; Source created with Parsic Version 3.x
; at              : 2008.07.19. 23:00:32
; Project File    : C:\PROGRA~1\Parsic\Projekt\egyéb\P_84_vil.PIC
; Project Version : 1.0.0
; Created         : 2008.07.19. 22:58:40
; Last change     : 2008.07.19. 23:00:24
	PROCESSOR 16F84
	INCLUDE P16F84.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
SYS_WSAV	= 12	; located in Bank 0, 1
SYS_SSAV	= 13	; located in Bank 0, 1
TR1	= 14	; located in Bank 0, 1
TR1_HI	= 15	; located in Bank 0, 1
SYS_FSAV	= 16	; located in Bank 0, 1
RAM	= 17	; located in Bank 0, 1
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	BCF STATUS,RP0	; Bank 0
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111110'
	MOVWF TRISB
; init vars
; Clear RAM
	MOVLW 12
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	MOVFW FSR
	SUBLW 80
	BTFSS STATUS,ZERO
	GOTO CR1
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 4	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 148
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 148
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC PORTB,0
	GOTO LABEL_TR1_CLR
	BSF PORTB,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF PORTB,0
LABEL_TR1_ENDE
	GOTO MAIN
	END
