<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="yes" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="yes" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="yes" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="yes" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="yes" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="yes" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="yes" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="yes" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="yes" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="yes" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="yes" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="yes" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="no" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="no" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find non-functional items- supply symbols, logos, notations, frame blocks, etc.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt; Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="CREATIVE_COMMONS">
<text x="-20.32" y="5.08" size="1.778" layer="51">Released under the Creative Commons Attribution Share-Alike 4.0 License</text>
<text x="0" y="2.54" size="1.778" layer="51"> https://creativecommons.org/licenses/by-sa/4.0/</text>
<text x="11.43" y="0" size="1.778" layer="51">Designed by:</text>
</package>
<package name="FIDUCIAL-1X2">
<smd name="1" x="0" y="0" dx="1" dy="1" layer="1" roundness="100" cream="no"/>
</package>
<package name="MICRO-FIDUCIAL">
<smd name="1" x="0" y="0" dx="0.635" dy="0.635" layer="1" roundness="100" cream="no"/>
</package>
<package name="FIDUCIALTAB">
<description>This is half of a tab, with fiducial reference mark, used to connect individual boards in a panel of PCBs.
Two of these half tabs, rotated in opposite directions, can be connected together to form a full tab, with two fiducial markings. Place along the edge of a panel of PCBs, this will allow for panels with boards not connected by v-scores, which allows for easier depanelization where there are overhanging components. It can also be used for designs too small to accomodate fiducial marks on individual boards.</description>
<wire x1="3.81" y1="2.54" x2="3.81" y2="21.59" width="0.2032" layer="20"/>
<wire x1="3.81" y1="21.59" x2="3.81" y2="88.9" width="0.2032" layer="20"/>
<wire x1="0" y1="0" x2="3.81" y2="0" width="0.2032" layer="20"/>
<wire x1="3.81" y1="0" x2="3.81" y2="21.59" width="0.2032" layer="20"/>
<wire x1="0" y1="0" x2="0" y2="22.86" width="0.2032" layer="20"/>
<smd name="P$2" x="1.905" y="4.064" dx="1" dy="1" layer="1" roundness="100"/>
</package>
<package name="FUNNEL_LOGO_BOTTOM_V2">
<wire x1="2.7432" y1="-3.429" x2="-2.8448" y2="-3.429" width="0.5334" layer="22"/>
<wire x1="-2.8448" y1="-3.429" x2="-2.8956" y2="-3.429" width="0.5334" layer="22"/>
<wire x1="-3.4544" y1="2.8448" x2="-3.4544" y2="-2.6924" width="0.5334" layer="22"/>
<wire x1="3.4798" y1="2.7432" x2="3.4798" y2="-2.8194" width="0.5334" layer="22"/>
<wire x1="2.8448" y1="3.4798" x2="-2.6924" y2="3.4798" width="0.5334" layer="22"/>
<wire x1="2.8448" y1="3.4798" x2="3.4798" y2="2.7432" width="0.5334" layer="22" curve="-90.046689"/>
<wire x1="-3.4544" y1="2.8448" x2="-2.7178" y2="3.4798" width="0.5334" layer="22" curve="-90.046689"/>
<wire x1="-2.8448" y1="-3.429" x2="-3.4544" y2="-2.7178" width="0.5334" layer="22" curve="-90.048358"/>
<wire x1="3.4798" y1="-2.794" x2="2.7432" y2="-3.429" width="0.5334" layer="22" curve="-90.046689"/>
<wire x1="0" y1="-0.0762" x2="3.2512" y2="3.2004" width="0.6096" layer="22"/>
<wire x1="0.0254" y1="-0.1016" x2="-3.2512" y2="3.1496" width="0.6096" layer="22"/>
<wire x1="-2.7686" y1="2.6924" x2="-3.0734" y2="3.302" width="0.5588" layer="22"/>
<wire x1="2.8194" y1="2.794" x2="2.9972" y2="3.3528" width="0.5588" layer="22"/>
<wire x1="0" y1="0.1524" x2="0" y2="-1.905" width="0.6096" layer="22"/>
<wire x1="0.127" y1="0.2286" x2="-0.1778" y2="0.2286" width="0.6096" layer="22"/>
<polygon width="0.0254" layer="22">
<vertex x="0.2896" y="-1.9304"/>
<vertex x="0.2896" y="-2.3368"/>
<vertex x="0.1778" y="-2.3368"/>
<vertex x="-0.2921" y="-2.1056"/>
<vertex x="-0.2921" y="-1.9278"/>
</polygon>
</package>
<package name="FKIT-LOGO_MEDIUM">
<rectangle x1="-0.4382" y1="-3.4862" x2="0.3007" y2="-3.4403" layer="21"/>
<rectangle x1="-0.7615" y1="-3.4403" x2="0.6241" y2="-3.394" layer="21"/>
<rectangle x1="-0.9462" y1="-3.394" x2="0.8087" y2="-3.3478" layer="21"/>
<rectangle x1="-1.0849" y1="-3.3478" x2="0.9934" y2="-3.3016" layer="21"/>
<rectangle x1="-1.2695" y1="-3.3016" x2="1.1321" y2="-3.2554" layer="21"/>
<rectangle x1="-1.362" y1="-3.2554" x2="1.2705" y2="-3.2091" layer="21"/>
<rectangle x1="-1.5004" y1="-3.2091" x2="1.3629" y2="-3.1632" layer="21"/>
<rectangle x1="-1.5929" y1="-3.1632" x2="1.4551" y2="-3.1169" layer="21"/>
<rectangle x1="-1.6851" y1="-3.1169" x2="1.5476" y2="-3.0707" layer="21"/>
<rectangle x1="-1.7775" y1="-3.0707" x2="1.6401" y2="-3.0245" layer="21"/>
<rectangle x1="-1.87" y1="-3.0245" x2="1.7323" y2="-2.9782" layer="21"/>
<rectangle x1="-1.9159" y1="-2.9782" x2="1.8247" y2="-2.9323" layer="21"/>
<rectangle x1="-2.0084" y1="-2.9323" x2="1.8709" y2="-2.886" layer="21"/>
<rectangle x1="-2.0546" y1="-2.886" x2="1.8709" y2="-2.8398" layer="21"/>
<rectangle x1="-2.1468" y1="-2.8398" x2="1.8247" y2="-2.7936" layer="21"/>
<rectangle x1="-2.1931" y1="-2.7936" x2="1.7785" y2="-2.7474" layer="21"/>
<rectangle x1="-2.2855" y1="-2.7474" x2="1.7323" y2="-2.7011" layer="21"/>
<rectangle x1="-2.3317" y1="-2.7011" x2="1.686" y2="-2.6552" layer="21"/>
<rectangle x1="-2.378" y1="-2.6552" x2="1.6401" y2="-2.6089" layer="21"/>
<rectangle x1="-2.4239" y1="-2.6089" x2="1.5938" y2="-2.5627" layer="21"/>
<rectangle x1="-2.4702" y1="-2.5627" x2="1.5476" y2="-2.5165" layer="21"/>
<rectangle x1="-2.5164" y1="-2.5165" x2="1.5014" y2="-2.4702" layer="21"/>
<rectangle x1="-2.5626" y1="-2.4702" x2="1.4551" y2="-2.4243" layer="21"/>
<rectangle x1="-2.6089" y1="-2.4243" x2="1.4092" y2="-2.378" layer="21"/>
<rectangle x1="-2.6548" y1="-2.378" x2="1.3629" y2="-2.3318" layer="21"/>
<rectangle x1="-2.7011" y1="-2.3318" x2="1.3629" y2="-2.2856" layer="21"/>
<rectangle x1="-2.7473" y1="-2.2856" x2="1.4551" y2="-2.2394" layer="21"/>
<rectangle x1="-2.7935" y1="-2.2394" x2="1.5476" y2="-2.1931" layer="21"/>
<rectangle x1="-2.8397" y1="-2.1931" x2="1.5938" y2="-2.1472" layer="21"/>
<rectangle x1="-2.886" y1="-2.1472" x2="1.6401" y2="-2.1009" layer="21"/>
<rectangle x1="-2.886" y1="-2.1009" x2="1.7323" y2="-2.0547" layer="21"/>
<rectangle x1="-2.9319" y1="-2.0547" x2="1.0858" y2="-2.0085" layer="21"/>
<rectangle x1="1.4092" y1="-2.0547" x2="1.7785" y2="-2.0085" layer="21"/>
<rectangle x1="-2.9782" y1="-2.0085" x2="0.9934" y2="-1.9622" layer="21"/>
<rectangle x1="1.5014" y1="-2.0085" x2="1.8247" y2="-1.9622" layer="21"/>
<rectangle x1="-3.0244" y1="-1.9622" x2="0.9471" y2="-1.9163" layer="21"/>
<rectangle x1="1.5476" y1="-1.9622" x2="1.8709" y2="-1.9163" layer="21"/>
<rectangle x1="-3.0244" y1="-1.9163" x2="0.9012" y2="-1.87" layer="21"/>
<rectangle x1="1.5938" y1="-1.9163" x2="1.9172" y2="-1.87" layer="21"/>
<rectangle x1="2.8869" y1="-1.9163" x2="2.9332" y2="-1.87" layer="21"/>
<rectangle x1="-3.0706" y1="-1.87" x2="0.8549" y2="-1.8238" layer="21"/>
<rectangle x1="1.6401" y1="-1.87" x2="1.9631" y2="-1.8238" layer="21"/>
<rectangle x1="2.8407" y1="-1.87" x2="2.9332" y2="-1.8238" layer="21"/>
<rectangle x1="-3.1169" y1="-1.8238" x2="-1.2233" y2="-1.7776" layer="21"/>
<rectangle x1="-0.8999" y1="-1.8238" x2="0.8087" y2="-1.7776" layer="21"/>
<rectangle x1="1.686" y1="-1.8238" x2="2.0094" y2="-1.7776" layer="21"/>
<rectangle x1="2.7945" y1="-1.8238" x2="2.9791" y2="-1.7776" layer="21"/>
<rectangle x1="-3.1169" y1="-1.7776" x2="-1.3157" y2="-1.7314" layer="21"/>
<rectangle x1="-0.8077" y1="-1.7776" x2="0.7625" y2="-1.7314" layer="21"/>
<rectangle x1="1.7323" y1="-1.7776" x2="2.0556" y2="-1.7314" layer="21"/>
<rectangle x1="2.7483" y1="-1.7776" x2="3.0254" y2="-1.7314" layer="21"/>
<rectangle x1="-3.1628" y1="-1.7314" x2="-1.362" y2="-1.6851" layer="21"/>
<rectangle x1="-0.7615" y1="-1.7314" x2="0.7163" y2="-1.6851" layer="21"/>
<rectangle x1="1.7785" y1="-1.7314" x2="2.1018" y2="-1.6851" layer="21"/>
<rectangle x1="2.702" y1="-1.7314" x2="3.0254" y2="-1.6851" layer="21"/>
<rectangle x1="-3.2091" y1="-1.6851" x2="-1.4079" y2="-1.6392" layer="21"/>
<rectangle x1="-0.7153" y1="-1.6851" x2="0.67" y2="-1.6392" layer="21"/>
<rectangle x1="1.8247" y1="-1.6851" x2="2.1481" y2="-1.6392" layer="21"/>
<rectangle x1="2.6561" y1="-1.6851" x2="3.0716" y2="-1.6392" layer="21"/>
<rectangle x1="-3.2091" y1="-1.6392" x2="-1.4542" y2="-1.5929" layer="21"/>
<rectangle x1="-0.6691" y1="-1.6392" x2="0.6241" y2="-1.5929" layer="21"/>
<rectangle x1="1.8709" y1="-1.6392" x2="2.1481" y2="-1.5929" layer="21"/>
<rectangle x1="2.6098" y1="-1.6392" x2="3.0716" y2="-1.5929" layer="21"/>
<rectangle x1="-3.2553" y1="-1.5929" x2="-1.5004" y2="-1.5467" layer="21"/>
<rectangle x1="-0.6228" y1="-1.5929" x2="0.5778" y2="-1.5467" layer="21"/>
<rectangle x1="1.9172" y1="-1.5929" x2="2.194" y2="-1.5467" layer="21"/>
<rectangle x1="2.5636" y1="-1.5929" x2="3.1178" y2="-1.5467" layer="21"/>
<rectangle x1="-3.2553" y1="-1.5467" x2="-1.5466" y2="-1.5005" layer="21"/>
<rectangle x1="-0.5769" y1="-1.5467" x2="0.5316" y2="-1.5005" layer="21"/>
<rectangle x1="1.9631" y1="-1.5467" x2="2.2403" y2="-1.5005" layer="21"/>
<rectangle x1="2.5174" y1="-1.5467" x2="3.1641" y2="-1.5005" layer="21"/>
<rectangle x1="-3.3015" y1="-1.5005" x2="-1.5929" y2="-1.4542" layer="21"/>
<rectangle x1="-0.5306" y1="-1.5005" x2="0.4854" y2="-1.4542" layer="21"/>
<rectangle x1="2.0094" y1="-1.5005" x2="2.2865" y2="-1.4542" layer="21"/>
<rectangle x1="2.4711" y1="-1.5005" x2="3.1641" y2="-1.4542" layer="21"/>
<rectangle x1="-3.3015" y1="-1.4542" x2="-1.6388" y2="-1.4083" layer="21"/>
<rectangle x1="-0.4844" y1="-1.4542" x2="0.4391" y2="-1.4083" layer="21"/>
<rectangle x1="2.0094" y1="-1.4542" x2="2.2865" y2="-1.4083" layer="21"/>
<rectangle x1="2.4252" y1="-1.4542" x2="3.21" y2="-1.4083" layer="21"/>
<rectangle x1="-3.3477" y1="-1.4083" x2="-1.6851" y2="-1.362" layer="21"/>
<rectangle x1="-0.4382" y1="-1.4083" x2="0.3932" y2="-1.362" layer="21"/>
<rectangle x1="2.0094" y1="-1.4083" x2="2.3327" y2="-1.362" layer="21"/>
<rectangle x1="2.3789" y1="-1.4083" x2="3.21" y2="-1.362" layer="21"/>
<rectangle x1="-3.3477" y1="-1.362" x2="-1.7313" y2="-1.3158" layer="21"/>
<rectangle x1="-0.3919" y1="-1.362" x2="0.3469" y2="-1.3158" layer="21"/>
<rectangle x1="2.0556" y1="-1.362" x2="3.21" y2="-1.3158" layer="21"/>
<rectangle x1="-3.394" y1="-1.3158" x2="-1.7775" y2="-1.2696" layer="21"/>
<rectangle x1="-0.346" y1="-1.3158" x2="0.3007" y2="-1.2696" layer="21"/>
<rectangle x1="2.0556" y1="-1.3158" x2="3.2563" y2="-1.2696" layer="21"/>
<rectangle x1="-3.394" y1="-1.2696" x2="-1.8237" y2="-1.2234" layer="21"/>
<rectangle x1="-0.2997" y1="-1.2696" x2="0.2545" y2="-1.2234" layer="21"/>
<rectangle x1="2.0556" y1="-1.2696" x2="3.2563" y2="-1.2234" layer="21"/>
<rectangle x1="-3.394" y1="-1.2234" x2="-1.8237" y2="-1.1771" layer="21"/>
<rectangle x1="-0.2535" y1="-1.2234" x2="0.162" y2="-1.1771" layer="21"/>
<rectangle x1="2.0556" y1="-1.2234" x2="3.3025" y2="-1.1771" layer="21"/>
<rectangle x1="-3.4399" y1="-1.1771" x2="-1.8237" y2="-1.1312" layer="21"/>
<rectangle x1="-0.1611" y1="-1.1771" x2="0.1161" y2="-1.1312" layer="21"/>
<rectangle x1="2.0556" y1="-1.1771" x2="3.3025" y2="-1.1312" layer="21"/>
<rectangle x1="-3.4399" y1="-1.1312" x2="-1.87" y2="-1.0849" layer="21"/>
<rectangle x1="2.0094" y1="-1.1312" x2="3.3025" y2="-1.0849" layer="21"/>
<rectangle x1="-3.4862" y1="-1.0849" x2="-1.87" y2="-1.0387" layer="21"/>
<rectangle x1="2.0094" y1="-1.0849" x2="3.3487" y2="-1.0387" layer="21"/>
<rectangle x1="-3.4862" y1="-1.0387" x2="-1.87" y2="-0.9925" layer="21"/>
<rectangle x1="1.9631" y1="-1.0387" x2="3.3487" y2="-0.9925" layer="21"/>
<rectangle x1="-3.4862" y1="-0.9925" x2="-1.87" y2="-0.9462" layer="21"/>
<rectangle x1="1.9172" y1="-0.9925" x2="3.3487" y2="-0.9462" layer="21"/>
<rectangle x1="-3.4862" y1="-0.9462" x2="-1.87" y2="-0.9003" layer="21"/>
<rectangle x1="1.9172" y1="-0.9462" x2="3.3949" y2="-0.9003" layer="21"/>
<rectangle x1="-3.5324" y1="-0.9003" x2="-1.8237" y2="-0.854" layer="21"/>
<rectangle x1="1.8709" y1="-0.9003" x2="3.3949" y2="-0.854" layer="21"/>
<rectangle x1="-3.5324" y1="-0.854" x2="-1.8237" y2="-0.8078" layer="21"/>
<rectangle x1="1.8247" y1="-0.854" x2="3.3949" y2="-0.8078" layer="21"/>
<rectangle x1="-3.5324" y1="-0.8078" x2="-1.8237" y2="-0.7616" layer="21"/>
<rectangle x1="1.7785" y1="-0.8078" x2="3.4412" y2="-0.7616" layer="21"/>
<rectangle x1="-3.5786" y1="-0.7616" x2="-1.7775" y2="-0.7154" layer="21"/>
<rectangle x1="1.7323" y1="-0.7616" x2="3.4412" y2="-0.7154" layer="21"/>
<rectangle x1="-3.5786" y1="-0.7154" x2="-1.7313" y2="-0.6691" layer="21"/>
<rectangle x1="1.686" y1="-0.7154" x2="3.4412" y2="-0.6691" layer="21"/>
<rectangle x1="-3.5786" y1="-0.6691" x2="-1.6851" y2="-0.6232" layer="21"/>
<rectangle x1="1.6401" y1="-0.6691" x2="3.4412" y2="-0.6232" layer="21"/>
<rectangle x1="-3.5786" y1="-0.6232" x2="-1.6388" y2="-0.5769" layer="21"/>
<rectangle x1="1.5938" y1="-0.6232" x2="3.4871" y2="-0.5769" layer="21"/>
<rectangle x1="-3.5786" y1="-0.5769" x2="-1.5929" y2="-0.5307" layer="21"/>
<rectangle x1="1.5476" y1="-0.5769" x2="3.4871" y2="-0.5307" layer="21"/>
<rectangle x1="-3.6249" y1="-0.5307" x2="-1.5466" y2="-0.4845" layer="21"/>
<rectangle x1="1.5014" y1="-0.5307" x2="3.4871" y2="-0.4845" layer="21"/>
<rectangle x1="-3.6249" y1="-0.4845" x2="-1.5004" y2="-0.4382" layer="21"/>
<rectangle x1="1.4551" y1="-0.4845" x2="3.4871" y2="-0.4382" layer="21"/>
<rectangle x1="-3.6249" y1="-0.4382" x2="-1.4542" y2="-0.3923" layer="21"/>
<rectangle x1="1.4092" y1="-0.4382" x2="3.4871" y2="-0.3923" layer="21"/>
<rectangle x1="-3.6249" y1="-0.3923" x2="-1.4079" y2="-0.346" layer="21"/>
<rectangle x1="1.3629" y1="-0.3923" x2="3.4871" y2="-0.346" layer="21"/>
<rectangle x1="-3.6249" y1="-0.346" x2="-1.362" y2="-0.2998" layer="21"/>
<rectangle x1="1.3167" y1="-0.346" x2="3.5334" y2="-0.2998" layer="21"/>
<rectangle x1="-3.6249" y1="-0.2998" x2="-1.3157" y2="-0.2536" layer="21"/>
<rectangle x1="1.2705" y1="-0.2998" x2="3.5334" y2="-0.2536" layer="21"/>
<rectangle x1="-3.6708" y1="-0.2536" x2="-1.2695" y2="-0.2074" layer="21"/>
<rectangle x1="1.2243" y1="-0.2536" x2="3.5334" y2="-0.2074" layer="21"/>
<rectangle x1="-3.6708" y1="-0.2074" x2="-1.2233" y2="-0.1611" layer="21"/>
<rectangle x1="1.178" y1="-0.2074" x2="3.5334" y2="-0.1611" layer="21"/>
<rectangle x1="-3.6708" y1="-0.1611" x2="-1.2233" y2="-0.1152" layer="21"/>
<rectangle x1="1.1321" y1="-0.1611" x2="3.5334" y2="-0.1152" layer="21"/>
<rectangle x1="-3.6708" y1="-0.1152" x2="-1.1771" y2="-0.0689" layer="21"/>
<rectangle x1="1.1321" y1="-0.1152" x2="3.5334" y2="-0.0689" layer="21"/>
<rectangle x1="-3.6708" y1="-0.0689" x2="-1.1771" y2="-0.0227" layer="21"/>
<rectangle x1="1.1321" y1="-0.0689" x2="3.5334" y2="-0.0227" layer="21"/>
<rectangle x1="-3.6708" y1="-0.0227" x2="-1.1771" y2="0.0235" layer="21"/>
<rectangle x1="1.0858" y1="-0.0227" x2="3.5334" y2="0.0235" layer="21"/>
<rectangle x1="-3.6708" y1="0.0235" x2="-1.1771" y2="0.0698" layer="21"/>
<rectangle x1="1.1321" y1="0.0235" x2="3.5334" y2="0.0698" layer="21"/>
<rectangle x1="-3.6708" y1="0.0698" x2="-1.1771" y2="0.1157" layer="21"/>
<rectangle x1="1.1321" y1="0.0698" x2="3.5334" y2="0.1157" layer="21"/>
<rectangle x1="-3.6708" y1="0.1157" x2="-1.1771" y2="0.162" layer="21"/>
<rectangle x1="1.1321" y1="0.1157" x2="3.5334" y2="0.162" layer="21"/>
<rectangle x1="-3.6708" y1="0.162" x2="-1.2233" y2="0.2082" layer="21"/>
<rectangle x1="1.178" y1="0.162" x2="3.5334" y2="0.2082" layer="21"/>
<rectangle x1="-3.6708" y1="0.2082" x2="-1.2695" y2="0.2544" layer="21"/>
<rectangle x1="1.178" y1="0.2082" x2="3.5334" y2="0.2544" layer="21"/>
<rectangle x1="-3.6708" y1="0.2544" x2="-1.2695" y2="0.3006" layer="21"/>
<rectangle x1="1.2243" y1="0.2544" x2="3.5334" y2="0.3006" layer="21"/>
<rectangle x1="-3.6708" y1="0.3006" x2="-1.3157" y2="0.3469" layer="21"/>
<rectangle x1="1.2705" y1="0.3006" x2="3.5334" y2="0.3469" layer="21"/>
<rectangle x1="-3.6708" y1="0.3469" x2="-1.362" y2="0.3928" layer="21"/>
<rectangle x1="1.3167" y1="0.3469" x2="3.5334" y2="0.3928" layer="21"/>
<rectangle x1="-3.6708" y1="0.3928" x2="-1.4079" y2="0.4391" layer="21"/>
<rectangle x1="1.3629" y1="0.3928" x2="3.5334" y2="0.4391" layer="21"/>
<rectangle x1="-3.6708" y1="0.4391" x2="-1.4542" y2="0.4853" layer="21"/>
<rectangle x1="1.4092" y1="0.4391" x2="3.5334" y2="0.4853" layer="21"/>
<rectangle x1="-3.6249" y1="0.4853" x2="-1.5004" y2="0.5315" layer="21"/>
<rectangle x1="1.4551" y1="0.4853" x2="3.5334" y2="0.5315" layer="21"/>
<rectangle x1="-3.6249" y1="0.5315" x2="-1.5466" y2="0.5778" layer="21"/>
<rectangle x1="1.5014" y1="0.5315" x2="3.5334" y2="0.5778" layer="21"/>
<rectangle x1="-3.6249" y1="0.5778" x2="-1.5929" y2="0.6237" layer="21"/>
<rectangle x1="1.5476" y1="0.5778" x2="3.5334" y2="0.6237" layer="21"/>
<rectangle x1="-3.6249" y1="0.6237" x2="-1.6388" y2="0.67" layer="21"/>
<rectangle x1="1.5938" y1="0.6237" x2="3.4871" y2="0.67" layer="21"/>
<rectangle x1="-3.6249" y1="0.67" x2="-1.6851" y2="0.7162" layer="21"/>
<rectangle x1="1.6401" y1="0.67" x2="3.4871" y2="0.7162" layer="21"/>
<rectangle x1="-3.6249" y1="0.7162" x2="-1.7313" y2="0.7624" layer="21"/>
<rectangle x1="1.686" y1="0.7162" x2="3.4871" y2="0.7624" layer="21"/>
<rectangle x1="-3.6249" y1="0.7624" x2="-1.7775" y2="0.8086" layer="21"/>
<rectangle x1="1.7323" y1="0.7624" x2="3.4871" y2="0.8086" layer="21"/>
<rectangle x1="-3.5786" y1="0.8086" x2="-1.8237" y2="0.8549" layer="21"/>
<rectangle x1="1.7785" y1="0.8086" x2="3.4871" y2="0.8549" layer="21"/>
<rectangle x1="-3.5786" y1="0.8549" x2="-1.87" y2="0.9008" layer="21"/>
<rectangle x1="1.8247" y1="0.8549" x2="3.4412" y2="0.9008" layer="21"/>
<rectangle x1="-3.5786" y1="0.9008" x2="-1.9159" y2="0.9471" layer="21"/>
<rectangle x1="1.8709" y1="0.9008" x2="3.4412" y2="0.9471" layer="21"/>
<rectangle x1="-3.5786" y1="0.9471" x2="-1.9622" y2="0.9933" layer="21"/>
<rectangle x1="1.9172" y1="0.9471" x2="3.4412" y2="0.9933" layer="21"/>
<rectangle x1="-3.5324" y1="0.9933" x2="-2.0084" y2="1.0395" layer="21"/>
<rectangle x1="1.9631" y1="0.9933" x2="3.4412" y2="1.0395" layer="21"/>
<rectangle x1="-3.5324" y1="1.0395" x2="-2.0546" y2="1.0858" layer="21"/>
<rectangle x1="2.0094" y1="1.0395" x2="3.3949" y2="1.0858" layer="21"/>
<rectangle x1="-3.5324" y1="1.0858" x2="-2.0546" y2="1.1317" layer="21"/>
<rectangle x1="2.0556" y1="1.0858" x2="3.3949" y2="1.1317" layer="21"/>
<rectangle x1="-3.5324" y1="1.1317" x2="-2.1009" y2="1.178" layer="21"/>
<rectangle x1="-0.1148" y1="1.1317" x2="0.0236" y2="1.178" layer="21"/>
<rectangle x1="2.1018" y1="1.1317" x2="3.3949" y2="1.178" layer="21"/>
<rectangle x1="-3.4862" y1="1.178" x2="-2.1009" y2="1.2242" layer="21"/>
<rectangle x1="-0.2073" y1="1.178" x2="0.162" y2="1.2242" layer="21"/>
<rectangle x1="2.1481" y1="1.178" x2="3.3949" y2="1.2242" layer="21"/>
<rectangle x1="-3.4862" y1="1.2242" x2="-2.1009" y2="1.2704" layer="21"/>
<rectangle x1="-0.2535" y1="1.2242" x2="0.2083" y2="1.2704" layer="21"/>
<rectangle x1="2.194" y1="1.2242" x2="3.3487" y2="1.2704" layer="21"/>
<rectangle x1="-3.4862" y1="1.2704" x2="-2.1009" y2="1.3166" layer="21"/>
<rectangle x1="-0.2997" y1="1.2704" x2="0.2545" y2="1.3166" layer="21"/>
<rectangle x1="2.2403" y1="1.2704" x2="3.3487" y2="1.3166" layer="21"/>
<rectangle x1="-3.4399" y1="1.3166" x2="-2.1009" y2="1.3629" layer="21"/>
<rectangle x1="-0.346" y1="1.3166" x2="0.3007" y2="1.3629" layer="21"/>
<rectangle x1="2.2865" y1="1.3166" x2="3.3487" y2="1.3629" layer="21"/>
<rectangle x1="-3.4399" y1="1.3629" x2="-2.1009" y2="1.4088" layer="21"/>
<rectangle x1="-0.3919" y1="1.3629" x2="0.3469" y2="1.4088" layer="21"/>
<rectangle x1="2.2865" y1="1.3629" x2="3.3025" y2="1.4088" layer="21"/>
<rectangle x1="-3.394" y1="1.4088" x2="-2.4239" y2="1.4551" layer="21"/>
<rectangle x1="-2.3317" y1="1.4088" x2="-2.1009" y2="1.4551" layer="21"/>
<rectangle x1="-0.4382" y1="1.4088" x2="0.3932" y2="1.4551" layer="21"/>
<rectangle x1="2.2865" y1="1.4088" x2="3.3025" y2="1.4551" layer="21"/>
<rectangle x1="-3.394" y1="1.4551" x2="-2.4702" y2="1.5013" layer="21"/>
<rectangle x1="-2.3317" y1="1.4551" x2="-2.0546" y2="1.5013" layer="21"/>
<rectangle x1="-0.4844" y1="1.4551" x2="0.4391" y2="1.5013" layer="21"/>
<rectangle x1="2.3327" y1="1.4551" x2="3.2563" y2="1.5013" layer="21"/>
<rectangle x1="-3.394" y1="1.5013" x2="-2.5164" y2="1.5475" layer="21"/>
<rectangle x1="-2.2855" y1="1.5013" x2="-2.0084" y2="1.5475" layer="21"/>
<rectangle x1="-0.5306" y1="1.5013" x2="0.4854" y2="1.5475" layer="21"/>
<rectangle x1="2.3327" y1="1.5013" x2="3.2563" y2="1.5475" layer="21"/>
<rectangle x1="-3.3477" y1="1.5475" x2="-2.5626" y2="1.5938" layer="21"/>
<rectangle x1="-2.2393" y1="1.5475" x2="-2.0084" y2="1.5938" layer="21"/>
<rectangle x1="-0.5769" y1="1.5475" x2="0.5316" y2="1.5938" layer="21"/>
<rectangle x1="2.3327" y1="1.5475" x2="3.2563" y2="1.5938" layer="21"/>
<rectangle x1="-3.3477" y1="1.5938" x2="-2.6089" y2="1.6397" layer="21"/>
<rectangle x1="-2.2393" y1="1.5938" x2="-1.9622" y2="1.6397" layer="21"/>
<rectangle x1="-0.6228" y1="1.5938" x2="0.5778" y2="1.6397" layer="21"/>
<rectangle x1="2.3327" y1="1.5938" x2="3.21" y2="1.6397" layer="21"/>
<rectangle x1="-3.3015" y1="1.6397" x2="-2.6548" y2="1.686" layer="21"/>
<rectangle x1="-2.1931" y1="1.6397" x2="-1.9159" y2="1.686" layer="21"/>
<rectangle x1="-0.6691" y1="1.6397" x2="0.6241" y2="1.686" layer="21"/>
<rectangle x1="2.3327" y1="1.6397" x2="3.21" y2="1.686" layer="21"/>
<rectangle x1="-3.3015" y1="1.686" x2="-2.7011" y2="1.7322" layer="21"/>
<rectangle x1="-2.1468" y1="1.686" x2="-1.87" y2="1.7322" layer="21"/>
<rectangle x1="-0.7153" y1="1.686" x2="0.67" y2="1.7322" layer="21"/>
<rectangle x1="2.2865" y1="1.686" x2="3.1641" y2="1.7322" layer="21"/>
<rectangle x1="-3.2553" y1="1.7322" x2="-2.7473" y2="1.7784" layer="21"/>
<rectangle x1="-2.1009" y1="1.7322" x2="-1.8237" y2="1.7784" layer="21"/>
<rectangle x1="-0.7615" y1="1.7322" x2="0.7163" y2="1.7784" layer="21"/>
<rectangle x1="2.2865" y1="1.7322" x2="3.1641" y2="1.7784" layer="21"/>
<rectangle x1="-3.2553" y1="1.7784" x2="-2.7935" y2="1.8246" layer="21"/>
<rectangle x1="-2.1009" y1="1.7784" x2="-1.7775" y2="1.8246" layer="21"/>
<rectangle x1="-0.8077" y1="1.7784" x2="0.7625" y2="1.8246" layer="21"/>
<rectangle x1="2.2403" y1="1.7784" x2="3.1178" y2="1.8246" layer="21"/>
<rectangle x1="-3.2091" y1="1.8246" x2="-2.8397" y2="1.8709" layer="21"/>
<rectangle x1="-2.0546" y1="1.8246" x2="-1.7313" y2="1.8709" layer="21"/>
<rectangle x1="-0.854" y1="1.8246" x2="0.8087" y2="1.8709" layer="21"/>
<rectangle x1="2.194" y1="1.8246" x2="3.1178" y2="1.8709" layer="21"/>
<rectangle x1="-3.2091" y1="1.8709" x2="-2.886" y2="1.9168" layer="21"/>
<rectangle x1="-2.0084" y1="1.8709" x2="-1.6851" y2="1.9168" layer="21"/>
<rectangle x1="-0.8999" y1="1.8709" x2="0.8549" y2="1.9168" layer="21"/>
<rectangle x1="2.194" y1="1.8709" x2="3.0716" y2="1.9168" layer="21"/>
<rectangle x1="-3.1628" y1="1.9168" x2="-2.9319" y2="1.9631" layer="21"/>
<rectangle x1="-1.9622" y1="1.9168" x2="-1.6388" y2="1.9631" layer="21"/>
<rectangle x1="-0.9462" y1="1.9168" x2="0.9012" y2="1.9631" layer="21"/>
<rectangle x1="2.1481" y1="1.9168" x2="3.0254" y2="1.9631" layer="21"/>
<rectangle x1="-3.1628" y1="1.9631" x2="-2.9782" y2="2.0093" layer="21"/>
<rectangle x1="-1.9159" y1="1.9631" x2="-1.5929" y2="2.0093" layer="21"/>
<rectangle x1="-1.0386" y1="1.9631" x2="0.9471" y2="2.0093" layer="21"/>
<rectangle x1="2.1018" y1="1.9631" x2="3.0254" y2="2.0093" layer="21"/>
<rectangle x1="-3.1169" y1="2.0093" x2="-3.0244" y2="2.0555" layer="21"/>
<rectangle x1="-1.87" y1="2.0093" x2="-1.5004" y2="2.0555" layer="21"/>
<rectangle x1="-1.0849" y1="2.0093" x2="0.9934" y2="2.0555" layer="21"/>
<rectangle x1="2.0556" y1="2.0093" x2="2.9791" y2="2.0555" layer="21"/>
<rectangle x1="-1.8237" y1="2.0555" x2="-1.362" y2="2.1018" layer="21"/>
<rectangle x1="-1.2233" y1="2.0555" x2="1.0396" y2="2.1018" layer="21"/>
<rectangle x1="2.0094" y1="2.0555" x2="2.9791" y2="2.1018" layer="21"/>
<rectangle x1="-1.7775" y1="2.1018" x2="1.0858" y2="2.1477" layer="21"/>
<rectangle x1="1.9631" y1="2.1018" x2="2.9332" y2="2.1477" layer="21"/>
<rectangle x1="-1.6851" y1="2.1477" x2="1.1321" y2="2.194" layer="21"/>
<rectangle x1="1.9172" y1="2.1477" x2="2.8869" y2="2.194" layer="21"/>
<rectangle x1="-1.6388" y1="2.194" x2="1.178" y2="2.2402" layer="21"/>
<rectangle x1="1.8709" y1="2.194" x2="2.8869" y2="2.2402" layer="21"/>
<rectangle x1="-1.5929" y1="2.2402" x2="1.2243" y2="2.2864" layer="21"/>
<rectangle x1="1.7785" y1="2.2402" x2="2.8407" y2="2.2864" layer="21"/>
<rectangle x1="-1.5004" y1="2.2864" x2="1.3167" y2="2.3326" layer="21"/>
<rectangle x1="1.7323" y1="2.2864" x2="2.7945" y2="2.3326" layer="21"/>
<rectangle x1="-1.4542" y1="2.3326" x2="1.4092" y2="2.3789" layer="21"/>
<rectangle x1="1.5938" y1="2.3326" x2="2.7483" y2="2.3789" layer="21"/>
<rectangle x1="-1.4079" y1="2.3789" x2="2.702" y2="2.4248" layer="21"/>
<rectangle x1="-1.4542" y1="2.4248" x2="2.702" y2="2.4711" layer="21"/>
<rectangle x1="-1.5004" y1="2.4711" x2="2.6561" y2="2.5173" layer="21"/>
<rectangle x1="-1.5466" y1="2.5173" x2="2.6098" y2="2.5635" layer="21"/>
<rectangle x1="-1.5929" y1="2.5635" x2="2.5636" y2="2.6098" layer="21"/>
<rectangle x1="-1.6388" y1="2.6098" x2="2.5174" y2="2.6557" layer="21"/>
<rectangle x1="-1.6851" y1="2.6557" x2="2.4711" y2="2.702" layer="21"/>
<rectangle x1="-1.7313" y1="2.702" x2="2.4252" y2="2.7482" layer="21"/>
<rectangle x1="-1.7775" y1="2.7482" x2="2.3789" y2="2.7944" layer="21"/>
<rectangle x1="-1.8237" y1="2.7944" x2="2.3327" y2="2.8406" layer="21"/>
<rectangle x1="-1.87" y1="2.8406" x2="2.2865" y2="2.8869" layer="21"/>
<rectangle x1="-1.9159" y1="2.8869" x2="2.194" y2="2.9328" layer="21"/>
<rectangle x1="-1.9622" y1="2.9328" x2="2.1481" y2="2.9791" layer="21"/>
<rectangle x1="-2.0084" y1="2.9791" x2="2.1018" y2="3.0253" layer="21"/>
<rectangle x1="-2.0084" y1="3.0253" x2="2.0556" y2="3.0715" layer="21"/>
<rectangle x1="-2.0546" y1="3.0715" x2="1.9631" y2="3.1178" layer="21"/>
<rectangle x1="-2.0084" y1="3.1178" x2="1.9172" y2="3.1637" layer="21"/>
<rectangle x1="-1.9622" y1="3.1637" x2="1.8247" y2="3.21" layer="21"/>
<rectangle x1="-1.87" y1="3.21" x2="1.7323" y2="3.2562" layer="21"/>
<rectangle x1="-1.7775" y1="3.2562" x2="1.686" y2="3.3024" layer="21"/>
<rectangle x1="-1.6851" y1="3.3024" x2="1.5938" y2="3.3486" layer="21"/>
<rectangle x1="-1.5929" y1="3.3486" x2="1.5014" y2="3.3949" layer="21"/>
<rectangle x1="-1.5004" y1="3.3949" x2="1.4092" y2="3.4408" layer="21"/>
<rectangle x1="-1.4079" y1="3.4408" x2="1.2705" y2="3.4871" layer="21"/>
<rectangle x1="-1.2695" y1="3.4871" x2="1.178" y2="3.5333" layer="21"/>
<rectangle x1="-1.1308" y1="3.5333" x2="1.0396" y2="3.5795" layer="21"/>
<rectangle x1="-0.9924" y1="3.5795" x2="0.8549" y2="3.6258" layer="21"/>
<rectangle x1="-0.8077" y1="3.6258" x2="0.67" y2="3.6717" layer="21"/>
<rectangle x1="-0.5306" y1="3.6717" x2="0.3932" y2="3.718" layer="21"/>
</package>
<package name="FKIT-LOGO_SMALL">
<wire x1="-0.6604" y1="1.1176" x2="-1.1176" y2="0.6604" width="0.2032" layer="21" curve="30.075632"/>
<wire x1="0.635" y1="-1.0922" x2="1.0922" y2="-0.635" width="0.2032" layer="21" curve="30.075632"/>
<wire x1="1.4224" y1="-0.8382" x2="-0.9398" y2="1.524" width="0.2032" layer="21" curve="153.381643"/>
<wire x1="-1.524" y1="0.9652" x2="0.8636" y2="-1.397" width="0.2032" layer="21" curve="153.654893"/>
<wire x1="-0.9398" y1="1.524" x2="-0.0254" y2="0.6096" width="0.2032" layer="21"/>
<wire x1="-0.0254" y1="0.6096" x2="0.6604" y2="1.2954" width="0.2032" layer="21"/>
<wire x1="0.6604" y1="1.2954" x2="0.889" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.889" y1="1.27" x2="1.2192" y2="0.9398" width="0.2032" layer="21"/>
<wire x1="1.2192" y1="0.9398" x2="1.2446" y2="0.6604" width="0.2032" layer="21"/>
<wire x1="1.2446" y1="0.6604" x2="1.0668" y2="0.4826" width="0.2032" layer="21"/>
<wire x1="1.0668" y1="0.4826" x2="0.5842" y2="0" width="0.2032" layer="21"/>
<wire x1="0.5842" y1="0" x2="1.397" y2="-0.8382" width="0.2032" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="0.508" y2="1.6256" width="0.2032" layer="21"/>
<wire x1="-0.7874" y1="1.5494" x2="0.762" y2="1.4986" width="0.2032" layer="21"/>
<wire x1="-0.7366" y1="1.397" x2="0.9398" y2="1.3716" width="0.2032" layer="21"/>
<wire x1="0.9906" y1="1.3208" x2="1.2192" y2="1.1176" width="0.2032" layer="21"/>
<wire x1="-0.5334" y1="1.2446" x2="0.4826" y2="1.2446" width="0.2032" layer="21"/>
<wire x1="-0.4064" y1="1.1176" x2="0.3556" y2="1.1176" width="0.2032" layer="21"/>
<wire x1="-0.3048" y1="0.9652" x2="0.1524" y2="0.9652" width="0.2032" layer="21"/>
<wire x1="-0.1016" y1="0.8128" x2="0.0508" y2="0.8382" width="0.2032" layer="21"/>
<wire x1="1.2954" y1="0.9144" x2="1.4478" y2="0.889" width="0.2032" layer="21"/>
<wire x1="1.3208" y1="0.762" x2="1.4986" y2="0.7366" width="0.2032" layer="21"/>
<wire x1="1.2954" y1="0.5842" x2="1.4732" y2="0.5588" width="0.2032" layer="21"/>
<wire x1="1.0668" y1="0.4826" x2="1.5748" y2="0.4064" width="0.2032" layer="21"/>
<wire x1="1.0414" y1="0.3302" x2="1.6002" y2="0.254" width="0.2032" layer="21"/>
<wire x1="0.8636" y1="0.1778" x2="1.6764" y2="0.0762" width="0.2032" layer="21"/>
<wire x1="0.6858" y1="0.0508" x2="1.5748" y2="-0.0762" width="0.2032" layer="21"/>
<wire x1="0.7874" y1="-0.0762" x2="1.5748" y2="-0.2286" width="0.2032" layer="21"/>
<wire x1="0.9398" y1="-0.2286" x2="1.5494" y2="-0.381" width="0.2032" layer="21"/>
<wire x1="1.1176" y1="-0.4064" x2="1.4224" y2="-0.508" width="0.2032" layer="21"/>
<wire x1="1.2954" y1="-0.5588" x2="1.3716" y2="-0.6858" width="0.2032" layer="21"/>
<wire x1="-1.524" y1="0.9652" x2="-0.5842" y2="0.0254" width="0.2032" layer="21"/>
<wire x1="-0.5842" y1="0.0254" x2="-0.9906" y2="-0.381" width="0.2032" layer="21"/>
<wire x1="-0.9906" y1="-0.381" x2="-0.9906" y2="-0.6604" width="0.2032" layer="21"/>
<wire x1="-0.9906" y1="-0.6604" x2="-0.635" y2="-1.016" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.016" x2="-0.4826" y2="-1.016" width="0.2032" layer="21"/>
<wire x1="-0.4826" y1="-1.016" x2="0" y2="-0.5588" width="0.2032" layer="21"/>
<wire x1="0" y1="-0.5588" x2="0.8636" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="-1.5494" y1="0.7874" x2="-0.8128" y2="0.0254" width="0.2032" layer="21"/>
<wire x1="-0.8382" y1="-0.127" x2="-1.5748" y2="0.5842" width="0.2032" layer="21"/>
<wire x1="-1.6764" y1="0.4318" x2="-0.9906" y2="-0.2032" width="0.2032" layer="21"/>
<wire x1="-0.9906" y1="-0.2032" x2="-1.0668" y2="-0.3302" width="0.2032" layer="21"/>
<wire x1="-1.0668" y1="-0.3302" x2="-1.651" y2="0.254" width="0.2032" layer="21"/>
<wire x1="-1.651" y1="0.254" x2="-1.651" y2="0.0254" width="0.2032" layer="21"/>
<wire x1="-1.651" y1="0.0254" x2="-1.0668" y2="-0.5334" width="0.2032" layer="21"/>
<wire x1="-1.0668" y1="-0.5334" x2="-1.0922" y2="-0.6858" width="0.2032" layer="21"/>
<wire x1="-1.0922" y1="-0.6858" x2="-1.651" y2="-0.1778" width="0.2032" layer="21"/>
<wire x1="-1.651" y1="-0.1778" x2="-1.5748" y2="-0.4064" width="0.2032" layer="21"/>
<wire x1="-1.5748" y1="-0.4064" x2="-0.2286" y2="-1.5748" width="0.2032" layer="21"/>
<wire x1="-0.2286" y1="-1.5748" x2="-0.5842" y2="-1.4478" width="0.2032" layer="21"/>
<wire x1="-0.5842" y1="-1.4478" x2="-1.4986" y2="-0.6096" width="0.2032" layer="21"/>
<wire x1="-1.4986" y1="-0.6096" x2="-0.8636" y2="-1.3716" width="0.2032" layer="21"/>
<wire x1="-0.5842" y1="-1.1176" x2="-0.0508" y2="-1.5494" width="0.2032" layer="21"/>
<wire x1="0.127" y1="-1.5494" x2="-0.3556" y2="-1.0922" width="0.2032" layer="21"/>
<wire x1="-0.3048" y1="-0.9652" x2="0.3302" y2="-1.4986" width="0.2032" layer="21"/>
<wire x1="0.5334" y1="-1.4732" x2="-0.1778" y2="-0.8128" width="0.2032" layer="21"/>
<wire x1="-0.0762" y1="-0.7366" x2="0.635" y2="-1.3462" width="0.2032" layer="21"/>
</package>
<package name="FKIT-LOGO_VERY_SMALL">
<wire x1="0.7112" y1="-0.3556" x2="-0.4064" y2="0.7365" width="0.2032" layer="21" curve="147.089401"/>
<wire x1="-0.7112" y1="0.4064" x2="0.4064" y2="-0.6857" width="0.2032" layer="21" curve="147.089401"/>
<wire x1="-0.4064" y1="0.7366" x2="-0.0254" y2="0.3556" width="0.2032" layer="21"/>
<wire x1="-0.0254" y1="0.3556" x2="0.2794" y2="0.6604" width="0.2032" layer="21"/>
<wire x1="0.2794" y1="0.6604" x2="0.4318" y2="0.6858" width="0.2032" layer="21"/>
<wire x1="0.7112" y1="-0.3556" x2="0.3556" y2="0" width="0.2032" layer="21"/>
<wire x1="0.3556" y1="0" x2="0.6858" y2="0.3048" width="0.2032" layer="21"/>
<wire x1="0.6858" y1="0.3048" x2="0.6858" y2="0.4318" width="0.2032" layer="21"/>
<wire x1="0.6858" y1="0.1778" x2="0.5334" y2="-0.0254" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-0.1778" x2="0.6858" y2="0.0254" width="0.2032" layer="21"/>
<wire x1="0.2032" y1="0.7366" x2="-0.0508" y2="0.5842" width="0.2032" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="0" y2="0.7112" width="0.2032" layer="21"/>
<wire x1="-0.7112" y1="0.4064" x2="-0.3302" y2="0.0254" width="0.2032" layer="21"/>
<wire x1="-0.3302" y1="0.0254" x2="-0.5588" y2="-0.2032" width="0.2032" layer="21"/>
<wire x1="-0.5588" y1="-0.2032" x2="-0.5588" y2="-0.3556" width="0.2032" layer="21"/>
<wire x1="-0.5588" y1="-0.3556" x2="-0.3556" y2="-0.5588" width="0.2032" layer="21"/>
<wire x1="-0.3556" y1="-0.5588" x2="-0.2032" y2="-0.5588" width="0.2032" layer="21"/>
<wire x1="-0.2032" y1="-0.5588" x2="0.0508" y2="-0.3302" width="0.2032" layer="21"/>
<wire x1="0.0508" y1="-0.3302" x2="0.4064" y2="-0.6858" width="0.2032" layer="21"/>
<wire x1="-0.6604" y1="0.2032" x2="-0.6858" y2="-0.1524" width="0.2032" layer="21"/>
<wire x1="-0.5588" y1="-0.127" x2="-0.5334" y2="0.1016" width="0.2032" layer="21"/>
<wire x1="-0.1524" y1="-0.6604" x2="0.2286" y2="-0.6604" width="0.2032" layer="21"/>
<wire x1="0.1524" y1="-0.5334" x2="-0.0254" y2="-0.508" width="0.2032" layer="21"/>
</package>
<package name="FKIT-LOGOTYPE_SMALL">
<rectangle x1="-2.8108" y1="-1.0335" x2="-2.7384" y2="-1.0216" layer="21"/>
<rectangle x1="-2.823" y1="-1.0216" x2="-2.714" y2="-1.0094" layer="21"/>
<rectangle x1="-2.823" y1="-1.0094" x2="-2.7021" y2="-0.9975" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9975" x2="-2.678" y2="-0.9853" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9853" x2="-2.6658" y2="-0.9731" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9731" x2="-2.6658" y2="-0.9611" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9611" x2="-2.6536" y2="-0.949" layer="21"/>
<rectangle x1="-2.8352" y1="-0.949" x2="-2.6416" y2="-0.9368" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9368" x2="-2.6416" y2="-0.9248" layer="21"/>
<rectangle x1="-2.8352" y1="-0.9248" x2="-2.6295" y2="-0.9126" layer="21"/>
<rectangle x1="-2.823" y1="-0.9126" x2="-2.6173" y2="-0.9007" layer="21"/>
<rectangle x1="-2.823" y1="-0.9007" x2="-2.6173" y2="-0.8885" layer="21"/>
<rectangle x1="-2.8108" y1="-0.8885" x2="-2.6173" y2="-0.8763" layer="21"/>
<rectangle x1="-2.8108" y1="-0.8763" x2="-2.6053" y2="-0.8644" layer="21"/>
<rectangle x1="-2.7989" y1="-0.8644" x2="-2.6053" y2="-0.8522" layer="21"/>
<rectangle x1="-2.7989" y1="-0.8522" x2="-2.6053" y2="-0.8402" layer="21"/>
<rectangle x1="-2.7867" y1="-0.8402" x2="-2.6053" y2="-0.828" layer="21"/>
<rectangle x1="-2.7867" y1="-0.828" x2="-2.5931" y2="-0.8159" layer="21"/>
<rectangle x1="-2.7867" y1="-0.8159" x2="-2.5931" y2="-0.8039" layer="21"/>
<rectangle x1="-2.7867" y1="-0.8039" x2="-2.5931" y2="-0.7917" layer="21"/>
<rectangle x1="-2.7867" y1="-0.7917" x2="-2.5931" y2="-0.7795" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7795" x2="-2.5931" y2="-0.7676" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7676" x2="-2.5931" y2="-0.7554" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7554" x2="-2.5931" y2="-0.7435" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7435" x2="-2.5931" y2="-0.7313" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7313" x2="-2.5931" y2="-0.7191" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7191" x2="-2.5931" y2="-0.7071" layer="21"/>
<rectangle x1="-2.7747" y1="-0.7071" x2="-2.5931" y2="-0.695" layer="21"/>
<rectangle x1="-2.7747" y1="-0.695" x2="-2.5931" y2="-0.6828" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6828" x2="-2.5931" y2="-0.6708" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6708" x2="-2.5931" y2="-0.6586" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6586" x2="-2.5931" y2="-0.6467" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6467" x2="-2.5931" y2="-0.6345" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6345" x2="-2.5931" y2="-0.6223" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6223" x2="-2.5931" y2="-0.6104" layer="21"/>
<rectangle x1="-2.7747" y1="-0.6104" x2="-2.5931" y2="-0.5982" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5982" x2="-2.5931" y2="-0.5862" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5862" x2="-2.5931" y2="-0.574" layer="21"/>
<rectangle x1="-2.7747" y1="-0.574" x2="-2.5931" y2="-0.5619" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5619" x2="-2.5931" y2="-0.5499" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5499" x2="-2.5931" y2="-0.5377" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5377" x2="-2.5931" y2="-0.5255" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5255" x2="-2.5931" y2="-0.5136" layer="21"/>
<rectangle x1="-2.1215" y1="-0.5255" x2="-2.0005" y2="-0.5136" layer="21"/>
<rectangle x1="-1.299" y1="-0.5255" x2="-0.9845" y2="-0.5136" layer="21"/>
<rectangle x1="0.1887" y1="-0.5255" x2="0.334" y2="-0.5136" layer="21"/>
<rectangle x1="0.588" y1="-0.5255" x2="0.8902" y2="-0.5136" layer="21"/>
<rectangle x1="2.3416" y1="-0.5255" x2="2.4869" y2="-0.5136" layer="21"/>
<rectangle x1="2.7772" y1="-0.5255" x2="2.9222" y2="-0.5136" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5136" x2="-2.5931" y2="-0.5014" layer="21"/>
<rectangle x1="-2.1336" y1="-0.5136" x2="-1.952" y2="-0.5014" layer="21"/>
<rectangle x1="-1.7465" y1="-0.5136" x2="-1.6256" y2="-0.5014" layer="21"/>
<rectangle x1="-1.3231" y1="-0.5136" x2="-0.9604" y2="-0.5014" layer="21"/>
<rectangle x1="-0.646" y1="-0.5136" x2="-0.5129" y2="-0.5014" layer="21"/>
<rectangle x1="0.1645" y1="-0.5136" x2="0.3459" y2="-0.5014" layer="21"/>
<rectangle x1="0.5636" y1="-0.5136" x2="0.9144" y2="-0.5014" layer="21"/>
<rectangle x1="1.2047" y1="-0.5136" x2="1.3256" y2="-0.5014" layer="21"/>
<rectangle x1="1.7007" y1="-0.5136" x2="1.8458" y2="-0.5014" layer="21"/>
<rectangle x1="1.9667" y1="-0.5136" x2="2.0635" y2="-0.5014" layer="21"/>
<rectangle x1="2.3175" y1="-0.5136" x2="2.4988" y2="-0.5014" layer="21"/>
<rectangle x1="2.7528" y1="-0.5136" x2="2.9344" y2="-0.5014" layer="21"/>
<rectangle x1="-2.7747" y1="-0.5014" x2="-2.5931" y2="-0.4895" layer="21"/>
<rectangle x1="-2.1578" y1="-0.5014" x2="-1.916" y2="-0.4895" layer="21"/>
<rectangle x1="-1.7587" y1="-0.5014" x2="-1.6013" y2="-0.4895" layer="21"/>
<rectangle x1="-1.3353" y1="-0.5014" x2="-0.9482" y2="-0.4895" layer="21"/>
<rectangle x1="-0.6579" y1="-0.5014" x2="-0.5007" y2="-0.4895" layer="21"/>
<rectangle x1="0.1404" y1="-0.5014" x2="0.3459" y2="-0.4895" layer="21"/>
<rectangle x1="0.5395" y1="-0.5014" x2="0.9387" y2="-0.4895" layer="21"/>
<rectangle x1="1.1805" y1="-0.5014" x2="1.3378" y2="-0.4895" layer="21"/>
<rectangle x1="1.6885" y1="-0.5014" x2="1.8699" y2="-0.4895" layer="21"/>
<rectangle x1="1.9547" y1="-0.5014" x2="2.0756" y2="-0.4895" layer="21"/>
<rectangle x1="2.3053" y1="-0.5014" x2="2.511" y2="-0.4895" layer="21"/>
<rectangle x1="2.7409" y1="-0.5014" x2="2.9464" y2="-0.4895" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4895" x2="-2.5931" y2="-0.4773" layer="21"/>
<rectangle x1="-2.17" y1="-0.4895" x2="-1.8796" y2="-0.4773" layer="21"/>
<rectangle x1="-1.7707" y1="-0.4895" x2="-1.6013" y2="-0.4773" layer="21"/>
<rectangle x1="-1.3473" y1="-0.4895" x2="-0.936" y2="-0.4773" layer="21"/>
<rectangle x1="-0.6579" y1="-0.4895" x2="-0.4887" y2="-0.4773" layer="21"/>
<rectangle x1="0.1282" y1="-0.4895" x2="0.3459" y2="-0.4773" layer="21"/>
<rectangle x1="0.5273" y1="-0.4895" x2="0.9629" y2="-0.4773" layer="21"/>
<rectangle x1="1.1805" y1="-0.4895" x2="1.35" y2="-0.4773" layer="21"/>
<rectangle x1="1.6764" y1="-0.4895" x2="1.8699" y2="-0.4773" layer="21"/>
<rectangle x1="1.9425" y1="-0.4895" x2="2.0876" y2="-0.4773" layer="21"/>
<rectangle x1="2.2933" y1="-0.4895" x2="2.511" y2="-0.4773" layer="21"/>
<rectangle x1="2.7287" y1="-0.4895" x2="2.9464" y2="-0.4773" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4773" x2="-2.5931" y2="-0.4651" layer="21"/>
<rectangle x1="-2.1819" y1="-0.4773" x2="-1.8433" y2="-0.4651" layer="21"/>
<rectangle x1="-1.7707" y1="-0.4773" x2="-1.5893" y2="-0.4651" layer="21"/>
<rectangle x1="-1.3595" y1="-0.4773" x2="-0.9241" y2="-0.4651" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4773" x2="-0.4887" y2="-0.4651" layer="21"/>
<rectangle x1="0.116" y1="-0.4773" x2="0.3581" y2="-0.4651" layer="21"/>
<rectangle x1="0.5153" y1="-0.4773" x2="0.9748" y2="-0.4651" layer="21"/>
<rectangle x1="1.1684" y1="-0.4773" x2="1.35" y2="-0.4651" layer="21"/>
<rectangle x1="1.6644" y1="-0.4773" x2="1.8699" y2="-0.4651" layer="21"/>
<rectangle x1="1.9304" y1="-0.4773" x2="2.0998" y2="-0.4651" layer="21"/>
<rectangle x1="2.2811" y1="-0.4773" x2="2.511" y2="-0.4651" layer="21"/>
<rectangle x1="2.7167" y1="-0.4773" x2="2.9464" y2="-0.4651" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4651" x2="-2.5931" y2="-0.4531" layer="21"/>
<rectangle x1="-2.1819" y1="-0.4651" x2="-1.807" y2="-0.4531" layer="21"/>
<rectangle x1="-1.7829" y1="-0.4651" x2="-1.5893" y2="-0.4531" layer="21"/>
<rectangle x1="-1.3716" y1="-0.4651" x2="-0.9119" y2="-0.4531" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4651" x2="-0.4887" y2="-0.4531" layer="21"/>
<rectangle x1="0.1041" y1="-0.4651" x2="0.3581" y2="-0.4531" layer="21"/>
<rectangle x1="0.5031" y1="-0.4651" x2="0.987" y2="-0.4531" layer="21"/>
<rectangle x1="1.1684" y1="-0.4651" x2="1.35" y2="-0.4531" layer="21"/>
<rectangle x1="1.6522" y1="-0.4651" x2="1.8699" y2="-0.4531" layer="21"/>
<rectangle x1="1.9304" y1="-0.4651" x2="2.0998" y2="-0.4531" layer="21"/>
<rectangle x1="2.2692" y1="-0.4651" x2="2.511" y2="-0.4531" layer="21"/>
<rectangle x1="2.7045" y1="-0.4651" x2="2.9464" y2="-0.4531" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4531" x2="-2.5931" y2="-0.441" layer="21"/>
<rectangle x1="-2.1941" y1="-0.4531" x2="-1.5893" y2="-0.441" layer="21"/>
<rectangle x1="-1.3836" y1="-0.4531" x2="-0.9" y2="-0.441" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4531" x2="-0.4887" y2="-0.441" layer="21"/>
<rectangle x1="0.0919" y1="-0.4531" x2="0.3581" y2="-0.441" layer="21"/>
<rectangle x1="0.4912" y1="-0.4531" x2="1.0111" y2="-0.441" layer="21"/>
<rectangle x1="1.1684" y1="-0.4531" x2="1.35" y2="-0.441" layer="21"/>
<rectangle x1="1.6522" y1="-0.4531" x2="1.8699" y2="-0.441" layer="21"/>
<rectangle x1="1.9184" y1="-0.4531" x2="2.112" y2="-0.441" layer="21"/>
<rectangle x1="2.257" y1="-0.4531" x2="2.511" y2="-0.441" layer="21"/>
<rectangle x1="2.6924" y1="-0.4531" x2="2.9464" y2="-0.441" layer="21"/>
<rectangle x1="-2.7747" y1="-0.441" x2="-2.5931" y2="-0.4288" layer="21"/>
<rectangle x1="-2.206" y1="-0.441" x2="-1.5893" y2="-0.4288" layer="21"/>
<rectangle x1="-1.3958" y1="-0.441" x2="-0.8878" y2="-0.4288" layer="21"/>
<rectangle x1="-0.6701" y1="-0.441" x2="-0.4887" y2="-0.4288" layer="21"/>
<rectangle x1="0.0919" y1="-0.441" x2="0.3581" y2="-0.4288" layer="21"/>
<rectangle x1="0.4912" y1="-0.441" x2="1.0233" y2="-0.4288" layer="21"/>
<rectangle x1="1.1684" y1="-0.441" x2="1.35" y2="-0.4288" layer="21"/>
<rectangle x1="1.64" y1="-0.441" x2="1.858" y2="-0.4288" layer="21"/>
<rectangle x1="1.9184" y1="-0.441" x2="2.112" y2="-0.4288" layer="21"/>
<rectangle x1="2.2448" y1="-0.441" x2="2.511" y2="-0.4288" layer="21"/>
<rectangle x1="2.6804" y1="-0.441" x2="2.9464" y2="-0.4288" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4288" x2="-2.5931" y2="-0.4168" layer="21"/>
<rectangle x1="-2.206" y1="-0.4288" x2="-1.5893" y2="-0.4168" layer="21"/>
<rectangle x1="-1.408" y1="-0.4288" x2="-0.8756" y2="-0.4168" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4288" x2="-0.4887" y2="-0.4168" layer="21"/>
<rectangle x1="0.08" y1="-0.4288" x2="0.3581" y2="-0.4168" layer="21"/>
<rectangle x1="0.479" y1="-0.4288" x2="1.0353" y2="-0.4168" layer="21"/>
<rectangle x1="1.1684" y1="-0.4288" x2="1.35" y2="-0.4168" layer="21"/>
<rectangle x1="1.6281" y1="-0.4288" x2="1.858" y2="-0.4168" layer="21"/>
<rectangle x1="1.9184" y1="-0.4288" x2="2.112" y2="-0.4168" layer="21"/>
<rectangle x1="2.2329" y1="-0.4288" x2="2.511" y2="-0.4168" layer="21"/>
<rectangle x1="2.6682" y1="-0.4288" x2="2.9464" y2="-0.4168" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4168" x2="-2.5931" y2="-0.4046" layer="21"/>
<rectangle x1="-2.2182" y1="-0.4168" x2="-1.5893" y2="-0.4046" layer="21"/>
<rectangle x1="-1.408" y1="-0.4168" x2="-0.8636" y2="-0.4046" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4168" x2="-0.4887" y2="-0.4046" layer="21"/>
<rectangle x1="0.0678" y1="-0.4168" x2="0.3581" y2="-0.4046" layer="21"/>
<rectangle x1="0.4668" y1="-0.4168" x2="1.0353" y2="-0.4046" layer="21"/>
<rectangle x1="1.1684" y1="-0.4168" x2="1.35" y2="-0.4046" layer="21"/>
<rectangle x1="1.6281" y1="-0.4168" x2="1.8458" y2="-0.4046" layer="21"/>
<rectangle x1="1.9184" y1="-0.4168" x2="2.112" y2="-0.4046" layer="21"/>
<rectangle x1="2.2329" y1="-0.4168" x2="2.511" y2="-0.4046" layer="21"/>
<rectangle x1="2.6682" y1="-0.4168" x2="2.9464" y2="-0.4046" layer="21"/>
<rectangle x1="-2.7747" y1="-0.4046" x2="-2.5931" y2="-0.3927" layer="21"/>
<rectangle x1="-2.2182" y1="-0.4046" x2="-1.5893" y2="-0.3927" layer="21"/>
<rectangle x1="-1.4199" y1="-0.4046" x2="-0.8515" y2="-0.3927" layer="21"/>
<rectangle x1="-0.6701" y1="-0.4046" x2="-0.4887" y2="-0.3927" layer="21"/>
<rectangle x1="0.0678" y1="-0.4046" x2="0.3581" y2="-0.3927" layer="21"/>
<rectangle x1="0.4668" y1="-0.4046" x2="1.0475" y2="-0.3927" layer="21"/>
<rectangle x1="1.1684" y1="-0.4046" x2="1.35" y2="-0.3927" layer="21"/>
<rectangle x1="1.6159" y1="-0.4046" x2="1.8336" y2="-0.3927" layer="21"/>
<rectangle x1="1.9184" y1="-0.4046" x2="2.112" y2="-0.3927" layer="21"/>
<rectangle x1="2.2207" y1="-0.4046" x2="2.511" y2="-0.3927" layer="21"/>
<rectangle x1="2.656" y1="-0.4046" x2="2.9464" y2="-0.3927" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3927" x2="-2.5931" y2="-0.3805" layer="21"/>
<rectangle x1="-2.2182" y1="-0.3927" x2="-1.5893" y2="-0.3805" layer="21"/>
<rectangle x1="-1.4199" y1="-0.3927" x2="-0.8393" y2="-0.3805" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3927" x2="-0.4887" y2="-0.3805" layer="21"/>
<rectangle x1="0.0556" y1="-0.3927" x2="0.3459" y2="-0.3805" layer="21"/>
<rectangle x1="0.4549" y1="-0.3927" x2="1.0596" y2="-0.3805" layer="21"/>
<rectangle x1="1.1684" y1="-0.3927" x2="1.35" y2="-0.3805" layer="21"/>
<rectangle x1="1.604" y1="-0.3927" x2="1.8336" y2="-0.3805" layer="21"/>
<rectangle x1="1.9184" y1="-0.3927" x2="2.112" y2="-0.3805" layer="21"/>
<rectangle x1="2.2087" y1="-0.3927" x2="2.511" y2="-0.3805" layer="21"/>
<rectangle x1="2.6441" y1="-0.3927" x2="2.9464" y2="-0.3805" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3805" x2="-2.5931" y2="-0.3683" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3805" x2="-1.5893" y2="-0.3683" layer="21"/>
<rectangle x1="-1.4321" y1="-0.3805" x2="-0.8273" y2="-0.3683" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3805" x2="-0.4887" y2="-0.3683" layer="21"/>
<rectangle x1="0.0436" y1="-0.3805" x2="0.3459" y2="-0.3683" layer="21"/>
<rectangle x1="0.4549" y1="-0.3805" x2="1.0596" y2="-0.3683" layer="21"/>
<rectangle x1="1.1684" y1="-0.3805" x2="1.35" y2="-0.3683" layer="21"/>
<rectangle x1="1.604" y1="-0.3805" x2="1.8216" y2="-0.3683" layer="21"/>
<rectangle x1="1.9304" y1="-0.3805" x2="2.0998" y2="-0.3683" layer="21"/>
<rectangle x1="2.2087" y1="-0.3805" x2="2.4988" y2="-0.3683" layer="21"/>
<rectangle x1="2.6441" y1="-0.3805" x2="2.9344" y2="-0.3683" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3683" x2="-2.5931" y2="-0.3564" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3683" x2="-1.5893" y2="-0.3564" layer="21"/>
<rectangle x1="-1.4321" y1="-0.3683" x2="-0.8273" y2="-0.3564" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3683" x2="-0.4887" y2="-0.3564" layer="21"/>
<rectangle x1="0.0436" y1="-0.3683" x2="0.334" y2="-0.3564" layer="21"/>
<rectangle x1="0.4427" y1="-0.3683" x2="1.0596" y2="-0.3564" layer="21"/>
<rectangle x1="1.1684" y1="-0.3683" x2="1.35" y2="-0.3564" layer="21"/>
<rectangle x1="1.5918" y1="-0.3683" x2="1.8095" y2="-0.3564" layer="21"/>
<rectangle x1="1.9304" y1="-0.3683" x2="2.0998" y2="-0.3564" layer="21"/>
<rectangle x1="2.2087" y1="-0.3683" x2="2.4988" y2="-0.3564" layer="21"/>
<rectangle x1="2.6319" y1="-0.3683" x2="2.9344" y2="-0.3564" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3564" x2="-2.5931" y2="-0.3442" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3564" x2="-1.5893" y2="-0.3442" layer="21"/>
<rectangle x1="-1.444" y1="-0.3564" x2="-0.8151" y2="-0.3442" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3564" x2="-0.4887" y2="-0.3442" layer="21"/>
<rectangle x1="0.0436" y1="-0.3564" x2="0.3218" y2="-0.3442" layer="21"/>
<rectangle x1="0.4427" y1="-0.3564" x2="1.0716" y2="-0.3442" layer="21"/>
<rectangle x1="1.1684" y1="-0.3564" x2="1.35" y2="-0.3442" layer="21"/>
<rectangle x1="1.5796" y1="-0.3564" x2="1.8095" y2="-0.3442" layer="21"/>
<rectangle x1="1.9425" y1="-0.3564" x2="2.0876" y2="-0.3442" layer="21"/>
<rectangle x1="2.1965" y1="-0.3564" x2="2.4747" y2="-0.3442" layer="21"/>
<rectangle x1="2.6319" y1="-0.3564" x2="2.91" y2="-0.3442" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3442" x2="-2.5931" y2="-0.3322" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3442" x2="-1.5893" y2="-0.3322" layer="21"/>
<rectangle x1="-1.444" y1="-0.3442" x2="-1.2385" y2="-0.3322" layer="21"/>
<rectangle x1="-1.0087" y1="-0.3442" x2="-0.8151" y2="-0.3322" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3442" x2="-0.4887" y2="-0.3322" layer="21"/>
<rectangle x1="0.0315" y1="-0.3442" x2="0.2372" y2="-0.3322" layer="21"/>
<rectangle x1="0.4307" y1="-0.3442" x2="0.6362" y2="-0.3322" layer="21"/>
<rectangle x1="0.878" y1="-0.3442" x2="1.0716" y2="-0.3322" layer="21"/>
<rectangle x1="1.1684" y1="-0.3442" x2="1.35" y2="-0.3322" layer="21"/>
<rectangle x1="1.5796" y1="-0.3442" x2="1.7973" y2="-0.3322" layer="21"/>
<rectangle x1="1.9547" y1="-0.3442" x2="2.0756" y2="-0.3322" layer="21"/>
<rectangle x1="2.1965" y1="-0.3442" x2="2.402" y2="-0.3322" layer="21"/>
<rectangle x1="2.6319" y1="-0.3442" x2="2.8255" y2="-0.3322" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3322" x2="-2.5931" y2="-0.32" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3322" x2="-2.0369" y2="-0.32" layer="21"/>
<rectangle x1="-2.0005" y1="-0.3322" x2="-1.5893" y2="-0.32" layer="21"/>
<rectangle x1="-1.444" y1="-0.3322" x2="-1.2627" y2="-0.32" layer="21"/>
<rectangle x1="-0.9967" y1="-0.3322" x2="-0.8151" y2="-0.32" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3322" x2="-0.4887" y2="-0.32" layer="21"/>
<rectangle x1="0.0315" y1="-0.3322" x2="0.2128" y2="-0.32" layer="21"/>
<rectangle x1="0.4307" y1="-0.3322" x2="0.6121" y2="-0.32" layer="21"/>
<rectangle x1="0.8902" y1="-0.3322" x2="1.0716" y2="-0.32" layer="21"/>
<rectangle x1="1.1684" y1="-0.3322" x2="1.35" y2="-0.32" layer="21"/>
<rectangle x1="1.5676" y1="-0.3322" x2="1.7973" y2="-0.32" layer="21"/>
<rectangle x1="1.9789" y1="-0.3322" x2="2.0513" y2="-0.32" layer="21"/>
<rectangle x1="2.1965" y1="-0.3322" x2="2.3779" y2="-0.32" layer="21"/>
<rectangle x1="2.6319" y1="-0.3322" x2="2.8133" y2="-0.32" layer="21"/>
<rectangle x1="-2.7747" y1="-0.32" x2="-2.5931" y2="-0.3079" layer="21"/>
<rectangle x1="-2.2304" y1="-0.32" x2="-2.0369" y2="-0.3079" layer="21"/>
<rectangle x1="-1.952" y1="-0.32" x2="-1.5893" y2="-0.3079" layer="21"/>
<rectangle x1="-1.444" y1="-0.32" x2="-1.2627" y2="-0.3079" layer="21"/>
<rectangle x1="-0.9967" y1="-0.32" x2="-0.8151" y2="-0.3079" layer="21"/>
<rectangle x1="-0.6701" y1="-0.32" x2="-0.4887" y2="-0.3079" layer="21"/>
<rectangle x1="0.0315" y1="-0.32" x2="0.2128" y2="-0.3079" layer="21"/>
<rectangle x1="0.4307" y1="-0.32" x2="0.6121" y2="-0.3079" layer="21"/>
<rectangle x1="0.8902" y1="-0.32" x2="1.0716" y2="-0.3079" layer="21"/>
<rectangle x1="1.1684" y1="-0.32" x2="1.35" y2="-0.3079" layer="21"/>
<rectangle x1="1.5676" y1="-0.32" x2="1.7853" y2="-0.3079" layer="21"/>
<rectangle x1="2.1965" y1="-0.32" x2="2.3779" y2="-0.3079" layer="21"/>
<rectangle x1="2.62" y1="-0.32" x2="2.8133" y2="-0.3079" layer="21"/>
<rectangle x1="-2.7747" y1="-0.3079" x2="-2.5931" y2="-0.2959" layer="21"/>
<rectangle x1="-2.2304" y1="-0.3079" x2="-2.0369" y2="-0.2959" layer="21"/>
<rectangle x1="-1.916" y1="-0.3079" x2="-1.5893" y2="-0.2959" layer="21"/>
<rectangle x1="-1.444" y1="-0.3079" x2="-1.2627" y2="-0.2959" layer="21"/>
<rectangle x1="-0.9967" y1="-0.3079" x2="-0.8151" y2="-0.2959" layer="21"/>
<rectangle x1="-0.6701" y1="-0.3079" x2="-0.4887" y2="-0.2959" layer="21"/>
<rectangle x1="0.0315" y1="-0.3079" x2="0.2128" y2="-0.2959" layer="21"/>
<rectangle x1="0.4307" y1="-0.3079" x2="0.6121" y2="-0.2959" layer="21"/>
<rectangle x1="0.8902" y1="-0.3079" x2="1.0716" y2="-0.2959" layer="21"/>
<rectangle x1="1.1684" y1="-0.3079" x2="1.35" y2="-0.2959" layer="21"/>
<rectangle x1="1.5555" y1="-0.3079" x2="1.7731" y2="-0.2959" layer="21"/>
<rectangle x1="2.1844" y1="-0.3079" x2="2.3779" y2="-0.2959" layer="21"/>
<rectangle x1="2.62" y1="-0.3079" x2="2.8133" y2="-0.2959" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2959" x2="-2.5931" y2="-0.2837" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2959" x2="-2.0369" y2="-0.2837" layer="21"/>
<rectangle x1="-1.8796" y1="-0.2959" x2="-1.5893" y2="-0.2837" layer="21"/>
<rectangle x1="-1.444" y1="-0.2959" x2="-1.2627" y2="-0.2837" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2959" x2="-0.8151" y2="-0.2837" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2959" x2="-0.4887" y2="-0.2837" layer="21"/>
<rectangle x1="0.0315" y1="-0.2959" x2="0.2128" y2="-0.2837" layer="21"/>
<rectangle x1="0.4307" y1="-0.2959" x2="0.6121" y2="-0.2837" layer="21"/>
<rectangle x1="0.8902" y1="-0.2959" x2="1.0716" y2="-0.2837" layer="21"/>
<rectangle x1="1.1684" y1="-0.2959" x2="1.35" y2="-0.2837" layer="21"/>
<rectangle x1="1.5433" y1="-0.2959" x2="1.7731" y2="-0.2837" layer="21"/>
<rectangle x1="2.1844" y1="-0.2959" x2="2.3779" y2="-0.2837" layer="21"/>
<rectangle x1="2.62" y1="-0.2959" x2="2.8133" y2="-0.2837" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2837" x2="-2.5931" y2="-0.2715" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2837" x2="-2.0369" y2="-0.2715" layer="21"/>
<rectangle x1="-1.8433" y1="-0.2837" x2="-1.5893" y2="-0.2715" layer="21"/>
<rectangle x1="-1.444" y1="-0.2837" x2="-1.2627" y2="-0.2715" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2837" x2="-0.8151" y2="-0.2715" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2837" x2="-0.4887" y2="-0.2715" layer="21"/>
<rectangle x1="0.0315" y1="-0.2837" x2="0.2128" y2="-0.2715" layer="21"/>
<rectangle x1="0.4307" y1="-0.2837" x2="0.6121" y2="-0.2715" layer="21"/>
<rectangle x1="0.8902" y1="-0.2837" x2="1.0716" y2="-0.2715" layer="21"/>
<rectangle x1="1.1684" y1="-0.2837" x2="1.3619" y2="-0.2715" layer="21"/>
<rectangle x1="1.5433" y1="-0.2837" x2="1.7612" y2="-0.2715" layer="21"/>
<rectangle x1="2.1844" y1="-0.2837" x2="2.3779" y2="-0.2715" layer="21"/>
<rectangle x1="2.62" y1="-0.2837" x2="2.8133" y2="-0.2715" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2715" x2="-2.5931" y2="-0.2596" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2715" x2="-2.0369" y2="-0.2596" layer="21"/>
<rectangle x1="-1.807" y1="-0.2715" x2="-1.5893" y2="-0.2596" layer="21"/>
<rectangle x1="-1.444" y1="-0.2715" x2="-1.2627" y2="-0.2596" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2715" x2="-0.8151" y2="-0.2596" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2715" x2="-0.4887" y2="-0.2596" layer="21"/>
<rectangle x1="0.0315" y1="-0.2715" x2="0.2128" y2="-0.2596" layer="21"/>
<rectangle x1="0.4307" y1="-0.2715" x2="0.6121" y2="-0.2596" layer="21"/>
<rectangle x1="0.8902" y1="-0.2715" x2="1.0716" y2="-0.2596" layer="21"/>
<rectangle x1="1.1684" y1="-0.2715" x2="1.3619" y2="-0.2596" layer="21"/>
<rectangle x1="1.5313" y1="-0.2715" x2="1.749" y2="-0.2596" layer="21"/>
<rectangle x1="2.1844" y1="-0.2715" x2="2.3779" y2="-0.2596" layer="21"/>
<rectangle x1="2.62" y1="-0.2715" x2="2.8133" y2="-0.2596" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2596" x2="-2.5931" y2="-0.2474" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2596" x2="-2.0369" y2="-0.2474" layer="21"/>
<rectangle x1="-1.7829" y1="-0.2596" x2="-1.5893" y2="-0.2474" layer="21"/>
<rectangle x1="-1.444" y1="-0.2596" x2="-1.2627" y2="-0.2474" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2596" x2="-0.8151" y2="-0.2474" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2596" x2="-0.4887" y2="-0.2474" layer="21"/>
<rectangle x1="0.0315" y1="-0.2596" x2="0.2128" y2="-0.2474" layer="21"/>
<rectangle x1="0.4307" y1="-0.2596" x2="0.6121" y2="-0.2474" layer="21"/>
<rectangle x1="0.8902" y1="-0.2596" x2="1.0716" y2="-0.2474" layer="21"/>
<rectangle x1="1.1684" y1="-0.2596" x2="1.3619" y2="-0.2474" layer="21"/>
<rectangle x1="1.5191" y1="-0.2596" x2="1.749" y2="-0.2474" layer="21"/>
<rectangle x1="2.1844" y1="-0.2596" x2="2.3779" y2="-0.2474" layer="21"/>
<rectangle x1="2.62" y1="-0.2596" x2="2.8133" y2="-0.2474" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2474" x2="-2.5931" y2="-0.2355" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2474" x2="-2.0369" y2="-0.2355" layer="21"/>
<rectangle x1="-1.7829" y1="-0.2474" x2="-1.5893" y2="-0.2355" layer="21"/>
<rectangle x1="-1.444" y1="-0.2474" x2="-1.2627" y2="-0.2355" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2474" x2="-0.8151" y2="-0.2355" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2474" x2="-0.4887" y2="-0.2355" layer="21"/>
<rectangle x1="0.0315" y1="-0.2474" x2="0.2128" y2="-0.2355" layer="21"/>
<rectangle x1="0.4307" y1="-0.2474" x2="0.6121" y2="-0.2355" layer="21"/>
<rectangle x1="0.8902" y1="-0.2474" x2="1.0716" y2="-0.2355" layer="21"/>
<rectangle x1="1.1684" y1="-0.2474" x2="1.3619" y2="-0.2355" layer="21"/>
<rectangle x1="1.5191" y1="-0.2474" x2="1.7368" y2="-0.2355" layer="21"/>
<rectangle x1="2.1844" y1="-0.2474" x2="2.3779" y2="-0.2355" layer="21"/>
<rectangle x1="2.62" y1="-0.2474" x2="2.8133" y2="-0.2355" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2355" x2="-2.5931" y2="-0.2233" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2355" x2="-2.0369" y2="-0.2233" layer="21"/>
<rectangle x1="-1.7829" y1="-0.2355" x2="-1.5893" y2="-0.2233" layer="21"/>
<rectangle x1="-1.444" y1="-0.2355" x2="-1.2627" y2="-0.2233" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2355" x2="-0.8151" y2="-0.2233" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2355" x2="-0.4887" y2="-0.2233" layer="21"/>
<rectangle x1="0.0315" y1="-0.2355" x2="0.2128" y2="-0.2233" layer="21"/>
<rectangle x1="0.4307" y1="-0.2355" x2="0.6121" y2="-0.2233" layer="21"/>
<rectangle x1="0.8902" y1="-0.2355" x2="1.0596" y2="-0.2233" layer="21"/>
<rectangle x1="1.1684" y1="-0.2355" x2="1.3619" y2="-0.2233" layer="21"/>
<rectangle x1="1.5072" y1="-0.2355" x2="1.7249" y2="-0.2233" layer="21"/>
<rectangle x1="2.1844" y1="-0.2355" x2="2.3779" y2="-0.2233" layer="21"/>
<rectangle x1="2.62" y1="-0.2355" x2="2.8133" y2="-0.2233" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2233" x2="-2.5931" y2="-0.2111" layer="21"/>
<rectangle x1="-2.2304" y1="-0.2233" x2="-2.0369" y2="-0.2111" layer="21"/>
<rectangle x1="-1.7829" y1="-0.2233" x2="-1.5893" y2="-0.2111" layer="21"/>
<rectangle x1="-1.444" y1="-0.2233" x2="-1.2627" y2="-0.2111" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2233" x2="-0.8151" y2="-0.2111" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2233" x2="-0.4887" y2="-0.2111" layer="21"/>
<rectangle x1="0.0315" y1="-0.2233" x2="0.2128" y2="-0.2111" layer="21"/>
<rectangle x1="0.4307" y1="-0.2233" x2="0.6121" y2="-0.2111" layer="21"/>
<rectangle x1="0.9024" y1="-0.2233" x2="1.0596" y2="-0.2111" layer="21"/>
<rectangle x1="1.1684" y1="-0.2233" x2="1.3619" y2="-0.2111" layer="21"/>
<rectangle x1="1.495" y1="-0.2233" x2="1.7249" y2="-0.2111" layer="21"/>
<rectangle x1="2.1844" y1="-0.2233" x2="2.3779" y2="-0.2111" layer="21"/>
<rectangle x1="2.62" y1="-0.2233" x2="2.8133" y2="-0.2111" layer="21"/>
<rectangle x1="-2.7747" y1="-0.2111" x2="-2.5931" y2="-0.1991" layer="21"/>
<rectangle x1="-2.2182" y1="-0.2111" x2="-2.0127" y2="-0.1991" layer="21"/>
<rectangle x1="-1.7829" y1="-0.2111" x2="-1.5893" y2="-0.1991" layer="21"/>
<rectangle x1="-1.444" y1="-0.2111" x2="-1.2627" y2="-0.1991" layer="21"/>
<rectangle x1="-0.9967" y1="-0.2111" x2="-0.8151" y2="-0.1991" layer="21"/>
<rectangle x1="-0.6701" y1="-0.2111" x2="-0.4887" y2="-0.1991" layer="21"/>
<rectangle x1="0.0315" y1="-0.2111" x2="0.2128" y2="-0.1991" layer="21"/>
<rectangle x1="0.4307" y1="-0.2111" x2="0.6121" y2="-0.1991" layer="21"/>
<rectangle x1="0.9024" y1="-0.2111" x2="1.0475" y2="-0.1991" layer="21"/>
<rectangle x1="1.1684" y1="-0.2111" x2="1.3619" y2="-0.1991" layer="21"/>
<rectangle x1="1.495" y1="-0.2111" x2="1.7127" y2="-0.1991" layer="21"/>
<rectangle x1="2.1844" y1="-0.2111" x2="2.3779" y2="-0.1991" layer="21"/>
<rectangle x1="2.62" y1="-0.2111" x2="2.8133" y2="-0.1991" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1991" x2="-2.5931" y2="-0.187" layer="21"/>
<rectangle x1="-2.2182" y1="-0.1991" x2="-1.952" y2="-0.187" layer="21"/>
<rectangle x1="-1.7829" y1="-0.1991" x2="-1.5893" y2="-0.187" layer="21"/>
<rectangle x1="-1.444" y1="-0.1991" x2="-1.2627" y2="-0.187" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1991" x2="-0.8151" y2="-0.187" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1991" x2="-0.4887" y2="-0.187" layer="21"/>
<rectangle x1="0.0315" y1="-0.1991" x2="0.2128" y2="-0.187" layer="21"/>
<rectangle x1="0.4307" y1="-0.1991" x2="0.6121" y2="-0.187" layer="21"/>
<rectangle x1="0.9265" y1="-0.1991" x2="1.0233" y2="-0.187" layer="21"/>
<rectangle x1="1.1684" y1="-0.1991" x2="1.3619" y2="-0.187" layer="21"/>
<rectangle x1="1.4828" y1="-0.1991" x2="1.7007" y2="-0.187" layer="21"/>
<rectangle x1="2.1844" y1="-0.1991" x2="2.3779" y2="-0.187" layer="21"/>
<rectangle x1="2.62" y1="-0.1991" x2="2.8133" y2="-0.187" layer="21"/>
<rectangle x1="-2.7747" y1="-0.187" x2="-2.5931" y2="-0.1748" layer="21"/>
<rectangle x1="-2.2182" y1="-0.187" x2="-1.9038" y2="-0.1748" layer="21"/>
<rectangle x1="-1.7829" y1="-0.187" x2="-1.5893" y2="-0.1748" layer="21"/>
<rectangle x1="-1.444" y1="-0.187" x2="-1.2627" y2="-0.1748" layer="21"/>
<rectangle x1="-0.9967" y1="-0.187" x2="-0.8151" y2="-0.1748" layer="21"/>
<rectangle x1="-0.6701" y1="-0.187" x2="-0.4887" y2="-0.1748" layer="21"/>
<rectangle x1="0.0315" y1="-0.187" x2="0.2128" y2="-0.1748" layer="21"/>
<rectangle x1="0.4307" y1="-0.187" x2="0.6121" y2="-0.1748" layer="21"/>
<rectangle x1="1.1684" y1="-0.187" x2="1.3619" y2="-0.1748" layer="21"/>
<rectangle x1="1.4709" y1="-0.187" x2="1.7007" y2="-0.1748" layer="21"/>
<rectangle x1="2.1844" y1="-0.187" x2="2.3779" y2="-0.1748" layer="21"/>
<rectangle x1="2.62" y1="-0.187" x2="2.8133" y2="-0.1748" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1748" x2="-2.5931" y2="-0.1628" layer="21"/>
<rectangle x1="-2.2182" y1="-0.1748" x2="-1.8433" y2="-0.1628" layer="21"/>
<rectangle x1="-1.7829" y1="-0.1748" x2="-1.5893" y2="-0.1628" layer="21"/>
<rectangle x1="-1.444" y1="-0.1748" x2="-1.2627" y2="-0.1628" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1748" x2="-0.8151" y2="-0.1628" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1748" x2="-0.4887" y2="-0.1628" layer="21"/>
<rectangle x1="0.0315" y1="-0.1748" x2="0.2128" y2="-0.1628" layer="21"/>
<rectangle x1="0.4307" y1="-0.1748" x2="0.6121" y2="-0.1628" layer="21"/>
<rectangle x1="1.1684" y1="-0.1748" x2="1.6885" y2="-0.1628" layer="21"/>
<rectangle x1="2.1844" y1="-0.1748" x2="2.3779" y2="-0.1628" layer="21"/>
<rectangle x1="2.62" y1="-0.1748" x2="2.8133" y2="-0.1628" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1628" x2="-2.5931" y2="-0.1506" layer="21"/>
<rectangle x1="-2.206" y1="-0.1628" x2="-1.7948" y2="-0.1506" layer="21"/>
<rectangle x1="-1.7829" y1="-0.1628" x2="-1.5893" y2="-0.1506" layer="21"/>
<rectangle x1="-1.444" y1="-0.1628" x2="-1.2627" y2="-0.1506" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1628" x2="-0.8151" y2="-0.1506" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1628" x2="-0.4887" y2="-0.1506" layer="21"/>
<rectangle x1="0.0315" y1="-0.1628" x2="0.2128" y2="-0.1506" layer="21"/>
<rectangle x1="0.4307" y1="-0.1628" x2="0.6121" y2="-0.1506" layer="21"/>
<rectangle x1="1.1684" y1="-0.1628" x2="1.6764" y2="-0.1506" layer="21"/>
<rectangle x1="2.1844" y1="-0.1628" x2="2.3779" y2="-0.1506" layer="21"/>
<rectangle x1="2.62" y1="-0.1628" x2="2.8133" y2="-0.1506" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1506" x2="-2.5931" y2="-0.1387" layer="21"/>
<rectangle x1="-2.206" y1="-0.1506" x2="-1.5893" y2="-0.1387" layer="21"/>
<rectangle x1="-1.444" y1="-0.1506" x2="-1.2627" y2="-0.1387" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1506" x2="-0.8151" y2="-0.1387" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1506" x2="-0.4887" y2="-0.1387" layer="21"/>
<rectangle x1="0.0315" y1="-0.1506" x2="0.2128" y2="-0.1387" layer="21"/>
<rectangle x1="0.4307" y1="-0.1506" x2="0.6121" y2="-0.1387" layer="21"/>
<rectangle x1="1.1684" y1="-0.1506" x2="1.6764" y2="-0.1387" layer="21"/>
<rectangle x1="2.1844" y1="-0.1506" x2="2.3779" y2="-0.1387" layer="21"/>
<rectangle x1="2.62" y1="-0.1506" x2="2.8133" y2="-0.1387" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1387" x2="-2.5931" y2="-0.1265" layer="21"/>
<rectangle x1="-2.206" y1="-0.1387" x2="-1.5893" y2="-0.1265" layer="21"/>
<rectangle x1="-1.444" y1="-0.1387" x2="-1.2627" y2="-0.1265" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1387" x2="-0.8151" y2="-0.1265" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1387" x2="-0.4887" y2="-0.1265" layer="21"/>
<rectangle x1="0.0315" y1="-0.1387" x2="0.2128" y2="-0.1265" layer="21"/>
<rectangle x1="0.4307" y1="-0.1387" x2="0.6121" y2="-0.1265" layer="21"/>
<rectangle x1="1.1684" y1="-0.1387" x2="1.6644" y2="-0.1265" layer="21"/>
<rectangle x1="2.1844" y1="-0.1387" x2="2.3779" y2="-0.1265" layer="21"/>
<rectangle x1="2.62" y1="-0.1387" x2="2.8133" y2="-0.1265" layer="21"/>
<rectangle x1="-2.7747" y1="-0.1265" x2="-2.5931" y2="-0.1143" layer="21"/>
<rectangle x1="-2.1941" y1="-0.1265" x2="-1.5893" y2="-0.1143" layer="21"/>
<rectangle x1="-1.444" y1="-0.1265" x2="-1.2627" y2="-0.1143" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1265" x2="-0.8151" y2="-0.1143" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1265" x2="-0.4887" y2="-0.1143" layer="21"/>
<rectangle x1="0.0315" y1="-0.1265" x2="0.2128" y2="-0.1143" layer="21"/>
<rectangle x1="0.4307" y1="-0.1265" x2="0.6121" y2="-0.1143" layer="21"/>
<rectangle x1="1.1684" y1="-0.1265" x2="1.6644" y2="-0.1143" layer="21"/>
<rectangle x1="2.1844" y1="-0.1265" x2="2.3779" y2="-0.1143" layer="21"/>
<rectangle x1="2.62" y1="-0.1265" x2="2.8133" y2="-0.1143" layer="21"/>
<rectangle x1="-2.7867" y1="-0.1143" x2="-2.5931" y2="-0.1024" layer="21"/>
<rectangle x1="-2.1819" y1="-0.1143" x2="-1.5893" y2="-0.1024" layer="21"/>
<rectangle x1="-1.444" y1="-0.1143" x2="-1.2627" y2="-0.1024" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1143" x2="-0.8151" y2="-0.1024" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1143" x2="-0.4887" y2="-0.1024" layer="21"/>
<rectangle x1="0.0315" y1="-0.1143" x2="0.2128" y2="-0.1024" layer="21"/>
<rectangle x1="0.4307" y1="-0.1143" x2="0.6121" y2="-0.1024" layer="21"/>
<rectangle x1="1.1684" y1="-0.1143" x2="1.6522" y2="-0.1024" layer="21"/>
<rectangle x1="2.1844" y1="-0.1143" x2="2.3779" y2="-0.1024" layer="21"/>
<rectangle x1="2.62" y1="-0.1143" x2="2.8133" y2="-0.1024" layer="21"/>
<rectangle x1="-2.7867" y1="-0.1024" x2="-2.5931" y2="-0.0902" layer="21"/>
<rectangle x1="-2.1819" y1="-0.1024" x2="-1.5893" y2="-0.0902" layer="21"/>
<rectangle x1="-1.444" y1="-0.1024" x2="-1.2627" y2="-0.0902" layer="21"/>
<rectangle x1="-0.9967" y1="-0.1024" x2="-0.8151" y2="-0.0902" layer="21"/>
<rectangle x1="-0.6701" y1="-0.1024" x2="-0.4887" y2="-0.0902" layer="21"/>
<rectangle x1="0.0315" y1="-0.1024" x2="0.2128" y2="-0.0902" layer="21"/>
<rectangle x1="0.4307" y1="-0.1024" x2="0.6121" y2="-0.0902" layer="21"/>
<rectangle x1="1.1684" y1="-0.1024" x2="1.6522" y2="-0.0902" layer="21"/>
<rectangle x1="2.1844" y1="-0.1024" x2="2.3779" y2="-0.0902" layer="21"/>
<rectangle x1="2.62" y1="-0.1024" x2="2.8133" y2="-0.0902" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0902" x2="-2.5931" y2="-0.0782" layer="21"/>
<rectangle x1="-2.17" y1="-0.0902" x2="-1.5893" y2="-0.0782" layer="21"/>
<rectangle x1="-1.444" y1="-0.0902" x2="-1.2627" y2="-0.0782" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0902" x2="-0.8151" y2="-0.0782" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0902" x2="-0.4887" y2="-0.0782" layer="21"/>
<rectangle x1="0.0315" y1="-0.0902" x2="0.2128" y2="-0.0782" layer="21"/>
<rectangle x1="0.4307" y1="-0.0902" x2="0.6121" y2="-0.0782" layer="21"/>
<rectangle x1="1.1684" y1="-0.0902" x2="1.64" y2="-0.0782" layer="21"/>
<rectangle x1="2.1844" y1="-0.0902" x2="2.3779" y2="-0.0782" layer="21"/>
<rectangle x1="2.62" y1="-0.0902" x2="2.8133" y2="-0.0782" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0782" x2="-2.5931" y2="-0.066" layer="21"/>
<rectangle x1="-2.1578" y1="-0.0782" x2="-1.5893" y2="-0.066" layer="21"/>
<rectangle x1="-1.444" y1="-0.0782" x2="-1.2627" y2="-0.066" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0782" x2="-0.8151" y2="-0.066" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0782" x2="-0.4765" y2="-0.066" layer="21"/>
<rectangle x1="0.0315" y1="-0.0782" x2="0.2128" y2="-0.066" layer="21"/>
<rectangle x1="0.4307" y1="-0.0782" x2="0.6121" y2="-0.066" layer="21"/>
<rectangle x1="1.1684" y1="-0.0782" x2="1.64" y2="-0.066" layer="21"/>
<rectangle x1="2.1844" y1="-0.0782" x2="2.3779" y2="-0.066" layer="21"/>
<rectangle x1="2.62" y1="-0.0782" x2="2.8133" y2="-0.066" layer="21"/>
<rectangle x1="-2.7867" y1="-0.066" x2="-2.5931" y2="-0.0539" layer="21"/>
<rectangle x1="-2.1456" y1="-0.066" x2="-1.5893" y2="-0.0539" layer="21"/>
<rectangle x1="-1.444" y1="-0.066" x2="-1.2627" y2="-0.0539" layer="21"/>
<rectangle x1="-0.9967" y1="-0.066" x2="-0.8151" y2="-0.0539" layer="21"/>
<rectangle x1="-0.6701" y1="-0.066" x2="-0.4765" y2="-0.0539" layer="21"/>
<rectangle x1="0.0315" y1="-0.066" x2="0.2128" y2="-0.0539" layer="21"/>
<rectangle x1="0.4307" y1="-0.066" x2="0.6121" y2="-0.0539" layer="21"/>
<rectangle x1="1.1684" y1="-0.066" x2="1.6522" y2="-0.0539" layer="21"/>
<rectangle x1="2.1844" y1="-0.066" x2="2.3779" y2="-0.0539" layer="21"/>
<rectangle x1="2.62" y1="-0.066" x2="2.8133" y2="-0.0539" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0539" x2="-2.5931" y2="-0.0419" layer="21"/>
<rectangle x1="-2.1336" y1="-0.0539" x2="-1.5893" y2="-0.0419" layer="21"/>
<rectangle x1="-1.444" y1="-0.0539" x2="-1.2627" y2="-0.0419" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0539" x2="-0.8151" y2="-0.0419" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0539" x2="-0.4765" y2="-0.0419" layer="21"/>
<rectangle x1="0.0315" y1="-0.0539" x2="0.2128" y2="-0.0419" layer="21"/>
<rectangle x1="0.4307" y1="-0.0539" x2="0.6121" y2="-0.0419" layer="21"/>
<rectangle x1="1.1684" y1="-0.0539" x2="1.6522" y2="-0.0419" layer="21"/>
<rectangle x1="2.1844" y1="-0.0539" x2="2.3779" y2="-0.0419" layer="21"/>
<rectangle x1="2.62" y1="-0.0539" x2="2.8133" y2="-0.0419" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0419" x2="-2.5931" y2="-0.0297" layer="21"/>
<rectangle x1="-2.1093" y1="-0.0419" x2="-1.5893" y2="-0.0297" layer="21"/>
<rectangle x1="-1.444" y1="-0.0419" x2="-1.2627" y2="-0.0297" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0419" x2="-0.8151" y2="-0.0297" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0419" x2="-0.4765" y2="-0.0297" layer="21"/>
<rectangle x1="0.0315" y1="-0.0419" x2="0.2128" y2="-0.0297" layer="21"/>
<rectangle x1="0.4307" y1="-0.0419" x2="0.6121" y2="-0.0297" layer="21"/>
<rectangle x1="1.1684" y1="-0.0419" x2="1.6644" y2="-0.0297" layer="21"/>
<rectangle x1="2.1844" y1="-0.0419" x2="2.3779" y2="-0.0297" layer="21"/>
<rectangle x1="2.62" y1="-0.0419" x2="2.8133" y2="-0.0297" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0297" x2="-2.5931" y2="-0.0175" layer="21"/>
<rectangle x1="-2.0732" y1="-0.0297" x2="-1.5893" y2="-0.0175" layer="21"/>
<rectangle x1="-1.444" y1="-0.0297" x2="-1.2627" y2="-0.0175" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0297" x2="-0.8151" y2="-0.0175" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0297" x2="-0.4765" y2="-0.0175" layer="21"/>
<rectangle x1="0.0315" y1="-0.0297" x2="0.2128" y2="-0.0175" layer="21"/>
<rectangle x1="0.4307" y1="-0.0297" x2="0.624" y2="-0.0175" layer="21"/>
<rectangle x1="0.9144" y1="-0.0297" x2="1.0353" y2="-0.0175" layer="21"/>
<rectangle x1="1.1684" y1="-0.0297" x2="1.6644" y2="-0.0175" layer="21"/>
<rectangle x1="2.1844" y1="-0.0297" x2="2.3779" y2="-0.0175" layer="21"/>
<rectangle x1="2.62" y1="-0.0297" x2="2.8133" y2="-0.0175" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0175" x2="-2.5931" y2="-0.0056" layer="21"/>
<rectangle x1="-2.0005" y1="-0.0175" x2="-1.5893" y2="-0.0056" layer="21"/>
<rectangle x1="-1.444" y1="-0.0175" x2="-1.2627" y2="-0.0056" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0175" x2="-0.8151" y2="-0.0056" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0175" x2="-0.4765" y2="-0.0056" layer="21"/>
<rectangle x1="-0.2104" y1="-0.0175" x2="-0.1016" y2="-0.0056" layer="21"/>
<rectangle x1="0.0315" y1="-0.0175" x2="0.2128" y2="-0.0056" layer="21"/>
<rectangle x1="0.4307" y1="-0.0175" x2="0.624" y2="-0.0056" layer="21"/>
<rectangle x1="0.9024" y1="-0.0175" x2="1.0596" y2="-0.0056" layer="21"/>
<rectangle x1="1.1684" y1="-0.0175" x2="1.6764" y2="-0.0056" layer="21"/>
<rectangle x1="2.1844" y1="-0.0175" x2="2.3779" y2="-0.0056" layer="21"/>
<rectangle x1="2.62" y1="-0.0175" x2="2.8133" y2="-0.0056" layer="21"/>
<rectangle x1="-2.7867" y1="-0.0056" x2="-2.5931" y2="0.0066" layer="21"/>
<rectangle x1="-1.9279" y1="-0.0056" x2="-1.5893" y2="0.0066" layer="21"/>
<rectangle x1="-1.444" y1="-0.0056" x2="-1.2627" y2="0.0066" layer="21"/>
<rectangle x1="-0.9967" y1="-0.0056" x2="-0.8151" y2="0.0066" layer="21"/>
<rectangle x1="-0.6701" y1="-0.0056" x2="-0.4765" y2="0.0066" layer="21"/>
<rectangle x1="-0.2347" y1="-0.0056" x2="-0.0773" y2="0.0066" layer="21"/>
<rectangle x1="0.0315" y1="-0.0056" x2="0.2128" y2="0.0066" layer="21"/>
<rectangle x1="0.4307" y1="-0.0056" x2="0.624" y2="0.0066" layer="21"/>
<rectangle x1="0.8902" y1="-0.0056" x2="1.0596" y2="0.0066" layer="21"/>
<rectangle x1="1.1684" y1="-0.0056" x2="1.6764" y2="0.0066" layer="21"/>
<rectangle x1="2.1844" y1="-0.0056" x2="2.3779" y2="0.0066" layer="21"/>
<rectangle x1="2.62" y1="-0.0056" x2="2.8133" y2="0.0066" layer="21"/>
<rectangle x1="-2.7867" y1="0.0066" x2="-2.5931" y2="0.0185" layer="21"/>
<rectangle x1="-1.8675" y1="0.0066" x2="-1.5893" y2="0.0185" layer="21"/>
<rectangle x1="-1.444" y1="0.0066" x2="-1.2627" y2="0.0185" layer="21"/>
<rectangle x1="-0.9967" y1="0.0066" x2="-0.8151" y2="0.0185" layer="21"/>
<rectangle x1="-0.6701" y1="0.0066" x2="-0.4765" y2="0.0185" layer="21"/>
<rectangle x1="-0.2467" y1="0.0066" x2="-0.0773" y2="0.0185" layer="21"/>
<rectangle x1="0.0315" y1="0.0066" x2="0.2128" y2="0.0185" layer="21"/>
<rectangle x1="0.4307" y1="0.0066" x2="0.624" y2="0.0185" layer="21"/>
<rectangle x1="0.8902" y1="0.0066" x2="1.0596" y2="0.0185" layer="21"/>
<rectangle x1="1.1684" y1="0.0066" x2="1.3619" y2="0.0185" layer="21"/>
<rectangle x1="1.4587" y1="0.0066" x2="1.6885" y2="0.0185" layer="21"/>
<rectangle x1="2.1844" y1="0.0066" x2="2.3779" y2="0.0185" layer="21"/>
<rectangle x1="2.62" y1="0.0066" x2="2.8133" y2="0.0185" layer="21"/>
<rectangle x1="-2.7867" y1="0.0185" x2="-2.5931" y2="0.0307" layer="21"/>
<rectangle x1="-1.8192" y1="0.0185" x2="-1.5893" y2="0.0307" layer="21"/>
<rectangle x1="-1.444" y1="0.0185" x2="-1.2627" y2="0.0307" layer="21"/>
<rectangle x1="-0.9967" y1="0.0185" x2="-0.8151" y2="0.0307" layer="21"/>
<rectangle x1="-0.6701" y1="0.0185" x2="-0.4765" y2="0.0307" layer="21"/>
<rectangle x1="-0.2467" y1="0.0185" x2="-0.0653" y2="0.0307" layer="21"/>
<rectangle x1="0.0315" y1="0.0185" x2="0.2128" y2="0.0307" layer="21"/>
<rectangle x1="0.4307" y1="0.0185" x2="0.624" y2="0.0307" layer="21"/>
<rectangle x1="0.878" y1="0.0185" x2="1.0716" y2="0.0307" layer="21"/>
<rectangle x1="1.1684" y1="0.0185" x2="1.35" y2="0.0307" layer="21"/>
<rectangle x1="1.4828" y1="0.0185" x2="1.7007" y2="0.0307" layer="21"/>
<rectangle x1="2.1844" y1="0.0185" x2="2.3779" y2="0.0307" layer="21"/>
<rectangle x1="2.62" y1="0.0185" x2="2.8133" y2="0.0307" layer="21"/>
<rectangle x1="-2.7989" y1="0.0307" x2="-2.5812" y2="0.0429" layer="21"/>
<rectangle x1="-1.7829" y1="0.0307" x2="-1.5893" y2="0.0429" layer="21"/>
<rectangle x1="-1.444" y1="0.0307" x2="-1.2507" y2="0.0429" layer="21"/>
<rectangle x1="-0.9967" y1="0.0307" x2="-0.8151" y2="0.0429" layer="21"/>
<rectangle x1="-0.6701" y1="0.0307" x2="-0.4765" y2="0.0429" layer="21"/>
<rectangle x1="-0.2467" y1="0.0307" x2="-0.0653" y2="0.0429" layer="21"/>
<rectangle x1="0.0315" y1="0.0307" x2="0.2128" y2="0.0429" layer="21"/>
<rectangle x1="0.4307" y1="0.0307" x2="0.624" y2="0.0429" layer="21"/>
<rectangle x1="0.878" y1="0.0307" x2="1.0716" y2="0.0429" layer="21"/>
<rectangle x1="1.1684" y1="0.0307" x2="1.35" y2="0.0429" layer="21"/>
<rectangle x1="1.4828" y1="0.0307" x2="1.7007" y2="0.0429" layer="21"/>
<rectangle x1="2.1844" y1="0.0307" x2="2.3779" y2="0.0429" layer="21"/>
<rectangle x1="2.62" y1="0.0307" x2="2.8133" y2="0.0429" layer="21"/>
<rectangle x1="-2.8108" y1="0.0429" x2="-2.569" y2="0.0549" layer="21"/>
<rectangle x1="-2.17" y1="0.0429" x2="-2.0369" y2="0.0549" layer="21"/>
<rectangle x1="-1.7829" y1="0.0429" x2="-1.5893" y2="0.0549" layer="21"/>
<rectangle x1="-1.444" y1="0.0429" x2="-1.2144" y2="0.0549" layer="21"/>
<rectangle x1="-0.9967" y1="0.0429" x2="-0.8151" y2="0.0549" layer="21"/>
<rectangle x1="-0.6701" y1="0.0429" x2="-0.4402" y2="0.0549" layer="21"/>
<rectangle x1="-0.2467" y1="0.0429" x2="-0.0653" y2="0.0549" layer="21"/>
<rectangle x1="0.0315" y1="0.0429" x2="0.2128" y2="0.0549" layer="21"/>
<rectangle x1="0.4307" y1="0.0429" x2="0.624" y2="0.0549" layer="21"/>
<rectangle x1="0.878" y1="0.0429" x2="1.0716" y2="0.0549" layer="21"/>
<rectangle x1="1.1684" y1="0.0429" x2="1.35" y2="0.0549" layer="21"/>
<rectangle x1="1.495" y1="0.0429" x2="1.7127" y2="0.0549" layer="21"/>
<rectangle x1="2.1844" y1="0.0429" x2="2.3779" y2="0.0549" layer="21"/>
<rectangle x1="2.62" y1="0.0429" x2="2.8133" y2="0.0549" layer="21"/>
<rectangle x1="-2.9439" y1="0.0549" x2="-2.3391" y2="0.067" layer="21"/>
<rectangle x1="-2.1819" y1="0.0549" x2="-2.0247" y2="0.067" layer="21"/>
<rectangle x1="-1.7829" y1="0.0549" x2="-1.5893" y2="0.067" layer="21"/>
<rectangle x1="-1.444" y1="0.0549" x2="-1.1781" y2="0.067" layer="21"/>
<rectangle x1="-0.9967" y1="0.0549" x2="-0.8151" y2="0.067" layer="21"/>
<rectangle x1="-0.6701" y1="0.0549" x2="-0.4039" y2="0.067" layer="21"/>
<rectangle x1="-0.2467" y1="0.0549" x2="-0.0653" y2="0.067" layer="21"/>
<rectangle x1="0.0315" y1="0.0549" x2="0.2128" y2="0.067" layer="21"/>
<rectangle x1="0.4307" y1="0.0549" x2="0.624" y2="0.067" layer="21"/>
<rectangle x1="0.878" y1="0.0549" x2="1.0716" y2="0.067" layer="21"/>
<rectangle x1="1.1684" y1="0.0549" x2="1.35" y2="0.067" layer="21"/>
<rectangle x1="1.5072" y1="0.0549" x2="1.7127" y2="0.067" layer="21"/>
<rectangle x1="2.1844" y1="0.0549" x2="2.3779" y2="0.067" layer="21"/>
<rectangle x1="2.62" y1="0.0549" x2="2.8133" y2="0.067" layer="21"/>
<rectangle x1="-2.9561" y1="0.067" x2="-2.3272" y2="0.0792" layer="21"/>
<rectangle x1="-2.1941" y1="0.067" x2="-2.0127" y2="0.0792" layer="21"/>
<rectangle x1="-1.7829" y1="0.067" x2="-1.5893" y2="0.0792" layer="21"/>
<rectangle x1="-1.444" y1="0.067" x2="-1.1418" y2="0.0792" layer="21"/>
<rectangle x1="-0.9967" y1="0.067" x2="-0.8151" y2="0.0792" layer="21"/>
<rectangle x1="-0.6701" y1="0.067" x2="-0.3798" y2="0.0792" layer="21"/>
<rectangle x1="-0.2467" y1="0.067" x2="-0.0653" y2="0.0792" layer="21"/>
<rectangle x1="0.0315" y1="0.067" x2="0.2128" y2="0.0792" layer="21"/>
<rectangle x1="0.4307" y1="0.067" x2="0.624" y2="0.0792" layer="21"/>
<rectangle x1="0.878" y1="0.067" x2="1.0716" y2="0.0792" layer="21"/>
<rectangle x1="1.1684" y1="0.067" x2="1.35" y2="0.0792" layer="21"/>
<rectangle x1="1.5072" y1="0.067" x2="1.7249" y2="0.0792" layer="21"/>
<rectangle x1="2.1844" y1="0.067" x2="2.3779" y2="0.0792" layer="21"/>
<rectangle x1="2.62" y1="0.067" x2="2.8133" y2="0.0792" layer="21"/>
<rectangle x1="-2.9561" y1="0.0792" x2="-2.315" y2="0.0912" layer="21"/>
<rectangle x1="-2.1941" y1="0.0792" x2="-2.0127" y2="0.0912" layer="21"/>
<rectangle x1="-1.7829" y1="0.0792" x2="-1.5893" y2="0.0912" layer="21"/>
<rectangle x1="-1.444" y1="0.0792" x2="-1.1055" y2="0.0912" layer="21"/>
<rectangle x1="-0.9967" y1="0.0792" x2="-0.8151" y2="0.0912" layer="21"/>
<rectangle x1="-0.6701" y1="0.0792" x2="-0.3435" y2="0.0912" layer="21"/>
<rectangle x1="-0.2467" y1="0.0792" x2="-0.0653" y2="0.0912" layer="21"/>
<rectangle x1="0.0315" y1="0.0792" x2="0.2128" y2="0.0912" layer="21"/>
<rectangle x1="0.4307" y1="0.0792" x2="0.624" y2="0.0912" layer="21"/>
<rectangle x1="0.878" y1="0.0792" x2="1.0716" y2="0.0912" layer="21"/>
<rectangle x1="1.1684" y1="0.0792" x2="1.35" y2="0.0912" layer="21"/>
<rectangle x1="1.5191" y1="0.0792" x2="1.7368" y2="0.0912" layer="21"/>
<rectangle x1="2.1844" y1="0.0792" x2="2.3779" y2="0.0912" layer="21"/>
<rectangle x1="2.62" y1="0.0792" x2="2.8133" y2="0.0912" layer="21"/>
<rectangle x1="-2.9561" y1="0.0912" x2="-2.315" y2="0.1034" layer="21"/>
<rectangle x1="-2.1941" y1="0.0912" x2="-2.0127" y2="0.1034" layer="21"/>
<rectangle x1="-1.7829" y1="0.0912" x2="-1.6013" y2="0.1034" layer="21"/>
<rectangle x1="-1.444" y1="0.0912" x2="-1.0691" y2="0.1034" layer="21"/>
<rectangle x1="-0.9967" y1="0.0912" x2="-0.8151" y2="0.1034" layer="21"/>
<rectangle x1="-0.6701" y1="0.0912" x2="-0.3071" y2="0.1034" layer="21"/>
<rectangle x1="-0.2467" y1="0.0912" x2="-0.0653" y2="0.1034" layer="21"/>
<rectangle x1="0.0315" y1="0.0912" x2="0.2128" y2="0.1034" layer="21"/>
<rectangle x1="0.4307" y1="0.0912" x2="0.624" y2="0.1034" layer="21"/>
<rectangle x1="0.878" y1="0.0912" x2="1.0596" y2="0.1034" layer="21"/>
<rectangle x1="1.1684" y1="0.0912" x2="1.35" y2="0.1034" layer="21"/>
<rectangle x1="1.5191" y1="0.0912" x2="1.7368" y2="0.1034" layer="21"/>
<rectangle x1="2.1844" y1="0.0912" x2="2.3779" y2="0.1034" layer="21"/>
<rectangle x1="2.62" y1="0.0912" x2="2.8133" y2="0.1034" layer="21"/>
<rectangle x1="-2.968" y1="0.1034" x2="-2.315" y2="0.1153" layer="21"/>
<rectangle x1="-2.1941" y1="0.1034" x2="-2.0005" y2="0.1153" layer="21"/>
<rectangle x1="-1.7829" y1="0.1034" x2="-1.6013" y2="0.1153" layer="21"/>
<rectangle x1="-1.444" y1="0.1034" x2="-1.0328" y2="0.1153" layer="21"/>
<rectangle x1="-0.9967" y1="0.1034" x2="-0.8151" y2="0.1153" layer="21"/>
<rectangle x1="-0.6701" y1="0.1034" x2="-0.2708" y2="0.1153" layer="21"/>
<rectangle x1="-0.2589" y1="0.1034" x2="-0.0653" y2="0.1153" layer="21"/>
<rectangle x1="0.0315" y1="0.1034" x2="0.2128" y2="0.1153" layer="21"/>
<rectangle x1="0.4307" y1="0.1034" x2="0.624" y2="0.1153" layer="21"/>
<rectangle x1="0.878" y1="0.1034" x2="1.0596" y2="0.1153" layer="21"/>
<rectangle x1="1.1684" y1="0.1034" x2="1.35" y2="0.1153" layer="21"/>
<rectangle x1="1.5313" y1="0.1034" x2="1.749" y2="0.1153" layer="21"/>
<rectangle x1="2.1844" y1="0.1034" x2="2.3779" y2="0.1153" layer="21"/>
<rectangle x1="2.62" y1="0.1034" x2="2.8133" y2="0.1153" layer="21"/>
<rectangle x1="-2.968" y1="0.1153" x2="-2.315" y2="0.1275" layer="21"/>
<rectangle x1="-2.1941" y1="0.1153" x2="-1.9884" y2="0.1275" layer="21"/>
<rectangle x1="-1.8311" y1="0.1153" x2="-1.6013" y2="0.1275" layer="21"/>
<rectangle x1="-1.444" y1="0.1153" x2="-0.8151" y2="0.1275" layer="21"/>
<rectangle x1="-0.6701" y1="0.1153" x2="-0.0653" y2="0.1275" layer="21"/>
<rectangle x1="0.0315" y1="0.1153" x2="0.2128" y2="0.1275" layer="21"/>
<rectangle x1="0.4307" y1="0.1153" x2="0.6362" y2="0.1275" layer="21"/>
<rectangle x1="0.8539" y1="0.1153" x2="1.0596" y2="0.1275" layer="21"/>
<rectangle x1="1.1684" y1="0.1153" x2="1.35" y2="0.1275" layer="21"/>
<rectangle x1="1.5433" y1="0.1153" x2="1.749" y2="0.1275" layer="21"/>
<rectangle x1="2.1844" y1="0.1153" x2="2.3779" y2="0.1275" layer="21"/>
<rectangle x1="2.5593" y1="0.1153" x2="2.9464" y2="0.1275" layer="21"/>
<rectangle x1="-2.968" y1="0.1275" x2="-2.315" y2="0.1397" layer="21"/>
<rectangle x1="-2.1941" y1="0.1275" x2="-1.6013" y2="0.1397" layer="21"/>
<rectangle x1="-1.444" y1="0.1275" x2="-0.8151" y2="0.1397" layer="21"/>
<rectangle x1="-0.6701" y1="0.1275" x2="-0.0653" y2="0.1397" layer="21"/>
<rectangle x1="0.0315" y1="0.1275" x2="0.2128" y2="0.1397" layer="21"/>
<rectangle x1="0.4427" y1="0.1275" x2="1.0596" y2="0.1397" layer="21"/>
<rectangle x1="1.1684" y1="0.1275" x2="1.35" y2="0.1397" layer="21"/>
<rectangle x1="1.5433" y1="0.1275" x2="1.7612" y2="0.1397" layer="21"/>
<rectangle x1="2.1844" y1="0.1275" x2="2.3779" y2="0.1397" layer="21"/>
<rectangle x1="2.5351" y1="0.1275" x2="2.9585" y2="0.1397" layer="21"/>
<rectangle x1="-2.968" y1="0.1397" x2="-2.315" y2="0.1516" layer="21"/>
<rectangle x1="-2.1941" y1="0.1397" x2="-1.6135" y2="0.1516" layer="21"/>
<rectangle x1="-1.444" y1="0.1397" x2="-0.8151" y2="0.1516" layer="21"/>
<rectangle x1="-0.6701" y1="0.1397" x2="-0.0653" y2="0.1516" layer="21"/>
<rectangle x1="0.0315" y1="0.1397" x2="0.2128" y2="0.1516" layer="21"/>
<rectangle x1="0.4427" y1="0.1397" x2="1.0475" y2="0.1516" layer="21"/>
<rectangle x1="1.1684" y1="0.1397" x2="1.35" y2="0.1516" layer="21"/>
<rectangle x1="1.5555" y1="0.1397" x2="1.7612" y2="0.1516" layer="21"/>
<rectangle x1="2.1965" y1="0.1397" x2="2.3779" y2="0.1516" layer="21"/>
<rectangle x1="2.5351" y1="0.1397" x2="2.9707" y2="0.1516" layer="21"/>
<rectangle x1="-2.968" y1="0.1516" x2="-2.315" y2="0.1638" layer="21"/>
<rectangle x1="-2.1819" y1="0.1516" x2="-1.6135" y2="0.1638" layer="21"/>
<rectangle x1="-1.444" y1="0.1516" x2="-0.8151" y2="0.1638" layer="21"/>
<rectangle x1="-0.6701" y1="0.1516" x2="-0.0773" y2="0.1638" layer="21"/>
<rectangle x1="0.0315" y1="0.1516" x2="0.2128" y2="0.1638" layer="21"/>
<rectangle x1="0.4427" y1="0.1516" x2="1.0475" y2="0.1638" layer="21"/>
<rectangle x1="1.1684" y1="0.1516" x2="1.35" y2="0.1638" layer="21"/>
<rectangle x1="1.5555" y1="0.1516" x2="1.7731" y2="0.1638" layer="21"/>
<rectangle x1="2.1965" y1="0.1516" x2="2.3779" y2="0.1638" layer="21"/>
<rectangle x1="2.5351" y1="0.1516" x2="2.9707" y2="0.1638" layer="21"/>
<rectangle x1="-2.968" y1="0.1638" x2="-2.315" y2="0.1758" layer="21"/>
<rectangle x1="-2.1819" y1="0.1638" x2="-1.6256" y2="0.1758" layer="21"/>
<rectangle x1="-1.444" y1="0.1638" x2="-0.8151" y2="0.1758" layer="21"/>
<rectangle x1="-0.6701" y1="0.1638" x2="-0.0773" y2="0.1758" layer="21"/>
<rectangle x1="0.0315" y1="0.1638" x2="0.2128" y2="0.1758" layer="21"/>
<rectangle x1="0.4549" y1="0.1638" x2="1.0353" y2="0.1758" layer="21"/>
<rectangle x1="1.1684" y1="0.1638" x2="1.35" y2="0.1758" layer="21"/>
<rectangle x1="1.5676" y1="0.1638" x2="1.7853" y2="0.1758" layer="21"/>
<rectangle x1="2.1965" y1="0.1638" x2="2.3779" y2="0.1758" layer="21"/>
<rectangle x1="2.5232" y1="0.1638" x2="2.9707" y2="0.1758" layer="21"/>
<rectangle x1="-2.968" y1="0.1758" x2="-2.315" y2="0.188" layer="21"/>
<rectangle x1="-2.17" y1="0.1758" x2="-1.6256" y2="0.188" layer="21"/>
<rectangle x1="-1.444" y1="0.1758" x2="-0.8151" y2="0.188" layer="21"/>
<rectangle x1="-0.6701" y1="0.1758" x2="-0.0773" y2="0.188" layer="21"/>
<rectangle x1="0.0315" y1="0.1758" x2="0.2128" y2="0.188" layer="21"/>
<rectangle x1="0.4549" y1="0.1758" x2="1.0353" y2="0.188" layer="21"/>
<rectangle x1="1.1684" y1="0.1758" x2="1.35" y2="0.188" layer="21"/>
<rectangle x1="1.5796" y1="0.1758" x2="1.7853" y2="0.188" layer="21"/>
<rectangle x1="2.1965" y1="0.1758" x2="2.3779" y2="0.188" layer="21"/>
<rectangle x1="2.5232" y1="0.1758" x2="2.9707" y2="0.188" layer="21"/>
<rectangle x1="-2.9561" y1="0.188" x2="-2.315" y2="0.2001" layer="21"/>
<rectangle x1="-2.1578" y1="0.188" x2="-1.6376" y2="0.2001" layer="21"/>
<rectangle x1="-1.444" y1="0.188" x2="-0.8151" y2="0.2001" layer="21"/>
<rectangle x1="-0.6701" y1="0.188" x2="-0.0773" y2="0.2001" layer="21"/>
<rectangle x1="0.0315" y1="0.188" x2="0.2128" y2="0.2001" layer="21"/>
<rectangle x1="0.4668" y1="0.188" x2="1.0233" y2="0.2001" layer="21"/>
<rectangle x1="1.1684" y1="0.188" x2="1.35" y2="0.2001" layer="21"/>
<rectangle x1="1.5796" y1="0.188" x2="1.7853" y2="0.2001" layer="21"/>
<rectangle x1="2.1965" y1="0.188" x2="2.3779" y2="0.2001" layer="21"/>
<rectangle x1="2.5232" y1="0.188" x2="2.9707" y2="0.2001" layer="21"/>
<rectangle x1="-2.9561" y1="0.2001" x2="-2.315" y2="0.2121" layer="21"/>
<rectangle x1="-2.1578" y1="0.2001" x2="-1.6498" y2="0.2121" layer="21"/>
<rectangle x1="-1.444" y1="0.2001" x2="-0.8273" y2="0.2121" layer="21"/>
<rectangle x1="-0.6701" y1="0.2001" x2="-0.0895" y2="0.2121" layer="21"/>
<rectangle x1="0.0315" y1="0.2001" x2="0.2128" y2="0.2121" layer="21"/>
<rectangle x1="0.479" y1="0.2001" x2="1.0233" y2="0.2121" layer="21"/>
<rectangle x1="1.1684" y1="0.2001" x2="1.35" y2="0.2121" layer="21"/>
<rectangle x1="1.5918" y1="0.2001" x2="1.7973" y2="0.2121" layer="21"/>
<rectangle x1="2.1965" y1="0.2001" x2="2.3779" y2="0.2121" layer="21"/>
<rectangle x1="2.5232" y1="0.2001" x2="2.9707" y2="0.2121" layer="21"/>
<rectangle x1="-2.9561" y1="0.2121" x2="-2.3272" y2="0.2243" layer="21"/>
<rectangle x1="-2.1456" y1="0.2121" x2="-1.6498" y2="0.2243" layer="21"/>
<rectangle x1="-1.444" y1="0.2121" x2="-0.8273" y2="0.2243" layer="21"/>
<rectangle x1="-0.6701" y1="0.2121" x2="-0.0895" y2="0.2243" layer="21"/>
<rectangle x1="0.0315" y1="0.2121" x2="0.2128" y2="0.2243" layer="21"/>
<rectangle x1="0.4912" y1="0.2121" x2="1.0111" y2="0.2243" layer="21"/>
<rectangle x1="1.1684" y1="0.2121" x2="1.35" y2="0.2243" layer="21"/>
<rectangle x1="1.5918" y1="0.2121" x2="1.8095" y2="0.2243" layer="21"/>
<rectangle x1="2.1965" y1="0.2121" x2="2.3779" y2="0.2243" layer="21"/>
<rectangle x1="2.5232" y1="0.2121" x2="2.9707" y2="0.2243" layer="21"/>
<rectangle x1="-2.932" y1="0.2243" x2="-2.3391" y2="0.2365" layer="21"/>
<rectangle x1="-2.1336" y1="0.2243" x2="-1.662" y2="0.2365" layer="21"/>
<rectangle x1="-1.444" y1="0.2243" x2="-1.2627" y2="0.2365" layer="21"/>
<rectangle x1="-1.2507" y1="0.2243" x2="-0.8273" y2="0.2365" layer="21"/>
<rectangle x1="-0.6701" y1="0.2243" x2="-0.4887" y2="0.2365" layer="21"/>
<rectangle x1="-0.4765" y1="0.2243" x2="-0.1016" y2="0.2365" layer="21"/>
<rectangle x1="0.0315" y1="0.2243" x2="0.2128" y2="0.2365" layer="21"/>
<rectangle x1="0.5031" y1="0.2243" x2="0.9992" y2="0.2365" layer="21"/>
<rectangle x1="1.1684" y1="0.2243" x2="1.35" y2="0.2365" layer="21"/>
<rectangle x1="1.604" y1="0.2243" x2="1.8095" y2="0.2365" layer="21"/>
<rectangle x1="2.1965" y1="0.2243" x2="2.3779" y2="0.2365" layer="21"/>
<rectangle x1="2.5232" y1="0.2243" x2="2.9707" y2="0.2365" layer="21"/>
<rectangle x1="-2.8108" y1="0.2365" x2="-2.569" y2="0.2484" layer="21"/>
<rectangle x1="-2.1093" y1="0.2365" x2="-1.6739" y2="0.2484" layer="21"/>
<rectangle x1="-1.444" y1="0.2365" x2="-1.2627" y2="0.2484" layer="21"/>
<rectangle x1="-1.2264" y1="0.2365" x2="-0.8393" y2="0.2484" layer="21"/>
<rectangle x1="-0.6701" y1="0.2365" x2="-0.4887" y2="0.2484" layer="21"/>
<rectangle x1="-0.4524" y1="0.2365" x2="-0.1136" y2="0.2484" layer="21"/>
<rectangle x1="0.0315" y1="0.2365" x2="0.2128" y2="0.2484" layer="21"/>
<rectangle x1="0.5153" y1="0.2365" x2="0.987" y2="0.2484" layer="21"/>
<rectangle x1="1.1684" y1="0.2365" x2="1.35" y2="0.2484" layer="21"/>
<rectangle x1="1.6159" y1="0.2365" x2="1.8095" y2="0.2484" layer="21"/>
<rectangle x1="2.1965" y1="0.2365" x2="2.3779" y2="0.2484" layer="21"/>
<rectangle x1="2.5232" y1="0.2365" x2="2.9707" y2="0.2484" layer="21"/>
<rectangle x1="-2.7867" y1="0.2484" x2="-2.5931" y2="0.2606" layer="21"/>
<rectangle x1="-2.0973" y1="0.2484" x2="-1.6861" y2="0.2606" layer="21"/>
<rectangle x1="-1.444" y1="0.2484" x2="-1.2627" y2="0.2606" layer="21"/>
<rectangle x1="-1.19" y1="0.2484" x2="-0.8515" y2="0.2606" layer="21"/>
<rectangle x1="-0.6701" y1="0.2484" x2="-0.4887" y2="0.2606" layer="21"/>
<rectangle x1="-0.4161" y1="0.2484" x2="-0.1258" y2="0.2606" layer="21"/>
<rectangle x1="0.0315" y1="0.2484" x2="0.2128" y2="0.2606" layer="21"/>
<rectangle x1="0.5273" y1="0.2484" x2="0.9748" y2="0.2606" layer="21"/>
<rectangle x1="1.1684" y1="0.2484" x2="1.35" y2="0.2606" layer="21"/>
<rectangle x1="1.6159" y1="0.2484" x2="1.8095" y2="0.2606" layer="21"/>
<rectangle x1="2.1965" y1="0.2484" x2="2.366" y2="0.2606" layer="21"/>
<rectangle x1="2.5232" y1="0.2484" x2="2.9707" y2="0.2606" layer="21"/>
<rectangle x1="-2.7867" y1="0.2606" x2="-2.5931" y2="0.2725" layer="21"/>
<rectangle x1="-2.0851" y1="0.2606" x2="-1.698" y2="0.2725" layer="21"/>
<rectangle x1="-1.444" y1="0.2606" x2="-1.2627" y2="0.2725" layer="21"/>
<rectangle x1="-1.154" y1="0.2606" x2="-0.8636" y2="0.2725" layer="21"/>
<rectangle x1="-0.6579" y1="0.2606" x2="-0.4887" y2="0.2725" layer="21"/>
<rectangle x1="-0.392" y1="0.2606" x2="-0.138" y2="0.2725" layer="21"/>
<rectangle x1="0.0436" y1="0.2606" x2="0.2128" y2="0.2725" layer="21"/>
<rectangle x1="0.5516" y1="0.2606" x2="0.9629" y2="0.2725" layer="21"/>
<rectangle x1="1.1684" y1="0.2606" x2="1.35" y2="0.2725" layer="21"/>
<rectangle x1="1.6281" y1="0.2606" x2="1.8095" y2="0.2725" layer="21"/>
<rectangle x1="2.1965" y1="0.2606" x2="2.366" y2="0.2725" layer="21"/>
<rectangle x1="2.5351" y1="0.2606" x2="2.9707" y2="0.2725" layer="21"/>
<rectangle x1="-2.7867" y1="0.2725" x2="-2.6053" y2="0.2847" layer="21"/>
<rectangle x1="-2.061" y1="0.2725" x2="-1.7102" y2="0.2847" layer="21"/>
<rectangle x1="-1.444" y1="0.2725" x2="-1.2627" y2="0.2847" layer="21"/>
<rectangle x1="-1.1176" y1="0.2725" x2="-0.8756" y2="0.2847" layer="21"/>
<rectangle x1="-0.646" y1="0.2725" x2="-0.5007" y2="0.2847" layer="21"/>
<rectangle x1="-0.3556" y1="0.2725" x2="-0.1499" y2="0.2847" layer="21"/>
<rectangle x1="0.0436" y1="0.2725" x2="0.2009" y2="0.2847" layer="21"/>
<rectangle x1="0.5636" y1="0.2725" x2="0.9507" y2="0.2847" layer="21"/>
<rectangle x1="1.1684" y1="0.2725" x2="1.35" y2="0.2847" layer="21"/>
<rectangle x1="1.64" y1="0.2725" x2="1.8095" y2="0.2847" layer="21"/>
<rectangle x1="2.2087" y1="0.2725" x2="2.3538" y2="0.2847" layer="21"/>
<rectangle x1="2.5473" y1="0.2725" x2="2.9585" y2="0.2847" layer="21"/>
<rectangle x1="-2.7747" y1="0.2847" x2="-2.6053" y2="0.2969" layer="21"/>
<rectangle x1="-2.0369" y1="0.2847" x2="-1.7344" y2="0.2969" layer="21"/>
<rectangle x1="-1.444" y1="0.2847" x2="-1.2627" y2="0.2969" layer="21"/>
<rectangle x1="-1.0813" y1="0.2847" x2="-0.8878" y2="0.2969" layer="21"/>
<rectangle x1="-0.6338" y1="0.2847" x2="-0.5248" y2="0.2969" layer="21"/>
<rectangle x1="-0.3193" y1="0.2847" x2="-0.1621" y2="0.2969" layer="21"/>
<rectangle x1="0.0556" y1="0.2847" x2="0.1887" y2="0.2969" layer="21"/>
<rectangle x1="0.588" y1="0.2847" x2="0.9265" y2="0.2969" layer="21"/>
<rectangle x1="1.1684" y1="0.2847" x2="1.35" y2="0.2969" layer="21"/>
<rectangle x1="1.6644" y1="0.2847" x2="1.7853" y2="0.2969" layer="21"/>
<rectangle x1="2.2207" y1="0.2847" x2="2.3538" y2="0.2969" layer="21"/>
<rectangle x1="2.5593" y1="0.2847" x2="2.9464" y2="0.2969" layer="21"/>
<rectangle x1="-2.7747" y1="0.2969" x2="-2.6053" y2="0.3089" layer="21"/>
<rectangle x1="-2.0005" y1="0.2969" x2="-1.7587" y2="0.3089" layer="21"/>
<rectangle x1="-1.444" y1="0.2969" x2="-1.2627" y2="0.3089" layer="21"/>
<rectangle x1="-1.0328" y1="0.2969" x2="-0.9241" y2="0.3089" layer="21"/>
<rectangle x1="-0.2708" y1="0.2969" x2="-0.1862" y2="0.3089" layer="21"/>
<rectangle x1="0.624" y1="0.2969" x2="0.9024" y2="0.3089" layer="21"/>
<rectangle x1="1.1684" y1="0.2969" x2="1.35" y2="0.3089" layer="21"/>
<rectangle x1="2.62" y1="0.2969" x2="2.8133" y2="0.3089" layer="21"/>
<rectangle x1="-2.7747" y1="0.3089" x2="-2.6053" y2="0.321" layer="21"/>
<rectangle x1="-1.444" y1="0.3089" x2="-1.2627" y2="0.321" layer="21"/>
<rectangle x1="1.1684" y1="0.3089" x2="1.35" y2="0.321" layer="21"/>
<rectangle x1="2.62" y1="0.3089" x2="2.8133" y2="0.321" layer="21"/>
<rectangle x1="-2.7747" y1="0.321" x2="-2.6053" y2="0.3332" layer="21"/>
<rectangle x1="-1.444" y1="0.321" x2="-1.2627" y2="0.3332" layer="21"/>
<rectangle x1="1.1684" y1="0.321" x2="1.35" y2="0.3332" layer="21"/>
<rectangle x1="2.62" y1="0.321" x2="2.8133" y2="0.3332" layer="21"/>
<rectangle x1="-2.7747" y1="0.3332" x2="-2.6053" y2="0.3452" layer="21"/>
<rectangle x1="-1.444" y1="0.3332" x2="-1.2627" y2="0.3452" layer="21"/>
<rectangle x1="1.1684" y1="0.3332" x2="1.35" y2="0.3452" layer="21"/>
<rectangle x1="2.6319" y1="0.3332" x2="2.8133" y2="0.3452" layer="21"/>
<rectangle x1="-2.7747" y1="0.3452" x2="-2.5931" y2="0.3574" layer="21"/>
<rectangle x1="-1.444" y1="0.3452" x2="-1.2627" y2="0.3574" layer="21"/>
<rectangle x1="1.1684" y1="0.3452" x2="1.35" y2="0.3574" layer="21"/>
<rectangle x1="2.6319" y1="0.3452" x2="2.8133" y2="0.3574" layer="21"/>
<rectangle x1="-2.7747" y1="0.3574" x2="-2.5931" y2="0.3693" layer="21"/>
<rectangle x1="-1.444" y1="0.3574" x2="-1.2627" y2="0.3693" layer="21"/>
<rectangle x1="1.1684" y1="0.3574" x2="1.35" y2="0.3693" layer="21"/>
<rectangle x1="2.6319" y1="0.3574" x2="2.8133" y2="0.3693" layer="21"/>
<rectangle x1="-2.7747" y1="0.3693" x2="-2.5931" y2="0.3815" layer="21"/>
<rectangle x1="-1.444" y1="0.3693" x2="-1.2627" y2="0.3815" layer="21"/>
<rectangle x1="0.0556" y1="0.3693" x2="0.1887" y2="0.3815" layer="21"/>
<rectangle x1="1.1684" y1="0.3693" x2="1.35" y2="0.3815" layer="21"/>
<rectangle x1="2.2207" y1="0.3693" x2="2.3538" y2="0.3815" layer="21"/>
<rectangle x1="2.6319" y1="0.3693" x2="2.8133" y2="0.3815" layer="21"/>
<rectangle x1="-2.7747" y1="0.3815" x2="-2.5931" y2="0.3937" layer="21"/>
<rectangle x1="-1.444" y1="0.3815" x2="-1.2627" y2="0.3937" layer="21"/>
<rectangle x1="0.0436" y1="0.3815" x2="0.2009" y2="0.3937" layer="21"/>
<rectangle x1="1.1684" y1="0.3815" x2="1.35" y2="0.3937" layer="21"/>
<rectangle x1="2.1965" y1="0.3815" x2="2.366" y2="0.3937" layer="21"/>
<rectangle x1="2.6319" y1="0.3815" x2="2.8133" y2="0.3937" layer="21"/>
<rectangle x1="-2.7747" y1="0.3937" x2="-2.5931" y2="0.4056" layer="21"/>
<rectangle x1="-1.444" y1="0.3937" x2="-1.2627" y2="0.4056" layer="21"/>
<rectangle x1="0.0315" y1="0.3937" x2="0.2128" y2="0.4056" layer="21"/>
<rectangle x1="1.1684" y1="0.3937" x2="1.35" y2="0.4056" layer="21"/>
<rectangle x1="2.1965" y1="0.3937" x2="2.366" y2="0.4056" layer="21"/>
<rectangle x1="2.6319" y1="0.3937" x2="2.8133" y2="0.4056" layer="21"/>
<rectangle x1="-2.7747" y1="0.4056" x2="-2.5931" y2="0.4178" layer="21"/>
<rectangle x1="-1.444" y1="0.4056" x2="-1.2627" y2="0.4178" layer="21"/>
<rectangle x1="0.0315" y1="0.4056" x2="0.2128" y2="0.4178" layer="21"/>
<rectangle x1="1.1684" y1="0.4056" x2="1.35" y2="0.4178" layer="21"/>
<rectangle x1="2.1965" y1="0.4056" x2="2.3779" y2="0.4178" layer="21"/>
<rectangle x1="2.6319" y1="0.4056" x2="2.8133" y2="0.4178" layer="21"/>
<rectangle x1="-2.7747" y1="0.4178" x2="-2.5931" y2="0.4298" layer="21"/>
<rectangle x1="-1.444" y1="0.4178" x2="-1.2627" y2="0.4298" layer="21"/>
<rectangle x1="0.0315" y1="0.4178" x2="0.2128" y2="0.4298" layer="21"/>
<rectangle x1="1.1684" y1="0.4178" x2="1.35" y2="0.4298" layer="21"/>
<rectangle x1="2.1965" y1="0.4178" x2="2.3779" y2="0.4298" layer="21"/>
<rectangle x1="2.6319" y1="0.4178" x2="2.8133" y2="0.4298" layer="21"/>
<rectangle x1="-2.7747" y1="0.4298" x2="-2.5931" y2="0.442" layer="21"/>
<rectangle x1="-1.444" y1="0.4298" x2="-1.2627" y2="0.442" layer="21"/>
<rectangle x1="0.0315" y1="0.4298" x2="0.2128" y2="0.442" layer="21"/>
<rectangle x1="1.1684" y1="0.4298" x2="1.35" y2="0.442" layer="21"/>
<rectangle x1="2.1965" y1="0.4298" x2="2.3779" y2="0.442" layer="21"/>
<rectangle x1="2.6319" y1="0.4298" x2="2.8133" y2="0.442" layer="21"/>
<rectangle x1="-2.7747" y1="0.442" x2="-2.5931" y2="0.4541" layer="21"/>
<rectangle x1="-1.444" y1="0.442" x2="-1.2627" y2="0.4541" layer="21"/>
<rectangle x1="0.0315" y1="0.442" x2="0.2128" y2="0.4541" layer="21"/>
<rectangle x1="1.1684" y1="0.442" x2="1.35" y2="0.4541" layer="21"/>
<rectangle x1="2.1965" y1="0.442" x2="2.3779" y2="0.4541" layer="21"/>
<rectangle x1="2.6319" y1="0.442" x2="2.8013" y2="0.4541" layer="21"/>
<rectangle x1="-2.7747" y1="0.4541" x2="-2.5931" y2="0.4661" layer="21"/>
<rectangle x1="-1.444" y1="0.4541" x2="-1.2627" y2="0.4661" layer="21"/>
<rectangle x1="0.0315" y1="0.4541" x2="0.2128" y2="0.4661" layer="21"/>
<rectangle x1="1.1684" y1="0.4541" x2="1.35" y2="0.4661" layer="21"/>
<rectangle x1="2.1965" y1="0.4541" x2="2.3779" y2="0.4661" layer="21"/>
<rectangle x1="2.6319" y1="0.4541" x2="2.8013" y2="0.4661" layer="21"/>
<rectangle x1="-2.7747" y1="0.4661" x2="-2.5931" y2="0.4783" layer="21"/>
<rectangle x1="-1.444" y1="0.4661" x2="-1.2627" y2="0.4783" layer="21"/>
<rectangle x1="0.0315" y1="0.4661" x2="0.2128" y2="0.4783" layer="21"/>
<rectangle x1="1.1684" y1="0.4661" x2="1.35" y2="0.4783" layer="21"/>
<rectangle x1="2.1965" y1="0.4661" x2="2.3779" y2="0.4783" layer="21"/>
<rectangle x1="2.6441" y1="0.4661" x2="2.7891" y2="0.4783" layer="21"/>
<rectangle x1="-2.7747" y1="0.4783" x2="-2.5931" y2="0.4905" layer="21"/>
<rectangle x1="-1.444" y1="0.4783" x2="-1.2627" y2="0.4905" layer="21"/>
<rectangle x1="0.0315" y1="0.4783" x2="0.2128" y2="0.4905" layer="21"/>
<rectangle x1="1.1684" y1="0.4783" x2="1.35" y2="0.4905" layer="21"/>
<rectangle x1="2.1965" y1="0.4783" x2="2.3779" y2="0.4905" layer="21"/>
<rectangle x1="2.6682" y1="0.4783" x2="2.7772" y2="0.4905" layer="21"/>
<rectangle x1="-2.7747" y1="0.4905" x2="-2.5931" y2="0.5024" layer="21"/>
<rectangle x1="-1.444" y1="0.4905" x2="-1.2627" y2="0.5024" layer="21"/>
<rectangle x1="0.0315" y1="0.4905" x2="0.2128" y2="0.5024" layer="21"/>
<rectangle x1="1.1684" y1="0.4905" x2="1.35" y2="0.5024" layer="21"/>
<rectangle x1="2.1965" y1="0.4905" x2="2.3779" y2="0.5024" layer="21"/>
<rectangle x1="-2.7747" y1="0.5024" x2="-2.5812" y2="0.5146" layer="21"/>
<rectangle x1="-1.444" y1="0.5024" x2="-1.2627" y2="0.5146" layer="21"/>
<rectangle x1="0.0315" y1="0.5024" x2="0.2128" y2="0.5146" layer="21"/>
<rectangle x1="1.1684" y1="0.5024" x2="1.35" y2="0.5146" layer="21"/>
<rectangle x1="2.1965" y1="0.5024" x2="2.3779" y2="0.5146" layer="21"/>
<rectangle x1="-2.7747" y1="0.5146" x2="-2.5812" y2="0.5265" layer="21"/>
<rectangle x1="-1.444" y1="0.5146" x2="-1.2627" y2="0.5265" layer="21"/>
<rectangle x1="0.0315" y1="0.5146" x2="0.2128" y2="0.5265" layer="21"/>
<rectangle x1="1.1684" y1="0.5146" x2="1.35" y2="0.5265" layer="21"/>
<rectangle x1="2.1965" y1="0.5146" x2="2.3779" y2="0.5265" layer="21"/>
<rectangle x1="-2.7747" y1="0.5265" x2="-2.5812" y2="0.5387" layer="21"/>
<rectangle x1="-1.444" y1="0.5265" x2="-1.2749" y2="0.5387" layer="21"/>
<rectangle x1="0.0315" y1="0.5265" x2="0.2128" y2="0.5387" layer="21"/>
<rectangle x1="1.1805" y1="0.5265" x2="1.35" y2="0.5387" layer="21"/>
<rectangle x1="2.1965" y1="0.5265" x2="2.366" y2="0.5387" layer="21"/>
<rectangle x1="-2.7747" y1="0.5387" x2="-2.569" y2="0.5509" layer="21"/>
<rectangle x1="-1.4321" y1="0.5387" x2="-1.2749" y2="0.5509" layer="21"/>
<rectangle x1="0.0436" y1="0.5387" x2="0.2009" y2="0.5509" layer="21"/>
<rectangle x1="1.1805" y1="0.5387" x2="1.3378" y2="0.5509" layer="21"/>
<rectangle x1="2.1965" y1="0.5387" x2="2.366" y2="0.5509" layer="21"/>
<rectangle x1="-2.7625" y1="0.5509" x2="-2.569" y2="0.5629" layer="21"/>
<rectangle x1="-1.4199" y1="0.5509" x2="-1.2868" y2="0.5629" layer="21"/>
<rectangle x1="0.0556" y1="0.5509" x2="0.1887" y2="0.5629" layer="21"/>
<rectangle x1="1.1927" y1="0.5509" x2="1.3256" y2="0.5629" layer="21"/>
<rectangle x1="2.2087" y1="0.5509" x2="2.3538" y2="0.5629" layer="21"/>
<rectangle x1="-2.7625" y1="0.5629" x2="-2.5449" y2="0.575" layer="21"/>
<rectangle x1="-1.3958" y1="0.5629" x2="-1.3112" y2="0.575" layer="21"/>
<rectangle x1="0.08" y1="0.5629" x2="0.1645" y2="0.575" layer="21"/>
<rectangle x1="1.2169" y1="0.5629" x2="1.3136" y2="0.575" layer="21"/>
<rectangle x1="2.2329" y1="0.5629" x2="2.3296" y2="0.575" layer="21"/>
<rectangle x1="-2.7504" y1="0.575" x2="-2.2787" y2="0.5872" layer="21"/>
<rectangle x1="-2.7504" y1="0.5872" x2="-2.2667" y2="0.5992" layer="21"/>
<rectangle x1="-2.7384" y1="0.5992" x2="-2.2545" y2="0.6114" layer="21"/>
<rectangle x1="-2.7262" y1="0.6114" x2="-2.2545" y2="0.6233" layer="21"/>
<rectangle x1="-2.714" y1="0.6233" x2="-2.2545" y2="0.6355" layer="21"/>
<rectangle x1="-2.7021" y1="0.6355" x2="-2.2545" y2="0.6477" layer="21"/>
<rectangle x1="-2.6899" y1="0.6477" x2="-2.2545" y2="0.6596" layer="21"/>
<rectangle x1="-2.678" y1="0.6596" x2="-2.2545" y2="0.6718" layer="21"/>
<rectangle x1="-2.6658" y1="0.6718" x2="-2.2545" y2="0.6838" layer="21"/>
<rectangle x1="-2.6416" y1="0.6838" x2="-2.2545" y2="0.696" layer="21"/>
<rectangle x1="-2.6295" y1="0.696" x2="-2.2545" y2="0.7081" layer="21"/>
<rectangle x1="-2.6053" y1="0.7081" x2="-2.2545" y2="0.7201" layer="21"/>
<rectangle x1="-2.5812" y1="0.7201" x2="-2.2545" y2="0.7323" layer="21"/>
<rectangle x1="-2.5568" y1="0.7323" x2="-2.2667" y2="0.7445" layer="21"/>
<rectangle x1="-2.5207" y1="0.7445" x2="-2.2787" y2="0.7564" layer="21"/>
</package>
<package name="FKIT-LOGOTYPE_VERY_SMALL">
<wire x1="-0.4318" y1="0.1524" x2="-0.4318" y2="0.0508" width="0.127" layer="21"/>
<wire x1="-0.4318" y1="0.0508" x2="-0.4318" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="-0.4318" y1="0.0508" x2="-0.1778" y2="0.1524" width="0.127" layer="21"/>
<wire x1="-0.1778" y1="0.1524" x2="-0.127" y2="0.127" width="0.127" layer="21"/>
<wire x1="-0.127" y1="0.127" x2="-0.127" y2="0.0254" width="0.127" layer="21"/>
<wire x1="0.0508" y1="0.1524" x2="0.0508" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.0508" y1="-0.254" x2="0.127" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="0.127" y1="-0.3302" x2="0.1778" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="0.0508" y1="0.3556" x2="0.0508" y2="0.3048" width="0.127" layer="21"/>
<wire x1="0.6604" y1="0.0254" x2="0.6604" y2="0.0762" width="0.127" layer="21"/>
<wire x1="0.6604" y1="0.0762" x2="0.5842" y2="0.1524" width="0.127" layer="21"/>
<wire x1="0.5842" y1="0.1524" x2="0.4318" y2="0.1524" width="0.127" layer="21"/>
<wire x1="0.4318" y1="0.1524" x2="0.3302" y2="0.0762" width="0.127" layer="21"/>
<wire x1="0.3302" y1="0.0762" x2="0.3302" y2="-0.2286" width="0.127" layer="21"/>
<wire x1="0.3302" y1="-0.2286" x2="0.4064" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="0.4064" y1="-0.3302" x2="0.5588" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="0.5588" y1="-0.3302" x2="0.6604" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.6604" y1="-0.254" x2="0.6604" y2="-0.2032" width="0.127" layer="21"/>
<wire x1="0.8636" y1="0.3556" x2="0.8636" y2="-0.0762" width="0.127" layer="21"/>
<wire x1="0.8636" y1="-0.0762" x2="0.8636" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="0.8636" y1="-0.0762" x2="1.0414" y2="-0.0762" width="0.127" layer="21"/>
<wire x1="1.1684" y1="0.1524" x2="1.0414" y2="-0.0762" width="0.127" layer="21"/>
<wire x1="1.0414" y1="-0.0762" x2="1.2192" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="1.397" y1="0.1524" x2="1.397" y2="-0.254" width="0.127" layer="21"/>
<wire x1="1.397" y1="-0.254" x2="1.4732" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="1.4732" y1="-0.3302" x2="1.524" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="1.397" y1="0.3556" x2="1.397" y2="0.3048" width="0.127" layer="21"/>
<wire x1="1.7018" y1="0.2794" x2="1.7018" y2="-0.254" width="0.127" layer="21"/>
<wire x1="1.7018" y1="-0.254" x2="1.7526" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="1.7526" y1="-0.3302" x2="1.8034" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="1.6002" y1="0.127" x2="1.8288" y2="0.127" width="0.127" layer="21"/>
<wire x1="-0.9652" y1="0.3556" x2="-0.9652" y2="0.0508" width="0.127" layer="21"/>
<wire x1="-0.9652" y1="0.0508" x2="-0.9652" y2="-0.2794" width="0.127" layer="21"/>
<wire x1="-0.9652" y1="-0.2794" x2="-0.9144" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="-0.9144" y1="-0.3302" x2="-0.7366" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="-0.7366" y1="-0.3302" x2="-0.6604" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.6604" y1="-0.254" x2="-0.6604" y2="0.1524" width="0.127" layer="21"/>
<wire x1="-0.6604" y1="0.1524" x2="-0.9652" y2="0.0508" width="0.127" layer="21"/>
<wire x1="-1.4986" y1="0.0762" x2="-1.4224" y2="0.1524" width="0.127" layer="21"/>
<wire x1="-1.4224" y1="0.1524" x2="-1.27" y2="0.1524" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0.1524" x2="-1.1938" y2="0.0762" width="0.127" layer="21"/>
<wire x1="-1.1938" y1="0.0762" x2="-1.1938" y2="-0.0508" width="0.127" layer="21"/>
<wire x1="-1.1938" y1="-0.0508" x2="-1.1938" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-1.1938" y1="-0.254" x2="-1.1938" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="-1.1938" y1="-0.0508" x2="-1.4986" y2="-0.1016" width="0.127" layer="21"/>
<wire x1="-1.4986" y1="-0.1016" x2="-1.524" y2="-0.127" width="0.127" layer="21"/>
<wire x1="-1.524" y1="-0.127" x2="-1.524" y2="-0.2794" width="0.127" layer="21"/>
<wire x1="-1.524" y1="-0.2794" x2="-1.4732" y2="-0.3302" width="0.127" layer="21"/>
<wire x1="-1.4732" y1="-0.3302" x2="-1.1938" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-1.9558" y1="-0.6858" x2="-1.905" y2="-0.6096" width="0.127" layer="21"/>
<wire x1="-1.905" y1="-0.6096" x2="-1.905" y2="0.381" width="0.127" layer="21"/>
<wire x1="-1.905" y1="0.381" x2="-1.8288" y2="0.4572" width="0.127" layer="21"/>
<wire x1="-1.8288" y1="0.4572" x2="-1.651" y2="0.4572" width="0.127" layer="21"/>
<wire x1="-2.032" y1="0.0762" x2="-1.7018" y2="0.0762" width="0.127" layer="21"/>
</package>
<package name="FKIT-LOGOTYPE_MEDIUM">
<wire x1="-5.1308" y1="1.8542" x2="-5.6134" y2="1.8542" width="0.4064" layer="21"/>
<wire x1="-5.6134" y1="1.8542" x2="-5.8166" y2="1.778" width="0.4064" layer="21"/>
<wire x1="-5.8166" y1="1.778" x2="-5.9436" y2="1.6764" width="0.4064" layer="21"/>
<wire x1="-5.9436" y1="1.6764" x2="-5.9944" y2="1.6256" width="0.4064" layer="21"/>
<wire x1="-5.9944" y1="1.6256" x2="-5.9944" y2="1.5748" width="0.4064" layer="21"/>
<wire x1="-6.0198" y1="1.0922" x2="-6.0198" y2="0.1778" width="0.4064" layer="21"/>
<wire x1="-6.5024" y1="0.635" x2="-5.3594" y2="0.635" width="0.4064" layer="21"/>
<wire x1="-6.0198" y1="-0.3556" x2="-6.0198" y2="-1.5748" width="0.4064" layer="21"/>
<wire x1="-6.0198" y1="-1.5748" x2="-6.096" y2="-1.7526" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="-1.7526" x2="-6.1976" y2="-1.8796" width="0.4064" layer="21"/>
<wire x1="-4.6482" y1="0.6096" x2="-4.4958" y2="0.7874" width="0.4064" layer="21"/>
<wire x1="-4.4958" y1="0.7874" x2="-4.4196" y2="0.8128" width="0.4064" layer="21"/>
<wire x1="-4.4196" y1="0.8128" x2="-3.9878" y2="0.8128" width="0.4064" layer="21"/>
<wire x1="-3.9878" y1="0.8128" x2="-3.8608" y2="0.7874" width="0.4064" layer="21"/>
<wire x1="-3.8608" y1="0.7874" x2="-3.683" y2="0.5588" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="0.5588" x2="-3.683" y2="-0.4318" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="-0.4318" x2="-3.683" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-3.7084" y1="0.1778" x2="-4.6228" y2="0.0254" width="0.4064" layer="21"/>
<wire x1="-4.6228" y1="0.0254" x2="-4.699" y2="-0.1016" width="0.4064" layer="21"/>
<wire x1="-4.699" y1="-0.1016" x2="-4.7244" y2="-0.2286" width="0.4064" layer="21"/>
<wire x1="-4.7244" y1="-0.2286" x2="-4.7244" y2="-0.6096" width="0.4064" layer="21"/>
<wire x1="-4.7244" y1="-0.6096" x2="-4.6228" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-4.6228" y1="-0.7112" x2="-4.4958" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-4.4958" y1="-0.7112" x2="-3.683" y2="-0.4318" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="1.4732" x2="-2.921" y2="-0.4318" width="0.4064" layer="21"/>
<wire x1="-2.921" y1="-0.4318" x2="-2.8194" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="-2.8194" y1="-0.635" x2="-2.7178" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-2.7178" y1="-0.7112" x2="-2.1336" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-2.1336" y1="-0.7112" x2="-1.8796" y2="-0.4572" width="0.4064" layer="21"/>
<wire x1="-1.8796" y1="-0.4572" x2="-1.8796" y2="0.8382" width="0.4064" layer="21"/>
<wire x1="-1.8796" y1="0.8382" x2="-1.9304" y2="0.8382" width="0.4064" layer="21"/>
<wire x1="-1.9304" y1="0.8382" x2="-2.8702" y2="0.5334" width="0.4064" layer="21"/>
<wire x1="-1.0922" y1="0.8128" x2="-1.0922" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="-1.0414" y1="0.5588" x2="-0.3048" y2="0.8382" width="0.4064" layer="21"/>
<wire x1="-0.3048" y1="0.8382" x2="-0.1778" y2="0.7366" width="0.4064" layer="21"/>
<wire x1="-0.1778" y1="0.7366" x2="-0.127" y2="0.6604" width="0.4064" layer="21"/>
<wire x1="-0.127" y1="0.6604" x2="-0.127" y2="0.4318" width="0.4064" layer="21"/>
<wire x1="0.5334" y1="1.4732" x2="0.5334" y2="1.3716" width="0.4064" layer="21"/>
<wire x1="0.5334" y1="0.8128" x2="0.5334" y2="-0.4572" width="0.4064" layer="21"/>
<wire x1="0.5334" y1="-0.4572" x2="0.635" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.7112" y2="-0.6858" width="0.4064" layer="21"/>
<wire x1="0.7112" y1="-0.6858" x2="0.762" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="0.762" y1="-0.7112" x2="0.889" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="2.5146" y1="0.4064" x2="2.5146" y2="0.5334" width="0.4064" layer="21"/>
<wire x1="2.5146" y1="0.5334" x2="2.4384" y2="0.6604" width="0.4064" layer="21"/>
<wire x1="2.4384" y1="0.6604" x2="2.286" y2="0.8128" width="0.4064" layer="21"/>
<wire x1="2.286" y1="0.8128" x2="1.778" y2="0.8128" width="0.4064" layer="21"/>
<wire x1="1.778" y1="0.8128" x2="1.651" y2="0.762" width="0.4064" layer="21"/>
<wire x1="1.651" y1="0.762" x2="1.4986" y2="0.6096" width="0.4064" layer="21"/>
<wire x1="1.4986" y1="0.6096" x2="1.4732" y2="0.508" width="0.4064" layer="21"/>
<wire x1="1.4732" y1="0.508" x2="1.4732" y2="-0.4064" width="0.4064" layer="21"/>
<wire x1="1.4732" y1="-0.4064" x2="1.4986" y2="-0.508" width="0.4064" layer="21"/>
<wire x1="1.4986" y1="-0.508" x2="1.651" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="1.651" y1="-0.7112" x2="2.2352" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="2.2352" y1="-0.7112" x2="2.4384" y2="-0.5842" width="0.4064" layer="21"/>
<wire x1="2.4384" y1="-0.5842" x2="2.5146" y2="-0.508" width="0.4064" layer="21"/>
<wire x1="2.5146" y1="-0.508" x2="2.5146" y2="-0.3302" width="0.4064" layer="21"/>
<wire x1="3.2004" y1="1.4478" x2="3.2004" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="3.2258" y1="0.127" x2="3.8354" y2="0.127" width="0.4064" layer="21"/>
<wire x1="3.8354" y1="0.127" x2="4.2418" y2="0.8382" width="0.4064" layer="21"/>
<wire x1="4.3688" y1="-0.7366" x2="3.81" y2="0.1016" width="0.4064" layer="21"/>
<wire x1="5.08" y1="1.4732" x2="5.08" y2="1.3716" width="0.4064" layer="21"/>
<wire x1="5.08" y1="0.8128" x2="5.08" y2="-0.4572" width="0.4064" layer="21"/>
<wire x1="5.08" y1="-0.4572" x2="5.1816" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="5.1816" y1="-0.635" x2="5.2578" y2="-0.6858" width="0.4064" layer="21"/>
<wire x1="5.2578" y1="-0.6858" x2="5.3086" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="5.3086" y1="-0.7112" x2="5.4356" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="6.096" y1="1.27" x2="6.096" y2="-0.4826" width="0.4064" layer="21"/>
<wire x1="6.096" y1="-0.4826" x2="6.1722" y2="-0.635" width="0.4064" layer="21"/>
<wire x1="6.1722" y1="-0.635" x2="6.2484" y2="-0.6858" width="0.4064" layer="21"/>
<wire x1="6.2484" y1="-0.6858" x2="6.2992" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="6.2992" y1="-0.7112" x2="6.4262" y2="-0.7112" width="0.4064" layer="21"/>
<wire x1="5.7912" y1="0.7874" x2="6.477" y2="0.7874" width="0.4064" layer="21"/>
</package>
<package name="GND_CONNECT">
<smd name="1" x="-1.016" y="0" dx="1.016" dy="1.016" layer="1"/>
<smd name="2" x="-1.016" y="-1.27" dx="1.016" dy="1.016" layer="1"/>
<smd name="3" x="0.254" y="-0.635" dx="1.016" dy="1.016" layer="1"/>
<text x="-0.889" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.143" y="-4.064" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="OVERTONE_LOGO">
<rectangle x1="-2.5019" y1="-2.9083" x2="2.6035" y2="-2.8829" layer="21"/>
<rectangle x1="-2.6289" y1="-2.8829" x2="2.7305" y2="-2.8575" layer="21"/>
<rectangle x1="-2.7051" y1="-2.8575" x2="2.8067" y2="-2.8321" layer="21"/>
<rectangle x1="-2.7305" y1="-2.8321" x2="2.8321" y2="-2.8067" layer="21"/>
<rectangle x1="-2.7813" y1="-2.8067" x2="2.8829" y2="-2.7813" layer="21"/>
<rectangle x1="-2.8067" y1="-2.7813" x2="2.9083" y2="-2.7559" layer="21"/>
<rectangle x1="-2.8321" y1="-2.7559" x2="2.9337" y2="-2.7305" layer="21"/>
<rectangle x1="-2.8575" y1="-2.7305" x2="2.9591" y2="-2.7051" layer="21"/>
<rectangle x1="-2.8575" y1="-2.7051" x2="2.9845" y2="-2.6797" layer="21"/>
<rectangle x1="-2.8829" y1="-2.6797" x2="2.9845" y2="-2.6543" layer="21"/>
<rectangle x1="-2.9083" y1="-2.6543" x2="3.0099" y2="-2.6289" layer="21"/>
<rectangle x1="-2.9083" y1="-2.6289" x2="3.0099" y2="-2.6035" layer="21"/>
<rectangle x1="-2.9083" y1="-2.6035" x2="-2.5527" y2="-2.5781" layer="21"/>
<rectangle x1="2.6543" y1="-2.6035" x2="3.0099" y2="-2.5781" layer="21"/>
<rectangle x1="-2.9337" y1="-2.5781" x2="-2.6035" y2="-2.5527" layer="21"/>
<rectangle x1="2.7051" y1="-2.5781" x2="3.0353" y2="-2.5527" layer="21"/>
<rectangle x1="-2.9337" y1="-2.5527" x2="-2.6289" y2="-2.5273" layer="21"/>
<rectangle x1="2.7305" y1="-2.5527" x2="3.0353" y2="-2.5273" layer="21"/>
<rectangle x1="-2.9337" y1="-2.5273" x2="-2.6289" y2="-2.5019" layer="21"/>
<rectangle x1="2.7559" y1="-2.5273" x2="3.0353" y2="-2.5019" layer="21"/>
<rectangle x1="-2.9337" y1="-2.5019" x2="-2.6543" y2="-2.4765" layer="21"/>
<rectangle x1="2.7559" y1="-2.5019" x2="3.0353" y2="-2.4765" layer="21"/>
<rectangle x1="-2.9591" y1="-2.4765" x2="-2.6543" y2="-2.4511" layer="21"/>
<rectangle x1="2.7559" y1="-2.4765" x2="3.0607" y2="-2.4511" layer="21"/>
<rectangle x1="-2.9591" y1="-2.4511" x2="-2.6543" y2="-2.4257" layer="21"/>
<rectangle x1="2.7559" y1="-2.4511" x2="3.0607" y2="-2.4257" layer="21"/>
<rectangle x1="-2.9591" y1="-2.4257" x2="-2.6543" y2="-2.4003" layer="21"/>
<rectangle x1="2.7559" y1="-2.4257" x2="3.0607" y2="-2.4003" layer="21"/>
<rectangle x1="-2.9591" y1="-2.4003" x2="-2.6543" y2="-2.3749" layer="21"/>
<rectangle x1="2.7559" y1="-2.4003" x2="3.0607" y2="-2.3749" layer="21"/>
<rectangle x1="-2.9591" y1="-2.3749" x2="-2.6543" y2="-2.3495" layer="21"/>
<rectangle x1="2.7559" y1="-2.3749" x2="3.0607" y2="-2.3495" layer="21"/>
<rectangle x1="-2.9591" y1="-2.3495" x2="-2.6543" y2="-2.3241" layer="21"/>
<rectangle x1="2.7559" y1="-2.3495" x2="3.0607" y2="-2.3241" layer="21"/>
<rectangle x1="-2.9591" y1="-2.3241" x2="-2.6543" y2="-2.2987" layer="21"/>
<rectangle x1="2.7559" y1="-2.3241" x2="3.0607" y2="-2.2987" layer="21"/>
<rectangle x1="-2.9591" y1="-2.2987" x2="-2.6543" y2="-2.2733" layer="21"/>
<rectangle x1="2.7559" y1="-2.2987" x2="3.0607" y2="-2.2733" layer="21"/>
<rectangle x1="-2.9591" y1="-2.2733" x2="-2.6543" y2="-2.2479" layer="21"/>
<rectangle x1="2.7559" y1="-2.2733" x2="3.0607" y2="-2.2479" layer="21"/>
<rectangle x1="-2.9591" y1="-2.2479" x2="-2.6543" y2="-2.2225" layer="21"/>
<rectangle x1="2.7559" y1="-2.2479" x2="3.0607" y2="-2.2225" layer="21"/>
<rectangle x1="-2.9591" y1="-2.2225" x2="-2.6543" y2="-2.1971" layer="21"/>
<rectangle x1="2.7559" y1="-2.2225" x2="3.0607" y2="-2.1971" layer="21"/>
<rectangle x1="-2.9591" y1="-2.1971" x2="-2.6543" y2="-2.1717" layer="21"/>
<rectangle x1="2.7559" y1="-2.1971" x2="3.0607" y2="-2.1717" layer="21"/>
<rectangle x1="-2.9591" y1="-2.1717" x2="-2.6543" y2="-2.1463" layer="21"/>
<rectangle x1="2.7559" y1="-2.1717" x2="3.0607" y2="-2.1463" layer="21"/>
<rectangle x1="-2.9591" y1="-2.1463" x2="-2.6543" y2="-2.1209" layer="21"/>
<rectangle x1="2.7559" y1="-2.1463" x2="3.0607" y2="-2.1209" layer="21"/>
<rectangle x1="-2.9591" y1="-2.1209" x2="-2.6543" y2="-2.0955" layer="21"/>
<rectangle x1="2.7559" y1="-2.1209" x2="3.0607" y2="-2.0955" layer="21"/>
<rectangle x1="-2.9591" y1="-2.0955" x2="-2.6543" y2="-2.0701" layer="21"/>
<rectangle x1="2.7559" y1="-2.0955" x2="3.0607" y2="-2.0701" layer="21"/>
<rectangle x1="-2.9591" y1="-2.0701" x2="-2.6543" y2="-2.0447" layer="21"/>
<rectangle x1="2.7559" y1="-2.0701" x2="3.0607" y2="-2.0447" layer="21"/>
<rectangle x1="-2.9591" y1="-2.0447" x2="-2.6543" y2="-2.0193" layer="21"/>
<rectangle x1="2.7559" y1="-2.0447" x2="3.0607" y2="-2.0193" layer="21"/>
<rectangle x1="-2.9591" y1="-2.0193" x2="-2.6543" y2="-1.9939" layer="21"/>
<rectangle x1="2.7559" y1="-2.0193" x2="3.0607" y2="-1.9939" layer="21"/>
<rectangle x1="-2.9591" y1="-1.9939" x2="-2.6543" y2="-1.9685" layer="21"/>
<rectangle x1="2.7559" y1="-1.9939" x2="3.0607" y2="-1.9685" layer="21"/>
<rectangle x1="-2.9591" y1="-1.9685" x2="-2.6543" y2="-1.9431" layer="21"/>
<rectangle x1="2.7559" y1="-1.9685" x2="3.0607" y2="-1.9431" layer="21"/>
<rectangle x1="-2.9591" y1="-1.9431" x2="-2.6543" y2="-1.9177" layer="21"/>
<rectangle x1="2.7559" y1="-1.9431" x2="3.0607" y2="-1.9177" layer="21"/>
<rectangle x1="-2.9591" y1="-1.9177" x2="-2.6543" y2="-1.8923" layer="21"/>
<rectangle x1="2.7559" y1="-1.9177" x2="3.0607" y2="-1.8923" layer="21"/>
<rectangle x1="-2.9591" y1="-1.8923" x2="-2.6543" y2="-1.8669" layer="21"/>
<rectangle x1="2.7559" y1="-1.8923" x2="3.0607" y2="-1.8669" layer="21"/>
<rectangle x1="-2.9591" y1="-1.8669" x2="-2.6543" y2="-1.8415" layer="21"/>
<rectangle x1="2.7559" y1="-1.8669" x2="3.0607" y2="-1.8415" layer="21"/>
<rectangle x1="-2.9591" y1="-1.8415" x2="-2.6543" y2="-1.8161" layer="21"/>
<rectangle x1="2.7559" y1="-1.8415" x2="3.0607" y2="-1.8161" layer="21"/>
<rectangle x1="-2.9591" y1="-1.8161" x2="-2.6543" y2="-1.7907" layer="21"/>
<rectangle x1="2.7559" y1="-1.8161" x2="3.0607" y2="-1.7907" layer="21"/>
<rectangle x1="-2.9591" y1="-1.7907" x2="-2.6543" y2="-1.7653" layer="21"/>
<rectangle x1="2.7559" y1="-1.7907" x2="3.0607" y2="-1.7653" layer="21"/>
<rectangle x1="-2.9591" y1="-1.7653" x2="-2.6543" y2="-1.7399" layer="21"/>
<rectangle x1="2.7559" y1="-1.7653" x2="3.0607" y2="-1.7399" layer="21"/>
<rectangle x1="-2.9591" y1="-1.7399" x2="-2.6543" y2="-1.7145" layer="21"/>
<rectangle x1="2.7559" y1="-1.7399" x2="3.0607" y2="-1.7145" layer="21"/>
<rectangle x1="-2.9591" y1="-1.7145" x2="-2.6543" y2="-1.6891" layer="21"/>
<rectangle x1="2.7559" y1="-1.7145" x2="3.0607" y2="-1.6891" layer="21"/>
<rectangle x1="-2.9591" y1="-1.6891" x2="-2.6543" y2="-1.6637" layer="21"/>
<rectangle x1="2.7559" y1="-1.6891" x2="3.0607" y2="-1.6637" layer="21"/>
<rectangle x1="-2.9591" y1="-1.6637" x2="-2.6543" y2="-1.6383" layer="21"/>
<rectangle x1="2.7559" y1="-1.6637" x2="3.0607" y2="-1.6383" layer="21"/>
<rectangle x1="-2.9591" y1="-1.6383" x2="-2.6543" y2="-1.6129" layer="21"/>
<rectangle x1="2.7559" y1="-1.6383" x2="3.0607" y2="-1.6129" layer="21"/>
<rectangle x1="-2.9591" y1="-1.6129" x2="-2.6543" y2="-1.5875" layer="21"/>
<rectangle x1="2.7559" y1="-1.6129" x2="3.0607" y2="-1.5875" layer="21"/>
<rectangle x1="-2.9591" y1="-1.5875" x2="-2.6543" y2="-1.5621" layer="21"/>
<rectangle x1="2.7559" y1="-1.5875" x2="3.0607" y2="-1.5621" layer="21"/>
<rectangle x1="-2.9591" y1="-1.5621" x2="-2.6543" y2="-1.5367" layer="21"/>
<rectangle x1="2.7559" y1="-1.5621" x2="3.0607" y2="-1.5367" layer="21"/>
<rectangle x1="-2.9591" y1="-1.5367" x2="-2.6543" y2="-1.5113" layer="21"/>
<rectangle x1="2.7559" y1="-1.5367" x2="3.0607" y2="-1.5113" layer="21"/>
<rectangle x1="-2.9591" y1="-1.5113" x2="-2.6543" y2="-1.4859" layer="21"/>
<rectangle x1="2.7559" y1="-1.5113" x2="3.0607" y2="-1.4859" layer="21"/>
<rectangle x1="-2.9591" y1="-1.4859" x2="-2.6543" y2="-1.4605" layer="21"/>
<rectangle x1="2.7559" y1="-1.4859" x2="3.0607" y2="-1.4605" layer="21"/>
<rectangle x1="-2.9591" y1="-1.4605" x2="-2.6543" y2="-1.4351" layer="21"/>
<rectangle x1="2.7559" y1="-1.4605" x2="3.0607" y2="-1.4351" layer="21"/>
<rectangle x1="-2.9591" y1="-1.4351" x2="-2.6543" y2="-1.4097" layer="21"/>
<rectangle x1="2.7559" y1="-1.4351" x2="3.0607" y2="-1.4097" layer="21"/>
<rectangle x1="-2.9591" y1="-1.4097" x2="-2.6543" y2="-1.3843" layer="21"/>
<rectangle x1="2.7559" y1="-1.4097" x2="3.0607" y2="-1.3843" layer="21"/>
<rectangle x1="-2.9591" y1="-1.3843" x2="-2.6543" y2="-1.3589" layer="21"/>
<rectangle x1="2.7559" y1="-1.3843" x2="3.0607" y2="-1.3589" layer="21"/>
<rectangle x1="-2.9591" y1="-1.3589" x2="-2.6543" y2="-1.3335" layer="21"/>
<rectangle x1="2.7559" y1="-1.3589" x2="3.0607" y2="-1.3335" layer="21"/>
<rectangle x1="-2.9591" y1="-1.3335" x2="-2.6543" y2="-1.3081" layer="21"/>
<rectangle x1="2.7559" y1="-1.3335" x2="3.0607" y2="-1.3081" layer="21"/>
<rectangle x1="-2.9591" y1="-1.3081" x2="-2.6543" y2="-1.2827" layer="21"/>
<rectangle x1="2.7559" y1="-1.3081" x2="3.0607" y2="-1.2827" layer="21"/>
<rectangle x1="-2.9591" y1="-1.2827" x2="-2.6543" y2="-1.2573" layer="21"/>
<rectangle x1="2.7559" y1="-1.2827" x2="3.0607" y2="-1.2573" layer="21"/>
<rectangle x1="-2.9591" y1="-1.2573" x2="-2.6543" y2="-1.2319" layer="21"/>
<rectangle x1="2.7559" y1="-1.2573" x2="3.0607" y2="-1.2319" layer="21"/>
<rectangle x1="-2.9591" y1="-1.2319" x2="-2.6543" y2="-1.2065" layer="21"/>
<rectangle x1="2.7559" y1="-1.2319" x2="3.0607" y2="-1.2065" layer="21"/>
<rectangle x1="-2.9591" y1="-1.2065" x2="-2.6543" y2="-1.1811" layer="21"/>
<rectangle x1="1.7145" y1="-1.2065" x2="1.8923" y2="-1.1811" layer="21"/>
<rectangle x1="2.7559" y1="-1.2065" x2="3.0607" y2="-1.1811" layer="21"/>
<rectangle x1="-2.9591" y1="-1.1811" x2="-2.6543" y2="-1.1557" layer="21"/>
<rectangle x1="-2.1717" y1="-1.1811" x2="-0.8509" y2="-1.1557" layer="21"/>
<rectangle x1="-0.3937" y1="-1.1811" x2="0.0381" y2="-1.1557" layer="21"/>
<rectangle x1="0.1651" y1="-1.1811" x2="0.8255" y2="-1.1557" layer="21"/>
<rectangle x1="1.5875" y1="-1.1811" x2="2.0193" y2="-1.1557" layer="21"/>
<rectangle x1="2.7559" y1="-1.1811" x2="3.0607" y2="-1.1557" layer="21"/>
<rectangle x1="-2.9591" y1="-1.1557" x2="-2.6543" y2="-1.1303" layer="21"/>
<rectangle x1="-2.1717" y1="-1.1557" x2="-0.8255" y2="-1.1303" layer="21"/>
<rectangle x1="-0.3937" y1="-1.1557" x2="0.0381" y2="-1.1303" layer="21"/>
<rectangle x1="0.1651" y1="-1.1557" x2="0.9271" y2="-1.1303" layer="21"/>
<rectangle x1="1.5367" y1="-1.1557" x2="2.0701" y2="-1.1303" layer="21"/>
<rectangle x1="2.7559" y1="-1.1557" x2="3.0607" y2="-1.1303" layer="21"/>
<rectangle x1="-2.9591" y1="-1.1303" x2="-2.6543" y2="-1.1049" layer="21"/>
<rectangle x1="-2.1717" y1="-1.1303" x2="-0.8255" y2="-1.1049" layer="21"/>
<rectangle x1="-0.4191" y1="-1.1303" x2="0.0127" y2="-1.1049" layer="21"/>
<rectangle x1="0.1651" y1="-1.1303" x2="1.0033" y2="-1.1049" layer="21"/>
<rectangle x1="1.4605" y1="-1.1303" x2="2.1209" y2="-1.1049" layer="21"/>
<rectangle x1="2.7559" y1="-1.1303" x2="3.0607" y2="-1.1049" layer="21"/>
<rectangle x1="-2.9591" y1="-1.1049" x2="-2.6543" y2="-1.0795" layer="21"/>
<rectangle x1="-2.1717" y1="-1.1049" x2="-0.8255" y2="-1.0795" layer="21"/>
<rectangle x1="-0.4191" y1="-1.1049" x2="0.0127" y2="-1.0795" layer="21"/>
<rectangle x1="0.1651" y1="-1.1049" x2="1.0541" y2="-1.0795" layer="21"/>
<rectangle x1="1.4097" y1="-1.1049" x2="2.1463" y2="-1.0795" layer="21"/>
<rectangle x1="2.7559" y1="-1.1049" x2="3.0607" y2="-1.0795" layer="21"/>
<rectangle x1="-2.9591" y1="-1.0795" x2="-2.6543" y2="-1.0541" layer="21"/>
<rectangle x1="-2.1717" y1="-1.0795" x2="-0.8255" y2="-1.0541" layer="21"/>
<rectangle x1="-0.4191" y1="-1.0795" x2="0.0127" y2="-1.0541" layer="21"/>
<rectangle x1="0.1651" y1="-1.0795" x2="1.1049" y2="-1.0541" layer="21"/>
<rectangle x1="1.4097" y1="-1.0795" x2="2.1971" y2="-1.0541" layer="21"/>
<rectangle x1="2.7559" y1="-1.0795" x2="3.0607" y2="-1.0541" layer="21"/>
<rectangle x1="-2.9591" y1="-1.0541" x2="-2.6543" y2="-1.0287" layer="21"/>
<rectangle x1="-2.1717" y1="-1.0541" x2="-1.2319" y2="-1.0287" layer="21"/>
<rectangle x1="-1.2065" y1="-1.0541" x2="-0.8255" y2="-1.0287" layer="21"/>
<rectangle x1="-0.4191" y1="-1.0541" x2="-0.0127" y2="-1.0287" layer="21"/>
<rectangle x1="0.1651" y1="-1.0541" x2="1.1303" y2="-1.0287" layer="21"/>
<rectangle x1="1.4097" y1="-1.0541" x2="2.2225" y2="-1.0287" layer="21"/>
<rectangle x1="2.7559" y1="-1.0541" x2="3.0607" y2="-1.0287" layer="21"/>
<rectangle x1="-2.9591" y1="-1.0287" x2="-2.6543" y2="-1.0033" layer="21"/>
<rectangle x1="-2.1717" y1="-1.0287" x2="-1.2319" y2="-1.0033" layer="21"/>
<rectangle x1="-1.2065" y1="-1.0287" x2="-0.8001" y2="-1.0033" layer="21"/>
<rectangle x1="-0.4191" y1="-1.0287" x2="-0.0127" y2="-1.0033" layer="21"/>
<rectangle x1="0.1651" y1="-1.0287" x2="1.1557" y2="-1.0033" layer="21"/>
<rectangle x1="1.4097" y1="-1.0287" x2="2.2479" y2="-1.0033" layer="21"/>
<rectangle x1="2.7559" y1="-1.0287" x2="3.0607" y2="-1.0033" layer="21"/>
<rectangle x1="-2.9591" y1="-1.0033" x2="-2.6543" y2="-0.9779" layer="21"/>
<rectangle x1="-2.1717" y1="-1.0033" x2="-1.2319" y2="-0.9779" layer="21"/>
<rectangle x1="-1.2065" y1="-1.0033" x2="-0.8001" y2="-0.9779" layer="21"/>
<rectangle x1="-0.4191" y1="-1.0033" x2="-0.0127" y2="-0.9779" layer="21"/>
<rectangle x1="0.1651" y1="-1.0033" x2="1.1811" y2="-0.9779" layer="21"/>
<rectangle x1="1.4097" y1="-1.0033" x2="2.2733" y2="-0.9779" layer="21"/>
<rectangle x1="2.7559" y1="-1.0033" x2="3.0607" y2="-0.9779" layer="21"/>
<rectangle x1="-2.9591" y1="-0.9779" x2="-2.6543" y2="-0.9525" layer="21"/>
<rectangle x1="-2.1717" y1="-0.9779" x2="-1.2319" y2="-0.9525" layer="21"/>
<rectangle x1="-1.1811" y1="-0.9779" x2="-0.8001" y2="-0.9525" layer="21"/>
<rectangle x1="-0.4445" y1="-0.9779" x2="-0.0127" y2="-0.9525" layer="21"/>
<rectangle x1="0.1651" y1="-0.9779" x2="1.2065" y2="-0.9525" layer="21"/>
<rectangle x1="1.4097" y1="-0.9779" x2="2.2733" y2="-0.9525" layer="21"/>
<rectangle x1="2.7559" y1="-0.9779" x2="3.0607" y2="-0.9525" layer="21"/>
<rectangle x1="-2.9591" y1="-0.9525" x2="-2.6543" y2="-0.9271" layer="21"/>
<rectangle x1="-2.1717" y1="-0.9525" x2="-1.2319" y2="-0.9271" layer="21"/>
<rectangle x1="-1.1811" y1="-0.9525" x2="-0.8001" y2="-0.9271" layer="21"/>
<rectangle x1="-0.4445" y1="-0.9525" x2="-0.0381" y2="-0.9271" layer="21"/>
<rectangle x1="0.1651" y1="-0.9525" x2="1.2319" y2="-0.9271" layer="21"/>
<rectangle x1="1.4097" y1="-0.9525" x2="2.2987" y2="-0.9271" layer="21"/>
<rectangle x1="2.7559" y1="-0.9525" x2="3.0607" y2="-0.9271" layer="21"/>
<rectangle x1="-2.9591" y1="-0.9271" x2="-2.6543" y2="-0.9017" layer="21"/>
<rectangle x1="-2.1717" y1="-0.9271" x2="-1.2319" y2="-0.9017" layer="21"/>
<rectangle x1="-1.1811" y1="-0.9271" x2="-0.8001" y2="-0.9017" layer="21"/>
<rectangle x1="-0.4445" y1="-0.9271" x2="-0.0381" y2="-0.9017" layer="21"/>
<rectangle x1="0.1651" y1="-0.9271" x2="1.2573" y2="-0.9017" layer="21"/>
<rectangle x1="1.4097" y1="-0.9271" x2="2.3241" y2="-0.9017" layer="21"/>
<rectangle x1="2.7559" y1="-0.9271" x2="3.0607" y2="-0.9017" layer="21"/>
<rectangle x1="-2.9591" y1="-0.9017" x2="-2.6543" y2="-0.8763" layer="21"/>
<rectangle x1="-2.1717" y1="-0.9017" x2="-1.2319" y2="-0.8763" layer="21"/>
<rectangle x1="-1.1811" y1="-0.9017" x2="-0.7747" y2="-0.8763" layer="21"/>
<rectangle x1="-0.4445" y1="-0.9017" x2="-0.0381" y2="-0.8763" layer="21"/>
<rectangle x1="0.1651" y1="-0.9017" x2="1.2573" y2="-0.8763" layer="21"/>
<rectangle x1="1.4097" y1="-0.9017" x2="2.3241" y2="-0.8763" layer="21"/>
<rectangle x1="2.7559" y1="-0.9017" x2="3.0607" y2="-0.8763" layer="21"/>
<rectangle x1="-2.9591" y1="-0.8763" x2="-2.6543" y2="-0.8509" layer="21"/>
<rectangle x1="-2.1717" y1="-0.8763" x2="-1.2319" y2="-0.8509" layer="21"/>
<rectangle x1="-1.1557" y1="-0.8763" x2="-0.7747" y2="-0.8509" layer="21"/>
<rectangle x1="-0.4445" y1="-0.8763" x2="-0.0381" y2="-0.8509" layer="21"/>
<rectangle x1="0.1651" y1="-0.8763" x2="1.2573" y2="-0.8509" layer="21"/>
<rectangle x1="1.4097" y1="-0.8763" x2="2.3495" y2="-0.8509" layer="21"/>
<rectangle x1="2.7559" y1="-0.8763" x2="3.0607" y2="-0.8509" layer="21"/>
<rectangle x1="-2.9591" y1="-0.8509" x2="-2.6543" y2="-0.8255" layer="21"/>
<rectangle x1="-2.1717" y1="-0.8509" x2="-1.2319" y2="-0.8255" layer="21"/>
<rectangle x1="-1.1557" y1="-0.8509" x2="-0.0635" y2="-0.8255" layer="21"/>
<rectangle x1="0.1651" y1="-0.8509" x2="0.5715" y2="-0.8255" layer="21"/>
<rectangle x1="0.6985" y1="-0.8509" x2="1.2827" y2="-0.8255" layer="21"/>
<rectangle x1="1.4097" y1="-0.8509" x2="1.6891" y2="-0.8255" layer="21"/>
<rectangle x1="1.8415" y1="-0.8509" x2="2.3495" y2="-0.8255" layer="21"/>
<rectangle x1="2.7559" y1="-0.8509" x2="3.0607" y2="-0.8255" layer="21"/>
<rectangle x1="-2.9591" y1="-0.8255" x2="-2.6543" y2="-0.8001" layer="21"/>
<rectangle x1="-2.1717" y1="-0.8255" x2="-1.7653" y2="-0.8001" layer="21"/>
<rectangle x1="-1.1557" y1="-0.8255" x2="-0.0635" y2="-0.8001" layer="21"/>
<rectangle x1="0.1651" y1="-0.8255" x2="0.5461" y2="-0.8001" layer="21"/>
<rectangle x1="0.8001" y1="-0.8255" x2="1.2827" y2="-0.8001" layer="21"/>
<rectangle x1="1.4097" y1="-0.8255" x2="1.6129" y2="-0.8001" layer="21"/>
<rectangle x1="1.8923" y1="-0.8255" x2="2.3749" y2="-0.8001" layer="21"/>
<rectangle x1="2.7559" y1="-0.8255" x2="3.0607" y2="-0.8001" layer="21"/>
<rectangle x1="-2.9591" y1="-0.8001" x2="-2.6543" y2="-0.7747" layer="21"/>
<rectangle x1="-2.1717" y1="-0.8001" x2="-1.7653" y2="-0.7747" layer="21"/>
<rectangle x1="-1.1557" y1="-0.8001" x2="-0.0635" y2="-0.7747" layer="21"/>
<rectangle x1="0.1651" y1="-0.8001" x2="0.5461" y2="-0.7747" layer="21"/>
<rectangle x1="0.8255" y1="-0.8001" x2="1.2827" y2="-0.7747" layer="21"/>
<rectangle x1="1.4097" y1="-0.8001" x2="1.5621" y2="-0.7747" layer="21"/>
<rectangle x1="1.9177" y1="-0.8001" x2="2.3749" y2="-0.7747" layer="21"/>
<rectangle x1="2.7559" y1="-0.8001" x2="3.0607" y2="-0.7747" layer="21"/>
<rectangle x1="-2.9591" y1="-0.7747" x2="-2.6543" y2="-0.7493" layer="21"/>
<rectangle x1="-2.1717" y1="-0.7747" x2="-1.7653" y2="-0.7493" layer="21"/>
<rectangle x1="-1.1303" y1="-0.7747" x2="-0.0635" y2="-0.7493" layer="21"/>
<rectangle x1="0.1651" y1="-0.7747" x2="0.5461" y2="-0.7493" layer="21"/>
<rectangle x1="0.8509" y1="-0.7747" x2="1.2827" y2="-0.7493" layer="21"/>
<rectangle x1="1.4097" y1="-0.7747" x2="1.5113" y2="-0.7493" layer="21"/>
<rectangle x1="1.9431" y1="-0.7747" x2="2.3749" y2="-0.7493" layer="21"/>
<rectangle x1="2.7559" y1="-0.7747" x2="3.0607" y2="-0.7493" layer="21"/>
<rectangle x1="-2.9591" y1="-0.7493" x2="-2.6543" y2="-0.7239" layer="21"/>
<rectangle x1="-2.1717" y1="-0.7493" x2="-1.7653" y2="-0.7239" layer="21"/>
<rectangle x1="-1.1303" y1="-0.7493" x2="-0.0889" y2="-0.7239" layer="21"/>
<rectangle x1="0.1651" y1="-0.7493" x2="0.5461" y2="-0.7239" layer="21"/>
<rectangle x1="0.8763" y1="-0.7493" x2="1.3081" y2="-0.7239" layer="21"/>
<rectangle x1="1.4097" y1="-0.7493" x2="1.4859" y2="-0.7239" layer="21"/>
<rectangle x1="1.9685" y1="-0.7493" x2="2.3749" y2="-0.7239" layer="21"/>
<rectangle x1="2.7559" y1="-0.7493" x2="3.0607" y2="-0.7239" layer="21"/>
<rectangle x1="-2.9591" y1="-0.7239" x2="-2.6543" y2="-0.6985" layer="21"/>
<rectangle x1="-2.1717" y1="-0.7239" x2="-1.7653" y2="-0.6985" layer="21"/>
<rectangle x1="-1.1303" y1="-0.7239" x2="-0.0889" y2="-0.6985" layer="21"/>
<rectangle x1="0.1651" y1="-0.7239" x2="0.5461" y2="-0.6985" layer="21"/>
<rectangle x1="0.8763" y1="-0.7239" x2="1.3081" y2="-0.6985" layer="21"/>
<rectangle x1="1.4097" y1="-0.7239" x2="1.4605" y2="-0.6985" layer="21"/>
<rectangle x1="1.9685" y1="-0.7239" x2="2.3749" y2="-0.6985" layer="21"/>
<rectangle x1="2.7559" y1="-0.7239" x2="3.0607" y2="-0.6985" layer="21"/>
<rectangle x1="-2.9591" y1="-0.6985" x2="-2.6543" y2="-0.6731" layer="21"/>
<rectangle x1="-2.1717" y1="-0.6985" x2="-1.7653" y2="-0.6731" layer="21"/>
<rectangle x1="-1.1303" y1="-0.6985" x2="-0.0889" y2="-0.6731" layer="21"/>
<rectangle x1="0.1651" y1="-0.6985" x2="0.5461" y2="-0.6731" layer="21"/>
<rectangle x1="0.9017" y1="-0.6985" x2="1.3081" y2="-0.6731" layer="21"/>
<rectangle x1="1.4097" y1="-0.6985" x2="1.4351" y2="-0.6731" layer="21"/>
<rectangle x1="1.9685" y1="-0.6985" x2="2.4003" y2="-0.6731" layer="21"/>
<rectangle x1="2.7559" y1="-0.6985" x2="3.0607" y2="-0.6731" layer="21"/>
<rectangle x1="-2.9591" y1="-0.6731" x2="-2.6543" y2="-0.6477" layer="21"/>
<rectangle x1="-2.1717" y1="-0.6731" x2="-1.7653" y2="-0.6477" layer="21"/>
<rectangle x1="-1.1049" y1="-0.6731" x2="-0.1143" y2="-0.6477" layer="21"/>
<rectangle x1="0.1651" y1="-0.6731" x2="0.5461" y2="-0.6477" layer="21"/>
<rectangle x1="0.9017" y1="-0.6731" x2="1.3081" y2="-0.6477" layer="21"/>
<rectangle x1="1.9939" y1="-0.6731" x2="2.4003" y2="-0.6477" layer="21"/>
<rectangle x1="2.7559" y1="-0.6731" x2="3.0607" y2="-0.6477" layer="21"/>
<rectangle x1="-2.9591" y1="-0.6477" x2="-2.6543" y2="-0.6223" layer="21"/>
<rectangle x1="-2.1717" y1="-0.6477" x2="-1.7653" y2="-0.6223" layer="21"/>
<rectangle x1="-1.1049" y1="-0.6477" x2="-0.1143" y2="-0.6223" layer="21"/>
<rectangle x1="0.1651" y1="-0.6477" x2="0.5461" y2="-0.6223" layer="21"/>
<rectangle x1="0.9017" y1="-0.6477" x2="1.3081" y2="-0.6223" layer="21"/>
<rectangle x1="1.9685" y1="-0.6477" x2="2.4003" y2="-0.6223" layer="21"/>
<rectangle x1="2.7559" y1="-0.6477" x2="3.0607" y2="-0.6223" layer="21"/>
<rectangle x1="-2.9591" y1="-0.6223" x2="-2.6543" y2="-0.5969" layer="21"/>
<rectangle x1="-2.1717" y1="-0.6223" x2="-1.7653" y2="-0.5969" layer="21"/>
<rectangle x1="-1.1049" y1="-0.6223" x2="-0.1143" y2="-0.5969" layer="21"/>
<rectangle x1="0.1651" y1="-0.6223" x2="0.5461" y2="-0.5969" layer="21"/>
<rectangle x1="0.9017" y1="-0.6223" x2="1.2827" y2="-0.5969" layer="21"/>
<rectangle x1="1.9685" y1="-0.6223" x2="2.4003" y2="-0.5969" layer="21"/>
<rectangle x1="2.7559" y1="-0.6223" x2="3.0607" y2="-0.5969" layer="21"/>
<rectangle x1="-2.9591" y1="-0.5969" x2="-2.6543" y2="-0.5715" layer="21"/>
<rectangle x1="-2.1717" y1="-0.5969" x2="-1.7653" y2="-0.5715" layer="21"/>
<rectangle x1="-1.1049" y1="-0.5969" x2="-0.1143" y2="-0.5715" layer="21"/>
<rectangle x1="0.1651" y1="-0.5969" x2="0.5461" y2="-0.5715" layer="21"/>
<rectangle x1="0.8763" y1="-0.5969" x2="1.2827" y2="-0.5715" layer="21"/>
<rectangle x1="1.9685" y1="-0.5969" x2="2.4003" y2="-0.5715" layer="21"/>
<rectangle x1="2.7559" y1="-0.5969" x2="3.0607" y2="-0.5715" layer="21"/>
<rectangle x1="-2.9591" y1="-0.5715" x2="-2.6543" y2="-0.5461" layer="21"/>
<rectangle x1="-2.1717" y1="-0.5715" x2="-1.7653" y2="-0.5461" layer="21"/>
<rectangle x1="-1.0795" y1="-0.5715" x2="-0.1397" y2="-0.5461" layer="21"/>
<rectangle x1="0.1651" y1="-0.5715" x2="0.5461" y2="-0.5461" layer="21"/>
<rectangle x1="0.8763" y1="-0.5715" x2="1.2827" y2="-0.5461" layer="21"/>
<rectangle x1="1.9431" y1="-0.5715" x2="2.3749" y2="-0.5461" layer="21"/>
<rectangle x1="2.7559" y1="-0.5715" x2="3.0607" y2="-0.5461" layer="21"/>
<rectangle x1="-2.9591" y1="-0.5461" x2="-2.6543" y2="-0.5207" layer="21"/>
<rectangle x1="-2.1717" y1="-0.5461" x2="-1.7653" y2="-0.5207" layer="21"/>
<rectangle x1="-1.0795" y1="-0.5461" x2="-0.7239" y2="-0.5207" layer="21"/>
<rectangle x1="-0.5207" y1="-0.5461" x2="-0.1397" y2="-0.5207" layer="21"/>
<rectangle x1="0.1651" y1="-0.5461" x2="0.5461" y2="-0.5207" layer="21"/>
<rectangle x1="0.8509" y1="-0.5461" x2="1.2827" y2="-0.5207" layer="21"/>
<rectangle x1="1.9177" y1="-0.5461" x2="2.3749" y2="-0.5207" layer="21"/>
<rectangle x1="2.7559" y1="-0.5461" x2="3.0607" y2="-0.5207" layer="21"/>
<rectangle x1="-7.1501" y1="-0.5207" x2="-6.8961" y2="-0.4953" layer="21"/>
<rectangle x1="-6.3881" y1="-0.5207" x2="-5.6261" y2="-0.4953" layer="21"/>
<rectangle x1="-4.8895" y1="-0.5207" x2="-4.6355" y2="-0.4953" layer="21"/>
<rectangle x1="-4.1275" y1="-0.5207" x2="-3.8735" y2="-0.4953" layer="21"/>
<rectangle x1="-3.3655" y1="-0.5207" x2="-2.6543" y2="-0.4953" layer="21"/>
<rectangle x1="-2.1717" y1="-0.5207" x2="-1.7653" y2="-0.4953" layer="21"/>
<rectangle x1="-1.0795" y1="-0.5207" x2="-0.7239" y2="-0.4953" layer="21"/>
<rectangle x1="-0.5207" y1="-0.5207" x2="-0.1397" y2="-0.4953" layer="21"/>
<rectangle x1="0.1651" y1="-0.5207" x2="0.5461" y2="-0.4953" layer="21"/>
<rectangle x1="0.8255" y1="-0.5207" x2="1.2573" y2="-0.4953" layer="21"/>
<rectangle x1="1.8923" y1="-0.5207" x2="2.3749" y2="-0.4953" layer="21"/>
<rectangle x1="2.7559" y1="-0.5207" x2="3.4671" y2="-0.4953" layer="21"/>
<rectangle x1="4.2291" y1="-0.5207" x2="4.4831" y2="-0.4953" layer="21"/>
<rectangle x1="4.9911" y1="-0.5207" x2="5.7277" y2="-0.4953" layer="21"/>
<rectangle x1="6.4897" y1="-0.5207" x2="6.7437" y2="-0.4953" layer="21"/>
<rectangle x1="7.2517" y1="-0.5207" x2="7.5057" y2="-0.4953" layer="21"/>
<rectangle x1="-7.1501" y1="-0.4953" x2="-6.8961" y2="-0.4699" layer="21"/>
<rectangle x1="-6.3881" y1="-0.4953" x2="-5.6261" y2="-0.4699" layer="21"/>
<rectangle x1="-4.8895" y1="-0.4953" x2="-4.6355" y2="-0.4699" layer="21"/>
<rectangle x1="-4.1275" y1="-0.4953" x2="-3.8735" y2="-0.4699" layer="21"/>
<rectangle x1="-3.3655" y1="-0.4953" x2="-2.6543" y2="-0.4699" layer="21"/>
<rectangle x1="-2.1717" y1="-0.4953" x2="-1.7653" y2="-0.4699" layer="21"/>
<rectangle x1="-1.0541" y1="-0.4953" x2="-0.7239" y2="-0.4699" layer="21"/>
<rectangle x1="-0.5207" y1="-0.4953" x2="-0.1397" y2="-0.4699" layer="21"/>
<rectangle x1="0.1651" y1="-0.4953" x2="0.5461" y2="-0.4699" layer="21"/>
<rectangle x1="0.8001" y1="-0.4953" x2="1.2573" y2="-0.4699" layer="21"/>
<rectangle x1="1.8669" y1="-0.4953" x2="2.3749" y2="-0.4699" layer="21"/>
<rectangle x1="2.7559" y1="-0.4953" x2="3.4671" y2="-0.4699" layer="21"/>
<rectangle x1="4.2291" y1="-0.4953" x2="4.4831" y2="-0.4699" layer="21"/>
<rectangle x1="4.9911" y1="-0.4953" x2="5.7277" y2="-0.4699" layer="21"/>
<rectangle x1="6.4897" y1="-0.4953" x2="6.7437" y2="-0.4699" layer="21"/>
<rectangle x1="7.2517" y1="-0.4953" x2="7.5057" y2="-0.4699" layer="21"/>
<rectangle x1="-7.1501" y1="-0.4699" x2="-6.8961" y2="-0.4445" layer="21"/>
<rectangle x1="-6.3881" y1="-0.4699" x2="-5.6261" y2="-0.4445" layer="21"/>
<rectangle x1="-4.8895" y1="-0.4699" x2="-4.6355" y2="-0.4445" layer="21"/>
<rectangle x1="-4.1275" y1="-0.4699" x2="-3.8735" y2="-0.4445" layer="21"/>
<rectangle x1="-3.3655" y1="-0.4699" x2="-2.6543" y2="-0.4445" layer="21"/>
<rectangle x1="-2.1717" y1="-0.4699" x2="-1.7653" y2="-0.4445" layer="21"/>
<rectangle x1="-1.0541" y1="-0.4699" x2="-0.6985" y2="-0.4445" layer="21"/>
<rectangle x1="-0.5207" y1="-0.4699" x2="-0.1651" y2="-0.4445" layer="21"/>
<rectangle x1="0.1651" y1="-0.4699" x2="0.5461" y2="-0.4445" layer="21"/>
<rectangle x1="0.7239" y1="-0.4699" x2="1.2319" y2="-0.4445" layer="21"/>
<rectangle x1="1.8161" y1="-0.4699" x2="2.3749" y2="-0.4445" layer="21"/>
<rectangle x1="2.7559" y1="-0.4699" x2="3.4671" y2="-0.4445" layer="21"/>
<rectangle x1="4.2291" y1="-0.4699" x2="4.4831" y2="-0.4445" layer="21"/>
<rectangle x1="4.9911" y1="-0.4699" x2="5.7277" y2="-0.4445" layer="21"/>
<rectangle x1="6.4897" y1="-0.4699" x2="6.7437" y2="-0.4445" layer="21"/>
<rectangle x1="7.2517" y1="-0.4699" x2="7.5057" y2="-0.4445" layer="21"/>
<rectangle x1="-7.1501" y1="-0.4445" x2="-6.8961" y2="-0.4191" layer="21"/>
<rectangle x1="-6.3881" y1="-0.4445" x2="-5.6261" y2="-0.4191" layer="21"/>
<rectangle x1="-4.8895" y1="-0.4445" x2="-4.6355" y2="-0.4191" layer="21"/>
<rectangle x1="-4.1275" y1="-0.4445" x2="-3.8735" y2="-0.4191" layer="21"/>
<rectangle x1="-3.3655" y1="-0.4445" x2="-2.6543" y2="-0.4191" layer="21"/>
<rectangle x1="-2.1717" y1="-0.4445" x2="-1.7653" y2="-0.4191" layer="21"/>
<rectangle x1="-1.0541" y1="-0.4445" x2="-0.6985" y2="-0.4191" layer="21"/>
<rectangle x1="-0.5207" y1="-0.4445" x2="-0.1651" y2="-0.4191" layer="21"/>
<rectangle x1="0.1651" y1="-0.4445" x2="1.2319" y2="-0.4191" layer="21"/>
<rectangle x1="1.7653" y1="-0.4445" x2="2.3495" y2="-0.4191" layer="21"/>
<rectangle x1="2.7559" y1="-0.4445" x2="3.4671" y2="-0.4191" layer="21"/>
<rectangle x1="4.2291" y1="-0.4445" x2="4.4831" y2="-0.4191" layer="21"/>
<rectangle x1="4.9911" y1="-0.4445" x2="5.7277" y2="-0.4191" layer="21"/>
<rectangle x1="6.4897" y1="-0.4445" x2="6.7437" y2="-0.4191" layer="21"/>
<rectangle x1="7.2517" y1="-0.4445" x2="7.5057" y2="-0.4191" layer="21"/>
<rectangle x1="-7.1501" y1="-0.4191" x2="-6.8961" y2="-0.3937" layer="21"/>
<rectangle x1="-6.3881" y1="-0.4191" x2="-5.6261" y2="-0.3937" layer="21"/>
<rectangle x1="-4.8895" y1="-0.4191" x2="-4.6355" y2="-0.3937" layer="21"/>
<rectangle x1="-4.1275" y1="-0.4191" x2="-3.8735" y2="-0.3937" layer="21"/>
<rectangle x1="-3.3655" y1="-0.4191" x2="-2.6543" y2="-0.3937" layer="21"/>
<rectangle x1="-2.1717" y1="-0.4191" x2="-1.7653" y2="-0.3937" layer="21"/>
<rectangle x1="-1.0541" y1="-0.4191" x2="-0.6985" y2="-0.3937" layer="21"/>
<rectangle x1="-0.5461" y1="-0.4191" x2="-0.1651" y2="-0.3937" layer="21"/>
<rectangle x1="0.1651" y1="-0.4191" x2="1.2065" y2="-0.3937" layer="21"/>
<rectangle x1="1.7145" y1="-0.4191" x2="2.3495" y2="-0.3937" layer="21"/>
<rectangle x1="2.7559" y1="-0.4191" x2="3.4671" y2="-0.3937" layer="21"/>
<rectangle x1="4.2291" y1="-0.4191" x2="4.4831" y2="-0.3937" layer="21"/>
<rectangle x1="4.9911" y1="-0.4191" x2="5.7277" y2="-0.3937" layer="21"/>
<rectangle x1="6.4897" y1="-0.4191" x2="6.7437" y2="-0.3937" layer="21"/>
<rectangle x1="7.2517" y1="-0.4191" x2="7.5057" y2="-0.3937" layer="21"/>
<rectangle x1="-7.1501" y1="-0.3937" x2="-6.8961" y2="-0.3683" layer="21"/>
<rectangle x1="-6.3881" y1="-0.3937" x2="-5.6261" y2="-0.3683" layer="21"/>
<rectangle x1="-4.8895" y1="-0.3937" x2="-4.6355" y2="-0.3683" layer="21"/>
<rectangle x1="-4.1275" y1="-0.3937" x2="-3.8735" y2="-0.3683" layer="21"/>
<rectangle x1="-3.3655" y1="-0.3937" x2="-2.6543" y2="-0.3683" layer="21"/>
<rectangle x1="-2.1717" y1="-0.3937" x2="-1.7653" y2="-0.3683" layer="21"/>
<rectangle x1="-1.0287" y1="-0.3937" x2="-0.6985" y2="-0.3683" layer="21"/>
<rectangle x1="-0.5461" y1="-0.3937" x2="-0.1651" y2="-0.3683" layer="21"/>
<rectangle x1="0.1651" y1="-0.3937" x2="1.1811" y2="-0.3683" layer="21"/>
<rectangle x1="1.6891" y1="-0.3937" x2="2.3241" y2="-0.3683" layer="21"/>
<rectangle x1="2.7559" y1="-0.3937" x2="3.4671" y2="-0.3683" layer="21"/>
<rectangle x1="4.2291" y1="-0.3937" x2="4.4831" y2="-0.3683" layer="21"/>
<rectangle x1="4.9911" y1="-0.3937" x2="5.7277" y2="-0.3683" layer="21"/>
<rectangle x1="6.4897" y1="-0.3937" x2="6.7437" y2="-0.3683" layer="21"/>
<rectangle x1="7.2517" y1="-0.3937" x2="7.5057" y2="-0.3683" layer="21"/>
<rectangle x1="-7.1501" y1="-0.3683" x2="-6.8961" y2="-0.3429" layer="21"/>
<rectangle x1="-6.3881" y1="-0.3683" x2="-5.6261" y2="-0.3429" layer="21"/>
<rectangle x1="-4.8895" y1="-0.3683" x2="-4.6355" y2="-0.3429" layer="21"/>
<rectangle x1="-4.1275" y1="-0.3683" x2="-3.8735" y2="-0.3429" layer="21"/>
<rectangle x1="-3.3655" y1="-0.3683" x2="-2.6543" y2="-0.3429" layer="21"/>
<rectangle x1="-2.1717" y1="-0.3683" x2="-1.7653" y2="-0.3429" layer="21"/>
<rectangle x1="-1.0287" y1="-0.3683" x2="-0.6985" y2="-0.3429" layer="21"/>
<rectangle x1="-0.5461" y1="-0.3683" x2="-0.1905" y2="-0.3429" layer="21"/>
<rectangle x1="0.1651" y1="-0.3683" x2="1.1557" y2="-0.3429" layer="21"/>
<rectangle x1="1.6383" y1="-0.3683" x2="2.2987" y2="-0.3429" layer="21"/>
<rectangle x1="2.7559" y1="-0.3683" x2="3.4671" y2="-0.3429" layer="21"/>
<rectangle x1="4.2291" y1="-0.3683" x2="4.4831" y2="-0.3429" layer="21"/>
<rectangle x1="4.9911" y1="-0.3683" x2="5.7277" y2="-0.3429" layer="21"/>
<rectangle x1="6.4897" y1="-0.3683" x2="6.7437" y2="-0.3429" layer="21"/>
<rectangle x1="7.2517" y1="-0.3683" x2="7.5057" y2="-0.3429" layer="21"/>
<rectangle x1="-7.1501" y1="-0.3429" x2="-6.8961" y2="-0.3175" layer="21"/>
<rectangle x1="-6.3881" y1="-0.3429" x2="-5.6261" y2="-0.3175" layer="21"/>
<rectangle x1="-4.8895" y1="-0.3429" x2="-4.6355" y2="-0.3175" layer="21"/>
<rectangle x1="-4.1275" y1="-0.3429" x2="-3.8735" y2="-0.3175" layer="21"/>
<rectangle x1="-3.3655" y1="-0.3429" x2="-2.6543" y2="-0.3175" layer="21"/>
<rectangle x1="-2.1717" y1="-0.3429" x2="-1.7653" y2="-0.3175" layer="21"/>
<rectangle x1="-1.0287" y1="-0.3429" x2="-0.6731" y2="-0.3175" layer="21"/>
<rectangle x1="-0.5461" y1="-0.3429" x2="-0.1905" y2="-0.3175" layer="21"/>
<rectangle x1="0.1651" y1="-0.3429" x2="1.1049" y2="-0.3175" layer="21"/>
<rectangle x1="1.6129" y1="-0.3429" x2="2.2987" y2="-0.3175" layer="21"/>
<rectangle x1="2.7559" y1="-0.3429" x2="3.4671" y2="-0.3175" layer="21"/>
<rectangle x1="4.2291" y1="-0.3429" x2="4.4831" y2="-0.3175" layer="21"/>
<rectangle x1="4.9911" y1="-0.3429" x2="5.7277" y2="-0.3175" layer="21"/>
<rectangle x1="6.4897" y1="-0.3429" x2="6.7437" y2="-0.3175" layer="21"/>
<rectangle x1="7.2517" y1="-0.3429" x2="7.5057" y2="-0.3175" layer="21"/>
<rectangle x1="-7.1501" y1="-0.3175" x2="-6.8961" y2="-0.2921" layer="21"/>
<rectangle x1="-6.3881" y1="-0.3175" x2="-5.6261" y2="-0.2921" layer="21"/>
<rectangle x1="-4.8895" y1="-0.3175" x2="-4.6355" y2="-0.2921" layer="21"/>
<rectangle x1="-4.1275" y1="-0.3175" x2="-3.8735" y2="-0.2921" layer="21"/>
<rectangle x1="-3.3655" y1="-0.3175" x2="-2.6543" y2="-0.2921" layer="21"/>
<rectangle x1="-2.1717" y1="-0.3175" x2="-1.7653" y2="-0.2921" layer="21"/>
<rectangle x1="-1.0287" y1="-0.3175" x2="-0.6731" y2="-0.2921" layer="21"/>
<rectangle x1="-0.5461" y1="-0.3175" x2="-0.1905" y2="-0.2921" layer="21"/>
<rectangle x1="0.1651" y1="-0.3175" x2="1.0541" y2="-0.2921" layer="21"/>
<rectangle x1="1.5621" y1="-0.3175" x2="2.2479" y2="-0.2921" layer="21"/>
<rectangle x1="2.7559" y1="-0.3175" x2="3.4671" y2="-0.2921" layer="21"/>
<rectangle x1="4.2291" y1="-0.3175" x2="4.4831" y2="-0.2921" layer="21"/>
<rectangle x1="4.9911" y1="-0.3175" x2="5.7277" y2="-0.2921" layer="21"/>
<rectangle x1="6.4897" y1="-0.3175" x2="6.7437" y2="-0.2921" layer="21"/>
<rectangle x1="7.2517" y1="-0.3175" x2="7.5057" y2="-0.2921" layer="21"/>
<rectangle x1="-7.1501" y1="-0.2921" x2="-6.8961" y2="-0.2667" layer="21"/>
<rectangle x1="-6.3881" y1="-0.2921" x2="-5.6261" y2="-0.2667" layer="21"/>
<rectangle x1="-4.8895" y1="-0.2921" x2="-4.6355" y2="-0.2667" layer="21"/>
<rectangle x1="-4.1275" y1="-0.2921" x2="-3.8735" y2="-0.2667" layer="21"/>
<rectangle x1="-3.3655" y1="-0.2921" x2="-2.6543" y2="-0.2667" layer="21"/>
<rectangle x1="-2.1717" y1="-0.2921" x2="-1.7653" y2="-0.2667" layer="21"/>
<rectangle x1="-1.0033" y1="-0.2921" x2="-0.6731" y2="-0.2667" layer="21"/>
<rectangle x1="-0.5461" y1="-0.2921" x2="-0.1905" y2="-0.2667" layer="21"/>
<rectangle x1="0.1651" y1="-0.2921" x2="0.9779" y2="-0.2667" layer="21"/>
<rectangle x1="1.5367" y1="-0.2921" x2="2.2479" y2="-0.2667" layer="21"/>
<rectangle x1="2.7559" y1="-0.2921" x2="3.4671" y2="-0.2667" layer="21"/>
<rectangle x1="4.2291" y1="-0.2921" x2="4.4831" y2="-0.2667" layer="21"/>
<rectangle x1="4.9657" y1="-0.2921" x2="5.7531" y2="-0.2667" layer="21"/>
<rectangle x1="6.4897" y1="-0.2921" x2="6.7437" y2="-0.2667" layer="21"/>
<rectangle x1="7.2517" y1="-0.2921" x2="7.5057" y2="-0.2667" layer="21"/>
<rectangle x1="-7.1501" y1="-0.2667" x2="-6.8961" y2="-0.2413" layer="21"/>
<rectangle x1="-6.6421" y1="-0.2667" x2="-6.3881" y2="-0.2413" layer="21"/>
<rectangle x1="-5.6261" y1="-0.2667" x2="-5.3721" y2="-0.2413" layer="21"/>
<rectangle x1="-4.8895" y1="-0.2667" x2="-4.6355" y2="-0.2413" layer="21"/>
<rectangle x1="-4.1275" y1="-0.2667" x2="-3.8735" y2="-0.2413" layer="21"/>
<rectangle x1="-3.6195" y1="-0.2667" x2="-3.3655" y2="-0.2413" layer="21"/>
<rectangle x1="-2.9591" y1="-0.2667" x2="-2.6543" y2="-0.2413" layer="21"/>
<rectangle x1="-2.1717" y1="-0.2667" x2="-1.7653" y2="-0.2413" layer="21"/>
<rectangle x1="-1.0033" y1="-0.2667" x2="-0.6731" y2="-0.2413" layer="21"/>
<rectangle x1="-0.5715" y1="-0.2667" x2="-0.2159" y2="-0.2413" layer="21"/>
<rectangle x1="0.1651" y1="-0.2667" x2="0.9271" y2="-0.2413" layer="21"/>
<rectangle x1="1.5113" y1="-0.2667" x2="2.1971" y2="-0.2413" layer="21"/>
<rectangle x1="2.7559" y1="-0.2667" x2="3.0607" y2="-0.2413" layer="21"/>
<rectangle x1="3.4671" y1="-0.2667" x2="3.7211" y2="-0.2413" layer="21"/>
<rectangle x1="4.2291" y1="-0.2667" x2="4.4831" y2="-0.2413" layer="21"/>
<rectangle x1="4.7371" y1="-0.2667" x2="4.9911" y2="-0.2413" layer="21"/>
<rectangle x1="5.7277" y1="-0.2667" x2="5.9817" y2="-0.2413" layer="21"/>
<rectangle x1="6.4897" y1="-0.2667" x2="6.7437" y2="-0.2413" layer="21"/>
<rectangle x1="7.2517" y1="-0.2667" x2="7.5057" y2="-0.2413" layer="21"/>
<rectangle x1="-7.1501" y1="-0.2413" x2="-6.8961" y2="-0.2159" layer="21"/>
<rectangle x1="-6.6421" y1="-0.2413" x2="-6.3881" y2="-0.2159" layer="21"/>
<rectangle x1="-5.6261" y1="-0.2413" x2="-5.3721" y2="-0.2159" layer="21"/>
<rectangle x1="-4.8895" y1="-0.2413" x2="-4.6355" y2="-0.2159" layer="21"/>
<rectangle x1="-4.1275" y1="-0.2413" x2="-3.8735" y2="-0.2159" layer="21"/>
<rectangle x1="-3.6195" y1="-0.2413" x2="-3.3655" y2="-0.2159" layer="21"/>
<rectangle x1="-2.9591" y1="-0.2413" x2="-2.6543" y2="-0.2159" layer="21"/>
<rectangle x1="-2.1717" y1="-0.2413" x2="-1.7653" y2="-0.2159" layer="21"/>
<rectangle x1="-1.0033" y1="-0.2413" x2="-0.6731" y2="-0.2159" layer="21"/>
<rectangle x1="-0.5715" y1="-0.2413" x2="-0.2159" y2="-0.2159" layer="21"/>
<rectangle x1="0.1651" y1="-0.2413" x2="0.9779" y2="-0.2159" layer="21"/>
<rectangle x1="1.4859" y1="-0.2413" x2="2.1717" y2="-0.2159" layer="21"/>
<rectangle x1="2.7559" y1="-0.2413" x2="3.0607" y2="-0.2159" layer="21"/>
<rectangle x1="3.4671" y1="-0.2413" x2="3.7211" y2="-0.2159" layer="21"/>
<rectangle x1="4.2291" y1="-0.2413" x2="4.4831" y2="-0.2159" layer="21"/>
<rectangle x1="4.7371" y1="-0.2413" x2="4.9911" y2="-0.2159" layer="21"/>
<rectangle x1="5.7277" y1="-0.2413" x2="5.9817" y2="-0.2159" layer="21"/>
<rectangle x1="6.4897" y1="-0.2413" x2="6.7437" y2="-0.2159" layer="21"/>
<rectangle x1="7.2517" y1="-0.2413" x2="7.5057" y2="-0.2159" layer="21"/>
<rectangle x1="-7.1501" y1="-0.2159" x2="-6.8961" y2="-0.1905" layer="21"/>
<rectangle x1="-6.6421" y1="-0.2159" x2="-6.3881" y2="-0.1905" layer="21"/>
<rectangle x1="-5.6261" y1="-0.2159" x2="-5.3721" y2="-0.1905" layer="21"/>
<rectangle x1="-4.8895" y1="-0.2159" x2="-4.6355" y2="-0.1905" layer="21"/>
<rectangle x1="-4.1275" y1="-0.2159" x2="-3.8735" y2="-0.1905" layer="21"/>
<rectangle x1="-3.6195" y1="-0.2159" x2="-3.3655" y2="-0.1905" layer="21"/>
<rectangle x1="-2.9591" y1="-0.2159" x2="-2.6543" y2="-0.1905" layer="21"/>
<rectangle x1="-2.1717" y1="-0.2159" x2="-1.7653" y2="-0.1905" layer="21"/>
<rectangle x1="-1.0033" y1="-0.2159" x2="-0.6477" y2="-0.1905" layer="21"/>
<rectangle x1="-0.5715" y1="-0.2159" x2="-0.2159" y2="-0.1905" layer="21"/>
<rectangle x1="0.1651" y1="-0.2159" x2="1.0287" y2="-0.1905" layer="21"/>
<rectangle x1="1.4859" y1="-0.2159" x2="2.1209" y2="-0.1905" layer="21"/>
<rectangle x1="2.7559" y1="-0.2159" x2="3.0607" y2="-0.1905" layer="21"/>
<rectangle x1="3.4671" y1="-0.2159" x2="3.7211" y2="-0.1905" layer="21"/>
<rectangle x1="4.2291" y1="-0.2159" x2="4.4831" y2="-0.1905" layer="21"/>
<rectangle x1="4.7371" y1="-0.2159" x2="4.9911" y2="-0.1905" layer="21"/>
<rectangle x1="5.7277" y1="-0.2159" x2="5.9817" y2="-0.1905" layer="21"/>
<rectangle x1="6.4897" y1="-0.2159" x2="6.7437" y2="-0.1905" layer="21"/>
<rectangle x1="7.2517" y1="-0.2159" x2="7.5057" y2="-0.1905" layer="21"/>
<rectangle x1="-7.1501" y1="-0.1905" x2="-6.8961" y2="-0.1651" layer="21"/>
<rectangle x1="-6.6421" y1="-0.1905" x2="-6.3881" y2="-0.1651" layer="21"/>
<rectangle x1="-5.6261" y1="-0.1905" x2="-5.3721" y2="-0.1651" layer="21"/>
<rectangle x1="-4.8895" y1="-0.1905" x2="-4.6355" y2="-0.1651" layer="21"/>
<rectangle x1="-4.1275" y1="-0.1905" x2="-3.8735" y2="-0.1651" layer="21"/>
<rectangle x1="-3.6195" y1="-0.1905" x2="-3.3655" y2="-0.1651" layer="21"/>
<rectangle x1="-2.9591" y1="-0.1905" x2="-2.6543" y2="-0.1651" layer="21"/>
<rectangle x1="-2.1717" y1="-0.1905" x2="-1.7653" y2="-0.1651" layer="21"/>
<rectangle x1="-0.9779" y1="-0.1905" x2="-0.6477" y2="-0.1651" layer="21"/>
<rectangle x1="-0.5715" y1="-0.1905" x2="-0.2413" y2="-0.1651" layer="21"/>
<rectangle x1="0.1651" y1="-0.1905" x2="1.0541" y2="-0.1651" layer="21"/>
<rectangle x1="1.4605" y1="-0.1905" x2="2.0701" y2="-0.1651" layer="21"/>
<rectangle x1="2.7559" y1="-0.1905" x2="3.0607" y2="-0.1651" layer="21"/>
<rectangle x1="3.4671" y1="-0.1905" x2="3.7211" y2="-0.1651" layer="21"/>
<rectangle x1="4.2291" y1="-0.1905" x2="4.4831" y2="-0.1651" layer="21"/>
<rectangle x1="4.7371" y1="-0.1905" x2="4.9911" y2="-0.1651" layer="21"/>
<rectangle x1="5.7277" y1="-0.1905" x2="5.9817" y2="-0.1651" layer="21"/>
<rectangle x1="6.4897" y1="-0.1905" x2="6.7437" y2="-0.1651" layer="21"/>
<rectangle x1="7.2517" y1="-0.1905" x2="7.5057" y2="-0.1651" layer="21"/>
<rectangle x1="-7.1501" y1="-0.1651" x2="-6.8961" y2="-0.1397" layer="21"/>
<rectangle x1="-6.6421" y1="-0.1651" x2="-6.3881" y2="-0.1397" layer="21"/>
<rectangle x1="-5.6261" y1="-0.1651" x2="-5.3721" y2="-0.1397" layer="21"/>
<rectangle x1="-4.8895" y1="-0.1651" x2="-4.6355" y2="-0.1397" layer="21"/>
<rectangle x1="-4.1275" y1="-0.1651" x2="-3.8735" y2="-0.1397" layer="21"/>
<rectangle x1="-3.6195" y1="-0.1651" x2="-3.3655" y2="-0.1397" layer="21"/>
<rectangle x1="-2.9591" y1="-0.1651" x2="-2.6543" y2="-0.1397" layer="21"/>
<rectangle x1="-2.1717" y1="-0.1651" x2="-1.7653" y2="-0.1397" layer="21"/>
<rectangle x1="-0.9779" y1="-0.1651" x2="-0.6477" y2="-0.1397" layer="21"/>
<rectangle x1="-0.5715" y1="-0.1651" x2="-0.2413" y2="-0.1397" layer="21"/>
<rectangle x1="0.1651" y1="-0.1651" x2="1.0795" y2="-0.1397" layer="21"/>
<rectangle x1="1.4351" y1="-0.1651" x2="2.0193" y2="-0.1397" layer="21"/>
<rectangle x1="2.7559" y1="-0.1651" x2="3.0607" y2="-0.1397" layer="21"/>
<rectangle x1="3.4671" y1="-0.1651" x2="3.7211" y2="-0.1397" layer="21"/>
<rectangle x1="4.2291" y1="-0.1651" x2="4.4831" y2="-0.1397" layer="21"/>
<rectangle x1="4.7371" y1="-0.1651" x2="4.9911" y2="-0.1397" layer="21"/>
<rectangle x1="5.7277" y1="-0.1651" x2="5.9817" y2="-0.1397" layer="21"/>
<rectangle x1="6.4897" y1="-0.1651" x2="6.7437" y2="-0.1397" layer="21"/>
<rectangle x1="7.2517" y1="-0.1651" x2="7.5057" y2="-0.1397" layer="21"/>
<rectangle x1="-7.1501" y1="-0.1397" x2="-6.8961" y2="-0.1143" layer="21"/>
<rectangle x1="-6.6421" y1="-0.1397" x2="-6.3881" y2="-0.1143" layer="21"/>
<rectangle x1="-5.6261" y1="-0.1397" x2="-5.3721" y2="-0.1143" layer="21"/>
<rectangle x1="-4.8895" y1="-0.1397" x2="-4.6355" y2="-0.1143" layer="21"/>
<rectangle x1="-4.1275" y1="-0.1397" x2="-3.8735" y2="-0.1143" layer="21"/>
<rectangle x1="-3.6195" y1="-0.1397" x2="-3.3655" y2="-0.1143" layer="21"/>
<rectangle x1="-2.9591" y1="-0.1397" x2="-2.6543" y2="-0.1143" layer="21"/>
<rectangle x1="-2.1717" y1="-0.1397" x2="-1.7653" y2="-0.1143" layer="21"/>
<rectangle x1="-0.9779" y1="-0.1397" x2="-0.6477" y2="-0.1143" layer="21"/>
<rectangle x1="-0.5969" y1="-0.1397" x2="-0.2413" y2="-0.1143" layer="21"/>
<rectangle x1="0.1651" y1="-0.1397" x2="0.5461" y2="-0.1143" layer="21"/>
<rectangle x1="0.6477" y1="-0.1397" x2="1.1049" y2="-0.1143" layer="21"/>
<rectangle x1="1.4351" y1="-0.1397" x2="1.9685" y2="-0.1143" layer="21"/>
<rectangle x1="2.7559" y1="-0.1397" x2="3.0607" y2="-0.1143" layer="21"/>
<rectangle x1="3.4671" y1="-0.1397" x2="3.7211" y2="-0.1143" layer="21"/>
<rectangle x1="4.2291" y1="-0.1397" x2="4.4831" y2="-0.1143" layer="21"/>
<rectangle x1="4.7371" y1="-0.1397" x2="4.9911" y2="-0.1143" layer="21"/>
<rectangle x1="5.7277" y1="-0.1397" x2="5.9817" y2="-0.1143" layer="21"/>
<rectangle x1="6.4897" y1="-0.1397" x2="6.7437" y2="-0.1143" layer="21"/>
<rectangle x1="7.2517" y1="-0.1397" x2="7.5057" y2="-0.1143" layer="21"/>
<rectangle x1="-7.1501" y1="-0.1143" x2="-6.8961" y2="-0.0889" layer="21"/>
<rectangle x1="-6.6421" y1="-0.1143" x2="-6.3881" y2="-0.0889" layer="21"/>
<rectangle x1="-5.6261" y1="-0.1143" x2="-5.3721" y2="-0.0889" layer="21"/>
<rectangle x1="-4.8895" y1="-0.1143" x2="-4.6355" y2="-0.0889" layer="21"/>
<rectangle x1="-4.1275" y1="-0.1143" x2="-3.8735" y2="-0.0889" layer="21"/>
<rectangle x1="-3.6195" y1="-0.1143" x2="-3.3655" y2="-0.0889" layer="21"/>
<rectangle x1="-2.9591" y1="-0.1143" x2="-2.6543" y2="-0.0889" layer="21"/>
<rectangle x1="-2.1717" y1="-0.1143" x2="-1.7653" y2="-0.0889" layer="21"/>
<rectangle x1="-0.9779" y1="-0.1143" x2="-0.6477" y2="-0.0889" layer="21"/>
<rectangle x1="-0.5969" y1="-0.1143" x2="-0.2413" y2="-0.0889" layer="21"/>
<rectangle x1="0.1651" y1="-0.1143" x2="0.5461" y2="-0.0889" layer="21"/>
<rectangle x1="0.6985" y1="-0.1143" x2="1.1303" y2="-0.0889" layer="21"/>
<rectangle x1="1.4351" y1="-0.1143" x2="1.9177" y2="-0.0889" layer="21"/>
<rectangle x1="2.7559" y1="-0.1143" x2="3.0607" y2="-0.0889" layer="21"/>
<rectangle x1="3.4671" y1="-0.1143" x2="3.7211" y2="-0.0889" layer="21"/>
<rectangle x1="4.2291" y1="-0.1143" x2="4.4831" y2="-0.0889" layer="21"/>
<rectangle x1="4.7371" y1="-0.1143" x2="4.9911" y2="-0.0889" layer="21"/>
<rectangle x1="5.7277" y1="-0.1143" x2="5.9817" y2="-0.0889" layer="21"/>
<rectangle x1="6.4897" y1="-0.1143" x2="6.7437" y2="-0.0889" layer="21"/>
<rectangle x1="7.2517" y1="-0.1143" x2="7.5057" y2="-0.0889" layer="21"/>
<rectangle x1="-7.1501" y1="-0.0889" x2="-6.8961" y2="-0.0635" layer="21"/>
<rectangle x1="-6.6421" y1="-0.0889" x2="-6.3881" y2="-0.0635" layer="21"/>
<rectangle x1="-5.6261" y1="-0.0889" x2="-5.3721" y2="-0.0635" layer="21"/>
<rectangle x1="-4.8895" y1="-0.0889" x2="-4.6355" y2="-0.0635" layer="21"/>
<rectangle x1="-4.1275" y1="-0.0889" x2="-3.8735" y2="-0.0635" layer="21"/>
<rectangle x1="-3.6195" y1="-0.0889" x2="-3.3655" y2="-0.0635" layer="21"/>
<rectangle x1="-2.9591" y1="-0.0889" x2="-2.6543" y2="-0.0635" layer="21"/>
<rectangle x1="-2.1717" y1="-0.0889" x2="-1.7653" y2="-0.0635" layer="21"/>
<rectangle x1="-0.9525" y1="-0.0889" x2="-0.6477" y2="-0.0635" layer="21"/>
<rectangle x1="-0.5969" y1="-0.0889" x2="-0.2667" y2="-0.0635" layer="21"/>
<rectangle x1="0.1651" y1="-0.0889" x2="0.5461" y2="-0.0635" layer="21"/>
<rectangle x1="0.7493" y1="-0.0889" x2="1.1303" y2="-0.0635" layer="21"/>
<rectangle x1="1.4097" y1="-0.0889" x2="1.8923" y2="-0.0635" layer="21"/>
<rectangle x1="2.7559" y1="-0.0889" x2="3.0607" y2="-0.0635" layer="21"/>
<rectangle x1="3.4671" y1="-0.0889" x2="3.7211" y2="-0.0635" layer="21"/>
<rectangle x1="4.2291" y1="-0.0889" x2="4.4831" y2="-0.0635" layer="21"/>
<rectangle x1="4.7371" y1="-0.0889" x2="4.9911" y2="-0.0635" layer="21"/>
<rectangle x1="5.7277" y1="-0.0889" x2="5.9817" y2="-0.0635" layer="21"/>
<rectangle x1="6.4897" y1="-0.0889" x2="6.7437" y2="-0.0635" layer="21"/>
<rectangle x1="7.2517" y1="-0.0889" x2="7.5057" y2="-0.0635" layer="21"/>
<rectangle x1="-7.1501" y1="-0.0635" x2="-6.8961" y2="-0.0381" layer="21"/>
<rectangle x1="-6.6421" y1="-0.0635" x2="-6.3881" y2="-0.0381" layer="21"/>
<rectangle x1="-5.6261" y1="-0.0635" x2="-5.3721" y2="-0.0381" layer="21"/>
<rectangle x1="-4.8895" y1="-0.0635" x2="-4.6355" y2="-0.0381" layer="21"/>
<rectangle x1="-4.1275" y1="-0.0635" x2="-3.8735" y2="-0.0381" layer="21"/>
<rectangle x1="-3.6195" y1="-0.0635" x2="-3.3655" y2="-0.0381" layer="21"/>
<rectangle x1="-2.9591" y1="-0.0635" x2="-2.6543" y2="-0.0381" layer="21"/>
<rectangle x1="-2.1717" y1="-0.0635" x2="-1.7653" y2="-0.0381" layer="21"/>
<rectangle x1="-0.9525" y1="-0.0635" x2="-0.6223" y2="-0.0381" layer="21"/>
<rectangle x1="-0.5969" y1="-0.0635" x2="-0.2667" y2="-0.0381" layer="21"/>
<rectangle x1="0.1651" y1="-0.0635" x2="0.5461" y2="-0.0381" layer="21"/>
<rectangle x1="0.7493" y1="-0.0635" x2="1.1557" y2="-0.0381" layer="21"/>
<rectangle x1="1.4097" y1="-0.0635" x2="1.8415" y2="-0.0381" layer="21"/>
<rectangle x1="2.7559" y1="-0.0635" x2="3.0607" y2="-0.0381" layer="21"/>
<rectangle x1="3.4671" y1="-0.0635" x2="3.7211" y2="-0.0381" layer="21"/>
<rectangle x1="4.2291" y1="-0.0635" x2="4.4831" y2="-0.0381" layer="21"/>
<rectangle x1="4.7371" y1="-0.0635" x2="4.9911" y2="-0.0381" layer="21"/>
<rectangle x1="5.7277" y1="-0.0635" x2="5.9817" y2="-0.0381" layer="21"/>
<rectangle x1="6.4897" y1="-0.0635" x2="6.7437" y2="-0.0381" layer="21"/>
<rectangle x1="7.2517" y1="-0.0635" x2="7.5057" y2="-0.0381" layer="21"/>
<rectangle x1="-7.1501" y1="-0.0381" x2="-6.8961" y2="-0.0127" layer="21"/>
<rectangle x1="-6.6421" y1="-0.0381" x2="-6.3881" y2="-0.0127" layer="21"/>
<rectangle x1="-5.6261" y1="-0.0381" x2="-5.3721" y2="-0.0127" layer="21"/>
<rectangle x1="-4.8895" y1="-0.0381" x2="-4.6355" y2="-0.0127" layer="21"/>
<rectangle x1="-4.1275" y1="-0.0381" x2="-3.8735" y2="-0.0127" layer="21"/>
<rectangle x1="-3.6195" y1="-0.0381" x2="-3.3655" y2="-0.0127" layer="21"/>
<rectangle x1="-2.9591" y1="-0.0381" x2="-2.6543" y2="-0.0127" layer="21"/>
<rectangle x1="-2.1717" y1="-0.0381" x2="-1.7653" y2="-0.0127" layer="21"/>
<rectangle x1="-0.9525" y1="-0.0381" x2="-0.6223" y2="-0.0127" layer="21"/>
<rectangle x1="-0.5969" y1="-0.0381" x2="-0.2667" y2="-0.0127" layer="21"/>
<rectangle x1="0.1651" y1="-0.0381" x2="0.5461" y2="-0.0127" layer="21"/>
<rectangle x1="0.7747" y1="-0.0381" x2="1.1557" y2="-0.0127" layer="21"/>
<rectangle x1="1.4097" y1="-0.0381" x2="1.8415" y2="-0.0127" layer="21"/>
<rectangle x1="2.7559" y1="-0.0381" x2="3.0607" y2="-0.0127" layer="21"/>
<rectangle x1="3.4671" y1="-0.0381" x2="3.7211" y2="-0.0127" layer="21"/>
<rectangle x1="4.2291" y1="-0.0381" x2="4.4831" y2="-0.0127" layer="21"/>
<rectangle x1="4.7371" y1="-0.0381" x2="4.9911" y2="-0.0127" layer="21"/>
<rectangle x1="5.7277" y1="-0.0381" x2="5.9817" y2="-0.0127" layer="21"/>
<rectangle x1="6.4897" y1="-0.0381" x2="6.7437" y2="-0.0127" layer="21"/>
<rectangle x1="7.2517" y1="-0.0381" x2="7.5057" y2="-0.0127" layer="21"/>
<rectangle x1="-7.1501" y1="-0.0127" x2="-6.8961" y2="0.0127" layer="21"/>
<rectangle x1="-6.6421" y1="-0.0127" x2="-6.3881" y2="0.0127" layer="21"/>
<rectangle x1="-5.6261" y1="-0.0127" x2="-5.3721" y2="0.0127" layer="21"/>
<rectangle x1="-4.8895" y1="-0.0127" x2="-4.6355" y2="0.0127" layer="21"/>
<rectangle x1="-4.1275" y1="-0.0127" x2="-3.8735" y2="0.0127" layer="21"/>
<rectangle x1="-3.6195" y1="-0.0127" x2="-3.3655" y2="0.0127" layer="21"/>
<rectangle x1="-2.9591" y1="-0.0127" x2="-2.6543" y2="0.0127" layer="21"/>
<rectangle x1="-2.1717" y1="-0.0127" x2="-1.7653" y2="0.0127" layer="21"/>
<rectangle x1="-0.9271" y1="-0.0127" x2="-0.6223" y2="0.0127" layer="21"/>
<rectangle x1="-0.5969" y1="-0.0127" x2="-0.2667" y2="0.0127" layer="21"/>
<rectangle x1="0.1651" y1="-0.0127" x2="0.5461" y2="0.0127" layer="21"/>
<rectangle x1="0.7747" y1="-0.0127" x2="1.1557" y2="0.0127" layer="21"/>
<rectangle x1="1.4097" y1="-0.0127" x2="1.8161" y2="0.0127" layer="21"/>
<rectangle x1="2.7559" y1="-0.0127" x2="3.0607" y2="0.0127" layer="21"/>
<rectangle x1="3.4671" y1="-0.0127" x2="3.7211" y2="0.0127" layer="21"/>
<rectangle x1="4.2291" y1="-0.0127" x2="4.4831" y2="0.0127" layer="21"/>
<rectangle x1="4.7371" y1="-0.0127" x2="4.9911" y2="0.0127" layer="21"/>
<rectangle x1="5.7277" y1="-0.0127" x2="5.9817" y2="0.0127" layer="21"/>
<rectangle x1="6.4897" y1="-0.0127" x2="6.7437" y2="0.0127" layer="21"/>
<rectangle x1="7.2517" y1="-0.0127" x2="7.5057" y2="0.0127" layer="21"/>
<rectangle x1="-7.1501" y1="0.0127" x2="-6.8961" y2="0.0381" layer="21"/>
<rectangle x1="-6.6421" y1="0.0127" x2="-6.3881" y2="0.0381" layer="21"/>
<rectangle x1="-5.6261" y1="0.0127" x2="-5.3721" y2="0.0381" layer="21"/>
<rectangle x1="-4.8895" y1="0.0127" x2="-4.6355" y2="0.0381" layer="21"/>
<rectangle x1="-4.1275" y1="0.0127" x2="-3.8735" y2="0.0381" layer="21"/>
<rectangle x1="-3.6195" y1="0.0127" x2="-3.3655" y2="0.0381" layer="21"/>
<rectangle x1="-2.9591" y1="0.0127" x2="-2.6543" y2="0.0381" layer="21"/>
<rectangle x1="-2.1717" y1="0.0127" x2="-1.7653" y2="0.0381" layer="21"/>
<rectangle x1="-0.9271" y1="0.0127" x2="-0.2921" y2="0.0381" layer="21"/>
<rectangle x1="0.1651" y1="0.0127" x2="0.5461" y2="0.0381" layer="21"/>
<rectangle x1="0.7747" y1="0.0127" x2="1.1811" y2="0.0381" layer="21"/>
<rectangle x1="1.4097" y1="0.0127" x2="1.8161" y2="0.0381" layer="21"/>
<rectangle x1="2.7559" y1="0.0127" x2="3.0607" y2="0.0381" layer="21"/>
<rectangle x1="3.4671" y1="0.0127" x2="3.7211" y2="0.0381" layer="21"/>
<rectangle x1="4.2291" y1="0.0127" x2="4.4831" y2="0.0381" layer="21"/>
<rectangle x1="4.7371" y1="0.0127" x2="4.9911" y2="0.0381" layer="21"/>
<rectangle x1="5.7277" y1="0.0127" x2="5.9817" y2="0.0381" layer="21"/>
<rectangle x1="6.4897" y1="0.0127" x2="6.7437" y2="0.0381" layer="21"/>
<rectangle x1="7.2517" y1="0.0127" x2="7.5057" y2="0.0381" layer="21"/>
<rectangle x1="-7.1501" y1="0.0381" x2="-6.8961" y2="0.0635" layer="21"/>
<rectangle x1="-6.6421" y1="0.0381" x2="-6.3881" y2="0.0635" layer="21"/>
<rectangle x1="-5.6261" y1="0.0381" x2="-5.3721" y2="0.0635" layer="21"/>
<rectangle x1="-4.8895" y1="0.0381" x2="-4.6355" y2="0.0635" layer="21"/>
<rectangle x1="-4.1275" y1="0.0381" x2="-3.8735" y2="0.0635" layer="21"/>
<rectangle x1="-3.6195" y1="0.0381" x2="-3.3655" y2="0.0635" layer="21"/>
<rectangle x1="-2.9591" y1="0.0381" x2="-2.6543" y2="0.0635" layer="21"/>
<rectangle x1="-2.1717" y1="0.0381" x2="-1.7653" y2="0.0635" layer="21"/>
<rectangle x1="-0.9271" y1="0.0381" x2="-0.2921" y2="0.0635" layer="21"/>
<rectangle x1="0.1651" y1="0.0381" x2="0.5461" y2="0.0635" layer="21"/>
<rectangle x1="0.7747" y1="0.0381" x2="1.1811" y2="0.0635" layer="21"/>
<rectangle x1="1.4097" y1="0.0381" x2="1.8161" y2="0.0635" layer="21"/>
<rectangle x1="2.7559" y1="0.0381" x2="3.0607" y2="0.0635" layer="21"/>
<rectangle x1="3.4671" y1="0.0381" x2="3.7211" y2="0.0635" layer="21"/>
<rectangle x1="4.2291" y1="0.0381" x2="4.4831" y2="0.0635" layer="21"/>
<rectangle x1="4.7371" y1="0.0381" x2="4.9911" y2="0.0635" layer="21"/>
<rectangle x1="5.7277" y1="0.0381" x2="5.9817" y2="0.0635" layer="21"/>
<rectangle x1="6.4897" y1="0.0381" x2="6.7437" y2="0.0635" layer="21"/>
<rectangle x1="7.2517" y1="0.0381" x2="7.5057" y2="0.0635" layer="21"/>
<rectangle x1="-7.1501" y1="0.0635" x2="-6.8961" y2="0.0889" layer="21"/>
<rectangle x1="-6.6421" y1="0.0635" x2="-6.3881" y2="0.0889" layer="21"/>
<rectangle x1="-5.6261" y1="0.0635" x2="-5.3721" y2="0.0889" layer="21"/>
<rectangle x1="-4.8895" y1="0.0635" x2="-4.6355" y2="0.0889" layer="21"/>
<rectangle x1="-4.1275" y1="0.0635" x2="-3.8735" y2="0.0889" layer="21"/>
<rectangle x1="-3.6195" y1="0.0635" x2="-3.3655" y2="0.0889" layer="21"/>
<rectangle x1="-2.9591" y1="0.0635" x2="-2.6543" y2="0.0889" layer="21"/>
<rectangle x1="-2.1717" y1="0.0635" x2="-1.7653" y2="0.0889" layer="21"/>
<rectangle x1="-0.9271" y1="0.0635" x2="-0.2921" y2="0.0889" layer="21"/>
<rectangle x1="0.1651" y1="0.0635" x2="0.5461" y2="0.0889" layer="21"/>
<rectangle x1="0.7747" y1="0.0635" x2="1.1811" y2="0.0889" layer="21"/>
<rectangle x1="1.4097" y1="0.0635" x2="1.8161" y2="0.0889" layer="21"/>
<rectangle x1="2.2479" y1="0.0635" x2="2.2987" y2="0.0889" layer="21"/>
<rectangle x1="2.7559" y1="0.0635" x2="3.0607" y2="0.0889" layer="21"/>
<rectangle x1="3.4671" y1="0.0635" x2="3.7211" y2="0.0889" layer="21"/>
<rectangle x1="4.2291" y1="0.0635" x2="4.4831" y2="0.0889" layer="21"/>
<rectangle x1="4.7371" y1="0.0635" x2="4.9911" y2="0.0889" layer="21"/>
<rectangle x1="5.7277" y1="0.0635" x2="5.9817" y2="0.0889" layer="21"/>
<rectangle x1="6.4897" y1="0.0635" x2="6.7437" y2="0.0889" layer="21"/>
<rectangle x1="7.2517" y1="0.0635" x2="7.5057" y2="0.0889" layer="21"/>
<rectangle x1="-7.1501" y1="0.0889" x2="-6.8961" y2="0.1143" layer="21"/>
<rectangle x1="-6.6421" y1="0.0889" x2="-6.3881" y2="0.1143" layer="21"/>
<rectangle x1="-5.6261" y1="0.0889" x2="-5.3721" y2="0.1143" layer="21"/>
<rectangle x1="-4.8895" y1="0.0889" x2="-4.6355" y2="0.1143" layer="21"/>
<rectangle x1="-4.1275" y1="0.0889" x2="-3.8735" y2="0.1143" layer="21"/>
<rectangle x1="-3.6195" y1="0.0889" x2="-3.3655" y2="0.1143" layer="21"/>
<rectangle x1="-2.9591" y1="0.0889" x2="-2.6543" y2="0.1143" layer="21"/>
