<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="con-lstb">
<packages>
<package name="MA20-2W">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="25.4" y1="2.794" x2="22.86" y2="2.794" width="0.1524" layer="21"/>
<wire x1="22.86" y1="2.794" x2="22.86" y2="5.588" width="0.1524" layer="21"/>
<wire x1="22.86" y1="2.794" x2="20.32" y2="2.794" width="0.1524" layer="21"/>
<wire x1="20.32" y1="2.794" x2="20.32" y2="5.588" width="0.1524" layer="21"/>
<wire x1="20.32" y1="5.588" x2="22.86" y2="5.588" width="0.1524" layer="21"/>
<wire x1="25.4" y1="2.794" x2="25.4" y2="5.588" width="0.1524" layer="21"/>
<wire x1="22.86" y1="5.588" x2="25.4" y2="5.588" width="0.1524" layer="21"/>
<wire x1="20.32" y1="2.794" x2="17.78" y2="2.794" width="0.1524" layer="21"/>
<wire x1="17.78" y1="5.588" x2="20.32" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.24" y1="2.794" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.794" x2="17.78" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.24" y1="2.794" x2="17.78" y2="2.794" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="17.78" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.97" y1="6.35" x2="13.97" y2="11.049" width="0.6604" layer="21"/>
<wire x1="16.51" y1="6.35" x2="16.51" y2="11.049" width="0.6604" layer="21"/>
<wire x1="19.05" y1="6.35" x2="19.05" y2="11.049" width="0.6604" layer="21"/>
<wire x1="21.59" y1="6.35" x2="21.59" y2="11.049" width="0.6604" layer="21"/>
<wire x1="24.13" y1="6.35" x2="24.13" y2="11.049" width="0.6604" layer="21"/>
<wire x1="15.24" y1="2.794" x2="12.7" y2="2.794" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.794" x2="10.16" y2="2.794" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.794" x2="10.16" y2="5.588" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.794" x2="7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="7.62" y1="2.794" x2="7.62" y2="5.588" width="0.1524" layer="21"/>
<wire x1="7.62" y1="5.588" x2="10.16" y2="5.588" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.794" x2="12.7" y2="5.588" width="0.1524" layer="21"/>
<wire x1="10.16" y1="5.588" x2="12.7" y2="5.588" width="0.1524" layer="21"/>
<wire x1="7.62" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="5.588" x2="7.62" y2="5.588" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.794" x2="2.54" y2="5.588" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.794" x2="0" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0" y1="2.794" x2="0" y2="5.588" width="0.1524" layer="21"/>
<wire x1="0" y1="5.588" x2="2.54" y2="5.588" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="5.588" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.54" y1="5.588" x2="5.08" y2="5.588" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.35" x2="1.27" y2="11.049" width="0.6604" layer="21"/>
<wire x1="3.81" y1="6.35" x2="3.81" y2="11.049" width="0.6604" layer="21"/>
<wire x1="6.35" y1="6.35" x2="6.35" y2="11.049" width="0.6604" layer="21"/>
<wire x1="8.89" y1="6.35" x2="8.89" y2="11.049" width="0.6604" layer="21"/>
<wire x1="11.43" y1="6.35" x2="11.43" y2="11.049" width="0.6604" layer="21"/>
<wire x1="0" y1="2.794" x2="-2.54" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.794" x2="-2.54" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="-5.08" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.588" x2="-2.54" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="5.588" x2="0" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="5.588" x2="-5.08" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-10.16" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.588" x2="-10.16" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="5.588" x2="-7.62" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="6.35" x2="-11.43" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-8.89" y1="6.35" x2="-8.89" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-6.35" y1="6.35" x2="-6.35" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-3.81" y1="6.35" x2="-3.81" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-1.27" y1="6.35" x2="-1.27" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-12.7" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.794" x2="-15.24" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="2.794" x2="-15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="2.794" x2="-17.78" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.794" x2="-17.78" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="5.588" x2="-15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.794" x2="-12.7" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.588" x2="-12.7" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.794" x2="-20.32" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="5.588" x2="-17.78" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="2.794" x2="-22.86" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="2.794" x2="-25.4" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="2.794" x2="-25.4" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="5.588" x2="-22.86" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="2.794" x2="-20.32" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="2.794" x2="-20.32" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="5.588" x2="-20.32" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="6.35" x2="-24.13" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-21.59" y1="6.35" x2="-21.59" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-19.05" y1="6.35" x2="-19.05" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-16.51" y1="6.35" x2="-16.51" y2="11.049" width="0.6604" layer="21"/>
<wire x1="-13.97" y1="6.35" x2="-13.97" y2="11.049" width="0.6604" layer="21"/>
<pad name="40" x="24.13" y="1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="21.59" y="1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-21.59" y="1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-24.13" y="1.27" drill="1.016" shape="octagon"/>
<pad name="1" x="-24.13" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="24.13" y="-1.27" drill="1.016" shape="octagon"/>
<text x="-25.4" y="-3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="24.765" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">40</text>
<text x="22.225" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">38</text>
<text x="19.685" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">36</text>
<text x="17.145" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">34</text>
<text x="14.605" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">32</text>
<text x="12.065" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">30</text>
<text x="9.525" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">28</text>
<text x="6.985" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">26</text>
<text x="4.445" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">24</text>
<text x="1.905" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">22</text>
<text x="-0.635" y="3.048" size="1.27" layer="21" ratio="10" rot="R90">20</text>
<text x="-3.175" y="3.175" size="1.27" layer="21" ratio="10" rot="R90">18</text>
<text x="-5.715" y="3.175" size="1.27" layer="21" ratio="10" rot="R90">16</text>
<text x="-8.255" y="3.175" size="1.27" layer="21" ratio="10" rot="R90">14</text>
<text x="-10.795" y="3.175" size="1.27" layer="21" ratio="10" rot="R90">12</text>
<text x="-13.335" y="3.175" size="1.27" layer="21" ratio="10" rot="R90">10</text>
<text x="-15.875" y="3.556" size="1.27" layer="21" ratio="10" rot="R90">8</text>
<text x="-18.415" y="3.556" size="1.27" layer="21" ratio="10" rot="R90">6</text>
<text x="-20.955" y="3.556" size="1.27" layer="21" ratio="10" rot="R90">4</text>
<text x="-23.495" y="3.556" size="1.27" layer="21" ratio="10" rot="R90">2</text>
<text x="-17.78" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="13.6398" y1="5.588" x2="14.3002" y2="6.35" layer="21"/>
<rectangle x1="16.1798" y1="5.588" x2="16.8402" y2="6.35" layer="21"/>
<rectangle x1="18.7198" y1="5.588" x2="19.3802" y2="6.35" layer="21"/>
<rectangle x1="21.2598" y1="5.588" x2="21.9202" y2="6.35" layer="21"/>
<rectangle x1="23.7998" y1="5.588" x2="24.4602" y2="6.35" layer="21"/>
<rectangle x1="0.9398" y1="5.588" x2="1.6002" y2="6.35" layer="21"/>
<rectangle x1="3.4798" y1="5.588" x2="4.1402" y2="6.35" layer="21"/>
<rectangle x1="6.0198" y1="5.588" x2="6.6802" y2="6.35" layer="21"/>
<rectangle x1="8.5598" y1="5.588" x2="9.2202" y2="6.35" layer="21"/>
<rectangle x1="11.0998" y1="5.588" x2="11.7602" y2="6.35" layer="21"/>
<rectangle x1="-11.7602" y1="5.588" x2="-11.0998" y2="6.35" layer="21"/>
<rectangle x1="-9.2202" y1="5.588" x2="-8.5598" y2="6.35" layer="21"/>
<rectangle x1="-6.6802" y1="5.588" x2="-6.0198" y2="6.35" layer="21"/>
<rectangle x1="-4.1402" y1="5.588" x2="-3.4798" y2="6.35" layer="21"/>
<rectangle x1="-1.6002" y1="5.588" x2="-0.9398" y2="6.35" layer="21"/>
<rectangle x1="-24.4602" y1="5.588" x2="-23.7998" y2="6.35" layer="21"/>
<rectangle x1="-21.9202" y1="5.588" x2="-21.2598" y2="6.35" layer="21"/>
<rectangle x1="-19.3802" y1="5.588" x2="-18.7198" y2="6.35" layer="21"/>
<rectangle x1="-16.8402" y1="5.588" x2="-16.1798" y2="6.35" layer="21"/>
<rectangle x1="-14.3002" y1="5.588" x2="-13.6398" y2="6.35" layer="21"/>
<rectangle x1="16.1798" y1="2.1336" x2="16.8402" y2="2.794" layer="21"/>
<rectangle x1="18.7198" y1="2.1336" x2="19.3802" y2="2.794" layer="21"/>
<rectangle x1="21.2598" y1="2.1336" x2="21.9202" y2="2.794" layer="21"/>
<rectangle x1="23.7998" y1="2.1336" x2="24.4602" y2="2.794" layer="21"/>
<rectangle x1="13.6398" y1="2.1336" x2="14.3002" y2="2.794" layer="21"/>
<rectangle x1="11.0998" y1="2.1336" x2="11.7602" y2="2.794" layer="21"/>
<rectangle x1="8.5598" y1="2.1336" x2="9.2202" y2="2.794" layer="21"/>
<rectangle x1="6.0198" y1="2.1336" x2="6.6802" y2="2.794" layer="21"/>
<rectangle x1="3.4798" y1="2.1336" x2="4.1402" y2="2.794" layer="21"/>
<rectangle x1="0.9398" y1="2.1336" x2="1.6002" y2="2.794" layer="21"/>
<rectangle x1="-1.6002" y1="2.1336" x2="-0.9398" y2="2.794" layer="21"/>
<rectangle x1="-4.1402" y1="2.1336" x2="-3.4798" y2="2.794" layer="21"/>
<rectangle x1="-6.6802" y1="2.1336" x2="-6.0198" y2="2.794" layer="21"/>
<rectangle x1="-9.2202" y1="2.1336" x2="-8.5598" y2="2.794" layer="21"/>
<rectangle x1="-11.7602" y1="2.1336" x2="-11.0998" y2="2.794" layer="21"/>
<rectangle x1="-14.3002" y1="2.1336" x2="-13.6398" y2="2.794" layer="21"/>
<rectangle x1="-16.8402" y1="2.1336" x2="-16.1798" y2="2.794" layer="21"/>
<rectangle x1="-19.3802" y1="2.1336" x2="-18.7198" y2="2.794" layer="21"/>
<rectangle x1="-21.9202" y1="2.1336" x2="-21.2598" y2="2.794" layer="21"/>
<rectangle x1="-24.4602" y1="2.1336" x2="-23.7998" y2="2.794" layer="21"/>
<rectangle x1="-24.4602" y1="-0.4064" x2="-23.7998" y2="0.4064" layer="21"/>
<rectangle x1="-24.4602" y1="0.4064" x2="-23.7998" y2="2.1336" layer="51"/>
<rectangle x1="-24.4602" y1="-1.5748" x2="-23.7998" y2="-0.4064" layer="51"/>
<rectangle x1="-21.9202" y1="-0.4064" x2="-21.2598" y2="0.4064" layer="21"/>
<rectangle x1="-21.9202" y1="0.4064" x2="-21.2598" y2="2.1336" layer="51"/>
<rectangle x1="-21.9202" y1="-1.5748" x2="-21.2598" y2="-0.4064" layer="51"/>
<rectangle x1="-19.3802" y1="-0.4064" x2="-18.7198" y2="0.4064" layer="21"/>
<rectangle x1="-19.3802" y1="0.4064" x2="-18.7198" y2="2.1336" layer="51"/>
<rectangle x1="-19.3802" y1="-1.5748" x2="-18.7198" y2="-0.4064" layer="51"/>
<rectangle x1="-16.8402" y1="-0.4064" x2="-16.1798" y2="0.4064" layer="21"/>
<rectangle x1="-16.8402" y1="0.4064" x2="-16.1798" y2="2.1336" layer="51"/>
<rectangle x1="-16.8402" y1="-1.5748" x2="-16.1798" y2="-0.4064" layer="51"/>
<rectangle x1="-14.3002" y1="-0.4064" x2="-13.6398" y2="0.4064" layer="21"/>
<rectangle x1="-11.7602" y1="-0.4064" x2="-11.0998" y2="0.4064" layer="21"/>
<rectangle x1="-14.3002" y1="0.4064" x2="-13.6398" y2="2.1336" layer="51"/>
<rectangle x1="-11.7602" y1="0.4064" x2="-11.0998" y2="2.1336" layer="51"/>
<rectangle x1="-14.3002" y1="-1.5748" x2="-13.6398" y2="-0.4064" layer="51"/>
<rectangle x1="-11.7602" y1="-1.5748" x2="-11.0998" y2="-0.4064" layer="51"/>
<rectangle x1="-9.2202" y1="-0.4064" x2="-8.5598" y2="0.4064" layer="21"/>
<rectangle x1="-6.6802" y1="-0.4064" x2="-6.0198" y2="0.4064" layer="21"/>
<rectangle x1="-9.2202" y1="0.4064" x2="-8.5598" y2="2.1336" layer="51"/>
<rectangle x1="-9.2202" y1="-1.5748" x2="-8.5598" y2="-0.4064" layer="51"/>
<rectangle x1="-6.6802" y1="0.4064" x2="-6.0198" y2="2.1336" layer="51"/>
<rectangle x1="-6.6802" y1="-1.5748" x2="-6.0198" y2="-0.4064" layer="51"/>
<rectangle x1="-4.1402" y1="-0.4064" x2="-3.4798" y2="0.4064" layer="21"/>
<rectangle x1="-1.6002" y1="-0.4064" x2="-0.9398" y2="0.4064" layer="21"/>
<rectangle x1="-4.1402" y1="0.4064" x2="-3.4798" y2="2.1336" layer="51"/>
<rectangle x1="-1.6002" y1="0.4064" x2="-0.9398" y2="2.1336" layer="51"/>
<rectangle x1="-4.1402" y1="-1.5748" x2="-3.4798" y2="-0.4064" layer="51"/>
<rectangle x1="-1.6002" y1="-1.5748" x2="-0.9398" y2="-0.4064" layer="51"/>
<rectangle x1="0.9398" y1="-0.4064" x2="1.6002" y2="0.4064" layer="21"/>
<rectangle x1="3.4798" y1="-0.4064" x2="4.1402" y2="0.4064" layer="21"/>
<rectangle x1="6.0198" y1="-0.4064" x2="6.6802" y2="0.4064" layer="21"/>
<rectangle x1="0.9398" y1="0.4064" x2="1.6002" y2="2.1336" layer="51"/>
<rectangle x1="3.4798" y1="0.4064" x2="4.1402" y2="2.1336" layer="51"/>
<rectangle x1="6.0198" y1="0.4064" x2="6.6802" y2="2.1336" layer="51"/>
<rectangle x1="0.9398" y1="-1.5748" x2="1.6002" y2="-0.4064" layer="51"/>
<rectangle x1="3.4798" y1="-1.5748" x2="4.1402" y2="-0.4064" layer="51"/>
<rectangle x1="6.0198" y1="-1.5748" x2="6.6802" y2="-0.4064" layer="51"/>
<rectangle x1="8.5598" y1="-0.4064" x2="9.2202" y2="0.4064" layer="21"/>
<rectangle x1="11.0998" y1="-0.4064" x2="11.7602" y2="0.4064" layer="21"/>
<rectangle x1="8.5598" y1="-1.5748" x2="9.2202" y2="-0.4064" layer="51"/>
<rectangle x1="11.0998" y1="-1.5748" x2="11.7602" y2="-0.4064" layer="51"/>
<rectangle x1="8.5598" y1="0.4064" x2="9.2202" y2="2.1336" layer="51"/>
<rectangle x1="11.0998" y1="0.4064" x2="11.7602" y2="2.1336" layer="51"/>
<rectangle x1="13.6398" y1="-0.4064" x2="14.3002" y2="0.4064" layer="21"/>
<rectangle x1="16.1798" y1="-0.4064" x2="16.8402" y2="0.4064" layer="21"/>
<rectangle x1="13.6398" y1="0.4064" x2="14.3002" y2="2.1336" layer="51"/>
<rectangle x1="16.1798" y1="0.4064" x2="16.8402" y2="2.1336" layer="51"/>
<rectangle x1="13.6398" y1="-1.5748" x2="14.3002" y2="-0.4064" layer="51"/>
<rectangle x1="16.1798" y1="-1.5748" x2="16.8402" y2="-0.4064" layer="51"/>
<rectangle x1="18.7198" y1="-0.4064" x2="19.3802" y2="0.4064" layer="21"/>
<rectangle x1="21.2598" y1="-0.4064" x2="21.9202" y2="0.4064" layer="21"/>
<rectangle x1="23.7998" y1="-0.4064" x2="24.4602" y2="0.4064" layer="21"/>
<rectangle x1="18.7198" y1="0.4064" x2="19.3802" y2="2.1336" layer="51"/>
<rectangle x1="21.2598" y1="0.4064" x2="21.9202" y2="2.1336" layer="51"/>
<rectangle x1="23.7998" y1="0.4064" x2="24.4602" y2="2.1336" layer="51"/>
<rectangle x1="18.7198" y1="-1.5748" x2="19.3802" y2="-0.4064" layer="51"/>
<rectangle x1="21.2598" y1="-1.5748" x2="21.9202" y2="-0.4064" layer="51"/>
<rectangle x1="23.7998" y1="-1.5748" x2="24.4602" y2="-0.4064" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MA20-2">
<wire x1="3.81" y1="-27.94" x2="-3.81" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-20.32" x2="2.54" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-22.86" x2="2.54" y2="-22.86" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-25.4" x2="2.54" y2="-25.4" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-20.32" x2="-1.27" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-22.86" x2="-1.27" y2="-22.86" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-25.4" x2="-1.27" y2="-25.4" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-15.24" x2="2.54" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-17.78" x2="2.54" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-15.24" x2="-1.27" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-17.78" x2="-1.27" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-12.7" x2="2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-1.27" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-10.16" x2="-1.27" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-12.7" x2="-1.27" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-1.27" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-1.27" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-1.27" y2="5.08" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.27" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-1.27" y2="10.16" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-1.27" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="15.24" x2="2.54" y2="15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="12.7" x2="2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="15.24" x2="-1.27" y2="15.24" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-1.27" y2="12.7" width="0.6096" layer="94"/>
<wire x1="-3.81" y1="25.4" x2="-3.81" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-27.94" x2="3.81" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="25.4" x2="3.81" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="17.78" x2="-1.27" y2="17.78" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="20.32" x2="-1.27" y2="20.32" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="22.86" x2="-1.27" y2="22.86" width="0.6096" layer="94"/>
<wire x1="1.27" y1="17.78" x2="2.54" y2="17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="20.32" x2="2.54" y2="20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="22.86" x2="2.54" y2="22.86" width="0.6096" layer="94"/>
<text x="-3.81" y="-30.48" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="26.162" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="-7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="4" x="-7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="6" x="-7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="7" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="-7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="10" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="11" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="14" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="16" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="17" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="20" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="21" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="24" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="26" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="27" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="29" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="28" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="30" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="31" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="33" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="32" x="-7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="34" x="-7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="36" x="-7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="38" x="-7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="40" x="-7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="35" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="37" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="39" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MA20-2W" prefix="SV" uservalue="yes">
