<root>
<document schema='101' license='1,FlowcodeHUN,P1HWFJ' title='' description='' target='PIC.18F.18F46K22' >
	<config data='!0,ff!8,83!10,f9!18,fc!20,ff!28,ff!30,ba!38,ff!40,ff!48,ff!50,ff!58,ff!60,ff!68,ff%8,3%c,0%d,0%e,0%f,1%10,1%11,0%13,3%18,0%1a,f%28,1%29,1%2a,1%2b,1%2c,1%2d,1%2f,1%30,0%32,0%36,0%37,1%40,1%41,1%42,1%43,1%4e,1%4f,1%50,1%51,1%52,1%53,1%5d,1%5e,1%5f,1%60,1%61,1%62,1%63,1%6e,1' clkspd='4000000' simspd='2' usewdt='0' constif='0' />
	<plugins >
		<dll_dbg_icd enabled='0' >
			<data name='debug' value='1' />
			<data name='userpins' value='0' />
			<data name='speed' value='0' />
			<data name='usev9' value='0' />
			<data name='breaks' value='8' />
			<data name='stacks' value='8' />
			<data name='clkport' value='1' />
			<data name='clkbit' value='6' />
			<data name='dataport' value='1' />
			<data name='databit' value='7' />
			<data name='ghostype' value='0' />
			<data name='monitor' value='1' />
			<data name='ictloop' value='0' />
			<data name='ictrate' value='20000' />
			<data name='ictmask' value='0' />
			<data name='anlpres' value='255' />
			<data name='digmask1' value='-1' />
			<data name='digmask2' value='-1' />
		</dll_dbg_icd>
		<dll_models enabled='1' />
		<dll_upgrader enabled='1' />
		<dll_webhelp enabled='1' />
	</plugins>
	<supplement use='0' head='' body='' />
	<debug />
	<components >
		<settings autoimg='1' center='1' unitscale='0' fixedscale='0' fixedx='1' fixedy='1' fixedz='1' headcode='0' />
		<definition guid='f7d27144-044c-4d55-9224-19c1836bf491' vstate='40' vmin='0' vmaj='1' srcleaf='' visiblename='' description='' category='' catenable='1' author='' manuname='' manucode='' sysinfo='0' keywords='' dynamic='0' iconpath='' />
		<component class_type='root' codename='panel' x='0' y='0' z='0' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='0' poslock='0' >
			<resources />
			<properties />
			<values />
			<events />
			<apis />
			<variables >
				<variable public='0' >
					<def class_type='variable' name='false' type='b1' description='' isconst='1' isinit='1' usrinit='0' setinit='0' />
				</variable>
					<def class_type='variable' name='true' type='b1' description='' isconst='1' isinit='1' usrinit='1' setinit='1' />
				</variable>
			</variables>
			<macros >
				<macro >
					<flowline name='aa' description='' >
						<return name='Return' type='v0' description='' isconst='0' isinit='0' usrinit='' setinit='' />
						<command class_type='call' title='Komponens makró hívása' component='gLCD_KS0108' macro='PrintNumber' >
							<argument exp='2' />
							<argument exp='3' />
						</command>
					</flowline>
				</macro>
				<macro >
					<flowline name='Main' description='' >
						<command class_type='interrupt' title='Megszakítás' enable='1' name='TMR0' call='aa' >
							<settings timer='1' prescale='256' postscale='-1' rollover='-1' bitcount='-1' trigger='3' maskhi='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' masklo='--------------------------------------------------------------------------------------------------------------------------------------------------------------------------8' >
								<option value='1' />
								<option value='0' />
								<option value='8' />
								<option value='-1' />
							</settings>
						</command>
						<command class_type='call' title='Komponens makró hívása' component='gLCD_KS0108' macro='Initialise' />
						<command class_type='loop' title='Ciklus' type='0' exp='1' >
							<flowline />
						</command>
					</flowline>
				</macro>
			</macros>
			<component class_type='ref' guid='c9d3b357-b914-4301-a741-0d13819e441c' vmin='3' vmaj='1' codename='gLCD_KS0108' x='0' y='0' z='3' xsz='1' ysz='1' zsz='1' xang='0' yang='0' zang='0' xquat='0' yquat='0' zquat='0' wquat='1' visible='1' interactive='1' solid='1' layer='1' poslock='0' >
				<resources />
				<properties />
				<values >
					<value target='pixel_height' data='64' />
					<value target='pixel_width' data='128' />
					<value target='ControllerCount' data='002' />
					<value target='monochrome' data='1' />
					<value target='foreground_colour' data='0' />
					<value target='background_colour' data='16777215' />
					<value target='colour_bit_depth' data='1' />
					<value target='red_bit_depth' data='0' />
					<value target='green_bit_depth' data='0' />
					<value target='blue_bit_depth' data='0' />
					<value target='chip_sel1_pin' data='$PORTC.0' />
					<value target='chip_sel2_pin' data='$PORTC.1' />
					<value target='chip_sel3_pin' data='$PORTC.1' />
					<value target='a0_pin' data='$PORTC.2' />
					<value target='read_write_pin' data='$PORTC.3' />
					<value target='enable_pin' data='$PORTC.4' />
					<value target='data0_pin' data='$PORTB.0' />
					<value target='data1_pin' data='$PORTB.1' />
					<value target='data2_pin' data='$PORTB.2' />
					<value target='data3_pin' data='$PORTB.3' />
					<value target='data4_pin' data='$PORTB.4' />
					<value target='data5_pin' data='$PORTB.5' />
					<value target='data6_pin' data='$PORTB.6' />
					<value target='data7_pin' data='$PORTB.7' />
					<value target='reset_pin' data='$PORTC.5' />
					<value target='DisplayMethod' data='000' />
					<value target='EnableDelay' data='10' />
				</values>
				<events />
				<apis />
				<variables />
				<macros />
			</component>
		</component>
	</components>
	<keymap />
	<panel2d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='5767167' img='' style='0' />
		<camera xe='0' ye='0' ze='300' xt='0' yt='0' zt='0' xquat='0' yquat='0' zquat='0' wquat='1' />
	</panel2d>
	<panel3d shadows='0' lighting='2' brightness='0' perspective='0' >
		<background rgb='8409120' img='' style='0' />
		<table rgb='7360576' img='' style='0' size='25' />
	</panel3d>
	<layout >
		<view type='0' name='aa' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAA4AIAAJQCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
		<view type='0' name='Main' mode='0' placement='LAAAAAAAAAABAAAA---------------------wAAAAAUAAAA4AIAAJQCAAA' zoom='75' scrollx='0' scrolly='0' flags='0' />
	</layout>
</document>
</root>
