<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="8.0.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="16" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="14" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="7" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="113" name="IDFDebug" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="153" name="FabDoc1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="154" name="FabDoc2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="155" name="FabDoc3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="231bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="SparkFun-AnalogIC">
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find all manner of analog ICs- DACs, ADCs, video chips, op-amps, and others.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt;Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="SOIC8">
<wire x1="-2.362" y1="-1.803" x2="2.362" y2="-1.803" width="0.1524" layer="51"/>
<wire x1="2.362" y1="-1.803" x2="2.362" y2="1.803" width="0.1524" layer="21"/>
<wire x1="2.362" y1="1.803" x2="-2.362" y2="1.803" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="1.803" x2="-2.362" y2="-1.803" width="0.1524" layer="21"/>
<circle x="-2.667" y="-2.032" radius="0.1436" width="0.2032" layer="21"/>
<smd name="1" x="-1.905" y="-2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="2" x="-0.635" y="-2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="3" x="0.635" y="-2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="4" x="1.905" y="-2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="5" x="1.905" y="2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="6" x="0.635" y="2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="7" x="-0.635" y="2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<smd name="8" x="-1.905" y="2.6162" dx="0.6096" dy="2.2098" layer="1"/>
<text x="-1.27" y="-0.635" size="0.4064" layer="27">&gt;VALUE</text>
<text x="-1.27" y="0" size="0.4064" layer="25">&gt;NAME</text>
<rectangle x1="-2.0828" y1="-2.8702" x2="-1.7272" y2="-1.8542" layer="51"/>
<rectangle x1="-0.8128" y1="-2.8702" x2="-0.4572" y2="-1.8542" layer="51"/>
<rectangle x1="0.4572" y1="-2.8702" x2="0.8128" y2="-1.8542" layer="51"/>
<rectangle x1="1.7272" y1="-2.8702" x2="2.0828" y2="-1.8542" layer="51"/>
<rectangle x1="-2.0828" y1="1.8542" x2="-1.7272" y2="2.8702" layer="51"/>
<rectangle x1="-0.8128" y1="1.8542" x2="-0.4572" y2="2.8702" layer="51"/>
<rectangle x1="0.4572" y1="1.8542" x2="0.8128" y2="2.8702" layer="51"/>
<rectangle x1="1.7272" y1="1.8542" x2="2.0828" y2="2.8702" layer="51"/>
</package>
<package name="DIL-08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="MSGEQ7">
<wire x1="-12.7" y1="7.62" x2="10.16" y2="7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="7.62" x2="10.16" y2="-5.08" width="0.254" layer="94"/>
<wire x1="10.16" y1="-5.08" x2="-12.7" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-5.08" x2="-12.7" y2="7.62" width="0.254" layer="94"/>
<text x="-6.096" y="8.636" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.096" y="-7.874" size="1.778" layer="96">MSGEQ7</text>
<pin name="DCOUT" x="15.24" y="5.08" visible="pin" length="middle" rot="R180"/>
<pin name="CG" x="15.24" y="0" visible="pin" length="middle" rot="R180"/>
<pin name="CKIN" x="15.24" y="2.54" visible="pin" length="middle" rot="R180"/>
<pin name="GND" x="15.24" y="-2.54" visible="pin" length="middle" rot="R180"/>
<pin name="RESET" x="-17.78" y="-2.54" visible="pin" length="middle" direction="in"/>
<pin name="STROBE" x="-17.78" y="0" visible="pin" length="middle" direction="in"/>
<pin name="AUDIO_IN" x="-17.78" y="2.54" visible="pin" length="middle" direction="in"/>
<pin name="VDD" x="-17.78" y="5.08" visible="pin" length="middle" direction="in"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MSGEQ7" prefix="IC">
<description>7-band graphic equalizer</description>
<gates>
<gate name="G$1" symbol="MSGEQ7" x="0" y="5.08"/>
</gates>
<devices>
<device name="SOIC" package="SOIC8">
<connects>
<connect gate="G$1" pin="AUDIO_IN" pad="5"/>
<connect gate="G$1" pin="CG" pad="6"/>
<connect gate="G$1" pin="CKIN" pad="8"/>
<connect gate="G$1" pin="DCOUT" pad="3"/>
<connect gate="G$1" pin="GND" pad="2"/>
<connect gate="G$1" pin="RESET" pad="7"/>
<connect gate="G$1" pin="STROBE" pad="4"/>
<connect gate="G$1" pin="VDD" pad="1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DIL" package="DIL-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="Arduino-clone">
<description>Arduino Clone pinheaders
By cl@xganon.com
http://www.xganon.com</description>
<packages>
<package name="NANO">
<pad name="TX0" x="5.08" y="-8.89" drill="0.8" shape="long"/>
<pad name="RX1" x="5.08" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST1" x="5.08" y="-3.81" drill="0.8" shape="long"/>
<pad name="GND1" x="5.08" y="-1.27" drill="0.8" shape="long"/>
<pad name="D2" x="5.08" y="1.27" drill="0.8" shape="long"/>
<pad name="D3" x="5.08" y="3.81" drill="0.8" shape="long"/>
<pad name="D4" x="5.08" y="6.35" drill="0.8" shape="long"/>
<pad name="D5" x="5.08" y="8.89" drill="0.8" shape="long"/>
<pad name="D6" x="5.08" y="11.43" drill="0.8" shape="long"/>
<pad name="D7" x="5.08" y="13.97" drill="0.8" shape="long"/>
<pad name="D8" x="5.08" y="16.51" drill="0.8" shape="long"/>
<pad name="D9" x="5.08" y="19.05" drill="0.8" shape="long"/>
<pad name="RAW" x="-10.16" y="-8.89" drill="0.8" shape="long"/>
<pad name="GND" x="-10.16" y="-6.35" drill="0.8" shape="long"/>
<pad name="RST" x="-10.16" y="-3.81" drill="0.8" shape="long"/>
<pad name="A3" x="-10.16" y="11.43" drill="0.8" shape="long"/>
<pad name="A2" x="-10.16" y="13.97" drill="0.8" shape="long"/>
<pad name="A1" x="-10.16" y="16.51" drill="0.8" shape="long"/>
<pad name="A0" x="-10.16" y="19.05" drill="0.8" shape="long"/>
<pad name="D13" x="-10.16" y="26.67" drill="0.8" shape="long"/>
<pad name="D12" x="5.08" y="26.67" drill="0.8" shape="long"/>
<pad name="D11" x="5.08" y="24.13" drill="0.8" shape="long"/>
<pad name="D10" x="5.08" y="21.59" drill="0.8" shape="long"/>
<pad name="3.3V" x="-10.16" y="24.13" drill="0.8" shape="long" rot="R180"/>
<pad name="AREF" x="-10.16" y="21.59" drill="0.8" shape="long" rot="R180"/>
<pad name="5V" x="-10.16" y="-1.27" drill="0.8" shape="long"/>
<pad name="ICSP2" x="-5.08" y="-7.62" drill="0.8" rot="R90"/>
<pad name="ICSP4" x="-2.54" y="-7.62" drill="0.8" rot="R90"/>
<pad name="ICSP6" x="0" y="-7.62" drill="0.8" rot="R90"/>
<pad name="A4" x="-10.16" y="8.89" drill="0.8" shape="long" rot="R180"/>
<pad name="A5" x="-10.16" y="6.35" drill="0.8" shape="long" rot="R180"/>
<pad name="A6" x="-10.16" y="3.81" drill="0.8" shape="long" rot="R180"/>
<pad name="A7" x="-10.16" y="1.27" drill="0.8" shape="long" rot="R180"/>
<pad name="ICSP1" x="-5.08" y="-10.16" drill="0.8" rot="R90"/>
<pad name="ICSP3" x="-2.54" y="-10.16" drill="0.8" rot="R90"/>
<pad name="ICSP5" x="0" y="-10.16" drill="0.8" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="NANO">
<pin name="3.3V" x="-22.86" y="12.7" visible="pin" length="middle"/>
<pin name="AREF" x="-22.86" y="10.16" visible="pin" length="middle"/>
<pin name="ICSP1" x="-10.16" y="-27.94" visible="off" length="point" rot="R270"/>
<pin name="ICSP2" x="-10.16" y="-25.4" visible="off" length="point" rot="R270"/>
<pin name="ICSP3" x="-7.62" y="-27.94" visible="off" length="point" rot="R270"/>
<pin name="ICSP4" x="-7.62" y="-25.4" visible="off" length="point" rot="R270"/>
<pin name="TX0" x="10.16" y="-20.32" visible="pin" length="middle" rot="R180"/>
<pin name="RX1" x="10.16" y="-17.78" visible="pin" length="middle" rot="R180"/>
<pin name="RST1" x="10.16" y="-15.24" visible="pin" length="middle" rot="R180"/>
<pin name="GND2" x="10.16" y="-12.7" visible="pin" length="middle" rot="R180"/>
<pin name="D2" x="10.16" y="-10.16" visible="pin" length="middle" rot="R180"/>
<pin name="D3" x="10.16" y="-7.62" visible="pin" length="middle" rot="R180"/>
<pin name="D4" x="10.16" y="-5.08" visible="pin" length="middle" rot="R180"/>
<pin name="D5" x="10.16" y="-2.54" visible="pin" length="middle" rot="R180"/>
<pin name="D6" x="10.16" y="0" visible="pin" length="middle" rot="R180"/>
<pin name="D7" x="10.16" y="2.54" visible="pin" length="middle" rot="R180"/>
<pin name="D8" x="10.16" y="5.08" visible="pin" length="middle" rot="R180"/>
<pin name="D9" x="10.16" y="7.62" visible="pin" length="middle" rot="R180"/>
<pin name="RAW" x="-22.86" y="-20.32" visible="pin" length="middle"/>
<pin name="GND" x="-22.86" y="-17.78" visible="pin" length="middle"/>
<pin name="RST" x="-22.86" y="-15.24" visible="pin" length="middle"/>
<pin name="5.5V" x="-22.86" y="-12.7" visible="pin" length="middle"/>
<pin name="A3" x="-22.86" y="0" visible="pin" length="middle"/>
<pin name="A2" x="-22.86" y="2.54" visible="pin" length="middle"/>
<pin name="A1" x="-22.86" y="5.08" visible="pin" length="middle"/>
<pin name="A0" x="-22.86" y="7.62" visible="pin" length="middle"/>
<pin name="D13" x="-22.86" y="15.24" visible="pin" length="middle"/>