<rectangle x1="-2.1717" y1="0.0889" x2="-1.7653" y2="0.1143" layer="21"/>
<rectangle x1="-0.9017" y1="0.0889" x2="-0.2921" y2="0.1143" layer="21"/>
<rectangle x1="0.1651" y1="0.0889" x2="0.5461" y2="0.1143" layer="21"/>
<rectangle x1="0.7747" y1="0.0889" x2="1.1811" y2="0.1143" layer="21"/>
<rectangle x1="1.4097" y1="0.0889" x2="1.8161" y2="0.1143" layer="21"/>
<rectangle x1="2.2225" y1="0.0889" x2="2.2987" y2="0.1143" layer="21"/>
<rectangle x1="2.7559" y1="0.0889" x2="3.0607" y2="0.1143" layer="21"/>
<rectangle x1="3.4671" y1="0.0889" x2="3.7211" y2="0.1143" layer="21"/>
<rectangle x1="4.2291" y1="0.0889" x2="4.4831" y2="0.1143" layer="21"/>
<rectangle x1="4.7371" y1="0.0889" x2="4.9911" y2="0.1143" layer="21"/>
<rectangle x1="5.7277" y1="0.0889" x2="5.9817" y2="0.1143" layer="21"/>
<rectangle x1="6.4897" y1="0.0889" x2="6.7437" y2="0.1143" layer="21"/>
<rectangle x1="7.2517" y1="0.0889" x2="7.5057" y2="0.1143" layer="21"/>
<rectangle x1="-7.1501" y1="0.1143" x2="-6.8961" y2="0.1397" layer="21"/>
<rectangle x1="-6.6421" y1="0.1143" x2="-6.3881" y2="0.1397" layer="21"/>
<rectangle x1="-5.6261" y1="0.1143" x2="-5.3721" y2="0.1397" layer="21"/>
<rectangle x1="-4.8895" y1="0.1143" x2="-4.6355" y2="0.1397" layer="21"/>
<rectangle x1="-4.1275" y1="0.1143" x2="-3.8735" y2="0.1397" layer="21"/>
<rectangle x1="-3.6195" y1="0.1143" x2="-3.3655" y2="0.1397" layer="21"/>
<rectangle x1="-2.9591" y1="0.1143" x2="-2.6543" y2="0.1397" layer="21"/>
<rectangle x1="-2.1717" y1="0.1143" x2="-1.7653" y2="0.1397" layer="21"/>
<rectangle x1="-0.9017" y1="0.1143" x2="-0.3175" y2="0.1397" layer="21"/>
<rectangle x1="0.1651" y1="0.1143" x2="0.5461" y2="0.1397" layer="21"/>
<rectangle x1="0.7493" y1="0.1143" x2="1.1811" y2="0.1397" layer="21"/>
<rectangle x1="1.4097" y1="0.1143" x2="1.8415" y2="0.1397" layer="21"/>
<rectangle x1="2.1971" y1="0.1143" x2="2.2987" y2="0.1397" layer="21"/>
<rectangle x1="2.7559" y1="0.1143" x2="3.0607" y2="0.1397" layer="21"/>
<rectangle x1="3.4671" y1="0.1143" x2="3.7211" y2="0.1397" layer="21"/>
<rectangle x1="4.2291" y1="0.1143" x2="4.4831" y2="0.1397" layer="21"/>
<rectangle x1="4.7371" y1="0.1143" x2="4.9911" y2="0.1397" layer="21"/>
<rectangle x1="5.7277" y1="0.1143" x2="5.9817" y2="0.1397" layer="21"/>
<rectangle x1="6.4897" y1="0.1143" x2="6.7437" y2="0.1397" layer="21"/>
<rectangle x1="7.2517" y1="0.1143" x2="7.5057" y2="0.1397" layer="21"/>
<rectangle x1="-7.1501" y1="0.1397" x2="-6.8961" y2="0.1651" layer="21"/>
<rectangle x1="-6.6421" y1="0.1397" x2="-6.3881" y2="0.1651" layer="21"/>
<rectangle x1="-5.6261" y1="0.1397" x2="-5.3721" y2="0.1651" layer="21"/>
<rectangle x1="-4.8895" y1="0.1397" x2="-4.6355" y2="0.1651" layer="21"/>
<rectangle x1="-4.1275" y1="0.1397" x2="-3.8735" y2="0.1651" layer="21"/>
<rectangle x1="-3.6195" y1="0.1397" x2="-3.3655" y2="0.1651" layer="21"/>
<rectangle x1="-2.9591" y1="0.1397" x2="-2.6543" y2="0.1651" layer="21"/>
<rectangle x1="-2.1717" y1="0.1397" x2="-1.7653" y2="0.1651" layer="21"/>
<rectangle x1="-0.9017" y1="0.1397" x2="-0.3175" y2="0.1651" layer="21"/>
<rectangle x1="0.1651" y1="0.1397" x2="0.5461" y2="0.1651" layer="21"/>
<rectangle x1="0.7239" y1="0.1397" x2="1.1811" y2="0.1651" layer="21"/>
<rectangle x1="1.4097" y1="0.1397" x2="1.8669" y2="0.1651" layer="21"/>
<rectangle x1="2.1463" y1="0.1397" x2="2.2987" y2="0.1651" layer="21"/>
<rectangle x1="2.7559" y1="0.1397" x2="3.0607" y2="0.1651" layer="21"/>
<rectangle x1="3.4671" y1="0.1397" x2="3.7211" y2="0.1651" layer="21"/>
<rectangle x1="4.2291" y1="0.1397" x2="4.4831" y2="0.1651" layer="21"/>
<rectangle x1="4.7371" y1="0.1397" x2="4.9911" y2="0.1651" layer="21"/>
<rectangle x1="5.7277" y1="0.1397" x2="5.9817" y2="0.1651" layer="21"/>
<rectangle x1="6.4897" y1="0.1397" x2="6.7437" y2="0.1651" layer="21"/>
<rectangle x1="7.2517" y1="0.1397" x2="7.5057" y2="0.1651" layer="21"/>
<rectangle x1="-7.1501" y1="0.1651" x2="-6.8961" y2="0.1905" layer="21"/>
<rectangle x1="-6.6421" y1="0.1651" x2="-6.3881" y2="0.1905" layer="21"/>
<rectangle x1="-5.6261" y1="0.1651" x2="-5.3721" y2="0.1905" layer="21"/>
<rectangle x1="-4.8895" y1="0.1651" x2="-4.6355" y2="0.1905" layer="21"/>
<rectangle x1="-4.1275" y1="0.1651" x2="-3.8735" y2="0.1905" layer="21"/>
<rectangle x1="-3.6195" y1="0.1651" x2="-3.3655" y2="0.1905" layer="21"/>
<rectangle x1="-2.9591" y1="0.1651" x2="-2.6543" y2="0.1905" layer="21"/>
<rectangle x1="-2.1717" y1="0.1651" x2="-1.7653" y2="0.1905" layer="21"/>
<rectangle x1="-0.9017" y1="0.1651" x2="-0.3175" y2="0.1905" layer="21"/>
<rectangle x1="0.1651" y1="0.1651" x2="0.5715" y2="0.1905" layer="21"/>
<rectangle x1="0.6731" y1="0.1651" x2="1.1811" y2="0.1905" layer="21"/>
<rectangle x1="1.4097" y1="0.1651" x2="1.8923" y2="0.1905" layer="21"/>
<rectangle x1="2.0955" y1="0.1651" x2="2.2987" y2="0.1905" layer="21"/>
<rectangle x1="2.7559" y1="0.1651" x2="3.0607" y2="0.1905" layer="21"/>
<rectangle x1="3.4671" y1="0.1651" x2="3.7211" y2="0.1905" layer="21"/>
<rectangle x1="4.2291" y1="0.1651" x2="4.4831" y2="0.1905" layer="21"/>
<rectangle x1="4.7371" y1="0.1651" x2="4.9911" y2="0.1905" layer="21"/>
<rectangle x1="5.7277" y1="0.1651" x2="5.9817" y2="0.1905" layer="21"/>
<rectangle x1="6.4897" y1="0.1651" x2="6.7437" y2="0.1905" layer="21"/>
<rectangle x1="7.2517" y1="0.1651" x2="7.5057" y2="0.1905" layer="21"/>
<rectangle x1="-7.1501" y1="0.1905" x2="-6.8961" y2="0.2159" layer="21"/>
<rectangle x1="-6.6421" y1="0.1905" x2="-6.3881" y2="0.2159" layer="21"/>
<rectangle x1="-5.6261" y1="0.1905" x2="-5.3721" y2="0.2159" layer="21"/>
<rectangle x1="-4.8895" y1="0.1905" x2="-4.6355" y2="0.2159" layer="21"/>
<rectangle x1="-4.1275" y1="0.1905" x2="-3.8735" y2="0.2159" layer="21"/>
<rectangle x1="-3.6195" y1="0.1905" x2="-3.3655" y2="0.2159" layer="21"/>
<rectangle x1="-2.9591" y1="0.1905" x2="-2.6543" y2="0.2159" layer="21"/>
<rectangle x1="-2.1717" y1="0.1905" x2="-1.7653" y2="0.2159" layer="21"/>
<rectangle x1="-0.8763" y1="0.1905" x2="-0.3175" y2="0.2159" layer="21"/>
<rectangle x1="0.1651" y1="0.1905" x2="1.1811" y2="0.2159" layer="21"/>
<rectangle x1="1.4351" y1="0.1905" x2="2.2987" y2="0.2159" layer="21"/>
<rectangle x1="2.7559" y1="0.1905" x2="3.0607" y2="0.2159" layer="21"/>
<rectangle x1="3.4671" y1="0.1905" x2="3.7211" y2="0.2159" layer="21"/>
<rectangle x1="4.2291" y1="0.1905" x2="4.4831" y2="0.2159" layer="21"/>
<rectangle x1="4.7371" y1="0.1905" x2="4.9911" y2="0.2159" layer="21"/>
<rectangle x1="5.7277" y1="0.1905" x2="5.9817" y2="0.2159" layer="21"/>
<rectangle x1="6.4897" y1="0.1905" x2="6.7437" y2="0.2159" layer="21"/>
<rectangle x1="7.2517" y1="0.1905" x2="7.5057" y2="0.2159" layer="21"/>
<rectangle x1="-7.1501" y1="0.2159" x2="-6.8961" y2="0.2413" layer="21"/>
<rectangle x1="-6.6421" y1="0.2159" x2="-6.3881" y2="0.2413" layer="21"/>
<rectangle x1="-5.6261" y1="0.2159" x2="-5.3721" y2="0.2413" layer="21"/>
<rectangle x1="-4.8895" y1="0.2159" x2="-4.6355" y2="0.2413" layer="21"/>
<rectangle x1="-4.1275" y1="0.2159" x2="-3.8735" y2="0.2413" layer="21"/>
<rectangle x1="-3.6195" y1="0.2159" x2="-3.3655" y2="0.2413" layer="21"/>
<rectangle x1="-2.9591" y1="0.2159" x2="-2.6543" y2="0.2413" layer="21"/>
<rectangle x1="-2.1717" y1="0.2159" x2="-1.7653" y2="0.2413" layer="21"/>
<rectangle x1="-0.8763" y1="0.2159" x2="-0.3429" y2="0.2413" layer="21"/>
<rectangle x1="0.1651" y1="0.2159" x2="1.1811" y2="0.2413" layer="21"/>
<rectangle x1="1.4351" y1="0.2159" x2="2.2987" y2="0.2413" layer="21"/>
<rectangle x1="2.7559" y1="0.2159" x2="3.0607" y2="0.2413" layer="21"/>
<rectangle x1="3.4671" y1="0.2159" x2="3.7211" y2="0.2413" layer="21"/>
<rectangle x1="4.2291" y1="0.2159" x2="4.4831" y2="0.2413" layer="21"/>
<rectangle x1="4.7371" y1="0.2159" x2="4.9911" y2="0.2413" layer="21"/>
<rectangle x1="5.7277" y1="0.2159" x2="5.9817" y2="0.2413" layer="21"/>
<rectangle x1="6.4897" y1="0.2159" x2="6.7437" y2="0.2413" layer="21"/>
<rectangle x1="7.2517" y1="0.2159" x2="7.5057" y2="0.2413" layer="21"/>
<rectangle x1="-7.4041" y1="0.2413" x2="-6.8961" y2="0.2667" layer="21"/>
<rectangle x1="-6.6421" y1="0.2413" x2="-6.3881" y2="0.2667" layer="21"/>
<rectangle x1="-5.6261" y1="0.2413" x2="-5.3721" y2="0.2667" layer="21"/>
<rectangle x1="-5.1181" y1="0.2413" x2="-4.6355" y2="0.2667" layer="21"/>
<rectangle x1="-4.3815" y1="0.2413" x2="-3.8735" y2="0.2667" layer="21"/>
<rectangle x1="-3.6195" y1="0.2413" x2="-3.3655" y2="0.2667" layer="21"/>
<rectangle x1="-2.9591" y1="0.2413" x2="-2.6543" y2="0.2667" layer="21"/>
<rectangle x1="-2.1717" y1="0.2413" x2="-1.7653" y2="0.2667" layer="21"/>
<rectangle x1="-0.8763" y1="0.2413" x2="-0.3429" y2="0.2667" layer="21"/>
<rectangle x1="0.1651" y1="0.2413" x2="1.1557" y2="0.2667" layer="21"/>
<rectangle x1="1.4351" y1="0.2413" x2="2.2987" y2="0.2667" layer="21"/>
<rectangle x1="2.7559" y1="0.2413" x2="3.0607" y2="0.2667" layer="21"/>
<rectangle x1="3.4671" y1="0.2413" x2="3.7211" y2="0.2667" layer="21"/>
<rectangle x1="3.9751" y1="0.2413" x2="4.4831" y2="0.2667" layer="21"/>
<rectangle x1="4.7371" y1="0.2413" x2="4.9911" y2="0.2667" layer="21"/>
<rectangle x1="5.7277" y1="0.2413" x2="5.9817" y2="0.2667" layer="21"/>
<rectangle x1="6.2357" y1="0.2413" x2="6.7437" y2="0.2667" layer="21"/>
<rectangle x1="6.9977" y1="0.2413" x2="7.5057" y2="0.2667" layer="21"/>
<rectangle x1="-7.4041" y1="0.2667" x2="-6.8961" y2="0.2921" layer="21"/>
<rectangle x1="-6.6421" y1="0.2667" x2="-6.3881" y2="0.2921" layer="21"/>
<rectangle x1="-5.6261" y1="0.2667" x2="-5.3721" y2="0.2921" layer="21"/>
<rectangle x1="-5.1181" y1="0.2667" x2="-4.6355" y2="0.2921" layer="21"/>
<rectangle x1="-4.3815" y1="0.2667" x2="-3.8735" y2="0.2921" layer="21"/>
<rectangle x1="-3.6195" y1="0.2667" x2="-3.3655" y2="0.2921" layer="21"/>
<rectangle x1="-2.9591" y1="0.2667" x2="-2.6543" y2="0.2921" layer="21"/>
<rectangle x1="-2.1717" y1="0.2667" x2="-1.7653" y2="0.2921" layer="21"/>
<rectangle x1="-0.8763" y1="0.2667" x2="-0.3429" y2="0.2921" layer="21"/>
<rectangle x1="0.1651" y1="0.2667" x2="1.1557" y2="0.2921" layer="21"/>
<rectangle x1="1.4605" y1="0.2667" x2="2.2987" y2="0.2921" layer="21"/>
<rectangle x1="2.7559" y1="0.2667" x2="3.0607" y2="0.2921" layer="21"/>
<rectangle x1="3.4671" y1="0.2667" x2="3.7211" y2="0.2921" layer="21"/>
<rectangle x1="3.9751" y1="0.2667" x2="4.4831" y2="0.2921" layer="21"/>
<rectangle x1="4.7371" y1="0.2667" x2="4.9911" y2="0.2921" layer="21"/>
<rectangle x1="5.7277" y1="0.2667" x2="5.9817" y2="0.2921" layer="21"/>
<rectangle x1="6.2357" y1="0.2667" x2="6.7437" y2="0.2921" layer="21"/>
<rectangle x1="6.9977" y1="0.2667" x2="7.5057" y2="0.2921" layer="21"/>
<rectangle x1="-7.4041" y1="0.2921" x2="-6.8961" y2="0.3175" layer="21"/>
<rectangle x1="-6.6421" y1="0.2921" x2="-6.3881" y2="0.3175" layer="21"/>
<rectangle x1="-5.6261" y1="0.2921" x2="-5.3721" y2="0.3175" layer="21"/>
<rectangle x1="-5.1181" y1="0.2921" x2="-4.6355" y2="0.3175" layer="21"/>
<rectangle x1="-4.3815" y1="0.2921" x2="-3.8735" y2="0.3175" layer="21"/>
<rectangle x1="-3.6195" y1="0.2921" x2="-3.3655" y2="0.3175" layer="21"/>
<rectangle x1="-2.9591" y1="0.2921" x2="-2.6543" y2="0.3175" layer="21"/>
<rectangle x1="-2.1717" y1="0.2921" x2="-1.7653" y2="0.3175" layer="21"/>
<rectangle x1="-0.8509" y1="0.2921" x2="-0.3683" y2="0.3175" layer="21"/>
<rectangle x1="0.1651" y1="0.2921" x2="1.1557" y2="0.3175" layer="21"/>
<rectangle x1="1.4859" y1="0.2921" x2="2.2987" y2="0.3175" layer="21"/>
<rectangle x1="2.7559" y1="0.2921" x2="3.0607" y2="0.3175" layer="21"/>
<rectangle x1="3.4671" y1="0.2921" x2="3.7211" y2="0.3175" layer="21"/>
<rectangle x1="3.9751" y1="0.2921" x2="4.4831" y2="0.3175" layer="21"/>
<rectangle x1="4.7371" y1="0.2921" x2="4.9911" y2="0.3175" layer="21"/>
<rectangle x1="5.7277" y1="0.2921" x2="5.9817" y2="0.3175" layer="21"/>
<rectangle x1="6.2357" y1="0.2921" x2="6.7437" y2="0.3175" layer="21"/>
<rectangle x1="6.9977" y1="0.2921" x2="7.5057" y2="0.3175" layer="21"/>
<rectangle x1="-7.4041" y1="0.3175" x2="-6.8961" y2="0.3429" layer="21"/>
<rectangle x1="-6.6421" y1="0.3175" x2="-6.3881" y2="0.3429" layer="21"/>
<rectangle x1="-5.6261" y1="0.3175" x2="-5.3721" y2="0.3429" layer="21"/>
<rectangle x1="-5.1181" y1="0.3175" x2="-4.6355" y2="0.3429" layer="21"/>
<rectangle x1="-4.3815" y1="0.3175" x2="-3.8735" y2="0.3429" layer="21"/>
<rectangle x1="-3.6195" y1="0.3175" x2="-3.3655" y2="0.3429" layer="21"/>
<rectangle x1="-2.9591" y1="0.3175" x2="-2.6543" y2="0.3429" layer="21"/>
<rectangle x1="-2.1717" y1="0.3175" x2="-1.7653" y2="0.3429" layer="21"/>
<rectangle x1="-0.8509" y1="0.3175" x2="-0.3683" y2="0.3429" layer="21"/>
<rectangle x1="0.1651" y1="0.3175" x2="1.1303" y2="0.3429" layer="21"/>
<rectangle x1="1.4859" y1="0.3175" x2="2.2987" y2="0.3429" layer="21"/>
<rectangle x1="2.7559" y1="0.3175" x2="3.0607" y2="0.3429" layer="21"/>
<rectangle x1="3.4671" y1="0.3175" x2="3.7211" y2="0.3429" layer="21"/>
<rectangle x1="3.9751" y1="0.3175" x2="4.4831" y2="0.3429" layer="21"/>
<rectangle x1="4.7371" y1="0.3175" x2="4.9911" y2="0.3429" layer="21"/>
<rectangle x1="5.7277" y1="0.3175" x2="5.9817" y2="0.3429" layer="21"/>
<rectangle x1="6.2357" y1="0.3175" x2="6.7437" y2="0.3429" layer="21"/>
<rectangle x1="6.9977" y1="0.3175" x2="7.5057" y2="0.3429" layer="21"/>
<rectangle x1="-7.4041" y1="0.3429" x2="-6.8961" y2="0.3683" layer="21"/>
<rectangle x1="-6.6421" y1="0.3429" x2="-6.3881" y2="0.3683" layer="21"/>
<rectangle x1="-5.6261" y1="0.3429" x2="-5.3721" y2="0.3683" layer="21"/>
<rectangle x1="-5.1181" y1="0.3429" x2="-4.6355" y2="0.3683" layer="21"/>
<rectangle x1="-4.3815" y1="0.3429" x2="-3.8735" y2="0.3683" layer="21"/>
<rectangle x1="-3.6195" y1="0.3429" x2="-3.3655" y2="0.3683" layer="21"/>
<rectangle x1="-2.9591" y1="0.3429" x2="-2.6543" y2="0.3683" layer="21"/>
<rectangle x1="-2.1717" y1="0.3429" x2="-1.7653" y2="0.3683" layer="21"/>
<rectangle x1="-0.8509" y1="0.3429" x2="-0.3683" y2="0.3683" layer="21"/>
<rectangle x1="0.1651" y1="0.3429" x2="1.1049" y2="0.3683" layer="21"/>
<rectangle x1="1.5113" y1="0.3429" x2="2.2987" y2="0.3683" layer="21"/>
<rectangle x1="2.7559" y1="0.3429" x2="3.0607" y2="0.3683" layer="21"/>
<rectangle x1="3.4671" y1="0.3429" x2="3.7211" y2="0.3683" layer="21"/>
<rectangle x1="3.9751" y1="0.3429" x2="4.4831" y2="0.3683" layer="21"/>
<rectangle x1="4.7371" y1="0.3429" x2="4.9911" y2="0.3683" layer="21"/>
<rectangle x1="5.7277" y1="0.3429" x2="5.9817" y2="0.3683" layer="21"/>
<rectangle x1="6.2357" y1="0.3429" x2="6.7437" y2="0.3683" layer="21"/>
<rectangle x1="6.9977" y1="0.3429" x2="7.5057" y2="0.3683" layer="21"/>
<rectangle x1="-7.4041" y1="0.3683" x2="-6.8961" y2="0.3937" layer="21"/>
<rectangle x1="-6.6421" y1="0.3683" x2="-6.3881" y2="0.3937" layer="21"/>
<rectangle x1="-5.6261" y1="0.3683" x2="-5.3721" y2="0.3937" layer="21"/>
<rectangle x1="-5.1181" y1="0.3683" x2="-4.6355" y2="0.3937" layer="21"/>
<rectangle x1="-4.3815" y1="0.3683" x2="-3.8735" y2="0.3937" layer="21"/>
<rectangle x1="-3.6195" y1="0.3683" x2="-3.3655" y2="0.3937" layer="21"/>
<rectangle x1="-2.9591" y1="0.3683" x2="-2.6543" y2="0.3937" layer="21"/>
<rectangle x1="-2.1717" y1="0.3683" x2="-1.7653" y2="0.3937" layer="21"/>
<rectangle x1="-0.8509" y1="0.3683" x2="-0.3683" y2="0.3937" layer="21"/>
<rectangle x1="0.1651" y1="0.3683" x2="1.0795" y2="0.3937" layer="21"/>
<rectangle x1="1.5367" y1="0.3683" x2="2.2987" y2="0.3937" layer="21"/>
<rectangle x1="2.7559" y1="0.3683" x2="3.0607" y2="0.3937" layer="21"/>
<rectangle x1="3.4671" y1="0.3683" x2="3.7211" y2="0.3937" layer="21"/>
<rectangle x1="3.9751" y1="0.3683" x2="4.4831" y2="0.3937" layer="21"/>
<rectangle x1="4.7371" y1="0.3683" x2="4.9911" y2="0.3937" layer="21"/>
<rectangle x1="5.7277" y1="0.3683" x2="5.9817" y2="0.3937" layer="21"/>
<rectangle x1="6.2357" y1="0.3683" x2="6.7437" y2="0.3937" layer="21"/>
<rectangle x1="6.9977" y1="0.3683" x2="7.5057" y2="0.3937" layer="21"/>
<rectangle x1="-7.4041" y1="0.3937" x2="-6.8961" y2="0.4191" layer="21"/>
<rectangle x1="-6.6421" y1="0.3937" x2="-6.3881" y2="0.4191" layer="21"/>
<rectangle x1="-5.6261" y1="0.3937" x2="-5.3721" y2="0.4191" layer="21"/>
<rectangle x1="-5.1181" y1="0.3937" x2="-4.6355" y2="0.4191" layer="21"/>
<rectangle x1="-4.3815" y1="0.3937" x2="-3.8735" y2="0.4191" layer="21"/>
<rectangle x1="-3.6195" y1="0.3937" x2="-3.3655" y2="0.4191" layer="21"/>
<rectangle x1="-2.9591" y1="0.3937" x2="-2.6543" y2="0.4191" layer="21"/>
<rectangle x1="-2.1717" y1="0.3937" x2="-1.7653" y2="0.4191" layer="21"/>
<rectangle x1="-0.8255" y1="0.3937" x2="-0.3683" y2="0.4191" layer="21"/>
<rectangle x1="0.1651" y1="0.3937" x2="1.0541" y2="0.4191" layer="21"/>
<rectangle x1="1.5621" y1="0.3937" x2="2.2987" y2="0.4191" layer="21"/>
<rectangle x1="2.7559" y1="0.3937" x2="3.0607" y2="0.4191" layer="21"/>
<rectangle x1="3.4671" y1="0.3937" x2="3.7211" y2="0.4191" layer="21"/>
<rectangle x1="3.9751" y1="0.3937" x2="4.4831" y2="0.4191" layer="21"/>
<rectangle x1="4.7371" y1="0.3937" x2="4.9911" y2="0.4191" layer="21"/>
<rectangle x1="5.7277" y1="0.3937" x2="5.9817" y2="0.4191" layer="21"/>
<rectangle x1="6.2357" y1="0.3937" x2="6.7437" y2="0.4191" layer="21"/>
<rectangle x1="6.9977" y1="0.3937" x2="7.5057" y2="0.4191" layer="21"/>
<rectangle x1="-7.4041" y1="0.4191" x2="-6.8961" y2="0.4445" layer="21"/>
<rectangle x1="-6.6421" y1="0.4191" x2="-6.3881" y2="0.4445" layer="21"/>
<rectangle x1="-5.6261" y1="0.4191" x2="-5.3721" y2="0.4445" layer="21"/>
<rectangle x1="-5.1181" y1="0.4191" x2="-4.6355" y2="0.4445" layer="21"/>
<rectangle x1="-4.3815" y1="0.4191" x2="-3.8735" y2="0.4445" layer="21"/>
<rectangle x1="-3.6195" y1="0.4191" x2="-3.3655" y2="0.4445" layer="21"/>
<rectangle x1="-2.9591" y1="0.4191" x2="-2.6543" y2="0.4445" layer="21"/>
<rectangle x1="-2.1717" y1="0.4191" x2="-1.7653" y2="0.4445" layer="21"/>
<rectangle x1="-0.8255" y1="0.4191" x2="-0.3937" y2="0.4445" layer="21"/>
<rectangle x1="0.1651" y1="0.4191" x2="1.0287" y2="0.4445" layer="21"/>
<rectangle x1="1.5875" y1="0.4191" x2="2.2987" y2="0.4445" layer="21"/>
<rectangle x1="2.7559" y1="0.4191" x2="3.0607" y2="0.4445" layer="21"/>
<rectangle x1="3.4671" y1="0.4191" x2="3.7211" y2="0.4445" layer="21"/>
<rectangle x1="3.9751" y1="0.4191" x2="4.4831" y2="0.4445" layer="21"/>
<rectangle x1="4.7371" y1="0.4191" x2="4.9911" y2="0.4445" layer="21"/>
<rectangle x1="5.7277" y1="0.4191" x2="5.9817" y2="0.4445" layer="21"/>
<rectangle x1="6.2357" y1="0.4191" x2="6.7437" y2="0.4445" layer="21"/>
<rectangle x1="6.9977" y1="0.4191" x2="7.5057" y2="0.4445" layer="21"/>
<rectangle x1="-7.4041" y1="0.4445" x2="-6.8961" y2="0.4699" layer="21"/>
<rectangle x1="-6.6421" y1="0.4445" x2="-6.3881" y2="0.4699" layer="21"/>
<rectangle x1="-5.6261" y1="0.4445" x2="-5.3721" y2="0.4699" layer="21"/>
<rectangle x1="-5.1181" y1="0.4445" x2="-4.6355" y2="0.4699" layer="21"/>
<rectangle x1="-4.3815" y1="0.4445" x2="-3.8735" y2="0.4699" layer="21"/>
<rectangle x1="-3.6195" y1="0.4445" x2="-3.3655" y2="0.4699" layer="21"/>
<rectangle x1="-2.9591" y1="0.4445" x2="-2.6543" y2="0.4699" layer="21"/>
<rectangle x1="-2.1717" y1="0.4445" x2="-1.7653" y2="0.4699" layer="21"/>
<rectangle x1="-0.8255" y1="0.4445" x2="-0.3937" y2="0.4699" layer="21"/>
<rectangle x1="0.1651" y1="0.4445" x2="1.0033" y2="0.4699" layer="21"/>
<rectangle x1="1.6383" y1="0.4445" x2="2.2733" y2="0.4699" layer="21"/>
<rectangle x1="2.7559" y1="0.4445" x2="3.0607" y2="0.4699" layer="21"/>
<rectangle x1="3.4671" y1="0.4445" x2="3.7211" y2="0.4699" layer="21"/>
<rectangle x1="3.9751" y1="0.4445" x2="4.4831" y2="0.4699" layer="21"/>
<rectangle x1="4.7371" y1="0.4445" x2="4.9911" y2="0.4699" layer="21"/>
<rectangle x1="5.7277" y1="0.4445" x2="5.9817" y2="0.4699" layer="21"/>
<rectangle x1="6.2357" y1="0.4445" x2="6.7437" y2="0.4699" layer="21"/>
<rectangle x1="6.9977" y1="0.4445" x2="7.5057" y2="0.4699" layer="21"/>
<rectangle x1="-7.4041" y1="0.4699" x2="-6.8961" y2="0.4953" layer="21"/>
<rectangle x1="-6.6421" y1="0.4699" x2="-6.3881" y2="0.4953" layer="21"/>
<rectangle x1="-5.6261" y1="0.4699" x2="-5.3721" y2="0.4953" layer="21"/>
<rectangle x1="-5.1181" y1="0.4699" x2="-4.6355" y2="0.4953" layer="21"/>
<rectangle x1="-4.3815" y1="0.4699" x2="-3.8735" y2="0.4953" layer="21"/>
<rectangle x1="-3.6195" y1="0.4699" x2="-3.3655" y2="0.4953" layer="21"/>
<rectangle x1="-2.9591" y1="0.4699" x2="-2.6543" y2="0.4953" layer="21"/>
<rectangle x1="-2.1717" y1="0.4699" x2="-1.7653" y2="0.4953" layer="21"/>
<rectangle x1="-0.8255" y1="0.4699" x2="-0.3937" y2="0.4953" layer="21"/>
<rectangle x1="0.1651" y1="0.4699" x2="0.9525" y2="0.4953" layer="21"/>
<rectangle x1="1.6637" y1="0.4699" x2="2.2225" y2="0.4953" layer="21"/>
<rectangle x1="2.7559" y1="0.4699" x2="3.0607" y2="0.4953" layer="21"/>
<rectangle x1="3.4671" y1="0.4699" x2="3.7211" y2="0.4953" layer="21"/>
<rectangle x1="3.9751" y1="0.4699" x2="4.4831" y2="0.4953" layer="21"/>
<rectangle x1="4.7371" y1="0.4699" x2="4.9911" y2="0.4953" layer="21"/>
<rectangle x1="5.7277" y1="0.4699" x2="5.9817" y2="0.4953" layer="21"/>
<rectangle x1="6.2357" y1="0.4699" x2="6.7437" y2="0.4953" layer="21"/>
<rectangle x1="6.9977" y1="0.4699" x2="7.5057" y2="0.4953" layer="21"/>
<rectangle x1="-7.1501" y1="0.4953" x2="-6.8961" y2="0.5207" layer="21"/>
<rectangle x1="-6.3881" y1="0.4953" x2="-5.6261" y2="0.5207" layer="21"/>
<rectangle x1="-4.8895" y1="0.4953" x2="-4.6355" y2="0.5207" layer="21"/>
<rectangle x1="-4.1275" y1="0.4953" x2="-3.8735" y2="0.5207" layer="21"/>
<rectangle x1="-3.3655" y1="0.4953" x2="-2.6543" y2="0.5207" layer="21"/>
<rectangle x1="-2.1717" y1="0.4953" x2="-1.7653" y2="0.5207" layer="21"/>
<rectangle x1="-1.4859" y1="0.4953" x2="-1.3081" y2="0.5207" layer="21"/>
<rectangle x1="-1.0287" y1="0.4953" x2="-0.3175" y2="0.5207" layer="21"/>
<rectangle x1="-0.1651" y1="0.4953" x2="0.0381" y2="0.5207" layer="21"/>
<rectangle x1="0.1651" y1="0.4953" x2="0.9779" y2="0.5207" layer="21"/>
<rectangle x1="1.2573" y1="0.4953" x2="1.4351" y2="0.5207" layer="21"/>
<rectangle x1="1.5875" y1="0.4953" x2="2.3495" y2="0.5207" layer="21"/>
<rectangle x1="2.7559" y1="0.4953" x2="3.4671" y2="0.5207" layer="21"/>
<rectangle x1="4.2291" y1="0.4953" x2="4.4831" y2="0.5207" layer="21"/>
<rectangle x1="4.9911" y1="0.4953" x2="5.7277" y2="0.5207" layer="21"/>
<rectangle x1="6.4897" y1="0.4953" x2="6.7437" y2="0.5207" layer="21"/>
<rectangle x1="7.2517" y1="0.4953" x2="7.5057" y2="0.5207" layer="21"/>
<rectangle x1="-7.1501" y1="0.5207" x2="-6.8961" y2="0.5461" layer="21"/>
<rectangle x1="-6.3881" y1="0.5207" x2="-5.6261" y2="0.5461" layer="21"/>
<rectangle x1="-4.8895" y1="0.5207" x2="-4.6355" y2="0.5461" layer="21"/>
<rectangle x1="-4.1275" y1="0.5207" x2="-3.8735" y2="0.5461" layer="21"/>
<rectangle x1="-3.3655" y1="0.5207" x2="-2.6543" y2="0.5461" layer="21"/>
<rectangle x1="-2.1209" y1="0.5207" x2="-1.8161" y2="0.5461" layer="21"/>
<rectangle x1="-1.4859" y1="0.5207" x2="-1.2827" y2="0.5461" layer="21"/>
<rectangle x1="-1.0287" y1="0.5207" x2="-0.5715" y2="0.5461" layer="21"/>
<rectangle x1="-0.4953" y1="0.5207" x2="-0.2921" y2="0.5461" layer="21"/>
<rectangle x1="-0.1905" y1="0.5207" x2="0.0381" y2="0.5461" layer="21"/>
<rectangle x1="0.2159" y1="0.5207" x2="0.3937" y2="0.5461" layer="21"/>
<rectangle x1="0.7239" y1="0.5207" x2="1.0287" y2="0.5461" layer="21"/>
<rectangle x1="1.2573" y1="0.5207" x2="1.4351" y2="0.5461" layer="21"/>
<rectangle x1="1.5875" y1="0.5207" x2="1.7907" y2="0.5461" layer="21"/>
<rectangle x1="1.8161" y1="0.5207" x2="2.3495" y2="0.5461" layer="21"/>
<rectangle x1="2.7559" y1="0.5207" x2="3.4671" y2="0.5461" layer="21"/>
<rectangle x1="4.2291" y1="0.5207" x2="4.4831" y2="0.5461" layer="21"/>
<rectangle x1="4.9911" y1="0.5207" x2="5.7277" y2="0.5461" layer="21"/>
<rectangle x1="6.4897" y1="0.5207" x2="6.7437" y2="0.5461" layer="21"/>
<rectangle x1="7.2517" y1="0.5207" x2="7.5057" y2="0.5461" layer="21"/>
<rectangle x1="-7.1501" y1="0.5461" x2="-6.8961" y2="0.5715" layer="21"/>
<rectangle x1="-6.3881" y1="0.5461" x2="-5.6261" y2="0.5715" layer="21"/>
<rectangle x1="-4.8895" y1="0.5461" x2="-4.6355" y2="0.5715" layer="21"/>
<rectangle x1="-4.1275" y1="0.5461" x2="-3.8735" y2="0.5715" layer="21"/>
<rectangle x1="-3.3655" y1="0.5461" x2="-2.6543" y2="0.5715" layer="21"/>
<rectangle x1="-2.1463" y1="0.5461" x2="-1.7907" y2="0.5715" layer="21"/>
<rectangle x1="-1.5113" y1="0.5461" x2="-1.2827" y2="0.5715" layer="21"/>
<rectangle x1="-1.0287" y1="0.5461" x2="-0.5715" y2="0.5715" layer="21"/>
<rectangle x1="-0.4953" y1="0.5461" x2="-0.2921" y2="0.5715" layer="21"/>
<rectangle x1="-0.1905" y1="0.5461" x2="0.0127" y2="0.5715" layer="21"/>
<rectangle x1="0.2159" y1="0.5461" x2="0.3937" y2="0.5715" layer="21"/>
<rectangle x1="0.6985" y1="0.5461" x2="1.0541" y2="0.5715" layer="21"/>
<rectangle x1="1.2573" y1="0.5461" x2="1.4351" y2="0.5715" layer="21"/>
<rectangle x1="1.5621" y1="0.5461" x2="1.7907" y2="0.5715" layer="21"/>
<rectangle x1="1.8923" y1="0.5461" x2="2.3495" y2="0.5715" layer="21"/>
<rectangle x1="2.7559" y1="0.5461" x2="3.4671" y2="0.5715" layer="21"/>
<rectangle x1="4.2291" y1="0.5461" x2="4.4831" y2="0.5715" layer="21"/>
<rectangle x1="4.9911" y1="0.5461" x2="5.7277" y2="0.5715" layer="21"/>
<rectangle x1="6.4897" y1="0.5461" x2="6.7437" y2="0.5715" layer="21"/>
<rectangle x1="7.2517" y1="0.5461" x2="7.5057" y2="0.5715" layer="21"/>
<rectangle x1="-7.1501" y1="0.5715" x2="-6.8961" y2="0.5969" layer="21"/>
<rectangle x1="-6.3881" y1="0.5715" x2="-5.6261" y2="0.5969" layer="21"/>
<rectangle x1="-4.8895" y1="0.5715" x2="-4.6355" y2="0.5969" layer="21"/>
<rectangle x1="-4.1275" y1="0.5715" x2="-3.8735" y2="0.5969" layer="21"/>
<rectangle x1="-3.3655" y1="0.5715" x2="-2.6543" y2="0.5969" layer="21"/>
<rectangle x1="-2.1717" y1="0.5715" x2="-1.7653" y2="0.5969" layer="21"/>
<rectangle x1="-1.5113" y1="0.5715" x2="-1.2827" y2="0.5969" layer="21"/>
<rectangle x1="-1.0287" y1="0.5715" x2="-0.5715" y2="0.5969" layer="21"/>
<rectangle x1="-0.4953" y1="0.5715" x2="-0.2921" y2="0.5969" layer="21"/>
<rectangle x1="-0.1905" y1="0.5715" x2="0.0127" y2="0.5969" layer="21"/>
<rectangle x1="0.2159" y1="0.5715" x2="0.3937" y2="0.5969" layer="21"/>
<rectangle x1="0.6731" y1="0.5715" x2="1.0795" y2="0.5969" layer="21"/>
<rectangle x1="1.2573" y1="0.5715" x2="1.4351" y2="0.5969" layer="21"/>
<rectangle x1="1.5621" y1="0.5715" x2="1.7907" y2="0.5969" layer="21"/>
<rectangle x1="1.8923" y1="0.5715" x2="2.3495" y2="0.5969" layer="21"/>
<rectangle x1="2.7559" y1="0.5715" x2="3.4671" y2="0.5969" layer="21"/>
<rectangle x1="4.2291" y1="0.5715" x2="4.4831" y2="0.5969" layer="21"/>
<rectangle x1="4.9911" y1="0.5715" x2="5.7277" y2="0.5969" layer="21"/>
<rectangle x1="6.4897" y1="0.5715" x2="6.7437" y2="0.5969" layer="21"/>
<rectangle x1="7.2517" y1="0.5715" x2="7.5057" y2="0.5969" layer="21"/>
<rectangle x1="-7.1501" y1="0.5969" x2="-6.8961" y2="0.6223" layer="21"/>
<rectangle x1="-6.3881" y1="0.5969" x2="-5.6261" y2="0.6223" layer="21"/>
<rectangle x1="-4.8895" y1="0.5969" x2="-4.6355" y2="0.6223" layer="21"/>
<rectangle x1="-4.1275" y1="0.5969" x2="-3.8735" y2="0.6223" layer="21"/>
<rectangle x1="-3.3655" y1="0.5969" x2="-2.6543" y2="0.6223" layer="21"/>
<rectangle x1="-2.1971" y1="0.5969" x2="-1.7399" y2="0.6223" layer="21"/>
<rectangle x1="-1.5113" y1="0.5969" x2="-1.2827" y2="0.6223" layer="21"/>
<rectangle x1="-1.0287" y1="0.5969" x2="-0.5715" y2="0.6223" layer="21"/>
<rectangle x1="-0.4953" y1="0.5969" x2="-0.2921" y2="0.6223" layer="21"/>
<rectangle x1="-0.1905" y1="0.5969" x2="0.0127" y2="0.6223" layer="21"/>
<rectangle x1="0.2159" y1="0.5969" x2="0.3937" y2="0.6223" layer="21"/>
<rectangle x1="0.6477" y1="0.5969" x2="1.1049" y2="0.6223" layer="21"/>
<rectangle x1="1.2573" y1="0.5969" x2="1.4351" y2="0.6223" layer="21"/>
<rectangle x1="1.5621" y1="0.5969" x2="1.7907" y2="0.6223" layer="21"/>
<rectangle x1="1.8923" y1="0.5969" x2="2.3495" y2="0.6223" layer="21"/>
<rectangle x1="2.7559" y1="0.5969" x2="3.4671" y2="0.6223" layer="21"/>
<rectangle x1="4.2291" y1="0.5969" x2="4.4831" y2="0.6223" layer="21"/>
<rectangle x1="4.9911" y1="0.5969" x2="5.7277" y2="0.6223" layer="21"/>
<rectangle x1="6.4897" y1="0.5969" x2="6.7437" y2="0.6223" layer="21"/>
<rectangle x1="7.2517" y1="0.5969" x2="7.5057" y2="0.6223" layer="21"/>
<rectangle x1="-7.1501" y1="0.6223" x2="-6.8961" y2="0.6477" layer="21"/>
<rectangle x1="-6.3881" y1="0.6223" x2="-5.6261" y2="0.6477" layer="21"/>
<rectangle x1="-4.8895" y1="0.6223" x2="-4.6355" y2="0.6477" layer="21"/>
<rectangle x1="-4.1275" y1="0.6223" x2="-3.8735" y2="0.6477" layer="21"/>
<rectangle x1="-3.3655" y1="0.6223" x2="-2.6543" y2="0.6477" layer="21"/>
<rectangle x1="-2.2225" y1="0.6223" x2="-1.7399" y2="0.6477" layer="21"/>
<rectangle x1="-1.5113" y1="0.6223" x2="-1.2573" y2="0.6477" layer="21"/>
<rectangle x1="-1.0287" y1="0.6223" x2="-0.5715" y2="0.6477" layer="21"/>
<rectangle x1="-0.4953" y1="0.6223" x2="-0.2921" y2="0.6477" layer="21"/>
<rectangle x1="-0.1905" y1="0.6223" x2="0.0127" y2="0.6477" layer="21"/>
<rectangle x1="0.2159" y1="0.6223" x2="0.3937" y2="0.6477" layer="21"/>
<rectangle x1="0.6477" y1="0.6223" x2="1.1049" y2="0.6477" layer="21"/>
<rectangle x1="1.2573" y1="0.6223" x2="1.4351" y2="0.6477" layer="21"/>
<rectangle x1="1.5367" y1="0.6223" x2="1.7907" y2="0.6477" layer="21"/>
<rectangle x1="1.8923" y1="0.6223" x2="2.3495" y2="0.6477" layer="21"/>
<rectangle x1="2.7559" y1="0.6223" x2="3.4671" y2="0.6477" layer="21"/>
<rectangle x1="4.2291" y1="0.6223" x2="4.4831" y2="0.6477" layer="21"/>
<rectangle x1="4.9911" y1="0.6223" x2="5.7277" y2="0.6477" layer="21"/>
<rectangle x1="6.4897" y1="0.6223" x2="6.7437" y2="0.6477" layer="21"/>
<rectangle x1="7.2517" y1="0.6223" x2="7.5057" y2="0.6477" layer="21"/>
<rectangle x1="-7.1501" y1="0.6477" x2="-6.8961" y2="0.6731" layer="21"/>
<rectangle x1="-6.3881" y1="0.6477" x2="-5.6261" y2="0.6731" layer="21"/>
<rectangle x1="-4.8895" y1="0.6477" x2="-4.6355" y2="0.6731" layer="21"/>
<rectangle x1="-4.1275" y1="0.6477" x2="-3.8735" y2="0.6731" layer="21"/>
<rectangle x1="-3.3655" y1="0.6477" x2="-2.6543" y2="0.6731" layer="21"/>
<rectangle x1="-2.2225" y1="0.6477" x2="-1.7145" y2="0.6731" layer="21"/>
<rectangle x1="-1.5367" y1="0.6477" x2="-1.2573" y2="0.6731" layer="21"/>
<rectangle x1="-1.0287" y1="0.6477" x2="-0.5715" y2="0.6731" layer="21"/>
<rectangle x1="-0.4953" y1="0.6477" x2="-0.2921" y2="0.6731" layer="21"/>
<rectangle x1="-0.1905" y1="0.6477" x2="-0.0127" y2="0.6731" layer="21"/>
<rectangle x1="0.2159" y1="0.6477" x2="0.3937" y2="0.6731" layer="21"/>
<rectangle x1="0.6223" y1="0.6477" x2="1.1303" y2="0.6731" layer="21"/>
<rectangle x1="1.2573" y1="0.6477" x2="1.4351" y2="0.6731" layer="21"/>
<rectangle x1="1.5367" y1="0.6477" x2="1.7907" y2="0.6731" layer="21"/>
<rectangle x1="1.8923" y1="0.6477" x2="2.3495" y2="0.6731" layer="21"/>
<rectangle x1="2.7559" y1="0.6477" x2="3.4671" y2="0.6731" layer="21"/>
<rectangle x1="4.2291" y1="0.6477" x2="4.4831" y2="0.6731" layer="21"/>
<rectangle x1="4.9911" y1="0.6477" x2="5.7277" y2="0.6731" layer="21"/>
<rectangle x1="6.4897" y1="0.6477" x2="6.7437" y2="0.6731" layer="21"/>
<rectangle x1="7.2517" y1="0.6477" x2="7.5057" y2="0.6731" layer="21"/>
<rectangle x1="-7.1501" y1="0.6731" x2="-6.8961" y2="0.6985" layer="21"/>
<rectangle x1="-6.3881" y1="0.6731" x2="-5.6261" y2="0.6985" layer="21"/>
<rectangle x1="-4.8895" y1="0.6731" x2="-4.6355" y2="0.6985" layer="21"/>
<rectangle x1="-4.1275" y1="0.6731" x2="-3.8735" y2="0.6985" layer="21"/>
<rectangle x1="-3.3655" y1="0.6731" x2="-2.6543" y2="0.6985" layer="21"/>
<rectangle x1="-2.2225" y1="0.6731" x2="-2.0193" y2="0.6985" layer="21"/>
<rectangle x1="-1.9177" y1="0.6731" x2="-1.7145" y2="0.6985" layer="21"/>
<rectangle x1="-1.5367" y1="0.6731" x2="-1.2573" y2="0.6985" layer="21"/>
<rectangle x1="-1.0287" y1="0.6731" x2="-0.8509" y2="0.6985" layer="21"/>
<rectangle x1="-0.4953" y1="0.6731" x2="-0.2921" y2="0.6985" layer="21"/>
<rectangle x1="-0.1905" y1="0.6731" x2="-0.0127" y2="0.6985" layer="21"/>
<rectangle x1="0.2159" y1="0.6731" x2="0.3937" y2="0.6985" layer="21"/>
<rectangle x1="0.6223" y1="0.6731" x2="0.8255" y2="0.6985" layer="21"/>
<rectangle x1="0.9271" y1="0.6731" x2="1.1303" y2="0.6985" layer="21"/>
<rectangle x1="1.2573" y1="0.6731" x2="1.4351" y2="0.6985" layer="21"/>
<rectangle x1="1.5113" y1="0.6731" x2="1.7907" y2="0.6985" layer="21"/>
<rectangle x1="1.8923" y1="0.6731" x2="2.0701" y2="0.6985" layer="21"/>
<rectangle x1="2.7559" y1="0.6731" x2="3.4671" y2="0.6985" layer="21"/>
<rectangle x1="4.2291" y1="0.6731" x2="4.4831" y2="0.6985" layer="21"/>
<rectangle x1="4.9911" y1="0.6731" x2="5.7277" y2="0.6985" layer="21"/>
<rectangle x1="6.4897" y1="0.6731" x2="6.7437" y2="0.6985" layer="21"/>
<rectangle x1="7.2517" y1="0.6731" x2="7.5057" y2="0.6985" layer="21"/>
<rectangle x1="-7.1501" y1="0.6985" x2="-6.8961" y2="0.7239" layer="21"/>
<rectangle x1="-6.3881" y1="0.6985" x2="-5.6261" y2="0.7239" layer="21"/>
<rectangle x1="-4.8895" y1="0.6985" x2="-4.6355" y2="0.7239" layer="21"/>
<rectangle x1="-4.1275" y1="0.6985" x2="-3.8735" y2="0.7239" layer="21"/>
<rectangle x1="-3.3655" y1="0.6985" x2="-2.6543" y2="0.7239" layer="21"/>
<rectangle x1="-2.2479" y1="0.6985" x2="-2.0447" y2="0.7239" layer="21"/>
<rectangle x1="-1.9177" y1="0.6985" x2="-1.6891" y2="0.7239" layer="21"/>
<rectangle x1="-1.5367" y1="0.6985" x2="-1.2573" y2="0.7239" layer="21"/>
<rectangle x1="-1.0287" y1="0.6985" x2="-0.8509" y2="0.7239" layer="21"/>
<rectangle x1="-0.4953" y1="0.6985" x2="-0.2921" y2="0.7239" layer="21"/>
<rectangle x1="-0.2159" y1="0.6985" x2="-0.0127" y2="0.7239" layer="21"/>
<rectangle x1="0.2159" y1="0.6985" x2="0.3937" y2="0.7239" layer="21"/>
<rectangle x1="0.5969" y1="0.6985" x2="0.8001" y2="0.7239" layer="21"/>
<rectangle x1="0.9525" y1="0.6985" x2="1.1557" y2="0.7239" layer="21"/>
<rectangle x1="1.2573" y1="0.6985" x2="1.4351" y2="0.7239" layer="21"/>
<rectangle x1="1.5113" y1="0.6985" x2="1.7907" y2="0.7239" layer="21"/>
<rectangle x1="1.8923" y1="0.6985" x2="2.0701" y2="0.7239" layer="21"/>
<rectangle x1="2.7559" y1="0.6985" x2="3.4671" y2="0.7239" layer="21"/>
<rectangle x1="4.2291" y1="0.6985" x2="4.4831" y2="0.7239" layer="21"/>
<rectangle x1="4.9911" y1="0.6985" x2="5.7277" y2="0.7239" layer="21"/>
<rectangle x1="6.4897" y1="0.6985" x2="6.7437" y2="0.7239" layer="21"/>
<rectangle x1="7.2517" y1="0.6985" x2="7.5057" y2="0.7239" layer="21"/>
<rectangle x1="-7.1501" y1="0.7239" x2="-6.8961" y2="0.7493" layer="21"/>
<rectangle x1="-6.3881" y1="0.7239" x2="-5.6261" y2="0.7493" layer="21"/>
<rectangle x1="-4.8895" y1="0.7239" x2="-4.6355" y2="0.7493" layer="21"/>
<rectangle x1="-4.1275" y1="0.7239" x2="-3.8735" y2="0.7493" layer="21"/>
<rectangle x1="-3.3655" y1="0.7239" x2="-2.6543" y2="0.7493" layer="21"/>
<rectangle x1="-2.2479" y1="0.7239" x2="-2.0447" y2="0.7493" layer="21"/>
<rectangle x1="-1.8923" y1="0.7239" x2="-1.6891" y2="0.7493" layer="21"/>
<rectangle x1="-1.5367" y1="0.7239" x2="-1.2319" y2="0.7493" layer="21"/>
<rectangle x1="-1.0287" y1="0.7239" x2="-0.8509" y2="0.7493" layer="21"/>
<rectangle x1="-0.4953" y1="0.7239" x2="-0.2921" y2="0.7493" layer="21"/>
<rectangle x1="-0.2159" y1="0.7239" x2="-0.0127" y2="0.7493" layer="21"/>
<rectangle x1="0.2159" y1="0.7239" x2="0.3937" y2="0.7493" layer="21"/>
<rectangle x1="0.5969" y1="0.7239" x2="0.8001" y2="0.7493" layer="21"/>
<rectangle x1="0.9525" y1="0.7239" x2="1.1557" y2="0.7493" layer="21"/>
<rectangle x1="1.2573" y1="0.7239" x2="1.4351" y2="0.7493" layer="21"/>
<rectangle x1="1.5113" y1="0.7239" x2="1.7907" y2="0.7493" layer="21"/>
<rectangle x1="1.8923" y1="0.7239" x2="2.0701" y2="0.7493" layer="21"/>
<rectangle x1="2.7559" y1="0.7239" x2="3.4671" y2="0.7493" layer="21"/>
<rectangle x1="4.2291" y1="0.7239" x2="4.4831" y2="0.7493" layer="21"/>
<rectangle x1="4.9911" y1="0.7239" x2="5.7277" y2="0.7493" layer="21"/>
<rectangle x1="6.4897" y1="0.7239" x2="6.7437" y2="0.7493" layer="21"/>
<rectangle x1="7.2517" y1="0.7239" x2="7.5057" y2="0.7493" layer="21"/>
<rectangle x1="-2.9591" y1="0.7493" x2="-2.6543" y2="0.7747" layer="21"/>
<rectangle x1="-2.2479" y1="0.7493" x2="-2.0701" y2="0.7747" layer="21"/>
<rectangle x1="-1.8923" y1="0.7493" x2="-1.6891" y2="0.7747" layer="21"/>
<rectangle x1="-1.5621" y1="0.7493" x2="-1.2319" y2="0.7747" layer="21"/>
<rectangle x1="-1.0287" y1="0.7493" x2="-0.8509" y2="0.7747" layer="21"/>
<rectangle x1="-0.4953" y1="0.7493" x2="-0.2921" y2="0.7747" layer="21"/>
<rectangle x1="-0.2159" y1="0.7493" x2="-0.0127" y2="0.7747" layer="21"/>
<rectangle x1="0.2159" y1="0.7493" x2="0.3937" y2="0.7747" layer="21"/>
<rectangle x1="0.5969" y1="0.7493" x2="0.7747" y2="0.7747" layer="21"/>
<rectangle x1="0.9779" y1="0.7493" x2="1.1557" y2="0.7747" layer="21"/>
<rectangle x1="1.2573" y1="0.7493" x2="1.4351" y2="0.7747" layer="21"/>
<rectangle x1="1.4859" y1="0.7493" x2="1.7907" y2="0.7747" layer="21"/>
<rectangle x1="1.8923" y1="0.7493" x2="2.0701" y2="0.7747" layer="21"/>
<rectangle x1="2.7559" y1="0.7493" x2="3.0607" y2="0.7747" layer="21"/>
<rectangle x1="-2.9591" y1="0.7747" x2="-2.6543" y2="0.8001" layer="21"/>
<rectangle x1="-2.2733" y1="0.7747" x2="-2.0701" y2="0.8001" layer="21"/>
<rectangle x1="-1.8669" y1="0.7747" x2="-1.6891" y2="0.8001" layer="21"/>
<rectangle x1="-1.5621" y1="0.7747" x2="-1.2319" y2="0.8001" layer="21"/>
<rectangle x1="-1.0287" y1="0.7747" x2="-0.8509" y2="0.8001" layer="21"/>
<rectangle x1="-0.4953" y1="0.7747" x2="-0.2921" y2="0.8001" layer="21"/>
<rectangle x1="-0.2159" y1="0.7747" x2="-0.0381" y2="0.8001" layer="21"/>
<rectangle x1="0.2159" y1="0.7747" x2="0.3937" y2="0.8001" layer="21"/>
<rectangle x1="0.5969" y1="0.7747" x2="0.7747" y2="0.8001" layer="21"/>
<rectangle x1="0.9779" y1="0.7747" x2="1.1557" y2="0.8001" layer="21"/>
<rectangle x1="1.2573" y1="0.7747" x2="1.4351" y2="0.8001" layer="21"/>
<rectangle x1="1.4859" y1="0.7747" x2="1.7907" y2="0.8001" layer="21"/>
<rectangle x1="1.8923" y1="0.7747" x2="2.0701" y2="0.8001" layer="21"/>
<rectangle x1="2.7559" y1="0.7747" x2="3.0607" y2="0.8001" layer="21"/>
<rectangle x1="-2.9591" y1="0.8001" x2="-2.6543" y2="0.8255" layer="21"/>
<rectangle x1="-2.2733" y1="0.8001" x2="-2.0701" y2="0.8255" layer="21"/>
<rectangle x1="-1.8669" y1="0.8001" x2="-1.6891" y2="0.8255" layer="21"/>
<rectangle x1="-1.5621" y1="0.8001" x2="-1.2319" y2="0.8255" layer="21"/>
<rectangle x1="-1.0287" y1="0.8001" x2="-0.8509" y2="0.8255" layer="21"/>
<rectangle x1="-0.4953" y1="0.8001" x2="-0.2921" y2="0.8255" layer="21"/>
<rectangle x1="-0.2413" y1="0.8001" x2="-0.0381" y2="0.8255" layer="21"/>
<rectangle x1="0.2159" y1="0.8001" x2="0.3937" y2="0.8255" layer="21"/>
<rectangle x1="0.5715" y1="0.8001" x2="0.7747" y2="0.8255" layer="21"/>
<rectangle x1="0.9779" y1="0.8001" x2="1.1811" y2="0.8255" layer="21"/>
<rectangle x1="1.2573" y1="0.8001" x2="1.4351" y2="0.8255" layer="21"/>
<rectangle x1="1.4859" y1="0.8001" x2="1.7907" y2="0.8255" layer="21"/>
<rectangle x1="1.8923" y1="0.8001" x2="2.0701" y2="0.8255" layer="21"/>
<rectangle x1="2.7559" y1="0.8001" x2="3.0607" y2="0.8255" layer="21"/>
<rectangle x1="-2.9591" y1="0.8255" x2="-2.6543" y2="0.8509" layer="21"/>
<rectangle x1="-2.2733" y1="0.8255" x2="-2.0701" y2="0.8509" layer="21"/>
<rectangle x1="-1.8669" y1="0.8255" x2="-1.6891" y2="0.8509" layer="21"/>
<rectangle x1="-1.5621" y1="0.8255" x2="-1.4097" y2="0.8509" layer="21"/>
<rectangle x1="-1.3843" y1="0.8255" x2="-1.2065" y2="0.8509" layer="21"/>
<rectangle x1="-1.0287" y1="0.8255" x2="-0.6223" y2="0.8509" layer="21"/>
<rectangle x1="-0.4953" y1="0.8255" x2="-0.0635" y2="0.8509" layer="21"/>
<rectangle x1="0.2159" y1="0.8255" x2="0.3937" y2="0.8509" layer="21"/>
<rectangle x1="0.5715" y1="0.8255" x2="0.7747" y2="0.8509" layer="21"/>
<rectangle x1="0.9779" y1="0.8255" x2="1.1811" y2="0.8509" layer="21"/>
<rectangle x1="1.2573" y1="0.8255" x2="1.4351" y2="0.8509" layer="21"/>
<rectangle x1="1.4605" y1="0.8255" x2="1.7907" y2="0.8509" layer="21"/>
<rectangle x1="1.8923" y1="0.8255" x2="2.3241" y2="0.8509" layer="21"/>
<rectangle x1="2.7559" y1="0.8255" x2="3.0607" y2="0.8509" layer="21"/>
<rectangle x1="-2.9591" y1="0.8509" x2="-2.6543" y2="0.8763" layer="21"/>
<rectangle x1="-2.2733" y1="0.8509" x2="-2.0701" y2="0.8763" layer="21"/>
<rectangle x1="-1.8669" y1="0.8509" x2="-1.6891" y2="0.8763" layer="21"/>
<rectangle x1="-1.5875" y1="0.8509" x2="-1.4097" y2="0.8763" layer="21"/>
<rectangle x1="-1.3843" y1="0.8509" x2="-1.2065" y2="0.8763" layer="21"/>
<rectangle x1="-1.0287" y1="0.8509" x2="-0.5969" y2="0.8763" layer="21"/>
<rectangle x1="-0.4953" y1="0.8509" x2="-0.0889" y2="0.8763" layer="21"/>
<rectangle x1="0.2159" y1="0.8509" x2="0.3937" y2="0.8763" layer="21"/>
<rectangle x1="0.5715" y1="0.8509" x2="0.7747" y2="0.8763" layer="21"/>
<rectangle x1="0.9779" y1="0.8509" x2="1.1811" y2="0.8763" layer="21"/>
<rectangle x1="1.2573" y1="0.8509" x2="1.4351" y2="0.8763" layer="21"/>
<rectangle x1="1.4605" y1="0.8509" x2="1.7907" y2="0.8763" layer="21"/>
<rectangle x1="1.8923" y1="0.8509" x2="2.3241" y2="0.8763" layer="21"/>
<rectangle x1="2.7559" y1="0.8509" x2="3.0607" y2="0.8763" layer="21"/>
<rectangle x1="-2.9591" y1="0.8763" x2="-2.6543" y2="0.9017" layer="21"/>
<rectangle x1="-2.2733" y1="0.8763" x2="-2.0955" y2="0.9017" layer="21"/>
<rectangle x1="-1.8669" y1="0.8763" x2="-1.6891" y2="0.9017" layer="21"/>
<rectangle x1="-1.5875" y1="0.8763" x2="-1.4097" y2="0.9017" layer="21"/>
<rectangle x1="-1.3843" y1="0.8763" x2="-1.2065" y2="0.9017" layer="21"/>
<rectangle x1="-1.0287" y1="0.8763" x2="-0.5969" y2="0.9017" layer="21"/>
<rectangle x1="-0.4953" y1="0.8763" x2="-0.1143" y2="0.9017" layer="21"/>
<rectangle x1="0.2159" y1="0.8763" x2="0.3937" y2="0.9017" layer="21"/>
<rectangle x1="0.5715" y1="0.8763" x2="0.7747" y2="0.9017" layer="21"/>
<rectangle x1="0.9779" y1="0.8763" x2="1.1811" y2="0.9017" layer="21"/>
<rectangle x1="1.2573" y1="0.8763" x2="1.4351" y2="0.9017" layer="21"/>
<rectangle x1="1.4605" y1="0.8763" x2="1.5875" y2="0.9017" layer="21"/>
<rectangle x1="1.6129" y1="0.8763" x2="1.7907" y2="0.9017" layer="21"/>
<rectangle x1="1.8923" y1="0.8763" x2="2.3241" y2="0.9017" layer="21"/>
<rectangle x1="2.7559" y1="0.8763" x2="3.0607" y2="0.9017" layer="21"/>
<rectangle x1="-2.9591" y1="0.9017" x2="-2.6543" y2="0.9271" layer="21"/>
<rectangle x1="-2.2733" y1="0.9017" x2="-2.0955" y2="0.9271" layer="21"/>
<rectangle x1="-1.8669" y1="0.9017" x2="-1.6891" y2="0.9271" layer="21"/>
<rectangle x1="-1.5875" y1="0.9017" x2="-1.4097" y2="0.9271" layer="21"/>
<rectangle x1="-1.3589" y1="0.9017" x2="-1.1811" y2="0.9271" layer="21"/>
<rectangle x1="-1.0287" y1="0.9017" x2="-0.5969" y2="0.9271" layer="21"/>
<rectangle x1="-0.4953" y1="0.9017" x2="-0.1143" y2="0.9271" layer="21"/>
<rectangle x1="0.2159" y1="0.9017" x2="0.3937" y2="0.9271" layer="21"/>
<rectangle x1="0.5715" y1="0.9017" x2="0.7747" y2="0.9271" layer="21"/>
<rectangle x1="0.9779" y1="0.9017" x2="1.1811" y2="0.9271" layer="21"/>
<rectangle x1="1.2573" y1="0.9017" x2="1.5875" y2="0.9271" layer="21"/>
<rectangle x1="1.6129" y1="0.9017" x2="1.7907" y2="0.9271" layer="21"/>
<rectangle x1="1.8923" y1="0.9017" x2="2.3241" y2="0.9271" layer="21"/>
<rectangle x1="2.7559" y1="0.9017" x2="3.0607" y2="0.9271" layer="21"/>
<rectangle x1="-2.9591" y1="0.9271" x2="-2.6543" y2="0.9525" layer="21"/>
<rectangle x1="-2.2733" y1="0.9271" x2="-2.0701" y2="0.9525" layer="21"/>
<rectangle x1="-1.8669" y1="0.9271" x2="-1.6891" y2="0.9525" layer="21"/>
<rectangle x1="-1.5875" y1="0.9271" x2="-1.4097" y2="0.9525" layer="21"/>
<rectangle x1="-1.3589" y1="0.9271" x2="-1.1811" y2="0.9525" layer="21"/>
<rectangle x1="-1.0287" y1="0.9271" x2="-0.5969" y2="0.9525" layer="21"/>
<rectangle x1="-0.4953" y1="0.9271" x2="-0.0635" y2="0.9525" layer="21"/>
<rectangle x1="0.2159" y1="0.9271" x2="0.3937" y2="0.9525" layer="21"/>
<rectangle x1="0.5715" y1="0.9271" x2="0.7747" y2="0.9525" layer="21"/>
<rectangle x1="0.9779" y1="0.9271" x2="1.1811" y2="0.9525" layer="21"/>
<rectangle x1="1.2573" y1="0.9271" x2="1.5621" y2="0.9525" layer="21"/>
<rectangle x1="1.6129" y1="0.9271" x2="1.7907" y2="0.9525" layer="21"/>
<rectangle x1="1.8923" y1="0.9271" x2="2.3241" y2="0.9525" layer="21"/>
<rectangle x1="2.7559" y1="0.9271" x2="3.0607" y2="0.9525" layer="21"/>
<rectangle x1="-2.9591" y1="0.9525" x2="-2.6543" y2="0.9779" layer="21"/>
<rectangle x1="-2.2733" y1="0.9525" x2="-2.0701" y2="0.9779" layer="21"/>
<rectangle x1="-1.8669" y1="0.9525" x2="-1.6891" y2="0.9779" layer="21"/>
<rectangle x1="-1.5875" y1="0.9525" x2="-1.4097" y2="0.9779" layer="21"/>
<rectangle x1="-1.3589" y1="0.9525" x2="-1.1811" y2="0.9779" layer="21"/>
<rectangle x1="-1.0287" y1="0.9525" x2="-0.5969" y2="0.9779" layer="21"/>
<rectangle x1="-0.4953" y1="0.9525" x2="-0.0381" y2="0.9779" layer="21"/>
<rectangle x1="0.2159" y1="0.9525" x2="0.3937" y2="0.9779" layer="21"/>
<rectangle x1="0.5715" y1="0.9525" x2="0.7747" y2="0.9779" layer="21"/>
<rectangle x1="0.9779" y1="0.9525" x2="1.1811" y2="0.9779" layer="21"/>
<rectangle x1="1.2573" y1="0.9525" x2="1.5621" y2="0.9779" layer="21"/>
<rectangle x1="1.6129" y1="0.9525" x2="1.7907" y2="0.9779" layer="21"/>
<rectangle x1="1.8923" y1="0.9525" x2="2.3241" y2="0.9779" layer="21"/>
<rectangle x1="2.7559" y1="0.9525" x2="3.0607" y2="0.9779" layer="21"/>
<rectangle x1="-2.9591" y1="0.9779" x2="-2.6543" y2="1.0033" layer="21"/>
<rectangle x1="-2.2733" y1="0.9779" x2="-2.0701" y2="1.0033" layer="21"/>
<rectangle x1="-1.8669" y1="0.9779" x2="-1.6891" y2="1.0033" layer="21"/>
<rectangle x1="-1.6129" y1="0.9779" x2="-1.4351" y2="1.0033" layer="21"/>
<rectangle x1="-1.3589" y1="0.9779" x2="-1.1811" y2="1.0033" layer="21"/>
<rectangle x1="-1.0287" y1="0.9779" x2="-0.5969" y2="1.0033" layer="21"/>
<rectangle x1="-0.4953" y1="0.9779" x2="-0.2921" y2="1.0033" layer="21"/>
<rectangle x1="-0.2159" y1="0.9779" x2="-0.0127" y2="1.0033" layer="21"/>
<rectangle x1="0.2159" y1="0.9779" x2="0.3937" y2="1.0033" layer="21"/>
<rectangle x1="0.5715" y1="0.9779" x2="0.7747" y2="1.0033" layer="21"/>
<rectangle x1="0.9779" y1="0.9779" x2="1.1811" y2="1.0033" layer="21"/>
<rectangle x1="1.2573" y1="0.9779" x2="1.5621" y2="1.0033" layer="21"/>
<rectangle x1="1.6129" y1="0.9779" x2="1.7907" y2="1.0033" layer="21"/>
<rectangle x1="1.8923" y1="0.9779" x2="2.3241" y2="1.0033" layer="21"/>
<rectangle x1="2.7559" y1="0.9779" x2="3.0607" y2="1.0033" layer="21"/>
<rectangle x1="-2.9591" y1="1.0033" x2="-2.6543" y2="1.0287" layer="21"/>
<rectangle x1="-2.2733" y1="1.0033" x2="-2.0701" y2="1.0287" layer="21"/>
<rectangle x1="-1.8669" y1="1.0033" x2="-1.6891" y2="1.0287" layer="21"/>
<rectangle x1="-1.6129" y1="1.0033" x2="-1.4351" y2="1.0287" layer="21"/>
<rectangle x1="-1.3589" y1="1.0033" x2="-1.1811" y2="1.0287" layer="21"/>
<rectangle x1="-1.0287" y1="1.0033" x2="-0.8509" y2="1.0287" layer="21"/>
<rectangle x1="-0.4953" y1="1.0033" x2="-0.2921" y2="1.0287" layer="21"/>
<rectangle x1="-0.1905" y1="1.0033" x2="-0.0127" y2="1.0287" layer="21"/>
<rectangle x1="0.2159" y1="1.0033" x2="0.3937" y2="1.0287" layer="21"/>
<rectangle x1="0.5969" y1="1.0033" x2="0.7747" y2="1.0287" layer="21"/>
<rectangle x1="0.9779" y1="1.0033" x2="1.1557" y2="1.0287" layer="21"/>
<rectangle x1="1.2573" y1="1.0033" x2="1.5621" y2="1.0287" layer="21"/>
<rectangle x1="1.6129" y1="1.0033" x2="1.7907" y2="1.0287" layer="21"/>
<rectangle x1="1.8923" y1="1.0033" x2="2.0701" y2="1.0287" layer="21"/>
<rectangle x1="2.7559" y1="1.0033" x2="3.0607" y2="1.0287" layer="21"/>
<rectangle x1="-2.9591" y1="1.0287" x2="-2.6543" y2="1.0541" layer="21"/>
<rectangle x1="-2.2479" y1="1.0287" x2="-2.0701" y2="1.0541" layer="21"/>
<rectangle x1="-1.8923" y1="1.0287" x2="-1.6891" y2="1.0541" layer="21"/>
<rectangle x1="-1.6129" y1="1.0287" x2="-1.4351" y2="1.0541" layer="21"/>
<rectangle x1="-1.3589" y1="1.0287" x2="-1.1557" y2="1.0541" layer="21"/>
<rectangle x1="-1.0287" y1="1.0287" x2="-0.8509" y2="1.0541" layer="21"/>
<rectangle x1="-0.4953" y1="1.0287" x2="-0.2921" y2="1.0541" layer="21"/>
<rectangle x1="-0.1905" y1="1.0287" x2="0.0127" y2="1.0541" layer="21"/>
<rectangle x1="0.2159" y1="1.0287" x2="0.3937" y2="1.0541" layer="21"/>
<rectangle x1="0.5969" y1="1.0287" x2="0.7747" y2="1.0541" layer="21"/>
<rectangle x1="0.9779" y1="1.0287" x2="1.1557" y2="1.0541" layer="21"/>
<rectangle x1="1.2573" y1="1.0287" x2="1.5367" y2="1.0541" layer="21"/>
<rectangle x1="1.6129" y1="1.0287" x2="1.7907" y2="1.0541" layer="21"/>
<rectangle x1="1.8923" y1="1.0287" x2="2.0701" y2="1.0541" layer="21"/>
<rectangle x1="2.7559" y1="1.0287" x2="3.0607" y2="1.0541" layer="21"/>
<rectangle x1="-2.9591" y1="1.0541" x2="-2.6543" y2="1.0795" layer="21"/>
<rectangle x1="-2.2479" y1="1.0541" x2="-2.0447" y2="1.0795" layer="21"/>
<rectangle x1="-1.8923" y1="1.0541" x2="-1.6891" y2="1.0795" layer="21"/>
<rectangle x1="-1.6383" y1="1.0541" x2="-1.4351" y2="1.0795" layer="21"/>
<rectangle x1="-1.3335" y1="1.0541" x2="-1.1557" y2="1.0795" layer="21"/>
<rectangle x1="-1.0287" y1="1.0541" x2="-0.8509" y2="1.0795" layer="21"/>
<rectangle x1="-0.4953" y1="1.0541" x2="-0.2921" y2="1.0795" layer="21"/>
<rectangle x1="-0.1905" y1="1.0541" x2="0.0127" y2="1.0795" layer="21"/>
<rectangle x1="0.2159" y1="1.0541" x2="0.3937" y2="1.0795" layer="21"/>
<rectangle x1="0.5969" y1="1.0541" x2="0.8001" y2="1.0795" layer="21"/>
<rectangle x1="0.9525" y1="1.0541" x2="1.1557" y2="1.0795" layer="21"/>
<rectangle x1="1.2573" y1="1.0541" x2="1.5367" y2="1.0795" layer="21"/>
<rectangle x1="1.6129" y1="1.0541" x2="1.7907" y2="1.0795" layer="21"/>
<rectangle x1="1.8923" y1="1.0541" x2="2.0701" y2="1.0795" layer="21"/>
<rectangle x1="2.7559" y1="1.0541" x2="3.0607" y2="1.0795" layer="21"/>
<rectangle x1="-2.9591" y1="1.0795" x2="-2.6543" y2="1.1049" layer="21"/>
<rectangle x1="-2.2479" y1="1.0795" x2="-2.0447" y2="1.1049" layer="21"/>
<rectangle x1="-1.8923" y1="1.0795" x2="-1.6891" y2="1.1049" layer="21"/>
<rectangle x1="-1.6383" y1="1.0795" x2="-1.4351" y2="1.1049" layer="21"/>
<rectangle x1="-1.3335" y1="1.0795" x2="-1.1557" y2="1.1049" layer="21"/>
<rectangle x1="-1.0287" y1="1.0795" x2="-0.8509" y2="1.1049" layer="21"/>
<rectangle x1="-0.4953" y1="1.0795" x2="-0.2921" y2="1.1049" layer="21"/>
<rectangle x1="-0.1905" y1="1.0795" x2="0.0127" y2="1.1049" layer="21"/>
<rectangle x1="0.2159" y1="1.0795" x2="0.3937" y2="1.1049" layer="21"/>
<rectangle x1="0.5969" y1="1.0795" x2="0.8001" y2="1.1049" layer="21"/>
<rectangle x1="0.9525" y1="1.0795" x2="1.1557" y2="1.1049" layer="21"/>
<rectangle x1="1.2573" y1="1.0795" x2="1.5113" y2="1.1049" layer="21"/>
<rectangle x1="1.6129" y1="1.0795" x2="1.7907" y2="1.1049" layer="21"/>
<rectangle x1="1.8923" y1="1.0795" x2="2.0701" y2="1.1049" layer="21"/>
<rectangle x1="2.7559" y1="1.0795" x2="3.0607" y2="1.1049" layer="21"/>
<rectangle x1="-2.9591" y1="1.1049" x2="-2.6543" y2="1.1303" layer="21"/>
<rectangle x1="-2.2225" y1="1.1049" x2="-2.0193" y2="1.1303" layer="21"/>
<rectangle x1="-1.9177" y1="1.1049" x2="-1.7145" y2="1.1303" layer="21"/>
<rectangle x1="-1.6383" y1="1.1049" x2="-1.4605" y2="1.1303" layer="21"/>
<rectangle x1="-1.3335" y1="1.1049" x2="-1.1303" y2="1.1303" layer="21"/>
<rectangle x1="-1.0287" y1="1.1049" x2="-0.8509" y2="1.1303" layer="21"/>
<rectangle x1="-0.4953" y1="1.1049" x2="-0.2921" y2="1.1303" layer="21"/>
<rectangle x1="-0.1905" y1="1.1049" x2="0.0127" y2="1.1303" layer="21"/>
<rectangle x1="0.2159" y1="1.1049" x2="0.3937" y2="1.1303" layer="21"/>
<rectangle x1="0.6223" y1="1.1049" x2="0.8255" y2="1.1303" layer="21"/>
<rectangle x1="0.9271" y1="1.1049" x2="1.1303" y2="1.1303" layer="21"/>
<rectangle x1="1.2573" y1="1.1049" x2="1.5113" y2="1.1303" layer="21"/>
<rectangle x1="1.6129" y1="1.1049" x2="1.7907" y2="1.1303" layer="21"/>
<rectangle x1="1.8923" y1="1.1049" x2="2.0701" y2="1.1303" layer="21"/>
<rectangle x1="2.7559" y1="1.1049" x2="3.0607" y2="1.1303" layer="21"/>
<rectangle x1="-2.9591" y1="1.1303" x2="-2.6543" y2="1.1557" layer="21"/>
<rectangle x1="-2.2225" y1="1.1303" x2="-1.7145" y2="1.1557" layer="21"/>
<rectangle x1="-1.6383" y1="1.1303" x2="-1.4605" y2="1.1557" layer="21"/>
<rectangle x1="-1.3335" y1="1.1303" x2="-1.1303" y2="1.1557" layer="21"/>
<rectangle x1="-1.0287" y1="1.1303" x2="-0.5715" y2="1.1557" layer="21"/>
<rectangle x1="-0.4953" y1="1.1303" x2="-0.2921" y2="1.1557" layer="21"/>
<rectangle x1="-0.2413" y1="1.1303" x2="0.0127" y2="1.1557" layer="21"/>
<rectangle x1="0.0635" y1="1.1303" x2="0.5715" y2="1.1557" layer="21"/>
<rectangle x1="0.6223" y1="1.1303" x2="1.1303" y2="1.1557" layer="21"/>
<rectangle x1="1.2573" y1="1.1303" x2="1.5113" y2="1.1557" layer="21"/>
<rectangle x1="1.6129" y1="1.1303" x2="1.7907" y2="1.1557" layer="21"/>
<rectangle x1="1.8923" y1="1.1303" x2="2.3495" y2="1.1557" layer="21"/>
<rectangle x1="2.7559" y1="1.1303" x2="3.0607" y2="1.1557" layer="21"/>
<rectangle x1="-2.9591" y1="1.1557" x2="-2.6543" y2="1.1811" layer="21"/>
<rectangle x1="-2.2225" y1="1.1557" x2="-1.7399" y2="1.1811" layer="21"/>
<rectangle x1="-1.6383" y1="1.1557" x2="-1.4605" y2="1.1811" layer="21"/>
<rectangle x1="-1.3335" y1="1.1557" x2="-1.1303" y2="1.1811" layer="21"/>
<rectangle x1="-1.0287" y1="1.1557" x2="-0.5715" y2="1.1811" layer="21"/>
<rectangle x1="-0.4953" y1="1.1557" x2="0.0127" y2="1.1811" layer="21"/>
<rectangle x1="0.0635" y1="1.1557" x2="0.5715" y2="1.1811" layer="21"/>
<rectangle x1="0.6477" y1="1.1557" x2="1.1303" y2="1.1811" layer="21"/>
<rectangle x1="1.2573" y1="1.1557" x2="1.4859" y2="1.1811" layer="21"/>
<rectangle x1="1.6129" y1="1.1557" x2="1.7907" y2="1.1811" layer="21"/>
<rectangle x1="1.8923" y1="1.1557" x2="2.3495" y2="1.1811" layer="21"/>
<rectangle x1="2.7559" y1="1.1557" x2="3.0607" y2="1.1811" layer="21"/>
<rectangle x1="-2.9591" y1="1.1811" x2="-2.6543" y2="1.2065" layer="21"/>
<rectangle x1="-2.1971" y1="1.1811" x2="-1.7399" y2="1.2065" layer="21"/>
<rectangle x1="-1.6637" y1="1.1811" x2="-1.4605" y2="1.2065" layer="21"/>
<rectangle x1="-1.3335" y1="1.1811" x2="-1.1303" y2="1.2065" layer="21"/>
<rectangle x1="-1.0287" y1="1.1811" x2="-0.5715" y2="1.2065" layer="21"/>
<rectangle x1="-0.4953" y1="1.1811" x2="-0.0127" y2="1.2065" layer="21"/>
<rectangle x1="0.0635" y1="1.1811" x2="0.5715" y2="1.2065" layer="21"/>
<rectangle x1="0.6477" y1="1.1811" x2="1.1049" y2="1.2065" layer="21"/>
<rectangle x1="1.2573" y1="1.1811" x2="1.4859" y2="1.2065" layer="21"/>
<rectangle x1="1.6129" y1="1.1811" x2="1.7907" y2="1.2065" layer="21"/>
<rectangle x1="1.8923" y1="1.1811" x2="2.3495" y2="1.2065" layer="21"/>
<rectangle x1="2.7559" y1="1.1811" x2="3.0607" y2="1.2065" layer="21"/>
<rectangle x1="-2.9591" y1="1.2065" x2="-2.6543" y2="1.2319" layer="21"/>
<rectangle x1="-2.1717" y1="1.2065" x2="-1.7653" y2="1.2319" layer="21"/>
<rectangle x1="-1.6637" y1="1.2065" x2="-1.4605" y2="1.2319" layer="21"/>
<rectangle x1="-1.3081" y1="1.2065" x2="-1.1049" y2="1.2319" layer="21"/>
<rectangle x1="-1.0287" y1="1.2065" x2="-0.5715" y2="1.2319" layer="21"/>
<rectangle x1="-0.4953" y1="1.2065" x2="-0.0127" y2="1.2319" layer="21"/>
<rectangle x1="0.0635" y1="1.2065" x2="0.5715" y2="1.2319" layer="21"/>
<rectangle x1="0.6731" y1="1.2065" x2="1.0795" y2="1.2319" layer="21"/>
<rectangle x1="1.2573" y1="1.2065" x2="1.4859" y2="1.2319" layer="21"/>
<rectangle x1="1.6129" y1="1.2065" x2="1.7907" y2="1.2319" layer="21"/>
<rectangle x1="1.8923" y1="1.2065" x2="2.3495" y2="1.2319" layer="21"/>
<rectangle x1="2.7559" y1="1.2065" x2="3.0607" y2="1.2319" layer="21"/>
<rectangle x1="-2.9591" y1="1.2319" x2="-2.6543" y2="1.2573" layer="21"/>
<rectangle x1="-2.1463" y1="1.2319" x2="-1.7907" y2="1.2573" layer="21"/>
<rectangle x1="-1.6637" y1="1.2319" x2="-1.4605" y2="1.2573" layer="21"/>
<rectangle x1="-1.3081" y1="1.2319" x2="-1.1049" y2="1.2573" layer="21"/>
<rectangle x1="-1.0287" y1="1.2319" x2="-0.5715" y2="1.2573" layer="21"/>
<rectangle x1="-0.4953" y1="1.2319" x2="-0.0381" y2="1.2573" layer="21"/>
<rectangle x1="0.0635" y1="1.2319" x2="0.5715" y2="1.2573" layer="21"/>
<rectangle x1="0.6985" y1="1.2319" x2="1.0541" y2="1.2573" layer="21"/>
<rectangle x1="1.2573" y1="1.2319" x2="1.4605" y2="1.2573" layer="21"/>
<rectangle x1="1.6129" y1="1.2319" x2="1.7907" y2="1.2573" layer="21"/>
<rectangle x1="1.8923" y1="1.2319" x2="2.3495" y2="1.2573" layer="21"/>
<rectangle x1="2.7559" y1="1.2319" x2="3.0607" y2="1.2573" layer="21"/>
<rectangle x1="-2.9591" y1="1.2573" x2="-2.6543" y2="1.2827" layer="21"/>
<rectangle x1="-2.1209" y1="1.2573" x2="-1.8161" y2="1.2827" layer="21"/>
<rectangle x1="-1.6637" y1="1.2573" x2="-1.4605" y2="1.2827" layer="21"/>
<rectangle x1="-1.3081" y1="1.2573" x2="-1.1049" y2="1.2827" layer="21"/>
<rectangle x1="-1.0287" y1="1.2573" x2="-0.5715" y2="1.2827" layer="21"/>
<rectangle x1="-0.4953" y1="1.2573" x2="-0.0635" y2="1.2827" layer="21"/>
<rectangle x1="0.0635" y1="1.2573" x2="0.5715" y2="1.2827" layer="21"/>
<rectangle x1="0.7239" y1="1.2573" x2="1.0287" y2="1.2827" layer="21"/>
<rectangle x1="1.2573" y1="1.2573" x2="1.4605" y2="1.2827" layer="21"/>
<rectangle x1="1.6129" y1="1.2573" x2="1.7907" y2="1.2827" layer="21"/>
<rectangle x1="1.8923" y1="1.2573" x2="2.3495" y2="1.2827" layer="21"/>
<rectangle x1="2.7559" y1="1.2573" x2="3.0607" y2="1.2827" layer="21"/>
<rectangle x1="-2.9591" y1="1.2827" x2="-2.6543" y2="1.3081" layer="21"/>
<rectangle x1="-2.0701" y1="1.2827" x2="-1.8669" y2="1.3081" layer="21"/>
<rectangle x1="-1.6891" y1="1.2827" x2="-1.4859" y2="1.3081" layer="21"/>
<rectangle x1="-1.3081" y1="1.2827" x2="-1.1049" y2="1.3081" layer="21"/>
<rectangle x1="-1.0287" y1="1.2827" x2="-0.5715" y2="1.3081" layer="21"/>
<rectangle x1="-0.4953" y1="1.2827" x2="-0.1143" y2="1.3081" layer="21"/>
<rectangle x1="0.0635" y1="1.2827" x2="0.5715" y2="1.3081" layer="21"/>
<rectangle x1="0.7747" y1="1.2827" x2="0.9779" y2="1.3081" layer="21"/>
<rectangle x1="1.2573" y1="1.2827" x2="1.4351" y2="1.3081" layer="21"/>
<rectangle x1="1.6129" y1="1.2827" x2="1.7907" y2="1.3081" layer="21"/>
<rectangle x1="1.8923" y1="1.2827" x2="2.3495" y2="1.3081" layer="21"/>
<rectangle x1="2.7559" y1="1.2827" x2="3.0607" y2="1.3081" layer="21"/>
<rectangle x1="-2.9591" y1="1.3081" x2="-2.6543" y2="1.3335" layer="21"/>
<rectangle x1="2.7559" y1="1.3081" x2="3.0607" y2="1.3335" layer="21"/>
<rectangle x1="-2.9591" y1="1.3335" x2="-2.6543" y2="1.3589" layer="21"/>
<rectangle x1="2.7559" y1="1.3335" x2="3.0607" y2="1.3589" layer="21"/>
<rectangle x1="-2.9591" y1="1.3589" x2="-2.6543" y2="1.3843" layer="21"/>
<rectangle x1="2.7559" y1="1.3589" x2="3.0607" y2="1.3843" layer="21"/>
<rectangle x1="-2.9591" y1="1.3843" x2="-2.6543" y2="1.4097" layer="21"/>
<rectangle x1="2.7559" y1="1.3843" x2="3.0607" y2="1.4097" layer="21"/>
<rectangle x1="-2.9591" y1="1.4097" x2="-2.6543" y2="1.4351" layer="21"/>
<rectangle x1="2.7559" y1="1.4097" x2="3.0607" y2="1.4351" layer="21"/>
<rectangle x1="-2.9591" y1="1.4351" x2="-2.6543" y2="1.4605" layer="21"/>
<rectangle x1="2.7559" y1="1.4351" x2="3.0607" y2="1.4605" layer="21"/>
<rectangle x1="-2.9591" y1="1.4605" x2="-2.6543" y2="1.4859" layer="21"/>
<rectangle x1="2.7559" y1="1.4605" x2="3.0607" y2="1.4859" layer="21"/>
<rectangle x1="-2.9591" y1="1.4859" x2="-2.6543" y2="1.5113" layer="21"/>
<rectangle x1="2.7559" y1="1.4859" x2="3.0607" y2="1.5113" layer="21"/>
<rectangle x1="-2.9591" y1="1.5113" x2="-2.6543" y2="1.5367" layer="21"/>
<rectangle x1="2.7559" y1="1.5113" x2="3.0607" y2="1.5367" layer="21"/>
<rectangle x1="-2.9591" y1="1.5367" x2="-2.6543" y2="1.5621" layer="21"/>
<rectangle x1="2.7559" y1="1.5367" x2="3.0607" y2="1.5621" layer="21"/>
<rectangle x1="-2.9591" y1="1.5621" x2="-2.6543" y2="1.5875" layer="21"/>
<rectangle x1="2.7559" y1="1.5621" x2="3.0607" y2="1.5875" layer="21"/>
<rectangle x1="-2.9591" y1="1.5875" x2="-2.6543" y2="1.6129" layer="21"/>
<rectangle x1="2.7559" y1="1.5875" x2="3.0607" y2="1.6129" layer="21"/>
<rectangle x1="-2.9591" y1="1.6129" x2="-2.6543" y2="1.6383" layer="21"/>
<rectangle x1="2.7559" y1="1.6129" x2="3.0607" y2="1.6383" layer="21"/>
<rectangle x1="-2.9591" y1="1.6383" x2="-2.6543" y2="1.6637" layer="21"/>
<rectangle x1="2.7559" y1="1.6383" x2="3.0607" y2="1.6637" layer="21"/>
<rectangle x1="-2.9591" y1="1.6637" x2="-2.6543" y2="1.6891" layer="21"/>
<rectangle x1="2.7559" y1="1.6637" x2="3.0607" y2="1.6891" layer="21"/>
<rectangle x1="-2.9591" y1="1.6891" x2="-2.6543" y2="1.7145" layer="21"/>
<rectangle x1="2.7559" y1="1.6891" x2="3.0607" y2="1.7145" layer="21"/>
<rectangle x1="-2.9591" y1="1.7145" x2="-2.6543" y2="1.7399" layer="21"/>
<rectangle x1="2.7559" y1="1.7145" x2="3.0607" y2="1.7399" layer="21"/>
<rectangle x1="-2.9591" y1="1.7399" x2="-2.6543" y2="1.7653" layer="21"/>
<rectangle x1="2.7559" y1="1.7399" x2="3.0607" y2="1.7653" layer="21"/>
<rectangle x1="-2.9591" y1="1.7653" x2="-2.6543" y2="1.7907" layer="21"/>
<rectangle x1="2.7559" y1="1.7653" x2="3.0607" y2="1.7907" layer="21"/>
<rectangle x1="-2.9591" y1="1.7907" x2="-2.6543" y2="1.8161" layer="21"/>
<rectangle x1="2.7559" y1="1.7907" x2="3.0607" y2="1.8161" layer="21"/>
<rectangle x1="-2.9591" y1="1.8161" x2="-2.6543" y2="1.8415" layer="21"/>
<rectangle x1="2.7559" y1="1.8161" x2="3.0607" y2="1.8415" layer="21"/>
<rectangle x1="-2.9591" y1="1.8415" x2="-2.6543" y2="1.8669" layer="21"/>
<rectangle x1="2.7559" y1="1.8415" x2="3.0607" y2="1.8669" layer="21"/>
<rectangle x1="-2.9591" y1="1.8669" x2="-2.6543" y2="1.8923" layer="21"/>
<rectangle x1="2.7559" y1="1.8669" x2="3.0607" y2="1.8923" layer="21"/>
<rectangle x1="-2.9591" y1="1.8923" x2="-2.6543" y2="1.9177" layer="21"/>
<rectangle x1="2.7559" y1="1.8923" x2="3.0607" y2="1.9177" layer="21"/>
<rectangle x1="-2.9591" y1="1.9177" x2="-2.6543" y2="1.9431" layer="21"/>
<rectangle x1="2.7559" y1="1.9177" x2="3.0607" y2="1.9431" layer="21"/>
<rectangle x1="-2.9591" y1="1.9431" x2="-2.6543" y2="1.9685" layer="21"/>
<rectangle x1="2.7559" y1="1.9431" x2="3.0607" y2="1.9685" layer="21"/>
<rectangle x1="-2.9591" y1="1.9685" x2="-2.6543" y2="1.9939" layer="21"/>
<rectangle x1="2.7559" y1="1.9685" x2="3.0607" y2="1.9939" layer="21"/>
<rectangle x1="-2.9591" y1="1.9939" x2="-2.6543" y2="2.0193" layer="21"/>
<rectangle x1="2.7559" y1="1.9939" x2="3.0607" y2="2.0193" layer="21"/>
<rectangle x1="-2.9591" y1="2.0193" x2="-2.6543" y2="2.0447" layer="21"/>
<rectangle x1="2.7559" y1="2.0193" x2="3.0607" y2="2.0447" layer="21"/>
<rectangle x1="-2.9591" y1="2.0447" x2="-2.6543" y2="2.0701" layer="21"/>
<rectangle x1="2.7559" y1="2.0447" x2="3.0607" y2="2.0701" layer="21"/>
<rectangle x1="-2.9591" y1="2.0701" x2="-2.6543" y2="2.0955" layer="21"/>
<rectangle x1="2.7559" y1="2.0701" x2="3.0607" y2="2.0955" layer="21"/>
<rectangle x1="-2.9591" y1="2.0955" x2="-2.6543" y2="2.1209" layer="21"/>
<rectangle x1="2.7559" y1="2.0955" x2="3.0607" y2="2.1209" layer="21"/>
<rectangle x1="-2.9591" y1="2.1209" x2="-2.6543" y2="2.1463" layer="21"/>
<rectangle x1="2.7559" y1="2.1209" x2="3.0607" y2="2.1463" layer="21"/>
<rectangle x1="-2.9591" y1="2.1463" x2="-2.6543" y2="2.1717" layer="21"/>
<rectangle x1="2.7559" y1="2.1463" x2="3.0607" y2="2.1717" layer="21"/>
<rectangle x1="-2.9591" y1="2.1717" x2="-2.6543" y2="2.1971" layer="21"/>
<rectangle x1="2.7559" y1="2.1717" x2="3.0607" y2="2.1971" layer="21"/>
<rectangle x1="-2.9591" y1="2.1971" x2="-2.6543" y2="2.2225" layer="21"/>
<rectangle x1="2.7559" y1="2.1971" x2="3.0607" y2="2.2225" layer="21"/>
<rectangle x1="-2.9591" y1="2.2225" x2="-2.6543" y2="2.2479" layer="21"/>
<rectangle x1="2.7559" y1="2.2225" x2="3.0607" y2="2.2479" layer="21"/>
<rectangle x1="-2.9591" y1="2.2479" x2="-2.6543" y2="2.2733" layer="21"/>
<rectangle x1="2.7559" y1="2.2479" x2="3.0607" y2="2.2733" layer="21"/>
<rectangle x1="-2.9591" y1="2.2733" x2="-2.6543" y2="2.2987" layer="21"/>
<rectangle x1="2.7559" y1="2.2733" x2="3.0607" y2="2.2987" layer="21"/>
<rectangle x1="-2.9591" y1="2.2987" x2="-2.6543" y2="2.3241" layer="21"/>
<rectangle x1="2.7559" y1="2.2987" x2="3.0607" y2="2.3241" layer="21"/>
<rectangle x1="-2.9591" y1="2.3241" x2="-2.6543" y2="2.3495" layer="21"/>
<rectangle x1="2.7559" y1="2.3241" x2="3.0607" y2="2.3495" layer="21"/>
<rectangle x1="-2.9591" y1="2.3495" x2="-2.6543" y2="2.3749" layer="21"/>
<rectangle x1="2.7559" y1="2.3495" x2="3.0607" y2="2.3749" layer="21"/>
<rectangle x1="-2.9591" y1="2.3749" x2="-2.6543" y2="2.4003" layer="21"/>
<rectangle x1="2.7559" y1="2.3749" x2="3.0607" y2="2.4003" layer="21"/>
<rectangle x1="-2.9591" y1="2.4003" x2="-2.6543" y2="2.4257" layer="21"/>
<rectangle x1="2.7559" y1="2.4003" x2="3.0607" y2="2.4257" layer="21"/>
<rectangle x1="-2.9591" y1="2.4257" x2="-2.6543" y2="2.4511" layer="21"/>
<rectangle x1="2.7559" y1="2.4257" x2="3.0607" y2="2.4511" layer="21"/>
<rectangle x1="-2.9591" y1="2.4511" x2="-2.6543" y2="2.4765" layer="21"/>
<rectangle x1="2.7559" y1="2.4511" x2="3.0607" y2="2.4765" layer="21"/>
<rectangle x1="-2.9591" y1="2.4765" x2="-2.6543" y2="2.5019" layer="21"/>
<rectangle x1="2.7559" y1="2.4765" x2="3.0607" y2="2.5019" layer="21"/>
<rectangle x1="-2.9591" y1="2.5019" x2="-2.6543" y2="2.5273" layer="21"/>
<rectangle x1="2.7559" y1="2.5019" x2="3.0607" y2="2.5273" layer="21"/>
<rectangle x1="-2.9591" y1="2.5273" x2="-2.6543" y2="2.5527" layer="21"/>
<rectangle x1="2.7559" y1="2.5273" x2="3.0607" y2="2.5527" layer="21"/>
<rectangle x1="-2.9591" y1="2.5527" x2="-2.6543" y2="2.5781" layer="21"/>
<rectangle x1="2.7559" y1="2.5527" x2="3.0607" y2="2.5781" layer="21"/>
<rectangle x1="-2.9591" y1="2.5781" x2="-2.6543" y2="2.6035" layer="21"/>
<rectangle x1="2.7559" y1="2.5781" x2="3.0607" y2="2.6035" layer="21"/>
<rectangle x1="-2.9591" y1="2.6035" x2="-2.6543" y2="2.6289" layer="21"/>
<rectangle x1="2.7559" y1="2.6035" x2="3.0607" y2="2.6289" layer="21"/>
<rectangle x1="-2.9591" y1="2.6289" x2="-2.6543" y2="2.6543" layer="21"/>
<rectangle x1="2.7559" y1="2.6289" x2="3.0607" y2="2.6543" layer="21"/>
<rectangle x1="-2.9591" y1="2.6543" x2="-2.6543" y2="2.6797" layer="21"/>
<rectangle x1="2.7559" y1="2.6543" x2="3.0607" y2="2.6797" layer="21"/>
<rectangle x1="-2.9337" y1="2.6797" x2="-2.6543" y2="2.7051" layer="21"/>
<rectangle x1="2.7559" y1="2.6797" x2="3.0607" y2="2.7051" layer="21"/>
<rectangle x1="-2.9337" y1="2.7051" x2="-2.6289" y2="2.7305" layer="21"/>
<rectangle x1="2.7559" y1="2.7051" x2="3.0353" y2="2.7305" layer="21"/>
<rectangle x1="-2.9337" y1="2.7305" x2="-2.6289" y2="2.7559" layer="21"/>
<rectangle x1="2.7305" y1="2.7305" x2="3.0353" y2="2.7559" layer="21"/>
<rectangle x1="-2.9337" y1="2.7559" x2="-2.6035" y2="2.7813" layer="21"/>
<rectangle x1="2.7051" y1="2.7559" x2="3.0353" y2="2.7813" layer="21"/>
<rectangle x1="-2.9083" y1="2.7813" x2="-2.5781" y2="2.8067" layer="21"/>
<rectangle x1="2.6797" y1="2.7813" x2="3.0099" y2="2.8067" layer="21"/>
<rectangle x1="-2.9083" y1="2.8067" x2="3.0099" y2="2.8321" layer="21"/>
<rectangle x1="-2.9083" y1="2.8321" x2="3.0099" y2="2.8575" layer="21"/>
<rectangle x1="-2.8829" y1="2.8575" x2="2.9845" y2="2.8829" layer="21"/>
<rectangle x1="-2.8829" y1="2.8829" x2="2.9845" y2="2.9083" layer="21"/>
<rectangle x1="-2.8575" y1="2.9083" x2="2.9591" y2="2.9337" layer="21"/>
<rectangle x1="-2.8321" y1="2.9337" x2="2.9337" y2="2.9591" layer="21"/>
<rectangle x1="-2.8067" y1="2.9591" x2="2.9083" y2="2.9845" layer="21"/>
<rectangle x1="-2.7813" y1="2.9845" x2="2.8829" y2="3.0099" layer="21"/>
<rectangle x1="-2.7559" y1="3.0099" x2="2.8575" y2="3.0353" layer="21"/>
<rectangle x1="-2.7051" y1="3.0353" x2="2.8067" y2="3.0607" layer="21"/>
<rectangle x1="-2.6543" y1="3.0607" x2="2.7559" y2="3.0861" layer="21"/>
<rectangle x1="-2.5527" y1="3.0861" x2="2.6543" y2="3.1115" layer="21"/>
</package>
<package name="SFE-NEW-WEBLOGO">
<wire x1="10.7163" y1="0.9449" x2="10.7163" y2="2.5171" width="0.0254" layer="21"/>
<wire x1="10.7163" y1="2.5171" x2="11.1201" y2="2.5171" width="0.0254" layer="21"/>
<wire x1="11.1201" y1="2.5171" x2="11.1201" y2="2.2962" width="0.0254" layer="21"/>
<wire x1="11.1201" y1="2.2962" x2="11.1277" y2="2.2962" width="0.0254" layer="21"/>
<wire x1="11.1277" y1="2.2962" x2="11.1455" y2="2.3038" width="0.0254" layer="21" curve="46.330674"/>
<wire x1="11.1455" y1="2.3038" x2="11.1582" y2="2.319" width="0.0254" layer="21" curve="7.631487"/>
<wire x1="11.1582" y1="2.319" x2="11.1862" y2="2.3571" width="0.0254" layer="21" curve="-0.503124"/>
<wire x1="11.1862" y1="2.3571" x2="11.2725" y2="2.446" width="0.0254" layer="21" curve="-15.190413"/>
<wire x1="11.2725" y1="2.446" x2="11.5672" y2="2.5552" width="0.0254" layer="21" curve="-35.851821"/>
<wire x1="11.5672" y1="2.5552" x2="11.7678" y2="2.5502" width="0.0254" layer="21" curve="-7.669318"/>
<wire x1="11.7678" y1="2.5502" x2="12.0345" y2="2.4257" width="0.0254" layer="21" curve="-39.496126"/>
<wire x1="12.0345" y1="2.4257" x2="12.1488" y2="2.2327" width="0.0254" layer="21" curve="-29.201449"/>
<wire x1="12.1488" y1="2.2327" x2="12.1818" y2="2.0091" width="0.0254" layer="21" curve="-15.281143"/>
<wire x1="12.1818" y1="2.0091" x2="12.1818" y2="0.955" width="0.0254" layer="21"/>
<wire x1="12.1818" y1="0.955" x2="11.7729" y2="0.955" width="0.0254" layer="21"/>
<wire x1="11.7729" y1="0.955" x2="11.7729" y2="1.9202" width="0.0254" layer="21"/>
<wire x1="11.7729" y1="1.9202" x2="11.7145" y2="2.1311" width="0.0254" layer="21" curve="30.972118"/>
<wire x1="11.7145" y1="2.1311" x2="11.5976" y2="2.2276" width="0.0254" layer="21" curve="39.023543"/>
<wire x1="11.5976" y1="2.2276" x2="11.5316" y2="2.2377" width="0.0254" layer="21" curve="22.666705"/>
<wire x1="11.5316" y1="2.2377" x2="11.4198" y2="2.2327" width="0.0254" layer="21" curve="-0.141885"/>
<wire x1="11.4198" y1="2.2327" x2="11.2598" y2="2.1692" width="0.0254" layer="21" curve="38.319405"/>
<wire x1="11.2598" y1="2.1692" x2="11.1684" y2="2.0396" width="0.0254" layer="21" curve="28.02057"/>
<wire x1="11.1684" y1="2.0396" x2="11.1379" y2="1.8821" width="0.0254" layer="21" curve="20.446837"/>
<wire x1="11.1379" y1="1.8821" x2="11.1379" y2="1.8136" width="0.0254" layer="21" curve="1.468547"/>
<wire x1="11.1379" y1="1.8136" x2="11.1379" y2="0.9449" width="0.0254" layer="21"/>
<wire x1="11.1379" y1="0.9449" x2="10.7163" y2="0.9449" width="0.0254" layer="21"/>
<wire x1="15.5499" y1="2.6137" x2="15.5499" y2="2.2911" width="0.0254" layer="21"/>
<wire x1="15.5499" y1="2.2911" x2="15.527" y2="2.2911" width="0.0254" layer="21"/>
<wire x1="15.527" y1="2.2911" x2="15.2781" y2="2.1692" width="0.0254" layer="21" curve="52.161542"/>
<wire x1="15.2781" y1="2.1692" x2="15.1689" y2="1.8847" width="0.0254" layer="21" curve="33.637372"/>
<wire x1="15.1689" y1="1.8847" x2="15.1714" y2="1.6383" width="0.0254" layer="21" curve="9.526321"/>
<wire x1="15.1714" y1="1.6383" x2="15.24" y2="1.4097" width="0.0254" layer="21" curve="22.72056"/>
<wire x1="15.24" y1="1.4097" x2="15.428" y2="1.2522" width="0.0254" layer="21" curve="43.950129"/>
<wire x1="15.428" y1="1.2522" x2="15.7632" y2="1.2725" width="0.0254" layer="21" curve="42.956637"/>
<wire x1="15.7632" y1="1.2725" x2="15.908" y2="1.4097" width="0.0254" layer="21" curve="37.092776"/>
<wire x1="15.908" y1="1.4097" x2="15.9868" y2="1.7196" width="0.0254" layer="21" curve="27.463631"/>
<wire x1="15.9868" y1="1.7196" x2="15.9588" y2="1.971" width="0.0254" layer="21" curve="13.781982"/>
<wire x1="15.9588" y1="1.971" x2="15.8318" y2="2.2047" width="0.0254" layer="21" curve="30.574869"/>
<wire x1="15.8318" y1="2.2047" x2="15.7277" y2="2.2708" width="0.0254" layer="21" curve="27.569924"/>
<wire x1="15.7277" y1="2.2708" x2="15.5702" y2="2.2962" width="0.0254" layer="21" curve="18.924644"/>
<wire x1="15.5702" y1="2.2962" x2="15.5702" y2="2.6137" width="0.0254" layer="21"/>
<wire x1="15.5702" y1="2.6137" x2="15.5854" y2="2.6137" width="0.0254" layer="21"/>
<wire x1="15.5854" y1="2.6137" x2="15.809" y2="2.5857" width="0.0254" layer="21" curve="-14.275307"/>
<wire x1="15.809" y1="2.5857" x2="16.129" y2="2.4181" width="0.0254" layer="21" curve="-26.738966"/>
<wire x1="16.129" y1="2.4181" x2="16.4033" y2="1.8085" width="0.0254" layer="21" curve="-49.520588"/>
<wire x1="16.4033" y1="1.8085" x2="16.317" y2="1.3665" width="0.0254" layer="21" curve="-21.032065"/>
<wire x1="16.317" y1="1.3665" x2="15.9029" y2="0.9754" width="0.0254" layer="21" curve="-50.14572"/>
<wire x1="15.9029" y1="0.9754" x2="15.5423" y2="0.9195" width="0.0254" layer="21" curve="-18.970273"/>
<wire x1="15.5423" y1="0.9195" x2="14.9911" y2="1.1201" width="0.0254" layer="21" curve="-38.667794"/>
<wire x1="14.9911" y1="1.1201" x2="14.8615" y2="1.27" width="0.0254" layer="21" curve="-19.649477"/>
<wire x1="14.8615" y1="1.27" x2="14.7523" y2="1.5672" width="0.0254" layer="21" curve="-21.686674"/>
<wire x1="14.7523" y1="1.5672" x2="14.7549" y2="1.9507" width="0.0254" layer="21" curve="-19.450751"/>
<wire x1="14.7549" y1="1.9507" x2="15.1282" y2="2.4892" width="0.0254" layer="21" curve="-49.247465"/>
<wire x1="15.1282" y1="2.4892" x2="15.5499" y2="2.6137" width="0.0254" layer="21" curve="-28.40069"/>
<rectangle x1="12.4257" y1="0.9449" x2="12.921" y2="1.43" layer="21"/>
<polygon width="0.0254" layer="21">
<vertex x="0.0127" y="1.4478"/>
<vertex x="0.0152" y="1.4122" curve="11.781889"/>
<vertex x="0.0254" y="1.3538" curve="5.986449"/>
<vertex x="0.0686" y="1.2268" curve="33.965574"/>
<vertex x="0.193" y="1.0719" curve="3.41051"/>
<vertex x="0.3124" y="0.9957" curve="23.808813"/>
<vertex x="0.4902" y="0.9347" curve="6.134334"/>
<vertex x="0.7468" y="0.9169" curve="11.726838"/>
<vertex x="1.0109" y="0.9398" curve="39.85103"/>
<vertex x="1.3614" y="1.1481" curve="32.659435"/>
<vertex x="1.4402" y="1.3335" curve="5.054801"/>
<vertex x="1.4478" y="1.4376" curve="27.000567"/>
<vertex x="1.4046" y="1.6434" curve="24.215951"/>
<vertex x="1.3462" y="1.7196" curve="16.336531"/>
<vertex x="1.2014" y="1.811" curve="15.491414"/>
<vertex x="0.8636" y="1.9101" curve="-5.389566"/>
<vertex x="0.6604" y="1.9507" curve="-23.534636"/>
<vertex x="0.5131" y="2.0218" curve="-33.901868"/>
<vertex x="0.4623" y="2.093" curve="-51.633481"/>
<vertex x="0.4775" y="2.2123" curve="-31.772747"/>
<vertex x="0.5359" y="2.2631" curve="-19.227223"/>
<vertex x="0.6274" y="2.2885" curve="-11.832222"/>
<vertex x="0.8001" y="2.2885" curve="-32.070958"/>
<vertex x="0.9449" y="2.2301" curve="-34.544037"/>
<vertex x="1.0135" y="2.1311" curve="-18.684123"/>
<vertex x="1.0211" y="2.0777"/>
<vertex x="1.4097" y="2.0777"/>
<vertex x="1.4021" y="2.1488"/>
<vertex x="1.1963" y="2.2784"/>
<vertex x="0.7417" y="2.4105"/>
<vertex x="0.3226" y="2.3012"/>
<vertex x="0.3759" y="1.9964"/>
<vertex x="0.8153" y="1.7348"/>
<vertex x="1.2395" y="1.5037"/>
<vertex x="1.1303" y="1.1786"/>
<vertex x="0.7366" y="1.0897"/>
</polygon>
<vertex x="1.4021" y="2.1565"/>
<vertex x="1.3818" y="2.2123" curve="8.641124"/>
<vertex x="1.3462" y="2.2911" curve="17.01851"/>
<vertex x="1.2827" y="2.3749" curve="24.288556"/>
<vertex x="1.077" y="2.5044" curve="19.111558"/>
<vertex x="0.8026" y="2.5552" curve="1.866622"/>
<vertex x="0.6223" y="2.5552" curve="31.269365"/>
<vertex x="0.2134" y="2.4333" curve="33.565662"/>
<vertex x="0.0965" y="2.2987" curve="35.404226"/>
<vertex x="0.0584" y="1.9634" curve="35.856587"/>
<vertex x="0.1321" y="1.8313" curve="26.645432"/>
<vertex x="0.3556" y="1.7043" curve="5.849498"/>
<vertex x="0.7188" y="1.618" curve="-16.758674"/>
<vertex x="0.95" y="1.5392" curve="-72.479784"/>
<vertex x="1.0414" y="1.3564" curve="-42.814064"/>
<vertex x="0.9754" y="1.2471" curve="-36.57155"/>
<vertex x="0.8001" y="1.1862" curve="-1.743126"/>
<vertex x="0.6655" y="1.1862" curve="-13.177653"/>
<vertex x="0.6071" y="1.1938" curve="-37.2471"/>
<vertex x="0.4445" y="1.2979" curve="-42.463913"/>
<vertex x="0.3988" y="1.4427"/>
<vertex x="0.3988" y="1.4478"/>
<vertex x="0.7264" y="1.0719"/>
<vertex x="1.1379" y="1.1633"/>
<vertex x="1.2497" y="1.4961"/>
<vertex x="1.2319" y="1.5316"/>
<vertex x="0.4064" y="2.0117"/>
<vertex x="0.3581" y="2.286"/>
<vertex x="0.7366" y="2.4003"/>
<vertex x="1.1582" y="2.2657"/>
<vertex x="1.3538" y="2.1209"/>
</polygon>
<vertex x="2.0447" y="2.5222"/>
<vertex x="2.0422" y="2.3216"/>
<vertex x="2.0498" y="2.3139"/>
<vertex x="2.0549" y="2.3114"/>
<vertex x="2.0777" y="2.3368" curve="-1.482215"/>
<vertex x="2.1666" y="2.4333" curve="-21.381055"/>
<vertex x="2.2403" y="2.4867" curve="-6.558669"/>
<vertex x="2.3724" y="2.54" curve="-13.501305"/>
<vertex x="2.4206" y="2.5502" curve="-8.934248"/>
<vertex x="2.6187" y="2.5527" curve="-23.485157"/>
<vertex x="2.8296" y="2.4943" curve="-14.880968"/>
<vertex x="3.0023" y="2.3749" curve="-25.018559"/>
<vertex x="3.1394" y="2.1819" curve="-31.105917"/>
<vertex x="3.2233" y="1.5291" curve="-29.834782"/>
<vertex x="3.0582" y="1.143" curve="-39.045306"/>
<vertex x="2.7381" y="0.9398" curve="-24.19089"/>
<vertex x="2.3724" y="0.9347" curve="-48.816375"/>
<vertex x="2.093" y="1.1354"/>
<vertex x="2.093" y="1.4326"/>
<vertex x="2.1006" y="1.4402"/>
<vertex x="2.1006" y="1.4351" curve="46.330674"/>
<vertex x="2.1082" y="1.4173" curve="-24.986858"/>
<vertex x="2.1133" y="1.4097" curve="39.800512"/>
<vertex x="2.2403" y="1.2649" curve="22.653395"/>
<vertex x="2.3851" y="1.2192" curve="23.391431"/>
<vertex x="2.5705" y="1.237" curve="59.483792"/>
<vertex x="2.7915" y="1.4732" curve="17.933067"/>
<vertex x="2.8219" y="1.8694" curve="52.248595"/>
<vertex x="2.6213" y="2.2073" curve="34.266137"/>
<vertex x="2.4536" y="2.2555" curve="3.141309"/>
<vertex x="2.3444" y="2.2504" curve="28.448901"/>
<vertex x="2.2682" y="2.225" curve="21.392676"/>
<vertex x="2.1336" y="2.098" curve="33.945153"/>
<vertex x="2.0523" y="1.8618" curve="5.204388"/>
<vertex x="2.0549" y="1.6053" curve="11.946721"/>
<vertex x="2.0676" y="1.5265" curve="6.549426"/>
<vertex x="2.0904" y="1.458" curve="-117.413922"/>
<vertex x="2.0828" y="1.4478"/>
<vertex x="2.0701" y="1.4478"/>
<vertex x="2.0701" y="1.1379"/>
<vertex x="2.0701" y="0.0178"/>
<vertex x="1.6561" y="0.3912"/>
<vertex x="1.6561" y="2.4409"/>
<vertex x="1.6561" y="2.4486"/>
</polygon>
<vertex x="7.7572" y="4.7803"/>
<vertex x="7.7089" y="4.7879" curve="17.884178"/>
<vertex x="7.5209" y="4.7879" curve="46.327753"/>
<vertex x="7.2822" y="4.638" curve="35.91905"/>
<vertex x="7.2111" y="4.4018"/>
<vertex x="7.2111" y="2.8854"/>
<vertex x="7.6987" y="3.4341" curve="-23.523907"/>
<vertex x="7.8867" y="3.5738" curve="-19.885101"/>
<vertex x="7.9629" y="3.5941"/>
<vertex x="8.1915" y="3.5941" curve="31.19409"/>
<vertex x="8.5827" y="3.7033" curve="24.220112"/>
<vertex x="8.89" y="3.9929" curve="41.579705"/>
<vertex x="9.0703" y="4.7269" curve="25.48189"/>
<vertex x="8.9637" y="5.0241" curve="24.327175"/>
<vertex x="8.7605" y="5.2299"/>
<vertex x="8.7605" y="5.141" curve="-30.728978"/>
<vertex x="8.7528" y="5.113" curve="-32.859185"/>
<vertex x="8.6843" y="5.0495" curve="-11.956766"/>
<vertex x="8.6639" y="5.0419" curve="-49.772638"/>
<vertex x="8.4988" y="5.0724" curve="-0.938211"/>
<vertex x="8.4074" y="5.1384" curve="-17.462115"/>
<vertex x="8.3287" y="5.2172" curve="-18.133005"/>
<vertex x="8.2779" y="5.3162" curve="-27.405164"/>
<vertex x="8.2728" y="5.3823" curve="-60.291265"/>
<vertex x="8.4125" y="5.5524" curve="-18.806378"/>
<vertex x="8.5166" y="5.5728" curve="-3.38798"/>
<vertex x="8.5776" y="5.5728"/>
<vertex x="8.5775" y="5.5728"/>
<vertex x="8.575" y="5.5753" curve="28.458071"/>
<vertex x="8.4811" y="5.6312" curve="-13.16107"/>
<vertex x="8.4455" y="5.6464" curve="11.36204"/>
<vertex x="8.4226" y="5.6566" curve="17.239689"/>
<vertex x="8.2448" y="5.6871" curve="33.13693"/>
<vertex x="7.9959" y="5.6185" curve="15.258219"/>
<vertex x="7.8486" y="5.4966" curve="72.107848"/>
<vertex x="7.808" y="5.1511" curve="18.59376"/>
<vertex x="8.0721" y="4.8209" curve="-104.814891"/>
<vertex x="8.0442" y="4.4628" curve="-28.91879"/>
<vertex x="7.8638" y="4.4018" curve="-42.347638"/>
<vertex x="7.6556" y="4.4653" curve="-32.991127"/>
<vertex x="7.5997" y="4.5441" curve="-37.722834"/>
<vertex x="7.5997" y="4.6787" curve="-35.953185"/>
<vertex x="7.6225" y="4.7092" curve="1.480237"/>
<vertex x="7.7064" y="4.7701" curve="-50.628124"/>
</polygon>
<vertex x="3.429" y="2.0422"/>
<vertex x="3.8481" y="2.0422"/>
<vertex x="3.8532" y="2.0422"/>
<vertex x="3.8532" y="2.0472" curve="-68.039308"/>
<vertex x="4.0005" y="2.2657" curve="-22.39327"/>
<vertex x="4.1199" y="2.2885" curve="-3.405437"/>
<vertex x="4.257" y="2.2835" curve="-33.177729"/>
<vertex x="4.3663" y="2.2428" curve="-34.890164"/>
<vertex x="4.4298" y="2.1539" curve="-36.168145"/>
<vertex x="4.4298" y="1.9888" curve="-21.999237"/>
<vertex x="4.4171" y="1.966" curve="-14.593315"/>
<vertex x="4.3866" y="1.938" curve="-21.154086"/>
<vertex x="4.2926" y="1.8948" curve="-8.629722"/>
<vertex x="4.1605" y="1.872" curve="0.869941"/>
<vertex x="3.9395" y="1.8491" curve="15.602192"/>
<vertex x="3.6373" y="1.7729" curve="34.549388"/>
<vertex x="3.4569" y="1.6256" curve="28.173786"/>
<vertex x="3.3934" y="1.4453" curve="31.078447"/>
<vertex x="3.4493" y="1.1354" curve="32.295148"/>
<vertex x="3.5611" y="1.0109" curve="25.694915"/>
<vertex x="3.8252" y="0.9195" curve="19.622558"/>
<vertex x="4.1504" y="0.9398" curve="32.390706"/>
<vertex x="4.4323" y="1.0998" curve="-125.07955"/>
<vertex x="4.4577" y="1.0922" curve="3.241851"/>
<vertex x="4.4806" y="0.9881" curve="2.315334"/>
<vertex x="4.4882" y="0.9601" curve="94.722749"/>
<vertex x="4.4983" y="0.955"/>
<vertex x="4.9022" y="0.955"/>
<vertex x="4.8946" y="0.9754" curve="-21.426246"/>
<vertex x="4.8489" y="1.2421" curve="1.324616"/>
<vertex x="4.8514" y="1.6764"/>
<vertex x="4.4425" y="1.6764"/>
<vertex x="4.4425" y="1.5926" curve="-14.598809"/>
<vertex x="4.4145" y="1.3741" curve="-2.929119"/>
<vertex x="4.4094" y="1.3564" curve="-22.4562"/>
<vertex x="4.3815" y="1.3056" curve="-11.881148"/>
<vertex x="4.3053" y="1.2319" curve="-23.083134"/>
<vertex x="4.2393" y="1.1989" curve="-13.72019"/>
<vertex x="4.1326" y="1.1836" curve="-6.374024"/>
<vertex x="3.9776" y="1.1887" curve="-41.251679"/>
<vertex x="3.8456" y="1.2522" curve="-36.807382"/>
<vertex x="3.8024" y="1.3437" curve="-34.728703"/>
<vertex x="3.8354" y="1.5215" curve="-26.276731"/>
<vertex x="3.8862" y="1.5799" curve="-30.039782"/>
<vertex x="4.0462" y="1.6408" curve="0.424762"/>
<vertex x="4.191" y="1.6561" curve="13.817366"/>
<vertex x="4.3866" y="1.7018" curve="43.884562"/>
<vertex x="4.4374" y="1.7475"/>
<vertex x="4.4425" y="1.7475"/>
<vertex x="4.4425" y="1.6866"/>
<vertex x="4.8489" y="1.6866"/>
<vertex x="4.8489" y="2.1692" curve="56.355147"/>
<vertex x="4.7142" y="2.4206" curve="22.550324"/>
<vertex x="4.4425" y="2.5324" curve="21.771523"/>
<vertex x="3.9192" y="2.5349" curve="18.654747"/>
<vertex x="3.6805" y="2.4486" curve="58.925698"/>
<vertex x="3.4315" y="2.0396"/>
</polygon>
<vertex x="5.1206" y="0.955"/>
<vertex x="5.1232" y="2.4435"/>
<vertex x="5.5093" y="2.5121"/>
<vertex x="5.5093" y="2.225"/>
<vertex x="5.5194" y="2.22"/>
<vertex x="5.5347" y="2.225"/>
<vertex x="5.555" y="2.2555" curve="0.575632"/>
<vertex x="5.6236" y="2.3597" curve="-26.005542"/>
<vertex x="5.6947" y="2.4282" curve="4.844231"/>
<vertex x="5.7836" y="2.4867" curve="-34.714226"/>
<vertex x="5.9817" y="2.5527" curve="-8.490145"/>
<vertex x="6.1189" y="2.5451"/>
<vertex x="6.1189" y="2.159"/>
<vertex x="6.1163" y="2.159" curve="-18.703114"/>
<vertex x="6.1011" y="2.1615" curve="13.897661"/>
<vertex x="6.0401" y="2.1742" curve="9.613772"/>
<vertex x="5.8852" y="2.1742" curve="28.869211"/>
<vertex x="5.7252" y="2.1184" curve="38.254929"/>
<vertex x="5.5651" y="1.9075" curve="17.519625"/>
<vertex x="5.5372" y="1.7374"/>
<vertex x="5.5372" y="0.955"/>
</polygon>
<vertex x="6.3068" y="0.9474"/>
<vertex x="6.3068" y="2.8804"/>
<vertex x="6.7208" y="3.1166"/>
<vertex x="6.7208" y="1.9431"/>
<vertex x="7.2898" y="2.5121"/>
<vertex x="7.7572" y="2.5121"/>
<vertex x="7.1806" y="1.9482"/>
<vertex x="7.8461" y="0.95"/>
<vertex x="7.3381" y="0.9525"/>
<vertex x="6.9113" y="1.6561"/>
<vertex x="6.9063" y="1.6637"/>
<vertex x="6.7259" y="1.4884"/>
<vertex x="6.7259" y="0.955"/>
<vertex x="6.7259" y="0.9423"/>
<vertex x="6.3119" y="0.9423"/>
</polygon>
<vertex x="8.1331" y="0.9449"/>
<vertex x="8.1331" y="2.225"/>
<vertex x="8.1331" y="2.2454"/>
<vertex x="7.7343" y="2.2479"/>
<vertex x="8.001" y="2.5146"/>
<vertex x="8.1382" y="2.5146"/>
<vertex x="8.1382" y="2.5603" curve="-9.483416"/>
<vertex x="8.1559" y="2.7737" curve="-31.210612"/>
<vertex x="8.2296" y="2.9312" curve="-45.199055"/>
<vertex x="8.5877" y="3.1115" curve="-8.265373"/>
<vertex x="8.7427" y="3.1115" curve="1.681156"/>
<vertex x="8.8748" y="3.1039"/>
<vertex x="8.8773" y="3.1039"/>
<vertex x="8.8773" y="2.8016"/>
<vertex x="8.8697" y="2.8016" curve="-10.615066"/>
<vertex x="8.8417" y="2.8042" curve="21.21415"/>
<vertex x="8.6563" y="2.8042" curve="49.503445"/>
<vertex x="8.5776" y="2.7483" curve="29.439827"/>
<vertex x="8.5522" y="2.6543"/>
<vertex x="8.5522" y="2.5146"/>
<vertex x="8.6639" y="2.5146"/>
<vertex x="8.8494" y="2.5146"/>
<vertex x="8.8494" y="2.2479"/>
<vertex x="8.5496" y="2.2479"/>
<vertex x="8.5496" y="0.9449"/>
</polygon>
<vertex x="8.9967" y="2.5197"/>
<vertex x="8.9967" y="1.4402" curve="41.959792"/>
<vertex x="9.1516" y="1.0363" curve="12.254948"/>
<vertex x="9.177" y="1.0135" curve="33.220183"/>
<vertex x="9.4691" y="0.9119" curve="14.888229"/>
<vertex x="9.7663" y="0.9373" curve="18.930743"/>
<vertex x="9.8171" y="0.9576" curve="24.494758"/>
<vertex x="10.0635" y="1.1913"/>
<vertex x="10.066" y="1.1913"/>
<vertex x="10.066" y="0.9525"/>
<vertex x="10.4673" y="0.9525"/>
<vertex x="10.4673" y="2.5146"/>
<vertex x="10.0457" y="2.5146"/>
<vertex x="10.0457" y="1.684" curve="-14.11186"/>
<vertex x="10.0152" y="1.4376" curve="-53.066617"/>
<vertex x="9.8603" y="1.2573" curve="-46.645991"/>
<vertex x="9.5682" y="1.2598" curve="-35.196173"/>
<vertex x="9.4615" y="1.3538" curve="-27.861744"/>
<vertex x="9.4107" y="1.5189"/>
<vertex x="9.4107" y="2.5197"/>
</polygon>
<vertex x="10.7163" y="2.5171"/>
<vertex x="11.1201" y="2.5171"/>
<vertex x="11.1201" y="2.2962"/>
<vertex x="11.1277" y="2.2962" curve="46.330674"/>
<vertex x="11.1455" y="2.3038" curve="7.631487"/>
<vertex x="11.1582" y="2.319" curve="-0.503124"/>
<vertex x="11.1862" y="2.3571" curve="-15.190413"/>
<vertex x="11.2725" y="2.446" curve="-35.851821"/>
<vertex x="11.5672" y="2.5552" curve="-7.669318"/>
<vertex x="11.7678" y="2.5502" curve="-39.496126"/>
<vertex x="12.0345" y="2.4257" curve="-29.201449"/>
<vertex x="12.1488" y="2.2327" curve="-15.281143"/>
<vertex x="12.1818" y="2.0091"/>
<vertex x="12.1818" y="0.955"/>
<vertex x="11.7729" y="0.955"/>
<vertex x="11.7729" y="1.9202" curve="30.972118"/>
<vertex x="11.7145" y="2.1311" curve="39.023543"/>
<vertex x="11.5976" y="2.2276" curve="22.666705"/>
<vertex x="11.5316" y="2.2377" curve="-0.141885"/>
<vertex x="11.4198" y="2.2327" curve="38.319405"/>
<vertex x="11.2598" y="2.1692" curve="28.02057"/>
<vertex x="11.1684" y="2.0396" curve="20.446837"/>
<vertex x="11.1379" y="1.8821" curve="1.468547"/>
<vertex x="11.1379" y="1.8136"/>
<vertex x="11.1379" y="0.9449"/>
<vertex x="10.7163" y="0.9449"/>
</polygon>
<vertex x="14.6025" y="2.0041"/>
<vertex x="14.1834" y="2.0041"/>
<vertex x="14.1834" y="2.0066" curve="65.464281"/>
<vertex x="14.0284" y="2.2479" curve="25.122129"/>
<vertex x="13.8608" y="2.2835" curve="15.789391"/>
<vertex x="13.6906" y="2.2581" curve="31.198357"/>
<vertex x="13.6093" y="2.2073" curve="43.122769"/>
<vertex x="13.4468" y="1.7805" curve="16.103262"/>
<vertex x="13.495" y="1.4681" curve="55.048084"/>
<vertex x="13.7135" y="1.2446" curve="20.22975"/>
<vertex x="13.876" y="1.2217" curve="29.706321"/>
<vertex x="14.0513" y="1.2751" curve="24.714804"/>
<vertex x="14.1351" y="1.3564" curve="29.74364"/>
<vertex x="14.2011" y="1.5519"/>
<vertex x="14.6075" y="1.5519"/>
<vertex x="14.6075" y="1.5469" curve="-15.385547"/>
<vertex x="14.5948" y="1.4529" curve="-47.147892"/>
<vertex x="14.2291" y="1.0008" curve="-27.402481"/>
<vertex x="13.8862" y="0.9169" curve="-13.33283"/>
<vertex x="13.5712" y="0.955" curve="-38.072748"/>
<vertex x="13.1978" y="1.1938" curve="-36.058683"/>
<vertex x="13.0302" y="1.6459" curve="-8.121987"/>
<vertex x="13.0378" y="1.8948" curve="-65.963815"/>
<vertex x="13.5788" y="2.5679" curve="-23.128317"/>
<vertex x="13.8836" y="2.6035" curve="-10.44896"/>
<vertex x="14.1681" y="2.5527" curve="-49.912447"/>
<vertex x="14.5364" y="2.2403" curve="-18.209056"/>
</polygon>
<vertex x="15.5245" y="2.606"/>
<vertex x="15.5372" y="2.601"/>
<vertex x="15.5372" y="2.3089"/>
<vertex x="15.4254" y="2.2936"/>
<vertex x="15.306" y="2.2276"/>
<vertex x="15.2248" y="2.1158"/>
<vertex x="15.1841" y="2.0244"/>
<vertex x="15.1562" y="1.8745"/>
<vertex x="15.1511" y="1.6866"/>
<vertex x="15.1689" y="1.5596"/>
<vertex x="15.207" y="1.4427"/>
<vertex x="15.2629" y="1.336"/>
<vertex x="15.433" y="1.2319"/>
<vertex x="15.6134" y="1.209"/>
<vertex x="15.7937" y="1.27"/>
<vertex x="15.9055" y="1.3716"/>
<vertex x="15.9614" y="1.4961"/>
<vertex x="15.9995" y="1.6535"/>
<vertex x="15.9995" y="1.7983"/>
<vertex x="15.9741" y="1.9939"/>
<vertex x="15.8979" y="2.159"/>
<vertex x="15.8115" y="2.2428"/>
<vertex x="15.7124" y="2.2962"/>
<vertex x="15.5905" y="2.3063"/>
<vertex x="15.5804" y="2.3063"/>
<vertex x="15.5854" y="2.6035"/>
<vertex x="15.7861" y="2.5781"/>
<vertex x="15.9487" y="2.5222"/>
<vertex x="16.1468" y="2.3851"/>
<vertex x="16.256" y="2.2581"/>
<vertex x="16.3601" y="2.0244"/>
<vertex x="16.3881" y="1.8059"/>
<vertex x="16.3627" y="1.5951"/>
<vertex x="16.2941" y="1.3487"/>
<vertex x="16.2128" y="1.2192"/>
<vertex x="16.0934" y="1.1049"/>
<vertex x="15.9817" y="1.0262"/>
<vertex x="15.7963" y="0.9627"/>
<vertex x="15.5448" y="0.9373"/>
<vertex x="15.2451" y="0.9779"/>
<vertex x="14.9606" y="1.1557"/>
<vertex x="14.8006" y="1.4046"/>
<vertex x="14.7396" y="1.7932"/>
<vertex x="14.8209" y="2.1488"/>
<vertex x="15.0343" y="2.4206"/>
<vertex x="15.3721" y="2.5883"/>
<vertex x="15.5194" y="2.606"/>
</polygon>
<vertex x="16.571" y="0.955"/>
<vertex x="16.571" y="2.5603"/>
<vertex x="16.9697" y="2.5603"/>
<vertex x="16.9697" y="2.3393"/>
<vertex x="16.9926" y="2.3444"/>
<vertex x="17.0256" y="2.3876"/>
<vertex x="17.1018" y="2.4663" curve="-28.630227"/>
<vertex x="17.2669" y="2.5679" curve="-8.397868"/>
<vertex x="17.3761" y="2.5933" curve="-7.216607"/>
<vertex x="17.5133" y="2.606" curve="-23.226266"/>
<vertex x="17.7013" y="2.573" curve="-43.906598"/>
<vertex x="17.9527" y="2.3343" curve="45.791594"/>
<vertex x="17.9614" y="2.3379"/>
<vertex x="17.9705" y="2.347" curve="3.053362"/>
<vertex x="18.0162" y="2.3952" curve="-16.521227"/>
<vertex x="18.1839" y="2.5349" curve="-33.134934"/>
<vertex x="18.4404" y="2.6035" curve="-12.76791"/>
<vertex x="18.6944" y="2.5679" curve="-37.751985"/>
<vertex x="18.923" y="2.4181" curve="-34.981411"/>
<vertex x="19.0373" y="2.1107"/>
<vertex x="19.0373" y="0.9525"/>
<vertex x="18.6131" y="0.9525"/>
<vertex x="18.6131" y="1.9812" curve="27.700549"/>
<vertex x="18.5699" y="2.1565" curve="52.997251"/>
<vertex x="18.415" y="2.2682" curve="20.248197"/>
<vertex x="18.2296" y="2.2657" curve="37.306133"/>
<vertex x="18.1127" y="2.1996" curve="34.495161"/>
<vertex x="18.0289" y="2.0168" curve="6.995853"/>
<vertex x="18.0213" y="1.905"/>
<vertex x="18.0213" y="0.9525"/>
<vertex x="17.5895" y="0.9525"/>
<vertex x="17.5895" y="2.0091" curve="40.942194"/>
<vertex x="17.5184" y="2.1996" curve="51.746517"/>
<vertex x="17.3406" y="2.2758" curve="1.299182"/>
<vertex x="17.2542" y="2.2708" curve="39.481905"/>
<vertex x="17.1272" y="2.2149" curve="11.09008"/>
<vertex x="17.0434" y="2.1184" curve="45.798571"/>
<vertex x="17.0028" y="1.9355"/>
<vertex x="17.0028" y="0.955"/>
</polygon>
</package>
<package name="SFE-LOGO-FLAME-COPPER">
<polygon width="0.0254" layer="1">
<vertex x="0.5462" y="1.8974"/>
<vertex x="0.4979" y="1.905" curve="17.884178"/>
<vertex x="0.3099" y="1.905" curve="46.327753"/>
<vertex x="0.0712" y="1.7551" curve="35.91905"/>
<vertex x="0.0001" y="1.5189"/>
<vertex x="0.0001" y="0.0025"/>
<vertex x="0.4877" y="0.5512" curve="-23.528974"/>
<vertex x="0.6757" y="0.6909" curve="-19.885101"/>
<vertex x="0.7519" y="0.7112"/>
<vertex x="0.9805" y="0.7112" curve="31.19409"/>
<vertex x="1.3717" y="0.8204" curve="24.226678"/>
<vertex x="1.679" y="1.11" curve="41.579705"/>
<vertex x="1.8593" y="1.844" curve="25.48189"/>
<vertex x="1.7527" y="2.1412" curve="24.327175"/>
<vertex x="1.5495" y="2.347"/>
<vertex x="1.5495" y="2.2581" curve="-30.728978"/>
<vertex x="1.5418" y="2.2301" curve="-33.074668"/>
<vertex x="1.4733" y="2.1666" curve="-11.956766"/>
<vertex x="1.4529" y="2.159" curve="-49.772638"/>
<vertex x="1.2878" y="2.1895" curve="-0.938211"/>
<vertex x="1.1964" y="2.2555" curve="-17.462115"/>
<vertex x="1.1177" y="2.3343" curve="-18.133005"/>
<vertex x="1.0669" y="2.4333" curve="-27.405164"/>
<vertex x="1.0618" y="2.4994" curve="-60.325263"/>
<vertex x="1.2015" y="2.6695" curve="-18.806378"/>
<vertex x="1.3056" y="2.6899" curve="-3.38798"/>
<vertex x="1.3666" y="2.6899"/>
<vertex x="1.3665" y="2.6899"/>
<vertex x="1.364" y="2.6924" curve="28.458071"/>
<vertex x="1.2701" y="2.7483" curve="-13.16107"/>
<vertex x="1.2345" y="2.7635" curve="11.36204"/>
<vertex x="1.2116" y="2.7737" curve="17.239689"/>
<vertex x="1.0338" y="2.8042" curve="33.13693"/>
<vertex x="0.7849" y="2.7356" curve="15.258219"/>
<vertex x="0.6376" y="2.6137" curve="72.107848"/>
<vertex x="0.597" y="2.2682" curve="18.59376"/>
<vertex x="0.8611" y="1.938" curve="-104.814891"/>
<vertex x="0.8332" y="1.5799" curve="-28.91879"/>
<vertex x="0.6528" y="1.5189" curve="-42.347638"/>
<vertex x="0.4446" y="1.5824" curve="-32.991127"/>
<vertex x="0.3887" y="1.6612" curve="-37.722834"/>
<vertex x="0.3887" y="1.7958" curve="-35.953185"/>
<vertex x="0.4115" y="1.8263" curve="1.480237"/>
<vertex x="0.4954" y="1.8872" curve="-50.628124"/>
</polygon>
</package>
<package name="SFE-LOGO-FLAME">
<vertex x="1.5418" y="2.2301" curve="-33.047583"/>
</polygon>
</package>
<package name="SFE-NEW-WEB">
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</package>
<package name="SFE-NEW-WEB-SOLDERMASK">
<wire x1="10.7163" y1="0.9449" x2="10.7163" y2="2.5171" width="0.0254" layer="29"/>
<wire x1="10.7163" y1="2.5171" x2="11.1201" y2="2.5171" width="0.0254" layer="29"/>
<wire x1="11.1201" y1="2.5171" x2="11.1201" y2="2.2962" width="0.0254" layer="29"/>
<wire x1="11.1201" y1="2.2962" x2="11.1277" y2="2.2962" width="0.0254" layer="29"/>
<wire x1="11.1277" y1="2.2962" x2="11.1455" y2="2.3038" width="0.0254" layer="29" curve="46.330674"/>
<wire x1="11.1455" y1="2.3038" x2="11.1582" y2="2.319" width="0.0254" layer="29" curve="7.631487"/>
<wire x1="11.1582" y1="2.319" x2="11.1862" y2="2.3571" width="0.0254" layer="29" curve="-0.503124"/>
<wire x1="11.1862" y1="2.3571" x2="11.2725" y2="2.446" width="0.0254" layer="29" curve="-15.190413"/>
<wire x1="11.2725" y1="2.446" x2="11.5672" y2="2.5552" width="0.0254" layer="29" curve="-35.851821"/>
<wire x1="11.5672" y1="2.5552" x2="11.7678" y2="2.5502" width="0.0254" layer="29" curve="-7.669318"/>
<wire x1="11.7678" y1="2.5502" x2="12.0345" y2="2.4257" width="0.0254" layer="29" curve="-39.496126"/>
<wire x1="12.0345" y1="2.4257" x2="12.1488" y2="2.2327" width="0.0254" layer="29" curve="-29.201449"/>
<wire x1="12.1488" y1="2.2327" x2="12.1818" y2="2.0091" width="0.0254" layer="29" curve="-15.281143"/>
<wire x1="12.1818" y1="2.0091" x2="12.1818" y2="0.955" width="0.0254" layer="29"/>
<wire x1="12.1818" y1="0.955" x2="11.7729" y2="0.955" width="0.0254" layer="29"/>
<wire x1="11.7729" y1="0.955" x2="11.7729" y2="1.9202" width="0.0254" layer="29"/>
<wire x1="11.7729" y1="1.9202" x2="11.7145" y2="2.1311" width="0.0254" layer="29" curve="30.972118"/>
<wire x1="11.7145" y1="2.1311" x2="11.5976" y2="2.2276" width="0.0254" layer="29" curve="39.023543"/>
<wire x1="11.5976" y1="2.2276" x2="11.5316" y2="2.2377" width="0.0254" layer="29" curve="22.666705"/>
<wire x1="11.5316" y1="2.2377" x2="11.4198" y2="2.2327" width="0.0254" layer="29" curve="-0.141885"/>
<wire x1="11.4198" y1="2.2327" x2="11.2598" y2="2.1692" width="0.0254" layer="29" curve="38.319405"/>
<wire x1="11.2598" y1="2.1692" x2="11.1684" y2="2.0396" width="0.0254" layer="29" curve="28.02057"/>
<wire x1="11.1684" y1="2.0396" x2="11.1379" y2="1.8821" width="0.0254" layer="29" curve="20.446837"/>
<wire x1="11.1379" y1="1.8821" x2="11.1379" y2="1.8136" width="0.0254" layer="29" curve="1.468547"/>
<wire x1="11.1379" y1="1.8136" x2="11.1379" y2="0.9449" width="0.0254" layer="29"/>
<wire x1="11.1379" y1="0.9449" x2="10.7163" y2="0.9449" width="0.0254" layer="29"/>
<polygon width="0.0254" layer="29">
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</polygon>
</package>
<package name="OSHW-LOGO-S">
<polygon width="0.15" layer="21">
<vertex x="0.3947" y="-0.9528" curve="9.498218"/>
<vertex x="0.5465" y="-0.8746"/>
<vertex x="0.9235" y="-1.182"/>
<vertex x="1.182" y="-0.9235"/>
<vertex x="0.8746" y="-0.5465" curve="19.000773"/>
<vertex x="1.0049" y="-0.232"/>
<vertex x="1.4888" y="-0.1828"/>
<vertex x="1.4888" y="0.1828"/>
<vertex x="1.0049" y="0.232" curve="19.000773"/>
<vertex x="0.8746" y="0.5465"/>
<vertex x="1.182" y="0.9235"/>
<vertex x="0.9235" y="1.182"/>
<vertex x="0.5465" y="0.8746" curve="19.000773"/>
<vertex x="0.232" y="1.0049"/>
<vertex x="0.1828" y="1.4888"/>
<vertex x="-0.1828" y="1.4888"/>
<vertex x="-0.232" y="1.0049" curve="19.000773"/>
<vertex x="-0.5465" y="0.8746"/>
<vertex x="-0.9235" y="1.182"/>
<vertex x="-1.182" y="0.9235"/>
<vertex x="-0.8746" y="0.5465" curve="19.000773"/>
<vertex x="-1.0049" y="0.232"/>
<vertex x="-1.4888" y="0.1828"/>
<vertex x="-1.4888" y="-0.1828"/>
<vertex x="-1.0049" y="-0.232" curve="19.000773"/>
<vertex x="-0.8746" y="-0.5465"/>
<vertex x="-1.182" y="-0.9235"/>
<vertex x="-0.9235" y="-1.182"/>
<vertex x="-0.5465" y="-0.8746" curve="9.498218"/>
<vertex x="-0.3947" y="-0.9528"/>
<vertex x="-0.1794" y="-0.4331" curve="-67.514699"/>
<vertex x="-0.4688" y="0" curve="-247.473915"/>
<vertex x="0.1794" y="-0.4331"/>
</polygon>
</package>
<package name="OSHW-LOGO-M">
<vertex x="0.6578" y="-1.588" curve="9.499253"/>
<vertex x="0.9108" y="-1.4576"/>
<vertex x="1.5392" y="-1.97"/>
<vertex x="1.97" y="-1.5392"/>
<vertex x="1.4576" y="-0.9108" curve="19.001165"/>
<vertex x="1.6747" y="-0.3866"/>
<vertex x="2.4814" y="-0.3047"/>
<vertex x="2.4814" y="0.3047"/>
<vertex x="1.6747" y="0.3866" curve="19.001165"/>
<vertex x="1.4576" y="0.9108"/>
<vertex x="1.97" y="1.5392"/>
<vertex x="1.5392" y="1.97"/>
<vertex x="0.9108" y="1.4576" curve="19.001165"/>
<vertex x="0.3866" y="1.6747"/>
<vertex x="0.3047" y="2.4814"/>
<vertex x="-0.3047" y="2.4814"/>
<vertex x="-0.3866" y="1.6747" curve="19.001165"/>
<vertex x="-0.9108" y="1.4576"/>
<vertex x="-1.5392" y="1.97"/>
<vertex x="-1.97" y="1.5392"/>
<vertex x="-1.4576" y="0.9108" curve="19.001165"/>
<vertex x="-1.6747" y="0.3866"/>
<vertex x="-2.4814" y="0.3047"/>
<vertex x="-2.4814" y="-0.3047"/>
<vertex x="-1.6747" y="-0.3866" curve="19.001165"/>
<vertex x="-1.4576" y="-0.9108"/>
<vertex x="-1.97" y="-1.5392"/>
<vertex x="-1.5392" y="-1.97"/>
<vertex x="-0.9108" y="-1.4576" curve="9.499253"/>
<vertex x="-0.6578" y="-1.588"/>
<vertex x="-0.299" y="-0.7218" curve="-67.507353"/>
<vertex x="-0.7813" y="0" curve="-247.497552"/>
<vertex x="0.299" y="-0.7218"/>
</polygon>
</package>
<package name="OSHW-LOGO-L">
<vertex x="0.9209" y="-2.2231" curve="9.497479"/>
<vertex x="1.2751" y="-2.0407"/>
<vertex x="2.1548" y="-2.758"/>
<vertex x="2.758" y="-2.1548"/>
<vertex x="2.0407" y="-1.2751" curve="18.998791"/>
<vertex x="2.3446" y="-0.5413"/>
<vertex x="3.4739" y="-0.4265"/>
<vertex x="3.4739" y="0.4265"/>
<vertex x="2.3446" y="0.5413" curve="18.998791"/>
<vertex x="2.0407" y="1.2751"/>
<vertex x="2.758" y="2.1548"/>
<vertex x="2.1548" y="2.758"/>
<vertex x="1.2751" y="2.0407" curve="18.998791"/>
<vertex x="0.5413" y="2.3446"/>
<vertex x="0.4265" y="3.4739"/>
<vertex x="-0.4265" y="3.4739"/>
<vertex x="-0.5413" y="2.3446" curve="18.998791"/>
<vertex x="-1.2751" y="2.0407"/>
<vertex x="-2.1548" y="2.758"/>
<vertex x="-2.758" y="2.1548"/>
<vertex x="-2.0407" y="1.2751" curve="18.998791"/>
<vertex x="-2.3446" y="0.5413"/>
<vertex x="-3.4739" y="0.4265"/>
<vertex x="-3.4739" y="-0.4265"/>
<vertex x="-2.3446" y="-0.5413" curve="18.998791"/>
<vertex x="-2.0407" y="-1.2751"/>
<vertex x="-2.758" y="-2.1548"/>
<vertex x="-2.1548" y="-2.758"/>
<vertex x="-1.2751" y="-2.0407" curve="9.497479"/>
<vertex x="-0.9209" y="-2.2231"/>
<vertex x="-0.4186" y="-1.0105" curve="-67.504205"/>
<vertex x="-1.0938" y="0" curve="-247.497204"/>
<vertex x="0.4186" y="-1.0105"/>
</polygon>
</package>
<package name="IOIO-OTG-COPPER-EXPOSED">
<description>IOIO-OTG label with exposed copper</description>
<rectangle x1="3.715071875" y1="-0.07383125" x2="4.279896875" y2="-0.05618125" layer="1"/>
<rectangle x1="9.963471875" y1="-0.07383125" x2="10.528296875" y2="-0.05618125" layer="1"/>
<rectangle x1="3.60916875" y1="-0.05618125" x2="4.40345625" y2="-0.03853125" layer="1"/>
<rectangle x1="9.839915625" y1="-0.05618125" x2="10.634203125" y2="-0.03853125" layer="1"/>
<rectangle x1="3.5209125" y1="-0.03853125" x2="4.49170625" y2="-0.02088125" layer="1"/>
<rectangle x1="9.7693125" y1="-0.03853125" x2="10.72245625" y2="-0.02088125" layer="1"/>
<rectangle x1="3.450309375" y1="-0.020878125" x2="4.562309375" y2="-0.003228125" layer="1"/>
<rectangle x1="9.698709375" y1="-0.020878125" x2="10.793059375" y2="-0.003228125" layer="1"/>
<rectangle x1="0.3437625" y1="-0.003228125" x2="1.4028125" y2="0.014421875" layer="1"/>
<rectangle x1="3.39735625" y1="-0.003228125" x2="4.6152625" y2="0.014421875" layer="1"/>
<rectangle x1="6.6274625" y1="-0.003228125" x2="7.7041625" y2="0.014421875" layer="1"/>
<rectangle x1="9.62810625" y1="-0.003228125" x2="10.8636625" y2="0.014421875" layer="1"/>
<rectangle x1="14.28793125" y1="-0.003228125" x2="17.65924375" y2="0.014421875" layer="1"/>
<rectangle x1="0.290809375" y1="0.014421875" x2="1.455765625" y2="0.032071875" layer="1"/>
<rectangle x1="3.326753125" y1="0.014421875" x2="4.668215625" y2="0.032071875" layer="1"/>
<rectangle x1="6.574509375" y1="0.014421875" x2="7.739465625" y2="0.032071875" layer="1"/>
<rectangle x1="9.575153125" y1="0.014421875" x2="10.916615625" y2="0.032071875" layer="1"/>
<rectangle x1="14.182025" y1="0.014421875" x2="17.76514375" y2="0.032071875" layer="1"/>
<rectangle x1="0.25550625" y1="0.032071875" x2="1.4910625" y2="0.049721875" layer="1"/>
<rectangle x1="3.273803125" y1="0.032071875" x2="4.721171875" y2="0.049721875" layer="1"/>
<rectangle x1="6.539209375" y1="0.032071875" x2="7.774765625" y2="0.049721875" layer="1"/>
<rectangle x1="9.522203125" y1="0.032071875" x2="10.969571875" y2="0.049721875" layer="1"/>
<rectangle x1="14.093771875" y1="0.032071875" x2="17.853403125" y2="0.049721875" layer="1"/>
<rectangle x1="0.22020625" y1="0.049725" x2="1.5087125" y2="0.067375" layer="1"/>
<rectangle x1="3.2385" y1="0.049725" x2="4.774125" y2="0.067375" layer="1"/>
<rectangle x1="6.52155625" y1="0.049725" x2="7.81006875" y2="0.067375" layer="1"/>
<rectangle x1="9.46925" y1="0.049725" x2="11.00486875" y2="0.067375" layer="1"/>
<rectangle x1="14.02316875" y1="0.049725" x2="17.90635" y2="0.067375" layer="1"/>
<rectangle x1="0.202553125" y1="0.067375" x2="1.544015625" y2="0.085025" layer="1"/>
<rectangle x1="3.185546875" y1="0.067375" x2="4.809421875" y2="0.085025" layer="1"/>
<rectangle x1="6.48625625" y1="0.067375" x2="7.84536875" y2="0.085025" layer="1"/>
<rectangle x1="9.433946875" y1="0.067375" x2="11.057821875" y2="0.085025" layer="1"/>
<rectangle x1="13.970215625" y1="0.067375" x2="17.976953125" y2="0.085025" layer="1"/>
<rectangle x1="0.184903125" y1="0.085025" x2="1.561665625" y2="0.102675" layer="1"/>
<rectangle x1="3.150246875" y1="0.085025" x2="4.862378125" y2="0.102675" layer="1"/>
<rectangle x1="6.46860625" y1="0.085025" x2="7.86301875" y2="0.102675" layer="1"/>
<rectangle x1="9.38099375" y1="0.085025" x2="11.093125" y2="0.102675" layer="1"/>
<rectangle x1="13.9172625" y1="0.085025" x2="18.02990625" y2="0.102675" layer="1"/>
<rectangle x1="0.149603125" y1="0.102675" x2="1.579321875" y2="0.120325" layer="1"/>
<rectangle x1="3.11494375" y1="0.102675" x2="4.897675" y2="0.120325" layer="1"/>
<rectangle x1="6.450953125" y1="0.102675" x2="7.880671875" y2="0.120325" layer="1"/>
<rectangle x1="9.34569375" y1="0.102675" x2="11.128425" y2="0.120325" layer="1"/>
<rectangle x1="13.8819625" y1="0.102675" x2="18.0652125" y2="0.120325" layer="1"/>
<rectangle x1="0.149603125" y1="0.120328125" x2="1.596971875" y2="0.137978125" layer="1"/>
<rectangle x1="3.07964375" y1="0.120328125" x2="4.93298125" y2="0.137978125" layer="1"/>
<rectangle x1="6.433303125" y1="0.120328125" x2="7.898321875" y2="0.137978125" layer="1"/>
<rectangle x1="9.310390625" y1="0.120328125" x2="11.163728125" y2="0.137978125" layer="1"/>
<rectangle x1="13.829009375" y1="0.120328125" x2="18.118165625" y2="0.137978125" layer="1"/>
<rectangle x1="0.13195" y1="0.137978125" x2="1.61461875" y2="0.155628125" layer="1"/>
<rectangle x1="3.044340625" y1="0.137978125" x2="4.968284375" y2="0.155628125" layer="1"/>
<rectangle x1="6.415653125" y1="0.137978125" x2="7.915971875" y2="0.155628125" layer="1"/>
<rectangle x1="9.275090625" y1="0.137978125" x2="11.199028125" y2="0.155628125" layer="1"/>
<rectangle x1="13.79370625" y1="0.137978125" x2="18.1534625" y2="0.155628125" layer="1"/>
<rectangle x1="0.1143" y1="0.155628125" x2="1.63226875" y2="0.173278125" layer="1"/>
<rectangle x1="3.0090375" y1="0.155628125" x2="5.00358125" y2="0.173278125" layer="1"/>
<rectangle x1="6.398003125" y1="0.155628125" x2="7.915971875" y2="0.173278125" layer="1"/>
<rectangle x1="9.2397875" y1="0.155628125" x2="11.23433125" y2="0.173278125" layer="1"/>
<rectangle x1="13.75840625" y1="0.155628125" x2="18.18876875" y2="0.173278125" layer="1"/>
<rectangle x1="0.09665" y1="0.173278125" x2="1.63226875" y2="0.190928125" layer="1"/>
<rectangle x1="2.9737375" y1="0.173278125" x2="5.0388875" y2="0.190928125" layer="1"/>
<rectangle x1="6.398003125" y1="0.173278125" x2="7.933621875" y2="0.190928125" layer="1"/>
<rectangle x1="9.2044875" y1="0.173278125" x2="11.26963125" y2="0.190928125" layer="1"/>
<rectangle x1="13.723103125" y1="0.173278125" x2="18.224065625" y2="0.190928125" layer="1"/>
<rectangle x1="0.09665" y1="0.19093125" x2="1.649925" y2="0.20858125" layer="1"/>
<rectangle x1="2.938434375" y1="0.19093125" x2="5.056534375" y2="0.20858125" layer="1"/>
<rectangle x1="6.38035" y1="0.19093125" x2="7.951275" y2="0.20858125" layer="1"/>
<rectangle x1="9.186834375" y1="0.19093125" x2="11.304934375" y2="0.20858125" layer="1"/>
<rectangle x1="13.687803125" y1="0.19093125" x2="18.259371875" y2="0.20858125" layer="1"/>
<rectangle x1="0.078996875" y1="0.20858125" x2="1.667571875" y2="0.22623125" layer="1"/>
<rectangle x1="2.920784375" y1="0.20858125" x2="5.091834375" y2="0.22623125" layer="1"/>
<rectangle x1="6.38035" y1="0.20858125" x2="7.951275" y2="0.22623125" layer="1"/>
<rectangle x1="9.151534375" y1="0.20858125" x2="11.340234375" y2="0.22623125" layer="1"/>
<rectangle x1="13.6525" y1="0.20858125" x2="18.29466875" y2="0.22623125" layer="1"/>
<rectangle x1="0.061346875" y1="0.22623125" x2="1.667571875" y2="0.24388125" layer="1"/>
<rectangle x1="2.885484375" y1="0.22623125" x2="5.127140625" y2="0.24388125" layer="1"/>
<rectangle x1="6.3627" y1="0.22623125" x2="7.968925" y2="0.24388125" layer="1"/>
<rectangle x1="9.11623125" y1="0.22623125" x2="11.3578875" y2="0.24388125" layer="1"/>
<rectangle x1="13.617196875" y1="0.22623125" x2="18.329971875" y2="0.24388125" layer="1"/>
<rectangle x1="0.061346875" y1="0.243884375" x2="1.685221875" y2="0.261534375" layer="1"/>
<rectangle x1="2.85018125" y1="0.243884375" x2="5.1447875" y2="0.261534375" layer="1"/>
<rectangle x1="6.34505" y1="0.243884375" x2="7.968925" y2="0.261534375" layer="1"/>
<rectangle x1="9.09858125" y1="0.243884375" x2="11.3931875" y2="0.261534375" layer="1"/>
<rectangle x1="13.599546875" y1="0.243884375" x2="18.347621875" y2="0.261534375" layer="1"/>
<rectangle x1="0.043696875" y1="0.261534375" x2="1.685221875" y2="0.279184375" layer="1"/>
<rectangle x1="2.83253125" y1="0.261534375" x2="5.18009375" y2="0.279184375" layer="1"/>
<rectangle x1="6.34505" y1="0.261534375" x2="7.986575" y2="0.279184375" layer="1"/>
<rectangle x1="9.063278125" y1="0.261534375" x2="11.410840625" y2="0.279184375" layer="1"/>
<rectangle x1="13.564246875" y1="0.261534375" x2="18.382928125" y2="0.279184375" layer="1"/>
<rectangle x1="0.043696875" y1="0.279184375" x2="1.702871875" y2="0.296834375" layer="1"/>
<rectangle x1="2.797228125" y1="0.279184375" x2="5.197740625" y2="0.296834375" layer="1"/>
<rectangle x1="6.34505" y1="0.279184375" x2="7.986575" y2="0.296834375" layer="1"/>
<rectangle x1="9.045628125" y1="0.279184375" x2="11.446140625" y2="0.296834375" layer="1"/>
<rectangle x1="13.54659375" y1="0.279184375" x2="18.400575" y2="0.296834375" layer="1"/>
<rectangle x1="0.043696875" y1="0.296834375" x2="1.702871875" y2="0.314484375" layer="1"/>
<rectangle x1="2.779578125" y1="0.296834375" x2="5.233046875" y2="0.314484375" layer="1"/>
<rectangle x1="6.327396875" y1="0.296834375" x2="8.004228125" y2="0.314484375" layer="1"/>
<rectangle x1="9.027978125" y1="0.296834375" x2="11.463790625" y2="0.314484375" layer="1"/>
<rectangle x1="13.51129375" y1="0.296834375" x2="18.435875" y2="0.314484375" layer="1"/>
<rectangle x1="0.026046875" y1="0.3144875" x2="1.702871875" y2="0.3321375" layer="1"/>
<rectangle x1="2.761928125" y1="0.3144875" x2="5.250696875" y2="0.3321375" layer="1"/>
<rectangle x1="6.327396875" y1="0.3144875" x2="8.004228125" y2="0.3321375" layer="1"/>
<rectangle x1="8.992675" y1="0.3144875" x2="11.48144375" y2="0.3321375" layer="1"/>
<rectangle x1="13.49364375" y1="0.3144875" x2="18.45353125" y2="0.3321375" layer="1"/>
<rectangle x1="0.026046875" y1="0.3321375" x2="1.720528125" y2="0.3497875" layer="1"/>
<rectangle x1="2.726625" y1="0.3321375" x2="5.26834375" y2="0.3497875" layer="1"/>
<rectangle x1="6.327396875" y1="0.3321375" x2="8.004228125" y2="0.3497875" layer="1"/>
<rectangle x1="8.975025" y1="0.3321375" x2="11.51674375" y2="0.3497875" layer="1"/>
<rectangle x1="13.458340625" y1="0.3321375" x2="18.488828125" y2="0.3497875" layer="1"/>
<rectangle x1="0.026046875" y1="0.3497875" x2="1.720528125" y2="0.3674375" layer="1"/>
<rectangle x1="2.708975" y1="0.3497875" x2="5.28599375" y2="0.3674375" layer="1"/>
<rectangle x1="6.309746875" y1="0.3497875" x2="8.021878125" y2="0.3674375" layer="1"/>
<rectangle x1="8.957375" y1="0.3497875" x2="11.53439375" y2="0.3674375" layer="1"/>
<rectangle x1="13.440690625" y1="0.3497875" x2="18.506484375" y2="0.3674375" layer="1"/>
<rectangle x1="0.00839375" y1="0.3674375" x2="1.720525" y2="0.3850875" layer="1"/>
<rectangle x1="2.691325" y1="0.3674375" x2="5.3213" y2="0.3850875" layer="1"/>
<rectangle x1="6.309746875" y1="0.3674375" x2="8.021878125" y2="0.3850875" layer="1"/>
<rectangle x1="8.922071875" y1="0.3674375" x2="11.552046875" y2="0.3850875" layer="1"/>
<rectangle x1="13.4230375" y1="0.3674375" x2="18.52413125" y2="0.3850875" layer="1"/>
<rectangle x1="0.00839375" y1="0.385090625" x2="1.720525" y2="0.402740625" layer="1"/>
<rectangle x1="2.673671875" y1="0.385090625" x2="5.338946875" y2="0.402740625" layer="1"/>
<rectangle x1="6.309746875" y1="0.385090625" x2="8.021878125" y2="0.402740625" layer="1"/>
<rectangle x1="8.904421875" y1="0.385090625" x2="11.569696875" y2="0.402740625" layer="1"/>
<rectangle x1="13.4053875" y1="0.385090625" x2="18.54178125" y2="0.402740625" layer="1"/>
<rectangle x1="0.00839375" y1="0.402740625" x2="1.738175" y2="0.420390625" layer="1"/>
<rectangle x1="2.656021875" y1="0.402740625" x2="5.356603125" y2="0.420390625" layer="1"/>
<rectangle x1="6.309746875" y1="0.402740625" x2="8.021878125" y2="0.420390625" layer="1"/>
<rectangle x1="8.886771875" y1="0.402740625" x2="11.605003125" y2="0.420390625" layer="1"/>
<rectangle x1="13.3700875" y1="0.402740625" x2="18.5770875" y2="0.420390625" layer="1"/>
<rectangle x1="0.00839375" y1="0.420390625" x2="1.738175" y2="0.438040625" layer="1"/>
<rectangle x1="2.620721875" y1="0.420390625" x2="5.374253125" y2="0.438040625" layer="1"/>
<rectangle x1="6.309746875" y1="0.420390625" x2="8.021878125" y2="0.438040625" layer="1"/>
<rectangle x1="8.869121875" y1="0.420390625" x2="11.622653125" y2="0.438040625" layer="1"/>
<rectangle x1="13.352434375" y1="0.420390625" x2="18.594734375" y2="0.438040625" layer="1"/>
<rectangle x1="0.00839375" y1="0.43804375" x2="1.738175" y2="0.45569375" layer="1"/>
<rectangle x1="2.60306875" y1="0.43804375" x2="5.3919" y2="0.45569375" layer="1"/>
<rectangle x1="6.292096875" y1="0.43804375" x2="8.021878125" y2="0.45569375" layer="1"/>
<rectangle x1="8.85146875" y1="0.43804375" x2="11.6403" y2="0.45569375" layer="1"/>
<rectangle x1="13.334784375" y1="0.43804375" x2="18.612384375" y2="0.45569375" layer="1"/>
<rectangle x1="0.00839375" y1="0.45569375" x2="1.738175" y2="0.47334375" layer="1"/>
<rectangle x1="2.58541875" y1="0.45569375" x2="5.40955" y2="0.47334375" layer="1"/>
<rectangle x1="6.292096875" y1="0.45569375" x2="8.039528125" y2="0.47334375" layer="1"/>
<rectangle x1="8.83381875" y1="0.45569375" x2="11.65795" y2="0.47334375" layer="1"/>
<rectangle x1="13.317134375" y1="0.45569375" x2="18.630034375" y2="0.47334375" layer="1"/>
<rectangle x1="0.00839375" y1="0.47334375" x2="1.738175" y2="0.49099375" layer="1"/>
<rectangle x1="2.56776875" y1="0.47334375" x2="5.42720625" y2="0.49099375" layer="1"/>
<rectangle x1="6.292096875" y1="0.47334375" x2="8.039528125" y2="0.49099375" layer="1"/>
<rectangle x1="8.81616875" y1="0.47334375" x2="11.67560625" y2="0.49099375" layer="1"/>
<rectangle x1="13.299484375" y1="0.47334375" x2="18.647690625" y2="0.49099375" layer="1"/>
<rectangle x1="0.00839375" y1="0.49099375" x2="1.738175" y2="0.50864375" layer="1"/>
<rectangle x1="2.550115625" y1="0.49099375" x2="5.444853125" y2="0.50864375" layer="1"/>
<rectangle x1="6.292096875" y1="0.49099375" x2="8.039528125" y2="0.50864375" layer="1"/>
<rectangle x1="8.798515625" y1="0.49099375" x2="11.693253125" y2="0.50864375" layer="1"/>
<rectangle x1="13.28183125" y1="0.49099375" x2="18.6653375" y2="0.50864375" layer="1"/>
<rectangle x1="0.00839375" y1="0.508646875" x2="1.738175" y2="0.526296875" layer="1"/>
<rectangle x1="2.532465625" y1="0.508646875" x2="5.462503125" y2="0.526296875" layer="1"/>
<rectangle x1="6.292096875" y1="0.508646875" x2="8.039528125" y2="0.526296875" layer="1"/>
<rectangle x1="8.780865625" y1="0.508646875" x2="11.710903125" y2="0.526296875" layer="1"/>
<rectangle x1="13.26418125" y1="0.508646875" x2="18.6829875" y2="0.526296875" layer="1"/>
<rectangle x1="0.00839375" y1="0.526296875" x2="1.738175" y2="0.543946875" layer="1"/>
<rectangle x1="2.514815625" y1="0.526296875" x2="5.480153125" y2="0.543946875" layer="1"/>
<rectangle x1="6.292096875" y1="0.526296875" x2="8.039528125" y2="0.543946875" layer="1"/>
<rectangle x1="8.763215625" y1="0.526296875" x2="11.728553125" y2="0.543946875" layer="1"/>
<rectangle x1="13.24653125" y1="0.526296875" x2="18.70064375" y2="0.543946875" layer="1"/>
<rectangle x1="0.00839375" y1="0.543946875" x2="1.738175" y2="0.561596875" layer="1"/>
<rectangle x1="2.497165625" y1="0.543946875" x2="5.497809375" y2="0.561596875" layer="1"/>
<rectangle x1="6.292096875" y1="0.543946875" x2="8.039528125" y2="0.561596875" layer="1"/>
<rectangle x1="8.745565625" y1="0.543946875" x2="11.746209375" y2="0.561596875" layer="1"/>
<rectangle x1="13.228878125" y1="0.543946875" x2="18.718290625" y2="0.561596875" layer="1"/>
<rectangle x1="0.00839375" y1="0.561596875" x2="1.738175" y2="0.579246875" layer="1"/>
<rectangle x1="2.4795125" y1="0.561596875" x2="5.51545625" y2="0.579246875" layer="1"/>
<rectangle x1="6.292096875" y1="0.561596875" x2="8.021878125" y2="0.579246875" layer="1"/>
<rectangle x1="8.7279125" y1="0.561596875" x2="11.76385625" y2="0.579246875" layer="1"/>
<rectangle x1="13.211228125" y1="0.561596875" x2="18.735940625" y2="0.579246875" layer="1"/>
<rectangle x1="0.00839375" y1="0.57925" x2="1.738175" y2="0.5969" layer="1"/>
<rectangle x1="2.4795125" y1="0.57925" x2="5.53310625" y2="0.5969" layer="1"/>
<rectangle x1="6.292096875" y1="0.57925" x2="8.021878125" y2="0.5969" layer="1"/>
<rectangle x1="8.7102625" y1="0.57925" x2="11.78150625" y2="0.5969" layer="1"/>
<rectangle x1="13.193578125" y1="0.57925" x2="18.753590625" y2="0.5969" layer="1"/>
<rectangle x1="0.00839375" y1="0.5969" x2="1.738175" y2="0.61455" layer="1"/>
<rectangle x1="2.4618625" y1="0.5969" x2="5.5507625" y2="0.61455" layer="1"/>
<rectangle x1="6.309746875" y1="0.5969" x2="8.021878125" y2="0.61455" layer="1"/>
<rectangle x1="8.6926125" y1="0.5969" x2="11.78150625" y2="0.61455" layer="1"/>
<rectangle x1="13.175928125" y1="0.5969" x2="18.771246875" y2="0.61455" layer="1"/>
<rectangle x1="0.00839375" y1="0.61455" x2="1.720525" y2="0.6322" layer="1"/>
<rectangle x1="2.4442125" y1="0.61455" x2="5.5684125" y2="0.6322" layer="1"/>
<rectangle x1="6.309746875" y1="0.61455" x2="8.021878125" y2="0.6322" layer="1"/>
<rectangle x1="8.6749625" y1="0.61455" x2="11.7991625" y2="0.6322" layer="1"/>
<rectangle x1="13.175928125" y1="0.61455" x2="18.771246875" y2="0.6322" layer="1"/>
<rectangle x1="0.00839375" y1="0.632203125" x2="1.720525" y2="0.649853125" layer="1"/>
<rectangle x1="2.4265625" y1="0.632203125" x2="5.5860625" y2="0.649853125" layer="1"/>
<rectangle x1="6.309746875" y1="0.632203125" x2="8.021878125" y2="0.649853125" layer="1"/>
<rectangle x1="8.6749625" y1="0.632203125" x2="11.8168125" y2="0.649853125" layer="1"/>
<rectangle x1="13.158275" y1="0.632203125" x2="18.78889375" y2="0.649853125" layer="1"/>
<rectangle x1="0.026046875" y1="0.649853125" x2="1.720528125" y2="0.667503125" layer="1"/>
<rectangle x1="2.408909375" y1="0.649853125" x2="5.586059375" y2="0.667503125" layer="1"/>
<rectangle x1="6.309746875" y1="0.649853125" x2="8.021878125" y2="0.667503125" layer="1"/>
<rectangle x1="8.657309375" y1="0.649853125" x2="11.834459375" y2="0.667503125" layer="1"/>
<rectangle x1="13.140625" y1="0.649853125" x2="18.80654375" y2="0.667503125" layer="1"/>
<rectangle x1="0.026046875" y1="0.667503125" x2="1.720528125" y2="0.685153125" layer="1"/>
<rectangle x1="2.408909375" y1="0.667503125" x2="5.603709375" y2="0.685153125" layer="1"/>
<rectangle x1="6.309746875" y1="0.667503125" x2="8.004228125" y2="0.685153125" layer="1"/>
<rectangle x1="8.639659375" y1="0.667503125" x2="11.852109375" y2="0.685153125" layer="1"/>
<rectangle x1="13.122975" y1="0.667503125" x2="18.82419375" y2="0.685153125" layer="1"/>
<rectangle x1="0.026046875" y1="0.685153125" x2="1.702871875" y2="0.702803125" layer="1"/>
<rectangle x1="2.391259375" y1="0.685153125" x2="5.621365625" y2="0.702803125" layer="1"/>
<rectangle x1="6.327396875" y1="0.685153125" x2="8.004228125" y2="0.702803125" layer="1"/>
<rectangle x1="8.622009375" y1="0.685153125" x2="11.852109375" y2="0.702803125" layer="1"/>
<rectangle x1="13.105325" y1="0.685153125" x2="18.84185" y2="0.702803125" layer="1"/>
<rectangle x1="0.026046875" y1="0.70280625" x2="1.702871875" y2="0.72045625" layer="1"/>
<rectangle x1="2.373609375" y1="0.70280625" x2="5.639015625" y2="0.72045625" layer="1"/>
<rectangle x1="6.327396875" y1="0.70280625" x2="8.004228125" y2="0.72045625" layer="1"/>
<rectangle x1="8.622009375" y1="0.70280625" x2="11.869765625" y2="0.72045625" layer="1"/>
<rectangle x1="13.105325" y1="0.70280625" x2="18.84185" y2="0.72045625" layer="1"/>
<rectangle x1="0.043696875" y1="0.72045625" x2="1.702871875" y2="0.73810625" layer="1"/>
<rectangle x1="2.35595625" y1="0.72045625" x2="5.6390125" y2="0.73810625" layer="1"/>
<rectangle x1="6.327396875" y1="0.72045625" x2="7.986578125" y2="0.73810625" layer="1"/>
<rectangle x1="8.60435625" y1="0.72045625" x2="11.8874125" y2="0.73810625" layer="1"/>
<rectangle x1="13.087671875" y1="0.72045625" x2="18.859496875" y2="0.73810625" layer="1"/>
<rectangle x1="0.043696875" y1="0.73810625" x2="1.685221875" y2="0.75575625" layer="1"/>
<rectangle x1="2.35595625" y1="0.73810625" x2="5.6566625" y2="0.75575625" layer="1"/>
<rectangle x1="6.34505" y1="0.73810625" x2="7.986575" y2="0.75575625" layer="1"/>
<rectangle x1="8.58670625" y1="0.73810625" x2="11.9050625" y2="0.75575625" layer="1"/>
<rectangle x1="13.070021875" y1="0.73810625" x2="18.877146875" y2="0.75575625" layer="1"/>
<rectangle x1="0.061346875" y1="0.75575625" x2="1.685221875" y2="0.77340625" layer="1"/>
<rectangle x1="2.33830625" y1="0.75575625" x2="5.6743125" y2="0.77340625" layer="1"/>
<rectangle x1="6.34505" y1="0.75575625" x2="7.986575" y2="0.77340625" layer="1"/>
<rectangle x1="8.56905625" y1="0.75575625" x2="11.9050625" y2="0.77340625" layer="1"/>
<rectangle x1="13.070021875" y1="0.75575625" x2="18.877146875" y2="0.77340625" layer="1"/>
<rectangle x1="0.061346875" y1="0.773409375" x2="1.667571875" y2="0.791059375" layer="1"/>
<rectangle x1="2.32065625" y1="0.773409375" x2="5.6743125" y2="0.791059375" layer="1"/>
<rectangle x1="6.3627" y1="0.773409375" x2="7.968925" y2="0.791059375" layer="1"/>
<rectangle x1="8.56905625" y1="0.773409375" x2="11.9227125" y2="0.791059375" layer="1"/>
<rectangle x1="13.052371875" y1="0.773409375" x2="14.252628125" y2="0.791059375" layer="1"/>
<rectangle x1="14.623296875" y1="0.773409375" x2="17.482734375" y2="0.791059375" layer="1"/>
<rectangle x1="17.94165625" y1="0.773409375" x2="18.8948" y2="0.791059375" layer="1"/>
<rectangle x1="0.078996875" y1="0.791059375" x2="1.667571875" y2="0.808709375" layer="1"/>
<rectangle x1="2.32065625" y1="0.791059375" x2="5.69196875" y2="0.808709375" layer="1"/>
<rectangle x1="6.3627" y1="0.791059375" x2="7.968925" y2="0.808709375" layer="1"/>
<rectangle x1="8.55140625" y1="0.791059375" x2="11.94036875" y2="0.808709375" layer="1"/>
<rectangle x1="13.034721875" y1="0.791059375" x2="14.164371875" y2="0.808709375" layer="1"/>
<rectangle x1="14.71155" y1="0.791059375" x2="15.84120625" y2="0.808709375" layer="1"/>
<rectangle x1="16.229525" y1="0.791059375" x2="17.394475" y2="0.808709375" layer="1"/>
<rectangle x1="18.0652125" y1="0.791059375" x2="18.91245" y2="0.808709375" layer="1"/>
<rectangle x1="0.078996875" y1="0.808709375" x2="1.649921875" y2="0.826359375" layer="1"/>
<rectangle x1="2.30300625" y1="0.808709375" x2="5.70961875" y2="0.826359375" layer="1"/>
<rectangle x1="6.38035" y1="0.808709375" x2="7.951275" y2="0.826359375" layer="1"/>
<rectangle x1="8.55140625" y1="0.808709375" x2="11.94036875" y2="0.826359375" layer="1"/>
<rectangle x1="13.034721875" y1="0.808709375" x2="14.111421875" y2="0.826359375" layer="1"/>
<rectangle x1="14.764503125" y1="0.808709375" x2="15.841203125" y2="0.826359375" layer="1"/>
<rectangle x1="16.247175" y1="0.808709375" x2="17.341525" y2="0.826359375" layer="1"/>
<rectangle x1="18.135815625" y1="0.808709375" x2="18.912453125" y2="0.826359375" layer="1"/>
<rectangle x1="0.09665" y1="0.8263625" x2="1.649925" y2="0.8440125" layer="1"/>
<rectangle x1="2.285353125" y1="0.8263625" x2="3.944534375" y2="0.8440125" layer="1"/>
<rectangle x1="4.068090625" y1="0.8263625" x2="5.709615625" y2="0.8440125" layer="1"/>
<rectangle x1="6.38035" y1="0.8263625" x2="7.933625" y2="0.8440125" layer="1"/>
<rectangle x1="8.533753125" y1="0.8263625" x2="10.175284375" y2="0.8440125" layer="1"/>
<rectangle x1="10.2988375" y1="0.8263625" x2="11.95801875" y2="0.8440125" layer="1"/>
<rectangle x1="13.01706875" y1="0.8263625" x2="14.07611875" y2="0.8440125" layer="1"/>
<rectangle x1="14.79980625" y1="0.8263625" x2="15.84120625" y2="0.8440125" layer="1"/>
<rectangle x1="16.247175" y1="0.8263625" x2="17.288575" y2="0.8440125" layer="1"/>
<rectangle x1="18.20641875" y1="0.8263625" x2="18.9301" y2="0.8440125" layer="1"/>
<rectangle x1="0.1143" y1="0.8440125" x2="1.63226875" y2="0.8616625" layer="1"/>
<rectangle x1="2.285353125" y1="0.8440125" x2="3.820978125" y2="0.8616625" layer="1"/>
<rectangle x1="4.17399375" y1="0.8440125" x2="5.72726875" y2="0.8616625" layer="1"/>
<rectangle x1="6.398003125" y1="0.8440125" x2="7.933621875" y2="0.8616625" layer="1"/>
<rectangle x1="8.516103125" y1="0.8440125" x2="10.069378125" y2="0.8616625" layer="1"/>
<rectangle x1="10.42239375" y1="0.8440125" x2="11.95801875" y2="0.8616625" layer="1"/>
<rectangle x1="12.99941875" y1="0.8440125" x2="14.04081875" y2="0.8616625" layer="1"/>
<rectangle x1="14.83510625" y1="0.8440125" x2="15.84120625" y2="0.8616625" layer="1"/>
<rectangle x1="16.247175" y1="0.8440125" x2="17.25326875" y2="0.8616625" layer="1"/>
<rectangle x1="18.277021875" y1="0.8440125" x2="18.930103125" y2="0.8616625" layer="1"/>
<rectangle x1="0.1143" y1="0.8616625" x2="1.61461875" y2="0.8793125" layer="1"/>
<rectangle x1="2.267703125" y1="0.8616625" x2="3.750371875" y2="0.8793125" layer="1"/>
<rectangle x1="4.244596875" y1="0.8616625" x2="5.727265625" y2="0.8793125" layer="1"/>
<rectangle x1="6.415653125" y1="0.8616625" x2="7.915971875" y2="0.8793125" layer="1"/>
<rectangle x1="8.516103125" y1="0.8616625" x2="9.998771875" y2="0.8793125" layer="1"/>
<rectangle x1="10.492996875" y1="0.8616625" x2="11.975665625" y2="0.8793125" layer="1"/>
<rectangle x1="12.99941875" y1="0.8616625" x2="14.0055125" y2="0.8793125" layer="1"/>
<rectangle x1="14.870409375" y1="0.8616625" x2="15.841203125" y2="0.8793125" layer="1"/>
<rectangle x1="16.247175" y1="0.8616625" x2="17.21796875" y2="0.8793125" layer="1"/>
<rectangle x1="18.329975" y1="0.8616625" x2="18.94775" y2="0.8793125" layer="1"/>
<rectangle x1="0.13195" y1="0.8793125" x2="1.59696875" y2="0.8969625" layer="1"/>
<rectangle x1="2.267703125" y1="0.8793125" x2="3.697421875" y2="0.8969625" layer="1"/>
<rectangle x1="4.29755" y1="0.8793125" x2="5.74491875" y2="0.8969625" layer="1"/>
<rectangle x1="6.433303125" y1="0.8793125" x2="7.898321875" y2="0.8969625" layer="1"/>
<rectangle x1="8.498453125" y1="0.8793125" x2="9.945821875" y2="0.8969625" layer="1"/>
<rectangle x1="10.54595" y1="0.8793125" x2="11.97566875" y2="0.8969625" layer="1"/>
<rectangle x1="12.98176875" y1="0.8793125" x2="13.9702125" y2="0.8969625" layer="1"/>
<rectangle x1="14.905709375" y1="0.8793125" x2="15.841203125" y2="0.8969625" layer="1"/>
<rectangle x1="16.247175" y1="0.8793125" x2="17.18266875" y2="0.8969625" layer="1"/>
<rectangle x1="18.347625" y1="0.8793125" x2="18.96540625" y2="0.8969625" layer="1"/>
<rectangle x1="0.149603125" y1="0.896965625" x2="1.596971875" y2="0.914615625" layer="1"/>
<rectangle x1="2.250053125" y1="0.896965625" x2="3.662121875" y2="0.914615625" layer="1"/>
<rectangle x1="4.350503125" y1="0.896965625" x2="5.762571875" y2="0.914615625" layer="1"/>
<rectangle x1="6.450953125" y1="0.896965625" x2="7.880671875" y2="0.914615625" layer="1"/>
<rectangle x1="8.498453125" y1="0.896965625" x2="9.910521875" y2="0.914615625" layer="1"/>
<rectangle x1="10.581253125" y1="0.896965625" x2="11.993321875" y2="0.914615625" layer="1"/>
<rectangle x1="12.98176875" y1="0.896965625" x2="13.9525625" y2="0.914615625" layer="1"/>
<rectangle x1="14.9410125" y1="0.896965625" x2="15.84120625" y2="0.914615625" layer="1"/>
<rectangle x1="16.247175" y1="0.896965625" x2="17.16501875" y2="0.914615625" layer="1"/>
<rectangle x1="18.347625" y1="0.896965625" x2="18.96540625" y2="0.914615625" layer="1"/>
<rectangle x1="0.167253125" y1="0.914615625" x2="1.579321875" y2="0.932265625" layer="1"/>
<rectangle x1="2.250053125" y1="0.914615625" x2="3.626815625" y2="0.932265625" layer="1"/>
<rectangle x1="4.38580625" y1="0.914615625" x2="5.76256875" y2="0.932265625" layer="1"/>
<rectangle x1="6.46860625" y1="0.914615625" x2="7.86301875" y2="0.932265625" layer="1"/>
<rectangle x1="8.480803125" y1="0.914615625" x2="9.857565625" y2="0.932265625" layer="1"/>
<rectangle x1="10.616553125" y1="0.914615625" x2="12.010971875" y2="0.932265625" layer="1"/>
<rectangle x1="12.964115625" y1="0.914615625" x2="13.917259375" y2="0.932265625" layer="1"/>
<rectangle x1="14.9586625" y1="0.914615625" x2="15.84120625" y2="0.932265625" layer="1"/>
<rectangle x1="16.247175" y1="0.914615625" x2="17.1297125" y2="0.932265625" layer="1"/>
<rectangle x1="18.347625" y1="0.914615625" x2="18.98305625" y2="0.932265625" layer="1"/>
<rectangle x1="0.184903125" y1="0.932265625" x2="1.544015625" y2="0.949915625" layer="1"/>
<rectangle x1="2.232403125" y1="0.932265625" x2="3.591515625" y2="0.949915625" layer="1"/>
<rectangle x1="4.42110625" y1="0.932265625" x2="5.78021875" y2="0.949915625" layer="1"/>
<rectangle x1="6.48625625" y1="0.932265625" x2="7.84536875" y2="0.949915625" layer="1"/>
<rectangle x1="8.480803125" y1="0.932265625" x2="9.822265625" y2="0.949915625" layer="1"/>
<rectangle x1="10.65185625" y1="0.932265625" x2="12.01096875" y2="0.949915625" layer="1"/>
<rectangle x1="12.964115625" y1="0.932265625" x2="13.899609375" y2="0.949915625" layer="1"/>
<rectangle x1="14.9763125" y1="0.932265625" x2="15.84120625" y2="0.949915625" layer="1"/>
<rectangle x1="16.247175" y1="0.932265625" x2="17.1120625" y2="0.949915625" layer="1"/>
<rectangle x1="18.347625" y1="0.932265625" x2="18.98305625" y2="0.949915625" layer="1"/>
<rectangle x1="0.202553125" y1="0.949915625" x2="1.526365625" y2="0.967565625" layer="1"/>
<rectangle x1="2.232403125" y1="0.949915625" x2="3.556215625" y2="0.967565625" layer="1"/>
<rectangle x1="4.43875625" y1="0.949915625" x2="5.78021875" y2="0.967565625" layer="1"/>
<rectangle x1="6.50390625" y1="0.949915625" x2="7.82771875" y2="0.967565625" layer="1"/>
<rectangle x1="8.46315" y1="0.949915625" x2="9.8046125" y2="0.967565625" layer="1"/>
<rectangle x1="10.68715625" y1="0.949915625" x2="12.02861875" y2="0.967565625" layer="1"/>
<rectangle x1="12.946465625" y1="0.949915625" x2="13.881959375" y2="0.967565625" layer="1"/>
<rectangle x1="14.993965625" y1="0.949915625" x2="15.841203125" y2="0.967565625" layer="1"/>
<rectangle x1="16.247175" y1="0.949915625" x2="17.0944125" y2="0.967565625" layer="1"/>
<rectangle x1="18.347625" y1="0.949915625" x2="19.00070625" y2="0.967565625" layer="1"/>
<rectangle x1="0.23785625" y1="0.96756875" x2="1.5087125" y2="0.98521875" layer="1"/>
<rectangle x1="2.21475" y1="0.96756875" x2="3.5385625" y2="0.98521875" layer="1"/>
<rectangle x1="4.474059375" y1="0.96756875" x2="5.797871875" y2="0.98521875" layer="1"/>
<rectangle x1="6.539209375" y1="0.96756875" x2="7.792415625" y2="0.98521875" layer="1"/>
<rectangle x1="8.46315" y1="0.96756875" x2="9.7693125" y2="0.98521875" layer="1"/>
<rectangle x1="10.722459375" y1="0.96756875" x2="12.028621875" y2="0.98521875" layer="1"/>
<rectangle x1="12.946465625" y1="0.96756875" x2="13.864309375" y2="0.98521875" layer="1"/>
<rectangle x1="15.011615625" y1="0.96756875" x2="15.841203125" y2="0.98521875" layer="1"/>
<rectangle x1="16.247175" y1="0.96756875" x2="17.0767625" y2="0.98521875" layer="1"/>
<rectangle x1="18.347625" y1="0.96756875" x2="19.00070625" y2="0.98521875" layer="1"/>
<rectangle x1="0.27315625" y1="0.98521875" x2="1.4734125" y2="1.00286875" layer="1"/>
<rectangle x1="2.21475" y1="0.98521875" x2="3.5032625" y2="1.00286875" layer="1"/>
<rectangle x1="4.5093625" y1="0.98521875" x2="5.79786875" y2="1.00286875" layer="1"/>
<rectangle x1="6.574509375" y1="0.98521875" x2="7.757115625" y2="1.00286875" layer="1"/>
<rectangle x1="8.4455" y1="0.98521875" x2="9.7516625" y2="1.00286875" layer="1"/>
<rectangle x1="10.740109375" y1="0.98521875" x2="12.046271875" y2="1.00286875" layer="1"/>
<rectangle x1="12.928815625" y1="0.98521875" x2="13.846659375" y2="1.00286875" layer="1"/>
<rectangle x1="15.029265625" y1="0.98521875" x2="15.841203125" y2="1.00286875" layer="1"/>
<rectangle x1="16.247175" y1="0.98521875" x2="17.0591125" y2="1.00286875" layer="1"/>
<rectangle x1="18.347625" y1="0.98521875" x2="19.01835625" y2="1.00286875" layer="1"/>
<rectangle x1="0.308459375" y1="1.00286875" x2="1.420459375" y2="1.02051875" layer="1"/>
<rectangle x1="2.1971" y1="1.00286875" x2="3.4856125" y2="1.02051875" layer="1"/>
<rectangle x1="4.5270125" y1="1.00286875" x2="5.815525" y2="1.02051875" layer="1"/>
<rectangle x1="6.6098125" y1="1.00286875" x2="7.7218125" y2="1.02051875" layer="1"/>
<rectangle x1="8.4455" y1="1.00286875" x2="9.7163625" y2="1.02051875" layer="1"/>
<rectangle x1="10.7577625" y1="1.00286875" x2="12.04626875" y2="1.02051875" layer="1"/>
<rectangle x1="12.928815625" y1="1.00286875" x2="13.829009375" y2="1.02051875" layer="1"/>
<rectangle x1="15.046915625" y1="1.00286875" x2="15.841203125" y2="1.02051875" layer="1"/>
<rectangle x1="16.247175" y1="1.00286875" x2="17.0414625" y2="1.02051875" layer="1"/>
<rectangle x1="18.347625" y1="1.00286875" x2="19.01835625" y2="1.02051875" layer="1"/>
<rectangle x1="0.3437625" y1="1.020521875" x2="1.3851625" y2="1.038171875" layer="1"/>
<rectangle x1="2.1971" y1="1.020521875" x2="3.45030625" y2="1.038171875" layer="1"/>
<rectangle x1="4.5446625" y1="1.020521875" x2="5.815525" y2="1.038171875" layer="1"/>
<rectangle x1="6.6451125" y1="1.020521875" x2="7.6865125" y2="1.038171875" layer="1"/>
<rectangle x1="8.42785" y1="1.020521875" x2="9.69870625" y2="1.038171875" layer="1"/>
<rectangle x1="10.7930625" y1="1.020521875" x2="12.063925" y2="1.038171875" layer="1"/>
<rectangle x1="12.911165625" y1="1.020521875" x2="13.811353125" y2="1.038171875" layer="1"/>
<rectangle x1="15.06456875" y1="1.020521875" x2="15.84120625" y2="1.038171875" layer="1"/>
<rectangle x1="16.247175" y1="1.020521875" x2="17.0238125" y2="1.038171875" layer="1"/>
<rectangle x1="18.347625" y1="1.020521875" x2="19.03600625" y2="1.038171875" layer="1"/>
<rectangle x1="0.3437625" y1="1.038171875" x2="1.3851625" y2="1.055821875" layer="1"/>
<rectangle x1="2.17945" y1="1.038171875" x2="3.43265625" y2="1.055821875" layer="1"/>
<rectangle x1="4.5623125" y1="1.038171875" x2="5.815525" y2="1.055821875" layer="1"/>
<rectangle x1="6.6451125" y1="1.038171875" x2="7.6865125" y2="1.055821875" layer="1"/>
<rectangle x1="8.42785" y1="1.038171875" x2="9.68105625" y2="1.055821875" layer="1"/>
<rectangle x1="10.8107125" y1="1.038171875" x2="12.063925" y2="1.055821875" layer="1"/>
<rectangle x1="12.911165625" y1="1.038171875" x2="13.793703125" y2="1.055821875" layer="1"/>
<rectangle x1="15.08221875" y1="1.038171875" x2="15.84120625" y2="1.055821875" layer="1"/>
<rectangle x1="16.247175" y1="1.038171875" x2="17.0061625" y2="1.055821875" layer="1"/>
<rectangle x1="18.347625" y1="1.038171875" x2="19.03600625" y2="1.055821875" layer="1"/>
<rectangle x1="0.3437625" y1="1.055821875" x2="1.3851625" y2="1.073471875" layer="1"/>
<rectangle x1="2.17945" y1="1.055821875" x2="3.41500625" y2="1.073471875" layer="1"/>
<rectangle x1="4.597615625" y1="1.055821875" x2="5.833171875" y2="1.073471875" layer="1"/>
<rectangle x1="6.6451125" y1="1.055821875" x2="7.6865125" y2="1.073471875" layer="1"/>
<rectangle x1="8.410196875" y1="1.055821875" x2="9.663409375" y2="1.073471875" layer="1"/>
<rectangle x1="10.828365625" y1="1.055821875" x2="12.063921875" y2="1.073471875" layer="1"/>
<rectangle x1="12.8935125" y1="1.055821875" x2="13.77605625" y2="1.073471875" layer="1"/>
<rectangle x1="15.09986875" y1="1.055821875" x2="15.84120625" y2="1.073471875" layer="1"/>
<rectangle x1="16.247175" y1="1.055821875" x2="16.98850625" y2="1.073471875" layer="1"/>
<rectangle x1="18.347625" y1="1.055821875" x2="19.05365625" y2="1.073471875" layer="1"/>
<rectangle x1="0.3437625" y1="1.073471875" x2="1.3851625" y2="1.091121875" layer="1"/>
<rectangle x1="2.161796875" y1="1.073471875" x2="3.397353125" y2="1.091121875" layer="1"/>
<rectangle x1="4.615265625" y1="1.073471875" x2="5.833171875" y2="1.091121875" layer="1"/>
<rectangle x1="6.6451125" y1="1.073471875" x2="7.6865125" y2="1.091121875" layer="1"/>
<rectangle x1="8.410196875" y1="1.073471875" x2="9.628103125" y2="1.091121875" layer="1"/>
<rectangle x1="10.846015625" y1="1.073471875" x2="12.081571875" y2="1.091121875" layer="1"/>
<rectangle x1="12.8935125" y1="1.073471875" x2="13.77605625" y2="1.091121875" layer="1"/>
<rectangle x1="15.09986875" y1="1.073471875" x2="15.84120625" y2="1.091121875" layer="1"/>
<rectangle x1="16.247175" y1="1.073471875" x2="16.98850625" y2="1.091121875" layer="1"/>
<rectangle x1="18.347625" y1="1.073471875" x2="19.05365625" y2="1.091121875" layer="1"/>
<rectangle x1="0.3437625" y1="1.091125" x2="1.3851625" y2="1.108775" layer="1"/>
<rectangle x1="2.161796875" y1="1.091125" x2="3.379703125" y2="1.108775" layer="1"/>
<rectangle x1="4.632915625" y1="1.091125" x2="5.850821875" y2="1.108775" layer="1"/>
<rectangle x1="6.6451125" y1="1.091125" x2="7.6865125" y2="1.108775" layer="1"/>
<rectangle x1="8.392546875" y1="1.091125" x2="9.610453125" y2="1.108775" layer="1"/>
<rectangle x1="10.863665625" y1="1.091125" x2="12.081571875" y2="1.108775" layer="1"/>
<rectangle x1="12.8935125" y1="1.091125" x2="13.75840625" y2="1.108775" layer="1"/>
<rectangle x1="15.117521875" y1="1.091125" x2="15.841203125" y2="1.108775" layer="1"/>
<rectangle x1="16.247175" y1="1.091125" x2="16.97085625" y2="1.108775" layer="1"/>
<rectangle x1="18.347625" y1="1.091125" x2="19.05365625" y2="1.108775" layer="1"/>
<rectangle x1="0.3437625" y1="1.108775" x2="1.3851625" y2="1.126425" layer="1"/>
<rectangle x1="2.161796875" y1="1.108775" x2="3.362053125" y2="1.126425" layer="1"/>
<rectangle x1="4.65056875" y1="1.108775" x2="5.850825" y2="1.126425" layer="1"/>
<rectangle x1="6.6451125" y1="1.108775" x2="7.6865125" y2="1.126425" layer="1"/>
<rectangle x1="8.392546875" y1="1.108775" x2="9.592803125" y2="1.126425" layer="1"/>
<rectangle x1="10.881315625" y1="1.108775" x2="12.099221875" y2="1.126425" layer="1"/>
<rectangle x1="12.8758625" y1="1.108775" x2="13.74075" y2="1.126425" layer="1"/>
<rectangle x1="14.358534375" y1="1.108775" x2="14.517390625" y2="1.126425" layer="1"/>
<rectangle x1="15.135171875" y1="1.108775" x2="15.841203125" y2="1.126425" layer="1"/>
<rectangle x1="16.247175" y1="1.108775" x2="16.95320625" y2="1.126425" layer="1"/>
<rectangle x1="17.606290625" y1="1.108775" x2="17.853403125" y2="1.126425" layer="1"/>
<rectangle x1="18.347625" y1="1.108775" x2="19.07130625" y2="1.126425" layer="1"/>
<rectangle x1="0.3437625" y1="1.126425" x2="1.3851625" y2="1.144075" layer="1"/>
<rectangle x1="2.144146875" y1="1.126425" x2="3.344403125" y2="1.144075" layer="1"/>
<rectangle x1="4.66821875" y1="1.126425" x2="5.850825" y2="1.144075" layer="1"/>
<rectangle x1="6.6451125" y1="1.126425" x2="7.6865125" y2="1.144075" layer="1"/>
<rectangle x1="8.392546875" y1="1.126425" x2="9.575153125" y2="1.144075" layer="1"/>
<rectangle x1="10.89896875" y1="1.126425" x2="12.099225" y2="1.144075" layer="1"/>
<rectangle x1="12.8758625" y1="1.126425" x2="13.74075" y2="1.144075" layer="1"/>
<rectangle x1="14.28793125" y1="1.126425" x2="14.58799375" y2="1.144075" layer="1"/>
<rectangle x1="15.135171875" y1="1.126425" x2="15.841203125" y2="1.144075" layer="1"/>
<rectangle x1="16.247175" y1="1.126425" x2="16.95320625" y2="1.144075" layer="1"/>
<rectangle x1="17.5356875" y1="1.126425" x2="17.94165625" y2="1.144075" layer="1"/>
<rectangle x1="18.347625" y1="1.126425" x2="19.07130625" y2="1.144075" layer="1"/>
<rectangle x1="0.3437625" y1="1.144075" x2="1.3851625" y2="1.161725" layer="1"/>
<rectangle x1="2.144146875" y1="1.144075" x2="3.326753125" y2="1.161725" layer="1"/>
<rectangle x1="4.68586875" y1="1.144075" x2="5.868475" y2="1.161725" layer="1"/>
<rectangle x1="6.6451125" y1="1.144075" x2="7.6865125" y2="1.161725" layer="1"/>
<rectangle x1="8.374896875" y1="1.144075" x2="9.575153125" y2="1.161725" layer="1"/>
<rectangle x1="10.91661875" y1="1.144075" x2="12.099225" y2="1.161725" layer="1"/>
<rectangle x1="12.8582125" y1="1.144075" x2="13.7231" y2="1.161725" layer="1"/>
<rectangle x1="14.252628125" y1="1.144075" x2="14.623296875" y2="1.161725" layer="1"/>
<rectangle x1="15.152821875" y1="1.144075" x2="15.841203125" y2="1.161725" layer="1"/>
<rectangle x1="16.247175" y1="1.144075" x2="16.93555625" y2="1.161725" layer="1"/>
<rectangle x1="17.482734375" y1="1.144075" x2="17.941653125" y2="1.161725" layer="1"/>
<rectangle x1="18.347625" y1="1.144075" x2="19.07130625" y2="1.161725" layer="1"/>
<rectangle x1="0.3437625" y1="1.161728125" x2="1.3851625" y2="1.179378125" layer="1"/>
<rectangle x1="2.126496875" y1="1.161728125" x2="3.309103125" y2="1.179378125" layer="1"/>
<rectangle x1="4.68586875" y1="1.161728125" x2="5.868475" y2="1.179378125" layer="1"/>
<rectangle x1="6.6451125" y1="1.161728125" x2="7.6865125" y2="1.179378125" layer="1"/>
<rectangle x1="8.374896875" y1="1.161728125" x2="9.557503125" y2="1.179378125" layer="1"/>
<rectangle x1="10.93426875" y1="1.161728125" x2="12.116875" y2="1.179378125" layer="1"/>
<rectangle x1="12.8582125" y1="1.161728125" x2="13.7231" y2="1.179378125" layer="1"/>
<rectangle x1="14.217328125" y1="1.161728125" x2="14.658596875" y2="1.179378125" layer="1"/>
<rectangle x1="15.152821875" y1="1.161728125" x2="15.841203125" y2="1.179378125" layer="1"/>
<rectangle x1="16.247175" y1="1.161728125" x2="16.93555625" y2="1.179378125" layer="1"/>
<rectangle x1="17.44743125" y1="1.161728125" x2="17.94165625" y2="1.179378125" layer="1"/>
<rectangle x1="18.347625" y1="1.161728125" x2="19.0889625" y2="1.179378125" layer="1"/>
<rectangle x1="0.3437625" y1="1.179378125" x2="1.3851625" y2="1.197028125" layer="1"/>
<rectangle x1="2.126496875" y1="1.179378125" x2="3.291453125" y2="1.197028125" layer="1"/>
<rectangle x1="4.703521875" y1="1.179378125" x2="5.868471875" y2="1.197028125" layer="1"/>
<rectangle x1="6.6451125" y1="1.179378125" x2="7.6865125" y2="1.197028125" layer="1"/>
<rectangle x1="8.374896875" y1="1.179378125" x2="9.539853125" y2="1.197028125" layer="1"/>
<rectangle x1="10.951921875" y1="1.179378125" x2="12.116871875" y2="1.197028125" layer="1"/>
<rectangle x1="12.8582125" y1="1.179378125" x2="13.70545" y2="1.197028125" layer="1"/>
<rectangle x1="14.199675" y1="1.179378125" x2="14.67625" y2="1.197028125" layer="1"/>
<rectangle x1="15.170471875" y1="1.179378125" x2="15.841203125" y2="1.197028125" layer="1"/>
<rectangle x1="16.247175" y1="1.179378125" x2="16.91790625" y2="1.197028125" layer="1"/>
<rectangle x1="17.42978125" y1="1.179378125" x2="17.94165625" y2="1.197028125" layer="1"/>
<rectangle x1="18.347625" y1="1.179378125" x2="19.0889625" y2="1.197028125" layer="1"/>
<rectangle x1="0.3437625" y1="1.197028125" x2="1.3851625" y2="1.214678125" layer="1"/>
<rectangle x1="2.126496875" y1="1.197028125" x2="3.291453125" y2="1.214678125" layer="1"/>
<rectangle x1="4.721171875" y1="1.197028125" x2="5.886128125" y2="1.214678125" layer="1"/>
<rectangle x1="6.6451125" y1="1.197028125" x2="7.6865125" y2="1.214678125" layer="1"/>
<rectangle x1="8.357246875" y1="1.197028125" x2="9.522203125" y2="1.214678125" layer="1"/>
<rectangle x1="10.969571875" y1="1.197028125" x2="12.116871875" y2="1.214678125" layer="1"/>
<rectangle x1="12.8405625" y1="1.197028125" x2="13.70545" y2="1.214678125" layer="1"/>
<rectangle x1="14.182025" y1="1.197028125" x2="14.71155" y2="1.214678125" layer="1"/>
<rectangle x1="15.170471875" y1="1.197028125" x2="15.841203125" y2="1.214678125" layer="1"/>
<rectangle x1="16.247175" y1="1.197028125" x2="16.91790625" y2="1.214678125" layer="1"/>
<rectangle x1="17.41213125" y1="1.197028125" x2="17.94165625" y2="1.214678125" layer="1"/>
<rectangle x1="18.347625" y1="1.197028125" x2="19.0889625" y2="1.214678125" layer="1"/>
<rectangle x1="0.3437625" y1="1.214678125" x2="1.3851625" y2="1.232328125" layer="1"/>
<rectangle x1="2.126496875" y1="1.214678125" x2="3.273803125" y2="1.232328125" layer="1"/>
<rectangle x1="4.738821875" y1="1.214678125" x2="5.886128125" y2="1.232328125" layer="1"/>
<rectangle x1="6.6451125" y1="1.214678125" x2="7.6865125" y2="1.232328125" layer="1"/>
<rectangle x1="8.357246875" y1="1.214678125" x2="9.504546875" y2="1.232328125" layer="1"/>
<rectangle x1="10.969571875" y1="1.214678125" x2="12.134528125" y2="1.232328125" layer="1"/>
<rectangle x1="12.8405625" y1="1.214678125" x2="13.6878" y2="1.232328125" layer="1"/>
<rectangle x1="14.164375" y1="1.214678125" x2="14.71155" y2="1.232328125" layer="1"/>
<rectangle x1="15.188125" y1="1.214678125" x2="15.84120625" y2="1.232328125" layer="1"/>
<rectangle x1="16.247175" y1="1.214678125" x2="16.90025625" y2="1.232328125" layer="1"/>
<rectangle x1="17.376828125" y1="1.214678125" x2="17.941653125" y2="1.232328125" layer="1"/>
<rectangle x1="18.347625" y1="1.214678125" x2="19.1066125" y2="1.232328125" layer="1"/>
<rectangle x1="0.3437625" y1="1.23233125" x2="1.3851625" y2="1.24998125" layer="1"/>
<rectangle x1="2.108846875" y1="1.23233125" x2="3.256146875" y2="1.24998125" layer="1"/>
<rectangle x1="4.756471875" y1="1.23233125" x2="5.886128125" y2="1.24998125" layer="1"/>
<rectangle x1="6.6451125" y1="1.23233125" x2="7.6865125" y2="1.24998125" layer="1"/>
<rectangle x1="8.357246875" y1="1.23233125" x2="9.504546875" y2="1.24998125" layer="1"/>
<rectangle x1="10.987221875" y1="1.23233125" x2="12.134528125" y2="1.24998125" layer="1"/>
<rectangle x1="12.8405625" y1="1.23233125" x2="13.6878" y2="1.24998125" layer="1"/>
<rectangle x1="14.146725" y1="1.23233125" x2="14.7292" y2="1.24998125" layer="1"/>
<rectangle x1="15.188125" y1="1.23233125" x2="15.84120625" y2="1.24998125" layer="1"/>
<rectangle x1="16.247175" y1="1.23233125" x2="16.90025625" y2="1.24998125" layer="1"/>
<rectangle x1="17.376828125" y1="1.23233125" x2="17.941653125" y2="1.24998125" layer="1"/>
<rectangle x1="18.347625" y1="1.23233125" x2="19.1066125" y2="1.24998125" layer="1"/>
<rectangle x1="0.3437625" y1="1.24998125" x2="1.3851625" y2="1.26763125" layer="1"/>
<rectangle x1="2.108846875" y1="1.24998125" x2="3.238496875" y2="1.26763125" layer="1"/>
<rectangle x1="4.756471875" y1="1.24998125" x2="5.903778125" y2="1.26763125" layer="1"/>
<rectangle x1="6.6451125" y1="1.24998125" x2="7.6865125" y2="1.26763125" layer="1"/>
<rectangle x1="8.33959375" y1="1.24998125" x2="9.4869" y2="1.26763125" layer="1"/>
<rectangle x1="11.004871875" y1="1.24998125" x2="12.134528125" y2="1.26763125" layer="1"/>
<rectangle x1="12.822909375" y1="1.24998125" x2="13.687803125" y2="1.26763125" layer="1"/>
<rectangle x1="14.129071875" y1="1.24998125" x2="14.746853125" y2="1.26763125" layer="1"/>
<rectangle x1="15.205775" y1="1.24998125" x2="15.84120625" y2="1.26763125" layer="1"/>
<rectangle x1="16.247175" y1="1.24998125" x2="16.88260625" y2="1.26763125" layer="1"/>
<rectangle x1="17.359178125" y1="1.24998125" x2="17.941653125" y2="1.26763125" layer="1"/>
<rectangle x1="18.347625" y1="1.24998125" x2="19.1066125" y2="1.26763125" layer="1"/>
<rectangle x1="0.3437625" y1="1.26763125" x2="1.3851625" y2="1.28528125" layer="1"/>
<rectangle x1="2.108846875" y1="1.26763125" x2="3.238496875" y2="1.28528125" layer="1"/>
<rectangle x1="4.774125" y1="1.26763125" x2="5.903775" y2="1.28528125" layer="1"/>
<rectangle x1="6.6451125" y1="1.26763125" x2="7.6865125" y2="1.28528125" layer="1"/>
<rectangle x1="8.33959375" y1="1.26763125" x2="9.46925" y2="1.28528125" layer="1"/>
<rectangle x1="11.004871875" y1="1.26763125" x2="12.134528125" y2="1.28528125" layer="1"/>
<rectangle x1="12.822909375" y1="1.26763125" x2="13.670146875" y2="1.28528125" layer="1"/>
<rectangle x1="14.129071875" y1="1.26763125" x2="14.764503125" y2="1.28528125" layer="1"/>
<rectangle x1="15.205775" y1="1.26763125" x2="15.84120625" y2="1.28528125" layer="1"/>
<rectangle x1="16.247175" y1="1.26763125" x2="16.88260625" y2="1.28528125" layer="1"/>
<rectangle x1="17.341528125" y1="1.26763125" x2="17.941653125" y2="1.28528125" layer="1"/>
<rectangle x1="18.347625" y1="1.26763125" x2="19.1242625" y2="1.28528125" layer="1"/>
<rectangle x1="0.3437625" y1="1.285284375" x2="1.3851625" y2="1.302934375" layer="1"/>
<rectangle x1="2.09119375" y1="1.285284375" x2="3.22085" y2="1.302934375" layer="1"/>
<rectangle x1="4.774125" y1="1.285284375" x2="5.903775" y2="1.302934375" layer="1"/>
<rectangle x1="6.6451125" y1="1.285284375" x2="7.6865125" y2="1.302934375" layer="1"/>
<rectangle x1="8.33959375" y1="1.285284375" x2="9.46925" y2="1.302934375" layer="1"/>
<rectangle x1="11.022525" y1="1.285284375" x2="12.152175" y2="1.302934375" layer="1"/>
<rectangle x1="12.822909375" y1="1.285284375" x2="13.670146875" y2="1.302934375" layer="1"/>
<rectangle x1="14.111421875" y1="1.285284375" x2="14.764503125" y2="1.302934375" layer="1"/>
<rectangle x1="15.205775" y1="1.285284375" x2="15.84120625" y2="1.302934375" layer="1"/>
<rectangle x1="16.247175" y1="1.285284375" x2="16.88260625" y2="1.302934375" layer="1"/>
<rectangle x1="17.323875" y1="1.285284375" x2="17.94165625" y2="1.302934375" layer="1"/>
<rectangle x1="18.347625" y1="1.285284375" x2="19.1242625" y2="1.302934375" layer="1"/>
<rectangle x1="0.3437625" y1="1.302934375" x2="1.3851625" y2="1.320584375" layer="1"/>
<rectangle x1="2.09119375" y1="1.302934375" x2="3.22085" y2="1.320584375" layer="1"/>
<rectangle x1="4.791775" y1="1.302934375" x2="5.903775" y2="1.320584375" layer="1"/>
<rectangle x1="6.6451125" y1="1.302934375" x2="7.6865125" y2="1.320584375" layer="1"/>
<rectangle x1="8.33959375" y1="1.302934375" x2="9.45159375" y2="1.320584375" layer="1"/>
<rectangle x1="11.040175" y1="1.302934375" x2="12.152175" y2="1.320584375" layer="1"/>
<rectangle x1="12.822909375" y1="1.302934375" x2="13.670146875" y2="1.320584375" layer="1"/>
<rectangle x1="14.093771875" y1="1.302934375" x2="14.782153125" y2="1.320584375" layer="1"/>
<rectangle x1="15.223425" y1="1.302934375" x2="15.84120625" y2="1.320584375" layer="1"/>
<rectangle x1="16.247175" y1="1.302934375" x2="16.86495" y2="1.320584375" layer="1"/>
<rectangle x1="17.323875" y1="1.302934375" x2="17.94165625" y2="1.320584375" layer="1"/>
<rectangle x1="18.347625" y1="1.302934375" x2="19.1242625" y2="1.320584375" layer="1"/>
<rectangle x1="0.3437625" y1="1.320584375" x2="1.3851625" y2="1.338234375" layer="1"/>
<rectangle x1="2.09119375" y1="1.320584375" x2="3.20319375" y2="1.338234375" layer="1"/>
<rectangle x1="4.809425" y1="1.320584375" x2="5.921425" y2="1.338234375" layer="1"/>
<rectangle x1="6.6451125" y1="1.320584375" x2="7.6865125" y2="1.338234375" layer="1"/>
<rectangle x1="8.32194375" y1="1.320584375" x2="9.45159375" y2="1.338234375" layer="1"/>
<rectangle x1="11.040175" y1="1.320584375" x2="12.152175" y2="1.338234375" layer="1"/>
<rectangle x1="12.805259375" y1="1.320584375" x2="13.652496875" y2="1.338234375" layer="1"/>
<rectangle x1="14.093771875" y1="1.320584375" x2="14.782153125" y2="1.338234375" layer="1"/>
<rectangle x1="15.223425" y1="1.320584375" x2="15.84120625" y2="1.338234375" layer="1"/>
<rectangle x1="16.247175" y1="1.320584375" x2="16.86495" y2="1.338234375" layer="1"/>
<rectangle x1="17.306225" y1="1.320584375" x2="17.94165625" y2="1.338234375" layer="1"/>
<rectangle x1="18.347625" y1="1.320584375" x2="19.1242625" y2="1.338234375" layer="1"/>
<rectangle x1="0.3437625" y1="1.338234375" x2="1.3851625" y2="1.355884375" layer="1"/>
<rectangle x1="2.09119375" y1="1.338234375" x2="3.20319375" y2="1.355884375" layer="1"/>
<rectangle x1="4.809425" y1="1.338234375" x2="5.921425" y2="1.355884375" layer="1"/>
<rectangle x1="6.6451125" y1="1.338234375" x2="7.6865125" y2="1.355884375" layer="1"/>
<rectangle x1="8.32194375" y1="1.338234375" x2="9.43394375" y2="1.355884375" layer="1"/>
<rectangle x1="11.057825" y1="1.338234375" x2="12.152175" y2="1.355884375" layer="1"/>
<rectangle x1="12.805259375" y1="1.338234375" x2="13.652496875" y2="1.355884375" layer="1"/>
<rectangle x1="14.093771875" y1="1.338234375" x2="14.799803125" y2="1.355884375" layer="1"/>
<rectangle x1="15.223425" y1="1.338234375" x2="15.84120625" y2="1.355884375" layer="1"/>
<rectangle x1="16.247175" y1="1.338234375" x2="16.86495" y2="1.355884375" layer="1"/>
<rectangle x1="17.306225" y1="1.338234375" x2="17.94165625" y2="1.355884375" layer="1"/>
<rectangle x1="18.347625" y1="1.338234375" x2="19.1419125" y2="1.355884375" layer="1"/>
<rectangle x1="0.3437625" y1="1.3558875" x2="1.3851625" y2="1.3735375" layer="1"/>
<rectangle x1="2.07354375" y1="1.3558875" x2="3.18554375" y2="1.3735375" layer="1"/>
<rectangle x1="4.827075" y1="1.3558875" x2="5.921425" y2="1.3735375" layer="1"/>
<rectangle x1="6.6451125" y1="1.3558875" x2="7.6865125" y2="1.3735375" layer="1"/>
<rectangle x1="8.32194375" y1="1.3558875" x2="9.43394375" y2="1.3735375" layer="1"/>
<rectangle x1="11.057825" y1="1.3558875" x2="12.169825" y2="1.3735375" layer="1"/>
<rectangle x1="12.805259375" y1="1.3558875" x2="13.652496875" y2="1.3735375" layer="1"/>
<rectangle x1="14.076121875" y1="1.3558875" x2="14.799803125" y2="1.3735375" layer="1"/>
<rectangle x1="15.223425" y1="1.3558875" x2="15.84120625" y2="1.3735375" layer="1"/>
<rectangle x1="16.247175" y1="1.3558875" x2="16.8473" y2="1.3735375" layer="1"/>
<rectangle x1="17.288575" y1="1.3558875" x2="17.94165625" y2="1.3735375" layer="1"/>
<rectangle x1="18.347625" y1="1.3558875" x2="19.1419125" y2="1.3735375" layer="1"/>
<rectangle x1="0.3437625" y1="1.3735375" x2="1.3851625" y2="1.3911875" layer="1"/>
<rectangle x1="2.07354375" y1="1.3735375" x2="3.18554375" y2="1.3911875" layer="1"/>
<rectangle x1="4.827075" y1="1.3735375" x2="5.921425" y2="1.3911875" layer="1"/>
<rectangle x1="6.6451125" y1="1.3735375" x2="7.6865125" y2="1.3911875" layer="1"/>
<rectangle x1="8.32194375" y1="1.3735375" x2="9.41629375" y2="1.3911875" layer="1"/>
<rectangle x1="11.075475" y1="1.3735375" x2="12.169825" y2="1.3911875" layer="1"/>
<rectangle x1="12.805259375" y1="1.3735375" x2="13.634846875" y2="1.3911875" layer="1"/>
<rectangle x1="14.076121875" y1="1.3735375" x2="14.799803125" y2="1.3911875" layer="1"/>
<rectangle x1="15.241075" y1="1.3735375" x2="15.84120625" y2="1.3911875" layer="1"/>
<rectangle x1="16.247175" y1="1.3735375" x2="16.8473" y2="1.3911875" layer="1"/>
<rectangle x1="17.288575" y1="1.3735375" x2="17.94165625" y2="1.3911875" layer="1"/>
<rectangle x1="18.347625" y1="1.3735375" x2="19.1419125" y2="1.3911875" layer="1"/>
<rectangle x1="0.3437625" y1="1.3911875" x2="1.3851625" y2="1.4088375" layer="1"/>
<rectangle x1="2.07354375" y1="1.3911875" x2="3.16789375" y2="1.4088375" layer="1"/>
<rectangle x1="4.844728125" y1="1.3911875" x2="5.939078125" y2="1.4088375" layer="1"/>
<rectangle x1="6.6451125" y1="1.3911875" x2="7.6865125" y2="1.4088375" layer="1"/>
<rectangle x1="8.32194375" y1="1.3911875" x2="9.41629375" y2="1.4088375" layer="1"/>
<rectangle x1="11.075475" y1="1.3911875" x2="12.169825" y2="1.4088375" layer="1"/>
<rectangle x1="12.805259375" y1="1.3911875" x2="13.634846875" y2="1.4088375" layer="1"/>
<rectangle x1="14.05846875" y1="1.3911875" x2="14.81745625" y2="1.4088375" layer="1"/>
<rectangle x1="15.241075" y1="1.3911875" x2="15.84120625" y2="1.4088375" layer="1"/>
<rectangle x1="16.247175" y1="1.3911875" x2="16.8473" y2="1.4088375" layer="1"/>
<rectangle x1="17.270925" y1="1.3911875" x2="17.94165625" y2="1.4088375" layer="1"/>
<rectangle x1="18.347625" y1="1.3911875" x2="19.1419125" y2="1.4088375" layer="1"/>
<rectangle x1="0.3437625" y1="1.4088375" x2="1.3851625" y2="1.4264875" layer="1"/>
<rectangle x1="2.07354375" y1="1.4088375" x2="3.16789375" y2="1.4264875" layer="1"/>
<rectangle x1="4.844728125" y1="1.4088375" x2="5.939078125" y2="1.4264875" layer="1"/>
<rectangle x1="6.6451125" y1="1.4088375" x2="7.6865125" y2="1.4264875" layer="1"/>
<rectangle x1="8.30429375" y1="1.4088375" x2="9.39864375" y2="1.4264875" layer="1"/>
<rectangle x1="11.075475" y1="1.4088375" x2="12.169825" y2="1.4264875" layer="1"/>
<rectangle x1="12.787609375" y1="1.4088375" x2="13.634846875" y2="1.4264875" layer="1"/>
<rectangle x1="14.05846875" y1="1.4088375" x2="14.81745625" y2="1.4264875" layer="1"/>
<rectangle x1="15.241075" y1="1.4088375" x2="15.84120625" y2="1.4264875" layer="1"/>
<rectangle x1="16.247175" y1="1.4088375" x2="16.8473" y2="1.4264875" layer="1"/>
<rectangle x1="17.270925" y1="1.4088375" x2="17.94165625" y2="1.4264875" layer="1"/>
<rectangle x1="18.347625" y1="1.4088375" x2="19.1595625" y2="1.4264875" layer="1"/>
<rectangle x1="0.3437625" y1="1.426490625" x2="1.3851625" y2="1.444140625" layer="1"/>
<rectangle x1="2.07354375" y1="1.426490625" x2="3.15024375" y2="1.444140625" layer="1"/>
<rectangle x1="4.844728125" y1="1.426490625" x2="5.939078125" y2="1.444140625" layer="1"/>
<rectangle x1="6.6451125" y1="1.426490625" x2="7.6865125" y2="1.444140625" layer="1"/>
<rectangle x1="8.30429375" y1="1.426490625" x2="9.39864375" y2="1.444140625" layer="1"/>
<rectangle x1="11.093128125" y1="1.426490625" x2="12.169828125" y2="1.444140625" layer="1"/>
<rectangle x1="12.787609375" y1="1.426490625" x2="13.634846875" y2="1.444140625" layer="1"/>
<rectangle x1="14.05846875" y1="1.426490625" x2="14.81745625" y2="1.444140625" layer="1"/>
<rectangle x1="15.241075" y1="1.426490625" x2="15.84120625" y2="1.444140625" layer="1"/>
<rectangle x1="16.247175" y1="1.426490625" x2="16.8473" y2="1.444140625" layer="1"/>
<rectangle x1="17.270925" y1="1.426490625" x2="17.94165625" y2="1.444140625" layer="1"/>
<rectangle x1="18.347625" y1="1.426490625" x2="19.1595625" y2="1.444140625" layer="1"/>
<rectangle x1="0.3437625" y1="1.444140625" x2="1.3851625" y2="1.461790625" layer="1"/>
<rectangle x1="2.07354375" y1="1.444140625" x2="3.15024375" y2="1.461790625" layer="1"/>
<rectangle x1="4.862378125" y1="1.444140625" x2="5.939078125" y2="1.461790625" layer="1"/>
<rectangle x1="6.6451125" y1="1.444140625" x2="7.6865125" y2="1.461790625" layer="1"/>
<rectangle x1="8.30429375" y1="1.444140625" x2="9.38099375" y2="1.461790625" layer="1"/>
<rectangle x1="11.093128125" y1="1.444140625" x2="12.187478125" y2="1.461790625" layer="1"/>
<rectangle x1="12.787609375" y1="1.444140625" x2="13.634846875" y2="1.461790625" layer="1"/>
<rectangle x1="14.05846875" y1="1.444140625" x2="14.81745625" y2="1.461790625" layer="1"/>
<rectangle x1="15.258728125" y1="1.444140625" x2="15.841203125" y2="1.461790625" layer="1"/>
<rectangle x1="16.247175" y1="1.444140625" x2="16.82965" y2="1.461790625" layer="1"/>
<rectangle x1="17.270925" y1="1.444140625" x2="17.94165625" y2="1.461790625" layer="1"/>
<rectangle x1="18.347625" y1="1.444140625" x2="19.1595625" y2="1.461790625" layer="1"/>
<rectangle x1="0.3437625" y1="1.461790625" x2="1.3851625" y2="1.479440625" layer="1"/>
<rectangle x1="2.05589375" y1="1.461790625" x2="3.15024375" y2="1.479440625" layer="1"/>
<rectangle x1="4.862378125" y1="1.461790625" x2="5.939078125" y2="1.479440625" layer="1"/>
<rectangle x1="6.6451125" y1="1.461790625" x2="7.6865125" y2="1.479440625" layer="1"/>
<rectangle x1="8.30429375" y1="1.461790625" x2="9.38099375" y2="1.479440625" layer="1"/>
<rectangle x1="11.110778125" y1="1.461790625" x2="12.187478125" y2="1.479440625" layer="1"/>
<rectangle x1="12.787609375" y1="1.461790625" x2="13.617196875" y2="1.479440625" layer="1"/>
<rectangle x1="14.04081875" y1="1.461790625" x2="14.83510625" y2="1.479440625" layer="1"/>
<rectangle x1="15.258728125" y1="1.461790625" x2="15.841203125" y2="1.479440625" layer="1"/>
<rectangle x1="16.247175" y1="1.461790625" x2="16.82965" y2="1.479440625" layer="1"/>
<rectangle x1="17.253271875" y1="1.461790625" x2="17.941653125" y2="1.479440625" layer="1"/>
<rectangle x1="18.347625" y1="1.461790625" x2="19.1595625" y2="1.479440625" layer="1"/>
<rectangle x1="0.3437625" y1="1.47944375" x2="1.3851625" y2="1.49709375" layer="1"/>
<rectangle x1="2.05589375" y1="1.47944375" x2="3.13259375" y2="1.49709375" layer="1"/>
<rectangle x1="4.862378125" y1="1.47944375" x2="5.939078125" y2="1.49709375" layer="1"/>
<rectangle x1="6.6451125" y1="1.47944375" x2="7.6865125" y2="1.49709375" layer="1"/>
<rectangle x1="8.30429375" y1="1.47944375" x2="9.38099375" y2="1.49709375" layer="1"/>
<rectangle x1="11.110778125" y1="1.47944375" x2="12.187478125" y2="1.49709375" layer="1"/>
<rectangle x1="12.787609375" y1="1.47944375" x2="13.617196875" y2="1.49709375" layer="1"/>
<rectangle x1="14.04081875" y1="1.47944375" x2="14.83510625" y2="1.49709375" layer="1"/>
<rectangle x1="15.258728125" y1="1.47944375" x2="15.841203125" y2="1.49709375" layer="1"/>
<rectangle x1="16.247175" y1="1.47944375" x2="16.82965" y2="1.49709375" layer="1"/>
<rectangle x1="17.253271875" y1="1.47944375" x2="17.941653125" y2="1.49709375" layer="1"/>
<rectangle x1="18.347625" y1="1.47944375" x2="19.1595625" y2="1.49709375" layer="1"/>
<rectangle x1="0.3437625" y1="1.49709375" x2="1.3851625" y2="1.51474375" layer="1"/>
<rectangle x1="2.05589375" y1="1.49709375" x2="3.13259375" y2="1.51474375" layer="1"/>
<rectangle x1="4.880028125" y1="1.49709375" x2="5.956728125" y2="1.51474375" layer="1"/>
<rectangle x1="6.6451125" y1="1.49709375" x2="7.6865125" y2="1.51474375" layer="1"/>
<rectangle x1="8.30429375" y1="1.49709375" x2="9.36334375" y2="1.51474375" layer="1"/>
<rectangle x1="11.110778125" y1="1.49709375" x2="12.187478125" y2="1.51474375" layer="1"/>
<rectangle x1="12.787609375" y1="1.49709375" x2="13.617196875" y2="1.51474375" layer="1"/>
<rectangle x1="14.04081875" y1="1.49709375" x2="14.83510625" y2="1.51474375" layer="1"/>
<rectangle x1="15.258728125" y1="1.49709375" x2="15.841203125" y2="1.51474375" layer="1"/>
<rectangle x1="16.247175" y1="1.49709375" x2="16.82965" y2="1.51474375" layer="1"/>
<rectangle x1="17.253271875" y1="1.49709375" x2="17.606290625" y2="1.51474375" layer="1"/>
<rectangle x1="18.347625" y1="1.49709375" x2="19.1595625" y2="1.51474375" layer="1"/>
<rectangle x1="0.3437625" y1="1.51474375" x2="1.3851625" y2="1.53239375" layer="1"/>
<rectangle x1="2.05589375" y1="1.51474375" x2="3.13259375" y2="1.53239375" layer="1"/>
<rectangle x1="4.880028125" y1="1.51474375" x2="5.956728125" y2="1.53239375" layer="1"/>
<rectangle x1="6.6451125" y1="1.51474375" x2="7.6865125" y2="1.53239375" layer="1"/>
<rectangle x1="8.30429375" y1="1.51474375" x2="9.36334375" y2="1.53239375" layer="1"/>
<rectangle x1="11.110778125" y1="1.51474375" x2="12.187478125" y2="1.53239375" layer="1"/>
<rectangle x1="12.76995625" y1="1.51474375" x2="13.61719375" y2="1.53239375" layer="1"/>
<rectangle x1="14.04081875" y1="1.51474375" x2="14.83510625" y2="1.53239375" layer="1"/>
<rectangle x1="15.258728125" y1="1.51474375" x2="15.841203125" y2="1.53239375" layer="1"/>
<rectangle x1="16.247175" y1="1.51474375" x2="16.82965" y2="1.53239375" layer="1"/>
<rectangle x1="17.253271875" y1="1.51474375" x2="17.588634375" y2="1.53239375" layer="1"/>
<rectangle x1="18.347625" y1="1.51474375" x2="19.1772125" y2="1.53239375" layer="1"/>
<rectangle x1="0.3437625" y1="1.53239375" x2="1.3851625" y2="1.55004375" layer="1"/>
<rectangle x1="2.05589375" y1="1.53239375" x2="3.11494375" y2="1.55004375" layer="1"/>
<rectangle x1="4.880028125" y1="1.53239375" x2="5.956728125" y2="1.55004375" layer="1"/>
<rectangle x1="6.6451125" y1="1.53239375" x2="7.6865125" y2="1.55004375" layer="1"/>
<rectangle x1="8.28664375" y1="1.53239375" x2="9.36334375" y2="1.55004375" layer="1"/>
<rectangle x1="11.128428125" y1="1.53239375" x2="12.187478125" y2="1.55004375" layer="1"/>
<rectangle x1="12.76995625" y1="1.53239375" x2="13.61719375" y2="1.55004375" layer="1"/>
<rectangle x1="14.04081875" y1="1.53239375" x2="14.83510625" y2="1.55004375" layer="1"/>
<rectangle x1="15.258728125" y1="1.53239375" x2="15.841203125" y2="1.55004375" layer="1"/>
<rectangle x1="16.247175" y1="1.53239375" x2="16.82965" y2="1.55004375" layer="1"/>
<rectangle x1="17.235621875" y1="1.53239375" x2="17.588634375" y2="1.55004375" layer="1"/>
<rectangle x1="18.347625" y1="1.53239375" x2="19.1772125" y2="1.55004375" layer="1"/>
<rectangle x1="0.3437625" y1="1.550046875" x2="1.3851625" y2="1.567696875" layer="1"/>
<rectangle x1="2.05589375" y1="1.550046875" x2="3.11494375" y2="1.567696875" layer="1"/>
<rectangle x1="4.880028125" y1="1.550046875" x2="5.956728125" y2="1.567696875" layer="1"/>
<rectangle x1="6.6451125" y1="1.550046875" x2="7.6865125" y2="1.567696875" layer="1"/>
<rectangle x1="8.28664375" y1="1.550046875" x2="9.36334375" y2="1.567696875" layer="1"/>
<rectangle x1="11.128428125" y1="1.550046875" x2="12.187478125" y2="1.567696875" layer="1"/>
<rectangle x1="12.76995625" y1="1.550046875" x2="13.61719375" y2="1.567696875" layer="1"/>
<rectangle x1="14.04081875" y1="1.550046875" x2="14.83510625" y2="1.567696875" layer="1"/>
<rectangle x1="15.258728125" y1="1.550046875" x2="15.841203125" y2="1.567696875" layer="1"/>
<rectangle x1="16.247175" y1="1.550046875" x2="16.82965" y2="1.567696875" layer="1"/>
<rectangle x1="17.235621875" y1="1.550046875" x2="17.588634375" y2="1.567696875" layer="1"/>
<rectangle x1="18.347625" y1="1.550046875" x2="19.1772125" y2="1.567696875" layer="1"/>
<rectangle x1="0.3437625" y1="1.567696875" x2="1.3851625" y2="1.585346875" layer="1"/>
<rectangle x1="2.05589375" y1="1.567696875" x2="3.11494375" y2="1.585346875" layer="1"/>
<rectangle x1="4.897678125" y1="1.567696875" x2="5.956728125" y2="1.585346875" layer="1"/>
<rectangle x1="6.6451125" y1="1.567696875" x2="7.6865125" y2="1.585346875" layer="1"/>
<rectangle x1="8.28664375" y1="1.567696875" x2="9.34569375" y2="1.585346875" layer="1"/>
<rectangle x1="11.128428125" y1="1.567696875" x2="12.187478125" y2="1.585346875" layer="1"/>
<rectangle x1="12.76995625" y1="1.567696875" x2="13.61719375" y2="1.585346875" layer="1"/>
<rectangle x1="14.04081875" y1="1.567696875" x2="14.85275625" y2="1.585346875" layer="1"/>
<rectangle x1="15.258728125" y1="1.567696875" x2="15.841203125" y2="1.585346875" layer="1"/>
<rectangle x1="16.247175" y1="1.567696875" x2="16.812" y2="1.585346875" layer="1"/>
<rectangle x1="17.235621875" y1="1.567696875" x2="17.588634375" y2="1.585346875" layer="1"/>
<rectangle x1="18.347625" y1="1.567696875" x2="19.1772125" y2="1.585346875" layer="1"/>
<rectangle x1="0.3437625" y1="1.585346875" x2="1.3851625" y2="1.602996875" layer="1"/>
<rectangle x1="2.05589375" y1="1.585346875" x2="3.11494375" y2="1.602996875" layer="1"/>
<rectangle x1="4.897678125" y1="1.585346875" x2="5.956728125" y2="1.602996875" layer="1"/>
<rectangle x1="6.6451125" y1="1.585346875" x2="7.6865125" y2="1.602996875" layer="1"/>
<rectangle x1="8.28664375" y1="1.585346875" x2="9.34569375" y2="1.602996875" layer="1"/>
<rectangle x1="11.128428125" y1="1.585346875" x2="12.205128125" y2="1.602996875" layer="1"/>
<rectangle x1="12.76995625" y1="1.585346875" x2="13.61719375" y2="1.602996875" layer="1"/>
<rectangle x1="14.02316875" y1="1.585346875" x2="14.85275625" y2="1.602996875" layer="1"/>
<rectangle x1="15.276378125" y1="1.585346875" x2="15.841203125" y2="1.602996875" layer="1"/>
<rectangle x1="16.247175" y1="1.585346875" x2="16.812" y2="1.602996875" layer="1"/>
<rectangle x1="17.235621875" y1="1.585346875" x2="17.588634375" y2="1.602996875" layer="1"/>
<rectangle x1="18.347625" y1="1.585346875" x2="19.1772125" y2="1.602996875" layer="1"/>
<rectangle x1="0.3437625" y1="1.602996875" x2="1.3851625" y2="1.620646875" layer="1"/>
<rectangle x1="2.05589375" y1="1.602996875" x2="3.11494375" y2="1.620646875" layer="1"/>
<rectangle x1="4.897678125" y1="1.602996875" x2="5.956728125" y2="1.620646875" layer="1"/>
<rectangle x1="6.6451125" y1="1.602996875" x2="7.6865125" y2="1.620646875" layer="1"/>
<rectangle x1="8.28664375" y1="1.602996875" x2="9.34569375" y2="1.620646875" layer="1"/>
<rectangle x1="11.128428125" y1="1.602996875" x2="12.205128125" y2="1.620646875" layer="1"/>
<rectangle x1="12.76995625" y1="1.602996875" x2="13.61719375" y2="1.620646875" layer="1"/>
<rectangle x1="14.02316875" y1="1.602996875" x2="14.85275625" y2="1.620646875" layer="1"/>
<rectangle x1="15.276378125" y1="1.602996875" x2="15.841203125" y2="1.620646875" layer="1"/>
<rectangle x1="16.247175" y1="1.602996875" x2="16.812" y2="1.620646875" layer="1"/>
<rectangle x1="17.235621875" y1="1.602996875" x2="17.588634375" y2="1.620646875" layer="1"/>
<rectangle x1="18.347625" y1="1.602996875" x2="19.1772125" y2="1.620646875" layer="1"/>
<rectangle x1="0.3437625" y1="1.62065" x2="1.3851625" y2="1.6383" layer="1"/>
<rectangle x1="2.03824375" y1="1.62065" x2="3.11494375" y2="1.6383" layer="1"/>
<rectangle x1="4.897678125" y1="1.62065" x2="5.956728125" y2="1.6383" layer="1"/>
<rectangle x1="6.6451125" y1="1.62065" x2="7.6865125" y2="1.6383" layer="1"/>
<rectangle x1="8.28664375" y1="1.62065" x2="9.34569375" y2="1.6383" layer="1"/>
<rectangle x1="11.146078125" y1="1.62065" x2="12.205128125" y2="1.6383" layer="1"/>
<rectangle x1="12.76995625" y1="1.62065" x2="13.59954375" y2="1.6383" layer="1"/>
<rectangle x1="14.02316875" y1="1.62065" x2="14.85275625" y2="1.6383" layer="1"/>
<rectangle x1="15.276378125" y1="1.62065" x2="15.841203125" y2="1.6383" layer="1"/>
<rectangle x1="16.247175" y1="1.62065" x2="16.812" y2="1.6383" layer="1"/>
<rectangle x1="17.235621875" y1="1.62065" x2="17.588634375" y2="1.6383" layer="1"/>
<rectangle x1="18.347625" y1="1.62065" x2="19.1772125" y2="1.6383" layer="1"/>
<rectangle x1="0.3437625" y1="1.6383" x2="1.3851625" y2="1.65595" layer="1"/>
<rectangle x1="2.03824375" y1="1.6383" x2="3.09729375" y2="1.65595" layer="1"/>
<rectangle x1="4.897678125" y1="1.6383" x2="5.956728125" y2="1.65595" layer="1"/>
<rectangle x1="6.6451125" y1="1.6383" x2="7.6865125" y2="1.65595" layer="1"/>
<rectangle x1="8.28664375" y1="1.6383" x2="9.34569375" y2="1.65595" layer="1"/>
<rectangle x1="11.146078125" y1="1.6383" x2="12.205128125" y2="1.65595" layer="1"/>
<rectangle x1="12.76995625" y1="1.6383" x2="13.59954375" y2="1.65595" layer="1"/>
<rectangle x1="14.02316875" y1="1.6383" x2="14.85275625" y2="1.65595" layer="1"/>
<rectangle x1="15.276378125" y1="1.6383" x2="15.841203125" y2="1.65595" layer="1"/>
<rectangle x1="16.247175" y1="1.6383" x2="16.812" y2="1.65595" layer="1"/>
<rectangle x1="17.235621875" y1="1.6383" x2="17.588634375" y2="1.65595" layer="1"/>
<rectangle x1="18.347625" y1="1.6383" x2="19.1772125" y2="1.65595" layer="1"/>
<rectangle x1="0.3437625" y1="1.65595" x2="1.3851625" y2="1.6736" layer="1"/>
<rectangle x1="2.03824375" y1="1.65595" x2="3.09729375" y2="1.6736" layer="1"/>
<rectangle x1="4.897678125" y1="1.65595" x2="5.956728125" y2="1.6736" layer="1"/>
<rectangle x1="6.6451125" y1="1.65595" x2="7.6865125" y2="1.6736" layer="1"/>
<rectangle x1="8.28664375" y1="1.65595" x2="9.34569375" y2="1.6736" layer="1"/>
<rectangle x1="11.146078125" y1="1.65595" x2="12.205128125" y2="1.6736" layer="1"/>
<rectangle x1="12.76995625" y1="1.65595" x2="13.59954375" y2="1.6736" layer="1"/>
<rectangle x1="14.02316875" y1="1.65595" x2="14.85275625" y2="1.6736" layer="1"/>
<rectangle x1="15.276378125" y1="1.65595" x2="15.841203125" y2="1.6736" layer="1"/>
<rectangle x1="16.247175" y1="1.65595" x2="16.812" y2="1.6736" layer="1"/>
<rectangle x1="17.235621875" y1="1.65595" x2="17.588634375" y2="1.6736" layer="1"/>
<rectangle x1="18.347625" y1="1.65595" x2="19.1772125" y2="1.6736" layer="1"/>
<rectangle x1="0.3437625" y1="1.673603125" x2="1.3851625" y2="1.691253125" layer="1"/>
<rectangle x1="2.03824375" y1="1.673603125" x2="3.09729375" y2="1.691253125" layer="1"/>
<rectangle x1="4.897678125" y1="1.673603125" x2="5.956728125" y2="1.691253125" layer="1"/>
<rectangle x1="6.6451125" y1="1.673603125" x2="7.6865125" y2="1.691253125" layer="1"/>
<rectangle x1="8.28664375" y1="1.673603125" x2="9.34569375" y2="1.691253125" layer="1"/>
<rectangle x1="11.146078125" y1="1.673603125" x2="12.205128125" y2="1.691253125" layer="1"/>
<rectangle x1="12.76995625" y1="1.673603125" x2="13.59954375" y2="1.691253125" layer="1"/>
<rectangle x1="14.02316875" y1="1.673603125" x2="14.85275625" y2="1.691253125" layer="1"/>
<rectangle x1="15.276378125" y1="1.673603125" x2="15.841203125" y2="1.691253125" layer="1"/>
<rectangle x1="16.247175" y1="1.673603125" x2="16.812" y2="1.691253125" layer="1"/>
<rectangle x1="17.235621875" y1="1.673603125" x2="17.588634375" y2="1.691253125" layer="1"/>
<rectangle x1="18.347625" y1="1.673603125" x2="19.1772125" y2="1.691253125" layer="1"/>
<rectangle x1="0.3437625" y1="1.691253125" x2="1.3851625" y2="1.708903125" layer="1"/>
<rectangle x1="2.03824375" y1="1.691253125" x2="3.09729375" y2="1.708903125" layer="1"/>
<rectangle x1="4.91533125" y1="1.691253125" x2="5.95673125" y2="1.708903125" layer="1"/>
<rectangle x1="6.6451125" y1="1.691253125" x2="7.6865125" y2="1.708903125" layer="1"/>
<rectangle x1="8.28664375" y1="1.691253125" x2="9.34569375" y2="1.708903125" layer="1"/>
<rectangle x1="11.146078125" y1="1.691253125" x2="12.205128125" y2="1.708903125" layer="1"/>
<rectangle x1="12.76995625" y1="1.691253125" x2="13.59954375" y2="1.708903125" layer="1"/>
<rectangle x1="14.02316875" y1="1.691253125" x2="14.85275625" y2="1.708903125" layer="1"/>
<rectangle x1="15.276378125" y1="1.691253125" x2="15.841203125" y2="1.708903125" layer="1"/>
<rectangle x1="16.247175" y1="1.691253125" x2="16.812" y2="1.708903125" layer="1"/>
<rectangle x1="17.235621875" y1="1.691253125" x2="17.588634375" y2="1.708903125" layer="1"/>
<rectangle x1="18.347625" y1="1.691253125" x2="19.1772125" y2="1.708903125" layer="1"/>
<rectangle x1="0.3437625" y1="1.708903125" x2="1.3851625" y2="1.726553125" layer="1"/>
<rectangle x1="2.03824375" y1="1.708903125" x2="3.09729375" y2="1.726553125" layer="1"/>
<rectangle x1="4.91533125" y1="1.708903125" x2="5.95673125" y2="1.726553125" layer="1"/>
<rectangle x1="6.6451125" y1="1.708903125" x2="7.6865125" y2="1.726553125" layer="1"/>
<rectangle x1="8.28664375" y1="1.708903125" x2="9.34569375" y2="1.726553125" layer="1"/>
<rectangle x1="11.146078125" y1="1.708903125" x2="12.205128125" y2="1.726553125" layer="1"/>
<rectangle x1="12.76995625" y1="1.708903125" x2="13.59954375" y2="1.726553125" layer="1"/>
<rectangle x1="14.02316875" y1="1.708903125" x2="14.85275625" y2="1.726553125" layer="1"/>
<rectangle x1="15.276378125" y1="1.708903125" x2="15.841203125" y2="1.726553125" layer="1"/>
<rectangle x1="16.247175" y1="1.708903125" x2="16.812" y2="1.726553125" layer="1"/>
<rectangle x1="17.235621875" y1="1.708903125" x2="17.588634375" y2="1.726553125" layer="1"/>
<rectangle x1="18.347625" y1="1.708903125" x2="19.1772125" y2="1.726553125" layer="1"/>
