<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.3175" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tPadExt" color="7" fill="6" visible="no" active="no"/>
<layer number="54" name="bPadExt" color="1" fill="3" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-33.909" y1="12.446" x2="-33.909" y2="12.5095" width="0" layer="20"/>
<wire x1="-0.03175" y1="-0.92075" x2="-0.03175" y2="0.889" width="0" layer="20"/>
<wire x1="0.889" y1="0.0635" x2="-0.73025" y2="0.0635" width="0" layer="20"/>
<wire x1="26.67" y1="24.4475" x2="31.115" y2="-18.415" width="0.1" layer="20" curve="-72.4191"/>
<wire x1="24.13" y1="-26.9875" x2="-21.2725" y2="-29.21" width="0.1" layer="20" curve="-77.8648"/>
<wire x1="-29.21" y1="-21.2725" x2="-33.9725" y2="12.7" width="0.1" layer="20" curve="-56.5617"/>
<wire x1="-20.0025" y1="30.1625" x2="-15.24" y2="33.02" width="0.1" layer="20" curve="-8.11186"/>
<wire x1="-6.35" y1="35.8775" x2="6.35" y2="35.8775" width="0.1" layer="20" curve="-19.6668"/>
<wire x1="15.24" y1="33.02" x2="18.7325" y2="31.115" width="0.1" layer="20" curve="-6.72713"/>
<wire x1="-27.94" y1="-20.32" x2="-26.035" y2="-20.6375" width="0.1" layer="20" curve="-81.4041"/>
<wire x1="-20.6375" y1="-26.035" x2="-20.32" y2="-27.6225" width="0.1" layer="20" curve="-79.9393"/>
<wire x1="27.6225" y1="-17.78" x2="29.5275" y2="-17.4625" width="0.1" layer="20" curve="-100.061"/>
<wire x1="22.86" y1="-23.8125" x2="22.86" y2="-25.7175" width="0.1" layer="20" curve="100.061"/>
<wire x1="-27.94" y1="-20.32" x2="-29.21" y2="-21.2725" width="0.1" layer="20" curve="11.2605"/>
<wire x1="-26.035" y1="-20.6375" x2="-20.6375" y2="-26.035" width="0.1" layer="20" curve="10.3287"/>
<wire x1="-20.32" y1="-27.6225" x2="-21.2725" y2="-29.21" width="0.1" layer="20"/>
<wire x1="22.86" y1="-25.7175" x2="24.13" y2="-26.9875" width="0.1" layer="20"/>
<wire x1="22.86" y1="-23.8125" x2="27.6225" y2="-17.78" width="0.1" layer="20"/>
<wire x1="29.5275" y1="-17.4625" x2="31.115" y2="-18.415" width="0.1" layer="20"/>
<wire x1="-4.1275" y1="-7.62" x2="-4.1275" y2="-4.7625" width="0.1" layer="20" curve="-180"/>
<wire x1="4.1275" y1="-7.62" x2="4.1275" y2="-4.7625" width="0.1" layer="20" curve="180"/>
<circle x="-31.75" y="-7.3025" radius="1.905" width="0.1" layer="20"/>
<circle x="29.5275" y="-13.335" radius="2.032990625" width="0.1" layer="20"/>
<wire x1="-4.1275" y1="-7.62" x2="4.1275" y2="-7.62" width="0.1" layer="20"/>
<wire x1="-4.1275" y1="-4.7625" x2="4.1275" y2="-4.7625" width="0.1" layer="20"/>
<wire x1="-8.255" y1="-29.845" x2="-11.43" y2="-29.845" width="0.1" layer="20" curve="-180"/>
<wire x1="-8.255" y1="-23.8125" x2="-11.43" y2="-23.8125" width="0.1" layer="20" curve="180"/>
<wire x1="-8.255" y1="-29.845" x2="-8.255" y2="-23.8125" width="0.1" layer="20"/>
<wire x1="-11.43" y1="-29.845" x2="-11.43" y2="-23.8125" width="0.1" layer="20"/>
<wire x1="11.7475" y1="-29.845" x2="8.5725" y2="-29.845" width="0.1" layer="20" curve="-180"/>
<wire x1="11.7475" y1="-23.8125" x2="8.5725" y2="-23.8125" width="0.1" layer="20" curve="180"/>
<wire x1="11.7475" y1="-29.845" x2="11.7475" y2="-23.8125" width="0.1" layer="20"/>
<wire x1="8.5725" y1="-29.845" x2="8.5725" y2="-23.8125" width="0.1" layer="20"/>
<circle x="13.97" y="5.3975" radius="0.9525" width="0.1" layer="20"/>
<circle x="13.97" y="-5.08" radius="0.9525" width="0.1" layer="20"/>
<circle x="-14.0335" y="5.23875" radius="0.93379375" width="0.1" layer="20"/>
<circle x="-17.145" y="26.9875" radius="2.129853125" width="0.1" layer="20"/>
<wire x1="-16.1925" y1="13.6525" x2="-17.145" y2="12.7" width="0.1" layer="20" curve="-108.434949"/>
<wire x1="-20.0025" y1="30.1625" x2="-20.0025" y2="25.7175" width="0.1" layer="20"/>
<wire x1="-20.0025" y1="25.7175" x2="-16.1925" y2="21.9075" width="0.1" layer="20"/>
<wire x1="-16.1925" y1="21.9075" x2="-16.1925" y2="13.6525" width="0.1" layer="20"/>
<wire x1="-14.605" y1="30.7975" x2="-15.24" y2="32.0675" width="0.1" layer="20" curve="-82.874984"/>
<wire x1="-7.62" y1="30.7975" x2="-6.35" y2="32.0675" width="0.1" layer="20" curve="106.260205"/>
<wire x1="6.35" y1="31.75" x2="7.3025" y2="30.7975" width="0.1" layer="20" curve="106.260205"/>
<wire x1="15.24" y1="31.75" x2="14.2875" y2="30.7975" width="0.1" layer="20" curve="-108.434949"/>
<wire x1="25.4" y1="23.1775" x2="23.8125" y2="23.1775" width="0.1" layer="20" curve="-111.801409"/>
<wire x1="17.78" y1="29.845" x2="17.78" y2="28.2575" width="0.1" layer="20" curve="90"/>
<wire x1="-15.24" y1="32.0675" x2="-15.24" y2="33.02" width="0.1" layer="20"/>
<wire x1="-14.605" y1="30.7975" x2="-7.62" y2="30.7975" width="0.1" layer="20"/>
<wire x1="-6.35" y1="32.0675" x2="-6.35" y2="35.8775" width="0.1" layer="20"/>
<wire x1="7.3025" y1="30.7975" x2="14.2875" y2="30.7975" width="0.1" layer="20"/>
<wire x1="15.24" y1="31.75" x2="15.24" y2="33.02" width="0.1" layer="20"/>
<wire x1="6.35" y1="31.75" x2="6.35" y2="35.8775" width="0.1" layer="20"/>
<wire x1="17.78" y1="29.845" x2="18.7325" y2="31.115" width="0.1" layer="20"/>
<wire x1="17.78" y1="28.2575" x2="23.8125" y2="23.1775" width="0.1" layer="20"/>
<wire x1="25.4" y1="23.1775" x2="26.67" y2="24.4475" width="0.1" layer="20"/>
<wire x1="-33.9725" y1="12.7" x2="-17.145" y2="12.7" width="0.1" layer="20"/>
<wire x1="-32.385" y1="6.985" x2="-32.385" y2="8.5725" width="0.1" layer="20" curve="-180"/>
<wire x1="-32.385" y1="4.445" x2="-32.385" y2="6.0325" width="0.1" layer="20" curve="-180"/>
<wire x1="-18.7325" y1="8.5725" x2="-18.7325" y2="6.985" width="0.1" layer="20" curve="-202.619865"/>
<wire x1="-18.7325" y1="6.0325" x2="-18.7325" y2="4.445" width="0.1" layer="20" curve="-202.619865"/>
<wire x1="-32.385" y1="4.445" x2="-18.7325" y2="4.445" width="0.1" layer="20"/>
<wire x1="-32.385" y1="8.5725" x2="-18.7325" y2="8.5725" width="0.1" layer="20"/>
<wire x1="-32.385" y1="6.985" x2="-32.385" y2="6.0325" width="0.1" layer="20"/>
<wire x1="-18.7325" y1="6.0325" x2="-18.7325" y2="6.985" width="0.1" layer="20"/>
<text x="0" y="33.655" size="1.4224" layer="1" font="vector" ratio="15" align="top-center">97793323</text>
<text x="-3.175" y="30.48" size="1.4224" layer="1" font="vector" ratio="15" align="top-center">R07</text>
</plain>
<libraries>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="CHIPLED_0603">
<description>&lt;b&gt;CHIPLED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG_LY Q971.pdf</description>
<wire x1="-0.3" y1="0.8" x2="0.3" y2="0.8" width="0.1016" layer="51" curve="170.055574"/>
<wire x1="-0.275" y1="-0.825" x2="0.275" y2="-0.825" width="0.0508" layer="51" curve="-180"/>
<wire x1="-0.4" y1="0.375" x2="-0.4" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.35" x2="0.4" y2="-0.35" width="0.1016" layer="51"/>
<circle x="-0.35" y="0.625" radius="0.075" width="0.0508" layer="51"/>
<smd name="C" x="0" y="0.75" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0" y="-0.75" dx="0.8" dy="0.8" layer="1"/>
<text x="-0.635" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.7" x2="-0.25" y2="0.85" layer="51"/>
<rectangle x1="-0.275" y1="0.55" x2="-0.225" y2="0.6" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="-0.4" y2="0.725" layer="51"/>
