<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.7.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
</layers>
<library>
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="1X20">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="20.955" y1="1.27" x2="22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="0.635" x2="22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="0.635" x2="20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="1.27" x2="17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="1.27" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="0.635" x2="12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.27" x2="-12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.27" x2="-15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-23.495" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-1.27" x2="-22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-1.27" x2="-24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.765" y2="1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="1.27" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="0.635" x2="25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-25.4762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-25.4" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="-16.764" y1="-0.254" x2="-16.256" y2="0.254" layer="51"/>
<rectangle x1="-19.304" y1="-0.254" x2="-18.796" y2="0.254" layer="51"/>
<rectangle x1="-21.844" y1="-0.254" x2="-21.336" y2="0.254" layer="51"/>
<rectangle x1="-24.384" y1="-0.254" x2="-23.876" y2="0.254" layer="51"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
</package>
<package name="1X19">
<wire x1="19.05" y1="0.635" x2="19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="21.59" y1="0.635" x2="21.59" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="19.05" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="1.27" x2="16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="0.635" x2="16.51" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="16.51" y1="0.635" x2="17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="1.27" x2="18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="0.635" x2="19.05" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="16.51" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="14.605" y1="1.27" x2="13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0.635" x2="11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.635" x2="-10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-0.635" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="0.635" x2="-13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-0.635" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="0.635" x2="-13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.635" x2="-11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-0.635" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.27" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="0.635" x2="-18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="0.635" x2="-16.51" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-0.635" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.05" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-0.635" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.27" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="0.635" x2="-21.59" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-0.635" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="0.635" x2="-20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="0.635" x2="-19.05" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-0.635" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-21.59" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="0.635" x2="-24.13" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-24.13" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="-0.635" x2="-23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-1.27" x2="-23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="21.59" y1="0.635" x2="22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="1.27" x2="23.495" y2="1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.13" y2="0.635" width="0.1524" layer="21"/>
<wire x1="24.13" y1="0.635" x2="24.13" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="21.59" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="22.86" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-24.2062" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-24.13" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="-7.874" y1="-0.254" x2="-7.366" y2="0.254" layer="51"/>
<rectangle x1="-10.414" y1="-0.254" x2="-9.906" y2="0.254" layer="51"/>
<rectangle x1="-12.954" y1="-0.254" x2="-12.446" y2="0.254" layer="51"/>
<rectangle x1="-15.494" y1="-0.254" x2="-14.986" y2="0.254" layer="51"/>
<rectangle x1="-18.034" y1="-0.254" x2="-17.526" y2="0.254" layer="51"/>
<rectangle x1="-20.574" y1="-0.254" x2="-20.066" y2="0.254" layer="51"/>
<rectangle x1="-23.114" y1="-0.254" x2="-22.606" y2="0.254" layer="51"/>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
</package>
<package name="1X18">
<wire x1="12.7" y1="0.635" x2="13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="15.875" y1="1.27" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.32" y1="0.635" x2="20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="20.32" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-22.9362" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-22.86" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X17">
<wire x1="13.97" y1="0.635" x2="14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="17.145" y1="1.27" x2="16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="0.635" x2="-15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-16.51" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-0.635" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-0.635" x2="-20.955" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="20.32" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-21.6662" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-21.59" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X16">
<wire x1="10.795" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-20.3962" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-20.32" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X15">
<wire x1="12.065" y1="1.27" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-0.635" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-0.635" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="17.78" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-19.1262" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-19.05" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X14">
<pad name="1" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-17.8562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-17.78" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X13">
<pad name="1" x="-15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="15.24" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-16.5862" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-16.51" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X12">
<pad name="1" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-15.3162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-15.24" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X11">
<pad name="1" x="-12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-14.0462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-13.97" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X10">
<pad name="1" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-12.7762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.7" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X09">
<pad name="1" x="-10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-11.5062" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.43" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X08">
<pad name="1" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-10.2362" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X07">
<pad name="1" x="-7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-8.9662" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.89" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X06">
<pad name="1" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-7.6962" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X05">
<pad name="1" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-6.4262" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X04">
<pad name="1" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-5.1562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X03">
<pad name="1" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.8862" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X02">
<pad name="1" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X01">
<pad name="1" x="0" y="0" drill="1.016" shape="octagon"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X20">
<wire x1="-25.4" y1="-1.905" x2="-24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="-2.54" x2="-23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-2.54" x2="-22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-2.54" x2="-20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-2.54" x2="-20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-2.54" x2="-18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-2.54" x2="-17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-2.54" x2="-15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-2.54" x2="-15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-1.905" x2="-25.4" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.905" x2="-24.765" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="2.54" x2="-23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="2.54" x2="-22.86" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="1.905" x2="-22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="2.54" x2="-20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="2.54" x2="-20.32" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.905" x2="-19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="2.54" x2="-18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="2.54" x2="-17.78" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.905" x2="-17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="2.54" x2="-15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="2.54" x2="-15.24" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.905" x2="-14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="2.54" x2="-12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.54" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.54" x2="12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.905" x2="13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="2.54" x2="13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="2.54" x2="15.24" y2="1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="2.54" x2="15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="2.54" x2="17.78" y2="1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.905" x2="18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="19.685" y1="2.54" x2="18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="19.685" y1="2.54" x2="20.32" y2="1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="22.225" y1="2.54" x2="20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="22.225" y1="2.54" x2="22.86" y2="1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-2.54" x2="20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-2.54" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-2.54" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="1.905" x2="-22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.905" x2="-20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.905" x2="-17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.905" x2="-15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.905" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="1.905" x2="22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="1.905" x2="23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="24.765" y1="2.54" x2="23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="24.765" y1="2.54" x2="25.4" y2="1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="24.765" y1="-2.54" x2="23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="25.4" y1="1.905" x2="25.4" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-24.13" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-21.59" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="21.59" y="1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="24.13" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="40" x="24.13" y="1.27" drill="1.016" shape="octagon"/>
<text x="-25.4" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-25.4" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-24.384" y1="-1.524" x2="-23.876" y2="-1.016" layer="51"/>
<rectangle x1="-24.384" y1="1.016" x2="-23.876" y2="1.524" layer="51"/>
<rectangle x1="-21.844" y1="1.016" x2="-21.336" y2="1.524" layer="51"/>
<rectangle x1="-21.844" y1="-1.524" x2="-21.336" y2="-1.016" layer="51"/>
<rectangle x1="-19.304" y1="1.016" x2="-18.796" y2="1.524" layer="51"/>
<rectangle x1="-19.304" y1="-1.524" x2="-18.796" y2="-1.016" layer="51"/>
<rectangle x1="-16.764" y1="1.016" x2="-16.256" y2="1.524" layer="51"/>
<rectangle x1="-14.224" y1="1.016" x2="-13.716" y2="1.524" layer="51"/>
<rectangle x1="-11.684" y1="1.016" x2="-11.176" y2="1.524" layer="51"/>
<rectangle x1="-16.764" y1="-1.524" x2="-16.256" y2="-1.016" layer="51"/>
<rectangle x1="-14.224" y1="-1.524" x2="-13.716" y2="-1.016" layer="51"/>
<rectangle x1="-11.684" y1="-1.524" x2="-11.176" y2="-1.016" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
<rectangle x1="11.176" y1="1.016" x2="11.684" y2="1.524" layer="51"/>
<rectangle x1="11.176" y1="-1.524" x2="11.684" y2="-1.016" layer="51"/>
<rectangle x1="13.716" y1="1.016" x2="14.224" y2="1.524" layer="51"/>
<rectangle x1="13.716" y1="-1.524" x2="14.224" y2="-1.016" layer="51"/>
<rectangle x1="16.256" y1="1.016" x2="16.764" y2="1.524" layer="51"/>
<rectangle x1="16.256" y1="-1.524" x2="16.764" y2="-1.016" layer="51"/>
<rectangle x1="18.796" y1="1.016" x2="19.304" y2="1.524" layer="51"/>
<rectangle x1="18.796" y1="-1.524" x2="19.304" y2="-1.016" layer="51"/>
<rectangle x1="21.336" y1="1.016" x2="21.844" y2="1.524" layer="51"/>
<rectangle x1="21.336" y1="-1.524" x2="21.844" y2="-1.016" layer="51"/>
<rectangle x1="23.876" y1="1.016" x2="24.384" y2="1.524" layer="51"/>
<rectangle x1="23.876" y1="-1.524" x2="24.384" y2="-1.016" layer="51"/>
</package>
<package name="2X18">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-22.86" y2="1.905" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-21.59" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="21.59" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="21.59" y="1.27" drill="1.016" shape="octagon"/>
<text x="-22.86" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-22.86" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X16">
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-20.32" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-19.05" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="19.05" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="19.05" y="1.27" drill="1.016" shape="octagon"/>
<text x="-20.32" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-20.32" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X14">
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-17.78" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-16.51" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="16.51" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="16.51" y="1.27" drill="1.016" shape="octagon"/>
<text x="-17.78" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-17.78" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X12">
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.24" y2="1.905" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-13.97" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="13.97" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="13.97" y="1.27" drill="1.016" shape="octagon"/>
<text x="-15.24" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-15.24" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X10">
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-11.43" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="11.43" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="11.43" y="1.27" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.7" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X15">
<wire x1="-19.05" y1="-1.905" x2="-18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-2.54" x2="-17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-2.54" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-1.905" x2="-15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-2.54" x2="-14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-1.905" x2="-19.05" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="1.905" x2="-18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="2.54" x2="-17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="2.54" x2="-16.51" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="1.905" x2="-15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="2.54" x2="-14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.54" x2="-13.97" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="2.54" x2="-12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.89" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="8.89" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="1.905" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.97" y2="1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="1.905" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="2.54" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="2.54" x2="16.51" y2="1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="1.905" x2="17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="2.54" x2="17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="2.54" x2="19.05" y2="1.905" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-2.54" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-2.54" x2="16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="1.905" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="1.905" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="1.905" x2="13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="1.905" x2="16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="19.05" y1="1.905" x2="19.05" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<text x="-19.05" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-19.05" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-18.034" y1="-1.524" x2="-17.526" y2="-1.016" layer="51"/>
<rectangle x1="-18.034" y1="1.016" x2="-17.526" y2="1.524" layer="51"/>
<rectangle x1="-15.494" y1="1.016" x2="-14.986" y2="1.524" layer="51"/>
<rectangle x1="-15.494" y1="-1.524" x2="-14.986" y2="-1.016" layer="51"/>
<rectangle x1="-12.954" y1="1.016" x2="-12.446" y2="1.524" layer="51"/>
<rectangle x1="-12.954" y1="-1.524" x2="-12.446" y2="-1.016" layer="51"/>
<rectangle x1="-10.414" y1="1.016" x2="-9.906" y2="1.524" layer="51"/>
<rectangle x1="-7.874" y1="1.016" x2="-7.366" y2="1.524" layer="51"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="51"/>
<rectangle x1="-10.414" y1="-1.524" x2="-9.906" y2="-1.016" layer="51"/>
<rectangle x1="-7.874" y1="-1.524" x2="-7.366" y2="-1.016" layer="51"/>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="51"/>
<rectangle x1="7.366" y1="1.016" x2="7.874" y2="1.524" layer="51"/>
<rectangle x1="7.366" y1="-1.524" x2="7.874" y2="-1.016" layer="51"/>
<rectangle x1="9.906" y1="1.016" x2="10.414" y2="1.524" layer="51"/>
<rectangle x1="9.906" y1="-1.524" x2="10.414" y2="-1.016" layer="51"/>
<rectangle x1="12.446" y1="1.016" x2="12.954" y2="1.524" layer="51"/>
<rectangle x1="12.446" y1="-1.524" x2="12.954" y2="-1.016" layer="51"/>
<rectangle x1="14.986" y1="1.016" x2="15.494" y2="1.524" layer="51"/>
<rectangle x1="14.986" y1="-1.524" x2="15.494" y2="-1.016" layer="51"/>
<rectangle x1="17.526" y1="1.016" x2="18.034" y2="1.524" layer="51"/>
<rectangle x1="17.526" y1="-1.524" x2="18.034" y2="-1.016" layer="51"/>
</package>
<package name="2X19">
<wire x1="-24.13" y1="-1.905" x2="-23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-2.54" x2="-22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-2.54" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-1.905" x2="-20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-2.54" x2="-19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-2.54" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="-1.905" x2="-24.13" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="1.905" x2="-23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="2.54" x2="-22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="2.54" x2="-21.59" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="1.905" x2="-20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="2.54" x2="-19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="2.54" x2="-19.05" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="19.05" y1="1.905" x2="19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="2.54" x2="19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="2.54" x2="21.59" y2="1.905" width="0.1524" layer="21"/>
<wire x1="21.59" y1="1.905" x2="22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="2.54" x2="22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="2.54" x2="24.13" y2="1.905" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-1.905" x2="23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-2.54" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-2.54" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="1.905" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="1.905" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="21.59" y1="1.905" x2="21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="24.13" y1="1.905" x2="24.13" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="22.86" y="1.27" drill="1.016" shape="octagon"/>
<text x="-24.13" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-24.13" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-23.114" y1="-1.524" x2="-22.606" y2="-1.016" layer="51"/>
<rectangle x1="-23.114" y1="1.016" x2="-22.606" y2="1.524" layer="51"/>
<rectangle x1="-20.574" y1="1.016" x2="-20.066" y2="1.524" layer="51"/>
<rectangle x1="-20.574" y1="-1.524" x2="-20.066" y2="-1.016" layer="51"/>
<rectangle x1="20.066" y1="1.016" x2="20.574" y2="1.524" layer="51"/>
<rectangle x1="20.066" y1="-1.524" x2="20.574" y2="-1.016" layer="51"/>
<rectangle x1="22.606" y1="1.016" x2="23.114" y2="1.524" layer="51"/>
<rectangle x1="22.606" y1="-1.524" x2="23.114" y2="-1.016" layer="51"/>
</package>
<package name="2X17">
<wire x1="-21.59" y1="-1.905" x2="-21.59" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<text x="-21.59" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-21.59" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X13">
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-1.905" x2="-16.51" y2="1.905" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.54" x2="13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="1.905" x2="13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="2.54" x2="15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="16.51" y1="1.905" x2="15.875" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<text x="-16.51" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-16.51" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-15.494" y1="-1.524" x2="-14.986" y2="-1.016" layer="21"/>
<rectangle x1="-15.494" y1="1.016" x2="-14.986" y2="1.524" layer="21"/>
<rectangle x1="-12.954" y1="1.016" x2="-12.446" y2="1.524" layer="21"/>
<rectangle x1="-12.954" y1="-1.524" x2="-12.446" y2="-1.016" layer="21"/>
<rectangle x1="-10.414" y1="1.016" x2="-9.906" y2="1.524" layer="21"/>
<rectangle x1="-10.414" y1="-1.524" x2="-9.906" y2="-1.016" layer="21"/>
<rectangle x1="-7.874" y1="1.016" x2="-7.366" y2="1.524" layer="21"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="21"/>
<rectangle x1="-7.874" y1="-1.524" x2="-7.366" y2="-1.016" layer="21"/>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="21"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="21"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="21"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="21"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="21"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="21"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="21"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="21"/>
<rectangle x1="7.366" y1="1.016" x2="7.874" y2="1.524" layer="21"/>
<rectangle x1="7.366" y1="-1.524" x2="7.874" y2="-1.016" layer="21"/>
<rectangle x1="9.906" y1="1.016" x2="10.414" y2="1.524" layer="21"/>
<rectangle x1="9.906" y1="-1.524" x2="10.414" y2="-1.016" layer="21"/>
<rectangle x1="12.446" y1="1.016" x2="12.954" y2="1.524" layer="21"/>
<rectangle x1="12.446" y1="-1.524" x2="12.954" y2="-1.016" layer="21"/>
<rectangle x1="14.986" y1="1.016" x2="15.494" y2="1.524" layer="21"/>
<rectangle x1="14.986" y1="-1.524" x2="15.494" y2="-1.016" layer="21"/>
</package>
<package name="2X11">
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-13.97" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<text x="-13.97" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-13.97" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X09">
<wire x1="3.175" y1="-2.54" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<text x="-11.43" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.43" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X08">
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-8.89" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="8.89" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="8.89" y="1.27" drill="1.016" shape="octagon"/>
<text x="-10.16" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.16" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X07">
<wire x1="5.715" y1="-2.54" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.89" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<text x="-8.89" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.89" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X06">
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-6.35" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="6.35" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="6.35" y="1.27" drill="1.016" shape="octagon"/>
<text x="-7.62" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X05">
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<text x="-6.35" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X04">
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-3.81" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="3.81" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="3.81" y="1.27" drill="1.016" shape="octagon"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X03">
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<text x="-3.81" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X02">
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-1.27" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="1.27" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="1.27" y="1.27" drill="1.016" shape="octagon"/>
<text x="-2.54" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X02/90">
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-3.175" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.445" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
</package>
<package name="1X03/90">
<wire x1="-3.81" y1="-1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="6.985" x2="-2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="6.985" x2="0" y2="1.27" width="0.762" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="6.985" x2="2.54" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-4.445" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.715" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.921" y1="0.635" x2="-2.159" y2="1.143" layer="21"/>
<rectangle x1="-0.381" y1="0.635" x2="0.381" y2="1.143" layer="21"/>
<rectangle x1="2.159" y1="0.635" x2="2.921" y2="1.143" layer="21"/>
<rectangle x1="-2.921" y1="-2.921" x2="-2.159" y2="-1.905" layer="21"/>
<rectangle x1="-0.381" y1="-2.921" x2="0.381" y2="-1.905" layer="21"/>
<rectangle x1="2.159" y1="-2.921" x2="2.921" y2="-1.905" layer="21"/>
</package>
<package name="1X04/90">
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-5.715" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.985" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
</package>
<package name="1X05/90">
<wire x1="-6.35" y1="-1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.985" x2="-5.08" y2="1.27" width="0.762" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.985" x2="5.08" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-6.985" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="8.255" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-5.461" y1="0.635" x2="-4.699" y2="1.143" layer="21"/>
