#include <LiquidCrystal_I2C.h>
Arduino Nano OBD reader (OBD protocol KW1281,  Audi A4 B5 etc.)
wiring:
D2 --- OBD level shifter input (RX) (e.g. LM339)
D3 --- OBD level shifter output (TX) (e.g. LM339)
A5 --- Arduino 20x4 LCD display SCL
A4 --- Arduino 20x4 LCD display SDA
NOTE: For the level shifting, I used a 'AutoDia K409 Profi USB adapter', disassembled it,
      and connected the Arduino to the level shifter chip (LM339) - the original FTDI chip TX line
      was removed (so it does not influence the communication)
#include <Wire.h>
//#include "LiquidCrystal.h"
#include "NewSoftwareSerial.h"
#define pinKLineRX 10
#define pinKLineTX 11
#define pinLED 9
#define pinBuzzer 5
#define pinButton 3
// https://www.blafusel.de/obd/obd2_kw1281.html
#define ADR_Engine 0x01
#define ADR_Gears  0x02
#define ADR_ABS_Brakes 0x03
#define ADR_Airbag 0x15
#define ADR_Dashboard 0x17
#define ADR_Immobilizer 0x25
#define ADR_Central_locking 0x35
//#define DEBUG 1
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x20 for a 16 chars and 2 line display
// RS,Enable,D4,D5,D6,D7,  10k resistor 5v-out-gnd
//LiquidCrystal lcd(13, 11, 7, 6 , 5, 4);
NewSoftwareSerial obd(pinKLineRX, pinKLineTX, false); // RX, TX, inverse logic
uint8_t currAddr = 0;
uint8_t blockCounter = 0;
uint8_t errorTimeout = 0;
uint8_t errorData = 0;
bool connected = false;
int sensorCounter = 0;
int pageUpdateCounter = 0;
int alarmCounter = 0;
uint8_t currPage = 1;
float coolantTemp = 0;
int8_t oilTemp = 0;
int8_t intakeAirTemp = 0;
int8_t oilPressure = 0;
float engineLoad = 0;
int   engineSpeed = 0;
int   nyomas = 0;
float throttleValve = 0;
float supplyVoltage = 0;
uint8_t vehicleSpeed = 0;
float fuelConsumption = 0;
uint8_t fuelLevel = 0;
unsigned long odometer = 0;
float actTrip = 0.0;
float actFuel = 0.0;
unsigned long tripTime = 0UL;
unsigned long fuelTime = 0UL;
String floatToString(float v) {
  String res;
  char buf[16];
  dtostrf(v, 4, 2, buf);
  res = String(buf);
  return res;
void disconnect() {
  connected = false;
  currAddr = 0;
void lcdPrint(int x, int y, String s, int width = 0) {
  lcd.setCursor(x, y);
  while (s.length() < width) s += " ";
  lcd.print(s);
void obdWrite(uint8_t data) {
#ifdef DEBUG
  Serial.print("uC:");
  Serial.println(data, HEX);
#endif
  //*********************  ADDED 5ms delay ****************************************************************
  delay(5);
  obd.write(data);
uint8_t obdRead() {
  unsigned long timeout = millis() + 1000;
  while (!obd.available()) {
    if (millis() >= timeout) {
      Serial.println(F("ERROR: obdRead timeout"));
      disconnect();
      errorTimeout++;
      return 0;
  uint8_t data = obd.read();
#ifdef DEBUG
  Serial.print("ECU:");
#endif
  return data;
// 5Bd, 7O1
void send5baud(uint8_t data) {
  // // 1 start bit, 7 data bits, 1 parity, 1 stop bit
#define bitcount 10
  byte bits[bitcount];
  byte even = 1;
  byte bit;
  for (int i = 0; i < bitcount; i++) {
    bit = 0;
    if (i == 0)  bit = 0;
    else if (i == 8) bit = even; // computes parity bit
    else if (i == 9) bit = 1;
    else {
      bit = (byte) ((data & (1 << (i - 1))) != 0);
      even = even ^ bit;
    Serial.print(F("bit"));
    Serial.print(i);
    Serial.print(F("="));
    Serial.print(bit);
    if (i == 0) Serial.print(F(" startbit"));
    else if (i == 8) Serial.print(F(" parity"));
    else if (i == 9) Serial.print(F(" stopbit"));
    Serial.println();
    bits[i] = bit;
  // now send bit stream
  for (int i = 0; i < bitcount + 1; i++) {
    if (i != 0) {
      // wait 200 ms (=5 baud), adjusted by latency correction
      delay(200);
      if (i == bitcount) break;
    if (bits[i] == 1) {
      // high
      digitalWrite(pinKLineTX, HIGH);
    } else {