<rectangle x1="0.3437625" y1="1.726553125" x2="1.3851625" y2="1.744203125" layer="1"/>
<rectangle x1="2.03824375" y1="1.726553125" x2="3.09729375" y2="1.744203125" layer="1"/>
<rectangle x1="4.91533125" y1="1.726553125" x2="5.95673125" y2="1.744203125" layer="1"/>
<rectangle x1="6.6451125" y1="1.726553125" x2="7.6865125" y2="1.744203125" layer="1"/>
<rectangle x1="8.28664375" y1="1.726553125" x2="9.34569375" y2="1.744203125" layer="1"/>
<rectangle x1="11.146078125" y1="1.726553125" x2="12.205128125" y2="1.744203125" layer="1"/>
<rectangle x1="12.76995625" y1="1.726553125" x2="13.59954375" y2="1.744203125" layer="1"/>
<rectangle x1="14.02316875" y1="1.726553125" x2="14.85275625" y2="1.744203125" layer="1"/>
<rectangle x1="15.276378125" y1="1.726553125" x2="15.841203125" y2="1.744203125" layer="1"/>
<rectangle x1="16.247175" y1="1.726553125" x2="16.812" y2="1.744203125" layer="1"/>
<rectangle x1="17.235621875" y1="1.726553125" x2="17.588634375" y2="1.744203125" layer="1"/>
<rectangle x1="18.347625" y1="1.726553125" x2="19.1772125" y2="1.744203125" layer="1"/>
<rectangle x1="0.3437625" y1="1.74420625" x2="1.3851625" y2="1.76185625" layer="1"/>
<rectangle x1="2.03824375" y1="1.74420625" x2="3.09729375" y2="1.76185625" layer="1"/>
<rectangle x1="4.897678125" y1="1.74420625" x2="5.956728125" y2="1.76185625" layer="1"/>
<rectangle x1="6.6451125" y1="1.74420625" x2="7.6865125" y2="1.76185625" layer="1"/>
<rectangle x1="8.28664375" y1="1.74420625" x2="9.34569375" y2="1.76185625" layer="1"/>
<rectangle x1="11.146078125" y1="1.74420625" x2="12.205128125" y2="1.76185625" layer="1"/>
<rectangle x1="12.76995625" y1="1.74420625" x2="13.59954375" y2="1.76185625" layer="1"/>
<rectangle x1="14.02316875" y1="1.74420625" x2="14.85275625" y2="1.76185625" layer="1"/>
<rectangle x1="15.276378125" y1="1.74420625" x2="15.841203125" y2="1.76185625" layer="1"/>
<rectangle x1="16.247175" y1="1.74420625" x2="16.812" y2="1.76185625" layer="1"/>
<rectangle x1="17.235621875" y1="1.74420625" x2="17.588634375" y2="1.76185625" layer="1"/>
<rectangle x1="18.347625" y1="1.74420625" x2="19.1772125" y2="1.76185625" layer="1"/>
<rectangle x1="0.3437625" y1="1.76185625" x2="1.3851625" y2="1.77950625" layer="1"/>
<rectangle x1="2.03824375" y1="1.76185625" x2="3.09729375" y2="1.77950625" layer="1"/>
<rectangle x1="4.897678125" y1="1.76185625" x2="5.956728125" y2="1.77950625" layer="1"/>
<rectangle x1="6.6451125" y1="1.76185625" x2="7.6865125" y2="1.77950625" layer="1"/>
<rectangle x1="8.28664375" y1="1.76185625" x2="9.34569375" y2="1.77950625" layer="1"/>
<rectangle x1="11.146078125" y1="1.76185625" x2="12.205128125" y2="1.77950625" layer="1"/>
<rectangle x1="12.76995625" y1="1.76185625" x2="13.59954375" y2="1.77950625" layer="1"/>
<rectangle x1="14.02316875" y1="1.76185625" x2="14.85275625" y2="1.77950625" layer="1"/>
<rectangle x1="15.276378125" y1="1.76185625" x2="15.841203125" y2="1.77950625" layer="1"/>
<rectangle x1="16.247175" y1="1.76185625" x2="16.812" y2="1.77950625" layer="1"/>
<rectangle x1="17.235621875" y1="1.76185625" x2="17.588634375" y2="1.77950625" layer="1"/>
<rectangle x1="18.347625" y1="1.76185625" x2="19.1772125" y2="1.77950625" layer="1"/>
<rectangle x1="0.3437625" y1="1.77950625" x2="1.3851625" y2="1.79715625" layer="1"/>
<rectangle x1="2.03824375" y1="1.77950625" x2="3.09729375" y2="1.79715625" layer="1"/>
<rectangle x1="4.897678125" y1="1.77950625" x2="5.956728125" y2="1.79715625" layer="1"/>
<rectangle x1="6.6451125" y1="1.77950625" x2="7.6865125" y2="1.79715625" layer="1"/>
<rectangle x1="8.28664375" y1="1.77950625" x2="9.34569375" y2="1.79715625" layer="1"/>
<rectangle x1="11.146078125" y1="1.77950625" x2="12.205128125" y2="1.79715625" layer="1"/>
<rectangle x1="12.76995625" y1="1.77950625" x2="13.59954375" y2="1.79715625" layer="1"/>
<rectangle x1="14.02316875" y1="1.77950625" x2="14.85275625" y2="1.79715625" layer="1"/>
<rectangle x1="15.276378125" y1="1.77950625" x2="15.841203125" y2="1.79715625" layer="1"/>
<rectangle x1="16.247175" y1="1.77950625" x2="16.812" y2="1.79715625" layer="1"/>
<rectangle x1="17.235621875" y1="1.77950625" x2="17.588634375" y2="1.79715625" layer="1"/>
<rectangle x1="18.347625" y1="1.77950625" x2="19.1772125" y2="1.79715625" layer="1"/>
<rectangle x1="0.3437625" y1="1.79715625" x2="1.3851625" y2="1.81480625" layer="1"/>
<rectangle x1="2.03824375" y1="1.79715625" x2="3.11494375" y2="1.81480625" layer="1"/>
<rectangle x1="4.897678125" y1="1.79715625" x2="5.956728125" y2="1.81480625" layer="1"/>
<rectangle x1="6.6451125" y1="1.79715625" x2="7.6865125" y2="1.81480625" layer="1"/>
<rectangle x1="8.28664375" y1="1.79715625" x2="9.34569375" y2="1.81480625" layer="1"/>
<rectangle x1="11.146078125" y1="1.79715625" x2="12.205128125" y2="1.81480625" layer="1"/>
<rectangle x1="12.76995625" y1="1.79715625" x2="13.59954375" y2="1.81480625" layer="1"/>
<rectangle x1="14.02316875" y1="1.79715625" x2="14.85275625" y2="1.81480625" layer="1"/>
<rectangle x1="15.276378125" y1="1.79715625" x2="15.841203125" y2="1.81480625" layer="1"/>
<rectangle x1="16.247175" y1="1.79715625" x2="16.812" y2="1.81480625" layer="1"/>
<rectangle x1="17.235621875" y1="1.79715625" x2="17.588634375" y2="1.81480625" layer="1"/>
<rectangle x1="18.347625" y1="1.79715625" x2="19.1772125" y2="1.81480625" layer="1"/>
<rectangle x1="0.3437625" y1="1.814809375" x2="1.3851625" y2="1.832459375" layer="1"/>
<rectangle x1="2.05589375" y1="1.814809375" x2="3.11494375" y2="1.832459375" layer="1"/>
<rectangle x1="4.897678125" y1="1.814809375" x2="5.956728125" y2="1.832459375" layer="1"/>
<rectangle x1="6.6451125" y1="1.814809375" x2="7.6865125" y2="1.832459375" layer="1"/>
<rectangle x1="8.28664375" y1="1.814809375" x2="9.34569375" y2="1.832459375" layer="1"/>
<rectangle x1="11.146078125" y1="1.814809375" x2="12.205128125" y2="1.832459375" layer="1"/>
<rectangle x1="12.76995625" y1="1.814809375" x2="13.59954375" y2="1.832459375" layer="1"/>
<rectangle x1="14.02316875" y1="1.814809375" x2="14.85275625" y2="1.832459375" layer="1"/>
<rectangle x1="15.276378125" y1="1.814809375" x2="15.841203125" y2="1.832459375" layer="1"/>
<rectangle x1="16.247175" y1="1.814809375" x2="16.812" y2="1.832459375" layer="1"/>
<rectangle x1="17.235621875" y1="1.814809375" x2="17.588634375" y2="1.832459375" layer="1"/>
<rectangle x1="18.347625" y1="1.814809375" x2="19.1772125" y2="1.832459375" layer="1"/>
<rectangle x1="0.3437625" y1="1.832459375" x2="1.3851625" y2="1.850109375" layer="1"/>
<rectangle x1="2.05589375" y1="1.832459375" x2="3.11494375" y2="1.850109375" layer="1"/>
<rectangle x1="4.897678125" y1="1.832459375" x2="5.956728125" y2="1.850109375" layer="1"/>
<rectangle x1="6.6451125" y1="1.832459375" x2="7.6865125" y2="1.850109375" layer="1"/>
<rectangle x1="8.28664375" y1="1.832459375" x2="9.34569375" y2="1.850109375" layer="1"/>
<rectangle x1="11.128428125" y1="1.832459375" x2="12.205128125" y2="1.850109375" layer="1"/>
<rectangle x1="12.76995625" y1="1.832459375" x2="13.61719375" y2="1.850109375" layer="1"/>
<rectangle x1="14.02316875" y1="1.832459375" x2="14.85275625" y2="1.850109375" layer="1"/>
<rectangle x1="15.276378125" y1="1.832459375" x2="15.841203125" y2="1.850109375" layer="1"/>
<rectangle x1="16.247175" y1="1.832459375" x2="16.812" y2="1.850109375" layer="1"/>
<rectangle x1="17.235621875" y1="1.832459375" x2="17.606290625" y2="1.850109375" layer="1"/>
<rectangle x1="18.329975" y1="1.832459375" x2="19.1772125" y2="1.850109375" layer="1"/>
<rectangle x1="0.3437625" y1="1.850109375" x2="1.3851625" y2="1.867759375" layer="1"/>
<rectangle x1="2.05589375" y1="1.850109375" x2="3.11494375" y2="1.867759375" layer="1"/>
<rectangle x1="4.897678125" y1="1.850109375" x2="5.956728125" y2="1.867759375" layer="1"/>
<rectangle x1="6.6451125" y1="1.850109375" x2="7.6865125" y2="1.867759375" layer="1"/>
<rectangle x1="8.28664375" y1="1.850109375" x2="9.34569375" y2="1.867759375" layer="1"/>
<rectangle x1="11.128428125" y1="1.850109375" x2="12.187478125" y2="1.867759375" layer="1"/>
<rectangle x1="12.76995625" y1="1.850109375" x2="13.61719375" y2="1.867759375" layer="1"/>
<rectangle x1="14.02316875" y1="1.850109375" x2="14.85275625" y2="1.867759375" layer="1"/>
<rectangle x1="15.276378125" y1="1.850109375" x2="15.841203125" y2="1.867759375" layer="1"/>
<rectangle x1="16.247175" y1="1.850109375" x2="16.812" y2="1.867759375" layer="1"/>
<rectangle x1="17.235621875" y1="1.850109375" x2="19.177215625" y2="1.867759375" layer="1"/>
<rectangle x1="0.3437625" y1="1.8677625" x2="1.3851625" y2="1.8854125" layer="1"/>
<rectangle x1="2.05589375" y1="1.8677625" x2="3.11494375" y2="1.8854125" layer="1"/>
<rectangle x1="4.897678125" y1="1.8677625" x2="5.956728125" y2="1.8854125" layer="1"/>
<rectangle x1="6.6451125" y1="1.8677625" x2="7.6865125" y2="1.8854125" layer="1"/>
<rectangle x1="8.28664375" y1="1.8677625" x2="9.36334375" y2="1.8854125" layer="1"/>
<rectangle x1="11.128428125" y1="1.8677625" x2="12.187478125" y2="1.8854125" layer="1"/>
<rectangle x1="12.76995625" y1="1.8677625" x2="13.61719375" y2="1.8854125" layer="1"/>
<rectangle x1="14.04081875" y1="1.8677625" x2="14.85275625" y2="1.8854125" layer="1"/>
<rectangle x1="15.258728125" y1="1.8677625" x2="15.841203125" y2="1.8854125" layer="1"/>
<rectangle x1="16.247175" y1="1.8677625" x2="16.82965" y2="1.8854125" layer="1"/>
<rectangle x1="17.253271875" y1="1.8677625" x2="19.177215625" y2="1.8854125" layer="1"/>
<rectangle x1="0.3437625" y1="1.8854125" x2="1.3851625" y2="1.9030625" layer="1"/>
<rectangle x1="2.05589375" y1="1.8854125" x2="3.11494375" y2="1.9030625" layer="1"/>
<rectangle x1="4.880028125" y1="1.8854125" x2="5.956728125" y2="1.9030625" layer="1"/>
<rectangle x1="6.6451125" y1="1.8854125" x2="7.6865125" y2="1.9030625" layer="1"/>
<rectangle x1="8.28664375" y1="1.8854125" x2="9.36334375" y2="1.9030625" layer="1"/>
<rectangle x1="11.128428125" y1="1.8854125" x2="12.187478125" y2="1.9030625" layer="1"/>
<rectangle x1="12.76995625" y1="1.8854125" x2="13.61719375" y2="1.9030625" layer="1"/>
<rectangle x1="14.04081875" y1="1.8854125" x2="14.83510625" y2="1.9030625" layer="1"/>
<rectangle x1="15.258728125" y1="1.8854125" x2="15.841203125" y2="1.9030625" layer="1"/>
<rectangle x1="16.247175" y1="1.8854125" x2="16.82965" y2="1.9030625" layer="1"/>
<rectangle x1="17.253271875" y1="1.8854125" x2="19.177215625" y2="1.9030625" layer="1"/>
<rectangle x1="0.3437625" y1="1.9030625" x2="1.3851625" y2="1.9207125" layer="1"/>
<rectangle x1="2.05589375" y1="1.9030625" x2="3.13259375" y2="1.9207125" layer="1"/>
<rectangle x1="4.880028125" y1="1.9030625" x2="5.956728125" y2="1.9207125" layer="1"/>
<rectangle x1="6.6451125" y1="1.9030625" x2="7.6865125" y2="1.9207125" layer="1"/>
<rectangle x1="8.28664375" y1="1.9030625" x2="9.36334375" y2="1.9207125" layer="1"/>
<rectangle x1="11.128428125" y1="1.9030625" x2="12.187478125" y2="1.9207125" layer="1"/>
<rectangle x1="12.76995625" y1="1.9030625" x2="13.61719375" y2="1.9207125" layer="1"/>
<rectangle x1="14.04081875" y1="1.9030625" x2="14.83510625" y2="1.9207125" layer="1"/>
<rectangle x1="15.258728125" y1="1.9030625" x2="15.841203125" y2="1.9207125" layer="1"/>
<rectangle x1="16.247175" y1="1.9030625" x2="16.82965" y2="1.9207125" layer="1"/>
<rectangle x1="17.253271875" y1="1.9030625" x2="19.177215625" y2="1.9207125" layer="1"/>
<rectangle x1="0.3437625" y1="1.9207125" x2="1.3851625" y2="1.9383625" layer="1"/>
<rectangle x1="2.05589375" y1="1.9207125" x2="3.13259375" y2="1.9383625" layer="1"/>
<rectangle x1="4.880028125" y1="1.9207125" x2="5.956728125" y2="1.9383625" layer="1"/>
<rectangle x1="6.6451125" y1="1.9207125" x2="7.6865125" y2="1.9383625" layer="1"/>
<rectangle x1="8.30429375" y1="1.9207125" x2="9.36334375" y2="1.9383625" layer="1"/>
<rectangle x1="11.110778125" y1="1.9207125" x2="12.187478125" y2="1.9383625" layer="1"/>
<rectangle x1="12.76995625" y1="1.9207125" x2="13.61719375" y2="1.9383625" layer="1"/>
<rectangle x1="14.04081875" y1="1.9207125" x2="14.83510625" y2="1.9383625" layer="1"/>
<rectangle x1="15.258728125" y1="1.9207125" x2="15.841203125" y2="1.9383625" layer="1"/>
<rectangle x1="16.247175" y1="1.9207125" x2="16.82965" y2="1.9383625" layer="1"/>
<rectangle x1="17.253271875" y1="1.9207125" x2="19.177215625" y2="1.9383625" layer="1"/>
<rectangle x1="0.3437625" y1="1.938365625" x2="1.3851625" y2="1.956015625" layer="1"/>
<rectangle x1="2.05589375" y1="1.938365625" x2="3.13259375" y2="1.956015625" layer="1"/>
<rectangle x1="4.880028125" y1="1.938365625" x2="5.939078125" y2="1.956015625" layer="1"/>
<rectangle x1="6.6451125" y1="1.938365625" x2="7.6865125" y2="1.956015625" layer="1"/>
<rectangle x1="8.30429375" y1="1.938365625" x2="9.38099375" y2="1.956015625" layer="1"/>
<rectangle x1="11.110778125" y1="1.938365625" x2="12.187478125" y2="1.956015625" layer="1"/>
<rectangle x1="12.76995625" y1="1.938365625" x2="13.61719375" y2="1.956015625" layer="1"/>
<rectangle x1="14.04081875" y1="1.938365625" x2="14.83510625" y2="1.956015625" layer="1"/>
<rectangle x1="15.258728125" y1="1.938365625" x2="15.841203125" y2="1.956015625" layer="1"/>
<rectangle x1="16.247175" y1="1.938365625" x2="16.82965" y2="1.956015625" layer="1"/>
<rectangle x1="17.270925" y1="1.938365625" x2="19.1772125" y2="1.956015625" layer="1"/>
<rectangle x1="0.3437625" y1="1.956015625" x2="1.3851625" y2="1.973665625" layer="1"/>
<rectangle x1="2.05589375" y1="1.956015625" x2="3.13259375" y2="1.973665625" layer="1"/>
<rectangle x1="4.862378125" y1="1.956015625" x2="5.939078125" y2="1.973665625" layer="1"/>
<rectangle x1="6.6451125" y1="1.956015625" x2="7.6865125" y2="1.973665625" layer="1"/>
<rectangle x1="8.30429375" y1="1.956015625" x2="9.38099375" y2="1.973665625" layer="1"/>
<rectangle x1="11.110778125" y1="1.956015625" x2="12.187478125" y2="1.973665625" layer="1"/>
<rectangle x1="12.76995625" y1="1.956015625" x2="13.61719375" y2="1.973665625" layer="1"/>
<rectangle x1="14.04081875" y1="1.956015625" x2="14.83510625" y2="1.973665625" layer="1"/>
<rectangle x1="15.258728125" y1="1.956015625" x2="15.841203125" y2="1.973665625" layer="1"/>
<rectangle x1="16.247175" y1="1.956015625" x2="16.82965" y2="1.973665625" layer="1"/>
<rectangle x1="17.270925" y1="1.956015625" x2="19.1772125" y2="1.973665625" layer="1"/>
<rectangle x1="0.3437625" y1="1.973665625" x2="1.3851625" y2="1.991315625" layer="1"/>
<rectangle x1="2.05589375" y1="1.973665625" x2="3.15024375" y2="1.991315625" layer="1"/>
<rectangle x1="4.862378125" y1="1.973665625" x2="5.939078125" y2="1.991315625" layer="1"/>
<rectangle x1="6.6451125" y1="1.973665625" x2="7.6865125" y2="1.991315625" layer="1"/>
<rectangle x1="8.30429375" y1="1.973665625" x2="9.38099375" y2="1.991315625" layer="1"/>
<rectangle x1="11.093128125" y1="1.973665625" x2="12.187478125" y2="1.991315625" layer="1"/>
<rectangle x1="12.76995625" y1="1.973665625" x2="13.61719375" y2="1.991315625" layer="1"/>
<rectangle x1="14.05846875" y1="1.973665625" x2="14.83510625" y2="1.991315625" layer="1"/>
<rectangle x1="15.258728125" y1="1.973665625" x2="15.841203125" y2="1.991315625" layer="1"/>
<rectangle x1="16.247175" y1="1.973665625" x2="16.8473" y2="1.991315625" layer="1"/>
<rectangle x1="17.270925" y1="1.973665625" x2="19.1772125" y2="1.991315625" layer="1"/>
<rectangle x1="0.3437625" y1="1.991315625" x2="1.3851625" y2="2.008965625" layer="1"/>
<rectangle x1="2.07354375" y1="1.991315625" x2="3.15024375" y2="2.008965625" layer="1"/>
<rectangle x1="4.862378125" y1="1.991315625" x2="5.939078125" y2="2.008965625" layer="1"/>
<rectangle x1="6.6451125" y1="1.991315625" x2="7.6865125" y2="2.008965625" layer="1"/>
<rectangle x1="8.30429375" y1="1.991315625" x2="9.39864375" y2="2.008965625" layer="1"/>
<rectangle x1="11.093128125" y1="1.991315625" x2="12.187478125" y2="2.008965625" layer="1"/>
<rectangle x1="12.76995625" y1="1.991315625" x2="13.63485" y2="2.008965625" layer="1"/>
<rectangle x1="14.05846875" y1="1.991315625" x2="14.81745625" y2="2.008965625" layer="1"/>
<rectangle x1="15.241075" y1="1.991315625" x2="15.84120625" y2="2.008965625" layer="1"/>
<rectangle x1="16.247175" y1="1.991315625" x2="16.8473" y2="2.008965625" layer="1"/>
<rectangle x1="17.288575" y1="1.991315625" x2="19.1595625" y2="2.008965625" layer="1"/>
<rectangle x1="0.3437625" y1="2.00896875" x2="1.3851625" y2="2.02661875" layer="1"/>
<rectangle x1="2.07354375" y1="2.00896875" x2="3.16789375" y2="2.02661875" layer="1"/>
<rectangle x1="4.844728125" y1="2.00896875" x2="5.939078125" y2="2.02661875" layer="1"/>
<rectangle x1="6.6451125" y1="2.00896875" x2="7.6865125" y2="2.02661875" layer="1"/>
<rectangle x1="8.30429375" y1="2.00896875" x2="9.39864375" y2="2.02661875" layer="1"/>
<rectangle x1="11.093128125" y1="2.00896875" x2="12.169828125" y2="2.02661875" layer="1"/>
<rectangle x1="12.787609375" y1="2.00896875" x2="13.634846875" y2="2.02661875" layer="1"/>
<rectangle x1="14.05846875" y1="2.00896875" x2="14.81745625" y2="2.02661875" layer="1"/>
<rectangle x1="15.241075" y1="2.00896875" x2="15.84120625" y2="2.02661875" layer="1"/>
<rectangle x1="16.247175" y1="2.00896875" x2="16.8473" y2="2.02661875" layer="1"/>
<rectangle x1="17.288575" y1="2.00896875" x2="19.1595625" y2="2.02661875" layer="1"/>
<rectangle x1="0.3437625" y1="2.02661875" x2="1.3851625" y2="2.04426875" layer="1"/>
<rectangle x1="2.07354375" y1="2.02661875" x2="3.16789375" y2="2.04426875" layer="1"/>
<rectangle x1="4.844728125" y1="2.02661875" x2="5.939078125" y2="2.04426875" layer="1"/>
<rectangle x1="6.6451125" y1="2.02661875" x2="7.6865125" y2="2.04426875" layer="1"/>
<rectangle x1="8.30429375" y1="2.02661875" x2="9.39864375" y2="2.04426875" layer="1"/>
<rectangle x1="11.075475" y1="2.02661875" x2="12.169825" y2="2.04426875" layer="1"/>
<rectangle x1="12.787609375" y1="2.02661875" x2="13.634846875" y2="2.04426875" layer="1"/>
<rectangle x1="14.05846875" y1="2.02661875" x2="14.81745625" y2="2.04426875" layer="1"/>
<rectangle x1="15.241075" y1="2.02661875" x2="15.84120625" y2="2.04426875" layer="1"/>
<rectangle x1="16.247175" y1="2.02661875" x2="16.8473" y2="2.04426875" layer="1"/>
<rectangle x1="17.288575" y1="2.02661875" x2="19.1595625" y2="2.04426875" layer="1"/>
<rectangle x1="0.3437625" y1="2.04426875" x2="1.3851625" y2="2.06191875" layer="1"/>
<rectangle x1="2.07354375" y1="2.04426875" x2="3.16789375" y2="2.06191875" layer="1"/>
<rectangle x1="4.827075" y1="2.04426875" x2="5.921425" y2="2.06191875" layer="1"/>
<rectangle x1="6.6451125" y1="2.04426875" x2="7.6865125" y2="2.06191875" layer="1"/>
<rectangle x1="8.32194375" y1="2.04426875" x2="9.41629375" y2="2.06191875" layer="1"/>
<rectangle x1="11.075475" y1="2.04426875" x2="12.169825" y2="2.06191875" layer="1"/>
<rectangle x1="12.787609375" y1="2.04426875" x2="13.634846875" y2="2.06191875" layer="1"/>
<rectangle x1="14.076121875" y1="2.04426875" x2="14.817453125" y2="2.06191875" layer="1"/>
<rectangle x1="15.241075" y1="2.04426875" x2="15.84120625" y2="2.06191875" layer="1"/>
<rectangle x1="16.247175" y1="2.04426875" x2="16.86495" y2="2.06191875" layer="1"/>
<rectangle x1="17.306225" y1="2.04426875" x2="19.1595625" y2="2.06191875" layer="1"/>
<rectangle x1="0.3437625" y1="2.061921875" x2="1.3851625" y2="2.079571875" layer="1"/>
<rectangle x1="2.07354375" y1="2.061921875" x2="3.18554375" y2="2.079571875" layer="1"/>
<rectangle x1="4.827075" y1="2.061921875" x2="5.921425" y2="2.079571875" layer="1"/>
<rectangle x1="6.6451125" y1="2.061921875" x2="7.6865125" y2="2.079571875" layer="1"/>
<rectangle x1="8.32194375" y1="2.061921875" x2="9.41629375" y2="2.079571875" layer="1"/>
<rectangle x1="11.057825" y1="2.061921875" x2="12.169825" y2="2.079571875" layer="1"/>
<rectangle x1="12.787609375" y1="2.061921875" x2="13.652496875" y2="2.079571875" layer="1"/>
<rectangle x1="14.076121875" y1="2.061921875" x2="14.799803125" y2="2.079571875" layer="1"/>
<rectangle x1="15.241075" y1="2.061921875" x2="15.84120625" y2="2.079571875" layer="1"/>
<rectangle x1="16.247175" y1="2.061921875" x2="16.86495" y2="2.079571875" layer="1"/>
<rectangle x1="17.306225" y1="2.061921875" x2="19.1595625" y2="2.079571875" layer="1"/>
<rectangle x1="0.3437625" y1="2.079571875" x2="1.3851625" y2="2.097221875" layer="1"/>
<rectangle x1="2.09119375" y1="2.079571875" x2="3.18554375" y2="2.097221875" layer="1"/>
<rectangle x1="4.809425" y1="2.079571875" x2="5.921425" y2="2.097221875" layer="1"/>
<rectangle x1="6.6451125" y1="2.079571875" x2="7.6865125" y2="2.097221875" layer="1"/>
<rectangle x1="8.32194375" y1="2.079571875" x2="9.43394375" y2="2.097221875" layer="1"/>
<rectangle x1="11.057825" y1="2.079571875" x2="12.169825" y2="2.097221875" layer="1"/>
<rectangle x1="12.787609375" y1="2.079571875" x2="13.652496875" y2="2.097221875" layer="1"/>
<rectangle x1="14.076121875" y1="2.079571875" x2="14.799803125" y2="2.097221875" layer="1"/>
<rectangle x1="15.223425" y1="2.079571875" x2="15.84120625" y2="2.097221875" layer="1"/>
<rectangle x1="16.247175" y1="2.079571875" x2="16.86495" y2="2.097221875" layer="1"/>
<rectangle x1="17.323875" y1="2.079571875" x2="19.1595625" y2="2.097221875" layer="1"/>
<rectangle x1="0.3437625" y1="2.097221875" x2="1.3851625" y2="2.114871875" layer="1"/>
<rectangle x1="2.09119375" y1="2.097221875" x2="3.20319375" y2="2.114871875" layer="1"/>
<rectangle x1="4.809425" y1="2.097221875" x2="5.921425" y2="2.114871875" layer="1"/>
<rectangle x1="6.6451125" y1="2.097221875" x2="7.6865125" y2="2.114871875" layer="1"/>
<rectangle x1="8.32194375" y1="2.097221875" x2="9.43394375" y2="2.114871875" layer="1"/>
<rectangle x1="11.040175" y1="2.097221875" x2="12.152175" y2="2.114871875" layer="1"/>
<rectangle x1="12.787609375" y1="2.097221875" x2="13.652496875" y2="2.114871875" layer="1"/>
<rectangle x1="14.093771875" y1="2.097221875" x2="14.782153125" y2="2.114871875" layer="1"/>
<rectangle x1="15.223425" y1="2.097221875" x2="15.84120625" y2="2.114871875" layer="1"/>
<rectangle x1="16.247175" y1="2.097221875" x2="16.86495" y2="2.114871875" layer="1"/>
<rectangle x1="17.341528125" y1="2.097221875" x2="19.141909375" y2="2.114871875" layer="1"/>
<rectangle x1="0.3437625" y1="2.114871875" x2="1.3851625" y2="2.132521875" layer="1"/>
<rectangle x1="2.09119375" y1="2.114871875" x2="3.20319375" y2="2.132521875" layer="1"/>
<rectangle x1="4.791775" y1="2.114871875" x2="5.921425" y2="2.132521875" layer="1"/>
<rectangle x1="6.6451125" y1="2.114871875" x2="7.6865125" y2="2.132521875" layer="1"/>
<rectangle x1="8.33959375" y1="2.114871875" x2="9.45159375" y2="2.132521875" layer="1"/>
<rectangle x1="11.040175" y1="2.114871875" x2="12.152175" y2="2.132521875" layer="1"/>
<rectangle x1="12.805259375" y1="2.114871875" x2="13.652496875" y2="2.132521875" layer="1"/>
<rectangle x1="14.093771875" y1="2.114871875" x2="14.782153125" y2="2.132521875" layer="1"/>
<rectangle x1="15.223425" y1="2.114871875" x2="15.84120625" y2="2.132521875" layer="1"/>
<rectangle x1="16.247175" y1="2.114871875" x2="16.88260625" y2="2.132521875" layer="1"/>
<rectangle x1="17.341528125" y1="2.114871875" x2="19.141909375" y2="2.132521875" layer="1"/>
<rectangle x1="0.3437625" y1="2.132525" x2="1.3851625" y2="2.150175" layer="1"/>
<rectangle x1="2.09119375" y1="2.132525" x2="3.22085" y2="2.150175" layer="1"/>
<rectangle x1="4.791775" y1="2.132525" x2="5.903775" y2="2.150175" layer="1"/>
<rectangle x1="6.6451125" y1="2.132525" x2="7.6865125" y2="2.150175" layer="1"/>
<rectangle x1="8.33959375" y1="2.132525" x2="9.45159375" y2="2.150175" layer="1"/>
<rectangle x1="11.022525" y1="2.132525" x2="12.152175" y2="2.150175" layer="1"/>
<rectangle x1="12.805259375" y1="2.132525" x2="13.670146875" y2="2.150175" layer="1"/>
<rectangle x1="14.111421875" y1="2.132525" x2="14.764503125" y2="2.150175" layer="1"/>
<rectangle x1="15.205775" y1="2.132525" x2="15.84120625" y2="2.150175" layer="1"/>
<rectangle x1="16.247175" y1="2.132525" x2="16.88260625" y2="2.150175" layer="1"/>
<rectangle x1="17.359178125" y1="2.132525" x2="19.141909375" y2="2.150175" layer="1"/>
<rectangle x1="0.3437625" y1="2.150175" x2="1.3851625" y2="2.167825" layer="1"/>
<rectangle x1="2.108846875" y1="2.150175" x2="3.238496875" y2="2.167825" layer="1"/>
<rectangle x1="4.774125" y1="2.150175" x2="5.903775" y2="2.167825" layer="1"/>
<rectangle x1="6.6451125" y1="2.150175" x2="7.6865125" y2="2.167825" layer="1"/>
<rectangle x1="8.33959375" y1="2.150175" x2="9.46925" y2="2.167825" layer="1"/>
<rectangle x1="11.022525" y1="2.150175" x2="12.152175" y2="2.167825" layer="1"/>
<rectangle x1="12.805259375" y1="2.150175" x2="13.670146875" y2="2.167825" layer="1"/>
<rectangle x1="14.111421875" y1="2.150175" x2="14.764503125" y2="2.167825" layer="1"/>
<rectangle x1="15.205775" y1="2.150175" x2="15.84120625" y2="2.167825" layer="1"/>
<rectangle x1="16.247175" y1="2.150175" x2="16.90025625" y2="2.167825" layer="1"/>
<rectangle x1="17.376828125" y1="2.150175" x2="19.141909375" y2="2.167825" layer="1"/>
<rectangle x1="0.3437625" y1="2.167825" x2="1.3851625" y2="2.185475" layer="1"/>
<rectangle x1="2.108846875" y1="2.167825" x2="3.238496875" y2="2.185475" layer="1"/>
<rectangle x1="4.774125" y1="2.167825" x2="5.903775" y2="2.185475" layer="1"/>
<rectangle x1="6.6451125" y1="2.167825" x2="7.6865125" y2="2.185475" layer="1"/>
<rectangle x1="8.33959375" y1="2.167825" x2="9.4869" y2="2.185475" layer="1"/>
<rectangle x1="11.004871875" y1="2.167825" x2="12.134528125" y2="2.185475" layer="1"/>
<rectangle x1="12.805259375" y1="2.167825" x2="13.670146875" y2="2.185475" layer="1"/>
<rectangle x1="14.129071875" y1="2.167825" x2="14.746853125" y2="2.185475" layer="1"/>
<rectangle x1="15.205775" y1="2.167825" x2="15.84120625" y2="2.185475" layer="1"/>
<rectangle x1="16.247175" y1="2.167825" x2="16.90025625" y2="2.185475" layer="1"/>
<rectangle x1="17.394478125" y1="2.167825" x2="19.141909375" y2="2.185475" layer="1"/>
<rectangle x1="0.3437625" y1="2.185475" x2="1.3851625" y2="2.203125" layer="1"/>
<rectangle x1="2.108846875" y1="2.185475" x2="3.256146875" y2="2.203125" layer="1"/>
<rectangle x1="4.756471875" y1="2.185475" x2="5.903778125" y2="2.203125" layer="1"/>
<rectangle x1="6.6451125" y1="2.185475" x2="7.6865125" y2="2.203125" layer="1"/>
<rectangle x1="8.357246875" y1="2.185475" x2="9.486896875" y2="2.203125" layer="1"/>
<rectangle x1="10.987221875" y1="2.185475" x2="12.134528125" y2="2.203125" layer="1"/>
<rectangle x1="12.822909375" y1="2.185475" x2="13.687803125" y2="2.203125" layer="1"/>
<rectangle x1="14.146725" y1="2.185475" x2="14.74685" y2="2.203125" layer="1"/>
<rectangle x1="15.188125" y1="2.185475" x2="15.84120625" y2="2.203125" layer="1"/>
<rectangle x1="16.247175" y1="2.185475" x2="16.91790625" y2="2.203125" layer="1"/>
<rectangle x1="17.41213125" y1="2.185475" x2="19.1242625" y2="2.203125" layer="1"/>
<rectangle x1="0.3437625" y1="2.203128125" x2="1.3851625" y2="2.220778125" layer="1"/>
<rectangle x1="2.108846875" y1="2.203128125" x2="3.273803125" y2="2.220778125" layer="1"/>
<rectangle x1="4.738821875" y1="2.203128125" x2="5.886128125" y2="2.220778125" layer="1"/>
<rectangle x1="6.6451125" y1="2.203128125" x2="7.6865125" y2="2.220778125" layer="1"/>
<rectangle x1="8.357246875" y1="2.203128125" x2="9.504546875" y2="2.220778125" layer="1"/>
<rectangle x1="10.987221875" y1="2.203128125" x2="12.134528125" y2="2.220778125" layer="1"/>
<rectangle x1="12.822909375" y1="2.203128125" x2="13.687803125" y2="2.220778125" layer="1"/>
<rectangle x1="14.146725" y1="2.203128125" x2="14.7292" y2="2.220778125" layer="1"/>
<rectangle x1="15.188125" y1="2.203128125" x2="15.84120625" y2="2.220778125" layer="1"/>
<rectangle x1="16.247175" y1="2.203128125" x2="16.91790625" y2="2.220778125" layer="1"/>
<rectangle x1="17.42978125" y1="2.203128125" x2="19.1242625" y2="2.220778125" layer="1"/>
<rectangle x1="0.3437625" y1="2.220778125" x2="1.3851625" y2="2.238428125" layer="1"/>
<rectangle x1="2.126496875" y1="2.220778125" x2="3.273803125" y2="2.238428125" layer="1"/>
<rectangle x1="4.721171875" y1="2.220778125" x2="5.886128125" y2="2.238428125" layer="1"/>
<rectangle x1="6.6451125" y1="2.220778125" x2="7.6865125" y2="2.238428125" layer="1"/>
<rectangle x1="8.357246875" y1="2.220778125" x2="9.522203125" y2="2.238428125" layer="1"/>
<rectangle x1="10.969571875" y1="2.220778125" x2="12.116871875" y2="2.238428125" layer="1"/>
<rectangle x1="12.822909375" y1="2.220778125" x2="13.705453125" y2="2.238428125" layer="1"/>
<rectangle x1="14.164375" y1="2.220778125" x2="14.71155" y2="2.238428125" layer="1"/>
<rectangle x1="15.188125" y1="2.220778125" x2="15.84120625" y2="2.238428125" layer="1"/>
<rectangle x1="16.247175" y1="2.220778125" x2="16.93555625" y2="2.238428125" layer="1"/>
<rectangle x1="17.44743125" y1="2.220778125" x2="19.1242625" y2="2.238428125" layer="1"/>
<rectangle x1="0.3437625" y1="2.238428125" x2="1.3851625" y2="2.256078125" layer="1"/>
<rectangle x1="2.126496875" y1="2.238428125" x2="3.291453125" y2="2.256078125" layer="1"/>
<rectangle x1="4.721171875" y1="2.238428125" x2="5.886128125" y2="2.256078125" layer="1"/>
<rectangle x1="6.6451125" y1="2.238428125" x2="7.6865125" y2="2.256078125" layer="1"/>
<rectangle x1="8.374896875" y1="2.238428125" x2="9.522203125" y2="2.256078125" layer="1"/>
<rectangle x1="10.951921875" y1="2.238428125" x2="12.116871875" y2="2.256078125" layer="1"/>
<rectangle x1="12.822909375" y1="2.238428125" x2="13.705453125" y2="2.256078125" layer="1"/>
<rectangle x1="14.182025" y1="2.238428125" x2="14.6939" y2="2.256078125" layer="1"/>
<rectangle x1="15.170471875" y1="2.238428125" x2="15.841203125" y2="2.256078125" layer="1"/>
<rectangle x1="16.247175" y1="2.238428125" x2="16.93555625" y2="2.256078125" layer="1"/>
<rectangle x1="17.465084375" y1="2.238428125" x2="18.171115625" y2="2.256078125" layer="1"/>
<rectangle x1="18.20641875" y1="2.238428125" x2="19.1242625" y2="2.256078125" layer="1"/>
<rectangle x1="0.3437625" y1="2.256078125" x2="1.3851625" y2="2.273728125" layer="1"/>
<rectangle x1="2.126496875" y1="2.256078125" x2="3.309103125" y2="2.273728125" layer="1"/>
<rectangle x1="4.703521875" y1="2.256078125" x2="5.868471875" y2="2.273728125" layer="1"/>
<rectangle x1="6.6451125" y1="2.256078125" x2="7.6865125" y2="2.273728125" layer="1"/>
<rectangle x1="8.374896875" y1="2.256078125" x2="9.539853125" y2="2.273728125" layer="1"/>
<rectangle x1="10.93426875" y1="2.256078125" x2="12.116875" y2="2.273728125" layer="1"/>
<rectangle x1="12.8405625" y1="2.256078125" x2="13.70545" y2="2.273728125" layer="1"/>
<rectangle x1="14.199675" y1="2.256078125" x2="14.67625" y2="2.273728125" layer="1"/>
<rectangle x1="15.170471875" y1="2.256078125" x2="15.841203125" y2="2.273728125" layer="1"/>
<rectangle x1="16.247175" y1="2.256078125" x2="16.95320625" y2="2.273728125" layer="1"/>
<rectangle x1="17.500384375" y1="2.256078125" x2="18.118165625" y2="2.273728125" layer="1"/>
<rectangle x1="18.22406875" y1="2.256078125" x2="19.1066125" y2="2.273728125" layer="1"/>
<rectangle x1="0.3437625" y1="2.27373125" x2="1.3851625" y2="2.29138125" layer="1"/>
<rectangle x1="2.144146875" y1="2.27373125" x2="3.326753125" y2="2.29138125" layer="1"/>
<rectangle x1="4.68586875" y1="2.27373125" x2="5.868475" y2="2.29138125" layer="1"/>
<rectangle x1="6.6451125" y1="2.27373125" x2="7.6865125" y2="2.29138125" layer="1"/>
<rectangle x1="8.374896875" y1="2.27373125" x2="9.557503125" y2="2.29138125" layer="1"/>
<rectangle x1="10.93426875" y1="2.27373125" x2="12.099225" y2="2.29138125" layer="1"/>
<rectangle x1="12.8405625" y1="2.27373125" x2="13.7231" y2="2.29138125" layer="1"/>
<rectangle x1="14.234978125" y1="2.27373125" x2="14.640946875" y2="2.29138125" layer="1"/>
<rectangle x1="15.152821875" y1="2.27373125" x2="15.841203125" y2="2.29138125" layer="1"/>
<rectangle x1="16.247175" y1="2.27373125" x2="16.95320625" y2="2.29138125" layer="1"/>
<rectangle x1="17.5356875" y1="2.27373125" x2="18.0828625" y2="2.29138125" layer="1"/>
<rectangle x1="18.22406875" y1="2.27373125" x2="19.1066125" y2="2.29138125" layer="1"/>
<rectangle x1="0.3437625" y1="2.29138125" x2="1.3851625" y2="2.30903125" layer="1"/>
<rectangle x1="2.144146875" y1="2.29138125" x2="3.344403125" y2="2.30903125" layer="1"/>
<rectangle x1="4.66821875" y1="2.29138125" x2="5.868475" y2="2.30903125" layer="1"/>
<rectangle x1="6.6451125" y1="2.29138125" x2="7.6865125" y2="2.30903125" layer="1"/>
<rectangle x1="8.392546875" y1="2.29138125" x2="9.575153125" y2="2.30903125" layer="1"/>
<rectangle x1="10.91661875" y1="2.29138125" x2="12.099225" y2="2.30903125" layer="1"/>
<rectangle x1="12.8405625" y1="2.29138125" x2="13.74075" y2="2.30903125" layer="1"/>
<rectangle x1="14.270278125" y1="2.29138125" x2="14.623296875" y2="2.30903125" layer="1"/>
<rectangle x1="15.152821875" y1="2.29138125" x2="15.841203125" y2="2.30903125" layer="1"/>
<rectangle x1="16.247175" y1="2.29138125" x2="16.97085625" y2="2.30903125" layer="1"/>
<rectangle x1="17.5886375" y1="2.29138125" x2="18.01225625" y2="2.30903125" layer="1"/>
<rectangle x1="18.22406875" y1="2.29138125" x2="19.1066125" y2="2.30903125" layer="1"/>
<rectangle x1="0.3437625" y1="2.30903125" x2="1.3851625" y2="2.32668125" layer="1"/>
<rectangle x1="2.144146875" y1="2.30903125" x2="3.344403125" y2="2.32668125" layer="1"/>
<rectangle x1="4.65056875" y1="2.30903125" x2="5.850825" y2="2.32668125" layer="1"/>
<rectangle x1="6.6451125" y1="2.30903125" x2="7.6865125" y2="2.32668125" layer="1"/>
<rectangle x1="8.392546875" y1="2.30903125" x2="9.592803125" y2="2.32668125" layer="1"/>
<rectangle x1="10.89896875" y1="2.30903125" x2="12.099225" y2="2.32668125" layer="1"/>
<rectangle x1="12.8582125" y1="2.30903125" x2="13.74075" y2="2.32668125" layer="1"/>
<rectangle x1="14.30558125" y1="2.30903125" x2="14.57034375" y2="2.32668125" layer="1"/>
<rectangle x1="15.135171875" y1="2.30903125" x2="15.382284375" y2="2.32668125" layer="1"/>
<rectangle x1="16.706096875" y1="2.30903125" x2="16.988509375" y2="2.32668125" layer="1"/>
<rectangle x1="17.641590625" y1="2.30903125" x2="17.941653125" y2="2.32668125" layer="1"/>
<rectangle x1="18.241721875" y1="2.30903125" x2="19.088959375" y2="2.32668125" layer="1"/>
<rectangle x1="0.3437625" y1="2.326684375" x2="1.3851625" y2="2.344334375" layer="1"/>
<rectangle x1="2.161796875" y1="2.326684375" x2="3.362053125" y2="2.344334375" layer="1"/>
<rectangle x1="4.632915625" y1="2.326684375" x2="5.850821875" y2="2.344334375" layer="1"/>
<rectangle x1="6.6451125" y1="2.326684375" x2="7.6865125" y2="2.344334375" layer="1"/>
<rectangle x1="8.392546875" y1="2.326684375" x2="9.610453125" y2="2.344334375" layer="1"/>
<rectangle x1="10.881315625" y1="2.326684375" x2="12.081571875" y2="2.344334375" layer="1"/>
<rectangle x1="12.8582125" y1="2.326684375" x2="13.75840625" y2="2.344334375" layer="1"/>
<rectangle x1="15.117521875" y1="2.326684375" x2="15.382284375" y2="2.344334375" layer="1"/>
<rectangle x1="16.706096875" y1="2.326684375" x2="16.988509375" y2="2.344334375" layer="1"/>
<rectangle x1="18.241721875" y1="2.326684375" x2="19.088959375" y2="2.344334375" layer="1"/>
<rectangle x1="0.3437625" y1="2.344334375" x2="1.3851625" y2="2.361984375" layer="1"/>
<rectangle x1="2.161796875" y1="2.344334375" x2="3.379703125" y2="2.361984375" layer="1"/>
<rectangle x1="4.615265625" y1="2.344334375" x2="5.833171875" y2="2.361984375" layer="1"/>
<rectangle x1="6.6451125" y1="2.344334375" x2="7.6865125" y2="2.361984375" layer="1"/>
<rectangle x1="8.410196875" y1="2.344334375" x2="9.628103125" y2="2.361984375" layer="1"/>
<rectangle x1="10.863665625" y1="2.344334375" x2="12.081571875" y2="2.361984375" layer="1"/>
<rectangle x1="12.8582125" y1="2.344334375" x2="13.75840625" y2="2.361984375" layer="1"/>
<rectangle x1="15.117521875" y1="2.344334375" x2="15.382284375" y2="2.361984375" layer="1"/>
<rectangle x1="16.706096875" y1="2.344334375" x2="17.006159375" y2="2.361984375" layer="1"/>
<rectangle x1="18.259371875" y1="2.344334375" x2="19.088959375" y2="2.361984375" layer="1"/>
<rectangle x1="0.3437625" y1="2.361984375" x2="1.3851625" y2="2.379634375" layer="1"/>
<rectangle x1="2.17945" y1="2.361984375" x2="3.41500625" y2="2.379634375" layer="1"/>
<rectangle x1="4.597615625" y1="2.361984375" x2="5.833171875" y2="2.379634375" layer="1"/>
<rectangle x1="6.6451125" y1="2.361984375" x2="7.6865125" y2="2.379634375" layer="1"/>
<rectangle x1="8.410196875" y1="2.361984375" x2="9.645753125" y2="2.379634375" layer="1"/>
<rectangle x1="10.846015625" y1="2.361984375" x2="12.081571875" y2="2.379634375" layer="1"/>
<rectangle x1="12.8758625" y1="2.361984375" x2="13.77605625" y2="2.379634375" layer="1"/>
<rectangle x1="15.09986875" y1="2.361984375" x2="15.38228125" y2="2.379634375" layer="1"/>
<rectangle x1="16.706096875" y1="2.361984375" x2="17.023809375" y2="2.379634375" layer="1"/>
<rectangle x1="18.259371875" y1="2.361984375" x2="19.071309375" y2="2.379634375" layer="1"/>
<rectangle x1="0.3437625" y1="2.379634375" x2="1.3851625" y2="2.397284375" layer="1"/>
<rectangle x1="2.17945" y1="2.379634375" x2="3.43265625" y2="2.397284375" layer="1"/>
<rectangle x1="4.579965625" y1="2.379634375" x2="5.833171875" y2="2.397284375" layer="1"/>
<rectangle x1="6.6451125" y1="2.379634375" x2="7.6865125" y2="2.397284375" layer="1"/>
<rectangle x1="8.42785" y1="2.379634375" x2="9.66340625" y2="2.397284375" layer="1"/>
<rectangle x1="10.828365625" y1="2.379634375" x2="12.063921875" y2="2.397284375" layer="1"/>
<rectangle x1="12.8758625" y1="2.379634375" x2="13.79370625" y2="2.397284375" layer="1"/>
<rectangle x1="15.08221875" y1="2.379634375" x2="15.38228125" y2="2.397284375" layer="1"/>
<rectangle x1="16.706096875" y1="2.379634375" x2="17.041459375" y2="2.397284375" layer="1"/>
<rectangle x1="18.277021875" y1="2.379634375" x2="19.071309375" y2="2.397284375" layer="1"/>
<rectangle x1="0.3437625" y1="2.3972875" x2="1.3851625" y2="2.4149375" layer="1"/>
<rectangle x1="2.17945" y1="2.3972875" x2="3.45030625" y2="2.4149375" layer="1"/>
<rectangle x1="4.5623125" y1="2.3972875" x2="5.815525" y2="2.4149375" layer="1"/>
<rectangle x1="6.6451125" y1="2.3972875" x2="7.6865125" y2="2.4149375" layer="1"/>
<rectangle x1="8.42785" y1="2.3972875" x2="9.68105625" y2="2.4149375" layer="1"/>
<rectangle x1="10.7930625" y1="2.3972875" x2="12.063925" y2="2.4149375" layer="1"/>
<rectangle x1="12.8758625" y1="2.3972875" x2="13.81135625" y2="2.4149375" layer="1"/>
<rectangle x1="15.08221875" y1="2.3972875" x2="15.38228125" y2="2.4149375" layer="1"/>
<rectangle x1="16.706096875" y1="2.3972875" x2="17.059109375" y2="2.4149375" layer="1"/>
<rectangle x1="18.277021875" y1="2.3972875" x2="19.071309375" y2="2.4149375" layer="1"/>
<rectangle x1="0.3437625" y1="2.4149375" x2="1.3851625" y2="2.4325875" layer="1"/>
<rectangle x1="2.1971" y1="2.4149375" x2="3.4679625" y2="2.4325875" layer="1"/>
<rectangle x1="4.5446625" y1="2.4149375" x2="5.815525" y2="2.4325875" layer="1"/>
<rectangle x1="6.6451125" y1="2.4149375" x2="7.6865125" y2="2.4325875" layer="1"/>
<rectangle x1="8.42785" y1="2.4149375" x2="9.7163625" y2="2.4325875" layer="1"/>
<rectangle x1="10.7754125" y1="2.4149375" x2="12.04626875" y2="2.4325875" layer="1"/>
<rectangle x1="12.8935125" y1="2.4149375" x2="13.81135625" y2="2.4325875" layer="1"/>
<rectangle x1="15.06456875" y1="2.4149375" x2="15.38228125" y2="2.4325875" layer="1"/>
<rectangle x1="16.706096875" y1="2.4149375" x2="17.076765625" y2="2.4325875" layer="1"/>
<rectangle x1="18.277021875" y1="2.4149375" x2="19.053659375" y2="2.4325875" layer="1"/>
<rectangle x1="0.3437625" y1="2.4325875" x2="1.4028125" y2="2.4502375" layer="1"/>
<rectangle x1="2.1971" y1="2.4325875" x2="3.4856125" y2="2.4502375" layer="1"/>
<rectangle x1="4.5093625" y1="2.4325875" x2="5.79786875" y2="2.4502375" layer="1"/>
<rectangle x1="6.6451125" y1="2.4325875" x2="7.6865125" y2="2.4502375" layer="1"/>
<rectangle x1="8.4455" y1="2.4325875" x2="9.7340125" y2="2.4502375" layer="1"/>
<rectangle x1="10.7577625" y1="2.4325875" x2="12.04626875" y2="2.4502375" layer="1"/>
<rectangle x1="12.8935125" y1="2.4325875" x2="13.82900625" y2="2.4502375" layer="1"/>
<rectangle x1="15.046915625" y1="2.4325875" x2="15.382284375" y2="2.4502375" layer="1"/>
<rectangle x1="16.706096875" y1="2.4325875" x2="17.094415625" y2="2.4502375" layer="1"/>
<rectangle x1="18.294671875" y1="2.4325875" x2="19.053659375" y2="2.4502375" layer="1"/>
<rectangle x1="0.290809375" y1="2.4502375" x2="1.438109375" y2="2.4678875" layer="1"/>
<rectangle x1="2.21475" y1="2.4502375" x2="3.5209125" y2="2.4678875" layer="1"/>
<rectangle x1="4.491709375" y1="2.4502375" x2="5.797871875" y2="2.4678875" layer="1"/>
<rectangle x1="6.5921625" y1="2.4502375" x2="7.7394625" y2="2.4678875" layer="1"/>
<rectangle x1="8.4455" y1="2.4502375" x2="9.7516625" y2="2.4678875" layer="1"/>
<rectangle x1="10.722459375" y1="2.4502375" x2="12.028621875" y2="2.4678875" layer="1"/>
<rectangle x1="12.911165625" y1="2.4502375" x2="13.846659375" y2="2.4678875" layer="1"/>
<rectangle x1="15.029265625" y1="2.4502375" x2="15.382284375" y2="2.4678875" layer="1"/>
<rectangle x1="16.706096875" y1="2.4502375" x2="17.112065625" y2="2.4678875" layer="1"/>
<rectangle x1="18.294671875" y1="2.4502375" x2="19.036009375" y2="2.4678875" layer="1"/>
<rectangle x1="0.25550625" y1="2.467890625" x2="1.4734125" y2="2.485540625" layer="1"/>
<rectangle x1="2.21475" y1="2.467890625" x2="3.5385625" y2="2.485540625" layer="1"/>
<rectangle x1="4.456409375" y1="2.467890625" x2="5.780221875" y2="2.485540625" layer="1"/>
<rectangle x1="6.556859375" y1="2.467890625" x2="7.774765625" y2="2.485540625" layer="1"/>
<rectangle x1="8.46315" y1="2.467890625" x2="9.7869625" y2="2.485540625" layer="1"/>
<rectangle x1="10.704809375" y1="2.467890625" x2="12.028621875" y2="2.485540625" layer="1"/>
<rectangle x1="12.911165625" y1="2.467890625" x2="13.864309375" y2="2.485540625" layer="1"/>
<rectangle x1="15.011615625" y1="2.467890625" x2="15.382284375" y2="2.485540625" layer="1"/>
<rectangle x1="16.706096875" y1="2.467890625" x2="17.129715625" y2="2.485540625" layer="1"/>
<rectangle x1="18.312325" y1="2.467890625" x2="19.03600625" y2="2.485540625" layer="1"/>
<rectangle x1="0.22020625" y1="2.485540625" x2="1.5087125" y2="2.503190625" layer="1"/>
<rectangle x1="2.232403125" y1="2.485540625" x2="3.573865625" y2="2.503190625" layer="1"/>
<rectangle x1="4.43875625" y1="2.485540625" x2="5.78021875" y2="2.503190625" layer="1"/>
<rectangle x1="6.52155625" y1="2.485540625" x2="7.81006875" y2="2.503190625" layer="1"/>
<rectangle x1="8.46315" y1="2.485540625" x2="9.8222625" y2="2.503190625" layer="1"/>
<rectangle x1="10.66950625" y1="2.485540625" x2="12.01096875" y2="2.503190625" layer="1"/>
<rectangle x1="12.911165625" y1="2.485540625" x2="13.881959375" y2="2.503190625" layer="1"/>
<rectangle x1="14.993965625" y1="2.485540625" x2="15.382284375" y2="2.503190625" layer="1"/>
<rectangle x1="16.706096875" y1="2.485540625" x2="17.165015625" y2="2.503190625" layer="1"/>
<rectangle x1="18.312325" y1="2.485540625" x2="19.01835625" y2="2.503190625" layer="1"/>
<rectangle x1="0.202553125" y1="2.503190625" x2="1.544015625" y2="2.520840625" layer="1"/>
<rectangle x1="2.232403125" y1="2.503190625" x2="3.609165625" y2="2.520840625" layer="1"/>
<rectangle x1="4.40345625" y1="2.503190625" x2="5.76256875" y2="2.520840625" layer="1"/>
<rectangle x1="6.50390625" y1="2.503190625" x2="7.82771875" y2="2.520840625" layer="1"/>
<rectangle x1="8.480803125" y1="2.503190625" x2="9.839915625" y2="2.520840625" layer="1"/>
<rectangle x1="10.63420625" y1="2.503190625" x2="12.01096875" y2="2.520840625" layer="1"/>
<rectangle x1="12.928815625" y1="2.503190625" x2="13.917259375" y2="2.520840625" layer="1"/>
<rectangle x1="14.9763125" y1="2.503190625" x2="15.38228125" y2="2.520840625" layer="1"/>
<rectangle x1="16.706096875" y1="2.503190625" x2="17.182665625" y2="2.520840625" layer="1"/>
<rectangle x1="18.312325" y1="2.503190625" x2="19.01835625" y2="2.520840625" layer="1"/>
<rectangle x1="0.184903125" y1="2.52084375" x2="1.561665625" y2="2.53849375" layer="1"/>
<rectangle x1="2.250053125" y1="2.52084375" x2="3.644465625" y2="2.53849375" layer="1"/>
<rectangle x1="4.368153125" y1="2.52084375" x2="5.762571875" y2="2.53849375" layer="1"/>
<rectangle x1="6.46860625" y1="2.52084375" x2="7.86301875" y2="2.53849375" layer="1"/>
<rectangle x1="8.480803125" y1="2.52084375" x2="9.875215625" y2="2.53849375" layer="1"/>
<rectangle x1="10.598903125" y1="2.52084375" x2="11.993321875" y2="2.53849375" layer="1"/>
<rectangle x1="12.928815625" y1="2.52084375" x2="13.934909375" y2="2.53849375" layer="1"/>
<rectangle x1="14.9410125" y1="2.52084375" x2="15.38228125" y2="2.53849375" layer="1"/>
<rectangle x1="16.706096875" y1="2.52084375" x2="17.200321875" y2="2.53849375" layer="1"/>
<rectangle x1="18.329975" y1="2.52084375" x2="19.01835625" y2="2.53849375" layer="1"/>
<rectangle x1="0.167253125" y1="2.53849375" x2="1.579321875" y2="2.55614375" layer="1"/>
<rectangle x1="2.250053125" y1="2.53849375" x2="3.679771875" y2="2.55614375" layer="1"/>
<rectangle x1="4.315203125" y1="2.53849375" x2="5.744921875" y2="2.55614375" layer="1"/>
<rectangle x1="6.450953125" y1="2.53849375" x2="7.880671875" y2="2.55614375" layer="1"/>
<rectangle x1="8.498453125" y1="2.53849375" x2="9.928171875" y2="2.55614375" layer="1"/>
<rectangle x1="10.563603125" y1="2.53849375" x2="11.993321875" y2="2.55614375" layer="1"/>
<rectangle x1="12.946465625" y1="2.53849375" x2="13.952565625" y2="2.55614375" layer="1"/>
<rectangle x1="14.9233625" y1="2.53849375" x2="15.38228125" y2="2.55614375" layer="1"/>
<rectangle x1="16.706096875" y1="2.53849375" x2="17.235621875" y2="2.55614375" layer="1"/>
<rectangle x1="18.329975" y1="2.53849375" x2="19.00070625" y2="2.55614375" layer="1"/>
<rectangle x1="0.149603125" y1="2.55614375" x2="1.596971875" y2="2.57379375" layer="1"/>
<rectangle x1="2.267703125" y1="2.55614375" x2="3.732721875" y2="2.57379375" layer="1"/>
<rectangle x1="4.2799" y1="2.55614375" x2="5.74491875" y2="2.57379375" layer="1"/>
<rectangle x1="6.433303125" y1="2.55614375" x2="7.898321875" y2="2.57379375" layer="1"/>
<rectangle x1="8.498453125" y1="2.55614375" x2="9.963471875" y2="2.57379375" layer="1"/>
<rectangle x1="10.51065" y1="2.55614375" x2="11.97566875" y2="2.57379375" layer="1"/>
<rectangle x1="12.946465625" y1="2.55614375" x2="13.987865625" y2="2.57379375" layer="1"/>
<rectangle x1="14.888059375" y1="2.55614375" x2="15.382284375" y2="2.57379375" layer="1"/>
<rectangle x1="16.706096875" y1="2.55614375" x2="17.270921875" y2="2.57379375" layer="1"/>
<rectangle x1="18.312325" y1="2.55614375" x2="19.00070625" y2="2.57379375" layer="1"/>
<rectangle x1="0.13195" y1="2.57379375" x2="1.61461875" y2="2.59144375" layer="1"/>
<rectangle x1="2.267703125" y1="2.57379375" x2="3.785671875" y2="2.59144375" layer="1"/>
<rectangle x1="4.209296875" y1="2.57379375" x2="5.727265625" y2="2.59144375" layer="1"/>
<rectangle x1="6.415653125" y1="2.57379375" x2="7.898321875" y2="2.59144375" layer="1"/>
<rectangle x1="8.516103125" y1="2.57379375" x2="10.034071875" y2="2.59144375" layer="1"/>
<rectangle x1="10.457696875" y1="2.57379375" x2="11.975665625" y2="2.59144375" layer="1"/>
<rectangle x1="12.964115625" y1="2.57379375" x2="14.023165625" y2="2.59144375" layer="1"/>
<rectangle x1="14.870409375" y1="2.57379375" x2="15.382284375" y2="2.59144375" layer="1"/>
<rectangle x1="16.706096875" y1="2.57379375" x2="17.306221875" y2="2.59144375" layer="1"/>
<rectangle x1="18.277021875" y1="2.57379375" x2="18.983053125" y2="2.59144375" layer="1"/>
<rectangle x1="0.1143" y1="2.591446875" x2="1.63226875" y2="2.609096875" layer="1"/>
<rectangle x1="2.285353125" y1="2.591446875" x2="3.873928125" y2="2.609096875" layer="1"/>
<rectangle x1="4.13869375" y1="2.591446875" x2="5.72726875" y2="2.609096875" layer="1"/>
<rectangle x1="6.415653125" y1="2.591446875" x2="7.915971875" y2="2.609096875" layer="1"/>
<rectangle x1="8.533753125" y1="2.591446875" x2="10.122328125" y2="2.609096875" layer="1"/>
<rectangle x1="10.36944375" y1="2.591446875" x2="11.95801875" y2="2.609096875" layer="1"/>
<rectangle x1="12.964115625" y1="2.591446875" x2="14.058465625" y2="2.609096875" layer="1"/>
<rectangle x1="14.83510625" y1="2.591446875" x2="15.38228125" y2="2.609096875" layer="1"/>
<rectangle x1="16.706096875" y1="2.591446875" x2="17.341528125" y2="2.609096875" layer="1"/>
<rectangle x1="18.22406875" y1="2.591446875" x2="18.98305625" y2="2.609096875" layer="1"/>
<rectangle x1="0.09665" y1="2.609096875" x2="1.63226875" y2="2.626746875" layer="1"/>
<rectangle x1="2.30300625" y1="2.609096875" x2="5.70961875" y2="2.626746875" layer="1"/>
<rectangle x1="6.398003125" y1="2.609096875" x2="7.933621875" y2="2.626746875" layer="1"/>
<rectangle x1="8.533753125" y1="2.609096875" x2="11.940365625" y2="2.626746875" layer="1"/>
<rectangle x1="12.98176875" y1="2.609096875" x2="14.09376875" y2="2.626746875" layer="1"/>
<rectangle x1="14.782153125" y1="2.609096875" x2="15.382284375" y2="2.626746875" layer="1"/>
<rectangle x1="16.706096875" y1="2.609096875" x2="17.394478125" y2="2.626746875" layer="1"/>
<rectangle x1="18.171115625" y1="2.609096875" x2="18.965403125" y2="2.626746875" layer="1"/>
<rectangle x1="0.09665" y1="2.626746875" x2="1.649925" y2="2.644396875" layer="1"/>
<rectangle x1="2.30300625" y1="2.626746875" x2="5.69196875" y2="2.644396875" layer="1"/>
<rectangle x1="6.38035" y1="2.626746875" x2="7.951275" y2="2.644396875" layer="1"/>
<rectangle x1="8.55140625" y1="2.626746875" x2="11.94036875" y2="2.644396875" layer="1"/>
<rectangle x1="12.98176875" y1="2.626746875" x2="14.146725" y2="2.644396875" layer="1"/>
<rectangle x1="14.746853125" y1="2.626746875" x2="15.382284375" y2="2.644396875" layer="1"/>
<rectangle x1="16.706096875" y1="2.626746875" x2="17.465084375" y2="2.644396875" layer="1"/>
<rectangle x1="18.1005125" y1="2.626746875" x2="18.94775" y2="2.644396875" layer="1"/>
<rectangle x1="0.078996875" y1="2.644396875" x2="1.667571875" y2="2.662046875" layer="1"/>
<rectangle x1="2.32065625" y1="2.644396875" x2="5.69196875" y2="2.662046875" layer="1"/>
<rectangle x1="6.38035" y1="2.644396875" x2="7.951275" y2="2.662046875" layer="1"/>
<rectangle x1="8.55140625" y1="2.644396875" x2="11.9227125" y2="2.662046875" layer="1"/>
<rectangle x1="12.99941875" y1="2.644396875" x2="14.199675" y2="2.662046875" layer="1"/>
<rectangle x1="14.67625" y1="2.644396875" x2="17.5356875" y2="2.662046875" layer="1"/>
<rectangle x1="18.029909375" y1="2.644396875" x2="18.947753125" y2="2.662046875" layer="1"/>
<rectangle x1="0.061346875" y1="2.66205" x2="1.667571875" y2="2.6797" layer="1"/>
<rectangle x1="2.33830625" y1="2.66205" x2="5.6743125" y2="2.6797" layer="1"/>
<rectangle x1="6.3627" y1="2.66205" x2="7.968925" y2="2.6797" layer="1"/>
<rectangle x1="8.56905625" y1="2.66205" x2="11.9227125" y2="2.6797" layer="1"/>
<rectangle x1="13.01706875" y1="2.66205" x2="14.30558125" y2="2.6797" layer="1"/>
<rectangle x1="14.57034375" y1="2.66205" x2="17.67689375" y2="2.6797" layer="1"/>
<rectangle x1="17.888703125" y1="2.66205" x2="18.930103125" y2="2.6797" layer="1"/>
<rectangle x1="0.061346875" y1="2.6797" x2="1.685221875" y2="2.69735" layer="1"/>
<rectangle x1="2.33830625" y1="2.6797" x2="5.6566625" y2="2.69735" layer="1"/>
<rectangle x1="6.3627" y1="2.6797" x2="7.968925" y2="2.69735" layer="1"/>
<rectangle x1="8.58670625" y1="2.6797" x2="11.9050625" y2="2.69735" layer="1"/>
<rectangle x1="13.01706875" y1="2.6797" x2="18.9301" y2="2.69735" layer="1"/>
<rectangle x1="0.043696875" y1="2.69735" x2="1.685221875" y2="2.715" layer="1"/>
<rectangle x1="2.35595625" y1="2.69735" x2="5.6566625" y2="2.715" layer="1"/>
<rectangle x1="6.34505" y1="2.69735" x2="7.986575" y2="2.715" layer="1"/>
<rectangle x1="8.58670625" y1="2.69735" x2="11.8874125" y2="2.715" layer="1"/>
<rectangle x1="13.034721875" y1="2.69735" x2="18.912453125" y2="2.715" layer="1"/>
<rectangle x1="0.043696875" y1="2.715003125" x2="1.702871875" y2="2.732653125" layer="1"/>
<rectangle x1="2.373609375" y1="2.715003125" x2="5.639015625" y2="2.732653125" layer="1"/>
<rectangle x1="6.34505" y1="2.715003125" x2="7.986575" y2="2.732653125" layer="1"/>
<rectangle x1="8.60435625" y1="2.715003125" x2="11.8697625" y2="2.732653125" layer="1"/>
<rectangle x1="13.034721875" y1="2.715003125" x2="18.894803125" y2="2.732653125" layer="1"/>
<rectangle x1="0.043696875" y1="2.732653125" x2="1.702871875" y2="2.750303125" layer="1"/>
<rectangle x1="2.373609375" y1="2.732653125" x2="5.621365625" y2="2.750303125" layer="1"/>
<rectangle x1="6.327396875" y1="2.732653125" x2="8.004228125" y2="2.750303125" layer="1"/>
<rectangle x1="8.622009375" y1="2.732653125" x2="11.869765625" y2="2.750303125" layer="1"/>
<rectangle x1="13.052371875" y1="2.732653125" x2="18.894803125" y2="2.750303125" layer="1"/>
<rectangle x1="0.026046875" y1="2.750303125" x2="1.702871875" y2="2.767953125" layer="1"/>
<rectangle x1="2.391259375" y1="2.750303125" x2="5.603709375" y2="2.767953125" layer="1"/>
<rectangle x1="6.327396875" y1="2.750303125" x2="8.004228125" y2="2.767953125" layer="1"/>
<rectangle x1="8.639659375" y1="2.750303125" x2="11.852109375" y2="2.767953125" layer="1"/>
<rectangle x1="13.070021875" y1="2.750303125" x2="18.877146875" y2="2.767953125" layer="1"/>
<rectangle x1="0.026046875" y1="2.767953125" x2="1.720528125" y2="2.785603125" layer="1"/>
<rectangle x1="2.408909375" y1="2.767953125" x2="5.603709375" y2="2.785603125" layer="1"/>
<rectangle x1="6.327396875" y1="2.767953125" x2="8.004228125" y2="2.785603125" layer="1"/>
<rectangle x1="8.639659375" y1="2.767953125" x2="11.834459375" y2="2.785603125" layer="1"/>
<rectangle x1="13.087671875" y1="2.767953125" x2="18.859496875" y2="2.785603125" layer="1"/>
<rectangle x1="0.026046875" y1="2.78560625" x2="1.720528125" y2="2.80325625" layer="1"/>
<rectangle x1="2.4265625" y1="2.78560625" x2="5.5860625" y2="2.80325625" layer="1"/>
<rectangle x1="6.309746875" y1="2.78560625" x2="8.021878125" y2="2.80325625" layer="1"/>
<rectangle x1="8.657309375" y1="2.78560625" x2="11.816809375" y2="2.80325625" layer="1"/>
<rectangle x1="13.087671875" y1="2.78560625" x2="18.859496875" y2="2.80325625" layer="1"/>
<rectangle x1="0.00839375" y1="2.80325625" x2="1.720525" y2="2.82090625" layer="1"/>
<rectangle x1="2.4442125" y1="2.80325625" x2="5.5684125" y2="2.82090625" layer="1"/>
<rectangle x1="6.309746875" y1="2.80325625" x2="8.021878125" y2="2.82090625" layer="1"/>
<rectangle x1="8.6749625" y1="2.80325625" x2="11.8168125" y2="2.82090625" layer="1"/>
<rectangle x1="13.105325" y1="2.80325625" x2="18.84185" y2="2.82090625" layer="1"/>
<rectangle x1="0.00839375" y1="2.82090625" x2="1.720525" y2="2.83855625" layer="1"/>
<rectangle x1="2.4442125" y1="2.82090625" x2="5.5507625" y2="2.83855625" layer="1"/>
<rectangle x1="6.309746875" y1="2.82090625" x2="8.021878125" y2="2.83855625" layer="1"/>
<rectangle x1="8.6926125" y1="2.82090625" x2="11.7991625" y2="2.83855625" layer="1"/>
<rectangle x1="13.122975" y1="2.82090625" x2="18.82419375" y2="2.83855625" layer="1"/>
<rectangle x1="0.00839375" y1="2.83855625" x2="1.720525" y2="2.85620625" layer="1"/>
<rectangle x1="2.4618625" y1="2.83855625" x2="5.53310625" y2="2.85620625" layer="1"/>
<rectangle x1="6.309746875" y1="2.83855625" x2="8.021878125" y2="2.85620625" layer="1"/>
<rectangle x1="8.7102625" y1="2.83855625" x2="11.78150625" y2="2.85620625" layer="1"/>
<rectangle x1="13.122975" y1="2.83855625" x2="18.80654375" y2="2.85620625" layer="1"/>
<rectangle x1="0.00839375" y1="2.856209375" x2="1.738175" y2="2.873859375" layer="1"/>
<rectangle x1="2.4795125" y1="2.856209375" x2="5.53310625" y2="2.873859375" layer="1"/>
<rectangle x1="6.309746875" y1="2.856209375" x2="8.021878125" y2="2.873859375" layer="1"/>
<rectangle x1="8.7279125" y1="2.856209375" x2="11.76385625" y2="2.873859375" layer="1"/>
<rectangle x1="13.140625" y1="2.856209375" x2="18.80654375" y2="2.873859375" layer="1"/>
<rectangle x1="0.00839375" y1="2.873859375" x2="1.738175" y2="2.891509375" layer="1"/>
<rectangle x1="2.497165625" y1="2.873859375" x2="5.515459375" y2="2.891509375" layer="1"/>
<rectangle x1="6.292096875" y1="2.873859375" x2="8.021878125" y2="2.891509375" layer="1"/>
<rectangle x1="8.7279125" y1="2.873859375" x2="11.74620625" y2="2.891509375" layer="1"/>
<rectangle x1="13.158275" y1="2.873859375" x2="18.78889375" y2="2.891509375" layer="1"/>
<rectangle x1="0.00839375" y1="2.891509375" x2="1.738175" y2="2.909159375" layer="1"/>
<rectangle x1="2.514815625" y1="2.891509375" x2="5.497809375" y2="2.909159375" layer="1"/>
<rectangle x1="6.292096875" y1="2.891509375" x2="8.021878125" y2="2.909159375" layer="1"/>
<rectangle x1="8.745565625" y1="2.891509375" x2="11.728553125" y2="2.909159375" layer="1"/>
<rectangle x1="13.175928125" y1="2.891509375" x2="18.771246875" y2="2.909159375" layer="1"/>
<rectangle x1="0.00839375" y1="2.9091625" x2="1.738175" y2="2.9268125" layer="1"/>
<rectangle x1="2.532465625" y1="2.9091625" x2="5.480153125" y2="2.9268125" layer="1"/>
<rectangle x1="6.292096875" y1="2.9091625" x2="8.039528125" y2="2.9268125" layer="1"/>
<rectangle x1="8.763215625" y1="2.9091625" x2="11.710903125" y2="2.9268125" layer="1"/>
<rectangle x1="13.193578125" y1="2.9091625" x2="18.753590625" y2="2.9268125" layer="1"/>
<rectangle x1="0.00839375" y1="2.9268125" x2="1.738175" y2="2.9444625" layer="1"/>
<rectangle x1="2.550115625" y1="2.9268125" x2="5.462503125" y2="2.9444625" layer="1"/>
<rectangle x1="6.292096875" y1="2.9268125" x2="8.039528125" y2="2.9444625" layer="1"/>
<rectangle x1="8.780865625" y1="2.9268125" x2="11.693253125" y2="2.9444625" layer="1"/>
<rectangle x1="13.211228125" y1="2.9268125" x2="18.735940625" y2="2.9444625" layer="1"/>
<rectangle x1="0.00839375" y1="2.9444625" x2="1.738175" y2="2.9621125" layer="1"/>
<rectangle x1="2.56776875" y1="2.9444625" x2="5.44485625" y2="2.9621125" layer="1"/>
<rectangle x1="6.292096875" y1="2.9444625" x2="8.039528125" y2="2.9621125" layer="1"/>
<rectangle x1="8.798515625" y1="2.9444625" x2="11.675603125" y2="2.9621125" layer="1"/>
<rectangle x1="13.211228125" y1="2.9444625" x2="18.718290625" y2="2.9621125" layer="1"/>
<rectangle x1="0.00839375" y1="2.9621125" x2="1.738175" y2="2.9797625" layer="1"/>
<rectangle x1="2.58541875" y1="2.9621125" x2="5.42720625" y2="2.9797625" layer="1"/>
<rectangle x1="6.292096875" y1="2.9621125" x2="8.039528125" y2="2.9797625" layer="1"/>
<rectangle x1="8.81616875" y1="2.9621125" x2="11.65795" y2="2.9797625" layer="1"/>
<rectangle x1="13.228878125" y1="2.9621125" x2="18.718290625" y2="2.9797625" layer="1"/>
<rectangle x1="0.00839375" y1="2.979765625" x2="1.738175" y2="2.997415625" layer="1"/>
<rectangle x1="2.60306875" y1="2.979765625" x2="5.40955" y2="2.997415625" layer="1"/>
<rectangle x1="6.292096875" y1="2.979765625" x2="8.039528125" y2="2.997415625" layer="1"/>
<rectangle x1="8.83381875" y1="2.979765625" x2="11.6403" y2="2.997415625" layer="1"/>
<rectangle x1="13.24653125" y1="2.979765625" x2="18.70064375" y2="2.997415625" layer="1"/>
<rectangle x1="0.00839375" y1="2.997415625" x2="1.738175" y2="3.015065625" layer="1"/>
<rectangle x1="2.620721875" y1="2.997415625" x2="5.391903125" y2="3.015065625" layer="1"/>
<rectangle x1="6.292096875" y1="2.997415625" x2="8.021878125" y2="3.015065625" layer="1"/>
<rectangle x1="8.85146875" y1="2.997415625" x2="11.62265" y2="3.015065625" layer="1"/>
<rectangle x1="13.26418125" y1="2.997415625" x2="18.6829875" y2="3.015065625" layer="1"/>
<rectangle x1="0.00839375" y1="3.015065625" x2="1.738175" y2="3.032715625" layer="1"/>
<rectangle x1="2.638371875" y1="3.015065625" x2="5.374253125" y2="3.032715625" layer="1"/>
<rectangle x1="6.292096875" y1="3.015065625" x2="8.021878125" y2="3.032715625" layer="1"/>
<rectangle x1="8.886771875" y1="3.015065625" x2="11.605003125" y2="3.032715625" layer="1"/>
<rectangle x1="13.28183125" y1="3.015065625" x2="18.6653375" y2="3.032715625" layer="1"/>
<rectangle x1="0.00839375" y1="3.032715625" x2="1.738175" y2="3.050365625" layer="1"/>
<rectangle x1="2.656021875" y1="3.032715625" x2="5.356603125" y2="3.050365625" layer="1"/>
<rectangle x1="6.309746875" y1="3.032715625" x2="8.021878125" y2="3.050365625" layer="1"/>
<rectangle x1="8.904421875" y1="3.032715625" x2="11.587346875" y2="3.050365625" layer="1"/>
<rectangle x1="13.299484375" y1="3.032715625" x2="18.647690625" y2="3.050365625" layer="1"/>
<rectangle x1="0.00839375" y1="3.05036875" x2="1.720525" y2="3.06801875" layer="1"/>
<rectangle x1="2.673671875" y1="3.05036875" x2="5.321296875" y2="3.06801875" layer="1"/>
<rectangle x1="6.309746875" y1="3.05036875" x2="8.021878125" y2="3.06801875" layer="1"/>
<rectangle x1="8.922071875" y1="3.05036875" x2="11.569696875" y2="3.06801875" layer="1"/>
<rectangle x1="13.317134375" y1="3.05036875" x2="18.612384375" y2="3.06801875" layer="1"/>
<rectangle x1="0.00839375" y1="3.06801875" x2="1.720525" y2="3.08566875" layer="1"/>
<rectangle x1="2.708975" y1="3.06801875" x2="5.30365" y2="3.08566875" layer="1"/>
<rectangle x1="6.309746875" y1="3.06801875" x2="8.021878125" y2="3.08566875" layer="1"/>
<rectangle x1="8.939725" y1="3.06801875" x2="11.55205" y2="3.08566875" layer="1"/>
<rectangle x1="13.334784375" y1="3.06801875" x2="18.594734375" y2="3.08566875" layer="1"/>
<rectangle x1="0.026046875" y1="3.08566875" x2="1.720528125" y2="3.10331875" layer="1"/>
<rectangle x1="2.726625" y1="3.08566875" x2="5.28599375" y2="3.10331875" layer="1"/>
<rectangle x1="6.309746875" y1="3.08566875" x2="8.021878125" y2="3.10331875" layer="1"/>
<rectangle x1="8.957375" y1="3.08566875" x2="11.51674375" y2="3.10331875" layer="1"/>
<rectangle x1="13.3700875" y1="3.08566875" x2="18.5770875" y2="3.10331875" layer="1"/>
<rectangle x1="0.026046875" y1="3.103321875" x2="1.720528125" y2="3.120971875" layer="1"/>
<rectangle x1="2.744275" y1="3.103321875" x2="5.26834375" y2="3.120971875" layer="1"/>
<rectangle x1="6.309746875" y1="3.103321875" x2="8.004228125" y2="3.120971875" layer="1"/>
<rectangle x1="8.992675" y1="3.103321875" x2="11.49909375" y2="3.120971875" layer="1"/>
<rectangle x1="13.3877375" y1="3.103321875" x2="18.55943125" y2="3.120971875" layer="1"/>
<rectangle x1="0.026046875" y1="3.120971875" x2="1.720528125" y2="3.138621875" layer="1"/>
<rectangle x1="2.761928125" y1="3.120971875" x2="5.233046875" y2="3.138621875" layer="1"/>
<rectangle x1="6.327396875" y1="3.120971875" x2="8.004228125" y2="3.138621875" layer="1"/>
<rectangle x1="9.010328125" y1="3.120971875" x2="11.481446875" y2="3.138621875" layer="1"/>
<rectangle x1="13.4053875" y1="3.120971875" x2="18.54178125" y2="3.138621875" layer="1"/>
<rectangle x1="0.026046875" y1="3.138621875" x2="1.702871875" y2="3.156271875" layer="1"/>
<rectangle x1="2.797228125" y1="3.138621875" x2="5.215390625" y2="3.156271875" layer="1"/>
<rectangle x1="6.327396875" y1="3.138621875" x2="8.004228125" y2="3.156271875" layer="1"/>
<rectangle x1="9.027978125" y1="3.138621875" x2="11.446140625" y2="3.156271875" layer="1"/>
<rectangle x1="13.4230375" y1="3.138621875" x2="18.52413125" y2="3.156271875" layer="1"/>
<rectangle x1="0.043696875" y1="3.156271875" x2="1.702871875" y2="3.173921875" layer="1"/>
<rectangle x1="2.814878125" y1="3.156271875" x2="5.180090625" y2="3.173921875" layer="1"/>
<rectangle x1="6.327396875" y1="3.156271875" x2="8.004228125" y2="3.173921875" layer="1"/>
<rectangle x1="9.063278125" y1="3.156271875" x2="11.428490625" y2="3.173921875" layer="1"/>
<rectangle x1="13.458340625" y1="3.156271875" x2="18.488828125" y2="3.173921875" layer="1"/>
<rectangle x1="0.043696875" y1="3.173925" x2="1.685221875" y2="3.191575" layer="1"/>
<rectangle x1="2.85018125" y1="3.173925" x2="5.16244375" y2="3.191575" layer="1"/>
<rectangle x1="6.34505" y1="3.173925" x2="7.986575" y2="3.191575" layer="1"/>
<rectangle x1="9.08093125" y1="3.173925" x2="11.3931875" y2="3.191575" layer="1"/>
<rectangle x1="13.475990625" y1="3.173925" x2="18.471178125" y2="3.191575" layer="1"/>
<rectangle x1="0.061346875" y1="3.191575" x2="1.685221875" y2="3.209225" layer="1"/>
<rectangle x1="2.86783125" y1="3.191575" x2="5.1271375" y2="3.209225" layer="1"/>
<rectangle x1="6.34505" y1="3.191575" x2="7.986575" y2="3.209225" layer="1"/>
<rectangle x1="9.11623125" y1="3.191575" x2="11.3755375" y2="3.209225" layer="1"/>
<rectangle x1="13.49364375" y1="3.191575" x2="18.45353125" y2="3.209225" layer="1"/>
<rectangle x1="0.061346875" y1="3.209225" x2="1.685221875" y2="3.226875" layer="1"/>
<rectangle x1="2.903134375" y1="3.209225" x2="5.109490625" y2="3.226875" layer="1"/>
<rectangle x1="6.3627" y1="3.209225" x2="7.968925" y2="3.226875" layer="1"/>
<rectangle x1="9.133884375" y1="3.209225" x2="11.340234375" y2="3.226875" layer="1"/>
<rectangle x1="13.52894375" y1="3.209225" x2="18.418225" y2="3.226875" layer="1"/>
<rectangle x1="0.078996875" y1="3.226875" x2="1.667571875" y2="3.244525" layer="1"/>
<rectangle x1="2.920784375" y1="3.226875" x2="5.074184375" y2="3.244525" layer="1"/>
<rectangle x1="6.3627" y1="3.226875" x2="7.968925" y2="3.244525" layer="1"/>
<rectangle x1="9.169184375" y1="3.226875" x2="11.322584375" y2="3.244525" layer="1"/>
<rectangle x1="13.54659375" y1="3.226875" x2="18.400575" y2="3.244525" layer="1"/>
<rectangle x1="0.078996875" y1="3.244528125" x2="1.649921875" y2="3.262178125" layer="1"/>
<rectangle x1="2.9560875" y1="3.244528125" x2="5.0565375" y2="3.262178125" layer="1"/>
<rectangle x1="6.38035" y1="3.244528125" x2="7.951275" y2="3.262178125" layer="1"/>
<rectangle x1="9.2044875" y1="3.244528125" x2="11.2872875" y2="3.262178125" layer="1"/>
<rectangle x1="13.581896875" y1="3.244528125" x2="18.365271875" y2="3.262178125" layer="1"/>
<rectangle x1="0.09665" y1="3.262178125" x2="1.649925" y2="3.279828125" layer="1"/>
<rectangle x1="2.9913875" y1="3.262178125" x2="5.02123125" y2="3.279828125" layer="1"/>
<rectangle x1="6.38035" y1="3.262178125" x2="7.951275" y2="3.279828125" layer="1"/>
<rectangle x1="9.2221375" y1="3.262178125" x2="11.25198125" y2="3.279828125" layer="1"/>
<rectangle x1="13.599546875" y1="3.262178125" x2="18.347621875" y2="3.279828125" layer="1"/>
<rectangle x1="0.09665" y1="3.279828125" x2="1.63226875" y2="3.297478125" layer="1"/>
<rectangle x1="3.026690625" y1="3.279828125" x2="4.985934375" y2="3.297478125" layer="1"/>
<rectangle x1="6.398003125" y1="3.279828125" x2="7.933621875" y2="3.297478125" layer="1"/>
<rectangle x1="9.2574375" y1="3.279828125" x2="11.21668125" y2="3.297478125" layer="1"/>
<rectangle x1="13.63485" y1="3.279828125" x2="18.312325" y2="3.297478125" layer="1"/>
<rectangle x1="0.1143" y1="3.297478125" x2="1.61461875" y2="3.315128125" layer="1"/>
<rectangle x1="3.061990625" y1="3.297478125" x2="4.950628125" y2="3.315128125" layer="1"/>
<rectangle x1="6.415653125" y1="3.297478125" x2="7.915971875" y2="3.315128125" layer="1"/>
<rectangle x1="9.292740625" y1="3.297478125" x2="11.199028125" y2="3.315128125" layer="1"/>
<rectangle x1="13.67015" y1="3.297478125" x2="18.27701875" y2="3.315128125" layer="1"/>
<rectangle x1="0.13195" y1="3.31513125" x2="1.61461875" y2="3.33278125" layer="1"/>
<rectangle x1="3.09729375" y1="3.31513125" x2="4.91533125" y2="3.33278125" layer="1"/>
<rectangle x1="6.433303125" y1="3.31513125" x2="7.898321875" y2="3.33278125" layer="1"/>
<rectangle x1="9.32804375" y1="3.31513125" x2="11.146075" y2="3.33278125" layer="1"/>
<rectangle x1="13.705453125" y1="3.31513125" x2="18.241721875" y2="3.33278125" layer="1"/>
<rectangle x1="0.149603125" y1="3.33278125" x2="1.596971875" y2="3.35043125" layer="1"/>
<rectangle x1="3.13259375" y1="3.33278125" x2="4.880025" y2="3.35043125" layer="1"/>
<rectangle x1="6.433303125" y1="3.33278125" x2="7.880671875" y2="3.35043125" layer="1"/>
<rectangle x1="9.36334375" y1="3.33278125" x2="11.110775" y2="3.35043125" layer="1"/>
<rectangle x1="13.740753125" y1="3.33278125" x2="18.206415625" y2="3.35043125" layer="1"/>
<rectangle x1="0.167253125" y1="3.35043125" x2="1.579321875" y2="3.36808125" layer="1"/>
<rectangle x1="3.167896875" y1="3.35043125" x2="4.844728125" y2="3.36808125" layer="1"/>
<rectangle x1="6.450953125" y1="3.35043125" x2="7.863021875" y2="3.36808125" layer="1"/>
<rectangle x1="9.416296875" y1="3.35043125" x2="11.075471875" y2="3.36808125" layer="1"/>
<rectangle x1="13.77605625" y1="3.35043125" x2="18.1711125" y2="3.36808125" layer="1"/>
<rectangle x1="0.184903125" y1="3.368084375" x2="1.561665625" y2="3.385734375" layer="1"/>
<rectangle x1="3.203196875" y1="3.368084375" x2="4.791771875" y2="3.385734375" layer="1"/>
<rectangle x1="6.48625625" y1="3.368084375" x2="7.84536875" y2="3.385734375" layer="1"/>
<rectangle x1="9.451596875" y1="3.368084375" x2="11.040171875" y2="3.385734375" layer="1"/>
<rectangle x1="13.81135625" y1="3.368084375" x2="18.1358125" y2="3.385734375" layer="1"/>
<rectangle x1="0.202553125" y1="3.385734375" x2="1.526365625" y2="3.403384375" layer="1"/>
<rectangle x1="3.25615" y1="3.385734375" x2="4.75646875" y2="3.403384375" layer="1"/>
<rectangle x1="6.50390625" y1="3.385734375" x2="7.82771875" y2="3.403384375" layer="1"/>
<rectangle x1="9.50455" y1="3.385734375" x2="10.98721875" y2="3.403384375" layer="1"/>
<rectangle x1="13.846659375" y1="3.385734375" x2="18.100509375" y2="3.403384375" layer="1"/>
<rectangle x1="0.23785625" y1="3.403384375" x2="1.5087125" y2="3.421034375" layer="1"/>
<rectangle x1="3.309103125" y1="3.403384375" x2="4.703521875" y2="3.421034375" layer="1"/>
<rectangle x1="6.52155625" y1="3.403384375" x2="7.79241875" y2="3.421034375" layer="1"/>
<rectangle x1="9.539853125" y1="3.403384375" x2="10.934265625" y2="3.421034375" layer="1"/>
<rectangle x1="13.8996125" y1="3.403384375" x2="18.0475625" y2="3.421034375" layer="1"/>
<rectangle x1="0.27315625" y1="3.421034375" x2="1.4734125" y2="3.438684375" layer="1"/>
<rectangle x1="3.36205625" y1="3.421034375" x2="4.65056875" y2="3.438684375" layer="1"/>
<rectangle x1="6.556859375" y1="3.421034375" x2="7.774765625" y2="3.438684375" layer="1"/>
<rectangle x1="9.59280625" y1="3.421034375" x2="10.8813125" y2="3.438684375" layer="1"/>
<rectangle x1="13.9349125" y1="3.421034375" x2="17.99460625" y2="3.438684375" layer="1"/>
<rectangle x1="0.308459375" y1="3.4386875" x2="1.438109375" y2="3.4563375" layer="1"/>
<rectangle x1="3.415009375" y1="3.4386875" x2="4.579965625" y2="3.4563375" layer="1"/>
<rectangle x1="6.5921625" y1="3.4386875" x2="7.7218125" y2="3.4563375" layer="1"/>
<rectangle x1="9.663409375" y1="3.4386875" x2="10.828365625" y2="3.4563375" layer="1"/>
<rectangle x1="13.987865625" y1="3.4386875" x2="17.941653125" y2="3.4563375" layer="1"/>
<rectangle x1="0.3614125" y1="3.4563375" x2="1.36750625" y2="3.4739875" layer="1"/>
<rectangle x1="3.4856125" y1="3.4563375" x2="4.5270125" y2="3.4739875" layer="1"/>
<rectangle x1="6.662765625" y1="3.4563375" x2="7.668859375" y2="3.4739875" layer="1"/>
<rectangle x1="9.7163625" y1="3.4563375" x2="10.7577625" y2="3.4739875" layer="1"/>
<rectangle x1="14.05846875" y1="3.4563375" x2="17.8887" y2="3.4739875" layer="1"/>
<rectangle x1="3.556215625" y1="3.4739875" x2="4.438753125" y2="3.4916375" layer="1"/>
<rectangle x1="9.804615625" y1="3.4739875" x2="10.687153125" y2="3.4916375" layer="1"/>
<rectangle x1="14.129071875" y1="3.4739875" x2="17.818096875" y2="3.4916375" layer="1"/>
<rectangle x1="3.662121875" y1="3.4916375" x2="4.350503125" y2="3.5092875" layer="1"/>
<rectangle x1="9.89286875" y1="3.4916375" x2="10.58125" y2="3.5092875" layer="1"/>
<rectangle x1="14.217328125" y1="3.4916375" x2="17.729846875" y2="3.5092875" layer="1"/>
<rectangle x1="3.803328125" y1="3.509290625" x2="4.209296875" y2="3.526940625" layer="1"/>
<rectangle x1="10.034075" y1="3.509290625" x2="10.44004375" y2="3.526940625" layer="1"/>
<rectangle x1="14.340884375" y1="3.509290625" x2="17.606290625" y2="3.526940625" layer="1"/>
<rectangle x1="3.715071875" y1="-0.07383125" x2="4.279896875" y2="-0.05618125" layer="29"/>
<rectangle x1="9.963471875" y1="-0.07383125" x2="10.528296875" y2="-0.05618125" layer="29"/>
<rectangle x1="3.60916875" y1="-0.05618125" x2="4.40345625" y2="-0.03853125" layer="29"/>
<rectangle x1="9.839915625" y1="-0.05618125" x2="10.634203125" y2="-0.03853125" layer="29"/>
<rectangle x1="3.5209125" y1="-0.03853125" x2="4.49170625" y2="-0.02088125" layer="29"/>
<rectangle x1="9.7693125" y1="-0.03853125" x2="10.72245625" y2="-0.02088125" layer="29"/>
<rectangle x1="3.450309375" y1="-0.020878125" x2="4.562309375" y2="-0.003228125" layer="29"/>
<rectangle x1="9.698709375" y1="-0.020878125" x2="10.793059375" y2="-0.003228125" layer="29"/>
<rectangle x1="0.3437625" y1="-0.003228125" x2="1.4028125" y2="0.014421875" layer="29"/>
<rectangle x1="3.39735625" y1="-0.003228125" x2="4.6152625" y2="0.014421875" layer="29"/>
<rectangle x1="6.6274625" y1="-0.003228125" x2="7.7041625" y2="0.014421875" layer="29"/>
<rectangle x1="9.62810625" y1="-0.003228125" x2="10.8636625" y2="0.014421875" layer="29"/>
<rectangle x1="14.28793125" y1="-0.003228125" x2="17.65924375" y2="0.014421875" layer="29"/>
<rectangle x1="0.290809375" y1="0.014421875" x2="1.455765625" y2="0.032071875" layer="29"/>
<rectangle x1="3.326753125" y1="0.014421875" x2="4.668215625" y2="0.032071875" layer="29"/>
<rectangle x1="6.574509375" y1="0.014421875" x2="7.739465625" y2="0.032071875" layer="29"/>
<rectangle x1="9.575153125" y1="0.014421875" x2="10.916615625" y2="0.032071875" layer="29"/>
<rectangle x1="14.182025" y1="0.014421875" x2="17.76514375" y2="0.032071875" layer="29"/>
<rectangle x1="0.25550625" y1="0.032071875" x2="1.4910625" y2="0.049721875" layer="29"/>
<rectangle x1="3.273803125" y1="0.032071875" x2="4.721171875" y2="0.049721875" layer="29"/>
<rectangle x1="6.539209375" y1="0.032071875" x2="7.774765625" y2="0.049721875" layer="29"/>
<rectangle x1="9.522203125" y1="0.032071875" x2="10.969571875" y2="0.049721875" layer="29"/>
<rectangle x1="14.093771875" y1="0.032071875" x2="17.853403125" y2="0.049721875" layer="29"/>
<rectangle x1="0.22020625" y1="0.049725" x2="1.5087125" y2="0.067375" layer="29"/>
<rectangle x1="3.2385" y1="0.049725" x2="4.774125" y2="0.067375" layer="29"/>
<rectangle x1="6.52155625" y1="0.049725" x2="7.81006875" y2="0.067375" layer="29"/>
<rectangle x1="9.46925" y1="0.049725" x2="11.00486875" y2="0.067375" layer="29"/>
<rectangle x1="14.02316875" y1="0.049725" x2="17.90635" y2="0.067375" layer="29"/>
<rectangle x1="0.202553125" y1="0.067375" x2="1.544015625" y2="0.085025" layer="29"/>
<rectangle x1="3.185546875" y1="0.067375" x2="4.809421875" y2="0.085025" layer="29"/>
<rectangle x1="6.48625625" y1="0.067375" x2="7.84536875" y2="0.085025" layer="29"/>
<rectangle x1="9.433946875" y1="0.067375" x2="11.057821875" y2="0.085025" layer="29"/>
<rectangle x1="13.970215625" y1="0.067375" x2="17.976953125" y2="0.085025" layer="29"/>
<rectangle x1="0.184903125" y1="0.085025" x2="1.561665625" y2="0.102675" layer="29"/>
<rectangle x1="3.150246875" y1="0.085025" x2="4.862378125" y2="0.102675" layer="29"/>
<rectangle x1="6.46860625" y1="0.085025" x2="7.86301875" y2="0.102675" layer="29"/>
<rectangle x1="9.38099375" y1="0.085025" x2="11.093125" y2="0.102675" layer="29"/>
<rectangle x1="13.9172625" y1="0.085025" x2="18.02990625" y2="0.102675" layer="29"/>
<rectangle x1="0.149603125" y1="0.102675" x2="1.579321875" y2="0.120325" layer="29"/>
<rectangle x1="3.11494375" y1="0.102675" x2="4.897675" y2="0.120325" layer="29"/>
<rectangle x1="6.450953125" y1="0.102675" x2="7.880671875" y2="0.120325" layer="29"/>
<rectangle x1="9.34569375" y1="0.102675" x2="11.128425" y2="0.120325" layer="29"/>
<rectangle x1="13.8819625" y1="0.102675" x2="18.0652125" y2="0.120325" layer="29"/>
<rectangle x1="0.149603125" y1="0.120328125" x2="1.596971875" y2="0.137978125" layer="29"/>
<rectangle x1="3.07964375" y1="0.120328125" x2="4.93298125" y2="0.137978125" layer="29"/>
<rectangle x1="6.433303125" y1="0.120328125" x2="7.898321875" y2="0.137978125" layer="29"/>
<rectangle x1="9.310390625" y1="0.120328125" x2="11.163728125" y2="0.137978125" layer="29"/>
<rectangle x1="13.829009375" y1="0.120328125" x2="18.118165625" y2="0.137978125" layer="29"/>
<rectangle x1="0.13195" y1="0.137978125" x2="1.61461875" y2="0.155628125" layer="29"/>
<rectangle x1="3.044340625" y1="0.137978125" x2="4.968284375" y2="0.155628125" layer="29"/>
<rectangle x1="6.415653125" y1="0.137978125" x2="7.915971875" y2="0.155628125" layer="29"/>
<rectangle x1="9.275090625" y1="0.137978125" x2="11.199028125" y2="0.155628125" layer="29"/>
<rectangle x1="13.79370625" y1="0.137978125" x2="18.1534625" y2="0.155628125" layer="29"/>
<rectangle x1="0.1143" y1="0.155628125" x2="1.63226875" y2="0.173278125" layer="29"/>
<rectangle x1="3.0090375" y1="0.155628125" x2="5.00358125" y2="0.173278125" layer="29"/>
<rectangle x1="6.398003125" y1="0.155628125" x2="7.915971875" y2="0.173278125" layer="29"/>
<rectangle x1="9.2397875" y1="0.155628125" x2="11.23433125" y2="0.173278125" layer="29"/>
<rectangle x1="13.75840625" y1="0.155628125" x2="18.18876875" y2="0.173278125" layer="29"/>
<rectangle x1="0.09665" y1="0.173278125" x2="1.63226875" y2="0.190928125" layer="29"/>
<rectangle x1="2.9737375" y1="0.173278125" x2="5.0388875" y2="0.190928125" layer="29"/>
<rectangle x1="6.398003125" y1="0.173278125" x2="7.933621875" y2="0.190928125" layer="29"/>
<rectangle x1="9.2044875" y1="0.173278125" x2="11.26963125" y2="0.190928125" layer="29"/>
<rectangle x1="13.723103125" y1="0.173278125" x2="18.224065625" y2="0.190928125" layer="29"/>
<rectangle x1="0.09665" y1="0.19093125" x2="1.649925" y2="0.20858125" layer="29"/>
<rectangle x1="2.938434375" y1="0.19093125" x2="5.056534375" y2="0.20858125" layer="29"/>
<rectangle x1="6.38035" y1="0.19093125" x2="7.951275" y2="0.20858125" layer="29"/>
<rectangle x1="9.186834375" y1="0.19093125" x2="11.304934375" y2="0.20858125" layer="29"/>
<rectangle x1="13.687803125" y1="0.19093125" x2="18.259371875" y2="0.20858125" layer="29"/>
<rectangle x1="0.078996875" y1="0.20858125" x2="1.667571875" y2="0.22623125" layer="29"/>
<rectangle x1="2.920784375" y1="0.20858125" x2="5.091834375" y2="0.22623125" layer="29"/>
<rectangle x1="6.38035" y1="0.20858125" x2="7.951275" y2="0.22623125" layer="29"/>
<rectangle x1="9.151534375" y1="0.20858125" x2="11.340234375" y2="0.22623125" layer="29"/>
<rectangle x1="13.6525" y1="0.20858125" x2="18.29466875" y2="0.22623125" layer="29"/>
<rectangle x1="0.061346875" y1="0.22623125" x2="1.667571875" y2="0.24388125" layer="29"/>
<rectangle x1="2.885484375" y1="0.22623125" x2="5.127140625" y2="0.24388125" layer="29"/>
<rectangle x1="6.3627" y1="0.22623125" x2="7.968925" y2="0.24388125" layer="29"/>
<rectangle x1="9.11623125" y1="0.22623125" x2="11.3578875" y2="0.24388125" layer="29"/>
<rectangle x1="13.617196875" y1="0.22623125" x2="18.329971875" y2="0.24388125" layer="29"/>
<rectangle x1="0.061346875" y1="0.243884375" x2="1.685221875" y2="0.261534375" layer="29"/>
<rectangle x1="2.85018125" y1="0.243884375" x2="5.1447875" y2="0.261534375" layer="29"/>
<rectangle x1="6.34505" y1="0.243884375" x2="7.968925" y2="0.261534375" layer="29"/>
<rectangle x1="9.09858125" y1="0.243884375" x2="11.3931875" y2="0.261534375" layer="29"/>
<rectangle x1="13.599546875" y1="0.243884375" x2="18.347621875" y2="0.261534375" layer="29"/>
<rectangle x1="0.043696875" y1="0.261534375" x2="1.685221875" y2="0.279184375" layer="29"/>
<rectangle x1="2.83253125" y1="0.261534375" x2="5.18009375" y2="0.279184375" layer="29"/>
<rectangle x1="6.34505" y1="0.261534375" x2="7.986575" y2="0.279184375" layer="29"/>
<rectangle x1="9.063278125" y1="0.261534375" x2="11.410840625" y2="0.279184375" layer="29"/>
<rectangle x1="13.564246875" y1="0.261534375" x2="18.382928125" y2="0.279184375" layer="29"/>
<rectangle x1="0.043696875" y1="0.279184375" x2="1.702871875" y2="0.296834375" layer="29"/>
<rectangle x1="2.797228125" y1="0.279184375" x2="5.197740625" y2="0.296834375" layer="29"/>
<rectangle x1="6.34505" y1="0.279184375" x2="7.986575" y2="0.296834375" layer="29"/>
<rectangle x1="9.045628125" y1="0.279184375" x2="11.446140625" y2="0.296834375" layer="29"/>
<rectangle x1="13.54659375" y1="0.279184375" x2="18.400575" y2="0.296834375" layer="29"/>
<rectangle x1="0.043696875" y1="0.296834375" x2="1.702871875" y2="0.314484375" layer="29"/>
<rectangle x1="2.779578125" y1="0.296834375" x2="5.233046875" y2="0.314484375" layer="29"/>
<rectangle x1="6.327396875" y1="0.296834375" x2="8.004228125" y2="0.314484375" layer="29"/>
<rectangle x1="9.027978125" y1="0.296834375" x2="11.463790625" y2="0.314484375" layer="29"/>
<rectangle x1="13.51129375" y1="0.296834375" x2="18.435875" y2="0.314484375" layer="29"/>
<rectangle x1="0.026046875" y1="0.3144875" x2="1.702871875" y2="0.3321375" layer="29"/>
<rectangle x1="2.761928125" y1="0.3144875" x2="5.250696875" y2="0.3321375" layer="29"/>
<rectangle x1="6.327396875" y1="0.3144875" x2="8.004228125" y2="0.3321375" layer="29"/>
<rectangle x1="8.992675" y1="0.3144875" x2="11.48144375" y2="0.3321375" layer="29"/>
<rectangle x1="13.49364375" y1="0.3144875" x2="18.45353125" y2="0.3321375" layer="29"/>
<rectangle x1="0.026046875" y1="0.3321375" x2="1.720528125" y2="0.3497875" layer="29"/>
<rectangle x1="2.726625" y1="0.3321375" x2="5.26834375" y2="0.3497875" layer="29"/>
<rectangle x1="6.327396875" y1="0.3321375" x2="8.004228125" y2="0.3497875" layer="29"/>
<rectangle x1="8.975025" y1="0.3321375" x2="11.51674375" y2="0.3497875" layer="29"/>
<rectangle x1="13.458340625" y1="0.3321375" x2="18.488828125" y2="0.3497875" layer="29"/>
<rectangle x1="0.026046875" y1="0.3497875" x2="1.720528125" y2="0.3674375" layer="29"/>
<rectangle x1="2.708975" y1="0.3497875" x2="5.28599375" y2="0.3674375" layer="29"/>
<rectangle x1="6.309746875" y1="0.3497875" x2="8.021878125" y2="0.3674375" layer="29"/>
<rectangle x1="8.957375" y1="0.3497875" x2="11.53439375" y2="0.3674375" layer="29"/>
<rectangle x1="13.440690625" y1="0.3497875" x2="18.506484375" y2="0.3674375" layer="29"/>
<rectangle x1="0.00839375" y1="0.3674375" x2="1.720525" y2="0.3850875" layer="29"/>
<rectangle x1="2.691325" y1="0.3674375" x2="5.3213" y2="0.3850875" layer="29"/>
<rectangle x1="6.309746875" y1="0.3674375" x2="8.021878125" y2="0.3850875" layer="29"/>
<rectangle x1="8.922071875" y1="0.3674375" x2="11.552046875" y2="0.3850875" layer="29"/>
<rectangle x1="13.4230375" y1="0.3674375" x2="18.52413125" y2="0.3850875" layer="29"/>
<rectangle x1="0.00839375" y1="0.385090625" x2="1.720525" y2="0.402740625" layer="29"/>
<rectangle x1="2.673671875" y1="0.385090625" x2="5.338946875" y2="0.402740625" layer="29"/>
<rectangle x1="6.309746875" y1="0.385090625" x2="8.021878125" y2="0.402740625" layer="29"/>
<rectangle x1="8.904421875" y1="0.385090625" x2="11.569696875" y2="0.402740625" layer="29"/>
<rectangle x1="13.4053875" y1="0.385090625" x2="18.54178125" y2="0.402740625" layer="29"/>
<rectangle x1="0.00839375" y1="0.402740625" x2="1.738175" y2="0.420390625" layer="29"/>
<rectangle x1="2.656021875" y1="0.402740625" x2="5.356603125" y2="0.420390625" layer="29"/>
<rectangle x1="6.309746875" y1="0.402740625" x2="8.021878125" y2="0.420390625" layer="29"/>
<rectangle x1="8.886771875" y1="0.402740625" x2="11.605003125" y2="0.420390625" layer="29"/>
<rectangle x1="13.3700875" y1="0.402740625" x2="18.5770875" y2="0.420390625" layer="29"/>
<rectangle x1="0.00839375" y1="0.420390625" x2="1.738175" y2="0.438040625" layer="29"/>
<rectangle x1="2.620721875" y1="0.420390625" x2="5.374253125" y2="0.438040625" layer="29"/>
<rectangle x1="6.309746875" y1="0.420390625" x2="8.021878125" y2="0.438040625" layer="29"/>
<rectangle x1="8.869121875" y1="0.420390625" x2="11.622653125" y2="0.438040625" layer="29"/>
<rectangle x1="13.352434375" y1="0.420390625" x2="18.594734375" y2="0.438040625" layer="29"/>
<rectangle x1="0.00839375" y1="0.43804375" x2="1.738175" y2="0.45569375" layer="29"/>
<rectangle x1="2.60306875" y1="0.43804375" x2="5.3919" y2="0.45569375" layer="29"/>
<rectangle x1="6.292096875" y1="0.43804375" x2="8.021878125" y2="0.45569375" layer="29"/>
<rectangle x1="8.85146875" y1="0.43804375" x2="11.6403" y2="0.45569375" layer="29"/>
<rectangle x1="13.334784375" y1="0.43804375" x2="18.612384375" y2="0.45569375" layer="29"/>
<rectangle x1="0.00839375" y1="0.45569375" x2="1.738175" y2="0.47334375" layer="29"/>
<rectangle x1="2.58541875" y1="0.45569375" x2="5.40955" y2="0.47334375" layer="29"/>
<rectangle x1="6.292096875" y1="0.45569375" x2="8.039528125" y2="0.47334375" layer="29"/>
<rectangle x1="8.83381875" y1="0.45569375" x2="11.65795" y2="0.47334375" layer="29"/>
<rectangle x1="13.317134375" y1="0.45569375" x2="18.630034375" y2="0.47334375" layer="29"/>
<rectangle x1="0.00839375" y1="0.47334375" x2="1.738175" y2="0.49099375" layer="29"/>
<rectangle x1="2.56776875" y1="0.47334375" x2="5.42720625" y2="0.49099375" layer="29"/>
<rectangle x1="6.292096875" y1="0.47334375" x2="8.039528125" y2="0.49099375" layer="29"/>
<rectangle x1="8.81616875" y1="0.47334375" x2="11.67560625" y2="0.49099375" layer="29"/>
<rectangle x1="13.299484375" y1="0.47334375" x2="18.647690625" y2="0.49099375" layer="29"/>
<rectangle x1="0.00839375" y1="0.49099375" x2="1.738175" y2="0.50864375" layer="29"/>
<rectangle x1="2.550115625" y1="0.49099375" x2="5.444853125" y2="0.50864375" layer="29"/>
<rectangle x1="6.292096875" y1="0.49099375" x2="8.039528125" y2="0.50864375" layer="29"/>
<rectangle x1="8.798515625" y1="0.49099375" x2="11.693253125" y2="0.50864375" layer="29"/>
<rectangle x1="13.28183125" y1="0.49099375" x2="18.6653375" y2="0.50864375" layer="29"/>
<rectangle x1="0.00839375" y1="0.508646875" x2="1.738175" y2="0.526296875" layer="29"/>
<rectangle x1="2.532465625" y1="0.508646875" x2="5.462503125" y2="0.526296875" layer="29"/>
<rectangle x1="6.292096875" y1="0.508646875" x2="8.039528125" y2="0.526296875" layer="29"/>
<rectangle x1="8.780865625" y1="0.508646875" x2="11.710903125" y2="0.526296875" layer="29"/>
<rectangle x1="13.26418125" y1="0.508646875" x2="18.6829875" y2="0.526296875" layer="29"/>
<rectangle x1="0.00839375" y1="0.526296875" x2="1.738175" y2="0.543946875" layer="29"/>
<rectangle x1="2.514815625" y1="0.526296875" x2="5.480153125" y2="0.543946875" layer="29"/>
<rectangle x1="6.292096875" y1="0.526296875" x2="8.039528125" y2="0.543946875" layer="29"/>
<rectangle x1="8.763215625" y1="0.526296875" x2="11.728553125" y2="0.543946875" layer="29"/>
<rectangle x1="13.24653125" y1="0.526296875" x2="18.70064375" y2="0.543946875" layer="29"/>
<rectangle x1="0.00839375" y1="0.543946875" x2="1.738175" y2="0.561596875" layer="29"/>
<rectangle x1="2.497165625" y1="0.543946875" x2="5.497809375" y2="0.561596875" layer="29"/>
<rectangle x1="6.292096875" y1="0.543946875" x2="8.039528125" y2="0.561596875" layer="29"/>
<rectangle x1="8.745565625" y1="0.543946875" x2="11.746209375" y2="0.561596875" layer="29"/>
<rectangle x1="13.228878125" y1="0.543946875" x2="18.718290625" y2="0.561596875" layer="29"/>
<rectangle x1="0.00839375" y1="0.561596875" x2="1.738175" y2="0.579246875" layer="29"/>
<rectangle x1="2.4795125" y1="0.561596875" x2="5.51545625" y2="0.579246875" layer="29"/>
<rectangle x1="6.292096875" y1="0.561596875" x2="8.021878125" y2="0.579246875" layer="29"/>
<rectangle x1="8.7279125" y1="0.561596875" x2="11.76385625" y2="0.579246875" layer="29"/>
<rectangle x1="13.211228125" y1="0.561596875" x2="18.735940625" y2="0.579246875" layer="29"/>
<rectangle x1="0.00839375" y1="0.57925" x2="1.738175" y2="0.5969" layer="29"/>
<rectangle x1="2.4795125" y1="0.57925" x2="5.53310625" y2="0.5969" layer="29"/>
<rectangle x1="6.292096875" y1="0.57925" x2="8.021878125" y2="0.5969" layer="29"/>
<rectangle x1="8.7102625" y1="0.57925" x2="11.78150625" y2="0.5969" layer="29"/>
<rectangle x1="13.193578125" y1="0.57925" x2="18.753590625" y2="0.5969" layer="29"/>
<rectangle x1="0.00839375" y1="0.5969" x2="1.738175" y2="0.61455" layer="29"/>
<rectangle x1="2.4618625" y1="0.5969" x2="5.5507625" y2="0.61455" layer="29"/>
<rectangle x1="6.309746875" y1="0.5969" x2="8.021878125" y2="0.61455" layer="29"/>
<rectangle x1="8.6926125" y1="0.5969" x2="11.78150625" y2="0.61455" layer="29"/>
<rectangle x1="13.175928125" y1="0.5969" x2="18.771246875" y2="0.61455" layer="29"/>
<rectangle x1="0.00839375" y1="0.61455" x2="1.720525" y2="0.6322" layer="29"/>
<rectangle x1="2.4442125" y1="0.61455" x2="5.5684125" y2="0.6322" layer="29"/>
<rectangle x1="6.309746875" y1="0.61455" x2="8.021878125" y2="0.6322" layer="29"/>
<rectangle x1="8.6749625" y1="0.61455" x2="11.7991625" y2="0.6322" layer="29"/>
<rectangle x1="13.175928125" y1="0.61455" x2="18.771246875" y2="0.6322" layer="29"/>
<rectangle x1="0.00839375" y1="0.632203125" x2="1.720525" y2="0.649853125" layer="29"/>
<rectangle x1="2.4265625" y1="0.632203125" x2="5.5860625" y2="0.649853125" layer="29"/>
<rectangle x1="6.309746875" y1="0.632203125" x2="8.021878125" y2="0.649853125" layer="29"/>
<rectangle x1="8.6749625" y1="0.632203125" x2="11.8168125" y2="0.649853125" layer="29"/>
<rectangle x1="13.158275" y1="0.632203125" x2="18.78889375" y2="0.649853125" layer="29"/>
<rectangle x1="0.026046875" y1="0.649853125" x2="1.720528125" y2="0.667503125" layer="29"/>
<rectangle x1="2.408909375" y1="0.649853125" x2="5.586059375" y2="0.667503125" layer="29"/>
<rectangle x1="6.309746875" y1="0.649853125" x2="8.021878125" y2="0.667503125" layer="29"/>
<rectangle x1="8.657309375" y1="0.649853125" x2="11.834459375" y2="0.667503125" layer="29"/>
<rectangle x1="13.140625" y1="0.649853125" x2="18.80654375" y2="0.667503125" layer="29"/>
<rectangle x1="0.026046875" y1="0.667503125" x2="1.720528125" y2="0.685153125" layer="29"/>
<rectangle x1="2.408909375" y1="0.667503125" x2="5.603709375" y2="0.685153125" layer="29"/>
<rectangle x1="6.309746875" y1="0.667503125" x2="8.004228125" y2="0.685153125" layer="29"/>
<rectangle x1="8.639659375" y1="0.667503125" x2="11.852109375" y2="0.685153125" layer="29"/>
<rectangle x1="13.122975" y1="0.667503125" x2="18.82419375" y2="0.685153125" layer="29"/>
<rectangle x1="0.026046875" y1="0.685153125" x2="1.702871875" y2="0.702803125" layer="29"/>
<rectangle x1="2.391259375" y1="0.685153125" x2="5.621365625" y2="0.702803125" layer="29"/>
<rectangle x1="6.327396875" y1="0.685153125" x2="8.004228125" y2="0.702803125" layer="29"/>
<rectangle x1="8.622009375" y1="0.685153125" x2="11.852109375" y2="0.702803125" layer="29"/>
<rectangle x1="13.105325" y1="0.685153125" x2="18.84185" y2="0.702803125" layer="29"/>
<rectangle x1="0.026046875" y1="0.70280625" x2="1.702871875" y2="0.72045625" layer="29"/>
<rectangle x1="2.373609375" y1="0.70280625" x2="5.639015625" y2="0.72045625" layer="29"/>
<rectangle x1="6.327396875" y1="0.70280625" x2="8.004228125" y2="0.72045625" layer="29"/>
<rectangle x1="8.622009375" y1="0.70280625" x2="11.869765625" y2="0.72045625" layer="29"/>
<rectangle x1="13.105325" y1="0.70280625" x2="18.84185" y2="0.72045625" layer="29"/>
<rectangle x1="0.043696875" y1="0.72045625" x2="1.702871875" y2="0.73810625" layer="29"/>
<rectangle x1="2.35595625" y1="0.72045625" x2="5.6390125" y2="0.73810625" layer="29"/>
<rectangle x1="6.327396875" y1="0.72045625" x2="7.986578125" y2="0.73810625" layer="29"/>
<rectangle x1="8.60435625" y1="0.72045625" x2="11.8874125" y2="0.73810625" layer="29"/>
<rectangle x1="13.087671875" y1="0.72045625" x2="18.859496875" y2="0.73810625" layer="29"/>
<rectangle x1="0.043696875" y1="0.73810625" x2="1.685221875" y2="0.75575625" layer="29"/>
<rectangle x1="2.35595625" y1="0.73810625" x2="5.6566625" y2="0.75575625" layer="29"/>
<rectangle x1="6.34505" y1="0.73810625" x2="7.986575" y2="0.75575625" layer="29"/>
<rectangle x1="8.58670625" y1="0.73810625" x2="11.9050625" y2="0.75575625" layer="29"/>
<rectangle x1="13.070021875" y1="0.73810625" x2="18.877146875" y2="0.75575625" layer="29"/>
<rectangle x1="0.061346875" y1="0.75575625" x2="1.685221875" y2="0.77340625" layer="29"/>
<rectangle x1="2.33830625" y1="0.75575625" x2="5.6743125" y2="0.77340625" layer="29"/>
<rectangle x1="6.34505" y1="0.75575625" x2="7.986575" y2="0.77340625" layer="29"/>
<rectangle x1="8.56905625" y1="0.75575625" x2="11.9050625" y2="0.77340625" layer="29"/>
<rectangle x1="13.070021875" y1="0.75575625" x2="18.877146875" y2="0.77340625" layer="29"/>
<rectangle x1="0.061346875" y1="0.773409375" x2="1.667571875" y2="0.791059375" layer="29"/>
<rectangle x1="2.32065625" y1="0.773409375" x2="5.6743125" y2="0.791059375" layer="29"/>
<rectangle x1="6.3627" y1="0.773409375" x2="7.968925" y2="0.791059375" layer="29"/>
<rectangle x1="8.56905625" y1="0.773409375" x2="11.9227125" y2="0.791059375" layer="29"/>
<rectangle x1="13.052371875" y1="0.773409375" x2="14.252628125" y2="0.791059375" layer="29"/>
<rectangle x1="14.623296875" y1="0.773409375" x2="17.482734375" y2="0.791059375" layer="29"/>
<rectangle x1="17.94165625" y1="0.773409375" x2="18.8948" y2="0.791059375" layer="29"/>
<rectangle x1="0.078996875" y1="0.791059375" x2="1.667571875" y2="0.808709375" layer="29"/>
<rectangle x1="2.32065625" y1="0.791059375" x2="5.69196875" y2="0.808709375" layer="29"/>
<rectangle x1="6.3627" y1="0.791059375" x2="7.968925" y2="0.808709375" layer="29"/>
<rectangle x1="8.55140625" y1="0.791059375" x2="11.94036875" y2="0.808709375" layer="29"/>
<rectangle x1="13.034721875" y1="0.791059375" x2="14.164371875" y2="0.808709375" layer="29"/>
<rectangle x1="14.71155" y1="0.791059375" x2="15.84120625" y2="0.808709375" layer="29"/>
<rectangle x1="16.229525" y1="0.791059375" x2="17.394475" y2="0.808709375" layer="29"/>
<rectangle x1="18.0652125" y1="0.791059375" x2="18.91245" y2="0.808709375" layer="29"/>
<rectangle x1="0.078996875" y1="0.808709375" x2="1.649921875" y2="0.826359375" layer="29"/>
<rectangle x1="2.30300625" y1="0.808709375" x2="5.70961875" y2="0.826359375" layer="29"/>
<rectangle x1="6.38035" y1="0.808709375" x2="7.951275" y2="0.826359375" layer="29"/>
<rectangle x1="8.55140625" y1="0.808709375" x2="11.94036875" y2="0.826359375" layer="29"/>
<rectangle x1="13.034721875" y1="0.808709375" x2="14.111421875" y2="0.826359375" layer="29"/>
<rectangle x1="14.764503125" y1="0.808709375" x2="15.841203125" y2="0.826359375" layer="29"/>
<rectangle x1="16.247175" y1="0.808709375" x2="17.341525" y2="0.826359375" layer="29"/>
<rectangle x1="18.135815625" y1="0.808709375" x2="18.912453125" y2="0.826359375" layer="29"/>
<rectangle x1="0.09665" y1="0.8263625" x2="1.649925" y2="0.8440125" layer="29"/>
<rectangle x1="2.285353125" y1="0.8263625" x2="3.944534375" y2="0.8440125" layer="29"/>
<rectangle x1="4.068090625" y1="0.8263625" x2="5.709615625" y2="0.8440125" layer="29"/>
<rectangle x1="6.38035" y1="0.8263625" x2="7.933625" y2="0.8440125" layer="29"/>
<rectangle x1="8.533753125" y1="0.8263625" x2="10.175284375" y2="0.8440125" layer="29"/>
<rectangle x1="10.2988375" y1="0.8263625" x2="11.95801875" y2="0.8440125" layer="29"/>
<rectangle x1="13.01706875" y1="0.8263625" x2="14.07611875" y2="0.8440125" layer="29"/>
<rectangle x1="14.79980625" y1="0.8263625" x2="15.84120625" y2="0.8440125" layer="29"/>
<rectangle x1="16.247175" y1="0.8263625" x2="17.288575" y2="0.8440125" layer="29"/>
<rectangle x1="18.20641875" y1="0.8263625" x2="18.9301" y2="0.8440125" layer="29"/>
<rectangle x1="0.1143" y1="0.8440125" x2="1.63226875" y2="0.8616625" layer="29"/>
<rectangle x1="2.285353125" y1="0.8440125" x2="3.820978125" y2="0.8616625" layer="29"/>
<rectangle x1="4.17399375" y1="0.8440125" x2="5.72726875" y2="0.8616625" layer="29"/>
<rectangle x1="6.398003125" y1="0.8440125" x2="7.933621875" y2="0.8616625" layer="29"/>
<rectangle x1="8.516103125" y1="0.8440125" x2="10.069378125" y2="0.8616625" layer="29"/>
<rectangle x1="10.42239375" y1="0.8440125" x2="11.95801875" y2="0.8616625" layer="29"/>
<rectangle x1="12.99941875" y1="0.8440125" x2="14.04081875" y2="0.8616625" layer="29"/>
<rectangle x1="14.83510625" y1="0.8440125" x2="15.84120625" y2="0.8616625" layer="29"/>
<rectangle x1="16.247175" y1="0.8440125" x2="17.25326875" y2="0.8616625" layer="29"/>
<rectangle x1="18.277021875" y1="0.8440125" x2="18.930103125" y2="0.8616625" layer="29"/>
<rectangle x1="0.1143" y1="0.8616625" x2="1.61461875" y2="0.8793125" layer="29"/>
<rectangle x1="2.267703125" y1="0.8616625" x2="3.750371875" y2="0.8793125" layer="29"/>
<rectangle x1="4.244596875" y1="0.8616625" x2="5.727265625" y2="0.8793125" layer="29"/>
<rectangle x1="6.415653125" y1="0.8616625" x2="7.915971875" y2="0.8793125" layer="29"/>
<rectangle x1="8.516103125" y1="0.8616625" x2="9.998771875" y2="0.8793125" layer="29"/>
<rectangle x1="10.492996875" y1="0.8616625" x2="11.975665625" y2="0.8793125" layer="29"/>
<rectangle x1="12.99941875" y1="0.8616625" x2="14.0055125" y2="0.8793125" layer="29"/>
<rectangle x1="14.870409375" y1="0.8616625" x2="15.841203125" y2="0.8793125" layer="29"/>
<rectangle x1="16.247175" y1="0.8616625" x2="17.21796875" y2="0.8793125" layer="29"/>
<rectangle x1="18.329975" y1="0.8616625" x2="18.94775" y2="0.8793125" layer="29"/>
<rectangle x1="0.13195" y1="0.8793125" x2="1.59696875" y2="0.8969625" layer="29"/>
<rectangle x1="2.267703125" y1="0.8793125" x2="3.697421875" y2="0.8969625" layer="29"/>
<rectangle x1="4.29755" y1="0.8793125" x2="5.74491875" y2="0.8969625" layer="29"/>
<rectangle x1="6.433303125" y1="0.8793125" x2="7.898321875" y2="0.8969625" layer="29"/>
<rectangle x1="8.498453125" y1="0.8793125" x2="9.945821875" y2="0.8969625" layer="29"/>
<rectangle x1="10.54595" y1="0.8793125" x2="11.97566875" y2="0.8969625" layer="29"/>
<rectangle x1="12.98176875" y1="0.8793125" x2="13.9702125" y2="0.8969625" layer="29"/>
<rectangle x1="14.905709375" y1="0.8793125" x2="15.841203125" y2="0.8969625" layer="29"/>
<rectangle x1="16.247175" y1="0.8793125" x2="17.18266875" y2="0.8969625" layer="29"/>
<rectangle x1="18.347625" y1="0.8793125" x2="18.96540625" y2="0.8969625" layer="29"/>
<rectangle x1="0.149603125" y1="0.896965625" x2="1.596971875" y2="0.914615625" layer="29"/>
<rectangle x1="2.250053125" y1="0.896965625" x2="3.662121875" y2="0.914615625" layer="29"/>
<rectangle x1="4.350503125" y1="0.896965625" x2="5.762571875" y2="0.914615625" layer="29"/>
<rectangle x1="6.450953125" y1="0.896965625" x2="7.880671875" y2="0.914615625" layer="29"/>
<rectangle x1="8.498453125" y1="0.896965625" x2="9.910521875" y2="0.914615625" layer="29"/>
<rectangle x1="10.581253125" y1="0.896965625" x2="11.993321875" y2="0.914615625" layer="29"/>
<rectangle x1="12.98176875" y1="0.896965625" x2="13.9525625" y2="0.914615625" layer="29"/>
<rectangle x1="14.9410125" y1="0.896965625" x2="15.84120625" y2="0.914615625" layer="29"/>
<rectangle x1="16.247175" y1="0.896965625" x2="17.16501875" y2="0.914615625" layer="29"/>
<rectangle x1="18.347625" y1="0.896965625" x2="18.96540625" y2="0.914615625" layer="29"/>
<rectangle x1="0.167253125" y1="0.914615625" x2="1.579321875" y2="0.932265625" layer="29"/>
<rectangle x1="2.250053125" y1="0.914615625" x2="3.626815625" y2="0.932265625" layer="29"/>
<rectangle x1="4.38580625" y1="0.914615625" x2="5.76256875" y2="0.932265625" layer="29"/>
<rectangle x1="6.46860625" y1="0.914615625" x2="7.86301875" y2="0.932265625" layer="29"/>
<rectangle x1="8.480803125" y1="0.914615625" x2="9.857565625" y2="0.932265625" layer="29"/>
<rectangle x1="10.616553125" y1="0.914615625" x2="12.010971875" y2="0.932265625" layer="29"/>
<rectangle x1="12.964115625" y1="0.914615625" x2="13.917259375" y2="0.932265625" layer="29"/>
<rectangle x1="14.9586625" y1="0.914615625" x2="15.84120625" y2="0.932265625" layer="29"/>
<rectangle x1="16.247175" y1="0.914615625" x2="17.1297125" y2="0.932265625" layer="29"/>
<rectangle x1="18.347625" y1="0.914615625" x2="18.98305625" y2="0.932265625" layer="29"/>
<rectangle x1="0.184903125" y1="0.932265625" x2="1.544015625" y2="0.949915625" layer="29"/>
<rectangle x1="2.232403125" y1="0.932265625" x2="3.591515625" y2="0.949915625" layer="29"/>
<rectangle x1="4.42110625" y1="0.932265625" x2="5.78021875" y2="0.949915625" layer="29"/>
<rectangle x1="6.48625625" y1="0.932265625" x2="7.84536875" y2="0.949915625" layer="29"/>
<rectangle x1="8.480803125" y1="0.932265625" x2="9.822265625" y2="0.949915625" layer="29"/>
<rectangle x1="10.65185625" y1="0.932265625" x2="12.01096875" y2="0.949915625" layer="29"/>
<rectangle x1="12.964115625" y1="0.932265625" x2="13.899609375" y2="0.949915625" layer="29"/>
<rectangle x1="14.9763125" y1="0.932265625" x2="15.84120625" y2="0.949915625" layer="29"/>
<rectangle x1="16.247175" y1="0.932265625" x2="17.1120625" y2="0.949915625" layer="29"/>
<rectangle x1="18.347625" y1="0.932265625" x2="18.98305625" y2="0.949915625" layer="29"/>
<rectangle x1="0.202553125" y1="0.949915625" x2="1.526365625" y2="0.967565625" layer="29"/>
<rectangle x1="2.232403125" y1="0.949915625" x2="3.556215625" y2="0.967565625" layer="29"/>
<rectangle x1="4.43875625" y1="0.949915625" x2="5.78021875" y2="0.967565625" layer="29"/>
<rectangle x1="6.50390625" y1="0.949915625" x2="7.82771875" y2="0.967565625" layer="29"/>
<rectangle x1="8.46315" y1="0.949915625" x2="9.8046125" y2="0.967565625" layer="29"/>
<rectangle x1="10.68715625" y1="0.949915625" x2="12.02861875" y2="0.967565625" layer="29"/>
<rectangle x1="12.946465625" y1="0.949915625" x2="13.881959375" y2="0.967565625" layer="29"/>
<rectangle x1="14.993965625" y1="0.949915625" x2="15.841203125" y2="0.967565625" layer="29"/>
<rectangle x1="16.247175" y1="0.949915625" x2="17.0944125" y2="0.967565625" layer="29"/>
<rectangle x1="18.347625" y1="0.949915625" x2="19.00070625" y2="0.967565625" layer="29"/>
<rectangle x1="0.23785625" y1="0.96756875" x2="1.5087125" y2="0.98521875" layer="29"/>
<rectangle x1="2.21475" y1="0.96756875" x2="3.5385625" y2="0.98521875" layer="29"/>
<rectangle x1="4.474059375" y1="0.96756875" x2="5.797871875" y2="0.98521875" layer="29"/>
<rectangle x1="6.539209375" y1="0.96756875" x2="7.792415625" y2="0.98521875" layer="29"/>
<rectangle x1="8.46315" y1="0.96756875" x2="9.7693125" y2="0.98521875" layer="29"/>
<rectangle x1="10.722459375" y1="0.96756875" x2="12.028621875" y2="0.98521875" layer="29"/>
<rectangle x1="12.946465625" y1="0.96756875" x2="13.864309375" y2="0.98521875" layer="29"/>
<rectangle x1="15.011615625" y1="0.96756875" x2="15.841203125" y2="0.98521875" layer="29"/>
<rectangle x1="16.247175" y1="0.96756875" x2="17.0767625" y2="0.98521875" layer="29"/>
<rectangle x1="18.347625" y1="0.96756875" x2="19.00070625" y2="0.98521875" layer="29"/>
<rectangle x1="0.27315625" y1="0.98521875" x2="1.4734125" y2="1.00286875" layer="29"/>
<rectangle x1="2.21475" y1="0.98521875" x2="3.5032625" y2="1.00286875" layer="29"/>
<rectangle x1="4.5093625" y1="0.98521875" x2="5.79786875" y2="1.00286875" layer="29"/>
<rectangle x1="6.574509375" y1="0.98521875" x2="7.757115625" y2="1.00286875" layer="29"/>
<rectangle x1="8.4455" y1="0.98521875" x2="9.7516625" y2="1.00286875" layer="29"/>
<rectangle x1="10.740109375" y1="0.98521875" x2="12.046271875" y2="1.00286875" layer="29"/>
<rectangle x1="12.928815625" y1="0.98521875" x2="13.846659375" y2="1.00286875" layer="29"/>
<rectangle x1="15.029265625" y1="0.98521875" x2="15.841203125" y2="1.00286875" layer="29"/>
<rectangle x1="16.247175" y1="0.98521875" x2="17.0591125" y2="1.00286875" layer="29"/>
<rectangle x1="18.347625" y1="0.98521875" x2="19.01835625" y2="1.00286875" layer="29"/>
<rectangle x1="0.308459375" y1="1.00286875" x2="1.420459375" y2="1.02051875" layer="29"/>
<rectangle x1="2.1971" y1="1.00286875" x2="3.4856125" y2="1.02051875" layer="29"/>
<rectangle x1="4.5270125" y1="1.00286875" x2="5.815525" y2="1.02051875" layer="29"/>
<rectangle x1="6.6098125" y1="1.00286875" x2="7.7218125" y2="1.02051875" layer="29"/>
<rectangle x1="8.4455" y1="1.00286875" x2="9.7163625" y2="1.02051875" layer="29"/>
<rectangle x1="10.7577625" y1="1.00286875" x2="12.04626875" y2="1.02051875" layer="29"/>
<rectangle x1="12.928815625" y1="1.00286875" x2="13.829009375" y2="1.02051875" layer="29"/>
<rectangle x1="15.046915625" y1="1.00286875" x2="15.841203125" y2="1.02051875" layer="29"/>
<rectangle x1="16.247175" y1="1.00286875" x2="17.0414625" y2="1.02051875" layer="29"/>
<rectangle x1="18.347625" y1="1.00286875" x2="19.01835625" y2="1.02051875" layer="29"/>
<rectangle x1="0.3437625" y1="1.020521875" x2="1.3851625" y2="1.038171875" layer="29"/>
<rectangle x1="2.1971" y1="1.020521875" x2="3.45030625" y2="1.038171875" layer="29"/>
<rectangle x1="4.5446625" y1="1.020521875" x2="5.815525" y2="1.038171875" layer="29"/>
<rectangle x1="6.6451125" y1="1.020521875" x2="7.6865125" y2="1.038171875" layer="29"/>
<rectangle x1="8.42785" y1="1.020521875" x2="9.69870625" y2="1.038171875" layer="29"/>
<rectangle x1="10.7930625" y1="1.020521875" x2="12.063925" y2="1.038171875" layer="29"/>
<rectangle x1="12.911165625" y1="1.020521875" x2="13.811353125" y2="1.038171875" layer="29"/>
<rectangle x1="15.06456875" y1="1.020521875" x2="15.84120625" y2="1.038171875" layer="29"/>
<rectangle x1="16.247175" y1="1.020521875" x2="17.0238125" y2="1.038171875" layer="29"/>
<rectangle x1="18.347625" y1="1.020521875" x2="19.03600625" y2="1.038171875" layer="29"/>
<rectangle x1="0.3437625" y1="1.038171875" x2="1.3851625" y2="1.055821875" layer="29"/>
<rectangle x1="2.17945" y1="1.038171875" x2="3.43265625" y2="1.055821875" layer="29"/>
<rectangle x1="4.5623125" y1="1.038171875" x2="5.815525" y2="1.055821875" layer="29"/>
<rectangle x1="6.6451125" y1="1.038171875" x2="7.6865125" y2="1.055821875" layer="29"/>
<rectangle x1="8.42785" y1="1.038171875" x2="9.68105625" y2="1.055821875" layer="29"/>
<rectangle x1="10.8107125" y1="1.038171875" x2="12.063925" y2="1.055821875" layer="29"/>
<rectangle x1="12.911165625" y1="1.038171875" x2="13.793703125" y2="1.055821875" layer="29"/>
<rectangle x1="15.08221875" y1="1.038171875" x2="15.84120625" y2="1.055821875" layer="29"/>
<rectangle x1="16.247175" y1="1.038171875" x2="17.0061625" y2="1.055821875" layer="29"/>
<rectangle x1="18.347625" y1="1.038171875" x2="19.03600625" y2="1.055821875" layer="29"/>
<rectangle x1="0.3437625" y1="1.055821875" x2="1.3851625" y2="1.073471875" layer="29"/>
<rectangle x1="2.17945" y1="1.055821875" x2="3.41500625" y2="1.073471875" layer="29"/>
<rectangle x1="4.597615625" y1="1.055821875" x2="5.833171875" y2="1.073471875" layer="29"/>
<rectangle x1="6.6451125" y1="1.055821875" x2="7.6865125" y2="1.073471875" layer="29"/>
<rectangle x1="8.410196875" y1="1.055821875" x2="9.663409375" y2="1.073471875" layer="29"/>
<rectangle x1="10.828365625" y1="1.055821875" x2="12.063921875" y2="1.073471875" layer="29"/>
<rectangle x1="12.8935125" y1="1.055821875" x2="13.77605625" y2="1.073471875" layer="29"/>
<rectangle x1="15.09986875" y1="1.055821875" x2="15.84120625" y2="1.073471875" layer="29"/>
<rectangle x1="16.247175" y1="1.055821875" x2="16.98850625" y2="1.073471875" layer="29"/>
<rectangle x1="18.347625" y1="1.055821875" x2="19.05365625" y2="1.073471875" layer="29"/>
<rectangle x1="0.3437625" y1="1.073471875" x2="1.3851625" y2="1.091121875" layer="29"/>
<rectangle x1="2.161796875" y1="1.073471875" x2="3.397353125" y2="1.091121875" layer="29"/>
<rectangle x1="4.615265625" y1="1.073471875" x2="5.833171875" y2="1.091121875" layer="29"/>
<rectangle x1="6.6451125" y1="1.073471875" x2="7.6865125" y2="1.091121875" layer="29"/>
<rectangle x1="8.410196875" y1="1.073471875" x2="9.628103125" y2="1.091121875" layer="29"/>
<rectangle x1="10.846015625" y1="1.073471875" x2="12.081571875" y2="1.091121875" layer="29"/>
<rectangle x1="12.8935125" y1="1.073471875" x2="13.77605625" y2="1.091121875" layer="29"/>
<rectangle x1="15.09986875" y1="1.073471875" x2="15.84120625" y2="1.091121875" layer="29"/>
<rectangle x1="16.247175" y1="1.073471875" x2="16.98850625" y2="1.091121875" layer="29"/>
<rectangle x1="18.347625" y1="1.073471875" x2="19.05365625" y2="1.091121875" layer="29"/>
<rectangle x1="0.3437625" y1="1.091125" x2="1.3851625" y2="1.108775" layer="29"/>
<rectangle x1="2.161796875" y1="1.091125" x2="3.379703125" y2="1.108775" layer="29"/>
<rectangle x1="4.632915625" y1="1.091125" x2="5.850821875" y2="1.108775" layer="29"/>
<rectangle x1="6.6451125" y1="1.091125" x2="7.6865125" y2="1.108775" layer="29"/>
<rectangle x1="8.392546875" y1="1.091125" x2="9.610453125" y2="1.108775" layer="29"/>
<rectangle x1="10.863665625" y1="1.091125" x2="12.081571875" y2="1.108775" layer="29"/>
<rectangle x1="12.8935125" y1="1.091125" x2="13.75840625" y2="1.108775" layer="29"/>
<rectangle x1="15.117521875" y1="1.091125" x2="15.841203125" y2="1.108775" layer="29"/>
<rectangle x1="16.247175" y1="1.091125" x2="16.97085625" y2="1.108775" layer="29"/>
<rectangle x1="18.347625" y1="1.091125" x2="19.05365625" y2="1.108775" layer="29"/>
<rectangle x1="0.3437625" y1="1.108775" x2="1.3851625" y2="1.126425" layer="29"/>
<rectangle x1="2.161796875" y1="1.108775" x2="3.362053125" y2="1.126425" layer="29"/>
<rectangle x1="4.65056875" y1="1.108775" x2="5.850825" y2="1.126425" layer="29"/>
<rectangle x1="6.6451125" y1="1.108775" x2="7.6865125" y2="1.126425" layer="29"/>
<rectangle x1="8.392546875" y1="1.108775" x2="9.592803125" y2="1.126425" layer="29"/>
<rectangle x1="10.881315625" y1="1.108775" x2="12.099221875" y2="1.126425" layer="29"/>
<rectangle x1="12.8758625" y1="1.108775" x2="13.74075" y2="1.126425" layer="29"/>
<rectangle x1="14.358534375" y1="1.108775" x2="14.517390625" y2="1.126425" layer="29"/>
<rectangle x1="15.135171875" y1="1.108775" x2="15.841203125" y2="1.126425" layer="29"/>
<rectangle x1="16.247175" y1="1.108775" x2="16.95320625" y2="1.126425" layer="29"/>
<rectangle x1="17.606290625" y1="1.108775" x2="17.853403125" y2="1.126425" layer="29"/>
<rectangle x1="18.347625" y1="1.108775" x2="19.07130625" y2="1.126425" layer="29"/>
<rectangle x1="0.3437625" y1="1.126425" x2="1.3851625" y2="1.144075" layer="29"/>
<rectangle x1="2.144146875" y1="1.126425" x2="3.344403125" y2="1.144075" layer="29"/>
<rectangle x1="4.66821875" y1="1.126425" x2="5.850825" y2="1.144075" layer="29"/>
<rectangle x1="6.6451125" y1="1.126425" x2="7.6865125" y2="1.144075" layer="29"/>
<rectangle x1="8.392546875" y1="1.126425" x2="9.575153125" y2="1.144075" layer="29"/>
<rectangle x1="10.89896875" y1="1.126425" x2="12.099225" y2="1.144075" layer="29"/>
<rectangle x1="12.8758625" y1="1.126425" x2="13.74075" y2="1.144075" layer="29"/>
<rectangle x1="14.28793125" y1="1.126425" x2="14.58799375" y2="1.144075" layer="29"/>
<rectangle x1="15.135171875" y1="1.126425" x2="15.841203125" y2="1.144075" layer="29"/>
<rectangle x1="16.247175" y1="1.126425" x2="16.95320625" y2="1.144075" layer="29"/>
<rectangle x1="17.5356875" y1="1.126425" x2="17.94165625" y2="1.144075" layer="29"/>
<rectangle x1="18.347625" y1="1.126425" x2="19.07130625" y2="1.144075" layer="29"/>
<rectangle x1="0.3437625" y1="1.144075" x2="1.3851625" y2="1.161725" layer="29"/>
<rectangle x1="2.144146875" y1="1.144075" x2="3.326753125" y2="1.161725" layer="29"/>
<rectangle x1="4.68586875" y1="1.144075" x2="5.868475" y2="1.161725" layer="29"/>
<rectangle x1="6.6451125" y1="1.144075" x2="7.6865125" y2="1.161725" layer="29"/>
<rectangle x1="8.374896875" y1="1.144075" x2="9.575153125" y2="1.161725" layer="29"/>
<rectangle x1="10.91661875" y1="1.144075" x2="12.099225" y2="1.161725" layer="29"/>
<rectangle x1="12.8582125" y1="1.144075" x2="13.7231" y2="1.161725" layer="29"/>
<rectangle x1="14.252628125" y1="1.144075" x2="14.623296875" y2="1.161725" layer="29"/>
<rectangle x1="15.152821875" y1="1.144075" x2="15.841203125" y2="1.161725" layer="29"/>
<rectangle x1="16.247175" y1="1.144075" x2="16.93555625" y2="1.161725" layer="29"/>
<rectangle x1="17.482734375" y1="1.144075" x2="17.941653125" y2="1.161725" layer="29"/>
<rectangle x1="18.347625" y1="1.144075" x2="19.07130625" y2="1.161725" layer="29"/>
<rectangle x1="0.3437625" y1="1.161728125" x2="1.3851625" y2="1.179378125" layer="29"/>
<rectangle x1="2.126496875" y1="1.161728125" x2="3.309103125" y2="1.179378125" layer="29"/>
<rectangle x1="4.68586875" y1="1.161728125" x2="5.868475" y2="1.179378125" layer="29"/>
<rectangle x1="6.6451125" y1="1.161728125" x2="7.6865125" y2="1.179378125" layer="29"/>
<rectangle x1="8.374896875" y1="1.161728125" x2="9.557503125" y2="1.179378125" layer="29"/>
<rectangle x1="10.93426875" y1="1.161728125" x2="12.116875" y2="1.179378125" layer="29"/>
<rectangle x1="12.8582125" y1="1.161728125" x2="13.7231" y2="1.179378125" layer="29"/>
<rectangle x1="14.217328125" y1="1.161728125" x2="14.658596875" y2="1.179378125" layer="29"/>
<rectangle x1="15.152821875" y1="1.161728125" x2="15.841203125" y2="1.179378125" layer="29"/>
<rectangle x1="16.247175" y1="1.161728125" x2="16.93555625" y2="1.179378125" layer="29"/>
<rectangle x1="17.44743125" y1="1.161728125" x2="17.94165625" y2="1.179378125" layer="29"/>
<rectangle x1="18.347625" y1="1.161728125" x2="19.0889625" y2="1.179378125" layer="29"/>
<rectangle x1="0.3437625" y1="1.179378125" x2="1.3851625" y2="1.197028125" layer="29"/>
<rectangle x1="2.126496875" y1="1.179378125" x2="3.291453125" y2="1.197028125" layer="29"/>
<rectangle x1="4.703521875" y1="1.179378125" x2="5.868471875" y2="1.197028125" layer="29"/>
<rectangle x1="6.6451125" y1="1.179378125" x2="7.6865125" y2="1.197028125" layer="29"/>
<rectangle x1="8.374896875" y1="1.179378125" x2="9.539853125" y2="1.197028125" layer="29"/>
<rectangle x1="10.951921875" y1="1.179378125" x2="12.116871875" y2="1.197028125" layer="29"/>
<rectangle x1="12.8582125" y1="1.179378125" x2="13.70545" y2="1.197028125" layer="29"/>
<rectangle x1="14.199675" y1="1.179378125" x2="14.67625" y2="1.197028125" layer="29"/>
<rectangle x1="15.170471875" y1="1.179378125" x2="15.841203125" y2="1.197028125" layer="29"/>
<rectangle x1="16.247175" y1="1.179378125" x2="16.91790625" y2="1.197028125" layer="29"/>
<rectangle x1="17.42978125" y1="1.179378125" x2="17.94165625" y2="1.197028125" layer="29"/>
<rectangle x1="18.347625" y1="1.179378125" x2="19.0889625" y2="1.197028125" layer="29"/>
<rectangle x1="0.3437625" y1="1.197028125" x2="1.3851625" y2="1.214678125" layer="29"/>
<rectangle x1="2.126496875" y1="1.197028125" x2="3.291453125" y2="1.214678125" layer="29"/>
<rectangle x1="4.721171875" y1="1.197028125" x2="5.886128125" y2="1.214678125" layer="29"/>
<rectangle x1="6.6451125" y1="1.197028125" x2="7.6865125" y2="1.214678125" layer="29"/>
<rectangle x1="8.357246875" y1="1.197028125" x2="9.522203125" y2="1.214678125" layer="29"/>
<rectangle x1="10.969571875" y1="1.197028125" x2="12.116871875" y2="1.214678125" layer="29"/>
<rectangle x1="12.8405625" y1="1.197028125" x2="13.70545" y2="1.214678125" layer="29"/>
<rectangle x1="14.182025" y1="1.197028125" x2="14.71155" y2="1.214678125" layer="29"/>
<rectangle x1="15.170471875" y1="1.197028125" x2="15.841203125" y2="1.214678125" layer="29"/>
<rectangle x1="16.247175" y1="1.197028125" x2="16.91790625" y2="1.214678125" layer="29"/>
<rectangle x1="17.41213125" y1="1.197028125" x2="17.94165625" y2="1.214678125" layer="29"/>
<rectangle x1="18.347625" y1="1.197028125" x2="19.0889625" y2="1.214678125" layer="29"/>
<rectangle x1="0.3437625" y1="1.214678125" x2="1.3851625" y2="1.232328125" layer="29"/>
<rectangle x1="2.126496875" y1="1.214678125" x2="3.273803125" y2="1.232328125" layer="29"/>
<rectangle x1="4.738821875" y1="1.214678125" x2="5.886128125" y2="1.232328125" layer="29"/>
<rectangle x1="6.6451125" y1="1.214678125" x2="7.6865125" y2="1.232328125" layer="29"/>
<rectangle x1="8.357246875" y1="1.214678125" x2="9.504546875" y2="1.232328125" layer="29"/>
<rectangle x1="10.969571875" y1="1.214678125" x2="12.134528125" y2="1.232328125" layer="29"/>
<rectangle x1="12.8405625" y1="1.214678125" x2="13.6878" y2="1.232328125" layer="29"/>
<rectangle x1="14.164375" y1="1.214678125" x2="14.71155" y2="1.232328125" layer="29"/>
<rectangle x1="15.188125" y1="1.214678125" x2="15.84120625" y2="1.232328125" layer="29"/>
<rectangle x1="16.247175" y1="1.214678125" x2="16.90025625" y2="1.232328125" layer="29"/>
<rectangle x1="17.376828125" y1="1.214678125" x2="17.941653125" y2="1.232328125" layer="29"/>
<rectangle x1="18.347625" y1="1.214678125" x2="19.1066125" y2="1.232328125" layer="29"/>
<rectangle x1="0.3437625" y1="1.23233125" x2="1.3851625" y2="1.24998125" layer="29"/>
<rectangle x1="2.108846875" y1="1.23233125" x2="3.256146875" y2="1.24998125" layer="29"/>
<rectangle x1="4.756471875" y1="1.23233125" x2="5.886128125" y2="1.24998125" layer="29"/>
<rectangle x1="6.6451125" y1="1.23233125" x2="7.6865125" y2="1.24998125" layer="29"/>
<rectangle x1="8.357246875" y1="1.23233125" x2="9.504546875" y2="1.24998125" layer="29"/>
<rectangle x1="10.987221875" y1="1.23233125" x2="12.134528125" y2="1.24998125" layer="29"/>
<rectangle x1="12.8405625" y1="1.23233125" x2="13.6878" y2="1.24998125" layer="29"/>
<rectangle x1="14.146725" y1="1.23233125" x2="14.7292" y2="1.24998125" layer="29"/>
<rectangle x1="15.188125" y1="1.23233125" x2="15.84120625" y2="1.24998125" layer="29"/>
<rectangle x1="16.247175" y1="1.23233125" x2="16.90025625" y2="1.24998125" layer="29"/>
<rectangle x1="17.376828125" y1="1.23233125" x2="17.941653125" y2="1.24998125" layer="29"/>
<rectangle x1="18.347625" y1="1.23233125" x2="19.1066125" y2="1.24998125" layer="29"/>
<rectangle x1="0.3437625" y1="1.24998125" x2="1.3851625" y2="1.26763125" layer="29"/>
<rectangle x1="2.108846875" y1="1.24998125" x2="3.238496875" y2="1.26763125" layer="29"/>
<rectangle x1="4.756471875" y1="1.24998125" x2="5.903778125" y2="1.26763125" layer="29"/>
<rectangle x1="6.6451125" y1="1.24998125" x2="7.6865125" y2="1.26763125" layer="29"/>
<rectangle x1="8.33959375" y1="1.24998125" x2="9.4869" y2="1.26763125" layer="29"/>
<rectangle x1="11.004871875" y1="1.24998125" x2="12.134528125" y2="1.26763125" layer="29"/>
<rectangle x1="12.822909375" y1="1.24998125" x2="13.687803125" y2="1.26763125" layer="29"/>
<rectangle x1="14.129071875" y1="1.24998125" x2="14.746853125" y2="1.26763125" layer="29"/>
<rectangle x1="15.205775" y1="1.24998125" x2="15.84120625" y2="1.26763125" layer="29"/>
<rectangle x1="16.247175" y1="1.24998125" x2="16.88260625" y2="1.26763125" layer="29"/>
<rectangle x1="17.359178125" y1="1.24998125" x2="17.941653125" y2="1.26763125" layer="29"/>
<rectangle x1="18.347625" y1="1.24998125" x2="19.1066125" y2="1.26763125" layer="29"/>
<rectangle x1="0.3437625" y1="1.26763125" x2="1.3851625" y2="1.28528125" layer="29"/>
<rectangle x1="2.108846875" y1="1.26763125" x2="3.238496875" y2="1.28528125" layer="29"/>
<rectangle x1="4.774125" y1="1.26763125" x2="5.903775" y2="1.28528125" layer="29"/>
<rectangle x1="6.6451125" y1="1.26763125" x2="7.6865125" y2="1.28528125" layer="29"/>
<rectangle x1="8.33959375" y1="1.26763125" x2="9.46925" y2="1.28528125" layer="29"/>
<rectangle x1="11.004871875" y1="1.26763125" x2="12.134528125" y2="1.28528125" layer="29"/>
<rectangle x1="12.822909375" y1="1.26763125" x2="13.670146875" y2="1.28528125" layer="29"/>
<rectangle x1="14.129071875" y1="1.26763125" x2="14.764503125" y2="1.28528125" layer="29"/>
<rectangle x1="15.205775" y1="1.26763125" x2="15.84120625" y2="1.28528125" layer="29"/>
<rectangle x1="16.247175" y1="1.26763125" x2="16.88260625" y2="1.28528125" layer="29"/>
<rectangle x1="17.341528125" y1="1.26763125" x2="17.941653125" y2="1.28528125" layer="29"/>
<rectangle x1="18.347625" y1="1.26763125" x2="19.1242625" y2="1.28528125" layer="29"/>
<rectangle x1="0.3437625" y1="1.285284375" x2="1.3851625" y2="1.302934375" layer="29"/>
<rectangle x1="2.09119375" y1="1.285284375" x2="3.22085" y2="1.302934375" layer="29"/>
<rectangle x1="4.774125" y1="1.285284375" x2="5.903775" y2="1.302934375" layer="29"/>
<rectangle x1="6.6451125" y1="1.285284375" x2="7.6865125" y2="1.302934375" layer="29"/>
<rectangle x1="8.33959375" y1="1.285284375" x2="9.46925" y2="1.302934375" layer="29"/>
<rectangle x1="11.022525" y1="1.285284375" x2="12.152175" y2="1.302934375" layer="29"/>
<rectangle x1="12.822909375" y1="1.285284375" x2="13.670146875" y2="1.302934375" layer="29"/>
<rectangle x1="14.111421875" y1="1.285284375" x2="14.764503125" y2="1.302934375" layer="29"/>
<rectangle x1="15.205775" y1="1.285284375" x2="15.84120625" y2="1.302934375" layer="29"/>
<rectangle x1="16.247175" y1="1.285284375" x2="16.88260625" y2="1.302934375" layer="29"/>
<rectangle x1="17.323875" y1="1.285284375" x2="17.94165625" y2="1.302934375" layer="29"/>
<rectangle x1="18.347625" y1="1.285284375" x2="19.1242625" y2="1.302934375" layer="29"/>
<rectangle x1="0.3437625" y1="1.302934375" x2="1.3851625" y2="1.320584375" layer="29"/>
<rectangle x1="2.09119375" y1="1.302934375" x2="3.22085" y2="1.320584375" layer="29"/>
<rectangle x1="4.791775" y1="1.302934375" x2="5.903775" y2="1.320584375" layer="29"/>
<rectangle x1="6.6451125" y1="1.302934375" x2="7.6865125" y2="1.320584375" layer="29"/>
<rectangle x1="8.33959375" y1="1.302934375" x2="9.45159375" y2="1.320584375" layer="29"/>
<rectangle x1="11.040175" y1="1.302934375" x2="12.152175" y2="1.320584375" layer="29"/>
<rectangle x1="12.822909375" y1="1.302934375" x2="13.670146875" y2="1.320584375" layer="29"/>
<rectangle x1="14.093771875" y1="1.302934375" x2="14.782153125" y2="1.320584375" layer="29"/>
<rectangle x1="15.223425" y1="1.302934375" x2="15.84120625" y2="1.320584375" layer="29"/>
<rectangle x1="16.247175" y1="1.302934375" x2="16.86495" y2="1.320584375" layer="29"/>
<rectangle x1="17.323875" y1="1.302934375" x2="17.94165625" y2="1.320584375" layer="29"/>
<rectangle x1="18.347625" y1="1.302934375" x2="19.1242625" y2="1.320584375" layer="29"/>
<rectangle x1="0.3437625" y1="1.320584375" x2="1.3851625" y2="1.338234375" layer="29"/>
<rectangle x1="2.09119375" y1="1.320584375" x2="3.20319375" y2="1.338234375" layer="29"/>
<rectangle x1="4.809425" y1="1.320584375" x2="5.921425" y2="1.338234375" layer="29"/>
<rectangle x1="6.6451125" y1="1.320584375" x2="7.6865125" y2="1.338234375" layer="29"/>
<rectangle x1="8.32194375" y1="1.320584375" x2="9.45159375" y2="1.338234375" layer="29"/>
<rectangle x1="11.040175" y1="1.320584375" x2="12.152175" y2="1.338234375" layer="29"/>
<rectangle x1="12.805259375" y1="1.320584375" x2="13.652496875" y2="1.338234375" layer="29"/>
<rectangle x1="14.093771875" y1="1.320584375" x2="14.782153125" y2="1.338234375" layer="29"/>
<rectangle x1="15.223425" y1="1.320584375" x2="15.84120625" y2="1.338234375" layer="29"/>
<rectangle x1="16.247175" y1="1.320584375" x2="16.86495" y2="1.338234375" layer="29"/>
<rectangle x1="17.306225" y1="1.320584375" x2="17.94165625" y2="1.338234375" layer="29"/>
<rectangle x1="18.347625" y1="1.320584375" x2="19.1242625" y2="1.338234375" layer="29"/>
<rectangle x1="0.3437625" y1="1.338234375" x2="1.3851625" y2="1.355884375" layer="29"/>
<rectangle x1="2.09119375" y1="1.338234375" x2="3.20319375" y2="1.355884375" layer="29"/>
<rectangle x1="4.809425" y1="1.338234375" x2="5.921425" y2="1.355884375" layer="29"/>
<rectangle x1="6.6451125" y1="1.338234375" x2="7.6865125" y2="1.355884375" layer="29"/>
<rectangle x1="8.32194375" y1="1.338234375" x2="9.43394375" y2="1.355884375" layer="29"/>
<rectangle x1="11.057825" y1="1.338234375" x2="12.152175" y2="1.355884375" layer="29"/>
<rectangle x1="12.805259375" y1="1.338234375" x2="13.652496875" y2="1.355884375" layer="29"/>
<rectangle x1="14.093771875" y1="1.338234375" x2="14.799803125" y2="1.355884375" layer="29"/>
<rectangle x1="15.223425" y1="1.338234375" x2="15.84120625" y2="1.355884375" layer="29"/>
<rectangle x1="16.247175" y1="1.338234375" x2="16.86495" y2="1.355884375" layer="29"/>
<rectangle x1="17.306225" y1="1.338234375" x2="17.94165625" y2="1.355884375" layer="29"/>
<rectangle x1="18.347625" y1="1.338234375" x2="19.1419125" y2="1.355884375" layer="29"/>
<rectangle x1="0.3437625" y1="1.3558875" x2="1.3851625" y2="1.3735375" layer="29"/>
<rectangle x1="2.07354375" y1="1.3558875" x2="3.18554375" y2="1.3735375" layer="29"/>
<rectangle x1="4.827075" y1="1.3558875" x2="5.921425" y2="1.3735375" layer="29"/>
<rectangle x1="6.6451125" y1="1.3558875" x2="7.6865125" y2="1.3735375" layer="29"/>
<rectangle x1="8.32194375" y1="1.3558875" x2="9.43394375" y2="1.3735375" layer="29"/>
<rectangle x1="11.057825" y1="1.3558875" x2="12.169825" y2="1.3735375" layer="29"/>
<rectangle x1="12.805259375" y1="1.3558875" x2="13.652496875" y2="1.3735375" layer="29"/>
<rectangle x1="14.076121875" y1="1.3558875" x2="14.799803125" y2="1.3735375" layer="29"/>
<rectangle x1="15.223425" y1="1.3558875" x2="15.84120625" y2="1.3735375" layer="29"/>
<rectangle x1="16.247175" y1="1.3558875" x2="16.8473" y2="1.3735375" layer="29"/>
<rectangle x1="17.288575" y1="1.3558875" x2="17.94165625" y2="1.3735375" layer="29"/>
<rectangle x1="18.347625" y1="1.3558875" x2="19.1419125" y2="1.3735375" layer="29"/>
<rectangle x1="0.3437625" y1="1.3735375" x2="1.3851625" y2="1.3911875" layer="29"/>
<rectangle x1="2.07354375" y1="1.3735375" x2="3.18554375" y2="1.3911875" layer="29"/>
<rectangle x1="4.827075" y1="1.3735375" x2="5.921425" y2="1.3911875" layer="29"/>
<rectangle x1="6.6451125" y1="1.3735375" x2="7.6865125" y2="1.3911875" layer="29"/>
<rectangle x1="8.32194375" y1="1.3735375" x2="9.41629375" y2="1.3911875" layer="29"/>
<rectangle x1="11.075475" y1="1.3735375" x2="12.169825" y2="1.3911875" layer="29"/>
<rectangle x1="12.805259375" y1="1.3735375" x2="13.634846875" y2="1.3911875" layer="29"/>
<rectangle x1="14.076121875" y1="1.3735375" x2="14.799803125" y2="1.3911875" layer="29"/>
<rectangle x1="15.241075" y1="1.3735375" x2="15.84120625" y2="1.3911875" layer="29"/>
<rectangle x1="16.247175" y1="1.3735375" x2="16.8473" y2="1.3911875" layer="29"/>
<rectangle x1="17.288575" y1="1.3735375" x2="17.94165625" y2="1.3911875" layer="29"/>
<rectangle x1="18.347625" y1="1.3735375" x2="19.1419125" y2="1.3911875" layer="29"/>
<rectangle x1="0.3437625" y1="1.3911875" x2="1.3851625" y2="1.4088375" layer="29"/>
<rectangle x1="2.07354375" y1="1.3911875" x2="3.16789375" y2="1.4088375" layer="29"/>
<rectangle x1="4.844728125" y1="1.3911875" x2="5.939078125" y2="1.4088375" layer="29"/>
<rectangle x1="6.6451125" y1="1.3911875" x2="7.6865125" y2="1.4088375" layer="29"/>
<rectangle x1="8.32194375" y1="1.3911875" x2="9.41629375" y2="1.4088375" layer="29"/>
<rectangle x1="11.075475" y1="1.3911875" x2="12.169825" y2="1.4088375" layer="29"/>
<rectangle x1="12.805259375" y1="1.3911875" x2="13.634846875" y2="1.4088375" layer="29"/>
<rectangle x1="14.05846875" y1="1.3911875" x2="14.81745625" y2="1.4088375" layer="29"/>
<rectangle x1="15.241075" y1="1.3911875" x2="15.84120625" y2="1.4088375" layer="29"/>
<rectangle x1="16.247175" y1="1.3911875" x2="16.8473" y2="1.4088375" layer="29"/>
<rectangle x1="17.270925" y1="1.3911875" x2="17.94165625" y2="1.4088375" layer="29"/>
<rectangle x1="18.347625" y1="1.3911875" x2="19.1419125" y2="1.4088375" layer="29"/>
<rectangle x1="0.3437625" y1="1.4088375" x2="1.3851625" y2="1.4264875" layer="29"/>
<rectangle x1="2.07354375" y1="1.4088375" x2="3.16789375" y2="1.4264875" layer="29"/>
<rectangle x1="4.844728125" y1="1.4088375" x2="5.939078125" y2="1.4264875" layer="29"/>
<rectangle x1="6.6451125" y1="1.4088375" x2="7.6865125" y2="1.4264875" layer="29"/>
<rectangle x1="8.30429375" y1="1.4088375" x2="9.39864375" y2="1.4264875" layer="29"/>
<rectangle x1="11.075475" y1="1.4088375" x2="12.169825" y2="1.4264875" layer="29"/>
<rectangle x1="12.787609375" y1="1.4088375" x2="13.634846875" y2="1.4264875" layer="29"/>
<rectangle x1="14.05846875" y1="1.4088375" x2="14.81745625" y2="1.4264875" layer="29"/>
<rectangle x1="15.241075" y1="1.4088375" x2="15.84120625" y2="1.4264875" layer="29"/>
<rectangle x1="16.247175" y1="1.4088375" x2="16.8473" y2="1.4264875" layer="29"/>
<rectangle x1="17.270925" y1="1.4088375" x2="17.94165625" y2="1.4264875" layer="29"/>
<rectangle x1="18.347625" y1="1.4088375" x2="19.1595625" y2="1.4264875" layer="29"/>
<rectangle x1="0.3437625" y1="1.426490625" x2="1.3851625" y2="1.444140625" layer="29"/>
<rectangle x1="2.07354375" y1="1.426490625" x2="3.15024375" y2="1.444140625" layer="29"/>
<rectangle x1="4.844728125" y1="1.426490625" x2="5.939078125" y2="1.444140625" layer="29"/>
<rectangle x1="6.6451125" y1="1.426490625" x2="7.6865125" y2="1.444140625" layer="29"/>
<rectangle x1="8.30429375" y1="1.426490625" x2="9.39864375" y2="1.444140625" layer="29"/>
<rectangle x1="11.093128125" y1="1.426490625" x2="12.169828125" y2="1.444140625" layer="29"/>
<rectangle x1="12.787609375" y1="1.426490625" x2="13.634846875" y2="1.444140625" layer="29"/>
<rectangle x1="14.05846875" y1="1.426490625" x2="14.81745625" y2="1.444140625" layer="29"/>
<rectangle x1="15.241075" y1="1.426490625" x2="15.84120625" y2="1.444140625" layer="29"/>
<rectangle x1="16.247175" y1="1.426490625" x2="16.8473" y2="1.444140625" layer="29"/>
<rectangle x1="17.270925" y1="1.426490625" x2="17.94165625" y2="1.444140625" layer="29"/>
<rectangle x1="18.347625" y1="1.426490625" x2="19.1595625" y2="1.444140625" layer="29"/>
<rectangle x1="0.3437625" y1="1.444140625" x2="1.3851625" y2="1.461790625" layer="29"/>
<rectangle x1="2.07354375" y1="1.444140625" x2="3.15024375" y2="1.461790625" layer="29"/>
<rectangle x1="4.862378125" y1="1.444140625" x2="5.939078125" y2="1.461790625" layer="29"/>
<rectangle x1="6.6451125" y1="1.444140625" x2="7.6865125" y2="1.461790625" layer="29"/>
<rectangle x1="8.30429375" y1="1.444140625" x2="9.38099375" y2="1.461790625" layer="29"/>
<rectangle x1="11.093128125" y1="1.444140625" x2="12.187478125" y2="1.461790625" layer="29"/>
<rectangle x1="12.787609375" y1="1.444140625" x2="13.634846875" y2="1.461790625" layer="29"/>
<rectangle x1="14.05846875" y1="1.444140625" x2="14.81745625" y2="1.461790625" layer="29"/>
<rectangle x1="15.258728125" y1="1.444140625" x2="15.841203125" y2="1.461790625" layer="29"/>
<rectangle x1="16.247175" y1="1.444140625" x2="16.82965" y2="1.461790625" layer="29"/>
<rectangle x1="17.270925" y1="1.444140625" x2="17.94165625" y2="1.461790625" layer="29"/>
<rectangle x1="18.347625" y1="1.444140625" x2="19.1595625" y2="1.461790625" layer="29"/>
<rectangle x1="0.3437625" y1="1.461790625" x2="1.3851625" y2="1.479440625" layer="29"/>
<rectangle x1="2.05589375" y1="1.461790625" x2="3.15024375" y2="1.479440625" layer="29"/>
<rectangle x1="4.862378125" y1="1.461790625" x2="5.939078125" y2="1.479440625" layer="29"/>
<rectangle x1="6.6451125" y1="1.461790625" x2="7.6865125" y2="1.479440625" layer="29"/>
<rectangle x1="8.30429375" y1="1.461790625" x2="9.38099375" y2="1.479440625" layer="29"/>
<rectangle x1="11.110778125" y1="1.461790625" x2="12.187478125" y2="1.479440625" layer="29"/>
<rectangle x1="12.787609375" y1="1.461790625" x2="13.617196875" y2="1.479440625" layer="29"/>
<rectangle x1="14.04081875" y1="1.461790625" x2="14.83510625" y2="1.479440625" layer="29"/>
<rectangle x1="15.258728125" y1="1.461790625" x2="15.841203125" y2="1.479440625" layer="29"/>
<rectangle x1="16.247175" y1="1.461790625" x2="16.82965" y2="1.479440625" layer="29"/>
<rectangle x1="17.253271875" y1="1.461790625" x2="17.941653125" y2="1.479440625" layer="29"/>
<rectangle x1="18.347625" y1="1.461790625" x2="19.1595625" y2="1.479440625" layer="29"/>
<rectangle x1="0.3437625" y1="1.47944375" x2="1.3851625" y2="1.49709375" layer="29"/>
<rectangle x1="2.05589375" y1="1.47944375" x2="3.13259375" y2="1.49709375" layer="29"/>
<rectangle x1="4.862378125" y1="1.47944375" x2="5.939078125" y2="1.49709375" layer="29"/>
<rectangle x1="6.6451125" y1="1.47944375" x2="7.6865125" y2="1.49709375" layer="29"/>
<rectangle x1="8.30429375" y1="1.47944375" x2="9.38099375" y2="1.49709375" layer="29"/>
<rectangle x1="11.110778125" y1="1.47944375" x2="12.187478125" y2="1.49709375" layer="29"/>
<rectangle x1="12.787609375" y1="1.47944375" x2="13.617196875" y2="1.49709375" layer="29"/>
<rectangle x1="14.04081875" y1="1.47944375" x2="14.83510625" y2="1.49709375" layer="29"/>
<rectangle x1="15.258728125" y1="1.47944375" x2="15.841203125" y2="1.49709375" layer="29"/>
<rectangle x1="16.247175" y1="1.47944375" x2="16.82965" y2="1.49709375" layer="29"/>
<rectangle x1="17.253271875" y1="1.47944375" x2="17.941653125" y2="1.49709375" layer="29"/>
<rectangle x1="18.347625" y1="1.47944375" x2="19.1595625" y2="1.49709375" layer="29"/>
<rectangle x1="0.3437625" y1="1.49709375" x2="1.3851625" y2="1.51474375" layer="29"/>
<rectangle x1="2.05589375" y1="1.49709375" x2="3.13259375" y2="1.51474375" layer="29"/>
<rectangle x1="4.880028125" y1="1.49709375" x2="5.956728125" y2="1.51474375" layer="29"/>
<rectangle x1="6.6451125" y1="1.49709375" x2="7.6865125" y2="1.51474375" layer="29"/>
<rectangle x1="8.30429375" y1="1.49709375" x2="9.36334375" y2="1.51474375" layer="29"/>
<rectangle x1="11.110778125" y1="1.49709375" x2="12.187478125" y2="1.51474375" layer="29"/>
<rectangle x1="12.787609375" y1="1.49709375" x2="13.617196875" y2="1.51474375" layer="29"/>
<rectangle x1="14.04081875" y1="1.49709375" x2="14.83510625" y2="1.51474375" layer="29"/>
<rectangle x1="15.258728125" y1="1.49709375" x2="15.841203125" y2="1.51474375" layer="29"/>
<rectangle x1="16.247175" y1="1.49709375" x2="16.82965" y2="1.51474375" layer="29"/>
<rectangle x1="17.253271875" y1="1.49709375" x2="17.606290625" y2="1.51474375" layer="29"/>
<rectangle x1="18.347625" y1="1.49709375" x2="19.1595625" y2="1.51474375" layer="29"/>
<rectangle x1="0.3437625" y1="1.51474375" x2="1.3851625" y2="1.53239375" layer="29"/>
<rectangle x1="2.05589375" y1="1.51474375" x2="3.13259375" y2="1.53239375" layer="29"/>
<rectangle x1="4.880028125" y1="1.51474375" x2="5.956728125" y2="1.53239375" layer="29"/>
<rectangle x1="6.6451125" y1="1.51474375" x2="7.6865125" y2="1.53239375" layer="29"/>
<rectangle x1="8.30429375" y1="1.51474375" x2="9.36334375" y2="1.53239375" layer="29"/>
<rectangle x1="11.110778125" y1="1.51474375" x2="12.187478125" y2="1.53239375" layer="29"/>
<rectangle x1="12.76995625" y1="1.51474375" x2="13.61719375" y2="1.53239375" layer="29"/>
<rectangle x1="14.04081875" y1="1.51474375" x2="14.83510625" y2="1.53239375" layer="29"/>
<rectangle x1="15.258728125" y1="1.51474375" x2="15.841203125" y2="1.53239375" layer="29"/>
<rectangle x1="16.247175" y1="1.51474375" x2="16.82965" y2="1.53239375" layer="29"/>
<rectangle x1="17.253271875" y1="1.51474375" x2="17.588634375" y2="1.53239375" layer="29"/>
<rectangle x1="18.347625" y1="1.51474375" x2="19.1772125" y2="1.53239375" layer="29"/>
<rectangle x1="0.3437625" y1="1.53239375" x2="1.3851625" y2="1.55004375" layer="29"/>
<rectangle x1="2.05589375" y1="1.53239375" x2="3.11494375" y2="1.55004375" layer="29"/>
<rectangle x1="4.880028125" y1="1.53239375" x2="5.956728125" y2="1.55004375" layer="29"/>
<rectangle x1="6.6451125" y1="1.53239375" x2="7.6865125" y2="1.55004375" layer="29"/>
<rectangle x1="8.28664375" y1="1.53239375" x2="9.36334375" y2="1.55004375" layer="29"/>
<rectangle x1="11.128428125" y1="1.53239375" x2="12.187478125" y2="1.55004375" layer="29"/>
<rectangle x1="12.76995625" y1="1.53239375" x2="13.61719375" y2="1.55004375" layer="29"/>
<rectangle x1="14.04081875" y1="1.53239375" x2="14.83510625" y2="1.55004375" layer="29"/>
<rectangle x1="15.258728125" y1="1.53239375" x2="15.841203125" y2="1.55004375" layer="29"/>
<rectangle x1="16.247175" y1="1.53239375" x2="16.82965" y2="1.55004375" layer="29"/>
<rectangle x1="17.235621875" y1="1.53239375" x2="17.588634375" y2="1.55004375" layer="29"/>
<rectangle x1="18.347625" y1="1.53239375" x2="19.1772125" y2="1.55004375" layer="29"/>
<rectangle x1="0.3437625" y1="1.550046875" x2="1.3851625" y2="1.567696875" layer="29"/>
<rectangle x1="2.05589375" y1="1.550046875" x2="3.11494375" y2="1.567696875" layer="29"/>
<rectangle x1="4.880028125" y1="1.550046875" x2="5.956728125" y2="1.567696875" layer="29"/>
<rectangle x1="6.6451125" y1="1.550046875" x2="7.6865125" y2="1.567696875" layer="29"/>
<rectangle x1="8.28664375" y1="1.550046875" x2="9.36334375" y2="1.567696875" layer="29"/>
<rectangle x1="11.128428125" y1="1.550046875" x2="12.187478125" y2="1.567696875" layer="29"/>
<rectangle x1="12.76995625" y1="1.550046875" x2="13.61719375" y2="1.567696875" layer="29"/>
<rectangle x1="14.04081875" y1="1.550046875" x2="14.83510625" y2="1.567696875" layer="29"/>
<rectangle x1="15.258728125" y1="1.550046875" x2="15.841203125" y2="1.567696875" layer="29"/>
<rectangle x1="16.247175" y1="1.550046875" x2="16.82965" y2="1.567696875" layer="29"/>
<rectangle x1="17.235621875" y1="1.550046875" x2="17.588634375" y2="1.567696875" layer="29"/>
<rectangle x1="18.347625" y1="1.550046875" x2="19.1772125" y2="1.567696875" layer="29"/>
<rectangle x1="0.3437625" y1="1.567696875" x2="1.3851625" y2="1.585346875" layer="29"/>
<rectangle x1="2.05589375" y1="1.567696875" x2="3.11494375" y2="1.585346875" layer="29"/>
<rectangle x1="4.897678125" y1="1.567696875" x2="5.956728125" y2="1.585346875" layer="29"/>
<rectangle x1="6.6451125" y1="1.567696875" x2="7.6865125" y2="1.585346875" layer="29"/>
<rectangle x1="8.28664375" y1="1.567696875" x2="9.34569375" y2="1.585346875" layer="29"/>
<rectangle x1="11.128428125" y1="1.567696875" x2="12.187478125" y2="1.585346875" layer="29"/>
<rectangle x1="12.76995625" y1="1.567696875" x2="13.61719375" y2="1.585346875" layer="29"/>
<rectangle x1="14.04081875" y1="1.567696875" x2="14.85275625" y2="1.585346875" layer="29"/>
<rectangle x1="15.258728125" y1="1.567696875" x2="15.841203125" y2="1.585346875" layer="29"/>
<rectangle x1="16.247175" y1="1.567696875" x2="16.812" y2="1.585346875" layer="29"/>
<rectangle x1="17.235621875" y1="1.567696875" x2="17.588634375" y2="1.585346875" layer="29"/>
<rectangle x1="18.347625" y1="1.567696875" x2="19.1772125" y2="1.585346875" layer="29"/>
<rectangle x1="0.3437625" y1="1.585346875" x2="1.3851625" y2="1.602996875" layer="29"/>
<rectangle x1="2.05589375" y1="1.585346875" x2="3.11494375" y2="1.602996875" layer="29"/>
<rectangle x1="4.897678125" y1="1.585346875" x2="5.956728125" y2="1.602996875" layer="29"/>
<rectangle x1="6.6451125" y1="1.585346875" x2="7.6865125" y2="1.602996875" layer="29"/>
<rectangle x1="8.28664375" y1="1.585346875" x2="9.34569375" y2="1.602996875" layer="29"/>
<rectangle x1="11.128428125" y1="1.585346875" x2="12.205128125" y2="1.602996875" layer="29"/>
<rectangle x1="12.76995625" y1="1.585346875" x2="13.61719375" y2="1.602996875" layer="29"/>
<rectangle x1="14.02316875" y1="1.585346875" x2="14.85275625" y2="1.602996875" layer="29"/>
<rectangle x1="15.276378125" y1="1.585346875" x2="15.841203125" y2="1.602996875" layer="29"/>
<rectangle x1="16.247175" y1="1.585346875" x2="16.812" y2="1.602996875" layer="29"/>
<rectangle x1="17.235621875" y1="1.585346875" x2="17.588634375" y2="1.602996875" layer="29"/>
<rectangle x1="18.347625" y1="1.585346875" x2="19.1772125" y2="1.602996875" layer="29"/>
<rectangle x1="0.3437625" y1="1.602996875" x2="1.3851625" y2="1.620646875" layer="29"/>
<rectangle x1="2.05589375" y1="1.602996875" x2="3.11494375" y2="1.620646875" layer="29"/>
<rectangle x1="4.897678125" y1="1.602996875" x2="5.956728125" y2="1.620646875" layer="29"/>
<rectangle x1="6.6451125" y1="1.602996875" x2="7.6865125" y2="1.620646875" layer="29"/>
<rectangle x1="8.28664375" y1="1.602996875" x2="9.34569375" y2="1.620646875" layer="29"/>
<rectangle x1="11.128428125" y1="1.602996875" x2="12.205128125" y2="1.620646875" layer="29"/>
<rectangle x1="12.76995625" y1="1.602996875" x2="13.61719375" y2="1.620646875" layer="29"/>
<rectangle x1="14.02316875" y1="1.602996875" x2="14.85275625" y2="1.620646875" layer="29"/>
<rectangle x1="15.276378125" y1="1.602996875" x2="15.841203125" y2="1.620646875" layer="29"/>
<rectangle x1="16.247175" y1="1.602996875" x2="16.812" y2="1.620646875" layer="29"/>
<rectangle x1="17.235621875" y1="1.602996875" x2="17.588634375" y2="1.620646875" layer="29"/>
<rectangle x1="18.347625" y1="1.602996875" x2="19.1772125" y2="1.620646875" layer="29"/>
<rectangle x1="0.3437625" y1="1.62065" x2="1.3851625" y2="1.6383" layer="29"/>
<rectangle x1="2.03824375" y1="1.62065" x2="3.11494375" y2="1.6383" layer="29"/>
<rectangle x1="4.897678125" y1="1.62065" x2="5.956728125" y2="1.6383" layer="29"/>
<rectangle x1="6.6451125" y1="1.62065" x2="7.6865125" y2="1.6383" layer="29"/>
<rectangle x1="8.28664375" y1="1.62065" x2="9.34569375" y2="1.6383" layer="29"/>
<rectangle x1="11.146078125" y1="1.62065" x2="12.205128125" y2="1.6383" layer="29"/>
<rectangle x1="12.76995625" y1="1.62065" x2="13.59954375" y2="1.6383" layer="29"/>
<rectangle x1="14.02316875" y1="1.62065" x2="14.85275625" y2="1.6383" layer="29"/>
<rectangle x1="15.276378125" y1="1.62065" x2="15.841203125" y2="1.6383" layer="29"/>
<rectangle x1="16.247175" y1="1.62065" x2="16.812" y2="1.6383" layer="29"/>
<rectangle x1="17.235621875" y1="1.62065" x2="17.588634375" y2="1.6383" layer="29"/>
<rectangle x1="18.347625" y1="1.62065" x2="19.1772125" y2="1.6383" layer="29"/>
<rectangle x1="0.3437625" y1="1.6383" x2="1.3851625" y2="1.65595" layer="29"/>
<rectangle x1="2.03824375" y1="1.6383" x2="3.09729375" y2="1.65595" layer="29"/>
<rectangle x1="4.897678125" y1="1.6383" x2="5.956728125" y2="1.65595" layer="29"/>
<rectangle x1="6.6451125" y1="1.6383" x2="7.6865125" y2="1.65595" layer="29"/>
<rectangle x1="8.28664375" y1="1.6383" x2="9.34569375" y2="1.65595" layer="29"/>
<rectangle x1="11.146078125" y1="1.6383" x2="12.205128125" y2="1.65595" layer="29"/>
<rectangle x1="12.76995625" y1="1.6383" x2="13.59954375" y2="1.65595" layer="29"/>
<rectangle x1="14.02316875" y1="1.6383" x2="14.85275625" y2="1.65595" layer="29"/>
<rectangle x1="15.276378125" y1="1.6383" x2="15.841203125" y2="1.65595" layer="29"/>
<rectangle x1="16.247175" y1="1.6383" x2="16.812" y2="1.65595" layer="29"/>
<rectangle x1="17.235621875" y1="1.6383" x2="17.588634375" y2="1.65595" layer="29"/>
<rectangle x1="18.347625" y1="1.6383" x2="19.1772125" y2="1.65595" layer="29"/>
<rectangle x1="0.3437625" y1="1.65595" x2="1.3851625" y2="1.6736" layer="29"/>
<rectangle x1="2.03824375" y1="1.65595" x2="3.09729375" y2="1.6736" layer="29"/>
<rectangle x1="4.897678125" y1="1.65595" x2="5.956728125" y2="1.6736" layer="29"/>
<rectangle x1="6.6451125" y1="1.65595" x2="7.6865125" y2="1.6736" layer="29"/>
<rectangle x1="8.28664375" y1="1.65595" x2="9.34569375" y2="1.6736" layer="29"/>
<rectangle x1="11.146078125" y1="1.65595" x2="12.205128125" y2="1.6736" layer="29"/>
<rectangle x1="12.76995625" y1="1.65595" x2="13.59954375" y2="1.6736" layer="29"/>
<rectangle x1="14.02316875" y1="1.65595" x2="14.85275625" y2="1.6736" layer="29"/>
<rectangle x1="15.276378125" y1="1.65595" x2="15.841203125" y2="1.6736" layer="29"/>
<rectangle x1="16.247175" y1="1.65595" x2="16.812" y2="1.6736" layer="29"/>
<rectangle x1="17.235621875" y1="1.65595" x2="17.588634375" y2="1.6736" layer="29"/>
<rectangle x1="18.347625" y1="1.65595" x2="19.1772125" y2="1.6736" layer="29"/>
<rectangle x1="0.3437625" y1="1.673603125" x2="1.3851625" y2="1.691253125" layer="29"/>
<rectangle x1="2.03824375" y1="1.673603125" x2="3.09729375" y2="1.691253125" layer="29"/>
<rectangle x1="4.897678125" y1="1.673603125" x2="5.956728125" y2="1.691253125" layer="29"/>
<rectangle x1="6.6451125" y1="1.673603125" x2="7.6865125" y2="1.691253125" layer="29"/>
<rectangle x1="8.28664375" y1="1.673603125" x2="9.34569375" y2="1.691253125" layer="29"/>
<rectangle x1="11.146078125" y1="1.673603125" x2="12.205128125" y2="1.691253125" layer="29"/>
<rectangle x1="12.76995625" y1="1.673603125" x2="13.59954375" y2="1.691253125" layer="29"/>
<rectangle x1="14.02316875" y1="1.673603125" x2="14.85275625" y2="1.691253125" layer="29"/>
<rectangle x1="15.276378125" y1="1.673603125" x2="15.841203125" y2="1.691253125" layer="29"/>
<rectangle x1="16.247175" y1="1.673603125" x2="16.812" y2="1.691253125" layer="29"/>
<rectangle x1="17.235621875" y1="1.673603125" x2="17.588634375" y2="1.691253125" layer="29"/>
<rectangle x1="18.347625" y1="1.673603125" x2="19.1772125" y2="1.691253125" layer="29"/>
<rectangle x1="0.3437625" y1="1.691253125" x2="1.3851625" y2="1.708903125" layer="29"/>
<rectangle x1="2.03824375" y1="1.691253125" x2="3.09729375" y2="1.708903125" layer="29"/>
<rectangle x1="4.91533125" y1="1.691253125" x2="5.95673125" y2="1.708903125" layer="29"/>
<rectangle x1="6.6451125" y1="1.691253125" x2="7.6865125" y2="1.708903125" layer="29"/>
<rectangle x1="8.28664375" y1="1.691253125" x2="9.34569375" y2="1.708903125" layer="29"/>
<rectangle x1="11.146078125" y1="1.691253125" x2="12.205128125" y2="1.708903125" layer="29"/>
<rectangle x1="12.76995625" y1="1.691253125" x2="13.59954375" y2="1.708903125" layer="29"/>
<rectangle x1="14.02316875" y1="1.691253125" x2="14.85275625" y2="1.708903125" layer="29"/>
<rectangle x1="15.276378125" y1="1.691253125" x2="15.841203125" y2="1.708903125" layer="29"/>
<rectangle x1="16.247175" y1="1.691253125" x2="16.812" y2="1.708903125" layer="29"/>
<rectangle x1="17.235621875" y1="1.691253125" x2="17.588634375" y2="1.708903125" layer="29"/>
<rectangle x1="18.347625" y1="1.691253125" x2="19.1772125" y2="1.708903125" layer="29"/>
<rectangle x1="0.3437625" y1="1.708903125" x2="1.3851625" y2="1.726553125" layer="29"/>
<rectangle x1="2.03824375" y1="1.708903125" x2="3.09729375" y2="1.726553125" layer="29"/>
<rectangle x1="4.91533125" y1="1.708903125" x2="5.95673125" y2="1.726553125" layer="29"/>
<rectangle x1="6.6451125" y1="1.708903125" x2="7.6865125" y2="1.726553125" layer="29"/>
<rectangle x1="8.28664375" y1="1.708903125" x2="9.34569375" y2="1.726553125" layer="29"/>
<rectangle x1="11.146078125" y1="1.708903125" x2="12.205128125" y2="1.726553125" layer="29"/>
<rectangle x1="12.76995625" y1="1.708903125" x2="13.59954375" y2="1.726553125" layer="29"/>
<rectangle x1="14.02316875" y1="1.708903125" x2="14.85275625" y2="1.726553125" layer="29"/>
<rectangle x1="15.276378125" y1="1.708903125" x2="15.841203125" y2="1.726553125" layer="29"/>
<rectangle x1="16.247175" y1="1.708903125" x2="16.812" y2="1.726553125" layer="29"/>
<rectangle x1="17.235621875" y1="1.708903125" x2="17.588634375" y2="1.726553125" layer="29"/>
<rectangle x1="18.347625" y1="1.708903125" x2="19.1772125" y2="1.726553125" layer="29"/>
<rectangle x1="0.3437625" y1="1.726553125" x2="1.3851625" y2="1.744203125" layer="29"/>
<rectangle x1="2.03824375" y1="1.726553125" x2="3.09729375" y2="1.744203125" layer="29"/>
<rectangle x1="4.91533125" y1="1.726553125" x2="5.95673125" y2="1.744203125" layer="29"/>
<rectangle x1="6.6451125" y1="1.726553125" x2="7.6865125" y2="1.744203125" layer="29"/>
<rectangle x1="8.28664375" y1="1.726553125" x2="9.34569375" y2="1.744203125" layer="29"/>
<rectangle x1="11.146078125" y1="1.726553125" x2="12.205128125" y2="1.744203125" layer="29"/>
<rectangle x1="12.76995625" y1="1.726553125" x2="13.59954375" y2="1.744203125" layer="29"/>
<rectangle x1="14.02316875" y1="1.726553125" x2="14.85275625" y2="1.744203125" layer="29"/>
<rectangle x1="15.276378125" y1="1.726553125" x2="15.841203125" y2="1.744203125" layer="29"/>
<rectangle x1="16.247175" y1="1.726553125" x2="16.812" y2="1.744203125" layer="29"/>
<rectangle x1="17.235621875" y1="1.726553125" x2="17.588634375" y2="1.744203125" layer="29"/>
<rectangle x1="18.347625" y1="1.726553125" x2="19.1772125" y2="1.744203125" layer="29"/>
<rectangle x1="0.3437625" y1="1.74420625" x2="1.3851625" y2="1.76185625" layer="29"/>
<rectangle x1="2.03824375" y1="1.74420625" x2="3.09729375" y2="1.76185625" layer="29"/>
<rectangle x1="4.897678125" y1="1.74420625" x2="5.956728125" y2="1.76185625" layer="29"/>
<rectangle x1="6.6451125" y1="1.74420625" x2="7.6865125" y2="1.76185625" layer="29"/>
<rectangle x1="8.28664375" y1="1.74420625" x2="9.34569375" y2="1.76185625" layer="29"/>
<rectangle x1="11.146078125" y1="1.74420625" x2="12.205128125" y2="1.76185625" layer="29"/>
<rectangle x1="12.76995625" y1="1.74420625" x2="13.59954375" y2="1.76185625" layer="29"/>
<rectangle x1="14.02316875" y1="1.74420625" x2="14.85275625" y2="1.76185625" layer="29"/>
<rectangle x1="15.276378125" y1="1.74420625" x2="15.841203125" y2="1.76185625" layer="29"/>
<rectangle x1="16.247175" y1="1.74420625" x2="16.812" y2="1.76185625" layer="29"/>
<rectangle x1="17.235621875" y1="1.74420625" x2="17.588634375" y2="1.76185625" layer="29"/>
<rectangle x1="18.347625" y1="1.74420625" x2="19.1772125" y2="1.76185625" layer="29"/>
<rectangle x1="0.3437625" y1="1.76185625" x2="1.3851625" y2="1.77950625" layer="29"/>
<rectangle x1="2.03824375" y1="1.76185625" x2="3.09729375" y2="1.77950625" layer="29"/>
<rectangle x1="4.897678125" y1="1.76185625" x2="5.956728125" y2="1.77950625" layer="29"/>
<rectangle x1="6.6451125" y1="1.76185625" x2="7.6865125" y2="1.77950625" layer="29"/>
<rectangle x1="8.28664375" y1="1.76185625" x2="9.34569375" y2="1.77950625" layer="29"/>
<rectangle x1="11.146078125" y1="1.76185625" x2="12.205128125" y2="1.77950625" layer="29"/>
<rectangle x1="12.76995625" y1="1.76185625" x2="13.59954375" y2="1.77950625" layer="29"/>
<rectangle x1="14.02316875" y1="1.76185625" x2="14.85275625" y2="1.77950625" layer="29"/>
<rectangle x1="15.276378125" y1="1.76185625" x2="15.841203125" y2="1.77950625" layer="29"/>
<rectangle x1="16.247175" y1="1.76185625" x2="16.812" y2="1.77950625" layer="29"/>
<rectangle x1="17.235621875" y1="1.76185625" x2="17.588634375" y2="1.77950625" layer="29"/>
<rectangle x1="18.347625" y1="1.76185625" x2="19.1772125" y2="1.77950625" layer="29"/>
<rectangle x1="0.3437625" y1="1.77950625" x2="1.3851625" y2="1.79715625" layer="29"/>
<rectangle x1="2.03824375" y1="1.77950625" x2="3.09729375" y2="1.79715625" layer="29"/>
<rectangle x1="4.897678125" y1="1.77950625" x2="5.956728125" y2="1.79715625" layer="29"/>
<rectangle x1="6.6451125" y1="1.77950625" x2="7.6865125" y2="1.79715625" layer="29"/>
<rectangle x1="8.28664375" y1="1.77950625" x2="9.34569375" y2="1.79715625" layer="29"/>
<rectangle x1="11.146078125" y1="1.77950625" x2="12.205128125" y2="1.79715625" layer="29"/>
<rectangle x1="12.76995625" y1="1.77950625" x2="13.59954375" y2="1.79715625" layer="29"/>
<rectangle x1="14.02316875" y1="1.77950625" x2="14.85275625" y2="1.79715625" layer="29"/>
<rectangle x1="15.276378125" y1="1.77950625" x2="15.841203125" y2="1.79715625" layer="29"/>
<rectangle x1="16.247175" y1="1.77950625" x2="16.812" y2="1.79715625" layer="29"/>
<rectangle x1="17.235621875" y1="1.77950625" x2="17.588634375" y2="1.79715625" layer="29"/>
<rectangle x1="18.347625" y1="1.77950625" x2="19.1772125" y2="1.79715625" layer="29"/>
<rectangle x1="0.3437625" y1="1.79715625" x2="1.3851625" y2="1.81480625" layer="29"/>
<rectangle x1="2.03824375" y1="1.79715625" x2="3.11494375" y2="1.81480625" layer="29"/>
<rectangle x1="4.897678125" y1="1.79715625" x2="5.956728125" y2="1.81480625" layer="29"/>
<rectangle x1="6.6451125" y1="1.79715625" x2="7.6865125" y2="1.81480625" layer="29"/>
<rectangle x1="8.28664375" y1="1.79715625" x2="9.34569375" y2="1.81480625" layer="29"/>
<rectangle x1="11.146078125" y1="1.79715625" x2="12.205128125" y2="1.81480625" layer="29"/>
<rectangle x1="12.76995625" y1="1.79715625" x2="13.59954375" y2="1.81480625" layer="29"/>
<rectangle x1="14.02316875" y1="1.79715625" x2="14.85275625" y2="1.81480625" layer="29"/>
<rectangle x1="15.276378125" y1="1.79715625" x2="15.841203125" y2="1.81480625" layer="29"/>
<rectangle x1="16.247175" y1="1.79715625" x2="16.812" y2="1.81480625" layer="29"/>
<rectangle x1="17.235621875" y1="1.79715625" x2="17.588634375" y2="1.81480625" layer="29"/>
<rectangle x1="18.347625" y1="1.79715625" x2="19.1772125" y2="1.81480625" layer="29"/>
<rectangle x1="0.3437625" y1="1.814809375" x2="1.3851625" y2="1.832459375" layer="29"/>
<rectangle x1="2.05589375" y1="1.814809375" x2="3.11494375" y2="1.832459375" layer="29"/>
<rectangle x1="4.897678125" y1="1.814809375" x2="5.956728125" y2="1.832459375" layer="29"/>
<rectangle x1="6.6451125" y1="1.814809375" x2="7.6865125" y2="1.832459375" layer="29"/>
<rectangle x1="8.28664375" y1="1.814809375" x2="9.34569375" y2="1.832459375" layer="29"/>
<rectangle x1="11.146078125" y1="1.814809375" x2="12.205128125" y2="1.832459375" layer="29"/>
<rectangle x1="12.76995625" y1="1.814809375" x2="13.59954375" y2="1.832459375" layer="29"/>
<rectangle x1="14.02316875" y1="1.814809375" x2="14.85275625" y2="1.832459375" layer="29"/>
<rectangle x1="15.276378125" y1="1.814809375" x2="15.841203125" y2="1.832459375" layer="29"/>
<rectangle x1="16.247175" y1="1.814809375" x2="16.812" y2="1.832459375" layer="29"/>
<rectangle x1="17.235621875" y1="1.814809375" x2="17.588634375" y2="1.832459375" layer="29"/>
<rectangle x1="18.347625" y1="1.814809375" x2="19.1772125" y2="1.832459375" layer="29"/>
<rectangle x1="0.3437625" y1="1.832459375" x2="1.3851625" y2="1.850109375" layer="29"/>
<rectangle x1="2.05589375" y1="1.832459375" x2="3.11494375" y2="1.850109375" layer="29"/>
<rectangle x1="4.897678125" y1="1.832459375" x2="5.956728125" y2="1.850109375" layer="29"/>
<rectangle x1="6.6451125" y1="1.832459375" x2="7.6865125" y2="1.850109375" layer="29"/>
<rectangle x1="8.28664375" y1="1.832459375" x2="9.34569375" y2="1.850109375" layer="29"/>
<rectangle x1="11.128428125" y1="1.832459375" x2="12.205128125" y2="1.850109375" layer="29"/>
<rectangle x1="12.76995625" y1="1.832459375" x2="13.61719375" y2="1.850109375" layer="29"/>
<rectangle x1="14.02316875" y1="1.832459375" x2="14.85275625" y2="1.850109375" layer="29"/>
<rectangle x1="15.276378125" y1="1.832459375" x2="15.841203125" y2="1.850109375" layer="29"/>
<rectangle x1="16.247175" y1="1.832459375" x2="16.812" y2="1.850109375" layer="29"/>
<rectangle x1="17.235621875" y1="1.832459375" x2="17.606290625" y2="1.850109375" layer="29"/>
<rectangle x1="18.329975" y1="1.832459375" x2="19.1772125" y2="1.850109375" layer="29"/>
<rectangle x1="0.3437625" y1="1.850109375" x2="1.3851625" y2="1.867759375" layer="29"/>
<rectangle x1="2.05589375" y1="1.850109375" x2="3.11494375" y2="1.867759375" layer="29"/>
<rectangle x1="4.897678125" y1="1.850109375" x2="5.956728125" y2="1.867759375" layer="29"/>
<rectangle x1="6.6451125" y1="1.850109375" x2="7.6865125" y2="1.867759375" layer="29"/>
<rectangle x1="8.28664375" y1="1.850109375" x2="9.34569375" y2="1.867759375" layer="29"/>
<rectangle x1="11.128428125" y1="1.850109375" x2="12.187478125" y2="1.867759375" layer="29"/>
<rectangle x1="12.76995625" y1="1.850109375" x2="13.61719375" y2="1.867759375" layer="29"/>
<rectangle x1="14.02316875" y1="1.850109375" x2="14.85275625" y2="1.867759375" layer="29"/>
<rectangle x1="15.276378125" y1="1.850109375" x2="15.841203125" y2="1.867759375" layer="29"/>
<rectangle x1="16.247175" y1="1.850109375" x2="16.812" y2="1.867759375" layer="29"/>
<rectangle x1="17.235621875" y1="1.850109375" x2="19.177215625" y2="1.867759375" layer="29"/>
<rectangle x1="0.3437625" y1="1.8677625" x2="1.3851625" y2="1.8854125" layer="29"/>
<rectangle x1="2.05589375" y1="1.8677625" x2="3.11494375" y2="1.8854125" layer="29"/>
<rectangle x1="4.897678125" y1="1.8677625" x2="5.956728125" y2="1.8854125" layer="29"/>
<rectangle x1="6.6451125" y1="1.8677625" x2="7.6865125" y2="1.8854125" layer="29"/>
<rectangle x1="8.28664375" y1="1.8677625" x2="9.36334375" y2="1.8854125" layer="29"/>
<rectangle x1="11.128428125" y1="1.8677625" x2="12.187478125" y2="1.8854125" layer="29"/>
<rectangle x1="12.76995625" y1="1.8677625" x2="13.61719375" y2="1.8854125" layer="29"/>
<rectangle x1="14.04081875" y1="1.8677625" x2="14.85275625" y2="1.8854125" layer="29"/>
<rectangle x1="15.258728125" y1="1.8677625" x2="15.841203125" y2="1.8854125" layer="29"/>
<rectangle x1="16.247175" y1="1.8677625" x2="16.82965" y2="1.8854125" layer="29"/>
<rectangle x1="17.253271875" y1="1.8677625" x2="19.177215625" y2="1.8854125" layer="29"/>
<rectangle x1="0.3437625" y1="1.8854125" x2="1.3851625" y2="1.9030625" layer="29"/>
<rectangle x1="2.05589375" y1="1.8854125" x2="3.11494375" y2="1.9030625" layer="29"/>
<rectangle x1="4.880028125" y1="1.8854125" x2="5.956728125" y2="1.9030625" layer="29"/>
<rectangle x1="6.6451125" y1="1.8854125" x2="7.6865125" y2="1.9030625" layer="29"/>
<rectangle x1="8.28664375" y1="1.8854125" x2="9.36334375" y2="1.9030625" layer="29"/>
<rectangle x1="11.128428125" y1="1.8854125" x2="12.187478125" y2="1.9030625" layer="29"/>
<rectangle x1="12.76995625" y1="1.8854125" x2="13.61719375" y2="1.9030625" layer="29"/>
<rectangle x1="14.04081875" y1="1.8854125" x2="14.83510625" y2="1.9030625" layer="29"/>
<rectangle x1="15.258728125" y1="1.8854125" x2="15.841203125" y2="1.9030625" layer="29"/>
<rectangle x1="16.247175" y1="1.8854125" x2="16.82965" y2="1.9030625" layer="29"/>
<rectangle x1="17.253271875" y1="1.8854125" x2="19.177215625" y2="1.9030625" layer="29"/>
<rectangle x1="0.3437625" y1="1.9030625" x2="1.3851625" y2="1.9207125" layer="29"/>
<rectangle x1="2.05589375" y1="1.9030625" x2="3.13259375" y2="1.9207125" layer="29"/>
<rectangle x1="4.880028125" y1="1.9030625" x2="5.956728125" y2="1.9207125" layer="29"/>
<rectangle x1="6.6451125" y1="1.9030625" x2="7.6865125" y2="1.9207125" layer="29"/>
<rectangle x1="8.28664375" y1="1.9030625" x2="9.36334375" y2="1.9207125" layer="29"/>
<rectangle x1="11.128428125" y1="1.9030625" x2="12.187478125" y2="1.9207125" layer="29"/>
<rectangle x1="12.76995625" y1="1.9030625" x2="13.61719375" y2="1.9207125" layer="29"/>
<rectangle x1="14.04081875" y1="1.9030625" x2="14.83510625" y2="1.9207125" layer="29"/>
<rectangle x1="15.258728125" y1="1.9030625" x2="15.841203125" y2="1.9207125" layer="29"/>
<rectangle x1="16.247175" y1="1.9030625" x2="16.82965" y2="1.9207125" layer="29"/>
<rectangle x1="17.253271875" y1="1.9030625" x2="19.177215625" y2="1.9207125" layer="29"/>
<rectangle x1="0.3437625" y1="1.9207125" x2="1.3851625" y2="1.9383625" layer="29"/>
<rectangle x1="2.05589375" y1="1.9207125" x2="3.13259375" y2="1.9383625" layer="29"/>
<rectangle x1="4.880028125" y1="1.9207125" x2="5.956728125" y2="1.9383625" layer="29"/>
<rectangle x1="6.6451125" y1="1.9207125" x2="7.6865125" y2="1.9383625" layer="29"/>
<rectangle x1="8.30429375" y1="1.9207125" x2="9.36334375" y2="1.9383625" layer="29"/>
<rectangle x1="11.110778125" y1="1.9207125" x2="12.187478125" y2="1.9383625" layer="29"/>
<rectangle x1="12.76995625" y1="1.9207125" x2="13.61719375" y2="1.9383625" layer="29"/>
<rectangle x1="14.04081875" y1="1.9207125" x2="14.83510625" y2="1.9383625" layer="29"/>
<rectangle x1="15.258728125" y1="1.9207125" x2="15.841203125" y2="1.9383625" layer="29"/>
<rectangle x1="16.247175" y1="1.9207125" x2="16.82965" y2="1.9383625" layer="29"/>
<rectangle x1="17.253271875" y1="1.9207125" x2="19.177215625" y2="1.9383625" layer="29"/>
<rectangle x1="0.3437625" y1="1.938365625" x2="1.3851625" y2="1.956015625" layer="29"/>
<rectangle x1="2.05589375" y1="1.938365625" x2="3.13259375" y2="1.956015625" layer="29"/>
<rectangle x1="4.880028125" y1="1.938365625" x2="5.939078125" y2="1.956015625" layer="29"/>
<rectangle x1="6.6451125" y1="1.938365625" x2="7.6865125" y2="1.956015625" layer="29"/>
<rectangle x1="8.30429375" y1="1.938365625" x2="9.38099375" y2="1.956015625" layer="29"/>
<rectangle x1="11.110778125" y1="1.938365625" x2="12.187478125" y2="1.956015625" layer="29"/>
<rectangle x1="12.76995625" y1="1.938365625" x2="13.61719375" y2="1.956015625" layer="29"/>
<rectangle x1="14.04081875" y1="1.938365625" x2="14.83510625" y2="1.956015625" layer="29"/>
<rectangle x1="15.258728125" y1="1.938365625" x2="15.841203125" y2="1.956015625" layer="29"/>
<rectangle x1="16.247175" y1="1.938365625" x2="16.82965" y2="1.956015625" layer="29"/>
<rectangle x1="17.270925" y1="1.938365625" x2="19.1772125" y2="1.956015625" layer="29"/>
<rectangle x1="0.3437625" y1="1.956015625" x2="1.3851625" y2="1.973665625" layer="29"/>
<rectangle x1="2.05589375" y1="1.956015625" x2="3.13259375" y2="1.973665625" layer="29"/>
<rectangle x1="4.862378125" y1="1.956015625" x2="5.939078125" y2="1.973665625" layer="29"/>
<rectangle x1="6.6451125" y1="1.956015625" x2="7.6865125" y2="1.973665625" layer="29"/>
<rectangle x1="8.30429375" y1="1.956015625" x2="9.38099375" y2="1.973665625" layer="29"/>
<rectangle x1="11.110778125" y1="1.956015625" x2="12.187478125" y2="1.973665625" layer="29"/>
<rectangle x1="12.76995625" y1="1.956015625" x2="13.61719375" y2="1.973665625" layer="29"/>
<rectangle x1="14.04081875" y1="1.956015625" x2="14.83510625" y2="1.973665625" layer="29"/>
<rectangle x1="15.258728125" y1="1.956015625" x2="15.841203125" y2="1.973665625" layer="29"/>
<rectangle x1="16.247175" y1="1.956015625" x2="16.82965" y2="1.973665625" layer="29"/>
<rectangle x1="17.270925" y1="1.956015625" x2="19.1772125" y2="1.973665625" layer="29"/>
<rectangle x1="0.3437625" y1="1.973665625" x2="1.3851625" y2="1.991315625" layer="29"/>
<rectangle x1="2.05589375" y1="1.973665625" x2="3.15024375" y2="1.991315625" layer="29"/>
<rectangle x1="4.862378125" y1="1.973665625" x2="5.939078125" y2="1.991315625" layer="29"/>
<rectangle x1="6.6451125" y1="1.973665625" x2="7.6865125" y2="1.991315625" layer="29"/>
<rectangle x1="8.30429375" y1="1.973665625" x2="9.38099375" y2="1.991315625" layer="29"/>
<rectangle x1="11.093128125" y1="1.973665625" x2="12.187478125" y2="1.991315625" layer="29"/>
<rectangle x1="12.76995625" y1="1.973665625" x2="13.61719375" y2="1.991315625" layer="29"/>
<rectangle x1="14.05846875" y1="1.973665625" x2="14.83510625" y2="1.991315625" layer="29"/>
<rectangle x1="15.258728125" y1="1.973665625" x2="15.841203125" y2="1.991315625" layer="29"/>
<rectangle x1="16.247175" y1="1.973665625" x2="16.8473" y2="1.991315625" layer="29"/>
<rectangle x1="17.270925" y1="1.973665625" x2="19.1772125" y2="1.991315625" layer="29"/>
<rectangle x1="0.3437625" y1="1.991315625" x2="1.3851625" y2="2.008965625" layer="29"/>
<rectangle x1="2.07354375" y1="1.991315625" x2="3.15024375" y2="2.008965625" layer="29"/>
<rectangle x1="4.862378125" y1="1.991315625" x2="5.939078125" y2="2.008965625" layer="29"/>
<rectangle x1="6.6451125" y1="1.991315625" x2="7.6865125" y2="2.008965625" layer="29"/>
<rectangle x1="8.30429375" y1="1.991315625" x2="9.39864375" y2="2.008965625" layer="29"/>
<rectangle x1="11.093128125" y1="1.991315625" x2="12.187478125" y2="2.008965625" layer="29"/>
<rectangle x1="12.76995625" y1="1.991315625" x2="13.63485" y2="2.008965625" layer="29"/>
<rectangle x1="14.05846875" y1="1.991315625" x2="14.81745625" y2="2.008965625" layer="29"/>
<rectangle x1="15.241075" y1="1.991315625" x2="15.84120625" y2="2.008965625" layer="29"/>
<rectangle x1="16.247175" y1="1.991315625" x2="16.8473" y2="2.008965625" layer="29"/>
<rectangle x1="17.288575" y1="1.991315625" x2="19.1595625" y2="2.008965625" layer="29"/>
<rectangle x1="0.3437625" y1="2.00896875" x2="1.3851625" y2="2.02661875" layer="29"/>
<rectangle x1="2.07354375" y1="2.00896875" x2="3.16789375" y2="2.02661875" layer="29"/>
<rectangle x1="4.844728125" y1="2.00896875" x2="5.939078125" y2="2.02661875" layer="29"/>
<rectangle x1="6.6451125" y1="2.00896875" x2="7.6865125" y2="2.02661875" layer="29"/>
<rectangle x1="8.30429375" y1="2.00896875" x2="9.39864375" y2="2.02661875" layer="29"/>
<rectangle x1="11.093128125" y1="2.00896875" x2="12.169828125" y2="2.02661875" layer="29"/>
<rectangle x1="12.787609375" y1="2.00896875" x2="13.634846875" y2="2.02661875" layer="29"/>
<rectangle x1="14.05846875" y1="2.00896875" x2="14.81745625" y2="2.02661875" layer="29"/>
<rectangle x1="15.241075" y1="2.00896875" x2="15.84120625" y2="2.02661875" layer="29"/>
<rectangle x1="16.247175" y1="2.00896875" x2="16.8473" y2="2.02661875" layer="29"/>
<rectangle x1="17.288575" y1="2.00896875" x2="19.1595625" y2="2.02661875" layer="29"/>
<rectangle x1="0.3437625" y1="2.02661875" x2="1.3851625" y2="2.04426875" layer="29"/>
<rectangle x1="2.07354375" y1="2.02661875" x2="3.16789375" y2="2.04426875" layer="29"/>
<rectangle x1="4.844728125" y1="2.02661875" x2="5.939078125" y2="2.04426875" layer="29"/>
<rectangle x1="6.6451125" y1="2.02661875" x2="7.6865125" y2="2.04426875" layer="29"/>
<rectangle x1="8.30429375" y1="2.02661875" x2="9.39864375" y2="2.04426875" layer="29"/>
<rectangle x1="11.075475" y1="2.02661875" x2="12.169825" y2="2.04426875" layer="29"/>
<rectangle x1="12.787609375" y1="2.02661875" x2="13.634846875" y2="2.04426875" layer="29"/>
<rectangle x1="14.05846875" y1="2.02661875" x2="14.81745625" y2="2.04426875" layer="29"/>
<rectangle x1="15.241075" y1="2.02661875" x2="15.84120625" y2="2.04426875" layer="29"/>
<rectangle x1="16.247175" y1="2.02661875" x2="16.8473" y2="2.04426875" layer="29"/>
<rectangle x1="17.288575" y1="2.02661875" x2="19.1595625" y2="2.04426875" layer="29"/>
<rectangle x1="0.3437625" y1="2.04426875" x2="1.3851625" y2="2.06191875" layer="29"/>
<rectangle x1="2.07354375" y1="2.04426875" x2="3.16789375" y2="2.06191875" layer="29"/>
<rectangle x1="4.827075" y1="2.04426875" x2="5.921425" y2="2.06191875" layer="29"/>
<rectangle x1="6.6451125" y1="2.04426875" x2="7.6865125" y2="2.06191875" layer="29"/>
<rectangle x1="8.32194375" y1="2.04426875" x2="9.41629375" y2="2.06191875" layer="29"/>
<rectangle x1="11.075475" y1="2.04426875" x2="12.169825" y2="2.06191875" layer="29"/>
<rectangle x1="12.787609375" y1="2.04426875" x2="13.634846875" y2="2.06191875" layer="29"/>
<rectangle x1="14.076121875" y1="2.04426875" x2="14.817453125" y2="2.06191875" layer="29"/>
<rectangle x1="15.241075" y1="2.04426875" x2="15.84120625" y2="2.06191875" layer="29"/>
<rectangle x1="16.247175" y1="2.04426875" x2="16.86495" y2="2.06191875" layer="29"/>
<rectangle x1="17.306225" y1="2.04426875" x2="19.1595625" y2="2.06191875" layer="29"/>
<rectangle x1="0.3437625" y1="2.061921875" x2="1.3851625" y2="2.079571875" layer="29"/>
<rectangle x1="2.07354375" y1="2.061921875" x2="3.18554375" y2="2.079571875" layer="29"/>
<rectangle x1="4.827075" y1="2.061921875" x2="5.921425" y2="2.079571875" layer="29"/>
<rectangle x1="6.6451125" y1="2.061921875" x2="7.6865125" y2="2.079571875" layer="29"/>
<rectangle x1="8.32194375" y1="2.061921875" x2="9.41629375" y2="2.079571875" layer="29"/>
<rectangle x1="11.057825" y1="2.061921875" x2="12.169825" y2="2.079571875" layer="29"/>
<rectangle x1="12.787609375" y1="2.061921875" x2="13.652496875" y2="2.079571875" layer="29"/>
<rectangle x1="14.076121875" y1="2.061921875" x2="14.799803125" y2="2.079571875" layer="29"/>
<rectangle x1="15.241075" y1="2.061921875" x2="15.84120625" y2="2.079571875" layer="29"/>
<rectangle x1="16.247175" y1="2.061921875" x2="16.86495" y2="2.079571875" layer="29"/>
<rectangle x1="17.306225" y1="2.061921875" x2="19.1595625" y2="2.079571875" layer="29"/>
<rectangle x1="0.3437625" y1="2.079571875" x2="1.3851625" y2="2.097221875" layer="29"/>
<rectangle x1="2.09119375" y1="2.079571875" x2="3.18554375" y2="2.097221875" layer="29"/>
<rectangle x1="4.809425" y1="2.079571875" x2="5.921425" y2="2.097221875" layer="29"/>
<rectangle x1="6.6451125" y1="2.079571875" x2="7.6865125" y2="2.097221875" layer="29"/>
<rectangle x1="8.32194375" y1="2.079571875" x2="9.43394375" y2="2.097221875" layer="29"/>
<rectangle x1="11.057825" y1="2.079571875" x2="12.169825" y2="2.097221875" layer="29"/>
<rectangle x1="12.787609375" y1="2.079571875" x2="13.652496875" y2="2.097221875" layer="29"/>
<rectangle x1="14.076121875" y1="2.079571875" x2="14.799803125" y2="2.097221875" layer="29"/>
<rectangle x1="15.223425" y1="2.079571875" x2="15.84120625" y2="2.097221875" layer="29"/>
<rectangle x1="16.247175" y1="2.079571875" x2="16.86495" y2="2.097221875" layer="29"/>
<rectangle x1="17.323875" y1="2.079571875" x2="19.1595625" y2="2.097221875" layer="29"/>
<rectangle x1="0.3437625" y1="2.097221875" x2="1.3851625" y2="2.114871875" layer="29"/>
<rectangle x1="2.09119375" y1="2.097221875" x2="3.20319375" y2="2.114871875" layer="29"/>
<rectangle x1="4.809425" y1="2.097221875" x2="5.921425" y2="2.114871875" layer="29"/>
<rectangle x1="6.6451125" y1="2.097221875" x2="7.6865125" y2="2.114871875" layer="29"/>
<rectangle x1="8.32194375" y1="2.097221875" x2="9.43394375" y2="2.114871875" layer="29"/>
<rectangle x1="11.040175" y1="2.097221875" x2="12.152175" y2="2.114871875" layer="29"/>
<rectangle x1="12.787609375" y1="2.097221875" x2="13.652496875" y2="2.114871875" layer="29"/>
<rectangle x1="14.093771875" y1="2.097221875" x2="14.782153125" y2="2.114871875" layer="29"/>
<rectangle x1="15.223425" y1="2.097221875" x2="15.84120625" y2="2.114871875" layer="29"/>
<rectangle x1="16.247175" y1="2.097221875" x2="16.86495" y2="2.114871875" layer="29"/>
<rectangle x1="17.341528125" y1="2.097221875" x2="19.141909375" y2="2.114871875" layer="29"/>
<rectangle x1="0.3437625" y1="2.114871875" x2="1.3851625" y2="2.132521875" layer="29"/>
<rectangle x1="2.09119375" y1="2.114871875" x2="3.20319375" y2="2.132521875" layer="29"/>
<rectangle x1="4.791775" y1="2.114871875" x2="5.921425" y2="2.132521875" layer="29"/>
<rectangle x1="6.6451125" y1="2.114871875" x2="7.6865125" y2="2.132521875" layer="29"/>
<rectangle x1="8.33959375" y1="2.114871875" x2="9.45159375" y2="2.132521875" layer="29"/>
<rectangle x1="11.040175" y1="2.114871875" x2="12.152175" y2="2.132521875" layer="29"/>
<rectangle x1="12.805259375" y1="2.114871875" x2="13.652496875" y2="2.132521875" layer="29"/>
<rectangle x1="14.093771875" y1="2.114871875" x2="14.782153125" y2="2.132521875" layer="29"/>
<rectangle x1="15.223425" y1="2.114871875" x2="15.84120625" y2="2.132521875" layer="29"/>
<rectangle x1="16.247175" y1="2.114871875" x2="16.88260625" y2="2.132521875" layer="29"/>
<rectangle x1="17.341528125" y1="2.114871875" x2="19.141909375" y2="2.132521875" layer="29"/>
<rectangle x1="0.3437625" y1="2.132525" x2="1.3851625" y2="2.150175" layer="29"/>
<rectangle x1="2.09119375" y1="2.132525" x2="3.22085" y2="2.150175" layer="29"/>
<rectangle x1="4.791775" y1="2.132525" x2="5.903775" y2="2.150175" layer="29"/>
<rectangle x1="6.6451125" y1="2.132525" x2="7.6865125" y2="2.150175" layer="29"/>
<rectangle x1="8.33959375" y1="2.132525" x2="9.45159375" y2="2.150175" layer="29"/>
<rectangle x1="11.022525" y1="2.132525" x2="12.152175" y2="2.150175" layer="29"/>
<rectangle x1="12.805259375" y1="2.132525" x2="13.670146875" y2="2.150175" layer="29"/>
<rectangle x1="14.111421875" y1="2.132525" x2="14.764503125" y2="2.150175" layer="29"/>
<rectangle x1="15.205775" y1="2.132525" x2="15.84120625" y2="2.150175" layer="29"/>
<rectangle x1="16.247175" y1="2.132525" x2="16.88260625" y2="2.150175" layer="29"/>
<rectangle x1="17.359178125" y1="2.132525" x2="19.141909375" y2="2.150175" layer="29"/>
<rectangle x1="0.3437625" y1="2.150175" x2="1.3851625" y2="2.167825" layer="29"/>
<rectangle x1="2.108846875" y1="2.150175" x2="3.238496875" y2="2.167825" layer="29"/>
<rectangle x1="4.774125" y1="2.150175" x2="5.903775" y2="2.167825" layer="29"/>
<rectangle x1="6.6451125" y1="2.150175" x2="7.6865125" y2="2.167825" layer="29"/>
<rectangle x1="8.33959375" y1="2.150175" x2="9.46925" y2="2.167825" layer="29"/>
<rectangle x1="11.022525" y1="2.150175" x2="12.152175" y2="2.167825" layer="29"/>
<rectangle x1="12.805259375" y1="2.150175" x2="13.670146875" y2="2.167825" layer="29"/>
<rectangle x1="14.111421875" y1="2.150175" x2="14.764503125" y2="2.167825" layer="29"/>
<rectangle x1="15.205775" y1="2.150175" x2="15.84120625" y2="2.167825" layer="29"/>
<rectangle x1="16.247175" y1="2.150175" x2="16.90025625" y2="2.167825" layer="29"/>
<rectangle x1="17.376828125" y1="2.150175" x2="19.141909375" y2="2.167825" layer="29"/>
<rectangle x1="0.3437625" y1="2.167825" x2="1.3851625" y2="2.185475" layer="29"/>
<rectangle x1="2.108846875" y1="2.167825" x2="3.238496875" y2="2.185475" layer="29"/>
<rectangle x1="4.774125" y1="2.167825" x2="5.903775" y2="2.185475" layer="29"/>
<rectangle x1="6.6451125" y1="2.167825" x2="7.6865125" y2="2.185475" layer="29"/>
<rectangle x1="8.33959375" y1="2.167825" x2="9.4869" y2="2.185475" layer="29"/>
<rectangle x1="11.004871875" y1="2.167825" x2="12.134528125" y2="2.185475" layer="29"/>
<rectangle x1="12.805259375" y1="2.167825" x2="13.670146875" y2="2.185475" layer="29"/>
<rectangle x1="14.129071875" y1="2.167825" x2="14.746853125" y2="2.185475" layer="29"/>
<rectangle x1="15.205775" y1="2.167825" x2="15.84120625" y2="2.185475" layer="29"/>
<rectangle x1="16.247175" y1="2.167825" x2="16.90025625" y2="2.185475" layer="29"/>
<rectangle x1="17.394478125" y1="2.167825" x2="19.141909375" y2="2.185475" layer="29"/>
<rectangle x1="0.3437625" y1="2.185475" x2="1.3851625" y2="2.203125" layer="29"/>
<rectangle x1="2.108846875" y1="2.185475" x2="3.256146875" y2="2.203125" layer="29"/>
<rectangle x1="4.756471875" y1="2.185475" x2="5.903778125" y2="2.203125" layer="29"/>
<rectangle x1="6.6451125" y1="2.185475" x2="7.6865125" y2="2.203125" layer="29"/>
<rectangle x1="8.357246875" y1="2.185475" x2="9.486896875" y2="2.203125" layer="29"/>
<rectangle x1="10.987221875" y1="2.185475" x2="12.134528125" y2="2.203125" layer="29"/>
<rectangle x1="12.822909375" y1="2.185475" x2="13.687803125" y2="2.203125" layer="29"/>
<rectangle x1="14.146725" y1="2.185475" x2="14.74685" y2="2.203125" layer="29"/>
<rectangle x1="15.188125" y1="2.185475" x2="15.84120625" y2="2.203125" layer="29"/>
<rectangle x1="16.247175" y1="2.185475" x2="16.91790625" y2="2.203125" layer="29"/>
<rectangle x1="17.41213125" y1="2.185475" x2="19.1242625" y2="2.203125" layer="29"/>
<rectangle x1="0.3437625" y1="2.203128125" x2="1.3851625" y2="2.220778125" layer="29"/>
<rectangle x1="2.108846875" y1="2.203128125" x2="3.273803125" y2="2.220778125" layer="29"/>
<rectangle x1="4.738821875" y1="2.203128125" x2="5.886128125" y2="2.220778125" layer="29"/>
<rectangle x1="6.6451125" y1="2.203128125" x2="7.6865125" y2="2.220778125" layer="29"/>
<rectangle x1="8.357246875" y1="2.203128125" x2="9.504546875" y2="2.220778125" layer="29"/>
<rectangle x1="10.987221875" y1="2.203128125" x2="12.134528125" y2="2.220778125" layer="29"/>
<rectangle x1="12.822909375" y1="2.203128125" x2="13.687803125" y2="2.220778125" layer="29"/>
<rectangle x1="14.146725" y1="2.203128125" x2="14.7292" y2="2.220778125" layer="29"/>
<rectangle x1="15.188125" y1="2.203128125" x2="15.84120625" y2="2.220778125" layer="29"/>
<rectangle x1="16.247175" y1="2.203128125" x2="16.91790625" y2="2.220778125" layer="29"/>
<rectangle x1="17.42978125" y1="2.203128125" x2="19.1242625" y2="2.220778125" layer="29"/>
<rectangle x1="0.3437625" y1="2.220778125" x2="1.3851625" y2="2.238428125" layer="29"/>
<rectangle x1="2.126496875" y1="2.220778125" x2="3.273803125" y2="2.238428125" layer="29"/>
<rectangle x1="4.721171875" y1="2.220778125" x2="5.886128125" y2="2.238428125" layer="29"/>
<rectangle x1="6.6451125" y1="2.220778125" x2="7.6865125" y2="2.238428125" layer="29"/>
<rectangle x1="8.357246875" y1="2.220778125" x2="9.522203125" y2="2.238428125" layer="29"/>
<rectangle x1="10.969571875" y1="2.220778125" x2="12.116871875" y2="2.238428125" layer="29"/>