<rectangle x1="4.699" y1="0.635" x2="5.461" y2="1.143" layer="21"/>
<rectangle x1="-5.461" y1="-2.921" x2="-4.699" y2="-1.905" layer="21"/>
<rectangle x1="4.699" y1="-2.921" x2="5.461" y2="-1.905" layer="21"/>
</package>
<package name="1X06/90">
<wire x1="-7.62" y1="-1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="6.985" x2="-6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.985" x2="6.35" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-8.255" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="9.525" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-6.731" y1="0.635" x2="-5.969" y2="1.143" layer="21"/>
<rectangle x1="5.969" y1="0.635" x2="6.731" y2="1.143" layer="21"/>
<rectangle x1="-6.731" y1="-2.921" x2="-5.969" y2="-1.905" layer="21"/>
<rectangle x1="5.969" y1="-2.921" x2="6.731" y2="-1.905" layer="21"/>
</package>
<package name="1X07/90">
<wire x1="-8.89" y1="-1.905" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.985" x2="-7.62" y2="1.27" width="0.762" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.985" x2="7.62" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-9.525" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="10.795" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-8.001" y1="0.635" x2="-7.239" y2="1.143" layer="21"/>
<rectangle x1="7.239" y1="0.635" x2="8.001" y2="1.143" layer="21"/>
<rectangle x1="-8.001" y1="-2.921" x2="-7.239" y2="-1.905" layer="21"/>
<rectangle x1="7.239" y1="-2.921" x2="8.001" y2="-1.905" layer="21"/>
</package>
<package name="1X08/90">
<wire x1="-10.16" y1="-1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="6.985" x2="-8.89" y2="1.27" width="0.762" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="6.985" x2="8.89" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-10.795" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="12.065" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-9.271" y1="0.635" x2="-8.509" y2="1.143" layer="21"/>
<rectangle x1="8.509" y1="0.635" x2="9.271" y2="1.143" layer="21"/>
<rectangle x1="-9.271" y1="-2.921" x2="-8.509" y2="-1.905" layer="21"/>
<rectangle x1="8.509" y1="-2.921" x2="9.271" y2="-1.905" layer="21"/>
</package>
<package name="1X09/90">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-11.43" y1="-1.905" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.635" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="6.985" x2="-10.16" y2="1.27" width="0.762" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0.635" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="6.985" x2="10.16" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-12.065" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="13.335" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-10.541" y1="0.635" x2="-9.779" y2="1.143" layer="21"/>
<rectangle x1="9.779" y1="0.635" x2="10.541" y2="1.143" layer="21"/>
<rectangle x1="-10.541" y1="-2.921" x2="-9.779" y2="-1.905" layer="21"/>
<rectangle x1="9.779" y1="-2.921" x2="10.541" y2="-1.905" layer="21"/>
</package>
<package name="1X10/90">
<wire x1="-12.7" y1="-1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="6.985" x2="-11.43" y2="1.27" width="0.762" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="0.635" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="6.985" x2="11.43" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-13.335" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="14.605" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-11.811" y1="0.635" x2="-11.049" y2="1.143" layer="21"/>
<rectangle x1="11.049" y1="0.635" x2="11.811" y2="1.143" layer="21"/>
<rectangle x1="-11.811" y1="-2.921" x2="-11.049" y2="-1.905" layer="21"/>
<rectangle x1="11.049" y1="-2.921" x2="11.811" y2="-1.905" layer="21"/>
</package>
<package name="1X11/90">
<wire x1="-13.97" y1="-1.905" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.635" x2="-13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="0.635" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="6.985" x2="-12.7" y2="1.27" width="0.762" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0.635" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="6.985" x2="12.7" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-14.605" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="15.875" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-13.081" y1="0.635" x2="-12.319" y2="1.143" layer="21"/>
<rectangle x1="12.319" y1="0.635" x2="13.081" y2="1.143" layer="21"/>
<rectangle x1="-13.081" y1="-2.921" x2="-12.319" y2="-1.905" layer="21"/>
<rectangle x1="12.319" y1="-2.921" x2="13.081" y2="-1.905" layer="21"/>
</package>
<package name="1X12/90">
<wire x1="-15.24" y1="-1.905" x2="-12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="6.985" x2="-13.97" y2="1.27" width="0.762" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="6.985" x2="13.97" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-15.875" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="17.145" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-14.351" y1="0.635" x2="-13.589" y2="1.143" layer="21"/>
<rectangle x1="13.589" y1="0.635" x2="14.351" y2="1.143" layer="21"/>
<rectangle x1="-14.351" y1="-2.921" x2="-13.589" y2="-1.905" layer="21"/>
<rectangle x1="13.589" y1="-2.921" x2="14.351" y2="-1.905" layer="21"/>
</package>
<package name="1X13/90">
<wire x1="-16.51" y1="-1.905" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="0.635" x2="-16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="0.635" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="6.985" x2="-15.24" y2="1.27" width="0.762" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="0.635" x2="13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.985" x2="15.24" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-17.145" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="18.415" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-15.621" y1="0.635" x2="-14.859" y2="1.143" layer="21"/>
<rectangle x1="14.859" y1="0.635" x2="15.621" y2="1.143" layer="21"/>
<rectangle x1="-15.621" y1="-2.921" x2="-14.859" y2="-1.905" layer="21"/>
<rectangle x1="14.859" y1="-2.921" x2="15.621" y2="-1.905" layer="21"/>
</package>
<package name="1X14/90">
<wire x1="-17.78" y1="-1.905" x2="-15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="6.985" x2="-16.51" y2="1.27" width="0.762" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="6.985" x2="16.51" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-18.415" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="19.685" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-16.891" y1="0.635" x2="-16.129" y2="1.143" layer="21"/>
<rectangle x1="16.129" y1="0.635" x2="16.891" y2="1.143" layer="21"/>
<rectangle x1="-16.891" y1="-2.921" x2="-16.129" y2="-1.905" layer="21"/>
<rectangle x1="16.129" y1="-2.921" x2="16.891" y2="-1.905" layer="21"/>
</package>
<package name="1X15/90">
<wire x1="-19.05" y1="-1.905" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-1.905" x2="-16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="0.635" x2="-19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="0.635" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="6.985" x2="-17.78" y2="1.27" width="0.762" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="0.635" x2="16.51" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="6.985" x2="17.78" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-19.685" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="20.955" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-18.161" y1="0.635" x2="-17.399" y2="1.143" layer="21"/>
<rectangle x1="17.399" y1="0.635" x2="18.161" y2="1.143" layer="21"/>
<rectangle x1="-18.161" y1="-2.921" x2="-17.399" y2="-1.905" layer="21"/>
<rectangle x1="17.399" y1="-2.921" x2="18.161" y2="-1.905" layer="21"/>
</package>
<package name="1X16/90">
<wire x1="-20.32" y1="-1.905" x2="-17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="6.985" x2="-19.05" y2="1.27" width="0.762" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="0.635" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="6.985" x2="19.05" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-20.955" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="22.225" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-19.431" y1="0.635" x2="-18.669" y2="1.143" layer="21"/>
<rectangle x1="18.669" y1="0.635" x2="19.431" y2="1.143" layer="21"/>
<rectangle x1="-19.431" y1="-2.921" x2="-18.669" y2="-1.905" layer="21"/>
<rectangle x1="18.669" y1="-2.921" x2="19.431" y2="-1.905" layer="21"/>
</package>
<package name="1X17/90">
<wire x1="-21.59" y1="-1.905" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-1.905" x2="-19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="0.635" x2="-21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="0.635" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="6.985" x2="-20.32" y2="1.27" width="0.762" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="21.59" y1="0.635" x2="19.05" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="6.985" x2="20.32" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-20.32" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="20.32" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-22.225" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="23.495" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-20.701" y1="0.635" x2="-19.939" y2="1.143" layer="21"/>
<rectangle x1="19.939" y1="0.635" x2="20.701" y2="1.143" layer="21"/>
<rectangle x1="-20.701" y1="-2.921" x2="-19.939" y2="-1.905" layer="21"/>
<rectangle x1="19.939" y1="-2.921" x2="20.701" y2="-1.905" layer="21"/>
</package>
<package name="1X18/90">
<wire x1="-22.86" y1="-1.905" x2="-20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="6.985" x2="-21.59" y2="1.27" width="0.762" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="0.635" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="21.59" y1="6.985" x2="21.59" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-23.495" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="24.765" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-21.971" y1="0.635" x2="-21.209" y2="1.143" layer="21"/>
<rectangle x1="21.209" y1="0.635" x2="21.971" y2="1.143" layer="21"/>
<rectangle x1="-21.971" y1="-2.921" x2="-21.209" y2="-1.905" layer="21"/>
<rectangle x1="21.209" y1="-2.921" x2="21.971" y2="-1.905" layer="21"/>
</package>
<package name="1X19/90">
<wire x1="-24.13" y1="-1.905" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-1.905" x2="-21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="0.635" x2="-24.13" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="0.635" x2="-24.13" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="6.985" x2="-22.86" y2="1.27" width="0.762" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="24.13" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-1.905" x2="24.13" y2="0.635" width="0.1524" layer="21"/>
<wire x1="24.13" y1="0.635" x2="21.59" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="6.985" x2="22.86" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-22.86" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-20.32" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="7.62" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="10.16" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="12.7" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="15.24" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="17.78" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="20.32" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="22.86" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-24.765" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="26.035" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-23.241" y1="0.635" x2="-22.479" y2="1.143" layer="21"/>
<rectangle x1="22.479" y1="0.635" x2="23.241" y2="1.143" layer="21"/>
<rectangle x1="-23.241" y1="-2.921" x2="-22.479" y2="-1.905" layer="21"/>
<rectangle x1="22.479" y1="-2.921" x2="23.241" y2="-1.905" layer="21"/>
</package>
<package name="1X20/90">
<wire x1="-25.4" y1="-1.905" x2="-22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="6.985" x2="-24.13" y2="1.27" width="0.762" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="0.635" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="24.13" y1="6.985" x2="24.13" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-26.035" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="27.305" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-24.511" y1="0.635" x2="-23.749" y2="1.143" layer="21"/>
<rectangle x1="23.749" y1="0.635" x2="24.511" y2="1.143" layer="21"/>
<rectangle x1="-24.511" y1="-2.921" x2="-23.749" y2="-1.905" layer="21"/>
<rectangle x1="23.749" y1="-2.921" x2="24.511" y2="-1.905" layer="21"/>
</package>
<package name="2X20/90">
<pad name="2" x="-24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="38" x="21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="37" x="21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="40" x="24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="39" x="24.13" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-24.511" y1="-5.461" x2="-23.749" y2="-4.699" layer="21"/>
<rectangle x1="-24.511" y1="-4.699" x2="-23.749" y2="-2.921" layer="51"/>
<rectangle x1="-21.971" y1="-4.699" x2="-21.209" y2="-2.921" layer="51"/>
<rectangle x1="-21.971" y1="-5.461" x2="-21.209" y2="-4.699" layer="21"/>
<rectangle x1="-19.431" y1="-5.461" x2="-18.669" y2="-4.699" layer="21"/>
<rectangle x1="-19.431" y1="-4.699" x2="-18.669" y2="-2.921" layer="51"/>
<rectangle x1="-16.891" y1="-4.699" x2="-16.129" y2="-2.921" layer="51"/>
<rectangle x1="-16.891" y1="-5.461" x2="-16.129" y2="-4.699" layer="21"/>
<rectangle x1="-14.351" y1="-5.461" x2="-13.589" y2="-4.699" layer="21"/>
<rectangle x1="-14.351" y1="-4.699" x2="-13.589" y2="-2.921" layer="51"/>
<rectangle x1="-11.811" y1="-5.461" x2="-11.049" y2="-4.699" layer="21"/>
<rectangle x1="-11.811" y1="-4.699" x2="-11.049" y2="-2.921" layer="51"/>
<rectangle x1="-9.271" y1="-4.699" x2="-8.509" y2="-2.921" layer="51"/>
<rectangle x1="-9.271" y1="-5.461" x2="-8.509" y2="-4.699" layer="21"/>
<rectangle x1="-6.731" y1="-5.461" x2="-5.969" y2="-4.699" layer="21"/>
<rectangle x1="-6.731" y1="-4.699" x2="-5.969" y2="-2.921" layer="51"/>
<rectangle x1="-4.191" y1="-4.699" x2="-3.429" y2="-2.921" layer="51"/>
<rectangle x1="-4.191" y1="-5.461" x2="-3.429" y2="-4.699" layer="21"/>
<rectangle x1="-1.651" y1="-5.461" x2="-0.889" y2="-4.699" layer="21"/>
<rectangle x1="-1.651" y1="-4.699" x2="-0.889" y2="-2.921" layer="51"/>
<rectangle x1="0.889" y1="-5.461" x2="1.651" y2="-4.699" layer="21"/>
<rectangle x1="0.889" y1="-4.699" x2="1.651" y2="-2.921" layer="51"/>
<rectangle x1="3.429" y1="-4.699" x2="4.191" y2="-2.921" layer="51"/>
<rectangle x1="3.429" y1="-5.461" x2="4.191" y2="-4.699" layer="21"/>
<rectangle x1="5.969" y1="-5.461" x2="6.731" y2="-4.699" layer="21"/>
<rectangle x1="5.969" y1="-4.699" x2="6.731" y2="-2.921" layer="51"/>
<rectangle x1="8.509" y1="-4.699" x2="9.271" y2="-2.921" layer="51"/>
<rectangle x1="8.509" y1="-5.461" x2="9.271" y2="-4.699" layer="21"/>
<rectangle x1="11.049" y1="-5.461" x2="11.811" y2="-4.699" layer="21"/>
<rectangle x1="11.049" y1="-4.699" x2="11.811" y2="-2.921" layer="51"/>
<rectangle x1="13.589" y1="-5.461" x2="14.351" y2="-4.699" layer="21"/>
<rectangle x1="13.589" y1="-4.699" x2="14.351" y2="-2.921" layer="51"/>
<rectangle x1="16.129" y1="-4.699" x2="16.891" y2="-2.921" layer="51"/>
<rectangle x1="16.129" y1="-5.461" x2="16.891" y2="-4.699" layer="21"/>
<rectangle x1="18.669" y1="-5.461" x2="19.431" y2="-4.699" layer="21"/>
<rectangle x1="18.669" y1="-4.699" x2="19.431" y2="-2.921" layer="51"/>
<rectangle x1="21.209" y1="-4.699" x2="21.971" y2="-2.921" layer="51"/>
<rectangle x1="21.209" y1="-5.461" x2="21.971" y2="-4.699" layer="21"/>
<rectangle x1="23.749" y1="-5.461" x2="24.511" y2="-4.699" layer="21"/>
<rectangle x1="23.749" y1="-4.699" x2="24.511" y2="-2.921" layer="51"/>
</package>
<package name="2X02/90">
<pad name="2" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
</package>
<package name="2X03/90">
<pad name="2" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-2.921" y1="-5.461" x2="-2.159" y2="-4.699" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-2.921" layer="51"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-2.921" layer="51"/>
<rectangle x1="-0.381" y1="-5.461" x2="0.381" y2="-4.699" layer="21"/>
<rectangle x1="2.159" y1="-5.461" x2="2.921" y2="-4.699" layer="21"/>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-2.921" layer="51"/>
</package>
<package name="2X04/90">
<pad name="2" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<text x="6.985" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="2X05/90">
<pad name="2" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-5.461" y1="-5.461" x2="-4.699" y2="-4.699" layer="21"/>
<rectangle x1="-5.461" y1="-4.699" x2="-4.699" y2="-2.921" layer="51"/>
<rectangle x1="4.699" y1="-5.461" x2="5.461" y2="-4.699" layer="21"/>
<rectangle x1="4.699" y1="-4.699" x2="5.461" y2="-2.921" layer="51"/>
</package>
<package name="2X06/90">
<pad name="2" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
</package>
<package name="2X07/90">
<pad name="2" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-8.001" y1="-5.461" x2="-7.239" y2="-4.699" layer="21"/>
<rectangle x1="-8.001" y1="-4.699" x2="-7.239" y2="-2.921" layer="51"/>
<rectangle x1="7.239" y1="-5.461" x2="8.001" y2="-4.699" layer="21"/>
<rectangle x1="7.239" y1="-4.699" x2="8.001" y2="-2.921" layer="51"/>
</package>
<package name="2X08/90">
<pad name="2" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
</package>
<package name="2X09/90">
<pad name="2" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-10.541" y1="-5.461" x2="-9.779" y2="-4.699" layer="21"/>
<rectangle x1="-10.541" y1="-4.699" x2="-9.779" y2="-2.921" layer="51"/>
<rectangle x1="9.779" y1="-5.461" x2="10.541" y2="-4.699" layer="21"/>
<rectangle x1="9.779" y1="-4.699" x2="10.541" y2="-2.921" layer="51"/>
</package>
<package name="2X10/90">
<pad name="2" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
</package>
<package name="2X11/90">
<pad name="2" x="-12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="12.7" y="-6.35" drill="1.016" shape="octagon"/>
<text x="15.875" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-13.081" y1="-5.461" x2="-12.319" y2="-4.699" layer="21"/>
<rectangle x1="-13.081" y1="-4.699" x2="-12.319" y2="-2.921" layer="51"/>
<rectangle x1="12.319" y1="-5.461" x2="13.081" y2="-4.699" layer="21"/>
<rectangle x1="12.319" y1="-4.699" x2="13.081" y2="-2.921" layer="51"/>
</package>
<package name="2X12/90">
<pad name="2" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
</package>
<package name="2X13/90">
<pad name="2" x="-15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="15.24" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-15.621" y1="-5.461" x2="-14.859" y2="-4.699" layer="21"/>
<rectangle x1="-15.621" y1="-4.699" x2="-14.859" y2="-2.921" layer="51"/>
<rectangle x1="14.859" y1="-5.461" x2="15.621" y2="-4.699" layer="21"/>
<rectangle x1="14.859" y1="-4.699" x2="15.621" y2="-2.921" layer="51"/>
</package>
<package name="2X14/90">
<pad name="2" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<text x="19.685" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="2X15/90">
<pad name="2" x="-17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-17.78" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="17.78" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-18.161" y1="-5.461" x2="-17.399" y2="-4.699" layer="21"/>
<rectangle x1="-18.161" y1="-4.699" x2="-17.399" y2="-2.921" layer="51"/>
<rectangle x1="17.399" y1="-5.461" x2="18.161" y2="-4.699" layer="21"/>
<rectangle x1="17.399" y1="-4.699" x2="18.161" y2="-2.921" layer="51"/>
</package>
<package name="2X16/90">
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
</package>
<package name="2X17/90">
<wire x1="-6.35" y1="-1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="6.985" x2="-5.08" y2="1.27" width="0.762" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="6.985" x2="-2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="6.985" x2="0" y2="1.27" width="0.762" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="6.985" x2="2.54" y2="1.27" width="0.762" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.985" x2="5.08" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-20.32" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="20.32" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-20.32" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-17.78" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="17.78" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="20.32" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-8.001" y1="0.635" x2="-7.239" y2="1.143" layer="21"/>
<rectangle x1="-5.461" y1="0.635" x2="-4.699" y2="1.143" layer="21"/>
<rectangle x1="-2.921" y1="0.635" x2="-2.159" y2="1.143" layer="21"/>
<rectangle x1="-0.381" y1="0.635" x2="0.381" y2="1.143" layer="21"/>
<rectangle x1="2.159" y1="0.635" x2="2.921" y2="1.143" layer="21"/>
<rectangle x1="4.699" y1="0.635" x2="5.461" y2="1.143" layer="21"/>
<rectangle x1="7.239" y1="0.635" x2="8.001" y2="1.143" layer="21"/>
<rectangle x1="-20.701" y1="-5.461" x2="-19.939" y2="-4.699" layer="21"/>
<rectangle x1="-20.701" y1="-4.699" x2="-19.939" y2="-2.921" layer="51"/>
<rectangle x1="-8.001" y1="-2.921" x2="-7.239" y2="-1.905" layer="21"/>
<rectangle x1="-5.461" y1="-2.921" x2="-4.699" y2="-1.905" layer="21"/>
<rectangle x1="-2.921" y1="-2.921" x2="-2.159" y2="-1.905" layer="21"/>
<rectangle x1="-0.381" y1="-2.921" x2="0.381" y2="-1.905" layer="21"/>
<rectangle x1="2.159" y1="-2.921" x2="2.921" y2="-1.905" layer="21"/>
<rectangle x1="4.699" y1="-2.921" x2="5.461" y2="-1.905" layer="21"/>
<rectangle x1="7.239" y1="-2.921" x2="8.001" y2="-1.905" layer="21"/>
<rectangle x1="19.939" y1="-4.699" x2="20.701" y2="-2.921" layer="51"/>
<rectangle x1="19.939" y1="-5.461" x2="20.701" y2="-4.699" layer="21"/>
</package>
<package name="2X18/90">
<wire x1="-10.16" y1="-1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="6.985" x2="-8.89" y2="1.27" width="0.762" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="6.985" x2="-6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.985" x2="6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="6.985" x2="8.89" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="21.59" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-11.811" y1="0.635" x2="-11.049" y2="1.143" layer="21"/>
<rectangle x1="-9.271" y1="0.635" x2="-8.509" y2="1.143" layer="21"/>
<rectangle x1="-6.731" y1="0.635" x2="-5.969" y2="1.143" layer="21"/>
<rectangle x1="5.969" y1="0.635" x2="6.731" y2="1.143" layer="21"/>
<rectangle x1="8.509" y1="0.635" x2="9.271" y2="1.143" layer="21"/>
<rectangle x1="11.049" y1="0.635" x2="11.811" y2="1.143" layer="21"/>
<rectangle x1="-11.811" y1="-2.921" x2="-11.049" y2="-1.905" layer="21"/>
<rectangle x1="-9.271" y1="-2.921" x2="-8.509" y2="-1.905" layer="21"/>
<rectangle x1="-6.731" y1="-2.921" x2="-5.969" y2="-1.905" layer="21"/>
<rectangle x1="5.969" y1="-2.921" x2="6.731" y2="-1.905" layer="21"/>
<rectangle x1="8.509" y1="-2.921" x2="9.271" y2="-1.905" layer="21"/>
<rectangle x1="11.049" y1="-2.921" x2="11.811" y2="-1.905" layer="21"/>
</package>
<package name="2X19/90">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-13.97" y1="-1.905" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.635" x2="-13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="6.985" x2="-12.7" y2="1.27" width="0.762" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0.635" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="6.985" x2="-10.16" y2="1.27" width="0.762" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.985" x2="-7.62" y2="1.27" width="0.762" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0.635" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.985" x2="7.62" y2="1.27" width="0.762" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0.635" x2="8.89" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="6.985" x2="10.16" y2="1.27" width="0.762" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="13.97" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0.635" x2="11.43" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="6.985" x2="12.7" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-22.86" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-20.32" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="0" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="2.54" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="5.08" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="7.62" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="10.16" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="12.7" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="15.24" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="17.78" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="20.32" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="38" x="22.86" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-22.86" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-20.32" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-17.78" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="0" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="2.54" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="5.08" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="7.62" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="10.16" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="12.7" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="15.24" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="17.78" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="20.32" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="37" x="22.86" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-13.081" y1="0.635" x2="-12.319" y2="1.143" layer="21"/>
<rectangle x1="-10.541" y1="0.635" x2="-9.779" y2="1.143" layer="21"/>
<rectangle x1="9.779" y1="0.635" x2="10.541" y2="1.143" layer="21"/>
<rectangle x1="12.319" y1="0.635" x2="13.081" y2="1.143" layer="21"/>
<rectangle x1="-23.241" y1="-5.461" x2="-22.479" y2="-4.699" layer="21"/>
<rectangle x1="-23.241" y1="-4.699" x2="-22.479" y2="-2.921" layer="51"/>
<rectangle x1="-15.621" y1="-2.921" x2="-14.859" y2="-1.905" layer="21"/>
<rectangle x1="-13.081" y1="-2.921" x2="-12.319" y2="-1.905" layer="21"/>
<rectangle x1="-10.541" y1="-2.921" x2="-9.779" y2="-1.905" layer="21"/>
<rectangle x1="9.779" y1="-2.921" x2="10.541" y2="-1.905" layer="21"/>
<rectangle x1="12.319" y1="-2.921" x2="13.081" y2="-1.905" layer="21"/>
<rectangle x1="14.859" y1="-2.921" x2="15.621" y2="-1.905" layer="21"/>
<rectangle x1="22.479" y1="-4.699" x2="23.241" y2="-2.921" layer="51"/>
<rectangle x1="22.479" y1="-5.461" x2="23.241" y2="-4.699" layer="21"/>
</package>
<package name="2X25">
