<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.1.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.127" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.0635" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tPadExt" color="7" fill="6" visible="no" active="no"/>
<layer number="54" name="bPadExt" color="1" fill="3" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
<layer number="200" name="200bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="Eagle3D_PG1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="232" name="Eagle3D_PG2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="233" name="Eagle3D_PG3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<board>
<plain>
<wire x1="-32.131" y1="-22.225" x2="32.131" y2="-22.225" width="0" layer="20"/>
<wire x1="32.131" y1="-22.225" x2="32.131" y2="158.369" width="0" layer="20"/>
<wire x1="32.131" y1="158.369" x2="-32.131" y2="158.369" width="0" layer="20"/>
<wire x1="-32.131" y1="158.369" x2="-32.131" y2="-22.225" width="0" layer="20"/>
<hole x="29" y="-19" drill="3.2"/>
<hole x="-29" y="-19" drill="3.2"/>
<hole x="-29" y="155" drill="3.2"/>
<hole x="-29" y="68" drill="3.2"/>
<hole x="29" y="155" drill="3.2"/>
<hole x="29" y="68" drill="3.2"/>
<text x="0.889" y="59.055" size="1.778" layer="20" rot="R90">ACTIDAMP</text>
<text x="0.889" y="75.565" size="1.778" layer="20" rot="R90">Mk-IV</text>
<text x="0.889" y="86.233" size="1.778" layer="25" rot="R90">by PAVEL DUDEK</text>
<text x="3.429" y="139.954" size="1.778" layer="25" rot="R90">CSABY</text>
<text x="-1.651" y="139.446" size="1.778" layer="25" rot="R90">designed:</text>
</plain>
<libraries>
<library name="wirepad">
<description>&lt;b&gt;Single Pads&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="3,17/1,3">
<description>&lt;b&gt;THROUGH-HOLE PAD&lt;/b&gt;</description>
<wire x1="1.524" y1="-1.016" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.524" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="-1.524" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.524" x2="1.524" y2="1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.524" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0" drill="1.3208" diameter="3.175" shape="octagon"/>
<text x="-1.524" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="1.2" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C025_050-025X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6E">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-6">
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0204/7">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" diameter="1.524" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" diameter="1.524" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="RTRIM64W">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
Cermet MIL-R-22097</description>
<wire x1="2.52" y1="-4.8" x2="-2.03" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="-4.8" x2="-2.03" y2="4.8" width="0.254" layer="21"/>
<wire x1="-2.03" y1="4.8" x2="2.52" y2="4.8" width="0.254" layer="21"/>
<wire x1="2.52" y1="4.8" x2="2.52" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="3.2" x2="2.27" y2="3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="3.2" x2="2.27" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.27" y1="-3.2" x2="2.52" y2="-3.2" width="0.254" layer="21"/>
<wire x1="2.52" y1="-3.2" x2="2.52" y2="-4.8" width="0.254" layer="21"/>
<circle x="-0.58" y="3.3" radius="1.1" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="-2.54" drill="0.6096"/>
<pad name="2" x="1.27" y="0" drill="0.6096"/>
<pad name="3" x="1.27" y="2.54" drill="0.6096"/>
<text x="-2.62" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="4.35" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.78" y1="2.25" x2="-0.38" y2="4.35" layer="21"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="SPAK">
<description>&lt;b&gt;SPAK&lt;/b&gt;&lt;p&gt;
Source: HITACHI .. 2SK439.pdf</description>
<wire x1="-1.7" y1="1.35" x2="1.675" y2="1.35" width="0.2032" layer="21"/>
<wire x1="2" y1="0.25" x2="2" y2="0" width="0.2032" layer="21"/>
<wire x1="2" y1="0" x2="1.775" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="1.775" y1="-0.6" x2="-1.75" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-0.6" x2="-2" y2="0" width="0.2032" layer="21"/>
<wire x1="-2" y1="0" x2="-2" y2="0.25" width="0.2032" layer="21"/>
<wire x1="-1.7" y1="1.35" x2="-2" y2="0.25" width="0.2032" layer="21"/>
<wire x1="1.675" y1="1.35" x2="2" y2="0.25" width="0.2032" layer="21"/>
<pad name="1" x="0" y="1.27" drill="0.7" diameter="1"/>
<pad name="2" x="1.27" y="0" drill="0.7" diameter="1"/>
<pad name="3" x="-1.27" y="0" drill="0.7" diameter="1"/>
<text x="-1.905" y="-2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch-dil">
<description>&lt;b&gt;DIL Switches and Code Switches&lt;/b&gt;&lt;p&gt;
<packages>
<package name="DIP04YL">
<description>&lt;b&gt;DIL/CODE SWITCH&lt;/b&gt;&lt;p&gt;</description>
<wire x1="6.35" y1="-3.81" x2="6.35" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-6.35" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-3.175" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.175" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-4.445" y2="1.27" width="0.254" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.905" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.905" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="1.905" y1="1.27" x2="0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.9398" x2="-3.175" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.9398" x2="-4.445" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-0.9398" x2="-3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.9398" x2="-0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.9398" x2="-1.905" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.9398" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-0.635" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.9398" x2="1.905" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.9398" x2="0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="1.905" y1="-0.9398" x2="1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="1.905" y2="-0.635" width="0.254" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.635" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="1.905" y1="-0.635" x2="1.905" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="4.445" y2="-1.27" width="0.254" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="4.445" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="4.445" y1="1.27" x2="3.175" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="3.175" y1="-0.9398" x2="4.445" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="3.175" y1="-0.9398" x2="3.175" y2="-1.27" width="0.254" layer="21"/>
<wire x1="4.445" y1="-0.9398" x2="4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="3.175" y1="-0.635" x2="4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="3.175" y1="-0.635" x2="3.175" y2="-0.9398" width="0.254" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.445" y2="1.27" width="0.254" layer="21"/>
<wire x1="6.35" y1="-3.81" x2="4.572" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.81" x2="-4.572" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-4.572" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.35" y1="3.81" x2="4.572" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-3.81" x2="-3.048" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-3.81" x2="-2.032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.81" x2="-0.508" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.81" x2="0.508" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-3.81" x2="2.032" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-3.81" x2="3.048" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.81" x2="4.572" y2="-3.81" width="0.1524" layer="51"/>
<wire x1="4.572" y1="3.81" x2="3.048" y2="3.81" width="0.1524" layer="51"/>
<wire x1="3.048" y1="3.81" x2="2.032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.81" x2="0.508" y2="3.81" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-2.032" y2="3.81" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="3.81" x2="-3.048" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.81" x2="-4.572" y2="3.81" width="0.1524" layer="51"/>
<circle x="-5.334" y="-2.794" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.191" y="-3.048" size="1.27" layer="51" ratio="10">1</text>
<text x="-1.651" y="-3.048" size="1.27" layer="51" ratio="10">2</text>
<text x="0.889" y="-3.048" size="1.27" layer="51" ratio="10">3</text>
<text x="3.429" y="-3.048" size="1.27" layer="51" ratio="10">4</text>
<text x="-6.6802" y="-3.7592" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.0452" y="-3.1496" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-4.191" y="1.7018" size="1.27" layer="51" ratio="10">ON</text>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
 grid 5.08 mm</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-pnp">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<wire x1="-2.413" y1="-0.1341" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="50.4167"/>
<wire x1="2.413" y1="-2.4059" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="50.4167"/>
</package>
</packages>
</library>
<library name="v-reg-3">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;/p&gt;
&lt;p&gt;&lt;date&gt;2008-05-16&lt;/date&gt;, updates by &lt;author&gt;Eike Schmidt&lt;/author&gt;&lt;/p&gt;&lt;ul&gt;&lt;li&gt;integrated library "ltc_swr.lbr" with switching regulators from &lt;a href=http://www.linear.com&gt;Linear Technology&lt;/a&gt;, created by &lt;author&gt;Claudius Stern&lt;/author&gt;&lt;/li&gt;&lt;li&gt;added step-down switching regulator LT1767&lt;/li&gt;&lt;li&gt;combined identical symbols for positive regulators&lt;/li&gt;&lt;li&gt;added packages SO8 and SOT89 for 78Lxx and 79Lxx&lt;/li&gt;&lt;li&gt;added package SO8 for LM317L and LM337L&lt;/li&gt;&lt;li&gt;added linear regulators L4931, L4949E, LM2931&lt;/li&gt;&lt;li&gt;added micropower, ultra-low dropout family LP298x&lt;/li&gt;&lt;li&gt;added ultra-low dropout regulators IRU1205, TK112, TK113&lt;/li&gt;&lt;li&gt;added low power, low dropout regulator family S-812&lt;/li&gt;&lt;li&gt;added NPN "Simple Switcher"(c) family LM257x&lt;/li&gt;&lt;li&gt;added DMOS "Simple Switcher"(c) family LM267x&lt;/li&gt;&lt;li&gt;added NPN Darlington switching regulator MC34063A&lt;/li&gt;&lt;li&gt;added LED boost drivers PR4401, PR4402, PR4403&lt;/li&gt;&lt;/ul&gt;</description>
<packages>
<package name="317TS">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="5.08" y2="-4.064" width="0.1778" layer="21"/>
<wire x1="4.826" y1="-4.318" x2="5.08" y2="-4.064" width="0.1778" layer="21"/>
<wire x1="4.826" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1778" layer="21"/>
<wire x1="-5.08" y1="-4.064" x2="-4.826" y2="-4.318" width="0.1778" layer="21"/>
<wire x1="-5.08" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1778" layer="21"/>
<circle x="-4.6228" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="-3.81" size="1.27" layer="51" ratio="10">O</text>
<text x="1.905" y="-3.81" size="1.27" layer="51" ratio="10">I</text>
<text x="-3.175" y="-3.81" size="1.27" layer="51" ratio="10">A</text>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="0" layer="21"/>
<rectangle x1="-3.429" y1="-0.762" x2="-1.651" y2="0" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="-0.889" y1="-0.762" x2="0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="0" layer="21"/>
<rectangle x1="1.651" y1="-0.762" x2="3.429" y2="0" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
<package name="337TS">
<text x="-5.08" y="-5.9182" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-3.81" size="1.27" layer="51" ratio="10">O</text>
<text x="-0.635" y="-3.81" size="1.27" layer="51" ratio="10">I</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO34-7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="a"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="a"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="+21,5V" library="wirepad" package="3,17/1,3" value="" x="-7.62" y="-18.288" smashed="yes">
<attribute name="NAME" x="-10.668" y="-21.717" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-7.62" y="-17.088" size="0.0254" layer="27"/>
</element>
<element name="-21,5V" library="wirepad" package="3,17/1,3" value="" x="7.62" y="-18.288" smashed="yes">
<attribute name="NAME" x="5.207" y="-21.59" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="7.62" y="-17.088" size="0.0254" layer="27"/>
</element>
<element name="C1" library="rcl" package="C025_050-025X075" value="100p" x="11.811" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="10.287" y="152.527" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="14.605" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C10" library="rcl" package="C025_050-025X075" value="100p" x="7.112" y="105.537" smashed="yes" rot="R270">
<attribute name="NAME" x="8.636" y="106.934" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="4.318" y="108.966" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C11" library="rcl" package="C050-025X075" value="10p" x="19.304" y="68.072" smashed="yes">
<attribute name="NAME" x="24.384" y="66.929" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="15.875" y="65.278" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C12" library="rcl" package="C050-025X075" value="1u" x="7.112" y="85.217" smashed="yes">
<attribute name="NAME" x="5.842" y="86.741" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="3.683" y="82.423" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C13" library="rcl" package="C050-025X075" value="580n" x="11.43" y="94.488" smashed="yes" rot="R90">
<attribute name="NAME" x="9.906" y="93.472" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="14.224" y="91.059" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C14" library="rcl" package="C025_050-025X075" value="680n" x="11.557" y="105.537" smashed="yes" rot="R270">
<attribute name="NAME" x="14.097" y="104.267" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="8.763" y="108.966" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C15A" library="rcl" package="C025_050-025X075" value="" x="4.699" y="76.2" smashed="yes">
<attribute name="NAME" x="3.302" y="77.724" size="0.8128" layer="25" ratio="10"/>
<attribute name="VALUE" x="1.27" y="73.406" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C215A" library="rcl" package="C025_050-025X075" value="" x="-4.699" y="76.2" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.794" y="78.486" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="78.994" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C15B" library="rcl" package="C025_050-025X075" value="" x="4.699" y="72.136" smashed="yes">
<attribute name="NAME" x="3.175" y="73.66" size="0.8128" layer="25" ratio="10"/>
<attribute name="VALUE" x="1.27" y="69.342" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C215B" library="rcl" package="C025_050-025X075" value="" x="-4.699" y="72.136" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.921" y="74.422" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="74.93" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C15C" library="rcl" package="C025_050-025X075" value="" x="4.699" y="68.072" smashed="yes">
<attribute name="NAME" x="3.175" y="69.596" size="0.8128" layer="25" ratio="10"/>
<attribute name="VALUE" x="1.27" y="65.278" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C215C" library="rcl" package="C025_050-025X075" value="" x="-4.699" y="68.072" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.794" y="70.358" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="70.866" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C16" library="rcl" package="C050-025X075" value="3n3" x="6.223" y="61.468" smashed="yes" rot="R90">
<attribute name="NAME" x="7.62" y="62.865" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="9.017" y="58.039" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C221" library="rcl" package="C025_050-025X075" value="100n" x="-27.305" y="135.89" smashed="yes">
<attribute name="NAME" x="-28.067" y="137.414" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="-30.734" y="133.096" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C17A" library="rcl" package="C025_050-025X075" value="10n" x="4.699" y="44.323" smashed="yes">
<attribute name="NAME" x="6.35" y="46.609" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="1.27" y="41.529" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C217A" library="rcl" package="C025_050-025X075" value="10n" x="-4.699" y="44.323" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.667" y="46.609" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="47.117" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C17B" library="rcl" package="C025_050-025X075" value="10n" x="4.699" y="48.387" smashed="yes">
<attribute name="NAME" x="6.35" y="50.673" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="1.27" y="45.593" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C217B" library="rcl" package="C025_050-025X075" value="10n" x="-4.699" y="48.387" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.667" y="50.673" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="51.181" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C17C" library="rcl" package="C025_050-025X075" value="10n" x="4.699" y="52.451" smashed="yes">
<attribute name="NAME" x="3.937" y="54.737" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="1.27" y="49.657" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C217C" library="rcl" package="C025_050-025X075" value="10n" x="-4.699" y="52.451" smashed="yes" rot="R180">
<attribute name="NAME" x="-2.667" y="54.737" size="0.8128" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-1.27" y="55.245" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C18" library="rcl" package="C050-025X075" value="10p" x="16.51" y="41.529" smashed="yes" rot="R180">
<attribute name="NAME" x="20.32" y="41.148" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="19.939" y="44.323" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C19" library="rcl" package="C050-025X075" value="680n" x="5.969" y="40.259" smashed="yes" rot="R180">
<attribute name="NAME" x="7.112" y="42.799" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="9.398" y="43.053" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C2" library="rcl" package="C025_050-025X075" value="220p" x="15.113" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="14.224" y="156.337" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="17.907" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C20" library="rcl" package="C050-025X075" value="680n" x="27.305" y="28.575" smashed="yes" rot="R90">
<attribute name="NAME" x="27.813" y="32.512" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="30.099" y="25.146" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C224" library="rcl" package="E3,5-8" value="220u" x="-4.318" y="2.032" smashed="yes">
<attribute name="NAME" x="-11.43" y="-2.032" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="-6.604" y="-1.016" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C225" library="rcl" package="E2,5-6" value="10u" x="-27.305" y="10.541" smashed="yes" rot="R90">