<gates>
<gate name="1" symbol="MA20-2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MA20-2W">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="10" pad="10"/>
<connect gate="1" pin="11" pad="11"/>
<connect gate="1" pin="12" pad="12"/>
<connect gate="1" pin="13" pad="13"/>
<connect gate="1" pin="14" pad="14"/>
<connect gate="1" pin="15" pad="15"/>
<connect gate="1" pin="16" pad="16"/>
<connect gate="1" pin="17" pad="17"/>
<connect gate="1" pin="18" pad="18"/>
<connect gate="1" pin="19" pad="19"/>
<connect gate="1" pin="2" pad="2"/>
<connect gate="1" pin="20" pad="20"/>
<connect gate="1" pin="21" pad="21"/>
<connect gate="1" pin="22" pad="22"/>
<connect gate="1" pin="23" pad="23"/>
<connect gate="1" pin="24" pad="24"/>
<connect gate="1" pin="25" pad="25"/>
<connect gate="1" pin="26" pad="26"/>
<connect gate="1" pin="27" pad="27"/>
<connect gate="1" pin="28" pad="28"/>
<connect gate="1" pin="29" pad="29"/>
<connect gate="1" pin="3" pad="3"/>
<connect gate="1" pin="30" pad="30"/>
<connect gate="1" pin="31" pad="31"/>
<connect gate="1" pin="32" pad="32"/>
<connect gate="1" pin="33" pad="33"/>
<connect gate="1" pin="34" pad="34"/>
<connect gate="1" pin="35" pad="35"/>
<connect gate="1" pin="36" pad="36"/>
<connect gate="1" pin="37" pad="37"/>
<connect gate="1" pin="38" pad="38"/>
<connect gate="1" pin="39" pad="39"/>
<connect gate="1" pin="4" pad="4"/>
<connect gate="1" pin="40" pad="40"/>
<connect gate="1" pin="5" pad="5"/>
<connect gate="1" pin="6" pad="6"/>
<connect gate="1" pin="7" pad="7"/>
<connect gate="1" pin="8" pad="8"/>
<connect gate="1" pin="9" pad="9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<packages>
</packages>
<symbols>
<symbol name="VCC">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="VCC" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="VCC" prefix="P+">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="VCC" symbol="VCC" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" prefix="GND">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="74xx-us">
<packages>
<package name="DIL20">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-13.081" y="-3.048" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.381" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SO20W">
<description>&lt;b&gt;Wide Small Outline package&lt;/b&gt; 300 mil</description>
<wire x1="6.1214" y1="3.7338" x2="-6.1214" y2="3.7338" width="0.1524" layer="51"/>
<wire x1="6.1214" y1="-3.7338" x2="6.5024" y2="-3.3528" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.5024" y1="3.3528" x2="-6.1214" y2="3.7338" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.1214" y1="3.7338" x2="6.5024" y2="3.3528" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.5024" y1="-3.3528" x2="-6.1214" y2="-3.7338" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.1214" y1="-3.7338" x2="6.1214" y2="-3.7338" width="0.1524" layer="51"/>
<wire x1="6.5024" y1="-3.3528" x2="6.5024" y2="3.3528" width="0.1524" layer="21"/>
<wire x1="-6.5024" y1="3.3528" x2="-6.5024" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.5024" y1="1.27" x2="-6.5024" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.5024" y1="-1.27" x2="-6.5024" y2="-3.3528" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-3.3782" x2="6.477" y2="-3.3782" width="0.0508" layer="21"/>
<wire x1="-6.5024" y1="1.27" x2="-6.5024" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<smd name="1" x="-5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="-0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="17" x="-1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="18" x="-3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="19" x="-4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="20" x="-5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.81" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="-3.175" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-5.969" y1="-3.8608" x2="-5.461" y2="-3.7338" layer="51"/>
<rectangle x1="-5.969" y1="-5.334" x2="-5.461" y2="-3.8608" layer="51"/>
<rectangle x1="-4.699" y1="-3.8608" x2="-4.191" y2="-3.7338" layer="51"/>
<rectangle x1="-4.699" y1="-5.334" x2="-4.191" y2="-3.8608" layer="51"/>
<rectangle x1="-3.429" y1="-3.8608" x2="-2.921" y2="-3.7338" layer="51"/>
<rectangle x1="-3.429" y1="-5.334" x2="-2.921" y2="-3.8608" layer="51"/>
<rectangle x1="-2.159" y1="-3.8608" x2="-1.651" y2="-3.7338" layer="51"/>
<rectangle x1="-2.159" y1="-5.334" x2="-1.651" y2="-3.8608" layer="51"/>
<rectangle x1="-0.889" y1="-5.334" x2="-0.381" y2="-3.8608" layer="51"/>
<rectangle x1="-0.889" y1="-3.8608" x2="-0.381" y2="-3.7338" layer="51"/>
<rectangle x1="0.381" y1="-3.8608" x2="0.889" y2="-3.7338" layer="51"/>
<rectangle x1="0.381" y1="-5.334" x2="0.889" y2="-3.8608" layer="51"/>
<rectangle x1="1.651" y1="-3.8608" x2="2.159" y2="-3.7338" layer="51"/>
<rectangle x1="1.651" y1="-5.334" x2="2.159" y2="-3.8608" layer="51"/>
<rectangle x1="2.921" y1="-3.8608" x2="3.429" y2="-3.7338" layer="51"/>
<rectangle x1="2.921" y1="-5.334" x2="3.429" y2="-3.8608" layer="51"/>
<rectangle x1="-5.969" y1="3.8608" x2="-5.461" y2="5.334" layer="51"/>
<rectangle x1="-5.969" y1="3.7338" x2="-5.461" y2="3.8608" layer="51"/>
<rectangle x1="-4.699" y1="3.7338" x2="-4.191" y2="3.8608" layer="51"/>
<rectangle x1="-4.699" y1="3.8608" x2="-4.191" y2="5.334" layer="51"/>
<rectangle x1="-3.429" y1="3.7338" x2="-2.921" y2="3.8608" layer="51"/>
<rectangle x1="-3.429" y1="3.8608" x2="-2.921" y2="5.334" layer="51"/>
<rectangle x1="-2.159" y1="3.7338" x2="-1.651" y2="3.8608" layer="51"/>
<rectangle x1="-2.159" y1="3.8608" x2="-1.651" y2="5.334" layer="51"/>
<rectangle x1="-0.889" y1="3.7338" x2="-0.381" y2="3.8608" layer="51"/>
<rectangle x1="-0.889" y1="3.8608" x2="-0.381" y2="5.334" layer="51"/>
<rectangle x1="0.381" y1="3.7338" x2="0.889" y2="3.8608" layer="51"/>
<rectangle x1="0.381" y1="3.8608" x2="0.889" y2="5.334" layer="51"/>
<rectangle x1="1.651" y1="3.7338" x2="2.159" y2="3.8608" layer="51"/>
<rectangle x1="1.651" y1="3.8608" x2="2.159" y2="5.334" layer="51"/>
<rectangle x1="2.921" y1="3.7338" x2="3.429" y2="3.8608" layer="51"/>
<rectangle x1="2.921" y1="3.8608" x2="3.429" y2="5.334" layer="51"/>
<rectangle x1="4.191" y1="3.7338" x2="4.699" y2="3.8608" layer="51"/>
<rectangle x1="5.461" y1="3.7338" x2="5.969" y2="3.8608" layer="51"/>
<rectangle x1="4.191" y1="3.8608" x2="4.699" y2="5.334" layer="51"/>
<rectangle x1="5.461" y1="3.8608" x2="5.969" y2="5.334" layer="51"/>
<rectangle x1="4.191" y1="-3.8608" x2="4.699" y2="-3.7338" layer="51"/>
<rectangle x1="5.461" y1="-3.8608" x2="5.969" y2="-3.7338" layer="51"/>
<rectangle x1="4.191" y1="-5.334" x2="4.699" y2="-3.8608" layer="51"/>
<rectangle x1="5.461" y1="-5.334" x2="5.969" y2="-3.8608" layer="51"/>
</package>
<package name="LCC20">
<description>&lt;b&gt;Leadless Chip Carrier&lt;/b&gt;&lt;p&gt; Ceramic Package</description>
<wire x1="-0.4001" y1="4.4" x2="-0.87" y2="4.4" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="4.4" x2="-4.4" y2="3.3" width="0.2032" layer="51"/>
<wire x1="-0.4001" y1="4.3985" x2="0.4001" y2="4.3985" width="0.2032" layer="51" curve="180"/>
<wire x1="-1.6701" y1="4.3985" x2="-0.8699" y2="4.3985" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.3985" y1="2.14" x2="-4.3985" y2="2.94" width="0.2032" layer="51" curve="180"/>
<wire x1="-2.9401" y1="4.4" x2="-3.3" y2="4.4" width="0.2032" layer="51"/>
<wire x1="0.87" y1="4.4" x2="0.4001" y2="4.4" width="0.2032" layer="51"/>
<wire x1="0.87" y1="4.3985" x2="1.67" y2="4.3985" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.4" y1="3.3" x2="-4.4" y2="2.9401" width="0.2032" layer="51"/>
<wire x1="-4.4" y1="2.14" x2="-4.4" y2="1.6701" width="0.2032" layer="51"/>
<wire x1="-4.3985" y1="0.87" x2="-4.3985" y2="1.67" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.3985" y1="-0.4001" x2="-4.3985" y2="0.4001" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.3985" y1="-1.6701" x2="-4.3985" y2="-0.8699" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.4" y1="0.87" x2="-4.4" y2="0.4001" width="0.2032" layer="51"/>
<wire x1="-4.4" y1="-0.4001" x2="-4.4" y2="-0.87" width="0.2032" layer="51"/>
<wire x1="-4.4" y1="-2.9401" x2="-4.4" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="-4.4" y1="-4.4" x2="-4.4" y2="-4.4099" width="0.2032" layer="51"/>
<wire x1="2.14" y1="4.3985" x2="2.94" y2="4.3985" width="0.2032" layer="51" curve="180"/>
<wire x1="2.14" y1="4.4" x2="1.6701" y2="4.4" width="0.2032" layer="51"/>
<wire x1="4.4" y1="4.4" x2="2.9401" y2="4.4" width="0.2032" layer="51"/>
<wire x1="0.4001" y1="-4.4" x2="0.87" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="-0.4001" y1="-4.3985" x2="0.4001" y2="-4.3985" width="0.2032" layer="51" curve="-180"/>
<wire x1="0.87" y1="-4.3985" x2="1.67" y2="-4.3985" width="0.2032" layer="51" curve="-180"/>
<wire x1="2.9401" y1="-4.4" x2="4.4" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="-0.87" y1="-4.4" x2="-0.4001" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="-1.6701" y1="-4.3985" x2="-0.8699" y2="-4.3985" width="0.2032" layer="51" curve="-180"/>
<wire x1="-2.9401" y1="-4.3985" x2="-2.1399" y2="-4.3985" width="0.2032" layer="51" curve="-180"/>
<wire x1="-2.14" y1="-4.4" x2="-1.6701" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="-4.4" y1="-4.4" x2="-2.9401" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="4.4" y1="0.4001" x2="4.4" y2="0.87" width="0.2032" layer="51"/>
<wire x1="4.3985" y1="0.4001" x2="4.3985" y2="-0.4001" width="0.2032" layer="51" curve="180"/>
<wire x1="4.3985" y1="1.6701" x2="4.3985" y2="0.8699" width="0.2032" layer="51" curve="180"/>
<wire x1="4.4" y1="2.9401" x2="4.4" y2="4.4" width="0.2032" layer="51"/>
<wire x1="4.4" y1="-0.87" x2="4.4" y2="-0.4001" width="0.2032" layer="51"/>
<wire x1="4.3985" y1="-0.87" x2="4.3985" y2="-1.67" width="0.2032" layer="51" curve="180"/>
<wire x1="4.3985" y1="-2.14" x2="4.3985" y2="-2.94" width="0.2032" layer="51" curve="180"/>
<wire x1="4.4" y1="-2.14" x2="4.4" y2="-1.6701" width="0.2032" layer="51"/>
<wire x1="4.4" y1="-4.4" x2="4.4" y2="-2.9401" width="0.2032" layer="51"/>
<wire x1="-2.9401" y1="4.3985" x2="-2.1399" y2="4.3985" width="0.2032" layer="51" curve="180"/>
<wire x1="-1.6701" y1="4.4" x2="-2.14" y2="4.4" width="0.2032" layer="51"/>
<wire x1="-4.3985" y1="-2.9401" x2="-4.3985" y2="-2.1399" width="0.2032" layer="51" curve="180"/>
<wire x1="-4.4" y1="-1.6701" x2="-4.4" y2="-2.14" width="0.2032" layer="51"/>
<wire x1="1.6701" y1="-4.4" x2="2.14" y2="-4.4" width="0.2032" layer="51"/>
<wire x1="2.14" y1="-4.3985" x2="2.94" y2="-4.3985" width="0.2032" layer="51" curve="-180"/>
<wire x1="4.3985" y1="2.9401" x2="4.3985" y2="2.1399" width="0.2032" layer="51" curve="180"/>
<wire x1="4.4" y1="1.6701" x2="4.4" y2="2.14" width="0.2032" layer="51"/>
<smd name="2" x="-1.27" y="4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="1" x="0" y="3.8001" dx="0.8" dy="3.4" layer="1"/>
<smd name="3" x="-2.54" y="4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="4" x="-4.5001" y="2.54" dx="2" dy="0.8" layer="1"/>
<smd name="5" x="-4.5001" y="1.27" dx="2" dy="0.8" layer="1"/>
<smd name="6" x="-4.5001" y="0" dx="2" dy="0.8" layer="1"/>
<smd name="7" x="-4.5001" y="-1.27" dx="2" dy="0.8" layer="1"/>
<smd name="8" x="-4.5001" y="-2.54" dx="2" dy="0.8" layer="1"/>
<smd name="9" x="-2.54" y="-4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="10" x="-1.27" y="-4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="11" x="0" y="-4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="12" x="1.27" y="-4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="13" x="2.54" y="-4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="14" x="4.5001" y="-2.54" dx="2" dy="0.8" layer="1"/>
<smd name="15" x="4.5001" y="-1.27" dx="2" dy="0.8" layer="1"/>
<smd name="16" x="4.5001" y="0" dx="2" dy="0.8" layer="1"/>
<smd name="17" x="4.5001" y="1.27" dx="2" dy="0.8" layer="1"/>
<smd name="18" x="4.5001" y="2.54" dx="2" dy="0.8" layer="1"/>
<smd name="19" x="2.54" y="4.5001" dx="0.8" dy="2" layer="1"/>
<smd name="20" x="1.27" y="4.5001" dx="0.8" dy="2" layer="1"/>
<text x="-3.4971" y="5.811" size="1.778" layer="25">&gt;NAME</text>
<text x="-3.9751" y="-7.6871" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL14">
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO14">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.064" y1="1.9558" x2="-4.064" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.9558" x2="4.445" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.445" y1="1.5748" x2="-4.064" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.064" y1="1.9558" x2="4.445" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.445" y1="-1.5748" x2="-4.064" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.064" y1="-1.9558" x2="4.064" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.5748" x2="4.445" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.5748" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.445" y1="-1.6002" x2="4.445" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="-1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="0" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="0" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.556" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.699" y="-1.778" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.254" y1="1.9558" x2="0.254" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="-3.0988" x2="-3.556" y2="-1.9558" layer="51"/>
<rectangle x1="-2.794" y1="-3.0988" x2="-2.286" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="-3.0734" x2="-1.016" y2="-1.9304" layer="51"/>
<rectangle x1="-0.254" y1="-3.0988" x2="0.254" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="1.9558" x2="-1.016" y2="3.0988" layer="51"/>
<rectangle x1="-2.794" y1="1.9558" x2="-2.286" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="1.9558" x2="-3.556" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="1.9558" x2="1.524" y2="3.0988" layer="51"/>
<rectangle x1="2.286" y1="1.9558" x2="2.794" y2="3.0988" layer="51"/>
<rectangle x1="3.556" y1="1.9558" x2="4.064" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="-3.0988" x2="1.524" y2="-1.9558" layer="51"/>
<rectangle x1="2.286" y1="-3.0988" x2="2.794" y2="-1.9558" layer="51"/>
<rectangle x1="3.556" y1="-3.0988" x2="4.064" y2="-1.9558" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="74688">
<wire x1="-7.62" y1="-25.4" x2="7.62" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-25.4" x2="7.62" y2="25.4" width="0.4064" layer="94"/>
<wire x1="7.62" y1="25.4" x2="-7.62" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="25.4" x2="-7.62" y2="-25.4" width="0.4064" layer="94"/>
<text x="-7.62" y="26.035" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<pin name="G" x="-12.7" y="-22.86" length="middle" direction="in" function="dot"/>
<pin name="P0" x="-12.7" y="22.86" length="middle" direction="in"/>
<pin name="Q0" x="-12.7" y="0" length="middle" direction="in"/>
<pin name="P1" x="-12.7" y="20.32" length="middle" direction="in"/>
<pin name="Q1" x="-12.7" y="-2.54" length="middle" direction="in"/>
<pin name="P2" x="-12.7" y="17.78" length="middle" direction="in"/>
<pin name="Q2" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="P3" x="-12.7" y="15.24" length="middle" direction="in"/>
<pin name="Q3" x="-12.7" y="-7.62" length="middle" direction="in"/>
<pin name="P4" x="-12.7" y="12.7" length="middle" direction="in"/>
<pin name="Q4" x="-12.7" y="-10.16" length="middle" direction="in"/>
<pin name="P5" x="-12.7" y="10.16" length="middle" direction="in"/>
<pin name="Q5" x="-12.7" y="-12.7" length="middle" direction="in"/>
<pin name="P6" x="-12.7" y="7.62" length="middle" direction="in"/>
<pin name="Q6" x="-12.7" y="-15.24" length="middle" direction="in"/>
<pin name="P7" x="-12.7" y="5.08" length="middle" direction="in"/>
<pin name="Q7" x="-12.7" y="-17.78" length="middle" direction="in"/>
<pin name="P=Q" x="12.7" y="22.86" length="middle" direction="out" function="dot" rot="R180"/>
</symbol>
<symbol name="PWRN">
<text x="-0.635" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="-7.62" size="1.27" layer="95" rot="R90">GND</text>
<text x="1.905" y="5.08" size="1.27" layer="95" rot="R90">VCC</text>
<pin name="GND" x="0" y="-10.16" visible="pad" direction="pwr" rot="R90"/>
<pin name="VCC" x="0" y="10.16" visible="pad" direction="pwr" rot="R270"/>
</symbol>
<symbol name="7400">
<wire x1="-7.62" y1="5.08" x2="-7.62" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="2.54" y1="5.08" x2="-7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="-5.08" width="0.4064" layer="94" curve="-180"/>
<text x="-7.62" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="I0" x="-12.7" y="2.54" visible="pad" length="middle" direction="in" swaplevel="1"/>
<pin name="I1" x="-12.7" y="-2.54" visible="pad" length="middle" direction="in" swaplevel="1"/>
<pin name="O" x="12.7" y="0" visible="pad" length="middle" direction="out" function="dot" rot="R180"/>
</symbol>
<symbol name="7404">
<wire x1="-5.08" y1="5.08" x2="5.08" y2="0" width="0.4064" layer="94"/>
<wire x1="5.08" y1="0" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="5.08" width="0.4064" layer="94"/>
<text x="2.54" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="I" x="-10.16" y="0" visible="pad" length="middle" direction="in"/>
<pin name="O" x="10.16" y="0" visible="pad" length="middle" direction="out" function="dot" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="74*688" prefix="IC">
<description>8-bit &lt;b&gt;MAGNITUDE/IDENTITY COMPARATOR&lt;/b&gt;, totem pole</description>
<gates>
<gate name="A" symbol="74688" x="20.32" y="0"/>
<gate name="P" symbol="PWRN" x="-5.08" y="0" addlevel="request"/>
</gates>
<devices>
<device name="N" package="DIL20">
<connects>
<connect gate="A" pin="G" pad="1"/>
<connect gate="A" pin="P0" pad="2"/>
<connect gate="A" pin="P1" pad="4"/>
<connect gate="A" pin="P2" pad="6"/>
<connect gate="A" pin="P3" pad="8"/>
<connect gate="A" pin="P4" pad="11"/>
<connect gate="A" pin="P5" pad="13"/>
<connect gate="A" pin="P6" pad="15"/>
<connect gate="A" pin="P7" pad="17"/>
<connect gate="A" pin="P=Q" pad="19"/>
<connect gate="A" pin="Q0" pad="3"/>
<connect gate="A" pin="Q1" pad="5"/>
<connect gate="A" pin="Q2" pad="7"/>
