<!--This work is licensed under a Creative Commons Attribution-ShareAlike 4.0 International License (CC BY-SA) with Design Exception 1.0-->
<eagle version="7.1.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="TO254P1515X470-3N">
<wire x1="-2.54" y1="5.08" x2="-3.81" y2="5.08" width="0.2" layer="21"/>
<wire x1="-3.81" y1="5.08" x2="-3.81" y2="-5.08" width="0.2" layer="21"/>
<wire x1="-3.81" y1="-5.08" x2="-2.54" y2="-5.08" width="0.2" layer="21"/>
<circle x="-6.6" y="4" radius="0.282841" width="0.2" layer="21"/>
<circle x="-6.6" y="4" radius="0.141419" width="0.2" layer="21"/>
<wire x1="-8.3" y1="5.5" x2="8.3" y2="5.5" width="0.05" layer="39"/>
<wire x1="8.3" y1="5.5" x2="8.3" y2="-5.5" width="0.05" layer="39"/>
<wire x1="8.3" y1="-5.5" x2="-8.3" y2="-5.5" width="0.05" layer="39"/>
<wire x1="-8.3" y1="-5.5" x2="-8.3" y2="5.5" width="0.05" layer="39"/>
<text x="-4.00433" y="6.0065" size="1.27137" layer="25">&gt;NAME</text>
<text x="-4.00126" y="-7.0022" size="1.2704" layer="27">&gt;VALUE</text>
<rectangle x1="-0.680751" y1="3.24358" x2="0.68" y2="4.76" layer="31"/>
<rectangle x1="1.47189" y1="3.24417" x2="2.83" y2="4.76" layer="31"/>
<rectangle x1="3.62594" y1="3.24532" x2="4.98" y2="4.76" layer="31"/>
<rectangle x1="5.74645" y1="3.24364" x2="7.1" y2="4.76" layer="31"/>
<rectangle x1="-0.680762" y1="1.24139" x2="0.68" y2="2.76" layer="31"/>
<rectangle x1="1.47216" y1="1.24182" x2="2.83" y2="2.76" layer="31"/>
<rectangle x1="3.62526" y1="1.2418" x2="4.98" y2="2.76" layer="31"/>
<rectangle x1="5.74046" y1="1.2401" x2="7.1" y2="2.76" layer="31"/>
<rectangle x1="-0.680133" y1="-0.760149" x2="0.68" y2="0.76" layer="31"/>
<rectangle x1="1.47056" y1="-0.760291" x2="2.83" y2="0.76" layer="31"/>
<rectangle x1="3.6218" y1="-0.760377" x2="4.98" y2="0.76" layer="31"/>
<rectangle x1="5.74322" y1="-0.760427" x2="7.1" y2="0.76" layer="31"/>
<rectangle x1="-0.680219" y1="-2.76089" x2="0.68" y2="-1.24" layer="31"/>
<rectangle x1="1.47092" y1="-2.76172" x2="2.83" y2="-1.24" layer="31"/>
<rectangle x1="3.62548" y1="-2.76418" x2="4.98" y2="-1.24" layer="31"/>
<rectangle x1="5.74075" y1="-2.76036" x2="7.1" y2="-1.24" layer="31"/>
<rectangle x1="-0.681074" y1="-4.76752" x2="0.68" y2="-3.24" layer="31"/>
<rectangle x1="1.4723" y1="-4.76744" x2="2.83" y2="-3.24" layer="31"/>
<rectangle x1="3.62497" y1="-4.76653" x2="4.98" y2="-3.24" layer="31"/>
<rectangle x1="5.74223" y1="-4.76185" x2="7.1" y2="-3.24" layer="31"/>
<smd name="1" x="-6.3" y="2.54" dx="3.45" dy="1" layer="1"/>
<smd name="2" x="-6.3" y="-2.54" dx="3.45" dy="1" layer="1"/>
<smd name="3" x="3.1" y="0" dx="9.85" dy="10.5" layer="1" cream="no"/>
</package>
</packages>
<symbols>
<symbol name="L7805ACD2T-TR">
<wire x1="-10.16" y1="5.08" x2="10.16" y2="5.08" width="0.254" layer="94"/>
<wire x1="10.16" y1="5.08" x2="10.16" y2="-5.08" width="0.254" layer="94"/>
<wire x1="10.16" y1="-5.08" x2="-10.16" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-5.08" x2="-10.16" y2="5.08" width="0.254" layer="94"/>
<text x="-9.40836" y="5.59416" size="1.2714" layer="95">&gt;NAME</text>
<text x="-9.91867" y="-6.86677" size="1.27162" layer="96">&gt;VALUE</text>
<pin name="IN" x="-15.24" y="0" length="middle" direction="in"/>
<pin name="OUT" x="15.24" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="GND" x="15.24" y="-2.54" length="middle" direction="pwr" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="L7805ACD2T-TR" prefix="U">
<description>Positive voltage regulator ICs</description>
<gates>
<gate name="G$1" symbol="L7805ACD2T-TR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO254P1515X470-3N">
<connects>
<connect gate="G$1" pin="GND" pad="3"/>
<connect gate="G$1" pin="IN" pad="1"/>
<connect gate="G$1" pin="OUT" pad="2"/>
</connects>
<technologies>
<technology name="">
<attribute name="Description" value="L7805 Series 5 V 1 A Three Terminal Positive Voltage Regulator - D2PAK"/>
<attribute name="MF" value="STMicroelectronics"/>
<attribute name="Price" value="0.41 USD"/>
<attribute name="Availability" value="Good"/>
<attribute name="Package" value="D2PAK STMicroelectronics"/>
<attribute name="MP" value="L7805ACD2T-TR"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