      // low
      digitalWrite(pinKLineTX, LOW);
  obd.flush();
bool KWP5BaudInit(uint8_t addr) {
  Serial.println(F("---KWP 5 baud init"));
  //delay(3000);
  send5baud(addr);
  return true;
bool KWPSendBlock(char *s, int size) {
  Serial.print(F("---KWPSend sz="));
  Serial.print(size);
  Serial.print(F(" blockCounter="));
  Serial.println(blockCounter);
  // show data
  Serial.print(F("OUT:"));
  for (int i = 0; i < size; i++) {
    uint8_t data = s[i];
    Serial.print(data, HEX);
    Serial.print(" ");
  Serial.println();
    obdWrite(data);
    /*uint8_t echo = obdRead();
    if (data != echo){
      Serial.println(F("ERROR: invalid echo"));
      disconnect();
      errorData++;
      return false;
    if (i < size - 1) {
      uint8_t complement = obdRead();
      if (complement != (data ^ 0xFF)) {
        Serial.println(F("ERROR: invalid complement"));
        disconnect();
        errorData++;
        return false;
  blockCounter++;
  return true;
// count: if zero given, first received byte contains block length
// 4800, 9600 oder 10400 Baud, 8N1
bool KWPReceiveBlock(char s[], int maxsize, int &size) {
  bool ackeachbyte = false;
  uint8_t data = 0;
  int recvcount = 0;
  if (size == 0) ackeachbyte = true;
  Serial.print(F("---KWPReceive sz="));
  Serial.print(size);
  if (size > maxsize) {
    Serial.println("ERROR: invalid maxsize");
    return false;
  while ((recvcount == 0) || (recvcount != size)) {
    while (obd.available()) {
      data = obdRead();
      s[recvcount] = data;
      recvcount++;
      if ((size == 0) && (recvcount == 1)) {
        size = data + 1;
          return false;
      if ((ackeachbyte) && (recvcount == 2)) {
        if (data != blockCounter) {
          Serial.println(F("ERROR: invalid blockCounter"));
          disconnect();
          errorData++;
          return false;
      if ( ((!ackeachbyte) && (recvcount == size)) ||  ((ackeachbyte) && (recvcount < size)) ) {
        obdWrite(data ^ 0xFF);  // send complement ack
        if (echo != (data ^ 0xFF)){
          Serial.print(F("ERROR: invalid echo "));
          Serial.println(echo, HEX);
          disconnect();
          errorData++;
          return false;
      Serial.println(F("ERROR: timeout"));
      disconnect();
      errorTimeout++;
      return false;
  // show data
  Serial.print(F("IN: sz="));
  Serial.print(size);
  Serial.print(F(" data="));
    Serial.print(F(" "));
  Serial.println();
  blockCounter++;
  return true;
bool KWPSendAckBlock() {
  Serial.print(F("---KWPSendAckBlock blockCounter="));
  char buf[32];
  sprintf(buf, "\x03%c\x09\x03", blockCounter);
  return (KWPSendBlock(buf, 4));
bool connect(uint8_t addr, int baudrate) {
  Serial.print(F("------connect addr="));
  Serial.print(addr);
  Serial.print(F(" baud="));
  Serial.println(baudrate);
  tone(pinBuzzer, 1200);
  delay(100);
  noTone(pinBuzzer);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Connecting.");
  //  lcdPrint(0, 1, "", 20);
  //  lcdPrint(0, 2, "", 20);
  blockCounter = 0;
  currAddr = 0;
  obd.begin(baudrate);
  KWP5BaudInit(addr);
  // answer: 0x55, 0x01, 0x8A
  char s[3];
  lcd.print("Connecting..");
  int size = 3;
  if (!KWPReceiveBlock(s, 3, size)) return false;
  if (    (((uint8_t)s[0]) != 0x55)
          ||   (((uint8_t)s[1]) != 0x01)
          ||   (((uint8_t)s[2]) != 0x8A)   ) {
    Serial.println(F("ERROR: invalid magic"));
    disconnect();
    errorData++;
    return false;
  currAddr = addr;
  connected = true;
  if (!readConnectBlocks()) return false;
  return true;
bool readConnectBlocks() {
  // read connect blocks
  Serial.println(F("------readconnectblocks"));
  lcd.print(" --B5 CarComp--");
  String info;
  while (true) {
    int size = 0;
