; Source created with Parsic Version 3.x
; at              : 2008.07.27. 19:14:46
; Project File    : C:\PROGRA~1\PARSIC\HA01_P.PIC
; Project Version : 1.0.9
; Created         : 2008.07.27. 16:58:57
; Last change     : 2008.07.27. 19:14:44
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_ON & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV3	= 32	; located in Bank 0
EE1_FD	= 33	; located in Bank 0
ZV2	= 34	; located in Bank 0
EE2_FD	= 35	; located in Bank 0
TR1	= 36	; located in Bank 0
TR1_HI	= 37	; located in Bank 0
S2	= 38	; located in Bank 0
ZV1	= 39	; located in Bank 0
ZV1_FD	= 40	; located in Bank 0
S3	= 41	; located in Bank 0
ZV2_FD	= 42	; located in Bank 0
ZV3_FD	= 43	; located in Bank 0
ZV4	= 44	; located in Bank 0
ZV4_FD	= 45	; located in Bank 0
S6	= 46	; located in Bank 0
ZV5	= 47	; located in Bank 0
ZV5_FD	= 48	; located in Bank 0
S4	= 49	; located in Bank 0
S5	= 50	; located in Bank 0
ZV6	= 51	; located in Bank 0
ZV6_FD	= 52	; located in Bank 0
OS1_FD	= 53	; located in Bank 0
OS2_FD	= 54	; located in Bank 0
OS3_FD	= 55	; located in Bank 0
OS4_FD	= 56	; located in Bank 0
OS5_FD	= 57	; located in Bank 0
OS6_FD	= 58	; located in Bank 0
S1	= 59	; located in Bank 0
S0	= 60	; located in Bank 0
RAM	= 61	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
EEINT_WRITE
	MOVFW INDF
EEINT_WRITE_0
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF EEDATA
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	CLRWDT
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	MOVLW 0
	MOVWF EEADR
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV3
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV3
	MOVWF FSR
	CALL EEINT_READ
	RETURN
; EE-Modul -> EE2
WRITE_EE2
	MOVLW 1
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE2
READ_EE2
	MOVLW 1
	MOVWF EEADR
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00001000'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000110'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CALL READ_EE1	; read vars from internal EE
	CALL READ_EE2	; read vars from internal EE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CLRWDT
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 156
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 156
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S2,0
	GOTO LABEL_TR1_CLR
	BSF S2,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S2,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S2,1	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S3,5
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S2,2	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S3,5
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; RS-FLIP-FLOP -> RS1
	BTFSC S2,3
	GOTO LABEL_RS1_RESET
	BTFSS S3,1
	GOTO LABEL_RS1_ENDE
	BSF S3,3	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S3,3	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; Zähler -> ZV2
	BTFSS S2,7	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S3,7
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S6,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S3,7
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Zähler -> ZV3
	BTFSS S5,7	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S4,0
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S4,0
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S2,1	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVFW S0
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 0	; Hysterese
	SUBWF S0,W
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S2,1	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S2,1	; if less
LABEL_ST1_ENDE
; GND
	BCF S2,2	; immer Low
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSC S2,1
	GOTO LABEL_LG1_TRUE
LABEL_LG1_2
	BTFSC S3,0
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BCF S2,3
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BSF S2,3
LABEL_LG1_ENDE
; Zähler -> ZV4
	BTFSS S2,4	; Reset ?
	GOTO LABEL_ZV4_COUNT
	CLRF ZV4
	GOTO LABEL_ZV4_SETOUT
LABEL_ZV4_COUNT
	BTFSS S2,5
	GOTO LABEL_ZV4_SETFD
	BTFSC ZV4_FD,0
	BSF ZV4_FD,0
	GOTO LABEL_ZV4_BACKWARD
	INCF ZV4,F
LABEL_ZV4_BACKWARD
	DECF ZV4,F
LABEL_ZV4_SETOUT
LABEL_ZV4_SETFD
	BTFSC S2,5
	GOTO LABEL_ZV4_EXIT
	BCF ZV4_FD,0
LABEL_ZV4_EXIT
; Schmitt-Trigger 8-Bit -> ST2
	BTFSC S2,4	; Ausgang gesetzt ?