<attribute name="NAME" x="-25.781" y="7.366" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-24.257" y="8.255" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C201" library="rcl" package="C025_050-025X075" value="100p" x="-21.463" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="-22.86" y="149.352" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-18.669" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C202" library="rcl" package="C025_050-025X075" value="220p" x="-18.288" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="-20.32" y="156.337" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="-15.494" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C203" library="rcl" package="C025_050-025X075" value="330p" x="-15.113" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="-12.954" y="157.353" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-12.319" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C204" library="rcl" package="C025_050-025X075" value="470p" x="-11.938" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="-9.398" y="152.527" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-9.144" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C205" library="rcl" package="C025_050-025X075" value="15p" x="-16.891" y="132.842" smashed="yes" rot="R180">
<attribute name="NAME" x="-15.494" y="131.318" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-13.462" y="135.636" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C206" library="rcl" package="C025_050-025X075" value="15p" x="-16.891" y="135.89" smashed="yes" rot="R180">
<attribute name="NAME" x="-20.574" y="138.303" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-13.462" y="138.684" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C207" library="rcl" package="C050-025X075" value="470p" x="-17.526" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="-14.986" y="121.92" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-20.32" y="127.254" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C3" library="rcl" package="C025_050-025X075" value="330p" x="18.288" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="17.399" y="156.337" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="21.082" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C208" library="rcl" package="C025_050-025X075" value="1u" x="-7.239" y="120.777" smashed="yes" rot="R180">
<attribute name="NAME" x="-5.588" y="123.317" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-3.81" y="123.571" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C209" library="rcl" package="C050-025X075" value="100p" x="-9.525" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="-8.128" y="115.697" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-12.319" y="117.475" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C210" library="rcl" package="C025_050-025X075" value="100p" x="-7.112" y="105.537" smashed="yes" rot="R270">
<attribute name="NAME" x="-9.652" y="106.934" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-9.906" y="108.966" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C211" library="rcl" package="C050-025X075" value="10p" x="-19.304" y="68.072" smashed="yes">
<attribute name="NAME" x="-23.495" y="66.548" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-22.733" y="65.278" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C212" library="rcl" package="C050-025X075" value="1u" x="-7.112" y="85.217" smashed="yes" rot="R180">
<attribute name="NAME" x="-5.715" y="87.757" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-3.683" y="88.011" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C213" library="rcl" package="C050-025X075" value="580n" x="-11.557" y="94.488" smashed="yes" rot="R90">
<attribute name="NAME" x="-9.017" y="92.71" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-8.763" y="91.059" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C214" library="rcl" package="C025_050-025X075" value="680n" x="-11.557" y="105.537" smashed="yes" rot="R270">
<attribute name="NAME" x="-13.081" y="103.759" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-14.351" y="108.966" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C216" library="rcl" package="C050-025X075" value="3n3" x="-6.223" y="61.468" smashed="yes" rot="R90">
<attribute name="NAME" x="-8.636" y="63.246" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-3.429" y="58.039" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C218" library="rcl" package="C050-025X075" value="10p" x="-16.51" y="41.529" smashed="yes" rot="R180">
<attribute name="NAME" x="-23.749" y="41.021" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="-13.081" y="44.323" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C219" library="rcl" package="C050-025X075" value="680n" x="-5.969" y="40.259" smashed="yes">
<attribute name="NAME" x="-4.445" y="42.672" size="1.016" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-9.398" y="37.465" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C4" library="rcl" package="C025_050-025X075" value="470p" x="21.463" y="151.13" smashed="yes" rot="R90">
<attribute name="NAME" x="24.003" y="150.114" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="24.257" y="147.701" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C220" library="rcl" package="C050-025X075" value="680n" x="-27.305" y="28.575" smashed="yes" rot="R90">
<attribute name="NAME" x="-26.924" y="32.512" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-24.511" y="25.146" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C5" library="rcl" package="C025_050-025X075" value="15p" x="16.891" y="132.842" smashed="yes">
<attribute name="NAME" x="15.367" y="133.223" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="13.462" y="130.048" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C6" library="rcl" package="C025_050-025X075" value="15p" x="16.891" y="135.89" smashed="yes">
<attribute name="NAME" x="15.367" y="136.271" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="13.462" y="133.096" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C7" library="rcl" package="C050-025X075" value="470p" x="17.653" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="16.129" y="122.809" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="14.859" y="127.254" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C8" library="rcl" package="C025_050-025X075" value="1u" x="7.239" y="120.777" smashed="yes">
<attribute name="NAME" x="6.223" y="122.301" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="3.81" y="117.983" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C9" library="rcl" package="C050-025X075" value="100p" x="9.525" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="7.112" y="114.808" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="6.731" y="117.475" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="OA1" library="linear" package="DIL08" value="NE5534AN" x="22.098" y="114.046" smashed="yes" rot="R180">
<attribute name="NAME" x="19.431" y="112.649" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="25.654" y="114.681" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA206" library="linear" package="DIL08" value="LF411N" x="-19.939" y="28.575" smashed="yes" rot="R180">
<attribute name="NAME" x="-22.606" y="27.178" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-16.383" y="29.21" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA203" library="linear" package="DIL08" value="LF411N" x="-19.558" y="94.488" smashed="yes" rot="R180">
<attribute name="NAME" x="-22.225" y="93.091" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-16.002" y="95.123" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA205" library="linear" package="DIL08" value="NE5534AN" x="-16.51" y="48.133" smashed="yes" rot="R180">
<attribute name="NAME" x="-19.177" y="46.736" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-12.954" y="48.768" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA2" library="linear" package="DIL08" value="NE5534AN" x="19.304" y="74.676" smashed="yes" rot="R180">
<attribute name="NAME" x="16.637" y="73.279" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="22.86" y="75.311" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA3" library="linear" package="DIL08" value="LF411N" x="19.558" y="94.488" smashed="yes" rot="R180">
<attribute name="NAME" x="16.891" y="93.091" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="23.114" y="95.123" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA4" library="linear" package="DIL08" value="NE5534AN" x="13.716" y="61.468" smashed="yes" rot="R180">
<attribute name="NAME" x="11.049" y="60.071" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="17.272" y="62.103" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA5" library="linear" package="DIL08" value="NE5534AN" x="16.51" y="48.133" smashed="yes" rot="R180">
<attribute name="NAME" x="13.843" y="46.736" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="20.066" y="48.768" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA6" library="linear" package="DIL08" value="LF411N" x="19.939" y="28.575" smashed="yes" rot="R180">
<attribute name="NAME" x="17.272" y="27.178" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="23.495" y="29.21" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA201" library="linear" package="DIL08" value="NE5534AN" x="-22.098" y="114.046" smashed="yes" rot="R180">
<attribute name="NAME" x="-24.765" y="112.649" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-18.542" y="114.681" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA202" library="linear" package="DIL08" value="NE5534AN" x="-19.304" y="74.676" smashed="yes" rot="R180">
<attribute name="NAME" x="-21.971" y="73.279" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-15.748" y="75.311" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="OA204" library="linear" package="DIL08" value="NE5534AN" x="-13.716" y="61.468" smashed="yes" rot="R180">
<attribute name="NAME" x="-16.383" y="60.071" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-10.16" y="62.103" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="L1" library="rcl" package="0204/7" value="220uH" x="3.429" y="132.08" smashed="yes" rot="R270">
<attribute name="NAME" x="2.9464" y="131.9276" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="1.1176" y="134.2136" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="L201" library="rcl" package="0204/7" value="220uH" x="-3.429" y="132.08" smashed="yes" rot="R270">
<attribute name="NAME" x="-3.9116" y="133.4516" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-5.7404" y="134.2136" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="T1" library="transistor-fet" package="SPAK" value="2SK170" x="13.208" y="126.619" smashed="yes" rot="R90">
<attribute name="NAME" x="15.367" y="125.476" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="11.303" y="124.714" size="1.27" layer="27" rot="R90"/>
</element>
<element name="T2" library="transistor-fet" package="SPAK" value="2SK170" x="7.747" y="126.619" smashed="yes" rot="R90">
<attribute name="NAME" x="9.906" y="125.476" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="5.842" y="124.714" size="1.27" layer="27" rot="R90"/>
</element>
<element name="T201" library="transistor-fet" package="SPAK" value="2SK170" x="-6.477" y="126.619" smashed="yes" rot="R90">
<attribute name="NAME" x="-4.318" y="124.587" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="-8.382" y="124.714" size="1.27" layer="27" rot="R90"/>
</element>
<element name="T202" library="transistor-fet" package="SPAK" value="2SK170" x="-11.938" y="126.619" smashed="yes" rot="R90">
<attribute name="NAME" x="-9.779" y="124.587" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="-13.843" y="124.714" size="1.27" layer="27" rot="R90"/>
</element>
<element name="R1" library="rcl" package="0204/7" value="220" x="9.779" y="135.89" smashed="yes">
<attribute name="NAME" x="8.0264" y="135.4074" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="7.6454" y="133.5786" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R10" library="rcl" package="0204/7" value="3k3" x="14.859" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="14.3764" y="114.9096" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="12.5476" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R11" library="rcl" package="0204/7" value="10k" x="3.429" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="2.9464" y="105.1306" size="1.016" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="1.1176" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R12" library="rcl" package="0204/7" value="10k" x="7.112" y="94.488" smashed="yes" rot="R270">
<attribute name="NAME" x="6.6294" y="95.3516" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="4.8006" y="96.6216" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R13" library="rcl" package="0204/7" value="5k1" x="7.112" y="82.423" smashed="yes">
<attribute name="NAME" x="5.3594" y="81.9404" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="4.9784" y="80.1116" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R14" library="rcl" package="0204/7" value="12k" x="23.368" y="104.267" smashed="yes" rot="R90">
<attribute name="NAME" x="23.8506" y="102.5144" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="25.6794" y="102.1334" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R15" library="rcl" package="0204/7" value="12k" x="20.828" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="21.3106" y="102.5144" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="18.5166" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R16" library="rcl" package="0204/7" value="1M" x="18.288" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="18.7706" y="102.5144" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="15.9766" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R17" library="rcl" package="0204/7" value="2k7" x="7.112" y="79.883" smashed="yes" rot="R180">
<attribute name="NAME" x="5.3594" y="79.4004" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="9.2456" y="82.1944" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R18" library="rcl" package="0204/7" value="300" x="3.429" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="2.9464" y="62.3316" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="1.1176" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R19" library="rcl" package="0204/7" value="3k3" x="20.955" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="21.4376" y="59.7154" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="18.6436" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R2" library="rcl" package="0204/7" value="51k" x="9.779" y="132.842" smashed="yes" rot="R180">
<attribute name="NAME" x="8.0264" y="132.3594" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="11.9126" y="135.1534" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R20" library="rcl" package="0204/7" value="390" x="23.495" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="23.0124" y="62.3316" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="21.1836" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R21" library="rcl" package="0204/7" value="5k8" x="25.908" y="48.133" smashed="yes" rot="R270">
<attribute name="NAME" x="26.3906" y="46.3804" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="23.5966" y="50.2666" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R22" library="rcl" package="0204/7" value="6k8" x="8.636" y="55.372" smashed="yes" rot="R180">
<attribute name="NAME" x="9.4996" y="55.8546" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="10.7696" y="57.6834" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R23" library="rcl" package="0204/7" value="1k" x="24.003" y="54.356" smashed="yes">
<attribute name="NAME" x="22.2504" y="53.8734" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="21.8694" y="52.0446" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R24" library="rcl" package="0204/7" value="750" x="23.368" y="48.133" smashed="yes" rot="R270">
<attribute name="NAME" x="23.8506" y="46.3804" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="21.0566" y="50.2666" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R25" library="rcl" package="0204/7" value="100" x="19.05" y="36.195" smashed="yes" rot="R180">
<attribute name="NAME" x="19.9136" y="36.6776" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="21.1836" y="38.5064" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R26" library="rcl" package="0204/7" value="1M" x="19.05" y="38.735" smashed="yes">
<attribute name="NAME" x="19.9136" y="39.2176" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="16.9164" y="36.4236" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R27" library="rcl" package="0204/7" value="1M" x="6.096" y="37.084" smashed="yes" rot="R180">
<attribute name="NAME" x="6.9596" y="37.5666" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="8.2296" y="39.3954" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R28" library="rcl" package="RTRIM64W" value="10k" x="9.017" y="28.575" smashed="yes" rot="R270">
<attribute name="NAME" x="7.242" y="28.782" size="1.016" layer="25"/>
<attribute name="VALUE" x="4.067" y="24.225" size="1.27" layer="27"/>
</element>
<element name="R3" library="rcl" package="0204/7" value="1M6" x="3.429" y="114.046" smashed="yes" rot="R90">
<attribute name="NAME" x="2.9464" y="114.1476" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="5.7404" y="111.9124" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R201" library="rcl" package="0204/7" value="220" x="-9.779" y="135.89" smashed="yes" rot="R180">
<attribute name="NAME" x="-8.1534" y="136.3726" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-7.6454" y="138.2014" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R202" library="rcl" package="0204/7" value="51k" x="-9.779" y="132.842" smashed="yes">
<attribute name="NAME" x="-8.1534" y="133.3246" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-11.9126" y="130.5306" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R203" library="rcl" package="0204/7" value="1M6" x="-3.429" y="114.046" smashed="yes" rot="R90">
<attribute name="NAME" x="-3.9116" y="115.6716" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-1.1176" y="111.9124" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R204" library="rcl" package="0204/7" value="3k3" x="-24.765" y="130.302" smashed="yes">
<attribute name="NAME" x="-23.1394" y="130.7846" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-26.8986" y="127.9906" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R205" library="rcl" package="0204/7" value="47" x="-20.447" y="123.825" smashed="yes" rot="R90">
