<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.3.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<library>
<description>7/8-Bit Single, +36V (±18V) Digital POT with I2C™ Serial Interface and Volatile Memory</description>
<packages>
<package name="TSSOP14">
<description>&lt;b&gt;Thin Shrink Small Outline Plastic 14&lt;/b&gt;&lt;p&gt;
MAX3223-MAX3243.pdf</description>
<wire x1="-2.5146" y1="-2.2828" x2="2.5146" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="2.5146" y1="2.2828" x2="2.5146" y2="-2.2828" width="0.1524" layer="21"/>
<wire x1="2.5146" y1="2.2828" x2="-2.5146" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-2.5146" y1="-2.2828" x2="-2.5146" y2="2.2828" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-2.0542" x2="2.286" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="2.286" y1="2.0542" x2="2.286" y2="-2.0542" width="0.0508" layer="21"/>
<wire x1="2.286" y1="2.0542" x2="-2.286" y2="2.0542" width="0.0508" layer="21"/>
<wire x1="-2.286" y1="-2.0542" x2="-2.286" y2="2.0542" width="0.0508" layer="21"/>
<circle x="-1.6256" y="-1.2192" radius="0.4572" width="0.1524" layer="21"/>
<smd name="1" x="-1.95" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="2" x="-1.3" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="3" x="-0.65" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="4" x="0" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="5" x="0.65" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="6" x="1.3" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="7" x="1.95" y="-2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="8" x="1.95" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="9" x="1.3" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="10" x="0.65" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="11" x="0" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="12" x="-0.65" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="13" x="-1.3" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<smd name="14" x="-1.95" y="2.9178" dx="0.3048" dy="0.9906" layer="1"/>
<text x="-2.8956" y="-2.0828" size="1.016" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.8862" y="-2.0828" size="1.016" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.0516" y1="-3.121" x2="-1.8484" y2="-2.2828" layer="51"/>
<rectangle x1="-1.4016" y1="-3.121" x2="-1.1984" y2="-2.2828" layer="51"/>
<rectangle x1="-0.7516" y1="-3.121" x2="-0.5484" y2="-2.2828" layer="51"/>
<rectangle x1="-0.1016" y1="-3.121" x2="0.1016" y2="-2.2828" layer="51"/>
<rectangle x1="0.5484" y1="-3.121" x2="0.7516" y2="-2.2828" layer="51"/>
<rectangle x1="1.1984" y1="-3.121" x2="1.4016" y2="-2.2828" layer="51"/>
<rectangle x1="1.8484" y1="-3.121" x2="2.0516" y2="-2.2828" layer="51"/>
<rectangle x1="1.8484" y1="2.2828" x2="2.0516" y2="3.121" layer="51"/>
<rectangle x1="1.1984" y1="2.2828" x2="1.4016" y2="3.121" layer="51"/>
<rectangle x1="0.5484" y1="2.2828" x2="0.7516" y2="3.121" layer="51"/>
<rectangle x1="-0.1016" y1="2.2828" x2="0.1016" y2="3.121" layer="51"/>
<rectangle x1="-0.7516" y1="2.2828" x2="-0.5484" y2="3.121" layer="51"/>
<rectangle x1="-1.4016" y1="2.2828" x2="-1.1984" y2="3.121" layer="51"/>
<rectangle x1="-2.0516" y1="2.2828" x2="-1.8484" y2="3.121" layer="51"/>
</package>
<package name="QFN20-MQ">
<description>20-Lead Plastic Quad Flat, No Lead Package(MQ) – 5x5x0.9 mm Body [QFN]&lt;br&gt;
EP is Exposed Pad</description>
<wire x1="-2.5" y1="2.5" x2="2.5" y2="2.5" width="0.15" layer="21"/>