<pin name="D12" x="10.16" y="15.24" visible="pin" length="middle" rot="R180"/>
<pin name="D11" x="10.16" y="12.7" visible="pin" length="middle" rot="R180"/>
<pin name="D10" x="10.16" y="10.16" visible="pin" length="middle" rot="R180"/>
<pin name="A7" x="-22.86" y="-10.16" visible="pin" length="middle"/>
<pin name="A6" x="-22.86" y="-7.62" visible="pin" length="middle"/>
<pin name="A5" x="-22.86" y="-5.08" visible="pin" length="middle"/>
<pin name="A4" x="-22.86" y="-2.54" visible="pin" length="middle"/>
<pin name="ICSP5" x="-5.08" y="-27.94" visible="off" length="point" rot="R270"/>
<pin name="ICSP6" x="-5.08" y="-25.4" visible="off" length="point" rot="R270"/>
<wire x1="-17.78" y1="17.78" x2="-17.78" y2="-30.48" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-30.48" x2="5.08" y2="-30.48" width="0.254" layer="94"/>
<wire x1="5.08" y1="-30.48" x2="5.08" y2="17.78" width="0.254" layer="94"/>
<wire x1="5.08" y1="17.78" x2="-17.78" y2="17.78" width="0.254" layer="94"/>
<text x="-12.7" y="20.32" size="1.778" layer="95">Arduino Nano</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="NANO">
<description>Arduino Nano</description>
<gates>
<gate name="G$1" symbol="NANO" x="7.62" y="2.54"/>
</gates>
<devices>
<device name="" package="NANO">
<connects>
<connect gate="G$1" pin="3.3V" pad="3.3V"/>
<connect gate="G$1" pin="5.5V" pad="5V"/>
<connect gate="G$1" pin="A0" pad="A0"/>
<connect gate="G$1" pin="A1" pad="A1"/>
<connect gate="G$1" pin="A2" pad="A2"/>
<connect gate="G$1" pin="A3" pad="A3"/>
<connect gate="G$1" pin="A4" pad="A4"/>
<connect gate="G$1" pin="A5" pad="A5"/>
<connect gate="G$1" pin="A6" pad="A6"/>
<connect gate="G$1" pin="A7" pad="A7"/>
<connect gate="G$1" pin="AREF" pad="AREF"/>
<connect gate="G$1" pin="D10" pad="D10"/>
<connect gate="G$1" pin="D11" pad="D11"/>
<connect gate="G$1" pin="D12" pad="D12"/>
<connect gate="G$1" pin="D13" pad="D13"/>
<connect gate="G$1" pin="D2" pad="D2"/>
<connect gate="G$1" pin="D3" pad="D3"/>
<connect gate="G$1" pin="D4" pad="D4"/>
<connect gate="G$1" pin="D5" pad="D5"/>
<connect gate="G$1" pin="D6" pad="D6"/>
<connect gate="G$1" pin="D7" pad="D7"/>
<connect gate="G$1" pin="D8" pad="D8"/>
<connect gate="G$1" pin="D9" pad="D9"/>
<connect gate="G$1" pin="GND" pad="GND"/>
<connect gate="G$1" pin="GND2" pad="GND1"/>
<connect gate="G$1" pin="ICSP1" pad="ICSP1"/>
<connect gate="G$1" pin="ICSP2" pad="ICSP2"/>
<connect gate="G$1" pin="ICSP3" pad="ICSP3"/>
<connect gate="G$1" pin="ICSP4" pad="ICSP4"/>
<connect gate="G$1" pin="ICSP5" pad="ICSP5"/>
<connect gate="G$1" pin="ICSP6" pad="ICSP6"/>
<connect gate="G$1" pin="RAW" pad="RAW"/>
<connect gate="G$1" pin="RST" pad="RST"/>
<connect gate="G$1" pin="RST1" pad="RST1"/>
<connect gate="G$1" pin="RX1" pad="RX1"/>
<connect gate="G$1" pin="TX0" pad="TX0"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
<symbols>
<symbol name="IGFET-EN-GDS">
<wire x1="-2.54" y1="-2.54" x2="-1.2192" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="0.762" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0" y1="3.683" x2="0" y2="1.397" width="0.254" layer="94"/>
<wire x1="1.905" y1="0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="1.905" y1="-0.635" x2="0.635" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.397" x2="0" y2="-3.683" width="0.254" layer="94"/>
<wire x1="-1.143" y1="2.54" x2="-1.143" y2="-2.54" width="0.254" layer="94"/>
<text x="-11.43" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="-11.43" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<pin name="D" x="5.08" y="2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="S" x="5.08" y="-2.54" visible="off" length="middle" direction="pas" rot="R180"/>
<pin name="G" x="-5.08" y="-2.54" visible="off" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BUZ11" prefix="Q">
<description>&lt;b&gt;N-Channel Enhancement MOSFET&lt;/b&gt; 50V; 30A; 0,040Ohm</description>
<gates>
<gate name="G$1" symbol="IGFET-EN-GDS" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO220">
<connects>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="G" pad="1"/>
<connect gate="G$1" pin="S" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1206">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
</package>
<package name="R3225">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
</package>
<package name="R5025">
</package>
<package name="R5025W">
</package>
<package name="R6332">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="PRL1632">
<description>&lt;b&gt;PRL1632 are realized as 1W for 3.2 × 1.6mm(1206)&lt;/b&gt;&lt;p&gt;
Source: http://www.mouser.com/ds/2/392/products_18-2245.pdf</description>
<wire x1="0.7275" y1="-1.5228" x2="-0.7277" y2="-1.5228" width="0.1524" layer="51"/>
<wire x1="0.7275" y1="1.5228" x2="-0.7152" y2="1.5228" width="0.1524" layer="51"/>
<smd name="2" x="0.822" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="1" x="-0.822" y="0" dx="1" dy="3.2" layer="1"/>
<text x="-1.4" y="1.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.4" y="-3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-1.6" x2="-0.4" y2="1.6" layer="51"/>
<rectangle x1="0.4" y1="-1.6" x2="0.8" y2="1.6" layer="51"/>
</package>
<package name="R01005">
<smd name="1" x="-0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<smd name="2" x="0.1625" y="0" dx="0.2" dy="0.25" layer="1"/>
<text x="-0.4" y="0.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.4" y="-1.6" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2" y1="-0.1" x2="-0.075" y2="0.1" layer="51"/>
<rectangle x1="0.075" y1="-0.1" x2="0.2" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="0.05" x2="0.15" y2="0.1" layer="51"/>
<rectangle x1="-0.15" y1="-0.1" x2="0.15" y2="-0.05" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="R-EU-1">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU-1" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PRL1632" package="PRL1632">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="01005" package="R01005">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="SparkFun-Aesthetics">
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find non-functional items- supply symbols, logos, notations, frame blocks, etc.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt; Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
</packages>
<symbols>
<symbol name="DGND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="VDD">
<wire x1="0.762" y1="1.27" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="-0.762" y2="1.27" width="0.254" layer="94"/>
<text x="-1.016" y="3.556" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VDD" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="DGND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="VDD" prefix="SUPPLY">
<gates>
<gate name="VDD" symbol="VDD" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="C10B4">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 4 mm, grid 10.16 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-3.429" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 5 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 6 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 5 mm, grid 15 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-7.493" y="2.794" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 6 mm, grid 15 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.302" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C15B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 7 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.81" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 8 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.318" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 9 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.699" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C2.5-2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 2.5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.651" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-4">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 4 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-1.778" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-6">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 6 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="2.667" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B10">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 10 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="-11.303" y="5.588" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 11 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 6 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.302" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 7 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 8 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="4.572" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 11 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<text x="-13.716" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B13">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 13 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="6.858" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B15">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 15 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B17">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 17 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B20">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 20 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C27.5B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 9 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B15">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 15 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<text x="-18.796" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B19">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 19 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B20">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 20 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B2.