AVR JTAG programmer-debugger
Bill of materials
Designator  LibRef            Description                                         Footprint      Comment        Bolt  Kd
C1          CAPSMD            Capacitor SMD1206                                   SMD1206                       RET   93-00-19
C2          CAPSMD            Capacitor SMD1206                                   SMD1206                       RET   93-00-19
C3          CAPPOLSMD         Capacitor Polarity SMD1206                          SMD1206 POL                   RET   93-02-80
C4          CAPPOLSMD         Capacitor Polarity SMD1206                          SMD1206 POL                   RET   93-02-80
C5          CAPPOLSMD         Capacitor Polarity SMD1206                          SMD1206 POL                   RET   93-02-80
C6          CAPPOLSMD         Capacitor Polarity SMD1206                          SMD1206 POL                   RET   93-02-80
C7          CAPPOLSMD         Capacitor Polarity SMD1206                          SMD1206 POL                   RET   93-02-80
D1          LED Piros         Piros Led 3mm                                       LED 3MM                       RET   46-01-40
D2          LED Zld          Zld Led 3mm                                        LED 3mm                       RET   46-01-42
J1          D Connector 9     Receptacle Assembly, 9 Position, Right Angle        DSUB9F90       D Connector 9
J2          M3 CSAVAR         M3 csavar hely                                      M3 CSAVAR      M3 csavar
J3          M3 CSAVAR         M3 csavar hely                                      M3 CSAVAR      M3 csavar
JP1         MLW10A            Header, 5-Pin, Dual row, Right Angle                MLW10A                        RET   53-02-64
R1          RES               Resistor SMD1206, 1% fmrteg                       SMD1206                       RET   96-00-73
R2          RES               Resistor SMD1206, 1% fmrteg                       SMD1206                       RET   96-00-73
R3          RES               Resistor SMD1206, 1% fmrteg                       SMD1206                       RET   96-00-89
R4          RES               Resistor SMD1206, 1% fmrteg                       SMD1206                       RET   96-00-97
U1          ATMEGA163-8AI     8 bit microcontroller                               DIP-40         ATMEGA163-8AI  MSC   ATMEGA163-8AI
U2          MAX232ACPE        +5V Powered, Multi-Channel RS-232 Driver/Receiver   DIP-16/X1.5    MAX232ACPE     RET   38-14-48
U3          MC33064P-5        Undervoltage Sensing Circuit                        BCY-W3         MC33064P-5     RET   38-10-28
Y1          XTAL              Crystal Oscillator                                  XTAL           XTAL           RET   62-00-45
