<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.7.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="MA08-1">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="29.845" y2="1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="1.27" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="0.635" x2="30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-10.16" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-9.398" y="-2.921" size="1.27" layer="21" ratio="10">1</text>
<text x="8.255" y="1.651" size="1.27" layer="21" ratio="10">8</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<pad name="9" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<pad name="10" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<pad name="11" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<pad name="12" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<pad name="13" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<pad name="14" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
<pad name="15" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="26.416" y1="-0.254" x2="26.924" y2="0.254" layer="51"/>
<pad name="16" x="29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="28.956" y1="-0.254" x2="29.464" y2="0.254" layer="51"/>
</package>
<package name="FE08">
<description>&lt;b&gt;FEMALE HEADER&lt;/b&gt;</description>
<wire x1="-10.16" y1="1.27" x2="-10.16" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.27" x2="-7.874" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.27" x2="-7.62" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.016" x2="-7.366" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-5.334" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-1.27" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.016" x2="-4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.27" x2="-2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.27" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="0" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.016" x2="0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.27" x2="0" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0" y1="1.016" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.794" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.27" x2="-4.826" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.27" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.334" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.27" x2="-7.366" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="1.27" x2="-7.62" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.016" x2="-7.874" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.27" x2="-10.16" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="0.762" x2="-9.144" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="0.508" x2="-9.398" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="0.508" x2="-9.398" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-0.508" x2="-9.144" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-0.508" x2="-9.144" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-9.144" y1="-0.762" x2="-8.636" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="-0.762" x2="-8.636" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="-0.508" x2="-8.382" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-8.382" y1="-0.508" x2="-8.382" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-8.382" y1="0.508" x2="-8.636" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="0.508" x2="-8.636" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="0.762" x2="-9.144" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="0.762" x2="-6.604" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="0.508" x2="-6.858" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-6.858" y1="0.508" x2="-6.858" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-6.858" y1="-0.508" x2="-6.604" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-0.508" x2="-6.604" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-0.762" x2="-6.096" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="-0.762" x2="-6.096" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="-0.508" x2="-5.842" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-0.508" x2="-5.842" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="0.508" x2="-6.096" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="0.508" x2="-6.096" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="0.762" x2="-6.604" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="0.762" x2="-4.064" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="0.508" x2="-4.318" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="0.508" x2="-4.318" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-0.508" x2="-4.064" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="-0.508" x2="-4.064" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="-0.762" x2="-3.556" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="-0.762" x2="-3.556" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="-0.508" x2="-3.302" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="-0.508" x2="-3