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 2.5 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 3 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B4.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B7.2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 7.2 mm, grid 5.08 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B3">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 3 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<text x="-3.81" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B4">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 4 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-3.81" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B5">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 5 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.81" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B6">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 6 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-3.683" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.889" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 3 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="C">
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;&lt;p&gt;
naming: grid - package width</description>
<gates>
<gate name="G$1" symbol="C" x="0" y="0"/>
</gates>
<devices>
<device name="10/4" package="C10B4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10/5" package="C10B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10/6" package="C10B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/5" package="C15B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/6" package="C15B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/7" package="C15B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/8" package="C15B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/9" package="C15B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/2" package="C2.5-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/4" package="C2.5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/5" package="C2.5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/6" package="C2.5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/10" package="C22.5B10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/11" package="C22.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/6" package="C22.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/7" package="C22.5B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/8" package="C22.5B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/11" package="C27.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/13" package="C27.5B13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/15" package="C27.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/17" package="C27.5B17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/20" package="C27.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/9" package="C27.5B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/15" package="C37.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/19" package="C37.5B19">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/20" package="C37.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/2.5" package="C5B2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3" package="C5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3.5" package="C5B3.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/4.5" package="C5B4.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5" package="C5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5.5" package="C5B5.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/7.2" package="C5B7.2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/3" package="C7.5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/4" package="C7.5B4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/5" package="C7.5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/6" package="C7.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2,5-3" package="C2.5-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-lumberg">
<description>&lt;b&gt;Lumberg Connectors&lt;/b&gt;&lt;p&gt;
include con-mfs.lbr - 2001.03.22&lt;br&gt;
Jack connectors - 2005.11.23&lt;p&gt;
http://www.lumberg.de&lt;p&gt;
<packages>
<package name="1503_09">
<description>&lt;b&gt;Jack connectors according to JISC 6560, 3.5 mm&lt;/b&gt;&lt;p&gt;
Klinkeneinbaukupplung nach JISC 6560, 3,5 mm, 3-polig/&lt;br&gt;
stereo, abgewinkelte Ausführung, mit 2 Öffnern und Lötaugen,&lt;br&gt;
für Leiterplatten Rückseitenmontage&lt;p&gt;
Source: http://www.lumberg.com/Produkte/PDFs/1503_09.pdf</description>
<wire x1="0.75" y1="-2.1" x2="0.35" y2="-1.7" width="0" layer="46" curve="90"/>
<wire x1="0.35" y1="-1.7" x2="-0.35" y2="-1.7" width="0" layer="46"/>
<wire x1="-0.35" y1="-1.7" x2="-0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-0.75" y1="-2.1" x2="-0.35" y2="-2.5" width="0" layer="46" curve="90"/>
<wire x1="-0.35" y1="-2.5" x2="0.35" y2="-2.5" width="0" layer="46"/>
<wire x1="0.35" y1="-2.5" x2="0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-6.15" x2="-4.15" y2="-5.75" width="0" layer="46" curve="90"/>
<wire x1="-4.15" y1="-5.75" x2="-4.15" y2="-5.05" width="0" layer="46"/>
<wire x1="-4.15" y1="-5.05" x2="-4.55" y2="-4.65" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-4.65" x2="-4.95" y2="-5.05" width="0" layer="46" curve="90"/>
<wire x1="-4.95" y1="-5.05" x2="-4.95" y2="-5.75" width="0" layer="46"/>
<wire x1="-4.95" y1="-5.75" x2="-4.55" y2="-6.15" width="0" layer="46" curve="90"/>
<wire x1="-3.25" y1="-13.1" x2="-3.65" y2="-12.7" width="0" layer="46" curve="90"/>
<wire x1="-3.65" y1="-12.7" x2="-4.35" y2="-12.7" width="0" layer="46"/>
<wire x1="-4.35" y1="-12.7" x2="-4.75" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="-4.75" y1="-13.1" x2="-4.35" y2="-13.5" width="0" layer="46" curve="90"/>
<wire x1="-4.35" y1="-13.5" x2="-3.65" y2="-13.5" width="0" layer="46"/>
<wire x1="-3.65" y1="-13.5" x2="-3.25" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-9.25" x2="3.05" y2="-8.85" width="0" layer="46" curve="90"/>
<wire x1="3.05" y1="-8.85" x2="3.05" y2="-8.15" width="0" layer="46"/>
<wire x1="3.05" y1="-8.15" x2="2.65" y2="-7.75" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-7.75" x2="2.25" y2="-8.15" width="0" layer="46" curve="90"/>
<wire x1="2.25" y1="-8.15" x2="2.25" y2="-8.85" width="0" layer="46"/>
<wire x1="2.25" y1="-8.85" x2="2.65" y2="-9.25" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-10.65" x2="5.45" y2="-10.25" width="0" layer="46" curve="90"/>
<wire x1="5.45" y1="-10.25" x2="5.45" y2="-9.55" width="0" layer="46"/>
<wire x1="5.45" y1="-9.55" x2="5.05" y2="-9.15" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-9.15" x2="4.65" y2="-9.55" width="0" layer="46" curve="90"/>
<wire x1="4.65" y1="-9.55" x2="4.65" y2="-10.25" width="0" layer="46"/>
<wire x1="4.65" y1="-10.25" x2="5.05" y2="-10.65" width="0" layer="46" curve="90"/>
<wire x1="-5.4" y1="-0.1" x2="5.9" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-0.1" x2="5.9" y2="-14" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-14" x2="-5.4" y2="-14" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-14" x2="-5.4" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="0" x2="-2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="3.4" x2="2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="2.9" y1="3.4" x2="2.9" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="-2.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="2" x="-4.55" y="-5.4" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="3" x="5.05" y="-9.9" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="4" x="-4" y="-13.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="5" x="2.65" y="-8.5" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<text x="0" y="7.24" size="1.27" layer="25">&gt;NAME</text>
<text x="0" y="-19.24" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="JACK-2SWITCH">