<attribute name="NAME" x="-19.9644" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-18.1356" y="121.6914" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R206" library="rcl" package="0204/7" value="1k8" x="-22.987" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="-22.5044" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-25.2984" y="125.9586" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R207" library="rcl" package="0204/7" value="1k8" x="-25.527" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="-25.0444" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-27.8384" y="125.9586" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R208" library="rcl" package="0204/7" value="1M6" x="-5.969" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="-5.4864" y="112.2934" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-8.2804" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R209" library="rcl" package="0204/7" value="100" x="-12.319" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="-12.8016" y="115.6716" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-14.6304" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R4" library="rcl" package="0204/7" value="3k3" x="24.765" y="130.302" smashed="yes" rot="R180">
<attribute name="NAME" x="23.0124" y="129.8194" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="26.8986" y="132.6134" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R210" library="rcl" package="0204/7" value="3k3" x="-14.859" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="-15.3416" y="115.6716" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-17.1704" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R211" library="rcl" package="0204/7" value="10k" x="-3.429" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="-3.9116" y="105.7656" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-5.7404" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R212" library="rcl" package="0204/7" value="10k" x="-7.112" y="94.488" smashed="yes" rot="R270">
<attribute name="NAME" x="-7.5946" y="96.1136" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-9.4234" y="96.6216" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R213" library="rcl" package="0204/7" value="5k1" x="-7.112" y="82.423" smashed="yes" rot="R180">
<attribute name="NAME" x="-5.4864" y="82.9056" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-4.9784" y="84.7344" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R214" library="rcl" package="0204/7" value="12k" x="-23.368" y="104.267" smashed="yes" rot="R90">
<attribute name="NAME" x="-22.8854" y="102.5144" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-21.0566" y="102.1334" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R215" library="rcl" package="0204/7" value="12k" x="-20.828" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="-20.3454" y="102.5144" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-23.1394" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R216" library="rcl" package="0204/7" value="1M" x="-18.288" y="104.267" smashed="yes" rot="R270">
<attribute name="NAME" x="-18.7706" y="105.8926" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-20.5994" y="106.4006" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R217" library="rcl" package="0204/7" value="2k7" x="-7.112" y="79.883" smashed="yes">
<attribute name="NAME" x="-5.4864" y="80.3656" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-9.2456" y="77.5716" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R218" library="rcl" package="0204/7" value="300" x="-3.429" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="-3.9116" y="63.0936" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-5.7404" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R219" library="rcl" package="0204/7" value="3k3" x="-20.955" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="-20.4724" y="59.8424" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-23.2664" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R5" library="rcl" package="0204/7" value="47" x="20.447" y="123.825" smashed="yes" rot="R90">
<attribute name="NAME" x="20.9296" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="22.7584" y="121.6914" size="0.9906" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R220" library="rcl" package="0204/7" value="390" x="-23.495" y="61.468" smashed="yes" rot="R270">
<attribute name="NAME" x="-23.9776" y="63.2206" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-25.8064" y="63.6016" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R221" library="rcl" package="0204/7" value="5k8" x="-25.781" y="48.133" smashed="yes" rot="R270">
<attribute name="NAME" x="-25.2984" y="46.3804" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-28.0924" y="50.2666" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R222" library="rcl" package="0204/7" value="6k8" x="-11.176" y="55.245" smashed="yes">
<attribute name="NAME" x="-12.8016" y="54.7624" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-13.3096" y="52.9336" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R223" library="rcl" package="0204/7" value="1k" x="-24.003" y="54.356" smashed="yes" rot="R180">
<attribute name="NAME" x="-22.3774" y="52.8066" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-21.8694" y="56.6674" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R224" library="rcl" package="0204/7" value="750" x="-23.241" y="48.133" smashed="yes" rot="R270">
<attribute name="NAME" x="-22.7584" y="46.3804" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-25.5524" y="50.2666" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R225" library="rcl" package="0204/7" value="100" x="-19.05" y="36.068" smashed="yes">
<attribute name="NAME" x="-20.8026" y="35.5854" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-21.1836" y="33.7566" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R226" library="rcl" package="0204/7" value="1M" x="-19.05" y="38.608" smashed="yes" rot="R180">
<attribute name="NAME" x="-20.8026" y="38.1254" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-16.9164" y="40.9194" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R227" library="rcl" package="0204/7" value="1M" x="-6.096" y="37.084" smashed="yes">
<attribute name="NAME" x="-7.8486" y="36.6014" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-8.2296" y="34.7726" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R228" library="rcl" package="RTRIM64W" value="10k" x="-9.017" y="28.575" smashed="yes" rot="R270">
<attribute name="NAME" x="-10.665" y="28.528" size="1.016" layer="25"/>
<attribute name="VALUE" x="-13.967" y="24.225" size="1.27" layer="27"/>
</element>
<element name="R6" library="rcl" package="0204/7" value="1k8" x="22.987" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="23.4696" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="20.6756" y="125.9586" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R7" library="rcl" package="0204/7" value="1k8" x="25.527" y="123.825" smashed="yes" rot="R270">
<attribute name="NAME" x="26.0096" y="122.0724" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="23.2156" y="125.9586" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R8" library="rcl" package="0204/7" value="1M6" x="5.969" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="6.4516" y="112.2934" size="0.9906" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="3.6576" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R9" library="rcl" package="0204/7" value="100" x="12.319" y="114.046" smashed="yes" rot="R270">
<attribute name="NAME" x="11.8364" y="114.1476" size="0.9906" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="10.0076" y="116.1796" size="0.9906" layer="27" ratio="10" rot="R270"/>
</element>
<element name="SW2" library="switch-dil" package="DIP04YL" value="DIP4" x="-16.129" y="142.748" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="-16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="-16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="-16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="-16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="-15.113" y="142.621" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-22.1742" y="145.8976" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="SW1" library="switch-dil" package="DIP04YL" value="DIP4" x="16.129" y="142.748" smashed="yes" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="16.129" y="142.748" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="NAME" x="13.0048" y="141.3002" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="10.0838" y="145.8976" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R_IN" library="wirepad" package="3,17/1,3" value="" x="7.112" y="150.368" smashed="yes">
<attribute name="NAME" x="5.588" y="152.273" size="1.016" layer="25" ratio="10" rot="SR0"/>
<attribute name="VALUE" x="7.112" y="151.568" size="0.0254" layer="27"/>
</element>
<element name="R__GND" library="wirepad" package="3,17/1,3" value="" x="2.54" y="154.94" smashed="yes">
<attribute name="NAME" x="1.016" y="156.972" size="1.016" layer="25" ratio="10" rot="SR0"/>
<attribute name="VALUE" x="2.54" y="156.14" size="0.0254" layer="27"/>
</element>
<element name="L_IN" library="wirepad" package="3,17/1,3" value="" x="-7.112" y="150.368" smashed="yes">
<attribute name="NAME" x="-8.509" y="152.4" size="1.016" layer="25" ratio="10" rot="SR0"/>
<attribute name="VALUE" x="-7.112" y="151.568" size="0.0254" layer="27"/>
</element>
<element name="L__GND" library="wirepad" package="3,17/1,3" value="" x="-2.54" y="154.94" smashed="yes">
<attribute name="NAME" x="-6.35" y="156.972" size="1.016" layer="25" ratio="10" rot="SR0"/>
<attribute name="VALUE" x="-2.54" y="156.14" size="0.0254" layer="27"/>
</element>
<element name="R_OUT" library="wirepad" package="3,17/1,3" value="" x="9.906" y="33.401" smashed="yes" rot="R270">
<attribute name="NAME" x="12.065" y="33.528" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="11.106" y="33.401" size="0.0254" layer="27" rot="R270"/>
</element>
<element name="R_GND" library="wirepad" package="3,17/1,3" value="" x="2.54" y="33.401" smashed="yes" rot="R270">
<attribute name="NAME" x="2.921" y="26.543" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="3.74" y="33.401" size="0.0254" layer="27" rot="R270"/>
</element>
<element name="L_GND" library="wirepad" package="3,17/1,3" value="" x="-2.54" y="33.401" smashed="yes" rot="R270">
<attribute name="NAME" x="-1.905" y="26.67" size="1.016" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-1.34" y="33.401" size="0.0254" layer="27" rot="R270"/>
</element>
<element name="L_OUT" library="wirepad" package="3,17/1,3" value="" x="-9.906" y="33.401" smashed="yes" rot="R270">
<attribute name="NAME" x="-16.51" y="33.528" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="-8.706" y="33.401" size="0.0254" layer="27" rot="R270"/>
</element>
<element name="0V" library="wirepad" package="3,17/1,3" value="" x="0" y="-18.288" smashed="yes">
<attribute name="NAME" x="-0.889" y="-21.463" size="1.016" layer="25" ratio="10"/>
<attribute name="VALUE" x="0" y="-17.088" size="0.0254" layer="27"/>
</element>
<element name="C226" library="rcl" package="C025_050-025X075" value="100n" x="-27.94" y="144.018" smashed="yes" rot="R270">
<attribute name="NAME" x="-28.575" y="150.876" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-30.734" y="146.177" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C227" library="rcl" package="C025_050-025X075" value="100n" x="-4.699" y="19.558" smashed="yes" rot="R180">
<attribute name="NAME" x="-11.176" y="21.463" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-2.54" y="22.352" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C21" library="rcl" package="C025_050-025X075" value="100n" x="27.305" y="135.89" rot="R180"/>
<element name="C22" library="rcl" package="C025_050-025X075" value="100n" x="24.892" y="144.018" rot="R270"/>
<element name="C23" library="rcl" package="C025_050-025X075" value="100n" x="4.699" y="23.114" smashed="yes">
<attribute name="NAME" x="9.779" y="22.479" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="2.54" y="20.32" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C24" library="rcl" package="E3,5-8" value="220u" x="4.318" y="2.032" smashed="yes" rot="R180">
<attribute name="NAME" x="10.668" y="-1.016" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="6.604" y="5.08" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C25" library="rcl" package="E2,5-6" value="10u" x="21.971" y="6.858" smashed="yes" rot="R90">
<attribute name="NAME" x="23.495" y="11.303" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="24.638" y="9.525" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C26" library="rcl" package="C025_050-025X075" value="100n" x="27.94" y="144.018" rot="R270"/>
<element name="C27" library="rcl" package="C025_050-025X075" value="100n" x="4.699" y="19.558" smashed="yes">
<attribute name="NAME" x="11.43" y="17.78" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="2.54" y="16.764" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C28" library="rcl" package="E3,5-8" value="220u" x="4.318" y="13.208" smashed="yes" rot="R180">
<attribute name="NAME" x="11.049" y="16.637" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="6.604" y="16.256" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C222" library="rcl" package="C025_050-025X075" value="100n" x="-24.892" y="144.018" smashed="yes" rot="R270">
<attribute name="NAME" x="-25.527" y="150.876" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-27.686" y="146.177" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C223" library="rcl" package="C025_050-025X075" value="100n" x="-4.699" y="23.114" smashed="yes" rot="R180">
<attribute name="NAME" x="-9.779" y="23.495" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-2.54" y="25.908" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="C228" library="rcl" package="E3,5-8" value="220u" x="-4.318" y="13.208" smashed="yes">
<attribute name="NAME" x="-12.319" y="15.24" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-6.604" y="10.16" size="1.27" layer="27" ratio="10"/>
</element>
<element name="T3" library="transistor-npn" package="TO92-EBC" value="BC546A" x="24.384" y="-1.27" smashed="yes" rot="R90">
<attribute name="NAME" x="28.956" y="-2.413" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="28.956" y="-3.81" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="T203" library="transistor-npn" package="TO92-EBC" value="BC546A" x="-26.924" y="-1.27" smashed="yes" rot="R90">
<attribute name="NAME" x="-28.702" y="-3.429" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-22.352" y="-3.81" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="T4" library="transistor-pnp" package="TO92-EBC" value="BC556" x="24.384" y="18.288" smashed="yes" rot="R90">
<attribute name="NAME" x="28.956" y="17.145" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="28.956" y="15.748" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="T204" library="transistor-pnp" package="TO92-EBC" value="BC556" x="-26.924" y="18.288" smashed="yes" rot="R90">
<attribute name="NAME" x="-28.702" y="16.002" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="-22.352" y="15.748" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="R29" library="rcl" package="0204/7" value="10" x="18.034" y="-3.81" smashed="yes" rot="R180">
<attribute name="NAME" x="18.923" y="-3.3274" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="19.6596" y="-3.3274" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R32" library="rcl" package="0204/7" value="10" x="18.034" y="15.748"/>
<element name="R229" library="rcl" package="0204/7" value="10" x="-18.542" y="-3.81" smashed="yes">
<attribute name="NAME" x="-20.32" y="-4.2926" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-20.1676" y="-4.2926" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R232" library="rcl" package="0204/7" value="10" x="-18.034" y="15.748" smashed="yes">
<attribute name="NAME" x="-19.812" y="15.2654" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-19.6596" y="15.2654" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R30" library="rcl" package="0204/7" value="6k8" x="18.034" y="-1.27" smashed="yes">
<attribute name="NAME" x="16.256" y="-1.7526" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.4084" y="-1.7526" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R33" library="rcl" package="0204/7" value="6k8" x="18.034" y="18.288"/>
<element name="R230" library="rcl" package="0204/7" value="6k8" x="-18.542" y="-1.27" smashed="yes" rot="R180">
<attribute name="NAME" x="-16.891" y="-0.9144" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-16.9164" y="-0.7874" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R233" library="rcl" package="0204/7" value="6k8" x="-18.034" y="20.828" smashed="yes" rot="R180">
<attribute name="NAME" x="-16.383" y="21.3106" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-16.4084" y="21.3106" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R31" library="rcl" package="0204/7" value="2k2" x="18.034" y="1.27" smashed="yes">
<attribute name="NAME" x="16.256" y="0.7874" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.4084" y="0.7874" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R34" library="rcl" package="0204/7" value="2k2" x="18.034" y="20.828"/>
<element name="R231" library="rcl" package="0204/7" value="2k2" x="-18.542" y="1.27" smashed="yes">
<attribute name="NAME" x="-20.32" y="0.7874" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-20.1676" y="0.7874" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R234" library="rcl" package="0204/7" value="2k2" x="-18.034" y="18.288" smashed="yes">
<attribute name="NAME" x="-19.812" y="17.8054" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-19.6596" y="17.8054" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="C229" library="rcl" package="E2,5-6" value="10u" x="-16.637" y="10.541" smashed="yes" rot="R270">
<attribute name="NAME" x="-18.796" y="6.096" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-19.304" y="7.874" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C29" library="rcl" package="E2,5-6E" value="10u" x="11.43" y="6.858" smashed="yes" rot="R270">
<attribute name="NAME" x="9.652" y="10.033" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="8.89" y="4.191" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C305" library="rcl" package="E2,5-6" value="10u" x="27.305" y="10.541" smashed="yes" rot="R90">
<attribute name="NAME" x="25.019" y="6.096" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="29.972" y="13.208" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C301" library="rcl" package="E2,5-6" value="10u" x="-21.971" y="6.858" smashed="yes" rot="R90">
<attribute name="NAME" x="-19.939" y="11.303" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-19.304" y="9.525" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="C303" library="rcl" package="E2,5-6" value="10u" x="-11.303" y="6.858" smashed="yes" rot="R270">
<attribute name="NAME" x="-13.589" y="10.033" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-13.97" y="4.191" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C306" library="rcl" package="E2,5-6" value="10u" x="16.637" y="10.541" smashed="yes" rot="R270">
<attribute name="NAME" x="14.605" y="6.223" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="13.97" y="7.874" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="IC301" library="v-reg-3" package="317TS" value="" x="-18.542" y="-7.366" smashed="yes">