<connect gate="A" pin="Q3" pad="9"/>
<connect gate="A" pin="Q4" pad="12"/>
<connect gate="A" pin="Q5" pad="14"/>
<connect gate="A" pin="Q6" pad="16"/>
<connect gate="A" pin="Q7" pad="18"/>
<connect gate="P" pin="GND" pad="10"/>
<connect gate="P" pin="VCC" pad="20"/>
</connects>
<technologies>
<technology name="LS"/>
</technologies>
</device>
<device name="DW" package="SO20W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FK" package="LCC20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="74*00" prefix="IC">
<description>Quad 2-input &lt;b&gt;NAND&lt;/b&gt; gate</description>
<gates>
<gate name="A" symbol="7400" x="20.32" y="0" swaplevel="1"/>
<gate name="B" symbol="7400" x="20.32" y="-12.7" swaplevel="1"/>
<gate name="C" symbol="7400" x="48.26" y="0" swaplevel="1"/>
<gate name="D" symbol="7400" x="48.26" y="-12.7" swaplevel="1"/>
<gate name="P" symbol="PWRN" x="2.54" y="-5.08" addlevel="request"/>
</gates>
<devices>
<device name="N" package="DIL14">
<connects>
<connect gate="A" pin="I0" pad="1"/>
<connect gate="A" pin="I1" pad="2"/>
<connect gate="A" pin="O" pad="3"/>
<connect gate="B" pin="I0" pad="4"/>
<connect gate="B" pin="I1" pad="5"/>
<connect gate="B" pin="O" pad="6"/>
<connect gate="C" pin="I0" pad="9"/>
<connect gate="C" pin="I1" pad="10"/>
<connect gate="C" pin="O" pad="8"/>
<connect gate="D" pin="I0" pad="12"/>
<connect gate="D" pin="I1" pad="13"/>
<connect gate="D" pin="O" pad="11"/>
<connect gate="P" pin="GND" pad="7"/>
<connect gate="P" pin="VCC" pad="14"/>
</connects>
<technologies>
<technology name="ALS"/>
<technology name="AS"/>
<technology name="S"/>
</technologies>
</device>
<device name="D" package="SO14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
<connect gate="A" pin="I0" pad="2"/>
<connect gate="A" pin="I1" pad="3"/>
<connect gate="A" pin="O" pad="4"/>
<connect gate="B" pin="I0" pad="6"/>
<connect gate="B" pin="I1" pad="8"/>
<connect gate="B" pin="O" pad="9"/>
<connect gate="C" pin="I0" pad="13"/>
<connect gate="C" pin="I1" pad="14"/>
<connect gate="C" pin="O" pad="12"/>
<connect gate="D" pin="I0" pad="18"/>
<connect gate="D" pin="I1" pad="19"/>
<connect gate="D" pin="O" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="74*04" prefix="IC">
<description>Hex &lt;b&gt;INVERTER&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="7404" x="17.78" y="0" swaplevel="1"/>
<gate name="B" symbol="7404" x="17.78" y="-12.7" swaplevel="1"/>
<gate name="C" symbol="7404" x="17.78" y="-25.4" swaplevel="1"/>
<gate name="D" symbol="7404" x="45.72" y="0" swaplevel="1"/>
<gate name="E" symbol="7404" x="45.72" y="-12.7" swaplevel="1"/>
<gate name="F" symbol="7404" x="45.72" y="-25.4" swaplevel="1"/>
<gate name="P" symbol="PWRN" x="-5.08" y="-10.16" addlevel="request"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="I" pad="1"/>
<connect gate="A" pin="O" pad="2"/>
<connect gate="B" pin="I" pad="3"/>
<connect gate="B" pin="O" pad="4"/>
<connect gate="C" pin="I" pad="5"/>
<connect gate="C" pin="O" pad="6"/>
<connect gate="D" pin="I" pad="9"/>
<connect gate="D" pin="O" pad="8"/>
<connect gate="E" pin="I" pad="11"/>
<connect gate="E" pin="O" pad="10"/>
<connect gate="F" pin="I" pad="13"/>
<connect gate="F" pin="O" pad="12"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
<connect gate="A" pin="I" pad="2"/>
<connect gate="B" pin="I" pad="4"/>
<connect gate="C" pin="I" pad="8"/>
<connect gate="C" pin="O" pad="9"/>
<connect gate="D" pin="I" pad="13"/>
<connect gate="D" pin="O" pad="12"/>
<connect gate="E" pin="I" pad="16"/>
<connect gate="E" pin="O" pad="14"/>
<connect gate="F" pin="I" pad="19"/>
<connect gate="F" pin="O" pad="18"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="plcc-socketed-devs">
<packages>
<package name="S44">
<description>&lt;b&gt;PLCC SOCKET&lt;/b&gt;</description>
<wire x1="-10.16" y1="11.684" x2="-11.684" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="10.16" x2="-11.684" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="6.985" x2="-6.985" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-7.239" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-10.414" y2="-9.398" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-9.398" x2="-8.255" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-7.239" x2="-8.255" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-8.255" x2="-6.985" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-9.398" x2="-5.461" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-9.398" x2="-5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-10.414" x2="-4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-10.414" x2="-4.699" y2="-9.398" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-8.255" x2="-4.699" y2="-9.398" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-8.255" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-2.921" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-9.525" x2="-2.921" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-9.525" x2="-2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-10.414" x2="-2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-10.414" x2="-2.159" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-8.255" x2="-2.159" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-8.255" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.381" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-9.525" x2="-0.381" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-9.525" x2="-0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-10.414" x2="0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-10.414" x2="0.381" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-8.255" x2="0.381" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-8.255" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="10.414" y1="9.398" x2="8.255" y2="7.239" width="0.1524" layer="21"/>
<wire x1="10.414" y1="9.398" x2="9.398" y2="10.414" width="0.1524" layer="21"/>
<wire x1="9.398" y1="10.414" x2="7.239" y2="8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="7.239" x2="8.255" y2="6.985" width="0.1524" layer="21"/>
<wire x1="8.255" y1="5.969" x2="8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.461" x2="9.398" y2="5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="5.461" x2="9.398" y2="5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="5.461" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="4.699" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="4.699" x2="8.255" y2="4.699" width="0.1524" layer="51"/>
<wire x1="8.255" y1="4.699" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="8.255" y1="2.921" x2="9.398" y2="2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="2.921" x2="9.398" y2="2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.921" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="2.159" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="2.159" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="8.255" y2="0.381" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.381" x2="9.398" y2="0.381" width="0.1524" layer="51"/>
<wire x1="10.414" y1="0.381" x2="9.398" y2="0.381" width="0.1524" layer="21"/>
<wire x1="10.414" y1="0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-0.381" x2="8.255" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-0.381" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-6.985" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.461" x2="-9.398" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.461" x2="-9.398" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-5.461" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-4.699" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-4.699" x2="-8.255" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-4.699" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-2.921" x2="-9.398" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.921" x2="-9.398" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.921" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-2.159" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-2.159" x2="-8.255" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-2.159" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-8.255" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.381" x2="-9.398" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.381" x2="-9.398" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="0.381" x2="-8.255" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="0.381" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="7.239" y1="8.255" x2="6.985" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.969" y1="8.255" x2="5.461" y2="8.255" width="0.1524" layer="51"/>
<wire x1="5.461" y1="8.255" x2="5.461" y2="9.398" width="0.1524" layer="51"/>
<wire x1="5.461" y1="10.414" x2="5.461" y2="9.398" width="0.1524" layer="21"/>
<wire x1="5.461" y1="10.414" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="9.398" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="9.398" x2="4.699" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="8.255" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="2.921" y2="8.255" width="0.1524" layer="51"/>
<wire x1="2.921" y1="8.255" x2="2.921" y2="9.398" width="0.1524" layer="51"/>
<wire x1="2.921" y1="10.414" x2="2.921" y2="9.398" width="0.1524" layer="21"/>
<wire x1="2.921" y1="10.414" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="9.398" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="9.398" x2="2.159" y2="8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="8.255" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.381" y2="8.255" width="0.1524" layer="51"/>
<wire x1="0.381" y1="8.255" x2="0.381" y2="9.398" width="0.1524" layer="51"/>
<wire x1="0.381" y1="10.414" x2="0.381" y2="9.398" width="0.1524" layer="21"/>
<wire x1="0.381" y1="10.414" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="9.398" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="9.398" x2="-0.381" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="8.255" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="8.255" x2="-2.159" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="8.255" x2="-2.159" y2="9.398" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="10.414" x2="-2.159" y2="9.398" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="10.414" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="9.398" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="9.398" x2="-2.921" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="8.255" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.699" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="8.255" x2="-4.699" y2="9.398" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="10.414" x2="-4.699" y2="9.398" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="10.414" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="9.398" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="9.398" x2="-5.461" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="8.255" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="2.159" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-9.525" x2="2.159" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-9.525" x2="2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-10.414" x2="2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-10.414" x2="2.921" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-8.255" x2="2.921" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-8.255" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.699" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-9.525" x2="4.699" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-9.525" x2="4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-10.414" x2="5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-10.414" x2="5.461" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-8.255" x2="5.461" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-8.255" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.461" x2="-9.398" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="5.461" x2="-9.398" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="5.461" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="4.699" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="4.699" x2="-8.255" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="4.699" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="2.921" x2="-9.398" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.921" x2="-9.398" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.921" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="2.159" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-10.414" x2="-6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-8.255" x2="-6.985" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-10.414" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-8.255" x2="-5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-8.255" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="8.255" y1="6.731" x2="8.255" y2="6.985" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.969" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-1.651" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.651" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="8.255" x2="6.985" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="8.255" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="8.255" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="8.255" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="7.112" y1="-8.255" x2="6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="-8.255" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-6.731" x2="8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-6.731" x2="8.255" y2="-7.112" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-6.731" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.461" x2="9.398" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.461" x2="9.398" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-5.461" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-4.699" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-4.699" x2="8.255" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-4.699" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-2.921" x2="9.398" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.921" x2="9.398" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.921" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="9.398" y1="-2.159" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-8.255" x2="8.255" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-8.255" x2="8.255" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.651" x2="8.255" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-2.159" x2="9.398" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="8.255" x2="-6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="6.731" x2="-8.255" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="2.159" x2="-8.255" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="2.159" x2="-8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-11.049" x2="-11.049" y2="-11.684" width="0.1524" layer="21" curve="90"/>
<wire x1="11.049" y1="-11.684" x2="-11.049" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-11.684" x2="11.684" y2="-11.049" width="0.1524" layer="21" curve="90"/>
<wire x1="11.049" y1="11.684" x2="-10.16" y2="11.684" width="0.1524" layer="21"/>
<wire x1="11.684" y1="11.049" x2="11.684" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="11.049" y1="11.684" x2="11.684" y2="11.049" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="3.81" x2="1.27" y2="3.81" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.81" x2="0" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0" y1="5.08" x2="-1.27" y2="3.81" width="0.1524" layer="21"/>
<circle x="-2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="-2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="6.35" drill="0.8128"/>
<pad name="2" x="-1.27" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="4" x="-3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="5" x="-3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="6" x="-6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="7" x="-8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="8" x="-6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="9" x="-8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="10" x="-6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="11" x="-8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="-6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="-8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="-6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="15" x="-8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="16" x="-6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="17" x="-8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="18" x="-6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="19" x="-6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="20" x="-3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="21" x="-3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="22" x="-1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="23" x="-1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="24" x="1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="25" x="1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="26" x="3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="27" x="3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="28" x="6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="29" x="8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="30" x="6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="31" x="8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="32" x="6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="33" x="8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="34" x="6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="35" x="8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="36" x="6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="37" x="8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="38" x="6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="39" x="8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="40" x="6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="41" x="6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="42" x="3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="43" x="3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="44" x="1.27" y="8.89" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="11.938" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.16" y="11.938" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="8.255" y="-10.795" size="1.27" layer="21" ratio="10">44</text>
<rectangle x1="-0.508" y1="2.159" x2="0.508" y2="4.064" layer="21"/>
<rectangle x1="-0.889" y1="3.81" x2="0.889" y2="4.191" layer="21"/>
