R180"/>
<element name="U$2" library="My_Eagle_library" package="TO92_" value="DS18B20_" x="-41.91" y="55.88"/>
<element name="JP4" library="pinhead" package="1X04" value="" x="-27.94" y="55.88"/>
<element name="JP5" library="pinhead" package="1X04" value="" x="-37.465" y="6.985" rot="R180"/>
<element name="JP6" library="pinhead" package="1X04" value="" x="-57.785" y="49.53" rot="R90"/>
<element name="JP7" library="pinhead" package="1X04" value="" x="105.41" y="49.53" rot="R90"/>
<element name="JP8" library="pinhead" package="1X04" value="" x="125.73" y="6.985" rot="R180"/>
<element name="JP9" library="pinhead" package="1X04" value="" x="135.255" y="55.88"/>
<element name="U$8" library="My_Eagle_library" package="TO92_" value="DS18B20_" x="121.285" y="55.88"/>
<element name="H5" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="168.275" y="9.525" rot="MR180"/>
<element name="H6" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="83.185" y="9.525" rot="R180"/>
<element name="H7" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="83.185" y="94.615" rot="R180"/>
<element name="H8" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="168.275" y="94.615" rot="R180"/>
<element name="H9" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="149.86" y="80.01" rot="R180"/>
<element name="H10" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="55.245" y="80.01" rot="R180"/>
<element name="H11" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="54.61" y="22.86" rot="R180"/>
<element name="H12" library="holes" package="3,0" value="MOUNT-HOLE3.0" x="149.86" y="22.86" rot="R180"/>
<element name="U$9" library="My_Eagle_library" package="SWITCH_NEGYZET_GOMB_FURATSZERELT" value="fel" x="33.655" y="75.565"/>
<element name="U$10" library="My_Eagle_library" package="SWITCH_NEGYZET_GOMB_FURATSZERELT" value="ok" x="33.655" y="50.8"/>
<element name="U$11" library="My_Eagle_library" package="SWITCH_NEGYZET_GOMB_FURATSZERELT" value="le" x="33.655" y="26.035"/>
<element name="J1" library="con-jack" package="DCJ0202" value="DCJ0202" x="27.94" y="93.345" rot="MR90">
<attribute name="OC_NEWARK" value="unknown" x="27.94" y="93.345" size="3.4" layer="28" rot="MR90" display="off"/>
<attribute name="MPN" value="" x="27.94" y="93.345" size="3.4" layer="28" rot="MR90" display="off"/>
<attribute name="MF" value="" x="27.94" y="93.345" size="3.4" layer="28" rot="MR90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="27.94" y="93.345" size="3.4" layer="28" rot="MR90" display="off"/>
</element>
<element name="R6" library="rcl" package="R0805_CUSTOM" value="1k" x="122.555" y="52.07" rot="R180"/>
<element name="C5" library="rcl" package="C1210" value="10uf 1210" x="97.155" y="74.93" rot="R90"/>
<element name="C6" library="rcl" package="C0805" value="100nF" x="54.61" y="47.625" rot="R270"/>
<element name="C7" library="rcl" package="C0805" value="100nF" x="57.15" y="47.625" rot="R270"/>
<element name="C8" library="rcl" package="C0805" value="100nF" x="62.865" y="36.83" rot="R270"/>
<element name="C9" library="rcl" package="C0805" value="100nF" x="65.405" y="36.83" rot="R270"/>
<element name="C10" library="rcl" package="C0805" value="100nF" x="67.945" y="36.83" rot="R270"/>
<element name="C11" library="rcl" package="C0805" value="100nF" x="70.485" y="36.83" rot="R270"/>
<element name="C12" library="rcl" package="C0805" value="100nF" x="48.895" y="58.42" rot="R270"/>
<element name="C13" library="rcl" package="C0805" value="100nF" x="52.705" y="54.61" rot="R90"/>
<element name="Q4" library="crystal" package="HC49/S" value="16MHz" x="83.82" y="65.405">
<attribute name="OC_NEWARK" value="unknown" x="83.82" y="65.405" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="83.82" y="65.405" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="83.82" y="65.405" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1667008" x="83.82" y="65.405" size="1.778" layer="27" display="off"/>
</element>
<element name="C14" library="rcl" package="C0805" value="22pf" x="88.265" y="66.04" rot="R90"/>
<element name="C15" library="rcl" package="C0805" value="22pf" x="86.995" y="68.58"/>
<element name="C16" library="rcl" package="C0805" value="100nF" x="86.995" y="56.515" rot="R180"/>
</elements>
<signals>
<signal name="GND">
<contactref element="IC1" pad="1"/>
<contactref element="U$1" pad="21"/>
<contactref element="U$3" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="U$1" pad="3"/>
<contactref element="U$1" pad="5"/>
<contactref element="R9" pad="1"/>
<contactref element="R13" pad="1"/>
<contactref element="R3" pad="P$1"/>
<contactref element="R5" pad="1"/>
<contactref element="R11" pad="1"/>
<contactref element="R12" pad="1"/>
<contactref element="R14" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="R23" pad="2"/>
<contactref element="R22" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="IC4" pad="4"/>
<contactref element="R26" pad="A"/>
<contactref element="R27" pad="A"/>
<contactref element="R28" pad="A"/>
<contactref element="R25" pad="A"/>
<contactref element="R1" pad="1"/>
<contactref element="Q1" pad="2"/>
<contactref element="R41" pad="1"/>
<contactref element="IC3" pad="4"/>
<contactref element="IC2" pad="4"/>
<contactref element="Q2" pad="2"/>
<contactref element="R44" pad="1"/>
<contactref element="Q3" pad="2"/>
<contactref element="R47" pad="1"/>
<contactref element="R42" pad="A"/>
<contactref element="U$7" pad="P$1"/>
<contactref element="U$7" pad="P$5"/>
<contactref element="X1" pad="4"/>
<contactref element="X1" pad="3"/>
<contactref element="X1" pad="2"/>
<contactref element="X1" pad="1"/>
<wire x1="161.29" y1="43.8404" x2="161.925" y2="43.8404" width="1.016" layer="1"/>
<wire x1="161.925" y1="43.8404" x2="170.815" y2="43.8404" width="1.016" layer="1"/>
<wire x1="161.29" y1="48.8696" x2="170.815" y2="48.8696" width="1.016" layer="1"/>
<wire x1="170.815" y1="48.8696" x2="170.815" y2="47.625" width="1.016" layer="1"/>
<wire x1="170.815" y1="47.625" x2="170.815" y2="46.355" width="1.016" layer="1"/>
<wire x1="170.815" y1="46.355" x2="170.815" y2="43.8404" width="1.016" layer="1"/>
<wire x1="161.29" y1="38.862" x2="165.8366" y2="38.862" width="1.016" layer="1"/>
<wire x1="165.8366" y1="38.862" x2="170.815" y2="43.8404" width="1.016" layer="1"/>
<wire x1="161.29" y1="53.848" x2="164.592" y2="53.848" width="1.016" layer="1"/>
<wire x1="164.592" y1="53.848" x2="170.4975" y2="47.9425" width="1.016" layer="1"/>
<contactref element="R37" pad="1"/>
<contactref element="R39" pad="1"/>
<contactref element="R35" pad="1"/>
<contactref element="R33" pad="1"/>
<wire x1="170.4975" y1="47.9425" x2="170.815" y2="47.625" width="1.016" layer="1"/>
<wire x1="173.355" y1="46.3804" x2="170.815" y2="43.8404" width="1.016" layer="1"/>
<contactref element="C3" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="LED1" pad="C"/>
<contactref element="X4" pad="2"/>
<contactref element="R2" pad="1"/>
<contactref element="R53" pad="2"/>
<contactref element="R8" pad="1"/>
<wire x1="173.355" y1="42.545" x2="170.815" y2="46.355" width="0.8128" layer="1"/>
<wire x1="161.2646" y1="48.895" x2="161.29" y2="48.8696" width="1.016" layer="1"/>
<wire x1="161.8996" y1="43.815" x2="161.925" y2="43.8404" width="1.016" layer="1"/>
<wire x1="160.782" y1="39.37" x2="161.29" y2="38.862" width="1.016" layer="1"/>
<contactref element="U$9" pad="B1"/>
<contactref element="U$10" pad="B1"/>
<contactref element="J1" pad="2"/>
<contactref element="J1" pad="3"/>
<wire x1="27.94" y1="98.145" x2="35.2558" y2="98.145" width="1.4224" layer="1"/>
<wire x1="35.2558" y1="98.145" x2="38.1508" y2="95.25" width="1.4224" layer="1"/>
<wire x1="27.94" y1="98.145" x2="25.755" y2="98.145" width="1.4224" layer="1"/>
<wire x1="25.755" y1="98.145" x2="24.765" y2="97.155" width="1.4224" layer="1"/>
<wire x1="24.765" y1="97.155" x2="24.765" y2="93.52" width="1.4224" layer="1"/>
<wire x1="24.765" y1="93.52" x2="24.94" y2="93.345" width="1.4224" layer="1"/>
<wire x1="52.07" y1="100.33" x2="40.005" y2="100.33" width="1.016" layer="1"/>
<wire x1="40.005" y1="100.33" x2="38.1" y2="98.425" width="1.016" layer="1"/>
<wire x1="38.1" y1="98.425" x2="38.1" y2="95.3008" width="1.016" layer="1"/>
<wire x1="38.1" y1="95.3008" x2="38.1508" y2="95.25" width="1.016" layer="1"/>
<wire x1="56.7944" y1="95.6056" x2="54.61" y2="95.6056" width="1.016" layer="1"/>
<wire x1="54.61" y1="95.6056" x2="51.0256" y2="95.6056" width="1.016" layer="1"/>
<wire x1="51.0256" y1="95.6056" x2="49.53" y2="94.11" width="1.016" layer="1"/>
<wire x1="53.975" y1="95.565" x2="54.5694" y2="95.565" width="1.016" layer="1"/>
<wire x1="54.5694" y1="95.565" x2="54.61" y2="95.6056" width="1.016" layer="1"/>
<wire x1="114.935" y1="71.755" x2="121.6" y2="71.755" width="0.8128" layer="1"/>
<wire x1="121.6" y1="71.755" x2="121.92" y2="71.435" width="0.4064" layer="1"/>
<wire x1="97.79" y1="30.165" x2="95.25" y2="30.165" width="0.8128" layer="1"/>
<wire x1="102.81" y1="30.48" x2="98.105" y2="30.48" width="0.4064" layer="1"/>
<wire x1="98.105" y1="30.48" x2="97.79" y2="30.165" width="0.4064" layer="1"/>
<wire x1="98.11" y1="26.67" x2="98.11" y2="29.845" width="0.8128" layer="1"/>
<wire x1="98.11" y1="29.845" x2="97.79" y2="30.165" width="0.4064" layer="1"/>
<wire x1="77.47" y1="20.635" x2="74.76" y2="20.635" width="0.4064" layer="1"/>
<wire x1="28.2575" y1="75.2475" x2="27.94" y2="74.93" width="0.4064" layer="1"/>
<wire x1="27.94" y1="74.93" x2="27.94" y2="48.26" width="0.8128" layer="1"/>
<wire x1="27.94" y1="48.26" x2="27.94" y2="27.305" width="0.8128" layer="1"/>
<wire x1="24.94" y1="93.345" x2="24.94" y2="78.565" width="0.8128" layer="1"/>
<wire x1="24.94" y1="78.565" x2="28.2575" y2="75.2475" width="0.8128" layer="1"/>
<wire x1="67.230625" y1="59.293125" x2="70.881875" y2="59.293125" width="0.4064" layer="1"/>
<wire x1="70.881875" y1="59.293125" x2="71.755" y2="58.42" width="0.8128" layer="1"/>
<wire x1="76.279375" y1="60.086875" x2="73.421875" y2="60.086875" width="0.4064" layer="1"/>
<wire x1="73.421875" y1="60.086875" x2="71.834375" y2="58.499375" width="0.4064" layer="1"/>
<wire x1="71.834375" y1="58.499375" x2="71.755" y2="58.42" width="0.4064" layer="1"/>
<wire x1="67.230625" y1="59.293125" x2="58.658125" y2="59.293125" width="0.4064" layer="1"/>
<wire x1="58.658125" y1="59.293125" x2="55.88" y2="56.515" width="0.4064" layer="1"/>
<wire x1="46.355" y1="34.925" x2="44.45" y2="34.925" width="0.8128" layer="1"/>
<wire x1="44.45" y1="34.925" x2="41.91" y2="37.465" width="0.8128" layer="1"/>
<wire x1="41.91" y1="37.465" x2="41.91" y2="62.865" width="0.8128" layer="1"/>
<wire x1="41.91" y1="62.865" x2="41.275" y2="63.5" width="0.8128" layer="1"/>
<wire x1="172.4" y1="69.215" x2="172.4" y2="64.135" width="0.8128" layer="1"/>
<wire x1="172.4" y1="64.135" x2="172.4" y2="59.055" width="0.8128" layer="1"/>
<wire x1="172.4" y1="69.215" x2="172.4" y2="74.295" width="0.8128" layer="1"/>
<wire x1="172.4" y1="59.055" x2="172.4" y2="49.845" width="0.8128" layer="1"/>
<wire x1="172.4" y1="49.845" x2="170.4975" y2="47.9425" width="0.4064" layer="1"/>
<contactref element="U$11" pad="A1"/>
<wire x1="56.7944" y1="95.6056" x2="56.7944" y2="96.2406" width="0.4064" layer="1"/>
<wire x1="56.7944" y1="96.2406" x2="55.245" y2="97.79" width="0.4064" layer="1"/>
<via x="55.245" y="97.79" extent="1-16" drill="0.6" shape="square"/>
<wire x1="55.245" y1="97.79" x2="75.565" y2="97.79" width="1.4224" layer="16"/>
<wire x1="75.565" y1="97.79" x2="79.375" y2="101.6" width="1.4224" layer="16"/>
<wire x1="79.375" y1="101.6" x2="149.86" y2="101.6" width="1.4224" layer="16"/>
<wire x1="149.86" y1="101.6" x2="173.99" y2="77.47" width="1.4224" layer="16"/>
<wire x1="173.99" y1="77.47" x2="173.99" y2="49.53" width="1.4224" layer="16"/>
<wire x1="173.99" y1="49.53" x2="171.1325" y2="46.6725" width="1.4224" layer="16"/>
<wire x1="171.1325" y1="46.6725" x2="170.815" y2="46.355" width="1.4224" layer="16"/>
<wire x1="57.8104" y1="95.6056" x2="56.7944" y2="95.6056" width="1.4224" layer="1"/>
<wire x1="56.7944" y1="95.6056" x2="52.07" y2="100.33" width="1.4224" layer="1"/>
<wire x1="41.275" y1="63.5" x2="41.275" y2="80.645" width="0.8128" layer="1"/>
<wire x1="41.275" y1="80.645" x2="38.1" y2="83.82" width="0.8128" layer="1"/>
<wire x1="38.1" y1="83.82" x2="34.465" y2="83.82" width="0.8128" layer="1"/>
<wire x1="34.465" y1="83.82" x2="24.94" y2="93.345" width="0.8128" layer="1"/>
<wire x1="43.18" y1="78.105" x2="60.325" y2="95.25" width="1.4224" layer="16"/>
<wire x1="60.325" y1="95.25" x2="75.565" y2="95.25" width="1.4224" layer="16"/>
<wire x1="75.565" y1="95.25" x2="80.01" y2="99.695" width="1.4224" layer="16"/>
<wire x1="80.01" y1="99.695" x2="149.225" y2="99.695" width="1.4224" layer="16"/>
<wire x1="149.225" y1="99.695" x2="172.085" y2="76.835" width="1.4224" layer="16"/>
<wire x1="172.085" y1="76.835" x2="172.085" y2="48.26" width="1.4224" layer="16"/>
<wire x1="172.085" y1="48.26" x2="169.545" y2="46.99" width="1.4224" layer="16"/>
<wire x1="151.765" y1="46.355" x2="152.4" y2="46.355" width="1.4224" layer="1"/>
<wire x1="152.4" y1="46.355" x2="170.815" y2="46.355" width="1.4224" layer="1"/>
<wire x1="137.22" y1="37.465" x2="139.065" y2="37.465" width="0.8128" layer="1"/>
<wire x1="139.065" y1="37.465" x2="139.7" y2="38.1" width="0.8128" layer="1"/>
<wire x1="139.7" y1="38.1" x2="139.7" y2="40.005" width="0.8128" layer="1"/>
<via x="101.6" y="76.835" extent="1-16" drill="0.6" shape="square"/>
<wire x1="101.6" y1="76.835" x2="144.145" y2="76.835" width="1.016" layer="16"/>
<wire x1="121.92" y1="71.435" x2="128.59" y2="71.435" width="0.8128" layer="1"/>
<wire x1="128.59" y1="71.435" x2="133.985" y2="66.04" width="0.8128" layer="1"/>
<wire x1="133.985" y1="66.04" x2="143.51" y2="66.04" width="0.8128" layer="1"/>
<wire x1="143.51" y1="66.04" x2="144.145" y2="66.04" width="0.8128" layer="1"/>
<via x="144.145" y="66.04" extent="1-16" drill="0.6" shape="square"/>
<wire x1="165.735" y1="66.675" x2="167.64" y2="64.77" width="0.8128" layer="16"/>
<wire x1="167.64" y1="64.77" x2="167.64" y2="49.53" width="0.8128" layer="16"/>
<wire x1="167.64" y1="49.53" x2="168.783" y2="48.006" width="0.8128" layer="16"/>
<wire x1="168.783" y1="48.006" x2="169.545" y2="46.99" width="0.8128" layer="16"/>
<wire x1="144.145" y1="76.835" x2="146.685" y2="74.295" width="1.016" layer="16"/>
<wire x1="146.685" y1="74.295" x2="151.13" y2="74.295" width="1.016" layer="16"/>
<wire x1="143.51" y1="66.04" x2="144.145" y2="66.675" width="0.8128" layer="1"/>
<wire x1="120.65" y1="17.78" x2="133.35" y2="17.78" width="0.8128" layer="1"/>
<wire x1="133.35" y1="17.78" x2="139.7" y2="24.13" width="0.8128" layer="1"/>
<wire x1="139.7" y1="24.13" x2="139.7" y2="31.75" width="0.8128" layer="1"/>
<wire x1="139.7" y1="31.75" x2="147.32" y2="39.37" width="0.8128" layer="1"/>