	GOTO LABEL_ST2_MH	; dann mit Hysterese ?
	MOVLW 10
	GOTO LABEL_ST2_TEST
LABEL_ST2_MH
	MOVLW 10
LABEL_ST2_TEST
	SUBWF ZV4,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
	BSF S2,4	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S2,4	; if less
LABEL_ST2_ENDE
; RS-FLIP-FLOP -> RS2
	BTFSC S2,2
	GOTO LABEL_RS2_RESET
	BTFSS S2,4
	GOTO LABEL_RS2_ENDE
	BSF S2,6	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF S2,6	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S2,0
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSC S2,6
LABEL_LG2_TRUE
	BSF S2,5
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S2,5
LABEL_LG2_ENDE
; ODER - Gatter -> LG3
LABEL_LG3_1
	BTFSC S2,4
	GOTO LABEL_LG3_TRUE
LABEL_LG3_2
	BTFSC S3,2
	GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
	BCF S3,1
	GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
	BSF S3,1
LABEL_LG3_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S3,3
	GOTO LABEL_LG4_FALSE
LABEL_LG4_2
	BTFSC S3,4
LABEL_LG4_TRUE
	BSF S6,6
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF S6,6
LABEL_LG4_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S2,0
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS S3,3
LABEL_LG5_TRUE
	BSF S3,5
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S3,5
LABEL_LG5_ENDE
; Zähler -> ZV5
	BTFSS S3,2	; Reset ?
	GOTO LABEL_ZV5_COUNT
	CLRF ZV5
	GOTO LABEL_ZV5_SETOUT
LABEL_ZV5_COUNT
	BTFSS S3,6
	GOTO LABEL_ZV5_SETFD
	BTFSC ZV5_FD,0
	BSF ZV5_FD,0
	GOTO LABEL_ZV5_BACKWARD
	INCF ZV5,F
LABEL_ZV5_BACKWARD
	DECF ZV5,F
LABEL_ZV5_SETOUT
LABEL_ZV5_SETFD
	BTFSC S3,6
	GOTO LABEL_ZV5_EXIT
	BCF ZV5_FD,0
LABEL_ZV5_EXIT
; Schmitt-Trigger 8-Bit -> ST3
	BTFSC S3,2	; Ausgang gesetzt ?
	GOTO LABEL_ST3_MH	; dann mit Hysterese ?
	MOVFW S1
	GOTO LABEL_ST3_TEST
LABEL_ST3_MH
	MOVLW 0	; Hysterese
	SUBWF S1,W
LABEL_ST3_TEST
	SUBWF ZV5,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST3_RESET
	BSF S3,2	; if greater or equal
	GOTO LABEL_ST3_ENDE
LABEL_ST3_RESET
	BCF S3,2	; if less
LABEL_ST3_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSC S3,3
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S2,0
LABEL_LG6_3
	BTFSS S2,6
LABEL_LG6_TRUE
	BSF S3,6
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S3,6
LABEL_LG6_ENDE
; Schmitt-Trigger 8-Bit -> ST4
	BTFSC S2,7	; Ausgang gesetzt ?
	GOTO LABEL_ST4_MH	; dann mit Hysterese ?