<rectangle x1="-0.635" y1="4.191" x2="0.635" y2="4.445" layer="21"/>
<rectangle x1="-0.381" y1="4.445" x2="0.381" y2="4.699" layer="21"/>
<rectangle x1="-0.127" y1="4.699" x2="0.127" y2="4.953" layer="21"/>
<rectangle x1="-1.143" y1="3.81" x2="-0.889" y2="3.937" layer="21"/>
<rectangle x1="-1.016" y1="3.937" x2="-0.889" y2="4.064" layer="21"/>
<rectangle x1="-0.762" y1="4.191" x2="-0.635" y2="4.318" layer="21"/>
<rectangle x1="-0.508" y1="4.445" x2="-0.381" y2="4.572" layer="21"/>
<rectangle x1="-0.254" y1="4.699" x2="-0.127" y2="4.826" layer="21"/>
<rectangle x1="0.127" y1="4.699" x2="0.254" y2="4.826" layer="21"/>
<rectangle x1="0.381" y1="4.445" x2="0.508" y2="4.572" layer="21"/>
<rectangle x1="0.635" y1="4.191" x2="0.762" y2="4.318" layer="21"/>
<rectangle x1="0.889" y1="3.81" x2="1.143" y2="3.937" layer="21"/>
<rectangle x1="0.889" y1="3.937" x2="1.016" y2="4.064" layer="21"/>
</package>
<package name="DIL40">
<wire x1="25.4" y1="6.731" x2="-25.4" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="25.4" y1="6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.731" x2="-25.4" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="-25.4" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.889" x2="-25.4" y2="-1.143" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.908" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-17.145" y="-1.016" size="1.778" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="Z8530">
<wire x1="-12.7" y1="27.94" x2="-12.7" y2="-27.94" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-27.94" x2="12.7" y2="-27.94" width="0.254" layer="94"/>
<wire x1="12.7" y1="-27.94" x2="12.7" y2="27.94" width="0.254" layer="94"/>
<wire x1="12.7" y1="27.94" x2="-12.7" y2="27.94" width="0.254" layer="94"/>
<pin name="D7" x="-17.78" y="25.4" length="middle"/>
<pin name="D6" x="-17.78" y="22.86" length="middle"/>
<pin name="D5" x="-17.78" y="20.32" length="middle"/>
<pin name="D4" x="-17.78" y="17.78" length="middle"/>
<pin name="D3" x="-17.78" y="15.24" length="middle"/>
<pin name="D2" x="-17.78" y="12.7" length="middle"/>
<pin name="D1" x="-17.78" y="10.16" length="middle"/>
<pin name="D0" x="-17.78" y="7.62" length="middle"/>
<pin name="/RD" x="-17.78" y="2.54" length="middle"/>
<pin name="/WR" x="-17.78" y="0" length="middle"/>
<pin name="A//B" x="-17.78" y="-5.08" length="middle"/>
<pin name="/CE" x="-17.78" y="-7.62" length="middle"/>
<pin name="D//C" x="-17.78" y="-10.16" length="middle"/>
<pin name="/INT" x="-17.78" y="-15.24" length="middle"/>
<pin name="/INTACK" x="-17.78" y="-17.78" length="middle"/>
<pin name="IEI" x="-17.78" y="-20.32" length="middle"/>
<pin name="IEO" x="-17.78" y="-22.86" length="middle"/>
<pin name="TXDA" x="17.78" y="25.4" length="middle" rot="R180"/>
<pin name="RXDA" x="17.78" y="22.86" length="middle" rot="R180"/>
<pin name="/TRXCA" x="17.78" y="20.32" length="middle" rot="R180"/>
<pin name="/RTXCA" x="17.78" y="17.78" length="middle" rot="R180"/>
<pin name="/SYNCA" x="17.78" y="15.24" length="middle" rot="R180"/>
<pin name="/W//REQA" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="/DTR//REQA" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="/RTSA" x="17.78" y="7.62" length="middle" rot="R180"/>
<pin name="/CTSA" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="/DCDA" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="TXDB" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="RXDB" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="/TRXCB" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="/RTXCB" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="/SYNCB" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="/W//REQB" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="/RTSB" x="17.78" y="-20.32" length="middle" rot="R180"/>
<pin name="/DTR//REQB" x="17.78" y="-17.78" length="middle" rot="R180"/>
<pin name="/CTSB" x="17.78" y="-22.86" length="middle" rot="R180"/>
<pin name="/DCDB" x="17.78" y="-25.4" length="middle" rot="R180"/>
<pin name="GND" x="0" y="-33.02" length="middle" rot="R90"/>
<pin name="VCC" x="0" y="33.02" length="middle" rot="R270"/>
<pin name="PCLK" x="-17.78" y="-25.4" length="middle"/>
</symbol>
<symbol name="82C55A">
<wire x1="-15.24" y1="-35.56" x2="2.54" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="2.54" y1="-35.56" x2="2.54" y2="33.02" width="0.4064" layer="94"/>
<wire x1="2.54" y1="33.02" x2="-15.24" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-15.24" y1="33.02" x2="-15.24" y2="-35.56" width="0.4064" layer="94"/>
<text x="-15.24" y="33.655" size="1.778" layer="95">&gt;NAME</text>
<text x="-15.24" y="-38.1" size="1.778" layer="96">&gt;VALUE</text>
<pin name="PA3" x="7.62" y="22.86" length="middle" rot="R180"/>
<pin name="PA2" x="7.62" y="25.4" length="middle" rot="R180"/>
<pin name="PA1" x="7.62" y="27.94" length="middle" rot="R180"/>
<pin name="PA0" x="7.62" y="30.48" length="middle" rot="R180"/>
<pin name="!RD" x="-20.32" y="7.62" length="middle" direction="in"/>
<pin name="!CS" x="-20.32" y="-12.7" length="middle" direction="in"/>
<pin name="A1" x="-20.32" y="-2.54" length="middle" direction="in"/>
<pin name="A0" x="-20.32" y="0" length="middle" direction="in"/>
<pin name="PC7" x="7.62" y="-33.02" length="middle" rot="R180"/>
<pin name="PC6" x="7.62" y="-30.48" length="middle" rot="R180"/>
<pin name="PC5" x="7.62" y="-27.94" length="middle" rot="R180"/>
<pin name="PC4" x="7.62" y="-25.4" length="middle" rot="R180"/>
<pin name="PC0" x="7.62" y="-15.24" length="middle" rot="R180"/>
<pin name="PC1" x="7.62" y="-17.78" length="middle" rot="R180"/>
<pin name="PC2" x="7.62" y="-20.32" length="middle" rot="R180"/>
<pin name="PC3" x="7.62" y="-22.86" length="middle" rot="R180"/>
<pin name="PB0" x="7.62" y="7.62" length="middle" rot="R180"/>
<pin name="PB1" x="7.62" y="5.08" length="middle" rot="R180"/>
<pin name="PB2" x="7.62" y="2.54" length="middle" rot="R180"/>
<pin name="PB3" x="7.62" y="0" length="middle" rot="R180"/>
<pin name="PB4" x="7.62" y="-2.54" length="middle" rot="R180"/>
<pin name="PB5" x="7.62" y="-5.08" length="middle" rot="R180"/>
<pin name="PB6" x="7.62" y="-7.62" length="middle" rot="R180"/>
<pin name="PB7" x="7.62" y="-10.16" length="middle" rot="R180"/>
<pin name="D7" x="-20.32" y="12.7" length="middle"/>
<pin name="D6" x="-20.32" y="15.24" length="middle"/>
<pin name="D5" x="-20.32" y="17.78" length="middle"/>
<pin name="D4" x="-20.32" y="20.32" length="middle"/>
<pin name="D3" x="-20.32" y="22.86" length="middle"/>
<pin name="D2" x="-20.32" y="25.4" length="middle"/>
<pin name="D1" x="-20.32" y="27.94" length="middle"/>
<pin name="D0" x="-20.32" y="30.48" length="middle"/>
<pin name="RESET" x="-20.32" y="-7.62" length="middle" direction="in"/>
<pin name="!WR" x="-20.32" y="5.08" length="middle" direction="in"/>
<pin name="PA7" x="7.62" y="12.7" length="middle" rot="R180"/>
<pin name="PA6" x="7.62" y="15.24" length="middle" rot="R180"/>
<pin name="PA5" x="7.62" y="17.78" length="middle" rot="R180"/>
<pin name="PA4" x="7.62" y="20.32" length="middle" rot="R180"/>
</symbol>
<text x="-1.27" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="-5.842" size="1.27" layer="95" rot="R90">GND</text>
<text x="1.905" y="2.667" size="1.27" layer="95" rot="R90">VCC</text>
<pin name="GND" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
<pin name="VCC" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="Z8530">
<description>Zilog 8530 SCC in PLCC socket</description>
<gates>
<gate name="G$1" symbol="Z8530" x="0" y="0"/>
</gates>
<devices>
<device name="" package="S44">
<connects>
<connect gate="G$1" pin="/CE" pad="38"/>
<connect gate="G$1" pin="/CTSA" pad="21"/>
<connect gate="G$1" pin="/CTSB" pad="25"/>
<connect gate="G$1" pin="/DCDA" pad="22"/>
<connect gate="G$1" pin="/DCDB" pad="24"/>
<connect gate="G$1" pin="/DTR//REQA" pad="19"/>
<connect gate="G$1" pin="/DTR//REQB" pad="27"/>
<connect gate="G$1" pin="/INT" pad="6"/>
<connect gate="G$1" pin="/INTACK" pad="9"/>
<connect gate="G$1" pin="/RD" pad="41"/>
<connect gate="G$1" pin="/RTSA" pad="20"/>
<connect gate="G$1" pin="/RTSB" pad="26"/>
<connect gate="G$1" pin="/RTXCA" pad="13"/>
<connect gate="G$1" pin="/RTXCB" pad="32"/>
<connect gate="G$1" pin="/SYNCA" pad="12"/>
<connect gate="G$1" pin="/SYNCB" pad="33"/>
<connect gate="G$1" pin="/TRXCA" pad="15"/>
<connect gate="G$1" pin="/TRXCB" pad="30"/>
<connect gate="G$1" pin="/W//REQA" pad="11"/>
<connect gate="G$1" pin="/W//REQB" pad="34"/>
<connect gate="G$1" pin="/WR" pad="40"/>
<connect gate="G$1" pin="A//B" pad="39"/>
<connect gate="G$1" pin="D//C" pad="37"/>
<connect gate="G$1" pin="D0" pad="1"/>
<connect gate="G$1" pin="D1" pad="2"/>
<connect gate="G$1" pin="D2" pad="44"/>
<connect gate="G$1" pin="D3" pad="3"/>
<connect gate="G$1" pin="D4" pad="43"/>
<connect gate="G$1" pin="D5" pad="4"/>
<connect gate="G$1" pin="D6" pad="42"/>
<connect gate="G$1" pin="D7" pad="5"/>
<connect gate="G$1" pin="GND" pad="35"/>
<connect gate="G$1" pin="IEI" pad="8"/>
<connect gate="G$1" pin="IEO" pad="7"/>
<connect gate="G$1" pin="PCLK" pad="23"/>
<connect gate="G$1" pin="RXDA" pad="14"/>
<connect gate="G$1" pin="RXDB" pad="31"/>
<connect gate="G$1" pin="TXDA" pad="16"/>
<connect gate="G$1" pin="TXDB" pad="29"/>
<connect gate="G$1" pin="VCC" pad="10"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="82C55A" prefix="U" uservalue="yes">
<description>&lt;b&gt;MICROCONTROLLER/MEMORY DEVICE&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="82C55A" x="27.94" y="0"/>
<gate name="P" symbol="PWRN" x="-10.16" y="7.62" addlevel="request"/>
</gates>
<devices>
<device name="DIL40" package="DIL40">
<connects>
<connect gate="A" pin="!CS" pad="6"/>
<connect gate="A" pin="!RD" pad="5"/>
<connect gate="A" pin="!WR" pad="36"/>
<connect gate="A" pin="A0" pad="9"/>
<connect gate="A" pin="A1" pad="8"/>
<connect gate="A" pin="D0" pad="34"/>
<connect gate="A" pin="D1" pad="33"/>
<connect gate="A" pin="D2" pad="32"/>
<connect gate="A" pin="D3" pad="31"/>
<connect gate="A" pin="D4" pad="30"/>
<connect gate="A" pin="D5" pad="29"/>
<connect gate="A" pin="D6" pad="28"/>
<connect gate="A" pin="D7" pad="27"/>
<connect gate="A" pin="PA0" pad="4"/>
<connect gate="A" pin="PA1" pad="3"/>
<connect gate="A" pin="PA2" pad="2"/>
<connect gate="A" pin="PA3" pad="1"/>
<connect gate="A" pin="PA4" pad="40"/>
<connect gate="A" pin="PA5" pad="39"/>
<connect gate="A" pin="PA6" pad="38"/>
<connect gate="A" pin="PA7" pad="37"/>
<connect gate="A" pin="PB0" pad="18"/>
<connect gate="A" pin="PB1" pad="19"/>
<connect gate="A" pin="PB2" pad="20"/>
<connect gate="A" pin="PB3" pad="21"/>
<connect gate="A" pin="PB4" pad="22"/>
<connect gate="A" pin="PB5" pad="23"/>
<connect gate="A" pin="PB6" pad="24"/>
<connect gate="A" pin="PB7" pad="25"/>
<connect gate="A" pin="PC0" pad="14"/>
<connect gate="A" pin="PC1" pad="15"/>
<connect gate="A" pin="PC2" pad="16"/>
<connect gate="A" pin="PC3" pad="17"/>
<connect gate="A" pin="PC4" pad="13"/>
<connect gate="A" pin="PC5" pad="12"/>
<connect gate="A" pin="PC6" pad="11"/>
<connect gate="A" pin="PC7" pad="10"/>
<connect gate="A" pin="RESET" pad="35"/>
<connect gate="P" pin="VCC" pad="26"/>
</connects>
<technologies>
</technologies>
</device>
<device name="PLCC44" package="S44">
<connects>
<connect gate="A" pin="!CS" pad="7"/>
<connect gate="A" pin="!RD" pad="6"/>
<connect gate="A" pin="!WR" pad="40"/>
<connect gate="A" pin="A0" pad="10"/>
<connect gate="A" pin="A1" pad="9"/>
<connect gate="A" pin="D0" pad="38"/>
<connect gate="A" pin="D1" pad="37"/>
<connect gate="A" pin="D2" pad="36"/>
<connect gate="A" pin="D3" pad="35"/>
<connect gate="A" pin="D4" pad="33"/>
<connect gate="A" pin="D5" pad="32"/>
<connect gate="A" pin="D6" pad="31"/>
<connect gate="A" pin="D7" pad="30"/>
<connect gate="A" pin="PA0" pad="5"/>
<connect gate="A" pin="PA1" pad="4"/>
<connect gate="A" pin="PA2" pad="3"/>
<connect gate="A" pin="PA3" pad="2"/>
<connect gate="A" pin="PA4" pad="44"/>
<connect gate="A" pin="PA5" pad="43"/>
<connect gate="A" pin="PA6" pad="42"/>
<connect gate="A" pin="PA7" pad="41"/>
<connect gate="A" pin="PB0" pad="20"/>
<connect gate="A" pin="PB1" pad="21"/>
<connect gate="A" pin="PB2" pad="22"/>
<connect gate="A" pin="PB3" pad="24"/>
<connect gate="A" pin="PB4" pad="25"/>
<connect gate="A" pin="PB5" pad="26"/>
<connect gate="A" pin="PB6" pad="27"/>
<connect gate="A" pin="PB7" pad="28"/>
<connect gate="A" pin="PC0" pad="16"/>
<connect gate="A" pin="PC1" pad="17"/>
<connect gate="A" pin="PC2" pad="18"/>
<connect gate="A" pin="PC3" pad="19"/>
<connect gate="A" pin="PC4" pad="15"/>
<connect gate="A" pin="PC5" pad="14"/>
<connect gate="A" pin="PC6" pad="13"/>
<connect gate="A" pin="PC7" pad="11"/>
<connect gate="A" pin="RESET" pad="39"/>
<connect gate="P" pin="GND" pad="8"/>
<connect gate="P" pin="VCC" pad="29"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pinhead">
<packages>
<package name="2X05">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-6.35" y1="-1.905" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<text x="-6.35" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="51"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="51"/>
</package>
<package name="2X05/90">
<wire x1="-6.35" y1="-1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.985" x2="-5.08" y2="1.27" width="0.762" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="6.985" x2="-2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="6.985" x2="0" y2="1.27" width="0.762" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="6.985" x2="2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.985" x2="5.08" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<text x="-6.985" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="8.255" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.461" y1="0.635" x2="-4.699" y2="1.143" layer="21"/>
<rectangle x1="-2.921" y1="0.635" x2="-2.159" y2="1.143" layer="21"/>
<rectangle x1="-0.381" y1="0.635" x2="0.381" y2="1.143" layer="21"/>
<rectangle x1="2.159" y1="0.635" x2="2.921" y2="1.143" layer="21"/>
<rectangle x1="4.699" y1="0.635" x2="5.461" y2="1.143" layer="21"/>
<rectangle x1="-5.461" y1="-2.921" x2="-4.699" y2="-1.905" layer="21"/>
<rectangle x1="-2.921" y1="-2.921" x2="-2.159" y2="-1.905" layer="21"/>
<rectangle x1="-5.461" y1="-5.461" x2="-4.699" y2="-4.699" layer="21"/>
<rectangle x1="-5.461" y1="-4.699" x2="-4.699" y2="-2.921" layer="51"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-2.921" layer="51"/>
<rectangle x1="-2.921" y1="-5.461" x2="-2.159" y2="-4.699" layer="21"/>
<rectangle x1="-0.381" y1="-2.921" x2="0.381" y2="-1.905" layer="21"/>
<rectangle x1="2.159" y1="-2.921" x2="2.921" y2="-1.905" layer="21"/>
<rectangle x1="-0.381" y1="-5.461" x2="0.381" y2="-4.699" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-2.921" layer="51"/>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-2.921" layer="51"/>
<rectangle x1="2.159" y1="-5.461" x2="2.921" y2="-4.699" layer="21"/>
<rectangle x1="4.699" y1="-2.921" x2="5.461" y2="-1.905" layer="21"/>
<rectangle x1="4.699" y1="-5.461" x2="5.461" y2="-4.699" layer="21"/>
<rectangle x1="4.699" y1="-4.699" x2="5.461" y2="-2.921" layer="51"/>
</package>
<package name="2X03">
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<text x="-3.81" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X03/90">
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<pad name="2" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<text x="-4.445" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.715" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="2X08">
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<text x="-10.16" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
</package>
<package name="2X08/90">
<wire x1="-10.16" y1="-1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="6.985" x2="-8.89" y2="1.27" width="0.762" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="6.985" x2="-6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.985" x2="6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="6.985" x2="8.89" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<text x="-10.795" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="12.065" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-9.271" y1="0.635" x2="-8.509" y2="1.143" layer="21"/>
<rectangle x1="-6.731" y1="0.635" x2="-5.969" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="5.969" y1="0.635" x2="6.731" y2="1.143" layer="21"/>
<rectangle x1="8.509" y1="0.635" x2="9.271" y2="1.143" layer="21"/>
<rectangle x1="-9.271" y1="-2.921" x2="-8.509" y2="-1.905" layer="21"/>
<rectangle x1="-6.731" y1="-2.921" x2="-5.969" y2="-1.905" layer="21"/>
<rectangle x1="-9.271" y1="-5.461" x2="-8.509" y2="-4.699" layer="21"/>
<rectangle x1="-9.271" y1="-4.699" x2="-8.509" y2="-2.921" layer="51"/>
<rectangle x1="-6.731" y1="-4.699" x2="-5.969" y2="-2.921" layer="51"/>
<rectangle x1="-6.731" y1="-5.461" x2="-5.969" y2="-4.699" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="-4.191" y1="-5.461" x2="-3.429" y2="-4.699" layer="21"/>
<rectangle x1="-4.191" y1="-4.699" x2="-3.429" y2="-2.921" layer="51"/>
<rectangle x1="-1.651" y1="-4.699" x2="-0.889" y2="-2.921" layer="51"/>
<rectangle x1="-1.651" y1="-5.461" x2="-0.889" y2="-4.699" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-5.461" x2="1.651" y2="-4.699" layer="21"/>
<rectangle x1="0.889" y1="-4.699" x2="1.651" y2="-2.921" layer="51"/>
<rectangle x1="3.429" y1="-4.699" x2="4.191" y2="-2.921" layer="51"/>
<rectangle x1="3.429" y1="-5.461" x2="4.191" y2="-4.699" layer="21"/>
<rectangle x1="5.969" y1="-2.921" x2="6.731" y2="-1.905" layer="21"/>
<rectangle x1="8.509" y1="-2.921" x2="9.271" y2="-1.905" layer="21"/>
<rectangle x1="5.969" y1="-5.461" x2="6.731" y2="-4.699" layer="21"/>
<rectangle x1="5.969" y1="-4.699" x2="6.731" y2="-2.921" layer="51"/>
<rectangle x1="8.509" y1="-4.699" x2="9.271" y2="-2.921" layer="51"/>
<rectangle x1="8.509" y1="-5.461" x2="9.271" y2="-4.699" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="PINH2X5">
<wire x1="-6.35" y1="-7.62" x2="8.89" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-7.62" x2="8.89" y2="7.62" width="0.4064" layer="94"/>
<wire x1="8.89" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-7.62" width="0.4064" layer="94"/>
<text x="-6.35" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X3">
<wire x1="-6.35" y1="-5.08" x2="8.89" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-5.08" x2="8.89" y2="5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X8">
<wire x1="-6.35" y1="-12.7" x2="8.89" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-12.7" x2="8.89" y2="10.16" width="0.4064" layer="94"/>
<wire x1="8.89" y1="10.16" x2="-6.35" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="10.16" x2="-6.35" y2="-12.7" width="0.4064" layer="94"/>
<text x="-6.35" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PINHD-2X5" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X5" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X05">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="10" pad="10"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="6" pad="6"/>
