  * @file      startup_stm32f4xx.s
  * @author    MCD Application Team
  * @version   V1.0.0RC1
  * @date      25-August-2011
  * @brief     STM32F4xx Devices vector table for Atollic TrueSTUDIO toolchain.
  *            This module performs:
  *                - Set the initial SP
  *                - Set the initial PC == Reset_Handler,
  *                - Set the vector table entries with the exceptions ISR address
  *                - Configure the clock system and the external SRAM mounted on
  *                  STM3220F-EVAL board to be used as data memory (optional,
  *                  to be enabled by user)
  *                - Branches to main in the C library (which eventually
  *                  calls main()).
  *            After Reset the Cortex-M4 processor is in Thread mode,
  *            priority is Privileged, and the Stack is set to Main.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
  .syntax unified
  .cpu cortex-m3
  .fpu softvfp
  .thumb
.global  g_pfnVectors
.global  Default_Handler
/* start address for the initialization values of the .data section.
defined in linker script */
.word  _sidata
/* start address for the .data section. defined in linker script */
.word  _sdata
/* end address for the .data section. defined in linker script */
.word  _edata
/* start address for the .bss section. defined in linker script */
.word  _sbss
/* end address for the .bss section. defined in linker script */
.word  _ebss
/* stack used for SystemInit_ExtMemCtl; always internal RAM used */
 * @brief  This is the code that gets called when the processor first
 *          starts execution following a reset event. Only the absolutely
 *          necessary set is performed, after which the application
 *          supplied main() routine is called.
 * @param  None
 * @retval : None
    .section  .text.Reset_Handler
  .weak  Reset_Handler
  .type  Reset_Handler, %function
Reset_Handler:
/* Copy the data segment initializers from flash to SRAM */
  movs  r1, #0
  b  LoopCopyDataInit
CopyDataInit:
  ldr  r3, =_sidata
  ldr  r3, [r3, r1]
  str  r3, [r0, r1]
  adds  r1, r1, #4
LoopCopyDataInit:
  ldr  r0, =_sdata
  ldr  r3, =_edata
  adds  r2, r0, r1
  cmp  r2, r3
  bcc  CopyDataInit
  ldr  r2, =_sbss
  b  LoopFillZerobss
/* Zero fill the bss segment. */
FillZerobss:
  movs  r3, #0
  str  r3, [r2], #4
LoopFillZerobss:
  ldr  r3, = _ebss
  cmp  r2, r3
  bcc  FillZerobss
/*FPU settings*/
 ldr     r0, =0xE000ED88           /* Enable CP10,CP11 */
 ldr     r1,[r0]
 orr     r1,r1,#(0xF << 20)
 str     r1,[r0]
/* Call the clock system intitialization function.*/
  bl  SystemInit
/* Call static constructors */
    bl __libc_init_array
/* Call the application's entry point.*/
  bl  main
  bx  lr
.size  Reset_Handler, .-Reset_Handler
 * @brief  This is the code that gets called when the processor receives an
 *         unexpected interrupt.  This simply enters an infinite loop, preserving
 *         the system state for examination by a debugger.
 * @param  None
 * @retval None
    .section  .text.Default_Handler,"ax",%progbits
Default_Handler:
/*	bl  isrDefaultHandler*/
  TST LR, #4
  ITE EQ
  MRSEQ R0, MSP
  MRSNE R0, PSP
  B default_handler_c
Infinite_Loop:
  b  Infinite_Loop
  .size  Default_Handler, .-Default_Handler
* The minimal vector table for a Cortex M3. Note that the proper constructs
* must be placed on this to ensure that it ends up at physical address
* 0x0000.0000.
