; Source created with Parsic Version 3.x
; at              : 2017.04.12. 15:38:05
; Project File    : C:\Users\D8A8A~1.CSA\AppData\Local\Temp\HS_drot-2.PIC
; Project Version : 1.0.12
; Created         : 2001.07.24. 15:00:00
; Last change     : 2017.04.10. 14:40:00
	PROCESSOR 16F877
	INCLUDE P16F877.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_ON & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S1	= 32	; located in Bank 0
TR1	= 33	; located in Bank 0
TR1_HI	= 34	; located in Bank 0
S4	= 35	; located in Bank 0
S0	= 36	; located in Bank 0
S3	= 37	; located in Bank 0
OS1_FD	= 38	; located in Bank 0
OS2_FD	= 39	; located in Bank 0
OS3_FD	= 40	; located in Bank 0
ZV1	= 41	; located in Bank 0
ZV1_FD	= 42	; located in Bank 0
OS4_FD	= 43	; located in Bank 0
ZV2	= 44	; located in Bank 0
ZV2_FD	= 45	; located in Bank 0
OS5_FD	= 46	; located in Bank 0
ZV3	= 47	; located in Bank 0
ZV3_FD	= 48	; located in Bank 0
S2	= 49	; located in Bank 0
ZV4	= 50	; located in Bank 0
ZV4_FD	= 51	; located in Bank 0
S5	= 52	; located in Bank 0
OS6_FD	= 53	; located in Bank 0
RAM	= 54	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 117	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 120	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 121	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplication 8 - Bit
SYSMUL8
	CLRF SYS_TMP3
	MOVLW 8
	MOVWF SYS_TMP4
SYSMUL8_1
	MOVFW SYS_TMP1
	RRF SYS_TMP2,F
	BTFSC STATUS,CARRY
	ADDWF SYS_TMP3,F
	RLF SYS_TMP1,F
	DECFSZ SYS_TMP4,F
	GOTO SYSMUL8_1
	RETURN
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'00000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
	MOVLW B'00001111'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CLRWDT
; Call subroutine BIN_TO_7SEG
	MOVLW LOW BIN_TO_7SEG
	MOVWF SYS_TMP1
	MOVLW HIGH BIN_TO_7SEG
	MOVWF SYS_TMP2
	MOVFW S0
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVLW HIGH SYSTABJMP	; set page
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S1
	BSF INTCON,GIE
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 8
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 8
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S4,0
	GOTO LABEL_TR1_CLR
	BSF S4,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S4,0
LABEL_TR1_ENDE
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW ZV1
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW ZV3
	MOVWF S0
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW ZV1
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW ZV2
	MOVWF S0
	GOTO LABEL_MX1_END
LABEL_MX1_END
; UND - Gatter -> UG12
LABEL_UG12_1
	BTFSC S3,0
	GOTO LABEL_UG12_FALSE
LABEL_UG12_2
	BTFSC S3,1
LABEL_UG12_3
	BTFSS S3,4
LABEL_UG12_TRUE
	BSF PORTD,4
	GOTO LABEL_UG12_ENDE
LABEL_UG12_FALSE
	BCF PORTD,4
LABEL_UG12_ENDE
; UND - Gatter -> UG13
LABEL_UG13_1
	BTFSS S3,0
	GOTO LABEL_UG13_FALSE
LABEL_UG13_2
	BTFSC S3,1
LABEL_UG13_3
	BTFSS S3,4
LABEL_UG13_TRUE
	BSF PORTD,5
	GOTO LABEL_UG13_ENDE
LABEL_UG13_FALSE
	BCF PORTD,5
LABEL_UG13_ENDE
; UND - Gatter -> UG14
LABEL_UG14_1
	BTFSC S3,0
	GOTO LABEL_UG14_FALSE
LABEL_UG14_2
	BTFSS S3,1
LABEL_UG14_3
	BTFSS S3,4
LABEL_UG14_TRUE
	BSF PORTD,6
	GOTO LABEL_UG14_ENDE
LABEL_UG14_FALSE
	BCF PORTD,6
LABEL_UG14_ENDE
; One Shot -> OS1
	BTFSS S4,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S3,5
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S3,5
	BTFSC S4,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSC S3,5
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S3,6
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S3,6
	BTFSS S3,5
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSC S3,6
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S3,7
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S3,7
	BTFSS S3,6
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; RS-FLIP-FLOP -> RS1
	BTFSC S3,5
	GOTO LABEL_RS1_RESET
	BTFSS S3,7
	GOTO LABEL_RS1_ENDE
	BSF S3,4	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S3,4	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; UND - Gatter -> UG15
LABEL_UG15_1
	BTFSS S3,0
	GOTO LABEL_UG15_FALSE
LABEL_UG15_2
	BTFSS S3,1
LABEL_UG15_3
	BTFSS S3,4
LABEL_UG15_TRUE
	BSF PORTD,7
	GOTO LABEL_UG15_ENDE
LABEL_UG15_FALSE
	BCF PORTD,7
LABEL_UG15_ENDE
; Zähler -> ZV1
