<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="8.0.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.000003125" unitdist="mm" unit="mm" style="dots" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="7" fill="1" visible="no" active="no"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="113" name="IDFDebug" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="153" name="FabDoc1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="154" name="FabDoc2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="155" name="FabDoc3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="231bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="96.5" y2="0" width="0" layer="20"/>
<wire x1="96.5" y1="0" x2="96.497428125" y2="66.5419875" width="0" layer="20"/>
<wire x1="96.497428125" y1="66.5419875" x2="-0.261834375" y2="66.5419875" width="0" layer="20"/>
<wire x1="-0.261834375" y1="66.5419875" x2="0" y2="0" width="0" layer="20"/>
<dimension x1="96.497428125" y1="66.5419875" x2="-0.261834375" y2="66.5419875" x3="48.117796875" y3="71.030971875" textsize="3.81" layer="16" dtype="horizontal"/>
<dimension x1="96.5" y1="0" x2="96.497428125" y2="66.5419875" x3="103.733446875" y3="33.271271875" textsize="1.778" layer="16"/>
<rectangle x1="29.55134375" y1="32.8336" x2="42.393028125" y2="43.442571875" layer="16"/>
<rectangle x1="29.7060625" y1="18.972246875" x2="42.4703875" y2="29.271465625" layer="16"/>
<rectangle x1="29.7060625" y1="5.033453125" x2="42.547746875" y2="15.410109375" layer="16"/>
<rectangle x1="27.772075" y1="47.701646875" x2="39.917521875" y2="57.845990625" layer="16"/>
<hole x="36.510703125" y="52.67198125" drill="0.6"/>
<hole x="39.15080625" y="38.101765625" drill="0.6"/>
<hole x="39.15080625" y="24.176246875" drill="0.6"/>
<hole x="39.0801625" y="10.15195625" drill="0.6"/>
</plain>
<libraries>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="C5B2.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 2.5 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
</packages>
</library>
<library name="jumper">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP1">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="long"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="long"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
</library>
<library name="SparkFun-AnalogIC">
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find all manner of analog ICs- DACs, ADCs, video chips, op-amps, and others.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt;Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="DIL-08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2-H">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.</description>
<wire x1="-5.08" y1="-7.239" x2="-5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-7.239" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.429" x2="5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.461" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="2.159" x2="0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="-2.794" x2="4.5466" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="-2.794" x2="4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="2.159" x2="0.4826" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="2.413" x2="-0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-0.2286" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="-3.048" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.5466" y1="0" x2="-0.4826" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.5466" y1="-2.413" x2="-4.2926" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-0.4826" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-4.2926" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-2.413" x2="-1.1176" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.9116" y1="-2.667" x2="-3.6576" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.6576" y1="-0.127" x2="-3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.127" x2="-1.3716" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-1.3716" y1="-0.127" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-0.762" x2="-1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="-5.08" y2="-3.81" width="0.0508" layer="21"/>
<wire x1="-5.08" y1="-3.81" x2="-5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="0" x2="4.5466" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="1.3716" y1="-0.127" x2="3.6576" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.127" x2="1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.762" x2="3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.127" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-2.667" x2="1.3716" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="3.6576" y1="-2.413" x2="3.9116" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2926" y1="-2.667" x2="0.7366" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.2926" y1="-2.667" x2="4.5466" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="0.4826" y1="-2.413" x2="0.7366" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.762" y1="-7.366" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-7.239" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.239" x2="-2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.239" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-0.762" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.239" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="4.318" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.366" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.239" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.239" x2="2.286" y2="-7.239" width="0.1524" layer="21"/>
<circle x="-2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="3.556" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
<text x="1.905" y="-5.715" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.6576" y1="-1.524" x2="-1.3716" y2="-0.762" layer="51"/>
<rectangle x1="1.3716" y1="-1.524" x2="3.6576" y2="-0.762" layer="51"/>
<rectangle x1="-3.6576" y1="-2.667" x2="-1.3716" y2="-1.524" layer="21"/>
<rectangle x1="1.3716" y1="-2.667" x2="3.6576" y2="-1.524" layer="21"/>
</package>
<package name="AK500/4-H">
