avrusb500 is a modern stk500 protocol compatible programer
for Linux, Mac, Windows ... (and more).
http://tuxgraphics.org/electronics
1) Hardware
The circuit diagram can be found in the hw/ directory
2) Compile
You need a avr-gcc installation with avrlibc-1.2.X
To compile all software including hardware test programs
type the command:
make
4) BitBang loading of firmware
Note: If you have ordered the avrusb500 kit from http://shop.tuxgraphics.org
then you can skip this step. Everything is already installed on the CD.
Loading of firmware is done under Linux only. The programer
is OS independent once you have loaded the firmware.
You can either use the pre-compiled uisp_ppbg binary from bin/
or build it from sources:
- install libusb http://libusb.sourceforge.net
- install uisp-20050207.tar.gz + uisp-20050207-usb-bbpg-patch.txt
  or install uisp-20050207-usb-bbpg.tar.gz
- copy the file called uisp into this directory and name it uisp_ppbg
- become root and execute the make load* commands (see further down)
3) Testing
The hardware is tested in 3 steps:
3a - connect avrusb500 to the usb port of your Linux PC and
     type
     more /proc/bus/usb/devices
     Search in this text for "Vendor=0403 ProdID=6001".
     If it is there then the USB part is working.
     If not check soldering and parts for the ftdi chip. A common
     mistake is to swap the D+/D- cables on the usb port.
3b - connect the little programmer bridge cable between CONN1 and CONN4
     (correct polarity please!) and execute the command:
     make load_test_1
     Note: this command needs to be executed as root unless you use
     the avr programming CD from http://shop.tuxgraphics.org
     The LED on the board should start to blink.
3c - This test has only limited added value compared to 3b. Allmost
     all functionallity is already tested if 3a and 3b were passed. You can
     skip this test if you want.
     For the test connect the little programmer bridge cable between CONN1 and CONN4
     (correct polarity please!) and execute the commands:
     make ttydevinit1152
     make load_test_2
     Note: the second command needs to be executed as root unless you use
     Remove the usb connector and plug it back in. Run the following
     command to see that the ftdi_sio module is loaded:
     /sbin/lsmod | grep ftdi
     If it is not loaded then execute the command (as root):
     modprobe ftdi_sio
     ./ttydevinit1152 /dev/usb/tts/0
     or (dependent on your Linux distribution):
     ./ttydevinit1152 /dev/ttyUSB0
     Open two shell windows (e.g xterm or Konsole) and execute in
     shell 1:
     cat /dev/ttyUSB0
     (or cat /dev/usb/tts/0 but that is obvious, I guess...)
     in shell 2:
     cat > /dev/ttyUSB0
     In shell 2 you type now:
     1
     In shell 1 you should see now the text "on OK" and the LED should go on.
     In shell 2 you type:
     0
     and in shell 1 you should see now the text "off OK" ... and the LED
     should go off.
     You can terminate the cat commands with crtl-c.
4) Loading the final firmware
After successful testing of the hardware (step 3) you can now load the final
firmware:
make load
This command is rather slow and will take about 40 minutes to
complete (run it over lunch time). The loading is a bit faster
on a PC with USB 2.0.
You will need to do this firmware loading only once. After this step
you have a fast and modern AVR programmer.
The command "make load" will load the file avrusb500.hex into
the atmega8. There is also a file avrusb500_pre.hex which can be loaded
in case you do not have a working avr-gcc compiler.
Optional: Setting to SW version to keep avrstudio quiet
A good serial terminal for Linux is gtkterm
  http://www.jls-info.com/julien/linux/
Under windows you can use Hyperterminal
To talk to the avrusb500 in terminal mode you have to
attach your serial terminal to the com port (Linux /dev/ttyUSB0)
with the following settings:
 Speed=115200 Parity=none Bits=8 Stopbits=1 Flow=none
Note to windows users: Hyperterminal crashes/hangs if you set Flowcontrol
accidently not to none.
Hit twice return and then you get a dialog on the screen
similar to this one (in this example we change ver=2.2 to ver=2.1):
	AvrUsb500 terminal mode
	Enter SW Version Major [2]: 2
	Enter SW Version Minor [2]: 1
	OK, my SW version is now: 2.1
	Ready. Just close the terminal. No reset needed.
An alternative to gtkterm is under linux also the ttydevinit1152 command included
in this package:
Open 2 xterm windows. In one you type
cat /dev/ttyUSB0
The other you use as input window (put mouse focus on it):
cat > /dev/ttyUSB0
Change history
2005-09-30:  avrusb500-0.6 first public version
2005-10-18:  avrusb500-0.7, minor editorial updates in the circuit diagram
2005-11-28:  avrusb500-0.8, Circuit diagram updated R11 and R13 changed from 220 to 1K
                            (220 Ohm works also for works also for low voltage
			    targets [2.7V] but 1K might be better)
2005-12-29:  avrusb500-0.9, Update this README
                            Frequencies not correctly set in spi.c (the impact of
			    this fault to the end user is almost none)
2006-01-07:  avrusb500-1.0, - Missing dependency in makefile.
                            - Timeout protection against possible hanging during
			      polling (main.c)
			    - Restore mode during word writing (solves problem with
			      timeout during programming of a at90s2313 chip)
2006-03-04:  avrusb500-1.1, - Updates for gcc-4.0.X (previous version would not
                              work very well with the new compiler)
			    - Added terminal mode to change SW version number.
			      This feature was contributed by Florin-Viorel Petrov
			      and is mainly interessting for users of the
			      avrstudio software to avoid the "update SW" dialog.
2006-03-10:  avrusb500-1.2, - Support for 2 digit version numbers
                            - Faults in timeout.c corrected
2006-04-08:  avrusb500-1.3, - Added support for some STK500 only parameters
                            - The second test program echos all input as
			      Hex values back.
			    - Fix for a problem reported by Magne Hellum: pull spi pins
			      to ground at spi-init.
2006-05-28:  avrusb500-1.4, - Add read delays for short commands
                            - Supervise the communication also with the watchdog
			    - Add slow programming mode. You get there if you use
			    the avrdude -B 10 option. This is useful to recover targets
			    with extremely low clock speed (atmega88/atmega168 can work
			    with clock dvision factors up to 256).
2006-11-06:  avrusb500-1.5, - enter version number in hex
                            - clock sck during the sync loops of CMD_ENTER_PROGMODE_ISP
			      This solves a problem when programming a tiny2313 where
			      port B is used for applications.
2007-05-13:  avrusb500-1.6, - set PARAM_TOPCARD_DETECT to 0x8c for
                              interworking with CodeVision (contrib by Erik Lins)
2007-11-24:  avrusb500-1.7, - Fix 64K flash bug, thanks to Andrzej Wolski
Author/Copyright/Links
Guido Socher (guido [At] tuxgraphics.org)
Idea for terminal mode by Florin-Viorel Petrov.
64K word flash addressing by Andrzej Wolski
Copyright: GPLv2 (see http://www.gnu.org/licenses/gpl.html )
Homepage of the avrusb500:
    http://tuxgraphics.org/electronics/200510/article05101.shtml
