Quick 'n Easy FTP Server - Programmed by Pablo van der Meer
[01/01/2002] Version 1.01
- Initial release
[02/02/2002] Version 1.04
- Several bug fixes
[05/20/2002] Version 1.05
- Major update!
- Added User Account Wizard
- Added Security Page
- Added transfer bytes counters
- and much more
[06/24/2002] Version 1.06
- Minor bug fix in credits.
[06/25/2002] Version 1.07
- Added Integrated Help
- Window position is now saved.
- Fixed application Icon.
[07/12/2002] Version 1.08
- Added support for BYE and QUIT commands
- Dirty fix for CWD /../../../ which introduced a big security hole (working on a better solution)
- Fixed bug in Online users list.
[07/14/2002] Version 1.09
- Rewrote access checks/user management so it can handle CWD /../../ correctly
- Fixed bug in virtual directories.
- Simplified ParseCommand a little
- Added credits for FileZilla (on which parts of this server are based).
- SendReponse can now handle variable argument.
[07/21/2002] Version 1.10
- Fixed security hole in GetDirectoryList (LIST \..\) (thanks to: http://www.securiteinfo.com)
- Added support for REST and HELP commands.
[07/29/2002] Version 1.11
- Fixed problem with PASV mode (socket timing issue).
[07/29/2002] Version 1.12
- Another small problem with PASV mode (WININET).
- Added support for wildcard in security (199.199.* -> blocks 199.199.0.0 to 199.199.255.255)
[08/27/2002] Version 1.2
- User management dialog now part of other configuration pages.
- Fixed lots of small UI issues. Special thanks to Edwin Brunner.
- Re-designed FTP communication classes to make the application robust and get much nicer code.
- PASV/Normal mode are now handled exactly the same for data transfers.
- Added support for APPE, NLST, XCWD, XMKD, XPWD and XRMD commands.
- Fixed some problems regarding virtual directories.
- Listing of root drives now works correctly (thanks to: Edwin Brunner)
- Easier IP management (Security page)
- Directory listing now also possible when user has upload rights for specific directory.
- Added icon buttons.
[10/10/2002] Version 1.3
- Better theme support for Windows XP (CIconButton updated)
- Optimized some routines
[10/11/2002] Version 1.31
- fix uxtheme.dll delayload setting.
[10/19/2002] Version 1.4
- CStarWarsCtrl updated (fixed problem in XP).
- Fixed bug in STOR command -> connection blocked when data was send before server was ready to receive data.
[10/22/2002] Version 1.5
- UI update: Windows XP style (with alpha channel) icons.
[11/01/2002] Version 1.51
- Fixed security vulnerability: sending %n%n%n (and other c-formating strings) crashed the system (thanks to www.idefense.com).
- Added exception handler to prevent more (unknown) formating problems.
[11/14/2002] Version 1.52
- IP address for PASV mode can now be configured (in case of firewall problems) Configuration->IP address
- Browse for folder dialogs now remember their previous folder, also uses new dialog style (IE 5.0)
[11/22/2002] Version 1.53
- Anonymous accounts are now working. Just add 'anonymous' user and leave password blank.
[11/22/2002] Version 1.54
- Bugfix: slashes in some pathnames were not correctly handled. This resulted in various problems when running under Win9x/ME (thanks to Adem Edturk for the bugreport).
[12/01/2002] Version 1.55
- Fixed CIconButtons now so it acts like a 'real' XP themed button.
- Fixed security vulnerability: Sending an incorrect PORT command could crash the server (Thanks to: Bram Staps).
- Added a general exception handler, so that any incorrect command will not bring down the server.
[12/15/2002] Version 1.56
- Fixed problem with NLST * and LIST * (for example used by mget *).
- Fixed problem with resume download/upload (APPE/STOR/RETR).
- Statistics will now be saved between sessions. Context menu in Statistics Page allows you to reset statistics.
[12/22/2002] Version 1.57
- NEW: Max. connections/IP determines the maximum number of simultaneous connections per IP address.
- Merry Christmas!
[12/29/2002] Version 1.58
- NEW: You can now set the thread priority for the connection threads.
- NEW: Online users page now displays current status of the connection (downloading/uploading)
- Updated help file and added FAQ.
- Saved passwords (in user.dat) are now encrypted.
- Some minor UI changes.
- Happy New Year!
[01/24/2003] Version 1.59
- If explorer.exe is restarted (after a crash), the taskbar icon will be added again.
- Replaced ON_MESSAGE by ON_THREAD_MESSAGE in CConnectThread (because of error in VC++7.0 and possible stack problems.
