<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.7.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="SMD">
</package>
<package name="ICCAF10P254_1240X1905X375L155X170N">
<description>Chip Array, 2 Side Flat, 2.54 mm pitch; 10 pin, 12.40 mm L X 19.05 mm W X 3.75 mm H body&lt;p&gt;&lt;i&gt;PCB Libraries Packages&lt;/i&gt;</description>
<smd name="1" x="-5.08" y="-8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R270" stop="no" cream="no"/>
<smd name="2" x="-2.54" y="-8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R270" stop="no" cream="no"/>
<smd name="3" x="0" y="-8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R270" stop="no" cream="no"/>
<smd name="4" x="2.54" y="-8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R270" stop="no" cream="no"/>
<smd name="5" x="5.08" y="-8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R270" stop="no" cream="no"/>
<smd name="6" x="5.08" y="8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R90" stop="no" cream="no"/>
<smd name="7" x="2.54" y="8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R90" stop="no" cream="no"/>
<smd name="8" x="0" y="8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R90" stop="no" cream="no"/>
<smd name="9" x="-2.54" y="8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R90" stop="no" cream="no"/>
<smd name="10" x="-5.08" y="8.985" dx="2.18" dy="1.76" layer="1" roundness="28" rot="R90" stop="no" cream="no"/>
<polygon width="0.01" layer="29">
<vertex x="-5.96" y="-8.985"/>
<vertex x="-5.96" y="-8.145"/>
<vertex x="-5.9569" y="-8.1059"/>
<vertex x="-5.9478" y="-8.0677"/>
<vertex x="-5.9328" y="-8.0315"/>
<vertex x="-5.9123" y="-7.9981"/>
<vertex x="-5.8868" y="-7.9682"/>
<vertex x="-5.8569" y="-7.9427"/>
<vertex x="-5.8235" y="-7.9222"/>
<vertex x="-5.7873" y="-7.9072"/>
<vertex x="-5.7491" y="-7.8981"/>
<vertex x="-4.45" y="-7.895"/>
<vertex x="-4.4109" y="-7.8981"/>
<vertex x="-4.3727" y="-7.9072"/>
<vertex x="-4.3365" y="-7.9222"/>
<vertex x="-4.3031" y="-7.9427"/>
<vertex x="-4.2732" y="-7.9682"/>
<vertex x="-4.2477" y="-7.9981"/>
<vertex x="-4.2272" y="-8.0315"/>
<vertex x="-4.2122" y="-8.0677"/>
<vertex x="-4.2031" y="-8.1059"/>
<vertex x="-4.2" y="-8.145"/>
<vertex x="-4.2" y="-9.825"/>
<vertex x="-4.2031" y="-9.8641"/>
<vertex x="-4.2122" y="-9.9023"/>
<vertex x="-4.2272" y="-9.9385"/>
<vertex x="-4.2477" y="-9.9719"/>
<vertex x="-4.2732" y="-10.0018"/>
<vertex x="-4.3031" y="-10.0273"/>
<vertex x="-4.3365" y="-10.0478"/>
<vertex x="-4.3727" y="-10.0628"/>
<vertex x="-4.4109" y="-10.0719"/>
<vertex x="-5.71" y="-10.075"/>
<vertex x="-5.7491" y="-10.0719"/>
<vertex x="-5.7873" y="-10.0628"/>
<vertex x="-5.8235" y="-10.0478"/>
<vertex x="-5.8569" y="-10.0273"/>
<vertex x="-5.8868" y="-10.0018"/>
<vertex x="-5.9123" y="-9.9719"/>
<vertex x="-5.9328" y="-9.9385"/>
<vertex x="-5.9478" y="-9.9023"/>
<vertex x="-5.9569" y="-9.8641"/>
<vertex x="-5.96" y="-9.825"/>
</polygon>
<polygon width="0.01" layer="31">
</polygon>
<wire x1="-5.93" y1="-7.975" x2="-4.23" y2="-7.975" width="0.025" layer="51"/>
<wire x1="-4.23" y1="-7.975" x2="-4.23" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-4.23" y1="-9.525" x2="-5.93" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-5.93" y1="-9.525" x2="-5.93" y2="-7.975" width="0.025" layer="51"/>