<wire x1="-31.75" y1="-1.905" x2="-31.115" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="-2.54" x2="-29.845" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="-2.54" x2="-29.21" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-29.21" y1="-1.905" x2="-28.575" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="-2.54" x2="-27.305" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="-2.54" x2="-26.67" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-26.67" y1="-1.905" x2="-26.035" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="-2.54" x2="-24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="-2.54" x2="-24.13" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="-1.905" x2="-23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-2.54" x2="-22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-2.54" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-1.905" x2="-20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-2.54" x2="-19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-2.54" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-1.905" x2="-18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-2.54" x2="-17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-2.54" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-31.75" y1="-1.905" x2="-31.75" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-31.75" y1="1.905" x2="-31.115" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="2.54" x2="-29.845" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="2.54" x2="-29.21" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-29.21" y1="1.905" x2="-28.575" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="2.54" x2="-27.305" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="2.54" x2="-26.67" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-26.67" y1="1.905" x2="-26.035" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="2.54" x2="-24.765" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="2.54" x2="-24.13" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="1.905" x2="-23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="2.54" x2="-22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="2.54" x2="-21.59" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="1.905" x2="-20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="2.54" x2="-19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="2.54" x2="-19.05" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="1.905" x2="-18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="2.54" x2="-17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="2.54" x2="-16.51" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="1.905" x2="-15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="2.54" x2="-14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.54" x2="-13.97" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="2.54" x2="-12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.89" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.35" y2="1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="8.89" y2="1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="1.905" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.97" y2="1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="1.905" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="2.54" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="2.54" x2="16.51" y2="1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-1.905" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.905" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-1.905" x2="-14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-1.905" x2="-15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-29.21" y1="1.905" x2="-29.21" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-26.67" y1="1.905" x2="-26.67" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="1.905" x2="-24.13" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="1.905" x2="-21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="1.905" x2="-19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="1.905" x2="-16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.905" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.905" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.905" x2="-6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="6.35" y1="1.905" x2="6.35" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.89" y1="1.905" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="13.97" y1="1.905" x2="13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="1.905" x2="16.51" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="16.51" y1="1.905" x2="17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="2.54" x2="17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="2.54" x2="19.05" y2="1.905" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-1.905" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.05" y1="1.905" x2="19.05" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="21.59" y1="1.905" x2="21.59" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="24.13" y1="1.905" x2="24.13" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="26.67" y1="1.905" x2="26.67" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="29.21" y1="1.905" x2="29.21" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-2.54" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-2.54" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="26.035" y1="-2.54" x2="24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="28.575" y1="-2.54" x2="27.305" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="31.115" y1="-2.54" x2="29.845" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="2.54" x2="19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="2.54" x2="22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="26.035" y1="2.54" x2="24.765" y2="2.54" width="0.1524" layer="21"/>
<wire x1="28.575" y1="2.54" x2="27.305" y2="2.54" width="0.1524" layer="21"/>
<wire x1="31.115" y1="2.54" x2="29.845" y2="2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="2.54" x2="21.59" y2="1.905" width="0.1524" layer="21"/>
<wire x1="23.495" y1="2.54" x2="24.13" y2="1.905" width="0.1524" layer="21"/>
<wire x1="26.035" y1="2.54" x2="26.67" y2="1.905" width="0.1524" layer="21"/>
<wire x1="28.575" y1="2.54" x2="29.21" y2="1.905" width="0.1524" layer="21"/>
<wire x1="31.115" y1="2.54" x2="31.75" y2="1.905" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-1.905" x2="23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="26.67" y1="-1.905" x2="26.035" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="29.21" y1="-1.905" x2="28.575" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="31.75" y1="-1.905" x2="31.115" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-1.905" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="21.59" y1="-1.905" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="24.13" y1="-1.905" x2="24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="26.67" y1="-1.905" x2="27.305" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="29.21" y1="-1.905" x2="29.845" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.05" y1="1.905" x2="19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="21.59" y1="1.905" x2="22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="24.13" y1="1.905" x2="24.765" y2="2.54" width="0.1524" layer="21"/>
<wire x1="26.67" y1="1.905" x2="27.305" y2="2.54" width="0.1524" layer="21"/>
<wire x1="29.21" y1="1.905" x2="29.845" y2="2.54" width="0.1524" layer="21"/>
<wire x1="31.75" y1="1.905" x2="31.75" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-30.48" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-30.48" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="40" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="42" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="41" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="43" x="22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="45" x="25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="47" x="27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="48" x="27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="46" x="25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="44" x="22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="50" x="30.48" y="1.27" drill="1.016" shape="octagon"/>
<pad name="49" x="30.48" y="-1.27" drill="1.016" shape="octagon"/>
<text x="-31.75" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-31.75" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-30.734" y1="-1.524" x2="-30.226" y2="-1.016" layer="51"/>
<rectangle x1="-30.734" y1="1.016" x2="-30.226" y2="1.524" layer="51"/>
<rectangle x1="-28.194" y1="1.016" x2="-27.686" y2="1.524" layer="51"/>
<rectangle x1="-28.194" y1="-1.524" x2="-27.686" y2="-1.016" layer="51"/>
<rectangle x1="-25.654" y1="1.016" x2="-25.146" y2="1.524" layer="51"/>
<rectangle x1="-25.654" y1="-1.524" x2="-25.146" y2="-1.016" layer="51"/>
<rectangle x1="-23.114" y1="1.016" x2="-22.606" y2="1.524" layer="51"/>
<rectangle x1="-20.574" y1="1.016" x2="-20.066" y2="1.524" layer="51"/>
<rectangle x1="-18.034" y1="1.016" x2="-17.526" y2="1.524" layer="51"/>
<rectangle x1="-23.114" y1="-1.524" x2="-22.606" y2="-1.016" layer="51"/>
<rectangle x1="-20.574" y1="-1.524" x2="-20.066" y2="-1.016" layer="51"/>
<rectangle x1="-18.034" y1="-1.524" x2="-17.526" y2="-1.016" layer="51"/>
<rectangle x1="-15.494" y1="1.016" x2="-14.986" y2="1.524" layer="51"/>
<rectangle x1="-15.494" y1="-1.524" x2="-14.986" y2="-1.016" layer="51"/>
<rectangle x1="-12.954" y1="1.016" x2="-12.446" y2="1.524" layer="51"/>
<rectangle x1="-12.954" y1="-1.524" x2="-12.446" y2="-1.016" layer="51"/>
<rectangle x1="-10.414" y1="1.016" x2="-9.906" y2="1.524" layer="51"/>
<rectangle x1="-10.414" y1="-1.524" x2="-9.906" y2="-1.016" layer="51"/>
<rectangle x1="-7.874" y1="1.016" x2="-7.366" y2="1.524" layer="51"/>
<rectangle x1="-7.874" y1="-1.524" x2="-7.366" y2="-1.016" layer="51"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="51"/>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="51"/>
<rectangle x1="7.366" y1="1.016" x2="7.874" y2="1.524" layer="51"/>
<rectangle x1="7.366" y1="-1.524" x2="7.874" y2="-1.016" layer="51"/>
<rectangle x1="9.906" y1="1.016" x2="10.414" y2="1.524" layer="51"/>
<rectangle x1="9.906" y1="-1.524" x2="10.414" y2="-1.016" layer="51"/>
<rectangle x1="12.446" y1="1.016" x2="12.954" y2="1.524" layer="51"/>
<rectangle x1="12.446" y1="-1.524" x2="12.954" y2="-1.016" layer="51"/>
<rectangle x1="14.986" y1="1.016" x2="15.494" y2="1.524" layer="51"/>
<rectangle x1="14.986" y1="-1.524" x2="15.494" y2="-1.016" layer="51"/>
<rectangle x1="17.526" y1="1.016" x2="18.034" y2="1.524" layer="51"/>
<rectangle x1="17.526" y1="-1.524" x2="18.034" y2="-1.016" layer="51"/>
<rectangle x1="20.066" y1="1.016" x2="20.574" y2="1.524" layer="51"/>
<rectangle x1="22.606" y1="1.016" x2="23.114" y2="1.524" layer="51"/>
<rectangle x1="25.146" y1="1.016" x2="25.654" y2="1.524" layer="51"/>
<rectangle x1="27.686" y1="1.016" x2="28.194" y2="1.524" layer="51"/>
<rectangle x1="30.226" y1="1.016" x2="30.734" y2="1.524" layer="51"/>
<rectangle x1="30.226" y1="-1.524" x2="30.734" y2="-1.016" layer="51"/>
<rectangle x1="27.686" y1="-1.524" x2="28.194" y2="-1.016" layer="51"/>
<rectangle x1="25.146" y1="-1.524" x2="25.654" y2="-1.016" layer="51"/>
<rectangle x1="22.606" y1="-1.524" x2="23.114" y2="-1.016" layer="51"/>
<rectangle x1="20.066" y1="-1.524" x2="20.574" y2="-1.016" layer="51"/>
</package>
<package name="1X22">
<wire x1="18.415" y1="1.27" x2="19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="0.635" x2="20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="1.27" x2="17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="1.27" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="18.415" y1="1.27" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="0.635" x2="12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.7" y1="0.635" x2="13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.27" x2="-15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-1.27" x2="-22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-26.035" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="1.27" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-26.035" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-24.765" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-23.495" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-1.27" x2="-24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="-1.27" x2="-25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.94" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="-0.635" x2="-27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="-1.27" x2="-27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.765" y2="1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="1.27" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="0.635" x2="25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.86" y1="0.635" x2="22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="26.035" y1="1.27" x2="27.305" y2="1.27" width="0.1524" layer="21"/>
<wire x1="27.305" y1="1.27" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="0.635" x2="27.94" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="26.035" y1="1.27" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="26.035" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.035" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-28.0162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-27.94" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="-16.764" y1="-0.254" x2="-16.256" y2="0.254" layer="51"/>
<rectangle x1="-19.304" y1="-0.254" x2="-18.796" y2="0.254" layer="51"/>
<rectangle x1="-21.844" y1="-0.254" x2="-21.336" y2="0.254" layer="51"/>
<rectangle x1="-24.384" y1="-0.254" x2="-23.876" y2="0.254" layer="51"/>
<rectangle x1="-26.924" y1="-0.254" x2="-26.416" y2="0.254" layer="51"/>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
<rectangle x1="26.416" y1="-0.254" x2="26.924" y2="0.254" layer="51"/>
</package>
<package name="1X24">
<wire x1="15.875" y1="1.27" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.27" x2="-12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="1.27" x2="-28.575" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="1.27" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="-0.635" x2="-28.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.305" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="-1.27" x2="-27.94" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="0.635" x2="-30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="1.27" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-0.635" x2="-29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="-1.27" x2="-29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="28.575" y1="1.27" x2="29.845" y2="1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="1.27" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="0.635" x2="30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="28.575" y1="1.27" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="28.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="28.575" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-30.5562" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-30.48" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-29.464" y1="-0.254" x2="-28.956" y2="0.254" layer="51"/>
<rectangle x1="28.956" y1="-0.254" x2="29.464" y2="0.254" layer="51"/>
</package>
<package name="1X25">
<wire x1="31.115" y1="1.27" x2="32.385" y2="1.27" width="0.1524" layer="21"/>
<wire x1="32.385" y1="1.27" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="0.635" x2="33.02" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="32.385" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="31.115" y1="1.27" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="31.115" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="32.385" y1="-1.27" x2="31.115" y2="-1.27" width="0.1524" layer="21"/>
<pad name="25" x="31.75" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="31.496" y1="-0.254" x2="32.004" y2="0.254" layer="51"/>
</package>
<package name="1X30">
<wire x1="-33.02" y1="0.635" x2="-32.385" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="1.27" x2="-31.115" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="1.27" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-0.635" x2="-31.115" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="-1.27" x2="-32.385" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="-1.27" x2="-33.02" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="1.27" x2="-36.195" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="1.27" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="0.635" x2="-35.56" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="-0.635" x2="-36.195" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="0.635" x2="-34.925" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="1.27" x2="-33.655" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="1.27" x2="-33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="0.635" x2="-33.02" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="-0.635" x2="-33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="-1.27" x2="-34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="-1.27" x2="-35.56" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="0.635" x2="-38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="1.27" x2="-38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="-0.635" x2="-37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="-1.27" x2="-37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="1.27" x2="34.925" y2="1.27" width="0.1524" layer="21"/>
<wire x1="34.925" y1="1.27" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-0.635" x2="34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="1.27" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="34.925" y1="-1.27" x2="33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="35.56" y1="0.635" x2="35.56" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="36.195" y1="1.27" x2="37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="37.465" y1="1.27" x2="38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="0.635" x2="38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="-0.635" x2="37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="36.195" y1="1.27" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-0.635" x2="36.195" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="37.465" y1="-1.27" x2="36.195" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-36.83" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-34.29" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-31.75" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="-6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="6.35" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="8.89" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="11.43" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="13.97" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="16.51" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="21.59" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="25" x="24.13" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="26" x="26.67" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="27" x="29.21" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="28" x="31.75" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="29" x="34.29" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="30" x="36.83" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-38.1762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-38.1" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-32.004" y1="-0.254" x2="-31.496" y2="0.254" layer="51"/>
<rectangle x1="-34.544" y1="-0.254" x2="-34.036" y2="0.254" layer="51"/>
<rectangle x1="-37.084" y1="-0.254" x2="-36.576" y2="0.254" layer="51"/>
<rectangle x1="34.036" y1="-0.254" x2="34.544" y2="0.254" layer="51"/>
<rectangle x1="36.576" y1="-0.254" x2="37.084" y2="0.254" layer="51"/>
</package>
<package name="2X22">
<wire x1="-15.875" y1="-2.54" x2="-14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-13.97" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-26.67" y1="-1.905" x2="-26.67" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="8.89" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="40" x="22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="41" x="25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="42" x="25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="43" x="27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="44" x="27.94" y="1.27" drill="1.016" shape="octagon"/>
<text x="-26.67" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-26.67" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X24">
<wire x1="-29.21" y1="-1.905" x2="-29.21" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="40" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="41" x="22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="42" x="22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="43" x="25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="44" x="25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="45" x="27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="46" x="27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="47" x="30.48" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="48" x="30.48" y="1.27" drill="1.016" shape="octagon"/>
<text x="-29.21" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-29.21" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2X30">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-39.37" y1="-1.905" x2="-38.735" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="-2.54" x2="-37.465" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="-2.54" x2="-36.83" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-36.83" y1="-1.905" x2="-36.195" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="-2.54" x2="-34.925" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="-2.54" x2="-34.29" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-34.29" y1="-1.905" x2="-33.655" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="-2.54" x2="-32.385" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="-2.54" x2="-31.75" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-39.37" y1="-1.905" x2="-39.37" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-39.37" y1="1.905" x2="-38.735" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="2.54" x2="-37.465" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="2.54" x2="-36.83" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-36.83" y1="1.905" x2="-36.195" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="2.54" x2="-34.925" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="2.54" x2="-34.29" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-34.29" y1="1.905" x2="-33.655" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="2.54" x2="-32.385" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="2.54" x2="-31.75" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-1.905" x2="-17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-2.54" x2="-18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-1.905" x2="-19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-2.54" x2="-20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-1.905" x2="-22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-2.54" x2="-23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-36.83" y1="1.905" x2="-36.83" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-34.29" y1="1.905" x2="-34.29" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-31.75" y1="1.905" x2="-31.75" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="31.75" y1="1.905" x2="32.385" y2="2.54" width="0.1524" layer="21"/>
<wire x1="33.655" y1="2.54" x2="32.385" y2="2.54" width="0.1524" layer="21"/>
<wire x1="33.655" y1="2.54" x2="34.29" y2="1.905" width="0.1524" layer="21"/>
<wire x1="34.29" y1="-1.905" x2="33.655" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="33.655" y1="-2.54" x2="32.385" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="31.75" y1="-1.905" x2="32.385" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="34.29" y1="1.905" x2="34.29" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="34.29" y1="1.905" x2="34.925" y2="2.54" width="0.1524" layer="21"/>
<wire x1="36.195" y1="2.54" x2="34.925" y2="2.54" width="0.1524" layer="21"/>
<wire x1="36.195" y1="2.54" x2="36.83" y2="1.905" width="0.1524" layer="21"/>
<wire x1="36.83" y1="-1.905" x2="36.195" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="36.195" y1="-2.54" x2="34.925" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="34.29" y1="-1.905" x2="34.925" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="36.83" y1="1.905" x2="36.83" y2="-1.905" width="0.1524" layer="21"/>
<pad name="1" x="-38.1" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-38.1" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-35.56" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-35.56" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-33.02" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-33.02" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="-30.48" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="-30.48" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="-27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="-27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="-25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="-25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="-22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="-15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="-12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="-12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="-10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="-10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="-7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="26" x="-7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="27" x="-5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="28" x="-5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="29" x="-2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="30" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="31" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="32" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="33" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="34" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="35" x="5.08" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="36" x="5.08" y="1.27" drill="1.016" shape="octagon"/>
<pad name="37" x="7.62" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="38" x="7.62" y="1.27" drill="1.016" shape="octagon"/>
<pad name="39" x="10.16" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="40" x="10.16" y="1.27" drill="1.016" shape="octagon"/>
<pad name="41" x="12.7" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="42" x="12.7" y="1.27" drill="1.016" shape="octagon"/>
<pad name="43" x="15.24" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="44" x="15.24" y="1.27" drill="1.016" shape="octagon"/>
<pad name="45" x="17.78" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="46" x="17.78" y="1.27" drill="1.016" shape="octagon"/>
<pad name="47" x="20.32" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="48" x="20.32" y="1.27" drill="1.016" shape="octagon"/>
<pad name="49" x="22.86" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="50" x="22.86" y="1.27" drill="1.016" shape="octagon"/>
<pad name="51" x="25.4" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="52" x="25.4" y="1.27" drill="1.016" shape="octagon"/>
<pad name="53" x="27.94" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="54" x="27.94" y="1.27" drill="1.016" shape="octagon"/>
<pad name="55" x="30.48" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="56" x="30.48" y="1.27" drill="1.016" shape="octagon"/>
<pad name="57" x="33.02" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="58" x="33.02" y="1.27" drill="1.016" shape="octagon"/>
<pad name="59" x="35.56" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="60" x="35.56" y="1.27" drill="1.016" shape="octagon"/>
<text x="-39.37" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-39.37" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-38.354" y1="-1.524" x2="-37.846" y2="-1.016" layer="51"/>
<rectangle x1="-38.354" y1="1.016" x2="-37.846" y2="1.524" layer="51"/>
<rectangle x1="-35.814" y1="1.016" x2="-35.306" y2="1.524" layer="51"/>
<rectangle x1="-35.814" y1="-1.524" x2="-35.306" y2="-1.016" layer="51"/>
<rectangle x1="-33.274" y1="1.016" x2="-32.766" y2="1.524" layer="51"/>
<rectangle x1="-33.274" y1="-1.524" x2="-32.766" y2="-1.016" layer="51"/>
<rectangle x1="32.766" y1="1.016" x2="33.274" y2="1.524" layer="51"/>
<rectangle x1="32.766" y1="-1.524" x2="33.274" y2="-1.016" layer="51"/>
<rectangle x1="35.306" y1="1.016" x2="35.814" y2="1.524" layer="51"/>
<rectangle x1="35.306" y1="-1.524" x2="35.814" y2="-1.016" layer="51"/>
</package>
<package name="57102-F08-25">
<description>&lt;b&gt;UNSH HEADER&lt;/b&gt; 2.0mm VERTICAL TMT&lt;p&gt;
Source: https://portal.fciconnect.com/res/en/pdffiles/doc_search/57102.pdf</description>
<wire x1="-10" y1="2" x2="40" y2="2" width="0.2032" layer="21"/>
<wire x1="40" y1="2" x2="40" y2="-2" width="0.2032" layer="21"/>
<wire x1="40" y1="-2" x2="-10" y2="-2" width="0.2032" layer="21"/>
<wire x1="-10" y1="-2" x2="-10" y2="2" width="0.2032" layer="21"/>
<pad name="1" x="-9" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-9" y="1" drill="0.8" diameter="1.4224"/>
<pad name="3" x="-7" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="4" x="-7" y="1" drill="0.8" diameter="1.4224"/>
<pad name="5" x="-5" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="6" x="-5" y="1" drill="0.8" diameter="1.4224"/>
<pad name="7" x="-3" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="8" x="-3" y="1" drill="0.8" diameter="1.4224"/>
<pad name="9" x="-1" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="10" x="-1" y="1" drill="0.8" diameter="1.4224"/>
<pad name="11" x="1" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="12" x="1" y="1" drill="0.8" diameter="1.4224"/>
<pad name="13" x="3" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="14" x="3" y="1" drill="0.8" diameter="1.4224"/>
<pad name="15" x="5" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="16" x="5" y="1" drill="0.8" diameter="1.4224"/>
<pad name="17" x="7" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="18" x="7" y="1" drill="0.8" diameter="1.4224"/>
<pad name="19" x="9" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="20" x="9" y="1" drill="0.8" diameter="1.4224"/>
<pad name="21" x="11" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="22" x="11" y="1" drill="0.8" diameter="1.4224"/>
<pad name="23" x="13" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="24" x="13" y="1" drill="0.8" diameter="1.4224"/>
<pad name="25" x="15" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="26" x="15" y="1" drill="0.8" diameter="1.4224"/>
<pad name="27" x="17" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="28" x="17" y="1" drill="0.8" diameter="1.4224"/>