   .section  .isr_vector,"a",%progbits
  .type  g_pfnVectors, %object
  .size  g_pfnVectors, .-g_pfnVectors
g_pfnVectors:
  .word  _estack
  .word  Reset_Handler
  .word  NMI_Handler
  .word  HardFault_Handler
  .word  MemManage_Handler
  .word  BusFault_Handler
  .word  UsageFault_Handler
  .word  0
  .word  0
  .word  0
  .word  0
  .word  SVC_Handler
  .word  DebugMon_Handler
  .word  0
  .word  PendSV_Handler
  .word  SysTick_Handler
  /* External Interrupts */
  .word     WWDG_IRQHandler                   /* Window WatchDog              */
  .word     PVD_IRQHandler                    /* PVD through EXTI Line detection */
  .word     TAMP_STAMP_IRQHandler             /* Tamper and TimeStamps through the EXTI line */
  .word     RTC_WKUP_IRQHandler               /* RTC Wakeup through the EXTI line */
  .word     FLASH_IRQHandler                  /* FLASH                        */
  .word     RCC_IRQHandler                    /* RCC                          */
  .word     EXTI0_IRQHandler                  /* EXTI Line0                   */
  .word     EXTI1_IRQHandler                  /* EXTI Line1                   */
  .word     EXTI2_IRQHandler                  /* EXTI Line2                   */
  .word     EXTI3_IRQHandler                  /* EXTI Line3                   */
  .word     EXTI4_IRQHandler                  /* EXTI Line4                   */
  .word     DMA1_Stream0_IRQHandler           /* DMA1 Stream 0                */
  .word     DMA1_Stream1_IRQHandler           /* DMA1 Stream 1                */
  .word     DMA1_Stream2_IRQHandler           /* DMA1 Stream 2                */
  .word     DMA1_Stream3_IRQHandler           /* DMA1 Stream 3                */
  .word     DMA1_Stream4_IRQHandler           /* DMA1 Stream 4                */
  .word     DMA1_Stream5_IRQHandler           /* DMA1 Stream 5                */
  .word     DMA1_Stream6_IRQHandler           /* DMA1 Stream 6                */
  .word     ADC_IRQHandler                    /* ADC1, ADC2 and ADC3s         */
  .word     CAN1_TX_IRQHandler                /* CAN1 TX                      */
  .word     CAN1_RX0_IRQHandler               /* CAN1 RX0                     */
  .word     CAN1_RX1_IRQHandler               /* CAN1 RX1                     */
  .word     CAN1_SCE_IRQHandler               /* CAN1 SCE                     */
  .word     EXTI9_5_IRQHandler                /* External Line[9:5]s          */
  .word     TIM1_BRK_TIM9_IRQHandler          /* TIM1 Break and TIM9          */
  .word     TIM1_UP_TIM10_IRQHandler          /* TIM1 Update and TIM10        */
  .word     TIM1_TRG_COM_TIM11_IRQHandler     /* TIM1 Trigger and Commutation and TIM11 */
  .word     TIM1_CC_IRQHandler                /* TIM1 Capture Compare         */
  .word     TIM2_IRQHandler                   /* TIM2                         */
  .word     TIM3_IRQHandler                   /* TIM3                         */
  .word     TIM4_IRQHandler                   /* TIM4                         */
  .word     I2C1_EV_IRQHandler                /* I2C1 Event                   */
  .word     I2C1_ER_IRQHandler                /* I2C1 Error                   */
  .word     I2C2_EV_IRQHandler                /* I2C2 Event                   */
  .word     I2C2_ER_IRQHandler                /* I2C2 Error                   */
  .word     SPI1_IRQHandler                   /* SPI1                         */
  .word     SPI2_IRQHandler                   /* SPI2                         */
  .word     USART1_IRQHandler                 /* USART1                       */
  .word     USART2_IRQHandler                 /* USART2                       */
  .word     USART3_IRQHandler                 /* USART3                       */
  .word     EXTI15_10_IRQHandler              /* External Line[15:10]s        */