<attribute name="NAME" x="-28.956" y="-8.5852" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-23.622" y="-14.986" size="1.27" layer="27" ratio="10"/>
</element>
<element name="IC302" library="v-reg-3" package="337TS" value="" x="18.542" y="-7.366" smashed="yes">
<attribute name="NAME" x="24.13" y="-8.7122" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="13.462" y="-14.986" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R301" library="rcl" package="0204/7" value="120" x="-18.542" y="-13.589" smashed="yes">
<attribute name="NAME" x="-20.193" y="-14.0716" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="-20.1676" y="-14.0716" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R302" library="rcl" package="0204/7" value="1k8" x="-18.542" y="-16.129" smashed="yes" rot="R180">
<attribute name="NAME" x="-16.891" y="-15.6464" size="0.9906" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-16.9164" y="-15.6464" size="0.9906" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R303" library="rcl" package="0204/7" value="120" x="18.542" y="-13.843" smashed="yes">
<attribute name="NAME" x="16.764" y="-14.3256" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.9164" y="-14.3256" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="R304" library="rcl" package="0204/7" value="1k8" x="18.542" y="-16.383" smashed="yes">
<attribute name="NAME" x="16.764" y="-16.8656" size="0.9906" layer="25" ratio="10"/>
<attribute name="VALUE" x="16.9164" y="-16.8656" size="0.9906" layer="27" ratio="10"/>
</element>
<element name="D302" library="diode" package="DO41-10" value="1N4002" x="-10.795" y="-11.049" smashed="yes" rot="R270">
<attribute name="NAME" x="-13.081" y="-13.208" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="-13.589" y="-9.017" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D303" library="diode" package="DO41-10" value="1N4002" x="10.795" y="-11.303" smashed="yes" rot="R270">
<attribute name="NAME" x="11.938" y="-13.589" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="8.001" y="-9.271" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="D301" library="diode" package="DO34-7" value="KA262" x="-18.542" y="-18.542" smashed="yes" rot="R180">
<attribute name="NAME" x="-16.383" y="-19.685" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="-17.018" y="-16.129" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="D304" library="diode" package="DO34-7" value="KA262" x="18.542" y="-18.796" smashed="yes">
<attribute name="NAME" x="16.51" y="-21.209" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="17.018" y="-21.209" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C302" library="rcl" package="E3,5-8" value="220u" x="-4.318" y="-9.144" smashed="yes">
<attribute name="NAME" x="-8.636" y="-14.859" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="-6.604" y="-12.192" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C304" library="rcl" package="E3,5-8" value="220u" x="4.318" y="-9.144" smashed="yes" rot="R180">
<attribute name="NAME" x="9.017" y="-13.589" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="6.604" y="-6.096" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="G2" library="wirepad" package="3,17/1,3" value="" x="0" y="121.412"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="R1" pad="1"/>
<contactref element="SW1" pad="8"/>
<contactref element="SW1" pad="7"/>
<contactref element="SW1" pad="6"/>
<contactref element="SW1" pad="5"/>
<contactref element="L1" pad="1"/>
<contactref element="R_IN" pad="1"/>
<wire x1="12.319" y1="138.938" x2="14.859" y2="138.938" width="0.6096" layer="16"/>
<wire x1="14.859" y1="138.938" x2="17.399" y2="138.938" width="0.6096" layer="16"/>
<wire x1="17.399" y1="138.938" x2="19.939" y2="138.938" width="0.6096" layer="16"/>
<wire x1="7.112" y1="150.368" x2="7.112" y2="138.938" width="0.6096" layer="16"/>
<wire x1="12.319" y1="138.938" x2="7.112" y2="138.938" width="0.6096" layer="16"/>
<wire x1="5.969" y1="135.89" x2="3.429" y2="135.89" width="0.6096" layer="16"/>
<wire x1="7.112" y1="138.938" x2="7.112" y2="137.033" width="0.6096" layer="16"/>
<wire x1="7.112" y1="137.033" x2="5.969" y2="135.89" width="0.6096" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="R1" pad="2"/>
<contactref element="L1" pad="2"/>
<contactref element="T1" pad="1"/>
<contactref element="R2" pad="2"/>
<contactref element="R3" pad="2"/>
<contactref element="C6" pad="1"/>
<wire x1="13.589" y1="135.89" x2="15.621" y2="135.89" width="0.6096" layer="16"/>
<wire x1="3.429" y1="128.27" x2="5.969" y2="130.81" width="0.6096" layer="16"/>
<wire x1="5.969" y1="130.81" x2="5.969" y2="132.842" width="0.6096" layer="16"/>
<wire x1="3.429" y1="117.856" x2="3.429" y2="128.27" width="0.6096" layer="16"/>
<wire x1="5.969" y1="132.842" x2="8.255" y2="132.842" width="0.6096" layer="16"/>
<wire x1="8.255" y1="132.842" x2="11.303" y2="135.89" width="0.6096" layer="16"/>
<wire x1="11.303" y1="135.89" x2="13.589" y2="135.89" width="0.6096" layer="16"/>
<wire x1="11.938" y1="126.619" x2="11.176" y2="126.619" width="0.6096" layer="1"/>
<wire x1="11.176" y1="126.619" x2="10.795" y2="127" width="0.6096" layer="1"/>
<wire x1="10.795" y1="127" x2="10.795" y2="133.985" width="0.6096" layer="1"/>
<wire x1="10.795" y1="133.985" x2="12.7" y2="135.89" width="0.6096" layer="1"/>
<wire x1="12.7" y1="135.89" x2="13.589" y2="135.89" width="0.6096" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="R2" pad="1"/>
<contactref element="C5" pad="1"/>
<wire x1="13.589" y1="132.842" x2="15.621" y2="132.842" width="0.6096" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="T1" pad="2"/>
<contactref element="T2" pad="2"/>
<contactref element="R4" pad="2"/>
<wire x1="7.747" y1="127.889" x2="13.208" y2="127.889" width="0.6096" layer="16"/>
<wire x1="20.955" y1="130.302" x2="16.51" y2="130.302" width="0.6096" layer="16"/>
<wire x1="16.51" y1="130.302" x2="14.097" y2="127.889" width="0.6096" layer="16"/>
<wire x1="14.097" y1="127.889" x2="13.208" y2="127.889" width="0.6096" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="OA1" pad="2"/>
<contactref element="T1" pad="3"/>
<contactref element="R5" pad="1"/>
<contactref element="R6" pad="2"/>
<wire x1="20.447" y1="120.015" x2="22.987" y2="120.015" width="0.6096" layer="16"/>
<wire x1="23.368" y1="117.856" x2="23.368" y2="119.634" width="0.6096" layer="16"/>
<wire x1="23.368" y1="119.634" x2="22.987" y2="120.015" width="0.6096" layer="16"/>
<wire x1="13.208" y1="125.349" x2="13.208" y2="124.46" width="0.6096" layer="1"/>
<wire x1="13.208" y1="124.46" x2="14.859" y2="122.809" width="0.6096" layer="1"/>
<wire x1="14.859" y1="122.809" x2="18.669" y2="122.809" width="0.6096" layer="1"/>
<wire x1="18.669" y1="122.809" x2="20.447" y2="121.031" width="0.6096" layer="1"/>
<wire x1="20.447" y1="121.031" x2="20.447" y2="120.015" width="0.6096" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="OA1" pad="3"/>
<contactref element="T2" pad="3"/>
<contactref element="R7" pad="2"/>
<contactref element="C7" pad="2"/>
<wire x1="20.828" y1="117.856" x2="20.32" y2="117.856" width="0.6096" layer="16"/>
<wire x1="20.32" y1="117.856" x2="17.653" y2="120.523" width="0.6096" layer="16"/>
<wire x1="25.527" y1="120.015" x2="25.527" y2="121.158" width="0.6096" layer="16"/>
<wire x1="9.398" y1="122.809" x2="7.747" y2="124.46" width="0.6096" layer="16"/>
<wire x1="7.747" y1="124.46" x2="7.747" y2="125.349" width="0.6096" layer="16"/>
<wire x1="9.398" y1="122.809" x2="17.653" y2="122.809" width="0.6096" layer="16"/>
<wire x1="17.653" y1="122.809" x2="23.876" y2="122.809" width="0.6096" layer="16"/>
<wire x1="23.876" y1="122.809" x2="25.527" y2="121.158" width="0.6096" layer="16"/>
<wire x1="17.653" y1="121.285" x2="17.653" y2="122.809" width="0.6096" layer="16"/>
<wire x1="17.653" y1="120.523" x2="17.653" y2="121.285" width="0.6096" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R5" pad="2"/>
<contactref element="C7" pad="1"/>
<wire x1="20.447" y1="127.635" x2="18.923" y2="127.635" width="0.6096" layer="16"/>
<wire x1="18.923" y1="127.635" x2="17.653" y2="126.365" width="0.6096" layer="16"/>
</signal>
<signal name="GND">
<contactref element="C5" pad="2"/>
<contactref element="C6" pad="2"/>
<contactref element="R13" pad="1"/>
<contactref element="C12" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="R15" pad="1"/>
<contactref element="C14" pad="1"/>
<contactref element="R9" pad="2"/>
<contactref element="R18" pad="2"/>
<contactref element="C16" pad="1"/>
<contactref element="C17A" pad="1"/>
<contactref element="C17B" pad="1"/>
<contactref element="C17C" pad="1"/>
<contactref element="R20" pad="2"/>
<contactref element="R23" pad="2"/>
<contactref element="C19" pad="2"/>
<contactref element="R27" pad="2"/>
<contactref element="C205" pad="2"/>
<contactref element="C206" pad="2"/>
<contactref element="R213" pad="1"/>
<contactref element="C212" pad="1"/>
<contactref element="R216" pad="1"/>
<contactref element="R215" pad="1"/>
<contactref element="C214" pad="1"/>
<contactref element="R209" pad="2"/>
<contactref element="R218" pad="2"/>
<contactref element="C216" pad="1"/>
<contactref element="C217A" pad="1"/>
<contactref element="C217B" pad="1"/>
<contactref element="C217C" pad="1"/>
<contactref element="R220" pad="2"/>
<contactref element="R223" pad="2"/>
<contactref element="C219" pad="2"/>
<contactref element="R227" pad="2"/>
<contactref element="R__GND" pad="1"/>
<contactref element="L__GND" pad="1"/>
<contactref element="R_GND" pad="1"/>
<contactref element="L_GND" pad="1"/>
<contactref element="0V" pad="1"/>
<wire x1="0" y1="-18.288" x2="0" y2="-13.589" width="3.81" layer="16"/>
<wire x1="0" y1="-13.589" x2="0" y2="-9.144" width="3.81" layer="16"/>
<wire x1="0" y1="-9.144" x2="0" y2="2.032" width="3.81" layer="16"/>
<wire x1="0" y1="2.032" x2="0" y2="5.588" width="3.81" layer="16"/>
<wire x1="0" y1="5.588" x2="0" y2="13.208" width="3.81" layer="16"/>
<wire x1="0" y1="13.208" x2="0" y2="13.335" width="3.81" layer="16"/>
<wire x1="0" y1="13.335" x2="0" y2="19.431" width="3.81" layer="16"/>
<wire x1="0" y1="19.431" x2="0" y2="23.114" width="3.81" layer="16"/>
<wire x1="0" y1="23.114" x2="0" y2="33.401" width="3.81" layer="16"/>
<wire x1="0" y1="33.401" x2="0" y2="37.084" width="3.81" layer="16"/>
<wire x1="0" y1="37.084" x2="0" y2="40.259" width="3.81" layer="16"/>
<wire x1="0" y1="40.259" x2="0" y2="44.196" width="3.81" layer="16"/>
<wire x1="0" y1="44.196" x2="0" y2="44.323" width="3.81" layer="16"/>
<wire x1="0" y1="44.323" x2="0" y2="48.387" width="3.81" layer="16"/>
<wire x1="0" y1="48.387" x2="0" y2="52.451" width="3.81" layer="16"/>
<wire x1="0" y1="52.451" x2="0" y2="57.658" width="3.81" layer="16"/>
<wire x1="0" y1="57.658" x2="0" y2="82.423" width="3.81" layer="16"/>
<wire x1="0" y1="82.423" x2="0" y2="85.217" width="3.81" layer="16"/>
<wire x1="0" y1="85.217" x2="0" y2="114.046" width="3.81" layer="16"/>
<contactref element="C22" pad="1"/>
<contactref element="C23" pad="1"/>
<contactref element="C24" pad="-"/>
<contactref element="C26" pad="1"/>
<contactref element="C27" pad="1"/>
<contactref element="C28" pad="-"/>
<contactref element="C224" pad="-"/>
<contactref element="C223" pad="1"/>
<contactref element="C222" pad="1"/>
<contactref element="C226" pad="1"/>
<contactref element="C227" pad="1"/>
<contactref element="C228" pad="-"/>
<contactref element="C229" pad="-"/>
<contactref element="C225" pad="-"/>
<contactref element="C25" pad="-"/>
<contactref element="C29" pad="-"/>
<contactref element="C305" pad="-"/>
<contactref element="C301" pad="-"/>
<contactref element="C303" pad="-"/>
<contactref element="C306" pad="-"/>
<contactref element="R302" pad="1"/>
<contactref element="R304" pad="1"/>
<contactref element="C302" pad="-"/>
<contactref element="C304" pad="-"/>
<contactref element="C4" pad="2"/>
<contactref element="C3" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="C204" pad="2"/>
<contactref element="C203" pad="2"/>
<contactref element="C202" pad="2"/>
<contactref element="C201" pad="2"/>
<wire x1="-27.94" y1="145.288" x2="-24.892" y2="145.288" width="0.6096" layer="16"/>
<wire x1="24.892" y1="145.288" x2="27.94" y2="145.288" width="0.6096" layer="16"/>
<wire x1="-24.892" y1="145.288" x2="-24.892" y2="152.4" width="0.6096" layer="16"/>
<wire x1="-24.892" y1="152.4" x2="-22.352" y2="154.94" width="0.6096" layer="16"/>
<wire x1="24.892" y1="145.288" x2="24.892" y2="152.4" width="0.6096" layer="16"/>
<wire x1="24.892" y1="152.4" x2="22.352" y2="154.94" width="0.6096" layer="16"/>
<wire x1="22.479" y1="137.668" x2="22.479" y2="143.002" width="0.6096" layer="16"/>
<wire x1="22.479" y1="143.002" x2="24.892" y2="145.288" width="0.6096" layer="16"/>
<wire x1="-22.479" y1="137.668" x2="-22.479" y2="142.875" width="0.6096" layer="16"/>
<wire x1="-22.479" y1="142.875" x2="-24.892" y2="145.288" width="0.6096" layer="16"/>
<wire x1="7.874" y1="110.49" x2="7.874" y2="111.379" width="0.6096" layer="16"/>
<wire x1="7.874" y1="111.379" x2="5.207" y2="114.046" width="0.6096" layer="16"/>
<wire x1="5.207" y1="114.046" x2="0" y2="114.046" width="0.6096" layer="16"/>
<wire x1="-7.874" y1="110.49" x2="-7.874" y2="111.506" width="0.6096" layer="16"/>
<wire x1="-7.874" y1="111.506" x2="-5.334" y2="114.046" width="0.6096" layer="16"/>
<wire x1="-5.334" y1="114.046" x2="0" y2="114.046" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="57.658" x2="0" y2="57.658" width="0.6096" layer="16"/>
<wire x1="3.429" y1="57.658" x2="0" y2="57.658" width="0.6096" layer="16"/>
<wire x1="6.223" y1="58.928" x2="4.699" y2="58.928" width="0.6096" layer="16"/>
<wire x1="4.699" y1="58.928" x2="3.429" y2="57.658" width="0.6096" layer="16"/>
<wire x1="-6.223" y1="58.928" x2="-4.699" y2="58.928" width="0.6096" layer="16"/>
<wire x1="-4.699" y1="58.928" x2="-3.429" y2="57.658" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="57.658" x2="-23.495" y2="58.674" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="58.674" x2="-22.606" y2="59.563" width="0.6096" layer="16"/>
<wire x1="-22.606" y1="59.563" x2="-6.858" y2="59.563" width="0.6096" layer="16"/>
<wire x1="-6.858" y1="59.563" x2="-6.223" y2="58.928" width="0.6096" layer="16"/>
<wire x1="23.495" y1="57.658" x2="23.495" y2="58.674" width="0.6096" layer="16"/>
<wire x1="23.495" y1="58.674" x2="22.606" y2="59.563" width="0.6096" layer="16"/>
<wire x1="22.606" y1="59.563" x2="6.858" y2="59.563" width="0.6096" layer="16"/>
<wire x1="6.858" y1="59.563" x2="6.223" y2="58.928" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="52.451" x2="0" y2="52.451" width="0.6096" layer="16"/>
<wire x1="3.429" y1="52.451" x2="0" y2="52.451" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="48.387" x2="0" y2="48.387" width="0.6096" layer="16"/>
<wire x1="3.429" y1="48.387" x2="0" y2="48.387" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="44.323" x2="0" y2="44.323" width="0.6096" layer="16"/>
<wire x1="3.429" y1="44.323" x2="0.127" y2="44.323" width="0.6096" layer="16"/>
<wire x1="0.127" y1="44.323" x2="0" y2="44.196" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="40.259" x2="0" y2="40.259" width="0.6096" layer="16"/>
<wire x1="3.429" y1="40.259" x2="0" y2="40.259" width="0.6096" layer="16"/>
<wire x1="-2.286" y1="37.084" x2="0" y2="37.084" width="0.6096" layer="16"/>
<wire x1="2.286" y1="37.084" x2="0" y2="37.084" width="0.6096" layer="16"/>
<wire x1="-2.54" y1="33.401" x2="0" y2="33.401" width="0.6096" layer="16"/>
<wire x1="2.54" y1="33.401" x2="0" y2="33.401" width="0.6096" layer="16"/>
<wire x1="-2.54" y1="13.208" x2="0" y2="13.208" width="1.6764" layer="16"/>
<wire x1="2.54" y1="13.208" x2="0.127" y2="13.208" width="1.6764" layer="16"/>
<wire x1="0.127" y1="13.208" x2="0" y2="13.335" width="1.6764" layer="16"/>
<wire x1="-0.127" y1="19.558" x2="0" y2="19.431" width="1.27" layer="16"/>
<wire x1="-27.305" y1="11.811" x2="-25.654" y2="11.811" width="1.016" layer="16"/>
<wire x1="-25.654" y1="11.811" x2="-21.971" y2="8.128" width="1.016" layer="16"/>
<wire x1="-21.971" y1="8.128" x2="-17.78" y2="8.128" width="1.016" layer="16"/>
<wire x1="-17.78" y1="8.128" x2="-16.637" y2="9.271" width="1.016" layer="16"/>
<wire x1="-11.303" y1="5.588" x2="-12.954" y2="5.588" width="1.016" layer="16"/>
<wire x1="-12.954" y1="5.588" x2="-16.637" y2="9.271" width="1.016" layer="16"/>
<wire x1="-11.303" y1="5.588" x2="0" y2="5.588" width="1.016" layer="16"/>
<wire x1="27.305" y1="11.811" x2="25.654" y2="11.811" width="1.016" layer="16"/>
<wire x1="25.654" y1="11.811" x2="21.971" y2="8.128" width="1.016" layer="16"/>
<wire x1="16.637" y1="9.271" x2="20.828" y2="9.271" width="1.016" layer="16"/>
<wire x1="20.828" y1="9.271" x2="21.971" y2="8.128" width="1.016" layer="16"/>
<wire x1="11.43" y1="5.588" x2="12.954" y2="5.588" width="1.016" layer="16"/>
<wire x1="12.954" y1="5.588" x2="16.637" y2="9.271" width="1.016" layer="16"/>
<wire x1="11.43" y1="5.588" x2="0" y2="5.588" width="1.016" layer="16"/>
<wire x1="-14.732" y1="-16.129" x2="-13.97" y2="-16.129" width="1.016" layer="16"/>
<wire x1="-13.97" y1="-16.129" x2="-11.43" y2="-13.589" width="1.016" layer="16"/>
<wire x1="-11.43" y1="-13.589" x2="0" y2="-13.589" width="1.016" layer="16"/>
<wire x1="14.732" y1="-16.383" x2="13.97" y2="-16.383" width="1.016" layer="16"/>
<wire x1="13.97" y1="-16.383" x2="11.176" y2="-13.589" width="1.016" layer="16"/>
<wire x1="11.176" y1="-13.589" x2="0" y2="-13.589" width="1.016" layer="16"/>
<wire x1="-20.828" y1="108.077" x2="-18.288" y2="108.077" width="0.6096" layer="16"/>
<wire x1="18.288" y1="108.077" x2="12.319" y2="108.077" width="0.6096" layer="16"/>
<wire x1="12.319" y1="108.077" x2="11.557" y2="108.077" width="0.6096" layer="16"/>
<wire x1="11.557" y1="108.077" x2="10.287" y2="108.077" width="0.6096" layer="16"/>
<wire x1="10.287" y1="108.077" x2="7.874" y2="110.49" width="0.6096" layer="16"/>
<wire x1="12.319" y1="110.236" x2="12.319" y2="108.077" width="0.6096" layer="16"/>
<wire x1="11.557" y1="106.807" x2="11.557" y2="108.077" width="0.6096" layer="16"/>
<wire x1="18.288" y1="108.077" x2="20.828" y2="108.077" width="0.6096" layer="16"/>
<wire x1="3.302" y1="82.423" x2="0" y2="82.423" width="0.6096" layer="16"/>
<wire x1="4.572" y1="85.217" x2="0" y2="85.217" width="0.6096" layer="16"/>
<wire x1="-3.302" y1="82.423" x2="0" y2="82.423" width="0.6096" layer="16"/>
<wire x1="-4.572" y1="85.217" x2="0" y2="85.217" width="0.6096" layer="16"/>
<wire x1="-2.54" y1="2.032" x2="0" y2="2.032" width="1.016" layer="16"/>
<wire x1="2.54" y1="2.032" x2="0" y2="2.032" width="1.016" layer="16"/>
<wire x1="-2.54" y1="-9.144" x2="0" y2="-9.144" width="1.016" layer="16"/>
<wire x1="2.54" y1="-9.144" x2="0" y2="-9.144" width="1.016" layer="16"/>
<wire x1="-3.429" y1="19.558" x2="-0.127" y2="19.558" width="1.016" layer="16"/>
<wire x1="-3.429" y1="23.114" x2="0" y2="23.114" width="1.016" layer="16"/>
<wire x1="3.429" y1="19.558" x2="0.127" y2="19.558" width="1.016" layer="16"/>
<wire x1="0.127" y1="19.558" x2="0" y2="19.431" width="1.016" layer="16"/>
<wire x1="3.429" y1="23.114" x2="0" y2="23.114" width="1.016" layer="16"/>
<contactref element="G2" pad="1"/>
<wire x1="0" y1="114.046" x2="0" y2="121.412" width="3.81" layer="16"/>
<wire x1="0" y1="121.412" x2="0" y2="154.94" width="1.9304" layer="16"/>
