;   Filename:      L8-Count_7seg_BCD.asm                                *
;   Date:          3/4/12                                               *
;   File Version:  1.3                                                  *
;   Author:        David Meiklejohn                                     *
;   Company:       Gooligum Electronics                                 *
;   Architecture:  Baseline PIC                                         *
;   Processor:     16F506                                               *
;   Files required: none                                                *
;   Description:    Lesson 8, example 3                                 *
;   Demonstrates BCD storage and counting                               *
;   3 digit 7-segment LED display: 1 digit minutes, 2 digit seconds     *
;   counts in seconds 0:00 to 9:59 then repeats,                        *
;   with timing derived from int 4 MHz oscillator                       *
;   (seconds count stored in BCD format)                                *
;   Pin assignments:                                                    *
;       RB0-1,RB4,RC1-4 = 7-segment display bus (common cathode)        *
;       RC5             = minutes enable (active high)                  *
;       RB5             = tens enable                                   *
;       RC0             = ones enable                                   *
    list        p=16F506 
    #include    <p16F506.inc>
    radix       dec
;***** CONFIGURATION
                ; ext reset, no code protect, no watchdog, 4 MHz int clock
    __CONFIG    _MCLRE_ON & _CP_OFF & _WDT_OFF & _IOSCFS_OFF & _IntRC_OSC_RB4EN
; pin assignments
    #define MINUTES PORTC,5     ; minutes enable
    #define TENS    PORTB,5     ; tens enable
    #define ONES    PORTC,0     ; ones enable
;***** VARIABLE DEFINITIONS
        UDATA_SHR
temp    res 1                   ; used by set7seg routine (temp digit store)
        UDATA
mpx_cnt res 1                   ; multiplex counter
mins    res 1                   ; time count: minutes
secs    res 1                   ;   seconds (BCD)
;***** RC CALIBRATION
RCCAL   CODE    0x3FF           ; processor reset vector
        res 1                   ; holds internal RC cal value, as a movlw k
;***** RESET VECTOR *****************************************************
RESET   CODE    0x000           ; effective reset vector
        movwf   OSCCAL          ; apply internal RC factory calibration 
        pagesel start
        goto    start           ; jump to main code
;***** Subroutine vectors
set7seg                         ; display digit on 7-segment display
        pagesel set7seg_R       
        goto    set7seg_R
;***** MAIN PROGRAM *****************************************************
MAIN    CODE
;***** Initialisation
start  
        ; configure ports
        clrw                    ; configure PORTB and PORTC as all outputs
        tris    PORTB
        tris    PORTC
        clrf    ADCON0          ; disable AN0, AN1, AN2 inputs 
        bcf     CM1CON0,C1ON    ;     and comparator 1 -> RB0,RB1 digital
        bcf     CM2CON0,C2ON    ; disable comparator 2 -> RC0,RC1 digital
        ; configure timer
        movlw   b'11010111'     ; configure Timer0:
                ; --0-----          timer mode (T0CS = 0) -> RC5 usable
                ; ----0---          prescaler assigned to Timer0 (PSA = 0)
                ; -----111          prescale = 256 (PS = 111)            
        option                  ;   -> increment every 256 us        
                                ;      (TMR0<2> cycles every 2.048ms)
        ; initialise variables
        banksel mins            ; start with count = 0:00
        clrf    mins
        clrf    secs
;***** Main loop
main_loop
; multiplex display for 1 sec
        movlw   1000000/2048/3  ; display each of 3 digits for 2.048 ms each
        movwf   mpx_cnt         ;   repeat multiplex loop for approx 1 second
mplex_loop
        ; display minutes for 2.048 ms
w60_hi  btfss   TMR0,2          ; wait for TMR0<2> to go high
        goto    w60_hi
        movf    mins,w          ; get minutes digit
        pagesel set7seg
        call    set7seg         ;   then output it
        pagesel $      
        bsf     MINUTES         ; enable minutes display
w60_lo  btfsc   TMR0,2          ; wait for TMR<2> to go low
        goto    w60_lo
        ; display tens for 2.048 ms
w10_hi  btfss   TMR0,2          ; wait for TMR0<2> to go high
        goto    w10_hi
        swapf   secs,w          ; get tens digit
        andlw   0x0F            ;   from high nybble of seconds
        pagesel set7seg
        pagesel $   
        bsf     TENS            ; enable tens display
w10_lo  btfsc   TMR0,2          ; wait for TMR<2> to go low
        goto    w10_lo
        ; display ones for 2.048 ms
w1_hi   btfss   TMR0,2          ; wait for TMR0<2> to go high
        goto    w1_hi
        movf    secs,w          ; get ones digit
        andlw   0x0F            ;   from low nybble of seconds
        pagesel set7seg
        pagesel $    
        bsf     ONES            ; enable ones display
w1_lo   btfsc   TMR0,2          ; wait for TMR<2> to go low
        goto    w1_lo
        decfsz  mpx_cnt,f       ; continue to multiplex display
        goto    mplex_loop      ;   until 1 sec has elapsed
; increment time counters
        incf    secs,f          ; increment seconds
        movf    secs,w          ; if ones overflow,
        andlw   0x0F
        xorlw   .10
        btfss   STATUS,Z 
        goto    end_inc 
        movlw   .6              ;   BCD adjust seconds
        addwf   secs,f 
        movlw   0x60
        xorwf   secs,w          ;   if seconds = 60,
        btfss   STATUS,Z
        goto    end_inc  
        clrf    secs            ;       reset seconds to 0
        incf    mins,f          ;       and increment minutes
        movlw   .10
        xorwf   mins,w          ;       if minutes overflow,
        btfsc   STATUS,Z
        clrf    mins            ;           reset minutes to 0
end_inc 
; repeat forever        
        goto    main_loop       
;***** LOOKUP TABLES ****************************************************
TABLES  CODE    0x200           ; locate at beginning of a page
; pattern table for 7 segment display on port B
;   RB4 = E, RB1:0 = FG
get7sB  addwf   PCL,f
        retlw   b'010010'       ; 0
        retlw   b'000000'       ; 1
        retlw   b'010001'       ; 2
        retlw   b'000001'       ; 3
        retlw   b'000011'       ; 4
        retlw   b'000011'       ; 5
        retlw   b'010011'       ; 6
        retlw   b'000000'       ; 7
        retlw   b'010011'       ; 8
        retlw   b'000011'       ; 9
; pattern table for 7 segment display on port C
;   RC4:1 = CDBA
get7sC  addwf   PCL,f
        retlw   b'011110'       ; 0
        retlw   b'010100'       ; 1
        retlw   b'001110'       ; 2
        retlw   b'011110'       ; 3
        retlw   b'010100'       ; 4
        retlw   b'011010'       ; 5
        retlw   b'011010'       ; 6
        retlw   b'010110'       ; 7
        retlw   b'011110'       ; 8
        retlw   b'011110'       ; 9
; Display digit passed in W on 7-segment display
set7seg_R
        ; disable displays
        clrf    PORTB           ; clear all digit enable lines on PORTB
        clrf    PORTC           ;   and PORTC
        ; output digit pattern
        movwf   temp            ; save digit
        call    get7sB          ; lookup pattern for port B
        movwf   PORTB           ;   then output it
        movf    temp,w          ; get digit 
        call    get7sC          ;   then repeat for port C
        movwf   PORTC
        retlw   0
        END