<wire x1="147.32" y1="39.37" x2="153.67" y2="39.37" width="0.8128" layer="1"/>
<wire x1="153.67" y1="39.37" x2="155.575" y2="41.275" width="0.8128" layer="1"/>
<wire x1="155.575" y1="41.275" x2="167.005" y2="41.275" width="0.8128" layer="1"/>
<wire x1="167.005" y1="41.275" x2="170.815" y2="46.355" width="0.8128" layer="1"/>
<wire x1="77.47" y1="20.635" x2="75.25" y2="20.635" width="0.8128" layer="1"/>
<wire x1="75.25" y1="20.635" x2="72.39" y2="23.495" width="0.8128" layer="1"/>
<wire x1="72.39" y1="23.495" x2="66.04" y2="23.495" width="0.8128" layer="1"/>
<wire x1="137.795" y1="40.64" x2="136.525" y2="40.64" width="0.8128" layer="1"/>
<wire x1="139.7" y1="40.005" x2="139.065" y2="40.64" width="0.8128" layer="1"/>
<wire x1="139.065" y1="40.64" x2="136.525" y2="40.64" width="0.8128" layer="1"/>
<wire x1="55.245" y1="56.515" x2="52.705" y2="56.515" width="1.4224" layer="1"/>
<wire x1="52.705" y1="56.515" x2="48.895" y2="56.515" width="1.4224" layer="1"/>
<wire x1="48.895" y1="56.515" x2="48.26" y2="56.515" width="1.4224" layer="1"/>
<wire x1="48.26" y1="56.515" x2="46.99" y2="56.515" width="1.4224" layer="1"/>
<wire x1="46.99" y1="56.515" x2="45.085" y2="58.42" width="1.4224" layer="1"/>
<wire x1="45.085" y1="58.42" x2="45.085" y2="65.405" width="1.4224" layer="1"/>
<wire x1="45.085" y1="65.405" x2="43.18" y2="67.31" width="1.4224" layer="1"/>
<wire x1="43.18" y1="67.31" x2="43.18" y2="76.2" width="1.4224" layer="1"/>
<via x="43.18" y="76.2" extent="1-16" drill="0.6" shape="square"/>
<wire x1="43.18" y1="76.2" x2="43.18" y2="78.105" width="1.4224" layer="16"/>
<wire x1="149.225" y1="97.155" x2="159.385" y2="86.995" width="1.016" layer="16"/>
<wire x1="159.385" y1="86.995" x2="170.18" y2="76.2" width="1.016" layer="16"/>
<wire x1="169.545" y1="46.99" x2="170.053" y2="46.736" width="0.8128" layer="16"/>
<wire x1="170.053" y1="46.736" x2="170.815" y2="46.355" width="0.8128" layer="16"/>
<wire x1="170.18" y1="76.2" x2="170.18" y2="47.625" width="1.016" layer="16"/>
<wire x1="170.18" y1="47.625" x2="171.1325" y2="46.6725" width="0.8128" layer="16"/>
<wire x1="151.13" y1="74.295" x2="154.94" y2="78.105" width="1.016" layer="16"/>
<wire x1="154.94" y1="78.105" x2="166.37" y2="78.105" width="1.016" layer="16"/>
<wire x1="166.37" y1="78.105" x2="168.91" y2="75.565" width="0.8128" layer="16"/>
<wire x1="168.91" y1="75.565" x2="168.91" y2="48.895" width="0.8128" layer="16"/>
<wire x1="168.91" y1="48.895" x2="170.18" y2="47.625" width="0.8128" layer="16"/>
<wire x1="126.365" y1="61.91" x2="126.685" y2="62.23" width="0.4064" layer="1"/>
<wire x1="148.905" y1="44.45" x2="148.905" y2="46.67" width="0.8128" layer="1"/>
<wire x1="148.905" y1="46.67" x2="149.225" y2="46.99" width="0.4064" layer="1"/>
<wire x1="148.905" y1="48.895" x2="148.905" y2="47.31" width="0.8128" layer="1"/>
<wire x1="148.905" y1="47.31" x2="149.225" y2="46.99" width="0.4064" layer="1"/>
<wire x1="139.38" y1="48.895" x2="139.38" y2="47.31" width="0.8128" layer="1"/>
<wire x1="139.38" y1="47.31" x2="139.7" y2="46.99" width="0.4064" layer="1"/>
<wire x1="139.38" y1="45.085" x2="139.38" y2="46.67" width="0.8128" layer="1"/>
<wire x1="139.38" y1="46.67" x2="139.7" y2="46.99" width="0.4064" layer="1"/>
<wire x1="126.365" y1="61.91" x2="126.365" y2="58.74" width="0.8128" layer="1"/>
<wire x1="126.365" y1="58.74" x2="126.685" y2="58.42" width="0.4064" layer="1"/>
<via x="136.525" y="40.64" extent="1-16" drill="0.6" shape="square"/>
<via x="152.4" y="43.815" extent="1-16" drill="0.6" shape="square"/>
<wire x1="152.4" y1="43.815" x2="152.4" y2="46.355" width="0.8128" layer="1"/>
<wire x1="116.145" y1="62.865" x2="114.3" y2="62.865" width="0.4064" layer="1"/>
<wire x1="114.3" y1="62.865" x2="112.395" y2="60.96" width="0.8128" layer="1"/>
<wire x1="112.395" y1="60.96" x2="110.49" y2="60.96" width="0.8128" layer="1"/>
<wire x1="110.49" y1="60.96" x2="111.125" y2="61.595" width="0.4064" layer="1"/>
<via x="111.125" y="61.595" extent="1-16" drill="0.6" shape="square"/>
<wire x1="111.125" y1="61.595" x2="112.395" y2="61.595" width="0.8128" layer="16"/>
<wire x1="112.395" y1="61.595" x2="120.015" y2="69.215" width="0.8128" layer="16"/>
<wire x1="120.015" y1="69.215" x2="134.9375" y2="69.215" width="0.8128" layer="16"/>
<wire x1="134.9375" y1="69.215" x2="142.5575" y2="61.595" width="0.8128" layer="16"/>
<wire x1="142.5575" y1="61.595" x2="165.1" y2="61.595" width="0.8128" layer="16"/>
<wire x1="165.1" y1="61.595" x2="166.37" y2="60.325" width="0.8128" layer="16"/>
<wire x1="166.37" y1="60.325" x2="166.37" y2="50.419" width="0.8128" layer="16"/>
<wire x1="166.37" y1="50.419" x2="168.783" y2="48.006" width="0.8128" layer="16"/>
<wire x1="98.11" y1="26.67" x2="98.11" y2="28.255" width="0.4064" layer="1"/>
<wire x1="98.11" y1="28.255" x2="97.79" y2="28.575" width="0.4064" layer="1"/>
<wire x1="97.79" y1="28.575" x2="97.155" y2="28.575" width="0.8128" layer="1"/>
<via x="97.155" y="28.575" extent="1-16" drill="0.6" shape="square"/>
<wire x1="97.155" y1="28.575" x2="149.225" y2="28.575" width="1.016" layer="16"/>
<wire x1="158.75" y1="46.355" x2="169.672" y2="46.355" width="1.016" layer="16"/>
<wire x1="169.672" y1="46.355" x2="170.053" y2="46.736" width="0.4064" layer="16"/>
<contactref element="U$2" pad="GND"/>
<contactref element="U$8" pad="GND"/>
<wire x1="151.765" y1="46.355" x2="150.495" y2="46.355" width="0.8128" layer="1"/>
<wire x1="150.495" y1="46.355" x2="149.86" y2="46.99" width="0.8128" layer="1"/>
<wire x1="149.225" y1="46.99" x2="145.415" y2="46.99" width="0.8128" layer="1"/>
<wire x1="145.415" y1="46.99" x2="141.605" y2="46.99" width="0.6096" layer="1"/>
<wire x1="141.605" y1="46.99" x2="139.7" y2="46.99" width="0.8128" layer="1"/>
<wire x1="139.7" y1="46.99" x2="135.255" y2="46.99" width="0.8128" layer="1"/>
<wire x1="135.255" y1="46.99" x2="131.445" y2="46.99" width="0.6096" layer="1"/>
<wire x1="149.86" y1="46.99" x2="149.225" y2="46.99" width="0.8128" layer="1"/>
<contactref element="C5" pad="2"/>
<wire x1="120.65" y1="17.78" x2="120.65" y2="15.24" width="0.6096" layer="1"/>
<wire x1="120.65" y1="15.24" x2="118.745" y2="15.24" width="0.6096" layer="1"/>
<wire x1="118.745" y1="15.24" x2="118.11" y2="15.875" width="0.6096" layer="1"/>
<wire x1="118.11" y1="15.875" x2="117.475" y2="15.875" width="0.6096" layer="1"/>
<wire x1="117.475" y1="15.875" x2="115.57" y2="17.78" width="0.6096" layer="1"/>
<wire x1="115.57" y1="17.78" x2="113.665" y2="17.78" width="0.6096" layer="1"/>
<wire x1="113.665" y1="17.78" x2="113.03" y2="17.145" width="0.6096" layer="1"/>
<wire x1="113.03" y1="17.145" x2="113.03" y2="15.24" width="0.6096" layer="1"/>
<wire x1="113.03" y1="15.24" x2="110.49" y2="15.24" width="0.6096" layer="1"/>
<wire x1="110.49" y1="15.24" x2="107.95" y2="17.78" width="0.6096" layer="1"/>
<wire x1="107.95" y1="17.78" x2="106.045" y2="17.78" width="0.6096" layer="1"/>
<wire x1="106.045" y1="17.78" x2="105.41" y2="17.145" width="0.6096" layer="1"/>
<wire x1="105.41" y1="17.145" x2="105.41" y2="15.24" width="0.6096" layer="1"/>
<wire x1="105.41" y1="15.24" x2="102.87" y2="15.24" width="0.6096" layer="1"/>
<wire x1="102.87" y1="15.24" x2="100.33" y2="17.78" width="0.6096" layer="1"/>
<wire x1="100.33" y1="17.78" x2="98.425" y2="17.78" width="0.8128" layer="1"/>
<wire x1="98.425" y1="17.78" x2="97.79" y2="17.145" width="0.8128" layer="1"/>
<wire x1="97.79" y1="17.145" x2="97.79" y2="15.24" width="0.8128" layer="1"/>
<wire x1="31.115" y1="73.025" x2="31.115" y2="74.295" width="0.8128" layer="1"/>
<wire x1="31.115" y1="48.26" x2="27.94" y2="48.26" width="0.6096" layer="1"/>
<wire x1="36.195" y1="29.845" x2="36.195" y2="28.575" width="0.8128" layer="1"/>
<wire x1="36.195" y1="28.575" x2="36.195" y2="27.305" width="0.8128" layer="1"/>
<wire x1="28.575" y1="26.67" x2="27.94" y2="27.305" width="0.8128" layer="1"/>
<wire x1="66.04" y1="23.495" x2="56.515" y2="13.97" width="0.8128" layer="1"/>
<wire x1="56.515" y1="13.97" x2="50.8" y2="13.97" width="0.8128" layer="1"/>
<wire x1="50.8" y1="13.97" x2="36.195" y2="28.575" width="0.8128" layer="1"/>
<wire x1="142.24" y1="87.63" x2="142.24" y2="80.9625" width="0.8128" layer="1"/>
<wire x1="142.24" y1="80.9625" x2="141.2875" y2="80.01" width="0.8128" layer="1"/>
<wire x1="149.225" y1="97.155" x2="94.615" y2="97.155" width="1.016" layer="16"/>
<wire x1="141.2875" y1="80.01" x2="141.2875" y2="80.9625" width="0.8128" layer="1"/>
<wire x1="141.2875" y1="80.9625" x2="143.51" y2="83.185" width="0.8128" layer="1"/>
<wire x1="143.51" y1="83.185" x2="143.51" y2="85.09" width="0.8128" layer="1"/>
<wire x1="143.51" y1="85.09" x2="145.415" y2="86.995" width="0.8128" layer="1"/>
<via x="145.415" y="86.995" extent="1-16" drill="0.6" shape="square"/>
<wire x1="145.415" y1="86.995" x2="159.385" y2="86.995" width="0.8128" layer="16"/>
<wire x1="96.52" y1="80.33" x2="98.595" y2="80.33" width="0.8128" layer="1"/>
<wire x1="98.595" y1="80.33" x2="98.595" y2="79.205" width="0.8128" layer="1"/>
<wire x1="98.595" y1="79.205" x2="100.05503125" y2="76.676240625" width="0.8128" layer="1"/>
<wire x1="100.05503125" y1="76.676240625" x2="100.33" y2="76.2" width="0.8128" layer="1"/>
<wire x1="60.96" y1="75.25" x2="63.67" y2="75.25" width="0.8128" layer="1"/>
<contactref element="C6" pad="2"/>
<contactref element="C10" pad="2"/>
<contactref element="C13" pad="2"/>
<contactref element="C12" pad="2"/>
<contactref element="C11" pad="2"/>
<contactref element="C7" pad="2"/>
<contactref element="C8" pad="2"/>
<wire x1="60.96" y1="75.25" x2="60.96" y2="74.295" width="0.8128" layer="1"/>
<wire x1="60.96" y1="74.295" x2="58.42" y2="71.755" width="0.8128" layer="1"/>
<via x="58.42" y="71.755" extent="1-16" drill="0.6" shape="square"/>
<wire x1="58.42" y1="71.755" x2="65.405" y2="71.755" width="1.016" layer="16"/>
<wire x1="65.405" y1="71.755" x2="78.105" y2="84.455" width="1.016" layer="16"/>
<wire x1="78.105" y1="84.455" x2="81.915" y2="84.455" width="1.016" layer="16"/>
<wire x1="81.915" y1="84.455" x2="94.615" y2="97.155" width="1.016" layer="16"/>
<wire x1="97.155" y1="76.33" x2="100.2" y2="76.33" width="0.8128" layer="1"/>
<wire x1="100.2" y1="76.33" x2="100.33" y2="76.2" width="0.8128" layer="1"/>
<wire x1="101.6" y1="76.835" x2="100.213790625" y2="76.835" width="0.8128" layer="1"/>
<wire x1="100.213790625" y1="76.835" x2="100.05503125" y2="76.676240625" width="0.8128" layer="1"/>
<wire x1="131.1275" y1="80.01" x2="130.81" y2="80.01" width="0.8128" layer="1"/>
<wire x1="130.81" y1="80.01" x2="130.81" y2="76.835" width="0.8128" layer="1"/>
<wire x1="130.81" y1="76.835" x2="131.1275" y2="76.5175" width="0.8128" layer="1"/>
<wire x1="131.1275" y1="76.5175" x2="132.08" y2="75.565" width="0.8128" layer="1"/>
<wire x1="132.08" y1="75.565" x2="140.335" y2="75.565" width="0.8128" layer="1"/>
<wire x1="140.335" y1="75.565" x2="141.605" y2="76.835" width="0.8128" layer="1"/>
<wire x1="141.605" y1="76.835" x2="141.605" y2="79.6925" width="0.8128" layer="1"/>
<wire x1="141.605" y1="79.6925" x2="141.2875" y2="80.01" width="0.8128" layer="1"/>
<wire x1="117.255" y1="76.2" x2="130.81" y2="76.2" width="0.8128" layer="1"/>
<wire x1="130.81" y1="76.2" x2="131.1275" y2="76.5175" width="0.8128" layer="1"/>
<wire x1="118.745" y1="55.88" x2="118.745" y2="58.42" width="0.8128" layer="1"/>
<wire x1="118.745" y1="58.42" x2="119.38" y2="59.055" width="0.8128" layer="1"/>
<wire x1="119.38" y1="59.055" x2="126.05" y2="59.055" width="0.8128" layer="1"/>
<wire x1="126.05" y1="59.055" x2="126.685" y2="58.42" width="0.8128" layer="1"/>
<wire x1="131.445" y1="46.99" x2="130.175" y2="46.99" width="0.8128" layer="1"/>
<wire x1="130.175" y1="46.99" x2="129.54" y2="47.625" width="0.8128" layer="1"/>
<wire x1="129.54" y1="47.625" x2="129.54" y2="51.435" width="0.8128" layer="1"/>
<wire x1="129.54" y1="51.435" x2="126.365" y2="54.61" width="0.8128" layer="1"/>
<wire x1="126.365" y1="54.61" x2="126.365" y2="58.1" width="0.8128" layer="1"/>
<wire x1="126.365" y1="58.1" x2="126.685" y2="58.42" width="0.8128" layer="1"/>
<via x="170.815" y="46.355" extent="1-16" drill="0.6" shape="square"/>
<contactref element="C9" pad="2"/>
<wire x1="52.705" y1="55.56" x2="52.705" y2="56.515" width="0.6096" layer="1"/>
<wire x1="55.245" y1="57.47" x2="55.245" y2="56.515" width="0.6096" layer="1"/>
<wire x1="55.245" y1="56.515" x2="55.88" y2="56.515" width="0.6096" layer="1"/>
<wire x1="48.895" y1="57.47" x2="48.895" y2="56.515" width="0.6096" layer="1"/>
<wire x1="57.15" y1="46.675" x2="55.88" y2="46.675" width="0.6096" layer="1"/>
<wire x1="55.88" y1="46.675" x2="54.61" y2="46.675" width="0.6096" layer="1"/>
<wire x1="54.61" y1="46.675" x2="51.75" y2="46.675" width="0.8128" layer="1"/>
<wire x1="51.75" y1="46.675" x2="50.8" y2="47.625" width="0.8128" layer="1"/>
<wire x1="50.8" y1="47.625" x2="50.165" y2="47.625" width="0.8128" layer="1"/>
<wire x1="50.165" y1="47.625" x2="48.26" y2="49.53" width="0.8128" layer="1"/>
<wire x1="48.26" y1="49.53" x2="48.26" y2="56.515" width="0.8128" layer="1"/>
<wire x1="70.485" y1="35.88" x2="67.945" y2="35.88" width="0.8128" layer="1"/>
<wire x1="67.945" y1="35.88" x2="65.405" y2="35.88" width="0.8128" layer="1"/>
<wire x1="65.405" y1="35.88" x2="62.865" y2="35.88" width="0.8128" layer="1"/>
<wire x1="62.865" y1="35.88" x2="58.735" y2="35.88" width="0.8128" layer="1"/>
<wire x1="58.735" y1="35.88" x2="55.88" y2="38.735" width="0.8128" layer="1"/>
<wire x1="55.88" y1="38.735" x2="55.88" y2="46.675" width="0.8128" layer="1"/>
<wire x1="28.2575" y1="75.2475" x2="30.1625" y2="75.2475" width="0.8128" layer="1"/>
<wire x1="30.1625" y1="75.2475" x2="31.115" y2="74.295" width="0.8128" layer="1"/>
<contactref element="C14" pad="2"/>
<contactref element="C15" pad="2"/>
<wire x1="87.945" y1="68.58" x2="87.945" y2="67.31" width="0.4064" layer="1"/>
<wire x1="87.945" y1="67.31" x2="88.265" y2="66.99" width="0.4064" layer="1"/>
<wire x1="87.945" y1="68.58" x2="87.945" y2="68.895" width="0.4064" layer="1"/>
<wire x1="87.945" y1="68.895" x2="95.25" y2="76.2" width="0.8128" layer="1"/>
<wire x1="95.25" y1="76.2" x2="97.025" y2="76.2" width="0.8128" layer="1"/>
<wire x1="97.025" y1="76.2" x2="97.155" y2="76.33" width="0.4064" layer="1"/>
<wire x1="71.834375" y1="58.499375" x2="76.279375" y2="58.499375" width="0.4064" layer="1"/>
<contactref element="C16" pad="2"/>
<wire x1="76.279375" y1="58.499375" x2="85.010625" y2="58.499375" width="0.4064" layer="1"/>
<wire x1="85.010625" y1="58.499375" x2="85.725" y2="57.785" width="0.8128" layer="1"/>
<wire x1="85.725" y1="57.785" x2="85.725" y2="56.835" width="0.8128" layer="1"/>
<wire x1="85.725" y1="56.835" x2="86.045" y2="56.515" width="0.4064" layer="1"/>
<wire x1="152.4" y1="43.815" x2="139.7" y2="43.815" width="1.27" layer="16"/>
<wire x1="139.7" y1="43.815" x2="136.525" y2="40.64" width="1.27" layer="16"/>
<wire x1="149.225" y1="28.575" x2="156.845" y2="36.195" width="1.016" layer="16"/>