<wire x1="-10.0838" y1="-7.239" x2="-10.0838" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="2.794" x2="-10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-7.239" x2="-9.3472" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="2.794" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-3.429" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-3.429" x2="-10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.429" x2="10.0838" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="2.794" x2="10.4648" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="-3.429" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="2.794" x2="10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.4864" y1="2.159" x2="-5.4864" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.5504" y1="-2.794" x2="-5.4864" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.5504" y1="-2.794" x2="-9.5504" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.4864" y1="2.159" x2="-9.5504" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="2.159" x2="-4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="-2.794" x2="-0.4572" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="-2.794" x2="-0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="2.159" x2="-4.5212" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.2032" y1="-3.048" x2="-4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2032" y1="-3.048" x2="-0.2032" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.7752" y1="2.413" x2="-0.2032" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.7752" y1="2.413" x2="-4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-5.2324" y1="2.413" x2="-5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-9.8044" y1="2.413" x2="-5.2324" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-9.8044" y1="2.413" x2="-9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-5.2324" y1="-3.048" x2="-9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-9.5504" y1="0" x2="-5.4864" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-9.5504" y1="-2.413" x2="-9.2964" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7404" y1="-2.667" x2="-5.4864" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7404" y1="-2.667" x2="-9.2964" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-6.3754" y1="-2.413" x2="-6.1214" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-8.9154" y1="-2.667" x2="-8.6614" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-8.6614" y1="-0.127" x2="-8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.127" x2="-6.3754" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-6.3754" y1="-0.127" x2="-6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.762" x2="-6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.762" x2="-8.6614" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-6.3754" y1="-0.762" x2="-6.3754" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.81" x2="-10.0838" y2="-3.81" width="0.0508" layer="21"/>
<wire x1="-10.0838" y1="-3.81" x2="-10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.81" x2="10.0838" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.6322" y1="-0.127" x2="-1.3462" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.127" x2="-3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.762" x2="-1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.762" x2="-3.6322" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3462" y1="-0.762" x2="-1.3462" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3462" y1="-0.127" x2="-1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.8862" y1="-2.667" x2="-3.6322" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.3462" y1="-2.413" x2="-1.0922" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7112" y1="-2.667" x2="-4.2672" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-0.7112" y1="-2.667" x2="-0.4572" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.5212" y1="-2.413" x2="-4.2672" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7912" y1="-7.366" x2="-5.7912" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-5.7912" y1="-7.239" x2="-4.2418" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.366" x2="-9.3472" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.239" x2="-7.8232" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.366" x2="-7.8232" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-7.8232" y1="-7.239" x2="-7.8232" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-7.8232" y1="-7.239" x2="-7.3152" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.239" x2="-5.7912" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.366" x2="-7.3152" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.366" x2="-5.7912" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.7178" y1="-7.239" x2="-2.7178" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.7178" y1="-7.239" x2="-2.2098" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.366" x2="-2.7178" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.366" x2="-2.2098" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.239" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.366" x2="-0.6858" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="-7.366" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.366" x2="-4.2418" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.239" x2="-2.7178" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="2.159" x2="4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-2.794" x2="4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-2.794" x2="0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="2.159" x2="0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.7752" y1="2.413" x2="4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="0.2032" y1="2.413" x2="4.7752" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2032" y1="2.413" x2="0.2032" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="4.7752" y1="-3.048" x2="0.2032" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="0.4572" y1="0" x2="4.5212" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="0.4572" y1="-2.413" x2="0.7112" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2672" y1="-2.667" x2="4.5212" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2672" y1="-2.667" x2="0.7112" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="3.6322" y1="-2.413" x2="3.8862" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="1.0922" y1="-2.667" x2="1.3462" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="1.3462" y1="-0.127" x2="1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.127" x2="3.6322" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="3.6322" y1="-0.127" x2="3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.762" x2="3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.762" x2="1.3462" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6322" y1="-0.762" x2="3.6322" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="4.2164" y1="-7.366" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.366" x2="2.1844" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.366" x2="4.2164" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="0.6604" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="2.1844" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.1844" y1="-7.239" x2="2.1844" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.1844" y1="-7.239" x2="2.6924" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.239" x2="2.6924" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.239" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-7.239" x2="9.2456" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="9.5504" y1="2.159" x2="9.5504" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.4864" y1="-2.794" x2="9.5504" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.4864" y1="-2.794" x2="5.4864" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.5504" y1="2.159" x2="5.4864" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.8044" y1="2.413" x2="9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="5.2324" y1="2.413" x2="9.8044" y2="2.413" width="0.0508" layer="21"/>