<wire x1="-2.54" y1="5.08" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="5.08" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="3.302" y2="3.302" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="4.826" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="4.826" x2="-2.286" y2="4.064" width="0.254" layer="94"/>
<wire x1="-2.286" y1="4.064" x2="-1.778" y2="4.064" width="0.254" layer="94"/>
<wire x1="-1.778" y1="4.064" x2="-2.032" y2="4.826" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="5.08" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-1.524" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.524" y1="-2.54" x2="1.016" y2="0" width="0.1524" layer="94"/>
<wire x1="1.016" y1="0" x2="1.778" y2="-0.762" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="0" x2="-2.032" y2="-2.286" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-2.286" x2="-2.286" y2="-1.524" width="0.254" layer="94"/>
<wire x1="-2.286" y1="-1.524" x2="-1.778" y2="-1.524" width="0.254" layer="94"/>
<wire x1="-1.778" y1="-1.524" x2="-2.032" y2="-2.286" width="0.254" layer="94"/>
<text x="-2.54" y="6.35" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="2.286" y1="0.762" x2="7.874" y2="1.778" layer="94" rot="R90"/>
<pin name="1" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-5.08" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="1503_09" prefix="X">
<gates>
<gate name="G$1" symbol="JACK-2SWITCH" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1503_09">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="1243244" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2-H">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;&lt;p&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.</description>
<wire x1="-5.08" y1="-7.239" x2="-5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-7.239" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.429" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.429" x2="5.08" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.461" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.429" x2="5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-2.794" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="2.159" x2="-4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="2.159" x2="0.4826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="-2.794" x2="4.5466" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="-2.794" x2="4.5466" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.5466" y1="2.159" x2="0.4826" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="4.8006" y1="-3.048" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="4.8006" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2286" y1="2.413" x2="0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="2.413" x2="-0.2286" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-0.2286" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.8006" y1="2.413" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2286" y1="-3.048" x2="-4.8006" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-4.5466" y1="0" x2="-0.4826" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.5466" y1="-2.413" x2="-4.2926" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-0.4826" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7366" y1="-2.667" x2="-4.2926" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-2.413" x2="-1.1176" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.9116" y1="-2.667" x2="-3.6576" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.6576" y1="-0.127" x2="-3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.127" x2="-1.3716" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-1.3716" y1="-0.127" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6576" y1="-0.762" x2="-3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3716" y1="-0.762" x2="-1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="-5.08" y2="-3.81" width="0.0508" layer="21"/>
<wire x1="-5.08" y1="-3.81" x2="-5.08" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.81" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.4826" y1="0" x2="4.5466" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="1.3716" y1="-0.127" x2="3.6576" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.127" x2="1.3716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3716" y1="-0.762" x2="1.3716" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.762" x2="3.6576" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6576" y1="-0.127" x2="3.6576" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-2.667" x2="1.3716" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="3.6576" y1="-2.413" x2="3.9116" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2926" y1="-2.667" x2="0.7366" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.2926" y1="-2.667" x2="4.5466" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="0.4826" y1="-2.413" x2="0.7366" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.762" y1="-7.366" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-7.239" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.239" x2="-2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-7.366" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.794" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-7.239" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.239" x2="-0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-2.286" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-7.366" x2="-0.762" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-7.239" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="2.286" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="2.794" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.239" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-7.366" x2="4.318" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.366" x2="4.318" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-7.239" x2="5.08" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.366" x2="0.762" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-7.239" x2="2.286" y2="-7.239" width="0.1524" layer="21"/>
<circle x="-2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="2.5146" y="0" radius="1.397" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="3.556" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
<text x="1.905" y="-5.715" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.6576" y1="-1.524" x2="-1.3716" y2="-0.762" layer="51"/>
<rectangle x1="1.3716" y1="-1.524" x2="3.6576" y2="-0.762" layer="51"/>
<rectangle x1="-3.6576" y1="-2.667" x2="-1.3716" y2="-1.524" layer="21"/>
<rectangle x1="1.3716" y1="-2.667" x2="3.6576" y2="-1.524" layer="21"/>
</package>
<package name="AK500/4-H">
<wire x1="-10.0838" y1="-7.239" x2="-10.0838" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="2.794" x2="-10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-7.239" x2="-9.3472" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="2.794" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-3.429" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.0838" y1="-3.429" x2="-10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.429" x2="10.0838" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="2.794" x2="10.4648" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="-3.429" x2="10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.4648" y1="2.794" x2="10.0838" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.4864" y1="2.159" x2="-5.4864" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.5504" y1="-2.794" x2="-5.4864" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-9.5504" y1="-2.794" x2="-9.5504" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.4864" y1="2.159" x2="-9.5504" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="2.159" x2="-4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="-2.794" x2="-0.4572" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="-2.794" x2="-0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="2.159" x2="-4.5212" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-0.2032" y1="-3.048" x2="-4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-0.2032" y1="-3.048" x2="-0.2032" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.7752" y1="2.413" x2="-0.2032" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-4.7752" y1="2.413" x2="-4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-5.2324" y1="2.413" x2="-5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-9.8044" y1="2.413" x2="-5.2324" y2="2.413" width="0.0508" layer="21"/>