<wire x1="156.845" y1="36.195" x2="156.845" y2="44.45" width="1.016" layer="16"/>
<wire x1="156.845" y1="44.45" x2="158.75" y2="46.355" width="1.016" layer="16"/>
<wire x1="165.735" y1="66.675" x2="144.78" y2="66.675" width="0.8128" layer="16"/>
<wire x1="144.78" y1="66.675" x2="144.145" y2="66.04" width="0.8128" layer="16"/>
<wire x1="36.195" y1="27.305" x2="35.56" y2="26.67" width="0.8128" layer="1"/>
<wire x1="35.56" y1="26.67" x2="32.385" y2="23.495" width="0.8128" layer="1"/>
<wire x1="32.385" y1="23.495" x2="26.035" y2="23.495" width="0.8128" layer="1"/>
<wire x1="28.575" y1="26.67" x2="35.56" y2="26.67" width="0.8128" layer="1"/>
<wire x1="-44.45" y1="55.88" x2="27.94" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="-81.915" y1="53.975" x2="-44.45" y2="55.88" width="0" layer="19" extent="1-1"/>
<wire x1="-81.915" y1="61.595" x2="-81.915" y2="53.975" width="0" layer="19" extent="1-1"/>
<wire x1="-81.915" y1="45.72" x2="-81.915" y2="53.975" width="0" layer="19" extent="1-1"/>
<wire x1="-81.915" y1="37.465" x2="-81.915" y2="45.72" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$5">
<contactref element="U$3" pad="1"/>
<contactref element="U$1" pad="29"/>
<wire x1="72.151875" y1="55.165625" x2="72.151875" y2="34.686875" width="0.4064" layer="1"/>
<wire x1="72.151875" y1="34.686875" x2="71.12" y2="33.655" width="0.4064" layer="1"/>
<wire x1="71.12" y1="33.655" x2="53.975" y2="33.655" width="0.8128" layer="1"/>
<wire x1="53.975" y1="33.655" x2="53.975" y2="34.925" width="1.016" layer="1"/>
<wire x1="53.975" y1="34.925" x2="53.975" y2="36.83" width="1.016" layer="1"/>
<wire x1="53.975" y1="36.83" x2="52.07" y2="38.735" width="1.016" layer="1"/>
<wire x1="52.07" y1="38.735" x2="50.165" y2="40.64" width="0.8128" layer="1"/>
<wire x1="50.165" y1="40.64" x2="47.625" y2="40.64" width="0.8128" layer="1"/>
<via x="47.625" y="40.64" extent="1-16" drill="0.6" shape="square"/>
<wire x1="47.625" y1="40.64" x2="46.355" y2="40.64" width="0.8128" layer="16"/>
<wire x1="46.355" y1="40.64" x2="43.815" y2="38.1" width="0.8128" layer="16"/>
<wire x1="43.815" y1="38.1" x2="43.815" y2="23.495" width="0.8128" layer="16"/>
<wire x1="43.815" y1="23.495" x2="37.465" y2="17.145" width="0.8128" layer="16"/>
<wire x1="37.465" y1="17.145" x2="33.655" y2="17.145" width="0.8128" layer="16"/>
<wire x1="33.655" y1="17.145" x2="33.02" y2="17.78" width="0.8128" layer="16"/>
<wire x1="33.02" y1="17.78" x2="26.035" y2="17.78" width="0.8128" layer="16"/>
<via x="26.035" y="17.78" extent="1-16" drill="0.6" shape="square"/>
<wire x1="26.035" y1="17.78" x2="25.4" y2="18.415" width="0.8128" layer="1"/>
<wire x1="53.34" y1="34.925" x2="53.975" y2="34.925" width="0.8128" layer="1"/>
</signal>
<signal name="N$6">
<contactref element="U$1" pad="20"/>
<contactref element="C1" pad="1"/>
<wire x1="67.230625" y1="60.086875" x2="55.326875" y2="60.086875" width="0.4064" layer="1"/>
<wire x1="55.326875" y1="60.086875" x2="55.245" y2="59.37" width="0.4064" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="IC2" pad="1"/>
<contactref element="R9" pad="2"/>
<contactref element="R7" pad="P$1"/>
<wire x1="137.22" y1="33.655" x2="139.7" y2="33.655" width="0.4064" layer="1"/>
<wire x1="139.7" y1="33.655" x2="143.51" y2="37.465" width="0.8128" layer="1"/>
<wire x1="143.51" y1="37.465" x2="143.51" y2="45.72" width="0.8128" layer="1"/>
<wire x1="143.51" y1="45.72" x2="145.735" y2="45.72" width="0.8128" layer="1"/>
<wire x1="145.735" y1="45.72" x2="147.005" y2="44.45" width="0.8128" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="D1_CELLA1" pad="C"/>
<contactref element="T1_CELLA1" pad="2"/>
<wire x1="-35.56" y1="15.995" x2="-36.195" y2="15.995" width="1.016" layer="1"/>
<wire x1="-27.94" y1="52.705" x2="10.795" y2="52.705" width="1.016" layer="1"/>
<wire x1="10.795" y1="52.705" x2="10.795" y2="81.28" width="1.016" layer="1"/>
<wire x1="10.795" y1="81.28" x2="0.635" y2="81.28" width="1.016" layer="1"/>
<wire x1="-35.56" y1="15.995" x2="-35.045" y2="15.995" width="1.016" layer="1"/>
<wire x1="-35.045" y1="15.995" x2="-34.925" y2="15.875" width="1.016" layer="1"/>
<wire x1="-34.925" y1="15.875" x2="-34.925" y2="19.685" width="1.016" layer="1"/>
<wire x1="-34.925" y1="19.685" x2="-33.02" y2="21.59" width="1.016" layer="1"/>
<wire x1="-33.02" y1="21.59" x2="-28.575" y2="21.59" width="1.016" layer="1"/>
<wire x1="-28.575" y1="21.59" x2="-28.575" y2="52.07" width="1.016" layer="1"/>
<wire x1="-28.575" y1="52.07" x2="-27.94" y2="52.705" width="1.016" layer="1"/>
</signal>
<signal name="N$12" airwireshidden="yes">
<contactref element="R1" pad="2"/>
<contactref element="R17" pad="P$1"/>
<contactref element="T1_CELLA1" pad="3"/>
<wire x1="0.635" y1="83.82" x2="10.795" y2="83.82" width="1.016" layer="1"/>
<wire x1="-86.36" y1="67.31" x2="-75.565" y2="67.31" width="1.016" layer="1"/>
<wire x1="-75.565" y1="67.31" x2="-75.565" y2="53.975" width="1.016" layer="1"/>
<wire x1="-75.565" y1="53.975" x2="-64.135" y2="53.975" width="1.016" layer="1"/>
<contactref element="JP6" pad="3"/>
<wire x1="-57.785" y1="50.8" x2="-60.325" y2="50.8" width="1.016" layer="1"/>
<wire x1="-60.325" y1="50.8" x2="-64.135" y2="53.975" width="1.016" layer="1"/>
<wire x1="-86.36" y1="100.33" x2="10.795" y2="100.33" width="1.016" layer="1"/>
<wire x1="10.795" y1="83.82" x2="10.795" y2="100.33" width="1.016" layer="1"/>
<wire x1="-86.36" y1="100.33" x2="-86.36" y2="67.31" width="1.016" layer="1"/>
<contactref element="JP7" pad="3"/>
<wire x1="121.92" y1="40.005" x2="121.285" y2="40.005" width="0.4064" layer="1"/>
<wire x1="108.585" y1="55.88" x2="102.235" y2="55.88" width="0.8128" layer="1"/>
<wire x1="102.235" y1="55.88" x2="100.965" y2="54.61" width="0.8128" layer="1"/>
<wire x1="100.965" y1="54.61" x2="100.965" y2="51.435" width="0.8128" layer="1"/>
<wire x1="100.965" y1="51.435" x2="101.6" y2="50.8" width="0.8128" layer="1"/>
<wire x1="101.6" y1="50.8" x2="105.41" y2="50.8" width="0.8128" layer="1"/>
<wire x1="121.285" y1="40.005" x2="121.285" y2="43.18" width="0.8128" layer="1"/>
<wire x1="121.285" y1="43.18" x2="108.585" y2="55.88" width="0.8128" layer="1"/>
<wire x1="10.795" y1="83.82" x2="100.965" y2="54.61" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$14" airwireshidden="yes">
<contactref element="R7" pad="P$2"/>
<contactref element="R13" pad="2"/>
<contactref element="T1_CELLA1" pad="1"/>
<contactref element="JP4" pad="4"/>
<wire x1="-24.13" y1="55.88" x2="-22.86" y2="54.61" width="1.016" layer="1"/>
<wire x1="-22.86" y1="54.61" x2="8.89" y2="54.61" width="1.016" layer="1"/>
<wire x1="8.89" y1="54.61" x2="8.89" y2="78.74" width="1.016" layer="1"/>
<wire x1="8.89" y1="78.74" x2="0.635" y2="78.74" width="1.016" layer="1"/>
<wire x1="-22.225" y1="56.515" x2="-22.225" y2="59.69" width="1.016" layer="1"/>
<wire x1="-22.225" y1="56.515" x2="-22.86" y2="55.88" width="1.016" layer="1"/>
<wire x1="-22.86" y1="55.88" x2="-24.13" y2="55.88" width="1.016" layer="1"/>
<contactref element="JP9" pad="4"/>
<wire x1="143.51" y1="48.26" x2="143.51" y2="54.61" width="0.8128" layer="1"/>
<wire x1="143.51" y1="54.61" x2="142.24" y2="55.88" width="0.8128" layer="1"/>
<wire x1="142.24" y1="55.88" x2="139.065" y2="55.88" width="0.8128" layer="1"/>
<wire x1="143.51" y1="48.26" x2="146.37" y2="48.26" width="0.8128" layer="1"/>
<wire x1="146.37" y1="48.26" x2="147.005" y2="48.895" width="0.4064" layer="1"/>
<wire x1="8.89" y1="54.61" x2="139.065" y2="55.88" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="R3" pad="P$2"/>
<contactref element="R4" pad="P$1"/>
<contactref element="IC3" pad="1"/>
<wire x1="116.145" y1="66.675" x2="112.395" y2="66.675" width="0.4064" layer="1"/>
<wire x1="112.395" y1="66.675" x2="111.76" y2="67.31" width="0.8128" layer="1"/>
<wire x1="111.76" y1="67.31" x2="111.76" y2="68.58" width="0.8128" layer="1"/>
<wire x1="111.76" y1="68.58" x2="112.395" y2="69.215" width="0.8128" layer="1"/>
<wire x1="112.395" y1="69.215" x2="114.935" y2="69.215" width="0.8128" layer="1"/>
<wire x1="117.475" y1="68.58" x2="117.475" y2="69.215" width="0.4064" layer="1"/>
<wire x1="117.475" y1="69.215" x2="114.935" y2="69.215" width="0.8128" layer="1"/>
</signal>
<signal name="N$4" airwireshidden="yes">
<contactref element="R4" pad="P$2"/>
<contactref element="R5" pad="2"/>
<contactref element="T2_CELLA3" pad="1"/>
<contactref element="JP4" pad="2"/>
<wire x1="-29.21" y1="55.88" x2="-29.21" y2="59.055" width="1.016" layer="1"/>
<wire x1="-29.21" y1="59.055" x2="-29.845" y2="59.69" width="1.016" layer="1"/>
<contactref element="JP9" pad="2"/>
<wire x1="121.92" y1="69.215" x2="128.27" y2="69.215" width="0.8128" layer="1"/>
<wire x1="128.27" y1="69.215" x2="133.985" y2="63.5" width="0.8128" layer="1"/>
<wire x1="133.985" y1="63.5" x2="133.985" y2="55.88" width="0.8128" layer="1"/>
<wire x1="121.92" y1="69.535" x2="121.92" y2="69.215" width="0.4064" layer="1"/>
<wire x1="121.92" y1="69.215" x2="120.65" y2="69.215" width="0.8128" layer="1"/>
<wire x1="120.65" y1="69.215" x2="120.015" y2="68.58" width="0.8128" layer="1"/>
<wire x1="-29.21" y1="59.055" x2="-29.21" y2="59.69" width="0.8128" layer="1"/>
<wire x1="-29.845" y1="60.325" x2="-29.21" y2="59.69" width="0.8128" layer="16"/>
<wire x1="-29.21" y1="59.69" x2="-29.21" y2="55.88" width="0.8128" layer="16"/>
<wire x1="-29.21" y1="59.69" x2="-29.845" y2="60.325" width="0.8128" layer="1"/>
<via x="-29.845" y="60.325" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-29.845" y1="60.325" x2="-29.845" y2="60.96" width="0.8128" layer="16"/>
<wire x1="-29.845" y1="60.96" x2="-31.75" y2="62.865" width="0.8128" layer="16"/>
<wire x1="-31.75" y1="62.865" x2="-46.355" y2="62.865" width="0.8128" layer="16"/>
<wire x1="-46.355" y1="62.865" x2="-49.53" y2="59.69" width="0.8128" layer="16"/>
<wire x1="-49.53" y1="59.69" x2="-49.53" y2="36.83" width="0.8128" layer="16"/>
<wire x1="-49.53" y1="36.83" x2="-55.245" y2="31.115" width="0.8128" layer="16"/>
<wire x1="-55.245" y1="31.115" x2="-72.39" y2="31.115" width="0.8128" layer="16"/>
<wire x1="-72.39" y1="31.115" x2="-72.39" y2="30.48" width="0.8128" layer="16"/>
<wire x1="-72.39" y1="30.48" x2="-76.2" y2="26.67" width="0.8128" layer="16"/>
<wire x1="-76.2" y1="26.67" x2="-77.47" y2="26.67" width="0.8128" layer="16"/>
<wire x1="-77.47" y1="26.67" x2="-78.74" y2="27.94" width="0.8128" layer="16"/>
<via x="-78.74" y="27.94" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-78.74" y1="27.94" x2="-78.105" y2="27.94" width="0.8128" layer="1"/>
<wire x1="-78.105" y1="27.94" x2="-76.835" y2="26.67" width="0.8128" layer="1"/>
<wire x1="-29.21" y1="59.69" x2="120.015" y2="68.58" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$8" airwireshidden="yes">
<contactref element="T2_CELLA3" pad="3"/>
<contactref element="R18" pad="P$1"/>
<contactref element="R8" pad="2"/>
<wire x1="-76.835" y1="21.59" x2="-72.39" y2="21.59" width="1.016" layer="1"/>
<wire x1="-72.39" y1="21.59" x2="-72.39" y2="40.005" width="1.016" layer="1"/>
<contactref element="JP6" pad="1"/>
<wire x1="-64.135" y1="37.465" x2="-57.785" y2="37.465" width="1.016" layer="1"/>
<wire x1="-57.785" y1="37.465" x2="-57.785" y2="45.72" width="1.016" layer="1"/>
<wire x1="-72.39" y1="40.005" x2="-67.31" y2="40.005" width="1.016" layer="1"/>
<wire x1="-67.31" y1="40.005" x2="-64.135" y2="37.465" width="1.016" layer="1"/>
<contactref element="JP7" pad="1"/>
<wire x1="107.315" y1="65.405" x2="106.045" y2="65.405" width="0.8128" layer="1"/>
<wire x1="106.045" y1="65.405" x2="97.79" y2="57.15" width="0.8128" layer="1"/>
<wire x1="97.79" y1="57.15" x2="97.79" y2="46.355" width="0.8128" layer="1"/>
<wire x1="97.79" y1="46.355" x2="98.425" y2="45.72" width="0.8128" layer="1"/>
<wire x1="98.425" y1="45.72" x2="105.41" y2="45.72" width="0.8128" layer="1"/>
<wire x1="-57.785" y1="45.72" x2="97.79" y2="46.355" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$9">
<contactref element="D2_CELLA3" pad="C"/>
<contactref element="T2_CELLA3" pad="2"/>
<wire x1="-76.835" y1="24.13" x2="-84.455" y2="24.13" width="1.016" layer="1"/>
<wire x1="-46.355" y1="5.715" x2="-46.355" y2="19.05" width="1.016" layer="1"/>
<wire x1="-46.355" y1="19.05" x2="-43.18" y2="19.05" width="1.016" layer="1"/>
<wire x1="-43.18" y1="19.05" x2="-43.18" y2="15.995" width="1.016" layer="1"/>
<wire x1="-46.355" y1="5.715" x2="-67.945" y2="5.715" width="1.016" layer="1"/>
<wire x1="-67.945" y1="5.715" x2="-84.455" y2="22.225" width="1.016" layer="1"/>
<wire x1="-84.455" y1="22.225" x2="-84.455" y2="24.13" width="1.016" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="D3_CELLA2" pad="C"/>
<contactref element="T3_CELLA2" pad="2"/>
<wire x1="-36.83" y1="52.705" x2="-36.83" y2="98.425" width="1.016" layer="1"/>
<wire x1="-36.83" y1="98.425" x2="-66.04" y2="98.425" width="1.016" layer="1"/>
<wire x1="-66.04" y1="98.425" x2="-66.04" y2="91.44" width="1.016" layer="1"/>
<wire x1="-36.83" y1="52.705" x2="-30.48" y2="52.705" width="1.016" layer="1"/>
<wire x1="-30.48" y1="52.705" x2="-30.48" y2="23.495" width="1.016" layer="1"/>
<wire x1="-30.48" y1="23.495" x2="-34.29" y2="23.495" width="1.016" layer="1"/>
<wire x1="-34.29" y1="23.495" x2="-39.37" y2="18.415" width="1.016" layer="1"/>
<wire x1="-39.37" y1="18.415" x2="-39.37" y2="15.995" width="1.016" layer="1"/>
<wire x1="-39.37" y1="15.875" x2="-39.37" y2="15.995" width="1.016" layer="1"/>
</signal>
<signal name="N$18" airwireshidden="yes">
<contactref element="T3_CELLA2" pad="3"/>
<contactref element="R20" pad="P$1"/>
<contactref element="R2" pad="2"/>
<contactref element="JP6" pad="4"/>
<wire x1="-57.785" y1="53.34" x2="-57.785" y2="61.595" width="1.016" layer="1"/>
<wire x1="-57.785" y1="61.595" x2="-64.135" y2="61.595" width="1.016" layer="1"/>
<contactref element="JP7" pad="4"/>
<wire x1="121.92" y1="37.465" x2="120.65" y2="37.465" width="0.8128" layer="1"/>
<wire x1="108.585" y1="53.34" x2="105.41" y2="53.34" width="0.8128" layer="1"/>
<wire x1="120.65" y1="37.465" x2="118.745" y2="39.37" width="0.8128" layer="1"/>
<wire x1="118.745" y1="39.37" x2="118.745" y2="43.18" width="0.8128" layer="1"/>
<wire x1="118.745" y1="43.18" x2="108.585" y2="53.34" width="0.8128" layer="1"/>
<wire x1="-68.58" y1="91.44" x2="-74.93" y2="91.44" width="1.016" layer="1"/>
<wire x1="-74.93" y1="91.44" x2="-76.835" y2="89.535" width="1.016" layer="1"/>
<wire x1="-76.835" y1="89.535" x2="-84.455" y2="89.535" width="1.016" layer="1"/>
<wire x1="-84.455" y1="89.535" x2="-84.455" y2="69.215" width="1.016" layer="1"/>
<wire x1="-84.455" y1="69.215" x2="-73.66" y2="69.215" width="1.016" layer="1"/>
<wire x1="-73.66" y1="69.215" x2="-73.66" y2="59.69" width="1.016" layer="1"/>
<wire x1="-73.66" y1="59.69" x2="-64.135" y2="59.69" width="1.016" layer="1"/>
<wire x1="-64.135" y1="59.69" x2="-64.135" y2="61.595" width="1.016" layer="1"/>