    char s[64];
    if (!(KWPReceiveBlock(s, 64, size))) return false;
    if (size == 0) return false;
    if (s[2] == '\x09') break;
    if (s[2] != '\xF6') {
      Serial.println(F("ERROR: unexpected answer"));
      disconnect();
      errorData++;
      return false;
    String text = String(s);
    info += text.substring(3, size - 2);
    if (!KWPSendAckBlock()) return false;
  Serial.print("label=");
  Serial.println(info);
  //lcd.setCursor(0, 1);
  //lcd.print(info);
  return true;
bool readSensors(int group) {
  Serial.print(F("------readSensors "));
  Serial.println(group);
  //lcd.setCursor(0, 0);
  // lcd.print("KW1281 sensor");
  char s[64];
  sprintf(s, "\x04%c\x29%c\x03", blockCounter, group);
  if (!KWPSendBlock(s, 5)) return false;
  int size = 0;
  KWPReceiveBlock(s, 64, size);
  if (s[2] != '\xe7') {
    Serial.println(F("ERROR: invalid answer"));
    disconnect();
    errorData++;
    return false;
  int count = (size - 4) / 3;
  Serial.print(F("count="));
  Serial.println(count);
  for (int idx = 0; idx < count; idx++) {
    byte k = s[3 + idx * 3];
    byte a = s[3 + idx * 3 + 1];
    byte b = s[3 + idx * 3 + 2];
    String n;
    float v = 0;
    Serial.print(F("type="));
    Serial.print(k);
    Serial.print(F("  a="));
    Serial.print(a);
    Serial.print(F("  b="));
    Serial.print(b);
    Serial.print(F("  text="));
    String t = "";
    String units = "";
    char buf[32];
    switch (k) {
      case 1:  v = 0.2 * a * b;             units = F("rpm"); break;
      case 2:  v = a * 0.002 * b;           units = F("%%"); break;
      case 3:  v = 0.002 * a * b;           units = F("Deg"); break;
      case 4:  v = abs(b - 127) * 0.01 * a;   units = F("ATDC"); break;
      case 5:  v = a * (b - 100) * 0.1;       units = F("°C"); break;
      case 6:  v = 0.001 * a * b;           units = F("V"); break;
      case 7:  v = 0.01 * a * b;            units = F("km/h"); break;
      case 8:  v = 0.1 * a * b;             units = F(" "); break;
      case 9:  v = (b - 127) * 0.02 * a;      units = F("Deg"); break;
      case 10: if (b == 0) t = F("COLD"); else t = F("WARM"); break;
      case 11: v = 0.0001 * a * (b - 128) + 1;  units = F(" "); break;
      case 12: v = 0.001 * a * b;           units = F("Ohm"); break;
      case 13: v = (b - 127) * 0.001 * a;     units = F("mm"); break;
      case 14: v = 0.005 * a * b;           units = F("bar"); break;
      case 15: v = 0.01 * a * b;            units = F("ms"); break;
      case 18: v = 0.04 * a * b;            units = F("mbar"); break;
      case 19: v = a * b * 0.01;            units = F("l"); break;
      case 20: v = a * (b - 128) / 128;       units = F("%%"); break;
      case 21: v = 0.001 * a * b;           units = F("V"); break;
      case 22: v = 0.001 * a * b;           units = F("ms"); break;
      case 23: v = b / 256 * a;             units = F("%%"); break;
      case 24: v = 0.001 * a * b;           units = F("A"); break;
      case 25: v = (b * 1.421) + (a / 182);   units = F("g/s"); break;
      case 26: v = float(b - a);          units = F("C"); break;
      case 27: v = abs(b - 128) * 0.01 * a;   units = F("°"); break;
      case 28: v = float(b - a);          units = F(" "); break;
      case 30: v = b / 12 * a;              units = F("Deg k/w"); break;
      case 31: v = b / 2560 * a;            units = F("°C"); break;
      case 33: v = 100 * b / a;             units = F("%%"); break;
      case 34: v = (b - 128) * 0.01 * a;      units = F("kW"); break;
      case 35: v = 0.01 * a * b;            units = F("l/h"); break;
      case 36: v = ((unsigned long)a) * 2560 + ((unsigned long)b) * 10;  units = F("km"); break;
      case 37: v = b; break; // oil pressure ?!