	MOVLW 200
	GOTO LABEL_ST4_TEST
LABEL_ST4_MH
	MOVLW 200
LABEL_ST4_TEST
	SUBWF ZV3,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST4_RESET
	BSF S2,7	; if greater or equal
	GOTO LABEL_ST4_ENDE
LABEL_ST4_RESET
	BCF S2,7	; if less
LABEL_ST4_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
	BTFSS S4,1
	GOTO LABEL_LG7_FALSE
LABEL_LG7_2
	BTFSS S3,4
LABEL_LG7_3
	BTFSS S4,2
LABEL_LG7_TRUE
	BSF S3,7
	GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
	BCF S3,7
LABEL_LG7_ENDE
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSS S3,4
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSS S4,1
LABEL_LG8_3
	BTFSC S4,2
LABEL_LG8_TRUE
	BSF S4,0
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S4,0
LABEL_LG8_ENDE
; RS-FLIP-FLOP -> RS3
	BTFSC S4,6
	GOTO LABEL_RS3_RESET
	BTFSS S4,7
	GOTO LABEL_RS3_ENDE
	BSF S3,4	; Ausgang setzen
	GOTO LABEL_RS3_ENDE
LABEL_RS3_RESET
	BCF S3,4	; Ausgang zurücksetzen
LABEL_RS3_ENDE
; RS-FLIP-FLOP -> RS4
	BTFSC S4,3
	GOTO LABEL_RS4_RESET
	BTFSS S4,4
	GOTO LABEL_RS4_ENDE
	BSF S4,2	; Ausgang setzen
	GOTO LABEL_RS4_ENDE
LABEL_RS4_RESET
	BCF S4,2	; Ausgang zurücksetzen
LABEL_RS4_ENDE
; UND - Gatter -> LG9
LABEL_LG9_1
	BTFSS S5,0
	GOTO LABEL_LG9_FALSE
LABEL_LG9_2
	BTFSC S3,4
LABEL_LG9_TRUE
	BSF S4,7
	GOTO LABEL_LG9_ENDE
LABEL_LG9_FALSE
	BCF S4,7
LABEL_LG9_ENDE
; UND - Gatter -> LG10
LABEL_LG10_1
	BTFSS S3,4
	GOTO LABEL_LG10_FALSE
LABEL_LG10_2
	BTFSS S5,0
LABEL_LG10_TRUE
	BSF S4,6
	GOTO LABEL_LG10_ENDE
LABEL_LG10_FALSE
	BCF S4,6
LABEL_LG10_ENDE
; UND - Gatter -> LG11
LABEL_LG11_1
	BTFSS S4,2
	GOTO LABEL_LG11_FALSE
LABEL_LG11_2
	BTFSS S4,5
LABEL_LG11_TRUE
	BSF S4,3
	GOTO LABEL_LG11_ENDE
LABEL_LG11_FALSE
	BCF S4,3
LABEL_LG11_ENDE
; UND - Gatter -> LG12
LABEL_LG12_1
	BTFSS S4,5
	GOTO LABEL_LG12_FALSE
LABEL_LG12_2
	BTFSC S4,2
LABEL_LG12_TRUE
	BSF S4,4
	GOTO LABEL_LG12_ENDE
LABEL_LG12_FALSE
	BCF S4,4
LABEL_LG12_ENDE
; UND - Gatter -> LG13
LABEL_LG13_1
	BTFSS S5,3
	GOTO LABEL_LG13_FALSE
LABEL_LG13_2
	BTFSS S2,0
LABEL_LG13_TRUE
	BSF S5,5
	GOTO LABEL_LG13_ENDE
LABEL_LG13_FALSE
	BCF S5,5
LABEL_LG13_ENDE
; Zähler -> ZV6
	BTFSS S5,2	; Reset ?
	GOTO LABEL_ZV6_COUNT
	CLRF ZV6
	GOTO LABEL_ZV6_SETOUT
LABEL_ZV6_COUNT
	BTFSS S5,5
	GOTO LABEL_ZV6_SETFD
	BTFSC ZV6_FD,0
	BSF ZV6_FD,0
	GOTO LABEL_ZV6_BACKWARD
	INCF ZV6,F
LABEL_ZV6_BACKWARD
	DECF ZV6,F
LABEL_ZV6_SETOUT
LABEL_ZV6_SETFD
	BTFSC S5,5
	GOTO LABEL_ZV6_EXIT
	BCF ZV6_FD,0
LABEL_ZV6_EXIT
; ODER - Gatter -> LG14
LABEL_LG14_1
	BTFSC S5,1
	GOTO LABEL_LG14_TRUE
LABEL_LG14_2
	BTFSC S5,4
LABEL_LG14_FALSE
	BCF S5,2
	GOTO LABEL_LG14_ENDE
LABEL_LG14_TRUE
	BSF S5,2
LABEL_LG14_ENDE
; Schmitt-Trigger 8-Bit -> ST5
	BTFSC S5,1	; Ausgang gesetzt ?