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.508" x2="-3.556" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="0.508" x2="-3.556" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-3.556" y1="0.762" x2="-4.064" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.762" x2="-1.524" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="-1.778" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="-0.508" x2="-1.524" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="-0.508" x2="-1.524" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="-0.762" x2="-1.016" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-0.762" x2="-1.016" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-0.508" x2="-0.762" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-0.508" x2="-0.762" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0.508" x2="-1.016" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="0.508" x2="-1.016" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="0.762" x2="-1.524" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.016" y1="0.762" x2="1.016" y2="0.508" width="0.1524" layer="51"/>
<wire x1="1.016" y1="0.508" x2="0.762" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.762" y1="0.508" x2="0.762" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.762" y1="-0.508" x2="1.016" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-0.508" x2="1.016" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.016" y1="-0.762" x2="1.524" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.524" y1="-0.762" x2="1.524" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.524" y1="-0.508" x2="1.778" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.508" x2="1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="1.778" y1="0.508" x2="1.524" y2="0.508" width="0.1524" layer="51"/>
<wire x1="1.524" y1="0.508" x2="1.524" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.524" y1="0.762" x2="1.016" y2="0.762" width="0.1524" layer="51"/>
<wire x1="0.254" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="4.826" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-1.27" x2="5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.016" x2="5.334" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.27" x2="5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.016" x2="4.826" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.27" x2="2.794" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.016" x2="2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.27" x2="0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.556" y1="0.762" x2="3.556" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.556" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.302" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="-0.508" x2="3.556" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.556" y1="-0.508" x2="3.556" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.556" y1="-0.762" x2="4.064" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="4.064" y1="-0.762" x2="4.064" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.064" y1="-0.508" x2="4.318" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-0.508" x2="4.318" y2="0.508" width="0.1524" layer="51"/>
<wire x1="4.318" y1="0.508" x2="4.064" y2="0.508" width="0.1524" layer="51"/>
<wire x1="4.064" y1="0.508" x2="4.064" y2="0.762" width="0.1524" layer="51"/>
<wire x1="4.064" y1="0.762" x2="3.556" y2="0.762" width="0.1524" layer="51"/>
<wire x1="6.096" y1="0.762" x2="6.096" y2="0.508" width="0.1524" layer="51"/>
<wire x1="6.096" y1="0.508" x2="5.842" y2="0.508" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.508" x2="5.842" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="5.842" y1="-0.508" x2="6.096" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="6.096" y1="-0.508" x2="6.096" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.096" y1="-0.762" x2="6.604" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="6.604" y1="-0.762" x2="6.604" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="6.604" y1="-0.508" x2="6.858" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="6.858" y1="-0.508" x2="6.858" y2="0.508" width="0.1524" layer="51"/>
<wire x1="6.858" y1="0.508" x2="6.604" y2="0.508" width="0.1524" layer="51"/>
<wire x1="6.604" y1="0.508" x2="6.604" y2="0.762" width="0.1524" layer="51"/>
<wire x1="6.604" y1="0.762" x2="6.096" y2="0.762" width="0.1524" layer="51"/>
<wire x1="30.48" y1="1.27" x2="7.874" y2="1.27" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-1.27" x2="30.48" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-1.27" x2="30.48" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.016" x2="7.366" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.874" y1="1.27" x2="7.62" y2="1.016" width="0.1524" layer="21"/>
<wire x1="7.366" y1="1.27" x2="5.334" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.016" x2="7.874" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.27" x2="7.62" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-1.27" x2="7.366" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0.762" x2="8.636" y2="0.508" width="0.1524" layer="51"/>