<pad name="29" x="19" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="30" x="19" y="1" drill="0.8" diameter="1.4224"/>
<pad name="31" x="21" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="32" x="21" y="1" drill="0.8" diameter="1.4224"/>
<pad name="33" x="23" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="34" x="23" y="1" drill="0.8" diameter="1.4224"/>
<pad name="35" x="25" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="36" x="25" y="1" drill="0.8" diameter="1.4224"/>
<pad name="37" x="27" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="38" x="27" y="1" drill="0.8" diameter="1.4224"/>
<pad name="39" x="29" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="40" x="29" y="1" drill="0.8" diameter="1.4224"/>
<pad name="41" x="31" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="42" x="31" y="1" drill="0.8" diameter="1.4224"/>
<pad name="43" x="33" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="44" x="33" y="1" drill="0.8" diameter="1.4224"/>
<pad name="45" x="35" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="46" x="35" y="1" drill="0.8" diameter="1.4224"/>
<pad name="47" x="37" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="48" x="37" y="1" drill="0.8" diameter="1.4224"/>
<pad name="49" x="39" y="-1" drill="0.8" diameter="1.4224"/>
<pad name="50" x="39" y="1" drill="0.8" diameter="1.4224"/>
<text x="-8.89" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.89" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="2802S-02G2">
<description>&lt;b&gt;2mm Center - .020 inch Square Pin - Single Row Straight Header&lt;/b&gt;&lt;p&gt;
Source: http://www.commcon.com/main</description>
<wire x1="-25" y1="1" x2="25" y2="1" width="0.2032" layer="21"/>
<wire x1="25" y1="1" x2="25" y2="-1" width="0.2032" layer="21"/>
<wire x1="25" y1="-1" x2="-25" y2="-1" width="0.2032" layer="21"/>
<wire x1="-25" y1="-1" x2="-25" y2="1" width="0.2032" layer="21"/>
<pad name="1" x="-24" y="0" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-22" y="0" drill="0.8" diameter="1.4224"/>
<pad name="3" x="-20" y="0" drill="0.8" diameter="1.4224"/>
<pad name="4" x="-18" y="0" drill="0.8" diameter="1.4224"/>
<pad name="5" x="-16" y="0" drill="0.8" diameter="1.4224"/>
<pad name="6" x="-14" y="0" drill="0.8" diameter="1.4224"/>
<pad name="7" x="-12" y="0" drill="0.8" diameter="1.4224"/>
<pad name="8" x="-10" y="0" drill="0.8" diameter="1.4224"/>
<pad name="9" x="-8" y="0" drill="0.8" diameter="1.4224"/>
<pad name="10" x="-6" y="0" drill="0.8" diameter="1.4224"/>
<pad name="11" x="-4" y="0" drill="0.8" diameter="1.4224"/>
<pad name="12" x="-2" y="0" drill="0.8" diameter="1.4224"/>
<pad name="13" x="0" y="0" drill="0.8" diameter="1.4224"/>
<pad name="14" x="2" y="0" drill="0.8" diameter="1.4224"/>
<pad name="15" x="4" y="0" drill="0.8" diameter="1.4224"/>
<pad name="16" x="6" y="0" drill="0.8" diameter="1.4224"/>
<pad name="17" x="8" y="0" drill="0.8" diameter="1.4224"/>
<pad name="18" x="10" y="0" drill="0.8" diameter="1.4224"/>
<pad name="19" x="12" y="0" drill="0.8" diameter="1.4224"/>
<pad name="20" x="14" y="0" drill="0.8" diameter="1.4224"/>
<pad name="21" x="16" y="0" drill="0.8" diameter="1.4224"/>
<pad name="22" x="18" y="0" drill="0.8" diameter="1.4224"/>
<pad name="23" x="20" y="0" drill="0.8" diameter="1.4224"/>
<pad name="24" x="22" y="0" drill="0.8" diameter="1.4224"/>
<pad name="25" x="24" y="0" drill="0.8" diameter="1.4224"/>
<text x="-24.13" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-24.13" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X40">
<description>&lt;b&gt;PIN HEADER 40 pol.&lt;/b&gt; Grid 2.54mm&lt;p&gt;</description>
<wire x1="-30.48" y1="0.635" x2="-29.845" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="-1.27" x2="-30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="0.635" x2="-37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="-1.27" x2="-38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="1.27" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="-0.635" x2="-34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-42.545" y1="1.27" x2="-41.275" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="1.27" x2="-40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="-0.635" x2="-41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="0.635" x2="-40.005" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-40.005" y1="1.27" x2="-38.735" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="1.27" x2="-38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="-0.635" x2="-38.735" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="-1.27" x2="-40.005" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-40.005" y1="-1.27" x2="-40.64" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-45.72" y1="0.635" x2="-45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-45.085" y1="1.27" x2="-43.815" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="1.27" x2="-43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-43.18" y1="-0.635" x2="-43.815" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="-1.27" x2="-45.085" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-45.085" y1="-1.27" x2="-45.72" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-42.545" y1="1.27" x2="-43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-43.18" y1="-0.635" x2="-42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="-1.27" x2="-42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-50.165" y1="1.27" x2="-48.895" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-48.895" y1="1.27" x2="-48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-48.26" y1="-0.635" x2="-48.895" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-48.26" y1="0.635" x2="-47.625" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-47.625" y1="1.27" x2="-46.355" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-46.355" y1="1.27" x2="-45.72" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-45.72" y1="-0.635" x2="-46.355" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-46.355" y1="-1.27" x2="-47.625" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-47.625" y1="-1.27" x2="-48.26" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-50.8" y1="0.635" x2="-50.8" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-50.165" y1="1.27" x2="-50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-50.8" y1="-0.635" x2="-50.165" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-48.895" y1="-1.27" x2="-50.165" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="48.895" y1="1.27" x2="50.165" y2="1.27" width="0.1524" layer="21"/>
<wire x1="45.72" y1="0.635" x2="46.355" y2="1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="1.27" x2="47.625" y2="1.27" width="0.1524" layer="21"/>
<wire x1="47.625" y1="1.27" x2="48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-0.635" x2="47.625" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="47.625" y1="-1.27" x2="46.355" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="-1.27" x2="45.72" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="48.895" y1="1.27" x2="48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-0.635" x2="48.895" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="50.165" y1="-1.27" x2="48.895" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="41.275" y1="1.27" x2="42.545" y2="1.27" width="0.1524" layer="21"/>
<wire x1="42.545" y1="1.27" x2="43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="43.18" y1="-0.635" x2="42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="43.18" y1="0.635" x2="43.815" y2="1.27" width="0.1524" layer="21"/>
<wire x1="43.815" y1="1.27" x2="45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="45.085" y1="1.27" x2="45.72" y2="0.635" width="0.1524" layer="21"/>
<wire x1="45.72" y1="-0.635" x2="45.085" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="45.085" y1="-1.27" x2="43.815" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="43.815" y1="-1.27" x2="43.18" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="0.635" x2="38.735" y2="1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="1.27" x2="40.005" y2="1.27" width="0.1524" layer="21"/>
<wire x1="40.005" y1="1.27" x2="40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="40.64" y1="-0.635" x2="40.005" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="40.005" y1="-1.27" x2="38.735" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="-1.27" x2="38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="41.275" y1="1.27" x2="40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="40.64" y1="-0.635" x2="41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="42.545" y1="-1.27" x2="41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="35.56" y1="0.635" x2="36.195" y2="1.27" width="0.1524" layer="21"/>
<wire x1="36.195" y1="-1.27" x2="35.56" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="0.635" x2="31.115" y2="1.27" width="0.1524" layer="21"/>
<wire x1="31.115" y1="-1.27" x2="30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="0.635" x2="28.575" y2="1.27" width="0.1524" layer="21"/>
<wire x1="28.575" y1="-1.27" x2="27.94" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-49.53" y="0" drill="1.016" rot="R90"/>
<pad name="2" x="-46.99" y="0" drill="1.016" rot="R90"/>
<pad name="3" x="-44.45" y="0" drill="1.016" rot="R90"/>
<pad name="4" x="-41.91" y="0" drill="1.016" rot="R90"/>
<pad name="5" x="-39.37" y="0" drill="1.016" rot="R90"/>
<pad name="6" x="-36.83" y="0" drill="1.016" rot="R90"/>
<pad name="7" x="-34.29" y="0" drill="1.016" rot="R90"/>
<pad name="8" x="-31.75" y="0" drill="1.016" rot="R90"/>
<pad name="9" x="-29.21" y="0" drill="1.016" rot="R90"/>
<pad name="10" x="-26.67" y="0" drill="1.016" rot="R90"/>
<pad name="11" x="-24.13" y="0" drill="1.016" rot="R90"/>
<pad name="12" x="-21.59" y="0" drill="1.016" rot="R90"/>
<pad name="13" x="-19.05" y="0" drill="1.016" rot="R90"/>
<pad name="14" x="-16.51" y="0" drill="1.016" rot="R90"/>
<pad name="15" x="-13.97" y="0" drill="1.016" rot="R90"/>
<pad name="16" x="-11.43" y="0" drill="1.016" rot="R90"/>
<pad name="17" x="-8.89" y="0" drill="1.016" rot="R90"/>
<pad name="18" x="-6.35" y="0" drill="1.016" rot="R90"/>
<pad name="19" x="-3.81" y="0" drill="1.016" rot="R90"/>
<pad name="20" x="-1.27" y="0" drill="1.016" rot="R90"/>
<pad name="21" x="1.27" y="0" drill="1.016" rot="R90"/>
<pad name="22" x="3.81" y="0" drill="1.016" rot="R90"/>
<pad name="23" x="6.35" y="0" drill="1.016" rot="R90"/>
<pad name="24" x="8.89" y="0" drill="1.016" rot="R90"/>
<pad name="25" x="11.43" y="0" drill="1.016" rot="R90"/>
<pad name="26" x="13.97" y="0" drill="1.016" rot="R90"/>
<pad name="27" x="16.51" y="0" drill="1.016" rot="R90"/>
<pad name="28" x="19.05" y="0" drill="1.016" rot="R90"/>
<pad name="29" x="21.59" y="0" drill="1.016" rot="R90"/>
<pad name="30" x="24.13" y="0" drill="1.016" rot="R90"/>
<pad name="31" x="26.67" y="0" drill="1.016" rot="R90"/>
<pad name="32" x="29.21" y="0" drill="1.016" rot="R90"/>
<pad name="33" x="31.75" y="0" drill="1.016" rot="R90"/>
<pad name="34" x="34.29" y="0" drill="1.016" rot="R90"/>
<pad name="35" x="36.83" y="0" drill="1.016" rot="R90"/>
<pad name="36" x="39.37" y="0" drill="1.016" rot="R90"/>
<pad name="37" x="41.91" y="0" drill="1.016" rot="R90"/>
<pad name="38" x="44.45" y="0" drill="1.016" rot="R90"/>
<pad name="39" x="46.99" y="0" drill="1.016" rot="R90"/>
<pad name="40" x="49.53" y="0" drill="1.016" rot="R90"/>
<text x="-50.8762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-50.8" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-39.624" y1="-0.254" x2="-39.116" y2="0.254" layer="51"/>
<rectangle x1="-42.164" y1="-0.254" x2="-41.656" y2="0.254" layer="51"/>
<rectangle x1="-44.704" y1="-0.254" x2="-44.196" y2="0.254" layer="51"/>
<rectangle x1="-47.244" y1="-0.254" x2="-46.736" y2="0.254" layer="51"/>
<rectangle x1="-49.784" y1="-0.254" x2="-49.276" y2="0.254" layer="51"/>
<rectangle x1="49.276" y1="-0.254" x2="49.784" y2="0.254" layer="51"/>
<rectangle x1="46.736" y1="-0.254" x2="47.244" y2="0.254" layer="51"/>
<rectangle x1="44.196" y1="-0.254" x2="44.704" y2="0.254" layer="51"/>
<rectangle x1="41.656" y1="-0.254" x2="42.164" y2="0.254" layer="51"/>
<rectangle x1="39.116" y1="-0.254" x2="39.624" y2="0.254" layer="51"/>
<wire x1="50.8" y1="0.635" x2="50.8" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="50.165" y1="1.27" x2="50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="50.8" y1="-0.635" x2="50.165" y2="-1.27" width="0.1524" layer="21"/>
</package>
<package name="1X22/90">
<wire x1="-27.94" y1="-1.905" x2="-25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-1.905" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.94" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-26.67" y1="6.985" x2="-26.67" y2="1.27" width="0.762" layer="21"/>
<wire x1="-25.4" y1="-1.905" x2="-22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-24.13" y1="6.985" x2="-24.13" y2="1.27" width="0.762" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="6.985" x2="-21.59" y2="1.27" width="0.762" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="6.985" x2="-19.05" y2="1.27" width="0.762" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="6.985" x2="-16.51" y2="1.27" width="0.762" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="6.985" x2="-13.97" y2="1.27" width="0.762" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="6.985" x2="-11.43" y2="1.27" width="0.762" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="6.985" x2="-8.89" y2="1.27" width="0.762" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="6.985" x2="-6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.985" x2="-3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.985" x2="3.81" y2="1.27" width="0.762" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.985" x2="6.35" y2="1.27" width="0.762" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0.635" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="6.985" x2="8.89" y2="1.27" width="0.762" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="0.635" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="6.985" x2="11.43" y2="1.27" width="0.762" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="6.985" x2="13.97" y2="1.27" width="0.762" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="6.985" x2="16.51" y2="1.27" width="0.762" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="0.635" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="6.985" x2="19.05" y2="1.27" width="0.762" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="0.635" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="21.59" y1="6.985" x2="21.59" y2="1.27" width="0.762" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="0.635" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="24.13" y1="6.985" x2="24.13" y2="1.27" width="0.762" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="27.94" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-1.905" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="0.635" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="26.67" y1="6.985" x2="26.67" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-26.67" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="26.67" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-28.575" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="29.845" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-27.051" y1="0.635" x2="-26.289" y2="1.143" layer="21"/>
<rectangle x1="-24.511" y1="0.635" x2="-23.749" y2="1.143" layer="21"/>
<rectangle x1="-21.971" y1="0.635" x2="-21.209" y2="1.143" layer="21"/>
<rectangle x1="-19.431" y1="0.635" x2="-18.669" y2="1.143" layer="21"/>
<rectangle x1="-16.891" y1="0.635" x2="-16.129" y2="1.143" layer="21"/>
<rectangle x1="-14.351" y1="0.635" x2="-13.589" y2="1.143" layer="21"/>
<rectangle x1="-11.811" y1="0.635" x2="-11.049" y2="1.143" layer="21"/>
<rectangle x1="-9.271" y1="0.635" x2="-8.509" y2="1.143" layer="21"/>
<rectangle x1="-6.731" y1="0.635" x2="-5.969" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="0.635" x2="-3.429" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="3.429" y1="0.635" x2="4.191" y2="1.143" layer="21"/>
<rectangle x1="5.969" y1="0.635" x2="6.731" y2="1.143" layer="21"/>
<rectangle x1="8.509" y1="0.635" x2="9.271" y2="1.143" layer="21"/>
<rectangle x1="11.049" y1="0.635" x2="11.811" y2="1.143" layer="21"/>
<rectangle x1="13.589" y1="0.635" x2="14.351" y2="1.143" layer="21"/>
<rectangle x1="16.129" y1="0.635" x2="16.891" y2="1.143" layer="21"/>
<rectangle x1="18.669" y1="0.635" x2="19.431" y2="1.143" layer="21"/>
<rectangle x1="21.209" y1="0.635" x2="21.971" y2="1.143" layer="21"/>
<rectangle x1="-27.051" y1="-2.921" x2="-26.289" y2="-1.905" layer="21"/>
<rectangle x1="-24.511" y1="-2.921" x2="-23.749" y2="-1.905" layer="21"/>
<rectangle x1="-21.971" y1="-2.921" x2="-21.209" y2="-1.905" layer="21"/>
<rectangle x1="-19.431" y1="-2.921" x2="-18.669" y2="-1.905" layer="21"/>
<rectangle x1="-16.891" y1="-2.921" x2="-16.129" y2="-1.905" layer="21"/>
<rectangle x1="-14.351" y1="-2.921" x2="-13.589" y2="-1.905" layer="21"/>
<rectangle x1="-11.811" y1="-2.921" x2="-11.049" y2="-1.905" layer="21"/>
<rectangle x1="-9.271" y1="-2.921" x2="-8.509" y2="-1.905" layer="21"/>
<rectangle x1="-6.731" y1="-2.921" x2="-5.969" y2="-1.905" layer="21"/>
<rectangle x1="-4.191" y1="-2.921" x2="-3.429" y2="-1.905" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
<rectangle x1="3.429" y1="-2.921" x2="4.191" y2="-1.905" layer="21"/>
<rectangle x1="5.969" y1="-2.921" x2="6.731" y2="-1.905" layer="21"/>
<rectangle x1="8.509" y1="-2.921" x2="9.271" y2="-1.905" layer="21"/>
<rectangle x1="11.049" y1="-2.921" x2="11.811" y2="-1.905" layer="21"/>
<rectangle x1="13.589" y1="-2.921" x2="14.351" y2="-1.905" layer="21"/>
<rectangle x1="16.129" y1="-2.921" x2="16.891" y2="-1.905" layer="21"/>
<rectangle x1="18.669" y1="-2.921" x2="19.431" y2="-1.905" layer="21"/>
<rectangle x1="21.209" y1="-2.921" x2="21.971" y2="-1.905" layer="21"/>
<rectangle x1="23.749" y1="0.635" x2="24.511" y2="1.143" layer="21"/>
<rectangle x1="26.289" y1="0.635" x2="27.051" y2="1.143" layer="21"/>
<rectangle x1="23.749" y1="-2.921" x2="24.511" y2="-1.905" layer="21"/>
<rectangle x1="26.289" y1="-2.921" x2="27.051" y2="-1.905" layer="21"/>
</package>
<package name="1X24/90">
<wire x1="-30.48" y1="-1.905" x2="-27.94" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="-1.905" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="0.635" x2="-30.48" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-29.21" y1="6.985" x2="-29.21" y2="1.27" width="0.762" layer="21"/>
<wire x1="27.94" y1="-1.905" x2="30.48" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-1.905" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="0.635" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="29.21" y1="6.985" x2="29.21" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-29.21" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-26.67" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-31.115" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="32.385" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-29.591" y1="0.635" x2="-28.829" y2="1.143" layer="21"/>
<rectangle x1="-29.591" y1="-2.921" x2="-28.829" y2="-1.905" layer="21"/>
<rectangle x1="28.829" y1="0.635" x2="29.591" y2="1.143" layer="21"/>
<rectangle x1="28.829" y1="-2.921" x2="29.591" y2="-1.905" layer="21"/>
</package>
<package name="2X22/90">
<pad name="2" x="-26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="38" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-26.67" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="37" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="40" x="21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="39" x="21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="42" x="24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="41" x="24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="44" x="26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="43" x="26.67" y="-6.35" drill="1.016" shape="octagon"/>
<rectangle x1="-27.051" y1="-5.461" x2="-26.289" y2="-4.699" layer="21"/>
<rectangle x1="-27.051" y1="-4.699" x2="-26.289" y2="-2.921" layer="51"/>
<rectangle x1="-24.511" y1="-4.699" x2="-23.749" y2="-2.921" layer="51"/>
<rectangle x1="-24.511" y1="-5.461" x2="-23.749" y2="-4.699" layer="21"/>
<rectangle x1="-21.971" y1="-5.461" x2="-21.209" y2="-4.699" layer="21"/>
<rectangle x1="-21.971" y1="-4.699" x2="-21.209" y2="-2.921" layer="51"/>
<rectangle x1="-19.431" y1="-4.699" x2="-18.669" y2="-2.921" layer="51"/>
<rectangle x1="-19.431" y1="-5.461" x2="-18.669" y2="-4.699" layer="21"/>
<rectangle x1="-16.891" y1="-5.461" x2="-16.129" y2="-4.699" layer="21"/>
<rectangle x1="-16.891" y1="-4.699" x2="-16.129" y2="-2.921" layer="51"/>
<rectangle x1="-14.351" y1="-5.461" x2="-13.589" y2="-4.699" layer="21"/>
<rectangle x1="-14.351" y1="-4.699" x2="-13.589" y2="-2.921" layer="51"/>
<rectangle x1="-11.811" y1="-4.699" x2="-11.049" y2="-2.921" layer="51"/>
<rectangle x1="-11.811" y1="-5.461" x2="-11.049" y2="-4.699" layer="21"/>
<rectangle x1="-9.271" y1="-5.461" x2="-8.509" y2="-4.699" layer="21"/>
<rectangle x1="-9.271" y1="-4.699" x2="-8.509" y2="-2.921" layer="51"/>
<rectangle x1="-6.731" y1="-4.699" x2="-5.969" y2="-2.921" layer="51"/>
<rectangle x1="-6.731" y1="-5.461" x2="-5.969" y2="-4.699" layer="21"/>
<rectangle x1="-4.191" y1="-5.461" x2="-3.429" y2="-4.699" layer="21"/>
<rectangle x1="-4.191" y1="-4.699" x2="-3.429" y2="-2.921" layer="51"/>
<rectangle x1="-1.651" y1="-5.461" x2="-0.889" y2="-4.699" layer="21"/>
<rectangle x1="-1.651" y1="-4.699" x2="-0.889" y2="-2.921" layer="51"/>
<rectangle x1="0.889" y1="-4.699" x2="1.651" y2="-2.921" layer="51"/>
<rectangle x1="0.889" y1="-5.461" x2="1.651" y2="-4.699" layer="21"/>
<rectangle x1="3.429" y1="-5.461" x2="4.191" y2="-4.699" layer="21"/>
<rectangle x1="3.429" y1="-4.699" x2="4.191" y2="-2.921" layer="51"/>
<rectangle x1="5.969" y1="-4.699" x2="6.731" y2="-2.921" layer="51"/>
<rectangle x1="5.969" y1="-5.461" x2="6.731" y2="-4.699" layer="21"/>
<rectangle x1="8.509" y1="-5.461" x2="9.271" y2="-4.699" layer="21"/>
<rectangle x1="8.509" y1="-4.699" x2="9.271" y2="-2.921" layer="51"/>
<rectangle x1="11.049" y1="-5.461" x2="11.811" y2="-4.699" layer="21"/>
<rectangle x1="11.049" y1="-4.699" x2="11.811" y2="-2.921" layer="51"/>
<rectangle x1="13.589" y1="-4.699" x2="14.351" y2="-2.921" layer="51"/>
<rectangle x1="13.589" y1="-5.461" x2="14.351" y2="-4.699" layer="21"/>
<rectangle x1="16.129" y1="-5.461" x2="16.891" y2="-4.699" layer="21"/>
<rectangle x1="16.129" y1="-4.699" x2="16.891" y2="-2.921" layer="51"/>
<rectangle x1="18.669" y1="-4.699" x2="19.431" y2="-2.921" layer="51"/>
<rectangle x1="18.669" y1="-5.461" x2="19.431" y2="-4.699" layer="21"/>
<rectangle x1="21.209" y1="-5.461" x2="21.971" y2="-4.699" layer="21"/>
<rectangle x1="21.209" y1="-4.699" x2="21.971" y2="-2.921" layer="51"/>
<rectangle x1="23.749" y1="-4.699" x2="24.511" y2="-2.921" layer="51"/>
<rectangle x1="23.749" y1="-5.461" x2="24.511" y2="-4.699" layer="21"/>
<rectangle x1="26.289" y1="-5.461" x2="27.051" y2="-4.699" layer="21"/>
<rectangle x1="26.289" y1="-4.699" x2="27.051" y2="-2.921" layer="51"/>
</package>
<package name="2X24/90">
<pad name="2" x="-29.21" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="38" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-29.21" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-26.67" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="37" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="40" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="39" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="41" x="21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="42" x="21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="43" x="24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="44" x="24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="45" x="26.67" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="46" x="26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="47" x="29.21" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="48" x="29.21" y="-3.81" drill="1.016" shape="octagon"/>
<text x="32.385" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-29.591" y1="-5.461" x2="-28.829" y2="-4.699" layer="21"/>
<rectangle x1="-29.591" y1="-4.699" x2="-28.829" y2="-2.921" layer="51"/>
<rectangle x1="28.829" y1="-5.461" x2="29.591" y2="-4.699" layer="21"/>
<rectangle x1="28.829" y1="-4.699" x2="29.591" y2="-2.921" layer="51"/>
</package>
<package name="2X25/90">
<wire x1="30.48" y1="-1.905" x2="33.02" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-1.905" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="0.635" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="31.75" y1="6.985" x2="31.75" y2="1.27" width="0.762" layer="21"/>
<pad name="50" x="31.75" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="49" x="31.75" y="-6.35" drill="1.016" shape="octagon"/>
<text x="34.925" y="-4.445" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="31.369" y1="0.635" x2="32.131" y2="1.143" layer="21"/>
<rectangle x1="31.369" y1="-2.921" x2="32.131" y2="-1.905" layer="21"/>
<rectangle x1="31.369" y1="-4.699" x2="32.131" y2="-2.921" layer="51"/>
<rectangle x1="31.369" y1="-5.461" x2="32.131" y2="-4.699" layer="21"/>
</package>
<package name="2X30/90">
<wire x1="-38.1" y1="-1.905" x2="-35.56" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="-1.905" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="0.635" x2="-38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="0.635" x2="-38.1" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-36.83" y1="6.985" x2="-36.83" y2="1.27" width="0.762" layer="21"/>
<wire x1="-35.56" y1="-1.905" x2="-33.02" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="-1.905" x2="-33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="0.635" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-34.29" y1="6.985" x2="-34.29" y2="1.27" width="0.762" layer="21"/>
<wire x1="-33.02" y1="-1.905" x2="-30.48" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-1.905" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="0.635" x2="-33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-31.75" y1="6.985" x2="-31.75" y2="1.27" width="0.762" layer="21"/>
<wire x1="33.02" y1="-1.905" x2="35.56" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-1.905" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="35.56" y1="0.635" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="34.29" y1="6.985" x2="34.29" y2="1.27" width="0.762" layer="21"/>
<wire x1="35.56" y1="-1.905" x2="38.1" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="38.1" y1="-1.905" x2="38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="0.635" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="36.83" y1="6.985" x2="36.83" y2="1.27" width="0.762" layer="21"/>
<pad name="2" x="-36.83" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="4" x="-34.29" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="6" x="-31.75" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="8" x="-29.21" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="10" x="-26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="12" x="-24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="14" x="-21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="16" x="-19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="18" x="-16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="20" x="-13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="22" x="-11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="24" x="-8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="26" x="-6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="28" x="-3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="30" x="-1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="32" x="1.27" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="34" x="3.81" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="36" x="6.35" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="38" x="8.89" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="1" x="-36.83" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="3" x="-34.29" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="5" x="-31.75" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="7" x="-29.21" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="9" x="-26.67" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="11" x="-24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="13" x="-21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="15" x="-19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="17" x="-16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="19" x="-13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="21" x="-11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="23" x="-8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="25" x="-6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="27" x="-3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="29" x="-1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="31" x="1.27" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="33" x="3.81" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="35" x="6.35" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="37" x="8.89" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="40" x="11.43" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="39" x="11.43" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="41" x="13.97" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="42" x="13.97" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="43" x="16.51" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="44" x="16.51" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="45" x="19.05" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="46" x="19.05" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="47" x="21.59" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="48" x="21.59" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="49" x="24.13" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="50" x="24.13" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="51" x="26.67" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="52" x="26.67" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="53" x="29.21" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="54" x="29.21" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="55" x="31.75" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="56" x="31.75" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="57" x="34.29" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="58" x="34.29" y="-3.81" drill="1.016" shape="octagon"/>