<vertex x="-3.42" y="-8.985"/>
<vertex x="-3.42" y="-8.145"/>
<vertex x="-3.4169" y="-8.1059"/>
<vertex x="-3.4078" y="-8.0677"/>
<vertex x="-3.3928" y="-8.0315"/>
<vertex x="-3.3723" y="-7.9981"/>
<vertex x="-3.3468" y="-7.9682"/>
<vertex x="-3.3169" y="-7.9427"/>
<vertex x="-3.2835" y="-7.9222"/>
<vertex x="-3.2473" y="-7.9072"/>
<vertex x="-3.2091" y="-7.8981"/>
<vertex x="-1.91" y="-7.895"/>
<vertex x="-1.8709" y="-7.8981"/>
<vertex x="-1.8327" y="-7.9072"/>
<vertex x="-1.7965" y="-7.9222"/>
<vertex x="-1.7631" y="-7.9427"/>
<vertex x="-1.7332" y="-7.9682"/>
<vertex x="-1.7077" y="-7.9981"/>
<vertex x="-1.6872" y="-8.0315"/>
<vertex x="-1.6722" y="-8.0677"/>
<vertex x="-1.6631" y="-8.1059"/>
<vertex x="-1.66" y="-8.145"/>
<vertex x="-1.66" y="-9.825"/>
<vertex x="-1.6631" y="-9.8641"/>
<vertex x="-1.6722" y="-9.9023"/>
<vertex x="-1.6872" y="-9.9385"/>
<vertex x="-1.7077" y="-9.9719"/>
<vertex x="-1.7332" y="-10.0018"/>
<vertex x="-1.7631" y="-10.0273"/>
<vertex x="-1.7965" y="-10.0478"/>
<vertex x="-1.8327" y="-10.0628"/>
<vertex x="-1.8709" y="-10.0719"/>
<vertex x="-3.17" y="-10.075"/>
<vertex x="-3.2091" y="-10.0719"/>
<vertex x="-3.2473" y="-10.0628"/>
<vertex x="-3.2835" y="-10.0478"/>
<vertex x="-3.3169" y="-10.0273"/>
<vertex x="-3.3468" y="-10.0018"/>
<vertex x="-3.3723" y="-9.9719"/>
<vertex x="-3.3928" y="-9.9385"/>
<vertex x="-3.4078" y="-9.9023"/>
<vertex x="-3.4169" y="-9.8641"/>
<vertex x="-3.42" y="-9.825"/>
</polygon>
</polygon>
<wire x1="-3.39" y1="-7.975" x2="-1.69" y2="-7.975" width="0.025" layer="51"/>
<wire x1="-1.69" y1="-7.975" x2="-1.69" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-1.69" y1="-9.525" x2="-3.39" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-3.39" y1="-9.525" x2="-3.39" y2="-7.975" width="0.025" layer="51"/>
<vertex x="-0.88" y="-8.985"/>
<vertex x="-0.88" y="-8.145"/>
<vertex x="-0.8769" y="-8.1059"/>
<vertex x="-0.8678" y="-8.0677"/>
<vertex x="-0.8528" y="-8.0315"/>
<vertex x="-0.8323" y="-7.9981"/>
<vertex x="-0.8068" y="-7.9682"/>
<vertex x="-0.7769" y="-7.9427"/>
<vertex x="-0.7435" y="-7.9222"/>
<vertex x="-0.7073" y="-7.9072"/>
<vertex x="-0.6691" y="-7.8981"/>
<vertex x="0.63" y="-7.895"/>
<vertex x="0.6691" y="-7.8981"/>
<vertex x="0.7073" y="-7.9072"/>
<vertex x="0.7435" y="-7.9222"/>
<vertex x="0.7769" y="-7.9427"/>
<vertex x="0.8068" y="-7.9682"/>
<vertex x="0.8323" y="-7.9981"/>
<vertex x="0.8528" y="-8.0315"/>
<vertex x="0.8678" y="-8.0677"/>
<vertex x="0.8769" y="-8.1059"/>
<vertex x="0.88" y="-8.145"/>
<vertex x="0.88" y="-9.825"/>
<vertex x="0.8769" y="-9.8641"/>
<vertex x="0.8678" y="-9.9023"/>
<vertex x="0.8528" y="-9.9385"/>
<vertex x="0.8323" y="-9.9719"/>
<vertex x="0.8068" y="-10.0018"/>
<vertex x="0.7769" y="-10.0273"/>
<vertex x="0.7435" y="-10.0478"/>
<vertex x="0.7073" y="-10.0628"/>
<vertex x="0.6691" y="-10.0719"/>
<vertex x="-0.63" y="-10.075"/>
<vertex x="-0.6691" y="-10.0719"/>
<vertex x="-0.7073" y="-10.0628"/>
<vertex x="-0.7435" y="-10.0478"/>
<vertex x="-0.7769" y="-10.0273"/>
<vertex x="-0.8068" y="-10.0018"/>