<rectangle x1="0.25" y1="0.55" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="0.45" y2="0.575" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="-0.25" y2="-0.35" layer="51"/>
<rectangle x1="0.25" y1="-0.85" x2="0.45" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.575" x2="0.275" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.65" x2="-0.175" y2="-0.55" layer="51"/>
<rectangle x1="0.175" y1="-0.65" x2="0.275" y2="-0.55" layer="51"/>
<rectangle x1="-0.125" y1="0" x2="0.125" y2="0.25" layer="21"/>
</package>
<package name="MICRO-SIDELED">
<description>&lt;b&gt;Hyper Micro SIDELED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY Y876.pdf</description>
<wire x1="0.65" y1="1.1" x2="-0.1" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="1.1" x2="-0.35" y2="1" width="0.1016" layer="51"/>
<wire x1="-0.35" y1="1" x2="-0.35" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-0.35" y1="-0.9" x2="-0.1" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="-1.1" x2="0.65" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="0.65" y2="1.1" width="0.1016" layer="21"/>
<wire x1="0.6" y1="0.9" x2="0.25" y2="0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="0.7" x2="0.25" y2="-0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="0.6" y2="-0.9" width="0.0508" layer="21"/>
<smd name="A" x="0" y="1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<text x="-1.27" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.4" y1="1.1" x2="0.4" y2="1.8" layer="29"/>
<rectangle x1="-0.4" y1="-1.8" x2="0.4" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-1.75" x2="0.35" y2="-1.15" layer="31"/>
<rectangle x1="-0.35" y1="1.15" x2="0.35" y2="1.75" layer="31"/>
<rectangle x1="-0.125" y1="1.125" x2="0.125" y2="1.75" layer="51"/>
<rectangle x1="-0.125" y1="-1.75" x2="0.125" y2="-1.125" layer="51"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT23">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.1524" x2="-1.4224" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.4224" y1="0.6604" x2="-0.8636" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="0.8636" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="1.57x14pin">
<packages>
<package name="1.57X14">
<description>csatlakozó</description>
<pad name="P$1" x="-6" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$2" x="-4" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$3" x="-2" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$4" x="0" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$5" x="2" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$6" x="4" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$7" x="6" y="-4" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$8" x="6" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$9" x="4" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$10" x="2" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$11" x="0" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$12" x="-2" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$13" x="-4" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<pad name="P$14" x="-6" y="2.238" drill="0.6" diameter="1.6" shape="square"/>
<wire x1="-7" y1="1.238" x2="7" y2="1.238" width="0.127" layer="21"/>
<wire x1="7" y1="1.238" x2="7" y2="-3" width="0.127" layer="21"/>
<wire x1="7" y1="-3" x2="-7" y2="-3" width="0.127" layer="21"/>
<wire x1="-7" y1="-3" x2="-7" y2="1.238" width="0.127" layer="21"/>
<circle x="-6" y="-2" radius="1" width="0.127" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<description language="hu">&lt;b&gt;EAGLE Tervezési Szabályok&lt;/b&gt;&lt;p&gt;Az alapértelmezett Tervezési Szabályok úgy lettek megállapítva, hogy használhatók legyenek minél többféle alkalmazás megtervezéséhez.A Te általad tervezni kívánt termék más beállításokat követelhet meg,így megkérlek, hogy tedd meg a neked szükséges beállításokat, és mentsd elegy másik néven.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="12mil"/>
<param name="mdWirePad" value="12mil"/>
<param name="mdWireVia" value="12mil"/>
<param name="mdPadPad" value="12mil"/>
<param name="mdPadVia" value="12mil"/>
<param name="mdViaVia" value="12mil"/>
<param name="mdSmdPad" value="12mil"/>
<param name="mdSmdVia" value="12mil"/>
<param name="mdSmdSmd" value="12mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="12mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="12mil"/>
<param name="msDrill" value="15mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="12mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="12mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="12mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="12mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="12mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="12mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="12mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="0"/>
<param name="psBottom" value="0"/>
<param name="psFirst" value="0"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="25mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="*"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="*"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="LED1" library="led" package="CHIPLED_0603" value="" x="-1.80975" y="13.589"/>
<element name="LED3" library="led" package="CHIPLED_0603" value="" x="-4.3815" y="6.31825" rot="R270"/>
<element name="LED4" library="led" package="CHIPLED_0603" value="" x="-6.95325" y="8.6995"/>
<element name="LED5" library="led" package="CHIPLED_0603" value="" x="-6.985" y="13.589"/>
<element name="LED6" library="led" package="CHIPLED_0603" value="" x="-4.41325" y="16.03375" rot="R270"/>
<element name="LED7" library="led" package="CHIPLED_0603" value="" x="-4.41325" y="11.176" rot="R270"/>
<element name="LED8" library="led" package="CHIPLED_0603" value="" x="6.858" y="13.62075"/>
<element name="LED9" library="led" package="CHIPLED_0603" value="" x="6.858" y="8.66775"/>
<element name="LED10" library="led" package="CHIPLED_0603" value="" x="4.28625" y="6.31825" rot="R270"/>
<element name="LED11" library="led" package="CHIPLED_0603" value="" x="1.68275" y="8.79475"/>
<element name="LED12" library="led" package="CHIPLED_0603" value="" x="1.68275" y="13.589"/>
<element name="LED13" library="led" package="CHIPLED_0603" value="" x="4.191" y="16.09725" rot="R270"/>
<element name="LED14" library="led" package="CHIPLED_0603" value="" x="4.2545" y="11.20775" rot="R270"/>
<element name="LED15" library="led" package="CHIPLED_0603" value="" x="12.0015" y="8.22325" rot="R90"/>
<element name="LED16" library="led" package="CHIPLED_0603" value="" x="14.70025" y="8.255" rot="R270"/>
<element name="LED17" library="led" package="CHIPLED_0603" value="" x="12.66825" y="14.1605"/>
<element name="LED18" library="led" package="CHIPLED_0603" value="" x="21.209" y="1.524"/>
<element name="LED19" library="led" package="CHIPLED_0603" value="" x="14.986" y="0.98425" rot="R90"/>
<element name="LED20" library="led" package="CHIPLED_0603" value="" x="27.33675" y="2.12725" rot="R180"/>
<element name="LED21" library="led" package="CHIPLED_0603" value="" x="24.03475" y="-3.683"/>
