# Makefile for OpenLRSng
# If your Arduino is in a weird place, you'll need to change this.
ARDUINO_PATH=/usr/share/arduino
# Board type can be one of 6 values:
# 0 - Flytron M1 TX
# 1 - Flytron M1 RX
# 2 - Flytron M2, M3 TX, Orange-TX
# 3 - Flytron V2 RX, Hawkeye RX, HK Orange-RX
# 4 - Hawkeye TX, OpenLRSng TX
# 5 - DTF 4ch RX
# 6 - Deluxe TX
# 7 - PowerTowerRX
BOARD_TYPE=3
BOARD_TYPES_TX=0 2 3 4 5 6 7 8 9
BOARD_TYPES_RX=2 3 5 7 8 9
# You can compile all TX as TX, and all RX as either RX or TX.
# You cannot currently compile TX as RX.
# This flag controls what primary function the board will have
COMPILE_TX=1
# No real user options below here.
# You don't want to change this unless you really know that you
# need to.  CPU clock.
CLOCK=16000000L
# Board type 6 requires a different Arduino target
ifeq ($(BOARD_TYPE),6)
CPU=atmega32u4
USB_VID=0x2341
USB_PID=0x8036
VARIANT=leonardo
BOOTLOADER=Caterina-Leonardo.hex
else
CPU=atmega328p
USB_VID=null
USB_PID=null
VARIANT=standard
BOOTLOADER=optiboot_atmega328.hex
endif
# C preprocessor defines
DEFINES=-DBOARD_TYPE=$(BOARD_TYPE) -DCOMPILE_TX=$(COMPILE_TX) -DRFMTYPE=$(RFMTYPE)
# AVR GCC info
EXEPREFIX=avr-
ifneq (,$(wildcard $(ARDUINO_PATH)/hardware/tools/avr/bin/avr-gcc))
	EXEPATH=$(ARDUINO_PATH)/hardware/tools/avr/bin
else ifneq (,$(wildcard /usr/bin/avr-gcc))
	EXEPATH=/usr/bin
endif
# AVR gcc and binutils
CC=$(EXEPATH)/$(EXEPREFIX)gcc
CXX=$(EXEPATH)/$(EXEPREFIX)g++
AR=$(EXEPATH)/$(EXEPREFIX)ar
SIZE=$(EXEPATH)/$(EXEPREFIX)size
OBJCOPY=$(EXEPATH)/$(EXEPREFIX)objcopy
# Shell commands
RM=rm
MKDIR=mkdir
LS=ls
SED=sed
CAT=cat
# Styling
ASTYLE=astyle
ASTYLEOPTIONS=--options=none --style=1tbs --indent=spaces=2 --suffix=none --lineend=linux
# Compile flags
COPTFLAGS= -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \
	   -fno-inline-small-functions -Wl,--relax -mcall-prologues
CFLAGS=-Wall -ffunction-sections -fdata-sections -mmcu=$(CPU) -DF_CPU=$(CLOCK) -MMD \
	-DUSB_VID=$(USB_VID) -DUSB_PID=$(USB_PID) -DARDUINO=105 -D__PROG_TYPES_COMPAT__ $(DEFINES)
CXXFLAGS=-fno-exceptions -std=gnu++11 -fno-threadsafe-statics
# Arduino libraries used, compilation settings.
ARDUINO_LIBS=HID
ARDUINO_LIB_PATH=$(ARDUINO_PATH)/hardware/arduino/avr/libraries/
ARDUINO_LIB_DIRS=$(addsuffix /src, $(addprefix $(ARDUINO_LIB_PATH), $(ARDUINO_LIBS)))
ARDUINO_LIB_INCL=$(addprefix -I, $(ARDUINO_LIB_DIRS))
ARDUINO_LIB_OBJS=$(patsubst %.cpp, libraries/%.o, $(addsuffix .cpp, $(ARDUINO_LIBS)))
# Arduino variant settings
ARDUINO_VARIANT_PATH=$(ARDUINO_PATH)/hardware/arduino/avr/variants/$(VARIANT)
# Arduino library files used, compilation settings.
ARDUINO_CORELIB_PATH=$(ARDUINO_PATH)/hardware/arduino/avr/cores/arduino/
ARDUINO_CORELIB_SRCS=WInterrupts.c wiring.c wiring_shift.c wiring_digital.c \
			wiring_pulse.c wiring_analog.c CDC.cpp Print.cpp \
			HardwareSerial.cpp HardwareSerial0.cpp HardwareSerial1.cpp \
			WString.cpp Stream.cpp main.cpp USBCore.cpp PluggableUSB.cpp \
			hooks.c
ARDUINO_CORELIB_OBJS= $(patsubst %.c, libraries/%.o, $(patsubst %.cpp, libraries/%.o, $(ARDUINO_CORELIB_SRCS)))
# Arduino stdc library files used, compilation settings.
ARDUINO_LIBC_PATH=$(ARDUINO_PATH)/hardware/arduino/avr/cores/arduino/avr-libc/
ARDUINO_LIBC_SRCS=malloc.c realloc.c
# Master include path
INCLUDE=-I$(ARDUINO_CORELIB_PATH) -I$(ARDUINO_VARIANT_PATH) $(ARDUINO_LIB_INCL) -I.
