; Phillips RC5(X) Infrared protocol implemented with 18 pin Microchip 	*
; microcontrollers from 16F / 16C series.								*
; 16F627(A), 16F628(A), 16F648A, 16F716, 16C83, 16F83, 16C84, 16F84(A)	*
; 16F818, 16F819, 16F87, 16F88											*
;   many other, one time programmable 18 pin 16Cxxx device may be used	*
;	   - 6 byte RAM from 0x20 - 0x25 used only							*
;	   - no more than 256 word of program memory needed					*
;	   - EEProm lookup table is only an option							*
;	   - 4MHz clock used												*
; - Visible LED output - flashes as many timas as the selected page num.*
; - Handles 16 addresses : 0x10 .. 0x1F									*
; - Handles 64 commands  : 0x00 .. 0x3F	- using 4 command pages			*
; - Handles 16 buttons with up to 4 + 1 extra:							*
;    Address button : Hold down and press button 0..15 to set address	*
;    Shift   button : Each press rolls command page						*
;    Option1 button : Not used yet										*
;    Option2 button : Not used yet										*
;    Option3 button : Not used yet										*
; - Command codes can be translated using on chip EEPROM memory			*
;		Can be changed without reprogramming the program memory			*
;		Not avaible on 16F716 and 16Cxxx devices with no data EEProm	*
; - Matrix can be extended with two more raws (8 buttons)				*
;		Driven by RA2 and RA3	not implemented yet						*
;	  With devices having 4MHz on board oscillator						*
;		ex. 16F628(A), 16F648A, 16F87, 16F88							*
;       even more two extra raws										* 
;		Driven by RA6 and RA7	not implemented yet						*
	ifdef	__16F627
		list	p=16f627             ; 16F627 can be used
		#include <p16f627.inc>       ; processor specific variable definitions
EEPROM_SIZE	EQU	128
		__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _MCLRE_OFF & _LVP_OFF
    endif
	ifdef	__16F627A
		list	p=16f627A            ; 16F627A can be used
		#include <p16f627A.inc>      ; processor specific variable definitions
EEPROM_SIZE	EQU	128
    endif
	ifdef	__16F628
		list	p=16f628             ; 16F628 can be used
		#include <p16f628.inc>       ; processor specific variable definitions
EEPROM_SIZE	EQU	128
    endif
	ifdef	__16F628A
		list	p=16f628A            ; 16F628A can be used
		#include <p16f628A.inc>      ; processor specific variable definitions
EEPROM_SIZE	EQU	128
    endif
	ifdef	__16F648A
		list	p=16f648A            ; 16F648A can be used
		#include <p16f648A.inc>      ; processor specific variable definitions
EEPROM_SIZE	EQU	256
	endif
	ifdef	__16F716
		list	p=16f716             ; 16F716 can be used
		#include <p16f716.inc>       ; processor specific variable definitions
EEPROM_SIZE	EQU	0
    endif
	ifdef	__16C83
		list	p=16C83              ; 16C83 can be used
		#include <p16c83.inc>        ; processor specific variable definitions
EEPROM_SIZE	EQU	64
	__config 0x3FF1
    endif
	ifdef	__16F83
		list	p=16f83              ; 16F83 can be used
		#include <p16f83.inc>        ; processor specific variable definitions
	__config 0x3FF1
	endif
	ifdef	__16C84
		list	p=16C84              ; 16C84 can be used
		#include <p16c84.inc>        ; processor specific variable definitions
EEPROM_SIZE	EQU	64
	__config 0x3FF1
    endif
	ifdef	__16F84
		list	p=16f84              ; 16F84 can be used
		#include <p16f84.inc>        ; processor specific variable definitions
EEPROM_SIZE	EQU	64
	__config 0x3FF1
    endif
	ifdef	__16F84A
		list	p=16f84A             ; 16F84A can be used
EEPROM_SIZE	EQU	64
	__config 0x3FF1
    endif
	ifdef	__16F818
		list	p=16F818             ; 16F88 can be used