<element name="LED22" library="led" package="CHIPLED_0603" value="" x="17.93875" y="-3.683"/>
<element name="LED23" library="led" package="CHIPLED_0603" value="" x="-30.00375" y="-2.8575"/>
<element name="LED24" library="led" package="CHIPLED_0603" value="" x="-21.2725" y="-2.8575"/>
<element name="LED25" library="led" package="CHIPLED_0603" value="" x="-13.97" y="-2.82575"/>
<element name="LED26" library="led" package="CHIPLED_0603" value="" x="-27.178" y="-12.73175"/>
<element name="LED27" library="led" package="CHIPLED_0603" value="" x="-0.03175" y="5.81025"/>
<element name="D1" library="diode" package="SOT23" value="BAS40-05" x="7.58825" y="-12.8905" rot="R270"/>
<element name="D2" library="diode" package="SOT23" value="BAS40-05" x="23.71725" y="-11.2395" rot="R270"/>
<element name="LED28" library="led" package="MICRO-SIDELED" value="" x="-20.66925" y="-19.8755" rot="R180"/>
<element name="LED29" library="led" package="MICRO-SIDELED" value="" x="-16.5735" y="-19.8755" rot="R180"/>
<element name="LED30" library="led" package="MICRO-SIDELED" value="" x="-2.19075" y="-19.78025" rot="R180"/>
<element name="LED31" library="led" package="MICRO-SIDELED" value="" x="2.00025" y="-19.685" rot="R180"/>
<element name="LED32" library="led" package="MICRO-SIDELED" value="" x="16.383" y="-19.58975" rot="R180"/>
<element name="LED33" library="led" package="MICRO-SIDELED" value="" x="20.54225" y="-19.58975" rot="R180"/>
<element name="LED34" library="led" package="CHIPLED_0603" value="" x="-3.52425" y="-1.778" rot="R90"/>
<element name="LED35" library="led" package="CHIPLED_0603" value="" x="3.46075" y="-1.74625" rot="R90"/>
<element name="LED2" library="led" package="CHIPLED_0603" value="" x="-1.80975" y="8.79475"/>
<element name="SZIV-CSAT1" library="1.57x14pin" package="1.57X14" value="1.57X14" x="-25.654" y="7.46125"/>
</elements>
<signals>
<signal name="N$15">
<contactref element="LED24" pad="A"/>
<contactref element="LED20" pad="C"/>
<contactref element="LED27" pad="A"/>
<contactref element="LED23" pad="A"/>
<contactref element="LED22" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$1"/>
<wire x1="-29.972" y1="-3.90525" x2="-30.2895" y2="-3.58775" width="0.3048" layer="1"/>
<wire x1="-30.2895" y1="-3.58775" x2="-31.5595" y2="-2.31775" width="0.3048" layer="1"/>
<wire x1="-29.972" y1="-3.90525" x2="-30.00375" y2="-3.6075" width="0.3048" layer="1"/>
<wire x1="1.778" y1="4.98475" x2="-0.127" y2="4.98475" width="0.3048" layer="1"/>
<wire x1="9.398" y1="-2.63525" x2="1.778" y2="4.98475" width="0.3048" layer="1"/>
<wire x1="17.653" y1="-2.63525" x2="11.938" y2="-2.63525" width="0.3048" layer="1"/>
<wire x1="11.938" y1="-2.63525" x2="9.398" y2="-2.63525" width="0.3048" layer="1"/>
<wire x1="-0.127" y1="4.98475" x2="-0.03175" y2="5.06025" width="0.3048" layer="1"/>
<wire x1="17.653" y1="-2.63525" x2="17.93875" y2="-2.933" width="0.3048" layer="1"/>
<wire x1="24.003" y1="0.53975" x2="24.003" y2="1.17475" width="0.3048" layer="16"/>
<wire x1="20.193" y1="-3.27025" x2="24.003" y2="0.53975" width="0.3048" layer="16"/>
<wire x1="4.953" y1="-9.62025" x2="-18.2245" y2="-9.62025" width="0.3048" layer="1"/>
<wire x1="11.938" y1="-2.63525" x2="4.953" y2="-9.62025" width="0.3048" layer="1"/>
<via x="24.003" y="1.17475" extent="1-16" drill="0.381"/>
<via x="20.193" y="-3.27025" extent="1-16" drill="0.381"/>
<wire x1="-21.2725" y1="-3.6075" x2="-21.57025" y2="-3.90525" width="0.3048" layer="1"/>
<wire x1="-21.57025" y1="-3.90525" x2="-26.162" y2="-3.90525" width="0.3048" layer="1"/>
<wire x1="-26.162" y1="-3.90525" x2="-27.1145" y2="-2.95275" width="0.3048" layer="1"/>
<wire x1="-27.1145" y1="-2.95275" x2="-28.3845" y2="-2.95275" width="0.3048" layer="1"/>
<wire x1="-28.3845" y1="-2.95275" x2="-29.0195" y2="-3.58775" width="0.3048" layer="1"/>
<wire x1="-29.0195" y1="-3.58775" x2="-30.2895" y2="-3.58775" width="0.3048" layer="1"/>
<wire x1="24.003" y1="1.17475" x2="27.178" y2="1.17475" width="0.3048" layer="1"/>
<wire x1="27.178" y1="1.17475" x2="27.33675" y2="1.37725" width="0.3048" layer="1"/>
<wire x1="-18.2245" y1="-9.62025" x2="-21.3995" y2="-6.44525" width="0.3048" layer="1"/>
<wire x1="-21.3995" y1="-6.44525" x2="-21.3995" y2="-3.90525" width="0.3048" layer="1"/>
<wire x1="-21.3995" y1="-3.90525" x2="-21.082" y2="-3.58775" width="0.3048" layer="1"/>
<wire x1="-21.082" y1="-3.58775" x2="-21.25275" y2="-3.58775" width="0.3048" layer="1"/>
<wire x1="-21.25275" y1="-3.58775" x2="-21.2725" y2="-3.6075" width="0.3048" layer="1"/>
<wire x1="-31.5595" y1="-2.31775" x2="-31.5595" y2="3.39725" width="0.3048" layer="1"/>
<wire x1="-31.654" y1="3.46125" x2="-31.5595" y2="3.39725" width="0" layer="19" extent="1-1"/>
<wire x1="17.93875" y1="-2.933" x2="19.85575" y2="-2.933" width="0.3048" layer="1"/>
<wire x1="19.85575" y1="-2.933" x2="20.193" y2="-3.27025" width="0.3048" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="LED30" pad="C"/>
<contactref element="LED31" pad="C"/>
<contactref element="D1" pad="2"/>
<wire x1="2.413" y1="-17.87525" x2="6.223" y2="-14.06525" width="0.3048" layer="1"/>
<wire x1="6.223" y1="-14.06525" x2="6.48825" y2="-13.8405" width="0.3048" layer="1"/>
<wire x1="2.413" y1="-17.87525" x2="2.00025" y2="-17.735" width="0.3048" layer="1"/>
<wire x1="1.778" y1="-17.87525" x2="-2.032" y2="-17.87525" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="-17.87525" x2="-2.19075" y2="-17.83025" width="0.3048" layer="1"/>
<wire x1="1.778" y1="-17.87525" x2="2.00025" y2="-17.735" width="0.3048" layer="1"/>
</signal>
<signal name="N$20">
<contactref element="LED28" pad="C"/>
<contactref element="LED29" pad="C"/>
<contactref element="D1" pad="1"/>
<wire x1="1.143" y1="-12.16025" x2="6.223" y2="-12.16025" width="0.3048" layer="1"/>
<wire x1="-3.937" y1="-17.24025" x2="1.143" y2="-12.16025" width="0.3048" layer="1"/>
<wire x1="-3.937" y1="-18.51025" x2="-3.937" y2="-17.24025" width="0.3048" layer="1"/>
<wire x1="-2.667" y1="-19.78025" x2="-3.937" y2="-18.51025" width="0.3048" layer="1"/>
<wire x1="2.413" y1="-19.78025" x2="-2.667" y2="-19.78025" width="0.3048" layer="1"/>
<wire x1="3.683" y1="-21.05025" x2="2.413" y2="-19.78025" width="0.3048" layer="1"/>
<wire x1="3.683" y1="-22.32025" x2="3.683" y2="-21.05025" width="0.3048" layer="1"/>
<wire x1="2.413" y1="-23.59025" x2="3.683" y2="-22.32025" width="0.3048" layer="1"/>
<wire x1="-5.842" y1="-23.59025" x2="2.413" y2="-23.59025" width="0.3048" layer="1"/>
<wire x1="-10.922" y1="-18.51025" x2="-5.842" y2="-23.59025" width="0.3048" layer="1"/>
<wire x1="-16.002" y1="-18.51025" x2="-10.922" y2="-18.51025" width="0.3048" layer="1"/>
<wire x1="6.223" y1="-12.16025" x2="6.48825" y2="-11.9405" width="0.3048" layer="1"/>
<wire x1="-16.002" y1="-18.51025" x2="-16.5735" y2="-17.9255" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="-17.87525" x2="-20.447" y2="-17.87525" width="0.3048" layer="1"/>
<wire x1="-20.447" y1="-17.87525" x2="-20.66925" y2="-17.9255" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="-17.87525" x2="-16.5735" y2="-17.9255" width="0.3048" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="LED30" pad="A"/>