  .word     RTC_Alarm_IRQHandler              /* RTC Alarm (A and B) through EXTI Line */
  .word     OTG_FS_WKUP_IRQHandler            /* USB OTG FS Wakeup through EXTI line */
  .word     TIM8_BRK_TIM12_IRQHandler         /* TIM8 Break and TIM12         */
  .word     TIM8_UP_TIM13_IRQHandler          /* TIM8 Update and TIM13        */
  .word     TIM8_TRG_COM_TIM14_IRQHandler     /* TIM8 Trigger and Commutation and TIM14 */
  .word     TIM8_CC_IRQHandler                /* TIM8 Capture Compare         */
  .word     DMA1_Stream7_IRQHandler           /* DMA1 Stream7                 */
  .word     FSMC_IRQHandler                   /* FSMC                         */
  .word     SDIO_IRQHandler                   /* SDIO                         */
  .word     TIM5_IRQHandler                   /* TIM5                         */
  .word     SPI3_IRQHandler                   /* SPI3                         */
  .word     UART4_IRQHandler                  /* UART4                        */
  .word     UART5_IRQHandler                  /* UART5                        */
  .word     TIM6_DAC_IRQHandler               /* TIM6 and DAC1&2 underrun errors */
  .word     TIM7_IRQHandler                   /* TIM7                         */
  .word     DMA2_Stream0_IRQHandler           /* DMA2 Stream 0                */
  .word     DMA2_Stream1_IRQHandler           /* DMA2 Stream 1                */
  .word     DMA2_Stream2_IRQHandler           /* DMA2 Stream 2                */
  .word     DMA2_Stream3_IRQHandler           /* DMA2 Stream 3                */
  .word     DMA2_Stream4_IRQHandler           /* DMA2 Stream 4                */
  .word     ETH_IRQHandler                    /* Ethernet                     */
  .word     ETH_WKUP_IRQHandler               /* Ethernet Wakeup through EXTI line */
  .word     CAN2_TX_IRQHandler                /* CAN2 TX                      */
  .word     CAN2_RX0_IRQHandler               /* CAN2 RX0                     */
  .word     CAN2_RX1_IRQHandler               /* CAN2 RX1                     */
  .word     CAN2_SCE_IRQHandler               /* CAN2 SCE                     */
  .word     OTG_FS_IRQHandler                 /* USB OTG FS                   */
  .word     DMA2_Stream5_IRQHandler           /* DMA2 Stream 5                */
  .word     DMA2_Stream6_IRQHandler           /* DMA2 Stream 6                */
  .word     DMA2_Stream7_IRQHandler           /* DMA2 Stream 7                */
  .word     USART6_IRQHandler                 /* USART6                       */
  .word     I2C3_EV_IRQHandler                /* I2C3 event                   */
  .word     I2C3_ER_IRQHandler                /* I2C3 error                   */
  .word     OTG_HS_EP1_OUT_IRQHandler         /* USB OTG HS End Point 1 Out   */
  .word     OTG_HS_EP1_IN_IRQHandler          /* USB OTG HS End Point 1 In    */
  .word     OTG_HS_WKUP_IRQHandler            /* USB OTG HS Wakeup through EXTI */
  .word     OTG_HS_IRQHandler                 /* USB OTG HS                   */
  .word     DCMI_IRQHandler                   /* DCMI                         */
  .word     CRYP_IRQHandler                   /* CRYP crypto                  */
  .word     HASH_RNG_IRQHandler               /* Hash and Rng                 */
  .word     FPU_IRQHandler                    /* FPU                          */
* Provide weak aliases for each Exception handler to the Default_Handler.
* As they are weak aliases, any function with the same name will override
* this definition.
   .weak      NMI_Handler
   .thumb_set NMI_Handler,Default_Handler
/*   .weak      HardFault_Handler
   .thumb_set HardFault_Handler,Default_Handler*/
   .weak      MemManage_Handler
   .thumb_set MemManage_Handler,Default_Handler
   .weak      BusFault_Handler
   .thumb_set BusFault_Handler,Default_Handler