<wire x1="-57.785" y1="53.34" x2="105.41" y2="53.34" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$20" airwireshidden="yes">
<contactref element="R10" pad="P$2"/>
<contactref element="T3_CELLA2" pad="1"/>
<contactref element="R12" pad="2"/>
<contactref element="JP4" pad="3"/>
<wire x1="-26.67" y1="55.88" x2="-26.67" y2="58.42" width="1.016" layer="1"/>
<wire x1="-26.67" y1="58.42" x2="-25.4" y2="59.69" width="1.016" layer="1"/>
<contactref element="JP9" pad="3"/>
<wire x1="137.48" y1="52.385" x2="136.525" y2="53.34" width="0.8128" layer="1"/>
<wire x1="136.525" y1="53.34" x2="136.525" y2="55.88" width="0.8128" layer="1"/>
<wire x1="133.35" y1="48.26" x2="136.845" y2="48.26" width="0.8128" layer="1"/>
<wire x1="136.845" y1="48.26" x2="137.48" y2="48.895" width="0.8128" layer="1"/>
<wire x1="137.48" y1="48.895" x2="137.48" y2="52.385" width="0.8128" layer="1"/>
<wire x1="-26.67" y1="58.42" x2="-26.67" y2="59.055" width="0.8128" layer="1"/>
<wire x1="-26.67" y1="59.055" x2="-25.4" y2="60.325" width="0.8128" layer="1"/>
<via x="-25.4" y="60.325" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-25.4" y1="84.455" x2="-32.385" y2="91.44" width="0.8128" layer="16"/>
<wire x1="-32.385" y1="91.44" x2="-59.69" y2="91.44" width="0.8128" layer="16"/>
<wire x1="-59.69" y1="91.44" x2="-62.23" y2="93.98" width="0.8128" layer="16"/>
<via x="-62.23" y="93.98" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-62.23" y1="93.98" x2="-62.23" y2="92.71" width="0.8128" layer="1"/>
<wire x1="-62.23" y1="92.71" x2="-63.5" y2="91.44" width="0.8128" layer="1"/>
<wire x1="-25.4" y1="84.455" x2="-25.4" y2="60.325" width="0.8128" layer="16"/>
<wire x1="-26.67" y1="54.61" x2="-26.67" y2="59.055" width="0.8128" layer="16"/>
<wire x1="-26.67" y1="59.055" x2="-25.4" y2="60.325" width="0.8128" layer="16"/>
<wire x1="-25.4" y1="59.69" x2="133.35" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$21">
<contactref element="IC3" pad="7"/>
<contactref element="R14" pad="2"/>
<contactref element="R15" pad="1"/>
<wire x1="130.81" y1="61.91" x2="130.81" y2="64.135" width="0.8128" layer="1"/>
<wire x1="130.81" y1="64.135" x2="129.54" y2="65.405" width="0.8128" layer="1"/>
<wire x1="129.54" y1="65.405" x2="121.345" y2="65.405" width="0.4064" layer="1"/>
<wire x1="128.585" y1="62.23" x2="130.49" y2="62.23" width="0.8128" layer="1"/>
<wire x1="130.49" y1="62.23" x2="130.81" y2="61.91" width="0.4064" layer="1"/>
</signal>
<signal name="N$22" airwireshidden="yes">
<contactref element="R15" pad="2"/>
<contactref element="R16" pad="2"/>
<contactref element="T4_CELLA4" pad="1"/>
<contactref element="JP4" pad="1"/>
<wire x1="-31.75" y1="55.88" x2="-33.02" y2="55.88" width="1.016" layer="1"/>
<wire x1="-33.02" y1="55.88" x2="-33.655" y2="56.515" width="1.016" layer="1"/>
<wire x1="-33.655" y1="56.515" x2="-33.655" y2="59.69" width="1.016" layer="1"/>
<contactref element="JP9" pad="1"/>
<wire x1="131.445" y1="55.88" x2="131.445" y2="57.785" width="0.8128" layer="1"/>
<wire x1="131.445" y1="57.785" x2="131.445" y2="59.375" width="0.8128" layer="1"/>
<wire x1="131.445" y1="59.375" x2="130.81" y2="60.01" width="0.8128" layer="1"/>
<wire x1="128.585" y1="58.42" x2="130.81" y2="58.42" width="0.8128" layer="1"/>
<wire x1="130.81" y1="58.42" x2="131.445" y2="57.785" width="0.8128" layer="1"/>
<wire x1="-33.655" y1="56.515" x2="-33.655" y2="60.325" width="0.8128" layer="1"/>
<via x="-33.655" y="60.325" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-33.655" y1="60.325" x2="-33.655" y2="56.515" width="0.8128" layer="16"/>
<wire x1="-33.655" y1="56.515" x2="-33.02" y2="55.88" width="0.8128" layer="16"/>
<wire x1="-33.02" y1="55.88" x2="-31.75" y2="55.88" width="0.8128" layer="16"/>
<wire x1="-31.75" y1="55.88" x2="-31.75" y2="33.655" width="0.8128" layer="16"/>
<wire x1="-31.75" y1="33.655" x2="-21.59" y2="23.495" width="0.8128" layer="16"/>
<wire x1="-21.59" y1="23.495" x2="-17.78" y2="23.495" width="0.8128" layer="16"/>
<wire x1="-17.78" y1="23.495" x2="-12.065" y2="17.78" width="0.8128" layer="16"/>
<wire x1="-12.065" y1="17.78" x2="-12.065" y2="12.065" width="0.8128" layer="16"/>
<wire x1="-12.065" y1="12.065" x2="-12.7" y2="11.43" width="0.8128" layer="16"/>
<via x="-12.7" y="11.43" extent="1-16" drill="0.6" shape="square"/>
<wire x1="-12.7" y1="11.43" x2="-12.065" y2="12.065" width="0.8128" layer="1"/>
<wire x1="-12.065" y1="12.065" x2="-12.065" y2="13.97" width="0.8128" layer="1"/>
<wire x1="-12.065" y1="17.78" x2="128.585" y2="58.42" width="0" layer="19" extent="1-16"/>
</signal>
<signal name="N$23" airwireshidden="yes">
<contactref element="T4_CELLA4" pad="3"/>
<contactref element="R19" pad="1"/>
<contactref element="R53" pad="1"/>
<wire x1="-6.985" y1="13.97" x2="-6.985" y2="3.81" width="1.016" layer="1"/>
<wire x1="-86.36" y1="33.02" x2="-75.565" y2="33.02" width="1.016" layer="1"/>
<wire x1="-75.565" y1="33.02" x2="-75.565" y2="45.72" width="1.016" layer="1"/>
<wire x1="-75.565" y1="45.72" x2="-64.135" y2="45.72" width="1.016" layer="1"/>
<contactref element="JP6" pad="2"/>
<wire x1="-57.785" y1="48.26" x2="-60.96" y2="48.26" width="1.016" layer="1"/>
<wire x1="-60.96" y1="48.26" x2="-64.135" y2="45.72" width="1.016" layer="1"/>
<wire x1="-6.985" y1="3.81" x2="-86.36" y2="3.81" width="1.016" layer="1"/>
<wire x1="-86.36" y1="3.81" x2="-86.36" y2="33.02" width="1.016" layer="1"/>
<contactref element="JP7" pad="2"/>
<wire x1="99.695" y1="56.515" x2="99.695" y2="48.895" width="0.8128" layer="1"/>
<wire x1="99.695" y1="48.895" x2="100.33" y2="48.26" width="0.8128" layer="1"/>
<wire x1="100.33" y1="48.26" x2="105.41" y2="48.26" width="0.8128" layer="1"/>
<wire x1="99.695" y1="56.515" x2="101.6" y2="58.42" width="0.8128" layer="1"/>
<wire x1="101.6" y1="58.42" x2="105.73" y2="58.42" width="0.8128" layer="1"/>
<wire x1="-6.985" y1="13.97" x2="99.695" y2="48.895" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$24">
<contactref element="D4_CELLA4" pad="C"/>
<contactref element="T4_CELLA4" pad="2"/>
<wire x1="-9.525" y1="13.97" x2="-9.525" y2="5.715" width="1.016" layer="1"/>
<wire x1="-9.525" y1="5.715" x2="-28.575" y2="5.715" width="1.016" layer="1"/>
<wire x1="-28.575" y1="5.715" x2="-28.575" y2="19.05" width="1.016" layer="1"/>
<wire x1="-28.575" y1="19.05" x2="-31.75" y2="19.05" width="1.016" layer="1"/>
<wire x1="-31.75" y1="19.05" x2="-31.75" y2="15.995" width="1.016" layer="1"/>
</signal>
<signal name="TILTAS_3">
<contactref element="R18" pad="P$2"/>
<contactref element="IC3" pad="2"/>
<contactref element="U$1" pad="26"/>
<wire x1="116.145" y1="65.405" x2="109.855" y2="65.405" width="0.4064" layer="1"/>
<wire x1="109.855" y1="65.405" x2="109.855" y2="68.58" width="0.8128" layer="1"/>
<wire x1="109.855" y1="68.58" x2="109.22" y2="69.215" width="0.8128" layer="1"/>
<wire x1="109.22" y1="69.215" x2="106.68" y2="69.215" width="0.8128" layer="1"/>
<wire x1="106.68" y1="69.215" x2="106.045" y2="69.85" width="0.4064" layer="1"/>
<wire x1="69.770625" y1="55.165625" x2="69.770625" y2="47.545625" width="0.4064" layer="1"/>
<via x="66.675" y="41.275" extent="1-16" drill="0.6" shape="square"/>
<wire x1="66.675" y1="41.275" x2="66.675" y2="45.085" width="0.8128" layer="16"/>
<wire x1="66.675" y1="45.085" x2="67.31" y2="45.72" width="0.8128" layer="16"/>
<wire x1="67.31" y1="45.72" x2="88.265" y2="45.72" width="0.8128" layer="16"/>
<wire x1="88.265" y1="45.72" x2="90.805" y2="48.26" width="0.8128" layer="16"/>
<wire x1="90.805" y1="48.26" x2="90.805" y2="52.07" width="0.8128" layer="16"/>
<wire x1="90.805" y1="52.07" x2="105.41" y2="66.675" width="0.8128" layer="16"/>
<wire x1="105.41" y1="66.675" x2="105.41" y2="69.215" width="0.8128" layer="16"/>
<wire x1="69.770625" y1="47.545625" x2="69.215" y2="46.99" width="0.4064" layer="1"/>
<wire x1="69.215" y1="46.99" x2="65.405" y2="46.99" width="0.4064" layer="1"/>
<wire x1="65.405" y1="46.99" x2="64.77" y2="46.355" width="0.4064" layer="1"/>
<wire x1="64.77" y1="46.355" x2="64.77" y2="43.815" width="0.8128" layer="1"/>
<wire x1="64.77" y1="43.815" x2="66.675" y2="41.275" width="0.8128" layer="1"/>
<contactref element="C9" pad="1"/>
<wire x1="65.405" y1="37.78" x2="65.405" y2="38.1" width="0.6096" layer="1"/>
<wire x1="65.405" y1="38.1" x2="66.04" y2="39.37" width="0.8128" layer="1"/>
<wire x1="66.04" y1="39.37" x2="66.04" y2="40.64" width="0.8128" layer="1"/>
<wire x1="66.04" y1="40.64" x2="66.675" y2="41.275" width="0.6096" layer="1"/>
<via x="105.41" y="69.215" extent="1-16" drill="0.6" shape="square"/>
<wire x1="105.41" y1="69.215" x2="106.045" y2="69.85" width="0.6096" layer="1"/>
</signal>
<signal name="TILTAS_4">
<contactref element="IC3" pad="6"/>
<contactref element="R19" pad="2"/>
<contactref element="U$1" pad="28"/>
<wire x1="124.46" y1="60.96" x2="124.46" y2="63.5" width="0.8128" layer="1"/>
<wire x1="124.46" y1="63.5" x2="123.825" y2="64.135" width="0.8128" layer="1"/>
<wire x1="123.825" y1="64.135" x2="121.345" y2="64.135" width="0.4064" layer="1"/>
<wire x1="114.935" y1="59.055" x2="114.935" y2="57.785" width="0.8128" layer="1"/>
<wire x1="114.935" y1="57.785" x2="114.3" y2="57.15" width="0.4064" layer="1"/>
<via x="70.485" y="40.64" extent="1-16" drill="0.6" shape="square"/>
<wire x1="97.155" y1="50.8" x2="103.505" y2="57.15" width="0.8128" layer="16"/>
<wire x1="103.505" y1="57.15" x2="113.665" y2="57.15" width="0.8128" layer="16"/>
<wire x1="71.358125" y1="55.165625" x2="71.358125" y2="41.513125" width="0.4064" layer="1"/>
<wire x1="71.358125" y1="41.513125" x2="70.485" y2="40.64" width="0.4064" layer="1"/>
<wire x1="97.155" y1="50.8" x2="97.155" y2="45.085" width="0.8128" layer="16"/>
<wire x1="114.935" y1="59.055" x2="108.265" y2="59.055" width="0.8128" layer="1"/>
<wire x1="108.265" y1="59.055" x2="107.63" y2="58.42" width="0.4064" layer="1"/>
<contactref element="C11" pad="1"/>
<wire x1="114.935" y1="59.055" x2="116.84" y2="60.96" width="0.8128" layer="1"/>
<wire x1="116.84" y1="60.96" x2="124.46" y2="60.96" width="0.8128" layer="1"/>
<wire x1="70.485" y1="37.78" x2="70.485" y2="40.64" width="0.8128" layer="1"/>
<wire x1="113.665" y1="57.15" x2="114.3" y2="56.515" width="0.6096" layer="16"/>
<via x="114.3" y="56.515" extent="1-16" drill="0.6" shape="square"/>
<wire x1="114.3" y1="56.515" x2="114.3" y2="57.15" width="0.6096" layer="1"/>
<wire x1="70.485" y1="40.64" x2="85.725" y2="40.64" width="0.8128" layer="16"/>
<wire x1="85.725" y1="40.64" x2="86.36" y2="41.275" width="0.8128" layer="16"/>
<wire x1="86.36" y1="41.275" x2="93.345" y2="41.275" width="0.8128" layer="16"/>
<wire x1="93.345" y1="41.275" x2="97.155" y2="45.085" width="0.8128" layer="16"/>
</signal>
<signal name="TILTAS_2">
<contactref element="R20" pad="P$2"/>
<contactref element="IC2" pad="6"/>
<contactref element="U$1" pad="24"/>
<wire x1="132.02" y1="36.195" x2="125.73" y2="36.195" width="0.4064" layer="1"/>
<wire x1="125.73" y1="36.195" x2="124.46" y2="37.465" width="0.8128" layer="1"/>
<wire x1="124.46" y1="37.465" x2="127" y2="37.465" width="0.8128" layer="1"/>
<wire x1="67.230625" y1="56.911875" x2="62.626875" y2="56.911875" width="0.4064" layer="1"/>
<via x="59.69" y="50.165" extent="1-16" drill="0.6" shape="square"/>
<wire x1="59.69" y1="50.165" x2="58.42" y2="48.895" width="0.8128" layer="16"/>
<wire x1="58.42" y1="48.895" x2="58.42" y2="36.195" width="0.8128" layer="16"/>
<wire x1="58.42" y1="36.195" x2="60.325" y2="34.29" width="0.6096" layer="16"/>
<wire x1="60.325" y1="34.29" x2="97.155" y2="34.29" width="0.6096" layer="16"/>
<wire x1="97.155" y1="34.29" x2="100.33" y2="37.465" width="0.6096" layer="16"/>
<wire x1="62.626875" y1="56.911875" x2="62.23" y2="56.515" width="0.4064" layer="1"/>
<wire x1="62.23" y1="56.515" x2="62.23" y2="55.88" width="0.4064" layer="1"/>
<wire x1="62.23" y1="55.88" x2="62.865" y2="55.245" width="0.4064" layer="1"/>
<wire x1="62.865" y1="55.245" x2="64.135" y2="55.245" width="0.4064" layer="1"/>
<wire x1="64.135" y1="55.245" x2="64.77" y2="54.61" width="0.4064" layer="1"/>
<wire x1="64.77" y1="54.61" x2="64.77" y2="52.705" width="0.4064" layer="1"/>
<wire x1="64.77" y1="52.705" x2="62.865" y2="50.8" width="0.8128" layer="1"/>
<wire x1="62.865" y1="50.8" x2="60.325" y2="50.8" width="0.8128" layer="1"/>
<wire x1="60.325" y1="50.8" x2="59.69" y2="50.165" width="0.4064" layer="1"/>
<contactref element="C7" pad="1"/>
<wire x1="100.33" y1="37.465" x2="127" y2="37.465" width="0.8128" layer="16"/>
<via x="127" y="37.465" extent="1-16" drill="0.6" shape="square"/>
<wire x1="57.15" y1="48.575" x2="58.1" y2="48.575" width="0.6096" layer="1"/>
<wire x1="58.1" y1="48.575" x2="59.69" y2="50.165" width="0.6096" layer="1"/>
</signal>
<signal name="TILTAS_1">
<contactref element="IC2" pad="2"/>
<contactref element="R17" pad="P$2"/>
<contactref element="U$1" pad="23"/>
<wire x1="141.605" y1="37.465" x2="139.065" y2="34.925" width="0.8128" layer="1"/>
<wire x1="139.065" y1="34.925" x2="137.22" y2="34.925" width="0.4064" layer="1"/>
<wire x1="124.46" y1="40.005" x2="125.73" y2="40.005" width="0.8128" layer="1"/>
<wire x1="125.73" y1="40.005" x2="127" y2="41.275" width="0.8128" layer="1"/>
<wire x1="127" y1="41.275" x2="127" y2="42.545" width="0.8128" layer="1"/>
<wire x1="127" y1="42.545" x2="127.635" y2="43.18" width="0.4064" layer="1"/>
<wire x1="67.230625" y1="57.705625" x2="62.150625" y2="57.705625" width="0.4064" layer="1"/>
<wire x1="62.150625" y1="57.705625" x2="60.96" y2="56.515" width="0.4064" layer="1"/>
<wire x1="60.96" y1="56.515" x2="60.96" y2="55.88" width="0.4064" layer="1"/>
<wire x1="60.96" y1="55.88" x2="59.055" y2="53.975" width="0.8128" layer="1"/>
<via x="59.055" y="53.975" extent="1-16" drill="0.6" shape="square"/>
<wire x1="59.055" y1="53.975" x2="58.42" y2="53.34" width="0.4064" layer="16"/>
<wire x1="58.42" y1="53.34" x2="56.515" y2="51.435" width="0.8128" layer="16"/>
<wire x1="56.515" y1="51.435" x2="56.515" y2="35.56" width="0.8128" layer="16"/>
<wire x1="56.515" y1="35.56" x2="59.055" y2="33.02" width="0.6096" layer="16"/>
<wire x1="59.055" y1="33.02" x2="99.695" y2="33.02" width="0.6096" layer="16"/>
<wire x1="99.695" y1="33.02" x2="102.235" y2="35.56" width="0.6096" layer="16"/>
<wire x1="102.235" y1="35.56" x2="123.19" y2="35.56" width="0.8128" layer="16"/>
<wire x1="123.19" y1="35.56" x2="125.73" y2="33.02" width="0.8128" layer="16"/>
<wire x1="125.73" y1="33.02" x2="127" y2="33.02" width="0.8128" layer="16"/>
<wire x1="127" y1="33.02" x2="128.905" y2="34.925" width="0.8128" layer="16"/>
<wire x1="128.905" y1="34.925" x2="128.905" y2="41.275" width="0.8128" layer="16"/>
<wire x1="128.905" y1="41.275" x2="127.3175" y2="42.8625" width="0.8128" layer="16"/>
<wire x1="141.605" y1="37.465" x2="141.605" y2="41.91" width="0.8128" layer="1"/>
<wire x1="141.605" y1="41.91" x2="140.97" y2="42.545" width="0.8128" layer="1"/>
