  TwoWire.cpp - TWI/I2C library for Wiring & Arduino
  Copyright (c) 2006 Nicholas Zambetti.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  Modified 2012 by Todd Krein (todd@krein.org) to implement repeated starts
extern "C" {
  #include <stdlib.h>
  #include <string.h>
  #include <inttypes.h>
  #include "twi.h"
#include "Wire.h"
// Initialize Class Variables //////////////////////////////////////////////////
uint8_t TwoWire::rxBuffer[BUFFER_LENGTH];
uint8_t TwoWire::rxBufferIndex = 0;
uint8_t TwoWire::rxBufferLength = 0;
uint8_t TwoWire::txAddress = 0;
uint8_t TwoWire::txBuffer[BUFFER_LENGTH];
uint8_t TwoWire::txBufferIndex = 0;
uint8_t TwoWire::txBufferLength = 0;
uint8_t TwoWire::transmitting = 0;
void (*TwoWire::user_onRequest)(void);
void (*TwoWire::user_onReceive)(int);
// Constructors ////////////////////////////////////////////////////////////////
TwoWire::TwoWire()
// Public Methods //////////////////////////////////////////////////////////////
void TwoWire::begin(void)
  rxBufferIndex = 0;
  rxBufferLength = 0;
  txBufferIndex = 0;
  txBufferLength = 0;
  twi_init();
void TwoWire::begin(uint8_t address)
  twi_setAddress(address);
  twi_attachSlaveTxEvent(onRequestService);
  twi_attachSlaveRxEvent(onReceiveService);
  begin();
void TwoWire::begin(int address)
  begin((uint8_t)address);
void TwoWire::setClock(uint32_t frequency)
  TWBR = ((F_CPU / frequency) - 16) / 2;
uint8_t TwoWire::requestFrom(uint8_t address, uint8_t quantity, uint8_t sendStop)
  // clamp to buffer length
  if(quantity > BUFFER_LENGTH){
    quantity = BUFFER_LENGTH;
  // perform blocking read into buffer
  uint8_t read = twi_readFrom(address, rxBuffer, quantity, sendStop);
  // set rx buffer iterator vars
  rxBufferIndex = 0;
  rxBufferLength = read;
  return read;
uint8_t TwoWire::requestFrom(uint8_t address, uint8_t quantity)
  return requestFrom((uint8_t)address, (uint8_t)quantity, (uint8_t)true);
uint8_t TwoWire::requestFrom(int address, int quantity)
uint8_t TwoWire::requestFrom(int address, int quantity, int sendStop)
  return requestFrom((uint8_t)address, (uint8_t)quantity, (uint8_t)sendStop);
void TwoWire::beginTransmission(uint8_t address)
  // indicate that we are transmitting
  transmitting = 1;
  // set address of targeted slave
  txAddress = address;
  // reset tx buffer iterator vars
  txBufferIndex = 0;
  txBufferLength = 0;
void TwoWire::beginTransmission(int address)
  beginTransmission((uint8_t)address);
//	Originally, 'endTransmission' was an f(void) function.
//	It has been modified to take one parameter indicating
//	whether or not a STOP should be performed on the bus.
//	Calling endTransmission(false) allows a sketch to
//	perform a repeated start.
//	WARNING: Nothing in the library keeps track of whether
//	the bus tenure has been properly ended with a STOP. It
//	is very possible to leave the bus in a hung state if
//	no call to endTransmission(true) is made. Some I2C
//	devices will behave oddly if they do not see a STOP.
uint8_t TwoWire::endTransmission(uint8_t sendStop)
  // transmit buffer (blocking)
  int8_t ret = twi_writeTo(txAddress, txBuffer, txBufferLength, 1, sendStop);
  txBufferIndex = 0;
  txBufferLength = 0;
  // indicate that we are done transmitting
  transmitting = 0;
  return ret;
//	This provides backwards compatibility with the original
//	definition, and expected behaviour, of endTransmission
uint8_t TwoWire::endTransmission(void)
  return endTransmission(true);
// must be called in:
// slave tx event callback
// or after beginTransmission(address)
size_t TwoWire::write(uint8_t data)
  if(transmitting){
  // in master transmitter mode
    // don't bother if buffer is full
    if(txBufferLength >= BUFFER_LENGTH){
      setWriteError();
      return 0;
    // put byte in tx buffer
    txBuffer[txBufferIndex] = data;
    ++txBufferIndex;
    // update amount in buffer
    txBufferLength = txBufferIndex;
  }else{
  // in slave send mode
    // reply to master
    twi_transmit(&data, 1);
  return 1;
size_t TwoWire::write(const uint8_t *data, size_t quantity)
  if(transmitting){
    for(size_t i = 0; i < quantity; ++i){
      write(data[i]);
  }else{
    // reply to master
    twi_transmit(data, quantity);
  return quantity;
// slave rx event callback
// or after requestFrom(address, numBytes)
int TwoWire::available(void)
  return rxBufferLength - rxBufferIndex;
int TwoWire::read(void)
  int value = -1;
  // get each successive byte on each call
  if(rxBufferIndex < rxBufferLength){
    value = rxBuffer[rxBufferIndex];
    ++rxBufferIndex;
  return value;
int TwoWire::peek(void)
  int value = -1;
  return value;
void TwoWire::flush(void)
  // XXX: to be implemented.
// behind the scenes function that is called when data is received
void TwoWire::onReceiveService(uint8_t* inBytes, int numBytes)
  // don't bother if user hasn't registered a callback
  if(!user_onReceive){
    return;
  // don't bother if rx buffer is in use by a master requestFrom() op
  // i know this drops data, but it allows for slight stupidity
  // meaning, they may not have read all the master requestFrom() data yet
    return;
  // copy twi rx buffer into local read buffer
  // this enables new reads to happen in parallel
  for(uint8_t i = 0; i < numBytes; ++i){
    rxBuffer[i] = inBytes[i];
  // set rx iterator vars
  rxBufferIndex = 0;
  rxBufferLength = numBytes;
  // alert user program
  user_onReceive(numBytes);
// behind the scenes function that is called when data is requested
void TwoWire::onRequestService(void)
  if(!user_onRequest){
    return;
  // !!! this will kill any pending pre-master sendTo() activity
  txBufferIndex = 0;
  txBufferLength = 0;
  user_onRequest();
// sets function called on slave write
void TwoWire::onReceive( void (*function)(int) )
  user_onReceive = function;
// sets function called on slave read
void TwoWire::onRequest( void (*function)(void) )
  user_onRequest = function;
// Preinstantiate Objects //////////////////////////////////////////////////////
TwoWire Wire = TwoWire();