[02/16/2003] Version 1.60
- Fixed bug in security manager (thanks to Will Tieleman)
- Fixed problem that occurred when PORT command was executed before data connection was destroyed. ("425 Can't open data connection.")
- Improved end of transfer mechnisme.
- LIST parameters (like -a -l -r) are now ignored instead of generating an error.
- Added menu items for Clear trace and Clear statistics.
[02/27/2003] Version 1.61
- Minor change in LIST command handler.
[03/19/2003] Version 1.62
- Home directory/Apply button fixed.
- Fixed bug with file/directories older than 350 days (some FTP clients didn't show first letter in listing).
- Fixed bug in CWD command when filename was given (instead of directory). Many Mac users found that this could cause problems while downloading files.
- Fixed bug in aboutbox when using a fast computer...
- Added extra option to Wizard, so it's easier to create an anonymous account.
- Some minor improvements in serveral modules.
[03/29/2003] Version 1.63
- Improved exception handler (under construction).
[03/30/2003] Version 1.64
- Fixed serious security hole in the server. It was possible to get the access rights from another user by logging in with username1 + wrong password and then logging with username2 + right password. (thanks to Julien Blanc!)
[05/17/2003] Version 1.7
- Changed the way file size is being displayed.
- Configuration Page is reorganized.
- Added keyboard accelaration keys for a couple of items.
- Added new option for directory listing time format: local time or UTC.
- Added new help menu item: What's my IP address.
- Trace window has a lot of new menu options like: copy to clipboard, save to file, show date/time.
- You can now specify a range of ports for PASV mode! (for better firewall support).
- Updated help file.
[05/28/2003] Version 1.71
- Security fix for various DOS vulnerabilities (thanks to: Dr. Insane!)
- Unidentified connections are now also displayed in 'Online Users' as 'Not logged in'.
[08/01/2003] Version 1.72
- Fixed: Add IP address to block list caused application lockup (thanks to: Sylvain Pappo).
- Fixed: Exception in CTracePage::OnAddTraceLine().
- Fixed: '426 Connection closed; transfer aborted' while uploading small files.
- Fixed: Exit menu.
- Added 'Show hidden files' option in Configuration.
[08/12/2003] Version 1.73
- A few user requests:
- Added Password mask. Registry key: (DWORD: MaskPassword, default: 1)
- Added Trace option: 'Insert on top'.
- Added Shutdown confirmation on close button: Registry key: (DWORD: ConfirmExit, default: 1)
- Added maximum log entries. Registry key: (DWORD: MaxEntries, default: 1000)
[09/24/2003] Version 1.74
- Fixed: LIST command now also displays LIST <FILENAME> correctly.
- Fixed: UNC paths and roots in Virtual Directories.
- Added Copy button in 'User Accounts' to simply duplicate an user account.
[10/14/2003] Version 1.75
- Fixed: System tray popup menu is closed when loosing focus.
- Added: System tray icon displays status of the server (on/off).
[11/14/2003] Version 1.76
- Fixed: Some FTP clients displayed both upper and lower-case directories.
- Fixed: Case of directory and file names will be corrected (in response to client).
- Added: Gradient to AboutBox
[12/25/2003] Version 1.77
- Fixed: On some systems the correct filename conversion did not work, now the shellname is returned.
[01/15/2004] Version 1.80
- Fixed: Minor security vulnerability in error response (550 Permission denied vs 550 File not found) thanks to: http://www.securiteinfo.com
[02/08/2004] Version 2.00
- Fixed: Bug in directory listing (files more than 350 days old had an extra space)
- Fixed: Bug in directory listing on non-English Windows versions.
- Improved crash detection (exceptions will now write a stack dump in the logfile).
- Improved stability by making FTP server classes more thread safe.
- New user interface: XP Luna Look (even on Windows 9x/NT/2000) can also be switch off...
- Added TaskPane
- Added XP Office 2003 menu's
- Changes now become directly active.
- Added context menu's and lots of other UI enhancements.
- Welcome message can now be multiple lines.
- Added: Remote administration commands (SITE LISTUSER, SITE ADDUSER, SITE DELUSER, SITE DESCUSER, SITE SETATTR,
	SITE LISTPATH, SITE ADDPATH, SITE DELPATH, SITE LISTIP, SITE ADDIP, SITE DELIP, SITE WHO, SITE KICK).
- Added: SITE MSG command (so clients can send messages to the server console).
- Added: FEAT and MDTM commands.
- Added: Default home directory in configuration (used in when new users is added).
- Added: PASV option: Get IP from remote server for better router support.