<pad name="59" x="36.83" y="-6.35" drill="1.016" shape="octagon"/>
<pad name="60" x="36.83" y="-3.81" drill="1.016" shape="octagon"/>
<text x="-38.735" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="40.005" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-37.211" y1="0.635" x2="-36.449" y2="1.143" layer="21"/>
<rectangle x1="-34.671" y1="0.635" x2="-33.909" y2="1.143" layer="21"/>
<rectangle x1="-32.131" y1="0.635" x2="-31.369" y2="1.143" layer="21"/>
<rectangle x1="-37.211" y1="-2.921" x2="-36.449" y2="-1.905" layer="21"/>
<rectangle x1="-34.671" y1="-2.921" x2="-33.909" y2="-1.905" layer="21"/>
<rectangle x1="-37.211" y1="-5.461" x2="-36.449" y2="-4.699" layer="21"/>
<rectangle x1="-37.211" y1="-4.699" x2="-36.449" y2="-2.921" layer="51"/>
<rectangle x1="-34.671" y1="-4.699" x2="-33.909" y2="-2.921" layer="51"/>
<rectangle x1="-34.671" y1="-5.461" x2="-33.909" y2="-4.699" layer="21"/>
<rectangle x1="-32.131" y1="-2.921" x2="-31.369" y2="-1.905" layer="21"/>
<rectangle x1="-32.131" y1="-5.461" x2="-31.369" y2="-4.699" layer="21"/>
<rectangle x1="-32.131" y1="-4.699" x2="-31.369" y2="-2.921" layer="51"/>
<rectangle x1="33.909" y1="0.635" x2="34.671" y2="1.143" layer="21"/>
<rectangle x1="36.449" y1="0.635" x2="37.211" y2="1.143" layer="21"/>
<rectangle x1="33.909" y1="-2.921" x2="34.671" y2="-1.905" layer="21"/>
<rectangle x1="33.909" y1="-4.699" x2="34.671" y2="-2.921" layer="51"/>
<rectangle x1="33.909" y1="-5.461" x2="34.671" y2="-4.699" layer="21"/>
<rectangle x1="36.449" y1="-2.921" x2="37.211" y2="-1.905" layer="21"/>
<rectangle x1="36.449" y1="-5.461" x2="37.211" y2="-4.699" layer="21"/>
<rectangle x1="36.449" y1="-4.699" x2="37.211" y2="-2.921" layer="51"/>
</package>
<package name="1_05X2MM">
<description>CON-M-1X5-200</description>
<text x="-4.5" y="1.5" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.75" y="-2.75" size="1.27" layer="27">&gt;VALUE</text>
<wire x1="-5" y1="0.5" x2="-4.5" y2="1" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="1" x2="-3.5" y2="1" width="0.1524" layer="21"/>
<wire x1="-3.5" y1="1" x2="-3" y2="0.5" width="0.1524" layer="21"/>
<wire x1="-3" y1="-0.5" x2="-3.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="-3.5" y1="-1" x2="-4.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-1" x2="-5" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="-5" y1="0.5" x2="-5" y2="-0.5" width="0.1524" layer="21"/>
<pad name="1" x="-4" y="0" drill="1.016" diameter="1.3" shape="square" rot="R90"/>
<rectangle x1="-4.254" y1="-0.254" x2="-3.746" y2="0.254" layer="51"/>
<wire x1="-3" y1="0.5" x2="-2.5" y2="1" width="0.1524" layer="21"/>
<wire x1="-2.5" y1="1" x2="-1.5" y2="1" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="1" x2="-1" y2="0.5" width="0.1524" layer="21"/>
<wire x1="-1" y1="-0.5" x2="-1.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="-1.5" y1="-1" x2="-2.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="-2.5" y1="-1" x2="-3" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="-3" y1="0.5" x2="-3" y2="-0.5" width="0.1524" layer="21"/>
<pad name="3" x="0" y="0" drill="1.016" diameter="1.3" rot="R90"/>
<rectangle x1="-2.254" y1="-0.254" x2="-1.746" y2="0.254" layer="51"/>
<wire x1="-1" y1="0.5" x2="-0.5" y2="1" width="0.1524" layer="21"/>
<wire x1="-0.5" y1="1" x2="0.5" y2="1" width="0.1524" layer="21"/>
<wire x1="0.5" y1="1" x2="1" y2="0.5" width="0.1524" layer="21"/>
<wire x1="1" y1="-0.5" x2="0.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="0.5" y1="-1" x2="-0.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="-0.5" y1="-1" x2="-1" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.1524" layer="21"/>
<pad name="2" x="-2" y="0" drill="1.016" diameter="1.3" rot="R90"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<wire x1="1" y1="0.5" x2="1.5" y2="1" width="0.1524" layer="21"/>
<wire x1="1.5" y1="1" x2="2.5" y2="1" width="0.1524" layer="21"/>
<wire x1="2.5" y1="1" x2="3" y2="0.5" width="0.1524" layer="21"/>
<wire x1="3" y1="-0.5" x2="2.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="2.5" y1="-1" x2="1.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="1.5" y1="-1" x2="1" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="1" y1="0.5" x2="1" y2="-0.5" width="0.1524" layer="21"/>
<pad name="4" x="2" y="0" drill="1.016" diameter="1.3" rot="R90"/>
<rectangle x1="1.746" y1="-0.254" x2="2.254" y2="0.254" layer="51"/>
<wire x1="3" y1="0.5" x2="3.5" y2="1" width="0.1524" layer="21"/>
<wire x1="3.5" y1="1" x2="4.5" y2="1" width="0.1524" layer="21"/>
<wire x1="4.5" y1="1" x2="5" y2="0.5" width="0.1524" layer="21"/>
<wire x1="5" y1="0.5" x2="5" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="5" y1="-0.5" x2="4.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-1" x2="3.5" y2="-1" width="0.1524" layer="21"/>
<wire x1="3.5" y1="-1" x2="3" y2="-0.5" width="0.1524" layer="21"/>
<wire x1="3" y1="0.5" x2="3" y2="-0.5" width="0.1524" layer="21"/>
<pad name="5" x="4" y="0" drill="1.016" diameter="1.3" rot="R90"/>
<rectangle x1="3.746" y1="-0.254" x2="4.254" y2="0.254" layer="51"/>
</package>
<package name="1X70">
<description>&lt;b&gt;PIN HEADER 70 pol.&lt;/b&gt; Grid 2.54mm&lt;p&gt;</description>
<wire x1="-53.34" y1="0.635" x2="-52.705" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-52.705" y1="1.27" x2="-51.435" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-51.435" y1="1.27" x2="-50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-50.8" y1="-0.635" x2="-51.435" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-51.435" y1="-1.27" x2="-52.705" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-52.705" y1="-1.27" x2="-53.34" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-57.785" y1="1.27" x2="-56.515" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-56.515" y1="1.27" x2="-55.88" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-55.88" y1="-0.635" x2="-56.515" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-55.88" y1="0.635" x2="-55.245" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-55.245" y1="1.27" x2="-53.975" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-53.975" y1="1.27" x2="-53.34" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-53.34" y1="-0.635" x2="-53.975" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-53.975" y1="-1.27" x2="-55.245" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-55.245" y1="-1.27" x2="-55.88" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-60.96" y1="0.635" x2="-60.325" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-60.325" y1="1.27" x2="-59.055" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-59.055" y1="1.27" x2="-58.42" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-58.42" y1="-0.635" x2="-59.055" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-59.055" y1="-1.27" x2="-60.325" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-60.325" y1="-1.27" x2="-60.96" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-57.785" y1="1.27" x2="-58.42" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-58.42" y1="-0.635" x2="-57.785" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-56.515" y1="-1.27" x2="-57.785" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-65.405" y1="1.27" x2="-64.135" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-64.135" y1="1.27" x2="-63.5" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-63.5" y1="-0.635" x2="-64.135" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-63.5" y1="0.635" x2="-62.865" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-62.865" y1="1.27" x2="-61.595" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-61.595" y1="1.27" x2="-60.96" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-60.96" y1="-0.635" x2="-61.595" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-61.595" y1="-1.27" x2="-62.865" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-62.865" y1="-1.27" x2="-63.5" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-68.58" y1="0.635" x2="-67.945" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-67.945" y1="1.27" x2="-66.675" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-66.675" y1="1.27" x2="-66.04" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-66.04" y1="-0.635" x2="-66.675" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-66.675" y1="-1.27" x2="-67.945" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-67.945" y1="-1.27" x2="-68.58" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-65.405" y1="1.27" x2="-66.04" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-66.04" y1="-0.635" x2="-65.405" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-64.135" y1="-1.27" x2="-65.405" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-73.025" y1="1.27" x2="-71.755" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-71.755" y1="1.27" x2="-71.12" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-71.12" y1="-0.635" x2="-71.755" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-71.12" y1="0.635" x2="-70.485" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-70.485" y1="1.27" x2="-69.215" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-69.215" y1="1.27" x2="-68.58" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-68.58" y1="-0.635" x2="-69.215" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-69.215" y1="-1.27" x2="-70.485" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-70.485" y1="-1.27" x2="-71.12" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-76.2" y1="0.635" x2="-75.565" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-75.565" y1="1.27" x2="-74.295" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-74.295" y1="1.27" x2="-73.66" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-73.66" y1="-0.635" x2="-74.295" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-74.295" y1="-1.27" x2="-75.565" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-75.565" y1="-1.27" x2="-76.2" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-73.025" y1="1.27" x2="-73.66" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-73.66" y1="-0.635" x2="-73.025" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-71.755" y1="-1.27" x2="-73.025" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-80.645" y1="1.27" x2="-79.375" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-79.375" y1="1.27" x2="-78.74" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-78.74" y1="-0.635" x2="-79.375" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-78.74" y1="0.635" x2="-78.105" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-78.105" y1="1.27" x2="-76.835" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-76.835" y1="1.27" x2="-76.2" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-76.2" y1="-0.635" x2="-76.835" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-76.835" y1="-1.27" x2="-78.105" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-78.105" y1="-1.27" x2="-78.74" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-83.82" y1="0.635" x2="-83.185" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-83.185" y1="1.27" x2="-81.915" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-81.915" y1="1.27" x2="-81.28" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-81.28" y1="-0.635" x2="-81.915" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-81.915" y1="-1.27" x2="-83.185" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-83.185" y1="-1.27" x2="-83.82" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-80.645" y1="1.27" x2="-81.28" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-81.28" y1="-0.635" x2="-80.645" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-79.375" y1="-1.27" x2="-80.645" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-88.265" y1="1.27" x2="-86.995" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-86.995" y1="1.27" x2="-86.36" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-86.36" y1="-0.635" x2="-86.995" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-86.36" y1="0.635" x2="-85.725" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-85.725" y1="1.27" x2="-84.455" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-84.455" y1="1.27" x2="-83.82" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-83.82" y1="-0.635" x2="-84.455" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-84.455" y1="-1.27" x2="-85.725" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-85.725" y1="-1.27" x2="-86.36" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-88.9" y1="0.635" x2="-88.9" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-88.265" y1="1.27" x2="-88.9" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-88.9" y1="-0.635" x2="-88.265" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-86.995" y1="-1.27" x2="-88.265" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-40.005" y1="1.27" x2="-40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="-0.635" x2="-40.005" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="1.27" x2="-36.195" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="1.27" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="-0.635" x2="-36.195" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="1.27" x2="-38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="-0.635" x2="-37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-36.195" y1="-1.27" x2="-37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="1.27" x2="-33.655" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="1.27" x2="-33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="-0.635" x2="-33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-33.655" y1="-1.27" x2="-34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="1.27" x2="-31.115" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="1.27" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-0.635" x2="-31.115" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="1.27" x2="-33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="-0.635" x2="-32.385" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-31.115" y1="-1.27" x2="-32.385" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="1.27" x2="-28.575" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="1.27" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="-0.635" x2="-28.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="1.27" x2="-30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="-0.635" x2="-29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-28.575" y1="-1.27" x2="-29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-26.035" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="1.27" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-26.035" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-27.94" y1="-0.635" x2="-27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="-1.27" x2="-27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-23.495" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-23.495" y1="-1.27" x2="-24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-20.955" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-13.335" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0.635" x2="8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="10.795" y1="1.27" x2="10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-9.525" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-87.63" y="0" drill="1.016" rot="R90"/>
<pad name="2" x="-85.09" y="0" drill="1.016" rot="R90"/>
<pad name="3" x="-82.55" y="0" drill="1.016" rot="R90"/>
<pad name="4" x="-80.01" y="0" drill="1.016" rot="R90"/>
<pad name="5" x="-77.47" y="0" drill="1.016" rot="R90"/>
<pad name="6" x="-74.93" y="0" drill="1.016" rot="R90"/>
<pad name="7" x="-72.39" y="0" drill="1.016" rot="R90"/>
<pad name="8" x="-69.85" y="0" drill="1.016" rot="R90"/>
<pad name="9" x="-67.31" y="0" drill="1.016" rot="R90"/>
<pad name="10" x="-64.77" y="0" drill="1.016" rot="R90"/>
<pad name="11" x="-62.23" y="0" drill="1.016" rot="R90"/>
<pad name="12" x="-59.69" y="0" drill="1.016" rot="R90"/>
<pad name="13" x="-57.15" y="0" drill="1.016" rot="R90"/>
<pad name="14" x="-54.61" y="0" drill="1.016" rot="R90"/>
<pad name="15" x="-52.07" y="0" drill="1.016" rot="R90"/>
<pad name="16" x="-49.53" y="0" drill="1.016" rot="R90"/>
<pad name="17" x="-46.99" y="0" drill="1.016" rot="R90"/>
<pad name="18" x="-44.45" y="0" drill="1.016" rot="R90"/>
<pad name="19" x="-41.91" y="0" drill="1.016" rot="R90"/>
<pad name="20" x="-39.37" y="0" drill="1.016" rot="R90"/>
<pad name="21" x="-36.83" y="0" drill="1.016" rot="R90"/>
<pad name="22" x="-34.29" y="0" drill="1.016" rot="R90"/>
<pad name="23" x="-31.75" y="0" drill="1.016" rot="R90"/>
<pad name="24" x="-29.21" y="0" drill="1.016" rot="R90"/>
<pad name="25" x="-26.67" y="0" drill="1.016" rot="R90"/>
<pad name="26" x="-24.13" y="0" drill="1.016" rot="R90"/>
<pad name="27" x="-21.59" y="0" drill="1.016" rot="R90"/>
<pad name="28" x="-19.05" y="0" drill="1.016" rot="R90"/>
<pad name="29" x="-16.51" y="0" drill="1.016" rot="R90"/>
<pad name="30" x="-13.97" y="0" drill="1.016" rot="R90"/>
<pad name="31" x="-11.43" y="0" drill="1.016" rot="R90"/>
<pad name="32" x="-8.89" y="0" drill="1.016" rot="R90"/>
<pad name="33" x="-6.35" y="0" drill="1.016" rot="R90"/>
<pad name="34" x="-3.81" y="0" drill="1.016" rot="R90"/>
<pad name="35" x="-1.27" y="0" drill="1.016" rot="R90"/>
<pad name="36" x="1.27" y="0" drill="1.016" rot="R90"/>
<pad name="37" x="3.81" y="0" drill="1.016" rot="R90"/>
<pad name="38" x="6.35" y="0" drill="1.016" rot="R90"/>
<pad name="39" x="8.89" y="0" drill="1.016" rot="R90"/>
<pad name="40" x="11.43" y="0" drill="1.016" rot="R90"/>
<text x="-88.9762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-88.9" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-52.324" y1="-0.254" x2="-51.816" y2="0.254" layer="51"/>
<rectangle x1="-54.864" y1="-0.254" x2="-54.356" y2="0.254" layer="51"/>
<rectangle x1="-57.404" y1="-0.254" x2="-56.896" y2="0.254" layer="51"/>
<rectangle x1="-59.944" y1="-0.254" x2="-59.436" y2="0.254" layer="51"/>
<rectangle x1="-62.484" y1="-0.254" x2="-61.976" y2="0.254" layer="51"/>
<rectangle x1="-65.024" y1="-0.254" x2="-64.516" y2="0.254" layer="51"/>
<rectangle x1="-67.564" y1="-0.254" x2="-67.056" y2="0.254" layer="51"/>
<rectangle x1="-70.104" y1="-0.254" x2="-69.596" y2="0.254" layer="51"/>
<rectangle x1="-72.644" y1="-0.254" x2="-72.136" y2="0.254" layer="51"/>
<rectangle x1="-75.184" y1="-0.254" x2="-74.676" y2="0.254" layer="51"/>
<rectangle x1="-77.724" y1="-0.254" x2="-77.216" y2="0.254" layer="51"/>
<rectangle x1="-80.264" y1="-0.254" x2="-79.756" y2="0.254" layer="51"/>
<rectangle x1="-82.804" y1="-0.254" x2="-82.296" y2="0.254" layer="51"/>
<rectangle x1="-85.344" y1="-0.254" x2="-84.836" y2="0.254" layer="51"/>
<rectangle x1="-87.884" y1="-0.254" x2="-87.376" y2="0.254" layer="51"/>
<rectangle x1="-37.084" y1="-0.254" x2="-36.576" y2="0.254" layer="51"/>
<rectangle x1="-34.544" y1="-0.254" x2="-34.036" y2="0.254" layer="51"/>
<rectangle x1="-32.004" y1="-0.254" x2="-31.496" y2="0.254" layer="51"/>
<rectangle x1="-29.464" y1="-0.254" x2="-28.956" y2="0.254" layer="51"/>
<rectangle x1="-26.924" y1="-0.254" x2="-26.416" y2="0.254" layer="51"/>
<rectangle x1="-24.384" y1="-0.254" x2="-23.876" y2="0.254" layer="51"/>
<rectangle x1="-21.844" y1="-0.254" x2="-21.336" y2="0.254" layer="51"/>
<rectangle x1="-19.304" y1="-0.254" x2="-18.796" y2="0.254" layer="51"/>
<rectangle x1="-16.764" y1="-0.254" x2="-16.256" y2="0.254" layer="51"/>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<wire x1="59.055" y1="1.27" x2="60.325" y2="1.27" width="0.1524" layer="21"/>
<wire x1="60.325" y1="1.27" x2="60.96" y2="0.635" width="0.1524" layer="21"/>
<wire x1="60.96" y1="-0.635" x2="60.325" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="55.88" y1="0.635" x2="56.515" y2="1.27" width="0.1524" layer="21"/>
<wire x1="56.515" y1="1.27" x2="57.785" y2="1.27" width="0.1524" layer="21"/>
<wire x1="57.785" y1="1.27" x2="58.42" y2="0.635" width="0.1524" layer="21"/>
<wire x1="58.42" y1="-0.635" x2="57.785" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="57.785" y1="-1.27" x2="56.515" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="56.515" y1="-1.27" x2="55.88" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="59.055" y1="1.27" x2="58.42" y2="0.635" width="0.1524" layer="21"/>
<wire x1="58.42" y1="-0.635" x2="59.055" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="60.325" y1="-1.27" x2="59.055" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="51.435" y1="1.27" x2="52.705" y2="1.27" width="0.1524" layer="21"/>
<wire x1="52.705" y1="1.27" x2="53.34" y2="0.635" width="0.1524" layer="21"/>
<wire x1="53.34" y1="-0.635" x2="52.705" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="53.34" y1="0.635" x2="53.975" y2="1.27" width="0.1524" layer="21"/>
<wire x1="53.975" y1="1.27" x2="55.245" y2="1.27" width="0.1524" layer="21"/>
<wire x1="55.245" y1="1.27" x2="55.88" y2="0.635" width="0.1524" layer="21"/>
<wire x1="55.88" y1="-0.635" x2="55.245" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="55.245" y1="-1.27" x2="53.975" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="53.975" y1="-1.27" x2="53.34" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="48.26" y1="0.635" x2="48.895" y2="1.27" width="0.1524" layer="21"/>
<wire x1="48.895" y1="1.27" x2="50.165" y2="1.27" width="0.1524" layer="21"/>
<wire x1="50.165" y1="1.27" x2="50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="50.8" y1="-0.635" x2="50.165" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="50.165" y1="-1.27" x2="48.895" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="48.895" y1="-1.27" x2="48.26" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="51.435" y1="1.27" x2="50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="50.8" y1="-0.635" x2="51.435" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="52.705" y1="-1.27" x2="51.435" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="43.815" y1="1.27" x2="45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="45.085" y1="1.27" x2="45.72" y2="0.635" width="0.1524" layer="21"/>
<wire x1="45.72" y1="-0.635" x2="45.085" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="45.72" y1="0.635" x2="46.355" y2="1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="1.27" x2="47.625" y2="1.27" width="0.1524" layer="21"/>
<wire x1="47.625" y1="1.27" x2="48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-0.635" x2="47.625" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="47.625" y1="-1.27" x2="46.355" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="-1.27" x2="45.72" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="40.64" y1="0.635" x2="41.275" y2="1.27" width="0.1524" layer="21"/>
<wire x1="41.275" y1="1.27" x2="42.545" y2="1.27" width="0.1524" layer="21"/>
<wire x1="42.545" y1="1.27" x2="43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="43.18" y1="-0.635" x2="42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="42.545" y1="-1.27" x2="41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="41.275" y1="-1.27" x2="40.64" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="43.815" y1="1.27" x2="43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="43.18" y1="-0.635" x2="43.815" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="45.085" y1="-1.27" x2="43.815" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="36.195" y1="1.27" x2="37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="37.465" y1="1.27" x2="38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="-0.635" x2="37.465" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="38.1" y1="0.635" x2="38.735" y2="1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="1.27" x2="40.005" y2="1.27" width="0.1524" layer="21"/>
<wire x1="40.005" y1="1.27" x2="40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="40.64" y1="-0.635" x2="40.005" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="40.005" y1="-1.27" x2="38.735" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="-1.27" x2="38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="0.635" x2="33.655" y2="1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="1.27" x2="34.925" y2="1.27" width="0.1524" layer="21"/>
<wire x1="34.925" y1="1.27" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-0.635" x2="34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="34.925" y1="-1.27" x2="33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="-1.27" x2="33.02" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="36.195" y1="1.27" x2="35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-0.635" x2="36.195" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="37.465" y1="-1.27" x2="36.195" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="28.575" y1="1.27" x2="29.845" y2="1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="1.27" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="29.845" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="30.48" y1="0.635" x2="31.115" y2="1.27" width="0.1524" layer="21"/>
<wire x1="31.115" y1="1.27" x2="32.385" y2="1.27" width="0.1524" layer="21"/>
<wire x1="32.385" y1="1.27" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="32.385" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="32.385" y1="-1.27" x2="31.115" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="31.115" y1="-1.27" x2="30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="0.635" x2="26.035" y2="1.27" width="0.1524" layer="21"/>
<wire x1="26.035" y1="1.27" x2="27.305" y2="1.27" width="0.1524" layer="21"/>
<wire x1="27.305" y1="1.27" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="27.305" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.035" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="26.035" y1="-1.27" x2="25.4" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="28.575" y1="1.27" x2="27.94" y2="0.635" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="28.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="28.575" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="22.225" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.86" y1="0.635" x2="23.495" y2="1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.765" y2="1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="1.27" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="24.765" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0.635" x2="18.415" y2="1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.78" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="20.955" y1="1.27" x2="20.32" y2="0.635" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="20.955" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.24" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0.635" x2="15.875" y2="1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="1.27" x2="17.145" y2="1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="1.27" x2="17.78" y2="0.635" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="13.335" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="61.595" y1="1.27" x2="62.865" y2="1.27" width="0.1524" layer="21"/>
<wire x1="62.865" y1="1.27" x2="63.5" y2="0.635" width="0.1524" layer="21"/>
<wire x1="63.5" y1="-0.635" x2="62.865" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="61.595" y1="1.27" x2="60.96" y2="0.635" width="0.1524" layer="21"/>
<wire x1="60.96" y1="-0.635" x2="61.595" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="62.865" y1="-1.27" x2="61.595" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="64.135" y1="1.27" x2="65.405" y2="1.27" width="0.1524" layer="21"/>
<wire x1="65.405" y1="1.27" x2="66.04" y2="0.635" width="0.1524" layer="21"/>
<wire x1="66.04" y1="-0.635" x2="65.405" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="64.135" y1="1.27" x2="63.5" y2="0.635" width="0.1524" layer="21"/>
