#!/bin/sh
prg="adude"
uc="m8"
help()
	echo "prg_load_uc -- load a .hex file into a atmega8 microcontroller"
	echo ""
	echo "Usage: prg_load_uc [-hu][-m uC] File.hex"
	echo ""
	echo "OPTIONS: -h this help"
        echo "         -m select a uC differnt from m8"
	echo "         -u use uisp instead of avrdude"
	echo "            avrdude can automatically detect dapa or avrusb500."
	echo "            uisp can only be used with the parallel port dapa."
	echo ""
	echo "This script can be easily adapted to different programmer types"
	exit 0
[ -z "$1" ] && help
while [ -n "$1" ]; do
case $1 in
    -h) help;shift 1;;
    -u) prg="uisp";shift 1;;
    -m) opt_m="1";uc="$2";shift 2;;
    -*) echo "error: no such option $1. -h for help";exit 1;;
    *)  break;;
esac
done
pfile="$1"
if [ "$prg" = "uisp" ]; then
	set -x
	uisp -dlpt=/dev/parport0 --erase  -dprog=dapa
	uisp -dlpt=/dev/parport0 --upload if="$pfile" -dprog=dapa  -v=3 --hash=32 --verify
	set +x
fi
if [ "$prg" = "adude" ]; then
	if grep "Vendor=0403 ProdID=6001" /proc/bus/usb/devices > /dev/null ; then
		set -x
		avrdude -p $uc -c avrusb500 -e -U flash:w:"$pfile"
		set +x
	else
		set -x
		avrdude -p $uc -c dapa -e -U flash:w:"$pfile"
		set +x
	fi
fi