<wire x1="-9.8044" y1="2.413" x2="-9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-5.2324" y1="-3.048" x2="-9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-9.5504" y1="0" x2="-5.4864" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-9.5504" y1="-2.413" x2="-9.2964" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7404" y1="-2.667" x2="-5.4864" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7404" y1="-2.667" x2="-9.2964" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-6.3754" y1="-2.413" x2="-6.1214" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-8.9154" y1="-2.667" x2="-8.6614" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-8.6614" y1="-0.127" x2="-8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.127" x2="-6.3754" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-6.3754" y1="-0.127" x2="-6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.762" x2="-6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.6614" y1="-0.762" x2="-8.6614" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-6.3754" y1="-0.762" x2="-6.3754" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.81" x2="-10.0838" y2="-3.81" width="0.0508" layer="21"/>
<wire x1="-10.0838" y1="-3.81" x2="-10.0838" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-3.81" x2="10.0838" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.5212" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.6322" y1="-0.127" x2="-1.3462" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.127" x2="-3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.762" x2="-1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.6322" y1="-0.762" x2="-3.6322" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3462" y1="-0.762" x2="-1.3462" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-1.3462" y1="-0.127" x2="-1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.8862" y1="-2.667" x2="-3.6322" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.3462" y1="-2.413" x2="-1.0922" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.7112" y1="-2.667" x2="-4.2672" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-0.7112" y1="-2.667" x2="-0.4572" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.5212" y1="-2.413" x2="-4.2672" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.7912" y1="-7.366" x2="-5.7912" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-5.7912" y1="-7.239" x2="-4.2418" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.366" x2="-9.3472" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.239" x2="-7.8232" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-9.3472" y1="-7.366" x2="-7.8232" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-7.8232" y1="-7.239" x2="-7.8232" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-7.8232" y1="-7.239" x2="-7.3152" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.239" x2="-5.7912" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.366" x2="-7.3152" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.3152" y1="-7.366" x2="-5.7912" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.7178" y1="-7.239" x2="-2.7178" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.7178" y1="-7.239" x2="-2.2098" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.366" x2="-2.7178" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.366" x2="-2.2098" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.239" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-7.366" x2="-0.6858" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="-7.366" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.366" x2="-4.2418" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-4.2418" y1="-7.239" x2="-2.7178" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="2.159" x2="4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-2.794" x2="4.5212" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-2.794" x2="0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="2.159" x2="0.4572" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.7752" y1="2.413" x2="4.7752" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="0.2032" y1="2.413" x2="4.7752" y2="2.413" width="0.0508" layer="21"/>
<wire x1="0.2032" y1="2.413" x2="0.2032" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="4.7752" y1="-3.048" x2="0.2032" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="0.4572" y1="0" x2="4.5212" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="0.4572" y1="-2.413" x2="0.7112" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2672" y1="-2.667" x2="4.5212" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="4.2672" y1="-2.667" x2="0.7112" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="3.6322" y1="-2.413" x2="3.8862" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="1.0922" y1="-2.667" x2="1.3462" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="1.3462" y1="-0.127" x2="1.3462" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.127" x2="3.6322" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="3.6322" y1="-0.127" x2="3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.762" x2="3.6322" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.3462" y1="-0.762" x2="1.3462" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="3.6322" y1="-0.762" x2="3.6322" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="4.2164" y1="-7.366" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.366" x2="2.1844" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.366" x2="4.2164" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="0.6604" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="-0.6858" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="0.6604" y1="-7.239" x2="2.1844" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.1844" y1="-7.239" x2="2.1844" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.1844" y1="-7.239" x2="2.6924" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.239" x2="2.6924" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="2.6924" y1="-7.239" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="10.0838" y1="-7.239" x2="9.2456" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="9.5504" y1="2.159" x2="9.5504" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.4864" y1="-2.794" x2="9.5504" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.4864" y1="-2.794" x2="5.4864" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.5504" y1="2.159" x2="5.4864" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.8044" y1="2.413" x2="9.8044" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="5.2324" y1="2.413" x2="9.8044" y2="2.413" width="0.0508" layer="21"/>
<wire x1="5.2324" y1="2.413" x2="5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="9.8044" y1="-3.048" x2="5.2324" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="5.4864" y1="0" x2="9.5504" y2="0" width="0.1524" layer="21" curve="-180"/>
<wire x1="5.4864" y1="-2.413" x2="5.7404" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="9.2964" y1="-2.667" x2="9.5504" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="9.2964" y1="-2.667" x2="5.7404" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="8.6614" y1="-2.413" x2="8.9154" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<wire x1="6.1214" y1="-2.667" x2="6.3754" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="6.3754" y1="-0.127" x2="6.3754" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.127" x2="8.6614" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="8.6614" y1="-0.127" x2="8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.762" x2="8.6614" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.3754" y1="-0.762" x2="6.3754" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="8.6614" y1="-0.762" x2="8.6614" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="9.2456" y1="-7.366" x2="9.2456" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.366" x2="7.2136" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.366" x2="9.2456" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.239" x2="5.6896" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.2136" y1="-7.239" x2="7.2136" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.239" x2="7.7216" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="7.7216" y1="-7.239" x2="7.2136" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="9.2456" y1="-7.239" x2="7.7216" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="7.2136" y1="-7.239" x2="5.6896" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="5.6896" y1="-7.239" x2="4.2164" y2="-7.239" width="0.1524" layer="21"/>
<circle x="-7.5184" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="-2.4892" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="2.4892" y="0" radius="1.397" width="0.1524" layer="51"/>
<circle x="7.5184" y="0" radius="1.397" width="0.1524" layer="51"/>
<pad name="1" x="-7.5184" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="-2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="4" x="7.5184" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-10.0838" y="3.556" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.0838" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.2042" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
<text x="-3.0988" y="-5.715" size="1.27" layer="21" ratio="10">2</text>
<text x="1.8034" y="-5.715" size="1.27" layer="21" ratio="10">3</text>
<text x="6.8326" y="-5.715" size="1.27" layer="21" ratio="10">4</text>
<rectangle x1="-8.6614" y1="-1.524" x2="-6.3754" y2="-0.762" layer="51"/>