<wire x1="63.5" y1="-0.635" x2="64.135" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="65.405" y1="-1.27" x2="64.135" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="66.675" y1="1.27" x2="67.945" y2="1.27" width="0.1524" layer="21"/>
<wire x1="67.945" y1="1.27" x2="68.58" y2="0.635" width="0.1524" layer="21"/>
<wire x1="68.58" y1="-0.635" x2="67.945" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="66.675" y1="1.27" x2="66.04" y2="0.635" width="0.1524" layer="21"/>
<wire x1="66.04" y1="-0.635" x2="66.675" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="67.945" y1="-1.27" x2="66.675" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="69.215" y1="1.27" x2="70.485" y2="1.27" width="0.1524" layer="21"/>
<wire x1="70.485" y1="1.27" x2="71.12" y2="0.635" width="0.1524" layer="21"/>
<wire x1="71.12" y1="-0.635" x2="70.485" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="69.215" y1="1.27" x2="68.58" y2="0.635" width="0.1524" layer="21"/>
<wire x1="68.58" y1="-0.635" x2="69.215" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="70.485" y1="-1.27" x2="69.215" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="71.755" y1="1.27" x2="73.025" y2="1.27" width="0.1524" layer="21"/>
<wire x1="73.025" y1="1.27" x2="73.66" y2="0.635" width="0.1524" layer="21"/>
<wire x1="73.66" y1="-0.635" x2="73.025" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="71.755" y1="1.27" x2="71.12" y2="0.635" width="0.1524" layer="21"/>
<wire x1="71.12" y1="-0.635" x2="71.755" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="73.025" y1="-1.27" x2="71.755" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="74.295" y1="1.27" x2="75.565" y2="1.27" width="0.1524" layer="21"/>
<wire x1="75.565" y1="1.27" x2="76.2" y2="0.635" width="0.1524" layer="21"/>
<wire x1="76.2" y1="-0.635" x2="75.565" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="74.295" y1="1.27" x2="73.66" y2="0.635" width="0.1524" layer="21"/>
<wire x1="73.66" y1="-0.635" x2="74.295" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="75.565" y1="-1.27" x2="74.295" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="76.835" y1="1.27" x2="78.105" y2="1.27" width="0.1524" layer="21"/>
<wire x1="78.105" y1="1.27" x2="78.74" y2="0.635" width="0.1524" layer="21"/>
<wire x1="78.74" y1="-0.635" x2="78.105" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="76.835" y1="1.27" x2="76.2" y2="0.635" width="0.1524" layer="21"/>
<wire x1="76.2" y1="-0.635" x2="76.835" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="78.105" y1="-1.27" x2="76.835" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="79.375" y1="1.27" x2="80.645" y2="1.27" width="0.1524" layer="21"/>
<wire x1="80.645" y1="1.27" x2="81.28" y2="0.635" width="0.1524" layer="21"/>
<wire x1="81.28" y1="-0.635" x2="80.645" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="79.375" y1="1.27" x2="78.74" y2="0.635" width="0.1524" layer="21"/>
<wire x1="78.74" y1="-0.635" x2="79.375" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="80.645" y1="-1.27" x2="79.375" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="81.915" y1="1.27" x2="83.185" y2="1.27" width="0.1524" layer="21"/>
<wire x1="83.185" y1="1.27" x2="83.82" y2="0.635" width="0.1524" layer="21"/>
<wire x1="83.82" y1="-0.635" x2="83.185" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="81.915" y1="1.27" x2="81.28" y2="0.635" width="0.1524" layer="21"/>
<wire x1="81.28" y1="-0.635" x2="81.915" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="83.185" y1="-1.27" x2="81.915" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="84.455" y1="1.27" x2="85.725" y2="1.27" width="0.1524" layer="21"/>
<wire x1="85.725" y1="1.27" x2="86.36" y2="0.635" width="0.1524" layer="21"/>
<wire x1="86.36" y1="-0.635" x2="85.725" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="84.455" y1="1.27" x2="83.82" y2="0.635" width="0.1524" layer="21"/>
<wire x1="83.82" y1="-0.635" x2="84.455" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="85.725" y1="-1.27" x2="84.455" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="86.995" y1="1.27" x2="88.265" y2="1.27" width="0.1524" layer="21"/>
<wire x1="88.265" y1="1.27" x2="88.9" y2="0.635" width="0.1524" layer="21"/>
<wire x1="88.9" y1="-0.635" x2="88.265" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="86.995" y1="1.27" x2="86.36" y2="0.635" width="0.1524" layer="21"/>
<wire x1="86.36" y1="-0.635" x2="86.995" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="88.265" y1="-1.27" x2="86.995" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="88.9" y1="0.635" x2="88.9" y2="-0.635" width="0.1524" layer="21"/>
<pad name="41" x="13.97" y="0" drill="1.016" rot="R90"/>
<pad name="42" x="16.51" y="0" drill="1.016" rot="R90"/>
<pad name="43" x="19.05" y="0" drill="1.016" rot="R90"/>
<pad name="44" x="21.59" y="0" drill="1.016" rot="R90"/>
<pad name="45" x="24.13" y="0" drill="1.016" rot="R90"/>
<pad name="46" x="26.67" y="0" drill="1.016" rot="R90"/>
<pad name="47" x="29.21" y="0" drill="1.016" rot="R90"/>
<pad name="48" x="31.75" y="0" drill="1.016" rot="R90"/>
<pad name="49" x="34.29" y="0" drill="1.016" rot="R90"/>
<pad name="50" x="36.83" y="0" drill="1.016" rot="R90"/>
<pad name="51" x="39.37" y="0" drill="1.016" rot="R90"/>
<pad name="52" x="41.91" y="0" drill="1.016" rot="R90"/>
<pad name="53" x="44.45" y="0" drill="1.016" rot="R90"/>
<pad name="54" x="46.99" y="0" drill="1.016" rot="R90"/>
<pad name="55" x="49.53" y="0" drill="1.016" rot="R90"/>
<pad name="56" x="52.07" y="0" drill="1.016" rot="R90"/>
<pad name="57" x="54.61" y="0" drill="1.016" rot="R90"/>
<pad name="58" x="57.15" y="0" drill="1.016" rot="R90"/>
<pad name="59" x="59.69" y="0" drill="1.016" rot="R90"/>
<pad name="60" x="62.23" y="0" drill="1.016" rot="R90"/>
<pad name="61" x="64.77" y="0" drill="1.016" rot="R90"/>
<pad name="62" x="67.31" y="0" drill="1.016" rot="R90"/>
<pad name="63" x="69.85" y="0" drill="1.016" rot="R90"/>
<pad name="64" x="72.39" y="0" drill="1.016" rot="R90"/>
<pad name="65" x="74.93" y="0" drill="1.016" rot="R90"/>
<pad name="66" x="77.47" y="0" drill="1.016" rot="R90"/>
<pad name="67" x="80.01" y="0" drill="1.016" rot="R90"/>
<pad name="68" x="82.55" y="0" drill="1.016" rot="R90"/>
<pad name="69" x="85.09" y="0" drill="1.016" rot="R90"/>
<pad name="70" x="87.63" y="0" drill="1.016" rot="R90"/>
<rectangle x1="59.436" y1="-0.254" x2="59.944" y2="0.254" layer="51"/>
<rectangle x1="56.896" y1="-0.254" x2="57.404" y2="0.254" layer="51"/>
<rectangle x1="54.356" y1="-0.254" x2="54.864" y2="0.254" layer="51"/>
<rectangle x1="51.816" y1="-0.254" x2="52.324" y2="0.254" layer="51"/>
<rectangle x1="49.276" y1="-0.254" x2="49.784" y2="0.254" layer="51"/>
<rectangle x1="46.736" y1="-0.254" x2="47.244" y2="0.254" layer="51"/>
<rectangle x1="44.196" y1="-0.254" x2="44.704" y2="0.254" layer="51"/>
<rectangle x1="41.656" y1="-0.254" x2="42.164" y2="0.254" layer="51"/>
<rectangle x1="39.116" y1="-0.254" x2="39.624" y2="0.254" layer="51"/>
<rectangle x1="36.576" y1="-0.254" x2="37.084" y2="0.254" layer="51"/>
<rectangle x1="34.036" y1="-0.254" x2="34.544" y2="0.254" layer="51"/>
<rectangle x1="31.496" y1="-0.254" x2="32.004" y2="0.254" layer="51"/>
<rectangle x1="28.956" y1="-0.254" x2="29.464" y2="0.254" layer="51"/>
<rectangle x1="26.416" y1="-0.254" x2="26.924" y2="0.254" layer="51"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="61.976" y1="-0.254" x2="62.484" y2="0.254" layer="51"/>
<rectangle x1="64.516" y1="-0.254" x2="65.024" y2="0.254" layer="51"/>
<rectangle x1="67.056" y1="-0.254" x2="67.564" y2="0.254" layer="51"/>
<rectangle x1="69.596" y1="-0.254" x2="70.104" y2="0.254" layer="51"/>
<rectangle x1="72.136" y1="-0.254" x2="72.644" y2="0.254" layer="51"/>
<rectangle x1="74.676" y1="-0.254" x2="75.184" y2="0.254" layer="51"/>
<rectangle x1="77.216" y1="-0.254" x2="77.724" y2="0.254" layer="51"/>
<rectangle x1="79.756" y1="-0.254" x2="80.264" y2="0.254" layer="51"/>
<rectangle x1="82.296" y1="-0.254" x2="82.804" y2="0.254" layer="51"/>
<rectangle x1="84.836" y1="-0.254" x2="85.344" y2="0.254" layer="51"/>
<rectangle x1="87.376" y1="-0.254" x2="87.884" y2="0.254" layer="51"/>
<wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
</package>
<package name="1X100">
<description>&lt;b&gt;PIN HEADER 100 pol.&lt;/b&gt; Grid 2.54mm&lt;p&gt;</description>
<wire x1="-91.44" y1="0.635" x2="-90.805" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-90.805" y1="1.27" x2="-89.535" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-89.535" y1="1.27" x2="-88.9" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-88.9" y1="-0.635" x2="-89.535" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-89.535" y1="-1.27" x2="-90.805" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-90.805" y1="-1.27" x2="-91.44" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-95.885" y1="1.27" x2="-94.615" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-94.615" y1="1.27" x2="-93.98" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-93.98" y1="-0.635" x2="-94.615" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-93.98" y1="0.635" x2="-93.345" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-93.345" y1="1.27" x2="-92.075" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-92.075" y1="1.27" x2="-91.44" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-91.44" y1="-0.635" x2="-92.075" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-92.075" y1="-1.27" x2="-93.345" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-93.345" y1="-1.27" x2="-93.98" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-99.06" y1="0.635" x2="-98.425" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-98.425" y1="1.27" x2="-97.155" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-97.155" y1="1.27" x2="-96.52" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-96.52" y1="-0.635" x2="-97.155" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-97.155" y1="-1.27" x2="-98.425" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-98.425" y1="-1.27" x2="-99.06" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-95.885" y1="1.27" x2="-96.52" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-96.52" y1="-0.635" x2="-95.885" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-94.615" y1="-1.27" x2="-95.885" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-103.505" y1="1.27" x2="-102.235" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-102.235" y1="1.27" x2="-101.6" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-101.6" y1="-0.635" x2="-102.235" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-101.6" y1="0.635" x2="-100.965" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-100.965" y1="1.27" x2="-99.695" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-99.695" y1="1.27" x2="-99.06" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-99.06" y1="-0.635" x2="-99.695" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-99.695" y1="-1.27" x2="-100.965" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-100.965" y1="-1.27" x2="-101.6" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-106.68" y1="0.635" x2="-106.045" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-106.045" y1="1.27" x2="-104.775" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-104.775" y1="1.27" x2="-104.14" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-104.14" y1="-0.635" x2="-104.775" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-104.775" y1="-1.27" x2="-106.045" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-106.045" y1="-1.27" x2="-106.68" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-103.505" y1="1.27" x2="-104.14" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-104.14" y1="-0.635" x2="-103.505" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-102.235" y1="-1.27" x2="-103.505" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-111.125" y1="1.27" x2="-109.855" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-109.855" y1="1.27" x2="-109.22" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-109.22" y1="-0.635" x2="-109.855" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-109.22" y1="0.635" x2="-108.585" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-108.585" y1="1.27" x2="-107.315" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-107.315" y1="1.27" x2="-106.68" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-106.68" y1="-0.635" x2="-107.315" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-107.315" y1="-1.27" x2="-108.585" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-108.585" y1="-1.27" x2="-109.22" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-114.3" y1="0.635" x2="-113.665" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-113.665" y1="1.27" x2="-112.395" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-112.395" y1="1.27" x2="-111.76" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-111.76" y1="-0.635" x2="-112.395" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-112.395" y1="-1.27" x2="-113.665" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-113.665" y1="-1.27" x2="-114.3" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-111.125" y1="1.27" x2="-111.76" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-111.76" y1="-0.635" x2="-111.125" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-109.855" y1="-1.27" x2="-111.125" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-118.745" y1="1.27" x2="-117.475" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-117.475" y1="1.27" x2="-116.84" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-116.84" y1="-0.635" x2="-117.475" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-116.84" y1="0.635" x2="-116.205" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-116.205" y1="1.27" x2="-114.935" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-114.935" y1="1.27" x2="-114.3" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-114.3" y1="-0.635" x2="-114.935" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-114.935" y1="-1.27" x2="-116.205" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-116.205" y1="-1.27" x2="-116.84" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-121.92" y1="0.635" x2="-121.285" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-121.285" y1="1.27" x2="-120.015" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-120.015" y1="1.27" x2="-119.38" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-119.38" y1="-0.635" x2="-120.015" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-120.015" y1="-1.27" x2="-121.285" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-121.285" y1="-1.27" x2="-121.92" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-118.745" y1="1.27" x2="-119.38" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-119.38" y1="-0.635" x2="-118.745" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-117.475" y1="-1.27" x2="-118.745" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-126.365" y1="1.27" x2="-125.095" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-125.095" y1="1.27" x2="-124.46" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-124.46" y1="-0.635" x2="-125.095" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-124.46" y1="0.635" x2="-123.825" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-123.825" y1="1.27" x2="-122.555" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-122.555" y1="1.27" x2="-121.92" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-121.92" y1="-0.635" x2="-122.555" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-122.555" y1="-1.27" x2="-123.825" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-123.825" y1="-1.27" x2="-124.46" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-127" y1="0.635" x2="-127" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-126.365" y1="1.27" x2="-127" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-127" y1="-0.635" x2="-126.365" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-125.095" y1="-1.27" x2="-126.365" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-78.105" y1="1.27" x2="-78.74" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-78.74" y1="-0.635" x2="-78.105" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-75.565" y1="1.27" x2="-76.2" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-76.2" y1="-0.635" x2="-75.565" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-70.485" y1="1.27" x2="-71.12" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-71.12" y1="-0.635" x2="-70.485" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-67.945" y1="1.27" x2="-68.58" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-68.58" y1="-0.635" x2="-67.945" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-62.865" y1="1.27" x2="-63.5" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-63.5" y1="-0.635" x2="-62.865" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-60.325" y1="1.27" x2="-60.96" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-60.96" y1="-0.635" x2="-60.325" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-55.245" y1="1.27" x2="-55.88" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-55.88" y1="-0.635" x2="-55.245" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-52.705" y1="1.27" x2="-53.34" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-53.34" y1="-0.635" x2="-52.705" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-30.48" y1="0.635" x2="-29.845" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="-1.27" x2="-30.48" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-33.02" y1="0.635" x2="-32.385" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-32.385" y1="-1.27" x2="-33.02" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="0.635" x2="-37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-37.465" y1="-1.27" x2="-38.1" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-34.925" y1="1.27" x2="-35.56" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-35.56" y1="-0.635" x2="-34.925" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-42.545" y1="1.27" x2="-41.275" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="1.27" x2="-40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="-0.635" x2="-41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-40.64" y1="0.635" x2="-40.005" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-40.005" y1="1.27" x2="-38.735" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="1.27" x2="-38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-38.1" y1="-0.635" x2="-38.735" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-38.735" y1="-1.27" x2="-40.005" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-40.005" y1="-1.27" x2="-40.64" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-45.72" y1="0.635" x2="-45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-45.085" y1="1.27" x2="-43.815" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="1.27" x2="-43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-43.18" y1="-0.635" x2="-43.815" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="-1.27" x2="-45.085" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-45.085" y1="-1.27" x2="-45.72" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-42.545" y1="1.27" x2="-43.18" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-43.18" y1="-0.635" x2="-42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="-1.27" x2="-42.545" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-50.165" y1="1.27" x2="-48.895" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-48.895" y1="1.27" x2="-48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-48.26" y1="-0.635" x2="-48.895" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-48.26" y1="0.635" x2="-47.625" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-47.625" y1="1.27" x2="-46.355" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-46.355" y1="1.27" x2="-45.72" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-45.72" y1="-0.635" x2="-46.355" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-46.355" y1="-1.27" x2="-47.625" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-47.625" y1="-1.27" x2="-48.26" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-50.165" y1="1.27" x2="-50.8" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-50.8" y1="-0.635" x2="-50.165" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-48.895" y1="-1.27" x2="-50.165" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-125.73" y="0" drill="1.016" rot="R90"/>
<pad name="2" x="-123.19" y="0" drill="1.016" rot="R90"/>
<pad name="3" x="-120.65" y="0" drill="1.016" rot="R90"/>
<pad name="4" x="-118.11" y="0" drill="1.016" rot="R90"/>
<pad name="5" x="-115.57" y="0" drill="1.016" rot="R90"/>
<pad name="6" x="-113.03" y="0" drill="1.016" rot="R90"/>
<pad name="7" x="-110.49" y="0" drill="1.016" rot="R90"/>
<pad name="8" x="-107.95" y="0" drill="1.016" rot="R90"/>
<pad name="9" x="-105.41" y="0" drill="1.016" rot="R90"/>
<pad name="10" x="-102.87" y="0" drill="1.016" rot="R90"/>
<pad name="11" x="-100.33" y="0" drill="1.016" rot="R90"/>
<pad name="12" x="-97.79" y="0" drill="1.016" rot="R90"/>
<pad name="13" x="-95.25" y="0" drill="1.016" rot="R90"/>
<pad name="14" x="-92.71" y="0" drill="1.016" rot="R90"/>
<pad name="15" x="-90.17" y="0" drill="1.016" rot="R90"/>
<pad name="16" x="-87.63" y="0" drill="1.016" rot="R90"/>
<pad name="17" x="-85.09" y="0" drill="1.016" rot="R90"/>
<pad name="18" x="-82.55" y="0" drill="1.016" rot="R90"/>
<pad name="19" x="-80.01" y="0" drill="1.016" rot="R90"/>
<pad name="20" x="-77.47" y="0" drill="1.016" rot="R90"/>
<pad name="21" x="-74.93" y="0" drill="1.016" rot="R90"/>
<pad name="22" x="-72.39" y="0" drill="1.016" rot="R90"/>
<pad name="23" x="-69.85" y="0" drill="1.016" rot="R90"/>
<pad name="24" x="-67.31" y="0" drill="1.016" rot="R90"/>
<pad name="25" x="-64.77" y="0" drill="1.016" rot="R90"/>
<pad name="26" x="-62.23" y="0" drill="1.016" rot="R90"/>
<pad name="27" x="-59.69" y="0" drill="1.016" rot="R90"/>
<pad name="28" x="-57.15" y="0" drill="1.016" rot="R90"/>
<pad name="29" x="-54.61" y="0" drill="1.016" rot="R90"/>
<pad name="30" x="-52.07" y="0" drill="1.016" rot="R90"/>
<pad name="31" x="-49.53" y="0" drill="1.016" rot="R90"/>
<pad name="32" x="-46.99" y="0" drill="1.016" rot="R90"/>
<pad name="33" x="-44.45" y="0" drill="1.016" rot="R90"/>
<pad name="34" x="-41.91" y="0" drill="1.016" rot="R90"/>
<pad name="35" x="-39.37" y="0" drill="1.016" rot="R90"/>
<pad name="36" x="-36.83" y="0" drill="1.016" rot="R90"/>
<pad name="37" x="-34.29" y="0" drill="1.016" rot="R90"/>
<pad name="38" x="-31.75" y="0" drill="1.016" rot="R90"/>
<pad name="39" x="-29.21" y="0" drill="1.016" rot="R90"/>
<pad name="40" x="-26.67" y="0" drill="1.016" rot="R90"/>
<text x="-127.0762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-127" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-90.424" y1="-0.254" x2="-89.916" y2="0.254" layer="51"/>
<rectangle x1="-92.964" y1="-0.254" x2="-92.456" y2="0.254" layer="51"/>
<rectangle x1="-95.504" y1="-0.254" x2="-94.996" y2="0.254" layer="51"/>
<rectangle x1="-98.044" y1="-0.254" x2="-97.536" y2="0.254" layer="51"/>
<rectangle x1="-100.584" y1="-0.254" x2="-100.076" y2="0.254" layer="51"/>
<rectangle x1="-103.124" y1="-0.254" x2="-102.616" y2="0.254" layer="51"/>
<rectangle x1="-105.664" y1="-0.254" x2="-105.156" y2="0.254" layer="51"/>
<rectangle x1="-108.204" y1="-0.254" x2="-107.696" y2="0.254" layer="51"/>
<rectangle x1="-110.744" y1="-0.254" x2="-110.236" y2="0.254" layer="51"/>
<rectangle x1="-113.284" y1="-0.254" x2="-112.776" y2="0.254" layer="51"/>
<rectangle x1="-115.824" y1="-0.254" x2="-115.316" y2="0.254" layer="51"/>
<rectangle x1="-118.364" y1="-0.254" x2="-117.856" y2="0.254" layer="51"/>
<rectangle x1="-120.904" y1="-0.254" x2="-120.396" y2="0.254" layer="51"/>
<rectangle x1="-123.444" y1="-0.254" x2="-122.936" y2="0.254" layer="51"/>
<rectangle x1="-125.984" y1="-0.254" x2="-125.476" y2="0.254" layer="51"/>
<rectangle x1="-39.624" y1="-0.254" x2="-39.116" y2="0.254" layer="51"/>
<rectangle x1="-42.164" y1="-0.254" x2="-41.656" y2="0.254" layer="51"/>
<rectangle x1="-44.704" y1="-0.254" x2="-44.196" y2="0.254" layer="51"/>
<rectangle x1="-47.244" y1="-0.254" x2="-46.736" y2="0.254" layer="51"/>
<rectangle x1="-49.784" y1="-0.254" x2="-49.276" y2="0.254" layer="51"/>
<wire x1="10.16" y1="0.635" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="10.16" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.08" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="0.635" x2="-12.065" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.27" x2="-12.7" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0.635" x2="-14.605" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.27" x2="-15.24" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-19.685" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.32" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="0.635" x2="-22.225" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-1.27" x2="-22.86" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="23.495" y1="1.27" x2="22.86" y2="0.635" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="23.495" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="26.035" y1="1.27" x2="25.4" y2="0.635" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="26.035" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="31.115" y1="1.27" x2="30.48" y2="0.635" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="31.115" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="1.27" x2="33.02" y2="0.635" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="33.655" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="1.27" x2="38.1" y2="0.635" width="0.1524" layer="21"/>
<wire x1="38.1" y1="-0.635" x2="38.735" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="41.275" y1="1.27" x2="40.64" y2="0.635" width="0.1524" layer="21"/>
<wire x1="40.64" y1="-0.635" x2="41.275" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="1.27" x2="45.72" y2="0.635" width="0.1524" layer="21"/>
<wire x1="45.72" y1="-0.635" x2="46.355" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="48.895" y1="1.27" x2="48.26" y2="0.635" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-0.635" x2="48.895" y2="-1.27" width="0.1524" layer="21"/>
<pad name="41" x="-24.13" y="0" drill="1.016" rot="R90"/>
<pad name="42" x="-21.59" y="0" drill="1.016" rot="R90"/>
<pad name="43" x="-19.05" y="0" drill="1.016" rot="R90"/>
<pad name="44" x="-16.51" y="0" drill="1.016" rot="R90"/>
<pad name="45" x="-13.97" y="0" drill="1.016" rot="R90"/>
<pad name="46" x="-11.43" y="0" drill="1.016" rot="R90"/>
<pad name="47" x="-8.89" y="0" drill="1.016" rot="R90"/>
<pad name="48" x="-6.35" y="0" drill="1.016" rot="R90"/>
<pad name="49" x="-3.81" y="0" drill="1.016" rot="R90"/>
<pad name="50" x="-1.27" y="0" drill="1.016" rot="R90"/>
<pad name="51" x="1.27" y="0" drill="1.016" rot="R90"/>
<pad name="52" x="3.81" y="0" drill="1.016" rot="R90"/>
<pad name="53" x="6.35" y="0" drill="1.016" rot="R90"/>
<pad name="54" x="8.89" y="0" drill="1.016" rot="R90"/>
<pad name="55" x="11.43" y="0" drill="1.016" rot="R90"/>
<pad name="56" x="13.97" y="0" drill="1.016" rot="R90"/>
<pad name="57" x="16.51" y="0" drill="1.016" rot="R90"/>
<pad name="58" x="19.05" y="0" drill="1.016" rot="R90"/>
<pad name="59" x="21.59" y="0" drill="1.016" rot="R90"/>
<pad name="60" x="24.13" y="0" drill="1.016" rot="R90"/>
<pad name="61" x="26.67" y="0" drill="1.016" rot="R90"/>
<pad name="62" x="29.21" y="0" drill="1.016" rot="R90"/>
<pad name="63" x="31.75" y="0" drill="1.016" rot="R90"/>
<pad name="64" x="34.29" y="0" drill="1.016" rot="R90"/>
<pad name="65" x="36.83" y="0" drill="1.016" rot="R90"/>
<pad name="66" x="39.37" y="0" drill="1.016" rot="R90"/>
<pad name="67" x="41.91" y="0" drill="1.016" rot="R90"/>
<pad name="68" x="44.45" y="0" drill="1.016" rot="R90"/>
<pad name="69" x="46.99" y="0" drill="1.016" rot="R90"/>
<pad name="70" x="49.53" y="0" drill="1.016" rot="R90"/>
<wire x1="97.155" y1="1.27" x2="98.425" y2="1.27" width="0.1524" layer="21"/>
<wire x1="98.425" y1="1.27" x2="99.06" y2="0.635" width="0.1524" layer="21"/>
<wire x1="99.06" y1="-0.635" x2="98.425" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="93.98" y1="0.635" x2="94.615" y2="1.27" width="0.1524" layer="21"/>
<wire x1="94.615" y1="1.27" x2="95.885" y2="1.27" width="0.1524" layer="21"/>
<wire x1="95.885" y1="1.27" x2="96.52" y2="0.635" width="0.1524" layer="21"/>
<wire x1="96.52" y1="-0.635" x2="95.885" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="95.885" y1="-1.27" x2="94.615" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="94.615" y1="-1.27" x2="93.98" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="97.155" y1="1.27" x2="96.52" y2="0.635" width="0.1524" layer="21"/>
<wire x1="96.52" y1="-0.635" x2="97.155" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="98.425" y1="-1.27" x2="97.155" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="89.535" y1="1.27" x2="90.805" y2="1.27" width="0.1524" layer="21"/>
<wire x1="90.805" y1="1.27" x2="91.44" y2="0.635" width="0.1524" layer="21"/>