<wire x1="140.97" y1="42.545" x2="127" y2="42.545" width="0.8128" layer="1"/>
<via x="127" y="42.545" extent="1-16" drill="0.6" shape="square"/>
<wire x1="127" y1="42.545" x2="127.3175" y2="42.8625" width="0.8128" layer="16"/>
<contactref element="C6" pad="1"/>
<wire x1="54.61" y1="48.575" x2="54.61" y2="48.895" width="0.6096" layer="1"/>
<wire x1="54.61" y1="48.895" x2="57.15" y2="51.435" width="0.8128" layer="1"/>
<wire x1="57.15" y1="51.435" x2="57.15" y2="52.07" width="0.6096" layer="1"/>
<wire x1="57.15" y1="52.07" x2="59.055" y2="53.975" width="0.6096" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="R21" pad="1"/>
<contactref element="R22" pad="1"/>
<contactref element="C2" pad="1"/>
<contactref element="IC4" pad="3"/>
<wire x1="102.81" y1="31.75" x2="100.33" y2="31.75" width="0.4064" layer="1"/>
<wire x1="100.33" y1="31.75" x2="99.695" y2="32.385" width="0.8128" layer="1"/>
<wire x1="99.695" y1="32.385" x2="97.79" y2="32.385" width="0.8128" layer="1"/>
<wire x1="97.79" y1="32.385" x2="95.57" y2="32.385" width="0.8128" layer="1"/>
<wire x1="95.57" y1="32.385" x2="95.25" y2="32.065" width="0.4064" layer="1"/>
<wire x1="97.79" y1="32.065" x2="97.79" y2="32.385" width="0.4064" layer="1"/>
<wire x1="95.25" y1="33.975" x2="95.25" y2="32.065" width="0.8128" layer="1"/>
</signal>
<signal name="+5V" airwireshidden="yes">
<contactref element="SG1" pad="+"/>
<contactref element="U$1" pad="6"/>
<contactref element="U$1" pad="4"/>
<contactref element="IC1" pad="2"/>
<contactref element="U$1" pad="18"/>
<contactref element="C4" pad="1"/>
<contactref element="R50" pad="1"/>
<contactref element="U$7" pad="P$2"/>
<contactref element="R42" pad="E"/>
<wire x1="57.8104" y1="93.3196" x2="54.3204" y2="93.3196" width="1.016" layer="1"/>
<wire x1="54.3204" y1="93.3196" x2="53.975" y2="93.665" width="1.016" layer="1"/>
<wire x1="110.81" y1="76.2" x2="110.49" y2="76.2" width="0.4064" layer="1"/>
<contactref element="R45" pad="1"/>
<wire x1="76.279375" y1="60.880625" x2="83.899375" y2="60.880625" width="0.4064" layer="1"/>
<wire x1="83.899375" y1="60.880625" x2="84.455" y2="60.325" width="0.4064" layer="1"/>
<wire x1="76.279375" y1="59.293125" x2="83.423125" y2="59.293125" width="0.4064" layer="1"/>
<wire x1="83.423125" y1="59.293125" x2="84.455" y2="60.325" width="0.4064" layer="1"/>
<wire x1="76.279375" y1="60.880625" x2="71.199375" y2="60.880625" width="0.4064" layer="1"/>
<wire x1="71.199375" y1="60.880625" x2="70.485" y2="61.595" width="0.4064" layer="1"/>
<wire x1="70.485" y1="61.595" x2="67.31" y2="61.595" width="0.4064" layer="1"/>
<wire x1="67.31" y1="61.595" x2="67.230625" y2="61.674375" width="0.4064" layer="1"/>
<wire x1="67.230625" y1="61.674375" x2="59.610625" y2="61.674375" width="0.4064" layer="1"/>
<wire x1="59.610625" y1="61.674375" x2="59.055" y2="62.23" width="0.4064" layer="1"/>
<wire x1="59.055" y1="62.23" x2="52.07" y2="62.23" width="1.016" layer="1"/>
<wire x1="52.07" y1="62.23" x2="45.72" y2="68.58" width="1.016" layer="1"/>
<wire x1="45.72" y1="68.58" x2="45.72" y2="80.645" width="1.016" layer="1"/>
<wire x1="45.72" y1="80.645" x2="53.34" y2="88.265" width="1.016" layer="1"/>
<wire x1="53.34" y1="88.265" x2="59.69" y2="88.265" width="1.016" layer="1"/>
<wire x1="59.69" y1="88.265" x2="60.325" y2="88.265" width="1.016" layer="1"/>
<wire x1="60.96" y1="88.9" x2="60.96" y2="92.075" width="1.016" layer="1"/>
<wire x1="60.96" y1="92.075" x2="59.69" y2="93.345" width="1.016" layer="1"/>
<wire x1="59.69" y1="93.345" x2="57.8358" y2="93.345" width="1.016" layer="1"/>
<wire x1="57.8358" y1="93.345" x2="57.8104" y2="93.3196" width="1.016" layer="1"/>
<wire x1="86.995" y1="60.325" x2="84.455" y2="60.325" width="0.8128" layer="1"/>
<wire x1="61.595" y1="8.89" x2="64.135" y2="6.35" width="0.8128" layer="1"/>
<wire x1="64.135" y1="6.35" x2="69.85" y2="6.35" width="0.8128" layer="1"/>
<wire x1="69.85" y1="6.35" x2="73.025" y2="9.525" width="0.8128" layer="1"/>
<wire x1="73.025" y1="9.525" x2="73.025" y2="11.43" width="0.8128" layer="1"/>
<wire x1="73.025" y1="11.43" x2="77.47" y2="15.875" width="0.8128" layer="1"/>
<wire x1="77.47" y1="15.875" x2="85.09" y2="15.875" width="0.8128" layer="1"/>
<wire x1="85.09" y1="15.875" x2="88.265" y2="19.05" width="0.8128" layer="1"/>
<wire x1="88.265" y1="19.05" x2="88.265" y2="36.83" width="0.8128" layer="1"/>
<wire x1="88.265" y1="36.83" x2="88.265" y2="56.515" width="0.8128" layer="1"/>
<wire x1="88.265" y1="56.515" x2="88.265" y2="59.055" width="0.8128" layer="1"/>
<wire x1="88.265" y1="59.055" x2="86.995" y2="60.325" width="0.8128" layer="1"/>
<contactref element="U$2" pad="5V"/>
<contactref element="U$8" pad="5V"/>
<contactref element="R6" pad="P$1"/>
<contactref element="C5" pad="1"/>
<wire x1="137.16" y1="87.63" x2="138.43" y2="86.36" width="0.8128" layer="1"/>
<wire x1="138.43" y1="86.36" x2="139.065" y2="85.725" width="0.8128" layer="1"/>
<wire x1="139.065" y1="85.725" x2="139.065" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="139.065" y1="80.3275" x2="138.7475" y2="80.01" width="0.8128" layer="1"/>
<wire x1="60.96" y1="88.9" x2="61.595" y2="87.63" width="0.8128" layer="1"/>
<wire x1="61.595" y1="87.63" x2="83.185" y2="87.63" width="0.8128" layer="1"/>
<wire x1="83.185" y1="87.63" x2="95.25" y2="99.695" width="0.8128" layer="1"/>
<wire x1="95.25" y1="99.695" x2="140.97" y2="99.695" width="0.8128" layer="1"/>
<wire x1="140.97" y1="99.695" x2="142.875" y2="97.79" width="0.8128" layer="1"/>
<wire x1="142.875" y1="97.79" x2="142.875" y2="90.805" width="0.8128" layer="1"/>
<wire x1="142.875" y1="90.805" x2="138.43" y2="86.36" width="0.8128" layer="1"/>
<wire x1="60.96" y1="88.9" x2="60.325" y2="88.9" width="0.4064" layer="1"/>
<wire x1="60.325" y1="88.9" x2="59.69" y2="88.265" width="0.4064" layer="1"/>
<wire x1="106.045" y1="75.25" x2="106.045" y2="74.93" width="0.8128" layer="1"/>
<wire x1="106.045" y1="74.93" x2="107.315" y2="73.66" width="0.8128" layer="1"/>
<wire x1="107.315" y1="73.66" x2="110.49" y2="73.66" width="0.8128" layer="1"/>
<wire x1="110.49" y1="73.66" x2="142.24" y2="73.66" width="0.8128" layer="1"/>
<wire x1="142.24" y1="73.66" x2="145.415" y2="76.835" width="0.8128" layer="1"/>
<wire x1="145.415" y1="76.835" x2="145.415" y2="81.915" width="0.8128" layer="1"/>
<wire x1="145.415" y1="81.915" x2="148.59" y2="85.09" width="0.8128" layer="1"/>
<wire x1="148.59" y1="85.09" x2="148.59" y2="89.535" width="0.8128" layer="1"/>
<wire x1="148.59" y1="89.535" x2="147.955" y2="90.17" width="0.8128" layer="1"/>
<wire x1="147.955" y1="90.17" x2="143.51" y2="90.17" width="0.8128" layer="1"/>
<wire x1="143.51" y1="90.17" x2="142.875" y2="90.805" width="0.8128" layer="1"/>
<wire x1="110.49" y1="76.2" x2="110.49" y2="73.66" width="0.8128" layer="1"/>
<wire x1="97.155" y1="73.53" x2="107.185" y2="73.53" width="0.8128" layer="1"/>
<wire x1="107.185" y1="73.53" x2="107.315" y2="73.66" width="0.8128" layer="1"/>
<wire x1="123.825" y1="55.88" x2="123.825" y2="52.07" width="0.8128" layer="1"/>
<wire x1="123.825" y1="55.88" x2="123.825" y2="50.165" width="0.8128" layer="1"/>
<wire x1="123.825" y1="50.165" x2="125.73" y2="48.26" width="0.8128" layer="1"/>
<via x="125.73" y="48.26" extent="1-16" drill="0.6" shape="square"/>
<wire x1="125.73" y1="48.26" x2="125.73" y2="46.355" width="0.8128" layer="16"/>
<wire x1="125.73" y1="46.355" x2="121.285" y2="41.91" width="0.8128" layer="16"/>
<wire x1="121.285" y1="41.91" x2="100.965" y2="41.91" width="0.8128" layer="16"/>
<wire x1="100.965" y1="41.91" x2="95.885" y2="36.83" width="0.8128" layer="16"/>
<wire x1="95.885" y1="36.83" x2="90.17" y2="36.83" width="0.8128" layer="16"/>
<via x="90.17" y="36.83" extent="1-16" drill="0.6" shape="square"/>
<wire x1="90.17" y1="36.83" x2="88.265" y2="36.83" width="0.8128" layer="1"/>
<contactref element="C16" pad="1"/>
<wire x1="87.945" y1="56.515" x2="88.265" y2="56.515" width="0.4064" layer="1"/>
<wire x1="61.595" y1="8.89" x2="48.895" y2="8.89" width="0.8128" layer="1"/>
<wire x1="61.595" y1="11.43" x2="61.595" y2="8.89" width="0.8128" layer="1"/>
<wire x1="48.895" y1="8.89" x2="37.465" y2="20.32" width="0.8128" layer="1"/>
<wire x1="37.465" y1="20.32" x2="26.035" y2="20.32" width="0.8128" layer="1"/>
<wire x1="26.035" y1="20.32" x2="25.4" y2="20.955" width="0.8128" layer="1"/>
<wire x1="-39.37" y1="55.88" x2="25.4" y2="20.955" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$34">
<contactref element="R27" pad="E"/>
<contactref element="R31" pad="2"/>
<wire x1="97.79" y1="9.84" x2="96.205" y2="9.84" width="0.8128" layer="1"/>
<wire x1="96.205" y1="9.84" x2="92.71" y2="13.335" width="0.8128" layer="1"/>
<wire x1="92.71" y1="13.335" x2="92.71" y2="15.24" width="0.8128" layer="1"/>
</signal>
<signal name="N$35">
<contactref element="R26" pad="E"/>
<contactref element="R32" pad="2"/>
<wire x1="102.87" y1="9.84" x2="102.87" y2="10.795" width="0.8128" layer="1"/>
<wire x1="102.87" y1="10.795" x2="100.33" y2="13.335" width="0.8128" layer="1"/>
<wire x1="100.33" y1="13.335" x2="100.33" y2="15.24" width="0.8128" layer="1"/>
</signal>
<signal name="N$1">
<contactref element="R29" pad="2"/>
<contactref element="R25" pad="E"/>
<wire x1="115.89" y1="10.16" x2="115.57" y2="9.84" width="0.4064" layer="1"/>
<wire x1="115.89" y1="10.16" x2="115.57" y2="10.16" width="0.6096" layer="1"/>
<wire x1="115.57" y1="10.16" x2="115.57" y2="15.24" width="0.6096" layer="1"/>
</signal>
<signal name="N$36">
<contactref element="R30" pad="2"/>
<contactref element="R28" pad="E"/>
<wire x1="110.49" y1="9.84" x2="110.805" y2="9.84" width="0.4064" layer="1"/>
<wire x1="110.49" y1="9.84" x2="110.49" y2="12.7" width="0.8128" layer="1"/>
<wire x1="110.49" y1="12.7" x2="107.95" y2="15.24" width="0.8128" layer="1"/>
</signal>
<signal name="N$38">
<contactref element="R25" pad="S"/>
<contactref element="IC2" pad="3"/>
<wire x1="137.22" y1="36.195" x2="135.5725" y2="36.195" width="0.4064" layer="1"/>
<wire x1="135.5725" y1="36.195" x2="135.09625" y2="35.71875" width="0.4064" layer="1"/>
<wire x1="135.09625" y1="35.71875" x2="135.09625" y2="27.14625" width="0.4064" layer="1"/>
<wire x1="135.09625" y1="27.14625" x2="130.175" y2="22.225" width="0.8128" layer="1"/>
<wire x1="130.175" y1="22.225" x2="122.555" y2="22.225" width="0.8128" layer="1"/>
<wire x1="122.555" y1="22.225" x2="120.015" y2="22.225" width="0.6096" layer="1"/>
<wire x1="120.015" y1="22.225" x2="118.11" y2="20.32" width="0.6096" layer="1"/>
<wire x1="118.11" y1="20.32" x2="118.11" y2="17.78" width="0.6096" layer="1"/>
</signal>
<signal name="N$40">
<contactref element="R27" pad="S"/>
<contactref element="IC3" pad="5"/>
<wire x1="121.345" y1="62.865" x2="118.745" y2="62.865" width="0.4064" layer="1"/>
<wire x1="118.745" y1="62.865" x2="118.745" y2="70.485" width="0.4064" layer="1"/>
<wire x1="118.745" y1="70.485" x2="111.76" y2="70.485" width="0.8128" layer="1"/>
<wire x1="94.615" y1="20.32" x2="95.885" y2="21.59" width="0.8128" layer="1"/>
<wire x1="95.885" y1="21.59" x2="108.585" y2="21.59" width="0.8128" layer="1"/>
<wire x1="108.585" y1="21.59" x2="114.935" y2="27.94" width="0.8128" layer="1"/>
<wire x1="114.935" y1="27.94" x2="114.935" y2="36.195" width="0.8128" layer="1"/>
<wire x1="114.935" y1="36.195" x2="111.76" y2="39.37" width="0.8128" layer="1"/>
<wire x1="111.76" y1="39.37" x2="97.79" y2="39.37" width="0.8128" layer="1"/>
<wire x1="97.79" y1="39.37" x2="94.615" y2="42.545" width="0.8128" layer="1"/>
<wire x1="94.615" y1="42.545" x2="94.615" y2="66.04" width="0.8128" layer="1"/>
<wire x1="111.76" y1="70.485" x2="110.49" y2="71.755" width="0.8128" layer="1"/>
<wire x1="110.49" y1="71.755" x2="100.33" y2="71.755" width="0.8128" layer="1"/>
<wire x1="100.33" y1="71.755" x2="94.615" y2="66.04" width="0.8128" layer="1"/>
<wire x1="94.615" y1="20.32" x2="94.615" y2="18.415" width="0.8128" layer="1"/>
<wire x1="94.615" y1="18.415" x2="95.25" y2="17.78" width="0.6096" layer="1"/>
</signal>
<signal name="REF_OPAMP">
<contactref element="R31" pad="1"/>
<contactref element="IC4" pad="2"/>
<contactref element="IC4" pad="1"/>
<contactref element="R23" pad="1"/>
<contactref element="R32" pad="1"/>
<contactref element="R29" pad="1"/>
<contactref element="R30" pad="1"/>
<wire x1="115.57" y1="7.94" x2="110.49" y2="7.94" width="0.8128" layer="1"/>
<wire x1="110.49" y1="7.94" x2="102.87" y2="7.94" width="0.8128" layer="1"/>
<wire x1="102.87" y1="7.94" x2="97.79" y2="7.94" width="0.8128" layer="1"/>
<wire x1="102.81" y1="34.29" x2="104.775" y2="34.29" width="0.8128" layer="1"/>
<wire x1="104.775" y1="34.29" x2="105.41" y2="33.655" width="0.8128" layer="1"/>
<wire x1="105.41" y1="33.655" x2="105.41" y2="27.94" width="0.8128" layer="1"/>
<wire x1="105.41" y1="27.94" x2="104.14" y2="26.67" width="0.8128" layer="1"/>
<wire x1="104.14" y1="26.67" x2="100.01" y2="26.67" width="0.8128" layer="1"/>
<wire x1="102.81" y1="33.02" x2="100.33" y2="33.02" width="0.4064" layer="1"/>
<wire x1="100.33" y1="33.02" x2="99.695" y2="33.655" width="0.4064" layer="1"/>
<wire x1="99.695" y1="33.655" x2="99.695" y2="34.29" width="0.8128" layer="1"/>
<wire x1="99.695" y1="34.29" x2="102.81" y2="34.29" width="0.4064" layer="1"/>
<wire x1="104.14" y1="26.67" x2="104.14" y2="24.765" width="0.8128" layer="1"/>
<wire x1="104.14" y1="24.765" x2="103.505" y2="24.13" width="0.8128" layer="1"/>
<wire x1="103.505" y1="24.13" x2="95.25" y2="24.13" width="0.8128" layer="1"/>
<wire x1="95.25" y1="24.13" x2="90.805" y2="19.685" width="0.8128" layer="1"/>
<wire x1="90.805" y1="19.685" x2="90.805" y2="8.89" width="0.8128" layer="1"/>
<wire x1="90.805" y1="8.89" x2="92.075" y2="7.62" width="0.8128" layer="1"/>
<wire x1="92.075" y1="7.62" x2="97.47" y2="7.62" width="0.8128" layer="1"/>
<wire x1="97.47" y1="7.62" x2="97.79" y2="7.94" width="0.4064" layer="1"/>
</signal>
<signal name="CELLA_ADC_1">
<contactref element="R24" pad="1"/>
<contactref element="R33" pad="2"/>
<contactref element="U$1" pad="19"/>
<wire x1="170.5" y1="74.295" x2="167.955" y2="74.295" width="0.8128" layer="1"/>
<wire x1="167.955" y1="74.295" x2="167.955" y2="72.705" width="0.8128" layer="1"/>
<wire x1="167.955" y1="72.705" x2="167.005" y2="71.755" width="0.8128" layer="1"/>
<wire x1="167.005" y1="71.755" x2="155.575" y2="71.755" width="0.8128" layer="1"/>
<wire x1="155.575" y1="71.755" x2="153.67" y2="73.66" width="0.8128" layer="1"/>
<wire x1="67.230625" y1="60.880625" x2="50.244375" y2="60.880625" width="0.4064" layer="1"/>
<wire x1="50.244375" y1="60.880625" x2="48.895" y2="60.325" width="0.4064" layer="1"/>
<via x="48.895" y="60.325" extent="1-16" drill="0.6" shape="square"/>
<wire x1="48.895" y1="60.325" x2="89.535" y2="60.325" width="0.8128" layer="16"/>
<wire x1="101.6" y1="73.66" x2="144.145" y2="73.66" width="0.8128" layer="16"/>
<wire x1="144.145" y1="73.66" x2="146.685" y2="71.12" width="0.8128" layer="16"/>