		#include <p16F818.inc>       ; processor specific variable definitions
EEPROM_SIZE	EQU	128
		__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _LVP_OFF
    endif
	ifdef	__16F819
		list	p=16F819             ; 16F88 can be used
		#include <p16F819.inc>       ; processor specific variable definitions
EEPROM_SIZE	EQU	128
    endif
	ifdef	__16F87
		list	p=16f87              ; 16F87 can be used
		#include <p16f87.inc>        ; processor specific variable definitions
EEPROM_SIZE	EQU	256
		__CONFIG _CONFIG1, _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _MCLRE_OFF & _LVP_OFF
		__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF 
    endif
	ifdef	__16F88
		list	p=16F88              ; 16F88 can be used
		#include <p16F88.inc>        ; processor specific variable definitions
EEPROM_SIZE	EQU	256
    endif
	ifndef	PORTA
		error	"Invalid processor type selected"
	endif
FOSC	EQU	.4000000		; 4.00 MHz clock frequency used
							; Default address to use ather power up
#define	DefaultAddress		0x1D
;#define	UsePage4		; Uncomment this line to use 4 command page mode 
    if EEPROM_SIZE >= 64
#define	UseLookUpTable		; Comment this line to send raw key codes
	endif
#define	VersionMajor	0x02
#define	VersionMinor	0x02
	__idlocs		0xC000 | (VersionMajor << 8) | (VersionMinor)
	cblock	0x20
		comcode					; Command code to send
		address					; Address to send  -  bit 5: toggle bit
		cntr					; Delay counter
		bitcnt					; Bit counter
		comset					; Current page number 0..2 or 0..3
		addrbutton				; Temp store of PORTA  -  Bit 4: address button 
	endc
		org		0x000
POWERON
		CLRWDT
		MOVLW	0x81 			; Pullups off,Prescaler 1:4 and int. Clock	
		BSF		STATUS,RP0
		GOTO	Main
		org		0x004
IT
		retfie
Delay200ms
		call	Delay100ms
Delay100ms
		movlw	.100
Delayms
		MOVWF	cntr
lDel1
		clrf	FSR
lDel2
		NOP  
		DECFSZ	FSR,1
		GOTO	lDel2
		DECFSZ	cntr,1
		GOTO	lDel1
		RETURN
SendBits
		movwf	FSR				; Save data to send
		movlw	.6
		movwf	bitcnt			; Save bit count
SendBits_loop
		btfsc	FSR,5			; Test bit
		CALL	SendBit1		; if bit==1 send a one
		btfss	FSR,5
		CALL	SendBit0		; if bit==0 send a zero
		RLF		FSR,f			; All bits to send are in the FSR, C is don't care
		decfsz	bitcnt,f		; Loop for all bits
		GOTO	SendBits_loop
		return
SendBit1
		call	SendPause
;		goto	SendBit
SendBit
		movlw	.32
		movwf	cntr
SendBit_loop
		BSF		PORTA,0			;1
		call	RET				;4
		call	RET				;4
		call	RET				;4
		BCF		PORTA,0			;1
		call	RET				;4
		call	RET				;4
		goto	$+1				;2
		decfsz	cntr,f			;1
		GOTO	SendBit_loop	;2
RET
		return
SendBit0
								;  890us with 36kHz modulation
								; 27.7us Periodtime - 32 Impulses
		call	SendBit
;		goto	SendPause
SendPause
		MOVLW	.32
		movwf	cntr
SendPause_loop
		call	RET				;4
		call	RET				;4
		call	RET				;4
		call	RET				;4
		call	RET				;4
		call	RET				;4
		decfsz	cntr,f			;1
		GOTO	SendPause_loop	;2
		return
; RC5 InfraRed Command Packet
;		Packet length: 24.899 ms, repeation time: 113.792 ms 		
;		Bit 1: 889uS - no pulses, 889us - 32 pulses 
;		Bit 0: 889uS - 32 pulses, 889us - no pulses 
;		S   s   T   A4  A3  A2  A1  A0  C5  C4  C3  C2  C1  C0
;		|1 |!c6|tg |a4 |a3 |a2 |a1 |a0 |c5 |c4 |c3 |c2 |c1 |c0 |
;		RC5  version s: second start bit : 1
;		RC5X version s: inverted bit 6 of command : !c6
;		tg: toggle bit: send the same bit for repeated packet sending
;						send opposite bit for a new command
SendTwoPackets
		SUBWF	comcode,W
		BTFSC	STATUS,C
SendTwoPackets0
		BCF		PORTA,1			; Turn on  visible LED
		CALL	SendIrPacket
		BSF		PORTA,1			; Turn off visible LED
