<xml xmlns="http://www.w3.org/1999/xhtml"><block type="arduino_setup" x="-362" y="-137"><statement name="MySetup"><block type="string_declare"><field name="VAR">sensor2</field><value name="VALUE"><block type="text"><field name="TEXT"></field></block></value><next><block type="string_declare"><field name="VAR">sensor3</field><value name="VALUE"><block type="text"><field name="TEXT"></field></block></value><next><block type="iots_disconnect"><next><block type="base_delayms"><value name="DELAY_TIME"><block type="math_number"><field name="NUM">3000</field></block></value><next><block type="serial_print"><value name="CONTENT"><block type="text"><field name="TEXT">Start</field></block></value><next><block type="iots_connectnetwork_nopass"><value name="ssid"><block type="text"><field name="TEXT">homenetwork</field></block></value><next><block type="do_while"><value name="CONDI"><block type="logic_negate"><value name="BOOL"><block type="iots_isconnected"></block></value></block></value><statement name="STATNAME"><block type="base_delayms"><value name="DELAY_TIME"><block type="math_number"><field name="NUM">200</field></block></value><next><block type="serial_print"><value name="CONTENT"><block type="text"><field name="TEXT">...</field></block></value></block></next></block></statement><next><block type="serial_print"><value name="CONTENT"><block type="text"><field name="TEXT">Csatlakozva</field></block></value><next><block type="iots_staticip"><field name="IP">192,168,1,100</field><field name="gateway">192,168,1,1</field><field name="masque">255,255,255,0</field><next><block type="serial_print"><value name="CONTENT"><block type="text"><field name="TEXT">IP címem</field></block></value><next><block type="serial_print"><value name="CONTENT"><block type="iots_localip"></block></value><next><block type="iot_startserver"><value name="port"><block type="math_number"><field name="NUM">80</field></block></value></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement><statement name="MyLoop"><block type="iot_waitconnection"><next><block type="iot_clientflush"><next><block type="string_set"><field name="VAR">sensor2</field><value name="VALUE"><block type="iotclient_sendrequestwithanswer"><value name="ip"><block type="text"><field name="TEXT">198.168.1.120</field></block></value><value name="message"><block type="text"><field name="TEXT">Yes</field></block></value></block></value><next><block type="string_iot_clearhttp_Client"><field name="VAR">sensor2</field><next><block type="string_set"><field name="VAR">sensor3</field><value name="VALUE"><block type="iotclient_sendrequestwithanswer"><value name="ip"><block type="text"><field name="TEXT">192.168.1.130</field></block></value><value name="message"><block type="text"><field name="TEXT">Yes</field></block></value></block></value><next><block type="string_iot_clearhttp_Client"><field name="VAR">sensor3</field></block></next></block></next></block></next></block></next></block></next></block></statement></block></xml>