<contactref element="LED31" pad="A"/>
<contactref element="LED14" pad="A"/>
<contactref element="LED8" pad="A"/>
<contactref element="LED22" pad="A"/>
<contactref element="LED18" pad="C"/>
<contactref element="LED26" pad="A"/>
<contactref element="SZIV-CSAT1" pad="P$14"/>
<wire x1="4.6355" y1="12.60475" x2="3.3655" y2="11.33475" width="0.3048" layer="1"/>
<wire x1="6.858" y1="12.60475" x2="5.588" y2="12.60475" width="0.3048" layer="1"/>
<wire x1="5.588" y1="12.60475" x2="4.6355" y2="12.60475" width="0.3048" layer="1"/>
<wire x1="3.3655" y1="11.33475" x2="3.5045" y2="11.20775" width="0.3048" layer="1"/>
<wire x1="6.858" y1="12.60475" x2="6.858" y2="12.87075" width="0.3048" layer="1"/>
<wire x1="-10.922" y1="-13.43025" x2="-26.797" y2="-13.43025" width="0.3048" layer="1"/>
<wire x1="-2.667" y1="-21.68525" x2="-6.477" y2="-17.87525" width="0.3048" layer="1"/>
<wire x1="-6.477" y1="-17.87525" x2="-10.922" y2="-13.43025" width="0.3048" layer="1"/>
<wire x1="-26.797" y1="-13.43025" x2="-27.178" y2="-13.48175" width="0.3048" layer="1"/>
<wire x1="-2.667" y1="-21.68525" x2="-2.19075" y2="-21.73025" width="0.3048" layer="1"/>
<wire x1="0.508" y1="-10.89025" x2="11.938" y2="-10.89025" width="0.3048" layer="1"/>
<wire x1="-6.477" y1="-17.87525" x2="0.508" y2="-10.89025" width="0.3048" layer="1"/>
<wire x1="19.558" y1="-0.73025" x2="19.558" y2="1.17475" width="0.3048" layer="16"/>
<wire x1="17.018" y1="-3.27025" x2="19.558" y2="-0.73025" width="0.3048" layer="16"/>
<wire x1="17.018" y1="-5.81025" x2="17.018" y2="-3.27025" width="0.3048" layer="16"/>
<wire x1="-2.032" y1="-21.68525" x2="1.778" y2="-21.68525" width="0.3048" layer="1"/>
<wire x1="1.778" y1="-21.68525" x2="2.00025" y2="-21.635" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="-21.68525" x2="-2.19075" y2="-21.73025" width="0.3048" layer="1"/>
<wire x1="8.763" y1="12.60475" x2="5.588" y2="12.60475" width="0.3048" layer="16"/>
<wire x1="11.303" y1="15.14475" x2="8.763" y2="12.60475" width="0.3048" layer="16"/>
<wire x1="-31.242" y1="10.69975" x2="-31.242" y2="10.06475" width="0.3048" layer="1"/>
<wire x1="-30.2895" y1="11.65225" x2="-31.242" y2="10.69975" width="0.3048" layer="1"/>
<wire x1="-16.3195" y1="11.65225" x2="-30.2895" y2="11.65225" width="0.3048" layer="1"/>
<wire x1="-9.652" y1="18.31975" x2="-16.3195" y2="11.65225" width="0.3048" layer="1"/>
<wire x1="9.7155" y1="18.31975" x2="-9.652" y2="18.31975" width="0.3048" layer="1"/>
<wire x1="-31.242" y1="10.06475" x2="-31.654" y2="9.69925" width="0.3048" layer="1"/>
<via x="19.558" y="1.17475" extent="1-16" drill="0.381"/>
<via x="17.018" y="-5.81025" extent="1-16" drill="0.381"/>
<via x="5.588" y="12.60475" extent="1-16" drill="0.381"/>
<via x="11.303" y="15.14475" extent="1-16" drill="0.381"/>
<wire x1="19.558" y1="1.17475" x2="19.558" y2="2.12725" width="0.3048" layer="1"/>
<wire x1="19.558" y1="2.12725" x2="19.558" y2="2.44475" width="0.3048" layer="1"/>
<wire x1="19.558" y1="2.44475" x2="16.383" y2="5.61975" width="0.3048" layer="1"/>
<wire x1="21.209" y1="2.274" x2="19.70475" y2="2.274" width="0.3048" layer="1"/>
<wire x1="19.70475" y1="2.274" x2="19.558" y2="2.12725" width="0.3048" layer="1"/>
<wire x1="17.93875" y1="-4.433" x2="17.93875" y2="-4.8895" width="0.3048" layer="1"/>
<wire x1="17.93875" y1="-4.8895" x2="17.018" y2="-5.81025" width="0.3048" layer="1"/>
<wire x1="17.018" y1="-5.81025" x2="11.938" y2="-10.89025" width="0.3048" layer="1"/>
<wire x1="16.383" y1="5.61975" x2="16.383" y2="7.20725" width="0.3048" layer="1"/>
<wire x1="16.383" y1="7.20725" x2="18.288" y2="9.11225" width="0.3048" layer="1"/>
<wire x1="18.288" y1="14.19225" x2="15.748" y2="16.73225" width="0.3048" layer="1"/>
<wire x1="18.288" y1="9.11225" x2="18.288" y2="14.19225" width="0.3048" layer="1"/>
<wire x1="11.303" y1="16.73225" x2="11.303" y2="15.14475" width="0.3048" layer="1"/>
<wire x1="15.748" y1="16.73225" x2="11.303" y2="16.73225" width="0.3048" layer="1"/>
<wire x1="9.7155" y1="18.31975" x2="11.303" y2="16.73225" width="0.3048" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="D1" pad="3"/>
<contactref element="D2" pad="3"/>
<contactref element="LED6" pad="C"/>
<contactref element="LED5" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$8"/>
<wire x1="17.653" y1="-12.79525" x2="8.763" y2="-12.79525" width="0.3048" layer="1"/>
<wire x1="21.463" y1="-8.98525" x2="17.653" y2="-12.79525" width="0.3048" layer="1"/>
<wire x1="23.368" y1="-8.98525" x2="21.463" y2="-8.98525" width="0.3048" layer="1"/>
<wire x1="25.273" y1="-10.89025" x2="23.368" y2="-8.98525" width="0.3048" layer="1"/>
<wire x1="8.763" y1="-12.79525" x2="8.68825" y2="-12.8905" width="0.3048" layer="1"/>
<wire x1="25.273" y1="-10.89025" x2="24.81725" y2="-11.2395" width="0.3048" layer="1"/>
<wire x1="-4.8895" y1="14.50975" x2="-7.112" y2="14.50975" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="15.77975" x2="-4.8895" y2="14.50975" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="15.77975" x2="-3.66325" y2="16.03375" width="0.3048" layer="1"/>
<wire x1="-9.017" y1="14.50975" x2="-7.112" y2="14.50975" width="0.3048" layer="1"/>
<wire x1="-12.5095" y1="11.01725" x2="-9.017" y2="14.50975" width="0.3048" layer="16"/>
<wire x1="-7.112" y1="14.50975" x2="-6.985" y2="14.339" width="0.3048" layer="1"/>
<wire x1="-19.177" y1="9.74725" x2="-19.654" y2="9.69925" width="0.3048" layer="1"/>
<wire x1="23.368" y1="-5.81025" x2="23.368" y2="-8.98525" width="0.3048" layer="1"/>
<wire x1="23.368" y1="-1.68275" x2="23.368" y2="-5.81025" width="0.3048" layer="16"/>
<wire x1="25.273" y1="0.22225" x2="23.368" y2="-1.68275" width="0.3048" layer="16"/>
<wire x1="25.273" y1="3.71475" x2="25.273" y2="0.22225" width="0.3048" layer="16"/>
<wire x1="11.938" y1="17.04975" x2="25.273" y2="3.71475" width="0.3048" layer="16"/>
<wire x1="-7.112" y1="17.04975" x2="11.938" y2="17.04975" width="0.3048" layer="16"/>
<wire x1="-9.017" y1="15.14475" x2="-7.112" y2="17.04975" width="0.3048" layer="16"/>
<wire x1="-9.017" y1="14.50975" x2="-9.017" y2="15.14475" width="0.3048" layer="16"/>
<via x="-9.017" y="14.50975" extent="1-16" drill="0.381"/>
<via x="-12.5095" y="11.01725" extent="1-16" drill="0.381"/>
<via x="23.368" y="-5.81025" extent="1-16" drill="0.381"/>
<wire x1="-19.177" y1="9.74725" x2="-13.7795" y2="9.74725" width="0.3048" layer="1"/>
<wire x1="-13.7795" y1="9.74725" x2="-12.5095" y2="11.01725" width="0.3048" layer="1"/>
</signal>
<signal name="N$21">
<contactref element="LED32" pad="C"/>
<contactref element="LED33" pad="C"/>
<contactref element="D2" pad="2"/>
<wire x1="16.383" y1="-17.87525" x2="17.018" y2="-17.24025" width="0.3048" layer="1"/>
<wire x1="17.018" y1="-17.24025" x2="22.098" y2="-12.16025" width="0.3048" layer="1"/>
<wire x1="22.098" y1="-12.16025" x2="22.61725" y2="-12.1895" width="0.3048" layer="1"/>
<wire x1="16.383" y1="-17.87525" x2="16.383" y2="-17.63975" width="0.3048" layer="1"/>
<wire x1="17.018" y1="-17.24025" x2="20.193" y2="-17.24025" width="0.3048" layer="1"/>
<wire x1="20.193" y1="-17.24025" x2="20.54225" y2="-17.63975" width="0.3048" layer="1"/>
<wire x1="17.018" y1="-17.24025" x2="16.383" y2="-17.63975" width="0.3048" layer="1"/>