# Project folders
LIBRARIES_FOLDER=libraries
OUT_FOLDER=out
# Target object files
OBJS=openLRSng.o $(ARDUINO_LIB_OBJS) $(LIBRARIES_FOLDER)/libcore.a
# Default target
default: 433
# Master target
all: mkdirs openLRSng.hex
# From here down are build rules
VPATH := $(ARDUINO_LIB_DIRS) $(ARDUINO_CORELIB_PATH) $(ARDUINO_LIBC_PATH)
define ino-command
	@$(CXX) -c $(COPTFLAGS) $(CXXFLAGS) $(CFLAGS) $(INCLUDE) -o $@ -x c++ $<
endef
define cc-command
	@$(CC) -c $(COPTFLAGS) $(CFLAGS) $(INCLUDE) -o $@ $<
endef
define cxx-command
	@$(CXX) -c $(COPTFLAGS) $(CXXFLAGS) $(CFLAGS) $(INCLUDE) -o $@ $<
endef
.PHONY: all clean upload astyle 433 868 915 allfw default
%.o: %.ino
	$(ino-command)
%.o: %.c
	$(cc-command)
%.o: %.cpp
	$(cxx-command)
$(LIBRARIES_FOLDER)/%.o: %.c
	$(cc-command) 2>/dev/null
$(LIBRARIES_FOLDER)/%.o: %.cpp
	$(cxx-command) 2>/dev/null
# Other targets
clean: clean_compilation_products
	@$(RM) -rf $(OUT_FOLDER)
clean_compilation_products:
	@$(RM) -rf $(LIBRARIES_FOLDER)
	@$(RM) -f *.[aod] *.elf *.eep *.d *.hex
mkdirs:
	@$(MKDIR) -p $(LIBRARIES_FOLDER)
openLRSng.hex: $(OBJS)
	@$(CC) -Os -Wl,--gc-sections -mmcu=$(CPU) -o openLRSng.elf $(OBJS) -L$(LIBRARIES_FOLDER) -lm
	@$(OBJCOPY) -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load \
		--no-change-warnings --change-section-lma .eeprom=0 \
		openLRSng.elf openLRSng.eep
	@$(OBJCOPY) -O ihex -R .eeprom openLRSng.elf openLRSng.hex
	@echo "NOTE: Deployment size is text + data."
	@$(SIZE) openLRSng.elf
	@$(SED) "/:00000001FF/d" openLRSng.hex > openLRSngBL.hex
	@$(CAT) bootloaders/$(BOOTLOADER) >> openLRSngBL.hex
$(LIBRARIES_FOLDER)/libcore.a: $(ARDUINO_CORELIB_OBJS)
	@$(AR) rcs $(LIBRARIES_FOLDER)/libcore.a $(ARDUINO_CORELIB_OBJS)
astyle:
	$(ASTYLE) $(ASTYLEOPTIONS) openLRSng.ino *.h
433 868 915:
	$(RM) -rf $(OUT_FOLDER)/$@
	$(MKDIR) -p $(OUT_FOLDER)/$@
	$(foreach type, $(BOARD_TYPES_RX), make -s RFMTYPE=$@ COMPILE_TX=0 BOARD_TYPE=$(type) clean_compilation_products all && cp openLRSng.hex $(OUT_FOLDER)/$@/RX-$(type).hex && cp openLRSngBL.hex $(OUT_FOLDER)/$@/RX-$(type)-bl.hex;)
	$(foreach type, $(BOARD_TYPES_TX), make -s RFMTYPE=$@ COMPILE_TX=1 BOARD_TYPE=$(type) clean_compilation_products all && cp openLRSng.hex $(OUT_FOLDER)/$@/TX-$(type).hex && cp openLRSngBL.hex $(OUT_FOLDER)/$@/TX-$(type)-bl.hex;)
	make -s RFMTYPE=$@ COMPILE_TX=0 BOARD_TYPE=8 CLOCK=8000000 clean_compilation_products all && cp openLRSng.hex $(OUT_FOLDER)/$@/RX-8-8MHz.hex && cp openLRSngBL.hex $(OUT_FOLDER)/$@/RX-8-8MHz-bl.hex
	$(LS) -l $(OUT_FOLDER)
allfw: 433 868 915
	$(LS) -lR $(OUT_FOLDER)
