#!/bin/sh
prg="adude"
uc="m8"
help()
	echo "prg_fusebit_uc -- read and write fuse bits of the atmega8"
	echo ""
	echo "Usage: prg_fusebit_uc [-hu] -r|-w Freq"
	echo ""
	echo "OPTIONS: -h this help"
	echo "         -r read fuse bytes"
	echo "         -u use uisp instead of avrdude"
	echo "            avrdude can automatically detect dapa or avrusb500."
	echo "            uisp can only be used with the parallel port dapa."
	echo "         -w write fuse bytes such that a given Freq is used"
	echo "            a frequency of 0 means external crystal. Possible"
	echo "            values are 0,1,2,4,8"
	echo ""
	echo "EXAMPLE: program the fuses to 4MHz internal"
	echo "         prg_fusebit_uc -w 4"
	echo ""
	echo "Warning: you can not undo the setting \"external crystal\" unless"
	echo "         you have a crystal that works."
	echo "This script can be easily adapted to different programmer types"
	exit 0
[ -z "$1" ] && help
while [ -n "$1" ]; do
case $1 in
    -h) help;shift 1;;
    -u) prg="uisp";shift 1;;
    -r) opt_r="1";shift 1;;
    -w) opt_w="1";freq="$2";shift 2;;
    -*) echo "error: no such option $1. -h for help";exit 1;;
    *)  break;;
esac
done
if [ -z "$opt_r" -a  -z "$opt_w" ];then
	# one of those options is mandatory
	help
fi
hf=0xd9
if [ "$opt_w" = "1" ]; then
	case $freq in
	    0) lf=0xee;echo "Make sure you have a crystal otherwise you can not change this!";sleep 2;;
	    1) lf=0xe1;;
	    2) lf=0xe2;;
	    4) lf=0xe3;;
	    8) lf=0xe4;;
	    *) echo "error: no such frequency, -h for help";exit 1;;
	esac
fi
if [ "$prg" = "uisp" ]; then
	if [ "$opt_r" = "1" ];then
		set -x
		uisp -dlpt=/dev/parport0 -dprog=dapa --rd_fuses
		set +x
		echo "Explanation: Fuse Low Byte: 0xe1 (1MHz intern), 0xe3 (4MHz intern), "
		echo "             0xe4 (8MHz intern)"
		echo "             Fuse High Byte should be 0xd9"
		exit 0
	fi
		set -x
		uisp -dlpt=/dev/parport0 -dprog=dapa --wr_fuse_l=$lf
		uisp -dlpt=/dev/parport0 -dprog=dapa --wr_fuse_h=$hf
		set +x
		exit 0
	fi
fi
if [ "$prg" = "adude" ]; then
	if grep "Vendor=0403 ProdID=6001" /proc/bus/usb/devices > /dev/null ; then
		prg="avrusb500"
	else
		prg="dapa"
	fi
		set -x
		avrdude -p $uc -c $prg -v -q
		set +x
		exit 0
	fi
		set -x
		avrdude -p $uc -c $prg -u -v -U lfuse:w:$lf:m
		avrdude -p $uc -c $prg -u -v -U hfuse:w:$hf:m
		set +x
		exit 0
	fi
fi