<rectangle x1="-3.6322" y1="-1.524" x2="-1.3462" y2="-0.762" layer="51"/>
<rectangle x1="-8.6614" y1="-2.667" x2="-6.3754" y2="-1.524" layer="21"/>
<rectangle x1="-3.6322" y1="-2.667" x2="-1.3462" y2="-1.524" layer="21"/>
<rectangle x1="1.3462" y1="-1.524" x2="3.6322" y2="-0.762" layer="51"/>
<rectangle x1="1.3462" y1="-2.667" x2="3.6322" y2="-1.524" layer="21"/>
<rectangle x1="6.3754" y1="-1.524" x2="8.6614" y2="-0.762" layer="51"/>
<rectangle x1="6.3754" y1="-2.667" x2="8.6614" y2="-1.524" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="KL">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KLV">
<text x="-3.81" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="AK500/2-H" prefix="X" uservalue="yes">
<gates>
<gate name="-1" symbol="KL" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="KLV" x="0" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK500/2-H">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
</connects>
<technologies>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AK500/4-H" prefix="X" uservalue="yes">
<gates>
<gate name="-1" symbol="KL" x="0" y="12.7" addlevel="always"/>
<gate name="-2" symbol="KL" x="0" y="7.62" addlevel="always"/>
<gate name="-3" symbol="KL" x="0" y="2.54" addlevel="always"/>
<gate name="-4" symbol="KLV" x="0" y="-2.54" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK500/4-H">
<connects>
<connect gate="-3" pin="KL" pad="3"/>
<connect gate="-4" pin="KL" pad="4"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO92">
<description>&lt;b&gt;TO-92&lt;/b&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.1524" layer="51" curve="-34.298964"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
<package name="TO39">
<description>&lt;b&gt;Metal Can Package&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-2.794" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO252">
<description>&lt;b&gt;SMALL OUTLINE TRANSISTOR&lt;/b&gt;&lt;p&gt;
TS-003</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="3" x="0" y="2.5" dx="5.4" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<smd name="2" x="2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="78XX">
<wire x1="-7.62" y1="-5.08" x2="7.62" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="7.62" y1="2.54" x2="-7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="-5.08" width="0.4064" layer="94"/>
<text x="-7.62" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="3.175" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-4.318" size="1.524" layer="95">GND</text>
<pin name="VI" x="-10.16" y="0" length="short" direction="in"/>
<pin name="GND" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="VO" x="10.16" y="0" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="78*" prefix="IC">
<description>Positive &lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;&lt;p&gt;
Source:&lt;br&gt;
http://cache.national.com/ds/LM/LM78L05.pdf&lt;br&gt;
http://www.fairchildsemi.com/ds/LM/LM7805.pdf</description>
<gates>
<gate name="A1" symbol="78XX" x="0" y="0"/>
</gates>
<devices>
<device name="Z" package="TO92">
<connects>
<connect gate="A1" pin="GND" pad="2"/>
<connect gate="A1" pin="VI" pad="3"/>
<connect gate="A1" pin="VO" pad="1"/>
</connects>
<technologies>
<technology name="L05"/>
<technology name="L08"/>
<technology name="L12"/>
<technology name="L15"/>
<technology name="L18"/>
<technology name="L24"/>
</technologies>
</device>
<device name="T" package="TO220H">
<connects>
<connect gate="A1" pin="VI" pad="1"/>
<connect gate="A1" pin="VO" pad="3"/>
</connects>
<technologies>
<technology name="05"/>
<technology name="06"/>
<technology name="08"/>
<technology name="12"/>
<technology name="15"/>
<technology name="18"/>
<technology name="24"/>
</technologies>
</device>
<device name="H" package="TO39">
<connects>
<connect gate="A1" pin="GND" pad="3"/>
<connect gate="A1" pin="VO" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="L" package="TO92">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DT" package="TO252">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TV" package="TO220V">
<connects>
</connects>
<technologies>
<technology name="6"/>
<technology name="8"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="switch">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, Siemens, C&amp;K, ITT, and others&lt;p&gt;
<packages>
<package name="255SB">
<description>&lt;b&gt;SLIDING SWITCH&lt;/b&gt;&lt;p&gt;
distributor Buerklin, 11G810</description>
<wire x1="-5.588" y1="3.048" x2="5.588" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.588" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.048" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.397" x2="3.81" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.81" y1="1.397" x2="-3.81" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.762" x2="-1.27" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.81" y1="-1.524" x2="-0.762" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.524" x2="-1.778" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.524" x2="-1.778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.016" x2="-2.794" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.81" y1="1.524" x2="-3.302" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.524" x2="3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.524" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.27" x2="-0.762" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.524" x2="-1.27" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.524" x2="-1.27" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.524" x2="-1.778" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.016" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.524" x2="-3.302" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.302" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.524" x2="-3.81" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.397" x2="-3.81" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.524" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.524" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.524" x2="-2.794" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.524" x2="-2.794" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.524" x2="-2.286" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.524" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.524" x2="-0.762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.524" x2="-0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.524" x2="3.81" y2="1.524" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="3.81" y="0" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.207" y="-2.794" size="1.27" layer="21" ratio="10">1</text>
<text x="4.191" y="-2.794" size="1.27" layer="21" ratio="10">2</text>
<text x="-5.588" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="SIS">
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-1.905" y2="0" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-0.762" y2="0" width="0.1524" layer="94"/>
<wire x1="0.254" y1="0" x2="0.635" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-3.175" x2="2.54" y2="-1.905" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.905" x2="0.635" y2="3.175" width="0.254" layer="94"/>
<wire x1="3.81" y1="2.54" x2="5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="3.175" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="3.175" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.905" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.762" y1="0" x2="-0.254" y2="-0.762" width="0.1524" layer="94"/>
<wire x1="-0.254" y1="-0.762" x2="0.254" y2="0" width="0.1524" layer="94"/>
<text x="-6.35" y="-1.905" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-3.81" y="3.175" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="P" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="S" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="O" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="255SB" prefix="S" uservalue="yes">
Distributor Buerklin, 11G810</description>
<gates>
<gate name="1" symbol="SIS" x="0" y="0"/>
</gates>
<devices>
<device name="" package="255SB">
<connects>
<connect gate="1" pin="O" pad="1"/>
<connect gate="1" pin="P" pad="2"/>
<connect gate="1" pin="S" pad="3"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="jumper">
<description>&lt;b&gt;Jumpers&lt;/b&gt;&lt;p&gt;
<packages>
<package name="JP1">
<description>&lt;b&gt;JUMPER&lt;/b&gt;</description>
<wire x1="-1.016" y1="0" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.54" x2="1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.286" x2="1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.286" x2="-1.27" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="-1.27" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-1.27" drill="0.9144" shape="long"/>
<pad name="2" x="0" y="1.27" drill="0.9144" shape="long"/>
<text x="-1.651" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.921" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="0.9652" x2="0.3048" y2="1.5748" layer="51"/>