<wire x1="8.636" y1="0.508" x2="8.382" y2="0.508" width="0.1524" layer="51"/>
<wire x1="8.382" y1="0.508" x2="8.382" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="8.382" y1="-0.508" x2="8.636" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-0.508" x2="8.636" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-0.762" x2="9.144" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-0.762" x2="9.144" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="9.144" y1="-0.508" x2="9.398" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="9.398" y1="-0.508" x2="9.398" y2="0.508" width="0.1524" layer="51"/>
<wire x1="9.398" y1="0.508" x2="9.144" y2="0.508" width="0.1524" layer="51"/>
<wire x1="9.144" y1="0.508" x2="9.144" y2="0.762" width="0.1524" layer="51"/>
<wire x1="9.144" y1="0.762" x2="8.636" y2="0.762" width="0.1524" layer="51"/>
<pad name="1" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-6.35" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-9.398" y="1.524" size="1.27" layer="21" ratio="10">1</text>
<text x="-10.16" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="8.382" y="1.524" size="1.27" layer="21" ratio="10">8</text>
<rectangle x1="-9.017" y1="0.254" x2="-8.763" y2="0.762" layer="51"/>
<rectangle x1="-9.017" y1="-0.762" x2="-8.763" y2="-0.254" layer="51"/>
<rectangle x1="-6.477" y1="0.254" x2="-6.223" y2="0.762" layer="51"/>
<rectangle x1="-6.477" y1="-0.762" x2="-6.223" y2="-0.254" layer="51"/>
<rectangle x1="-3.937" y1="0.254" x2="-3.683" y2="0.762" layer="51"/>
<rectangle x1="-3.937" y1="-0.762" x2="-3.683" y2="-0.254" layer="51"/>
<rectangle x1="-1.397" y1="0.254" x2="-1.143" y2="0.762" layer="51"/>
<rectangle x1="-1.397" y1="-0.762" x2="-1.143" y2="-0.254" layer="51"/>
<rectangle x1="1.143" y1="0.254" x2="1.397" y2="0.762" layer="51"/>
<rectangle x1="1.143" y1="-0.762" x2="1.397" y2="-0.254" layer="51"/>
<rectangle x1="3.683" y1="0.254" x2="3.937" y2="0.762" layer="51"/>
<rectangle x1="3.683" y1="-0.762" x2="3.937" y2="-0.254" layer="51"/>
<rectangle x1="6.223" y1="0.254" x2="6.477" y2="0.762" layer="51"/>
<rectangle x1="6.223" y1="-0.762" x2="6.477" y2="-0.254" layer="51"/>
<rectangle x1="8.763" y1="0.254" x2="9.017" y2="0.762" layer="51"/>
<rectangle x1="8.763" y1="-0.762" x2="9.017" y2="-0.254" layer="51"/>
<wire x1="11.176" y1="0.762" x2="11.176" y2="0.508" width="0.1524" layer="51"/>
<wire x1="11.176" y1="0.508" x2="10.922" y2="0.508" width="0.1524" layer="51"/>
<wire x1="10.922" y1="0.508" x2="10.922" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="10.922" y1="-0.508" x2="11.176" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="11.176" y1="-0.508" x2="11.176" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="11.176" y1="-0.762" x2="11.684" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-0.762" x2="11.684" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-0.508" x2="11.938" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="11.938" y1="-0.508" x2="11.938" y2="0.508" width="0.1524" layer="51"/>
<wire x1="11.938" y1="0.508" x2="11.684" y2="0.508" width="0.1524" layer="51"/>
<wire x1="11.684" y1="0.508" x2="11.684" y2="0.762" width="0.1524" layer="51"/>
<wire x1="11.684" y1="0.762" x2="11.176" y2="0.762" width="0.1524" layer="51"/>
<pad name="9" x="11.43" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="11.303" y1="0.254" x2="11.557" y2="0.762" layer="51"/>
<rectangle x1="11.303" y1="-0.762" x2="11.557" y2="-0.254" layer="51"/>
<wire x1="13.716" y1="0.762" x2="13.716" y2="0.508" width="0.1524" layer="51"/>
<wire x1="13.716" y1="0.508" x2="13.462" y2="0.508" width="0.1524" layer="51"/>
<wire x1="13.462" y1="0.508" x2="13.462" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="13.462" y1="-0.508" x2="13.716" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="13.716" y1="-0.508" x2="13.716" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="13.716" y1="-0.762" x2="14.224" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-0.762" x2="14.224" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-0.508" x2="14.478" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="14.478" y1="-0.508" x2="14.478" y2="0.508" width="0.1524" layer="51"/>
<wire x1="14.478" y1="0.508" x2="14.224" y2="0.508" width="0.1524" layer="51"/>
<wire x1="14.224" y1="0.508" x2="14.224" y2="0.762" width="0.1524" layer="51"/>
<wire x1="14.224" y1="0.762" x2="13.716" y2="0.762" width="0.1524" layer="51"/>
<pad name="10" x="13.97" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="13.843" y1="0.254" x2="14.097" y2="0.762" layer="51"/>
<rectangle x1="13.843" y1="-0.762" x2="14.097" y2="-0.254" layer="51"/>
<wire x1="16.256" y1="0.762" x2="16.256" y2="0.508" width="0.1524" layer="51"/>
<wire x1="16.256" y1="0.508" x2="16.002" y2="0.508" width="0.1524" layer="51"/>
<wire x1="16.002" y1="0.508" x2="16.002" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="16.002" y1="-0.508" x2="16.256" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="16.256" y1="-0.508" x2="16.256" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="16.256" y1="-0.762" x2="16.764" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-0.762" x2="16.764" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-0.508" x2="17.018" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="17.018" y1="-0.508" x2="17.018" y2="0.508" width="0.1524" layer="51"/>