<connect gate="A" pin="7" pad="7"/>
<connect gate="A" pin="8" pad="8"/>
<connect gate="A" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X05/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X3" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X3" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X03/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X8" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X08">
<connects>
<connect gate="A" pin="11" pad="11"/>
<connect gate="A" pin="12" pad="12"/>
<connect gate="A" pin="13" pad="13"/>
<connect gate="A" pin="14" pad="14"/>
<connect gate="A" pin="15" pad="15"/>
<connect gate="A" pin="16" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X08/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="maxim">
<packages>
<package name="DIL16">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="MAX232">
<wire x1="-10.16" y1="15.24" x2="10.16" y2="15.24" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-17.78" x2="10.16" y2="15.24" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-17.78" x2="-10.16" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="15.24" x2="-10.16" y2="-17.78" width="0.4064" layer="94"/>
<text x="-10.16" y="15.875" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="C1+" x="-15.24" y="12.7" length="middle"/>
<pin name="C1-" x="-15.24" y="7.62" length="middle"/>
<pin name="C2+" x="-15.24" y="2.54" length="middle"/>
<pin name="C2-" x="-15.24" y="-2.54" length="middle"/>
<pin name="T1IN" x="-15.24" y="-7.62" length="middle" direction="in"/>
<pin name="T2IN" x="-15.24" y="-10.16" length="middle" direction="in"/>
<pin name="R1OUT" x="-15.24" y="-12.7" length="middle" direction="out"/>
<pin name="R2OUT" x="-15.24" y="-15.24" length="middle" direction="out"/>
<pin name="V+" x="15.24" y="10.16" length="middle" rot="R180"/>
<pin name="V-" x="15.24" y="5.08" length="middle" rot="R180"/>
<pin name="T1OUT" x="15.24" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="T2OUT" x="15.24" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="R1IN" x="15.24" y="-12.7" length="middle" direction="in" rot="R180"/>
<pin name="R2IN" x="15.24" y="-15.24" length="middle" direction="in" rot="R180"/>
</symbol>
<symbol name="VCC-GND">
<text x="1.524" y="-5.08" size="1.016" layer="95" rot="R90">GND</text>
<text x="1.524" y="2.54" size="1.016" layer="95" rot="R90">VCC</text>
<text x="-0.762" y="-0.762" size="1.778" layer="95">&gt;NAME</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MAX232" prefix="IC">
<description>&lt;b&gt;RS232 TRANSEIVER&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="MAX232" x="0" y="0"/>
<gate name="P" symbol="VCC-GND" x="25.4" y="-5.08" addlevel="request"/>
</gates>
<devices>
<device name="" package="DIL16">
<connects>
<connect gate="G$1" pin="C1+" pad="1"/>
<connect gate="G$1" pin="C1-" pad="3"/>
<connect gate="G$1" pin="C2+" pad="4"/>
<connect gate="G$1" pin="C2-" pad="5"/>
<connect gate="G$1" pin="R1IN" pad="13"/>
<connect gate="G$1" pin="R1OUT" pad="12"/>
<connect gate="G$1" pin="R2IN" pad="8"/>
<connect gate="G$1" pin="R2OUT" pad="9"/>
<connect gate="G$1" pin="T1IN" pad="11"/>
<connect gate="G$1" pin="T1OUT" pad="14"/>
<connect gate="G$1" pin="T2IN" pad="10"/>
<connect gate="G$1" pin="T2OUT" pad="7"/>
<connect gate="G$1" pin="V+" pad="2"/>
<connect gate="G$1" pin="V-" pad="6"/>
<connect gate="P" pin="GND" pad="15"/>
<connect gate="P" pin="VCC" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor">
<packages>
<package name="CT3216">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip
tantalum</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.651" y1="-0.559" x2="1.651" y2="0.559" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-0.559" x2="-1.651" y2="0.559" width="0.1524" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="21"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="21"/>
<wire x1="0.7" y1="0" x2="1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="0.97" y1="-0.26" x2="0.97" y2="0.3" width="0.2032" layer="51"/>
<smd name="+" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="CT3528">
chip
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="1.637" y1="1.383" x2="1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="-1.016" x2="1.778" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.383" x2="1.637" y2="-1.383" width="0.2032" layer="21"/>
<wire x1="-1.637" y1="1.383" x2="1.637" y2="1.383" width="0.2032" layer="21"/>
<wire x1="-1.778" y1="-1.016" x2="-1.778" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="0.68" y1="0" x2="1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.3" x2="1" y2="0.33" width="0.2032" layer="51"/>
<smd name="+" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-1.651" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="CT6032">
chip
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="2.932" y1="1.637" x2="2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="-1.067" x2="3.073" y2="1.067" width="0.1524" layer="51"/>
<wire x1="-2.957" y1="-1.637" x2="2.932" y2="-1.637" width="0.2032" layer="21"/>
<wire x1="-2.957" y1="1.637" x2="2.932" y2="1.637" width="0.2032" layer="21"/>
<wire x1="-3.073" y1="-1.067" x2="-3.073" y2="1.067" width="0.1524" layer="51"/>
<wire x1="-2.957" y1="1.637" x2="-2.957" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="1.18" y1="0" x2="2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-0.63" x2="1.8" y2="0.64" width="0.2032" layer="51"/>
<smd name="+" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<text x="-2.54" y="2.032" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="CT7343">
chip
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="3.592" y1="2.195" x2="3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="-1.143" x2="3.734" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.582" y1="-2.195" x2="3.592" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="2.195" x2="3.592" y2="2.195" width="0.2032" layer="21"/>
<wire x1="-3.734" y1="-1.143" x2="-3.734" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.582" y1="2.195" x2="-3.582" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="2.04" y1="0" x2="3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-0.52" x2="2.55" y2="0.52" width="0.2032" layer="51"/>
<wire x1="3.592" y1="-1.615" x2="3.592" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="-1.615" x2="-3.582" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="3.592" y1="2.195" x2="3.592" y2="1.615" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="2.195" x2="-3.582" y2="1.615" width="0.2032" layer="21"/>
<smd name="+" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<text x="-3.175" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="B45181A">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="B45181B">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-50">
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="085CS_1R">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012">
</package>
<package name="153CLV-1014">
</package>
<package name="175TMP-0808">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Reflow solder&lt;/b&gt;&lt;p&gt;
KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Reflow solder&lt;/b&gt;&lt;p&gt;
KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Reflow solder&lt;/b&gt;&lt;p&gt;
KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="E1,8-4">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="EB20D">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB22,5D">
grid 10.16 mm, diameter 22.5 mm</description>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB25D">
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB30D">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-6E">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2-4">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-4R">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6">
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E25-10">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E30-10">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16">
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12">
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-14">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-16">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5R">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30">
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E7,5-16">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="TT2D5L">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="C0402">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504">
chip</description>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603">
chip</description>
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<text x="-0.889" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805">
chip</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.889" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1005">
chip</description>
</package>
<package name="C1206">
chip</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C1210">
chip</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310">
chip</description>
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608">
chip</description>
<text x="-0.635" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C1812">
chip</description>
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825">
chip</description>
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.683" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.826" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012">
chip</description>
</package>
<package name="C3216">
chip</description>
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225">
chip</description>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532">
chip</description>
<text x="-1.905" y="2.032" size="1.27" layer="25">&gt;NAME</text>
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564">
chip</description>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-025X075">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C075-063X106">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C275-154X316">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="CPOL-US">
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="-1.016" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-1" x2="2.4892" y2="-1.8542" width="0.254" layer="94" curve="-37.878202" cap="flat"/>
<wire x1="-2.4669" y1="-1.8504" x2="0" y2="-1.0161" width="0.254" layer="94" curve="-37.376341" cap="flat"/>
<text x="1.016" y="0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.016" y="-4.191" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.253" y1="0.668" x2="-1.364" y2="0.795" layer="94"/>
<rectangle x1="-1.872" y1="0.287" x2="-1.745" y2="1.176" layer="94"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="C-US">
<wire x1="-2.4668" y1="-1.8504" x2="0" y2="-1.0161" width="0.254" layer="94" curve="-37.373024" cap="flat"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="CPOL-US" prefix="C" uservalue="yes">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, American symbol</description>
<gates>
<gate name="G$1" symbol="CPOL-US" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-US" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, American symbol</description>
<gates>
<gate name="G$1" symbol="C-US" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1005" package="C1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="crystal">
<packages>
<package name="DIL08S">
<description>&lt;b&gt;CRYSTAL RESONATOR&lt;/b&gt;</description>
<wire x1="-6.604" y1="-6.604" x2="5.334" y2="-6.604" width="0.254" layer="21"/>
<wire x1="6.604" y1="-5.334" x2="6.604" y2="5.334" width="0.254" layer="21"/>
<wire x1="5.334" y1="6.604" x2="-5.334" y2="6.604" width="0.254" layer="21"/>
<wire x1="-6.604" y1="-6.604" x2="-6.604" y2="5.334" width="0.254" layer="21"/>
<wire x1="-5.334" y1="-5.969" x2="5.334" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-5.334" x2="5.969" y2="5.334" width="0.1524" layer="21"/>
<wire x1="5.334" y1="5.969" x2="-5.334" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="5.334" x2="-5.969" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-6.604" x2="6.604" y2="-5.334" width="0.254" layer="21" curve="90"/>
<wire x1="5.334" y1="-5.969" x2="5.969" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="5.334" y1="5.969" x2="5.969" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.334" y1="6.604" x2="6.604" y2="5.334" width="0.254" layer="21" curve="-90"/>
<wire x1="-5.969" y1="5.334" x2="-5.334" y2="5.969" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.604" y1="5.334" x2="-5.334" y2="6.604" width="0.254" layer="21" curve="-90"/>
<wire x1="-5.969" y1="-5.334" x2="-5.334" y2="-5.969" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3302" y1="5.08" x2="-0.3302" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-0.3302" y1="2.54" x2="0.3048" y2="2.54" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="2.54" x2="0.3048" y2="5.08" width="0.3048" layer="21"/>
<wire x1="0.3048" y1="5.08" x2="-0.3302" y2="5.08" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="5.08" x2="0.9398" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="5.08" x2="-0.9398" y2="3.81" width="0.3048" layer="21"/>
<wire x1="0.9398" y1="3.81" x2="2.54" y2="3.81" width="0.1524" layer="21"/>
<wire x1="0.9398" y1="3.81" x2="0.9398" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-0.9398" y1="3.81" x2="-2.54" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="3.81" x2="-0.9398" y2="2.54" width="0.3048" layer="21"/>
<circle x="-4.953" y="-4.953" radius="0.635" width="0.3048" layer="51"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128"/>
<text x="-5.08" y="7.0866" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.794" y="-5.715" size="1.27" layer="21" ratio="10">1</text>
</package>
<package name="DIL14S">
<wire x1="-10.16" y1="-6.35" x2="8.89" y2="-6.35" width="0.254" layer="21"/>
<wire x1="10.16" y1="-5.08" x2="10.16" y2="5.08" width="0.254" layer="21"/>
<wire x1="8.89" y1="6.35" x2="-8.89" y2="6.35" width="0.254" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.16" y2="5.08" width="0.254" layer="21"/>
<wire x1="-8.89" y1="-5.715" x2="8.89" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-5.08" x2="9.525" y2="5.08" width="0.1524" layer="21"/>
<wire x1="8.89" y1="5.715" x2="-8.89" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="5.08" x2="-9.525" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-6.35" x2="10.16" y2="-5.08" width="0.254" layer="21" curve="90"/>
<wire x1="8.89" y1="-5.715" x2="9.525" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="8.89" y1="5.715" x2="9.525" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.89" y1="6.35" x2="10.16" y2="5.08" width="0.254" layer="21" curve="-90"/>
<wire x1="-9.525" y1="5.08" x2="-8.89" y2="5.715" width="0.1524" layer="21" curve="-90"/>
<wire x1="-10.16" y1="5.08" x2="-8.89" y2="6.35" width="0.254" layer="21" curve="-90"/>
<wire x1="-9.525" y1="-5.08" x2="-8.89" y2="-5.715" width="0.1524" layer="21" curve="90"/>
<circle x="-8.509" y="-4.699" radius="0.635" width="0.3048" layer="51"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128"/>
<text x="-7.62" y="6.8326" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-0.8128" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.477" y="-5.461" size="1.27" layer="21" ratio="10">1</text>
</package>
</packages>
<symbols>
<symbol name="QG3">
<wire x1="-7.62" y1="7.62" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="0" width="0.4064" layer="94"/>
<wire x1="7.62" y1="0" x2="7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="5.08" x2="7.62" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="7.62" x2="7.62" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="2.54" y2="2.54" width="0.4064" layer="94"/>
<wire x1="2.54" y1="2.54" x2="6.35" y2="0" width="0.4064" layer="94"/>
<wire x1="6.35" y1="0" x2="-1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="-1.27" y2="-3.175" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-3.175" x2="-1.27" y2="3.175" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="3.175" x2="-1.27" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="3.175" x2="-1.27" y2="3.175" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="-3.175" x2="-1.27" y2="-3.175" width="0.1524" layer="94"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.1524" layer="94"/>
<wire x1="7.62" y1="5.08" x2="2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-4.826" y1="-0.381" x2="-4.826" y2="0.381" width="0.254" layer="94"/>
<wire x1="-4.826" y1="0.381" x2="-2.794" y2="0.381" width="0.254" layer="94"/>
<wire x1="-2.794" y1="0.381" x2="-2.794" y2="-0.381" width="0.254" layer="94"/>
<wire x1="-4.826" y1="-0.381" x2="-2.794" y2="-0.381" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.016" x2="-3.81" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.016" x2="-2.54" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.016" x2="-3.81" y2="3.175" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="1.016" x2="-2.54" y2="1.016" width="0.254" layer="94"/>
<text x="-7.62" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="2.54" y="-5.842" size="1.524" layer="95">OUT</text>
<text x="-6.985" y="-5.842" size="1.524" layer="95">GND</text>
<text x="-6.985" y="4.318" size="1.524" layer="95">VCC</text>
<text x="0" y="5.588" size="1.524" layer="95">NC/TS</text>
<pin name="GND" x="-12.7" y="-5.08" visible="pad" length="middle" direction="pwr"/>
<pin name="VCC" x="-12.7" y="5.08" visible="pad" length="middle" direction="pwr"/>
<pin name="OUT" x="12.7" y="0" visible="pad" length="middle" direction="out" rot="R180"/>
<pin name="TS" x="12.7" y="5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="XO-" prefix="QG" uservalue="yes">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="QG3" x="0" y="0"/>
</gates>
<devices>
<device name="8" package="DIL08S">
<connects>
<connect gate="G$1" pin="GND" pad="4"/>
<connect gate="G$1" pin="OUT" pad="5"/>
<connect gate="G$1" pin="TS" pad="1"/>
<connect gate="G$1" pin="VCC" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<device name="14" package="DIL14S">
<connects>
<connect gate="G$1" pin="GND" pad="7"/>
<connect gate="G$1" pin="OUT" pad="8"/>
<connect gate="G$1" pin="VCC" pad="14"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor-sil">
<packages>
<package name="SIL6">
<description>&lt;b&gt;Single In Line&lt;/b&gt;</description>