<rectangle x1="12.822909375" y1="2.220778125" x2="13.705453125" y2="2.238428125" layer="29"/>
<rectangle x1="14.164375" y1="2.220778125" x2="14.71155" y2="2.238428125" layer="29"/>
<rectangle x1="15.188125" y1="2.220778125" x2="15.84120625" y2="2.238428125" layer="29"/>
<rectangle x1="16.247175" y1="2.220778125" x2="16.93555625" y2="2.238428125" layer="29"/>
<rectangle x1="17.44743125" y1="2.220778125" x2="19.1242625" y2="2.238428125" layer="29"/>
<rectangle x1="0.3437625" y1="2.238428125" x2="1.3851625" y2="2.256078125" layer="29"/>
<rectangle x1="2.126496875" y1="2.238428125" x2="3.291453125" y2="2.256078125" layer="29"/>
<rectangle x1="4.721171875" y1="2.238428125" x2="5.886128125" y2="2.256078125" layer="29"/>
<rectangle x1="6.6451125" y1="2.238428125" x2="7.6865125" y2="2.256078125" layer="29"/>
<rectangle x1="8.374896875" y1="2.238428125" x2="9.522203125" y2="2.256078125" layer="29"/>
<rectangle x1="10.951921875" y1="2.238428125" x2="12.116871875" y2="2.256078125" layer="29"/>
<rectangle x1="12.822909375" y1="2.238428125" x2="13.705453125" y2="2.256078125" layer="29"/>
<rectangle x1="14.182025" y1="2.238428125" x2="14.6939" y2="2.256078125" layer="29"/>
<rectangle x1="15.170471875" y1="2.238428125" x2="15.841203125" y2="2.256078125" layer="29"/>
<rectangle x1="16.247175" y1="2.238428125" x2="16.93555625" y2="2.256078125" layer="29"/>
<rectangle x1="17.465084375" y1="2.238428125" x2="18.171115625" y2="2.256078125" layer="29"/>
<rectangle x1="18.20641875" y1="2.238428125" x2="19.1242625" y2="2.256078125" layer="29"/>
<rectangle x1="0.3437625" y1="2.256078125" x2="1.3851625" y2="2.273728125" layer="29"/>
<rectangle x1="2.126496875" y1="2.256078125" x2="3.309103125" y2="2.273728125" layer="29"/>
<rectangle x1="4.703521875" y1="2.256078125" x2="5.868471875" y2="2.273728125" layer="29"/>
<rectangle x1="6.6451125" y1="2.256078125" x2="7.6865125" y2="2.273728125" layer="29"/>
<rectangle x1="8.374896875" y1="2.256078125" x2="9.539853125" y2="2.273728125" layer="29"/>
<rectangle x1="10.93426875" y1="2.256078125" x2="12.116875" y2="2.273728125" layer="29"/>
<rectangle x1="12.8405625" y1="2.256078125" x2="13.70545" y2="2.273728125" layer="29"/>
<rectangle x1="14.199675" y1="2.256078125" x2="14.67625" y2="2.273728125" layer="29"/>
<rectangle x1="15.170471875" y1="2.256078125" x2="15.841203125" y2="2.273728125" layer="29"/>
<rectangle x1="16.247175" y1="2.256078125" x2="16.95320625" y2="2.273728125" layer="29"/>
<rectangle x1="17.500384375" y1="2.256078125" x2="18.118165625" y2="2.273728125" layer="29"/>
<rectangle x1="18.22406875" y1="2.256078125" x2="19.1066125" y2="2.273728125" layer="29"/>
<rectangle x1="0.3437625" y1="2.27373125" x2="1.3851625" y2="2.29138125" layer="29"/>
<rectangle x1="2.144146875" y1="2.27373125" x2="3.326753125" y2="2.29138125" layer="29"/>
<rectangle x1="4.68586875" y1="2.27373125" x2="5.868475" y2="2.29138125" layer="29"/>
<rectangle x1="6.6451125" y1="2.27373125" x2="7.6865125" y2="2.29138125" layer="29"/>
<rectangle x1="8.374896875" y1="2.27373125" x2="9.557503125" y2="2.29138125" layer="29"/>
<rectangle x1="10.93426875" y1="2.27373125" x2="12.099225" y2="2.29138125" layer="29"/>
<rectangle x1="12.8405625" y1="2.27373125" x2="13.7231" y2="2.29138125" layer="29"/>
<rectangle x1="14.234978125" y1="2.27373125" x2="14.640946875" y2="2.29138125" layer="29"/>
<rectangle x1="15.152821875" y1="2.27373125" x2="15.841203125" y2="2.29138125" layer="29"/>
<rectangle x1="16.247175" y1="2.27373125" x2="16.95320625" y2="2.29138125" layer="29"/>
<rectangle x1="17.5356875" y1="2.27373125" x2="18.0828625" y2="2.29138125" layer="29"/>
<rectangle x1="18.22406875" y1="2.27373125" x2="19.1066125" y2="2.29138125" layer="29"/>
<rectangle x1="0.3437625" y1="2.29138125" x2="1.3851625" y2="2.30903125" layer="29"/>
<rectangle x1="2.144146875" y1="2.29138125" x2="3.344403125" y2="2.30903125" layer="29"/>
<rectangle x1="4.66821875" y1="2.29138125" x2="5.868475" y2="2.30903125" layer="29"/>
<rectangle x1="6.6451125" y1="2.29138125" x2="7.6865125" y2="2.30903125" layer="29"/>
<rectangle x1="8.392546875" y1="2.29138125" x2="9.575153125" y2="2.30903125" layer="29"/>
<rectangle x1="10.91661875" y1="2.29138125" x2="12.099225" y2="2.30903125" layer="29"/>
<rectangle x1="12.8405625" y1="2.29138125" x2="13.74075" y2="2.30903125" layer="29"/>
<rectangle x1="14.270278125" y1="2.29138125" x2="14.623296875" y2="2.30903125" layer="29"/>
<rectangle x1="15.152821875" y1="2.29138125" x2="15.841203125" y2="2.30903125" layer="29"/>
<rectangle x1="16.247175" y1="2.29138125" x2="16.97085625" y2="2.30903125" layer="29"/>
<rectangle x1="17.5886375" y1="2.29138125" x2="18.01225625" y2="2.30903125" layer="29"/>
<rectangle x1="18.22406875" y1="2.29138125" x2="19.1066125" y2="2.30903125" layer="29"/>
<rectangle x1="0.3437625" y1="2.30903125" x2="1.3851625" y2="2.32668125" layer="29"/>
<rectangle x1="2.144146875" y1="2.30903125" x2="3.344403125" y2="2.32668125" layer="29"/>
<rectangle x1="4.65056875" y1="2.30903125" x2="5.850825" y2="2.32668125" layer="29"/>
<rectangle x1="6.6451125" y1="2.30903125" x2="7.6865125" y2="2.32668125" layer="29"/>
<rectangle x1="8.392546875" y1="2.30903125" x2="9.592803125" y2="2.32668125" layer="29"/>
<rectangle x1="10.89896875" y1="2.30903125" x2="12.099225" y2="2.32668125" layer="29"/>
<rectangle x1="12.8582125" y1="2.30903125" x2="13.74075" y2="2.32668125" layer="29"/>
<rectangle x1="14.30558125" y1="2.30903125" x2="14.57034375" y2="2.32668125" layer="29"/>
<rectangle x1="15.135171875" y1="2.30903125" x2="15.382284375" y2="2.32668125" layer="29"/>
<rectangle x1="16.706096875" y1="2.30903125" x2="16.988509375" y2="2.32668125" layer="29"/>
<rectangle x1="17.641590625" y1="2.30903125" x2="17.941653125" y2="2.32668125" layer="29"/>
<rectangle x1="18.241721875" y1="2.30903125" x2="19.088959375" y2="2.32668125" layer="29"/>
<rectangle x1="0.3437625" y1="2.326684375" x2="1.3851625" y2="2.344334375" layer="29"/>
<rectangle x1="2.161796875" y1="2.326684375" x2="3.362053125" y2="2.344334375" layer="29"/>
<rectangle x1="4.632915625" y1="2.326684375" x2="5.850821875" y2="2.344334375" layer="29"/>
<rectangle x1="6.6451125" y1="2.326684375" x2="7.6865125" y2="2.344334375" layer="29"/>
<rectangle x1="8.392546875" y1="2.326684375" x2="9.610453125" y2="2.344334375" layer="29"/>
<rectangle x1="10.881315625" y1="2.326684375" x2="12.081571875" y2="2.344334375" layer="29"/>
<rectangle x1="12.8582125" y1="2.326684375" x2="13.75840625" y2="2.344334375" layer="29"/>
<rectangle x1="15.117521875" y1="2.326684375" x2="15.382284375" y2="2.344334375" layer="29"/>
<rectangle x1="16.706096875" y1="2.326684375" x2="16.988509375" y2="2.344334375" layer="29"/>
<rectangle x1="18.241721875" y1="2.326684375" x2="19.088959375" y2="2.344334375" layer="29"/>
<rectangle x1="0.3437625" y1="2.344334375" x2="1.3851625" y2="2.361984375" layer="29"/>
<rectangle x1="2.161796875" y1="2.344334375" x2="3.379703125" y2="2.361984375" layer="29"/>
<rectangle x1="4.615265625" y1="2.344334375" x2="5.833171875" y2="2.361984375" layer="29"/>
<rectangle x1="6.6451125" y1="2.344334375" x2="7.6865125" y2="2.361984375" layer="29"/>
<rectangle x1="8.410196875" y1="2.344334375" x2="9.628103125" y2="2.361984375" layer="29"/>
<rectangle x1="10.863665625" y1="2.344334375" x2="12.081571875" y2="2.361984375" layer="29"/>
<rectangle x1="12.8582125" y1="2.344334375" x2="13.75840625" y2="2.361984375" layer="29"/>
<rectangle x1="15.117521875" y1="2.344334375" x2="15.382284375" y2="2.361984375" layer="29"/>
<rectangle x1="16.706096875" y1="2.344334375" x2="17.006159375" y2="2.361984375" layer="29"/>
<rectangle x1="18.259371875" y1="2.344334375" x2="19.088959375" y2="2.361984375" layer="29"/>
<rectangle x1="0.3437625" y1="2.361984375" x2="1.3851625" y2="2.379634375" layer="29"/>
<rectangle x1="2.17945" y1="2.361984375" x2="3.41500625" y2="2.379634375" layer="29"/>
<rectangle x1="4.597615625" y1="2.361984375" x2="5.833171875" y2="2.379634375" layer="29"/>
<rectangle x1="6.6451125" y1="2.361984375" x2="7.6865125" y2="2.379634375" layer="29"/>
<rectangle x1="8.410196875" y1="2.361984375" x2="9.645753125" y2="2.379634375" layer="29"/>
<rectangle x1="10.846015625" y1="2.361984375" x2="12.081571875" y2="2.379634375" layer="29"/>
<rectangle x1="12.8758625" y1="2.361984375" x2="13.77605625" y2="2.379634375" layer="29"/>
<rectangle x1="15.09986875" y1="2.361984375" x2="15.38228125" y2="2.379634375" layer="29"/>
<rectangle x1="16.706096875" y1="2.361984375" x2="17.023809375" y2="2.379634375" layer="29"/>
<rectangle x1="18.259371875" y1="2.361984375" x2="19.071309375" y2="2.379634375" layer="29"/>
<rectangle x1="0.3437625" y1="2.379634375" x2="1.3851625" y2="2.397284375" layer="29"/>
<rectangle x1="2.17945" y1="2.379634375" x2="3.43265625" y2="2.397284375" layer="29"/>
<rectangle x1="4.579965625" y1="2.379634375" x2="5.833171875" y2="2.397284375" layer="29"/>
<rectangle x1="6.6451125" y1="2.379634375" x2="7.6865125" y2="2.397284375" layer="29"/>
<rectangle x1="8.42785" y1="2.379634375" x2="9.66340625" y2="2.397284375" layer="29"/>
<rectangle x1="10.828365625" y1="2.379634375" x2="12.063921875" y2="2.397284375" layer="29"/>
<rectangle x1="12.8758625" y1="2.379634375" x2="13.79370625" y2="2.397284375" layer="29"/>
<rectangle x1="15.08221875" y1="2.379634375" x2="15.38228125" y2="2.397284375" layer="29"/>
<rectangle x1="16.706096875" y1="2.379634375" x2="17.041459375" y2="2.397284375" layer="29"/>
<rectangle x1="18.277021875" y1="2.379634375" x2="19.071309375" y2="2.397284375" layer="29"/>
<rectangle x1="0.3437625" y1="2.3972875" x2="1.3851625" y2="2.4149375" layer="29"/>
<rectangle x1="2.17945" y1="2.3972875" x2="3.45030625" y2="2.4149375" layer="29"/>
<rectangle x1="4.5623125" y1="2.3972875" x2="5.815525" y2="2.4149375" layer="29"/>
<rectangle x1="6.6451125" y1="2.3972875" x2="7.6865125" y2="2.4149375" layer="29"/>
<rectangle x1="8.42785" y1="2.3972875" x2="9.68105625" y2="2.4149375" layer="29"/>
<rectangle x1="10.7930625" y1="2.3972875" x2="12.063925" y2="2.4149375" layer="29"/>
<rectangle x1="12.8758625" y1="2.3972875" x2="13.81135625" y2="2.4149375" layer="29"/>
<rectangle x1="15.08221875" y1="2.3972875" x2="15.38228125" y2="2.4149375" layer="29"/>
<rectangle x1="16.706096875" y1="2.3972875" x2="17.059109375" y2="2.4149375" layer="29"/>
<rectangle x1="18.277021875" y1="2.3972875" x2="19.071309375" y2="2.4149375" layer="29"/>
<rectangle x1="0.3437625" y1="2.4149375" x2="1.3851625" y2="2.4325875" layer="29"/>
<rectangle x1="2.1971" y1="2.4149375" x2="3.4679625" y2="2.4325875" layer="29"/>
<rectangle x1="4.5446625" y1="2.4149375" x2="5.815525" y2="2.4325875" layer="29"/>
<rectangle x1="6.6451125" y1="2.4149375" x2="7.6865125" y2="2.4325875" layer="29"/>
<rectangle x1="8.42785" y1="2.4149375" x2="9.7163625" y2="2.4325875" layer="29"/>
<rectangle x1="10.7754125" y1="2.4149375" x2="12.04626875" y2="2.4325875" layer="29"/>
<rectangle x1="12.8935125" y1="2.4149375" x2="13.81135625" y2="2.4325875" layer="29"/>
<rectangle x1="15.06456875" y1="2.4149375" x2="15.38228125" y2="2.4325875" layer="29"/>
<rectangle x1="16.706096875" y1="2.4149375" x2="17.076765625" y2="2.4325875" layer="29"/>
<rectangle x1="18.277021875" y1="2.4149375" x2="19.053659375" y2="2.4325875" layer="29"/>
<rectangle x1="0.3437625" y1="2.4325875" x2="1.4028125" y2="2.4502375" layer="29"/>
<rectangle x1="2.1971" y1="2.4325875" x2="3.4856125" y2="2.4502375" layer="29"/>
<rectangle x1="4.5093625" y1="2.4325875" x2="5.79786875" y2="2.4502375" layer="29"/>
<rectangle x1="6.6451125" y1="2.4325875" x2="7.6865125" y2="2.4502375" layer="29"/>
<rectangle x1="8.4455" y1="2.4325875" x2="9.7340125" y2="2.4502375" layer="29"/>
<rectangle x1="10.7577625" y1="2.4325875" x2="12.04626875" y2="2.4502375" layer="29"/>
<rectangle x1="12.8935125" y1="2.4325875" x2="13.82900625" y2="2.4502375" layer="29"/>
<rectangle x1="15.046915625" y1="2.4325875" x2="15.382284375" y2="2.4502375" layer="29"/>
<rectangle x1="16.706096875" y1="2.4325875" x2="17.094415625" y2="2.4502375" layer="29"/>
<rectangle x1="18.294671875" y1="2.4325875" x2="19.053659375" y2="2.4502375" layer="29"/>
<rectangle x1="0.290809375" y1="2.4502375" x2="1.438109375" y2="2.4678875" layer="29"/>
<rectangle x1="2.21475" y1="2.4502375" x2="3.5209125" y2="2.4678875" layer="29"/>
<rectangle x1="4.491709375" y1="2.4502375" x2="5.797871875" y2="2.4678875" layer="29"/>
<rectangle x1="6.5921625" y1="2.4502375" x2="7.7394625" y2="2.4678875" layer="29"/>
<rectangle x1="8.4455" y1="2.4502375" x2="9.7516625" y2="2.4678875" layer="29"/>
<rectangle x1="10.722459375" y1="2.4502375" x2="12.028621875" y2="2.4678875" layer="29"/>
<rectangle x1="12.911165625" y1="2.4502375" x2="13.846659375" y2="2.4678875" layer="29"/>
<rectangle x1="15.029265625" y1="2.4502375" x2="15.382284375" y2="2.4678875" layer="29"/>
<rectangle x1="16.706096875" y1="2.4502375" x2="17.112065625" y2="2.4678875" layer="29"/>
<rectangle x1="18.294671875" y1="2.4502375" x2="19.036009375" y2="2.4678875" layer="29"/>
<rectangle x1="0.25550625" y1="2.467890625" x2="1.4734125" y2="2.485540625" layer="29"/>
<rectangle x1="2.21475" y1="2.467890625" x2="3.5385625" y2="2.485540625" layer="29"/>
<rectangle x1="4.456409375" y1="2.467890625" x2="5.780221875" y2="2.485540625" layer="29"/>
<rectangle x1="6.556859375" y1="2.467890625" x2="7.774765625" y2="2.485540625" layer="29"/>
<rectangle x1="8.46315" y1="2.467890625" x2="9.7869625" y2="2.485540625" layer="29"/>
<rectangle x1="10.704809375" y1="2.467890625" x2="12.028621875" y2="2.485540625" layer="29"/>
<rectangle x1="12.911165625" y1="2.467890625" x2="13.864309375" y2="2.485540625" layer="29"/>
<rectangle x1="15.011615625" y1="2.467890625" x2="15.382284375" y2="2.485540625" layer="29"/>
<rectangle x1="16.706096875" y1="2.467890625" x2="17.129715625" y2="2.485540625" layer="29"/>
<rectangle x1="18.312325" y1="2.467890625" x2="19.03600625" y2="2.485540625" layer="29"/>
<rectangle x1="0.22020625" y1="2.485540625" x2="1.5087125" y2="2.503190625" layer="29"/>
<rectangle x1="2.232403125" y1="2.485540625" x2="3.573865625" y2="2.503190625" layer="29"/>
<rectangle x1="4.43875625" y1="2.485540625" x2="5.78021875" y2="2.503190625" layer="29"/>
<rectangle x1="6.52155625" y1="2.485540625" x2="7.81006875" y2="2.503190625" layer="29"/>
<rectangle x1="8.46315" y1="2.485540625" x2="9.8222625" y2="2.503190625" layer="29"/>
<rectangle x1="10.66950625" y1="2.485540625" x2="12.01096875" y2="2.503190625" layer="29"/>
<rectangle x1="12.911165625" y1="2.485540625" x2="13.881959375" y2="2.503190625" layer="29"/>
<rectangle x1="14.993965625" y1="2.485540625" x2="15.382284375" y2="2.503190625" layer="29"/>
<rectangle x1="16.706096875" y1="2.485540625" x2="17.165015625" y2="2.503190625" layer="29"/>
<rectangle x1="18.312325" y1="2.485540625" x2="19.01835625" y2="2.503190625" layer="29"/>
<rectangle x1="0.202553125" y1="2.503190625" x2="1.544015625" y2="2.520840625" layer="29"/>
<rectangle x1="2.232403125" y1="2.503190625" x2="3.609165625" y2="2.520840625" layer="29"/>
<rectangle x1="4.40345625" y1="2.503190625" x2="5.76256875" y2="2.520840625" layer="29"/>
<rectangle x1="6.50390625" y1="2.503190625" x2="7.82771875" y2="2.520840625" layer="29"/>
<rectangle x1="8.480803125" y1="2.503190625" x2="9.839915625" y2="2.520840625" layer="29"/>
<rectangle x1="10.63420625" y1="2.503190625" x2="12.01096875" y2="2.520840625" layer="29"/>
<rectangle x1="12.928815625" y1="2.503190625" x2="13.917259375" y2="2.520840625" layer="29"/>
<rectangle x1="14.9763125" y1="2.503190625" x2="15.38228125" y2="2.520840625" layer="29"/>
<rectangle x1="16.706096875" y1="2.503190625" x2="17.182665625" y2="2.520840625" layer="29"/>
<rectangle x1="18.312325" y1="2.503190625" x2="19.01835625" y2="2.520840625" layer="29"/>
<rectangle x1="0.184903125" y1="2.52084375" x2="1.561665625" y2="2.53849375" layer="29"/>
<rectangle x1="2.250053125" y1="2.52084375" x2="3.644465625" y2="2.53849375" layer="29"/>
<rectangle x1="4.368153125" y1="2.52084375" x2="5.762571875" y2="2.53849375" layer="29"/>
<rectangle x1="6.46860625" y1="2.52084375" x2="7.86301875" y2="2.53849375" layer="29"/>
<rectangle x1="8.480803125" y1="2.52084375" x2="9.875215625" y2="2.53849375" layer="29"/>
<rectangle x1="10.598903125" y1="2.52084375" x2="11.993321875" y2="2.53849375" layer="29"/>
<rectangle x1="12.928815625" y1="2.52084375" x2="13.934909375" y2="2.53849375" layer="29"/>
<rectangle x1="14.9410125" y1="2.52084375" x2="15.38228125" y2="2.53849375" layer="29"/>
<rectangle x1="16.706096875" y1="2.52084375" x2="17.200321875" y2="2.53849375" layer="29"/>
<rectangle x1="18.329975" y1="2.52084375" x2="19.01835625" y2="2.53849375" layer="29"/>
<rectangle x1="0.167253125" y1="2.53849375" x2="1.579321875" y2="2.55614375" layer="29"/>
<rectangle x1="2.250053125" y1="2.53849375" x2="3.679771875" y2="2.55614375" layer="29"/>
<rectangle x1="4.315203125" y1="2.53849375" x2="5.744921875" y2="2.55614375" layer="29"/>
<rectangle x1="6.450953125" y1="2.53849375" x2="7.880671875" y2="2.55614375" layer="29"/>
<rectangle x1="8.498453125" y1="2.53849375" x2="9.928171875" y2="2.55614375" layer="29"/>
<rectangle x1="10.563603125" y1="2.53849375" x2="11.993321875" y2="2.55614375" layer="29"/>
<rectangle x1="12.946465625" y1="2.53849375" x2="13.952565625" y2="2.55614375" layer="29"/>
<rectangle x1="14.9233625" y1="2.53849375" x2="15.38228125" y2="2.55614375" layer="29"/>
<rectangle x1="16.706096875" y1="2.53849375" x2="17.235621875" y2="2.55614375" layer="29"/>
<rectangle x1="18.329975" y1="2.53849375" x2="19.00070625" y2="2.55614375" layer="29"/>
<rectangle x1="0.149603125" y1="2.55614375" x2="1.596971875" y2="2.57379375" layer="29"/>
<rectangle x1="2.267703125" y1="2.55614375" x2="3.732721875" y2="2.57379375" layer="29"/>
<rectangle x1="4.2799" y1="2.55614375" x2="5.74491875" y2="2.57379375" layer="29"/>
<rectangle x1="6.433303125" y1="2.55614375" x2="7.898321875" y2="2.57379375" layer="29"/>
<rectangle x1="8.498453125" y1="2.55614375" x2="9.963471875" y2="2.57379375" layer="29"/>
<rectangle x1="10.51065" y1="2.55614375" x2="11.97566875" y2="2.57379375" layer="29"/>
<rectangle x1="12.946465625" y1="2.55614375" x2="13.987865625" y2="2.57379375" layer="29"/>
<rectangle x1="14.888059375" y1="2.55614375" x2="15.382284375" y2="2.57379375" layer="29"/>
<rectangle x1="16.706096875" y1="2.55614375" x2="17.270921875" y2="2.57379375" layer="29"/>
<rectangle x1="18.312325" y1="2.55614375" x2="19.00070625" y2="2.57379375" layer="29"/>
<rectangle x1="0.13195" y1="2.57379375" x2="1.61461875" y2="2.59144375" layer="29"/>
<rectangle x1="2.267703125" y1="2.57379375" x2="3.785671875" y2="2.59144375" layer="29"/>
<rectangle x1="4.209296875" y1="2.57379375" x2="5.727265625" y2="2.59144375" layer="29"/>
<rectangle x1="6.415653125" y1="2.57379375" x2="7.898321875" y2="2.59144375" layer="29"/>
<rectangle x1="8.516103125" y1="2.57379375" x2="10.034071875" y2="2.59144375" layer="29"/>
<rectangle x1="10.457696875" y1="2.57379375" x2="11.975665625" y2="2.59144375" layer="29"/>
<rectangle x1="12.964115625" y1="2.57379375" x2="14.023165625" y2="2.59144375" layer="29"/>
<rectangle x1="14.870409375" y1="2.57379375" x2="15.382284375" y2="2.59144375" layer="29"/>
<rectangle x1="16.706096875" y1="2.57379375" x2="17.306221875" y2="2.59144375" layer="29"/>
<rectangle x1="18.277021875" y1="2.57379375" x2="18.983053125" y2="2.59144375" layer="29"/>
<rectangle x1="0.1143" y1="2.591446875" x2="1.63226875" y2="2.609096875" layer="29"/>
<rectangle x1="2.285353125" y1="2.591446875" x2="3.873928125" y2="2.609096875" layer="29"/>
<rectangle x1="4.13869375" y1="2.591446875" x2="5.72726875" y2="2.609096875" layer="29"/>
<rectangle x1="6.415653125" y1="2.591446875" x2="7.915971875" y2="2.609096875" layer="29"/>
<rectangle x1="8.533753125" y1="2.591446875" x2="10.122328125" y2="2.609096875" layer="29"/>
<rectangle x1="10.36944375" y1="2.591446875" x2="11.95801875" y2="2.609096875" layer="29"/>
<rectangle x1="12.964115625" y1="2.591446875" x2="14.058465625" y2="2.609096875" layer="29"/>
<rectangle x1="14.83510625" y1="2.591446875" x2="15.38228125" y2="2.609096875" layer="29"/>
<rectangle x1="16.706096875" y1="2.591446875" x2="17.341528125" y2="2.609096875" layer="29"/>
<rectangle x1="18.22406875" y1="2.591446875" x2="18.98305625" y2="2.609096875" layer="29"/>
<rectangle x1="0.09665" y1="2.609096875" x2="1.63226875" y2="2.626746875" layer="29"/>
<rectangle x1="2.30300625" y1="2.609096875" x2="5.70961875" y2="2.626746875" layer="29"/>
<rectangle x1="6.398003125" y1="2.609096875" x2="7.933621875" y2="2.626746875" layer="29"/>
<rectangle x1="8.533753125" y1="2.609096875" x2="11.940365625" y2="2.626746875" layer="29"/>
<rectangle x1="12.98176875" y1="2.609096875" x2="14.09376875" y2="2.626746875" layer="29"/>
<rectangle x1="14.782153125" y1="2.609096875" x2="15.382284375" y2="2.626746875" layer="29"/>
<rectangle x1="16.706096875" y1="2.609096875" x2="17.394478125" y2="2.626746875" layer="29"/>
<rectangle x1="18.171115625" y1="2.609096875" x2="18.965403125" y2="2.626746875" layer="29"/>
<rectangle x1="0.09665" y1="2.626746875" x2="1.649925" y2="2.644396875" layer="29"/>
<rectangle x1="2.30300625" y1="2.626746875" x2="5.69196875" y2="2.644396875" layer="29"/>
<rectangle x1="6.38035" y1="2.626746875" x2="7.951275" y2="2.644396875" layer="29"/>
<rectangle x1="8.55140625" y1="2.626746875" x2="11.94036875" y2="2.644396875" layer="29"/>
<rectangle x1="12.98176875" y1="2.626746875" x2="14.146725" y2="2.644396875" layer="29"/>
<rectangle x1="14.746853125" y1="2.626746875" x2="15.382284375" y2="2.644396875" layer="29"/>
<rectangle x1="16.706096875" y1="2.626746875" x2="17.465084375" y2="2.644396875" layer="29"/>
<rectangle x1="18.1005125" y1="2.626746875" x2="18.94775" y2="2.644396875" layer="29"/>
<rectangle x1="0.078996875" y1="2.644396875" x2="1.667571875" y2="2.662046875" layer="29"/>
<rectangle x1="2.32065625" y1="2.644396875" x2="5.69196875" y2="2.662046875" layer="29"/>
<rectangle x1="6.38035" y1="2.644396875" x2="7.951275" y2="2.662046875" layer="29"/>
<rectangle x1="8.55140625" y1="2.644396875" x2="11.9227125" y2="2.662046875" layer="29"/>
<rectangle x1="12.99941875" y1="2.644396875" x2="14.199675" y2="2.662046875" layer="29"/>
<rectangle x1="14.67625" y1="2.644396875" x2="17.5356875" y2="2.662046875" layer="29"/>
<rectangle x1="18.029909375" y1="2.644396875" x2="18.947753125" y2="2.662046875" layer="29"/>
<rectangle x1="0.061346875" y1="2.66205" x2="1.667571875" y2="2.6797" layer="29"/>
<rectangle x1="2.33830625" y1="2.66205" x2="5.6743125" y2="2.6797" layer="29"/>
<rectangle x1="6.3627" y1="2.66205" x2="7.968925" y2="2.6797" layer="29"/>
<rectangle x1="8.56905625" y1="2.66205" x2="11.9227125" y2="2.6797" layer="29"/>
<rectangle x1="13.01706875" y1="2.66205" x2="14.30558125" y2="2.6797" layer="29"/>
<rectangle x1="14.57034375" y1="2.66205" x2="17.67689375" y2="2.6797" layer="29"/>
<rectangle x1="17.888703125" y1="2.66205" x2="18.930103125" y2="2.6797" layer="29"/>
<rectangle x1="0.061346875" y1="2.6797" x2="1.685221875" y2="2.69735" layer="29"/>
<rectangle x1="2.33830625" y1="2.6797" x2="5.6566625" y2="2.69735" layer="29"/>
<rectangle x1="6.3627" y1="2.6797" x2="7.968925" y2="2.69735" layer="29"/>
<rectangle x1="8.58670625" y1="2.6797" x2="11.9050625" y2="2.69735" layer="29"/>
<rectangle x1="13.01706875" y1="2.6797" x2="18.9301" y2="2.69735" layer="29"/>
<rectangle x1="0.043696875" y1="2.69735" x2="1.685221875" y2="2.715" layer="29"/>
<rectangle x1="2.35595625" y1="2.69735" x2="5.6566625" y2="2.715" layer="29"/>
<rectangle x1="6.34505" y1="2.69735" x2="7.986575" y2="2.715" layer="29"/>
<rectangle x1="8.58670625" y1="2.69735" x2="11.8874125" y2="2.715" layer="29"/>
<rectangle x1="13.034721875" y1="2.69735" x2="18.912453125" y2="2.715" layer="29"/>
<rectangle x1="0.043696875" y1="2.715003125" x2="1.702871875" y2="2.732653125" layer="29"/>
<rectangle x1="2.373609375" y1="2.715003125" x2="5.639015625" y2="2.732653125" layer="29"/>
<rectangle x1="6.34505" y1="2.715003125" x2="7.986575" y2="2.732653125" layer="29"/>
<rectangle x1="8.60435625" y1="2.715003125" x2="11.8697625" y2="2.732653125" layer="29"/>
<rectangle x1="13.034721875" y1="2.715003125" x2="18.894803125" y2="2.732653125" layer="29"/>
<rectangle x1="0.043696875" y1="2.732653125" x2="1.702871875" y2="2.750303125" layer="29"/>
<rectangle x1="2.373609375" y1="2.732653125" x2="5.621365625" y2="2.750303125" layer="29"/>
<rectangle x1="6.327396875" y1="2.732653125" x2="8.004228125" y2="2.750303125" layer="29"/>
<rectangle x1="8.622009375" y1="2.732653125" x2="11.869765625" y2="2.750303125" layer="29"/>
<rectangle x1="13.052371875" y1="2.732653125" x2="18.894803125" y2="2.750303125" layer="29"/>
<rectangle x1="0.026046875" y1="2.750303125" x2="1.702871875" y2="2.767953125" layer="29"/>
<rectangle x1="2.391259375" y1="2.750303125" x2="5.603709375" y2="2.767953125" layer="29"/>
<rectangle x1="6.327396875" y1="2.750303125" x2="8.004228125" y2="2.767953125" layer="29"/>
<rectangle x1="8.639659375" y1="2.750303125" x2="11.852109375" y2="2.767953125" layer="29"/>
<rectangle x1="13.070021875" y1="2.750303125" x2="18.877146875" y2="2.767953125" layer="29"/>
<rectangle x1="0.026046875" y1="2.767953125" x2="1.720528125" y2="2.785603125" layer="29"/>
<rectangle x1="2.408909375" y1="2.767953125" x2="5.603709375" y2="2.785603125" layer="29"/>
<rectangle x1="6.327396875" y1="2.767953125" x2="8.004228125" y2="2.785603125" layer="29"/>
<rectangle x1="8.639659375" y1="2.767953125" x2="11.834459375" y2="2.785603125" layer="29"/>
<rectangle x1="13.087671875" y1="2.767953125" x2="18.859496875" y2="2.785603125" layer="29"/>
<rectangle x1="0.026046875" y1="2.78560625" x2="1.720528125" y2="2.80325625" layer="29"/>
<rectangle x1="2.4265625" y1="2.78560625" x2="5.5860625" y2="2.80325625" layer="29"/>
<rectangle x1="6.309746875" y1="2.78560625" x2="8.021878125" y2="2.80325625" layer="29"/>
<rectangle x1="8.657309375" y1="2.78560625" x2="11.816809375" y2="2.80325625" layer="29"/>
<rectangle x1="13.087671875" y1="2.78560625" x2="18.859496875" y2="2.80325625" layer="29"/>
<rectangle x1="0.00839375" y1="2.80325625" x2="1.720525" y2="2.82090625" layer="29"/>
<rectangle x1="2.4442125" y1="2.80325625" x2="5.5684125" y2="2.82090625" layer="29"/>
<rectangle x1="6.309746875" y1="2.80325625" x2="8.021878125" y2="2.82090625" layer="29"/>
<rectangle x1="8.6749625" y1="2.80325625" x2="11.8168125" y2="2.82090625" layer="29"/>
<rectangle x1="13.105325" y1="2.80325625" x2="18.84185" y2="2.82090625" layer="29"/>
<rectangle x1="0.00839375" y1="2.82090625" x2="1.720525" y2="2.83855625" layer="29"/>
<rectangle x1="2.4442125" y1="2.82090625" x2="5.5507625" y2="2.83855625" layer="29"/>
<rectangle x1="6.309746875" y1="2.82090625" x2="8.021878125" y2="2.83855625" layer="29"/>
<rectangle x1="8.6926125" y1="2.82090625" x2="11.7991625" y2="2.83855625" layer="29"/>
<rectangle x1="13.122975" y1="2.82090625" x2="18.82419375" y2="2.83855625" layer="29"/>
<rectangle x1="0.00839375" y1="2.83855625" x2="1.720525" y2="2.85620625" layer="29"/>
<rectangle x1="2.4618625" y1="2.83855625" x2="5.53310625" y2="2.85620625" layer="29"/>
<rectangle x1="6.309746875" y1="2.83855625" x2="8.021878125" y2="2.85620625" layer="29"/>
<rectangle x1="8.7102625" y1="2.83855625" x2="11.78150625" y2="2.85620625" layer="29"/>
<rectangle x1="13.122975" y1="2.83855625" x2="18.80654375" y2="2.85620625" layer="29"/>
<rectangle x1="0.00839375" y1="2.856209375" x2="1.738175" y2="2.873859375" layer="29"/>
<rectangle x1="2.4795125" y1="2.856209375" x2="5.53310625" y2="2.873859375" layer="29"/>
<rectangle x1="6.309746875" y1="2.856209375" x2="8.021878125" y2="2.873859375" layer="29"/>
<rectangle x1="8.7279125" y1="2.856209375" x2="11.76385625" y2="2.873859375" layer="29"/>
<rectangle x1="13.140625" y1="2.856209375" x2="18.80654375" y2="2.873859375" layer="29"/>
<rectangle x1="0.00839375" y1="2.873859375" x2="1.738175" y2="2.891509375" layer="29"/>
<rectangle x1="2.497165625" y1="2.873859375" x2="5.515459375" y2="2.891509375" layer="29"/>
<rectangle x1="6.292096875" y1="2.873859375" x2="8.021878125" y2="2.891509375" layer="29"/>
<rectangle x1="8.7279125" y1="2.873859375" x2="11.74620625" y2="2.891509375" layer="29"/>
<rectangle x1="13.158275" y1="2.873859375" x2="18.78889375" y2="2.891509375" layer="29"/>
<rectangle x1="0.00839375" y1="2.891509375" x2="1.738175" y2="2.909159375" layer="29"/>
<rectangle x1="2.514815625" y1="2.891509375" x2="5.497809375" y2="2.909159375" layer="29"/>
<rectangle x1="6.292096875" y1="2.891509375" x2="8.021878125" y2="2.909159375" layer="29"/>
<rectangle x1="8.745565625" y1="2.891509375" x2="11.728553125" y2="2.909159375" layer="29"/>
<rectangle x1="13.175928125" y1="2.891509375" x2="18.771246875" y2="2.909159375" layer="29"/>
<rectangle x1="0.00839375" y1="2.9091625" x2="1.738175" y2="2.9268125" layer="29"/>
<rectangle x1="2.532465625" y1="2.9091625" x2="5.480153125" y2="2.9268125" layer="29"/>
<rectangle x1="6.292096875" y1="2.9091625" x2="8.039528125" y2="2.9268125" layer="29"/>
<rectangle x1="8.763215625" y1="2.9091625" x2="11.710903125" y2="2.9268125" layer="29"/>
<rectangle x1="13.193578125" y1="2.9091625" x2="18.753590625" y2="2.9268125" layer="29"/>
<rectangle x1="0.00839375" y1="2.9268125" x2="1.738175" y2="2.9444625" layer="29"/>
<rectangle x1="2.550115625" y1="2.9268125" x2="5.462503125" y2="2.9444625" layer="29"/>
<rectangle x1="6.292096875" y1="2.9268125" x2="8.039528125" y2="2.9444625" layer="29"/>
<rectangle x1="8.780865625" y1="2.9268125" x2="11.693253125" y2="2.9444625" layer="29"/>
<rectangle x1="13.211228125" y1="2.9268125" x2="18.735940625" y2="2.9444625" layer="29"/>
<rectangle x1="0.00839375" y1="2.9444625" x2="1.738175" y2="2.9621125" layer="29"/>
<rectangle x1="2.56776875" y1="2.9444625" x2="5.44485625" y2="2.9621125" layer="29"/>
<rectangle x1="6.292096875" y1="2.9444625" x2="8.039528125" y2="2.9621125" layer="29"/>
<rectangle x1="8.798515625" y1="2.9444625" x2="11.675603125" y2="2.9621125" layer="29"/>
<rectangle x1="13.211228125" y1="2.9444625" x2="18.718290625" y2="2.9621125" layer="29"/>
<rectangle x1="0.00839375" y1="2.9621125" x2="1.738175" y2="2.9797625" layer="29"/>
<rectangle x1="2.58541875" y1="2.9621125" x2="5.42720625" y2="2.9797625" layer="29"/>
<rectangle x1="6.292096875" y1="2.9621125" x2="8.039528125" y2="2.9797625" layer="29"/>
<rectangle x1="8.81616875" y1="2.9621125" x2="11.65795" y2="2.9797625" layer="29"/>
<rectangle x1="13.228878125" y1="2.9621125" x2="18.718290625" y2="2.9797625" layer="29"/>
<rectangle x1="0.00839375" y1="2.979765625" x2="1.738175" y2="2.997415625" layer="29"/>
<rectangle x1="2.60306875" y1="2.979765625" x2="5.40955" y2="2.997415625" layer="29"/>
<rectangle x1="6.292096875" y1="2.979765625" x2="8.039528125" y2="2.997415625" layer="29"/>
<rectangle x1="8.83381875" y1="2.979765625" x2="11.6403" y2="2.997415625" layer="29"/>
<rectangle x1="13.24653125" y1="2.979765625" x2="18.70064375" y2="2.997415625" layer="29"/>
<rectangle x1="0.00839375" y1="2.997415625" x2="1.738175" y2="3.015065625" layer="29"/>
<rectangle x1="2.620721875" y1="2.997415625" x2="5.391903125" y2="3.015065625" layer="29"/>
<rectangle x1="6.292096875" y1="2.997415625" x2="8.021878125" y2="3.015065625" layer="29"/>
<rectangle x1="8.85146875" y1="2.997415625" x2="11.62265" y2="3.015065625" layer="29"/>
<rectangle x1="13.26418125" y1="2.997415625" x2="18.6829875" y2="3.015065625" layer="29"/>
<rectangle x1="0.00839375" y1="3.015065625" x2="1.738175" y2="3.032715625" layer="29"/>
<rectangle x1="2.638371875" y1="3.015065625" x2="5.374253125" y2="3.032715625" layer="29"/>
<rectangle x1="6.292096875" y1="3.015065625" x2="8.021878125" y2="3.032715625" layer="29"/>
<rectangle x1="8.886771875" y1="3.015065625" x2="11.605003125" y2="3.032715625" layer="29"/>
<rectangle x1="13.28183125" y1="3.015065625" x2="18.6653375" y2="3.032715625" layer="29"/>
<rectangle x1="0.00839375" y1="3.032715625" x2="1.738175" y2="3.050365625" layer="29"/>
<rectangle x1="2.656021875" y1="3.032715625" x2="5.356603125" y2="3.050365625" layer="29"/>
<rectangle x1="6.309746875" y1="3.032715625" x2="8.021878125" y2="3.050365625" layer="29"/>
<rectangle x1="8.904421875" y1="3.032715625" x2="11.587346875" y2="3.050365625" layer="29"/>
<rectangle x1="13.299484375" y1="3.032715625" x2="18.647690625" y2="3.050365625" layer="29"/>
<rectangle x1="0.00839375" y1="3.05036875" x2="1.720525" y2="3.06801875" layer="29"/>
<rectangle x1="2.673671875" y1="3.05036875" x2="5.321296875" y2="3.06801875" layer="29"/>
<rectangle x1="6.309746875" y1="3.05036875" x2="8.021878125" y2="3.06801875" layer="29"/>
<rectangle x1="8.922071875" y1="3.05036875" x2="11.569696875" y2="3.06801875" layer="29"/>
<rectangle x1="13.317134375" y1="3.05036875" x2="18.612384375" y2="3.06801875" layer="29"/>
<rectangle x1="0.00839375" y1="3.06801875" x2="1.720525" y2="3.08566875" layer="29"/>
<rectangle x1="2.708975" y1="3.06801875" x2="5.30365" y2="3.08566875" layer="29"/>
<rectangle x1="6.309746875" y1="3.06801875" x2="8.021878125" y2="3.08566875" layer="29"/>
<rectangle x1="8.939725" y1="3.06801875" x2="11.55205" y2="3.08566875" layer="29"/>
<rectangle x1="13.334784375" y1="3.06801875" x2="18.594734375" y2="3.08566875" layer="29"/>
<rectangle x1="0.026046875" y1="3.08566875" x2="1.720528125" y2="3.10331875" layer="29"/>
<rectangle x1="2.726625" y1="3.08566875" x2="5.28599375" y2="3.10331875" layer="29"/>
<rectangle x1="6.309746875" y1="3.08566875" x2="8.021878125" y2="3.10331875" layer="29"/>
<rectangle x1="8.957375" y1="3.08566875" x2="11.51674375" y2="3.10331875" layer="29"/>
<rectangle x1="13.3700875" y1="3.08566875" x2="18.5770875" y2="3.10331875" layer="29"/>
<rectangle x1="0.026046875" y1="3.103321875" x2="1.720528125" y2="3.120971875" layer="29"/>
<rectangle x1="2.744275" y1="3.103321875" x2="5.26834375" y2="3.120971875" layer="29"/>
<rectangle x1="6.309746875" y1="3.103321875" x2="8.004228125" y2="3.120971875" layer="29"/>
<rectangle x1="8.992675" y1="3.103321875" x2="11.49909375" y2="3.120971875" layer="29"/>
<rectangle x1="13.3877375" y1="3.103321875" x2="18.55943125" y2="3.120971875" layer="29"/>
<rectangle x1="0.026046875" y1="3.120971875" x2="1.720528125" y2="3.138621875" layer="29"/>
<rectangle x1="2.761928125" y1="3.120971875" x2="5.233046875" y2="3.138621875" layer="29"/>
<rectangle x1="6.327396875" y1="3.120971875" x2="8.004228125" y2="3.138621875" layer="29"/>
<rectangle x1="9.010328125" y1="3.120971875" x2="11.481446875" y2="3.138621875" layer="29"/>
<rectangle x1="13.4053875" y1="3.120971875" x2="18.54178125" y2="3.138621875" layer="29"/>
<rectangle x1="0.026046875" y1="3.138621875" x2="1.702871875" y2="3.156271875" layer="29"/>
<rectangle x1="2.797228125" y1="3.138621875" x2="5.215390625" y2="3.156271875" layer="29"/>
<rectangle x1="6.327396875" y1="3.138621875" x2="8.004228125" y2="3.156271875" layer="29"/>
<rectangle x1="9.027978125" y1="3.138621875" x2="11.446140625" y2="3.156271875" layer="29"/>
<rectangle x1="13.4230375" y1="3.138621875" x2="18.52413125" y2="3.156271875" layer="29"/>
<rectangle x1="0.043696875" y1="3.156271875" x2="1.702871875" y2="3.173921875" layer="29"/>
<rectangle x1="2.814878125" y1="3.156271875" x2="5.180090625" y2="3.173921875" layer="29"/>
<rectangle x1="6.327396875" y1="3.156271875" x2="8.004228125" y2="3.173921875" layer="29"/>
<rectangle x1="9.063278125" y1="3.156271875" x2="11.428490625" y2="3.173921875" layer="29"/>
<rectangle x1="13.458340625" y1="3.156271875" x2="18.488828125" y2="3.173921875" layer="29"/>
<rectangle x1="0.043696875" y1="3.173925" x2="1.685221875" y2="3.191575" layer="29"/>
<rectangle x1="2.85018125" y1="3.173925" x2="5.16244375" y2="3.191575" layer="29"/>
<rectangle x1="6.34505" y1="3.173925" x2="7.986575" y2="3.191575" layer="29"/>
<rectangle x1="9.08093125" y1="3.173925" x2="11.3931875" y2="3.191575" layer="29"/>
<rectangle x1="13.475990625" y1="3.173925" x2="18.471178125" y2="3.191575" layer="29"/>
<rectangle x1="0.061346875" y1="3.191575" x2="1.685221875" y2="3.209225" layer="29"/>
<rectangle x1="2.86783125" y1="3.191575" x2="5.1271375" y2="3.209225" layer="29"/>
<rectangle x1="6.34505" y1="3.191575" x2="7.986575" y2="3.209225" layer="29"/>
<rectangle x1="9.11623125" y1="3.191575" x2="11.3755375" y2="3.209225" layer="29"/>
<rectangle x1="13.49364375" y1="3.191575" x2="18.45353125" y2="3.209225" layer="29"/>
<rectangle x1="0.061346875" y1="3.209225" x2="1.685221875" y2="3.226875" layer="29"/>
<rectangle x1="2.903134375" y1="3.209225" x2="5.109490625" y2="3.226875" layer="29"/>
<rectangle x1="6.3627" y1="3.209225" x2="7.968925" y2="3.226875" layer="29"/>
<rectangle x1="9.133884375" y1="3.209225" x2="11.340234375" y2="3.226875" layer="29"/>
<rectangle x1="13.52894375" y1="3.209225" x2="18.418225" y2="3.226875" layer="29"/>
<rectangle x1="0.078996875" y1="3.226875" x2="1.667571875" y2="3.244525" layer="29"/>
<rectangle x1="2.920784375" y1="3.226875" x2="5.074184375" y2="3.244525" layer="29"/>
<rectangle x1="6.3627" y1="3.226875" x2="7.968925" y2="3.244525" layer="29"/>
<rectangle x1="9.169184375" y1="3.226875" x2="11.322584375" y2="3.244525" layer="29"/>
<rectangle x1="13.54659375" y1="3.226875" x2="18.400575" y2="3.244525" layer="29"/>
<rectangle x1="0.078996875" y1="3.244528125" x2="1.649921875" y2="3.262178125" layer="29"/>
<rectangle x1="2.9560875" y1="3.244528125" x2="5.0565375" y2="3.262178125" layer="29"/>
<rectangle x1="6.38035" y1="3.244528125" x2="7.951275" y2="3.262178125" layer="29"/>
<rectangle x1="9.2044875" y1="3.244528125" x2="11.2872875" y2="3.262178125" layer="29"/>
<rectangle x1="13.581896875" y1="3.244528125" x2="18.365271875" y2="3.262178125" layer="29"/>
<rectangle x1="0.09665" y1="3.262178125" x2="1.649925" y2="3.279828125" layer="29"/>
<rectangle x1="2.9913875" y1="3.262178125" x2="5.02123125" y2="3.279828125" layer="29"/>
<rectangle x1="6.38035" y1="3.262178125" x2="7.951275" y2="3.279828125" layer="29"/>
<rectangle x1="9.2221375" y1="3.262178125" x2="11.25198125" y2="3.279828125" layer="29"/>
<rectangle x1="13.599546875" y1="3.262178125" x2="18.347621875" y2="3.279828125" layer="29"/>
<rectangle x1="0.09665" y1="3.279828125" x2="1.63226875" y2="3.297478125" layer="29"/>
<rectangle x1="3.026690625" y1="3.279828125" x2="4.985934375" y2="3.297478125" layer="29"/>
<rectangle x1="6.398003125" y1="3.279828125" x2="7.933621875" y2="3.297478125" layer="29"/>
<rectangle x1="9.2574375" y1="3.279828125" x2="11.21668125" y2="3.297478125" layer="29"/>
<rectangle x1="13.63485" y1="3.279828125" x2="18.312325" y2="3.297478125" layer="29"/>
<rectangle x1="0.1143" y1="3.297478125" x2="1.61461875" y2="3.315128125" layer="29"/>
<rectangle x1="3.061990625" y1="3.297478125" x2="4.950628125" y2="3.315128125" layer="29"/>
<rectangle x1="6.415653125" y1="3.297478125" x2="7.915971875" y2="3.315128125" layer="29"/>
<rectangle x1="9.292740625" y1="3.297478125" x2="11.199028125" y2="3.315128125" layer="29"/>
<rectangle x1="13.67015" y1="3.297478125" x2="18.27701875" y2="3.315128125" layer="29"/>
<rectangle x1="0.13195" y1="3.31513125" x2="1.61461875" y2="3.33278125" layer="29"/>
<rectangle x1="3.09729375" y1="3.31513125" x2="4.91533125" y2="3.33278125" layer="29"/>
<rectangle x1="6.433303125" y1="3.31513125" x2="7.898321875" y2="3.33278125" layer="29"/>
<rectangle x1="9.32804375" y1="3.31513125" x2="11.146075" y2="3.33278125" layer="29"/>
<rectangle x1="13.705453125" y1="3.31513125" x2="18.241721875" y2="3.33278125" layer="29"/>
<rectangle x1="0.149603125" y1="3.33278125" x2="1.596971875" y2="3.35043125" layer="29"/>
<rectangle x1="3.13259375" y1="3.33278125" x2="4.880025" y2="3.35043125" layer="29"/>
<rectangle x1="6.433303125" y1="3.33278125" x2="7.880671875" y2="3.35043125" layer="29"/>
<rectangle x1="9.36334375" y1="3.33278125" x2="11.110775" y2="3.35043125" layer="29"/>
<rectangle x1="13.740753125" y1="3.33278125" x2="18.206415625" y2="3.35043125" layer="29"/>
<rectangle x1="0.167253125" y1="3.35043125" x2="1.579321875" y2="3.36808125" layer="29"/>
<rectangle x1="3.167896875" y1="3.35043125" x2="4.844728125" y2="3.36808125" layer="29"/>
<rectangle x1="6.450953125" y1="3.35043125" x2="7.863021875" y2="3.36808125" layer="29"/>
<rectangle x1="9.416296875" y1="3.35043125" x2="11.075471875" y2="3.36808125" layer="29"/>
<rectangle x1="13.77605625" y1="3.35043125" x2="18.1711125" y2="3.36808125" layer="29"/>
<rectangle x1="0.184903125" y1="3.368084375" x2="1.561665625" y2="3.385734375" layer="29"/>
<rectangle x1="3.203196875" y1="3.368084375" x2="4.791771875" y2="3.385734375" layer="29"/>
<rectangle x1="6.48625625" y1="3.368084375" x2="7.84536875" y2="3.385734375" layer="29"/>
<rectangle x1="9.451596875" y1="3.368084375" x2="11.040171875" y2="3.385734375" layer="29"/>
<rectangle x1="13.81135625" y1="3.368084375" x2="18.1358125" y2="3.385734375" layer="29"/>
<rectangle x1="0.202553125" y1="3.385734375" x2="1.526365625" y2="3.403384375" layer="29"/>
<rectangle x1="3.25615" y1="3.385734375" x2="4.75646875" y2="3.403384375" layer="29"/>
<rectangle x1="6.50390625" y1="3.385734375" x2="7.82771875" y2="3.403384375" layer="29"/>
<rectangle x1="9.50455" y1="3.385734375" x2="10.98721875" y2="3.403384375" layer="29"/>
<rectangle x1="13.846659375" y1="3.385734375" x2="18.100509375" y2="3.403384375" layer="29"/>
<rectangle x1="0.23785625" y1="3.403384375" x2="1.5087125" y2="3.421034375" layer="29"/>
<rectangle x1="3.309103125" y1="3.403384375" x2="4.703521875" y2="3.421034375" layer="29"/>
<rectangle x1="6.52155625" y1="3.403384375" x2="7.79241875" y2="3.421034375" layer="29"/>
<rectangle x1="9.539853125" y1="3.403384375" x2="10.934265625" y2="3.421034375" layer="29"/>
<rectangle x1="13.8996125" y1="3.403384375" x2="18.0475625" y2="3.421034375" layer="29"/>
<rectangle x1="0.27315625" y1="3.421034375" x2="1.4734125" y2="3.438684375" layer="29"/>
<rectangle x1="3.36205625" y1="3.421034375" x2="4.65056875" y2="3.438684375" layer="29"/>
<rectangle x1="6.556859375" y1="3.421034375" x2="7.774765625" y2="3.438684375" layer="29"/>
<rectangle x1="9.59280625" y1="3.421034375" x2="10.8813125" y2="3.438684375" layer="29"/>
<rectangle x1="13.9349125" y1="3.421034375" x2="17.99460625" y2="3.438684375" layer="29"/>
<rectangle x1="0.308459375" y1="3.4386875" x2="1.438109375" y2="3.4563375" layer="29"/>
<rectangle x1="3.415009375" y1="3.4386875" x2="4.579965625" y2="3.4563375" layer="29"/>
<rectangle x1="6.5921625" y1="3.4386875" x2="7.7218125" y2="3.4563375" layer="29"/>
<rectangle x1="9.663409375" y1="3.4386875" x2="10.828365625" y2="3.4563375" layer="29"/>
<rectangle x1="13.987865625" y1="3.4386875" x2="17.941653125" y2="3.4563375" layer="29"/>
<rectangle x1="0.3614125" y1="3.4563375" x2="1.36750625" y2="3.4739875" layer="29"/>
<rectangle x1="3.4856125" y1="3.4563375" x2="4.5270125" y2="3.4739875" layer="29"/>
<rectangle x1="6.662765625" y1="3.4563375" x2="7.668859375" y2="3.4739875" layer="29"/>
<rectangle x1="9.7163625" y1="3.4563375" x2="10.7577625" y2="3.4739875" layer="29"/>
<rectangle x1="14.05846875" y1="3.4563375" x2="17.8887" y2="3.4739875" layer="29"/>
<rectangle x1="3.556215625" y1="3.4739875" x2="4.438753125" y2="3.4916375" layer="29"/>
<rectangle x1="9.804615625" y1="3.4739875" x2="10.687153125" y2="3.4916375" layer="29"/>
<rectangle x1="14.129071875" y1="3.4739875" x2="17.818096875" y2="3.4916375" layer="29"/>
<rectangle x1="3.662121875" y1="3.4916375" x2="4.350503125" y2="3.5092875" layer="29"/>
<rectangle x1="9.89286875" y1="3.4916375" x2="10.58125" y2="3.5092875" layer="29"/>
<rectangle x1="14.217328125" y1="3.4916375" x2="17.729846875" y2="3.5092875" layer="29"/>
<rectangle x1="3.803328125" y1="3.509290625" x2="4.209296875" y2="3.526940625" layer="29"/>
<rectangle x1="10.034075" y1="3.509290625" x2="10.44004375" y2="3.526940625" layer="29"/>
<rectangle x1="14.340884375" y1="3.509290625" x2="17.606290625" y2="3.526940625" layer="29"/>
</package>
<package name="FOUR_LAYER_WARNING">
<text x="0" y="0" size="1.27" layer="51">THIS IS A FOUR-LAYER BOARD!</text>
</package>
<package name="SFE_LOGO_NAME_FLAME_.5">
<polygon width="0" layer="21">
<vertex x="2.68" y="6.81"/>
<vertex x="2.71" y="6.52"/>
<vertex x="2.81" y="6.28"/>
<vertex x="2.95" y="6.07"/>
<vertex x="3.14" y="5.91"/>
<vertex x="3.37" y="5.78"/>
<vertex x="3.62" y="5.69"/>
<vertex x="3.89" y="5.64"/>
<vertex x="4.17" y="5.62"/>
<vertex x="4.38" y="5.63"/>
<vertex x="4.6" y="5.67"/>
<vertex x="4.81" y="5.73"/>
<vertex x="5.01" y="5.82"/>
<vertex x="5.19" y="5.94"/>
<vertex x="5.32" y="6.1"/>
<vertex x="5.41" y="6.29"/>
<vertex x="5.44" y="6.53"/>
<vertex x="5.41" y="6.73"/>
<vertex x="5.29" y="6.9"/>
<vertex x="5.11" y="7.06"/>
<vertex x="4.86" y="7.19"/>
<vertex x="4.55" y="7.3"/>
<vertex x="4.17" y="7.41"/>
<vertex x="3.73" y="7.51"/>
<vertex x="3.24" y="7.62"/>
<vertex x="2.82" y="7.72"/>
<vertex x="2.41" y="7.85"/>
<vertex x="2.03" y="8"/>
<vertex x="1.7" y="8.19"/>
<vertex x="1.41" y="8.43"/>
<vertex x="1.19" y="8.72"/>
<vertex x="1.05" y="9.08"/>
<vertex x="1" y="9.51"/>
<vertex x="1.07" y="10.12"/>
<vertex x="1.27" y="10.62"/>
<vertex x="1.57" y="11.02"/>
<vertex x="1.97" y="11.32"/>
<vertex x="2.43" y="11.54"/>
<vertex x="2.95" y="11.68"/>
<vertex x="3.51" y="11.75"/>
<vertex x="4.08" y="11.78"/>
<vertex x="4.64" y="11.75"/>
<vertex x="5.19" y="11.67"/>
<vertex x="5.7" y="11.52"/>
<vertex x="6.15" y="11.3"/>
<vertex x="6.54" y="11"/>
<vertex x="6.86" y="10.61"/>
<vertex x="7.08" y="10.12"/>
<vertex x="7.19" y="9.52"/>
<vertex x="6.96" y="9.52"/>
<vertex x="6.73" y="9.52"/>
<vertex x="6.5" y="9.52"/>
<vertex x="6.27" y="9.52"/>
<vertex x="6.04" y="9.52"/>
<vertex x="5.81" y="9.52"/>
<vertex x="5.58" y="9.52"/>
<vertex x="5.35" y="9.52"/>
<vertex x="5.3" y="9.78"/>
<vertex x="5.22" y="9.99"/>
<vertex x="5.09" y="10.16"/>
<vertex x="4.93" y="10.28"/>
<vertex x="4.73" y="10.37"/>
<vertex x="4.52" y="10.44"/>
<vertex x="4.28" y="10.47"/>
<vertex x="4.02" y="10.48"/>
<vertex x="3.85" y="10.48"/>
<vertex x="3.67" y="10.46"/>
<vertex x="3.49" y="10.43"/>
<vertex x="3.32" y="10.37"/>
<vertex x="3.17" y="10.29"/>
<vertex x="3.05" y="10.17"/>
<vertex x="2.97" y="10.02"/>
<vertex x="2.94" y="9.82"/>
<vertex x="2.99" y="9.59"/>
<vertex x="3.13" y="9.4"/>
<vertex x="3.35" y="9.25"/>
<vertex x="3.63" y="9.13"/>
<vertex x="3.97" y="9.03"/>
<vertex x="4.34" y="8.95"/>
<vertex x="4.73" y="8.86"/>
<vertex x="5.14" y="8.77"/>
<vertex x="5.56" y="8.66"/>
<vertex x="5.97" y="8.53"/>
<vertex x="6.35" y="8.37"/>
<vertex x="6.69" y="8.17"/>
<vertex x="6.97" y="7.92"/>
<vertex x="7.19" y="7.61"/>
<vertex x="7.33" y="7.24"/>
<vertex x="7.38" y="6.79"/>
<vertex x="7.31" y="6.15"/>
<vertex x="7.11" y="5.62"/>
<vertex x="6.79" y="5.19"/>
<vertex x="6.37" y="4.86"/>
<vertex x="5.88" y="4.61"/>
<vertex x="5.34" y="4.45"/>
<vertex x="4.75" y="4.36"/>
<vertex x="4.16" y="4.33"/>
<vertex x="3.55" y="4.36"/>
<vertex x="2.96" y="4.45"/>
<vertex x="2.4" y="4.62"/>
<vertex x="1.91" y="4.87"/>
<vertex x="1.48" y="5.2"/>
<vertex x="1.15" y="5.64"/>
<vertex x="0.93" y="6.17"/>
<vertex x="0.84" y="6.82"/>
<vertex x="1.07" y="6.82"/>
<vertex x="1.3" y="6.82"/>
<vertex x="1.53" y="6.82"/>
<vertex x="1.76" y="6.82"/>
<vertex x="1.99" y="6.82"/>
<vertex x="2.22" y="6.82"/>
<vertex x="2.45" y="6.82"/>
</polygon>
<vertex x="13.22" y="6.82"/>
<vertex x="13.33" y="7.2"/>
<vertex x="13.39" y="7.61"/>
<vertex x="13.41" y="8.03"/>
<vertex x="15.35" y="7.98"/>
<vertex x="15.31" y="7.28"/>
<vertex x="15.16" y="6.61"/>
<vertex x="14.92" y="5.99"/>
</polygon>
<vertex x="14.58" y="5.44"/>
<vertex x="14.15" y="4.98"/>
<vertex x="13.61" y="4.63"/>
<vertex x="12.98" y="4.41"/>
<vertex x="12.25" y="4.33"/>
<vertex x="11.93" y="4.34"/>
<vertex x="11.62" y="4.4"/>
<vertex x="11.33" y="4.48"/>
<vertex x="11.05" y="4.6"/>
<vertex x="10.78" y="4.75"/>
<vertex x="10.54" y="4.93"/>
<vertex x="10.32" y="5.15"/>
<vertex x="10.13" y="5.39"/>
<vertex x="10.12" y="5.39"/>
<vertex x="10.12" y="4.76"/>
<vertex x="10.12" y="4.12"/>
<vertex x="10.12" y="3.48"/>
<vertex x="10.12" y="2.85"/>
<vertex x="10.12" y="2.21"/>
<vertex x="10.12" y="1.58"/>
<vertex x="10.12" y="0.94"/>
<vertex x="10.12" y="0.3"/>
<vertex x="9.88" y="0.52"/>
<vertex x="9.63" y="0.73"/>
<vertex x="9.39" y="0.95"/>
<vertex x="9.15" y="1.17"/>
<vertex x="8.91" y="1.38"/>
<vertex x="8.66" y="1.6"/>
<vertex x="8.42" y="1.81"/>
<vertex x="8.18" y="2.03"/>
<vertex x="8.18" y="3.18"/>
<vertex x="8.18" y="4.34"/>
<vertex x="8.18" y="5.49"/>
<vertex x="8.18" y="6.64"/>
<vertex x="8.18" y="7.8"/>
<vertex x="8.18" y="8.95"/>
<vertex x="8.18" y="10.11"/>
<vertex x="8.18" y="11.26"/>
<vertex x="8.41" y="11.3"/>
<vertex x="8.64" y="11.34"/>
<vertex x="8.87" y="11.38"/>
<vertex x="9.1" y="11.42"/>
<vertex x="9.33" y="11.46"/>
<vertex x="9.56" y="11.51"/>
<vertex x="9.79" y="11.55"/>
<vertex x="10.02" y="11.59"/>
<vertex x="10.02" y="11.47"/>
<vertex x="10.02" y="11.36"/>
<vertex x="10.02" y="11.25"/>
<vertex x="10.02" y="11.14"/>
<vertex x="10.02" y="11.02"/>
<vertex x="10.02" y="10.91"/>
<vertex x="10.02" y="10.8"/>
<vertex x="10.02" y="10.69"/>
<vertex x="10.03" y="10.69"/>
<vertex x="10.04" y="10.69"/>
<vertex x="10.23" y="10.95"/>
<vertex x="10.44" y="11.18"/>
<vertex x="10.68" y="11.37"/>
<vertex x="10.94" y="11.52"/>
<vertex x="11.22" y="11.63"/>
<vertex x="11.51" y="11.72"/>
<vertex x="11.82" y="11.76"/>
<vertex x="12.14" y="11.78"/>
<vertex x="12.92" y="11.7"/>
<vertex x="13.58" y="11.47"/>
<vertex x="14.13" y="11.11"/>
<vertex x="14.58" y="10.63"/>
<vertex x="14.92" y="10.06"/>
<vertex x="15.16" y="9.42"/>
<vertex x="15.31" y="8.72"/>
<vertex x="15.36" y="7.98"/>
<vertex x="13.39" y="8.46"/>
<vertex x="13.32" y="8.87"/>
<vertex x="13.2" y="9.25"/>
<vertex x="13.03" y="9.6"/>
<vertex x="12.8" y="9.89"/>
<vertex x="12.51" y="10.12"/>
<vertex x="12.15" y="10.26"/>
<vertex x="11.72" y="10.31"/>
<vertex x="11.28" y="10.26"/>
<vertex x="10.92" y="10.12"/>
<vertex x="10.63" y="9.9"/>
<vertex x="10.4" y="9.6"/>
<vertex x="10.23" y="9.26"/>
<vertex x="10.12" y="8.87"/>
<vertex x="10.05" y="8.46"/>
<vertex x="10.04" y="8.03"/>
<vertex x="10.06" y="7.61"/>
<vertex x="10.12" y="7.2"/>
<vertex x="10.24" y="6.82"/>
<vertex x="10.41" y="6.48"/>
<vertex x="10.64" y="6.2"/>
<vertex x="10.94" y="5.98"/>
<vertex x="11.3" y="5.84"/>
<vertex x="11.73" y="5.79"/>
<vertex x="12.17" y="5.84"/>
<vertex x="12.53" y="5.98"/>
<vertex x="12.82" y="6.2"/>
<vertex x="13.05" y="6.48"/>
</polygon>
<vertex x="18.31" y="8.57"/>
<vertex x="18.75" y="8.63"/>
<vertex x="19.17" y="8.68"/>
<vertex x="19.57" y="8.73"/>
<vertex x="19.8" y="7.69"/>
<vertex x="19.69" y="7.67"/>
<vertex x="19.58" y="7.65"/>
<vertex x="19.46" y="7.63"/>
<vertex x="19.35" y="7.62"/>
<vertex x="19.23" y="7.6"/>
<vertex x="19.12" y="7.58"/>
<vertex x="19" y="7.56"/>
<vertex x="18.89" y="7.54"/>
<vertex x="18.78" y="7.52"/>
<vertex x="18.67" y="7.49"/>
</polygon>
<vertex x="18.57" y="7.45"/>
<vertex x="18.47" y="7.42"/>
<vertex x="18.37" y="7.37"/>
<vertex x="18.28" y="7.32"/>
<vertex x="18.2" y="7.27"/>
<vertex x="18.13" y="7.2"/>
<vertex x="18.06" y="7.13"/>
<vertex x="18" y="7.06"/>
<vertex x="17.95" y="6.97"/>
<vertex x="17.91" y="6.87"/>
<vertex x="17.88" y="6.77"/>
<vertex x="17.86" y="6.65"/>
<vertex x="17.85" y="6.52"/>
<vertex x="17.86" y="6.39"/>
<vertex x="17.88" y="6.28"/>
<vertex x="17.91" y="6.17"/>
<vertex x="17.95" y="6.08"/>
<vertex x="18" y="6"/>
<vertex x="18.06" y="5.92"/>
<vertex x="18.13" y="5.86"/>
<vertex x="18.21" y="5.8"/>
<vertex x="18.3" y="5.76"/>
<vertex x="18.39" y="5.72"/>
<vertex x="18.49" y="5.68"/>
<vertex x="18.59" y="5.66"/>
<vertex x="18.7" y="5.64"/>
<vertex x="18.81" y="5.63"/>
<vertex x="18.93" y="5.62"/>
<vertex x="19.04" y="5.62"/>
<vertex x="19.31" y="5.64"/>
<vertex x="19.55" y="5.67"/>
<vertex x="19.75" y="5.74"/>
<vertex x="19.93" y="5.82"/>
<vertex x="20.08" y="5.91"/>
<vertex x="20.21" y="6.02"/>
<vertex x="20.31" y="6.14"/>
<vertex x="20.4" y="6.27"/>
<vertex x="20.47" y="6.41"/>
<vertex x="20.52" y="6.54"/>
<vertex x="20.56" y="6.68"/>
<vertex x="20.58" y="6.81"/>
<vertex x="20.6" y="6.94"/>
<vertex x="20.61" y="7.05"/>
<vertex x="20.61" y="7.16"/>
<vertex x="20.61" y="7.25"/>
<vertex x="20.61" y="7.29"/>
<vertex x="20.61" y="7.34"/>
<vertex x="20.61" y="7.39"/>
<vertex x="20.61" y="7.43"/>
<vertex x="20.61" y="7.48"/>
<vertex x="20.61" y="7.52"/>
<vertex x="20.61" y="7.57"/>
<vertex x="20.61" y="7.61"/>
<vertex x="20.61" y="7.66"/>
<vertex x="20.61" y="7.7"/>
<vertex x="20.61" y="7.75"/>
<vertex x="20.61" y="7.79"/>
<vertex x="20.61" y="7.84"/>
<vertex x="20.61" y="7.88"/>
<vertex x="20.61" y="7.93"/>
<vertex x="20.61" y="7.97"/>
<vertex x="20.55" y="7.92"/>
<vertex x="20.48" y="7.88"/>
<vertex x="20.4" y="7.84"/>
<vertex x="20.31" y="7.8"/>
<vertex x="20.22" y="7.77"/>
<vertex x="20.12" y="7.74"/>
<vertex x="20.02" y="7.72"/>
<vertex x="19.91" y="7.7"/>
<vertex x="19.92" y="8.82"/>
<vertex x="20.21" y="8.92"/>
<vertex x="20.44" y="9.06"/>
<vertex x="20.58" y="9.25"/>
<vertex x="20.61" y="9.51"/>
<vertex x="20.61" y="9.66"/>
<vertex x="20.59" y="9.79"/>
<vertex x="20.56" y="9.91"/>
<vertex x="20.52" y="10.01"/>
<vertex x="20.46" y="10.1"/>
<vertex x="20.4" y="10.18"/>
<vertex x="20.33" y="10.25"/>
<vertex x="20.24" y="10.3"/>
<vertex x="20.15" y="10.35"/>
<vertex x="20.06" y="10.39"/>
<vertex x="19.95" y="10.42"/>
<vertex x="19.84" y="10.44"/>
<vertex x="19.73" y="10.46"/>
<vertex x="19.61" y="10.47"/>
<vertex x="19.49" y="10.47"/>
<vertex x="19.36" y="10.47"/>
<vertex x="19.22" y="10.47"/>
<vertex x="19.09" y="10.45"/>
<vertex x="18.97" y="10.43"/>
<vertex x="18.85" y="10.41"/>
<vertex x="18.74" y="10.37"/>
<vertex x="18.64" y="10.33"/>
<vertex x="18.55" y="10.28"/>
<vertex x="18.46" y="10.22"/>
<vertex x="18.38" y="10.15"/>
<vertex x="18.31" y="10.07"/>
<vertex x="18.25" y="9.99"/>
<vertex x="18.2" y="9.89"/>
<vertex x="18.15" y="9.78"/>
<vertex x="18.12" y="9.67"/>
<vertex x="18.09" y="9.54"/>
<vertex x="18.07" y="9.4"/>
<vertex x="17.95" y="9.4"/>
<vertex x="17.83" y="9.4"/>
<vertex x="17.71" y="9.4"/>
<vertex x="17.59" y="9.4"/>
<vertex x="17.47" y="9.4"/>
<vertex x="17.35" y="9.4"/>
<vertex x="17.23" y="9.4"/>
<vertex x="17.1" y="9.4"/>
<vertex x="16.98" y="9.4"/>
<vertex x="16.86" y="9.4"/>
<vertex x="16.74" y="9.4"/>
<vertex x="16.62" y="9.4"/>
<vertex x="16.5" y="9.4"/>
<vertex x="16.38" y="9.4"/>
<vertex x="16.26" y="9.4"/>
<vertex x="16.13" y="9.4"/>
<vertex x="16.17" y="9.72"/>
<vertex x="16.24" y="10.02"/>
<vertex x="16.35" y="10.29"/>
<vertex x="16.48" y="10.53"/>
<vertex x="16.63" y="10.75"/>
<vertex x="16.82" y="10.94"/>
<vertex x="17.02" y="11.11"/>
<vertex x="17.24" y="11.26"/>
<vertex x="17.48" y="11.39"/>
<vertex x="17.74" y="11.49"/>
<vertex x="18.01" y="11.58"/>
<vertex x="18.29" y="11.65"/>
<vertex x="18.57" y="11.7"/>
<vertex x="18.86" y="11.74"/>
<vertex x="19.16" y="11.76"/>
<vertex x="19.46" y="11.76"/>
<vertex x="19.73" y="11.76"/>
<vertex x="20" y="11.75"/>
<vertex x="20.27" y="11.72"/>
<vertex x="20.54" y="11.69"/>
<vertex x="20.8" y="11.64"/>
<vertex x="21.06" y="11.57"/>
<vertex x="21.31" y="11.49"/>
<vertex x="21.54" y="11.39"/>
<vertex x="21.76" y="11.27"/>
<vertex x="21.95" y="11.13"/>
<vertex x="22.13" y="10.97"/>
<vertex x="22.28" y="10.78"/>
<vertex x="22.4" y="10.57"/>
<vertex x="22.49" y="10.32"/>
<vertex x="22.54" y="10.05"/>
<vertex x="22.56" y="9.75"/>
<vertex x="22.56" y="9.52"/>
<vertex x="22.56" y="9.29"/>
<vertex x="22.56" y="9.06"/>
<vertex x="22.56" y="8.83"/>
<vertex x="22.56" y="8.6"/>
<vertex x="22.56" y="8.37"/>
<vertex x="22.56" y="8.14"/>
<vertex x="22.56" y="7.91"/>
<vertex x="22.56" y="7.68"/>
<vertex x="22.56" y="7.45"/>
<vertex x="22.56" y="7.22"/>
<vertex x="22.56" y="6.99"/>
<vertex x="22.56" y="6.76"/>
<vertex x="22.56" y="6.53"/>
<vertex x="22.56" y="6.3"/>
<vertex x="22.56" y="6.07"/>
<vertex x="22.56" y="5.95"/>
<vertex x="22.57" y="5.83"/>
<vertex x="22.57" y="5.71"/>
<vertex x="22.57" y="5.6"/>
<vertex x="22.58" y="5.48"/>
<vertex x="22.59" y="5.37"/>
<vertex x="22.6" y="5.26"/>
<vertex x="22.62" y="5.15"/>
<vertex x="22.63" y="5.05"/>
<vertex x="22.65" y="4.96"/>
<vertex x="22.67" y="4.86"/>
<vertex x="22.69" y="4.78"/>
<vertex x="22.72" y="4.7"/>
<vertex x="22.74" y="4.62"/>
<vertex x="22.77" y="4.56"/>
<vertex x="22.8" y="4.5"/>
<vertex x="22.68" y="4.5"/>
<vertex x="22.56" y="4.5"/>
<vertex x="22.44" y="4.5"/>
<vertex x="22.31" y="4.5"/>
<vertex x="22.19" y="4.5"/>
<vertex x="22.07" y="4.5"/>
<vertex x="21.94" y="4.5"/>
<vertex x="21.82" y="4.5"/>
<vertex x="21.7" y="4.5"/>
<vertex x="21.58" y="4.5"/>
<vertex x="21.45" y="4.5"/>
<vertex x="21.33" y="4.5"/>
<vertex x="21.21" y="4.5"/>
<vertex x="21.08" y="4.5"/>
<vertex x="20.96" y="4.5"/>
<vertex x="20.84" y="4.5"/>
<vertex x="20.82" y="4.54"/>
<vertex x="20.81" y="4.58"/>
<vertex x="20.79" y="4.63"/>
<vertex x="20.78" y="4.67"/>
<vertex x="20.76" y="4.71"/>
<vertex x="20.75" y="4.75"/>
<vertex x="20.74" y="4.8"/>
<vertex x="20.73" y="4.84"/>
<vertex x="20.72" y="4.88"/>
<vertex x="20.72" y="4.92"/>
<vertex x="20.72" y="4.97"/>
<vertex x="20.71" y="5.01"/>
<vertex x="20.71" y="5.05"/>
<vertex x="20.71" y="5.1"/>
<vertex x="20.7" y="5.14"/>
<vertex x="20.7" y="5.18"/>
<vertex x="20.58" y="5.07"/>
<vertex x="20.46" y="4.96"/>
<vertex x="20.33" y="4.87"/>
<vertex x="20.19" y="4.78"/>
<vertex x="20.05" y="4.7"/>
<vertex x="19.91" y="4.63"/>
<vertex x="19.76" y="4.56"/>
<vertex x="19.61" y="4.51"/>
<vertex x="19.46" y="4.46"/>
<vertex x="19.3" y="4.42"/>
<vertex x="19.14" y="4.38"/>
<vertex x="18.98" y="4.36"/>
<vertex x="18.82" y="4.33"/>
<vertex x="18.65" y="4.32"/>
<vertex x="18.49" y="4.31"/>
<vertex x="18.32" y="4.31"/>
<vertex x="18.07" y="4.31"/>
<vertex x="17.83" y="4.34"/>
<vertex x="17.6" y="4.38"/>
<vertex x="17.38" y="4.43"/>
<vertex x="17.17" y="4.5"/>
<vertex x="16.97" y="4.59"/>
<vertex x="16.78" y="4.7"/>
<vertex x="16.61" y="4.82"/>
<vertex x="16.46" y="4.96"/>
<vertex x="16.32" y="5.12"/>
<vertex x="16.2" y="5.29"/>
<vertex x="16.1" y="5.48"/>
<vertex x="16.02" y="5.69"/>
<vertex x="15.97" y="5.92"/>
<vertex x="15.93" y="6.16"/>
<vertex x="15.92" y="6.42"/>
<vertex x="15.97" y="6.97"/>
<vertex x="16.13" y="7.41"/>
<vertex x="16.37" y="7.77"/>
<vertex x="16.67" y="8.04"/>
<vertex x="17.03" y="8.24"/>
<vertex x="17.44" y="8.39"/>
<vertex x="17.87" y="8.5"/>
</polygon>
<vertex x="23.66" y="11.26"/>
<vertex x="23.89" y="11.3"/>
<vertex x="24.12" y="11.34"/>
<vertex x="24.35" y="11.38"/>
<vertex x="24.58" y="11.42"/>
<vertex x="24.81" y="11.46"/>
<vertex x="25.04" y="11.5"/>
<vertex x="25.27" y="11.54"/>
<vertex x="25.5" y="11.59"/>
<vertex x="25.5" y="11.42"/>
<vertex x="25.5" y="11.26"/>
<vertex x="25.5" y="11.09"/>
<vertex x="25.5" y="10.93"/>
<vertex x="25.5" y="10.76"/>
<vertex x="25.5" y="10.6"/>
<vertex x="25.5" y="10.44"/>
<vertex x="25.5" y="10.27"/>
<vertex x="25.51" y="10.27"/>
<vertex x="25.52" y="10.27"/>
<vertex x="25.68" y="10.59"/>
<vertex x="25.89" y="10.88"/>
<vertex x="26.14" y="11.14"/>
<vertex x="26.42" y="11.36"/>
<vertex x="26.73" y="11.53"/>
<vertex x="27.06" y="11.67"/>
<vertex x="27.41" y="11.75"/>
<vertex x="27.77" y="11.78"/>
<vertex x="27.83" y="11.77"/>
<vertex x="27.88" y="11.77"/>
<vertex x="27.94" y="11.77"/>
<vertex x="27.99" y="11.76"/>
<vertex x="28.04" y="11.75"/>
<vertex x="28.09" y="11.74"/>
<vertex x="28.15" y="11.72"/>
<vertex x="28.2" y="11.71"/>
<vertex x="28.2" y="11.48"/>
<vertex x="28.2" y="11.26"/>
<vertex x="28.2" y="11.03"/>
<vertex x="28.2" y="10.81"/>
<vertex x="28.2" y="10.58"/>
<vertex x="28.2" y="10.35"/>
<vertex x="28.2" y="10.13"/>
<vertex x="28.2" y="9.9"/>
<vertex x="28.12" y="9.92"/>
<vertex x="28.04" y="9.93"/>
<vertex x="27.96" y="9.95"/>
<vertex x="27.87" y="9.96"/>
<vertex x="27.77" y="9.96"/>
<vertex x="27.68" y="9.97"/>
<vertex x="27.59" y="9.97"/>
<vertex x="27.5" y="9.97"/>
<vertex x="27" y="9.92"/>
<vertex x="26.59" y="9.79"/>
<vertex x="26.26" y="9.58"/>
<vertex x="26" y="9.31"/>
<vertex x="25.81" y="8.97"/>
<vertex x="25.68" y="8.59"/>
<vertex x="25.61" y="8.16"/>
<vertex x="25.58" y="7.7"/>
<vertex x="25.58" y="7.3"/>
<vertex x="25.58" y="6.9"/>
<vertex x="25.58" y="6.51"/>
<vertex x="25.58" y="6.11"/>
<vertex x="25.58" y="5.71"/>
<vertex x="25.58" y="5.31"/>
<vertex x="25.58" y="4.91"/>
<vertex x="25.58" y="4.51"/>
<vertex x="25.34" y="4.51"/>
<vertex x="25.1" y="4.51"/>
<vertex x="24.85" y="4.51"/>
<vertex x="24.61" y="4.51"/>
<vertex x="24.37" y="4.51"/>
<vertex x="24.13" y="4.51"/>
<vertex x="23.88" y="4.51"/>
<vertex x="23.64" y="4.51"/>
<vertex x="23.64" y="5.36"/>
<vertex x="23.64" y="6.2"/>
<vertex x="23.64" y="7.04"/>
<vertex x="23.64" y="7.88"/>
<vertex x="23.64" y="8.73"/>
<vertex x="23.64" y="9.57"/>
<vertex x="23.64" y="10.41"/>
</polygon>
<vertex x="28.96" y="13.22"/>
<vertex x="30.9" y="14.28"/>
<vertex x="30.9" y="9.04"/>
<vertex x="33.35" y="11.59"/>
<vertex x="35.65" y="11.59"/>
<vertex x="32.98" y="8.99"/>
<vertex x="35.95" y="4.52"/>
<vertex x="33.6" y="4.52"/>
<vertex x="31.66" y="7.68"/>
<vertex x="30.9" y="6.95"/>
<vertex x="30.9" y="4.52"/>
<vertex x="28.96" y="4.52"/>
</polygon>
<vertex x="37.13" y="10.29"/>
<vertex x="36.89" y="10.29"/>
<vertex x="36.65" y="10.29"/>
<vertex x="36.41" y="10.29"/>
<vertex x="36.17" y="10.29"/>
<vertex x="35.93" y="10.29"/>
<vertex x="35.69" y="10.29"/>
<vertex x="35.45" y="10.29"/>
<vertex x="35.21" y="10.29"/>
<vertex x="35.38" y="10.45"/>
<vertex x="35.55" y="10.61"/>
<vertex x="35.71" y="10.78"/>
<vertex x="35.88" y="10.94"/>
<vertex x="36.04" y="11.1"/>
<vertex x="36.21" y="11.26"/>
<vertex x="36.37" y="11.42"/>
<vertex x="36.54" y="11.59"/>
<vertex x="36.61" y="11.59"/>
<vertex x="36.69" y="11.59"/>
<vertex x="36.76" y="11.59"/>
<vertex x="36.83" y="11.59"/>
<vertex x="36.91" y="11.59"/>
<vertex x="36.98" y="11.59"/>
<vertex x="37.06" y="11.59"/>
<vertex x="37.13" y="11.59"/>
<vertex x="37.13" y="11.65"/>
<vertex x="37.13" y="11.72"/>
<vertex x="37.13" y="11.79"/>
<vertex x="37.13" y="11.86"/>
<vertex x="37.13" y="11.93"/>
<vertex x="37.13" y="11.99"/>
<vertex x="37.13" y="12.06"/>
<vertex x="37.13" y="12.13"/>
<vertex x="37.17" y="12.59"/>
<vertex x="37.28" y="13"/>
<vertex x="37.46" y="13.36"/>
<vertex x="37.72" y="13.68"/>
<vertex x="38.05" y="13.93"/>
<vertex x="38.46" y="14.12"/>
<vertex x="38.94" y="14.24"/>
<vertex x="39.49" y="14.28"/>
<vertex x="39.62" y="14.28"/>
<vertex x="39.75" y="14.27"/>
<vertex x="39.88" y="14.27"/>
<vertex x="40.01" y="14.26"/>
<vertex x="40.14" y="14.25"/>
<vertex x="40.27" y="14.24"/>
<vertex x="40.4" y="14.24"/>
<vertex x="40.52" y="14.23"/>
<vertex x="40.52" y="14.05"/>
<vertex x="40.52" y="13.87"/>
<vertex x="40.52" y="13.69"/>
<vertex x="40.52" y="13.51"/>
<vertex x="40.52" y="13.33"/>
<vertex x="40.52" y="13.15"/>
<vertex x="40.52" y="12.96"/>
<vertex x="40.52" y="12.78"/>
<vertex x="40.43" y="12.79"/>
<vertex x="40.34" y="12.8"/>
<vertex x="40.25" y="12.81"/>
<vertex x="40.16" y="12.81"/>
<vertex x="40.07" y="12.81"/>
<vertex x="39.99" y="12.81"/>
<vertex x="39.9" y="12.82"/>
<vertex x="39.81" y="12.82"/>
<vertex x="39.62" y="12.81"/>
<vertex x="39.47" y="12.77"/>
<vertex x="39.34" y="12.72"/>
<vertex x="39.24" y="12.63"/>
<vertex x="39.16" y="12.52"/>
<vertex x="39.11" y="12.38"/>
<vertex x="39.08" y="12.21"/>
<vertex x="39.07" y="12.01"/>
<vertex x="39.07" y="11.96"/>
<vertex x="39.07" y="11.9"/>
<vertex x="39.07" y="11.85"/>
<vertex x="39.07" y="11.8"/>
<vertex x="39.07" y="11.75"/>
<vertex x="39.07" y="11.69"/>
<vertex x="39.07" y="11.64"/>
<vertex x="39.07" y="11.59"/>
<vertex x="39.24" y="11.59"/>
<vertex x="39.4" y="11.59"/>
<vertex x="39.57" y="11.59"/>
<vertex x="39.74" y="11.59"/>
<vertex x="39.91" y="11.59"/>
<vertex x="40.07" y="11.59"/>
<vertex x="40.24" y="11.59"/>
<vertex x="40.41" y="11.59"/>
<vertex x="40.41" y="11.42"/>
<vertex x="40.41" y="11.26"/>
<vertex x="40.41" y="11.1"/>
<vertex x="40.41" y="10.94"/>
<vertex x="40.41" y="10.77"/>
<vertex x="40.41" y="10.61"/>
<vertex x="40.41" y="10.45"/>
<vertex x="40.41" y="10.29"/>
<vertex x="40.24" y="10.29"/>
<vertex x="40.07" y="10.29"/>
<vertex x="39.91" y="10.29"/>
<vertex x="39.74" y="10.29"/>
<vertex x="39.57" y="10.29"/>
<vertex x="39.4" y="10.29"/>
<vertex x="39.24" y="10.29"/>
<vertex x="39.07" y="10.29"/>
<vertex x="39.07" y="9.57"/>
<vertex x="39.07" y="8.84"/>
<vertex x="39.07" y="8.12"/>
<vertex x="39.07" y="7.4"/>
<vertex x="39.07" y="6.68"/>
<vertex x="39.07" y="5.96"/>
<vertex x="39.07" y="5.24"/>
<vertex x="39.07" y="4.52"/>
<vertex x="38.83" y="4.52"/>
<vertex x="38.58" y="4.52"/>
<vertex x="38.34" y="4.52"/>
<vertex x="38.1" y="4.52"/>
<vertex x="37.86" y="4.52"/>
<vertex x="37.61" y="4.52"/>
<vertex x="37.37" y="4.52"/>
<vertex x="37.13" y="4.52"/>
<vertex x="37.13" y="5.24"/>
<vertex x="37.13" y="5.96"/>
<vertex x="37.13" y="6.68"/>
<vertex x="37.13" y="7.4"/>
<vertex x="37.13" y="8.12"/>
<vertex x="37.13" y="8.84"/>
<vertex x="37.13" y="9.57"/>
</polygon>
<vertex x="47.59" y="4.52"/>
<vertex x="47.36" y="4.52"/>
<vertex x="47.13" y="4.52"/>
<vertex x="46.89" y="4.52"/>
<vertex x="46.66" y="4.52"/>
<vertex x="46.43" y="4.52"/>
<vertex x="46.2" y="4.52"/>
<vertex x="45.97" y="4.52"/>
<vertex x="45.74" y="4.52"/>
<vertex x="45.74" y="4.64"/>
<vertex x="45.74" y="4.76"/>
<vertex x="45.74" y="4.89"/>
<vertex x="45.74" y="5.01"/>
<vertex x="45.74" y="5.13"/>
<vertex x="45.74" y="5.25"/>
<vertex x="45.74" y="5.38"/>
<vertex x="45.74" y="5.5"/>
<vertex x="45.73" y="5.5"/>
<vertex x="45.72" y="5.5"/>
<vertex x="45.52" y="5.22"/>
<vertex x="45.29" y="4.98"/>
<vertex x="45.04" y="4.77"/>
<vertex x="44.76" y="4.61"/>
<vertex x="44.47" y="4.48"/>
<vertex x="44.17" y="4.39"/>
<vertex x="43.87" y="4.34"/>
<vertex x="43.56" y="4.32"/>
<vertex x="42.85" y="4.38"/>
<vertex x="42.28" y="4.53"/>
<vertex x="41.83" y="4.78"/>
<vertex x="41.49" y="5.12"/>
<vertex x="41.25" y="5.55"/>
<vertex x="41.09" y="6.04"/>
<vertex x="41" y="6.61"/>
<vertex x="40.97" y="7.24"/>
<vertex x="40.97" y="7.78"/>
<vertex x="40.97" y="8.32"/>
<vertex x="40.97" y="8.87"/>
<vertex x="40.97" y="9.41"/>
<vertex x="40.97" y="9.95"/>
<vertex x="40.97" y="10.5"/>
<vertex x="40.97" y="11.04"/>
<vertex x="40.97" y="11.59"/>
<vertex x="41.22" y="11.59"/>
<vertex x="41.46" y="11.59"/>
<vertex x="41.7" y="11.59"/>
<vertex x="41.94" y="11.59"/>
<vertex x="42.19" y="11.59"/>
<vertex x="42.43" y="11.59"/>
<vertex x="42.67" y="11.59"/>
<vertex x="42.92" y="11.59"/>
<vertex x="42.92" y="11.09"/>
<vertex x="42.92" y="10.59"/>
<vertex x="42.92" y="10.09"/>
<vertex x="42.92" y="9.59"/>
<vertex x="42.92" y="9.09"/>
<vertex x="42.92" y="8.59"/>
<vertex x="42.92" y="8.09"/>
<vertex x="42.92" y="7.59"/>
<vertex x="42.93" y="7.18"/>
<vertex x="42.98" y="6.83"/>
<vertex x="43.07" y="6.53"/>
<vertex x="43.2" y="6.29"/>
<vertex x="43.37" y="6.1"/>
<vertex x="43.58" y="5.96"/>
<vertex x="43.84" y="5.88"/>
<vertex x="44.16" y="5.86"/>
<vertex x="44.53" y="5.88"/>
<vertex x="44.84" y="5.97"/>
<vertex x="45.1" y="6.12"/>
<vertex x="45.31" y="6.33"/>
<vertex x="45.47" y="6.61"/>
<vertex x="45.58" y="6.96"/>
<vertex x="45.64" y="7.38"/>
<vertex x="45.67" y="7.88"/>
<vertex x="45.67" y="8.34"/>
<vertex x="45.67" y="8.81"/>
<vertex x="45.67" y="9.27"/>
<vertex x="45.67" y="9.73"/>
<vertex x="45.67" y="10.2"/>
<vertex x="45.67" y="10.66"/>
<vertex x="45.67" y="11.12"/>
<vertex x="45.67" y="11.58"/>
<vertex x="45.91" y="11.58"/>
<vertex x="46.15" y="11.58"/>
<vertex x="46.39" y="11.58"/>
<vertex x="46.64" y="11.58"/>
<vertex x="46.88" y="11.58"/>
<vertex x="47.12" y="11.58"/>
<vertex x="47.36" y="11.58"/>
<vertex x="47.61" y="11.58"/>
<vertex x="47.61" y="10.7"/>
<vertex x="47.61" y="9.82"/>
<vertex x="47.61" y="8.93"/>
<vertex x="47.61" y="8.05"/>
<vertex x="47.61" y="7.17"/>
<vertex x="47.61" y="6.28"/>
<vertex x="47.61" y="5.4"/>
</polygon>
<vertex x="48.66" y="11.59"/>
<vertex x="48.89" y="11.59"/>
<vertex x="49.12" y="11.59"/>
<vertex x="49.35" y="11.59"/>
<vertex x="49.58" y="11.59"/>
<vertex x="49.81" y="11.59"/>
<vertex x="50.04" y="11.59"/>
<vertex x="50.27" y="11.59"/>
<vertex x="50.5" y="11.59"/>
<vertex x="50.5" y="11.46"/>
<vertex x="50.5" y="11.34"/>
<vertex x="50.5" y="11.22"/>
<vertex x="50.5" y="11.1"/>
<vertex x="50.5" y="10.97"/>
<vertex x="50.5" y="10.85"/>
<vertex x="50.5" y="10.73"/>
<vertex x="50.5" y="10.6"/>
<vertex x="50.51" y="10.6"/>
<vertex x="50.52" y="10.6"/>
<vertex x="50.53" y="10.6"/>
<vertex x="50.73" y="10.89"/>
<vertex x="50.96" y="11.13"/>
<vertex x="51.21" y="11.33"/>
<vertex x="51.48" y="11.49"/>
<vertex x="51.77" y="11.62"/>
<vertex x="52.07" y="11.71"/>
<vertex x="52.38" y="11.76"/>
<vertex x="52.69" y="11.78"/>
<vertex x="53.39" y="11.73"/>
<vertex x="53.96" y="11.57"/>
<vertex x="54.41" y="11.32"/>
<vertex x="54.75" y="10.98"/>
<vertex x="55" y="10.56"/>
<vertex x="55.16" y="10.06"/>
<vertex x="55.25" y="9.5"/>
<vertex x="55.27" y="8.87"/>
<vertex x="55.27" y="8.32"/>
<vertex x="55.27" y="7.78"/>
<vertex x="55.27" y="7.24"/>
<vertex x="55.27" y="6.69"/>
<vertex x="55.27" y="6.15"/>
<vertex x="55.27" y="5.61"/>
<vertex x="55.27" y="5.06"/>
<vertex x="55.27" y="4.52"/>
<vertex x="55.03" y="4.52"/>
<vertex x="54.79" y="4.52"/>
<vertex x="54.54" y="4.52"/>
<vertex x="54.3" y="4.52"/>
<vertex x="54.06" y="4.52"/>
<vertex x="53.82" y="4.52"/>
<vertex x="53.57" y="4.52"/>
<vertex x="53.33" y="4.52"/>
<vertex x="53.33" y="5.02"/>
<vertex x="53.33" y="5.52"/>
<vertex x="53.33" y="6.02"/>
<vertex x="53.33" y="6.52"/>
<vertex x="53.33" y="7.01"/>
<vertex x="53.33" y="7.51"/>
<vertex x="53.33" y="8.01"/>
<vertex x="53.33" y="8.51"/>
<vertex x="53.31" y="8.92"/>
<vertex x="53.26" y="9.27"/>
<vertex x="53.18" y="9.57"/>
<vertex x="53.05" y="9.82"/>
<vertex x="52.88" y="10.01"/>
<vertex x="52.67" y="10.14"/>
<vertex x="52.4" y="10.22"/>
<vertex x="52.08" y="10.25"/>
<vertex x="51.72" y="10.22"/>
<vertex x="51.41" y="10.13"/>
<vertex x="51.15" y="9.99"/>
<vertex x="50.94" y="9.77"/>
<vertex x="50.78" y="9.5"/>
<vertex x="50.67" y="9.15"/>
<vertex x="50.6" y="8.72"/>
<vertex x="50.58" y="8.22"/>
<vertex x="50.58" y="7.76"/>
<vertex x="50.58" y="7.3"/>
<vertex x="50.58" y="6.83"/>
<vertex x="50.58" y="6.37"/>
<vertex x="50.58" y="5.91"/>
<vertex x="50.58" y="5.45"/>
<vertex x="50.58" y="4.98"/>
<vertex x="50.58" y="4.52"/>
<vertex x="50.34" y="4.52"/>
<vertex x="50.1" y="4.52"/>
<vertex x="49.85" y="4.52"/>
<vertex x="49.61" y="4.52"/>
<vertex x="49.37" y="4.52"/>
<vertex x="49.13" y="4.52"/>
<vertex x="48.88" y="4.52"/>
<vertex x="48.64" y="4.52"/>
<vertex x="48.64" y="5.4"/>
<vertex x="48.64" y="6.29"/>
<vertex x="48.64" y="7.17"/>
<vertex x="48.64" y="8.05"/>
<vertex x="48.64" y="8.94"/>
<vertex x="48.64" y="9.82"/>
<vertex x="48.64" y="10.7"/>
</polygon>
<vertex x="39.88" y="23.72"/>
<vertex x="39.89" y="23.69"/>
<vertex x="39.9" y="23.6"/>
<vertex x="39.91" y="23.47"/>
<vertex x="39.9" y="23.33"/>
<vertex x="39.86" y="23.17"/>
<vertex x="39.79" y="23.03"/>
<vertex x="39.66" y="22.92"/>
<vertex x="39.48" y="22.85"/>
<vertex x="39.32" y="22.85"/>
<vertex x="39.14" y="22.88"/>
<vertex x="38.96" y="22.95"/>
<vertex x="38.77" y="23.04"/>
<vertex x="38.58" y="23.16"/>
<vertex x="38.4" y="23.29"/>
<vertex x="38.25" y="23.43"/>
<vertex x="38.11" y="23.58"/>
<vertex x="37.98" y="23.76"/>
<vertex x="37.89" y="23.93"/>
<vertex x="37.84" y="24.09"/>
<vertex x="37.82" y="24.24"/>
<vertex x="37.84" y="24.39"/>
<vertex x="37.89" y="24.53"/>
<vertex x="37.96" y="24.66"/>
<vertex x="38.07" y="24.79"/>
<vertex x="38.26" y="24.96"/>
<vertex x="38.46" y="25.06"/>
<vertex x="38.68" y="25.12"/>
<vertex x="38.88" y="25.15"/>
<vertex x="39.06" y="25.15"/>
<vertex x="39.21" y="25.13"/>
<vertex x="39.3" y="25.11"/>
<vertex x="39.34" y="25.11"/>
<vertex x="39.27" y="25.16"/>
<vertex x="39.08" y="25.3"/>
<vertex x="38.79" y="25.46"/>
<vertex x="38.41" y="25.62"/>
<vertex x="37.96" y="25.73"/>
<vertex x="37.45" y="25.75"/>
<vertex x="36.91" y="25.64"/>
<vertex x="36.34" y="25.34"/>
<vertex x="35.91" y="24.98"/>
<vertex x="35.63" y="24.58"/>
<vertex x="35.5" y="24.17"/>
<vertex x="35.49" y="23.74"/>
<vertex x="35.61" y="23.31"/>
<vertex x="35.85" y="22.87"/>
<vertex x="36.18" y="22.44"/>
<vertex x="36.6" y="22.01"/>
<vertex x="36.92" y="21.63"/>
<vertex x="37.08" y="21.26"/>
<vertex x="37.1" y="20.91"/>
<vertex x="36.99" y="20.59"/>
<vertex x="36.77" y="20.33"/>
<vertex x="36.47" y="20.14"/>
<vertex x="36.11" y="20.04"/>
<vertex x="35.7" y="20.04"/>
<vertex x="35.44" y="20.1"/>
<vertex x="35.22" y="20.2"/>
<vertex x="35.04" y="20.33"/>
<vertex x="34.9" y="20.48"/>
<vertex x="34.81" y="20.64"/>
<vertex x="34.76" y="20.81"/>
<vertex x="34.76" y="20.98"/>
<vertex x="34.81" y="21.13"/>
<vertex x="34.89" y="21.24"/>
<vertex x="34.99" y="21.35"/>
<vertex x="35.1" y="21.44"/>
<vertex x="35.22" y="21.51"/>
<vertex x="35.34" y="21.57"/>
<vertex x="35.43" y="21.61"/>
<vertex x="35.49" y="21.64"/>
<vertex x="35.52" y="21.65"/>
<vertex x="35.49" y="21.66"/>
<vertex x="35.41" y="21.69"/>
<vertex x="35.28" y="21.72"/>
<vertex x="35.11" y="21.74"/>
<vertex x="34.9" y="21.76"/>
<vertex x="34.67" y="21.75"/>
<vertex x="34.42" y="21.71"/>
<vertex x="34.14" y="21.63"/>
<vertex x="33.9" y="21.52"/>
<vertex x="33.67" y="21.38"/>
<vertex x="33.47" y="21.19"/>
<vertex x="33.29" y="20.96"/>
<vertex x="33.15" y="20.68"/>
<vertex x="33.04" y="20.33"/>
<vertex x="32.98" y="19.92"/>
<vertex x="32.97" y="19.44"/>
<vertex x="32.97" y="18.64"/>
<vertex x="32.97" y="17.84"/>
<vertex x="32.97" y="17.04"/>
<vertex x="32.97" y="16.24"/>
<vertex x="32.97" y="15.44"/>
<vertex x="32.97" y="14.64"/>
<vertex x="32.97" y="13.84"/>
<vertex x="32.97" y="13.04"/>
<vertex x="33" y="13.08"/>
<vertex x="33.09" y="13.18"/>
<vertex x="33.23" y="13.35"/>
<vertex x="33.42" y="13.57"/>
<vertex x="33.64" y="13.83"/>
<vertex x="33.89" y="14.12"/>
<vertex x="34.17" y="14.43"/>
<vertex x="34.47" y="14.75"/>
<vertex x="34.79" y="15.1"/>
<vertex x="35.08" y="15.42"/>
<vertex x="35.34" y="15.7"/>
<vertex x="35.59" y="15.93"/>
<vertex x="35.84" y="16.11"/>
<vertex x="36.11" y="16.24"/>
<vertex x="36.4" y="16.31"/>
<vertex x="36.73" y="16.31"/>
<vertex x="37.37" y="16.31"/>
<vertex x="37.96" y="16.39"/>
<vertex x="38.51" y="16.54"/>
<vertex x="39.02" y="16.76"/>
<vertex x="39.48" y="17.05"/>
<vertex x="39.91" y="17.39"/>
<vertex x="40.29" y="17.79"/>
<vertex x="40.64" y="18.24"/>
<vertex x="40.71" y="18.36"/>
<vertex x="41.13" y="19.16"/>
<vertex x="41.38" y="20.07"/>
<vertex x="41.42" y="20.95"/>
<vertex x="41.3" y="21.76"/>
<vertex x="41.05" y="22.47"/>
<vertex x="40.7" y="23.06"/>
<vertex x="40.3" y="23.49"/>
<vertex x="39.88" y="23.73"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.1">
<vertex x="0.81" y="1.4"/>
<vertex x="0.81" y="1.34"/>
<vertex x="0.83" y="1.29"/>
<vertex x="0.86" y="1.25"/>
<vertex x="0.9" y="1.22"/>
<vertex x="0.94" y="1.19"/>
<vertex x="1" y="1.18"/>
<vertex x="1.05" y="1.17"/>
<vertex x="1.11" y="1.16"/>
<vertex x="1.15" y="1.17"/>
<vertex x="1.19" y="1.17"/>
<vertex x="1.23" y="1.18"/>
<vertex x="1.27" y="1.2"/>
<vertex x="1.31" y="1.23"/>
<vertex x="1.34" y="1.26"/>
<vertex x="1.35" y="1.3"/>
<vertex x="1.36" y="1.34"/>
<vertex x="1.35" y="1.38"/>
<vertex x="1.33" y="1.42"/>
<vertex x="1.29" y="1.45"/>
<vertex x="1.24" y="1.48"/>
<vertex x="1.18" y="1.5"/>
<vertex x="1.1" y="1.52"/>
<vertex x="1.02" y="1.54"/>
<vertex x="0.92" y="1.56"/>
<vertex x="0.83" y="1.58"/>
<vertex x="0.75" y="1.61"/>
<vertex x="0.68" y="1.64"/>
<vertex x="0.61" y="1.68"/>
<vertex x="0.55" y="1.72"/>
<vertex x="0.51" y="1.78"/>
<vertex x="0.48" y="1.85"/>
<vertex x="0.47" y="1.94"/>
<vertex x="0.48" y="2.06"/>
<vertex x="0.52" y="2.16"/>
<vertex x="0.59" y="2.24"/>
<vertex x="0.66" y="2.3"/>
<vertex x="0.76" y="2.35"/>
<vertex x="0.86" y="2.37"/>
<vertex x="0.97" y="2.39"/>
<vertex x="1.09" y="2.39"/>
<vertex x="1.2" y="2.39"/>
<vertex x="1.31" y="2.37"/>
<vertex x="1.41" y="2.34"/>
<vertex x="1.5" y="2.3"/>
<vertex x="1.58" y="2.24"/>
<vertex x="1.64" y="2.16"/>
<vertex x="1.69" y="2.06"/>
<vertex x="1.71" y="1.94"/>
<vertex x="1.66" y="1.94"/>
<vertex x="1.62" y="1.94"/>
<vertex x="1.57" y="1.94"/>
<vertex x="1.53" y="1.94"/>
<vertex x="1.48" y="1.94"/>
<vertex x="1.43" y="1.94"/>
<vertex x="1.39" y="1.94"/>
<vertex x="1.34" y="1.94"/>
<vertex x="1.33" y="1.99"/>
<vertex x="1.31" y="2.04"/>
<vertex x="1.29" y="2.07"/>
<vertex x="1.26" y="2.09"/>
<vertex x="1.22" y="2.11"/>
<vertex x="1.17" y="2.13"/>
<vertex x="1.13" y="2.13"/>
<vertex x="1.08" y="2.13"/>
<vertex x="1.04" y="2.13"/>
<vertex x="1" y="2.13"/>
<vertex x="0.97" y="2.12"/>
<vertex x="0.93" y="2.11"/>
<vertex x="0.9" y="2.1"/>
<vertex x="0.88" y="2.07"/>
<vertex x="0.86" y="2.04"/>
<vertex x="0.86" y="2"/>
<vertex x="0.87" y="1.96"/>
<vertex x="0.9" y="1.92"/>
<vertex x="0.94" y="1.89"/>
<vertex x="1" y="1.86"/>
<vertex x="1.06" y="1.84"/>
<vertex x="1.14" y="1.83"/>
<vertex x="1.22" y="1.81"/>
<vertex x="1.3" y="1.79"/>
<vertex x="1.38" y="1.77"/>
<vertex x="1.47" y="1.75"/>
<vertex x="1.54" y="1.71"/>
<vertex x="1.61" y="1.67"/>
<vertex x="1.67" y="1.62"/>
<vertex x="1.71" y="1.56"/>
<vertex x="1.74" y="1.49"/>
<vertex x="1.75" y="1.4"/>
<vertex x="1.73" y="1.27"/>
<vertex x="1.69" y="1.16"/>
<vertex x="1.63" y="1.08"/>
<vertex x="1.55" y="1.01"/>
<vertex x="1.45" y="0.96"/>
<vertex x="1.34" y="0.93"/>
<vertex x="1.22" y="0.91"/>
<vertex x="1.1" y="0.9"/>
<vertex x="0.98" y="0.91"/>
<vertex x="0.86" y="0.93"/>
<vertex x="0.75" y="0.96"/>
<vertex x="0.65" y="1.01"/>
<vertex x="0.57" y="1.08"/>
<vertex x="0.5" y="1.17"/>
<vertex x="0.46" y="1.27"/>
<vertex x="0.44" y="1.4"/>
<vertex x="0.48" y="1.4"/>
<vertex x="0.53" y="1.4"/>
<vertex x="0.58" y="1.4"/>
<vertex x="0.62" y="1.4"/>
<vertex x="0.67" y="1.4"/>
<vertex x="0.71" y="1.4"/>
<vertex x="0.76" y="1.4"/>
</polygon>
<vertex x="2.91" y="1.4"/>
<vertex x="2.94" y="1.48"/>
<vertex x="2.95" y="1.56"/>
<vertex x="2.95" y="1.64"/>
<vertex x="3.34" y="1.63"/>
<vertex x="3.33" y="1.49"/>
<vertex x="3.3" y="1.36"/>
<vertex x="3.25" y="1.24"/>
</polygon>
<vertex x="3.19" y="1.13"/>
<vertex x="3.1" y="1.04"/>
<vertex x="2.99" y="0.96"/>
<vertex x="2.87" y="0.92"/>
<vertex x="2.72" y="0.9"/>
<vertex x="2.66" y="0.91"/>
<vertex x="2.6" y="0.92"/>
<vertex x="2.54" y="0.93"/>
<vertex x="2.48" y="0.96"/>
<vertex x="2.43" y="0.99"/>
<vertex x="2.38" y="1.02"/>
<vertex x="2.34" y="1.07"/>
<vertex x="2.3" y="1.12"/>
<vertex x="2.29" y="1.12"/>
<vertex x="2.29" y="0.99"/>
<vertex x="2.29" y="0.86"/>
<vertex x="2.29" y="0.74"/>
<vertex x="2.29" y="0.61"/>
<vertex x="2.29" y="0.48"/>
<vertex x="2.29" y="0.35"/>
<vertex x="2.29" y="0.23"/>
<vertex x="2.29" y="0.1"/>
<vertex x="2.25" y="0.14"/>
<vertex x="2.2" y="0.19"/>
<vertex x="2.15" y="0.23"/>
<vertex x="2.1" y="0.27"/>
<vertex x="2.05" y="0.31"/>
<vertex x="2" y="0.36"/>
<vertex x="1.96" y="0.4"/>
<vertex x="1.91" y="0.44"/>
<vertex x="1.91" y="0.68"/>
<vertex x="1.91" y="0.91"/>
<vertex x="1.91" y="1.14"/>
<vertex x="1.91" y="1.37"/>
<vertex x="1.91" y="1.6"/>
<vertex x="1.91" y="1.83"/>
<vertex x="1.91" y="2.06"/>
<vertex x="1.91" y="2.29"/>
<vertex x="1.95" y="2.3"/>
<vertex x="2" y="2.31"/>
<vertex x="2.05" y="2.31"/>
<vertex x="2.09" y="2.32"/>
<vertex x="2.14" y="2.33"/>
<vertex x="2.18" y="2.34"/>
<vertex x="2.23" y="2.35"/>
<vertex x="2.28" y="2.36"/>
<vertex x="2.28" y="2.33"/>
<vertex x="2.28" y="2.31"/>
<vertex x="2.28" y="2.29"/>
<vertex x="2.28" y="2.27"/>
<vertex x="2.28" y="2.24"/>
<vertex x="2.28" y="2.22"/>
<vertex x="2.28" y="2.2"/>
<vertex x="2.28" y="2.18"/>
<vertex x="2.32" y="2.23"/>
<vertex x="2.36" y="2.27"/>
<vertex x="2.41" y="2.31"/>
<vertex x="2.46" y="2.34"/>
<vertex x="2.51" y="2.37"/>
<vertex x="2.57" y="2.38"/>
<vertex x="2.63" y="2.39"/>
<vertex x="2.7" y="2.39"/>
<vertex x="2.85" y="2.38"/>
<vertex x="2.99" y="2.33"/>
<vertex x="3.1" y="2.26"/>
<vertex x="3.19" y="2.16"/>
<vertex x="3.26" y="2.05"/>
<vertex x="3.3" y="1.92"/>
<vertex x="3.33" y="1.78"/>
<vertex x="2.95" y="1.73"/>
<vertex x="2.94" y="1.81"/>
<vertex x="2.91" y="1.89"/>
<vertex x="2.88" y="1.96"/>
<vertex x="2.83" y="2.02"/>
<vertex x="2.77" y="2.06"/>
<vertex x="2.7" y="2.09"/>
<vertex x="2.61" y="2.1"/>
<vertex x="2.53" y="2.09"/>
<vertex x="2.45" y="2.06"/>
<vertex x="2.4" y="2.02"/>
<vertex x="2.35" y="1.96"/>
<vertex x="2.32" y="1.89"/>
<vertex x="2.29" y="1.81"/>
<vertex x="2.28" y="1.73"/>
<vertex x="2.28" y="1.64"/>
<vertex x="2.28" y="1.56"/>
<vertex x="2.3" y="1.48"/>
<vertex x="2.32" y="1.4"/>
<vertex x="2.35" y="1.33"/>
<vertex x="2.4" y="1.28"/>
<vertex x="2.46" y="1.23"/>
<vertex x="2.53" y="1.21"/>
<vertex x="2.62" y="1.2"/>
<vertex x="2.7" y="1.21"/>
<vertex x="2.78" y="1.23"/>
<vertex x="2.84" y="1.28"/>
<vertex x="2.88" y="1.33"/>
</polygon>
<vertex x="3.93" y="1.75"/>
<vertex x="4.02" y="1.76"/>
<vertex x="4.11" y="1.77"/>
<vertex x="4.18" y="1.78"/>
<vertex x="4.23" y="1.58"/>
<vertex x="4.21" y="1.57"/>
<vertex x="4.19" y="1.57"/>
<vertex x="4.16" y="1.56"/>
<vertex x="4.14" y="1.56"/>
<vertex x="4.12" y="1.56"/>
<vertex x="4.09" y="1.55"/>
<vertex x="4.07" y="1.55"/>
<vertex x="4.05" y="1.55"/>
<vertex x="4.03" y="1.54"/>
<vertex x="4.01" y="1.54"/>
</polygon>
<vertex x="3.98" y="1.53"/>
<vertex x="3.96" y="1.52"/>
<vertex x="3.95" y="1.51"/>
<vertex x="3.93" y="1.5"/>
<vertex x="3.91" y="1.49"/>
<vertex x="3.9" y="1.48"/>
<vertex x="3.88" y="1.47"/>
<vertex x="3.87" y="1.45"/>
<vertex x="3.86" y="1.43"/>
<vertex x="3.85" y="1.41"/>
<vertex x="3.85" y="1.39"/>
<vertex x="3.84" y="1.37"/>
<vertex x="3.84" y="1.34"/>
<vertex x="3.84" y="1.32"/>
<vertex x="3.85" y="1.29"/>
<vertex x="3.85" y="1.27"/>
<vertex x="3.86" y="1.25"/>
<vertex x="3.87" y="1.24"/>
<vertex x="3.88" y="1.22"/>
<vertex x="3.9" y="1.21"/>
<vertex x="3.91" y="1.2"/>
<vertex x="3.93" y="1.19"/>
<vertex x="3.95" y="1.18"/>
<vertex x="3.97" y="1.18"/>
<vertex x="3.99" y="1.17"/>
<vertex x="4.01" y="1.17"/>
<vertex x="4.03" y="1.16"/>
<vertex x="4.06" y="1.16"/>
<vertex x="4.08" y="1.16"/>
<vertex x="4.13" y="1.17"/>
<vertex x="4.18" y="1.17"/>
<vertex x="4.22" y="1.19"/>
<vertex x="4.26" y="1.2"/>
<vertex x="4.29" y="1.22"/>
<vertex x="4.31" y="1.24"/>
<vertex x="4.33" y="1.27"/>
<vertex x="4.35" y="1.29"/>
<vertex x="4.36" y="1.32"/>
<vertex x="4.37" y="1.35"/>
<vertex x="4.38" y="1.37"/>
<vertex x="4.39" y="1.4"/>
<vertex x="4.39" y="1.43"/>
<vertex x="4.39" y="1.45"/>
<vertex x="4.39" y="1.47"/>
<vertex x="4.39" y="1.49"/>
<vertex x="4.39" y="1.5"/>
<vertex x="4.39" y="1.51"/>
<vertex x="4.39" y="1.52"/>
<vertex x="4.39" y="1.53"/>
<vertex x="4.39" y="1.54"/>
<vertex x="4.39" y="1.55"/>
<vertex x="4.39" y="1.56"/>
<vertex x="4.39" y="1.57"/>
<vertex x="4.39" y="1.58"/>
<vertex x="4.39" y="1.59"/>
<vertex x="4.39" y="1.6"/>
<vertex x="4.39" y="1.61"/>
<vertex x="4.39" y="1.62"/>
<vertex x="4.39" y="1.63"/>
<vertex x="4.38" y="1.62"/>
<vertex x="4.37" y="1.61"/>
<vertex x="4.35" y="1.61"/>
<vertex x="4.33" y="1.6"/>
<vertex x="4.31" y="1.59"/>
<vertex x="4.29" y="1.59"/>
<vertex x="4.27" y="1.58"/>
<vertex x="4.25" y="1.58"/>
<vertex x="4.25" y="1.8"/>
<vertex x="4.31" y="1.82"/>
<vertex x="4.36" y="1.85"/>
<vertex x="4.39" y="1.89"/>
<vertex x="4.39" y="1.94"/>
<vertex x="4.39" y="1.97"/>
<vertex x="4.39" y="2"/>
<vertex x="4.38" y="2.02"/>
<vertex x="4.37" y="2.04"/>
<vertex x="4.36" y="2.06"/>
<vertex x="4.35" y="2.07"/>
<vertex x="4.34" y="2.09"/>
<vertex x="4.32" y="2.1"/>
<vertex x="4.3" y="2.11"/>
<vertex x="4.28" y="2.12"/>
<vertex x="4.26" y="2.12"/>
<vertex x="4.24" y="2.13"/>
<vertex x="4.22" y="2.13"/>
<vertex x="4.19" y="2.13"/>
<vertex x="4.17" y="2.13"/>
<vertex x="4.14" y="2.13"/>
<vertex x="4.12" y="2.13"/>
<vertex x="4.09" y="2.13"/>
<vertex x="4.06" y="2.13"/>
<vertex x="4.04" y="2.12"/>
<vertex x="4.02" y="2.11"/>
<vertex x="4" y="2.1"/>
<vertex x="3.98" y="2.09"/>
<vertex x="3.96" y="2.08"/>
<vertex x="3.95" y="2.07"/>
<vertex x="3.93" y="2.05"/>
<vertex x="3.92" y="2.04"/>
<vertex x="3.91" y="2.02"/>
<vertex x="3.9" y="1.99"/>
<vertex x="3.89" y="1.97"/>
<vertex x="3.89" y="1.95"/>
<vertex x="3.89" y="1.92"/>
<vertex x="3.86" y="1.92"/>
<vertex x="3.84" y="1.92"/>
<vertex x="3.81" y="1.92"/>
<vertex x="3.79" y="1.92"/>
<vertex x="3.76" y="1.92"/>
<vertex x="3.74" y="1.92"/>
<vertex x="3.72" y="1.92"/>
<vertex x="3.69" y="1.92"/>
<vertex x="3.67" y="1.92"/>
<vertex x="3.64" y="1.92"/>
<vertex x="3.62" y="1.92"/>
<vertex x="3.59" y="1.92"/>
<vertex x="3.57" y="1.92"/>
<vertex x="3.55" y="1.92"/>
<vertex x="3.52" y="1.92"/>
<vertex x="3.5" y="1.92"/>
<vertex x="3.51" y="1.98"/>
<vertex x="3.52" y="2.04"/>
<vertex x="3.54" y="2.1"/>
<vertex x="3.57" y="2.14"/>
<vertex x="3.6" y="2.19"/>
<vertex x="3.63" y="2.23"/>
<vertex x="3.67" y="2.26"/>
<vertex x="3.72" y="2.29"/>
<vertex x="3.77" y="2.32"/>
<vertex x="3.82" y="2.34"/>
<vertex x="3.87" y="2.35"/>
<vertex x="3.93" y="2.37"/>
<vertex x="3.99" y="2.38"/>
<vertex x="4.04" y="2.39"/>
<vertex x="4.1" y="2.39"/>
<vertex x="4.16" y="2.39"/>
<vertex x="4.22" y="2.39"/>
<vertex x="4.27" y="2.39"/>
<vertex x="4.32" y="2.38"/>
<vertex x="4.38" y="2.38"/>
<vertex x="4.43" y="2.37"/>
<vertex x="4.48" y="2.35"/>
<vertex x="4.53" y="2.34"/>
<vertex x="4.58" y="2.32"/>
<vertex x="4.62" y="2.29"/>
<vertex x="4.66" y="2.26"/>
<vertex x="4.7" y="2.23"/>
<vertex x="4.73" y="2.19"/>
<vertex x="4.75" y="2.15"/>
<vertex x="4.77" y="2.1"/>
<vertex x="4.78" y="2.05"/>
<vertex x="4.78" y="1.99"/>
<vertex x="4.78" y="1.94"/>
<vertex x="4.78" y="1.9"/>
<vertex x="4.78" y="1.85"/>
<vertex x="4.78" y="1.8"/>
<vertex x="4.78" y="1.76"/>
<vertex x="4.78" y="1.71"/>
<vertex x="4.78" y="1.67"/>
<vertex x="4.78" y="1.62"/>
<vertex x="4.78" y="1.57"/>
<vertex x="4.78" y="1.53"/>
<vertex x="4.78" y="1.48"/>
<vertex x="4.78" y="1.44"/>
<vertex x="4.78" y="1.39"/>
<vertex x="4.78" y="1.34"/>
<vertex x="4.78" y="1.3"/>
<vertex x="4.78" y="1.25"/>
<vertex x="4.78" y="1.23"/>
<vertex x="4.78" y="1.2"/>
<vertex x="4.78" y="1.18"/>
<vertex x="4.79" y="1.16"/>
<vertex x="4.79" y="1.13"/>
<vertex x="4.79" y="1.11"/>
<vertex x="4.79" y="1.09"/>
<vertex x="4.79" y="1.07"/>
<vertex x="4.8" y="1.05"/>
<vertex x="4.8" y="1.03"/>
<vertex x="4.81" y="1.01"/>
<vertex x="4.81" y="0.99"/>
<vertex x="4.81" y="0.98"/>
<vertex x="4.82" y="0.96"/>
<vertex x="4.83" y="0.95"/>
<vertex x="4.83" y="0.94"/>
<vertex x="4.81" y="0.94"/>
<vertex x="4.78" y="0.94"/>
<vertex x="4.76" y="0.94"/>
<vertex x="4.73" y="0.94"/>
<vertex x="4.71" y="0.94"/>
<vertex x="4.68" y="0.94"/>
<vertex x="4.66" y="0.94"/>
<vertex x="4.64" y="0.94"/>
<vertex x="4.61" y="0.94"/>
<vertex x="4.59" y="0.94"/>
<vertex x="4.56" y="0.94"/>
<vertex x="4.54" y="0.94"/>
<vertex x="4.51" y="0.94"/>
<vertex x="4.49" y="0.94"/>
<vertex x="4.46" y="0.94"/>
<vertex x="4.44" y="0.94"/>
<vertex x="4.44" y="0.95"/>
<vertex x="4.43" y="0.96"/>
<vertex x="4.43" y="0.97"/>
<vertex x="4.42" y="0.98"/>
<vertex x="4.42" y="0.99"/>
<vertex x="4.42" y="1"/>
<vertex x="4.42" y="1.01"/>
<vertex x="4.41" y="1.02"/>
<vertex x="4.41" y="1.03"/>
<vertex x="4.41" y="1.04"/>
<vertex x="4.41" y="1.05"/>
<vertex x="4.41" y="1.06"/>
<vertex x="4.41" y="1.07"/>
<vertex x="4.41" y="1.08"/>
<vertex x="4.39" y="1.05"/>
<vertex x="4.36" y="1.03"/>
<vertex x="4.34" y="1.01"/>
<vertex x="4.31" y="0.99"/>
<vertex x="4.28" y="0.98"/>
<vertex x="4.25" y="0.96"/>
<vertex x="4.22" y="0.95"/>
<vertex x="4.19" y="0.94"/>
<vertex x="4.16" y="0.93"/>
<vertex x="4.13" y="0.92"/>
<vertex x="4.1" y="0.92"/>
<vertex x="4.07" y="0.91"/>
<vertex x="4.03" y="0.91"/>
<vertex x="4" y="0.9"/>
<vertex x="3.97" y="0.9"/>
<vertex x="3.94" y="0.9"/>
<vertex x="3.89" y="0.9"/>
<vertex x="3.84" y="0.91"/>
<vertex x="3.79" y="0.91"/>
<vertex x="3.75" y="0.92"/>
<vertex x="3.7" y="0.94"/>
<vertex x="3.66" y="0.96"/>
<vertex x="3.63" y="0.98"/>
<vertex x="3.59" y="1"/>
<vertex x="3.56" y="1.03"/>
<vertex x="3.54" y="1.06"/>
<vertex x="3.51" y="1.1"/>
<vertex x="3.49" y="1.13"/>
<vertex x="3.48" y="1.18"/>
<vertex x="3.46" y="1.22"/>
<vertex x="3.46" y="1.27"/>
<vertex x="3.45" y="1.32"/>
<vertex x="3.47" y="1.43"/>
<vertex x="3.5" y="1.52"/>
<vertex x="3.54" y="1.59"/>
<vertex x="3.61" y="1.65"/>
<vertex x="3.68" y="1.69"/>
<vertex x="3.76" y="1.72"/>
<vertex x="3.84" y="1.74"/>
</polygon>
<vertex x="5" y="2.29"/>
<vertex x="5.05" y="2.3"/>
<vertex x="5.09" y="2.31"/>
<vertex x="5.14" y="2.31"/>
<vertex x="5.19" y="2.32"/>
<vertex x="5.23" y="2.33"/>
<vertex x="5.28" y="2.34"/>
<vertex x="5.33" y="2.35"/>
<vertex x="5.37" y="2.36"/>
<vertex x="5.37" y="2.32"/>
<vertex x="5.37" y="2.29"/>
<vertex x="5.37" y="2.26"/>
<vertex x="5.37" y="2.22"/>
<vertex x="5.37" y="2.19"/>
<vertex x="5.37" y="2.16"/>
<vertex x="5.37" y="2.13"/>
<vertex x="5.37" y="2.09"/>
<vertex x="5.41" y="2.16"/>
<vertex x="5.45" y="2.21"/>
<vertex x="5.5" y="2.27"/>
<vertex x="5.55" y="2.31"/>
<vertex x="5.62" y="2.35"/>
<vertex x="5.68" y="2.37"/>
<vertex x="5.75" y="2.39"/>
<vertex x="5.83" y="2.39"/>
<vertex x="5.84" y="2.39"/>
<vertex x="5.85" y="2.39"/>
<vertex x="5.86" y="2.39"/>
<vertex x="5.87" y="2.39"/>
<vertex x="5.88" y="2.39"/>
<vertex x="5.89" y="2.39"/>
<vertex x="5.9" y="2.38"/>
<vertex x="5.91" y="2.38"/>
<vertex x="5.91" y="2.33"/>
<vertex x="5.91" y="2.29"/>
<vertex x="5.91" y="2.24"/>
<vertex x="5.91" y="2.2"/>
<vertex x="5.91" y="2.15"/>
<vertex x="5.91" y="2.11"/>
<vertex x="5.91" y="2.06"/>
<vertex x="5.91" y="2.02"/>
<vertex x="5.9" y="2.02"/>
<vertex x="5.88" y="2.03"/>
<vertex x="5.86" y="2.03"/>
<vertex x="5.84" y="2.03"/>
<vertex x="5.83" y="2.03"/>
<vertex x="5.81" y="2.03"/>
<vertex x="5.79" y="2.03"/>
<vertex x="5.77" y="2.03"/>
<vertex x="5.67" y="2.02"/>
<vertex x="5.59" y="2"/>
<vertex x="5.52" y="1.96"/>
<vertex x="5.47" y="1.9"/>
<vertex x="5.43" y="1.83"/>
<vertex x="5.41" y="1.76"/>
<vertex x="5.39" y="1.67"/>
<vertex x="5.39" y="1.58"/>
<vertex x="5.39" y="1.5"/>
<vertex x="5.39" y="1.42"/>
<vertex x="5.39" y="1.34"/>
<vertex x="5.39" y="1.26"/>
<vertex x="5.39" y="1.18"/>
<vertex x="5.39" y="1.1"/>
<vertex x="5.39" y="1.02"/>
<vertex x="5.39" y="0.94"/>
<vertex x="5.34" y="0.94"/>
<vertex x="5.29" y="0.94"/>
<vertex x="5.24" y="0.94"/>
<vertex x="5.19" y="0.94"/>
<vertex x="5.14" y="0.94"/>
<vertex x="5.1" y="0.94"/>
<vertex x="5.05" y="0.94"/>
<vertex x="5" y="0.94"/>
<vertex x="5" y="1.11"/>
<vertex x="5" y="1.28"/>
<vertex x="5" y="1.45"/>
<vertex x="5" y="1.62"/>
<vertex x="5" y="1.78"/>
<vertex x="5" y="1.95"/>
<vertex x="5" y="2.12"/>
</polygon>
<vertex x="6.06" y="2.68"/>
<vertex x="6.45" y="2.89"/>
<vertex x="6.45" y="1.85"/>
<vertex x="6.94" y="2.36"/>
<vertex x="7.4" y="2.36"/>
<vertex x="6.87" y="1.84"/>
<vertex x="7.46" y="0.94"/>
<vertex x="6.99" y="0.94"/>
<vertex x="6.6" y="1.57"/>
<vertex x="6.45" y="1.43"/>
<vertex x="6.45" y="0.94"/>
<vertex x="6.06" y="0.94"/>
</polygon>
<vertex x="7.7" y="2.1"/>
<vertex x="7.65" y="2.1"/>
<vertex x="7.6" y="2.1"/>
<vertex x="7.55" y="2.1"/>
<vertex x="7.51" y="2.1"/>
<vertex x="7.46" y="2.1"/>
<vertex x="7.41" y="2.1"/>
<vertex x="7.36" y="2.1"/>
<vertex x="7.31" y="2.1"/>
<vertex x="7.35" y="2.13"/>
<vertex x="7.38" y="2.16"/>
<vertex x="7.41" y="2.19"/>
<vertex x="7.45" y="2.23"/>
<vertex x="7.48" y="2.26"/>
<vertex x="7.51" y="2.29"/>
<vertex x="7.55" y="2.32"/>
<vertex x="7.58" y="2.36"/>
<vertex x="7.59" y="2.36"/>
<vertex x="7.61" y="2.36"/>
<vertex x="7.62" y="2.36"/>
<vertex x="7.64" y="2.36"/>
<vertex x="7.65" y="2.36"/>
<vertex x="7.67" y="2.36"/>
<vertex x="7.68" y="2.36"/>
<vertex x="7.7" y="2.36"/>
<vertex x="7.7" y="2.37"/>
<vertex x="7.7" y="2.38"/>
<vertex x="7.7" y="2.4"/>
<vertex x="7.7" y="2.41"/>
<vertex x="7.7" y="2.42"/>
<vertex x="7.7" y="2.44"/>
<vertex x="7.7" y="2.45"/>
<vertex x="7.7" y="2.46"/>
<vertex x="7.7" y="2.56"/>
<vertex x="7.73" y="2.64"/>
<vertex x="7.76" y="2.71"/>
<vertex x="7.81" y="2.77"/>
<vertex x="7.88" y="2.82"/>
<vertex x="7.96" y="2.86"/>
<vertex x="8.06" y="2.89"/>
<vertex x="8.17" y="2.89"/>
<vertex x="8.2" y="2.89"/>
<vertex x="8.22" y="2.89"/>
<vertex x="8.25" y="2.89"/>
<vertex x="8.27" y="2.89"/>
<vertex x="8.3" y="2.89"/>
<vertex x="8.32" y="2.89"/>
<vertex x="8.35" y="2.89"/>
<vertex x="8.37" y="2.88"/>
<vertex x="8.37" y="2.85"/>
<vertex x="8.37" y="2.81"/>
<vertex x="8.37" y="2.78"/>
<vertex x="8.37" y="2.74"/>
<vertex x="8.37" y="2.7"/>
<vertex x="8.37" y="2.67"/>
<vertex x="8.37" y="2.63"/>
<vertex x="8.37" y="2.6"/>
<vertex x="8.36" y="2.6"/>
<vertex x="8.34" y="2.6"/>
<vertex x="8.32" y="2.6"/>
<vertex x="8.3" y="2.6"/>
<vertex x="8.29" y="2.6"/>
<vertex x="8.27" y="2.6"/>
<vertex x="8.25" y="2.6"/>
<vertex x="8.23" y="2.6"/>
<vertex x="8.2" y="2.6"/>
<vertex x="8.16" y="2.59"/>
<vertex x="8.14" y="2.58"/>
<vertex x="8.12" y="2.57"/>
<vertex x="8.1" y="2.54"/>
<vertex x="8.09" y="2.52"/>
<vertex x="8.09" y="2.48"/>
<vertex x="8.08" y="2.44"/>
<vertex x="8.08" y="2.43"/>
<vertex x="8.08" y="2.42"/>
<vertex x="8.08" y="2.41"/>
<vertex x="8.08" y="2.4"/>
<vertex x="8.08" y="2.39"/>
<vertex x="8.08" y="2.38"/>
<vertex x="8.08" y="2.37"/>
<vertex x="8.08" y="2.36"/>
<vertex x="8.12" y="2.36"/>
<vertex x="8.15" y="2.36"/>
<vertex x="8.19" y="2.36"/>
<vertex x="8.22" y="2.36"/>
<vertex x="8.25" y="2.36"/>
<vertex x="8.29" y="2.36"/>
<vertex x="8.32" y="2.36"/>
<vertex x="8.35" y="2.36"/>
<vertex x="8.35" y="2.32"/>
<vertex x="8.35" y="2.29"/>
<vertex x="8.35" y="2.26"/>
<vertex x="8.35" y="2.23"/>
<vertex x="8.35" y="2.19"/>
<vertex x="8.35" y="2.16"/>
<vertex x="8.35" y="2.13"/>
<vertex x="8.35" y="2.1"/>
<vertex x="8.32" y="2.1"/>
<vertex x="8.29" y="2.1"/>
<vertex x="8.25" y="2.1"/>
<vertex x="8.22" y="2.1"/>
<vertex x="8.19" y="2.1"/>
<vertex x="8.15" y="2.1"/>
<vertex x="8.12" y="2.1"/>
<vertex x="8.08" y="2.1"/>
<vertex x="8.08" y="1.95"/>
<vertex x="8.08" y="1.81"/>
<vertex x="8.08" y="1.66"/>
<vertex x="8.08" y="1.52"/>
<vertex x="8.08" y="1.37"/>
<vertex x="8.08" y="1.23"/>
<vertex x="8.08" y="1.09"/>
<vertex x="8.08" y="0.94"/>
<vertex x="8.04" y="0.94"/>
<vertex x="7.99" y="0.94"/>
<vertex x="7.94" y="0.94"/>
<vertex x="7.89" y="0.94"/>
<vertex x="7.84" y="0.94"/>
<vertex x="7.79" y="0.94"/>
<vertex x="7.74" y="0.94"/>
<vertex x="7.7" y="0.94"/>
<vertex x="7.7" y="1.09"/>
<vertex x="7.7" y="1.23"/>
<vertex x="7.7" y="1.37"/>
<vertex x="7.7" y="1.52"/>
<vertex x="7.7" y="1.66"/>
<vertex x="7.7" y="1.81"/>
<vertex x="7.7" y="1.95"/>
</polygon>
<vertex x="9.79" y="0.94"/>
<vertex x="9.74" y="0.94"/>
<vertex x="9.7" y="0.94"/>
<vertex x="9.65" y="0.94"/>
<vertex x="9.6" y="0.94"/>
<vertex x="9.56" y="0.94"/>
<vertex x="9.51" y="0.94"/>
<vertex x="9.47" y="0.94"/>
<vertex x="9.42" y="0.94"/>
<vertex x="9.42" y="0.97"/>
<vertex x="9.42" y="0.99"/>
<vertex x="9.42" y="1.02"/>
<vertex x="9.42" y="1.04"/>
<vertex x="9.42" y="1.06"/>
<vertex x="9.42" y="1.09"/>
<vertex x="9.42" y="1.11"/>
<vertex x="9.42" y="1.14"/>
<vertex x="9.41" y="1.14"/>
<vertex x="9.37" y="1.08"/>
<vertex x="9.33" y="1.03"/>
<vertex x="9.28" y="0.99"/>
<vertex x="9.22" y="0.96"/>
<vertex x="9.17" y="0.94"/>
<vertex x="9.11" y="0.92"/>
<vertex x="9.04" y="0.91"/>
<vertex x="8.98" y="0.9"/>
<vertex x="8.84" y="0.91"/>
<vertex x="8.73" y="0.95"/>
<vertex x="8.64" y="1"/>
<vertex x="8.57" y="1.06"/>
<vertex x="8.52" y="1.15"/>
<vertex x="8.49" y="1.25"/>
<vertex x="8.47" y="1.36"/>
<vertex x="8.47" y="1.49"/>
<vertex x="8.47" y="1.59"/>
<vertex x="8.47" y="1.7"/>
<vertex x="8.47" y="1.81"/>
<vertex x="8.47" y="1.92"/>
<vertex x="8.47" y="2.03"/>
<vertex x="8.47" y="2.14"/>
<vertex x="8.47" y="2.25"/>
<vertex x="8.47" y="2.36"/>
<vertex x="8.51" y="2.36"/>
<vertex x="8.56" y="2.36"/>
<vertex x="8.61" y="2.36"/>
<vertex x="8.66" y="2.36"/>
<vertex x="8.71" y="2.36"/>
<vertex x="8.76" y="2.36"/>
<vertex x="8.81" y="2.36"/>
<vertex x="8.85" y="2.36"/>
<vertex x="8.85" y="2.26"/>
<vertex x="8.85" y="2.16"/>
<vertex x="8.85" y="2.06"/>
<vertex x="8.85" y="1.96"/>
<vertex x="8.85" y="1.86"/>
<vertex x="8.85" y="1.76"/>
<vertex x="8.85" y="1.66"/>
<vertex x="8.85" y="1.56"/>
<vertex x="8.86" y="1.48"/>
<vertex x="8.87" y="1.4"/>
<vertex x="8.88" y="1.34"/>
<vertex x="8.91" y="1.3"/>
<vertex x="8.94" y="1.26"/>
<vertex x="8.99" y="1.23"/>
<vertex x="9.04" y="1.22"/>
<vertex x="9.1" y="1.21"/>
<vertex x="9.18" y="1.22"/>
<vertex x="9.24" y="1.23"/>
<vertex x="9.29" y="1.26"/>
<vertex x="9.33" y="1.3"/>
<vertex x="9.36" y="1.36"/>
<vertex x="9.39" y="1.43"/>
<vertex x="9.4" y="1.51"/>
<vertex x="9.4" y="1.61"/>
<vertex x="9.4" y="1.71"/>
<vertex x="9.4" y="1.8"/>
<vertex x="9.4" y="1.89"/>
<vertex x="9.4" y="1.98"/>
<vertex x="9.4" y="2.08"/>
<vertex x="9.4" y="2.17"/>
<vertex x="9.4" y="2.26"/>
<vertex x="9.4" y="2.36"/>
<vertex x="9.45" y="2.36"/>
<vertex x="9.5" y="2.36"/>
<vertex x="9.55" y="2.36"/>
<vertex x="9.6" y="2.36"/>
<vertex x="9.65" y="2.36"/>
<vertex x="9.7" y="2.36"/>
<vertex x="9.74" y="2.36"/>
<vertex x="9.79" y="2.36"/>
<vertex x="9.79" y="2.18"/>
<vertex x="9.79" y="2"/>
<vertex x="9.79" y="1.83"/>
<vertex x="9.79" y="1.65"/>
<vertex x="9.79" y="1.47"/>
<vertex x="9.79" y="1.29"/>
<vertex x="9.79" y="1.12"/>
</polygon>
<vertex x="10" y="2.36"/>
<vertex x="10.05" y="2.36"/>
<vertex x="10.1" y="2.36"/>
<vertex x="10.14" y="2.36"/>
<vertex x="10.19" y="2.36"/>
<vertex x="10.23" y="2.36"/>
<vertex x="10.28" y="2.36"/>
<vertex x="10.33" y="2.36"/>
<vertex x="10.37" y="2.36"/>
<vertex x="10.37" y="2.33"/>
<vertex x="10.37" y="2.31"/>
<vertex x="10.37" y="2.28"/>
<vertex x="10.37" y="2.26"/>
<vertex x="10.37" y="2.23"/>
<vertex x="10.37" y="2.21"/>
<vertex x="10.37" y="2.18"/>
<vertex x="10.37" y="2.16"/>
<vertex x="10.38" y="2.16"/>
<vertex x="10.42" y="2.22"/>
<vertex x="10.46" y="2.26"/>
<vertex x="10.51" y="2.3"/>
<vertex x="10.57" y="2.34"/>
<vertex x="10.63" y="2.36"/>
<vertex x="10.69" y="2.38"/>
<vertex x="10.75" y="2.39"/>
<vertex x="10.81" y="2.39"/>
<vertex x="10.95" y="2.38"/>
<vertex x="11.06" y="2.35"/>
<vertex x="11.15" y="2.3"/>
<vertex x="11.22" y="2.23"/>
<vertex x="11.27" y="2.15"/>
<vertex x="11.3" y="2.05"/>
<vertex x="11.32" y="1.94"/>
<vertex x="11.33" y="1.81"/>
<vertex x="11.33" y="1.7"/>
<vertex x="11.33" y="1.59"/>
<vertex x="11.33" y="1.49"/>
<vertex x="11.33" y="1.38"/>
<vertex x="11.33" y="1.27"/>
<vertex x="11.33" y="1.16"/>
<vertex x="11.33" y="1.05"/>
<vertex x="11.33" y="0.94"/>
<vertex x="11.28" y="0.94"/>
<vertex x="11.23" y="0.94"/>
<vertex x="11.18" y="0.94"/>
<vertex x="11.13" y="0.94"/>
<vertex x="11.08" y="0.94"/>
<vertex x="11.03" y="0.94"/>
<vertex x="10.99" y="0.94"/>
<vertex x="10.94" y="0.94"/>
<vertex x="10.94" y="1.04"/>
<vertex x="10.94" y="1.14"/>
<vertex x="10.94" y="1.24"/>
<vertex x="10.94" y="1.34"/>
<vertex x="10.94" y="1.44"/>
<vertex x="10.94" y="1.54"/>
<vertex x="10.94" y="1.64"/>
<vertex x="10.94" y="1.74"/>
<vertex x="10.93" y="1.82"/>
<vertex x="10.92" y="1.89"/>
<vertex x="10.91" y="1.95"/>
<vertex x="10.88" y="2"/>
<vertex x="10.85" y="2.04"/>
<vertex x="10.8" y="2.07"/>
<vertex x="10.75" y="2.08"/>
<vertex x="10.69" y="2.09"/>
<vertex x="10.61" y="2.08"/>
<vertex x="10.55" y="2.07"/>
<vertex x="10.5" y="2.04"/>
<vertex x="10.46" y="1.99"/>
<vertex x="10.43" y="1.94"/>
<vertex x="10.4" y="1.87"/>
<vertex x="10.39" y="1.78"/>
<vertex x="10.39" y="1.68"/>
<vertex x="10.39" y="1.59"/>
<vertex x="10.39" y="1.5"/>
<vertex x="10.39" y="1.41"/>
<vertex x="10.39" y="1.31"/>
<vertex x="10.39" y="1.22"/>
<vertex x="10.39" y="1.13"/>
<vertex x="10.39" y="1.03"/>
<vertex x="10.39" y="0.94"/>
<vertex x="10.34" y="0.94"/>
<vertex x="10.29" y="0.94"/>
<vertex x="10.24" y="0.94"/>
<vertex x="10.19" y="0.94"/>
<vertex x="10.14" y="0.94"/>
<vertex x="10.1" y="0.94"/>
<vertex x="10.05" y="0.94"/>
<vertex x="10" y="0.94"/>
<vertex x="10" y="1.12"/>
<vertex x="10" y="1.3"/>
<vertex x="10" y="1.47"/>
<vertex x="10" y="1.65"/>
<vertex x="10" y="1.83"/>
<vertex x="10" y="2"/>
<vertex x="10" y="2.18"/>
</polygon>
<vertex x="8.25" y="4.78"/>
<vertex x="8.25" y="4.76"/>
<vertex x="8.25" y="4.73"/>
<vertex x="8.25" y="4.7"/>
<vertex x="8.24" y="4.67"/>
<vertex x="8.23" y="4.64"/>
<vertex x="8.2" y="4.62"/>
<vertex x="8.17" y="4.61"/>
<vertex x="8.14" y="4.61"/>
<vertex x="8.1" y="4.61"/>
<vertex x="8.06" y="4.63"/>
<vertex x="8.02" y="4.65"/>
<vertex x="7.99" y="4.67"/>
<vertex x="7.95" y="4.7"/>
<vertex x="7.92" y="4.72"/>
<vertex x="7.89" y="4.75"/>
<vertex x="7.87" y="4.79"/>
<vertex x="7.85" y="4.82"/>
<vertex x="7.84" y="4.86"/>
<vertex x="7.83" y="4.89"/>
<vertex x="7.84" y="4.92"/>
<vertex x="7.85" y="4.94"/>
<vertex x="7.86" y="4.97"/>
<vertex x="7.88" y="5"/>
<vertex x="7.92" y="5.03"/>
<vertex x="7.96" y="5.05"/>
<vertex x="8.01" y="5.06"/>
<vertex x="8.05" y="5.07"/>
<vertex x="8.08" y="5.07"/>
<vertex x="8.11" y="5.06"/>
<vertex x="8.13" y="5.06"/>
<vertex x="8.14" y="5.06"/>
<vertex x="8.13" y="5.07"/>
<vertex x="8.09" y="5.1"/>
<vertex x="8.03" y="5.13"/>
<vertex x="7.95" y="5.16"/>
<vertex x="7.86" y="5.19"/>
<vertex x="7.76" y="5.19"/>
<vertex x="7.65" y="5.17"/>
<vertex x="7.54" y="5.11"/>
<vertex x="7.45" y="5.03"/>
<vertex x="7.4" y="4.96"/>
<vertex x="7.37" y="4.87"/>
<vertex x="7.37" y="4.79"/>
<vertex x="7.39" y="4.7"/>
<vertex x="7.44" y="4.61"/>
<vertex x="7.51" y="4.53"/>
<vertex x="7.59" y="4.44"/>
<vertex x="7.66" y="4.36"/>
<vertex x="7.69" y="4.29"/>
<vertex x="7.69" y="4.22"/>
<vertex x="7.67" y="4.16"/>
<vertex x="7.63" y="4.11"/>
<vertex x="7.57" y="4.07"/>
<vertex x="7.49" y="4.05"/>
<vertex x="7.41" y="4.05"/>
<vertex x="7.36" y="4.06"/>
<vertex x="7.31" y="4.08"/>
<vertex x="7.28" y="4.1"/>
<vertex x="7.25" y="4.13"/>
<vertex x="7.23" y="4.17"/>
<vertex x="7.22" y="4.2"/>
<vertex x="7.22" y="4.23"/>
<vertex x="7.23" y="4.26"/>
<vertex x="7.25" y="4.29"/>
<vertex x="7.27" y="4.31"/>
<vertex x="7.29" y="4.33"/>
<vertex x="7.32" y="4.34"/>
<vertex x="7.34" y="4.35"/>
<vertex x="7.36" y="4.36"/>
<vertex x="7.37" y="4.37"/>
<vertex x="7.35" y="4.38"/>
<vertex x="7.33" y="4.38"/>
<vertex x="7.29" y="4.39"/>
<vertex x="7.25" y="4.39"/>
<vertex x="7.21" y="4.39"/>
<vertex x="7.15" y="4.38"/>
<vertex x="7.1" y="4.36"/>
<vertex x="7.05" y="4.34"/>
<vertex x="7.01" y="4.31"/>
<vertex x="6.96" y="4.28"/>
<vertex x="6.93" y="4.23"/>
<vertex x="6.9" y="4.17"/>
<vertex x="6.88" y="4.11"/>
<vertex x="6.87" y="4.02"/>
<vertex x="6.86" y="3.93"/>
<vertex x="6.86" y="3.77"/>
<vertex x="6.86" y="3.61"/>
<vertex x="6.86" y="3.45"/>
<vertex x="6.86" y="3.29"/>
<vertex x="6.86" y="3.13"/>
<vertex x="6.86" y="2.97"/>
<vertex x="6.86" y="2.81"/>
<vertex x="6.86" y="2.65"/>
<vertex x="6.87" y="2.65"/>
<vertex x="6.89" y="2.68"/>
<vertex x="6.92" y="2.71"/>
<vertex x="6.95" y="2.75"/>
<vertex x="7" y="2.8"/>
<vertex x="7.05" y="2.86"/>
<vertex x="7.11" y="2.92"/>
<vertex x="7.16" y="2.99"/>
<vertex x="7.23" y="3.06"/>
<vertex x="7.29" y="3.12"/>
<vertex x="7.34" y="3.18"/>
<vertex x="7.39" y="3.22"/>
<vertex x="7.44" y="3.26"/>
<vertex x="7.49" y="3.29"/>
<vertex x="7.55" y="3.3"/>
<vertex x="7.62" y="3.3"/>
<vertex x="7.74" y="3.3"/>
<vertex x="7.86" y="3.32"/>
<vertex x="7.97" y="3.35"/>
<vertex x="8.07" y="3.39"/>
<vertex x="8.17" y="3.45"/>
<vertex x="8.25" y="3.52"/>
<vertex x="8.33" y="3.6"/>
<vertex x="8.4" y="3.69"/>
<vertex x="8.5" y="3.87"/>
<vertex x="8.55" y="4.05"/>
<vertex x="8.56" y="4.23"/>
<vertex x="8.53" y="4.39"/>
<vertex x="8.48" y="4.53"/>
<vertex x="8.41" y="4.65"/>
<vertex x="8.33" y="4.74"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.2">
<vertex x="1.45" y="2.7"/>
<vertex x="1.46" y="2.59"/>
<vertex x="1.5" y="2.49"/>
<vertex x="1.56" y="2.41"/>
<vertex x="1.64" y="2.34"/>
<vertex x="1.73" y="2.29"/>
<vertex x="1.83" y="2.26"/>
<vertex x="1.93" y="2.24"/>
<vertex x="2.05" y="2.23"/>
<vertex x="2.13" y="2.23"/>
<vertex x="2.22" y="2.25"/>
<vertex x="2.3" y="2.27"/>
<vertex x="2.38" y="2.31"/>
<vertex x="2.45" y="2.35"/>
<vertex x="2.51" y="2.42"/>
<vertex x="2.54" y="2.5"/>
<vertex x="2.56" y="2.59"/>
<vertex x="2.54" y="2.67"/>
<vertex x="2.5" y="2.74"/>
<vertex x="2.42" y="2.8"/>
<vertex x="2.32" y="2.85"/>
<vertex x="2.2" y="2.9"/>
<vertex x="2.05" y="2.94"/>
<vertex x="1.87" y="2.98"/>
<vertex x="1.67" y="3.03"/>
<vertex x="1.51" y="3.07"/>
<vertex x="1.34" y="3.12"/>
<vertex x="1.19" y="3.18"/>
<vertex x="1.06" y="3.25"/>
<vertex x="0.94" y="3.35"/>
<vertex x="0.85" y="3.47"/>
<vertex x="0.8" y="3.61"/>
<vertex x="0.78" y="3.78"/>
<vertex x="0.81" y="4.03"/>
<vertex x="0.88" y="4.23"/>
<vertex x="1.01" y="4.39"/>
<vertex x="1.17" y="4.51"/>
<vertex x="1.35" y="4.59"/>
<vertex x="1.56" y="4.65"/>
<vertex x="1.78" y="4.68"/>
<vertex x="2.01" y="4.69"/>
<vertex x="2.24" y="4.68"/>
<vertex x="2.45" y="4.65"/>
<vertex x="2.66" y="4.59"/>
<vertex x="2.84" y="4.5"/>
<vertex x="3" y="4.38"/>
<vertex x="3.12" y="4.22"/>
<vertex x="3.21" y="4.03"/>
<vertex x="3.26" y="3.79"/>
<vertex x="3.16" y="3.79"/>
<vertex x="3.07" y="3.79"/>
<vertex x="2.98" y="3.79"/>
<vertex x="2.89" y="3.79"/>
<vertex x="2.79" y="3.79"/>
<vertex x="2.7" y="3.79"/>
<vertex x="2.61" y="3.79"/>
<vertex x="2.52" y="3.79"/>
<vertex x="2.5" y="3.89"/>
<vertex x="2.46" y="3.97"/>
<vertex x="2.41" y="4.04"/>
<vertex x="2.35" y="4.09"/>
<vertex x="2.27" y="4.13"/>
<vertex x="2.18" y="4.15"/>
<vertex x="2.09" y="4.17"/>
<vertex x="1.99" y="4.17"/>
<vertex x="1.92" y="4.17"/>
<vertex x="1.84" y="4.16"/>
<vertex x="1.77" y="4.15"/>
<vertex x="1.7" y="4.13"/>
<vertex x="1.64" y="4.09"/>
<vertex x="1.6" y="4.05"/>
<vertex x="1.57" y="3.99"/>
<vertex x="1.55" y="3.91"/>
<vertex x="1.57" y="3.81"/>
<vertex x="1.63" y="3.74"/>
<vertex x="1.72" y="3.68"/>
<vertex x="1.83" y="3.63"/>
<vertex x="1.96" y="3.59"/>
<vertex x="2.11" y="3.56"/>
<vertex x="2.27" y="3.52"/>
<vertex x="2.44" y="3.49"/>
<vertex x="2.6" y="3.44"/>
<vertex x="2.77" y="3.39"/>
<vertex x="2.92" y="3.33"/>
<vertex x="3.05" y="3.25"/>
<vertex x="3.17" y="3.15"/>
<vertex x="3.26" y="3.02"/>
<vertex x="3.31" y="2.87"/>
<vertex x="3.33" y="2.69"/>
<vertex x="3.3" y="2.44"/>
<vertex x="3.22" y="2.23"/>
<vertex x="3.09" y="2.06"/>
<vertex x="2.93" y="1.92"/>
<vertex x="2.73" y="1.82"/>
<vertex x="2.51" y="1.76"/>
<vertex x="2.28" y="1.72"/>
<vertex x="2.04" y="1.71"/>
<vertex x="1.8" y="1.72"/>
<vertex x="1.56" y="1.76"/>
<vertex x="1.34" y="1.83"/>
<vertex x="1.14" y="1.93"/>
<vertex x="0.97" y="2.06"/>
<vertex x="0.84" y="2.23"/>
<vertex x="0.75" y="2.45"/>
<vertex x="0.71" y="2.7"/>
<vertex x="0.8" y="2.7"/>
<vertex x="0.9" y="2.7"/>
<vertex x="0.99" y="2.7"/>
<vertex x="1.08" y="2.7"/>
<vertex x="1.17" y="2.7"/>
<vertex x="1.27" y="2.7"/>
<vertex x="1.36" y="2.7"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="5.66" y="2.71"/>
<vertex x="5.71" y="2.86"/>
<vertex x="5.73" y="3.02"/>
<vertex x="5.74" y="3.19"/>
<vertex x="6.52" y="3.17"/>
<vertex x="6.5" y="2.89"/>
<vertex x="6.44" y="2.62"/>
<vertex x="6.35" y="2.38"/>
</polygon>
<vertex x="6.21" y="2.16"/>
<vertex x="6.04" y="1.97"/>
<vertex x="5.82" y="1.83"/>
<vertex x="5.57" y="1.74"/>
<vertex x="5.28" y="1.71"/>
<vertex x="5.15" y="1.72"/>
<vertex x="5.03" y="1.74"/>
<vertex x="4.91" y="1.77"/>
<vertex x="4.8" y="1.82"/>
<vertex x="4.69" y="1.88"/>
<vertex x="4.59" y="1.95"/>
<vertex x="4.51" y="2.04"/>
<vertex x="4.43" y="2.14"/>
<vertex x="4.43" y="1.88"/>
<vertex x="4.43" y="1.63"/>
<vertex x="4.43" y="1.37"/>
<vertex x="4.43" y="1.12"/>
<vertex x="4.43" y="0.86"/>
<vertex x="4.43" y="0.61"/>
<vertex x="4.43" y="0.35"/>
<vertex x="4.43" y="0.1"/>
<vertex x="4.33" y="0.19"/>
<vertex x="4.23" y="0.27"/>
<vertex x="4.13" y="0.36"/>
<vertex x="4.04" y="0.45"/>
<vertex x="3.94" y="0.53"/>
<vertex x="3.84" y="0.62"/>
<vertex x="3.75" y="0.7"/>
<vertex x="3.65" y="0.79"/>
<vertex x="3.65" y="1.25"/>
<vertex x="3.65" y="1.71"/>
<vertex x="3.65" y="2.18"/>
<vertex x="3.65" y="2.64"/>
<vertex x="3.65" y="3.1"/>
<vertex x="3.65" y="3.56"/>
<vertex x="3.65" y="4.02"/>
<vertex x="3.65" y="4.48"/>
<vertex x="3.74" y="4.5"/>
<vertex x="3.83" y="4.52"/>
<vertex x="3.93" y="4.53"/>
<vertex x="4.02" y="4.55"/>
<vertex x="4.11" y="4.56"/>
<vertex x="4.2" y="4.58"/>
<vertex x="4.3" y="4.6"/>
<vertex x="4.39" y="4.61"/>
<vertex x="4.39" y="4.57"/>
<vertex x="4.39" y="4.52"/>
<vertex x="4.39" y="4.48"/>
<vertex x="4.39" y="4.43"/>
<vertex x="4.39" y="4.39"/>
<vertex x="4.39" y="4.34"/>
<vertex x="4.39" y="4.3"/>
<vertex x="4.39" y="4.25"/>
<vertex x="4.47" y="4.36"/>
<vertex x="4.56" y="4.45"/>
<vertex x="4.65" y="4.53"/>
<vertex x="4.75" y="4.59"/>
<vertex x="4.86" y="4.63"/>
<vertex x="4.98" y="4.67"/>
<vertex x="5.11" y="4.68"/>
<vertex x="5.23" y="4.69"/>
<vertex x="5.54" y="4.66"/>
<vertex x="5.81" y="4.57"/>
<vertex x="6.03" y="4.42"/>
<vertex x="6.21" y="4.23"/>
<vertex x="6.35" y="4"/>
<vertex x="6.44" y="3.75"/>
<vertex x="6.5" y="3.47"/>
<vertex x="5.73" y="3.36"/>
<vertex x="5.71" y="3.53"/>
<vertex x="5.66" y="3.68"/>
<vertex x="5.59" y="3.82"/>
<vertex x="5.5" y="3.94"/>
<vertex x="5.38" y="4.03"/>
<vertex x="5.24" y="4.08"/>
<vertex x="5.06" y="4.1"/>
<vertex x="4.89" y="4.08"/>
<vertex x="4.74" y="4.03"/>
<vertex x="4.63" y="3.94"/>
<vertex x="4.54" y="3.82"/>
<vertex x="4.47" y="3.68"/>
<vertex x="4.43" y="3.53"/>
<vertex x="4.4" y="3.36"/>
<vertex x="4.39" y="3.19"/>
<vertex x="4.4" y="3.02"/>
<vertex x="4.43" y="2.86"/>
<vertex x="4.47" y="2.71"/>
<vertex x="4.54" y="2.57"/>
<vertex x="4.63" y="2.46"/>
<vertex x="4.75" y="2.37"/>
<vertex x="4.9" y="2.31"/>
<vertex x="5.07" y="2.29"/>
<vertex x="5.25" y="2.31"/>
<vertex x="5.39" y="2.37"/>
<vertex x="5.51" y="2.46"/>
<vertex x="5.6" y="2.57"/>
</polygon>
<vertex x="7.7" y="3.41"/>
<vertex x="7.88" y="3.43"/>
<vertex x="8.05" y="3.45"/>
<vertex x="8.21" y="3.47"/>
<vertex x="8.3" y="3.05"/>
<vertex x="8.25" y="3.05"/>
<vertex x="8.21" y="3.04"/>
<vertex x="8.16" y="3.03"/>
<vertex x="8.12" y="3.03"/>
<vertex x="8.07" y="3.02"/>
<vertex x="8.02" y="3.01"/>
<vertex x="7.98" y="3"/>
<vertex x="7.93" y="2.99"/>
<vertex x="7.89" y="2.98"/>
<vertex x="7.85" y="2.97"/>
</polygon>
<vertex x="7.81" y="2.96"/>
<vertex x="7.77" y="2.94"/>
<vertex x="7.73" y="2.93"/>
<vertex x="7.69" y="2.91"/>
<vertex x="7.66" y="2.89"/>
<vertex x="7.63" y="2.86"/>
<vertex x="7.6" y="2.83"/>
<vertex x="7.58" y="2.8"/>
<vertex x="7.56" y="2.77"/>
<vertex x="7.54" y="2.73"/>
<vertex x="7.53" y="2.69"/>
<vertex x="7.52" y="2.64"/>
<vertex x="7.52" y="2.59"/>
<vertex x="7.52" y="2.54"/>
<vertex x="7.53" y="2.49"/>
<vertex x="7.54" y="2.45"/>
<vertex x="7.56" y="2.41"/>
<vertex x="7.58" y="2.38"/>
<vertex x="7.6" y="2.35"/>
<vertex x="7.63" y="2.32"/>
<vertex x="7.66" y="2.3"/>
<vertex x="7.7" y="2.28"/>
<vertex x="7.73" y="2.27"/>
<vertex x="7.77" y="2.25"/>
<vertex x="7.81" y="2.24"/>
<vertex x="7.86" y="2.23"/>
<vertex x="7.9" y="2.23"/>
<vertex x="7.95" y="2.23"/>
<vertex x="8" y="2.23"/>
<vertex x="8.1" y="2.23"/>
<vertex x="8.2" y="2.25"/>
<vertex x="8.28" y="2.27"/>
<vertex x="8.35" y="2.31"/>
<vertex x="8.41" y="2.34"/>
<vertex x="8.46" y="2.39"/>
<vertex x="8.5" y="2.44"/>
<vertex x="8.54" y="2.49"/>
<vertex x="8.56" y="2.54"/>
<vertex x="8.59" y="2.6"/>
<vertex x="8.6" y="2.65"/>
<vertex x="8.61" y="2.7"/>
<vertex x="8.62" y="2.75"/>
<vertex x="8.62" y="2.8"/>
<vertex x="8.62" y="2.84"/>
<vertex x="8.62" y="2.88"/>
<vertex x="8.62" y="2.9"/>
<vertex x="8.62" y="2.91"/>
<vertex x="8.62" y="2.93"/>
<vertex x="8.62" y="2.95"/>
<vertex x="8.62" y="2.97"/>
<vertex x="8.62" y="2.99"/>
<vertex x="8.62" y="3.01"/>
<vertex x="8.62" y="3.02"/>
<vertex x="8.62" y="3.04"/>
<vertex x="8.62" y="3.06"/>
<vertex x="8.62" y="3.08"/>
<vertex x="8.62" y="3.1"/>
<vertex x="8.62" y="3.11"/>
<vertex x="8.62" y="3.13"/>
<vertex x="8.62" y="3.15"/>
<vertex x="8.62" y="3.17"/>
<vertex x="8.6" y="3.15"/>
<vertex x="8.57" y="3.13"/>
<vertex x="8.54" y="3.11"/>
<vertex x="8.5" y="3.1"/>
<vertex x="8.46" y="3.09"/>
<vertex x="8.43" y="3.08"/>
<vertex x="8.38" y="3.07"/>
<vertex x="8.34" y="3.06"/>
<vertex x="8.34" y="3.51"/>
<vertex x="8.46" y="3.55"/>
<vertex x="8.55" y="3.6"/>
<vertex x="8.61" y="3.68"/>
<vertex x="8.62" y="3.78"/>
<vertex x="8.62" y="3.84"/>
<vertex x="8.61" y="3.9"/>
<vertex x="8.6" y="3.94"/>
<vertex x="8.58" y="3.98"/>
<vertex x="8.56" y="4.02"/>
<vertex x="8.54" y="4.05"/>
<vertex x="8.51" y="4.08"/>
<vertex x="8.48" y="4.1"/>
<vertex x="8.44" y="4.12"/>
<vertex x="8.4" y="4.13"/>
<vertex x="8.36" y="4.15"/>
<vertex x="8.32" y="4.15"/>
<vertex x="8.27" y="4.16"/>
<vertex x="8.22" y="4.17"/>
<vertex x="8.17" y="4.17"/>
<vertex x="8.12" y="4.17"/>
<vertex x="8.07" y="4.17"/>
<vertex x="8.01" y="4.16"/>
<vertex x="7.96" y="4.15"/>
<vertex x="7.92" y="4.14"/>
<vertex x="7.87" y="4.13"/>
<vertex x="7.83" y="4.11"/>
<vertex x="7.8" y="4.09"/>
<vertex x="7.76" y="4.07"/>
<vertex x="7.73" y="4.04"/>
<vertex x="7.7" y="4.01"/>
<vertex x="7.68" y="3.97"/>
<vertex x="7.66" y="3.93"/>
<vertex x="7.64" y="3.89"/>
<vertex x="7.63" y="3.84"/>
<vertex x="7.61" y="3.79"/>
<vertex x="7.61" y="3.74"/>
<vertex x="7.56" y="3.74"/>
<vertex x="7.51" y="3.74"/>
<vertex x="7.46" y="3.74"/>
<vertex x="7.41" y="3.74"/>
<vertex x="7.37" y="3.74"/>
<vertex x="7.32" y="3.74"/>
<vertex x="7.27" y="3.74"/>
<vertex x="7.22" y="3.74"/>
<vertex x="7.17" y="3.74"/>
<vertex x="7.12" y="3.74"/>
<vertex x="7.07" y="3.74"/>
<vertex x="7.03" y="3.74"/>
<vertex x="6.98" y="3.74"/>
<vertex x="6.93" y="3.74"/>
<vertex x="6.88" y="3.74"/>
<vertex x="6.83" y="3.74"/>
<vertex x="6.85" y="3.87"/>
<vertex x="6.88" y="3.99"/>
<vertex x="6.92" y="4.09"/>
<vertex x="6.97" y="4.19"/>
<vertex x="7.03" y="4.28"/>
<vertex x="7.19" y="4.42"/>
<vertex x="7.28" y="4.48"/>
<vertex x="7.37" y="4.53"/>
<vertex x="7.47" y="4.58"/>
<vertex x="7.58" y="4.61"/>
<vertex x="7.69" y="4.64"/>
<vertex x="7.81" y="4.66"/>
<vertex x="7.92" y="4.67"/>
<vertex x="8.04" y="4.68"/>
<vertex x="8.16" y="4.68"/>
<vertex x="8.27" y="4.68"/>
<vertex x="8.38" y="4.68"/>
<vertex x="8.48" y="4.67"/>
<vertex x="8.59" y="4.65"/>
<vertex x="8.7" y="4.63"/>
<vertex x="8.8" y="4.61"/>
<vertex x="8.9" y="4.58"/>
<vertex x="8.99" y="4.54"/>
<vertex x="9.08" y="4.49"/>
<vertex x="9.16" y="4.43"/>
<vertex x="9.23" y="4.37"/>
<vertex x="9.29" y="4.29"/>
<vertex x="9.34" y="4.21"/>
<vertex x="9.37" y="4.11"/>
<vertex x="9.4" y="4"/>
<vertex x="9.4" y="3.88"/>
<vertex x="9.4" y="3.79"/>
<vertex x="9.4" y="3.7"/>
<vertex x="9.4" y="3.6"/>
<vertex x="9.4" y="3.51"/>
<vertex x="9.4" y="3.42"/>
<vertex x="9.4" y="3.33"/>
<vertex x="9.4" y="3.24"/>
<vertex x="9.4" y="3.14"/>
<vertex x="9.4" y="3.05"/>
<vertex x="9.4" y="2.96"/>
<vertex x="9.4" y="2.87"/>
<vertex x="9.4" y="2.78"/>
<vertex x="9.4" y="2.68"/>
<vertex x="9.4" y="2.59"/>
<vertex x="9.4" y="2.5"/>
<vertex x="9.4" y="2.41"/>
<vertex x="9.4" y="2.31"/>
<vertex x="9.41" y="2.26"/>
<vertex x="9.41" y="2.22"/>
<vertex x="9.41" y="2.17"/>
<vertex x="9.41" y="2.13"/>
<vertex x="9.42" y="2.08"/>
<vertex x="9.42" y="2.04"/>
<vertex x="9.43" y="2"/>
<vertex x="9.44" y="1.96"/>
<vertex x="9.45" y="1.92"/>
<vertex x="9.45" y="1.89"/>
<vertex x="9.46" y="1.86"/>
<vertex x="9.48" y="1.83"/>
<vertex x="9.49" y="1.8"/>
<vertex x="9.5" y="1.78"/>
<vertex x="9.45" y="1.78"/>
<vertex x="9.4" y="1.78"/>
<vertex x="9.35" y="1.78"/>
<vertex x="9.3" y="1.78"/>
<vertex x="9.25" y="1.78"/>
<vertex x="9.2" y="1.78"/>
<vertex x="9.16" y="1.78"/>
<vertex x="9.11" y="1.78"/>
<vertex x="9.06" y="1.78"/>
<vertex x="9.01" y="1.78"/>
<vertex x="8.96" y="1.78"/>
<vertex x="8.91" y="1.78"/>
<vertex x="8.86" y="1.78"/>
<vertex x="8.81" y="1.78"/>
<vertex x="8.76" y="1.78"/>
<vertex x="8.71" y="1.78"/>
<vertex x="8.71" y="1.8"/>
<vertex x="8.7" y="1.81"/>
<vertex x="8.7" y="1.83"/>
<vertex x="8.69" y="1.85"/>
<vertex x="8.68" y="1.86"/>
<vertex x="8.68" y="1.88"/>
<vertex x="8.68" y="1.9"/>
<vertex x="8.67" y="1.91"/>
<vertex x="8.67" y="1.93"/>
<vertex x="8.67" y="1.95"/>
<vertex x="8.66" y="1.97"/>
<vertex x="8.66" y="1.98"/>
<vertex x="8.66" y="2"/>
<vertex x="8.66" y="2.02"/>
<vertex x="8.66" y="2.04"/>
<vertex x="8.66" y="2.05"/>
<vertex x="8.61" y="2.01"/>
<vertex x="8.56" y="1.96"/>
<vertex x="8.51" y="1.92"/>
<vertex x="8.46" y="1.89"/>
<vertex x="8.4" y="1.86"/>
<vertex x="8.34" y="1.83"/>
<vertex x="8.28" y="1.8"/>
<vertex x="8.22" y="1.78"/>
<vertex x="8.16" y="1.76"/>
<vertex x="8.1" y="1.75"/>
<vertex x="8.03" y="1.73"/>
<vertex x="7.97" y="1.72"/>
<vertex x="7.9" y="1.71"/>
<vertex x="7.84" y="1.71"/>
<vertex x="7.77" y="1.7"/>
<vertex x="7.71" y="1.7"/>
<vertex x="7.61" y="1.7"/>
<vertex x="7.51" y="1.71"/>
<vertex x="7.42" y="1.73"/>
<vertex x="7.33" y="1.75"/>
<vertex x="7.24" y="1.78"/>
<vertex x="7.16" y="1.82"/>
<vertex x="7.09" y="1.86"/>
<vertex x="7.02" y="1.91"/>
<vertex x="6.96" y="1.96"/>
<vertex x="6.91" y="2.03"/>
<vertex x="6.86" y="2.09"/>
<vertex x="6.82" y="2.17"/>
<vertex x="6.79" y="2.25"/>
<vertex x="6.76" y="2.35"/>
<vertex x="6.75" y="2.44"/>
<vertex x="6.74" y="2.55"/>
<vertex x="6.77" y="2.77"/>
<vertex x="6.83" y="2.94"/>
<vertex x="6.92" y="3.08"/>
<vertex x="7.05" y="3.19"/>
<vertex x="7.19" y="3.28"/>
<vertex x="7.35" y="3.34"/>
<vertex x="7.52" y="3.38"/>
</polygon>
<vertex x="9.84" y="4.48"/>
<vertex x="9.93" y="4.5"/>
<vertex x="10.03" y="4.51"/>
<vertex x="10.12" y="4.53"/>
<vertex x="10.21" y="4.55"/>
<vertex x="10.3" y="4.56"/>
<vertex x="10.39" y="4.58"/>
<vertex x="10.49" y="4.6"/>
<vertex x="10.58" y="4.61"/>
<vertex x="10.58" y="4.55"/>
<vertex x="10.58" y="4.48"/>
<vertex x="10.58" y="4.42"/>
<vertex x="10.58" y="4.35"/>
<vertex x="10.58" y="4.28"/>
<vertex x="10.58" y="4.22"/>
<vertex x="10.58" y="4.15"/>
<vertex x="10.58" y="4.09"/>
<vertex x="10.65" y="4.22"/>
<vertex x="10.73" y="4.33"/>
<vertex x="10.83" y="4.43"/>
<vertex x="10.95" y="4.52"/>
<vertex x="11.07" y="4.59"/>
<vertex x="11.2" y="4.65"/>
<vertex x="11.34" y="4.68"/>
<vertex x="11.49" y="4.69"/>
<vertex x="11.51" y="4.69"/>
<vertex x="11.53" y="4.69"/>
<vertex x="11.55" y="4.69"/>
<vertex x="11.57" y="4.68"/>
<vertex x="11.59" y="4.68"/>
<vertex x="11.62" y="4.67"/>
<vertex x="11.64" y="4.67"/>
<vertex x="11.66" y="4.66"/>
<vertex x="11.66" y="4.57"/>
<vertex x="11.66" y="4.48"/>
<vertex x="11.66" y="4.39"/>
<vertex x="11.66" y="4.3"/>
<vertex x="11.66" y="4.21"/>
<vertex x="11.66" y="4.12"/>
<vertex x="11.66" y="4.03"/>
<vertex x="11.66" y="3.94"/>
<vertex x="11.63" y="3.95"/>
<vertex x="11.6" y="3.95"/>
<vertex x="11.56" y="3.96"/>
<vertex x="11.53" y="3.96"/>
<vertex x="11.49" y="3.96"/>
<vertex x="11.45" y="3.97"/>
<vertex x="11.41" y="3.97"/>
<vertex x="11.38" y="3.97"/>
<vertex x="11.18" y="3.95"/>
<vertex x="11.02" y="3.9"/>
<vertex x="10.88" y="3.81"/>
<vertex x="10.78" y="3.7"/>
<vertex x="10.7" y="3.57"/>
<vertex x="10.65" y="3.41"/>
<vertex x="10.62" y="3.24"/>
<vertex x="10.61" y="3.06"/>
<vertex x="10.61" y="2.9"/>
<vertex x="10.61" y="2.74"/>
<vertex x="10.61" y="2.58"/>
<vertex x="10.61" y="2.42"/>
<vertex x="10.61" y="2.26"/>
<vertex x="10.61" y="2.1"/>
<vertex x="10.61" y="1.94"/>
<vertex x="10.61" y="1.78"/>
<vertex x="10.51" y="1.78"/>
<vertex x="10.42" y="1.78"/>
<vertex x="10.32" y="1.78"/>
<vertex x="10.22" y="1.78"/>
<vertex x="10.13" y="1.78"/>
<vertex x="10.03" y="1.78"/>
<vertex x="9.93" y="1.78"/>
<vertex x="9.83" y="1.78"/>
<vertex x="9.83" y="2.12"/>
<vertex x="9.83" y="2.46"/>
<vertex x="9.83" y="2.8"/>
<vertex x="9.83" y="3.13"/>
<vertex x="9.83" y="3.47"/>
<vertex x="9.83" y="3.81"/>
<vertex x="9.83" y="4.14"/>
</polygon>
<vertex x="11.96" y="5.26"/>
<vertex x="12.74" y="5.69"/>
<vertex x="12.74" y="3.6"/>
<vertex x="13.72" y="4.61"/>
<vertex x="14.64" y="4.61"/>
<vertex x="13.57" y="3.57"/>
<vertex x="14.76" y="1.79"/>
<vertex x="13.82" y="1.79"/>
<vertex x="13.04" y="3.05"/>
<vertex x="12.74" y="2.76"/>
<vertex x="12.74" y="1.79"/>
<vertex x="11.96" y="1.79"/>
</polygon>
<vertex x="15.23" y="4.09"/>
<vertex x="15.13" y="4.09"/>
<vertex x="15.04" y="4.09"/>
<vertex x="14.94" y="4.09"/>
<vertex x="14.85" y="4.09"/>
<vertex x="14.75" y="4.09"/>
<vertex x="14.66" y="4.09"/>
<vertex x="14.56" y="4.09"/>
<vertex x="14.46" y="4.09"/>
<vertex x="14.53" y="4.16"/>
<vertex x="14.6" y="4.22"/>
<vertex x="14.66" y="4.29"/>
<vertex x="14.73" y="4.35"/>
<vertex x="14.79" y="4.42"/>
<vertex x="14.86" y="4.48"/>
<vertex x="14.93" y="4.55"/>
<vertex x="14.99" y="4.61"/>
<vertex x="15.02" y="4.61"/>
<vertex x="15.05" y="4.61"/>
<vertex x="15.08" y="4.61"/>
<vertex x="15.11" y="4.61"/>
<vertex x="15.14" y="4.61"/>
<vertex x="15.17" y="4.61"/>
<vertex x="15.2" y="4.61"/>
<vertex x="15.23" y="4.61"/>
<vertex x="15.23" y="4.64"/>
<vertex x="15.23" y="4.67"/>
<vertex x="15.23" y="4.7"/>
<vertex x="15.23" y="4.72"/>
<vertex x="15.23" y="4.75"/>
<vertex x="15.23" y="4.78"/>
<vertex x="15.23" y="4.8"/>
<vertex x="15.23" y="4.83"/>
<vertex x="15.24" y="5.01"/>
<vertex x="15.29" y="5.18"/>
<vertex x="15.36" y="5.32"/>
<vertex x="15.46" y="5.45"/>
<vertex x="15.6" y="5.55"/>
<vertex x="15.76" y="5.63"/>
<vertex x="15.95" y="5.67"/>
<vertex x="16.18" y="5.69"/>
<vertex x="16.23" y="5.69"/>
<vertex x="16.28" y="5.69"/>
<vertex x="16.33" y="5.69"/>
<vertex x="16.38" y="5.68"/>
<vertex x="16.43" y="5.68"/>
<vertex x="16.49" y="5.68"/>
<vertex x="16.54" y="5.67"/>
<vertex x="16.59" y="5.67"/>
<vertex x="16.59" y="5.6"/>
<vertex x="16.59" y="5.53"/>
<vertex x="16.59" y="5.45"/>
<vertex x="16.59" y="5.38"/>
<vertex x="16.59" y="5.31"/>
<vertex x="16.59" y="5.24"/>
<vertex x="16.59" y="5.16"/>
<vertex x="16.59" y="5.09"/>
<vertex x="16.55" y="5.1"/>
<vertex x="16.52" y="5.1"/>
<vertex x="16.48" y="5.1"/>
<vertex x="16.44" y="5.1"/>
<vertex x="16.41" y="5.1"/>
<vertex x="16.37" y="5.1"/>
<vertex x="16.34" y="5.11"/>
<vertex x="16.3" y="5.11"/>
<vertex x="16.23" y="5.1"/>
<vertex x="16.17" y="5.09"/>
<vertex x="16.11" y="5.07"/>
<vertex x="16.07" y="5.03"/>
<vertex x="16.04" y="4.99"/>
<vertex x="16.02" y="4.93"/>
<vertex x="16.01" y="4.86"/>
<vertex x="16.01" y="4.78"/>
<vertex x="16.01" y="4.76"/>
<vertex x="16.01" y="4.74"/>
<vertex x="16.01" y="4.72"/>
<vertex x="16.01" y="4.7"/>
<vertex x="16.01" y="4.68"/>
<vertex x="16.01" y="4.66"/>
<vertex x="16.01" y="4.63"/>
<vertex x="16.01" y="4.61"/>
<vertex x="16.07" y="4.61"/>
<vertex x="16.14" y="4.61"/>
<vertex x="16.21" y="4.61"/>
<vertex x="16.27" y="4.61"/>
<vertex x="16.34" y="4.61"/>
<vertex x="16.41" y="4.61"/>
<vertex x="16.47" y="4.61"/>
<vertex x="16.54" y="4.61"/>
<vertex x="16.54" y="4.55"/>
<vertex x="16.54" y="4.48"/>
<vertex x="16.54" y="4.42"/>
<vertex x="16.54" y="4.35"/>
<vertex x="16.54" y="4.29"/>
<vertex x="16.54" y="4.22"/>
<vertex x="16.54" y="4.16"/>
<vertex x="16.54" y="4.09"/>
<vertex x="16.47" y="4.09"/>
<vertex x="16.41" y="4.09"/>
<vertex x="16.34" y="4.09"/>
<vertex x="16.27" y="4.09"/>
<vertex x="16.21" y="4.09"/>
<vertex x="16.14" y="4.09"/>
<vertex x="16.07" y="4.09"/>
<vertex x="16.01" y="4.09"/>
<vertex x="16.01" y="3.81"/>
<vertex x="16.01" y="3.52"/>
<vertex x="16.01" y="3.23"/>
<vertex x="16.01" y="2.94"/>
<vertex x="16.01" y="2.65"/>
<vertex x="16.01" y="2.36"/>
<vertex x="16.01" y="2.07"/>
<vertex x="16.01" y="1.79"/>
<vertex x="15.91" y="1.79"/>
<vertex x="15.81" y="1.79"/>
<vertex x="15.71" y="1.79"/>
<vertex x="15.62" y="1.79"/>
<vertex x="15.52" y="1.79"/>
<vertex x="15.42" y="1.79"/>
<vertex x="15.33" y="1.79"/>
<vertex x="15.23" y="1.79"/>
<vertex x="15.23" y="2.07"/>
<vertex x="15.23" y="2.36"/>
<vertex x="15.23" y="2.65"/>
<vertex x="15.23" y="2.94"/>
<vertex x="15.23" y="3.23"/>
<vertex x="15.23" y="3.52"/>
<vertex x="15.23" y="3.81"/>
</polygon>
<vertex x="19.41" y="1.79"/>
<vertex x="19.32" y="1.79"/>
<vertex x="19.23" y="1.79"/>
<vertex x="19.14" y="1.79"/>
<vertex x="19.04" y="1.79"/>
<vertex x="18.95" y="1.79"/>
<vertex x="18.86" y="1.79"/>
<vertex x="18.77" y="1.79"/>
<vertex x="18.67" y="1.79"/>
<vertex x="18.67" y="1.83"/>
<vertex x="18.67" y="1.88"/>
<vertex x="18.67" y="1.93"/>
<vertex x="18.67" y="1.98"/>
<vertex x="18.67" y="2.03"/>
<vertex x="18.67" y="2.08"/>
<vertex x="18.67" y="2.13"/>
<vertex x="18.67" y="2.18"/>
<vertex x="18.59" y="2.07"/>
<vertex x="18.49" y="1.97"/>
<vertex x="18.39" y="1.89"/>
<vertex x="18.28" y="1.82"/>
<vertex x="18.17" y="1.77"/>
<vertex x="18.05" y="1.74"/>
<vertex x="17.92" y="1.72"/>
<vertex x="17.8" y="1.71"/>
<vertex x="17.52" y="1.73"/>
<vertex x="17.29" y="1.79"/>
<vertex x="17.11" y="1.89"/>
<vertex x="16.97" y="2.03"/>
<vertex x="16.88" y="2.2"/>
<vertex x="16.81" y="2.4"/>
<vertex x="16.78" y="2.62"/>
<vertex x="16.77" y="2.87"/>
<vertex x="16.77" y="3.09"/>
<vertex x="16.77" y="3.31"/>
<vertex x="16.77" y="3.53"/>
<vertex x="16.77" y="3.74"/>
<vertex x="16.77" y="3.96"/>
<vertex x="16.77" y="4.18"/>
<vertex x="16.77" y="4.4"/>
<vertex x="16.77" y="4.61"/>
<vertex x="16.86" y="4.61"/>
<vertex x="16.96" y="4.61"/>
<vertex x="17.06" y="4.61"/>
<vertex x="17.16" y="4.61"/>
<vertex x="17.25" y="4.61"/>
<vertex x="17.35" y="4.61"/>
<vertex x="17.45" y="4.61"/>
<vertex x="17.54" y="4.61"/>
<vertex x="17.54" y="4.41"/>
<vertex x="17.54" y="4.21"/>
<vertex x="17.54" y="4.01"/>
<vertex x="17.54" y="3.81"/>
<vertex x="17.54" y="3.61"/>
<vertex x="17.54" y="3.42"/>
<vertex x="17.54" y="3.22"/>
<vertex x="17.54" y="3.02"/>
<vertex x="17.55" y="2.85"/>
<vertex x="17.57" y="2.71"/>
<vertex x="17.61" y="2.59"/>
<vertex x="17.66" y="2.49"/>
<vertex x="17.72" y="2.42"/>
<vertex x="17.81" y="2.36"/>
<vertex x="17.92" y="2.33"/>
<vertex x="18.04" y="2.32"/>
<vertex x="18.19" y="2.33"/>
<vertex x="18.31" y="2.37"/>
<vertex x="18.42" y="2.43"/>
<vertex x="18.5" y="2.51"/>
<vertex x="18.56" y="2.62"/>
<vertex x="18.61" y="2.76"/>
<vertex x="18.64" y="2.93"/>
<vertex x="18.64" y="3.13"/>
<vertex x="18.64" y="3.32"/>
<vertex x="18.64" y="3.5"/>
<vertex x="18.64" y="3.69"/>
<vertex x="18.64" y="3.87"/>
<vertex x="18.64" y="4.06"/>
<vertex x="18.64" y="4.24"/>
<vertex x="18.64" y="4.43"/>
<vertex x="18.64" y="4.61"/>
<vertex x="18.74" y="4.61"/>
<vertex x="18.84" y="4.61"/>
<vertex x="18.94" y="4.61"/>
<vertex x="19.03" y="4.61"/>
<vertex x="19.13" y="4.61"/>
<vertex x="19.23" y="4.61"/>
<vertex x="19.32" y="4.61"/>
<vertex x="19.42" y="4.61"/>
<vertex x="19.42" y="4.26"/>
<vertex x="19.42" y="3.91"/>
<vertex x="19.42" y="3.55"/>
<vertex x="19.42" y="3.2"/>
<vertex x="19.42" y="2.85"/>
<vertex x="19.42" y="2.49"/>
<vertex x="19.42" y="2.14"/>
</polygon>
<vertex x="19.84" y="4.61"/>
<vertex x="19.93" y="4.61"/>
<vertex x="20.03" y="4.61"/>
<vertex x="20.12" y="4.61"/>
<vertex x="20.21" y="4.61"/>
<vertex x="20.3" y="4.61"/>
<vertex x="20.4" y="4.61"/>
<vertex x="20.49" y="4.61"/>
<vertex x="20.58" y="4.61"/>
<vertex x="20.58" y="4.56"/>
<vertex x="20.58" y="4.52"/>
<vertex x="20.58" y="4.47"/>
<vertex x="20.58" y="4.42"/>
<vertex x="20.58" y="4.37"/>
<vertex x="20.58" y="4.32"/>
<vertex x="20.58" y="4.27"/>
<vertex x="20.58" y="4.22"/>
<vertex x="20.59" y="4.22"/>
<vertex x="20.67" y="4.33"/>
<vertex x="20.76" y="4.43"/>
<vertex x="20.86" y="4.51"/>
<vertex x="20.97" y="4.58"/>
<vertex x="21.09" y="4.63"/>
<vertex x="21.21" y="4.66"/>
<vertex x="21.33" y="4.68"/>
<vertex x="21.45" y="4.69"/>
<vertex x="21.73" y="4.67"/>
<vertex x="21.96" y="4.61"/>
<vertex x="22.14" y="4.51"/>
<vertex x="22.28" y="4.37"/>
<vertex x="22.38" y="4.2"/>
<vertex x="22.44" y="4"/>
<vertex x="22.48" y="3.78"/>
<vertex x="22.49" y="3.53"/>
<vertex x="22.49" y="3.31"/>
<vertex x="22.49" y="3.09"/>
<vertex x="22.49" y="2.87"/>
<vertex x="22.49" y="2.66"/>
<vertex x="22.49" y="2.44"/>
<vertex x="22.49" y="2.22"/>
<vertex x="22.49" y="2"/>
<vertex x="22.49" y="1.79"/>
<vertex x="22.39" y="1.79"/>
<vertex x="22.29" y="1.79"/>
<vertex x="22.2" y="1.79"/>
<vertex x="22.1" y="1.79"/>
<vertex x="22" y="1.79"/>
<vertex x="21.9" y="1.79"/>
<vertex x="21.81" y="1.79"/>
<vertex x="21.71" y="1.79"/>
<vertex x="21.71" y="1.99"/>
<vertex x="21.71" y="2.19"/>
<vertex x="21.71" y="2.39"/>
<vertex x="21.71" y="2.58"/>
<vertex x="21.71" y="2.78"/>
<vertex x="21.71" y="2.98"/>
<vertex x="21.71" y="3.18"/>
<vertex x="21.71" y="3.38"/>
<vertex x="21.7" y="3.55"/>
<vertex x="21.68" y="3.69"/>
<vertex x="21.65" y="3.81"/>
<vertex x="21.6" y="3.91"/>
<vertex x="21.53" y="3.98"/>
<vertex x="21.44" y="4.03"/>
<vertex x="21.34" y="4.07"/>
<vertex x="21.21" y="4.08"/>
<vertex x="21.07" y="4.07"/>
<vertex x="20.94" y="4.03"/>
<vertex x="20.84" y="3.97"/>
<vertex x="20.75" y="3.89"/>
<vertex x="20.69" y="3.78"/>
<vertex x="20.65" y="3.64"/>
<vertex x="20.62" y="3.47"/>
<vertex x="20.61" y="3.27"/>
<vertex x="20.61" y="3.08"/>
<vertex x="20.61" y="2.9"/>
<vertex x="20.61" y="2.71"/>
<vertex x="20.61" y="2.53"/>
<vertex x="20.61" y="2.34"/>
<vertex x="20.61" y="2.16"/>
<vertex x="20.61" y="1.97"/>
<vertex x="20.61" y="1.79"/>
<vertex x="20.51" y="1.79"/>
<vertex x="20.42" y="1.79"/>
<vertex x="20.32" y="1.79"/>
<vertex x="20.22" y="1.79"/>
<vertex x="20.13" y="1.79"/>
<vertex x="20.03" y="1.79"/>
<vertex x="19.93" y="1.79"/>
<vertex x="19.83" y="1.79"/>
<vertex x="19.83" y="2.14"/>
<vertex x="19.83" y="2.49"/>
<vertex x="19.83" y="2.85"/>
<vertex x="19.83" y="3.2"/>
<vertex x="19.83" y="3.55"/>
<vertex x="19.83" y="3.91"/>
<vertex x="19.83" y="4.26"/>
</polygon>
<vertex x="16.33" y="9.47"/>
<vertex x="16.33" y="9.45"/>
<vertex x="16.34" y="9.42"/>
<vertex x="16.34" y="9.37"/>
<vertex x="16.34" y="9.31"/>
<vertex x="16.32" y="9.25"/>
<vertex x="16.29" y="9.19"/>
<vertex x="16.24" y="9.15"/>
<vertex x="16.17" y="9.12"/>
<vertex x="16.11" y="9.12"/>
<vertex x="16.04" y="9.13"/>
<vertex x="15.96" y="9.16"/>
<vertex x="15.88" y="9.2"/>
<vertex x="15.81" y="9.24"/>
<vertex x="15.74" y="9.29"/>
<vertex x="15.68" y="9.35"/>
<vertex x="15.62" y="9.41"/>
<vertex x="15.57" y="9.48"/>
<vertex x="15.53" y="9.55"/>
<vertex x="15.51" y="9.61"/>
<vertex x="15.51" y="9.68"/>
<vertex x="15.51" y="9.73"/>
<vertex x="15.53" y="9.79"/>
<vertex x="15.56" y="9.84"/>
<vertex x="15.61" y="9.9"/>
<vertex x="15.68" y="9.96"/>
<vertex x="15.76" y="10"/>
<vertex x="15.85" y="10.03"/>
<vertex x="15.93" y="10.04"/>
<vertex x="16" y="10.04"/>
<vertex x="16.06" y="10.03"/>
<vertex x="16.1" y="10.02"/>
<vertex x="16.11" y="10.02"/>
<vertex x="16.09" y="10.04"/>
<vertex x="16.01" y="10.1"/>
<vertex x="15.89" y="10.16"/>
<vertex x="15.74" y="10.23"/>
<vertex x="15.56" y="10.27"/>
<vertex x="15.36" y="10.28"/>
<vertex x="15.14" y="10.23"/>
<vertex x="14.91" y="10.12"/>
<vertex x="14.74" y="9.97"/>
<vertex x="14.63" y="9.81"/>
<vertex x="14.58" y="9.65"/>
<vertex x="14.58" y="9.48"/>
<vertex x="14.62" y="9.3"/>
<vertex x="14.72" y="9.13"/>
<vertex x="14.85" y="8.95"/>
<vertex x="15.02" y="8.78"/>
<vertex x="15.15" y="8.63"/>
<vertex x="15.21" y="8.48"/>
<vertex x="15.22" y="8.34"/>
<vertex x="15.17" y="8.22"/>
<vertex x="15.09" y="8.11"/>
<vertex x="14.97" y="8.04"/>
<vertex x="14.82" y="8"/>
<vertex x="14.66" y="7.99"/>
<vertex x="14.55" y="8.02"/>
<vertex x="14.46" y="8.06"/>
<vertex x="14.39" y="8.11"/>
<vertex x="14.34" y="8.17"/>
<vertex x="14.3" y="8.24"/>
<vertex x="14.28" y="8.3"/>
<vertex x="14.28" y="8.37"/>
<vertex x="14.3" y="8.43"/>
<vertex x="14.33" y="8.48"/>
<vertex x="14.37" y="8.52"/>
<vertex x="14.42" y="8.55"/>
<vertex x="14.47" y="8.58"/>
<vertex x="14.51" y="8.61"/>
<vertex x="14.55" y="8.62"/>
<vertex x="14.58" y="8.64"/>
<vertex x="14.59" y="8.64"/>
<vertex x="14.57" y="8.64"/>
<vertex x="14.54" y="8.65"/>
<vertex x="14.49" y="8.67"/>
<vertex x="14.42" y="8.68"/>
<vertex x="14.34" y="8.68"/>
<vertex x="14.25" y="8.68"/>
<vertex x="14.14" y="8.66"/>
<vertex x="14.04" y="8.63"/>
<vertex x="13.94" y="8.59"/>
<vertex x="13.85" y="8.53"/>
<vertex x="13.76" y="8.46"/>
<vertex x="13.69" y="8.36"/>
<vertex x="13.64" y="8.25"/>
<vertex x="13.59" y="8.11"/>
<vertex x="13.57" y="7.95"/>
<vertex x="13.57" y="7.76"/>
<vertex x="13.57" y="7.44"/>
<vertex x="13.57" y="7.12"/>
<vertex x="13.57" y="6.8"/>
<vertex x="13.57" y="6.48"/>
<vertex x="13.57" y="6.15"/>
<vertex x="13.57" y="5.83"/>
<vertex x="13.57" y="5.51"/>
<vertex x="13.57" y="5.19"/>
<vertex x="13.58" y="5.21"/>
<vertex x="13.61" y="5.25"/>
<vertex x="13.67" y="5.32"/>
<vertex x="13.74" y="5.41"/>
<vertex x="13.83" y="5.51"/>
<vertex x="13.94" y="5.63"/>
<vertex x="14.05" y="5.75"/>
<vertex x="14.17" y="5.88"/>
<vertex x="14.29" y="6.02"/>
<vertex x="14.41" y="6.15"/>
<vertex x="14.51" y="6.26"/>
<vertex x="14.61" y="6.35"/>
<vertex x="14.72" y="6.42"/>
<vertex x="14.82" y="6.47"/>
<vertex x="14.94" y="6.5"/>
<vertex x="15.07" y="6.5"/>
<vertex x="15.32" y="6.5"/>
<vertex x="15.56" y="6.53"/>
<vertex x="15.78" y="6.6"/>
<vertex x="15.98" y="6.68"/>
<vertex x="16.17" y="6.8"/>
<vertex x="16.34" y="6.94"/>
<vertex x="16.49" y="7.1"/>
<vertex x="16.63" y="7.28"/>
<vertex x="16.83" y="7.64"/>
<vertex x="16.93" y="8.01"/>
<vertex x="16.95" y="8.36"/>
<vertex x="16.9" y="8.68"/>
<vertex x="16.8" y="8.97"/>
<vertex x="16.66" y="9.2"/>
<vertex x="16.5" y="9.37"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.3">
<vertex x="1.69" y="4.06"/>
<vertex x="1.71" y="3.88"/>
<vertex x="1.77" y="3.74"/>
<vertex x="1.86" y="3.61"/>
<vertex x="1.97" y="3.51"/>
<vertex x="2.11" y="3.44"/>
<vertex x="2.26" y="3.39"/>
<vertex x="2.42" y="3.35"/>
<vertex x="2.59" y="3.34"/>
<vertex x="2.72" y="3.35"/>
<vertex x="2.85" y="3.37"/>
<vertex x="2.97" y="3.41"/>
<vertex x="3.09" y="3.46"/>
<vertex x="3.2" y="3.53"/>
<vertex x="3.28" y="3.63"/>
<vertex x="3.33" y="3.74"/>
<vertex x="3.35" y="3.88"/>
<vertex x="3.33" y="4.01"/>
<vertex x="3.26" y="4.11"/>
<vertex x="3.15" y="4.2"/>
<vertex x="3" y="4.28"/>
<vertex x="2.81" y="4.35"/>
<vertex x="2.59" y="4.42"/>
<vertex x="2.33" y="4.48"/>
<vertex x="2.03" y="4.54"/>
<vertex x="1.78" y="4.6"/>
<vertex x="1.53" y="4.68"/>
<vertex x="1.31" y="4.77"/>
<vertex x="1.1" y="4.88"/>
<vertex x="0.93" y="5.03"/>
<vertex x="0.8" y="5.2"/>
<vertex x="0.72" y="5.41"/>
<vertex x="0.69" y="5.67"/>
<vertex x="0.73" y="6.04"/>
<vertex x="0.85" y="6.34"/>
<vertex x="1.03" y="6.58"/>
<vertex x="1.27" y="6.76"/>
<vertex x="1.55" y="6.89"/>
<vertex x="1.86" y="6.98"/>
<vertex x="2.19" y="7.02"/>
<vertex x="2.53" y="7.04"/>
<vertex x="2.87" y="7.02"/>
<vertex x="3.2" y="6.97"/>
<vertex x="3.5" y="6.88"/>
<vertex x="3.78" y="6.75"/>
<vertex x="4.01" y="6.57"/>
<vertex x="4.2" y="6.33"/>
<vertex x="4.33" y="6.04"/>
<vertex x="4.4" y="5.68"/>
<vertex x="4.26" y="5.68"/>
<vertex x="4.13" y="5.68"/>
<vertex x="3.99" y="5.68"/>
<vertex x="3.85" y="5.68"/>
<vertex x="3.71" y="5.68"/>
<vertex x="3.57" y="5.68"/>
<vertex x="3.43" y="5.68"/>
<vertex x="3.29" y="5.68"/>
<vertex x="3.27" y="5.84"/>
<vertex x="3.21" y="5.96"/>
<vertex x="3.14" y="6.06"/>
<vertex x="3.04" y="6.14"/>
<vertex x="2.93" y="6.19"/>
<vertex x="2.79" y="6.23"/>
<vertex x="2.65" y="6.25"/>
<vertex x="2.5" y="6.26"/>
<vertex x="2.4" y="6.26"/>
<vertex x="2.29" y="6.24"/>
<vertex x="2.18" y="6.23"/>
<vertex x="2.08" y="6.19"/>
<vertex x="1.99" y="6.14"/>
<vertex x="1.91" y="6.07"/>
<vertex x="1.87" y="5.98"/>
<vertex x="1.85" y="5.86"/>
<vertex x="1.88" y="5.72"/>
<vertex x="1.96" y="5.61"/>
<vertex x="2.09" y="5.52"/>
<vertex x="2.26" y="5.45"/>
<vertex x="2.46" y="5.39"/>
<vertex x="2.69" y="5.34"/>
<vertex x="2.93" y="5.29"/>
<vertex x="3.17" y="5.23"/>
<vertex x="3.42" y="5.17"/>
<vertex x="3.67" y="5.09"/>
<vertex x="3.9" y="4.99"/>
<vertex x="4.1" y="4.87"/>
<vertex x="4.27" y="4.72"/>
<vertex x="4.4" y="4.54"/>
<vertex x="4.49" y="4.31"/>
<vertex x="4.52" y="4.04"/>
<vertex x="4.47" y="3.66"/>
<vertex x="4.35" y="3.34"/>
<vertex x="4.16" y="3.08"/>
<vertex x="3.91" y="2.88"/>
<vertex x="3.61" y="2.74"/>
<vertex x="3.29" y="2.64"/>
<vertex x="2.94" y="2.58"/>
<vertex x="2.58" y="2.56"/>
<vertex x="2.21" y="2.58"/>
<vertex x="1.86" y="2.64"/>
<vertex x="1.53" y="2.74"/>
<vertex x="1.23" y="2.89"/>
<vertex x="0.98" y="3.09"/>
<vertex x="0.78" y="3.35"/>
<vertex x="0.64" y="3.67"/>
<vertex x="0.59" y="4.06"/>
<vertex x="0.72" y="4.06"/>
<vertex x="0.86" y="4.06"/>
<vertex x="1" y="4.06"/>
<vertex x="1.14" y="4.06"/>
<vertex x="1.28" y="4.06"/>
<vertex x="1.42" y="4.06"/>
<vertex x="1.56" y="4.06"/>
</polygon>
<vertex x="8.01" y="4.06"/>
<vertex x="8.08" y="4.29"/>
<vertex x="8.12" y="4.53"/>
<vertex x="8.13" y="4.79"/>
<vertex x="9.3" y="4.76"/>
<vertex x="9.27" y="4.34"/>
<vertex x="9.18" y="3.94"/>
<vertex x="9.04" y="3.56"/>
</polygon>
<vertex x="8.83" y="3.24"/>
<vertex x="8.57" y="2.96"/>
<vertex x="8.25" y="2.75"/>
<vertex x="7.87" y="2.61"/>
<vertex x="7.44" y="2.56"/>
<vertex x="7.24" y="2.58"/>
<vertex x="7.06" y="2.61"/>
<vertex x="6.88" y="2.66"/>
<vertex x="6.71" y="2.73"/>
<vertex x="6.56" y="2.82"/>
<vertex x="6.41" y="2.93"/>
<vertex x="6.28" y="3.06"/>
<vertex x="6.16" y="3.2"/>
<vertex x="6.16" y="2.82"/>
<vertex x="6.16" y="2.44"/>
<vertex x="6.16" y="2.06"/>
<vertex x="6.16" y="1.68"/>
<vertex x="6.16" y="1.3"/>
<vertex x="6.16" y="0.91"/>
<vertex x="6.16" y="0.53"/>
<vertex x="6.16" y="0.15"/>
<vertex x="6.01" y="0.28"/>
<vertex x="5.87" y="0.41"/>
<vertex x="5.72" y="0.54"/>
<vertex x="5.57" y="0.67"/>
<vertex x="5.43" y="0.8"/>
<vertex x="5.28" y="0.93"/>
<vertex x="5.14" y="1.06"/>
<vertex x="4.99" y="1.19"/>
<vertex x="4.99" y="1.88"/>
<vertex x="4.99" y="2.57"/>
<vertex x="4.99" y="3.26"/>
<vertex x="4.99" y="3.96"/>
<vertex x="4.99" y="4.65"/>
<vertex x="4.99" y="5.34"/>
<vertex x="4.99" y="6.03"/>
<vertex x="4.99" y="6.72"/>
<vertex x="5.13" y="6.75"/>
<vertex x="5.27" y="6.77"/>
<vertex x="5.41" y="6.8"/>
<vertex x="5.55" y="6.82"/>
<vertex x="5.68" y="6.85"/>
<vertex x="5.82" y="6.87"/>
<vertex x="5.96" y="6.9"/>
<vertex x="6.1" y="6.92"/>
<vertex x="6.1" y="6.85"/>
<vertex x="6.1" y="6.79"/>
<vertex x="6.1" y="6.72"/>
<vertex x="6.1" y="6.65"/>
<vertex x="6.1" y="6.58"/>
<vertex x="6.1" y="6.52"/>
<vertex x="6.1" y="6.45"/>
<vertex x="6.1" y="6.38"/>
<vertex x="6.11" y="6.38"/>
<vertex x="6.22" y="6.54"/>
<vertex x="6.35" y="6.68"/>
<vertex x="6.49" y="6.79"/>
<vertex x="6.65" y="6.88"/>
<vertex x="6.82" y="6.95"/>
<vertex x="6.99" y="7"/>
<vertex x="7.18" y="7.03"/>
<vertex x="7.37" y="7.04"/>
<vertex x="7.84" y="6.99"/>
<vertex x="8.23" y="6.85"/>
<vertex x="8.56" y="6.63"/>
<vertex x="8.83" y="6.35"/>
<vertex x="9.04" y="6.01"/>
<vertex x="9.18" y="5.62"/>
<vertex x="9.27" y="5.2"/>
<vertex x="8.12" y="5.04"/>
<vertex x="8.08" y="5.29"/>
<vertex x="8.01" y="5.52"/>
<vertex x="7.9" y="5.73"/>
<vertex x="7.77" y="5.9"/>
<vertex x="7.59" y="6.04"/>
<vertex x="7.37" y="6.13"/>
<vertex x="7.12" y="6.16"/>
<vertex x="6.85" y="6.13"/>
<vertex x="6.64" y="6.04"/>
<vertex x="6.46" y="5.91"/>
<vertex x="6.32" y="5.73"/>
<vertex x="6.22" y="5.52"/>
<vertex x="6.16" y="5.29"/>
<vertex x="6.12" y="5.04"/>
<vertex x="6.11" y="4.79"/>
<vertex x="6.12" y="4.53"/>
<vertex x="6.16" y="4.29"/>
<vertex x="6.23" y="4.06"/>
<vertex x="6.33" y="3.86"/>
<vertex x="6.47" y="3.69"/>
<vertex x="6.65" y="3.56"/>
<vertex x="6.86" y="3.47"/>
<vertex x="7.12" y="3.44"/>
<vertex x="7.39" y="3.47"/>
<vertex x="7.6" y="3.56"/>
<vertex x="7.78" y="3.69"/>
<vertex x="7.91" y="3.86"/>
</polygon>
<vertex x="11.07" y="5.11"/>
<vertex x="11.33" y="5.15"/>
<vertex x="11.59" y="5.18"/>
<vertex x="11.83" y="5.21"/>
<vertex x="11.97" y="4.58"/>
<vertex x="11.9" y="4.57"/>
<vertex x="11.83" y="4.56"/>
<vertex x="11.76" y="4.55"/>
<vertex x="11.69" y="4.54"/>
<vertex x="11.62" y="4.53"/>
<vertex x="11.55" y="4.52"/>
<vertex x="11.49" y="4.51"/>
<vertex x="11.42" y="4.49"/>
<vertex x="11.35" y="4.48"/>
<vertex x="11.29" y="4.46"/>
</polygon>
<vertex x="11.23" y="4.44"/>
<vertex x="11.17" y="4.42"/>
<vertex x="11.11" y="4.39"/>
<vertex x="11.06" y="4.36"/>
<vertex x="11.01" y="4.33"/>
<vertex x="10.96" y="4.29"/>
<vertex x="10.92" y="4.25"/>
<vertex x="10.88" y="4.2"/>
<vertex x="10.85" y="4.15"/>
<vertex x="10.83" y="4.09"/>
<vertex x="10.81" y="4.03"/>
<vertex x="10.8" y="3.96"/>
<vertex x="10.8" y="3.88"/>
<vertex x="10.8" y="3.81"/>
<vertex x="10.81" y="3.74"/>
<vertex x="10.83" y="3.67"/>
<vertex x="10.86" y="3.62"/>
<vertex x="10.89" y="3.57"/>
<vertex x="10.92" y="3.52"/>
<vertex x="10.97" y="3.48"/>
<vertex x="11.01" y="3.45"/>
<vertex x="11.06" y="3.42"/>
<vertex x="11.12" y="3.4"/>
<vertex x="11.18" y="3.38"/>
<vertex x="11.24" y="3.37"/>
<vertex x="11.31" y="3.35"/>
<vertex x="11.37" y="3.34"/>
<vertex x="11.44" y="3.34"/>
<vertex x="11.51" y="3.34"/>
<vertex x="11.67" y="3.35"/>
<vertex x="11.81" y="3.37"/>
<vertex x="11.94" y="3.41"/>
<vertex x="12.04" y="3.46"/>
<vertex x="12.13" y="3.52"/>
<vertex x="12.21" y="3.58"/>
<vertex x="12.27" y="3.66"/>
<vertex x="12.32" y="3.73"/>
<vertex x="12.37" y="3.81"/>
<vertex x="12.4" y="3.89"/>
<vertex x="12.42" y="3.98"/>
<vertex x="12.44" y="4.06"/>
<vertex x="12.45" y="4.13"/>
<vertex x="12.45" y="4.2"/>
<vertex x="12.45" y="4.26"/>
<vertex x="12.45" y="4.32"/>
<vertex x="12.45" y="4.35"/>
<vertex x="12.45" y="4.37"/>
<vertex x="12.45" y="4.4"/>
<vertex x="12.45" y="4.43"/>
<vertex x="12.45" y="4.45"/>
<vertex x="12.45" y="4.48"/>
<vertex x="12.45" y="4.51"/>
<vertex x="12.45" y="4.54"/>
<vertex x="12.45" y="4.56"/>
<vertex x="12.45" y="4.59"/>
<vertex x="12.45" y="4.62"/>
<vertex x="12.45" y="4.64"/>
<vertex x="12.45" y="4.67"/>
<vertex x="12.45" y="4.7"/>
<vertex x="12.45" y="4.73"/>
<vertex x="12.45" y="4.75"/>
<vertex x="12.42" y="4.72"/>
<vertex x="12.37" y="4.7"/>
<vertex x="12.32" y="4.67"/>
<vertex x="12.27" y="4.65"/>
<vertex x="12.22" y="4.63"/>
<vertex x="12.16" y="4.62"/>
<vertex x="12.1" y="4.6"/>
<vertex x="12.03" y="4.59"/>
<vertex x="12.04" y="5.26"/>
<vertex x="12.21" y="5.32"/>
<vertex x="12.35" y="5.4"/>
<vertex x="12.43" y="5.52"/>
<vertex x="12.45" y="5.68"/>
<vertex x="12.45" y="5.77"/>
<vertex x="12.44" y="5.84"/>
<vertex x="12.42" y="5.91"/>
<vertex x="12.4" y="5.98"/>
<vertex x="12.36" y="6.03"/>
<vertex x="12.33" y="6.08"/>
<vertex x="12.28" y="6.12"/>
<vertex x="12.23" y="6.15"/>
<vertex x="12.18" y="6.18"/>
<vertex x="12.12" y="6.2"/>
<vertex x="12.06" y="6.22"/>
<vertex x="11.99" y="6.23"/>
<vertex x="11.92" y="6.24"/>
<vertex x="11.85" y="6.25"/>
<vertex x="11.78" y="6.25"/>
<vertex x="11.7" y="6.25"/>
<vertex x="11.62" y="6.25"/>
<vertex x="11.54" y="6.24"/>
<vertex x="11.47" y="6.23"/>
<vertex x="11.4" y="6.21"/>
<vertex x="11.33" y="6.19"/>
<vertex x="11.27" y="6.17"/>
<vertex x="11.21" y="6.14"/>
<vertex x="11.16" y="6.1"/>
<vertex x="11.11" y="6.06"/>
<vertex x="11.07" y="6.01"/>
<vertex x="11.04" y="5.96"/>
<vertex x="11" y="5.9"/>
<vertex x="10.98" y="5.84"/>
<vertex x="10.96" y="5.77"/>
<vertex x="10.94" y="5.69"/>
<vertex x="10.93" y="5.61"/>
<vertex x="10.86" y="5.61"/>
<vertex x="10.78" y="5.61"/>
<vertex x="10.71" y="5.61"/>
<vertex x="10.64" y="5.61"/>
<vertex x="10.57" y="5.61"/>
<vertex x="10.49" y="5.61"/>
<vertex x="10.42" y="5.61"/>
<vertex x="10.35" y="5.61"/>
<vertex x="10.28" y="5.61"/>
<vertex x="10.2" y="5.61"/>
<vertex x="10.13" y="5.61"/>
<vertex x="10.06" y="5.61"/>
<vertex x="9.98" y="5.61"/>
<vertex x="9.91" y="5.61"/>
<vertex x="9.84" y="5.61"/>
<vertex x="9.77" y="5.61"/>
<vertex x="9.79" y="5.8"/>
<vertex x="9.83" y="5.98"/>
<vertex x="9.89" y="6.14"/>
<vertex x="9.97" y="6.29"/>
<vertex x="10.07" y="6.42"/>
<vertex x="10.18" y="6.53"/>
<vertex x="10.3" y="6.64"/>
<vertex x="10.43" y="6.72"/>
<vertex x="10.58" y="6.8"/>
<vertex x="10.73" y="6.86"/>
<vertex x="10.89" y="6.92"/>
<vertex x="11.06" y="6.96"/>
<vertex x="11.23" y="6.99"/>
<vertex x="11.4" y="7.01"/>
<vertex x="11.58" y="7.02"/>
<vertex x="11.76" y="7.03"/>
<vertex x="11.92" y="7.03"/>
<vertex x="12.08" y="7.02"/>
<vertex x="12.25" y="7"/>
<vertex x="12.41" y="6.98"/>
<vertex x="12.57" y="6.95"/>
<vertex x="12.72" y="6.91"/>
<vertex x="12.87" y="6.86"/>
<vertex x="13.01" y="6.8"/>
<vertex x="13.14" y="6.73"/>
<vertex x="13.26" y="6.65"/>
<vertex x="13.36" y="6.55"/>
<vertex x="13.45" y="6.44"/>
<vertex x="13.52" y="6.31"/>
<vertex x="13.58" y="6.16"/>
<vertex x="13.61" y="6"/>
<vertex x="13.62" y="5.82"/>
<vertex x="13.62" y="5.68"/>
<vertex x="13.62" y="5.54"/>
<vertex x="13.62" y="5.41"/>
<vertex x="13.62" y="5.27"/>
<vertex x="13.62" y="5.13"/>
<vertex x="13.62" y="4.99"/>
<vertex x="13.62" y="4.85"/>
<vertex x="13.62" y="4.72"/>
<vertex x="13.62" y="4.58"/>
<vertex x="13.62" y="4.44"/>
<vertex x="13.62" y="4.3"/>
<vertex x="13.62" y="4.16"/>
<vertex x="13.62" y="4.03"/>
<vertex x="13.62" y="3.89"/>
<vertex x="13.62" y="3.75"/>
<vertex x="13.62" y="3.61"/>
<vertex x="13.62" y="3.54"/>
<vertex x="13.63" y="3.47"/>
<vertex x="13.63" y="3.4"/>
<vertex x="13.63" y="3.33"/>
<vertex x="13.63" y="3.26"/>
<vertex x="13.64" y="3.19"/>
<vertex x="13.65" y="3.12"/>
<vertex x="13.66" y="3.06"/>
<vertex x="13.67" y="3"/>
<vertex x="13.68" y="2.94"/>
<vertex x="13.69" y="2.89"/>
<vertex x="13.7" y="2.84"/>
<vertex x="13.72" y="2.79"/>
<vertex x="13.73" y="2.74"/>
<vertex x="13.75" y="2.7"/>
<vertex x="13.77" y="2.67"/>
<vertex x="13.69" y="2.67"/>
<vertex x="13.62" y="2.67"/>
<vertex x="13.55" y="2.67"/>
<vertex x="13.47" y="2.67"/>
<vertex x="13.4" y="2.67"/>
<vertex x="13.33" y="2.67"/>
<vertex x="13.25" y="2.67"/>
<vertex x="13.18" y="2.67"/>
<vertex x="13.1" y="2.67"/>
<vertex x="13.03" y="2.67"/>
<vertex x="12.96" y="2.67"/>
<vertex x="12.88" y="2.67"/>
<vertex x="12.81" y="2.67"/>
<vertex x="12.74" y="2.67"/>
<vertex x="12.66" y="2.67"/>
<vertex x="12.59" y="2.67"/>
<vertex x="12.58" y="2.69"/>
<vertex x="12.57" y="2.72"/>
<vertex x="12.56" y="2.74"/>
<vertex x="12.55" y="2.77"/>
<vertex x="12.54" y="2.8"/>
<vertex x="12.54" y="2.82"/>
<vertex x="12.53" y="2.85"/>
<vertex x="12.53" y="2.87"/>
<vertex x="12.52" y="2.9"/>
<vertex x="12.52" y="2.92"/>
<vertex x="12.52" y="2.95"/>
<vertex x="12.51" y="2.98"/>
<vertex x="12.51" y="3"/>
<vertex x="12.51" y="3.03"/>
<vertex x="12.51" y="3.05"/>
<vertex x="12.51" y="3.08"/>
<vertex x="12.44" y="3.01"/>
<vertex x="12.36" y="2.95"/>
<vertex x="12.28" y="2.89"/>
<vertex x="12.2" y="2.84"/>
<vertex x="12.12" y="2.79"/>
<vertex x="12.03" y="2.74"/>
<vertex x="11.94" y="2.71"/>
<vertex x="11.85" y="2.67"/>
<vertex x="11.76" y="2.64"/>
<vertex x="11.67" y="2.62"/>
<vertex x="11.57" y="2.6"/>
<vertex x="11.47" y="2.58"/>
<vertex x="11.38" y="2.57"/>
<vertex x="11.28" y="2.56"/>
<vertex x="11.18" y="2.55"/>
<vertex x="11.08" y="2.55"/>
<vertex x="10.93" y="2.56"/>
<vertex x="10.78" y="2.57"/>
<vertex x="10.65" y="2.59"/>
<vertex x="10.51" y="2.63"/>
<vertex x="10.39" y="2.67"/>
<vertex x="10.27" y="2.73"/>
<vertex x="10.16" y="2.79"/>
<vertex x="10.05" y="2.86"/>
<vertex x="9.96" y="2.95"/>
<vertex x="9.88" y="3.04"/>
<vertex x="9.81" y="3.14"/>
<vertex x="9.75" y="3.26"/>
<vertex x="9.7" y="3.38"/>
<vertex x="9.67" y="3.52"/>
<vertex x="9.64" y="3.67"/>
<vertex x="9.64" y="3.82"/>
<vertex x="9.67" y="4.15"/>
<vertex x="9.76" y="4.42"/>
<vertex x="9.91" y="4.63"/>
<vertex x="10.09" y="4.79"/>
<vertex x="10.31" y="4.91"/>
<vertex x="10.55" y="5"/>
<vertex x="10.8" y="5.07"/>
</polygon>
<vertex x="14.28" y="6.72"/>
<vertex x="14.42" y="6.75"/>
<vertex x="14.56" y="6.77"/>
<vertex x="14.7" y="6.8"/>
<vertex x="14.83" y="6.82"/>
<vertex x="14.97" y="6.85"/>
<vertex x="15.11" y="6.87"/>
<vertex x="15.25" y="6.9"/>
<vertex x="15.39" y="6.92"/>
<vertex x="15.39" y="6.82"/>
<vertex x="15.39" y="6.72"/>
<vertex x="15.39" y="6.62"/>
<vertex x="15.39" y="6.53"/>
<vertex x="15.39" y="6.43"/>
<vertex x="15.39" y="6.33"/>
<vertex x="15.39" y="6.23"/>
<vertex x="15.39" y="6.13"/>
<vertex x="15.49" y="6.32"/>
<vertex x="15.62" y="6.5"/>
<vertex x="15.77" y="6.65"/>
<vertex x="15.94" y="6.78"/>
<vertex x="16.12" y="6.89"/>
<vertex x="16.32" y="6.97"/>
<vertex x="16.53" y="7.02"/>
<vertex x="16.75" y="7.03"/>
<vertex x="16.78" y="7.03"/>
<vertex x="16.81" y="7.03"/>
<vertex x="16.85" y="7.03"/>
<vertex x="16.88" y="7.03"/>
<vertex x="16.91" y="7.02"/>
<vertex x="16.94" y="7.01"/>
<vertex x="16.97" y="7"/>
<vertex x="17" y="6.99"/>
<vertex x="17" y="6.86"/>
<vertex x="17" y="6.72"/>
<vertex x="17" y="6.59"/>
<vertex x="17" y="6.45"/>
<vertex x="17" y="6.32"/>
<vertex x="17" y="6.18"/>
<vertex x="17" y="6.05"/>
<vertex x="17" y="5.91"/>
<vertex x="16.96" y="5.92"/>
<vertex x="16.91" y="5.93"/>
<vertex x="16.86" y="5.94"/>
<vertex x="16.81" y="5.94"/>
<vertex x="16.75" y="5.95"/>
<vertex x="16.69" y="5.95"/>
<vertex x="16.64" y="5.95"/>
<vertex x="16.58" y="5.95"/>
<vertex x="16.29" y="5.92"/>
<vertex x="16.04" y="5.84"/>
<vertex x="15.84" y="5.72"/>
<vertex x="15.69" y="5.55"/>
<vertex x="15.57" y="5.35"/>
<vertex x="15.49" y="5.12"/>
<vertex x="15.45" y="4.86"/>
<vertex x="15.44" y="4.59"/>
<vertex x="15.44" y="4.35"/>
<vertex x="15.44" y="4.11"/>
<vertex x="15.44" y="3.87"/>
<vertex x="15.44" y="3.63"/>
<vertex x="15.44" y="3.39"/>
<vertex x="15.44" y="3.16"/>
<vertex x="15.44" y="2.92"/>
<vertex x="15.44" y="2.68"/>
<vertex x="15.29" y="2.68"/>
<vertex x="15.14" y="2.68"/>
<vertex x="15" y="2.68"/>
<vertex x="14.85" y="2.68"/>
<vertex x="14.71" y="2.68"/>
<vertex x="14.56" y="2.68"/>
<vertex x="14.42" y="2.68"/>
<vertex x="14.27" y="2.68"/>
<vertex x="14.27" y="3.18"/>
<vertex x="14.27" y="3.69"/>
<vertex x="14.27" y="4.19"/>
<vertex x="14.27" y="4.7"/>
<vertex x="14.27" y="5.21"/>
<vertex x="14.27" y="5.71"/>
<vertex x="14.27" y="6.22"/>
</polygon>
<vertex x="17.46" y="7.9"/>
<vertex x="18.63" y="8.54"/>
<vertex x="18.63" y="5.39"/>
<vertex x="20.1" y="6.92"/>
<vertex x="21.47" y="6.92"/>
<vertex x="19.87" y="5.36"/>
<vertex x="21.65" y="2.68"/>
<vertex x="20.24" y="2.68"/>
<vertex x="19.08" y="4.57"/>
<vertex x="18.63" y="4.14"/>
<vertex x="18.63" y="2.68"/>
<vertex x="17.46" y="2.68"/>
</polygon>
<vertex x="22.36" y="6.14"/>
<vertex x="22.22" y="6.14"/>
<vertex x="22.08" y="6.14"/>
<vertex x="21.93" y="6.14"/>
<vertex x="21.79" y="6.14"/>
<vertex x="21.64" y="6.14"/>
<vertex x="21.5" y="6.14"/>
<vertex x="21.36" y="6.14"/>
<vertex x="21.21" y="6.14"/>
<vertex x="21.31" y="6.24"/>
<vertex x="21.41" y="6.34"/>
<vertex x="21.51" y="6.43"/>
<vertex x="21.61" y="6.53"/>
<vertex x="21.71" y="6.63"/>
<vertex x="21.81" y="6.73"/>
<vertex x="21.91" y="6.82"/>
<vertex x="22.01" y="6.92"/>
<vertex x="22.05" y="6.92"/>
<vertex x="22.1" y="6.92"/>
<vertex x="22.14" y="6.92"/>
<vertex x="22.19" y="6.92"/>
<vertex x="22.23" y="6.92"/>
<vertex x="22.27" y="6.92"/>
<vertex x="22.32" y="6.92"/>
<vertex x="22.36" y="6.92"/>
<vertex x="22.36" y="6.96"/>
<vertex x="22.36" y="7"/>
<vertex x="22.36" y="7.04"/>
<vertex x="22.36" y="7.08"/>
<vertex x="22.36" y="7.13"/>
<vertex x="22.36" y="7.17"/>
<vertex x="22.36" y="7.21"/>
<vertex x="22.36" y="7.25"/>
<vertex x="22.38" y="7.52"/>
<vertex x="22.45" y="7.77"/>
<vertex x="22.56" y="7.99"/>
<vertex x="22.72" y="8.18"/>
<vertex x="22.91" y="8.33"/>
<vertex x="23.16" y="8.44"/>
<vertex x="23.45" y="8.51"/>
<vertex x="23.78" y="8.54"/>
<vertex x="23.86" y="8.54"/>
<vertex x="23.94" y="8.53"/>
<vertex x="24.02" y="8.53"/>
<vertex x="24.09" y="8.53"/>
<vertex x="24.17" y="8.52"/>
<vertex x="24.25" y="8.51"/>
<vertex x="24.32" y="8.51"/>
<vertex x="24.4" y="8.51"/>
<vertex x="24.4" y="8.4"/>
<vertex x="24.4" y="8.29"/>
<vertex x="24.4" y="8.18"/>
<vertex x="24.4" y="8.07"/>
<vertex x="24.4" y="7.97"/>
<vertex x="24.4" y="7.86"/>
<vertex x="24.4" y="7.75"/>
<vertex x="24.4" y="7.64"/>
<vertex x="24.34" y="7.65"/>
<vertex x="24.29" y="7.65"/>
<vertex x="24.24" y="7.65"/>
<vertex x="24.18" y="7.66"/>
<vertex x="24.13" y="7.66"/>
<vertex x="24.08" y="7.66"/>
<vertex x="24.02" y="7.66"/>
<vertex x="23.97" y="7.66"/>
<vertex x="23.86" y="7.65"/>
<vertex x="23.77" y="7.63"/>
<vertex x="23.69" y="7.6"/>
<vertex x="23.63" y="7.55"/>
<vertex x="23.58" y="7.48"/>
<vertex x="23.55" y="7.4"/>
<vertex x="23.53" y="7.3"/>
<vertex x="23.53" y="7.18"/>
<vertex x="23.53" y="7.14"/>
<vertex x="23.53" y="7.11"/>
<vertex x="23.53" y="7.08"/>
<vertex x="23.53" y="7.05"/>
<vertex x="23.53" y="7.02"/>
<vertex x="23.53" y="6.98"/>
<vertex x="23.53" y="6.95"/>
<vertex x="23.53" y="6.92"/>
<vertex x="23.63" y="6.92"/>
<vertex x="23.73" y="6.92"/>
<vertex x="23.83" y="6.92"/>
<vertex x="23.93" y="6.92"/>
<vertex x="24.03" y="6.92"/>
<vertex x="24.13" y="6.92"/>
<vertex x="24.23" y="6.92"/>
<vertex x="24.33" y="6.92"/>
<vertex x="24.33" y="6.82"/>
<vertex x="24.33" y="6.73"/>
<vertex x="24.33" y="6.63"/>
<vertex x="24.33" y="6.53"/>
<vertex x="24.33" y="6.43"/>
<vertex x="24.33" y="6.34"/>
<vertex x="24.33" y="6.24"/>
<vertex x="24.33" y="6.14"/>
<vertex x="24.23" y="6.14"/>
<vertex x="24.13" y="6.14"/>
<vertex x="24.03" y="6.14"/>
<vertex x="23.93" y="6.14"/>
<vertex x="23.83" y="6.14"/>
<vertex x="23.73" y="6.14"/>
<vertex x="23.63" y="6.14"/>
<vertex x="23.53" y="6.14"/>
<vertex x="23.53" y="5.71"/>
<vertex x="23.53" y="5.28"/>
<vertex x="23.53" y="4.84"/>
<vertex x="23.53" y="4.41"/>
<vertex x="23.53" y="3.98"/>
<vertex x="23.53" y="3.54"/>
<vertex x="23.53" y="3.11"/>
<vertex x="23.53" y="2.68"/>
<vertex x="23.38" y="2.68"/>
<vertex x="23.24" y="2.68"/>
<vertex x="23.09" y="2.68"/>
<vertex x="22.94" y="2.68"/>
<vertex x="22.8" y="2.68"/>
<vertex x="22.65" y="2.68"/>
<vertex x="22.51" y="2.68"/>
<vertex x="22.36" y="2.68"/>
<vertex x="22.36" y="3.11"/>
<vertex x="22.36" y="3.54"/>
<vertex x="22.36" y="3.98"/>
<vertex x="22.36" y="4.41"/>
<vertex x="22.36" y="4.84"/>
<vertex x="22.36" y="5.28"/>
<vertex x="22.36" y="5.71"/>
</polygon>
<vertex x="28.64" y="2.68"/>
<vertex x="28.5" y="2.68"/>
<vertex x="28.36" y="2.68"/>
<vertex x="28.22" y="2.68"/>
<vertex x="28.08" y="2.68"/>
<vertex x="27.95" y="2.68"/>
<vertex x="27.81" y="2.68"/>
<vertex x="27.67" y="2.68"/>
<vertex x="27.53" y="2.68"/>
<vertex x="27.53" y="2.75"/>
<vertex x="27.53" y="2.83"/>
<vertex x="27.53" y="2.9"/>
<vertex x="27.53" y="2.97"/>
<vertex x="27.53" y="3.05"/>
<vertex x="27.53" y="3.12"/>
<vertex x="27.53" y="3.2"/>
<vertex x="27.53" y="3.27"/>
<vertex x="27.52" y="3.27"/>
<vertex x="27.4" y="3.1"/>
<vertex x="27.26" y="2.96"/>
<vertex x="27.11" y="2.83"/>
<vertex x="26.94" y="2.74"/>
<vertex x="26.77" y="2.66"/>
<vertex x="26.59" y="2.61"/>
<vertex x="26.41" y="2.57"/>
<vertex x="26.22" y="2.56"/>
<vertex x="25.8" y="2.6"/>
<vertex x="25.46" y="2.69"/>
<vertex x="25.19" y="2.84"/>
<vertex x="24.98" y="3.04"/>
<vertex x="24.83" y="3.3"/>
<vertex x="24.74" y="3.6"/>
<vertex x="24.69" y="3.93"/>
<vertex x="24.67" y="4.31"/>
<vertex x="24.67" y="4.64"/>
<vertex x="24.67" y="4.96"/>
<vertex x="24.67" y="5.29"/>
<vertex x="24.67" y="5.62"/>
<vertex x="24.67" y="5.94"/>
<vertex x="24.67" y="6.27"/>
<vertex x="24.67" y="6.59"/>
<vertex x="24.67" y="6.92"/>
<vertex x="24.82" y="6.92"/>
<vertex x="24.96" y="6.92"/>
<vertex x="25.11" y="6.92"/>
<vertex x="25.25" y="6.92"/>
<vertex x="25.4" y="6.92"/>
<vertex x="25.54" y="6.92"/>
<vertex x="25.69" y="6.92"/>
<vertex x="25.83" y="6.92"/>
<vertex x="25.83" y="6.62"/>
<vertex x="25.83" y="6.32"/>
<vertex x="25.83" y="6.02"/>
<vertex x="25.83" y="5.72"/>
<vertex x="25.83" y="5.42"/>
<vertex x="25.83" y="5.12"/>
<vertex x="25.83" y="4.82"/>
<vertex x="25.83" y="4.53"/>
<vertex x="25.85" y="4.28"/>
<vertex x="25.88" y="4.07"/>
<vertex x="25.93" y="3.89"/>
<vertex x="26" y="3.74"/>
<vertex x="26.1" y="3.63"/>
<vertex x="26.23" y="3.55"/>
<vertex x="26.39" y="3.5"/>
<vertex x="26.58" y="3.48"/>
<vertex x="26.8" y="3.5"/>
<vertex x="26.99" y="3.55"/>
<vertex x="27.15" y="3.64"/>
<vertex x="27.27" y="3.77"/>
<vertex x="27.37" y="3.93"/>
<vertex x="27.43" y="4.14"/>
<vertex x="27.47" y="4.4"/>
<vertex x="27.48" y="4.7"/>
<vertex x="27.48" y="4.97"/>
<vertex x="27.48" y="5.25"/>
<vertex x="27.48" y="5.53"/>
<vertex x="27.48" y="5.81"/>
<vertex x="27.48" y="6.09"/>
<vertex x="27.48" y="6.36"/>
<vertex x="27.48" y="6.64"/>
<vertex x="27.48" y="6.92"/>
<vertex x="27.63" y="6.92"/>
<vertex x="27.78" y="6.92"/>
<vertex x="27.92" y="6.92"/>
<vertex x="28.07" y="6.92"/>
<vertex x="28.21" y="6.92"/>
<vertex x="28.36" y="6.92"/>
<vertex x="28.5" y="6.92"/>
<vertex x="28.65" y="6.92"/>
<vertex x="28.65" y="6.39"/>
<vertex x="28.65" y="5.86"/>
<vertex x="28.65" y="5.33"/>
<vertex x="28.65" y="4.8"/>
<vertex x="28.65" y="4.27"/>
<vertex x="28.65" y="3.74"/>
<vertex x="28.65" y="3.21"/>
</polygon>
<vertex x="29.28" y="6.92"/>
<vertex x="29.42" y="6.92"/>
<vertex x="29.56" y="6.92"/>
<vertex x="29.7" y="6.92"/>
<vertex x="29.83" y="6.92"/>
<vertex x="29.97" y="6.92"/>
<vertex x="30.11" y="6.92"/>
<vertex x="30.25" y="6.92"/>
<vertex x="30.39" y="6.92"/>
<vertex x="30.39" y="6.85"/>
<vertex x="30.39" y="6.77"/>
<vertex x="30.39" y="6.7"/>
<vertex x="30.39" y="6.63"/>
<vertex x="30.39" y="6.55"/>
<vertex x="30.39" y="6.48"/>
<vertex x="30.39" y="6.41"/>
<vertex x="30.39" y="6.33"/>
<vertex x="30.4" y="6.33"/>
<vertex x="30.52" y="6.5"/>
<vertex x="30.66" y="6.65"/>
<vertex x="30.81" y="6.77"/>
<vertex x="30.98" y="6.87"/>
<vertex x="31.15" y="6.94"/>
<vertex x="31.33" y="6.99"/>
<vertex x="31.51" y="7.03"/>
<vertex x="31.7" y="7.04"/>
<vertex x="32.12" y="7"/>
<vertex x="32.46" y="6.91"/>
<vertex x="32.73" y="6.76"/>
<vertex x="32.94" y="6.56"/>
<vertex x="33.08" y="6.3"/>
<vertex x="33.18" y="6.01"/>
<vertex x="33.23" y="5.67"/>
<vertex x="33.25" y="5.29"/>
<vertex x="33.25" y="4.96"/>
<vertex x="33.25" y="4.64"/>
<vertex x="33.25" y="4.31"/>
<vertex x="33.25" y="3.99"/>
<vertex x="33.25" y="3.66"/>
<vertex x="33.25" y="3.33"/>
<vertex x="33.25" y="3.01"/>
<vertex x="33.25" y="2.68"/>
<vertex x="33.1" y="2.68"/>
<vertex x="32.96" y="2.68"/>
<vertex x="32.81" y="2.68"/>
<vertex x="32.67" y="2.68"/>
<vertex x="32.52" y="2.68"/>
<vertex x="32.37" y="2.68"/>
<vertex x="32.23" y="2.68"/>
<vertex x="32.08" y="2.68"/>
<vertex x="32.08" y="2.98"/>
<vertex x="32.08" y="3.28"/>
<vertex x="32.08" y="3.58"/>
<vertex x="32.08" y="3.88"/>
<vertex x="32.08" y="4.18"/>
<vertex x="32.08" y="4.48"/>
<vertex x="32.08" y="4.78"/>
<vertex x="32.08" y="5.08"/>
<vertex x="32.07" y="5.32"/>
<vertex x="32.04" y="5.53"/>
<vertex x="31.99" y="5.71"/>
<vertex x="31.92" y="5.86"/>
<vertex x="31.81" y="5.97"/>
<vertex x="31.68" y="6.05"/>
<vertex x="31.53" y="6.1"/>
<vertex x="31.34" y="6.12"/>
<vertex x="31.12" y="6.1"/>
<vertex x="30.93" y="6.05"/>
<vertex x="30.77" y="5.96"/>
<vertex x="30.65" y="5.83"/>
<vertex x="30.55" y="5.67"/>
<vertex x="30.49" y="5.46"/>
<vertex x="30.45" y="5.2"/>
<vertex x="30.43" y="4.9"/>
<vertex x="30.43" y="4.63"/>
<vertex x="30.43" y="4.35"/>
<vertex x="30.43" y="4.07"/>
<vertex x="30.43" y="3.79"/>
<vertex x="30.43" y="3.51"/>
<vertex x="30.43" y="3.24"/>
<vertex x="30.43" y="2.96"/>
<vertex x="30.43" y="2.68"/>
<vertex x="30.29" y="2.68"/>
<vertex x="30.14" y="2.68"/>
<vertex x="30" y="2.68"/>
<vertex x="29.85" y="2.68"/>
<vertex x="29.71" y="2.68"/>
<vertex x="29.56" y="2.68"/>
<vertex x="29.41" y="2.68"/>
<vertex x="29.27" y="2.68"/>
<vertex x="29.27" y="3.21"/>
<vertex x="29.27" y="3.74"/>
<vertex x="29.27" y="4.27"/>
<vertex x="29.27" y="4.8"/>
<vertex x="29.27" y="5.33"/>
<vertex x="29.27" y="5.86"/>
<vertex x="29.27" y="6.39"/>
</polygon>
<vertex x="24.01" y="14.2"/>
<vertex x="24.02" y="14.18"/>
<vertex x="24.03" y="14.13"/>
<vertex x="24.03" y="14.05"/>
<vertex x="24.02" y="13.96"/>
<vertex x="24" y="13.87"/>
<vertex x="23.96" y="13.79"/>
<vertex x="23.88" y="13.72"/>
<vertex x="23.77" y="13.68"/>
<vertex x="23.68" y="13.68"/>
<vertex x="23.57" y="13.7"/>
<vertex x="23.46" y="13.74"/>
<vertex x="23.35" y="13.79"/>
<vertex x="23.23" y="13.86"/>
<vertex x="23.13" y="13.94"/>
<vertex x="23.03" y="14.03"/>
<vertex x="22.95" y="14.12"/>
<vertex x="22.87" y="14.22"/>
<vertex x="22.82" y="14.32"/>
<vertex x="22.79" y="14.42"/>
<vertex x="22.78" y="14.51"/>
<vertex x="22.79" y="14.6"/>
<vertex x="22.82" y="14.69"/>
<vertex x="22.86" y="14.77"/>
<vertex x="22.93" y="14.84"/>
<vertex x="23.04" y="14.94"/>
<vertex x="23.16" y="15.01"/>
<vertex x="23.29" y="15.04"/>
<vertex x="23.41" y="15.06"/>
<vertex x="23.52" y="15.06"/>
<vertex x="23.61" y="15.05"/>
<vertex x="23.67" y="15.04"/>
<vertex x="23.69" y="15.04"/>
<vertex x="23.65" y="15.07"/>
<vertex x="23.54" y="15.15"/>
<vertex x="23.36" y="15.25"/>
<vertex x="23.13" y="15.34"/>
<vertex x="22.86" y="15.41"/>
<vertex x="22.56" y="15.42"/>
<vertex x="22.23" y="15.35"/>
<vertex x="21.89" y="15.18"/>
<vertex x="21.63" y="14.96"/>
<vertex x="21.46" y="14.72"/>
<vertex x="21.38" y="14.47"/>
<vertex x="21.38" y="14.22"/>
<vertex x="21.45" y="13.95"/>
<vertex x="21.59" y="13.69"/>
<vertex x="21.79" y="13.43"/>
<vertex x="22.04" y="13.18"/>
<vertex x="22.24" y="12.95"/>
<vertex x="22.33" y="12.72"/>
<vertex x="22.34" y="12.51"/>
<vertex x="22.28" y="12.32"/>
<vertex x="22.15" y="12.17"/>
<vertex x="21.97" y="12.06"/>
<vertex x="21.75" y="11.99"/>
<vertex x="21.51" y="11.99"/>
<vertex x="21.35" y="12.03"/>
<vertex x="21.22" y="12.09"/>
<vertex x="21.11" y="12.17"/>
<vertex x="21.03" y="12.26"/>
<vertex x="20.97" y="12.36"/>
<vertex x="20.94" y="12.46"/>
<vertex x="20.94" y="12.56"/>
<vertex x="20.97" y="12.65"/>
<vertex x="21.02" y="12.72"/>
<vertex x="21.08" y="12.78"/>
<vertex x="21.15" y="12.83"/>
<vertex x="21.22" y="12.88"/>
<vertex x="21.29" y="12.91"/>
<vertex x="21.34" y="12.94"/>
<vertex x="21.38" y="12.95"/>
<vertex x="21.4" y="12.96"/>
<vertex x="21.38" y="12.97"/>
<vertex x="21.33" y="12.98"/>
<vertex x="21.25" y="13"/>
<vertex x="21.15" y="13.02"/>
<vertex x="21.03" y="13.03"/>
<vertex x="20.89" y="13.02"/>
<vertex x="20.73" y="13"/>
<vertex x="20.57" y="12.95"/>
<vertex x="20.43" y="12.88"/>
<vertex x="20.29" y="12.79"/>
<vertex x="20.17" y="12.68"/>
<vertex x="20.06" y="12.55"/>
<vertex x="19.97" y="12.38"/>
<vertex x="19.91" y="12.17"/>
<vertex x="19.87" y="11.92"/>
<vertex x="19.87" y="11.64"/>
<vertex x="19.87" y="11.16"/>
<vertex x="19.87" y="10.67"/>
<vertex x="19.87" y="10.19"/>
<vertex x="19.87" y="9.71"/>
<vertex x="19.87" y="9.23"/>
<vertex x="19.87" y="8.75"/>
<vertex x="19.87" y="8.27"/>
<vertex x="19.87" y="7.79"/>
<vertex x="19.89" y="7.81"/>
<vertex x="19.94" y="7.88"/>
<vertex x="20.02" y="7.98"/>
<vertex x="20.14" y="8.11"/>
<vertex x="20.27" y="8.27"/>
<vertex x="20.42" y="8.44"/>
<vertex x="20.59" y="8.63"/>
<vertex x="20.77" y="8.82"/>
<vertex x="20.96" y="9.03"/>
<vertex x="21.13" y="9.22"/>
<vertex x="21.29" y="9.39"/>
<vertex x="21.44" y="9.53"/>
<vertex x="21.59" y="9.64"/>
<vertex x="21.75" y="9.71"/>
<vertex x="21.93" y="9.75"/>
<vertex x="22.12" y="9.76"/>
<vertex x="22.51" y="9.76"/>
<vertex x="22.86" y="9.8"/>
<vertex x="23.19" y="9.89"/>
<vertex x="23.5" y="10.03"/>
<vertex x="23.78" y="10.2"/>
<vertex x="24.03" y="10.41"/>
<vertex x="24.26" y="10.65"/>
<vertex x="24.47" y="10.91"/>
<vertex x="24.76" y="11.46"/>
<vertex x="24.91" y="12.01"/>
<vertex x="24.94" y="12.54"/>
<vertex x="24.87" y="13.02"/>
<vertex x="24.71" y="13.45"/>
<vertex x="24.51" y="13.8"/>
<vertex x="24.27" y="14.06"/>
<vertex x="24.01" y="14.21"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.4">
<vertex x="2.21" y="5.41"/>
<vertex x="2.24" y="5.18"/>
<vertex x="2.31" y="4.98"/>
<vertex x="2.43" y="4.82"/>
<vertex x="2.58" y="4.69"/>
<vertex x="2.76" y="4.59"/>
<vertex x="2.97" y="4.51"/>
<vertex x="3.18" y="4.47"/>
<vertex x="3.41" y="4.46"/>
<vertex x="3.57" y="4.47"/>
<vertex x="3.75" y="4.49"/>
<vertex x="3.92" y="4.54"/>
<vertex x="4.08" y="4.61"/>
<vertex x="4.22" y="4.71"/>
<vertex x="4.33" y="4.84"/>
<vertex x="4.4" y="4.99"/>
<vertex x="4.42" y="5.18"/>
<vertex x="4.39" y="5.34"/>
<vertex x="4.3" y="5.48"/>
<vertex x="4.16" y="5.6"/>
<vertex x="3.96" y="5.71"/>
<vertex x="3.7" y="5.8"/>
<vertex x="3.4" y="5.89"/>
<vertex x="3.05" y="5.97"/>
<vertex x="2.66" y="6.06"/>
<vertex x="2.32" y="6.14"/>
<vertex x="2" y="6.24"/>
<vertex x="1.69" y="6.36"/>
<vertex x="1.42" y="6.51"/>
<vertex x="1.2" y="6.7"/>
<vertex x="1.02" y="6.93"/>
<vertex x="0.91" y="7.22"/>
<vertex x="0.87" y="7.57"/>
<vertex x="0.92" y="8.06"/>
<vertex x="1.08" y="8.46"/>
<vertex x="1.33" y="8.77"/>
<vertex x="1.64" y="9.02"/>
<vertex x="2.02" y="9.19"/>
<vertex x="2.43" y="9.3"/>
<vertex x="2.87" y="9.36"/>
<vertex x="3.33" y="9.38"/>
<vertex x="3.78" y="9.36"/>
<vertex x="4.22" y="9.3"/>
<vertex x="4.62" y="9.18"/>
<vertex x="4.99" y="9"/>
<vertex x="5.3" y="8.76"/>
<vertex x="5.55" y="8.45"/>
<vertex x="5.73" y="8.05"/>
<vertex x="5.82" y="7.58"/>
<vertex x="5.64" y="7.58"/>
<vertex x="5.45" y="7.58"/>
<vertex x="5.27" y="7.58"/>
<vertex x="5.08" y="7.58"/>
<vertex x="4.9" y="7.58"/>
<vertex x="4.72" y="7.58"/>
<vertex x="4.53" y="7.58"/>
<vertex x="4.35" y="7.58"/>
<vertex x="4.31" y="7.78"/>
<vertex x="4.24" y="7.95"/>
<vertex x="4.14" y="8.08"/>
<vertex x="4.01" y="8.19"/>
<vertex x="3.85" y="8.26"/>
<vertex x="3.68" y="8.31"/>
<vertex x="3.49" y="8.34"/>
<vertex x="3.28" y="8.34"/>
<vertex x="3.15" y="8.34"/>
<vertex x="3" y="8.33"/>
<vertex x="2.86" y="8.3"/>
<vertex x="2.72" y="8.26"/>
<vertex x="2.6" y="8.19"/>
<vertex x="2.51" y="8.1"/>
<vertex x="2.44" y="7.97"/>
<vertex x="2.42" y="7.82"/>
<vertex x="2.46" y="7.63"/>
<vertex x="2.57" y="7.48"/>
<vertex x="2.75" y="7.36"/>
<vertex x="2.97" y="7.27"/>
<vertex x="3.24" y="7.19"/>
<vertex x="3.54" y="7.12"/>
<vertex x="3.86" y="7.05"/>
<vertex x="4.18" y="6.98"/>
<vertex x="4.52" y="6.89"/>
<vertex x="4.84" y="6.79"/>
<vertex x="5.15" y="6.66"/>
<vertex x="5.42" y="6.5"/>
<vertex x="5.65" y="6.3"/>
<vertex x="5.82" y="6.05"/>
<vertex x="5.94" y="5.75"/>
<vertex x="5.98" y="5.39"/>
<vertex x="5.92" y="4.88"/>
<vertex x="5.75" y="4.45"/>
<vertex x="5.5" y="4.11"/>
<vertex x="5.16" y="3.85"/>
<vertex x="4.77" y="3.65"/>
<vertex x="4.34" y="3.52"/>
<vertex x="3.87" y="3.44"/>
<vertex x="3.39" y="3.42"/>
<vertex x="2.9" y="3.44"/>
<vertex x="2.43" y="3.52"/>
<vertex x="1.99" y="3.66"/>
<vertex x="1.59" y="3.85"/>
<vertex x="1.25" y="4.12"/>
<vertex x="0.99" y="4.47"/>
<vertex x="0.81" y="4.9"/>
<vertex x="0.74" y="5.41"/>
<vertex x="0.92" y="5.41"/>
<vertex x="1.1" y="5.41"/>
<vertex x="1.29" y="5.41"/>
<vertex x="1.47" y="5.41"/>
<vertex x="1.66" y="5.41"/>
<vertex x="1.84" y="5.41"/>
<vertex x="2.03" y="5.41"/>
</polygon>
<vertex x="10.64" y="5.41"/>
<vertex x="10.73" y="5.72"/>
<vertex x="10.78" y="6.04"/>
<vertex x="10.8" y="6.38"/>
<vertex x="12.35" y="6.34"/>
<vertex x="12.31" y="5.78"/>
<vertex x="12.2" y="5.25"/>
<vertex x="12" y="4.75"/>
</polygon>
<vertex x="11.73" y="4.31"/>
<vertex x="11.38" y="3.95"/>
<vertex x="10.96" y="3.66"/>
<vertex x="10.45" y="3.48"/>
<vertex x="9.87" y="3.42"/>
<vertex x="9.61" y="3.43"/>
<vertex x="9.37" y="3.48"/>
<vertex x="9.13" y="3.54"/>
<vertex x="8.9" y="3.64"/>
<vertex x="8.69" y="3.76"/>
<vertex x="8.5" y="3.91"/>
<vertex x="8.33" y="4.08"/>
<vertex x="8.17" y="4.27"/>
<vertex x="8.16" y="4.27"/>
<vertex x="8.16" y="3.76"/>
<vertex x="8.16" y="3.26"/>
<vertex x="8.16" y="2.75"/>
<vertex x="8.16" y="2.24"/>
<vertex x="8.16" y="1.73"/>
<vertex x="8.16" y="1.22"/>
<vertex x="8.16" y="0.71"/>
<vertex x="8.16" y="0.2"/>
<vertex x="7.97" y="0.37"/>
<vertex x="7.78" y="0.55"/>
<vertex x="7.58" y="0.72"/>
<vertex x="7.39" y="0.89"/>
<vertex x="7.19" y="1.07"/>
<vertex x="7" y="1.24"/>
<vertex x="6.8" y="1.41"/>
<vertex x="6.61" y="1.58"/>
<vertex x="6.61" y="2.51"/>
<vertex x="6.61" y="3.43"/>
<vertex x="6.61" y="4.35"/>
<vertex x="6.61" y="5.28"/>
<vertex x="6.61" y="6.2"/>
<vertex x="6.61" y="7.12"/>
<vertex x="6.61" y="8.04"/>
<vertex x="6.61" y="8.97"/>
<vertex x="6.79" y="9"/>
<vertex x="6.98" y="9.03"/>
<vertex x="7.16" y="9.07"/>
<vertex x="7.35" y="9.1"/>
<vertex x="7.53" y="9.13"/>
<vertex x="7.72" y="9.16"/>
<vertex x="7.9" y="9.2"/>
<vertex x="8.09" y="9.23"/>
<vertex x="8.09" y="9.14"/>
<vertex x="8.09" y="9.05"/>
<vertex x="8.09" y="8.96"/>
<vertex x="8.09" y="8.87"/>
<vertex x="8.09" y="8.78"/>
<vertex x="8.09" y="8.69"/>
<vertex x="8.09" y="8.6"/>
<vertex x="8.09" y="8.51"/>
<vertex x="8.1" y="8.51"/>
<vertex x="8.25" y="8.72"/>
<vertex x="8.42" y="8.9"/>
<vertex x="8.61" y="9.05"/>
<vertex x="8.82" y="9.17"/>
<vertex x="9.04" y="9.27"/>
<vertex x="9.28" y="9.33"/>
<vertex x="9.52" y="9.37"/>
<vertex x="9.78" y="9.38"/>
<vertex x="10.4" y="9.32"/>
<vertex x="10.93" y="9.13"/>
<vertex x="11.37" y="8.84"/>
<vertex x="11.73" y="8.47"/>
<vertex x="12.01" y="8.01"/>
<vertex x="12.2" y="7.5"/>
<vertex x="12.31" y="6.93"/>
<vertex x="10.78" y="6.72"/>
<vertex x="10.72" y="7.05"/>
<vertex x="10.63" y="7.36"/>
<vertex x="10.49" y="7.64"/>
<vertex x="10.31" y="7.87"/>
<vertex x="10.07" y="8.05"/>
<vertex x="9.79" y="8.17"/>
<vertex x="9.44" y="8.21"/>
<vertex x="9.09" y="8.17"/>
<vertex x="8.8" y="8.06"/>
<vertex x="8.57" y="7.88"/>
<vertex x="8.39" y="7.64"/>
<vertex x="8.25" y="7.37"/>
<vertex x="8.16" y="7.06"/>
<vertex x="8.11" y="6.73"/>
<vertex x="8.1" y="6.38"/>
<vertex x="8.11" y="6.04"/>
<vertex x="8.17" y="5.72"/>
<vertex x="8.26" y="5.41"/>
<vertex x="8.4" y="5.14"/>
<vertex x="8.58" y="4.92"/>
<vertex x="8.82" y="4.74"/>
<vertex x="9.11" y="4.63"/>
<vertex x="9.45" y="4.59"/>
<vertex x="9.8" y="4.63"/>
<vertex x="10.09" y="4.74"/>
<vertex x="10.33" y="4.92"/>
<vertex x="10.51" y="5.14"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="14.71" y="6.82"/>
<vertex x="15.07" y="6.86"/>
<vertex x="15.41" y="6.9"/>
<vertex x="15.72" y="6.94"/>
<vertex x="15.91" y="6.11"/>
<vertex x="15.82" y="6.09"/>
<vertex x="15.73" y="6.08"/>
<vertex x="15.64" y="6.07"/>
<vertex x="15.54" y="6.05"/>
<vertex x="15.45" y="6.04"/>
<vertex x="15.36" y="6.02"/>
<vertex x="15.27" y="6.01"/>
<vertex x="15.18" y="5.99"/>
<vertex x="15.09" y="5.97"/>
<vertex x="15.01" y="5.95"/>
</polygon>
<vertex x="14.92" y="5.92"/>
<vertex x="14.84" y="5.89"/>
<vertex x="14.77" y="5.86"/>
<vertex x="14.7" y="5.82"/>
<vertex x="14.63" y="5.77"/>
<vertex x="14.57" y="5.72"/>
<vertex x="14.51" y="5.67"/>
<vertex x="14.47" y="5.6"/>
<vertex x="14.43" y="5.53"/>
<vertex x="14.39" y="5.46"/>
<vertex x="14.37" y="5.37"/>
<vertex x="14.35" y="5.28"/>
<vertex x="14.35" y="5.18"/>
<vertex x="14.35" y="5.07"/>
<vertex x="14.37" y="4.98"/>
<vertex x="14.39" y="4.9"/>
<vertex x="14.43" y="4.82"/>
<vertex x="14.47" y="4.76"/>
<vertex x="14.52" y="4.7"/>
<vertex x="14.57" y="4.65"/>
<vertex x="14.64" y="4.6"/>
<vertex x="14.71" y="4.56"/>
<vertex x="14.78" y="4.53"/>
<vertex x="14.86" y="4.51"/>
<vertex x="14.94" y="4.49"/>
<vertex x="15.03" y="4.47"/>
<vertex x="15.12" y="4.46"/>
<vertex x="15.21" y="4.46"/>
<vertex x="15.3" y="4.46"/>
<vertex x="15.52" y="4.47"/>
<vertex x="15.71" y="4.5"/>
<vertex x="15.87" y="4.55"/>
<vertex x="16.13" y="4.69"/>
<vertex x="16.23" y="4.78"/>
<vertex x="16.32" y="4.87"/>
<vertex x="16.39" y="4.98"/>
<vertex x="16.44" y="5.08"/>
<vertex x="16.48" y="5.19"/>
<vertex x="16.51" y="5.3"/>
<vertex x="16.53" y="5.41"/>
<vertex x="16.55" y="5.51"/>
<vertex x="16.56" y="5.6"/>
<vertex x="16.56" y="5.69"/>
<vertex x="16.56" y="5.76"/>
<vertex x="16.56" y="5.8"/>
<vertex x="16.56" y="5.83"/>
<vertex x="16.56" y="5.87"/>
<vertex x="16.56" y="5.9"/>
<vertex x="16.56" y="5.94"/>
<vertex x="16.56" y="5.98"/>
<vertex x="16.56" y="6.01"/>
<vertex x="16.56" y="6.05"/>
<vertex x="16.56" y="6.08"/>
<vertex x="16.56" y="6.12"/>
<vertex x="16.56" y="6.16"/>
<vertex x="16.56" y="6.19"/>
<vertex x="16.56" y="6.23"/>
<vertex x="16.56" y="6.27"/>
<vertex x="16.56" y="6.3"/>
<vertex x="16.56" y="6.34"/>
<vertex x="16.51" y="6.3"/>
<vertex x="16.45" y="6.26"/>
<vertex x="16.38" y="6.23"/>
<vertex x="16.31" y="6.2"/>
<vertex x="16.24" y="6.18"/>
<vertex x="16.16" y="6.16"/>
<vertex x="16.08" y="6.14"/>
<vertex x="16" y="6.12"/>
<vertex x="16" y="7.01"/>
<vertex x="16.24" y="7.09"/>
<vertex x="16.42" y="7.21"/>
<vertex x="16.53" y="7.36"/>
<vertex x="16.56" y="7.57"/>
<vertex x="16.56" y="7.69"/>
<vertex x="16.54" y="7.79"/>
<vertex x="16.52" y="7.89"/>
<vertex x="16.48" y="7.97"/>
<vertex x="16.44" y="8.04"/>
<vertex x="16.39" y="8.1"/>
<vertex x="16.33" y="8.16"/>
<vertex x="16.26" y="8.2"/>
<vertex x="16.19" y="8.24"/>
<vertex x="16.11" y="8.27"/>
<vertex x="16.03" y="8.29"/>
<vertex x="15.94" y="8.31"/>
<vertex x="15.85" y="8.32"/>
<vertex x="15.76" y="8.33"/>
<vertex x="15.66" y="8.33"/>
<vertex x="15.56" y="8.34"/>
<vertex x="15.45" y="8.33"/>
<vertex x="15.34" y="8.32"/>
<vertex x="15.24" y="8.31"/>
<vertex x="15.15" y="8.29"/>
<vertex x="15.06" y="8.26"/>
<vertex x="14.98" y="8.22"/>
<vertex x="14.9" y="8.18"/>
<vertex x="14.84" y="8.14"/>
<vertex x="14.77" y="8.08"/>
<vertex x="14.72" y="8.02"/>
<vertex x="14.67" y="7.95"/>
<vertex x="14.63" y="7.87"/>
<vertex x="14.59" y="7.79"/>
<vertex x="14.56" y="7.69"/>
<vertex x="14.54" y="7.59"/>
<vertex x="14.53" y="7.48"/>
<vertex x="14.43" y="7.48"/>
<vertex x="14.33" y="7.48"/>
<vertex x="14.24" y="7.48"/>
<vertex x="14.14" y="7.48"/>
<vertex x="14.04" y="7.48"/>
<vertex x="13.94" y="7.48"/>
<vertex x="13.85" y="7.48"/>
<vertex x="13.75" y="7.48"/>
<vertex x="13.65" y="7.48"/>
<vertex x="13.56" y="7.48"/>
<vertex x="13.46" y="7.48"/>
<vertex x="13.36" y="7.48"/>
<vertex x="13.27" y="7.48"/>
<vertex x="13.17" y="7.48"/>
<vertex x="13.07" y="7.48"/>
<vertex x="12.98" y="7.48"/>
<vertex x="13.01" y="7.74"/>
<vertex x="13.06" y="7.98"/>
<vertex x="13.14" y="8.19"/>
<vertex x="13.25" y="8.38"/>
<vertex x="13.38" y="8.56"/>
<vertex x="13.52" y="8.71"/>
<vertex x="13.68" y="8.85"/>
<vertex x="13.86" y="8.97"/>
<vertex x="14.05" y="9.07"/>
<vertex x="14.26" y="9.15"/>
<vertex x="14.47" y="9.22"/>
<vertex x="14.7" y="9.28"/>
<vertex x="14.93" y="9.32"/>
<vertex x="15.16" y="9.35"/>
<vertex x="15.4" y="9.37"/>
<vertex x="15.63" y="9.37"/>
<vertex x="15.85" y="9.37"/>
<vertex x="16.06" y="9.36"/>
<vertex x="16.28" y="9.34"/>
<vertex x="16.5" y="9.31"/>
<vertex x="16.71" y="9.27"/>
<vertex x="16.92" y="9.22"/>
<vertex x="17.11" y="9.15"/>
<vertex x="17.3" y="9.07"/>
<vertex x="17.47" y="8.98"/>
<vertex x="17.63" y="8.87"/>
<vertex x="17.77" y="8.73"/>
<vertex x="17.89" y="8.58"/>
<vertex x="17.99" y="8.41"/>
<vertex x="18.06" y="8.22"/>
<vertex x="18.1" y="8"/>
<vertex x="18.12" y="7.76"/>
<vertex x="18.12" y="7.58"/>
<vertex x="18.12" y="7.39"/>
<vertex x="18.12" y="7.21"/>
<vertex x="18.12" y="7.03"/>
<vertex x="18.12" y="6.84"/>
<vertex x="18.12" y="6.66"/>
<vertex x="18.12" y="6.47"/>
<vertex x="18.12" y="6.29"/>
<vertex x="18.12" y="6.11"/>
<vertex x="18.12" y="5.92"/>
<vertex x="18.12" y="5.74"/>
<vertex x="18.12" y="5.55"/>
<vertex x="18.12" y="5.37"/>