<wire x1="5.2324" y1="2.413" x2="5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="9.8044" y1="-3.048" x2="5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="5.4864" y1="0" x2="9.5504" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="5.4864" y1="-2.413" x2="5.7404" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="9.2964" y1="-2.667" x2="9.5504" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="9.2964" y1="-2.667" x2="5.7404" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="8.6614" y1="-2.413" x2="8.9154" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="6.1214" y1="-2.667" x2="6.3754" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="6.3754" y1="-0.127" x2="6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.127" x2="8.6614" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="8.6614" y1="-0.127" x2="8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.762" x2="8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.762" x2="6.3754" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="8.6614" y1="-0.762" x2="8.6614" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="9.2456" y1="-7.366" x2="9.2456" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.366" x2="7.2136" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.366" x2="9.2456" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.239" x2="5.6896" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.2136" y1="-7.239" x2="7.2136" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.239" x2="7.7216" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.239" x2="7.2136" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="9.2456" y1="-7.239" x2="7.7216" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="7.2136" y1="-7.239" x2="5.6896" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.239" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<circle x="-7.5184" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="-2.4892" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="2.4892" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="7.5184" y="0" radius="1.397" width="0.1524" layer="51"/>
<pad name="1" x="-7.5184" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="-2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="4" x="7.5184" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-10.0838" y="3.556" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.0838" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.2042" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
<text x="-3.0988" y="-5.715" size="1.27" layer="21" ratio="10">2</text>
<text x="1.8034" y="-5.715" size="1.27" layer="21" ratio="10">3</text>
<text x="6.8326" y="-5.715" size="1.27" layer="21" ratio="10">4</text>
<rectangle x1="-8.6614" y1="-1.524" x2="-6.3754" y2="-0.762" layer="51"/>
<rectangle x1="-3.6322" y1="-1.524" x2="-1.3462" y2="-0.762" layer="51"/>
<rectangle x1="-8.6614" y1="-2.667" x2="-6.3754" y2="-1.524" layer="21"/>
<rectangle x1="-3.6322" y1="-2.667" x2="-1.3462" y2="-1.524" layer="21"/>
<rectangle x1="1.3462" y1="-1.524" x2="3.6322" y2="-0.762" layer="51"/>
<rectangle x1="1.3462" y1="-2.667" x2="3.6322" y2="-1.524" layer="21"/>
<rectangle x1="6.3754" y1="-1.524" x2="8.6614" y2="-0.762" layer="51"/>
<rectangle x1="6.3754" y1="-2.667" x2="8.6614" y2="-1.524" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="switch">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, Siemens, C&amp;K, ITT, and others&lt;p&gt;
<packages>
<package name="255SB">
<description>&lt;b&gt;SLIDING SWITCH&lt;/b&gt;&lt;p&gt;
distributor Buerklin, 11G810</description>
<wire x1="-5.588" y1="3.048" x2="5.588" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.588" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.048" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.397" x2="3.81" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.81" y1="1.397" x2="-3.81" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.762" x2="-1.27" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.81" y1="-1.524" x2="-0.762" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.524" x2="-1.778" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.524" x2="-1.778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.016" x2="-2.794" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.81" y1="1.524" x2="-3.302" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.524" x2="3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.524" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.27" x2="-0.762" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.524" x2="-1.27" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.524" x2="-1.27" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.524" x2="-1.778" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.016" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.524" x2="-3.302" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.302" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.524" x2="-3.81" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.397" x2="-3.81" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.524" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.524" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.524" x2="-2.794" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.524" x2="-2.794" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.524" x2="-2.286" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.524" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.524" x2="-0.762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.524" x2="-0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.524" x2="3.81" y2="1.524" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="3.81" y="0" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.207" y="-2.794" size="1.27" layer="21" ratio="10">1</text>
<text x="4.191" y="-2.794" size="1.27" layer="21" ratio="10">2</text>
<text x="-5.588" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="Arduino-clone">
<description>Arduino Clone pinheaders
By cl@xganon.com
http://www.xganon.com</description>
<packages>
<package name="NANO">
<pad name="TX0" x="5.08" y="-8.89" drill="0.8" shape="long"/>
<pad name="RX1" x="5.08" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST1" x="5.08" y="-3.81" drill="0.8" shape="long"/>
<pad name="GND1" x="5.08" y="-1.27" drill="0.8" shape="long"/>
<pad name="D2" x="5.08" y="1.27" drill="0.8" shape="long"/>