<wire x1="0" y1="154.94" x2="2.54" y2="154.94" width="1.9304" layer="16"/>
<wire x1="-2.54" y1="154.94" x2="0" y2="154.94" width="1.9304" layer="16"/>
<wire x1="2.54" y1="154.94" x2="11.811" y2="154.94" width="0.6096" layer="16"/>
<wire x1="11.811" y1="154.94" x2="15.113" y2="154.94" width="0.6096" layer="16"/>
<wire x1="15.113" y1="154.94" x2="18.288" y2="154.94" width="0.6096" layer="16"/>
<wire x1="18.288" y1="154.94" x2="21.463" y2="154.94" width="0.6096" layer="16"/>
<wire x1="11.811" y1="152.4" x2="11.811" y2="154.94" width="0.6096" layer="16"/>
<wire x1="15.113" y1="152.4" x2="15.113" y2="154.94" width="0.6096" layer="16"/>
<wire x1="18.288" y1="152.4" x2="18.288" y2="154.94" width="0.6096" layer="16"/>
<wire x1="21.463" y1="152.4" x2="21.463" y2="154.94" width="0.6096" layer="16"/>
<wire x1="22.352" y1="154.94" x2="21.463" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-2.54" y1="154.94" x2="-11.938" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-11.938" y1="154.94" x2="-15.113" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-15.113" y1="154.94" x2="-18.288" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-18.288" y1="154.94" x2="-21.463" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-21.463" y1="154.94" x2="-22.352" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-11.938" y1="152.4" x2="-11.938" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-15.113" y1="152.4" x2="-15.113" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-18.288" y1="152.4" x2="-18.288" y2="154.94" width="0.6096" layer="16"/>
<wire x1="-21.463" y1="152.4" x2="-21.463" y2="154.94" width="0.6096" layer="16"/>
<wire x1="18.161" y1="132.842" x2="20.701" y2="132.842" width="0.6096" layer="16"/>
<wire x1="18.161" y1="135.89" x2="20.574" y2="135.89" width="0.6096" layer="16"/>
<wire x1="20.574" y1="135.89" x2="20.701" y2="135.89" width="0.6096" layer="16"/>
<wire x1="20.701" y1="132.842" x2="20.701" y2="135.763" width="0.6096" layer="16"/>
<wire x1="20.701" y1="135.763" x2="20.574" y2="135.89" width="0.6096" layer="16"/>
<wire x1="20.701" y1="135.89" x2="22.479" y2="137.668" width="0.6096" layer="16"/>
<wire x1="-18.161" y1="132.842" x2="-20.701" y2="132.842" width="0.6096" layer="16"/>
<wire x1="-18.161" y1="135.89" x2="-20.574" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-20.574" y1="135.89" x2="-20.701" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-20.701" y1="132.842" x2="-20.701" y2="135.763" width="0.6096" layer="16"/>
<wire x1="-20.701" y1="135.763" x2="-20.574" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-20.701" y1="135.89" x2="-22.479" y2="137.668" width="0.6096" layer="16"/>
<wire x1="-18.288" y1="108.077" x2="-12.319" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="108.077" x2="-11.557" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-11.557" y1="108.077" x2="-10.287" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-10.287" y1="108.077" x2="-7.874" y2="110.49" width="0.6096" layer="16"/>
<wire x1="-11.557" y1="106.807" x2="-11.557" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="110.236" x2="-12.319" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-27.813" y1="54.356" x2="-25.781" y2="54.356" width="0.6096" layer="16"/>
<wire x1="-25.781" y1="54.356" x2="-23.495" y2="56.642" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="56.642" x2="-23.495" y2="57.658" width="0.6096" layer="16"/>
<wire x1="27.813" y1="54.356" x2="25.781" y2="54.356" width="0.6096" layer="16"/>
<wire x1="25.781" y1="54.356" x2="23.495" y2="56.642" width="0.6096" layer="16"/>
<wire x1="23.495" y1="56.642" x2="23.495" y2="57.658" width="0.6096" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="R3" pad="1"/>
<contactref element="OA2" pad="6"/>
<contactref element="R11" pad="1"/>
<contactref element="C10" pad="1"/>
<wire x1="3.429" y1="110.236" x2="3.429" y2="108.077" width="0.6096" layer="16"/>
<wire x1="7.112" y1="106.807" x2="4.699" y2="106.807" width="0.6096" layer="16"/>
<wire x1="4.699" y1="106.807" x2="3.429" y2="108.077" width="0.6096" layer="16"/>
<wire x1="8.763" y1="105.156" x2="7.112" y2="106.807" width="0.6096" layer="16"/>
<wire x1="8.763" y1="105.156" x2="8.763" y2="91.821" width="0.6096" layer="16"/>
<wire x1="8.763" y1="91.821" x2="12.954" y2="87.63" width="0.6096" layer="16"/>
<wire x1="12.954" y1="75.946" x2="12.954" y2="87.63" width="0.6096" layer="16"/>
<wire x1="18.034" y1="70.866" x2="18.034" y2="71.755" width="0.6096" layer="16"/>
<wire x1="18.034" y1="71.755" x2="17.399" y2="72.39" width="0.6096" layer="16"/>
<wire x1="17.399" y1="72.39" x2="16.51" y2="72.39" width="0.6096" layer="16"/>
<wire x1="16.51" y1="72.39" x2="12.954" y2="75.946" width="0.6096" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="OA2" pad="2"/>
<contactref element="C10" pad="2"/>
<contactref element="R11" pad="2"/>
<contactref element="R12" pad="1"/>
<wire x1="4.699" y1="101.727" x2="3.429" y2="100.457" width="0.6096" layer="16"/>
<wire x1="7.112" y1="98.298" x2="7.112" y2="101.727" width="0.6096" layer="16"/>
<wire x1="7.112" y1="101.727" x2="7.112" y2="104.267" width="0.6096" layer="16"/>
<wire x1="20.574" y1="78.486" x2="20.574" y2="77.597" width="0.6096" layer="1"/>
<wire x1="20.574" y1="77.597" x2="19.939" y2="76.962" width="0.6096" layer="1"/>
<wire x1="19.939" y1="76.962" x2="10.922" y2="76.962" width="0.6096" layer="1"/>
<wire x1="10.922" y1="76.962" x2="7.112" y2="80.772" width="0.6096" layer="1"/>
<wire x1="7.112" y1="80.772" x2="7.112" y2="85.217" width="0.6096" layer="1"/>
<wire x1="7.112" y1="85.217" x2="3.429" y2="88.9" width="0.6096" layer="1"/>
<wire x1="3.429" y1="88.9" x2="3.429" y2="100.457" width="0.6096" layer="1"/>
<wire x1="4.699" y1="101.727" x2="7.112" y2="101.727" width="0.6096" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="OA2" pad="3"/>
<contactref element="C12" pad="2"/>
<contactref element="R13" pad="2"/>
<wire x1="9.652" y1="85.217" x2="9.652" y2="83.693" width="0.6096" layer="16"/>
<wire x1="9.652" y1="83.693" x2="10.922" y2="82.423" width="0.6096" layer="16"/>
<wire x1="10.922" y1="82.423" x2="14.986" y2="82.423" width="0.6096" layer="1"/>
<wire x1="14.986" y1="82.423" x2="18.034" y2="79.375" width="0.6096" layer="1"/>
<wire x1="18.034" y1="79.375" x2="18.034" y2="78.486" width="0.6096" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="T2" pad="1"/>
<contactref element="C8" pad="1"/>
<contactref element="R8" pad="1"/>
<wire x1="5.969" y1="117.856" x2="5.969" y2="120.777" width="0.6096" layer="16"/>
<wire x1="5.969" y1="120.777" x2="5.969" y2="126.111" width="0.6096" layer="16"/>
<wire x1="5.969" y1="126.111" x2="6.477" y2="126.619" width="0.6096" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R8" pad="2"/>
<contactref element="C13" pad="1"/>
<contactref element="OA3" pad="6"/>
<wire x1="18.288" y1="90.678" x2="18.288" y2="91.567" width="0.6096" layer="16"/>
<wire x1="18.288" y1="91.567" x2="17.653" y2="92.202" width="0.6096" layer="16"/>
<wire x1="17.653" y1="92.202" x2="11.684" y2="92.202" width="0.6096" layer="16"/>
<wire x1="11.684" y1="92.202" x2="11.43" y2="91.948" width="0.6096" layer="16"/>
<wire x1="5.969" y1="110.236" x2="10.033" y2="106.172" width="0.6096" layer="16"/>
<wire x1="10.033" y1="106.172" x2="10.033" y2="93.345" width="0.6096" layer="16"/>
<wire x1="10.033" y1="93.345" x2="11.43" y2="91.948" width="0.6096" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="C8" pad="2"/>
<contactref element="R10" pad="1"/>
<contactref element="R9" pad="1"/>
<contactref element="C9" pad="1"/>
<wire x1="12.319" y1="117.856" x2="14.859" y2="117.856" width="0.6096" layer="16"/>
<wire x1="8.509" y1="120.777" x2="11.049" y2="120.777" width="0.6096" layer="16"/>
<wire x1="12.319" y1="117.856" x2="12.319" y2="119.507" width="0.6096" layer="16"/>
<wire x1="12.319" y1="119.507" x2="11.049" y2="120.777" width="0.6096" layer="16"/>
<wire x1="12.319" y1="117.856" x2="10.795" y2="117.856" width="0.6096" layer="16"/>
<wire x1="10.795" y1="117.856" x2="9.525" y2="116.586" width="0.6096" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R12" pad="2"/>
<contactref element="R10" pad="2"/>
<contactref element="R14" pad="2"/>
<contactref element="OA1" pad="6"/>
<contactref element="C9" pad="2"/>
<contactref element="R17" pad="1"/>
<wire x1="14.859" y1="112.141" x2="19.812" y2="112.141" width="0.6096" layer="16"/>
<wire x1="14.859" y1="110.236" x2="14.859" y2="112.141" width="0.6096" layer="16"/>
<wire x1="14.859" y1="112.141" x2="10.16" y2="112.141" width="0.6096" layer="16"/>
<wire x1="10.16" y1="112.141" x2="9.525" y2="111.506" width="0.6096" layer="16"/>
<wire x1="20.828" y1="110.236" x2="21.209" y2="110.236" width="0.6096" layer="16"/>
<wire x1="21.209" y1="110.236" x2="23.368" y2="108.077" width="0.6096" layer="16"/>
<wire x1="5.08" y1="107.061" x2="9.525" y2="111.506" width="0.6096" layer="1"/>
<wire x1="5.08" y1="107.061" x2="5.08" y2="92.71" width="0.6096" layer="1"/>
<wire x1="5.08" y1="92.71" x2="7.112" y2="90.678" width="0.6096" layer="1"/>
<wire x1="7.112" y1="90.678" x2="7.112" y2="82.677" width="0.6096" layer="16"/>
<wire x1="7.112" y1="82.677" x2="9.906" y2="79.883" width="0.6096" layer="16"/>
<wire x1="9.906" y1="79.883" x2="10.922" y2="79.883" width="0.6096" layer="16"/>
<wire x1="19.812" y1="112.141" x2="20.828" y2="111.125" width="0.6096" layer="16"/>
<wire x1="20.828" y1="111.125" x2="20.828" y2="110.236" width="0.6096" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="C13" pad="2"/>
<contactref element="R16" pad="2"/>
<contactref element="OA3" pad="2"/>
<wire x1="11.43" y1="97.028" x2="11.684" y2="96.774" width="0.6096" layer="1"/>
<wire x1="11.684" y1="96.774" x2="20.193" y2="96.774" width="0.6096" layer="1"/>
<wire x1="18.288" y1="100.457" x2="20.447" y2="98.298" width="0.6096" layer="1"/>
<wire x1="20.447" y1="98.298" x2="20.828" y2="98.298" width="0.6096" layer="1"/>
<wire x1="20.193" y1="96.774" x2="20.828" y2="97.409" width="0.6096" layer="1"/>
<wire x1="20.828" y1="97.409" x2="20.828" y2="98.298" width="0.6096" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="R14" pad="1"/>
<contactref element="R15" pad="2"/>
<contactref element="C14" pad="2"/>
<contactref element="OA3" pad="3"/>
<wire x1="20.828" y1="102.362" x2="22.479" y2="102.362" width="0.6096" layer="16"/>
<wire x1="22.479" y1="102.362" x2="23.368" y2="101.473" width="0.6096" layer="16"/>
<wire x1="23.368" y1="101.473" x2="23.368" y2="100.457" width="0.6096" layer="16"/>
<wire x1="20.828" y1="100.457" x2="20.828" y2="102.362" width="0.6096" layer="16"/>
<wire x1="20.828" y1="100.457" x2="18.669" y2="98.298" width="0.6096" layer="16"/>
<wire x1="18.669" y1="98.298" x2="18.288" y2="98.298" width="0.6096" layer="16"/>
<wire x1="11.557" y1="104.267" x2="11.557" y2="101.727" width="0.6096" layer="16"/>
<wire x1="20.828" y1="102.362" x2="13.081" y2="102.362" width="0.6096" layer="16"/>
<wire x1="13.081" y1="102.362" x2="12.446" y2="101.727" width="0.6096" layer="16"/>
<wire x1="12.446" y1="101.727" x2="11.557" y2="101.727" width="0.6096" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R17" pad="2"/>
<contactref element="OA4" pad="3"/>
<contactref element="C15A" pad="2"/>
<contactref element="C15B" pad="2"/>
<contactref element="C15C" pad="2"/>
<wire x1="12.446" y1="65.278" x2="12.446" y2="66.167" width="0.6096" layer="16"/>
<wire x1="12.446" y1="66.167" x2="10.541" y2="68.072" width="0.6096" layer="16"/>
<wire x1="5.969" y1="78.232" x2="4.318" y2="79.883" width="0.6096" layer="16"/>
<wire x1="4.318" y1="79.883" x2="3.302" y2="79.883" width="0.6096" layer="16"/>
<wire x1="8.509" y1="76.2" x2="5.969" y2="76.2" width="0.6096" layer="16"/>
<wire x1="8.509" y1="72.136" x2="5.969" y2="72.136" width="0.6096" layer="16"/>
<wire x1="5.969" y1="68.072" x2="10.541" y2="68.072" width="0.6096" layer="16"/>
<wire x1="5.969" y1="68.072" x2="5.969" y2="72.136" width="0.6096" layer="16"/>
<wire x1="5.969" y1="72.136" x2="5.969" y2="76.2" width="0.6096" layer="16"/>
<wire x1="5.969" y1="76.2" x2="5.969" y2="78.232" width="0.6096" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R18" pad="1"/>
<contactref element="C15A" pad="1"/>
<contactref element="C15C" pad="1"/>
<contactref element="C15B" pad="1"/>
<contactref element="C16" pad="2"/>
<wire x1="3.429" y1="65.278" x2="4.699" y2="64.008" width="0.6096" layer="16"/>
<wire x1="4.699" y1="64.008" x2="6.223" y2="64.008" width="0.6096" layer="16"/>
<wire x1="3.429" y1="65.278" x2="3.429" y2="68.072" width="0.6096" layer="16"/>
<wire x1="3.429" y1="68.072" x2="3.429" y2="72.136" width="0.6096" layer="16"/>
<wire x1="3.429" y1="72.136" x2="3.429" y2="76.2" width="0.6096" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="OA4" pad="6"/>
<contactref element="R22" pad="1"/>
<contactref element="R19" pad="2"/>
<wire x1="12.446" y1="55.372" x2="12.446" y2="57.658" width="0.6096" layer="16"/>
<wire x1="12.446" y1="55.372" x2="17.907" y2="55.372" width="0.6096" layer="16"/>
<wire x1="17.907" y1="55.372" x2="20.193" y2="57.658" width="0.6096" layer="16"/>
<wire x1="20.193" y1="57.658" x2="20.955" y2="57.658" width="0.6096" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="OA4" pad="2"/>
<contactref element="R20" pad="1"/>
<contactref element="R19" pad="1"/>
<contactref element="R21" pad="1"/>
<wire x1="20.955" y1="65.278" x2="20.955" y2="63.373" width="0.6096" layer="1"/>
<wire x1="25.908" y1="51.943" x2="25.908" y2="52.959" width="0.6096" layer="1"/>
<wire x1="25.908" y1="52.959" x2="22.86" y2="56.007" width="0.6096" layer="1"/>
<wire x1="22.86" y1="56.007" x2="18.542" y2="56.007" width="0.6096" layer="1"/>
<wire x1="18.542" y1="56.007" x2="16.129" y2="53.594" width="0.6096" layer="1"/>
<wire x1="16.129" y1="53.594" x2="11.049" y2="53.594" width="0.6096" layer="1"/>
<wire x1="11.049" y1="53.594" x2="8.128" y2="56.515" width="0.6096" layer="1"/>
<wire x1="8.128" y1="56.515" x2="8.128" y2="62.484" width="0.6096" layer="1"/>
<wire x1="9.017" y1="63.373" x2="14.986" y2="63.373" width="0.6096" layer="1"/>
<wire x1="14.986" y1="63.373" x2="20.955" y2="63.373" width="0.6096" layer="1"/>
<wire x1="8.128" y1="62.484" x2="9.017" y2="63.373" width="0.6096" layer="1"/>
<wire x1="20.955" y1="63.373" x2="22.606" y2="63.373" width="0.6096" layer="1"/>
<wire x1="22.606" y1="63.373" x2="23.495" y2="64.262" width="0.6096" layer="1"/>
<wire x1="23.495" y1="64.262" x2="23.495" y2="65.278" width="0.6096" layer="1"/>
<wire x1="14.986" y1="65.278" x2="14.986" y2="63.373" width="0.6096" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="R22" pad="2"/>
<contactref element="C17C" pad="2"/>
<contactref element="C17A" pad="2"/>
<contactref element="C17B" pad="2"/>
<contactref element="OA5" pad="3"/>
<wire x1="5.969" y1="44.323" x2="8.509" y2="44.323" width="0.6096" layer="16"/>
<wire x1="5.969" y1="48.387" x2="8.509" y2="48.387" width="0.6096" layer="16"/>
<wire x1="8.509" y1="48.387" x2="8.509" y2="44.323" width="0.6096" layer="16"/>
<wire x1="5.969" y1="52.451" x2="8.509" y2="52.451" width="0.6096" layer="16"/>
<wire x1="8.509" y1="52.451" x2="8.509" y2="48.387" width="0.6096" layer="16"/>
<wire x1="15.24" y1="51.943" x2="15.24" y2="52.832" width="0.6096" layer="16"/>
<wire x1="15.24" y1="52.832" x2="14.478" y2="53.594" width="0.6096" layer="16"/>
<wire x1="14.478" y1="53.594" x2="9.652" y2="53.594" width="0.6096" layer="16"/>
<wire x1="9.652" y1="53.594" x2="8.509" y2="52.451" width="0.6096" layer="16"/>
<wire x1="5.969" y1="52.451" x2="5.969" y2="54.229" width="0.6096" layer="16"/>
<wire x1="5.969" y1="54.229" x2="4.826" y2="55.372" width="0.6096" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="OA5" pad="2"/>
<contactref element="R23" pad="1"/>
<contactref element="R24" pad="1"/>
<wire x1="17.78" y1="51.943" x2="20.193" y2="54.356" width="0.6096" layer="16"/>
<wire x1="23.368" y1="51.943" x2="20.955" y2="54.356" width="0.6096" layer="16"/>
<wire x1="20.955" y1="54.356" x2="20.193" y2="54.356" width="0.6096" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="OA5" pad="6"/>
<contactref element="R24" pad="2"/>
<contactref element="R25" pad="1"/>
<contactref element="R26" pad="2"/>
<wire x1="23.368" y1="44.323" x2="23.368" y2="45.339" width="0.6096" layer="16"/>
<wire x1="23.368" y1="45.339" x2="22.479" y2="46.228" width="0.6096" layer="16"/>
<wire x1="22.479" y1="46.228" x2="16.256" y2="46.228" width="0.6096" layer="16"/>
<wire x1="16.256" y1="46.228" x2="15.24" y2="45.212" width="0.6096" layer="16"/>
<wire x1="15.24" y1="45.212" x2="15.24" y2="44.323" width="0.6096" layer="16"/>
<wire x1="22.86" y1="36.195" x2="22.86" y2="38.735" width="0.6096" layer="16"/>
<wire x1="23.368" y1="44.323" x2="23.368" y2="40.259" width="0.6096" layer="16"/>
<wire x1="23.368" y1="40.259" x2="22.86" y2="39.751" width="0.6096" layer="16"/>
<wire x1="22.86" y1="39.751" x2="22.86" y2="38.735" width="0.6096" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="OA6" pad="6"/>
<contactref element="R21" pad="2"/>
<contactref element="C20" pad="1"/>
<wire x1="18.669" y1="24.765" x2="18.669" y2="25.654" width="0.6096" layer="16"/>
<wire x1="18.669" y1="25.654" x2="19.431" y2="26.416" width="0.6096" layer="16"/>
<wire x1="27.305" y1="26.035" x2="28.829" y2="27.559" width="0.6096" layer="1"/>
<wire x1="28.829" y1="27.559" x2="28.829" y2="40.386" width="0.6096" layer="1"/>
<wire x1="28.829" y1="40.386" x2="25.908" y2="43.307" width="0.6096" layer="1"/>
<wire x1="25.908" y1="43.307" x2="25.908" y2="44.323" width="0.6096" layer="1"/>
<wire x1="19.431" y1="26.416" x2="26.035" y2="26.416" width="0.6096" layer="16"/>
<wire x1="26.035" y1="26.416" x2="26.416" y2="26.035" width="0.6096" layer="16"/>
<wire x1="26.416" y1="26.035" x2="27.305" y2="26.035" width="0.6096" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="OA6" pad="3"/>
<contactref element="R26" pad="1"/>
<contactref element="C19" pad="1"/>
<wire x1="18.669" y1="36.322" x2="16.256" y2="38.735" width="0.6096" layer="16"/>
<wire x1="16.256" y1="38.735" x2="15.24" y2="38.735" width="0.6096" layer="16"/>
<wire x1="15.24" y1="38.735" x2="14.224" y2="38.735" width="0.6096" layer="16"/>
<wire x1="14.224" y1="38.735" x2="12.7" y2="40.259" width="0.6096" layer="16"/>
<wire x1="12.7" y1="40.259" x2="8.509" y2="40.259" width="0.6096" layer="16"/>
<wire x1="18.669" y1="32.385" x2="18.669" y2="36.322" width="0.6096" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="OA6" pad="2"/>
<contactref element="R27" pad="1"/>
<contactref element="C20" pad="2"/>
<wire x1="9.906" y1="37.084" x2="10.922" y2="37.084" width="0.6096" layer="1"/>
<wire x1="10.922" y1="37.084" x2="13.97" y2="34.036" width="0.6096" layer="1"/>
<wire x1="13.97" y1="34.036" x2="21.209" y2="34.036" width="0.6096" layer="1"/>
<wire x1="21.209" y1="34.036" x2="25.273" y2="34.036" width="0.6096" layer="1"/>
<wire x1="25.273" y1="34.036" x2="27.305" y2="32.004" width="0.6096" layer="1"/>
<wire x1="27.305" y1="32.004" x2="27.305" y2="31.115" width="0.6096" layer="1"/>
<wire x1="21.209" y1="32.385" x2="21.209" y2="34.036" width="0.6096" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="C11" pad="2"/>
<contactref element="OA2" pad="8"/>
<wire x1="23.114" y1="70.866" x2="23.114" y2="69.342" width="0.6096" layer="16"/>
<wire x1="23.114" y1="69.342" x2="21.844" y2="68.072" width="0.6096" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="OA2" pad="5"/>