   .weak      UsageFault_Handler
   .thumb_set UsageFault_Handler,Default_Handler
   .weak      SVC_Handler
   .thumb_set SVC_Handler,Default_Handler
   .weak      DebugMon_Handler
   .thumb_set DebugMon_Handler,Default_Handler
   .weak      PendSV_Handler
   .thumb_set PendSV_Handler,Default_Handler
   .weak      SysTick_Handler
   .thumb_set SysTick_Handler,Default_Handler
   .weak      WWDG_IRQHandler
   .thumb_set WWDG_IRQHandler,Default_Handler
   .weak      PVD_IRQHandler
   .thumb_set PVD_IRQHandler,Default_Handler
   .weak      TAMP_STAMP_IRQHandler
   .thumb_set TAMP_STAMP_IRQHandler,Default_Handler
   .weak      RTC_WKUP_IRQHandler
   .thumb_set RTC_WKUP_IRQHandler,Default_Handler
   .weak      FLASH_IRQHandler
   .thumb_set FLASH_IRQHandler,Default_Handler
   .weak      RCC_IRQHandler
   .thumb_set RCC_IRQHandler,Default_Handler
   .weak      EXTI0_IRQHandler
   .thumb_set EXTI0_IRQHandler,Default_Handler
   .weak      EXTI1_IRQHandler
   .thumb_set EXTI1_IRQHandler,Default_Handler
   .weak      EXTI2_IRQHandler
   .thumb_set EXTI2_IRQHandler,Default_Handler
   .weak      EXTI3_IRQHandler
   .thumb_set EXTI3_IRQHandler,Default_Handler
   .weak      EXTI4_IRQHandler
   .thumb_set EXTI4_IRQHandler,Default_Handler
   .weak      DMA1_Stream0_IRQHandler
   .thumb_set DMA1_Stream0_IRQHandler,Default_Handler
   .weak      DMA1_Stream1_IRQHandler
   .thumb_set DMA1_Stream1_IRQHandler,Default_Handler
   .weak      DMA1_Stream2_IRQHandler
   .thumb_set DMA1_Stream2_IRQHandler,Default_Handler
   .weak      DMA1_Stream3_IRQHandler
   .thumb_set DMA1_Stream3_IRQHandler,Default_Handler
   .weak      DMA1_Stream4_IRQHandler
   .thumb_set DMA1_Stream4_IRQHandler,Default_Handler
   .weak      DMA1_Stream5_IRQHandler
   .thumb_set DMA1_Stream5_IRQHandler,Default_Handler
   .weak      DMA1_Stream6_IRQHandler
   .thumb_set DMA1_Stream6_IRQHandler,Default_Handler
   .weak      ADC_IRQHandler
   .thumb_set ADC_IRQHandler,Default_Handler
   .weak      CAN1_TX_IRQHandler
   .thumb_set CAN1_TX_IRQHandler,Default_Handler
   .weak      CAN1_RX0_IRQHandler
   .thumb_set CAN1_RX0_IRQHandler,Default_Handler
   .weak      CAN1_RX1_IRQHandler
   .thumb_set CAN1_RX1_IRQHandler,Default_Handler
   .weak      CAN1_SCE_IRQHandler
   .thumb_set CAN1_SCE_IRQHandler,Default_Handler
   .weak      EXTI9_5_IRQHandler
   .thumb_set EXTI9_5_IRQHandler,Default_Handler
   .weak      TIM1_BRK_TIM9_IRQHandler
   .thumb_set TIM1_BRK_TIM9_IRQHandler,Default_Handler
   .weak      TIM1_UP_TIM10_IRQHandler
   .thumb_set TIM1_UP_TIM10_IRQHandler,Default_Handler
   .weak      TIM1_TRG_COM_TIM11_IRQHandler
   .thumb_set TIM1_TRG_COM_TIM11_IRQHandler,Default_Handler
   .weak      TIM1_CC_IRQHandler
   .thumb_set TIM1_CC_IRQHandler,Default_Handler
   .weak      TIM2_IRQHandler
   .thumb_set TIM2_IRQHandler,Default_Handler
   .weak      TIM3_IRQHandler
   .thumb_set TIM3_IRQHandler,Default_Handler
   .weak      TIM4_IRQHandler
   .thumb_set TIM4_IRQHandler,Default_Handler
   .weak      I2C1_EV_IRQHandler
   .thumb_set I2C1_EV_IRQHandler,Default_Handler
   .weak      I2C1_ER_IRQHandler
   .thumb_set I2C1_ER_IRQHandler,Default_Handler
   .weak      I2C2_EV_IRQHandler
   .thumb_set I2C2_EV_IRQHandler,Default_Handler
   .weak      I2C2_ER_IRQHandler
   .thumb_set I2C2_ER_IRQHandler,Default_Handler
   .weak      SPI1_IRQHandler
   .thumb_set SPI1_IRQHandler,Default_Handler
   .weak      SPI2_IRQHandler
   .thumb_set SPI2_IRQHandler,Default_Handler
   .weak      USART1_IRQHandler
   .thumb_set USART1_IRQHandler,Default_Handler
   .weak      USART2_IRQHandler
   .thumb_set USART2_IRQHandler,Default_Handler
   .weak      USART3_IRQHandler
   .thumb_set USART3_IRQHandler,Default_Handler
   .weak      EXTI15_10_IRQHandler
   .thumb_set EXTI15_10_IRQHandler,Default_Handler
   .weak      RTC_Alarm_IRQHandler