<vertex x="18.12" y="5.19"/>
<vertex x="18.12" y="5"/>
<vertex x="18.12" y="4.82"/>
<vertex x="18.12" y="4.72"/>
<vertex x="18.12" y="4.63"/>
<vertex x="18.12" y="4.53"/>
<vertex x="18.12" y="4.44"/>
<vertex x="18.13" y="4.34"/>
<vertex x="18.14" y="4.25"/>
<vertex x="18.15" y="4.17"/>
<vertex x="18.16" y="4.08"/>
<vertex x="18.17" y="4"/>
<vertex x="18.19" y="3.92"/>
<vertex x="18.2" y="3.85"/>
<vertex x="18.22" y="3.78"/>
<vertex x="18.24" y="3.72"/>
<vertex x="18.26" y="3.66"/>
<vertex x="18.29" y="3.61"/>
<vertex x="18.31" y="3.56"/>
<vertex x="18.21" y="3.56"/>
<vertex x="18.11" y="3.56"/>
<vertex x="18.02" y="3.56"/>
<vertex x="17.92" y="3.56"/>
<vertex x="17.82" y="3.56"/>
<vertex x="17.72" y="3.56"/>
<vertex x="17.62" y="3.56"/>
<vertex x="17.52" y="3.56"/>
<vertex x="17.43" y="3.56"/>
<vertex x="17.33" y="3.56"/>
<vertex x="17.23" y="3.56"/>
<vertex x="17.13" y="3.56"/>
<vertex x="17.03" y="3.56"/>
<vertex x="16.93" y="3.56"/>
<vertex x="16.84" y="3.56"/>
<vertex x="16.74" y="3.56"/>
<vertex x="16.73" y="3.59"/>
<vertex x="16.71" y="3.63"/>
<vertex x="16.7" y="3.66"/>
<vertex x="16.69" y="3.69"/>
<vertex x="16.68" y="3.73"/>
<vertex x="16.67" y="3.76"/>
<vertex x="16.66" y="3.8"/>
<vertex x="16.65" y="3.83"/>
<vertex x="16.65" y="3.86"/>
<vertex x="16.64" y="3.9"/>
<vertex x="16.64" y="3.93"/>
<vertex x="16.64" y="3.97"/>
<vertex x="16.63" y="4"/>
<vertex x="16.63" y="4.04"/>
<vertex x="16.63" y="4.07"/>
<vertex x="16.63" y="4.11"/>
<vertex x="16.53" y="4.01"/>
<vertex x="16.44" y="3.93"/>
<vertex x="16.33" y="3.85"/>
<vertex x="16.22" y="3.78"/>
<vertex x="16.11" y="3.72"/>
<vertex x="16" y="3.66"/>
<vertex x="15.88" y="3.61"/>
<vertex x="15.76" y="3.56"/>
<vertex x="15.63" y="3.53"/>
<vertex x="15.51" y="3.49"/>
<vertex x="15.38" y="3.47"/>
<vertex x="15.25" y="3.44"/>
<vertex x="15.12" y="3.43"/>
<vertex x="14.99" y="3.41"/>
<vertex x="14.86" y="3.41"/>
<vertex x="14.73" y="3.41"/>
<vertex x="14.53" y="3.41"/>
<vertex x="14.33" y="3.43"/>
<vertex x="14.15" y="3.46"/>
<vertex x="13.97" y="3.51"/>
<vertex x="13.8" y="3.56"/>
<vertex x="13.64" y="3.63"/>
<vertex x="13.49" y="3.72"/>
<vertex x="13.36" y="3.82"/>
<vertex x="13.24" y="3.93"/>
<vertex x="13.13" y="4.05"/>
<vertex x="13.03" y="4.19"/>
<vertex x="12.95" y="4.34"/>
<vertex x="12.89" y="4.51"/>
<vertex x="12.84" y="4.69"/>
<vertex x="12.81" y="4.89"/>
<vertex x="12.8" y="5.1"/>
<vertex x="12.85" y="5.54"/>
<vertex x="12.97" y="5.89"/>
<vertex x="13.16" y="6.17"/>
<vertex x="13.41" y="6.39"/>
<vertex x="13.69" y="6.55"/>
<vertex x="14.02" y="6.67"/>
<vertex x="14.36" y="6.76"/>
</polygon>
<vertex x="18.99" y="8.97"/>
<vertex x="19.18" y="9"/>
<vertex x="19.36" y="9.03"/>
<vertex x="19.55" y="9.06"/>
<vertex x="19.73" y="9.1"/>
<vertex x="19.92" y="9.13"/>
<vertex x="20.1" y="9.16"/>
<vertex x="20.29" y="9.19"/>
<vertex x="20.47" y="9.23"/>
<vertex x="20.47" y="9.1"/>
<vertex x="20.47" y="8.97"/>
<vertex x="20.47" y="8.83"/>
<vertex x="20.47" y="8.7"/>
<vertex x="20.47" y="8.57"/>
<vertex x="20.47" y="8.44"/>
<vertex x="20.47" y="8.31"/>
<vertex x="20.47" y="8.18"/>
<vertex x="20.48" y="8.18"/>
<vertex x="20.61" y="8.43"/>
<vertex x="20.78" y="8.66"/>
<vertex x="20.98" y="8.87"/>
<vertex x="21.2" y="9.05"/>
<vertex x="21.45" y="9.19"/>
<vertex x="21.72" y="9.29"/>
<vertex x="22" y="9.36"/>
<vertex x="22.28" y="9.38"/>
<vertex x="22.33" y="9.38"/>
<vertex x="22.37" y="9.38"/>
<vertex x="22.42" y="9.37"/>
<vertex x="22.46" y="9.37"/>
<vertex x="22.5" y="9.36"/>
<vertex x="22.54" y="9.35"/>
<vertex x="22.58" y="9.34"/>
<vertex x="22.62" y="9.33"/>
<vertex x="22.62" y="9.15"/>
<vertex x="22.62" y="8.97"/>
<vertex x="22.62" y="8.78"/>
<vertex x="22.62" y="8.6"/>
<vertex x="22.62" y="8.42"/>
<vertex x="22.62" y="8.24"/>
<vertex x="22.62" y="8.06"/>
<vertex x="22.62" y="7.88"/>
<vertex x="22.57" y="7.89"/>
<vertex x="22.5" y="7.91"/>
<vertex x="22.43" y="7.92"/>
<vertex x="22.36" y="7.93"/>
<vertex x="22.29" y="7.93"/>
<vertex x="22.21" y="7.93"/>
<vertex x="22.14" y="7.93"/>
<vertex x="22.07" y="7.94"/>
<vertex x="21.67" y="7.9"/>
<vertex x="21.34" y="7.79"/>
<vertex x="21.08" y="7.63"/>
<vertex x="20.87" y="7.41"/>
<vertex x="20.72" y="7.14"/>
<vertex x="20.61" y="6.83"/>
<vertex x="20.55" y="6.49"/>
<vertex x="20.53" y="6.12"/>
<vertex x="20.53" y="5.8"/>
<vertex x="20.53" y="5.48"/>
<vertex x="20.53" y="5.16"/>
<vertex x="20.53" y="4.85"/>
<vertex x="20.53" y="4.53"/>
<vertex x="20.53" y="4.21"/>
<vertex x="20.53" y="3.89"/>
<vertex x="20.53" y="3.57"/>
<vertex x="20.34" y="3.57"/>
<vertex x="20.15" y="3.57"/>
<vertex x="19.95" y="3.57"/>
<vertex x="19.76" y="3.57"/>
<vertex x="19.56" y="3.57"/>
<vertex x="19.37" y="3.57"/>
<vertex x="19.17" y="3.57"/>
<vertex x="18.98" y="3.57"/>
<vertex x="18.98" y="4.25"/>
<vertex x="18.98" y="4.92"/>
<vertex x="18.98" y="5.59"/>
<vertex x="18.98" y="6.27"/>
<vertex x="18.98" y="6.94"/>
<vertex x="18.98" y="7.62"/>
<vertex x="18.98" y="8.29"/>
</polygon>
<vertex x="23.24" y="10.53"/>
<vertex x="24.79" y="11.38"/>
<vertex x="24.79" y="7.19"/>
<vertex x="26.75" y="9.23"/>
<vertex x="28.59" y="9.23"/>
<vertex x="26.45" y="7.15"/>
<vertex x="28.83" y="3.57"/>
<vertex x="26.94" y="3.57"/>
<vertex x="25.39" y="6.1"/>
<vertex x="24.79" y="5.52"/>
<vertex x="24.79" y="3.57"/>
<vertex x="23.24" y="3.57"/>
</polygon>
<vertex x="29.77" y="8.19"/>
<vertex x="29.58" y="8.19"/>
<vertex x="29.39" y="8.19"/>
<vertex x="29.2" y="8.19"/>
<vertex x="29" y="8.19"/>
<vertex x="28.81" y="8.19"/>
<vertex x="28.62" y="8.19"/>
<vertex x="28.43" y="8.19"/>
<vertex x="28.24" y="8.19"/>
<vertex x="28.37" y="8.32"/>
<vertex x="28.5" y="8.45"/>
<vertex x="28.64" y="8.58"/>
<vertex x="28.77" y="8.71"/>
<vertex x="28.9" y="8.84"/>
<vertex x="29.03" y="8.97"/>
<vertex x="29.17" y="9.1"/>
<vertex x="29.3" y="9.23"/>
<vertex x="29.36" y="9.23"/>
<vertex x="29.42" y="9.23"/>
<vertex x="29.48" y="9.23"/>
<vertex x="29.53" y="9.23"/>
<vertex x="29.59" y="9.23"/>
<vertex x="29.65" y="9.23"/>
<vertex x="29.71" y="9.23"/>
<vertex x="29.77" y="9.23"/>
<vertex x="29.77" y="9.28"/>
<vertex x="29.77" y="9.34"/>
<vertex x="29.77" y="9.39"/>
<vertex x="29.77" y="9.45"/>
<vertex x="29.77" y="9.5"/>
<vertex x="29.77" y="9.56"/>
<vertex x="29.77" y="9.61"/>
<vertex x="29.77" y="9.66"/>
<vertex x="29.8" y="10.03"/>
<vertex x="29.89" y="10.36"/>
<vertex x="30.03" y="10.65"/>
<vertex x="30.24" y="10.9"/>
<vertex x="30.51" y="11.1"/>
<vertex x="30.83" y="11.26"/>
<vertex x="31.22" y="11.35"/>
<vertex x="31.66" y="11.38"/>
<vertex x="31.77" y="11.38"/>
<vertex x="31.87" y="11.38"/>
<vertex x="31.97" y="11.38"/>
<vertex x="32.08" y="11.37"/>
<vertex x="32.18" y="11.36"/>
<vertex x="32.28" y="11.35"/>
<vertex x="32.38" y="11.35"/>
<vertex x="32.48" y="11.35"/>
<vertex x="32.48" y="11.2"/>
<vertex x="32.48" y="11.06"/>
<vertex x="32.48" y="10.91"/>
<vertex x="32.48" y="10.77"/>
<vertex x="32.48" y="10.62"/>
<vertex x="32.48" y="10.48"/>
<vertex x="32.48" y="10.33"/>
<vertex x="32.48" y="10.19"/>
<vertex x="32.41" y="10.19"/>
<vertex x="32.34" y="10.2"/>
<vertex x="32.27" y="10.21"/>
<vertex x="32.2" y="10.21"/>
<vertex x="32.13" y="10.21"/>
<vertex x="32.06" y="10.21"/>
<vertex x="31.99" y="10.21"/>
<vertex x="31.92" y="10.21"/>
<vertex x="31.77" y="10.21"/>
<vertex x="31.64" y="10.18"/>
<vertex x="31.54" y="10.13"/>
<vertex x="31.46" y="10.07"/>
<vertex x="31.4" y="9.98"/>
<vertex x="31.36" y="9.87"/>
<vertex x="31.33" y="9.73"/>
<vertex x="31.32" y="9.57"/>
<vertex x="31.32" y="9.53"/>
<vertex x="31.32" y="9.48"/>
<vertex x="31.32" y="9.44"/>
<vertex x="31.32" y="9.4"/>
<vertex x="31.32" y="9.36"/>
<vertex x="31.32" y="9.31"/>
<vertex x="31.32" y="9.27"/>
<vertex x="31.32" y="9.23"/>
<vertex x="31.46" y="9.23"/>
<vertex x="31.59" y="9.23"/>
<vertex x="31.72" y="9.23"/>
<vertex x="31.86" y="9.23"/>
<vertex x="31.99" y="9.23"/>
<vertex x="32.13" y="9.23"/>
<vertex x="32.26" y="9.23"/>
<vertex x="32.39" y="9.23"/>
<vertex x="32.39" y="9.1"/>
<vertex x="32.39" y="8.97"/>
<vertex x="32.39" y="8.84"/>
<vertex x="32.39" y="8.71"/>
<vertex x="32.39" y="8.58"/>
<vertex x="32.39" y="8.45"/>
<vertex x="32.39" y="8.32"/>
<vertex x="32.39" y="8.19"/>
<vertex x="32.26" y="8.19"/>
<vertex x="32.13" y="8.19"/>
<vertex x="31.99" y="8.19"/>
<vertex x="31.86" y="8.19"/>
<vertex x="31.72" y="8.19"/>
<vertex x="31.59" y="8.19"/>
<vertex x="31.46" y="8.19"/>
<vertex x="31.32" y="8.19"/>
<vertex x="31.32" y="7.61"/>
<vertex x="31.32" y="7.04"/>
<vertex x="31.32" y="6.46"/>
<vertex x="31.32" y="5.88"/>
<vertex x="31.32" y="5.3"/>
<vertex x="31.32" y="4.73"/>
<vertex x="31.32" y="4.15"/>
<vertex x="31.32" y="3.57"/>
<vertex x="31.13" y="3.57"/>
<vertex x="30.93" y="3.57"/>
<vertex x="30.74" y="3.57"/>
<vertex x="30.55" y="3.57"/>
<vertex x="30.35" y="3.57"/>
<vertex x="30.16" y="3.57"/>
<vertex x="29.96" y="3.57"/>
<vertex x="29.77" y="3.57"/>
<vertex x="29.77" y="4.15"/>
<vertex x="29.77" y="4.73"/>
<vertex x="29.77" y="5.3"/>
<vertex x="29.77" y="5.88"/>
<vertex x="29.77" y="6.46"/>
<vertex x="29.77" y="7.04"/>
<vertex x="29.77" y="7.61"/>
</polygon>
<vertex x="38.14" y="3.57"/>
<vertex x="37.95" y="3.57"/>
<vertex x="37.77" y="3.57"/>
<vertex x="37.58" y="3.57"/>
<vertex x="37.4" y="3.57"/>
<vertex x="37.21" y="3.57"/>
<vertex x="37.03" y="3.57"/>
<vertex x="36.84" y="3.57"/>
<vertex x="36.66" y="3.57"/>
<vertex x="36.66" y="3.67"/>
<vertex x="36.66" y="3.77"/>
<vertex x="36.66" y="3.87"/>
<vertex x="36.66" y="3.97"/>
<vertex x="36.66" y="4.07"/>
<vertex x="36.66" y="4.16"/>
<vertex x="36.66" y="4.26"/>
<vertex x="36.66" y="4.36"/>
<vertex x="36.65" y="4.36"/>
<vertex x="36.64" y="4.36"/>
<vertex x="36.48" y="4.13"/>
<vertex x="36.3" y="3.94"/>
<vertex x="36.1" y="3.78"/>
<vertex x="35.88" y="3.65"/>
<vertex x="35.65" y="3.55"/>
<vertex x="35.41" y="3.48"/>
<vertex x="35.16" y="3.43"/>
<vertex x="34.91" y="3.42"/>
<vertex x="34.35" y="3.46"/>
<vertex x="33.89" y="3.59"/>
<vertex x="33.53" y="3.79"/>
<vertex x="33.26" y="4.06"/>
<vertex x="33.07" y="4.4"/>
<vertex x="32.94" y="4.79"/>
<vertex x="32.87" y="5.25"/>
<vertex x="32.85" y="5.75"/>
<vertex x="32.85" y="6.18"/>
<vertex x="32.85" y="6.62"/>
<vertex x="32.85" y="7.05"/>
<vertex x="32.85" y="7.49"/>
<vertex x="32.85" y="7.92"/>
<vertex x="32.85" y="8.36"/>
<vertex x="32.85" y="8.79"/>
<vertex x="32.85" y="9.23"/>
<vertex x="33.04" y="9.23"/>
<vertex x="33.23" y="9.23"/>
<vertex x="33.43" y="9.23"/>
<vertex x="33.62" y="9.23"/>
<vertex x="33.82" y="9.23"/>
<vertex x="34.01" y="9.23"/>
<vertex x="34.21" y="9.23"/>
<vertex x="34.4" y="9.23"/>
<vertex x="34.4" y="8.83"/>
<vertex x="34.4" y="8.43"/>
<vertex x="34.4" y="8.03"/>
<vertex x="34.4" y="7.63"/>
<vertex x="34.4" y="7.23"/>
<vertex x="34.4" y="6.83"/>
<vertex x="34.4" y="6.43"/>
<vertex x="34.4" y="6.03"/>
<vertex x="34.41" y="5.71"/>
<vertex x="34.45" y="5.42"/>
<vertex x="34.52" y="5.19"/>
<vertex x="34.62" y="4.99"/>
<vertex x="34.76" y="4.84"/>
<vertex x="34.93" y="4.73"/>
<vertex x="35.14" y="4.67"/>
<vertex x="35.4" y="4.64"/>
<vertex x="35.69" y="4.67"/>
<vertex x="35.94" y="4.74"/>
<vertex x="36.15" y="4.85"/>
<vertex x="36.31" y="5.02"/>
<vertex x="36.44" y="5.25"/>
<vertex x="36.53" y="5.53"/>
<vertex x="36.58" y="5.86"/>
<vertex x="36.6" y="6.26"/>
<vertex x="36.6" y="6.63"/>
<vertex x="36.6" y="7"/>
<vertex x="36.6" y="7.37"/>
<vertex x="36.6" y="7.75"/>
<vertex x="36.6" y="8.12"/>
<vertex x="36.6" y="8.49"/>
<vertex x="36.6" y="8.86"/>
<vertex x="36.6" y="9.23"/>
<vertex x="36.79" y="9.23"/>
<vertex x="36.99" y="9.23"/>
<vertex x="37.18" y="9.23"/>
<vertex x="37.38" y="9.23"/>
<vertex x="37.57" y="9.23"/>
<vertex x="37.77" y="9.23"/>
<vertex x="37.96" y="9.23"/>
<vertex x="38.15" y="9.23"/>
<vertex x="38.15" y="8.52"/>
<vertex x="38.15" y="7.81"/>
<vertex x="38.15" y="7.11"/>
<vertex x="38.15" y="6.4"/>
<vertex x="38.15" y="5.69"/>
<vertex x="38.15" y="4.99"/>
<vertex x="38.15" y="4.28"/>
</polygon>
<vertex x="39" y="9.23"/>
<vertex x="39.18" y="9.23"/>
<vertex x="39.36" y="9.23"/>
<vertex x="39.55" y="9.23"/>
<vertex x="39.73" y="9.23"/>
<vertex x="39.92" y="9.23"/>
<vertex x="40.1" y="9.23"/>
<vertex x="40.29" y="9.23"/>
<vertex x="40.47" y="9.23"/>
<vertex x="40.47" y="9.13"/>
<vertex x="40.47" y="9.03"/>
<vertex x="40.47" y="8.93"/>
<vertex x="40.47" y="8.84"/>
<vertex x="40.47" y="8.74"/>
<vertex x="40.47" y="8.64"/>
<vertex x="40.47" y="8.54"/>
<vertex x="40.47" y="8.44"/>
<vertex x="40.48" y="8.44"/>
<vertex x="40.49" y="8.44"/>
<vertex x="40.65" y="8.67"/>
<vertex x="40.83" y="8.86"/>
<vertex x="41.04" y="9.02"/>
<vertex x="41.25" y="9.15"/>
<vertex x="41.49" y="9.26"/>
<vertex x="41.73" y="9.33"/>
<vertex x="41.97" y="9.37"/>
<vertex x="42.22" y="9.38"/>
<vertex x="42.78" y="9.34"/>
<vertex x="43.24" y="9.22"/>
<vertex x="43.6" y="9.02"/>
<vertex x="43.87" y="8.74"/>
<vertex x="44.07" y="8.41"/>
<vertex x="44.19" y="8.01"/>
<vertex x="44.26" y="7.56"/>
<vertex x="44.29" y="7.05"/>
<vertex x="44.29" y="6.62"/>
<vertex x="44.29" y="6.18"/>
<vertex x="44.29" y="5.75"/>
<vertex x="44.29" y="5.31"/>
<vertex x="44.29" y="4.88"/>
<vertex x="44.29" y="4.44"/>
<vertex x="44.29" y="4.01"/>
<vertex x="44.29" y="3.57"/>
<vertex x="44.09" y="3.57"/>
<vertex x="43.9" y="3.57"/>
<vertex x="43.7" y="3.57"/>
<vertex x="43.51" y="3.57"/>
<vertex x="43.31" y="3.57"/>
<vertex x="43.12" y="3.57"/>
<vertex x="42.93" y="3.57"/>
<vertex x="42.73" y="3.57"/>
<vertex x="42.73" y="3.97"/>
<vertex x="42.73" y="4.37"/>
<vertex x="42.73" y="4.77"/>
<vertex x="42.73" y="5.17"/>
<vertex x="42.73" y="5.57"/>
<vertex x="42.73" y="5.97"/>
<vertex x="42.73" y="6.37"/>
<vertex x="42.73" y="6.77"/>
<vertex x="42.72" y="7.1"/>
<vertex x="42.68" y="7.38"/>
<vertex x="42.61" y="7.62"/>
<vertex x="42.51" y="7.81"/>
<vertex x="42.37" y="7.96"/>
<vertex x="42.2" y="8.07"/>
<vertex x="41.99" y="8.14"/>
<vertex x="41.74" y="8.16"/>
<vertex x="41.44" y="8.14"/>
<vertex x="41.19" y="8.07"/>
<vertex x="40.99" y="7.95"/>
<vertex x="40.82" y="7.78"/>
<vertex x="40.69" y="7.56"/>
<vertex x="40.6" y="7.28"/>
<vertex x="40.55" y="6.94"/>
<vertex x="40.53" y="6.54"/>
<vertex x="40.53" y="6.17"/>
<vertex x="40.53" y="5.8"/>
<vertex x="40.53" y="5.43"/>
<vertex x="40.53" y="5.06"/>
<vertex x="40.53" y="4.69"/>
<vertex x="40.53" y="4.32"/>
<vertex x="40.53" y="3.95"/>
<vertex x="40.53" y="3.57"/>
<vertex x="40.34" y="3.57"/>
<vertex x="40.14" y="3.57"/>
<vertex x="39.95" y="3.57"/>
<vertex x="39.76" y="3.57"/>
<vertex x="39.56" y="3.57"/>
<vertex x="39.37" y="3.57"/>
<vertex x="39.17" y="3.57"/>
<vertex x="38.98" y="3.57"/>
<vertex x="38.98" y="4.28"/>
<vertex x="38.98" y="4.99"/>
<vertex x="38.98" y="5.7"/>
<vertex x="38.98" y="6.4"/>
<vertex x="38.98" y="7.11"/>
<vertex x="38.98" y="7.82"/>
<vertex x="38.98" y="8.52"/>
</polygon>
<vertex x="31.97" y="18.94"/>
<vertex x="31.98" y="18.91"/>
<vertex x="31.99" y="18.84"/>
<vertex x="31.99" y="18.74"/>
<vertex x="31.98" y="18.62"/>
<vertex x="31.96" y="18.5"/>
<vertex x="31.9" y="18.39"/>
<vertex x="31.8" y="18.3"/>
<vertex x="31.65" y="18.24"/>
<vertex x="31.52" y="18.24"/>
<vertex x="31.38" y="18.27"/>
<vertex x="31.23" y="18.32"/>
<vertex x="31.08" y="18.39"/>
<vertex x="30.93" y="18.48"/>
<vertex x="30.79" y="18.59"/>
<vertex x="30.66" y="18.7"/>
<vertex x="30.55" y="18.82"/>
<vertex x="30.45" y="18.96"/>
<vertex x="30.38" y="19.1"/>
<vertex x="30.34" y="19.23"/>
<vertex x="30.32" y="19.35"/>
<vertex x="30.34" y="19.47"/>
<vertex x="30.38" y="19.58"/>
<vertex x="30.44" y="19.69"/>
<vertex x="30.52" y="19.79"/>
<vertex x="30.67" y="19.92"/>
<vertex x="30.84" y="20.01"/>
<vertex x="31.01" y="20.06"/>
<vertex x="31.17" y="20.08"/>
<vertex x="31.32" y="20.08"/>
<vertex x="31.43" y="20.06"/>
<vertex x="31.51" y="20.05"/>
<vertex x="31.54" y="20.05"/>
<vertex x="31.49" y="20.09"/>
<vertex x="31.34" y="20.2"/>
<vertex x="31.1" y="20.33"/>
<vertex x="30.8" y="20.46"/>
<vertex x="30.44" y="20.55"/>
<vertex x="30.03" y="20.56"/>
<vertex x="29.59" y="20.47"/>
<vertex x="29.14" y="20.24"/>
<vertex x="28.79" y="19.94"/>
<vertex x="28.57" y="19.63"/>
<vertex x="28.46" y="19.3"/>
<vertex x="28.46" y="18.96"/>
<vertex x="28.56" y="18.61"/>
<vertex x="28.74" y="18.26"/>
<vertex x="29.01" y="17.91"/>
<vertex x="29.34" y="17.57"/>
<vertex x="29.61" y="17.26"/>
<vertex x="29.73" y="16.97"/>
<vertex x="29.75" y="16.68"/>
<vertex x="29.66" y="16.43"/>
<vertex x="29.48" y="16.23"/>
<vertex x="29.24" y="16.08"/>
<vertex x="28.96" y="15.99"/>
<vertex x="28.63" y="15.99"/>
<vertex x="28.42" y="16.04"/>
<vertex x="28.24" y="16.12"/>
<vertex x="28.1" y="16.22"/>
<vertex x="27.99" y="16.34"/>
<vertex x="27.92" y="16.47"/>
<vertex x="27.88" y="16.61"/>
<vertex x="27.88" y="16.74"/>
<vertex x="27.92" y="16.86"/>
<vertex x="27.98" y="16.95"/>
<vertex x="28.06" y="17.04"/>
<vertex x="28.15" y="17.11"/>
<vertex x="28.25" y="17.17"/>
<vertex x="28.34" y="17.22"/>
<vertex x="28.41" y="17.25"/>
<vertex x="28.46" y="17.27"/>
<vertex x="28.48" y="17.28"/>
<vertex x="28.46" y="17.29"/>
<vertex x="28.39" y="17.31"/>
<vertex x="28.29" y="17.33"/>
<vertex x="28.16" y="17.36"/>
<vertex x="27.99" y="17.37"/>
<vertex x="27.8" y="17.36"/>
<vertex x="27.6" y="17.33"/>
<vertex x="27.38" y="17.26"/>
<vertex x="27.19" y="17.18"/>
<vertex x="27.01" y="17.06"/>
<vertex x="26.84" y="16.91"/>
<vertex x="26.7" y="16.73"/>
<vertex x="26.58" y="16.5"/>
<vertex x="26.5" y="16.23"/>
<vertex x="26.45" y="15.9"/>
<vertex x="26.44" y="15.52"/>
<vertex x="26.44" y="14.87"/>
<vertex x="26.44" y="14.23"/>
<vertex x="26.44" y="13.59"/>
<vertex x="26.44" y="12.95"/>
<vertex x="26.44" y="12.31"/>
<vertex x="26.44" y="11.67"/>
<vertex x="26.44" y="11.03"/>
<vertex x="26.44" y="10.39"/>
<vertex x="26.47" y="10.42"/>
<vertex x="26.54" y="10.51"/>
<vertex x="26.65" y="10.64"/>
<vertex x="26.8" y="10.82"/>
<vertex x="26.98" y="11.02"/>
<vertex x="27.18" y="11.26"/>
<vertex x="27.41" y="11.51"/>
<vertex x="27.64" y="11.76"/>
<vertex x="27.9" y="12.04"/>
<vertex x="28.13" y="12.3"/>
<vertex x="28.34" y="12.52"/>
<vertex x="28.54" y="12.7"/>
<vertex x="28.74" y="12.85"/>
<vertex x="28.95" y="12.95"/>
<vertex x="29.19" y="13.01"/>
<vertex x="29.45" y="13.01"/>
<vertex x="29.96" y="13.01"/>
<vertex x="30.44" y="13.07"/>
<vertex x="30.88" y="13.19"/>
<vertex x="31.28" y="13.37"/>
<vertex x="31.65" y="13.6"/>
<vertex x="31.99" y="13.88"/>
<vertex x="32.3" y="14.19"/>
<vertex x="32.58" y="14.55"/>
<vertex x="32.97" y="15.29"/>
<vertex x="33.17" y="16.02"/>
<vertex x="33.21" y="16.72"/>
<vertex x="33.11" y="17.36"/>
<vertex x="32.91" y="17.94"/>
<vertex x="32.63" y="18.41"/>
<vertex x="32.31" y="18.75"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.6">
<vertex x="3.1" y="8.42"/>
<vertex x="3.14" y="8.07"/>
<vertex x="3.25" y="7.77"/>
<vertex x="3.43" y="7.53"/>
<vertex x="3.66" y="7.33"/>
<vertex x="3.93" y="7.18"/>
<vertex x="4.23" y="7.07"/>
<vertex x="4.55" y="7.01"/>
<vertex x="4.89" y="6.99"/>
<vertex x="5.14" y="7"/>
<vertex x="5.4" y="7.04"/>
<vertex x="5.66" y="7.11"/>
<vertex x="5.9" y="7.22"/>
<vertex x="6.1" y="7.37"/>
<vertex x="6.27" y="7.56"/>
<vertex x="6.38" y="7.79"/>
<vertex x="6.41" y="8.07"/>
<vertex x="6.37" y="8.32"/>
<vertex x="6.23" y="8.53"/>
<vertex x="6.02" y="8.71"/>
<vertex x="5.72" y="8.86"/>
<vertex x="5.34" y="9"/>
<vertex x="4.88" y="9.13"/>
<vertex x="4.36" y="9.26"/>
<vertex x="3.77" y="9.38"/>
<vertex x="3.27" y="9.51"/>
<vertex x="2.78" y="9.66"/>
<vertex x="2.32" y="9.84"/>
<vertex x="1.92" y="10.07"/>
<vertex x="1.57" y="10.35"/>
<vertex x="1.31" y="10.7"/>
<vertex x="1.14" y="11.13"/>
<vertex x="1.08" y="11.65"/>
<vertex x="1.17" y="12.39"/>
<vertex x="1.4" y="12.99"/>
<vertex x="1.77" y="13.46"/>
<vertex x="2.24" y="13.82"/>
<vertex x="2.8" y="14.08"/>
<vertex x="3.43" y="14.25"/>
<vertex x="4.09" y="14.34"/>
<vertex x="4.77" y="14.37"/>
<vertex x="5.45" y="14.34"/>
<vertex x="6.11" y="14.24"/>
<vertex x="6.72" y="14.07"/>
<vertex x="7.27" y="13.8"/>
<vertex x="7.74" y="13.44"/>
<vertex x="8.11" y="12.97"/>
<vertex x="8.38" y="12.38"/>
<vertex x="8.52" y="11.67"/>
<vertex x="8.24" y="11.67"/>
<vertex x="7.96" y="11.67"/>
<vertex x="7.68" y="11.67"/>
<vertex x="7.41" y="11.67"/>
<vertex x="7.13" y="11.67"/>
<vertex x="6.85" y="11.67"/>
<vertex x="6.58" y="11.67"/>
<vertex x="6.3" y="11.67"/>
<vertex x="6.25" y="11.97"/>
<vertex x="6.14" y="12.23"/>
<vertex x="5.99" y="12.43"/>
<vertex x="5.79" y="12.58"/>
<vertex x="5.56" y="12.69"/>
<vertex x="5.3" y="12.76"/>
<vertex x="5.01" y="12.8"/>
<vertex x="4.71" y="12.82"/>
<vertex x="4.5" y="12.81"/>
<vertex x="4.28" y="12.79"/>
<vertex x="4.07" y="12.75"/>
<vertex x="3.86" y="12.69"/>
<vertex x="3.68" y="12.59"/>
<vertex x="3.54" y="12.45"/>
<vertex x="3.44" y="12.26"/>
<vertex x="3.41" y="12.03"/>
<vertex x="3.47" y="11.74"/>
<vertex x="3.64" y="11.52"/>
<vertex x="3.9" y="11.34"/>
<vertex x="4.24" y="11.2"/>
<vertex x="4.64" y="11.08"/>
<vertex x="5.09" y="10.97"/>
<vertex x="5.56" y="10.87"/>
<vertex x="6.05" y="10.76"/>
<vertex x="6.56" y="10.64"/>
<vertex x="7.05" y="10.48"/>
<vertex x="7.5" y="10.29"/>
<vertex x="7.91" y="10.05"/>
<vertex x="8.25" y="9.75"/>
<vertex x="8.52" y="9.38"/>
<vertex x="8.68" y="8.93"/>
<vertex x="8.74" y="8.38"/>
<vertex x="8.66" y="7.62"/>
<vertex x="8.41" y="6.98"/>
<vertex x="8.02" y="6.47"/>
<vertex x="7.53" y="6.07"/>
<vertex x="6.94" y="5.78"/>
<vertex x="6.29" y="5.58"/>
<vertex x="5.59" y="5.47"/>
<vertex x="4.87" y="5.43"/>
<vertex x="4.14" y="5.47"/>
<vertex x="3.43" y="5.58"/>
<vertex x="2.77" y="5.78"/>
<vertex x="2.17" y="6.08"/>
<vertex x="1.66" y="6.48"/>
<vertex x="1.27" y="7"/>
<vertex x="1" y="7.64"/>
<vertex x="0.88" y="8.42"/>
<vertex x="1.16" y="8.42"/>
<vertex x="1.44" y="8.42"/>
<vertex x="1.71" y="8.42"/>
<vertex x="1.99" y="8.42"/>
<vertex x="2.27" y="8.42"/>
<vertex x="2.55" y="8.42"/>
<vertex x="2.82" y="8.42"/>
</polygon>
<vertex x="15.74" y="8.42"/>
<vertex x="15.88" y="8.88"/>
<vertex x="15.95" y="9.37"/>
<vertex x="15.98" y="9.88"/>
<vertex x="18.31" y="9.81"/>
<vertex x="18.25" y="8.97"/>
<vertex x="18.08" y="8.17"/>
<vertex x="17.79" y="7.43"/>
</polygon>
<vertex x="17.38" y="6.77"/>
<vertex x="16.86" y="6.22"/>
<vertex x="16.22" y="5.8"/>
<vertex x="15.46" y="5.53"/>
<vertex x="14.58" y="5.43"/>
<vertex x="14.2" y="5.45"/>
<vertex x="13.83" y="5.51"/>
<vertex x="13.47" y="5.62"/>
<vertex x="13.14" y="5.76"/>
<vertex x="12.82" y="5.94"/>
<vertex x="12.53" y="6.16"/>
<vertex x="12.27" y="6.42"/>
<vertex x="12.04" y="6.71"/>
<vertex x="12.03" y="6.71"/>
<vertex x="12.03" y="5.95"/>
<vertex x="12.03" y="5.18"/>
<vertex x="12.03" y="4.42"/>
<vertex x="12.03" y="3.66"/>
<vertex x="12.03" y="2.89"/>
<vertex x="12.03" y="2.13"/>
<vertex x="12.03" y="1.37"/>
<vertex x="12.03" y="0.6"/>
<vertex x="11.73" y="0.86"/>
<vertex x="11.44" y="1.12"/>
<vertex x="11.15" y="1.38"/>
<vertex x="10.86" y="1.64"/>
<vertex x="10.57" y="1.9"/>
<vertex x="10.28" y="2.16"/>
<vertex x="9.99" y="2.42"/>
<vertex x="9.7" y="2.68"/>
<vertex x="9.7" y="4.06"/>
<vertex x="9.7" y="5.45"/>
<vertex x="9.7" y="6.83"/>
<vertex x="9.7" y="8.21"/>
<vertex x="9.7" y="9.6"/>
<vertex x="9.7" y="10.98"/>
<vertex x="9.7" y="12.37"/>
<vertex x="9.7" y="13.75"/>
<vertex x="9.97" y="13.8"/>
<vertex x="10.25" y="13.85"/>
<vertex x="10.53" y="13.9"/>
<vertex x="10.8" y="13.95"/>
<vertex x="11.08" y="14"/>
<vertex x="11.36" y="14.05"/>
<vertex x="11.64" y="14.1"/>
<vertex x="11.91" y="14.15"/>
<vertex x="11.91" y="14.01"/>
<vertex x="11.91" y="13.87"/>
<vertex x="11.91" y="13.74"/>
<vertex x="11.91" y="13.6"/>
<vertex x="11.91" y="13.47"/>
<vertex x="11.91" y="13.33"/>
<vertex x="11.91" y="13.2"/>
<vertex x="11.91" y="13.06"/>
<vertex x="11.92" y="13.06"/>
<vertex x="11.93" y="13.06"/>
<vertex x="12.16" y="13.38"/>
<vertex x="12.42" y="13.66"/>
<vertex x="12.7" y="13.88"/>
<vertex x="13.01" y="14.06"/>
<vertex x="13.34" y="14.2"/>
<vertex x="13.7" y="14.3"/>
<vertex x="14.07" y="14.36"/>
<vertex x="14.45" y="14.37"/>
<vertex x="15.38" y="14.28"/>
<vertex x="16.18" y="14"/>
<vertex x="16.84" y="13.57"/>
<vertex x="17.38" y="13"/>
<vertex x="17.79" y="12.32"/>
<vertex x="18.08" y="11.54"/>
<vertex x="18.25" y="10.7"/>
<vertex x="15.95" y="10.39"/>
<vertex x="15.87" y="10.88"/>
<vertex x="15.73" y="11.34"/>
<vertex x="15.52" y="11.76"/>
<vertex x="15.24" y="12.11"/>
<vertex x="14.89" y="12.38"/>
<vertex x="14.46" y="12.56"/>
<vertex x="13.94" y="12.62"/>
<vertex x="13.42" y="12.56"/>
<vertex x="12.98" y="12.38"/>
<vertex x="12.63" y="12.11"/>
<vertex x="12.36" y="11.76"/>
<vertex x="12.16" y="11.35"/>
<vertex x="12.02" y="10.89"/>
<vertex x="11.95" y="10.39"/>
<vertex x="11.92" y="9.88"/>
<vertex x="11.95" y="9.37"/>
<vertex x="12.03" y="8.88"/>
<vertex x="12.17" y="8.42"/>
<vertex x="12.38" y="8.02"/>
<vertex x="12.65" y="7.68"/>
<vertex x="13" y="7.41"/>
<vertex x="13.44" y="7.25"/>
<vertex x="13.96" y="7.19"/>
<vertex x="14.49" y="7.25"/>
<vertex x="14.92" y="7.41"/>
<vertex x="15.27" y="7.68"/>
<vertex x="15.54" y="8.02"/>
</polygon>
<vertex x="21.85" y="10.53"/>
<vertex x="22.38" y="10.59"/>
<vertex x="22.89" y="10.65"/>
<vertex x="23.37" y="10.72"/>
<vertex x="23.65" y="9.46"/>
<vertex x="23.51" y="9.44"/>
<vertex x="23.37" y="9.42"/>
<vertex x="23.24" y="9.4"/>
<vertex x="23.1" y="9.38"/>
<vertex x="22.96" y="9.36"/>
<vertex x="22.82" y="9.34"/>
<vertex x="22.68" y="9.31"/>
<vertex x="22.55" y="9.29"/>
<vertex x="22.42" y="9.26"/>
<vertex x="22.29" y="9.22"/>
</polygon>
<vertex x="22.16" y="9.18"/>
<vertex x="22.05" y="9.14"/>
<vertex x="21.93" y="9.09"/>
<vertex x="21.82" y="9.03"/>
<vertex x="21.72" y="8.96"/>
<vertex x="21.63" y="8.89"/>
<vertex x="21.55" y="8.8"/>
<vertex x="21.48" y="8.71"/>
<vertex x="21.42" y="8.6"/>
<vertex x="21.37" y="8.49"/>
<vertex x="21.34" y="8.36"/>
<vertex x="21.31" y="8.22"/>
<vertex x="21.31" y="8.07"/>
<vertex x="21.31" y="7.91"/>
<vertex x="21.34" y="7.77"/>
<vertex x="21.37" y="7.65"/>
<vertex x="21.42" y="7.54"/>
<vertex x="21.48" y="7.44"/>
<vertex x="21.56" y="7.35"/>
<vertex x="21.64" y="7.27"/>
<vertex x="21.74" y="7.2"/>
<vertex x="21.84" y="7.15"/>
<vertex x="21.95" y="7.1"/>
<vertex x="22.07" y="7.06"/>
<vertex x="22.19" y="7.03"/>
<vertex x="22.32" y="7.01"/>
<vertex x="22.46" y="6.99"/>
<vertex x="22.59" y="6.99"/>
<vertex x="22.73" y="6.98"/>
<vertex x="23.06" y="7"/>
<vertex x="23.34" y="7.05"/>
<vertex x="23.58" y="7.12"/>
<vertex x="23.8" y="7.22"/>
<vertex x="23.98" y="7.33"/>
<vertex x="24.13" y="7.47"/>
<vertex x="24.26" y="7.61"/>
<vertex x="24.36" y="7.77"/>
<vertex x="24.44" y="7.93"/>
<vertex x="24.5" y="8.09"/>
<vertex x="24.55" y="8.25"/>
<vertex x="24.58" y="8.41"/>
<vertex x="24.6" y="8.56"/>
<vertex x="24.62" y="8.71"/>
<vertex x="24.62" y="8.83"/>
<vertex x="24.62" y="8.94"/>
<vertex x="24.62" y="8.99"/>
<vertex x="24.62" y="9.05"/>
<vertex x="24.62" y="9.1"/>
<vertex x="24.62" y="9.16"/>
<vertex x="24.62" y="9.21"/>
<vertex x="24.62" y="9.26"/>
<vertex x="24.62" y="9.32"/>
<vertex x="24.62" y="9.37"/>
<vertex x="24.62" y="9.43"/>
<vertex x="24.62" y="9.48"/>
<vertex x="24.62" y="9.54"/>
<vertex x="24.62" y="9.59"/>
<vertex x="24.62" y="9.64"/>
<vertex x="24.62" y="9.7"/>
<vertex x="24.62" y="9.75"/>
<vertex x="24.62" y="9.81"/>
<vertex x="24.54" y="9.75"/>
<vertex x="24.45" y="9.69"/>
<vertex x="24.36" y="9.64"/>
<vertex x="24.25" y="9.6"/>
<vertex x="24.14" y="9.57"/>
<vertex x="24.02" y="9.53"/>
<vertex x="23.9" y="9.5"/>
<vertex x="23.78" y="9.48"/>
<vertex x="23.64" y="9.46"/>
<vertex x="23.78" y="10.82"/>
<vertex x="24.14" y="10.94"/>
<vertex x="24.41" y="11.11"/>
<vertex x="24.57" y="11.35"/>
<vertex x="24.62" y="11.66"/>
<vertex x="24.61" y="11.83"/>
<vertex x="24.59" y="11.99"/>
<vertex x="24.55" y="12.13"/>
<vertex x="24.5" y="12.25"/>
<vertex x="24.44" y="12.36"/>
<vertex x="24.36" y="12.46"/>
<vertex x="24.27" y="12.54"/>
<vertex x="24.18" y="12.6"/>
<vertex x="24.07" y="12.66"/>
<vertex x="23.95" y="12.7"/>
<vertex x="23.83" y="12.74"/>
<vertex x="23.7" y="12.77"/>
<vertex x="23.56" y="12.79"/>
<vertex x="23.41" y="12.8"/>
<vertex x="23.27" y="12.8"/>
<vertex x="23.11" y="12.8"/>
<vertex x="22.95" y="12.8"/>
<vertex x="22.79" y="12.78"/>
<vertex x="22.64" y="12.76"/>
<vertex x="22.5" y="12.73"/>
<vertex x="22.37" y="12.69"/>
<vertex x="22.25" y="12.64"/>
<vertex x="22.14" y="12.58"/>
<vertex x="22.03" y="12.5"/>
<vertex x="21.94" y="12.42"/>
<vertex x="21.86" y="12.33"/>
<vertex x="21.78" y="12.22"/>
<vertex x="21.72" y="12.11"/>
<vertex x="21.67" y="11.98"/>
<vertex x="21.62" y="11.84"/>
<vertex x="21.59" y="11.69"/>
<vertex x="21.57" y="11.52"/>
<vertex x="21.43" y="11.52"/>
<vertex x="21.28" y="11.52"/>
<vertex x="21.13" y="11.52"/>
<vertex x="20.99" y="11.52"/>
<vertex x="20.84" y="11.52"/>
<vertex x="20.7" y="11.52"/>
<vertex x="20.55" y="11.52"/>
<vertex x="20.41" y="11.52"/>
<vertex x="20.26" y="11.52"/>
<vertex x="20.12" y="11.52"/>
<vertex x="19.97" y="11.52"/>
<vertex x="19.83" y="11.52"/>
<vertex x="19.68" y="11.52"/>
<vertex x="19.54" y="11.52"/>
<vertex x="19.39" y="11.52"/>
<vertex x="19.24" y="11.52"/>
<vertex x="19.29" y="11.91"/>
<vertex x="19.38" y="12.26"/>
<vertex x="19.5" y="12.59"/>
<vertex x="19.66" y="12.88"/>
<vertex x="19.84" y="13.14"/>
<vertex x="20.06" y="13.37"/>
<vertex x="20.31" y="13.57"/>
<vertex x="20.57" y="13.75"/>
<vertex x="20.86" y="13.9"/>
<vertex x="21.17" y="14.03"/>
<vertex x="21.49" y="14.14"/>
<vertex x="21.82" y="14.22"/>
<vertex x="22.17" y="14.28"/>
<vertex x="22.52" y="14.32"/>
<vertex x="22.88" y="14.35"/>
<vertex x="23.23" y="14.36"/>
<vertex x="23.55" y="14.35"/>
<vertex x="23.88" y="14.33"/>
<vertex x="24.2" y="14.31"/>
<vertex x="24.53" y="14.26"/>
<vertex x="24.85" y="14.2"/>
<vertex x="25.15" y="14.13"/>
<vertex x="25.45" y="14.03"/>
<vertex x="25.73" y="13.91"/>
<vertex x="25.99" y="13.77"/>
<vertex x="26.23" y="13.6"/>
<vertex x="26.43" y="13.4"/>
<vertex x="26.61" y="13.18"/>
<vertex x="26.76" y="12.92"/>
<vertex x="26.87" y="12.63"/>
<vertex x="26.94" y="12.3"/>
<vertex x="26.96" y="11.94"/>
<vertex x="26.96" y="11.67"/>
<vertex x="26.96" y="11.39"/>
<vertex x="26.96" y="11.11"/>
<vertex x="26.96" y="10.84"/>
<vertex x="26.96" y="10.56"/>
<vertex x="26.96" y="10.29"/>
<vertex x="26.96" y="10.01"/>
<vertex x="26.96" y="9.74"/>
<vertex x="26.96" y="9.46"/>
<vertex x="26.96" y="9.18"/>
<vertex x="26.96" y="8.91"/>
<vertex x="26.96" y="8.63"/>
<vertex x="26.96" y="8.36"/>
<vertex x="26.96" y="8.08"/>
<vertex x="26.96" y="7.8"/>
<vertex x="26.96" y="7.53"/>
<vertex x="26.96" y="7.38"/>
<vertex x="26.96" y="7.24"/>
<vertex x="26.96" y="7.1"/>
<vertex x="26.97" y="6.96"/>
<vertex x="26.97" y="6.82"/>
<vertex x="26.99" y="6.68"/>
<vertex x="27" y="6.55"/>
<vertex x="27.02" y="6.42"/>
<vertex x="27.04" y="6.3"/>
<vertex x="27.06" y="6.19"/>
<vertex x="27.09" y="6.08"/>
<vertex x="27.11" y="5.97"/>
<vertex x="27.14" y="5.88"/>
<vertex x="27.18" y="5.79"/>
<vertex x="27.21" y="5.71"/>
<vertex x="27.25" y="5.64"/>
<vertex x="27.1" y="5.64"/>
<vertex x="26.95" y="5.64"/>
<vertex x="26.81" y="5.64"/>
<vertex x="26.66" y="5.64"/>
<vertex x="26.51" y="5.64"/>
<vertex x="26.36" y="5.64"/>
<vertex x="26.22" y="5.64"/>
<vertex x="26.07" y="5.64"/>
<vertex x="25.92" y="5.64"/>
<vertex x="25.77" y="5.64"/>
<vertex x="25.63" y="5.64"/>
<vertex x="25.48" y="5.64"/>
<vertex x="25.33" y="5.64"/>
<vertex x="25.18" y="5.64"/>
<vertex x="25.04" y="5.64"/>
<vertex x="24.89" y="5.64"/>
<vertex x="24.87" y="5.69"/>
<vertex x="24.85" y="5.74"/>
<vertex x="24.83" y="5.79"/>
<vertex x="24.82" y="5.84"/>
<vertex x="24.8" y="5.89"/>
<vertex x="24.79" y="5.94"/>
<vertex x="24.78" y="5.99"/>
<vertex x="24.76" y="6.05"/>
<vertex x="24.75" y="6.1"/>
<vertex x="24.75" y="6.15"/>
<vertex x="24.74" y="6.2"/>
<vertex x="24.74" y="6.25"/>
<vertex x="24.73" y="6.31"/>
<vertex x="24.73" y="6.36"/>
<vertex x="24.73" y="6.41"/>
<vertex x="24.72" y="6.46"/>
<vertex x="24.58" y="6.32"/>
<vertex x="24.43" y="6.19"/>
<vertex x="24.28" y="6.08"/>
<vertex x="24.12" y="5.97"/>
<vertex x="23.95" y="5.88"/>
<vertex x="23.78" y="5.79"/>
<vertex x="23.6" y="5.71"/>
<vertex x="23.42" y="5.65"/>
<vertex x="23.23" y="5.59"/>
<vertex x="23.04" y="5.54"/>
<vertex x="22.85" y="5.5"/>
<vertex x="22.66" y="5.47"/>
<vertex x="22.46" y="5.44"/>
<vertex x="22.27" y="5.42"/>
<vertex x="22.07" y="5.41"/>
<vertex x="21.87" y="5.41"/>
<vertex x="21.57" y="5.41"/>
<vertex x="21.28" y="5.44"/>
<vertex x="21" y="5.49"/>
<vertex x="20.73" y="5.56"/>
<vertex x="20.48" y="5.65"/>
<vertex x="20.24" y="5.75"/>
<vertex x="20.02" y="5.88"/>
<vertex x="19.82" y="6.02"/>
<vertex x="19.63" y="6.19"/>
<vertex x="19.47" y="6.38"/>
<vertex x="19.33" y="6.59"/>
<vertex x="19.21" y="6.82"/>
<vertex x="19.11" y="7.07"/>
<vertex x="19.04" y="7.34"/>
<vertex x="19" y="7.63"/>
<vertex x="18.98" y="7.95"/>
<vertex x="19.05" y="8.61"/>
<vertex x="19.24" y="9.14"/>
<vertex x="19.52" y="9.56"/>
<vertex x="19.89" y="9.88"/>
<vertex x="20.32" y="10.13"/>
<vertex x="20.81" y="10.31"/>
<vertex x="21.32" y="10.44"/>
</polygon>
<vertex x="28.27" y="13.75"/>
<vertex x="28.55" y="13.8"/>
<vertex x="28.83" y="13.85"/>
<vertex x="29.1" y="13.9"/>
<vertex x="29.38" y="13.95"/>
<vertex x="29.66" y="13.99"/>
<vertex x="29.93" y="14.04"/>
<vertex x="30.21" y="14.09"/>
<vertex x="30.49" y="14.14"/>
<vertex x="30.49" y="13.95"/>
<vertex x="30.49" y="13.75"/>
<vertex x="30.49" y="13.55"/>
<vertex x="30.49" y="13.35"/>
<vertex x="30.49" y="13.16"/>
<vertex x="30.49" y="12.96"/>
<vertex x="30.49" y="12.76"/>
<vertex x="30.49" y="12.57"/>
<vertex x="30.5" y="12.57"/>
<vertex x="30.7" y="12.95"/>
<vertex x="30.95" y="13.3"/>
<vertex x="31.24" y="13.61"/>
<vertex x="31.58" y="13.87"/>
<vertex x="31.96" y="14.08"/>
<vertex x="32.36" y="14.24"/>
<vertex x="32.78" y="14.34"/>
<vertex x="33.21" y="14.37"/>
<vertex x="33.28" y="14.37"/>
<vertex x="33.34" y="14.37"/>
<vertex x="33.41" y="14.36"/>
<vertex x="33.47" y="14.36"/>
<vertex x="33.53" y="14.34"/>
<vertex x="33.59" y="14.33"/>
<vertex x="33.66" y="14.31"/>
<vertex x="33.72" y="14.29"/>
<vertex x="33.72" y="14.02"/>
<vertex x="33.72" y="13.75"/>
<vertex x="33.72" y="13.48"/>
<vertex x="33.72" y="13.21"/>
<vertex x="33.72" y="12.94"/>
<vertex x="33.72" y="12.67"/>
<vertex x="33.72" y="12.39"/>
<vertex x="33.72" y="12.12"/>
<vertex x="33.63" y="12.14"/>
<vertex x="33.54" y="12.16"/>
<vertex x="33.43" y="12.18"/>
<vertex x="33.32" y="12.19"/>
<vertex x="33.21" y="12.2"/>
<vertex x="33.1" y="12.2"/>
<vertex x="32.99" y="12.2"/>
<vertex x="32.88" y="12.2"/>
<vertex x="32.29" y="12.15"/>
<vertex x="31.8" y="11.99"/>
<vertex x="31.4" y="11.74"/>
<vertex x="31.09" y="11.41"/>
<vertex x="30.86" y="11.01"/>
<vertex x="30.7" y="10.54"/>
<vertex x="30.61" y="10.03"/>
<vertex x="30.58" y="9.48"/>
<vertex x="30.58" y="9"/>
<vertex x="30.58" y="8.52"/>
<vertex x="30.58" y="8.05"/>
<vertex x="30.58" y="7.57"/>
<vertex x="30.58" y="7.09"/>
<vertex x="30.58" y="6.61"/>
<vertex x="30.58" y="6.14"/>
<vertex x="30.58" y="5.66"/>
<vertex x="30.29" y="5.66"/>
<vertex x="30" y="5.66"/>
<vertex x="29.71" y="5.66"/>
<vertex x="29.42" y="5.66"/>
<vertex x="29.13" y="5.66"/>
<vertex x="28.83" y="5.66"/>
<vertex x="28.54" y="5.66"/>
<vertex x="28.25" y="5.66"/>
<vertex x="28.25" y="6.67"/>
<vertex x="28.25" y="7.68"/>
<vertex x="28.25" y="8.69"/>
<vertex x="28.25" y="9.7"/>
<vertex x="28.25" y="10.71"/>
<vertex x="28.25" y="11.72"/>
<vertex x="28.25" y="12.73"/>
</polygon>
<vertex x="34.64" y="16.1"/>
<vertex x="36.97" y="17.38"/>
<vertex x="36.97" y="11.09"/>
<vertex x="39.9" y="14.14"/>
<vertex x="42.66" y="14.14"/>
<vertex x="39.46" y="11.02"/>
<vertex x="43.02" y="5.66"/>
<vertex x="40.2" y="5.66"/>
<vertex x="37.87" y="9.45"/>
<vertex x="36.97" y="8.58"/>
<vertex x="36.97" y="5.66"/>
<vertex x="34.64" y="5.66"/>
</polygon>
<vertex x="44.44" y="12.59"/>
<vertex x="44.15" y="12.59"/>
<vertex x="43.86" y="12.59"/>
<vertex x="43.58" y="12.59"/>
<vertex x="43.29" y="12.59"/>
<vertex x="43" y="12.59"/>
<vertex x="42.71" y="12.59"/>
<vertex x="42.43" y="12.59"/>
<vertex x="42.14" y="12.59"/>
<vertex x="42.34" y="12.78"/>
<vertex x="42.54" y="12.98"/>
<vertex x="42.73" y="13.17"/>
<vertex x="42.93" y="13.37"/>
<vertex x="43.13" y="13.56"/>
<vertex x="43.33" y="13.75"/>
<vertex x="43.53" y="13.95"/>
<vertex x="43.73" y="14.14"/>
<vertex x="43.82" y="14.14"/>
<vertex x="43.9" y="14.14"/>
<vertex x="43.99" y="14.14"/>
<vertex x="44.08" y="14.14"/>
<vertex x="44.17" y="14.14"/>
<vertex x="44.26" y="14.14"/>
<vertex x="44.35" y="14.14"/>
<vertex x="44.44" y="14.14"/>
<vertex x="44.44" y="14.23"/>
<vertex x="44.44" y="14.31"/>
<vertex x="44.44" y="14.39"/>
<vertex x="44.44" y="14.47"/>
<vertex x="44.44" y="14.55"/>
<vertex x="44.44" y="14.63"/>
<vertex x="44.44" y="14.72"/>
<vertex x="44.44" y="14.8"/>
<vertex x="44.48" y="15.34"/>
<vertex x="44.61" y="15.84"/>
<vertex x="44.83" y="16.28"/>
<vertex x="45.14" y="16.65"/>
<vertex x="45.54" y="16.96"/>
<vertex x="46.03" y="17.18"/>
<vertex x="46.61" y="17.33"/>
<vertex x="47.28" y="17.37"/>
<vertex x="47.43" y="17.37"/>
<vertex x="47.59" y="17.37"/>
<vertex x="47.74" y="17.36"/>
<vertex x="47.9" y="17.35"/>
<vertex x="48.05" y="17.34"/>
<vertex x="48.21" y="17.33"/>
<vertex x="48.36" y="17.32"/>
<vertex x="48.51" y="17.32"/>
<vertex x="48.51" y="17.1"/>
<vertex x="48.51" y="16.88"/>
<vertex x="48.51" y="16.67"/>
<vertex x="48.51" y="16.45"/>
<vertex x="48.51" y="16.23"/>
<vertex x="48.51" y="16.01"/>
<vertex x="48.51" y="15.8"/>
<vertex x="48.51" y="15.58"/>
<vertex x="48.4" y="15.59"/>
<vertex x="48.29" y="15.6"/>
<vertex x="48.19" y="15.61"/>
<vertex x="48.08" y="15.61"/>
<vertex x="47.97" y="15.62"/>
<vertex x="47.86" y="15.62"/>
<vertex x="47.76" y="15.62"/>
<vertex x="47.65" y="15.62"/>
<vertex x="47.43" y="15.61"/>
<vertex x="47.24" y="15.57"/>
<vertex x="47.09" y="15.5"/>
<vertex x="46.97" y="15.4"/>
<vertex x="46.88" y="15.27"/>
<vertex x="46.82" y="15.1"/>
<vertex x="46.78" y="14.9"/>
<vertex x="46.77" y="14.65"/>
<vertex x="46.77" y="14.59"/>
<vertex x="46.77" y="14.53"/>
<vertex x="46.77" y="14.46"/>
<vertex x="46.77" y="14.4"/>
<vertex x="46.77" y="14.33"/>
<vertex x="46.77" y="14.27"/>
<vertex x="46.77" y="14.21"/>
<vertex x="46.77" y="14.14"/>
<vertex x="46.97" y="14.14"/>
<vertex x="47.17" y="14.14"/>
<vertex x="47.37" y="14.14"/>
<vertex x="47.57" y="14.14"/>
<vertex x="47.77" y="14.14"/>
<vertex x="47.97" y="14.14"/>
<vertex x="48.17" y="14.14"/>
<vertex x="48.37" y="14.14"/>
<vertex x="48.37" y="13.95"/>
<vertex x="48.37" y="13.75"/>
<vertex x="48.37" y="13.56"/>
<vertex x="48.37" y="13.36"/>
<vertex x="48.37" y="13.17"/>
<vertex x="48.37" y="12.97"/>
<vertex x="48.37" y="12.78"/>
<vertex x="48.37" y="12.58"/>
<vertex x="48.17" y="12.58"/>
<vertex x="47.97" y="12.58"/>
<vertex x="47.77" y="12.58"/>
<vertex x="47.57" y="12.58"/>
<vertex x="47.37" y="12.58"/>
<vertex x="47.17" y="12.58"/>
<vertex x="46.97" y="12.58"/>
<vertex x="46.77" y="12.58"/>
<vertex x="46.77" y="11.72"/>
<vertex x="46.77" y="10.85"/>
<vertex x="46.77" y="9.99"/>
<vertex x="46.77" y="9.12"/>
<vertex x="46.77" y="8.26"/>
<vertex x="46.77" y="7.39"/>
<vertex x="46.77" y="6.53"/>
<vertex x="46.77" y="5.66"/>
<vertex x="46.47" y="5.66"/>
<vertex x="46.18" y="5.66"/>
<vertex x="45.89" y="5.66"/>
<vertex x="45.6" y="5.66"/>
<vertex x="45.31" y="5.66"/>
<vertex x="45.02" y="5.66"/>
<vertex x="44.73" y="5.66"/>
<vertex x="44.44" y="5.66"/>
<vertex x="44.44" y="6.53"/>
<vertex x="44.44" y="7.39"/>
<vertex x="44.44" y="8.26"/>
<vertex x="44.44" y="9.12"/>
<vertex x="44.44" y="9.99"/>
<vertex x="44.44" y="10.85"/>
<vertex x="44.44" y="11.72"/>
</polygon>
<vertex x="56.99" y="5.66"/>
<vertex x="56.71" y="5.66"/>
<vertex x="56.43" y="5.66"/>
<vertex x="56.16" y="5.66"/>
<vertex x="55.88" y="5.66"/>
<vertex x="55.6" y="5.66"/>
<vertex x="55.33" y="5.66"/>
<vertex x="55.05" y="5.66"/>
<vertex x="54.77" y="5.66"/>
<vertex x="54.77" y="5.81"/>
<vertex x="54.77" y="5.96"/>
<vertex x="54.77" y="6.1"/>
<vertex x="54.77" y="6.25"/>
<vertex x="54.77" y="6.4"/>
<vertex x="54.77" y="6.55"/>
<vertex x="54.77" y="6.69"/>
<vertex x="54.77" y="6.84"/>
<vertex x="54.76" y="6.84"/>
<vertex x="54.75" y="6.84"/>
<vertex x="54.74" y="6.84"/>
<vertex x="54.5" y="6.5"/>
<vertex x="54.23" y="6.21"/>
<vertex x="53.92" y="5.97"/>
<vertex x="53.6" y="5.77"/>
<vertex x="53.25" y="5.62"/>
<vertex x="52.89" y="5.51"/>
<vertex x="52.52" y="5.45"/>
<vertex x="52.15" y="5.43"/>
<vertex x="51.31" y="5.49"/>
<vertex x="50.62" y="5.68"/>
<vertex x="50.08" y="5.98"/>
<vertex x="49.67" y="6.39"/>
<vertex x="49.38" y="6.9"/>
<vertex x="49.19" y="7.49"/>
<vertex x="49.08" y="8.17"/>
<vertex x="49.05" y="8.92"/>
<vertex x="49.05" y="9.58"/>
<vertex x="49.05" y="10.23"/>
<vertex x="49.05" y="10.88"/>
<vertex x="49.05" y="11.53"/>
<vertex x="49.05" y="12.19"/>
<vertex x="49.05" y="12.84"/>
<vertex x="49.05" y="13.49"/>
<vertex x="49.05" y="14.14"/>
<vertex x="49.34" y="14.14"/>
<vertex x="49.63" y="14.14"/>
<vertex x="49.92" y="14.14"/>
<vertex x="50.22" y="14.14"/>
<vertex x="50.51" y="14.14"/>
<vertex x="50.8" y="14.14"/>
<vertex x="51.09" y="14.14"/>
<vertex x="51.38" y="14.14"/>
<vertex x="51.38" y="13.54"/>
<vertex x="51.38" y="12.94"/>
<vertex x="51.38" y="12.35"/>
<vertex x="51.38" y="11.75"/>
<vertex x="51.38" y="11.15"/>
<vertex x="51.38" y="10.55"/>
<vertex x="51.38" y="9.95"/>
<vertex x="51.38" y="9.35"/>
<vertex x="51.4" y="8.86"/>
<vertex x="51.46" y="8.44"/>
<vertex x="51.57" y="8.08"/>
<vertex x="51.72" y="7.79"/>
<vertex x="51.92" y="7.56"/>
<vertex x="52.18" y="7.4"/>
<vertex x="52.5" y="7.3"/>
<vertex x="52.88" y="7.27"/>
<vertex x="53.32" y="7.3"/>
<vertex x="53.69" y="7.4"/>
<vertex x="54" y="7.58"/>
<vertex x="54.25" y="7.84"/>
<vertex x="54.44" y="8.17"/>
<vertex x="54.58" y="8.59"/>
<vertex x="54.65" y="9.1"/>
<vertex x="54.68" y="9.7"/>
<vertex x="54.68" y="10.25"/>
<vertex x="54.68" y="10.81"/>
<vertex x="54.68" y="11.36"/>
<vertex x="54.68" y="11.92"/>
<vertex x="54.68" y="12.47"/>
<vertex x="54.68" y="13.03"/>
<vertex x="54.68" y="13.59"/>
<vertex x="54.68" y="14.14"/>
<vertex x="54.97" y="14.14"/>
<vertex x="55.26" y="14.14"/>
<vertex x="55.55" y="14.14"/>
<vertex x="55.85" y="14.14"/>
<vertex x="56.14" y="14.14"/>
<vertex x="56.43" y="14.14"/>
<vertex x="56.72" y="14.14"/>
<vertex x="57.01" y="14.14"/>
<vertex x="57.01" y="13.08"/>
<vertex x="57.01" y="12.02"/>
<vertex x="57.01" y="10.96"/>
<vertex x="57.01" y="9.9"/>
<vertex x="57.01" y="8.84"/>
<vertex x="57.01" y="7.78"/>
<vertex x="57.01" y="6.72"/>
</polygon>
<vertex x="58.27" y="14.14"/>
<vertex x="58.55" y="14.14"/>
<vertex x="58.83" y="14.14"/>
<vertex x="59.1" y="14.14"/>
<vertex x="59.38" y="14.14"/>
<vertex x="59.66" y="14.14"/>
<vertex x="59.93" y="14.14"/>
<vertex x="60.21" y="14.14"/>
<vertex x="60.49" y="14.14"/>
<vertex x="60.49" y="14"/>
<vertex x="60.49" y="13.85"/>
<vertex x="60.49" y="13.7"/>
<vertex x="60.49" y="13.55"/>
<vertex x="60.49" y="13.41"/>
<vertex x="60.49" y="13.26"/>
<vertex x="60.49" y="13.11"/>
<vertex x="60.49" y="12.96"/>
<vertex x="60.5" y="12.96"/>
<vertex x="60.51" y="12.96"/>
<vertex x="60.52" y="12.96"/>
<vertex x="60.76" y="13.3"/>
<vertex x="61.03" y="13.59"/>
<vertex x="61.33" y="13.84"/>
<vertex x="61.66" y="14.03"/>
<vertex x="62.01" y="14.18"/>
<vertex x="62.37" y="14.29"/>
<vertex x="62.74" y="14.35"/>
<vertex x="63.11" y="14.38"/>
<vertex x="63.95" y="14.31"/>
<vertex x="64.64" y="14.12"/>
<vertex x="65.18" y="13.82"/>
<vertex x="65.59" y="13.42"/>
<vertex x="65.88" y="12.91"/>
<vertex x="66.07" y="12.31"/>
<vertex x="66.18" y="11.63"/>
<vertex x="66.21" y="10.88"/>
<vertex x="66.21" y="10.23"/>
<vertex x="66.21" y="9.58"/>
<vertex x="66.21" y="8.92"/>
<vertex x="66.21" y="8.27"/>
<vertex x="66.21" y="7.62"/>
<vertex x="66.21" y="6.97"/>
<vertex x="66.21" y="6.32"/>
<vertex x="66.21" y="5.66"/>
<vertex x="65.92" y="5.66"/>
<vertex x="65.63" y="5.66"/>
<vertex x="65.33" y="5.66"/>
<vertex x="65.04" y="5.66"/>
<vertex x="64.75" y="5.66"/>
<vertex x="64.46" y="5.66"/>
<vertex x="64.17" y="5.66"/>
<vertex x="63.88" y="5.66"/>
<vertex x="63.88" y="6.26"/>
<vertex x="63.88" y="6.86"/>
<vertex x="63.88" y="7.46"/>
<vertex x="63.88" y="8.06"/>
<vertex x="63.88" y="8.66"/>
<vertex x="63.88" y="9.26"/>
<vertex x="63.88" y="9.85"/>
<vertex x="63.88" y="10.45"/>
<vertex x="63.86" y="10.94"/>
<vertex x="63.8" y="11.37"/>
<vertex x="63.69" y="11.73"/>
<vertex x="63.54" y="12.02"/>
<vertex x="63.34" y="12.25"/>
<vertex x="63.08" y="12.41"/>
<vertex x="62.76" y="12.51"/>
<vertex x="62.38" y="12.54"/>
<vertex x="61.94" y="12.5"/>
<vertex x="61.57" y="12.4"/>
<vertex x="61.26" y="12.22"/>
<vertex x="61.01" y="11.97"/>
<vertex x="60.82" y="11.63"/>
<vertex x="60.68" y="11.22"/>
<vertex x="60.61" y="10.71"/>
<vertex x="60.58" y="10.11"/>
<vertex x="60.58" y="9.55"/>
<vertex x="60.58" y="9"/>
<vertex x="60.58" y="8.44"/>
<vertex x="60.58" y="7.89"/>
<vertex x="60.58" y="7.33"/>
<vertex x="60.58" y="6.77"/>
<vertex x="60.58" y="6.22"/>
<vertex x="60.58" y="5.66"/>
<vertex x="60.29" y="5.66"/>
<vertex x="60" y="5.66"/>
<vertex x="59.71" y="5.66"/>
<vertex x="59.42" y="5.66"/>
<vertex x="59.12" y="5.66"/>
<vertex x="58.83" y="5.66"/>
<vertex x="58.54" y="5.66"/>
<vertex x="58.25" y="5.66"/>
<vertex x="58.25" y="6.72"/>
<vertex x="58.25" y="7.78"/>
<vertex x="58.25" y="8.84"/>
<vertex x="58.25" y="9.9"/>
<vertex x="58.25" y="10.97"/>
<vertex x="58.25" y="12.03"/>
<vertex x="58.25" y="13.09"/>
</polygon>
<vertex x="47.74" y="28.7"/>
<vertex x="47.75" y="28.66"/>
<vertex x="47.76" y="28.56"/>
<vertex x="47.77" y="28.41"/>
<vertex x="47.76" y="28.23"/>
<vertex x="47.71" y="28.05"/>
<vertex x="47.63" y="27.88"/>
<vertex x="47.48" y="27.74"/>
<vertex x="47.26" y="27.66"/>
<vertex x="47.07" y="27.66"/>
<vertex x="46.86" y="27.7"/>
<vertex x="46.63" y="27.78"/>
<vertex x="46.4" y="27.89"/>
<vertex x="46.18" y="28.03"/>
<vertex x="45.97" y="28.19"/>
<vertex x="45.78" y="28.36"/>
<vertex x="45.61" y="28.53"/>
<vertex x="45.46" y="28.75"/>
<vertex x="45.35" y="28.95"/>
<vertex x="45.29" y="29.14"/>
<vertex x="45.27" y="29.33"/>
<vertex x="45.29" y="29.5"/>
<vertex x="45.35" y="29.67"/>
<vertex x="45.44" y="29.83"/>
<vertex x="45.56" y="29.99"/>
<vertex x="45.79" y="30.19"/>
<vertex x="46.04" y="30.31"/>
<vertex x="46.29" y="30.38"/>
<vertex x="46.54" y="30.41"/>
<vertex x="46.75" y="30.42"/>
<vertex x="46.93" y="30.4"/>
<vertex x="47.05" y="30.38"/>
<vertex x="47.09" y="30.37"/>
<vertex x="47.01" y="30.44"/>
<vertex x="46.78" y="30.59"/>
<vertex x="46.43" y="30.8"/>
<vertex x="45.98" y="30.99"/>
<vertex x="45.43" y="31.12"/>
<vertex x="44.83" y="31.14"/>
<vertex x="44.17" y="31.01"/>
<vertex x="43.49" y="30.65"/>
<vertex x="42.97" y="30.21"/>
<vertex x="42.64" y="29.74"/>
<vertex x="42.48" y="29.25"/>
<vertex x="42.48" y="28.73"/>
<vertex x="42.62" y="28.21"/>
<vertex x="42.9" y="27.68"/>
<vertex x="43.29" y="27.16"/>
<vertex x="43.8" y="26.65"/>
<vertex x="44.19" y="26.2"/>
<vertex x="44.38" y="25.75"/>
<vertex x="44.4" y="25.33"/>
<vertex x="44.27" y="24.95"/>
<vertex x="44.01" y="24.64"/>
<vertex x="43.65" y="24.41"/>
<vertex x="43.21" y="24.29"/>
<vertex x="42.73" y="24.29"/>
<vertex x="42.41" y="24.36"/>
<vertex x="42.14" y="24.48"/>
<vertex x="41.93" y="24.63"/>
<vertex x="41.76" y="24.81"/>
<vertex x="41.65" y="25.01"/>
<vertex x="41.6" y="25.21"/>
<vertex x="41.6" y="25.41"/>
<vertex x="41.65" y="25.59"/>
<vertex x="41.75" y="25.73"/>
<vertex x="41.87" y="25.86"/>
<vertex x="42.01" y="25.96"/>
<vertex x="42.15" y="26.05"/>
<vertex x="42.29" y="26.12"/>
<vertex x="42.4" y="26.18"/>
<vertex x="42.48" y="26.21"/>
<vertex x="42.5" y="26.22"/>
<vertex x="42.47" y="26.23"/>
<vertex x="42.37" y="26.26"/>
<vertex x="42.22" y="26.3"/>
<vertex x="42.01" y="26.33"/>
<vertex x="41.77" y="26.35"/>
<vertex x="41.49" y="26.34"/>
<vertex x="41.18" y="26.29"/>
<vertex x="40.85" y="26.2"/>
<vertex x="40.56" y="26.06"/>
<vertex x="40.29" y="25.89"/>
<vertex x="40.04" y="25.67"/>
<vertex x="39.83" y="25.39"/>
<vertex x="39.66" y="25.05"/>
<vertex x="39.53" y="24.64"/>
<vertex x="39.46" y="24.15"/>
<vertex x="39.45" y="23.57"/>
<vertex x="39.45" y="22.61"/>
<vertex x="39.45" y="21.65"/>
<vertex x="39.45" y="20.69"/>
<vertex x="39.45" y="19.73"/>
<vertex x="39.45" y="18.77"/>
<vertex x="39.45" y="17.81"/>
<vertex x="39.45" y="16.85"/>
<vertex x="39.45" y="15.88"/>
<vertex x="39.48" y="15.93"/>
<vertex x="39.59" y="16.06"/>
<vertex x="39.76" y="16.26"/>
<vertex x="39.98" y="16.53"/>
<vertex x="40.25" y="16.84"/>
<vertex x="40.56" y="17.19"/>
<vertex x="40.89" y="17.56"/>
<vertex x="41.25" y="17.95"/>
<vertex x="41.63" y="18.37"/>
<vertex x="41.97" y="18.74"/>
<vertex x="42.29" y="19.08"/>
<vertex x="42.59" y="19.35"/>
<vertex x="42.89" y="19.57"/>
<vertex x="43.21" y="19.73"/>
<vertex x="43.56" y="19.81"/>
<vertex x="43.95" y="19.81"/>
<vertex x="44.72" y="19.81"/>
<vertex x="45.43" y="19.91"/>
<vertex x="46.09" y="20.09"/>
<vertex x="46.7" y="20.36"/>
<vertex x="47.26" y="20.7"/>
<vertex x="47.77" y="21.11"/>
<vertex x="48.23" y="21.59"/>
<vertex x="48.64" y="22.13"/>
<vertex x="48.74" y="22.27"/>
<vertex x="49.23" y="23.23"/>
<vertex x="49.29" y="23.37"/>
<vertex x="49.53" y="24.32"/>
<vertex x="49.55" y="24.46"/>
<vertex x="49.59" y="25.37"/>
<vertex x="49.44" y="26.35"/>
<vertex x="49.14" y="27.2"/>
<vertex x="48.72" y="27.91"/>
<vertex x="48.24" y="28.42"/>
<vertex x="47.74" y="28.71"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.7">
<vertex x="3.67" y="9.52"/>
<vertex x="3.71" y="9.11"/>
<vertex x="3.85" y="8.77"/>
<vertex x="4.05" y="8.48"/>
<vertex x="4.32" y="8.25"/>
<vertex x="4.63" y="8.08"/>
<vertex x="4.98" y="7.95"/>
<vertex x="5.36" y="7.88"/>
<vertex x="5.75" y="7.86"/>
<vertex x="6.05" y="7.87"/>
<vertex x="6.36" y="7.92"/>
<vertex x="6.65" y="8"/>
<vertex x="6.93" y="8.13"/>
<vertex x="7.17" y="8.3"/>
<vertex x="7.36" y="8.52"/>
<vertex x="7.49" y="8.79"/>
<vertex x="7.54" y="9.12"/>
<vertex x="7.48" y="9.4"/>
<vertex x="7.33" y="9.65"/>
<vertex x="7.07" y="9.86"/>
<vertex x="6.72" y="10.04"/>
<vertex x="6.28" y="10.2"/>
<vertex x="5.75" y="10.36"/>
<vertex x="5.14" y="10.5"/>
<vertex x="4.45" y="10.65"/>
<vertex x="3.86" y="10.79"/>
<vertex x="3.29" y="10.97"/>
<vertex x="2.76" y="11.18"/>
<vertex x="2.29" y="11.45"/>
<vertex x="1.89" y="11.78"/>
<vertex x="1.58" y="12.19"/>
<vertex x="1.38" y="12.69"/>
<vertex x="1.31" y="13.29"/>
<vertex x="1.41" y="14.15"/>
<vertex x="1.69" y="14.85"/>
<vertex x="2.12" y="15.41"/>
<vertex x="2.67" y="15.83"/>
<vertex x="3.32" y="16.13"/>
<vertex x="4.05" y="16.33"/>
<vertex x="4.82" y="16.44"/>
<vertex x="5.62" y="16.47"/>
<vertex x="6.41" y="16.43"/>
<vertex x="7.18" y="16.32"/>
<vertex x="7.89" y="16.11"/>
<vertex x="8.53" y="15.8"/>
<vertex x="9.08" y="15.38"/>
<vertex x="9.52" y="14.83"/>
<vertex x="9.83" y="14.14"/>
<vertex x="9.99" y="13.31"/>
<vertex x="9.66" y="13.31"/>
<vertex x="9.34" y="13.31"/>
<vertex x="9.02" y="13.31"/>
<vertex x="8.69" y="13.31"/>
<vertex x="8.37" y="13.31"/>
<vertex x="8.05" y="13.31"/>
<vertex x="7.73" y="13.31"/>
<vertex x="7.4" y="13.31"/>
<vertex x="7.34" y="13.67"/>
<vertex x="7.22" y="13.96"/>
<vertex x="7.04" y="14.2"/>
<vertex x="6.81" y="14.38"/>
<vertex x="6.54" y="14.51"/>
<vertex x="6.24" y="14.59"/>
<vertex x="5.9" y="14.64"/>
<vertex x="5.54" y="14.65"/>
<vertex x="5.3" y="14.65"/>
<vertex x="5.05" y="14.62"/>
<vertex x="4.8" y="14.58"/>
<vertex x="4.56" y="14.5"/>
<vertex x="4.35" y="14.38"/>
<vertex x="4.18" y="14.22"/>
<vertex x="4.07" y="14.01"/>
<vertex x="4.03" y="13.73"/>
<vertex x="4.1" y="13.4"/>
<vertex x="4.3" y="13.14"/>
<vertex x="4.6" y="12.93"/>
<vertex x="5" y="12.77"/>
<vertex x="5.47" y="12.63"/>
<vertex x="5.99" y="12.5"/>
<vertex x="6.54" y="12.39"/>
<vertex x="7.11" y="12.26"/>
<vertex x="7.71" y="12.11"/>
<vertex x="8.27" y="11.93"/>
<vertex x="8.81" y="11.7"/>
<vertex x="9.28" y="11.42"/>
<vertex x="9.68" y="11.07"/>
<vertex x="9.99" y="10.64"/>
<vertex x="10.18" y="10.11"/>
<vertex x="10.25" y="9.48"/>
<vertex x="10.15" y="8.59"/>
<vertex x="9.86" y="7.85"/>
<vertex x="9.41" y="7.25"/>
<vertex x="8.83" y="6.78"/>
<vertex x="8.15" y="6.44"/>
<vertex x="7.38" y="6.21"/>
<vertex x="6.57" y="6.08"/>
<vertex x="5.73" y="6.04"/>
<vertex x="4.88" y="6.08"/>
<vertex x="4.05" y="6.21"/>
<vertex x="3.28" y="6.45"/>
<vertex x="2.58" y="6.8"/>
<vertex x="1.99" y="7.27"/>
<vertex x="1.53" y="7.87"/>
<vertex x="1.22" y="8.62"/>
<vertex x="1.08" y="9.52"/>
<vertex x="1.41" y="9.52"/>
<vertex x="1.73" y="9.52"/>
<vertex x="2.05" y="9.52"/>
<vertex x="2.38" y="9.52"/>
<vertex x="2.7" y="9.52"/>
<vertex x="3.02" y="9.52"/>
<vertex x="3.34" y="9.52"/>
</polygon>
<vertex x="18.42" y="9.53"/>
<vertex x="18.57" y="10.06"/>
<vertex x="18.66" y="10.63"/>
<vertex x="18.69" y="11.23"/>
<vertex x="21.41" y="11.15"/>
<vertex x="21.34" y="10.17"/>
<vertex x="21.14" y="9.24"/>
<vertex x="20.8" y="8.37"/>
</polygon>
<vertex x="20.33" y="7.6"/>
<vertex x="19.72" y="6.96"/>
<vertex x="18.97" y="6.46"/>
<vertex x="18.09" y="6.15"/>
<vertex x="17.97" y="6.12"/>
<vertex x="17.06" y="6.04"/>
<vertex x="16.62" y="6.06"/>
<vertex x="16.19" y="6.13"/>
<vertex x="15.77" y="6.25"/>
<vertex x="15.38" y="6.42"/>
<vertex x="15.01" y="6.63"/>
<vertex x="14.67" y="6.89"/>
<vertex x="14.37" y="7.19"/>
<vertex x="14.1" y="7.53"/>
<vertex x="14.09" y="7.53"/>
<vertex x="14.08" y="7.53"/>
<vertex x="14.08" y="6.64"/>
<vertex x="14.08" y="5.75"/>
<vertex x="14.08" y="4.86"/>
<vertex x="14.08" y="3.97"/>
<vertex x="14.08" y="3.08"/>
<vertex x="14.08" y="2.19"/>
<vertex x="14.08" y="1.3"/>
<vertex x="14.08" y="0.4"/>
<vertex x="13.74" y="0.71"/>
<vertex x="13.4" y="1.01"/>
<vertex x="13.06" y="1.31"/>
<vertex x="12.72" y="1.61"/>
<vertex x="12.38" y="1.92"/>
<vertex x="12.04" y="2.22"/>
<vertex x="11.7" y="2.52"/>
<vertex x="11.36" y="2.82"/>
<vertex x="11.36" y="4.44"/>
<vertex x="11.36" y="6.05"/>
<vertex x="11.36" y="7.67"/>
<vertex x="11.36" y="9.28"/>
<vertex x="11.36" y="10.9"/>
<vertex x="11.36" y="12.51"/>
<vertex x="11.36" y="14.13"/>
<vertex x="11.36" y="15.74"/>
<vertex x="11.69" y="15.8"/>
<vertex x="12.01" y="15.86"/>
<vertex x="12.33" y="15.92"/>
<vertex x="12.66" y="15.97"/>
<vertex x="12.98" y="16.03"/>
<vertex x="13.3" y="16.09"/>
<vertex x="13.63" y="16.15"/>
<vertex x="13.95" y="16.2"/>
<vertex x="13.95" y="16.05"/>
<vertex x="13.95" y="15.89"/>
<vertex x="13.95" y="15.73"/>
<vertex x="13.95" y="15.57"/>
<vertex x="13.95" y="15.41"/>
<vertex x="13.95" y="15.26"/>
<vertex x="13.95" y="15.1"/>
<vertex x="13.95" y="14.94"/>
<vertex x="13.96" y="14.94"/>
<vertex x="13.97" y="14.94"/>
<vertex x="14.23" y="15.31"/>
<vertex x="14.54" y="15.63"/>
<vertex x="14.87" y="15.9"/>
<vertex x="15.23" y="16.11"/>
<vertex x="15.62" y="16.27"/>
<vertex x="16.03" y="16.38"/>
<vertex x="16.46" y="16.45"/>
<vertex x="16.91" y="16.47"/>
<vertex x="17.06" y="16.47"/>
<vertex x="18" y="16.36"/>
<vertex x="18.92" y="16.04"/>
<vertex x="19.7" y="15.53"/>
<vertex x="20.33" y="14.87"/>
<vertex x="20.81" y="14.07"/>
<vertex x="21.14" y="13.17"/>
<vertex x="21.18" y="13.05"/>
<vertex x="21.35" y="12.19"/>
<vertex x="21.36" y="12.06"/>
<vertex x="18.69" y="11.22"/>
<vertex x="18.66" y="11.82"/>
<vertex x="18.56" y="12.39"/>
<vertex x="18.4" y="12.93"/>
<vertex x="18.16" y="13.42"/>
<vertex x="17.83" y="13.83"/>
<vertex x="17.42" y="14.15"/>
<vertex x="16.92" y="14.35"/>
<vertex x="16.32" y="14.42"/>
<vertex x="15.71" y="14.35"/>
<vertex x="15.2" y="14.15"/>
<vertex x="14.79" y="13.83"/>
<vertex x="14.47" y="13.43"/>
<vertex x="14.24" y="12.94"/>
<vertex x="14.08" y="12.4"/>
<vertex x="13.99" y="11.82"/>
<vertex x="13.96" y="11.23"/>
<vertex x="13.99" y="10.63"/>
<vertex x="14.09" y="10.06"/>
<vertex x="14.25" y="9.53"/>
<vertex x="14.49" y="9.05"/>
<vertex x="14.81" y="8.66"/>
<vertex x="15.22" y="8.35"/>
<vertex x="15.73" y="8.16"/>
<vertex x="16.34" y="8.09"/>
<vertex x="16.95" y="8.16"/>
<vertex x="17.46" y="8.35"/>
<vertex x="17.87" y="8.66"/>
<vertex x="18.18" y="9.05"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="25.54" y="11.98"/>
<vertex x="26.16" y="12.06"/>
<vertex x="26.76" y="12.13"/>
<vertex x="27.31" y="12.21"/>
<vertex x="27.64" y="10.74"/>
<vertex x="27.48" y="10.72"/>
<vertex x="27.32" y="10.69"/>
<vertex x="27.16" y="10.67"/>
<vertex x="27" y="10.64"/>
<vertex x="26.84" y="10.62"/>
<vertex x="26.68" y="10.59"/>
<vertex x="26.52" y="10.57"/>
<vertex x="26.36" y="10.54"/>
<vertex x="26.21" y="10.5"/>
<vertex x="26.06" y="10.46"/>
</polygon>
<vertex x="25.91" y="10.42"/>
<vertex x="25.77" y="10.36"/>
<vertex x="25.64" y="10.3"/>
<vertex x="25.51" y="10.23"/>
<vertex x="25.4" y="10.15"/>
<vertex x="25.29" y="10.07"/>
<vertex x="25.2" y="9.97"/>
<vertex x="25.11" y="9.86"/>
<vertex x="25.04" y="9.74"/>
<vertex x="24.99" y="9.6"/>
<vertex x="24.94" y="9.45"/>
<vertex x="24.92" y="9.29"/>
<vertex x="24.91" y="9.11"/>
<vertex x="24.92" y="8.93"/>
<vertex x="24.94" y="8.77"/>
<vertex x="24.99" y="8.62"/>
<vertex x="25.04" y="8.49"/>
<vertex x="25.12" y="8.38"/>
<vertex x="25.2" y="8.27"/>
<vertex x="25.3" y="8.18"/>
<vertex x="25.41" y="8.1"/>
<vertex x="25.53" y="8.04"/>
<vertex x="25.66" y="7.98"/>
<vertex x="25.8" y="7.94"/>
<vertex x="25.94" y="7.9"/>
<vertex x="26.09" y="7.88"/>
<vertex x="26.25" y="7.86"/>
<vertex x="26.41" y="7.85"/>
<vertex x="26.58" y="7.85"/>
<vertex x="26.95" y="7.87"/>
<vertex x="27.28" y="7.92"/>
<vertex x="27.57" y="8.01"/>
<vertex x="27.82" y="8.12"/>
<vertex x="28.03" y="8.26"/>
<vertex x="28.21" y="8.41"/>
<vertex x="28.35" y="8.58"/>
<vertex x="28.47" y="8.76"/>
<vertex x="28.57" y="8.95"/>
<vertex x="28.64" y="9.14"/>
<vertex x="28.69" y="9.33"/>
<vertex x="28.73" y="9.52"/>
<vertex x="28.76" y="9.69"/>
<vertex x="28.77" y="9.86"/>
<vertex x="28.77" y="10"/>
<vertex x="28.77" y="10.13"/>
<vertex x="28.77" y="10.19"/>
<vertex x="28.77" y="10.26"/>
<vertex x="28.77" y="10.32"/>
<vertex x="28.77" y="10.38"/>
<vertex x="28.77" y="10.45"/>
<vertex x="28.77" y="10.51"/>
<vertex x="28.77" y="10.57"/>
<vertex x="28.77" y="10.64"/>
<vertex x="28.77" y="10.7"/>
<vertex x="28.77" y="10.76"/>
<vertex x="28.77" y="10.83"/>
<vertex x="28.77" y="10.89"/>
<vertex x="28.77" y="10.95"/>
<vertex x="28.77" y="11.02"/>
<vertex x="28.77" y="11.08"/>
<vertex x="28.77" y="11.14"/>
<vertex x="28.68" y="11.07"/>
<vertex x="28.58" y="11.01"/>
<vertex x="28.47" y="10.95"/>
<vertex x="28.35" y="10.9"/>
<vertex x="28.22" y="10.86"/>
<vertex x="28.08" y="10.82"/>
<vertex x="27.94" y="10.79"/>
<vertex x="27.79" y="10.76"/>
<vertex x="27.8" y="12.32"/>
<vertex x="28.21" y="12.46"/>
<vertex x="28.53" y="12.66"/>
<vertex x="28.72" y="12.94"/>
<vertex x="28.77" y="13.3"/>
<vertex x="28.77" y="13.51"/>
<vertex x="28.74" y="13.69"/>
<vertex x="28.7" y="13.85"/>
<vertex x="28.64" y="14"/>
<vertex x="28.56" y="14.12"/>
<vertex x="28.47" y="14.23"/>
<vertex x="28.37" y="14.33"/>
<vertex x="28.26" y="14.4"/>
<vertex x="28.13" y="14.47"/>
<vertex x="28" y="14.52"/>
<vertex x="27.85" y="14.56"/>
<vertex x="27.7" y="14.59"/>
<vertex x="27.54" y="14.62"/>
<vertex x="27.37" y="14.63"/>
<vertex x="27.19" y="14.64"/>
<vertex x="27.02" y="14.64"/>
<vertex x="26.82" y="14.64"/>
<vertex x="26.64" y="14.62"/>
<vertex x="26.47" y="14.59"/>
<vertex x="26.31" y="14.55"/>
<vertex x="26.15" y="14.5"/>
<vertex x="26.01" y="14.44"/>
<vertex x="25.88" y="14.37"/>
<vertex x="25.76" y="14.29"/>
<vertex x="25.65" y="14.19"/>
<vertex x="25.55" y="14.08"/>
<vertex x="25.47" y="13.96"/>
<vertex x="25.39" y="13.83"/>
<vertex x="25.33" y="13.68"/>
<vertex x="25.28" y="13.51"/>
<vertex x="25.24" y="13.33"/>
<vertex x="25.22" y="13.14"/>
<vertex x="25.05" y="13.14"/>
<vertex x="24.88" y="13.14"/>
<vertex x="24.71" y="13.14"/>
<vertex x="24.54" y="13.14"/>
<vertex x="24.37" y="13.14"/>
<vertex x="24.2" y="13.14"/>
<vertex x="24.03" y="13.14"/>
<vertex x="23.86" y="13.14"/>
<vertex x="23.69" y="13.14"/>
<vertex x="23.52" y="13.14"/>
<vertex x="23.35" y="13.14"/>
<vertex x="23.18" y="13.14"/>
<vertex x="23.01" y="13.14"/>
<vertex x="22.84" y="13.14"/>
<vertex x="22.67" y="13.14"/>
<vertex x="22.5" y="13.14"/>
<vertex x="22.56" y="13.59"/>
<vertex x="22.66" y="14.01"/>
<vertex x="22.8" y="14.38"/>
<vertex x="22.98" y="14.72"/>
<vertex x="23.2" y="15.03"/>
<vertex x="23.46" y="15.3"/>
<vertex x="23.74" y="15.54"/>
<vertex x="24.05" y="15.74"/>
<vertex x="24.39" y="15.92"/>
<vertex x="24.75" y="16.07"/>
<vertex x="25.12" y="16.19"/>
<vertex x="25.51" y="16.29"/>
<vertex x="25.91" y="16.36"/>
<vertex x="26.32" y="16.41"/>
<vertex x="26.74" y="16.44"/>
<vertex x="27.16" y="16.45"/>
<vertex x="27.53" y="16.44"/>
<vertex x="27.91" y="16.42"/>
<vertex x="28.29" y="16.39"/>
<vertex x="28.67" y="16.34"/>
<vertex x="29.04" y="16.27"/>
<vertex x="29.4" y="16.18"/>
<vertex x="29.74" y="16.07"/>
<vertex x="30.07" y="15.93"/>
<vertex x="30.37" y="15.76"/>
<vertex x="30.65" y="15.57"/>
<vertex x="30.89" y="15.34"/>
<vertex x="31.1" y="15.07"/>
<vertex x="31.27" y="14.77"/>
<vertex x="31.4" y="14.44"/>
<vertex x="31.48" y="14.06"/>
<vertex x="31.5" y="13.63"/>
<vertex x="31.5" y="13.31"/>
<vertex x="31.5" y="12.99"/>
<vertex x="31.5" y="12.67"/>
<vertex x="31.5" y="12.35"/>
<vertex x="31.5" y="12.02"/>
<vertex x="31.5" y="11.7"/>
<vertex x="31.5" y="11.38"/>
<vertex x="31.5" y="11.06"/>
<vertex x="31.5" y="10.74"/>
<vertex x="31.5" y="10.41"/>
<vertex x="31.5" y="10.09"/>
<vertex x="31.5" y="9.77"/>
<vertex x="31.5" y="9.45"/>
<vertex x="31.5" y="9.13"/>
<vertex x="31.5" y="8.81"/>
<vertex x="31.5" y="8.48"/>
<vertex x="31.5" y="8.31"/>
<vertex x="31.51" y="8.15"/>
<vertex x="31.51" y="7.98"/>
<vertex x="31.51" y="7.82"/>
<vertex x="31.52" y="7.65"/>
<vertex x="31.53" y="7.5"/>
<vertex x="31.55" y="7.34"/>
<vertex x="31.58" y="7.2"/>
<vertex x="31.6" y="7.05"/>
<vertex x="31.63" y="6.92"/>
<vertex x="31.65" y="6.79"/>
<vertex x="31.68" y="6.67"/>
<vertex x="31.72" y="6.56"/>
<vertex x="31.76" y="6.46"/>
<vertex x="31.8" y="6.36"/>
<vertex x="31.84" y="6.28"/>
<vertex x="31.67" y="6.28"/>
<vertex x="31.5" y="6.28"/>
<vertex x="31.32" y="6.28"/>
<vertex x="31.15" y="6.28"/>
<vertex x="30.98" y="6.28"/>
<vertex x="30.81" y="6.28"/>
<vertex x="30.64" y="6.28"/>
<vertex x="30.46" y="6.28"/>
<vertex x="30.29" y="6.28"/>
<vertex x="30.12" y="6.28"/>
<vertex x="29.95" y="6.28"/>
<vertex x="29.78" y="6.28"/>
<vertex x="29.6" y="6.28"/>
<vertex x="29.43" y="6.28"/>
<vertex x="29.26" y="6.28"/>
<vertex x="29.09" y="6.28"/>
<vertex x="29.07" y="6.34"/>
<vertex x="29.05" y="6.4"/>
<vertex x="29.03" y="6.46"/>
<vertex x="29" y="6.52"/>
<vertex x="28.98" y="6.57"/>
<vertex x="28.97" y="6.63"/>
<vertex x="28.96" y="6.69"/>
<vertex x="28.94" y="6.75"/>
<vertex x="28.93" y="6.81"/>
<vertex x="28.92" y="6.88"/>
<vertex x="28.92" y="6.94"/>
<vertex x="28.91" y="7"/>
<vertex x="28.91" y="7.06"/>
<vertex x="28.9" y="7.12"/>
<vertex x="28.9" y="7.18"/>
<vertex x="28.9" y="7.24"/>
<vertex x="28.73" y="7.08"/>
<vertex x="28.56" y="6.93"/>
<vertex x="28.38" y="6.79"/>
<vertex x="28.19" y="6.67"/>
<vertex x="27.99" y="6.56"/>
<vertex x="27.79" y="6.46"/>
<vertex x="27.58" y="6.37"/>
<vertex x="27.37" y="6.29"/>
<vertex x="27.15" y="6.22"/>
<vertex x="26.93" y="6.17"/>
<vertex x="26.71" y="6.12"/>
<vertex x="26.48" y="6.08"/>
<vertex x="26.26" y="6.05"/>
<vertex x="26.03" y="6.03"/>
<vertex x="25.8" y="6.01"/>
<vertex x="25.57" y="6.01"/>
<vertex x="25.22" y="6.02"/>
<vertex x="24.88" y="6.05"/>
<vertex x="24.55" y="6.11"/>
<vertex x="24.24" y="6.19"/>
<vertex x="23.95" y="6.29"/>
<vertex x="23.67" y="6.41"/>
<vertex x="23.41" y="6.56"/>
<vertex x="23.17" y="6.73"/>
<vertex x="22.96" y="6.92"/>
<vertex x="22.77" y="7.14"/>
<vertex x="22.6" y="7.39"/>
<vertex x="22.46" y="7.65"/>
<vertex x="22.35" y="7.95"/>
<vertex x="22.27" y="8.26"/>
<vertex x="22.22" y="8.61"/>
<vertex x="22.2" y="8.98"/>
<vertex x="22.28" y="9.74"/>
<vertex x="22.49" y="10.36"/>
<vertex x="22.83" y="10.85"/>
<vertex x="23.26" y="11.23"/>
<vertex x="23.76" y="11.52"/>
<vertex x="24.33" y="11.73"/>
<vertex x="24.93" y="11.88"/>
</polygon>
<vertex x="33.03" y="15.74"/>
<vertex x="33.36" y="15.8"/>
<vertex x="33.68" y="15.86"/>
<vertex x="34" y="15.91"/>
<vertex x="34.33" y="15.97"/>
<vertex x="34.65" y="16.03"/>
<vertex x="34.97" y="16.09"/>
<vertex x="35.3" y="16.14"/>
<vertex x="35.62" y="16.2"/>
<vertex x="35.62" y="15.97"/>
<vertex x="35.62" y="15.74"/>
<vertex x="35.62" y="15.51"/>
<vertex x="35.62" y="15.28"/>
<vertex x="35.62" y="15.05"/>
<vertex x="35.62" y="14.82"/>
<vertex x="35.62" y="14.59"/>
<vertex x="35.62" y="14.36"/>
<vertex x="35.63" y="14.36"/>
<vertex x="35.64" y="14.36"/>
<vertex x="35.86" y="14.81"/>
<vertex x="36.16" y="15.21"/>
<vertex x="36.5" y="15.57"/>
<vertex x="36.9" y="15.88"/>
<vertex x="37.33" y="16.13"/>
<vertex x="37.8" y="16.31"/>
<vertex x="38.29" y="16.43"/>
<vertex x="38.79" y="16.47"/>
<vertex x="38.87" y="16.47"/>
<vertex x="38.95" y="16.46"/>
<vertex x="39.02" y="16.46"/>
<vertex x="39.1" y="16.45"/>
<vertex x="39.17" y="16.44"/>
<vertex x="39.25" y="16.41"/>
<vertex x="39.32" y="16.39"/>
<vertex x="39.39" y="16.37"/>
<vertex x="39.39" y="16.06"/>
<vertex x="39.39" y="15.74"/>
<vertex x="39.39" y="15.42"/>
<vertex x="39.39" y="15.11"/>
<vertex x="39.39" y="14.79"/>
<vertex x="39.39" y="14.48"/>
<vertex x="39.39" y="14.16"/>
<vertex x="39.39" y="13.85"/>
<vertex x="39.29" y="13.87"/>
<vertex x="39.18" y="13.89"/>
<vertex x="39.06" y="13.91"/>
<vertex x="38.93" y="13.92"/>
<vertex x="38.8" y="13.93"/>
<vertex x="38.67" y="13.93"/>
<vertex x="38.54" y="13.94"/>
<vertex x="38.41" y="13.94"/>
<vertex x="37.72" y="13.87"/>
<vertex x="37.15" y="13.69"/>
<vertex x="36.68" y="13.4"/>
<vertex x="36.32" y="13.01"/>
<vertex x="36.05" y="12.54"/>
<vertex x="35.87" y="12"/>
<vertex x="35.76" y="11.4"/>
<vertex x="35.73" y="10.76"/>
<vertex x="35.73" y="10.2"/>
<vertex x="35.73" y="9.65"/>
<vertex x="35.73" y="9.09"/>
<vertex x="35.73" y="8.53"/>
<vertex x="35.73" y="7.97"/>
<vertex x="35.73" y="7.42"/>
<vertex x="35.73" y="6.86"/>
<vertex x="35.73" y="6.3"/>
<vertex x="35.39" y="6.3"/>
<vertex x="35.05" y="6.3"/>
<vertex x="34.71" y="6.3"/>
<vertex x="34.37" y="6.3"/>
<vertex x="34.03" y="6.3"/>
<vertex x="33.69" y="6.3"/>
<vertex x="33.35" y="6.3"/>
<vertex x="33.01" y="6.3"/>
<vertex x="33.01" y="7.48"/>
<vertex x="33.01" y="8.66"/>
<vertex x="33.01" y="9.84"/>
<vertex x="33.01" y="11.02"/>
<vertex x="33.01" y="12.2"/>
<vertex x="33.01" y="13.38"/>
<vertex x="33.01" y="14.56"/>
</polygon>
<vertex x="40.46" y="18.48"/>
<vertex x="43.18" y="19.97"/>
<vertex x="43.18" y="12.64"/>
<vertex x="46.61" y="16.2"/>
<vertex x="49.82" y="16.2"/>
<vertex x="46.09" y="12.56"/>
<vertex x="50.24" y="6.31"/>
<vertex x="46.95" y="6.31"/>
<vertex x="44.23" y="10.73"/>
<vertex x="43.18" y="9.71"/>
<vertex x="43.18" y="6.31"/>
<vertex x="40.46" y="6.31"/>
</polygon>
<vertex x="51.89" y="14.38"/>
<vertex x="51.56" y="14.38"/>
<vertex x="51.22" y="14.38"/>
<vertex x="50.89" y="14.38"/>
<vertex x="50.55" y="14.38"/>
<vertex x="50.22" y="14.38"/>
<vertex x="49.88" y="14.38"/>
<vertex x="49.55" y="14.38"/>
<vertex x="49.21" y="14.38"/>
<vertex x="49.45" y="14.61"/>
<vertex x="49.68" y="14.84"/>
<vertex x="49.91" y="15.07"/>
<vertex x="50.14" y="15.29"/>
<vertex x="50.37" y="15.52"/>
<vertex x="50.6" y="15.75"/>
<vertex x="50.84" y="15.97"/>
<vertex x="51.07" y="16.2"/>
<vertex x="51.17" y="16.2"/>
<vertex x="51.27" y="16.2"/>
<vertex x="51.38" y="16.2"/>
<vertex x="51.48" y="16.2"/>
<vertex x="51.58" y="16.2"/>
<vertex x="51.69" y="16.2"/>
<vertex x="51.79" y="16.2"/>
<vertex x="51.89" y="16.2"/>
<vertex x="51.89" y="16.3"/>
<vertex x="51.89" y="16.39"/>
<vertex x="51.89" y="16.49"/>
<vertex x="51.89" y="16.58"/>
<vertex x="51.89" y="16.68"/>
<vertex x="51.89" y="16.77"/>
<vertex x="51.89" y="16.87"/>
<vertex x="51.89" y="16.96"/>
<vertex x="51.95" y="17.6"/>
<vertex x="52.1" y="18.18"/>
<vertex x="52.36" y="18.69"/>
<vertex x="52.72" y="19.13"/>
<vertex x="53.18" y="19.48"/>
<vertex x="53.75" y="19.75"/>
<vertex x="54.43" y="19.91"/>
<vertex x="55.21" y="19.97"/>
<vertex x="55.39" y="19.97"/>
<vertex x="55.57" y="19.97"/>
<vertex x="55.75" y="19.96"/>
<vertex x="55.93" y="19.95"/>
<vertex x="56.11" y="19.93"/>
<vertex x="56.29" y="19.92"/>
<vertex x="56.47" y="19.91"/>
<vertex x="56.64" y="19.91"/>
<vertex x="56.64" y="19.65"/>
<vertex x="56.64" y="19.4"/>
<vertex x="56.64" y="19.15"/>
<vertex x="56.64" y="18.89"/>
<vertex x="56.64" y="18.64"/>
<vertex x="56.64" y="18.38"/>
<vertex x="56.64" y="18.13"/>
<vertex x="56.64" y="17.88"/>
<vertex x="56.52" y="17.89"/>
<vertex x="56.4" y="17.91"/>
<vertex x="56.27" y="17.91"/>
<vertex x="56.14" y="17.92"/>
<vertex x="56.02" y="17.92"/>
<vertex x="55.89" y="17.92"/>
<vertex x="55.77" y="17.92"/>
<vertex x="55.65" y="17.92"/>
<vertex x="55.39" y="17.91"/>
<vertex x="55.17" y="17.86"/>
<vertex x="54.99" y="17.78"/>
<vertex x="54.85" y="17.67"/>
<vertex x="54.74" y="17.51"/>
<vertex x="54.67" y="17.32"/>
<vertex x="54.63" y="17.08"/>
<vertex x="54.61" y="16.8"/>
<vertex x="54.61" y="16.72"/>
<vertex x="54.61" y="16.65"/>
<vertex x="54.61" y="16.57"/>
<vertex x="54.61" y="16.5"/>
<vertex x="54.61" y="16.42"/>
<vertex x="54.61" y="16.35"/>
<vertex x="54.61" y="16.28"/>
<vertex x="54.61" y="16.2"/>
<vertex x="54.85" y="16.2"/>
<vertex x="55.08" y="16.2"/>
<vertex x="55.31" y="16.2"/>
<vertex x="55.55" y="16.2"/>
<vertex x="55.78" y="16.2"/>
<vertex x="56.02" y="16.2"/>
<vertex x="56.25" y="16.2"/>
<vertex x="56.49" y="16.2"/>
<vertex x="56.49" y="15.97"/>
<vertex x="56.49" y="15.75"/>
<vertex x="56.49" y="15.52"/>
<vertex x="56.49" y="15.29"/>
<vertex x="56.49" y="15.07"/>
<vertex x="56.49" y="14.84"/>
<vertex x="56.49" y="14.61"/>
<vertex x="56.49" y="14.38"/>
<vertex x="56.25" y="14.38"/>
<vertex x="56.02" y="14.38"/>
<vertex x="55.78" y="14.38"/>
<vertex x="55.55" y="14.38"/>
<vertex x="55.31" y="14.38"/>
<vertex x="55.08" y="14.38"/>
<vertex x="54.85" y="14.38"/>
<vertex x="54.61" y="14.38"/>
<vertex x="54.61" y="13.37"/>
<vertex x="54.61" y="12.36"/>
<vertex x="54.61" y="11.35"/>
<vertex x="54.61" y="10.34"/>
<vertex x="54.61" y="9.33"/>
<vertex x="54.61" y="8.32"/>
<vertex x="54.61" y="7.31"/>
<vertex x="54.61" y="6.3"/>
<vertex x="54.27" y="6.3"/>
<vertex x="53.93" y="6.3"/>
<vertex x="53.59" y="6.3"/>
<vertex x="53.25" y="6.3"/>
<vertex x="52.91" y="6.3"/>
<vertex x="52.57" y="6.3"/>
<vertex x="52.23" y="6.3"/>
<vertex x="51.89" y="6.3"/>
<vertex x="51.89" y="7.31"/>
<vertex x="51.89" y="8.32"/>
<vertex x="51.89" y="9.33"/>
<vertex x="51.89" y="10.34"/>
<vertex x="51.89" y="11.35"/>
<vertex x="51.89" y="12.36"/>
<vertex x="51.89" y="13.37"/>
</polygon>
<vertex x="66.54" y="6.3"/>
<vertex x="66.21" y="6.3"/>
<vertex x="65.89" y="6.3"/>
<vertex x="65.57" y="6.3"/>
<vertex x="65.24" y="6.3"/>
<vertex x="64.92" y="6.3"/>
<vertex x="64.6" y="6.3"/>
<vertex x="64.27" y="6.3"/>
<vertex x="63.95" y="6.3"/>
<vertex x="63.95" y="6.48"/>
<vertex x="63.95" y="6.65"/>
<vertex x="63.95" y="6.82"/>
<vertex x="63.95" y="6.99"/>
<vertex x="63.95" y="7.17"/>
<vertex x="63.95" y="7.34"/>
<vertex x="63.95" y="7.51"/>
<vertex x="63.95" y="7.68"/>
<vertex x="63.94" y="7.68"/>
<vertex x="63.93" y="7.68"/>
<vertex x="63.92" y="7.68"/>
<vertex x="63.64" y="7.29"/>
<vertex x="63.32" y="6.95"/>
<vertex x="62.96" y="6.66"/>
<vertex x="62.58" y="6.44"/>
<vertex x="62.18" y="6.26"/>
<vertex x="61.76" y="6.13"/>
<vertex x="61.33" y="6.06"/>
<vertex x="60.89" y="6.04"/>
<vertex x="59.91" y="6.11"/>
<vertex x="59.11" y="6.33"/>
<vertex x="58.48" y="6.68"/>
<vertex x="58" y="7.15"/>
<vertex x="57.66" y="7.75"/>
<vertex x="57.44" y="8.44"/>
<vertex x="57.31" y="9.23"/>
<vertex x="57.28" y="10.11"/>
<vertex x="57.28" y="10.87"/>
<vertex x="57.28" y="11.63"/>
<vertex x="57.28" y="12.39"/>
<vertex x="57.28" y="13.16"/>
<vertex x="57.28" y="13.92"/>
<vertex x="57.28" y="14.68"/>
<vertex x="57.28" y="15.44"/>
<vertex x="57.28" y="16.2"/>
<vertex x="57.62" y="16.2"/>
<vertex x="57.96" y="16.2"/>
<vertex x="58.3" y="16.2"/>
<vertex x="58.64" y="16.2"/>
<vertex x="58.98" y="16.2"/>
<vertex x="59.32" y="16.2"/>
<vertex x="59.66" y="16.2"/>
<vertex x="60" y="16.2"/>
<vertex x="60" y="15.5"/>
<vertex x="60" y="14.8"/>
<vertex x="60" y="14.1"/>
<vertex x="60" y="13.41"/>
<vertex x="60" y="12.71"/>
<vertex x="60" y="12.01"/>
<vertex x="60" y="11.31"/>
<vertex x="60" y="10.61"/>
<vertex x="60.02" y="10.04"/>
<vertex x="60.09" y="9.54"/>
<vertex x="60.21" y="9.13"/>
<vertex x="60.39" y="8.78"/>
<vertex x="60.63" y="8.52"/>
<vertex x="60.93" y="8.33"/>
<vertex x="61.3" y="8.22"/>
<vertex x="61.74" y="8.18"/>
<vertex x="62.25" y="8.22"/>
<vertex x="62.69" y="8.34"/>
<vertex x="63.05" y="8.55"/>
<vertex x="63.35" y="8.84"/>
<vertex x="63.57" y="9.23"/>
<vertex x="63.72" y="9.72"/>
<vertex x="63.82" y="10.31"/>
<vertex x="63.85" y="11.01"/>
<vertex x="63.85" y="11.66"/>
<vertex x="63.85" y="12.31"/>
<vertex x="63.85" y="12.96"/>
<vertex x="63.85" y="13.61"/>
<vertex x="63.85" y="14.25"/>
<vertex x="63.85" y="14.9"/>
<vertex x="63.85" y="15.55"/>
<vertex x="63.85" y="16.2"/>
<vertex x="64.19" y="16.2"/>
<vertex x="64.53" y="16.2"/>
<vertex x="64.87" y="16.2"/>
<vertex x="65.21" y="16.2"/>
<vertex x="65.55" y="16.2"/>
<vertex x="65.89" y="16.2"/>
<vertex x="66.23" y="16.2"/>
<vertex x="66.57" y="16.2"/>
<vertex x="66.57" y="14.96"/>
<vertex x="66.57" y="13.73"/>
<vertex x="66.57" y="12.49"/>
<vertex x="66.57" y="11.25"/>
<vertex x="66.57" y="10.01"/>
<vertex x="66.57" y="8.78"/>
<vertex x="66.57" y="7.54"/>
</polygon>
<vertex x="68.04" y="16.2"/>
<vertex x="68.36" y="16.2"/>
<vertex x="68.68" y="16.2"/>
<vertex x="69.01" y="16.2"/>
<vertex x="69.33" y="16.2"/>
<vertex x="69.65" y="16.2"/>
<vertex x="69.98" y="16.2"/>
<vertex x="70.3" y="16.2"/>
<vertex x="70.62" y="16.2"/>
<vertex x="70.62" y="16.03"/>
<vertex x="70.62" y="15.86"/>
<vertex x="70.62" y="15.69"/>
<vertex x="70.62" y="15.51"/>
<vertex x="70.62" y="15.34"/>
<vertex x="70.62" y="15.17"/>
<vertex x="70.62" y="15"/>
<vertex x="70.62" y="14.83"/>
<vertex x="70.63" y="14.83"/>
<vertex x="70.64" y="14.83"/>
<vertex x="70.65" y="14.83"/>
<vertex x="70.93" y="15.22"/>
<vertex x="71.25" y="15.56"/>
<vertex x="71.61" y="15.84"/>
<vertex x="71.99" y="16.07"/>
<vertex x="72.4" y="16.25"/>
<vertex x="72.82" y="16.37"/>
<vertex x="73.25" y="16.45"/>
<vertex x="73.68" y="16.47"/>
<vertex x="74.66" y="16.4"/>
<vertex x="75.46" y="16.18"/>
<vertex x="76.09" y="15.83"/>
<vertex x="76.57" y="15.35"/>
<vertex x="76.91" y="14.76"/>
<vertex x="77.14" y="14.07"/>
<vertex x="77.26" y="13.27"/>
<vertex x="77.3" y="12.4"/>
<vertex x="77.3" y="11.64"/>
<vertex x="77.3" y="10.87"/>
<vertex x="77.3" y="10.11"/>
<vertex x="77.3" y="9.35"/>
<vertex x="77.3" y="8.59"/>
<vertex x="77.3" y="7.83"/>
<vertex x="77.3" y="7.07"/>
<vertex x="77.3" y="6.31"/>
<vertex x="76.96" y="6.31"/>
<vertex x="76.62" y="6.31"/>
<vertex x="76.28" y="6.31"/>
<vertex x="75.94" y="6.31"/>
<vertex x="75.6" y="6.31"/>
<vertex x="75.26" y="6.31"/>
<vertex x="74.92" y="6.31"/>
<vertex x="74.58" y="6.31"/>
<vertex x="74.58" y="7.01"/>
<vertex x="74.58" y="7.7"/>
<vertex x="74.58" y="8.4"/>
<vertex x="74.58" y="9.1"/>
<vertex x="74.58" y="9.8"/>
<vertex x="74.58" y="10.5"/>
<vertex x="74.58" y="11.2"/>
<vertex x="74.58" y="11.9"/>
<vertex x="74.55" y="12.47"/>
<vertex x="74.48" y="12.96"/>
<vertex x="74.36" y="13.38"/>
<vertex x="74.18" y="13.72"/>
<vertex x="73.95" y="13.99"/>
<vertex x="73.65" y="14.18"/>
<vertex x="73.28" y="14.29"/>
<vertex x="72.83" y="14.33"/>
<vertex x="72.32" y="14.29"/>
<vertex x="71.88" y="14.17"/>
<vertex x="71.52" y="13.96"/>
<vertex x="71.23" y="13.67"/>
<vertex x="71.01" y="13.27"/>
<vertex x="70.85" y="12.79"/>
<vertex x="70.76" y="12.19"/>
<vertex x="70.73" y="11.49"/>
<vertex x="70.73" y="10.85"/>
<vertex x="70.73" y="10.2"/>
<vertex x="70.73" y="9.55"/>
<vertex x="70.73" y="8.9"/>
<vertex x="70.73" y="8.25"/>
<vertex x="70.73" y="7.6"/>
<vertex x="70.73" y="6.96"/>
<vertex x="70.73" y="6.31"/>
<vertex x="70.39" y="6.31"/>
<vertex x="70.05" y="6.31"/>
<vertex x="69.71" y="6.31"/>
<vertex x="69.37" y="6.31"/>
<vertex x="69.03" y="6.31"/>
<vertex x="68.69" y="6.31"/>
<vertex x="68.35" y="6.31"/>
<vertex x="68.01" y="6.31"/>
<vertex x="68.01" y="7.54"/>
<vertex x="68.01" y="8.78"/>
<vertex x="68.01" y="10.02"/>
<vertex x="68.01" y="11.26"/>
<vertex x="68.01" y="12.49"/>
<vertex x="68.01" y="13.73"/>
<vertex x="68.01" y="14.97"/>
</polygon>
<vertex x="55.75" y="33.19"/>
<vertex x="55.75" y="33.14"/>
<vertex x="55.78" y="33.02"/>
<vertex x="55.78" y="32.84"/>
<vertex x="55.77" y="32.64"/>
<vertex x="55.72" y="32.42"/>
<vertex x="55.62" y="32.23"/>
<vertex x="55.44" y="32.07"/>
<vertex x="55.19" y="31.97"/>
<vertex x="54.96" y="31.97"/>
<vertex x="54.72" y="32.02"/>
<vertex x="54.45" y="32.11"/>
<vertex x="54.19" y="32.24"/>
<vertex x="53.93" y="32.4"/>
<vertex x="53.68" y="32.58"/>
<vertex x="53.46" y="32.78"/>
<vertex x="53.27" y="32.99"/>
<vertex x="53.09" y="33.24"/>
<vertex x="52.96" y="33.48"/>
<vertex x="52.89" y="33.7"/>
<vertex x="52.86" y="33.92"/>
<vertex x="52.89" y="34.12"/>
<vertex x="52.96" y="34.32"/>
<vertex x="53.06" y="34.51"/>
<vertex x="53.21" y="34.69"/>
<vertex x="53.48" y="34.92"/>
<vertex x="53.76" y="35.07"/>
<vertex x="54.06" y="35.15"/>
<vertex x="54.35" y="35.18"/>
<vertex x="54.6" y="35.19"/>
<vertex x="54.8" y="35.16"/>
<vertex x="54.94" y="35.14"/>
<vertex x="54.99" y="35.14"/>
<vertex x="54.9" y="35.21"/>
<vertex x="54.63" y="35.39"/>
<vertex x="54.22" y="35.63"/>
<vertex x="53.69" y="35.85"/>
<vertex x="53.06" y="36.01"/>
<vertex x="52.35" y="36.04"/>
<vertex x="51.58" y="35.87"/>
<vertex x="50.79" y="35.46"/>
<vertex x="50.18" y="34.95"/>
<vertex x="49.8" y="34.4"/>
<vertex x="49.61" y="33.82"/>
<vertex x="49.61" y="33.22"/>
<vertex x="49.77" y="32.61"/>
<vertex x="50.1" y="32"/>
<vertex x="50.56" y="31.39"/>
<vertex x="51.15" y="30.8"/>
<vertex x="51.6" y="30.26"/>
<vertex x="51.83" y="29.74"/>
<vertex x="51.85" y="29.25"/>
<vertex x="51.7" y="28.81"/>
<vertex x="51.39" y="28.45"/>
<vertex x="50.97" y="28.18"/>
<vertex x="50.47" y="28.04"/>
<vertex x="49.9" y="28.04"/>
<vertex x="49.53" y="28.12"/>
<vertex x="49.22" y="28.26"/>
<vertex x="48.97" y="28.44"/>
<vertex x="48.78" y="28.65"/>
<vertex x="48.65" y="28.88"/>
<vertex x="48.58" y="29.12"/>
<vertex x="48.58" y="29.35"/>
<vertex x="48.65" y="29.56"/>
<vertex x="48.75" y="29.72"/>
<vertex x="48.9" y="29.87"/>
<vertex x="49.06" y="29.99"/>
<vertex x="49.23" y="30.1"/>
<vertex x="49.38" y="30.18"/>
<vertex x="49.52" y="30.24"/>
<vertex x="49.61" y="30.28"/>
<vertex x="49.64" y="30.29"/>
<vertex x="49.6" y="30.31"/>
<vertex x="49.49" y="30.34"/>
<vertex x="49.31" y="30.39"/>
<vertex x="49.07" y="30.42"/>
<vertex x="48.78" y="30.45"/>
<vertex x="48.45" y="30.43"/>
<vertex x="48.1" y="30.38"/>
<vertex x="47.71" y="30.26"/>
<vertex x="47.37" y="30.11"/>
<vertex x="47.06" y="29.91"/>
<vertex x="46.77" y="29.65"/>
<vertex x="46.52" y="29.33"/>
<vertex x="46.32" y="28.93"/>
<vertex x="46.17" y="28.45"/>
<vertex x="46.09" y="27.88"/>
<vertex x="46.07" y="27.2"/>
<vertex x="46.07" y="26.08"/>
<vertex x="46.07" y="24.96"/>
<vertex x="46.07" y="23.84"/>
<vertex x="46.07" y="22.72"/>
<vertex x="46.07" y="21.6"/>
<vertex x="46.07" y="20.48"/>
<vertex x="46.07" y="19.35"/>
<vertex x="46.07" y="18.23"/>
<vertex x="46.12" y="18.29"/>
<vertex x="46.24" y="18.44"/>
<vertex x="46.44" y="18.67"/>
<vertex x="46.7" y="18.98"/>
<vertex x="47.01" y="19.34"/>
<vertex x="47.37" y="19.75"/>
<vertex x="47.76" y="20.19"/>
<vertex x="48.17" y="20.64"/>
<vertex x="48.62" y="21.13"/>
<vertex x="49.02" y="21.57"/>
<vertex x="49.39" y="21.96"/>
<vertex x="49.74" y="22.28"/>
<vertex x="50.09" y="22.54"/>
<vertex x="50.47" y="22.71"/>
<vertex x="50.87" y="22.81"/>
<vertex x="51.33" y="22.82"/>
<vertex x="52.23" y="22.82"/>
<vertex x="53.06" y="22.93"/>
<vertex x="53.83" y="23.14"/>
<vertex x="54.54" y="23.45"/>
<vertex x="55.19" y="23.85"/>
<vertex x="55.78" y="24.33"/>
<vertex x="56.32" y="24.89"/>
<vertex x="56.8" y="25.52"/>
<vertex x="56.91" y="25.68"/>
<vertex x="57.49" y="26.8"/>
<vertex x="57.55" y="26.96"/>
<vertex x="57.84" y="28.08"/>
<vertex x="57.86" y="28.23"/>
<vertex x="57.91" y="29.3"/>
<vertex x="57.9" y="29.45"/>
<vertex x="57.74" y="30.44"/>
<vertex x="57.7" y="30.57"/>
<vertex x="57.38" y="31.44"/>
<vertex x="56.9" y="32.26"/>
<vertex x="56.33" y="32.86"/>
<vertex x="55.74" y="33.2"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.8">
<vertex x="5.12" y="10.49"/>
<vertex x="5.17" y="10.03"/>
<vertex x="5.32" y="9.63"/>
<vertex x="5.55" y="9.31"/>
<vertex x="5.86" y="9.04"/>
<vertex x="6.22" y="8.84"/>
<vertex x="6.62" y="8.7"/>
<vertex x="7.05" y="8.62"/>
<vertex x="7.5" y="8.59"/>
<vertex x="7.84" y="8.61"/>
<vertex x="8.19" y="8.66"/>
<vertex x="8.53" y="8.76"/>
<vertex x="8.85" y="8.9"/>
<vertex x="9.12" y="9.09"/>
<vertex x="9.34" y="9.34"/>
<vertex x="9.48" y="9.66"/>
<vertex x="9.54" y="10.03"/>
<vertex x="9.47" y="10.36"/>
<vertex x="9.3" y="10.64"/>
<vertex x="9" y="10.88"/>
<vertex x="8.6" y="11.09"/>
<vertex x="8.1" y="11.28"/>
<vertex x="7.5" y="11.45"/>
<vertex x="6.8" y="11.61"/>
<vertex x="6.01" y="11.78"/>
<vertex x="5.34" y="11.95"/>
<vertex x="4.69" y="12.15"/>
<vertex x="4.08" y="12.39"/>
<vertex x="3.54" y="12.69"/>
<vertex x="3.08" y="13.07"/>
<vertex x="2.73" y="13.54"/>
<vertex x="2.51" y="14.11"/>
<vertex x="2.43" y="14.8"/>
<vertex x="2.54" y="15.79"/>
<vertex x="2.85" y="16.59"/>
<vertex x="3.34" y="17.22"/>
<vertex x="3.98" y="17.7"/>
<vertex x="4.72" y="18.05"/>
<vertex x="5.55" y="18.27"/>
<vertex x="6.44" y="18.4"/>
<vertex x="7.35" y="18.44"/>
<vertex x="8.26" y="18.39"/>
<vertex x="9.13" y="18.26"/>
<vertex x="9.94" y="18.03"/>
<vertex x="10.67" y="17.67"/>
<vertex x="11.3" y="17.19"/>
<vertex x="11.8" y="16.56"/>
<vertex x="12.15" y="15.78"/>
<vertex x="12.34" y="14.83"/>
<vertex x="11.97" y="14.83"/>
<vertex x="11.6" y="14.83"/>
<vertex x="11.23" y="14.83"/>
<vertex x="10.86" y="14.83"/>
<vertex x="10.49" y="14.83"/>
<vertex x="10.12" y="14.83"/>
<vertex x="9.75" y="14.83"/>
<vertex x="9.38" y="14.83"/>
<vertex x="9.31" y="15.24"/>
<vertex x="9.17" y="15.57"/>
<vertex x="8.97" y="15.84"/>
<vertex x="8.71" y="16.04"/>
<vertex x="8.4" y="16.19"/>
<vertex x="8.05" y="16.29"/>
<vertex x="7.67" y="16.34"/>
<vertex x="7.26" y="16.36"/>
<vertex x="6.99" y="16.35"/>
<vertex x="6.69" y="16.33"/>
<vertex x="6.41" y="16.27"/>
<vertex x="6.13" y="16.18"/>
<vertex x="5.89" y="16.05"/>
<vertex x="5.7" y="15.87"/>
<vertex x="5.58" y="15.62"/>
<vertex x="5.53" y="15.31"/>
<vertex x="5.61" y="14.93"/>
<vertex x="5.84" y="14.63"/>
<vertex x="6.18" y="14.39"/>
<vertex x="6.64" y="14.2"/>
<vertex x="7.17" y="14.04"/>
<vertex x="7.77" y="13.9"/>
<vertex x="8.4" y="13.77"/>
<vertex x="9.06" y="13.62"/>
<vertex x="9.73" y="13.45"/>
<vertex x="10.38" y="13.25"/>
<vertex x="10.99" y="12.99"/>
<vertex x="11.53" y="12.67"/>
<vertex x="11.99" y="12.27"/>
<vertex x="12.34" y="11.77"/>
<vertex x="12.56" y="11.17"/>
<vertex x="12.64" y="10.45"/>
<vertex x="12.64" y="10.31"/>
<vertex x="12.52" y="9.43"/>
<vertex x="12.19" y="8.58"/>
<vertex x="11.68" y="7.9"/>
<vertex x="11.02" y="7.36"/>
<vertex x="10.24" y="6.97"/>
<vertex x="9.36" y="6.71"/>
<vertex x="8.43" y="6.56"/>
<vertex x="7.48" y="6.51"/>
<vertex x="6.5" y="6.56"/>
<vertex x="5.56" y="6.71"/>
<vertex x="4.67" y="6.98"/>
<vertex x="3.88" y="7.38"/>
<vertex x="3.2" y="7.92"/>
<vertex x="2.67" y="8.61"/>
<vertex x="2.31" y="9.46"/>
<vertex x="2.28" y="9.58"/>
<vertex x="2.16" y="10.49"/>
<vertex x="2.53" y="10.49"/>
<vertex x="2.9" y="10.49"/>
<vertex x="3.27" y="10.49"/>
<vertex x="3.64" y="10.49"/>
<vertex x="4.01" y="10.49"/>
<vertex x="4.38" y="10.49"/>
<vertex x="4.75" y="10.49"/>
</polygon>
<vertex x="21.97" y="10.5"/>
<vertex x="22.15" y="11.11"/>
<vertex x="22.25" y="11.76"/>
<vertex x="22.28" y="12.44"/>
<vertex x="25.39" y="12.35"/>
<vertex x="25.39" y="12.21"/>
<vertex x="25.32" y="11.24"/>
<vertex x="25.3" y="11.1"/>
<vertex x="25.08" y="10.17"/>
<vertex x="25.04" y="10.04"/>
<vertex x="24.7" y="9.18"/>
</polygon>
<vertex x="24.64" y="9.06"/>
<vertex x="24.16" y="8.3"/>
<vertex x="24.08" y="8.2"/>
<vertex x="23.46" y="7.56"/>
<vertex x="23.36" y="7.48"/>
<vertex x="22.6" y="7"/>
<vertex x="22.49" y="6.94"/>
<vertex x="21.59" y="6.64"/>
<vertex x="21.46" y="6.61"/>
<vertex x="20.43" y="6.51"/>
<vertex x="19.92" y="6.54"/>
<vertex x="19.42" y="6.62"/>
<vertex x="18.95" y="6.76"/>
<vertex x="18.5" y="6.95"/>
<vertex x="18.08" y="7.19"/>
<vertex x="17.69" y="7.48"/>
<vertex x="17.34" y="7.83"/>
<vertex x="17.04" y="8.22"/>
<vertex x="17.03" y="8.22"/>
<vertex x="17.02" y="8.22"/>
<vertex x="17.02" y="7.2"/>
<vertex x="17.02" y="6.18"/>
<vertex x="17.02" y="5.16"/>
<vertex x="17.02" y="4.15"/>
<vertex x="17.02" y="3.13"/>
<vertex x="17.02" y="2.11"/>
<vertex x="17.02" y="1.09"/>
<vertex x="17.02" y="0.08"/>
<vertex x="16.63" y="0.42"/>
<vertex x="16.24" y="0.77"/>
<vertex x="15.85" y="1.11"/>
<vertex x="15.46" y="1.46"/>
<vertex x="15.08" y="1.8"/>
<vertex x="14.69" y="2.15"/>
<vertex x="14.3" y="2.49"/>
<vertex x="13.91" y="2.84"/>
<vertex x="13.91" y="4.69"/>
<vertex x="13.91" y="6.53"/>
<vertex x="13.91" y="8.38"/>
<vertex x="13.91" y="10.22"/>
<vertex x="13.91" y="12.07"/>
<vertex x="13.91" y="13.91"/>
<vertex x="13.91" y="15.76"/>
<vertex x="13.91" y="17.61"/>
<vertex x="14.28" y="17.67"/>
<vertex x="14.65" y="17.74"/>
<vertex x="15.02" y="17.8"/>
<vertex x="15.39" y="17.87"/>
<vertex x="15.76" y="17.93"/>
<vertex x="16.13" y="18"/>
<vertex x="16.5" y="18.07"/>
<vertex x="16.87" y="18.13"/>
<vertex x="16.87" y="17.95"/>
<vertex x="16.87" y="17.77"/>
<vertex x="16.87" y="17.59"/>
<vertex x="16.87" y="17.41"/>
<vertex x="16.87" y="17.23"/>
<vertex x="16.87" y="17.05"/>
<vertex x="16.87" y="16.87"/>
<vertex x="16.87" y="16.69"/>
<vertex x="16.88" y="16.69"/>
<vertex x="17.19" y="17.11"/>
<vertex x="17.54" y="17.48"/>
<vertex x="17.92" y="17.78"/>
<vertex x="18.33" y="18.02"/>
<vertex x="18.77" y="18.21"/>
<vertex x="19.24" y="18.34"/>
<vertex x="19.74" y="18.41"/>
<vertex x="20.25" y="18.44"/>
<vertex x="20.42" y="18.43"/>
<vertex x="21.49" y="18.31"/>
<vertex x="21.63" y="18.27"/>
<vertex x="22.55" y="17.94"/>
<vertex x="22.67" y="17.88"/>
<vertex x="23.44" y="17.36"/>
<vertex x="23.54" y="17.28"/>
<vertex x="24.15" y="16.6"/>
<vertex x="24.23" y="16.5"/>
<vertex x="24.7" y="15.69"/>
<vertex x="24.76" y="15.57"/>
<vertex x="25.09" y="14.66"/>
<vertex x="25.13" y="14.53"/>
<vertex x="25.32" y="13.54"/>
<vertex x="25.34" y="13.4"/>
<vertex x="25.39" y="12.36"/>
<vertex x="22.25" y="13.12"/>
<vertex x="22.14" y="13.78"/>
<vertex x="21.95" y="14.39"/>
<vertex x="21.68" y="14.95"/>
<vertex x="21.31" y="15.42"/>
<vertex x="20.84" y="15.78"/>
<vertex x="20.26" y="16.01"/>
<vertex x="19.57" y="16.09"/>
<vertex x="18.87" y="16.01"/>
<vertex x="18.29" y="15.78"/>
<vertex x="17.83" y="15.42"/>
<vertex x="17.46" y="14.96"/>
<vertex x="17.2" y="14.4"/>
<vertex x="17.02" y="13.79"/>
<vertex x="16.91" y="13.13"/>
<vertex x="16.88" y="12.44"/>
<vertex x="16.92" y="11.76"/>
<vertex x="17.02" y="11.11"/>
<vertex x="17.21" y="10.5"/>
<vertex x="17.48" y="9.96"/>
<vertex x="17.85" y="9.51"/>
<vertex x="18.32" y="9.16"/>
<vertex x="18.9" y="8.93"/>
<vertex x="19.6" y="8.86"/>
<vertex x="20.3" y="8.93"/>
<vertex x="20.88" y="9.16"/>
<vertex x="21.34" y="9.51"/>
<vertex x="21.7" y="9.96"/>
</polygon>
<vertex x="30.12" y="13.31"/>
<vertex x="30.82" y="13.4"/>
<vertex x="31.5" y="13.48"/>
<vertex x="32.14" y="13.56"/>
<vertex x="32.51" y="11.89"/>
<vertex x="32.33" y="11.86"/>
<vertex x="32.15" y="11.83"/>
<vertex x="31.97" y="11.8"/>
<vertex x="31.78" y="11.78"/>
<vertex x="31.59" y="11.75"/>
<vertex x="31.41" y="11.72"/>
<vertex x="31.23" y="11.69"/>
<vertex x="31.05" y="11.65"/>
<vertex x="30.87" y="11.61"/>
<vertex x="30.7" y="11.57"/>
</polygon>
<vertex x="30.54" y="11.52"/>
<vertex x="30.38" y="11.46"/>
<vertex x="30.23" y="11.39"/>
<vertex x="30.08" y="11.31"/>
<vertex x="29.95" y="11.22"/>
<vertex x="29.83" y="11.12"/>
<vertex x="29.72" y="11.01"/>
<vertex x="29.62" y="10.88"/>
<vertex x="29.54" y="10.74"/>
<vertex x="29.48" y="10.59"/>
<vertex x="29.43" y="10.42"/>
<vertex x="29.4" y="10.23"/>
<vertex x="29.39" y="10.02"/>
<vertex x="29.4" y="9.82"/>
<vertex x="29.43" y="9.64"/>
<vertex x="29.48" y="9.47"/>
<vertex x="29.55" y="9.32"/>
<vertex x="29.63" y="9.19"/>
<vertex x="29.73" y="9.07"/>
<vertex x="29.84" y="8.96"/>
<vertex x="29.97" y="8.88"/>
<vertex x="30.1" y="8.8"/>
<vertex x="30.25" y="8.74"/>
<vertex x="30.41" y="8.69"/>
<vertex x="30.57" y="8.65"/>
<vertex x="30.75" y="8.62"/>
<vertex x="30.92" y="8.59"/>
<vertex x="31.11" y="8.58"/>
<vertex x="31.3" y="8.58"/>
<vertex x="31.72" y="8.61"/>
<vertex x="32.1" y="8.67"/>
<vertex x="32.43" y="8.77"/>
<vertex x="32.71" y="8.9"/>
<vertex x="32.96" y="9.05"/>
<vertex x="33.16" y="9.23"/>
<vertex x="33.33" y="9.42"/>
<vertex x="33.46" y="9.63"/>
<vertex x="33.57" y="9.84"/>
<vertex x="33.66" y="10.06"/>
<vertex x="33.72" y="10.28"/>
<vertex x="33.76" y="10.49"/>
<vertex x="33.79" y="10.69"/>
<vertex x="33.8" y="10.88"/>
<vertex x="33.81" y="11.05"/>
<vertex x="33.81" y="11.19"/>
<vertex x="33.81" y="11.26"/>
<vertex x="33.81" y="11.33"/>
<vertex x="33.81" y="11.41"/>
<vertex x="33.81" y="11.48"/>
<vertex x="33.81" y="11.55"/>
<vertex x="33.81" y="11.62"/>
<vertex x="33.81" y="11.7"/>
<vertex x="33.81" y="11.77"/>
<vertex x="33.81" y="11.84"/>
<vertex x="33.81" y="11.91"/>
<vertex x="33.81" y="11.99"/>
<vertex x="33.81" y="12.06"/>
<vertex x="33.81" y="12.13"/>
<vertex x="33.81" y="12.2"/>
<vertex x="33.81" y="12.27"/>
<vertex x="33.81" y="12.35"/>
<vertex x="33.71" y="12.27"/>
<vertex x="33.59" y="12.19"/>
<vertex x="33.46" y="12.13"/>
<vertex x="33.32" y="12.07"/>
<vertex x="33.17" y="12.02"/>
<vertex x="33.02" y="11.98"/>
<vertex x="32.85" y="11.94"/>
<vertex x="32.68" y="11.91"/>
<vertex x="32.69" y="13.7"/>
<vertex x="33.17" y="13.86"/>
<vertex x="33.53" y="14.09"/>
<vertex x="33.75" y="14.4"/>
<vertex x="33.81" y="14.81"/>
<vertex x="33.8" y="15.05"/>
<vertex x="33.77" y="15.26"/>
<vertex x="33.72" y="15.44"/>
<vertex x="33.65" y="15.61"/>
<vertex x="33.57" y="15.75"/>
<vertex x="33.47" y="15.88"/>
<vertex x="33.35" y="15.98"/>
<vertex x="33.22" y="16.07"/>
<vertex x="33.07" y="16.15"/>
<vertex x="32.92" y="16.21"/>
<vertex x="32.75" y="16.26"/>
<vertex x="32.58" y="16.29"/>
<vertex x="32.39" y="16.32"/>
<vertex x="32.2" y="16.34"/>
<vertex x="32" y="16.34"/>
<vertex x="31.8" y="16.34"/>
<vertex x="31.58" y="16.34"/>
<vertex x="31.37" y="16.32"/>
<vertex x="31.17" y="16.29"/>
<vertex x="30.99" y="16.24"/>
<vertex x="30.81" y="16.19"/>
<vertex x="30.65" y="16.12"/>
<vertex x="30.5" y="16.04"/>
<vertex x="30.36" y="15.94"/>
<vertex x="30.24" y="15.83"/>
<vertex x="30.13" y="15.71"/>
<vertex x="30.03" y="15.57"/>
<vertex x="29.94" y="15.41"/>
<vertex x="29.87" y="15.24"/>
<vertex x="29.82" y="15.06"/>
<vertex x="29.77" y="14.85"/>
<vertex x="29.74" y="14.63"/>
<vertex x="29.55" y="14.63"/>
<vertex x="29.36" y="14.63"/>
<vertex x="29.16" y="14.63"/>
<vertex x="28.97" y="14.63"/>
<vertex x="28.78" y="14.63"/>
<vertex x="28.58" y="14.63"/>
<vertex x="28.39" y="14.63"/>
<vertex x="28.19" y="14.63"/>
<vertex x="28" y="14.63"/>
<vertex x="27.81" y="14.63"/>
<vertex x="27.61" y="14.63"/>
<vertex x="27.42" y="14.63"/>
<vertex x="27.22" y="14.63"/>
<vertex x="27.03" y="14.63"/>
<vertex x="26.84" y="14.63"/>
<vertex x="26.64" y="14.63"/>
<vertex x="26.7" y="15.15"/>
<vertex x="26.82" y="15.62"/>
<vertex x="26.98" y="16.05"/>
<vertex x="27.19" y="16.44"/>
<vertex x="27.44" y="16.79"/>
<vertex x="27.73" y="17.1"/>
<vertex x="28.06" y="17.37"/>
<vertex x="28.42" y="17.61"/>
<vertex x="28.8" y="17.81"/>
<vertex x="29.21" y="17.98"/>
<vertex x="29.64" y="18.12"/>
<vertex x="30.08" y="18.23"/>
<vertex x="30.54" y="18.31"/>
<vertex x="31.01" y="18.37"/>
<vertex x="31.48" y="18.4"/>
<vertex x="31.96" y="18.41"/>
<vertex x="32.39" y="18.41"/>
<vertex x="32.82" y="18.38"/>
<vertex x="33.25" y="18.34"/>
<vertex x="33.69" y="18.29"/>
<vertex x="34.11" y="18.21"/>
<vertex x="34.52" y="18.11"/>
<vertex x="34.92" y="17.98"/>
<vertex x="35.29" y="17.82"/>
<vertex x="35.63" y="17.63"/>
<vertex x="35.95" y="17.4"/>
<vertex x="36.23" y="17.14"/>
<vertex x="36.47" y="16.84"/>
<vertex x="36.66" y="16.5"/>
<vertex x="36.81" y="16.11"/>
<vertex x="36.9" y="15.68"/>
<vertex x="36.93" y="15.19"/>
<vertex x="36.93" y="14.83"/>
<vertex x="36.93" y="14.46"/>
<vertex x="36.93" y="14.09"/>
<vertex x="36.93" y="13.72"/>
<vertex x="36.93" y="13.35"/>
<vertex x="36.93" y="12.99"/>
<vertex x="36.93" y="12.62"/>
<vertex x="36.93" y="12.25"/>
<vertex x="36.93" y="11.88"/>
<vertex x="36.93" y="11.52"/>
<vertex x="36.93" y="11.15"/>
<vertex x="36.93" y="10.78"/>
<vertex x="36.93" y="10.41"/>
<vertex x="36.93" y="10.04"/>
<vertex x="36.93" y="9.68"/>
<vertex x="36.93" y="9.31"/>
<vertex x="36.93" y="9.11"/>
<vertex x="36.93" y="8.92"/>
<vertex x="36.94" y="8.73"/>
<vertex x="36.94" y="8.55"/>
<vertex x="36.95" y="8.36"/>
<vertex x="36.96" y="8.18"/>
<vertex x="36.99" y="8.01"/>
<vertex x="37.01" y="7.84"/>
<vertex x="37.04" y="7.67"/>
<vertex x="37.07" y="7.52"/>
<vertex x="37.1" y="7.37"/>
<vertex x="37.13" y="7.23"/>
<vertex x="37.17" y="7.11"/>
<vertex x="37.22" y="6.99"/>
<vertex x="37.26" y="6.89"/>
<vertex x="37.31" y="6.79"/>
<vertex x="37.12" y="6.79"/>
<vertex x="36.92" y="6.79"/>
<vertex x="36.72" y="6.79"/>
<vertex x="36.53" y="6.79"/>
<vertex x="36.33" y="6.79"/>
<vertex x="36.13" y="6.79"/>
<vertex x="35.94" y="6.79"/>
<vertex x="35.74" y="6.79"/>
<vertex x="35.54" y="6.79"/>
<vertex x="35.35" y="6.79"/>
<vertex x="35.15" y="6.79"/>
<vertex x="34.95" y="6.79"/>
<vertex x="34.76" y="6.79"/>
<vertex x="34.56" y="6.79"/>
<vertex x="34.36" y="6.79"/>
<vertex x="34.17" y="6.79"/>
<vertex x="34.14" y="6.86"/>
<vertex x="34.12" y="6.92"/>
<vertex x="34.1" y="6.99"/>
<vertex x="34.07" y="7.06"/>
<vertex x="34.05" y="7.13"/>
<vertex x="34.03" y="7.19"/>
<vertex x="34.02" y="7.26"/>
<vertex x="34" y="7.33"/>
<vertex x="33.99" y="7.4"/>
<vertex x="33.98" y="7.47"/>
<vertex x="33.97" y="7.54"/>
<vertex x="33.97" y="7.61"/>
<vertex x="33.96" y="7.68"/>
<vertex x="33.96" y="7.75"/>
<vertex x="33.95" y="7.82"/>
<vertex x="33.95" y="7.89"/>
<vertex x="33.76" y="7.7"/>
<vertex x="33.56" y="7.53"/>
<vertex x="33.35" y="7.38"/>
<vertex x="33.14" y="7.23"/>
<vertex x="32.91" y="7.11"/>
<vertex x="32.68" y="6.99"/>
<vertex x="32.45" y="6.89"/>
<vertex x="32.2" y="6.8"/>
<vertex x="31.96" y="6.72"/>
<vertex x="31.71" y="6.66"/>
<vertex x="31.45" y="6.6"/>
<vertex x="31.19" y="6.56"/>
<vertex x="30.93" y="6.53"/>
<vertex x="30.67" y="6.5"/>
<vertex x="30.41" y="6.49"/>
<vertex x="30.14" y="6.48"/>
<vertex x="29.74" y="6.49"/>
<vertex x="29.36" y="6.53"/>
<vertex x="28.98" y="6.59"/>
<vertex x="28.63" y="6.68"/>
<vertex x="28.29" y="6.8"/>
<vertex x="27.97" y="6.94"/>
<vertex x="27.68" y="7.11"/>
<vertex x="27.41" y="7.3"/>
<vertex x="27.16" y="7.53"/>
<vertex x="26.94" y="7.78"/>
<vertex x="26.75" y="8.06"/>
<vertex x="26.59" y="8.36"/>
<vertex x="26.47" y="8.7"/>
<vertex x="26.37" y="9.06"/>
<vertex x="26.32" y="9.45"/>
<vertex x="26.29" y="9.87"/>
<vertex x="26.38" y="10.74"/>
<vertex x="26.63" y="11.45"/>
<vertex x="27.01" y="12.02"/>
<vertex x="27.5" y="12.45"/>
<vertex x="28.08" y="12.78"/>
<vertex x="28.72" y="13.02"/>
<vertex x="29.41" y="13.19"/>
</polygon>
<vertex x="38.68" y="17.6"/>
<vertex x="39.05" y="17.67"/>
<vertex x="39.42" y="17.73"/>
<vertex x="39.79" y="17.8"/>
<vertex x="40.16" y="17.86"/>
<vertex x="40.52" y="17.93"/>
<vertex x="40.89" y="18"/>
<vertex x="41.26" y="18.06"/>
<vertex x="41.63" y="18.13"/>
<vertex x="41.63" y="17.86"/>
<vertex x="41.63" y="17.6"/>
<vertex x="41.63" y="17.34"/>
<vertex x="41.63" y="17.08"/>
<vertex x="41.63" y="16.81"/>
<vertex x="41.63" y="16.55"/>
<vertex x="41.63" y="16.29"/>
<vertex x="41.63" y="16.02"/>
<vertex x="41.64" y="16.02"/>
<vertex x="41.65" y="16.02"/>
<vertex x="41.91" y="16.54"/>
<vertex x="42.25" y="17"/>
<vertex x="42.64" y="17.41"/>
<vertex x="43.09" y="17.76"/>
<vertex x="43.59" y="18.05"/>
<vertex x="44.12" y="18.26"/>
<vertex x="44.68" y="18.39"/>
<vertex x="45.26" y="18.43"/>
<vertex x="45.35" y="18.43"/>
<vertex x="45.44" y="18.43"/>
<vertex x="45.52" y="18.42"/>
<vertex x="45.61" y="18.41"/>
<vertex x="45.69" y="18.4"/>
<vertex x="45.78" y="18.37"/>
<vertex x="45.86" y="18.35"/>
<vertex x="45.94" y="18.32"/>
<vertex x="45.94" y="17.96"/>
<vertex x="45.94" y="17.6"/>
<vertex x="45.94" y="17.24"/>
<vertex x="45.94" y="16.88"/>
<vertex x="45.94" y="16.52"/>
<vertex x="45.94" y="16.16"/>
<vertex x="45.94" y="15.8"/>
<vertex x="45.94" y="15.44"/>
<vertex x="45.83" y="15.46"/>
<vertex x="45.7" y="15.49"/>
<vertex x="45.56" y="15.51"/>
<vertex x="45.42" y="15.53"/>
<vertex x="45.27" y="15.53"/>
<vertex x="45.12" y="15.54"/>
<vertex x="44.97" y="15.54"/>
<vertex x="44.82" y="15.54"/>
<vertex x="44.03" y="15.47"/>
<vertex x="43.38" y="15.26"/>
<vertex x="42.85" y="14.92"/>
<vertex x="42.43" y="14.48"/>
<vertex x="42.12" y="13.94"/>
<vertex x="41.92" y="13.33"/>
<vertex x="41.8" y="12.65"/>
<vertex x="41.76" y="11.91"/>
<vertex x="41.76" y="11.27"/>
<vertex x="41.76" y="10.64"/>
<vertex x="41.76" y="10"/>
<vertex x="41.76" y="9.36"/>
<vertex x="41.76" y="8.73"/>
<vertex x="41.76" y="8.09"/>
<vertex x="41.76" y="7.45"/>
<vertex x="41.76" y="6.81"/>
<vertex x="41.37" y="6.81"/>
<vertex x="40.98" y="6.81"/>
<vertex x="40.59" y="6.81"/>
<vertex x="40.21" y="6.81"/>
<vertex x="39.82" y="6.81"/>
<vertex x="39.43" y="6.81"/>
<vertex x="39.04" y="6.81"/>
<vertex x="38.65" y="6.81"/>
<vertex x="38.65" y="8.16"/>
<vertex x="38.65" y="9.51"/>
<vertex x="38.65" y="10.86"/>
<vertex x="38.65" y="12.21"/>
<vertex x="38.65" y="13.55"/>
<vertex x="38.65" y="14.9"/>
<vertex x="38.65" y="16.25"/>
</polygon>
<vertex x="47.16" y="20.74"/>
<vertex x="50.27" y="22.44"/>
<vertex x="50.27" y="14.06"/>
<vertex x="54.19" y="18.13"/>
<vertex x="57.86" y="18.13"/>
<vertex x="53.6" y="13.97"/>
<vertex x="58.34" y="6.82"/>
<vertex x="54.58" y="6.82"/>
<vertex x="51.47" y="11.87"/>
<vertex x="50.27" y="10.71"/>
<vertex x="50.27" y="6.82"/>
<vertex x="47.16" y="6.82"/>
</polygon>
<vertex x="60.23" y="16.05"/>
<vertex x="59.85" y="16.05"/>
<vertex x="59.47" y="16.05"/>
<vertex x="59.08" y="16.05"/>
<vertex x="58.7" y="16.05"/>
<vertex x="58.32" y="16.05"/>
<vertex x="57.94" y="16.05"/>
<vertex x="57.55" y="16.05"/>
<vertex x="57.17" y="16.05"/>
<vertex x="57.43" y="16.31"/>
<vertex x="57.7" y="16.57"/>
<vertex x="57.96" y="16.83"/>
<vertex x="58.23" y="17.09"/>
<vertex x="58.49" y="17.35"/>
<vertex x="58.76" y="17.61"/>
<vertex x="59.02" y="17.87"/>
<vertex x="59.29" y="18.13"/>
<vertex x="59.4" y="18.13"/>
<vertex x="59.52" y="18.13"/>
<vertex x="59.64" y="18.13"/>
<vertex x="59.76" y="18.13"/>
<vertex x="59.88" y="18.13"/>
<vertex x="60" y="18.13"/>
<vertex x="60.11" y="18.13"/>
<vertex x="60.23" y="18.13"/>
<vertex x="60.23" y="18.24"/>
<vertex x="60.23" y="18.35"/>
<vertex x="60.23" y="18.46"/>
<vertex x="60.23" y="18.57"/>
<vertex x="60.23" y="18.67"/>
<vertex x="60.23" y="18.78"/>
<vertex x="60.23" y="18.89"/>
<vertex x="60.23" y="19"/>
<vertex x="60.29" y="19.73"/>
<vertex x="60.47" y="20.39"/>
<vertex x="60.76" y="20.97"/>
<vertex x="61.17" y="21.47"/>
<vertex x="61.7" y="21.88"/>
<vertex x="62.36" y="22.18"/>
<vertex x="63.13" y="22.37"/>
<vertex x="64.02" y="22.44"/>
<vertex x="64.22" y="22.44"/>
<vertex x="64.43" y="22.43"/>
<vertex x="64.64" y="22.42"/>
<vertex x="64.85" y="22.41"/>
<vertex x="65.05" y="22.39"/>
<vertex x="65.26" y="22.38"/>
<vertex x="65.46" y="22.37"/>
<vertex x="65.66" y="22.36"/>
<vertex x="65.66" y="22.07"/>
<vertex x="65.66" y="21.78"/>
<vertex x="65.66" y="21.49"/>
<vertex x="65.66" y="21.2"/>
<vertex x="65.66" y="20.91"/>
<vertex x="65.66" y="20.62"/>
<vertex x="65.66" y="20.33"/>
<vertex x="65.66" y="20.04"/>
<vertex x="65.52" y="20.06"/>
<vertex x="65.38" y="20.08"/>
<vertex x="65.23" y="20.08"/>
<vertex x="65.09" y="20.09"/>
<vertex x="64.95" y="20.09"/>
<vertex x="64.8" y="20.09"/>
<vertex x="64.66" y="20.1"/>
<vertex x="64.52" y="20.1"/>
<vertex x="64.23" y="20.08"/>
<vertex x="63.98" y="20.03"/>
<vertex x="63.77" y="19.94"/>
<vertex x="63.61" y="19.81"/>
<vertex x="63.49" y="19.63"/>
<vertex x="63.4" y="19.41"/>
<vertex x="63.35" y="19.13"/>
<vertex x="63.34" y="18.81"/>
<vertex x="63.34" y="18.72"/>
<vertex x="63.34" y="18.64"/>
<vertex x="63.34" y="18.55"/>
<vertex x="63.34" y="18.47"/>
<vertex x="63.34" y="18.38"/>
<vertex x="63.34" y="18.3"/>
<vertex x="63.34" y="18.21"/>
<vertex x="63.34" y="18.13"/>
<vertex x="63.6" y="18.13"/>
<vertex x="63.87" y="18.13"/>
<vertex x="64.14" y="18.13"/>
<vertex x="64.41" y="18.13"/>
<vertex x="64.68" y="18.13"/>
<vertex x="64.94" y="18.13"/>
<vertex x="65.21" y="18.13"/>
<vertex x="65.48" y="18.13"/>
<vertex x="65.48" y="17.87"/>
<vertex x="65.48" y="17.61"/>
<vertex x="65.48" y="17.35"/>
<vertex x="65.48" y="17.09"/>
<vertex x="65.48" y="16.83"/>
<vertex x="65.48" y="16.57"/>
<vertex x="65.48" y="16.31"/>
<vertex x="65.48" y="16.05"/>
<vertex x="65.21" y="16.05"/>
<vertex x="64.94" y="16.05"/>
<vertex x="64.68" y="16.05"/>
<vertex x="64.41" y="16.05"/>
<vertex x="64.14" y="16.05"/>
<vertex x="63.87" y="16.05"/>
<vertex x="63.6" y="16.05"/>
<vertex x="63.34" y="16.05"/>
<vertex x="63.34" y="14.9"/>
<vertex x="63.34" y="13.74"/>
<vertex x="63.34" y="12.59"/>
<vertex x="63.34" y="11.43"/>
<vertex x="63.34" y="10.28"/>
<vertex x="63.34" y="9.13"/>
<vertex x="63.34" y="7.97"/>
<vertex x="63.34" y="6.82"/>
<vertex x="62.95" y="6.82"/>
<vertex x="62.56" y="6.82"/>
<vertex x="62.17" y="6.82"/>
<vertex x="61.78" y="6.82"/>
<vertex x="61.39" y="6.82"/>
<vertex x="61.01" y="6.82"/>
<vertex x="60.62" y="6.82"/>
<vertex x="60.23" y="6.82"/>
<vertex x="60.23" y="7.97"/>
<vertex x="60.23" y="9.13"/>
<vertex x="60.23" y="10.28"/>
<vertex x="60.23" y="11.43"/>
<vertex x="60.23" y="12.59"/>
<vertex x="60.23" y="13.74"/>
<vertex x="60.23" y="14.9"/>
</polygon>
<vertex x="76.97" y="6.82"/>
<vertex x="76.6" y="6.82"/>
<vertex x="76.23" y="6.82"/>
<vertex x="75.86" y="6.82"/>
<vertex x="75.49" y="6.82"/>
<vertex x="75.12" y="6.82"/>
<vertex x="74.75" y="6.82"/>
<vertex x="74.38" y="6.82"/>
<vertex x="74.01" y="6.82"/>
<vertex x="74.01" y="7.01"/>
<vertex x="74.01" y="7.21"/>
<vertex x="74.01" y="7.41"/>
<vertex x="74.01" y="7.61"/>
<vertex x="74.01" y="7.8"/>
<vertex x="74.01" y="8"/>
<vertex x="74.01" y="8.2"/>
<vertex x="74.01" y="8.39"/>
<vertex x="74" y="8.39"/>
<vertex x="73.99" y="8.39"/>
<vertex x="73.98" y="8.39"/>
<vertex x="73.66" y="7.94"/>
<vertex x="73.29" y="7.55"/>
<vertex x="72.88" y="7.23"/>
<vertex x="72.44" y="6.97"/>
<vertex x="71.98" y="6.77"/>
<vertex x="71.5" y="6.62"/>
<vertex x="71.01" y="6.54"/>
<vertex x="70.52" y="6.51"/>
<vertex x="70.37" y="6.51"/>
<vertex x="69.39" y="6.6"/>
<vertex x="68.48" y="6.84"/>
<vertex x="67.76" y="7.25"/>
<vertex x="67.21" y="7.79"/>
<vertex x="66.82" y="8.46"/>
<vertex x="66.57" y="9.26"/>
<vertex x="66.43" y="10.16"/>
<vertex x="66.42" y="10.29"/>
<vertex x="66.38" y="11.17"/>
<vertex x="66.38" y="12.04"/>
<vertex x="66.38" y="12.91"/>
<vertex x="66.38" y="13.78"/>
<vertex x="66.38" y="14.65"/>
<vertex x="66.38" y="15.52"/>
<vertex x="66.38" y="16.39"/>
<vertex x="66.38" y="17.26"/>
<vertex x="66.38" y="18.13"/>
<vertex x="66.77" y="18.13"/>
<vertex x="67.16" y="18.13"/>
<vertex x="67.55" y="18.13"/>
<vertex x="67.94" y="18.13"/>
<vertex x="68.33" y="18.13"/>
<vertex x="68.71" y="18.13"/>
<vertex x="69.1" y="18.13"/>
<vertex x="69.49" y="18.13"/>
<vertex x="69.49" y="17.33"/>
<vertex x="69.49" y="16.53"/>
<vertex x="69.49" y="15.73"/>
<vertex x="69.49" y="14.93"/>
<vertex x="69.49" y="14.14"/>
<vertex x="69.49" y="13.34"/>
<vertex x="69.49" y="12.54"/>
<vertex x="69.49" y="11.74"/>
<vertex x="69.52" y="11.09"/>
<vertex x="69.6" y="10.52"/>
<vertex x="69.74" y="10.04"/>
<vertex x="69.94" y="9.65"/>
<vertex x="70.21" y="9.35"/>
<vertex x="70.56" y="9.13"/>
<vertex x="70.98" y="9"/>
<vertex x="71.48" y="8.96"/>
<vertex x="72.07" y="9.01"/>
<vertex x="72.57" y="9.14"/>
<vertex x="72.99" y="9.38"/>
<vertex x="73.32" y="9.72"/>
<vertex x="73.57" y="10.16"/>
<vertex x="73.75" y="10.72"/>
<vertex x="73.86" y="11.4"/>
<vertex x="73.89" y="12.2"/>
<vertex x="73.89" y="12.94"/>
<vertex x="73.89" y="13.68"/>
<vertex x="73.89" y="14.42"/>
<vertex x="73.89" y="15.16"/>
<vertex x="73.89" y="15.9"/>
<vertex x="73.89" y="16.64"/>
<vertex x="73.89" y="17.39"/>
<vertex x="73.89" y="18.13"/>
<vertex x="74.28" y="18.13"/>
<vertex x="74.67" y="18.13"/>
<vertex x="75.06" y="18.13"/>
<vertex x="75.44" y="18.13"/>
<vertex x="75.83" y="18.13"/>
<vertex x="76.22" y="18.13"/>
<vertex x="76.61" y="18.13"/>
<vertex x="77" y="18.13"/>
<vertex x="77" y="16.71"/>
<vertex x="77" y="15.3"/>
<vertex x="77" y="13.89"/>
<vertex x="77" y="12.47"/>
<vertex x="77" y="11.06"/>
<vertex x="77" y="9.64"/>
<vertex x="77" y="8.23"/>
</polygon>
<vertex x="78.68" y="18.13"/>
<vertex x="79.05" y="18.13"/>
<vertex x="79.42" y="18.13"/>
<vertex x="79.79" y="18.13"/>
<vertex x="80.16" y="18.13"/>
<vertex x="80.53" y="18.13"/>
<vertex x="80.9" y="18.13"/>
<vertex x="81.27" y="18.13"/>
<vertex x="81.63" y="18.13"/>
<vertex x="81.63" y="17.93"/>
<vertex x="81.63" y="17.74"/>
<vertex x="81.63" y="17.54"/>
<vertex x="81.63" y="17.34"/>
<vertex x="81.63" y="17.15"/>
<vertex x="81.63" y="16.95"/>
<vertex x="81.63" y="16.75"/>
<vertex x="81.63" y="16.56"/>
<vertex x="81.64" y="16.56"/>
<vertex x="81.65" y="16.56"/>
<vertex x="81.66" y="16.56"/>
<vertex x="81.67" y="16.56"/>
<vertex x="81.99" y="17.01"/>
<vertex x="82.36" y="17.39"/>
<vertex x="82.76" y="17.72"/>
<vertex x="83.2" y="17.98"/>
<vertex x="83.66" y="18.18"/>
<vertex x="84.14" y="18.33"/>
<vertex x="84.63" y="18.41"/>
<vertex x="85.13" y="18.44"/>
<vertex x="85.28" y="18.44"/>
<vertex x="86.25" y="18.35"/>
<vertex x="87.17" y="18.1"/>
<vertex x="87.89" y="17.7"/>
<vertex x="88.43" y="17.16"/>
<vertex x="88.82" y="16.48"/>
<vertex x="89.08" y="15.69"/>
<vertex x="89.22" y="14.78"/>
<vertex x="89.23" y="14.66"/>
<vertex x="89.26" y="13.78"/>
<vertex x="89.26" y="12.91"/>
<vertex x="89.26" y="12.04"/>
<vertex x="89.26" y="11.17"/>
<vertex x="89.26" y="10.3"/>
<vertex x="89.26" y="9.43"/>
<vertex x="89.26" y="8.56"/>
<vertex x="89.26" y="7.69"/>
<vertex x="89.26" y="6.82"/>
<vertex x="88.87" y="6.82"/>
<vertex x="88.48" y="6.82"/>
<vertex x="88.1" y="6.82"/>
<vertex x="87.71" y="6.82"/>
<vertex x="87.32" y="6.82"/>
<vertex x="86.93" y="6.82"/>
<vertex x="86.54" y="6.82"/>
<vertex x="86.15" y="6.82"/>
<vertex x="86.15" y="7.62"/>
<vertex x="86.15" y="8.42"/>
<vertex x="86.15" y="9.22"/>
<vertex x="86.15" y="10.02"/>
<vertex x="86.15" y="10.81"/>
<vertex x="86.15" y="11.61"/>
<vertex x="86.15" y="12.41"/>
<vertex x="86.15" y="13.21"/>
<vertex x="86.13" y="13.86"/>
<vertex x="86.05" y="14.43"/>
<vertex x="85.91" y="14.91"/>
<vertex x="85.71" y="15.3"/>
<vertex x="85.44" y="15.6"/>
<vertex x="85.09" y="15.82"/>
<vertex x="84.67" y="15.94"/>
<vertex x="84.16" y="15.99"/>
<vertex x="83.58" y="15.94"/>
<vertex x="83.08" y="15.81"/>
<vertex x="82.66" y="15.57"/>
<vertex x="82.33" y="15.23"/>
<vertex x="82.07" y="14.78"/>
<vertex x="81.9" y="14.22"/>
<vertex x="81.79" y="13.55"/>
<vertex x="81.76" y="12.75"/>
<vertex x="81.76" y="12.01"/>
<vertex x="81.76" y="11.27"/>
<vertex x="81.76" y="10.53"/>
<vertex x="81.76" y="9.79"/>
<vertex x="81.76" y="9.04"/>
<vertex x="81.76" y="8.3"/>
<vertex x="81.76" y="7.56"/>
<vertex x="81.76" y="6.82"/>
<vertex x="81.37" y="6.82"/>
<vertex x="80.98" y="6.82"/>
<vertex x="80.59" y="6.82"/>
<vertex x="80.2" y="6.82"/>
<vertex x="79.82" y="6.82"/>
<vertex x="79.43" y="6.82"/>
<vertex x="79.04" y="6.82"/>
<vertex x="78.65" y="6.82"/>
<vertex x="78.65" y="8.24"/>
<vertex x="78.65" y="9.65"/>
<vertex x="78.65" y="11.06"/>
<vertex x="78.65" y="12.48"/>
<vertex x="78.65" y="13.89"/>
<vertex x="78.65" y="15.3"/>
<vertex x="78.65" y="16.72"/>
</polygon>
<vertex x="64.64" y="37.54"/>
<vertex x="64.64" y="37.49"/>
<vertex x="64.67" y="37.35"/>
<vertex x="64.67" y="37.15"/>
<vertex x="64.66" y="36.91"/>
<vertex x="64.6" y="36.67"/>
<vertex x="64.48" y="36.44"/>
<vertex x="64.29" y="36.26"/>
<vertex x="64" y="36.15"/>
<vertex x="63.74" y="36.15"/>
<vertex x="63.46" y="36.2"/>
<vertex x="63.16" y="36.31"/>
<vertex x="62.85" y="36.46"/>
<vertex x="62.56" y="36.64"/>
<vertex x="62.27" y="36.85"/>
<vertex x="62.02" y="37.08"/>
<vertex x="61.8" y="37.31"/>
<vertex x="61.59" y="37.6"/>
<vertex x="61.45" y="37.87"/>
<vertex x="61.37" y="38.13"/>
<vertex x="61.34" y="38.38"/>
<vertex x="61.37" y="38.61"/>
<vertex x="61.44" y="38.84"/>
<vertex x="61.57" y="39.05"/>
<vertex x="61.74" y="39.26"/>
<vertex x="62.04" y="39.52"/>
<vertex x="62.37" y="39.69"/>
<vertex x="62.71" y="39.78"/>
<vertex x="63.03" y="39.82"/>
<vertex x="63.32" y="39.82"/>
<vertex x="63.56" y="39.8"/>
<vertex x="63.71" y="39.77"/>
<vertex x="63.77" y="39.77"/>
<vertex x="63.66" y="39.85"/>
<vertex x="63.36" y="40.06"/>
<vertex x="62.89" y="40.33"/>
<vertex x="62.29" y="40.59"/>
<vertex x="61.56" y="40.77"/>
<vertex x="60.75" y="40.8"/>
<vertex x="59.88" y="40.61"/>
<vertex x="59.76" y="40.57"/>
<vertex x="58.97" y="40.14"/>
<vertex x="58.28" y="39.55"/>
<vertex x="57.83" y="38.93"/>
<vertex x="57.62" y="38.27"/>
<vertex x="57.62" y="37.58"/>
<vertex x="57.81" y="36.88"/>
<vertex x="58.18" y="36.18"/>
<vertex x="58.71" y="35.49"/>
<vertex x="59.38" y="34.81"/>
<vertex x="59.9" y="34.2"/>
<vertex x="60.16" y="33.6"/>
<vertex x="60.18" y="33.04"/>
<vertex x="60" y="32.54"/>
<vertex x="59.66" y="32.12"/>
<vertex x="59.18" y="31.82"/>
<vertex x="58.6" y="31.66"/>
<vertex x="57.95" y="31.65"/>
<vertex x="57.53" y="31.75"/>
<vertex x="57.17" y="31.91"/>
<vertex x="56.88" y="32.11"/>
<vertex x="56.67" y="32.36"/>
<vertex x="56.52" y="32.62"/>
<vertex x="56.45" y="32.89"/>
<vertex x="56.45" y="33.15"/>
<vertex x="56.52" y="33.4"/>
<vertex x="56.64" y="33.58"/>
<vertex x="56.81" y="33.74"/>
<vertex x="56.99" y="33.89"/>
<vertex x="57.18" y="34.01"/>
<vertex x="57.36" y="34.1"/>
<vertex x="57.51" y="34.17"/>
<vertex x="57.62" y="34.22"/>
<vertex x="57.66" y="34.23"/>
<vertex x="57.61" y="34.25"/>
<vertex x="57.48" y="34.29"/>
<vertex x="57.27" y="34.34"/>
<vertex x="57" y="34.38"/>
<vertex x="56.67" y="34.41"/>
<vertex x="56.3" y="34.39"/>
<vertex x="55.89" y="34.33"/>
<vertex x="55.46" y="34.2"/>
<vertex x="55.07" y="34.02"/>
<vertex x="54.7" y="33.79"/>
<vertex x="54.37" y="33.5"/>
<vertex x="54.09" y="33.13"/>
<vertex x="53.86" y="32.67"/>
<vertex x="53.69" y="32.12"/>
<vertex x="53.59" y="31.47"/>
<vertex x="53.58" y="30.7"/>
<vertex x="53.58" y="29.42"/>
<vertex x="53.58" y="28.14"/>
<vertex x="53.58" y="26.86"/>
<vertex x="53.58" y="25.58"/>
<vertex x="53.58" y="24.29"/>
<vertex x="53.58" y="23.01"/>
<vertex x="53.58" y="21.73"/>
<vertex x="53.58" y="20.45"/>
<vertex x="53.63" y="20.51"/>
<vertex x="53.77" y="20.69"/>
<vertex x="54" y="20.95"/>
<vertex x="54.29" y="21.3"/>
<vertex x="54.65" y="21.72"/>
<vertex x="55.06" y="22.18"/>
<vertex x="55.5" y="22.68"/>
<vertex x="55.98" y="23.2"/>
<vertex x="56.49" y="23.76"/>
<vertex x="56.95" y="24.26"/>
<vertex x="57.37" y="24.7"/>
<vertex x="57.77" y="25.08"/>
<vertex x="58.18" y="25.37"/>
<vertex x="58.6" y="25.57"/>
<vertex x="59.07" y="25.68"/>
<vertex x="59.59" y="25.69"/>
<vertex x="59.72" y="25.68"/>
<vertex x="60.61" y="25.69"/>
<vertex x="61.56" y="25.81"/>
<vertex x="62.44" y="26.06"/>
<vertex x="63.25" y="26.41"/>
<vertex x="64" y="26.87"/>
<vertex x="64.68" y="27.42"/>
<vertex x="65.29" y="28.06"/>
<vertex x="65.84" y="28.78"/>
<vertex x="65.96" y="28.96"/>
<vertex x="66.63" y="30.24"/>
<vertex x="66.7" y="30.43"/>
<vertex x="67.03" y="31.7"/>
<vertex x="67.05" y="31.88"/>
<vertex x="67.1" y="33.1"/>
<vertex x="67.09" y="33.27"/>
<vertex x="66.91" y="34.4"/>
<vertex x="66.87" y="34.55"/>
<vertex x="66.5" y="35.54"/>
<vertex x="66.44" y="35.67"/>
<vertex x="65.95" y="36.48"/>
<vertex x="65.31" y="37.17"/>
<vertex x="64.63" y="37.55"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_.9">
<vertex x="4.28" y="12.92"/>
<vertex x="4.34" y="12.4"/>
<vertex x="4.51" y="11.96"/>
<vertex x="4.77" y="11.59"/>
<vertex x="5.11" y="11.29"/>
<vertex x="5.52" y="11.06"/>
<vertex x="5.97" y="10.91"/>
<vertex x="6.46" y="10.81"/>
<vertex x="6.96" y="10.78"/>
<vertex x="7.34" y="10.8"/>
<vertex x="7.73" y="10.86"/>
<vertex x="8.12" y="10.97"/>
<vertex x="8.48" y="11.13"/>
<vertex x="8.79" y="11.35"/>
<vertex x="9.03" y="11.63"/>
<vertex x="9.19" y="11.98"/>
<vertex x="9.25" y="12.4"/>
<vertex x="9.18" y="12.77"/>
<vertex x="8.98" y="13.09"/>
<vertex x="8.65" y="13.36"/>
<vertex x="8.2" y="13.59"/>
<vertex x="7.63" y="13.8"/>
<vertex x="6.96" y="14"/>
<vertex x="6.17" y="14.18"/>
<vertex x="5.29" y="14.37"/>
<vertex x="4.53" y="14.56"/>
<vertex x="3.8" y="14.78"/>
<vertex x="3.11" y="15.06"/>
<vertex x="2.5" y="15.4"/>
<vertex x="1.99" y="15.82"/>
<vertex x="1.6" y="16.35"/>
<vertex x="1.34" y="16.99"/>
<vertex x="1.25" y="17.77"/>
<vertex x="1.26" y="17.92"/>
<vertex x="1.38" y="18.88"/>
<vertex x="1.73" y="19.78"/>
<vertex x="2.28" y="20.49"/>
<vertex x="3" y="21.03"/>
<vertex x="3.84" y="21.42"/>
<vertex x="4.77" y="21.67"/>
<vertex x="4.89" y="21.7"/>
<vertex x="5.77" y="21.81"/>
<vertex x="5.89" y="21.82"/>
<vertex x="6.79" y="21.86"/>
<vertex x="6.92" y="21.86"/>
<vertex x="7.81" y="21.81"/>
<vertex x="8.79" y="21.66"/>
<vertex x="9.71" y="21.4"/>
<vertex x="10.53" y="21"/>
<vertex x="11.23" y="20.45"/>
<vertex x="11.8" y="19.75"/>
<vertex x="12.2" y="18.87"/>
<vertex x="12.23" y="18.74"/>
<vertex x="12.4" y="17.8"/>
<vertex x="11.99" y="17.8"/>
<vertex x="11.57" y="17.8"/>
<vertex x="11.16" y="17.8"/>
<vertex x="10.74" y="17.8"/>
<vertex x="10.33" y="17.8"/>
<vertex x="9.91" y="17.8"/>
<vertex x="9.5" y="17.8"/>
<vertex x="9.08" y="17.8"/>
<vertex x="9" y="18.26"/>
<vertex x="8.84" y="18.64"/>
<vertex x="8.61" y="18.94"/>
<vertex x="8.32" y="19.17"/>
<vertex x="7.97" y="19.33"/>
<vertex x="7.58" y="19.44"/>
<vertex x="7.15" y="19.5"/>
<vertex x="6.69" y="19.52"/>
<vertex x="6.38" y="19.52"/>
<vertex x="6.05" y="19.48"/>
<vertex x="5.73" y="19.42"/>
<vertex x="5.42" y="19.32"/>
<vertex x="5.15" y="19.18"/>
<vertex x="4.94" y="18.97"/>
<vertex x="4.8" y="18.69"/>
<vertex x="4.75" y="18.34"/>
<vertex x="4.83" y="17.91"/>
<vertex x="5.09" y="17.58"/>
<vertex x="5.48" y="17.31"/>
<vertex x="5.99" y="17.09"/>
<vertex x="6.59" y="16.92"/>
<vertex x="7.26" y="16.76"/>
<vertex x="7.97" y="16.61"/>
<vertex x="8.71" y="16.44"/>
<vertex x="9.47" y="16.25"/>
<vertex x="10.2" y="16.02"/>
<vertex x="10.88" y="15.73"/>
<vertex x="11.49" y="15.37"/>
<vertex x="12.01" y="14.92"/>
<vertex x="12.4" y="14.36"/>
<vertex x="12.66" y="13.68"/>
<vertex x="12.75" y="12.87"/>
<vertex x="12.74" y="12.72"/>
<vertex x="12.61" y="11.72"/>
<vertex x="12.58" y="11.59"/>
<vertex x="12.24" y="10.77"/>
<vertex x="11.67" y="10"/>
<vertex x="10.92" y="9.4"/>
<vertex x="10.04" y="8.96"/>
<vertex x="9.92" y="8.92"/>
<vertex x="9.06" y="8.66"/>
<vertex x="8.93" y="8.64"/>
<vertex x="8.01" y="8.5"/>
<vertex x="7.88" y="8.48"/>
<vertex x="6.93" y="8.44"/>
<vertex x="6.8" y="8.44"/>
<vertex x="5.84" y="8.5"/>
<vertex x="5.7" y="8.51"/>
<vertex x="4.77" y="8.67"/>
<vertex x="4.64" y="8.7"/>
<vertex x="3.78" y="8.97"/>
<vertex x="3.66" y="9.02"/>
<vertex x="2.88" y="9.42"/>
<vertex x="2.12" y="10.02"/>
<vertex x="1.53" y="10.8"/>
<vertex x="1.47" y="10.91"/>
<vertex x="1.13" y="11.76"/>
<vertex x="1.09" y="11.9"/>
<vertex x="0.96" y="12.92"/>
<vertex x="1.37" y="12.92"/>
<vertex x="1.79" y="12.92"/>
<vertex x="2.2" y="12.92"/>
<vertex x="2.62" y="12.92"/>
<vertex x="3.03" y="12.92"/>
<vertex x="3.45" y="12.92"/>
<vertex x="3.86" y="12.92"/>
</polygon>
<vertex x="23.24" y="12.93"/>
<vertex x="23.44" y="13.61"/>
<vertex x="23.56" y="14.35"/>
<vertex x="23.59" y="15.11"/>
<vertex x="27.09" y="15.02"/>
<vertex x="27.09" y="14.86"/>
<vertex x="27" y="13.76"/>
<vertex x="26.98" y="13.6"/>
<vertex x="26.74" y="12.56"/>
<vertex x="26.7" y="12.41"/>
<vertex x="26.31" y="11.44"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="26.24" y="11.31"/>
<vertex x="25.7" y="10.46"/>
<vertex x="25.61" y="10.34"/>
<vertex x="24.91" y="9.63"/>
<vertex x="24.8" y="9.54"/>
<vertex x="23.95" y="8.99"/>
<vertex x="23.82" y="8.93"/>
<vertex x="22.82" y="8.59"/>
<vertex x="22.66" y="8.55"/>
<vertex x="21.5" y="8.44"/>
<vertex x="20.93" y="8.48"/>
<vertex x="20.37" y="8.57"/>
<vertex x="19.84" y="8.72"/>
<vertex x="19.34" y="8.93"/>
<vertex x="18.86" y="9.21"/>
<vertex x="18.43" y="9.54"/>
<vertex x="18.04" y="9.92"/>
<vertex x="17.69" y="10.36"/>
<vertex x="17.68" y="10.36"/>
<vertex x="17.67" y="10.36"/>
<vertex x="17.67" y="9.22"/>
<vertex x="17.67" y="8.07"/>
<vertex x="17.67" y="6.93"/>
<vertex x="17.67" y="5.78"/>
<vertex x="17.67" y="4.64"/>
<vertex x="17.67" y="3.49"/>
<vertex x="17.67" y="2.35"/>
<vertex x="17.67" y="1.2"/>
<vertex x="17.23" y="1.59"/>
<vertex x="16.79" y="1.98"/>
<vertex x="16.36" y="2.37"/>
<vertex x="15.92" y="2.76"/>
<vertex x="15.48" y="3.15"/>
<vertex x="15.05" y="3.53"/>
<vertex x="14.61" y="3.92"/>
<vertex x="14.17" y="4.31"/>
<vertex x="14.17" y="6.39"/>
<vertex x="14.17" y="8.46"/>
<vertex x="14.17" y="10.54"/>
<vertex x="14.17" y="12.62"/>
<vertex x="14.17" y="14.69"/>
<vertex x="14.17" y="16.77"/>
<vertex x="14.17" y="18.85"/>
<vertex x="14.17" y="20.92"/>
<vertex x="14.59" y="21"/>
<vertex x="15" y="21.07"/>
<vertex x="15.42" y="21.14"/>
<vertex x="15.84" y="21.22"/>
<vertex x="16.25" y="21.29"/>
<vertex x="16.67" y="21.37"/>
<vertex x="17.08" y="21.44"/>
<vertex x="17.5" y="21.51"/>
<vertex x="17.5" y="21.31"/>
<vertex x="17.5" y="21.11"/>
<vertex x="17.5" y="20.91"/>
<vertex x="17.5" y="20.7"/>
<vertex x="17.5" y="20.5"/>
<vertex x="17.5" y="20.3"/>
<vertex x="17.5" y="20.09"/>
<vertex x="17.5" y="19.89"/>
<vertex x="17.51" y="19.89"/>
<vertex x="17.52" y="19.89"/>
<vertex x="17.86" y="20.37"/>
<vertex x="18.25" y="20.78"/>
<vertex x="18.68" y="21.12"/>
<vertex x="19.15" y="21.39"/>
<vertex x="19.64" y="21.6"/>
<vertex x="20.17" y="21.74"/>
<vertex x="20.73" y="21.83"/>
<vertex x="21.31" y="21.86"/>
<vertex x="21.49" y="21.86"/>
<vertex x="22.7" y="21.71"/>
<vertex x="22.86" y="21.68"/>
<vertex x="23.89" y="21.3"/>
<vertex x="24.03" y="21.23"/>
<vertex x="24.89" y="20.65"/>
<vertex x="25" y="20.55"/>
<vertex x="25.7" y="19.79"/>
<vertex x="25.78" y="19.68"/>
<vertex x="26.31" y="18.77"/>
<vertex x="26.38" y="18.63"/>
<vertex x="26.75" y="17.61"/>
<vertex x="26.79" y="17.46"/>
<vertex x="27.01" y="16.35"/>
<vertex x="27.03" y="16.19"/>
<vertex x="23.55" y="15.88"/>
<vertex x="23.43" y="16.62"/>
<vertex x="23.22" y="17.31"/>
<vertex x="22.91" y="17.93"/>
<vertex x="22.49" y="18.46"/>
<vertex x="21.96" y="18.87"/>
<vertex x="21.32" y="19.13"/>
<vertex x="20.54" y="19.22"/>
<vertex x="19.76" y="19.13"/>
<vertex x="19.1" y="18.87"/>
<vertex x="18.58" y="18.47"/>
<vertex x="18.17" y="17.94"/>
<vertex x="17.87" y="17.32"/>
<vertex x="17.67" y="16.63"/>
<vertex x="17.55" y="15.88"/>
<vertex x="17.52" y="15.11"/>
<vertex x="17.56" y="14.35"/>
<vertex x="17.68" y="13.61"/>
<vertex x="17.89" y="12.93"/>
<vertex x="18.19" y="12.32"/>
<vertex x="18.61" y="11.81"/>
<vertex x="19.14" y="11.42"/>
<vertex x="19.79" y="11.17"/>
<vertex x="20.57" y="11.08"/>
<vertex x="21.36" y="11.17"/>
<vertex x="22.01" y="11.42"/>
<vertex x="22.53" y="11.81"/>
<vertex x="22.94" y="12.32"/>
</polygon>
<vertex x="32.41" y="16.09"/>
<vertex x="33.2" y="16.19"/>
<vertex x="33.96" y="16.28"/>
<vertex x="34.68" y="16.37"/>
<vertex x="35.1" y="14.49"/>
<vertex x="34.9" y="14.46"/>
<vertex x="34.69" y="14.43"/>
<vertex x="34.48" y="14.4"/>
<vertex x="34.28" y="14.36"/>
<vertex x="34.07" y="14.33"/>
<vertex x="33.86" y="14.3"/>
<vertex x="33.66" y="14.27"/>
<vertex x="33.45" y="14.23"/>
<vertex x="33.26" y="14.18"/>
<vertex x="33.06" y="14.13"/>
</polygon>
<vertex x="32.88" y="14.07"/>
<vertex x="32.7" y="14"/>
<vertex x="32.53" y="13.93"/>
<vertex x="32.37" y="13.84"/>
<vertex x="32.22" y="13.74"/>
<vertex x="32.08" y="13.62"/>
<vertex x="31.96" y="13.5"/>
<vertex x="31.85" y="13.36"/>
<vertex x="31.76" y="13.2"/>
<vertex x="31.69" y="13.03"/>
<vertex x="31.63" y="12.84"/>
<vertex x="31.6" y="12.62"/>
<vertex x="31.59" y="12.39"/>
<vertex x="31.6" y="12.17"/>
<vertex x="31.63" y="11.96"/>
<vertex x="31.69" y="11.77"/>
<vertex x="31.76" y="11.6"/>
<vertex x="31.86" y="11.45"/>
<vertex x="31.97" y="11.32"/>
<vertex x="32.09" y="11.2"/>
<vertex x="32.24" y="11.1"/>
<vertex x="32.39" y="11.02"/>
<vertex x="32.56" y="10.95"/>
<vertex x="32.73" y="10.89"/>
<vertex x="32.92" y="10.84"/>
<vertex x="33.11" y="10.81"/>
<vertex x="33.31" y="10.78"/>
<vertex x="33.52" y="10.77"/>
<vertex x="33.73" y="10.77"/>
<vertex x="34.21" y="10.8"/>
<vertex x="34.64" y="10.87"/>
<vertex x="35.01" y="10.98"/>
<vertex x="35.33" y="11.13"/>
<vertex x="35.6" y="11.3"/>
<vertex x="35.83" y="11.5"/>
<vertex x="36.02" y="11.71"/>
<vertex x="36.17" y="11.95"/>
<vertex x="36.29" y="12.19"/>
<vertex x="36.39" y="12.43"/>
<vertex x="36.46" y="12.68"/>
<vertex x="36.5" y="12.92"/>
<vertex x="36.53" y="13.14"/>
<vertex x="36.55" y="13.35"/>
<vertex x="36.56" y="13.54"/>
<vertex x="36.56" y="13.71"/>
<vertex x="36.56" y="13.79"/>
<vertex x="36.56" y="13.87"/>
<vertex x="36.56" y="13.95"/>
<vertex x="36.56" y="14.03"/>
<vertex x="36.56" y="14.11"/>
<vertex x="36.56" y="14.19"/>
<vertex x="36.56" y="14.28"/>
<vertex x="36.56" y="14.36"/>
<vertex x="36.56" y="14.44"/>
<vertex x="36.56" y="14.52"/>
<vertex x="36.56" y="14.6"/>
<vertex x="36.56" y="14.68"/>
<vertex x="36.56" y="14.76"/>
<vertex x="36.56" y="14.85"/>
<vertex x="36.56" y="14.93"/>
<vertex x="36.56" y="15.01"/>
<vertex x="36.44" y="14.92"/>
<vertex x="36.31" y="14.83"/>
<vertex x="36.16" y="14.76"/>
<vertex x="36.01" y="14.7"/>
<vertex x="35.84" y="14.64"/>
<vertex x="35.67" y="14.6"/>
<vertex x="35.48" y="14.55"/>
<vertex x="35.29" y="14.51"/>
<vertex x="35.3" y="16.53"/>
<vertex x="35.84" y="16.71"/>
<vertex x="36.24" y="16.96"/>
<vertex x="36.49" y="17.31"/>
<vertex x="36.56" y="17.78"/>
<vertex x="36.55" y="18.05"/>
<vertex x="36.52" y="18.28"/>
<vertex x="36.46" y="18.49"/>
<vertex x="36.38" y="18.68"/>
<vertex x="36.29" y="18.84"/>
<vertex x="36.17" y="18.98"/>
<vertex x="36.04" y="19.1"/>
<vertex x="35.89" y="19.2"/>
<vertex x="35.73" y="19.28"/>
<vertex x="35.56" y="19.35"/>
<vertex x="35.37" y="19.41"/>
<vertex x="35.17" y="19.45"/>
<vertex x="34.97" y="19.48"/>
<vertex x="34.75" y="19.5"/>
<vertex x="34.53" y="19.5"/>
<vertex x="34.3" y="19.5"/>
<vertex x="34.05" y="19.5"/>
<vertex x="33.82" y="19.47"/>
<vertex x="33.59" y="19.44"/>
<vertex x="33.38" y="19.39"/>
<vertex x="33.19" y="19.33"/>
<vertex x="33" y="19.25"/>
<vertex x="32.84" y="19.16"/>
<vertex x="32.68" y="19.05"/>
<vertex x="32.54" y="18.93"/>
<vertex x="32.41" y="18.79"/>
<vertex x="32.3" y="18.63"/>
<vertex x="32.21" y="18.46"/>
<vertex x="32.13" y="18.27"/>
<vertex x="32.07" y="18.05"/>
<vertex x="32.02" y="17.83"/>
<vertex x="31.99" y="17.58"/>
<vertex x="31.77" y="17.58"/>
<vertex x="31.55" y="17.58"/>
<vertex x="31.33" y="17.58"/>
<vertex x="31.11" y="17.58"/>
<vertex x="30.9" y="17.58"/>
<vertex x="30.68" y="17.58"/>
<vertex x="30.46" y="17.58"/>
<vertex x="30.24" y="17.58"/>
<vertex x="30.02" y="17.58"/>
<vertex x="29.8" y="17.58"/>
<vertex x="29.59" y="17.58"/>
<vertex x="29.37" y="17.58"/>
<vertex x="29.15" y="17.58"/>
<vertex x="28.93" y="17.58"/>
<vertex x="28.71" y="17.58"/>
<vertex x="28.5" y="17.58"/>
<vertex x="28.56" y="18.16"/>
<vertex x="28.69" y="18.69"/>
<vertex x="28.88" y="19.18"/>
<vertex x="29.11" y="19.61"/>
<vertex x="29.4" y="20"/>
<vertex x="29.72" y="20.35"/>
<vertex x="30.09" y="20.66"/>
<vertex x="30.49" y="20.92"/>
<vertex x="30.92" y="21.15"/>
<vertex x="31.38" y="21.34"/>
<vertex x="31.86" y="21.5"/>
<vertex x="32.37" y="21.62"/>
<vertex x="32.88" y="21.72"/>
<vertex x="33.41" y="21.78"/>
<vertex x="33.94" y="21.82"/>
<vertex x="34.48" y="21.83"/>
<vertex x="34.96" y="21.83"/>
<vertex x="35.45" y="21.8"/>
<vertex x="35.93" y="21.75"/>
<vertex x="36.42" y="21.69"/>
<vertex x="36.9" y="21.6"/>
<vertex x="37.36" y="21.49"/>
<vertex x="37.8" y="21.34"/>
<vertex x="38.22" y="21.16"/>
<vertex x="38.61" y="20.95"/>
<vertex x="38.97" y="20.69"/>
<vertex x="39.28" y="20.4"/>
<vertex x="39.55" y="20.06"/>
<vertex x="39.77" y="19.68"/>
<vertex x="39.93" y="19.24"/>
<vertex x="40.03" y="18.75"/>
<vertex x="40.07" y="18.21"/>
<vertex x="40.07" y="17.8"/>
<vertex x="40.07" y="17.38"/>
<vertex x="40.07" y="16.97"/>
<vertex x="40.07" y="16.55"/>
<vertex x="40.07" y="16.14"/>
<vertex x="40.07" y="15.73"/>
<vertex x="40.07" y="15.31"/>
<vertex x="40.07" y="14.9"/>
<vertex x="40.07" y="14.49"/>
<vertex x="40.07" y="14.07"/>
<vertex x="40.07" y="13.66"/>
<vertex x="40.07" y="13.24"/>
<vertex x="40.07" y="12.83"/>
<vertex x="40.07" y="12.42"/>
<vertex x="40.07" y="12"/>
<vertex x="40.07" y="11.59"/>
<vertex x="40.07" y="11.37"/>
<vertex x="40.07" y="11.16"/>
<vertex x="40.08" y="10.94"/>
<vertex x="40.08" y="10.73"/>
<vertex x="40.09" y="10.52"/>
<vertex x="40.11" y="10.32"/>
<vertex x="40.13" y="10.12"/>
<vertex x="40.16" y="9.93"/>
<vertex x="40.19" y="9.75"/>
<vertex x="40.23" y="9.58"/>
<vertex x="40.26" y="9.41"/>
<vertex x="40.3" y="9.26"/>
<vertex x="40.34" y="9.11"/>
<vertex x="40.39" y="8.98"/>
<vertex x="40.44" y="8.86"/>
<vertex x="40.5" y="8.76"/>
<vertex x="40.28" y="8.76"/>
<vertex x="40.06" y="8.76"/>
<vertex x="39.84" y="8.76"/>
<vertex x="39.62" y="8.76"/>
<vertex x="39.4" y="8.76"/>
<vertex x="39.17" y="8.76"/>
<vertex x="38.95" y="8.76"/>
<vertex x="38.73" y="8.76"/>
<vertex x="38.51" y="8.76"/>
<vertex x="38.29" y="8.76"/>
<vertex x="38.07" y="8.76"/>
<vertex x="37.85" y="8.76"/>
<vertex x="37.63" y="8.76"/>
<vertex x="37.4" y="8.76"/>
<vertex x="37.18" y="8.76"/>
<vertex x="36.96" y="8.76"/>
<vertex x="36.94" y="8.83"/>
<vertex x="36.91" y="8.91"/>
<vertex x="36.88" y="8.98"/>
<vertex x="36.85" y="9.06"/>
<vertex x="36.83" y="9.13"/>
<vertex x="36.81" y="9.21"/>
<vertex x="36.79" y="9.29"/>
<vertex x="36.77" y="9.37"/>
<vertex x="36.76" y="9.44"/>
<vertex x="36.75" y="9.52"/>
<vertex x="36.74" y="9.6"/>
<vertex x="36.73" y="9.68"/>
<vertex x="36.73" y="9.76"/>
<vertex x="36.72" y="9.83"/>
<vertex x="36.72" y="9.91"/>
<vertex x="36.72" y="9.99"/>
<vertex x="36.5" y="9.78"/>
<vertex x="36.28" y="9.59"/>
<vertex x="36.05" y="9.41"/>
<vertex x="35.8" y="9.26"/>
<vertex x="35.55" y="9.11"/>
<vertex x="35.29" y="8.98"/>
<vertex x="35.03" y="8.87"/>
<vertex x="34.75" y="8.77"/>
<vertex x="34.47" y="8.68"/>
<vertex x="34.19" y="8.61"/>
<vertex x="33.9" y="8.55"/>
<vertex x="33.61" y="8.5"/>
<vertex x="33.32" y="8.46"/>
<vertex x="33.03" y="8.43"/>
<vertex x="32.73" y="8.41"/>
<vertex x="32.43" y="8.41"/>
<vertex x="31.98" y="8.42"/>
<vertex x="31.55" y="8.46"/>
<vertex x="31.13" y="8.53"/>
<vertex x="30.73" y="8.63"/>
<vertex x="30.35" y="8.76"/>
<vertex x="29.99" y="8.92"/>
<vertex x="29.66" y="9.11"/>
<vertex x="29.36" y="9.33"/>
<vertex x="29.08" y="9.58"/>
<vertex x="28.83" y="9.87"/>
<vertex x="28.62" y="10.18"/>
<vertex x="28.44" y="10.52"/>
<vertex x="28.3" y="10.9"/>
<vertex x="28.19" y="11.31"/>
<vertex x="28.13" y="11.75"/>
<vertex x="28.1" y="12.22"/>
<vertex x="28.21" y="13.2"/>
<vertex x="28.48" y="14"/>
<vertex x="28.91" y="14.63"/>
<vertex x="29.46" y="15.12"/>
<vertex x="30.11" y="15.49"/>
<vertex x="30.84" y="15.76"/>
<vertex x="31.61" y="15.95"/>
</polygon>
<vertex x="42.04" y="20.92"/>
<vertex x="42.45" y="20.99"/>
<vertex x="42.87" y="21.07"/>
<vertex x="43.28" y="21.14"/>
<vertex x="43.7" y="21.22"/>
<vertex x="44.11" y="21.29"/>
<vertex x="44.53" y="21.36"/>
<vertex x="44.94" y="21.44"/>
<vertex x="45.36" y="21.51"/>
<vertex x="45.36" y="21.21"/>
<vertex x="45.36" y="20.92"/>
<vertex x="45.36" y="20.62"/>
<vertex x="45.36" y="20.33"/>
<vertex x="45.36" y="20.03"/>
<vertex x="45.36" y="19.74"/>
<vertex x="45.36" y="19.44"/>
<vertex x="45.36" y="19.15"/>
<vertex x="45.37" y="19.15"/>
<vertex x="45.38" y="19.15"/>
<vertex x="45.67" y="19.72"/>
<vertex x="46.05" y="20.24"/>
<vertex x="46.5" y="20.71"/>
<vertex x="47.01" y="21.1"/>
<vertex x="47.56" y="21.42"/>
<vertex x="48.16" y="21.66"/>
<vertex x="48.79" y="21.8"/>
<vertex x="49.44" y="21.85"/>
<vertex x="49.54" y="21.85"/>
<vertex x="49.64" y="21.85"/>
<vertex x="49.74" y="21.84"/>
<vertex x="49.83" y="21.83"/>
<vertex x="49.93" y="21.81"/>
<vertex x="50.02" y="21.79"/>
<vertex x="50.11" y="21.76"/>
<vertex x="50.21" y="21.73"/>
<vertex x="50.21" y="21.32"/>
<vertex x="50.21" y="20.92"/>
<vertex x="50.21" y="20.51"/>
<vertex x="50.21" y="20.11"/>
<vertex x="50.21" y="19.7"/>
<vertex x="50.21" y="19.29"/>
<vertex x="50.21" y="18.89"/>
<vertex x="50.21" y="18.48"/>
<vertex x="50.08" y="18.51"/>
<vertex x="49.93" y="18.54"/>
<vertex x="49.78" y="18.56"/>
<vertex x="49.62" y="18.58"/>
<vertex x="49.45" y="18.59"/>
<vertex x="49.28" y="18.6"/>
<vertex x="49.11" y="18.6"/>
<vertex x="48.95" y="18.6"/>
<vertex x="48.06" y="18.52"/>
<vertex x="47.32" y="18.28"/>
<vertex x="46.72" y="17.91"/>
<vertex x="46.26" y="17.41"/>
<vertex x="45.91" y="16.81"/>
<vertex x="45.68" y="16.11"/>
<vertex x="45.55" y="15.34"/>
<vertex x="45.5" y="14.52"/>
<vertex x="45.5" y="13.8"/>
<vertex x="45.5" y="13.08"/>
<vertex x="45.5" y="12.37"/>
<vertex x="45.5" y="11.65"/>
<vertex x="45.5" y="10.93"/>
<vertex x="45.5" y="10.22"/>
<vertex x="45.5" y="9.5"/>
<vertex x="45.5" y="8.78"/>
<vertex x="45.07" y="8.78"/>
<vertex x="44.63" y="8.78"/>
<vertex x="44.19" y="8.78"/>
<vertex x="43.75" y="8.78"/>
<vertex x="43.32" y="8.78"/>
<vertex x="42.88" y="8.78"/>
<vertex x="42.44" y="8.78"/>
<vertex x="42.01" y="8.78"/>
<vertex x="42.01" y="10.3"/>
<vertex x="42.01" y="11.82"/>
<vertex x="42.01" y="13.33"/>
<vertex x="42.01" y="14.85"/>
<vertex x="42.01" y="16.37"/>
<vertex x="42.01" y="17.88"/>
<vertex x="42.01" y="19.4"/>
</polygon>
<vertex x="51.58" y="24.44"/>
<vertex x="55.08" y="26.36"/>
<vertex x="55.08" y="16.93"/>
<vertex x="59.48" y="21.51"/>
<vertex x="63.62" y="21.51"/>
<vertex x="58.82" y="16.83"/>
<vertex x="64.16" y="8.79"/>
<vertex x="59.93" y="8.79"/>
<vertex x="56.43" y="14.47"/>
<vertex x="55.08" y="13.17"/>
<vertex x="55.08" y="8.79"/>
<vertex x="51.58" y="8.79"/>
</polygon>
<vertex x="66.28" y="19.17"/>
<vertex x="65.85" y="19.17"/>
<vertex x="65.42" y="19.17"/>
<vertex x="64.99" y="19.17"/>
<vertex x="64.56" y="19.17"/>
<vertex x="64.13" y="19.17"/>
<vertex x="63.7" y="19.17"/>
<vertex x="63.27" y="19.17"/>
<vertex x="62.84" y="19.17"/>
<vertex x="63.14" y="19.47"/>
<vertex x="63.43" y="19.76"/>
<vertex x="63.73" y="20.05"/>
<vertex x="64.03" y="20.34"/>
<vertex x="64.33" y="20.64"/>
<vertex x="64.62" y="20.93"/>
<vertex x="64.92" y="21.22"/>
<vertex x="65.22" y="21.51"/>
<vertex x="65.35" y="21.51"/>
<vertex x="65.49" y="21.51"/>
<vertex x="65.62" y="21.51"/>
<vertex x="65.75" y="21.51"/>
<vertex x="65.89" y="21.51"/>
<vertex x="66.02" y="21.51"/>
<vertex x="66.15" y="21.51"/>
<vertex x="66.28" y="21.51"/>
<vertex x="66.28" y="21.64"/>
<vertex x="66.28" y="21.76"/>
<vertex x="66.28" y="21.88"/>
<vertex x="66.28" y="22"/>
<vertex x="66.28" y="22.13"/>
<vertex x="66.28" y="22.25"/>
<vertex x="66.28" y="22.37"/>
<vertex x="66.28" y="22.49"/>
<vertex x="66.35" y="23.31"/>
<vertex x="66.55" y="24.05"/>
<vertex x="66.88" y="24.71"/>
<vertex x="67.34" y="25.28"/>
<vertex x="67.94" y="25.73"/>
<vertex x="68.67" y="26.07"/>
<vertex x="69.54" y="26.29"/>
<vertex x="69.66" y="26.3"/>
<vertex x="70.54" y="26.36"/>
<vertex x="70.77" y="26.36"/>
<vertex x="71.01" y="26.35"/>
<vertex x="71.24" y="26.34"/>
<vertex x="71.48" y="26.33"/>
<vertex x="71.71" y="26.31"/>
<vertex x="71.94" y="26.29"/>
<vertex x="72.16" y="26.28"/>
<vertex x="72.39" y="26.28"/>
<vertex x="72.39" y="25.95"/>
<vertex x="72.39" y="25.62"/>
<vertex x="72.39" y="25.3"/>
<vertex x="72.39" y="24.97"/>
<vertex x="72.39" y="24.65"/>
<vertex x="72.39" y="24.32"/>
<vertex x="72.39" y="23.99"/>
<vertex x="72.39" y="23.67"/>
<vertex x="72.23" y="23.68"/>
<vertex x="72.07" y="23.7"/>
<vertex x="71.91" y="23.71"/>
<vertex x="71.75" y="23.72"/>
<vertex x="71.59" y="23.72"/>
<vertex x="71.43" y="23.72"/>
<vertex x="71.27" y="23.73"/>
<vertex x="71.11" y="23.73"/>
<vertex x="70.78" y="23.71"/>
<vertex x="70.5" y="23.65"/>
<vertex x="70.27" y="23.55"/>
<vertex x="70.08" y="23.4"/>
<vertex x="69.95" y="23.2"/>
<vertex x="69.85" y="22.95"/>
<vertex x="69.8" y="22.64"/>
<vertex x="69.78" y="22.28"/>
<vertex x="69.78" y="22.18"/>
<vertex x="69.78" y="22.08"/>
<vertex x="69.78" y="21.99"/>
<vertex x="69.78" y="21.89"/>
<vertex x="69.78" y="21.8"/>
<vertex x="69.78" y="21.7"/>
<vertex x="69.78" y="21.61"/>
<vertex x="69.78" y="21.51"/>
<vertex x="70.08" y="21.51"/>
<vertex x="70.38" y="21.51"/>
<vertex x="70.68" y="21.51"/>
<vertex x="70.98" y="21.51"/>
<vertex x="71.28" y="21.51"/>
<vertex x="71.59" y="21.51"/>
<vertex x="71.89" y="21.51"/>
<vertex x="72.19" y="21.51"/>
<vertex x="72.19" y="21.22"/>
<vertex x="72.19" y="20.93"/>
<vertex x="72.19" y="20.64"/>
<vertex x="72.19" y="20.34"/>
<vertex x="72.19" y="20.05"/>
<vertex x="72.19" y="19.76"/>
<vertex x="72.19" y="19.47"/>
<vertex x="72.19" y="19.17"/>
<vertex x="71.89" y="19.17"/>
<vertex x="71.59" y="19.17"/>
<vertex x="71.28" y="19.17"/>
<vertex x="70.98" y="19.17"/>
<vertex x="70.68" y="19.17"/>
<vertex x="70.38" y="19.17"/>
<vertex x="70.08" y="19.17"/>
<vertex x="69.78" y="19.17"/>
<vertex x="69.78" y="17.88"/>
<vertex x="69.78" y="16.58"/>
<vertex x="69.78" y="15.28"/>
<vertex x="69.78" y="13.98"/>
<vertex x="69.78" y="12.68"/>
<vertex x="69.78" y="11.38"/>
<vertex x="69.78" y="10.08"/>
<vertex x="69.78" y="8.79"/>
<vertex x="69.34" y="8.79"/>
<vertex x="68.9" y="8.79"/>
<vertex x="68.47" y="8.79"/>
<vertex x="68.03" y="8.79"/>
<vertex x="67.59" y="8.79"/>
<vertex x="67.16" y="8.79"/>
<vertex x="66.72" y="8.79"/>
<vertex x="66.28" y="8.79"/>
<vertex x="66.28" y="10.08"/>
<vertex x="66.28" y="11.38"/>
<vertex x="66.28" y="12.68"/>
<vertex x="66.28" y="13.98"/>
<vertex x="66.28" y="15.28"/>
<vertex x="66.28" y="16.58"/>
<vertex x="66.28" y="17.88"/>
</polygon>
<vertex x="85.11" y="8.79"/>
<vertex x="84.7" y="8.79"/>
<vertex x="84.28" y="8.79"/>
<vertex x="83.86" y="8.79"/>
<vertex x="83.45" y="8.79"/>
<vertex x="83.03" y="8.79"/>
<vertex x="82.62" y="8.79"/>
<vertex x="82.2" y="8.79"/>
<vertex x="81.79" y="8.79"/>
<vertex x="81.79" y="9.01"/>
<vertex x="81.79" y="9.23"/>
<vertex x="81.79" y="9.45"/>
<vertex x="81.79" y="9.67"/>
<vertex x="81.79" y="9.89"/>
<vertex x="81.79" y="10.12"/>
<vertex x="81.79" y="10.34"/>
<vertex x="81.79" y="10.56"/>
<vertex x="81.78" y="10.56"/>
<vertex x="81.77" y="10.56"/>
<vertex x="81.76" y="10.56"/>
<vertex x="81.75" y="10.56"/>
<vertex x="81.39" y="10.05"/>
<vertex x="80.97" y="9.61"/>
<vertex x="80.52" y="9.25"/>
<vertex x="80.02" y="8.96"/>
<vertex x="79.5" y="8.73"/>
<vertex x="78.96" y="8.57"/>
<vertex x="78.41" y="8.47"/>
<vertex x="77.86" y="8.44"/>
<vertex x="77.68" y="8.44"/>
<vertex x="76.59" y="8.54"/>
<vertex x="76.45" y="8.56"/>
<vertex x="75.56" y="8.82"/>
<vertex x="74.75" y="9.27"/>
<vertex x="74.14" y="9.88"/>
<vertex x="73.7" y="10.64"/>
<vertex x="73.41" y="11.53"/>
<vertex x="73.38" y="11.66"/>
<vertex x="73.25" y="12.55"/>
<vertex x="73.24" y="12.69"/>
<vertex x="73.21" y="13.68"/>
<vertex x="73.21" y="14.66"/>
<vertex x="73.21" y="15.64"/>
<vertex x="73.21" y="16.62"/>
<vertex x="73.21" y="17.6"/>
<vertex x="73.21" y="18.57"/>
<vertex x="73.21" y="19.55"/>
<vertex x="73.21" y="20.53"/>
<vertex x="73.21" y="21.51"/>
<vertex x="73.64" y="21.51"/>
<vertex x="74.08" y="21.51"/>
<vertex x="74.52" y="21.51"/>
<vertex x="74.95" y="21.51"/>
<vertex x="75.39" y="21.51"/>
<vertex x="75.83" y="21.51"/>
<vertex x="76.26" y="21.51"/>
<vertex x="76.7" y="21.51"/>
<vertex x="76.7" y="20.61"/>
<vertex x="76.7" y="19.71"/>
<vertex x="76.7" y="18.82"/>
<vertex x="76.7" y="17.92"/>
<vertex x="76.7" y="17.02"/>
<vertex x="76.7" y="16.12"/>
<vertex x="76.7" y="15.22"/>
<vertex x="76.7" y="14.32"/>
<vertex x="76.73" y="13.59"/>
<vertex x="76.82" y="12.95"/>
<vertex x="76.98" y="12.42"/>
<vertex x="77.21" y="11.98"/>
<vertex x="77.51" y="11.64"/>
<vertex x="77.9" y="11.39"/>
<vertex x="78.37" y="11.25"/>
<vertex x="78.94" y="11.2"/>
<vertex x="79.6" y="11.25"/>
<vertex x="80.17" y="11.4"/>
<vertex x="80.63" y="11.67"/>
<vertex x="81.01" y="12.05"/>
<vertex x="81.29" y="12.55"/>
<vertex x="81.49" y="13.18"/>
<vertex x="81.61" y="13.94"/>
<vertex x="81.65" y="14.84"/>
<vertex x="81.65" y="15.67"/>
<vertex x="81.65" y="16.51"/>
<vertex x="81.65" y="17.34"/>
<vertex x="81.65" y="18.17"/>
<vertex x="81.65" y="19.01"/>
<vertex x="81.65" y="19.84"/>
<vertex x="81.65" y="20.68"/>
<vertex x="81.65" y="21.51"/>
<vertex x="82.09" y="21.51"/>
<vertex x="82.52" y="21.51"/>
<vertex x="82.96" y="21.51"/>
<vertex x="83.4" y="21.51"/>
<vertex x="83.84" y="21.51"/>
<vertex x="84.27" y="21.51"/>
<vertex x="84.71" y="21.51"/>
<vertex x="85.15" y="21.51"/>
<vertex x="85.15" y="19.92"/>
<vertex x="85.15" y="18.33"/>
<vertex x="85.15" y="16.74"/>
<vertex x="85.15" y="15.15"/>
<vertex x="85.15" y="13.56"/>
<vertex x="85.15" y="11.97"/>
<vertex x="85.15" y="10.38"/>
</polygon>
<vertex x="87.04" y="21.51"/>
<vertex x="87.46" y="21.51"/>
<vertex x="87.87" y="21.51"/>
<vertex x="88.29" y="21.51"/>
<vertex x="88.7" y="21.51"/>
<vertex x="89.12" y="21.51"/>
<vertex x="89.53" y="21.51"/>
<vertex x="89.95" y="21.51"/>
<vertex x="90.36" y="21.51"/>
<vertex x="90.36" y="21.29"/>
<vertex x="90.36" y="21.07"/>
<vertex x="90.36" y="20.85"/>
<vertex x="90.36" y="20.63"/>
<vertex x="90.36" y="20.41"/>
<vertex x="90.36" y="20.19"/>
<vertex x="90.36" y="19.96"/>
<vertex x="90.36" y="19.74"/>
<vertex x="90.37" y="19.74"/>
<vertex x="90.38" y="19.74"/>
<vertex x="90.39" y="19.74"/>
<vertex x="90.4" y="19.74"/>
<vertex x="90.76" y="20.25"/>
<vertex x="91.18" y="20.69"/>
<vertex x="91.63" y="21.05"/>
<vertex x="92.12" y="21.35"/>
<vertex x="92.64" y="21.57"/>
<vertex x="93.18" y="21.73"/>
<vertex x="93.74" y="21.83"/>
<vertex x="94.29" y="21.86"/>
<vertex x="94.46" y="21.86"/>
<vertex x="95.56" y="21.76"/>
<vertex x="95.7" y="21.74"/>
<vertex x="96.59" y="21.48"/>
<vertex x="97.4" y="21.03"/>
<vertex x="98.01" y="20.42"/>
<vertex x="98.45" y="19.66"/>
<vertex x="98.74" y="18.77"/>
<vertex x="98.76" y="18.65"/>
<vertex x="98.9" y="17.75"/>
<vertex x="98.91" y="17.61"/>
<vertex x="98.94" y="16.62"/>
<vertex x="98.94" y="15.64"/>
<vertex x="98.94" y="14.66"/>
<vertex x="98.94" y="13.68"/>
<vertex x="98.94" y="12.71"/>
<vertex x="98.94" y="11.73"/>
<vertex x="98.94" y="10.75"/>
<vertex x="98.94" y="9.77"/>
<vertex x="98.94" y="8.79"/>
<vertex x="98.51" y="8.79"/>
<vertex x="98.07" y="8.79"/>
<vertex x="97.63" y="8.79"/>
<vertex x="97.2" y="8.79"/>
<vertex x="96.76" y="8.79"/>
<vertex x="96.32" y="8.79"/>
<vertex x="95.88" y="8.79"/>
<vertex x="95.45" y="8.79"/>
<vertex x="95.45" y="9.69"/>
<vertex x="95.45" y="10.59"/>
<vertex x="95.45" y="11.49"/>
<vertex x="95.45" y="12.38"/>
<vertex x="95.45" y="13.28"/>
<vertex x="95.45" y="14.18"/>
<vertex x="95.45" y="15.08"/>
<vertex x="95.45" y="15.98"/>
<vertex x="95.42" y="16.71"/>
<vertex x="95.33" y="17.35"/>
<vertex x="95.17" y="17.89"/>
<vertex x="94.94" y="18.33"/>
<vertex x="94.64" y="18.67"/>
<vertex x="94.25" y="18.91"/>
<vertex x="93.77" y="19.05"/>
<vertex x="93.21" y="19.1"/>
<vertex x="92.55" y="19.05"/>
<vertex x="91.98" y="18.9"/>
<vertex x="91.52" y="18.63"/>
<vertex x="91.14" y="18.25"/>
<vertex x="90.86" y="17.75"/>
<vertex x="90.66" y="17.12"/>
<vertex x="90.54" y="16.36"/>
<vertex x="90.5" y="15.46"/>
<vertex x="90.5" y="14.63"/>
<vertex x="90.5" y="13.79"/>
<vertex x="90.5" y="12.96"/>
<vertex x="90.5" y="12.13"/>
<vertex x="90.5" y="11.29"/>
<vertex x="90.5" y="10.46"/>
<vertex x="90.5" y="9.62"/>
<vertex x="90.5" y="8.79"/>
<vertex x="90.06" y="8.79"/>
<vertex x="89.63" y="8.79"/>
<vertex x="89.19" y="8.79"/>
<vertex x="88.75" y="8.79"/>
<vertex x="88.32" y="8.79"/>
<vertex x="87.88" y="8.79"/>
<vertex x="87.44" y="8.79"/>
<vertex x="87" y="8.79"/>
<vertex x="87" y="10.38"/>
<vertex x="87" y="11.97"/>
<vertex x="87" y="13.56"/>
<vertex x="87" y="15.15"/>
<vertex x="87" y="16.74"/>
<vertex x="87" y="18.33"/>
<vertex x="87" y="19.93"/>
</polygon>
<vertex x="71.24" y="43.35"/>
<vertex x="71.25" y="43.29"/>
<vertex x="71.27" y="43.14"/>
<vertex x="71.28" y="42.91"/>
<vertex x="71.26" y="42.64"/>
<vertex x="71.2" y="42.37"/>
<vertex x="71.07" y="42.12"/>
<vertex x="70.85" y="41.91"/>
<vertex x="70.52" y="41.79"/>
<vertex x="70.23" y="41.79"/>
<vertex x="69.91" y="41.85"/>
<vertex x="69.58" y="41.96"/>
<vertex x="69.23" y="42.13"/>
<vertex x="68.9" y="42.34"/>
<vertex x="68.58" y="42.57"/>
<vertex x="68.29" y="42.83"/>
<vertex x="68.05" y="43.1"/>
<vertex x="67.82" y="43.42"/>
<vertex x="67.65" y="43.72"/>
<vertex x="67.56" y="44.01"/>
<vertex x="67.53" y="44.29"/>
<vertex x="67.56" y="44.55"/>
<vertex x="67.65" y="44.81"/>
<vertex x="67.79" y="45.05"/>
<vertex x="67.98" y="45.28"/>
<vertex x="68.32" y="45.58"/>
<vertex x="68.69" y="45.77"/>
<vertex x="69.07" y="45.87"/>
<vertex x="69.44" y="45.92"/>
<vertex x="69.76" y="45.92"/>
<vertex x="70.02" y="45.89"/>
<vertex x="70.2" y="45.86"/>
<vertex x="70.26" y="45.86"/>
<vertex x="70.14" y="45.95"/>
<vertex x="69.81" y="46.19"/>
<vertex x="69.28" y="46.49"/>
<vertex x="68.59" y="46.78"/>
<vertex x="67.78" y="46.98"/>
<vertex x="66.87" y="47.01"/>
<vertex x="66.75" y="47"/>
<vertex x="65.88" y="46.81"/>
<vertex x="65.76" y="46.76"/>
<vertex x="64.86" y="46.28"/>
<vertex x="64.75" y="46.2"/>
<vertex x="64.09" y="45.62"/>
<vertex x="63.59" y="44.91"/>
<vertex x="63.35" y="44.17"/>
<vertex x="63.34" y="43.4"/>
<vertex x="63.56" y="42.61"/>
<vertex x="63.97" y="41.82"/>
<vertex x="64.57" y="41.04"/>
<vertex x="64.66" y="40.95"/>
<vertex x="65.33" y="40.28"/>
<vertex x="65.91" y="39.59"/>
<vertex x="66.2" y="38.92"/>
<vertex x="66.23" y="38.29"/>
<vertex x="66.03" y="37.72"/>
<vertex x="65.64" y="37.26"/>
<vertex x="65.1" y="36.92"/>
<vertex x="64.45" y="36.73"/>
<vertex x="63.72" y="36.73"/>
<vertex x="63.24" y="36.84"/>
<vertex x="62.84" y="37.01"/>
<vertex x="62.52" y="37.25"/>
<vertex x="62.28" y="37.52"/>
<vertex x="62.11" y="37.82"/>
<vertex x="62.03" y="38.12"/>
<vertex x="62.03" y="38.42"/>
<vertex x="62.11" y="38.69"/>
<vertex x="62.25" y="38.9"/>
<vertex x="62.43" y="39.08"/>
<vertex x="62.64" y="39.24"/>
<vertex x="62.86" y="39.38"/>
<vertex x="63.06" y="39.48"/>
<vertex x="63.23" y="39.56"/>
<vertex x="63.34" y="39.61"/>
<vertex x="63.39" y="39.63"/>
<vertex x="63.33" y="39.65"/>
<vertex x="63.19" y="39.69"/>
<vertex x="62.96" y="39.75"/>
<vertex x="62.65" y="39.8"/>
<vertex x="62.28" y="39.83"/>
<vertex x="61.86" y="39.81"/>
<vertex x="61.4" y="39.74"/>
<vertex x="60.91" y="39.59"/>
<vertex x="60.47" y="39.39"/>
<vertex x="60.06" y="39.13"/>
<vertex x="59.69" y="38.8"/>
<vertex x="59.37" y="38.39"/>
<vertex x="59.11" y="37.88"/>
<vertex x="58.93" y="37.26"/>
<vertex x="58.82" y="36.52"/>
<vertex x="58.8" y="35.66"/>
<vertex x="58.8" y="34.22"/>
<vertex x="58.8" y="32.77"/>
<vertex x="58.8" y="31.33"/>
<vertex x="58.8" y="29.89"/>
<vertex x="58.8" y="28.45"/>
<vertex x="58.8" y="27.01"/>
<vertex x="58.8" y="25.57"/>
<vertex x="58.8" y="24.12"/>
<vertex x="58.86" y="24.19"/>
<vertex x="59.02" y="24.39"/>
<vertex x="59.27" y="24.69"/>
<vertex x="59.6" y="25.09"/>
<vertex x="60" y="25.55"/>
<vertex x="60.46" y="26.07"/>
<vertex x="60.96" y="26.63"/>
<vertex x="61.5" y="27.21"/>
<vertex x="62.07" y="27.84"/>
<vertex x="62.59" y="28.41"/>
<vertex x="63.06" y="28.91"/>
<vertex x="63.51" y="29.33"/>
<vertex x="63.97" y="29.66"/>
<vertex x="64.45" y="29.89"/>
<vertex x="64.97" y="30.01"/>
<vertex x="65.56" y="30.02"/>
<vertex x="65.71" y="30.01"/>
<vertex x="66.71" y="30.02"/>
<vertex x="66.85" y="30.03"/>
<vertex x="67.78" y="30.16"/>
<vertex x="67.91" y="30.18"/>
<vertex x="68.77" y="30.43"/>
<vertex x="69.68" y="30.83"/>
<vertex x="70.52" y="31.35"/>
<vertex x="71.28" y="31.97"/>
<vertex x="71.98" y="32.69"/>
<vertex x="72.06" y="32.78"/>
<vertex x="72.6" y="33.49"/>
<vertex x="72.73" y="33.7"/>
<vertex x="73.48" y="35.14"/>
<vertex x="73.56" y="35.35"/>
<vertex x="73.93" y="36.78"/>
<vertex x="73.96" y="36.98"/>
<vertex x="74.01" y="38.36"/>
<vertex x="74" y="38.55"/>
<vertex x="73.79" y="39.82"/>
<vertex x="73.75" y="39.99"/>
<vertex x="73.34" y="41.1"/>
<vertex x="73.27" y="41.25"/>
<vertex x="72.72" y="42.16"/>
<vertex x="72.63" y="42.27"/>
<vertex x="71.99" y="42.93"/>
<vertex x="71.23" y="43.37"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_FLAME_1">
<vertex x="5.98" y="13.09"/>
<vertex x="6.05" y="12.51"/>
<vertex x="6.24" y="12.02"/>
<vertex x="6.53" y="11.61"/>
<vertex x="6.91" y="11.28"/>
<vertex x="7.36" y="11.03"/>
<vertex x="7.87" y="10.85"/>
<vertex x="8.41" y="10.75"/>
<vertex x="8.97" y="10.71"/>
<vertex x="9.39" y="10.73"/>
<vertex x="9.82" y="10.8"/>
<vertex x="10.25" y="10.92"/>
<vertex x="10.65" y="11.1"/>
<vertex x="10.99" y="11.34"/>
<vertex x="11.27" y="11.66"/>
<vertex x="11.44" y="12.04"/>
<vertex x="11.51" y="12.51"/>
<vertex x="11.43" y="12.92"/>
<vertex x="11.21" y="13.27"/>
<vertex x="10.84" y="13.57"/>
<vertex x="10.34" y="13.83"/>
<vertex x="9.71" y="14.07"/>
<vertex x="8.96" y="14.28"/>
<vertex x="8.09" y="14.49"/>
<vertex x="7.97" y="14.52"/>
<vertex x="7.11" y="14.7"/>
<vertex x="6.26" y="14.91"/>
<vertex x="5.45" y="15.16"/>
<vertex x="4.69" y="15.46"/>
<vertex x="4.01" y="15.84"/>
<vertex x="3.44" y="16.32"/>
<vertex x="3" y="16.9"/>
<vertex x="2.72" y="17.61"/>
<vertex x="2.62" y="18.48"/>
<vertex x="2.62" y="18.64"/>
<vertex x="2.76" y="19.71"/>
<vertex x="2.8" y="19.85"/>
<vertex x="3.16" y="20.71"/>
<vertex x="3.22" y="20.82"/>
<vertex x="3.77" y="21.5"/>
<vertex x="4.56" y="22.1"/>
<vertex x="4.67" y="22.16"/>
<vertex x="5.49" y="22.53"/>
<vertex x="5.62" y="22.58"/>
<vertex x="6.53" y="22.82"/>
<vertex x="6.67" y="22.84"/>
<vertex x="7.64" y="22.97"/>
<vertex x="7.78" y="22.98"/>
<vertex x="8.77" y="23.02"/>
<vertex x="8.92" y="23.02"/>
<vertex x="9.91" y="22.97"/>
<vertex x="10.05" y="22.95"/>
<vertex x="11" y="22.8"/>
<vertex x="11.13" y="22.77"/>
<vertex x="12.01" y="22.51"/>
<vertex x="12.13" y="22.46"/>
<vertex x="12.93" y="22.06"/>
<vertex x="13.71" y="21.46"/>
<vertex x="13.8" y="21.37"/>
<vertex x="14.34" y="20.68"/>
<vertex x="14.4" y="20.57"/>
<vertex x="14.78" y="19.7"/>
<vertex x="14.82" y="19.56"/>
<vertex x="15.01" y="18.51"/>
<vertex x="14.55" y="18.51"/>
<vertex x="14.09" y="18.51"/>
<vertex x="13.63" y="18.51"/>
<vertex x="13.16" y="18.51"/>
<vertex x="12.7" y="18.51"/>
<vertex x="12.24" y="18.51"/>
<vertex x="11.78" y="18.51"/>
<vertex x="11.32" y="18.51"/>
<vertex x="11.23" y="19.02"/>
<vertex x="11.05" y="19.44"/>
<vertex x="10.8" y="19.77"/>
<vertex x="10.47" y="20.03"/>
<vertex x="10.09" y="20.21"/>
<vertex x="9.65" y="20.33"/>
<vertex x="9.17" y="20.4"/>
<vertex x="8.66" y="20.42"/>
<vertex x="8.32" y="20.42"/>
<vertex x="7.96" y="20.38"/>
<vertex x="7.6" y="20.32"/>
<vertex x="7.26" y="20.2"/>
<vertex x="6.96" y="20.04"/>
<vertex x="6.72" y="19.81"/>
<vertex x="6.56" y="19.5"/>
<vertex x="6.5" y="19.11"/>
<vertex x="6.6" y="18.64"/>
<vertex x="6.88" y="18.26"/>
<vertex x="7.32" y="17.97"/>
<vertex x="7.88" y="17.73"/>
<vertex x="8.55" y="17.53"/>
<vertex x="9.3" y="17.35"/>
<vertex x="10.09" y="17.18"/>
<vertex x="10.91" y="17"/>
<vertex x="11.75" y="16.79"/>
<vertex x="12.56" y="16.53"/>
<vertex x="13.32" y="16.21"/>
<vertex x="14" y="15.81"/>
<vertex x="14.57" y="15.31"/>
<vertex x="15.01" y="14.69"/>
<vertex x="15.29" y="13.94"/>
<vertex x="15.39" y="13.04"/>
<vertex x="15.39" y="12.86"/>
<vertex x="15.24" y="11.76"/>
<vertex x="15.21" y="11.61"/>
<vertex x="14.83" y="10.7"/>
<vertex x="14.76" y="10.58"/>
<vertex x="14.19" y="9.84"/>
<vertex x="14.1" y="9.75"/>
<vertex x="13.36" y="9.18"/>
<vertex x="13.25" y="9.11"/>
<vertex x="12.38" y="8.69"/>
<vertex x="12.25" y="8.64"/>
<vertex x="11.29" y="8.36"/>
<vertex x="11.15" y="8.33"/>
<vertex x="10.13" y="8.17"/>
<vertex x="9.98" y="8.16"/>
<vertex x="8.94" y="8.11"/>
<vertex x="8.78" y="8.12"/>
<vertex x="7.71" y="8.18"/>
<vertex x="7.56" y="8.19"/>
<vertex x="6.53" y="8.37"/>
<vertex x="6.39" y="8.4"/>
<vertex x="5.43" y="8.7"/>
<vertex x="5.3" y="8.75"/>
<vertex x="4.43" y="9.2"/>
<vertex x="4.32" y="9.27"/>
<vertex x="3.59" y="9.87"/>
<vertex x="3.5" y="9.97"/>
<vertex x="2.93" y="10.73"/>
<vertex x="2.86" y="10.86"/>
<vertex x="2.48" y="11.8"/>
<vertex x="2.44" y="11.95"/>
<vertex x="2.29" y="13.09"/>
<vertex x="2.75" y="13.09"/>
<vertex x="3.21" y="13.09"/>
<vertex x="3.68" y="13.09"/>
<vertex x="4.14" y="13.09"/>
<vertex x="4.6" y="13.09"/>
<vertex x="5.06" y="13.09"/>
<vertex x="5.52" y="13.09"/>
</polygon>
<vertex x="27.05" y="13.1"/>
<vertex x="27.28" y="13.86"/>
<vertex x="27.41" y="14.67"/>
<vertex x="27.44" y="15.53"/>
<vertex x="31.33" y="15.42"/>
<vertex x="31.33" y="15.24"/>
<vertex x="31.23" y="14.02"/>
<vertex x="31.21" y="13.85"/>
<vertex x="30.94" y="12.68"/>
<vertex x="30.89" y="12.52"/>
<vertex x="30.46" y="11.45"/>
</polygon>
<vertex x="30.39" y="11.3"/>
<vertex x="29.78" y="10.35"/>
<vertex x="29.69" y="10.22"/>
<vertex x="28.91" y="9.43"/>
<vertex x="28.79" y="9.33"/>
<vertex x="27.84" y="8.73"/>
<vertex x="27.7" y="8.65"/>
<vertex x="26.58" y="8.27"/>
<vertex x="26.41" y="8.24"/>
<vertex x="25.12" y="8.12"/>
<vertex x="24.48" y="8.15"/>
<vertex x="23.87" y="8.25"/>
<vertex x="23.27" y="8.42"/>
<vertex x="22.71" y="8.66"/>
<vertex x="22.19" y="8.96"/>
<vertex x="21.71" y="9.33"/>
<vertex x="21.27" y="9.76"/>
<vertex x="20.88" y="10.25"/>
<vertex x="20.87" y="10.25"/>
<vertex x="20.86" y="10.25"/>
<vertex x="20.86" y="8.98"/>
<vertex x="20.86" y="7.7"/>
<vertex x="20.86" y="6.43"/>
<vertex x="20.86" y="5.16"/>
<vertex x="20.86" y="3.89"/>
<vertex x="20.86" y="2.61"/>
<vertex x="20.86" y="1.34"/>
<vertex x="20.86" y="0.07"/>
<vertex x="20.38" y="0.5"/>
<vertex x="19.89" y="0.93"/>
<vertex x="19.4" y="1.36"/>
<vertex x="18.92" y="1.8"/>
<vertex x="18.43" y="2.23"/>
<vertex x="17.95" y="2.66"/>
<vertex x="17.46" y="3.09"/>
<vertex x="16.98" y="3.52"/>
<vertex x="16.98" y="5.83"/>
<vertex x="16.98" y="8.14"/>
<vertex x="16.98" y="10.45"/>
<vertex x="16.98" y="12.75"/>
<vertex x="16.98" y="15.06"/>
<vertex x="16.98" y="17.37"/>
<vertex x="16.98" y="19.67"/>
<vertex x="16.98" y="21.98"/>
<vertex x="17.44" y="22.06"/>
<vertex x="17.9" y="22.15"/>
<vertex x="18.36" y="22.23"/>
<vertex x="18.82" y="22.31"/>
<vertex x="19.29" y="22.39"/>
<vertex x="19.75" y="22.47"/>
<vertex x="20.21" y="22.56"/>
<vertex x="20.67" y="22.64"/>
<vertex x="20.67" y="22.41"/>
<vertex x="20.67" y="22.19"/>
<vertex x="20.67" y="21.96"/>
<vertex x="20.67" y="21.74"/>
<vertex x="20.67" y="21.51"/>
<vertex x="20.67" y="21.28"/>
<vertex x="20.67" y="21.06"/>
<vertex x="20.67" y="20.83"/>
<vertex x="20.68" y="20.83"/>
<vertex x="20.69" y="20.83"/>
<vertex x="21.08" y="21.37"/>
<vertex x="21.51" y="21.82"/>
<vertex x="21.99" y="22.2"/>
<vertex x="22.5" y="22.5"/>
<vertex x="23.06" y="22.73"/>
<vertex x="23.64" y="22.89"/>
<vertex x="24.26" y="22.99"/>
<vertex x="24.91" y="23.02"/>
<vertex x="25.11" y="23.02"/>
<vertex x="26.45" y="22.86"/>
<vertex x="26.63" y="22.82"/>
<vertex x="27.78" y="22.4"/>
<vertex x="27.93" y="22.32"/>
<vertex x="28.89" y="21.68"/>
<vertex x="29.01" y="21.57"/>
<vertex x="29.78" y="20.73"/>
<vertex x="29.88" y="20.59"/>
<vertex x="30.47" y="19.59"/>
<vertex x="30.54" y="19.44"/>
<vertex x="30.95" y="18.3"/>
<vertex x="31" y="18.13"/>
<vertex x="31.24" y="16.9"/>
<vertex x="31.26" y="16.72"/>
<vertex x="27.4" y="16.37"/>
<vertex x="27.26" y="17.2"/>
<vertex x="27.03" y="17.97"/>
<vertex x="26.68" y="18.66"/>
<vertex x="26.22" y="19.25"/>
<vertex x="25.64" y="19.7"/>
<vertex x="24.92" y="19.99"/>
<vertex x="24.06" y="20.09"/>
<vertex x="23.18" y="19.99"/>
<vertex x="22.46" y="19.7"/>
<vertex x="21.87" y="19.25"/>
<vertex x="21.42" y="18.67"/>
<vertex x="21.09" y="17.98"/>
<vertex x="20.86" y="17.21"/>
<vertex x="20.73" y="16.38"/>
<vertex x="20.69" y="15.53"/>
<vertex x="20.74" y="14.67"/>
<vertex x="20.87" y="13.86"/>
<vertex x="21.1" y="13.1"/>
<vertex x="21.44" y="12.42"/>
<vertex x="21.9" y="11.86"/>
<vertex x="22.49" y="11.42"/>
<vertex x="23.22" y="11.14"/>
<vertex x="24.09" y="11.04"/>
<vertex x="24.96" y="11.14"/>
<vertex x="25.68" y="11.42"/>
<vertex x="26.27" y="11.86"/>
<vertex x="26.72" y="12.42"/>
</polygon>
<vertex x="37.24" y="16.61"/>
<vertex x="38.12" y="16.72"/>
<vertex x="38.97" y="16.82"/>
<vertex x="39.76" y="16.93"/>
<vertex x="40.23" y="14.83"/>
<vertex x="40" y="14.8"/>
<vertex x="39.78" y="14.76"/>
<vertex x="39.55" y="14.73"/>
<vertex x="39.31" y="14.69"/>
<vertex x="39.08" y="14.66"/>
<vertex x="38.85" y="14.62"/>
<vertex x="38.63" y="14.59"/>
<vertex x="38.4" y="14.54"/>
<vertex x="38.18" y="14.49"/>
<vertex x="37.97" y="14.44"/>
</polygon>
<vertex x="37.76" y="14.37"/>
<vertex x="37.56" y="14.29"/>
<vertex x="37.37" y="14.21"/>
<vertex x="37.19" y="14.11"/>
<vertex x="37.03" y="14"/>
<vertex x="36.87" y="13.87"/>
<vertex x="36.74" y="13.73"/>
<vertex x="36.62" y="13.57"/>
<vertex x="36.52" y="13.4"/>
<vertex x="36.44" y="13.21"/>
<vertex x="36.38" y="12.99"/>
<vertex x="36.34" y="12.76"/>
<vertex x="36.33" y="12.51"/>
<vertex x="36.34" y="12.25"/>
<vertex x="36.38" y="12.02"/>
<vertex x="36.44" y="11.81"/>
<vertex x="36.52" y="11.62"/>
<vertex x="36.63" y="11.46"/>
<vertex x="36.75" y="11.31"/>
<vertex x="36.89" y="11.18"/>
<vertex x="37.05" y="11.07"/>
<vertex x="37.22" y="10.97"/>
<vertex x="37.4" y="10.9"/>
<vertex x="37.6" y="10.83"/>
<vertex x="37.81" y="10.78"/>
<vertex x="38.02" y="10.74"/>
<vertex x="38.25" y="10.71"/>
<vertex x="38.47" y="10.71"/>
<vertex x="38.71" y="10.7"/>
<vertex x="39.24" y="10.73"/>
<vertex x="39.72" y="10.81"/>
<vertex x="40.13" y="10.93"/>
<vertex x="40.48" y="11.09"/>
<vertex x="40.78" y="11.29"/>
<vertex x="41.04" y="11.51"/>
<vertex x="41.25" y="11.75"/>
<vertex x="41.42" y="12.01"/>
<vertex x="41.55" y="12.28"/>
<vertex x="41.66" y="12.55"/>
<vertex x="41.74" y="12.82"/>
<vertex x="41.79" y="13.09"/>
<vertex x="41.82" y="13.34"/>
<vertex x="41.84" y="13.57"/>
<vertex x="41.85" y="13.78"/>
<vertex x="41.85" y="13.96"/>
<vertex x="41.85" y="14.05"/>
<vertex x="41.85" y="14.14"/>
<vertex x="41.85" y="14.23"/>
<vertex x="41.85" y="14.32"/>
<vertex x="41.85" y="14.41"/>
<vertex x="41.85" y="14.5"/>
<vertex x="41.85" y="14.59"/>
<vertex x="41.85" y="14.69"/>
<vertex x="41.85" y="14.78"/>
<vertex x="41.85" y="14.87"/>
<vertex x="41.85" y="14.96"/>
<vertex x="41.85" y="15.05"/>
<vertex x="41.85" y="15.14"/>
<vertex x="41.85" y="15.23"/>
<vertex x="41.85" y="15.32"/>
<vertex x="41.85" y="15.41"/>
<vertex x="41.72" y="15.31"/>
<vertex x="41.57" y="15.22"/>
<vertex x="41.41" y="15.14"/>
<vertex x="41.24" y="15.07"/>
<vertex x="41.05" y="15.01"/>
<vertex x="40.86" y="14.95"/>
<vertex x="40.65" y="14.9"/>
<vertex x="40.44" y="14.86"/>
<vertex x="40.46" y="17.1"/>
<vertex x="41.05" y="17.3"/>
<vertex x="41.5" y="17.58"/>
<vertex x="41.77" y="17.97"/>
<vertex x="41.85" y="18.49"/>
<vertex x="41.84" y="18.78"/>
<vertex x="41.8" y="19.05"/>
<vertex x="41.74" y="19.28"/>
<vertex x="41.66" y="19.48"/>
<vertex x="41.55" y="19.66"/>
<vertex x="41.42" y="19.82"/>
<vertex x="41.27" y="19.95"/>
<vertex x="41.11" y="20.07"/>
<vertex x="40.93" y="20.16"/>
<vertex x="40.74" y="20.24"/>
<vertex x="40.53" y="20.3"/>
<vertex x="40.31" y="20.34"/>
<vertex x="40.08" y="20.37"/>
<vertex x="39.84" y="20.39"/>
<vertex x="39.59" y="20.4"/>
<vertex x="39.34" y="20.4"/>
<vertex x="39.07" y="20.4"/>
<vertex x="38.8" y="20.37"/>
<vertex x="38.56" y="20.33"/>
<vertex x="38.32" y="20.28"/>
<vertex x="38.1" y="20.21"/>
<vertex x="37.9" y="20.13"/>
<vertex x="37.71" y="20.02"/>
<vertex x="37.54" y="19.9"/>
<vertex x="37.39" y="19.77"/>
<vertex x="37.25" y="19.61"/>
<vertex x="37.12" y="19.44"/>
<vertex x="37.02" y="19.24"/>
<vertex x="36.93" y="19.03"/>
<vertex x="36.86" y="18.79"/>
<vertex x="36.8" y="18.54"/>
<vertex x="36.77" y="18.26"/>
<vertex x="36.53" y="18.26"/>
<vertex x="36.28" y="18.26"/>
<vertex x="36.04" y="18.26"/>
<vertex x="35.8" y="18.26"/>
<vertex x="35.56" y="18.26"/>
<vertex x="35.32" y="18.26"/>
<vertex x="35.07" y="18.26"/>
<vertex x="34.83" y="18.26"/>
<vertex x="34.59" y="18.26"/>
<vertex x="34.35" y="18.26"/>
<vertex x="34.1" y="18.26"/>
<vertex x="33.86" y="18.26"/>
<vertex x="33.62" y="18.26"/>
<vertex x="33.38" y="18.26"/>
<vertex x="33.13" y="18.26"/>
<vertex x="32.89" y="18.26"/>
<vertex x="32.97" y="18.91"/>
<vertex x="33.11" y="19.5"/>
<vertex x="33.31" y="20.04"/>
<vertex x="33.58" y="20.52"/>
<vertex x="33.89" y="20.96"/>
<vertex x="34.25" y="21.35"/>
<vertex x="34.66" y="21.69"/>
<vertex x="35.11" y="21.98"/>
<vertex x="35.59" y="22.23"/>
<vertex x="36.1" y="22.45"/>
<vertex x="36.64" y="22.62"/>
<vertex x="37.19" y="22.76"/>
<vertex x="37.77" y="22.86"/>
<vertex x="38.35" y="22.94"/>
<vertex x="38.94" y="22.98"/>
<vertex x="39.54" y="22.99"/>
<vertex x="40.07" y="22.98"/>
<vertex x="40.61" y="22.95"/>
<vertex x="41.16" y="22.9"/>
<vertex x="41.7" y="22.83"/>
<vertex x="42.23" y="22.73"/>
<vertex x="42.74" y="22.61"/>
<vertex x="43.23" y="22.45"/>
<vertex x="43.7" y="22.25"/>
<vertex x="44.13" y="22.01"/>
<vertex x="44.53" y="21.73"/>
<vertex x="44.87" y="21.4"/>
<vertex x="45.17" y="21.02"/>
<vertex x="45.42" y="20.6"/>
<vertex x="45.6" y="20.11"/>
<vertex x="45.71" y="19.57"/>
<vertex x="45.75" y="18.97"/>
<vertex x="45.75" y="18.51"/>
<vertex x="45.75" y="18.05"/>
<vertex x="45.75" y="17.59"/>
<vertex x="45.75" y="17.13"/>
<vertex x="45.75" y="16.67"/>
<vertex x="45.75" y="16.21"/>
<vertex x="45.75" y="15.75"/>
<vertex x="45.75" y="15.29"/>
<vertex x="45.75" y="14.83"/>
<vertex x="45.75" y="14.37"/>
<vertex x="45.75" y="13.91"/>
<vertex x="45.75" y="13.45"/>
<vertex x="45.75" y="12.99"/>
<vertex x="45.75" y="12.53"/>
<vertex x="45.75" y="12.07"/>
<vertex x="45.75" y="11.61"/>
<vertex x="45.75" y="11.37"/>
<vertex x="45.75" y="11.13"/>
<vertex x="45.76" y="10.89"/>
<vertex x="45.76" y="10.66"/>
<vertex x="45.77" y="10.43"/>
<vertex x="45.79" y="10.2"/>
<vertex x="45.82" y="9.98"/>
<vertex x="45.85" y="9.77"/>
<vertex x="45.89" y="9.57"/>
<vertex x="45.92" y="9.37"/>
<vertex x="45.96" y="9.19"/>
<vertex x="46.01" y="9.02"/>
<vertex x="46.06" y="8.86"/>
<vertex x="46.11" y="8.71"/>
<vertex x="46.17" y="8.58"/>
<vertex x="46.23" y="8.47"/>
<vertex x="45.99" y="8.47"/>
<vertex x="45.74" y="8.47"/>
<vertex x="45.49" y="8.47"/>
<vertex x="45.25" y="8.47"/>
<vertex x="45" y="8.47"/>
<vertex x="44.76" y="8.47"/>
<vertex x="44.51" y="8.47"/>
<vertex x="44.27" y="8.47"/>
<vertex x="44.02" y="8.47"/>
<vertex x="43.77" y="8.47"/>
<vertex x="43.53" y="8.47"/>
<vertex x="43.28" y="8.47"/>
<vertex x="43.04" y="8.47"/>
<vertex x="42.79" y="8.47"/>
<vertex x="42.54" y="8.47"/>
<vertex x="42.3" y="8.47"/>
<vertex x="42.27" y="8.55"/>
<vertex x="42.24" y="8.63"/>
<vertex x="42.21" y="8.71"/>
<vertex x="42.18" y="8.8"/>
<vertex x="42.15" y="8.88"/>
<vertex x="42.13" y="8.97"/>
<vertex x="42.11" y="9.05"/>
<vertex x="42.09" y="9.14"/>
<vertex x="42.07" y="9.23"/>
<vertex x="42.06" y="9.31"/>
<vertex x="42.05" y="9.4"/>
<vertex x="42.05" y="9.49"/>
<vertex x="42.04" y="9.57"/>
<vertex x="42.03" y="9.66"/>
<vertex x="42.03" y="9.75"/>
<vertex x="42.03" y="9.83"/>
<vertex x="41.79" y="9.6"/>
<vertex x="41.54" y="9.39"/>
<vertex x="41.28" y="9.19"/>
<vertex x="41.01" y="9.02"/>
<vertex x="40.73" y="8.86"/>
<vertex x="40.44" y="8.71"/>
<vertex x="40.15" y="8.59"/>
<vertex x="39.84" y="8.48"/>
<vertex x="39.54" y="8.38"/>
<vertex x="39.22" y="8.3"/>
<vertex x="38.9" y="8.23"/>
<vertex x="38.58" y="8.18"/>
<vertex x="38.25" y="8.13"/>
<vertex x="37.93" y="8.1"/>
<vertex x="37.6" y="8.08"/>
<vertex x="37.27" y="8.08"/>
<vertex x="36.77" y="8.09"/>
<vertex x="36.29" y="8.13"/>
<vertex x="35.82" y="8.21"/>
<vertex x="35.38" y="8.33"/>
<vertex x="34.95" y="8.47"/>
<vertex x="34.56" y="8.65"/>
<vertex x="34.19" y="8.86"/>
<vertex x="33.85" y="9.1"/>
<vertex x="33.54" y="9.38"/>
<vertex x="33.27" y="9.7"/>
<vertex x="33.03" y="10.04"/>
<vertex x="32.83" y="10.43"/>
<vertex x="32.67" y="10.84"/>
<vertex x="32.55" y="11.3"/>
<vertex x="32.48" y="11.79"/>
<vertex x="32.45" y="12.31"/>
<vertex x="32.46" y="12.46"/>
<vertex x="32.57" y="13.41"/>
<vertex x="32.88" y="14.29"/>
<vertex x="33.35" y="14.99"/>
<vertex x="33.97" y="15.54"/>
<vertex x="34.69" y="15.95"/>
<vertex x="35.49" y="16.25"/>
<vertex x="36.35" y="16.46"/>
</polygon>
<vertex x="47.94" y="21.98"/>
<vertex x="48.4" y="22.06"/>
<vertex x="48.86" y="22.14"/>
<vertex x="49.32" y="22.22"/>
<vertex x="49.78" y="22.31"/>
<vertex x="50.24" y="22.39"/>
<vertex x="50.71" y="22.47"/>
<vertex x="51.17" y="22.55"/>
<vertex x="51.63" y="22.63"/>
<vertex x="51.63" y="22.3"/>
<vertex x="51.63" y="21.98"/>
<vertex x="51.63" y="21.65"/>
<vertex x="51.63" y="21.32"/>
<vertex x="51.63" y="20.99"/>
<vertex x="51.63" y="20.66"/>
<vertex x="51.63" y="20.33"/>
<vertex x="51.63" y="20.01"/>
<vertex x="51.64" y="20.01"/>
<vertex x="51.65" y="20.01"/>
<vertex x="51.98" y="20.65"/>
<vertex x="52.4" y="21.23"/>
<vertex x="52.89" y="21.74"/>
<vertex x="53.46" y="22.18"/>
<vertex x="54.08" y="22.53"/>
<vertex x="54.74" y="22.79"/>
<vertex x="55.44" y="22.96"/>
<vertex x="56.16" y="23.02"/>
<vertex x="56.28" y="23.01"/>
<vertex x="56.39" y="23.01"/>
<vertex x="56.49" y="23"/>
<vertex x="56.6" y="22.99"/>
<vertex x="56.7" y="22.97"/>
<vertex x="56.81" y="22.94"/>
<vertex x="56.91" y="22.91"/>
<vertex x="57.02" y="22.88"/>
<vertex x="57.02" y="22.43"/>
<vertex x="57.02" y="21.98"/>
<vertex x="57.02" y="21.53"/>
<vertex x="57.02" y="21.07"/>
<vertex x="57.02" y="20.62"/>
<vertex x="57.02" y="20.17"/>
<vertex x="57.02" y="19.72"/>
<vertex x="57.02" y="19.27"/>
<vertex x="56.87" y="19.3"/>
<vertex x="56.71" y="19.33"/>
<vertex x="56.54" y="19.36"/>
<vertex x="56.36" y="19.38"/>
<vertex x="56.17" y="19.39"/>
<vertex x="55.98" y="19.39"/>
<vertex x="55.8" y="19.4"/>
<vertex x="55.62" y="19.4"/>
<vertex x="54.63" y="19.31"/>
<vertex x="53.81" y="19.05"/>
<vertex x="53.15" y="18.63"/>
<vertex x="52.63" y="18.08"/>
<vertex x="52.24" y="17.41"/>
<vertex x="51.98" y="16.63"/>
<vertex x="51.84" y="15.78"/>
<vertex x="51.79" y="14.86"/>
<vertex x="51.79" y="14.07"/>
<vertex x="51.79" y="13.27"/>
<vertex x="51.79" y="12.47"/>
<vertex x="51.79" y="11.68"/>
<vertex x="51.79" y="10.88"/>
<vertex x="51.79" y="10.08"/>
<vertex x="51.79" y="9.29"/>
<vertex x="51.79" y="8.49"/>
<vertex x="51.3" y="8.49"/>
<vertex x="50.82" y="8.49"/>
<vertex x="50.33" y="8.49"/>
<vertex x="49.85" y="8.49"/>
<vertex x="49.36" y="8.49"/>
<vertex x="48.88" y="8.49"/>
<vertex x="48.39" y="8.49"/>
<vertex x="47.9" y="8.49"/>
<vertex x="47.9" y="10.18"/>
<vertex x="47.9" y="11.86"/>
<vertex x="47.9" y="13.55"/>
<vertex x="47.9" y="15.23"/>
<vertex x="47.9" y="16.92"/>
<vertex x="47.9" y="18.6"/>
<vertex x="47.9" y="20.29"/>
</polygon>
<vertex x="58.54" y="25.89"/>
<vertex x="62.43" y="28.02"/>
<vertex x="62.43" y="17.55"/>
<vertex x="67.32" y="22.64"/>
<vertex x="71.92" y="22.64"/>
<vertex x="66.58" y="17.44"/>
<vertex x="72.52" y="8.5"/>
<vertex x="67.81" y="8.5"/>
<vertex x="63.93" y="14.82"/>
<vertex x="62.43" y="13.36"/>
<vertex x="62.43" y="8.5"/>
<vertex x="58.54" y="8.5"/>
</polygon>
<vertex x="74.88" y="20.04"/>
<vertex x="74.4" y="20.04"/>
<vertex x="73.92" y="20.04"/>
<vertex x="73.44" y="20.04"/>
<vertex x="72.97" y="20.04"/>
<vertex x="72.49" y="20.04"/>
<vertex x="72.01" y="20.04"/>
<vertex x="71.53" y="20.04"/>
<vertex x="71.05" y="20.04"/>
<vertex x="71.38" y="20.36"/>
<vertex x="71.71" y="20.69"/>
<vertex x="72.04" y="21.01"/>
<vertex x="72.37" y="21.34"/>
<vertex x="72.7" y="21.66"/>
<vertex x="73.04" y="21.99"/>
<vertex x="73.37" y="22.31"/>
<vertex x="73.7" y="22.64"/>
<vertex x="73.84" y="22.64"/>
<vertex x="73.99" y="22.64"/>
<vertex x="74.14" y="22.64"/>
<vertex x="74.29" y="22.64"/>
<vertex x="74.44" y="22.64"/>
<vertex x="74.58" y="22.64"/>
<vertex x="74.73" y="22.64"/>
<vertex x="74.88" y="22.64"/>
<vertex x="74.88" y="22.77"/>
<vertex x="74.88" y="22.91"/>
<vertex x="74.88" y="23.04"/>
<vertex x="74.88" y="23.18"/>
<vertex x="74.88" y="23.32"/>
<vertex x="74.88" y="23.45"/>
<vertex x="74.88" y="23.59"/>
<vertex x="74.88" y="23.73"/>
<vertex x="74.95" y="24.63"/>
<vertex x="75.17" y="25.46"/>
<vertex x="75.54" y="26.19"/>
<vertex x="76.06" y="26.82"/>
<vertex x="76.72" y="27.33"/>
<vertex x="77.53" y="27.7"/>
<vertex x="78.5" y="27.94"/>
<vertex x="78.63" y="27.96"/>
<vertex x="79.61" y="28.02"/>
<vertex x="79.87" y="28.02"/>
<vertex x="80.13" y="28.01"/>
<vertex x="80.39" y="28"/>
<vertex x="80.65" y="27.98"/>
<vertex x="80.9" y="27.96"/>
<vertex x="81.16" y="27.94"/>
<vertex x="81.41" y="27.94"/>
<vertex x="81.66" y="27.93"/>
<vertex x="81.66" y="27.57"/>
<vertex x="81.66" y="27.2"/>
<vertex x="81.66" y="26.84"/>
<vertex x="81.66" y="26.48"/>
<vertex x="81.66" y="26.12"/>
<vertex x="81.66" y="25.75"/>
<vertex x="81.66" y="25.39"/>
<vertex x="81.66" y="25.03"/>
<vertex x="81.49" y="25.05"/>
<vertex x="81.31" y="25.07"/>
<vertex x="81.13" y="25.08"/>
<vertex x="80.95" y="25.08"/>
<vertex x="80.77" y="25.09"/>
<vertex x="80.59" y="25.09"/>
<vertex x="80.42" y="25.09"/>
<vertex x="80.24" y="25.1"/>
<vertex x="79.87" y="25.08"/>
<vertex x="79.56" y="25.01"/>
<vertex x="79.3" y="24.9"/>
<vertex x="79.1" y="24.73"/>
<vertex x="78.95" y="24.51"/>
<vertex x="78.84" y="24.23"/>
<vertex x="78.78" y="23.89"/>
<vertex x="78.76" y="23.48"/>
<vertex x="78.76" y="23.38"/>
<vertex x="78.76" y="23.27"/>
<vertex x="78.76" y="23.17"/>
<vertex x="78.76" y="23.06"/>
<vertex x="78.76" y="22.95"/>
<vertex x="78.76" y="22.85"/>
<vertex x="78.76" y="22.74"/>
<vertex x="78.76" y="22.64"/>
<vertex x="79.1" y="22.64"/>
<vertex x="79.43" y="22.64"/>
<vertex x="79.76" y="22.64"/>
<vertex x="80.1" y="22.64"/>
<vertex x="80.43" y="22.64"/>
<vertex x="80.77" y="22.64"/>
<vertex x="81.1" y="22.64"/>
<vertex x="81.44" y="22.64"/>
<vertex x="81.44" y="22.31"/>
<vertex x="81.44" y="21.99"/>
<vertex x="81.44" y="21.66"/>
<vertex x="81.44" y="21.34"/>
<vertex x="81.44" y="21.01"/>
<vertex x="81.44" y="20.69"/>
<vertex x="81.44" y="20.36"/>
<vertex x="81.44" y="20.04"/>
<vertex x="81.1" y="20.04"/>
<vertex x="80.77" y="20.04"/>
<vertex x="80.43" y="20.04"/>
<vertex x="80.1" y="20.04"/>
<vertex x="79.76" y="20.04"/>
<vertex x="79.43" y="20.04"/>
<vertex x="79.1" y="20.04"/>
<vertex x="78.76" y="20.04"/>
<vertex x="78.76" y="18.59"/>
<vertex x="78.76" y="17.15"/>
<vertex x="78.76" y="15.71"/>
<vertex x="78.76" y="14.27"/>
<vertex x="78.76" y="12.82"/>
<vertex x="78.76" y="11.38"/>
<vertex x="78.76" y="9.94"/>
<vertex x="78.76" y="8.5"/>
<vertex x="78.27" y="8.5"/>
<vertex x="77.79" y="8.5"/>
<vertex x="77.3" y="8.5"/>
<vertex x="76.82" y="8.5"/>
<vertex x="76.33" y="8.5"/>
<vertex x="75.85" y="8.5"/>
<vertex x="75.36" y="8.5"/>
<vertex x="74.88" y="8.5"/>
<vertex x="74.88" y="9.94"/>
<vertex x="74.88" y="11.38"/>
<vertex x="74.88" y="12.82"/>
<vertex x="74.88" y="14.27"/>
<vertex x="74.88" y="15.71"/>
<vertex x="74.88" y="17.15"/>
<vertex x="74.88" y="18.59"/>
</polygon>
<vertex x="95.8" y="8.5"/>
<vertex x="95.34" y="8.5"/>
<vertex x="94.87" y="8.5"/>
<vertex x="94.41" y="8.5"/>
<vertex x="93.95" y="8.5"/>
<vertex x="93.49" y="8.5"/>
<vertex x="93.03" y="8.5"/>
<vertex x="92.56" y="8.5"/>
<vertex x="92.1" y="8.5"/>
<vertex x="92.1" y="8.74"/>
<vertex x="92.1" y="8.99"/>
<vertex x="92.1" y="9.23"/>
<vertex x="92.1" y="9.48"/>
<vertex x="92.1" y="9.73"/>
<vertex x="92.1" y="9.97"/>
<vertex x="92.1" y="10.22"/>
<vertex x="92.1" y="10.46"/>
<vertex x="92.09" y="10.46"/>
<vertex x="92.08" y="10.46"/>
<vertex x="92.07" y="10.46"/>
<vertex x="92.06" y="10.46"/>
<vertex x="91.66" y="9.9"/>
<vertex x="91.2" y="9.42"/>
<vertex x="90.69" y="9.01"/>
<vertex x="90.14" y="8.68"/>
<vertex x="89.57" y="8.43"/>
<vertex x="88.97" y="8.25"/>
<vertex x="88.35" y="8.15"/>
<vertex x="87.74" y="8.11"/>
<vertex x="87.55" y="8.11"/>
<vertex x="86.33" y="8.22"/>
<vertex x="86.17" y="8.25"/>
<vertex x="85.19" y="8.53"/>
<vertex x="85.06" y="8.58"/>
<vertex x="84.29" y="9.03"/>
<vertex x="83.6" y="9.71"/>
<vertex x="83.12" y="10.55"/>
<vertex x="83.07" y="10.67"/>
<vertex x="82.8" y="11.55"/>
<vertex x="82.77" y="11.68"/>
<vertex x="82.62" y="12.68"/>
<vertex x="82.61" y="12.83"/>
<vertex x="82.57" y="13.94"/>
<vertex x="82.57" y="15.02"/>
<vertex x="82.57" y="16.11"/>
<vertex x="82.57" y="17.2"/>
<vertex x="82.57" y="18.28"/>
<vertex x="82.57" y="19.37"/>
<vertex x="82.57" y="20.46"/>
<vertex x="82.57" y="21.55"/>
<vertex x="82.57" y="22.63"/>
<vertex x="83.05" y="22.63"/>
<vertex x="83.54" y="22.63"/>
<vertex x="84.03" y="22.63"/>
<vertex x="84.51" y="22.63"/>
<vertex x="85" y="22.63"/>
<vertex x="85.48" y="22.63"/>
<vertex x="85.97" y="22.63"/>
<vertex x="86.45" y="22.63"/>
<vertex x="86.45" y="21.64"/>
<vertex x="86.45" y="20.64"/>
<vertex x="86.45" y="19.64"/>
<vertex x="86.45" y="18.64"/>
<vertex x="86.45" y="17.64"/>
<vertex x="86.45" y="16.65"/>
<vertex x="86.45" y="15.65"/>
<vertex x="86.45" y="14.65"/>
<vertex x="86.49" y="13.83"/>
<vertex x="86.59" y="13.13"/>
<vertex x="86.76" y="12.53"/>
<vertex x="87.01" y="12.04"/>
<vertex x="87.35" y="11.66"/>
<vertex x="87.78" y="11.39"/>
<vertex x="88.31" y="11.23"/>
<vertex x="88.94" y="11.18"/>
<vertex x="89.68" y="11.23"/>
<vertex x="90.3" y="11.4"/>
<vertex x="90.82" y="11.7"/>
<vertex x="91.24" y="12.12"/>
<vertex x="91.56" y="12.68"/>
<vertex x="91.78" y="13.38"/>
<vertex x="91.91" y="14.22"/>
<vertex x="91.95" y="15.22"/>
<vertex x="91.95" y="16.15"/>
<vertex x="91.95" y="17.07"/>
<vertex x="91.95" y="18"/>
<vertex x="91.95" y="18.93"/>
<vertex x="91.95" y="19.85"/>
<vertex x="91.95" y="20.78"/>
<vertex x="91.95" y="21.71"/>
<vertex x="91.95" y="22.63"/>
<vertex x="92.44" y="22.63"/>
<vertex x="92.92" y="22.63"/>
<vertex x="93.41" y="22.63"/>
<vertex x="93.89" y="22.63"/>
<vertex x="94.38" y="22.63"/>
<vertex x="94.87" y="22.63"/>
<vertex x="95.35" y="22.63"/>
<vertex x="95.84" y="22.63"/>
<vertex x="95.84" y="20.87"/>
<vertex x="95.84" y="19.1"/>
<vertex x="95.84" y="17.33"/>
<vertex x="95.84" y="15.56"/>
<vertex x="95.84" y="13.8"/>
<vertex x="95.84" y="12.03"/>
<vertex x="95.84" y="10.26"/>
</polygon>
<vertex x="97.94" y="22.64"/>
<vertex x="98.4" y="22.64"/>
<vertex x="98.86" y="22.64"/>
<vertex x="99.33" y="22.64"/>
<vertex x="99.79" y="22.64"/>
<vertex x="100.25" y="22.64"/>
<vertex x="100.71" y="22.64"/>
<vertex x="101.17" y="22.64"/>
<vertex x="101.63" y="22.64"/>
<vertex x="101.63" y="22.39"/>
<vertex x="101.63" y="22.14"/>
<vertex x="101.63" y="21.9"/>
<vertex x="101.63" y="21.65"/>
<vertex x="101.63" y="21.41"/>
<vertex x="101.63" y="21.16"/>
<vertex x="101.63" y="20.92"/>
<vertex x="101.63" y="20.67"/>
<vertex x="101.64" y="20.67"/>
<vertex x="101.65" y="20.67"/>
<vertex x="101.66" y="20.67"/>
<vertex x="101.67" y="20.67"/>
<vertex x="101.68" y="20.67"/>
<vertex x="102.08" y="21.23"/>
<vertex x="102.54" y="21.72"/>
<vertex x="103.04" y="22.12"/>
<vertex x="103.59" y="22.45"/>
<vertex x="104.17" y="22.7"/>
<vertex x="104.77" y="22.88"/>
<vertex x="105.38" y="22.99"/>
<vertex x="106" y="23.02"/>
<vertex x="106.19" y="23.02"/>
<vertex x="107.41" y="22.92"/>
<vertex x="107.56" y="22.89"/>
<vertex x="108.55" y="22.6"/>
<vertex x="108.67" y="22.55"/>
<vertex x="109.45" y="22.1"/>
<vertex x="110.13" y="21.42"/>
<vertex x="110.62" y="20.58"/>
<vertex x="110.67" y="20.46"/>
<vertex x="110.94" y="19.58"/>
<vertex x="110.97" y="19.45"/>
<vertex x="111.11" y="18.45"/>
<vertex x="111.13" y="18.3"/>
<vertex x="111.17" y="17.2"/>
<vertex x="111.17" y="16.11"/>
<vertex x="111.17" y="15.02"/>
<vertex x="111.17" y="13.94"/>
<vertex x="111.17" y="12.85"/>
<vertex x="111.17" y="11.76"/>
<vertex x="111.17" y="10.68"/>
<vertex x="111.17" y="9.59"/>
<vertex x="111.17" y="8.5"/>
<vertex x="110.68" y="8.5"/>
<vertex x="110.2" y="8.5"/>
<vertex x="109.71" y="8.5"/>
<vertex x="109.22" y="8.5"/>
<vertex x="108.74" y="8.5"/>
<vertex x="108.25" y="8.5"/>
<vertex x="107.77" y="8.5"/>
<vertex x="107.28" y="8.5"/>
<vertex x="107.28" y="9.5"/>
<vertex x="107.28" y="10.5"/>
<vertex x="107.28" y="11.5"/>
<vertex x="107.28" y="12.49"/>
<vertex x="107.28" y="13.49"/>
<vertex x="107.28" y="14.49"/>
<vertex x="107.28" y="15.49"/>
<vertex x="107.28" y="16.49"/>
<vertex x="107.25" y="17.3"/>
<vertex x="107.15" y="18.01"/>
<vertex x="106.97" y="18.61"/>
<vertex x="106.72" y="19.09"/>
<vertex x="106.38" y="19.47"/>
<vertex x="105.95" y="19.74"/>
<vertex x="105.42" y="19.91"/>
<vertex x="104.79" y="19.96"/>
<vertex x="104.06" y="19.9"/>
<vertex x="103.43" y="19.73"/>
<vertex x="102.92" y="19.44"/>
<vertex x="102.5" y="19.01"/>
<vertex x="102.18" y="18.45"/>
<vertex x="101.96" y="17.76"/>
<vertex x="101.83" y="16.91"/>
<vertex x="101.79" y="15.91"/>
<vertex x="101.79" y="14.98"/>
<vertex x="101.79" y="14.06"/>
<vertex x="101.79" y="13.13"/>
<vertex x="101.79" y="12.21"/>
<vertex x="101.79" y="11.28"/>
<vertex x="101.79" y="10.35"/>
<vertex x="101.79" y="9.43"/>
<vertex x="101.79" y="8.5"/>
<vertex x="101.3" y="8.5"/>
<vertex x="100.81" y="8.5"/>
<vertex x="100.33" y="8.5"/>
<vertex x="99.84" y="8.5"/>
<vertex x="99.36" y="8.5"/>
<vertex x="98.87" y="8.5"/>
<vertex x="98.39" y="8.5"/>