</signal>
<signal name="N$25">
<contactref element="LED9" pad="A"/>
<contactref element="LED20" pad="A"/>
<contactref element="LED19" pad="A"/>
<contactref element="LED29" pad="A"/>
<contactref element="LED28" pad="A"/>
<contactref element="LED12" pad="A"/>
<contactref element="LED13" pad="A"/>
<contactref element="SZIV-CSAT1" pad="P$2"/>
<wire x1="5.588" y1="8.15975" x2="6.858" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="5.588" y1="10.38225" x2="5.588" y2="8.15975" width="0.3048" layer="16"/>
<wire x1="3.3655" y1="12.92225" x2="5.588" y2="10.38225" width="0.3048" layer="16"/>
<wire x1="6.858" y1="8.15975" x2="6.858" y2="7.91775" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="-21.68525" x2="-20.447" y2="-21.68525" width="0.3048" layer="1"/>
<wire x1="-20.447" y1="-21.68525" x2="-20.66925" y2="-21.8255" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="-21.68525" x2="-16.5735" y2="-21.8255" width="0.3048" layer="1"/>
<wire x1="-29.0195" y1="-13.74775" x2="-25.2095" y2="-17.55775" width="0.3048" layer="1"/>
<wire x1="-25.2095" y1="-17.55775" x2="-21.082" y2="-21.68525" width="0.3048" layer="1"/>
<wire x1="-21.082" y1="-21.68525" x2="-20.66925" y2="-21.8255" width="0.3048" layer="1"/>
<wire x1="18.288" y1="-8.98525" x2="18.288" y2="-3.27025" width="0.3048" layer="16"/>
<wire x1="13.843" y1="-13.43025" x2="18.288" y2="-8.98525" width="0.3048" layer="16"/>
<via x="5.588" y="8.15975" extent="1-16" drill="0.381"/>
<via x="3.3655" y="12.92225" extent="1-16" drill="0.381"/>
<via x="24.003" y="3.07975" extent="1-16" drill="0.381"/>
<via x="-28.067" y="-4.22275" extent="1-16" drill="0.381"/>
<wire x1="24.003" y1="3.07975" x2="27.178" y2="3.07975" width="0.3048" layer="1"/>
<wire x1="27.178" y1="3.07975" x2="27.33675" y2="2.87725" width="0.3048" layer="1"/>
<wire x1="18.288" y1="-3.27025" x2="20.828" y2="-0.73025" width="0.3048" layer="16"/>
<wire x1="-29.654" y1="3.46125" x2="-29.654" y2="1.17425" width="0.3048" layer="16"/>
<wire x1="-29.654" y1="1.17425" x2="-28.067" y2="-0.41275" width="0.3048" layer="16"/>
<wire x1="-28.067" y1="-0.41275" x2="-28.067" y2="-4.22275" width="0.3048" layer="16"/>
<wire x1="3.441" y1="16.09725" x2="3.441" y2="12.99775" width="0.3048" layer="1"/>
<wire x1="3.441" y1="12.99775" x2="3.3655" y2="12.92225" width="0.3048" layer="1"/>
<wire x1="1.68275" y1="12.839" x2="3.13125" y2="12.839" width="0.3048" layer="1"/>
<wire x1="3.13125" y1="12.839" x2="3.3655" y2="12.92225" width="0.3048" layer="1"/>
<wire x1="24.003" y1="3.07975" x2="20.828" y2="3.07975" width="0.3048" layer="16"/>
<wire x1="20.828" y1="-0.73025" x2="20.828" y2="3.07975" width="0.3048" layer="16"/>
<wire x1="20.828" y1="3.07975" x2="17.653" y2="3.07975" width="0.3048" layer="16"/>
<wire x1="17.653" y1="3.07975" x2="17.018" y2="2.44475" width="0.3048" layer="16"/>
<via x="17.018" y="2.44475" extent="1-16" drill="0.4" diameter="0.4064"/>
<wire x1="17.018" y1="2.44475" x2="17.018" y2="1.49225" width="0.3048" layer="1"/>
<wire x1="17.018" y1="1.49225" x2="16.7005" y2="1.17475" width="0.3048" layer="1"/>
<wire x1="16.7005" y1="1.17475" x2="15.9265" y2="1.17475" width="0.3048" layer="1"/>
<wire x1="15.9265" y1="1.17475" x2="15.736" y2="0.98425" width="0.3048" layer="1"/>
<wire x1="5.588" y1="8.15975" x2="5.9055" y2="8.15975" width="0.3048" layer="16"/>
<wire x1="5.9055" y1="8.15975" x2="11.6205" y2="2.44475" width="0.3048" layer="16"/>
<wire x1="11.6205" y1="2.44475" x2="17.018" y2="2.44475" width="0.3048" layer="16"/>
<wire x1="-29.0195" y1="-13.74775" x2="-29.0195" y2="-9.93775" width="0.3048" layer="1"/>
<wire x1="-29.0195" y1="-9.93775" x2="-28.067" y2="-8.98525" width="0.3048" layer="1"/>
<wire x1="-28.067" y1="-8.98525" x2="-28.067" y2="-4.22275" width="0.3048" layer="1"/>
<wire x1="13.843" y1="-13.43025" x2="-21.082" y2="-13.43025" width="0.3048" layer="16"/>
<wire x1="-21.082" y1="-13.43025" x2="-25.2095" y2="-17.55775" width="0.3048" layer="16"/>
<via x="-25.2095" y="-17.55775" extent="1-16" drill="0.4" diameter="0.4064"/>
</signal>
<signal name="N$27">
<contactref element="LED26" pad="C"/>
<contactref element="LED21" pad="A"/>
<contactref element="LED7" pad="C"/>
<contactref element="LED1" pad="C"/>
<contactref element="LED12" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$13"/>
<wire x1="-3.6195" y1="12.92225" x2="-3.6195" y2="11.33475" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="14.50975" x2="-3.6195" y2="12.92225" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="11.01725" x2="-3.66325" y2="11.176" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="14.50975" x2="1.778" y2="14.50975" width="0.3048" layer="1"/>
<wire x1="1.778" y1="14.50975" x2="1.68275" y2="14.339" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="14.50975" x2="-1.80975" y2="14.339" width="0.3048" layer="1"/>
<wire x1="-25.527" y1="-12.16025" x2="-26.797" y2="-12.16025" width="0.3048" layer="1"/>
<wire x1="-26.797" y1="-12.16025" x2="-27.178" y2="-11.98175" width="0.3048" layer="1"/>
<wire x1="20.828" y1="-4.54025" x2="24.003" y2="-4.54025" width="0.3048" layer="1"/>
<wire x1="15.748" y1="-9.62025" x2="20.828" y2="-4.54025" width="0.3048" layer="1"/>
<wire x1="-25.527" y1="-9.62025" x2="15.748" y2="-9.62025" width="0.3048" layer="16"/>
<wire x1="24.003" y1="-4.54025" x2="24.03475" y2="-4.433" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="10.69975" x2="-3.6195" y2="11.01725" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="11.01725" x2="-3.6195" y2="11.33475" width="0.3048" layer="1"/>
<wire x1="-4.2545" y1="10.06475" x2="-3.6195" y2="10.69975" width="0.3048" layer="1"/>
<wire x1="-5.842" y1="10.06475" x2="-4.2545" y2="10.06475" width="0.3048" layer="1"/>
<wire x1="-6.477" y1="10.69975" x2="-5.842" y2="10.06475" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="11.33475" x2="-3.66325" y2="11.176" width="0.3048" layer="1"/>
<via x="-25.527" y="-12.16025" extent="1-16" drill="0.381"/>
<via x="15.748" y="-9.62025" extent="1-16" drill="0.381"/>
<via x="-6.477" y="10.69975" extent="1-16" drill="0.381"/>
<wire x1="-29.654" y1="9.69925" x2="-29.6545" y2="9.44575" width="0.3048" layer="16"/>
<wire x1="-29.6545" y1="9.44575" x2="-29.6545" y2="10.69975" width="0.3048" layer="16"/>
<wire x1="-29.6545" y1="10.69975" x2="-30.2895" y2="11.33475" width="0.3048" layer="16"/>
<wire x1="-30.2895" y1="11.33475" x2="-32.8295" y2="11.33475" width="0.3048" layer="16"/>
<wire x1="-6.477" y1="4.34975" x2="-6.477" y2="10.69975" width="0.3048" layer="16"/>
<wire x1="-6.477" y1="4.34975" x2="-12.192" y2="-1.36525" width="0.3048" layer="16"/>
<wire x1="-12.192" y1="-1.36525" x2="-24.5745" y2="-1.36525" width="0.3048" layer="16"/>
<wire x1="-24.5745" y1="-1.36525" x2="-25.527" y2="-2.31775" width="0.3048" layer="16"/>
<wire x1="-25.527" y1="-2.31775" x2="-25.527" y2="-6.12775" width="0.3048" layer="16"/>
<wire x1="-25.527" y1="-6.12775" x2="-25.527" y2="-9.62025" width="0.3048" layer="16"/>
<wire x1="-25.527" y1="-9.62025" x2="-25.527" y2="-12.16025" width="0.3048" layer="16"/>
<wire x1="-34.0995" y1="-0.41275" x2="-28.3845" y2="-6.12775" width="0.3048" layer="16"/>