- Users/Security configuration is now saved in XML format.
- Added: Integrated download/upload statistics.
- Added: Transfer progress in Online Users window.
- Added: Option to configure maximum download/upload speed per user.
- Removed: Thread priority option.
- Added: commandline option (/f) to specify custom configuration file: /fconfig.ini (uses config.ini to load/save settings instead of the registry)
- Added: better support for wildcards in LIST and NLST.
- And much more...
[02/22/2004] Version 2.01
- Fixed: Bug in XML routines cause some passwords to become invalid after restart.
- Fixed: QUIT and BYE command now return 221 instead of 220.
[03/04/2004] Version 2.02
- Fixed: LIST command didn't accept directories with dashes.
- Fixed: Accelerator keys (F1 ... F12)
- Added: Almost all strings are now stored in the resources, so it's easier to translate the application to another language.
- Added: You can now specify ranges in the security IP filter.
- And some other minor changes to improve the quality of the code.
[03/16/2004] Version 2.03
- Fixed: Bug in 'Failed Uploads' v.s. strange download manager behaviour... (Thanks to Soul!).
[05/02/2004] Version 2.04
- Fixed: MKD now returns 257 (instead of 250) (Thanks to Owen!)
- Fixed: Sending MSG %s could crash the server! (Thanks to AkirA!)
- Fixed: Better handling of invalid characters. Removed some overhead in string manupulations.
[05/08/2004] Version 2.0.5
- Fixed: Forgot to re-enable messages console in previous fix :(
[06/08/2004] Version 2.1
- Log file class completely rewritten in MFC.
- Fixed: Problems with UI/thread synchronisation could cause exceptions (finally found it!)
- Fixed: Sometimes the security mode was not saved between sessions.
- Fixed: 'What is my IP address?' option now also work when 'Get ip from remote server' is set.
- Added: Support for files larger than 2 GB (64 bits).
- Added: 'Allow Directory Browse' option in User Accounts.
- Added: FTP Server setup wizard, to quickly configure the server.
- Added: Help information for router/firewall owners.
[06/12/2004] Version 2.11a
- Fixed: Invalid USERS.XML (virtual directory order) could cause corrupted User Accounts (thanks to Otoplenie.org!)
- Fixed: View and Clear button on Configuration page (thanks to Alexander!)
- Fixed: When skinned scrollbar was active, a large number of user accounts made the user list disappear... (thanks to Harold!)
- Added: Checkbox for 'hidden' option: Disable skinned scrollbar. Usefull if you already run XP in 'Themed mode'.
[06/14/2004] Version 2.12
- Fixed: TaskPane bug deleting collapsed items could cause an exception (thanks to Alexander!)
- Fixed: Compatibility with Win9x/NT4 issues.
- Fixed: Some minor issues with 64 bits values.
[07/02/2004] Version 2.14
- Fixed: Compatibility issues with CuteFTP Clients (and probably some other FTP clients) thanks to Mark!
- Added: Tray Icon tooltip now shows number of online users.
[07/10/2004] Version 2.2
- Fixed: Allow directory listing is now also available in remote administration commands.
- Fixed: Virtual directory did not show 'List' option in UI.
- Fixed: Virtual directory problems when mapped to root drive.
- Fixed: If 'Getting IP from remote server' failed, PASV mode did get 'confused'.
- Fixed: TaskPane now uses Windows Color Scheme when XP-look is disabled.
- Added: Detailed trace info for 'Getting IP from remote server'.
- Added: Improved Remote administration command documentation (in help file).
- Added: Configuration Tasks: 'Show Configuration help' and 'Frequently Asked Questions'
[08/10/2004] Version 2.3
- Fixed: GetPeerName failure could result in stability problems.
- Fixed: Problems with corrupt XML files (improved XML character encoding).
- Added: External changes to USERS.XML and SECURITY.XML can now be reloaded using  the commandline option: /c
- Added: 'What is my IP address?" now validates the IP address (checks if it's a valid internet IP address).
[09/05/2004] Version 2.4
- Added: Disk quota(amount of uploaded bytes) to limit users disk space: when users deletes file(s) the value is decreased again.
- Added: File Types Filter, to edit the displayed file types for the LIST command.
- Changed: Layout of the User Accounts dialog.
[10/05/2004] Version 2.4.1
- Fixed: MFC's GetLength64() did not report correct file size in LIST command.
- Fixed: Kick user did not work correctly for downloads.
- Fixed: Transfer progress is now only displayed for downloads, since it's not possible to determine the status for uploads.
- Fixed: Slightly changed error/exception handling.