<vertex x="97.9" y="8.5"/>
<vertex x="97.9" y="10.27"/>
<vertex x="97.9" y="12.04"/>
<vertex x="97.9" y="13.8"/>
<vertex x="97.9" y="15.57"/>
<vertex x="97.9" y="17.34"/>
<vertex x="97.9" y="19.11"/>
<vertex x="97.9" y="20.87"/>
</polygon>
<vertex x="80.39" y="46.9"/>
<vertex x="80.39" y="46.84"/>
<vertex x="80.42" y="46.66"/>
<vertex x="80.43" y="46.41"/>
<vertex x="80.41" y="46.12"/>
<vertex x="80.34" y="45.81"/>
<vertex x="80.19" y="45.53"/>
<vertex x="79.95" y="45.3"/>
<vertex x="79.59" y="45.17"/>
<vertex x="79.26" y="45.16"/>
<vertex x="78.91" y="45.23"/>
<vertex x="78.54" y="45.36"/>
<vertex x="78.16" y="45.54"/>
<vertex x="77.78" y="45.78"/>
<vertex x="77.43" y="46.04"/>
<vertex x="77.11" y="46.32"/>
<vertex x="76.84" y="46.62"/>
<vertex x="76.58" y="46.98"/>
<vertex x="76.4" y="47.31"/>
<vertex x="76.3" y="47.64"/>
<vertex x="76.26" y="47.94"/>
<vertex x="76.3" y="48.24"/>
<vertex x="76.4" y="48.52"/>
<vertex x="76.55" y="48.79"/>
<vertex x="76.76" y="49.05"/>
<vertex x="77.14" y="49.37"/>
<vertex x="77.55" y="49.58"/>
<vertex x="77.97" y="49.7"/>
<vertex x="78.38" y="49.75"/>
<vertex x="78.74" y="49.75"/>
<vertex x="79.03" y="49.72"/>
<vertex x="79.23" y="49.69"/>
<vertex x="79.3" y="49.68"/>
<vertex x="79.17" y="49.79"/>
<vertex x="78.79" y="50.05"/>
<vertex x="78.21" y="50.39"/>
<vertex x="77.45" y="50.71"/>
<vertex x="76.54" y="50.93"/>
<vertex x="76.42" y="50.95"/>
<vertex x="75.53" y="50.97"/>
<vertex x="75.39" y="50.96"/>
<vertex x="74.43" y="50.74"/>
<vertex x="74.29" y="50.69"/>
<vertex x="73.3" y="50.15"/>
<vertex x="73.17" y="50.06"/>
<vertex x="72.44" y="49.42"/>
<vertex x="71.88" y="48.63"/>
<vertex x="71.61" y="47.81"/>
<vertex x="71.61" y="46.95"/>
<vertex x="71.85" y="46.08"/>
<vertex x="72.31" y="45.2"/>
<vertex x="72.38" y="45.1"/>
<vertex x="72.97" y="44.34"/>
<vertex x="73.07" y="44.23"/>
<vertex x="73.81" y="43.49"/>
<vertex x="73.91" y="43.39"/>
<vertex x="74.47" y="42.72"/>
<vertex x="74.78" y="41.98"/>
<vertex x="74.82" y="41.27"/>
<vertex x="74.59" y="40.65"/>
<vertex x="74.16" y="40.13"/>
<vertex x="73.56" y="39.75"/>
<vertex x="72.84" y="39.55"/>
<vertex x="72.03" y="39.54"/>
<vertex x="71.5" y="39.66"/>
<vertex x="71.05" y="39.86"/>
<vertex x="70.69" y="40.12"/>
<vertex x="70.42" y="40.42"/>
<vertex x="70.24" y="40.75"/>
<vertex x="70.15" y="41.09"/>
<vertex x="70.15" y="41.42"/>
<vertex x="70.24" y="41.72"/>
<vertex x="70.39" y="41.95"/>
<vertex x="70.6" y="42.16"/>
<vertex x="70.83" y="42.33"/>
<vertex x="71.07" y="42.48"/>
<vertex x="71.29" y="42.6"/>
<vertex x="71.48" y="42.69"/>
<vertex x="71.61" y="42.74"/>
<vertex x="71.66" y="42.77"/>
<vertex x="71.6" y="42.79"/>
<vertex x="71.44" y="42.84"/>
<vertex x="71.18" y="42.9"/>
<vertex x="70.84" y="42.95"/>
<vertex x="70.43" y="42.98"/>
<vertex x="69.96" y="42.96"/>
<vertex x="69.45" y="42.88"/>
<vertex x="68.91" y="42.72"/>
<vertex x="68.42" y="42.5"/>
<vertex x="67.97" y="42.22"/>
<vertex x="67.56" y="41.85"/>
<vertex x="67.2" y="41.38"/>
<vertex x="66.91" y="40.82"/>
<vertex x="66.7" y="40.13"/>
<vertex x="66.58" y="39.31"/>
<vertex x="66.56" y="38.35"/>
<vertex x="66.56" y="36.75"/>
<vertex x="66.56" y="35.15"/>
<vertex x="66.56" y="33.55"/>
<vertex x="66.56" y="31.94"/>
<vertex x="66.56" y="30.34"/>
<vertex x="66.56" y="28.74"/>
<vertex x="66.56" y="27.14"/>
<vertex x="66.56" y="25.54"/>
<vertex x="66.62" y="25.61"/>
<vertex x="66.8" y="25.83"/>
<vertex x="67.08" y="26.17"/>
<vertex x="67.46" y="26.61"/>
<vertex x="67.9" y="27.12"/>
<vertex x="68.41" y="27.7"/>
<vertex x="68.97" y="28.33"/>
<vertex x="69.56" y="28.97"/>
<vertex x="70.2" y="29.67"/>
<vertex x="70.77" y="30.3"/>
<vertex x="71.3" y="30.86"/>
<vertex x="71.8" y="31.32"/>
<vertex x="72.31" y="31.68"/>
<vertex x="72.84" y="31.94"/>
<vertex x="73.42" y="32.08"/>
<vertex x="74.08" y="32.08"/>
<vertex x="74.24" y="32.07"/>
<vertex x="75.35" y="32.08"/>
<vertex x="75.51" y="32.1"/>
<vertex x="76.54" y="32.24"/>
<vertex x="76.68" y="32.27"/>
<vertex x="77.64" y="32.55"/>
<vertex x="77.77" y="32.6"/>
<vertex x="78.66" y="32.99"/>
<vertex x="78.78" y="33.06"/>
<vertex x="79.59" y="33.56"/>
<vertex x="79.7" y="33.64"/>
<vertex x="80.44" y="34.25"/>
<vertex x="80.54" y="34.35"/>
<vertex x="81.2" y="35.05"/>
<vertex x="81.29" y="35.16"/>
<vertex x="81.89" y="35.95"/>
<vertex x="82.04" y="36.17"/>
<vertex x="82.19" y="36.4"/>
<vertex x="82.88" y="37.78"/>
<vertex x="82.96" y="38.01"/>
<vertex x="83.38" y="39.6"/>
<vertex x="83.41" y="39.83"/>
<vertex x="83.47" y="41.35"/>
<vertex x="83.45" y="41.57"/>
<vertex x="83.22" y="42.98"/>
<vertex x="83.17" y="43.17"/>
<vertex x="82.72" y="44.4"/>
<vertex x="82.64" y="44.57"/>
<vertex x="82.03" y="45.58"/>
<vertex x="81.93" y="45.7"/>
<vertex x="81.22" y="46.44"/>
<vertex x="80.38" y="46.92"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.1">
<polygon width="0" layer="21">
<vertex x="1.7" y="2.48"/>
<vertex x="1.7" y="2.46"/>
<vertex x="1.7" y="2.43"/>
<vertex x="1.7" y="2.4"/>
<vertex x="1.69" y="2.37"/>
<vertex x="1.68" y="2.35"/>
<vertex x="1.65" y="2.32"/>
<vertex x="1.62" y="2.31"/>
<vertex x="1.59" y="2.31"/>
<vertex x="1.55" y="2.32"/>
<vertex x="1.51" y="2.33"/>
<vertex x="1.47" y="2.35"/>
<vertex x="1.44" y="2.37"/>
<vertex x="1.4" y="2.4"/>
<vertex x="1.37" y="2.43"/>
<vertex x="1.34" y="2.46"/>
<vertex x="1.32" y="2.49"/>
<vertex x="1.3" y="2.52"/>
<vertex x="1.29" y="2.56"/>
<vertex x="1.29" y="2.59"/>
<vertex x="1.29" y="2.62"/>
<vertex x="1.3" y="2.65"/>
<vertex x="1.31" y="2.67"/>
<vertex x="1.33" y="2.7"/>
<vertex x="1.37" y="2.73"/>
<vertex x="1.41" y="2.75"/>
<vertex x="1.46" y="2.76"/>
<vertex x="1.5" y="2.77"/>
<vertex x="1.53" y="2.77"/>
<vertex x="1.56" y="2.77"/>
<vertex x="1.58" y="2.76"/>
<vertex x="1.59" y="2.76"/>
<vertex x="1.58" y="2.77"/>
<vertex x="1.54" y="2.8"/>
<vertex x="1.48" y="2.83"/>
<vertex x="1.4" y="2.87"/>
<vertex x="1.31" y="2.89"/>
<vertex x="1.21" y="2.89"/>
<vertex x="1.1" y="2.87"/>
<vertex x="0.99" y="2.81"/>
<vertex x="0.9" y="2.74"/>
<vertex x="0.85" y="2.66"/>
<vertex x="0.82" y="2.57"/>
<vertex x="0.82" y="2.49"/>
<vertex x="0.84" y="2.4"/>
<vertex x="0.89" y="2.31"/>
<vertex x="0.96" y="2.23"/>
<vertex x="1.04" y="2.14"/>
<vertex x="1.11" y="2.07"/>
<vertex x="1.14" y="1.99"/>
<vertex x="1.14" y="1.92"/>
<vertex x="1.12" y="1.86"/>
<vertex x="1.08" y="1.81"/>
<vertex x="1.02" y="1.77"/>
<vertex x="0.94" y="1.75"/>
<vertex x="0.86" y="1.75"/>
<vertex x="0.81" y="1.76"/>
<vertex x="0.76" y="1.78"/>
<vertex x="0.73" y="1.81"/>
<vertex x="0.7" y="1.84"/>
<vertex x="0.68" y="1.87"/>
<vertex x="0.67" y="1.9"/>
<vertex x="0.67" y="1.94"/>
<vertex x="0.68" y="1.97"/>
<vertex x="0.7" y="1.99"/>
<vertex x="0.72" y="2.01"/>
<vertex x="0.74" y="2.03"/>
<vertex x="0.77" y="2.04"/>
<vertex x="0.79" y="2.05"/>
<vertex x="0.81" y="2.06"/>
<vertex x="0.82" y="2.07"/>
<vertex x="0.8" y="2.08"/>
<vertex x="0.78" y="2.09"/>
<vertex x="0.74" y="2.09"/>
<vertex x="0.7" y="2.09"/>
<vertex x="0.66" y="2.09"/>
<vertex x="0.6" y="2.08"/>
<vertex x="0.55" y="2.07"/>
<vertex x="0.5" y="2.05"/>
<vertex x="0.46" y="2.02"/>
<vertex x="0.41" y="1.98"/>
<vertex x="0.38" y="1.93"/>
<vertex x="0.35" y="1.88"/>
<vertex x="0.33" y="1.81"/>
<vertex x="0.32" y="1.73"/>
<vertex x="0.32" y="1.63"/>
<vertex x="0.32" y="1.47"/>
<vertex x="0.32" y="1.31"/>
<vertex x="0.32" y="1.15"/>
<vertex x="0.32" y="0.99"/>
<vertex x="0.32" y="0.83"/>
<vertex x="0.32" y="0.67"/>
<vertex x="0.32" y="0.51"/>
<vertex x="0.32" y="0.35"/>
<vertex x="0.32" y="0.36"/>
<vertex x="0.34" y="0.38"/>
<vertex x="0.37" y="0.41"/>
<vertex x="0.4" y="0.46"/>
<vertex x="0.45" y="0.51"/>
<vertex x="0.5" y="0.57"/>
<vertex x="0.56" y="0.63"/>
<vertex x="0.62" y="0.69"/>
<vertex x="0.68" y="0.76"/>
<vertex x="0.74" y="0.83"/>
<vertex x="0.79" y="0.88"/>
<vertex x="0.84" y="0.93"/>
<vertex x="0.89" y="0.96"/>
<vertex x="0.94" y="0.99"/>
<vertex x="1" y="1"/>
<vertex x="1.07" y="1"/>
<vertex x="1.19" y="1"/>
<vertex x="1.31" y="1.02"/>
<vertex x="1.42" y="1.05"/>
<vertex x="1.52" y="1.09"/>
<vertex x="1.62" y="1.15"/>
<vertex x="1.7" y="1.22"/>
<vertex x="1.78" y="1.3"/>
<vertex x="1.85" y="1.39"/>
<vertex x="1.95" y="1.57"/>
<vertex x="2" y="1.76"/>
<vertex x="2.01" y="1.93"/>
<vertex x="1.98" y="2.09"/>
<vertex x="1.93" y="2.24"/>
<vertex x="1.86" y="2.35"/>
<vertex x="1.78" y="2.44"/>
<vertex x="1.7" y="2.49"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.2">
<vertex x="3.12" y="4.54"/>
<vertex x="3.12" y="4.53"/>
<vertex x="3.12" y="4.49"/>
<vertex x="3.13" y="4.44"/>
<vertex x="3.12" y="4.38"/>
<vertex x="3.11" y="4.32"/>
<vertex x="3.08" y="4.27"/>
<vertex x="3.03" y="4.22"/>
<vertex x="2.96" y="4.19"/>
<vertex x="2.89" y="4.19"/>
<vertex x="2.82" y="4.21"/>
<vertex x="2.75" y="4.23"/>
<vertex x="2.67" y="4.27"/>
<vertex x="2.6" y="4.32"/>
<vertex x="2.53" y="4.37"/>
<vertex x="2.46" y="4.43"/>
<vertex x="2.41" y="4.48"/>
<vertex x="2.36" y="4.56"/>
<vertex x="2.32" y="4.62"/>
<vertex x="2.3" y="4.69"/>
<vertex x="2.29" y="4.75"/>
<vertex x="2.3" y="4.81"/>
<vertex x="2.32" y="4.86"/>
<vertex x="2.35" y="4.92"/>
<vertex x="2.39" y="4.97"/>
<vertex x="2.47" y="5.04"/>
<vertex x="2.55" y="5.08"/>
<vertex x="2.63" y="5.1"/>
<vertex x="2.72" y="5.11"/>
<vertex x="2.79" y="5.11"/>
<vertex x="2.85" y="5.11"/>
<vertex x="2.89" y="5.1"/>
<vertex x="2.9" y="5.1"/>
<vertex x="2.87" y="5.12"/>
<vertex x="2.8" y="5.17"/>
<vertex x="2.68" y="5.24"/>
<vertex x="2.53" y="5.3"/>
<vertex x="2.35" y="5.35"/>
<vertex x="2.15" y="5.36"/>
<vertex x="1.93" y="5.31"/>
<vertex x="1.7" y="5.19"/>
<vertex x="1.53" y="5.05"/>
<vertex x="1.42" y="4.89"/>
<vertex x="1.36" y="4.72"/>
<vertex x="1.36" y="4.55"/>
<vertex x="1.41" y="4.38"/>
<vertex x="1.5" y="4.2"/>
<vertex x="1.63" y="4.03"/>
<vertex x="1.8" y="3.86"/>
<vertex x="1.93" y="3.71"/>
<vertex x="2" y="3.56"/>
<vertex x="2" y="3.42"/>
<vertex x="1.96" y="3.29"/>
<vertex x="1.87" y="3.19"/>
<vertex x="1.75" y="3.11"/>
<vertex x="1.61" y="3.07"/>
<vertex x="1.45" y="3.07"/>
<vertex x="1.34" y="3.1"/>
<vertex x="1.25" y="3.13"/>
<vertex x="1.18" y="3.19"/>
<vertex x="1.12" y="3.25"/>
<vertex x="1.09" y="3.31"/>
<vertex x="1.07" y="3.38"/>
<vertex x="1.07" y="3.45"/>
<vertex x="1.09" y="3.51"/>
<vertex x="1.12" y="3.55"/>
<vertex x="1.16" y="3.59"/>
<vertex x="1.21" y="3.63"/>
<vertex x="1.25" y="3.66"/>
<vertex x="1.3" y="3.68"/>
<vertex x="1.34" y="3.7"/>
<vertex x="1.36" y="3.71"/>
<vertex x="1.37" y="3.72"/>
<vertex x="1.36" y="3.72"/>
<vertex x="1.33" y="3.73"/>
<vertex x="1.28" y="3.75"/>
<vertex x="1.21" y="3.76"/>
<vertex x="1.13" y="3.76"/>
<vertex x="1.03" y="3.76"/>
<vertex x="0.93" y="3.74"/>
<vertex x="0.82" y="3.71"/>
<vertex x="0.72" y="3.67"/>
<vertex x="0.63" y="3.61"/>
<vertex x="0.55" y="3.53"/>
<vertex x="0.48" y="3.44"/>
<vertex x="0.42" y="3.33"/>
<vertex x="0.38" y="3.19"/>
<vertex x="0.36" y="3.03"/>
<vertex x="0.35" y="2.84"/>
<vertex x="0.35" y="2.51"/>
<vertex x="0.35" y="2.19"/>
<vertex x="0.35" y="1.87"/>
<vertex x="0.35" y="1.55"/>
<vertex x="0.35" y="1.23"/>
<vertex x="0.35" y="0.91"/>
<vertex x="0.35" y="0.59"/>
<vertex x="0.35" y="0.27"/>
<vertex x="0.36" y="0.29"/>
<vertex x="0.4" y="0.33"/>
<vertex x="0.46" y="0.4"/>
<vertex x="0.53" y="0.49"/>
<vertex x="0.62" y="0.59"/>
<vertex x="0.72" y="0.71"/>
<vertex x="0.83" y="0.83"/>
<vertex x="0.95" y="0.96"/>
<vertex x="1.08" y="1.1"/>
<vertex x="1.19" y="1.23"/>
<vertex x="1.3" y="1.34"/>
<vertex x="1.4" y="1.43"/>
<vertex x="1.5" y="1.5"/>
<vertex x="1.61" y="1.55"/>
<vertex x="1.72" y="1.58"/>
<vertex x="1.86" y="1.58"/>
<vertex x="2.11" y="1.58"/>
<vertex x="2.35" y="1.61"/>
<vertex x="2.57" y="1.67"/>
<vertex x="2.77" y="1.76"/>
<vertex x="2.96" y="1.88"/>
<vertex x="3.13" y="2.01"/>
<vertex x="3.28" y="2.17"/>
<vertex x="3.42" y="2.35"/>
<vertex x="3.61" y="2.72"/>
<vertex x="3.71" y="3.08"/>
<vertex x="3.73" y="3.43"/>
<vertex x="3.68" y="3.76"/>
<vertex x="3.58" y="4.04"/>
<vertex x="3.45" y="4.28"/>
<vertex x="3.28" y="4.45"/>
<vertex x="3.12" y="4.55"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.3">
<vertex x="4.65" y="6.54"/>
<vertex x="4.65" y="6.52"/>
<vertex x="4.66" y="6.47"/>
<vertex x="4.66" y="6.4"/>
<vertex x="4.66" y="6.31"/>
<vertex x="4.63" y="6.22"/>
<vertex x="4.59" y="6.13"/>
<vertex x="4.52" y="6.06"/>
<vertex x="4.41" y="6.02"/>
<vertex x="4.31" y="6.02"/>
<vertex x="4.2" y="6.04"/>
<vertex x="4.09" y="6.08"/>
<vertex x="3.98" y="6.14"/>
<vertex x="3.87" y="6.21"/>
<vertex x="3.76" y="6.28"/>
<vertex x="3.67" y="6.37"/>
<vertex x="3.58" y="6.46"/>
<vertex x="3.51" y="6.57"/>
<vertex x="3.45" y="6.67"/>
<vertex x="3.42" y="6.76"/>
<vertex x="3.41" y="6.86"/>
<vertex x="3.42" y="6.94"/>
<vertex x="3.45" y="7.03"/>
<vertex x="3.5" y="7.11"/>
<vertex x="3.56" y="7.19"/>
<vertex x="3.67" y="7.28"/>
<vertex x="3.8" y="7.35"/>
<vertex x="3.92" y="7.38"/>
<vertex x="4.05" y="7.4"/>
<vertex x="4.15" y="7.4"/>
<vertex x="4.24" y="7.39"/>
<vertex x="4.3" y="7.38"/>
<vertex x="4.32" y="7.38"/>
<vertex x="4.28" y="7.41"/>
<vertex x="4.17" y="7.49"/>
<vertex x="3.99" y="7.59"/>
<vertex x="3.77" y="7.69"/>
<vertex x="3.49" y="7.75"/>
<vertex x="3.19" y="7.77"/>
<vertex x="2.86" y="7.7"/>
<vertex x="2.52" y="7.52"/>
<vertex x="2.26" y="7.3"/>
<vertex x="2.1" y="7.06"/>
<vertex x="2.02" y="6.82"/>
<vertex x="2.02" y="6.56"/>
<vertex x="2.09" y="6.3"/>
<vertex x="2.23" y="6.04"/>
<vertex x="2.42" y="5.78"/>
<vertex x="2.68" y="5.52"/>
<vertex x="2.87" y="5.29"/>
<vertex x="2.97" y="5.07"/>
<vertex x="2.98" y="4.86"/>
<vertex x="2.91" y="4.67"/>
<vertex x="2.78" y="4.51"/>
<vertex x="2.6" y="4.4"/>
<vertex x="2.38" y="4.34"/>
<vertex x="2.14" y="4.34"/>
<vertex x="1.98" y="4.37"/>
<vertex x="1.85" y="4.43"/>
<vertex x="1.74" y="4.51"/>
<vertex x="1.66" y="4.6"/>
<vertex x="1.6" y="4.7"/>
<vertex x="1.58" y="4.8"/>
<vertex x="1.58" y="4.9"/>
<vertex x="1.6" y="4.99"/>
<vertex x="1.65" y="5.06"/>
<vertex x="1.71" y="5.12"/>
<vertex x="1.78" y="5.18"/>
<vertex x="1.85" y="5.22"/>
<vertex x="1.92" y="5.26"/>
<vertex x="1.98" y="5.28"/>
<vertex x="2.01" y="5.3"/>
<vertex x="2.03" y="5.31"/>
<vertex x="2.01" y="5.32"/>
<vertex x="1.96" y="5.33"/>
<vertex x="1.89" y="5.35"/>
<vertex x="1.78" y="5.37"/>
<vertex x="1.66" y="5.38"/>
<vertex x="1.52" y="5.37"/>
<vertex x="1.37" y="5.34"/>
<vertex x="1.2" y="5.29"/>
<vertex x="1.06" y="5.23"/>
<vertex x="0.92" y="5.14"/>
<vertex x="0.8" y="5.03"/>
<vertex x="0.69" y="4.89"/>
<vertex x="0.61" y="4.72"/>
<vertex x="0.54" y="4.52"/>
<vertex x="0.51" y="4.27"/>
<vertex x="0.5" y="3.98"/>
<vertex x="0.5" y="3.5"/>
<vertex x="0.5" y="3.02"/>
<vertex x="0.5" y="2.54"/>
<vertex x="0.5" y="2.06"/>
<vertex x="0.5" y="1.58"/>
<vertex x="0.5" y="1.1"/>
<vertex x="0.5" y="0.62"/>
<vertex x="0.5" y="0.14"/>
<vertex x="0.52" y="0.16"/>
<vertex x="0.57" y="0.23"/>
<vertex x="0.66" y="0.33"/>
<vertex x="0.77" y="0.46"/>
<vertex x="0.9" y="0.62"/>
<vertex x="1.05" y="0.79"/>
<vertex x="1.22" y="0.98"/>
<vertex x="1.4" y="1.17"/>
<vertex x="1.59" y="1.38"/>
<vertex x="1.76" y="1.57"/>
<vertex x="1.92" y="1.73"/>
<vertex x="2.07" y="1.87"/>
<vertex x="2.22" y="1.98"/>
<vertex x="2.38" y="2.06"/>
<vertex x="2.56" y="2.1"/>
<vertex x="2.75" y="2.1"/>
<vertex x="3.14" y="2.1"/>
<vertex x="3.49" y="2.15"/>
<vertex x="3.82" y="2.24"/>
<vertex x="4.13" y="2.37"/>
<vertex x="4.41" y="2.55"/>
<vertex x="4.66" y="2.75"/>
<vertex x="4.89" y="2.99"/>
<vertex x="5.1" y="3.26"/>
<vertex x="5.39" y="3.81"/>
<vertex x="5.54" y="4.36"/>
<vertex x="5.57" y="4.88"/>
<vertex x="5.5" y="5.37"/>
<vertex x="5.35" y="5.8"/>
<vertex x="5.14" y="6.15"/>
<vertex x="4.9" y="6.41"/>
<vertex x="4.64" y="6.55"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.4">
<vertex x="6.17" y="9.11"/>
<vertex x="6.18" y="9.09"/>
<vertex x="6.19" y="9.02"/>
<vertex x="6.19" y="8.92"/>
<vertex x="6.18" y="8.8"/>
<vertex x="6.16" y="8.68"/>
<vertex x="6.1" y="8.56"/>
<vertex x="6" y="8.47"/>
<vertex x="5.85" y="8.42"/>
<vertex x="5.72" y="8.42"/>
<vertex x="5.58" y="8.44"/>
<vertex x="5.43" y="8.5"/>
<vertex x="5.28" y="8.57"/>
<vertex x="5.13" y="8.66"/>
<vertex x="4.99" y="8.77"/>
<vertex x="4.86" y="8.88"/>
<vertex x="4.75" y="9"/>
<vertex x="4.65" y="9.14"/>
<vertex x="4.58" y="9.28"/>
<vertex x="4.54" y="9.41"/>
<vertex x="4.52" y="9.53"/>
<vertex x="4.54" y="9.65"/>
<vertex x="4.58" y="9.76"/>
<vertex x="4.64" y="9.87"/>
<vertex x="4.72" y="9.97"/>
<vertex x="4.87" y="10.1"/>
<vertex x="5.04" y="10.19"/>
<vertex x="5.21" y="10.23"/>
<vertex x="5.37" y="10.25"/>
<vertex x="5.52" y="10.25"/>
<vertex x="5.63" y="10.24"/>
<vertex x="5.71" y="10.23"/>
<vertex x="5.74" y="10.23"/>
<vertex x="5.69" y="10.27"/>
<vertex x="5.54" y="10.38"/>
<vertex x="5.3" y="10.51"/>
<vertex x="5" y="10.64"/>
<vertex x="4.64" y="10.73"/>
<vertex x="4.23" y="10.74"/>
<vertex x="3.79" y="10.65"/>
<vertex x="3.34" y="10.41"/>
<vertex x="2.99" y="10.12"/>
<vertex x="2.77" y="9.81"/>
<vertex x="2.66" y="9.48"/>
<vertex x="2.66" y="9.13"/>
<vertex x="2.76" y="8.79"/>
<vertex x="2.94" y="8.44"/>
<vertex x="3.21" y="8.09"/>
<vertex x="3.54" y="7.75"/>
<vertex x="3.81" y="7.44"/>
<vertex x="3.93" y="7.14"/>
<vertex x="3.95" y="6.86"/>
<vertex x="3.86" y="6.61"/>
<vertex x="3.68" y="6.41"/>
<vertex x="3.44" y="6.25"/>
<vertex x="3.15" y="6.17"/>
<vertex x="2.83" y="6.17"/>
<vertex x="2.62" y="6.22"/>
<vertex x="2.44" y="6.3"/>
<vertex x="2.3" y="6.4"/>
<vertex x="2.19" y="6.52"/>
<vertex x="2.12" y="6.66"/>
<vertex x="2.08" y="6.79"/>
<vertex x="2.08" y="6.92"/>
<vertex x="2.12" y="7.04"/>
<vertex x="2.18" y="7.14"/>
<vertex x="2.26" y="7.22"/>
<vertex x="2.35" y="7.29"/>
<vertex x="2.45" y="7.35"/>
<vertex x="2.54" y="7.4"/>
<vertex x="2.61" y="7.43"/>
<vertex x="2.66" y="7.45"/>
<vertex x="2.68" y="7.47"/>
<vertex x="2.66" y="7.48"/>
<vertex x="2.59" y="7.5"/>
<vertex x="2.49" y="7.52"/>
<vertex x="2.36" y="7.54"/>
<vertex x="2.19" y="7.56"/>
<vertex x="2" y="7.54"/>
<vertex x="1.8" y="7.51"/>
<vertex x="1.58" y="7.45"/>
<vertex x="1.39" y="7.36"/>
<vertex x="1.21" y="7.24"/>
<vertex x="1.04" y="7.1"/>
<vertex x="0.9" y="6.91"/>
<vertex x="0.78" y="6.69"/>
<vertex x="0.7" y="6.41"/>
<vertex x="0.65" y="6.08"/>
<vertex x="0.64" y="5.7"/>
<vertex x="0.64" y="5.06"/>
<vertex x="0.64" y="4.42"/>
<vertex x="0.64" y="3.78"/>
<vertex x="0.64" y="3.14"/>
<vertex x="0.64" y="2.5"/>
<vertex x="0.64" y="1.86"/>
<vertex x="0.64" y="1.21"/>
<vertex x="0.64" y="0.57"/>
<vertex x="0.67" y="0.6"/>
<vertex x="0.74" y="0.69"/>
<vertex x="0.85" y="0.83"/>
<vertex x="1.18" y="1.21"/>
<vertex x="1.38" y="1.44"/>
<vertex x="1.61" y="1.69"/>
<vertex x="1.84" y="1.95"/>
<vertex x="2.1" y="2.23"/>
<vertex x="2.33" y="2.48"/>
<vertex x="2.54" y="2.7"/>
<vertex x="2.74" y="2.89"/>
<vertex x="2.94" y="3.03"/>
<vertex x="3.15" y="3.14"/>
<vertex x="3.39" y="3.19"/>
<vertex x="3.65" y="3.19"/>
<vertex x="4.16" y="3.19"/>
<vertex x="4.64" y="3.25"/>
<vertex x="5.08" y="3.38"/>
<vertex x="5.48" y="3.55"/>
<vertex x="5.85" y="3.78"/>
<vertex x="6.19" y="4.06"/>
<vertex x="6.5" y="4.38"/>
<vertex x="6.78" y="4.74"/>
<vertex x="7.17" y="5.47"/>
<vertex x="7.37" y="6.2"/>
<vertex x="7.41" y="6.9"/>
<vertex x="7.31" y="7.55"/>
<vertex x="7.11" y="8.12"/>
<vertex x="6.83" y="8.59"/>
<vertex x="6.51" y="8.93"/>
<vertex x="6.17" y="9.12"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.5">
<vertex x="7.41" y="10.77"/>
<vertex x="7.42" y="10.74"/>
<vertex x="7.43" y="10.65"/>
<vertex x="7.44" y="10.53"/>
<vertex x="7.43" y="10.38"/>
<vertex x="7.39" y="10.23"/>
<vertex x="7.32" y="10.09"/>
<vertex x="7.19" y="9.97"/>
<vertex x="7.01" y="9.9"/>
<vertex x="6.85" y="9.9"/>
<vertex x="6.67" y="9.94"/>
<vertex x="6.49" y="10"/>
<vertex x="6.3" y="10.09"/>
<vertex x="6.11" y="10.21"/>
<vertex x="5.93" y="10.34"/>
<vertex x="5.78" y="10.48"/>
<vertex x="5.64" y="10.63"/>
<vertex x="5.51" y="10.81"/>
<vertex x="5.42" y="10.98"/>
<vertex x="5.37" y="11.14"/>
<vertex x="5.35" y="11.3"/>
<vertex x="5.37" y="11.44"/>
<vertex x="5.42" y="11.58"/>
<vertex x="5.49" y="11.72"/>
<vertex x="5.6" y="11.85"/>
<vertex x="5.79" y="12.01"/>
<vertex x="5.99" y="12.11"/>
<vertex x="6.21" y="12.17"/>
<vertex x="6.41" y="12.2"/>
<vertex x="6.59" y="12.2"/>
<vertex x="6.74" y="12.18"/>
<vertex x="6.83" y="12.17"/>
<vertex x="6.87" y="12.17"/>
<vertex x="6.8" y="12.22"/>
<vertex x="6.61" y="12.35"/>
<vertex x="6.32" y="12.52"/>
<vertex x="5.94" y="12.68"/>
<vertex x="5.49" y="12.79"/>
<vertex x="4.98" y="12.81"/>
<vertex x="4.44" y="12.69"/>
<vertex x="3.87" y="12.4"/>
<vertex x="3.44" y="12.03"/>
<vertex x="3.16" y="11.64"/>
<vertex x="3.03" y="11.23"/>
<vertex x="3.02" y="10.8"/>
<vertex x="3.14" y="10.36"/>
<vertex x="3.38" y="9.93"/>
<vertex x="3.71" y="9.49"/>
<vertex x="4.13" y="9.07"/>
<vertex x="4.45" y="8.69"/>
<vertex x="4.61" y="8.31"/>
<vertex x="4.63" y="7.96"/>
<vertex x="4.52" y="7.65"/>
<vertex x="4.3" y="7.39"/>
<vertex x="4" y="7.2"/>
<vertex x="3.64" y="7.1"/>
<vertex x="3.23" y="7.1"/>
<vertex x="2.97" y="7.16"/>
<vertex x="2.75" y="7.26"/>
<vertex x="2.57" y="7.39"/>
<vertex x="2.43" y="7.54"/>
<vertex x="2.34" y="7.7"/>
<vertex x="2.29" y="7.87"/>
<vertex x="2.29" y="8.04"/>
<vertex x="2.34" y="8.19"/>
<vertex x="2.42" y="8.3"/>
<vertex x="2.52" y="8.41"/>
<vertex x="2.63" y="8.49"/>
<vertex x="2.75" y="8.57"/>
<vertex x="2.87" y="8.63"/>
<vertex x="2.96" y="8.67"/>
<vertex x="3.02" y="8.7"/>
<vertex x="3.05" y="8.71"/>
<vertex x="3.02" y="8.73"/>
<vertex x="2.94" y="8.75"/>
<vertex x="2.81" y="8.78"/>
<vertex x="2.64" y="8.81"/>
<vertex x="2.43" y="8.83"/>
<vertex x="2.2" y="8.81"/>
<vertex x="1.95" y="8.77"/>
<vertex x="1.67" y="8.69"/>
<vertex x="1.43" y="8.58"/>
<vertex x="1.2" y="8.44"/>
<vertex x="1" y="8.25"/>
<vertex x="0.82" y="8.02"/>
<vertex x="0.68" y="7.74"/>
<vertex x="0.57" y="7.4"/>
<vertex x="0.51" y="6.99"/>
<vertex x="0.5" y="6.51"/>
<vertex x="0.5" y="5.71"/>
<vertex x="0.5" y="4.91"/>
<vertex x="0.5" y="4.1"/>
<vertex x="0.5" y="3.3"/>
<vertex x="0.5" y="2.5"/>
<vertex x="0.5" y="1.7"/>
<vertex x="0.5" y="0.9"/>
<vertex x="0.5" y="0.1"/>
<vertex x="0.53" y="0.14"/>
<vertex x="0.62" y="0.25"/>
<vertex x="0.76" y="0.41"/>
<vertex x="0.95" y="0.63"/>
<vertex x="1.17" y="0.89"/>
<vertex x="1.42" y="1.18"/>
<vertex x="1.7" y="1.49"/>
<vertex x="2" y="1.82"/>
<vertex x="2.32" y="2.17"/>
<vertex x="2.61" y="2.48"/>
<vertex x="2.87" y="2.76"/>
<vertex x="3.12" y="2.99"/>
<vertex x="3.37" y="3.17"/>
<vertex x="3.64" y="3.3"/>
<vertex x="3.93" y="3.37"/>
<vertex x="4.26" y="3.37"/>
<vertex x="4.9" y="3.37"/>
<vertex x="5.49" y="3.45"/>
<vertex x="6.04" y="3.6"/>
<vertex x="6.55" y="3.82"/>
<vertex x="7.01" y="4.11"/>
<vertex x="7.44" y="4.46"/>
<vertex x="7.82" y="4.85"/>
<vertex x="8.17" y="5.3"/>
<vertex x="8.24" y="5.42"/>
<vertex x="8.66" y="6.22"/>
<vertex x="8.91" y="7.13"/>
<vertex x="8.95" y="8.01"/>
<vertex x="8.83" y="8.82"/>
<vertex x="8.58" y="9.53"/>
<vertex x="8.23" y="10.12"/>
<vertex x="7.83" y="10.55"/>
<vertex x="7.41" y="10.79"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.6">
<vertex x="8.85" y="13.12"/>
<vertex x="8.86" y="13.08"/>
<vertex x="8.87" y="12.98"/>
<vertex x="8.88" y="12.83"/>
<vertex x="8.87" y="12.65"/>
<vertex x="8.82" y="12.47"/>
<vertex x="8.74" y="12.3"/>
<vertex x="8.59" y="12.16"/>
<vertex x="8.37" y="12.08"/>
<vertex x="8.18" y="12.08"/>
<vertex x="7.96" y="12.12"/>
<vertex x="7.74" y="12.2"/>
<vertex x="7.51" y="12.31"/>
<vertex x="7.29" y="12.45"/>
<vertex x="7.08" y="12.61"/>
<vertex x="6.89" y="12.78"/>
<vertex x="6.72" y="12.95"/>
<vertex x="6.57" y="13.17"/>
<vertex x="6.46" y="13.37"/>
<vertex x="6.4" y="13.57"/>
<vertex x="6.38" y="13.75"/>
<vertex x="6.4" y="13.93"/>
<vertex x="6.46" y="14.09"/>
<vertex x="6.55" y="14.26"/>
<vertex x="6.67" y="14.41"/>
<vertex x="6.9" y="14.61"/>
<vertex x="7.15" y="14.73"/>
<vertex x="7.4" y="14.8"/>
<vertex x="7.65" y="14.83"/>
<vertex x="7.86" y="14.83"/>
<vertex x="8.04" y="14.82"/>
<vertex x="8.16" y="14.8"/>
<vertex x="8.2" y="14.8"/>
<vertex x="8.12" y="14.86"/>
<vertex x="7.89" y="15.02"/>
<vertex x="7.54" y="15.22"/>
<vertex x="7.09" y="15.41"/>
<vertex x="6.54" y="15.54"/>
<vertex x="5.94" y="15.57"/>
<vertex x="5.28" y="15.43"/>
<vertex x="4.6" y="15.08"/>
<vertex x="4.08" y="14.64"/>
<vertex x="3.75" y="14.17"/>
<vertex x="3.59" y="13.67"/>
<vertex x="3.59" y="13.16"/>
<vertex x="3.73" y="12.63"/>
<vertex x="4.01" y="12.11"/>
<vertex x="4.4" y="11.59"/>
<vertex x="4.91" y="11.08"/>
<vertex x="5.3" y="10.62"/>
<vertex x="5.49" y="10.17"/>
<vertex x="5.51" y="9.75"/>
<vertex x="5.38" y="9.37"/>
<vertex x="5.12" y="9.06"/>
<vertex x="4.76" y="8.84"/>
<vertex x="4.32" y="8.71"/>
<vertex x="3.84" y="8.71"/>
<vertex x="3.52" y="8.78"/>
<vertex x="3.25" y="8.9"/>
<vertex x="3.04" y="9.06"/>
<vertex x="2.87" y="9.24"/>
<vertex x="2.76" y="9.44"/>
<vertex x="2.71" y="9.64"/>
<vertex x="2.71" y="9.84"/>
<vertex x="2.76" y="10.02"/>
<vertex x="2.85" y="10.16"/>
<vertex x="2.98" y="10.28"/>
<vertex x="3.12" y="10.39"/>
<vertex x="3.26" y="10.48"/>
<vertex x="3.4" y="10.55"/>
<vertex x="3.51" y="10.6"/>
<vertex x="3.59" y="10.64"/>
<vertex x="3.61" y="10.65"/>
<vertex x="3.58" y="10.67"/>
<vertex x="3.48" y="10.7"/>
<vertex x="3.33" y="10.74"/>
<vertex x="3.12" y="10.77"/>
<vertex x="2.88" y="10.79"/>
<vertex x="2.6" y="10.77"/>
<vertex x="2.29" y="10.72"/>
<vertex x="1.96" y="10.63"/>
<vertex x="1.67" y="10.5"/>
<vertex x="1.4" y="10.32"/>
<vertex x="1.15" y="10.1"/>
<vertex x="0.94" y="9.82"/>
<vertex x="0.77" y="9.48"/>
<vertex x="0.64" y="9.07"/>
<vertex x="0.57" y="8.58"/>
<vertex x="0.56" y="8"/>
<vertex x="0.56" y="7.04"/>
<vertex x="0.56" y="6.08"/>
<vertex x="0.56" y="5.12"/>
<vertex x="0.56" y="4.16"/>
<vertex x="0.56" y="3.2"/>
<vertex x="0.56" y="2.24"/>
<vertex x="0.56" y="1.28"/>
<vertex x="0.56" y="0.32"/>
<vertex x="0.59" y="0.36"/>
<vertex x="0.7" y="0.49"/>
<vertex x="0.87" y="0.69"/>
<vertex x="1.09" y="0.96"/>
<vertex x="1.36" y="1.27"/>
<vertex x="1.67" y="1.62"/>
<vertex x="2" y="1.99"/>
<vertex x="2.36" y="2.38"/>
<vertex x="2.74" y="2.8"/>
<vertex x="3.08" y="3.18"/>
<vertex x="3.4" y="3.51"/>
<vertex x="3.7" y="3.78"/>
<vertex x="4" y="4"/>
<vertex x="4.32" y="4.16"/>
<vertex x="4.67" y="4.24"/>
<vertex x="5.06" y="4.24"/>
<vertex x="5.83" y="4.24"/>
<vertex x="6.54" y="4.34"/>
<vertex x="7.2" y="4.52"/>
<vertex x="7.81" y="4.79"/>
<vertex x="8.37" y="5.13"/>
<vertex x="8.88" y="5.54"/>
<vertex x="9.34" y="6.02"/>
<vertex x="9.75" y="6.56"/>
<vertex x="9.85" y="6.7"/>
<vertex x="10.34" y="7.66"/>
<vertex x="10.4" y="7.8"/>
<vertex x="10.64" y="8.75"/>
<vertex x="10.66" y="8.89"/>
<vertex x="10.7" y="9.8"/>
<vertex x="10.55" y="10.78"/>
<vertex x="10.25" y="11.63"/>
<vertex x="9.83" y="12.34"/>
<vertex x="9.35" y="12.85"/>
<vertex x="8.84" y="13.14"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.7">
<vertex x="10.18" y="15.58"/>
<vertex x="10.18" y="15.54"/>
<vertex x="10.2" y="15.41"/>
<vertex x="10.21" y="15.24"/>
<vertex x="10.2" y="15.03"/>
<vertex x="10.15" y="14.82"/>
<vertex x="10.04" y="14.62"/>
<vertex x="9.87" y="14.46"/>
<vertex x="9.62" y="14.37"/>
<vertex x="9.39" y="14.37"/>
<vertex x="9.14" y="14.41"/>
<vertex x="8.88" y="14.5"/>
<vertex x="8.62" y="14.63"/>
<vertex x="8.35" y="14.8"/>
<vertex x="8.11" y="14.98"/>
<vertex x="7.89" y="15.18"/>
<vertex x="7.69" y="15.39"/>
<vertex x="7.51" y="15.64"/>
<vertex x="7.39" y="15.87"/>
<vertex x="7.31" y="16.1"/>
<vertex x="7.29" y="16.31"/>
<vertex x="7.31" y="16.52"/>
<vertex x="7.38" y="16.71"/>
<vertex x="7.49" y="16.9"/>
<vertex x="7.64" y="17.08"/>
<vertex x="7.9" y="17.31"/>
<vertex x="8.19" y="17.46"/>
<vertex x="8.49" y="17.54"/>
<vertex x="8.77" y="17.58"/>
<vertex x="9.03" y="17.58"/>
<vertex x="9.23" y="17.56"/>
<vertex x="9.37" y="17.53"/>
<vertex x="9.42" y="17.53"/>
<vertex x="9.32" y="17.61"/>
<vertex x="9.06" y="17.79"/>
<vertex x="8.65" y="18.03"/>
<vertex x="8.12" y="18.25"/>
<vertex x="7.49" y="18.41"/>
<vertex x="6.78" y="18.43"/>
<vertex x="6.01" y="18.27"/>
<vertex x="5.22" y="17.86"/>
<vertex x="4.61" y="17.35"/>
<vertex x="4.22" y="16.8"/>
<vertex x="4.04" y="16.22"/>
<vertex x="4.03" y="15.62"/>
<vertex x="4.2" y="15.01"/>
<vertex x="4.53" y="14.4"/>
<vertex x="4.99" y="13.79"/>
<vertex x="5.58" y="13.19"/>
<vertex x="6.03" y="12.66"/>
<vertex x="6.26" y="12.14"/>
<vertex x="6.28" y="11.65"/>
<vertex x="6.12" y="11.21"/>
<vertex x="5.82" y="10.85"/>
<vertex x="5.4" y="10.58"/>
<vertex x="4.89" y="10.44"/>
<vertex x="4.33" y="10.44"/>
<vertex x="3.96" y="10.52"/>
<vertex x="3.64" y="10.66"/>
<vertex x="3.39" y="10.84"/>
<vertex x="3.2" y="11.05"/>
<vertex x="3.08" y="11.28"/>
<vertex x="3.01" y="11.52"/>
<vertex x="3.01" y="11.75"/>
<vertex x="3.07" y="11.96"/>
<vertex x="3.18" y="12.12"/>
<vertex x="3.32" y="12.27"/>
<vertex x="3.49" y="12.39"/>
<vertex x="3.66" y="12.5"/>
<vertex x="3.81" y="12.58"/>
<vertex x="3.94" y="12.64"/>
<vertex x="4.03" y="12.68"/>
<vertex x="4.07" y="12.7"/>
<vertex x="4.03" y="12.72"/>
<vertex x="3.91" y="12.76"/>
<vertex x="3.73" y="12.8"/>
<vertex x="3.49" y="12.84"/>
<vertex x="3.21" y="12.86"/>
<vertex x="2.88" y="12.84"/>
<vertex x="2.52" y="12.78"/>
<vertex x="2.14" y="12.67"/>
<vertex x="1.8" y="12.52"/>
<vertex x="1.48" y="12.31"/>
<vertex x="1.2" y="12.06"/>
<vertex x="0.95" y="11.73"/>
<vertex x="0.75" y="11.33"/>
<vertex x="0.6" y="10.85"/>
<vertex x="0.51" y="10.28"/>
<vertex x="0.5" y="9.61"/>
<vertex x="0.5" y="8.49"/>
<vertex x="0.5" y="7.37"/>
<vertex x="0.5" y="6.25"/>
<vertex x="0.5" y="5.13"/>
<vertex x="0.5" y="4"/>
<vertex x="0.5" y="2.88"/>
<vertex x="0.5" y="1.76"/>
<vertex x="0.5" y="0.64"/>
<vertex x="0.54" y="0.69"/>
<vertex x="0.67" y="0.85"/>
<vertex x="0.87" y="1.08"/>
<vertex x="1.13" y="1.39"/>
<vertex x="1.44" y="1.75"/>
<vertex x="1.79" y="2.16"/>
<vertex x="2.18" y="2.59"/>
<vertex x="2.6" y="3.04"/>
<vertex x="3.05" y="3.53"/>
<vertex x="3.45" y="3.98"/>
<vertex x="3.82" y="4.36"/>
<vertex x="4.17" y="4.69"/>
<vertex x="4.52" y="4.94"/>
<vertex x="4.89" y="5.12"/>
<vertex x="5.3" y="5.22"/>
<vertex x="5.76" y="5.22"/>
<vertex x="6.65" y="5.22"/>
<vertex x="7.49" y="5.33"/>
<vertex x="8.26" y="5.54"/>
<vertex x="8.97" y="5.85"/>
<vertex x="9.62" y="6.25"/>
<vertex x="10.21" y="6.74"/>
<vertex x="10.75" y="7.3"/>
<vertex x="11.23" y="7.92"/>
<vertex x="11.34" y="8.08"/>
<vertex x="11.92" y="9.21"/>
<vertex x="11.98" y="9.37"/>
<vertex x="12.27" y="10.48"/>
<vertex x="12.29" y="10.64"/>
<vertex x="12.33" y="11.71"/>
<vertex x="12.32" y="11.86"/>
<vertex x="12.16" y="12.84"/>
<vertex x="12.13" y="12.98"/>
<vertex x="11.81" y="13.84"/>
<vertex x="11.32" y="14.67"/>
<vertex x="10.76" y="15.27"/>
<vertex x="10.17" y="15.6"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.8">
<vertex x="11.06" y="17.02"/>
<vertex x="11.06" y="16.96"/>
<vertex x="11.09" y="16.82"/>
<vertex x="11.1" y="16.62"/>
<vertex x="11.08" y="16.39"/>
<vertex x="11.02" y="16.14"/>
<vertex x="10.91" y="15.92"/>
<vertex x="10.71" y="15.74"/>
<vertex x="10.42" y="15.63"/>
<vertex x="10.16" y="15.63"/>
<vertex x="9.88" y="15.68"/>
<vertex x="9.58" y="15.78"/>
<vertex x="9.27" y="15.93"/>
<vertex x="8.98" y="16.12"/>
<vertex x="8.69" y="16.33"/>
<vertex x="8.44" y="16.56"/>
<vertex x="8.22" y="16.79"/>
<vertex x="8.01" y="17.08"/>
<vertex x="7.87" y="17.35"/>
<vertex x="7.79" y="17.61"/>
<vertex x="7.76" y="17.85"/>
<vertex x="7.79" y="18.09"/>
<vertex x="7.87" y="18.31"/>
<vertex x="7.99" y="18.53"/>
<vertex x="8.16" y="18.73"/>
<vertex x="8.46" y="18.99"/>
<vertex x="8.79" y="19.16"/>
<vertex x="9.13" y="19.26"/>
<vertex x="9.45" y="19.3"/>
<vertex x="9.74" y="19.3"/>
<vertex x="9.98" y="19.27"/>
<vertex x="10.13" y="19.25"/>
<vertex x="10.19" y="19.25"/>
<vertex x="10.08" y="19.33"/>
<vertex x="9.78" y="19.54"/>
<vertex x="9.32" y="19.81"/>
<vertex x="8.71" y="20.07"/>
<vertex x="7.98" y="20.24"/>
<vertex x="7.17" y="20.28"/>
<vertex x="6.3" y="20.09"/>
<vertex x="6.19" y="20.05"/>
<vertex x="5.39" y="19.62"/>
<vertex x="4.7" y="19.03"/>
<vertex x="4.26" y="18.41"/>
<vertex x="4.04" y="17.74"/>
<vertex x="4.04" y="17.06"/>
<vertex x="4.23" y="16.36"/>
<vertex x="4.6" y="15.66"/>
<vertex x="5.13" y="14.97"/>
<vertex x="5.8" y="14.29"/>
<vertex x="6.32" y="13.68"/>
<vertex x="6.58" y="13.08"/>
<vertex x="6.6" y="12.52"/>
<vertex x="6.43" y="12.02"/>
<vertex x="6.08" y="11.6"/>
<vertex x="5.6" y="11.3"/>
<vertex x="5.02" y="11.14"/>
<vertex x="4.37" y="11.14"/>
<vertex x="3.95" y="11.23"/>
<vertex x="3.59" y="11.39"/>
<vertex x="3.31" y="11.6"/>
<vertex x="3.09" y="11.84"/>
<vertex x="2.94" y="12.1"/>
<vertex x="2.87" y="12.37"/>
<vertex x="2.87" y="12.64"/>
<vertex x="2.94" y="12.88"/>
<vertex x="3.06" y="13.06"/>
<vertex x="3.23" y="13.23"/>
<vertex x="3.41" y="13.37"/>
<vertex x="3.61" y="13.49"/>
<vertex x="3.79" y="13.59"/>
<vertex x="3.93" y="13.66"/>
<vertex x="4.04" y="13.7"/>
<vertex x="4.08" y="13.72"/>
<vertex x="4.03" y="13.74"/>
<vertex x="3.9" y="13.79"/>
<vertex x="3.69" y="13.84"/>
<vertex x="3.42" y="13.88"/>
<vertex x="3.1" y="13.9"/>
<vertex x="2.72" y="13.88"/>
<vertex x="2.31" y="13.81"/>
<vertex x="1.88" y="13.69"/>
<vertex x="1.49" y="13.51"/>
<vertex x="1.12" y="13.28"/>
<vertex x="0.79" y="12.99"/>
<vertex x="0.51" y="12.62"/>
<vertex x="0.28" y="12.16"/>
<vertex x="0.11" y="11.61"/>
<vertex x="0.02" y="10.96"/>
<vertex x="0" y="10.19"/>
<vertex x="0" y="8.91"/>
<vertex x="0" y="7.63"/>
<vertex x="0" y="6.35"/>
<vertex x="0" y="5.07"/>
<vertex x="0" y="3.78"/>
<vertex x="0" y="2.5"/>
<vertex x="0" y="1.22"/>
<vertex x="0" y="-0.06"/>
<vertex x="0.05" y="0"/>
<vertex x="0.19" y="0.17"/>
<vertex x="0.42" y="0.44"/>
<vertex x="0.71" y="0.79"/>
<vertex x="1.07" y="1.21"/>
<vertex x="1.48" y="1.67"/>
<vertex x="1.92" y="2.17"/>
<vertex x="2.4" y="2.69"/>
<vertex x="2.91" y="3.25"/>
<vertex x="3.37" y="3.75"/>
<vertex x="3.79" y="4.19"/>
<vertex x="4.19" y="4.56"/>
<vertex x="4.6" y="4.86"/>
<vertex x="5.02" y="5.06"/>
<vertex x="5.49" y="5.17"/>
<vertex x="6.01" y="5.17"/>
<vertex x="6.14" y="5.16"/>
<vertex x="7.03" y="5.17"/>
<vertex x="7.98" y="5.3"/>
<vertex x="8.86" y="5.54"/>
<vertex x="9.68" y="5.9"/>
<vertex x="10.42" y="6.36"/>
<vertex x="11.1" y="6.91"/>
<vertex x="11.71" y="7.55"/>
<vertex x="12.26" y="8.26"/>
<vertex x="12.38" y="8.45"/>
<vertex x="13.05" y="9.73"/>
<vertex x="13.12" y="9.91"/>
<vertex x="13.45" y="11.19"/>
<vertex x="13.48" y="11.37"/>
<vertex x="13.52" y="12.59"/>
<vertex x="13.51" y="12.76"/>
<vertex x="13.33" y="13.89"/>
<vertex x="13.29" y="14.04"/>
<vertex x="12.92" y="15.03"/>
<vertex x="12.86" y="15.16"/>
<vertex x="12.37" y="15.97"/>
<vertex x="11.73" y="16.66"/>
<vertex x="11.05" y="17.04"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_.9">
<vertex x="12.72" y="19.45"/>
<vertex x="12.73" y="19.39"/>
<vertex x="12.76" y="19.23"/>
<vertex x="12.77" y="19"/>
<vertex x="12.75" y="18.74"/>
<vertex x="12.68" y="18.46"/>
<vertex x="12.55" y="18.21"/>
<vertex x="12.33" y="18.01"/>
<vertex x="12" y="17.88"/>
<vertex x="11.71" y="17.88"/>
<vertex x="11.4" y="17.94"/>
<vertex x="11.06" y="18.06"/>
<vertex x="10.72" y="18.23"/>
<vertex x="10.38" y="18.44"/>
<vertex x="10.06" y="18.67"/>
<vertex x="9.78" y="18.93"/>
<vertex x="9.53" y="19.19"/>
<vertex x="9.3" y="19.52"/>
<vertex x="9.14" y="19.82"/>
<vertex x="9.04" y="20.11"/>
<vertex x="9.01" y="20.39"/>
<vertex x="9.04" y="20.65"/>
<vertex x="9.13" y="20.9"/>
<vertex x="9.27" y="21.15"/>
<vertex x="9.46" y="21.38"/>
<vertex x="9.8" y="21.67"/>
<vertex x="10.17" y="21.86"/>
<vertex x="10.55" y="21.97"/>
<vertex x="10.92" y="22.01"/>
<vertex x="11.24" y="22.01"/>
<vertex x="11.51" y="21.99"/>
<vertex x="11.68" y="21.96"/>
<vertex x="11.75" y="21.96"/>
<vertex x="11.63" y="22.05"/>
<vertex x="11.29" y="22.29"/>
<vertex x="10.76" y="22.59"/>
<vertex x="10.08" y="22.88"/>
<vertex x="9.26" y="23.08"/>
<vertex x="8.35" y="23.11"/>
<vertex x="8.23" y="23.1"/>
<vertex x="7.37" y="22.91"/>
<vertex x="7.24" y="22.86"/>
<vertex x="6.34" y="22.38"/>
<vertex x="6.23" y="22.3"/>
<vertex x="5.57" y="21.72"/>
<vertex x="5.07" y="21.01"/>
<vertex x="4.83" y="20.27"/>
<vertex x="4.83" y="19.5"/>
<vertex x="5.04" y="18.71"/>
<vertex x="5.46" y="17.93"/>
<vertex x="6.05" y="17.14"/>
<vertex x="6.14" y="17.05"/>
<vertex x="6.81" y="16.38"/>
<vertex x="7.4" y="15.69"/>
<vertex x="7.68" y="15.02"/>
<vertex x="7.71" y="14.39"/>
<vertex x="7.51" y="13.82"/>
<vertex x="7.12" y="13.36"/>
<vertex x="6.59" y="13.02"/>
<vertex x="5.93" y="12.83"/>
<vertex x="5.2" y="12.83"/>
<vertex x="4.73" y="12.94"/>
<vertex x="4.33" y="13.12"/>
<vertex x="4" y="13.35"/>
<vertex x="3.76" y="13.62"/>
<vertex x="3.6" y="13.92"/>
<vertex x="3.51" y="14.22"/>
<vertex x="3.51" y="14.52"/>
<vertex x="3.59" y="14.79"/>
<vertex x="3.73" y="15"/>
<vertex x="3.91" y="15.19"/>
<vertex x="4.12" y="15.35"/>
<vertex x="4.34" y="15.48"/>
<vertex x="4.54" y="15.59"/>
<vertex x="4.71" y="15.67"/>
<vertex x="4.83" y="15.72"/>
<vertex x="4.87" y="15.74"/>
<vertex x="4.82" y="15.77"/>
<vertex x="4.67" y="15.81"/>
<vertex x="4.44" y="15.87"/>
<vertex x="4.13" y="15.92"/>
<vertex x="3.77" y="15.95"/>
<vertex x="3.35" y="15.92"/>
<vertex x="2.88" y="15.85"/>
<vertex x="2.39" y="15.7"/>
<vertex x="1.96" y="15.51"/>
<vertex x="1.55" y="15.25"/>
<vertex x="1.18" y="14.91"/>
<vertex x="0.86" y="14.5"/>
<vertex x="0.6" y="13.99"/>
<vertex x="0.41" y="13.37"/>
<vertex x="0.3" y="12.63"/>
<vertex x="0.28" y="11.77"/>
<vertex x="0.28" y="10.33"/>
<vertex x="0.28" y="8.89"/>
<vertex x="0.28" y="7.44"/>
<vertex x="0.28" y="6"/>
<vertex x="0.28" y="4.56"/>
<vertex x="0.28" y="3.12"/>
<vertex x="0.28" y="1.68"/>
<vertex x="0.28" y="0.24"/>
<vertex x="0.34" y="0.3"/>
<vertex x="0.5" y="0.5"/>
<vertex x="0.75" y="0.8"/>
<vertex x="1.09" y="1.2"/>
<vertex x="1.49" y="1.66"/>
<vertex x="1.95" y="2.19"/>
<vertex x="2.45" y="2.75"/>
<vertex x="2.98" y="3.33"/>
<vertex x="3.56" y="3.96"/>
<vertex x="4.07" y="4.53"/>
<vertex x="4.55" y="5.02"/>
<vertex x="5" y="5.44"/>
<vertex x="5.45" y="5.77"/>
<vertex x="5.93" y="6"/>
<vertex x="6.46" y="6.12"/>
<vertex x="7.05" y="6.12"/>
<vertex x="7.19" y="6.11"/>
<vertex x="8.2" y="6.12"/>
<vertex x="8.33" y="6.14"/>
<vertex x="9.26" y="6.27"/>
<vertex x="9.39" y="6.29"/>
<vertex x="10.26" y="6.54"/>
<vertex x="11.17" y="6.94"/>
<vertex x="12.01" y="7.46"/>
<vertex x="12.77" y="8.08"/>
<vertex x="13.46" y="8.79"/>
<vertex x="13.54" y="8.89"/>
<vertex x="14.08" y="9.6"/>
<vertex x="14.22" y="9.81"/>
<vertex x="14.96" y="11.25"/>
<vertex x="15.04" y="11.46"/>
<vertex x="15.41" y="12.89"/>
<vertex x="15.44" y="13.09"/>
<vertex x="15.5" y="14.47"/>
<vertex x="15.48" y="14.66"/>
<vertex x="15.28" y="15.93"/>
<vertex x="15.23" y="16.1"/>
<vertex x="14.82" y="17.21"/>
<vertex x="14.75" y="17.36"/>
<vertex x="14.2" y="18.27"/>
<vertex x="14.11" y="18.38"/>
<vertex x="13.48" y="19.04"/>
<vertex x="12.72" y="19.47"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_1">
<vertex x="14.32" y="21.65"/>
<vertex x="14.33" y="21.58"/>
<vertex x="14.36" y="21.4"/>
<vertex x="14.37" y="21.15"/>
<vertex x="14.35" y="20.86"/>
<vertex x="14.28" y="20.55"/>
<vertex x="14.13" y="20.27"/>
<vertex x="13.89" y="20.04"/>
<vertex x="13.52" y="19.91"/>
<vertex x="13.2" y="19.91"/>
<vertex x="12.85" y="19.97"/>
<vertex x="12.47" y="20.1"/>
<vertex x="12.09" y="20.29"/>
<vertex x="11.72" y="20.52"/>
<vertex x="11.37" y="20.78"/>
<vertex x="11.05" y="21.07"/>
<vertex x="10.78" y="21.36"/>
<vertex x="10.52" y="21.72"/>
<vertex x="10.34" y="22.06"/>
<vertex x="10.24" y="22.38"/>
<vertex x="10.2" y="22.69"/>
<vertex x="10.24" y="22.98"/>
<vertex x="10.33" y="23.26"/>
<vertex x="10.49" y="23.53"/>
<vertex x="10.7" y="23.79"/>
<vertex x="11.07" y="24.12"/>
<vertex x="11.49" y="24.33"/>
<vertex x="11.91" y="24.45"/>
<vertex x="12.32" y="24.5"/>
<vertex x="12.68" y="24.5"/>
<vertex x="12.97" y="24.47"/>
<vertex x="13.17" y="24.43"/>
<vertex x="13.24" y="24.43"/>
<vertex x="13.1" y="24.54"/>
<vertex x="12.73" y="24.8"/>
<vertex x="12.14" y="25.14"/>
<vertex x="11.38" y="25.46"/>
<vertex x="10.48" y="25.68"/>
<vertex x="10.36" y="25.7"/>
<vertex x="9.46" y="25.72"/>
<vertex x="9.33" y="25.71"/>
<vertex x="8.37" y="25.49"/>
<vertex x="8.23" y="25.44"/>
<vertex x="7.24" y="24.9"/>
<vertex x="7.11" y="24.81"/>
<vertex x="6.37" y="24.17"/>
<vertex x="5.82" y="23.38"/>
<vertex x="5.55" y="22.56"/>
<vertex x="5.55" y="21.7"/>
<vertex x="5.79" y="20.83"/>
<vertex x="6.25" y="19.95"/>
<vertex x="6.32" y="19.85"/>
<vertex x="6.91" y="19.09"/>
<vertex x="7.01" y="18.98"/>
<vertex x="7.75" y="18.24"/>
<vertex x="7.85" y="18.14"/>
<vertex x="8.4" y="17.47"/>
<vertex x="8.72" y="16.73"/>
<vertex x="8.75" y="16.02"/>
<vertex x="8.53" y="15.4"/>
<vertex x="8.1" y="14.88"/>
<vertex x="7.5" y="14.5"/>
<vertex x="6.78" y="14.3"/>
<vertex x="5.97" y="14.3"/>
<vertex x="5.44" y="14.41"/>
<vertex x="4.99" y="14.61"/>
<vertex x="4.63" y="14.87"/>
<vertex x="4.36" y="15.18"/>
<vertex x="4.18" y="15.5"/>
<vertex x="4.09" y="15.84"/>
<vertex x="4.09" y="16.17"/>
<vertex x="4.18" y="16.47"/>
<vertex x="4.33" y="16.71"/>
<vertex x="4.53" y="16.91"/>
<vertex x="4.77" y="17.09"/>
<vertex x="5.01" y="17.24"/>
<vertex x="5.23" y="17.36"/>
<vertex x="5.42" y="17.45"/>
<vertex x="5.55" y="17.5"/>
<vertex x="5.6" y="17.53"/>
<vertex x="5.54" y="17.56"/>
<vertex x="5.38" y="17.61"/>
<vertex x="5.12" y="17.67"/>
<vertex x="4.78" y="17.72"/>
<vertex x="4.37" y="17.75"/>
<vertex x="3.9" y="17.73"/>
<vertex x="3.39" y="17.64"/>
<vertex x="2.85" y="17.48"/>
<vertex x="2.36" y="17.27"/>
<vertex x="1.9" y="16.98"/>
<vertex x="1.49" y="16.61"/>
<vertex x="1.14" y="16.15"/>
<vertex x="0.85" y="15.58"/>
<vertex x="0.64" y="14.89"/>
<vertex x="0.52" y="14.08"/>
<vertex x="0.5" y="13.11"/>
<vertex x="0.5" y="11.51"/>
<vertex x="0.5" y="9.91"/>
<vertex x="0.5" y="8.31"/>
<vertex x="0.5" y="6.71"/>
<vertex x="0.5" y="5.11"/>
<vertex x="0.5" y="1.9"/>
<vertex x="0.5" y="0.3"/>
<vertex x="0.56" y="0.38"/>
<vertex x="0.74" y="0.59"/>
<vertex x="1.02" y="0.93"/>
<vertex x="1.39" y="1.37"/>
<vertex x="1.84" y="1.89"/>
<vertex x="2.35" y="2.47"/>
<vertex x="2.91" y="3.09"/>
<vertex x="3.5" y="3.73"/>
<vertex x="4.14" y="4.43"/>
<vertex x="4.71" y="5.07"/>
<vertex x="5.24" y="5.62"/>
<vertex x="5.74" y="6.08"/>
<vertex x="6.25" y="6.45"/>
<vertex x="6.78" y="6.7"/>
<vertex x="7.36" y="6.84"/>
<vertex x="8.01" y="6.84"/>
<vertex x="8.18" y="6.83"/>
<vertex x="9.29" y="6.84"/>
<vertex x="9.44" y="6.85"/>
<vertex x="10.48" y="7"/>
<vertex x="10.62" y="7.03"/>
<vertex x="11.58" y="7.31"/>
<vertex x="11.71" y="7.35"/>
<vertex x="12.59" y="7.75"/>
<vertex x="12.72" y="7.81"/>
<vertex x="13.52" y="8.32"/>
<vertex x="13.64" y="8.4"/>
<vertex x="14.37" y="9.01"/>
<vertex x="14.47" y="9.1"/>
<vertex x="15.14" y="9.81"/>
<vertex x="15.23" y="9.92"/>
<vertex x="15.83" y="10.71"/>
<vertex x="15.98" y="10.93"/>
<vertex x="16.12" y="11.16"/>
<vertex x="16.81" y="12.54"/>
<vertex x="16.9" y="12.77"/>
<vertex x="17.31" y="14.36"/>
<vertex x="17.35" y="14.58"/>
<vertex x="17.4" y="16.11"/>
<vertex x="17.39" y="16.32"/>
<vertex x="17.16" y="17.73"/>
<vertex x="17.11" y="17.92"/>
<vertex x="16.66" y="19.16"/>
<vertex x="16.58" y="19.32"/>
<vertex x="15.96" y="20.34"/>
<vertex x="15.87" y="20.46"/>
<vertex x="15.16" y="21.19"/>
<vertex x="14.31" y="21.67"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.1">
<vertex x="0.87" y="1.8"/>
<vertex x="0.88" y="1.74"/>
<vertex x="0.9" y="1.7"/>
<vertex x="0.92" y="1.65"/>
<vertex x="0.96" y="1.62"/>
<vertex x="1.01" y="1.6"/>
<vertex x="1.06" y="1.58"/>
<vertex x="1.11" y="1.57"/>
<vertex x="1.17" y="1.56"/>
<vertex x="1.21" y="1.57"/>
<vertex x="1.25" y="1.57"/>
<vertex x="1.3" y="1.59"/>
<vertex x="1.34" y="1.6"/>
<vertex x="1.37" y="1.63"/>
<vertex x="1.4" y="1.66"/>
<vertex x="1.42" y="1.7"/>
<vertex x="1.42" y="1.75"/>
<vertex x="1.41" y="1.79"/>
<vertex x="1.39" y="1.82"/>
<vertex x="1.36" y="1.85"/>
<vertex x="1.31" y="1.88"/>
<vertex x="1.24" y="1.9"/>
<vertex x="1.17" y="1.92"/>
<vertex x="1.08" y="1.94"/>
<vertex x="0.98" y="1.96"/>
<vertex x="0.9" y="1.99"/>
<vertex x="0.82" y="2.01"/>
<vertex x="0.74" y="2.04"/>
<vertex x="0.67" y="2.08"/>
<vertex x="0.62" y="2.13"/>
<vertex x="0.57" y="2.18"/>
<vertex x="0.54" y="2.26"/>
<vertex x="0.53" y="2.34"/>
<vertex x="0.55" y="2.47"/>
<vertex x="0.59" y="2.57"/>
<vertex x="0.65" y="2.64"/>
<vertex x="0.73" y="2.7"/>
<vertex x="0.82" y="2.75"/>
<vertex x="0.92" y="2.78"/>
<vertex x="1.03" y="2.79"/>
<vertex x="1.15" y="2.8"/>
<vertex x="1.26" y="2.79"/>
<vertex x="1.37" y="2.78"/>
<vertex x="1.47" y="2.75"/>
<vertex x="1.56" y="2.7"/>
<vertex x="1.64" y="2.64"/>
<vertex x="1.71" y="2.56"/>
<vertex x="1.75" y="2.46"/>
<vertex x="1.77" y="2.35"/>
<vertex x="1.73" y="2.35"/>
<vertex x="1.63" y="2.35"/>
<vertex x="1.59" y="2.35"/>
<vertex x="1.54" y="2.35"/>
<vertex x="1.5" y="2.35"/>
<vertex x="1.45" y="2.35"/>
<vertex x="1.4" y="2.35"/>
<vertex x="1.39" y="2.4"/>
<vertex x="1.38" y="2.44"/>
<vertex x="1.35" y="2.47"/>
<vertex x="1.32" y="2.5"/>
<vertex x="1.28" y="2.52"/>
<vertex x="1.24" y="2.53"/>
<vertex x="1.19" y="2.54"/>
<vertex x="1.14" y="2.54"/>
<vertex x="1.1" y="2.54"/>
<vertex x="1.07" y="2.53"/>
<vertex x="1.03" y="2.53"/>
<vertex x="1" y="2.52"/>
<vertex x="0.97" y="2.5"/>
<vertex x="0.94" y="2.48"/>
<vertex x="0.93" y="2.45"/>
<vertex x="0.92" y="2.41"/>
<vertex x="0.93" y="2.36"/>
<vertex x="0.96" y="2.32"/>
<vertex x="1" y="2.29"/>
<vertex x="1.06" y="2.27"/>
<vertex x="1.13" y="2.25"/>
<vertex x="1.2" y="2.23"/>
<vertex x="1.28" y="2.22"/>
<vertex x="1.36" y="2.2"/>
<vertex x="1.45" y="2.18"/>
<vertex x="1.53" y="2.15"/>
<vertex x="1.6" y="2.12"/>
<vertex x="1.67" y="2.08"/>
<vertex x="1.73" y="2.03"/>
<vertex x="1.77" y="1.97"/>
<vertex x="1.8" y="1.89"/>
<vertex x="1.81" y="1.8"/>
<vertex x="1.8" y="1.67"/>
<vertex x="1.75" y="1.57"/>
<vertex x="1.69" y="1.48"/>
<vertex x="1.61" y="1.42"/>
<vertex x="1.51" y="1.37"/>
<vertex x="1.4" y="1.33"/>
<vertex x="1.28" y="1.31"/>
<vertex x="1.16" y="1.31"/>
<vertex x="1.04" y="1.31"/>
<vertex x="0.92" y="1.33"/>
<vertex x="0.81" y="1.37"/>
<vertex x="0.71" y="1.42"/>
<vertex x="0.63" y="1.48"/>
<vertex x="0.56" y="1.57"/>
<vertex x="0.52" y="1.68"/>
<vertex x="0.5" y="1.8"/>
<vertex x="0.55" y="1.8"/>
<vertex x="0.59" y="1.8"/>
<vertex x="0.64" y="1.8"/>
<vertex x="0.68" y="1.8"/>
<vertex x="0.73" y="1.8"/>
<vertex x="0.78" y="1.8"/>
<vertex x="0.82" y="1.8"/>
</polygon>
<vertex x="2.98" y="1.8"/>
<vertex x="3" y="1.88"/>
<vertex x="3.01" y="1.96"/>
<vertex x="3.02" y="2.05"/>
<vertex x="3.4" y="2.04"/>
<vertex x="3.39" y="1.9"/>
<vertex x="3.37" y="1.76"/>
<vertex x="3.32" y="1.64"/>
</polygon>
<vertex x="3.25" y="1.53"/>
<vertex x="3.16" y="1.44"/>
<vertex x="3.06" y="1.37"/>
<vertex x="2.93" y="1.32"/>
<vertex x="2.78" y="1.31"/>
<vertex x="2.72" y="1.31"/>
<vertex x="2.66" y="1.32"/>
<vertex x="2.6" y="1.34"/>
<vertex x="2.54" y="1.36"/>
<vertex x="2.49" y="1.39"/>
<vertex x="2.44" y="1.43"/>
<vertex x="2.4" y="1.47"/>
<vertex x="2.36" y="1.52"/>
<vertex x="2.36" y="1.39"/>
<vertex x="2.36" y="1.26"/>
<vertex x="2.36" y="1.14"/>
<vertex x="2.36" y="1.01"/>
<vertex x="2.36" y="0.88"/>
<vertex x="2.36" y="0.75"/>
<vertex x="2.36" y="0.63"/>
<vertex x="2.36" y="0.5"/>
<vertex x="2.31" y="0.54"/>
<vertex x="2.26" y="0.59"/>
<vertex x="2.21" y="0.63"/>
<vertex x="2.16" y="0.67"/>
<vertex x="2.11" y="0.72"/>
<vertex x="2.07" y="0.76"/>
<vertex x="2.02" y="0.8"/>
<vertex x="1.97" y="0.85"/>
<vertex x="1.97" y="1.08"/>
<vertex x="1.97" y="1.31"/>
<vertex x="1.97" y="1.54"/>
<vertex x="1.97" y="1.77"/>
<vertex x="1.97" y="2"/>
<vertex x="1.97" y="2.23"/>
<vertex x="1.97" y="2.46"/>
<vertex x="1.97" y="2.69"/>
<vertex x="2.02" y="2.7"/>
<vertex x="2.06" y="2.71"/>
<vertex x="2.11" y="2.72"/>
<vertex x="2.15" y="2.72"/>
<vertex x="2.2" y="2.73"/>
<vertex x="2.25" y="2.74"/>
<vertex x="2.29" y="2.75"/>
<vertex x="2.34" y="2.76"/>
<vertex x="2.34" y="2.73"/>
<vertex x="2.34" y="2.71"/>
<vertex x="2.34" y="2.69"/>
<vertex x="2.34" y="2.67"/>
<vertex x="2.34" y="2.64"/>
<vertex x="2.34" y="2.62"/>
<vertex x="2.34" y="2.6"/>
<vertex x="2.34" y="2.58"/>
<vertex x="2.38" y="2.63"/>
<vertex x="2.42" y="2.68"/>
<vertex x="2.47" y="2.71"/>
<vertex x="2.52" y="2.74"/>
<vertex x="2.58" y="2.77"/>
<vertex x="2.64" y="2.78"/>
<vertex x="2.7" y="2.79"/>
<vertex x="2.76" y="2.8"/>
<vertex x="2.92" y="2.78"/>
<vertex x="3.05" y="2.73"/>
<vertex x="3.16" y="2.66"/>
<vertex x="3.25" y="2.57"/>
<vertex x="3.32" y="2.45"/>
<vertex x="3.37" y="2.32"/>
<vertex x="3.4" y="2.18"/>
<vertex x="3.01" y="2.13"/>
<vertex x="3" y="2.21"/>
<vertex x="2.97" y="2.29"/>
<vertex x="2.94" y="2.36"/>
<vertex x="2.89" y="2.42"/>
<vertex x="2.83" y="2.46"/>
<vertex x="2.76" y="2.49"/>
<vertex x="2.68" y="2.5"/>
<vertex x="2.59" y="2.49"/>
<vertex x="2.52" y="2.46"/>
<vertex x="2.46" y="2.42"/>
<vertex x="2.41" y="2.36"/>
<vertex x="2.38" y="2.29"/>
<vertex x="2.36" y="2.21"/>
<vertex x="2.34" y="2.13"/>
<vertex x="2.34" y="2.05"/>
<vertex x="2.34" y="1.96"/>
<vertex x="2.36" y="1.88"/>
<vertex x="2.38" y="1.8"/>
<vertex x="2.42" y="1.74"/>
<vertex x="2.46" y="1.68"/>
<vertex x="2.52" y="1.64"/>
<vertex x="2.59" y="1.61"/>
<vertex x="2.68" y="1.6"/>
<vertex x="2.77" y="1.61"/>
<vertex x="2.84" y="1.64"/>
<vertex x="2.9" y="1.68"/>
<vertex x="2.94" y="1.74"/>
</polygon>
<vertex x="3.99" y="2.15"/>
<vertex x="4.08" y="2.17"/>
<vertex x="4.17" y="2.18"/>
<vertex x="4.25" y="2.19"/>
<vertex x="4.29" y="1.98"/>
<vertex x="4.27" y="1.97"/>
<vertex x="4.25" y="1.97"/>
<vertex x="4.23" y="1.97"/>
<vertex x="4.2" y="1.96"/>
<vertex x="4.18" y="1.96"/>
<vertex x="4.16" y="1.96"/>
<vertex x="4.13" y="1.95"/>
<vertex x="4.11" y="1.95"/>
<vertex x="4.09" y="1.94"/>
<vertex x="4.07" y="1.94"/>
</polygon>
<vertex x="4.05" y="1.93"/>
<vertex x="4.03" y="1.92"/>
<vertex x="4.01" y="1.91"/>
<vertex x="3.99" y="1.9"/>
<vertex x="3.97" y="1.89"/>
<vertex x="3.96" y="1.88"/>
<vertex x="3.95" y="1.87"/>
<vertex x="3.93" y="1.85"/>
<vertex x="3.92" y="1.83"/>
<vertex x="3.91" y="1.81"/>
<vertex x="3.91" y="1.79"/>
<vertex x="3.91" y="1.77"/>
<vertex x="3.9" y="1.74"/>
<vertex x="3.91" y="1.72"/>
<vertex x="3.91" y="1.7"/>
<vertex x="3.92" y="1.67"/>
<vertex x="3.92" y="1.66"/>
<vertex x="3.93" y="1.64"/>
<vertex x="3.95" y="1.62"/>
<vertex x="3.96" y="1.61"/>
<vertex x="3.98" y="1.6"/>
<vertex x="3.99" y="1.59"/>
<vertex x="4.01" y="1.58"/>
<vertex x="4.03" y="1.58"/>
<vertex x="4.05" y="1.57"/>
<vertex x="4.07" y="1.57"/>
<vertex x="4.1" y="1.57"/>
<vertex x="4.12" y="1.57"/>
<vertex x="4.14" y="1.57"/>
<vertex x="4.2" y="1.57"/>
<vertex x="4.24" y="1.58"/>
<vertex x="4.28" y="1.59"/>
<vertex x="4.32" y="1.6"/>
<vertex x="4.35" y="1.62"/>
<vertex x="4.38" y="1.65"/>
<vertex x="4.4" y="1.67"/>
<vertex x="4.41" y="1.7"/>
<vertex x="4.43" y="1.72"/>
<vertex x="4.44" y="1.75"/>
<vertex x="4.44" y="1.78"/>
<vertex x="4.45" y="1.8"/>
<vertex x="4.45" y="1.83"/>
<vertex x="4.46" y="1.85"/>
<vertex x="4.46" y="1.87"/>
<vertex x="4.46" y="1.89"/>
<vertex x="4.46" y="1.9"/>
<vertex x="4.46" y="1.91"/>
<vertex x="4.46" y="1.92"/>
<vertex x="4.46" y="1.93"/>
<vertex x="4.46" y="1.94"/>
<vertex x="4.46" y="1.95"/>
<vertex x="4.46" y="1.96"/>
<vertex x="4.46" y="1.97"/>
<vertex x="4.46" y="1.98"/>
<vertex x="4.46" y="1.99"/>
<vertex x="4.46" y="2"/>
<vertex x="4.46" y="2.01"/>
<vertex x="4.46" y="2.02"/>
<vertex x="4.46" y="2.03"/>
<vertex x="4.46" y="2.04"/>
<vertex x="4.44" y="2.03"/>
<vertex x="4.43" y="2.02"/>
<vertex x="4.41" y="2.01"/>
<vertex x="4.4" y="2"/>
<vertex x="4.38" y="2"/>
<vertex x="4.36" y="1.99"/>
<vertex x="4.34" y="1.98"/>
<vertex x="4.32" y="1.98"/>
<vertex x="4.32" y="2.2"/>
<vertex x="4.38" y="2.22"/>
<vertex x="4.42" y="2.25"/>
<vertex x="4.45" y="2.29"/>
<vertex x="4.46" y="2.34"/>
<vertex x="4.46" y="2.37"/>
<vertex x="4.45" y="2.4"/>
<vertex x="4.45" y="2.42"/>
<vertex x="4.44" y="2.44"/>
<vertex x="4.43" y="2.46"/>
<vertex x="4.41" y="2.48"/>
<vertex x="4.4" y="2.49"/>
<vertex x="4.38" y="2.5"/>
<vertex x="4.36" y="2.51"/>
<vertex x="4.34" y="2.52"/>
<vertex x="4.32" y="2.52"/>
<vertex x="4.3" y="2.53"/>
<vertex x="4.28" y="2.53"/>
<vertex x="4.26" y="2.53"/>
<vertex x="4.23" y="2.53"/>
<vertex x="4.21" y="2.54"/>
<vertex x="4.18" y="2.53"/>
<vertex x="4.15" y="2.53"/>
<vertex x="4.13" y="2.53"/>
<vertex x="4.1" y="2.52"/>
<vertex x="4.08" y="2.52"/>
<vertex x="4.06" y="2.51"/>
<vertex x="4.04" y="2.5"/>
<vertex x="4.03" y="2.49"/>
<vertex x="4.01" y="2.47"/>
<vertex x="4" y="2.46"/>
<vertex x="3.98" y="2.44"/>
<vertex x="3.97" y="2.42"/>
<vertex x="3.96" y="2.4"/>
<vertex x="3.96" y="2.37"/>
<vertex x="3.95" y="2.35"/>
<vertex x="3.95" y="2.32"/>
<vertex x="3.92" y="2.32"/>
<vertex x="3.9" y="2.32"/>
<vertex x="3.88" y="2.32"/>
<vertex x="3.85" y="2.32"/>
<vertex x="3.83" y="2.32"/>
<vertex x="3.8" y="2.32"/>
<vertex x="3.78" y="2.32"/>
<vertex x="3.75" y="2.32"/>
<vertex x="3.73" y="2.32"/>
<vertex x="3.71" y="2.32"/>
<vertex x="3.68" y="2.32"/>
<vertex x="3.66" y="2.32"/>
<vertex x="3.63" y="2.32"/>
<vertex x="3.61" y="2.32"/>
<vertex x="3.58" y="2.32"/>
<vertex x="3.56" y="2.32"/>
<vertex x="3.57" y="2.39"/>
<vertex x="3.58" y="2.44"/>
<vertex x="3.6" y="2.5"/>
<vertex x="3.63" y="2.55"/>
<vertex x="3.66" y="2.59"/>
<vertex x="3.7" y="2.63"/>
<vertex x="3.74" y="2.66"/>
<vertex x="3.78" y="2.69"/>
<vertex x="3.83" y="2.72"/>
<vertex x="3.88" y="2.74"/>
<vertex x="3.93" y="2.76"/>
<vertex x="3.99" y="2.77"/>
<vertex x="4.05" y="2.78"/>
<vertex x="4.11" y="2.79"/>
<vertex x="4.17" y="2.79"/>
<vertex x="4.23" y="2.79"/>
<vertex x="4.28" y="2.79"/>
<vertex x="4.33" y="2.79"/>
<vertex x="4.39" y="2.78"/>
<vertex x="4.44" y="2.78"/>
<vertex x="4.49" y="2.77"/>
<vertex x="4.55" y="2.75"/>
<vertex x="4.59" y="2.74"/>
<vertex x="4.64" y="2.72"/>
<vertex x="4.68" y="2.7"/>
<vertex x="4.72" y="2.67"/>
<vertex x="4.76" y="2.63"/>
<vertex x="4.79" y="2.6"/>
<vertex x="4.81" y="2.55"/>
<vertex x="4.83" y="2.51"/>
<vertex x="4.84" y="2.45"/>
<vertex x="4.85" y="2.39"/>
<vertex x="4.85" y="2.35"/>
<vertex x="4.85" y="2.3"/>
<vertex x="4.85" y="2.25"/>
<vertex x="4.85" y="2.21"/>
<vertex x="4.85" y="2.16"/>
<vertex x="4.85" y="2.12"/>
<vertex x="4.85" y="2.07"/>
<vertex x="4.85" y="2.02"/>
<vertex x="4.85" y="1.98"/>
<vertex x="4.85" y="1.93"/>
<vertex x="4.85" y="1.89"/>
<vertex x="4.85" y="1.84"/>
<vertex x="4.85" y="1.79"/>
<vertex x="4.85" y="1.75"/>
<vertex x="4.85" y="1.7"/>
<vertex x="4.85" y="1.66"/>
<vertex x="4.85" y="1.63"/>
<vertex x="4.85" y="1.61"/>
<vertex x="4.85" y="1.58"/>
<vertex x="4.85" y="1.56"/>
<vertex x="4.85" y="1.54"/>
<vertex x="4.85" y="1.51"/>
<vertex x="4.85" y="1.49"/>
<vertex x="4.86" y="1.47"/>
<vertex x="4.86" y="1.45"/>
<vertex x="4.86" y="1.43"/>
<vertex x="4.87" y="1.41"/>
<vertex x="4.87" y="1.4"/>
<vertex x="4.88" y="1.38"/>
<vertex x="4.88" y="1.37"/>
<vertex x="4.89" y="1.35"/>
<vertex x="4.89" y="1.34"/>
<vertex x="4.87" y="1.34"/>
<vertex x="4.85" y="1.34"/>
<vertex x="4.82" y="1.34"/>
<vertex x="4.8" y="1.34"/>
<vertex x="4.77" y="1.34"/>
<vertex x="4.75" y="1.34"/>
<vertex x="4.72" y="1.34"/>
<vertex x="4.7" y="1.34"/>
<vertex x="4.67" y="1.34"/>
<vertex x="4.65" y="1.34"/>
<vertex x="4.62" y="1.34"/>
<vertex x="4.6" y="1.34"/>
<vertex x="4.57" y="1.34"/>
<vertex x="4.55" y="1.34"/>
<vertex x="4.53" y="1.34"/>
<vertex x="4.5" y="1.34"/>
<vertex x="4.5" y="1.35"/>
<vertex x="4.5" y="1.36"/>
<vertex x="4.49" y="1.37"/>
<vertex x="4.49" y="1.38"/>
<vertex x="4.48" y="1.39"/>
<vertex x="4.48" y="1.4"/>
<vertex x="4.48" y="1.41"/>
<vertex x="4.48" y="1.42"/>
<vertex x="4.48" y="1.43"/>
<vertex x="4.48" y="1.44"/>
<vertex x="4.48" y="1.45"/>
<vertex x="4.47" y="1.46"/>
<vertex x="4.47" y="1.47"/>
<vertex x="4.47" y="1.48"/>
<vertex x="4.45" y="1.46"/>
<vertex x="4.43" y="1.43"/>
<vertex x="4.4" y="1.41"/>
<vertex x="4.37" y="1.4"/>
<vertex x="4.34" y="1.38"/>
<vertex x="4.32" y="1.37"/>
<vertex x="4.29" y="1.35"/>
<vertex x="4.26" y="1.34"/>
<vertex x="4.22" y="1.33"/>
<vertex x="4.19" y="1.32"/>
<vertex x="4.16" y="1.32"/>
<vertex x="4.13" y="1.31"/>
<vertex x="4.1" y="1.31"/>
<vertex x="4.06" y="1.31"/>
<vertex x="4.03" y="1.3"/>
<vertex x="4" y="1.3"/>
<vertex x="3.95" y="1.3"/>
<vertex x="3.9" y="1.31"/>
<vertex x="3.85" y="1.31"/>
<vertex x="3.81" y="1.33"/>
<vertex x="3.77" y="1.34"/>
<vertex x="3.73" y="1.36"/>
<vertex x="3.69" y="1.38"/>
<vertex x="3.66" y="1.4"/>
<vertex x="3.63" y="1.43"/>
<vertex x="3.6" y="1.46"/>
<vertex x="3.57" y="1.5"/>
<vertex x="3.55" y="1.54"/>
<vertex x="3.54" y="1.58"/>
<vertex x="3.53" y="1.62"/>
<vertex x="3.52" y="1.67"/>
<vertex x="3.52" y="1.72"/>
<vertex x="3.53" y="1.83"/>
<vertex x="3.56" y="1.92"/>
<vertex x="3.61" y="1.99"/>
<vertex x="3.67" y="2.05"/>
<vertex x="3.74" y="2.09"/>
<vertex x="3.82" y="2.12"/>
<vertex x="3.91" y="2.14"/>
</polygon>
<vertex x="5.06" y="2.69"/>
<vertex x="5.11" y="2.7"/>
<vertex x="5.16" y="2.71"/>
<vertex x="5.2" y="2.72"/>
<vertex x="5.25" y="2.72"/>
<vertex x="5.3" y="2.73"/>
<vertex x="5.34" y="2.74"/>
<vertex x="5.39" y="2.75"/>
<vertex x="5.43" y="2.76"/>
<vertex x="5.43" y="2.72"/>
<vertex x="5.43" y="2.69"/>
<vertex x="5.43" y="2.66"/>
<vertex x="5.43" y="2.63"/>
<vertex x="5.43" y="2.59"/>
<vertex x="5.43" y="2.56"/>
<vertex x="5.43" y="2.53"/>
<vertex x="5.43" y="2.49"/>
<vertex x="5.44" y="2.49"/>
<vertex x="5.47" y="2.56"/>
<vertex x="5.51" y="2.62"/>
<vertex x="5.56" y="2.67"/>
<vertex x="5.62" y="2.71"/>
<vertex x="5.68" y="2.75"/>
<vertex x="5.75" y="2.77"/>
<vertex x="5.82" y="2.79"/>
<vertex x="5.89" y="2.79"/>
<vertex x="5.9" y="2.79"/>
<vertex x="5.91" y="2.79"/>
<vertex x="5.92" y="2.79"/>
<vertex x="5.93" y="2.79"/>
<vertex x="5.94" y="2.79"/>
<vertex x="5.95" y="2.79"/>
<vertex x="5.96" y="2.79"/>
<vertex x="5.97" y="2.78"/>
<vertex x="5.97" y="2.74"/>
<vertex x="5.97" y="2.69"/>
<vertex x="5.97" y="2.65"/>
<vertex x="5.97" y="2.6"/>
<vertex x="5.97" y="2.56"/>
<vertex x="5.97" y="2.51"/>
<vertex x="5.97" y="2.47"/>
<vertex x="5.97" y="2.42"/>
<vertex x="5.96" y="2.42"/>
<vertex x="5.94" y="2.43"/>
<vertex x="5.93" y="2.43"/>
<vertex x="5.91" y="2.43"/>
<vertex x="5.89" y="2.43"/>
<vertex x="5.87" y="2.43"/>
<vertex x="5.85" y="2.43"/>
<vertex x="5.83" y="2.43"/>
<vertex x="5.73" y="2.42"/>
<vertex x="5.65" y="2.4"/>
<vertex x="5.59" y="2.36"/>
<vertex x="5.53" y="2.3"/>
<vertex x="5.5" y="2.23"/>
<vertex x="5.47" y="2.16"/>
<vertex x="5.45" y="2.07"/>
<vertex x="5.45" y="1.98"/>
<vertex x="5.45" y="1.9"/>
<vertex x="5.45" y="1.82"/>
<vertex x="5.45" y="1.74"/>
<vertex x="5.45" y="1.66"/>
<vertex x="5.45" y="1.58"/>
<vertex x="5.45" y="1.5"/>
<vertex x="5.45" y="1.42"/>
<vertex x="5.45" y="1.34"/>
<vertex x="5.4" y="1.34"/>
<vertex x="5.35" y="1.34"/>
<vertex x="5.3" y="1.34"/>
<vertex x="5.26" y="1.34"/>
<vertex x="5.21" y="1.34"/>
<vertex x="5.16" y="1.34"/>
<vertex x="5.11" y="1.34"/>
<vertex x="5.06" y="1.34"/>
<vertex x="5.06" y="1.51"/>
<vertex x="5.06" y="1.68"/>
<vertex x="5.06" y="1.85"/>
<vertex x="5.06" y="2.02"/>
<vertex x="5.06" y="2.19"/>
<vertex x="5.06" y="2.35"/>
<vertex x="5.06" y="2.52"/>
</polygon>
<vertex x="6.13" y="3.08"/>
<vertex x="6.51" y="3.3"/>
<vertex x="6.51" y="2.25"/>
<vertex x="7" y="2.76"/>
<vertex x="7.46" y="2.76"/>
<vertex x="6.93" y="2.24"/>
<vertex x="7.52" y="1.34"/>
<vertex x="7.05" y="1.34"/>
<vertex x="6.66" y="1.98"/>
<vertex x="6.51" y="1.83"/>
<vertex x="6.51" y="1.34"/>
<vertex x="6.13" y="1.34"/>
</polygon>
<vertex x="7.76" y="2.5"/>
<vertex x="7.71" y="2.5"/>
<vertex x="7.66" y="2.5"/>
<vertex x="7.62" y="2.5"/>
<vertex x="7.57" y="2.5"/>
<vertex x="7.52" y="2.5"/>
<vertex x="7.47" y="2.5"/>
<vertex x="7.42" y="2.5"/>
<vertex x="7.38" y="2.5"/>
<vertex x="7.41" y="2.53"/>
<vertex x="7.44" y="2.56"/>
<vertex x="7.48" y="2.59"/>
<vertex x="7.51" y="2.63"/>
<vertex x="7.54" y="2.66"/>
<vertex x="7.57" y="2.69"/>
<vertex x="7.61" y="2.72"/>
<vertex x="7.64" y="2.76"/>
<vertex x="7.66" y="2.76"/>
<vertex x="7.67" y="2.76"/>
<vertex x="7.69" y="2.76"/>
<vertex x="7.7" y="2.76"/>
<vertex x="7.71" y="2.76"/>
<vertex x="7.73" y="2.76"/>
<vertex x="7.74" y="2.76"/>
<vertex x="7.76" y="2.76"/>
<vertex x="7.76" y="2.77"/>
<vertex x="7.76" y="2.78"/>
<vertex x="7.76" y="2.8"/>
<vertex x="7.76" y="2.81"/>
<vertex x="7.76" y="2.82"/>
<vertex x="7.76" y="2.84"/>
<vertex x="7.76" y="2.85"/>
<vertex x="7.76" y="2.87"/>
<vertex x="7.77" y="2.96"/>
<vertex x="7.79" y="3.04"/>
<vertex x="7.83" y="3.11"/>
<vertex x="7.88" y="3.17"/>
<vertex x="7.94" y="3.23"/>
<vertex x="8.02" y="3.26"/>
<vertex x="8.12" y="3.29"/>
<vertex x="8.23" y="3.3"/>
<vertex x="8.26" y="3.3"/>
<vertex x="8.28" y="3.3"/>
<vertex x="8.31" y="3.3"/>
<vertex x="8.34" y="3.29"/>
<vertex x="8.36" y="3.29"/>
<vertex x="8.39" y="3.29"/>
<vertex x="8.41" y="3.29"/>
<vertex x="8.44" y="3.29"/>
<vertex x="8.44" y="3.25"/>
<vertex x="8.44" y="3.21"/>
<vertex x="8.44" y="3.18"/>
<vertex x="8.44" y="3.14"/>
<vertex x="8.44" y="3.11"/>
<vertex x="8.44" y="3.07"/>
<vertex x="8.44" y="3.03"/>
<vertex x="8.44" y="3"/>
<vertex x="8.42" y="3"/>
<vertex x="8.4" y="3"/>
<vertex x="8.38" y="3"/>
<vertex x="8.37" y="3"/>
<vertex x="8.35" y="3"/>
<vertex x="8.33" y="3"/>
<vertex x="8.31" y="3"/>
<vertex x="8.3" y="3"/>
<vertex x="8.26" y="3"/>
<vertex x="8.23" y="2.99"/>
<vertex x="8.2" y="2.98"/>
<vertex x="8.18" y="2.97"/>
<vertex x="8.17" y="2.94"/>
<vertex x="8.16" y="2.92"/>
<vertex x="8.15" y="2.88"/>
<vertex x="8.15" y="2.84"/>
<vertex x="8.15" y="2.83"/>
<vertex x="8.15" y="2.82"/>
<vertex x="8.15" y="2.81"/>
<vertex x="8.15" y="2.8"/>
<vertex x="8.15" y="2.79"/>
<vertex x="8.15" y="2.78"/>
<vertex x="8.15" y="2.77"/>
<vertex x="8.15" y="2.76"/>
<vertex x="8.18" y="2.76"/>
<vertex x="8.21" y="2.76"/>
<vertex x="8.25" y="2.76"/>
<vertex x="8.28" y="2.76"/>
<vertex x="8.31" y="2.76"/>
<vertex x="8.35" y="2.76"/>
<vertex x="8.38" y="2.76"/>
<vertex x="8.42" y="2.76"/>
<vertex x="8.42" y="2.72"/>
<vertex x="8.42" y="2.69"/>
<vertex x="8.42" y="2.66"/>
<vertex x="8.42" y="2.63"/>
<vertex x="8.42" y="2.59"/>
<vertex x="8.42" y="2.56"/>
<vertex x="8.42" y="2.53"/>
<vertex x="8.42" y="2.5"/>
<vertex x="8.38" y="2.5"/>
<vertex x="8.35" y="2.5"/>
<vertex x="8.31" y="2.5"/>
<vertex x="8.28" y="2.5"/>
<vertex x="8.25" y="2.5"/>
<vertex x="8.21" y="2.5"/>
<vertex x="8.18" y="2.5"/>
<vertex x="8.15" y="2.5"/>
<vertex x="8.15" y="2.35"/>
<vertex x="8.15" y="2.21"/>
<vertex x="8.15" y="2.06"/>
<vertex x="8.15" y="1.92"/>
<vertex x="8.15" y="1.78"/>
<vertex x="8.15" y="1.63"/>
<vertex x="8.15" y="1.49"/>
<vertex x="8.15" y="1.34"/>
<vertex x="8.1" y="1.34"/>
<vertex x="8.05" y="1.34"/>
<vertex x="8" y="1.34"/>
<vertex x="7.95" y="1.34"/>
<vertex x="7.9" y="1.34"/>
<vertex x="7.86" y="1.34"/>
<vertex x="7.81" y="1.34"/>
<vertex x="7.76" y="1.34"/>
<vertex x="7.76" y="1.49"/>
<vertex x="7.76" y="1.63"/>
<vertex x="7.76" y="1.78"/>
<vertex x="7.76" y="1.92"/>
<vertex x="7.76" y="2.06"/>
<vertex x="7.76" y="2.21"/>
<vertex x="7.76" y="2.35"/>
</polygon>
<vertex x="9.85" y="1.34"/>
<vertex x="9.8" y="1.34"/>
<vertex x="9.76" y="1.34"/>
<vertex x="9.71" y="1.34"/>
<vertex x="9.67" y="1.34"/>
<vertex x="9.62" y="1.34"/>
<vertex x="9.57" y="1.34"/>
<vertex x="9.53" y="1.34"/>
<vertex x="9.48" y="1.34"/>
<vertex x="9.48" y="1.37"/>
<vertex x="9.48" y="1.39"/>
<vertex x="9.48" y="1.42"/>
<vertex x="9.48" y="1.44"/>
<vertex x="9.48" y="1.47"/>
<vertex x="9.48" y="1.49"/>
<vertex x="9.48" y="1.52"/>
<vertex x="9.48" y="1.54"/>
<vertex x="9.44" y="1.48"/>
<vertex x="9.39" y="1.44"/>
<vertex x="9.34" y="1.39"/>
<vertex x="9.29" y="1.36"/>
<vertex x="9.23" y="1.34"/>
<vertex x="9.17" y="1.32"/>
<vertex x="9.11" y="1.31"/>
<vertex x="9.04" y="1.3"/>
<vertex x="8.9" y="1.32"/>
<vertex x="8.79" y="1.35"/>
<vertex x="8.7" y="1.4"/>
<vertex x="8.63" y="1.46"/>
<vertex x="8.58" y="1.55"/>
<vertex x="8.55" y="1.65"/>
<vertex x="8.53" y="1.76"/>
<vertex x="8.53" y="1.89"/>
<vertex x="8.53" y="2"/>
<vertex x="8.53" y="2.1"/>
<vertex x="8.53" y="2.21"/>
<vertex x="8.53" y="2.32"/>
<vertex x="8.53" y="2.43"/>
<vertex x="8.53" y="2.54"/>
<vertex x="8.53" y="2.65"/>
<vertex x="8.53" y="2.76"/>
<vertex x="8.58" y="2.76"/>
<vertex x="8.63" y="2.76"/>
<vertex x="8.67" y="2.76"/>
<vertex x="8.72" y="2.76"/>
<vertex x="8.77" y="2.76"/>
<vertex x="8.82" y="2.76"/>
<vertex x="8.87" y="2.76"/>
<vertex x="8.92" y="2.76"/>
<vertex x="8.92" y="2.66"/>
<vertex x="8.92" y="2.56"/>
<vertex x="8.92" y="2.46"/>
<vertex x="8.92" y="2.36"/>
<vertex x="8.92" y="2.26"/>
<vertex x="8.92" y="2.16"/>
<vertex x="8.92" y="2.06"/>
<vertex x="8.92" y="1.96"/>
<vertex x="8.92" y="1.88"/>
<vertex x="8.93" y="1.81"/>
<vertex x="8.95" y="1.75"/>
<vertex x="8.97" y="1.7"/>
<vertex x="9.01" y="1.66"/>
<vertex x="9.05" y="1.63"/>
<vertex x="9.1" y="1.62"/>
<vertex x="9.17" y="1.61"/>
<vertex x="9.24" y="1.62"/>
<vertex x="9.3" y="1.63"/>
<vertex x="9.35" y="1.66"/>
<vertex x="9.4" y="1.71"/>
<vertex x="9.43" y="1.76"/>
<vertex x="9.45" y="1.83"/>
<vertex x="9.46" y="1.92"/>
<vertex x="9.47" y="2.02"/>
<vertex x="9.47" y="2.11"/>
<vertex x="9.47" y="2.2"/>
<vertex x="9.47" y="2.29"/>
<vertex x="9.47" y="2.39"/>
<vertex x="9.47" y="2.48"/>
<vertex x="9.47" y="2.57"/>
<vertex x="9.47" y="2.66"/>
<vertex x="9.47" y="2.76"/>
<vertex x="9.52" y="2.76"/>
<vertex x="9.56" y="2.76"/>
<vertex x="9.61" y="2.76"/>
<vertex x="9.66" y="2.76"/>
<vertex x="9.71" y="2.76"/>
<vertex x="9.76" y="2.76"/>
<vertex x="9.81" y="2.76"/>
<vertex x="9.85" y="2.76"/>
<vertex x="9.85" y="2.58"/>
<vertex x="9.85" y="2.4"/>
<vertex x="9.85" y="2.23"/>
<vertex x="9.85" y="2.05"/>
<vertex x="9.85" y="1.87"/>
<vertex x="9.85" y="1.7"/>
<vertex x="9.85" y="1.52"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="10.07" y="2.76"/>
<vertex x="10.11" y="2.76"/>
<vertex x="10.16" y="2.76"/>
<vertex x="10.2" y="2.76"/>
<vertex x="10.25" y="2.76"/>
<vertex x="10.3" y="2.76"/>
<vertex x="10.34" y="2.76"/>
<vertex x="10.39" y="2.76"/>
<vertex x="10.43" y="2.76"/>
<vertex x="10.43" y="2.73"/>
<vertex x="10.43" y="2.71"/>
<vertex x="10.43" y="2.68"/>
<vertex x="10.43" y="2.66"/>
<vertex x="10.43" y="2.63"/>
<vertex x="10.43" y="2.61"/>
<vertex x="10.43" y="2.59"/>
<vertex x="10.43" y="2.56"/>
<vertex x="10.44" y="2.56"/>
<vertex x="10.48" y="2.62"/>
<vertex x="10.52" y="2.67"/>
<vertex x="10.58" y="2.71"/>
<vertex x="10.63" y="2.74"/>
<vertex x="10.69" y="2.76"/>
<vertex x="10.75" y="2.78"/>
<vertex x="10.81" y="2.79"/>
<vertex x="10.87" y="2.8"/>
<vertex x="11.01" y="2.78"/>
<vertex x="11.13" y="2.75"/>
<vertex x="11.22" y="2.7"/>
<vertex x="11.28" y="2.64"/>
<vertex x="11.33" y="2.55"/>
<vertex x="11.37" y="2.45"/>
<vertex x="11.38" y="2.34"/>
<vertex x="11.39" y="2.21"/>
<vertex x="11.39" y="2.1"/>
<vertex x="11.39" y="2"/>
<vertex x="11.39" y="1.89"/>
<vertex x="11.39" y="1.78"/>
<vertex x="11.39" y="1.67"/>
<vertex x="11.39" y="1.56"/>
<vertex x="11.39" y="1.45"/>
<vertex x="11.39" y="1.34"/>
<vertex x="11.34" y="1.34"/>
<vertex x="11.29" y="1.34"/>
<vertex x="11.24" y="1.34"/>
<vertex x="11.19" y="1.34"/>
<vertex x="11.15" y="1.34"/>
<vertex x="11.1" y="1.34"/>
<vertex x="11.05" y="1.34"/>
<vertex x="11" y="1.34"/>
<vertex x="11" y="1.44"/>
<vertex x="11" y="1.54"/>
<vertex x="11" y="1.64"/>
<vertex x="11" y="1.74"/>
<vertex x="11" y="1.84"/>
<vertex x="11" y="1.94"/>
<vertex x="11" y="2.04"/>
<vertex x="11" y="2.14"/>
<vertex x="11" y="2.22"/>
<vertex x="10.99" y="2.29"/>
<vertex x="10.97" y="2.35"/>
<vertex x="10.94" y="2.4"/>
<vertex x="10.91" y="2.44"/>
<vertex x="10.87" y="2.47"/>
<vertex x="10.81" y="2.48"/>
<vertex x="10.75" y="2.49"/>
<vertex x="10.68" y="2.48"/>
<vertex x="10.61" y="2.47"/>
<vertex x="10.56" y="2.44"/>
<vertex x="10.52" y="2.39"/>
<vertex x="10.49" y="2.34"/>
<vertex x="10.47" y="2.27"/>
<vertex x="10.45" y="2.18"/>
<vertex x="10.45" y="2.08"/>
<vertex x="10.45" y="1.99"/>
<vertex x="10.45" y="1.9"/>
<vertex x="10.45" y="1.81"/>
<vertex x="10.45" y="1.71"/>
<vertex x="10.45" y="1.62"/>
<vertex x="10.45" y="1.53"/>
<vertex x="10.45" y="1.44"/>
<vertex x="10.45" y="1.34"/>
<vertex x="10.4" y="1.34"/>
<vertex x="10.35" y="1.34"/>
<vertex x="10.3" y="1.34"/>
<vertex x="10.26" y="1.34"/>
<vertex x="10.21" y="1.34"/>
<vertex x="10.16" y="1.34"/>
<vertex x="10.11" y="1.34"/>
<vertex x="10.06" y="1.34"/>
<vertex x="10.06" y="1.52"/>
<vertex x="10.06" y="1.7"/>
<vertex x="10.06" y="1.87"/>
<vertex x="10.06" y="2.05"/>
<vertex x="10.06" y="2.23"/>
<vertex x="10.06" y="2.4"/>
<vertex x="10.06" y="2.58"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.2">
<vertex x="0.74" y="2.6"/>
<vertex x="0.75" y="2.49"/>
<vertex x="0.79" y="2.39"/>
<vertex x="0.85" y="2.31"/>
<vertex x="0.92" y="2.24"/>
<vertex x="1.01" y="2.19"/>
<vertex x="1.11" y="2.16"/>
<vertex x="1.22" y="2.14"/>
<vertex x="1.33" y="2.13"/>
<vertex x="1.42" y="2.13"/>
<vertex x="1.51" y="2.15"/>
<vertex x="1.59" y="2.17"/>
<vertex x="1.67" y="2.21"/>
<vertex x="1.74" y="2.26"/>
<vertex x="1.79" y="2.32"/>
<vertex x="1.83" y="2.4"/>
<vertex x="1.84" y="2.49"/>
<vertex x="1.83" y="2.57"/>
<vertex x="1.78" y="2.64"/>
<vertex x="1.71" y="2.7"/>
<vertex x="1.61" y="2.76"/>
<vertex x="1.48" y="2.8"/>
<vertex x="1.33" y="2.85"/>
<vertex x="1.16" y="2.89"/>
<vertex x="0.96" y="2.93"/>
<vertex x="0.79" y="2.97"/>
<vertex x="0.63" y="3.02"/>
<vertex x="0.48" y="3.08"/>
<vertex x="0.34" y="3.16"/>
<vertex x="0.23" y="3.25"/>
<vertex x="0.14" y="3.37"/>
<vertex x="0.09" y="3.51"/>
<vertex x="0.07" y="3.68"/>
<vertex x="0.09" y="3.93"/>
<vertex x="0.17" y="4.13"/>
<vertex x="0.29" y="4.29"/>
<vertex x="0.45" y="4.41"/>
<vertex x="0.64" y="4.5"/>
<vertex x="0.85" y="4.55"/>
<vertex x="1.07" y="4.58"/>
<vertex x="1.3" y="4.59"/>
<vertex x="1.52" y="4.58"/>
<vertex x="1.74" y="4.55"/>
<vertex x="1.94" y="4.49"/>
<vertex x="2.13" y="4.4"/>
<vertex x="2.28" y="4.28"/>
<vertex x="2.41" y="4.12"/>
<vertex x="2.5" y="3.93"/>
<vertex x="2.54" y="3.69"/>
<vertex x="2.45" y="3.69"/>
<vertex x="2.36" y="3.69"/>
<vertex x="2.27" y="3.69"/>
<vertex x="2.17" y="3.69"/>
<vertex x="2.08" y="3.69"/>
<vertex x="1.99" y="3.69"/>
<vertex x="1.9" y="3.69"/>
<vertex x="1.81" y="3.69"/>
<vertex x="1.79" y="3.79"/>
<vertex x="1.75" y="3.88"/>
<vertex x="1.7" y="3.94"/>
<vertex x="1.64" y="3.99"/>
<vertex x="1.56" y="4.03"/>
<vertex x="1.47" y="4.06"/>
<vertex x="1.38" y="4.07"/>
<vertex x="1.27" y="4.07"/>
<vertex x="1.21" y="4.07"/>
<vertex x="1.13" y="4.07"/>
<vertex x="1.06" y="4.06"/>
<vertex x="0.99" y="4.03"/>
<vertex x="0.93" y="4"/>
<vertex x="0.88" y="3.95"/>
<vertex x="0.85" y="3.89"/>
<vertex x="0.84" y="3.81"/>
<vertex x="0.86" y="3.72"/>
<vertex x="0.92" y="3.65"/>
<vertex x="1.01" y="3.59"/>
<vertex x="1.12" y="3.54"/>
<vertex x="1.25" y="3.5"/>
<vertex x="1.4" y="3.46"/>
<vertex x="1.56" y="3.43"/>
<vertex x="1.72" y="3.39"/>
<vertex x="1.89" y="3.35"/>
<vertex x="2.05" y="3.3"/>
<vertex x="2.21" y="3.24"/>
<vertex x="2.34" y="3.15"/>
<vertex x="2.46" y="3.05"/>
<vertex x="2.54" y="2.93"/>
<vertex x="2.6" y="2.78"/>
<vertex x="2.62" y="2.6"/>
<vertex x="2.59" y="2.34"/>
<vertex x="2.51" y="2.13"/>
<vertex x="2.38" y="1.96"/>
<vertex x="2.21" y="1.83"/>
<vertex x="2.02" y="1.73"/>
<vertex x="1.57" y="1.63"/>
<vertex x="1.33" y="1.62"/>
<vertex x="1.08" y="1.63"/>
<vertex x="0.85" y="1.67"/>
<vertex x="0.63" y="1.73"/>
<vertex x="0.43" y="1.83"/>
<vertex x="0.26" y="1.97"/>
<vertex x="0.13" y="2.14"/>
<vertex x="0.04" y="2.35"/>
<vertex x="0" y="2.6"/>
<vertex x="0.09" y="2.6"/>
<vertex x="0.18" y="2.6"/>
<vertex x="0.28" y="2.6"/>
<vertex x="0.37" y="2.6"/>
<vertex x="0.46" y="2.6"/>
<vertex x="0.55" y="2.6"/>
<vertex x="0.65" y="2.6"/>
</polygon>
<vertex x="4.95" y="2.61"/>
<vertex x="5" y="2.76"/>
<vertex x="5.02" y="2.92"/>
<vertex x="5.03" y="3.09"/>
<vertex x="5.81" y="3.07"/>
<vertex x="5.79" y="2.79"/>
<vertex x="5.73" y="2.52"/>
<vertex x="5.63" y="2.28"/>
</polygon>
<vertex x="5.5" y="2.06"/>
<vertex x="5.32" y="1.87"/>
<vertex x="5.11" y="1.73"/>
<vertex x="4.86" y="1.64"/>
<vertex x="4.57" y="1.61"/>
<vertex x="4.44" y="1.62"/>
<vertex x="4.31" y="1.64"/>
<vertex x="4.2" y="1.67"/>
<vertex x="4.08" y="1.72"/>
<vertex x="3.98" y="1.78"/>
<vertex x="3.88" y="1.85"/>
<vertex x="3.8" y="1.94"/>
<vertex x="3.72" y="2.04"/>
<vertex x="3.71" y="2.04"/>
<vertex x="3.71" y="1.78"/>
<vertex x="3.71" y="1.53"/>
<vertex x="3.71" y="1.27"/>
<vertex x="3.71" y="1.02"/>
<vertex x="3.71" y="0.76"/>
<vertex x="3.71" y="0.51"/>
<vertex x="3.71" y="0.25"/>
<vertex x="3.71" y="0"/>
<vertex x="3.62" y="0.09"/>
<vertex x="3.52" y="0.17"/>
<vertex x="3.42" y="0.26"/>
<vertex x="3.33" y="0.35"/>
<vertex x="3.23" y="0.43"/>
<vertex x="3.13" y="0.52"/>
<vertex x="3.03" y="0.6"/>
<vertex x="2.94" y="0.69"/>
<vertex x="2.94" y="1.15"/>
<vertex x="2.94" y="1.61"/>
<vertex x="2.94" y="2.08"/>
<vertex x="2.94" y="2.54"/>
<vertex x="2.94" y="3"/>
<vertex x="2.94" y="3.46"/>
<vertex x="2.94" y="3.92"/>
<vertex x="2.94" y="4.38"/>
<vertex x="3.03" y="4.4"/>
<vertex x="3.12" y="4.42"/>
<vertex x="3.21" y="4.43"/>
<vertex x="3.31" y="4.45"/>
<vertex x="3.4" y="4.46"/>
<vertex x="3.49" y="4.48"/>
<vertex x="3.58" y="4.5"/>
<vertex x="3.68" y="4.51"/>
<vertex x="3.68" y="4.47"/>
<vertex x="3.68" y="4.42"/>
<vertex x="3.68" y="4.38"/>
<vertex x="3.68" y="4.33"/>
<vertex x="3.68" y="4.29"/>
<vertex x="3.68" y="4.24"/>
<vertex x="3.68" y="4.2"/>
<vertex x="3.68" y="4.15"/>
<vertex x="3.76" y="4.26"/>
<vertex x="3.84" y="4.35"/>
<vertex x="3.94" y="4.42"/>
<vertex x="4.04" y="4.49"/>
<vertex x="4.15" y="4.53"/>
<vertex x="4.27" y="4.56"/>
<vertex x="4.39" y="4.58"/>
<vertex x="4.52" y="4.59"/>
<vertex x="4.83" y="4.56"/>
<vertex x="5.1" y="4.47"/>
<vertex x="5.32" y="4.32"/>
<vertex x="5.5" y="4.13"/>
<vertex x="5.63" y="3.9"/>
<vertex x="5.73" y="3.65"/>
<vertex x="5.79" y="3.37"/>
<vertex x="5.02" y="3.26"/>
<vertex x="4.99" y="3.42"/>
<vertex x="4.95" y="3.58"/>
<vertex x="4.88" y="3.72"/>
<vertex x="4.79" y="3.83"/>
<vertex x="4.67" y="3.92"/>
<vertex x="4.52" y="3.98"/>
<vertex x="4.35" y="4"/>
<vertex x="4.18" y="3.98"/>
<vertex x="4.03" y="3.93"/>
<vertex x="3.92" y="3.84"/>
<vertex x="3.83" y="3.72"/>
<vertex x="3.76" y="3.58"/>
<vertex x="3.71" y="3.43"/>
<vertex x="3.69" y="3.26"/>
<vertex x="3.68" y="3.09"/>
<vertex x="3.69" y="2.92"/>
<vertex x="3.72" y="2.76"/>
<vertex x="3.76" y="2.61"/>
<vertex x="3.83" y="2.47"/>
<vertex x="3.92" y="2.36"/>
<vertex x="4.04" y="2.27"/>
<vertex x="4.18" y="2.21"/>
<vertex x="4.36" y="2.19"/>
<vertex x="4.53" y="2.21"/>
<vertex x="4.68" y="2.27"/>
<vertex x="4.79" y="2.36"/>
<vertex x="4.89" y="2.47"/>
</polygon>
<vertex x="6.99" y="3.31"/>
<vertex x="7.17" y="3.33"/>
<vertex x="7.34" y="3.35"/>
<vertex x="7.49" y="3.37"/>
<vertex x="7.59" y="2.95"/>
<vertex x="7.54" y="2.95"/>
<vertex x="7.5" y="2.94"/>
<vertex x="7.45" y="2.93"/>
<vertex x="7.4" y="2.93"/>
<vertex x="7.36" y="2.92"/>
<vertex x="7.31" y="2.91"/>
<vertex x="7.27" y="2.9"/>
<vertex x="7.22" y="2.9"/>
<vertex x="7.18" y="2.89"/>
<vertex x="7.13" y="2.88"/>
</polygon>
<vertex x="7.13" y="2.87"/>
<vertex x="7.09" y="2.86"/>
<vertex x="7.05" y="2.85"/>
<vertex x="7.02" y="2.83"/>
<vertex x="6.98" y="2.81"/>
<vertex x="6.95" y="2.79"/>
<vertex x="6.92" y="2.76"/>
<vertex x="6.89" y="2.73"/>
<vertex x="6.87" y="2.7"/>
<vertex x="6.85" y="2.67"/>
<vertex x="6.83" y="2.63"/>
<vertex x="6.82" y="2.59"/>
<vertex x="6.81" y="2.54"/>
<vertex x="6.81" y="2.49"/>
<vertex x="6.81" y="2.44"/>
<vertex x="6.82" y="2.39"/>
<vertex x="6.83" y="2.35"/>
<vertex x="6.85" y="2.31"/>
<vertex x="6.87" y="2.28"/>
<vertex x="6.89" y="2.25"/>
<vertex x="6.92" y="2.22"/>
<vertex x="6.95" y="2.2"/>
<vertex x="6.99" y="2.18"/>
<vertex x="7.02" y="2.17"/>
<vertex x="7.06" y="2.15"/>
<vertex x="7.1" y="2.14"/>
<vertex x="7.15" y="2.14"/>
<vertex x="7.19" y="2.13"/>
<vertex x="7.24" y="2.13"/>
<vertex x="7.28" y="2.13"/>
<vertex x="7.39" y="2.14"/>
<vertex x="7.48" y="2.15"/>
<vertex x="7.57" y="2.18"/>
<vertex x="7.64" y="2.21"/>
<vertex x="7.7" y="2.25"/>
<vertex x="7.75" y="2.29"/>
<vertex x="7.79" y="2.34"/>
<vertex x="7.83" y="2.39"/>
<vertex x="7.85" y="2.44"/>
<vertex x="7.87" y="2.5"/>
<vertex x="7.89" y="2.55"/>
<vertex x="7.9" y="2.61"/>
<vertex x="7.91" y="2.66"/>
<vertex x="7.91" y="2.7"/>
<vertex x="7.91" y="2.74"/>
<vertex x="7.91" y="2.78"/>
<vertex x="7.91" y="2.8"/>
<vertex x="7.91" y="2.82"/>
<vertex x="7.91" y="2.83"/>
<vertex x="7.91" y="2.85"/>
<vertex x="7.91" y="2.87"/>
<vertex x="7.91" y="2.89"/>
<vertex x="7.91" y="2.91"/>
<vertex x="7.91" y="2.93"/>
<vertex x="7.91" y="2.94"/>
<vertex x="7.91" y="2.96"/>
<vertex x="7.91" y="2.98"/>
<vertex x="7.91" y="3"/>
<vertex x="7.91" y="3.02"/>
<vertex x="7.91" y="3.03"/>
<vertex x="7.91" y="3.05"/>
<vertex x="7.91" y="3.07"/>
<vertex x="7.89" y="3.05"/>
<vertex x="7.86" y="3.03"/>
<vertex x="7.82" y="3.02"/>
<vertex x="7.79" y="3"/>
<vertex x="7.75" y="2.99"/>
<vertex x="7.71" y="2.98"/>
<vertex x="7.67" y="2.97"/>
<vertex x="7.63" y="2.96"/>
<vertex x="7.63" y="3.41"/>
<vertex x="7.75" y="3.45"/>
<vertex x="7.84" y="3.5"/>
<vertex x="7.9" y="3.58"/>
<vertex x="7.91" y="3.69"/>
<vertex x="7.91" y="3.74"/>
<vertex x="7.9" y="3.8"/>
<vertex x="7.89" y="3.84"/>
<vertex x="7.87" y="3.89"/>
<vertex x="7.85" y="3.92"/>
<vertex x="7.83" y="3.95"/>
<vertex x="7.8" y="3.98"/>
<vertex x="7.76" y="4"/>
<vertex x="7.73" y="4.02"/>
<vertex x="7.69" y="4.04"/>
<vertex x="7.65" y="4.05"/>
<vertex x="7.6" y="4.06"/>
<vertex x="7.56" y="4.06"/>
<vertex x="7.51" y="4.07"/>
<vertex x="7.46" y="4.07"/>
<vertex x="7.41" y="4.07"/>
<vertex x="7.35" y="4.07"/>
<vertex x="7.3" y="4.06"/>
<vertex x="7.25" y="4.05"/>
<vertex x="7.21" y="4.04"/>
<vertex x="7.16" y="4.03"/>
<vertex x="7.12" y="4.01"/>
<vertex x="7.08" y="3.99"/>
<vertex x="7.05" y="3.97"/>
<vertex x="7.02" y="3.94"/>
<vertex x="6.99" y="3.91"/>
<vertex x="6.97" y="3.88"/>
<vertex x="6.95" y="3.84"/>
<vertex x="6.93" y="3.79"/>
<vertex x="6.91" y="3.75"/>
<vertex x="6.9" y="3.7"/>
<vertex x="6.9" y="3.64"/>
<vertex x="6.85" y="3.64"/>
<vertex x="6.8" y="3.64"/>
<vertex x="6.75" y="3.64"/>
<vertex x="6.7" y="3.64"/>
<vertex x="6.65" y="3.64"/>
<vertex x="6.6" y="3.64"/>
<vertex x="6.56" y="3.64"/>
<vertex x="6.51" y="3.64"/>
<vertex x="6.46" y="3.64"/>
<vertex x="6.41" y="3.64"/>
<vertex x="6.36" y="3.64"/>
<vertex x="6.31" y="3.64"/>
<vertex x="6.27" y="3.64"/>
<vertex x="6.22" y="3.64"/>
<vertex x="6.17" y="3.64"/>
<vertex x="6.12" y="3.64"/>
<vertex x="6.14" y="3.77"/>
<vertex x="6.16" y="3.89"/>
<vertex x="6.2" y="4"/>
<vertex x="6.26" y="4.09"/>
<vertex x="6.32" y="4.18"/>
<vertex x="6.39" y="4.26"/>
<vertex x="6.47" y="4.33"/>
<vertex x="6.56" y="4.38"/>
<vertex x="6.66" y="4.44"/>
<vertex x="6.76" y="4.48"/>
<vertex x="6.87" y="4.51"/>
<vertex x="6.98" y="4.54"/>
<vertex x="7.09" y="4.56"/>
<vertex x="7.21" y="4.58"/>
<vertex x="7.33" y="4.58"/>
<vertex x="7.45" y="4.58"/>
<vertex x="7.56" y="4.58"/>
<vertex x="7.66" y="4.58"/>
<vertex x="7.77" y="4.57"/>
<vertex x="7.88" y="4.55"/>
<vertex x="7.99" y="4.53"/>
<vertex x="8.09" y="4.51"/>
<vertex x="8.19" y="4.48"/>
<vertex x="8.28" y="4.44"/>
<vertex x="8.37" y="4.39"/>
<vertex x="8.45" y="4.33"/>
<vertex x="8.52" y="4.27"/>
<vertex x="8.58" y="4.19"/>
<vertex x="8.62" y="4.11"/>
<vertex x="8.66" y="4.01"/>
<vertex x="8.68" y="3.9"/>
<vertex x="8.69" y="3.78"/>
<vertex x="8.69" y="3.69"/>
<vertex x="8.69" y="3.6"/>
<vertex x="8.69" y="3.51"/>
<vertex x="8.69" y="3.41"/>
<vertex x="8.69" y="3.32"/>
<vertex x="8.69" y="3.23"/>
<vertex x="8.69" y="3.14"/>
<vertex x="8.69" y="3.05"/>
<vertex x="8.69" y="2.95"/>
<vertex x="8.69" y="2.86"/>
<vertex x="8.69" y="2.77"/>
<vertex x="8.69" y="2.68"/>
<vertex x="8.69" y="2.59"/>
<vertex x="8.69" y="2.49"/>
<vertex x="8.69" y="2.4"/>
<vertex x="8.69" y="2.31"/>
<vertex x="8.69" y="2.26"/>
<vertex x="8.69" y="2.21"/>
<vertex x="8.69" y="2.17"/>
<vertex x="8.69" y="2.12"/>
<vertex x="8.7" y="2.07"/>
<vertex x="8.7" y="2.03"/>
<vertex x="8.71" y="1.98"/>
<vertex x="8.71" y="1.94"/>
<vertex x="8.72" y="1.9"/>
<vertex x="8.73" y="1.86"/>
<vertex x="8.73" y="1.83"/>
<vertex x="8.74" y="1.79"/>
<vertex x="8.75" y="1.76"/>
<vertex x="8.76" y="1.73"/>
<vertex x="8.78" y="1.7"/>
<vertex x="8.79" y="1.68"/>
<vertex x="8.74" y="1.68"/>
<vertex x="8.69" y="1.68"/>
<vertex x="8.64" y="1.68"/>
<vertex x="8.59" y="1.68"/>
<vertex x="8.54" y="1.68"/>
<vertex x="8.49" y="1.68"/>
<vertex x="8.44" y="1.68"/>
<vertex x="8.39" y="1.68"/>
<vertex x="8.35" y="1.68"/>
<vertex x="8.3" y="1.68"/>
<vertex x="8.25" y="1.68"/>
<vertex x="8.2" y="1.68"/>
<vertex x="8.15" y="1.68"/>
<vertex x="8.1" y="1.68"/>
<vertex x="8.05" y="1.68"/>
<vertex x="8" y="1.68"/>
<vertex x="8" y="1.7"/>
<vertex x="7.99" y="1.71"/>
<vertex x="7.98" y="1.73"/>
<vertex x="7.98" y="1.75"/>
<vertex x="7.97" y="1.76"/>
<vertex x="7.97" y="1.78"/>
<vertex x="7.96" y="1.8"/>
<vertex x="7.96" y="1.82"/>
<vertex x="7.96" y="1.83"/>
<vertex x="7.95" y="1.85"/>
<vertex x="7.95" y="1.87"/>
<vertex x="7.95" y="1.89"/>
<vertex x="7.95" y="1.9"/>
<vertex x="7.95" y="1.92"/>
<vertex x="7.95" y="1.94"/>
<vertex x="7.95" y="1.96"/>
<vertex x="7.9" y="1.91"/>
<vertex x="7.85" y="1.87"/>
<vertex x="7.8" y="1.83"/>
<vertex x="7.74" y="1.79"/>
<vertex x="7.69" y="1.76"/>
<vertex x="7.63" y="1.73"/>
<vertex x="7.57" y="1.71"/>
<vertex x="7.51" y="1.68"/>
<vertex x="7.45" y="1.66"/>
<vertex x="7.39" y="1.65"/>
<vertex x="7.32" y="1.63"/>
<vertex x="7.26" y="1.62"/>
<vertex x="7.19" y="1.62"/>
<vertex x="7.13" y="1.61"/>
<vertex x="7.06" y="1.6"/>
<vertex x="7" y="1.6"/>
<vertex x="6.9" y="1.6"/>
<vertex x="6.8" y="1.61"/>
<vertex x="6.71" y="1.63"/>
<vertex x="6.62" y="1.65"/>
<vertex x="6.53" y="1.68"/>
<vertex x="6.45" y="1.72"/>
<vertex x="6.38" y="1.76"/>
<vertex x="6.31" y="1.81"/>
<vertex x="6.25" y="1.86"/>
<vertex x="6.19" y="1.93"/>
<vertex x="6.15" y="2"/>
<vertex x="6.11" y="2.07"/>
<vertex x="6.08" y="2.16"/>
<vertex x="6.05" y="2.25"/>
<vertex x="6.04" y="2.34"/>
<vertex x="6.03" y="2.45"/>
<vertex x="6.06" y="2.67"/>
<vertex x="6.12" y="2.85"/>
<vertex x="6.21" y="2.99"/>
<vertex x="6.33" y="3.09"/>
<vertex x="6.48" y="3.18"/>
<vertex x="6.64" y="3.24"/>
<vertex x="6.81" y="3.28"/>
</polygon>
<vertex x="9.13" y="4.38"/>
<vertex x="9.22" y="4.4"/>
<vertex x="9.31" y="4.41"/>
<vertex x="9.41" y="4.43"/>
<vertex x="9.5" y="4.45"/>
<vertex x="9.59" y="4.46"/>
<vertex x="9.68" y="4.48"/>
<vertex x="9.78" y="4.5"/>
<vertex x="9.87" y="4.51"/>
<vertex x="9.87" y="4.45"/>
<vertex x="9.87" y="4.38"/>
<vertex x="9.87" y="4.32"/>
<vertex x="9.87" y="4.25"/>
<vertex x="9.87" y="4.18"/>
<vertex x="9.87" y="4.12"/>
<vertex x="9.87" y="4.05"/>
<vertex x="9.87" y="3.99"/>
<vertex x="9.94" y="4.12"/>
<vertex x="10.02" y="4.23"/>
<vertex x="10.12" y="4.33"/>
<vertex x="10.23" y="4.42"/>
<vertex x="10.36" y="4.49"/>
<vertex x="10.49" y="4.54"/>
<vertex x="10.63" y="4.58"/>
<vertex x="10.77" y="4.59"/>
<vertex x="10.8" y="4.59"/>
<vertex x="10.82" y="4.59"/>
<vertex x="10.84" y="4.59"/>
<vertex x="10.86" y="4.59"/>
<vertex x="10.88" y="4.58"/>
<vertex x="10.9" y="4.58"/>
<vertex x="10.92" y="4.57"/>
<vertex x="10.94" y="4.56"/>
<vertex x="10.94" y="4.47"/>
<vertex x="10.94" y="4.38"/>
<vertex x="10.94" y="4.29"/>
<vertex x="10.94" y="4.2"/>
<vertex x="10.94" y="4.11"/>
<vertex x="10.94" y="4.02"/>
<vertex x="10.94" y="3.93"/>
<vertex x="10.94" y="3.84"/>
<vertex x="10.92" y="3.85"/>
<vertex x="10.88" y="3.86"/>
<vertex x="10.85" y="3.86"/>
<vertex x="10.81" y="3.87"/>
<vertex x="10.78" y="3.87"/>
<vertex x="10.74" y="3.87"/>
<vertex x="10.7" y="3.87"/>
<vertex x="10.67" y="3.87"/>
<vertex x="10.47" y="3.85"/>
<vertex x="10.3" y="3.8"/>
<vertex x="10.17" y="3.71"/>
<vertex x="10.07" y="3.6"/>
<vertex x="9.99" y="3.47"/>
<vertex x="9.94" y="3.31"/>
<vertex x="9.91" y="3.14"/>
<vertex x="9.9" y="2.96"/>
<vertex x="9.9" y="2.8"/>
<vertex x="9.9" y="2.64"/>
<vertex x="9.9" y="2.48"/>
<vertex x="9.9" y="2.32"/>
<vertex x="9.9" y="2.16"/>
<vertex x="9.9" y="2"/>
<vertex x="9.9" y="1.84"/>
<vertex x="9.9" y="1.69"/>
<vertex x="9.8" y="1.69"/>
<vertex x="9.7" y="1.69"/>
<vertex x="9.61" y="1.69"/>
<vertex x="9.51" y="1.69"/>
<vertex x="9.41" y="1.69"/>
<vertex x="9.32" y="1.69"/>
<vertex x="9.22" y="1.69"/>
<vertex x="9.12" y="1.69"/>
<vertex x="9.12" y="2.02"/>
<vertex x="9.12" y="2.36"/>
<vertex x="9.12" y="2.7"/>
<vertex x="9.12" y="3.03"/>
<vertex x="9.12" y="3.37"/>
<vertex x="9.12" y="3.71"/>
<vertex x="9.12" y="4.04"/>
</polygon>
<vertex x="11.25" y="5.16"/>
<vertex x="12.03" y="5.59"/>
<vertex x="12.03" y="3.5"/>
<vertex x="13.01" y="4.51"/>
<vertex x="13.93" y="4.51"/>
<vertex x="12.86" y="3.47"/>
<vertex x="14.04" y="1.69"/>
<vertex x="13.1" y="1.69"/>
<vertex x="12.33" y="2.95"/>
<vertex x="12.03" y="2.66"/>
<vertex x="12.03" y="1.69"/>
<vertex x="11.25" y="1.69"/>
</polygon>
<vertex x="14.52" y="3.99"/>
<vertex x="14.42" y="3.99"/>
<vertex x="14.33" y="3.99"/>
<vertex x="14.23" y="3.99"/>
<vertex x="14.13" y="3.99"/>
<vertex x="14.04" y="3.99"/>
<vertex x="13.94" y="3.99"/>
<vertex x="13.85" y="3.99"/>
<vertex x="13.75" y="3.99"/>
<vertex x="13.82" y="4.06"/>
<vertex x="13.88" y="4.12"/>
<vertex x="13.95" y="4.19"/>
<vertex x="14.02" y="4.25"/>
<vertex x="14.08" y="4.32"/>
<vertex x="14.15" y="4.38"/>
<vertex x="14.21" y="4.45"/>
<vertex x="14.28" y="4.51"/>
<vertex x="14.31" y="4.51"/>
<vertex x="14.34" y="4.51"/>
<vertex x="14.37" y="4.51"/>
<vertex x="14.4" y="4.51"/>
<vertex x="14.43" y="4.51"/>
<vertex x="14.46" y="4.51"/>
<vertex x="14.49" y="4.51"/>
<vertex x="14.52" y="4.51"/>
<vertex x="14.52" y="4.54"/>
<vertex x="14.52" y="4.57"/>
<vertex x="14.52" y="4.59"/>
<vertex x="14.52" y="4.62"/>
<vertex x="14.52" y="4.65"/>
<vertex x="14.52" y="4.68"/>
<vertex x="14.52" y="4.7"/>
<vertex x="14.52" y="4.73"/>
<vertex x="14.53" y="4.91"/>
<vertex x="14.58" y="5.08"/>
<vertex x="14.65" y="5.22"/>
<vertex x="14.75" y="5.35"/>
<vertex x="14.89" y="5.45"/>
<vertex x="15.05" y="5.53"/>
<vertex x="15.24" y="5.57"/>
<vertex x="15.46" y="5.59"/>
<vertex x="15.52" y="5.59"/>
<vertex x="15.57" y="5.59"/>
<vertex x="15.62" y="5.59"/>
<vertex x="15.67" y="5.58"/>
<vertex x="15.72" y="5.58"/>
<vertex x="15.77" y="5.57"/>
<vertex x="15.82" y="5.57"/>
<vertex x="15.87" y="5.57"/>
<vertex x="15.87" y="5.5"/>
<vertex x="15.87" y="5.43"/>
<vertex x="15.87" y="5.36"/>
<vertex x="15.87" y="5.28"/>
<vertex x="15.87" y="5.21"/>
<vertex x="15.87" y="5.14"/>
<vertex x="15.87" y="5.07"/>
<vertex x="15.87" y="4.99"/>
<vertex x="15.84" y="5"/>
<vertex x="15.8" y="5"/>
<vertex x="15.77" y="5"/>
<vertex x="15.73" y="5"/>
<vertex x="15.7" y="5"/>
<vertex x="15.66" y="5"/>
<vertex x="15.62" y="5"/>
<vertex x="15.59" y="5"/>
<vertex x="15.52" y="5"/>
<vertex x="15.45" y="4.99"/>
<vertex x="15.4" y="4.96"/>
<vertex x="15.36" y="4.93"/>
<vertex x="15.33" y="4.89"/>
<vertex x="15.31" y="4.83"/>
<vertex x="15.3" y="4.76"/>
<vertex x="15.29" y="4.68"/>
<vertex x="15.29" y="4.66"/>
<vertex x="15.29" y="4.64"/>
<vertex x="15.29" y="4.62"/>
<vertex x="15.29" y="4.6"/>
<vertex x="15.29" y="4.58"/>
<vertex x="15.29" y="4.55"/>
<vertex x="15.29" y="4.53"/>
<vertex x="15.29" y="4.51"/>
<vertex x="15.36" y="4.51"/>
<vertex x="15.43" y="4.51"/>
<vertex x="15.49" y="4.51"/>
<vertex x="15.56" y="4.51"/>
<vertex x="15.63" y="4.51"/>
<vertex x="15.7" y="4.51"/>
<vertex x="15.76" y="4.51"/>
<vertex x="15.83" y="4.51"/>
<vertex x="15.83" y="4.45"/>
<vertex x="15.83" y="4.38"/>
<vertex x="15.83" y="4.32"/>
<vertex x="15.83" y="4.25"/>
<vertex x="15.83" y="4.19"/>
<vertex x="15.83" y="4.12"/>
<vertex x="15.83" y="4.06"/>
<vertex x="15.83" y="3.99"/>
<vertex x="15.76" y="3.99"/>
<vertex x="15.7" y="3.99"/>
<vertex x="15.63" y="3.99"/>
<vertex x="15.56" y="3.99"/>
<vertex x="15.49" y="3.99"/>
<vertex x="15.43" y="3.99"/>
<vertex x="15.36" y="3.99"/>
<vertex x="15.29" y="3.99"/>
<vertex x="15.29" y="3.7"/>
<vertex x="15.29" y="3.42"/>
<vertex x="15.29" y="3.13"/>
<vertex x="15.29" y="2.84"/>
<vertex x="15.29" y="2.55"/>
<vertex x="15.29" y="2.26"/>
<vertex x="15.29" y="1.97"/>
<vertex x="15.29" y="1.68"/>
<vertex x="15.2" y="1.68"/>
<vertex x="15.1" y="1.68"/>
<vertex x="15" y="1.68"/>
<vertex x="14.91" y="1.68"/>
<vertex x="14.81" y="1.68"/>
<vertex x="14.71" y="1.68"/>
<vertex x="14.61" y="1.68"/>
<vertex x="14.52" y="1.68"/>
<vertex x="14.52" y="1.97"/>
<vertex x="14.52" y="2.26"/>
<vertex x="14.52" y="2.55"/>
<vertex x="14.52" y="2.84"/>
<vertex x="14.52" y="3.13"/>
<vertex x="14.52" y="3.42"/>
<vertex x="14.52" y="3.7"/>
</polygon>
<vertex x="18.7" y="1.69"/>
<vertex x="18.61" y="1.69"/>
<vertex x="18.52" y="1.69"/>
<vertex x="18.42" y="1.69"/>
<vertex x="18.33" y="1.69"/>
<vertex x="18.24" y="1.69"/>
<vertex x="18.15" y="1.69"/>
<vertex x="18.05" y="1.69"/>
<vertex x="17.96" y="1.69"/>
<vertex x="17.96" y="1.73"/>
<vertex x="17.96" y="1.78"/>
<vertex x="17.96" y="1.83"/>
<vertex x="17.96" y="1.88"/>
<vertex x="17.96" y="1.93"/>
<vertex x="17.96" y="1.98"/>
<vertex x="17.96" y="2.03"/>
<vertex x="17.96" y="2.08"/>
<vertex x="17.95" y="2.08"/>
<vertex x="17.87" y="1.97"/>
<vertex x="17.78" y="1.87"/>
<vertex x="17.68" y="1.79"/>
<vertex x="17.57" y="1.72"/>
<vertex x="17.45" y="1.67"/>
<vertex x="17.33" y="1.64"/>
<vertex x="17.21" y="1.62"/>
<vertex x="17.09" y="1.61"/>
<vertex x="16.81" y="1.63"/>
<vertex x="16.58" y="1.69"/>
<vertex x="16.4" y="1.79"/>
<vertex x="16.26" y="1.93"/>
<vertex x="16.16" y="2.1"/>
<vertex x="16.1" y="2.3"/>
<vertex x="16.07" y="2.52"/>
<vertex x="16.06" y="2.77"/>
<vertex x="16.06" y="2.99"/>
<vertex x="16.06" y="3.21"/>
<vertex x="16.06" y="3.43"/>
<vertex x="16.06" y="3.64"/>
<vertex x="16.06" y="3.86"/>
<vertex x="16.06" y="4.08"/>
<vertex x="16.06" y="4.3"/>
<vertex x="16.06" y="4.51"/>
<vertex x="16.15" y="4.51"/>
<vertex x="16.25" y="4.51"/>
<vertex x="16.35" y="4.51"/>
<vertex x="16.44" y="4.51"/>
<vertex x="16.54" y="4.51"/>
<vertex x="16.64" y="4.51"/>
<vertex x="16.74" y="4.51"/>
<vertex x="16.83" y="4.51"/>
<vertex x="16.83" y="4.31"/>
<vertex x="16.83" y="4.11"/>
<vertex x="16.83" y="3.91"/>
<vertex x="16.83" y="3.71"/>
<vertex x="16.83" y="3.51"/>
<vertex x="16.83" y="3.32"/>
<vertex x="16.83" y="3.12"/>
<vertex x="16.83" y="2.92"/>
<vertex x="16.84" y="2.75"/>
<vertex x="16.86" y="2.61"/>
<vertex x="16.89" y="2.49"/>
<vertex x="16.94" y="2.39"/>
<vertex x="17.01" y="2.32"/>
<vertex x="17.1" y="2.26"/>
<vertex x="17.2" y="2.23"/>
<vertex x="17.33" y="2.22"/>
<vertex x="17.48" y="2.23"/>
<vertex x="17.6" y="2.27"/>
<vertex x="17.71" y="2.33"/>
<vertex x="17.79" y="2.41"/>
<vertex x="17.85" y="2.52"/>
<vertex x="17.9" y="2.66"/>
<vertex x="17.92" y="2.83"/>
<vertex x="17.93" y="3.03"/>
<vertex x="17.93" y="3.22"/>
<vertex x="17.93" y="3.4"/>
<vertex x="17.93" y="3.59"/>
<vertex x="17.93" y="3.77"/>
<vertex x="17.93" y="3.96"/>
<vertex x="17.93" y="4.14"/>
<vertex x="17.93" y="4.33"/>
<vertex x="17.93" y="4.51"/>
<vertex x="18.03" y="4.51"/>
<vertex x="18.13" y="4.51"/>
<vertex x="18.22" y="4.51"/>
<vertex x="18.32" y="4.51"/>
<vertex x="18.42" y="4.51"/>
<vertex x="18.51" y="4.51"/>
<vertex x="18.61" y="4.51"/>
<vertex x="18.71" y="4.51"/>
<vertex x="18.71" y="4.16"/>
<vertex x="18.71" y="3.81"/>
<vertex x="18.71" y="3.45"/>
<vertex x="18.71" y="3.1"/>
<vertex x="18.71" y="2.75"/>
<vertex x="18.71" y="2.39"/>
<vertex x="18.71" y="2.04"/>
</polygon>
<vertex x="19.13" y="4.51"/>
<vertex x="19.22" y="4.51"/>
<vertex x="19.31" y="4.51"/>
<vertex x="19.41" y="4.51"/>
<vertex x="19.5" y="4.51"/>
<vertex x="19.59" y="4.51"/>
<vertex x="19.68" y="4.51"/>
<vertex x="19.78" y="4.51"/>
<vertex x="19.87" y="4.51"/>
<vertex x="19.87" y="4.46"/>
<vertex x="19.87" y="4.42"/>
<vertex x="19.87" y="4.37"/>
<vertex x="19.87" y="4.32"/>
<vertex x="19.87" y="4.27"/>
<vertex x="19.87" y="4.22"/>
<vertex x="19.87" y="4.17"/>
<vertex x="19.87" y="4.12"/>
<vertex x="19.88" y="4.12"/>
<vertex x="19.96" y="4.23"/>
<vertex x="20.05" y="4.33"/>
<vertex x="20.15" y="4.41"/>
<vertex x="20.26" y="4.48"/>
<vertex x="20.38" y="4.53"/>
<vertex x="20.5" y="4.56"/>
<vertex x="20.62" y="4.58"/>
<vertex x="20.74" y="4.59"/>
<vertex x="21.02" y="4.57"/>
<vertex x="21.25" y="4.51"/>
<vertex x="21.43" y="4.41"/>
<vertex x="21.57" y="4.27"/>
<vertex x="21.67" y="4.1"/>
<vertex x="21.73" y="3.9"/>
<vertex x="21.76" y="3.68"/>
<vertex x="21.77" y="3.43"/>
<vertex x="21.77" y="3.21"/>
<vertex x="21.77" y="2.99"/>
<vertex x="21.77" y="2.77"/>
<vertex x="21.77" y="2.56"/>
<vertex x="21.77" y="2.34"/>
<vertex x="21.77" y="2.12"/>
<vertex x="21.77" y="1.9"/>
<vertex x="21.77" y="1.69"/>
<vertex x="21.68" y="1.69"/>
<vertex x="21.58" y="1.69"/>
<vertex x="21.48" y="1.69"/>
<vertex x="21.39" y="1.69"/>
<vertex x="21.29" y="1.69"/>
<vertex x="21.19" y="1.69"/>
<vertex x="21.1" y="1.69"/>
<vertex x="21" y="1.69"/>
<vertex x="21" y="1.89"/>
<vertex x="21" y="2.09"/>
<vertex x="21" y="2.28"/>
<vertex x="21" y="2.48"/>
<vertex x="21" y="2.68"/>
<vertex x="21" y="2.88"/>
<vertex x="21" y="3.08"/>
<vertex x="21" y="3.28"/>
<vertex x="20.99" y="3.45"/>
<vertex x="20.97" y="3.59"/>
<vertex x="20.94" y="3.71"/>
<vertex x="20.89" y="3.8"/>
<vertex x="20.82" y="3.88"/>
<vertex x="20.73" y="3.93"/>
<vertex x="20.63" y="3.97"/>
<vertex x="20.5" y="3.98"/>
<vertex x="20.35" y="3.97"/>
<vertex x="20.23" y="3.93"/>
<vertex x="20.12" y="3.87"/>
<vertex x="20.04" y="3.79"/>
<vertex x="19.98" y="3.68"/>
<vertex x="19.93" y="3.54"/>
<vertex x="19.91" y="3.37"/>
<vertex x="19.9" y="3.17"/>
<vertex x="19.9" y="2.98"/>
<vertex x="19.9" y="2.8"/>
<vertex x="19.9" y="2.61"/>
<vertex x="19.9" y="2.43"/>
<vertex x="19.9" y="2.24"/>
<vertex x="19.9" y="2.06"/>
<vertex x="19.9" y="1.87"/>
<vertex x="19.9" y="1.69"/>
<vertex x="19.8" y="1.69"/>
<vertex x="19.7" y="1.69"/>
<vertex x="19.61" y="1.69"/>
<vertex x="19.51" y="1.69"/>
<vertex x="19.41" y="1.69"/>
<vertex x="19.32" y="1.69"/>
<vertex x="19.22" y="1.69"/>
<vertex x="19.12" y="1.69"/>
<vertex x="19.12" y="2.04"/>
<vertex x="19.12" y="2.39"/>
<vertex x="19.12" y="2.75"/>
<vertex x="19.12" y="3.1"/>
<vertex x="19.12" y="3.45"/>
<vertex x="19.12" y="3.81"/>
<vertex x="19.12" y="4.16"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.3">
<vertex x="1.61" y="3.91"/>
<vertex x="1.63" y="3.73"/>
<vertex x="1.68" y="3.58"/>
<vertex x="1.77" y="3.46"/>
<vertex x="1.89" y="3.36"/>
<vertex x="2.02" y="3.29"/>
<vertex x="2.17" y="3.23"/>
<vertex x="2.33" y="3.2"/>
<vertex x="2.5" y="3.19"/>
<vertex x="2.63" y="3.2"/>
<vertex x="2.76" y="3.22"/>
<vertex x="2.89" y="3.26"/>
<vertex x="3.01" y="3.31"/>
<vertex x="3.11" y="3.39"/>
<vertex x="3.19" y="3.48"/>
<vertex x="3.25" y="3.6"/>
<vertex x="3.27" y="3.74"/>
<vertex x="3.24" y="3.86"/>
<vertex x="3.18" y="3.96"/>
<vertex x="3.07" y="4.05"/>
<vertex x="2.92" y="4.13"/>
<vertex x="2.73" y="4.2"/>
<vertex x="2.5" y="4.27"/>
<vertex x="2.24" y="4.33"/>
<vertex x="1.94" y="4.39"/>
<vertex x="1.69" y="4.46"/>
<vertex x="1.45" y="4.53"/>
<vertex x="1.22" y="4.62"/>
<vertex x="1.02" y="4.74"/>
<vertex x="0.85" y="4.88"/>
<vertex x="0.71" y="5.05"/>
<vertex x="0.63" y="5.27"/>
<vertex x="0.6" y="5.53"/>
<vertex x="0.64" y="5.9"/>
<vertex x="0.76" y="6.2"/>
<vertex x="0.94" y="6.43"/>
<vertex x="1.18" y="6.61"/>
<vertex x="1.46" y="6.74"/>
<vertex x="1.77" y="6.83"/>
<vertex x="2.1" y="6.87"/>
<vertex x="2.44" y="6.89"/>
<vertex x="2.79" y="6.87"/>
<vertex x="3.11" y="6.82"/>
<vertex x="3.42" y="6.74"/>
<vertex x="3.69" y="6.6"/>
<vertex x="3.93" y="6.42"/>
<vertex x="4.11" y="6.19"/>
<vertex x="4.25" y="5.89"/>
<vertex x="4.32" y="5.54"/>
<vertex x="4.18" y="5.54"/>
<vertex x="4.04" y="5.54"/>
<vertex x="3.9" y="5.54"/>
<vertex x="3.76" y="5.54"/>
<vertex x="3.62" y="5.54"/>
<vertex x="3.49" y="5.54"/>
<vertex x="3.35" y="5.54"/>
<vertex x="3.21" y="5.54"/>
<vertex x="3.18" y="5.69"/>
<vertex x="3.13" y="5.82"/>
<vertex x="3.05" y="5.92"/>
<vertex x="2.95" y="5.99"/>
<vertex x="2.84" y="6.05"/>
<vertex x="2.71" y="6.08"/>
<vertex x="2.57" y="6.1"/>
<vertex x="2.41" y="6.11"/>
<vertex x="2.31" y="6.11"/>
<vertex x="2.2" y="6.1"/>
<vertex x="2.09" y="6.08"/>
<vertex x="1.99" y="6.05"/>
<vertex x="1.9" y="6"/>
<vertex x="1.83" y="5.93"/>
<vertex x="1.78" y="5.84"/>
<vertex x="1.76" y="5.72"/>
<vertex x="1.79" y="5.58"/>
<vertex x="1.88" y="5.47"/>
<vertex x="2.01" y="5.38"/>
<vertex x="2.18" y="5.31"/>
<vertex x="2.38" y="5.25"/>
<vertex x="2.6" y="5.2"/>
<vertex x="2.84" y="5.14"/>
<vertex x="3.09" y="5.09"/>
<vertex x="3.34" y="5.03"/>
<vertex x="3.58" y="4.95"/>
<vertex x="3.81" y="4.85"/>
<vertex x="4.01" y="4.73"/>
<vertex x="4.18" y="4.58"/>
<vertex x="4.32" y="4.4"/>
<vertex x="4.4" y="4.17"/>
<vertex x="4.43" y="3.9"/>
<vertex x="4.39" y="3.52"/>
<vertex x="4.26" y="3.2"/>
<vertex x="4.07" y="2.94"/>
<vertex x="3.82" y="2.74"/>
<vertex x="3.53" y="2.6"/>
<vertex x="3.2" y="2.5"/>
<vertex x="2.85" y="2.44"/>
<vertex x="2.49" y="2.42"/>
<vertex x="2.13" y="2.44"/>
<vertex x="1.77" y="2.5"/>
<vertex x="1.44" y="2.6"/>
<vertex x="1.14" y="2.75"/>
<vertex x="0.89" y="2.95"/>
<vertex x="0.69" y="3.21"/>
<vertex x="0.56" y="3.53"/>
<vertex x="0.5" y="3.91"/>
<vertex x="0.64" y="3.91"/>
<vertex x="0.78" y="3.91"/>
<vertex x="0.92" y="3.91"/>
<vertex x="1.05" y="3.91"/>
<vertex x="1.19" y="3.91"/>
<vertex x="1.33" y="3.91"/>
<vertex x="1.47" y="3.91"/>
</polygon>
<vertex x="7.93" y="3.91"/>
<vertex x="8" y="4.14"/>
<vertex x="8.03" y="4.38"/>
<vertex x="8.05" y="4.64"/>
<vertex x="9.21" y="4.6"/>
<vertex x="9.18" y="4.18"/>
<vertex x="9.1" y="3.78"/>
<vertex x="8.95" y="3.41"/>
</polygon>
<vertex x="8.75" y="3.08"/>
<vertex x="8.49" y="2.81"/>
<vertex x="8.17" y="2.6"/>
<vertex x="7.79" y="2.46"/>
<vertex x="7.35" y="2.41"/>
<vertex x="7.16" y="2.42"/>
<vertex x="6.97" y="2.46"/>
<vertex x="6.8" y="2.51"/>
<vertex x="6.63" y="2.58"/>
<vertex x="6.47" y="2.67"/>
<vertex x="6.32" y="2.78"/>
<vertex x="6.19" y="2.91"/>
<vertex x="6.08" y="3.05"/>
<vertex x="6.07" y="3.05"/>
<vertex x="6.07" y="2.67"/>
<vertex x="6.07" y="2.29"/>
<vertex x="6.07" y="1.91"/>
<vertex x="6.07" y="1.53"/>
<vertex x="6.07" y="1.15"/>
<vertex x="6.07" y="0.76"/>
<vertex x="6.07" y="0.38"/>
<vertex x="6.07" y="0"/>
<vertex x="5.93" y="0.13"/>
<vertex x="5.78" y="0.26"/>
<vertex x="5.63" y="0.39"/>
<vertex x="5.49" y="0.52"/>
<vertex x="5.34" y="0.65"/>
<vertex x="5.2" y="0.78"/>
<vertex x="5.05" y="0.91"/>
<vertex x="4.91" y="1.04"/>
<vertex x="4.91" y="1.73"/>
<vertex x="4.91" y="2.42"/>
<vertex x="4.91" y="3.11"/>
<vertex x="4.91" y="3.81"/>
<vertex x="4.91" y="4.5"/>
<vertex x="4.91" y="5.19"/>
<vertex x="4.91" y="5.88"/>
<vertex x="4.91" y="6.57"/>
<vertex x="5.04" y="6.6"/>
<vertex x="5.18" y="6.62"/>
<vertex x="5.32" y="6.65"/>
<vertex x="5.46" y="6.67"/>
<vertex x="5.6" y="6.7"/>
<vertex x="5.74" y="6.72"/>
<vertex x="5.88" y="6.75"/>
<vertex x="6.01" y="6.77"/>
<vertex x="6.01" y="6.7"/>
<vertex x="6.01" y="6.63"/>
<vertex x="6.01" y="6.57"/>
<vertex x="6.01" y="6.5"/>
<vertex x="6.01" y="6.43"/>
<vertex x="6.01" y="6.36"/>
<vertex x="6.01" y="6.3"/>
<vertex x="6.01" y="6.23"/>
<vertex x="6.02" y="6.23"/>
<vertex x="6.14" y="6.39"/>
<vertex x="6.27" y="6.52"/>
<vertex x="6.41" y="6.64"/>
<vertex x="6.56" y="6.73"/>
<vertex x="6.73" y="6.8"/>
<vertex x="6.91" y="6.85"/>
<vertex x="7.09" y="6.87"/>
<vertex x="7.28" y="6.88"/>
<vertex x="7.75" y="6.84"/>
<vertex x="8.15" y="6.7"/>
<vertex x="8.48" y="6.48"/>
<vertex x="8.75" y="6.2"/>
<vertex x="8.95" y="5.86"/>
<vertex x="9.1" y="5.47"/>
<vertex x="9.18" y="5.05"/>
<vertex x="8.03" y="4.89"/>
<vertex x="7.99" y="5.14"/>
<vertex x="7.92" y="5.37"/>
<vertex x="7.82" y="5.58"/>
<vertex x="7.68" y="5.75"/>
<vertex x="7.5" y="5.89"/>
<vertex x="7.29" y="5.97"/>
<vertex x="7.03" y="6.01"/>
<vertex x="6.77" y="5.98"/>
<vertex x="6.55" y="5.89"/>
<vertex x="6.37" y="5.75"/>
<vertex x="6.24" y="5.58"/>
<vertex x="6.14" y="5.37"/>
<vertex x="6.07" y="5.14"/>
<vertex x="6.03" y="4.89"/>
<vertex x="6.02" y="4.64"/>
<vertex x="6.03" y="4.38"/>
<vertex x="6.07" y="4.14"/>
<vertex x="6.14" y="3.91"/>
<vertex x="6.25" y="3.71"/>
<vertex x="6.38" y="3.54"/>
<vertex x="6.56" y="3.4"/>
<vertex x="6.78" y="3.32"/>
<vertex x="7.04" y="3.29"/>
<vertex x="7.3" y="3.32"/>
<vertex x="7.52" y="3.4"/>
<vertex x="7.69" y="3.54"/>
<vertex x="7.83" y="3.71"/>
</polygon>
<vertex x="10.98" y="4.96"/>
<vertex x="11.25" y="5"/>
<vertex x="11.5" y="5.03"/>
<vertex x="11.74" y="5.06"/>
<vertex x="11.88" y="4.43"/>
<vertex x="11.81" y="4.42"/>
<vertex x="11.75" y="4.41"/>
<vertex x="11.68" y="4.4"/>
<vertex x="11.61" y="4.39"/>
<vertex x="11.54" y="4.38"/>
<vertex x="11.47" y="4.37"/>
<vertex x="11.4" y="4.36"/>
<vertex x="11.33" y="4.34"/>
<vertex x="11.27" y="4.33"/>
<vertex x="11.2" y="4.31"/>
</polygon>
<vertex x="11.14" y="4.29"/>
<vertex x="11.08" y="4.27"/>
<vertex x="11.02" y="4.24"/>
<vertex x="10.97" y="4.21"/>
<vertex x="10.92" y="4.18"/>
<vertex x="10.88" y="4.14"/>
<vertex x="10.83" y="4.1"/>
<vertex x="10.8" y="4.05"/>
<vertex x="10.77" y="4"/>
<vertex x="10.74" y="3.94"/>
<vertex x="10.73" y="3.88"/>
<vertex x="10.71" y="3.81"/>
<vertex x="10.71" y="3.73"/>
<vertex x="10.71" y="3.66"/>
<vertex x="10.73" y="3.59"/>
<vertex x="10.74" y="3.52"/>
<vertex x="10.77" y="3.47"/>
<vertex x="10.8" y="3.42"/>
<vertex x="10.84" y="3.37"/>
<vertex x="10.88" y="3.33"/>
<vertex x="10.93" y="3.3"/>
<vertex x="10.98" y="3.27"/>
<vertex x="11.03" y="3.25"/>
<vertex x="11.09" y="3.23"/>
<vertex x="11.15" y="3.22"/>
<vertex x="11.22" y="3.2"/>
<vertex x="11.29" y="3.19"/>
<vertex x="11.36" y="3.19"/>
<vertex x="11.43" y="3.19"/>
<vertex x="11.59" y="3.2"/>
<vertex x="11.73" y="3.23"/>
<vertex x="11.85" y="3.26"/>
<vertex x="11.96" y="3.31"/>
<vertex x="12.05" y="3.37"/>
<vertex x="12.12" y="3.43"/>
<vertex x="12.19" y="3.51"/>
<vertex x="12.24" y="3.58"/>
<vertex x="12.28" y="3.67"/>
<vertex x="12.31" y="3.75"/>
<vertex x="12.33" y="3.83"/>
<vertex x="12.35" y="3.91"/>
<vertex x="12.36" y="3.98"/>
<vertex x="12.37" y="4.05"/>
<vertex x="12.37" y="4.12"/>
<vertex x="12.37" y="4.17"/>
<vertex x="12.37" y="4.2"/>
<vertex x="12.37" y="4.23"/>
<vertex x="12.37" y="4.25"/>
<vertex x="12.37" y="4.28"/>
<vertex x="12.37" y="4.31"/>
<vertex x="12.37" y="4.33"/>
<vertex x="12.37" y="4.36"/>
<vertex x="12.37" y="4.39"/>
<vertex x="12.37" y="4.42"/>
<vertex x="12.37" y="4.44"/>
<vertex x="12.37" y="4.47"/>
<vertex x="12.37" y="4.5"/>
<vertex x="12.37" y="4.52"/>
<vertex x="12.37" y="4.55"/>
<vertex x="12.37" y="4.58"/>
<vertex x="12.37" y="4.61"/>
<vertex x="12.33" y="4.57"/>
<vertex x="12.28" y="4.55"/>
<vertex x="12.24" y="4.52"/>
<vertex x="12.18" y="4.5"/>
<vertex x="12.13" y="4.48"/>
<vertex x="12.07" y="4.47"/>
<vertex x="12.01" y="4.45"/>
<vertex x="11.95" y="4.44"/>
<vertex x="11.95" y="5.11"/>
<vertex x="12.13" y="5.17"/>
<vertex x="12.26" y="5.26"/>
<vertex x="12.34" y="5.37"/>
<vertex x="12.37" y="5.53"/>
<vertex x="12.37" y="5.62"/>
<vertex x="12.35" y="5.7"/>
<vertex x="12.34" y="5.77"/>
<vertex x="12.31" y="5.83"/>
<vertex x="12.28" y="5.88"/>
<vertex x="12.24" y="5.93"/>
<vertex x="12.2" y="5.97"/>
<vertex x="12.15" y="6"/>
<vertex x="12.09" y="6.03"/>
<vertex x="12.03" y="6.05"/>
<vertex x="11.97" y="6.07"/>
<vertex x="11.91" y="6.08"/>
<vertex x="11.84" y="6.09"/>
<vertex x="11.77" y="6.1"/>
<vertex x="11.69" y="6.1"/>
<vertex x="11.62" y="6.1"/>
<vertex x="11.53" y="6.1"/>
<vertex x="11.45" y="6.09"/>
<vertex x="11.38" y="6.08"/>
<vertex x="11.31" y="6.07"/>
<vertex x="11.24" y="6.05"/>
<vertex x="11.18" y="6.02"/>
<vertex x="11.13" y="5.99"/>
<vertex x="11.08" y="5.95"/>
<vertex x="11.03" y="5.91"/>
<vertex x="10.99" y="5.87"/>
<vertex x="10.95" y="5.81"/>
<vertex x="10.92" y="5.75"/>
<vertex x="10.89" y="5.69"/>
<vertex x="10.87" y="5.62"/>
<vertex x="10.85" y="5.54"/>
<vertex x="10.84" y="5.46"/>
<vertex x="10.77" y="5.46"/>
<vertex x="10.7" y="5.46"/>
<vertex x="10.63" y="5.46"/>
<vertex x="10.55" y="5.46"/>
<vertex x="10.48" y="5.46"/>
<vertex x="10.41" y="5.46"/>
<vertex x="10.33" y="5.46"/>
<vertex x="10.26" y="5.46"/>
<vertex x="10.19" y="5.46"/>
<vertex x="10.12" y="5.46"/>
<vertex x="10.04" y="5.46"/>
<vertex x="9.97" y="5.46"/>
<vertex x="9.9" y="5.46"/>
<vertex x="9.83" y="5.46"/>
<vertex x="9.75" y="5.46"/>
<vertex x="9.68" y="5.46"/>
<vertex x="9.7" y="5.66"/>
<vertex x="9.75" y="5.83"/>
<vertex x="9.81" y="5.99"/>
<vertex x="9.89" y="6.14"/>
<vertex x="9.98" y="6.27"/>
<vertex x="10.09" y="6.39"/>
<vertex x="10.21" y="6.49"/>
<vertex x="10.35" y="6.58"/>
<vertex x="10.49" y="6.65"/>
<vertex x="10.64" y="6.72"/>
<vertex x="10.8" y="6.77"/>
<vertex x="10.97" y="6.81"/>
<vertex x="11.14" y="6.84"/>
<vertex x="11.32" y="6.86"/>
<vertex x="11.5" y="6.88"/>
<vertex x="11.67" y="6.88"/>
<vertex x="11.83" y="6.88"/>
<vertex x="12" y="6.87"/>
<vertex x="12.16" y="6.85"/>
<vertex x="12.32" y="6.83"/>
<vertex x="12.48" y="6.8"/>
<vertex x="12.64" y="6.76"/>
<vertex x="12.78" y="6.72"/>
<vertex x="12.92" y="6.66"/>
<vertex x="13.05" y="6.58"/>
<vertex x="13.17" y="6.5"/>
<vertex x="13.28" y="6.4"/>
<vertex x="13.36" y="6.29"/>
<vertex x="13.44" y="6.16"/>
<vertex x="13.49" y="6.02"/>
<vertex x="13.53" y="5.85"/>
<vertex x="13.54" y="5.67"/>
<vertex x="13.54" y="5.53"/>
<vertex x="13.54" y="5.4"/>
<vertex x="13.54" y="5.26"/>
<vertex x="13.54" y="5.12"/>
<vertex x="13.54" y="4.98"/>
<vertex x="13.54" y="4.84"/>
<vertex x="13.54" y="4.71"/>
<vertex x="13.54" y="4.57"/>
<vertex x="13.54" y="4.43"/>
<vertex x="13.54" y="4.29"/>
<vertex x="13.54" y="4.15"/>
<vertex x="13.54" y="4.02"/>
<vertex x="13.54" y="3.88"/>
<vertex x="13.54" y="3.74"/>
<vertex x="13.54" y="3.6"/>
<vertex x="13.54" y="3.46"/>
<vertex x="13.54" y="3.39"/>
<vertex x="13.54" y="3.32"/>
<vertex x="13.54" y="3.25"/>
<vertex x="13.54" y="3.18"/>
<vertex x="13.54" y="3.11"/>
<vertex x="13.55" y="3.04"/>
<vertex x="13.56" y="2.98"/>
<vertex x="13.57" y="2.91"/>
<vertex x="13.58" y="2.85"/>
<vertex x="13.59" y="2.79"/>
<vertex x="13.6" y="2.74"/>
<vertex x="13.61" y="2.69"/>
<vertex x="13.63" y="2.64"/>
<vertex x="13.65" y="2.6"/>
<vertex x="13.66" y="2.56"/>
<vertex x="13.68" y="2.52"/>
<vertex x="13.61" y="2.52"/>
<vertex x="13.53" y="2.52"/>
<vertex x="13.46" y="2.52"/>
<vertex x="13.39" y="2.52"/>
<vertex x="13.31" y="2.52"/>
<vertex x="13.24" y="2.52"/>
<vertex x="13.17" y="2.52"/>
<vertex x="13.09" y="2.52"/>
<vertex x="13.02" y="2.52"/>
<vertex x="12.94" y="2.52"/>
<vertex x="12.87" y="2.52"/>
<vertex x="12.8" y="2.52"/>
<vertex x="12.72" y="2.52"/>
<vertex x="12.65" y="2.52"/>
<vertex x="12.58" y="2.52"/>
<vertex x="12.5" y="2.52"/>
<vertex x="12.49" y="2.55"/>
<vertex x="12.48" y="2.57"/>
<vertex x="12.48" y="2.6"/>
<vertex x="12.47" y="2.62"/>
<vertex x="12.46" y="2.65"/>
<vertex x="12.45" y="2.67"/>
<vertex x="12.45" y="2.7"/>
<vertex x="12.44" y="2.72"/>
<vertex x="12.43" y="2.75"/>
<vertex x="12.43" y="2.78"/>
<vertex x="12.43" y="2.8"/>
<vertex x="12.43" y="2.83"/>
<vertex x="12.42" y="2.85"/>
<vertex x="12.42" y="2.88"/>
<vertex x="12.42" y="2.91"/>
<vertex x="12.42" y="2.93"/>
<vertex x="12.35" y="2.86"/>
<vertex x="12.28" y="2.8"/>
<vertex x="12.2" y="2.74"/>
<vertex x="12.12" y="2.69"/>
<vertex x="12.03" y="2.64"/>
<vertex x="11.95" y="2.6"/>
<vertex x="11.86" y="2.56"/>
<vertex x="11.77" y="2.53"/>
<vertex x="11.67" y="2.5"/>
<vertex x="11.58" y="2.47"/>
<vertex x="11.48" y="2.45"/>
<vertex x="11.39" y="2.44"/>
<vertex x="11.29" y="2.42"/>
<vertex x="11.19" y="2.41"/>
<vertex x="11.09" y="2.41"/>
<vertex x="10.99" y="2.41"/>
<vertex x="10.84" y="2.41"/>
<vertex x="10.7" y="2.42"/>
<vertex x="10.43" y="2.48"/>
<vertex x="10.3" y="2.52"/>
<vertex x="10.18" y="2.57"/>
<vertex x="10.07" y="2.64"/>
<vertex x="9.97" y="2.71"/>
<vertex x="9.88" y="2.8"/>
<vertex x="9.79" y="2.89"/>
<vertex x="9.72" y="2.99"/>
<vertex x="9.66" y="3.11"/>
<vertex x="9.61" y="3.23"/>
<vertex x="9.58" y="3.37"/>
<vertex x="9.56" y="3.52"/>
<vertex x="9.55" y="3.67"/>
<vertex x="9.58" y="4"/>
<vertex x="9.68" y="4.27"/>
<vertex x="9.82" y="4.48"/>
<vertex x="10" y="4.64"/>
<vertex x="10.22" y="4.76"/>
<vertex x="10.46" y="4.85"/>
<vertex x="10.72" y="4.92"/>
</polygon>
<vertex x="14.19" y="6.57"/>
<vertex x="14.33" y="6.6"/>
<vertex x="14.47" y="6.62"/>
<vertex x="14.61" y="6.65"/>
<vertex x="14.75" y="6.67"/>
<vertex x="14.89" y="6.7"/>
<vertex x="15.02" y="6.72"/>
<vertex x="15.16" y="6.74"/>
<vertex x="15.3" y="6.77"/>
<vertex x="15.3" y="6.67"/>
<vertex x="15.3" y="6.57"/>
<vertex x="15.3" y="6.47"/>
<vertex x="15.3" y="6.37"/>
<vertex x="15.3" y="6.28"/>
<vertex x="15.3" y="6.18"/>
<vertex x="15.3" y="6.08"/>
<vertex x="15.3" y="5.98"/>
<vertex x="15.31" y="5.98"/>
<vertex x="15.41" y="6.17"/>
<vertex x="15.53" y="6.35"/>
<vertex x="15.68" y="6.5"/>
<vertex x="15.85" y="6.63"/>
<vertex x="16.04" y="6.74"/>
<vertex x="16.24" y="6.82"/>
<vertex x="16.45" y="6.87"/>
<vertex x="16.66" y="6.88"/>
<vertex x="16.7" y="6.88"/>
<vertex x="16.73" y="6.88"/>
<vertex x="16.76" y="6.88"/>
<vertex x="16.79" y="6.88"/>
<vertex x="16.82" y="6.87"/>
<vertex x="16.86" y="6.87"/>
<vertex x="16.89" y="6.86"/>
<vertex x="16.92" y="6.85"/>
<vertex x="16.92" y="6.71"/>
<vertex x="16.92" y="6.58"/>
<vertex x="16.92" y="6.44"/>
<vertex x="16.92" y="6.31"/>
<vertex x="16.92" y="6.17"/>
<vertex x="16.92" y="6.03"/>
<vertex x="16.92" y="5.9"/>
<vertex x="16.92" y="5.76"/>
<vertex x="16.87" y="5.77"/>
<vertex x="16.83" y="5.78"/>
<vertex x="16.77" y="5.79"/>
<vertex x="16.72" y="5.8"/>
<vertex x="16.66" y="5.8"/>
<vertex x="16.61" y="5.8"/>
<vertex x="16.55" y="5.8"/>
<vertex x="16.5" y="5.8"/>
<vertex x="16.2" y="5.77"/>
<vertex x="15.96" y="5.69"/>
<vertex x="15.76" y="5.57"/>
<vertex x="15.6" y="5.4"/>
<vertex x="15.49" y="5.2"/>
<vertex x="15.41" y="4.97"/>
<vertex x="15.36" y="4.71"/>
<vertex x="15.35" y="4.44"/>
<vertex x="15.35" y="4.2"/>
<vertex x="15.35" y="3.96"/>
<vertex x="15.35" y="3.72"/>
<vertex x="15.35" y="3.48"/>
<vertex x="15.35" y="3.24"/>
<vertex x="15.35" y="3.01"/>
<vertex x="15.35" y="2.77"/>
<vertex x="15.35" y="2.53"/>
<vertex x="15.2" y="2.53"/>
<vertex x="15.06" y="2.53"/>
<vertex x="14.91" y="2.53"/>
<vertex x="14.77" y="2.53"/>
<vertex x="14.62" y="2.53"/>
<vertex x="14.48" y="2.53"/>
<vertex x="14.33" y="2.53"/>
<vertex x="14.18" y="2.53"/>
<vertex x="14.18" y="3.03"/>
<vertex x="14.18" y="3.54"/>
<vertex x="14.18" y="4.04"/>
<vertex x="14.18" y="4.55"/>
<vertex x="14.18" y="5.06"/>
<vertex x="14.18" y="5.56"/>
<vertex x="14.18" y="6.07"/>
</polygon>
<vertex x="17.38" y="7.75"/>
<vertex x="18.54" y="8.39"/>
<vertex x="18.54" y="5.24"/>
<vertex x="20.01" y="6.77"/>
<vertex x="21.39" y="6.77"/>
<vertex x="19.79" y="5.21"/>
<vertex x="21.57" y="2.53"/>
<vertex x="20.16" y="2.53"/>
<vertex x="18.99" y="4.42"/>
<vertex x="18.54" y="3.99"/>
<vertex x="18.54" y="2.53"/>
<vertex x="17.38" y="2.53"/>
</polygon>
<vertex x="22.28" y="5.99"/>
<vertex x="22.13" y="5.99"/>
<vertex x="21.99" y="5.99"/>
<vertex x="21.85" y="5.99"/>
<vertex x="21.7" y="5.99"/>
<vertex x="21.56" y="5.99"/>
<vertex x="21.42" y="5.99"/>
<vertex x="21.27" y="5.99"/>
<vertex x="21.13" y="5.99"/>
<vertex x="21.23" y="6.09"/>
<vertex x="21.33" y="6.19"/>
<vertex x="21.43" y="6.28"/>
<vertex x="21.52" y="6.38"/>
<vertex x="21.62" y="6.48"/>
<vertex x="21.72" y="6.58"/>
<vertex x="21.82" y="6.67"/>
<vertex x="21.92" y="6.77"/>
<vertex x="21.97" y="6.77"/>
<vertex x="22.01" y="6.77"/>
<vertex x="22.05" y="6.77"/>
<vertex x="22.1" y="6.77"/>
<vertex x="22.14" y="6.77"/>
<vertex x="22.19" y="6.77"/>
<vertex x="22.23" y="6.77"/>
<vertex x="22.28" y="6.77"/>
<vertex x="22.28" y="6.81"/>
<vertex x="22.28" y="6.85"/>
<vertex x="22.28" y="6.89"/>
<vertex x="22.28" y="6.93"/>
<vertex x="22.28" y="6.97"/>
<vertex x="22.28" y="7.01"/>
<vertex x="22.28" y="7.05"/>
<vertex x="22.28" y="7.1"/>
<vertex x="22.3" y="7.37"/>
<vertex x="22.36" y="7.62"/>
<vertex x="22.47" y="7.84"/>
<vertex x="22.63" y="8.02"/>
<vertex x="22.83" y="8.18"/>
<vertex x="23.07" y="8.29"/>
<vertex x="23.36" y="8.36"/>
<vertex x="23.7" y="8.38"/>
<vertex x="23.77" y="8.38"/>
<vertex x="23.85" y="8.38"/>
<vertex x="23.93" y="8.38"/>
<vertex x="24.01" y="8.38"/>
<vertex x="24.08" y="8.37"/>
<vertex x="24.16" y="8.36"/>
<vertex x="24.24" y="8.36"/>
<vertex x="24.31" y="8.36"/>
<vertex x="24.31" y="8.25"/>
<vertex x="24.31" y="8.14"/>
<vertex x="24.31" y="8.03"/>
<vertex x="24.31" y="7.92"/>
<vertex x="24.31" y="7.82"/>
<vertex x="24.31" y="7.71"/>
<vertex x="24.31" y="7.6"/>
<vertex x="24.31" y="7.49"/>
<vertex x="24.26" y="7.5"/>
<vertex x="24.21" y="7.51"/>
<vertex x="24.15" y="7.51"/>
<vertex x="24.1" y="7.51"/>
<vertex x="24.04" y="7.51"/>
<vertex x="23.99" y="7.51"/>
<vertex x="23.94" y="7.51"/>
<vertex x="23.89" y="7.51"/>
<vertex x="23.77" y="7.5"/>
<vertex x="23.68" y="7.48"/>
<vertex x="23.6" y="7.45"/>
<vertex x="23.54" y="7.4"/>
<vertex x="23.5" y="7.33"/>
<vertex x="23.47" y="7.25"/>
<vertex x="23.45" y="7.14"/>
<vertex x="23.44" y="7.02"/>
<vertex x="23.44" y="6.99"/>
<vertex x="23.44" y="6.96"/>
<vertex x="23.44" y="6.93"/>
<vertex x="23.44" y="6.89"/>
<vertex x="23.44" y="6.86"/>
<vertex x="23.44" y="6.83"/>
<vertex x="23.44" y="6.8"/>
<vertex x="23.44" y="6.77"/>
<vertex x="23.54" y="6.77"/>
<vertex x="23.64" y="6.77"/>
<vertex x="23.74" y="6.77"/>
<vertex x="23.84" y="6.77"/>
<vertex x="23.94" y="6.77"/>
<vertex x="24.04" y="6.77"/>
<vertex x="24.14" y="6.77"/>
<vertex x="24.24" y="6.77"/>
<vertex x="24.24" y="6.67"/>
<vertex x="24.24" y="6.57"/>
<vertex x="24.24" y="6.48"/>
<vertex x="24.24" y="6.38"/>
<vertex x="24.24" y="6.28"/>
<vertex x="24.24" y="6.18"/>
<vertex x="24.24" y="6.09"/>
<vertex x="24.24" y="5.99"/>
<vertex x="24.14" y="5.99"/>
<vertex x="24.04" y="5.99"/>
<vertex x="23.94" y="5.99"/>
<vertex x="23.84" y="5.99"/>
<vertex x="23.74" y="5.99"/>
<vertex x="23.64" y="5.99"/>
<vertex x="23.54" y="5.99"/>
<vertex x="23.44" y="5.99"/>
<vertex x="23.44" y="5.56"/>
<vertex x="23.44" y="5.12"/>
<vertex x="23.44" y="4.69"/>
<vertex x="23.44" y="4.26"/>
<vertex x="23.44" y="3.82"/>
<vertex x="23.44" y="3.39"/>
<vertex x="23.44" y="2.96"/>
<vertex x="23.44" y="2.53"/>
<vertex x="23.3" y="2.53"/>
<vertex x="23.15" y="2.53"/>
<vertex x="23" y="2.53"/>
<vertex x="22.86" y="2.53"/>
<vertex x="22.71" y="2.53"/>
<vertex x="22.57" y="2.53"/>
<vertex x="22.42" y="2.53"/>
<vertex x="22.28" y="2.53"/>
<vertex x="22.28" y="2.96"/>
<vertex x="22.28" y="3.39"/>
<vertex x="22.28" y="3.82"/>
<vertex x="22.28" y="4.26"/>
<vertex x="22.28" y="4.69"/>
<vertex x="22.28" y="5.12"/>
<vertex x="22.28" y="5.56"/>
</polygon>
<vertex x="28.55" y="2.53"/>
<vertex x="28.41" y="2.53"/>
<vertex x="28.27" y="2.53"/>
<vertex x="28.14" y="2.53"/>
<vertex x="28" y="2.53"/>
<vertex x="27.86" y="2.53"/>
<vertex x="27.72" y="2.53"/>
<vertex x="27.58" y="2.53"/>
<vertex x="27.44" y="2.53"/>
<vertex x="27.44" y="2.6"/>
<vertex x="27.44" y="2.68"/>
<vertex x="27.44" y="2.75"/>
<vertex x="27.44" y="2.82"/>
<vertex x="27.44" y="2.9"/>
<vertex x="27.44" y="2.97"/>
<vertex x="27.44" y="3.04"/>
<vertex x="27.44" y="3.12"/>
<vertex x="27.43" y="3.12"/>
<vertex x="27.31" y="2.95"/>
<vertex x="27.17" y="2.8"/>
<vertex x="27.02" y="2.68"/>
<vertex x="26.86" y="2.58"/>
<vertex x="26.68" y="2.51"/>
<vertex x="26.5" y="2.46"/>
<vertex x="26.32" y="2.42"/>
<vertex x="26.13" y="2.41"/>
<vertex x="25.71" y="2.44"/>
<vertex x="25.37" y="2.54"/>
<vertex x="25.1" y="2.69"/>
<vertex x="24.89" y="2.89"/>
<vertex x="24.75" y="3.15"/>
<vertex x="24.65" y="3.44"/>
<vertex x="24.6" y="3.78"/>
<vertex x="24.58" y="4.16"/>
<vertex x="24.58" y="4.49"/>
<vertex x="24.58" y="4.81"/>
<vertex x="24.58" y="5.14"/>
<vertex x="24.58" y="5.46"/>
<vertex x="24.58" y="5.79"/>
<vertex x="24.58" y="6.12"/>
<vertex x="24.58" y="6.44"/>
<vertex x="24.58" y="6.77"/>
<vertex x="24.73" y="6.77"/>
<vertex x="24.87" y="6.77"/>
<vertex x="25.02" y="6.77"/>
<vertex x="25.17" y="6.77"/>
<vertex x="25.31" y="6.77"/>
<vertex x="25.46" y="6.77"/>
<vertex x="25.6" y="6.77"/>
<vertex x="25.75" y="6.77"/>
<vertex x="25.75" y="6.47"/>
<vertex x="25.75" y="6.17"/>
<vertex x="25.75" y="5.87"/>
<vertex x="25.75" y="5.57"/>
<vertex x="25.75" y="5.27"/>
<vertex x="25.75" y="4.97"/>
<vertex x="25.75" y="4.67"/>
<vertex x="25.75" y="4.37"/>
<vertex x="25.76" y="4.13"/>
<vertex x="25.79" y="3.92"/>
<vertex x="25.84" y="3.74"/>
<vertex x="25.92" y="3.59"/>
<vertex x="26.02" y="3.48"/>
<vertex x="26.15" y="3.4"/>
<vertex x="26.31" y="3.35"/>
<vertex x="26.5" y="3.33"/>
<vertex x="26.72" y="3.35"/>
<vertex x="26.9" y="3.4"/>
<vertex x="27.06" y="3.49"/>
<vertex x="27.18" y="3.62"/>
<vertex x="27.28" y="3.78"/>
<vertex x="27.35" y="3.99"/>
<vertex x="27.39" y="4.25"/>
<vertex x="27.4" y="4.55"/>
<vertex x="27.4" y="4.82"/>
<vertex x="27.4" y="5.1"/>
<vertex x="27.4" y="5.38"/>
<vertex x="27.4" y="5.66"/>
<vertex x="27.4" y="5.94"/>
<vertex x="27.4" y="6.21"/>
<vertex x="27.4" y="6.49"/>
<vertex x="27.4" y="6.77"/>
<vertex x="27.54" y="6.77"/>
<vertex x="27.69" y="6.77"/>
<vertex x="27.84" y="6.77"/>
<vertex x="27.98" y="6.77"/>
<vertex x="28.13" y="6.77"/>
<vertex x="28.27" y="6.77"/>
<vertex x="28.42" y="6.77"/>
<vertex x="28.56" y="6.77"/>
<vertex x="28.56" y="6.24"/>
<vertex x="28.56" y="5.71"/>
<vertex x="28.56" y="5.18"/>
<vertex x="28.56" y="4.65"/>
<vertex x="28.56" y="4.12"/>
<vertex x="28.56" y="3.59"/>
<vertex x="28.56" y="3.06"/>
</polygon>
<vertex x="29.2" y="6.77"/>
<vertex x="29.33" y="6.77"/>
<vertex x="29.47" y="6.77"/>
<vertex x="29.61" y="6.77"/>
<vertex x="29.75" y="6.77"/>
<vertex x="29.89" y="6.77"/>
<vertex x="30.03" y="6.77"/>
<vertex x="30.16" y="6.77"/>
<vertex x="30.3" y="6.77"/>
<vertex x="30.3" y="6.7"/>
<vertex x="30.3" y="6.62"/>
<vertex x="30.3" y="6.55"/>
<vertex x="30.3" y="6.48"/>
<vertex x="30.3" y="6.4"/>
<vertex x="30.3" y="6.33"/>
<vertex x="30.3" y="6.25"/>
<vertex x="30.3" y="6.18"/>
<vertex x="30.31" y="6.18"/>
<vertex x="30.32" y="6.18"/>
<vertex x="30.44" y="6.35"/>
<vertex x="30.57" y="6.49"/>
<vertex x="30.73" y="6.62"/>
<vertex x="30.89" y="6.71"/>
<vertex x="31.06" y="6.79"/>
<vertex x="31.24" y="6.84"/>
<vertex x="31.43" y="6.88"/>
<vertex x="31.61" y="6.89"/>
<vertex x="32.03" y="6.85"/>
<vertex x="32.38" y="6.76"/>
<vertex x="32.65" y="6.61"/>
<vertex x="32.85" y="6.41"/>
<vertex x="33" y="6.15"/>
<vertex x="33.09" y="5.85"/>
<vertex x="33.15" y="5.51"/>
<vertex x="33.16" y="5.14"/>
<vertex x="33.16" y="4.81"/>
<vertex x="33.16" y="4.49"/>
<vertex x="33.16" y="4.16"/>
<vertex x="33.16" y="3.83"/>
<vertex x="33.16" y="3.51"/>
<vertex x="33.16" y="3.18"/>
<vertex x="33.16" y="2.86"/>
<vertex x="33.16" y="2.53"/>
<vertex x="33.02" y="2.53"/>
<vertex x="32.87" y="2.53"/>
<vertex x="32.73" y="2.53"/>
<vertex x="32.58" y="2.53"/>
<vertex x="32.43" y="2.53"/>
<vertex x="32.29" y="2.53"/>
<vertex x="32.14" y="2.53"/>
<vertex x="32" y="2.53"/>
<vertex x="32" y="2.83"/>
<vertex x="32" y="3.13"/>
<vertex x="32" y="3.43"/>
<vertex x="32" y="3.73"/>
<vertex x="32" y="4.03"/>
<vertex x="32" y="4.33"/>
<vertex x="32" y="4.63"/>
<vertex x="32" y="4.92"/>
<vertex x="31.99" y="5.17"/>
<vertex x="31.96" y="5.38"/>
<vertex x="31.91" y="5.56"/>
<vertex x="31.83" y="5.71"/>
<vertex x="31.73" y="5.82"/>
<vertex x="31.6" y="5.9"/>
<vertex x="31.44" y="5.95"/>
<vertex x="31.25" y="5.97"/>
<vertex x="31.03" y="5.95"/>
<vertex x="30.84" y="5.9"/>
<vertex x="30.69" y="5.81"/>
<vertex x="30.56" y="5.68"/>
<vertex x="30.47" y="5.51"/>
<vertex x="30.4" y="5.31"/>
<vertex x="30.36" y="5.05"/>
<vertex x="30.35" y="4.75"/>
<vertex x="30.35" y="4.47"/>
<vertex x="30.35" y="4.2"/>
<vertex x="30.35" y="3.92"/>
<vertex x="30.35" y="3.64"/>
<vertex x="30.35" y="3.36"/>
<vertex x="30.35" y="3.08"/>
<vertex x="30.35" y="2.81"/>
<vertex x="30.35" y="2.53"/>
<vertex x="30.2" y="2.53"/>
<vertex x="30.06" y="2.53"/>
<vertex x="29.91" y="2.53"/>
<vertex x="29.77" y="2.53"/>
<vertex x="29.62" y="2.53"/>
<vertex x="29.47" y="2.53"/>
<vertex x="29.33" y="2.53"/>
<vertex x="29.18" y="2.53"/>
<vertex x="29.18" y="3.06"/>
<vertex x="29.18" y="3.59"/>
<vertex x="29.18" y="4.12"/>
<vertex x="29.18" y="4.65"/>
<vertex x="29.18" y="5.18"/>
<vertex x="29.18" y="5.71"/>
<vertex x="29.18" y="6.24"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.4">
<vertex x="1.47" y="5.2"/>
<vertex x="1.5" y="4.96"/>
<vertex x="1.57" y="4.77"/>
<vertex x="1.69" y="4.6"/>
<vertex x="1.84" y="4.47"/>
<vertex x="2.02" y="4.37"/>
<vertex x="2.22" y="4.3"/>
<vertex x="2.44" y="4.26"/>
<vertex x="2.66" y="4.25"/>
<vertex x="2.83" y="4.26"/>
<vertex x="3.01" y="4.29"/>
<vertex x="3.18" y="4.33"/>
<vertex x="3.33" y="4.41"/>
<vertex x="3.47" y="4.5"/>
<vertex x="3.58" y="4.63"/>
<vertex x="3.65" y="4.78"/>
<vertex x="3.68" y="4.97"/>
<vertex x="3.65" y="5.13"/>
<vertex x="3.56" y="5.27"/>
<vertex x="3.41" y="5.39"/>
<vertex x="3.21" y="5.5"/>
<vertex x="2.96" y="5.59"/>
<vertex x="2.66" y="5.68"/>
<vertex x="2.31" y="5.76"/>
<vertex x="1.92" y="5.84"/>
<vertex x="1.58" y="5.93"/>
<vertex x="1.26" y="6.03"/>
<vertex x="0.96" y="6.15"/>
<vertex x="0.69" y="6.3"/>
<vertex x="0.46" y="6.49"/>
<vertex x="0.28" y="6.72"/>
<vertex x="0.17" y="7.01"/>
<vertex x="0.13" y="7.35"/>
<vertex x="0.19" y="7.84"/>
<vertex x="0.34" y="8.24"/>
<vertex x="0.59" y="8.56"/>
<vertex x="0.9" y="8.8"/>
<vertex x="1.28" y="8.97"/>
<vertex x="1.69" y="9.08"/>
<vertex x="2.13" y="9.14"/>
<vertex x="2.59" y="9.16"/>
<vertex x="3.04" y="9.14"/>
<vertex x="3.47" y="9.08"/>
<vertex x="3.88" y="8.96"/>
<vertex x="4.24" y="8.78"/>
<vertex x="4.56" y="8.54"/>
<vertex x="4.81" y="8.23"/>
<vertex x="4.98" y="7.84"/>
<vertex x="5.07" y="7.36"/>
<vertex x="4.89" y="7.36"/>
<vertex x="4.71" y="7.36"/>
<vertex x="4.52" y="7.36"/>
<vertex x="4.34" y="7.36"/>
<vertex x="4.15" y="7.36"/>
<vertex x="3.97" y="7.36"/>
<vertex x="3.79" y="7.36"/>
<vertex x="3.6" y="7.36"/>
<vertex x="3.57" y="7.57"/>
<vertex x="3.5" y="7.74"/>
<vertex x="3.39" y="7.87"/>
<vertex x="3.26" y="7.97"/>
<vertex x="3.11" y="8.04"/>
<vertex x="2.94" y="8.09"/>
<vertex x="2.75" y="8.12"/>
<vertex x="2.54" y="8.13"/>
<vertex x="2.41" y="8.13"/>
<vertex x="2.26" y="8.12"/>
<vertex x="2.12" y="8.09"/>
<vertex x="1.98" y="8.05"/>
<vertex x="1.86" y="7.98"/>
<vertex x="1.77" y="7.89"/>
<vertex x="1.7" y="7.77"/>
<vertex x="1.68" y="7.61"/>
<vertex x="1.72" y="7.42"/>
<vertex x="1.83" y="7.27"/>
<vertex x="2.01" y="7.15"/>
<vertex x="2.23" y="7.06"/>
<vertex x="2.5" y="6.98"/>
<vertex x="2.79" y="6.91"/>
<vertex x="3.11" y="6.84"/>
<vertex x="3.44" y="6.77"/>
<vertex x="3.77" y="6.69"/>
<vertex x="4.1" y="6.58"/>
<vertex x="4.4" y="6.45"/>
<vertex x="4.67" y="6.29"/>
<vertex x="4.9" y="6.09"/>
<vertex x="5.07" y="5.85"/>
<vertex x="5.19" y="5.55"/>
<vertex x="5.23" y="5.19"/>
<vertex x="5.17" y="4.68"/>
<vertex x="5" y="4.25"/>
<vertex x="4.75" y="3.91"/>
<vertex x="4.42" y="3.65"/>
<vertex x="4.03" y="3.45"/>
<vertex x="3.59" y="3.32"/>
<vertex x="3.13" y="3.25"/>
<vertex x="2.65" y="3.22"/>
<vertex x="2.16" y="3.25"/>
<vertex x="1.69" y="3.32"/>
<vertex x="1.25" y="3.46"/>
<vertex x="0.85" y="3.66"/>
<vertex x="0.52" y="3.92"/>
<vertex x="0.25" y="4.27"/>
<vertex x="0.08" y="4.69"/>
<vertex x="0" y="5.2"/>
<vertex x="0.18" y="5.2"/>
<vertex x="0.37" y="5.2"/>
<vertex x="0.55" y="5.2"/>
<vertex x="0.74" y="5.2"/>
<vertex x="0.92" y="5.2"/>
<vertex x="1.1" y="5.2"/>
<vertex x="1.29" y="5.2"/>
</polygon>
<vertex x="9.88" y="5.2"/>
<vertex x="9.97" y="5.5"/>
<vertex x="10.02" y="5.83"/>
<vertex x="10.04" y="6.17"/>
<vertex x="11.59" y="6.12"/>
<vertex x="11.55" y="5.57"/>
<vertex x="11.43" y="5.03"/>
<vertex x="11.24" y="4.54"/>
</polygon>
<vertex x="10.97" y="4.1"/>
<vertex x="10.62" y="3.74"/>
<vertex x="10.2" y="3.45"/>
<vertex x="9.69" y="3.27"/>
<vertex x="9.11" y="3.21"/>
<vertex x="8.85" y="3.22"/>
<vertex x="8.61" y="3.27"/>
<vertex x="8.37" y="3.33"/>
<vertex x="8.15" y="3.43"/>
<vertex x="7.94" y="3.55"/>
<vertex x="7.75" y="3.69"/>
<vertex x="7.57" y="3.87"/>
<vertex x="7.42" y="4.06"/>
<vertex x="7.41" y="4.06"/>
<vertex x="7.41" y="3.55"/>
<vertex x="7.41" y="3.05"/>
<vertex x="7.41" y="2.54"/>
<vertex x="7.41" y="2.03"/>
<vertex x="7.41" y="1.52"/>
<vertex x="7.41" y="1.02"/>
<vertex x="7.41" y="0.51"/>
<vertex x="7.41" y="0"/>
<vertex x="7.22" y="0.17"/>
<vertex x="7.02" y="0.34"/>
<vertex x="6.83" y="0.52"/>
<vertex x="6.63" y="0.69"/>
<vertex x="6.44" y="0.86"/>
<vertex x="6.25" y="1.03"/>
<vertex x="6.05" y="1.21"/>
<vertex x="5.86" y="1.38"/>
<vertex x="5.86" y="2.3"/>
<vertex x="5.86" y="3.22"/>
<vertex x="5.86" y="4.14"/>
<vertex x="5.86" y="5.06"/>
<vertex x="5.86" y="5.98"/>
<vertex x="5.86" y="6.9"/>
<vertex x="5.86" y="7.82"/>
<vertex x="5.86" y="8.74"/>
<vertex x="6.04" y="8.78"/>
<vertex x="6.23" y="8.81"/>
<vertex x="6.41" y="8.84"/>
<vertex x="6.6" y="8.87"/>
<vertex x="6.78" y="8.91"/>
<vertex x="6.96" y="8.94"/>
<vertex x="7.15" y="8.97"/>
<vertex x="7.33" y="9"/>
<vertex x="7.33" y="8.91"/>
<vertex x="7.33" y="8.82"/>
<vertex x="7.33" y="8.73"/>
<vertex x="7.33" y="8.64"/>
<vertex x="7.33" y="8.55"/>
<vertex x="7.33" y="8.46"/>
<vertex x="7.33" y="8.37"/>
<vertex x="7.33" y="8.28"/>
<vertex x="7.34" y="8.28"/>
<vertex x="7.5" y="8.5"/>
<vertex x="7.67" y="8.68"/>
<vertex x="7.86" y="8.83"/>
<vertex x="8.06" y="8.95"/>
<vertex x="8.29" y="9.04"/>
<vertex x="8.52" y="9.11"/>
<vertex x="8.77" y="9.14"/>
<vertex x="9.02" y="9.16"/>
<vertex x="9.64" y="9.09"/>
<vertex x="10.17" y="8.91"/>
<vertex x="10.61" y="8.62"/>
<vertex x="10.97" y="8.24"/>
<vertex x="11.24" y="7.79"/>
<vertex x="11.43" y="7.27"/>
<vertex x="11.55" y="6.71"/>
<vertex x="10.02" y="6.5"/>
<vertex x="9.96" y="6.83"/>
<vertex x="9.87" y="7.14"/>
<vertex x="9.73" y="7.42"/>
<vertex x="9.55" y="7.65"/>
<vertex x="9.31" y="7.83"/>
<vertex x="9.03" y="7.95"/>
<vertex x="8.68" y="7.99"/>
<vertex x="8.33" y="7.95"/>
<vertex x="8.05" y="7.83"/>
<vertex x="7.81" y="7.65"/>
<vertex x="7.63" y="7.42"/>
<vertex x="7.5" y="7.15"/>
<vertex x="7.41" y="6.84"/>
<vertex x="7.36" y="6.51"/>
<vertex x="7.34" y="6.17"/>
<vertex x="7.36" y="5.83"/>
<vertex x="7.41" y="5.5"/>
<vertex x="7.51" y="5.2"/>
<vertex x="7.64" y="4.93"/>
<vertex x="7.83" y="4.7"/>
<vertex x="8.06" y="4.53"/>
<vertex x="8.35" y="4.42"/>
<vertex x="8.7" y="4.38"/>
<vertex x="9.04" y="4.42"/>
<vertex x="9.33" y="4.53"/>
<vertex x="9.57" y="4.7"/>
<vertex x="9.75" y="4.93"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="13.94" y="6.6"/>
<vertex x="14.29" y="6.64"/>
<vertex x="14.63" y="6.68"/>
<vertex x="14.95" y="6.73"/>
<vertex x="15.14" y="5.89"/>
<vertex x="15.05" y="5.88"/>
<vertex x="14.96" y="5.86"/>
<vertex x="14.86" y="5.85"/>
<vertex x="14.77" y="5.84"/>
<vertex x="14.68" y="5.82"/>
<vertex x="14.59" y="5.81"/>
<vertex x="14.5" y="5.79"/>
<vertex x="14.41" y="5.78"/>
<vertex x="14.32" y="5.76"/>
<vertex x="14.23" y="5.74"/>
</polygon>
<vertex x="14.23" y="5.73"/>
<vertex x="14.15" y="5.71"/>
<vertex x="14.07" y="5.68"/>
<vertex x="14" y="5.64"/>
<vertex x="13.92" y="5.6"/>
<vertex x="13.86" y="5.56"/>
<vertex x="13.8" y="5.51"/>
<vertex x="13.74" y="5.45"/>
<vertex x="13.7" y="5.39"/>
<vertex x="13.66" y="5.32"/>
<vertex x="13.62" y="5.24"/>
<vertex x="13.6" y="5.16"/>
<vertex x="13.58" y="5.06"/>
<vertex x="13.58" y="4.96"/>
<vertex x="13.58" y="4.86"/>
<vertex x="13.6" y="4.77"/>
<vertex x="13.62" y="4.69"/>
<vertex x="13.66" y="4.61"/>
<vertex x="13.7" y="4.54"/>
<vertex x="13.75" y="4.49"/>
<vertex x="13.8" y="4.43"/>
<vertex x="13.87" y="4.39"/>
<vertex x="13.94" y="4.35"/>
<vertex x="14.01" y="4.32"/>
<vertex x="14.09" y="4.3"/>
<vertex x="14.17" y="4.28"/>
<vertex x="14.26" y="4.26"/>
<vertex x="14.35" y="4.25"/>
<vertex x="14.44" y="4.25"/>
<vertex x="14.53" y="4.25"/>
<vertex x="14.74" y="4.26"/>
<vertex x="14.93" y="4.29"/>
<vertex x="15.1" y="4.34"/>
<vertex x="15.24" y="4.4"/>
<vertex x="15.36" y="4.48"/>
<vertex x="15.46" y="4.57"/>
<vertex x="15.54" y="4.66"/>
<vertex x="15.61" y="4.77"/>
<vertex x="15.67" y="4.87"/>
<vertex x="15.71" y="4.98"/>
<vertex x="15.74" y="5.09"/>
<vertex x="15.76" y="5.2"/>
<vertex x="15.77" y="5.3"/>
<vertex x="15.78" y="5.39"/>
<vertex x="15.78" y="5.48"/>
<vertex x="15.78" y="5.55"/>
<vertex x="15.78" y="5.58"/>
<vertex x="15.78" y="5.62"/>
<vertex x="15.78" y="5.66"/>
<vertex x="15.78" y="5.69"/>
<vertex x="15.78" y="5.73"/>
<vertex x="15.78" y="5.76"/>
<vertex x="15.78" y="5.8"/>
<vertex x="15.78" y="5.84"/>
<vertex x="15.78" y="5.87"/>
<vertex x="15.78" y="5.91"/>
<vertex x="15.78" y="5.94"/>
<vertex x="15.78" y="5.98"/>
<vertex x="15.78" y="6.02"/>
<vertex x="15.78" y="6.05"/>
<vertex x="15.78" y="6.09"/>
<vertex x="15.78" y="6.12"/>
<vertex x="15.73" y="6.08"/>
<vertex x="15.67" y="6.05"/>
<vertex x="15.61" y="6.02"/>
<vertex x="15.54" y="5.99"/>
<vertex x="15.47" y="5.96"/>
<vertex x="15.39" y="5.94"/>
<vertex x="15.31" y="5.92"/>
<vertex x="15.22" y="5.91"/>
<vertex x="15.23" y="6.8"/>
<vertex x="15.46" y="6.88"/>
<vertex x="15.64" y="6.99"/>
<vertex x="15.75" y="7.15"/>
<vertex x="15.78" y="7.35"/>
<vertex x="15.78" y="7.47"/>
<vertex x="15.77" y="7.58"/>
<vertex x="15.74" y="7.67"/>
<vertex x="15.71" y="7.75"/>
<vertex x="15.66" y="7.82"/>
<vertex x="15.61" y="7.89"/>
<vertex x="15.55" y="7.94"/>
<vertex x="15.49" y="7.98"/>
<vertex x="15.42" y="8.02"/>
<vertex x="15.34" y="8.05"/>
<vertex x="15.26" y="8.07"/>
<vertex x="15.17" y="8.09"/>
<vertex x="15.08" y="8.11"/>
<vertex x="14.98" y="8.12"/>
<vertex x="14.88" y="8.12"/>
<vertex x="14.78" y="8.12"/>
<vertex x="14.67" y="8.12"/>
<vertex x="14.57" y="8.1"/>
<vertex x="14.47" y="8.09"/>
<vertex x="14.38" y="8.07"/>
<vertex x="14.29" y="8.04"/>
<vertex x="14.21" y="8.01"/>
<vertex x="14.13" y="7.97"/>
<vertex x="14.06" y="7.92"/>
<vertex x="14" y="7.86"/>
<vertex x="13.95" y="7.8"/>
<vertex x="13.9" y="7.73"/>
<vertex x="13.86" y="7.65"/>
<vertex x="13.82" y="7.57"/>
<vertex x="13.79" y="7.47"/>
<vertex x="13.77" y="7.37"/>
<vertex x="13.76" y="7.26"/>
<vertex x="13.66" y="7.26"/>
<vertex x="13.56" y="7.26"/>
<vertex x="13.47" y="7.26"/>
<vertex x="13.37" y="7.26"/>
<vertex x="13.27" y="7.26"/>
<vertex x="13.18" y="7.26"/>
<vertex x="13.08" y="7.26"/>
<vertex x="12.98" y="7.26"/>
<vertex x="12.89" y="7.26"/>
<vertex x="12.79" y="7.26"/>
<vertex x="12.69" y="7.26"/>
<vertex x="12.6" y="7.26"/>
<vertex x="12.5" y="7.26"/>
<vertex x="12.4" y="7.26"/>
<vertex x="12.31" y="7.26"/>
<vertex x="12.21" y="7.26"/>
<vertex x="12.24" y="7.52"/>
<vertex x="12.3" y="7.76"/>
<vertex x="12.38" y="7.97"/>
<vertex x="12.48" y="8.16"/>
<vertex x="12.61" y="8.34"/>
<vertex x="12.75" y="8.49"/>
<vertex x="12.92" y="8.63"/>
<vertex x="13.09" y="8.75"/>
<vertex x="13.29" y="8.85"/>
<vertex x="13.49" y="8.93"/>
<vertex x="13.7" y="9"/>
<vertex x="13.93" y="9.06"/>
<vertex x="14.15" y="9.1"/>
<vertex x="14.39" y="9.13"/>
<vertex x="14.62" y="9.14"/>
<vertex x="14.86" y="9.14"/>
<vertex x="15.07" y="9.14"/>
<vertex x="15.29" y="9.13"/>
<vertex x="15.51" y="9.11"/>
<vertex x="15.72" y="9.09"/>
<vertex x="15.93" y="9.05"/>
<vertex x="16.14" y="8.99"/>
<vertex x="16.34" y="8.93"/>
<vertex x="16.52" y="8.85"/>
<vertex x="16.69" y="8.76"/>
<vertex x="16.85" y="8.64"/>
<vertex x="16.99" y="8.51"/>
<vertex x="17.11" y="8.36"/>
<vertex x="17.21" y="8.19"/>
<vertex x="17.28" y="8"/>
<vertex x="17.32" y="7.78"/>
<vertex x="17.34" y="7.54"/>
<vertex x="17.34" y="7.36"/>
<vertex x="17.34" y="7.18"/>
<vertex x="17.34" y="6.99"/>
<vertex x="17.34" y="6.81"/>
<vertex x="17.34" y="6.63"/>
<vertex x="17.34" y="6.44"/>
<vertex x="17.34" y="6.26"/>
<vertex x="17.34" y="6.08"/>
<vertex x="17.34" y="5.89"/>
<vertex x="17.34" y="5.71"/>
<vertex x="17.34" y="5.52"/>
<vertex x="17.34" y="5.34"/>
<vertex x="17.34" y="5.16"/>
<vertex x="17.34" y="4.97"/>
<vertex x="17.34" y="4.79"/>
<vertex x="17.34" y="4.61"/>
<vertex x="17.34" y="4.51"/>
<vertex x="17.34" y="4.42"/>
<vertex x="17.34" y="4.32"/>
<vertex x="17.35" y="4.23"/>
<vertex x="17.35" y="4.14"/>
<vertex x="17.36" y="4.04"/>
<vertex x="17.37" y="3.96"/>
<vertex x="17.38" y="3.87"/>
<vertex x="17.4" y="3.79"/>
<vertex x="17.41" y="3.71"/>
<vertex x="17.42" y="3.64"/>
<vertex x="17.44" y="3.57"/>
<vertex x="17.46" y="3.51"/>
<vertex x="17.48" y="3.45"/>
<vertex x="17.51" y="3.4"/>
<vertex x="17.53" y="3.35"/>
<vertex x="17.43" y="3.35"/>
<vertex x="17.34" y="3.35"/>
<vertex x="17.24" y="3.35"/>
<vertex x="17.14" y="3.35"/>
<vertex x="17.04" y="3.35"/>
<vertex x="16.94" y="3.35"/>
<vertex x="16.85" y="3.35"/>
<vertex x="16.75" y="3.35"/>
<vertex x="16.65" y="3.35"/>
<vertex x="16.55" y="3.35"/>
<vertex x="16.45" y="3.35"/>
<vertex x="16.35" y="3.35"/>
<vertex x="16.26" y="3.35"/>
<vertex x="16.16" y="3.35"/>
<vertex x="16.06" y="3.35"/>
<vertex x="15.96" y="3.35"/>
<vertex x="15.95" y="3.39"/>
<vertex x="15.94" y="3.42"/>
<vertex x="15.93" y="3.45"/>
<vertex x="15.92" y="3.49"/>
<vertex x="15.9" y="3.52"/>
<vertex x="15.9" y="3.55"/>
<vertex x="15.89" y="3.59"/>
<vertex x="15.88" y="3.62"/>
<vertex x="15.87" y="3.66"/>
<vertex x="15.87" y="3.69"/>
<vertex x="15.86" y="3.73"/>
<vertex x="15.86" y="3.76"/>
<vertex x="15.86" y="3.8"/>
<vertex x="15.86" y="3.83"/>
<vertex x="15.85" y="3.87"/>
<vertex x="15.85" y="3.9"/>
<vertex x="15.76" y="3.81"/>
<vertex x="15.66" y="3.72"/>
<vertex x="15.56" y="3.65"/>
<vertex x="15.45" y="3.58"/>
<vertex x="15.34" y="3.51"/>
<vertex x="15.22" y="3.45"/>
<vertex x="15.1" y="3.4"/>
<vertex x="14.98" y="3.36"/>
<vertex x="14.86" y="3.32"/>
<vertex x="14.73" y="3.29"/>
<vertex x="14.61" y="3.26"/>
<vertex x="14.48" y="3.24"/>
<vertex x="14.35" y="3.22"/>
<vertex x="14.22" y="3.21"/>
<vertex x="14.09" y="3.2"/>
<vertex x="13.96" y="3.2"/>
<vertex x="13.76" y="3.2"/>
<vertex x="13.56" y="3.22"/>
<vertex x="13.38" y="3.25"/>
<vertex x="13.2" y="3.29"/>
<vertex x="13.03" y="3.35"/>
<vertex x="12.87" y="3.42"/>
<vertex x="12.73" y="3.51"/>
<vertex x="12.59" y="3.61"/>
<vertex x="12.47" y="3.72"/>
<vertex x="12.36" y="3.84"/>
<vertex x="12.26" y="3.98"/>
<vertex x="12.18" y="4.13"/>
<vertex x="12.12" y="4.3"/>
<vertex x="12.07" y="4.48"/>
<vertex x="12.05" y="4.68"/>
<vertex x="12.03" y="4.89"/>
<vertex x="12.08" y="5.32"/>
<vertex x="12.2" y="5.68"/>
<vertex x="12.39" y="5.96"/>
<vertex x="12.64" y="6.17"/>
<vertex x="12.93" y="6.34"/>
<vertex x="13.25" y="6.46"/>
<vertex x="13.59" y="6.54"/>
</polygon>
<vertex x="18.21" y="8.74"/>
<vertex x="18.4" y="8.77"/>
<vertex x="18.58" y="8.81"/>
<vertex x="18.76" y="8.84"/>
<vertex x="18.95" y="8.87"/>
<vertex x="19.13" y="8.9"/>
<vertex x="19.32" y="8.94"/>
<vertex x="19.5" y="8.97"/>
<vertex x="19.69" y="9"/>
<vertex x="19.69" y="8.87"/>
<vertex x="19.69" y="8.74"/>
<vertex x="19.69" y="8.61"/>
<vertex x="19.69" y="8.48"/>
<vertex x="19.69" y="8.35"/>
<vertex x="19.69" y="8.22"/>
<vertex x="19.69" y="8.09"/>
<vertex x="19.69" y="7.95"/>
<vertex x="19.82" y="8.21"/>
<vertex x="19.99" y="8.44"/>
<vertex x="20.19" y="8.65"/>
<vertex x="20.41" y="8.82"/>
<vertex x="20.66" y="8.96"/>
<vertex x="20.93" y="9.07"/>
<vertex x="21.21" y="9.13"/>
<vertex x="21.49" y="9.15"/>
<vertex x="21.54" y="9.15"/>
<vertex x="21.58" y="9.15"/>
<vertex x="21.63" y="9.15"/>
<vertex x="21.67" y="9.15"/>
<vertex x="21.71" y="9.14"/>
<vertex x="21.75" y="9.13"/>
<vertex x="21.79" y="9.12"/>
<vertex x="21.83" y="9.11"/>
<vertex x="21.83" y="8.93"/>
<vertex x="21.83" y="8.75"/>
<vertex x="21.83" y="8.57"/>
<vertex x="21.83" y="8.39"/>
<vertex x="21.83" y="8.21"/>
<vertex x="21.83" y="8.03"/>
<vertex x="21.83" y="7.85"/>
<vertex x="21.83" y="7.67"/>
<vertex x="21.78" y="7.68"/>
<vertex x="21.71" y="7.69"/>
<vertex x="21.64" y="7.7"/>
<vertex x="21.57" y="7.71"/>
<vertex x="21.5" y="7.71"/>
<vertex x="21.42" y="7.71"/>
<vertex x="21.35" y="7.71"/>
<vertex x="21.28" y="7.71"/>
<vertex x="20.88" y="7.68"/>
<vertex x="20.56" y="7.57"/>
<vertex x="20.29" y="7.41"/>
<vertex x="20.08" y="7.19"/>
<vertex x="19.93" y="6.92"/>
<vertex x="19.83" y="6.61"/>
<vertex x="19.77" y="6.27"/>
<vertex x="19.75" y="5.9"/>
<vertex x="19.75" y="5.59"/>
<vertex x="19.75" y="5.27"/>
<vertex x="19.75" y="4.95"/>
<vertex x="19.75" y="4.63"/>
<vertex x="19.75" y="4.32"/>
<vertex x="19.75" y="4"/>
<vertex x="19.75" y="3.68"/>
<vertex x="19.75" y="3.36"/>
<vertex x="19.56" y="3.36"/>
<vertex x="19.36" y="3.36"/>
<vertex x="19.17" y="3.36"/>
<vertex x="18.97" y="3.36"/>
<vertex x="18.78" y="3.36"/>
<vertex x="18.59" y="3.36"/>
<vertex x="18.39" y="3.36"/>
<vertex x="18.2" y="3.36"/>
<vertex x="18.2" y="4.03"/>
<vertex x="18.2" y="4.71"/>
<vertex x="18.2" y="5.38"/>
<vertex x="18.2" y="6.05"/>
<vertex x="18.2" y="6.72"/>
<vertex x="18.2" y="7.4"/>
<vertex x="18.2" y="8.07"/>
</polygon>
<vertex x="22.44" y="10.3"/>
<vertex x="23.99" y="11.15"/>
<vertex x="23.99" y="6.97"/>
<vertex x="25.95" y="9"/>
<vertex x="27.78" y="9"/>
<vertex x="25.65" y="6.93"/>
<vertex x="28.02" y="3.36"/>
<vertex x="26.14" y="3.36"/>
<vertex x="24.59" y="5.88"/>
<vertex x="23.99" y="5.3"/>
<vertex x="23.99" y="3.36"/>
<vertex x="22.44" y="3.36"/>
</polygon>
<vertex x="28.96" y="7.97"/>
<vertex x="28.77" y="7.97"/>
<vertex x="28.58" y="7.97"/>
<vertex x="28.39" y="7.97"/>
<vertex x="28.2" y="7.97"/>
<vertex x="28.01" y="7.97"/>
<vertex x="27.82" y="7.97"/>
<vertex x="27.63" y="7.97"/>
<vertex x="27.43" y="7.97"/>
<vertex x="27.57" y="8.1"/>
<vertex x="27.7" y="8.23"/>
<vertex x="27.83" y="8.36"/>
<vertex x="27.96" y="8.49"/>
<vertex x="28.09" y="8.62"/>
<vertex x="28.23" y="8.75"/>
<vertex x="28.36" y="8.87"/>
<vertex x="28.49" y="9"/>
<vertex x="28.55" y="9"/>
<vertex x="28.61" y="9"/>
<vertex x="28.67" y="9"/>
<vertex x="28.73" y="9"/>
<vertex x="28.79" y="9"/>
<vertex x="28.84" y="9"/>
<vertex x="28.9" y="9"/>
<vertex x="28.96" y="9"/>
<vertex x="28.96" y="9.06"/>
<vertex x="28.96" y="9.11"/>
<vertex x="28.96" y="9.17"/>
<vertex x="28.96" y="9.22"/>
<vertex x="28.96" y="9.27"/>
<vertex x="28.96" y="9.33"/>
<vertex x="28.96" y="9.38"/>
<vertex x="28.96" y="9.44"/>
<vertex x="28.99" y="9.8"/>
<vertex x="29.08" y="10.13"/>
<vertex x="29.23" y="10.42"/>
<vertex x="29.43" y="10.67"/>
<vertex x="29.7" y="10.87"/>
<vertex x="30.02" y="11.02"/>
<vertex x="30.41" y="11.12"/>
<vertex x="30.85" y="11.15"/>
<vertex x="30.95" y="11.15"/>
<vertex x="31.06" y="11.15"/>
<vertex x="31.16" y="11.15"/>
<vertex x="31.26" y="11.14"/>
<vertex x="31.37" y="11.13"/>
<vertex x="31.47" y="11.12"/>
<vertex x="31.57" y="11.12"/>
<vertex x="31.67" y="11.12"/>
<vertex x="31.67" y="10.97"/>
<vertex x="31.67" y="10.83"/>
<vertex x="31.67" y="10.68"/>
<vertex x="31.67" y="10.54"/>
<vertex x="31.67" y="10.4"/>
<vertex x="31.67" y="10.25"/>
<vertex x="31.67" y="10.11"/>
<vertex x="31.67" y="9.96"/>
<vertex x="31.6" y="9.97"/>
<vertex x="31.53" y="9.98"/>
<vertex x="31.46" y="9.98"/>
<vertex x="31.38" y="9.98"/>
<vertex x="31.31" y="9.98"/>
<vertex x="31.24" y="9.98"/>
<vertex x="31.17" y="9.98"/>
<vertex x="31.1" y="9.98"/>
<vertex x="30.95" y="9.97"/>
<vertex x="30.83" y="9.95"/>
<vertex x="30.73" y="9.9"/>
<vertex x="30.65" y="9.84"/>
<vertex x="30.59" y="9.75"/>
<vertex x="30.54" y="9.64"/>
<vertex x="30.52" y="9.5"/>
<vertex x="30.51" y="9.34"/>
<vertex x="30.51" y="9.3"/>
<vertex x="30.51" y="9.25"/>
<vertex x="30.51" y="9.21"/>
<vertex x="30.51" y="9.17"/>
<vertex x="30.51" y="9.13"/>
<vertex x="30.51" y="9.08"/>
<vertex x="30.51" y="9.04"/>
<vertex x="30.51" y="9"/>
<vertex x="30.64" y="9"/>
<vertex x="30.78" y="9"/>
<vertex x="30.91" y="9"/>
<vertex x="31.05" y="9"/>
<vertex x="31.18" y="9"/>
<vertex x="31.31" y="9"/>
<vertex x="31.45" y="9"/>
<vertex x="31.58" y="9"/>
<vertex x="31.58" y="8.87"/>
<vertex x="31.58" y="8.74"/>
<vertex x="31.58" y="8.61"/>
<vertex x="31.58" y="8.48"/>
<vertex x="31.58" y="8.35"/>
<vertex x="31.58" y="8.22"/>
<vertex x="31.58" y="8.09"/>
<vertex x="31.58" y="7.96"/>
<vertex x="31.45" y="7.96"/>
<vertex x="31.31" y="7.96"/>
<vertex x="31.18" y="7.96"/>
<vertex x="31.05" y="7.96"/>
<vertex x="30.91" y="7.96"/>
<vertex x="30.78" y="7.96"/>
<vertex x="30.64" y="7.96"/>
<vertex x="30.51" y="7.96"/>
<vertex x="30.51" y="7.39"/>
<vertex x="30.51" y="6.81"/>
<vertex x="30.51" y="6.24"/>
<vertex x="30.51" y="5.66"/>
<vertex x="30.51" y="5.09"/>
<vertex x="30.51" y="4.51"/>
<vertex x="30.51" y="3.93"/>
<vertex x="30.51" y="3.36"/>
<vertex x="30.32" y="3.36"/>
<vertex x="30.12" y="3.36"/>
<vertex x="29.93" y="3.36"/>
<vertex x="29.74" y="3.36"/>
<vertex x="29.54" y="3.36"/>
<vertex x="29.35" y="3.36"/>
<vertex x="29.15" y="3.36"/>
<vertex x="28.96" y="3.36"/>
<vertex x="28.96" y="3.93"/>
<vertex x="28.96" y="4.51"/>
<vertex x="28.96" y="5.09"/>
<vertex x="28.96" y="5.66"/>
<vertex x="28.96" y="6.24"/>
<vertex x="28.96" y="6.81"/>
<vertex x="28.96" y="7.39"/>
</polygon>
<vertex x="37.31" y="3.36"/>
<vertex x="37.12" y="3.36"/>
<vertex x="36.94" y="3.36"/>
<vertex x="36.76" y="3.36"/>
<vertex x="36.57" y="3.36"/>
<vertex x="36.39" y="3.36"/>
<vertex x="36.2" y="3.36"/>
<vertex x="36.02" y="3.36"/>
<vertex x="35.83" y="3.36"/>
<vertex x="35.83" y="3.46"/>
<vertex x="35.83" y="3.56"/>
<vertex x="35.83" y="3.66"/>
<vertex x="35.83" y="3.75"/>
<vertex x="35.83" y="3.85"/>
<vertex x="35.83" y="3.95"/>
<vertex x="35.83" y="4.05"/>
<vertex x="35.83" y="4.15"/>
<vertex x="35.82" y="4.15"/>
<vertex x="35.66" y="3.92"/>
<vertex x="35.47" y="3.73"/>
<vertex x="35.27" y="3.57"/>
<vertex x="35.05" y="3.44"/>
<vertex x="34.82" y="3.34"/>
<vertex x="34.58" y="3.27"/>
<vertex x="34.34" y="3.22"/>
<vertex x="34.09" y="3.21"/>
<vertex x="33.53" y="3.25"/>
<vertex x="33.08" y="3.38"/>
<vertex x="32.72" y="3.58"/>
<vertex x="32.44" y="3.85"/>
<vertex x="32.25" y="4.18"/>
<vertex x="32.12" y="4.58"/>
<vertex x="32.05" y="5.03"/>
<vertex x="32.03" y="5.53"/>
<vertex x="32.03" y="5.97"/>
<vertex x="32.03" y="6.4"/>
<vertex x="32.03" y="6.83"/>
<vertex x="32.03" y="7.27"/>
<vertex x="32.03" y="7.7"/>
<vertex x="32.03" y="8.14"/>
<vertex x="32.03" y="8.57"/>
<vertex x="32.03" y="9"/>
<vertex x="32.22" y="9"/>
<vertex x="32.42" y="9"/>
<vertex x="32.61" y="9"/>
<vertex x="32.81" y="9"/>
<vertex x="33" y="9"/>
<vertex x="33.19" y="9"/>
<vertex x="33.39" y="9"/>
<vertex x="33.58" y="9"/>
<vertex x="33.58" y="8.6"/>
<vertex x="33.58" y="8.21"/>
<vertex x="33.58" y="7.81"/>
<vertex x="33.58" y="7.41"/>
<vertex x="33.58" y="7.01"/>
<vertex x="33.58" y="6.61"/>
<vertex x="33.58" y="6.22"/>
<vertex x="33.58" y="5.82"/>
<vertex x="33.59" y="5.49"/>
<vertex x="33.63" y="5.21"/>
<vertex x="33.7" y="4.97"/>
<vertex x="33.8" y="4.78"/>
<vertex x="33.94" y="4.63"/>
<vertex x="34.11" y="4.52"/>
<vertex x="34.32" y="4.45"/>
<vertex x="34.57" y="4.43"/>
<vertex x="34.87" y="4.45"/>
<vertex x="35.12" y="4.52"/>
<vertex x="35.32" y="4.64"/>
<vertex x="35.49" y="4.81"/>
<vertex x="35.62" y="5.03"/>
<vertex x="35.7" y="5.31"/>
<vertex x="35.76" y="5.65"/>
<vertex x="35.77" y="6.05"/>
<vertex x="35.77" y="6.42"/>
<vertex x="35.77" y="6.79"/>
<vertex x="35.77" y="7.15"/>
<vertex x="35.77" y="7.52"/>
<vertex x="35.77" y="7.89"/>
<vertex x="35.77" y="8.26"/>
<vertex x="35.77" y="8.63"/>
<vertex x="35.77" y="9"/>
<vertex x="35.97" y="9"/>
<vertex x="36.16" y="9"/>
<vertex x="36.36" y="9"/>
<vertex x="36.55" y="9"/>
<vertex x="36.74" y="9"/>
<vertex x="36.94" y="9"/>
<vertex x="37.13" y="9"/>
<vertex x="37.32" y="9"/>
<vertex x="37.32" y="8.3"/>
<vertex x="37.32" y="7.59"/>
<vertex x="37.32" y="6.89"/>
<vertex x="37.32" y="6.18"/>
<vertex x="37.32" y="5.48"/>
<vertex x="37.32" y="4.77"/>
<vertex x="37.32" y="4.07"/>
</polygon>
<vertex x="38.16" y="9"/>
<vertex x="38.35" y="9"/>
<vertex x="38.53" y="9"/>
<vertex x="38.72" y="9"/>
<vertex x="38.9" y="9"/>
<vertex x="39.08" y="9"/>
<vertex x="39.27" y="9"/>
<vertex x="39.45" y="9"/>
<vertex x="39.64" y="9"/>
<vertex x="39.64" y="8.91"/>
<vertex x="39.64" y="8.81"/>
<vertex x="39.64" y="8.71"/>
<vertex x="39.64" y="8.61"/>
<vertex x="39.64" y="8.51"/>
<vertex x="39.64" y="8.42"/>
<vertex x="39.64" y="8.32"/>
<vertex x="39.64" y="8.22"/>
<vertex x="39.65" y="8.22"/>
<vertex x="39.81" y="8.44"/>
<vertex x="40" y="8.64"/>
<vertex x="40.2" y="8.8"/>
<vertex x="40.42" y="8.93"/>
<vertex x="40.65" y="9.03"/>
<vertex x="40.89" y="9.1"/>
<vertex x="41.13" y="9.14"/>
<vertex x="41.38" y="9.16"/>
<vertex x="41.94" y="9.12"/>
<vertex x="42.4" y="8.99"/>
<vertex x="42.76" y="8.79"/>
<vertex x="43.03" y="8.52"/>
<vertex x="43.22" y="8.18"/>
<vertex x="43.35" y="7.79"/>
<vertex x="43.42" y="7.33"/>
<vertex x="43.44" y="6.83"/>
<vertex x="43.44" y="6.4"/>
<vertex x="43.44" y="5.97"/>
<vertex x="43.44" y="5.53"/>
<vertex x="43.44" y="5.1"/>
<vertex x="43.44" y="4.67"/>
<vertex x="43.44" y="4.23"/>
<vertex x="43.44" y="3.8"/>
<vertex x="43.44" y="3.36"/>
<vertex x="43.25" y="3.36"/>
<vertex x="43.05" y="3.36"/>
<vertex x="42.86" y="3.36"/>
<vertex x="42.67" y="3.36"/>
<vertex x="42.47" y="3.36"/>
<vertex x="42.28" y="3.36"/>
<vertex x="42.08" y="3.36"/>
<vertex x="41.89" y="3.36"/>
<vertex x="41.89" y="3.76"/>
<vertex x="41.89" y="4.16"/>
<vertex x="41.89" y="4.56"/>
<vertex x="41.89" y="4.96"/>
<vertex x="41.89" y="5.35"/>
<vertex x="41.89" y="5.75"/>
<vertex x="41.89" y="6.15"/>
<vertex x="41.89" y="6.55"/>
<vertex x="41.88" y="6.88"/>
<vertex x="41.84" y="7.16"/>
<vertex x="41.77" y="7.4"/>
<vertex x="41.67" y="7.59"/>
<vertex x="41.53" y="7.74"/>
<vertex x="41.36" y="7.85"/>
<vertex x="41.15" y="7.91"/>
<vertex x="40.9" y="7.94"/>
<vertex x="40.6" y="7.91"/>
<vertex x="40.36" y="7.84"/>
<vertex x="40.15" y="7.73"/>
<vertex x="39.98" y="7.56"/>
<vertex x="39.86" y="7.33"/>
<vertex x="39.77" y="7.06"/>
<vertex x="39.72" y="6.72"/>
<vertex x="39.7" y="6.32"/>
<vertex x="39.7" y="5.95"/>
<vertex x="39.7" y="5.58"/>
<vertex x="39.7" y="5.21"/>
<vertex x="39.7" y="4.84"/>
<vertex x="39.7" y="4.47"/>
<vertex x="39.7" y="4.1"/>
<vertex x="39.7" y="3.73"/>
<vertex x="39.7" y="3.36"/>
<vertex x="39.5" y="3.36"/>
<vertex x="39.31" y="3.36"/>
<vertex x="39.12" y="3.36"/>
<vertex x="38.92" y="3.36"/>
<vertex x="38.73" y="3.36"/>
<vertex x="38.54" y="3.36"/>
<vertex x="38.34" y="3.36"/>
<vertex x="38.15" y="3.36"/>
<vertex x="38.15" y="4.07"/>
<vertex x="38.15" y="4.77"/>
<vertex x="38.15" y="5.48"/>
<vertex x="38.15" y="6.18"/>
<vertex x="38.15" y="6.89"/>
<vertex x="38.15" y="7.59"/>
<vertex x="38.15" y="8.3"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.5">
<vertex x="1.84" y="6.5"/>
<vertex x="1.87" y="6.21"/>
<vertex x="1.97" y="5.96"/>
<vertex x="2.11" y="5.75"/>
<vertex x="2.3" y="5.59"/>
<vertex x="2.53" y="5.46"/>
<vertex x="2.78" y="5.38"/>
<vertex x="3.05" y="5.33"/>
<vertex x="3.33" y="5.31"/>
<vertex x="3.54" y="5.32"/>
<vertex x="3.76" y="5.36"/>
<vertex x="3.97" y="5.42"/>
<vertex x="4.17" y="5.51"/>
<vertex x="4.34" y="5.63"/>
<vertex x="4.48" y="5.78"/>
<vertex x="4.56" y="5.98"/>
<vertex x="4.6" y="6.21"/>
<vertex x="4.56" y="6.42"/>
<vertex x="4.45" y="6.59"/>
<vertex x="4.27" y="6.74"/>
<vertex x="4.02" y="6.87"/>
<vertex x="3.7" y="6.99"/>
<vertex x="3.33" y="7.1"/>
<vertex x="2.89" y="7.2"/>
<vertex x="2.4" y="7.3"/>
<vertex x="1.98" y="7.41"/>
<vertex x="1.57" y="7.53"/>
<vertex x="1.2" y="7.68"/>
<vertex x="0.86" y="7.87"/>
<vertex x="0.57" y="8.11"/>
<vertex x="0.35" y="8.4"/>
<vertex x="0.21" y="8.76"/>
<vertex x="0.16" y="9.19"/>
<vertex x="0.23" y="9.8"/>
<vertex x="0.43" y="10.3"/>
<vertex x="0.74" y="10.7"/>
<vertex x="1.13" y="10.99"/>
<vertex x="1.6" y="11.21"/>
<vertex x="2.11" y="11.35"/>
<vertex x="2.67" y="11.43"/>
<vertex x="3.23" y="11.45"/>
<vertex x="3.8" y="11.43"/>
<vertex x="4.34" y="11.35"/>
<vertex x="4.85" y="11.2"/>
<vertex x="5.3" y="10.98"/>
<vertex x="5.7" y="10.68"/>
<vertex x="6.01" y="10.29"/>
<vertex x="6.23" y="9.8"/>
<vertex x="6.34" y="9.2"/>
<vertex x="6.11" y="9.2"/>
<vertex x="5.88" y="9.2"/>
<vertex x="5.65" y="9.2"/>
<vertex x="5.42" y="9.2"/>
<vertex x="5.19" y="9.2"/>
<vertex x="4.96" y="9.2"/>
<vertex x="4.73" y="9.2"/>
<vertex x="4.5" y="9.2"/>
<vertex x="4.46" y="9.46"/>
<vertex x="4.37" y="9.67"/>
<vertex x="4.24" y="9.84"/>
<vertex x="4.08" y="9.96"/>
<vertex x="3.89" y="10.05"/>
<vertex x="3.67" y="10.11"/>
<vertex x="3.43" y="10.15"/>
<vertex x="3.18" y="10.16"/>
<vertex x="3.01" y="10.16"/>
<vertex x="2.83" y="10.15"/>
<vertex x="2.65" y="10.11"/>
<vertex x="2.48" y="10.06"/>
<vertex x="2.33" y="9.98"/>
<vertex x="2.21" y="9.86"/>
<vertex x="2.13" y="9.71"/>
<vertex x="2.1" y="9.51"/>
<vertex x="2.15" y="9.28"/>
<vertex x="2.29" y="9.09"/>
<vertex x="2.51" y="8.94"/>
<vertex x="2.79" y="8.82"/>
<vertex x="3.12" y="8.72"/>
<vertex x="3.49" y="8.64"/>
<vertex x="3.89" y="8.55"/>
<vertex x="4.3" y="8.46"/>
<vertex x="4.72" y="8.36"/>
<vertex x="5.12" y="8.23"/>
<vertex x="5.5" y="8.07"/>
<vertex x="5.84" y="7.87"/>
<vertex x="6.12" y="7.62"/>
<vertex x="6.34" y="7.31"/>
<vertex x="6.48" y="6.93"/>
<vertex x="6.53" y="6.48"/>
<vertex x="6.46" y="5.85"/>
<vertex x="6.25" y="5.32"/>
<vertex x="5.93" y="4.89"/>
<vertex x="5.52" y="4.56"/>
<vertex x="5.03" y="4.32"/>
<vertex x="4.49" y="4.15"/>
<vertex x="3.91" y="4.06"/>
<vertex x="3.31" y="4.03"/>
<vertex x="2.7" y="4.06"/>
<vertex x="2.11" y="4.15"/>
<vertex x="1.56" y="4.32"/>
<vertex x="1.07" y="4.57"/>
<vertex x="0.65" y="4.9"/>
<vertex x="0.32" y="5.33"/>
<vertex x="0.09" y="5.87"/>
<vertex x="0" y="6.5"/>
<vertex x="0.23" y="6.5"/>
<vertex x="0.46" y="6.5"/>
<vertex x="0.69" y="6.5"/>
<vertex x="0.92" y="6.5"/>
<vertex x="1.15" y="6.5"/>
<vertex x="1.38" y="6.5"/>
<vertex x="1.61" y="6.5"/>
</polygon>
<vertex x="12.35" y="6.5"/>
<vertex x="12.46" y="6.88"/>
<vertex x="12.53" y="7.28"/>
<vertex x="12.54" y="7.71"/>
<vertex x="14.48" y="7.65"/>
<vertex x="14.43" y="6.96"/>
<vertex x="14.29" y="6.29"/>
<vertex x="14.05" y="5.67"/>
</polygon>
<vertex x="14.05" y="5.68"/>
<vertex x="13.71" y="5.13"/>
<vertex x="13.28" y="4.67"/>
<vertex x="12.74" y="4.32"/>
<vertex x="12.11" y="4.09"/>
<vertex x="11.39" y="4.01"/>
<vertex x="11.07" y="4.03"/>
<vertex x="10.76" y="4.08"/>
<vertex x="10.46" y="4.17"/>
<vertex x="10.19" y="4.29"/>
<vertex x="9.92" y="4.44"/>
<vertex x="9.68" y="4.62"/>
<vertex x="9.46" y="4.83"/>
<vertex x="9.27" y="5.08"/>
<vertex x="9.26" y="5.08"/>
<vertex x="9.26" y="4.44"/>
<vertex x="9.26" y="3.81"/>
<vertex x="9.26" y="3.17"/>
<vertex x="9.26" y="2.54"/>
<vertex x="9.26" y="1.9"/>
<vertex x="9.26" y="1.27"/>
<vertex x="9.26" y="0.63"/>
<vertex x="9.26" y="0"/>
<vertex x="9.02" y="0.22"/>
<vertex x="8.78" y="0.43"/>
<vertex x="8.53" y="0.65"/>
<vertex x="8.29" y="0.86"/>
<vertex x="8.05" y="1.08"/>
<vertex x="7.81" y="1.29"/>
<vertex x="7.57" y="1.51"/>
<vertex x="7.32" y="1.72"/>
<vertex x="7.32" y="2.87"/>
<vertex x="7.32" y="4.02"/>
<vertex x="7.32" y="5.18"/>
<vertex x="7.32" y="6.33"/>
<vertex x="7.32" y="7.48"/>
<vertex x="7.32" y="8.63"/>
<vertex x="7.32" y="9.78"/>
<vertex x="7.32" y="10.93"/>
<vertex x="7.55" y="10.97"/>
<vertex x="7.78" y="11.01"/>
<vertex x="8.02" y="11.05"/>
<vertex x="8.25" y="11.09"/>
<vertex x="8.48" y="11.13"/>
<vertex x="8.71" y="11.17"/>
<vertex x="8.94" y="11.22"/>
<vertex x="9.17" y="11.26"/>
<vertex x="9.17" y="11.14"/>
<vertex x="9.17" y="11.03"/>
<vertex x="9.17" y="10.92"/>
<vertex x="9.17" y="10.81"/>
<vertex x="9.17" y="10.69"/>
<vertex x="9.17" y="10.58"/>
<vertex x="9.17" y="10.47"/>
<vertex x="9.17" y="10.35"/>
<vertex x="9.18" y="10.35"/>
<vertex x="9.37" y="10.62"/>
<vertex x="9.59" y="10.85"/>
<vertex x="9.82" y="11.03"/>
<vertex x="10.08" y="11.19"/>
<vertex x="10.36" y="11.3"/>
<vertex x="10.65" y="11.38"/>
<vertex x="10.96" y="11.43"/>
<vertex x="11.28" y="11.45"/>
<vertex x="12.05" y="11.36"/>
<vertex x="12.71" y="11.14"/>
<vertex x="13.26" y="10.77"/>
<vertex x="13.71" y="10.3"/>
<vertex x="14.05" y="9.73"/>
<vertex x="14.29" y="9.09"/>
<vertex x="14.44" y="8.39"/>
<vertex x="12.52" y="8.13"/>
<vertex x="12.45" y="8.54"/>
<vertex x="12.34" y="8.92"/>
<vertex x="12.17" y="9.27"/>
<vertex x="11.93" y="9.56"/>
<vertex x="11.64" y="9.79"/>
<vertex x="11.28" y="9.93"/>
<vertex x="10.85" y="9.98"/>
<vertex x="10.42" y="9.93"/>
<vertex x="10.06" y="9.79"/>
<vertex x="9.77" y="9.57"/>
<vertex x="9.54" y="9.28"/>
<vertex x="9.37" y="8.93"/>
<vertex x="9.26" y="8.55"/>
<vertex x="9.2" y="8.13"/>
<vertex x="9.18" y="7.71"/>
<vertex x="9.2" y="7.28"/>
<vertex x="9.27" y="6.88"/>
<vertex x="9.38" y="6.5"/>
<vertex x="9.55" y="6.16"/>
<vertex x="9.78" y="5.88"/>
<vertex x="10.07" y="5.66"/>
<vertex x="10.44" y="5.52"/>
<vertex x="10.87" y="5.47"/>
<vertex x="11.31" y="5.52"/>
<vertex x="11.67" y="5.66"/>
<vertex x="11.96" y="5.88"/>
<vertex x="12.18" y="6.16"/>
</polygon>
<vertex x="17.43" y="8.25"/>
<vertex x="17.87" y="8.31"/>
<vertex x="18.29" y="8.35"/>
<vertex x="18.69" y="8.41"/>
<vertex x="18.92" y="7.36"/>
<vertex x="18.81" y="7.35"/>
<vertex x="18.69" y="7.33"/>
<vertex x="18.58" y="7.31"/>
<vertex x="18.46" y="7.3"/>
<vertex x="18.35" y="7.28"/>
<vertex x="18.23" y="7.26"/>
<vertex x="18.12" y="7.24"/>
<vertex x="18.01" y="7.22"/>
<vertex x="17.9" y="7.2"/>
<vertex x="17.79" y="7.17"/>
</polygon>
<vertex x="17.69" y="7.13"/>
<vertex x="17.59" y="7.09"/>
<vertex x="17.5" y="7.05"/>
<vertex x="17.41" y="7"/>
<vertex x="17.32" y="6.95"/>
<vertex x="17.25" y="6.89"/>
<vertex x="17.18" y="6.81"/>
<vertex x="17.12" y="6.74"/>
<vertex x="17.07" y="6.65"/>
<vertex x="17.03" y="6.55"/>
<vertex x="17" y="6.45"/>
<vertex x="16.98" y="6.33"/>
<vertex x="16.98" y="6.2"/>
<vertex x="16.98" y="6.08"/>
<vertex x="17" y="5.96"/>
<vertex x="17.03" y="5.86"/>
<vertex x="17.07" y="5.76"/>
<vertex x="17.12" y="5.68"/>
<vertex x="17.19" y="5.61"/>
<vertex x="17.26" y="5.54"/>
<vertex x="17.33" y="5.49"/>
<vertex x="17.42" y="5.44"/>
<vertex x="17.51" y="5.4"/>
<vertex x="17.61" y="5.37"/>
<vertex x="17.71" y="5.35"/>
<vertex x="17.82" y="5.33"/>
<vertex x="17.93" y="5.31"/>
<vertex x="18.05" y="5.31"/>
<vertex x="18.16" y="5.31"/>
<vertex x="18.43" y="5.33"/>
<vertex x="18.66" y="5.36"/>
<vertex x="18.87" y="5.42"/>
<vertex x="19.05" y="5.5"/>
<vertex x="19.2" y="5.6"/>
<vertex x="19.32" y="5.71"/>
<vertex x="19.43" y="5.83"/>
<vertex x="19.51" y="5.96"/>
<vertex x="19.58" y="6.09"/>
<vertex x="19.63" y="6.23"/>
<vertex x="19.67" y="6.36"/>
<vertex x="19.7" y="6.5"/>
<vertex x="19.72" y="6.62"/>
<vertex x="19.73" y="6.74"/>
<vertex x="19.73" y="6.84"/>
<vertex x="19.73" y="6.93"/>
<vertex x="19.73" y="6.98"/>
<vertex x="19.73" y="7.02"/>
<vertex x="19.73" y="7.07"/>
<vertex x="19.73" y="7.11"/>
<vertex x="19.73" y="7.16"/>
<vertex x="19.73" y="7.2"/>
<vertex x="19.73" y="7.25"/>
<vertex x="19.73" y="7.29"/>
<vertex x="19.73" y="7.34"/>
<vertex x="19.73" y="7.39"/>
<vertex x="19.73" y="7.43"/>
<vertex x="19.73" y="7.48"/>
<vertex x="19.73" y="7.52"/>
<vertex x="19.73" y="7.57"/>
<vertex x="19.73" y="7.61"/>
<vertex x="19.73" y="7.66"/>
<vertex x="19.66" y="7.6"/>
<vertex x="19.59" y="7.56"/>
<vertex x="19.51" y="7.52"/>
<vertex x="19.42" y="7.48"/>
<vertex x="19.33" y="7.45"/>
<vertex x="19.24" y="7.43"/>
<vertex x="19.13" y="7.4"/>
<vertex x="19.03" y="7.38"/>
<vertex x="18.92" y="7.37"/>
<vertex x="19.03" y="8.5"/>
<vertex x="19.33" y="8.6"/>
<vertex x="19.55" y="8.74"/>
<vertex x="19.69" y="8.93"/>
<vertex x="19.73" y="9.19"/>
<vertex x="19.73" y="9.34"/>
<vertex x="19.71" y="9.47"/>
<vertex x="19.68" y="9.58"/>
<vertex x="19.63" y="9.69"/>
<vertex x="19.58" y="9.78"/>
<vertex x="19.52" y="9.86"/>
<vertex x="19.44" y="9.92"/>
<vertex x="19.36" y="9.98"/>
<vertex x="19.27" y="10.03"/>
<vertex x="19.17" y="10.06"/>
<vertex x="19.07" y="10.09"/>
<vertex x="18.96" y="10.11"/>
<vertex x="18.85" y="10.13"/>
<vertex x="18.73" y="10.15"/>
<vertex x="18.6" y="10.15"/>
<vertex x="18.48" y="10.15"/>
<vertex x="18.34" y="10.15"/>
<vertex x="18.21" y="10.13"/>
<vertex x="18.09" y="10.11"/>
<vertex x="17.97" y="10.08"/>
<vertex x="17.86" y="10.05"/>
<vertex x="17.76" y="10.01"/>
<vertex x="17.67" y="9.96"/>
<vertex x="17.58" y="9.9"/>
<vertex x="17.5" y="9.83"/>
<vertex x="17.43" y="9.75"/>
<vertex x="17.37" y="9.66"/>
<vertex x="17.32" y="9.57"/>
<vertex x="17.28" y="9.46"/>
<vertex x="17.24" y="9.34"/>
<vertex x="17.21" y="9.22"/>
<vertex x="17.2" y="9.08"/>
<vertex x="17.07" y="9.08"/>
<vertex x="16.95" y="9.08"/>
<vertex x="16.83" y="9.08"/>
<vertex x="16.71" y="9.08"/>
<vertex x="16.59" y="9.08"/>
<vertex x="16.47" y="9.08"/>
<vertex x="16.35" y="9.08"/>
<vertex x="16.23" y="9.08"/>
<vertex x="16.11" y="9.08"/>
<vertex x="15.99" y="9.08"/>
<vertex x="15.87" y="9.08"/>
<vertex x="15.74" y="9.08"/>
<vertex x="15.62" y="9.08"/>
<vertex x="15.5" y="9.08"/>
<vertex x="15.38" y="9.08"/>
<vertex x="15.26" y="9.08"/>
<vertex x="15.3" y="9.4"/>
<vertex x="15.37" y="9.7"/>
<vertex x="15.47" y="9.96"/>
<vertex x="15.6" y="10.21"/>
<vertex x="15.76" y="10.42"/>
<vertex x="15.94" y="10.62"/>
<vertex x="16.14" y="10.79"/>
<vertex x="16.37" y="10.93"/>
<vertex x="16.61" y="11.06"/>
<vertex x="16.86" y="11.16"/>
<vertex x="17.13" y="11.25"/>
<vertex x="17.41" y="11.32"/>
<vertex x="17.69" y="11.37"/>
<vertex x="17.98" y="11.41"/>
<vertex x="18.28" y="11.43"/>
<vertex x="18.58" y="11.43"/>
<vertex x="18.84" y="11.43"/>
<vertex x="19.11" y="11.42"/>
<vertex x="19.38" y="11.39"/>
<vertex x="19.65" y="11.36"/>
<vertex x="19.92" y="11.31"/>
<vertex x="20.17" y="11.24"/>
<vertex x="20.42" y="11.16"/>
<vertex x="20.65" y="11.06"/>
<vertex x="20.87" y="10.95"/>
<vertex x="21.06" y="10.81"/>
<vertex x="21.24" y="10.64"/>
<vertex x="21.39" y="10.46"/>
<vertex x="21.51" y="10.24"/>
<vertex x="21.6" y="10"/>
<vertex x="21.65" y="9.73"/>
<vertex x="21.67" y="9.43"/>
<vertex x="21.67" y="9.2"/>
<vertex x="21.67" y="8.97"/>
<vertex x="21.67" y="8.74"/>
<vertex x="21.67" y="8.51"/>
<vertex x="21.67" y="8.28"/>
<vertex x="21.67" y="8.05"/>
<vertex x="21.67" y="7.82"/>
<vertex x="21.67" y="7.59"/>
<vertex x="21.67" y="7.36"/>
<vertex x="21.67" y="7.14"/>
<vertex x="21.67" y="6.91"/>
<vertex x="21.67" y="6.68"/>
<vertex x="21.67" y="6.45"/>
<vertex x="21.67" y="6.22"/>
<vertex x="21.67" y="5.99"/>
<vertex x="21.67" y="5.76"/>
<vertex x="21.67" y="5.64"/>
<vertex x="21.68" y="5.52"/>
<vertex x="21.68" y="5.4"/>
<vertex x="21.68" y="5.28"/>
<vertex x="21.69" y="5.17"/>
<vertex x="21.7" y="5.06"/>
<vertex x="21.71" y="4.95"/>
<vertex x="21.73" y="4.84"/>
<vertex x="21.74" y="4.74"/>
<vertex x="21.76" y="4.64"/>
<vertex x="21.78" y="4.55"/>
<vertex x="21.8" y="4.47"/>
<vertex x="21.83" y="4.39"/>
<vertex x="21.85" y="4.31"/>
<vertex x="21.88" y="4.25"/>
<vertex x="21.91" y="4.19"/>
<vertex x="21.79" y="4.19"/>
<vertex x="21.67" y="4.19"/>
<vertex x="21.55" y="4.19"/>
<vertex x="21.42" y="4.19"/>
<vertex x="21.3" y="4.19"/>
<vertex x="21.18" y="4.19"/>
<vertex x="21.06" y="4.19"/>
<vertex x="20.93" y="4.19"/>
<vertex x="20.81" y="4.19"/>
<vertex x="20.69" y="4.19"/>
<vertex x="20.57" y="4.19"/>
<vertex x="20.44" y="4.19"/>
<vertex x="20.32" y="4.19"/>
<vertex x="20.2" y="4.19"/>
<vertex x="20.08" y="4.19"/>
<vertex x="19.95" y="4.19"/>
<vertex x="19.94" y="4.23"/>
<vertex x="19.92" y="4.27"/>
<vertex x="19.91" y="4.32"/>
<vertex x="19.89" y="4.36"/>
<vertex x="19.88" y="4.4"/>
<vertex x="19.87" y="4.44"/>
<vertex x="19.86" y="4.48"/>
<vertex x="19.85" y="4.53"/>
<vertex x="19.84" y="4.57"/>
<vertex x="19.84" y="4.61"/>
<vertex x="19.83" y="4.66"/>
<vertex x="19.83" y="4.7"/>
<vertex x="19.82" y="4.74"/>
<vertex x="19.82" y="4.79"/>
<vertex x="19.82" y="4.83"/>
<vertex x="19.82" y="4.88"/>
<vertex x="19.7" y="4.76"/>
<vertex x="19.58" y="4.65"/>
<vertex x="19.45" y="4.56"/>
<vertex x="19.31" y="4.47"/>
<vertex x="19.17" y="4.39"/>
<vertex x="19.03" y="4.32"/>
<vertex x="18.88" y="4.25"/>
<vertex x="18.73" y="4.2"/>
<vertex x="18.57" y="4.15"/>
<vertex x="18.42" y="4.11"/>
<vertex x="18.26" y="4.08"/>
<vertex x="18.1" y="4.05"/>
<vertex x="17.94" y="4.03"/>
<vertex x="17.77" y="4.01"/>
<vertex x="17.61" y="4"/>
<vertex x="17.44" y="4"/>
<vertex x="17.2" y="4"/>
<vertex x="16.95" y="4.02"/>
<vertex x="16.72" y="4.06"/>
<vertex x="16.5" y="4.12"/>
<vertex x="16.29" y="4.19"/>
<vertex x="16.09" y="4.28"/>
<vertex x="15.91" y="4.38"/>
<vertex x="15.74" y="4.51"/>
<vertex x="15.59" y="4.65"/>
<vertex x="15.45" y="4.8"/>
<vertex x="15.33" y="4.98"/>
<vertex x="15.23" y="5.17"/>
<vertex x="15.15" y="5.37"/>
<vertex x="15.09" y="5.6"/>
<vertex x="15.06" y="5.84"/>
<vertex x="15.04" y="6.11"/>
<vertex x="15.1" y="6.65"/>
<vertex x="15.25" y="7.09"/>
<vertex x="15.49" y="7.44"/>
<vertex x="15.8" y="7.72"/>
<vertex x="16.16" y="7.92"/>
<vertex x="16.56" y="8.07"/>
<vertex x="16.99" y="8.17"/>
</polygon>
<vertex x="22.77" y="10.93"/>
<vertex x="23" y="10.97"/>
<vertex x="23.23" y="11.01"/>
<vertex x="23.46" y="11.05"/>
<vertex x="23.69" y="11.09"/>
<vertex x="23.92" y="11.13"/>
<vertex x="24.15" y="11.17"/>
<vertex x="24.38" y="11.21"/>
<vertex x="24.61" y="11.25"/>
<vertex x="24.61" y="11.09"/>
<vertex x="24.61" y="10.93"/>
<vertex x="24.61" y="10.76"/>
<vertex x="24.61" y="10.6"/>
<vertex x="24.61" y="10.43"/>
<vertex x="24.61" y="10.27"/>
<vertex x="24.61" y="10.11"/>
<vertex x="24.61" y="9.94"/>
<vertex x="24.62" y="9.94"/>
<vertex x="24.78" y="10.26"/>
<vertex x="24.99" y="10.55"/>
<vertex x="25.24" y="10.81"/>
<vertex x="25.52" y="11.03"/>
<vertex x="25.83" y="11.2"/>
<vertex x="26.16" y="11.33"/>
<vertex x="26.51" y="11.42"/>
<vertex x="26.87" y="11.44"/>
<vertex x="26.92" y="11.44"/>
<vertex x="26.98" y="11.44"/>
<vertex x="27.03" y="11.44"/>
<vertex x="27.09" y="11.44"/>
<vertex x="27.14" y="11.43"/>
<vertex x="27.19" y="11.41"/>
<vertex x="27.24" y="11.4"/>
<vertex x="27.29" y="11.38"/>
<vertex x="27.29" y="11.16"/>
<vertex x="27.29" y="10.93"/>
<vertex x="27.29" y="10.71"/>
<vertex x="27.29" y="10.48"/>
<vertex x="27.29" y="10.26"/>
<vertex x="27.29" y="10.03"/>
<vertex x="27.29" y="9.81"/>
<vertex x="27.29" y="9.58"/>
<vertex x="27.22" y="9.6"/>
<vertex x="27.14" y="9.61"/>
<vertex x="27.06" y="9.63"/>
<vertex x="26.97" y="9.64"/>
<vertex x="26.87" y="9.64"/>
<vertex x="26.78" y="9.64"/>
<vertex x="26.69" y="9.64"/>
<vertex x="26.6" y="9.64"/>
<vertex x="26.1" y="9.6"/>
<vertex x="25.69" y="9.47"/>
<vertex x="25.36" y="9.26"/>
<vertex x="25.11" y="8.98"/>
<vertex x="24.91" y="8.65"/>
<vertex x="24.78" y="8.26"/>
<vertex x="24.71" y="7.84"/>
<vertex x="24.69" y="7.38"/>
<vertex x="24.69" y="6.98"/>
<vertex x="24.69" y="6.59"/>
<vertex x="24.69" y="6.19"/>
<vertex x="24.69" y="5.79"/>
<vertex x="24.69" y="5.39"/>
<vertex x="24.69" y="5"/>
<vertex x="24.69" y="4.6"/>
<vertex x="24.69" y="4.2"/>
<vertex x="24.44" y="4.2"/>
<vertex x="24.2" y="4.2"/>
<vertex x="23.96" y="4.2"/>
<vertex x="23.72" y="4.2"/>
<vertex x="23.48" y="4.2"/>
<vertex x="23.23" y="4.2"/>
<vertex x="22.99" y="4.2"/>
<vertex x="22.75" y="4.2"/>
<vertex x="22.75" y="5.04"/>
<vertex x="22.75" y="5.88"/>
<vertex x="22.75" y="6.72"/>
<vertex x="22.75" y="7.56"/>
<vertex x="22.75" y="8.4"/>
<vertex x="22.75" y="9.24"/>
<vertex x="22.75" y="10.09"/>
</polygon>
<vertex x="28.06" y="12.88"/>
<vertex x="29.99" y="13.94"/>
<vertex x="29.99" y="8.72"/>
<vertex x="32.43" y="11.26"/>
<vertex x="34.73" y="11.26"/>
<vertex x="32.07" y="8.66"/>
<vertex x="35.02" y="4.2"/>
<vertex x="32.68" y="4.2"/>
<vertex x="30.74" y="7.35"/>
<vertex x="29.99" y="6.63"/>
<vertex x="29.99" y="4.2"/>
<vertex x="28.06" y="4.2"/>
</polygon>
<vertex x="36.2" y="9.96"/>
<vertex x="35.96" y="9.96"/>
<vertex x="35.73" y="9.96"/>
<vertex x="35.49" y="9.96"/>
<vertex x="35.25" y="9.96"/>
<vertex x="35.01" y="9.96"/>
<vertex x="34.77" y="9.96"/>
<vertex x="34.53" y="9.96"/>
<vertex x="34.29" y="9.96"/>
<vertex x="34.46" y="10.12"/>
<vertex x="34.62" y="10.28"/>
<vertex x="34.79" y="10.45"/>
<vertex x="34.95" y="10.61"/>
<vertex x="35.12" y="10.77"/>
<vertex x="35.28" y="10.93"/>
<vertex x="35.45" y="11.09"/>
<vertex x="35.61" y="11.26"/>
<vertex x="35.69" y="11.26"/>
<vertex x="35.76" y="11.26"/>
<vertex x="35.83" y="11.26"/>
<vertex x="35.91" y="11.26"/>
<vertex x="35.98" y="11.26"/>
<vertex x="36.06" y="11.26"/>
<vertex x="36.13" y="11.26"/>
<vertex x="36.2" y="11.26"/>
<vertex x="36.2" y="11.32"/>
<vertex x="36.2" y="11.39"/>
<vertex x="36.2" y="11.46"/>
<vertex x="36.2" y="11.53"/>
<vertex x="36.2" y="11.59"/>
<vertex x="36.2" y="11.66"/>
<vertex x="36.2" y="11.73"/>
<vertex x="36.2" y="11.8"/>
<vertex x="36.24" y="12.25"/>
<vertex x="36.35" y="12.66"/>
<vertex x="36.53" y="13.03"/>
<vertex x="36.79" y="13.34"/>
<vertex x="37.12" y="13.59"/>
<vertex x="37.53" y="13.78"/>
<vertex x="38.01" y="13.9"/>
<vertex x="38.56" y="13.94"/>
<vertex x="38.69" y="13.94"/>
<vertex x="38.82" y="13.94"/>
<vertex x="38.95" y="13.94"/>
<vertex x="39.08" y="13.93"/>
<vertex x="39.21" y="13.91"/>
<vertex x="39.34" y="13.9"/>
<vertex x="39.46" y="13.9"/>
<vertex x="39.58" y="13.9"/>
<vertex x="39.58" y="13.72"/>
<vertex x="39.58" y="13.54"/>
<vertex x="39.58" y="13.36"/>
<vertex x="39.58" y="13.17"/>
<vertex x="39.58" y="12.99"/>
<vertex x="39.58" y="12.81"/>
<vertex x="39.58" y="12.63"/>
<vertex x="39.58" y="12.45"/>
<vertex x="39.5" y="12.47"/>
<vertex x="39.41" y="12.48"/>
<vertex x="39.32" y="12.48"/>
<vertex x="39.23" y="12.48"/>
<vertex x="39.14" y="12.48"/>
<vertex x="39.05" y="12.48"/>
<vertex x="38.96" y="12.48"/>
<vertex x="38.88" y="12.48"/>
<vertex x="38.69" y="12.47"/>
<vertex x="38.54" y="12.43"/>
<vertex x="38.41" y="12.38"/>
<vertex x="38.31" y="12.3"/>
<vertex x="38.23" y="12.19"/>
<vertex x="38.18" y="12.05"/>
<vertex x="38.15" y="11.88"/>
<vertex x="38.14" y="11.67"/>
<vertex x="38.14" y="11.62"/>
<vertex x="38.14" y="11.57"/>
<vertex x="38.14" y="11.52"/>
<vertex x="38.14" y="11.46"/>
<vertex x="38.14" y="11.41"/>
<vertex x="38.14" y="11.36"/>
<vertex x="38.14" y="11.3"/>
<vertex x="38.14" y="11.25"/>
<vertex x="38.31" y="11.25"/>
<vertex x="38.47" y="11.25"/>
<vertex x="38.64" y="11.25"/>
<vertex x="38.81" y="11.25"/>
<vertex x="38.97" y="11.25"/>
<vertex x="39.14" y="11.25"/>
<vertex x="39.31" y="11.25"/>
<vertex x="39.47" y="11.25"/>
<vertex x="39.47" y="11.09"/>
<vertex x="39.47" y="10.93"/>
<vertex x="39.47" y="10.77"/>
<vertex x="39.47" y="10.6"/>
<vertex x="39.47" y="10.44"/>
<vertex x="39.47" y="10.28"/>
<vertex x="39.47" y="10.12"/>
<vertex x="39.47" y="9.96"/>
<vertex x="39.31" y="9.96"/>
<vertex x="39.14" y="9.96"/>
<vertex x="38.97" y="9.96"/>
<vertex x="38.81" y="9.96"/>
<vertex x="38.64" y="9.96"/>
<vertex x="38.47" y="9.96"/>
<vertex x="38.31" y="9.96"/>
<vertex x="38.14" y="9.96"/>
<vertex x="38.14" y="9.24"/>
<vertex x="38.14" y="8.52"/>
<vertex x="38.14" y="7.8"/>
<vertex x="38.14" y="7.08"/>
<vertex x="38.14" y="6.36"/>
<vertex x="38.14" y="5.64"/>
<vertex x="38.14" y="4.92"/>
<vertex x="38.14" y="4.2"/>
<vertex x="37.9" y="4.2"/>
<vertex x="37.65" y="4.2"/>
<vertex x="37.41" y="4.2"/>
<vertex x="37.17" y="4.2"/>
<vertex x="36.93" y="4.2"/>
<vertex x="36.69" y="4.2"/>
<vertex x="36.44" y="4.2"/>
<vertex x="36.2" y="4.2"/>
<vertex x="36.2" y="4.92"/>
<vertex x="36.2" y="5.64"/>
<vertex x="36.2" y="6.36"/>
<vertex x="36.2" y="7.08"/>
<vertex x="36.2" y="7.8"/>
<vertex x="36.2" y="8.52"/>
<vertex x="36.2" y="9.24"/>
</polygon>
<vertex x="46.64" y="4.2"/>
<vertex x="46.41" y="4.2"/>
<vertex x="46.17" y="4.2"/>
<vertex x="45.94" y="4.2"/>
<vertex x="45.71" y="4.2"/>
<vertex x="45.48" y="4.2"/>
<vertex x="45.25" y="4.2"/>
<vertex x="45.02" y="4.2"/>
<vertex x="44.79" y="4.2"/>
<vertex x="44.79" y="4.33"/>
<vertex x="44.79" y="4.45"/>
<vertex x="44.79" y="4.57"/>
<vertex x="44.79" y="4.69"/>
<vertex x="44.79" y="4.82"/>
<vertex x="44.79" y="4.94"/>
<vertex x="44.79" y="5.06"/>
<vertex x="44.79" y="5.18"/>
<vertex x="44.78" y="5.18"/>
<vertex x="44.77" y="5.18"/>
<vertex x="44.57" y="4.9"/>
<vertex x="44.34" y="4.66"/>
<vertex x="44.09" y="4.46"/>
<vertex x="43.82" y="4.3"/>
<vertex x="43.53" y="4.17"/>
<vertex x="43.23" y="4.08"/>
<vertex x="42.92" y="4.03"/>
<vertex x="42.62" y="4.01"/>
<vertex x="41.91" y="4.06"/>
<vertex x="41.34" y="4.22"/>
<vertex x="40.89" y="4.47"/>
<vertex x="40.55" y="4.81"/>
<vertex x="40.31" y="5.23"/>
<vertex x="40.15" y="5.73"/>
<vertex x="40.06" y="6.29"/>
<vertex x="40.04" y="6.92"/>
<vertex x="40.04" y="7.46"/>
<vertex x="40.04" y="8"/>
<vertex x="40.04" y="8.54"/>
<vertex x="40.04" y="9.08"/>
<vertex x="40.04" y="9.63"/>
<vertex x="40.04" y="10.17"/>
<vertex x="40.04" y="10.71"/>
<vertex x="40.04" y="11.25"/>
<vertex x="40.28" y="11.25"/>
<vertex x="40.52" y="11.25"/>
<vertex x="40.76" y="11.25"/>
<vertex x="41.01" y="11.25"/>
<vertex x="41.25" y="11.25"/>
<vertex x="41.49" y="11.25"/>
<vertex x="41.73" y="11.25"/>
<vertex x="41.98" y="11.25"/>
<vertex x="41.98" y="10.76"/>
<vertex x="41.98" y="10.26"/>
<vertex x="41.98" y="9.76"/>
<vertex x="41.98" y="9.26"/>
<vertex x="41.98" y="8.76"/>
<vertex x="41.98" y="8.27"/>
<vertex x="41.98" y="7.77"/>
<vertex x="41.98" y="7.27"/>
<vertex x="41.99" y="6.86"/>
<vertex x="42.04" y="6.51"/>
<vertex x="42.13" y="6.21"/>
<vertex x="42.25" y="5.97"/>
<vertex x="42.42" y="5.78"/>
<vertex x="42.64" y="5.65"/>
<vertex x="42.9" y="5.57"/>
<vertex x="43.22" y="5.54"/>
<vertex x="43.58" y="5.57"/>
<vertex x="43.9" y="5.65"/>
<vertex x="44.15" y="5.8"/>
<vertex x="44.36" y="6.01"/>
<vertex x="44.52" y="6.29"/>
<vertex x="44.63" y="6.64"/>
<vertex x="44.7" y="7.06"/>
<vertex x="44.72" y="7.56"/>
<vertex x="44.72" y="8.02"/>
<vertex x="44.72" y="8.48"/>
<vertex x="44.72" y="8.94"/>
<vertex x="44.72" y="9.41"/>
<vertex x="44.72" y="9.87"/>
<vertex x="44.72" y="10.33"/>
<vertex x="44.72" y="10.79"/>
<vertex x="44.72" y="11.25"/>
<vertex x="44.96" y="11.25"/>
<vertex x="45.2" y="11.25"/>
<vertex x="45.44" y="11.25"/>
<vertex x="45.69" y="11.25"/>
<vertex x="45.93" y="11.25"/>
<vertex x="46.17" y="11.25"/>
<vertex x="46.41" y="11.25"/>
<vertex x="46.66" y="11.25"/>
<vertex x="46.66" y="10.37"/>
<vertex x="46.66" y="9.49"/>
<vertex x="46.66" y="8.61"/>
<vertex x="46.66" y="7.73"/>
<vertex x="46.66" y="6.85"/>
<vertex x="46.66" y="5.96"/>
<vertex x="46.66" y="5.08"/>
</polygon>
<vertex x="47.71" y="11.26"/>
<vertex x="47.94" y="11.26"/>
<vertex x="48.17" y="11.26"/>
<vertex x="48.4" y="11.26"/>
<vertex x="48.63" y="11.26"/>
<vertex x="48.86" y="11.26"/>
<vertex x="49.09" y="11.26"/>
<vertex x="49.32" y="11.26"/>
<vertex x="49.55" y="11.26"/>
<vertex x="49.55" y="11.13"/>
<vertex x="49.55" y="11.01"/>
<vertex x="49.55" y="10.89"/>
<vertex x="49.55" y="10.76"/>
<vertex x="49.55" y="10.64"/>
<vertex x="49.55" y="10.52"/>
<vertex x="49.55" y="10.4"/>
<vertex x="49.55" y="10.27"/>
<vertex x="49.56" y="10.27"/>
<vertex x="49.57" y="10.27"/>
<vertex x="49.77" y="10.56"/>
<vertex x="50" y="10.8"/>
<vertex x="50.25" y="11"/>
<vertex x="50.52" y="11.16"/>
<vertex x="50.81" y="11.29"/>
<vertex x="51.11" y="11.38"/>
<vertex x="51.42" y="11.43"/>
<vertex x="51.72" y="11.45"/>
<vertex x="52.43" y="11.39"/>
<vertex x="52.99" y="11.24"/>
<vertex x="53.44" y="10.99"/>
<vertex x="53.78" y="10.65"/>
<vertex x="54.03" y="10.23"/>
<vertex x="54.19" y="9.73"/>
<vertex x="54.27" y="9.17"/>
<vertex x="54.3" y="8.54"/>
<vertex x="54.3" y="8"/>
<vertex x="54.3" y="7.46"/>
<vertex x="54.3" y="6.92"/>
<vertex x="54.3" y="6.37"/>
<vertex x="54.3" y="5.83"/>
<vertex x="54.3" y="5.29"/>
<vertex x="54.3" y="4.75"/>
<vertex x="54.3" y="4.2"/>
<vertex x="54.06" y="4.2"/>
<vertex x="53.82" y="4.2"/>
<vertex x="53.57" y="4.2"/>
<vertex x="53.33" y="4.2"/>
<vertex x="53.09" y="4.2"/>
<vertex x="52.85" y="4.2"/>
<vertex x="52.61" y="4.2"/>
<vertex x="52.36" y="4.2"/>
<vertex x="52.36" y="4.7"/>
<vertex x="52.36" y="5.2"/>
<vertex x="52.36" y="5.7"/>
<vertex x="52.36" y="6.2"/>
<vertex x="52.36" y="6.69"/>
<vertex x="52.36" y="7.19"/>
<vertex x="52.36" y="7.69"/>
<vertex x="52.36" y="8.19"/>
<vertex x="52.35" y="8.59"/>
<vertex x="52.3" y="8.95"/>
<vertex x="52.21" y="9.24"/>
<vertex x="52.08" y="9.49"/>
<vertex x="51.92" y="9.68"/>
<vertex x="51.7" y="9.81"/>
<vertex x="51.44" y="9.89"/>
<vertex x="51.12" y="9.92"/>
<vertex x="50.76" y="9.89"/>
<vertex x="50.44" y="9.81"/>
<vertex x="50.19" y="9.66"/>
<vertex x="49.98" y="9.45"/>
<vertex x="49.82" y="9.17"/>
<vertex x="49.71" y="8.82"/>
<vertex x="49.64" y="8.4"/>
<vertex x="49.62" y="7.9"/>
<vertex x="49.62" y="7.44"/>
<vertex x="49.62" y="6.98"/>
<vertex x="49.62" y="6.51"/>
<vertex x="49.62" y="6.05"/>
<vertex x="49.62" y="5.59"/>
<vertex x="49.62" y="5.13"/>
<vertex x="49.62" y="4.67"/>
<vertex x="49.62" y="4.2"/>
<vertex x="49.38" y="4.2"/>
<vertex x="49.14" y="4.2"/>
<vertex x="48.9" y="4.2"/>
<vertex x="48.65" y="4.2"/>
<vertex x="48.41" y="4.2"/>
<vertex x="48.17" y="4.2"/>
<vertex x="47.93" y="4.2"/>
<vertex x="47.68" y="4.2"/>
<vertex x="47.68" y="5.09"/>
<vertex x="47.68" y="5.97"/>
<vertex x="47.68" y="6.85"/>
<vertex x="47.68" y="7.73"/>
<vertex x="47.68" y="8.61"/>
<vertex x="47.68" y="9.49"/>
<vertex x="47.68" y="10.37"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.6">
<vertex x="2.21" y="7.79"/>
<vertex x="2.25" y="7.45"/>
<vertex x="2.36" y="7.15"/>
<vertex x="2.54" y="6.91"/>
<vertex x="2.76" y="6.71"/>
<vertex x="3.03" y="6.56"/>
<vertex x="3.34" y="6.45"/>
<vertex x="3.66" y="6.39"/>
<vertex x="3.99" y="6.37"/>
<vertex x="4.25" y="6.39"/>
<vertex x="4.51" y="6.43"/>
<vertex x="4.76" y="6.5"/>
<vertex x="5" y="6.61"/>
<vertex x="5.21" y="6.75"/>
<vertex x="5.37" y="6.94"/>
<vertex x="5.48" y="7.17"/>
<vertex x="5.52" y="7.46"/>
<vertex x="5.47" y="7.7"/>
<vertex x="5.34" y="7.91"/>
<vertex x="5.12" y="8.09"/>
<vertex x="4.82" y="8.25"/>
<vertex x="4.44" y="8.39"/>
<vertex x="3.99" y="8.52"/>
<vertex x="3.47" y="8.64"/>
<vertex x="2.88" y="8.77"/>
<vertex x="2.38" y="8.89"/>
<vertex x="1.89" y="9.04"/>
<vertex x="1.43" y="9.22"/>
<vertex x="1.03" y="9.45"/>
<vertex x="0.69" y="9.73"/>
<vertex x="0.43" y="10.08"/>
<vertex x="0.26" y="10.51"/>
<vertex x="0.2" y="11.02"/>
<vertex x="0.28" y="11.76"/>
<vertex x="0.52" y="12.36"/>
<vertex x="0.88" y="12.83"/>
<vertex x="1.36" y="13.19"/>
<vertex x="1.91" y="13.45"/>