<wire x1="-28.3845" y1="-6.12775" x2="-25.527" y2="-6.12775" width="0.3048" layer="16"/>
<wire x1="-32.8295" y1="11.33475" x2="-33.3375" y2="10.82675" width="0.3048" layer="16"/>
<wire x1="-33.3375" y1="10.82675" x2="-33.3375" y2="9.525" width="0.3048" layer="16"/>
<wire x1="-33.3375" y1="9.525" x2="-34.0995" y2="8.763" width="0.3048" layer="16"/>
<wire x1="-34.0995" y1="8.763" x2="-34.0995" y2="-0.41275" width="0.3048" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="LED35" pad="A"/>
<contactref element="SZIV-CSAT1" pad="P$10"/>
<wire x1="-23.654" y1="9.69925" x2="-23.622" y2="9.47725" width="0.3048" layer="16"/>
<wire x1="-23.622" y1="9.47725" x2="-23.622" y2="10.38225" width="0.3048" layer="16"/>
<wire x1="-23.622" y1="10.38225" x2="-22.987" y2="11.01725" width="0.3048" layer="16"/>
<wire x1="-22.987" y1="11.01725" x2="-16.637" y2="11.01725" width="0.3048" layer="16"/>
<wire x1="-16.637" y1="11.01725" x2="-9.017" y2="3.39725" width="0.3048" layer="16"/>
<via x="-9.017" y="3.39725" extent="1-16" drill="0.5" diameter="0.6096"/>
<wire x1="-9.017" y1="3.39725" x2="-5.842" y2="0.22225" width="0.3048" layer="1"/>
<wire x1="-5.842" y1="0.22225" x2="2.7305" y2="0.22225" width="0.3048" layer="1"/>
<wire x1="2.7305" y1="0.22225" x2="4.21075" y2="-1.258" width="0.3048" layer="1"/>
<wire x1="4.21075" y1="-1.258" x2="4.21075" y2="-1.74625" width="0.3048" layer="1"/>
</signal>
<signal name="N$24">
<contactref element="LED35" pad="C"/>
<contactref element="LED34" pad="A"/>
<wire x1="2.413" y1="-2.00025" x2="-2.667" y2="-2.00025" width="0.3048" layer="1"/>
<wire x1="-2.667" y1="-2.00025" x2="-2.77425" y2="-1.778" width="0.3048" layer="1"/>
<wire x1="2.413" y1="-2.00025" x2="2.71075" y2="-1.74625" width="0.3048" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="LED34" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$12"/>
<wire x1="-27.654" y1="9.69925" x2="-27.654" y2="10.79525" width="0.3048" layer="16"/>
<wire x1="-27.654" y1="10.79525" x2="-26.797" y2="11.65225" width="0.3048" layer="16"/>
<wire x1="-26.797" y1="11.65225" x2="-15.6845" y2="11.65225" width="0.3048" layer="16"/>
<wire x1="-15.6845" y1="11.65225" x2="-9.017" y2="4.98475" width="0.3048" layer="16"/>
<via x="-9.017" y="4.98475" extent="1-16" drill="0.5" diameter="0.6096"/>
<wire x1="-9.017" y1="4.98475" x2="-10.287" y2="3.71475" width="0.3048" layer="1"/>
<wire x1="-10.287" y1="3.71475" x2="-10.287" y2="1.80975" width="0.3048" layer="1"/>
<wire x1="-10.287" y1="1.80975" x2="-7.747" y2="-0.73025" width="0.3048" layer="1"/>
<wire x1="-7.747" y1="-0.73025" x2="-4.8895" y2="-0.73025" width="0.3048" layer="1"/>
<wire x1="-4.8895" y1="-0.73025" x2="-4.27425" y2="-1.3455" width="0.3048" layer="1"/>
<wire x1="-4.27425" y1="-1.3455" x2="-4.27425" y2="-1.778" width="0.3048" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="LED14" pad="C"/>
<contactref element="LED11" pad="C"/>
<contactref element="LED9" pad="C"/>
<contactref element="LED16" pad="C"/>
<contactref element="LED2" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$11"/>
<wire x1="1.778" y1="9.42975" x2="-2.032" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="9.42975" x2="-1.80975" y2="9.54475" width="0.3048" layer="1"/>
<wire x1="4.953" y1="11.33475" x2="5.0045" y2="11.20775" width="0.3048" layer="1"/>
<wire x1="9.398" y1="11.96975" x2="15.4305" y2="11.96975" width="0.3048" layer="16"/>
<wire x1="8.128" y1="10.69975" x2="9.398" y2="11.96975" width="0.3048" layer="16"/>
<wire x1="6.858" y1="9.42975" x2="8.128" y2="10.69975" width="0.3048" layer="1"/>
<wire x1="6.858" y1="9.42975" x2="5.2705" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="5.2705" y1="9.42975" x2="1.778" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="1.778" y1="9.42975" x2="1.68275" y2="9.54475" width="0.3048" layer="1"/>
<wire x1="6.858" y1="9.42975" x2="6.858" y2="9.41775" width="0.3048" layer="1"/>
<via x="15.4305" y="11.96975" extent="1-16" drill="0.381"/>
<via x="8.128" y="10.69975" extent="1-16" drill="0.381"/>
<wire x1="-25.654" y1="9.69925" x2="-25.527" y2="9.57225" width="0.3048" layer="1"/>
<wire x1="-25.527" y1="9.57225" x2="-25.527" y2="10.38225" width="0.3048" layer="1"/>
<wire x1="-25.527" y1="10.38225" x2="-24.892" y2="11.01725" width="0.3048" layer="1"/>
<wire x1="-24.892" y1="11.01725" x2="-14.732" y2="11.01725" width="0.3048" layer="1"/>
<wire x1="-14.732" y1="11.01725" x2="-12.5095" y2="13.23975" width="0.3048" layer="1"/>
<via x="-12.5095" y="13.23975" extent="1-16" drill="0.5" diameter="0.6096"/>
<wire x1="-12.5095" y1="13.23975" x2="-7.747" y2="18.00225" width="0.3048" layer="16"/>
<wire x1="-7.747" y1="18.00225" x2="12.8905" y2="18.00225" width="0.3048" layer="16"/>
<wire x1="4.953" y1="11.33475" x2="5.2705" y2="11.01725" width="0.3048" layer="1"/>
<wire x1="5.2705" y1="11.01725" x2="5.2705" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="15.45025" y1="8.255" x2="15.45025" y2="10.9975" width="0.3048" layer="1"/>
<wire x1="15.45025" y1="10.9975" x2="15.4305" y2="11.96975" width="0.3048" layer="1"/>
<via x="17.018" y="13.55725" extent="1-16" drill="0.4" diameter="0.4064"/>
<wire x1="17.018" y1="13.55725" x2="15.4305" y2="11.96975" width="0.3048" layer="1"/>
<wire x1="12.8905" y1="18.00225" x2="17.018" y2="13.87475" width="0.3048" layer="16"/>
<wire x1="17.018" y1="13.87475" x2="17.018" y2="13.55725" width="0.3048" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="LED15" pad="C"/>
<contactref element="LED8" pad="C"/>
<contactref element="LED13" pad="C"/>
<contactref element="LED4" pad="C"/>
<contactref element="LED3" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$5"/>
<wire x1="11.303" y1="11.33475" x2="11.303" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="11.303" y1="8.15975" x2="11.2515" y2="8.22325" width="0.3048" layer="1"/>
<wire x1="6.858" y1="14.50975" x2="6.858" y2="14.37075" width="0.3048" layer="1"/>
<wire x1="-7.112" y1="9.42975" x2="-6.95325" y2="9.4495" width="0.3048" layer="1"/>
<wire x1="-23.622" y1="-0.09525" x2="-23.622" y2="3.07975" width="0.3048" layer="1"/>
<wire x1="-18.542" y1="-0.09525" x2="-23.622" y2="-0.09525" width="0.3048" layer="16"/>
<wire x1="-17.907" y1="0.53975" x2="-18.542" y2="-0.09525" width="0.3048" layer="16"/>
<wire x1="-15.367" y1="0.53975" x2="-17.907" y2="0.53975" width="0.3048" layer="1"/>
<wire x1="-23.622" y1="3.07975" x2="-23.654" y2="3.46125" width="0.3048" layer="1"/>
<wire x1="-8.382" y1="17.04975" x2="4.953" y2="17.04975" width="0.3048" layer="1"/>
<wire x1="4.953" y1="17.04975" x2="5.588" y2="17.04975" width="0.3048" layer="1"/>
<wire x1="-10.287" y1="15.14475" x2="-8.382" y2="17.04975" width="0.3048" layer="1"/>
<via x="-23.622" y="-0.09525" extent="1-16" drill="0.381"/>
<via x="-17.907" y="0.53975" extent="1-16" drill="0.381"/>
<wire x1="-10.287" y1="15.14475" x2="-10.287" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="-10.287" y1="9.42975" x2="-10.287" y2="6.57225" width="0.3048" layer="1"/>
<wire x1="-10.287" y1="6.57225" x2="-10.287" y2="5.61975" width="0.3048" layer="1"/>
<wire x1="-15.367" y1="0.53975" x2="-10.287" y2="5.61975" width="0.3048" layer="1"/>