	BTFSS S3,2	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf negative Flanke
	BTFSC S3,5
	GOTO LABEL_ZV1_SETFD
	BTFSS ZV1_FD,0
	BCF ZV1_FD,0
	BTFSC S3,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
; Output Q0
	BTFSS ZV1,0
	GOTO LABEL_ZV1_SETOUT0
	BSF S3,0
	GOTO LABEL_ZV1_SETOUT0_END
LABEL_ZV1_SETOUT0
	BCF S3,0
; Output Q1
	BTFSS ZV1,1
	GOTO LABEL_ZV1_SETOUT1
	BSF S3,1
	GOTO LABEL_ZV1_SETOUT1_END
LABEL_ZV1_SETOUT1
	BCF S3,1
; Output Q2
	BTFSS ZV1,2
	GOTO LABEL_ZV1_SETOUT2
	BSF S3,2
	GOTO LABEL_ZV1_SETOUT2_END
LABEL_ZV1_SETOUT2
	BCF S3,2
LABEL_ZV1_SETFD
; Test auf positive Flanke
	BTFSS S3,5
	GOTO LABEL_ZV1_EXIT
	BSF ZV1_FD,0
LABEL_ZV1_EXIT
; Verteiler -> BV1
	BTFSC S1,0
	GOTO LABEL_BV1_0
	BCF PORTB,6
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,6
LABEL_BV1_0_END
	BTFSC S1,1
	GOTO LABEL_BV1_1
	BCF PORTB,7
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,7
LABEL_BV1_1_END
	BTFSC S1,2
	GOTO LABEL_BV1_2
	BCF PORTB,5
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,5
LABEL_BV1_2_END
	BTFSC S1,3
	GOTO LABEL_BV1_3
	BCF PORTB,2
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTB,2
LABEL_BV1_3_END
	BTFSC S1,4
	GOTO LABEL_BV1_4
	BCF PORTB,1
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF PORTB,1
LABEL_BV1_4_END
	BTFSC S1,5
	GOTO LABEL_BV1_5
	BCF PORTB,4
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF PORTB,4
LABEL_BV1_5_END
	BTFSC S1,6
	GOTO LABEL_BV1_6
	BCF PORTB,3
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF PORTB,3
LABEL_BV1_6_END
	BTFSC S1,7
	GOTO LABEL_BV1_7
	BCF PORTB,0
	GOTO LABEL_BV1_7_END
LABEL_BV1_7
	BSF PORTB,0
LABEL_BV1_7_END
; GND
	BCF S3,3	; immer Low
; Vergleich -> IF1
	MOVLW 10
	SUBWF ZV2,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S4,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S4,1
LABEL_IF1_EXIT
; One Shot -> OS4
	BTFSC PORTD,3
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S4,2
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S4,2
	BTFSS PORTD,3
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; Zähler -> ZV2
	BTFSS S4,1	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S4,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S4,5	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S4,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Vergleich -> IF2
	MOVLW 10
	SUBWF ZV3,W	; F - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S4,3
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S4,3
LABEL_IF2_EXIT
; One Shot -> OS5
	BTFSC PORTD,2
	GOTO LABEL_OS5_1
	BTFSC OS5_FD,0
	GOTO LABEL_OS5_1
	BSF OS5_FD,0
	BSF S4,4
	GOTO LABEL_OS5_2
LABEL_OS5_1
	BCF S4,4
	BTFSS PORTD,2
	GOTO LABEL_OS5_2
	BCF OS5_FD,0
LABEL_OS5_2
; Zähler -> ZV3
	BTFSS S4,3	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S4,4
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S4,4
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; GND
	BCF S4,5	; immer Low
;AF1
	MOVFW ZV3
	ADDWF S2,W
	MOVWF S3
LABEL_AF1_EXIT
;AF2
	MOVFW ZV2
	MOVWF SYS_TMP1
	MOVLW 10
	MOVWF SYS_TMP2
	MOVLW HIGH SYSMUL8
	MOVWF PCLATH
	CALL SYSMUL8
	MOVLW HIGH LABEL_AF2
	MOVWF PCLATH
LABEL_AF2
	MOVFW SYS_TMP3
	MOVWF S2
LABEL_AF2_EXIT
; Zähler -> ZV4
	BTFSS S4,7	; Reset ?
	GOTO LABEL_ZV4_COUNT
	CLRF ZV4
	GOTO LABEL_ZV4_SETOUT
LABEL_ZV4_COUNT
	BTFSS S4,6
	GOTO LABEL_ZV4_SETFD
	BTFSC ZV4_FD,0
	BSF ZV4_FD,0
	BTFSC S5,0	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV4_BACKWARD
	INCF ZV4,F
LABEL_ZV4_BACKWARD
	DECF ZV4,F
LABEL_ZV4_SETOUT
LABEL_ZV4_SETFD
	BTFSC S4,6
	GOTO LABEL_ZV4_EXIT
	BCF ZV4_FD,0
LABEL_ZV4_EXIT
; GND
	BCF S5,0	; immer Low
; One Shot -> OS6
	BTFSC PORTC,3
	GOTO LABEL_OS6_1
	BTFSC OS6_FD,0
	GOTO LABEL_OS6_1
	BSF OS6_FD,0
	BSF S4,6
	GOTO LABEL_OS6_2
LABEL_OS6_1
	BCF S4,6
	BTFSS PORTC,3
	GOTO LABEL_OS6_2
	BCF OS6_FD,0
LABEL_OS6_2
; Vergleich -> IF3
	MOVFW ZV4
	SUBWF S3,W	; F - W -> W
LABEL_IF3_CHECK
	BTFSC STATUS,CARRY	; Test auf -> <
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S4,7
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S4,7
LABEL_IF3_EXIT
	GOTO MAIN
; Table -> BIN_TO_7SEG
BIN_TO_7SEG
	RETLW 63	; // INDEX 0
	RETLW 6	; // INDEX 1
	RETLW 91	; // INDEX 2
	RETLW 79	; // INDEX 3
	RETLW 102	; // INDEX 4
	RETLW 109	; // INDEX 5
	RETLW 125	; // INDEX 6
	RETLW 7	; // INDEX 7
	RETLW 127	; // INDEX 8
	RETLW 111	; // INDEX 9
	RETLW 63	; // INDEX 10
	END