<vertex x="-0.8323" y="-9.9719"/>
<vertex x="-0.8528" y="-9.9385"/>
<vertex x="-0.8678" y="-9.9023"/>
<vertex x="-0.8769" y="-9.8641"/>
<vertex x="-0.88" y="-9.825"/>
</polygon>
</polygon>
<wire x1="-0.85" y1="-7.975" x2="0.85" y2="-7.975" width="0.025" layer="51"/>
<wire x1="0.85" y1="-7.975" x2="0.85" y2="-9.525" width="0.025" layer="51"/>
<wire x1="0.85" y1="-9.525" x2="-0.85" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-0.85" y1="-9.525" x2="-0.85" y2="-7.975" width="0.025" layer="51"/>
<vertex x="1.66" y="-8.985"/>
<vertex x="1.66" y="-8.145"/>
<vertex x="1.6631" y="-8.1059"/>
<vertex x="1.6722" y="-8.0677"/>
<vertex x="1.6872" y="-8.0315"/>
<vertex x="1.7077" y="-7.9981"/>
<vertex x="1.7332" y="-7.9682"/>
<vertex x="1.7631" y="-7.9427"/>
<vertex x="1.7965" y="-7.9222"/>
<vertex x="1.8327" y="-7.9072"/>
<vertex x="1.8709" y="-7.8981"/>
<vertex x="3.17" y="-7.895"/>
<vertex x="3.2091" y="-7.8981"/>
<vertex x="3.2473" y="-7.9072"/>
<vertex x="3.2835" y="-7.9222"/>
<vertex x="3.3169" y="-7.9427"/>
<vertex x="3.3468" y="-7.9682"/>
<vertex x="3.3723" y="-7.9981"/>
<vertex x="3.3928" y="-8.0315"/>
<vertex x="3.4078" y="-8.0677"/>
<vertex x="3.4169" y="-8.1059"/>
<vertex x="3.42" y="-8.145"/>
<vertex x="3.42" y="-9.825"/>
<vertex x="3.4169" y="-9.8641"/>
<vertex x="3.4078" y="-9.9023"/>
<vertex x="3.3928" y="-9.9385"/>
<vertex x="3.3723" y="-9.9719"/>
<vertex x="3.3468" y="-10.0018"/>
<vertex x="3.3169" y="-10.0273"/>
<vertex x="3.2835" y="-10.0478"/>
<vertex x="3.2473" y="-10.0628"/>
<vertex x="3.2091" y="-10.0719"/>
<vertex x="1.91" y="-10.075"/>
<vertex x="1.8709" y="-10.0719"/>
<vertex x="1.8327" y="-10.0628"/>
<vertex x="1.7965" y="-10.0478"/>
<vertex x="1.7631" y="-10.0273"/>
<vertex x="1.7332" y="-10.0018"/>
<vertex x="1.7077" y="-9.9719"/>
<vertex x="1.6872" y="-9.9385"/>
<vertex x="1.6722" y="-9.9023"/>
<vertex x="1.6631" y="-9.8641"/>
<vertex x="1.66" y="-9.825"/>
</polygon>
</polygon>
<wire x1="1.69" y1="-7.975" x2="3.39" y2="-7.975" width="0.025" layer="51"/>
<wire x1="3.39" y1="-7.975" x2="3.39" y2="-9.525" width="0.025" layer="51"/>
<wire x1="3.39" y1="-9.525" x2="1.69" y2="-9.525" width="0.025" layer="51"/>
<wire x1="1.69" y1="-9.525" x2="1.69" y2="-7.975" width="0.025" layer="51"/>
<vertex x="4.2" y="-8.985"/>
<vertex x="4.2" y="-8.145"/>
<vertex x="4.2031" y="-8.1059"/>
<vertex x="4.2122" y="-8.0677"/>
<vertex x="4.2272" y="-8.0315"/>
<vertex x="4.2477" y="-7.9981"/>
<vertex x="4.2732" y="-7.9682"/>
<vertex x="4.3031" y="-7.9427"/>
<vertex x="4.3365" y="-7.9222"/>
<vertex x="4.3727" y="-7.9072"/>
<vertex x="4.4109" y="-7.8981"/>
<vertex x="5.71" y="-7.895"/>
<vertex x="5.7491" y="-7.8981"/>
<vertex x="5.7873" y="-7.9072"/>
<vertex x="5.8235" y="-7.9222"/>
<vertex x="5.8569" y="-7.9427"/>
<vertex x="5.8868" y="-7.9682"/>
<vertex x="5.9123" y="-7.9981"/>
<vertex x="5.9328" y="-8.0315"/>
<vertex x="5.9478" y="-8.0677"/>
<vertex x="5.9569" y="-8.1059"/>
<vertex x="5.96" y="-8.145"/>
<vertex x="5.96" y="-9.825"/>
<vertex x="5.9569" y="-9.8641"/>
<vertex x="5.9478" y="-9.9023"/>
<vertex x="5.9328" y="-9.9385"/>
<vertex x="5.9123" y="-9.9719"/>
<vertex x="5.8868" y="-10.0018"/>
<vertex x="5.8569" y="-10.0273"/>