<pad name="D3" x="5.08" y="3.81" drill="0.8" shape="long"/>
<pad name="D4" x="5.08" y="6.35" drill="0.8" shape="long"/>
<pad name="D5" x="5.08" y="8.89" drill="0.8" shape="long"/>
<pad name="D6" x="5.08" y="11.43" drill="0.8" shape="long"/>
<pad name="D7" x="5.08" y="13.97" drill="0.8" shape="long"/>
<pad name="D8" x="5.08" y="16.51" drill="0.8" shape="long"/>
<pad name="D9" x="5.08" y="19.05" drill="0.8" shape="long"/>
<pad name="RAW" x="-10.16" y="-8.89" drill="0.8" shape="long"/>
<pad name="GND" x="-10.16" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST" x="-10.16" y="-3.81" drill="0.8" shape="long"/>
<pad name="A3" x="-10.16" y="11.43" drill="0.8" shape="long"/>
<pad name="A2" x="-10.16" y="13.97" drill="0.8" shape="long"/>
<pad name="A1" x="-10.16" y="16.51" drill="0.8" shape="long"/>
<pad name="A0" x="-10.16" y="19.05" drill="0.8" shape="long"/>
<pad name="D13" x="-10.16" y="26.67" drill="0.8" shape="long"/>
<pad name="D12" x="5.08" y="26.67" drill="0.8" shape="long"/>
<pad name="D11" x="5.08" y="24.13" drill="0.8" shape="long"/>
<pad name="D10" x="5.08" y="21.59" drill="0.8" shape="long"/>
<pad name="3.3V" x="-10.16" y="24.13" drill="0.8" shape="long" rot="R180"/>
<pad name="AREF" x="-10.16" y="21.59" drill="0.8" shape="long" rot="R180"/>
<pad name="5V" x="-10.16" y="-1.27" drill="0.8" shape="long"/>
<pad name="ICSP2" x="-5.08" y="-7.62" drill="0.8" rot="R90"/>
<pad name="ICSP4" x="-2.54" y="-7.62" drill="0.8" rot="R90"/>
<pad name="ICSP6" x="0" y="-7.62" drill="0.8" rot="R90"/>
<pad name="A4" x="-10.16" y="8.89" drill="0.8" shape="long" rot="R180"/>
<pad name="A5" x="-10.16" y="6.35" drill="0.8" shape="long" rot="R180"/>
<pad name="A6" x="-10.16" y="3.81" drill="0.8" shape="long" rot="R180"/>
<pad name="A7" x="-10.16" y="1.27" drill="0.8" shape="long" rot="R180"/>
<pad name="ICSP1" x="-5.08" y="-10.16" drill="0.8" rot="R90"/>
<pad name="ICSP3" x="-2.54" y="-10.16" drill="0.8" rot="R90"/>
<pad name="ICSP5" x="0" y="-10.16" drill="0.8" rot="R90"/>
</package>
</packages>
</library>
<library name="con-lumberg">
<description>&lt;b&gt;Lumberg Connectors&lt;/b&gt;&lt;p&gt;
include con-mfs.lbr - 2001.03.22&lt;br&gt;
Jack connectors - 2005.11.23&lt;p&gt;
http://www.lumberg.de&lt;p&gt;
<packages>
<package name="1503_09">
<description>&lt;b&gt;Jack connectors according to JISC 6560, 3.5 mm&lt;/b&gt;&lt;p&gt;
Klinkeneinbaukupplung nach JISC 6560, 3,5 mm, 3-polig/&lt;br&gt;
stereo, abgewinkelte Ausführung, mit 2 Öffnern und Lötaugen,&lt;br&gt;
für Leiterplatten Rückseitenmontage&lt;p&gt;
Source: http://www.lumberg.com/Produkte/PDFs/1503_09.pdf</description>
<wire x1="0.75" y1="-2.1" x2="0.35" y2="-1.7" width="0" layer="46" curve="90"/>
<wire x1="0.35" y1="-1.7" x2="-0.35" y2="-1.7" width="0" layer="46"/>
<wire x1="-0.35" y1="-1.7" x2="-0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-0.75" y1="-2.1" x2="-0.35" y2="-2.5" width="0" layer="46" curve="90"/>
<wire x1="-0.35" y1="-2.5" x2="0.35" y2="-2.5" width="0" layer="46"/>
<wire x1="0.35" y1="-2.5" x2="0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-6.15" x2="-4.15" y2="-5.75" width="0" layer="46" curve="90"/>
<wire x1="-4.15" y1="-5.75" x2="-4.15" y2="-5.05" width="0" layer="46"/>
<wire x1="-4.15" y1="-5.05" x2="-4.55" y2="-4.65" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-4.65" x2="-4.95" y2="-5.05" width="0" layer="46" curve="90"/>
<wire x1="-4.95" y1="-5.05" x2="-4.95" y2="-5.75" width="0" layer="46"/>
<wire x1="-4.95" y1="-5.75" x2="-4.55" y2="-6.15" width="0" layer="46" curve="90"/>
<wire x1="-3.25" y1="-13.1" x2="-3.65" y2="-12.7" width="0" layer="46" curve="90"/>
<wire x1="-3.65" y1="-12.7" x2="-4.35" y2="-12.7" width="0" layer="46"/>
<wire x1="-4.35" y1="-12.7" x2="-4.75" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="-4.75" y1="-13.1" x2="-4.35" y2="-13.5" width="0" layer="46" curve="90"/>
<wire x1="-4.35" y1="-13.5" x2="-3.65" y2="-13.5" width="0" layer="46"/>
<wire x1="-3.65" y1="-13.5" x2="-3.25" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-9.25" x2="3.05" y2="-8.85" width="0" layer="46" curve="90"/>
<wire x1="3.05" y1="-8.85" x2="3.05" y2="-8.15" width="0" layer="46"/>
<wire x1="3.05" y1="-8.15" x2="2.65" y2="-7.75" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-7.75" x2="2.25" y2="-8.15" width="0" layer="46" curve="90"/>
<wire x1="2.25" y1="-8.15" x2="2.25" y2="-8.85" width="0" layer="46"/>
<wire x1="2.25" y1="-8.85" x2="2.65" y2="-9.25" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-10.65" x2="5.45" y2="-10.25" width="0" layer="46" curve="90"/>
<wire x1="5.45" y1="-10.25" x2="5.45" y2="-9.55" width="0" layer="46"/>
<wire x1="5.45" y1="-9.55" x2="5.05" y2="-9.15" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-9.15" x2="4.65" y2="-9.55" width="0" layer="46" curve="90"/>
<wire x1="4.65" y1="-9.55" x2="4.65" y2="-10.25" width="0" layer="46"/>
<wire x1="4.65" y1="-10.25" x2="5.05" y2="-10.65" width="0" layer="46" curve="90"/>
<wire x1="-5.4" y1="-0.1" x2="5.9" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-0.1" x2="5.9" y2="-14" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-14" x2="-5.4" y2="-14" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-14" x2="-5.4" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="0" x2="-2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="3.4" x2="2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="2.9" y1="3.4" x2="2.9" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="-2.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="2" x="-4.55" y="-5.4" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="3" x="5.05" y="-9.9" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="4" x="-4" y="-13.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="5" x="2.65" y="-8.5" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<text x="0" y="7.24" size="1.27" layer="25">&gt;NAME</text>
<text x="0" y="-19.24" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="C2" library="capacitor-wima" package="C5B2.5" value="0.1uF" x="77.6397" y="53.0361625" rot="R90"/>
<element name="C3" library="capacitor-wima" package="C5B2.5" value="0.1uF" x="72.437228125" y="53.0361625" rot="R270"/>
<element name="C4" library="capacitor-wima" package="C5B2.5" value="0.1uF" x="83.82" y="53.34" rot="R270"/>
<element name="C5" library="capacitor-wima" package="C5B2.5" value="33pF" x="58.42" y="53.34" rot="R180"/>
<element name="IC1" library="linear" package="TO220H" value="7805T" x="31.75" y="52.72105625" rot="R270"/>
<element name="JP1" library="jumper" package="JP1" value="" x="76.888359375" y="44.870040625" rot="R90"/>
<element name="MSGEQ7" library="SparkFun-AnalogIC" package="DIL-08" value="MSGEQ7DIL" x="58.42" y="53.34" rot="R180"/>
<element name="POWER" library="con-ptr500" package="AK500/2-H" value="" x="10.284571875" y="56.771134375" rot="R270">