<contactref element="C11" pad="1"/>
<wire x1="15.494" y1="70.866" x2="15.494" y2="69.342" width="0.6096" layer="16"/>
<wire x1="15.494" y1="69.342" x2="16.764" y2="68.072" width="0.6096" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="OA5" pad="8"/>
<contactref element="C18" pad="1"/>
<wire x1="20.32" y1="44.323" x2="20.32" y2="42.799" width="0.6096" layer="16"/>
<wire x1="20.32" y1="42.799" x2="19.05" y2="41.529" width="0.6096" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="OA5" pad="5"/>
<contactref element="C18" pad="2"/>
<wire x1="12.7" y1="44.323" x2="12.7" y2="42.799" width="0.6096" layer="16"/>
<wire x1="12.7" y1="42.799" x2="13.97" y2="41.529" width="0.6096" layer="16"/>
</signal>
<signal name="+18V">
<contactref element="R207" pad="1"/>
<contactref element="R206" pad="1"/>
<contactref element="OA201" pad="7"/>
<contactref element="OA204" pad="7"/>
<contactref element="OA205" pad="7"/>
<contactref element="OA203" pad="7"/>
<contactref element="OA206" pad="7"/>
<contactref element="OA202" pad="7"/>
<contactref element="C221" pad="2"/>
<contactref element="C222" pad="2"/>
<contactref element="C223" pad="2"/>
<contactref element="C224" pad="+"/>
<contactref element="T203" pad="E"/>
<wire x1="-23.495" y1="129.159" x2="-22.987" y2="128.651" width="0.6096" layer="16"/>
<wire x1="-22.987" y1="128.651" x2="-22.987" y2="127.635" width="0.6096" layer="16"/>
<wire x1="-25.527" y1="127.635" x2="-29.337" y2="127.635" width="1.016" layer="1"/>
<wire x1="-29.337" y1="127.635" x2="-30.353" y2="126.619" width="1.016" layer="1"/>
<wire x1="-30.353" y1="126.619" x2="-30.353" y2="111.76" width="1.016" layer="1"/>
<wire x1="-30.353" y1="111.76" x2="-30.353" y2="92.202" width="1.016" layer="1"/>
<wire x1="-30.353" y1="60.706" x2="-30.353" y2="59.563" width="1.016" layer="1"/>
<wire x1="-30.353" y1="59.563" x2="-30.353" y2="46.228" width="1.016" layer="1"/>
<wire x1="-30.353" y1="46.228" x2="-30.353" y2="22.733" width="1.016" layer="1"/>
<wire x1="-30.353" y1="22.733" x2="-30.353" y2="2.54" width="1.016" layer="1"/>
<wire x1="-20.828" y1="110.236" x2="-20.828" y2="111.125" width="0.6096" layer="1"/>
<wire x1="-20.828" y1="111.125" x2="-21.463" y2="111.76" width="0.6096" layer="1"/>
<wire x1="-21.463" y1="111.76" x2="-30.353" y2="111.76" width="0.6096" layer="1"/>
<wire x1="-18.288" y1="90.678" x2="-18.288" y2="91.567" width="0.6096" layer="1"/>
<wire x1="-18.288" y1="91.567" x2="-18.923" y2="92.202" width="0.6096" layer="1"/>
<wire x1="-18.923" y1="92.202" x2="-30.353" y2="92.202" width="0.6096" layer="1"/>
<wire x1="-18.034" y1="70.866" x2="-18.034" y2="71.755" width="0.6096" layer="1"/>
<wire x1="-18.034" y1="71.755" x2="-18.669" y2="72.39" width="0.6096" layer="1"/>
<wire x1="-12.446" y1="57.658" x2="-12.446" y2="58.547" width="0.6096" layer="1"/>
<wire x1="-15.24" y1="44.323" x2="-15.24" y2="45.212" width="0.6096" layer="1"/>
<wire x1="-15.24" y1="45.212" x2="-16.256" y2="46.228" width="0.6096" layer="1"/>
<wire x1="-16.256" y1="46.228" x2="-30.353" y2="46.228" width="0.6096" layer="1"/>
<wire x1="-18.669" y1="22.733" x2="-10.033" y2="22.733" width="1.016" layer="1"/>
<wire x1="-18.669" y1="24.765" x2="-18.669" y2="22.733" width="1.016" layer="1"/>
<wire x1="-24.892" y1="3.175" x2="-25.654" y2="2.413" width="1.016" layer="1"/>
<wire x1="-30.353" y1="2.54" x2="-29.083" y2="1.27" width="1.016" layer="1"/>
<wire x1="-29.083" y1="1.27" x2="-25.654" y2="1.27" width="1.016" layer="1"/>
<wire x1="-25.654" y1="2.413" x2="-25.654" y2="1.27" width="1.016" layer="1"/>
<wire x1="-18.669" y1="22.733" x2="-30.353" y2="22.733" width="1.016" layer="1"/>
<wire x1="-25.527" y1="65.532" x2="-30.353" y2="60.706" width="1.016" layer="1"/>
<wire x1="-25.527" y1="70.485" x2="-26.924" y2="71.882" width="1.016" layer="1"/>
<wire x1="-26.924" y1="71.882" x2="-30.353" y2="75.311" width="1.016" layer="1"/>
<wire x1="-30.353" y1="92.202" x2="-30.353" y2="75.311" width="1.016" layer="1"/>
<wire x1="-18.669" y1="72.39" x2="-26.416" y2="72.39" width="0.6096" layer="1"/>
<wire x1="-12.446" y1="58.547" x2="-13.462" y2="59.563" width="0.6096" layer="1"/>
<wire x1="-13.462" y1="59.563" x2="-30.353" y2="59.563" width="0.6096" layer="1"/>
<wire x1="-24.892" y1="3.175" x2="-7.239" y2="3.175" width="1.016" layer="1"/>
<wire x1="-7.239" y1="3.175" x2="-6.096" y2="2.032" width="1.016" layer="1"/>
<wire x1="-10.033" y1="22.733" x2="-9.652" y2="23.114" width="1.016" layer="1"/>
<wire x1="-9.652" y1="23.114" x2="-5.969" y2="23.114" width="1.016" layer="1"/>
<wire x1="-25.527" y1="127.635" x2="-22.987" y2="127.635" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="129.159" x2="-23.495" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="135.89" x2="-26.035" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-24.892" y1="142.748" x2="-24.892" y2="137.922" width="0.6096" layer="16"/>
<wire x1="-24.892" y1="137.922" x2="-23.495" y2="136.525" width="0.6096" layer="16"/>
<wire x1="-23.495" y1="136.525" x2="-23.495" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-26.416" y1="72.39" x2="-26.924" y2="71.882" width="0.6096" layer="1"/>
<wire x1="-25.527" y1="65.532" x2="-25.527" y2="70.485" width="1.016" layer="1"/>
</signal>
<signal name="-18V">
<contactref element="R204" pad="1"/>
<contactref element="OA202" pad="4"/>
<contactref element="OA201" pad="4"/>
<contactref element="OA204" pad="4"/>
<contactref element="OA205" pad="4"/>
<contactref element="OA203" pad="4"/>
<contactref element="OA206" pad="4"/>
<contactref element="R228" pad="2"/>
<contactref element="C226" pad="2"/>
<contactref element="C227" pad="2"/>
<contactref element="C228" pad="+"/>
<contactref element="C221" pad="1"/>
<contactref element="T204" pad="E"/>
<wire x1="-30.353" y1="137.795" x2="-30.353" y2="135.89" width="1.016" layer="16"/>
<wire x1="-30.353" y1="135.89" x2="-30.353" y2="130.302" width="1.016" layer="16"/>
<wire x1="-30.353" y1="130.302" x2="-30.353" y2="116.332" width="1.016" layer="16"/>
<wire x1="-30.353" y1="116.332" x2="-30.353" y2="96.774" width="1.016" layer="16"/>
<wire x1="-30.353" y1="96.774" x2="-30.353" y2="76.962" width="1.016" layer="16"/>
<wire x1="-28.575" y1="135.89" x2="-30.353" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-28.575" y1="130.302" x2="-30.353" y2="130.302" width="0.6096" layer="16"/>
<wire x1="-23.114" y1="78.486" x2="-23.114" y2="77.597" width="0.6096" layer="16"/>
<wire x1="-23.114" y1="77.597" x2="-23.749" y2="76.962" width="0.6096" layer="16"/>
<wire x1="-23.749" y1="76.962" x2="-30.353" y2="76.962" width="0.6096" layer="16"/>
<wire x1="-17.526" y1="65.278" x2="-17.526" y2="64.389" width="0.6096" layer="16"/>
<wire x1="-17.526" y1="64.389" x2="-18.542" y2="63.373" width="0.6096" layer="16"/>
<wire x1="-30.353" y1="50.038" x2="-30.353" y2="29.464" width="1.016" layer="16"/>
<wire x1="-30.353" y1="29.464" x2="-30.353" y2="22.352" width="1.016" layer="16"/>
<wire x1="-20.32" y1="51.943" x2="-20.32" y2="51.054" width="0.6096" layer="16"/>
<wire x1="-20.32" y1="51.054" x2="-21.336" y2="50.038" width="0.6096" layer="16"/>
<wire x1="-21.336" y1="50.038" x2="-30.353" y2="50.038" width="0.6096" layer="16"/>
<wire x1="-30.353" y1="29.464" x2="-23.749" y2="29.464" width="0.6096" layer="16"/>
<wire x1="-23.749" y1="32.385" x2="-23.749" y2="29.464" width="0.6096" layer="16"/>
<wire x1="-9.017" y1="27.305" x2="-10.668" y2="28.956" width="0.6096" layer="16"/>
<wire x1="-10.668" y1="28.956" x2="-23.241" y2="28.956" width="0.6096" layer="16"/>
<wire x1="-23.241" y1="28.956" x2="-23.749" y2="29.464" width="0.6096" layer="16"/>
<wire x1="-30.353" y1="22.352" x2="-28.829" y2="20.828" width="1.016" layer="16"/>
<wire x1="-28.829" y1="20.828" x2="-25.654" y2="20.828" width="1.016" layer="16"/>
<wire x1="-10.541" y1="21.59" x2="-11.684" y2="22.733" width="1.016" layer="16"/>
<wire x1="-11.684" y1="22.733" x2="-24.892" y2="22.733" width="1.016" layer="16"/>
<wire x1="-24.892" y1="22.733" x2="-25.654" y2="21.971" width="1.016" layer="16"/>
<wire x1="-25.654" y1="21.971" x2="-25.654" y2="20.828" width="1.016" layer="16"/>
<wire x1="-30.353" y1="50.038" x2="-30.353" y2="60.706" width="1.016" layer="16"/>
<wire x1="-30.353" y1="60.706" x2="-27.178" y2="63.881" width="1.016" layer="16"/>
<wire x1="-27.178" y1="63.881" x2="-25.527" y2="65.532" width="1.016" layer="16"/>
<wire x1="-26.035" y1="70.993" x2="-26.289" y2="71.247" width="1.016" layer="16"/>
<wire x1="-26.289" y1="71.247" x2="-30.353" y2="75.311" width="1.016" layer="16"/>
<wire x1="-30.353" y1="75.311" x2="-30.353" y2="76.962" width="1.016" layer="16"/>
<wire x1="-18.542" y1="63.373" x2="-26.67" y2="63.373" width="0.6096" layer="16"/>
<wire x1="-23.368" y1="98.298" x2="-23.368" y2="97.409" width="0.6096" layer="16"/>
<wire x1="-23.368" y1="97.409" x2="-24.003" y2="96.774" width="0.6096" layer="16"/>
<wire x1="-24.003" y1="96.774" x2="-30.353" y2="96.774" width="0.6096" layer="16"/>
<wire x1="-25.908" y1="117.856" x2="-25.908" y2="116.967" width="0.6096" layer="16"/>
<wire x1="-25.908" y1="116.967" x2="-26.543" y2="116.332" width="0.6096" layer="16"/>
<wire x1="-26.543" y1="116.332" x2="-30.353" y2="116.332" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="19.558" x2="-10.541" y2="19.558" width="1.016" layer="16"/>
<wire x1="-10.541" y1="21.59" x2="-10.541" y2="19.558" width="1.016" layer="16"/>
<wire x1="-10.541" y1="19.558" x2="-10.541" y2="18.923" width="1.016" layer="16"/>
<wire x1="-10.541" y1="18.923" x2="-6.096" y2="14.478" width="1.016" layer="16"/>
<wire x1="-6.096" y1="14.478" x2="-6.096" y2="13.208" width="1.016" layer="16"/>
<wire x1="-30.353" y1="137.795" x2="-27.94" y2="140.208" width="1.016" layer="16"/>
<wire x1="-27.94" y1="140.208" x2="-27.94" y2="142.748" width="1.016" layer="16"/>
<wire x1="-26.67" y1="63.373" x2="-27.178" y2="63.881" width="0.6096" layer="16"/>
<wire x1="-25.527" y1="65.532" x2="-25.527" y2="70.485" width="1.016" layer="16"/>
<wire x1="-25.527" y1="70.485" x2="-26.035" y2="70.993" width="1.016" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="R28" pad="3"/>
<contactref element="OA6" pad="1"/>
<wire x1="11.557" y1="27.305" x2="19.558" y2="27.305" width="0.6096" layer="1"/>
<wire x1="19.558" y1="27.305" x2="23.749" y2="31.496" width="0.6096" layer="1"/>
<wire x1="23.749" y1="31.496" x2="23.749" y2="32.385" width="0.6096" layer="1"/>
</signal>
<signal name="N$37">
<contactref element="OA6" pad="5"/>
<contactref element="R28" pad="1"/>
<wire x1="16.129" y1="24.765" x2="8.255" y2="24.765" width="0.6096" layer="16"/>
<wire x1="8.255" y1="24.765" x2="6.477" y2="26.543" width="0.6096" layer="16"/>
<wire x1="6.477" y1="26.543" x2="6.477" y2="27.305" width="0.6096" layer="16"/>
</signal>
<signal name="N$38">
<contactref element="R25" pad="2"/>
<contactref element="R_OUT" pad="1"/>
<wire x1="15.24" y1="36.195" x2="12.7" y2="36.195" width="0.6096" layer="16"/>
<wire x1="12.7" y1="36.195" x2="9.906" y2="33.401" width="0.6096" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R201" pad="1"/>
<contactref element="SW2" pad="8"/>
<contactref element="SW2" pad="7"/>
<contactref element="SW2" pad="6"/>
<contactref element="SW2" pad="5"/>
<contactref element="L201" pad="1"/>
<contactref element="L_IN" pad="1"/>
<wire x1="-19.939" y1="138.938" x2="-17.399" y2="138.938" width="0.6096" layer="16"/>
<wire x1="-17.399" y1="138.938" x2="-14.859" y2="138.938" width="0.6096" layer="16"/>
<wire x1="-14.859" y1="138.938" x2="-12.319" y2="138.938" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="150.368" x2="-7.112" y2="138.938" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="138.938" x2="-7.112" y2="138.938" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="138.938" x2="-7.112" y2="137.033" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="137.033" x2="-5.969" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="135.89" x2="-3.429" y2="135.89" width="0.6096" layer="16"/>
</signal>
<signal name="N$39">
<contactref element="R201" pad="2"/>
<contactref element="L201" pad="2"/>
<contactref element="T201" pad="1"/>
<contactref element="R202" pad="2"/>
<contactref element="R203" pad="2"/>
<contactref element="C206" pad="1"/>
<wire x1="-15.621" y1="135.89" x2="-13.589" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="128.27" x2="-3.556" y2="129.159" width="0.6096" layer="16"/>
<wire x1="-3.556" y1="129.159" x2="-5.969" y2="130.81" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="130.81" x2="-5.969" y2="132.842" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="117.856" x2="-3.429" y2="128.27" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="132.842" x2="-8.382" y2="132.842" width="0.6096" layer="16"/>
<wire x1="-8.382" y1="132.842" x2="-11.43" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-11.43" y1="135.89" x2="-13.589" y2="135.89" width="0.6096" layer="16"/>
<wire x1="-7.747" y1="126.619" x2="-8.509" y2="126.619" width="0.6096" layer="1"/>
<wire x1="-8.509" y1="126.619" x2="-8.89" y2="127" width="0.6096" layer="1"/>
<wire x1="-8.89" y1="127" x2="-8.89" y2="129.921" width="0.6096" layer="1"/>
<wire x1="-8.89" y1="129.921" x2="-5.969" y2="132.842" width="0.6096" layer="1"/>
</signal>
<signal name="N$46">
<contactref element="R202" pad="1"/>
<contactref element="C205" pad="1"/>
<wire x1="-15.621" y1="132.842" x2="-13.589" y2="132.842" width="0.6096" layer="16"/>
</signal>
<signal name="N$47">
<contactref element="T201" pad="2"/>
<contactref element="T202" pad="2"/>
<contactref element="R204" pad="2"/>
<wire x1="-6.477" y1="127.889" x2="-11.938" y2="127.889" width="0.6096" layer="16"/>
<wire x1="-20.955" y1="130.302" x2="-15.24" y2="130.302" width="0.6096" layer="16"/>
<wire x1="-15.24" y1="130.302" x2="-12.827" y2="127.889" width="0.6096" layer="16"/>
<wire x1="-12.827" y1="127.889" x2="-11.938" y2="127.889" width="0.6096" layer="16"/>
</signal>
<signal name="N$48">
<contactref element="OA201" pad="2"/>
<contactref element="T201" pad="3"/>
<contactref element="R205" pad="1"/>
<contactref element="R206" pad="2"/>
<wire x1="-22.987" y1="120.015" x2="-20.447" y2="120.015" width="0.6096" layer="16"/>
<wire x1="-20.828" y1="117.856" x2="-20.828" y2="119.634" width="0.6096" layer="16"/>
<wire x1="-20.828" y1="119.634" x2="-20.447" y2="120.015" width="0.6096" layer="16"/>
<wire x1="-20.447" y1="120.015" x2="-19.558" y2="120.015" width="0.6096" layer="16"/>
<wire x1="-19.558" y1="120.015" x2="-19.05" y2="119.507" width="0.6096" layer="16"/>
<wire x1="-19.05" y1="119.507" x2="-15.494" y2="119.507" width="0.6096" layer="16"/>
<wire x1="-15.494" y1="119.507" x2="-11.938" y2="123.063" width="0.6096" layer="16"/>
<wire x1="-11.938" y1="123.063" x2="-8.763" y2="123.063" width="0.6096" layer="16"/>
<wire x1="-8.763" y1="123.063" x2="-6.477" y2="125.349" width="0.6096" layer="16"/>
</signal>
<signal name="N$49">
<contactref element="OA201" pad="3"/>
<contactref element="T202" pad="3"/>
<contactref element="R207" pad="2"/>
<contactref element="C207" pad="2"/>
<wire x1="-23.368" y1="117.856" x2="-25.527" y2="120.015" width="0.6096" layer="16"/>
<wire x1="-25.527" y1="120.015" x2="-25.527" y2="121.031" width="0.6096" layer="16"/>
<wire x1="-11.938" y1="125.349" x2="-14.478" y2="122.809" width="0.6096" layer="16"/>
<wire x1="-14.478" y1="122.809" x2="-17.526" y2="122.809" width="0.6096" layer="16"/>
<wire x1="-17.526" y1="122.809" x2="-23.749" y2="122.809" width="0.6096" layer="16"/>
<wire x1="-23.749" y1="122.809" x2="-25.527" y2="121.031" width="0.6096" layer="16"/>
<wire x1="-17.526" y1="121.285" x2="-17.526" y2="122.809" width="0.6096" layer="16"/>
</signal>
<signal name="N$50">
<contactref element="R205" pad="2"/>
<contactref element="C207" pad="1"/>
<wire x1="-20.447" y1="127.635" x2="-18.796" y2="127.635" width="0.6096" layer="16"/>
<wire x1="-18.796" y1="127.635" x2="-17.526" y2="126.365" width="0.6096" layer="16"/>
</signal>
<signal name="N$51">
<contactref element="R203" pad="1"/>
<contactref element="OA202" pad="6"/>
<contactref element="R211" pad="1"/>
<contactref element="C210" pad="1"/>
<wire x1="-3.429" y1="110.236" x2="-3.429" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="106.807" x2="-4.699" y2="106.807" width="0.6096" layer="16"/>
<wire x1="-4.699" y1="106.807" x2="-3.429" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-8.763" y1="105.156" x2="-7.112" y2="106.807" width="0.6096" layer="16"/>
<wire x1="-8.763" y1="105.156" x2="-8.763" y2="91.948" width="0.6096" layer="16"/>
<wire x1="-8.763" y1="91.948" x2="-12.954" y2="87.757" width="0.6096" layer="16"/>
<wire x1="-19.939" y1="72.39" x2="-16.51" y2="72.39" width="0.6096" layer="16"/>
<wire x1="-16.51" y1="72.39" x2="-12.954" y2="75.946" width="0.6096" layer="16"/>
<wire x1="-12.954" y1="75.946" x2="-12.954" y2="87.757" width="0.6096" layer="16"/>
<wire x1="-19.939" y1="72.39" x2="-20.574" y2="71.755" width="0.6096" layer="16"/>
<wire x1="-20.574" y1="71.755" x2="-20.574" y2="70.866" width="0.6096" layer="16"/>
</signal>
<signal name="N$52">
<contactref element="OA202" pad="2"/>
<contactref element="C210" pad="2"/>
<contactref element="R211" pad="2"/>
<contactref element="R212" pad="1"/>
<wire x1="-4.699" y1="101.727" x2="-3.429" y2="100.457" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="98.298" x2="-7.112" y2="101.727" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="101.727" x2="-7.112" y2="104.267" width="0.6096" layer="16"/>
<wire x1="-17.399" y1="76.962" x2="-10.922" y2="76.962" width="0.6096" layer="1"/>
<wire x1="-10.922" y1="76.962" x2="-7.112" y2="80.772" width="0.6096" layer="1"/>
<wire x1="-7.112" y1="80.772" x2="-7.112" y2="85.217" width="0.6096" layer="1"/>
<wire x1="-7.112" y1="85.217" x2="-3.429" y2="88.9" width="0.6096" layer="1"/>
<wire x1="-3.429" y1="88.9" x2="-3.429" y2="100.457" width="0.6096" layer="1"/>
<wire x1="-17.399" y1="76.962" x2="-18.034" y2="77.597" width="0.6096" layer="1"/>
<wire x1="-18.034" y1="77.597" x2="-18.034" y2="78.486" width="0.6096" layer="1"/>
<wire x1="-4.699" y1="101.727" x2="-7.112" y2="101.727" width="0.6096" layer="16"/>
</signal>
<signal name="N$53">
<contactref element="OA202" pad="3"/>
<contactref element="C212" pad="2"/>
<contactref element="R213" pad="2"/>
<wire x1="-9.652" y1="85.217" x2="-9.652" y2="83.693" width="0.6096" layer="16"/>
<wire x1="-9.652" y1="83.693" x2="-10.922" y2="82.423" width="0.6096" layer="16"/>
<wire x1="-10.922" y1="82.423" x2="-17.526" y2="82.423" width="0.6096" layer="1"/>
<wire x1="-17.526" y1="82.423" x2="-20.574" y2="79.375" width="0.6096" layer="1"/>
<wire x1="-20.574" y1="79.375" x2="-20.574" y2="78.486" width="0.6096" layer="1"/>
</signal>
<signal name="N$54">
<contactref element="T202" pad="1"/>
<contactref element="C208" pad="1"/>
<contactref element="R208" pad="1"/>
<wire x1="-5.969" y1="117.856" x2="-5.969" y2="120.777" width="0.6096" layer="16"/>
<wire x1="-13.208" y1="126.619" x2="-13.97" y2="126.619" width="0.6096" layer="1"/>
<wire x1="-13.97" y1="126.619" x2="-14.224" y2="126.365" width="0.6096" layer="1"/>
<wire x1="-14.224" y1="126.365" x2="-14.224" y2="123.698" width="0.6096" layer="1"/>
<wire x1="-14.224" y1="123.698" x2="-13.589" y2="123.063" width="0.6096" layer="1"/>
<wire x1="-13.589" y1="123.063" x2="-7.366" y2="123.063" width="0.6096" layer="1"/>
<wire x1="-7.366" y1="123.063" x2="-5.969" y2="121.666" width="0.6096" layer="1"/>