<wire x1="17.018" y1="0.508" x2="16.764" y2="0.508" width="0.1524" layer="51"/>
<wire x1="16.764" y1="0.508" x2="16.764" y2="0.762" width="0.1524" layer="51"/>
<wire x1="16.764" y1="0.762" x2="16.256" y2="0.762" width="0.1524" layer="51"/>
<pad name="11" x="16.51" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="16.383" y1="0.254" x2="16.637" y2="0.762" layer="51"/>
<rectangle x1="16.383" y1="-0.762" x2="16.637" y2="-0.254" layer="51"/>
<wire x1="18.796" y1="0.762" x2="18.796" y2="0.508" width="0.1524" layer="51"/>
<wire x1="18.796" y1="0.508" x2="18.542" y2="0.508" width="0.1524" layer="51"/>
<wire x1="18.542" y1="0.508" x2="18.542" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="18.542" y1="-0.508" x2="18.796" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="18.796" y1="-0.508" x2="18.796" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="18.796" y1="-0.762" x2="19.304" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="19.304" y1="-0.762" x2="19.304" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="19.304" y1="-0.508" x2="19.558" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="19.558" y1="-0.508" x2="19.558" y2="0.508" width="0.1524" layer="51"/>
<wire x1="19.558" y1="0.508" x2="19.304" y2="0.508" width="0.1524" layer="51"/>
<wire x1="19.304" y1="0.508" x2="19.304" y2="0.762" width="0.1524" layer="51"/>
<wire x1="19.304" y1="0.762" x2="18.796" y2="0.762" width="0.1524" layer="51"/>
<pad name="12" x="19.05" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="18.923" y1="0.254" x2="19.177" y2="0.762" layer="51"/>
<rectangle x1="18.923" y1="-0.762" x2="19.177" y2="-0.254" layer="51"/>
<wire x1="21.336" y1="0.762" x2="21.336" y2="0.508" width="0.1524" layer="51"/>
<wire x1="21.336" y1="0.508" x2="21.082" y2="0.508" width="0.1524" layer="51"/>
<wire x1="21.082" y1="0.508" x2="21.082" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="21.082" y1="-0.508" x2="21.336" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="21.336" y1="-0.508" x2="21.336" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="21.336" y1="-0.762" x2="21.844" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="21.844" y1="-0.762" x2="21.844" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="21.844" y1="-0.508" x2="22.098" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="22.098" y1="-0.508" x2="22.098" y2="0.508" width="0.1524" layer="51"/>
<wire x1="22.098" y1="0.508" x2="21.844" y2="0.508" width="0.1524" layer="51"/>
<wire x1="21.844" y1="0.508" x2="21.844" y2="0.762" width="0.1524" layer="51"/>
<wire x1="21.844" y1="0.762" x2="21.336" y2="0.762" width="0.1524" layer="51"/>
<pad name="13" x="21.59" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="21.463" y1="0.254" x2="21.717" y2="0.762" layer="51"/>
<rectangle x1="21.463" y1="-0.762" x2="21.717" y2="-0.254" layer="51"/>
<wire x1="23.876" y1="0.762" x2="23.876" y2="0.508" width="0.1524" layer="51"/>
<wire x1="23.876" y1="0.508" x2="23.622" y2="0.508" width="0.1524" layer="51"/>
<wire x1="23.622" y1="0.508" x2="23.622" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="23.622" y1="-0.508" x2="23.876" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="23.876" y1="-0.508" x2="23.876" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="23.876" y1="-0.762" x2="24.384" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="24.384" y1="-0.762" x2="24.384" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="24.384" y1="-0.508" x2="24.638" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="24.638" y1="-0.508" x2="24.638" y2="0.508" width="0.1524" layer="51"/>
<wire x1="24.638" y1="0.508" x2="24.384" y2="0.508" width="0.1524" layer="51"/>
<wire x1="24.384" y1="0.508" x2="24.384" y2="0.762" width="0.1524" layer="51"/>
<wire x1="24.384" y1="0.762" x2="23.876" y2="0.762" width="0.1524" layer="51"/>
<pad name="14" x="24.13" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="24.003" y1="0.254" x2="24.257" y2="0.762" layer="51"/>
<rectangle x1="24.003" y1="-0.762" x2="24.257" y2="-0.254" layer="51"/>
<wire x1="26.416" y1="0.762" x2="26.416" y2="0.508" width="0.1524" layer="51"/>
<wire x1="26.416" y1="0.508" x2="26.162" y2="0.508" width="0.1524" layer="51"/>
<wire x1="26.162" y1="0.508" x2="26.162" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="26.162" y1="-0.508" x2="26.416" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="26.416" y1="-0.508" x2="26.416" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="26.416" y1="-0.762" x2="26.924" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="26.924" y1="-0.762" x2="26.924" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="26.924" y1="-0.508" x2="27.178" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="27.178" y1="-0.508" x2="27.178" y2="0.508" width="0.1524" layer="51"/>
<wire x1="27.178" y1="0.508" x2="26.924" y2="0.508" width="0.1524" layer="51"/>