SendIrPacket
		CALL	SendBit1		; First  Startbit = 1
		btfss	comcode,6
		CALL	SendBit1		; Second Startbit = inv of bit 6 of command code 
		btfsc	comcode,6
		CALL	SendBit0
		movf	address,w		; toggle bit and 5 Bit address
		call	SendBits
		movf	comcode,w		; 6 Bit command code
		call	SendBits
		BCF   	PORTA,0			; Turn off IR LED
		MOVLW	.113			; Delay 64 Bits @ 1,78ms = 113ms
		GOTO  	Delayms
Main
;;;		CLRWDT					; Done at reset
;;;		MOVLW	0x81 			; Pullups off,Prescaler 1:4 and int. Clock	
;;;		BSF		STATUS,RP0
		MOVWF	OPTION_REG
		MOVLW	0xF0
		MOVWF	TRISA			; Bit 3..0 Output 3: Extra 1 row drive, 2: Extra 0 row drive, 0: Visible Led 0: IR Led
		MOVWF	TRISB			; Bit 7..4 Key sense (port change hw) 3..0 Column drive
		BCF		STATUS,RP0
		MOVWF	PORTB			; Enable all raws
		CLRF	PORTA			; Turn on Visible Led
		CALL	Delay200ms
		CALL	Delay200ms
		CALL	Delay200ms
								; address = default address
		MOVLW	DefaultAddress
		MOVWF	address			; Clear toggle bit
		CLRF	comset			; Command page 0
	ifdef	CMCON				; If controller has comparator - disable it
	 if ((CMCON & 0x180)!=(PORTA & 0x180))
	  if ((CMCON & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	  if ((CMCON & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	 endif
		movlw	7
		movwf	CMCON
		clrf	STATUS
	 endif
	endif
	ifdef	ADCON1				; If controller has A/D - disable it
	 if ((ADCON1 & 0x180)!=(PORTA & 0x180))
	  if ((ADCON1 & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	  if ((ADCON1 & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	 endif
		movlw	7
		movwf	ADCON1
		clrf	STATUS
	 endif
	endif
	ifdef	ANSEL				; If controller has A/D - disable it
	 if ((ANSEL & 0x180)!=(PORTA & 0x180))
	  if ((ANSEL & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	  if ((ANSEL & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP01
	  endif
	 endif
		clrf	ANSEL
		clrf	STATUS
	 endif
	endif
		bsf		PORTA,1			; Turn off bouth Leds
MainLoop
;		MOVLW	0xF0			; Enabble all raws / done at reser and KeyUp
;		MOVWF	PORTB
		BCF   	INTCON,RBIF		; Clear Port Change Int Flag 
		BSF		INTCON,RBIE		; Enable Port Change Int
		SLEEP					; Goto sleep
		NOP  					; PortB change will wake up
		MOVF	PORTA,W			; Get a copy of PORTA
		MOVWF	addrbutton		; Bit 4 == 0 means Address button down
		BSF		comcode,7		; Command code invalid
		BCF   	INTCON,RBIE		; Disable Port Change Int
								; Scan of keymatrix		Normal raws			Extra raw
								; PORTB.4==0 	 		Buttons  0.. 3		Option 1
		CLRW
		BTFSS	PORTB,4
		CALL	FindRow
								; PORTB.5==0			Buttons  4.. 7		Option 2
		MOVLW	.4
		BTFSS	PORTB,5
		CALL	FindRow
								; PORTB.6==0			Buttons  8..11		Option 3
		MOVLW	.8
		BTFSS	PORTB,6
		CALL	FindRow
								; PORTB.7==0			Buttons 12..15		Shift
		MOVLW	.12
		BTFSS	PORTB,7
		CALL	FindRow
		BTFSC	comcode,7		; Test for key detected
		GOTO	KeyUp			; No -> Wait for all key up
		MOVLW	0x10
		SUBWF	comcode,W		; Test for normal key
		BTFSS	addrbutton,4	; Test for Address key down
		BTFSC	STATUS,C
		GOTO	NotAddress		; No -> Test for Shift
		movf	comcode,w
		xorwf	address,w
		andlw	0x0f
		btfsc	STATUS,Z
		goto	KeyUp
		MOVLW	0x0F			; Combine key code and address:4
		ANDWF	comcode,W
		IORLW	0x10
		MOVWF	address			; Set new address, clear toggle bit
NotAddress
								; Test for shift button
		MOVF	comcode,W
		XORLW	0x4C
		BTFSS 	STATUS,Z
		GOTO	NormalButton	; No -> Test for normal button
								; Shift button pressed - roll command page
		MOVLW	0x10
		ADDWF	comset,f
		MOVF	comset,W
	ifdef	UsePage4
		XORLW	0x40
	else
		XORLW	0x30