      // ADP: FIXME!
      /*case 37: switch(b){
             case 0: sprintf(buf, F("ADP OK (%d,%d)"), a,b); t=String(buf); break;
             case 1: sprintf(buf, F("ADP RUN (%d,%d)"), a,b); t=String(buf); break;
             case 0x10: sprintf(buf, F("ADP ERR (%d,%d)"), a,b); t=String(buf); break;
             default: sprintf(buf, F("ADP (%d,%d)"), a,b); t=String(buf); break;
      case 38: v = (b - 128) * 0.001 * a;        units = F("Deg k/w"); break;
      case 39: v = b / 256 * a;                units = F("mg/h"); break;
      case 40: v = b * 0.1 + (25.5 * a) - 400;     units = F("A"); break;
      case 41: v = b + a * 255;                units = F("Ah"); break;
      case 42: v = b * 0.1 + (25.5 * a) - 400;     units = F("Kw"); break;
      case 43: v = b * 0.1 + (25.5 * a);         units = F("V"); break;
      case 44: sprintf(buf, "%2d:%2d", a, b); t = String(buf); break;
      case 45: v = 0.1 * a * b / 100;            units = F(" "); break;
      case 46: v = (a * b - 3200) * 0.0027;      units = F("Deg k/w"); break;
      case 47: v = (b - 128) * a;              units = F("ms"); break;
      case 48: v = b + a * 255;                units = F(" "); break;
      case 49: v = (b / 4) * a * 0.1;            units = F("mg/h"); break;
      case 50: v = (b - 128) / (0.01 * a);       units = F("mbar"); break;
      case 51: v = ((b - 128) / 255) * a;        units = F("mg/h"); break;
      case 52: v = b * 0.02 * a - a;             units = F("Nm"); break;
      case 53: v = (b - 128) * 1.4222 + 0.006 * a;  units = F("g/s"); break;
      case 54: v = a * 256 + b;                units = F("count"); break;
      case 55: v = a * b / 200;                units = F("s"); break;
      case 56: v = a * 256 + b;                units = F("WSC"); break;
      case 57: v = a * 256 + b + 65536;          units = F("WSC"); break;
      case 59: v = (a * 256 + b) / 32768;        units = F("g/s"); break;
      case 60: v = (a * 256 + b) * 0.01;         units = F("sec"); break;
      case 62: v = 0.256 * a * b;              units = F("S"); break;
      case 64: v = float(a + b);             units = F("Ohm"); break;
      case 65: v = 0.01 * a * (b - 127);         units = F("mm"); break;
      case 66: v = (a * b) / 511.12;          units = F("V"); break;
      case 67: v = (640 * a) + b * 2.5;         units = F("Deg"); break;
      case 68: v = (256 * a + b) / 7.365;       units = F("deg/s"); break;
      case 69: v = (256 * a + b) * 0.3254;     units = F("Bar"); break;
      case 70: v = (256 * a + b) * 0.192;      units = F("m/s^2"); break;
      default: sprintf(buf, "%2x, %2x      ", a, b); break;
    switch (currAddr) {
      case ADR_Engine:
        switch (group) {
          /*          case 3:
                      switch (idx) {
                        case 0: engineSpeed = v; break;
                        case 1: supplyVoltage = v; break;
                        case 2: coolantTemp = v; break;
                        case 3: intakeAirTemp = v; break;
                      break;
                    case 11:
                      switch (idx) {
                        case 1: engineLoad = v; break;
                        case 2: vehicleSpeed = v; break;
                        case 3: fuelConsumption = v; break;
                      break;*/
// *************** VPI ****************************************************************************************
          // 6-0 vehicle speed, 12-2 Supply voltage, 12-3 coolant temp, 15-2 fuel consumption