<vertex x="5.8235" y="-10.0478"/>
<vertex x="5.7873" y="-10.0628"/>
<vertex x="5.7491" y="-10.0719"/>
<vertex x="4.45" y="-10.075"/>
<vertex x="4.4109" y="-10.0719"/>
<vertex x="4.3727" y="-10.0628"/>
<vertex x="4.3365" y="-10.0478"/>
<vertex x="4.3031" y="-10.0273"/>
<vertex x="4.2732" y="-10.0018"/>
<vertex x="4.2477" y="-9.9719"/>
<vertex x="4.2272" y="-9.9385"/>
<vertex x="4.2122" y="-9.9023"/>
<vertex x="4.2031" y="-9.8641"/>
<vertex x="4.2" y="-9.825"/>
</polygon>
</polygon>
<wire x1="4.23" y1="-7.975" x2="5.93" y2="-7.975" width="0.025" layer="51"/>
<wire x1="5.93" y1="-7.975" x2="5.93" y2="-9.525" width="0.025" layer="51"/>
<wire x1="5.93" y1="-9.525" x2="4.23" y2="-9.525" width="0.025" layer="51"/>
<wire x1="4.23" y1="-9.525" x2="4.23" y2="-7.975" width="0.025" layer="51"/>
<vertex x="5.96" y="8.985"/>
<vertex x="5.96" y="8.145"/>
<vertex x="5.9569" y="8.1059"/>
<vertex x="5.9478" y="8.0677"/>
<vertex x="5.9328" y="8.0315"/>
<vertex x="5.9123" y="7.9981"/>
<vertex x="5.8868" y="7.9682"/>
<vertex x="5.8569" y="7.9427"/>
<vertex x="5.8235" y="7.9222"/>
<vertex x="5.7873" y="7.9072"/>
<vertex x="5.7491" y="7.8981"/>
<vertex x="4.45" y="7.895"/>
<vertex x="4.4109" y="7.8981"/>
<vertex x="4.3727" y="7.9072"/>
<vertex x="4.3365" y="7.9222"/>
<vertex x="4.3031" y="7.9427"/>
<vertex x="4.2732" y="7.9682"/>
<vertex x="4.2477" y="7.9981"/>
<vertex x="4.2272" y="8.0315"/>
<vertex x="4.2122" y="8.0677"/>
<vertex x="4.2031" y="8.1059"/>
<vertex x="4.2" y="8.145"/>
<vertex x="4.2" y="9.825"/>
<vertex x="4.2031" y="9.8641"/>
<vertex x="4.2122" y="9.9023"/>
<vertex x="4.2272" y="9.9385"/>
<vertex x="4.2477" y="9.9719"/>
<vertex x="4.2732" y="10.0018"/>
<vertex x="4.3031" y="10.0273"/>
<vertex x="4.3365" y="10.0478"/>
<vertex x="4.3727" y="10.0628"/>
<vertex x="4.4109" y="10.0719"/>
<vertex x="5.71" y="10.075"/>
<vertex x="5.7491" y="10.0719"/>
<vertex x="5.7873" y="10.0628"/>
<vertex x="5.8235" y="10.0478"/>
<vertex x="5.8569" y="10.0273"/>
<vertex x="5.8868" y="10.0018"/>
<vertex x="5.9123" y="9.9719"/>
<vertex x="5.9328" y="9.9385"/>
<vertex x="5.9478" y="9.9023"/>
<vertex x="5.9569" y="9.8641"/>
<vertex x="5.96" y="9.825"/>
</polygon>
</polygon>
<wire x1="5.93" y1="7.975" x2="4.23" y2="7.975" width="0.025" layer="51"/>
<wire x1="4.23" y1="7.975" x2="4.23" y2="9.525" width="0.025" layer="51"/>
<wire x1="4.23" y1="9.525" x2="5.93" y2="9.525" width="0.025" layer="51"/>
<wire x1="5.93" y1="9.525" x2="5.93" y2="7.975" width="0.025" layer="51"/>
<vertex x="3.42" y="8.985"/>
<vertex x="3.42" y="8.145"/>
<vertex x="3.4169" y="8.1059"/>
<vertex x="3.4078" y="8.0677"/>
<vertex x="3.3928" y="8.0315"/>
<vertex x="3.3723" y="7.9981"/>
<vertex x="3.3468" y="7.9682"/>
<vertex x="3.3169" y="7.9427"/>
<vertex x="3.2835" y="7.9222"/>
<vertex x="3.2473" y="7.9072"/>
<vertex x="3.2091" y="7.8981"/>
<vertex x="1.91" y="7.895"/>
<vertex x="1.8709" y="7.8981"/>
<vertex x="1.8327" y="7.9072"/>
<vertex x="1.7965" y="7.9222"/>
<vertex x="1.7631" y="7.9427"/>
<vertex x="1.7332" y="7.9682"/>
<vertex x="1.7077" y="7.9981"/>
<vertex x="1.6872" y="8.0315"/>
<vertex x="1.6722" y="8.0677"/>
<vertex x="1.6631" y="8.1059"/>
<vertex x="1.66" y="8.145"/>
<vertex x="1.66" y="9.825"/>