<wire x1="91.44" y1="-0.635" x2="90.805" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="91.44" y1="0.635" x2="92.075" y2="1.27" width="0.1524" layer="21"/>
<wire x1="92.075" y1="1.27" x2="93.345" y2="1.27" width="0.1524" layer="21"/>
<wire x1="93.345" y1="1.27" x2="93.98" y2="0.635" width="0.1524" layer="21"/>
<wire x1="93.98" y1="-0.635" x2="93.345" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="93.345" y1="-1.27" x2="92.075" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="92.075" y1="-1.27" x2="91.44" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="86.36" y1="0.635" x2="86.995" y2="1.27" width="0.1524" layer="21"/>
<wire x1="86.995" y1="-1.27" x2="86.36" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="89.535" y1="1.27" x2="88.9" y2="0.635" width="0.1524" layer="21"/>
<wire x1="88.9" y1="-0.635" x2="89.535" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="90.805" y1="-1.27" x2="89.535" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="83.82" y1="0.635" x2="84.455" y2="1.27" width="0.1524" layer="21"/>
<wire x1="84.455" y1="-1.27" x2="83.82" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="78.74" y1="0.635" x2="79.375" y2="1.27" width="0.1524" layer="21"/>
<wire x1="79.375" y1="-1.27" x2="78.74" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="76.2" y1="0.635" x2="76.835" y2="1.27" width="0.1524" layer="21"/>
<wire x1="76.835" y1="-1.27" x2="76.2" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="71.12" y1="0.635" x2="71.755" y2="1.27" width="0.1524" layer="21"/>
<wire x1="71.755" y1="-1.27" x2="71.12" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="68.58" y1="0.635" x2="69.215" y2="1.27" width="0.1524" layer="21"/>
<wire x1="69.215" y1="-1.27" x2="68.58" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="63.5" y1="0.635" x2="64.135" y2="1.27" width="0.1524" layer="21"/>
<wire x1="64.135" y1="-1.27" x2="63.5" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="60.96" y1="0.635" x2="61.595" y2="1.27" width="0.1524" layer="21"/>
<wire x1="61.595" y1="-1.27" x2="60.96" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="99.695" y1="1.27" x2="100.965" y2="1.27" width="0.1524" layer="21"/>
<wire x1="100.965" y1="1.27" x2="101.6" y2="0.635" width="0.1524" layer="21"/>
<wire x1="101.6" y1="-0.635" x2="100.965" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="99.695" y1="1.27" x2="99.06" y2="0.635" width="0.1524" layer="21"/>
<wire x1="99.06" y1="-0.635" x2="99.695" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="100.965" y1="-1.27" x2="99.695" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="102.235" y1="1.27" x2="103.505" y2="1.27" width="0.1524" layer="21"/>
<wire x1="103.505" y1="1.27" x2="104.14" y2="0.635" width="0.1524" layer="21"/>
<wire x1="104.14" y1="-0.635" x2="103.505" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="102.235" y1="1.27" x2="101.6" y2="0.635" width="0.1524" layer="21"/>
<wire x1="101.6" y1="-0.635" x2="102.235" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="103.505" y1="-1.27" x2="102.235" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="104.775" y1="1.27" x2="106.045" y2="1.27" width="0.1524" layer="21"/>
<wire x1="106.045" y1="1.27" x2="106.68" y2="0.635" width="0.1524" layer="21"/>
<wire x1="106.68" y1="-0.635" x2="106.045" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="104.775" y1="1.27" x2="104.14" y2="0.635" width="0.1524" layer="21"/>
<wire x1="104.14" y1="-0.635" x2="104.775" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="106.045" y1="-1.27" x2="104.775" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="107.315" y1="1.27" x2="108.585" y2="1.27" width="0.1524" layer="21"/>
<wire x1="108.585" y1="1.27" x2="109.22" y2="0.635" width="0.1524" layer="21"/>
<wire x1="109.22" y1="-0.635" x2="108.585" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="107.315" y1="1.27" x2="106.68" y2="0.635" width="0.1524" layer="21"/>
<wire x1="106.68" y1="-0.635" x2="107.315" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="108.585" y1="-1.27" x2="107.315" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="109.855" y1="1.27" x2="111.125" y2="1.27" width="0.1524" layer="21"/>
<wire x1="111.125" y1="1.27" x2="111.76" y2="0.635" width="0.1524" layer="21"/>
<wire x1="111.76" y1="-0.635" x2="111.125" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="109.855" y1="1.27" x2="109.22" y2="0.635" width="0.1524" layer="21"/>
<wire x1="109.22" y1="-0.635" x2="109.855" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="111.125" y1="-1.27" x2="109.855" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="112.395" y1="1.27" x2="113.665" y2="1.27" width="0.1524" layer="21"/>
<wire x1="113.665" y1="1.27" x2="114.3" y2="0.635" width="0.1524" layer="21"/>
<wire x1="114.3" y1="-0.635" x2="113.665" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="112.395" y1="1.27" x2="111.76" y2="0.635" width="0.1524" layer="21"/>
<wire x1="111.76" y1="-0.635" x2="112.395" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="113.665" y1="-1.27" x2="112.395" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="114.935" y1="1.27" x2="116.205" y2="1.27" width="0.1524" layer="21"/>
<wire x1="116.205" y1="1.27" x2="116.84" y2="0.635" width="0.1524" layer="21"/>
<wire x1="116.84" y1="-0.635" x2="116.205" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="114.935" y1="1.27" x2="114.3" y2="0.635" width="0.1524" layer="21"/>
<wire x1="114.3" y1="-0.635" x2="114.935" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="116.205" y1="-1.27" x2="114.935" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="117.475" y1="1.27" x2="118.745" y2="1.27" width="0.1524" layer="21"/>
<wire x1="118.745" y1="1.27" x2="119.38" y2="0.635" width="0.1524" layer="21"/>
<wire x1="119.38" y1="-0.635" x2="118.745" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="117.475" y1="1.27" x2="116.84" y2="0.635" width="0.1524" layer="21"/>
<wire x1="116.84" y1="-0.635" x2="117.475" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="118.745" y1="-1.27" x2="117.475" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="120.015" y1="1.27" x2="121.285" y2="1.27" width="0.1524" layer="21"/>
<wire x1="121.285" y1="1.27" x2="121.92" y2="0.635" width="0.1524" layer="21"/>
<wire x1="121.92" y1="-0.635" x2="121.285" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="120.015" y1="1.27" x2="119.38" y2="0.635" width="0.1524" layer="21"/>
<wire x1="119.38" y1="-0.635" x2="120.015" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="121.285" y1="-1.27" x2="120.015" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="122.555" y1="1.27" x2="123.825" y2="1.27" width="0.1524" layer="21"/>
<wire x1="123.825" y1="1.27" x2="124.46" y2="0.635" width="0.1524" layer="21"/>
<wire x1="124.46" y1="-0.635" x2="123.825" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="122.555" y1="1.27" x2="121.92" y2="0.635" width="0.1524" layer="21"/>
<wire x1="121.92" y1="-0.635" x2="122.555" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="123.825" y1="-1.27" x2="122.555" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="125.095" y1="1.27" x2="126.365" y2="1.27" width="0.1524" layer="21"/>
<wire x1="126.365" y1="1.27" x2="127" y2="0.635" width="0.1524" layer="21"/>
<wire x1="127" y1="-0.635" x2="126.365" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="125.095" y1="1.27" x2="124.46" y2="0.635" width="0.1524" layer="21"/>
<wire x1="124.46" y1="-0.635" x2="125.095" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="126.365" y1="-1.27" x2="125.095" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="127" y1="0.635" x2="127" y2="-0.635" width="0.1524" layer="21"/>
<pad name="71" x="52.07" y="0" drill="1.016" rot="R90"/>
<pad name="72" x="54.61" y="0" drill="1.016" rot="R90"/>
<pad name="73" x="57.15" y="0" drill="1.016" rot="R90"/>
<pad name="74" x="59.69" y="0" drill="1.016" rot="R90"/>
<pad name="75" x="62.23" y="0" drill="1.016" rot="R90"/>
<pad name="76" x="64.77" y="0" drill="1.016" rot="R90"/>
<pad name="77" x="67.31" y="0" drill="1.016" rot="R90"/>
<pad name="78" x="69.85" y="0" drill="1.016" rot="R90"/>
<pad name="79" x="72.39" y="0" drill="1.016" rot="R90"/>
<pad name="80" x="74.93" y="0" drill="1.016" rot="R90"/>
<pad name="81" x="77.47" y="0" drill="1.016" rot="R90"/>
<pad name="82" x="80.01" y="0" drill="1.016" rot="R90"/>
<pad name="83" x="82.55" y="0" drill="1.016" rot="R90"/>
<pad name="84" x="85.09" y="0" drill="1.016" rot="R90"/>
<pad name="85" x="87.63" y="0" drill="1.016" rot="R90"/>
<pad name="86" x="90.17" y="0" drill="1.016" rot="R90"/>
<pad name="87" x="92.71" y="0" drill="1.016" rot="R90"/>
<pad name="88" x="95.25" y="0" drill="1.016" rot="R90"/>
<pad name="89" x="97.79" y="0" drill="1.016" rot="R90"/>
<pad name="90" x="100.33" y="0" drill="1.016" rot="R90"/>
<pad name="91" x="102.87" y="0" drill="1.016" rot="R90"/>
<pad name="92" x="105.41" y="0" drill="1.016" rot="R90"/>
<pad name="93" x="107.95" y="0" drill="1.016" rot="R90"/>
<pad name="94" x="110.49" y="0" drill="1.016" rot="R90"/>
<pad name="95" x="113.03" y="0" drill="1.016" rot="R90"/>
<pad name="96" x="115.57" y="0" drill="1.016" rot="R90"/>
<pad name="97" x="118.11" y="0" drill="1.016" rot="R90"/>
<pad name="98" x="120.65" y="0" drill="1.016" rot="R90"/>
<pad name="99" x="123.19" y="0" drill="1.016" rot="R90"/>
<pad name="100" x="125.73" y="0" drill="1.016" rot="R90"/>
<rectangle x1="97.536" y1="-0.254" x2="98.044" y2="0.254" layer="51"/>
<rectangle x1="94.996" y1="-0.254" x2="95.504" y2="0.254" layer="51"/>
<rectangle x1="92.456" y1="-0.254" x2="92.964" y2="0.254" layer="51"/>
<rectangle x1="89.916" y1="-0.254" x2="90.424" y2="0.254" layer="51"/>
<rectangle x1="100.076" y1="-0.254" x2="100.584" y2="0.254" layer="51"/>
<rectangle x1="102.616" y1="-0.254" x2="103.124" y2="0.254" layer="51"/>
<rectangle x1="105.156" y1="-0.254" x2="105.664" y2="0.254" layer="51"/>
<rectangle x1="107.696" y1="-0.254" x2="108.204" y2="0.254" layer="51"/>
<rectangle x1="110.236" y1="-0.254" x2="110.744" y2="0.254" layer="51"/>
<rectangle x1="112.776" y1="-0.254" x2="113.284" y2="0.254" layer="51"/>
<rectangle x1="115.316" y1="-0.254" x2="115.824" y2="0.254" layer="51"/>
<rectangle x1="117.856" y1="-0.254" x2="118.364" y2="0.254" layer="51"/>
<rectangle x1="120.396" y1="-0.254" x2="120.904" y2="0.254" layer="51"/>
<rectangle x1="122.936" y1="-0.254" x2="123.444" y2="0.254" layer="51"/>
<rectangle x1="125.476" y1="-0.254" x2="125.984" y2="0.254" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="PINHD12">
<wire x1="-6.35" y1="-17.78" x2="1.27" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-17.78" x2="1.27" y2="15.24" width="0.4064" layer="94"/>
<wire x1="1.27" y1="15.24" x2="-6.35" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="15.24" x2="-6.35" y2="-17.78" width="0.4064" layer="94"/>
<text x="-6.35" y="15.875" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="9" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="11" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD4">
<wire x1="-6.35" y1="-5.08" x2="1.27" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD8">
<wire x1="-6.35" y1="-10.16" x2="1.27" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<wire x1="1.27" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="12.7" x2="-6.35" y2="-10.16" width="0.4064" layer="94"/>
<text x="-6.35" y="13.335" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD10">
<wire x1="-6.35" y1="-15.24" x2="1.27" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-15.24" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="12.7" x2="-6.35" y2="-15.24" width="0.4064" layer="94"/>
<text x="-6.35" y="-17.78" size="1.778" layer="96">&gt;VALUE</text>
<pin name="9" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X10">
<wire x1="-6.35" y1="-15.24" x2="8.89" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-15.24" x2="8.89" y2="12.7" width="0.4064" layer="94"/>
<wire x1="8.89" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="4" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD11">
<wire x1="1.27" y1="-15.24" x2="1.27" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="15.24" x2="-6.35" y2="-15.24" width="0.4064" layer="94"/>
</symbol>
<symbol name="PINH2X11">
<wire x1="8.89" y1="-15.24" x2="8.89" y2="15.24" width="0.4064" layer="94"/>
<wire x1="8.89" y1="15.24" x2="-6.35" y2="15.24" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X12">
<wire x1="-6.35" y1="-17.78" x2="8.89" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-17.78" x2="8.89" y2="15.24" width="0.4064" layer="94"/>
<pin name="23" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD13">
<wire x1="1.27" y1="-17.78" x2="1.27" y2="17.78" width="0.4064" layer="94"/>
<wire x1="1.27" y1="17.78" x2="-6.35" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="17.78" x2="-6.35" y2="-17.78" width="0.4064" layer="94"/>
<text x="-6.35" y="18.415" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="9" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="11" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="13" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X13">
<wire x1="8.89" y1="-17.78" x2="8.89" y2="17.78" width="0.4064" layer="94"/>
<wire x1="8.89" y1="17.78" x2="-6.35" y2="17.78" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD14">
<wire x1="-6.35" y1="-20.32" x2="1.27" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-20.32" x2="1.27" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="17.78" x2="-6.35" y2="-20.32" width="0.4064" layer="94"/>
<text x="-6.35" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<pin name="14" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X14">
<wire x1="-6.35" y1="-20.32" x2="8.89" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-20.32" x2="8.89" y2="17.78" width="0.4064" layer="94"/>
<pin name="27" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD15">
<wire x1="1.27" y1="-20.32" x2="1.27" y2="20.32" width="0.4064" layer="94"/>
<wire x1="1.27" y1="20.32" x2="-6.35" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="20.32" x2="-6.35" y2="-20.32" width="0.4064" layer="94"/>
<text x="-6.35" y="20.955" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="9" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="11" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="13" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="15" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X15">
<wire x1="8.89" y1="-20.32" x2="8.89" y2="20.32" width="0.4064" layer="94"/>
<wire x1="8.89" y1="20.32" x2="-6.35" y2="20.32" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD16">
<wire x1="-6.35" y1="-22.86" x2="1.27" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-22.86" x2="1.27" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="20.32" x2="-6.35" y2="-22.86" width="0.4064" layer="94"/>
<text x="-6.35" y="-25.4" size="1.778" layer="96">&gt;VALUE</text>
<pin name="16" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X16">
<wire x1="-6.35" y1="-22.86" x2="8.89" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-22.86" x2="8.89" y2="20.32" width="0.4064" layer="94"/>
<pin name="31" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD18">
<wire x1="-6.35" y1="-25.4" x2="1.27" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-25.4" x2="1.27" y2="22.86" width="0.4064" layer="94"/>
<wire x1="1.27" y1="22.86" x2="-6.35" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="22.86" x2="-6.35" y2="-25.4" width="0.4064" layer="94"/>
<text x="-6.35" y="23.495" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="11" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="13" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="15" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="17" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X18">
<wire x1="-6.35" y1="-25.4" x2="8.89" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-25.4" x2="8.89" y2="22.86" width="0.4064" layer="94"/>
<wire x1="8.89" y1="22.86" x2="-6.35" y2="22.86" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD2">
<wire x1="-6.35" y1="-2.54" x2="1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-2.54" width="0.4064" layer="94"/>
<text x="-6.35" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD20">
<wire x1="-6.35" y1="-27.94" x2="1.27" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-27.94" x2="1.27" y2="25.4" width="0.4064" layer="94"/>
<wire x1="1.27" y1="25.4" x2="-6.35" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="25.4" x2="-6.35" y2="-27.94" width="0.4064" layer="94"/>
<text x="-6.35" y="26.035" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-30.48" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="13" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="15" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="17" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="19" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X20">
<wire x1="-6.35" y1="-27.94" x2="8.89" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-27.94" x2="8.89" y2="25.4" width="0.4064" layer="94"/>
<wire x1="8.89" y1="25.4" x2="-6.35" y2="25.4" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="37" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="39" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD22">
<wire x1="-6.35" y1="-30.48" x2="1.27" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-30.48" x2="1.27" y2="27.94" width="0.4064" layer="94"/>
<wire x1="1.27" y1="27.94" x2="-6.35" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="27.94" x2="-6.35" y2="-30.48" width="0.4064" layer="94"/>
<text x="-6.35" y="28.575" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-33.02" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="15" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="17" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="19" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="21" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X22">
<wire x1="-6.35" y1="-30.48" x2="8.89" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-30.48" x2="8.89" y2="27.94" width="0.4064" layer="94"/>
<wire x1="8.89" y1="27.94" x2="-6.35" y2="27.94" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="37" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="39" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="41" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="42" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="43" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="44" x="5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD24">
<wire x1="-6.35" y1="-33.02" x2="1.27" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-33.02" x2="1.27" y2="30.48" width="0.4064" layer="94"/>
<wire x1="1.27" y1="30.48" x2="-6.35" y2="30.48" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="30.48" x2="-6.35" y2="-33.02" width="0.4064" layer="94"/>
<text x="-6.35" y="31.115" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="17" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="19" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="21" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="23" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X24">
<wire x1="-6.35" y1="-33.02" x2="8.89" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-33.02" x2="8.89" y2="30.48" width="0.4064" layer="94"/>
<wire x1="8.89" y1="30.48" x2="-6.35" y2="30.48" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="37" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="39" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="41" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="42" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="43" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="44" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="45" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="46" x="5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="47" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="48" x="5.08" y="-30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD25">
<wire x1="1.27" y1="-33.02" x2="1.27" y2="33.02" width="0.4064" layer="94"/>
<wire x1="1.27" y1="33.02" x2="-6.35" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="33.02" x2="-6.35" y2="-33.02" width="0.4064" layer="94"/>
<text x="-6.35" y="33.655" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="19" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="21" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="23" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="25" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X25">
<wire x1="8.89" y1="-33.02" x2="8.89" y2="33.02" width="0.4064" layer="94"/>
<wire x1="8.89" y1="33.02" x2="-6.35" y2="33.02" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="37" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="39" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="41" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="42" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="43" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="44" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="45" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="46" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="47" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="48" x="5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="49" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="50" x="5.08" y="-30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X2">
<wire x1="-8.89" y1="-2.54" x2="6.35" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-2.54" x2="6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="6.35" y1="5.08" x2="-8.89" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="5.08" x2="-8.89" y2="-2.54" width="0.4064" layer="94"/>
<text x="-8.89" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-8.89" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-5.08" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="2.54" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD3">
<wire x1="1.27" y1="-5.08" x2="1.27" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<pin name="3" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD30">
<wire x1="-6.35" y1="-40.64" x2="1.27" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-40.64" x2="1.27" y2="38.1" width="0.4064" layer="94"/>
<wire x1="1.27" y1="38.1" x2="-6.35" y2="38.1" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="38.1" x2="-6.35" y2="-40.64" width="0.4064" layer="94"/>
<text x="-6.35" y="38.735" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-43.18" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="35.56" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="21" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="23" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="25" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="27" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="-2.54" y="-33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="29" x="-2.54" y="-35.56" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="-2.54" y="-38.1" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X30">
<wire x1="-6.35" y1="-40.64" x2="8.89" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-40.64" x2="8.89" y2="38.1" width="0.4064" layer="94"/>
<wire x1="8.89" y1="38.1" x2="-6.35" y2="38.1" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="35.56" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="33.02" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="25" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="27" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="29" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="31" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="33" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="35" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="37" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="39" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="41" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="42" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="43" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="44" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="45" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="46" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="47" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="48" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="49" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="50" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="51" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="52" x="5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="53" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="54" x="5.08" y="-30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="55" x="-2.54" y="-33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="56" x="5.08" y="-33.02" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="57" x="-2.54" y="-35.56" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="58" x="5.08" y="-35.56" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="59" x="-2.54" y="-38.1" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="60" x="5.08" y="-38.1" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X3">
<wire x1="-6.35" y1="-5.08" x2="8.89" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-5.08" x2="8.89" y2="5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X4">
<wire x1="8.89" y1="-5.08" x2="8.89" y2="7.62" width="0.4064" layer="94"/>
<wire x1="8.89" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD5">
<wire x1="-6.35" y1="-7.62" x2="1.27" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="7.62" x2="-6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-7.62" width="0.4064" layer="94"/>
<text x="-6.35" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X5">
<wire x1="-6.35" y1="-7.62" x2="8.89" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-7.62" x2="8.89" y2="7.62" width="0.4064" layer="94"/>
<pin name="10" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD6">
<wire x1="1.27" y1="-7.62" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="10.16" x2="-6.35" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="10.16" x2="-6.35" y2="-7.62" width="0.4064" layer="94"/>
<text x="-6.35" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X6">
<wire x1="-6.35" y1="-10.16" x2="8.89" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-10.16" x2="8.89" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="7.62" x2="-6.35" y2="-10.16" width="0.4064" layer="94"/>
<text x="-6.35" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="12" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD7">
<wire x1="-6.35" y1="-10.16" x2="1.27" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="10.16" x2="-6.35" y2="-10.16" width="0.4064" layer="94"/>
<pin name="7" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X7">
<wire x1="8.89" y1="-10.16" x2="8.89" y2="10.16" width="0.4064" layer="94"/>
<wire x1="8.89" y1="10.16" x2="-6.35" y2="10.16" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="8" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="10" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="12" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="14" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X8">
<wire x1="-6.35" y1="-12.7" x2="8.89" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-12.7" x2="8.89" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="10.16" x2="-6.35" y2="-12.7" width="0.4064" layer="94"/>
<text x="-6.35" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="16" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD9">
<wire x1="-6.35" y1="-12.7" x2="1.27" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-12.7" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<wire x1="1.27" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="12.7" x2="-6.35" y2="-12.7" width="0.4064" layer="94"/>
<text x="-6.35" y="13.335" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="9" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X9">
<wire x1="8.89" y1="-12.7" x2="8.89" y2="12.7" width="0.4064" layer="94"/>
<wire x1="8.89" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<pin name="2" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD1">
<wire x1="1.27" y1="-2.54" x2="1.27" y2="2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="2.54" x2="-6.35" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="2.54" x2="-6.35" y2="-2.54" width="0.4064" layer="94"/>
<text x="-6.35" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD17">
<wire x1="1.27" y1="-25.4" x2="1.27" y2="20.32" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="20.32" x2="-6.35" y2="-25.4" width="0.4064" layer="94"/>
<pin name="3" x="-2.54" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="17" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD19">
<wire x1="1.27" y1="-27.94" x2="1.27" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="22.86" x2="-6.35" y2="-27.94" width="0.4064" layer="94"/>
<pin name="5" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="19" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINH2X17">
<wire x1="8.89" y1="-22.86" x2="8.89" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="22.86" x2="-6.35" y2="-22.86" width="0.4064" layer="94"/>
</symbol>
<symbol name="PINH2X19">
