# Makefile for OpenLRSng
# If your Arduino is in a weird place, you'll need to change this.
ARDUINO_PATH=/usr/share/arduino
# Board type can be one of 6 values:
# 0 - Flytron M1 TX
# 1 - Flytron M1 RX
# 2 - Flytron M2, M3 TX, Orange-TX
# 3 - Flytron V2 RX, Hawkeye RX, HK Orange-RX
# 4 - Hawkeye TX, OpenLRSng TX
# 5 - DTF 4ch RX
# 6 - Deluxe TX
BOARD_TYPE=3
# You can compile all TX as TX, and all RX as either RX or TX.
# You cannot currently compile TX as RX.
# This flag controls what primary function the board will have
COMPILE_TX=1
# No real user options below here.
# You don't want to change this unless you really know that you
# need to.  CPU clock.
CLOCK=16000000L
# Board type 6 requires a different Arduino target
ifeq ($(BOARD_TYPE),6)
CPU=atmega32u4
USB_VID=0x2341
USB_PID=0x8036
VARIANT=leonardo
else
CPU=atmega328p
USB_VID=null
USB_PID=null
VARIANT=standard
endif
# C preprocessor defines
ifeq ($(COMPILE_TX),1)
DEFINES=-DBOARD_TYPE=$(BOARD_TYPE) -DCOMPILE_TX
else
endif
# AVR GCC info
EXEPATH=$(ARDUINO_PATH)/hardware/tools/avr/bin
EXEPREFIX=avr-
# AVR gcc and binutils
CC=$(EXEPATH)/$(EXEPREFIX)gcc
CXX=$(EXEPATH)/$(EXEPREFIX)g++
AR=$(EXEPATH)/$(EXEPREFIX)ar
SIZE=$(EXEPATH)/$(EXEPREFIX)size
OBJCOPY=$(EXEPATH)/$(EXEPREFIX)objcopy
# Compile flags
COPTFLAGS= -g -Os
CFLAGS=-Wall -ffunction-sections -fdata-sections -mmcu=$(CPU) -DF_CPU=$(CLOCK) -MMD \
	-DUSB_VID=$(USB_VID) -DUSB_PID=$(USB_PID) -DARDUINO=105 -D__PROG_TYPES_COMPAT__ $(DEFINES)
CXXFLAGS=-fno-exceptions
# Arduino libraries used, compilation settings.
ARDUINO_LIBS=EEPROM
ARDUINO_LIB_PATH=$(ARDUINO_PATH)/libraries/
ARDUINO_LIB_DIRS=$(addprefix $(ARDUINO_LIB_PATH),$(ARDUINO_LIBS))
ARDUINO_LIB_INCL=$(addsuffix $(ARDUINO_LIBS),-I$(ARDUINO_LIB_PATH))
ARDUINO_LIB_SRCS=$(addsuffix .cpp,$(addprefix $(ARDUINO_LIB_PATH),$(ARDUINO_LIBS)/$(ARDUINO_LIBS)))
ARDUINO_LIB_OBJS=$(patsubst %.cpp, libraries/%.o, $(addsuffix .cpp,$(ARDUINO_LIBS)))
# Arduino variant settings
ARDUINO_VARIANT_PATH=$(ARDUINO_PATH)/hardware/arduino/variants/$(VARIANT)
# Arduino library files used, compilation settings.
ARDUINO_CORELIB_PATH=$(ARDUINO_PATH)/hardware/arduino/cores/arduino/
ARDUINO_CORELIB_SRCS=WInterrupts.c wiring.c wiring_shift.c wiring_digital.c \
		     wiring_pulse.c wiring_analog.c \
		     CDC.cpp Print.cpp HardwareSerial.cpp WString.cpp IPAddress.cpp \
		     Stream.cpp main.cpp USBCore.cpp HID.cpp new.cpp Tone.cpp WMath.cpp
ARDUINO_CORELIB_OBJS= $(patsubst %.c, libraries/%.o, $(patsubst %.cpp, libraries/%.o, $(ARDUINO_CORELIB_SRCS)))
# Arduino stdc library files used, compilation settings.
ARDUINO_LIBC_PATH=/usr/share/arduino/hardware/arduino/cores/arduino/avr-libc/
ARDUINO_LIBC_SRCS=malloc.c realloc.c
# Master include path
INCLUDE=-I$(ARDUINO_CORELIB_PATH) -I$(ARDUINO_VARIANT_PATH) $(ARDUINO_LIB_INCL) -I.
# Target object files
OBJS=openLRSng.o $(ARDUINO_LIB_OBJS) libraries/libcore.a
# Master target
all: openLRSng.hex
# From here down are build rules
VPATH := $(ARDUINO_LIB_DIRS) $(ARDUINO_CORELIB_PATH) $(ARDUINO_LIBC_PATH)
define ino-command
	$(CXX) -c $(COPTFLAGS) $(CXXFLAGS) $(CFLAGS) $(INCLUDE) -o $@ -x c++ $<
endef
define cc-command
	$(CC) -c $(COPTFLAGS) $(CFLAGS) $(INCLUDE) -o $@ $<
endef
define cxx-command
	$(CXX) -c $(COPTFLAGS) $(CXXFLAGS) $(CFLAGS) $(INCLUDE) -o $@ $<
endef
.PHONY: all clean upload
%.o: %.ino
	$(ino-command)
%.o: %.c
	$(cc-command)
%.o: %.cpp
	$(cxx-command)
libraries/%.o: %.c
	$(cc-command)
libraries/%.o: %.cpp
	$(cxx-command)
# Other targets
clean:
	rm -f *.[aod] libraries/*.[aod] *.elf *.eep *.d *.hex
openLRSng.hex: $(OBJS)
	@$(CC) -Os -Wl,--gc-sections -mmcu=atmega328p -o openLRSng.elf $(OBJS) -Llibraries -lm
	@$(OBJCOPY) -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load \
		--no-change-warnings --change-section-lma .eeprom=0 \
		openLRSng.elf openLRSng.eep
	@$(OBJCOPY) -O ihex -R .eeprom openLRSng.elf openLRSng.hex
	@echo "NOTE: Deployment size is text + data."
	@$(SIZE) openLRSng.elf
libraries/libcore.a: $(ARDUINO_CORELIB_OBJS)
	$(AR) rcs libraries/libcore.a $(ARDUINO_CORELIB_OBJS)