<wire x1="-7.112" y1="9.42975" x2="-10.287" y2="9.42975" width="0.3048" layer="1"/>
<wire x1="-3.6315" y1="6.31825" x2="-3.6195" y2="6.30625" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="6.30625" x2="-3.6195" y2="5.30225" width="0.3048" layer="1"/>
<wire x1="-3.6195" y1="5.30225" x2="-4.2545" y2="4.66725" width="0.3048" layer="1"/>
<wire x1="-4.2545" y1="4.66725" x2="-6.1595" y2="4.66725" width="0.3048" layer="1"/>
<wire x1="-6.1595" y1="4.66725" x2="-8.0645" y2="6.57225" width="0.3048" layer="1"/>
<wire x1="-8.0645" y1="6.57225" x2="-10.287" y2="6.57225" width="0.3048" layer="1"/>
<wire x1="5.588" y1="17.04975" x2="7.8105" y2="14.82725" width="0.3048" layer="1"/>
<wire x1="7.8105" y1="14.82725" x2="11.303" y2="11.33475" width="0.3048" layer="1"/>
<wire x1="4.941" y1="16.09725" x2="4.941" y2="17.03775" width="0.3048" layer="1"/>
<wire x1="4.941" y1="17.03775" x2="4.953" y2="17.04975" width="0.3048" layer="1"/>
<wire x1="6.858" y1="14.50975" x2="7.493" y2="14.50975" width="0.3048" layer="1"/>
<wire x1="7.493" y1="14.50975" x2="7.8105" y2="14.82725" width="0.3048" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="LED10" pad="C"/>
<contactref element="LED18" pad="A"/>
<contactref element="LED17" pad="C"/>
<contactref element="LED25" pad="C"/>
<contactref element="LED19" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$3"/>
<wire x1="-17.272" y1="-2.00025" x2="-14.097" y2="-2.00025" width="0.3048" layer="1"/>
<wire x1="-20.447" y1="1.17475" x2="-17.272" y2="-2.00025" width="0.3048" layer="1"/>
<wire x1="-26.797" y1="1.17475" x2="-20.447" y2="1.17475" width="0.3048" layer="16"/>
<wire x1="9.398" y1="6.25475" x2="5.588" y2="6.25475" width="0.3048" layer="1"/>
<wire x1="5.588" y1="6.25475" x2="4.953" y2="6.25475" width="0.3048" layer="1"/>
<wire x1="13.843" y1="10.69975" x2="9.398" y2="6.25475" width="0.3048" layer="16"/>
<wire x1="13.843" y1="14.82725" x2="13.843" y2="10.69975" width="0.3048" layer="1"/>
<wire x1="4.953" y1="6.25475" x2="5.03625" y2="6.31825" width="0.3048" layer="1"/>
<wire x1="13.843" y1="10.69975" x2="17.653" y2="6.88975" width="0.3048" layer="16"/>
<wire x1="21.463" y1="0.53975" x2="21.209" y2="0.774" width="0.3048" layer="1"/>
<wire x1="5.588" y1="6.25475" x2="5.588" y2="4.98475" width="0.3048" layer="1"/>
<wire x1="-7.112" y1="-2.00025" x2="-14.097" y2="-2.00025" width="0.3048" layer="1"/>
<wire x1="-5.207" y1="-2.00025" x2="-7.112" y2="-2.00025" width="0.3048" layer="16"/>
<wire x1="-14.097" y1="-2.00025" x2="-13.97" y2="-2.07575" width="0.3048" layer="1"/>
<via x="-20.447" y="1.17475" extent="1-16" drill="0.381"/>
<via x="9.398" y="6.25475" extent="1-16" drill="0.381"/>
<via x="13.843" y="10.69975" extent="1-16" drill="0.381"/>
<via x="17.653" y="6.88975" extent="1-16" drill="0.381"/>
<via x="9.7155" y="2.12725" extent="1-16" drill="0.381"/>
<via x="5.588" y="4.98475" extent="1-16" drill="0.381"/>
<via x="-7.112" y="-2.00025" extent="1-16" drill="0.381"/>
<wire x1="17.653" y1="6.88975" x2="18.6055" y2="6.88975" width="0.3048" layer="1"/>
<wire x1="18.6055" y1="6.88975" x2="22.733" y2="2.76225" width="0.3048" layer="1"/>
<wire x1="22.733" y1="2.76225" x2="22.733" y2="0.85725" width="0.3048" layer="1"/>
<wire x1="22.733" y1="0.85725" x2="21.1455" y2="0.85725" width="0.3048" layer="1"/>
<wire x1="9.7155" y1="2.12725" x2="10.9855" y2="0.85725" width="0.3048" layer="1"/>
<wire x1="10.9855" y1="0.85725" x2="14.1605" y2="0.85725" width="0.3048" layer="1"/>
<wire x1="14.236" y1="0.98425" x2="14.236" y2="0.93275" width="0.3048" layer="1"/>
<wire x1="14.236" y1="0.93275" x2="14.1605" y2="0.85725" width="0.3048" layer="1"/>
<wire x1="-5.207" y1="-2.00025" x2="-1.0795" y2="2.12725" width="0.3048" layer="16"/>
<wire x1="-1.0795" y1="2.12725" x2="5.588" y2="2.12725" width="0.3048" layer="16"/>
<wire x1="5.588" y1="2.12725" x2="9.7155" y2="2.12725" width="0.3048" layer="16"/>
<wire x1="5.588" y1="4.98475" x2="5.588" y2="2.12725" width="0.3048" layer="16"/>
<wire x1="-26.797" y1="1.17475" x2="-27.7495" y2="2.12725" width="0.3048" layer="16"/>
<wire x1="-27.7495" y1="2.12725" x2="-27.7495" y2="3.36575" width="0.3048" layer="16"/>
<wire x1="-27.7495" y1="3.36575" x2="-27.654" y2="3.46125" width="0.3048" layer="16"/>
<wire x1="13.843" y1="14.82725" x2="13.5255" y2="15.14475" width="0.3048" layer="1"/>
<wire x1="13.5255" y1="15.14475" x2="12.573" y2="15.14475" width="0.3048" layer="1"/>
<wire x1="12.66825" y1="14.9105" x2="12.66825" y2="15.0495" width="0.3048" layer="1"/>
<wire x1="12.66825" y1="15.0495" x2="12.573" y2="15.14475" width="0.3048" layer="1"/>
<wire x1="21.209" y1="0.774" x2="21.209" y2="0.79375" width="0.3048" layer="1"/>
<wire x1="21.209" y1="0.79375" x2="21.1455" y2="0.85725" width="0.3048" layer="1"/>
</signal>
<signal name="N$22">
<contactref element="LED10" pad="A"/>
<contactref element="LED11" pad="A"/>
<contactref element="LED1" pad="A"/>
<contactref element="LED4" pad="A"/>
<contactref element="LED6" pad="A"/>
<contactref element="LED23" pad="C"/>
<contactref element="SZIV-CSAT1" pad="P$4"/>
<wire x1="-29.972" y1="-2.00025" x2="-30.00375" y2="-2.1075" width="0.3048" layer="1"/>
<wire x1="3.683" y1="6.25475" x2="1.778" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="3.683" y1="6.25475" x2="3.53625" y2="6.31825" width="0.3048" layer="1"/>
<wire x1="-5.5245" y1="7.84225" x2="-6.7945" y2="7.84225" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="11.33475" x2="-5.5245" y2="7.84225" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="12.60475" x2="-2.032" y2="11.33475" width="0.3048" layer="1"/>
<wire x1="-6.7945" y1="7.84225" x2="-6.95325" y2="7.9495" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="12.60475" x2="-1.80975" y2="12.839" width="0.3048" layer="1"/>
<wire x1="-6.477" y1="15.77975" x2="-5.207" y2="15.77975" width="0.3048" layer="1"/>
<wire x1="-5.207" y1="15.77975" x2="-5.16325" y2="16.03375" width="0.3048" layer="1"/>
<wire x1="-0.127" y1="8.15975" x2="1.778" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="-0.127" y1="9.42975" x2="-0.127" y2="8.15975" width="0.3048" layer="16"/>
<wire x1="-2.032" y1="11.33475" x2="-0.127" y2="9.42975" width="0.3048" layer="16"/>
<wire x1="1.778" y1="8.15975" x2="1.68275" y2="8.04475" width="0.3048" layer="1"/>
<wire x1="-20.447" y1="-5.17525" x2="-22.987" y2="-2.63525" width="0.3048" layer="16"/>
<wire x1="-0.127" y1="6.88975" x2="-12.192" y2="-5.17525" width="0.3048" layer="16"/>
<wire x1="-0.127" y1="8.15975" x2="-0.127" y2="6.88975" width="0.3048" layer="16"/>
<via x="-6.477" y="15.77975" extent="1-16" drill="0.381"/>
<via x="-2.032" y="11.33475" extent="1-16" drill="0.381"/>
<via x="-0.127" y="8.15975" extent="1-16" drill="0.381"/>
<via x="-22.987" y="-2.63525" extent="1-16" drill="0.381"/>
<wire x1="-2.032" y1="11.33475" x2="-2.032" y2="12.92225" width="0.3048" layer="16"/>
<wire x1="-2.032" y1="12.92225" x2="-4.572" y2="15.46225" width="0.3048" layer="16"/>
<wire x1="-4.572" y1="15.46225" x2="-6.1595" y2="15.46225" width="0.3048" layer="16"/>
<wire x1="-6.1595" y1="15.46225" x2="-6.477" y2="15.77975" width="0.3048" layer="16"/>
<wire x1="-20.447" y1="-5.17525" x2="-12.192" y2="-5.17525" width="0.3048" layer="16"/>