	GOTO LABEL_ST5_MH	; dann mit Hysterese ?
	MOVLW 100
	GOTO LABEL_ST5_TEST
LABEL_ST5_MH
	MOVLW 100
LABEL_ST5_TEST
	SUBWF ZV6,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST5_RESET
	BSF S5,1	; if greater or equal
	GOTO LABEL_ST5_ENDE
LABEL_ST5_RESET
	BCF S5,1	; if less
LABEL_ST5_ENDE
; UND - Gatter -> LG15
LABEL_LG15_1
	BTFSC PORTA,1
	GOTO LABEL_LG15_FALSE
LABEL_LG15_TRUE
	BSF S5,3
	GOTO LABEL_LG15_ENDE
LABEL_LG15_FALSE
	BCF S5,3
LABEL_LG15_ENDE
; One Shot -> OS1
	BTFSC S5,3
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S5,4
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S5,4
	BTFSS S5,3
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSS S5,1
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S5,0
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S5,0
	BTFSC S5,1
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSS S5,6
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S4,5
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S4,5
	BTFSC S5,6
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; UND - Gatter -> LG16
LABEL_LG16_1
	BTFSS S3,4
	GOTO LABEL_LG16_FALSE
LABEL_LG16_2
	BTFSS S5,3
LABEL_LG16_TRUE
	BSF S5,6
	GOTO LABEL_LG16_ENDE
LABEL_LG16_FALSE
	BCF S5,6
LABEL_LG16_ENDE
; UND - Gatter -> LG17
LABEL_LG17_1
	BTFSS S6,7
	GOTO LABEL_LG17_FALSE
LABEL_LG17_TRUE
	BCF PORTB,3
	GOTO LABEL_LG17_ENDE
LABEL_LG17_FALSE
	BSF PORTB,3
LABEL_LG17_ENDE
; Schmitt-Trigger 8-Bit -> ST6
	BTFSC S5,7	; Ausgang gesetzt ?
	GOTO LABEL_ST6_MH	; dann mit Hysterese ?
	MOVLW 200
	GOTO LABEL_ST6_TEST
LABEL_ST6_MH
	MOVLW 200
LABEL_ST6_TEST
	SUBWF ZV3,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST6_RESET
	BSF S5,7	; if greater or equal
	GOTO LABEL_ST6_ENDE
LABEL_ST6_RESET
	BCF S5,7	; if less
LABEL_ST6_ENDE
; UND - Gatter -> LG18
LABEL_LG18_1
	BTFSC PORTA,3
	GOTO LABEL_LG18_FALSE
LABEL_LG18_TRUE
	BSF S6,0
	GOTO LABEL_LG18_ENDE
LABEL_LG18_FALSE
	BCF S6,0
LABEL_LG18_ENDE
; UND - Gatter -> LG19
LABEL_LG19_1
	BTFSC PORTA,2
	GOTO LABEL_LG19_FALSE
LABEL_LG19_TRUE
	BSF S6,1
	GOTO LABEL_LG19_ENDE
LABEL_LG19_FALSE
	BCF S6,1
LABEL_LG19_ENDE
; One Shot -> OS4
	BTFSS S6,0
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S6,2
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S6,2
	BTFSC S6,0