<wire x1="-7.62" y1="0.508" x2="-7.62" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="0.762" x2="-5.588" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-5.588" y1="0.762" x2="-5.588" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-5.588" y1="-0.762" x2="-7.112" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-7.112" y1="-0.762" x2="-7.112" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="0.889" x2="-5.461" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-0.889" x2="-7.239" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.508" x2="-7.112" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.112" y1="-1.016" x2="7.62" y2="-0.508" width="0.1524" layer="21" curve="90"/>
<wire x1="7.112" y1="1.016" x2="7.62" y2="0.508" width="0.1524" layer="21" curve="-90"/>
<wire x1="-7.62" y1="-0.508" x2="-7.112" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="7.62" y1="0.508" x2="7.62" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.016" x2="7.112" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="-1.016" x2="7.112" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="0.889" x2="-7.239" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-7.239" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="1.778" y1="0" x2="1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.381" x2="1.143" y2="0.381" width="0.1524" layer="51"/>
<wire x1="1.143" y1="0.381" x2="1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="1.143" y1="0" x2="1.143" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.381" x2="-1.143" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.381" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0" x2="-1.143" y2="0.381" width="0.1524" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-7.62" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.636" y="-0.508" size="0.9906" layer="21" ratio="12">1</text>
</package>
</packages>
<symbols>
<symbol name="R5">
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.842" y1="3.81" x2="-5.842" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-4.318" y1="3.81" x2="-5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.842" y1="-1.27" x2="-5.08" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.27" x2="-5.08" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-1.27" x2="-4.318" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="3.81" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="3.81" x2="-5.842" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="3.81" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="0" y2="5.08" width="0.1524" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="3.81" width="0.1524" layer="94"/>
<wire x1="0" y1="5.08" x2="2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="3.81" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="5.08" y2="5.08" width="0.1524" layer="94"/>
<wire x1="5.08" y1="5.08" x2="5.08" y2="3.81" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="-1.778" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.302" y1="-1.27" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.778" y1="3.81" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.81" x2="-3.302" y2="3.81" width="0.254" layer="94"/>
<wire x1="-1.778" y1="-1.27" x2="-1.778" y2="3.81" width="0.254" layer="94"/>
<wire x1="-3.302" y1="3.81" x2="-3.302" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.762" y1="-1.27" x2="0.762" y2="3.81" width="0.254" layer="94"/>
<wire x1="3.302" y1="-1.27" x2="3.302" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.842" y1="-1.27" x2="5.842" y2="3.81" width="0.254" layer="94"/>
<wire x1="-0.762" y1="3.81" x2="-0.762" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.778" y1="3.81" x2="1.778" y2="-1.27" width="0.254" layer="94"/>
<wire x1="4.318" y1="3.81" x2="4.318" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.762" y1="3.81" x2="0" y2="3.81" width="0.254" layer="94"/>
<wire x1="3.302" y1="3.81" x2="2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.842" y1="3.81" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="0" y1="3.81" x2="-0.762" y2="3.81" width="0.254" layer="94"/>
<wire x1="2.54" y1="3.81" x2="1.778" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.81" x2="4.318" y2="3.81" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="0.762" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="3.302" y2="-1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.27" x2="5.842" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-1.27" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.27" x2="2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="4.318" y1="-1.27" x2="5.08" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="6.35" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="6.35" x2="7.62" y2="6.35" width="0.4064" layer="94"/>
<wire x1="7.62" y1="6.35" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="7.62" width="0.1524" layer="94"/>
<circle x="2.54" y="5.08" radius="0.254" width="0.4064" layer="94"/>
<circle x="0" y="5.08" radius="0.254" width="0.4064" layer="94"/>
<circle x="-2.54" y="5.08" radius="0.254" width="0.4064" layer="94"/>
<circle x="-5.08" y="5.08" radius="0.254" width="0.4064" layer="94"/>
<text x="-2.54" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="6.985" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="10.16" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="2" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="3" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="4" x="0" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="5" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="6" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="G05R" prefix="RN" uservalue="yes">
<description>&lt;b&gt;SIL RESISTOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="R5" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SIL6">
<connects>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="ic-package">
<packages>
<package name="DIL10">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="6.35" y1="2.921" x2="-6.35" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-2.921" x2="6.35" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.921" x2="6.35" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="2.921" x2="-6.35" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-2.921" x2="-6.35" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.016" x2="-6.35" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-6.604" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-4.953" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="DIL10">
<wire x1="-5.08" y1="3.81" x2="-5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-8.89" x2="5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="-8.89" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.81" x2="2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="3.81" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.81" x2="2.54" y2="3.81" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="4.445" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-11.43" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="8" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIL10" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line / Socket&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL10" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="DIL10">
<connects>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="EXPANSION" library="con-lstb" deviceset="MA20-2W" device=""/>
<part name="P+1" library="supply1" deviceset="VCC" device=""/>
<part name="GND1" library="supply1" deviceset="GND" device=""/>
<part name="IC1" library="74xx-us" deviceset="74*688" device="N" technology="LS"/>
<part name="U2" library="plcc-socketed-devs" deviceset="Z8530" device=""/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="P+3" library="supply1" deviceset="VCC" device=""/>
<part name="JP5" library="pinhead" deviceset="PINHD-2X5" device="/90"/>
<part name="JP6" library="pinhead" deviceset="PINHD-2X5" device="/90"/>
<part name="IC3" library="maxim" deviceset="MAX232" device=""/>
<part name="GND4" library="supply1" deviceset="GND" device=""/>
<part name="GND5" library="supply1" deviceset="GND" device=""/>
<part name="C1" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C2" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C3" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C4" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C5" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="GND6" library="supply1" deviceset="GND" device=""/>
<part name="P+4" library="supply1" deviceset="VCC" device=""/>
<part name="IC4" library="maxim" deviceset="MAX232" device=""/>
<part name="C6" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C7" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C8" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C9" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="C10" library="resistor" deviceset="CPOL-US" device="E2,5-6E"/>
<part name="GND7" library="supply1" deviceset="GND" device=""/>
<part name="P+5" library="supply1" deviceset="VCC" device=""/>
<part name="QG1" library="crystal" deviceset="XO-" device="8"/>
<part name="JP3" library="pinhead" deviceset="PINHD-2X3" device=""/>
<part name="U1" library="plcc-socketed-devs" deviceset="82C55A" device="PLCC44" value="8255"/>
<part name="JP4" library="pinhead" deviceset="PINHD-2X3" device=""/>
<part name="C11" library="resistor" deviceset="CPOL-US" device="E15-6AXIAL"/>
<part name="C12" library="resistor" deviceset="C-US" device="075-032X103"/>
<part name="C13" library="resistor" deviceset="C-US" device="075-032X103"/>
<part name="C14" library="resistor" deviceset="C-US" device="075-032X103"/>
<part name="C15" library="resistor" deviceset="C-US" device="075-032X103"/>
<part name="P+6" library="supply1" deviceset="VCC" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="JP1" library="pinhead" deviceset="PINHD-2X8" device="/90"/>
<part name="JP2" library="pinhead" deviceset="PINHD-2X8" device="/90"/>
<part name="RN1" library="resistor-sil" deviceset="G05R" device=""/>
<part name="GND8" library="supply1" deviceset="GND" device=""/>
<part name="P+2" library="supply1" deviceset="VCC" device=""/>
<part name="IC2" library="ic-package" deviceset="DIL10" device=""/>
<part name="GND9" library="supply1" deviceset="GND" device=""/>
<part name="C16" library="resistor" deviceset="C-US" device="075-032X103"/>
<part name="P+7" library="supply1" deviceset="VCC" device=""/>
<part name="GND10" library="supply1" deviceset="GND" device=""/>
<part name="IC5" library="74xx-us" deviceset="74*00" device="N" technology="ALS"/>
<part name="IC6" library="74xx-us" deviceset="74*04" device="N" technology="ALS"/>
<part name="C17" library="resistor" deviceset="C-US" device="075-032X103"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="EXPANSION" gate="1" x="-124.46" y="63.5" rot="R180"/>
<instance part="P+1" gate="VCC" x="-124.46" y="99.06"/>
<instance part="GND1" gate="1" x="-124.46" y="33.02"/>
<instance part="IC1" gate="A" x="-165.1" y="22.86"/>
<instance part="U2" gate="G$1" x="-45.72" y="63.5"/>
<instance part="GND3" gate="1" x="-45.72" y="27.94"/>
<instance part="P+3" gate="VCC" x="-45.72" y="99.06"/>
<instance part="JP5" gate="A" x="104.14" y="106.68"/>
<instance part="JP6" gate="A" x="104.14" y="60.96"/>
<instance part="IC3" gate="G$1" x="38.1" y="104.14"/>
<instance part="GND4" gate="1" x="96.52" y="91.44"/>
<instance part="GND5" gate="1" x="96.52" y="43.18"/>
<instance part="C1" gate="G$1" x="15.24" y="116.84" rot="R270"/>
<instance part="C2" gate="G$1" x="15.24" y="106.68" rot="R270"/>
<instance part="C3" gate="G$1" x="58.42" y="119.38" rot="R180"/>
<instance part="C4" gate="G$1" x="58.42" y="104.14" rot="R180"/>
<instance part="C5" gate="G$1" x="66.04" y="106.68"/>
<instance part="GND6" gate="1" x="58.42" y="99.06"/>
<instance part="P+4" gate="VCC" x="58.42" y="127"/>
<instance part="IC4" gate="G$1" x="38.1" y="58.42"/>
<instance part="C6" gate="G$1" x="15.24" y="71.12" rot="R270"/>
<instance part="C7" gate="G$1" x="15.24" y="60.96" rot="R270"/>
<instance part="C8" gate="G$1" x="58.42" y="73.66" rot="R180"/>
<instance part="C9" gate="G$1" x="58.42" y="58.42" rot="R180"/>
<instance part="C10" gate="G$1" x="66.04" y="60.96"/>
<instance part="GND7" gate="1" x="58.42" y="53.34"/>
<instance part="P+5" gate="VCC" x="58.42" y="81.28"/>
<instance part="QG1" gate="G$1" x="-35.56" y="111.76"/>
<instance part="JP3" gate="A" x="83.82" y="106.68"/>
<instance part="U1" gate="A" x="-40.64" y="-20.32"/>
<instance part="JP4" gate="A" x="83.82" y="60.96"/>
<instance part="C11" gate="G$1" x="106.68" y="-33.02"/>
<instance part="C12" gate="G$1" x="99.06" y="-35.56" rot="R180"/>
<instance part="C13" gate="G$1" x="91.44" y="-35.56" rot="R180"/>
<instance part="C14" gate="G$1" x="83.82" y="-35.56" rot="R180"/>
<instance part="C15" gate="G$1" x="76.2" y="-35.56" rot="R180"/>
<instance part="P+6" gate="VCC" x="68.58" y="-20.32"/>
<instance part="GND2" gate="1" x="106.68" y="-48.26"/>
<instance part="JP1" gate="A" x="-17.78" y="2.54"/>
<instance part="JP2" gate="A" x="-17.78" y="-20.32"/>
<instance part="RN1" gate="G$1" x="-205.74" y="48.26"/>
<instance part="GND8" gate="1" x="-200.66" y="0"/>
<instance part="P+2" gate="VCC" x="-210.82" y="63.5"/>
<instance part="IC2" gate="G$1" x="-208.28" y="15.24" rot="MR270"/>
<instance part="GND9" gate="1" x="-182.88" y="-10.16"/>
<instance part="C16" gate="G$1" x="68.58" y="-35.56" rot="R180"/>
<instance part="P+7" gate="VCC" x="-5.08" y="17.78"/>
<instance part="GND10" gate="1" x="-2.54" y="-40.64"/>
<instance part="IC5" gate="A" x="-137.16" y="-33.02"/>
<instance part="IC5" gate="D" x="-137.16" y="-60.96"/>
<instance part="IC6" gate="A" x="-167.64" y="-30.48"/>
<instance part="IC6" gate="B" x="-167.64" y="-63.5"/>
<instance part="IC6" gate="F" x="-124.46" y="20.32" rot="R180"/>
<instance part="C17" gate="G$1" x="60.96" y="-35.56" rot="R180"/>
</instances>
<busses>
<bus name="DATA">
<segment>
<wire x1="-139.7" y1="58.42" x2="-139.7" y2="106.68" width="0.762" layer="92"/>
<wire x1="-139.7" y1="106.68" x2="-137.16" y2="109.22" width="0.762" layer="92"/>
<wire x1="-137.16" y1="109.22" x2="-71.12" y2="109.22" width="0.762" layer="92"/>
<wire x1="-71.12" y1="109.22" x2="-68.58" y2="106.68" width="0.762" layer="92"/>
<wire x1="-68.58" y1="106.68" x2="-68.58" y2="-5.08" width="0.762" layer="92"/>
</segment>
</bus>
<bus name="ADDRESS">
<segment>
<wire x1="-109.22" y1="58.42" x2="-109.22" y2="114.3" width="0.762" layer="92"/>
<wire x1="-109.22" y1="114.3" x2="-111.76" y2="116.84" width="0.762" layer="92"/>
<wire x1="-111.76" y1="116.84" x2="-180.34" y2="116.84" width="0.762" layer="92"/>
<wire x1="-180.34" y1="116.84" x2="-187.96" y2="109.22" width="0.762" layer="92"/>
<wire x1="-187.96" y1="109.22" x2="-187.96" y2="7.62" width="0.762" layer="92"/>
</segment>
</bus>
</busses>
<nets>
<net name="DATA0" class="0">
<segment>
<wire x1="-132.08" y1="55.88" x2="-137.16" y2="55.88" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="55.88" x2="-139.7" y2="58.42" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="27"/>
</segment>
<segment>
<wire x1="-63.5" y1="71.12" x2="-66.04" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="71.12" x2="-68.58" y2="73.66" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D0"/>
</segment>
<segment>
<wire x1="-60.96" y1="10.16" x2="-66.04" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="10.16" x2="-68.58" y2="12.7" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D0"/>
</segment>
</net>
<net name="DATA1" class="0">
<segment>
<wire x1="-132.08" y1="58.42" x2="-137.16" y2="58.42" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="58.42" x2="-139.7" y2="60.96" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="25"/>
</segment>
<segment>
<wire x1="-63.5" y1="73.66" x2="-66.04" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="73.66" x2="-68.58" y2="76.2" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D1"/>
</segment>
<segment>
<wire x1="-60.96" y1="7.62" x2="-66.04" y2="7.62" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="7.62" x2="-68.58" y2="10.16" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D1"/>
</segment>
</net>
<net name="DATA2" class="0">
<segment>
<wire x1="-132.08" y1="60.96" x2="-137.16" y2="60.96" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="60.96" x2="-139.7" y2="63.5" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="23"/>
</segment>
<segment>
<wire x1="-63.5" y1="76.2" x2="-66.04" y2="76.2" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="76.2" x2="-68.58" y2="78.74" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D2"/>
</segment>
<segment>
<wire x1="-60.96" y1="5.08" x2="-66.04" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="5.08" x2="-68.58" y2="7.62" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D2"/>
</segment>
</net>
<net name="DATA3" class="0">
<segment>
<wire x1="-132.08" y1="63.5" x2="-137.16" y2="63.5" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="63.5" x2="-139.7" y2="66.04" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="21"/>
</segment>
<segment>
<wire x1="-63.5" y1="78.74" x2="-66.04" y2="78.74" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="78.74" x2="-68.58" y2="81.28" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D3"/>
</segment>
<segment>
<wire x1="-60.96" y1="2.54" x2="-66.04" y2="2.54" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="2.54" x2="-68.58" y2="5.08" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D3"/>
</segment>
</net>
<net name="DATA4" class="0">
<segment>
<wire x1="-132.08" y1="66.04" x2="-137.16" y2="66.04" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="66.04" x2="-139.7" y2="68.58" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="19"/>
</segment>
<segment>
<wire x1="-63.5" y1="81.28" x2="-66.04" y2="81.28" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="81.28" x2="-68.58" y2="83.82" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D4"/>
</segment>
<segment>
<wire x1="-60.96" y1="0" x2="-66.04" y2="0" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="0" x2="-68.58" y2="2.54" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D4"/>
</segment>
</net>
<net name="DATA5" class="0">
<segment>
<wire x1="-132.08" y1="68.58" x2="-137.16" y2="68.58" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="68.58" x2="-139.7" y2="71.12" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="17"/>
</segment>
<segment>
<wire x1="-63.5" y1="83.82" x2="-66.04" y2="83.82" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="83.82" x2="-68.58" y2="86.36" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D5"/>
</segment>
<segment>
<wire x1="-60.96" y1="-2.54" x2="-66.04" y2="-2.54" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-2.54" x2="-68.58" y2="0" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D5"/>
</segment>
</net>
<net name="DATA6" class="0">
<segment>
<wire x1="-132.08" y1="71.12" x2="-137.16" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="71.12" x2="-139.7" y2="73.66" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="15"/>
</segment>
<segment>