<wire x1="146.685" y1="71.12" x2="151.13" y2="71.12" width="0.8128" layer="16"/>
<wire x1="151.13" y1="71.12" x2="153.67" y2="73.66" width="0.8128" layer="16"/>
<contactref element="C12" pad="1"/>
<via x="153.67" y="73.66" extent="1-16" drill="0.6" shape="square"/>
<wire x1="48.895" y1="59.37" x2="48.895" y2="60.325" width="0.6096" layer="1"/>
<wire x1="89.535" y1="60.325" x2="98.425" y2="69.215" width="0.8128" layer="16"/>
<wire x1="98.425" y1="69.215" x2="98.425" y2="71.12" width="0.8128" layer="16"/>
<wire x1="98.425" y1="71.12" x2="100.965" y2="73.66" width="0.8128" layer="16"/>
<wire x1="100.965" y1="73.66" x2="101.6" y2="73.66" width="0.8128" layer="16"/>
</signal>
<signal name="CELLA_ADC_2">
<contactref element="R34" pad="1"/>
<contactref element="R35" pad="2"/>
<contactref element="U$1" pad="22"/>
<wire x1="170.5" y1="69.215" x2="167.955" y2="69.215" width="0.8128" layer="1"/>
<wire x1="167.955" y1="69.215" x2="167.955" y2="67.625" width="0.8128" layer="1"/>
<wire x1="167.955" y1="67.625" x2="167.005" y2="66.675" width="0.8128" layer="1"/>
<wire x1="167.005" y1="66.675" x2="156.21" y2="66.675" width="0.8128" layer="1"/>
<wire x1="156.21" y1="66.675" x2="153.67" y2="69.215" width="0.8128" layer="1"/>
<wire x1="67.230625" y1="58.499375" x2="60.404375" y2="58.499375" width="0.4064" layer="1"/>
<wire x1="60.404375" y1="58.499375" x2="54.61" y2="52.705" width="0.4064" layer="1"/>
<via x="54.61" y="52.705" extent="1-16" drill="0.6" shape="square"/>
<wire x1="54.61" y1="52.705" x2="54.61" y2="53.34" width="0.4064" layer="16"/>
<wire x1="103.505" y1="72.39" x2="142.875" y2="72.39" width="0.8128" layer="16"/>
<wire x1="142.875" y1="72.39" x2="146.685" y2="68.58" width="0.8128" layer="16"/>
<wire x1="146.685" y1="68.58" x2="152.4" y2="68.58" width="0.8128" layer="16"/>
<wire x1="152.4" y1="68.58" x2="153.67" y2="69.215" width="0.8128" layer="16"/>
<contactref element="C13" pad="1"/>
<via x="153.67" y="69.215" extent="1-16" drill="0.6" shape="square"/>
<wire x1="52.705" y1="53.66" x2="52.705" y2="53.34" width="0.6096" layer="1"/>
<wire x1="52.705" y1="53.34" x2="53.34" y2="52.705" width="0.8128" layer="1"/>
<wire x1="53.34" y1="52.705" x2="54.61" y2="52.705" width="0.8128" layer="1"/>
<wire x1="89.535" y1="57.15" x2="56.515" y2="57.15" width="0.8128" layer="16"/>
<wire x1="56.515" y1="57.15" x2="54.61" y2="55.245" width="0.8128" layer="16"/>
<wire x1="54.61" y1="55.245" x2="54.61" y2="52.705" width="0.8128" layer="16"/>
<wire x1="89.535" y1="57.15" x2="100.965" y2="68.58" width="0.8128" layer="16"/>
<wire x1="100.965" y1="68.58" x2="100.965" y2="70.485" width="0.8128" layer="16"/>
<wire x1="100.965" y1="70.485" x2="102.87" y2="72.39" width="0.8128" layer="16"/>
<wire x1="102.87" y1="72.39" x2="103.505" y2="72.39" width="0.8128" layer="16"/>
</signal>
<signal name="CELLA_ADC_3">
<contactref element="R36" pad="1"/>
<contactref element="R37" pad="2"/>
<contactref element="U$1" pad="25"/>
<wire x1="167.955" y1="64.135" x2="170.5" y2="64.135" width="0.8128" layer="1"/>
<wire x1="167.955" y1="64.135" x2="167.955" y2="62.545" width="0.8128" layer="1"/>
<wire x1="167.955" y1="62.545" x2="167.005" y2="61.595" width="0.8128" layer="1"/>
<wire x1="167.005" y1="61.595" x2="156.21" y2="61.595" width="0.8128" layer="1"/>
<wire x1="156.21" y1="61.595" x2="153.67" y2="64.135" width="0.8128" layer="1"/>
<wire x1="68.976875" y1="55.165625" x2="68.976875" y2="48.656875" width="0.4064" layer="1"/>
<wire x1="63.5" y1="41.275" x2="63.5" y2="40.64" width="0.4064" layer="1"/>
<via x="63.5" y="40.64" extent="1-16" drill="0.6" shape="square"/>
<wire x1="63.5" y1="40.64" x2="63.5" y2="45.72" width="0.8128" layer="16"/>
<wire x1="63.5" y1="45.72" x2="65.405" y2="47.625" width="0.8128" layer="16"/>
<wire x1="65.405" y1="47.625" x2="86.995" y2="47.625" width="0.8128" layer="16"/>
<wire x1="86.995" y1="47.625" x2="88.9" y2="49.53" width="0.8128" layer="16"/>
<wire x1="88.9" y1="49.53" x2="88.9" y2="53.975" width="0.8128" layer="16"/>
<wire x1="88.9" y1="53.975" x2="103.505" y2="68.58" width="0.8128" layer="16"/>
<wire x1="103.505" y1="68.58" x2="103.505" y2="70.485" width="0.8128" layer="16"/>
<wire x1="103.505" y1="70.485" x2="104.14" y2="71.12" width="0.8128" layer="16"/>
<wire x1="104.14" y1="71.12" x2="135.41375" y2="71.12" width="0.8128" layer="16"/>
<wire x1="135.41375" y1="71.12" x2="142.39875" y2="64.135" width="0.8128" layer="16"/>
<wire x1="142.39875" y1="64.135" x2="153.67" y2="64.135" width="0.8128" layer="16"/>
<wire x1="68.976875" y1="48.656875" x2="68.58" y2="48.26" width="0.4064" layer="1"/>
<wire x1="68.58" y1="48.26" x2="61.595" y2="48.26" width="0.4064" layer="1"/>
<wire x1="61.595" y1="48.26" x2="59.69" y2="46.355" width="0.8128" layer="1"/>
<wire x1="59.69" y1="46.355" x2="59.69" y2="42.545" width="0.8128" layer="1"/>
<wire x1="59.69" y1="42.545" x2="61.595" y2="40.64" width="0.8128" layer="1"/>
<wire x1="61.595" y1="40.64" x2="63.5" y2="40.64" width="0.8128" layer="1"/>
<contactref element="C8" pad="1"/>
<via x="153.67" y="64.135" extent="1-16" drill="0.6" shape="square"/>
<wire x1="64.135" y1="40.64" x2="63.5" y2="40.64" width="0.8128" layer="1"/>
<wire x1="62.865" y1="37.78" x2="62.865" y2="39.37" width="0.8128" layer="1"/>
<wire x1="62.865" y1="39.37" x2="64.135" y2="40.64" width="0.8128" layer="1"/>
</signal>
<signal name="CELLA_ADC_4">
<contactref element="R38" pad="1"/>
<contactref element="R39" pad="2"/>
<contactref element="U$1" pad="27"/>
<wire x1="70.564375" y1="55.165625" x2="70.564375" y2="44.529375" width="0.4064" layer="1"/>
<wire x1="70.564375" y1="44.529375" x2="69.215" y2="43.18" width="0.4064" layer="1"/>
<wire x1="69.215" y1="43.18" x2="69.215" y2="43.815" width="0.4064" layer="1"/>
<via x="69.215" y="43.815" extent="1-16" drill="0.6" shape="square"/>
<wire x1="69.215" y1="43.815" x2="90.17" y2="43.815" width="0.8128" layer="16"/>
<wire x1="90.17" y1="43.815" x2="93.345" y2="46.99" width="0.8128" layer="16"/>
<wire x1="93.345" y1="46.99" x2="93.345" y2="51.435" width="0.8128" layer="16"/>
<wire x1="93.345" y1="51.435" x2="101.6" y2="59.69" width="0.8128" layer="16"/>
<wire x1="167.955" y1="59.055" x2="170.5" y2="59.055" width="0.8128" layer="1"/>
<wire x1="167.955" y1="59.055" x2="167.955" y2="56.83" width="0.8128" layer="1"/>
<wire x1="167.955" y1="56.83" x2="167.005" y2="55.88" width="0.8128" layer="1"/>
<wire x1="167.005" y1="55.88" x2="164.465" y2="55.88" width="0.8128" layer="1"/>
<wire x1="164.465" y1="55.88" x2="163.83" y2="56.515" width="0.8128" layer="1"/>
<wire x1="163.83" y1="56.515" x2="156.21" y2="56.515" width="0.8128" layer="1"/>
<wire x1="156.21" y1="56.515" x2="150.495" y2="62.23" width="0.8128" layer="1"/>
<wire x1="150.495" y1="62.23" x2="138.43" y2="62.23" width="0.8128" layer="1"/>
<wire x1="138.43" y1="62.23" x2="135.89" y2="59.69" width="0.8128" layer="1"/>
<via x="135.89" y="59.69" extent="1-16" drill="0.6" shape="square"/>
<wire x1="135.89" y1="59.69" x2="101.6" y2="59.69" width="0.8128" layer="16"/>
<contactref element="C10" pad="1"/>
<wire x1="67.945" y1="37.78" x2="67.945" y2="38.735" width="0.8128" layer="1"/>
<wire x1="67.945" y1="38.735" x2="68.58" y2="39.37" width="0.8128" layer="1"/>
<wire x1="68.58" y1="39.37" x2="68.58" y2="43.18" width="0.4064" layer="1"/>
<wire x1="68.58" y1="43.18" x2="69.215" y2="43.815" width="0.4064" layer="1"/>
</signal>
<signal name="CELLA0" airwireshidden="yes">
<contactref element="D1_CELLA1" pad="A"/>
<contactref element="X2" pad="4"/>
<contactref element="JP5" pad="2"/>
<wire x1="-36.195" y1="6.985" x2="-36.195" y2="12.065" width="1.016" layer="1"/>
<wire x1="-36.195" y1="12.065" x2="-35.56" y2="12.065" width="1.016" layer="1"/>
<wire x1="-35.56" y1="12.065" x2="-35.56" y2="11.945" width="1.016" layer="1"/>
<contactref element="JP8" pad="2"/>
<wire x1="161.29" y1="33.528" x2="148.463" y2="33.528" width="1.4224" layer="1"/>
<wire x1="148.463" y1="33.528" x2="144.145" y2="29.21" width="1.4224" layer="1"/>
<wire x1="144.145" y1="29.21" x2="144.145" y2="14.605" width="1.4224" layer="1"/>
<wire x1="144.145" y1="14.605" x2="141.605" y2="12.065" width="1.4224" layer="1"/>
<wire x1="141.605" y1="12.065" x2="128.27" y2="12.065" width="1.4224" layer="1"/>
<wire x1="128.27" y1="12.065" x2="127" y2="10.795" width="1.4224" layer="1"/>
<wire x1="127" y1="10.795" x2="127" y2="6.985" width="1.4224" layer="1"/>
<wire x1="-35.56" y1="12.065" x2="127" y2="10.795" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="CELLA1">
<contactref element="R24" pad="2"/>
<contactref element="X3" pad="4"/>
<wire x1="166.055" y1="74.295" x2="161.417" y2="74.295" width="0.8128" layer="1"/>
<wire x1="161.417" y1="74.295" x2="161.29" y2="74.168" width="0.4064" layer="1"/>
</signal>
<signal name="CELLA4" airwireshidden="yes">
<contactref element="D3_CELLA2" pad="A"/>
<contactref element="X2" pad="3"/>
<contactref element="JP5" pad="3"/>
<wire x1="-39.37" y1="11.945" x2="-38.735" y2="11.945" width="1.016" layer="1"/>
<wire x1="-38.735" y1="11.945" x2="-38.735" y2="6.985" width="1.016" layer="1"/>
<contactref element="JP8" pad="3"/>
<wire x1="147.32" y1="36.195" x2="164.465" y2="36.195" width="1.4224" layer="1"/>
<wire x1="164.465" y1="36.195" x2="166.37" y2="34.29" width="1.4224" layer="1"/>
<wire x1="166.37" y1="34.29" x2="166.37" y2="30.48" width="1.4224" layer="1"/>
<wire x1="166.37" y1="30.48" x2="164.465" y2="28.575" width="1.4224" layer="1"/>
<wire x1="164.465" y1="28.575" x2="161.3154" y2="28.575" width="1.4224" layer="1"/>
<wire x1="161.3154" y1="28.575" x2="161.29" y2="28.5496" width="1.4224" layer="16"/>
<via x="161.3154" y="28.575" extent="1-16" drill="0.6" shape="square"/>
<wire x1="147.32" y1="36.195" x2="141.605" y2="30.48" width="1.4224" layer="1"/>
<wire x1="141.605" y1="30.48" x2="141.605" y2="15.875" width="1.4224" layer="1"/>
<wire x1="141.605" y1="15.875" x2="140.335" y2="14.605" width="1.4224" layer="1"/>
<wire x1="140.335" y1="14.605" x2="127" y2="14.605" width="1.4224" layer="1"/>
<wire x1="127" y1="14.605" x2="124.46" y2="12.065" width="1.4224" layer="1"/>
<wire x1="124.46" y1="12.065" x2="124.46" y2="6.985" width="1.4224" layer="1"/>
<wire x1="-38.735" y1="6.985" x2="124.46" y2="6.985" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="CELLA5">
<contactref element="R34" pad="2"/>
<contactref element="X3" pad="3"/>
<wire x1="166.055" y1="69.215" x2="161.3154" y2="69.215" width="0.8128" layer="1"/>
<wire x1="161.3154" y1="69.215" x2="161.29" y2="69.1896" width="0.4064" layer="1"/>
</signal>
<signal name="CELLA8" airwireshidden="yes">
<contactref element="D2_CELLA3" pad="A"/>
<contactref element="X2" pad="2"/>
<contactref element="JP5" pad="4"/>
<wire x1="-41.275" y1="6.985" x2="-43.18" y2="6.985" width="1.016" layer="1"/>
<wire x1="-43.18" y1="6.985" x2="-43.18" y2="11.945" width="1.016" layer="1"/>
<contactref element="JP8" pad="4"/>
<wire x1="161.29" y1="23.5204" x2="165.0746" y2="23.5204" width="1.4224" layer="1"/>
<wire x1="165.0746" y1="23.5204" x2="166.37" y2="22.225" width="1.4224" layer="1"/>
<wire x1="166.37" y1="22.225" x2="166.37" y2="17.145" width="1.4224" layer="1"/>
<wire x1="166.37" y1="17.145" x2="164.465" y2="15.24" width="1.4224" layer="1"/>
<wire x1="164.465" y1="15.24" x2="160.655" y2="15.24" width="1.4224" layer="1"/>
<wire x1="160.655" y1="15.24" x2="148.59" y2="3.175" width="1.4224" layer="1"/>
<wire x1="148.59" y1="3.175" x2="121.285" y2="3.175" width="1.4224" layer="1"/>
<wire x1="121.285" y1="3.175" x2="121.285" y2="6.35" width="1.4224" layer="1"/>
<wire x1="121.285" y1="6.35" x2="121.92" y2="6.985" width="1.4224" layer="1"/>
<wire x1="-41.275" y1="6.985" x2="121.285" y2="6.35" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="CELLA9">
<contactref element="R36" pad="2"/>
<contactref element="X3" pad="2"/>
<wire x1="161.29" y1="64.1604" x2="166.0296" y2="64.1604" width="0.8128" layer="1"/>
<wire x1="166.0296" y1="64.1604" x2="166.055" y2="64.135" width="0.4064" layer="1"/>
</signal>
<signal name="CELLA12" airwireshidden="yes">
<contactref element="D4_CELLA4" pad="A"/>
<contactref element="X2" pad="1"/>
<contactref element="JP5" pad="1"/>
<wire x1="-33.655" y1="6.985" x2="-31.75" y2="6.985" width="1.016" layer="1"/>
<wire x1="-31.75" y1="6.985" x2="-31.75" y2="11.945" width="1.016" layer="1"/>
<contactref element="JP8" pad="1"/>
<wire x1="161.29" y1="18.542" x2="158.242" y2="18.542" width="1.4224" layer="1"/>
<wire x1="158.242" y1="18.542" x2="146.685" y2="6.985" width="1.4224" layer="1"/>
<wire x1="146.685" y1="6.985" x2="130.175" y2="6.985" width="1.4224" layer="1"/>
<wire x1="130.175" y1="6.985" x2="129.54" y2="6.35" width="1.4224" layer="1"/>
<wire x1="129.54" y1="6.35" x2="129.54" y2="6.985" width="1.4224" layer="1"/>
<wire x1="-31.75" y1="6.985" x2="129.54" y2="6.35" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="CELLA13">
<contactref element="R38" pad="2"/>
<contactref element="X3" pad="1"/>
<wire x1="166.055" y1="59.055" x2="161.417" y2="59.055" width="0.8128" layer="1"/>
<wire x1="161.417" y1="59.055" x2="161.29" y2="59.182" width="0.4064" layer="1"/>
</signal>
<signal name="N$10">
<contactref element="R11" pad="2"/>
<contactref element="IC2" pad="7"/>
<contactref element="R10" pad="P$1"/>
<wire x1="132.02" y1="34.925" x2="123.825" y2="34.925" width="0.4064" layer="1"/>
<wire x1="123.825" y1="42.545" x2="123.19" y2="41.91" width="0.8128" layer="1"/>
<wire x1="123.19" y1="41.91" x2="123.19" y2="35.56" width="0.4064" layer="1"/>
<wire x1="123.19" y1="35.56" x2="123.825" y2="34.925" width="0.8128" layer="1"/>
<wire x1="123.825" y1="44.45" x2="123.825" y2="42.545" width="0.8128" layer="1"/>
<wire x1="133.35" y1="45.72" x2="125.095" y2="45.72" width="0.8128" layer="1"/>
<wire x1="125.095" y1="45.72" x2="123.825" y2="44.45" width="0.8128" layer="1"/>
<wire x1="133.35" y1="45.72" x2="136.845" y2="45.72" width="0.8128" layer="1"/>
<wire x1="136.845" y1="45.72" x2="137.48" y2="45.085" width="0.4064" layer="1"/>
</signal>
<signal name="N$13">
<contactref element="R26" pad="S"/>
<contactref element="IC3" pad="3"/>
<wire x1="96.52" y1="43.18" x2="96.52" y2="59.055" width="0.8128" layer="1"/>
<wire x1="96.52" y1="59.055" x2="104.775" y2="67.31" width="0.8128" layer="1"/>
<wire x1="104.775" y1="67.31" x2="108.585" y2="67.31" width="0.8128" layer="1"/>
<wire x1="108.585" y1="67.31" x2="108.585" y2="63.5" width="0.4064" layer="1"/>
<wire x1="108.585" y1="63.5" x2="111.76" y2="63.5" width="0.8128" layer="1"/>
<wire x1="111.76" y1="63.5" x2="112.395" y2="64.135" width="0.8128" layer="1"/>
<wire x1="112.395" y1="64.135" x2="116.145" y2="64.135" width="0.4064" layer="1"/>
<wire x1="96.52" y1="43.18" x2="99.06" y2="40.64" width="0.8128" layer="1"/>
<wire x1="99.06" y1="40.64" x2="112.395" y2="40.64" width="0.8128" layer="1"/>
<wire x1="112.395" y1="40.64" x2="116.84" y2="36.195" width="0.8128" layer="1"/>