	endif
		BTFSC 	STATUS,Z
		CLRF	comset
								; Sign active set on visible led
		call	FlashLED0
		MOVLW	.16
		call	FlashLED
		MOVLW	.32
		call	FlashLED
	ifdef	UsePage4
		MOVLW	.48
		call	FlashLED
	endif
		goto	KeyUp			; Wait for all keys up
FlashLED
		SUBWF	comset,W
		BTFSC 	STATUS,C
FlashLED0
		BCF		PORTA,1
		CALL	Delay100ms
		BSF		PORTA,1
		goto	Delay100ms
NormalButton					; Test for normal buttons
		MOVLW	.16
		SUBWF	comcode,W
		BTFSC	STATUS,C
		GOTO	KeyUp
								; Normal button pressed
		ANDWF	comset,W		; Combine comcode and comset
		IORWF	comcode,f
								; If comcode < 64 send it
		MOVLW	0x40
		SUBWF	comcode,W
		BTFSC 	STATUS,C
	ifdef	UseLookUpTable
		movf	comcode,w		; Read look-up table
		call	EpromRead
		movwf	comcode			; 0x80..0xFF means No command assigned for this key 
		btfsc	comcode,7
		goto	KeyUp
	endif
								; Send command for 5 times
		call	SendTwoPackets0
		MOVLW	.16
		call	SendTwoPackets
		MOVLW	.32
		call	SendTwoPackets
	ifdef	UsePage4
		MOVLW	.48
		call	SendTwoPackets
	endif
		movlw	0x20
		xorwf	address,f		; Invert toggle:0
		MOVLW	0xF0			; Enable all raws
		MOVWF	PORTB
		ANDWF	PORTB,W
		XORLW	0xF0
		BTFSS 	STATUS,Z
		GOTO	KeyUp
		MOVLW	.50
		CALL	Delayms
		GOTO	MainLoop
FindRow							; Find a key in raw number in w
		movwf	comcode			; Store raw number
		MOVWF	FSR
		MOVLW 	.1				; Init mask
		MOVWF	PORTB			; Drive only one column
FindRaw_loop
		MOVF	PORTB,W			; Check if all columns high
		andlw	0xF0
		XORLW	0xF0
		BTFSC 	STATUS,Z
		goto	RawFound		; Key found - comcode holds it's code
		INCF	comcode,f		; Move comcode
		BCF		STATUS,C
		RLF		PORTB,f			; Shift column drive
		movf	PORTB,w
		andlw	0x0F
		BTFSS	STATUS,Z		; All columns read
		GOTO	FindRaw_loop	; Loop for all columns
		MOVLW	0x40			; There was no key down in matrix
		IORWF	FSR,W
		MOVWF	comcode			; Must be an extra key
RawFound
		movlw	0xF0
		movwf	PORTB
		RETURN
; Reads keycode from EEProm memory at w - returns with Bank0 selection
EpromRead
	if  ((EEADR & 0x80)!=(PORTA & 0x80))
	  if ((EEADR & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	endif
	if  ((EEADR & 0x100)!=(PORTA & 0x100))
	  if ((EEADR & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	endif
		movwf	EEADR
	if  ((EECON1 & 0x80)!=(EEADR & 0x80))
	  if ((EECON1 & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	endif
	if  ((EECON1 & 0x100)!=(EEADR & 0x100))
	endif
		bsf		EECON1,RD		; read character from EEProm
	if ((EEDATA & 0x80)!=(EECON1 & 0x80))
	  if ((EEDATA & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	endif
	if ((EEDATA & 0x100)!=(EECON1 & 0x100))
	  if ((EEDATA & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	endif
		movf	EEDATA,w		; Get next character
	if ((PORTA & 0x180)!=(EEDATA & 0x180))
	  if ((PORTA & 0x80)==0x80)
		bsf		STATUS,RP0
	  else
		bcf		STATUS,RP0
	  endif
	endif
	  if ((PORTA & 0x100)==0x100)
		bsf		STATUS,RP1
	  else
		bcf		STATUS,RP1
	  endif
	endif
		return
  endif
	org		0x2100
; Key code - command code look up table
; 0x00 - 0x7F : Command code to send for 
; 0x80 - 0xFF : No command assigned for this key 
; Page 1
; Button   0    1    2    3    4    5    6    7    8    9   10   11   12   13   14   15
	DE	0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F
; Page 2
	DE	0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1A,0x1B,0x1C,0x1D,0x1E,0x1F
; Page 3
	DE	0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2A,0x2B,0x2C,0x2D,0x2E,0x2F
; Page 4
	DE	0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3A,0x3B,0x3C,0x3D,0x3E,0x3F
	END