<attribute name="MF" value="" x="10.284571875" y="56.771134375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="10.284571875" y="56.771134375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="10.284571875" y="56.771134375" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="10.284571875" y="56.771134375" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="Q1" library="transistor-fet" package="TO220" value="BUZ11" x="27.94" y="10.16" rot="R270"/>
<element name="Q2" library="transistor-fet" package="TO220" value="BUZ11" x="27.94" y="24.13" rot="R270"/>
<element name="Q3" library="transistor-fet" package="TO220" value="BUZ11" x="27.94" y="38.1" rot="R270"/>
<element name="R1" library="resistor" package="0207/10" value="22k" x="74.93" y="34.29" rot="R90"/>
<element name="R2" library="resistor" package="0207/10" value="200k" x="67.31" y="53.34" rot="R270"/>
<element name="R3" library="resistor" package="0207/10" value="22k" x="69.85" y="34.29" rot="R90"/>
<element name="R4" library="resistor" package="0207/10" value="10k" x="54.61" y="22.86" rot="R270"/>
<element name="R5" library="resistor" package="0207/10" value="10k" x="57.795115625" y="22.79745625" rot="R270"/>
<element name="R6" library="resistor" package="0207/10" value="10k" x="61.1677" y="22.79745625" rot="R270"/>
<element name="S1" library="switch" package="255SB" value="" x="8.23359375" y="45.956784375"/>
<element name="U$1" library="Arduino-clone" package="NANO" value="NANO" x="55.88" y="33.02" rot="R180"/>
<element name="UV_LED" library="con-ptr500" package="AK500/2-H" value="" x="11.43" y="35.56" rot="R270">
<attribute name="MF" value="" x="11.43" y="35.56" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="11.43" y="35.56" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="11.43" y="35.56" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="11.43" y="35.56" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="X1" library="con-lumberg" package="1503_09" value="1503_09" x="77.47" y="8.89" rot="R180">
<attribute name="MF" value="" x="77.47" y="8.89" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="77.47" y="8.89" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="77.47" y="8.89" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="1243244" x="77.47" y="8.89" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="X3" library="con-ptr500" package="AK500/4-H" value="" x="11.43" y="16.51" rot="R270">
<attribute name="MF" value="" x="11.43" y="16.51" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="11.43" y="16.51" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="11.43" y="16.51" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="11.43" y="16.51" size="1.778" layer="27" rot="R270" display="off"/>
</element>
</elements>
<signals>
<signal name="S1">
<contactref element="Q1" pad="1"/>
<contactref element="R4" pad="2"/>
<contactref element="U$1" pad="D9"/>
<wire x1="54.61" y1="17.78" x2="54.59795625" y2="17.78" width="0.6096" layer="16"/>
<wire x1="54.59795625" y1="17.78" x2="54.59795625" y2="13.965946875" width="0.6096" layer="16"/>
<wire x1="54.59795625" y1="13.965946875" x2="50.8" y2="13.965946875" width="0.6096" layer="16"/>
<wire x1="50.8" y1="13.965946875" x2="50.8" y2="13.97" width="0.6096" layer="16"/>
<wire x1="50.8" y1="13.97" x2="50.548109375" y2="13.97" width="0.6096" layer="16"/>
<wire x1="50.548109375" y1="13.97" x2="50.548109375" y2="14.04103125" width="0.6096" layer="16"/>
<wire x1="21.59" y1="12.7" x2="21.570615625" y2="12.843509375" width="0.6096" layer="16"/>
<wire x1="21.570615625" y1="12.843509375" x2="21.585421875" y2="16.410965625" width="0.6096" layer="16"/>
<wire x1="50.8" y1="13.97" x2="47.55595625" y2="14.01478125" width="0.6096" layer="16"/>
<wire x1="47.55595625" y1="14.01478125" x2="47.557821875" y2="16.54138125" width="0.6096" layer="16"/>
<wire x1="21.585421875" y1="16.410965625" x2="47.557821875" y2="16.54138125" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S2">
<contactref element="Q2" pad="1"/>
<contactref element="R5" pad="2"/>
<contactref element="U$1" pad="D10"/>
<wire x1="57.795115625" y1="17.71745625" x2="57.79511875" y2="11.68260625" width="0.6096" layer="16"/>
<wire x1="57.79511875" y1="11.68260625" x2="57.53165625" y2="11.41914375" width="0.6096" layer="16"/>
<wire x1="57.53165625" y1="11.41914375" x2="50.8734" y2="11.3566" width="0.6096" layer="16"/>
<wire x1="50.8734" y1="11.3566" x2="50.8" y2="11.43" width="0.6096" layer="16"/>
<wire x1="21.59" y1="26.67" x2="21.9958875" y2="26.67" width="0.6096" layer="16"/>
<wire x1="21.9958875" y1="26.67" x2="22.015378125" y2="30.1612" width="0.6096" layer="16"/>
<wire x1="50.8" y1="11.43" x2="45.769603125" y2="11.40495625" width="0.6096" layer="16"/>
<wire x1="45.769603125" y1="11.40495625" x2="45.83355625" y2="30.1697125" width="0.6096" layer="16"/>
<wire x1="22.015378125" y1="30.1612" x2="45.83355625" y2="30.1697125" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S3">
<contactref element="Q3" pad="1"/>
<contactref element="R6" pad="2"/>
<contactref element="U$1" pad="D11"/>
<wire x1="61.1677" y1="17.71745625" x2="61.1677" y2="8.982803125" width="0.6096" layer="16"/>
<wire x1="61.1677" y1="8.982803125" x2="61.269909375" y2="8.960253125" width="0.6096" layer="16"/>
<wire x1="61.269909375" y1="8.960253125" x2="50.870253125" y2="8.960253125" width="0.6096" layer="16"/>
<wire x1="50.8" y1="8.89" x2="50.870253125" y2="8.960253125" width="0.6096" layer="16"/>
<wire x1="21.59" y1="40.64" x2="21.7251375" y2="40.64" width="0.6096" layer="16"/>
<wire x1="21.7251375" y1="40.64" x2="21.7251375" y2="44.84223125" width="0.6096" layer="16"/>
<wire x1="21.7251375" y1="44.84223125" x2="44.22386875" y2="44.84223125" width="0.6096" layer="16"/>
<wire x1="44.22386875" y1="44.84223125" x2="44.22386875" y2="8.903925" width="0.6096" layer="16"/>
<wire x1="44.22386875" y1="8.903925" x2="50.8" y2="8.903925" width="0.6096" layer="16"/>
<wire x1="50.8" y1="8.903925" x2="50.8" y2="8.89" width="0.6096" layer="16"/>
</signal>
<signal name="GND">
<contactref element="Q3" pad="3"/>
<contactref element="R6" pad="1"/>
<contactref element="R4" pad="1"/>
<contactref element="Q1" pad="3"/>
<contactref element="C4" pad="2"/>
<contactref element="MSGEQ7" pad="6"/>
<contactref element="C5" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="R5" pad="1"/>
<contactref element="Q2" pad="3"/>
<contactref element="X1" pad="1"/>
<contactref element="POWER" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="U$1" pad="GND"/>
<contactref element="UV_LED" pad="2"/>
<contactref element="JP1" pad="2"/>
<wire x1="21.59" y1="7.62" x2="24.60685" y2="7.62" width="1.4224" layer="16"/>
<wire x1="24.60685" y1="7.62" x2="24.671321875" y2="21.71904375" width="1.4224" layer="16"/>
<wire x1="24.671321875" y1="21.71904375" x2="21.59" y2="21.59" width="1.4224" layer="16"/>
<wire x1="21.59" y1="35.56" x2="24.671325" y2="35.56" width="1.4224" layer="16"/>
<wire x1="24.671325" y1="35.56" x2="24.671321875" y2="21.71904375" width="1.4224" layer="16"/>
