 *                  RTCC API Example
 * FileName:        time_date.c
 * Dependencies:	Rtcc.h
 * Processor:       PIC32
 * Complier:        MPLAB Cxx
 *                  MPLAB IDE vxx
 * Company:         Microchip Technology Inc.
 * Software License Agreement
 * The software supplied herewith by Microchip Technology Incorporated
 * (the “Company”) for its PIC32 Microcontroller is intended
 * and supplied to you, the Company’s customer, for use solely and
 * exclusively on Microchip PIC32 Microcontroller products.
 * The software is owned by the Company and/or its supplier, and is
 * protected under applicable copyright laws. All rights are reserved.
 * Any use in violation of the foregoing restrictions may subject the
 * user to criminal sanctions under applicable laws, as well as to
 * civil liability for the breach of the terms and conditions of this
 * license.
 * THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
 * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
 * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
 * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
 * Author               Date        Comment
 * $Id: rtcc_api_example.c 4288 2007-08-22 23:00:56Z aura $
// Master header file for all peripheral library includes
#include <plib.h>
#ifndef _RTCC
    #error "This example needs a PIC32MX processor with RTCC peripheral present. Aborting build!
#endif  // _RTCC
//	local function prototypes
int CheckRtccRunning(int secWait);
// Configuration Bit settings
// SYSCLK = 80 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
// PBCLK = 40 MHz
// Primary Osc w/PLL (XT+,HS+,EC+PLL)
// WDT OFF
// Other options are don't care
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_1
#define SYS_FREQ 		(80000000L)
 * Function:        int main(void)
 * PreCondition:    None
 * Input:           None
 * Output:          1 if everything went on ok, 0 if failed
 * Side Effects:    None
 * Overview:        The function is an example of using the RTCC device.
 * Note:            None
int main(void)
	rtccTime	tm, tm1;			// time structure
	rtccDate	dt, dt1;			// date structure
	// Configure the device for maximum performance but do not change the PBDIV
	// Given the options, this function will change the flash wait states, RAM
	// wait state and enable prefetch cache but will not change the PBDIV.
	// The PBDIV value is already set via the pragma FPBDIV option above..
	SYSTEMConfig(SYS_FREQ, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
	RtccInit();			// init the RTCC
	while(RtccGetClkStat()!=RTCC_CLK_ON);	// wait for the SOSC to be actually running and RTCC to have its clock source
							// could wait here at most 32ms
	// when using the RtccSetTimeDate() function, the write operation is enabled if needed and then restored to the initial value
	// so that we don't have to worry about calling RtccWrEnable()/RtccWrDisable() functions
	// let's start setting the current date
		// one way to do it
		tm.l=0;
		tm.sec=0x30;
		tm.min=0x07;
		tm.hour=0x10;
		dt.wday=2;
		dt.mday=0x16;
		dt.mon=0x01;
		dt.year=0x07;
		RtccSetTimeDate(tm.l, dt.l);
	// however, much easier to do it should be:
	RtccSetTimeDate(0x10073000, 0x07011602);	// time is MSb: hour, min, sec, rsvd. date is MSb: year, mon, mday, wday.
												// please note that the rsvd field has to be 0 in the time field!
	// NOTE: at this point the writes to the RTCC time and date registers are disabled
	// we can also read the time and date
	tm1.l=RtccGetTime();
	dt1.l=RtccGetDate();
	// can check that the time and date are the ones we just set
	if(tm.hour!=tm1.hour ||tm.min!=tm1.min)
		return 0;
	if(dt.l!=dt1.l)		// check for proper date
		return 0;
	// we can read the time and date in a single operation
	RtccGetTimeDate(&tm1, &dt1);
	// now that we know the RTCC clock is up and running, it's easier to start from fresh:
	RtccOpen(tm.l, dt.l, 0);	// set time, date and calibration in a single operation
	// check that the RTCC is running
	if(!CheckRtccRunning(3))
		return 0;
	// another way to see the RTCC is tunning: check the SYNC bit
	while(RtccGetSync());	// wait sync to be low
	while(!RtccGetSync());	// wait to be high
	while(RtccGetSync());	// wait sync to be low again
	// other RTCC operations
	// adjust the RTCC timing
	RtccSetCalibration(200);	// value to calibrate with at each minute
	// enabling the RTCC output pin
	RtccSelectPulseOutput(1);		// select the seconds clock pulse as the function of the RTCC output pin
	RtccSelectPulseOutput(0);		// select the alarm pulse as the function of the RTCC output pin
	RtccOutputEnable(1);			// enable the Output pin of the RTCC
	return 1;
 * Function:        int CheckRtccRunning(int secWait)
 * Input:           None
 * Output:          1(true) if test succeeded, 0(FALSE) otherwise
 * Overview:        The function checks that the RTCC has the clock enabled and counts the time.
 * Note:            None
	#define	WAIT_FOR_SEC_TMO	1100			// how many ms to wait for the RTCC seconds count to change
	rtccTime	t0, t1;
	int		fail;
	int		secCnt;
	unsigned int	tStart;
	for(secCnt=0, fail=0; secCnt<secWait; secCnt++)
		tStart=ReadCoreTimer();
		t0.l=RtccGetTime();
		do
			t1.l=RtccGetTime();
		}while((t1.sec==t0.sec) && (ReadCoreTimer()-tStart)<(SYS_FREQ/2000)*WAIT_FOR_SEC_TMO);	// wait seconds change
		if(t1.sec==t0.sec)
			fail=1;
			break;	// failed
	return !fail;