<vertex x="1.6631" y="9.8641"/>
<vertex x="1.6722" y="9.9023"/>
<vertex x="1.6872" y="9.9385"/>
<vertex x="1.7077" y="9.9719"/>
<vertex x="1.7332" y="10.0018"/>
<vertex x="1.7631" y="10.0273"/>
<vertex x="1.7965" y="10.0478"/>
<vertex x="1.8327" y="10.0628"/>
<vertex x="1.8709" y="10.0719"/>
<vertex x="3.17" y="10.075"/>
<vertex x="3.2091" y="10.0719"/>
<vertex x="3.2473" y="10.0628"/>
<vertex x="3.2835" y="10.0478"/>
<vertex x="3.3169" y="10.0273"/>
<vertex x="3.3468" y="10.0018"/>
<vertex x="3.3723" y="9.9719"/>
<vertex x="3.3928" y="9.9385"/>
<vertex x="3.4078" y="9.9023"/>
<vertex x="3.4169" y="9.8641"/>
<vertex x="3.42" y="9.825"/>
</polygon>
</polygon>
<wire x1="3.39" y1="7.975" x2="1.69" y2="7.975" width="0.025" layer="51"/>
<wire x1="1.69" y1="7.975" x2="1.69" y2="9.525" width="0.025" layer="51"/>
<wire x1="1.69" y1="9.525" x2="3.39" y2="9.525" width="0.025" layer="51"/>
<wire x1="3.39" y1="9.525" x2="3.39" y2="7.975" width="0.025" layer="51"/>
<vertex x="0.88" y="8.985"/>
<vertex x="0.88" y="8.145"/>
<vertex x="0.8769" y="8.1059"/>
<vertex x="0.8678" y="8.0677"/>
<vertex x="0.8528" y="8.0315"/>
<vertex x="0.8323" y="7.9981"/>
<vertex x="0.8068" y="7.9682"/>
<vertex x="0.7769" y="7.9427"/>
<vertex x="0.7435" y="7.9222"/>
<vertex x="0.7073" y="7.9072"/>
<vertex x="0.6691" y="7.8981"/>
<vertex x="-0.63" y="7.895"/>
<vertex x="-0.6691" y="7.8981"/>
<vertex x="-0.7073" y="7.9072"/>
<vertex x="-0.7435" y="7.9222"/>
<vertex x="-0.7769" y="7.9427"/>
<vertex x="-0.8068" y="7.9682"/>
<vertex x="-0.8323" y="7.9981"/>
<vertex x="-0.8528" y="8.0315"/>
<vertex x="-0.8678" y="8.0677"/>
<vertex x="-0.8769" y="8.1059"/>
<vertex x="-0.88" y="8.145"/>
<vertex x="-0.88" y="9.825"/>
<vertex x="-0.8769" y="9.8641"/>
<vertex x="-0.8678" y="9.9023"/>
<vertex x="-0.8528" y="9.9385"/>
<vertex x="-0.8323" y="9.9719"/>
<vertex x="-0.8068" y="10.0018"/>
<vertex x="-0.7769" y="10.0273"/>
<vertex x="-0.7435" y="10.0478"/>
<vertex x="-0.7073" y="10.0628"/>
<vertex x="-0.6691" y="10.0719"/>
<vertex x="0.63" y="10.075"/>
<vertex x="0.6691" y="10.0719"/>
<vertex x="0.7073" y="10.0628"/>
<vertex x="0.7435" y="10.0478"/>
<vertex x="0.7769" y="10.0273"/>
<vertex x="0.8068" y="10.0018"/>
<vertex x="0.8323" y="9.9719"/>
<vertex x="0.8528" y="9.9385"/>
<vertex x="0.8678" y="9.9023"/>
<vertex x="0.8769" y="9.8641"/>
<vertex x="0.88" y="9.825"/>
</polygon>
</polygon>
<wire x1="0.85" y1="7.975" x2="-0.85" y2="7.975" width="0.025" layer="51"/>
<wire x1="-0.85" y1="7.975" x2="-0.85" y2="9.525" width="0.025" layer="51"/>
<wire x1="-0.85" y1="9.525" x2="0.85" y2="9.525" width="0.025" layer="51"/>
<wire x1="0.85" y1="9.525" x2="0.85" y2="7.975" width="0.025" layer="51"/>
<vertex x="-1.66" y="8.985"/>
<vertex x="-1.66" y="8.145"/>
<vertex x="-1.6631" y="8.1059"/>
<vertex x="-1.6722" y="8.0677"/>
<vertex x="-1.6872" y="8.0315"/>
<vertex x="-1.7077" y="7.9981"/>
<vertex x="-1.7332" y="7.9682"/>
<vertex x="-1.7631" y="7.9427"/>
<vertex x="-1.7965" y="7.9222"/>
<vertex x="-1.8327" y="7.9072"/>
<vertex x="-1.8709" y="7.8981"/>
<vertex x="-3.17" y="7.895"/>
<vertex x="-3.2091" y="7.8981"/>
<vertex x="-3.2473" y="7.9072"/>
<vertex x="-3.2835" y="7.9222"/>
