; Source created with Parsic Version 3.x
; at              : 2008.07.04. 20:07:17
; Project File    : C:\PROGRA~1\Parsic\Projekt\egyéb\RS_vevo.PIC
; Project Version : 1.0.3
; Created         : 2008.07.04. 19:49:00
; Last change     : 2008.07.04. 20:07:15
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
UD1_FD	= 32	; located in Bank 0
S0	= 33	; located in Bank 0
UA1RSFLAG	= 34	; located in Bank 0
ADAT	= 35	; located in Bank 0
ADAT_HI	= 36	; located in Bank 0
MF1	= 37	; located in Bank 0
MF1_HI	= 38	; located in Bank 0
UA1OUTBUF	= 39	; located in Bank 0
UA1OUTBUF1	= 40	; located in Bank 0
UA1OUTBUF2	= 41	; located in Bank 0
UA1OUTBUF3	= 42	; located in Bank 0
UA1OUTBUF4	= 43	; located in Bank 0
RAM	= 44	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
; UART -> UA1
UA1CHKTX
	BTFSS PIR1,TXIF	; send byte ?
	GOTO UA1ENDINT	; no
	MOVFW UA1OUTBUF+1	; all transmitted ? 
	BTFSC STATUS,ZERO
	GOTO UA1TXINT1
	ERRORLEVEL -312
	BANKISEL UA1OUTBUF	; FILE INDIREKT
	ERRORLEVEL +312
	MOVFW UA1OUTBUF	; pointer
	INCF UA1OUTBUF,F	; pointer+1
	MOVWF FSR
	MOVFW INDF	; data
	MOVWF TXREG	; Transmit Register
	DECF UA1OUTBUF+1,F	; length-1
	GOTO EXITINT	; that's all
UA1TXINT1
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	BTFSS TXSTA,TRMT	; last byte transmitted ?
	GOTO EXITINT	; no
	BCF TXSTA,TXEN	; transmitter off
	BSF UA1RSFLAG,2	; ready
	GOTO EXITINT
UA1ENDINT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000100'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11000000'
	MOVWF TRISA
	MOVLW B'00000010'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
; initalisize UA1
	MOVLW B'10010000'	; serial enable,8-bit,continous-enable
	MOVWF RCSTA
	MOVLW 103
	MOVWF SPBRG	; BAUDRATE GENERATOR
	MOVLW B'00000100'	; 8-BIt,TRANSMIT DISABLED,ASYNCHRON,BRGH=1=HIGH SPEED
	MOVWF TXSTA
	BSF PIE1,TXIE	; enable INTERRUPT for transmit
	BSF INTCON,PEIE	; PERIPHERIE INT ENABLE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Verteiler -> BV1
	BTFSC ADAT,0
	GOTO LABEL_BV1_0
	BCF PORTA,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTA,0
LABEL_BV1_0_END
	BTFSC ADAT,1
	GOTO LABEL_BV1_1
	BCF PORTA,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTA,1
LABEL_BV1_1_END
	BTFSC ADAT,2
	GOTO LABEL_BV1_2
	BCF PORTA,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTA,2
LABEL_BV1_2_END
	BTFSC ADAT,3
	GOTO LABEL_BV1_3
	BCF PORTA,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTA,3
LABEL_BV1_3_END
	BTFSC ADAT,4
	GOTO LABEL_BV1_4
	BCF PORTA,4
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF PORTA,4
LABEL_BV1_4_END
	BTFSC ADAT,5
	GOTO LABEL_BV1_5
	BCF PORTA,5
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF PORTA,5
LABEL_BV1_5_END
	BTFSC ADAT,6
	GOTO LABEL_BV1_6
	BCF PORTB,0
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF PORTB,0
LABEL_BV1_6_END
	BTFSC ADAT,7
	GOTO LABEL_BV1_7
	BCF PORTB,3
	GOTO LABEL_BV1_7_END
LABEL_BV1_7
	BSF PORTB,3
LABEL_BV1_7_END
	BTFSC ADAT_HI,0
	GOTO LABEL_BV1_8
	BCF PORTB,4
	GOTO LABEL_BV1_8_END
LABEL_BV1_8
	BSF PORTB,4
LABEL_BV1_8_END
	BTFSC ADAT_HI,1
	GOTO LABEL_BV1_9
	BCF PORTB,5
	GOTO LABEL_BV1_9_END
LABEL_BV1_9
	BSF PORTB,5
LABEL_BV1_9_END
	BTFSC ADAT_HI,2
	GOTO LABEL_BV1_10
	BCF PORTB,6
	GOTO LABEL_BV1_10_END
LABEL_BV1_10
	BSF PORTB,6
LABEL_BV1_10_END
	BTFSC ADAT_HI,3
	GOTO LABEL_BV1_11
	BCF PORTB,7
	GOTO LABEL_BV1_11_END
LABEL_BV1_11
	BSF PORTB,7
LABEL_BV1_11_END
; UDATA -> UD1
	BTFSC S0,1	; active
	GOTO LABEL_UD1_1	; yes
; test positive edge
	BTFSS S0,0
	GOTO LABEL_UD1_SETFD
	BTFSC UD1_FD,0
	BSF UD1_FD,0
	BCF UA1RSFLAG,2		; set not ready
	BSF S0,1	; active
	MOVLW LOW UA1OUTBUF+2	; set pointer (ADRESS)
	MOVWF UA1OUTBUF
	MOVLW H'AA'	; init checksum
	MOVWF UA1OUTBUF+4
	MOVLW 3	; 3 bytes
	MOVWF UA1OUTBUF+1
	BCF INTCON,GIE	; disable interrupts
	BTFSC INTCON,GIE	; disabled ?
	GOTO $-2	; no
	MOVFW ADAT
	MOVWF UA1OUTBUF+2
	ADDWF UA1OUTBUF+4,F
	MOVFW ADAT_HI
	MOVWF UA1OUTBUF+3
	ADDWF UA1OUTBUF+4,F
	BSF TXSTA,TXEN
	BSF INTCON,GIE	; enable interrupts
LABEL_UD1_1
	BTFSS UA1RSFLAG,2	; transmit ready ?
	GOTO LABEL_UD1_2	; no
	BCF S0,1	; not active
LABEL_UD1_2
LABEL_UD1_SETFD
; test negative edge
	BTFSC S0,0
	GOTO LABEL_UD1_EXIT
	BCF UD1_FD,0
LABEL_UD1_EXIT
; Anzug-Verzögerung -> MF1
	BTFSS S0,1	; Eingang auf Low ?
	GOTO LABEL_MF1_CHKTIME	; Ja
; RESET
	CLRF MF1
	CLRF MF1_HI
	BCF S0,0
	GOTO LABEL_MF1_EXIT	; raus
LABEL_MF1_CHKTIME
	BTFSC S0,0	; Ausgang schon auf High ?
	GOTO LABEL_MF1_EXIT	; Ja
	MOVLW 0
	SUBWF MF1_HI,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	MOVLW 78
	SUBWF MF1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_MF1_EXIT
	BSF S0,0
LABEL_MF1_EXIT
	GOTO MAIN
	END
