 // Flex_LCD420.c 
 // These pins are for my Microchip PicDem2-Plus board, 
 // which I used to test this driver. 
 // An external 20x4 LCD is connected to these pins. 
 // Change these pins to match your own board's connections. 
 #define LCD_DB4   PIN_D4 
 #define LCD_DB5   PIN_D5 
 #define LCD_DB6   PIN_D6 
 #define LCD_DB7   PIN_D7 
 #define LCD_RS    PIN_E0 
 #define LCD_RW    PIN_E1 
 #define LCD_E     PIN_E2 
 // To prove that the driver can be used with random 
 // pins, I also tested it with these pins: 
 #define LCD_DB5   PIN_B1 
 #define LCD_DB6   PIN_C5 
 #define LCD_DB7   PIN_B5 
 #define LCD_RS    PIN_E2 
 #define LCD_RW    PIN_B2 
 #define LCD_E     PIN_D6 
 // If you want only a 6-pin interface to your LCD, then 
 // connect the R/W pin on the LCD to ground, and comment 
 // out the following line.  Doing so will save one PIC 
 // pin, but at the cost of losing the ability to read from 
 // the LCD.  It also makes the write time a little longer 
 // because a static delay must be used, instead of polling 
 // the LCD's busy bit.  Normally a 6-pin interface is only 
 // used if you are running out of PIC pins, and you need 
 // to use as few as possible for the LCD. 
 #define USE_RW_PIN   1      
 // These are the line addresses for most 4x20 LCDs. 
 #define LCD_LINE_1_ADDRESS 0x00 
 #define LCD_LINE_2_ADDRESS 0x40 
 #define LCD_LINE_3_ADDRESS 0x14 
 #define LCD_LINE_4_ADDRESS 0x54 
 // These are the line addresses for LCD's which use 
 // the Hitachi HD66712U controller chip. 
 #define LCD_LINE_2_ADDRESS 0x20 
 #define LCD_LINE_3_ADDRESS 0x40 
 #define LCD_LINE_4_ADDRESS 0x60 
 #define lcd_type 2   // 0=5x7, 1=5x10, 2=2 lines(or more) 
 int8 lcd_line; 
 int8 const LCD_INIT_STRING[4] = 
  0x20 | (lcd_type << 2),  // Set mode: 4-bit, 2+ lines, 5x8 dots 
  0xc,                     // Display on 
  1,                       // Clear display 
  6                        // Increment cursor 
 void lcd_send_nibble(int8 nibble) 
 // Note:  !! converts an integer expression 
 // to a boolean (1 or 0). 
  output_bit(LCD_DB4, !!(nibble & 1)); 
  output_bit(LCD_DB5, !!(nibble & 2));  
  output_bit(LCD_DB6, !!(nibble & 4));    
  output_bit(LCD_DB7, !!(nibble & 8));    
  delay_cycles(1); 
  output_high(LCD_E); 
  delay_us(2); 
  output_low(LCD_E); 
 // This sub-routine is only called by lcd_read_byte(). 
 // It's not a stand-alone routine.  For example, the 
 // R/W signal is set high by lcd_read_byte() before 
 // this routine is called.      
 #ifdef USE_RW_PIN 
 int8 lcd_read_nibble(void) 
 int8 retval; 
 // Create bit variables so that we can easily set 
 // individual bits in the retval variable. 
 #bit retval_0 = retval.0 
 #bit retval_1 = retval.1 
 #bit retval_2 = retval.2 
 #bit retval_3 = retval.3 
 retval = 0; 
 output_high(LCD_E); 
 delay_us(1); 
 retval_0 = input(LCD_DB4); 
 retval_1 = input(LCD_DB5); 
 retval_2 = input(LCD_DB6); 
 retval_3 = input(LCD_DB7); 
 output_low(LCD_E); 
 delay_us(1); 
 return(retval);    
 #endif 
 // Read a byte from the LCD and return it. 
 #ifdef USE_RW_PIN 
 int8 lcd_read_byte(void) 
 int8 low; 
 int8 high; 
 output_high(LCD_RW); 
 delay_cycles(1); 
 high = lcd_read_nibble(); 
 low = lcd_read_nibble(); 
 return( (high<<4) | low); 
 #endif 
 // Send a byte to the LCD. 
 void lcd_send_byte(int8 address, int8 n) 
 output_low(LCD_RS); 
 #ifdef USE_RW_PIN 
 while(bit_test(lcd_read_byte(),7)) ; 
 #else 
 delay_us(60);  
 #endif 
 if(address) 
    output_high(LCD_RS); 
 else 
    output_low(LCD_RS); 
  delay_cycles(1); 
 #ifdef USE_RW_PIN 
 output_low(LCD_RW); 
 delay_cycles(1); 
 #endif 
 output_low(LCD_E); 
 lcd_send_nibble(n >> 4); 
 lcd_send_nibble(n & 0xf); 
 void lcd_init(void) 
 int8 i; 
 lcd_line = 1; 
 output_low(LCD_RS); 
 #ifdef USE_RW_PIN 
 output_low(LCD_RW); 
 #endif 
 output_low(LCD_E); 
 // Some LCDs require 15 ms minimum delay after 
 // power-up.  Others require 30 ms.  I'm going 
 // to set it to 35 ms, so it should work with 
 // all of them. 
 delay_ms(35);          
 for(i=0 ;i < 3; i++) 
     lcd_send_nibble(0x03); 
     delay_ms(5); 
 lcd_send_nibble(0x02); 
 for(i=0; i < sizeof(LCD_INIT_STRING); i++) 
     lcd_send_byte(0, LCD_INIT_STRING[i]); 
     // If the R/W signal is not used, then 
     // the busy bit can't be polled.  One of 
     // the init commands takes longer than 
     // the hard-coded delay of 50 us, so in 
     // that case, lets just do a 5 ms delay 
     // after all four of them. 
     #ifndef USE_RW_PIN 
     delay_ms(5); 
     #endif 
 void lcd_gotoxy(int8 x, int8 y) 
 int8 address; 
 switch(y) 
    case 1: 
      address = LCD_LINE_1_ADDRESS; 
      break; 
    case 2: 
      address = LCD_LINE_2_ADDRESS; 
      break; 
    case 3: 
      address = LCD_LINE_3_ADDRESS; 
      break; 
    case 4: 
      address = LCD_LINE_4_ADDRESS; 
      break; 
    default: 
      break; 
 address += x-1; 
 lcd_send_byte(0, 0x80 | address); 
void lcd_putc(char c) 
  switch(c) 
     case '\f': 
       lcd_send_byte(0,1); 
       lcd_line = 1; 
       delay_ms(2); 
       break; 
     case '\n': 
        lcd_gotoxy(1, ++lcd_line); 
        break; 
     case '\b': 
        lcd_send_byte(0,0x10); 
        break; 
     case '\r': 
        lcd_gotoxy(1, lcd_line); 
        break; 
     default: 
        lcd_send_byte(1,c); 
        break; 
   if (lcd_line>4) 
        lcd_line=1; 
void lcd_cursor_on(int1 on)
   if (on)
      lcd_send_byte(0,0x0F);           //turn LCD cursor ON
   else
      lcd_send_byte(0,0x0C);           //turn LCD cursor OFF
 #ifdef USE_RW_PIN 
 char lcd_getc(int8 x, int8 y) 
 char value; 
 lcd_gotoxy(x,y); 
 // Wait until busy flag is low. 
 while(bit_test(lcd_read_byte(),7));  
 value = lcd_read_byte(); 
 output_low(LCD_RS); 
 return(value); 
 #endif