<wire x1="11.4554" y1="33.02" x2="11.43" y2="33.0454" width="1.4224" layer="16"/>
<wire x1="15.59889375" y1="35.56" x2="15.79395" y2="46.30655625" width="1.4224" layer="16"/>
<wire x1="15.79395" y1="46.30655625" x2="15.6557125" y2="45.17051875" width="1.4224" layer="16"/>
<wire x1="15.59889375" y1="52.07" x2="15.6557125" y2="45.17051875" width="1.4224" layer="16"/>
<wire x1="54.61" y1="27.94" x2="57.795115625" y2="27.87745625" width="0.6096" layer="16"/>
<wire x1="57.795115625" y1="27.87745625" x2="61.1677" y2="27.87745625" width="0.6096" layer="16"/>
<wire x1="61.1677" y1="27.87745625" x2="63.317271875" y2="27.87745625" width="0.6096" layer="16"/>
<wire x1="63.317271875" y1="27.87745625" x2="63.4256375" y2="27.769090625" width="0.6096" layer="16"/>
<wire x1="63.4256375" y1="27.769090625" x2="63.4256375" y2="4.940678125" width="0.6096" layer="16"/>
<wire x1="63.4256375" y1="4.940678125" x2="63.675590625" y2="4.690725" width="0.6096" layer="16"/>
<wire x1="63.675590625" y1="4.690725" x2="68.043978125" y2="4.690725" width="0.6096" layer="16"/>
<wire x1="68.043978125" y1="4.690725" x2="74.673534375" y2="11.32028125" width="0.6096" layer="16"/>
<wire x1="74.673534375" y1="11.32028125" x2="77.13971875" y2="11.32028125" width="0.6096" layer="16"/>
<wire x1="77.13971875" y1="11.32028125" x2="77.47" y2="10.99" width="0.6096" layer="16"/>
<wire x1="55.88" y1="53.34" x2="57.15" y2="53.34" width="0.6096" layer="16"/>
<wire x1="57.15" y1="53.34" x2="57.15" y2="49.53" width="0.6096" layer="16"/>
<wire x1="61.1677" y1="27.87745625" x2="63.343484375" y2="27.87745625" width="0.6096" layer="16"/>
<wire x1="63.343484375" y1="27.87745625" x2="63.343484375" y2="39.36855" width="0.6096" layer="16"/>
<wire x1="63.343484375" y1="39.36855" x2="66.04" y2="39.36855" width="0.6096" layer="16"/>
<wire x1="66.04" y1="39.36855" x2="66.04" y2="39.37" width="0.6096" layer="16"/>
<wire x1="66.04" y1="39.37" x2="63.36315" y2="39.37" width="0.6096" layer="16"/>
<wire x1="63.36315" y1="39.37" x2="63.40375625" y2="44.289965625" width="0.6096" layer="16"/>
<wire x1="63.40375625" y1="44.289965625" x2="51.17393125" y2="44.332890625" width="0.6096" layer="16"/>
<wire x1="51.17393125" y1="44.332890625" x2="51.17393125" y2="44.2881125" width="0.6096" layer="16"/>
<wire x1="51.17393125" y1="44.2881125" x2="51.218703125" y2="44.2881125" width="0.6096" layer="16"/>
<wire x1="51.218703125" y1="44.2881125" x2="51.218703125" y2="45.857290625" width="0.6096" layer="16"/>
<wire x1="51.218703125" y1="45.857290625" x2="50.9051375" y2="46.305096875" width="0.6096" layer="16"/>
<wire x1="50.9051375" y1="46.305096875" x2="51.177928125" y2="45.343675" width="0.6096" layer="16"/>
<wire x1="51.177928125" y1="45.343675" x2="51.240415625" y2="45.343675" width="0.6096" layer="16"/>
<wire x1="51.240415625" y1="45.343675" x2="51.240415625" y2="53.349178125" width="0.6096" layer="16"/>
<wire x1="51.240415625" y1="53.349178125" x2="55.88" y2="53.349178125" width="0.6096" layer="16"/>
<wire x1="55.88" y1="53.349178125" x2="55.88" y2="53.34" width="0.6096" layer="16"/>
<wire x1="50.9051375" y1="46.305096875" x2="15.79395" y2="46.30655625" width="1.016" layer="16"/>
<wire x1="21.59" y1="35.56" x2="15.59889375" y2="35.56" width="1.4224" layer="16"/>
<wire x1="12.074709375" y1="54.256534375" x2="10.284571875" y2="54.256534375" width="1.4224" layer="16"/>
<wire x1="15.6557125" y1="45.940228125" x2="15.6557125" y2="45.17051875" width="1.4224" layer="16"/>
<wire x1="83.82" y1="50.8" x2="83.7351375" y2="50.8" width="0.6096" layer="16"/>
<wire x1="83.7351375" y1="50.8" x2="83.7351375" y2="52.140009375" width="0.6096" layer="16"/>
<wire x1="83.7351375" y1="52.140009375" x2="75.388815625" y2="52.140009375" width="0.6096" layer="16"/>
<wire x1="75.388815625" y1="50.487096875" x2="75.388815625" y2="52.140009375" width="0.6096" layer="16"/>
<wire x1="75.388815625" y1="50.487096875" x2="72.437228125" y2="50.487096875" width="0.6096" layer="16"/>
<wire x1="72.437228125" y1="50.487096875" x2="72.437228125" y2="50.4961625" width="0.6096" layer="16"/>
<wire x1="10.284571875" y1="54.256534375" x2="15.59889375" y2="54.256534375" width="1.4224" layer="16"/>
<wire x1="15.59889375" y1="54.256534375" x2="15.59889375" y2="52.72105625" width="1.4224" layer="16"/>
<wire x1="11.43" y1="33.0454" x2="15.59889375" y2="33.0454" width="1.4224" layer="16"/>
<wire x1="15.59889375" y1="33.0454" x2="15.59889375" y2="35.56" width="1.4224" layer="16"/>
<wire x1="21.59" y1="52.72105625" x2="15.59889375" y2="52.72105625" width="1.4224" layer="16"/>
<wire x1="15.59889375" y1="52.72105625" x2="15.59889375" y2="52.07" width="1.4224" layer="16"/>
<wire x1="63.40375625" y1="44.289965625" x2="75.098053125" y2="44.289965625" width="0.6096" layer="16"/>
<wire x1="75.098053125" y1="44.289965625" x2="75.098053125" y2="44.216628125" width="0.6096" layer="16"/>
<wire x1="75.098053125" y1="44.216628125" x2="75.388815625" y2="44.216628125" width="0.6096" layer="16"/>
<wire x1="75.388815625" y1="44.216628125" x2="75.388815625" y2="50.487096875" width="0.6096" layer="16"/>
<wire x1="53.949734375" y1="44.323146875" x2="53.63636875" y2="44.323146875" width="0.6096" layer="16"/>
<wire x1="53.63636875" y1="44.323146875" x2="53.63636875" y2="34.212453125" width="0.6096" layer="16"/>
<wire x1="53.63636875" y1="34.212453125" x2="50.950071875" y2="34.212453125" width="0.6096" layer="16"/>
<wire x1="50.950071875" y1="34.212453125" x2="50.950071875" y2="34.346796875" width="0.6096" layer="16"/>
<wire x1="50.950071875" y1="34.346796875" x2="51.0843875" y2="34.346796875" width="0.6096" layer="16"/>
<wire x1="51.0843875" y1="34.346796875" x2="51.0843875" y2="34.302015625" width="0.6096" layer="16"/>
<wire x1="51.0843875" y1="34.302015625" x2="50.860528125" y2="34.302015625" width="0.6096" layer="16"/>
<wire x1="50.860528125" y1="34.302015625" x2="50.860528125" y2="34.346796875" width="0.6096" layer="16"/>
<wire x1="75.388815625" y1="44.216628125" x2="75.618359375" y2="44.870040625" width="0" layer="19" extent="16-16"/>
<wire x1="53.63636875" y1="44.323146875" x2="51.218703125" y2="44.2881125" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="OUT1">
<contactref element="Q1" pad="2"/>
<contactref element="X3" pad="3"/>
<wire x1="21.495759375" y1="10.0849125" x2="21.59" y2="10.16" width="1.4224" layer="16"/>
<wire x1="11.43" y1="14.0208" x2="18.847509375" y2="14.013421875" width="1.4224" layer="16"/>
<wire x1="18.847509375" y1="14.013421875" x2="18.847509375" y2="9.89795625" width="1.4224" layer="16"/>
<wire x1="18.847509375" y1="9.89795625" x2="20.56565" y2="9.95005" width="1.4224" layer="16"/>
<wire x1="20.56565" y1="9.95005" x2="21.495759375" y2="10.0849125" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="OUT3">
<contactref element="Q3" pad="2"/>
<wire x1="21.580203125" y1="38.109796875" x2="21.59" y2="38.1" width="1.4224" layer="16"/>
<wire x1="21.59" y1="38.1" x2="26.873909375" y2="38.251459375" width="1.4224" layer="16"/>