<rectangle x1="-0.3048" y1="-1.5748" x2="0.3048" y2="-0.9652" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="JP2E">
<wire x1="0" y1="0" x2="0" y2="1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.27" width="0.4064" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="1.27" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="0" x2="3.175" y2="0" width="0.4064" layer="94"/>
<wire x1="3.175" y1="0" x2="3.175" y2="0.635" width="0.4064" layer="94"/>
<wire x1="3.175" y1="0.635" x2="-0.635" y2="0.635" width="0.4064" layer="94"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.4064" layer="94"/>
<text x="-1.27" y="0" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.715" y="0" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="1" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="2" x="2.54" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="JP1E" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="JP2E" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="JP1">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="MSGEQ7" library="SparkFun-AnalogIC" deviceset="MSGEQ7" device="DIL"/>
<part name="U$1" library="Arduino-clone" deviceset="NANO" device=""/>
<part name="Q1" library="transistor-fet" deviceset="BUZ11" device=""/>
<part name="Q2" library="transistor-fet" deviceset="BUZ11" device=""/>
<part name="Q3" library="transistor-fet" deviceset="BUZ11" device=""/>
<part name="R4" library="resistor" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R5" library="resistor" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R6" library="resistor" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="GND1" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="GND2" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="GND3" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="SUPPLY1" library="SparkFun-Aesthetics" deviceset="VDD" device="" value="5V"/>
<part name="SUPPLY2" library="SparkFun-Aesthetics" deviceset="VDD" device=""/>
<part name="C4" library="capacitor-wima" deviceset="C" device="5/2.5" value="0.1uF"/>
<part name="C5" library="capacitor-wima" deviceset="C" device="5/2.5" value="33pF"/>
<part name="C3" library="capacitor-wima" deviceset="C" device="5/2.5" value="0.1uF"/>
<part name="R1" library="resistor" deviceset="R-EU_" device="0207/10" value="22k"/>
<part name="R2" library="resistor" deviceset="R-EU_" device="0207/10" value="200k"/>
<part name="R3" library="resistor" deviceset="R-EU_" device="0207/10" value="22k"/>
<part name="GND4" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="GND5" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="C2" library="capacitor-wima" deviceset="C" device="5/2.5" value="0.1uF"/>
<part name="X1" library="con-lumberg" deviceset="1503_09" device=""/>
<part name="POWER" library="con-ptr500" deviceset="AK500/2-H" device=""/>
<part name="GND7" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="IC1" library="linear" deviceset="78*" device="T" technology="05"/>
<part name="SUPPLY3" library="SparkFun-Aesthetics" deviceset="VDD" device=""/>
<part name="X3" library="con-ptr500" deviceset="AK500/4-H" device=""/>
<part name="UV_LED" library="con-ptr500" deviceset="AK500/2-H" device=""/>
<part name="GND6" library="SparkFun-Aesthetics" deviceset="GND" device=""/>
<part name="S1" library="switch" deviceset="255SB" device=""/>
<part name="JP1" library="jumper" deviceset="JP1E" device=""/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="MSGEQ7" gate="G$1" x="45.72" y="53.34"/>
<instance part="U$1" gate="G$1" x="142.24" y="60.96"/>
<instance part="Q1" gate="G$1" x="43.18" y="160.02"/>
<instance part="Q2" gate="G$1" x="78.74" y="160.02"/>
<instance part="Q3" gate="G$1" x="111.76" y="160.02"/>
<instance part="R4" gate="G$1" x="35.56" y="149.86" rot="R90"/>
<instance part="R5" gate="G$1" x="71.12" y="149.86" rot="R90"/>
<instance part="R6" gate="G$1" x="104.14" y="149.86" rot="R90"/>
<instance part="GND1" gate="1" x="109.22" y="137.16"/>
<instance part="GND2" gate="1" x="76.2" y="137.16"/>
<instance part="GND3" gate="1" x="43.18" y="142.24"/>
<instance part="SUPPLY1" gate="VDD" x="25.4" y="63.5"/>
<instance part="SUPPLY2" gate="VDD" x="104.14" y="60.96"/>
<instance part="C4" gate="G$1" x="71.12" y="45.72"/>
<instance part="C5" gate="G$1" x="88.9" y="48.26"/>
<instance part="C3" gate="G$1" x="104.14" y="48.26"/>
<instance part="R1" gate="G$1" x="17.78" y="91.44" rot="R180"/>
<instance part="R2" gate="G$1" x="96.52" y="55.88" rot="R180"/>
<instance part="R3" gate="G$1" x="17.78" y="99.06" rot="R180"/>
<instance part="GND4" gate="1" x="88.9" y="35.56"/>
<instance part="GND5" gate="1" x="27.94" y="81.28"/>
<instance part="C2" gate="G$1" x="0" y="81.28"/>
<instance part="X1" gate="G$1" x="33.02" y="93.98"/>
<instance part="POWER" gate="-1" x="152.4" y="119.38" rot="R180"/>
<instance part="POWER" gate="-2" x="152.4" y="124.46" rot="R180"/>
<instance part="GND7" gate="1" x="139.7" y="129.54" rot="R180"/>
<instance part="IC1" gate="A1" x="91.44" y="106.68" rot="R90"/>
<instance part="SUPPLY3" gate="VDD" x="91.44" y="119.38"/>
<instance part="X3" gate="-1" x="152.4" y="91.44" rot="R180"/>
<instance part="X3" gate="-2" x="152.4" y="96.52" rot="R180"/>
<instance part="X3" gate="-3" x="152.4" y="101.6" rot="R180"/>
<instance part="X3" gate="-4" x="152.4" y="106.68" rot="R180"/>
<instance part="UV_LED" gate="-1" x="149.86" y="160.02" rot="R180"/>
<instance part="UV_LED" gate="-2" x="149.86" y="165.1" rot="R180"/>
<instance part="GND6" gate="1" x="137.16" y="170.18" rot="R180"/>
<instance part="S1" gate="1" x="132.08" y="149.86"/>
<instance part="JP1" gate="A" x="0" y="116.84"/>
</instances>
<busses>
</busses>
<nets>
<net name="S1" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="G"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="38.1" y1="157.48" x2="35.56" y2="157.48" width="0.1524" layer="91"/>
<wire x1="35.56" y1="157.48" x2="35.56" y2="154.94" width="0.1524" layer="91"/>
<wire x1="35.56" y1="157.48" x2="30.48" y2="157.48" width="0.1524" layer="91"/>
<junction x="35.56" y="157.48"/>
<label x="27.94" y="154.94" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="D9"/>
<wire x1="152.4" y1="68.58" x2="157.48" y2="68.58" width="0.1524" layer="91"/>
<label x="160.02" y="68.58" size="1.778" layer="95"/>
</segment>
</net>
<net name="S2" class="0">
<segment>
<pinref part="Q2" gate="G$1" pin="G"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="73.66" y1="157.48" x2="71.12" y2="157.48" width="0.1524" layer="91"/>
<wire x1="71.12" y1="157.48" x2="71.12" y2="154.94" width="0.1524" layer="91"/>
<wire x1="71.12" y1="157.48" x2="66.04" y2="157.48" width="0.1524" layer="91"/>
<junction x="71.12" y="157.48"/>
<label x="63.5" y="154.94" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="D10"/>
<wire x1="152.4" y1="71.12" x2="157.48" y2="71.12" width="0.1524" layer="91"/>
<label x="160.02" y="71.12" size="1.778" layer="95"/>
</segment>
</net>
<net name="S3" class="0">
<segment>
<pinref part="Q3" gate="G$1" pin="G"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="106.68" y1="157.48" x2="104.14" y2="157.48" width="0.1524" layer="91"/>
<wire x1="104.14" y1="157.48" x2="104.14" y2="154.94" width="0.1524" layer="91"/>
<wire x1="104.14" y1="157.48" x2="99.06" y2="157.48" width="0.1524" layer="91"/>
<junction x="104.14" y="157.48"/>
<label x="96.52" y="154.94" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="D11"/>
<wire x1="152.4" y1="73.66" x2="157.48" y2="73.66" width="0.1524" layer="91"/>
<label x="160.02" y="73.66" size="1.778" layer="95"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="Q3" gate="G$1" pin="S"/>
<wire x1="116.84" y1="157.48" x2="116.84" y2="144.78" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="1"/>
<wire x1="116.84" y1="144.78" x2="109.22" y2="144.78" width="0.1524" layer="91"/>
<wire x1="109.22" y1="144.78" x2="104.14" y2="144.78" width="0.1524" layer="91"/>
<wire x1="109.22" y1="144.78" x2="109.22" y2="139.7" width="0.1524" layer="91"/>
<junction x="109.22" y="144.78"/>
<pinref part="GND1" gate="1" pin="GND"/>
</segment>
<segment>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="35.56" y1="144.78" x2="43.18" y2="144.78" width="0.1524" layer="91"/>
<pinref part="Q1" gate="G$1" pin="S"/>
<wire x1="43.18" y1="144.78" x2="48.26" y2="144.78" width="0.1524" layer="91"/>
<wire x1="48.26" y1="144.78" x2="48.26" y2="157.48" width="0.1524" layer="91"/>
<pinref part="GND3" gate="1" pin="GND"/>
<junction x="43.18" y="144.78"/>
</segment>
<segment>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="71.12" y1="40.64" x2="71.12" y2="38.1" width="0.1524" layer="91"/>
<wire x1="71.12" y1="38.1" x2="81.28" y2="38.1" width="0.1524" layer="91"/>
<pinref part="MSGEQ7" gate="G$1" pin="CG"/>
<wire x1="60.96" y1="53.34" x2="81.28" y2="53.34" width="0.1524" layer="91"/>
<wire x1="81.28" y1="53.34" x2="81.28" y2="38.1" width="0.1524" layer="91"/>
<wire x1="81.28" y1="38.1" x2="88.9" y2="38.1" width="0.1524" layer="91"/>