<wire x1="-5.969" y1="121.666" x2="-5.969" y2="120.777" width="0.6096" layer="1"/>
</signal>
<signal name="N$55">
<contactref element="R208" pad="2"/>
<contactref element="C213" pad="1"/>
<contactref element="OA203" pad="6"/>
<wire x1="-20.828" y1="90.678" x2="-20.828" y2="91.567" width="0.6096" layer="16"/>
<wire x1="-20.828" y1="91.567" x2="-20.193" y2="92.202" width="0.6096" layer="16"/>
<wire x1="-20.193" y1="92.202" x2="-11.811" y2="92.202" width="0.6096" layer="16"/>
<wire x1="-11.811" y1="92.202" x2="-11.557" y2="91.948" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="110.236" x2="-10.033" y2="106.172" width="0.6096" layer="16"/>
<wire x1="-10.033" y1="106.172" x2="-10.033" y2="93.472" width="0.6096" layer="16"/>
<wire x1="-10.033" y1="93.472" x2="-11.557" y2="91.948" width="0.6096" layer="16"/>
</signal>
<signal name="N$56">
<contactref element="C208" pad="2"/>
<contactref element="R210" pad="1"/>
<contactref element="R209" pad="1"/>
<contactref element="C209" pad="1"/>
<wire x1="-14.859" y1="117.856" x2="-12.319" y2="117.856" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="120.777" x2="-11.049" y2="120.777" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="117.856" x2="-12.319" y2="119.507" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="119.507" x2="-11.049" y2="120.777" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="117.856" x2="-10.795" y2="117.856" width="0.6096" layer="16"/>
<wire x1="-10.795" y1="117.856" x2="-9.525" y2="116.586" width="0.6096" layer="16"/>
</signal>
<signal name="N$57">
<contactref element="R212" pad="2"/>
<contactref element="R210" pad="2"/>
<contactref element="R214" pad="2"/>
<contactref element="OA201" pad="6"/>
<contactref element="C209" pad="2"/>
<contactref element="R217" pad="1"/>
<wire x1="-23.114" y1="110.236" x2="-23.368" y2="110.236" width="0.6096" layer="16"/>
<wire x1="-9.525" y1="111.506" x2="-10.16" y2="112.141" width="0.6096" layer="16"/>
<wire x1="-10.16" y1="112.141" x2="-14.859" y2="112.141" width="0.6096" layer="16"/>
<wire x1="-14.859" y1="112.141" x2="-22.352" y2="112.141" width="0.6096" layer="16"/>
<wire x1="-14.859" y1="110.236" x2="-14.859" y2="112.141" width="0.6096" layer="16"/>
<wire x1="-23.368" y1="110.236" x2="-23.368" y2="108.077" width="0.6096" layer="16"/>
<wire x1="-5.08" y1="107.061" x2="-9.525" y2="111.506" width="0.6096" layer="1"/>
<wire x1="-5.08" y1="107.061" x2="-5.08" y2="92.71" width="0.6096" layer="1"/>
<wire x1="-5.08" y1="92.71" x2="-7.112" y2="90.678" width="0.6096" layer="1"/>
<wire x1="-7.112" y1="90.678" x2="-7.112" y2="82.677" width="0.6096" layer="16"/>
<wire x1="-7.112" y1="82.677" x2="-9.906" y2="79.883" width="0.6096" layer="16"/>
<wire x1="-9.906" y1="79.883" x2="-10.922" y2="79.883" width="0.6096" layer="16"/>
<wire x1="-22.352" y1="112.141" x2="-23.368" y2="111.125" width="0.6096" layer="16"/>
<wire x1="-23.368" y1="111.125" x2="-23.368" y2="110.236" width="0.6096" layer="16"/>
</signal>
<signal name="N$58">
<contactref element="C213" pad="2"/>
<contactref element="R216" pad="2"/>
<contactref element="OA203" pad="2"/>
<wire x1="-18.288" y1="100.457" x2="-18.288" y2="98.298" width="0.6096" layer="16"/>
<wire x1="-17.653" y1="96.774" x2="-11.811" y2="96.774" width="0.6096" layer="16"/>
<wire x1="-11.811" y1="96.774" x2="-11.557" y2="97.028" width="0.6096" layer="16"/>
<wire x1="-17.653" y1="96.774" x2="-18.288" y2="97.409" width="0.6096" layer="16"/>
<wire x1="-18.288" y1="97.409" x2="-18.288" y2="98.298" width="0.6096" layer="16"/>
</signal>
<signal name="N$59">
<contactref element="R214" pad="1"/>
<contactref element="R215" pad="2"/>
<contactref element="C214" pad="2"/>
<contactref element="OA203" pad="3"/>
<wire x1="-20.828" y1="101.473" x2="-20.828" y2="100.457" width="0.6096" layer="16"/>
<wire x1="-23.368" y1="100.457" x2="-20.828" y2="100.457" width="0.6096" layer="16"/>
<wire x1="-20.828" y1="100.457" x2="-20.828" y2="98.298" width="0.6096" layer="16"/>
<wire x1="-19.939" y1="102.362" x2="-20.828" y2="101.473" width="0.6096" layer="16"/>
<wire x1="-11.557" y1="104.267" x2="-11.557" y2="101.727" width="0.6096" layer="16"/>
<wire x1="-19.939" y1="102.362" x2="-13.081" y2="102.362" width="0.6096" layer="16"/>
<wire x1="-13.081" y1="102.362" x2="-12.446" y2="101.727" width="0.6096" layer="16"/>
<wire x1="-12.446" y1="101.727" x2="-11.557" y2="101.727" width="0.6096" layer="16"/>
</signal>
<signal name="N$60">
<contactref element="R217" pad="2"/>
<contactref element="OA204" pad="3"/>
<contactref element="C215A" pad="2"/>
<contactref element="C215B" pad="2"/>
<contactref element="C215C" pad="2"/>
<wire x1="-5.969" y1="76.2" x2="-8.509" y2="76.2" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="72.136" x2="-8.509" y2="72.136" width="0.6096" layer="16"/>
<wire x1="-14.986" y1="65.278" x2="-14.986" y2="66.167" width="0.6096" layer="16"/>
<wire x1="-14.986" y1="66.167" x2="-13.081" y2="68.072" width="0.6096" layer="16"/>
<wire x1="-13.081" y1="68.072" x2="-5.969" y2="68.072" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="68.072" x2="-5.969" y2="72.136" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="72.136" x2="-5.969" y2="76.2" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="76.2" x2="-5.969" y2="78.232" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="78.232" x2="-4.318" y2="79.883" width="0.6096" layer="16"/>
<wire x1="-4.318" y1="79.883" x2="-3.302" y2="79.883" width="0.6096" layer="16"/>
</signal>
<signal name="N$61">
<contactref element="R218" pad="1"/>
<contactref element="C215A" pad="1"/>
<contactref element="C215C" pad="1"/>
<contactref element="C215B" pad="1"/>
<contactref element="C216" pad="2"/>
<wire x1="-3.429" y1="65.278" x2="-4.699" y2="64.008" width="0.6096" layer="16"/>
<wire x1="-4.699" y1="64.008" x2="-6.223" y2="64.008" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="65.278" x2="-3.429" y2="68.072" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="68.072" x2="-3.429" y2="72.136" width="0.6096" layer="16"/>
<wire x1="-3.429" y1="72.136" x2="-3.429" y2="76.2" width="0.6096" layer="16"/>
</signal>
<signal name="N$62">
<contactref element="OA204" pad="6"/>
<contactref element="R222" pad="1"/>
<contactref element="R219" pad="2"/>
<wire x1="-14.986" y1="55.245" x2="-14.986" y2="57.658" width="0.6096" layer="16"/>
<wire x1="-14.986" y1="55.245" x2="-17.78" y2="55.245" width="0.6096" layer="16"/>
<wire x1="-17.78" y1="55.245" x2="-20.193" y2="57.658" width="0.6096" layer="16"/>
<wire x1="-20.193" y1="57.658" x2="-20.955" y2="57.658" width="0.6096" layer="16"/>
</signal>
<signal name="N$63">
<contactref element="OA204" pad="2"/>
<contactref element="R220" pad="1"/>
<contactref element="R219" pad="1"/>
<contactref element="R221" pad="1"/>
<wire x1="-20.955" y1="63.373" x2="-12.446" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-12.446" y1="63.373" x2="-9.144" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-20.955" y1="65.278" x2="-20.955" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-25.781" y1="51.943" x2="-25.781" y2="52.959" width="0.6096" layer="1"/>
<wire x1="-25.781" y1="52.959" x2="-22.733" y2="56.007" width="0.6096" layer="1"/>
<wire x1="-22.733" y1="56.007" x2="-19.05" y2="56.007" width="0.6096" layer="1"/>
<wire x1="-19.05" y1="56.007" x2="-16.51" y2="53.467" width="0.6096" layer="1"/>
<wire x1="-16.51" y1="53.467" x2="-11.684" y2="53.467" width="0.6096" layer="1"/>
<wire x1="-11.684" y1="53.467" x2="-8.128" y2="57.023" width="0.6096" layer="1"/>
<wire x1="-20.955" y1="63.373" x2="-22.606" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-22.606" y1="63.373" x2="-23.495" y2="64.262" width="0.6096" layer="1"/>
<wire x1="-23.495" y1="64.262" x2="-23.495" y2="65.278" width="0.6096" layer="1"/>
<wire x1="-12.446" y1="65.278" x2="-12.446" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-8.128" y1="62.357" x2="-9.144" y2="63.373" width="0.6096" layer="1"/>
<wire x1="-8.128" y1="57.023" x2="-8.128" y2="62.357" width="0.6096" layer="1"/>
</signal>
<signal name="N$64">
<contactref element="R222" pad="2"/>
<contactref element="C217C" pad="2"/>
<contactref element="C217A" pad="2"/>
<contactref element="C217B" pad="2"/>
<contactref element="OA205" pad="3"/>
<wire x1="-5.969" y1="44.323" x2="-8.509" y2="44.323" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="48.387" x2="-8.509" y2="48.387" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="48.387" x2="-8.509" y2="44.323" width="0.6096" layer="16"/>
<wire x1="-5.969" y1="52.451" x2="-8.509" y2="52.451" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="52.451" x2="-8.509" y2="50.292" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="50.292" x2="-8.509" y2="48.387" width="0.6096" layer="16"/>
<wire x1="-17.78" y1="51.943" x2="-17.78" y2="51.054" width="0.6096" layer="16"/>
<wire x1="-17.78" y1="51.054" x2="-17.018" y2="50.292" width="0.6096" layer="16"/>
<wire x1="-17.018" y1="50.292" x2="-8.509" y2="50.292" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="52.451" x2="-8.509" y2="54.102" width="0.6096" layer="16"/>
<wire x1="-8.509" y1="54.102" x2="-7.366" y2="55.245" width="0.6096" layer="16"/>
</signal>
<signal name="N$65">
<contactref element="OA205" pad="2"/>
<contactref element="R223" pad="1"/>
<contactref element="R224" pad="1"/>
<wire x1="-15.24" y1="51.943" x2="-17.018" y2="53.721" width="0.6096" layer="16"/>
<wire x1="-17.018" y1="53.721" x2="-18.542" y2="53.721" width="0.6096" layer="16"/>
<wire x1="-23.241" y1="51.943" x2="-20.828" y2="54.356" width="0.6096" layer="16"/>
<wire x1="-20.828" y1="54.356" x2="-20.193" y2="54.356" width="0.6096" layer="16"/>
<wire x1="-18.542" y1="53.721" x2="-19.177" y2="54.356" width="0.6096" layer="16"/>
<wire x1="-19.177" y1="54.356" x2="-20.193" y2="54.356" width="0.6096" layer="16"/>
</signal>
<signal name="N$66">
<contactref element="OA205" pad="6"/>
<contactref element="R224" pad="2"/>
<contactref element="R225" pad="1"/>
<contactref element="R226" pad="2"/>
<wire x1="-23.241" y1="44.323" x2="-23.241" y2="45.339" width="0.6096" layer="16"/>
<wire x1="-23.241" y1="45.339" x2="-22.352" y2="46.228" width="0.6096" layer="16"/>
<wire x1="-22.352" y1="46.228" x2="-18.796" y2="46.228" width="0.6096" layer="16"/>
<wire x1="-18.796" y1="46.228" x2="-17.78" y2="45.212" width="0.6096" layer="16"/>
<wire x1="-17.78" y1="45.212" x2="-17.78" y2="44.323" width="0.6096" layer="16"/>
<wire x1="-22.86" y1="36.068" x2="-22.86" y2="38.608" width="0.6096" layer="16"/>
<wire x1="-23.241" y1="44.323" x2="-23.241" y2="40.005" width="0.6096" layer="16"/>
<wire x1="-23.241" y1="40.005" x2="-22.86" y2="39.624" width="0.6096" layer="16"/>
<wire x1="-22.86" y1="39.624" x2="-22.86" y2="38.608" width="0.6096" layer="16"/>
</signal>
<signal name="N$67">
<contactref element="OA206" pad="6"/>
<contactref element="R221" pad="2"/>
<contactref element="C220" pad="1"/>
<wire x1="-26.416" y1="26.035" x2="-26.035" y2="26.416" width="0.6096" layer="1"/>
<wire x1="-26.035" y1="26.416" x2="-21.971" y2="26.416" width="0.6096" layer="1"/>
<wire x1="-21.971" y1="26.416" x2="-21.209" y2="25.654" width="0.6096" layer="1"/>
<wire x1="-21.209" y1="25.654" x2="-21.209" y2="24.765" width="0.6096" layer="1"/>
<wire x1="-27.305" y1="26.035" x2="-28.829" y2="27.559" width="0.6096" layer="1"/>
<wire x1="-28.829" y1="27.559" x2="-28.829" y2="40.259" width="0.6096" layer="1"/>
<wire x1="-28.829" y1="40.259" x2="-25.781" y2="43.307" width="0.6096" layer="1"/>
<wire x1="-25.781" y1="43.307" x2="-25.781" y2="44.323" width="0.6096" layer="1"/>
<wire x1="-26.416" y1="26.035" x2="-27.305" y2="26.035" width="0.6096" layer="1"/>
</signal>
<signal name="N$68">
<contactref element="OA206" pad="3"/>
<contactref element="R226" pad="1"/>
<contactref element="C219" pad="1"/>
<wire x1="-21.209" y1="32.385" x2="-21.209" y2="34.29" width="0.6096" layer="16"/>
<wire x1="-21.209" y1="34.29" x2="-16.891" y2="38.608" width="0.6096" layer="16"/>
<wire x1="-16.891" y1="38.608" x2="-15.24" y2="38.608" width="0.6096" layer="16"/>
<wire x1="-15.24" y1="38.608" x2="-14.224" y2="38.608" width="0.6096" layer="16"/>
<wire x1="-14.224" y1="38.608" x2="-12.573" y2="40.259" width="0.6096" layer="16"/>
<wire x1="-12.573" y1="40.259" x2="-8.509" y2="40.259" width="0.6096" layer="16"/>
</signal>
<signal name="N$69">
<contactref element="OA206" pad="2"/>
<contactref element="R227" pad="1"/>
<contactref element="C220" pad="2"/>
<wire x1="-27.305" y1="31.115" x2="-26.416" y2="31.115" width="0.6096" layer="1"/>
<wire x1="-26.416" y1="31.115" x2="-25.908" y2="30.607" width="0.6096" layer="1"/>
<wire x1="-25.908" y1="30.607" x2="-19.558" y2="30.607" width="0.6096" layer="1"/>
<wire x1="-19.558" y1="30.607" x2="-18.669" y2="31.496" width="0.6096" layer="1"/>
<wire x1="-18.669" y1="31.496" x2="-18.669" y2="32.385" width="0.6096" layer="1"/>
<wire x1="-9.906" y1="37.084" x2="-10.922" y2="37.084" width="0.6096" layer="1"/>
<wire x1="-10.922" y1="37.084" x2="-13.97" y2="34.036" width="0.6096" layer="1"/>
<wire x1="-13.97" y1="34.036" x2="-17.907" y2="34.036" width="0.6096" layer="1"/>
<wire x1="-17.907" y1="34.036" x2="-18.669" y2="33.274" width="0.6096" layer="1"/>
<wire x1="-18.669" y1="33.274" x2="-18.669" y2="32.385" width="0.6096" layer="1"/>
</signal>
<signal name="N$70">
<contactref element="C211" pad="2"/>
<contactref element="OA202" pad="8"/>
<wire x1="-15.494" y1="70.866" x2="-15.494" y2="69.342" width="0.6096" layer="16"/>
<wire x1="-15.494" y1="69.342" x2="-16.764" y2="68.072" width="0.6096" layer="16"/>
</signal>
<signal name="N$71">
<contactref element="OA202" pad="5"/>
<contactref element="C211" pad="1"/>
<wire x1="-23.114" y1="70.866" x2="-23.114" y2="69.342" width="0.6096" layer="16"/>
<wire x1="-23.114" y1="69.342" x2="-21.844" y2="68.072" width="0.6096" layer="16"/>
</signal>
<signal name="N$72">
<contactref element="OA205" pad="8"/>
<contactref element="C218" pad="1"/>
<wire x1="-12.7" y1="44.323" x2="-12.7" y2="42.799" width="0.6096" layer="16"/>
<wire x1="-12.7" y1="42.799" x2="-13.97" y2="41.529" width="0.6096" layer="16"/>
</signal>
<signal name="N$73">
<contactref element="OA205" pad="5"/>
<contactref element="C218" pad="2"/>
<wire x1="-20.32" y1="44.323" x2="-20.32" y2="42.799" width="0.6096" layer="16"/>
<wire x1="-20.32" y1="42.799" x2="-19.05" y2="41.529" width="0.6096" layer="16"/>
</signal>
<signal name="N$74">
<contactref element="R228" pad="3"/>
<contactref element="OA206" pad="1"/>
<wire x1="-6.477" y1="27.305" x2="-9.652" y2="30.48" width="0.6096" layer="16"/>
<wire x1="-9.652" y1="30.48" x2="-12.827" y2="30.48" width="0.6096" layer="16"/>
<wire x1="-12.827" y1="30.48" x2="-14.732" y2="32.385" width="0.6096" layer="16"/>
<wire x1="-14.732" y1="32.385" x2="-16.129" y2="32.385" width="0.6096" layer="16"/>
</signal>
<signal name="N$75">
<contactref element="OA206" pad="5"/>
<contactref element="R228" pad="1"/>
<wire x1="-11.557" y1="27.305" x2="-22.098" y2="27.305" width="0.6096" layer="16"/>
<wire x1="-22.098" y1="27.305" x2="-23.749" y2="25.654" width="0.6096" layer="16"/>
<wire x1="-23.749" y1="25.654" x2="-23.749" y2="24.765" width="0.6096" layer="16"/>
</signal>
<signal name="N$76">
<contactref element="R225" pad="2"/>
<contactref element="L_OUT" pad="1"/>
<wire x1="-15.24" y1="36.068" x2="-12.573" y2="36.068" width="0.6096" layer="16"/>
<wire x1="-12.573" y1="36.068" x2="-9.906" y2="33.401" width="0.6096" layer="16"/>
</signal>
<signal name="+15V">
<contactref element="R7" pad="1"/>
<contactref element="R6" pad="1"/>
<contactref element="OA1" pad="7"/>
<contactref element="OA4" pad="7"/>
<contactref element="OA5" pad="7"/>
<contactref element="OA6" pad="7"/>
<contactref element="OA3" pad="7"/>
<contactref element="OA2" pad="7"/>
<contactref element="C22" pad="2"/>
<contactref element="C23" pad="2"/>
<contactref element="C24" pad="+"/>
<contactref element="C21" pad="2"/>
<contactref element="T3" pad="E"/>
<wire x1="23.495" y1="129.159" x2="22.987" y2="128.651" width="0.6096" layer="16"/>
<wire x1="22.987" y1="128.651" x2="22.987" y2="127.635" width="0.6096" layer="16"/>
<wire x1="25.527" y1="127.635" x2="29.337" y2="127.635" width="1.016" layer="1"/>
<wire x1="29.337" y1="127.635" x2="30.353" y2="126.619" width="1.016" layer="1"/>
<wire x1="30.353" y1="126.619" x2="30.353" y2="111.76" width="1.016" layer="1"/>
<wire x1="30.353" y1="111.76" x2="30.353" y2="92.202" width="1.016" layer="1"/>
<wire x1="30.353" y1="46.228" x2="30.353" y2="22.733" width="1.016" layer="1"/>
<wire x1="30.353" y1="22.733" x2="30.353" y2="4.445" width="1.016" layer="1"/>
<wire x1="22.987" y1="127.635" x2="25.527" y2="127.635" width="0.6096" layer="16"/>
<wire x1="23.368" y1="110.236" x2="23.368" y2="111.125" width="0.6096" layer="1"/>
<wire x1="23.368" y1="111.125" x2="24.003" y2="111.76" width="0.6096" layer="1"/>
<wire x1="24.003" y1="111.76" x2="30.353" y2="111.76" width="0.6096" layer="1"/>
<wire x1="20.828" y1="90.678" x2="20.828" y2="91.567" width="0.6096" layer="1"/>
<wire x1="20.828" y1="91.567" x2="21.463" y2="92.202" width="0.6096" layer="1"/>
<wire x1="21.463" y1="92.202" x2="30.353" y2="92.202" width="0.6096" layer="1"/>
<wire x1="20.574" y1="70.866" x2="20.574" y2="71.755" width="0.6096" layer="1"/>
<wire x1="20.574" y1="71.755" x2="21.209" y2="72.39" width="0.6096" layer="1"/>
<wire x1="14.986" y1="57.658" x2="14.986" y2="58.547" width="0.6096" layer="1"/>
<wire x1="14.986" y1="58.547" x2="16.002" y2="59.563" width="0.6096" layer="1"/>
<wire x1="17.78" y1="44.323" x2="17.78" y2="45.212" width="0.6096" layer="1"/>
<wire x1="17.78" y1="45.212" x2="18.796" y2="46.228" width="0.6096" layer="1"/>
<wire x1="18.796" y1="46.228" x2="30.353" y2="46.228" width="0.6096" layer="1"/>
<wire x1="21.209" y1="22.733" x2="10.033" y2="22.733" width="1.016" layer="1"/>
<wire x1="21.209" y1="24.765" x2="21.209" y2="22.733" width="0.6096" layer="1"/>
<wire x1="25.654" y1="3.175" x2="29.083" y2="3.175" width="1.016" layer="1"/>
<wire x1="25.654" y1="3.175" x2="25.654" y2="1.27" width="1.016" layer="1"/>
<wire x1="30.353" y1="4.445" x2="29.083" y2="3.175" width="1.016" layer="1"/>
<wire x1="21.209" y1="22.733" x2="30.353" y2="22.733" width="1.016" layer="1"/>
<wire x1="25.654" y1="3.175" x2="7.239" y2="3.175" width="1.016" layer="1"/>
<wire x1="7.239" y1="3.175" x2="6.096" y2="2.032" width="1.016" layer="1"/>
<wire x1="5.969" y1="23.114" x2="9.652" y2="23.114" width="1.016" layer="1"/>
<wire x1="10.033" y1="22.733" x2="9.652" y2="23.114" width="1.016" layer="1"/>
<wire x1="30.353" y1="46.228" x2="30.353" y2="59.563" width="1.016" layer="1"/>
<wire x1="30.353" y1="59.563" x2="30.353" y2="60.706" width="1.016" layer="1"/>
<wire x1="30.353" y1="60.706" x2="25.527" y2="65.532" width="1.016" layer="1"/>
<wire x1="30.353" y1="92.202" x2="30.353" y2="75.184" width="1.016" layer="1"/>
<wire x1="30.353" y1="75.184" x2="26.9875" y2="71.8185" width="1.016" layer="1"/>
<wire x1="26.9875" y1="71.8185" x2="25.527" y2="70.358" width="1.016" layer="1"/>
<wire x1="16.002" y1="59.563" x2="30.353" y2="59.563" width="0.6096" layer="1"/>
<wire x1="21.209" y1="72.39" x2="26.416" y2="72.39" width="0.6096" layer="1"/>
<wire x1="23.495" y1="129.159" x2="23.495" y2="135.89" width="0.6096" layer="16"/>
<wire x1="23.495" y1="135.89" x2="26.035" y2="135.89" width="0.6096" layer="16"/>
<wire x1="24.892" y1="142.748" x2="24.892" y2="137.922" width="0.6096" layer="16"/>
