# Sources
SRCS = main.c stm32f4xx_it.c system_stm32f4xx.c syscalls.c
# USB
SRCS += usbd_usr.c usbd_cdc_vcp.c usbd_desc.c usb_bsp.c
# Project name
PROJ_NAME=stm32f4_usb_cdc
OUTPATH=build
# Check for valid float argument
# NOTE that you have to run make clan after
# changing these as hardfloat and softfloat are not
# binary compatible
ifneq ($(FLOAT_TYPE), hard)
ifneq ($(FLOAT_TYPE), soft)
override FLOAT_TYPE = hard
#override FLOAT_TYPE = soft
endif
endif
BINPATH=~/sat/bin
CC=$(BINPATH)/arm-none-eabi-gcc
OBJCOPY=$(BINPATH)/arm-none-eabi-objcopy
SIZE=$(BINPATH)/arm-none-eabi-size
CFLAGS  = -std=gnu99 -g -O2 -Wall -Tstm32_flash.ld
CFLAGS += -mlittle-endian -mthumb -mthumb-interwork -nostartfiles -mcpu=cortex-m4
ifeq ($(FLOAT_TYPE), hard)
CFLAGS += -fsingle-precision-constant -Wdouble-promotion
CFLAGS += -mfpu=fpv4-sp-d16 -mfloat-abi=hard
else
CFLAGS += -msoft-float
endif
vpath %.c src
vpath %.a lib
ROOT=$(shell pwd)
# Includes
CFLAGS += -Iinc -Ilib/Core/cmsis -Ilib/Core/stm32
CFLAGS += -Ilib/Conf
# Library paths
LIBPATHS = -Llib/StdPeriph -Llib/USB_Device/Core
LIBPATHS += -Llib/USB_Device/Class/cdc -Llib/USB_OTG
# Libraries to link
LIBS = -lm -lstdperiph -lusbdevcore -lusbdevcdc -lusbcore
# Extra includes
CFLAGS += -Ilib/StdPeriph/inc
CFLAGS += -Ilib/USB_OTG/inc
CFLAGS += -Ilib/USB_Device/Core/inc
CFLAGS += -Ilib/USB_Device/Class/cdc/inc
# add startup file to build
SRCS += lib/startup_stm32f4xx.s
OBJS = $(SRCS:.c=.o)
.PHONY: lib proj
all: lib proj
	$(SIZE) $(OUTPATH)/$(PROJ_NAME).elf
lib:
	$(MAKE) -C lib FLOAT_TYPE=$(FLOAT_TYPE)
proj: 	$(OUTPATH)/$(PROJ_NAME).elf
$(OUTPATH)/$(PROJ_NAME).elf: $(SRCS)
	$(CC) $(CFLAGS) $^ -o $@ $(LIBPATHS) $(LIBS)
	$(OBJCOPY) -O ihex $(OUTPATH)/$(PROJ_NAME).elf $(OUTPATH)/$(PROJ_NAME).hex
	$(OBJCOPY) -O binary $(OUTPATH)/$(PROJ_NAME).elf $(OUTPATH)/$(PROJ_NAME).bin
clean:
	rm -f *.o
	rm -f $(OUTPATH)/$(PROJ_NAME).elf
	rm -f $(OUTPATH)/$(PROJ_NAME).hex
	rm -f $(OUTPATH)/$(PROJ_NAME).bin
	$(MAKE) clean -C lib # Remove this line if you don't want to clean the libs as well