<vertex x="-3.3169" y="7.9427"/>
<vertex x="-3.3468" y="7.9682"/>
<vertex x="-3.3723" y="7.9981"/>
<vertex x="-3.3928" y="8.0315"/>
<vertex x="-3.4078" y="8.0677"/>
<vertex x="-3.4169" y="8.1059"/>
<vertex x="-3.42" y="8.145"/>
<vertex x="-3.42" y="9.825"/>
<vertex x="-3.4169" y="9.8641"/>
<vertex x="-3.4078" y="9.9023"/>
<vertex x="-3.3928" y="9.9385"/>
<vertex x="-3.3723" y="9.9719"/>
<vertex x="-3.3468" y="10.0018"/>
<vertex x="-3.3169" y="10.0273"/>
<vertex x="-3.2835" y="10.0478"/>
<vertex x="-3.2473" y="10.0628"/>
<vertex x="-3.2091" y="10.0719"/>
<vertex x="-1.91" y="10.075"/>
<vertex x="-1.8709" y="10.0719"/>
<vertex x="-1.8327" y="10.0628"/>
<vertex x="-1.7965" y="10.0478"/>
<vertex x="-1.7631" y="10.0273"/>
<vertex x="-1.7332" y="10.0018"/>
<vertex x="-1.7077" y="9.9719"/>
<vertex x="-1.6872" y="9.9385"/>
<vertex x="-1.6722" y="9.9023"/>
<vertex x="-1.6631" y="9.8641"/>
<vertex x="-1.66" y="9.825"/>
</polygon>
</polygon>
<wire x1="-1.69" y1="7.975" x2="-3.39" y2="7.975" width="0.025" layer="51"/>
<wire x1="-3.39" y1="7.975" x2="-3.39" y2="9.525" width="0.025" layer="51"/>
<wire x1="-3.39" y1="9.525" x2="-1.69" y2="9.525" width="0.025" layer="51"/>
<wire x1="-1.69" y1="9.525" x2="-1.69" y2="7.975" width="0.025" layer="51"/>
<vertex x="-4.2" y="8.985"/>
<vertex x="-4.2" y="8.145"/>
<vertex x="-4.2031" y="8.1059"/>
<vertex x="-4.2122" y="8.0677"/>
<vertex x="-4.2272" y="8.0315"/>
<vertex x="-4.2477" y="7.9981"/>
<vertex x="-4.2732" y="7.9682"/>
<vertex x="-4.3031" y="7.9427"/>
<vertex x="-4.3365" y="7.9222"/>
<vertex x="-4.3727" y="7.9072"/>
<vertex x="-4.4109" y="7.8981"/>
<vertex x="-5.71" y="7.895"/>
<vertex x="-5.7491" y="7.8981"/>
<vertex x="-5.7873" y="7.9072"/>
<vertex x="-5.8235" y="7.9222"/>
<vertex x="-5.8569" y="7.9427"/>
<vertex x="-5.8868" y="7.9682"/>
<vertex x="-5.9123" y="7.9981"/>
<vertex x="-5.9328" y="8.0315"/>
<vertex x="-5.9478" y="8.0677"/>
<vertex x="-5.9569" y="8.1059"/>
<vertex x="-5.96" y="8.145"/>
<vertex x="-5.96" y="9.825"/>
<vertex x="-5.9569" y="9.8641"/>
<vertex x="-5.9478" y="9.9023"/>
<vertex x="-5.9328" y="9.9385"/>
<vertex x="-5.9123" y="9.9719"/>
<vertex x="-5.8868" y="10.0018"/>
<vertex x="-5.8569" y="10.0273"/>
<vertex x="-5.8235" y="10.0478"/>
<vertex x="-5.7873" y="10.0628"/>
<vertex x="-5.7491" y="10.0719"/>
<vertex x="-4.45" y="10.075"/>
<vertex x="-4.4109" y="10.0719"/>
<vertex x="-4.3727" y="10.0628"/>
<vertex x="-4.3365" y="10.0478"/>
<vertex x="-4.3031" y="10.0273"/>
<vertex x="-4.2732" y="10.0018"/>
<vertex x="-4.2477" y="9.9719"/>
<vertex x="-4.2272" y="9.9385"/>
<vertex x="-4.2122" y="9.9023"/>
<vertex x="-4.2031" y="9.8641"/>
<vertex x="-4.2" y="9.825"/>
</polygon>
</polygon>
<wire x1="-4.23" y1="7.975" x2="-5.93" y2="7.975" width="0.025" layer="51"/>
<wire x1="-5.93" y1="7.975" x2="-5.93" y2="9.525" width="0.025" layer="51"/>
<wire x1="-5.93" y1="9.525" x2="-4.23" y2="9.525" width="0.025" layer="51"/>
<wire x1="-4.23" y1="9.525" x2="-4.23" y2="7.975" width="0.025" layer="51"/>
<wire x1="-6.2" y1="-9.525" x2="-6.2" y2="9.525" width="0.025" layer="51"/>
<wire x1="-6.2" y1="9.525" x2="6.2" y2="9.525" width="0.025" layer="51"/>
<wire x1="6.2" y1="9.525" x2="6.2" y2="-9.525" width="0.025" layer="51"/>