<wire x1="24.892" y1="137.922" x2="23.495" y2="136.525" width="0.6096" layer="16"/>
<wire x1="23.495" y1="136.525" x2="23.495" y2="135.89" width="0.6096" layer="16"/>
<wire x1="26.416" y1="72.39" x2="26.9875" y2="71.8185" width="0.6096" layer="1"/>
<wire x1="25.527" y1="70.358" x2="25.527" y2="65.532" width="1.016" layer="1"/>
</signal>
<signal name="-15V">
<contactref element="OA1" pad="4"/>
<contactref element="OA4" pad="4"/>
<contactref element="OA5" pad="4"/>
<contactref element="OA3" pad="4"/>
<contactref element="OA2" pad="4"/>
<contactref element="OA6" pad="4"/>
<contactref element="R28" pad="2"/>
<contactref element="C26" pad="2"/>
<contactref element="C27" pad="2"/>
<contactref element="C28" pad="+"/>
<contactref element="C21" pad="1"/>
<contactref element="T4" pad="E"/>
<wire x1="30.353" y1="137.795" x2="30.353" y2="135.89" width="1.016" layer="16"/>
<wire x1="30.353" y1="135.89" x2="30.353" y2="130.302" width="1.016" layer="16"/>
<wire x1="30.353" y1="130.302" x2="30.353" y2="116.332" width="1.016" layer="16"/>
<wire x1="30.353" y1="116.332" x2="30.353" y2="96.774" width="1.016" layer="16"/>
<wire x1="30.353" y1="96.774" x2="30.353" y2="76.962" width="1.016" layer="16"/>
<wire x1="30.353" y1="50.038" x2="30.353" y2="29.464" width="1.016" layer="16"/>
<wire x1="28.575" y1="135.89" x2="30.353" y2="135.89" width="0.6096" layer="16"/>
<wire x1="18.288" y1="117.856" x2="18.288" y2="116.967" width="0.6096" layer="16"/>
<wire x1="18.288" y1="116.967" x2="18.923" y2="116.332" width="0.6096" layer="16"/>
<wire x1="18.923" y1="116.332" x2="30.353" y2="116.332" width="0.6096" layer="16"/>
<wire x1="15.748" y1="98.298" x2="15.748" y2="97.409" width="0.6096" layer="16"/>
<wire x1="15.748" y1="97.409" x2="16.383" y2="96.774" width="0.6096" layer="16"/>
<wire x1="16.383" y1="96.774" x2="30.353" y2="96.774" width="0.6096" layer="16"/>
<contactref element="R4" pad="1"/>
<wire x1="28.575" y1="130.302" x2="30.353" y2="130.302" width="0.6096" layer="16"/>
<wire x1="15.494" y1="78.486" x2="15.494" y2="77.597" width="0.6096" layer="16"/>
<wire x1="15.494" y1="77.597" x2="16.129" y2="76.962" width="0.6096" layer="16"/>
<wire x1="16.129" y1="76.962" x2="30.099" y2="76.962" width="0.6096" layer="16"/>
<wire x1="30.099" y1="76.962" x2="30.353" y2="76.962" width="0.6096" layer="16"/>
<wire x1="9.906" y1="65.278" x2="9.906" y2="64.389" width="0.6096" layer="16"/>
<wire x1="9.906" y1="64.389" x2="10.922" y2="63.373" width="0.6096" layer="16"/>
<wire x1="12.7" y1="51.943" x2="12.7" y2="51.054" width="0.6096" layer="16"/>
<wire x1="12.7" y1="51.054" x2="13.716" y2="50.038" width="0.6096" layer="16"/>
<wire x1="13.716" y1="50.038" x2="30.353" y2="50.038" width="0.6096" layer="16"/>
<wire x1="16.129" y1="29.464" x2="30.353" y2="29.464" width="0.6096" layer="16"/>
<wire x1="16.129" y1="32.385" x2="16.129" y2="29.464" width="0.6096" layer="16"/>
<wire x1="30.353" y1="29.464" x2="30.353" y2="22.225" width="1.016" layer="16"/>
<wire x1="30.353" y1="22.225" x2="28.956" y2="20.828" width="1.016" layer="16"/>
<wire x1="28.956" y1="20.828" x2="25.654" y2="20.828" width="1.016" layer="16"/>
<wire x1="10.541" y1="19.558" x2="10.541" y2="21.59" width="1.016" layer="16"/>
<wire x1="10.541" y1="21.59" x2="11.684" y2="22.733" width="1.016" layer="16"/>
<wire x1="11.684" y1="22.733" x2="24.892" y2="22.733" width="1.016" layer="16"/>
<wire x1="24.892" y1="22.733" x2="25.654" y2="21.971" width="1.016" layer="16"/>
<wire x1="25.654" y1="21.971" x2="25.654" y2="20.828" width="1.016" layer="16"/>
<wire x1="5.969" y1="19.558" x2="10.541" y2="19.558" width="1.016" layer="16"/>
<wire x1="10.541" y1="19.558" x2="10.541" y2="18.923" width="1.016" layer="16"/>
<wire x1="10.541" y1="18.923" x2="6.096" y2="14.478" width="1.016" layer="16"/>
<wire x1="6.096" y1="14.478" x2="6.096" y2="13.208" width="1.016" layer="16"/>
<wire x1="30.353" y1="50.038" x2="30.353" y2="60.706" width="1.016" layer="16"/>
<wire x1="30.353" y1="60.706" x2="27.178" y2="63.881" width="1.016" layer="16"/>
<wire x1="27.178" y1="63.881" x2="25.527" y2="65.532" width="1.016" layer="16"/>
<wire x1="25.527" y1="70.358" x2="30.353" y2="75.184" width="1.016" layer="16"/>
<wire x1="30.353" y1="75.184" x2="30.353" y2="76.708" width="1.016" layer="16"/>
<wire x1="30.353" y1="76.708" x2="30.099" y2="76.962" width="1.016" layer="16"/>
<wire x1="10.922" y1="63.373" x2="26.67" y2="63.373" width="0.6096" layer="16"/>
<wire x1="16.129" y1="29.464" x2="10.414" y2="29.464" width="0.6096" layer="16"/>
<wire x1="10.414" y1="29.464" x2="9.017" y2="28.067" width="0.6096" layer="16"/>
<wire x1="9.017" y1="28.067" x2="9.017" y2="27.305" width="0.6096" layer="16"/>
<wire x1="30.353" y1="137.795" x2="27.94" y2="140.208" width="1.016" layer="16"/>
<wire x1="27.94" y1="140.208" x2="27.94" y2="142.748" width="1.016" layer="16"/>
<wire x1="26.67" y1="63.373" x2="27.178" y2="63.881" width="0.6096" layer="16"/>
<wire x1="25.527" y1="65.532" x2="25.527" y2="70.358" width="1.016" layer="16"/>
</signal>
<signal name="N$40">
<contactref element="T3" pad="B"/>
<contactref element="R30" pad="2"/>
<wire x1="21.844" y1="-1.27" x2="25.654" y2="-1.27" width="1.016" layer="16"/>
</signal>
<signal name="N$41">
<contactref element="R233" pad="1"/>
<contactref element="C229" pad="+"/>
<contactref element="R234" pad="1"/>
<wire x1="-21.844" y1="18.288" x2="-20.574" y2="18.288" width="1.016" layer="16"/>
<wire x1="-20.574" y1="18.288" x2="-18.034" y2="20.828" width="1.016" layer="16"/>
<wire x1="-18.034" y1="20.828" x2="-16.637" y2="20.828" width="1.016" layer="16"/>
<wire x1="-16.637" y1="20.828" x2="-14.224" y2="20.828" width="1.016" layer="16"/>
<wire x1="-16.637" y1="11.811" x2="-16.637" y2="20.828" width="1.016" layer="16"/>
</signal>
<signal name="N$77">
<contactref element="T204" pad="B"/>
<contactref element="R233" pad="2"/>
<wire x1="-25.654" y1="18.288" x2="-24.765" y2="18.288" width="1.016" layer="16"/>
<wire x1="-24.765" y1="18.288" x2="-22.225" y2="20.828" width="1.016" layer="16"/>
<wire x1="-22.225" y1="20.828" x2="-21.844" y2="20.828" width="1.016" layer="16"/>
</signal>
<signal name="N$78">
<contactref element="T204" pad="C"/>
<contactref element="R232" pad="1"/>
<wire x1="-25.654" y1="15.748" x2="-21.844" y2="15.748" width="1.016" layer="16"/>
</signal>
<signal name="N$79">
<contactref element="T203" pad="B"/>
<contactref element="R230" pad="2"/>
<wire x1="-25.654" y1="-1.27" x2="-22.352" y2="-1.27" width="1.016" layer="16"/>
</signal>
<signal name="N$80">
<contactref element="T203" pad="C"/>
<contactref element="R229" pad="1"/>
<wire x1="-25.654" y1="-3.81" x2="-22.352" y2="-3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$81">
<contactref element="R230" pad="1"/>
<contactref element="C225" pad="+"/>
<contactref element="R231" pad="1"/>
<wire x1="-22.352" y1="1.27" x2="-19.812" y2="1.27" width="1.016" layer="16"/>
<wire x1="-19.812" y1="1.27" x2="-17.272" y2="-1.27" width="1.016" layer="16"/>
<wire x1="-17.272" y1="-1.27" x2="-14.732" y2="-1.27" width="1.016" layer="16"/>
<wire x1="-27.305" y1="9.271" x2="-27.305" y2="7.366" width="1.016" layer="16"/>
<wire x1="-27.305" y1="7.366" x2="-22.352" y2="2.413" width="1.016" layer="16"/>
<wire x1="-22.352" y1="2.413" x2="-22.352" y2="1.27" width="1.016" layer="16"/>
</signal>
<signal name="N$82">
<contactref element="R229" pad="2"/>
<contactref element="R231" pad="2"/>
<contactref element="R29" pad="2"/>
<contactref element="R31" pad="2"/>
<contactref element="C305" pad="+"/>
<contactref element="C301" pad="+"/>
<contactref element="IC301" pad="2"/>
<contactref element="R301" pad="2"/>
<contactref element="D301" pad="C"/>
<wire x1="-14.732" y1="-18.542" x2="-16.256" y2="-18.542" width="1.016" layer="16"/>
<wire x1="-16.256" y1="-18.542" x2="-18.542" y2="-16.256" width="1.016" layer="16"/>
<wire x1="-18.542" y1="-16.256" x2="-18.542" y2="-13.589" width="1.016" layer="16"/>
<wire x1="-18.542" y1="-13.589" x2="-18.542" y2="-9.906" width="1.016" layer="16"/>
<wire x1="-14.732" y1="-13.589" x2="-18.542" y2="-13.589" width="1.016" layer="16"/>
<wire x1="-18.542" y1="-9.906" x2="-18.542" y2="-6.477" width="1.016" layer="16"/>
<wire x1="-18.542" y1="-6.477" x2="-15.875" y2="-3.81" width="1.016" layer="16"/>
<wire x1="-15.875" y1="-3.81" x2="-14.732" y2="-3.81" width="1.016" layer="16"/>
<wire x1="14.224" y1="-3.81" x2="15.367" y2="-3.81" width="1.016" layer="16"/>
<wire x1="15.367" y1="-3.81" x2="20.447" y2="1.27" width="1.016" layer="16"/>
<wire x1="20.447" y1="1.27" x2="21.844" y2="1.27" width="1.016" layer="16"/>
<wire x1="21.844" y1="1.27" x2="27.305" y2="6.731" width="1.016" layer="16"/>
<wire x1="27.305" y1="6.731" x2="27.305" y2="9.271" width="1.016" layer="16"/>
<wire x1="-21.971" y1="5.588" x2="-19.05" y2="5.588" width="1.016" layer="16"/>
<wire x1="-19.05" y1="5.588" x2="-14.732" y2="1.27" width="1.016" layer="16"/>
<wire x1="14.224" y1="-3.81" x2="-12.573" y2="-3.81" width="1.016" layer="1"/>
<wire x1="-12.573" y1="-3.81" x2="-14.732" y2="-3.81" width="1.016" layer="1"/>
<wire x1="-14.732" y1="1.27" x2="-13.589" y2="1.27" width="1.016" layer="1"/>
<wire x1="-13.589" y1="1.27" x2="-12.573" y2="0.254" width="1.016" layer="1"/>
<wire x1="-12.573" y1="0.254" x2="-12.573" y2="-3.81" width="1.016" layer="1"/>
</signal>
<signal name="N$83">
<contactref element="R234" pad="2"/>
<contactref element="R232" pad="2"/>
<contactref element="R34" pad="2"/>
<contactref element="R32" pad="2"/>
<contactref element="C303" pad="+"/>
<contactref element="C306" pad="+"/>
<contactref element="IC302" pad="3"/>
<contactref element="R303" pad="2"/>
<contactref element="D304" pad="A"/>
<wire x1="-14.224" y1="18.288" x2="-14.224" y2="15.748" width="0.6096" layer="16"/>
<wire x1="-11.303" y1="8.128" x2="-11.303" y2="12.827" width="1.016" layer="16"/>
<wire x1="-11.303" y1="12.827" x2="-14.224" y2="15.748" width="1.016" layer="16"/>
<wire x1="18.034" y1="15.748" x2="18.034" y2="18.161" width="1.016" layer="16"/>
<wire x1="18.034" y1="18.161" x2="20.701" y2="20.828" width="1.016" layer="16"/>
<wire x1="20.701" y1="20.828" x2="21.844" y2="20.828" width="1.016" layer="16"/>
<wire x1="21.844" y1="15.748" x2="18.034" y2="15.748" width="1.016" layer="16"/>
<wire x1="22.352" y1="-13.843" x2="23.495" y2="-13.843" width="1.016" layer="16"/>
<wire x1="23.495" y1="-13.843" x2="24.511" y2="-14.859" width="1.016" layer="16"/>
<wire x1="24.511" y1="-14.859" x2="24.511" y2="-18.288" width="1.016" layer="16"/>
<wire x1="24.511" y1="-18.288" x2="24.003" y2="-18.796" width="1.016" layer="16"/>
<wire x1="24.003" y1="-18.796" x2="22.352" y2="-18.796" width="1.016" layer="16"/>
<wire x1="21.082" y1="-9.906" x2="21.082" y2="-12.573" width="1.016" layer="16"/>
<wire x1="21.082" y1="-12.573" x2="22.352" y2="-13.843" width="1.016" layer="16"/>
<wire x1="21.082" y1="-9.906" x2="29.083" y2="-9.906" width="1.016" layer="16"/>
<wire x1="29.083" y1="-9.906" x2="30.353" y2="-8.636" width="1.016" layer="16"/>
<wire x1="30.353" y1="-8.636" x2="30.353" y2="12.192" width="1.016" layer="16"/>
<wire x1="30.353" y1="12.192" x2="28.702" y2="13.843" width="1.016" layer="16"/>
<wire x1="28.702" y1="13.843" x2="23.749" y2="13.843" width="1.016" layer="16"/>
<wire x1="23.749" y1="13.843" x2="21.844" y2="15.748" width="1.016" layer="16"/>
<wire x1="16.637" y1="11.811" x2="10.414" y2="11.811" width="1.016" layer="1"/>
<wire x1="10.414" y1="11.811" x2="6.731" y2="8.128" width="1.016" layer="1"/>
<wire x1="6.731" y1="8.128" x2="-11.303" y2="8.128" width="1.016" layer="1"/>
<wire x1="18.034" y1="15.748" x2="18.034" y2="13.208" width="1.016" layer="16"/>
<wire x1="18.034" y1="13.208" x2="16.637" y2="11.811" width="1.016" layer="16"/>
</signal>
<signal name="N$84">
<contactref element="T4" pad="B"/>
<contactref element="R33" pad="2"/>
<wire x1="25.654" y1="18.288" x2="21.844" y2="18.288" width="1.016" layer="16"/>
</signal>
<signal name="N$85">
<contactref element="T4" pad="C"/>
<contactref element="R32" pad="1"/>
<wire x1="14.224" y1="15.748" x2="15.24" y2="15.748" width="1.016" layer="1"/>
<wire x1="15.24" y1="15.748" x2="17.145" y2="13.843" width="1.016" layer="1"/>
<wire x1="17.145" y1="13.843" x2="24.765" y2="13.843" width="1.016" layer="1"/>
<wire x1="24.765" y1="13.843" x2="25.654" y2="14.732" width="1.016" layer="1"/>
<wire x1="25.654" y1="14.732" x2="25.654" y2="15.748" width="1.016" layer="1"/>
</signal>
<signal name="N$86">
<contactref element="R30" pad="1"/>
<contactref element="C25" pad="+"/>
<contactref element="R31" pad="1"/>
<wire x1="14.224" y1="-1.27" x2="14.224" y2="1.27" width="1.016" layer="16"/>
<wire x1="14.224" y1="1.27" x2="17.653" y2="1.27" width="1.016" layer="16"/>
<wire x1="17.653" y1="1.27" x2="21.971" y2="5.588" width="1.016" layer="16"/>
</signal>
<signal name="N$87">
<contactref element="T3" pad="C"/>
<contactref element="R29" pad="1"/>
<wire x1="21.844" y1="-3.81" x2="25.654" y2="-3.81" width="1.016" layer="16"/>
</signal>
<signal name="N$88">
<contactref element="R33" pad="1"/>
<contactref element="C29" pad="+"/>
<contactref element="R34" pad="1"/>
<wire x1="14.224" y1="20.828" x2="14.224" y2="18.288" width="1.016" layer="16"/>
<wire x1="11.43" y1="8.128" x2="11.43" y2="16.637" width="1.016" layer="16"/>
<wire x1="11.43" y1="16.637" x2="13.081" y2="18.288" width="1.016" layer="16"/>
<wire x1="13.081" y1="18.288" x2="14.224" y2="18.288" width="1.016" layer="16"/>
</signal>
<signal name="N$89">
<contactref element="R302" pad="2"/>
<contactref element="IC301" pad="1"/>
<contactref element="R301" pad="1"/>
<contactref element="D301" pad="A"/>
<wire x1="-22.352" y1="-18.542" x2="-22.352" y2="-16.129" width="1.016" layer="16"/>
<wire x1="-22.352" y1="-16.129" x2="-22.352" y2="-13.589" width="1.016" layer="16"/>
<wire x1="-22.352" y1="-13.589" x2="-22.352" y2="-13.081" width="1.016" layer="16"/>
<wire x1="-22.352" y1="-13.081" x2="-21.082" y2="-11.811" width="1.016" layer="16"/>
<wire x1="-21.082" y1="-11.811" x2="-21.082" y2="-9.906" width="1.016" layer="16"/>
</signal>
<signal name="N$90">
<contactref element="R304" pad="2"/>
<contactref element="IC302" pad="1"/>
<contactref element="R303" pad="1"/>
<contactref element="D304" pad="C"/>
<wire x1="14.732" y1="-18.796" x2="16.129" y2="-18.796" width="1.016" layer="16"/>
<wire x1="14.732" y1="-13.843" x2="16.002" y2="-13.843" width="1.016" layer="16"/>
<wire x1="16.129" y1="-18.796" x2="16.891" y2="-18.034" width="1.016" layer="16"/>
<wire x1="16.891" y1="-18.034" x2="16.891" y2="-16.383" width="1.016" layer="16"/>
<wire x1="16.891" y1="-16.383" x2="16.891" y2="-14.986" width="1.016" layer="16"/>
<wire x1="16.891" y1="-14.986" x2="16.002" y2="-14.097" width="1.016" layer="16"/>
<wire x1="16.002" y1="-13.843" x2="16.002" y2="-9.906" width="1.016" layer="16"/>
<wire x1="22.352" y1="-16.383" x2="16.891" y2="-16.383" width="1.016" layer="16"/>
<wire x1="16.002" y1="-14.097" x2="16.002" y2="-13.843" width="1.016" layer="16"/>
</signal>
<signal name="N$91">
<contactref element="IC301" pad="3"/>
<contactref element="C302" pad="+"/>
<contactref element="D302" pad="C"/>
<wire x1="-10.795" y1="-5.969" x2="-13.97" y2="-5.969" width="1.016" layer="16"/>
<wire x1="-13.97" y1="-5.969" x2="-16.002" y2="-8.001" width="1.016" layer="16"/>
<wire x1="-16.002" y1="-8.001" x2="-16.002" y2="-9.906" width="1.016" layer="16"/>
<wire x1="-10.795" y1="-5.969" x2="-9.271" y2="-5.969" width="1.016" layer="16"/>
<wire x1="-9.271" y1="-5.969" x2="-6.096" y2="-9.144" width="1.016" layer="16"/>
</signal>
<signal name="N$92">
<contactref element="+21,5V" pad="1"/>
<contactref element="D302" pad="A"/>
<wire x1="-7.62" y1="-18.288" x2="-9.779" y2="-16.129" width="1.016" layer="16"/>
<wire x1="-9.779" y1="-16.129" x2="-10.795" y2="-16.129" width="1.016" layer="16"/>
</signal>
<signal name="N$93">
<contactref element="IC302" pad="2"/>
<contactref element="D303" pad="C"/>
<contactref element="C304" pad="+"/>
<wire x1="10.795" y1="-6.223" x2="16.764" y2="-6.223" width="1.016" layer="16"/>
<wire x1="16.764" y1="-6.223" x2="18.542" y2="-8.001" width="1.016" layer="16"/>
<wire x1="18.542" y1="-8.001" x2="18.542" y2="-9.906" width="1.016" layer="16"/>
<wire x1="10.795" y1="-6.223" x2="9.017" y2="-6.223" width="1.016" layer="16"/>
<wire x1="9.017" y1="-6.223" x2="6.096" y2="-9.144" width="1.016" layer="16"/>
</signal>
<signal name="N$94">
<contactref element="D303" pad="A"/>
<contactref element="-21,5V" pad="1"/>
<wire x1="7.62" y1="-18.288" x2="9.525" y2="-16.383" width="1.016" layer="16"/>
<wire x1="9.525" y1="-16.383" x2="10.795" y2="-16.383" width="1.016" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="C4" pad="1"/>
<contactref element="SW1" pad="1"/>
<wire x1="19.939" y1="146.558" x2="19.939" y2="147.447" width="0.6096" layer="16"/>
<wire x1="19.939" y1="147.447" x2="21.463" y2="148.971" width="0.6096" layer="16"/>
<wire x1="21.463" y1="148.971" x2="21.463" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="C3" pad="1"/>
<contactref element="SW1" pad="2"/>
<wire x1="17.399" y1="146.558" x2="17.399" y2="148.082" width="0.6096" layer="16"/>
<wire x1="17.399" y1="148.082" x2="18.288" y2="148.971" width="0.6096" layer="16"/>
<wire x1="18.288" y1="148.971" x2="18.288" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="C2" pad="1"/>
<contactref element="SW1" pad="3"/>
<wire x1="14.859" y1="146.558" x2="14.859" y2="148.717" width="0.6096" layer="16"/>
<wire x1="14.859" y1="148.717" x2="15.113" y2="148.971" width="0.6096" layer="16"/>
<wire x1="15.113" y1="148.971" x2="15.113" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="C1" pad="1"/>
<contactref element="SW1" pad="4"/>
<wire x1="12.319" y1="146.558" x2="12.319" y2="148.59" width="0.6096" layer="16"/>
<wire x1="12.319" y1="148.59" x2="11.938" y2="148.971" width="0.6096" layer="16"/>
<wire x1="11.938" y1="148.971" x2="11.811" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$42">
<contactref element="C204" pad="1"/>
<contactref element="SW2" pad="1"/>
<wire x1="-12.319" y1="146.558" x2="-12.319" y2="148.463" width="0.6096" layer="16"/>
<wire x1="-12.319" y1="148.463" x2="-11.938" y2="148.844" width="0.6096" layer="16"/>
<wire x1="-11.938" y1="148.844" x2="-11.938" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$43">
<contactref element="C203" pad="1"/>
<contactref element="SW2" pad="2"/>
<wire x1="-14.859" y1="146.558" x2="-14.859" y2="148.717" width="0.6096" layer="16"/>
<wire x1="-14.859" y1="148.717" x2="-15.113" y2="148.971" width="0.6096" layer="16"/>
<wire x1="-15.113" y1="148.971" x2="-15.113" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$44">
<contactref element="C202" pad="1"/>
<contactref element="SW2" pad="3"/>
<wire x1="-17.399" y1="146.558" x2="-17.399" y2="148.082" width="0.6096" layer="16"/>
<wire x1="-17.399" y1="148.082" x2="-18.288" y2="148.971" width="0.6096" layer="16"/>
<wire x1="-18.288" y1="148.971" x2="-18.288" y2="149.86" width="0.6096" layer="16"/>
</signal>
<signal name="N$45">
<contactref element="C201" pad="1"/>
<contactref element="SW2" pad="4"/>
<wire x1="-19.939" y1="146.558" x2="-19.939" y2="147.447" width="0.6096" layer="16"/>
<wire x1="-19.939" y1="147.447" x2="-21.463" y2="148.971" width="0.6096" layer="16"/>
<wire x1="-21.463" y1="148.971" x2="-21.463" y2="149.86" width="0.6096" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