<vertex x="2.54" y="13.62"/>
<vertex x="3.2" y="13.71"/>
<vertex x="3.88" y="13.74"/>
<vertex x="4.56" y="13.71"/>
<vertex x="5.21" y="13.61"/>
<vertex x="5.82" y="13.44"/>
<vertex x="6.37" y="13.17"/>
<vertex x="6.83" y="12.81"/>
<vertex x="7.21" y="12.34"/>
<vertex x="7.47" y="11.76"/>
<vertex x="7.61" y="11.04"/>
<vertex x="7.34" y="11.04"/>
<vertex x="7.06" y="11.04"/>
<vertex x="6.78" y="11.04"/>
<vertex x="6.51" y="11.04"/>
<vertex x="6.23" y="11.04"/>
<vertex x="5.96" y="11.04"/>
<vertex x="5.68" y="11.04"/>
<vertex x="5.4" y="11.04"/>
<vertex x="5.35" y="11.35"/>
<vertex x="5.24" y="11.6"/>
<vertex x="5.09" y="11.8"/>
<vertex x="4.9" y="11.95"/>
<vertex x="4.67" y="12.06"/>
<vertex x="4.4" y="12.14"/>
<vertex x="4.12" y="12.18"/>
<vertex x="3.81" y="12.19"/>
<vertex x="3.61" y="12.19"/>
<vertex x="3.39" y="12.17"/>
<vertex x="3.17" y="12.14"/>
<vertex x="2.97" y="12.07"/>
<vertex x="2.79" y="11.97"/>
<vertex x="2.65" y="11.83"/>
<vertex x="2.55" y="11.65"/>
<vertex x="2.52" y="11.41"/>
<vertex x="2.58" y="11.13"/>
<vertex x="2.75" y="10.91"/>
<vertex x="3.01" y="10.73"/>
<vertex x="3.35" y="10.59"/>
<vertex x="3.75" y="10.47"/>
<vertex x="4.19" y="10.36"/>
<vertex x="4.67" y="10.26"/>
<vertex x="5.16" y="10.16"/>
<vertex x="5.66" y="10.03"/>
<vertex x="6.15" y="9.87"/>
<vertex x="6.6" y="9.68"/>
<vertex x="7.01" y="9.44"/>
<vertex x="7.35" y="9.14"/>
<vertex x="7.61" y="8.77"/>
<vertex x="7.78" y="8.32"/>
<vertex x="7.84" y="7.78"/>
<vertex x="7.75" y="7.02"/>
<vertex x="7.51" y="6.38"/>
<vertex x="7.12" y="5.87"/>
<vertex x="6.63" y="5.47"/>
<vertex x="6.04" y="5.18"/>
<vertex x="5.39" y="4.98"/>
<vertex x="4.69" y="4.87"/>
<vertex x="3.98" y="4.84"/>
<vertex x="3.24" y="4.87"/>
<vertex x="2.54" y="4.98"/>
<vertex x="1.88" y="5.19"/>
<vertex x="1.28" y="5.48"/>
<vertex x="0.78" y="5.89"/>
<vertex x="0.38" y="6.4"/>
<vertex x="0.11" y="7.04"/>
<vertex x="0" y="7.79"/>
<vertex x="0.28" y="7.79"/>
<vertex x="0.55" y="7.79"/>
<vertex x="0.83" y="7.79"/>
<vertex x="1.1" y="7.79"/>
<vertex x="1.38" y="7.79"/>
<vertex x="1.66" y="7.79"/>
<vertex x="1.93" y="7.79"/>
</polygon>
<vertex x="14.82" y="7.8"/>
<vertex x="14.95" y="8.25"/>
<vertex x="15.03" y="8.74"/>
<vertex x="15.05" y="9.25"/>
<vertex x="17.38" y="9.19"/>
<vertex x="17.32" y="8.35"/>
<vertex x="17.15" y="7.55"/>
<vertex x="16.86" y="6.81"/>
</polygon>
<vertex x="16.45" y="6.15"/>
<vertex x="15.93" y="5.6"/>
<vertex x="15.29" y="5.18"/>
<vertex x="14.54" y="4.91"/>
<vertex x="13.66" y="4.82"/>
<vertex x="13.28" y="4.84"/>
<vertex x="12.91" y="4.9"/>
<vertex x="12.56" y="5"/>
<vertex x="12.22" y="5.14"/>
<vertex x="11.91" y="5.32"/>
<vertex x="11.62" y="5.54"/>
<vertex x="11.36" y="5.8"/>
<vertex x="11.13" y="6.09"/>
<vertex x="11.12" y="6.09"/>
<vertex x="11.11" y="6.09"/>
<vertex x="11.11" y="5.33"/>
<vertex x="11.11" y="4.57"/>
<vertex x="11.11" y="3.81"/>
<vertex x="11.11" y="3.05"/>
<vertex x="11.11" y="2.28"/>
<vertex x="11.11" y="1.52"/>
<vertex x="11.11" y="0.76"/>
<vertex x="11.11" y="0"/>
<vertex x="10.82" y="0.26"/>
<vertex x="10.53" y="0.52"/>
<vertex x="10.24" y="0.78"/>
<vertex x="9.95" y="1.03"/>
<vertex x="9.66" y="1.29"/>
<vertex x="9.37" y="1.55"/>
<vertex x="9.08" y="1.81"/>
<vertex x="8.79" y="2.07"/>
<vertex x="8.79" y="3.45"/>
<vertex x="8.79" y="4.83"/>
<vertex x="8.79" y="6.21"/>
<vertex x="8.79" y="7.59"/>
<vertex x="8.79" y="8.97"/>
<vertex x="8.79" y="10.35"/>
<vertex x="8.79" y="11.73"/>
<vertex x="8.79" y="13.11"/>
<vertex x="9.07" y="13.16"/>
<vertex x="9.34" y="13.21"/>
<vertex x="9.62" y="13.26"/>
<vertex x="9.89" y="13.31"/>
<vertex x="10.17" y="13.36"/>
<vertex x="10.45" y="13.41"/>
<vertex x="10.72" y="13.46"/>
<vertex x="11" y="13.51"/>
<vertex x="11" y="13.37"/>
<vertex x="11" y="13.24"/>
<vertex x="11" y="13.1"/>
<vertex x="11" y="12.97"/>
<vertex x="11" y="12.83"/>
<vertex x="11" y="12.7"/>
<vertex x="11" y="12.56"/>
<vertex x="11" y="12.42"/>
<vertex x="11.01" y="12.42"/>
<vertex x="11.24" y="12.74"/>
<vertex x="11.5" y="13.02"/>
<vertex x="11.79" y="13.24"/>
<vertex x="12.1" y="13.42"/>
<vertex x="12.43" y="13.56"/>
<vertex x="12.78" y="13.66"/>
<vertex x="13.15" y="13.72"/>
<vertex x="13.53" y="13.73"/>
<vertex x="14.46" y="13.64"/>
<vertex x="15.25" y="13.36"/>
<vertex x="15.92" y="12.93"/>
<vertex x="16.45" y="12.36"/>
<vertex x="16.86" y="11.68"/>
<vertex x="17.15" y="10.91"/>
<vertex x="17.32" y="10.07"/>
<vertex x="15.03" y="9.76"/>
<vertex x="14.95" y="10.25"/>
<vertex x="14.8" y="10.71"/>
<vertex x="14.6" y="11.12"/>
<vertex x="14.32" y="11.47"/>
<vertex x="13.97" y="11.74"/>
<vertex x="13.54" y="11.92"/>
<vertex x="13.03" y="11.98"/>
<vertex x="12.5" y="11.92"/>
<vertex x="12.07" y="11.75"/>
<vertex x="11.72" y="11.48"/>
<vertex x="11.45" y="11.13"/>
<vertex x="11.25" y="10.72"/>
<vertex x="11.11" y="10.26"/>
<vertex x="11.04" y="9.76"/>
<vertex x="11.01" y="9.25"/>
<vertex x="11.04" y="8.74"/>
<vertex x="11.12" y="8.25"/>
<vertex x="11.26" y="7.8"/>
<vertex x="11.46" y="7.39"/>
<vertex x="11.74" y="7.05"/>
<vertex x="12.09" y="6.79"/>
<vertex x="12.52" y="6.62"/>
<vertex x="13.04" y="6.57"/>
<vertex x="13.57" y="6.62"/>
<vertex x="14" y="6.79"/>
<vertex x="14.35" y="7.05"/>
<vertex x="14.62" y="7.39"/>
</polygon>
<vertex x="20.91" y="9.9"/>
<vertex x="21.44" y="9.97"/>
<vertex x="21.95" y="10.03"/>
<vertex x="22.42" y="10.09"/>
<vertex x="22.7" y="8.84"/>
<vertex x="22.57" y="8.82"/>
<vertex x="22.43" y="8.8"/>
<vertex x="22.3" y="8.78"/>
<vertex x="22.16" y="8.76"/>
<vertex x="22.02" y="8.74"/>
<vertex x="21.88" y="8.72"/>
<vertex x="21.75" y="8.69"/>
<vertex x="21.61" y="8.67"/>
<vertex x="21.48" y="8.64"/>
<vertex x="21.35" y="8.6"/>
</polygon>
<vertex x="21.23" y="8.56"/>
<vertex x="21.11" y="8.51"/>
<vertex x="20.99" y="8.46"/>
<vertex x="20.89" y="8.4"/>
<vertex x="20.79" y="8.34"/>
<vertex x="20.7" y="8.26"/>
<vertex x="20.62" y="8.18"/>
<vertex x="20.54" y="8.08"/>
<vertex x="20.48" y="7.98"/>
<vertex x="20.44" y="7.86"/>
<vertex x="20.4" y="7.74"/>
<vertex x="20.38" y="7.6"/>
<vertex x="20.37" y="7.44"/>
<vertex x="20.38" y="7.29"/>
<vertex x="20.4" y="7.15"/>
<vertex x="20.44" y="7.03"/>
<vertex x="20.49" y="6.92"/>
<vertex x="20.55" y="6.82"/>
<vertex x="20.62" y="6.73"/>
<vertex x="20.71" y="6.65"/>
<vertex x="20.8" y="6.59"/>
<vertex x="20.9" y="6.53"/>
<vertex x="21.01" y="6.48"/>
<vertex x="21.13" y="6.44"/>
<vertex x="21.25" y="6.41"/>
<vertex x="21.38" y="6.39"/>
<vertex x="21.52" y="6.37"/>
<vertex x="21.66" y="6.37"/>
<vertex x="21.8" y="6.37"/>
<vertex x="22.12" y="6.39"/>
<vertex x="22.4" y="6.44"/>
<vertex x="22.64" y="6.51"/>
<vertex x="22.86" y="6.61"/>
<vertex x="23.04" y="6.72"/>
<vertex x="23.19" y="6.85"/>
<vertex x="23.31" y="7"/>
<vertex x="23.42" y="7.15"/>
<vertex x="23.5" y="7.31"/>
<vertex x="23.56" y="7.48"/>
<vertex x="23.61" y="7.64"/>
<vertex x="23.64" y="7.8"/>
<vertex x="23.66" y="7.95"/>
<vertex x="23.67" y="8.09"/>
<vertex x="23.68" y="8.21"/>
<vertex x="23.68" y="8.32"/>
<vertex x="23.68" y="8.38"/>
<vertex x="23.68" y="8.43"/>
<vertex x="23.68" y="8.48"/>
<vertex x="23.68" y="8.54"/>
<vertex x="23.68" y="8.59"/>
<vertex x="23.68" y="8.65"/>
<vertex x="23.68" y="8.7"/>
<vertex x="23.68" y="8.75"/>
<vertex x="23.68" y="8.81"/>
<vertex x="23.68" y="8.86"/>
<vertex x="23.68" y="8.92"/>
<vertex x="23.68" y="8.97"/>
<vertex x="23.68" y="9.02"/>
<vertex x="23.68" y="9.08"/>
<vertex x="23.68" y="9.13"/>
<vertex x="23.68" y="9.19"/>
<vertex x="23.6" y="9.13"/>
<vertex x="23.51" y="9.07"/>
<vertex x="23.41" y="9.02"/>
<vertex x="23.31" y="8.98"/>
<vertex x="23.2" y="8.94"/>
<vertex x="23.08" y="8.91"/>
<vertex x="22.96" y="8.88"/>
<vertex x="22.83" y="8.86"/>
<vertex x="22.84" y="10.2"/>
<vertex x="23.2" y="10.32"/>
<vertex x="23.46" y="10.49"/>
<vertex x="23.63" y="10.72"/>
<vertex x="23.68" y="11.03"/>
<vertex x="23.67" y="11.21"/>
<vertex x="23.65" y="11.36"/>
<vertex x="23.61" y="11.5"/>
<vertex x="23.56" y="11.63"/>
<vertex x="23.49" y="11.73"/>
<vertex x="23.42" y="11.83"/>
<vertex x="23.33" y="11.91"/>
<vertex x="23.23" y="11.98"/>
<vertex x="23.13" y="12.03"/>
<vertex x="23.01" y="12.08"/>
<vertex x="22.89" y="12.11"/>
<vertex x="22.75" y="12.14"/>
<vertex x="22.62" y="12.16"/>
<vertex x="22.47" y="12.17"/>
<vertex x="22.32" y="12.17"/>
<vertex x="22.17" y="12.17"/>
<vertex x="22.01" y="12.17"/>
<vertex x="21.85" y="12.16"/>
<vertex x="21.7" y="12.13"/>
<vertex x="21.56" y="12.1"/>
<vertex x="21.43" y="12.06"/>
<vertex x="21.31" y="12.01"/>
<vertex x="21.2" y="11.95"/>
<vertex x="21.1" y="11.88"/>
<vertex x="21" y="11.79"/>
<vertex x="20.92" y="11.7"/>
<vertex x="20.85" y="11.6"/>
<vertex x="20.78" y="11.48"/>
<vertex x="20.73" y="11.35"/>
<vertex x="20.69" y="11.21"/>
<vertex x="20.66" y="11.06"/>
<vertex x="20.63" y="10.89"/>
<vertex x="20.49" y="10.89"/>
<vertex x="20.34" y="10.89"/>
<vertex x="20.2" y="10.89"/>
<vertex x="20.05" y="10.89"/>
<vertex x="19.91" y="10.89"/>
<vertex x="19.76" y="10.89"/>
<vertex x="19.62" y="10.89"/>
<vertex x="19.47" y="10.89"/>
<vertex x="19.33" y="10.89"/>
<vertex x="19.18" y="10.89"/>
<vertex x="19.04" y="10.89"/>
<vertex x="18.89" y="10.89"/>
<vertex x="18.75" y="10.89"/>
<vertex x="18.6" y="10.89"/>
<vertex x="18.46" y="10.89"/>
<vertex x="18.31" y="10.89"/>
<vertex x="18.36" y="11.28"/>
<vertex x="18.44" y="11.64"/>
<vertex x="18.57" y="11.96"/>
<vertex x="18.72" y="12.25"/>
<vertex x="18.91" y="12.51"/>
<vertex x="19.13" y="12.74"/>
<vertex x="19.37" y="12.94"/>
<vertex x="19.64" y="13.12"/>
<vertex x="19.93" y="13.27"/>
<vertex x="20.23" y="13.4"/>
<vertex x="20.55" y="13.5"/>
<vertex x="20.89" y="13.59"/>
<vertex x="21.23" y="13.65"/>
<vertex x="21.58" y="13.69"/>
<vertex x="21.94" y="13.72"/>
<vertex x="22.29" y="13.72"/>
<vertex x="22.61" y="13.72"/>
<vertex x="22.94" y="13.7"/>
<vertex x="23.26" y="13.67"/>
<vertex x="23.58" y="13.63"/>
<vertex x="23.9" y="13.57"/>
<vertex x="24.21" y="13.49"/>
<vertex x="24.5" y="13.4"/>
<vertex x="24.78" y="13.28"/>
<vertex x="25.04" y="13.14"/>
<vertex x="25.28" y="12.97"/>
<vertex x="25.49" y="12.77"/>
<vertex x="25.66" y="12.55"/>
<vertex x="25.81" y="12.29"/>
<vertex x="25.92" y="12"/>
<vertex x="25.99" y="11.68"/>
<vertex x="26.01" y="11.31"/>
<vertex x="26.01" y="11.04"/>
<vertex x="26.01" y="10.76"/>
<vertex x="26.01" y="10.49"/>
<vertex x="26.01" y="10.21"/>
<vertex x="26.01" y="9.94"/>
<vertex x="26.01" y="9.66"/>
<vertex x="26.01" y="9.39"/>
<vertex x="26.01" y="9.11"/>
<vertex x="26.01" y="8.84"/>
<vertex x="26.01" y="8.56"/>
<vertex x="26.01" y="8.29"/>
<vertex x="26.01" y="8.01"/>
<vertex x="26.01" y="7.74"/>
<vertex x="26.01" y="7.46"/>
<vertex x="26.01" y="7.19"/>
<vertex x="26.01" y="6.91"/>
<vertex x="26.01" y="6.77"/>
<vertex x="26.01" y="6.62"/>
<vertex x="26.01" y="6.48"/>
<vertex x="26.02" y="6.34"/>
<vertex x="26.02" y="6.2"/>
<vertex x="26.04" y="6.07"/>
<vertex x="26.05" y="5.94"/>
<vertex x="26.07" y="5.81"/>
<vertex x="26.09" y="5.69"/>
<vertex x="26.11" y="5.57"/>
<vertex x="26.14" y="5.46"/>
<vertex x="26.16" y="5.36"/>
<vertex x="26.19" y="5.26"/>
<vertex x="26.22" y="5.18"/>
<vertex x="26.26" y="5.1"/>
<vertex x="26.3" y="5.03"/>
<vertex x="26.15" y="5.03"/>
<vertex x="26" y="5.03"/>
<vertex x="25.86" y="5.03"/>
<vertex x="25.71" y="5.03"/>
<vertex x="25.56" y="5.03"/>
<vertex x="25.41" y="5.03"/>
<vertex x="25.27" y="5.03"/>
<vertex x="25.12" y="5.03"/>
<vertex x="24.97" y="5.03"/>
<vertex x="24.83" y="5.03"/>
<vertex x="24.68" y="5.03"/>
<vertex x="24.53" y="5.03"/>
<vertex x="24.39" y="5.03"/>
<vertex x="24.24" y="5.03"/>
<vertex x="24.09" y="5.03"/>
<vertex x="23.94" y="5.03"/>
<vertex x="23.93" y="5.08"/>
<vertex x="23.91" y="5.13"/>
<vertex x="23.89" y="5.18"/>
<vertex x="23.87" y="5.23"/>
<vertex x="23.85" y="5.28"/>
<vertex x="23.84" y="5.33"/>
<vertex x="23.83" y="5.38"/>
<vertex x="23.82" y="5.43"/>
<vertex x="23.81" y="5.48"/>
<vertex x="23.8" y="5.54"/>
<vertex x="23.8" y="5.59"/>
<vertex x="23.79" y="5.64"/>
<vertex x="23.79" y="5.69"/>
<vertex x="23.79" y="5.75"/>
<vertex x="23.78" y="5.8"/>
<vertex x="23.78" y="5.85"/>
<vertex x="23.64" y="5.71"/>
<vertex x="23.49" y="5.59"/>
<vertex x="23.33" y="5.47"/>
<vertex x="23.17" y="5.36"/>
<vertex x="23.01" y="5.27"/>
<vertex x="22.83" y="5.18"/>
<vertex x="22.66" y="5.11"/>
<vertex x="22.47" y="5.04"/>
<vertex x="22.29" y="4.98"/>
<vertex x="22.1" y="4.93"/>
<vertex x="21.91" y="4.89"/>
<vertex x="21.72" y="4.86"/>
<vertex x="21.52" y="4.83"/>
<vertex x="21.33" y="4.81"/>
<vertex x="21.13" y="4.8"/>
<vertex x="20.93" y="4.8"/>
<vertex x="20.63" y="4.8"/>
<vertex x="20.34" y="4.83"/>
<vertex x="20.07" y="4.87"/>
<vertex x="19.8" y="4.94"/>
<vertex x="19.55" y="5.03"/>
<vertex x="19.31" y="5.13"/>
<vertex x="19.09" y="5.26"/>
<vertex x="18.89" y="5.41"/>
<vertex x="18.7" y="5.58"/>
<vertex x="18.54" y="5.76"/>
<vertex x="18.4" y="5.97"/>
<vertex x="18.28" y="6.2"/>
<vertex x="18.18" y="6.45"/>
<vertex x="18.11" y="6.72"/>
<vertex x="18.07" y="7.01"/>
<vertex x="18.05" y="7.33"/>
<vertex x="18.12" y="7.98"/>
<vertex x="18.31" y="8.51"/>
<vertex x="18.59" y="8.93"/>
<vertex x="18.96" y="9.26"/>
<vertex x="19.39" y="9.5"/>
<vertex x="19.87" y="9.68"/>
<vertex x="20.39" y="9.81"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="27.32" y="13.11"/>
<vertex x="27.59" y="13.16"/>
<vertex x="27.87" y="13.21"/>
<vertex x="28.15" y="13.26"/>
<vertex x="28.42" y="13.31"/>
<vertex x="28.7" y="13.36"/>
<vertex x="28.98" y="13.41"/>
<vertex x="29.25" y="13.46"/>
<vertex x="29.53" y="13.5"/>
<vertex x="29.53" y="13.31"/>
<vertex x="29.53" y="13.11"/>
<vertex x="29.53" y="12.91"/>
<vertex x="29.53" y="12.72"/>
<vertex x="29.53" y="12.52"/>
<vertex x="29.53" y="12.32"/>
<vertex x="29.53" y="12.13"/>
<vertex x="29.53" y="11.93"/>
<vertex x="29.54" y="11.93"/>
<vertex x="29.74" y="12.31"/>
<vertex x="29.99" y="12.66"/>
<vertex x="30.28" y="12.97"/>
<vertex x="30.62" y="13.23"/>
<vertex x="30.99" y="13.44"/>
<vertex x="31.39" y="13.6"/>
<vertex x="31.81" y="13.7"/>
<vertex x="32.24" y="13.73"/>
<vertex x="32.31" y="13.73"/>
<vertex x="32.38" y="13.73"/>
<vertex x="32.44" y="13.73"/>
<vertex x="32.5" y="13.73"/>
<vertex x="32.57" y="13.72"/>
<vertex x="32.63" y="13.7"/>
<vertex x="32.69" y="13.68"/>
<vertex x="32.75" y="13.66"/>
<vertex x="32.75" y="13.39"/>
<vertex x="32.75" y="13.12"/>
<vertex x="32.75" y="12.85"/>
<vertex x="32.75" y="12.58"/>
<vertex x="32.75" y="12.31"/>
<vertex x="32.75" y="12.04"/>
<vertex x="32.75" y="11.77"/>
<vertex x="32.75" y="11.5"/>
<vertex x="32.67" y="11.52"/>
<vertex x="32.57" y="11.54"/>
<vertex x="32.47" y="11.56"/>
<vertex x="32.36" y="11.57"/>
<vertex x="32.25" y="11.57"/>
<vertex x="32.13" y="11.57"/>
<vertex x="32.02" y="11.57"/>
<vertex x="31.92" y="11.57"/>
<vertex x="31.32" y="11.52"/>
<vertex x="30.83" y="11.36"/>
<vertex x="30.44" y="11.11"/>
<vertex x="30.13" y="10.78"/>
<vertex x="29.9" y="10.38"/>
<vertex x="29.74" y="9.92"/>
<vertex x="29.65" y="9.41"/>
<vertex x="29.62" y="8.86"/>
<vertex x="29.62" y="8.38"/>
<vertex x="29.62" y="7.9"/>
<vertex x="29.62" y="7.43"/>
<vertex x="29.62" y="6.95"/>
<vertex x="29.62" y="6.47"/>
<vertex x="29.62" y="6"/>
<vertex x="29.62" y="5.52"/>
<vertex x="29.62" y="5.04"/>
<vertex x="29.33" y="5.04"/>
<vertex x="29.04" y="5.04"/>
<vertex x="28.75" y="5.04"/>
<vertex x="28.46" y="5.04"/>
<vertex x="28.17" y="5.04"/>
<vertex x="27.88" y="5.04"/>
<vertex x="27.59" y="5.04"/>
<vertex x="27.3" y="5.04"/>
<vertex x="27.3" y="6.05"/>
<vertex x="27.3" y="7.06"/>
<vertex x="27.3" y="8.07"/>
<vertex x="27.3" y="9.08"/>
<vertex x="27.3" y="10.09"/>
<vertex x="27.3" y="11.09"/>
<vertex x="27.3" y="12.1"/>
</polygon>
<vertex x="33.67" y="15.46"/>
<vertex x="35.99" y="16.73"/>
<vertex x="35.99" y="10.46"/>
<vertex x="38.92" y="13.51"/>
<vertex x="41.67" y="13.51"/>
<vertex x="38.48" y="10.39"/>
<vertex x="42.03" y="5.04"/>
<vertex x="39.21" y="5.04"/>
<vertex x="36.89" y="8.83"/>
<vertex x="35.99" y="7.96"/>
<vertex x="35.99" y="5.04"/>
<vertex x="33.67" y="5.04"/>
</polygon>
<vertex x="43.44" y="11.95"/>
<vertex x="43.16" y="11.95"/>
<vertex x="42.87" y="11.95"/>
<vertex x="42.58" y="11.95"/>
<vertex x="42.3" y="11.95"/>
<vertex x="42.01" y="11.95"/>
<vertex x="41.72" y="11.95"/>
<vertex x="41.44" y="11.95"/>
<vertex x="41.15" y="11.95"/>
<vertex x="41.35" y="12.15"/>
<vertex x="41.55" y="12.34"/>
<vertex x="41.75" y="12.54"/>
<vertex x="41.94" y="12.73"/>
<vertex x="42.14" y="12.92"/>
<vertex x="42.34" y="13.12"/>
<vertex x="42.54" y="13.31"/>
<vertex x="42.74" y="13.51"/>
<vertex x="42.82" y="13.51"/>
<vertex x="42.91" y="13.51"/>
<vertex x="43" y="13.51"/>
<vertex x="43.09" y="13.51"/>
<vertex x="43.18" y="13.51"/>
<vertex x="43.27" y="13.51"/>
<vertex x="43.36" y="13.51"/>
<vertex x="43.44" y="13.51"/>
<vertex x="43.44" y="13.59"/>
<vertex x="43.44" y="13.67"/>
<vertex x="43.44" y="13.75"/>
<vertex x="43.44" y="13.83"/>
<vertex x="43.44" y="13.91"/>
<vertex x="43.44" y="13.99"/>
<vertex x="43.44" y="14.07"/>
<vertex x="43.44" y="14.16"/>
<vertex x="43.49" y="14.7"/>
<vertex x="43.62" y="15.19"/>
<vertex x="43.84" y="15.63"/>
<vertex x="44.15" y="16.01"/>
<vertex x="44.54" y="16.31"/>
<vertex x="45.03" y="16.54"/>
<vertex x="45.61" y="16.68"/>
<vertex x="46.28" y="16.73"/>
<vertex x="46.43" y="16.73"/>
<vertex x="46.58" y="16.73"/>
<vertex x="46.74" y="16.73"/>
<vertex x="46.9" y="16.71"/>
<vertex x="47.05" y="16.69"/>
<vertex x="47.2" y="16.68"/>
<vertex x="47.35" y="16.68"/>
<vertex x="47.5" y="16.68"/>
<vertex x="47.5" y="16.46"/>
<vertex x="47.5" y="16.24"/>
<vertex x="47.5" y="16.03"/>
<vertex x="47.5" y="15.81"/>
<vertex x="47.5" y="15.59"/>
<vertex x="47.5" y="15.38"/>
<vertex x="47.5" y="15.16"/>
<vertex x="47.5" y="14.94"/>
<vertex x="47.4" y="14.96"/>
<vertex x="47.29" y="14.98"/>
<vertex x="47.18" y="14.98"/>
<vertex x="47.08" y="14.98"/>
<vertex x="46.97" y="14.98"/>
<vertex x="46.86" y="14.98"/>
<vertex x="46.76" y="14.98"/>
<vertex x="46.65" y="14.98"/>
<vertex x="46.43" y="14.96"/>
<vertex x="46.24" y="14.92"/>
<vertex x="46.09" y="14.85"/>
<vertex x="45.97" y="14.75"/>
<vertex x="45.88" y="14.62"/>
<vertex x="45.82" y="14.46"/>
<vertex x="45.78" y="14.25"/>
<vertex x="45.77" y="14.01"/>
<vertex x="45.77" y="13.94"/>
<vertex x="45.77" y="13.88"/>
<vertex x="45.77" y="13.82"/>
<vertex x="45.77" y="13.75"/>
<vertex x="45.77" y="13.69"/>
<vertex x="45.77" y="13.63"/>
<vertex x="45.77" y="13.56"/>
<vertex x="45.77" y="13.5"/>
<vertex x="45.97" y="13.5"/>
<vertex x="46.17" y="13.5"/>
<vertex x="46.37" y="13.5"/>
<vertex x="46.57" y="13.5"/>
<vertex x="46.77" y="13.5"/>
<vertex x="46.97" y="13.5"/>
<vertex x="47.17" y="13.5"/>
<vertex x="47.37" y="13.5"/>
<vertex x="47.37" y="13.31"/>
<vertex x="47.37" y="13.11"/>
<vertex x="47.37" y="12.92"/>
<vertex x="47.37" y="12.72"/>
<vertex x="47.37" y="12.53"/>
<vertex x="47.37" y="12.34"/>
<vertex x="47.37" y="12.14"/>
<vertex x="47.37" y="11.95"/>
<vertex x="47.17" y="11.95"/>
<vertex x="46.97" y="11.95"/>
<vertex x="46.77" y="11.95"/>
<vertex x="46.57" y="11.95"/>
<vertex x="46.37" y="11.95"/>
<vertex x="46.17" y="11.95"/>
<vertex x="45.97" y="11.95"/>
<vertex x="45.77" y="11.95"/>
<vertex x="45.77" y="11.08"/>
<vertex x="45.77" y="10.22"/>
<vertex x="45.77" y="9.36"/>
<vertex x="45.77" y="8.49"/>
<vertex x="45.77" y="7.63"/>
<vertex x="45.77" y="6.77"/>
<vertex x="45.77" y="5.9"/>
<vertex x="45.77" y="5.04"/>
<vertex x="45.48" y="5.04"/>
<vertex x="45.18" y="5.04"/>
<vertex x="44.89" y="5.04"/>
<vertex x="44.6" y="5.04"/>
<vertex x="44.31" y="5.04"/>
<vertex x="44.02" y="5.04"/>
<vertex x="43.73" y="5.04"/>
<vertex x="43.44" y="5.04"/>
<vertex x="43.44" y="5.9"/>
<vertex x="43.44" y="6.77"/>
<vertex x="43.44" y="7.63"/>
<vertex x="43.44" y="8.49"/>
<vertex x="43.44" y="9.36"/>
<vertex x="43.44" y="10.22"/>
<vertex x="43.44" y="11.08"/>
</polygon>
<vertex x="55.96" y="5.04"/>
<vertex x="55.69" y="5.04"/>
<vertex x="55.41" y="5.04"/>
<vertex x="55.13" y="5.04"/>
<vertex x="54.86" y="5.04"/>
<vertex x="54.58" y="5.04"/>
<vertex x="54.3" y="5.04"/>
<vertex x="54.03" y="5.04"/>
<vertex x="53.75" y="5.04"/>
<vertex x="53.75" y="5.19"/>
<vertex x="53.75" y="5.34"/>
<vertex x="53.75" y="5.49"/>
<vertex x="53.75" y="5.63"/>
<vertex x="53.75" y="5.78"/>
<vertex x="53.75" y="5.93"/>
<vertex x="53.75" y="6.07"/>
<vertex x="53.75" y="6.22"/>
<vertex x="53.74" y="6.22"/>
<vertex x="53.73" y="6.22"/>
<vertex x="53.72" y="6.22"/>
<vertex x="53.49" y="5.88"/>
<vertex x="53.21" y="5.59"/>
<vertex x="52.91" y="5.35"/>
<vertex x="52.58" y="5.16"/>
<vertex x="52.23" y="5"/>
<vertex x="51.87" y="4.9"/>
<vertex x="51.51" y="4.83"/>
<vertex x="51.14" y="4.81"/>
<vertex x="50.3" y="4.88"/>
<vertex x="49.61" y="5.06"/>
<vertex x="49.07" y="5.36"/>
<vertex x="48.67" y="5.77"/>
<vertex x="48.37" y="6.28"/>
<vertex x="48.18" y="6.87"/>
<vertex x="48.08" y="7.55"/>
<vertex x="48.05" y="8.3"/>
<vertex x="48.05" y="8.95"/>
<vertex x="48.05" y="9.6"/>
<vertex x="48.05" y="10.25"/>
<vertex x="48.05" y="10.9"/>
<vertex x="48.05" y="11.55"/>
<vertex x="48.05" y="12.2"/>
<vertex x="48.05" y="12.85"/>
<vertex x="48.05" y="13.5"/>
<vertex x="48.34" y="13.5"/>
<vertex x="48.63" y="13.5"/>
<vertex x="48.92" y="13.5"/>
<vertex x="49.21" y="13.5"/>
<vertex x="49.5" y="13.5"/>
<vertex x="49.79" y="13.5"/>
<vertex x="50.08" y="13.5"/>
<vertex x="50.37" y="13.5"/>
<vertex x="50.37" y="12.91"/>
<vertex x="50.37" y="12.31"/>
<vertex x="50.37" y="11.71"/>
<vertex x="50.37" y="11.12"/>
<vertex x="50.37" y="10.52"/>
<vertex x="50.37" y="9.92"/>
<vertex x="50.37" y="9.32"/>
<vertex x="50.37" y="8.73"/>
<vertex x="50.39" y="8.24"/>
<vertex x="50.45" y="7.81"/>
<vertex x="50.55" y="7.46"/>
<vertex x="50.71" y="7.16"/>
<vertex x="50.91" y="6.94"/>
<vertex x="51.17" y="6.78"/>
<vertex x="51.48" y="6.68"/>
<vertex x="51.86" y="6.65"/>
<vertex x="52.3" y="6.68"/>
<vertex x="52.67" y="6.78"/>
<vertex x="52.98" y="6.96"/>
<vertex x="53.23" y="7.21"/>
<vertex x="53.42" y="7.55"/>
<vertex x="53.56" y="7.97"/>
<vertex x="53.64" y="8.47"/>
<vertex x="53.66" y="9.07"/>
<vertex x="53.66" y="9.62"/>
<vertex x="53.66" y="10.18"/>
<vertex x="53.66" y="10.73"/>
<vertex x="53.66" y="11.29"/>
<vertex x="53.66" y="11.84"/>
<vertex x="53.66" y="12.4"/>
<vertex x="53.66" y="12.95"/>
<vertex x="53.66" y="13.5"/>
<vertex x="53.95" y="13.5"/>
<vertex x="54.24" y="13.5"/>
<vertex x="54.53" y="13.5"/>
<vertex x="54.82" y="13.5"/>
<vertex x="55.11" y="13.5"/>
<vertex x="55.41" y="13.5"/>
<vertex x="55.7" y="13.5"/>
<vertex x="55.99" y="13.5"/>
<vertex x="55.99" y="12.45"/>
<vertex x="55.99" y="11.39"/>
<vertex x="55.99" y="10.33"/>
<vertex x="55.99" y="9.27"/>
<vertex x="55.99" y="8.22"/>
<vertex x="55.99" y="7.16"/>
<vertex x="55.99" y="6.1"/>
</polygon>
<vertex x="57.25" y="13.51"/>
<vertex x="57.52" y="13.51"/>
<vertex x="57.8" y="13.51"/>
<vertex x="58.07" y="13.51"/>
<vertex x="58.35" y="13.51"/>
<vertex x="58.63" y="13.51"/>
<vertex x="58.9" y="13.51"/>
<vertex x="59.18" y="13.51"/>
<vertex x="59.45" y="13.51"/>
<vertex x="59.45" y="13.36"/>
<vertex x="59.45" y="13.21"/>
<vertex x="59.45" y="13.07"/>
<vertex x="59.45" y="12.92"/>
<vertex x="59.45" y="12.77"/>
<vertex x="59.45" y="12.62"/>
<vertex x="59.45" y="12.48"/>
<vertex x="59.45" y="12.33"/>
<vertex x="59.46" y="12.33"/>
<vertex x="59.47" y="12.33"/>
<vertex x="59.48" y="12.33"/>
<vertex x="59.72" y="12.67"/>
<vertex x="60" y="12.96"/>
<vertex x="60.3" y="13.2"/>
<vertex x="60.63" y="13.4"/>
<vertex x="60.97" y="13.55"/>
<vertex x="61.33" y="13.65"/>
<vertex x="61.7" y="13.72"/>
<vertex x="62.07" y="13.74"/>
<vertex x="62.91" y="13.67"/>
<vertex x="63.59" y="13.49"/>
<vertex x="64.13" y="13.19"/>
<vertex x="64.54" y="12.78"/>
<vertex x="64.83" y="12.27"/>
<vertex x="65.03" y="11.68"/>
<vertex x="65.13" y="11"/>
<vertex x="65.16" y="10.25"/>
<vertex x="65.16" y="9.6"/>
<vertex x="65.16" y="8.95"/>
<vertex x="65.16" y="8.3"/>
<vertex x="65.16" y="7.65"/>
<vertex x="65.16" y="7"/>
<vertex x="65.16" y="6.35"/>
<vertex x="65.16" y="5.7"/>
<vertex x="65.16" y="5.05"/>
<vertex x="64.87" y="5.05"/>
<vertex x="64.58" y="5.05"/>
<vertex x="64.29" y="5.05"/>
<vertex x="64" y="5.05"/>
<vertex x="63.71" y="5.05"/>
<vertex x="63.42" y="5.05"/>
<vertex x="63.13" y="5.05"/>
<vertex x="62.84" y="5.05"/>
<vertex x="62.84" y="5.64"/>
<vertex x="62.84" y="6.24"/>
<vertex x="62.84" y="6.84"/>
<vertex x="62.84" y="7.44"/>
<vertex x="62.84" y="8.03"/>
<vertex x="62.84" y="8.63"/>
<vertex x="62.84" y="9.23"/>
<vertex x="62.84" y="9.82"/>
<vertex x="62.82" y="10.31"/>
<vertex x="62.76" y="10.74"/>
<vertex x="62.65" y="11.09"/>
<vertex x="62.5" y="11.39"/>
<vertex x="62.3" y="11.61"/>
<vertex x="62.04" y="11.77"/>
<vertex x="61.72" y="11.87"/>
<vertex x="61.35" y="11.9"/>
<vertex x="60.91" y="11.87"/>
<vertex x="60.53" y="11.77"/>
<vertex x="60.22" y="11.59"/>
<vertex x="59.97" y="11.34"/>
<vertex x="59.78" y="11"/>
<vertex x="59.65" y="10.58"/>
<vertex x="59.57" y="10.08"/>
<vertex x="59.55" y="9.48"/>
<vertex x="59.55" y="8.93"/>
<vertex x="59.55" y="8.37"/>
<vertex x="59.55" y="7.82"/>
<vertex x="59.55" y="7.26"/>
<vertex x="59.55" y="6.71"/>
<vertex x="59.55" y="6.15"/>
<vertex x="59.55" y="5.6"/>
<vertex x="59.55" y="5.05"/>
<vertex x="59.26" y="5.05"/>
<vertex x="58.97" y="5.05"/>
<vertex x="58.68" y="5.05"/>
<vertex x="58.38" y="5.05"/>
<vertex x="58.09" y="5.05"/>
<vertex x="57.8" y="5.05"/>
<vertex x="57.51" y="5.05"/>
<vertex x="57.22" y="5.05"/>
<vertex x="57.22" y="6.1"/>
<vertex x="57.22" y="7.16"/>
<vertex x="57.22" y="8.22"/>
<vertex x="57.22" y="9.28"/>
<vertex x="57.22" y="10.33"/>
<vertex x="57.22" y="11.39"/>
<vertex x="57.22" y="12.45"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.7">
<vertex x="2.58" y="9.09"/>
<vertex x="2.62" y="8.69"/>
<vertex x="2.75" y="8.34"/>
<vertex x="2.96" y="8.06"/>
<vertex x="3.22" y="7.83"/>
<vertex x="3.54" y="7.65"/>
<vertex x="3.89" y="7.53"/>
<vertex x="4.27" y="7.46"/>
<vertex x="4.66" y="7.43"/>
<vertex x="4.96" y="7.45"/>
<vertex x="5.26" y="7.5"/>
<vertex x="5.56" y="7.58"/>
<vertex x="5.83" y="7.71"/>
<vertex x="6.07" y="7.88"/>
<vertex x="6.27" y="8.1"/>
<vertex x="6.39" y="8.37"/>
<vertex x="6.44" y="8.7"/>
<vertex x="6.38" y="8.98"/>
<vertex x="6.23" y="9.23"/>
<vertex x="5.97" y="9.44"/>
<vertex x="5.62" y="9.62"/>
<vertex x="5.18" y="9.78"/>
<vertex x="4.66" y="9.94"/>
<vertex x="4.05" y="10.08"/>
<vertex x="3.36" y="10.23"/>
<vertex x="2.77" y="10.37"/>
<vertex x="2.2" y="10.55"/>
<vertex x="1.67" y="10.76"/>
<vertex x="1.2" y="11.02"/>
<vertex x="0.8" y="11.35"/>
<vertex x="0.5" y="11.76"/>
<vertex x="0.3" y="12.26"/>
<vertex x="0.23" y="12.86"/>
<vertex x="0.33" y="13.72"/>
<vertex x="0.6" y="14.42"/>
<vertex x="1.03" y="14.97"/>
<vertex x="1.58" y="15.39"/>
<vertex x="2.23" y="15.69"/>
<vertex x="2.96" y="15.89"/>
<vertex x="3.73" y="16"/>
<vertex x="4.52" y="16.03"/>
<vertex x="5.32" y="16"/>
<vertex x="6.08" y="15.88"/>
<vertex x="6.79" y="15.68"/>
<vertex x="7.43" y="15.37"/>
<vertex x="7.97" y="14.95"/>
<vertex x="8.41" y="14.4"/>
<vertex x="8.72" y="13.72"/>
<vertex x="8.88" y="12.88"/>
<vertex x="8.56" y="12.88"/>
<vertex x="8.24" y="12.88"/>
<vertex x="7.91" y="12.88"/>
<vertex x="7.59" y="12.88"/>
<vertex x="7.27" y="12.88"/>
<vertex x="6.95" y="12.88"/>
<vertex x="6.63" y="12.88"/>
<vertex x="6.3" y="12.88"/>
<vertex x="6.24" y="13.24"/>
<vertex x="6.12" y="13.54"/>
<vertex x="5.94" y="13.77"/>
<vertex x="5.71" y="13.95"/>
<vertex x="5.44" y="14.07"/>
<vertex x="5.14" y="14.16"/>
<vertex x="4.81" y="14.21"/>
<vertex x="4.45" y="14.23"/>
<vertex x="4.21" y="14.23"/>
<vertex x="3.96" y="14.2"/>
<vertex x="3.7" y="14.16"/>
<vertex x="3.47" y="14.08"/>
<vertex x="3.26" y="13.97"/>
<vertex x="3.09" y="13.8"/>
<vertex x="2.98" y="13.59"/>
<vertex x="2.94" y="13.31"/>
<vertex x="3.01" y="12.99"/>
<vertex x="3.21" y="12.73"/>
<vertex x="3.51" y="12.52"/>
<vertex x="3.9" y="12.35"/>
<vertex x="4.37" y="12.21"/>
<vertex x="4.89" y="12.09"/>
<vertex x="5.44" y="11.97"/>
<vertex x="6.02" y="11.85"/>
<vertex x="6.6" y="11.7"/>
<vertex x="7.17" y="11.52"/>
<vertex x="7.7" y="11.3"/>
<vertex x="8.18" y="11.01"/>
<vertex x="8.57" y="10.66"/>
<vertex x="8.88" y="10.23"/>
<vertex x="9.08" y="9.71"/>
<vertex x="9.15" y="9.08"/>
<vertex x="9.04" y="8.19"/>
<vertex x="8.76" y="7.45"/>
<vertex x="8.31" y="6.85"/>
<vertex x="7.73" y="6.39"/>
<vertex x="7.05" y="6.04"/>
<vertex x="6.29" y="5.81"/>
<vertex x="5.47" y="5.68"/>
<vertex x="4.64" y="5.64"/>
<vertex x="3.79" y="5.68"/>
<vertex x="2.96" y="5.82"/>
<vertex x="2.19" y="6.05"/>
<vertex x="1.5" y="6.4"/>
<vertex x="0.91" y="6.87"/>
<vertex x="0.44" y="7.47"/>
<vertex x="0.13" y="8.22"/>
<vertex x="0" y="9.09"/>
<vertex x="0.32" y="9.09"/>
<vertex x="0.64" y="9.09"/>
<vertex x="0.97" y="9.09"/>
<vertex x="1.29" y="9.09"/>
<vertex x="1.61" y="9.09"/>
<vertex x="1.93" y="9.09"/>
<vertex x="2.25" y="9.09"/>
</polygon>
<vertex x="17.29" y="9.1"/>
<vertex x="17.45" y="9.63"/>
<vertex x="17.54" y="10.2"/>
<vertex x="17.56" y="10.79"/>
<vertex x="20.27" y="10.72"/>
<vertex x="20.21" y="9.74"/>
<vertex x="20.01" y="8.81"/>
<vertex x="19.67" y="7.94"/>
</polygon>
<vertex x="19.67" y="7.95"/>
<vertex x="19.2" y="7.18"/>
<vertex x="18.59" y="6.54"/>
<vertex x="17.84" y="6.04"/>
<vertex x="16.96" y="5.73"/>
<vertex x="16.84" y="5.7"/>
<vertex x="15.94" y="5.62"/>
<vertex x="15.49" y="5.64"/>
<vertex x="15.06" y="5.72"/>
<vertex x="14.65" y="5.83"/>
<vertex x="14.26" y="6"/>
<vertex x="13.89" y="6.21"/>
<vertex x="13.56" y="6.47"/>
<vertex x="13.25" y="6.77"/>
<vertex x="12.98" y="7.11"/>
<vertex x="12.97" y="7.11"/>
<vertex x="12.97" y="6.22"/>
<vertex x="12.97" y="5.33"/>
<vertex x="12.97" y="4.44"/>
<vertex x="12.97" y="3.55"/>
<vertex x="12.97" y="2.67"/>
<vertex x="12.97" y="1.78"/>
<vertex x="12.97" y="0.89"/>
<vertex x="12.97" y="0"/>
<vertex x="12.63" y="0.3"/>
<vertex x="12.29" y="0.6"/>
<vertex x="11.95" y="0.9"/>
<vertex x="11.61" y="1.21"/>
<vertex x="11.27" y="1.51"/>
<vertex x="10.93" y="1.81"/>
<vertex x="10.59" y="2.11"/>
<vertex x="10.25" y="2.41"/>
<vertex x="10.25" y="4.02"/>
<vertex x="10.25" y="5.63"/>
<vertex x="10.25" y="7.25"/>
<vertex x="10.25" y="8.86"/>
<vertex x="10.25" y="10.47"/>
<vertex x="10.25" y="12.08"/>
<vertex x="10.25" y="13.69"/>
<vertex x="10.25" y="15.3"/>
<vertex x="10.58" y="15.36"/>
<vertex x="10.9" y="15.41"/>
<vertex x="11.22" y="15.47"/>
<vertex x="11.54" y="15.53"/>
<vertex x="11.87" y="15.59"/>
<vertex x="12.19" y="15.64"/>
<vertex x="12.51" y="15.7"/>
<vertex x="12.83" y="15.76"/>
<vertex x="12.83" y="15.6"/>
<vertex x="12.83" y="15.44"/>
<vertex x="12.83" y="15.28"/>
<vertex x="12.83" y="15.13"/>
<vertex x="12.83" y="14.97"/>
<vertex x="12.83" y="14.81"/>
<vertex x="12.83" y="14.65"/>
<vertex x="12.83" y="14.5"/>
<vertex x="12.84" y="14.5"/>
<vertex x="12.85" y="14.5"/>
<vertex x="13.12" y="14.87"/>
<vertex x="13.42" y="15.19"/>
<vertex x="13.75" y="15.45"/>
<vertex x="14.11" y="15.66"/>
<vertex x="14.5" y="15.82"/>
<vertex x="14.91" y="15.93"/>
<vertex x="15.34" y="16"/>
<vertex x="15.79" y="16.02"/>
<vertex x="15.93" y="16.02"/>
<vertex x="16.87" y="15.91"/>
<vertex x="17.8" y="15.59"/>
<vertex x="18.57" y="15.08"/>
<vertex x="19.19" y="14.42"/>
<vertex x="19.67" y="13.63"/>
<vertex x="20.01" y="12.73"/>
<vertex x="20.04" y="12.61"/>
<vertex x="20.21" y="11.75"/>
<vertex x="20.23" y="11.62"/>
<vertex x="20.28" y="10.72"/>
<vertex x="17.53" y="11.38"/>
<vertex x="17.44" y="11.96"/>
<vertex x="17.27" y="12.49"/>
<vertex x="17.03" y="12.98"/>
<vertex x="16.71" y="13.39"/>
<vertex x="16.3" y="13.7"/>
<vertex x="15.8" y="13.91"/>
<vertex x="15.2" y="13.98"/>
<vertex x="14.59" y="13.91"/>
<vertex x="14.08" y="13.71"/>
<vertex x="13.67" y="13.39"/>
<vertex x="13.36" y="12.99"/>
<vertex x="13.12" y="12.5"/>
<vertex x="12.96" y="11.97"/>
<vertex x="12.88" y="11.39"/>
<vertex x="12.85" y="10.79"/>
<vertex x="12.88" y="10.2"/>
<vertex x="12.97" y="9.63"/>
<vertex x="13.13" y="9.1"/>
<vertex x="13.37" y="8.62"/>
<vertex x="13.69" y="8.23"/>
<vertex x="14.1" y="7.92"/>
<vertex x="14.61" y="7.73"/>
<vertex x="15.22" y="7.66"/>
<vertex x="15.83" y="7.73"/>
<vertex x="16.33" y="7.92"/>
<vertex x="16.74" y="8.23"/>
<vertex x="17.06" y="8.62"/>
</polygon>
<vertex x="24.4" y="11.55"/>
<vertex x="25.01" y="11.63"/>
<vertex x="25.61" y="11.7"/>
<vertex x="26.16" y="11.77"/>
<vertex x="26.49" y="10.31"/>
<vertex x="26.33" y="10.29"/>
<vertex x="26.17" y="10.26"/>
<vertex x="26.01" y="10.24"/>
<vertex x="25.85" y="10.22"/>
<vertex x="25.69" y="10.19"/>
<vertex x="25.53" y="10.17"/>
<vertex x="25.37" y="10.14"/>
<vertex x="25.21" y="10.11"/>
<vertex x="25.06" y="10.08"/>
<vertex x="24.91" y="10.04"/>
</polygon>
<vertex x="24.91" y="10.03"/>
<vertex x="24.76" y="9.99"/>
<vertex x="24.63" y="9.93"/>
<vertex x="24.49" y="9.87"/>
<vertex x="24.37" y="9.8"/>
<vertex x="24.25" y="9.73"/>
<vertex x="24.15" y="9.64"/>
<vertex x="24.05" y="9.54"/>
<vertex x="23.97" y="9.43"/>
<vertex x="23.9" y="9.31"/>
<vertex x="23.84" y="9.17"/>
<vertex x="23.8" y="9.03"/>
<vertex x="23.77" y="8.86"/>
<vertex x="23.77" y="8.68"/>
<vertex x="23.77" y="8.51"/>
<vertex x="23.8" y="8.35"/>
<vertex x="23.84" y="8.2"/>
<vertex x="23.9" y="8.07"/>
<vertex x="23.97" y="7.95"/>
<vertex x="24.06" y="7.85"/>
<vertex x="24.16" y="7.76"/>
<vertex x="24.27" y="7.68"/>
<vertex x="24.39" y="7.62"/>
<vertex x="24.52" y="7.56"/>
<vertex x="24.65" y="7.52"/>
<vertex x="24.8" y="7.48"/>
<vertex x="24.95" y="7.46"/>
<vertex x="25.1" y="7.43"/>
<vertex x="25.26" y="7.43"/>
<vertex x="25.43" y="7.43"/>
<vertex x="25.8" y="7.46"/>
<vertex x="26.13" y="7.51"/>
<vertex x="26.42" y="7.59"/>
<vertex x="26.66" y="7.71"/>
<vertex x="26.88" y="7.84"/>
<vertex x="27.05" y="7.99"/>
<vertex x="27.2" y="8.16"/>
<vertex x="27.32" y="8.34"/>
<vertex x="27.41" y="8.53"/>
<vertex x="27.49" y="8.72"/>
<vertex x="27.54" y="8.91"/>
<vertex x="27.58" y="9.1"/>
<vertex x="27.6" y="9.27"/>
<vertex x="27.62" y="9.44"/>
<vertex x="27.62" y="9.58"/>
<vertex x="27.62" y="9.71"/>
<vertex x="27.62" y="9.77"/>
<vertex x="27.62" y="9.83"/>
<vertex x="27.62" y="9.9"/>
<vertex x="27.62" y="9.96"/>
<vertex x="27.62" y="10.02"/>
<vertex x="27.62" y="10.09"/>
<vertex x="27.62" y="10.15"/>
<vertex x="27.62" y="10.21"/>
<vertex x="27.62" y="10.28"/>
<vertex x="27.62" y="10.34"/>
<vertex x="27.62" y="10.4"/>
<vertex x="27.62" y="10.47"/>
<vertex x="27.62" y="10.53"/>
<vertex x="27.62" y="10.59"/>
<vertex x="27.62" y="10.65"/>
<vertex x="27.62" y="10.72"/>
<vertex x="27.53" y="10.65"/>
<vertex x="27.43" y="10.58"/>
<vertex x="27.32" y="10.53"/>
<vertex x="27.19" y="10.48"/>
<vertex x="27.07" y="10.44"/>
<vertex x="26.93" y="10.4"/>
<vertex x="26.79" y="10.36"/>
<vertex x="26.64" y="10.33"/>
<vertex x="26.16" y="11.78"/>
<vertex x="26.65" y="11.9"/>
<vertex x="27.06" y="12.04"/>
<vertex x="27.37" y="12.23"/>
<vertex x="27.57" y="12.51"/>
<vertex x="27.62" y="12.87"/>
<vertex x="27.62" y="13.07"/>
<vertex x="27.59" y="13.26"/>
<vertex x="27.55" y="13.42"/>
<vertex x="27.49" y="13.56"/>
<vertex x="27.41" y="13.69"/>
<vertex x="27.32" y="13.8"/>
<vertex x="27.22" y="13.89"/>
<vertex x="27.11" y="13.97"/>
<vertex x="26.98" y="14.04"/>
<vertex x="26.84" y="14.09"/>
<vertex x="26.7" y="14.13"/>
<vertex x="26.55" y="14.16"/>
<vertex x="26.39" y="14.18"/>
<vertex x="26.22" y="14.2"/>
<vertex x="26.05" y="14.2"/>
<vertex x="25.87" y="14.2"/>
<vertex x="25.68" y="14.2"/>
<vertex x="25.49" y="14.18"/>
<vertex x="25.32" y="14.15"/>
<vertex x="25.16" y="14.12"/>
<vertex x="25.01" y="14.07"/>
<vertex x="24.86" y="14.01"/>
<vertex x="24.73" y="13.94"/>
<vertex x="24.61" y="13.86"/>
<vertex x="24.5" y="13.76"/>
<vertex x="24.41" y="13.65"/>
<vertex x="24.32" y="13.53"/>
<vertex x="24.25" y="13.39"/>
<vertex x="24.19" y="13.24"/>
<vertex x="24.14" y="13.08"/>
<vertex x="24.1" y="12.9"/>
<vertex x="24.07" y="12.71"/>
<vertex x="23.9" y="12.71"/>
<vertex x="23.74" y="12.71"/>
<vertex x="23.57" y="12.71"/>
<vertex x="23.4" y="12.71"/>
<vertex x="23.23" y="12.71"/>
<vertex x="23.06" y="12.71"/>
<vertex x="22.89" y="12.71"/>
<vertex x="22.72" y="12.71"/>
<vertex x="22.55" y="12.71"/>
<vertex x="22.38" y="12.71"/>
<vertex x="22.21" y="12.71"/>
<vertex x="22.04" y="12.71"/>
<vertex x="21.87" y="12.71"/>
<vertex x="21.7" y="12.71"/>
<vertex x="21.54" y="12.71"/>
<vertex x="21.37" y="12.71"/>
<vertex x="21.42" y="13.16"/>
<vertex x="21.52" y="13.57"/>
<vertex x="21.66" y="13.95"/>
<vertex x="21.84" y="14.29"/>
<vertex x="22.06" y="14.59"/>
<vertex x="22.32" y="14.86"/>
<vertex x="22.6" y="15.1"/>
<vertex x="22.91" y="15.31"/>
<vertex x="23.25" y="15.48"/>
<vertex x="23.61" y="15.63"/>
<vertex x="23.98" y="15.75"/>
<vertex x="24.37" y="15.85"/>
<vertex x="24.77" y="15.92"/>
<vertex x="25.18" y="15.97"/>
<vertex x="25.59" y="16"/>
<vertex x="26.01" y="16"/>
<vertex x="26.38" y="16"/>
<vertex x="26.76" y="15.98"/>
<vertex x="27.14" y="15.95"/>
<vertex x="27.51" y="15.9"/>
<vertex x="27.88" y="15.83"/>
<vertex x="28.24" y="15.74"/>
<vertex x="28.59" y="15.63"/>
<vertex x="28.91" y="15.49"/>
<vertex x="29.21" y="15.32"/>
<vertex x="29.49" y="15.13"/>
<vertex x="29.73" y="14.9"/>
<vertex x="29.94" y="14.64"/>
<vertex x="30.11" y="14.34"/>
<vertex x="30.24" y="14"/>
<vertex x="30.32" y="13.62"/>
<vertex x="30.34" y="13.2"/>
<vertex x="30.34" y="12.88"/>
<vertex x="30.34" y="12.56"/>
<vertex x="30.34" y="12.24"/>
<vertex x="30.34" y="11.92"/>
<vertex x="30.34" y="11.59"/>
<vertex x="30.34" y="11.27"/>
<vertex x="30.34" y="10.95"/>
<vertex x="30.34" y="10.63"/>
<vertex x="30.34" y="10.31"/>
<vertex x="30.34" y="9.99"/>
<vertex x="30.34" y="9.67"/>
<vertex x="30.34" y="9.35"/>
<vertex x="30.34" y="9.03"/>
<vertex x="30.34" y="8.71"/>
<vertex x="30.34" y="8.38"/>
<vertex x="30.34" y="8.06"/>
<vertex x="30.34" y="7.9"/>
<vertex x="30.35" y="7.73"/>
<vertex x="30.35" y="7.56"/>
<vertex x="30.35" y="7.4"/>
<vertex x="30.36" y="7.24"/>
<vertex x="30.37" y="7.08"/>
<vertex x="30.39" y="6.93"/>
<vertex x="30.42" y="6.78"/>
<vertex x="30.44" y="6.64"/>
<vertex x="30.47" y="6.5"/>
<vertex x="30.49" y="6.37"/>
<vertex x="30.52" y="6.25"/>
<vertex x="30.56" y="6.14"/>
<vertex x="30.6" y="6.04"/>
<vertex x="30.64" y="5.95"/>
<vertex x="30.68" y="5.87"/>
<vertex x="30.51" y="5.87"/>
<vertex x="30.34" y="5.87"/>
<vertex x="30.17" y="5.87"/>
<vertex x="29.99" y="5.87"/>
<vertex x="29.82" y="5.87"/>
<vertex x="29.65" y="5.87"/>
<vertex x="29.48" y="5.87"/>
<vertex x="29.31" y="5.87"/>
<vertex x="29.14" y="5.87"/>
<vertex x="28.96" y="5.87"/>
<vertex x="28.79" y="5.87"/>
<vertex x="28.62" y="5.87"/>
<vertex x="28.45" y="5.87"/>
<vertex x="28.28" y="5.87"/>
<vertex x="28.11" y="5.87"/>
<vertex x="27.93" y="5.87"/>
<vertex x="27.91" y="5.92"/>
<vertex x="27.89" y="5.98"/>
<vertex x="27.87" y="6.04"/>
<vertex x="27.85" y="6.1"/>
<vertex x="27.83" y="6.16"/>
<vertex x="27.82" y="6.22"/>
<vertex x="27.8" y="6.28"/>
<vertex x="27.79" y="6.34"/>
<vertex x="27.78" y="6.4"/>
<vertex x="27.77" y="6.46"/>
<vertex x="27.76" y="6.52"/>
<vertex x="27.76" y="6.58"/>
<vertex x="27.75" y="6.64"/>
<vertex x="27.75" y="6.7"/>
<vertex x="27.75" y="6.77"/>
<vertex x="27.74" y="6.83"/>
<vertex x="27.58" y="6.66"/>
<vertex x="27.41" y="6.52"/>
<vertex x="27.22" y="6.38"/>
<vertex x="27.04" y="6.26"/>
<vertex x="26.84" y="6.15"/>
<vertex x="26.64" y="6.05"/>
<vertex x="26.43" y="5.96"/>
<vertex x="26.22" y="5.88"/>
<vertex x="26" y="5.81"/>
<vertex x="25.79" y="5.75"/>
<vertex x="25.56" y="5.71"/>
<vertex x="25.34" y="5.67"/>
<vertex x="25.11" y="5.64"/>
<vertex x="24.88" y="5.62"/>
<vertex x="24.65" y="5.6"/>
<vertex x="24.42" y="5.6"/>
<vertex x="24.07" y="5.6"/>
<vertex x="23.74" y="5.63"/>
<vertex x="23.41" y="5.69"/>
<vertex x="23.1" y="5.76"/>
<vertex x="22.81" y="5.87"/>
<vertex x="22.53" y="5.99"/>
<vertex x="22.27" y="6.14"/>
<vertex x="22.03" y="6.31"/>
<vertex x="21.82" y="6.5"/>
<vertex x="21.63" y="6.72"/>
<vertex x="21.46" y="6.97"/>
<vertex x="21.32" y="7.23"/>
<vertex x="21.21" y="7.52"/>
<vertex x="21.13" y="7.84"/>
<vertex x="21.08" y="8.18"/>
<vertex x="21.06" y="8.55"/>
<vertex x="21.14" y="9.31"/>
<vertex x="21.36" y="9.93"/>
<vertex x="21.69" y="10.42"/>
<vertex x="22.12" y="10.8"/>
<vertex x="22.62" y="11.09"/>
<vertex x="23.18" y="11.3"/>
<vertex x="23.78" y="11.44"/>
</polygon>
<vertex x="31.87" y="15.3"/>
<vertex x="32.19" y="15.35"/>
<vertex x="32.52" y="15.41"/>
<vertex x="32.84" y="15.47"/>
<vertex x="33.16" y="15.53"/>
<vertex x="33.48" y="15.58"/>
<vertex x="33.8" y="15.64"/>
<vertex x="34.13" y="15.7"/>
<vertex x="34.45" y="15.76"/>
<vertex x="34.45" y="15.53"/>
<vertex x="34.45" y="15.3"/>
<vertex x="34.45" y="15.07"/>
<vertex x="34.45" y="14.84"/>
<vertex x="34.45" y="14.61"/>
<vertex x="34.45" y="14.38"/>
<vertex x="34.45" y="14.15"/>
<vertex x="34.45" y="13.92"/>
<vertex x="34.46" y="13.92"/>
<vertex x="34.47" y="13.92"/>
<vertex x="34.69" y="14.37"/>
<vertex x="34.98" y="14.77"/>
<vertex x="35.33" y="15.13"/>
<vertex x="35.73" y="15.44"/>
<vertex x="36.16" y="15.68"/>
<vertex x="36.62" y="15.87"/>
<vertex x="37.11" y="15.98"/>
<vertex x="37.62" y="16.02"/>
<vertex x="37.69" y="16.02"/>
<vertex x="37.77" y="16.02"/>
<vertex x="37.85" y="16.02"/>
<vertex x="37.92" y="16.02"/>
<vertex x="37.99" y="16"/>
<vertex x="38.07" y="15.98"/>
<vertex x="38.14" y="15.96"/>
<vertex x="38.21" y="15.94"/>
<vertex x="38.21" y="15.62"/>
<vertex x="38.21" y="15.31"/>
<vertex x="38.21" y="14.99"/>
<vertex x="38.21" y="14.68"/>
<vertex x="38.21" y="14.36"/>
<vertex x="38.21" y="14.05"/>
<vertex x="38.21" y="13.73"/>
<vertex x="38.21" y="13.42"/>
<vertex x="38.11" y="13.44"/>
<vertex x="38" y="13.46"/>
<vertex x="37.88" y="13.48"/>
<vertex x="37.75" y="13.5"/>
<vertex x="37.62" y="13.5"/>
<vertex x="37.49" y="13.5"/>
<vertex x="37.36" y="13.5"/>
<vertex x="37.24" y="13.5"/>
<vertex x="36.55" y="13.44"/>
<vertex x="35.97" y="13.25"/>
<vertex x="35.51" y="12.96"/>
<vertex x="35.15" y="12.58"/>
<vertex x="34.88" y="12.11"/>
<vertex x="34.7" y="11.57"/>
<vertex x="34.59" y="10.97"/>
<vertex x="34.56" y="10.33"/>
<vertex x="34.56" y="9.78"/>
<vertex x="34.56" y="9.22"/>
<vertex x="34.56" y="8.66"/>
<vertex x="34.56" y="8.11"/>
<vertex x="34.56" y="7.55"/>
<vertex x="34.56" y="7"/>
<vertex x="34.56" y="6.44"/>
<vertex x="34.56" y="5.88"/>
<vertex x="34.22" y="5.88"/>
<vertex x="33.88" y="5.88"/>
<vertex x="33.54" y="5.88"/>
<vertex x="33.2" y="5.88"/>
<vertex x="32.87" y="5.88"/>
<vertex x="32.53" y="5.88"/>
<vertex x="32.19" y="5.88"/>
<vertex x="31.85" y="5.88"/>
<vertex x="31.85" y="7.06"/>
<vertex x="31.85" y="8.24"/>
<vertex x="31.85" y="9.41"/>
<vertex x="31.85" y="10.59"/>
<vertex x="31.85" y="11.77"/>
<vertex x="31.85" y="12.94"/>
<vertex x="31.85" y="14.12"/>
</polygon>
<vertex x="39.28" y="18.03"/>
<vertex x="41.99" y="19.52"/>
<vertex x="41.99" y="12.2"/>
<vertex x="45.41" y="15.76"/>
<vertex x="48.62" y="15.76"/>
<vertex x="44.89" y="12.13"/>
<vertex x="49.03" y="5.89"/>
<vertex x="45.75" y="5.89"/>
<vertex x="43.04" y="10.3"/>
<vertex x="41.99" y="9.28"/>
<vertex x="41.99" y="5.89"/>
<vertex x="39.28" y="5.89"/>
</polygon>
<vertex x="50.68" y="13.94"/>
<vertex x="50.35" y="13.94"/>
<vertex x="50.02" y="13.94"/>
<vertex x="49.68" y="13.94"/>
<vertex x="49.35" y="13.94"/>
<vertex x="49.01" y="13.94"/>
<vertex x="48.68" y="13.94"/>
<vertex x="48.34" y="13.94"/>
<vertex x="48.01" y="13.94"/>
<vertex x="48.24" y="14.17"/>
<vertex x="48.47" y="14.4"/>
<vertex x="48.7" y="14.62"/>
<vertex x="48.93" y="14.85"/>
<vertex x="49.17" y="15.08"/>
<vertex x="49.4" y="15.3"/>
<vertex x="49.63" y="15.53"/>
<vertex x="49.86" y="15.76"/>
<vertex x="49.96" y="15.76"/>
<vertex x="50.06" y="15.76"/>
<vertex x="50.17" y="15.76"/>
<vertex x="50.27" y="15.76"/>
<vertex x="50.37" y="15.76"/>
<vertex x="50.48" y="15.76"/>
<vertex x="50.58" y="15.76"/>
<vertex x="50.68" y="15.76"/>
<vertex x="50.68" y="15.85"/>
<vertex x="50.68" y="15.95"/>
<vertex x="50.68" y="16.04"/>
<vertex x="50.68" y="16.14"/>
<vertex x="50.68" y="16.23"/>
<vertex x="50.68" y="16.33"/>
<vertex x="50.68" y="16.42"/>
<vertex x="50.68" y="16.51"/>
<vertex x="50.74" y="17.15"/>
<vertex x="50.89" y="17.73"/>
<vertex x="51.15" y="18.24"/>
<vertex x="51.51" y="18.67"/>
<vertex x="51.97" y="19.03"/>
<vertex x="52.54" y="19.29"/>
<vertex x="53.21" y="19.46"/>
<vertex x="53.99" y="19.52"/>
<vertex x="54.17" y="19.52"/>
<vertex x="54.35" y="19.52"/>
<vertex x="54.53" y="19.52"/>
<vertex x="54.71" y="19.5"/>
<vertex x="54.89" y="19.48"/>
<vertex x="55.07" y="19.46"/>
<vertex x="55.25" y="19.46"/>
<vertex x="55.42" y="19.46"/>
<vertex x="55.42" y="19.2"/>
<vertex x="55.42" y="18.95"/>
<vertex x="55.42" y="18.7"/>
<vertex x="55.42" y="18.44"/>
<vertex x="55.42" y="18.19"/>
<vertex x="55.42" y="17.94"/>
<vertex x="55.42" y="17.69"/>
<vertex x="55.42" y="17.43"/>
<vertex x="55.3" y="17.45"/>
<vertex x="55.17" y="17.47"/>
<vertex x="55.05" y="17.47"/>
<vertex x="54.92" y="17.47"/>
<vertex x="54.8" y="17.47"/>
<vertex x="54.67" y="17.47"/>
<vertex x="54.55" y="17.47"/>
<vertex x="54.43" y="17.47"/>
<vertex x="54.17" y="17.45"/>
<vertex x="53.95" y="17.41"/>
<vertex x="53.77" y="17.33"/>
<vertex x="53.63" y="17.21"/>
<vertex x="53.52" y="17.06"/>
<vertex x="53.45" y="16.86"/>
<vertex x="53.41" y="16.63"/>
<vertex x="53.39" y="16.34"/>
<vertex x="53.39" y="16.27"/>
<vertex x="53.39" y="16.19"/>
<vertex x="53.39" y="16.12"/>
<vertex x="53.39" y="16.05"/>
<vertex x="53.39" y="15.97"/>
<vertex x="53.39" y="15.9"/>
<vertex x="53.39" y="15.83"/>
<vertex x="53.39" y="15.75"/>
<vertex x="53.63" y="15.75"/>
<vertex x="53.86" y="15.75"/>
<vertex x="54.1" y="15.75"/>
<vertex x="54.33" y="15.75"/>
<vertex x="54.56" y="15.75"/>
<vertex x="54.8" y="15.75"/>
<vertex x="55.03" y="15.75"/>
<vertex x="55.26" y="15.75"/>
<vertex x="55.26" y="15.53"/>
<vertex x="55.26" y="15.3"/>
<vertex x="55.26" y="15.07"/>
<vertex x="55.26" y="14.85"/>
<vertex x="55.26" y="14.62"/>
<vertex x="55.26" y="14.39"/>
<vertex x="55.26" y="14.17"/>
<vertex x="55.26" y="13.94"/>
<vertex x="55.03" y="13.94"/>
<vertex x="54.8" y="13.94"/>
<vertex x="54.56" y="13.94"/>
<vertex x="54.33" y="13.94"/>
<vertex x="54.1" y="13.94"/>
<vertex x="53.86" y="13.94"/>
<vertex x="53.63" y="13.94"/>
<vertex x="53.39" y="13.94"/>
<vertex x="53.39" y="12.93"/>
<vertex x="53.39" y="11.92"/>
<vertex x="53.39" y="10.92"/>
<vertex x="53.39" y="9.91"/>
<vertex x="53.39" y="8.9"/>
<vertex x="53.39" y="7.89"/>
<vertex x="53.39" y="6.89"/>
<vertex x="53.39" y="5.88"/>
<vertex x="53.05" y="5.88"/>
<vertex x="52.72" y="5.88"/>
<vertex x="52.38" y="5.88"/>
<vertex x="52.04" y="5.88"/>
<vertex x="51.7" y="5.88"/>
<vertex x="51.36" y="5.88"/>
<vertex x="51.02" y="5.88"/>
<vertex x="50.68" y="5.88"/>
<vertex x="50.68" y="6.89"/>
<vertex x="50.68" y="7.89"/>
<vertex x="50.68" y="8.9"/>
<vertex x="50.68" y="9.91"/>
<vertex x="50.68" y="10.92"/>
<vertex x="50.68" y="11.92"/>
<vertex x="50.68" y="12.93"/>
</polygon>
<vertex x="65.29" y="5.88"/>
<vertex x="64.97" y="5.88"/>
<vertex x="64.64" y="5.88"/>
<vertex x="64.32" y="5.88"/>
<vertex x="64" y="5.88"/>
<vertex x="63.68" y="5.88"/>
<vertex x="63.36" y="5.88"/>
<vertex x="63.03" y="5.88"/>
<vertex x="62.71" y="5.88"/>
<vertex x="62.71" y="6.06"/>
<vertex x="62.71" y="6.23"/>
<vertex x="62.71" y="6.4"/>
<vertex x="62.71" y="6.57"/>
<vertex x="62.71" y="6.74"/>
<vertex x="62.71" y="6.91"/>
<vertex x="62.71" y="7.09"/>
<vertex x="62.71" y="7.26"/>
<vertex x="62.7" y="7.26"/>
<vertex x="62.69" y="7.26"/>
<vertex x="62.68" y="7.26"/>
<vertex x="62.4" y="6.86"/>
<vertex x="62.08" y="6.53"/>
<vertex x="61.73" y="6.24"/>
<vertex x="61.34" y="6.01"/>
<vertex x="60.94" y="5.84"/>
<vertex x="60.52" y="5.71"/>
<vertex x="60.09" y="5.64"/>
<vertex x="59.66" y="5.62"/>
<vertex x="58.68" y="5.69"/>
<vertex x="57.88" y="5.91"/>
<vertex x="57.25" y="6.26"/>
<vertex x="56.78" y="6.73"/>
<vertex x="56.43" y="7.32"/>
<vertex x="56.21" y="8.02"/>
<vertex x="56.09" y="8.81"/>
<vertex x="56.05" y="9.68"/>
<vertex x="56.05" y="10.44"/>
<vertex x="56.05" y="11.2"/>
<vertex x="56.05" y="11.96"/>
<vertex x="56.05" y="12.72"/>
<vertex x="56.05" y="13.48"/>
<vertex x="56.05" y="14.24"/>
<vertex x="56.05" y="15"/>
<vertex x="56.05" y="15.76"/>
<vertex x="56.39" y="15.76"/>
<vertex x="56.73" y="15.76"/>
<vertex x="57.07" y="15.76"/>
<vertex x="57.41" y="15.76"/>
<vertex x="57.75" y="15.76"/>
<vertex x="58.09" y="15.76"/>
<vertex x="58.43" y="15.76"/>
<vertex x="58.77" y="15.76"/>
<vertex x="58.77" y="15.06"/>
<vertex x="58.77" y="14.36"/>
<vertex x="58.77" y="13.66"/>
<vertex x="58.77" y="12.97"/>
<vertex x="58.77" y="12.27"/>
<vertex x="58.77" y="11.57"/>
<vertex x="58.77" y="10.88"/>
<vertex x="58.77" y="10.18"/>
<vertex x="58.79" y="9.61"/>
<vertex x="58.86" y="9.12"/>
<vertex x="58.98" y="8.7"/>
<vertex x="59.16" y="8.36"/>
<vertex x="59.39" y="8.09"/>
<vertex x="59.69" y="7.9"/>
<vertex x="60.06" y="7.79"/>
<vertex x="60.5" y="7.75"/>
<vertex x="61.02" y="7.79"/>
<vertex x="61.45" y="7.91"/>
<vertex x="61.82" y="8.12"/>
<vertex x="62.11" y="8.42"/>
<vertex x="62.33" y="8.81"/>
<vertex x="62.48" y="9.29"/>
<vertex x="62.58" y="9.88"/>
<vertex x="62.61" y="10.58"/>
<vertex x="62.61" y="11.23"/>
<vertex x="62.61" y="11.87"/>
<vertex x="62.61" y="12.52"/>
<vertex x="62.61" y="13.17"/>
<vertex x="62.61" y="13.81"/>
<vertex x="62.61" y="14.46"/>
<vertex x="62.61" y="15.11"/>
<vertex x="62.61" y="15.76"/>
<vertex x="62.94" y="15.76"/>
<vertex x="63.28" y="15.76"/>
<vertex x="63.62" y="15.76"/>
<vertex x="63.96" y="15.76"/>
<vertex x="64.3" y="15.76"/>
<vertex x="64.64" y="15.76"/>
<vertex x="64.98" y="15.76"/>
<vertex x="65.32" y="15.76"/>
<vertex x="65.32" y="14.52"/>
<vertex x="65.32" y="13.29"/>
<vertex x="65.32" y="12.05"/>
<vertex x="65.32" y="10.82"/>
<vertex x="65.32" y="9.59"/>
<vertex x="65.32" y="8.35"/>
<vertex x="65.32" y="7.12"/>
</polygon>
<vertex x="66.79" y="15.76"/>
<vertex x="67.11" y="15.76"/>
<vertex x="67.43" y="15.76"/>
<vertex x="67.75" y="15.76"/>
<vertex x="68.08" y="15.76"/>
<vertex x="68.4" y="15.76"/>
<vertex x="68.72" y="15.76"/>
<vertex x="69.04" y="15.76"/>
<vertex x="69.36" y="15.76"/>
<vertex x="69.36" y="15.59"/>
<vertex x="69.36" y="15.41"/>
<vertex x="69.36" y="15.24"/>
<vertex x="69.36" y="15.07"/>
<vertex x="69.36" y="14.9"/>
<vertex x="69.36" y="14.73"/>
<vertex x="69.36" y="14.56"/>
<vertex x="69.36" y="14.38"/>
<vertex x="69.37" y="14.38"/>
<vertex x="69.38" y="14.38"/>
<vertex x="69.39" y="14.38"/>
<vertex x="69.4" y="14.38"/>
<vertex x="69.68" y="14.78"/>
<vertex x="70" y="15.12"/>
<vertex x="70.35" y="15.4"/>
<vertex x="70.73" y="15.63"/>
<vertex x="71.13" y="15.8"/>
<vertex x="71.55" y="15.93"/>
<vertex x="71.98" y="16"/>
<vertex x="72.41" y="16.03"/>
<vertex x="73.4" y="15.95"/>
<vertex x="74.19" y="15.73"/>
<vertex x="74.82" y="15.38"/>
<vertex x="75.3" y="14.91"/>
<vertex x="75.64" y="14.32"/>
<vertex x="75.86" y="13.63"/>
<vertex x="75.98" y="12.84"/>
<vertex x="76.02" y="11.96"/>
<vertex x="76.02" y="11.2"/>
<vertex x="76.02" y="10.44"/>
<vertex x="76.02" y="9.68"/>
<vertex x="76.02" y="8.92"/>
<vertex x="76.02" y="8.16"/>
<vertex x="76.02" y="7.4"/>
<vertex x="76.02" y="6.65"/>
<vertex x="76.02" y="5.89"/>
<vertex x="75.68" y="5.89"/>
<vertex x="75.34" y="5.89"/>
<vertex x="75" y="5.89"/>
<vertex x="74.67" y="5.89"/>
<vertex x="74.33" y="5.89"/>
<vertex x="73.99" y="5.89"/>
<vertex x="73.65" y="5.89"/>
<vertex x="73.31" y="5.89"/>
<vertex x="73.31" y="6.58"/>
<vertex x="73.31" y="7.28"/>
<vertex x="73.31" y="7.98"/>
<vertex x="73.31" y="8.67"/>
<vertex x="73.31" y="9.37"/>
<vertex x="73.31" y="10.07"/>
<vertex x="73.31" y="10.76"/>
<vertex x="73.31" y="11.46"/>
<vertex x="73.29" y="12.03"/>
<vertex x="73.22" y="12.53"/>
<vertex x="73.09" y="12.94"/>
<vertex x="72.92" y="13.28"/>
<vertex x="72.68" y="13.55"/>
<vertex x="72.38" y="13.74"/>
<vertex x="72.01" y="13.85"/>
<vertex x="71.57" y="13.89"/>
<vertex x="71.06" y="13.85"/>
<vertex x="70.62" y="13.73"/>
<vertex x="70.26" y="13.52"/>
<vertex x="69.97" y="13.23"/>
<vertex x="69.75" y="12.84"/>
<vertex x="69.59" y="12.35"/>
<vertex x="69.5" y="11.76"/>
<vertex x="69.47" y="11.06"/>
<vertex x="69.47" y="10.41"/>
<vertex x="69.47" y="9.77"/>
<vertex x="69.47" y="9.12"/>
<vertex x="69.47" y="8.47"/>
<vertex x="69.47" y="7.83"/>
<vertex x="69.47" y="7.18"/>
<vertex x="69.47" y="6.53"/>
<vertex x="69.47" y="5.89"/>
<vertex x="69.13" y="5.89"/>
<vertex x="68.79" y="5.89"/>
<vertex x="68.45" y="5.89"/>
<vertex x="68.12" y="5.89"/>
<vertex x="67.78" y="5.89"/>
<vertex x="67.44" y="5.89"/>
<vertex x="67.1" y="5.89"/>
<vertex x="66.76" y="5.89"/>
<vertex x="66.76" y="7.12"/>
<vertex x="66.76" y="8.35"/>
<vertex x="66.76" y="9.59"/>
<vertex x="66.76" y="10.82"/>
<vertex x="66.76" y="12.06"/>
<vertex x="66.76" y="13.29"/>
<vertex x="66.76" y="14.52"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.8">
<vertex x="3.45" y="10.39"/>
<vertex x="3.5" y="9.93"/>
<vertex x="3.65" y="9.53"/>
<vertex x="3.88" y="9.21"/>
<vertex x="4.19" y="8.94"/>
<vertex x="4.55" y="8.74"/>
<vertex x="4.95" y="8.6"/>
<vertex x="5.38" y="8.52"/>
<vertex x="5.83" y="8.49"/>
<vertex x="6.16" y="8.52"/>
<vertex x="6.51" y="8.57"/>
<vertex x="6.85" y="8.67"/>
<vertex x="7.17" y="8.81"/>
<vertex x="7.44" y="9.01"/>
<vertex x="7.66" y="9.25"/>
<vertex x="7.8" y="9.57"/>
<vertex x="7.86" y="9.94"/>
<vertex x="7.79" y="10.27"/>
<vertex x="7.62" y="10.55"/>
<vertex x="7.32" y="10.78"/>
<vertex x="6.93" y="10.99"/>
<vertex x="6.42" y="11.18"/>
<vertex x="5.82" y="11.36"/>
<vertex x="5.13" y="11.52"/>
<vertex x="4.34" y="11.69"/>
<vertex x="3.67" y="11.85"/>
<vertex x="3.02" y="12.05"/>
<vertex x="2.41" y="12.29"/>
<vertex x="1.87" y="12.6"/>
<vertex x="1.42" y="12.97"/>
<vertex x="1.07" y="13.44"/>
<vertex x="0.84" y="14.01"/>
<vertex x="0.76" y="14.7"/>
<vertex x="0.87" y="15.68"/>
<vertex x="1.19" y="16.48"/>
<vertex x="1.68" y="17.11"/>
<vertex x="2.31" y="17.59"/>
<vertex x="3.05" y="17.94"/>
<vertex x="3.88" y="18.16"/>
<vertex x="4.76" y="18.29"/>
<vertex x="5.67" y="18.32"/>
<vertex x="6.58" y="18.28"/>
<vertex x="7.45" y="18.15"/>
<vertex x="8.26" y="17.92"/>
<vertex x="8.99" y="17.56"/>
<vertex x="9.61" y="17.08"/>
<vertex x="10.11" y="16.46"/>
<vertex x="10.47" y="15.68"/>
<vertex x="10.65" y="14.72"/>
<vertex x="10.28" y="14.72"/>
<vertex x="9.91" y="14.72"/>
<vertex x="9.54" y="14.72"/>
<vertex x="9.18" y="14.72"/>
<vertex x="8.81" y="14.72"/>
<vertex x="8.44" y="14.72"/>
<vertex x="8.07" y="14.72"/>
<vertex x="7.7" y="14.72"/>
<vertex x="7.63" y="15.14"/>
<vertex x="7.49" y="15.47"/>
<vertex x="7.29" y="15.74"/>
<vertex x="7.03" y="15.94"/>
<vertex x="6.72" y="16.09"/>
<vertex x="6.37" y="16.18"/>
<vertex x="5.99" y="16.24"/>
<vertex x="5.59" y="16.26"/>
<vertex x="5.31" y="16.26"/>
<vertex x="5.02" y="16.23"/>
<vertex x="4.73" y="16.18"/>
<vertex x="4.46" y="16.09"/>
<vertex x="4.22" y="15.96"/>
<vertex x="4.03" y="15.78"/>
<vertex x="3.91" y="15.53"/>
<vertex x="3.86" y="15.22"/>
<vertex x="3.94" y="14.84"/>
<vertex x="4.16" y="14.54"/>
<vertex x="4.51" y="14.31"/>
<vertex x="4.96" y="14.12"/>
<vertex x="5.5" y="13.96"/>
<vertex x="6.09" y="13.82"/>
<vertex x="6.72" y="13.68"/>
<vertex x="7.38" y="13.54"/>
<vertex x="8.05" y="13.37"/>
<vertex x="8.7" y="13.17"/>
<vertex x="9.3" y="12.91"/>
<vertex x="9.84" y="12.59"/>
<vertex x="10.3" y="12.19"/>
<vertex x="10.65" y="11.7"/>
<vertex x="10.87" y="11.1"/>
<vertex x="10.95" y="10.38"/>
<vertex x="10.95" y="10.24"/>
<vertex x="10.84" y="9.35"/>
<vertex x="10.51" y="8.51"/>
<vertex x="10" y="7.83"/>
<vertex x="9.33" y="7.3"/>
<vertex x="8.55" y="6.91"/>
<vertex x="7.68" y="6.64"/>
<vertex x="6.76" y="6.5"/>
<vertex x="5.8" y="6.45"/>
<vertex x="4.83" y="6.5"/>
<vertex x="3.88" y="6.65"/>
<vertex x="3" y="6.91"/>
<vertex x="2.21" y="7.31"/>
<vertex x="1.54" y="7.85"/>
<vertex x="1.01" y="8.54"/>
<vertex x="0.65" y="9.39"/>
<vertex x="0.62" y="9.5"/>
<vertex x="0.5" y="10.39"/>
<vertex x="0.87" y="10.39"/>
<vertex x="1.24" y="10.39"/>
<vertex x="1.6" y="10.39"/>
<vertex x="1.97" y="10.39"/>
<vertex x="2.34" y="10.39"/>
<vertex x="2.71" y="10.39"/>
<vertex x="3.08" y="10.39"/>
</polygon>
<vertex x="20.26" y="10.4"/>
<vertex x="20.44" y="11"/>
<vertex x="20.54" y="11.65"/>
<vertex x="20.57" y="12.33"/>
<vertex x="23.67" y="12.25"/>
<vertex x="23.67" y="12.11"/>
<vertex x="23.6" y="11.13"/>
<vertex x="23.57" y="10.99"/>
<vertex x="23.36" y="10.07"/>
<vertex x="23.32" y="9.94"/>
<vertex x="22.98" y="9.08"/>
</polygon>
<vertex x="22.92" y="8.96"/>
<vertex x="22.44" y="8.2"/>
<vertex x="22.36" y="8.1"/>
<vertex x="21.74" y="7.47"/>
<vertex x="21.65" y="7.39"/>
<vertex x="20.89" y="6.91"/>
<vertex x="20.77" y="6.85"/>
<vertex x="19.88" y="6.55"/>
<vertex x="19.75" y="6.52"/>
<vertex x="18.72" y="6.42"/>
<vertex x="18.21" y="6.45"/>
<vertex x="17.72" y="6.53"/>
<vertex x="17.24" y="6.67"/>
<vertex x="16.8" y="6.86"/>
<vertex x="16.38" y="7.1"/>
<vertex x="15.99" y="7.39"/>
<vertex x="15.64" y="7.73"/>
<vertex x="15.34" y="8.12"/>
<vertex x="15.33" y="8.12"/>
<vertex x="15.32" y="8.12"/>
<vertex x="15.32" y="7.11"/>
<vertex x="15.32" y="6.09"/>
<vertex x="15.32" y="5.08"/>
<vertex x="15.32" y="4.06"/>
<vertex x="15.32" y="3.05"/>
<vertex x="15.32" y="2.03"/>
<vertex x="15.32" y="1.02"/>
<vertex x="15.32" y="0"/>
<vertex x="14.93" y="0.34"/>
<vertex x="14.54" y="0.69"/>
<vertex x="14.16" y="1.03"/>
<vertex x="13.77" y="1.38"/>
<vertex x="13.38" y="1.72"/>
<vertex x="12.99" y="2.07"/>
<vertex x="12.61" y="2.41"/>
<vertex x="12.22" y="2.76"/>
<vertex x="12.22" y="4.6"/>
<vertex x="12.22" y="6.44"/>
<vertex x="12.22" y="8.28"/>
<vertex x="12.22" y="10.12"/>
<vertex x="12.22" y="11.96"/>
<vertex x="12.22" y="13.8"/>
<vertex x="12.22" y="15.65"/>
<vertex x="12.22" y="17.49"/>
<vertex x="12.59" y="17.55"/>
<vertex x="12.96" y="17.62"/>
<vertex x="13.32" y="17.68"/>
<vertex x="13.69" y="17.75"/>
<vertex x="14.06" y="17.81"/>
<vertex x="14.43" y="17.88"/>
<vertex x="14.8" y="17.94"/>
<vertex x="15.17" y="18.01"/>
<vertex x="15.17" y="17.83"/>
<vertex x="15.17" y="17.65"/>
<vertex x="15.17" y="17.47"/>
<vertex x="15.17" y="17.29"/>
<vertex x="15.17" y="17.11"/>
<vertex x="15.17" y="16.93"/>
<vertex x="15.17" y="16.75"/>
<vertex x="15.17" y="16.57"/>
<vertex x="15.18" y="16.57"/>
<vertex x="15.19" y="16.57"/>
<vertex x="15.49" y="16.99"/>
<vertex x="15.84" y="17.35"/>
<vertex x="16.22" y="17.66"/>
<vertex x="16.63" y="17.9"/>
<vertex x="17.07" y="18.08"/>
<vertex x="17.54" y="18.21"/>
<vertex x="18.03" y="18.29"/>
<vertex x="18.55" y="18.31"/>
<vertex x="18.71" y="18.31"/>
<vertex x="19.78" y="18.18"/>
<vertex x="19.92" y="18.15"/>
<vertex x="20.84" y="17.82"/>
<vertex x="20.96" y="17.75"/>
<vertex x="21.72" y="17.24"/>
<vertex x="21.82" y="17.15"/>
<vertex x="22.44" y="16.48"/>
<vertex x="22.51" y="16.38"/>
<vertex x="22.98" y="15.58"/>
<vertex x="23.04" y="15.45"/>
<vertex x="23.37" y="14.55"/>
<vertex x="23.41" y="14.41"/>
<vertex x="23.6" y="13.43"/>
<vertex x="23.62" y="13.28"/>
<vertex x="20.54" y="13.01"/>
<vertex x="20.43" y="13.66"/>
<vertex x="20.24" y="14.28"/>
<vertex x="19.96" y="14.83"/>
<vertex x="19.6" y="15.3"/>
<vertex x="19.13" y="15.66"/>
<vertex x="18.55" y="15.89"/>
<vertex x="17.87" y="15.98"/>
<vertex x="17.17" y="15.89"/>
<vertex x="16.59" y="15.66"/>
<vertex x="16.13" y="15.31"/>
<vertex x="15.76" y="14.84"/>
<vertex x="15.5" y="14.29"/>
<vertex x="15.32" y="13.67"/>
<vertex x="15.21" y="13.01"/>
<vertex x="15.18" y="12.33"/>
<vertex x="15.22" y="11.65"/>
<vertex x="15.32" y="11"/>
<vertex x="15.51" y="10.4"/>
<vertex x="15.78" y="9.86"/>
<vertex x="16.15" y="9.4"/>
<vertex x="16.62" y="9.06"/>
<vertex x="17.2" y="8.83"/>
<vertex x="17.89" y="8.75"/>
<vertex x="18.59" y="8.83"/>
<vertex x="19.17" y="9.06"/>
<vertex x="19.63" y="9.4"/>
<vertex x="19.99" y="9.86"/>
</polygon>
<vertex x="28.39" y="13.2"/>
<vertex x="29.09" y="13.29"/>
<vertex x="29.77" y="13.37"/>
<vertex x="30.4" y="13.45"/>
<vertex x="30.77" y="11.78"/>
<vertex x="30.59" y="11.76"/>
<vertex x="30.41" y="11.73"/>
<vertex x="30.23" y="11.7"/>
<vertex x="30.04" y="11.68"/>
<vertex x="29.86" y="11.65"/>
<vertex x="29.68" y="11.62"/>
<vertex x="29.49" y="11.59"/>
<vertex x="29.32" y="11.56"/>
<vertex x="29.14" y="11.52"/>
<vertex x="28.97" y="11.47"/>
</polygon>
<vertex x="28.97" y="11.46"/>
<vertex x="28.8" y="11.41"/>
<vertex x="28.64" y="11.35"/>
<vertex x="28.49" y="11.28"/>
<vertex x="28.35" y="11.2"/>
<vertex x="28.22" y="11.12"/>
<vertex x="28.1" y="11.02"/>
<vertex x="27.99" y="10.9"/>
<vertex x="27.89" y="10.78"/>
<vertex x="27.81" y="10.64"/>
<vertex x="27.75" y="10.48"/>
<vertex x="27.7" y="10.32"/>
<vertex x="27.67" y="10.13"/>
<vertex x="27.66" y="9.93"/>
<vertex x="27.67" y="9.72"/>
<vertex x="27.7" y="9.54"/>
<vertex x="27.75" y="9.37"/>
<vertex x="27.82" y="9.22"/>
<vertex x="27.9" y="9.09"/>
<vertex x="28" y="8.97"/>
<vertex x="28.11" y="8.87"/>
<vertex x="28.23" y="8.78"/>
<vertex x="28.37" y="8.71"/>
<vertex x="28.52" y="8.64"/>
<vertex x="28.68" y="8.59"/>
<vertex x="28.84" y="8.55"/>
<vertex x="29.01" y="8.52"/>
<vertex x="29.19" y="8.5"/>
<vertex x="29.37" y="8.5"/>
<vertex x="29.56" y="8.5"/>
<vertex x="29.99" y="8.52"/>
<vertex x="30.36" y="8.58"/>
<vertex x="30.69" y="8.68"/>
<vertex x="30.97" y="8.81"/>
<vertex x="31.22" y="8.96"/>
<vertex x="31.42" y="9.14"/>
<vertex x="31.59" y="9.33"/>
<vertex x="31.72" y="9.53"/>
<vertex x="31.83" y="9.75"/>
<vertex x="31.91" y="9.97"/>
<vertex x="31.98" y="10.18"/>
<vertex x="32.02" y="10.4"/>
<vertex x="32.05" y="10.6"/>
<vertex x="32.06" y="10.78"/>
<vertex x="32.07" y="10.95"/>
<vertex x="32.07" y="11.09"/>
<vertex x="32.07" y="11.17"/>
<vertex x="32.07" y="11.24"/>
<vertex x="32.07" y="11.31"/>
<vertex x="32.07" y="11.38"/>
<vertex x="32.07" y="11.46"/>
<vertex x="32.07" y="11.53"/>
<vertex x="32.07" y="11.6"/>
<vertex x="32.07" y="11.67"/>
<vertex x="32.07" y="11.74"/>
<vertex x="32.07" y="11.82"/>
<vertex x="32.07" y="11.89"/>
<vertex x="32.07" y="11.96"/>
<vertex x="32.07" y="12.03"/>
<vertex x="32.07" y="12.1"/>
<vertex x="32.07" y="12.18"/>
<vertex x="32.07" y="12.25"/>
<vertex x="31.96" y="12.17"/>
<vertex x="31.85" y="12.1"/>
<vertex x="31.72" y="12.03"/>
<vertex x="31.58" y="11.98"/>
<vertex x="31.43" y="11.93"/>
<vertex x="31.28" y="11.88"/>
<vertex x="31.11" y="11.84"/>
<vertex x="30.95" y="11.81"/>
<vertex x="30.77" y="11.79"/>
<vertex x="30.4" y="13.46"/>
<vertex x="30.96" y="13.6"/>
<vertex x="31.43" y="13.76"/>
<vertex x="31.78" y="13.98"/>
<vertex x="32.01" y="14.29"/>
<vertex x="32.07" y="14.71"/>
<vertex x="32.06" y="14.94"/>
<vertex x="32.03" y="15.15"/>
<vertex x="31.98" y="15.34"/>
<vertex x="31.91" y="15.5"/>
<vertex x="31.83" y="15.64"/>
<vertex x="31.73" y="15.77"/>
<vertex x="31.61" y="15.88"/>
<vertex x="31.48" y="15.97"/>
<vertex x="31.33" y="16.04"/>
<vertex x="31.18" y="16.1"/>
<vertex x="31.01" y="16.15"/>
<vertex x="30.84" y="16.18"/>
<vertex x="30.66" y="16.21"/>
<vertex x="30.46" y="16.23"/>
<vertex x="30.27" y="16.23"/>
<vertex x="30.07" y="16.23"/>
<vertex x="29.85" y="16.23"/>
<vertex x="29.64" y="16.21"/>
<vertex x="29.44" y="16.18"/>
<vertex x="29.25" y="16.13"/>
<vertex x="29.08" y="16.08"/>
<vertex x="28.92" y="16.01"/>
<vertex x="28.77" y="15.93"/>
<vertex x="28.63" y="15.84"/>
<vertex x="28.51" y="15.73"/>
<vertex x="28.39" y="15.6"/>
<vertex x="28.3" y="15.46"/>
<vertex x="28.21" y="15.31"/>
<vertex x="28.14" y="15.14"/>
<vertex x="28.08" y="14.95"/>
<vertex x="28.04" y="14.75"/>
<vertex x="28.01" y="14.52"/>
<vertex x="27.82" y="14.52"/>
<vertex x="27.63" y="14.52"/>
<vertex x="27.43" y="14.52"/>
<vertex x="27.24" y="14.52"/>
<vertex x="27.05" y="14.52"/>
<vertex x="26.85" y="14.52"/>
<vertex x="26.66" y="14.52"/>
<vertex x="26.47" y="14.52"/>
<vertex x="26.27" y="14.52"/>
<vertex x="26.08" y="14.52"/>
<vertex x="25.89" y="14.52"/>
<vertex x="25.69" y="14.52"/>
<vertex x="25.5" y="14.52"/>
<vertex x="25.31" y="14.52"/>
<vertex x="25.11" y="14.52"/>
<vertex x="24.92" y="14.52"/>
<vertex x="24.98" y="15.04"/>
<vertex x="25.09" y="15.51"/>
<vertex x="25.26" y="15.94"/>
<vertex x="25.47" y="16.33"/>
<vertex x="25.72" y="16.68"/>
<vertex x="26.01" y="16.98"/>
<vertex x="26.33" y="17.26"/>
<vertex x="26.69" y="17.49"/>
<vertex x="27.07" y="17.69"/>
<vertex x="27.48" y="17.86"/>
<vertex x="27.91" y="18"/>
<vertex x="28.35" y="18.11"/>
<vertex x="28.81" y="18.2"/>
<vertex x="29.28" y="18.26"/>
<vertex x="29.75" y="18.29"/>
<vertex x="30.22" y="18.29"/>
<vertex x="30.65" y="18.29"/>
<vertex x="31.08" y="18.27"/>
<vertex x="31.51" y="18.23"/>
<vertex x="31.95" y="18.17"/>
<vertex x="32.37" y="18.09"/>
<vertex x="32.78" y="17.99"/>
<vertex x="33.17" y="17.86"/>
<vertex x="33.54" y="17.7"/>
<vertex x="33.89" y="17.51"/>
<vertex x="34.2" y="17.29"/>
<vertex x="34.48" y="17.03"/>
<vertex x="34.72" y="16.73"/>
<vertex x="34.91" y="16.39"/>
<vertex x="35.06" y="16"/>
<vertex x="35.15" y="15.57"/>
<vertex x="35.18" y="15.09"/>
<vertex x="35.18" y="14.72"/>
<vertex x="35.18" y="14.35"/>
<vertex x="35.18" y="13.99"/>
<vertex x="35.18" y="13.62"/>
<vertex x="35.18" y="13.25"/>
<vertex x="35.18" y="12.88"/>
<vertex x="35.18" y="12.52"/>
<vertex x="35.18" y="12.15"/>
<vertex x="35.18" y="11.78"/>
<vertex x="35.18" y="11.42"/>
<vertex x="35.18" y="11.05"/>
<vertex x="35.18" y="10.68"/>
<vertex x="35.18" y="10.32"/>
<vertex x="35.18" y="9.95"/>
<vertex x="35.18" y="9.58"/>
<vertex x="35.18" y="9.21"/>
<vertex x="35.18" y="9.02"/>
<vertex x="35.18" y="8.83"/>
<vertex x="35.19" y="8.64"/>
<vertex x="35.19" y="8.46"/>
<vertex x="35.2" y="8.27"/>
<vertex x="35.21" y="8.09"/>
<vertex x="35.24" y="7.92"/>
<vertex x="35.26" y="7.75"/>
<vertex x="35.29" y="7.59"/>
<vertex x="35.32" y="7.43"/>
<vertex x="35.35" y="7.28"/>
<vertex x="35.38" y="7.15"/>
<vertex x="35.42" y="7.02"/>
<vertex x="35.47" y="6.9"/>
<vertex x="35.51" y="6.8"/>
<vertex x="35.56" y="6.71"/>
<vertex x="35.37" y="6.71"/>
<vertex x="35.17" y="6.71"/>
<vertex x="34.98" y="6.71"/>
<vertex x="34.78" y="6.71"/>
<vertex x="34.58" y="6.71"/>
<vertex x="34.39" y="6.71"/>
<vertex x="34.19" y="6.71"/>
<vertex x="34" y="6.71"/>
<vertex x="33.8" y="6.71"/>
<vertex x="33.6" y="6.71"/>
<vertex x="33.41" y="6.71"/>
<vertex x="33.21" y="6.71"/>
<vertex x="33.01" y="6.71"/>
<vertex x="32.82" y="6.71"/>
<vertex x="32.62" y="6.71"/>
<vertex x="32.43" y="6.71"/>
<vertex x="32.4" y="6.77"/>
<vertex x="32.38" y="6.84"/>
<vertex x="32.35" y="6.9"/>
<vertex x="32.33" y="6.97"/>
<vertex x="32.31" y="7.04"/>
<vertex x="32.29" y="7.11"/>
<vertex x="32.28" y="7.17"/>
<vertex x="32.26" y="7.24"/>
<vertex x="32.24" y="7.31"/>
<vertex x="32.24" y="7.38"/>
<vertex x="32.23" y="7.45"/>
<vertex x="32.22" y="7.52"/>
<vertex x="32.22" y="7.59"/>
<vertex x="32.21" y="7.66"/>
<vertex x="32.21" y="7.73"/>
<vertex x="32.21" y="7.8"/>
<vertex x="32.02" y="7.62"/>
<vertex x="31.82" y="7.45"/>
<vertex x="31.61" y="7.29"/>
<vertex x="31.4" y="7.15"/>
<vertex x="31.17" y="7.02"/>
<vertex x="30.94" y="6.91"/>
<vertex x="30.71" y="6.81"/>
<vertex x="30.47" y="6.72"/>
<vertex x="30.22" y="6.64"/>
<vertex x="29.97" y="6.58"/>
<vertex x="29.71" y="6.52"/>
<vertex x="29.46" y="6.48"/>
<vertex x="29.2" y="6.44"/>
<vertex x="28.94" y="6.42"/>
<vertex x="28.67" y="6.4"/>
<vertex x="28.41" y="6.4"/>
<vertex x="28.01" y="6.4"/>
<vertex x="27.63" y="6.44"/>
<vertex x="27.26" y="6.5"/>
<vertex x="26.9" y="6.59"/>
<vertex x="26.56" y="6.7"/>
<vertex x="26.25" y="6.85"/>
<vertex x="25.95" y="7.01"/>
<vertex x="25.68" y="7.21"/>
<vertex x="25.44" y="7.43"/>
<vertex x="25.22" y="7.68"/>
<vertex x="25.03" y="7.96"/>
<vertex x="24.87" y="8.27"/>
<vertex x="24.74" y="8.6"/>
<vertex x="24.65" y="8.96"/>
<vertex x="24.59" y="9.35"/>
<vertex x="24.57" y="9.77"/>
<vertex x="24.66" y="10.64"/>
<vertex x="24.91" y="11.35"/>
<vertex x="25.29" y="11.91"/>
<vertex x="25.78" y="12.35"/>
<vertex x="26.35" y="12.67"/>
<vertex x="27" y="12.91"/>
<vertex x="27.68" y="13.08"/>
</polygon>
<vertex x="36.92" y="17.48"/>
<vertex x="37.29" y="17.55"/>
<vertex x="37.66" y="17.61"/>
<vertex x="38.03" y="17.68"/>
<vertex x="38.4" y="17.74"/>
<vertex x="38.77" y="17.81"/>
<vertex x="39.13" y="17.88"/>
<vertex x="39.5" y="17.94"/>
<vertex x="39.87" y="18.01"/>
<vertex x="39.87" y="17.74"/>
<vertex x="39.87" y="17.48"/>
<vertex x="39.87" y="17.22"/>
<vertex x="39.87" y="16.96"/>
<vertex x="39.87" y="16.69"/>
<vertex x="39.87" y="16.43"/>
<vertex x="39.87" y="16.17"/>
<vertex x="39.87" y="15.91"/>
<vertex x="39.88" y="15.91"/>
<vertex x="39.89" y="15.91"/>
<vertex x="40.15" y="16.42"/>
<vertex x="40.48" y="16.88"/>
<vertex x="40.88" y="17.29"/>
<vertex x="41.33" y="17.64"/>
<vertex x="41.83" y="17.92"/>
<vertex x="42.36" y="18.13"/>
<vertex x="42.92" y="18.26"/>
<vertex x="43.49" y="18.31"/>
<vertex x="43.58" y="18.31"/>
<vertex x="43.67" y="18.31"/>
<vertex x="43.75" y="18.31"/>
<vertex x="43.84" y="18.31"/>
<vertex x="43.92" y="18.29"/>
<vertex x="44" y="18.26"/>
<vertex x="44.09" y="18.24"/>
<vertex x="44.17" y="18.21"/>
<vertex x="44.17" y="17.85"/>
<vertex x="44.17" y="17.49"/>
<vertex x="44.17" y="17.13"/>
<vertex x="44.17" y="16.77"/>
<vertex x="44.17" y="16.41"/>
<vertex x="44.17" y="16.05"/>
<vertex x="44.17" y="15.69"/>
<vertex x="44.17" y="15.33"/>
<vertex x="44.05" y="15.36"/>
<vertex x="43.93" y="15.38"/>
<vertex x="43.79" y="15.41"/>
<vertex x="43.64" y="15.43"/>
<vertex x="43.5" y="15.43"/>
<vertex x="43.35" y="15.43"/>
<vertex x="43.2" y="15.43"/>
<vertex x="43.06" y="15.43"/>
<vertex x="42.27" y="15.36"/>
<vertex x="41.61" y="15.15"/>
<vertex x="41.08" y="14.81"/>
<vertex x="40.67" y="14.37"/>
<vertex x="40.36" y="13.84"/>
<vertex x="40.15" y="13.22"/>
<vertex x="40.04" y="12.54"/>
<vertex x="40" y="11.81"/>
<vertex x="40" y="11.17"/>
<vertex x="40" y="10.54"/>
<vertex x="40" y="9.9"/>
<vertex x="40" y="9.27"/>
<vertex x="40" y="8.63"/>
<vertex x="40" y="8"/>
<vertex x="40" y="7.36"/>
<vertex x="40" y="6.72"/>
<vertex x="39.61" y="6.72"/>
<vertex x="39.22" y="6.72"/>
<vertex x="38.84" y="6.72"/>
<vertex x="38.45" y="6.72"/>
<vertex x="38.06" y="6.72"/>
<vertex x="37.67" y="6.72"/>
<vertex x="37.29" y="6.72"/>
<vertex x="36.9" y="6.72"/>
<vertex x="36.9" y="8.07"/>
<vertex x="36.9" y="9.41"/>
<vertex x="36.9" y="10.76"/>
<vertex x="36.9" y="12.1"/>
<vertex x="36.9" y="13.45"/>
<vertex x="36.9" y="14.79"/>
<vertex x="36.9" y="16.14"/>
</polygon>
<vertex x="45.39" y="20.61"/>
<vertex x="48.49" y="22.31"/>
<vertex x="48.49" y="13.95"/>
<vertex x="52.4" y="18.01"/>
<vertex x="56.06" y="18.01"/>
<vertex x="51.8" y="13.86"/>
<vertex x="56.54" y="6.73"/>
<vertex x="52.79" y="6.73"/>
<vertex x="49.69" y="11.77"/>
<vertex x="48.49" y="10.61"/>
<vertex x="48.49" y="6.73"/>
<vertex x="45.39" y="6.73"/>
</polygon>
<vertex x="58.43" y="15.94"/>
<vertex x="58.04" y="15.94"/>
<vertex x="57.66" y="15.94"/>
<vertex x="57.28" y="15.94"/>
<vertex x="56.9" y="15.94"/>
<vertex x="56.52" y="15.94"/>
<vertex x="56.13" y="15.94"/>
<vertex x="55.75" y="15.94"/>
<vertex x="55.37" y="15.94"/>
<vertex x="55.63" y="16.2"/>
<vertex x="55.9" y="16.45"/>
<vertex x="56.16" y="16.71"/>
<vertex x="56.43" y="16.97"/>
<vertex x="56.69" y="17.23"/>
<vertex x="56.95" y="17.49"/>
<vertex x="57.22" y="17.75"/>
<vertex x="57.48" y="18.01"/>
<vertex x="57.6" y="18.01"/>
<vertex x="57.72" y="18.01"/>
<vertex x="57.84" y="18.01"/>
<vertex x="57.95" y="18.01"/>
<vertex x="58.07" y="18.01"/>
<vertex x="58.19" y="18.01"/>
<vertex x="58.31" y="18.01"/>
<vertex x="58.43" y="18.01"/>
<vertex x="58.43" y="18.12"/>
<vertex x="58.43" y="18.22"/>
<vertex x="58.43" y="18.33"/>
<vertex x="58.43" y="18.44"/>
<vertex x="58.43" y="18.55"/>
<vertex x="58.43" y="18.66"/>
<vertex x="58.43" y="18.77"/>
<vertex x="58.43" y="18.87"/>
<vertex x="58.48" y="19.6"/>
<vertex x="58.66" y="20.26"/>
<vertex x="58.95" y="20.84"/>
<vertex x="59.36" y="21.34"/>
<vertex x="59.89" y="21.75"/>
<vertex x="60.54" y="22.05"/>
<vertex x="61.31" y="22.24"/>
<vertex x="62.2" y="22.3"/>
<vertex x="62.41" y="22.3"/>
<vertex x="62.61" y="22.3"/>
<vertex x="62.82" y="22.3"/>
<vertex x="63.03" y="22.28"/>
<vertex x="63.23" y="22.26"/>
<vertex x="63.44" y="22.24"/>
<vertex x="63.64" y="22.24"/>
<vertex x="63.84" y="22.24"/>
<vertex x="63.84" y="21.95"/>
<vertex x="63.84" y="21.66"/>
<vertex x="63.84" y="21.37"/>
<vertex x="63.84" y="21.08"/>
<vertex x="63.84" y="20.79"/>
<vertex x="63.84" y="20.5"/>
<vertex x="63.84" y="20.21"/>
<vertex x="63.84" y="19.92"/>
<vertex x="63.7" y="19.95"/>
<vertex x="63.56" y="19.97"/>
<vertex x="63.41" y="19.97"/>
<vertex x="63.27" y="19.97"/>
<vertex x="63.13" y="19.97"/>
<vertex x="62.98" y="19.97"/>
<vertex x="62.84" y="19.97"/>
<vertex x="62.7" y="19.97"/>
<vertex x="62.41" y="19.95"/>
<vertex x="62.16" y="19.89"/>
<vertex x="61.96" y="19.8"/>
<vertex x="61.79" y="19.67"/>
<vertex x="61.67" y="19.5"/>
<vertex x="61.59" y="19.27"/>
<vertex x="61.54" y="19"/>
<vertex x="61.52" y="18.68"/>
<vertex x="61.52" y="18.59"/>
<vertex x="61.52" y="18.51"/>
<vertex x="61.52" y="18.42"/>
<vertex x="61.52" y="18.34"/>
<vertex x="61.52" y="18.26"/>
<vertex x="61.52" y="18.17"/>
<vertex x="61.52" y="18.09"/>
<vertex x="61.52" y="18"/>
<vertex x="61.79" y="18"/>
<vertex x="62.06" y="18"/>
<vertex x="62.32" y="18"/>
<vertex x="62.59" y="18"/>
<vertex x="62.86" y="18"/>
<vertex x="63.12" y="18"/>
<vertex x="63.39" y="18"/>
<vertex x="63.66" y="18"/>
<vertex x="63.66" y="17.74"/>
<vertex x="63.66" y="17.48"/>
<vertex x="63.66" y="17.23"/>
<vertex x="63.66" y="16.97"/>
<vertex x="63.66" y="16.71"/>
<vertex x="63.66" y="16.45"/>
<vertex x="63.66" y="16.19"/>
<vertex x="63.66" y="15.93"/>
<vertex x="63.39" y="15.93"/>
<vertex x="63.12" y="15.93"/>
<vertex x="62.86" y="15.93"/>
<vertex x="62.59" y="15.93"/>
<vertex x="62.32" y="15.93"/>
<vertex x="62.06" y="15.93"/>
<vertex x="61.79" y="15.93"/>
<vertex x="61.52" y="15.93"/>
<vertex x="61.52" y="14.78"/>
<vertex x="61.52" y="13.63"/>
<vertex x="61.52" y="12.48"/>
<vertex x="61.52" y="11.32"/>
<vertex x="61.52" y="10.17"/>
<vertex x="61.52" y="9.02"/>
<vertex x="61.52" y="7.87"/>
<vertex x="61.52" y="6.72"/>
<vertex x="61.13" y="6.72"/>
<vertex x="60.75" y="6.72"/>
<vertex x="60.36" y="6.72"/>
<vertex x="59.97" y="6.72"/>
<vertex x="59.58" y="6.72"/>
<vertex x="59.2" y="6.72"/>
<vertex x="58.81" y="6.72"/>
<vertex x="58.42" y="6.72"/>
<vertex x="58.42" y="7.87"/>
<vertex x="58.42" y="9.02"/>
<vertex x="58.42" y="10.17"/>
<vertex x="58.42" y="11.32"/>
<vertex x="58.42" y="12.48"/>
<vertex x="58.42" y="13.63"/>
<vertex x="58.42" y="14.78"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="75.12" y="6.73"/>
<vertex x="74.75" y="6.73"/>
<vertex x="74.38" y="6.73"/>
<vertex x="74.01" y="6.73"/>
<vertex x="73.64" y="6.73"/>
<vertex x="73.27" y="6.73"/>
<vertex x="72.91" y="6.73"/>
<vertex x="72.54" y="6.73"/>
<vertex x="72.17" y="6.73"/>
<vertex x="72.17" y="6.92"/>
<vertex x="72.17" y="7.12"/>
<vertex x="72.17" y="7.31"/>
<vertex x="72.17" y="7.51"/>
<vertex x="72.17" y="7.71"/>
<vertex x="72.17" y="7.9"/>
<vertex x="72.17" y="8.1"/>
<vertex x="72.17" y="8.29"/>
<vertex x="72.16" y="8.29"/>
<vertex x="72.15" y="8.29"/>
<vertex x="72.14" y="8.29"/>
<vertex x="72.13" y="8.29"/>
<vertex x="71.81" y="7.84"/>
<vertex x="71.45" y="7.46"/>
<vertex x="71.04" y="7.13"/>
<vertex x="70.61" y="6.87"/>
<vertex x="70.15" y="6.67"/>
<vertex x="69.67" y="6.53"/>
<vertex x="69.18" y="6.45"/>
<vertex x="68.69" y="6.42"/>
<vertex x="68.53" y="6.42"/>
<vertex x="67.56" y="6.5"/>
<vertex x="66.65" y="6.75"/>
<vertex x="65.93" y="7.15"/>
<vertex x="65.39" y="7.69"/>
<vertex x="65" y="8.37"/>
<vertex x="64.74" y="9.16"/>
<vertex x="64.6" y="10.06"/>
<vertex x="64.59" y="10.18"/>
<vertex x="64.56" y="11.07"/>
<vertex x="64.56" y="11.93"/>
<vertex x="64.56" y="12.8"/>
<vertex x="64.56" y="13.67"/>
<vertex x="64.56" y="14.54"/>
<vertex x="64.56" y="15.4"/>
<vertex x="64.56" y="16.27"/>
<vertex x="64.56" y="17.14"/>
<vertex x="64.56" y="18.01"/>
<vertex x="64.95" y="18.01"/>
<vertex x="65.34" y="18.01"/>
<vertex x="65.72" y="18.01"/>
<vertex x="66.11" y="18.01"/>
<vertex x="66.5" y="18.01"/>
<vertex x="66.89" y="18.01"/>
<vertex x="67.27" y="18.01"/>
<vertex x="67.66" y="18.01"/>
<vertex x="67.66" y="17.21"/>
<vertex x="67.66" y="16.41"/>
<vertex x="67.66" y="15.62"/>
<vertex x="67.66" y="14.82"/>
<vertex x="67.66" y="14.02"/>
<vertex x="67.66" y="13.23"/>
<vertex x="67.66" y="12.43"/>
<vertex x="67.66" y="11.63"/>
<vertex x="67.69" y="10.98"/>
<vertex x="67.77" y="10.42"/>
<vertex x="67.91" y="9.94"/>
<vertex x="68.11" y="9.55"/>
<vertex x="68.38" y="9.25"/>
<vertex x="68.72" y="9.03"/>
<vertex x="69.14" y="8.91"/>
<vertex x="69.65" y="8.86"/>
<vertex x="70.23" y="8.91"/>
<vertex x="70.73" y="9.05"/>
<vertex x="71.15" y="9.28"/>
<vertex x="71.48" y="9.62"/>
<vertex x="71.73" y="10.06"/>
<vertex x="71.91" y="10.62"/>
<vertex x="72.01" y="11.3"/>
<vertex x="72.05" y="12.09"/>
<vertex x="72.05" y="12.83"/>
<vertex x="72.05" y="13.57"/>
<vertex x="72.05" y="14.31"/>
<vertex x="72.05" y="15.05"/>
<vertex x="72.05" y="15.79"/>
<vertex x="72.05" y="16.53"/>
<vertex x="72.05" y="17.27"/>
<vertex x="72.05" y="18.01"/>
<vertex x="72.44" y="18.01"/>
<vertex x="72.82" y="18.01"/>
<vertex x="73.21" y="18.01"/>
<vertex x="73.6" y="18.01"/>
<vertex x="73.99" y="18.01"/>
<vertex x="74.37" y="18.01"/>
<vertex x="74.76" y="18.01"/>
<vertex x="75.15" y="18.01"/>
<vertex x="75.15" y="16.6"/>
<vertex x="75.15" y="15.19"/>
<vertex x="75.15" y="13.78"/>
<vertex x="75.15" y="12.36"/>
<vertex x="75.15" y="10.95"/>
<vertex x="75.15" y="9.54"/>
<vertex x="75.15" y="8.13"/>
</polygon>
<vertex x="76.83" y="18.01"/>
<vertex x="77.2" y="18.01"/>
<vertex x="77.56" y="18.01"/>
<vertex x="77.93" y="18.01"/>
<vertex x="78.3" y="18.01"/>
<vertex x="78.67" y="18.01"/>
<vertex x="79.04" y="18.01"/>
<vertex x="79.41" y="18.01"/>
<vertex x="79.77" y="18.01"/>
<vertex x="79.77" y="17.81"/>
<vertex x="79.77" y="17.62"/>
<vertex x="79.77" y="17.42"/>
<vertex x="79.77" y="17.22"/>
<vertex x="79.77" y="17.03"/>
<vertex x="79.77" y="16.83"/>
<vertex x="79.77" y="16.64"/>
<vertex x="79.77" y="16.44"/>
<vertex x="79.78" y="16.44"/>
<vertex x="79.79" y="16.44"/>
<vertex x="79.8" y="16.44"/>
<vertex x="79.81" y="16.44"/>
<vertex x="80.13" y="16.89"/>
<vertex x="80.49" y="17.28"/>
<vertex x="80.9" y="17.6"/>
<vertex x="81.34" y="17.86"/>
<vertex x="81.8" y="18.06"/>
<vertex x="82.28" y="18.2"/>
<vertex x="82.77" y="18.29"/>
<vertex x="83.26" y="18.32"/>
<vertex x="83.41" y="18.31"/>
<vertex x="84.38" y="18.23"/>
<vertex x="85.29" y="17.98"/>
<vertex x="86.01" y="17.58"/>
<vertex x="86.56" y="17.04"/>
<vertex x="86.95" y="16.37"/>
<vertex x="87.2" y="15.57"/>
<vertex x="87.34" y="14.67"/>
<vertex x="87.35" y="14.55"/>
<vertex x="87.38" y="13.67"/>
<vertex x="87.38" y="12.8"/>
<vertex x="87.38" y="11.93"/>
<vertex x="87.38" y="11.07"/>
<vertex x="87.38" y="10.2"/>
<vertex x="87.38" y="9.33"/>
<vertex x="87.38" y="8.46"/>
<vertex x="87.38" y="7.6"/>
<vertex x="87.38" y="6.73"/>
<vertex x="86.99" y="6.73"/>
<vertex x="86.61" y="6.73"/>
<vertex x="86.22" y="6.73"/>
<vertex x="85.83" y="6.73"/>
<vertex x="85.44" y="6.73"/>
<vertex x="85.06" y="6.73"/>
<vertex x="84.67" y="6.73"/>
<vertex x="84.28" y="6.73"/>
<vertex x="84.28" y="7.52"/>
<vertex x="84.28" y="8.32"/>
<vertex x="84.28" y="9.12"/>
<vertex x="84.28" y="9.91"/>
<vertex x="84.28" y="10.71"/>
<vertex x="84.28" y="11.51"/>
<vertex x="84.28" y="12.3"/>
<vertex x="84.28" y="13.1"/>
<vertex x="84.25" y="13.75"/>
<vertex x="84.18" y="14.32"/>
<vertex x="84.04" y="14.79"/>
<vertex x="83.84" y="15.18"/>
<vertex x="83.57" y="15.48"/>
<vertex x="83.22" y="15.7"/>
<vertex x="82.8" y="15.83"/>
<vertex x="82.29" y="15.87"/>
<vertex x="81.71" y="15.83"/>
<vertex x="81.21" y="15.69"/>
<vertex x="80.8" y="15.45"/>
<vertex x="80.47" y="15.12"/>
<vertex x="80.21" y="14.67"/>
<vertex x="80.04" y="14.11"/>
<vertex x="79.93" y="13.44"/>
<vertex x="79.9" y="12.64"/>
<vertex x="79.9" y="11.9"/>
<vertex x="79.9" y="11.16"/>
<vertex x="79.9" y="10.42"/>
<vertex x="79.9" y="9.68"/>
<vertex x="79.9" y="8.94"/>
<vertex x="79.9" y="8.21"/>
<vertex x="79.9" y="7.47"/>
<vertex x="79.9" y="6.73"/>
<vertex x="79.51" y="6.73"/>
<vertex x="79.12" y="6.73"/>
<vertex x="78.73" y="6.73"/>
<vertex x="78.35" y="6.73"/>
<vertex x="77.96" y="6.73"/>
<vertex x="77.57" y="6.73"/>
<vertex x="77.18" y="6.73"/>
<vertex x="76.8" y="6.73"/>
<vertex x="76.8" y="8.14"/>
<vertex x="76.8" y="9.55"/>
<vertex x="76.8" y="10.96"/>
<vertex x="76.8" y="12.37"/>
<vertex x="76.8" y="13.78"/>
<vertex x="76.8" y="15.19"/>
<vertex x="76.8" y="16.6"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_.9">
<vertex x="3.31" y="11.69"/>
<vertex x="3.37" y="11.17"/>
<vertex x="3.54" y="10.73"/>
<vertex x="3.8" y="10.36"/>
<vertex x="4.15" y="10.06"/>
<vertex x="4.55" y="9.84"/>
<vertex x="5" y="9.68"/>
<vertex x="5.49" y="9.59"/>
<vertex x="5.99" y="9.56"/>
<vertex x="6.37" y="9.58"/>
<vertex x="6.76" y="9.64"/>
<vertex x="7.14" y="9.75"/>
<vertex x="7.5" y="9.91"/>
<vertex x="7.81" y="10.13"/>
<vertex x="8.06" y="10.41"/>
<vertex x="8.22" y="10.76"/>
<vertex x="8.27" y="11.18"/>
<vertex x="8.21" y="11.55"/>
<vertex x="8.01" y="11.86"/>
<vertex x="7.68" y="12.13"/>
<vertex x="7.23" y="12.37"/>
<vertex x="6.66" y="12.58"/>
<vertex x="5.99" y="12.77"/>
<vertex x="5.2" y="12.96"/>
<vertex x="4.32" y="13.15"/>
<vertex x="3.56" y="13.34"/>
<vertex x="2.83" y="13.56"/>
<vertex x="2.15" y="13.83"/>
<vertex x="1.54" y="14.17"/>
<vertex x="1.03" y="14.6"/>
<vertex x="0.64" y="15.12"/>
<vertex x="0.39" y="15.76"/>
<vertex x="0.3" y="16.54"/>
<vertex x="0.3" y="16.69"/>
<vertex x="0.42" y="17.64"/>
<vertex x="0.77" y="18.54"/>
<vertex x="1.32" y="19.25"/>
<vertex x="2.03" y="19.79"/>
<vertex x="2.87" y="20.18"/>
<vertex x="3.8" y="20.43"/>
<vertex x="3.93" y="20.46"/>
<vertex x="4.8" y="20.57"/>
<vertex x="4.92" y="20.58"/>
<vertex x="5.82" y="20.61"/>
<vertex x="5.95" y="20.61"/>
<vertex x="6.84" y="20.57"/>
<vertex x="7.82" y="20.42"/>
<vertex x="8.73" y="20.16"/>
<vertex x="9.55" y="19.76"/>
<vertex x="10.25" y="19.22"/>
<vertex x="10.81" y="18.51"/>
<vertex x="11.21" y="17.63"/>
<vertex x="11.25" y="17.51"/>
<vertex x="11.42" y="16.57"/>
<vertex x="11" y="16.57"/>
<vertex x="10.59" y="16.57"/>
<vertex x="10.18" y="16.57"/>
<vertex x="9.76" y="16.57"/>
<vertex x="9.35" y="16.57"/>
<vertex x="8.93" y="16.57"/>
<vertex x="8.52" y="16.57"/>
<vertex x="8.1" y="16.57"/>
<vertex x="8.02" y="17.03"/>
<vertex x="7.87" y="17.4"/>
<vertex x="7.64" y="17.7"/>
<vertex x="7.34" y="17.93"/>
<vertex x="7" y="18.1"/>
<vertex x="6.61" y="18.21"/>
<vertex x="6.18" y="18.27"/>
<vertex x="5.72" y="18.29"/>
<vertex x="5.41" y="18.29"/>
<vertex x="5.09" y="18.26"/>
<vertex x="4.76" y="18.2"/>
<vertex x="4.46" y="18.1"/>
<vertex x="4.19" y="17.96"/>
<vertex x="3.97" y="17.75"/>
<vertex x="3.83" y="17.47"/>
<vertex x="3.78" y="17.12"/>
<vertex x="3.87" y="16.7"/>
<vertex x="4.12" y="16.36"/>
<vertex x="4.51" y="16.09"/>
<vertex x="5.02" y="15.88"/>
<vertex x="5.62" y="15.7"/>
<vertex x="6.29" y="15.55"/>
<vertex x="7" y="15.39"/>
<vertex x="7.73" y="15.23"/>
<vertex x="8.49" y="15.04"/>
<vertex x="9.22" y="14.81"/>
<vertex x="9.9" y="14.52"/>
<vertex x="10.51" y="14.16"/>
<vertex x="11.02" y="13.71"/>
<vertex x="11.42" y="13.16"/>
<vertex x="11.67" y="12.48"/>
<vertex x="11.76" y="11.67"/>
<vertex x="11.76" y="11.52"/>
<vertex x="11.63" y="10.52"/>
<vertex x="11.59" y="10.39"/>
<vertex x="11.26" y="9.57"/>
<vertex x="10.68" y="8.81"/>
<vertex x="9.94" y="8.21"/>
<vertex x="9.06" y="7.77"/>
<vertex x="8.94" y="7.73"/>
<vertex x="8.08" y="7.47"/>
<vertex x="7.95" y="7.45"/>
<vertex x="7.04" y="7.31"/>
<vertex x="6.9" y="7.29"/>
<vertex x="5.96" y="7.25"/>
<vertex x="5.83" y="7.25"/>
<vertex x="4.87" y="7.31"/>
<vertex x="4.73" y="7.32"/>
<vertex x="3.81" y="7.48"/>
<vertex x="3.68" y="7.51"/>
<vertex x="2.82" y="7.78"/>
<vertex x="1.92" y="8.22"/>
<vertex x="1.16" y="8.83"/>
<vertex x="0.57" y="9.6"/>
<vertex x="0.51" y="9.71"/>
<vertex x="0.17" y="10.56"/>
<vertex x="0.14" y="10.69"/>
<vertex x="0" y="11.69"/>
<vertex x="0.41" y="11.69"/>
<vertex x="0.83" y="11.69"/>
<vertex x="1.24" y="11.69"/>
<vertex x="1.66" y="11.69"/>
<vertex x="2.07" y="11.69"/>
<vertex x="2.48" y="11.69"/>
<vertex x="2.9" y="11.69"/>
</polygon>
<vertex x="22.23" y="11.7"/>
<vertex x="22.43" y="12.38"/>
<vertex x="22.55" y="13.11"/>
<vertex x="22.58" y="13.88"/>
<vertex x="26.07" y="13.78"/>
<vertex x="26.07" y="13.62"/>
<vertex x="25.98" y="12.52"/>
<vertex x="25.96" y="12.37"/>
<vertex x="25.72" y="11.32"/>
<vertex x="25.68" y="11.18"/>
<vertex x="25.29" y="10.21"/>
</polygon>
<vertex x="25.29" y="10.22"/>
<vertex x="25.22" y="10.08"/>
<vertex x="24.68" y="9.23"/>
<vertex x="24.59" y="9.12"/>
<vertex x="23.9" y="8.4"/>
<vertex x="23.79" y="8.31"/>
<vertex x="22.94" y="7.77"/>
<vertex x="22.81" y="7.71"/>
<vertex x="21.81" y="7.37"/>
<vertex x="21.65" y="7.33"/>
<vertex x="20.49" y="7.22"/>
<vertex x="19.92" y="7.25"/>
<vertex x="19.37" y="7.35"/>
<vertex x="18.84" y="7.5"/>
<vertex x="18.33" y="7.71"/>
<vertex x="17.86" y="7.98"/>
<vertex x="17.43" y="8.31"/>
<vertex x="17.04" y="8.7"/>
<vertex x="16.69" y="9.14"/>
<vertex x="16.68" y="9.14"/>
<vertex x="16.67" y="9.14"/>
<vertex x="16.67" y="8"/>
<vertex x="16.67" y="6.85"/>
<vertex x="16.67" y="5.71"/>
<vertex x="16.67" y="4.57"/>
<vertex x="16.67" y="3.43"/>
<vertex x="16.67" y="2.28"/>
<vertex x="16.67" y="1.14"/>
<vertex x="16.67" y="0"/>
<vertex x="16.23" y="0.39"/>
<vertex x="15.8" y="0.78"/>
<vertex x="15.36" y="1.16"/>
<vertex x="14.93" y="1.55"/>
<vertex x="14.49" y="1.94"/>
<vertex x="14.06" y="2.33"/>
<vertex x="13.62" y="2.71"/>
<vertex x="13.18" y="3.1"/>
<vertex x="13.18" y="5.17"/>
<vertex x="13.18" y="7.24"/>
<vertex x="13.18" y="9.32"/>
<vertex x="13.18" y="11.39"/>
<vertex x="13.18" y="13.46"/>
<vertex x="13.18" y="15.53"/>
<vertex x="13.18" y="17.6"/>
<vertex x="13.18" y="19.67"/>
<vertex x="13.6" y="19.75"/>
<vertex x="14.01" y="19.82"/>
<vertex x="14.43" y="19.89"/>
<vertex x="14.84" y="19.97"/>
<vertex x="15.26" y="20.04"/>
<vertex x="15.67" y="20.11"/>
<vertex x="16.09" y="20.19"/>
<vertex x="16.5" y="20.26"/>
<vertex x="16.5" y="20.06"/>
<vertex x="16.5" y="19.85"/>
<vertex x="16.5" y="19.65"/>
<vertex x="16.5" y="19.45"/>
<vertex x="16.5" y="19.25"/>
<vertex x="16.5" y="19.04"/>
<vertex x="16.5" y="18.84"/>
<vertex x="16.5" y="18.64"/>
<vertex x="16.51" y="18.64"/>
<vertex x="16.52" y="18.64"/>
<vertex x="16.87" y="19.12"/>
<vertex x="17.25" y="19.52"/>
<vertex x="17.68" y="19.86"/>
<vertex x="18.14" y="20.13"/>
<vertex x="18.64" y="20.34"/>
<vertex x="19.17" y="20.49"/>
<vertex x="19.72" y="20.57"/>
<vertex x="20.3" y="20.6"/>
<vertex x="20.49" y="20.6"/>
<vertex x="21.69" y="20.46"/>
<vertex x="21.85" y="20.42"/>
<vertex x="22.88" y="20.04"/>
<vertex x="23.02" y="19.97"/>
<vertex x="23.87" y="19.39"/>
<vertex x="23.98" y="19.3"/>
<vertex x="24.68" y="18.54"/>
<vertex x="24.76" y="18.42"/>
<vertex x="25.29" y="17.52"/>
<vertex x="25.36" y="17.38"/>
<vertex x="25.73" y="16.37"/>
<vertex x="25.77" y="16.21"/>
<vertex x="25.99" y="15.11"/>
<vertex x="26.01" y="14.94"/>
<vertex x="22.58" y="13.87"/>
<vertex x="22.54" y="14.63"/>
<vertex x="22.42" y="15.37"/>
<vertex x="22.21" y="16.06"/>
<vertex x="21.9" y="16.69"/>
<vertex x="21.48" y="17.21"/>
<vertex x="20.96" y="17.62"/>
<vertex x="20.31" y="17.88"/>
<vertex x="19.54" y="17.97"/>
<vertex x="18.75" y="17.88"/>
<vertex x="18.1" y="17.62"/>
<vertex x="17.58" y="17.22"/>
<vertex x="17.17" y="16.7"/>
<vertex x="16.87" y="16.08"/>
<vertex x="16.67" y="15.38"/>
<vertex x="16.55" y="14.64"/>
<vertex x="16.52" y="13.87"/>
<vertex x="16.56" y="13.11"/>
<vertex x="16.68" y="12.38"/>
<vertex x="16.89" y="11.69"/>
<vertex x="17.19" y="11.09"/>
<vertex x="17.61" y="10.58"/>
<vertex x="18.13" y="10.19"/>
<vertex x="18.78" y="9.94"/>
<vertex x="19.56" y="9.85"/>
<vertex x="20.35" y="9.94"/>
<vertex x="21" y="10.19"/>
<vertex x="21.52" y="10.58"/>
<vertex x="21.93" y="11.09"/>
<vertex x="22.23" y="11.69"/>
</polygon>
<vertex x="31.37" y="14.85"/>
<vertex x="32.16" y="14.95"/>
<vertex x="32.93" y="15.04"/>
<vertex x="33.64" y="15.13"/>
<vertex x="34.06" y="13.26"/>
<vertex x="33.86" y="13.23"/>
<vertex x="33.65" y="13.2"/>
<vertex x="33.44" y="13.16"/>
<vertex x="33.24" y="13.13"/>
<vertex x="33.03" y="13.1"/>
<vertex x="32.82" y="13.07"/>
<vertex x="32.62" y="13.04"/>
<vertex x="32.42" y="13"/>
<vertex x="32.22" y="12.96"/>
<vertex x="32.03" y="12.91"/>
</polygon>
<vertex x="32.03" y="12.9"/>
<vertex x="31.84" y="12.84"/>
<vertex x="31.66" y="12.77"/>
<vertex x="31.49" y="12.69"/>
<vertex x="31.33" y="12.6"/>
<vertex x="31.18" y="12.5"/>
<vertex x="31.05" y="12.39"/>
<vertex x="30.92" y="12.27"/>
<vertex x="30.82" y="12.12"/>
<vertex x="30.73" y="11.97"/>
<vertex x="30.65" y="11.79"/>
<vertex x="30.6" y="11.6"/>
<vertex x="30.57" y="11.39"/>
<vertex x="30.56" y="11.17"/>
<vertex x="30.57" y="10.94"/>
<vertex x="30.6" y="10.73"/>
<vertex x="30.65" y="10.54"/>
<vertex x="30.73" y="10.37"/>
<vertex x="30.82" y="10.22"/>
<vertex x="30.93" y="10.09"/>
<vertex x="31.06" y="9.98"/>
<vertex x="31.2" y="9.88"/>
<vertex x="31.35" y="9.79"/>
<vertex x="31.52" y="9.72"/>
<vertex x="31.7" y="9.66"/>
<vertex x="31.88" y="9.62"/>
<vertex x="32.08" y="9.59"/>
<vertex x="32.28" y="9.56"/>
<vertex x="32.48" y="9.56"/>
<vertex x="32.69" y="9.56"/>
<vertex x="33.17" y="9.59"/>
<vertex x="33.6" y="9.65"/>
<vertex x="33.97" y="9.76"/>
<vertex x="34.28" y="9.91"/>
<vertex x="34.56" y="10.08"/>
<vertex x="34.78" y="10.28"/>
<vertex x="34.97" y="10.5"/>
<vertex x="35.13" y="10.73"/>
<vertex x="35.25" y="10.97"/>
<vertex x="35.34" y="11.21"/>
<vertex x="35.41" y="11.46"/>
<vertex x="35.46" y="11.7"/>
<vertex x="35.49" y="11.92"/>
<vertex x="35.51" y="12.13"/>
<vertex x="35.51" y="12.32"/>
<vertex x="35.51" y="12.48"/>
<vertex x="35.51" y="12.56"/>
<vertex x="35.51" y="12.64"/>
<vertex x="35.51" y="12.72"/>
<vertex x="35.51" y="12.81"/>
<vertex x="35.51" y="12.89"/>
<vertex x="35.51" y="12.97"/>
<vertex x="35.51" y="13.05"/>
<vertex x="35.51" y="13.13"/>
<vertex x="35.51" y="13.21"/>
<vertex x="35.51" y="13.29"/>
<vertex x="35.51" y="13.37"/>
<vertex x="35.51" y="13.46"/>
<vertex x="35.51" y="13.54"/>
<vertex x="35.51" y="13.62"/>
<vertex x="35.51" y="13.7"/>
<vertex x="35.51" y="13.78"/>
<vertex x="35.4" y="13.69"/>
<vertex x="35.26" y="13.61"/>
<vertex x="35.12" y="13.54"/>
<vertex x="34.96" y="13.47"/>
<vertex x="34.8" y="13.42"/>
<vertex x="34.62" y="13.37"/>
<vertex x="34.44" y="13.33"/>
<vertex x="34.25" y="13.29"/>
<vertex x="33.64" y="15.14"/>
<vertex x="34.26" y="15.29"/>
<vertex x="34.79" y="15.47"/>
<vertex x="35.2" y="15.73"/>
<vertex x="35.44" y="16.08"/>
<vertex x="35.51" y="16.55"/>
<vertex x="35.51" y="16.81"/>
<vertex x="35.47" y="17.04"/>
<vertex x="35.42" y="17.25"/>
<vertex x="35.34" y="17.44"/>
<vertex x="35.24" y="17.6"/>
<vertex x="35.13" y="17.74"/>
<vertex x="35" y="17.86"/>
<vertex x="34.85" y="17.96"/>
<vertex x="34.69" y="18.05"/>
<vertex x="34.51" y="18.11"/>
<vertex x="34.33" y="18.17"/>
<vertex x="34.13" y="18.21"/>
<vertex x="33.92" y="18.24"/>
<vertex x="33.71" y="18.26"/>
<vertex x="33.49" y="18.26"/>
<vertex x="33.26" y="18.26"/>
<vertex x="33.01" y="18.26"/>
<vertex x="32.78" y="18.23"/>
<vertex x="32.56" y="18.2"/>
<vertex x="32.35" y="18.15"/>
<vertex x="32.15" y="18.09"/>
<vertex x="31.97" y="18.01"/>
<vertex x="31.8" y="17.92"/>
<vertex x="31.65" y="17.82"/>
<vertex x="31.51" y="17.69"/>
<vertex x="31.38" y="17.55"/>
<vertex x="31.27" y="17.39"/>
<vertex x="31.18" y="17.22"/>
<vertex x="31.1" y="17.03"/>
<vertex x="31.03" y="16.82"/>
<vertex x="30.98" y="16.59"/>
<vertex x="30.95" y="16.34"/>
<vertex x="30.73" y="16.34"/>
<vertex x="30.52" y="16.34"/>
<vertex x="30.3" y="16.34"/>
<vertex x="30.08" y="16.34"/>
<vertex x="29.86" y="16.34"/>
<vertex x="29.65" y="16.34"/>
<vertex x="29.43" y="16.34"/>
<vertex x="29.21" y="16.34"/>
<vertex x="28.99" y="16.34"/>
<vertex x="28.78" y="16.34"/>
<vertex x="28.56" y="16.34"/>
<vertex x="28.34" y="16.34"/>
<vertex x="28.12" y="16.34"/>
<vertex x="27.91" y="16.34"/>
<vertex x="27.69" y="16.34"/>
<vertex x="27.47" y="16.34"/>
<vertex x="27.54" y="16.92"/>
<vertex x="27.67" y="17.45"/>
<vertex x="27.85" y="17.94"/>
<vertex x="28.09" y="18.37"/>
<vertex x="28.37" y="18.76"/>
<vertex x="28.69" y="19.11"/>
<vertex x="29.06" y="19.41"/>
<vertex x="29.46" y="19.68"/>
<vertex x="29.89" y="19.91"/>
<vertex x="30.35" y="20.1"/>
<vertex x="30.83" y="20.25"/>
<vertex x="31.33" y="20.38"/>
<vertex x="31.85" y="20.47"/>
<vertex x="32.37" y="20.54"/>
<vertex x="32.9" y="20.58"/>
<vertex x="33.44" y="20.58"/>
<vertex x="33.92" y="20.58"/>
<vertex x="34.4" y="20.55"/>
<vertex x="34.89" y="20.51"/>
<vertex x="35.38" y="20.44"/>
<vertex x="35.85" y="20.35"/>
<vertex x="36.31" y="20.24"/>
<vertex x="36.76" y="20.09"/>
<vertex x="37.17" y="19.92"/>
<vertex x="37.56" y="19.7"/>
<vertex x="37.92" y="19.45"/>
<vertex x="38.23" y="19.16"/>
<vertex x="38.5" y="18.82"/>
<vertex x="38.71" y="18.43"/>
<vertex x="38.88" y="18"/>
<vertex x="38.98" y="17.51"/>
<vertex x="39.01" y="16.97"/>
<vertex x="39.01" y="16.56"/>
<vertex x="39.01" y="16.15"/>
<vertex x="39.01" y="15.73"/>
<vertex x="39.01" y="15.32"/>
<vertex x="39.01" y="14.91"/>
<vertex x="39.01" y="14.49"/>
<vertex x="39.01" y="14.08"/>
<vertex x="39.01" y="13.67"/>
<vertex x="39.01" y="13.26"/>
<vertex x="39.01" y="12.84"/>
<vertex x="39.01" y="12.43"/>
<vertex x="39.01" y="12.02"/>
<vertex x="39.01" y="11.61"/>
<vertex x="39.01" y="11.19"/>
<vertex x="39.01" y="10.78"/>
<vertex x="39.01" y="10.37"/>
<vertex x="39.01" y="10.15"/>
<vertex x="39.02" y="9.94"/>
<vertex x="39.02" y="9.72"/>
<vertex x="39.03" y="9.51"/>
<vertex x="39.04" y="9.3"/>
<vertex x="39.05" y="9.1"/>
<vertex x="39.08" y="8.91"/>
<vertex x="39.11" y="8.72"/>
<vertex x="39.14" y="8.53"/>
<vertex x="39.17" y="8.36"/>
<vertex x="39.21" y="8.19"/>
<vertex x="39.25" y="8.04"/>
<vertex x="39.29" y="7.9"/>
<vertex x="39.34" y="7.76"/>
<vertex x="39.39" y="7.65"/>
<vertex x="39.45" y="7.54"/>
<vertex x="39.23" y="7.54"/>
<vertex x="39.01" y="7.54"/>
<vertex x="38.78" y="7.54"/>
<vertex x="38.56" y="7.54"/>
<vertex x="38.34" y="7.54"/>
<vertex x="38.12" y="7.54"/>
<vertex x="37.9" y="7.54"/>
<vertex x="37.68" y="7.54"/>
<vertex x="37.46" y="7.54"/>
<vertex x="37.24" y="7.54"/>
<vertex x="37.02" y="7.54"/>
<vertex x="36.8" y="7.54"/>
<vertex x="36.58" y="7.54"/>
<vertex x="36.36" y="7.54"/>
<vertex x="36.14" y="7.54"/>
<vertex x="35.92" y="7.54"/>
<vertex x="35.89" y="7.62"/>
<vertex x="35.86" y="7.69"/>
<vertex x="35.84" y="7.77"/>
<vertex x="35.81" y="7.84"/>
<vertex x="35.78" y="7.92"/>
<vertex x="35.76" y="8"/>
<vertex x="35.75" y="8.07"/>
<vertex x="35.73" y="8.15"/>
<vertex x="35.71" y="8.23"/>
<vertex x="35.7" y="8.3"/>
<vertex x="35.7" y="8.38"/>
<vertex x="35.69" y="8.46"/>
<vertex x="35.68" y="8.54"/>
<vertex x="35.68" y="8.62"/>
<vertex x="35.67" y="8.7"/>
<vertex x="35.67" y="8.78"/>
<vertex x="35.46" y="8.57"/>
<vertex x="35.24" y="8.38"/>
<vertex x="35" y="8.2"/>
<vertex x="34.76" y="8.05"/>
<vertex x="34.51" y="7.9"/>
<vertex x="34.25" y="7.77"/>
<vertex x="33.98" y="7.66"/>
<vertex x="33.71" y="7.56"/>
<vertex x="33.44" y="7.47"/>
<vertex x="33.15" y="7.4"/>
<vertex x="32.87" y="7.34"/>
<vertex x="32.58" y="7.29"/>
<vertex x="32.28" y="7.25"/>
<vertex x="31.99" y="7.22"/>
<vertex x="31.7" y="7.2"/>
<vertex x="31.4" y="7.2"/>
<vertex x="30.95" y="7.2"/>
<vertex x="30.52" y="7.24"/>
<vertex x="30.1" y="7.31"/>
<vertex x="29.7" y="7.41"/>
<vertex x="29.32" y="7.54"/>
<vertex x="28.97" y="7.7"/>
<vertex x="28.64" y="7.89"/>
<vertex x="28.33" y="8.11"/>
<vertex x="28.05" y="8.36"/>
<vertex x="27.81" y="8.64"/>
<vertex x="27.59" y="8.96"/>
<vertex x="27.41" y="9.3"/>
<vertex x="27.27" y="9.67"/>
<vertex x="27.17" y="10.08"/>
<vertex x="27.1" y="10.52"/>
<vertex x="27.08" y="10.99"/>
<vertex x="27.18" y="11.97"/>
<vertex x="27.46" y="12.77"/>
<vertex x="27.89" y="13.4"/>
<vertex x="28.44" y="13.89"/>
<vertex x="29.09" y="14.26"/>
<vertex x="29.81" y="14.52"/>
<vertex x="30.58" y="14.71"/>
</polygon>
<vertex x="40.98" y="19.67"/>
<vertex x="41.39" y="19.74"/>
<vertex x="41.81" y="19.82"/>
<vertex x="42.22" y="19.89"/>
<vertex x="42.64" y="19.96"/>
<vertex x="43.05" y="20.04"/>
<vertex x="43.46" y="20.11"/>
<vertex x="43.88" y="20.18"/>
<vertex x="44.29" y="20.26"/>
<vertex x="44.29" y="19.96"/>
<vertex x="44.29" y="19.67"/>
<vertex x="44.29" y="19.37"/>
<vertex x="44.29" y="19.08"/>
<vertex x="44.29" y="18.78"/>
<vertex x="44.29" y="18.49"/>
<vertex x="44.29" y="18.19"/>
<vertex x="44.29" y="17.9"/>
<vertex x="44.3" y="17.9"/>
<vertex x="44.31" y="17.9"/>
<vertex x="44.61" y="18.47"/>
<vertex x="44.98" y="18.99"/>
<vertex x="45.43" y="19.45"/>
<vertex x="45.93" y="19.85"/>
<vertex x="46.49" y="20.16"/>
<vertex x="47.09" y="20.4"/>
<vertex x="47.72" y="20.55"/>
<vertex x="48.36" y="20.6"/>
<vertex x="48.46" y="20.6"/>
<vertex x="48.56" y="20.6"/>
<vertex x="48.66" y="20.6"/>
<vertex x="48.75" y="20.6"/>
<vertex x="48.85" y="20.57"/>
<vertex x="48.94" y="20.55"/>
<vertex x="49.03" y="20.52"/>
<vertex x="49.13" y="20.49"/>
<vertex x="49.13" y="20.08"/>
<vertex x="49.13" y="19.68"/>
<vertex x="49.13" y="19.27"/>
<vertex x="49.13" y="18.87"/>
<vertex x="49.13" y="18.46"/>
<vertex x="49.13" y="18.06"/>
<vertex x="49.13" y="17.65"/>
<vertex x="49.13" y="17.25"/>
<vertex x="49" y="17.28"/>
<vertex x="48.85" y="17.3"/>
<vertex x="48.7" y="17.33"/>
<vertex x="48.54" y="17.36"/>
<vertex x="48.37" y="17.36"/>
<vertex x="48.2" y="17.36"/>
<vertex x="48.04" y="17.36"/>
<vertex x="47.87" y="17.36"/>
<vertex x="46.99" y="17.28"/>
<vertex x="46.25" y="17.04"/>
<vertex x="45.65" y="16.67"/>
<vertex x="45.19" y="16.17"/>
<vertex x="44.85" y="15.57"/>
<vertex x="44.61" y="14.87"/>
<vertex x="44.48" y="14.11"/>
<vertex x="44.43" y="13.28"/>
<vertex x="44.43" y="12.57"/>
<vertex x="44.43" y="11.85"/>
<vertex x="44.43" y="11.14"/>
<vertex x="44.43" y="10.42"/>
<vertex x="44.43" y="9.71"/>
<vertex x="44.43" y="8.99"/>
<vertex x="44.43" y="8.28"/>
<vertex x="44.43" y="7.56"/>
<vertex x="44" y="7.56"/>
<vertex x="43.56" y="7.56"/>
<vertex x="43.13" y="7.56"/>
<vertex x="42.69" y="7.56"/>
<vertex x="42.26" y="7.56"/>
<vertex x="41.82" y="7.56"/>
<vertex x="41.38" y="7.56"/>
<vertex x="40.95" y="7.56"/>
<vertex x="40.95" y="9.08"/>
<vertex x="40.95" y="10.59"/>
<vertex x="40.95" y="12.1"/>
<vertex x="40.95" y="13.62"/>
<vertex x="40.95" y="15.13"/>
<vertex x="40.95" y="16.64"/>
<vertex x="40.95" y="18.15"/>
</polygon>
<vertex x="50.5" y="23.18"/>
<vertex x="53.99" y="25.1"/>
<vertex x="53.99" y="15.69"/>
<vertex x="58.38" y="20.26"/>
<vertex x="62.51" y="20.26"/>
<vertex x="57.72" y="15.59"/>
<vertex x="63.04" y="7.57"/>
<vertex x="58.82" y="7.57"/>
<vertex x="55.34" y="13.24"/>
<vertex x="53.99" y="11.94"/>
<vertex x="53.99" y="7.57"/>
<vertex x="50.5" y="7.57"/>
</polygon>
<vertex x="65.17" y="17.93"/>
<vertex x="64.74" y="17.93"/>
<vertex x="64.31" y="17.93"/>
<vertex x="63.88" y="17.93"/>
<vertex x="63.45" y="17.93"/>
<vertex x="63.02" y="17.93"/>
<vertex x="62.59" y="17.93"/>
<vertex x="62.16" y="17.93"/>
<vertex x="61.73" y="17.93"/>
<vertex x="62.02" y="18.22"/>
<vertex x="62.32" y="18.51"/>
<vertex x="62.62" y="18.8"/>
<vertex x="62.92" y="19.09"/>
<vertex x="63.21" y="19.39"/>
<vertex x="63.51" y="19.68"/>
<vertex x="63.81" y="19.97"/>
<vertex x="64.1" y="20.26"/>
<vertex x="64.24" y="20.26"/>
<vertex x="64.37" y="20.26"/>
<vertex x="64.5" y="20.26"/>
<vertex x="64.63" y="20.26"/>
<vertex x="64.77" y="20.26"/>
<vertex x="64.9" y="20.26"/>
<vertex x="65.03" y="20.26"/>
<vertex x="65.17" y="20.26"/>
<vertex x="65.17" y="20.38"/>
<vertex x="65.17" y="20.5"/>
<vertex x="65.17" y="20.62"/>
<vertex x="65.17" y="20.75"/>
<vertex x="65.17" y="20.87"/>
<vertex x="65.17" y="20.99"/>
<vertex x="65.17" y="21.11"/>
<vertex x="65.17" y="21.23"/>
<vertex x="65.23" y="22.05"/>
<vertex x="65.43" y="22.79"/>
<vertex x="65.76" y="23.45"/>
<vertex x="66.22" y="24.01"/>
<vertex x="66.82" y="24.47"/>
<vertex x="67.55" y="24.81"/>
<vertex x="68.41" y="25.02"/>
<vertex x="68.53" y="25.04"/>
<vertex x="69.41" y="25.09"/>
<vertex x="69.64" y="25.09"/>
<vertex x="69.88" y="25.09"/>
<vertex x="70.11" y="25.09"/>
<vertex x="70.34" y="25.07"/>
<vertex x="70.57" y="25.04"/>
<vertex x="70.8" y="25.02"/>
<vertex x="71.03" y="25.02"/>
<vertex x="71.25" y="25.02"/>
<vertex x="71.25" y="24.69"/>
<vertex x="71.25" y="24.37"/>
<vertex x="71.25" y="24.04"/>
<vertex x="71.25" y="23.71"/>
<vertex x="71.25" y="23.39"/>
<vertex x="71.25" y="23.06"/>
<vertex x="71.25" y="22.74"/>
<vertex x="71.25" y="22.41"/>
<vertex x="71.1" y="22.44"/>
<vertex x="70.94" y="22.46"/>
<vertex x="70.78" y="22.46"/>
<vertex x="70.62" y="22.46"/>
<vertex x="70.45" y="22.46"/>
<vertex x="70.29" y="22.46"/>
<vertex x="70.14" y="22.46"/>
<vertex x="69.98" y="22.46"/>
<vertex x="69.65" y="22.44"/>
<vertex x="69.37" y="22.38"/>
<vertex x="69.14" y="22.28"/>
<vertex x="68.95" y="22.13"/>
<vertex x="68.82" y="21.93"/>
<vertex x="68.72" y="21.68"/>
<vertex x="68.67" y="21.38"/>
<vertex x="68.65" y="21.01"/>
<vertex x="68.65" y="20.91"/>
<vertex x="68.65" y="20.82"/>
<vertex x="68.65" y="20.73"/>
<vertex x="68.65" y="20.63"/>
<vertex x="68.65" y="20.54"/>
<vertex x="68.65" y="20.44"/>
<vertex x="68.65" y="20.35"/>
<vertex x="68.65" y="20.25"/>
<vertex x="68.95" y="20.25"/>
<vertex x="69.25" y="20.25"/>
<vertex x="69.55" y="20.25"/>
<vertex x="69.85" y="20.25"/>
<vertex x="70.15" y="20.25"/>
<vertex x="70.45" y="20.25"/>
<vertex x="70.75" y="20.25"/>
<vertex x="71.05" y="20.25"/>
<vertex x="71.05" y="19.96"/>
<vertex x="71.05" y="19.67"/>
<vertex x="71.05" y="19.38"/>
<vertex x="71.05" y="19.09"/>
<vertex x="71.05" y="18.8"/>
<vertex x="71.05" y="18.5"/>
<vertex x="71.05" y="18.21"/>
<vertex x="71.05" y="17.92"/>
<vertex x="70.75" y="17.92"/>
<vertex x="70.45" y="17.92"/>
<vertex x="70.15" y="17.92"/>
<vertex x="69.85" y="17.92"/>
<vertex x="69.55" y="17.92"/>
<vertex x="69.25" y="17.92"/>
<vertex x="68.95" y="17.92"/>
<vertex x="68.65" y="17.92"/>
<vertex x="68.65" y="16.63"/>
<vertex x="68.65" y="15.33"/>
<vertex x="68.65" y="14.03"/>
<vertex x="68.65" y="12.74"/>
<vertex x="68.65" y="11.44"/>
<vertex x="68.65" y="10.15"/>
<vertex x="68.65" y="8.85"/>
<vertex x="68.65" y="7.56"/>
<vertex x="68.21" y="7.56"/>
<vertex x="67.78" y="7.56"/>
<vertex x="67.34" y="7.56"/>
<vertex x="66.91" y="7.56"/>
<vertex x="66.47" y="7.56"/>
<vertex x="66.03" y="7.56"/>
<vertex x="65.6" y="7.56"/>
<vertex x="65.16" y="7.56"/>
<vertex x="65.16" y="8.85"/>
<vertex x="65.16" y="10.15"/>
<vertex x="65.16" y="11.44"/>
<vertex x="65.16" y="12.74"/>
<vertex x="65.16" y="14.03"/>
<vertex x="65.16" y="15.33"/>
<vertex x="65.16" y="16.63"/>
</polygon>
<vertex x="83.94" y="7.57"/>
<vertex x="83.53" y="7.57"/>
<vertex x="83.11" y="7.57"/>
<vertex x="82.7" y="7.57"/>
<vertex x="82.29" y="7.57"/>
<vertex x="81.87" y="7.57"/>
<vertex x="81.46" y="7.57"/>
<vertex x="81.04" y="7.57"/>
<vertex x="80.63" y="7.57"/>
<vertex x="80.63" y="7.79"/>
<vertex x="80.63" y="8.01"/>
<vertex x="80.63" y="8.23"/>
<vertex x="80.63" y="8.45"/>
<vertex x="80.63" y="8.67"/>
<vertex x="80.63" y="8.89"/>
<vertex x="80.63" y="9.11"/>
<vertex x="80.63" y="9.33"/>
<vertex x="80.62" y="9.33"/>
<vertex x="80.61" y="9.33"/>
<vertex x="80.6" y="9.33"/>
<vertex x="80.59" y="9.33"/>
<vertex x="80.23" y="8.82"/>
<vertex x="79.82" y="8.39"/>
<vertex x="79.36" y="8.03"/>
<vertex x="78.87" y="7.73"/>
<vertex x="78.35" y="7.51"/>
<vertex x="77.81" y="7.35"/>
<vertex x="77.26" y="7.25"/>
<vertex x="76.71" y="7.22"/>
<vertex x="76.54" y="7.22"/>
<vertex x="75.44" y="7.32"/>
<vertex x="75.3" y="7.34"/>
<vertex x="74.42" y="7.6"/>
<vertex x="73.61" y="8.05"/>
<vertex x="73" y="8.66"/>
<vertex x="72.56" y="9.41"/>
<vertex x="72.27" y="10.31"/>
<vertex x="72.25" y="10.43"/>
<vertex x="72.12" y="11.32"/>
<vertex x="72.1" y="11.46"/>
<vertex x="72.07" y="12.45"/>
<vertex x="72.07" y="13.42"/>
<vertex x="72.07" y="14.4"/>
<vertex x="72.07" y="15.38"/>
<vertex x="72.07" y="16.35"/>
<vertex x="72.07" y="17.33"/>
<vertex x="72.07" y="18.3"/>
<vertex x="72.07" y="19.28"/>
<vertex x="72.07" y="20.26"/>
<vertex x="72.5" y="20.26"/>
<vertex x="72.94" y="20.26"/>
<vertex x="73.38" y="20.26"/>
<vertex x="73.81" y="20.26"/>
<vertex x="74.25" y="20.26"/>
<vertex x="74.68" y="20.26"/>
<vertex x="75.12" y="20.26"/>
<vertex x="75.56" y="20.26"/>
<vertex x="75.56" y="19.36"/>
<vertex x="75.56" y="18.47"/>
<vertex x="75.56" y="17.57"/>
<vertex x="75.56" y="16.67"/>
<vertex x="75.56" y="15.78"/>
<vertex x="75.56" y="14.88"/>
<vertex x="75.56" y="13.98"/>
<vertex x="75.56" y="13.09"/>
<vertex x="75.59" y="12.36"/>
<vertex x="75.68" y="11.72"/>
<vertex x="75.83" y="11.18"/>
<vertex x="76.06" y="10.75"/>
<vertex x="76.36" y="10.41"/>
<vertex x="76.75" y="10.16"/>
<vertex x="77.22" y="10.02"/>
<vertex x="77.79" y="9.97"/>
<vertex x="78.45" y="10.02"/>
<vertex x="79.01" y="10.18"/>
<vertex x="79.48" y="10.44"/>
<vertex x="79.85" y="10.82"/>
<vertex x="80.14" y="11.32"/>
<vertex x="80.34" y="11.95"/>
<vertex x="80.45" y="12.71"/>
<vertex x="80.49" y="13.6"/>
<vertex x="80.49" y="14.44"/>
<vertex x="80.49" y="15.27"/>
<vertex x="80.49" y="16.1"/>
<vertex x="80.49" y="16.93"/>
<vertex x="80.49" y="17.76"/>
<vertex x="80.49" y="18.59"/>
<vertex x="80.49" y="19.43"/>
<vertex x="80.49" y="20.26"/>
<vertex x="80.93" y="20.26"/>
<vertex x="81.36" y="20.26"/>
<vertex x="81.8" y="20.26"/>
<vertex x="82.24" y="20.26"/>
<vertex x="82.67" y="20.26"/>
<vertex x="83.11" y="20.26"/>
<vertex x="83.54" y="20.26"/>
<vertex x="83.98" y="20.26"/>
<vertex x="83.98" y="18.67"/>
<vertex x="83.98" y="17.08"/>
<vertex x="83.98" y="15.5"/>
<vertex x="83.98" y="13.91"/>
<vertex x="83.98" y="12.32"/>
<vertex x="83.98" y="10.74"/>
<vertex x="83.98" y="9.15"/>
</polygon>
<vertex x="85.87" y="20.26"/>
<vertex x="86.28" y="20.26"/>
<vertex x="86.7" y="20.26"/>
<vertex x="87.11" y="20.26"/>
<vertex x="87.53" y="20.26"/>
<vertex x="87.94" y="20.26"/>
<vertex x="88.35" y="20.26"/>
<vertex x="88.77" y="20.26"/>
<vertex x="89.18" y="20.26"/>
<vertex x="89.18" y="20.04"/>
<vertex x="89.18" y="19.82"/>
<vertex x="89.18" y="19.6"/>
<vertex x="89.18" y="19.38"/>
<vertex x="89.18" y="19.16"/>
<vertex x="89.18" y="18.94"/>
<vertex x="89.18" y="18.72"/>
<vertex x="89.18" y="18.49"/>
<vertex x="89.19" y="18.49"/>
<vertex x="89.2" y="18.49"/>
<vertex x="89.21" y="18.49"/>
<vertex x="89.22" y="18.49"/>
<vertex x="89.58" y="19"/>
<vertex x="89.99" y="19.43"/>
<vertex x="90.45" y="19.8"/>
<vertex x="90.94" y="20.09"/>
<vertex x="91.46" y="20.32"/>
<vertex x="92" y="20.48"/>
<vertex x="92.55" y="20.57"/>
<vertex x="93.1" y="20.61"/>
<vertex x="93.27" y="20.6"/>
<vertex x="94.37" y="20.51"/>
<vertex x="94.51" y="20.48"/>
<vertex x="95.39" y="20.23"/>
<vertex x="96.2" y="19.78"/>
<vertex x="96.81" y="19.17"/>
<vertex x="97.25" y="18.41"/>
<vertex x="97.54" y="17.52"/>
<vertex x="97.56" y="17.4"/>
<vertex x="97.69" y="16.5"/>
<vertex x="97.71" y="16.37"/>
<vertex x="97.74" y="15.38"/>
<vertex x="97.74" y="14.4"/>
<vertex x="97.74" y="13.42"/>
<vertex x="97.74" y="12.45"/>
<vertex x="97.74" y="11.47"/>
<vertex x="97.74" y="10.5"/>
<vertex x="97.74" y="9.52"/>
<vertex x="97.74" y="8.54"/>
<vertex x="97.74" y="7.57"/>
<vertex x="97.31" y="7.57"/>
<vertex x="96.87" y="7.57"/>
<vertex x="96.43" y="7.57"/>
<vertex x="96" y="7.57"/>
<vertex x="95.56" y="7.57"/>
<vertex x="95.13" y="7.57"/>
<vertex x="94.69" y="7.57"/>
<vertex x="94.26" y="7.57"/>
<vertex x="94.26" y="8.46"/>
<vertex x="94.26" y="9.36"/>
<vertex x="94.26" y="10.26"/>
<vertex x="94.26" y="11.15"/>
<vertex x="94.26" y="12.05"/>
<vertex x="94.26" y="12.94"/>
<vertex x="94.26" y="13.84"/>
<vertex x="94.26" y="14.74"/>
<vertex x="94.22" y="15.47"/>
<vertex x="94.13" y="16.1"/>
<vertex x="93.98" y="16.64"/>
<vertex x="93.75" y="17.08"/>
<vertex x="93.45" y="17.42"/>
<vertex x="93.06" y="17.66"/>
<vertex x="92.59" y="17.81"/>
<vertex x="92.02" y="17.86"/>
<vertex x="91.36" y="17.8"/>
<vertex x="90.8" y="17.65"/>
<vertex x="90.33" y="17.38"/>
<vertex x="89.96" y="17"/>
<vertex x="89.68" y="16.5"/>
<vertex x="89.48" y="15.88"/>
<vertex x="89.36" y="15.12"/>
<vertex x="89.32" y="14.22"/>
<vertex x="89.32" y="13.39"/>
<vertex x="89.32" y="12.56"/>
<vertex x="89.32" y="11.73"/>
<vertex x="89.32" y="10.89"/>
<vertex x="89.32" y="10.06"/>
<vertex x="89.32" y="9.23"/>
<vertex x="89.32" y="8.4"/>
<vertex x="89.32" y="7.57"/>
<vertex x="88.88" y="7.57"/>
<vertex x="88.45" y="7.57"/>
<vertex x="88.01" y="7.57"/>
<vertex x="87.58" y="7.57"/>
<vertex x="87.14" y="7.57"/>
<vertex x="86.7" y="7.57"/>
<vertex x="86.27" y="7.57"/>
<vertex x="85.83" y="7.57"/>
<vertex x="85.83" y="9.15"/>
<vertex x="85.83" y="10.74"/>
<vertex x="85.83" y="12.33"/>
<vertex x="85.83" y="13.91"/>
<vertex x="85.83" y="15.5"/>
<vertex x="85.83" y="17.09"/>
<vertex x="85.83" y="18.67"/>
</polygon>
</package>
<package name="SFE_LOGO_NAME_1">
<vertex x="3.68" y="12.99"/>
<vertex x="3.75" y="12.41"/>
<vertex x="3.94" y="11.92"/>
<vertex x="4.23" y="11.51"/>
<vertex x="4.61" y="11.18"/>
<vertex x="5.06" y="10.93"/>
<vertex x="5.56" y="10.75"/>
<vertex x="6.1" y="10.65"/>
<vertex x="6.66" y="10.62"/>
<vertex x="7.08" y="10.64"/>
<vertex x="7.51" y="10.71"/>
<vertex x="7.94" y="10.83"/>
<vertex x="8.33" y="11.01"/>
<vertex x="8.68" y="11.26"/>
<vertex x="8.95" y="11.57"/>
<vertex x="9.13" y="11.96"/>
<vertex x="9.19" y="12.43"/>
<vertex x="9.12" y="12.83"/>
<vertex x="8.89" y="13.18"/>
<vertex x="8.53" y="13.48"/>
<vertex x="8.03" y="13.74"/>
<vertex x="7.4" y="13.98"/>
<vertex x="6.65" y="14.19"/>
<vertex x="5.78" y="14.4"/>
<vertex x="5.66" y="14.43"/>
<vertex x="4.8" y="14.61"/>
<vertex x="3.96" y="14.82"/>
<vertex x="3.15" y="15.06"/>
<vertex x="2.39" y="15.37"/>
<vertex x="1.72" y="15.75"/>
<vertex x="1.15" y="16.22"/>
<vertex x="0.71" y="16.8"/>
<vertex x="0.43" y="17.51"/>
<vertex x="0.33" y="18.37"/>
<vertex x="0.33" y="18.54"/>
<vertex x="0.47" y="19.6"/>
<vertex x="0.5" y="19.74"/>
<vertex x="0.86" y="20.6"/>
<vertex x="0.93" y="20.71"/>
<vertex x="1.47" y="21.39"/>
<vertex x="2.26" y="21.99"/>
<vertex x="2.37" y="22.05"/>
<vertex x="3.19" y="22.42"/>
<vertex x="3.32" y="22.46"/>
<vertex x="4.23" y="22.7"/>
<vertex x="4.36" y="22.73"/>
<vertex x="5.33" y="22.86"/>
<vertex x="5.47" y="22.87"/>
<vertex x="6.46" y="22.91"/>
<vertex x="6.61" y="22.91"/>
<vertex x="7.6" y="22.85"/>
<vertex x="7.74" y="22.84"/>
<vertex x="8.68" y="22.69"/>
<vertex x="8.81" y="22.66"/>
<vertex x="9.7" y="22.4"/>
<vertex x="9.82" y="22.35"/>
<vertex x="10.61" y="21.96"/>
<vertex x="11.39" y="21.35"/>
<vertex x="11.48" y="21.27"/>
<vertex x="12.02" y="20.57"/>
<vertex x="12.08" y="20.46"/>
<vertex x="12.46" y="19.59"/>
<vertex x="12.5" y="19.46"/>
<vertex x="12.69" y="18.41"/>
<vertex x="12.23" y="18.41"/>
<vertex x="11.77" y="18.41"/>
<vertex x="11.31" y="18.41"/>
<vertex x="10.85" y="18.41"/>
<vertex x="10.39" y="18.41"/>
<vertex x="9.93" y="18.41"/>
<vertex x="9.47" y="18.41"/>
<vertex x="9" y="18.41"/>
<vertex x="8.92" y="18.92"/>
<vertex x="8.74" y="19.34"/>
<vertex x="8.48" y="19.67"/>
<vertex x="8.16" y="19.92"/>
<vertex x="7.78" y="20.11"/>
<vertex x="7.34" y="20.23"/>
<vertex x="6.86" y="20.3"/>
<vertex x="6.36" y="20.32"/>
<vertex x="6.01" y="20.32"/>
<vertex x="5.65" y="20.29"/>
<vertex x="5.29" y="20.23"/>
<vertex x="4.95" y="20.12"/>
<vertex x="4.65" y="19.95"/>
<vertex x="4.41" y="19.72"/>
<vertex x="4.26" y="19.41"/>
<vertex x="4.2" y="19.02"/>
<vertex x="4.3" y="18.55"/>
<vertex x="4.58" y="18.18"/>
<vertex x="5.01" y="17.88"/>
<vertex x="5.58" y="17.65"/>
<vertex x="6.24" y="17.45"/>
<vertex x="6.99" y="17.27"/>
<vertex x="7.78" y="17.11"/>
<vertex x="8.59" y="16.93"/>
<vertex x="9.44" y="16.71"/>
<vertex x="10.25" y="16.46"/>
<vertex x="11" y="16.14"/>
<vertex x="11.68" y="15.73"/>
<vertex x="12.25" y="15.23"/>
<vertex x="12.69" y="14.62"/>
<vertex x="12.97" y="13.87"/>
<vertex x="13.07" y="12.97"/>
<vertex x="13.06" y="12.8"/>
<vertex x="12.92" y="11.69"/>
<vertex x="12.88" y="11.55"/>
<vertex x="12.51" y="10.64"/>
<vertex x="12.44" y="10.52"/>
<vertex x="11.87" y="9.79"/>
<vertex x="11.78" y="9.69"/>
<vertex x="11.04" y="9.12"/>
<vertex x="10.93" y="9.05"/>
<vertex x="10.07" y="8.63"/>
<vertex x="9.94" y="8.59"/>
<vertex x="8.98" y="8.3"/>
<vertex x="8.84" y="8.27"/>
<vertex x="7.82" y="8.12"/>
<vertex x="7.67" y="8.11"/>
<vertex x="6.63" y="8.06"/>
<vertex x="6.47" y="8.06"/>
<vertex x="5.41" y="8.12"/>
<vertex x="5.26" y="8.14"/>
<vertex x="4.23" y="8.31"/>
<vertex x="4.09" y="8.34"/>
<vertex x="3.13" y="8.64"/>
<vertex x="3" y="8.7"/>
<vertex x="2.14" y="9.14"/>
<vertex x="2.02" y="9.21"/>
<vertex x="1.29" y="9.81"/>
<vertex x="1.2" y="9.91"/>
<vertex x="0.63" y="10.67"/>
<vertex x="0.56" y="10.79"/>
<vertex x="0.19" y="11.74"/>
<vertex x="0.15" y="11.87"/>
<vertex x="0" y="12.99"/>
<vertex x="0.46" y="12.99"/>
<vertex x="0.92" y="12.99"/>
<vertex x="1.38" y="12.99"/>
<vertex x="1.84" y="12.99"/>
<vertex x="2.3" y="12.99"/>
<vertex x="2.76" y="12.99"/>
<vertex x="3.22" y="12.99"/>
</polygon>
<vertex x="24.7" y="13"/>
<vertex x="24.92" y="13.75"/>
<vertex x="25.05" y="14.57"/>
<vertex x="25.09" y="15.42"/>
<vertex x="28.96" y="15.31"/>
<vertex x="28.96" y="15.13"/>
<vertex x="28.87" y="13.91"/>
<vertex x="28.84" y="13.74"/>
<vertex x="28.58" y="12.58"/>
<vertex x="28.53" y="12.42"/>
<vertex x="28.1" y="11.35"/>
</polygon>
<vertex x="28.02" y="11.2"/>
<vertex x="27.42" y="10.26"/>
<vertex x="27.32" y="10.13"/>
<vertex x="26.55" y="9.34"/>
<vertex x="26.43" y="9.24"/>
<vertex x="25.49" y="8.63"/>
<vertex x="25.34" y="8.56"/>
<vertex x="24.23" y="8.18"/>
<vertex x="24.06" y="8.15"/>
<vertex x="22.77" y="8.03"/>
<vertex x="22.14" y="8.06"/>
<vertex x="21.52" y="8.16"/>
<vertex x="20.93" y="8.33"/>
<vertex x="20.37" y="8.57"/>
<vertex x="19.85" y="8.87"/>
<vertex x="19.37" y="9.24"/>
<vertex x="18.93" y="9.66"/>
<vertex x="18.54" y="10.15"/>
<vertex x="18.53" y="10.15"/>
<vertex x="18.52" y="10.15"/>
<vertex x="18.52" y="8.89"/>
<vertex x="18.52" y="7.62"/>
<vertex x="18.52" y="6.35"/>
<vertex x="18.52" y="5.08"/>
<vertex x="18.52" y="3.81"/>
<vertex x="18.52" y="2.54"/>
<vertex x="18.52" y="1.27"/>
<vertex x="18.52" y="0"/>
<vertex x="18.04" y="0.43"/>
<vertex x="17.55" y="0.86"/>
<vertex x="17.07" y="1.29"/>
<vertex x="16.59" y="1.72"/>
<vertex x="16.1" y="2.15"/>
<vertex x="15.62" y="2.59"/>
<vertex x="15.13" y="3.02"/>
<vertex x="14.65" y="3.45"/>
<vertex x="14.65" y="5.75"/>
<vertex x="14.65" y="8.05"/>
<vertex x="14.65" y="10.35"/>
<vertex x="14.65" y="12.65"/>
<vertex x="14.65" y="14.95"/>
<vertex x="14.65" y="17.26"/>
<vertex x="14.65" y="19.56"/>
<vertex x="14.65" y="21.86"/>
<vertex x="15.11" y="21.94"/>
<vertex x="15.57" y="22.02"/>
<vertex x="16.03" y="22.1"/>
<vertex x="16.49" y="22.18"/>
<vertex x="16.95" y="22.27"/>
<vertex x="17.41" y="22.35"/>
<vertex x="17.87" y="22.43"/>
<vertex x="18.33" y="22.51"/>
<vertex x="18.33" y="22.29"/>
<vertex x="18.33" y="22.06"/>
<vertex x="18.33" y="21.84"/>
<vertex x="18.33" y="21.61"/>
<vertex x="18.33" y="21.38"/>
<vertex x="18.33" y="21.16"/>
<vertex x="18.33" y="20.93"/>
<vertex x="18.33" y="20.71"/>
<vertex x="18.34" y="20.71"/>
<vertex x="18.35" y="20.71"/>
<vertex x="18.36" y="20.71"/>
<vertex x="18.74" y="21.24"/>
<vertex x="19.17" y="21.69"/>
<vertex x="19.64" y="22.07"/>
<vertex x="20.16" y="22.37"/>
<vertex x="20.71" y="22.6"/>
<vertex x="21.3" y="22.76"/>
<vertex x="21.91" y="22.86"/>
<vertex x="22.56" y="22.89"/>
<vertex x="22.76" y="22.89"/>
<vertex x="24.1" y="22.73"/>
<vertex x="24.28" y="22.69"/>
<vertex x="25.42" y="22.27"/>
<vertex x="25.57" y="22.19"/>
<vertex x="26.53" y="21.55"/>
<vertex x="26.65" y="21.44"/>
<vertex x="27.42" y="20.6"/>
<vertex x="27.52" y="20.47"/>
<vertex x="28.1" y="19.47"/>
<vertex x="28.18" y="19.32"/>
<vertex x="28.59" y="18.18"/>
<vertex x="28.63" y="18.02"/>
<vertex x="28.87" y="16.79"/>
<vertex x="28.9" y="16.6"/>
<vertex x="28.97" y="15.31"/>
<vertex x="25.09" y="15.41"/>
<vertex x="25.05" y="16.26"/>
<vertex x="24.91" y="17.08"/>
<vertex x="24.67" y="17.85"/>
<vertex x="24.33" y="18.54"/>
<vertex x="23.87" y="19.12"/>
<vertex x="23.28" y="19.57"/>
<vertex x="22.57" y="19.87"/>
<vertex x="21.71" y="19.97"/>
<vertex x="20.84" y="19.87"/>
<vertex x="20.11" y="19.58"/>
<vertex x="19.53" y="19.13"/>
<vertex x="19.08" y="18.55"/>
<vertex x="18.75" y="17.86"/>
<vertex x="18.52" y="17.09"/>
<vertex x="18.39" y="16.27"/>
<vertex x="18.35" y="15.42"/>
<vertex x="18.4" y="14.57"/>
<vertex x="18.53" y="13.75"/>
<vertex x="18.76" y="12.99"/>
<vertex x="19.1" y="12.32"/>
<vertex x="19.56" y="11.75"/>
<vertex x="20.15" y="11.32"/>
<vertex x="20.87" y="11.04"/>
<vertex x="21.74" y="10.94"/>
<vertex x="22.61" y="11.04"/>
<vertex x="23.33" y="11.32"/>
<vertex x="23.91" y="11.75"/>
<vertex x="24.37" y="12.32"/>
<vertex x="24.7" y="12.99"/>
</polygon>
<vertex x="34.86" y="16.5"/>
<vertex x="35.74" y="16.61"/>
<vertex x="36.58" y="16.71"/>
<vertex x="37.37" y="16.82"/>
<vertex x="37.84" y="14.73"/>
<vertex x="37.62" y="14.7"/>
<vertex x="37.39" y="14.66"/>
<vertex x="37.16" y="14.63"/>
<vertex x="36.93" y="14.59"/>
<vertex x="36.7" y="14.56"/>
<vertex x="36.47" y="14.53"/>
<vertex x="36.24" y="14.49"/>
<vertex x="36.02" y="14.44"/>
<vertex x="35.8" y="14.4"/>
<vertex x="35.59" y="14.34"/>
</polygon>
<vertex x="35.59" y="14.33"/>
<vertex x="35.38" y="14.27"/>
<vertex x="35.18" y="14.19"/>
<vertex x="34.99" y="14.1"/>
<vertex x="34.81" y="14"/>
<vertex x="34.65" y="13.89"/>
<vertex x="34.5" y="13.77"/>
<vertex x="34.36" y="13.63"/>
<vertex x="34.24" y="13.47"/>
<vertex x="34.14" y="13.3"/>
<vertex x="34.06" y="13.11"/>
<vertex x="34" y="12.89"/>
<vertex x="33.96" y="12.66"/>
<vertex x="33.95" y="12.41"/>
<vertex x="33.96" y="12.15"/>
<vertex x="34" y="11.92"/>
<vertex x="34.06" y="11.71"/>
<vertex x="34.14" y="11.53"/>
<vertex x="34.25" y="11.36"/>
<vertex x="34.37" y="11.21"/>
<vertex x="34.51" y="11.08"/>
<vertex x="34.67" y="10.97"/>
<vertex x="34.84" y="10.88"/>
<vertex x="35.02" y="10.8"/>
<vertex x="35.22" y="10.74"/>
<vertex x="35.42" y="10.69"/>
<vertex x="35.64" y="10.65"/>
<vertex x="35.86" y="10.62"/>
<vertex x="36.09" y="10.62"/>
<vertex x="36.33" y="10.62"/>
<vertex x="36.86" y="10.65"/>
<vertex x="37.33" y="10.73"/>
<vertex x="37.74" y="10.85"/>
<vertex x="38.09" y="11.01"/>
<vertex x="38.39" y="11.2"/>
<vertex x="38.65" y="11.42"/>
<vertex x="38.86" y="11.66"/>
<vertex x="39.03" y="11.92"/>
<vertex x="39.16" y="12.19"/>
<vertex x="39.27" y="12.46"/>
<vertex x="39.34" y="12.73"/>
<vertex x="39.4" y="13"/>
<vertex x="39.43" y="13.25"/>
<vertex x="39.45" y="13.48"/>
<vertex x="39.46" y="13.69"/>
<vertex x="39.46" y="13.87"/>
<vertex x="39.46" y="13.96"/>
<vertex x="39.46" y="14.05"/>
<vertex x="39.46" y="14.14"/>
<vertex x="39.46" y="14.23"/>
<vertex x="39.46" y="14.32"/>
<vertex x="39.46" y="14.41"/>
<vertex x="39.46" y="14.5"/>
<vertex x="39.46" y="14.59"/>
<vertex x="39.46" y="14.68"/>
<vertex x="39.46" y="14.77"/>
<vertex x="39.46" y="14.86"/>
<vertex x="39.46" y="14.95"/>
<vertex x="39.46" y="15.04"/>
<vertex x="39.46" y="15.13"/>
<vertex x="39.46" y="15.22"/>
<vertex x="39.46" y="15.31"/>
<vertex x="39.33" y="15.21"/>
<vertex x="39.18" y="15.12"/>
<vertex x="39.02" y="15.04"/>
<vertex x="38.85" y="14.97"/>
<vertex x="38.66" y="14.91"/>
<vertex x="38.47" y="14.85"/>
<vertex x="38.27" y="14.81"/>
<vertex x="38.06" y="14.76"/>
<vertex x="37.84" y="14.74"/>
<vertex x="38.07" y="16.99"/>
<vertex x="38.66" y="17.19"/>
<vertex x="39.11" y="17.48"/>
<vertex x="39.38" y="17.87"/>
<vertex x="39.46" y="18.39"/>
<vertex x="39.45" y="18.68"/>
<vertex x="39.41" y="18.94"/>
<vertex x="39.35" y="19.17"/>
<vertex x="39.27" y="19.38"/>
<vertex x="39.16" y="19.56"/>
<vertex x="39.03" y="19.71"/>
<vertex x="38.88" y="19.85"/>
<vertex x="38.72" y="19.96"/>
<vertex x="38.54" y="20.05"/>
<vertex x="38.35" y="20.13"/>
<vertex x="38.14" y="20.19"/>
<vertex x="37.92" y="20.23"/>
<vertex x="37.69" y="20.26"/>
<vertex x="37.46" y="20.29"/>
<vertex x="37.21" y="20.29"/>
<vertex x="36.96" y="20.29"/>
<vertex x="36.68" y="20.29"/>
<vertex x="36.42" y="20.26"/>
<vertex x="36.17" y="20.22"/>
<vertex x="35.94" y="20.17"/>
<vertex x="35.72" y="20.1"/>
<vertex x="35.52" y="20.01"/>
<vertex x="35.33" y="19.91"/>
<vertex x="35.16" y="19.8"/>
<vertex x="35.01" y="19.66"/>
<vertex x="34.87" y="19.5"/>
<vertex x="34.74" y="19.33"/>
<vertex x="34.64" y="19.13"/>
<vertex x="34.55" y="18.92"/>
<vertex x="34.48" y="18.68"/>
<vertex x="34.43" y="18.43"/>
<vertex x="34.39" y="18.16"/>
<vertex x="34.15" y="18.16"/>
<vertex x="33.91" y="18.16"/>
<vertex x="33.67" y="18.16"/>
<vertex x="33.42" y="18.16"/>
<vertex x="33.18" y="18.16"/>
<vertex x="32.94" y="18.16"/>
<vertex x="32.7" y="18.16"/>
<vertex x="32.46" y="18.16"/>
<vertex x="32.22" y="18.16"/>
<vertex x="31.97" y="18.16"/>
<vertex x="31.73" y="18.16"/>
<vertex x="31.49" y="18.16"/>
<vertex x="31.25" y="18.16"/>
<vertex x="31.01" y="18.16"/>
<vertex x="30.76" y="18.16"/>
<vertex x="30.52" y="18.16"/>
<vertex x="30.6" y="18.8"/>
<vertex x="30.74" y="19.39"/>
<vertex x="30.94" y="19.93"/>
<vertex x="31.21" y="20.41"/>
<vertex x="31.52" y="20.85"/>
<vertex x="31.88" y="21.23"/>
<vertex x="32.29" y="21.57"/>
<vertex x="32.73" y="21.86"/>
<vertex x="33.21" y="22.12"/>
<vertex x="33.72" y="22.33"/>
<vertex x="34.26" y="22.5"/>
<vertex x="34.81" y="22.64"/>
<vertex x="35.38" y="22.75"/>
<vertex x="35.97" y="22.82"/>
<vertex x="36.56" y="22.86"/>
<vertex x="37.15" y="22.86"/>
<vertex x="37.69" y="22.86"/>
<vertex x="38.23" y="22.83"/>
<vertex x="38.77" y="22.78"/>
<vertex x="39.31" y="22.71"/>
<vertex x="39.83" y="22.61"/>
<vertex x="40.35" y="22.49"/>
<vertex x="40.84" y="22.33"/>
<vertex x="41.3" y="22.13"/>
<vertex x="41.74" y="21.89"/>
<vertex x="42.13" y="21.61"/>
<vertex x="42.48" y="21.29"/>
<vertex x="42.77" y="20.91"/>
<vertex x="43.02" y="20.48"/>
<vertex x="43.2" y="20"/>
<vertex x="43.31" y="19.46"/>
<vertex x="43.35" y="18.86"/>
<vertex x="43.35" y="18.4"/>
<vertex x="43.35" y="17.94"/>
<vertex x="43.35" y="17.48"/>
<vertex x="43.35" y="17.02"/>
<vertex x="43.35" y="16.56"/>
<vertex x="43.35" y="16.11"/>
<vertex x="43.35" y="15.65"/>
<vertex x="43.35" y="15.19"/>
<vertex x="43.35" y="14.73"/>
<vertex x="43.35" y="14.27"/>
<vertex x="43.35" y="13.81"/>
<vertex x="43.35" y="13.35"/>
<vertex x="43.35" y="12.89"/>
<vertex x="43.35" y="12.44"/>
<vertex x="43.35" y="11.98"/>
<vertex x="43.35" y="11.52"/>
<vertex x="43.35" y="11.28"/>
<vertex x="43.35" y="11.04"/>
<vertex x="43.36" y="10.8"/>
<vertex x="43.36" y="10.57"/>
<vertex x="43.37" y="10.34"/>
<vertex x="43.39" y="10.11"/>
<vertex x="43.42" y="9.9"/>
<vertex x="43.45" y="9.68"/>
<vertex x="43.49" y="9.48"/>
<vertex x="43.52" y="9.29"/>
<vertex x="43.56" y="9.1"/>
<vertex x="43.61" y="8.93"/>
<vertex x="43.65" y="8.77"/>
<vertex x="43.71" y="8.63"/>
<vertex x="43.77" y="8.5"/>
<vertex x="43.83" y="8.38"/>
<vertex x="43.58" y="8.38"/>
<vertex x="43.34" y="8.38"/>
<vertex x="43.09" y="8.38"/>
<vertex x="42.85" y="8.38"/>
<vertex x="42.6" y="8.38"/>
<vertex x="42.36" y="8.38"/>
<vertex x="42.11" y="8.38"/>
<vertex x="41.87" y="8.38"/>
<vertex x="41.62" y="8.38"/>
<vertex x="41.38" y="8.38"/>
<vertex x="41.13" y="8.38"/>
<vertex x="40.89" y="8.38"/>
<vertex x="40.64" y="8.38"/>
<vertex x="40.4" y="8.38"/>
<vertex x="40.15" y="8.38"/>
<vertex x="39.91" y="8.38"/>
<vertex x="39.88" y="8.46"/>
<vertex x="39.85" y="8.55"/>
<vertex x="39.82" y="8.63"/>
<vertex x="39.79" y="8.71"/>
<vertex x="39.76" y="8.8"/>
<vertex x="39.74" y="8.88"/>
<vertex x="39.72" y="8.97"/>
<vertex x="39.7" y="9.05"/>
<vertex x="39.68" y="9.14"/>
<vertex x="39.67" y="9.23"/>
<vertex x="39.66" y="9.32"/>
<vertex x="39.65" y="9.4"/>
<vertex x="39.65" y="9.49"/>
<vertex x="39.64" y="9.58"/>
<vertex x="39.64" y="9.66"/>
<vertex x="39.63" y="9.75"/>
<vertex x="39.4" y="9.52"/>
<vertex x="39.15" y="9.31"/>
<vertex x="38.89" y="9.12"/>
<vertex x="38.62" y="8.94"/>
<vertex x="38.34" y="8.78"/>
<vertex x="38.06" y="8.64"/>
<vertex x="37.76" y="8.51"/>
<vertex x="37.46" y="8.4"/>
<vertex x="37.15" y="8.3"/>
<vertex x="36.84" y="8.22"/>
<vertex x="36.52" y="8.15"/>
<vertex x="36.2" y="8.1"/>
<vertex x="35.87" y="8.06"/>
<vertex x="35.54" y="8.02"/>
<vertex x="35.22" y="8"/>
<vertex x="34.89" y="8"/>
<vertex x="34.39" y="8"/>
<vertex x="33.91" y="8.04"/>
<vertex x="33.44" y="8.12"/>
<vertex x="33" y="8.24"/>
<vertex x="32.58" y="8.38"/>
<vertex x="32.18" y="8.56"/>
<vertex x="31.82" y="8.77"/>
<vertex x="31.48" y="9.01"/>
<vertex x="31.17" y="9.29"/>
<vertex x="30.9" y="9.6"/>
<vertex x="30.66" y="9.95"/>
<vertex x="30.46" y="10.33"/>
<vertex x="30.3" y="10.75"/>
<vertex x="30.19" y="11.2"/>
<vertex x="30.12" y="11.69"/>
<vertex x="30.09" y="12.21"/>
<vertex x="30.09" y="12.36"/>
<vertex x="30.2" y="13.3"/>
<vertex x="30.51" y="14.19"/>
<vertex x="30.98" y="14.89"/>
<vertex x="31.6" y="15.43"/>
<vertex x="32.32" y="15.84"/>
<vertex x="33.12" y="16.14"/>
<vertex x="33.98" y="16.35"/>
</polygon>
<vertex x="45.53" y="21.85"/>
<vertex x="45.99" y="21.94"/>
<vertex x="46.45" y="22.02"/>
<vertex x="46.91" y="22.1"/>
<vertex x="47.37" y="22.18"/>
<vertex x="47.83" y="22.26"/>
<vertex x="48.29" y="22.34"/>
<vertex x="48.75" y="22.43"/>
<vertex x="49.21" y="22.51"/>
<vertex x="49.21" y="22.18"/>
<vertex x="49.21" y="21.85"/>
<vertex x="49.21" y="21.52"/>
<vertex x="49.21" y="21.2"/>
<vertex x="49.21" y="20.87"/>
<vertex x="49.21" y="20.54"/>
<vertex x="49.21" y="20.21"/>
<vertex x="49.21" y="19.89"/>
<vertex x="49.22" y="19.89"/>
<vertex x="49.23" y="19.89"/>
<vertex x="49.24" y="19.89"/>
<vertex x="49.56" y="20.52"/>
<vertex x="49.98" y="21.1"/>
<vertex x="50.47" y="21.61"/>
<vertex x="51.04" y="22.05"/>
<vertex x="51.66" y="22.41"/>
<vertex x="52.32" y="22.67"/>
<vertex x="53.02" y="22.83"/>
<vertex x="53.74" y="22.89"/>
<vertex x="53.85" y="22.89"/>
<vertex x="53.96" y="22.89"/>
<vertex x="54.07" y="22.89"/>
<vertex x="54.17" y="22.89"/>
<vertex x="54.28" y="22.86"/>
<vertex x="54.38" y="22.83"/>
<vertex x="54.48" y="22.8"/>
<vertex x="54.59" y="22.77"/>
<vertex x="54.59" y="22.32"/>
<vertex x="54.59" y="21.87"/>
<vertex x="54.59" y="21.42"/>
<vertex x="54.59" y="20.97"/>
<vertex x="54.59" y="20.52"/>
<vertex x="54.59" y="20.07"/>
<vertex x="54.59" y="19.62"/>
<vertex x="54.59" y="19.17"/>
<vertex x="54.44" y="19.2"/>
<vertex x="54.28" y="19.23"/>
<vertex x="54.11" y="19.26"/>
<vertex x="53.93" y="19.29"/>
<vertex x="53.74" y="19.29"/>
<vertex x="53.56" y="19.29"/>
<vertex x="53.37" y="19.29"/>
<vertex x="53.19" y="19.29"/>
<vertex x="52.21" y="19.2"/>
<vertex x="51.39" y="18.93"/>
<vertex x="50.73" y="18.52"/>
<vertex x="50.21" y="17.97"/>
<vertex x="49.83" y="17.3"/>
<vertex x="49.57" y="16.53"/>
<vertex x="49.42" y="15.68"/>
<vertex x="49.37" y="14.76"/>
<vertex x="49.37" y="13.97"/>
<vertex x="49.37" y="13.17"/>
<vertex x="49.37" y="12.38"/>
<vertex x="49.37" y="11.58"/>
<vertex x="49.37" y="10.79"/>
<vertex x="49.37" y="9.99"/>
<vertex x="49.37" y="9.2"/>
<vertex x="49.37" y="8.41"/>
<vertex x="48.89" y="8.41"/>
<vertex x="48.4" y="8.41"/>
<vertex x="47.92" y="8.41"/>
<vertex x="47.44" y="8.41"/>
<vertex x="46.95" y="8.41"/>
<vertex x="46.47" y="8.41"/>
<vertex x="45.98" y="8.41"/>
<vertex x="45.5" y="8.41"/>
<vertex x="45.5" y="10.09"/>
<vertex x="45.5" y="11.77"/>
<vertex x="45.5" y="13.45"/>
<vertex x="45.5" y="15.13"/>
<vertex x="45.5" y="16.81"/>
<vertex x="45.5" y="18.49"/>
<vertex x="45.5" y="20.17"/>
</polygon>
<vertex x="56.11" y="25.76"/>
<vertex x="59.99" y="27.88"/>
<vertex x="59.99" y="17.43"/>
<vertex x="64.87" y="22.51"/>
<vertex x="69.45" y="22.51"/>
<vertex x="64.13" y="17.32"/>
<vertex x="70.05" y="8.41"/>
<vertex x="65.36" y="8.41"/>
<vertex x="61.49" y="14.71"/>
<vertex x="59.99" y="13.26"/>
<vertex x="59.99" y="8.41"/>
<vertex x="56.11" y="8.41"/>
</polygon>
<vertex x="72.41" y="19.92"/>
<vertex x="71.93" y="19.92"/>
<vertex x="71.45" y="19.92"/>
<vertex x="70.97" y="19.92"/>
<vertex x="70.5" y="19.92"/>
<vertex x="70.02" y="19.92"/>
<vertex x="69.54" y="19.92"/>
<vertex x="69.06" y="19.92"/>
<vertex x="68.59" y="19.92"/>
<vertex x="68.92" y="20.24"/>
<vertex x="69.25" y="20.57"/>
<vertex x="69.58" y="20.89"/>
<vertex x="69.91" y="21.22"/>
<vertex x="70.24" y="21.54"/>
<vertex x="70.57" y="21.86"/>
<vertex x="70.9" y="22.19"/>
<vertex x="71.23" y="22.51"/>
<vertex x="71.37" y="22.51"/>
<vertex x="71.52" y="22.51"/>
<vertex x="71.67" y="22.51"/>
<vertex x="71.82" y="22.51"/>
<vertex x="71.96" y="22.51"/>
<vertex x="72.11" y="22.51"/>
<vertex x="72.26" y="22.51"/>
<vertex x="72.41" y="22.51"/>
<vertex x="72.41" y="22.65"/>
<vertex x="72.41" y="22.78"/>
<vertex x="72.41" y="22.92"/>
<vertex x="72.41" y="23.05"/>
<vertex x="72.41" y="23.19"/>
<vertex x="72.41" y="23.32"/>
<vertex x="72.41" y="23.46"/>
<vertex x="72.41" y="23.59"/>
<vertex x="72.48" y="24.5"/>
<vertex x="72.7" y="25.32"/>
<vertex x="73.06" y="26.05"/>
<vertex x="73.58" y="26.68"/>
<vertex x="74.24" y="27.18"/>
<vertex x="75.05" y="27.56"/>
<vertex x="76.01" y="27.8"/>
<vertex x="76.14" y="27.82"/>
<vertex x="77.13" y="27.88"/>
<vertex x="77.38" y="27.88"/>
<vertex x="77.64" y="27.88"/>
<vertex x="77.9" y="27.88"/>
<vertex x="78.16" y="27.85"/>
<vertex x="78.42" y="27.82"/>
<vertex x="78.67" y="27.8"/>
<vertex x="78.92" y="27.8"/>
<vertex x="79.17" y="27.8"/>
<vertex x="79.17" y="27.43"/>
<vertex x="79.17" y="27.07"/>
<vertex x="79.17" y="26.71"/>
<vertex x="79.17" y="26.35"/>
<vertex x="79.17" y="25.99"/>
<vertex x="79.17" y="25.63"/>
<vertex x="79.17" y="25.27"/>
<vertex x="79.17" y="24.9"/>
<vertex x="79" y="24.93"/>
<vertex x="78.82" y="24.96"/>
<vertex x="78.64" y="24.96"/>
<vertex x="78.46" y="24.96"/>
<vertex x="78.28" y="24.96"/>
<vertex x="78.1" y="24.96"/>
<vertex x="77.93" y="24.96"/>
<vertex x="77.75" y="24.96"/>
<vertex x="77.38" y="24.93"/>
<vertex x="77.07" y="24.87"/>
<vertex x="76.82" y="24.75"/>
<vertex x="76.62" y="24.59"/>
<vertex x="76.46" y="24.37"/>
<vertex x="76.36" y="24.09"/>
<vertex x="76.3" y="23.75"/>
<vertex x="76.28" y="23.35"/>
<vertex x="76.28" y="23.24"/>
<vertex x="76.28" y="23.13"/>
<vertex x="76.28" y="23.03"/>
<vertex x="76.28" y="22.92"/>
<vertex x="76.28" y="22.82"/>
<vertex x="76.28" y="22.71"/>
<vertex x="76.28" y="22.61"/>
<vertex x="76.28" y="22.5"/>
<vertex x="76.61" y="22.5"/>
<vertex x="76.94" y="22.5"/>
<vertex x="77.28" y="22.5"/>
<vertex x="77.61" y="22.5"/>
<vertex x="77.95" y="22.5"/>
<vertex x="78.28" y="22.5"/>
<vertex x="78.61" y="22.5"/>
<vertex x="78.95" y="22.5"/>
<vertex x="78.95" y="22.18"/>
<vertex x="78.95" y="21.86"/>
<vertex x="78.95" y="21.53"/>
<vertex x="78.95" y="21.21"/>
<vertex x="78.95" y="20.88"/>
<vertex x="78.95" y="20.56"/>
<vertex x="78.95" y="20.24"/>
<vertex x="78.95" y="19.91"/>
<vertex x="78.61" y="19.91"/>
<vertex x="78.28" y="19.91"/>
<vertex x="77.95" y="19.91"/>
<vertex x="77.61" y="19.91"/>
<vertex x="77.28" y="19.91"/>
<vertex x="76.94" y="19.91"/>
<vertex x="76.61" y="19.91"/>
<vertex x="76.28" y="19.91"/>
<vertex x="76.28" y="18.47"/>
<vertex x="76.28" y="17.03"/>
<vertex x="76.28" y="15.59"/>
<vertex x="76.28" y="14.16"/>
<vertex x="76.28" y="12.72"/>
<vertex x="76.28" y="11.28"/>
<vertex x="76.28" y="9.84"/>
<vertex x="76.28" y="8.4"/>
<vertex x="75.79" y="8.4"/>
<vertex x="75.31" y="8.4"/>
<vertex x="74.82" y="8.4"/>
<vertex x="74.34" y="8.4"/>
<vertex x="73.86" y="8.4"/>
<vertex x="73.37" y="8.4"/>
<vertex x="72.89" y="8.4"/>
<vertex x="72.4" y="8.4"/>
<vertex x="72.4" y="9.84"/>
<vertex x="72.4" y="11.28"/>
<vertex x="72.4" y="12.72"/>
<vertex x="72.4" y="14.15"/>
<vertex x="72.4" y="15.59"/>
<vertex x="72.4" y="17.03"/>
<vertex x="72.4" y="18.47"/>
</polygon>
<vertex x="93.27" y="8.41"/>
<vertex x="92.81" y="8.41"/>
<vertex x="92.35" y="8.41"/>
<vertex x="91.89" y="8.41"/>
<vertex x="91.43" y="8.41"/>
<vertex x="90.97" y="8.41"/>
<vertex x="90.51" y="8.41"/>
<vertex x="90.05" y="8.41"/>
<vertex x="89.59" y="8.41"/>
<vertex x="89.59" y="8.65"/>
<vertex x="89.59" y="8.9"/>
<vertex x="89.59" y="9.14"/>
<vertex x="89.59" y="9.39"/>
<vertex x="89.59" y="9.63"/>
<vertex x="89.59" y="9.88"/>
<vertex x="89.59" y="10.12"/>
<vertex x="89.59" y="10.37"/>
<vertex x="89.58" y="10.37"/>
<vertex x="89.57" y="10.37"/>
<vertex x="89.56" y="10.37"/>
<vertex x="89.55" y="10.37"/>
<vertex x="89.54" y="10.37"/>
<vertex x="89.14" y="9.81"/>
<vertex x="88.68" y="9.32"/>
<vertex x="88.18" y="8.92"/>
<vertex x="87.63" y="8.59"/>
<vertex x="87.06" y="8.34"/>
<vertex x="86.46" y="8.16"/>
<vertex x="85.85" y="8.06"/>
<vertex x="85.23" y="8.02"/>
<vertex x="85.04" y="8.02"/>
<vertex x="83.83" y="8.13"/>
<vertex x="83.67" y="8.16"/>
<vertex x="82.69" y="8.44"/>
<vertex x="82.56" y="8.49"/>
<vertex x="81.79" y="8.94"/>
<vertex x="81.11" y="9.62"/>
<vertex x="80.62" y="10.46"/>
<vertex x="80.57" y="10.58"/>
<vertex x="80.3" y="11.45"/>
<vertex x="80.27" y="11.58"/>
<vertex x="80.13" y="12.58"/>
<vertex x="80.12" y="12.73"/>
<vertex x="80.08" y="13.83"/>
<vertex x="80.08" y="14.92"/>
<vertex x="80.08" y="16"/>
<vertex x="80.08" y="17.09"/>
<vertex x="80.08" y="18.17"/>
<vertex x="80.08" y="19.25"/>
<vertex x="80.08" y="20.34"/>
<vertex x="80.08" y="21.42"/>
<vertex x="80.08" y="22.51"/>
<vertex x="80.56" y="22.51"/>
<vertex x="81.04" y="22.51"/>
<vertex x="81.53" y="22.51"/>
<vertex x="82.01" y="22.51"/>
<vertex x="82.5" y="22.51"/>
<vertex x="82.98" y="22.51"/>
<vertex x="83.47" y="22.51"/>
<vertex x="83.95" y="22.51"/>
<vertex x="83.95" y="21.51"/>
<vertex x="83.95" y="20.52"/>
<vertex x="83.95" y="19.52"/>
<vertex x="83.95" y="18.53"/>
<vertex x="83.95" y="17.53"/>
<vertex x="83.95" y="16.53"/>
<vertex x="83.95" y="15.54"/>
<vertex x="83.95" y="14.54"/>
<vertex x="83.99" y="13.73"/>
<vertex x="84.08" y="13.02"/>
<vertex x="84.26" y="12.43"/>
<vertex x="84.51" y="11.94"/>
<vertex x="84.85" y="11.56"/>
<vertex x="85.28" y="11.29"/>
<vertex x="85.8" y="11.13"/>
<vertex x="86.43" y="11.08"/>
<vertex x="87.17" y="11.13"/>
<vertex x="87.79" y="11.31"/>
<vertex x="88.31" y="11.6"/>
<vertex x="88.72" y="12.02"/>
<vertex x="89.04" y="12.58"/>
<vertex x="89.26" y="13.28"/>
<vertex x="89.39" y="14.12"/>
<vertex x="89.44" y="15.12"/>
<vertex x="89.44" y="16.04"/>
<vertex x="89.44" y="16.96"/>
<vertex x="89.44" y="17.89"/>
<vertex x="89.44" y="18.81"/>
<vertex x="89.44" y="19.74"/>
<vertex x="89.44" y="20.66"/>
<vertex x="89.44" y="21.58"/>
<vertex x="89.44" y="22.51"/>
<vertex x="89.92" y="22.51"/>
<vertex x="90.4" y="22.51"/>
<vertex x="90.89" y="22.51"/>
<vertex x="91.37" y="22.51"/>
<vertex x="91.86" y="22.51"/>
<vertex x="92.34" y="22.51"/>
<vertex x="92.83" y="22.51"/>
<vertex x="93.31" y="22.51"/>
<vertex x="93.31" y="20.74"/>
<vertex x="93.31" y="18.98"/>
<vertex x="93.31" y="17.22"/>
<vertex x="93.31" y="15.46"/>
<vertex x="93.31" y="13.69"/>
<vertex x="93.31" y="11.93"/>
<vertex x="93.31" y="10.17"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="95.41" y="22.51"/>
<vertex x="95.87" y="22.51"/>
<vertex x="96.33" y="22.51"/>
<vertex x="96.79" y="22.51"/>
<vertex x="97.25" y="22.51"/>
<vertex x="97.71" y="22.51"/>
<vertex x="98.17" y="22.51"/>
<vertex x="98.63" y="22.51"/>
<vertex x="99.09" y="22.51"/>
<vertex x="99.09" y="22.27"/>
<vertex x="99.09" y="22.02"/>
<vertex x="99.09" y="21.78"/>
<vertex x="99.09" y="21.53"/>
<vertex x="99.09" y="21.28"/>
<vertex x="99.09" y="21.04"/>
<vertex x="99.09" y="20.79"/>
<vertex x="99.09" y="20.55"/>
<vertex x="99.1" y="20.55"/>
<vertex x="99.11" y="20.55"/>
<vertex x="99.12" y="20.55"/>
<vertex x="99.13" y="20.55"/>
<vertex x="99.14" y="20.55"/>
<vertex x="99.54" y="21.11"/>
<vertex x="99.99" y="21.59"/>
<vertex x="100.5" y="22"/>
<vertex x="101.04" y="22.33"/>
<vertex x="101.62" y="22.58"/>
<vertex x="102.22" y="22.75"/>
<vertex x="102.83" y="22.86"/>
<vertex x="103.45" y="22.89"/>
<vertex x="103.64" y="22.89"/>
<vertex x="104.85" y="22.79"/>
<vertex x="105.01" y="22.76"/>
<vertex x="105.99" y="22.48"/>
<vertex x="106.11" y="22.43"/>
<vertex x="106.89" y="21.98"/>
<vertex x="107.57" y="21.3"/>
<vertex x="108.06" y="20.46"/>
<vertex x="108.11" y="20.34"/>
<vertex x="108.38" y="19.47"/>
<vertex x="108.4" y="19.33"/>
<vertex x="108.55" y="18.34"/>
<vertex x="108.56" y="18.19"/>
<vertex x="108.6" y="17.09"/>
<vertex x="108.6" y="16"/>
<vertex x="108.6" y="14.92"/>
<vertex x="108.6" y="13.83"/>
<vertex x="108.6" y="12.75"/>
<vertex x="108.6" y="11.66"/>
<vertex x="108.6" y="10.58"/>
<vertex x="108.6" y="9.49"/>
<vertex x="108.6" y="8.41"/>
<vertex x="108.12" y="8.41"/>
<vertex x="107.63" y="8.41"/>
<vertex x="107.15" y="8.41"/>
<vertex x="106.66" y="8.41"/>
<vertex x="106.18" y="8.41"/>
<vertex x="105.7" y="8.41"/>
<vertex x="105.21" y="8.41"/>
<vertex x="104.73" y="8.41"/>
<vertex x="104.73" y="9.4"/>
<vertex x="104.73" y="10.4"/>
<vertex x="104.73" y="11.4"/>
<vertex x="104.73" y="12.39"/>
<vertex x="104.73" y="13.39"/>
<vertex x="104.73" y="14.38"/>
<vertex x="104.73" y="15.38"/>
<vertex x="104.73" y="16.37"/>
<vertex x="104.69" y="17.19"/>
<vertex x="104.59" y="17.89"/>
<vertex x="104.42" y="18.49"/>
<vertex x="104.17" y="18.98"/>
<vertex x="103.83" y="19.35"/>
<vertex x="103.4" y="19.62"/>
<vertex x="102.87" y="19.79"/>
<vertex x="102.24" y="19.84"/>
<vertex x="101.51" y="19.78"/>
<vertex x="100.89" y="19.61"/>
<vertex x="100.37" y="19.32"/>
<vertex x="99.96" y="18.89"/>
<vertex x="99.64" y="18.34"/>
<vertex x="99.42" y="17.64"/>
<vertex x="99.29" y="16.8"/>
<vertex x="99.25" y="15.8"/>
<vertex x="99.25" y="14.88"/>
<vertex x="99.25" y="13.95"/>
<vertex x="99.25" y="13.03"/>
<vertex x="99.25" y="12.1"/>
<vertex x="99.25" y="11.18"/>
<vertex x="99.25" y="10.26"/>
<vertex x="99.25" y="9.33"/>
<vertex x="99.25" y="8.41"/>
<vertex x="98.76" y="8.41"/>
<vertex x="98.28" y="8.41"/>
<vertex x="97.79" y="8.41"/>
<vertex x="97.31" y="8.41"/>
<vertex x="96.82" y="8.41"/>
<vertex x="96.34" y="8.41"/>
<vertex x="95.85" y="8.41"/>
<vertex x="95.37" y="8.41"/>
<vertex x="95.37" y="10.17"/>
<vertex x="95.37" y="11.93"/>
<vertex x="95.37" y="13.7"/>
<vertex x="95.37" y="15.46"/>
<vertex x="95.37" y="17.22"/>
<vertex x="95.37" y="18.99"/>
<vertex x="95.37" y="20.75"/>
</polygon>
</package>
<package name="REVISION">
<text x="0" y="0" size="1.778" layer="51">Revision By: </text>
</package>
<package name="REDBOT_LOGO">
<wire x1="36.32" y1="3.45" x2="0.16" y2="3.45" width="0.262" layer="21"/>
<polygon width="0.003" layer="21">
<vertex x="3.46" y="1.98"/>
<vertex x="3.42" y="1.85"/>
<vertex x="3.34" y="1.75"/>
<vertex x="3.22" y="1.67"/>
<vertex x="3.09" y="1.64"/>
<vertex x="2.96" y="1.63"/>
<vertex x="2.78" y="1.63"/>
<vertex x="2.78" y="0.98"/>
<vertex x="2.46" y="0.98"/>
<vertex x="2.46" y="2.6"/>
<vertex x="3.03" y="2.6"/>
<vertex x="3.15" y="2.59"/>
<vertex x="3.27" y="2.54"/>
<vertex x="3.36" y="2.46"/>
<vertex x="3.43" y="2.36"/>
<vertex x="3.46" y="2.24"/>
<vertex x="3.47" y="2.11"/>
<vertex x="3.15" y="2.11"/>
<vertex x="3.13" y="2.24"/>
<vertex x="3.05" y="2.33"/>
<vertex x="2.92" y="2.36"/>
<vertex x="2.78" y="2.36"/>
<vertex x="2.78" y="1.87"/>
<vertex x="2.93" y="1.87"/>
<vertex x="3.05" y="1.9"/>
<vertex x="3.13" y="1.99"/>
</polygon>
<vertex x="3.84" y="2.6"/>
<vertex x="4.44" y="2.6"/>
<vertex x="4.58" y="2.59"/>
<vertex x="4.71" y="2.54"/>
<vertex x="4.81" y="2.44"/>
<vertex x="4.86" y="2.32"/>
<vertex x="4.88" y="2.18"/>
<vertex x="4.86" y="2.05"/>
<vertex x="4.82" y="1.93"/>
<vertex x="4.73" y="1.83"/>
<vertex x="4.61" y="1.78"/>
<vertex x="4.73" y="1.74"/>
<vertex x="4.81" y="1.66"/>
<vertex x="4.85" y="1.54"/>
<vertex x="4.87" y="1.28"/>
<vertex x="4.87" y="1.18"/>
<vertex x="4.88" y="1.08"/>
<vertex x="4.94" y="0.99"/>
<vertex x="4.94" y="0.98"/>
<vertex x="4.59" y="0.98"/>
<vertex x="4.55" y="1.06"/>
<vertex x="4.54" y="1.15"/>
<vertex x="4.54" y="1.46"/>
<vertex x="4.51" y="1.56"/>
<vertex x="4.45" y="1.64"/>
<vertex x="4.34" y="1.67"/>
<vertex x="4.17" y="1.67"/>
<vertex x="4.17" y="0.98"/>
<vertex x="3.84" y="0.98"/>
<vertex x="4.17" y="2.36"/>
<vertex x="4.17" y="1.89"/>
<vertex x="4.3" y="1.89"/>
<vertex x="4.43" y="1.91"/>
<vertex x="4.53" y="2.01"/>
<vertex x="4.55" y="2.14"/>
<vertex x="4.53" y="2.25"/>
<vertex x="4.44" y="2.34"/>
<vertex x="4.32" y="2.36"/>
</polygon>
<vertex x="5.93" y="2.62"/>
<vertex x="6.06" y="2.59"/>
<vertex x="6.17" y="2.52"/>
<vertex x="6.25" y="2.42"/>
<vertex x="6.3" y="2.3"/>
<vertex x="6.33" y="2.18"/>
<vertex x="6.35" y="2.05"/>
<vertex x="6.35" y="1.53"/>
<vertex x="6.33" y="1.4"/>
<vertex x="6.3" y="1.28"/>
<vertex x="6.25" y="1.16"/>
<vertex x="6.17" y="1.06"/>
<vertex x="6.06" y="0.99"/>
<vertex x="5.93" y="0.96"/>
<vertex x="5.8" y="0.95"/>
<vertex x="5.67" y="0.96"/>
<vertex x="5.55" y="0.99"/>
<vertex x="5.44" y="1.06"/>
<vertex x="5.36" y="1.16"/>
<vertex x="5.3" y="1.28"/>
<vertex x="5.27" y="1.4"/>
<vertex x="5.25" y="1.66"/>
<vertex x="5.25" y="1.92"/>
<vertex x="5.27" y="2.18"/>
<vertex x="5.3" y="2.3"/>
<vertex x="5.36" y="2.42"/>
<vertex x="5.44" y="2.52"/>
<vertex x="5.55" y="2.59"/>
<vertex x="5.67" y="2.62"/>
<vertex x="5.8" y="2.63"/>
<vertex x="5.8" y="2.39"/>
<vertex x="5.69" y="2.36"/>
<vertex x="5.62" y="2.26"/>
<vertex x="5.59" y="2.15"/>
<vertex x="5.58" y="2.03"/>
<vertex x="5.58" y="1.55"/>
<vertex x="5.59" y="1.43"/>
<vertex x="5.62" y="1.32"/>
<vertex x="5.69" y="1.22"/>
<vertex x="5.8" y="1.19"/>
<vertex x="5.92" y="1.22"/>
<vertex x="5.98" y="1.32"/>
<vertex x="6.01" y="1.43"/>
<vertex x="6.03" y="1.67"/>
<vertex x="6.03" y="1.91"/>
<vertex x="6.01" y="2.15"/>
<vertex x="5.98" y="2.26"/>
<vertex x="5.92" y="2.36"/>
</polygon>
<vertex x="7.46" y="2.12"/>
<vertex x="7.45" y="2.24"/>
<vertex x="7.39" y="2.35"/>
<vertex x="7.28" y="2.39"/>
<vertex x="7.16" y="2.34"/>
<vertex x="7.09" y="2.22"/>
<vertex x="7.07" y="2.09"/>
<vertex x="7.06" y="1.96"/>
<vertex x="7.05" y="1.82"/>
<vertex x="7.06" y="1.7"/>
<vertex x="7.06" y="1.58"/>
<vertex x="7.08" y="1.45"/>
<vertex x="7.1" y="1.34"/>
<vertex x="7.17" y="1.23"/>
<vertex x="7.28" y="1.19"/>
<vertex x="7.39" y="1.23"/>
<vertex x="7.46" y="1.33"/>
<vertex x="7.48" y="1.45"/>
<vertex x="7.48" y="1.61"/>
<vertex x="7.27" y="1.61"/>
<vertex x="7.27" y="1.85"/>
<vertex x="7.8" y="1.85"/>
<vertex x="7.8" y="0.98"/>
<vertex x="7.55" y="0.98"/>
<vertex x="7.55" y="1.13"/>
<vertex x="7.46" y="1.03"/>
<vertex x="7.34" y="0.96"/>
<vertex x="7.21" y="0.95"/>
<vertex x="7.08" y="0.96"/>
<vertex x="6.97" y="1"/>
<vertex x="6.87" y="1.08"/>
<vertex x="6.81" y="1.19"/>
<vertex x="6.77" y="1.31"/>
<vertex x="6.75" y="1.43"/>
<vertex x="6.73" y="1.56"/>
<vertex x="6.73" y="1.93"/>
<vertex x="6.74" y="2.06"/>
<vertex x="6.76" y="2.18"/>
<vertex x="6.79" y="2.31"/>
<vertex x="6.84" y="2.42"/>
<vertex x="6.92" y="2.52"/>
<vertex x="7.03" y="2.59"/>
<vertex x="7.15" y="2.62"/>
<vertex x="7.27" y="2.63"/>
<vertex x="7.41" y="2.62"/>
<vertex x="7.54" y="2.58"/>
<vertex x="7.65" y="2.5"/>
<vertex x="7.73" y="2.39"/>
<vertex x="7.77" y="2.26"/>
<vertex x="7.78" y="2.12"/>
</polygon>
<vertex x="8.21" y="2.6"/>
<vertex x="8.82" y="2.6"/>
<vertex x="8.95" y="2.59"/>
<vertex x="9.08" y="2.54"/>
<vertex x="9.18" y="2.44"/>
<vertex x="9.23" y="2.32"/>
<vertex x="9.25" y="2.18"/>
<vertex x="9.24" y="2.05"/>
<vertex x="9.19" y="1.93"/>
<vertex x="9.1" y="1.83"/>
<vertex x="8.98" y="1.78"/>
<vertex x="9.1" y="1.74"/>
<vertex x="9.19" y="1.66"/>
<vertex x="9.22" y="1.54"/>
<vertex x="9.24" y="1.28"/>
<vertex x="9.24" y="1.18"/>
<vertex x="9.26" y="1.08"/>
<vertex x="9.31" y="0.99"/>
<vertex x="9.31" y="0.98"/>
<vertex x="8.96" y="0.98"/>
<vertex x="8.92" y="1.06"/>
<vertex x="8.92" y="1.15"/>
<vertex x="8.91" y="1.25"/>
<vertex x="8.91" y="1.46"/>
<vertex x="8.89" y="1.56"/>
<vertex x="8.82" y="1.64"/>
<vertex x="8.71" y="1.67"/>
<vertex x="8.54" y="1.67"/>
<vertex x="8.54" y="0.98"/>
<vertex x="8.21" y="0.98"/>
<vertex x="8.54" y="2.36"/>
<vertex x="8.54" y="1.89"/>
<vertex x="8.68" y="1.89"/>
<vertex x="8.81" y="1.91"/>
<vertex x="8.9" y="2.01"/>
<vertex x="8.92" y="2.14"/>
<vertex x="8.9" y="2.25"/>
<vertex x="8.81" y="2.34"/>
<vertex x="8.69" y="2.36"/>
</polygon>
<vertex x="10.09" y="1.59"/>
<vertex x="10.41" y="1.59"/>
<vertex x="10.47" y="1.32"/>
<vertex x="10.04" y="1.32"/>
<vertex x="9.96" y="0.98"/>
<vertex x="9.62" y="0.98"/>
<vertex x="10.05" y="2.6"/>
<vertex x="10.46" y="2.6"/>
<vertex x="10.88" y="0.98"/>
<vertex x="10.54" y="0.98"/>
<vertex x="10.25" y="2.32"/>
</polygon>
<vertex x="11.23" y="2.6"/>
<vertex x="11.72" y="2.6"/>
<vertex x="11.95" y="1.46"/>
<vertex x="12.19" y="2.6"/>
<vertex x="12.67" y="2.6"/>
<vertex x="12.67" y="0.98"/>
<vertex x="12.37" y="0.98"/>
<vertex x="12.37" y="2.27"/>
<vertex x="12.08" y="0.98"/>
<vertex x="11.82" y="0.98"/>
<vertex x="11.53" y="2.27"/>
<vertex x="11.53" y="0.98"/>
<vertex x="11.23" y="0.98"/>
</polygon>
<vertex x="13.11" y="2.6"/>
<vertex x="13.59" y="2.6"/>
<vertex x="13.83" y="1.46"/>
<vertex x="14.06" y="2.6"/>
<vertex x="14.55" y="2.6"/>
<vertex x="14.55" y="0.98"/>
<vertex x="14.25" y="0.98"/>
<vertex x="14.25" y="2.27"/>
<vertex x="14.24" y="2.27"/>
<vertex x="13.96" y="0.98"/>
<vertex x="13.7" y="0.98"/>
<vertex x="13.41" y="2.27"/>
<vertex x="13.41" y="0.98"/>
<vertex x="13.11" y="0.98"/>
</polygon>
<vertex x="15.89" y="2.6"/>
<vertex x="15.89" y="2.33"/>
<vertex x="15.31" y="2.33"/>
<vertex x="15.31" y="1.95"/>
<vertex x="15.86" y="1.95"/>
<vertex x="15.86" y="1.68"/>
<vertex x="15.31" y="1.68"/>
<vertex x="15.31" y="1.25"/>
<vertex x="15.91" y="1.25"/>
<vertex x="15.91" y="0.98"/>
<vertex x="14.98" y="0.98"/>
<vertex x="14.98" y="2.6"/>
</polygon>
<vertex x="16.96" y="2.59"/>
<vertex x="17.09" y="2.55"/>
<vertex x="17.2" y="2.47"/>
<vertex x="17.28" y="2.35"/>
<vertex x="17.32" y="2.22"/>
<vertex x="17.35" y="2.09"/>
<vertex x="17.36" y="1.95"/>
<vertex x="17.36" y="1.68"/>
<vertex x="17.35" y="1.56"/>
<vertex x="17.33" y="1.43"/>
<vertex x="17.3" y="1.3"/>
<vertex x="17.25" y="1.19"/>
<vertex x="17.17" y="1.09"/>
<vertex x="17.06" y="1.02"/>
<vertex x="16.93" y="0.99"/>
<vertex x="16.8" y="0.98"/>
<vertex x="16.29" y="0.98"/>
<vertex x="16.29" y="2.6"/>
<vertex x="16.82" y="2.6"/>
<vertex x="16.79" y="2.48"/>
<vertex x="16.75" y="2.36"/>
<vertex x="16.61" y="2.36"/>
<vertex x="16.61" y="1.22"/>
<vertex x="16.76" y="1.22"/>
<vertex x="16.88" y="1.24"/>
<vertex x="16.97" y="1.32"/>
<vertex x="17.01" y="1.44"/>
<vertex x="17.03" y="1.56"/>
<vertex x="17.03" y="1.92"/>
<vertex x="17.01" y="2.16"/>
<vertex x="16.96" y="2.27"/>
<vertex x="16.87" y="2.34"/>
</polygon>
<vertex x="18.44" y="2.6"/>
<vertex x="18.75" y="2.6"/>
<vertex x="18.93" y="1.4"/>
<vertex x="19.12" y="2.6"/>
<vertex x="19.44" y="2.6"/>
<vertex x="19.63" y="1.4"/>
<vertex x="19.81" y="2.6"/>
<vertex x="20.13" y="2.6"/>
<vertex x="19.83" y="0.98"/>
<vertex x="19.46" y="0.98"/>
<vertex x="19.28" y="2.16"/>
<vertex x="19.1" y="0.98"/>
<vertex x="18.73" y="0.98"/>
</polygon>
<vertex x="20.49" y="0.98"/>
<vertex x="20.49" y="2.6"/>
<vertex x="20.81" y="2.6"/>
<vertex x="20.81" y="0.98"/>
</polygon>
<vertex x="22.21" y="2.6"/>
<vertex x="22.21" y="2.33"/>
<vertex x="21.86" y="2.33"/>
<vertex x="21.86" y="0.98"/>
<vertex x="21.53" y="0.98"/>
<vertex x="21.53" y="2.33"/>
<vertex x="21.17" y="2.33"/>
<vertex x="21.17" y="2.6"/>
</polygon>
<vertex x="22.56" y="2.6"/>
<vertex x="22.89" y="2.6"/>
<vertex x="22.89" y="1.98"/>
<vertex x="23.27" y="1.98"/>
<vertex x="23.27" y="2.6"/>
<vertex x="23.6" y="2.6"/>
<vertex x="23.6" y="0.98"/>
<vertex x="23.27" y="0.98"/>
<vertex x="23.27" y="1.7"/>
<vertex x="22.89" y="1.7"/>
<vertex x="22.89" y="0.98"/>
<vertex x="22.56" y="0.98"/>
</polygon>
<vertex x="25.14" y="1.59"/>
<vertex x="25.46" y="1.59"/>
<vertex x="25.52" y="1.32"/>
<vertex x="25.08" y="1.32"/>
<vertex x="25.01" y="0.98"/>
<vertex x="24.67" y="0.98"/>
<vertex x="25.1" y="2.6"/>
<vertex x="25.5" y="2.6"/>
<vertex x="25.93" y="0.98"/>
<vertex x="25.59" y="0.98"/>
<vertex x="25.3" y="2.32"/>
</polygon>
<vertex x="26.27" y="2.6"/>
<vertex x="26.88" y="2.6"/>
<vertex x="27.01" y="2.59"/>
<vertex x="27.14" y="2.54"/>
<vertex x="27.24" y="2.44"/>
<vertex x="27.29" y="2.32"/>
<vertex x="27.31" y="2.18"/>
<vertex x="27.3" y="2.05"/>
<vertex x="27.25" y="1.93"/>
<vertex x="27.16" y="1.83"/>
<vertex x="27.04" y="1.78"/>
<vertex x="27.16" y="1.74"/>
<vertex x="27.25" y="1.66"/>
<vertex x="27.28" y="1.54"/>
<vertex x="27.3" y="1.41"/>
<vertex x="27.3" y="1.18"/>
<vertex x="27.32" y="1.08"/>
<vertex x="27.37" y="0.99"/>
<vertex x="27.37" y="0.98"/>
<vertex x="27.02" y="0.98"/>
<vertex x="26.98" y="1.06"/>
<vertex x="26.98" y="1.15"/>
<vertex x="26.97" y="1.25"/>
<vertex x="26.97" y="1.46"/>
<vertex x="26.95" y="1.56"/>
<vertex x="26.88" y="1.64"/>
<vertex x="26.77" y="1.67"/>
<vertex x="26.6" y="1.67"/>
<vertex x="26.6" y="0.98"/>
<vertex x="26.27" y="0.98"/>
<vertex x="26.6" y="2.36"/>
<vertex x="26.6" y="1.89"/>
<vertex x="26.74" y="1.89"/>
<vertex x="26.87" y="1.91"/>
<vertex x="26.96" y="2.01"/>
<vertex x="26.98" y="2.14"/>
<vertex x="26.96" y="2.25"/>
<vertex x="26.87" y="2.34"/>
<vertex x="26.75" y="2.36"/>
</polygon>
<vertex x="28.42" y="2.59"/>
<vertex x="28.55" y="2.55"/>
<vertex x="28.66" y="2.47"/>
<vertex x="28.74" y="2.35"/>
<vertex x="28.78" y="2.22"/>
<vertex x="28.81" y="2.09"/>
<vertex x="28.82" y="1.95"/>
<vertex x="28.82" y="1.68"/>
<vertex x="28.81" y="1.56"/>
<vertex x="28.79" y="1.43"/>
<vertex x="28.76" y="1.3"/>
<vertex x="28.71" y="1.19"/>
<vertex x="28.62" y="1.09"/>
<vertex x="28.51" y="1.02"/>
<vertex x="28.39" y="0.99"/>
<vertex x="28.26" y="0.98"/>
<vertex x="27.75" y="0.98"/>
<vertex x="27.75" y="2.6"/>
<vertex x="28.28" y="2.6"/>
<vertex x="28.25" y="2.48"/>
<vertex x="28.21" y="2.36"/>
<vertex x="28.07" y="2.36"/>
<vertex x="28.07" y="1.22"/>
<vertex x="28.22" y="1.22"/>
<vertex x="28.34" y="1.24"/>
<vertex x="28.43" y="1.32"/>
<vertex x="28.47" y="1.44"/>
<vertex x="28.49" y="1.68"/>
<vertex x="28.49" y="1.92"/>
<vertex x="28.47" y="2.16"/>
<vertex x="28.42" y="2.27"/>
<vertex x="28.33" y="2.34"/>
</polygon>
<vertex x="29.54" y="2.6"/>
<vertex x="29.54" y="1.47"/>
<vertex x="29.55" y="1.34"/>
<vertex x="29.61" y="1.23"/>
<vertex x="29.73" y="1.19"/>
<vertex x="29.85" y="1.23"/>
<vertex x="29.91" y="1.34"/>
<vertex x="29.92" y="1.47"/>
<vertex x="29.92" y="2.6"/>
<vertex x="30.25" y="2.6"/>
<vertex x="30.25" y="1.47"/>
<vertex x="30.24" y="1.35"/>
<vertex x="30.21" y="1.23"/>
<vertex x="30.16" y="1.13"/>
<vertex x="30.07" y="1.04"/>
<vertex x="29.97" y="0.99"/>
<vertex x="29.85" y="0.96"/>
<vertex x="29.73" y="0.95"/>
<vertex x="29.61" y="0.95"/>
<vertex x="29.49" y="0.98"/>
<vertex x="29.38" y="1.04"/>
<vertex x="29.3" y="1.12"/>
<vertex x="29.25" y="1.23"/>
<vertex x="29.22" y="1.35"/>
<vertex x="29.21" y="1.47"/>
<vertex x="29.21" y="2.6"/>
</polygon>
<vertex x="30.68" y="0.98"/>
<vertex x="30.68" y="2.6"/>
<vertex x="31" y="2.6"/>
<vertex x="31" y="0.98"/>
</polygon>
<vertex x="31.82" y="2.6"/>
<vertex x="32.21" y="1.49"/>
<vertex x="32.22" y="1.49"/>
<vertex x="32.22" y="2.6"/>
<vertex x="32.52" y="2.6"/>
<vertex x="32.52" y="0.98"/>
<vertex x="32.14" y="0.98"/>
<vertex x="31.74" y="2.11"/>
<vertex x="31.74" y="0.98"/>
<vertex x="31.44" y="0.98"/>
<vertex x="31.44" y="2.6"/>
</polygon>
<vertex x="33.59" y="2.62"/>
<vertex x="33.72" y="2.59"/>
<vertex x="33.83" y="2.52"/>
<vertex x="33.91" y="2.42"/>
<vertex x="33.96" y="2.3"/>
<vertex x="33.99" y="2.18"/>
<vertex x="34.01" y="2.05"/>
<vertex x="34.02" y="1.92"/>
<vertex x="34.02" y="1.66"/>
<vertex x="34.01" y="1.53"/>
<vertex x="33.99" y="1.4"/>
<vertex x="33.96" y="1.28"/>
<vertex x="33.91" y="1.16"/>
<vertex x="33.83" y="1.06"/>
<vertex x="33.72" y="0.99"/>
<vertex x="33.59" y="0.96"/>
<vertex x="33.47" y="0.95"/>
<vertex x="33.34" y="0.96"/>
<vertex x="33.21" y="0.99"/>
<vertex x="33.1" y="1.06"/>
<vertex x="33.02" y="1.16"/>
<vertex x="32.97" y="1.28"/>
<vertex x="32.94" y="1.4"/>
<vertex x="32.92" y="1.53"/>
<vertex x="32.92" y="1.66"/>
<vertex x="32.91" y="1.79"/>
<vertex x="32.92" y="1.92"/>
<vertex x="32.92" y="2.05"/>
<vertex x="32.94" y="2.18"/>
<vertex x="32.97" y="2.3"/>
<vertex x="33.02" y="2.42"/>
<vertex x="33.1" y="2.52"/>
<vertex x="33.21" y="2.59"/>
<vertex x="33.34" y="2.62"/>
<vertex x="33.47" y="2.63"/>
<vertex x="33.47" y="2.39"/>
<vertex x="33.35" y="2.36"/>
<vertex x="33.28" y="2.26"/>
<vertex x="33.26" y="2.15"/>
<vertex x="33.24" y="1.91"/>
<vertex x="33.24" y="1.67"/>
<vertex x="33.26" y="1.43"/>
<vertex x="33.28" y="1.32"/>
<vertex x="33.35" y="1.22"/>
<vertex x="33.47" y="1.19"/>
<vertex x="33.58" y="1.22"/>
<vertex x="33.65" y="1.32"/>
<vertex x="33.67" y="1.43"/>
<vertex x="33.69" y="1.67"/>
<vertex x="33.69" y="1.91"/>
<vertex x="33.67" y="2.15"/>
<vertex x="33.65" y="2.26"/>
<vertex x="33.58" y="2.36"/>
</polygon>
<polygon width="0.033" layer="21">
<vertex x="21.71" y="6.69"/>
<vertex x="21.69" y="6.56"/>
<vertex x="21.66" y="6.43"/>
<vertex x="21.61" y="6.32"/>
<vertex x="21.53" y="6.21"/>
<vertex x="21.43" y="6.13"/>
<vertex x="21.32" y="6.07"/>
<vertex x="21.2" y="6.02"/>
<vertex x="21.07" y="6"/>
<vertex x="20.81" y="5.98"/>
<vertex x="20.42" y="5.98"/>
<vertex x="20.42" y="7.65"/>
<vertex x="20.86" y="7.65"/>
<vertex x="21" y="7.64"/>
<vertex x="21.14" y="7.62"/>
<vertex x="21.27" y="7.59"/>
<vertex x="21.39" y="7.53"/>
<vertex x="21.5" y="7.45"/>
<vertex x="21.59" y="7.35"/>
<vertex x="21.65" y="7.22"/>
<vertex x="21.69" y="7.09"/>
<vertex x="21.71" y="6.96"/>
<vertex x="21.72" y="6.82"/>
<vertex x="21.9" y="6.81"/>
<vertex x="23.2" y="6.78"/>
<vertex x="23.2" y="6.91"/>
<vertex x="23.16" y="7.17"/>
<vertex x="23.1" y="7.43"/>
<vertex x="23.05" y="7.55"/>
<vertex x="22.98" y="7.67"/>
<vertex x="22.91" y="7.78"/>
<vertex x="22.83" y="7.88"/>
<vertex x="22.73" y="7.98"/>
<vertex x="22.63" y="8.06"/>
<vertex x="22.52" y="8.13"/>
<vertex x="22.4" y="8.19"/>
<vertex x="22.28" y="8.24"/>
<vertex x="22.39" y="8.3"/>
<vertex x="22.5" y="8.38"/>
<vertex x="22.6" y="8.47"/>
<vertex x="22.69" y="8.57"/>
<vertex x="22.77" y="8.68"/>
<vertex x="22.84" y="8.79"/>
<vertex x="22.89" y="8.92"/>
<vertex x="22.94" y="9.04"/>
<vertex x="22.97" y="9.17"/>
<vertex x="22.99" y="9.31"/>
<vertex x="23.01" y="9.44"/>
<vertex x="23.01" y="9.57"/>
<vertex x="22.88" y="9.56"/>
<vertex x="22.75" y="9.54"/>
<vertex x="22.49" y="9.52"/>
<vertex x="22.36" y="9.5"/>
<vertex x="22.23" y="9.49"/>
<vertex x="22.1" y="9.47"/>
<vertex x="21.84" y="9.45"/>
<vertex x="21.71" y="9.43"/>
<vertex x="21.58" y="9.42"/>
<vertex x="21.57" y="9.28"/>
<vertex x="21.55" y="9.15"/>
<vertex x="21.5" y="9.03"/>
<vertex x="21.43" y="8.92"/>
<vertex x="21.33" y="8.83"/>
<vertex x="21.21" y="8.77"/>
<vertex x="20.95" y="8.71"/>
<vertex x="20.81" y="8.7"/>
<vertex x="20.42" y="8.7"/>
<vertex x="20.42" y="10.12"/>
<vertex x="20.9" y="10.12"/>
<vertex x="21.02" y="10.11"/>
<vertex x="21.15" y="10.09"/>
<vertex x="21.27" y="10.05"/>
<vertex x="21.37" y="9.98"/>
<vertex x="21.46" y="9.89"/>
<vertex x="21.52" y="9.78"/>
<vertex x="21.56" y="9.67"/>
<vertex x="21.57" y="9.54"/>
<vertex x="21.84" y="9.44"/>
<vertex x="21.97" y="9.46"/>
<vertex x="23.01" y="9.71"/>
<vertex x="23" y="9.84"/>
<vertex x="22.98" y="9.98"/>
<vertex x="22.95" y="10.11"/>
<vertex x="22.91" y="10.24"/>
<vertex x="22.86" y="10.37"/>
<vertex x="22.8" y="10.49"/>
<vertex x="22.73" y="10.6"/>
<vertex x="22.65" y="10.71"/>
<vertex x="22.56" y="10.8"/>
<vertex x="22.45" y="10.89"/>
<vertex x="22.34" y="10.96"/>
<vertex x="22.22" y="11.03"/>
<vertex x="22.09" y="11.08"/>
<vertex x="21.97" y="11.12"/>
<vertex x="21.84" y="11.16"/>
<vertex x="21.7" y="11.19"/>
<vertex x="21.57" y="11.21"/>
<vertex x="21.43" y="11.22"/>
<vertex x="21.3" y="11.23"/>
<vertex x="19.08" y="11.23"/>
<vertex x="19.02" y="11.2"/>
<vertex x="18.99" y="11.13"/>
<vertex x="18.99" y="4.97"/>
<vertex x="19.02" y="4.9"/>
<vertex x="19.08" y="4.88"/>
<vertex x="21.32" y="4.88"/>
<vertex x="21.46" y="4.89"/>
<vertex x="21.59" y="4.9"/>
<vertex x="21.73" y="4.92"/>
<vertex x="21.86" y="4.95"/>
<vertex x="22" y="4.98"/>
<vertex x="22.13" y="5.03"/>
<vertex x="22.25" y="5.08"/>
<vertex x="22.37" y="5.14"/>
<vertex x="22.49" y="5.22"/>
<vertex x="22.6" y="5.3"/>
<vertex x="22.7" y="5.39"/>
<vertex x="22.8" y="5.49"/>
<vertex x="22.88" y="5.6"/>
<vertex x="22.95" y="5.72"/>
<vertex x="23.01" y="5.84"/>
<vertex x="23.07" y="5.97"/>
<vertex x="23.11" y="6.1"/>
<vertex x="23.17" y="6.36"/>
<vertex x="23.19" y="6.5"/>
<vertex x="23.2" y="6.64"/>
<vertex x="23.02" y="6.78"/>
</polygon>
<vertex x="25.9" y="7.29"/>
<vertex x="25.9" y="7.02"/>
<vertex x="25.89" y="6.88"/>
<vertex x="25.89" y="6.74"/>
<vertex x="25.88" y="6.6"/>
<vertex x="25.86" y="6.47"/>
<vertex x="25.84" y="6.33"/>
<vertex x="25.81" y="6.2"/>
<vertex x="25.77" y="6.06"/>
<vertex x="25.71" y="5.94"/>
<vertex x="25.62" y="5.84"/>
<vertex x="25.5" y="5.77"/>
<vertex x="25.36" y="5.76"/>
<vertex x="25.23" y="5.77"/>
<vertex x="25.11" y="5.82"/>
<vertex x="25.02" y="5.91"/>
<vertex x="24.96" y="6.02"/>
<vertex x="24.91" y="6.14"/>
<vertex x="24.88" y="6.27"/>
<vertex x="24.86" y="6.39"/>
<vertex x="24.84" y="6.52"/>
<vertex x="24.82" y="6.78"/>
<vertex x="24.82" y="7.16"/>
<vertex x="24.81" y="7.29"/>
<vertex x="24.82" y="7.42"/>
<vertex x="24.82" y="7.81"/>
<vertex x="24.83" y="7.94"/>
<vertex x="24.84" y="8.06"/>
<vertex x="24.88" y="8.32"/>
<vertex x="24.91" y="8.44"/>
<vertex x="24.96" y="8.57"/>
<vertex x="25.02" y="8.68"/>
<vertex x="25.11" y="8.76"/>
<vertex x="25.23" y="8.82"/>
<vertex x="25.36" y="8.83"/>
<vertex x="25.5" y="8.81"/>
<vertex x="25.62" y="8.75"/>
<vertex x="25.71" y="8.65"/>
<vertex x="25.77" y="8.52"/>
<vertex x="25.81" y="8.39"/>
<vertex x="25.84" y="8.26"/>
<vertex x="25.88" y="7.98"/>
<vertex x="25.89" y="7.85"/>
<vertex x="25.89" y="7.71"/>
<vertex x="25.9" y="7.57"/>
<vertex x="27.28" y="7.29"/>
<vertex x="27.28" y="7.56"/>
<vertex x="27.27" y="7.7"/>
<vertex x="27.27" y="7.83"/>
<vertex x="27.26" y="7.96"/>
<vertex x="27.24" y="8.1"/>
<vertex x="27.2" y="8.36"/>
<vertex x="27.17" y="8.5"/>
<vertex x="27.14" y="8.63"/>
<vertex x="27.1" y="8.75"/>
<vertex x="27.05" y="8.88"/>
<vertex x="27" y="9"/>
<vertex x="26.93" y="9.12"/>
<vertex x="26.85" y="9.23"/>
<vertex x="26.77" y="9.33"/>
<vertex x="26.67" y="9.43"/>
<vertex x="26.57" y="9.51"/>
<vertex x="26.46" y="9.59"/>
<vertex x="26.34" y="9.65"/>
<vertex x="26.22" y="9.7"/>
<vertex x="26.09" y="9.75"/>
<vertex x="25.96" y="9.78"/>
<vertex x="25.82" y="9.8"/>
<vertex x="25.69" y="9.82"/>
<vertex x="25.56" y="9.83"/>
<vertex x="25.22" y="9.83"/>
<vertex x="25.09" y="9.82"/>
<vertex x="24.95" y="9.8"/>
<vertex x="24.82" y="9.78"/>
<vertex x="24.69" y="9.75"/>
<vertex x="24.56" y="9.71"/>
<vertex x="24.43" y="9.65"/>
<vertex x="24.31" y="9.59"/>
<vertex x="24.2" y="9.52"/>
<vertex x="24.09" y="9.43"/>
<vertex x="24" y="9.34"/>
<vertex x="23.91" y="9.23"/>
<vertex x="23.83" y="9.12"/>
<vertex x="23.76" y="9.01"/>
<vertex x="23.7" y="8.89"/>
<vertex x="23.6" y="8.63"/>
<vertex x="23.57" y="8.5"/>
<vertex x="23.53" y="8.37"/>
<vertex x="23.51" y="8.24"/>
<vertex x="23.49" y="8.1"/>
<vertex x="23.47" y="7.97"/>
<vertex x="23.46" y="7.83"/>
<vertex x="23.45" y="7.7"/>
<vertex x="23.44" y="7.56"/>
<vertex x="23.44" y="7.43"/>
<vertex x="23.43" y="7.29"/>
<vertex x="23.44" y="7.16"/>
<vertex x="23.44" y="6.89"/>
<vertex x="23.45" y="6.76"/>
<vertex x="23.46" y="6.62"/>
<vertex x="23.48" y="6.49"/>
<vertex x="23.49" y="6.35"/>
<vertex x="23.52" y="6.22"/>
<vertex x="23.54" y="6.09"/>
<vertex x="23.62" y="5.83"/>
<vertex x="23.67" y="5.71"/>
<vertex x="23.72" y="5.58"/>
<vertex x="23.86" y="5.36"/>
<vertex x="23.95" y="5.25"/>
<vertex x="24.04" y="5.16"/>
<vertex x="24.15" y="5.07"/>
<vertex x="24.26" y="5"/>
<vertex x="24.38" y="4.93"/>
<vertex x="24.5" y="4.88"/>
<vertex x="24.63" y="4.84"/>
<vertex x="24.89" y="4.78"/>
<vertex x="25.03" y="4.77"/>
<vertex x="25.16" y="4.76"/>
<vertex x="25.49" y="4.76"/>
<vertex x="25.63" y="4.77"/>
<vertex x="25.76" y="4.78"/>
<vertex x="25.9" y="4.81"/>
<vertex x="26.03" y="4.84"/>
<vertex x="26.16" y="4.88"/>
<vertex x="26.28" y="4.93"/>
<vertex x="26.52" y="5.07"/>
<vertex x="26.62" y="5.15"/>
<vertex x="26.72" y="5.25"/>
<vertex x="26.81" y="5.35"/>
<vertex x="26.89" y="5.46"/>
<vertex x="26.96" y="5.58"/>
<vertex x="27.02" y="5.7"/>
<vertex x="27.07" y="5.83"/>
<vertex x="27.11" y="5.95"/>
<vertex x="27.15" y="6.08"/>
<vertex x="27.18" y="6.22"/>
<vertex x="27.21" y="6.35"/>
<vertex x="27.23" y="6.48"/>
<vertex x="27.25" y="6.62"/>
<vertex x="27.26" y="6.75"/>
<vertex x="27.27" y="6.89"/>
<vertex x="27.28" y="7.02"/>
</polygon>
<vertex x="30.06" y="8.75"/>
<vertex x="30.06" y="9.83"/>
<vertex x="29.35" y="9.83"/>
<vertex x="29.35" y="11.19"/>
<vertex x="27.88" y="11.19"/>
<vertex x="27.88" y="9.83"/>
<vertex x="27.27" y="9.83"/>
<vertex x="27.27" y="8.75"/>
<vertex x="27.88" y="8.75"/>
<vertex x="27.88" y="6.16"/>
<vertex x="27.89" y="6.02"/>
<vertex x="27.89" y="5.88"/>
<vertex x="27.9" y="5.74"/>
<vertex x="27.92" y="5.61"/>
<vertex x="27.94" y="5.47"/>
<vertex x="27.98" y="5.34"/>
<vertex x="28.04" y="5.21"/>
<vertex x="28.12" y="5.1"/>
<vertex x="28.22" y="5"/>
<vertex x="28.33" y="4.93"/>
<vertex x="28.46" y="4.87"/>
<vertex x="28.59" y="4.83"/>
<vertex x="28.73" y="4.81"/>
<vertex x="28.86" y="4.79"/>
<vertex x="29" y="4.78"/>
<vertex x="29.26" y="4.78"/>
<vertex x="29.38" y="4.79"/>
<vertex x="29.5" y="4.79"/>
<vertex x="29.74" y="4.81"/>
<vertex x="29.86" y="4.83"/>
<vertex x="29.96" y="4.84"/>
<vertex x="30.06" y="4.84"/>
<vertex x="30.06" y="5.95"/>
<vertex x="29.92" y="5.93"/>
<vertex x="29.66" y="5.91"/>
<vertex x="29.54" y="5.92"/>
<vertex x="29.43" y="5.96"/>
<vertex x="29.37" y="6.07"/>
<vertex x="29.35" y="6.31"/>
<vertex x="29.35" y="8.75"/>
</polygon>
<wire x1="7.85" y1="10.22" x2="8.39" y2="10.22" width="0.262" layer="21"/>
<wire x1="8.39" y1="10.22" x2="8.52" y2="10.21" width="0.262" layer="21"/>
<wire x1="8.52" y1="10.21" x2="8.66" y2="10.19" width="0.262" layer="21"/>
<wire x1="8.66" y1="10.19" x2="8.79" y2="10.15" width="0.262" layer="21"/>
<wire x1="8.79" y1="10.15" x2="8.91" y2="10.09" width="0.262" layer="21"/>
<wire x1="8.91" y1="10.09" x2="9.02" y2="10.01" width="0.262" layer="21"/>
<wire x1="9.02" y1="10.01" x2="9.1" y2="9.9" width="0.262" layer="21"/>
<wire x1="9.1" y1="9.9" x2="9.16" y2="9.78" width="0.262" layer="21"/>
<wire x1="9.16" y1="9.78" x2="9.2" y2="9.65" width="0.262" layer="21"/>
<wire x1="9.2" y1="9.65" x2="9.23" y2="9.52" width="0.262" layer="21"/>
<wire x1="9.23" y1="9.52" x2="9.23" y2="9.21" width="0.262" layer="21"/>
<wire x1="9.23" y1="9.21" x2="9.21" y2="9.08" width="0.262" layer="21"/>
<wire x1="9.21" y1="9.08" x2="9.18" y2="8.95" width="0.262" layer="21"/>
<wire x1="9.18" y1="8.95" x2="9.12" y2="8.83" width="0.262" layer="21"/>
<wire x1="9.12" y1="8.83" x2="9.05" y2="8.72" width="0.262" layer="21"/>
<wire x1="9.05" y1="8.72" x2="8.96" y2="8.63" width="0.262" layer="21"/>
<wire x1="8.96" y1="8.63" x2="8.85" y2="8.55" width="0.262" layer="21"/>
<wire x1="8.85" y1="8.55" x2="8.73" y2="8.5" width="0.262" layer="21"/>
<wire x1="8.73" y1="8.5" x2="8.6" y2="8.47" width="0.262" layer="21"/>
<wire x1="8.6" y1="8.47" x2="8.47" y2="8.45" width="0.262" layer="21"/>
<wire x1="8.47" y1="8.45" x2="8.34" y2="8.44" width="0.262" layer="21"/>
<wire x1="8.34" y1="8.44" x2="7.89" y2="8.44" width="0.262" layer="21"/>
<wire x1="7.89" y1="8.44" x2="7.8" y2="8.47" width="0.262" layer="21"/>
<wire x1="7.8" y1="8.47" x2="7.78" y2="8.53" width="0.262" layer="21"/>
<wire x1="7.78" y1="8.53" x2="7.78" y2="10.08" width="0.262" layer="21"/>
<wire x1="7.78" y1="10.08" x2="7.8" y2="10.16" width="0.262" layer="21"/>
<wire x1="7.8" y1="10.16" x2="7.85" y2="10.22" width="0.262" layer="21"/>
<wire x1="12.87" y1="8.91" x2="13" y2="8.87" width="0.262" layer="21"/>
<wire x1="13" y1="8.87" x2="13.11" y2="8.8" width="0.262" layer="21"/>
<wire x1="13.11" y1="8.8" x2="13.19" y2="8.69" width="0.262" layer="21"/>
<wire x1="13.19" y1="8.69" x2="13.24" y2="8.57" width="0.262" layer="21"/>
<wire x1="13.24" y1="8.57" x2="13.28" y2="8.44" width="0.262" layer="21"/>
<wire x1="13.28" y1="8.44" x2="13.32" y2="8.18" width="0.262" layer="21"/>
<wire x1="13.32" y1="8.18" x2="13.33" y2="8.04" width="0.262" layer="21"/>
<wire x1="13.33" y1="8.04" x2="13.34" y2="7.91" width="0.262" layer="21"/>
<wire x1="13.34" y1="7.91" x2="13.33" y2="7.85" width="0.262" layer="21"/>
<wire x1="13.33" y1="7.85" x2="13.31" y2="7.84" width="0.262" layer="21"/>
<wire x1="13.31" y1="7.84" x2="13.23" y2="7.82" width="0.262" layer="21"/>
<wire x1="13.23" y1="7.82" x2="12.23" y2="7.82" width="0.262" layer="21"/>
<wire x1="12.23" y1="7.82" x2="12.14" y2="7.85" width="0.262" layer="21"/>
<wire x1="12.14" y1="7.85" x2="12.13" y2="7.91" width="0.262" layer="21"/>
<wire x1="12.13" y1="7.91" x2="12.13" y2="8.06" width="0.262" layer="21"/>
<wire x1="12.13" y1="8.06" x2="12.15" y2="8.32" width="0.262" layer="21"/>
<wire x1="12.15" y1="8.32" x2="12.18" y2="8.45" width="0.262" layer="21"/>
<wire x1="12.18" y1="8.45" x2="12.23" y2="8.57" width="0.262" layer="21"/>
<wire x1="12.23" y1="8.57" x2="12.29" y2="8.69" width="0.262" layer="21"/>
<wire x1="12.29" y1="8.69" x2="12.38" y2="8.79" width="0.262" layer="21"/>
<wire x1="12.38" y1="8.79" x2="12.49" y2="8.87" width="0.262" layer="21"/>
<wire x1="12.49" y1="8.87" x2="12.61" y2="8.91" width="0.262" layer="21"/>
<wire x1="12.61" y1="8.91" x2="12.74" y2="8.92" width="0.262" layer="21"/>
<wire x1="12.74" y1="8.92" x2="12.87" y2="8.91" width="0.262" layer="21"/>
<wire x1="13.35" y1="6.45" x2="13.31" y2="6.36" width="0.262" layer="21"/>
<wire x1="13.31" y1="6.36" x2="13.29" y2="6.23" width="0.262" layer="21"/>
<wire x1="13.29" y1="6.23" x2="13.21" y2="5.99" width="0.262" layer="21"/>
<wire x1="13.21" y1="5.99" x2="13.14" y2="5.88" width="0.262" layer="21"/>
<wire x1="13.14" y1="5.88" x2="13.06" y2="5.79" width="0.262" layer="21"/>
<wire x1="13.06" y1="5.79" x2="12.95" y2="5.72" width="0.262" layer="21"/>
<wire x1="12.95" y1="5.72" x2="12.82" y2="5.69" width="0.262" layer="21"/>
<wire x1="12.82" y1="5.69" x2="12.7" y2="5.68" width="0.262" layer="21"/>
<wire x1="12.7" y1="5.68" x2="12.57" y2="5.7" width="0.262" layer="21"/>
<wire x1="12.57" y1="5.7" x2="12.46" y2="5.75" width="0.262" layer="21"/>
<wire x1="12.46" y1="5.75" x2="12.36" y2="5.82" width="0.262" layer="21"/>
<wire x1="12.36" y1="5.82" x2="12.29" y2="5.93" width="0.262" layer="21"/>
<wire x1="12.29" y1="5.93" x2="12.24" y2="6.04" width="0.262" layer="21"/>
<wire x1="12.24" y1="6.04" x2="12.2" y2="6.15" width="0.262" layer="21"/>
<wire x1="12.2" y1="6.15" x2="12.17" y2="6.28" width="0.262" layer="21"/>
<wire x1="12.17" y1="6.28" x2="12.15" y2="6.4" width="0.262" layer="21"/>
<wire x1="12.15" y1="6.4" x2="12.14" y2="6.52" width="0.262" layer="21"/>
<wire x1="12.14" y1="6.52" x2="12.13" y2="6.65" width="0.262" layer="21"/>
<wire x1="12.13" y1="6.65" x2="12.13" y2="6.97" width="0.262" layer="21"/>
<wire x1="12.13" y1="6.97" x2="12.14" y2="7.05" width="0.262" layer="21"/>
<wire x1="12.14" y1="7.05" x2="12.19" y2="7.11" width="0.262" layer="21"/>
<wire x1="12.19" y1="7.11" x2="14.29" y2="7.11" width="0.262" layer="21"/>
<wire x1="14.29" y1="7.11" x2="14.37" y2="7.13" width="0.262" layer="21"/>
<wire x1="14.37" y1="7.13" x2="14.44" y2="7.18" width="0.262" layer="21"/>
<wire x1="14.44" y1="7.18" x2="14.48" y2="7.22" width="0.262" layer="21"/>
<wire x1="14.48" y1="7.22" x2="14.48" y2="7.65" width="0.262" layer="21"/>
<wire x1="14.48" y1="7.65" x2="14.47" y2="7.79" width="0.262" layer="21"/>
<wire x1="14.47" y1="7.79" x2="14.46" y2="7.92" width="0.262" layer="21"/>
<wire x1="14.46" y1="7.92" x2="14.45" y2="8.06" width="0.262" layer="21"/>
<wire x1="14.45" y1="8.06" x2="14.44" y2="8.19" width="0.262" layer="21"/>
<wire x1="14.44" y1="8.19" x2="14.42" y2="8.32" width="0.262" layer="21"/>
<wire x1="14.42" y1="8.32" x2="14.33" y2="8.71" width="0.262" layer="21"/>
<wire x1="14.33" y1="8.71" x2="14.28" y2="8.84" width="0.262" layer="21"/>
<wire x1="14.28" y1="8.84" x2="14.23" y2="8.96" width="0.262" layer="21"/>
<wire x1="14.23" y1="8.96" x2="14.16" y2="9.08" width="0.262" layer="21"/>
<wire x1="14.16" y1="9.08" x2="14.09" y2="9.19" width="0.262" layer="21"/>
<wire x1="14.09" y1="9.19" x2="14.01" y2="9.29" width="0.262" layer="21"/>
<wire x1="14.01" y1="9.29" x2="13.91" y2="9.39" width="0.262" layer="21"/>
<wire x1="13.91" y1="9.39" x2="13.8" y2="9.47" width="0.262" layer="21"/>
<wire x1="13.8" y1="9.47" x2="13.69" y2="9.54" width="0.262" layer="21"/>
<wire x1="13.69" y1="9.54" x2="13.57" y2="9.6" width="0.262" layer="21"/>
<wire x1="13.57" y1="9.6" x2="13.44" y2="9.65" width="0.262" layer="21"/>
<wire x1="13.44" y1="9.65" x2="13.32" y2="9.68" width="0.262" layer="21"/>
<wire x1="13.32" y1="9.68" x2="13.18" y2="9.71" width="0.262" layer="21"/>
<wire x1="13.18" y1="9.71" x2="12.92" y2="9.73" width="0.262" layer="21"/>
<wire x1="12.92" y1="9.73" x2="12.78" y2="9.74" width="0.262" layer="21"/>
<wire x1="12.78" y1="9.74" x2="12.65" y2="9.73" width="0.262" layer="21"/>
<wire x1="12.65" y1="9.73" x2="12.37" y2="9.71" width="0.262" layer="21"/>
<wire x1="12.37" y1="9.71" x2="12.11" y2="9.65" width="0.262" layer="21"/>
<wire x1="12.11" y1="9.65" x2="11.98" y2="9.61" width="0.262" layer="21"/>
<wire x1="11.98" y1="9.61" x2="11.85" y2="9.55" width="0.262" layer="21"/>
<wire x1="11.85" y1="9.55" x2="11.73" y2="9.49" width="0.262" layer="21"/>
<wire x1="11.73" y1="9.49" x2="11.62" y2="9.41" width="0.262" layer="21"/>
<wire x1="11.62" y1="9.41" x2="11.51" y2="9.32" width="0.262" layer="21"/>
<wire x1="11.51" y1="9.32" x2="11.42" y2="9.23" width="0.262" layer="21"/>
<wire x1="11.42" y1="9.23" x2="11.33" y2="9.12" width="0.262" layer="21"/>
<wire x1="11.33" y1="9.12" x2="11.26" y2="9.01" width="0.262" layer="21"/>
<wire x1="11.26" y1="9.01" x2="11.19" y2="8.88" width="0.262" layer="21"/>
<wire x1="11.19" y1="8.88" x2="11.14" y2="8.76" width="0.262" layer="21"/>
<wire x1="11.14" y1="8.76" x2="11.09" y2="8.63" width="0.262" layer="21"/>
<wire x1="11.09" y1="8.63" x2="11.05" y2="8.5" width="0.262" layer="21"/>
<wire x1="11.05" y1="8.5" x2="11.02" y2="8.37" width="0.262" layer="21"/>
<wire x1="11.02" y1="8.37" x2="11" y2="8.23" width="0.262" layer="21"/>
<wire x1="11" y1="8.23" x2="10.98" y2="8.1" width="0.262" layer="21"/>
<wire x1="10.98" y1="8.1" x2="10.96" y2="7.96" width="0.262" layer="21"/>
<wire x1="10.96" y1="7.96" x2="10.95" y2="7.83" width="0.262" layer="21"/>
<wire x1="10.95" y1="7.83" x2="10.94" y2="7.69" width="0.262" layer="21"/>
<wire x1="10.94" y1="7.69" x2="10.94" y2="6.83" width="0.262" layer="21"/>
<wire x1="10.94" y1="6.83" x2="10.95" y2="6.69" width="0.262" layer="21"/>
<wire x1="10.95" y1="6.69" x2="10.96" y2="6.56" width="0.262" layer="21"/>
<wire x1="10.96" y1="6.56" x2="11" y2="6.28" width="0.262" layer="21"/>
<wire x1="11" y1="6.28" x2="11.02" y2="6.15" width="0.262" layer="21"/>
<wire x1="11.02" y1="6.15" x2="11.05" y2="6.01" width="0.262" layer="21"/>
<wire x1="11.05" y1="6.01" x2="11.09" y2="5.88" width="0.262" layer="21"/>
<wire x1="11.09" y1="5.88" x2="11.14" y2="5.75" width="0.262" layer="21"/>
<wire x1="11.14" y1="5.75" x2="11.2" y2="5.63" width="0.262" layer="21"/>
<wire x1="11.2" y1="5.63" x2="11.27" y2="5.51" width="0.262" layer="21"/>
<wire x1="11.27" y1="5.51" x2="11.35" y2="5.4" width="0.262" layer="21"/>
<wire x1="11.35" y1="5.4" x2="11.44" y2="5.29" width="0.262" layer="21"/>
<wire x1="11.44" y1="5.29" x2="11.54" y2="5.2" width="0.262" layer="21"/>
<wire x1="11.54" y1="5.2" x2="11.65" y2="5.12" width="0.262" layer="21"/>
<wire x1="11.65" y1="5.12" x2="11.77" y2="5.05" width="0.262" layer="21"/>
<wire x1="11.77" y1="5.05" x2="11.89" y2="4.99" width="0.262" layer="21"/>
<wire x1="11.89" y1="4.99" x2="12.02" y2="4.95" width="0.262" layer="21"/>
<wire x1="12.02" y1="4.95" x2="12.16" y2="4.91" width="0.262" layer="21"/>
<wire x1="12.16" y1="4.91" x2="12.29" y2="4.89" width="0.262" layer="21"/>
<wire x1="12.29" y1="4.89" x2="12.43" y2="4.87" width="0.262" layer="21"/>
<wire x1="12.43" y1="4.87" x2="12.57" y2="4.86" width="0.262" layer="21"/>
<wire x1="12.57" y1="4.86" x2="12.92" y2="4.86" width="0.262" layer="21"/>
<wire x1="12.92" y1="4.86" x2="13.06" y2="4.88" width="0.262" layer="21"/>
<wire x1="13.06" y1="4.88" x2="13.19" y2="4.9" width="0.262" layer="21"/>
<wire x1="13.19" y1="4.9" x2="13.33" y2="4.93" width="0.262" layer="21"/>
<wire x1="13.33" y1="4.93" x2="13.46" y2="4.97" width="0.262" layer="21"/>
<wire x1="13.46" y1="4.97" x2="13.58" y2="5.02" width="0.262" layer="21"/>
<wire x1="13.58" y1="5.02" x2="13.7" y2="5.08" width="0.262" layer="21"/>
<wire x1="13.7" y1="5.08" x2="13.82" y2="5.16" width="0.262" layer="21"/>
<wire x1="13.82" y1="5.16" x2="13.92" y2="5.24" width="0.262" layer="21"/>
<wire x1="13.92" y1="5.24" x2="14.02" y2="5.34" width="0.262" layer="21"/>
<wire x1="14.02" y1="5.34" x2="14.1" y2="5.45" width="0.262" layer="21"/>
<wire x1="14.1" y1="5.45" x2="14.17" y2="5.56" width="0.262" layer="21"/>
<wire x1="14.17" y1="5.56" x2="14.23" y2="5.68" width="0.262" layer="21"/>
<wire x1="14.23" y1="5.68" x2="14.28" y2="5.81" width="0.262" layer="21"/>
<wire x1="14.28" y1="5.81" x2="14.32" y2="5.94" width="0.262" layer="21"/>
<wire x1="14.32" y1="5.94" x2="14.35" y2="6.07" width="0.262" layer="21"/>
<wire x1="14.35" y1="6.07" x2="14.38" y2="6.21" width="0.262" layer="21"/>
<wire x1="14.38" y1="6.21" x2="14.39" y2="6.34" width="0.262" layer="21"/>
<wire x1="14.39" y1="6.34" x2="14.38" y2="6.43" width="0.262" layer="21"/>
<wire x1="14.38" y1="6.43" x2="14.34" y2="6.49" width="0.262" layer="21"/>