<wire x1="26.924" y1="0.508" x2="26.924" y2="0.762" width="0.1524" layer="51"/>
<wire x1="26.924" y1="0.762" x2="26.416" y2="0.762" width="0.1524" layer="51"/>
<pad name="15" x="26.67" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="26.543" y1="0.254" x2="26.797" y2="0.762" layer="51"/>
<rectangle x1="26.543" y1="-0.762" x2="26.797" y2="-0.254" layer="51"/>
<wire x1="28.956" y1="0.762" x2="28.956" y2="0.508" width="0.1524" layer="51"/>
<wire x1="28.956" y1="0.508" x2="28.702" y2="0.508" width="0.1524" layer="51"/>
<wire x1="28.702" y1="0.508" x2="28.702" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="28.702" y1="-0.508" x2="28.956" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="28.956" y1="-0.508" x2="28.956" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="28.956" y1="-0.762" x2="29.464" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="29.464" y1="-0.762" x2="29.464" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="29.464" y1="-0.508" x2="29.718" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="29.718" y1="-0.508" x2="29.718" y2="0.508" width="0.1524" layer="51"/>
<wire x1="29.718" y1="0.508" x2="29.464" y2="0.508" width="0.1524" layer="51"/>
<wire x1="29.464" y1="0.508" x2="29.464" y2="0.762" width="0.1524" layer="51"/>
<wire x1="29.464" y1="0.762" x2="28.956" y2="0.762" width="0.1524" layer="51"/>
<pad name="16" x="29.21" y="0" drill="0.8128" shape="long" rot="R90"/>
<rectangle x1="29.083" y1="0.254" x2="29.337" y2="0.762" layer="51"/>
<rectangle x1="29.083" y1="-0.762" x2="29.337" y2="-0.254" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="MA08-1">
<wire x1="3.81" y1="-10.16" x2="-1.27" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="33.02" x2="-1.27" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-10.16" x2="3.81" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="33.02" x2="3.81" y2="33.02" width="0.4064" layer="94"/>
<text x="-1.27" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<text x="-1.27" y="33.782" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<wire x1="1.27" y1="12.7" x2="2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="15.24" x2="2.54" y2="15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="17.78" x2="2.54" y2="17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="20.32" x2="2.54" y2="20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="22.86" x2="2.54" y2="22.86" width="0.6096" layer="94"/>
<wire x1="1.27" y1="25.4" x2="2.54" y2="25.4" width="0.6096" layer="94"/>
<wire x1="1.27" y1="27.94" x2="2.54" y2="27.94" width="0.6096" layer="94"/>
<wire x1="1.27" y1="30.48" x2="2.54" y2="30.48" width="0.6096" layer="94"/>
<pin name="9" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="FE08-1">
<wire x1="1.905" y1="-1.905" x2="1.905" y2="-3.175" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="-4.445" x2="1.905" y2="-5.715" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="-6.985" x2="1.905" y2="-8.255" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="3.175" x2="1.905" y2="1.905" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="0.635" x2="1.905" y2="-0.635" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="10.795" x2="1.905" y2="9.525" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="8.255" x2="1.905" y2="6.985" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="5.715" x2="1.905" y2="4.445" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="13.335" x2="1.905" y2="12.065" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="15.875" x2="1.905" y2="14.605" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="18.415" x2="1.905" y2="17.145" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="20.955" x2="1.905" y2="19.685" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="23.495" x2="1.905" y2="22.225" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="26.035" x2="1.905" y2="24.765" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="28.575" x2="1.905" y2="27.305" width="0.254" layer="94" curve="-180" cap="flat"/>
<wire x1="1.905" y1="31.115" x2="1.905" y2="29.845" width="0.254" layer="94" curve="-180" cap="flat"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="MA08-1" prefix="SV" uservalue="yes">
<gates>
<gate name="1" symbol="MA08-1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MA08-1">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="10" pad="10"/>
<connect gate="1" pin="11" pad="11"/>
<connect gate="1" pin="12" pad="12"/>
<connect gate="1" pin="13" pad="13"/>
<connect gate="1" pin="14" pad="14"/>
<connect gate="1" pin="15" pad="15"/>
<connect gate="1" pin="16" pad="16"/>
<connect gate="1" pin="2" pad="2"/>
<connect gate="1" pin="3" pad="3"/>
<connect gate="1" pin="4" pad="4"/>
<connect gate="1" pin="5" pad="5"/>
<connect gate="1" pin="6" pad="6"/>
<connect gate="1" pin="7" pad="7"/>
<connect gate="1" pin="8" pad="8"/>
<connect gate="1" pin="9" pad="9"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FE08-1" prefix="SV" uservalue="yes">
<gates>
<gate name="G$1" symbol="FE08-1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="FE08">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