<wire x1="2.5" y1="2.5" x2="2.5" y2="-2.5" width="0.15" layer="21"/>
<wire x1="2.5" y1="-2.5" x2="-2.5" y2="-2.5" width="0.15" layer="21"/>
<wire x1="-2.5" y1="-2.5" x2="-2.5" y2="2.5" width="0.15" layer="21"/>
<smd name="18" x="0" y="2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="17" x="0.6" y="2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="16" x="1.2" y="2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="19" x="-0.6" y="2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="20" x="-1.2" y="2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="8" x="0" y="-2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="9" x="0.6" y="-2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="10" x="1.2" y="-2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="7" x="-0.6" y="-2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="6" x="-1.2" y="-2.25" dx="0.4" dy="0.55" layer="1"/>
<smd name="13" x="2.25" y="0" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="12" x="2.25" y="-0.6" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="11" x="2.25" y="-1.2" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="3" x="-2.25" y="0" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="4" x="-2.25" y="-0.6" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="5" x="-2.25" y="-1.2" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="14" x="2.25" y="0.6" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="15" x="2.25" y="1.2" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="2" x="-2.25" y="0.6" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="1" x="-2.25" y="1.2" dx="0.4" dy="0.55" layer="1" rot="R90"/>
<smd name="EP" x="0" y="0" dx="3.35" dy="3.35" layer="1"/>
<rectangle x1="-2.5" y1="0" x2="0" y2="2.45" layer="21"/>
<text x="-2.5" y="2.7" size="0.5" layer="25" font="vector">&gt;NAME</text>
<text x="-2.5" y="-3.15" size="0.5" layer="27" font="vector">&gt;VALUE</text>
<wire x1="-2.5" y1="2.5" x2="2.5" y2="2.5" width="0.15" layer="39"/>
<wire x1="2.5" y1="2.5" x2="2.5" y2="-2.5" width="0.15" layer="39"/>
<wire x1="2.5" y1="-2.5" x2="-2.55" y2="-2.5" width="0.15" layer="39"/>
<wire x1="-2.55" y1="-2.5" x2="-2.5" y2="-2.55" width="0.15" layer="39"/>
<wire x1="-2.5" y1="-2.55" x2="-2.5" y2="2.5" width="0.15" layer="39"/>
</package>
</packages>
<symbols>
<symbol name="MCP45HVX1">
<wire x1="-10.16" y1="12.7" x2="10.16" y2="12.7" width="0.4064" layer="94"/>
<wire x1="10.16" y1="12.7" x2="10.16" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-12.7" x2="-10.16" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="-12.7" x2="-10.16" y2="12.7" width="0.4064" layer="94"/>
<pin name="V+" x="15.24" y="10.16" length="middle" direction="pwr" rot="R180"/>
<pin name="V-" x="15.24" y="-10.16" length="middle" direction="pwr" rot="R180"/>
<pin name="VL" x="-15.24" y="10.16" length="middle" direction="pwr"/>
<pin name="SCL" x="-15.24" y="7.62" length="middle"/>
<pin name="SDA" x="-15.24" y="5.08" length="middle"/>
<pin name="A0" x="-15.24" y="2.54" length="middle"/>
<pin name="A1" x="-15.24" y="0" length="middle"/>
<pin name="!WLAT" x="-15.24" y="-2.54" length="middle"/>
<pin name="!SHDN" x="-15.24" y="-5.08" length="middle"/>
<pin name="DGND" x="-15.24" y="-10.16" length="middle" direction="pwr"/>
<pin name="P0A" x="15.24" y="7.62" length="middle" direction="pas" rot="R180"/>
<pin name="P0B" x="15.24" y="-7.62" length="middle" direction="pas" rot="R180"/>
<pin name="P0W" x="15.24" y="0" length="middle" direction="pas" rot="R180"/>