          case 6:
            switch (idx) {
              //  case 0: engineSpeed = v; break;
              case 0: vehicleSpeed = v;
                if (vehicleSpeed > 0)
                  actTrip = actTrip + ((vehicleSpeed / 3600.0) * (millis() - tripTime)); //m
                  Serial.print("  Act Trip: ");
                  Serial.println(actTrip);
                tripTime = millis();
                break;
            break;
            case 7:
            switch (idx) {
              case 0: oilTemp = v; break;
            break;
           case 12:
            switch (idx) {
              case 2: supplyVoltage = v; break;
              case 3: coolantTemp = v; break;
            break;
          case 23:
            switch (idx) {
              case 0: nyomas = v; break;
            break;
          case 15:
            switch (idx) {
              case 2: fuelConsumption = v;
                //************************* fuel calculation *****************************************************
                actFuel = actFuel + ((fuelConsumption / 3600.0) * (millis() - fuelTime)); //mLt
                fuelTime = millis();
                Serial.print("  Act Fuel: ");
                Serial.println(actFuel);
                break;
            break;
        break;
        /*     case ADR_Dashboard:
               switch (group) {
                 case 1:
                   switch (idx) {
                     case 0: vehicleSpeed = v; break;
                     case 1: engineSpeed = v; break;
                     case 2: oilPressure = v; break;
                   break;
                 case 2:
                   switch (idx) {
                     case 0: odometer = v; break;
                     case 1: fuelLevel = v; break;
                   break;
                 case 50:
                   switch (idx) {
                     case 2: oilTemp = v; break;
                   break;
        break;
    if (units.length() != 0) {
      t = String(buf) + " " + units;
    Serial.println(t);
    //lcd.setCursor(0, idx);
    //while (t.length() < 20) t += " ";
    //lcd.print(t);
  sensorCounter++;
  return true;
void alarm() {
  //  if (alarmCounter > 10) return;
  //  tone(pinBuzzer, 1200);
  //  delay(100);
  //  noTone(pinBuzzer);
  //  alarmCounter++;
void updateDisplay() {
  if (!connected) {
    if ( (errorTimeout != 0) || (errorData != 0) ) {
      lcd.print(" ");
      lcd.setCursor(0, 9);
      lcd.print(errorTimeout);
      lcd.print("ERROR");
      lcd.setCursor(6, 1);
      lcd.print(errorData);
  }  else {
     /*  switch (currPage) {
         case 1:
           if (coolantTemp > 99) {
             lcdPrint(0, 1, F("COOL"));
             alarm();
           } else lcdPrint(0, 1, F("cool"));
           lcdPrint(6, 1, String(coolantTemp), 3);
           if ( (oilTemp > 99) || ((oilPressure != 30) && (oilPressure != 31)) ) {
             lcdPrint(10, 1, F("OIL "));
             alarm();
           } else lcdPrint(10, 1, F("oil "));
           lcdPrint(14, 1, String(oilPressure), 3);
           lcdPrint(0, 2, F("rpm "));
           lcdPrint(4, 2, String(engineSpeed), 4);
           lcdPrint(10, 2, F("km/h "));
           lcdPrint(15, 2, String(vehicleSpeed, 3));
           lcdPrint(0, 3, F("fuel "));
           lcdPrint(5, 3, String(fuelLevel), 3);
           lcdPrint(10, 3, F("odo "));
           lcdPrint(14, 3, String(odometer), 6);
           break;
         case 2:
             alarm();
           lcdPrint(10, 1, F("air "));
           lcdPrint(14, 1, String(intakeAirTemp), 3);
           lcdPrint(5, 3, String(fuelConsumption), 3);
           lcdPrint(10, 3, F("volt "));
           lcdPrint(15, 3, String(supplyVoltage), 5);
           break;
    //****** LCD actual cons
     lcd.clear();
      lcd.print(String((fuelConsumption / float(vehicleSpeed)) * 100.0));
      lcd.setCursor(4, 0);
      lcd.print("L/100");
    else
      lcd.print(fuelConsumption);
      lcd.print("L/h  ");
    lcd.setCursor(9,0);
    lcd.print(" ");
    lcd.setCursor(10, 0);
   // if (actTrip > 5.0)
      lcd.print(String((actFuel / actTrip) * 100.0)); // mLt/m is same as Lt/km
      lcd.setCursor(14, 0);
      lcd.print("L/100");
  //  else
    lcd.setCursor(9,2);
      lcd.print(String(actFuel / 1000.0));
      lcd.setCursor(13,2);
      lcd.print(" Liter");
    /*if (coolantTemp > 99) {
    lcdPrint(0, 1, F("COOL  "));
    alarm();
    } else*/
    lcd.print(coolantTemp);
    lcd.setCursor(2,1);
    lcd.print((char)223);
    lcd.print("C");
    lcd.setCursor(4,1);
    lcd.print(" ");
    lcd.setCursor(5,1);
    lcd.print(oilTemp);
    lcd.setCursor(7,1);
    lcd.print("C");
    lcd.setCursor(9,1);
    lcd.print(" ");
    lcd.setCursor(10,1);
    lcd.print(supplyVoltage);
    lcd.setCursor(15,1);
    lcd.print("V");
    float nyomas1 = nyomas - 990;
    float nyomas2 = nyomas1 / 1000;
    lcd.setCursor(0,2);
    lcd.print(nyomas2);
    lcd.print("bar ");
    lcd.setCursor(8,2);
    lcd.print(" ");
    lcd.setCursor(0,3);
    lcd.print(vehicleSpeed);
    lcd.setCursor(2,3);
    lcd.print("Km/h");
  //pageUpdateCounter++;
void setup() {
  Serial.begin(19200);
  Serial.println(F("SETUP"));
  //lcd.begin(16, 2);
  // Print a message to the LCD.
  //lcd.print("SETUP");
    lcd.init();
    lcd.backlight();
    lcd.init();
  pinMode(pinKLineTX, OUTPUT);
  pinMode(pinButton, INPUT);
  pinMode(pinButton, INPUT_PULLUP);
  pinMode(pinBuzzer, OUTPUT);
  /*tone(pinBuzzer, 1200);
  delay(100);
  noTone(pinBuzzer);*/
  pinMode(pinLED, OUTPUT);
  analogWrite(pinLED, 50);
  Serial.println(F("START"));
void loop() {
  currPage = 2 ;
  ////  if (digitalRead(pinButton) == LOW){
  //    currPage++;
  //    if (currPage > 2) currPage = 1;
  //    lcd.clear();
  //    lcd.setCursor(0,0);
  //    lcd.print(F("page "));
  //    lcd.print(currPage);
  errorTimeout = 0;
  errorData = 0;
  //    while (digitalRead(pinButton) == LOW);
  switch (currPage) {
    case 1:
      if (currAddr != ADR_Dashboard) {
        connect(ADR_Dashboard, 9600);
        //      connect(ADR_Dashboard, 10400);
      } else  {
        readSensors(1);
        readSensors(2);
        readSensors(50);
      break;
    case 2:
      if (currAddr != ADR_Engine) {
        delay (1000);
        connect(ADR_Engine, 9600);//4800??
        //        connect(ADR_Engine, 10400);
      } else {
        //        readSensors(1);
        //        readSensors(2);
        //        readSensors(3);
        //        readSensors(4);
        //       readSensors(5);
        readSensors(6);
        readSensors(7);
        //        readSensors(8);
        //        readSensors(9);
        //        readSensors(10);
        //        readSensors(11);
        readSensors(12);
        //        readSensors(13);
        //        readSensors(14);
        readSensors(15);
        //        readSensors(16);
        readSensors(23);
      break;
  //lcd.begin(16,2);
  updateDisplay();