<wire x1="116.84" y1="36.195" x2="116.84" y2="27.305" width="0.8128" layer="1"/>
<wire x1="116.84" y1="27.305" x2="109.855" y2="20.32" width="0.8128" layer="1"/>
<wire x1="109.855" y1="20.32" x2="105.41" y2="20.32" width="0.8128" layer="1"/>
<wire x1="105.41" y1="20.32" x2="102.87" y2="17.78" width="0.6096" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="R28" pad="S"/>
<contactref element="IC2" pad="5"/>
<wire x1="132.02" y1="37.465" x2="133.35" y2="37.465" width="0.4064" layer="1"/>
<wire x1="133.35" y1="37.465" x2="133.985" y2="36.83" width="0.4064" layer="1"/>
<wire x1="133.985" y1="36.83" x2="133.985" y2="29.21" width="0.4064" layer="1"/>
<wire x1="133.985" y1="29.21" x2="130.175" y2="25.4" width="0.8128" layer="1"/>
<wire x1="130.175" y1="25.4" x2="118.11" y2="25.4" width="0.8128" layer="1"/>
<wire x1="110.49" y1="17.78" x2="118.11" y2="25.4" width="0.6096" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="JP1" pad="2"/>
<contactref element="Q1" pad="3"/>
<contactref element="D5" pad="A"/>
<wire x1="65.87" y1="76.2" x2="66.675" y2="76.2" width="0.8128" layer="1"/>
<wire x1="66.675" y1="76.2" x2="66.675" y2="80.645" width="0.8128" layer="1"/>
<wire x1="62.865" y1="79.89" x2="65.92" y2="79.89" width="0.8128" layer="1"/>
<wire x1="65.92" y1="79.89" x2="66.675" y2="80.645" width="0.8128" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="R40" pad="P$2"/>
<contactref element="R41" pad="2"/>
<contactref element="Q1" pad="1"/>
<wire x1="59.055" y1="76.835" x2="60.645" y2="76.835" width="0.8128" layer="1"/>
<wire x1="60.645" y1="76.835" x2="60.96" y2="77.15" width="0.4064" layer="1"/>
<wire x1="60.96" y1="77.15" x2="63.67" y2="77.15" width="0.8128" layer="1"/>
<wire x1="51.435" y1="73.3425" x2="55.5625" y2="73.3425" width="0.8128" layer="1"/>
<wire x1="55.5625" y1="73.3425" x2="59.055" y2="76.835" width="0.8128" layer="1"/>
</signal>
<signal name="FAN">
<contactref element="R40" pad="P$1"/>
<contactref element="U$1" pad="14"/>
<wire x1="70.564375" y1="64.214375" x2="70.564375" y2="73.104375" width="0.4064" layer="1"/>
<wire x1="70.564375" y1="73.104375" x2="73.025" y2="75.565" width="0.4064" layer="1"/>
<wire x1="73.025" y1="75.565" x2="76.2" y2="75.565" width="0.8128" layer="1"/>
<via x="76.2" y="75.565" extent="1-16" drill="0.6" shape="square"/>
<via x="53.975" y="70.485" extent="1-16" drill="0.6" shape="square"/>
<wire x1="53.975" y1="70.485" x2="53.975" y2="70.8025" width="0.4064" layer="1"/>
<wire x1="53.975" y1="70.8025" x2="51.435" y2="70.8025" width="0.8128" layer="1"/>
<wire x1="53.975" y1="70.485" x2="55.88" y2="68.58" width="1.27" layer="16"/>
<wire x1="55.88" y1="68.58" x2="69.215" y2="68.58" width="1.27" layer="16"/>
<wire x1="69.215" y1="68.58" x2="76.2" y2="75.565" width="1.27" layer="16"/>
</signal>
<signal name="REF">
<contactref element="U$1" pad="13"/>
<contactref element="R21" pad="2"/>
<wire x1="93.345" y1="67.945" x2="90.805" y2="65.405" width="0.8128" layer="1"/>
<wire x1="90.805" y1="65.405" x2="90.805" y2="40.32" width="0.8128" layer="1"/>
<wire x1="90.805" y1="40.32" x2="95.25" y2="35.875" width="0.8128" layer="1"/>
<wire x1="71.358125" y1="64.214375" x2="71.358125" y2="71.993125" width="0.4064" layer="1"/>
<wire x1="71.358125" y1="71.993125" x2="73.025" y2="73.66" width="0.4064" layer="1"/>
<wire x1="73.025" y1="73.66" x2="77.47" y2="73.66" width="0.8128" layer="1"/>
<wire x1="77.47" y1="73.66" x2="78.74" y2="74.93" width="0.8128" layer="1"/>
<via x="78.74" y="74.93" extent="1-16" drill="0.6" shape="square"/>
<wire x1="78.74" y1="74.93" x2="84.455" y2="74.93" width="1.016" layer="16"/>
<wire x1="84.455" y1="74.93" x2="91.44" y2="67.945" width="1.016" layer="16"/>
<wire x1="91.44" y1="67.945" x2="93.345" y2="67.945" width="1.016" layer="16"/>
<via x="93.345" y="67.945" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$43">
<contactref element="SG1" pad="-"/>
<contactref element="Q2" pad="3"/>
<wire x1="72.56" y1="19.685" x2="70.485" y2="19.685" width="0.8128" layer="1"/>
<wire x1="70.485" y1="19.685" x2="69.215" y2="18.415" width="0.8128" layer="1"/>
<wire x1="69.215" y1="18.415" x2="69.215" y2="11.43" width="0.8128" layer="1"/>
</signal>
<signal name="N$45">
<contactref element="Q2" pad="1"/>
<contactref element="R43" pad="1"/>
<contactref element="R44" pad="2"/>
<wire x1="74.76" y1="18.735" x2="77.47" y2="18.735" width="0.8128" layer="1"/>
<wire x1="77.47" y1="18.735" x2="81.28" y2="18.735" width="0.8128" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="R42" pad="S"/>
<contactref element="U$7" pad="P$3"/>
<wire x1="136.2075" y1="80.01" x2="136.2075" y2="84.1375" width="0.8128" layer="1"/>
<wire x1="136.2075" y1="84.1375" x2="134.62" y2="85.725" width="0.8128" layer="1"/>
<wire x1="134.62" y1="85.725" x2="134.62" y2="89.535" width="0.8128" layer="1"/>
<wire x1="134.62" y1="89.535" x2="135.255" y2="90.17" width="0.8128" layer="1"/>
<wire x1="135.255" y1="90.17" x2="139.7" y2="90.17" width="0.8128" layer="1"/>
</signal>
<signal name="N$51">
<contactref element="Q3" pad="3"/>
<contactref element="U$7" pad="P$16"/>
<wire x1="100.795" y1="81.28" x2="101.9175" y2="81.28" width="0.8128" layer="1"/>
<wire x1="101.9175" y1="81.28" x2="103.1875" y2="80.01" width="0.8128" layer="1"/>
</signal>
<signal name="N$53">
<contactref element="Q3" pad="1"/>
<contactref element="R46" pad="1"/>
<contactref element="R47" pad="2"/>
<wire x1="96.52" y1="82.23" x2="98.595" y2="82.23" width="0.8128" layer="1"/>
<wire x1="96.52" y1="82.23" x2="94.295" y2="82.23" width="0.8128" layer="1"/>
<wire x1="94.295" y1="82.23" x2="93.98" y2="82.55" width="0.8128" layer="1"/>
<wire x1="93.98" y1="82.23" x2="93.98" y2="82.235" width="0.8128" layer="1"/>
<wire x1="93.98" y1="82.55" x2="93.98" y2="82.23" width="0.8128" layer="1"/>
</signal>
<signal name="N$55">
<contactref element="R45" pad="2"/>
<contactref element="U$7" pad="P$15"/>
<wire x1="105.7275" y1="80.01" x2="105.7275" y2="77.4675" width="0.8128" layer="1"/>
<wire x1="105.7275" y1="77.4675" x2="106.045" y2="77.15" width="0.8128" layer="1"/>
</signal>
<signal name="FEL">
<contactref element="U$1" pad="30"/>
<contactref element="U$9" pad="B2"/>
<wire x1="40.005" y1="35.56" x2="40.005" y2="57.15" width="0.8128" layer="1"/>
<wire x1="72.945625" y1="55.165625" x2="72.945625" y2="32.305625" width="0.4064" layer="1"/>
<wire x1="72.945625" y1="32.305625" x2="72.39" y2="31.75" width="0.4064" layer="1"/>
<wire x1="72.39" y1="31.75" x2="43.815" y2="31.75" width="0.8128" layer="1"/>
<wire x1="43.815" y1="31.75" x2="40.005" y2="35.56" width="0.8128" layer="1"/>
<wire x1="33.655" y1="73.025" x2="33.655" y2="59.69" width="0.8128" layer="1"/>
<wire x1="40.005" y1="57.15" x2="37.465" y2="59.69" width="0.8128" layer="1"/>
<wire x1="37.465" y1="59.69" x2="34.29" y2="59.69" width="0.8128" layer="1"/>
<wire x1="34.29" y1="59.69" x2="33.655" y2="60.325" width="0.8128" layer="1"/>
<via x="33.655" y="60.325" extent="1-16" drill="0.6" shape="square"/>
<wire x1="33.655" y1="60.325" x2="28.575" y2="60.325" width="0.8128" layer="16"/>
<wire x1="28.575" y1="60.325" x2="23.495" y2="55.245" width="0.8128" layer="16"/>
<wire x1="23.495" y1="55.245" x2="23.495" y2="29.21" width="0.8128" layer="16"/>
<wire x1="23.495" y1="29.21" x2="24.13" y2="28.575" width="0.8128" layer="16"/>
<via x="24.13" y="28.575" extent="1-16" drill="0.6" shape="square"/>
<wire x1="24.13" y1="28.575" x2="24.765" y2="28.575" width="0.8128" layer="1"/>
<wire x1="33.655" y1="59.69" x2="34.29" y2="59.69" width="0.8128" layer="1"/>
</signal>
<signal name="OK">
<contactref element="U$1" pad="31"/>
<contactref element="U$10" pad="B2"/>
<wire x1="73.739375" y1="55.165625" x2="73.739375" y2="31.194375" width="0.4064" layer="1"/>
<wire x1="73.739375" y1="31.194375" x2="73.025" y2="30.48" width="0.4064" layer="1"/>
<wire x1="73.025" y1="30.48" x2="42.545" y2="30.48" width="0.8128" layer="1"/>
<wire x1="42.545" y1="30.48" x2="38.735" y2="34.29" width="0.8128" layer="1"/>
<wire x1="38.735" y1="34.29" x2="34.925" y2="34.29" width="0.8128" layer="1"/>
<wire x1="33.655" y1="35.56" x2="33.655" y2="48.26" width="0.8128" layer="1"/>
<wire x1="34.925" y1="34.29" x2="33.655" y2="35.56" width="0.8128" layer="1"/>
<via x="33.655" y="35.56" extent="1-16" drill="0.6" shape="square"/>
<wire x1="33.655" y1="35.56" x2="30.48" y2="35.56" width="0.8128" layer="16"/>
<wire x1="30.48" y1="35.56" x2="27.94" y2="33.02" width="0.8128" layer="16"/>
<wire x1="27.94" y1="33.02" x2="27.94" y2="27.305" width="0.8128" layer="16"/>
<wire x1="27.94" y1="27.305" x2="26.67" y2="26.035" width="0.8128" layer="16"/>
<wire x1="26.67" y1="26.035" x2="24.13" y2="26.035" width="0.8128" layer="16"/>
<via x="24.13" y="26.035" extent="1-16" drill="0.6" shape="square"/>
<wire x1="24.13" y1="26.035" x2="23.495" y2="26.035" width="0.8128" layer="1"/>
</signal>
<signal name="LE">
<contactref element="U$1" pad="32"/>
<contactref element="U$11" pad="A2"/>
<wire x1="74.533125" y1="55.165625" x2="74.533125" y2="29.448125" width="0.4064" layer="1"/>
<wire x1="74.533125" y1="29.448125" x2="73.66" y2="28.575" width="0.4064" layer="1"/>
<wire x1="73.66" y1="28.575" x2="41.91" y2="28.575" width="0.8128" layer="1"/>
<wire x1="41.91" y1="28.575" x2="38.1" y2="32.385" width="0.8128" layer="1"/>
<wire x1="38.1" y1="32.385" x2="33.655" y2="32.385" width="0.8128" layer="1"/>
<wire x1="33.655" y1="29.845" x2="33.655" y2="32.385" width="0.8128" layer="1"/>
</signal>
<signal name="LCD_HATTER">
<contactref element="R46" pad="2"/>
<contactref element="U$1" pad="15"/>
<wire x1="69.770625" y1="64.214375" x2="69.770625" y2="74.850625" width="0.4064" layer="1"/>
<wire x1="69.770625" y1="74.850625" x2="73.025" y2="78.105" width="0.4064" layer="1"/>
<wire x1="73.025" y1="78.105" x2="81.915" y2="78.105" width="0.8128" layer="1"/>
<wire x1="81.915" y1="78.105" x2="82.55" y2="78.74" width="0.4064" layer="1"/>
<via x="82.55" y="78.74" extent="1-16" drill="0.6" shape="square"/>
<wire x1="82.55" y1="78.74" x2="93.345" y2="78.74" width="1.016" layer="16"/>
<wire x1="93.345" y1="78.74" x2="93.98" y2="78.105" width="0.4064" layer="16"/>
<via x="93.98" y="78.105" extent="1-16" drill="0.6" shape="square"/>
<wire x1="93.98" y1="78.105" x2="93.98" y2="80.33" width="0.4064" layer="1"/>
</signal>
<signal name="N$61">
<contactref element="U$1" pad="2"/>
<contactref element="R43" pad="2"/>
<wire x1="76.279375" y1="57.705625" x2="83.264375" y2="57.705625" width="0.4064" layer="1"/>
<wire x1="83.264375" y1="57.705625" x2="83.82" y2="57.15" width="0.4064" layer="1"/>
<wire x1="83.82" y1="57.15" x2="83.82" y2="52.705" width="0.8128" layer="1"/>
<wire x1="83.82" y1="52.705" x2="85.725" y2="50.8" width="0.8128" layer="1"/>
<wire x1="85.725" y1="50.8" x2="85.725" y2="25.08" width="0.8128" layer="1"/>
<wire x1="85.725" y1="25.08" x2="81.28" y2="20.635" width="0.8128" layer="1"/>
</signal>
<signal name="N$47">
<contactref element="R50" pad="2"/>
<contactref element="LED1" pad="A"/>
<wire x1="112.71" y1="76.2" x2="115.155" y2="76.2" width="0.8128" layer="1"/>
</signal>
<signal name="N$65">
<contactref element="X4" pad="1"/>
<contactref element="D6" pad="A"/>
<contactref element="J1" pad="1"/>
<wire x1="31.04" y1="93.345" x2="31.04" y2="92.15" width="1.4224" layer="1"/>
<wire x1="31.04" y1="92.15" x2="35.56" y2="87.63" width="1.4224" layer="1"/>
<wire x1="35.56" y1="87.63" x2="38.1" y2="87.63" width="1.4224" layer="1"/>
<wire x1="38.1" y1="87.63" x2="43.18" y2="92.71" width="1.4224" layer="1"/>
<wire x1="43.18" y1="92.71" x2="43.18" y2="95.2246" width="1.4224" layer="1"/>
<wire x1="43.18" y1="95.2246" x2="43.1546" y2="95.25" width="1.4224" layer="1"/>
<wire x1="43.695" y1="87.63" x2="38.1" y2="87.63" width="1.016" layer="1"/>
</signal>
<signal name="+12V">
<contactref element="IC1" pad="3"/>
<contactref element="C3" pad="1"/>
<contactref element="D6" pad="C"/>
<contactref element="IC2" pad="8"/>
<contactref element="JP1" pad="1"/>
<contactref element="D5" pad="C"/>
<contactref element="IC3" pad="8"/>
<contactref element="IC4" pad="8"/>
<wire x1="57.8104" y1="91.0336" x2="52.07" y2="91.0336" width="1.016" layer="1"/>
<wire x1="52.07" y1="91.0336" x2="51.1486" y2="91.0336" width="1.016" layer="1"/>
<wire x1="51.1486" y1="91.0336" x2="47.745" y2="87.63" width="1.016" layer="1"/>
<wire x1="49.53" y1="91.31" x2="51.7936" y2="91.31" width="1.016" layer="1"/>
<wire x1="51.7936" y1="91.31" x2="52.07" y2="91.0336" width="1.016" layer="1"/>
<wire x1="132.02" y1="33.655" x2="118.745" y2="33.655" width="0.4064" layer="1"/>
<wire x1="108.01" y1="34.29" x2="112.395" y2="34.29" width="0.4064" layer="1"/>
<wire x1="112.395" y1="34.29" x2="113.03" y2="33.655" width="0.4064" layer="1"/>
<via x="113.03" y="33.655" extent="1-16" drill="0.6" shape="square"/>
<wire x1="121.345" y1="66.675" x2="125.095" y2="66.675" width="0.8128" layer="1"/>
<wire x1="125.095" y1="66.675" x2="125.73" y2="67.31" width="0.8128" layer="1"/>
<via x="125.73" y="67.31" extent="1-16" drill="0.6" shape="square"/>
<wire x1="132.715" y1="42.545" x2="132.715" y2="35.56" width="1.016" layer="16"/>
<wire x1="132.715" y1="35.56" x2="128.27" y2="31.115" width="1.016" layer="16"/>
<wire x1="128.27" y1="31.115" x2="120.65" y2="31.115" width="1.016" layer="16"/>
<wire x1="120.65" y1="31.115" x2="118.745" y2="33.02" width="1.016" layer="16"/>
<via x="118.745" y="33.655" extent="1-16" drill="0.6" shape="square"/>
<wire x1="40.005" y1="80.01" x2="43.815" y2="83.82" width="1.016" layer="16"/>
<via x="43.815" y="83.82" extent="1-16" drill="0.6" shape="square"/>
<wire x1="43.815" y1="83.82" x2="45.085" y2="83.82" width="0.8128" layer="1"/>
<wire x1="45.085" y1="83.82" x2="47.625" y2="86.36" width="0.8128" layer="1"/>
<wire x1="47.625" y1="86.36" x2="47.625" y2="87.51" width="0.8128" layer="1"/>
<wire x1="47.625" y1="87.51" x2="47.745" y2="87.63" width="0.8128" layer="1"/>
<wire x1="113.03" y1="33.655" x2="112.395" y2="33.655" width="0.8128" layer="16"/>
<wire x1="112.395" y1="33.655" x2="109.855" y2="31.115" width="1.016" layer="16"/>
<wire x1="118.745" y1="33.655" x2="118.745" y2="33.02" width="0.8128" layer="16"/>
<wire x1="118.745" y1="33.02" x2="117.475" y2="31.75" width="1.016" layer="16"/>
<wire x1="117.475" y1="31.75" x2="114.3" y2="31.75" width="1.016" layer="16"/>
<wire x1="114.3" y1="31.75" x2="113.03" y2="33.02" width="1.016" layer="16"/>
<wire x1="113.03" y1="33.02" x2="113.03" y2="33.655" width="1.016" layer="16"/>
<wire x1="125.73" y1="67.31" x2="133.985" y2="67.31" width="1.016" layer="16"/>
<wire x1="133.985" y1="67.31" x2="141.605" y2="59.69" width="1.016" layer="16"/>
<wire x1="132.715" y1="42.545" x2="141.605" y2="51.435" width="1.016" layer="16"/>
<wire x1="141.605" y1="51.435" x2="141.605" y2="59.69" width="1.016" layer="16"/>
<wire x1="62.865" y1="83.94" x2="65.92" y2="83.94" width="0.8128" layer="1"/>
<wire x1="65.92" y1="83.94" x2="66.675" y2="83.185" width="0.8128" layer="1"/>
