#include <Wire.h>
#include <Keypad_I2C.h>
#include <Keypad.h>
#include <EEPROM.h>
char* secretCode = "123456";
int position = 0;
int position2 = 0;
boolean locked = true;
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[rows] = {0,1,2,3}; //connect to the row pinouts of the keypad
byte colPins[cols] = {4,5,6,7}; //connect to the column pinouts of the keypad
int i2caddress = 0x20;
Keypad_I2C keypad = Keypad_I2C(makeKeymap(keys), rowPins, colPins, rows, cols, i2caddress );
int redPin = 11;
int greenPin = 12;
int bluePin = 10;
//int solenoidPin = 13;
int i = 0;
void setup()
  keypad.begin();
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
loadCode();
flash();
updateOutputs();
void loop()
char key = keypad.getKey();
if (key)
position2 ++;
digitalWrite(bluePin, HIGH);
delay(30);
digitalWrite(bluePin, LOW);
if (key == '*' && ! locked)
// unlocked and * pressed so change code
position = 0;
position2 = 0;
getNewCode();
updateOutputs();
if (key == '#')
locked = true;
position = 0;
position2= 0;
updateOutputs();
delay(300);
if (key == secretCode[position])
position ++;
if (position == 6 & position2 == 6)
locked = false;
delay(300);
updateOutputs();
delay(100);
void updateOutputs()
if (locked)
digitalWrite(redPin, HIGH);
digitalWrite(greenPin, LOW);
//digitalWrite(solenoidPin, HIGH);
else
digitalWrite(redPin, LOW);
digitalWrite(greenPin, HIGH);
//digitalWrite(solenoidPin, LOW);
delay (50);
for (int i=0; i <= 100; i++)
char key;
if (key == '*')
position = 0;
position2 = 0;
getNewCode();
updateOutputs();
delay (50);
locked = true;
position = 0;
position2= 0;
void getNewCode()
flash();
for (int i = 0; i < 6; i++ )
char key;
while (key == 0)
flash();
secretCode[i] = key;
saveCode();
flash();flash();
void loadCode()
if (EEPROM.read(0) == 9)
secretCode[0] = EEPROM.read(1);
secretCode[1] = EEPROM.read(2);
secretCode[2] = EEPROM.read(3);
secretCode[3] = EEPROM.read(4);
secretCode[4] = EEPROM.read(5);
secretCode[5] = EEPROM.read(6);
void saveCode()
EEPROM.write(1, secretCode[0]);
EEPROM.write(2, secretCode[1]);
EEPROM.write(3, secretCode[2]);
EEPROM.write(4, secretCode[3]);
EEPROM.write(5, secretCode[4]);
EEPROM.write(6, secretCode[5]);
EEPROM.write(0, 9);
void flash()
delay(100);
delay(100);