<wire x1="2.286" y1="-2.032" x2="1.27" y2="-1.016" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.016" x2="2.286" y2="0" width="0.254" layer="94"/>
<wire x1="2.286" y1="0" x2="1.27" y2="1.016" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.016" x2="2.286" y2="2.032" width="0.254" layer="94"/>
<wire x1="2.286" y1="2.032" x2="1.27" y2="3.048" width="0.254" layer="94"/>
<wire x1="1.27" y1="3.048" x2="2.286" y2="4.064" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.032" x2="1.27" y2="-3.048" width="0.254" layer="94"/>
<wire x1="1.27" y1="-3.048" x2="2.286" y2="-4.064" width="0.254" layer="94"/>
<wire x1="2.286" y1="0" x2="2.54" y2="-0.254" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.254" x2="2.54" y2="0.254" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.254" x2="2.286" y2="0" width="0.254" layer="94"/>
<wire x1="2.286" y1="0" x2="3.048" y2="0" width="0.254" layer="94"/>
<wire x1="2.286" y1="4.064" x2="1.27" y2="5.08" width="0.254" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.286" y2="6.096" width="0.254" layer="94"/>
<wire x1="2.286" y1="-4.064" x2="1.27" y2="-5.08" width="0.254" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.286" y2="-6.096" width="0.254" layer="94"/>
<wire x1="2.286" y1="-6.096" x2="1.27" y2="-7.112" width="0.254" layer="94"/>
<wire x1="1.27" y1="-7.112" x2="1.778" y2="-7.62" width="0.254" layer="94"/>
<wire x1="1.778" y1="-7.62" x2="2.794" y2="-7.62" width="0.254" layer="94"/>
<wire x1="2.286" y1="6.096" x2="1.27" y2="7.112" width="0.254" layer="94"/>
<wire x1="1.27" y1="7.112" x2="1.778" y2="7.62" width="0.254" layer="94"/>
<wire x1="1.778" y1="7.62" x2="2.794" y2="7.62" width="0.254" layer="94"/>
<circle x="2.794" y="-7.62" radius="0.254" width="0.254" layer="94"/>
<circle x="2.794" y="7.62" radius="0.254" width="0.254" layer="94"/>
<text x="-10.16" y="13.208" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="-10.16" y="-14.986" size="1.778" layer="95" font="vector">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MCP45HVX1" prefix="IC">
<description>The MCP45HVX1 family of devices have dual power rails (analog and digital). The analog power rail allows high voltage on the resistor network terminal pins. The analog voltage range is determined by the V+ and V– voltages.
&lt;br&gt;&lt;br&gt;
The library has been designed by&lt;a href="https://www.facebook.com/groups/eaglecadsoftUK"&gt; Richard Magdycz&lt;/a&gt;</description>
<gates>
<gate name="G$1" symbol="MCP45HVX1" x="0" y="0"/>
</gates>
<devices>
<device name="ST" package="TSSOP14">
<connects>
<connect gate="G$1" pin="!SHDN" pad="8"/>
<connect gate="G$1" pin="!WLAT" pad="6"/>
<connect gate="G$1" pin="A0" pad="5"/>
<connect gate="G$1" pin="A1" pad="3"/>
<connect gate="G$1" pin="DGND" pad="9"/>
<connect gate="G$1" pin="P0A" pad="13"/>
<connect gate="G$1" pin="P0B" pad="11"/>
<connect gate="G$1" pin="P0W" pad="12"/>
<connect gate="G$1" pin="SCL" pad="2"/>
<connect gate="G$1" pin="SDA" pad="4"/>
<connect gate="G$1" pin="V+" pad="14"/>
<connect gate="G$1" pin="V-" pad="10"/>
<connect gate="G$1" pin="VL" pad="1"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="MQ" package="QFN20-MQ">
<connects>
<connect gate="G$1" pin="!SHDN" pad="7"/>
<connect gate="G$1" pin="DGND" pad="11"/>
<connect gate="G$1" pin="P0A" pad="15"/>
<connect gate="G$1" pin="P0B" pad="13"/>
<connect gate="G$1" pin="P0W" pad="14"/>
<connect gate="G$1" pin="V+" pad="16"/>
<connect gate="G$1" pin="V-" pad="12"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