<wire x1="40.005" y1="80.01" x2="40.005" y2="74.295" width="1.016" layer="16"/>
<wire x1="40.005" y1="74.295" x2="41.275" y2="73.025" width="1.016" layer="16"/>
<wire x1="41.275" y1="73.025" x2="55.88" y2="73.025" width="1.016" layer="16"/>
<wire x1="55.88" y1="73.025" x2="60.96" y2="78.105" width="0.8128" layer="16"/>
<wire x1="60.96" y1="78.105" x2="60.96" y2="83.185" width="1.016" layer="16"/>
<wire x1="60.96" y1="83.185" x2="60.325" y2="83.82" width="1.016" layer="16"/>
<via x="60.325" y="83.82" extent="1-16" drill="0.6" shape="square"/>
<wire x1="60.325" y1="83.82" x2="62.745" y2="83.82" width="0.8128" layer="1"/>
<wire x1="62.745" y1="83.82" x2="62.865" y2="83.94" width="0.8128" layer="1"/>
<wire x1="40.005" y1="74.295" x2="40.005" y2="55.88" width="1.016" layer="16"/>
<wire x1="40.005" y1="55.88" x2="53.34" y2="42.545" width="1.016" layer="16"/>
<wire x1="53.34" y1="42.545" x2="53.34" y2="34.925" width="1.016" layer="16"/>
<wire x1="53.34" y1="34.925" x2="57.785" y2="30.48" width="1.016" layer="16"/>
<wire x1="57.785" y1="30.48" x2="92.075" y2="30.48" width="1.016" layer="16"/>
<wire x1="92.075" y1="30.48" x2="92.71" y2="31.115" width="1.016" layer="16"/>
<wire x1="92.71" y1="31.115" x2="109.855" y2="31.115" width="1.016" layer="16"/>
</signal>
<signal name="N$69">
<polygon width="1.016" layer="1" isolate="0.8128" rank="5">
<vertex x="12.065" y="2.54"/>
<vertex x="-38.1" y="2.54"/>
<vertex x="-38.1" y="53.34"/>
<vertex x="12.065" y="53.34"/>
</polygon>
</signal>
<signal name="N$70">
<polygon width="1.016" layer="1" isolate="0.8128" rank="2">
<vertex x="-87.63" y="2.54"/>
<vertex x="-87.63" y="53.34"/>
<vertex x="-30.48" y="53.34"/>
<vertex x="-30.48" y="2.54"/>
</polygon>
</signal>
<signal name="N$71">
<polygon width="1.016" layer="1" isolate="0.8128" rank="4">
<vertex x="-37.465" y="52.705"/>
<vertex x="-37.465" y="101.6"/>
<vertex x="-87.63" y="102.235"/>
</polygon>
</signal>
<signal name="N$72">
<vertex x="-36.83" y="53.34"/>
<vertex x="-36.83" y="102.235"/>
<vertex x="12.065" y="102.235"/>
</polygon>
</signal>
<signal name="N$3">
</signal>
<signal name="N$63" airwireshidden="yes">
<contactref element="U$2" pad="DATA"/>
<contactref element="U$8" pad="DATA"/>
<contactref element="R6" pad="P$2"/>
<contactref element="U$1" pad="1"/>
<wire x1="76.279375" y1="56.911875" x2="81.518125" y2="56.911875" width="0.4064" layer="1"/>
<wire x1="81.518125" y1="56.911875" x2="81.915" y2="56.515" width="0.4064" layer="1"/>
<wire x1="81.915" y1="56.515" x2="81.915" y2="49.53" width="0.8128" layer="1"/>
<wire x1="119.38" y1="43.815" x2="99.695" y2="43.815" width="0.8128" layer="16"/>
<wire x1="99.695" y1="43.815" x2="95.25" y2="39.37" width="0.8128" layer="16"/>
<wire x1="60.325" y1="38.1" x2="60.325" y2="46.355" width="0.8128" layer="16"/>
<wire x1="60.325" y1="46.355" x2="63.5" y2="49.53" width="0.8128" layer="16"/>
<wire x1="63.5" y1="49.53" x2="81.915" y2="49.53" width="0.8128" layer="16"/>
<via x="81.915" y="49.53" extent="1-16" drill="0.6" shape="square"/>
<wire x1="121.285" y1="55.88" x2="121.285" y2="52.07" width="0.8128" layer="1"/>
<wire x1="121.285" y1="52.07" x2="121.285" y2="48.895" width="0.8128" layer="1"/>
<wire x1="121.285" y1="48.895" x2="121.92" y2="48.26" width="0.8128" layer="1"/>
<via x="121.92" y="48.26" extent="1-16" drill="0.6" shape="square"/>
<wire x1="121.92" y1="48.26" x2="121.92" y2="46.355" width="0.8128" layer="16"/>
<wire x1="121.92" y1="46.355" x2="119.38" y2="43.815" width="0.8128" layer="16"/>
<wire x1="60.325" y1="38.1" x2="60.96" y2="37.465" width="0.8128" layer="16"/>
<wire x1="60.96" y1="37.465" x2="85.725" y2="37.465" width="0.8128" layer="16"/>
<wire x1="85.725" y1="37.465" x2="87.63" y2="39.37" width="0.8128" layer="16"/>
<wire x1="87.63" y1="39.37" x2="95.25" y2="39.37" width="0.8128" layer="16"/>
<wire x1="-41.91" y1="55.88" x2="60.325" y2="46.355" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$66">
<wire x1="167.005" y1="2.54" x2="175.26" y2="2.54" width="1.016" layer="1"/>
<wire x1="175.26" y1="2.54" x2="175.26" y2="10.795" width="1.016" layer="1"/>
</signal>
<signal name="N$67">
<wire x1="83.82" y1="2.54" x2="75.565" y2="2.54" width="1.016" layer="1"/>
<wire x1="75.565" y1="2.54" x2="75.565" y2="10.795" width="1.016" layer="1"/>
<wire x1="71.755" y1="2.54" x2="16.51" y2="2.54" width="1.016" layer="1"/>
<wire x1="71.755" y1="2.54" x2="75.565" y2="2.54" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$68">
<wire x1="83.185" y1="102.235" x2="75.565" y2="102.235" width="1.016" layer="1"/>
<wire x1="75.565" y1="102.235" x2="75.565" y2="93.98" width="1.016" layer="1"/>
<wire x1="73.66" y1="102.235" x2="16.51" y2="102.235" width="1.016" layer="1"/>
<wire x1="16.51" y1="102.235" x2="16.51" y2="2.54" width="1.016" layer="1"/>
<wire x1="73.66" y1="102.235" x2="75.565" y2="102.235" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$73">
<wire x1="163.83" y1="102.235" x2="175.26" y2="102.235" width="1.016" layer="1"/>
<wire x1="175.26" y1="102.235" x2="175.26" y2="92.075" width="1.016" layer="1"/>
</signal>
<signal name="N$49">
<contactref element="U$11" pad="A0"/>
</signal>
<signal name="N$27">
<contactref element="U$1" pad="17"/>
<contactref element="U$7" pad="P$4"/>
<wire x1="67.230625" y1="62.468125" x2="61.991875" y2="62.468125" width="0.4064" layer="1"/>
<wire x1="61.991875" y1="62.468125" x2="60.325" y2="64.135" width="0.4064" layer="1"/>
<wire x1="60.325" y1="64.135" x2="60.325" y2="69.85" width="0.8128" layer="1"/>
<wire x1="60.325" y1="69.85" x2="62.865" y2="72.39" width="0.8128" layer="1"/>
<wire x1="62.865" y1="72.39" x2="66.675" y2="72.39" width="0.8128" layer="1"/>
<wire x1="66.675" y1="72.39" x2="67.945" y2="73.66" width="0.8128" layer="1"/>
<wire x1="67.945" y1="73.66" x2="67.945" y2="76.835" width="0.8128" layer="1"/>
<wire x1="67.945" y1="76.835" x2="76.835" y2="85.725" width="0.8128" layer="1"/>
<wire x1="76.835" y1="85.725" x2="83.82" y2="85.725" width="0.8128" layer="1"/>
<wire x1="83.82" y1="85.725" x2="89.535" y2="91.44" width="0.8128" layer="1"/>
<wire x1="89.535" y1="91.44" x2="129.54" y2="91.44" width="0.8128" layer="1"/>
<wire x1="129.54" y1="91.44" x2="132.715" y2="88.265" width="0.8128" layer="1"/>
<wire x1="132.715" y1="88.265" x2="132.715" y2="84.455" width="0.8128" layer="1"/>
<wire x1="132.715" y1="84.455" x2="133.985" y2="83.185" width="0.8128" layer="1"/>
<wire x1="133.985" y1="83.185" x2="133.985" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="133.985" y1="80.3275" x2="133.6675" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$28">
<contactref element="U$1" pad="16"/>
<contactref element="U$7" pad="P$6"/>
<wire x1="68.976875" y1="64.214375" x2="68.976875" y2="75.961875" width="0.4064" layer="1"/>
<wire x1="68.976875" y1="75.961875" x2="77.47" y2="84.455" width="0.8128" layer="1"/>
<wire x1="77.47" y1="84.455" x2="84.455" y2="84.455" width="0.8128" layer="1"/>
<wire x1="84.455" y1="84.455" x2="90.17" y2="90.17" width="0.8128" layer="1"/>
<wire x1="90.17" y1="90.17" x2="125.095" y2="90.17" width="0.8128" layer="1"/>
<wire x1="125.095" y1="90.17" x2="128.905" y2="86.36" width="0.8128" layer="1"/>
<wire x1="128.905" y1="86.36" x2="128.905" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="128.905" y1="80.3275" x2="128.5875" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$29">
<contactref element="U$1" pad="12"/>
<contactref element="U$7" pad="P$11"/>
<wire x1="72.151875" y1="64.214375" x2="72.151875" y2="70.881875" width="0.4064" layer="1"/>
<wire x1="72.151875" y1="70.881875" x2="73.66" y2="72.39" width="0.4064" layer="1"/>
<wire x1="73.66" y1="72.39" x2="80.645" y2="72.39" width="0.8128" layer="1"/>
<wire x1="80.645" y1="72.39" x2="87.63" y2="79.375" width="0.8128" layer="1"/>
<wire x1="87.63" y1="79.375" x2="87.63" y2="85.725" width="0.8128" layer="1"/>
<wire x1="87.63" y1="85.725" x2="90.805" y2="88.9" width="0.8128" layer="1"/>
<wire x1="90.805" y1="88.9" x2="114.3" y2="88.9" width="0.8128" layer="1"/>
<wire x1="114.3" y1="88.9" x2="116.205" y2="86.995" width="0.8128" layer="1"/>
<wire x1="116.205" y1="86.995" x2="116.205" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="116.205" y1="80.3275" x2="115.8875" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$30">
<contactref element="U$1" pad="11"/>
<contactref element="U$7" pad="P$12"/>
<wire x1="72.945625" y1="64.214375" x2="72.945625" y2="69.770625" width="0.4064" layer="1"/>
<wire x1="72.945625" y1="69.770625" x2="74.295" y2="71.12" width="0.4064" layer="1"/>
<wire x1="74.295" y1="71.12" x2="81.28" y2="71.12" width="0.8128" layer="1"/>
<wire x1="81.28" y1="71.12" x2="88.9" y2="78.74" width="0.8128" layer="1"/>
<wire x1="88.9" y1="78.74" x2="88.9" y2="85.09" width="0.8128" layer="1"/>
<wire x1="88.9" y1="85.09" x2="91.44" y2="87.63" width="0.8128" layer="1"/>
<wire x1="91.44" y1="87.63" x2="112.395" y2="87.63" width="0.8128" layer="1"/>
<wire x1="112.395" y1="87.63" x2="113.665" y2="86.36" width="0.8128" layer="1"/>
<wire x1="113.665" y1="86.36" x2="113.665" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="113.665" y1="80.3275" x2="113.3475" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$31">
<contactref element="U$1" pad="10"/>
<contactref element="U$7" pad="P$13"/>
<wire x1="73.739375" y1="64.214375" x2="73.739375" y2="68.659375" width="0.4064" layer="1"/>
<wire x1="73.739375" y1="68.659375" x2="74.93" y2="69.85" width="0.4064" layer="1"/>
<wire x1="74.93" y1="69.85" x2="81.915" y2="69.85" width="0.8128" layer="1"/>
<wire x1="81.915" y1="69.85" x2="90.17" y2="78.105" width="0.8128" layer="1"/>
<wire x1="90.17" y1="78.105" x2="90.17" y2="84.455" width="0.8128" layer="1"/>
<wire x1="90.17" y1="84.455" x2="92.075" y2="86.36" width="0.8128" layer="1"/>
<wire x1="92.075" y1="86.36" x2="108.585" y2="86.36" width="0.8128" layer="1"/>
<wire x1="108.585" y1="86.36" x2="110.49" y2="84.455" width="0.8128" layer="1"/>
<wire x1="110.49" y1="84.455" x2="110.49" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="110.49" y1="80.3275" x2="110.8075" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$33">
<contactref element="U$1" pad="9"/>
<contactref element="U$7" pad="P$14"/>
<wire x1="74.533125" y1="64.214375" x2="74.533125" y2="67.548125" width="0.4064" layer="1"/>
<wire x1="74.533125" y1="67.548125" x2="75.565" y2="68.58" width="0.4064" layer="1"/>
<wire x1="75.565" y1="68.58" x2="82.55" y2="68.58" width="0.8128" layer="1"/>
<wire x1="82.55" y1="68.58" x2="91.44" y2="77.47" width="0.8128" layer="1"/>
<wire x1="91.44" y1="77.47" x2="91.44" y2="83.82" width="0.8128" layer="1"/>
<wire x1="91.44" y1="83.82" x2="92.71" y2="85.09" width="0.8128" layer="1"/>
<wire x1="92.71" y1="85.09" x2="106.68" y2="85.09" width="0.8128" layer="1"/>
<wire x1="106.68" y1="85.09" x2="108.585" y2="83.185" width="0.8128" layer="1"/>
<wire x1="108.585" y1="83.185" x2="108.585" y2="80.3275" width="0.8128" layer="1"/>
<wire x1="108.585" y1="80.3275" x2="108.2675" y2="80.01" width="0.4064" layer="1"/>
</signal>
<signal name="N$25">
<via x="83.185" y="94.615" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$37">
<wire x1="1.905" y1="101.6" x2="12.065" y2="101.6" width="0.8128" layer="1"/>
<wire x1="12.065" y1="101.6" x2="12.065" y2="92.075" width="0.8128" layer="1"/>
</signal>
<signal name="N$39">
<wire x1="-78.74" y1="101.6" x2="-87.63" y2="101.6" width="0.8128" layer="1"/>
<wire x1="-87.63" y1="101.6" x2="-87.63" y2="92.71" width="0.8128" layer="1"/>
</signal>
<signal name="N$41">
<wire x1="-76.835" y1="2.54" x2="-87.63" y2="2.54" width="0.8128" layer="1"/>
<wire x1="-87.63" y1="2.54" x2="-87.63" y2="11.43" width="0.8128" layer="1"/>
</signal>
<signal name="N$42">
<wire x1="1.27" y1="2.54" x2="12.065" y2="2.54" width="0.8128" layer="1"/>
<wire x1="12.065" y1="2.54" x2="12.065" y2="13.335" width="0.8128" layer="1"/>
</signal>
<signal name="N$44">
<via x="5.08" y="9.525" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$46">
<via x="-80.01" y="9.525" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$48">
<via x="-80.01" y="94.615" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$50">
<via x="5.08" y="94.615" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$52">
<via x="-16.8275" y="81.28" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$54">
<via x="-66.04" y="73.9775" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$56">
<via x="-59.3725" y="24.28875" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$57">
<via x="-9.525" y="31.4325" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$58">
<via x="168.275" y="94.615" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$59">
<via x="149.86" y="80.01" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$60">
<via x="149.86" y="22.86" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$62">
<via x="168.275" y="9.525" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$64">
<via x="83.185" y="9.525" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$74">
<via x="54.61" y="22.86" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$75">
<via x="55.08625" y="80.01" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$76">
<polygon width="0.8128" layer="16" isolate="1.27">
<vertex x="-87.63" y="101.6"/>
<vertex x="11.43" y="101.6"/>
<vertex x="11.43" y="3.175"/>
<vertex x="-86.995" y="3.175"/>
<vertex x="-86.995" y="100.965"/>
</polygon>
</signal>
<signal name="N$77">
</signal>
<signal name="N$78">
</signal>
<signal name="N$79">
<contactref element="U$1" pad="7"/>
<contactref element="C14" pad="1"/>
<contactref element="Q4" pad="2"/>
<wire x1="76.279375" y1="61.674375" x2="83.264375" y2="61.674375" width="0.4064" layer="1"/>
<wire x1="83.264375" y1="61.674375" x2="85.725" y2="64.135" width="0.4064" layer="1"/>
<wire x1="85.725" y1="64.135" x2="85.725" y2="64.897" width="0.8128" layer="1"/>
<wire x1="85.725" y1="64.897" x2="86.233" y2="65.405" width="0.8128" layer="1"/>
<wire x1="86.233" y1="65.405" x2="87.95" y2="65.405" width="0.8128" layer="1"/>
<wire x1="87.95" y1="65.405" x2="88.265" y2="65.09" width="0.4064" layer="1"/>
</signal>
<signal name="N$80">
<contactref element="U$1" pad="8"/>
<contactref element="C15" pad="1"/>
<contactref element="Q4" pad="1"/>
<wire x1="76.279375" y1="62.468125" x2="81.407" y2="62.468125" width="0.4064" layer="1"/>
<wire x1="81.407" y1="62.468125" x2="81.407" y2="65.405" width="0.4064" layer="1"/>
<wire x1="86.045" y1="68.58" x2="84.582" y2="68.58" width="0.8128" layer="1"/>
<wire x1="84.582" y1="68.58" x2="81.407" y2="65.405" width="0.8128" layer="1"/>
</signal>
</signals>
</board>
</drawing>
<compatibility>
<note version="6.3" minversion="6.2.2" severity="warning">
Since Version 6.2.2 text objects can contain more than one line,
which will not be processed correctly with this version.
</note>
</compatibility>
</eagle>