   .thumb_set RTC_Alarm_IRQHandler,Default_Handler
   .weak      OTG_FS_WKUP_IRQHandler
   .thumb_set OTG_FS_WKUP_IRQHandler,Default_Handler
   .weak      TIM8_BRK_TIM12_IRQHandler
   .thumb_set TIM8_BRK_TIM12_IRQHandler,Default_Handler
   .weak      TIM8_UP_TIM13_IRQHandler
   .thumb_set TIM8_UP_TIM13_IRQHandler,Default_Handler
   .weak      TIM8_TRG_COM_TIM14_IRQHandler
   .thumb_set TIM8_TRG_COM_TIM14_IRQHandler,Default_Handler
   .weak      TIM8_CC_IRQHandler
   .thumb_set TIM8_CC_IRQHandler,Default_Handler
   .weak      DMA1_Stream7_IRQHandler
   .thumb_set DMA1_Stream7_IRQHandler,Default_Handler
   .weak      FSMC_IRQHandler
   .thumb_set FSMC_IRQHandler,Default_Handler
   .weak      SDIO_IRQHandler
   .thumb_set SDIO_IRQHandler,Default_Handler
   .weak      TIM5_IRQHandler
   .thumb_set TIM5_IRQHandler,Default_Handler
   .weak      SPI3_IRQHandler
   .thumb_set SPI3_IRQHandler,Default_Handler
   .weak      UART4_IRQHandler
   .thumb_set UART4_IRQHandler,Default_Handler
   .weak      UART5_IRQHandler
   .thumb_set UART5_IRQHandler,Default_Handler
   .weak      TIM6_DAC_IRQHandler
   .thumb_set TIM6_DAC_IRQHandler,Default_Handler
   .weak      TIM7_IRQHandler
   .thumb_set TIM7_IRQHandler,Default_Handler
   .weak      DMA2_Stream0_IRQHandler
   .thumb_set DMA2_Stream0_IRQHandler,Default_Handler
   .weak      DMA2_Stream1_IRQHandler
   .thumb_set DMA2_Stream1_IRQHandler,Default_Handler
   .weak      DMA2_Stream2_IRQHandler
   .thumb_set DMA2_Stream2_IRQHandler,Default_Handler
   .weak      DMA2_Stream3_IRQHandler
   .thumb_set DMA2_Stream3_IRQHandler,Default_Handler
   .weak      DMA2_Stream4_IRQHandler
   .thumb_set DMA2_Stream4_IRQHandler,Default_Handler
   .weak      ETH_IRQHandler
   .thumb_set ETH_IRQHandler,Default_Handler
   .weak      ETH_WKUP_IRQHandler
   .thumb_set ETH_WKUP_IRQHandler,Default_Handler
   .weak      CAN2_TX_IRQHandler
   .thumb_set CAN2_TX_IRQHandler,Default_Handler
   .weak      CAN2_RX0_IRQHandler
   .thumb_set CAN2_RX0_IRQHandler,Default_Handler
   .weak      CAN2_RX1_IRQHandler
   .thumb_set CAN2_RX1_IRQHandler,Default_Handler
   .weak      CAN2_SCE_IRQHandler
   .thumb_set CAN2_SCE_IRQHandler,Default_Handler
   .weak      OTG_FS_IRQHandler
   .thumb_set OTG_FS_IRQHandler,Default_Handler
   .weak      DMA2_Stream5_IRQHandler
   .thumb_set DMA2_Stream5_IRQHandler,Default_Handler
   .weak      DMA2_Stream6_IRQHandler
   .thumb_set DMA2_Stream6_IRQHandler,Default_Handler
   .weak      DMA2_Stream7_IRQHandler
   .thumb_set DMA2_Stream7_IRQHandler,Default_Handler
   .weak      USART6_IRQHandler
   .thumb_set USART6_IRQHandler,Default_Handler
   .weak      I2C3_EV_IRQHandler
   .thumb_set I2C3_EV_IRQHandler,Default_Handler
   .weak      I2C3_ER_IRQHandler
   .thumb_set I2C3_ER_IRQHandler,Default_Handler
   .weak      OTG_HS_EP1_OUT_IRQHandler
   .thumb_set OTG_HS_EP1_OUT_IRQHandler,Default_Handler
   .weak      OTG_HS_EP1_IN_IRQHandler
   .thumb_set OTG_HS_EP1_IN_IRQHandler,Default_Handler
   .weak      OTG_HS_WKUP_IRQHandler
   .thumb_set OTG_HS_WKUP_IRQHandler,Default_Handler
   .weak      OTG_HS_IRQHandler
   .thumb_set OTG_HS_IRQHandler,Default_Handler
   .weak      DCMI_IRQHandler
   .thumb_set DCMI_IRQHandler,Default_Handler
   .weak      CRYP_IRQHandler
   .thumb_set CRYP_IRQHandler,Default_Handler
   .weak      HASH_RNG_IRQHandler
   .thumb_set HASH_RNG_IRQHandler,Default_Handler
   .weak      FPU_IRQHandler
   .thumb_set FPU_IRQHandler,Default_Handler
.thumb
.global HardFault_Handler
.extern hard_fault_handler_c
HardFault_Handler:
  TST LR, #4
  ITE EQ
  MRSEQ R0, MSP
  MRSNE R0, PSP
  B hard_fault_handler_c
.extern default_handler_c
Default_Handler:
  TST LR, #4
  ITE EQ
  MRSEQ R0, MSP
  MRSNE R0, PSP
  B default_handler_c
/*******************   (C)   COPYRIGHT   2011   STMicroelectronics   *****END   OF   FILE****/