<wire x1="-63.5" y1="86.36" x2="-66.04" y2="86.36" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="86.36" x2="-68.58" y2="88.9" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D6"/>
</segment>
<segment>
<wire x1="-60.96" y1="-5.08" x2="-66.04" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-5.08" x2="-68.58" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D6"/>
</segment>
</net>
<net name="DATA7" class="0">
<segment>
<wire x1="-132.08" y1="73.66" x2="-137.16" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="73.66" x2="-139.7" y2="76.2" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="13"/>
</segment>
<segment>
<wire x1="-63.5" y1="88.9" x2="-66.04" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="88.9" x2="-68.58" y2="91.44" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="D7"/>
</segment>
<segment>
<wire x1="-60.96" y1="-7.62" x2="-66.04" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-7.62" x2="-68.58" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="D7"/>
</segment>
</net>
<net name="ALE" class="0">
<segment>
<wire x1="-114.3" y1="50.8" x2="-116.84" y2="50.8" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="32"/>
</segment>
</net>
<net name="ADDRESS8" class="0">
<segment>
<wire x1="-73.66" y1="73.66" x2="-73.66" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="53.34" x2="-63.5" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="53.34" x2="-73.66" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="-20.32" x2="-60.96" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="-109.22" y1="76.2" x2="-111.76" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="73.66" x2="-116.84" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-109.22" y1="76.2" x2="-106.68" y2="73.66" width="0.1524" layer="91"/>
<wire x1="-106.68" y1="73.66" x2="-73.66" y2="73.66" width="0.1524" layer="91"/>
<junction x="-73.66" y="53.34"/>
<pinref part="U2" gate="G$1" pin="D//C"/>
<pinref part="U1" gate="A" pin="A0"/>
<pinref part="EXPANSION" gate="1" pin="14"/>
</segment>
</net>
<net name="ADDRESS9" class="0">
<segment>
<wire x1="-88.9" y1="71.12" x2="-71.12" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-71.12" y1="71.12" x2="-71.12" y2="58.42" width="0.1524" layer="91"/>
<wire x1="-71.12" y1="58.42" x2="-63.5" y2="58.42" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="-22.86" x2="-88.9" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="-88.9" y1="-22.86" x2="-88.9" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-88.9" y1="71.12" x2="-106.68" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-109.22" y1="73.66" x2="-111.76" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="71.12" x2="-116.84" y2="71.12" width="0.1524" layer="91"/>
<wire x1="-106.68" y1="71.12" x2="-109.22" y2="73.66" width="0.1524" layer="91"/>
<junction x="-88.9" y="71.12"/>
<pinref part="U2" gate="G$1" pin="A//B"/>
<pinref part="U1" gate="A" pin="A1"/>
<pinref part="EXPANSION" gate="1" pin="16"/>
</segment>
</net>
<net name="ADDRESS10" class="0">
<segment>
<wire x1="-109.22" y1="71.12" x2="-111.76" y2="68.58" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="68.58" x2="-116.84" y2="68.58" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="18"/>
</segment>
<segment>
<wire x1="-149.86" y1="-58.42" x2="-154.94" y2="-58.42" width="0.1524" layer="91"/>
<wire x1="-154.94" y1="-58.42" x2="-154.94" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="-154.94" y1="-48.26" x2="-190.5" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="-190.5" y1="-48.26" x2="-190.5" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="-190.5" y1="-30.48" x2="-177.8" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="-187.96" y1="20.32" x2="-190.5" y2="17.78" width="0.1524" layer="91"/>
<wire x1="-190.5" y1="17.78" x2="-190.5" y2="-30.48" width="0.1524" layer="91"/>
<junction x="-190.5" y="-30.48"/>
<pinref part="IC6" gate="A" pin="I"/>
<pinref part="IC5" gate="D" pin="I0"/>
</segment>
</net>
<net name="ADDRESS11" class="0">
<segment>
<wire x1="-109.22" y1="68.58" x2="-111.76" y2="66.04" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="66.04" x2="-116.84" y2="66.04" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="20"/>
</segment>
<segment>
<wire x1="-177.8" y1="15.24" x2="-185.42" y2="15.24" width="0.1524" layer="91"/>
<wire x1="-185.42" y1="15.24" x2="-187.96" y2="17.78" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="Q3"/>
</segment>
</net>
<net name="ADDRESS12" class="0">
<segment>
<wire x1="-109.22" y1="66.04" x2="-111.76" y2="63.5" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="63.5" x2="-116.84" y2="63.5" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="22"/>
</segment>
<segment>
<wire x1="-177.8" y1="12.7" x2="-185.42" y2="12.7" width="0.1524" layer="91"/>
<wire x1="-185.42" y1="12.7" x2="-187.96" y2="15.24" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="Q4"/>
</segment>
</net>
<net name="ADDRESS13" class="0">
<segment>
<wire x1="-109.22" y1="63.5" x2="-111.76" y2="60.96" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="60.96" x2="-116.84" y2="60.96" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="24"/>
</segment>
<segment>
<wire x1="-187.96" y1="12.7" x2="-185.42" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-185.42" y1="10.16" x2="-177.8" y2="10.16" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="Q5"/>
</segment>
</net>
<net name="ADDRESS14" class="0">
<segment>
<wire x1="-109.22" y1="60.96" x2="-111.76" y2="58.42" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="58.42" x2="-116.84" y2="58.42" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="26"/>
</segment>
<segment>
<wire x1="-177.8" y1="7.62" x2="-185.42" y2="7.62" width="0.1524" layer="91"/>
<wire x1="-185.42" y1="7.62" x2="-187.96" y2="10.16" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="Q6"/>
</segment>
</net>
<net name="ADDRESS15" class="0">
<segment>
<wire x1="-116.84" y1="55.88" x2="-111.76" y2="55.88" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="55.88" x2="-109.22" y2="58.42" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="28"/>
</segment>
<segment>
<wire x1="-177.8" y1="5.08" x2="-185.42" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-185.42" y1="5.08" x2="-187.96" y2="7.62" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="Q7"/>
</segment>
</net>
<net name="IO/M" class="0">
<segment>
<wire x1="-116.84" y1="43.18" x2="-111.76" y2="43.18" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="43.18" x2="-111.76" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-111.76" y1="20.32" x2="-114.3" y2="20.32" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="38"/>
<pinref part="IC6" gate="F" pin="I"/>
</segment>
</net>
<net name="VCC" class="0">
<segment>
<wire x1="-116.84" y1="88.9" x2="-114.3" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-114.3" y1="88.9" x2="-114.3" y2="93.98" width="0.1524" layer="91"/>
<wire x1="-114.3" y1="93.98" x2="-124.46" y2="93.98" width="0.1524" layer="91"/>
<wire x1="-124.46" y1="93.98" x2="-124.46" y2="96.52" width="0.1524" layer="91"/>
<wire x1="-132.08" y1="88.9" x2="-134.62" y2="88.9" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="88.9" x2="-134.62" y2="91.44" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="91.44" x2="-134.62" y2="93.98" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="93.98" x2="-124.46" y2="93.98" width="0.1524" layer="91"/>
<junction x="-124.46" y="93.98"/>
<pinref part="EXPANSION" gate="1" pin="2"/>
<pinref part="P+1" gate="VCC" pin="VCC"/>
<pinref part="EXPANSION" gate="1" pin="1"/>
</segment>
<segment>
<pinref part="U2" gate="G$1" pin="VCC"/>
<pinref part="P+3" gate="VCC" pin="VCC"/>
</segment>
<segment>
<wire x1="58.42" y1="124.46" x2="66.04" y2="124.46" width="0.1524" layer="91"/>
<wire x1="66.04" y1="124.46" x2="66.04" y2="109.22" width="0.1524" layer="91"/>
<junction x="58.42" y="124.46"/>
<pinref part="C3" gate="G$1" pin="-"/>
<pinref part="C5" gate="G$1" pin="+"/>
<pinref part="P+4" gate="VCC" pin="VCC"/>
</segment>
<segment>
<wire x1="58.42" y1="78.74" x2="66.04" y2="78.74" width="0.1524" layer="91"/>
<wire x1="66.04" y1="78.74" x2="66.04" y2="63.5" width="0.1524" layer="91"/>
<junction x="58.42" y="78.74"/>
<pinref part="C8" gate="G$1" pin="-"/>
<pinref part="C10" gate="G$1" pin="+"/>
<pinref part="P+5" gate="VCC" pin="VCC"/>
</segment>
<segment>
<wire x1="68.58" y1="-27.94" x2="76.2" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-27.94" x2="83.82" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-27.94" x2="91.44" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-27.94" x2="99.06" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-27.94" x2="106.68" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-27.94" x2="106.68" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="68.58" y1="-27.94" x2="68.58" y2="-22.86" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-30.48" x2="99.06" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-30.48" x2="91.44" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-30.48" x2="83.82" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="68.58" y1="-30.48" x2="68.58" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-30.48" x2="76.2" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-30.48" x2="60.96" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-27.94" x2="68.58" y2="-27.94" width="0.1524" layer="91"/>
<junction x="83.82" y="-27.94"/>
<junction x="91.44" y="-27.94"/>
<junction x="99.06" y="-27.94"/>
<junction x="76.2" y="-27.94"/>
<junction x="68.58" y="-27.94"/>
<pinref part="C11" gate="G$1" pin="+"/>
<pinref part="P+6" gate="VCC" pin="VCC"/>
<pinref part="C12" gate="G$1" pin="2"/>
<pinref part="C13" gate="G$1" pin="2"/>
<pinref part="C14" gate="G$1" pin="2"/>
<pinref part="C16" gate="G$1" pin="2"/>
<pinref part="C15" gate="G$1" pin="2"/>
<pinref part="C17" gate="G$1" pin="2"/>
</segment>
<segment>
<wire x1="-210.82" y1="60.96" x2="-210.82" y2="58.42" width="0.1524" layer="91"/>
<pinref part="RN1" gate="G$1" pin="1"/>
<pinref part="P+2" gate="VCC" pin="VCC"/>
</segment>
<segment>
<wire x1="-12.7" y1="-30.48" x2="-5.08" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="-30.48" x2="-5.08" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="-7.62" x2="-12.7" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="-7.62" x2="-5.08" y2="15.24" width="0.1524" layer="91"/>
<junction x="-5.08" y="-7.62"/>
<pinref part="JP2" gate="A" pin="16"/>
<pinref part="JP1" gate="A" pin="16"/>
<pinref part="P+7" gate="VCC" pin="VCC"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<wire x1="-116.84" y1="40.64" x2="-114.3" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-114.3" y1="40.64" x2="-114.3" y2="35.56" width="0.1524" layer="91"/>
<wire x1="-114.3" y1="35.56" x2="-124.46" y2="35.56" width="0.1524" layer="91"/>
<wire x1="-132.08" y1="40.64" x2="-134.62" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="40.64" x2="-134.62" y2="35.56" width="0.1524" layer="91"/>
<wire x1="-134.62" y1="35.56" x2="-124.46" y2="35.56" width="0.1524" layer="91"/>
<junction x="-124.46" y="35.56"/>
<pinref part="EXPANSION" gate="1" pin="40"/>
<pinref part="GND1" gate="1" pin="GND"/>
<pinref part="EXPANSION" gate="1" pin="39"/>
</segment>
<segment>
<pinref part="U2" gate="G$1" pin="GND"/>
<pinref part="GND3" gate="1" pin="GND"/>
</segment>
<segment>
<wire x1="96.52" y1="93.98" x2="96.52" y2="106.68" width="0.1524" layer="91"/>
<wire x1="96.52" y1="106.68" x2="101.6" y2="106.68" width="0.1524" layer="91"/>
<pinref part="GND4" gate="1" pin="GND"/>
<pinref part="JP5" gate="A" pin="5"/>
</segment>
<segment>
<wire x1="96.52" y1="45.72" x2="96.52" y2="60.96" width="0.1524" layer="91"/>
<wire x1="96.52" y1="60.96" x2="101.6" y2="60.96" width="0.1524" layer="91"/>
<pinref part="GND5" gate="1" pin="GND"/>
<pinref part="JP6" gate="A" pin="5"/>
</segment>
<segment>
<wire x1="58.42" y1="101.6" x2="66.04" y2="101.6" width="0.1524" layer="91"/>
<junction x="58.42" y="101.6"/>
<pinref part="GND6" gate="1" pin="GND"/>
<pinref part="C4" gate="G$1" pin="+"/>
<pinref part="C5" gate="G$1" pin="-"/>
</segment>
<segment>
<wire x1="58.42" y1="55.88" x2="66.04" y2="55.88" width="0.1524" layer="91"/>
<junction x="58.42" y="55.88"/>
<pinref part="GND7" gate="1" pin="GND"/>
<pinref part="C9" gate="G$1" pin="+"/>
<pinref part="C10" gate="G$1" pin="-"/>
</segment>
<segment>
<wire x1="106.68" y1="-38.1" x2="106.68" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-40.64" x2="99.06" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-40.64" x2="91.44" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-40.64" x2="83.82" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-40.64" x2="76.2" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="106.68" y1="-40.64" x2="106.68" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-38.1" x2="76.2" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="83.82" y1="-38.1" x2="83.82" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="91.44" y1="-38.1" x2="91.44" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="99.06" y1="-38.1" x2="99.06" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="76.2" y1="-40.64" x2="68.58" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="68.58" y1="-40.64" x2="68.58" y2="-38.1" width="0.1524" layer="91"/>
<wire x1="66.04" y1="-40.64" x2="68.58" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="66.04" y1="-40.64" x2="60.96" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="60.96" y1="-40.64" x2="60.96" y2="-38.1" width="0.1524" layer="91"/>
<junction x="106.68" y="-40.64"/>
<junction x="99.06" y="-40.64"/>
<junction x="91.44" y="-40.64"/>
<junction x="83.82" y="-40.64"/>
<junction x="68.58" y="-40.64"/>
<junction x="76.2" y="-40.64"/>
<pinref part="C11" gate="G$1" pin="-"/>
<pinref part="GND2" gate="1" pin="GND"/>
<pinref part="C15" gate="G$1" pin="1"/>
<pinref part="C14" gate="G$1" pin="1"/>
<pinref part="C13" gate="G$1" pin="1"/>
<pinref part="C12" gate="G$1" pin="1"/>
<pinref part="C16" gate="G$1" pin="1"/>
<pinref part="C17" gate="G$1" pin="1"/>
</segment>
<segment>
<wire x1="-200.66" y1="7.62" x2="-200.66" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-200.66" y1="5.08" x2="-203.2" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-203.2" y1="5.08" x2="-205.74" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-205.74" y1="5.08" x2="-208.28" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-208.28" y1="5.08" x2="-210.82" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-210.82" y1="5.08" x2="-210.82" y2="7.62" width="0.1524" layer="91"/>
<wire x1="-208.28" y1="7.62" x2="-208.28" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-205.74" y1="7.62" x2="-205.74" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-203.2" y1="7.62" x2="-203.2" y2="5.08" width="0.1524" layer="91"/>
<wire x1="-200.66" y1="5.08" x2="-200.66" y2="2.54" width="0.1524" layer="91"/>
<junction x="-200.66" y="5.08"/>
<junction x="-203.2" y="5.08"/>
<junction x="-205.74" y="5.08"/>
<junction x="-208.28" y="5.08"/>
<pinref part="GND8" gate="1" pin="GND"/>
<pinref part="IC2" gate="G$1" pin="6"/>
<pinref part="IC2" gate="G$1" pin="7"/>
<pinref part="IC2" gate="G$1" pin="8"/>
<pinref part="IC2" gate="G$1" pin="9"/>
<pinref part="IC2" gate="G$1" pin="10"/>
</segment>
<segment>
<wire x1="-177.8" y1="45.72" x2="-182.88" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="45.72" x2="-182.88" y2="43.18" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="43.18" x2="-182.88" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="40.64" x2="-182.88" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="22.86" x2="-182.88" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="20.32" x2="-182.88" y2="17.78" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="17.78" x2="-182.88" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="43.18" x2="-182.88" y2="43.18" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="40.64" x2="-182.88" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="22.86" x2="-182.88" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="20.32" x2="-182.88" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="17.78" x2="-182.88" y2="17.78" width="0.1524" layer="91"/>
<junction x="-182.88" y="43.18"/>
<junction x="-182.88" y="40.64"/>
<junction x="-182.88" y="22.86"/>
<junction x="-182.88" y="20.32"/>
<junction x="-182.88" y="17.78"/>
<pinref part="IC1" gate="A" pin="P0"/>
<pinref part="IC1" gate="A" pin="P1"/>
<pinref part="IC1" gate="A" pin="P2"/>
<pinref part="IC1" gate="A" pin="Q0"/>
<pinref part="IC1" gate="A" pin="Q1"/>
<pinref part="IC1" gate="A" pin="Q2"/>
<pinref part="GND9" gate="1" pin="GND"/>
</segment>
<segment>
<wire x1="-12.7" y1="10.16" x2="-2.54" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="10.16" x2="-2.54" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="-12.7" x2="-12.7" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="-2.54" y1="-12.7" x2="-2.54" y2="-38.1" width="0.1524" layer="91"/>
<junction x="-2.54" y="-12.7"/>
<pinref part="JP1" gate="A" pin="2"/>
<pinref part="JP2" gate="A" pin="2"/>
<pinref part="GND10" gate="1" pin="GND"/>
</segment>
</net>
<net name="INTBUS0" class="0">
<segment>
<wire x1="-134.62" y1="43.18" x2="-132.08" y2="43.18" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="37"/>
</segment>
</net>
<net name="INTBUS1" class="0">
<segment>
<wire x1="-134.62" y1="45.72" x2="-132.08" y2="45.72" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="35"/>
</segment>
</net>
<net name="INTBUS2" class="0">
<segment>
<wire x1="-134.62" y1="48.26" x2="-132.08" y2="48.26" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="33"/>
</segment>
</net>
<net name="INTBUS3" class="0">
<segment>
<wire x1="-134.62" y1="50.8" x2="-132.08" y2="50.8" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="31"/>
</segment>
</net>
<net name="INTBUS4" class="0">
<segment>
<wire x1="-134.62" y1="53.34" x2="-132.08" y2="53.34" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="29"/>
</segment>
</net>
<net name="/RD" class="0">
<segment>
<wire x1="-116.84" y1="45.72" x2="-96.52" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-96.52" y1="45.72" x2="-86.36" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-86.36" y1="45.72" x2="-86.36" y2="66.04" width="0.1524" layer="91"/>
<wire x1="-86.36" y1="66.04" x2="-63.5" y2="66.04" width="0.1524" layer="91"/>
<wire x1="-60.96" y1="-12.7" x2="-96.52" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="-96.52" y1="-12.7" x2="-96.52" y2="45.72" width="0.1524" layer="91"/>
<junction x="-96.52" y="45.72"/>
<pinref part="EXPANSION" gate="1" pin="36"/>
<pinref part="U2" gate="G$1" pin="/RD"/>
<pinref part="U1" gate="A" pin="!RD"/>
</segment>
</net>
<net name="/WR" class="0">
<segment>
<wire x1="-116.84" y1="48.26" x2="-93.98" y2="48.26" width="0.1524" layer="91"/>
<wire x1="-93.98" y1="48.26" x2="-83.82" y2="48.26" width="0.1524" layer="91"/>