<wire x1="6.2" y1="-9.525" x2="-6.2" y2="-9.525" width="0.025" layer="51"/>
<wire x1="-6.25" y1="-9.55" x2="-6.25" y2="9.55" width="0.12" layer="51"/>
<wire x1="-6.25" y1="9.55" x2="6.25" y2="9.55" width="0.12" layer="51"/>
<wire x1="6.25" y1="9.55" x2="6.25" y2="-9.55" width="0.12" layer="51"/>
<wire x1="6.25" y1="-9.55" x2="-6.25" y2="-9.55" width="0.12" layer="51"/>
<circle x="0" y="0" radius="0.25" width="0.05" layer="39"/>
<wire x1="0" y1="0.35" x2="0" y2="-0.35" width="0.05" layer="39"/>
<wire x1="-0.35" y1="0" x2="0.35" y2="0" width="0.05" layer="39"/>
<wire x1="-6.25" y1="-9.55" x2="-6.25" y2="9.55" width="0.12" layer="21"/>
<wire x1="6.25" y1="-9.55" x2="6.25" y2="9.55" width="0.12" layer="21"/>
<wire x1="6.45" y1="-9.75" x2="6.45" y2="9.75" width="0.05" layer="39"/>
<wire x1="6.45" y1="9.75" x2="6.16" y2="9.75" width="0.05" layer="39"/>
<wire x1="6.16" y1="9.75" x2="6.16" y2="10.275" width="0.05" layer="39"/>
<wire x1="6.16" y1="10.275" x2="-6.16" y2="10.275" width="0.05" layer="39"/>
<wire x1="-6.16" y1="10.275" x2="-6.16" y2="9.75" width="0.05" layer="39"/>
<wire x1="-6.16" y1="9.75" x2="-6.45" y2="9.75" width="0.05" layer="39"/>
<wire x1="-6.45" y1="9.75" x2="-6.45" y2="-9.75" width="0.05" layer="39"/>
<wire x1="-6.45" y1="-9.75" x2="-6.16" y2="-9.75" width="0.05" layer="39"/>
<wire x1="-6.16" y1="-9.75" x2="-6.16" y2="-10.275" width="0.05" layer="39"/>
<wire x1="-6.16" y1="-10.275" x2="6.16" y2="-10.275" width="0.05" layer="39"/>
<wire x1="6.16" y1="-10.275" x2="6.16" y2="-9.75" width="0.05" layer="39"/>
<wire x1="6.16" y1="-9.75" x2="6.45" y2="-9.75" width="0.05" layer="39"/>
<text x="7.62" y="-6.35" size="1.2" layer="27" font="vector" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-6.35" y="-6.35" size="1.2" layer="25" font="vector" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="DIP">
</package>
<package name="DIPS1524W81P254L1243H350Q10">
<description>DIPS, 15.24 mm lead span, 2.54 mm pitch; 10 pin, 12.43 mm L X 17.50 mm W X 3.50 mm H body&lt;p&gt;&lt;i&gt;PCB Libraries Packages&lt;/i&gt;</description>
<pad name="1" x="-5.08" y="-7.62" drill="1.02" diameter="1.53" shape="square" rot="R90" first="yes"/>
<pad name="2" x="-2.54" y="-7.62" drill="1.02" diameter="1.53"/>
<pad name="3" x="0" y="-7.62" drill="1.02" diameter="1.53"/>
<pad name="4" x="2.54" y="-7.62" drill="1.02" diameter="1.53"/>
<pad name="5" x="5.08" y="-7.62" drill="1.02" diameter="1.53"/>
<pad name="6" x="5.08" y="7.62" drill="1.02" diameter="1.53"/>
<pad name="7" x="2.54" y="7.62" drill="1.02" diameter="1.53"/>
<pad name="8" x="0" y="7.62" drill="1.02" diameter="1.53"/>
<pad name="9" x="-2.54" y="7.62" drill="1.02" diameter="1.53"/>
<pad name="10" x="-5.08" y="7.62" drill="1.02" diameter="1.53"/>
<circle x="-5.08" y="-7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="-2.54" y="-7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="0" y="-7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="2.54" y="-7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="5.08" y="-7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="5.08" y="7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="2.54" y="7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="0" y="7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="-2.54" y="7.62" radius="0.41" width="0.025" layer="51"/>