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; One Shot -> OS5
	BTFSS S6,1
	GOTO LABEL_OS5_1
	BTFSC OS5_FD,0
	GOTO LABEL_OS5_1
	BSF OS5_FD,0
	BSF S6,3
	GOTO LABEL_OS5_2
LABEL_OS5_1
	BCF S6,3
	BTFSC S6,1
	GOTO LABEL_OS5_2
	BCF OS5_FD,0
LABEL_OS5_2
; ODER - Gatter -> LG20
LABEL_LG20_1
	BTFSC S6,2
	GOTO LABEL_LG20_TRUE
LABEL_LG20_2
	BTFSC S6,3
LABEL_LG20_FALSE
	BCF S4,1
	GOTO LABEL_LG20_ENDE
LABEL_LG20_TRUE
	BSF S4,1
LABEL_LG20_ENDE
; EE-Modul -> EE1
; Test of falling edge
	BTFSC S4,0
	GOTO LABEL_EE1_SETFD
	BTFSS EE1_FD,0
	BCF EE1_FD,0
	CALL WRITE_EE1
LABEL_EE1_SETFD
; test input
	BTFSS S4,0
	GOTO LABEL_EE1_EXIT
	BSF EE1_FD,0
LABEL_EE1_EXIT
; EE-Modul -> EE2
	BTFSC S3,7
	GOTO LABEL_EE2_SETFD
	BTFSS EE2_FD,0
	BCF EE2_FD,0
	CALL WRITE_EE2
LABEL_EE2_SETFD
; test input
	BTFSS S3,7
	GOTO LABEL_EE2_EXIT
	BSF EE2_FD,0
LABEL_EE2_EXIT
; UND - Gatter -> LG21
LABEL_LG21_1
	BTFSS S6,5
	GOTO LABEL_LG21_FALSE
LABEL_LG21_2
	BTFSS S6,6
LABEL_LG21_TRUE
	BSF S3,0
	GOTO LABEL_LG21_ENDE
LABEL_LG21_FALSE
	BCF S3,0
LABEL_LG21_ENDE
; UND - Gatter -> LG22
LABEL_LG22_1
	BTFSS S6,6
	GOTO LABEL_LG22_FALSE
LABEL_LG22_TRUE
	BSF PORTB,4
	GOTO LABEL_LG22_ENDE
LABEL_LG22_FALSE
	BCF PORTB,4
LABEL_LG22_ENDE
; UND - Gatter -> LG23
LABEL_LG23_1
	BTFSS S3,3
	GOTO LABEL_LG23_FALSE
LABEL_LG23_TRUE
	BSF PORTB,5
	GOTO LABEL_LG23_ENDE
LABEL_LG23_FALSE
	BCF PORTB,5
LABEL_LG23_ENDE
; One Shot -> OS6
	BTFSS S6,4
	GOTO LABEL_OS6_1
	BTFSC OS6_FD,0
	GOTO LABEL_OS6_1
	BSF OS6_FD,0
	BSF S6,5
	GOTO LABEL_OS6_2
LABEL_OS6_1
	BCF S6,5
	BTFSC S6,4
	GOTO LABEL_OS6_2
	BCF OS6_FD,0
LABEL_OS6_2
; UND - Gatter -> LG24
LABEL_LG24_1
	BTFSC PORTA,0
	GOTO LABEL_LG24_FALSE
LABEL_LG24_TRUE
	BSF S6,4
	GOTO LABEL_LG24_ENDE
LABEL_LG24_FALSE
	BCF S6,4
LABEL_LG24_ENDE
; UND - Gatter -> LG25
LABEL_LG25_1
	BTFSS S2,0
	GOTO LABEL_LG25_FALSE
LABEL_LG25_2
	BTFSS S3,4
LABEL_LG25_TRUE
	BSF PORTB,0
	GOTO LABEL_LG25_ENDE
LABEL_LG25_FALSE
	BCF PORTB,0
LABEL_LG25_ENDE
; UND - Gatter -> LG26
LABEL_LG26_1
	BTFSS S4,2
	GOTO LABEL_LG26_FALSE
LABEL_LG26_2
	BTFSS S3,4
LABEL_LG26_TRUE
	BSF S6,7
	GOTO LABEL_LG26_ENDE
LABEL_LG26_FALSE
	BCF S6,7
LABEL_LG26_ENDE
;AF1
	MOVFW ZV2
	ADDLW 2
	MOVWF S1
LABEL_AF1_EXIT
;AF2
	MOVFW ZV3
	ADDLW 2
	MOVWF S0
LABEL_AF2_EXIT
	GOTO MAIN
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