<wire x1="8.89" y1="-27.94" x2="8.89" y2="22.86" width="0.4064" layer="94"/>
<pin name="37" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINHD40">
<wire x1="-6.35" y1="-53.34" x2="1.27" y2="-53.34" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-53.34" x2="1.27" y2="50.8" width="0.4064" layer="94"/>
<wire x1="1.27" y1="50.8" x2="-6.35" y2="50.8" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="50.8" x2="-6.35" y2="-53.34" width="0.4064" layer="94"/>
<text x="-6.35" y="51.435" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-55.88" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="48.26" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="45.72" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="43.18" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="40.64" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="38.1" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="35.56" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="-2.54" y="30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="9" x="-2.54" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="-2.54" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="-2.54" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="13" x="-2.54" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="-2.54" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="26" x="-2.54" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="27" x="-2.54" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="28" x="-2.54" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="29" x="-2.54" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="30" x="-2.54" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="31" x="-2.54" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="32" x="-2.54" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="33" x="-2.54" y="-33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="34" x="-2.54" y="-35.56" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="35" x="-2.54" y="-38.1" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="36" x="-2.54" y="-40.64" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="37" x="-2.54" y="-43.18" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="38" x="-2.54" y="-45.72" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="39" x="-2.54" y="-48.26" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="40" x="-2.54" y="-50.8" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="PINHD_1V">
<text x="2.54" y="-0.889" size="1.778" layer="95">&gt;NAME</text>
<text x="0" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<wire x1="0.508" y1="0.381" x2="0.762" y2="0.635" width="0.1524" layer="94"/>
<wire x1="0.762" y1="0.635" x2="1.524" y2="0.635" width="0.1524" layer="94"/>
<wire x1="1.524" y1="0.635" x2="1.778" y2="0.381" width="0.1524" layer="94"/>
<wire x1="1.778" y1="0.381" x2="1.778" y2="-0.381" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-0.381" x2="1.524" y2="-0.635" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-0.635" x2="0.762" y2="-0.635" width="0.1524" layer="94"/>
<wire x1="0.762" y1="-0.635" x2="0.508" y2="-0.381" width="0.1524" layer="94"/>
<wire x1="0.508" y1="-0.381" x2="0.508" y2="0" width="0.1524" layer="94"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.381" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0.508" y2="0" width="0.1524" layer="94"/>
</symbol>
<symbol name="PINHD_1">
</symbol>
</symbols>
<devicesets>
<deviceset name="PINHD-1X4" prefix="JP" uservalue="yes">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="PINHD4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X04">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="/90" package="1X04/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X8" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X08">
<connects>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="6" pad="6"/>
<connect gate="A" pin="7" pad="7"/>
<connect gate="A" pin="8" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X08/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X10" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD10" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X10">
<connects>
<connect gate="A" pin="10" pad="10"/>
<connect gate="A" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X10/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X10" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X10" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X10">
<connects>
<connect gate="A" pin="11" pad="11"/>
<connect gate="A" pin="12" pad="12"/>
<connect gate="A" pin="13" pad="13"/>
<connect gate="A" pin="14" pad="14"/>
<connect gate="A" pin="15" pad="15"/>
<connect gate="A" pin="16" pad="16"/>
<connect gate="A" pin="17" pad="17"/>
<connect gate="A" pin="18" pad="18"/>
<connect gate="A" pin="19" pad="19"/>
<connect gate="A" pin="20" pad="20"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X10/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X11" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD11" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X11/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X11" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X11" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X11">
<connects>
<connect gate="A" pin="21" pad="21"/>
<connect gate="A" pin="22" pad="22"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X11/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X12" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X12" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X12">
<connects>
<connect gate="A" pin="23" pad="23"/>
<connect gate="A" pin="24" pad="24"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X12/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X13" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD13" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X13/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X13" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X13" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X13">
<connects>
<connect gate="A" pin="25" pad="25"/>
<connect gate="A" pin="26" pad="26"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X13/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X14" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X14/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X14" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X14">
<connects>
<connect gate="A" pin="27" pad="27"/>
<connect gate="A" pin="28" pad="28"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X14/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X15" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD15" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X15/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X15" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X15" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X15">
<connects>
<connect gate="A" pin="29" pad="29"/>
<connect gate="A" pin="30" pad="30"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X15/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X16" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD16" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X16/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X16" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X16" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X16">
<connects>
<connect gate="A" pin="31" pad="31"/>
<connect gate="A" pin="32" pad="32"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X16/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X18" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD18" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X18/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X18" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X18" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X18">
<connects>
<connect gate="A" pin="33" pad="33"/>
<connect gate="A" pin="34" pad="34"/>
<connect gate="A" pin="35" pad="35"/>
<connect gate="A" pin="36" pad="36"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X18/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X2" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X02">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X02/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X20" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD20" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X20/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X20" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X20" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X20">
<connects>
<connect gate="A" pin="37" pad="37"/>
<connect gate="A" pin="38" pad="38"/>
<connect gate="A" pin="39" pad="39"/>
<connect gate="A" pin="40" pad="40"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X20/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X22" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD22" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X22/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X22" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X22" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X22">
<connects>
<connect gate="A" pin="41" pad="41"/>
<connect gate="A" pin="42" pad="42"/>
<connect gate="A" pin="43" pad="43"/>
<connect gate="A" pin="44" pad="44"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X22/90">
<connects>
<connect gate="A" pin="41" pad="42"/>
<connect gate="A" pin="42" pad="41"/>
<connect gate="A" pin="43" pad="44"/>
<connect gate="A" pin="44" pad="43"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X24" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD24" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X24">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X24/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X24" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X24" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X24">
<connects>
<connect gate="A" pin="45" pad="45"/>
<connect gate="A" pin="46" pad="46"/>
<connect gate="A" pin="47" pad="47"/>
<connect gate="A" pin="48" pad="48"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X24/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X25" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD25" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="_2802S-02G2" package="2802S-02G2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X25" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X25" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X25">
<connects>
<connect gate="A" pin="49" pad="49"/>
<connect gate="A" pin="50" pad="50"/>
</connects>
<technologies>
</technologies>
</device>
<device name="_57102-F08-25" package="57102-F08-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X25/90">
<connects>
<connect gate="A" pin="45" pad="46"/>
<connect gate="A" pin="46" pad="45"/>
<connect gate="A" pin="47" pad="48"/>
<connect gate="A" pin="48" pad="47"/>
<connect gate="A" pin="49" pad="50"/>
<connect gate="A" pin="50" pad="49"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X2" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X02/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X3" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD3" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X03/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X30" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD30" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X30">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X30" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X30" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X30">
<connects>
<connect gate="A" pin="51" pad="51"/>
<connect gate="A" pin="52" pad="52"/>
<connect gate="A" pin="53" pad="53"/>
<connect gate="A" pin="54" pad="54"/>
<connect gate="A" pin="55" pad="55"/>
<connect gate="A" pin="56" pad="56"/>
<connect gate="A" pin="57" pad="57"/>
<connect gate="A" pin="58" pad="58"/>
<connect gate="A" pin="59" pad="59"/>
<connect gate="A" pin="60" pad="60"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X30/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X3" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X3" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X03">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X03/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X4" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X04/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X5" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD5" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X05/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5X2MM" package="1_05X2MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X5" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X5" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X05/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X6" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD6" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="1X06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X06/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X6" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X6" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X06">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X06/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X7" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD7" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X07/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X7" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X7" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X07/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X8" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X08">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X08/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X9" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINHD9" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X09/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X9" prefix="JP" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X9" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X09/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X1" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X01">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X12" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD12" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X12">
<connects>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X12/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X17" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD17" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="1X17">
<connects>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X17/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X19" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD19" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X19">
<connects>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X19/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X17" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINH2X17" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X17">
<connects>
<connect gate="G$1" pin="20" pad="20"/>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="25" pad="25"/>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="27" pad="27"/>
<connect gate="G$1" pin="28" pad="28"/>
<connect gate="G$1" pin="29" pad="29"/>
<connect gate="G$1" pin="30" pad="30"/>
<connect gate="G$1" pin="31" pad="31"/>
<connect gate="G$1" pin="32" pad="32"/>
<connect gate="G$1" pin="33" pad="33"/>
<connect gate="G$1" pin="34" pad="34"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X17/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X19" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINH2X19" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="2X19">
<connects>
<connect gate="G$1" pin="35" pad="35"/>
<connect gate="G$1" pin="36" pad="36"/>
<connect gate="G$1" pin="37" pad="37"/>
<connect gate="G$1" pin="38" pad="38"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="2X19/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X40" prefix="JP" uservalue="yes">
<gates>
<gate name="-1" symbol="PINHD40" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X40">
<connects>
<connect gate="-1" pin="1" pad="1"/>
<connect gate="-1" pin="10" pad="10"/>
<connect gate="-1" pin="11" pad="11"/>
<connect gate="-1" pin="12" pad="12"/>
<connect gate="-1" pin="13" pad="13"/>
<connect gate="-1" pin="14" pad="14"/>
<connect gate="-1" pin="15" pad="15"/>
<connect gate="-1" pin="16" pad="16"/>
<connect gate="-1" pin="17" pad="17"/>
<connect gate="-1" pin="18" pad="18"/>
<connect gate="-1" pin="19" pad="19"/>
<connect gate="-1" pin="2" pad="2"/>
<connect gate="-1" pin="20" pad="20"/>
<connect gate="-1" pin="21" pad="21"/>
<connect gate="-1" pin="22" pad="22"/>
<connect gate="-1" pin="23" pad="23"/>
<connect gate="-1" pin="24" pad="24"/>
<connect gate="-1" pin="25" pad="25"/>
<connect gate="-1" pin="26" pad="26"/>
<connect gate="-1" pin="27" pad="27"/>
<connect gate="-1" pin="28" pad="28"/>
<connect gate="-1" pin="29" pad="29"/>
<connect gate="-1" pin="3" pad="3"/>
<connect gate="-1" pin="30" pad="30"/>
<connect gate="-1" pin="31" pad="31"/>
<connect gate="-1" pin="32" pad="32"/>
<connect gate="-1" pin="33" pad="33"/>
<connect gate="-1" pin="34" pad="34"/>
<connect gate="-1" pin="35" pad="35"/>
<connect gate="-1" pin="36" pad="36"/>
<connect gate="-1" pin="37" pad="37"/>
<connect gate="-1" pin="38" pad="38"/>
<connect gate="-1" pin="39" pad="39"/>
<connect gate="-1" pin="4" pad="4"/>
<connect gate="-1" pin="40" pad="40"/>
<connect gate="-1" pin="5" pad="5"/>
<connect gate="-1" pin="6" pad="6"/>
<connect gate="-1" pin="7" pad="7"/>
<connect gate="-1" pin="8" pad="8"/>
<connect gate="-1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X70" prefix="JP">
<description>&lt;b&gt;PIN HEADER 70 pol.&lt;/b&gt; Grid 2.54mm&lt;p&gt;</description>
<gates>
<gate name=".1" symbol="PINHD_1V" x="0" y="0" addlevel="always"/>
<gate name=".2" symbol="PINHD_1" x="0" y="-2.54" addlevel="always"/>
<gate name=".3" symbol="PINHD_1" x="0" y="-5.08" addlevel="always"/>
<gate name=".4" symbol="PINHD_1" x="0" y="-7.62" addlevel="always"/>
<gate name=".5" symbol="PINHD_1" x="0" y="-10.16" addlevel="always"/>
<gate name=".6" symbol="PINHD_1" x="0" y="-12.7" addlevel="always"/>
<gate name=".7" symbol="PINHD_1" x="0" y="-15.24" addlevel="always"/>
<gate name=".8" symbol="PINHD_1" x="0" y="-17.78" addlevel="always"/>
<gate name=".9" symbol="PINHD_1" x="0" y="-20.32" addlevel="always"/>
<gate name=".10" symbol="PINHD_1" x="0" y="-22.86" addlevel="always"/>
<gate name=".11" symbol="PINHD_1" x="0" y="-25.4" addlevel="always"/>
<gate name=".12" symbol="PINHD_1" x="0" y="-27.94" addlevel="always"/>
<gate name=".13" symbol="PINHD_1" x="0" y="-30.48" addlevel="always"/>
<gate name=".14" symbol="PINHD_1" x="0" y="-33.02" addlevel="always"/>
<gate name=".15" symbol="PINHD_1" x="0" y="-35.56" addlevel="always"/>
<gate name=".16" symbol="PINHD_1" x="0" y="-38.1" addlevel="always"/>
<gate name=".17" symbol="PINHD_1" x="0" y="-40.64" addlevel="always"/>
<gate name=".18" symbol="PINHD_1" x="0" y="-43.18" addlevel="always"/>
<gate name=".19" symbol="PINHD_1" x="0" y="-45.72" addlevel="always"/>
<gate name=".20" symbol="PINHD_1" x="0" y="-48.26" addlevel="always"/>
<gate name=".21" symbol="PINHD_1" x="0" y="-50.8" addlevel="always"/>
<gate name=".22" symbol="PINHD_1" x="0" y="-53.34" addlevel="always"/>
<gate name=".23" symbol="PINHD_1" x="0" y="-55.88" addlevel="always"/>
<gate name=".24" symbol="PINHD_1" x="0" y="-58.42" addlevel="always"/>
<gate name=".25" symbol="PINHD_1" x="0" y="-60.96" addlevel="always"/>
<gate name=".26" symbol="PINHD_1" x="0" y="-63.5" addlevel="always"/>
<gate name=".27" symbol="PINHD_1" x="0" y="-66.04" addlevel="always"/>
<gate name=".28" symbol="PINHD_1" x="0" y="-68.58" addlevel="always"/>
<gate name=".29" symbol="PINHD_1" x="0" y="-71.12" addlevel="always"/>
<gate name=".30" symbol="PINHD_1" x="0" y="-73.66" addlevel="always"/>
<gate name=".31" symbol="PINHD_1" x="0" y="-76.2" addlevel="always"/>
<gate name=".32" symbol="PINHD_1" x="0" y="-78.74" addlevel="always"/>
<gate name=".33" symbol="PINHD_1" x="0" y="-81.28" addlevel="always"/>
<gate name=".34" symbol="PINHD_1" x="0" y="-83.82" addlevel="always"/>
<gate name=".35" symbol="PINHD_1" x="0" y="-86.36" addlevel="always"/>
<gate name=".36" symbol="PINHD_1" x="0" y="-88.9" addlevel="always"/>
<gate name=".37" symbol="PINHD_1" x="0" y="-91.44" addlevel="always"/>
<gate name=".38" symbol="PINHD_1" x="0" y="-93.98" addlevel="always"/>
<gate name=".39" symbol="PINHD_1" x="0" y="-96.52" addlevel="always"/>
<gate name=".40" symbol="PINHD_1" x="0" y="-99.06" addlevel="always"/>
<gate name=".41" symbol="PINHD_1" x="0" y="-101.6" addlevel="always"/>
<gate name=".42" symbol="PINHD_1" x="0" y="-104.14" addlevel="always"/>
<gate name=".43" symbol="PINHD_1" x="0" y="-106.68" addlevel="always"/>
<gate name=".44" symbol="PINHD_1" x="0" y="-109.22" addlevel="always"/>
<gate name=".45" symbol="PINHD_1" x="0" y="-111.76" addlevel="always"/>
<gate name=".46" symbol="PINHD_1" x="0" y="-114.3" addlevel="always"/>
<gate name=".47" symbol="PINHD_1" x="0" y="-116.84" addlevel="always"/>
<gate name=".48" symbol="PINHD_1" x="0" y="-119.38" addlevel="always"/>
<gate name=".49" symbol="PINHD_1" x="0" y="-121.92" addlevel="always"/>
<gate name=".50" symbol="PINHD_1" x="0" y="-124.46" addlevel="always"/>
<gate name=".51" symbol="PINHD_1" x="0" y="-127" addlevel="always"/>
<gate name=".52" symbol="PINHD_1" x="0" y="-129.54" addlevel="always"/>
<gate name=".53" symbol="PINHD_1" x="0" y="-132.08" addlevel="always"/>
<gate name=".54" symbol="PINHD_1" x="0" y="-134.62" addlevel="always"/>
<gate name=".55" symbol="PINHD_1" x="0" y="-137.16" addlevel="always"/>
<gate name=".56" symbol="PINHD_1" x="0" y="-139.7" addlevel="always"/>
<gate name=".57" symbol="PINHD_1" x="0" y="-142.24" addlevel="always"/>
<gate name=".58" symbol="PINHD_1" x="0" y="-144.78" addlevel="always"/>
<gate name=".59" symbol="PINHD_1" x="0" y="-147.32" addlevel="always"/>
<gate name=".60" symbol="PINHD_1" x="0" y="-149.86" addlevel="always"/>
<gate name=".61" symbol="PINHD_1" x="0" y="-152.4" addlevel="always"/>
<gate name=".62" symbol="PINHD_1" x="0" y="-154.94" addlevel="always"/>
<gate name=".63" symbol="PINHD_1" x="0" y="-157.48" addlevel="always"/>
<gate name=".64" symbol="PINHD_1" x="0" y="-160.02" addlevel="always"/>
<gate name=".65" symbol="PINHD_1" x="0" y="-162.56" addlevel="always"/>
<gate name=".66" symbol="PINHD_1" x="0" y="-165.1" addlevel="always"/>
<gate name=".67" symbol="PINHD_1" x="0" y="-167.64" addlevel="always"/>
<gate name=".68" symbol="PINHD_1" x="0" y="-170.18" addlevel="always"/>
<gate name=".69" symbol="PINHD_1" x="0" y="-172.72" addlevel="always"/>
<gate name=".70" symbol="PINHD_1" x="0" y="-175.26" addlevel="always"/>
</gates>
<devices>
<device name="" package="1X70">
<connects>
<connect gate=".1" pin="1" pad="1"/>
<connect gate=".10" pin="1" pad="10"/>
<connect gate=".11" pin="1" pad="11"/>
<connect gate=".12" pin="1" pad="12"/>
<connect gate=".13" pin="1" pad="13"/>
<connect gate=".14" pin="1" pad="14"/>
<connect gate=".15" pin="1" pad="15"/>
<connect gate=".16" pin="1" pad="16"/>
<connect gate=".17" pin="1" pad="17"/>
<connect gate=".18" pin="1" pad="18"/>
<connect gate=".19" pin="1" pad="19"/>
<connect gate=".2" pin="1" pad="2"/>
<connect gate=".20" pin="1" pad="20"/>
<connect gate=".21" pin="1" pad="21"/>
<connect gate=".22" pin="1" pad="22"/>
<connect gate=".23" pin="1" pad="23"/>
<connect gate=".24" pin="1" pad="24"/>
<connect gate=".25" pin="1" pad="25"/>
<connect gate=".26" pin="1" pad="26"/>
<connect gate=".27" pin="1" pad="27"/>
<connect gate=".28" pin="1" pad="28"/>
<connect gate=".29" pin="1" pad="29"/>
<connect gate=".3" pin="1" pad="3"/>
<connect gate=".30" pin="1" pad="30"/>
<connect gate=".31" pin="1" pad="31"/>
<connect gate=".32" pin="1" pad="32"/>
<connect gate=".33" pin="1" pad="33"/>
<connect gate=".34" pin="1" pad="34"/>
<connect gate=".35" pin="1" pad="35"/>
<connect gate=".36" pin="1" pad="36"/>
<connect gate=".37" pin="1" pad="37"/>
<connect gate=".38" pin="1" pad="38"/>
<connect gate=".39" pin="1" pad="39"/>
<connect gate=".4" pin="1" pad="4"/>
<connect gate=".40" pin="1" pad="40"/>
<connect gate=".41" pin="1" pad="41"/>
<connect gate=".42" pin="1" pad="42"/>
<connect gate=".43" pin="1" pad="43"/>
<connect gate=".44" pin="1" pad="44"/>
<connect gate=".45" pin="1" pad="45"/>
<connect gate=".46" pin="1" pad="46"/>
<connect gate=".47" pin="1" pad="47"/>
<connect gate=".48" pin="1" pad="48"/>
<connect gate=".49" pin="1" pad="49"/>
<connect gate=".5" pin="1" pad="5"/>
<connect gate=".50" pin="1" pad="50"/>
<connect gate=".51" pin="1" pad="51"/>
<connect gate=".52" pin="1" pad="52"/>
<connect gate=".53" pin="1" pad="53"/>
<connect gate=".54" pin="1" pad="54"/>
<connect gate=".55" pin="1" pad="55"/>
<connect gate=".56" pin="1" pad="56"/>
<connect gate=".57" pin="1" pad="57"/>
<connect gate=".58" pin="1" pad="58"/>
<connect gate=".59" pin="1" pad="59"/>
<connect gate=".6" pin="1" pad="6"/>
<connect gate=".60" pin="1" pad="60"/>
<connect gate=".61" pin="1" pad="61"/>
<connect gate=".62" pin="1" pad="62"/>
<connect gate=".63" pin="1" pad="63"/>
<connect gate=".64" pin="1" pad="64"/>
<connect gate=".65" pin="1" pad="65"/>
<connect gate=".66" pin="1" pad="66"/>
<connect gate=".67" pin="1" pad="67"/>
<connect gate=".68" pin="1" pad="68"/>
<connect gate=".69" pin="1" pad="69"/>
<connect gate=".7" pin="1" pad="7"/>
<connect gate=".70" pin="1" pad="70"/>
<connect gate=".8" pin="1" pad="8"/>
<connect gate=".9" pin="1" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-1X100" prefix="JP">
<description>&lt;b&gt;PIN HEADER 100 pol.&lt;/b&gt; Grid 2.54mm&lt;p&gt;</description>
<gates>
<gate name=".71" symbol="PINHD_1" x="0" y="-177.8" addlevel="always"/>
<gate name=".72" symbol="PINHD_1" x="0" y="-180.34" addlevel="always"/>
<gate name=".73" symbol="PINHD_1" x="0" y="-182.88" addlevel="always"/>
<gate name=".74" symbol="PINHD_1" x="0" y="-185.42" addlevel="always"/>
<gate name=".75" symbol="PINHD_1" x="0" y="-187.96" addlevel="always"/>
<gate name=".76" symbol="PINHD_1" x="0" y="-190.5" addlevel="always"/>
<gate name=".77" symbol="PINHD_1" x="0" y="-193.04" addlevel="always"/>
<gate name=".78" symbol="PINHD_1" x="0" y="-195.58" addlevel="always"/>
<gate name=".79" symbol="PINHD_1" x="0" y="-198.12" addlevel="always"/>
<gate name=".80" symbol="PINHD_1" x="0" y="-200.66" addlevel="always"/>
<gate name=".81" symbol="PINHD_1" x="0" y="-203.2" addlevel="always"/>
<gate name=".82" symbol="PINHD_1" x="0" y="-205.74" addlevel="always"/>
<gate name=".83" symbol="PINHD_1" x="0" y="-208.28" addlevel="always"/>
<gate name=".84" symbol="PINHD_1" x="0" y="-210.82" addlevel="always"/>
<gate name=".85" symbol="PINHD_1" x="0" y="-213.36" addlevel="always"/>
<gate name=".86" symbol="PINHD_1" x="0" y="-215.9" addlevel="always"/>
<gate name=".87" symbol="PINHD_1" x="0" y="-218.44" addlevel="always"/>
<gate name=".88" symbol="PINHD_1" x="0" y="-220.98" addlevel="always"/>
<gate name=".89" symbol="PINHD_1" x="0" y="-223.52" addlevel="always"/>
<gate name=".90" symbol="PINHD_1" x="0" y="-226.06" addlevel="always"/>
<gate name=".91" symbol="PINHD_1" x="0" y="-228.6" addlevel="always"/>
<gate name=".92" symbol="PINHD_1" x="0" y="-231.14" addlevel="always"/>
<gate name=".93" symbol="PINHD_1" x="0" y="-233.68" addlevel="always"/>
<gate name=".94" symbol="PINHD_1" x="0" y="-236.22" addlevel="always"/>
<gate name=".95" symbol="PINHD_1" x="0" y="-238.76" addlevel="always"/>
<gate name=".96" symbol="PINHD_1" x="0" y="-241.3" addlevel="always"/>
<gate name=".97" symbol="PINHD_1" x="0" y="-243.84" addlevel="always"/>
<gate name=".98" symbol="PINHD_1" x="0" y="-246.38" addlevel="always"/>
<gate name=".99" symbol="PINHD_1" x="0" y="-248.92" addlevel="always"/>
<gate name=".100" symbol="PINHD_1" x="0" y="-251.46" addlevel="always"/>
</gates>
<devices>
<device name="" package="1X100">
<connects>
<connect gate=".100" pin="1" pad="100"/>
<connect gate=".71" pin="1" pad="71"/>
<connect gate=".72" pin="1" pad="72"/>
<connect gate=".73" pin="1" pad="73"/>
<connect gate=".74" pin="1" pad="74"/>
<connect gate=".75" pin="1" pad="75"/>
<connect gate=".76" pin="1" pad="76"/>
<connect gate=".77" pin="1" pad="77"/>
<connect gate=".78" pin="1" pad="78"/>
<connect gate=".79" pin="1" pad="79"/>
<connect gate=".80" pin="1" pad="80"/>
<connect gate=".81" pin="1" pad="81"/>
<connect gate=".82" pin="1" pad="82"/>
<connect gate=".83" pin="1" pad="83"/>
<connect gate=".84" pin="1" pad="84"/>
<connect gate=".85" pin="1" pad="85"/>
<connect gate=".86" pin="1" pad="86"/>
<connect gate=".87" pin="1" pad="87"/>
<connect gate=".88" pin="1" pad="88"/>
<connect gate=".89" pin="1" pad="89"/>
<connect gate=".90" pin="1" pad="90"/>
<connect gate=".91" pin="1" pad="91"/>
<connect gate=".92" pin="1" pad="92"/>
<connect gate=".93" pin="1" pad="93"/>
<connect gate=".94" pin="1" pad="94"/>
<connect gate=".95" pin="1" pad="95"/>
<connect gate=".96" pin="1" pad="96"/>
<connect gate=".97" pin="1" pad="97"/>
<connect gate=".98" pin="1" pad="98"/>
<connect gate=".99" pin="1" pad="99"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