<wire x1="26.873909375" y1="38.251459375" x2="27.0989" y2="3.968978125" width="1.4224" layer="16"/>
<contactref element="X3" pad="4"/>
<wire x1="27.0989" y1="3.968978125" x2="16.013425" y2="3.968978125" width="1.4224" layer="16"/>
<wire x1="16.013425" y1="3.968978125" x2="16.013425" y2="8.755259375" width="1.4224" layer="16"/>
<wire x1="11.43" y1="8.755259375" x2="16.013425" y2="8.755259375" width="1.4224" layer="16"/>
<wire x1="11.43" y1="8.755259375" x2="11.43" y2="8.9916" width="1.4224" layer="16"/>
<wire x1="11.43" y1="8.9916" x2="11.43" y2="8.755259375" width="1.4224" layer="16"/>
</signal>
<signal name="OUT2">
<contactref element="Q2" pad="2"/>
<contactref element="X3" pad="2"/>
<wire x1="20.66563125" y1="24.1616" x2="21.59" y2="24.13" width="1.4224" layer="16"/>
<wire x1="21.59" y1="24.13" x2="17.17381875" y2="24.13" width="1.4224" layer="16"/>
<wire x1="17.17381875" y1="24.13" x2="17.17381875" y2="19.06011875" width="1.4224" layer="16"/>
<wire x1="11.43" y1="19.06011875" x2="17.17381875" y2="19.06011875" width="1.4224" layer="16"/>
<wire x1="11.43" y1="19.06011875" x2="11.43" y2="18.9992" width="1.4224" layer="16"/>
<wire x1="11.43" y1="18.9992" x2="11.43" y2="19.06011875" width="1.4224" layer="16"/>
</signal>
<signal name="VDD">
<contactref element="MSGEQ7" pad="1"/>
<contactref element="U$1" pad="5V"/>
<contactref element="R2" pad="1"/>
<contactref element="C3" pad="1"/>
<contactref element="IC1" pad="3"/>
<wire x1="21.59" y1="50.18105625" x2="24.767609375" y2="50.258540625" width="1.4224" layer="16"/>
<wire x1="24.767609375" y1="50.258540625" x2="24.808125" y2="58.94100625" width="1.4224" layer="16"/>
<wire x1="24.808125" y1="58.94100625" x2="24.760259375" y2="62.82161875" width="1.4224" layer="16"/>
<wire x1="24.760259375" y1="62.82161875" x2="41.966290625" y2="62.825503125" width="1.4224" layer="16"/>
<wire x1="41.966290625" y1="62.825503125" x2="57.9520625" y2="62.8291125" width="1.4224" layer="16"/>
<wire x1="57.9520625" y1="62.8291125" x2="87.110809375" y2="62.8291125" width="1.4224" layer="16"/>
<wire x1="87.110809375" y1="62.8291125" x2="87.32673125" y2="62.619165625" width="1.4224" layer="16"/>
<wire x1="87.32673125" y1="62.619165625" x2="87.02674375" y2="34.409828125" width="1.4224" layer="16"/>
<wire x1="87.02674375" y1="34.409828125" x2="87.116740625" y2="34.31983125" width="1.4224" layer="16"/>
<wire x1="87.116740625" y1="34.31983125" x2="66.06983125" y2="34.31983125" width="1.4224" layer="16"/>
<wire x1="66.06983125" y1="34.31983125" x2="66.04" y2="34.29" width="1.4224" layer="16"/>
<wire x1="62.23" y1="56.8249" x2="62.23" y2="57.15" width="0.6096" layer="16"/>
<wire x1="62.23" y1="56.8249" x2="62.23" y2="55.857225" width="0.6096" layer="16"/>
<wire x1="42.3929" y1="55.247534375" x2="42.501465625" y2="54.88979375" width="0.6096" layer="16"/>
<wire x1="41.966290625" y1="62.825503125" x2="42.4703875" y2="62.825503125" width="1.016" layer="16"/>
<wire x1="42.4703875" y1="62.825503125" x2="42.501465625" y2="54.88979375" width="1.016" layer="16"/>
<wire x1="42.501465625" y1="54.88979375" x2="62.261078125" y2="54.88979375" width="1.016" layer="16"/>
<wire x1="62.261078125" y1="54.88979375" x2="62.23" y2="56.8249" width="1.016" layer="16"/>
<wire x1="62.23" y1="57.15" x2="67.31" y2="57.15" width="0.6096" layer="16"/>
<wire x1="67.31" y1="57.15" x2="67.31" y2="58.42" width="0.6096" layer="16"/>
<wire x1="67.31" y1="58.42" x2="72.437228125" y2="58.42" width="0.6096" layer="16"/>
<wire x1="72.437228125" y1="58.42" x2="72.437228125" y2="55.5761625" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="MSGEQ7" pad="2"/>
<contactref element="C4" pad="1"/>
<wire x1="59.69" y1="57.15" x2="59.6359875" y2="57.15" width="0.6096" layer="16"/>
<wire x1="59.6359875" y1="57.15" x2="59.6359875" y2="60.8075625" width="0.6096" layer="16"/>
<wire x1="59.6359875" y1="60.8075625" x2="83.82" y2="60.8075625" width="0.6096" layer="16"/>
<wire x1="83.82" y1="60.8075625" x2="83.82" y2="55.88" width="0.6096" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="MSGEQ7" pad="8"/>
<contactref element="R2" pad="2"/>
<contactref element="C5" pad="1"/>
<wire x1="60.96" y1="53.34" x2="62.23" y2="53.34" width="0.6096" layer="16"/>
<wire x1="62.23" y1="53.34" x2="62.23" y2="49.53" width="0.6096" layer="16"/>
<wire x1="62.23" y1="49.53" x2="62.300846875" y2="49.53" width="0.6096" layer="16"/>
<wire x1="62.300846875" y1="49.53" x2="62.300846875" y2="48.220653125" width="0.6096" layer="16"/>
<wire x1="62.300846875" y1="48.220653125" x2="67.31" y2="48.220653125" width="0.6096" layer="16"/>
<wire x1="67.31" y1="48.220653125" x2="67.31" y2="48.26" width="0.6096" layer="16"/>
</signal>
<signal name="OUT">
<contactref element="MSGEQ7" pad="3"/>
<contactref element="U$1" pad="A0"/>
<wire x1="57.15" y1="57.15" x2="56.906978125" y2="57.15" width="0.6096" layer="16"/>
<wire x1="56.906978125" y1="57.15" x2="56.8759" y2="60.13739375" width="0.6096" layer="16"/>
<wire x1="66.04" y1="13.97" x2="80.232071875" y2="13.97" width="0.6096" layer="16"/>
<wire x1="80.232071875" y1="13.97" x2="80.232071875" y2="11.096128125" width="0.6096" layer="16"/>
<wire x1="80.232071875" y1="11.096128125" x2="83.4601" y2="11.096128125" width="0.6096" layer="16"/>
<wire x1="83.4601" y1="11.096128125" x2="84.9801" y2="11.0793125" width="0.6096" layer="16"/>
<wire x1="84.9801" y1="11.0793125" x2="84.9516" y2="12.656409375" width="0.6096" layer="16"/>
<wire x1="84.9516" y1="12.656409375" x2="84.833684375" y2="31.6858625" width="0.6096" layer="16"/>
<wire x1="84.833684375" y1="31.6858625" x2="89.368228125" y2="31.759196875" width="0.6096" layer="16"/>
<wire x1="89.368228125" y1="31.759196875" x2="89.313890625" y2="33.206696875" width="0.6096" layer="16"/>
<wire x1="89.313890625" y1="33.206696875" x2="89.291371875" y2="32.97581875" width="0.6096" layer="16"/>
<wire x1="89.291371875" y1="32.97581875" x2="89.291371875" y2="64.7534625" width="0.6096" layer="16"/>
<wire x1="89.291371875" y1="64.7534625" x2="56.94534375" y2="64.83148125" width="0.6096" layer="16"/>
<wire x1="56.94534375" y1="64.83148125" x2="56.8759" y2="60.13739375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="STROBE">
<contactref element="MSGEQ7" pad="4"/>
<contactref element="U$1" pad="D7"/>
<wire x1="54.61" y1="57.15" x2="54.59795625" y2="57.96618125" width="0.6096" layer="16"/>
<wire x1="54.59795625" y1="57.96618125" x2="48.757625" y2="57.915125" width="0.6096" layer="16"/>
<wire x1="50.8" y1="19.05" x2="48.055940625" y2="19.05" width="0.6096" layer="16"/>
<wire x1="48.055940625" y1="19.05" x2="48.024571875" y2="42.02803125" width="0.6096" layer="16"/>
<wire x1="48.024571875" y1="42.02803125" x2="48.757625" y2="57.915125" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="RESET">
<contactref element="MSGEQ7" pad="7"/>
<contactref element="U$1" pad="D8"/>
<wire x1="59.69" y1="49.53" x2="59.5747375" y2="49.53" width="0.6096" layer="16"/>