<wire x1="-29.972" y1="-2.00025" x2="-28.702" y2="-0.73025" width="0.3048" layer="1"/>
<wire x1="-28.702" y1="-0.73025" x2="-25.8445" y2="-0.73025" width="0.3048" layer="1"/>
<wire x1="-25.8445" y1="-0.73025" x2="-23.9395" y2="-2.63525" width="0.3048" layer="1"/>
<wire x1="-23.9395" y1="-2.63525" x2="-22.987" y2="-2.63525" width="0.3048" layer="1"/>
<wire x1="-25.654" y1="3.46125" x2="-25.8445" y2="3.27075" width="0.3048" layer="1"/>
<wire x1="-25.8445" y1="3.27075" x2="-25.8445" y2="-0.73025" width="0.3048" layer="1"/>
</signal>
<signal name="N$33">
<contactref element="LED24" pad="C"/>
<contactref element="LED25" pad="A"/>
<contactref element="LED5" pad="A"/>
<contactref element="LED7" pad="A"/>
<contactref element="LED3" pad="A"/>
<contactref element="LED2" pad="A"/>
<contactref element="SZIV-CSAT1" pad="P$6"/>
<wire x1="-5.207" y1="11.33475" x2="-5.16325" y2="11.176" width="0.3048" layer="1"/>
<wire x1="-7.112" y1="12.60475" x2="-6.985" y2="12.839" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="8.15975" x2="-3.302" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="-5.207" y1="6.25475" x2="-5.1315" y2="6.31825" width="0.3048" layer="1"/>
<wire x1="-2.032" y1="8.15975" x2="-1.80975" y2="8.04475" width="0.3048" layer="1"/>
<wire x1="-4.8895" y1="10.38225" x2="-4.8895" y2="12.92225" width="0.3048" layer="16"/>
<wire x1="-3.302" y1="8.15975" x2="-4.8895" y2="10.38225" width="0.3048" layer="16"/>
<wire x1="-21.082" y1="-0.09525" x2="-21.082" y2="-2.00025" width="0.3048" layer="1"/>
<wire x1="-21.717" y1="0.53975" x2="-21.082" y2="-0.09525" width="0.3048" layer="1"/>
<wire x1="-21.717" y1="3.07975" x2="-21.717" y2="0.53975" width="0.3048" layer="1"/>
<wire x1="-21.717" y1="3.07975" x2="-21.654" y2="3.46125" width="0.3048" layer="1"/>
<wire x1="-19.812" y1="-3.27025" x2="-14.097" y2="-3.27025" width="0.3048" layer="1"/>
<wire x1="-21.082" y1="-2.00025" x2="-19.812" y2="-3.27025" width="0.3048" layer="1"/>
<wire x1="-21.082" y1="-2.00025" x2="-21.2725" y2="-2.1075" width="0.3048" layer="1"/>
<wire x1="-3.302" y1="5.61975" x2="-3.302" y2="8.15975" width="0.3048" layer="16"/>
<wire x1="-12.192" y1="-3.27025" x2="-3.302" y2="5.61975" width="0.3048" layer="16"/>
<wire x1="-14.097" y1="-3.27025" x2="-12.192" y2="-3.27025" width="0.3048" layer="1"/>
<wire x1="-14.097" y1="-3.27025" x2="-13.97" y2="-3.57575" width="0.3048" layer="1"/>
<via x="-4.8895" y="12.92225" extent="1-16" drill="0.381"/>
<via x="-3.302" y="8.15975" extent="1-16" drill="0.381"/>
<via x="-12.192" y="-3.27025" extent="1-16" drill="0.381"/>
<wire x1="-4.8895" y1="12.92225" x2="-7.112" y2="12.92225" width="0.3048" layer="1"/>
<wire x1="-5.16325" y1="11.176" x2="-5.16325" y2="12.6485" width="0.3048" layer="1"/>
<wire x1="-5.16325" y1="12.6485" x2="-4.8895" y2="12.92225" width="0.3048" layer="1"/>
<wire x1="-3.302" y1="8.15975" x2="-3.937" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="-3.937" y1="8.15975" x2="-5.207" y2="6.88975" width="0.3048" layer="1"/>
<wire x1="-5.207" y1="6.88975" x2="-5.207" y2="6.25475" width="0.3048" layer="1"/>
<wire x1="-6.985" y1="12.839" x2="-7.02875" y2="12.839" width="0.3048" layer="1"/>
<wire x1="-7.02875" y1="12.839" x2="-7.112" y2="12.92225" width="0.3048" layer="1"/>
</signal>
<signal name="N$30">
<contactref element="LED15" pad="A"/>
<contactref element="LED16" pad="A"/>
<contactref element="LED32" pad="A"/>
<contactref element="LED33" pad="A"/>
<contactref element="LED21" pad="C"/>
<contactref element="LED27" pad="C"/>
<contactref element="LED17" pad="A"/>
<contactref element="SZIV-CSAT1" pad="P$7"/>
<wire x1="20.193" y1="-21.68525" x2="16.383" y2="-21.68525" width="0.3048" layer="1"/>
<wire x1="16.383" y1="-21.68525" x2="16.383" y2="-21.53975" width="0.3048" layer="1"/>
<wire x1="20.193" y1="-21.68525" x2="20.54225" y2="-21.53975" width="0.3048" layer="1"/>
<wire x1="12.573" y1="8.15975" x2="12.573" y2="7.52475" width="0.3048" layer="1"/>
<wire x1="12.573" y1="8.15975" x2="13.843" y2="8.15975" width="0.3048" layer="1"/>
<wire x1="13.843" y1="8.15975" x2="13.95025" y2="8.255" width="0.3048" layer="1"/>
<wire x1="12.573" y1="8.15975" x2="12.573" y2="13.23975" width="0.3048" layer="1"/>
<wire x1="12.573" y1="13.23975" x2="12.66825" y2="13.4105" width="0.3048" layer="1"/>
<wire x1="12.573" y1="8.15975" x2="12.7515" y2="8.22325" width="0.3048" layer="1"/>
<wire x1="20.828" y1="-19.78025" x2="20.828" y2="-21.05025" width="0.3048" layer="1"/>
<wire x1="25.908" y1="-14.70025" x2="20.828" y2="-19.78025" width="0.3048" layer="1"/>
<wire x1="25.908" y1="-12.47775" x2="25.908" y2="-14.70025" width="0.3048" layer="1"/>
<wire x1="26.543" y1="-11.84275" x2="25.908" y2="-12.47775" width="0.3048" layer="1"/>
<wire x1="26.543" y1="-4.54025" x2="26.543" y2="-11.84275" width="0.3048" layer="1"/>
<wire x1="20.828" y1="-21.05025" x2="20.54225" y2="-21.53975" width="0.3048" layer="1"/>
<wire x1="-17.5895" y1="3.39725" x2="-18.8595" y2="3.39725" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="4.34975" x2="-17.5895" y2="3.39725" width="0.3048" layer="1"/>
<wire x1="-16.637" y1="6.25475" x2="-16.637" y2="4.34975" width="0.3048" layer="1"/>
<wire x1="-15.367" y1="7.52475" x2="-16.637" y2="6.25475" width="0.3048" layer="1"/>
<wire x1="-14.097" y1="7.52475" x2="-15.367" y2="7.52475" width="0.3048" layer="1"/>
<wire x1="-11.2395" y1="10.38225" x2="-14.097" y2="7.52475" width="0.3048" layer="1"/>
<wire x1="-11.2395" y1="15.46225" x2="-11.2395" y2="10.38225" width="0.3048" layer="1"/>
<wire x1="-9.017" y1="17.68475" x2="-11.2395" y2="15.46225" width="0.3048" layer="1"/>
<wire x1="6.5405" y1="17.68475" x2="-9.017" y2="17.68475" width="0.3048" layer="1"/>
<wire x1="10.9855" y1="13.23975" x2="6.5405" y2="17.68475" width="0.3048" layer="1"/>
<wire x1="-18.8595" y1="3.39725" x2="-19.654" y2="3.46125" width="0.3048" layer="1"/>
<wire x1="10.9855" y1="13.23975" x2="12.573" y2="13.23975" width="0.3048" layer="1"/>
<wire x1="1.4605" y1="6.57225" x2="-0.127" y2="6.57225" width="0.3048" layer="1"/>
<wire x1="-0.127" y1="6.57225" x2="-0.115" y2="6.56025" width="0.3048" layer="1"/>
<wire x1="-0.115" y1="6.56025" x2="-0.03175" y2="6.56025" width="0.3048" layer="1"/>
<wire x1="1.4605" y1="6.57225" x2="6.38175" y2="1.651" width="0.3048" layer="1"/>
<wire x1="6.38175" y1="1.651" x2="9.398" y2="-1.36525" width="0.3048" layer="1"/>
<wire x1="9.398" y1="-1.36525" x2="23.0505" y2="-1.36525" width="0.3048" layer="1"/>
<wire x1="23.0505" y1="-1.36525" x2="24.003" y2="-2.31775" width="0.3048" layer="1"/>
<wire x1="12.573" y1="7.52475" x2="6.69925" y2="1.651" width="0.3048" layer="1"/>
<wire x1="6.69925" y1="1.651" x2="6.38175" y2="1.651" width="0.3048" layer="1"/>
<wire x1="26.543" y1="-4.54025" x2="24.9555" y2="-2.95275" width="0.3048" layer="1"/>
<wire x1="24.9555" y1="-2.95275" x2="24.015" y2="-2.95275" width="0.3048" layer="1"/>
<wire x1="24.003" y1="-2.95275" x2="24.003" y2="-2.31775" width="0.3048" layer="1"/>
<wire x1="24.003" y1="-2.95275" x2="24.015" y2="-2.95275" width="0.3048" layer="1"/>
<wire x1="24.015" y1="-2.95275" x2="24.03475" y2="-2.933" width="0.3048" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