<wire x1="-83.82" y1="48.26" x2="-83.82" y2="63.5" width="0.1524" layer="91"/>
<wire x1="-83.82" y1="63.5" x2="-63.5" y2="63.5" width="0.1524" layer="91"/>
<wire x1="-93.98" y1="48.26" x2="-93.98" y2="-15.24" width="0.1524" layer="91"/>
<wire x1="-93.98" y1="-15.24" x2="-60.96" y2="-15.24" width="0.1524" layer="91"/>
<junction x="-93.98" y="48.26"/>
<pinref part="EXPANSION" gate="1" pin="34"/>
<pinref part="U2" gate="G$1" pin="/WR"/>
<pinref part="U1" gate="A" pin="!WR"/>
</segment>
</net>
<net name="CLKOUT" class="0">
<segment>
<wire x1="-116.84" y1="53.34" x2="-78.74" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-78.74" y1="53.34" x2="-78.74" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-78.74" y1="38.1" x2="-63.5" y2="38.1" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="30"/>
<pinref part="U2" gate="G$1" pin="PCLK"/>
</segment>
</net>
<net name="RESOUT" class="0">
<segment>
<wire x1="-132.08" y1="76.2" x2="-134.62" y2="76.2" width="0.1524" layer="91"/>
<pinref part="EXPANSION" gate="1" pin="11"/>
<wire x1="-134.62" y1="76.2" x2="-137.16" y2="78.74" width="0.1524" layer="91"/>
<wire x1="-137.16" y1="78.74" x2="-142.24" y2="78.74" width="0.1524" layer="91"/>
<wire x1="-142.24" y1="78.74" x2="-142.24" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-142.24" y1="-17.78" x2="-101.6" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-101.6" y1="-17.78" x2="-101.6" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="RESET"/>
<wire x1="-101.6" y1="-27.94" x2="-60.96" y2="-27.94" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<wire x1="17.78" y1="116.84" x2="22.86" y2="116.84" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="+"/>
<pinref part="IC3" gate="G$1" pin="C1+"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<wire x1="22.86" y1="111.76" x2="10.16" y2="111.76" width="0.1524" layer="91"/>
<wire x1="10.16" y1="111.76" x2="10.16" y2="116.84" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="C1-"/>
<pinref part="C1" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<wire x1="22.86" y1="106.68" x2="17.78" y2="106.68" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="C2+"/>
<pinref part="C2" gate="G$1" pin="+"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<wire x1="22.86" y1="101.6" x2="10.16" y2="101.6" width="0.1524" layer="91"/>
<wire x1="10.16" y1="101.6" x2="10.16" y2="106.68" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="C2-"/>
<pinref part="C2" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<wire x1="53.34" y1="114.3" x2="58.42" y2="114.3" width="0.1524" layer="91"/>
<wire x1="58.42" y1="114.3" x2="58.42" y2="116.84" width="0.1524" layer="91"/>
<pinref part="IC3" gate="G$1" pin="V+"/>
<pinref part="C3" gate="G$1" pin="+"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<wire x1="17.78" y1="71.12" x2="22.86" y2="71.12" width="0.1524" layer="91"/>
<pinref part="C6" gate="G$1" pin="+"/>
<pinref part="IC4" gate="G$1" pin="C1+"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<wire x1="22.86" y1="66.04" x2="10.16" y2="66.04" width="0.1524" layer="91"/>
<wire x1="10.16" y1="66.04" x2="10.16" y2="71.12" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="C1-"/>
<pinref part="C6" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<wire x1="22.86" y1="60.96" x2="17.78" y2="60.96" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="C2+"/>
<pinref part="C7" gate="G$1" pin="+"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<wire x1="22.86" y1="55.88" x2="10.16" y2="55.88" width="0.1524" layer="91"/>
<wire x1="10.16" y1="55.88" x2="10.16" y2="60.96" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="C2-"/>
<pinref part="C7" gate="G$1" pin="-"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<wire x1="53.34" y1="68.58" x2="58.42" y2="68.58" width="0.1524" layer="91"/>
<wire x1="58.42" y1="68.58" x2="58.42" y2="71.12" width="0.1524" layer="91"/>
<pinref part="IC4" gate="G$1" pin="V+"/>
<pinref part="C8" gate="G$1" pin="+"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<wire x1="58.42" y1="109.22" x2="53.34" y2="109.22" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="-"/>
<pinref part="IC3" gate="G$1" pin="V-"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<wire x1="58.42" y1="63.5" x2="53.34" y2="63.5" width="0.1524" layer="91"/>
<pinref part="C9" gate="G$1" pin="-"/>
<pinref part="IC4" gate="G$1" pin="V-"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<wire x1="-22.86" y1="81.28" x2="-22.86" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-22.86" y1="53.34" x2="-27.94" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-27.94" y1="81.28" x2="-22.86" y2="81.28" width="0.1524" layer="91"/>
<wire x1="-22.86" y1="111.76" x2="-22.86" y2="81.28" width="0.1524" layer="91"/>
<junction x="-22.86" y="81.28"/>
<pinref part="U2" gate="G$1" pin="/RTXCB"/>
<pinref part="U2" gate="G$1" pin="/RTXCA"/>
<pinref part="QG1" gate="G$1" pin="OUT"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<wire x1="-27.94" y1="88.9" x2="12.7" y2="88.9" width="0.1524" layer="91"/>
<wire x1="12.7" y1="88.9" x2="12.7" y2="93.98" width="0.1524" layer="91"/>
<wire x1="12.7" y1="93.98" x2="22.86" y2="93.98" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="TXDA"/>
<pinref part="IC3" gate="G$1" pin="T2IN"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<wire x1="-27.94" y1="86.36" x2="15.24" y2="86.36" width="0.1524" layer="91"/>
<wire x1="15.24" y1="86.36" x2="15.24" y2="88.9" width="0.1524" layer="91"/>
<wire x1="15.24" y1="88.9" x2="22.86" y2="88.9" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="RXDA"/>
<pinref part="IC3" gate="G$1" pin="R2OUT"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<wire x1="88.9" y1="106.68" x2="93.98" y2="106.68" width="0.1524" layer="91"/>
<wire x1="93.98" y1="106.68" x2="93.98" y2="109.22" width="0.1524" layer="91"/>
<wire x1="93.98" y1="109.22" x2="101.6" y2="109.22" width="0.1524" layer="91"/>
<pinref part="JP3" gate="A" pin="4"/>
<pinref part="JP5" gate="A" pin="3"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<wire x1="81.28" y1="106.68" x2="76.2" y2="106.68" width="0.1524" layer="91"/>
<wire x1="76.2" y1="106.68" x2="76.2" y2="96.52" width="0.1524" layer="91"/>
<wire x1="76.2" y1="96.52" x2="114.3" y2="96.52" width="0.1524" layer="91"/>
<wire x1="114.3" y1="96.52" x2="114.3" y2="111.76" width="0.1524" layer="91"/>
<wire x1="114.3" y1="111.76" x2="109.22" y2="111.76" width="0.1524" layer="91"/>
<pinref part="JP3" gate="A" pin="3"/>
<pinref part="JP5" gate="A" pin="2"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<wire x1="81.28" y1="104.14" x2="78.74" y2="104.14" width="0.1524" layer="91"/>
<wire x1="53.34" y1="88.9" x2="78.74" y2="88.9" width="0.1524" layer="91"/>
<wire x1="78.74" y1="88.9" x2="91.44" y2="88.9" width="0.1524" layer="91"/>
<wire x1="91.44" y1="88.9" x2="91.44" y2="104.14" width="0.1524" layer="91"/>
<wire x1="91.44" y1="104.14" x2="88.9" y2="104.14" width="0.1524" layer="91"/>
<wire x1="78.74" y1="104.14" x2="78.74" y2="88.9" width="0.1524" layer="91"/>
<junction x="78.74" y="88.9"/>
<pinref part="JP3" gate="A" pin="5"/>
<pinref part="IC3" gate="G$1" pin="R2IN"/>
<pinref part="JP3" gate="A" pin="6"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<wire x1="53.34" y1="93.98" x2="73.66" y2="93.98" width="0.1524" layer="91"/>
<wire x1="73.66" y1="93.98" x2="73.66" y2="109.22" width="0.1524" layer="91"/>
<wire x1="73.66" y1="109.22" x2="81.28" y2="109.22" width="0.1524" layer="91"/>
<wire x1="88.9" y1="109.22" x2="91.44" y2="109.22" width="0.1524" layer="91"/>
<wire x1="91.44" y1="109.22" x2="91.44" y2="116.84" width="0.1524" layer="91"/>
<wire x1="91.44" y1="116.84" x2="73.66" y2="116.84" width="0.1524" layer="91"/>
<wire x1="73.66" y1="116.84" x2="73.66" y2="109.22" width="0.1524" layer="91"/>
<junction x="73.66" y="109.22"/>
<pinref part="IC3" gate="G$1" pin="T2OUT"/>
<pinref part="JP3" gate="A" pin="1"/>
<pinref part="JP3" gate="A" pin="2"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<wire x1="-33.02" y1="10.16" x2="-20.32" y2="10.16" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA0"/>
<pinref part="JP1" gate="A" pin="1"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<wire x1="-33.02" y1="7.62" x2="-20.32" y2="7.62" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA1"/>
<pinref part="JP1" gate="A" pin="3"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<wire x1="-33.02" y1="5.08" x2="-20.32" y2="5.08" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA2"/>
<pinref part="JP1" gate="A" pin="5"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<wire x1="-33.02" y1="2.54" x2="-20.32" y2="2.54" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA3"/>
<pinref part="JP1" gate="A" pin="7"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<wire x1="-33.02" y1="0" x2="-20.32" y2="0" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA4"/>
<pinref part="JP1" gate="A" pin="9"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<wire x1="-33.02" y1="-2.54" x2="-20.32" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA5"/>
<pinref part="JP1" gate="A" pin="11"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<wire x1="-33.02" y1="-5.08" x2="-20.32" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA6"/>
<pinref part="JP1" gate="A" pin="13"/>
</segment>
</net>
<net name="N$36" class="0">
<segment>
<wire x1="-33.02" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PA7"/>
<pinref part="JP1" gate="A" pin="15"/>
</segment>
</net>
<net name="N$37" class="0">
<segment>
<wire x1="-33.02" y1="-12.7" x2="-20.32" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB0"/>
<pinref part="JP2" gate="A" pin="1"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<wire x1="-33.02" y1="-15.24" x2="-20.32" y2="-15.24" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB1"/>
<pinref part="JP2" gate="A" pin="3"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<wire x1="-33.02" y1="-17.78" x2="-20.32" y2="-17.78" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB2"/>
<pinref part="JP2" gate="A" pin="5"/>
</segment>
</net>
<net name="N$40" class="0">
<segment>
<wire x1="-33.02" y1="-20.32" x2="-20.32" y2="-20.32" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB3"/>
<pinref part="JP2" gate="A" pin="7"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<wire x1="-33.02" y1="-22.86" x2="-20.32" y2="-22.86" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB4"/>
<pinref part="JP2" gate="A" pin="9"/>
</segment>
</net>
<net name="N$42" class="0">
<segment>
<wire x1="-33.02" y1="-25.4" x2="-20.32" y2="-25.4" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB5"/>
<pinref part="JP2" gate="A" pin="11"/>
</segment>
</net>
<net name="N$43" class="0">
<segment>
<wire x1="-33.02" y1="-27.94" x2="-20.32" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB6"/>
<pinref part="JP2" gate="A" pin="13"/>
</segment>
</net>
<net name="N$44" class="0">
<segment>
<wire x1="-33.02" y1="-30.48" x2="-20.32" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="PB7"/>
<pinref part="JP2" gate="A" pin="15"/>
</segment>
</net>
<net name="N$53" class="0">
<segment>
<wire x1="88.9" y1="60.96" x2="93.98" y2="60.96" width="0.1524" layer="91"/>
<wire x1="93.98" y1="60.96" x2="93.98" y2="63.5" width="0.1524" layer="91"/>
<wire x1="93.98" y1="63.5" x2="101.6" y2="63.5" width="0.1524" layer="91"/>
<pinref part="JP4" gate="A" pin="4"/>
<pinref part="JP6" gate="A" pin="3"/>
</segment>
</net>
<net name="N$54" class="0">
<segment>
<wire x1="81.28" y1="60.96" x2="76.2" y2="60.96" width="0.1524" layer="91"/>
<wire x1="76.2" y1="60.96" x2="76.2" y2="50.8" width="0.1524" layer="91"/>
<wire x1="76.2" y1="50.8" x2="114.3" y2="50.8" width="0.1524" layer="91"/>
<wire x1="114.3" y1="50.8" x2="114.3" y2="66.04" width="0.1524" layer="91"/>
<wire x1="114.3" y1="66.04" x2="109.22" y2="66.04" width="0.1524" layer="91"/>
<pinref part="JP4" gate="A" pin="3"/>
<pinref part="JP6" gate="A" pin="2"/>
</segment>
</net>
<net name="N$55" class="0">
<segment>
<wire x1="88.9" y1="63.5" x2="91.44" y2="63.5" width="0.1524" layer="91"/>
<wire x1="91.44" y1="63.5" x2="91.44" y2="71.12" width="0.1524" layer="91"/>
<wire x1="91.44" y1="71.12" x2="73.66" y2="71.12" width="0.1524" layer="91"/>
<wire x1="73.66" y1="71.12" x2="73.66" y2="63.5" width="0.1524" layer="91"/>
<wire x1="73.66" y1="63.5" x2="73.66" y2="48.26" width="0.1524" layer="91"/>
<wire x1="73.66" y1="48.26" x2="53.34" y2="48.26" width="0.1524" layer="91"/>
<wire x1="81.28" y1="63.5" x2="73.66" y2="63.5" width="0.1524" layer="91"/>
<junction x="73.66" y="63.5"/>
<pinref part="JP4" gate="A" pin="2"/>
<pinref part="IC4" gate="G$1" pin="T2OUT"/>
<pinref part="JP4" gate="A" pin="1"/>
</segment>
</net>
<net name="N$56" class="0">
<segment>
<wire x1="88.9" y1="58.42" x2="91.44" y2="58.42" width="0.1524" layer="91"/>
<wire x1="91.44" y1="58.42" x2="91.44" y2="43.18" width="0.1524" layer="91"/>
<wire x1="91.44" y1="43.18" x2="78.74" y2="43.18" width="0.1524" layer="91"/>
<wire x1="78.74" y1="43.18" x2="53.34" y2="43.18" width="0.1524" layer="91"/>
<wire x1="81.28" y1="58.42" x2="78.74" y2="58.42" width="0.1524" layer="91"/>
<wire x1="78.74" y1="58.42" x2="78.74" y2="43.18" width="0.1524" layer="91"/>
<junction x="78.74" y="43.18"/>
<pinref part="JP4" gate="A" pin="6"/>
<pinref part="IC4" gate="G$1" pin="R2IN"/>
<pinref part="JP4" gate="A" pin="5"/>
</segment>
</net>
<net name="N$57" class="0">
<segment>
<wire x1="-27.94" y1="60.96" x2="5.08" y2="60.96" width="0.1524" layer="91"/>
<wire x1="5.08" y1="60.96" x2="5.08" y2="48.26" width="0.1524" layer="91"/>
<wire x1="5.08" y1="48.26" x2="22.86" y2="48.26" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="TXDB"/>
<pinref part="IC4" gate="G$1" pin="T2IN"/>
</segment>
</net>
<net name="N$58" class="0">
<segment>
<wire x1="-27.94" y1="58.42" x2="2.54" y2="58.42" width="0.1524" layer="91"/>
<wire x1="2.54" y1="58.42" x2="2.54" y2="43.18" width="0.1524" layer="91"/>
<wire x1="2.54" y1="43.18" x2="22.86" y2="43.18" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="RXDB"/>
<pinref part="IC4" gate="G$1" pin="R2OUT"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<wire x1="-210.82" y1="43.18" x2="-210.82" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-210.82" y1="38.1" x2="-210.82" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="38.1" x2="-210.82" y2="38.1" width="0.1524" layer="91"/>
<junction x="-210.82" y="38.1"/>
<pinref part="RN1" gate="G$1" pin="2"/>
<pinref part="IC2" gate="G$1" pin="1"/>
<pinref part="IC1" gate="A" pin="P3"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<wire x1="-208.28" y1="43.18" x2="-208.28" y2="35.56" width="0.1524" layer="91"/>
<wire x1="-208.28" y1="35.56" x2="-208.28" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="35.56" x2="-208.28" y2="35.56" width="0.1524" layer="91"/>
<junction x="-208.28" y="35.56"/>
<pinref part="RN1" gate="G$1" pin="3"/>
<pinref part="IC2" gate="G$1" pin="2"/>
<pinref part="IC1" gate="A" pin="P4"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<wire x1="-205.74" y1="43.18" x2="-205.74" y2="33.02" width="0.1524" layer="91"/>
<wire x1="-205.74" y1="33.02" x2="-205.74" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="33.02" x2="-205.74" y2="33.02" width="0.1524" layer="91"/>
<junction x="-205.74" y="33.02"/>
<pinref part="RN1" gate="G$1" pin="4"/>
<pinref part="IC2" gate="G$1" pin="3"/>
<pinref part="IC1" gate="A" pin="P5"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<wire x1="-203.2" y1="43.18" x2="-203.2" y2="30.48" width="0.1524" layer="91"/>
<wire x1="-203.2" y1="30.48" x2="-203.2" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="30.48" x2="-203.2" y2="30.48" width="0.1524" layer="91"/>
<junction x="-203.2" y="30.48"/>
<pinref part="RN1" gate="G$1" pin="5"/>
<pinref part="IC2" gate="G$1" pin="4"/>
<pinref part="IC1" gate="A" pin="P6"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<wire x1="-200.66" y1="43.18" x2="-200.66" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-200.66" y1="27.94" x2="-200.66" y2="22.86" width="0.1524" layer="91"/>
<wire x1="-177.8" y1="27.94" x2="-200.66" y2="27.94" width="0.1524" layer="91"/>
<junction x="-200.66" y="27.94"/>
<pinref part="RN1" gate="G$1" pin="6"/>
<pinref part="IC2" gate="G$1" pin="5"/>
<pinref part="IC1" gate="A" pin="P7"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<wire x1="-157.48" y1="-30.48" x2="-149.86" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="IC6" gate="A" pin="O"/>
<pinref part="IC5" gate="A" pin="I0"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<wire x1="-149.86" y1="-35.56" x2="-152.4" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="-152.4" y1="-35.56" x2="-152.4" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="-149.86" y1="-63.5" x2="-152.4" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="-152.4" y1="-63.5" x2="-157.48" y2="-63.5" width="0.1524" layer="91"/>
<junction x="-152.4" y="-63.5"/>
<pinref part="IC5" gate="A" pin="I1"/>
<pinref part="IC6" gate="B" pin="O"/>
<pinref part="IC5" gate="D" pin="I1"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<wire x1="-63.5" y1="55.88" x2="-81.28" y2="55.88" width="0.1524" layer="91"/>
<wire x1="-81.28" y1="55.88" x2="-81.28" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="-81.28" y1="-33.02" x2="-124.46" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="U2" gate="G$1" pin="/CE"/>
<pinref part="IC5" gate="A" pin="O"/>
</segment>
</net>
<net name="N$45" class="0">
<segment>
<wire x1="-60.96" y1="-33.02" x2="-76.2" y2="-33.02" width="0.1524" layer="91"/>
<wire x1="-76.2" y1="-33.02" x2="-76.2" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="-76.2" y1="-60.96" x2="-124.46" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="U1" gate="A" pin="!CS"/>
<pinref part="IC5" gate="D" pin="O"/>
</segment>
</net>
<net name="N$47" class="0">
<segment>
<wire x1="-152.4" y1="45.72" x2="-149.86" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-149.86" y1="45.72" x2="-149.86" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-149.86" y1="-17.78" x2="-182.88" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="-17.78" x2="-182.88" y2="-63.5" width="0.1524" layer="91"/>
<wire x1="-182.88" y1="-63.5" x2="-177.8" y2="-63.5" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="P=Q"/>
<pinref part="IC6" gate="B" pin="I"/>
</segment>
</net>
<net name="N$49" class="0">
<segment>
<wire x1="-134.62" y1="20.32" x2="-144.78" y2="20.32" width="0.1524" layer="91"/>
<wire x1="-144.78" y1="20.32" x2="-144.78" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-144.78" y1="-7.62" x2="-180.34" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="-180.34" y1="-7.62" x2="-180.34" y2="0" width="0.1524" layer="91"/>
<wire x1="-180.34" y1="0" x2="-177.8" y2="0" width="0.1524" layer="91"/>
<pinref part="IC6" gate="F" pin="O"/>
<pinref part="IC1" gate="A" pin="G"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