<wire x1="59.5747375" y1="49.53" x2="59.6058125" y2="47.56389375" width="0.6096" layer="16"/>
<wire x1="50.8" y1="16.51" x2="53.0543375" y2="16.51" width="0.6096" layer="16"/>
<wire x1="53.0543375" y1="16.51" x2="53.0543375" y2="16.65841875" width="0.6096" layer="16"/>
<wire x1="53.0543375" y1="16.65841875" x2="53.188653125" y2="16.65841875" width="0.6096" layer="16"/>
<wire x1="53.188653125" y1="16.65841875" x2="53.188653125" y2="29.689603125" width="0.6096" layer="16"/>
<wire x1="53.188653125" y1="29.689603125" x2="59.680534375" y2="29.689603125" width="0.6096" layer="16"/>
<wire x1="59.680534375" y1="29.689603125" x2="59.680534375" y2="37.391884375" width="0.6096" layer="16"/>
<wire x1="59.680534375" y1="37.436665625" x2="59.680534375" y2="37.391884375" width="0.6096" layer="16"/>
<wire x1="59.680534375" y1="37.391884375" x2="59.680534375" y2="37.436665625" width="0.6096" layer="16"/>
<wire x1="59.680534375" y1="37.436665625" x2="59.6058125" y2="47.56389375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$1">
<contactref element="MSGEQ7" pad="5"/>
<wire x1="69.986909375" y1="52.848834375" x2="70.049453125" y2="53.2098875" width="0.6096" layer="16"/>
<wire x1="69.986909375" y1="52.848834375" x2="69.986909375" y2="47.157259375" width="0.6096" layer="16"/>
<wire x1="69.986909375" y1="47.157259375" x2="70.04421875" y2="45.52869375" width="0.6096" layer="16"/>
<wire x1="70.04421875" y1="45.52869375" x2="54.294159375" y2="45.52869375" width="0.6096" layer="16"/>
<wire x1="54.294159375" y1="45.52869375" x2="54.36483125" y2="49.0337125" width="0.6096" layer="16"/>
<wire x1="54.36483125" y1="49.0337125" x2="54.36483125" y2="49.28483125" width="0.6096" layer="16"/>
<wire x1="54.36483125" y1="49.28483125" x2="54.61" y2="49.53" width="0.6096" layer="16"/>
<contactref element="C2" pad="2"/>
<wire x1="77.6397" y1="53.2098875" x2="77.6397" y2="55.5761625" width="0.6096" layer="16"/>
<wire x1="70.049453125" y1="53.2098875" x2="77.6397" y2="53.2098875" width="0.6096" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="R3" pad="1"/>
<contactref element="X1" pad="3"/>
<wire x1="72.42" y1="18.79" x2="69.85" y2="18.79" width="0.6096" layer="16"/>
<wire x1="69.85" y1="18.79" x2="69.85" y2="29.21" width="0.6096" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="R1" pad="1"/>
<contactref element="X1" pad="2"/>
<wire x1="82.02" y1="14.29" x2="81.968059375" y2="14.29" width="0.6096" layer="16"/>
<wire x1="81.968059375" y1="14.29" x2="81.968059375" y2="18.046621875" width="0.6096" layer="16"/>
<wire x1="81.968059375" y1="18.046621875" x2="77.357078125" y2="18.046621875" width="0.6096" layer="16"/>
<wire x1="77.357078125" y1="18.046621875" x2="77.357078125" y2="29.241796875" width="0.6096" layer="16"/>
<wire x1="77.357078125" y1="29.241796875" x2="74.93" y2="29.241796875" width="0.6096" layer="16"/>
<wire x1="74.93" y1="29.241796875" x2="74.93" y2="29.21" width="0.6096" layer="16"/>
</signal>
<signal name="SIG">
<contactref element="JP1" pad="1"/>
<contactref element="C2" pad="1"/>
<wire x1="78.158359375" y1="44.870040625" x2="77.6397" y2="44.870040625" width="0.6096" layer="16"/>
<wire x1="77.6397" y1="44.870040625" x2="77.6397" y2="50.4961625" width="0.6096" layer="16"/>
<contactref element="R3" pad="2"/>
<contactref element="R1" pad="2"/>
<wire x1="69.85" y1="39.37" x2="74.93" y2="39.37" width="0.6096" layer="16"/>
<wire x1="74.93" y1="39.37" x2="78.158359375" y2="39.37" width="0.6096" layer="16"/>
<wire x1="78.158359375" y1="39.37" x2="78.158359375" y2="44.870040625" width="0.6096" layer="16"/>
</signal>
<signal name="12V">
<contactref element="POWER" pad="1"/>
<contactref element="IC1" pad="1"/>
<contactref element="S1" pad="2"/>
<wire x1="10.284571875" y1="59.285734375" x2="21.59" y2="59.285734375" width="1.4224" layer="16"/>
<wire x1="21.59" y1="59.285734375" x2="21.59" y2="55.26105625" width="1.4224" layer="16"/>
<wire x1="10.284571875" y1="59.285734375" x2="6.435025" y2="59.285734375" width="1.4224" layer="16"/>
<wire x1="6.435025" y1="59.285734375" x2="6.435025" y2="48.472365625" width="1.4224" layer="16"/>
<wire x1="6.435025" y1="48.472365625" x2="8.23359375" y2="48.472365625" width="1.4224" layer="16"/>
<wire x1="8.23359375" y1="48.472365625" x2="8.23359375" y2="45.956784375" width="1.4224" layer="16"/>
<wire x1="8.23359375" y1="45.956784375" x2="8.17469375" y2="45.956784375" width="1.4224" layer="16"/>
<wire x1="8.17469375" y1="45.956784375" x2="8.17469375" y2="42.198178125" width="1.4224" layer="16"/>
<wire x1="8.17469375" y1="42.198178125" x2="5.099809375" y2="42.198178125" width="1.4224" layer="16"/>
<wire x1="5.099809375" y1="42.198178125" x2="5.099809375" y2="42.12309375" width="1.4224" layer="16"/>
<wire x1="5.099809375" y1="42.12309375" x2="4.936578125" y2="42.12309375" width="1.4224" layer="16"/>
<wire x1="4.936578125" y1="42.12309375" x2="4.859215625" y2="23.9758375" width="1.4224" layer="16"/>
<wire x1="5.8743375" y1="23.9758375" x2="11.598946875" y2="24.005734375" width="1.4224" layer="16"/>
<contactref element="X3" pad="1"/>
<contactref element="S1" pad="3"/>
<contactref element="UV_LED" pad="1"/>
<wire x1="11.43" y1="38.0746" x2="11.43" y2="38.1" width="1.4224" layer="16"/>
<wire x1="12.04359375" y1="45.956784375" x2="12.027" y2="45.956784375" width="1.4224" layer="16"/>
<wire x1="12.027" y1="45.956784375" x2="12.027" y2="37.7685125" width="1.4224" layer="16"/>
<wire x1="12.027" y1="37.7685125" x2="11.43" y2="38.0746" width="0" layer="19" extent="16-16"/>
<wire x1="8.23359375" y1="45.956784375" x2="12.04359375" y2="45.956784375" width="0" layer="19" extent="1-1"/>
<wire x1="5.8743375" y1="23.9758375" x2="4.859215625" y2="23.9758375" width="0" layer="19" extent="16-16"/>
<wire x1="11.43" y1="24.0284" x2="11.598946875" y2="24.005734375" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$11">
</signal>
<signal name="N$13">
</signal>
<signal name="N$9">
</signal>
<signal name="N$8">
</signal>
<signal name="N$5">
<via x="21.949371875" y="30.991321875" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$7">
<via x="21.655753125" y="17.210596875" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$10">
<via x="47.61959375" y="17.234278125" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$12">
<via x="48.07099375" y="42.76409375" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$14">
<via x="48.084690625" y="57.81188125" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$15">
<via x="56.859921875" y="60.095696875" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$16">
<via x="56.859921875" y="65.06635625" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$17">
<via x="59.6531375" y="38.09859375" extent="1-16" drill="0.9" diameter="2.1844"/>
</signal>
<signal name="N$18">
<via x="59.677453125" y="46.9730875" extent="1-16" drill="0.9" diameter="1.6764"/>
</signal>
<signal name="N$19">
<via x="45.900134375" y="30.839009375" extent="1-16" drill="0.9" diameter="1.6764"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