<circle x="-5.08" y="7.62" radius="0.41" width="0.025" layer="51"/>
<wire x1="-6.215" y1="-8.75" x2="-6.215" y2="8.75" width="0.025" layer="51"/>
<wire x1="-6.215" y1="8.75" x2="6.215" y2="8.75" width="0.025" layer="51"/>
<wire x1="6.215" y1="8.75" x2="6.215" y2="-8.75" width="0.025" layer="51"/>
<wire x1="6.215" y1="-8.75" x2="-6.215" y2="-8.75" width="0.025" layer="51"/>
<wire x1="-6.22" y1="-8.75" x2="-6.22" y2="8.75" width="0.12" layer="51"/>
<wire x1="-6.22" y1="8.75" x2="6.22" y2="8.75" width="0.12" layer="21"/>
<wire x1="6.22" y1="8.75" x2="6.22" y2="-8.75" width="0.12" layer="51"/>
<wire x1="6.22" y1="-8.75" x2="-6.22" y2="-8.75" width="0.12" layer="21"/>
<wire x1="6.47" y1="-9" x2="6.47" y2="9" width="0.05" layer="39"/>
<wire x1="6.47" y1="9" x2="-6.47" y2="9" width="0.05" layer="39"/>
<wire x1="-6.47" y1="9" x2="-6.47" y2="-9" width="0.05" layer="39"/>
<wire x1="-6.47" y1="-9" x2="6.47" y2="-9" width="0.05" layer="39"/>
<wire x1="-6.22" y1="-8.75" x2="-6.22" y2="8.75" width="0.12" layer="21"/>
<wire x1="6.22" y1="-8.75" x2="6.22" y2="8.75" width="0.12" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="7SEG">
<pin name="E" x="-5.08" y="-10.16" visible="pin" length="middle" rot="R90"/>
<pin name="D" x="-2.54" y="-10.16" visible="pin" length="middle" rot="R90"/>
<pin name="P$3" x="0" y="-10.16" visible="off" length="middle" rot="R90"/>
<pin name="C" x="2.54" y="-10.16" visible="pin" length="middle" rot="R90"/>
<pin name="DP" x="5.08" y="-10.16" visible="pin" length="middle" rot="R90"/>
<pin name="B" x="5.08" y="10.16" visible="pin" length="middle" rot="R270"/>
<pin name="A" x="2.54" y="10.16" visible="pin" length="middle" rot="R270"/>
<pin name="P$8" x="0" y="10.16" visible="off" length="middle" rot="R270"/>
<pin name="F" x="-2.54" y="10.16" visible="pin" length="middle" rot="R270"/>
<pin name="G" x="-5.08" y="10.16" visible="pin" length="middle" rot="R270"/>
<wire x1="-7.62" y1="5.08" x2="-7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-7.62" y2="5.08" width="0.254" layer="94"/>
<text x="-2.032" y="-0.508" size="1.27" layer="94" font="vector" ratio="10">7Seg</text>
<text x="-5.588" y="-4.572" size="1.27" layer="94" font="vector" ratio="10">1</text>
<text x="-6.096" y="3.302" size="1.27" layer="94" font="vector" ratio="10">10</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="7SEG">
<gates>
<gate name="G$1" symbol="7SEG" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="ICCAF10P254_1240X1905X375L155X170N">
<connects>
<connect gate="G$1" pin="A" pad="7"/>
<connect gate="G$1" pin="B" pad="6"/>
<connect gate="G$1" pin="C" pad="4"/>
<connect gate="G$1" pin="D" pad="2"/>
<connect gate="G$1" pin="DP" pad="5"/>
<connect gate="G$1" pin="E" pad="1"/>
<connect gate="G$1" pin="F" pad="9"/>
<connect gate="G$1" pin="G" pad="10"/>
<connect gate="G$1" pin="P$3" pad="3"/>
<connect gate="G$1" pin="P$8" pad="8"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DIP" package="DIPS1524W81P254L1243H350Q10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