<junction x="81.28" y="38.1"/>
<pinref part="C5" gate="G$1" pin="2"/>
<wire x1="88.9" y1="38.1" x2="88.9" y2="43.18" width="0.1524" layer="91"/>
<wire x1="104.14" y1="38.1" x2="88.9" y2="38.1" width="0.1524" layer="91"/>
<junction x="88.9" y="38.1"/>
<pinref part="GND4" gate="1" pin="GND"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="104.14" y1="43.18" x2="104.14" y2="38.1" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="Q2" gate="G$1" pin="S"/>
<wire x1="71.12" y1="144.78" x2="76.2" y2="144.78" width="0.1524" layer="91"/>
<wire x1="76.2" y1="144.78" x2="83.82" y2="144.78" width="0.1524" layer="91"/>
<wire x1="83.82" y1="144.78" x2="83.82" y2="157.48" width="0.1524" layer="91"/>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="76.2" y1="144.78" x2="76.2" y2="139.7" width="0.1524" layer="91"/>
<junction x="76.2" y="144.78"/>
</segment>
<segment>
<pinref part="X1" gate="G$1" pin="1"/>
<pinref part="GND5" gate="1" pin="GND"/>
<wire x1="27.94" y1="88.9" x2="27.94" y2="83.82" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="POWER" gate="-2" pin="KL"/>
<wire x1="147.32" y1="124.46" x2="139.7" y2="124.46" width="0.1524" layer="91"/>
<pinref part="GND7" gate="1" pin="GND"/>
<wire x1="139.7" y1="124.46" x2="139.7" y2="127" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC1" gate="A1" pin="GND"/>
<wire x1="99.06" y1="106.68" x2="101.6" y2="106.68" width="0.1524" layer="91"/>
<label x="104.14" y="106.68" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="GND"/>
<wire x1="119.38" y1="43.18" x2="116.84" y2="43.18" width="0.1524" layer="91"/>
<label x="114.3" y="43.18" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="UV_LED" gate="-2" pin="KL"/>
<wire x1="144.78" y1="165.1" x2="137.16" y2="165.1" width="0.1524" layer="91"/>
<pinref part="GND6" gate="1" pin="GND"/>
<wire x1="137.16" y1="165.1" x2="137.16" y2="167.64" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="JP1" gate="A" pin="2"/>
<wire x1="2.54" y1="114.3" x2="2.54" y2="111.76" width="0.1524" layer="91"/>
<wire x1="2.54" y1="111.76" x2="5.08" y2="111.76" width="0.1524" layer="91"/>
<label x="7.62" y="111.76" size="1.778" layer="95"/>
</segment>
</net>
<net name="OUT1" class="0">
<segment>
<pinref part="Q1" gate="G$1" pin="D"/>
<wire x1="48.26" y1="162.56" x2="48.26" y2="172.72" width="0.1524" layer="91"/>
<label x="48.26" y="172.72" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="X3" gate="-3" pin="KL"/>
<wire x1="147.32" y1="101.6" x2="142.24" y2="101.6" width="0.1524" layer="91"/>
<label x="137.16" y="101.6" size="1.778" layer="95"/>
</segment>
</net>
<net name="OUT3" class="0">
<segment>
<pinref part="Q3" gate="G$1" pin="D"/>
<wire x1="116.84" y1="162.56" x2="116.84" y2="172.72" width="0.1524" layer="91"/>
<label x="116.84" y="172.72" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="X3" gate="-4" pin="KL"/>
<wire x1="147.32" y1="106.68" x2="142.24" y2="106.68" width="0.1524" layer="91"/>
<label x="137.16" y="106.68" size="1.778" layer="95"/>
</segment>
</net>
<net name="OUT2" class="0">
<segment>
<pinref part="Q2" gate="G$1" pin="D"/>
<wire x1="83.82" y1="162.56" x2="83.82" y2="172.72" width="0.1524" layer="91"/>
<label x="83.82" y="172.72" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="X3" gate="-2" pin="KL"/>
<wire x1="147.32" y1="96.52" x2="142.24" y2="96.52" width="0.1524" layer="91"/>
<label x="137.16" y="96.52" size="1.778" layer="95"/>
</segment>
</net>
<net name="VDD" class="0">
<segment>
<pinref part="SUPPLY1" gate="VDD" pin="VDD"/>
<wire x1="25.4" y1="63.5" x2="25.4" y2="58.42" width="0.1524" layer="91"/>
<pinref part="MSGEQ7" gate="G$1" pin="VDD"/>
<wire x1="25.4" y1="58.42" x2="27.94" y2="58.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="5.5V"/>
<wire x1="119.38" y1="48.26" x2="116.84" y2="48.26" width="0.1524" layer="91"/>
<label x="114.3" y="48.26" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="101.6" y1="55.88" x2="104.14" y2="55.88" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="104.14" y1="55.88" x2="104.14" y2="50.8" width="0.1524" layer="91"/>
<pinref part="SUPPLY2" gate="VDD" pin="VDD"/>
<wire x1="104.14" y1="55.88" x2="104.14" y2="60.96" width="0.1524" layer="91"/>
<junction x="104.14" y="55.88"/>
</segment>
<segment>
<pinref part="SUPPLY3" gate="VDD" pin="VDD"/>
<pinref part="IC1" gate="A1" pin="VO"/>
<wire x1="91.44" y1="119.38" x2="91.44" y2="116.84" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="GND"/>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="60.96" y1="50.8" x2="71.12" y2="50.8" width="0.1524" layer="91"/>
<wire x1="71.12" y1="50.8" x2="71.12" y2="48.26" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="CKIN"/>
<wire x1="60.96" y1="55.88" x2="88.9" y2="55.88" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<pinref part="C5" gate="G$1" pin="1"/>
<wire x1="88.9" y1="55.88" x2="91.44" y2="55.88" width="0.1524" layer="91"/>
<wire x1="88.9" y1="55.88" x2="88.9" y2="50.8" width="0.1524" layer="91"/>
<junction x="88.9" y="55.88"/>
</segment>
</net>
<net name="OUT" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="DCOUT"/>
<wire x1="60.96" y1="58.42" x2="60.96" y2="63.5" width="0.1524" layer="91"/>
<label x="60.96" y="63.5" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="A0"/>
<wire x1="119.38" y1="68.58" x2="116.84" y2="68.58" width="0.1524" layer="91"/>
<label x="111.76" y="68.58" size="1.778" layer="95"/>
</segment>
</net>
<net name="STROBE" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="STROBE"/>
<wire x1="27.94" y1="53.34" x2="20.32" y2="53.34" width="0.1524" layer="91"/>
<label x="17.78" y="53.34" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="D7"/>
<wire x1="152.4" y1="63.5" x2="157.48" y2="63.5" width="0.1524" layer="91"/>
<label x="160.02" y="63.5" size="1.778" layer="95"/>
</segment>
</net>
<net name="RESET" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="RESET"/>
<wire x1="27.94" y1="50.8" x2="27.94" y2="45.72" width="0.1524" layer="91"/>
<label x="27.94" y="43.18" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="U$1" gate="G$1" pin="D8"/>
<wire x1="152.4" y1="66.04" x2="157.48" y2="66.04" width="0.1524" layer="91"/>
<label x="160.02" y="66.04" size="1.778" layer="95"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<pinref part="MSGEQ7" gate="G$1" pin="AUDIO_IN"/>
<wire x1="0" y1="55.88" x2="27.94" y2="55.88" width="0.1524" layer="91"/>
<pinref part="C2" gate="G$1" pin="2"/>
<wire x1="0" y1="55.88" x2="0" y2="76.2" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="R3" gate="G$1" pin="1"/>
<pinref part="X1" gate="G$1" pin="3"/>
<wire x1="22.86" y1="99.06" x2="27.94" y2="99.06" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="X1" gate="G$1" pin="2"/>
<wire x1="22.86" y1="91.44" x2="27.94" y2="91.44" width="0.1524" layer="91"/>
</segment>
</net>
<net name="SIG" class="0">
<segment>
<pinref part="JP1" gate="A" pin="1"/>
<wire x1="0" y1="83.82" x2="0" y2="91.44" width="0.1524" layer="91"/>
<label x="-7.62" y="114.3" size="1.778" layer="95"/>
<pinref part="C2" gate="G$1" pin="1"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="0" y1="91.44" x2="0" y2="99.06" width="0.1524" layer="91"/>
<wire x1="0" y1="99.06" x2="0" y2="114.3" width="0.1524" layer="91"/>
<wire x1="12.7" y1="99.06" x2="0" y2="99.06" width="0.1524" layer="91"/>
<junction x="0" y="99.06"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="12.7" y1="91.44" x2="0" y2="91.44" width="0.1524" layer="91"/>
<junction x="0" y="91.44"/>
</segment>
</net>
<net name="12V" class="0">
<segment>
<pinref part="POWER" gate="-1" pin="KL"/>
<wire x1="147.32" y1="119.38" x2="142.24" y2="119.38" width="0.1524" layer="91"/>
<wire x1="139.7" y1="119.38" x2="139.7" y2="114.3" width="0.1524" layer="91"/>
<wire x1="139.7" y1="119.38" x2="142.24" y2="119.38" width="0.1524" layer="91"/>
<label x="134.62" y="111.76" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="IC1" gate="A1" pin="VI"/>
<wire x1="91.44" y1="96.52" x2="91.44" y2="93.98" width="0.1524" layer="91"/>
<label x="91.44" y="91.44" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="S1" gate="1" pin="P"/>
<wire x1="134.62" y1="144.78" x2="134.62" y2="139.7" width="0.1524" layer="91"/>
<label x="127" y="137.16" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="X3" gate="-1" pin="KL"/>
<junction x="147.32" y="91.44"/>
<wire x1="147.32" y1="91.44" x2="142.24" y2="91.44" width="0.1524" layer="91"/>
<label x="137.16" y="91.44" size="1.778" layer="95"/>
</segment>
<segment>
<pinref part="S1" gate="1" pin="S"/>
<wire x1="137.16" y1="154.94" x2="137.16" y2="160.02" width="0.1524" layer="91"/>
<pinref part="UV_LED" gate="-1" pin="KL"/>
<wire x1="137.16" y1="160.02" x2="144.78" y2="160.02" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
<errors>
<approved hash="113,1,154.046,119.38,POWER,,,,,"/>
<approved hash="113,1,151.225,91.44,X3,,,,,"/>
<approved hash="113,1,151.751,160.02,UV_LED,,,,,"/>
<approved hash="113,1,131.199,149.86,S1,,,,,"/>
<approved hash="113,1,0.389466,115.635,JP1,,,,,"/>
</errors>
</schematic>
</drawing>
</eagle>
