/* YourDuinoStarter Example:RECEIVE nRF24L01 Joystick data to control Pan Tilt Servos Over Radio.
   QUESTIONS? terry@yourduino.com
 -WHAT IT DOES:
  -Receives Joystick Analog Values over a nRF24L01 Radio Link, using the Radiohead library.
  - Sends Joystick position to 2 servos, usually X,Y to pan-tilt arrangement
  - TODO! Send the Joystick push-down click to turn Laser on and off
 - SEE the comments after "//" on each line below
 - CONNECTIONS: nRF24L01 Modules See:
 http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
   1 - GND
   2 - VCC 3.3V !!! NOT 5V
   3 - CE to Arduino pin 8
   4 - CSN to Arduino pin 10
   5 - SCK to Arduino pin 13
   6 - MOSI to Arduino pin 11
   7 - MISO to Arduino pin 12
   8 - UNUSED
   -V2.00 7/12/14 by Noah King
   Based on examples at http://www.airspayce.com/mikem/arduino/RadioHead/index.html
/*-----( Import needed libraries )-----*/
// SEE http://arduino-info.wikispaces.com/Arduino-Libraries  !!
// NEED the SoftwareServo library installed
// http://playground.arduino.cc/uploads/ComponentLib/SoftwareServo.zip
#include <SoftwareServo.h>  // Regular Servo library creates timer conflict!
// NEED the RadioHead Library installed!
// http://www.airspayce.com/mikem/arduino/RadioHead/RadioHead-1.23.zip
#include <RHReliableDatagram.h>
#include <RH_NRF24.h>
#include <SPI.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define CLIENT_ADDRESS     5
#define SERVER_ADDRESS     6
#define ServoHorizontalPIN 3   //Pin Numbers
#define ServoVerticalPIN   5
#define LaserPIN           6
#define ServoMIN_H  0  // Don't go to very end of servo travel
#define ServoMAX_H  160 // which may not be all the way from 0 to 180.
#define ServoMIN_V  0  // Don't go to very end of servo travel
#define ServoMAX_V  140 // which may not be all the way from 0 to 180.
/*-----( Declare objects )-----*/
//SoftwareServo HorizontalServo;
//SoftwareServo VerticalServo;  // create servo objects to control servos
// Create an instance of the radio driver
RH_NRF24 RadioDriver;
// Create an instance of a manager object to manage message delivery and receipt, using the driver declared above
RHReliableDatagram RadioManager(RadioDriver, SERVER_ADDRESS);
/*-----( Declare Variables )-----*/
int HorizontalJoystickReceived; // Variable to store received Joystick values
int HorizontalServoPosition;    // variable to store the servo position
int VerticalJoystickReceived;   // Variable to store received Joystick values
int VerticalServoPosition;      // variable to store the servo position
uint8_t ReturnMessage[] = "JoyStick Data Received";  // 28 MAX
// Predefine the message buffer here: Don't put this on the stack:
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
uint8_t tmp=0;
//--------------------------------( SETUP Runs ONCE )-----------------------------------------------------
void setup()
  //pinMode(LaserPIN, OUTPUT);
  //digitalWrite(LaserPIN, HIGH); // turn on Laser
  /*-----( Set up servos )-----*/
  //HorizontalServo.attach(ServoHorizontalPIN);  // attaches the servo to the servo object
  //VerticalServo.attach(ServoVerticalPIN);      // attaches the servo to the servo object
  // begin serial to display on Serial Monitor. Set Serial Monitor to 115200
  // See http://arduino-info.wikispaces.com/YourDuino-Serial-Monitor
  Serial.begin(115200);
  if (!RadioManager.init()){ // Initialize radio. If NOT "1" received, it failed.
    Serial.println("init failed");
  else
    Serial.println("init ok");
  // Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
} // END Setup
//--------------------------------( LOOP runs continuously )-----------------------------------------------------
void loop()
  if (RadioManager.available())
 // Wait for a message addressed to us from the client
    uint8_t len = sizeof(buf);
    uint8_t from;
    if (RadioManager.recvfromAck(buf, &len, &from))
 //Serial Print the values of joystick
      if(tmp<200){tmp++;}else{tmp=0;}
      Serial.print("got request from : 0x");
      Serial.print(from, HEX);
      Serial.print(": X = ");
      Serial.print(buf[0]);
      Serial.print(" Y = ");
      Serial.print(buf[1]);
      Serial.print(" Z = ");
      Serial.print(buf[2]);
      Serial.print(" Gomb = ");
      Serial.print(buf[3]);
      Serial.print(" counter = ");
      Serial.println(tmp);
      // Send a reply back to the originator client, check for error
      if (!RadioManager.sendtoWait(ReturnMessage, sizeof(ReturnMessage), from))
        Serial.println(" sendtoWait failed");
    }// end 'IF Received data Available
  }// end 'IF RadioManager Available
   // SoftwareServo::refresh();//refreshes servo to keep them updating
    //HorizontalJoystickReceived  = buf[1];  // Get the values received
    //VerticalJoystickReceived    = buf[0];
    // scale it to use it with the servo (value between MIN and MAX)
  //  HorizontalServoPosition  = map(HorizontalJoystickReceived, 0, 255, ServoMIN_H , ServoMAX_H);
  //  VerticalServoPosition    = map(VerticalJoystickReceived,   0, 255, ServoMIN_V , ServoMAX_V);
   // Serial.print("HorizontalServoPosition : ");
   // Serial.print(HorizontalServoPosition);
   // Serial.print("  VerticalServoPosition : ");
   // Serial.println(VerticalServoPosition);
    // tell servos to go to position
   // HorizontalServo.write(HorizontalServoPosition);
   // VerticalServo.write(VerticalServoPosition);
   // delay(25);                      // wait for the servo to reach the position
}// END Main LOOP