<wire x1="14.34" y1="6.49" x2="14.3" y2="6.53" width="0.262" layer="21"/>
<wire x1="14.3" y1="6.53" x2="13.4" y2="6.53" width="0.262" layer="21"/>
<wire x1="13.4" y1="6.53" x2="13.35" y2="6.45" width="0.262" layer="21"/>
<wire x1="10.48" y1="9.55" x2="10.46" y2="9.81" width="0.262" layer="21"/>
<wire x1="10.46" y1="9.81" x2="10.44" y2="9.95" width="0.262" layer="21"/>
<wire x1="10.44" y1="9.95" x2="10.42" y2="10.08" width="0.262" layer="21"/>
<wire x1="10.42" y1="10.08" x2="10.38" y2="10.21" width="0.262" layer="21"/>
<wire x1="10.38" y1="10.21" x2="10.33" y2="10.33" width="0.262" layer="21"/>
<wire x1="10.33" y1="10.33" x2="10.27" y2="10.45" width="0.262" layer="21"/>
<wire x1="10.27" y1="10.45" x2="10.2" y2="10.56" width="0.262" layer="21"/>
<wire x1="10.2" y1="10.56" x2="10.11" y2="10.67" width="0.262" layer="21"/>
<wire x1="10.11" y1="10.67" x2="10.02" y2="10.76" width="0.262" layer="21"/>
<wire x1="10.02" y1="10.76" x2="9.8" y2="10.92" width="0.262" layer="21"/>
<wire x1="9.8" y1="10.92" x2="9.68" y2="10.98" width="0.262" layer="21"/>
<wire x1="9.68" y1="10.98" x2="9.56" y2="11.03" width="0.262" layer="21"/>
<wire x1="9.56" y1="11.03" x2="9.3" y2="11.09" width="0.262" layer="21"/>
<wire x1="9.3" y1="11.09" x2="9.17" y2="11.11" width="0.262" layer="21"/>
<wire x1="9.17" y1="11.11" x2="9.03" y2="11.13" width="0.262" layer="21"/>
<wire x1="9.03" y1="11.13" x2="6.6" y2="11.13" width="0.262" layer="21"/>
<wire x1="6.6" y1="11.13" x2="6.55" y2="11.07" width="0.262" layer="21"/>
<wire x1="6.55" y1="11.07" x2="6.54" y2="10.98" width="0.262" layer="21"/>
<wire x1="6.54" y1="10.98" x2="6.54" y2="5.12" width="0.262" layer="21"/>
<wire x1="6.54" y1="5.12" x2="6.55" y2="5.04" width="0.262" layer="21"/>
<wire x1="6.55" y1="5.04" x2="6.6" y2="4.97" width="0.262" layer="21"/>
<wire x1="6.6" y1="4.97" x2="7.62" y2="4.97" width="0.262" layer="21"/>
<wire x1="7.62" y1="4.97" x2="7.69" y2="5" width="0.262" layer="21"/>
<wire x1="7.69" y1="5" x2="7.72" y2="5.07" width="0.262" layer="21"/>
<wire x1="7.72" y1="5.07" x2="7.77" y2="5.14" width="0.262" layer="21"/>
<wire x1="7.77" y1="5.14" x2="7.78" y2="5.23" width="0.262" layer="21"/>
<wire x1="7.78" y1="5.23" x2="7.78" y2="7.37" width="0.262" layer="21"/>
<wire x1="7.78" y1="7.37" x2="7.8" y2="7.46" width="0.262" layer="21"/>
<wire x1="7.8" y1="7.46" x2="7.85" y2="7.54" width="0.262" layer="21"/>
<wire x1="7.85" y1="7.54" x2="7.89" y2="7.58" width="0.262" layer="21"/>
<wire x1="7.89" y1="7.58" x2="8.48" y2="7.58" width="0.262" layer="21"/>
<wire x1="8.48" y1="7.58" x2="8.61" y2="7.57" width="0.262" layer="21"/>
<wire x1="8.61" y1="7.57" x2="8.74" y2="7.53" width="0.262" layer="21"/>
<wire x1="8.74" y1="7.53" x2="8.86" y2="7.48" width="0.262" layer="21"/>
<wire x1="8.86" y1="7.48" x2="8.96" y2="7.39" width="0.262" layer="21"/>
<wire x1="8.96" y1="7.39" x2="9.04" y2="7.29" width="0.262" layer="21"/>
<wire x1="9.04" y1="7.29" x2="9.09" y2="7.17" width="0.262" layer="21"/>
<wire x1="9.09" y1="7.17" x2="9.13" y2="7.05" width="0.262" layer="21"/>
<wire x1="9.13" y1="7.05" x2="9.16" y2="6.92" width="0.262" layer="21"/>
<wire x1="9.16" y1="6.92" x2="9.17" y2="6.8" width="0.262" layer="21"/>
<wire x1="9.17" y1="6.8" x2="9.19" y2="6.54" width="0.262" layer="21"/>
<wire x1="9.19" y1="6.54" x2="9.19" y2="6.41" width="0.262" layer="21"/>
<wire x1="9.19" y1="6.41" x2="9.2" y2="6.28" width="0.262" layer="21"/>
<wire x1="9.2" y1="6.28" x2="9.2" y2="6.03" width="0.262" layer="21"/>
<wire x1="9.2" y1="6.03" x2="9.21" y2="5.9" width="0.262" layer="21"/>
<wire x1="9.21" y1="5.9" x2="9.21" y2="5.78" width="0.262" layer="21"/>
<wire x1="9.21" y1="5.78" x2="9.24" y2="5.45" width="0.262" layer="21"/>
<wire x1="9.24" y1="5.45" x2="9.26" y2="5.34" width="0.262" layer="21"/>
<wire x1="9.26" y1="5.34" x2="9.28" y2="5.26" width="0.262" layer="21"/>
<wire x1="9.28" y1="5.26" x2="9.31" y2="5.18" width="0.262" layer="21"/>
<wire x1="9.31" y1="5.18" x2="9.37" y2="5.1" width="0.262" layer="21"/>
<wire x1="9.37" y1="5.1" x2="9.44" y2="5.02" width="0.262" layer="21"/>
<wire x1="9.44" y1="5.02" x2="9.54" y2="4.97" width="0.262" layer="21"/>
<wire x1="9.54" y1="4.97" x2="10.59" y2="4.97" width="0.262" layer="21"/>
<wire x1="10.59" y1="4.97" x2="10.62" y2="5.04" width="0.262" layer="21"/>
<wire x1="10.62" y1="5.04" x2="10.62" y2="5.12" width="0.262" layer="21"/>
<wire x1="10.62" y1="5.12" x2="10.61" y2="5.17" width="0.262" layer="21"/>
<wire x1="10.61" y1="5.17" x2="10.57" y2="5.29" width="0.262" layer="21"/>
<wire x1="10.57" y1="5.29" x2="10.51" y2="5.42" width="0.262" layer="21"/>
<wire x1="10.51" y1="5.42" x2="10.48" y2="5.55" width="0.262" layer="21"/>
<wire x1="10.48" y1="5.55" x2="10.46" y2="5.69" width="0.262" layer="21"/>
<wire x1="10.46" y1="5.69" x2="10.45" y2="5.82" width="0.262" layer="21"/>
<wire x1="10.45" y1="5.82" x2="10.45" y2="5.96" width="0.262" layer="21"/>
<wire x1="10.45" y1="5.96" x2="10.44" y2="6.07" width="0.262" layer="21"/>
<wire x1="10.44" y1="6.07" x2="10.44" y2="6.29" width="0.262" layer="21"/>
<wire x1="10.44" y1="6.29" x2="10.43" y2="6.43" width="0.262" layer="21"/>
<wire x1="10.43" y1="6.43" x2="10.43" y2="6.57" width="0.262" layer="21"/>
<wire x1="10.43" y1="6.57" x2="10.42" y2="6.7" width="0.262" layer="21"/>
<wire x1="10.42" y1="6.7" x2="10.4" y2="6.84" width="0.262" layer="21"/>
<wire x1="10.4" y1="6.84" x2="10.39" y2="6.97" width="0.262" layer="21"/>
<wire x1="10.39" y1="6.97" x2="10.37" y2="7.11" width="0.262" layer="21"/>
<wire x1="10.37" y1="7.11" x2="10.34" y2="7.24" width="0.262" layer="21"/>
<wire x1="10.34" y1="7.24" x2="10.3" y2="7.37" width="0.262" layer="21"/>
<wire x1="10.3" y1="7.37" x2="10.25" y2="7.5" width="0.262" layer="21"/>
<wire x1="10.25" y1="7.5" x2="10.18" y2="7.62" width="0.262" layer="21"/>
<wire x1="10.18" y1="7.62" x2="10.09" y2="7.72" width="0.262" layer="21"/>
<wire x1="10.09" y1="7.72" x2="9.98" y2="7.8" width="0.262" layer="21"/>
<wire x1="9.98" y1="7.8" x2="9.86" y2="7.87" width="0.262" layer="21"/>
<wire x1="9.86" y1="7.87" x2="9.73" y2="7.92" width="0.262" layer="21"/>
<wire x1="9.73" y1="7.92" x2="9.66" y2="7.96" width="0.262" layer="21"/>
<wire x1="9.66" y1="7.96" x2="9.59" y2="8.03" width="0.262" layer="21"/>
<wire x1="9.59" y1="8.03" x2="9.65" y2="8.09" width="0.262" layer="21"/>
<wire x1="9.65" y1="8.09" x2="9.71" y2="8.14" width="0.262" layer="21"/>
<wire x1="9.71" y1="8.14" x2="9.83" y2="8.19" width="0.262" layer="21"/>
<wire x1="9.83" y1="8.19" x2="9.95" y2="8.26" width="0.262" layer="21"/>
<wire x1="9.95" y1="8.26" x2="10.05" y2="8.34" width="0.262" layer="21"/>
<wire x1="10.05" y1="8.34" x2="10.14" y2="8.44" width="0.262" layer="21"/>
<wire x1="10.14" y1="8.44" x2="10.22" y2="8.54" width="0.262" layer="21"/>
<wire x1="10.22" y1="8.54" x2="10.29" y2="8.65" width="0.262" layer="21"/>
<wire x1="10.29" y1="8.65" x2="10.35" y2="8.77" width="0.262" layer="21"/>
<wire x1="10.35" y1="8.77" x2="10.39" y2="8.9" width="0.262" layer="21"/>
<wire x1="10.39" y1="8.9" x2="10.42" y2="9.02" width="0.262" layer="21"/>
<wire x1="10.42" y1="9.02" x2="10.45" y2="9.15" width="0.262" layer="21"/>
<wire x1="10.45" y1="9.15" x2="10.46" y2="9.28" width="0.262" layer="21"/>
<wire x1="10.46" y1="9.28" x2="10.47" y2="9.42" width="0.262" layer="21"/>
<wire x1="10.47" y1="9.42" x2="10.48" y2="9.55" width="0.262" layer="21"/>
<wire x1="18.48" y1="5.04" x2="18.5" y2="5.13" width="0.262" layer="21"/>
<wire x1="18.5" y1="5.13" x2="18.5" y2="11.07" width="0.262" layer="21"/>
<wire x1="18.5" y1="11.07" x2="18.44" y2="11.12" width="0.262" layer="21"/>
<wire x1="18.44" y1="11.12" x2="18.37" y2="11.13" width="0.262" layer="21"/>
<wire x1="18.37" y1="11.13" x2="17.37" y2="11.13" width="0.262" layer="21"/>
<wire x1="17.37" y1="11.13" x2="17.31" y2="11.06" width="0.262" layer="21"/>
<wire x1="17.31" y1="11.06" x2="17.3" y2="10.96" width="0.262" layer="21"/>
<wire x1="17.3" y1="10.96" x2="17.3" y2="9.44" width="0.262" layer="21"/>
<wire x1="17.3" y1="9.44" x2="17.29" y2="9.35" width="0.262" layer="21"/>
<wire x1="17.29" y1="9.35" x2="17.24" y2="9.29" width="0.262" layer="21"/>
<wire x1="17.24" y1="9.29" x2="17.13" y2="9.36" width="0.262" layer="21"/>
<wire x1="17.13" y1="9.36" x2="17.03" y2="9.46" width="0.262" layer="21"/>
<wire x1="17.03" y1="9.46" x2="16.92" y2="9.54" width="0.262" layer="21"/>
<wire x1="16.92" y1="9.54" x2="16.81" y2="9.61" width="0.262" layer="21"/>
<wire x1="16.81" y1="9.61" x2="16.68" y2="9.67" width="0.262" layer="21"/>
<wire x1="16.68" y1="9.67" x2="16.55" y2="9.7" width="0.262" layer="21"/>
<wire x1="16.55" y1="9.7" x2="16.42" y2="9.72" width="0.262" layer="21"/>
<wire x1="16.42" y1="9.72" x2="16.28" y2="9.73" width="0.262" layer="21"/>
<wire x1="16.28" y1="9.73" x2="16.15" y2="9.73" width="0.262" layer="21"/>
<wire x1="16.15" y1="9.73" x2="16.02" y2="9.71" width="0.262" layer="21"/>
<wire x1="16.02" y1="9.71" x2="15.89" y2="9.68" width="0.262" layer="21"/>
<wire x1="15.89" y1="9.68" x2="15.76" y2="9.64" width="0.262" layer="21"/>
<wire x1="15.76" y1="9.64" x2="15.64" y2="9.58" width="0.262" layer="21"/>
<wire x1="15.64" y1="9.58" x2="15.53" y2="9.51" width="0.262" layer="21"/>
<wire x1="15.53" y1="9.51" x2="15.43" y2="9.43" width="0.262" layer="21"/>
<wire x1="15.43" y1="9.43" x2="15.33" y2="9.33" width="0.262" layer="21"/>
<wire x1="15.33" y1="9.33" x2="15.25" y2="9.22" width="0.262" layer="21"/>
<wire x1="15.25" y1="9.22" x2="15.19" y2="9.11" width="0.262" layer="21"/>
<wire x1="15.19" y1="9.11" x2="15.13" y2="8.99" width="0.262" layer="21"/>
<wire x1="15.13" y1="8.99" x2="15.08" y2="8.87" width="0.262" layer="21"/>
<wire x1="15.08" y1="8.87" x2="15.03" y2="8.74" width="0.262" layer="21"/>
<wire x1="15.03" y1="8.74" x2="15" y2="8.61" width="0.262" layer="21"/>
<wire x1="15" y1="8.61" x2="14.97" y2="8.49" width="0.262" layer="21"/>
<wire x1="14.97" y1="8.49" x2="14.94" y2="8.35" width="0.262" layer="21"/>
<wire x1="14.94" y1="8.35" x2="14.9" y2="8.09" width="0.262" layer="21"/>
<wire x1="14.9" y1="8.09" x2="14.88" y2="7.83" width="0.262" layer="21"/>
<wire x1="14.88" y1="7.83" x2="14.87" y2="7.69" width="0.262" layer="21"/>
<wire x1="14.87" y1="7.69" x2="14.87" y2="7.56" width="0.262" layer="21"/>
<wire x1="14.87" y1="7.56" x2="14.86" y2="7.43" width="0.262" layer="21"/>
<wire x1="14.86" y1="7.43" x2="14.86" y2="7.16" width="0.262" layer="21"/>
<wire x1="14.86" y1="7.16" x2="14.87" y2="7.03" width="0.262" layer="21"/>
<wire x1="14.87" y1="7.03" x2="14.87" y2="6.89" width="0.262" layer="21"/>
<wire x1="14.87" y1="6.89" x2="14.9" y2="6.5" width="0.262" layer="21"/>
<wire x1="14.9" y1="6.5" x2="14.92" y2="6.36" width="0.262" layer="21"/>
<wire x1="14.92" y1="6.36" x2="14.94" y2="6.23" width="0.262" layer="21"/>
<wire x1="14.94" y1="6.23" x2="15" y2="5.97" width="0.262" layer="21"/>
<wire x1="15" y1="5.97" x2="15.03" y2="5.85" width="0.262" layer="21"/>
<wire x1="15.03" y1="5.85" x2="15.08" y2="5.72" width="0.262" layer="21"/>
<wire x1="15.08" y1="5.72" x2="15.18" y2="5.48" width="0.262" layer="21"/>
<wire x1="15.18" y1="5.48" x2="15.25" y2="5.37" width="0.262" layer="21"/>
<wire x1="15.25" y1="5.37" x2="15.33" y2="5.26" width="0.262" layer="21"/>
<wire x1="15.33" y1="5.26" x2="15.42" y2="5.16" width="0.262" layer="21"/>
<wire x1="15.42" y1="5.16" x2="15.53" y2="5.08" width="0.262" layer="21"/>
<wire x1="15.53" y1="5.08" x2="15.64" y2="5.01" width="0.262" layer="21"/>
<wire x1="15.64" y1="5.01" x2="15.76" y2="4.95" width="0.262" layer="21"/>
<wire x1="15.76" y1="4.95" x2="15.88" y2="4.91" width="0.262" layer="21"/>
<wire x1="15.88" y1="4.91" x2="16.01" y2="4.88" width="0.262" layer="21"/>
<wire x1="16.01" y1="4.88" x2="16.14" y2="4.86" width="0.262" layer="21"/>
<wire x1="16.14" y1="4.86" x2="16.42" y2="4.86" width="0.262" layer="21"/>
<wire x1="16.42" y1="4.86" x2="16.55" y2="4.88" width="0.262" layer="21"/>
<wire x1="16.55" y1="4.88" x2="16.67" y2="4.91" width="0.262" layer="21"/>
<wire x1="16.67" y1="4.91" x2="16.79" y2="4.96" width="0.262" layer="21"/>
<wire x1="16.79" y1="4.96" x2="16.9" y2="5.02" width="0.262" layer="21"/>
<wire x1="16.9" y1="5.02" x2="17" y2="5.09" width="0.262" layer="21"/>
<wire x1="17" y1="5.09" x2="17.1" y2="5.18" width="0.262" layer="21"/>
<wire x1="17.1" y1="5.18" x2="17.18" y2="5.27" width="0.262" layer="21"/>
<wire x1="17.18" y1="5.27" x2="17.28" y2="5.35" width="0.262" layer="21"/>
<wire x1="17.28" y1="5.35" x2="17.34" y2="5.3" width="0.262" layer="21"/>
<wire x1="17.34" y1="5.3" x2="17.36" y2="5.22" width="0.262" layer="21"/>
<wire x1="17.36" y1="5.22" x2="17.36" y2="5.21" width="0.262" layer="21"/>
<wire x1="17.36" y1="5.21" x2="17.37" y2="5.08" width="0.262" layer="21"/>
<wire x1="17.37" y1="5.08" x2="17.42" y2="4.97" width="0.262" layer="21"/>
<wire x1="17.42" y1="4.97" x2="18.43" y2="4.97" width="0.262" layer="21"/>
<wire x1="18.43" y1="4.97" x2="18.48" y2="5.04" width="0.262" layer="21"/>
<wire x1="16.54" y1="8.81" x2="16.42" y2="8.76" width="0.262" layer="21"/>
<wire x1="16.42" y1="8.76" x2="16.32" y2="8.69" width="0.262" layer="21"/>
<wire x1="16.32" y1="8.69" x2="16.24" y2="8.58" width="0.262" layer="21"/>
<wire x1="16.24" y1="8.58" x2="16.18" y2="8.46" width="0.262" layer="21"/>
<wire x1="16.18" y1="8.46" x2="16.14" y2="8.34" width="0.262" layer="21"/>
<wire x1="16.14" y1="8.34" x2="16.11" y2="8.21" width="0.262" layer="21"/>
<wire x1="16.11" y1="8.21" x2="16.09" y2="8.08" width="0.262" layer="21"/>
<wire x1="16.09" y1="8.08" x2="16.06" y2="7.69" width="0.262" layer="21"/>
<wire x1="16.06" y1="7.69" x2="16.06" y2="7.56" width="0.262" layer="21"/>
<wire x1="16.06" y1="7.56" x2="16.05" y2="7.42" width="0.262" layer="21"/>
<wire x1="16.05" y1="7.42" x2="16.05" y2="7.16" width="0.262" layer="21"/>
<wire x1="16.05" y1="7.16" x2="16.06" y2="7.03" width="0.262" layer="21"/>
<wire x1="16.06" y1="7.03" x2="16.06" y2="6.9" width="0.262" layer="21"/>
<wire x1="16.06" y1="6.9" x2="16.09" y2="6.51" width="0.262" layer="21"/>
<wire x1="16.09" y1="6.51" x2="16.11" y2="6.38" width="0.262" layer="21"/>
<wire x1="16.11" y1="6.38" x2="16.14" y2="6.25" width="0.262" layer="21"/>
<wire x1="16.14" y1="6.25" x2="16.18" y2="6.12" width="0.262" layer="21"/>
<wire x1="16.18" y1="6.12" x2="16.24" y2="6.01" width="0.262" layer="21"/>
<wire x1="16.24" y1="6.01" x2="16.32" y2="5.9" width="0.262" layer="21"/>
<wire x1="16.32" y1="5.9" x2="16.42" y2="5.82" width="0.262" layer="21"/>
<wire x1="16.42" y1="5.82" x2="16.54" y2="5.78" width="0.262" layer="21"/>
<wire x1="16.54" y1="5.78" x2="16.67" y2="5.77" width="0.262" layer="21"/>
<wire x1="16.67" y1="5.77" x2="16.81" y2="5.78" width="0.262" layer="21"/>
<wire x1="16.81" y1="5.78" x2="16.93" y2="5.82" width="0.262" layer="21"/>
<wire x1="16.93" y1="5.82" x2="17.04" y2="5.9" width="0.262" layer="21"/>
<wire x1="17.04" y1="5.9" x2="17.12" y2="6" width="0.262" layer="21"/>
<wire x1="17.12" y1="6" x2="17.17" y2="6.12" width="0.262" layer="21"/>
<wire x1="17.17" y1="6.12" x2="17.22" y2="6.25" width="0.262" layer="21"/>
<wire x1="17.22" y1="6.25" x2="17.25" y2="6.37" width="0.262" layer="21"/>
<wire x1="17.25" y1="6.37" x2="17.27" y2="6.5" width="0.262" layer="21"/>
<wire x1="17.27" y1="6.5" x2="17.28" y2="6.63" width="0.262" layer="21"/>
<wire x1="17.28" y1="6.63" x2="17.29" y2="6.77" width="0.262" layer="21"/>
<wire x1="17.29" y1="6.77" x2="17.3" y2="6.9" width="0.262" layer="21"/>
<wire x1="17.3" y1="6.9" x2="17.3" y2="7.69" width="0.262" layer="21"/>
<wire x1="17.3" y1="7.69" x2="17.27" y2="8.08" width="0.262" layer="21"/>
<wire x1="17.27" y1="8.08" x2="17.25" y2="8.21" width="0.262" layer="21"/>
<wire x1="17.25" y1="8.21" x2="17.22" y2="8.34" width="0.262" layer="21"/>
<wire x1="17.22" y1="8.34" x2="17.17" y2="8.47" width="0.262" layer="21"/>
<wire x1="17.17" y1="8.47" x2="17.12" y2="8.58" width="0.262" layer="21"/>
<wire x1="17.12" y1="8.58" x2="17.04" y2="8.69" width="0.262" layer="21"/>
<wire x1="17.04" y1="8.69" x2="16.93" y2="8.77" width="0.262" layer="21"/>
<wire x1="16.93" y1="8.77" x2="16.81" y2="8.81" width="0.262" layer="21"/>
<wire x1="16.81" y1="8.81" x2="16.67" y2="8.82" width="0.262" layer="21"/>
<wire x1="16.67" y1="8.82" x2="16.54" y2="8.81" width="0.262" layer="21"/>
<wire x1="0.15" y1="12.6" x2="36.33" y2="12.6" width="0.262" layer="21"/>
<wire x1="36.33" y1="12.6" x2="36.33" y2="0.15" width="0.262" layer="21"/>
<wire x1="36.33" y1="0.15" x2="0.15" y2="0.15" width="0.262" layer="21"/>
<wire x1="0.15" y1="0.15" x2="0.15" y2="12.6" width="0.262" layer="21"/>
</package>
<package name="SPARKPUNK_LOGO_.1">
<polygon width="0.011" layer="21">
<vertex x="0.65" y="0.87"/>
<vertex x="0.65" y="0.82"/>
<vertex x="0.66" y="0.77"/>
<vertex x="0.67" y="0.73"/>
<vertex x="0.71" y="0.65"/>
<vertex x="0.77" y="0.59"/>
<vertex x="0.8" y="0.57"/>
<vertex x="0.92" y="0.51"/>
<vertex x="1" y="0.49"/>
<vertex x="1.05" y="0.48"/>
<vertex x="1.24" y="0.48"/>
<vertex x="1.28" y="0.49"/>
<vertex x="1.31" y="0.5"/>
<vertex x="1.35" y="0.51"/>
<vertex x="1.38" y="0.52"/>
<vertex x="1.47" y="0.58"/>
<vertex x="1.52" y="0.63"/>
<vertex x="1.54" y="0.69"/>
<vertex x="1.56" y="0.77"/>
<vertex x="1.55" y="0.81"/>
<vertex x="1.53" y="0.87"/>
<vertex x="1.48" y="0.92"/>
<vertex x="1.45" y="0.94"/>
<vertex x="1.41" y="0.97"/>
<vertex x="1.36" y="0.99"/>
<vertex x="1.32" y="1.01"/>
<vertex x="1.26" y="1.03"/>
<vertex x="1.2" y="1.04"/>
<vertex x="1.14" y="1.06"/>
<vertex x="1.07" y="1.08"/>
<vertex x="0.99" y="1.09"/>
<vertex x="0.92" y="1.11"/>
<vertex x="0.83" y="1.13"/>
<vertex x="0.76" y="1.15"/>
<vertex x="0.7" y="1.16"/>
<vertex x="0.56" y="1.2"/>
<vertex x="0.5" y="1.23"/>
<vertex x="0.44" y="1.25"/>
<vertex x="0.38" y="1.28"/>
<vertex x="0.33" y="1.32"/>
<vertex x="0.28" y="1.35"/>
<vertex x="0.23" y="1.39"/>
<vertex x="0.19" y="1.44"/>
<vertex x="0.16" y="1.49"/>
<vertex x="0.13" y="1.55"/>
<vertex x="0.11" y="1.61"/>
<vertex x="0.1" y="1.67"/>
<vertex x="0.1" y="1.85"/>
<vertex x="0.12" y="1.95"/>
<vertex x="0.15" y="2.04"/>
<vertex x="0.23" y="2.18"/>
<vertex x="0.35" y="2.3"/>
<vertex x="0.49" y="2.38"/>
<vertex x="0.65" y="2.44"/>
<vertex x="0.74" y="2.46"/>
<vertex x="1.01" y="2.49"/>
<vertex x="1.2" y="2.49"/>
<vertex x="1.47" y="2.46"/>
<vertex x="1.56" y="2.44"/>
<vertex x="1.72" y="2.38"/>
<vertex x="1.79" y="2.34"/>
<vertex x="1.85" y="2.29"/>
<vertex x="1.92" y="2.24"/>
<vertex x="1.97" y="2.18"/>
<vertex x="2.02" y="2.11"/>
<vertex x="2.06" y="2.03"/>
<vertex x="2.09" y="1.95"/>
<vertex x="2.13" y="1.75"/>
<vertex x="1.52" y="1.75"/>
<vertex x="1.52" y="1.8"/>
<vertex x="1.51" y="1.84"/>
<vertex x="1.5" y="1.87"/>
<vertex x="1.48" y="1.91"/>
<vertex x="1.46" y="1.93"/>
<vertex x="1.44" y="1.96"/>
<vertex x="1.41" y="1.98"/>
<vertex x="1.39" y="2"/>
<vertex x="1.36" y="2.02"/>
<vertex x="1.32" y="2.03"/>
<vertex x="1.29" y="2.04"/>
<vertex x="1.21" y="2.06"/>
<vertex x="1.17" y="2.06"/>
<vertex x="1.13" y="2.07"/>
<vertex x="1.03" y="2.07"/>
<vertex x="1" y="2.06"/>
<vertex x="0.94" y="2.06"/>
<vertex x="0.91" y="2.05"/>
<vertex x="0.89" y="2.04"/>
<vertex x="0.83" y="2.02"/>
<vertex x="0.81" y="2"/>
<vertex x="0.79" y="1.99"/>
<vertex x="0.77" y="1.97"/>
<vertex x="0.76" y="1.94"/>
<vertex x="0.74" y="1.92"/>
<vertex x="0.74" y="1.89"/>
<vertex x="0.73" y="1.85"/>
<vertex x="0.75" y="1.77"/>
<vertex x="0.77" y="1.74"/>
<vertex x="0.8" y="1.71"/>
<vertex x="0.83" y="1.69"/>
<vertex x="0.87" y="1.66"/>
<vertex x="0.91" y="1.64"/>
<vertex x="0.96" y="1.62"/>
<vertex x="1.01" y="1.61"/>
<vertex x="1.07" y="1.59"/>
<vertex x="1.13" y="1.58"/>
<vertex x="1.19" y="1.56"/>
<vertex x="1.26" y="1.55"/>
<vertex x="1.32" y="1.54"/>
<vertex x="1.39" y="1.52"/>
<vertex x="1.46" y="1.51"/>
<vertex x="1.6" y="1.47"/>
<vertex x="1.66" y="1.45"/>
<vertex x="1.73" y="1.43"/>
<vertex x="1.79" y="1.4"/>
<vertex x="1.85" y="1.38"/>
<vertex x="1.91" y="1.35"/>
<vertex x="2.06" y="1.23"/>
<vertex x="2.1" y="1.18"/>
<vertex x="2.13" y="1.13"/>
<vertex x="2.16" y="1.07"/>
<vertex x="2.18" y="1"/>
<vertex x="2.19" y="0.93"/>
<vertex x="2.19" y="0.75"/>
<vertex x="2.17" y="0.65"/>
<vertex x="2.14" y="0.56"/>
<vertex x="2.1" y="0.47"/>
<vertex x="2" y="0.33"/>
<vertex x="1.93" y="0.27"/>
<vertex x="1.86" y="0.22"/>
<vertex x="1.7" y="0.14"/>
<vertex x="1.61" y="0.11"/>
<vertex x="1.43" y="0.07"/>
<vertex x="1.23" y="0.05"/>
<vertex x="1.03" y="0.05"/>
<vertex x="0.93" y="0.06"/>
<vertex x="0.84" y="0.07"/>
<vertex x="0.74" y="0.09"/>
<vertex x="0.65" y="0.11"/>
<vertex x="0.56" y="0.15"/>
<vertex x="0.47" y="0.18"/>
<vertex x="0.4" y="0.23"/>
<vertex x="0.32" y="0.28"/>
<vertex x="0.2" y="0.4"/>
<vertex x="0.15" y="0.48"/>
<vertex x="0.11" y="0.56"/>
<vertex x="0.08" y="0.65"/>
<vertex x="0.05" y="0.75"/>
<vertex x="0.04" y="0.87"/>
</polygon>
<vertex x="3.83" y="2.48"/>
<vertex x="3.79" y="2.48"/>
<vertex x="3.79" y="2.49"/>
<vertex x="3.64" y="2.49"/>
<vertex x="3.49" y="2.46"/>
<vertex x="3.45" y="2.45"/>
<vertex x="3.4" y="2.43"/>
<vertex x="3.36" y="2.41"/>
<vertex x="3.31" y="2.38"/>
<vertex x="3.27" y="2.36"/>
<vertex x="3.19" y="2.3"/>
<vertex x="3.16" y="2.26"/>
<vertex x="3.12" y="2.22"/>
<vertex x="3.09" y="2.18"/>
<vertex x="3.06" y="2.13"/>
<vertex x="3.05" y="2.13"/>
<vertex x="3.05" y="2.43"/>
<vertex x="2.45" y="2.32"/>
<vertex x="2.45" y="-0.7"/>
<vertex x="3.08" y="-1.27"/>
<vertex x="3.08" y="0.4"/>
<vertex x="3.09" y="0.4"/>
<vertex x="3.12" y="0.36"/>
<vertex x="3.16" y="0.32"/>
<vertex x="3.19" y="0.28"/>
<vertex x="3.35" y="0.16"/>
<vertex x="3.39" y="0.14"/>
<vertex x="3.44" y="0.12"/>
<vertex x="3.48" y="0.1"/>
<vertex x="3.53" y="0.09"/>
<vertex x="3.58" y="0.07"/>
<vertex x="3.63" y="0.06"/>
<vertex x="3.68" y="0.06"/>
<vertex x="3.73" y="0.05"/>
<vertex x="3.81" y="0.05"/>
<vertex x="3.81" y="0.06"/>
<vertex x="3.83" y="0.06"/>
<vertex x="3.83" y="0.58"/>
<vertex x="3.82" y="0.57"/>
<vertex x="3.8" y="0.57"/>
<vertex x="3.79" y="0.56"/>
<vertex x="3.77" y="0.56"/>
<vertex x="3.76" y="0.55"/>
<vertex x="3.74" y="0.55"/>
<vertex x="3.73" y="0.54"/>
<vertex x="3.69" y="0.54"/>
<vertex x="3.67" y="0.53"/>
<vertex x="3.54" y="0.53"/>
<vertex x="3.47" y="0.55"/>
<vertex x="3.35" y="0.59"/>
<vertex x="3.3" y="0.62"/>
<vertex x="3.26" y="0.66"/>
<vertex x="3.18" y="0.76"/>
<vertex x="3.15" y="0.81"/>
<vertex x="3.09" y="0.99"/>
<vertex x="3.08" y="1.06"/>
<vertex x="3.07" y="1.12"/>
<vertex x="3.06" y="1.19"/>
<vertex x="3.06" y="1.33"/>
<vertex x="3.09" y="1.54"/>
<vertex x="3.1" y="1.6"/>
<vertex x="3.12" y="1.67"/>
<vertex x="3.15" y="1.73"/>
<vertex x="3.21" y="1.83"/>
<vertex x="3.25" y="1.88"/>
<vertex x="3.3" y="1.92"/>
<vertex x="3.4" y="1.98"/>
<vertex x="3.47" y="2"/>
<vertex x="3.54" y="2.01"/>
<vertex x="3.7" y="2.01"/>
<vertex x="3.71" y="2"/>
<vertex x="3.73" y="2"/>
<vertex x="3.74" y="1.99"/>
<vertex x="3.77" y="1.99"/>
<vertex x="3.78" y="1.98"/>
<vertex x="3.79" y="1.98"/>
<vertex x="3.8" y="1.97"/>
<vertex x="3.82" y="1.97"/>
<vertex x="3.83" y="1.96"/>
</polygon>
<vertex x="3.87" y="1.94"/>
<vertex x="3.95" y="1.88"/>
<vertex x="3.98" y="1.85"/>
<vertex x="4.07" y="1.73"/>
<vertex x="4.11" y="1.63"/>
<vertex x="4.12" y="1.58"/>
<vertex x="4.14" y="1.53"/>
<vertex x="4.16" y="1.43"/>
<vertex x="4.16" y="1.37"/>
<vertex x="4.17" y="1.32"/>
<vertex x="4.17" y="1.21"/>
<vertex x="4.16" y="1.15"/>
<vertex x="4.16" y="1.1"/>
<vertex x="4.15" y="1.05"/>
<vertex x="4.14" y="0.99"/>
<vertex x="4.13" y="0.94"/>
<vertex x="4.11" y="0.89"/>
<vertex x="4.09" y="0.85"/>
<vertex x="4.07" y="0.8"/>
<vertex x="4.04" y="0.76"/>
<vertex x="4.02" y="0.72"/>
<vertex x="3.98" y="0.69"/>
<vertex x="3.95" y="0.66"/>
<vertex x="3.87" y="0.6"/>
<vertex x="3.95" y="0.07"/>
<vertex x="4.06" y="0.09"/>
<vertex x="4.16" y="0.13"/>
<vertex x="4.25" y="0.17"/>
<vertex x="4.34" y="0.22"/>
<vertex x="4.42" y="0.29"/>
<vertex x="4.49" y="0.36"/>
<vertex x="4.56" y="0.44"/>
<vertex x="4.62" y="0.52"/>
<vertex x="4.67" y="0.61"/>
<vertex x="4.71" y="0.71"/>
<vertex x="4.74" y="0.81"/>
<vertex x="4.77" y="0.92"/>
<vertex x="4.79" y="1.02"/>
<vertex x="4.8" y="1.13"/>
<vertex x="4.8" y="1.36"/>
<vertex x="4.79" y="1.48"/>
<vertex x="4.77" y="1.59"/>
<vertex x="4.74" y="1.7"/>
<vertex x="4.71" y="1.8"/>
<vertex x="4.67" y="1.9"/>
<vertex x="4.62" y="2"/>
<vertex x="4.5" y="2.16"/>
<vertex x="4.43" y="2.23"/>
<vertex x="4.35" y="2.3"/>
<vertex x="4.26" y="2.35"/>
<vertex x="4.16" y="2.4"/>
<vertex x="4.06" y="2.44"/>
<vertex x="3.95" y="2.46"/>
</polygon>
<vertex x="6.23" y="0.13"/>
<vertex x="6.23" y="0.52"/>
<vertex x="6.21" y="0.52"/>
<vertex x="6.2" y="0.51"/>
<vertex x="6.18" y="0.51"/>
<vertex x="6.17" y="0.5"/>
<vertex x="6.16" y="0.5"/>
<vertex x="6.14" y="0.49"/>
<vertex x="6.12" y="0.49"/>
<vertex x="6.1" y="0.48"/>
<vertex x="5.9" y="0.48"/>
<vertex x="5.86" y="0.49"/>
<vertex x="5.77" y="0.52"/>
<vertex x="5.74" y="0.54"/>
<vertex x="5.72" y="0.55"/>
<vertex x="5.67" y="0.6"/>
<vertex x="5.66" y="0.63"/>
<vertex x="5.64" y="0.66"/>
<vertex x="5.63" y="0.69"/>
<vertex x="5.63" y="0.73"/>
<vertex x="5.62" y="0.77"/>
<vertex x="5.63" y="0.81"/>
<vertex x="5.63" y="0.85"/>
<vertex x="5.64" y="0.89"/>
<vertex x="5.65" y="0.92"/>
<vertex x="5.67" y="0.95"/>
<vertex x="5.69" y="0.97"/>
<vertex x="5.71" y="1"/>
<vertex x="5.74" y="1.02"/>
<vertex x="5.77" y="1.03"/>
<vertex x="5.79" y="1.05"/>
<vertex x="5.83" y="1.06"/>
<vertex x="5.86" y="1.08"/>
<vertex x="5.89" y="1.09"/>
<vertex x="5.93" y="1.1"/>
<vertex x="5.96" y="1.1"/>
<vertex x="6" y="1.11"/>
<vertex x="6.01" y="1.11"/>
<vertex x="6.03" y="1.12"/>
<vertex x="6.07" y="1.12"/>
<vertex x="6.09" y="1.13"/>
<vertex x="6.14" y="1.13"/>
<vertex x="6.16" y="1.14"/>
<vertex x="6.23" y="1.14"/>
<vertex x="6.23" y="1.51"/>
<vertex x="6.14" y="1.5"/>
<vertex x="6.05" y="1.48"/>
<vertex x="5.85" y="1.46"/>
<vertex x="5.74" y="1.45"/>
<vertex x="5.54" y="1.41"/>
<vertex x="5.44" y="1.38"/>
<vertex x="5.35" y="1.34"/>
<vertex x="5.19" y="1.24"/>
<vertex x="5.12" y="1.17"/>
<vertex x="5.07" y="1.09"/>
<vertex x="5.02" y="0.99"/>
<vertex x="5" y="0.87"/>
<vertex x="4.99" y="0.74"/>
<vertex x="4.99" y="0.66"/>
<vertex x="5" y="0.58"/>
<vertex x="5.02" y="0.5"/>
<vertex x="5.05" y="0.43"/>
<vertex x="5.08" y="0.37"/>
<vertex x="5.12" y="0.31"/>
<vertex x="5.16" y="0.26"/>
<vertex x="5.22" y="0.22"/>
<vertex x="5.27" y="0.18"/>
<vertex x="5.33" y="0.14"/>
<vertex x="5.4" y="0.12"/>
<vertex x="5.47" y="0.09"/>
<vertex x="5.54" y="0.07"/>
<vertex x="5.61" y="0.06"/>
<vertex x="5.69" y="0.05"/>
<vertex x="5.86" y="0.05"/>
<vertex x="5.89" y="0.06"/>
<vertex x="5.95" y="0.06"/>
<vertex x="5.98" y="0.07"/>
<vertex x="6.01" y="0.07"/>
<vertex x="6.03" y="0.08"/>
<vertex x="6.06" y="0.08"/>
<vertex x="6.12" y="0.1"/>
<vertex x="6.14" y="0.1"/>
</polygon>
<vertex x="6.32" y="2.49"/>
<vertex x="6.05" y="2.49"/>
<vertex x="5.95" y="2.48"/>
<vertex x="5.86" y="2.47"/>
<vertex x="5.76" y="2.46"/>
<vertex x="5.58" y="2.4"/>
<vertex x="5.5" y="2.37"/>
<vertex x="5.42" y="2.33"/>
<vertex x="5.35" y="2.28"/>
<vertex x="5.28" y="2.22"/>
<vertex x="5.22" y="2.16"/>
<vertex x="5.17" y="2.09"/>
<vertex x="5.13" y="2.01"/>
<vertex x="5.09" y="1.92"/>
<vertex x="5.07" y="1.82"/>
<vertex x="5.06" y="1.71"/>
<vertex x="5.69" y="1.71"/>
<vertex x="5.7" y="1.76"/>
<vertex x="5.73" y="1.88"/>
<vertex x="5.77" y="1.94"/>
<vertex x="5.82" y="1.99"/>
<vertex x="5.85" y="2.01"/>
<vertex x="5.88" y="2.02"/>
<vertex x="5.91" y="2.04"/>
<vertex x="5.99" y="2.06"/>
<vertex x="6.03" y="2.06"/>
<vertex x="6.07" y="2.07"/>
<vertex x="6.16" y="2.07"/>
<vertex x="6.2" y="2.06"/>
<vertex x="6.27" y="2.06"/>
<vertex x="6.31" y="2.05"/>
<vertex x="6.34" y="2.04"/>
<vertex x="6.38" y="2.03"/>
<vertex x="6.41" y="2.01"/>
<vertex x="6.43" y="1.99"/>
<vertex x="6.46" y="1.97"/>
<vertex x="6.5" y="1.91"/>
<vertex x="6.51" y="1.88"/>
<vertex x="6.53" y="1.8"/>
<vertex x="6.53" y="1.7"/>
<vertex x="6.5" y="1.64"/>
<vertex x="6.48" y="1.62"/>
<vertex x="6.47" y="1.6"/>
<vertex x="6.45" y="1.59"/>
<vertex x="6.43" y="1.57"/>
<vertex x="6.4" y="1.56"/>
<vertex x="6.38" y="1.55"/>
<vertex x="6.29" y="1.52"/>
<vertex x="6.26" y="1.52"/>
<vertex x="6.25" y="1.15"/>
<vertex x="6.27" y="1.15"/>
<vertex x="6.29" y="1.16"/>
<vertex x="6.34" y="1.16"/>
<vertex x="6.38" y="1.18"/>
<vertex x="6.4" y="1.18"/>
<vertex x="6.42" y="1.19"/>
<vertex x="6.44" y="1.19"/>
<vertex x="6.45" y="1.2"/>
<vertex x="6.49" y="1.22"/>
<vertex x="6.5" y="1.23"/>
<vertex x="6.52" y="1.24"/>
<vertex x="6.53" y="1.25"/>
<vertex x="6.53" y="0.93"/>
<vertex x="6.52" y="0.9"/>
<vertex x="6.51" y="0.86"/>
<vertex x="6.51" y="0.83"/>
<vertex x="6.5" y="0.79"/>
<vertex x="6.48" y="0.76"/>
<vertex x="6.46" y="0.72"/>
<vertex x="6.42" y="0.66"/>
<vertex x="6.39" y="0.62"/>
<vertex x="6.36" y="0.59"/>
<vertex x="6.32" y="0.57"/>
<vertex x="6.27" y="0.54"/>
<vertex x="6.29" y="0.16"/>
<vertex x="6.32" y="0.17"/>
<vertex x="6.38" y="0.2"/>
<vertex x="6.4" y="0.22"/>
<vertex x="6.44" y="0.24"/>
<vertex x="6.46" y="0.26"/>
<vertex x="6.48" y="0.27"/>
<vertex x="6.5" y="0.29"/>
<vertex x="6.52" y="0.3"/>
<vertex x="6.54" y="0.32"/>
<vertex x="6.55" y="0.34"/>
<vertex x="6.56" y="0.32"/>
<vertex x="6.56" y="0.25"/>
<vertex x="6.57" y="0.24"/>
<vertex x="6.57" y="0.21"/>
<vertex x="6.58" y="0.19"/>
<vertex x="6.58" y="0.17"/>
<vertex x="6.59" y="0.15"/>
<vertex x="6.59" y="0.14"/>
<vertex x="6.6" y="0.13"/>
<vertex x="6.6" y="0.11"/>
<vertex x="7.25" y="0.11"/>
<vertex x="7.23" y="0.15"/>
<vertex x="7.22" y="0.18"/>
<vertex x="7.21" y="0.2"/>
<vertex x="7.2" y="0.23"/>
<vertex x="7.2" y="0.26"/>
<vertex x="7.19" y="0.29"/>
<vertex x="7.18" y="0.33"/>
<vertex x="7.18" y="0.4"/>
<vertex x="7.17" y="0.43"/>
<vertex x="7.17" y="1.83"/>
<vertex x="7.16" y="1.93"/>
<vertex x="7.14" y="2.02"/>
<vertex x="7.11" y="2.1"/>
<vertex x="7.07" y="2.17"/>
<vertex x="6.97" y="2.29"/>
<vertex x="6.83" y="2.37"/>
<vertex x="6.67" y="2.43"/>
<vertex x="6.59" y="2.45"/>
<vertex x="6.5" y="2.47"/>
</polygon>
<vertex x="7.53" y="2.32"/>
<vertex x="8.13" y="2.43"/>
<vertex x="8.13" y="2"/>
<vertex x="8.14" y="2"/>
<vertex x="8.16" y="2.05"/>
<vertex x="8.19" y="2.1"/>
<vertex x="8.23" y="2.15"/>
<vertex x="8.26" y="2.2"/>
<vertex x="8.34" y="2.28"/>
<vertex x="8.39" y="2.32"/>
<vertex x="8.44" y="2.35"/>
<vertex x="8.49" y="2.39"/>
<vertex x="8.54" y="2.41"/>
<vertex x="8.59" y="2.44"/>
<vertex x="8.65" y="2.46"/>
<vertex x="8.7" y="2.47"/>
<vertex x="8.82" y="2.49"/>
<vertex x="8.95" y="2.49"/>
<vertex x="8.96" y="2.48"/>
<vertex x="8.99" y="2.48"/>
<vertex x="9" y="2.47"/>
<vertex x="9.02" y="2.47"/>
<vertex x="9.02" y="1.88"/>
<vertex x="9" y="1.88"/>
<vertex x="8.98" y="1.89"/>
<vertex x="8.91" y="1.89"/>
<vertex x="8.9" y="1.9"/>
<vertex x="8.71" y="1.9"/>
<vertex x="8.63" y="1.89"/>
<vertex x="8.56" y="1.87"/>
<vertex x="8.49" y="1.84"/>
<vertex x="8.44" y="1.81"/>
<vertex x="8.38" y="1.77"/>
<vertex x="8.34" y="1.73"/>
<vertex x="8.3" y="1.68"/>
<vertex x="8.27" y="1.63"/>
<vertex x="8.21" y="1.51"/>
<vertex x="8.19" y="1.45"/>
<vertex x="8.17" y="1.31"/>
<vertex x="8.16" y="1.23"/>
<vertex x="8.16" y="0.11"/>
<vertex x="7.53" y="0.11"/>
</polygon>
<vertex x="9.26" y="2.96"/>
<vertex x="9.9" y="3.31"/>
<vertex x="9.9" y="1.6"/>
<vertex x="10.7" y="2.43"/>
<vertex x="11.46" y="2.43"/>
<vertex x="10.58" y="1.58"/>
<vertex x="11.55" y="0.11"/>
<vertex x="10.78" y="0.11"/>
<vertex x="10.15" y="1.15"/>
<vertex x="9.9" y="0.91"/>
<vertex x="9.9" y="0.11"/>
<vertex x="9.26" y="0.11"/>
</polygon>
<vertex x="15.37" y="0.11"/>
<vertex x="14.76" y="0.11"/>
<vertex x="14.76" y="0.43"/>
<vertex x="14.75" y="0.43"/>
<vertex x="14.72" y="0.39"/>
<vertex x="14.69" y="0.34"/>
<vertex x="14.61" y="0.26"/>
<vertex x="14.53" y="0.2"/>
<vertex x="14.48" y="0.17"/>
<vertex x="14.44" y="0.14"/>
<vertex x="14.34" y="0.1"/>
<vertex x="14.29" y="0.09"/>
<vertex x="14.24" y="0.07"/>
<vertex x="14.19" y="0.06"/>
<vertex x="14.14" y="0.06"/>
<vertex x="14.09" y="0.05"/>
<vertex x="13.92" y="0.05"/>
<vertex x="13.81" y="0.07"/>
<vertex x="13.71" y="0.09"/>
<vertex x="13.63" y="0.12"/>
<vertex x="13.55" y="0.16"/>
<vertex x="13.48" y="0.2"/>
<vertex x="13.42" y="0.25"/>
<vertex x="13.37" y="0.31"/>
<vertex x="13.32" y="0.38"/>
<vertex x="13.29" y="0.45"/>
<vertex x="13.23" y="0.61"/>
<vertex x="13.22" y="0.7"/>
<vertex x="13.2" y="0.8"/>
<vertex x="13.2" y="2.43"/>
<vertex x="13.83" y="2.43"/>
<vertex x="13.83" y="1.05"/>
<vertex x="13.84" y="0.99"/>
<vertex x="13.84" y="0.93"/>
<vertex x="13.85" y="0.87"/>
<vertex x="13.87" y="0.82"/>
<vertex x="13.88" y="0.77"/>
<vertex x="13.92" y="0.69"/>
<vertex x="13.98" y="0.63"/>
<vertex x="14.01" y="0.61"/>
<vertex x="14.09" y="0.57"/>
<vertex x="14.19" y="0.55"/>
<vertex x="14.3" y="0.55"/>
<vertex x="14.36" y="0.56"/>
<vertex x="14.41" y="0.57"/>
<vertex x="14.51" y="0.61"/>
<vertex x="14.55" y="0.64"/>
<vertex x="14.62" y="0.71"/>
<vertex x="14.64" y="0.75"/>
<vertex x="14.67" y="0.8"/>
<vertex x="14.69" y="0.85"/>
<vertex x="14.7" y="0.91"/>
<vertex x="14.72" y="0.98"/>
<vertex x="14.73" y="1.05"/>
<vertex x="14.73" y="2.43"/>
<vertex x="15.37" y="2.43"/>
</polygon>
<vertex x="15.72" y="2.43"/>
<vertex x="16.33" y="2.43"/>
<vertex x="16.33" y="2.11"/>
<vertex x="16.34" y="2.11"/>
<vertex x="16.37" y="2.15"/>
<vertex x="16.41" y="2.2"/>
<vertex x="16.44" y="2.24"/>
<vertex x="16.48" y="2.28"/>
<vertex x="16.56" y="2.34"/>
<vertex x="16.61" y="2.37"/>
<vertex x="16.65" y="2.4"/>
<vertex x="16.8" y="2.46"/>
<vertex x="16.95" y="2.49"/>
<vertex x="17.17" y="2.49"/>
<vertex x="17.28" y="2.47"/>
<vertex x="17.38" y="2.45"/>
<vertex x="17.47" y="2.42"/>
<vertex x="17.54" y="2.39"/>
<vertex x="17.61" y="2.34"/>
<vertex x="17.67" y="2.29"/>
<vertex x="17.73" y="2.23"/>
<vertex x="17.81" y="2.09"/>
<vertex x="17.84" y="2.01"/>
<vertex x="17.86" y="1.93"/>
<vertex x="17.88" y="1.84"/>
<vertex x="17.89" y="1.74"/>
<vertex x="17.89" y="1.64"/>
<vertex x="17.9" y="1.54"/>
<vertex x="17.9" y="0.11"/>
<vertex x="17.26" y="0.11"/>
<vertex x="17.26" y="1.49"/>
<vertex x="17.25" y="1.55"/>
<vertex x="17.25" y="1.61"/>
<vertex x="17.24" y="1.67"/>
<vertex x="17.22" y="1.72"/>
<vertex x="17.21" y="1.77"/>
<vertex x="17.17" y="1.85"/>
<vertex x="17.11" y="1.91"/>
<vertex x="17.08" y="1.93"/>
<vertex x="17" y="1.97"/>
<vertex x="16.9" y="1.99"/>
<vertex x="16.79" y="1.99"/>
<vertex x="16.73" y="1.98"/>
<vertex x="16.68" y="1.97"/>
<vertex x="16.58" y="1.93"/>
<vertex x="16.54" y="1.9"/>
<vertex x="16.51" y="1.87"/>
<vertex x="16.45" y="1.79"/>
<vertex x="16.42" y="1.74"/>
<vertex x="16.4" y="1.69"/>
<vertex x="16.39" y="1.63"/>
<vertex x="16.37" y="1.56"/>
<vertex x="16.37" y="1.49"/>
<vertex x="16.36" y="1.41"/>
<vertex x="16.36" y="0.11"/>
<vertex x="15.72" y="0.11"/>
</polygon>
<vertex x="12.64" y="-0.53"/>
<vertex x="12.64" y="-0.23"/>
<vertex x="12.5" y="-0.24"/>
<vertex x="12.36" y="-0.35"/>
<vertex x="12.28" y="-0.37"/>
<vertex x="11.9" y="-0.42"/>
<vertex x="11.9" y="-0.61"/>
<vertex x="11.93" y="-0.61"/>
<vertex x="12.51" y="-0.46"/>
</polygon>
<vertex x="12.36" y="3.59"/>
<vertex x="12.35" y="3.56"/>
<vertex x="12.33" y="3.53"/>
<vertex x="12.27" y="3.47"/>
<vertex x="12.11" y="3.54"/>
<vertex x="12.08" y="3.53"/>
<vertex x="12.03" y="3.5"/>
<vertex x="11.97" y="3.46"/>
<vertex x="11.98" y="3.45"/>
<vertex x="11.97" y="3.43"/>
<vertex x="11.96" y="3.4"/>
<vertex x="11.93" y="3.4"/>
<vertex x="11.86" y="3.37"/>
<vertex x="11.79" y="3.32"/>
<vertex x="11.76" y="3.29"/>
<vertex x="11.78" y="3.23"/>
<vertex x="11.82" y="3.13"/>
<vertex x="11.7" y="3.17"/>
<vertex x="11.7" y="3"/>
<vertex x="11.6" y="3.03"/>
<vertex x="11.55" y="3.02"/>
<vertex x="11.49" y="3.04"/>
<vertex x="11.24" y="2.97"/>
<vertex x="11.3" y="2.76"/>
<vertex x="11.29" y="2.6"/>
<vertex x="11.28" y="2.56"/>
<vertex x="11.27" y="2.53"/>
<vertex x="11.27" y="2.52"/>
<vertex x="11.17" y="2.27"/>
<vertex x="11.31" y="1.92"/>
<vertex x="11.37" y="1.86"/>
<vertex x="11.36" y="1.85"/>
<vertex x="11.4" y="1.78"/>
<vertex x="11.21" y="1.48"/>
<vertex x="11.36" y="1.41"/>
<vertex x="11.25" y="1.31"/>
<vertex x="11.31" y="1.26"/>
<vertex x="11.38" y="1.23"/>
<vertex x="11.28" y="1.06"/>
<vertex x="11.25" y="1.01"/>
<vertex x="11.27" y="0.99"/>
<vertex x="11.31" y="0.94"/>
<vertex x="11.37" y="0.88"/>
<vertex x="11.33" y="0.76"/>
<vertex x="11.35" y="0.72"/>
<vertex x="11.36" y="0.68"/>
<vertex x="11.29" y="0.56"/>
<vertex x="11.31" y="0.54"/>
<vertex x="11.29" y="0.48"/>
<vertex x="11.28" y="0.41"/>
<vertex x="11.31" y="0.17"/>
<vertex x="11.33" y="0.11"/>
<vertex x="11.33" y="-0.12"/>
<vertex x="11.34" y="-0.26"/>
<vertex x="11.35" y="-0.52"/>
<vertex x="11.55" y="-0.55"/>
<vertex x="11.65" y="-0.52"/>
<vertex x="11.8" y="-0.57"/>
<vertex x="11.81" y="-0.57"/>
<vertex x="11.82" y="-0.58"/>
<vertex x="11.87" y="-0.42"/>
<vertex x="11.81" y="-0.41"/>
<vertex x="11.76" y="-0.36"/>
<vertex x="11.73" y="-0.31"/>
<vertex x="11.63" y="-0.37"/>
<vertex x="11.55" y="-0.4"/>
<vertex x="11.48" y="-0.4"/>
<vertex x="11.47" y="-0.34"/>
<vertex x="11.47" y="-0.03"/>
<vertex x="11.46" y="0.05"/>
<vertex x="11.44" y="0.2"/>
<vertex x="11.46" y="0.48"/>
<vertex x="11.47" y="0.53"/>
<vertex x="11.63" y="0.73"/>
<vertex x="11.56" y="0.87"/>
<vertex x="11.63" y="1"/>
<vertex x="11.53" y="1.06"/>
<vertex x="11.62" y="1.28"/>
<vertex x="11.63" y="1.31"/>
<vertex x="11.55" y="1.38"/>
<vertex x="11.67" y="1.53"/>
<vertex x="11.58" y="1.58"/>
<vertex x="11.54" y="1.58"/>
<vertex x="11.68" y="1.87"/>
<vertex x="11.58" y="2.29"/>
<vertex x="11.61" y="2.31"/>
<vertex x="11.61" y="2.54"/>
<vertex x="11.53" y="2.73"/>
<vertex x="11.52" y="2.76"/>
<vertex x="11.59" y="2.78"/>
<vertex x="11.67" y="2.76"/>
<vertex x="11.79" y="2.67"/>
<vertex x="11.86" y="2.88"/>
<vertex x="11.99" y="2.84"/>
<vertex x="12.05" y="2.83"/>
<vertex x="12.08" y="2.82"/>
<vertex x="12.04" y="2.94"/>
<vertex x="11.91" y="2.94"/>
<vertex x="11.89" y="2.99"/>
<vertex x="11.91" y="2.95"/>
<vertex x="12.18" y="2.94"/>
<vertex x="12.16" y="2.97"/>
<vertex x="12.12" y="3.02"/>
<vertex x="12.06" y="3.11"/>
<vertex x="12.11" y="3.13"/>
<vertex x="12.17" y="3.13"/>
<vertex x="12.22" y="3.21"/>
<vertex x="12.24" y="3.2"/>
<vertex x="12.24" y="3.24"/>
<vertex x="12.26" y="3.27"/>
<vertex x="12.28" y="3.26"/>
<vertex x="12.32" y="3.22"/>
<vertex x="12.36" y="3.19"/>
<vertex x="12.37" y="3.17"/>
<vertex x="12.38" y="3.2"/>
<vertex x="12.38" y="3.22"/>
<vertex x="12.41" y="3.25"/>
<vertex x="12.48" y="3.33"/>
<vertex x="12.54" y="3.31"/>
<vertex x="12.7" y="3.24"/>
<vertex x="12.79" y="3.26"/>
<vertex x="12.86" y="3.29"/>
<vertex x="12.9" y="3.32"/>
<vertex x="12.95" y="3.35"/>
<vertex x="13" y="3.33"/>
<vertex x="13.06" y="3.33"/>
<vertex x="13.1" y="3.32"/>
<vertex x="13.09" y="3.28"/>
<vertex x="12.99" y="3.16"/>
<vertex x="12.97" y="3.14"/>
<vertex x="12.99" y="3.13"/>
<vertex x="13.04" y="3.1"/>
<vertex x="13.09" y="3.05"/>
<vertex x="13.1" y="3.03"/>
<vertex x="13.11" y="2.99"/>
<vertex x="13.11" y="2.87"/>
<vertex x="13.03" y="2.78"/>
<vertex x="13.02" y="2.75"/>
<vertex x="13.05" y="2.73"/>
<vertex x="13.13" y="2.65"/>
<vertex x="13.11" y="2.48"/>
<vertex x="12.86" y="2.24"/>
<vertex x="13.08" y="1.98"/>
<vertex x="13.13" y="1.83"/>
<vertex x="13.14" y="1.71"/>
<vertex x="13.07" y="1.63"/>
<vertex x="12.98" y="1.56"/>
<vertex x="12.96" y="1.52"/>
<vertex x="12.86" y="1.39"/>
<vertex x="13.06" y="1.21"/>
<vertex x="13.06" y="1.18"/>
<vertex x="12.95" y="1.11"/>
<vertex x="12.98" y="0.98"/>
<vertex x="12.97" y="0.93"/>
<vertex x="12.95" y="0.88"/>
<vertex x="12.95" y="0.85"/>
<vertex x="12.94" y="0.78"/>
<vertex x="12.92" y="0.7"/>
<vertex x="13.01" y="0.63"/>
<vertex x="12.95" y="0.55"/>
<vertex x="12.86" y="0.28"/>
<vertex x="12.81" y="0.12"/>
<vertex x="12.81" y="0.08"/>
<vertex x="12.91" y="-0.09"/>
<vertex x="12.92" y="-0.11"/>
<vertex x="12.93" y="-0.12"/>
<vertex x="12.95" y="-0.15"/>
<vertex x="12.99" y="-0.22"/>
<vertex x="13.01" y="-0.4"/>
<vertex x="12.97" y="-0.4"/>
<vertex x="12.86" y="-0.29"/>
<vertex x="12.77" y="-0.18"/>
<vertex x="12.76" y="-0.22"/>
<vertex x="12.73" y="-0.27"/>
<vertex x="12.71" y="-0.25"/>
<vertex x="12.68" y="-0.23"/>
<vertex x="12.69" y="-0.56"/>
<vertex x="12.71" y="-0.54"/>
<vertex x="12.74" y="-0.52"/>
<vertex x="12.79" y="-0.5"/>
<vertex x="12.95" y="-0.6"/>
<vertex x="13.18" y="-0.69"/>
<vertex x="13.29" y="-0.7"/>
<vertex x="13.32" y="-0.46"/>
<vertex x="13.33" y="-0.11"/>
<vertex x="13.27" y="0.01"/>
<vertex x="13.24" y="0.05"/>
<vertex x="13.1" y="0.22"/>
<vertex x="13.2" y="0.44"/>
<vertex x="13.21" y="0.54"/>
<vertex x="13.3" y="0.64"/>
<vertex x="13.17" y="0.77"/>
<vertex x="13.21" y="0.89"/>
<vertex x="13.21" y="0.94"/>
<vertex x="13.2" y="1.05"/>
<vertex x="13.29" y="1.13"/>
<vertex x="13.2" y="1.37"/>
<vertex x="13.3" y="1.55"/>
<vertex x="13.36" y="1.69"/>
<vertex x="13.38" y="1.72"/>
<vertex x="13.33" y="2.22"/>
<vertex x="13.34" y="2.24"/>
<vertex x="13.37" y="2.25"/>
<vertex x="13.41" y="2.32"/>
<vertex x="13.39" y="2.42"/>
<vertex x="13.39" y="2.6"/>
<vertex x="13.37" y="2.61"/>
<vertex x="13.31" y="2.68"/>
<vertex x="13.32" y="2.7"/>
<vertex x="13.35" y="2.75"/>
<vertex x="13.3" y="3.04"/>
<vertex x="13.28" y="3.06"/>
<vertex x="13.28" y="3.07"/>
<vertex x="13.26" y="3.1"/>
<vertex x="13.23" y="3.16"/>
<vertex x="13.29" y="3.25"/>
<vertex x="13.35" y="3.36"/>
<vertex x="13.31" y="3.44"/>
<vertex x="13.28" y="3.54"/>
<vertex x="13.18" y="3.51"/>
<vertex x="13.07" y="3.53"/>
<vertex x="12.95" y="3.54"/>
<vertex x="12.85" y="3.51"/>
<vertex x="12.81" y="3.49"/>
<vertex x="12.79" y="3.49"/>
<vertex x="12.77" y="3.47"/>
<vertex x="12.68" y="3.46"/>
<vertex x="12.44" y="3.55"/>
</polygon>
<vertex x="12.32" y="1.97"/>
<vertex x="11.93" y="1.95"/>
<vertex x="11.92" y="1.95"/>
<vertex x="11.92" y="1.94"/>
<vertex x="11.91" y="1.94"/>
<vertex x="11.91" y="1.92"/>
<vertex x="11.98" y="0.2"/>
<vertex x="11.98" y="0.19"/>
<vertex x="11.99" y="0.18"/>
<vertex x="12.21" y="0.18"/>
<vertex x="12.21" y="0.19"/>
<vertex x="12.22" y="0.19"/>
<vertex x="12.22" y="0.21"/>
<vertex x="12.2" y="0.83"/>
<vertex x="12.2" y="0.84"/>
<vertex x="12.21" y="0.85"/>
<vertex x="12.22" y="0.85"/>
<vertex x="12.22" y="0.86"/>
<vertex x="12.32" y="0.86"/>
<vertex x="12.32" y="1.11"/>
<vertex x="12.22" y="1.1"/>
<vertex x="12.21" y="1.1"/>
<vertex x="12.2" y="1.11"/>
<vertex x="12.19" y="1.11"/>
<vertex x="12.19" y="1.13"/>
<vertex x="12.16" y="1.69"/>
<vertex x="12.16" y="1.7"/>
<vertex x="12.17" y="1.7"/>
<vertex x="12.17" y="1.71"/>
<vertex x="12.19" y="1.71"/>
<vertex x="12.32" y="1.72"/>
</polygon>
<vertex x="12.42" y="1.72"/>
<vertex x="12.43" y="1.71"/>
<vertex x="12.44" y="1.71"/>
<vertex x="12.49" y="1.66"/>
<vertex x="12.49" y="1.65"/>
<vertex x="12.5" y="1.65"/>
<vertex x="12.5" y="1.63"/>
<vertex x="12.51" y="1.63"/>
<vertex x="12.51" y="1.61"/>
<vertex x="12.53" y="1.24"/>
<vertex x="12.53" y="1.22"/>
<vertex x="12.52" y="1.21"/>
<vertex x="12.52" y="1.19"/>
<vertex x="12.51" y="1.19"/>
<vertex x="12.46" y="1.13"/>
<vertex x="12.45" y="1.12"/>
<vertex x="12.43" y="1.12"/>
<vertex x="12.43" y="1.11"/>
<vertex x="12.53" y="0.87"/>
<vertex x="12.55" y="0.87"/>
<vertex x="12.55" y="0.88"/>
<vertex x="12.56" y="0.88"/>
<vertex x="12.57" y="0.89"/>
<vertex x="12.76" y="1.09"/>
<vertex x="12.76" y="1.1"/>
<vertex x="12.77" y="1.1"/>
<vertex x="12.77" y="1.12"/>
<vertex x="12.78" y="1.12"/>
<vertex x="12.78" y="1.14"/>
<vertex x="12.75" y="1.72"/>
<vertex x="12.75" y="1.75"/>
<vertex x="12.74" y="1.76"/>
<vertex x="12.74" y="1.77"/>
<vertex x="12.73" y="1.77"/>
<vertex x="12.53" y="1.96"/>
<vertex x="12.52" y="1.96"/>
<vertex x="12.51" y="1.97"/>
</polygon>
<vertex x="20.31" y="-1.34"/>
<vertex x="20.03" y="-1.34"/>
<vertex x="20.05" y="-1.4"/>
<vertex x="20.06" y="-1.42"/>
<vertex x="20.05" y="-1.43"/>
<vertex x="20.05" y="-1.47"/>
<vertex x="20.06" y="-1.48"/>
<vertex x="20.06" y="-1.56"/>
<vertex x="20.05" y="-1.56"/>
<vertex x="20.05" y="-1.57"/>
<vertex x="20.02" y="-1.57"/>
<vertex x="20.01" y="-1.58"/>
<vertex x="19.98" y="-1.58"/>
<vertex x="19.97" y="-1.59"/>
<vertex x="19.94" y="-1.59"/>
<vertex x="19.94" y="-1.58"/>
<vertex x="19.93" y="-1.57"/>
<vertex x="19.93" y="-1.56"/>
<vertex x="19.92" y="-1.56"/>
<vertex x="19.92" y="-1.55"/>
<vertex x="19.91" y="-1.55"/>
<vertex x="19.91" y="-1.54"/>
<vertex x="19.9" y="-1.54"/>
<vertex x="19.9" y="-1.53"/>
<vertex x="19.89" y="-1.53"/>
<vertex x="19.89" y="-1.52"/>
<vertex x="19.88" y="-1.52"/>
<vertex x="19.87" y="-1.51"/>
<vertex x="19.86" y="-1.51"/>
<vertex x="19.86" y="-1.5"/>
<vertex x="19.85" y="-1.5"/>
<vertex x="19.85" y="-1.49"/>
<vertex x="19.84" y="-1.49"/>
<vertex x="19.81" y="-1.46"/>
<vertex x="19.81" y="-1.45"/>
<vertex x="19.79" y="-1.46"/>
<vertex x="19.78" y="-1.47"/>
<vertex x="19.76" y="-1.47"/>
<vertex x="19.74" y="-1.49"/>
<vertex x="19.72" y="-1.5"/>
<vertex x="19.71" y="-1.5"/>
<vertex x="19.69" y="-1.51"/>
<vertex x="19.67" y="-1.53"/>
<vertex x="19.65" y="-1.54"/>
<vertex x="19.64" y="-1.55"/>
<vertex x="19.63" y="-1.55"/>
<vertex x="19.61" y="-1.56"/>
<vertex x="19.6" y="-1.57"/>
<vertex x="19.58" y="-1.58"/>
<vertex x="19.58" y="-1.57"/>
<vertex x="19.53" y="-1.57"/>
<vertex x="19.53" y="-1.56"/>
<vertex x="19.48" y="-1.56"/>
<vertex x="19.47" y="-1.57"/>
<vertex x="19.44" y="-1.57"/>
<vertex x="19.42" y="-1.58"/>
<vertex x="19.41" y="-1.58"/>
<vertex x="19.4" y="-1.59"/>
<vertex x="19.38" y="-1.59"/>
<vertex x="19.37" y="-1.6"/>
<vertex x="19.34" y="-1.6"/>
<vertex x="19.33" y="-1.61"/>
<vertex x="19.31" y="-1.61"/>
<vertex x="19.3" y="-1.62"/>
<vertex x="19.28" y="-1.62"/>
<vertex x="19.28" y="-1.63"/>
<vertex x="19.27" y="-1.63"/>
<vertex x="19.27" y="-1.64"/>
<vertex x="19.26" y="-1.64"/>
<vertex x="19.26" y="-1.65"/>
<vertex x="19.25" y="-1.66"/>
<vertex x="19.24" y="-1.66"/>
<vertex x="19.24" y="-1.67"/>
<vertex x="19.23" y="-1.67"/>
<vertex x="19.23" y="-1.68"/>
<vertex x="19.22" y="-1.69"/>
<vertex x="19.21" y="-1.69"/>
<vertex x="19.21" y="-1.7"/>
<vertex x="19.2" y="-1.7"/>
<vertex x="19.2" y="-1.71"/>
<vertex x="19.19" y="-1.71"/>
<vertex x="19.19" y="-1.72"/>
<vertex x="19.18" y="-1.72"/>
<vertex x="19.18" y="-1.73"/>
<vertex x="19.16" y="-1.73"/>
<vertex x="19.16" y="-1.74"/>
<vertex x="19.14" y="-1.74"/>
<vertex x="19.13" y="-1.75"/>
<vertex x="19.12" y="-1.75"/>
<vertex x="19.12" y="-1.76"/>
<vertex x="19.1" y="-1.76"/>
<vertex x="19.09" y="-1.77"/>
<vertex x="19.05" y="-1.77"/>
<vertex x="19.05" y="-1.75"/>
<vertex x="19.04" y="-1.74"/>
<vertex x="19.04" y="-1.69"/>
<vertex x="19.03" y="-1.69"/>
<vertex x="19.03" y="-1.64"/>
<vertex x="19.02" y="-1.64"/>
<vertex x="19.02" y="-1.6"/>
<vertex x="19.01" y="-1.59"/>
<vertex x="19.01" y="-1.56"/>
<vertex x="19" y="-1.56"/>
<vertex x="19" y="-1.52"/>
<vertex x="18.99" y="-1.52"/>
<vertex x="18.99" y="-1.49"/>
<vertex x="18.98" y="-1.49"/>
<vertex x="18.98" y="-1.47"/>
<vertex x="18.97" y="-1.47"/>
<vertex x="18.97" y="-1.45"/>
<vertex x="18.96" y="-1.44"/>
<vertex x="18.96" y="-1.42"/>
<vertex x="18.95" y="-1.42"/>
<vertex x="18.95" y="-1.41"/>
<vertex x="18.94" y="-1.4"/>
<vertex x="18.94" y="-1.39"/>
<vertex x="18.92" y="-1.37"/>
<vertex x="18.92" y="-1.36"/>
<vertex x="18.91" y="-1.29"/>
<vertex x="18.91" y="-1.28"/>
<vertex x="18.92" y="-1.27"/>
<vertex x="18.92" y="-1.23"/>
<vertex x="18.93" y="-1.22"/>
<vertex x="18.93" y="-1.15"/>
<vertex x="18.94" y="-1.15"/>
<vertex x="18.94" y="-1.11"/>
<vertex x="18.95" y="-1.11"/>
<vertex x="18.95" y="-1.1"/>
<vertex x="18.94" y="-1.09"/>
<vertex x="18.94" y="-1.08"/>
<vertex x="18.85" y="-1.08"/>
<vertex x="18.85" y="-1.07"/>
<vertex x="18.71" y="-1.07"/>
<vertex x="18.7" y="-1.06"/>
<vertex x="18.67" y="-1.06"/>
<vertex x="18.67" y="-1.05"/>
<vertex x="18.64" y="-1.05"/>
<vertex x="18.64" y="-1.04"/>
<vertex x="18.61" y="-1.04"/>
<vertex x="18.6" y="-1.03"/>
<vertex x="18.57" y="-1.03"/>
<vertex x="18.56" y="-1.02"/>
<vertex x="18.54" y="-1.02"/>
<vertex x="18.53" y="-1.01"/>
<vertex x="18.52" y="-1.01"/>
<vertex x="18.51" y="-1"/>
<vertex x="18.49" y="-1"/>
<vertex x="18.48" y="-0.99"/>
<vertex x="18.46" y="-0.99"/>
<vertex x="18.46" y="-0.98"/>
<vertex x="18.43" y="-0.98"/>
<vertex x="18.42" y="-0.97"/>
<vertex x="18.41" y="-0.97"/>
<vertex x="18.4" y="-0.96"/>
<vertex x="18.38" y="-0.96"/>
<vertex x="18.37" y="-0.95"/>
<vertex x="18.36" y="-0.95"/>
<vertex x="18.35" y="-0.94"/>
<vertex x="18.34" y="-0.94"/>
<vertex x="18.33" y="-0.93"/>
<vertex x="18.32" y="-0.93"/>
<vertex x="18.31" y="-0.92"/>
<vertex x="18.28" y="-0.92"/>
<vertex x="18.28" y="-0.91"/>
<vertex x="18.26" y="-0.91"/>
<vertex x="18.25" y="-0.9"/>
<vertex x="18.25" y="-0.68"/>
<vertex x="18.24" y="-0.68"/>
<vertex x="18.24" y="-0.42"/>
<vertex x="18.25" y="-0.4"/>
<vertex x="18.25" y="-0.3"/>
<vertex x="18.26" y="-0.28"/>
<vertex x="18.26" y="-0.24"/>
<vertex x="18.27" y="-0.22"/>
<vertex x="18.27" y="-0.18"/>
<vertex x="18.28" y="-0.18"/>
<vertex x="18.28" y="-0.16"/>
<vertex x="18.29" y="-0.15"/>
<vertex x="18.3" y="-0.13"/>
<vertex x="18.3" y="-0.12"/>
<vertex x="18.32" y="-0.08"/>
<vertex x="18.33" y="-0.07"/>
<vertex x="18.33" y="-0.05"/>
<vertex x="18.34" y="-0.04"/>
<vertex x="18.35" y="-0.02"/>
<vertex x="18.36" y="-0.01"/>
<vertex x="18.36" y="0.01"/>
<vertex x="18.37" y="0.02"/>
<vertex x="18.38" y="0.04"/>
<vertex x="18.39" y="0.05"/>
<vertex x="18.4" y="0.07"/>
<vertex x="18.41" y="0.08"/>
<vertex x="18.41" y="0.09"/>
<vertex x="18.42" y="0.1"/>
<vertex x="18.42" y="0.15"/>
<vertex x="18.41" y="0.16"/>
<vertex x="18.41" y="0.17"/>
<vertex x="18.4" y="0.18"/>
<vertex x="18.4" y="0.2"/>
<vertex x="18.39" y="0.21"/>
<vertex x="18.39" y="0.22"/>
<vertex x="18.37" y="0.24"/>
<vertex x="18.37" y="0.25"/>
<vertex x="18.36" y="0.26"/>
<vertex x="18.37" y="0.27"/>
<vertex x="18.37" y="0.3"/>
<vertex x="18.38" y="0.31"/>
<vertex x="18.38" y="0.33"/>
<vertex x="18.39" y="0.34"/>
<vertex x="18.39" y="0.37"/>
<vertex x="18.4" y="0.38"/>
<vertex x="18.4" y="0.39"/>
<vertex x="18.41" y="0.4"/>
<vertex x="18.41" y="0.41"/>
<vertex x="18.42" y="0.42"/>
<vertex x="18.4" y="0.44"/>
<vertex x="18.4" y="0.45"/>
<vertex x="18.39" y="0.45"/>
<vertex x="18.39" y="0.46"/>
<vertex x="18.38" y="0.46"/>
<vertex x="18.38" y="0.47"/>
<vertex x="18.37" y="0.47"/>
<vertex x="18.36" y="0.48"/>
<vertex x="18.36" y="0.49"/>
<vertex x="18.35" y="0.49"/>
<vertex x="18.35" y="0.5"/>
<vertex x="18.34" y="0.5"/>
<vertex x="18.35" y="0.52"/>
<vertex x="18.35" y="0.53"/>
<vertex x="18.36" y="0.55"/>
<vertex x="18.37" y="0.56"/>
<vertex x="18.37" y="0.58"/>
<vertex x="18.38" y="0.6"/>
<vertex x="18.38" y="0.61"/>
<vertex x="18.39" y="0.63"/>
<vertex x="18.39" y="0.67"/>
<vertex x="18.4" y="0.68"/>
<vertex x="18.4" y="0.7"/>
<vertex x="18.41" y="0.72"/>
<vertex x="18.41" y="0.76"/>
<vertex x="18.42" y="0.78"/>
<vertex x="18.42" y="0.83"/>
<vertex x="18.41" y="0.83"/>
<vertex x="18.41" y="0.84"/>
<vertex x="18.4" y="0.85"/>
<vertex x="18.4" y="0.86"/>
<vertex x="18.39" y="0.87"/>
<vertex x="18.39" y="0.88"/>
<vertex x="18.38" y="0.88"/>
<vertex x="18.37" y="0.89"/>
<vertex x="18.38" y="0.91"/>
<vertex x="18.38" y="0.92"/>
<vertex x="18.39" y="0.93"/>
<vertex x="18.39" y="0.94"/>
<vertex x="18.4" y="0.95"/>
<vertex x="18.4" y="0.97"/>
<vertex x="18.42" y="0.99"/>
<vertex x="18.42" y="1"/>
<vertex x="18.43" y="1.01"/>
<vertex x="18.43" y="1.02"/>
<vertex x="18.44" y="1.03"/>
<vertex x="18.44" y="1.05"/>
<vertex x="18.46" y="1.07"/>
<vertex x="18.46" y="1.09"/>
<vertex x="18.45" y="1.09"/>
<vertex x="18.45" y="1.1"/>
<vertex x="18.43" y="1.1"/>
<vertex x="18.42" y="1.11"/>
<vertex x="18.41" y="1.11"/>
<vertex x="18.41" y="1.12"/>
<vertex x="18.4" y="1.12"/>
<vertex x="18.4" y="1.13"/>
<vertex x="18.39" y="1.14"/>
<vertex x="18.37" y="1.14"/>
<vertex x="18.38" y="1.16"/>
<vertex x="18.38" y="1.19"/>
<vertex x="18.4" y="1.23"/>
<vertex x="18.4" y="1.25"/>
<vertex x="18.41" y="1.28"/>
<vertex x="18.43" y="1.32"/>
<vertex x="18.43" y="1.35"/>
<vertex x="18.46" y="1.41"/>
<vertex x="18.46" y="1.44"/>
<vertex x="18.48" y="1.48"/>
<vertex x="18.48" y="1.54"/>
<vertex x="18.46" y="1.6"/>
<vertex x="18.46" y="1.64"/>
<vertex x="18.44" y="1.7"/>
<vertex x="18.44" y="1.74"/>
<vertex x="18.43" y="1.77"/>
<vertex x="18.43" y="1.8"/>
<vertex x="18.42" y="1.83"/>
<vertex x="18.42" y="1.97"/>
<vertex x="18.43" y="2"/>
<vertex x="18.43" y="2.05"/>
<vertex x="18.44" y="2.05"/>
<vertex x="18.44" y="2.06"/>
<vertex x="18.45" y="2.06"/>
<vertex x="18.45" y="2.21"/>
<vertex x="18.46" y="2.24"/>
<vertex x="18.46" y="2.39"/>
<vertex x="18.45" y="2.42"/>
<vertex x="18.45" y="2.46"/>
<vertex x="18.44" y="2.49"/>
<vertex x="18.44" y="2.53"/>
<vertex x="18.4" y="2.65"/>
<vertex x="18.4" y="2.71"/>
<vertex x="18.41" y="2.74"/>
<vertex x="18.41" y="2.76"/>
<vertex x="18.42" y="2.78"/>
<vertex x="18.43" y="2.81"/>
<vertex x="18.5" y="2.95"/>
<vertex x="18.52" y="2.97"/>
<vertex x="18.53" y="2.99"/>
<vertex x="18.49" y="3.03"/>
<vertex x="18.49" y="3.04"/>
<vertex x="18.44" y="3.09"/>
<vertex x="18.44" y="3.1"/>
<vertex x="18.39" y="3.15"/>
<vertex x="18.4" y="3.16"/>
<vertex x="18.4" y="3.17"/>
<vertex x="18.41" y="3.17"/>
<vertex x="18.41" y="3.19"/>
<vertex x="18.42" y="3.19"/>
<vertex x="18.42" y="3.21"/>
<vertex x="18.43" y="3.22"/>
<vertex x="18.46" y="3.29"/>
<vertex x="18.49" y="3.31"/>
<vertex x="18.37" y="3.29"/>
<vertex x="18.39" y="3.39"/>
<vertex x="18.3" y="3.39"/>
<vertex x="18.27" y="3.33"/>
<vertex x="18.27" y="3.31"/>
<vertex x="18.15" y="3.07"/>
<vertex x="18.17" y="3.06"/>
<vertex x="18.18" y="3.05"/>
<vertex x="18.19" y="3.05"/>
<vertex x="18.22" y="3.02"/>
<vertex x="18.23" y="3.02"/>
<vertex x="18.24" y="3.01"/>
<vertex x="18.25" y="3.01"/>
<vertex x="18.25" y="3"/>
<vertex x="18.27" y="3"/>
<vertex x="18.27" y="2.98"/>
<vertex x="18.26" y="2.97"/>
<vertex x="18.26" y="2.96"/>
<vertex x="18.25" y="2.96"/>
<vertex x="18.25" y="2.95"/>
<vertex x="18.23" y="2.93"/>
<vertex x="18.23" y="2.88"/>
<vertex x="18.22" y="2.88"/>
<vertex x="18.22" y="2.87"/>
<vertex x="18.21" y="2.87"/>
<vertex x="18.2" y="2.86"/>
<vertex x="18.19" y="2.84"/>
<vertex x="18.19" y="2.77"/>
<vertex x="18.18" y="2.75"/>
<vertex x="18.19" y="2.73"/>
<vertex x="18.19" y="2.67"/>
<vertex x="18.2" y="2.65"/>
<vertex x="18.2" y="2.61"/>
<vertex x="18.22" y="2.57"/>
<vertex x="18.22" y="2.55"/>
<vertex x="18.23" y="2.53"/>
<vertex x="18.23" y="2.5"/>
<vertex x="18.22" y="2.46"/>
<vertex x="18.22" y="2.43"/>
<vertex x="18.21" y="2.4"/>
<vertex x="18.21" y="2.36"/>
<vertex x="18.19" y="2.3"/>
<vertex x="18.19" y="2.27"/>
<vertex x="18.18" y="2.23"/>
<vertex x="18.13" y="2.08"/>
<vertex x="18.13" y="2.05"/>
<vertex x="18.12" y="2.02"/>
<vertex x="18.12" y="1.99"/>
<vertex x="18.13" y="1.96"/>
<vertex x="18.14" y="1.94"/>
<vertex x="18.14" y="1.91"/>
<vertex x="18.16" y="1.85"/>
<vertex x="18.16" y="1.83"/>
<vertex x="18.18" y="1.77"/>
<vertex x="18.19" y="1.75"/>
<vertex x="18.19" y="1.72"/>
<vertex x="18.2" y="1.69"/>
<vertex x="18.2" y="1.67"/>
<vertex x="18.21" y="1.64"/>
<vertex x="18.21" y="1.58"/>
<vertex x="18.22" y="1.58"/>
<vertex x="18.22" y="1.57"/>
<vertex x="18.23" y="1.56"/>
<vertex x="18.23" y="1.55"/>
<vertex x="18.24" y="1.55"/>
<vertex x="18.24" y="1.52"/>
<vertex x="18.25" y="1.52"/>
<vertex x="18.25" y="1.5"/>
<vertex x="18.24" y="1.49"/>
<vertex x="18.25" y="1.48"/>
<vertex x="18.25" y="1.47"/>
<vertex x="18.26" y="1.47"/>
<vertex x="18.26" y="1.44"/>
<vertex x="18.27" y="1.44"/>
<vertex x="18.27" y="1.41"/>
<vertex x="18.28" y="1.4"/>
<vertex x="18.27" y="1.38"/>
<vertex x="18.26" y="1.35"/>
<vertex x="18.25" y="1.33"/>
<vertex x="18.24" y="1.3"/>
<vertex x="18.21" y="1.24"/>
<vertex x="18.2" y="1.21"/>
<vertex x="18.16" y="1.13"/>
<vertex x="18.15" y="1.1"/>
<vertex x="18.14" y="1.08"/>
<vertex x="18.13" y="1.05"/>
<vertex x="18.12" y="1.03"/>
<vertex x="18.13" y="1.02"/>
<vertex x="18.13" y="1.01"/>
<vertex x="18.17" y="0.97"/>
<vertex x="18.18" y="0.97"/>
<vertex x="18.18" y="0.96"/>
<vertex x="18.19" y="0.96"/>
<vertex x="18.2" y="0.95"/>
<vertex x="18.21" y="0.95"/>
<vertex x="18.22" y="0.94"/>
<vertex x="18.23" y="0.94"/>
<vertex x="18.22" y="0.93"/>
<vertex x="18.22" y="0.92"/>
<vertex x="18.21" y="0.92"/>
<vertex x="18.21" y="0.91"/>
<vertex x="18.2" y="0.9"/>
<vertex x="18.19" y="0.9"/>
<vertex x="18.19" y="0.89"/>
<vertex x="18.18" y="0.88"/>
<vertex x="18.18" y="0.87"/>
<vertex x="18.17" y="0.87"/>
<vertex x="18.17" y="0.86"/>
<vertex x="18.16" y="0.85"/>
<vertex x="18.16" y="0.84"/>
<vertex x="18.15" y="0.84"/>
<vertex x="18.15" y="0.83"/>
<vertex x="18.14" y="0.82"/>
<vertex x="18.15" y="0.82"/>
<vertex x="18.15" y="0.81"/>
<vertex x="18.16" y="0.8"/>
<vertex x="18.16" y="0.79"/>
<vertex x="18.17" y="0.79"/>
<vertex x="18.17" y="0.78"/>
<vertex x="18.18" y="0.78"/>
<vertex x="18.18" y="0.76"/>
<vertex x="18.19" y="0.76"/>
<vertex x="18.19" y="0.75"/>
<vertex x="18.22" y="0.72"/>
<vertex x="18.23" y="0.72"/>
<vertex x="18.23" y="0.71"/>
<vertex x="18.24" y="0.71"/>
<vertex x="18.24" y="0.7"/>
<vertex x="18.23" y="0.68"/>
<vertex x="18.23" y="0.67"/>
<vertex x="18.22" y="0.65"/>
<vertex x="18.22" y="0.64"/>
<vertex x="18.21" y="0.63"/>
<vertex x="18.21" y="0.62"/>
<vertex x="18.2" y="0.6"/>
<vertex x="18.2" y="0.59"/>
<vertex x="18.19" y="0.58"/>
<vertex x="18.19" y="0.57"/>
<vertex x="18.18" y="0.56"/>
<vertex x="18.18" y="0.55"/>
<vertex x="18.17" y="0.53"/>
<vertex x="18.16" y="0.52"/>
<vertex x="18.16" y="0.5"/>
<vertex x="18.15" y="0.49"/>
<vertex x="18.15" y="0.47"/>
<vertex x="18.14" y="0.47"/>
<vertex x="18.14" y="0.45"/>
<vertex x="18.13" y="0.45"/>
<vertex x="18.13" y="0.43"/>
<vertex x="18.14" y="0.43"/>
<vertex x="18.14" y="0.42"/>
<vertex x="18.15" y="0.41"/>
<vertex x="18.15" y="0.39"/>
<vertex x="18.16" y="0.39"/>
<vertex x="18.16" y="0.37"/>
<vertex x="18.17" y="0.37"/>
<vertex x="18.17" y="0.35"/>
<vertex x="18.18" y="0.35"/>
<vertex x="18.18" y="0.33"/>
<vertex x="18.19" y="0.33"/>
<vertex x="18.19" y="0.31"/>
<vertex x="18.2" y="0.31"/>
<vertex x="18.2" y="0.3"/>
<vertex x="18.21" y="0.3"/>
<vertex x="18.21" y="0.28"/>
<vertex x="18.22" y="0.28"/>
<vertex x="18.22" y="0.27"/>
<vertex x="18.21" y="0.26"/>
<vertex x="18.21" y="0.24"/>
<vertex x="18.2" y="0.23"/>
<vertex x="18.2" y="0.21"/>
<vertex x="18.19" y="0.2"/>
<vertex x="18.19" y="0.17"/>
<vertex x="18.18" y="0.16"/>
<vertex x="18.18" y="0.12"/>
<vertex x="18.19" y="0.11"/>
<vertex x="18.19" y="0.09"/>
<vertex x="18.2" y="0.09"/>
<vertex x="18.2" y="0.02"/>
<vertex x="18.19" y="0.01"/>
<vertex x="18.19" y="-0.01"/>
<vertex x="18.18" y="-0.02"/>
<vertex x="18.18" y="-0.05"/>
<vertex x="18.17" y="-0.06"/>
<vertex x="18.17" y="-0.08"/>
<vertex x="18.15" y="-0.1"/>
<vertex x="18.15" y="-0.11"/>
<vertex x="18.14" y="-0.12"/>
<vertex x="18.15" y="-0.12"/>
<vertex x="18.15" y="-0.18"/>
<vertex x="18.14" y="-0.18"/>
<vertex x="18.14" y="-0.3"/>
<vertex x="18.13" y="-0.3"/>
<vertex x="18.13" y="-0.33"/>
<vertex x="18.14" y="-0.34"/>
<vertex x="18.14" y="-0.51"/>
<vertex x="18.15" y="-0.53"/>
<vertex x="18.15" y="-0.75"/>
<vertex x="18.16" y="-0.75"/>
<vertex x="18.16" y="-0.85"/>
<vertex x="18.15" y="-0.86"/>
<vertex x="18.15" y="-0.98"/>
<vertex x="18.16" y="-0.98"/>
<vertex x="18.18" y="-0.99"/>
<vertex x="18.19" y="-0.99"/>
<vertex x="18.2" y="-1"/>
<vertex x="18.22" y="-1"/>
<vertex x="18.23" y="-1.01"/>
<vertex x="18.24" y="-1.01"/>
<vertex x="18.25" y="-1.02"/>
<vertex x="18.27" y="-1.02"/>
<vertex x="18.28" y="-1.03"/>
<vertex x="18.29" y="-1.03"/>
<vertex x="18.31" y="-1.04"/>
<vertex x="18.33" y="-1.04"/>
<vertex x="18.35" y="-1.05"/>
<vertex x="18.36" y="-1.05"/>
<vertex x="18.41" y="-1.07"/>
<vertex x="18.44" y="-1.08"/>
<vertex x="18.47" y="-1.08"/>
<vertex x="18.47" y="-1.09"/>
<vertex x="18.5" y="-1.09"/>
<vertex x="18.5" y="-1.1"/>
<vertex x="18.53" y="-1.1"/>
<vertex x="18.54" y="-1.11"/>
<vertex x="18.55" y="-1.11"/>
<vertex x="18.56" y="-1.12"/>
<vertex x="18.58" y="-1.12"/>
<vertex x="18.59" y="-1.13"/>
<vertex x="18.61" y="-1.13"/>
<vertex x="18.61" y="-1.14"/>
<vertex x="18.63" y="-1.14"/>
<vertex x="18.64" y="-1.15"/>
<vertex x="18.65" y="-1.15"/>
<vertex x="18.66" y="-1.16"/>
<vertex x="18.69" y="-1.16"/>
<vertex x="18.69" y="-1.17"/>
<vertex x="18.71" y="-1.17"/>
<vertex x="18.71" y="-1.18"/>
<vertex x="18.72" y="-1.18"/>
<vertex x="18.72" y="-1.19"/>
<vertex x="18.74" y="-1.19"/>
<vertex x="18.74" y="-1.2"/>
<vertex x="18.79" y="-1.2"/>
<vertex x="18.79" y="-1.21"/>
<vertex x="18.8" y="-1.21"/>
<vertex x="18.8" y="-1.28"/>
<vertex x="18.79" y="-1.29"/>
<vertex x="18.79" y="-1.48"/>
<vertex x="18.8" y="-1.48"/>
<vertex x="18.8" y="-1.5"/>
<vertex x="18.81" y="-1.51"/>
<vertex x="18.81" y="-1.54"/>
<vertex x="18.82" y="-1.54"/>
<vertex x="18.82" y="-1.56"/>
<vertex x="18.83" y="-1.59"/>
<vertex x="18.83" y="-1.6"/>
<vertex x="18.84" y="-1.61"/>
<vertex x="18.84" y="-1.65"/>
<vertex x="18.85" y="-1.65"/>
<vertex x="18.85" y="-1.69"/>
<vertex x="18.86" y="-1.71"/>
<vertex x="18.86" y="-1.72"/>
<vertex x="18.87" y="-1.74"/>
<vertex x="18.87" y="-1.76"/>
<vertex x="18.88" y="-1.78"/>
<vertex x="18.88" y="-1.79"/>
<vertex x="18.89" y="-1.81"/>
<vertex x="18.89" y="-1.83"/>
<vertex x="18.9" y="-1.85"/>
<vertex x="18.9" y="-1.88"/>
<vertex x="18.91" y="-1.9"/>
<vertex x="18.91" y="-1.91"/>
<vertex x="18.92" y="-1.93"/>
<vertex x="18.92" y="-1.94"/>
<vertex x="18.93" y="-1.96"/>
<vertex x="18.95" y="-1.95"/>
<vertex x="18.96" y="-1.95"/>
<vertex x="18.98" y="-1.94"/>
<vertex x="19" y="-1.94"/>
<vertex x="19.01" y="-1.93"/>
<vertex x="19.03" y="-1.93"/>
<vertex x="19.05" y="-1.92"/>
<vertex x="19.06" y="-1.92"/>
<vertex x="19.08" y="-1.91"/>
<vertex x="19.09" y="-1.91"/>
<vertex x="19.11" y="-1.9"/>
<vertex x="19.12" y="-1.9"/>
<vertex x="19.14" y="-1.89"/>
<vertex x="19.15" y="-1.88"/>
<vertex x="19.17" y="-1.88"/>
<vertex x="19.18" y="-1.87"/>
<vertex x="19.2" y="-1.87"/>
<vertex x="19.2" y="-1.86"/>
<vertex x="19.22" y="-1.86"/>
<vertex x="19.22" y="-1.85"/>
<vertex x="19.24" y="-1.85"/>
<vertex x="19.25" y="-1.84"/>
<vertex x="19.26" y="-1.84"/>
<vertex x="19.26" y="-1.83"/>
<vertex x="19.28" y="-1.83"/>
<vertex x="19.28" y="-1.82"/>
<vertex x="19.29" y="-1.82"/>
<vertex x="19.29" y="-1.81"/>
<vertex x="19.31" y="-1.81"/>
<vertex x="19.31" y="-1.8"/>
<vertex x="19.32" y="-1.8"/>
<vertex x="19.32" y="-1.79"/>
<vertex x="19.33" y="-1.79"/>
<vertex x="19.33" y="-1.78"/>
<vertex x="19.34" y="-1.78"/>
<vertex x="19.35" y="-1.77"/>
<vertex x="19.38" y="-1.77"/>
<vertex x="19.4" y="-1.76"/>
<vertex x="19.46" y="-1.76"/>
<vertex x="19.47" y="-1.77"/>
<vertex x="19.5" y="-1.77"/>
<vertex x="19.51" y="-1.78"/>
<vertex x="19.54" y="-1.78"/>
<vertex x="19.56" y="-1.79"/>
<vertex x="19.59" y="-1.79"/>
<vertex x="19.59" y="-1.78"/>
<vertex x="19.6" y="-1.78"/>
<vertex x="19.6" y="-1.77"/>
<vertex x="19.61" y="-1.77"/>
<vertex x="19.62" y="-1.76"/>
<vertex x="19.63" y="-1.76"/>
<vertex x="19.63" y="-1.75"/>
<vertex x="19.65" y="-1.75"/>
<vertex x="19.65" y="-1.74"/>
<vertex x="19.67" y="-1.74"/>
<vertex x="19.68" y="-1.73"/>
<vertex x="19.69" y="-1.73"/>
<vertex x="19.7" y="-1.74"/>
<vertex x="19.73" y="-1.74"/>
<vertex x="19.73" y="-1.75"/>
<vertex x="19.76" y="-1.75"/>
<vertex x="19.77" y="-1.76"/>
<vertex x="19.8" y="-1.76"/>
<vertex x="19.81" y="-1.77"/>
<vertex x="19.85" y="-1.77"/>
<vertex x="19.86" y="-1.78"/>
<vertex x="19.91" y="-1.78"/>
<vertex x="19.91" y="-1.79"/>
<vertex x="20.03" y="-1.79"/>
<vertex x="20.05" y="-1.78"/>
<vertex x="20.1" y="-1.78"/>
<vertex x="20.12" y="-1.77"/>
<vertex x="20.15" y="-1.77"/>
<vertex x="20.17" y="-1.76"/>
<vertex x="20.22" y="-1.76"/>
<vertex x="20.24" y="-1.75"/>
<vertex x="20.28" y="-1.75"/>
<vertex x="20.28" y="-1.7"/>
<vertex x="20.29" y="-1.69"/>
<vertex x="20.29" y="-1.62"/>
<vertex x="20.3" y="-1.61"/>
<vertex x="20.3" y="-1.52"/>
<vertex x="20.31" y="-1.5"/>
</polygon>
<vertex x="20.22" y="-0.95"/>
<vertex x="19.94" y="-0.95"/>
<vertex x="19.94" y="-1.02"/>
<vertex x="19.95" y="-1.04"/>
<vertex x="19.95" y="-1.05"/>
<vertex x="19.96" y="-1.06"/>
<vertex x="19.96" y="-1.09"/>
<vertex x="19.97" y="-1.1"/>
<vertex x="19.97" y="-1.11"/>
<vertex x="19.98" y="-1.13"/>
<vertex x="19.98" y="-1.15"/>
<vertex x="19.99" y="-1.17"/>
<vertex x="19.99" y="-1.19"/>
<vertex x="20" y="-1.2"/>
<vertex x="20" y="-1.22"/>
<vertex x="20.01" y="-1.23"/>
<vertex x="20.01" y="-1.27"/>
<vertex x="20.02" y="-1.28"/>
<vertex x="20.02" y="-1.32"/>
<vertex x="20.03" y="-1.32"/>
<vertex x="20.31" y="-1.31"/>
<vertex x="20.32" y="-1.31"/>
<vertex x="20.32" y="-1.25"/>
<vertex x="20.31" y="-1.24"/>
<vertex x="20.31" y="-1.22"/>
<vertex x="20.3" y="-1.21"/>
<vertex x="20.3" y="-1.19"/>
<vertex x="20.29" y="-1.18"/>
<vertex x="20.29" y="-1.17"/>
<vertex x="20.28" y="-1.16"/>
<vertex x="20.28" y="-1.13"/>
<vertex x="20.27" y="-1.12"/>
<vertex x="20.27" y="-1.08"/>
<vertex x="20.26" y="-1.08"/>
<vertex x="20.26" y="-1.04"/>
<vertex x="20.25" y="-1.04"/>
<vertex x="20.25" y="-1.02"/>
<vertex x="20.24" y="-1.01"/>
<vertex x="20.24" y="-1"/>
<vertex x="20.23" y="-0.99"/>
<vertex x="20.23" y="-0.97"/>
<vertex x="20.22" y="-0.97"/>
</polygon>
<vertex x="18.69" y="3.57"/>
<vertex x="18.41" y="3.49"/>
<vertex x="18.38" y="3.3"/>
<vertex x="18.6" y="3.35"/>
<vertex x="18.7" y="3.26"/>
<vertex x="18.95" y="3.17"/>
<vertex x="19.1" y="3.19"/>
<vertex x="19.27" y="3.09"/>
<vertex x="19.47" y="3.18"/>
<vertex x="19.54" y="3.16"/>
<vertex x="19.73" y="3.07"/>
<vertex x="19.98" y="3.07"/>
<vertex x="19.99" y="3.08"/>
<vertex x="20.05" y="3.08"/>
<vertex x="20.06" y="3.09"/>
<vertex x="20.07" y="3.09"/>
<vertex x="20.08" y="3.1"/>
<vertex x="20.1" y="3.1"/>
<vertex x="20.1" y="3.09"/>
<vertex x="20.13" y="3.09"/>
<vertex x="20.13" y="3.08"/>
<vertex x="20.15" y="3.08"/>
<vertex x="20.16" y="3.07"/>
<vertex x="20.18" y="3.07"/>
<vertex x="20.19" y="3.06"/>
<vertex x="20.31" y="3.06"/>
<vertex x="20.31" y="3.02"/>
<vertex x="20.3" y="3.02"/>
<vertex x="20.3" y="3"/>
<vertex x="20.29" y="3"/>
<vertex x="20.29" y="2.98"/>
<vertex x="20.28" y="2.98"/>
<vertex x="20.28" y="2.96"/>
<vertex x="20.27" y="2.96"/>
<vertex x="20.27" y="2.95"/>
<vertex x="20.26" y="2.95"/>
<vertex x="20.26" y="2.94"/>
<vertex x="20.25" y="2.94"/>
<vertex x="20.25" y="2.93"/>
<vertex x="20.21" y="2.89"/>
<vertex x="20.22" y="2.89"/>
<vertex x="20.22" y="2.88"/>
<vertex x="20.23" y="2.88"/>
<vertex x="20.23" y="2.85"/>
<vertex x="20.24" y="2.85"/>
<vertex x="20.24" y="2.82"/>
<vertex x="20.25" y="2.82"/>
<vertex x="20.25" y="2.8"/>
<vertex x="20.26" y="2.79"/>
<vertex x="20.26" y="2.77"/>
<vertex x="20.27" y="2.77"/>
<vertex x="20.27" y="2.75"/>
<vertex x="20.28" y="2.75"/>
<vertex x="20.28" y="2.73"/>
<vertex x="20.29" y="2.72"/>
<vertex x="20.29" y="2.71"/>
<vertex x="20.3" y="2.69"/>
<vertex x="20.3" y="2.47"/>
<vertex x="20.29" y="2.46"/>
<vertex x="20.29" y="2.44"/>
<vertex x="20.28" y="2.43"/>
<vertex x="20.28" y="2.42"/>
<vertex x="20.27" y="2.41"/>
<vertex x="20.27" y="2.4"/>
<vertex x="20.26" y="2.4"/>
<vertex x="20.26" y="2.39"/>
<vertex x="20.25" y="2.38"/>
<vertex x="20.25" y="2.37"/>
<vertex x="20.24" y="2.37"/>
<vertex x="20.23" y="2.36"/>
<vertex x="20.23" y="2.32"/>
<vertex x="20.24" y="2.32"/>
<vertex x="20.24" y="2.31"/>
<vertex x="20.25" y="2.31"/>
<vertex x="20.25" y="2.3"/>
<vertex x="20.26" y="2.29"/>
<vertex x="20.26" y="2.28"/>
<vertex x="20.27" y="2.27"/>
<vertex x="20.27" y="2.26"/>
<vertex x="20.28" y="2.25"/>
<vertex x="20.28" y="2.23"/>
<vertex x="20.29" y="2.23"/>
<vertex x="20.29" y="2.22"/>
<vertex x="20.3" y="2.21"/>
<vertex x="20.3" y="2.2"/>
<vertex x="20.31" y="2.2"/>
<vertex x="20.3" y="2.19"/>
<vertex x="20.3" y="2.16"/>
<vertex x="20.29" y="2.15"/>
<vertex x="20.29" y="2.09"/>
<vertex x="20.28" y="2.08"/>
<vertex x="20.28" y="1.98"/>
<vertex x="20.27" y="1.97"/>
<vertex x="20.26" y="1.95"/>
<vertex x="20.24" y="1.94"/>
<vertex x="20.22" y="1.9"/>
<vertex x="20.19" y="1.87"/>
<vertex x="20.17" y="1.83"/>
<vertex x="20.15" y="1.81"/>
<vertex x="20.1" y="1.71"/>
<vertex x="20.08" y="1.69"/>
<vertex x="20.21" y="1.43"/>
<vertex x="20.22" y="1.4"/>
<vertex x="20.24" y="1.36"/>
<vertex x="20.24" y="1.33"/>
<vertex x="20.25" y="1.31"/>
<vertex x="20.25" y="1.2"/>
<vertex x="20.26" y="1.19"/>
<vertex x="20.26" y="1.07"/>
<vertex x="20.27" y="1.06"/>
<vertex x="20.27" y="1.02"/>
<vertex x="20.26" y="1.01"/>
<vertex x="20.26" y="1"/>
<vertex x="20.24" y="0.98"/>
<vertex x="20.24" y="0.97"/>
<vertex x="20.23" y="0.97"/>
<vertex x="20.23" y="0.96"/>
<vertex x="20.22" y="0.96"/>
<vertex x="20.22" y="0.94"/>
<vertex x="20.21" y="0.93"/>
<vertex x="20.21" y="0.92"/>
<vertex x="20.2" y="0.91"/>
<vertex x="20.19" y="0.91"/>
<vertex x="20.19" y="0.9"/>
<vertex x="20.18" y="0.9"/>
<vertex x="20.18" y="0.89"/>
<vertex x="20.17" y="0.89"/>
<vertex x="20.16" y="0.88"/>
<vertex x="20.16" y="0.87"/>
<vertex x="20.15" y="0.87"/>
<vertex x="20.15" y="0.85"/>
<vertex x="20.14" y="0.85"/>
<vertex x="20.14" y="0.83"/>
<vertex x="20.13" y="0.83"/>
<vertex x="20.13" y="0.8"/>
<vertex x="20.12" y="0.8"/>
<vertex x="20.12" y="0.79"/>
<vertex x="20.11" y="0.78"/>
<vertex x="20.11" y="0.77"/>
<vertex x="20.1" y="0.76"/>
<vertex x="20.1" y="0.75"/>
<vertex x="20.09" y="0.74"/>
<vertex x="20.09" y="0.73"/>
<vertex x="20.07" y="0.71"/>
<vertex x="20.07" y="0.7"/>
<vertex x="20.06" y="0.69"/>
<vertex x="20.06" y="0.67"/>
<vertex x="20.05" y="0.66"/>
<vertex x="20.05" y="0.65"/>
<vertex x="20.03" y="0.63"/>
<vertex x="20.04" y="0.62"/>
<vertex x="20.05" y="0.6"/>
<vertex x="20.06" y="0.59"/>
<vertex x="20.07" y="0.57"/>
<vertex x="20.07" y="0.55"/>
<vertex x="20.08" y="0.54"/>
<vertex x="20.09" y="0.52"/>
<vertex x="20.11" y="0.5"/>
<vertex x="20.12" y="0.48"/>
<vertex x="20.13" y="0.47"/>
<vertex x="20.14" y="0.45"/>
<vertex x="20.18" y="0.41"/>
<vertex x="20.18" y="0.36"/>
<vertex x="20.17" y="0.36"/>
<vertex x="20.17" y="0.35"/>
<vertex x="20.1" y="0.28"/>
<vertex x="20.09" y="0.28"/>
<vertex x="20.09" y="0.27"/>
<vertex x="20.1" y="0.25"/>
<vertex x="20.1" y="0.18"/>
<vertex x="20.11" y="0.17"/>
<vertex x="20.11" y="0.1"/>
<vertex x="20.1" y="0.1"/>
<vertex x="20.1" y="0.05"/>
<vertex x="20.08" y="-0.02"/>
<vertex x="20.08" y="-0.08"/>
<vertex x="20.07" y="-0.08"/>
<vertex x="20.07" y="-0.15"/>
<vertex x="20.06" y="-0.15"/>
<vertex x="20.06" y="-0.21"/>
<vertex x="20.05" y="-0.21"/>
<vertex x="20.05" y="-0.24"/>
<vertex x="20.06" y="-0.25"/>
<vertex x="20.06" y="-0.26"/>
<vertex x="20.07" y="-0.26"/>
<vertex x="20.07" y="-0.27"/>
<vertex x="20.08" y="-0.28"/>
<vertex x="20.08" y="-0.29"/>
<vertex x="20.09" y="-0.29"/>
<vertex x="20.09" y="-0.3"/>
<vertex x="20.1" y="-0.31"/>
<vertex x="20.1" y="-0.32"/>
<vertex x="20.11" y="-0.32"/>
<vertex x="20.11" y="-0.33"/>
<vertex x="20.1" y="-0.34"/>
<vertex x="20.1" y="-0.35"/>
<vertex x="20.09" y="-0.36"/>
<vertex x="20.09" y="-0.38"/>
<vertex x="20.08" y="-0.38"/>
<vertex x="20.08" y="-0.4"/>
<vertex x="20.07" y="-0.4"/>
<vertex x="20.07" y="-0.41"/>
<vertex x="20.06" y="-0.42"/>
<vertex x="20.06" y="-0.46"/>
<vertex x="20.05" y="-0.48"/>
<vertex x="20.05" y="-0.51"/>
<vertex x="20.04" y="-0.53"/>
<vertex x="20.04" y="-0.57"/>
<vertex x="20.02" y="-0.61"/>
<vertex x="20.02" y="-0.63"/>
<vertex x="20.01" y="-0.65"/>
<vertex x="20.01" y="-0.67"/>
<vertex x="19.98" y="-0.73"/>
<vertex x="19.98" y="-0.77"/>
<vertex x="19.97" y="-0.78"/>
<vertex x="19.97" y="-0.84"/>
<vertex x="19.96" y="-0.85"/>
<vertex x="19.96" y="-0.9"/>
<vertex x="19.95" y="-0.91"/>
<vertex x="19.95" y="-0.94"/>
<vertex x="20.21" y="-0.94"/>
<vertex x="20.21" y="-0.93"/>
<vertex x="20.2" y="-0.92"/>
<vertex x="20.2" y="-0.9"/>
<vertex x="20.19" y="-0.89"/>
<vertex x="20.19" y="-0.87"/>
<vertex x="20.17" y="-0.85"/>
<vertex x="20.17" y="-0.84"/>
<vertex x="20.16" y="-0.83"/>
<vertex x="20.17" y="-0.81"/>
<vertex x="20.17" y="-0.78"/>
<vertex x="20.18" y="-0.76"/>
<vertex x="20.18" y="-0.74"/>
<vertex x="20.19" y="-0.73"/>
<vertex x="20.19" y="-0.71"/>
<vertex x="20.2" y="-0.69"/>
<vertex x="20.2" y="-0.68"/>
<vertex x="20.21" y="-0.66"/>
<vertex x="20.21" y="-0.64"/>
<vertex x="20.22" y="-0.63"/>
<vertex x="20.22" y="-0.61"/>
<vertex x="20.23" y="-0.6"/>
<vertex x="20.24" y="-0.58"/>
<vertex x="20.24" y="-0.56"/>
<vertex x="20.25" y="-0.56"/>
<vertex x="20.25" y="-0.46"/>
<vertex x="20.26" y="-0.45"/>
<vertex x="20.26" y="-0.44"/>
<vertex x="20.28" y="-0.42"/>
<vertex x="20.28" y="-0.4"/>
<vertex x="20.29" y="-0.39"/>
<vertex x="20.29" y="-0.38"/>
<vertex x="20.3" y="-0.38"/>
<vertex x="20.3" y="-0.37"/>
<vertex x="20.31" y="-0.36"/>
<vertex x="20.31" y="-0.34"/>
<vertex x="20.33" y="-0.32"/>
<vertex x="20.33" y="-0.3"/>
<vertex x="20.32" y="-0.29"/>
<vertex x="20.32" y="-0.28"/>
<vertex x="20.31" y="-0.27"/>
<vertex x="20.31" y="-0.26"/>
<vertex x="20.3" y="-0.25"/>
<vertex x="20.3" y="-0.24"/>
<vertex x="20.28" y="-0.22"/>
<vertex x="20.28" y="-0.21"/>
<vertex x="20.27" y="-0.2"/>
<vertex x="20.27" y="-0.19"/>
<vertex x="20.25" y="-0.17"/>
<vertex x="20.25" y="-0.16"/>
<vertex x="20.24" y="-0.15"/>
<vertex x="20.24" y="-0.14"/>
<vertex x="20.25" y="-0.13"/>
<vertex x="20.25" y="-0.09"/>
<vertex x="20.26" y="-0.08"/>
<vertex x="20.26" y="-0.02"/>
<vertex x="20.27" y="-0.01"/>
<vertex x="20.27" y="0.03"/>
<vertex x="20.28" y="0.04"/>
<vertex x="20.28" y="0.21"/>
<vertex x="20.29" y="0.21"/>
<vertex x="20.29" y="0.22"/>
<vertex x="20.3" y="0.23"/>
<vertex x="20.3" y="0.24"/>
<vertex x="20.31" y="0.24"/>
<vertex x="20.31" y="0.25"/>
<vertex x="20.33" y="0.27"/>
<vertex x="20.33" y="0.28"/>
<vertex x="20.34" y="0.28"/>
<vertex x="20.34" y="0.29"/>
<vertex x="20.35" y="0.3"/>
<vertex x="20.35" y="0.32"/>
<vertex x="20.34" y="0.34"/>
<vertex x="20.34" y="0.49"/>
<vertex x="20.33" y="0.51"/>
<vertex x="20.33" y="0.55"/>
<vertex x="20.32" y="0.57"/>
<vertex x="20.31" y="0.58"/>
<vertex x="20.3" y="0.6"/>
<vertex x="20.29" y="0.61"/>
<vertex x="20.29" y="0.62"/>
<vertex x="20.3" y="0.64"/>
<vertex x="20.3" y="0.65"/>
<vertex x="20.31" y="0.67"/>
<vertex x="20.31" y="0.68"/>
<vertex x="20.32" y="0.69"/>
<vertex x="20.32" y="0.71"/>
<vertex x="20.33" y="0.72"/>
<vertex x="20.33" y="0.73"/>
<vertex x="20.34" y="0.75"/>
<vertex x="20.34" y="0.76"/>
<vertex x="20.36" y="0.78"/>
<vertex x="20.36" y="0.8"/>
<vertex x="20.38" y="0.82"/>
<vertex x="20.38" y="0.85"/>
<vertex x="20.39" y="0.86"/>
<vertex x="20.39" y="0.87"/>
<vertex x="20.4" y="0.88"/>
<vertex x="20.4" y="0.9"/>
<vertex x="20.41" y="0.91"/>
<vertex x="20.41" y="0.92"/>
<vertex x="20.42" y="0.93"/>
<vertex x="20.42" y="0.96"/>
<vertex x="20.43" y="0.97"/>
<vertex x="20.43" y="1"/>
<vertex x="20.44" y="1.01"/>
<vertex x="20.44" y="1.03"/>
<vertex x="20.45" y="1.03"/>
<vertex x="20.45" y="1.19"/>
<vertex x="20.46" y="1.23"/>
<vertex x="20.46" y="1.51"/>
<vertex x="20.45" y="1.55"/>
<vertex x="20.45" y="1.59"/>
<vertex x="20.44" y="1.62"/>
<vertex x="20.43" y="1.66"/>
<vertex x="20.44" y="1.66"/>
<vertex x="20.44" y="1.69"/>
<vertex x="20.45" y="1.69"/>
<vertex x="20.45" y="1.7"/>
<vertex x="20.47" y="1.7"/>
<vertex x="20.46" y="1.71"/>
<vertex x="20.46" y="1.72"/>
<vertex x="20.47" y="1.73"/>
<vertex x="20.47" y="1.75"/>
<vertex x="20.48" y="1.75"/>
<vertex x="20.48" y="1.77"/>
<vertex x="20.49" y="1.77"/>
<vertex x="20.49" y="2.07"/>
<vertex x="20.5" y="2.09"/>
<vertex x="20.5" y="2.13"/>
<vertex x="20.49" y="2.13"/>
<vertex x="20.49" y="2.14"/>
<vertex x="20.48" y="2.14"/>
<vertex x="20.48" y="2.17"/>
<vertex x="20.47" y="2.18"/>
<vertex x="20.47" y="2.2"/>
<vertex x="20.46" y="2.2"/>
<vertex x="20.46" y="2.21"/>
<vertex x="20.45" y="2.22"/>
<vertex x="20.45" y="2.23"/>
<vertex x="20.44" y="2.23"/>
<vertex x="20.44" y="2.26"/>
<vertex x="20.45" y="2.26"/>
<vertex x="20.45" y="2.27"/>
<vertex x="20.46" y="2.27"/>
<vertex x="20.46" y="2.28"/>
<vertex x="20.47" y="2.29"/>
<vertex x="20.47" y="2.37"/>
<vertex x="20.46" y="2.39"/>
<vertex x="20.46" y="2.44"/>
<vertex x="20.45" y="2.46"/>
<vertex x="20.45" y="2.55"/>
<vertex x="20.44" y="2.57"/>
<vertex x="20.44" y="2.64"/>
<vertex x="20.45" y="2.66"/>
<vertex x="20.45" y="2.68"/>
<vertex x="20.44" y="2.69"/>
<vertex x="20.44" y="2.71"/>
<vertex x="20.43" y="2.71"/>
<vertex x="20.43" y="2.74"/>
<vertex x="20.42" y="2.74"/>
<vertex x="20.42" y="2.77"/>
<vertex x="20.41" y="2.77"/>
<vertex x="20.41" y="2.8"/>
<vertex x="20.4" y="2.81"/>
<vertex x="20.41" y="2.81"/>
<vertex x="20.41" y="2.82"/>
<vertex x="20.42" y="2.82"/>
<vertex x="20.42" y="2.83"/>
<vertex x="20.43" y="2.83"/>
<vertex x="20.43" y="2.85"/>
<vertex x="20.44" y="2.85"/>
<vertex x="20.44" y="2.87"/>
<vertex x="20.45" y="2.87"/>
<vertex x="20.45" y="2.9"/>
<vertex x="20.46" y="2.9"/>
<vertex x="20.46" y="2.92"/>
<vertex x="20.47" y="2.93"/>
<vertex x="20.47" y="2.94"/>
<vertex x="20.48" y="2.95"/>
<vertex x="20.48" y="2.96"/>
<vertex x="20.49" y="2.97"/>
<vertex x="20.49" y="2.98"/>
<vertex x="20.5" y="2.98"/>
<vertex x="20.5" y="2.99"/>
<vertex x="20.49" y="2.99"/>
<vertex x="20.49" y="3.06"/>
<vertex x="20.48" y="3.06"/>
<vertex x="20.48" y="3.11"/>
<vertex x="20.47" y="3.11"/>
<vertex x="20.47" y="3.19"/>
<vertex x="20.45" y="3.2"/>
<vertex x="20.4" y="3.2"/>
<vertex x="20.39" y="3.19"/>
<vertex x="20.27" y="3.19"/>
<vertex x="20.26" y="3.2"/>
<vertex x="20.21" y="3.2"/>
<vertex x="20.2" y="3.21"/>
<vertex x="20.17" y="3.21"/>
<vertex x="20.16" y="3.22"/>
<vertex x="20.14" y="3.22"/>
<vertex x="20.13" y="3.23"/>
<vertex x="20.1" y="3.23"/>
<vertex x="20.1" y="3.24"/>
<vertex x="20.07" y="3.24"/>
<vertex x="20.06" y="3.25"/>
<vertex x="19.99" y="3.25"/>
<vertex x="19.98" y="3.24"/>
<vertex x="19.86" y="3.24"/>
<vertex x="19.85" y="3.23"/>
<vertex x="19.83" y="3.23"/>
<vertex x="19.83" y="3.24"/>
<vertex x="19.77" y="3.24"/>
<vertex x="19.76" y="3.23"/>
<vertex x="19.74" y="3.23"/>
<vertex x="19.74" y="3.24"/>
<vertex x="19.71" y="3.25"/>
<vertex x="19.67" y="3.27"/>
<vertex x="19.64" y="3.28"/>
<vertex x="19.6" y="3.3"/>
<vertex x="19.57" y="3.31"/>
<vertex x="19.55" y="3.32"/>
<vertex x="19.52" y="3.33"/>
<vertex x="19.5" y="3.33"/>
<vertex x="19.47" y="3.34"/>
<vertex x="19.43" y="3.36"/>
<vertex x="19.4" y="3.37"/>
<vertex x="19.38" y="3.38"/>
<vertex x="19.36" y="3.4"/>
<vertex x="19.36" y="3.38"/>
<vertex x="19.35" y="3.38"/>
<vertex x="19.34" y="3.37"/>
<vertex x="19.33" y="3.37"/>
<vertex x="19.33" y="3.36"/>
<vertex x="19.32" y="3.36"/>
<vertex x="19.31" y="3.35"/>
<vertex x="19.29" y="3.35"/>
<vertex x="19.29" y="3.34"/>
<vertex x="19.28" y="3.34"/>
<vertex x="19.28" y="3.33"/>
<vertex x="19.25" y="3.33"/>
<vertex x="19.23" y="3.35"/>
<vertex x="19.22" y="3.35"/>
<vertex x="19.21" y="3.36"/>
<vertex x="19.2" y="3.36"/>
<vertex x="19.19" y="3.37"/>
<vertex x="19.18" y="3.37"/>
<vertex x="19.18" y="3.38"/>
<vertex x="19.16" y="3.38"/>
<vertex x="19.15" y="3.39"/>
<vertex x="19.14" y="3.39"/>
<vertex x="19.14" y="3.4"/>
<vertex x="19.11" y="3.4"/>
<vertex x="19.11" y="3.39"/>
<vertex x="19.07" y="3.39"/>
<vertex x="19.07" y="3.38"/>
<vertex x="19.02" y="3.38"/>
<vertex x="19.02" y="3.37"/>
<vertex x="18.96" y="3.37"/>
<vertex x="18.95" y="3.36"/>
<vertex x="18.94" y="3.36"/>
<vertex x="18.88" y="3.39"/>
</polygon>
<polygon width="0.011" layer="21">
<vertex x="19.14" y="2.74"/>
<vertex x="19.03" y="1.2"/>
<vertex x="19.58" y="2.71"/>
<vertex x="19.85" y="2.69"/>
<vertex x="19.29" y="1.18"/>
<vertex x="19.62" y="-0.67"/>
<vertex x="19.35" y="-0.65"/>
<vertex x="19.03" y="1.12"/>
<vertex x="18.9" y="-0.62"/>
<vertex x="18.62" y="-0.6"/>
<vertex x="18.86" y="2.76"/>
</polygon>
</package>
<package name="SPARKPUNK_LOGO_.2">
<polygon width="0.023" layer="21">
<vertex x="1.41" y="1.73"/>
<vertex x="1.42" y="1.63"/>
<vertex x="1.43" y="1.54"/>
<vertex x="1.46" y="1.45"/>
<vertex x="1.5" y="1.37"/>
<vertex x="1.54" y="1.3"/>
<vertex x="1.6" y="1.23"/>
<vertex x="1.66" y="1.17"/>
<vertex x="1.72" y="1.12"/>
<vertex x="1.8" y="1.07"/>
<vertex x="1.88" y="1.03"/>
<vertex x="1.96" y="1"/>
<vertex x="2.05" y="0.97"/>
<vertex x="2.14" y="0.95"/>
<vertex x="2.32" y="0.93"/>
<vertex x="2.49" y="0.93"/>
<vertex x="2.56" y="0.94"/>
<vertex x="2.64" y="0.94"/>
<vertex x="2.85" y="1"/>
<vertex x="2.99" y="1.06"/>
<vertex x="3.11" y="1.14"/>
<vertex x="3.16" y="1.19"/>
<vertex x="3.2" y="1.25"/>
<vertex x="3.23" y="1.31"/>
<vertex x="3.26" y="1.38"/>
<vertex x="3.28" y="1.46"/>
<vertex x="3.28" y="1.54"/>
<vertex x="3.26" y="1.68"/>
<vertex x="3.18" y="1.8"/>
<vertex x="3.06" y="1.9"/>
<vertex x="2.98" y="1.94"/>
<vertex x="2.89" y="1.99"/>
<vertex x="2.78" y="2.03"/>
<vertex x="2.67" y="2.06"/>
<vertex x="2.55" y="2.1"/>
<vertex x="2.42" y="2.14"/>
<vertex x="2.28" y="2.17"/>
<vertex x="2.12" y="2.21"/>
<vertex x="1.96" y="2.24"/>
<vertex x="1.79" y="2.28"/>
<vertex x="1.65" y="2.31"/>
<vertex x="1.5" y="2.35"/>
<vertex x="1.36" y="2.39"/>
<vertex x="1.23" y="2.43"/>
<vertex x="1.1" y="2.48"/>
<vertex x="0.97" y="2.54"/>
<vertex x="0.85" y="2.6"/>
<vertex x="0.74" y="2.67"/>
<vertex x="0.64" y="2.74"/>
<vertex x="0.55" y="2.83"/>
<vertex x="0.47" y="2.92"/>
<vertex x="0.4" y="3.02"/>
<vertex x="0.35" y="3.14"/>
<vertex x="0.31" y="3.26"/>
<vertex x="0.28" y="3.4"/>
<vertex x="0.27" y="3.56"/>
<vertex x="0.28" y="3.78"/>
<vertex x="0.32" y="3.97"/>
<vertex x="0.38" y="4.15"/>
<vertex x="0.45" y="4.31"/>
<vertex x="0.55" y="4.45"/>
<vertex x="0.66" y="4.58"/>
<vertex x="0.79" y="4.69"/>
<vertex x="0.93" y="4.78"/>
<vertex x="1.08" y="4.86"/>
<vertex x="1.24" y="4.93"/>
<vertex x="1.6" y="5.03"/>
<vertex x="1.78" y="5.06"/>
<vertex x="1.97" y="5.08"/>
<vertex x="2.16" y="5.09"/>
<vertex x="2.55" y="5.09"/>
<vertex x="2.74" y="5.08"/>
<vertex x="2.93" y="5.05"/>
<vertex x="3.11" y="5.02"/>
<vertex x="3.28" y="4.98"/>
<vertex x="3.45" y="4.92"/>
<vertex x="3.61" y="4.85"/>
<vertex x="3.76" y="4.77"/>
<vertex x="3.9" y="4.68"/>
<vertex x="4.03" y="4.57"/>
<vertex x="4.14" y="4.44"/>
<vertex x="4.24" y="4.3"/>
<vertex x="4.32" y="4.14"/>
<vertex x="4.39" y="3.97"/>
<vertex x="4.44" y="3.78"/>
<vertex x="4.47" y="3.57"/>
<vertex x="3.22" y="3.57"/>
<vertex x="3.21" y="3.66"/>
<vertex x="3.19" y="3.74"/>
<vertex x="3.16" y="3.82"/>
<vertex x="3.13" y="3.88"/>
<vertex x="3.09" y="3.94"/>
<vertex x="3.04" y="4"/>
<vertex x="2.99" y="4.04"/>
<vertex x="2.87" y="4.12"/>
<vertex x="2.8" y="4.14"/>
<vertex x="2.73" y="4.17"/>
<vertex x="2.65" y="4.19"/>
<vertex x="2.49" y="4.21"/>
<vertex x="2.41" y="4.21"/>
<vertex x="2.32" y="4.22"/>
<vertex x="2.26" y="4.21"/>
<vertex x="2.14" y="4.21"/>
<vertex x="1.96" y="4.18"/>
<vertex x="1.84" y="4.14"/>
<vertex x="1.79" y="4.12"/>
<vertex x="1.74" y="4.09"/>
<vertex x="1.66" y="4.01"/>
<vertex x="1.63" y="3.96"/>
<vertex x="1.59" y="3.84"/>
<vertex x="1.59" y="3.69"/>
<vertex x="1.62" y="3.61"/>
<vertex x="1.66" y="3.54"/>
<vertex x="1.71" y="3.48"/>
<vertex x="1.78" y="3.43"/>
<vertex x="1.86" y="3.38"/>
<vertex x="1.95" y="3.34"/>
<vertex x="2.05" y="3.3"/>
<vertex x="2.16" y="3.27"/>
<vertex x="2.4" y="3.21"/>
<vertex x="2.66" y="3.15"/>
<vertex x="3.08" y="3.06"/>
<vertex x="3.22" y="3.02"/>
<vertex x="3.36" y="2.99"/>
<vertex x="3.5" y="2.94"/>
<vertex x="3.64" y="2.9"/>
<vertex x="3.77" y="2.85"/>
<vertex x="4.01" y="2.73"/>
<vertex x="4.23" y="2.57"/>
<vertex x="4.32" y="2.48"/>
<vertex x="4.4" y="2.38"/>
<vertex x="4.47" y="2.27"/>
<vertex x="4.52" y="2.15"/>
<vertex x="4.56" y="2.02"/>
<vertex x="4.59" y="1.87"/>
<vertex x="4.6" y="1.72"/>
<vertex x="4.58" y="1.49"/>
<vertex x="4.55" y="1.28"/>
<vertex x="4.49" y="1.09"/>
<vertex x="4.41" y="0.92"/>
<vertex x="4.31" y="0.77"/>
<vertex x="4.19" y="0.63"/>
<vertex x="4.06" y="0.51"/>
<vertex x="3.91" y="0.41"/>
<vertex x="3.75" y="0.32"/>
<vertex x="3.58" y="0.24"/>
<vertex x="3.4" y="0.18"/>
<vertex x="3.21" y="0.13"/>
<vertex x="3.01" y="0.09"/>
<vertex x="2.61" y="0.05"/>
<vertex x="2.2" y="0.05"/>
<vertex x="2" y="0.07"/>
<vertex x="1.79" y="0.1"/>
<vertex x="1.6" y="0.13"/>
<vertex x="1.41" y="0.18"/>
<vertex x="1.22" y="0.25"/>
<vertex x="1.05" y="0.32"/>
<vertex x="0.89" y="0.42"/>
<vertex x="0.74" y="0.52"/>
<vertex x="0.6" y="0.64"/>
<vertex x="0.48" y="0.78"/>
<vertex x="0.38" y="0.94"/>
<vertex x="0.29" y="1.11"/>
<vertex x="0.23" y="1.3"/>
<vertex x="0.18" y="1.51"/>
<vertex x="0.16" y="1.73"/>
</polygon>
<vertex x="7.97" y="5.06"/>
<vertex x="7.96" y="5.06"/>
<vertex x="7.95" y="5.07"/>
<vertex x="7.92" y="5.07"/>
<vertex x="7.91" y="5.08"/>
<vertex x="7.88" y="5.08"/>
<vertex x="7.88" y="5.09"/>
<vertex x="7.85" y="5.09"/>
<vertex x="7.83" y="5.1"/>
<vertex x="7.81" y="5.1"/>
<vertex x="7.7" y="5.09"/>
<vertex x="7.59" y="5.09"/>
<vertex x="7.29" y="5.03"/>
<vertex x="7.19" y="5"/>
<vertex x="7.09" y="4.96"/>
<vertex x="7" y="4.92"/>
<vertex x="6.91" y="4.87"/>
<vertex x="6.83" y="4.82"/>
<vertex x="6.74" y="4.75"/>
<vertex x="6.67" y="4.69"/>
<vertex x="6.59" y="4.61"/>
<vertex x="6.45" y="4.45"/>
<vertex x="6.39" y="4.35"/>
<vertex x="6.37" y="4.35"/>
<vertex x="6.37" y="4.96"/>
<vertex x="5.12" y="4.74"/>
<vertex x="5.12" y="-1.51"/>
<vertex x="6.43" y="-2.68"/>
<vertex x="6.43" y="0.77"/>
<vertex x="6.46" y="0.77"/>
<vertex x="6.52" y="0.68"/>
<vertex x="6.59" y="0.6"/>
<vertex x="6.66" y="0.53"/>
<vertex x="6.82" y="0.39"/>
<vertex x="6.9" y="0.34"/>
<vertex x="6.99" y="0.28"/>
<vertex x="7.08" y="0.23"/>
<vertex x="7.17" y="0.19"/>
<vertex x="7.27" y="0.15"/>
<vertex x="7.36" y="0.12"/>
<vertex x="7.46" y="0.1"/>
<vertex x="7.57" y="0.08"/>
<vertex x="7.67" y="0.06"/>
<vertex x="7.78" y="0.05"/>
<vertex x="7.92" y="0.05"/>
<vertex x="7.92" y="0.06"/>
<vertex x="7.95" y="0.06"/>
<vertex x="7.96" y="0.07"/>
<vertex x="7.97" y="0.07"/>
<vertex x="7.97" y="1.14"/>
<vertex x="7.95" y="1.13"/>
<vertex x="7.92" y="1.12"/>
<vertex x="7.9" y="1.11"/>
<vertex x="7.87" y="1.1"/>
<vertex x="7.85" y="1.09"/>
<vertex x="7.82" y="1.09"/>
<vertex x="7.8" y="1.08"/>
<vertex x="7.74" y="1.06"/>
<vertex x="7.72" y="1.06"/>
<vertex x="7.69" y="1.05"/>
<vertex x="7.63" y="1.05"/>
<vertex x="7.6" y="1.04"/>
<vertex x="7.53" y="1.04"/>
<vertex x="7.38" y="1.05"/>
<vertex x="7.24" y="1.07"/>
<vertex x="7.11" y="1.11"/>
<vertex x="7" y="1.17"/>
<vertex x="6.89" y="1.24"/>
<vertex x="6.8" y="1.32"/>
<vertex x="6.71" y="1.41"/>
<vertex x="6.64" y="1.51"/>
<vertex x="6.58" y="1.62"/>
<vertex x="6.48" y="1.86"/>
<vertex x="6.45" y="1.99"/>
<vertex x="6.42" y="2.13"/>
<vertex x="6.4" y="2.27"/>
<vertex x="6.39" y="2.41"/>
<vertex x="6.39" y="2.7"/>
<vertex x="6.4" y="2.85"/>
<vertex x="6.42" y="2.99"/>
<vertex x="6.45" y="3.13"/>
<vertex x="6.48" y="3.26"/>
<vertex x="6.52" y="3.39"/>
<vertex x="6.57" y="3.51"/>
<vertex x="6.63" y="3.62"/>
<vertex x="6.71" y="3.73"/>
<vertex x="6.79" y="3.82"/>
<vertex x="6.88" y="3.9"/>
<vertex x="6.98" y="3.97"/>
<vertex x="7.1" y="4.03"/>
<vertex x="7.23" y="4.07"/>
<vertex x="7.37" y="4.1"/>
<vertex x="7.52" y="4.11"/>
<vertex x="7.56" y="4.11"/>
<vertex x="7.59" y="4.1"/>
<vertex x="7.65" y="4.1"/>
<vertex x="7.68" y="4.09"/>
<vertex x="7.71" y="4.09"/>
<vertex x="7.77" y="4.07"/>
<vertex x="7.79" y="4.07"/>
<vertex x="7.85" y="4.05"/>
<vertex x="7.87" y="4.04"/>
<vertex x="7.9" y="4.03"/>
<vertex x="7.92" y="4.02"/>
<vertex x="7.95" y="4.01"/>
<vertex x="7.97" y="4"/>
</polygon>
<vertex x="8.06" y="3.95"/>
<vertex x="8.15" y="3.89"/>
<vertex x="8.22" y="3.83"/>
<vertex x="8.29" y="3.76"/>
<vertex x="8.36" y="3.68"/>
<vertex x="8.41" y="3.6"/>
<vertex x="8.47" y="3.51"/>
<vertex x="8.51" y="3.42"/>
<vertex x="8.55" y="3.32"/>
<vertex x="8.58" y="3.22"/>
<vertex x="8.61" y="3.11"/>
<vertex x="8.64" y="3.01"/>
<vertex x="8.65" y="2.9"/>
<vertex x="8.67" y="2.78"/>
<vertex x="8.67" y="2.67"/>
<vertex x="8.68" y="2.56"/>
<vertex x="8.67" y="2.44"/>
<vertex x="8.67" y="2.33"/>
<vertex x="8.66" y="2.21"/>
<vertex x="8.64" y="2.11"/>
<vertex x="8.62" y="2"/>
<vertex x="8.59" y="1.89"/>
<vertex x="8.55" y="1.79"/>
<vertex x="8.52" y="1.7"/>
<vertex x="8.42" y="1.52"/>
<vertex x="8.36" y="1.44"/>
<vertex x="8.3" y="1.37"/>
<vertex x="8.23" y="1.3"/>
<vertex x="8.15" y="1.24"/>
<vertex x="8.07" y="1.19"/>
<vertex x="8.22" y="0.09"/>
<vertex x="8.45" y="0.14"/>
<vertex x="8.66" y="0.21"/>
<vertex x="8.86" y="0.3"/>
<vertex x="9.04" y="0.41"/>
<vertex x="9.2" y="0.54"/>
<vertex x="9.35" y="0.68"/>
<vertex x="9.48" y="0.85"/>
<vertex x="9.6" y="1.02"/>
<vertex x="9.71" y="1.21"/>
<vertex x="9.79" y="1.41"/>
<vertex x="9.86" y="1.62"/>
<vertex x="9.92" y="1.84"/>
<vertex x="9.96" y="2.06"/>
<vertex x="9.98" y="2.29"/>
<vertex x="9.99" y="2.52"/>
<vertex x="9.98" y="2.77"/>
<vertex x="9.96" y="3"/>
<vertex x="9.92" y="3.23"/>
<vertex x="9.87" y="3.46"/>
<vertex x="9.8" y="3.67"/>
<vertex x="9.71" y="3.88"/>
<vertex x="9.61" y="4.07"/>
<vertex x="9.5" y="4.25"/>
<vertex x="9.36" y="4.41"/>
<vertex x="9.21" y="4.56"/>
<vertex x="9.05" y="4.7"/>
<vertex x="8.87" y="4.81"/>
<vertex x="8.67" y="4.91"/>
<vertex x="8.45" y="4.98"/>
<vertex x="8.22" y="5.03"/>
</polygon>
<vertex x="12.93" y="0.22"/>
<vertex x="12.93" y="1.02"/>
<vertex x="12.9" y="1.02"/>
<vertex x="12.86" y="1"/>
<vertex x="12.83" y="0.99"/>
<vertex x="12.81" y="0.98"/>
<vertex x="12.78" y="0.97"/>
<vertex x="12.76" y="0.97"/>
<vertex x="12.7" y="0.95"/>
<vertex x="12.68" y="0.95"/>
<vertex x="12.65" y="0.94"/>
<vertex x="12.59" y="0.94"/>
<vertex x="12.55" y="0.93"/>
<vertex x="12.41" y="0.93"/>
<vertex x="12.25" y="0.95"/>
<vertex x="12.18" y="0.96"/>
<vertex x="12.04" y="1"/>
<vertex x="11.98" y="1.02"/>
<vertex x="11.92" y="1.06"/>
<vertex x="11.87" y="1.09"/>
<vertex x="11.82" y="1.14"/>
<vertex x="11.78" y="1.19"/>
<vertex x="11.75" y="1.24"/>
<vertex x="11.72" y="1.31"/>
<vertex x="11.7" y="1.38"/>
<vertex x="11.69" y="1.45"/>
<vertex x="11.68" y="1.54"/>
<vertex x="11.69" y="1.63"/>
<vertex x="11.7" y="1.71"/>
<vertex x="11.72" y="1.78"/>
<vertex x="11.78" y="1.9"/>
<vertex x="11.82" y="1.96"/>
<vertex x="11.87" y="2"/>
<vertex x="11.92" y="2.05"/>
<vertex x="11.98" y="2.08"/>
<vertex x="12.04" y="2.12"/>
<vertex x="12.1" y="2.15"/>
<vertex x="12.31" y="2.21"/>
<vertex x="12.39" y="2.23"/>
<vertex x="12.46" y="2.24"/>
<vertex x="12.49" y="2.25"/>
<vertex x="12.52" y="2.25"/>
<vertex x="12.55" y="2.26"/>
<vertex x="12.58" y="2.26"/>
<vertex x="12.61" y="2.27"/>
<vertex x="12.64" y="2.27"/>
<vertex x="12.66" y="2.28"/>
<vertex x="12.72" y="2.28"/>
<vertex x="12.75" y="2.29"/>
<vertex x="12.78" y="2.29"/>
<vertex x="12.81" y="2.3"/>
<vertex x="12.87" y="2.3"/>
<vertex x="12.9" y="2.31"/>
<vertex x="12.93" y="2.31"/>
<vertex x="12.93" y="3.06"/>
<vertex x="12.75" y="3.03"/>
<vertex x="12.35" y="2.99"/>
<vertex x="11.72" y="2.9"/>
<vertex x="11.51" y="2.85"/>
<vertex x="11.31" y="2.79"/>
<vertex x="11.12" y="2.71"/>
<vertex x="10.94" y="2.62"/>
<vertex x="10.78" y="2.5"/>
<vertex x="10.65" y="2.36"/>
<vertex x="10.53" y="2.19"/>
<vertex x="10.45" y="1.99"/>
<vertex x="10.39" y="1.75"/>
<vertex x="10.37" y="1.48"/>
<vertex x="10.38" y="1.3"/>
<vertex x="10.4" y="1.14"/>
<vertex x="10.44" y="0.98"/>
<vertex x="10.5" y="0.84"/>
<vertex x="10.56" y="0.71"/>
<vertex x="10.64" y="0.6"/>
<vertex x="10.74" y="0.49"/>
<vertex x="10.84" y="0.4"/>
<vertex x="10.95" y="0.32"/>
<vertex x="11.08" y="0.24"/>
<vertex x="11.21" y="0.18"/>
<vertex x="11.51" y="0.1"/>
<vertex x="11.66" y="0.07"/>
<vertex x="12" y="0.05"/>
<vertex x="12.12" y="0.05"/>
<vertex x="12.18" y="0.06"/>
<vertex x="12.23" y="0.06"/>
<vertex x="12.35" y="0.08"/>
<vertex x="12.41" y="0.08"/>
<vertex x="12.47" y="0.09"/>
<vertex x="12.53" y="0.11"/>
<vertex x="12.59" y="0.12"/>
<vertex x="12.64" y="0.13"/>
<vertex x="12.7" y="0.15"/>
<vertex x="12.76" y="0.16"/>
<vertex x="12.82" y="0.18"/>
<vertex x="12.87" y="0.2"/>
</polygon>
<vertex x="12.77" y="5.1"/>
<vertex x="12.56" y="5.09"/>
<vertex x="12.36" y="5.08"/>
<vertex x="12.17" y="5.05"/>
<vertex x="11.97" y="5.02"/>
<vertex x="11.78" y="4.97"/>
<vertex x="11.6" y="4.91"/>
<vertex x="11.43" y="4.84"/>
<vertex x="11.27" y="4.75"/>
<vertex x="11.11" y="4.65"/>
<vertex x="10.98" y="4.53"/>
<vertex x="10.85" y="4.4"/>
<vertex x="10.75" y="4.26"/>
<vertex x="10.66" y="4.09"/>
<vertex x="10.59" y="3.91"/>
<vertex x="10.54" y="3.71"/>
<vertex x="10.51" y="3.49"/>
<vertex x="11.83" y="3.49"/>
<vertex x="11.84" y="3.58"/>
<vertex x="11.86" y="3.67"/>
<vertex x="11.88" y="3.75"/>
<vertex x="11.91" y="3.82"/>
<vertex x="11.95" y="3.89"/>
<vertex x="11.99" y="3.95"/>
<vertex x="12.09" y="4.05"/>
<vertex x="12.15" y="4.09"/>
<vertex x="12.21" y="4.12"/>
<vertex x="12.35" y="4.18"/>
<vertex x="12.43" y="4.19"/>
<vertex x="12.52" y="4.21"/>
<vertex x="12.61" y="4.21"/>
<vertex x="12.7" y="4.22"/>
<vertex x="12.78" y="4.22"/>
<vertex x="12.87" y="4.21"/>
<vertex x="13.03" y="4.19"/>
<vertex x="13.1" y="4.18"/>
<vertex x="13.17" y="4.16"/>
<vertex x="13.24" y="4.13"/>
<vertex x="13.3" y="4.1"/>
<vertex x="13.36" y="4.06"/>
<vertex x="13.4" y="4.01"/>
<vertex x="13.45" y="3.96"/>
<vertex x="13.48" y="3.9"/>
<vertex x="13.51" y="3.83"/>
<vertex x="13.54" y="3.75"/>
<vertex x="13.55" y="3.66"/>
<vertex x="13.55" y="3.46"/>
<vertex x="13.53" y="3.41"/>
<vertex x="13.49" y="3.33"/>
<vertex x="13.46" y="3.29"/>
<vertex x="13.34" y="3.2"/>
<vertex x="13.29" y="3.17"/>
<vertex x="13.24" y="3.15"/>
<vertex x="13.06" y="3.09"/>
<vertex x="12.99" y="3.08"/>
<vertex x="12.97" y="2.32"/>
<vertex x="13.02" y="2.33"/>
<vertex x="13.07" y="2.33"/>
<vertex x="13.11" y="2.34"/>
<vertex x="13.16" y="2.35"/>
<vertex x="13.24" y="2.37"/>
<vertex x="13.28" y="2.39"/>
<vertex x="13.36" y="2.41"/>
<vertex x="13.4" y="2.43"/>
<vertex x="13.43" y="2.44"/>
<vertex x="13.47" y="2.46"/>
<vertex x="13.53" y="2.5"/>
<vertex x="13.55" y="2.52"/>
<vertex x="13.55" y="1.93"/>
<vertex x="13.54" y="1.87"/>
<vertex x="13.54" y="1.8"/>
<vertex x="13.52" y="1.73"/>
<vertex x="13.51" y="1.66"/>
<vertex x="13.48" y="1.59"/>
<vertex x="13.45" y="1.51"/>
<vertex x="13.42" y="1.44"/>
<vertex x="13.38" y="1.37"/>
<vertex x="13.26" y="1.23"/>
<vertex x="13.2" y="1.17"/>
<vertex x="13.12" y="1.12"/>
<vertex x="13.03" y="1.07"/>
<vertex x="12.97" y="0.24"/>
<vertex x="13.07" y="0.28"/>
<vertex x="13.11" y="0.3"/>
<vertex x="13.16" y="0.32"/>
<vertex x="13.2" y="0.34"/>
<vertex x="13.25" y="0.37"/>
<vertex x="13.29" y="0.39"/>
<vertex x="13.53" y="0.57"/>
<vertex x="13.6" y="0.64"/>
<vertex x="13.61" y="0.61"/>
<vertex x="13.61" y="0.55"/>
<vertex x="13.62" y="0.53"/>
<vertex x="13.62" y="0.5"/>
<vertex x="13.63" y="0.47"/>
<vertex x="13.63" y="0.44"/>
<vertex x="13.64" y="0.41"/>
<vertex x="13.64" y="0.38"/>
<vertex x="13.66" y="0.32"/>
<vertex x="13.66" y="0.29"/>
<vertex x="13.68" y="0.23"/>
<vertex x="13.69" y="0.21"/>
<vertex x="13.7" y="0.18"/>
<vertex x="15.04" y="0.18"/>
<vertex x="15.01" y="0.22"/>
<vertex x="14.99" y="0.26"/>
<vertex x="14.98" y="0.31"/>
<vertex x="14.96" y="0.37"/>
<vertex x="14.94" y="0.42"/>
<vertex x="14.93" y="0.49"/>
<vertex x="14.92" y="0.55"/>
<vertex x="14.9" y="0.69"/>
<vertex x="14.89" y="0.77"/>
<vertex x="14.88" y="0.84"/>
<vertex x="14.88" y="0.92"/>
<vertex x="14.87" y="1"/>
<vertex x="14.87" y="3.73"/>
<vertex x="14.85" y="3.94"/>
<vertex x="14.81" y="4.12"/>
<vertex x="14.75" y="4.29"/>
<vertex x="14.67" y="4.43"/>
<vertex x="14.57" y="4.56"/>
<vertex x="14.45" y="4.67"/>
<vertex x="14.32" y="4.76"/>
<vertex x="14.17" y="4.85"/>
<vertex x="14.02" y="4.91"/>
<vertex x="13.85" y="4.97"/>
<vertex x="13.68" y="5.01"/>
<vertex x="13.5" y="5.05"/>
<vertex x="13.31" y="5.07"/>
<vertex x="13.13" y="5.09"/>
<vertex x="12.95" y="5.09"/>
</polygon>
<vertex x="15.61" y="4.74"/>
<vertex x="16.86" y="4.96"/>
<vertex x="16.86" y="4.08"/>
<vertex x="16.88" y="4.08"/>
<vertex x="16.93" y="4.19"/>
<vertex x="16.99" y="4.29"/>
<vertex x="17.13" y="4.49"/>
<vertex x="17.21" y="4.58"/>
<vertex x="17.39" y="4.74"/>
<vertex x="17.49" y="4.81"/>
<vertex x="17.59" y="4.87"/>
<vertex x="17.7" y="4.93"/>
<vertex x="17.81" y="4.98"/>
<vertex x="17.93" y="5.02"/>
<vertex x="18.04" y="5.05"/>
<vertex x="18.28" y="5.09"/>
<vertex x="18.52" y="5.09"/>
<vertex x="18.54" y="5.08"/>
<vertex x="18.57" y="5.08"/>
<vertex x="18.59" y="5.07"/>
<vertex x="18.62" y="5.07"/>
<vertex x="18.64" y="5.06"/>
<vertex x="18.66" y="5.06"/>
<vertex x="18.68" y="5.05"/>
<vertex x="18.69" y="5.05"/>
<vertex x="18.69" y="3.83"/>
<vertex x="18.67" y="3.83"/>
<vertex x="18.65" y="3.84"/>
<vertex x="18.59" y="3.84"/>
<vertex x="18.56" y="3.85"/>
<vertex x="18.53" y="3.85"/>
<vertex x="18.5" y="3.86"/>
<vertex x="18.41" y="3.86"/>
<vertex x="18.38" y="3.87"/>
<vertex x="18.22" y="3.87"/>
<vertex x="18.05" y="3.86"/>
<vertex x="17.89" y="3.84"/>
<vertex x="17.74" y="3.8"/>
<vertex x="17.61" y="3.75"/>
<vertex x="17.49" y="3.69"/>
<vertex x="17.38" y="3.61"/>
<vertex x="17.29" y="3.52"/>
<vertex x="17.21" y="3.42"/>
<vertex x="17.14" y="3.31"/>
<vertex x="17.08" y="3.2"/>
<vertex x="17.03" y="3.07"/>
<vertex x="16.99" y="2.93"/>
<vertex x="16.96" y="2.79"/>
<vertex x="16.94" y="2.65"/>
<vertex x="16.93" y="2.49"/>
<vertex x="16.93" y="0.18"/>
<vertex x="15.61" y="0.18"/>
</polygon>
<vertex x="19.2" y="6.07"/>
<vertex x="20.52" y="6.79"/>
<vertex x="20.52" y="3.24"/>
<vertex x="22.17" y="4.96"/>
<vertex x="23.73" y="4.96"/>
<vertex x="21.92" y="3.2"/>
<vertex x="23.93" y="0.18"/>
<vertex x="22.34" y="0.18"/>
<vertex x="21.03" y="2.32"/>
<vertex x="20.52" y="1.83"/>
<vertex x="20.52" y="0.18"/>
<vertex x="19.2" y="0.18"/>
</polygon>
<vertex x="31.81" y="0.18"/>
<vertex x="30.56" y="0.18"/>
<vertex x="30.56" y="0.85"/>
<vertex x="30.53" y="0.85"/>
<vertex x="30.47" y="0.75"/>
<vertex x="30.4" y="0.65"/>
<vertex x="30.24" y="0.49"/>
<vertex x="30.16" y="0.42"/>
<vertex x="30.07" y="0.35"/>
<vertex x="29.98" y="0.29"/>
<vertex x="29.89" y="0.24"/>
<vertex x="29.59" y="0.12"/>
<vertex x="29.49" y="0.1"/>
<vertex x="29.38" y="0.08"/>
<vertex x="29.28" y="0.06"/>
<vertex x="29.18" y="0.05"/>
<vertex x="29.07" y="0.05"/>
<vertex x="28.82" y="0.06"/>
<vertex x="28.59" y="0.09"/>
<vertex x="28.39" y="0.13"/>
<vertex x="28.21" y="0.19"/>
<vertex x="28.05" y="0.27"/>
<vertex x="27.9" y="0.36"/>
<vertex x="27.78" y="0.47"/>
<vertex x="27.67" y="0.59"/>
<vertex x="27.58" y="0.73"/>
<vertex x="27.51" y="0.88"/>
<vertex x="27.45" y="1.04"/>
<vertex x="27.4" y="1.21"/>
<vertex x="27.36" y="1.4"/>
<vertex x="27.34" y="1.6"/>
<vertex x="27.33" y="1.8"/>
<vertex x="27.32" y="2.02"/>
<vertex x="27.32" y="4.96"/>
<vertex x="28.64" y="4.96"/>
<vertex x="28.64" y="2.12"/>
<vertex x="28.66" y="1.86"/>
<vertex x="28.68" y="1.75"/>
<vertex x="28.71" y="1.64"/>
<vertex x="28.74" y="1.54"/>
<vertex x="28.82" y="1.38"/>
<vertex x="28.88" y="1.31"/>
<vertex x="28.94" y="1.25"/>
<vertex x="29.01" y="1.2"/>
<vertex x="29.09" y="1.16"/>
<vertex x="29.17" y="1.13"/>
<vertex x="29.26" y="1.1"/>
<vertex x="29.37" y="1.09"/>
<vertex x="29.61" y="1.09"/>
<vertex x="29.73" y="1.11"/>
<vertex x="29.84" y="1.13"/>
<vertex x="29.94" y="1.16"/>
<vertex x="30.03" y="1.21"/>
<vertex x="30.11" y="1.26"/>
<vertex x="30.19" y="1.33"/>
<vertex x="30.25" y="1.41"/>
<vertex x="30.31" y="1.5"/>
<vertex x="30.36" y="1.6"/>
<vertex x="30.4" y="1.71"/>
<vertex x="30.44" y="1.83"/>
<vertex x="30.46" y="1.97"/>
<vertex x="30.48" y="2.12"/>
<vertex x="30.49" y="2.28"/>
<vertex x="30.5" y="2.46"/>
<vertex x="30.5" y="4.96"/>
<vertex x="31.81" y="4.96"/>
</polygon>
<vertex x="32.54" y="4.96"/>
<vertex x="33.79" y="4.96"/>
<vertex x="33.79" y="4.3"/>
<vertex x="33.81" y="4.3"/>
<vertex x="33.88" y="4.4"/>
<vertex x="33.95" y="4.49"/>
<vertex x="34.11" y="4.65"/>
<vertex x="34.19" y="4.72"/>
<vertex x="34.28" y="4.79"/>
<vertex x="34.37" y="4.85"/>
<vertex x="34.46" y="4.9"/>
<vertex x="34.56" y="4.95"/>
<vertex x="34.66" y="4.99"/>
<vertex x="34.86" y="5.05"/>
<vertex x="34.96" y="5.07"/>
<vertex x="35.07" y="5.08"/>
<vertex x="35.17" y="5.09"/>
<vertex x="35.28" y="5.09"/>
<vertex x="35.53" y="5.08"/>
<vertex x="35.75" y="5.06"/>
<vertex x="35.96" y="5.01"/>
<vertex x="36.14" y="4.95"/>
<vertex x="36.3" y="4.88"/>
<vertex x="36.45" y="4.78"/>
<vertex x="36.57" y="4.67"/>
<vertex x="36.68" y="4.55"/>
<vertex x="36.77" y="4.42"/>
<vertex x="36.84" y="4.27"/>
<vertex x="36.9" y="4.1"/>
<vertex x="36.95" y="3.93"/>
<vertex x="36.99" y="3.74"/>
<vertex x="37.01" y="3.55"/>
<vertex x="37.02" y="3.34"/>
<vertex x="37.03" y="3.12"/>
<vertex x="37.03" y="0.18"/>
<vertex x="35.71" y="0.18"/>
<vertex x="35.71" y="3.02"/>
<vertex x="35.7" y="3.16"/>
<vertex x="35.69" y="3.28"/>
<vertex x="35.67" y="3.4"/>
<vertex x="35.61" y="3.6"/>
<vertex x="35.57" y="3.69"/>
<vertex x="35.47" y="3.83"/>
<vertex x="35.41" y="3.89"/>
<vertex x="35.34" y="3.94"/>
<vertex x="35.18" y="4.02"/>
<vertex x="35.08" y="4.04"/>
<vertex x="34.98" y="4.05"/>
<vertex x="34.87" y="4.06"/>
<vertex x="34.74" y="4.05"/>
<vertex x="34.62" y="4.04"/>
<vertex x="34.51" y="4.01"/>
<vertex x="34.41" y="3.98"/>
<vertex x="34.32" y="3.94"/>
<vertex x="34.23" y="3.88"/>
<vertex x="34.09" y="3.74"/>
<vertex x="34.04" y="3.65"/>
<vertex x="33.99" y="3.55"/>
<vertex x="33.94" y="3.44"/>
<vertex x="33.91" y="3.31"/>
<vertex x="33.89" y="3.17"/>
<vertex x="33.87" y="3.02"/>
<vertex x="33.86" y="2.86"/>
<vertex x="33.85" y="2.69"/>
<vertex x="33.85" y="0.18"/>
<vertex x="32.54" y="0.18"/>
</polygon>
<vertex x="26.17" y="-1.14"/>
<vertex x="26.17" y="-0.53"/>
<vertex x="25.87" y="-0.55"/>
<vertex x="25.59" y="-0.78"/>
<vertex x="25.52" y="-0.8"/>
<vertex x="25.42" y="-0.82"/>
<vertex x="24.65" y="-0.91"/>
<vertex x="24.65" y="-1.3"/>
<vertex x="24.7" y="-1.32"/>
<vertex x="25.91" y="-1"/>
</polygon>
<vertex x="25.59" y="7.36"/>
<vertex x="25.57" y="7.3"/>
<vertex x="25.53" y="7.24"/>
<vertex x="25.41" y="7.12"/>
<vertex x="25.08" y="7.25"/>
<vertex x="25.01" y="7.23"/>
<vertex x="24.8" y="7.09"/>
<vertex x="24.81" y="7.08"/>
<vertex x="24.78" y="7.03"/>
<vertex x="24.76" y="6.98"/>
<vertex x="24.71" y="6.97"/>
<vertex x="24.55" y="6.91"/>
<vertex x="24.41" y="6.81"/>
<vertex x="24.35" y="6.75"/>
<vertex x="24.4" y="6.62"/>
<vertex x="24.49" y="6.4"/>
<vertex x="24.24" y="6.5"/>
<vertex x="24.24" y="6.45"/>
<vertex x="24.22" y="6.15"/>
<vertex x="24.02" y="6.21"/>
<vertex x="23.92" y="6.19"/>
<vertex x="23.81" y="6.23"/>
<vertex x="23.29" y="6.09"/>
<vertex x="23.41" y="5.66"/>
<vertex x="23.38" y="5.32"/>
<vertex x="23.36" y="5.22"/>
<vertex x="23.35" y="5.18"/>
<vertex x="23.35" y="5.17"/>
<vertex x="23.34" y="5.16"/>
<vertex x="23.31" y="5.05"/>
<vertex x="23.13" y="4.64"/>
<vertex x="23.44" y="3.92"/>
<vertex x="23.55" y="3.78"/>
<vertex x="23.53" y="3.76"/>
<vertex x="23.62" y="3.62"/>
<vertex x="23.22" y="3"/>
<vertex x="23.53" y="2.86"/>
<vertex x="23.3" y="2.66"/>
<vertex x="23.43" y="2.56"/>
<vertex x="23.58" y="2.48"/>
<vertex x="23.37" y="2.14"/>
<vertex x="23.3" y="2.03"/>
<vertex x="23.44" y="1.89"/>
<vertex x="23.51" y="1.8"/>
<vertex x="23.55" y="1.76"/>
<vertex x="23.46" y="1.52"/>
<vertex x="23.51" y="1.43"/>
<vertex x="23.52" y="1.35"/>
<vertex x="23.39" y="1.11"/>
<vertex x="23.42" y="1.07"/>
<vertex x="23.39" y="0.93"/>
<vertex x="23.37" y="0.8"/>
<vertex x="23.44" y="0.3"/>
<vertex x="23.46" y="0.18"/>
<vertex x="23.46" y="-0.06"/>
<vertex x="23.47" y="-0.16"/>
<vertex x="23.47" y="-0.3"/>
<vertex x="23.49" y="-0.58"/>
<vertex x="23.5" y="-1.13"/>
<vertex x="23.93" y="-1.19"/>
<vertex x="24.12" y="-1.13"/>
<vertex x="24.37" y="-1.21"/>
<vertex x="24.43" y="-1.23"/>
<vertex x="24.45" y="-1.23"/>
<vertex x="24.46" y="-1.24"/>
<vertex x="24.49" y="-1.24"/>
<vertex x="24.59" y="-0.92"/>
<vertex x="24.45" y="-0.91"/>
<vertex x="24.35" y="-0.8"/>
<vertex x="24.3" y="-0.69"/>
<vertex x="24.2" y="-0.75"/>
<vertex x="24.09" y="-0.81"/>
<vertex x="23.93" y="-0.87"/>
<vertex x="23.77" y="-0.88"/>
<vertex x="23.75" y="-0.75"/>
<vertex x="23.75" y="-0.5"/>
<vertex x="23.77" y="-0.26"/>
<vertex x="23.76" y="-0.19"/>
<vertex x="23.75" y="-0.11"/>
<vertex x="23.73" y="0.04"/>
<vertex x="23.7" y="0.36"/>
<vertex x="23.74" y="0.94"/>
<vertex x="23.77" y="1.04"/>
<vertex x="24.1" y="1.45"/>
<vertex x="23.95" y="1.74"/>
<vertex x="24.1" y="2.01"/>
<vertex x="23.88" y="2.14"/>
<vertex x="24.06" y="2.6"/>
<vertex x="24.08" y="2.66"/>
<vertex x="23.93" y="2.79"/>
<vertex x="24.16" y="3.11"/>
<vertex x="23.98" y="3.2"/>
<vertex x="23.9" y="3.2"/>
<vertex x="24.18" y="3.81"/>
<vertex x="23.99" y="4.68"/>
<vertex x="24.04" y="4.72"/>
<vertex x="24.04" y="5.19"/>
<vertex x="23.88" y="5.59"/>
<vertex x="23.86" y="5.66"/>
<vertex x="24.01" y="5.68"/>
<vertex x="24.17" y="5.64"/>
<vertex x="24.41" y="5.47"/>
<vertex x="24.57" y="5.9"/>
<vertex x="24.82" y="5.81"/>
<vertex x="24.95" y="5.78"/>
<vertex x="25.02" y="5.77"/>
<vertex x="24.94" y="6.03"/>
<vertex x="24.66" y="6.03"/>
<vertex x="24.62" y="6.12"/>
<vertex x="24.67" y="6.04"/>
<vertex x="25.21" y="6.03"/>
<vertex x="25.18" y="6.07"/>
<vertex x="25.1" y="6.18"/>
<vertex x="25.02" y="6.31"/>
<vertex x="24.98" y="6.37"/>
<vertex x="25.09" y="6.4"/>
<vertex x="25.2" y="6.42"/>
<vertex x="25.31" y="6.58"/>
<vertex x="25.36" y="6.56"/>
<vertex x="25.36" y="6.63"/>
<vertex x="25.38" y="6.7"/>
<vertex x="25.42" y="6.67"/>
<vertex x="25.52" y="6.6"/>
<vertex x="25.59" y="6.53"/>
<vertex x="25.61" y="6.5"/>
<vertex x="25.63" y="6.55"/>
<vertex x="25.64" y="6.58"/>
<vertex x="25.64" y="6.59"/>
<vertex x="25.65" y="6.6"/>
<vertex x="25.7" y="6.66"/>
<vertex x="25.85" y="6.82"/>
<vertex x="25.96" y="6.79"/>
<vertex x="26.3" y="6.63"/>
<vertex x="26.49" y="6.69"/>
<vertex x="26.62" y="6.75"/>
<vertex x="26.71" y="6.81"/>
<vertex x="26.81" y="6.87"/>
<vertex x="26.92" y="6.82"/>
<vertex x="27.05" y="6.82"/>
<vertex x="27.12" y="6.8"/>
<vertex x="27.09" y="6.71"/>
<vertex x="27" y="6.59"/>
<vertex x="26.9" y="6.47"/>
<vertex x="26.85" y="6.43"/>
<vertex x="26.9" y="6.41"/>
<vertex x="26.99" y="6.36"/>
<vertex x="27.11" y="6.24"/>
<vertex x="27.14" y="6.12"/>
<vertex x="27.14" y="5.95"/>
<vertex x="27.15" y="5.87"/>
<vertex x="26.98" y="5.69"/>
<vertex x="26.96" y="5.63"/>
<vertex x="27.03" y="5.58"/>
<vertex x="27.19" y="5.42"/>
<vertex x="27.15" y="5.06"/>
<vertex x="26.63" y="4.58"/>
<vertex x="27.08" y="4.03"/>
<vertex x="27.18" y="3.73"/>
<vertex x="27.21" y="3.49"/>
<vertex x="27.07" y="3.31"/>
<vertex x="26.88" y="3.18"/>
<vertex x="26.83" y="3.09"/>
<vertex x="26.62" y="2.83"/>
<vertex x="27.03" y="2.46"/>
<vertex x="27.05" y="2.39"/>
<vertex x="26.81" y="2.24"/>
<vertex x="26.87" y="1.96"/>
<vertex x="26.86" y="1.87"/>
<vertex x="26.82" y="1.76"/>
<vertex x="26.81" y="1.69"/>
<vertex x="26.79" y="1.57"/>
<vertex x="26.75" y="1.39"/>
<vertex x="26.93" y="1.24"/>
<vertex x="26.81" y="1.09"/>
<vertex x="26.62" y="0.53"/>
<vertex x="26.53" y="0.19"/>
<vertex x="26.53" y="0.11"/>
<vertex x="26.72" y="-0.23"/>
<vertex x="26.75" y="-0.27"/>
<vertex x="26.81" y="-0.36"/>
<vertex x="26.9" y="-0.51"/>
<vertex x="26.92" y="-0.69"/>
<vertex x="26.94" y="-0.89"/>
<vertex x="26.86" y="-0.88"/>
<vertex x="26.62" y="-0.64"/>
<vertex x="26.44" y="-0.42"/>
<vertex x="26.42" y="-0.51"/>
<vertex x="26.36" y="-0.62"/>
<vertex x="26.35" y="-0.59"/>
<vertex x="26.31" y="-0.58"/>
<vertex x="26.26" y="-0.53"/>
<vertex x="26.28" y="-1.2"/>
<vertex x="26.31" y="-1.16"/>
<vertex x="26.37" y="-1.13"/>
<vertex x="26.48" y="-1.09"/>
<vertex x="26.82" y="-1.3"/>
<vertex x="27.28" y="-1.48"/>
<vertex x="27.52" y="-1.5"/>
<vertex x="27.58" y="-1.01"/>
<vertex x="27.6" y="-0.27"/>
<vertex x="27.47" y="-0.04"/>
<vertex x="27.41" y="0.06"/>
<vertex x="27.13" y="0.41"/>
<vertex x="27.32" y="0.85"/>
<vertex x="27.35" y="1.06"/>
<vertex x="27.54" y="1.28"/>
<vertex x="27.27" y="1.53"/>
<vertex x="27.35" y="1.79"/>
<vertex x="27.35" y="1.89"/>
<vertex x="27.33" y="2.12"/>
<vertex x="27.52" y="2.29"/>
<vertex x="27.32" y="2.79"/>
<vertex x="27.53" y="3.14"/>
<vertex x="27.66" y="3.43"/>
<vertex x="27.71" y="3.5"/>
<vertex x="27.59" y="4.54"/>
<vertex x="27.61" y="4.58"/>
<vertex x="27.69" y="4.6"/>
<vertex x="27.75" y="4.73"/>
<vertex x="27.74" y="4.83"/>
<vertex x="27.73" y="4.94"/>
<vertex x="27.72" y="5.32"/>
<vertex x="27.68" y="5.34"/>
<vertex x="27.56" y="5.48"/>
<vertex x="27.57" y="5.52"/>
<vertex x="27.63" y="5.63"/>
<vertex x="27.53" y="6.22"/>
<vertex x="27.51" y="6.25"/>
<vertex x="27.5" y="6.27"/>
<vertex x="27.49" y="6.28"/>
<vertex x="27.46" y="6.35"/>
<vertex x="27.4" y="6.47"/>
<vertex x="27.51" y="6.66"/>
<vertex x="27.63" y="6.88"/>
<vertex x="27.59" y="6.98"/>
<vertex x="27.55" y="7.06"/>
<vertex x="27.49" y="7.26"/>
<vertex x="27.3" y="7.21"/>
<vertex x="27.07" y="7.24"/>
<vertex x="26.82" y="7.26"/>
<vertex x="26.49" y="7.15"/>
<vertex x="26.43" y="7.12"/>
<vertex x="26.25" y="7.09"/>
<vertex x="25.92" y="7.22"/>
<vertex x="25.76" y="7.28"/>
<vertex x="25.68" y="7.32"/>
</polygon>
<vertex x="25.52" y="4.01"/>
<vertex x="24.71" y="3.98"/>
<vertex x="24.7" y="3.98"/>
<vertex x="24.69" y="3.97"/>
<vertex x="24.68" y="3.97"/>
<vertex x="24.68" y="3.96"/>
<vertex x="24.67" y="3.95"/>
<vertex x="24.67" y="3.94"/>
<vertex x="24.66" y="3.93"/>
<vertex x="24.66" y="3.91"/>
<vertex x="24.81" y="0.36"/>
<vertex x="24.81" y="0.34"/>
<vertex x="24.82" y="0.34"/>
<vertex x="24.82" y="0.33"/>
<vertex x="24.83" y="0.33"/>
<vertex x="24.83" y="0.32"/>
<vertex x="24.84" y="0.32"/>
<vertex x="24.85" y="0.31"/>
<vertex x="24.87" y="0.31"/>
<vertex x="25.26" y="0.32"/>
<vertex x="25.28" y="0.32"/>
<vertex x="25.29" y="0.33"/>
<vertex x="25.3" y="0.33"/>
<vertex x="25.3" y="0.34"/>
<vertex x="25.31" y="0.34"/>
<vertex x="25.31" y="0.38"/>
<vertex x="25.26" y="1.66"/>
<vertex x="25.27" y="1.67"/>
<vertex x="25.27" y="1.69"/>
<vertex x="25.28" y="1.7"/>
<vertex x="25.29" y="1.7"/>
<vertex x="25.29" y="1.71"/>
<vertex x="25.3" y="1.71"/>
<vertex x="25.31" y="1.72"/>
<vertex x="25.32" y="1.72"/>
<vertex x="25.52" y="1.73"/>
<vertex x="25.52" y="2.24"/>
<vertex x="25.3" y="2.23"/>
<vertex x="25.27" y="2.23"/>
<vertex x="25.25" y="2.25"/>
<vertex x="25.25" y="2.26"/>
<vertex x="25.24" y="2.26"/>
<vertex x="25.24" y="2.29"/>
<vertex x="25.19" y="3.43"/>
<vertex x="25.19" y="3.46"/>
<vertex x="25.2" y="3.46"/>
<vertex x="25.2" y="3.47"/>
<vertex x="25.21" y="3.47"/>
<vertex x="25.21" y="3.48"/>
<vertex x="25.22" y="3.48"/>
<vertex x="25.23" y="3.49"/>
<vertex x="25.25" y="3.49"/>
<vertex x="25.52" y="3.5"/>
</polygon>
<vertex x="25.65" y="3.51"/>
<vertex x="25.66" y="3.51"/>
<vertex x="25.67" y="3.5"/>
<vertex x="25.71" y="3.5"/>
<vertex x="25.72" y="3.49"/>
<vertex x="25.73" y="3.49"/>
<vertex x="25.74" y="3.48"/>
<vertex x="25.75" y="3.48"/>
<vertex x="25.75" y="3.47"/>
<vertex x="25.76" y="3.47"/>
<vertex x="25.87" y="3.37"/>
<vertex x="25.87" y="3.36"/>
<vertex x="25.88" y="3.35"/>
<vertex x="25.88" y="3.34"/>
<vertex x="25.89" y="3.34"/>
<vertex x="25.89" y="3.32"/>
<vertex x="25.9" y="3.32"/>
<vertex x="25.9" y="3.29"/>
<vertex x="25.91" y="3.28"/>
<vertex x="25.91" y="3.27"/>
<vertex x="25.94" y="2.5"/>
<vertex x="25.94" y="2.46"/>
<vertex x="25.93" y="2.45"/>
<vertex x="25.93" y="2.43"/>
<vertex x="25.92" y="2.42"/>
<vertex x="25.92" y="2.41"/>
<vertex x="25.91" y="2.41"/>
<vertex x="25.91" y="2.4"/>
<vertex x="25.81" y="2.29"/>
<vertex x="25.79" y="2.27"/>
<vertex x="25.78" y="2.27"/>
<vertex x="25.77" y="2.26"/>
<vertex x="25.76" y="2.26"/>
<vertex x="25.75" y="2.25"/>
<vertex x="25.72" y="2.25"/>
<vertex x="25.72" y="2.24"/>
<vertex x="25.94" y="1.74"/>
<vertex x="25.95" y="1.74"/>
<vertex x="25.95" y="1.75"/>
<vertex x="25.98" y="1.75"/>
<vertex x="25.99" y="1.76"/>
<vertex x="26" y="1.76"/>
<vertex x="26.01" y="1.77"/>
<vertex x="26.02" y="1.77"/>
<vertex x="26.02" y="1.78"/>
<vertex x="26.03" y="1.78"/>
<vertex x="26.03" y="1.79"/>
<vertex x="26.42" y="2.2"/>
<vertex x="26.42" y="2.21"/>
<vertex x="26.44" y="2.23"/>
<vertex x="26.44" y="2.24"/>
<vertex x="26.45" y="2.25"/>
<vertex x="26.45" y="2.27"/>
<vertex x="26.46" y="2.28"/>
<vertex x="26.46" y="2.3"/>
<vertex x="26.41" y="3.51"/>
<vertex x="26.41" y="3.52"/>
<vertex x="26.4" y="3.53"/>
<vertex x="26.4" y="3.55"/>
<vertex x="26.39" y="3.56"/>
<vertex x="26.39" y="3.58"/>
<vertex x="26.36" y="3.61"/>
<vertex x="25.94" y="3.99"/>
<vertex x="25.93" y="3.99"/>
<vertex x="25.93" y="4"/>
<vertex x="25.92" y="4"/>
<vertex x="25.91" y="4.01"/>
<vertex x="25.89" y="4.01"/>
<vertex x="25.89" y="4.02"/>
<vertex x="25.85" y="4.02"/>
</polygon>
<vertex x="42.02" y="-2.81"/>
<vertex x="41.44" y="-2.81"/>
<vertex x="41.46" y="-2.89"/>
<vertex x="41.47" y="-2.94"/>
<vertex x="41.49" y="-2.98"/>
<vertex x="41.49" y="-3.26"/>
<vertex x="41.5" y="-3.28"/>
<vertex x="41.48" y="-3.28"/>
<vertex x="41.47" y="-3.29"/>
<vertex x="41.44" y="-3.29"/>
<vertex x="41.43" y="-3.3"/>
<vertex x="41.42" y="-3.3"/>
<vertex x="41.4" y="-3.31"/>
<vertex x="41.39" y="-3.31"/>
<vertex x="41.37" y="-3.32"/>
<vertex x="41.35" y="-3.32"/>
<vertex x="41.33" y="-3.33"/>
<vertex x="41.28" y="-3.33"/>
<vertex x="41.27" y="-3.34"/>
<vertex x="41.25" y="-3.32"/>
<vertex x="41.25" y="-3.31"/>
<vertex x="41.24" y="-3.31"/>
<vertex x="41.24" y="-3.3"/>
<vertex x="41.23" y="-3.3"/>
<vertex x="41.23" y="-3.29"/>
<vertex x="41.22" y="-3.29"/>
<vertex x="41.22" y="-3.28"/>
<vertex x="41.19" y="-3.25"/>
<vertex x="41.18" y="-3.25"/>
<vertex x="41.18" y="-3.24"/>
<vertex x="41.17" y="-3.23"/>
<vertex x="41.16" y="-3.23"/>
<vertex x="41.16" y="-3.22"/>
<vertex x="41.15" y="-3.22"/>
<vertex x="41.15" y="-3.2"/>
<vertex x="41.14" y="-3.2"/>
<vertex x="41.12" y="-3.18"/>
<vertex x="41.11" y="-3.18"/>
<vertex x="41.08" y="-3.15"/>
<vertex x="41.07" y="-3.15"/>
<vertex x="41.05" y="-3.14"/>
<vertex x="41.01" y="-3.1"/>
<vertex x="41" y="-3.1"/>
<vertex x="41" y="-3.09"/>
<vertex x="40.97" y="-3.06"/>
<vertex x="40.91" y="-3.08"/>
<vertex x="40.88" y="-3.1"/>
<vertex x="40.85" y="-3.11"/>
<vertex x="40.83" y="-3.13"/>
<vertex x="40.8" y="-3.14"/>
<vertex x="40.74" y="-3.18"/>
<vertex x="40.71" y="-3.19"/>
<vertex x="40.68" y="-3.21"/>
<vertex x="40.66" y="-3.23"/>
<vertex x="40.63" y="-3.24"/>
<vertex x="40.57" y="-3.28"/>
<vertex x="40.54" y="-3.29"/>
<vertex x="40.51" y="-3.31"/>
<vertex x="40.5" y="-3.3"/>
<vertex x="40.48" y="-3.3"/>
<vertex x="40.47" y="-3.29"/>
<vertex x="40.41" y="-3.29"/>
<vertex x="40.39" y="-3.28"/>
<vertex x="40.38" y="-3.28"/>
<vertex x="40.37" y="-3.27"/>
<vertex x="40.36" y="-3.27"/>
<vertex x="40.33" y="-3.28"/>
<vertex x="40.3" y="-3.28"/>
<vertex x="40.24" y="-3.3"/>
<vertex x="40.21" y="-3.3"/>
<vertex x="40.18" y="-3.31"/>
<vertex x="40.16" y="-3.32"/>
<vertex x="39.98" y="-3.38"/>
<vertex x="39.96" y="-3.39"/>
<vertex x="39.93" y="-3.39"/>
<vertex x="39.9" y="-3.4"/>
<vertex x="39.89" y="-3.41"/>
<vertex x="39.89" y="-3.42"/>
<vertex x="39.88" y="-3.42"/>
<vertex x="39.88" y="-3.43"/>
<vertex x="39.87" y="-3.43"/>
<vertex x="39.86" y="-3.44"/>
<vertex x="39.86" y="-3.45"/>
<vertex x="39.85" y="-3.45"/>
<vertex x="39.83" y="-3.47"/>
<vertex x="39.82" y="-3.47"/>
<vertex x="39.82" y="-3.48"/>
<vertex x="39.81" y="-3.48"/>
<vertex x="39.81" y="-3.5"/>
<vertex x="39.8" y="-3.5"/>
<vertex x="39.75" y="-3.55"/>
<vertex x="39.74" y="-3.55"/>
<vertex x="39.74" y="-3.56"/>
<vertex x="39.72" y="-3.58"/>
<vertex x="39.71" y="-3.58"/>
<vertex x="39.7" y="-3.59"/>
<vertex x="39.7" y="-3.6"/>
<vertex x="39.68" y="-3.62"/>
<vertex x="39.67" y="-3.62"/>
<vertex x="39.66" y="-3.63"/>
<vertex x="39.65" y="-3.63"/>
<vertex x="39.64" y="-3.64"/>
<vertex x="39.61" y="-3.64"/>
<vertex x="39.6" y="-3.65"/>
<vertex x="39.59" y="-3.65"/>
<vertex x="39.59" y="-3.66"/>
<vertex x="39.58" y="-3.66"/>
<vertex x="39.57" y="-3.67"/>
<vertex x="39.56" y="-3.67"/>
<vertex x="39.55" y="-3.68"/>
<vertex x="39.54" y="-3.68"/>
<vertex x="39.53" y="-3.69"/>
<vertex x="39.51" y="-3.69"/>
<vertex x="39.51" y="-3.7"/>
<vertex x="39.49" y="-3.7"/>
<vertex x="39.48" y="-3.71"/>
<vertex x="39.47" y="-3.71"/>
<vertex x="39.41" y="-3.72"/>
<vertex x="39.41" y="-3.68"/>
<vertex x="39.4" y="-3.66"/>
<vertex x="39.4" y="-3.63"/>
<vertex x="39.39" y="-3.62"/>
<vertex x="39.39" y="-3.58"/>
<vertex x="39.38" y="-3.56"/>
<vertex x="39.38" y="-3.52"/>
<vertex x="39.37" y="-3.51"/>
<vertex x="39.37" y="-3.47"/>
<vertex x="39.36" y="-3.46"/>
<vertex x="39.36" y="-3.42"/>
<vertex x="39.35" y="-3.41"/>
<vertex x="39.35" y="-3.37"/>
<vertex x="39.34" y="-3.36"/>
<vertex x="39.34" y="-3.34"/>
<vertex x="39.33" y="-3.33"/>
<vertex x="39.33" y="-3.29"/>
<vertex x="39.32" y="-3.29"/>
<vertex x="39.32" y="-3.26"/>
<vertex x="39.31" y="-3.25"/>
<vertex x="39.31" y="-3.22"/>
<vertex x="39.3" y="-3.22"/>
<vertex x="39.3" y="-3.19"/>
<vertex x="39.29" y="-3.18"/>
<vertex x="39.29" y="-3.16"/>
<vertex x="39.28" y="-3.16"/>
<vertex x="39.28" y="-3.14"/>
<vertex x="39.27" y="-3.13"/>
<vertex x="39.27" y="-3.11"/>
<vertex x="39.26" y="-3.1"/>
<vertex x="39.26" y="-3.08"/>
<vertex x="39.25" y="-3.07"/>
<vertex x="39.25" y="-3.06"/>
<vertex x="39.24" y="-3.05"/>
<vertex x="39.23" y="-3.03"/>
<vertex x="39.23" y="-3.02"/>
<vertex x="39.22" y="-3.01"/>
<vertex x="39.22" y="-2.99"/>
<vertex x="39.2" y="-2.97"/>
<vertex x="39.2" y="-2.96"/>
<vertex x="39.19" y="-2.94"/>
<vertex x="39.17" y="-2.92"/>
<vertex x="39.17" y="-2.91"/>
<vertex x="39.16" y="-2.89"/>
<vertex x="39.14" y="-2.87"/>
<vertex x="39.13" y="-2.71"/>
<vertex x="39.13" y="-2.69"/>
<vertex x="39.14" y="-2.68"/>
<vertex x="39.14" y="-2.63"/>
<vertex x="39.15" y="-2.62"/>
<vertex x="39.15" y="-2.56"/>
<vertex x="39.16" y="-2.55"/>
<vertex x="39.16" y="-2.49"/>
<vertex x="39.17" y="-2.47"/>
<vertex x="39.17" y="-2.42"/>
<vertex x="39.18" y="-2.41"/>
<vertex x="39.18" y="-2.39"/>
<vertex x="39.19" y="-2.37"/>
<vertex x="39.19" y="-2.35"/>
<vertex x="39.2" y="-2.34"/>
<vertex x="39.2" y="-2.32"/>
<vertex x="39.19" y="-2.31"/>
<vertex x="39.19" y="-2.3"/>
<vertex x="39.18" y="-2.3"/>
<vertex x="39.18" y="-2.29"/>
<vertex x="39.17" y="-2.29"/>
<vertex x="39.16" y="-2.28"/>
<vertex x="39.03" y="-2.28"/>
<vertex x="39.02" y="-2.27"/>
<vertex x="38.76" y="-2.27"/>
<vertex x="38.75" y="-2.26"/>
<vertex x="38.72" y="-2.26"/>
<vertex x="38.7" y="-2.25"/>
<vertex x="38.68" y="-2.25"/>
<vertex x="38.67" y="-2.24"/>
<vertex x="38.65" y="-2.24"/>
<vertex x="38.64" y="-2.23"/>
<vertex x="38.62" y="-2.23"/>
<vertex x="38.6" y="-2.22"/>
<vertex x="38.57" y="-2.22"/>
<vertex x="38.56" y="-2.21"/>
<vertex x="38.54" y="-2.21"/>
<vertex x="38.52" y="-2.2"/>
<vertex x="38.51" y="-2.2"/>
<vertex x="38.49" y="-2.19"/>
<vertex x="38.46" y="-2.19"/>
<vertex x="38.45" y="-2.18"/>
<vertex x="38.41" y="-2.18"/>
<vertex x="38.4" y="-2.17"/>
<vertex x="38.36" y="-2.15"/>
<vertex x="38.35" y="-2.15"/>
<vertex x="38.31" y="-2.13"/>
<vertex x="38.3" y="-2.13"/>
<vertex x="38.28" y="-2.12"/>
<vertex x="38.27" y="-2.11"/>
<vertex x="38.25" y="-2.11"/>
<vertex x="38.23" y="-2.1"/>
<vertex x="38.22" y="-2.1"/>
<vertex x="38.2" y="-2.09"/>
<vertex x="38.18" y="-2.09"/>
<vertex x="38.17" y="-2.08"/>
<vertex x="38.15" y="-2.07"/>
<vertex x="38.13" y="-2.07"/>
<vertex x="38.12" y="-2.06"/>
<vertex x="38.1" y="-2.06"/>
<vertex x="38.06" y="-2.04"/>
<vertex x="38.05" y="-2.04"/>
<vertex x="38.01" y="-2.02"/>
<vertex x="38" y="-2.01"/>
<vertex x="37.98" y="-2.01"/>
<vertex x="37.94" y="-1.99"/>
<vertex x="37.93" y="-1.98"/>
<vertex x="37.91" y="-1.97"/>
<vertex x="37.9" y="-1.97"/>
<vertex x="37.88" y="-1.96"/>
<vertex x="37.87" y="-1.95"/>
<vertex x="37.84" y="-1.95"/>
<vertex x="37.83" y="-1.94"/>
<vertex x="37.79" y="-1.94"/>
<vertex x="37.78" y="-1.93"/>
<vertex x="37.77" y="-1.93"/>
<vertex x="37.77" y="-1.84"/>
<vertex x="37.76" y="-1.82"/>
<vertex x="37.76" y="-1.6"/>
<vertex x="37.75" y="-1.57"/>
<vertex x="37.75" y="-1.38"/>
<vertex x="37.74" y="-1.37"/>
<vertex x="37.74" y="-1.11"/>
<vertex x="37.75" y="-1.06"/>
<vertex x="37.75" y="-0.84"/>
<vertex x="37.76" y="-0.8"/>
<vertex x="37.76" y="-0.72"/>
<vertex x="37.77" y="-0.67"/>
<vertex x="37.77" y="-0.63"/>
<vertex x="37.8" y="-0.51"/>
<vertex x="37.8" y="-0.46"/>
<vertex x="37.81" y="-0.46"/>
<vertex x="37.81" y="-0.42"/>
<vertex x="37.82" y="-0.41"/>
<vertex x="37.82" y="-0.39"/>
<vertex x="37.84" y="-0.36"/>
<vertex x="37.85" y="-0.33"/>
<vertex x="37.87" y="-0.29"/>
<vertex x="37.89" y="-0.26"/>
<vertex x="37.9" y="-0.23"/>
<vertex x="37.92" y="-0.19"/>
<vertex x="37.93" y="-0.16"/>
<vertex x="37.95" y="-0.13"/>
<vertex x="37.96" y="-0.1"/>
<vertex x="37.98" y="-0.06"/>
<vertex x="37.99" y="-0.03"/>
<vertex x="38.03" y="0.03"/>
<vertex x="38.04" y="0.06"/>
<vertex x="38.06" y="0.08"/>
<vertex x="38.1" y="0.14"/>
<vertex x="38.11" y="0.16"/>
<vertex x="38.11" y="0.26"/>
<vertex x="38.1" y="0.28"/>
<vertex x="38.09" y="0.31"/>
<vertex x="38.07" y="0.35"/>
<vertex x="38.05" y="0.37"/>
<vertex x="38.04" y="0.4"/>
<vertex x="38.03" y="0.42"/>
<vertex x="38.01" y="0.44"/>
<vertex x="37.99" y="0.48"/>
<vertex x="38" y="0.5"/>
<vertex x="38" y="0.52"/>
<vertex x="38.01" y="0.54"/>
<vertex x="38.02" y="0.57"/>
<vertex x="38.02" y="0.59"/>
<vertex x="38.03" y="0.61"/>
<vertex x="38.03" y="0.63"/>
<vertex x="38.04" y="0.65"/>
<vertex x="38.04" y="0.67"/>
<vertex x="38.07" y="0.73"/>
<vertex x="38.07" y="0.75"/>
<vertex x="38.1" y="0.81"/>
<vertex x="38.09" y="0.83"/>
<vertex x="38.08" y="0.84"/>
<vertex x="38.07" y="0.86"/>
<vertex x="38.02" y="0.91"/>
<vertex x="38.02" y="0.92"/>
<vertex x="38.01" y="0.93"/>
<vertex x="38" y="0.93"/>
<vertex x="37.95" y="0.98"/>
<vertex x="37.96" y="1.01"/>
<vertex x="37.97" y="1.05"/>
<vertex x="37.99" y="1.08"/>
<vertex x="38" y="1.11"/>
<vertex x="38.01" y="1.15"/>
<vertex x="38.02" y="1.18"/>
<vertex x="38.03" y="1.22"/>
<vertex x="38.04" y="1.25"/>
<vertex x="38.05" y="1.29"/>
<vertex x="38.06" y="1.32"/>
<vertex x="38.06" y="1.36"/>
<vertex x="38.08" y="1.44"/>
<vertex x="38.09" y="1.47"/>
<vertex x="38.09" y="1.51"/>
<vertex x="38.1" y="1.55"/>
<vertex x="38.1" y="1.57"/>
<vertex x="38.11" y="1.57"/>
<vertex x="38.11" y="1.61"/>
<vertex x="38.12" y="1.62"/>
<vertex x="38.12" y="1.63"/>
<vertex x="38.1" y="1.65"/>
<vertex x="38.1" y="1.67"/>
<vertex x="38.08" y="1.69"/>
<vertex x="38.08" y="1.7"/>
<vertex x="38.07" y="1.71"/>
<vertex x="38.07" y="1.72"/>
<vertex x="38.05" y="1.74"/>
<vertex x="38.05" y="1.75"/>
<vertex x="38.04" y="1.76"/>
<vertex x="38.03" y="1.76"/>
<vertex x="38.03" y="1.77"/>
<vertex x="38.01" y="1.79"/>
<vertex x="38.03" y="1.85"/>
<vertex x="38.05" y="1.89"/>
<vertex x="38.06" y="1.92"/>
<vertex x="38.08" y="1.94"/>
<vertex x="38.09" y="1.97"/>
<vertex x="38.11" y="2.01"/>
<vertex x="38.12" y="2.04"/>
<vertex x="38.14" y="2.06"/>
<vertex x="38.15" y="2.08"/>
<vertex x="38.16" y="2.11"/>
<vertex x="38.17" y="2.13"/>
<vertex x="38.18" y="2.16"/>
<vertex x="38.19" y="2.18"/>
<vertex x="38.17" y="2.2"/>
<vertex x="38.17" y="2.21"/>
<vertex x="38.16" y="2.22"/>
<vertex x="38.14" y="2.22"/>
<vertex x="38.13" y="2.23"/>
<vertex x="38.12" y="2.23"/>
<vertex x="38.11" y="2.24"/>
<vertex x="38.1" y="2.24"/>
<vertex x="38.09" y="2.25"/>
<vertex x="38.09" y="2.26"/>
<vertex x="38.06" y="2.29"/>
<vertex x="38.06" y="2.3"/>
<vertex x="38.01" y="2.3"/>
<vertex x="38.03" y="2.4"/>
<vertex x="38.05" y="2.44"/>
<vertex x="38.07" y="2.54"/>
<vertex x="38.09" y="2.59"/>
<vertex x="38.11" y="2.63"/>
<vertex x="38.12" y="2.68"/>
<vertex x="38.14" y="2.73"/>
<vertex x="38.15" y="2.77"/>
<vertex x="38.17" y="2.82"/>
<vertex x="38.18" y="2.87"/>
<vertex x="38.2" y="2.92"/>
<vertex x="38.21" y="2.96"/>
<vertex x="38.22" y="3.01"/>
<vertex x="38.24" y="3.06"/>
<vertex x="38.22" y="3.13"/>
<vertex x="38.21" y="3.19"/>
<vertex x="38.2" y="3.26"/>
<vertex x="38.18" y="3.33"/>
<vertex x="38.17" y="3.4"/>
<vertex x="38.16" y="3.46"/>
<vertex x="38.14" y="3.53"/>
<vertex x="38.12" y="3.67"/>
<vertex x="38.12" y="3.73"/>
<vertex x="38.11" y="3.8"/>
<vertex x="38.11" y="4.01"/>
<vertex x="38.12" y="4.08"/>
<vertex x="38.13" y="4.16"/>
<vertex x="38.14" y="4.17"/>
<vertex x="38.14" y="4.18"/>
<vertex x="38.15" y="4.19"/>
<vertex x="38.16" y="4.19"/>
<vertex x="38.16" y="4.2"/>
<vertex x="38.17" y="4.21"/>
<vertex x="38.17" y="4.36"/>
<vertex x="38.18" y="4.43"/>
<vertex x="38.18" y="4.58"/>
<vertex x="38.19" y="4.66"/>
<vertex x="38.19" y="4.81"/>
<vertex x="38.18" y="4.88"/>
<vertex x="38.18" y="4.95"/>
<vertex x="38.17" y="5.03"/>
<vertex x="38.15" y="5.17"/>
<vertex x="38.13" y="5.24"/>
<vertex x="38.11" y="5.3"/>
<vertex x="38.08" y="5.37"/>
<vertex x="38.08" y="5.43"/>
<vertex x="38.07" y="5.49"/>
<vertex x="38.07" y="5.54"/>
<vertex x="38.08" y="5.6"/>
<vertex x="38.09" y="5.65"/>
<vertex x="38.11" y="5.69"/>
<vertex x="38.12" y="5.74"/>
<vertex x="38.14" y="5.78"/>
<vertex x="38.16" y="5.83"/>
<vertex x="38.19" y="5.87"/>
<vertex x="38.21" y="5.91"/>
<vertex x="38.24" y="5.95"/>
<vertex x="38.28" y="6.03"/>
<vertex x="38.31" y="6.07"/>
<vertex x="38.33" y="6.11"/>
<vertex x="38.31" y="6.13"/>
<vertex x="38.3" y="6.16"/>
<vertex x="38.26" y="6.2"/>
<vertex x="38.25" y="6.22"/>
<vertex x="38.23" y="6.24"/>
<vertex x="38.21" y="6.27"/>
<vertex x="38.19" y="6.29"/>
<vertex x="38.18" y="6.31"/>
<vertex x="38.12" y="6.37"/>
<vertex x="38.11" y="6.4"/>
<vertex x="38.07" y="6.44"/>
<vertex x="38.06" y="6.46"/>
<vertex x="38.06" y="6.47"/>
<vertex x="38.08" y="6.49"/>
<vertex x="38.08" y="6.5"/>
<vertex x="38.09" y="6.51"/>
<vertex x="38.09" y="6.53"/>
<vertex x="38.1" y="6.53"/>
<vertex x="38.1" y="6.54"/>
<vertex x="38.11" y="6.55"/>
<vertex x="38.11" y="6.57"/>
<vertex x="38.12" y="6.58"/>
<vertex x="38.12" y="6.59"/>
<vertex x="38.13" y="6.6"/>
<vertex x="38.19" y="6.73"/>
<vertex x="38.24" y="6.79"/>
<vertex x="38.02" y="6.74"/>
<vertex x="38.05" y="6.95"/>
<vertex x="37.86" y="6.95"/>
<vertex x="37.84" y="6.9"/>
<vertex x="37.83" y="6.86"/>
<vertex x="37.81" y="6.82"/>
<vertex x="37.79" y="6.77"/>
<vertex x="37.71" y="6.61"/>
<vertex x="37.69" y="6.58"/>
<vertex x="37.61" y="6.42"/>
<vertex x="37.59" y="6.37"/>
<vertex x="37.57" y="6.33"/>
<vertex x="37.56" y="6.28"/>
<vertex x="37.59" y="6.26"/>
<vertex x="37.61" y="6.25"/>
<vertex x="37.62" y="6.24"/>
<vertex x="37.63" y="6.24"/>
<vertex x="37.65" y="6.23"/>
<vertex x="37.67" y="6.21"/>
<vertex x="37.69" y="6.2"/>
<vertex x="37.71" y="6.18"/>
<vertex x="37.73" y="6.17"/>
<vertex x="37.74" y="6.17"/>
<vertex x="37.75" y="6.16"/>
<vertex x="37.77" y="6.15"/>
<vertex x="37.78" y="6.14"/>
<vertex x="37.79" y="6.14"/>
<vertex x="37.8" y="6.13"/>
<vertex x="37.8" y="6.11"/>
<vertex x="37.79" y="6.1"/>
<vertex x="37.79" y="6.09"/>
<vertex x="37.78" y="6.08"/>
<vertex x="37.78" y="6.07"/>
<vertex x="37.76" y="6.05"/>
<vertex x="37.76" y="6.04"/>
<vertex x="37.75" y="6.03"/>
<vertex x="37.74" y="6.03"/>
<vertex x="37.74" y="6.02"/>
<vertex x="37.73" y="6.01"/>
<vertex x="37.72" y="6.01"/>
<vertex x="37.72" y="6"/>
<vertex x="37.71" y="5.99"/>
<vertex x="37.71" y="5.9"/>
<vertex x="37.7" y="5.9"/>
<vertex x="37.7" y="5.89"/>
<vertex x="37.69" y="5.89"/>
<vertex x="37.69" y="5.88"/>
<vertex x="37.68" y="5.87"/>
<vertex x="37.67" y="5.87"/>
<vertex x="37.67" y="5.86"/>
<vertex x="37.65" y="5.86"/>
<vertex x="37.64" y="5.81"/>
<vertex x="37.63" y="5.77"/>
<vertex x="37.63" y="5.68"/>
<vertex x="37.62" y="5.63"/>
<vertex x="37.63" y="5.59"/>
<vertex x="37.63" y="5.5"/>
<vertex x="37.7" y="5.22"/>
<vertex x="37.72" y="5.18"/>
<vertex x="37.7" y="5.04"/>
<vertex x="37.7" y="4.97"/>
<vertex x="37.68" y="4.9"/>
<vertex x="37.66" y="4.76"/>
<vertex x="37.64" y="4.69"/>
<vertex x="37.63" y="4.63"/>
<vertex x="37.61" y="4.56"/>
<vertex x="37.59" y="4.5"/>
<vertex x="37.57" y="4.43"/>
<vertex x="37.56" y="4.37"/>
<vertex x="37.54" y="4.3"/>
<vertex x="37.5" y="4.18"/>
<vertex x="37.48" y="4.11"/>
<vertex x="37.49" y="4.06"/>
<vertex x="37.51" y="4"/>
<vertex x="37.52" y="3.94"/>
<vertex x="37.54" y="3.89"/>
<vertex x="37.55" y="3.83"/>
<vertex x="37.57" y="3.78"/>
<vertex x="37.58" y="3.72"/>
<vertex x="37.6" y="3.67"/>
<vertex x="37.61" y="3.61"/>
<vertex x="37.63" y="3.56"/>
<vertex x="37.65" y="3.44"/>
<vertex x="37.66" y="3.39"/>
<vertex x="37.67" y="3.33"/>
<vertex x="37.68" y="3.28"/>
<vertex x="37.69" y="3.22"/>
<vertex x="37.69" y="3.21"/>
<vertex x="37.7" y="3.2"/>
<vertex x="37.7" y="3.19"/>
<vertex x="37.72" y="3.17"/>
<vertex x="37.72" y="3.16"/>
<vertex x="37.73" y="3.15"/>
<vertex x="37.73" y="3.14"/>
<vertex x="37.74" y="3.13"/>
<vertex x="37.74" y="3.11"/>
<vertex x="37.75" y="3.1"/>
<vertex x="37.75" y="3.08"/>
<vertex x="37.76" y="3.07"/>
<vertex x="37.76" y="3.04"/>
<vertex x="37.74" y="3.01"/>
<vertex x="37.75" y="3.01"/>
<vertex x="37.76" y="3"/>
<vertex x="37.76" y="2.99"/>
<vertex x="37.77" y="2.98"/>
<vertex x="37.77" y="2.97"/>
<vertex x="37.78" y="2.96"/>
<vertex x="37.78" y="2.95"/>
<vertex x="37.79" y="2.94"/>
<vertex x="37.79" y="2.92"/>
<vertex x="37.8" y="2.9"/>
<vertex x="37.8" y="2.88"/>
<vertex x="37.81" y="2.87"/>
<vertex x="37.81" y="2.84"/>
<vertex x="37.8" y="2.79"/>
<vertex x="37.7" y="2.54"/>
<vertex x="37.67" y="2.5"/>
<vertex x="37.65" y="2.46"/>
<vertex x="37.63" y="2.41"/>
<vertex x="37.61" y="2.37"/>
<vertex x="37.58" y="2.32"/>
<vertex x="37.56" y="2.27"/>
<vertex x="37.54" y="2.23"/>
<vertex x="37.52" y="2.17"/>
<vertex x="37.51" y="2.12"/>
<vertex x="37.49" y="2.07"/>
<vertex x="37.5" y="2.05"/>
<vertex x="37.54" y="2.01"/>
<vertex x="37.55" y="1.99"/>
<vertex x="37.57" y="1.98"/>
<vertex x="37.59" y="1.96"/>
<vertex x="37.61" y="1.95"/>
<vertex x="37.62" y="1.93"/>
<vertex x="37.64" y="1.93"/>
<vertex x="37.66" y="1.91"/>
<vertex x="37.7" y="1.89"/>
<vertex x="37.71" y="1.89"/>
<vertex x="37.7" y="1.87"/>
<vertex x="37.69" y="1.86"/>
<vertex x="37.68" y="1.84"/>
<vertex x="37.67" y="1.83"/>
<vertex x="37.66" y="1.81"/>
<vertex x="37.62" y="1.77"/>
<vertex x="37.6" y="1.73"/>
<vertex x="37.59" y="1.72"/>
<vertex x="37.58" y="1.7"/>
<vertex x="37.54" y="1.66"/>
<vertex x="37.53" y="1.64"/>
<vertex x="37.54" y="1.64"/>
<vertex x="37.55" y="1.63"/>
<vertex x="37.55" y="1.62"/>
<vertex x="37.56" y="1.62"/>
<vertex x="37.56" y="1.61"/>
<vertex x="37.58" y="1.59"/>
<vertex x="37.58" y="1.58"/>
<vertex x="37.61" y="1.55"/>
<vertex x="37.61" y="1.54"/>
<vertex x="37.62" y="1.53"/>
<vertex x="37.62" y="1.52"/>
<vertex x="37.63" y="1.52"/>
<vertex x="37.63" y="1.51"/>
<vertex x="37.64" y="1.5"/>
<vertex x="37.64" y="1.49"/>
<vertex x="37.7" y="1.43"/>
<vertex x="37.71" y="1.43"/>
<vertex x="37.71" y="1.42"/>
<vertex x="37.73" y="1.42"/>
<vertex x="37.74" y="1.41"/>
<vertex x="37.72" y="1.35"/>
<vertex x="37.71" y="1.33"/>
<vertex x="37.69" y="1.27"/>
<vertex x="37.68" y="1.25"/>
<vertex x="37.67" y="1.22"/>
<vertex x="37.66" y="1.2"/>
<vertex x="37.65" y="1.17"/>
<vertex x="37.64" y="1.15"/>
<vertex x="37.63" y="1.12"/>
<vertex x="37.62" y="1.1"/>
<vertex x="37.61" y="1.07"/>
<vertex x="37.59" y="1.05"/>
<vertex x="37.58" y="1.02"/>
<vertex x="37.57" y="1"/>
<vertex x="37.57" y="0.99"/>
<vertex x="37.56" y="0.98"/>
<vertex x="37.56" y="0.95"/>
<vertex x="37.55" y="0.94"/>
<vertex x="37.55" y="0.93"/>
<vertex x="37.54" y="0.92"/>
<vertex x="37.54" y="0.91"/>
<vertex x="37.53" y="0.9"/>
<vertex x="37.53" y="0.89"/>
<vertex x="37.52" y="0.88"/>
<vertex x="37.52" y="0.87"/>
<vertex x="37.51" y="0.87"/>
<vertex x="37.51" y="0.85"/>
<vertex x="37.52" y="0.85"/>
<vertex x="37.52" y="0.84"/>
<vertex x="37.53" y="0.83"/>
<vertex x="37.53" y="0.82"/>
<vertex x="37.54" y="0.82"/>
<vertex x="37.54" y="0.8"/>
<vertex x="37.55" y="0.79"/>
<vertex x="37.55" y="0.78"/>
<vertex x="37.56" y="0.78"/>
<vertex x="37.56" y="0.76"/>
<vertex x="37.57" y="0.75"/>
<vertex x="37.57" y="0.74"/>
<vertex x="37.58" y="0.73"/>
<vertex x="37.58" y="0.71"/>
<vertex x="37.59" y="0.7"/>
<vertex x="37.59" y="0.69"/>
<vertex x="37.6" y="0.69"/>
<vertex x="37.6" y="0.68"/>
<vertex x="37.61" y="0.67"/>
<vertex x="37.61" y="0.65"/>
<vertex x="37.63" y="0.63"/>
<vertex x="37.63" y="0.61"/>
<vertex x="37.64" y="0.61"/>
<vertex x="37.64" y="0.59"/>
<vertex x="37.65" y="0.59"/>
<vertex x="37.65" y="0.58"/>
<vertex x="37.66" y="0.57"/>
<vertex x="37.66" y="0.56"/>
<vertex x="37.67" y="0.56"/>
<vertex x="37.67" y="0.55"/>
<vertex x="37.68" y="0.54"/>
<vertex x="37.68" y="0.53"/>
<vertex x="37.69" y="0.53"/>
<vertex x="37.69" y="0.5"/>
<vertex x="37.68" y="0.48"/>
<vertex x="37.67" y="0.47"/>
<vertex x="37.67" y="0.45"/>
<vertex x="37.66" y="0.43"/>
<vertex x="37.66" y="0.41"/>
<vertex x="37.65" y="0.39"/>
<vertex x="37.65" y="0.37"/>
<vertex x="37.64" y="0.35"/>
<vertex x="37.64" y="0.34"/>
<vertex x="37.63" y="0.31"/>
<vertex x="37.63" y="0.29"/>
<vertex x="37.62" y="0.27"/>
<vertex x="37.62" y="0.25"/>
<vertex x="37.61" y="0.23"/>
<vertex x="37.61" y="0.21"/>
<vertex x="37.62" y="0.2"/>
<vertex x="37.62" y="0.19"/>
<vertex x="37.63" y="0.18"/>
<vertex x="37.63" y="0.17"/>
<vertex x="37.64" y="0.16"/>
<vertex x="37.64" y="0.14"/>
<vertex x="37.65" y="0.14"/>
<vertex x="37.65" y="0.08"/>
<vertex x="37.66" y="0.08"/>
<vertex x="37.66" y="0.05"/>
<vertex x="37.65" y="0.05"/>
<vertex x="37.65" y="-0.01"/>
<vertex x="37.63" y="-0.05"/>
<vertex x="37.63" y="-0.07"/>
<vertex x="37.62" y="-0.09"/>
<vertex x="37.62" y="-0.11"/>
<vertex x="37.61" y="-0.13"/>
<vertex x="37.61" y="-0.15"/>
<vertex x="37.59" y="-0.19"/>
<vertex x="37.59" y="-0.21"/>
<vertex x="37.57" y="-0.25"/>
<vertex x="37.56" y="-0.26"/>
<vertex x="37.54" y="-0.3"/>
<vertex x="37.54" y="-0.31"/>
<vertex x="37.55" y="-0.32"/>
<vertex x="37.55" y="-0.34"/>
<vertex x="37.56" y="-0.34"/>
<vertex x="37.56" y="-0.37"/>
<vertex x="37.55" y="-0.38"/>
<vertex x="37.55" y="-0.4"/>
<vertex x="37.54" y="-0.41"/>
<vertex x="37.54" y="-0.48"/>
<vertex x="37.53" y="-0.49"/>
<vertex x="37.53" y="-0.64"/>
<vertex x="37.52" y="-0.65"/>
<vertex x="37.52" y="-0.8"/>
<vertex x="37.53" y="-0.84"/>
<vertex x="37.53" y="-0.96"/>
<vertex x="37.54" y="-1"/>
<vertex x="37.54" y="-1.19"/>
<vertex x="37.55" y="-1.23"/>
<vertex x="37.55" y="-1.41"/>
<vertex x="37.56" y="-1.42"/>
<vertex x="37.56" y="-1.62"/>
<vertex x="37.57" y="-1.62"/>
<vertex x="37.57" y="-1.8"/>
<vertex x="37.56" y="-1.81"/>
<vertex x="37.56" y="-1.85"/>
<vertex x="37.55" y="-1.86"/>
<vertex x="37.55" y="-2.07"/>
<vertex x="37.61" y="-2.09"/>
<vertex x="37.63" y="-2.1"/>
<vertex x="37.69" y="-2.12"/>
<vertex x="37.71" y="-2.13"/>
<vertex x="37.77" y="-2.15"/>
<vertex x="37.79" y="-2.16"/>
<vertex x="37.88" y="-2.19"/>
<vertex x="37.9" y="-2.2"/>
<vertex x="37.96" y="-2.22"/>
<vertex x="37.98" y="-2.23"/>
<vertex x="38.08" y="-2.26"/>
<vertex x="38.16" y="-2.28"/>
<vertex x="38.18" y="-2.28"/>
<vertex x="38.19" y="-2.29"/>
<vertex x="38.21" y="-2.29"/>
<vertex x="38.22" y="-2.3"/>
<vertex x="38.24" y="-2.3"/>
<vertex x="38.25" y="-2.31"/>
<vertex x="38.27" y="-2.31"/>
<vertex x="38.27" y="-2.32"/>
<vertex x="38.29" y="-2.32"/>
<vertex x="38.3" y="-2.33"/>
<vertex x="38.33" y="-2.33"/>
<vertex x="38.37" y="-2.35"/>
<vertex x="38.39" y="-2.35"/>
<vertex x="38.4" y="-2.36"/>
<vertex x="38.42" y="-2.37"/>
<vertex x="38.44" y="-2.37"/>
<vertex x="38.46" y="-2.38"/>
<vertex x="38.47" y="-2.39"/>
<vertex x="38.49" y="-2.4"/>
<vertex x="38.51" y="-2.4"/>
<vertex x="38.55" y="-2.42"/>
<vertex x="38.56" y="-2.42"/>
<vertex x="38.6" y="-2.44"/>
<vertex x="38.61" y="-2.44"/>
<vertex x="38.62" y="-2.45"/>
<vertex x="38.65" y="-2.45"/>
<vertex x="38.65" y="-2.46"/>
<vertex x="38.68" y="-2.46"/>
<vertex x="38.69" y="-2.47"/>
<vertex x="38.7" y="-2.47"/>
<vertex x="38.7" y="-2.48"/>
<vertex x="38.71" y="-2.48"/>
<vertex x="38.73" y="-2.5"/>
<vertex x="38.74" y="-2.5"/>
<vertex x="38.74" y="-2.51"/>
<vertex x="38.76" y="-2.51"/>
<vertex x="38.76" y="-2.52"/>
<vertex x="38.78" y="-2.52"/>
<vertex x="38.78" y="-2.53"/>
<vertex x="38.8" y="-2.53"/>
<vertex x="38.8" y="-2.54"/>
<vertex x="38.88" y="-2.54"/>
<vertex x="38.88" y="-2.55"/>
<vertex x="38.9" y="-2.55"/>
<vertex x="38.9" y="-2.64"/>
<vertex x="38.89" y="-2.65"/>
<vertex x="38.89" y="-2.7"/>
<vertex x="38.88" y="-2.71"/>
<vertex x="38.88" y="-3.1"/>
<vertex x="38.89" y="-3.11"/>
<vertex x="38.89" y="-3.13"/>
<vertex x="38.9" y="-3.14"/>
<vertex x="38.9" y="-3.16"/>
<vertex x="38.91" y="-3.17"/>
<vertex x="38.91" y="-3.19"/>
<vertex x="38.92" y="-3.21"/>
<vertex x="38.92" y="-3.23"/>
<vertex x="38.93" y="-3.24"/>
<vertex x="38.93" y="-3.25"/>
<vertex x="38.94" y="-3.27"/>
<vertex x="38.94" y="-3.28"/>
<vertex x="38.96" y="-3.33"/>
<vertex x="38.96" y="-3.35"/>
<vertex x="38.97" y="-3.39"/>
<vertex x="38.98" y="-3.4"/>
<vertex x="38.98" y="-3.43"/>
<vertex x="38.99" y="-3.44"/>
<vertex x="38.99" y="-3.48"/>
<vertex x="39" y="-3.49"/>
<vertex x="39" y="-3.53"/>
<vertex x="39.01" y="-3.54"/>
<vertex x="39.02" y="-3.58"/>
<vertex x="39.03" y="-3.61"/>
<vertex x="39.03" y="-3.65"/>
<vertex x="39.04" y="-3.69"/>
<vertex x="39.05" y="-3.72"/>
<vertex x="39.06" y="-3.76"/>
<vertex x="39.07" y="-3.79"/>
<vertex x="39.08" y="-3.83"/>
<vertex x="39.09" y="-3.86"/>
<vertex x="39.1" y="-3.9"/>
<vertex x="39.11" y="-3.93"/>
<vertex x="39.12" y="-3.97"/>
<vertex x="39.14" y="-4.03"/>
<vertex x="39.15" y="-4.07"/>
<vertex x="39.16" y="-4.1"/>
<vertex x="39.19" y="-4.09"/>
<vertex x="39.27" y="-4.07"/>
<vertex x="39.33" y="-4.05"/>
<vertex x="39.37" y="-4.03"/>
<vertex x="39.4" y="-4.02"/>
<vertex x="39.44" y="-4.01"/>
<vertex x="39.56" y="-3.97"/>
<vertex x="39.6" y="-3.96"/>
<vertex x="39.63" y="-3.94"/>
<vertex x="39.66" y="-3.93"/>
<vertex x="39.7" y="-3.91"/>
<vertex x="39.71" y="-3.91"/>
<vertex x="39.73" y="-3.9"/>
<vertex x="39.74" y="-3.9"/>
<vertex x="39.75" y="-3.89"/>
<vertex x="39.77" y="-3.88"/>
<vertex x="39.78" y="-3.88"/>
<vertex x="39.8" y="-3.86"/>
<vertex x="39.82" y="-3.86"/>
<vertex x="39.83" y="-3.85"/>
<vertex x="39.84" y="-3.85"/>
<vertex x="39.86" y="-3.83"/>
<vertex x="39.88" y="-3.83"/>
<vertex x="39.9" y="-3.81"/>
<vertex x="39.91" y="-3.81"/>
<vertex x="39.91" y="-3.8"/>
<vertex x="39.92" y="-3.79"/>
<vertex x="39.93" y="-3.79"/>
<vertex x="39.94" y="-3.78"/>
<vertex x="39.95" y="-3.78"/>
<vertex x="39.98" y="-3.75"/>
<vertex x="39.99" y="-3.75"/>
<vertex x="40.01" y="-3.73"/>
<vertex x="40.01" y="-3.72"/>
<vertex x="40.02" y="-3.72"/>
<vertex x="40.06" y="-3.71"/>
<vertex x="40.09" y="-3.7"/>
<vertex x="40.13" y="-3.7"/>
<vertex x="40.16" y="-3.69"/>
<vertex x="40.19" y="-3.69"/>
<vertex x="40.22" y="-3.7"/>
<vertex x="40.28" y="-3.7"/>
<vertex x="40.31" y="-3.71"/>
<vertex x="40.34" y="-3.71"/>
<vertex x="40.43" y="-3.74"/>
<vertex x="40.46" y="-3.74"/>
<vertex x="40.49" y="-3.75"/>
<vertex x="40.51" y="-3.76"/>
<vertex x="40.56" y="-3.71"/>
<vertex x="40.58" y="-3.7"/>
<vertex x="40.6" y="-3.68"/>
<vertex x="40.62" y="-3.67"/>
<vertex x="40.63" y="-3.67"/>
<vertex x="40.64" y="-3.66"/>
<vertex x="40.66" y="-3.65"/>
<vertex x="40.67" y="-3.64"/>
<vertex x="40.69" y="-3.64"/>
<vertex x="40.7" y="-3.63"/>
<vertex x="40.72" y="-3.62"/>
<vertex x="40.73" y="-3.63"/>
<vertex x="40.75" y="-3.64"/>
<vertex x="40.77" y="-3.64"/>
<vertex x="40.79" y="-3.65"/>
<vertex x="40.81" y="-3.65"/>
<vertex x="40.83" y="-3.66"/>
<vertex x="40.84" y="-3.67"/>
<vertex x="40.86" y="-3.67"/>
<vertex x="40.88" y="-3.68"/>
<vertex x="40.9" y="-3.68"/>
<vertex x="40.92" y="-3.69"/>
<vertex x="40.94" y="-3.69"/>
<vertex x="40.96" y="-3.7"/>
<vertex x="40.99" y="-3.7"/>
<vertex x="41.01" y="-3.71"/>
<vertex x="41.04" y="-3.71"/>
<vertex x="41.05" y="-3.72"/>
<vertex x="41.11" y="-3.72"/>
<vertex x="41.12" y="-3.73"/>
<vertex x="41.17" y="-3.73"/>
<vertex x="41.17" y="-3.74"/>
<vertex x="41.21" y="-3.74"/>
<vertex x="41.22" y="-3.75"/>
<vertex x="41.24" y="-3.75"/>
<vertex x="41.25" y="-3.76"/>
<vertex x="41.36" y="-3.76"/>
<vertex x="41.4" y="-3.75"/>
<vertex x="41.43" y="-3.75"/>
<vertex x="41.51" y="-3.73"/>
<vertex x="41.54" y="-3.73"/>
<vertex x="41.62" y="-3.71"/>
<vertex x="41.65" y="-3.71"/>
<vertex x="41.69" y="-3.7"/>
<vertex x="41.72" y="-3.7"/>
<vertex x="41.76" y="-3.69"/>
<vertex x="41.8" y="-3.69"/>
<vertex x="41.83" y="-3.68"/>
<vertex x="41.87" y="-3.68"/>
<vertex x="41.91" y="-3.67"/>
<vertex x="41.94" y="-3.67"/>
<vertex x="41.95" y="-3.65"/>
<vertex x="41.95" y="-3.6"/>
<vertex x="41.96" y="-3.58"/>
<vertex x="41.96" y="-3.52"/>
<vertex x="41.97" y="-3.49"/>
<vertex x="41.97" y="-3.45"/>
<vertex x="41.98" y="-3.43"/>
<vertex x="41.98" y="-3.38"/>
<vertex x="41.99" y="-3.36"/>
<vertex x="41.99" y="-3.33"/>
<vertex x="42" y="-3.31"/>
<vertex x="42" y="-3.13"/>
<vertex x="42.01" y="-3.1"/>
<vertex x="42.01" y="-2.94"/>
<vertex x="42.02" y="-2.91"/>
</polygon>
<polygon width="0.023" layer="21">
<vertex x="41.82" y="-2.02"/>
<vertex x="41.26" y="-2.02"/>
<vertex x="41.25" y="-2.14"/>
<vertex x="41.27" y="-2.2"/>
<vertex x="41.28" y="-2.22"/>
<vertex x="41.28" y="-2.25"/>
<vertex x="41.29" y="-2.28"/>
<vertex x="41.3" y="-2.3"/>
<vertex x="41.31" y="-2.33"/>
<vertex x="41.32" y="-2.35"/>
<vertex x="41.32" y="-2.38"/>
<vertex x="41.33" y="-2.41"/>
<vertex x="41.34" y="-2.43"/>
<vertex x="41.36" y="-2.49"/>
<vertex x="41.36" y="-2.51"/>
<vertex x="41.38" y="-2.57"/>
<vertex x="41.38" y="-2.59"/>
<vertex x="41.39" y="-2.61"/>
<vertex x="41.39" y="-2.63"/>
<vertex x="41.4" y="-2.65"/>
<vertex x="41.4" y="-2.68"/>
<vertex x="41.41" y="-2.69"/>
<vertex x="41.41" y="-2.72"/>
<vertex x="41.42" y="-2.73"/>
<vertex x="41.42" y="-2.77"/>
<vertex x="42.02" y="-2.73"/>
<vertex x="42.03" y="-2.72"/>
<vertex x="42.03" y="-2.63"/>
<vertex x="42.02" y="-2.62"/>
<vertex x="42.02" y="-2.6"/>
<vertex x="42.01" y="-2.58"/>
<vertex x="42" y="-2.57"/>
<vertex x="42" y="-2.55"/>
<vertex x="41.99" y="-2.53"/>
<vertex x="41.98" y="-2.52"/>
<vertex x="41.98" y="-2.5"/>
<vertex x="41.96" y="-2.46"/>
<vertex x="41.96" y="-2.44"/>
<vertex x="41.95" y="-2.42"/>
<vertex x="41.95" y="-2.4"/>
<vertex x="41.94" y="-2.38"/>
<vertex x="41.94" y="-2.34"/>
<vertex x="41.93" y="-2.33"/>
<vertex x="41.93" y="-2.3"/>
<vertex x="41.92" y="-2.29"/>
<vertex x="41.92" y="-2.26"/>
<vertex x="41.91" y="-2.25"/>
<vertex x="41.91" y="-2.23"/>
<vertex x="41.9" y="-2.22"/>
<vertex x="41.9" y="-2.2"/>
<vertex x="41.89" y="-2.18"/>
<vertex x="41.89" y="-2.17"/>
<vertex x="41.88" y="-2.16"/>
<vertex x="41.88" y="-2.15"/>
<vertex x="41.87" y="-2.13"/>
<vertex x="41.87" y="-2.12"/>
<vertex x="41.86" y="-2.11"/>
<vertex x="41.86" y="-2.1"/>
<vertex x="41.85" y="-2.09"/>
<vertex x="41.85" y="-2.08"/>
<vertex x="41.84" y="-2.06"/>
<vertex x="41.83" y="-2.05"/>
<vertex x="41.83" y="-2.04"/>
<vertex x="41.82" y="-2.03"/>
</polygon>
<vertex x="38.66" y="7.32"/>
<vertex x="38.08" y="7.15"/>
<vertex x="38.02" y="6.76"/>
<vertex x="38.49" y="6.86"/>
<vertex x="38.68" y="6.67"/>
<vertex x="39.2" y="6.49"/>
<vertex x="39.51" y="6.55"/>
<vertex x="39.87" y="6.33"/>
<vertex x="40.28" y="6.52"/>
<vertex x="40.42" y="6.47"/>
<vertex x="40.81" y="6.29"/>
<vertex x="41.32" y="6.29"/>
<vertex x="41.33" y="6.3"/>
<vertex x="41.36" y="6.3"/>
<vertex x="41.38" y="6.31"/>
<vertex x="41.42" y="6.31"/>
<vertex x="41.44" y="6.32"/>
<vertex x="41.45" y="6.31"/>
<vertex x="41.48" y="6.31"/>
<vertex x="41.49" y="6.32"/>
<vertex x="41.5" y="6.32"/>
<vertex x="41.51" y="6.33"/>
<vertex x="41.52" y="6.33"/>
<vertex x="41.52" y="6.34"/>
<vertex x="41.54" y="6.34"/>
<vertex x="41.54" y="6.35"/>
<vertex x="41.56" y="6.35"/>
<vertex x="41.56" y="6.34"/>
<vertex x="41.58" y="6.34"/>
<vertex x="41.59" y="6.33"/>
<vertex x="41.61" y="6.33"/>
<vertex x="41.61" y="6.32"/>
<vertex x="41.64" y="6.32"/>
<vertex x="41.65" y="6.31"/>
<vertex x="41.67" y="6.31"/>
<vertex x="41.68" y="6.3"/>
<vertex x="41.7" y="6.3"/>
<vertex x="41.7" y="6.29"/>
<vertex x="41.73" y="6.29"/>
<vertex x="41.74" y="6.28"/>
<vertex x="41.76" y="6.28"/>
<vertex x="41.77" y="6.27"/>
<vertex x="41.8" y="6.27"/>
<vertex x="41.82" y="6.26"/>
<vertex x="41.95" y="6.26"/>
<vertex x="41.97" y="6.27"/>
<vertex x="42.01" y="6.27"/>
<vertex x="42.01" y="6.26"/>
<vertex x="42.02" y="6.26"/>
<vertex x="42.02" y="6.21"/>
<vertex x="42.01" y="6.21"/>
<vertex x="42.01" y="6.19"/>
<vertex x="42" y="6.19"/>
<vertex x="42" y="6.17"/>
<vertex x="41.99" y="6.17"/>
<vertex x="41.99" y="6.15"/>
<vertex x="41.97" y="6.13"/>
<vertex x="41.97" y="6.11"/>
<vertex x="41.96" y="6.1"/>
<vertex x="41.96" y="6.09"/>
<vertex x="41.95" y="6.09"/>
<vertex x="41.95" y="6.08"/>
<vertex x="41.94" y="6.07"/>
<vertex x="41.94" y="6.06"/>
<vertex x="41.92" y="6.04"/>
<vertex x="41.92" y="6.03"/>
<vertex x="41.84" y="5.95"/>
<vertex x="41.84" y="5.94"/>
<vertex x="41.83" y="5.94"/>
<vertex x="41.83" y="5.93"/>
<vertex x="41.82" y="5.93"/>
<vertex x="41.81" y="5.92"/>
<vertex x="41.81" y="5.91"/>
<vertex x="41.82" y="5.91"/>
<vertex x="41.82" y="5.89"/>
<vertex x="41.84" y="5.89"/>
<vertex x="41.84" y="5.88"/>
<vertex x="41.85" y="5.87"/>
<vertex x="41.85" y="5.85"/>
<vertex x="41.86" y="5.84"/>
<vertex x="41.86" y="5.82"/>
<vertex x="41.87" y="5.81"/>
<vertex x="41.87" y="5.79"/>
<vertex x="41.88" y="5.78"/>
<vertex x="41.88" y="5.77"/>
<vertex x="41.89" y="5.76"/>
<vertex x="41.89" y="5.74"/>
<vertex x="41.9" y="5.73"/>
<vertex x="41.9" y="5.72"/>
<vertex x="41.91" y="5.7"/>
<vertex x="41.91" y="5.69"/>
<vertex x="41.92" y="5.68"/>
<vertex x="41.92" y="5.66"/>
<vertex x="41.93" y="5.65"/>
<vertex x="41.93" y="5.64"/>
<vertex x="41.94" y="5.63"/>
<vertex x="41.94" y="5.62"/>
<vertex x="41.95" y="5.61"/>
<vertex x="41.95" y="5.6"/>
<vertex x="41.96" y="5.59"/>
<vertex x="41.96" y="5.57"/>
<vertex x="41.97" y="5.56"/>
<vertex x="41.97" y="5.55"/>
<vertex x="41.99" y="5.51"/>
<vertex x="41.99" y="5.47"/>
<vertex x="42" y="5.44"/>
<vertex x="42" y="5.32"/>
<vertex x="41.99" y="5.29"/>
<vertex x="41.99" y="5.07"/>
<vertex x="42" y="5.06"/>
<vertex x="42" y="5.05"/>
<vertex x="41.99" y="5.04"/>
<vertex x="41.98" y="5.02"/>
<vertex x="41.97" y="5.01"/>
<vertex x="41.97" y="4.99"/>
<vertex x="41.96" y="4.97"/>
<vertex x="41.95" y="4.96"/>
<vertex x="41.93" y="4.92"/>
<vertex x="41.92" y="4.91"/>
<vertex x="41.92" y="4.89"/>
<vertex x="41.85" y="4.82"/>
<vertex x="41.85" y="4.79"/>
<vertex x="41.84" y="4.79"/>
<vertex x="41.84" y="4.75"/>
<vertex x="41.88" y="4.71"/>
<vertex x="41.88" y="4.7"/>
<vertex x="41.89" y="4.7"/>
<vertex x="41.89" y="4.69"/>
<vertex x="41.92" y="4.66"/>
<vertex x="41.93" y="4.64"/>
<vertex x="41.93" y="4.63"/>
<vertex x="41.94" y="4.62"/>
<vertex x="41.94" y="4.6"/>
<vertex x="41.95" y="4.59"/>
<vertex x="41.95" y="4.58"/>
<vertex x="41.96" y="4.56"/>
<vertex x="41.97" y="4.55"/>
<vertex x="41.97" y="4.54"/>
<vertex x="41.98" y="4.52"/>
<vertex x="42" y="4.5"/>
<vertex x="42" y="4.46"/>
<vertex x="41.99" y="4.43"/>
<vertex x="41.98" y="4.41"/>
<vertex x="41.98" y="4.38"/>
<vertex x="41.97" y="4.35"/>
<vertex x="41.97" y="4.29"/>
<vertex x="41.96" y="4.26"/>
<vertex x="41.96" y="4.04"/>
<vertex x="41.9" y="3.98"/>
<vertex x="41.87" y="3.94"/>
<vertex x="41.85" y="3.91"/>
<vertex x="41.82" y="3.87"/>
<vertex x="41.79" y="3.84"/>
<vertex x="41.77" y="3.8"/>
<vertex x="41.74" y="3.76"/>
<vertex x="41.72" y="3.73"/>
<vertex x="41.69" y="3.69"/>
<vertex x="41.67" y="3.65"/>
<vertex x="41.64" y="3.61"/>
<vertex x="41.6" y="3.53"/>
<vertex x="41.57" y="3.49"/>
<vertex x="41.55" y="3.45"/>
<vertex x="41.57" y="3.4"/>
<vertex x="41.63" y="3.28"/>
<vertex x="41.65" y="3.23"/>
<vertex x="41.67" y="3.19"/>
<vertex x="41.68" y="3.15"/>
<vertex x="41.72" y="3.07"/>
<vertex x="41.74" y="3.02"/>
<vertex x="41.78" y="2.94"/>
<vertex x="41.8" y="2.89"/>
<vertex x="41.82" y="2.85"/>
<vertex x="41.86" y="2.75"/>
<vertex x="41.87" y="2.73"/>
<vertex x="41.87" y="2.71"/>
<vertex x="41.88" y="2.68"/>
<vertex x="41.88" y="2.61"/>
<vertex x="41.89" y="2.59"/>
<vertex x="41.89" y="2.45"/>
<vertex x="41.9" y="2.42"/>
<vertex x="41.9" y="2.4"/>
<vertex x="41.91" y="2.38"/>
<vertex x="41.91" y="2.21"/>
<vertex x="41.92" y="2.19"/>
<vertex x="41.92" y="2.12"/>
<vertex x="41.93" y="2.1"/>
<vertex x="41.93" y="2.07"/>
<vertex x="41.92" y="2.05"/>
<vertex x="41.92" y="2.04"/>
<vertex x="41.91" y="2.02"/>
<vertex x="41.89" y="2"/>
<vertex x="41.89" y="1.99"/>
<vertex x="41.88" y="1.97"/>
<vertex x="41.83" y="1.92"/>
<vertex x="41.83" y="1.91"/>
<vertex x="41.81" y="1.87"/>
<vertex x="41.81" y="1.85"/>
<vertex x="41.8" y="1.84"/>
<vertex x="41.79" y="1.84"/>
<vertex x="41.73" y="1.78"/>
<vertex x="41.72" y="1.78"/>
<vertex x="41.71" y="1.77"/>
<vertex x="41.71" y="1.76"/>
<vertex x="41.7" y="1.75"/>
<vertex x="41.69" y="1.73"/>
<vertex x="41.67" y="1.71"/>
<vertex x="41.67" y="1.69"/>
<vertex x="41.66" y="1.69"/>
<vertex x="41.66" y="1.68"/>
<vertex x="41.65" y="1.67"/>
<vertex x="41.65" y="1.65"/>
<vertex x="41.64" y="1.64"/>
<vertex x="41.64" y="1.62"/>
<vertex x="41.63" y="1.61"/>
<vertex x="41.63" y="1.59"/>
<vertex x="41.62" y="1.58"/>
<vertex x="41.6" y="1.54"/>
<vertex x="41.58" y="1.52"/>
<vertex x="41.49" y="1.34"/>
<vertex x="41.48" y="1.31"/>
<vertex x="41.45" y="1.25"/>
<vertex x="41.46" y="1.22"/>
<vertex x="41.48" y="1.19"/>
<vertex x="41.49" y="1.16"/>
<vertex x="41.51" y="1.12"/>
<vertex x="41.53" y="1.09"/>
<vertex x="41.54" y="1.06"/>
<vertex x="41.64" y="0.91"/>
<vertex x="41.66" y="0.89"/>
<vertex x="41.7" y="0.83"/>
<vertex x="41.74" y="0.79"/>
<vertex x="41.74" y="0.75"/>
<vertex x="41.75" y="0.74"/>
<vertex x="41.75" y="0.7"/>
<vertex x="41.7" y="0.65"/>
<vertex x="41.69" y="0.63"/>
<vertex x="41.67" y="0.62"/>
<vertex x="41.65" y="0.6"/>
<vertex x="41.64" y="0.58"/>
<vertex x="41.62" y="0.56"/>
<vertex x="41.6" y="0.55"/>
<vertex x="41.58" y="0.53"/>
<vertex x="41.56" y="0.52"/>
<vertex x="41.57" y="0.49"/>
<vertex x="41.57" y="0.47"/>
<vertex x="41.58" y="0.45"/>
<vertex x="41.58" y="0.39"/>
<vertex x="41.59" y="0.37"/>
<vertex x="41.59" y="0.22"/>
<vertex x="41.6" y="0.2"/>
<vertex x="41.6" y="0.17"/>
<vertex x="41.59" y="0.16"/>
<vertex x="41.59" y="0.13"/>
<vertex x="41.58" y="0.12"/>
<vertex x="41.58" y="0.08"/>
<vertex x="41.57" y="0.07"/>
<vertex x="41.57" y="0.06"/>
<vertex x="41.55" y="-0.08"/>
<vertex x="41.55" y="-0.1"/>
<vertex x="41.54" y="-0.11"/>
<vertex x="41.54" y="-0.18"/>
<vertex x="41.53" y="-0.19"/>
<vertex x="41.53" y="-0.24"/>
<vertex x="41.52" y="-0.25"/>
<vertex x="41.52" y="-0.3"/>
<vertex x="41.51" y="-0.31"/>
<vertex x="41.51" y="-0.37"/>
<vertex x="41.5" y="-0.38"/>
<vertex x="41.5" y="-0.42"/>
<vertex x="41.49" y="-0.44"/>
<vertex x="41.49" y="-0.48"/>
<vertex x="41.48" y="-0.49"/>
<vertex x="41.48" y="-0.52"/>
<vertex x="41.47" y="-0.54"/>
<vertex x="41.47" y="-0.55"/>
<vertex x="41.51" y="-0.59"/>
<vertex x="41.51" y="-0.6"/>
<vertex x="41.53" y="-0.62"/>
<vertex x="41.54" y="-0.64"/>
<vertex x="41.55" y="-0.65"/>
<vertex x="41.55" y="-0.66"/>
<vertex x="41.57" y="-0.68"/>
<vertex x="41.58" y="-0.7"/>
<vertex x="41.59" y="-0.71"/>
<vertex x="41.6" y="-0.71"/>
<vertex x="41.61" y="-0.72"/>
<vertex x="41.59" y="-0.74"/>
<vertex x="41.59" y="-0.75"/>
<vertex x="41.58" y="-0.77"/>
<vertex x="41.57" y="-0.78"/>
<vertex x="41.57" y="-0.79"/>
<vertex x="41.56" y="-0.8"/>
<vertex x="41.56" y="-0.82"/>
<vertex x="41.54" y="-0.84"/>
<vertex x="41.54" y="-0.86"/>
<vertex x="41.52" y="-0.88"/>
<vertex x="41.52" y="-0.89"/>
<vertex x="41.5" y="-0.91"/>
<vertex x="41.5" y="-0.96"/>
<vertex x="41.49" y="-1.01"/>
<vertex x="41.48" y="-1.05"/>
<vertex x="41.48" y="-1.1"/>
<vertex x="41.47" y="-1.14"/>
<vertex x="41.46" y="-1.19"/>
<vertex x="41.45" y="-1.23"/>
<vertex x="41.43" y="-1.27"/>
<vertex x="41.42" y="-1.32"/>
<vertex x="41.4" y="-1.4"/>
<vertex x="41.38" y="-1.44"/>
<vertex x="41.37" y="-1.48"/>
<vertex x="41.36" y="-1.53"/>
<vertex x="41.34" y="-1.57"/>
<vertex x="41.33" y="-1.61"/>
<vertex x="41.32" y="-1.63"/>
<vertex x="41.32" y="-1.66"/>
<vertex x="41.31" y="-1.69"/>
<vertex x="41.31" y="-1.76"/>
<vertex x="41.3" y="-1.79"/>
<vertex x="41.3" y="-1.84"/>
<vertex x="41.29" y="-1.86"/>
<vertex x="41.29" y="-1.89"/>
<vertex x="41.28" y="-1.91"/>
<vertex x="41.28" y="-1.94"/>
<vertex x="41.27" y="-1.96"/>
<vertex x="41.27" y="-1.99"/>
<vertex x="41.81" y="-2"/>
<vertex x="41.81" y="-1.98"/>
<vertex x="41.8" y="-1.97"/>
<vertex x="41.79" y="-1.95"/>
<vertex x="41.79" y="-1.93"/>
<vertex x="41.78" y="-1.92"/>
<vertex x="41.78" y="-1.9"/>
<vertex x="41.77" y="-1.89"/>
<vertex x="41.76" y="-1.87"/>
<vertex x="41.76" y="-1.85"/>
<vertex x="41.75" y="-1.84"/>
<vertex x="41.74" y="-1.82"/>
<vertex x="41.73" y="-1.81"/>
<vertex x="41.73" y="-1.8"/>
<vertex x="41.72" y="-1.78"/>
<vertex x="41.71" y="-1.77"/>
<vertex x="41.72" y="-1.73"/>
<vertex x="41.72" y="-1.7"/>
<vertex x="41.74" y="-1.62"/>
<vertex x="41.75" y="-1.59"/>
<vertex x="41.76" y="-1.55"/>
<vertex x="41.77" y="-1.52"/>
<vertex x="41.78" y="-1.48"/>
<vertex x="41.79" y="-1.45"/>
<vertex x="41.8" y="-1.41"/>
<vertex x="41.82" y="-1.35"/>
<vertex x="41.84" y="-1.31"/>
<vertex x="41.86" y="-1.25"/>
<vertex x="41.88" y="-1.22"/>
<vertex x="41.88" y="-1.17"/>
<vertex x="41.89" y="-1.16"/>
<vertex x="41.89" y="-1.03"/>
<vertex x="41.9" y="-1.01"/>
<vertex x="41.9" y="-0.98"/>
<vertex x="41.91" y="-0.97"/>
<vertex x="41.93" y="-0.93"/>
<vertex x="41.94" y="-0.92"/>
<vertex x="41.96" y="-0.88"/>
<vertex x="41.97" y="-0.87"/>
<vertex x="42.01" y="-0.79"/>
<vertex x="42.01" y="-0.78"/>
<vertex x="42.03" y="-0.74"/>
<vertex x="42.04" y="-0.73"/>
<vertex x="42.06" y="-0.69"/>
<vertex x="42.05" y="-0.68"/>
<vertex x="42.01" y="-0.6"/>
<vertex x="41.99" y="-0.58"/>
<vertex x="41.98" y="-0.56"/>
<vertex x="41.97" y="-0.53"/>
<vertex x="41.94" y="-0.47"/>
<vertex x="41.92" y="-0.45"/>
<vertex x="41.9" y="-0.41"/>
<vertex x="41.88" y="-0.39"/>
<vertex x="41.87" y="-0.37"/>
<vertex x="41.88" y="-0.35"/>
<vertex x="41.88" y="-0.33"/>
<vertex x="41.89" y="-0.31"/>
<vertex x="41.89" y="-0.27"/>
<vertex x="41.9" y="-0.25"/>
<vertex x="41.9" y="-0.18"/>
<vertex x="41.91" y="-0.16"/>
<vertex x="41.91" y="-0.12"/>
<vertex x="41.92" y="-0.1"/>
<vertex x="41.92" y="-0.08"/>
<vertex x="41.93" y="-0.05"/>
<vertex x="41.94" y="-0.03"/>
<vertex x="41.94" y="0.07"/>
<vertex x="41.95" y="0.08"/>
<vertex x="41.95" y="0.18"/>
<vertex x="41.96" y="0.19"/>
<vertex x="41.96" y="0.3"/>
<vertex x="41.95" y="0.32"/>
<vertex x="41.95" y="0.34"/>
<vertex x="41.94" y="0.36"/>
<vertex x="41.96" y="0.37"/>
<vertex x="41.97" y="0.38"/>
<vertex x="41.98" y="0.4"/>
<vertex x="41.98" y="0.41"/>
<vertex x="41.99" y="0.43"/>
<vertex x="42.01" y="0.45"/>
<vertex x="42.02" y="0.47"/>
<vertex x="42.05" y="0.5"/>
<vertex x="42.06" y="0.52"/>
<vertex x="42.07" y="0.53"/>
<vertex x="42.08" y="0.55"/>
<vertex x="42.09" y="0.56"/>
<vertex x="42.1" y="0.58"/>
<vertex x="42.09" y="0.61"/>
<vertex x="42.08" y="0.65"/>
<vertex x="42.08" y="0.7"/>
<vertex x="42.07" y="0.74"/>
<vertex x="42.07" y="0.96"/>
<vertex x="42.05" y="1.04"/>
<vertex x="42.05" y="1.08"/>
<vertex x="42.03" y="1.12"/>
<vertex x="42.02" y="1.15"/>
<vertex x="42" y="1.18"/>
<vertex x="41.97" y="1.2"/>
<vertex x="42.04" y="1.41"/>
<vertex x="42.05" y="1.43"/>
<vertex x="42.07" y="1.49"/>
<vertex x="42.08" y="1.51"/>
<vertex x="42.1" y="1.54"/>
<vertex x="42.11" y="1.57"/>
<vertex x="42.12" y="1.59"/>
<vertex x="42.13" y="1.62"/>
<vertex x="42.15" y="1.64"/>
<vertex x="42.15" y="1.66"/>
<vertex x="42.17" y="1.7"/>
<vertex x="42.17" y="1.73"/>
<vertex x="42.23" y="1.85"/>
<vertex x="42.23" y="1.88"/>
<vertex x="42.25" y="1.92"/>
<vertex x="42.25" y="1.95"/>
<vertex x="42.26" y="1.97"/>
<vertex x="42.26" y="2.01"/>
<vertex x="42.27" y="2.01"/>
<vertex x="42.27" y="2.03"/>
<vertex x="42.28" y="2.04"/>
<vertex x="42.28" y="2.05"/>
<vertex x="42.29" y="2.06"/>
<vertex x="42.29" y="2.07"/>
<vertex x="42.3" y="2.08"/>
<vertex x="42.3" y="2.24"/>
<vertex x="42.31" y="2.32"/>
<vertex x="42.31" y="2.41"/>
<vertex x="42.32" y="2.49"/>
<vertex x="42.32" y="2.66"/>
<vertex x="42.33" y="2.74"/>
<vertex x="42.33" y="2.9"/>
<vertex x="42.32" y="2.99"/>
<vertex x="42.32" y="3.07"/>
<vertex x="42.31" y="3.15"/>
<vertex x="42.29" y="3.23"/>
<vertex x="42.28" y="3.3"/>
<vertex x="42.26" y="3.38"/>
<vertex x="42.28" y="3.38"/>
<vertex x="42.28" y="3.43"/>
<vertex x="42.29" y="3.43"/>
<vertex x="42.29" y="3.44"/>
<vertex x="42.3" y="3.44"/>
<vertex x="42.3" y="3.45"/>
<vertex x="42.33" y="3.45"/>
<vertex x="42.33" y="3.52"/>
<vertex x="42.34" y="3.53"/>
<vertex x="42.34" y="3.55"/>
<vertex x="42.35" y="3.56"/>
<vertex x="42.35" y="3.57"/>
<vertex x="42.37" y="3.59"/>
<vertex x="42.37" y="3.6"/>
<vertex x="42.38" y="3.6"/>
<vertex x="42.39" y="3.61"/>
<vertex x="42.39" y="3.75"/>
<vertex x="42.38" y="3.76"/>
<vertex x="42.38" y="3.85"/>
<vertex x="42.39" y="3.86"/>
<vertex x="42.39" y="3.89"/>
<vertex x="42.38" y="3.92"/>
<vertex x="42.38" y="4.12"/>
<vertex x="42.39" y="4.15"/>
<vertex x="42.39" y="4.23"/>
<vertex x="42.4" y="4.26"/>
<vertex x="42.4" y="4.35"/>
<vertex x="42.39" y="4.36"/>
<vertex x="42.38" y="4.36"/>
<vertex x="42.38" y="4.37"/>
<vertex x="42.37" y="4.38"/>
<vertex x="42.37" y="4.4"/>
<vertex x="42.36" y="4.42"/>
<vertex x="42.36" y="4.43"/>
<vertex x="42.35" y="4.44"/>
<vertex x="42.35" y="4.46"/>
<vertex x="42.34" y="4.47"/>
<vertex x="42.34" y="4.48"/>
<vertex x="42.33" y="4.49"/>
<vertex x="42.33" y="4.5"/>
<vertex x="42.32" y="4.51"/>
<vertex x="42.32" y="4.52"/>
<vertex x="42.28" y="4.56"/>
<vertex x="42.29" y="4.61"/>
<vertex x="42.31" y="4.63"/>
<vertex x="42.32" y="4.63"/>
<vertex x="42.32" y="4.64"/>
<vertex x="42.33" y="4.65"/>
<vertex x="42.33" y="4.67"/>
<vertex x="42.34" y="4.68"/>
<vertex x="42.34" y="4.72"/>
<vertex x="42.35" y="4.73"/>
<vertex x="42.35" y="4.75"/>
<vertex x="42.34" y="4.8"/>
<vertex x="42.34" y="4.84"/>
<vertex x="42.32" y="4.94"/>
<vertex x="42.32" y="4.98"/>
<vertex x="42.31" y="5.03"/>
<vertex x="42.3" y="5.07"/>
<vertex x="42.3" y="5.16"/>
<vertex x="42.29" y="5.21"/>
<vertex x="42.29" y="5.39"/>
<vertex x="42.3" y="5.44"/>
<vertex x="42.3" y="5.49"/>
<vertex x="42.29" y="5.5"/>
<vertex x="42.28" y="5.52"/>
<vertex x="42.28" y="5.53"/>
<vertex x="42.26" y="5.57"/>
<vertex x="42.26" y="5.58"/>
<vertex x="42.25" y="5.6"/>
<vertex x="42.25" y="5.61"/>
<vertex x="42.24" y="5.63"/>
<vertex x="42.24" y="5.65"/>
<vertex x="42.23" y="5.66"/>
<vertex x="42.23" y="5.68"/>
<vertex x="42.22" y="5.69"/>
<vertex x="42.22" y="5.71"/>
<vertex x="42.21" y="5.72"/>
<vertex x="42.21" y="5.75"/>
<vertex x="42.22" y="5.75"/>
<vertex x="42.22" y="5.76"/>
<vertex x="42.23" y="5.76"/>
<vertex x="42.23" y="5.77"/>
<vertex x="42.24" y="5.78"/>
<vertex x="42.24" y="5.79"/>
<vertex x="42.25" y="5.79"/>
<vertex x="42.25" y="5.8"/>
<vertex x="42.26" y="5.8"/>
<vertex x="42.26" y="5.82"/>
<vertex x="42.27" y="5.82"/>
<vertex x="42.27" y="5.84"/>
<vertex x="42.28" y="5.84"/>
<vertex x="42.28" y="5.86"/>
<vertex x="42.29" y="5.87"/>
<vertex x="42.29" y="5.88"/>
<vertex x="42.3" y="5.89"/>
<vertex x="42.3" y="5.9"/>
<vertex x="42.31" y="5.92"/>
<vertex x="42.31" y="5.93"/>
<vertex x="42.32" y="5.94"/>
<vertex x="42.32" y="5.96"/>
<vertex x="42.33" y="5.97"/>
<vertex x="42.33" y="5.98"/>
<vertex x="42.34" y="6"/>
<vertex x="42.34" y="6.01"/>
<vertex x="42.35" y="6.02"/>
<vertex x="42.36" y="6.04"/>
<vertex x="42.36" y="6.05"/>
<vertex x="42.39" y="6.08"/>
<vertex x="42.39" y="6.09"/>
<vertex x="42.4" y="6.1"/>
<vertex x="42.4" y="6.12"/>
<vertex x="42.39" y="6.13"/>
<vertex x="42.39" y="6.17"/>
<vertex x="42.38" y="6.18"/>
<vertex x="42.38" y="6.26"/>
<vertex x="42.37" y="6.27"/>
<vertex x="42.37" y="6.33"/>
<vertex x="42.36" y="6.34"/>
<vertex x="42.36" y="6.36"/>
<vertex x="42.35" y="6.37"/>
<vertex x="42.35" y="6.45"/>
<vertex x="42.34" y="6.47"/>
<vertex x="42.34" y="6.54"/>
<vertex x="42.33" y="6.55"/>
<vertex x="42.18" y="6.55"/>
<vertex x="42.16" y="6.54"/>
<vertex x="41.92" y="6.54"/>
<vertex x="41.9" y="6.55"/>
<vertex x="41.86" y="6.55"/>
<vertex x="41.84" y="6.56"/>
<vertex x="41.83" y="6.56"/>
<vertex x="41.81" y="6.57"/>
<vertex x="41.77" y="6.57"/>
<vertex x="41.75" y="6.58"/>
<vertex x="41.73" y="6.58"/>
<vertex x="41.71" y="6.59"/>
<vertex x="41.69" y="6.59"/>
<vertex x="41.68" y="6.6"/>
<vertex x="41.66" y="6.6"/>
<vertex x="41.65" y="6.61"/>
<vertex x="41.63" y="6.61"/>
<vertex x="41.6" y="6.62"/>
<vertex x="41.59" y="6.62"/>
<vertex x="41.58" y="6.63"/>
<vertex x="41.56" y="6.63"/>
<vertex x="41.56" y="6.64"/>
<vertex x="41.53" y="6.64"/>
<vertex x="41.52" y="6.65"/>
<vertex x="41.48" y="6.65"/>
<vertex x="41.47" y="6.66"/>
<vertex x="41.41" y="6.66"/>
<vertex x="41.38" y="6.65"/>
<vertex x="41.31" y="6.65"/>
<vertex x="41.29" y="6.64"/>
<vertex x="41.12" y="6.64"/>
<vertex x="41.09" y="6.63"/>
<vertex x="41.07" y="6.63"/>
<vertex x="41.05" y="6.62"/>
<vertex x="41.03" y="6.63"/>
<vertex x="40.83" y="6.63"/>
<vertex x="40.78" y="6.65"/>
<vertex x="40.74" y="6.67"/>
<vertex x="40.69" y="6.7"/>
<vertex x="40.49" y="6.78"/>
<vertex x="40.44" y="6.79"/>
<vertex x="40.19" y="6.89"/>
<vertex x="40.14" y="6.92"/>
<vertex x="40.09" y="6.94"/>
<vertex x="40.05" y="6.96"/>
<vertex x="40.05" y="6.94"/>
<vertex x="40.03" y="6.92"/>
<vertex x="40.02" y="6.92"/>
<vertex x="40.01" y="6.91"/>
<vertex x="40" y="6.91"/>
<vertex x="40" y="6.9"/>
<vertex x="39.99" y="6.9"/>
<vertex x="39.98" y="6.89"/>
<vertex x="39.98" y="6.88"/>
<vertex x="39.96" y="6.88"/>
<vertex x="39.95" y="6.87"/>
<vertex x="39.93" y="6.87"/>
<vertex x="39.92" y="6.86"/>
<vertex x="39.91" y="6.86"/>
<vertex x="39.9" y="6.85"/>
<vertex x="39.9" y="6.84"/>
<vertex x="39.89" y="6.84"/>
<vertex x="39.88" y="6.83"/>
<vertex x="39.87" y="6.83"/>
<vertex x="39.86" y="6.82"/>
<vertex x="39.83" y="6.82"/>
<vertex x="39.81" y="6.84"/>
<vertex x="39.79" y="6.85"/>
<vertex x="39.77" y="6.87"/>
<vertex x="39.75" y="6.88"/>
<vertex x="39.74" y="6.88"/>
<vertex x="39.7" y="6.9"/>
<vertex x="39.69" y="6.91"/>
<vertex x="39.65" y="6.93"/>
<vertex x="39.64" y="6.93"/>
<vertex x="39.62" y="6.94"/>
<vertex x="39.61" y="6.95"/>
<vertex x="39.59" y="6.96"/>
<vertex x="39.54" y="6.96"/>
<vertex x="39.53" y="6.95"/>
<vertex x="39.5" y="6.95"/>
<vertex x="39.49" y="6.94"/>
<vertex x="39.45" y="6.94"/>
<vertex x="39.44" y="6.93"/>
<vertex x="39.4" y="6.93"/>
<vertex x="39.38" y="6.92"/>
<vertex x="39.34" y="6.92"/>
<vertex x="39.32" y="6.91"/>
<vertex x="39.29" y="6.91"/>
<vertex x="39.27" y="6.9"/>
<vertex x="39.22" y="6.9"/>
<vertex x="39.21" y="6.89"/>
<vertex x="39.19" y="6.89"/>
<vertex x="39.06" y="6.94"/>
</polygon>
<vertex x="39.6" y="5.6"/>
<vertex x="39.38" y="2.43"/>
<vertex x="40.51" y="5.54"/>
<vertex x="41.07" y="5.5"/>
<vertex x="39.92" y="2.39"/>
<vertex x="40.59" y="-1.43"/>
<vertex x="40.02" y="-1.39"/>
<vertex x="39.36" y="2.26"/>
<vertex x="39.11" y="-1.32"/>
<vertex x="38.53" y="-1.28"/>
<vertex x="39.03" y="5.64"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_.1">
<polygon width="0" layer="1">
<vertex x="1.7" y="2.48"/>
<vertex x="1.7" y="2.46"/>
<vertex x="1.7" y="2.43"/>
<vertex x="1.7" y="2.4"/>
<vertex x="1.69" y="2.37"/>
<vertex x="1.68" y="2.35"/>
<vertex x="1.65" y="2.32"/>
<vertex x="1.62" y="2.31"/>
<vertex x="1.59" y="2.31"/>
<vertex x="1.55" y="2.32"/>
<vertex x="1.51" y="2.33"/>
<vertex x="1.47" y="2.35"/>
<vertex x="1.44" y="2.37"/>
<vertex x="1.4" y="2.4"/>
<vertex x="1.37" y="2.43"/>
<vertex x="1.34" y="2.46"/>
<vertex x="1.32" y="2.49"/>
<vertex x="1.3" y="2.52"/>
<vertex x="1.29" y="2.56"/>
<vertex x="1.29" y="2.59"/>
<vertex x="1.29" y="2.62"/>
<vertex x="1.3" y="2.65"/>
<vertex x="1.31" y="2.67"/>
<vertex x="1.33" y="2.7"/>
<vertex x="1.37" y="2.73"/>
<vertex x="1.41" y="2.75"/>
<vertex x="1.46" y="2.76"/>
<vertex x="1.5" y="2.77"/>
<vertex x="1.53" y="2.77"/>
<vertex x="1.56" y="2.77"/>
<vertex x="1.58" y="2.76"/>
<vertex x="1.59" y="2.76"/>
<vertex x="1.58" y="2.77"/>
<vertex x="1.54" y="2.8"/>
<vertex x="1.48" y="2.83"/>
<vertex x="1.4" y="2.87"/>
<vertex x="1.31" y="2.89"/>
<vertex x="1.21" y="2.89"/>
<vertex x="1.1" y="2.87"/>
<vertex x="0.99" y="2.81"/>
<vertex x="0.9" y="2.74"/>
<vertex x="0.85" y="2.66"/>
<vertex x="0.82" y="2.57"/>
<vertex x="0.82" y="2.49"/>
<vertex x="0.84" y="2.4"/>
<vertex x="0.89" y="2.31"/>
<vertex x="0.96" y="2.23"/>
<vertex x="1.04" y="2.14"/>
<vertex x="1.11" y="2.07"/>
<vertex x="1.14" y="1.99"/>
<vertex x="1.14" y="1.92"/>
<vertex x="1.12" y="1.86"/>
<vertex x="1.08" y="1.81"/>
<vertex x="1.02" y="1.77"/>
<vertex x="0.94" y="1.75"/>
<vertex x="0.86" y="1.75"/>
<vertex x="0.81" y="1.76"/>
<vertex x="0.76" y="1.78"/>
<vertex x="0.73" y="1.81"/>
<vertex x="0.7" y="1.84"/>
<vertex x="0.68" y="1.87"/>
<vertex x="0.67" y="1.9"/>
<vertex x="0.67" y="1.94"/>
<vertex x="0.68" y="1.97"/>
<vertex x="0.7" y="1.99"/>
<vertex x="0.72" y="2.01"/>
<vertex x="0.74" y="2.03"/>
<vertex x="0.77" y="2.04"/>
<vertex x="0.79" y="2.05"/>
<vertex x="0.81" y="2.06"/>
<vertex x="0.82" y="2.07"/>
<vertex x="0.8" y="2.08"/>
<vertex x="0.78" y="2.09"/>
<vertex x="0.74" y="2.09"/>
<vertex x="0.7" y="2.09"/>
<vertex x="0.66" y="2.09"/>
<vertex x="0.6" y="2.08"/>
<vertex x="0.55" y="2.07"/>
<vertex x="0.5" y="2.05"/>
<vertex x="0.46" y="2.02"/>
<vertex x="0.41" y="1.98"/>
<vertex x="0.38" y="1.93"/>
<vertex x="0.35" y="1.88"/>
<vertex x="0.33" y="1.81"/>
<vertex x="0.32" y="1.73"/>
<vertex x="0.32" y="1.63"/>
<vertex x="0.32" y="1.47"/>
<vertex x="0.32" y="1.31"/>
<vertex x="0.32" y="1.15"/>
<vertex x="0.32" y="0.99"/>
<vertex x="0.32" y="0.83"/>
<vertex x="0.32" y="0.67"/>
<vertex x="0.32" y="0.51"/>
<vertex x="0.32" y="0.35"/>
<vertex x="0.32" y="0.36"/>
<vertex x="0.34" y="0.38"/>
<vertex x="0.37" y="0.41"/>
<vertex x="0.4" y="0.46"/>
<vertex x="0.45" y="0.51"/>
<vertex x="0.5" y="0.57"/>
<vertex x="0.56" y="0.63"/>
<vertex x="0.62" y="0.69"/>
<vertex x="0.68" y="0.76"/>
<vertex x="0.74" y="0.83"/>
<vertex x="0.79" y="0.88"/>
<vertex x="0.84" y="0.93"/>
<vertex x="0.89" y="0.96"/>
<vertex x="0.94" y="0.99"/>
<vertex x="1" y="1"/>
<vertex x="1.07" y="1"/>
<vertex x="1.19" y="1"/>
<vertex x="1.31" y="1.02"/>
<vertex x="1.42" y="1.05"/>
<vertex x="1.52" y="1.09"/>
<vertex x="1.62" y="1.15"/>
<vertex x="1.7" y="1.22"/>
<vertex x="1.78" y="1.3"/>
<vertex x="1.85" y="1.39"/>
<vertex x="1.95" y="1.57"/>
<vertex x="2" y="1.76"/>
<vertex x="2.01" y="1.93"/>
<vertex x="1.98" y="2.09"/>
<vertex x="1.93" y="2.24"/>
<vertex x="1.86" y="2.35"/>
<vertex x="1.78" y="2.44"/>
<vertex x="1.7" y="2.49"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_EXPOSED_.1">
</polygon>
<polygon width="0" layer="29">
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_.2">
<vertex x="3.12" y="4.54"/>
<vertex x="3.12" y="4.53"/>
<vertex x="3.12" y="4.49"/>
<vertex x="3.13" y="4.44"/>
<vertex x="3.12" y="4.38"/>
<vertex x="3.11" y="4.32"/>
<vertex x="3.08" y="4.27"/>
<vertex x="3.03" y="4.22"/>
<vertex x="2.96" y="4.19"/>
<vertex x="2.89" y="4.19"/>
<vertex x="2.82" y="4.21"/>
<vertex x="2.75" y="4.23"/>
<vertex x="2.67" y="4.27"/>
<vertex x="2.6" y="4.32"/>
<vertex x="2.53" y="4.37"/>
<vertex x="2.46" y="4.43"/>
<vertex x="2.41" y="4.48"/>
<vertex x="2.36" y="4.56"/>
<vertex x="2.32" y="4.62"/>
<vertex x="2.3" y="4.69"/>
<vertex x="2.29" y="4.75"/>
<vertex x="2.3" y="4.81"/>
<vertex x="2.32" y="4.86"/>
<vertex x="2.35" y="4.92"/>
<vertex x="2.39" y="4.97"/>
<vertex x="2.47" y="5.04"/>
<vertex x="2.55" y="5.08"/>
<vertex x="2.63" y="5.1"/>
<vertex x="2.72" y="5.11"/>
<vertex x="2.79" y="5.11"/>
<vertex x="2.85" y="5.11"/>
<vertex x="2.89" y="5.1"/>
<vertex x="2.9" y="5.1"/>
<vertex x="2.87" y="5.12"/>
<vertex x="2.8" y="5.17"/>
<vertex x="2.68" y="5.24"/>
<vertex x="2.53" y="5.3"/>
<vertex x="2.35" y="5.35"/>
<vertex x="2.15" y="5.36"/>
<vertex x="1.93" y="5.31"/>
<vertex x="1.7" y="5.19"/>
<vertex x="1.53" y="5.05"/>
<vertex x="1.42" y="4.89"/>
<vertex x="1.36" y="4.72"/>
<vertex x="1.36" y="4.55"/>
<vertex x="1.41" y="4.38"/>
<vertex x="1.5" y="4.2"/>
<vertex x="1.63" y="4.03"/>
<vertex x="1.8" y="3.86"/>
<vertex x="1.93" y="3.71"/>
<vertex x="2" y="3.56"/>
<vertex x="2" y="3.42"/>
<vertex x="1.96" y="3.29"/>
<vertex x="1.87" y="3.19"/>
<vertex x="1.75" y="3.11"/>
<vertex x="1.61" y="3.07"/>
<vertex x="1.45" y="3.07"/>
<vertex x="1.34" y="3.1"/>
<vertex x="1.25" y="3.13"/>
<vertex x="1.18" y="3.19"/>
<vertex x="1.12" y="3.25"/>
<vertex x="1.09" y="3.31"/>
<vertex x="1.07" y="3.38"/>
<vertex x="1.07" y="3.45"/>
<vertex x="1.09" y="3.51"/>
<vertex x="1.12" y="3.55"/>
<vertex x="1.16" y="3.59"/>
<vertex x="1.21" y="3.63"/>
<vertex x="1.25" y="3.66"/>
<vertex x="1.3" y="3.68"/>
<vertex x="1.34" y="3.7"/>
<vertex x="1.36" y="3.71"/>
<vertex x="1.37" y="3.72"/>
<vertex x="1.36" y="3.72"/>
<vertex x="1.33" y="3.73"/>
<vertex x="1.28" y="3.75"/>
<vertex x="1.21" y="3.76"/>
<vertex x="1.13" y="3.76"/>
<vertex x="1.03" y="3.76"/>
<vertex x="0.93" y="3.74"/>
<vertex x="0.82" y="3.71"/>
<vertex x="0.72" y="3.67"/>
<vertex x="0.63" y="3.61"/>
<vertex x="0.55" y="3.53"/>
<vertex x="0.48" y="3.44"/>
<vertex x="0.42" y="3.33"/>
<vertex x="0.38" y="3.19"/>
<vertex x="0.36" y="3.03"/>
<vertex x="0.35" y="2.84"/>
<vertex x="0.35" y="2.51"/>
<vertex x="0.35" y="2.19"/>
<vertex x="0.35" y="1.87"/>
<vertex x="0.35" y="1.55"/>
<vertex x="0.35" y="1.23"/>
<vertex x="0.35" y="0.91"/>
<vertex x="0.35" y="0.59"/>
<vertex x="0.35" y="0.27"/>
<vertex x="0.36" y="0.29"/>
<vertex x="0.4" y="0.33"/>
<vertex x="0.46" y="0.4"/>
<vertex x="0.53" y="0.49"/>
<vertex x="0.62" y="0.59"/>
<vertex x="0.72" y="0.71"/>
<vertex x="0.83" y="0.83"/>
<vertex x="0.95" y="0.96"/>
<vertex x="1.08" y="1.1"/>
<vertex x="1.19" y="1.23"/>
<vertex x="1.3" y="1.34"/>
<vertex x="1.4" y="1.43"/>
<vertex x="1.5" y="1.5"/>
<vertex x="1.61" y="1.55"/>
<vertex x="1.72" y="1.58"/>
<vertex x="1.86" y="1.58"/>
<vertex x="2.11" y="1.58"/>
<vertex x="2.35" y="1.61"/>
<vertex x="2.57" y="1.67"/>
<vertex x="2.77" y="1.76"/>
<vertex x="2.96" y="1.88"/>
<vertex x="3.13" y="2.01"/>
<vertex x="3.28" y="2.17"/>
<vertex x="3.42" y="2.35"/>
<vertex x="3.61" y="2.72"/>
<vertex x="3.71" y="3.08"/>
<vertex x="3.73" y="3.43"/>
<vertex x="3.68" y="3.76"/>
<vertex x="3.58" y="4.04"/>
<vertex x="3.45" y="4.28"/>
<vertex x="3.28" y="4.45"/>
<vertex x="3.12" y="4.55"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_EXPOSED_.2">
</polygon>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_.3">
<vertex x="4.65" y="6.54"/>
<vertex x="4.65" y="6.52"/>
<vertex x="4.66" y="6.47"/>
<vertex x="4.66" y="6.4"/>
<vertex x="4.66" y="6.31"/>
<vertex x="4.63" y="6.22"/>
<vertex x="4.59" y="6.13"/>
<vertex x="4.52" y="6.06"/>
<vertex x="4.41" y="6.02"/>
<vertex x="4.31" y="6.02"/>
<vertex x="4.2" y="6.04"/>
<vertex x="4.09" y="6.08"/>
<vertex x="3.98" y="6.14"/>
<vertex x="3.87" y="6.21"/>
<vertex x="3.76" y="6.28"/>
<vertex x="3.67" y="6.37"/>
<vertex x="3.58" y="6.46"/>
<vertex x="3.51" y="6.57"/>
<vertex x="3.45" y="6.67"/>
<vertex x="3.42" y="6.76"/>
<vertex x="3.41" y="6.86"/>
<vertex x="3.42" y="6.94"/>
<vertex x="3.45" y="7.03"/>
<vertex x="3.5" y="7.11"/>
<vertex x="3.56" y="7.19"/>
<vertex x="3.67" y="7.28"/>
<vertex x="3.8" y="7.35"/>
<vertex x="3.92" y="7.38"/>
<vertex x="4.05" y="7.4"/>
<vertex x="4.15" y="7.4"/>
<vertex x="4.24" y="7.39"/>
<vertex x="4.3" y="7.38"/>
<vertex x="4.32" y="7.38"/>
<vertex x="4.28" y="7.41"/>
<vertex x="4.17" y="7.49"/>
<vertex x="3.99" y="7.59"/>
<vertex x="3.77" y="7.69"/>
<vertex x="3.49" y="7.75"/>
<vertex x="3.19" y="7.77"/>
<vertex x="2.86" y="7.7"/>
<vertex x="2.52" y="7.52"/>
<vertex x="2.26" y="7.3"/>
<vertex x="2.1" y="7.06"/>
<vertex x="2.02" y="6.82"/>
<vertex x="2.02" y="6.56"/>
<vertex x="2.09" y="6.3"/>
<vertex x="2.23" y="6.04"/>
<vertex x="2.42" y="5.78"/>
<vertex x="2.68" y="5.52"/>
<vertex x="2.87" y="5.29"/>
<vertex x="2.97" y="5.07"/>
<vertex x="2.98" y="4.86"/>
<vertex x="2.91" y="4.67"/>
<vertex x="2.78" y="4.51"/>
<vertex x="2.6" y="4.4"/>
<vertex x="2.38" y="4.34"/>
<vertex x="2.14" y="4.34"/>
<vertex x="1.98" y="4.37"/>
<vertex x="1.85" y="4.43"/>
<vertex x="1.74" y="4.51"/>
<vertex x="1.66" y="4.6"/>
<vertex x="1.6" y="4.7"/>
<vertex x="1.58" y="4.8"/>
<vertex x="1.58" y="4.9"/>
<vertex x="1.6" y="4.99"/>
<vertex x="1.65" y="5.06"/>
<vertex x="1.71" y="5.12"/>
<vertex x="1.78" y="5.18"/>
<vertex x="1.85" y="5.22"/>
<vertex x="1.92" y="5.26"/>
<vertex x="1.98" y="5.28"/>
<vertex x="2.01" y="5.3"/>
<vertex x="2.03" y="5.31"/>
<vertex x="2.01" y="5.32"/>
<vertex x="1.96" y="5.33"/>
<vertex x="1.89" y="5.35"/>
<vertex x="1.78" y="5.37"/>
<vertex x="1.66" y="5.38"/>
<vertex x="1.52" y="5.37"/>
<vertex x="1.37" y="5.34"/>
<vertex x="1.2" y="5.29"/>
<vertex x="1.06" y="5.23"/>
<vertex x="0.92" y="5.14"/>
<vertex x="0.8" y="5.03"/>
<vertex x="0.69" y="4.89"/>
<vertex x="0.61" y="4.72"/>
<vertex x="0.54" y="4.52"/>
<vertex x="0.51" y="4.27"/>
<vertex x="0.5" y="3.98"/>
<vertex x="0.5" y="3.5"/>
<vertex x="0.5" y="3.02"/>
<vertex x="0.5" y="2.54"/>
<vertex x="0.5" y="2.06"/>
<vertex x="0.5" y="1.58"/>
<vertex x="0.5" y="1.1"/>
<vertex x="0.5" y="0.62"/>
<vertex x="0.5" y="0.14"/>
<vertex x="0.52" y="0.16"/>
<vertex x="0.57" y="0.23"/>
<vertex x="0.66" y="0.33"/>
<vertex x="0.77" y="0.46"/>
<vertex x="0.9" y="0.62"/>
<vertex x="1.05" y="0.79"/>
<vertex x="1.22" y="0.98"/>
<vertex x="1.4" y="1.17"/>
<vertex x="1.59" y="1.38"/>
<vertex x="1.76" y="1.57"/>
<vertex x="1.92" y="1.73"/>
<vertex x="2.07" y="1.87"/>
<vertex x="2.22" y="1.98"/>
<vertex x="2.38" y="2.06"/>
<vertex x="2.56" y="2.1"/>
<vertex x="2.75" y="2.1"/>
<vertex x="3.14" y="2.1"/>
<vertex x="3.49" y="2.15"/>
<vertex x="3.82" y="2.24"/>
<vertex x="4.13" y="2.37"/>
<vertex x="4.41" y="2.55"/>
<vertex x="4.66" y="2.75"/>
<vertex x="4.89" y="2.99"/>
<vertex x="5.1" y="3.26"/>
<vertex x="5.39" y="3.81"/>
<vertex x="5.54" y="4.36"/>
<vertex x="5.57" y="4.88"/>
<vertex x="5.5" y="5.37"/>
<vertex x="5.35" y="5.8"/>
<vertex x="5.14" y="6.15"/>
<vertex x="4.9" y="6.41"/>
<vertex x="4.64" y="6.55"/>
</polygon>
</package>
<package name="SFE_LOGO_FLAME_COPPER_EXPOSED_.3">
</polygon>
</polygon>
</package>
<package name="LOGOMATIC_LOGO">
<polygon width="0" layer="21">
<vertex x="0" y="2.05"/>
<vertex x="0" y="0"/>
<vertex x="28.82" y="0"/>
<vertex x="28.82" y="1.67"/>
<vertex x="27.15" y="1.79"/>
<vertex x="27.14" y="1.66"/>
<vertex x="27.13" y="1.54"/>
<vertex x="27.1" y="1.43"/>
<vertex x="27.07" y="1.32"/>
<vertex x="27.03" y="1.22"/>
<vertex x="26.98" y="1.13"/>
<vertex x="26.93" y="1.05"/>
<vertex x="26.86" y="0.97"/>
<vertex x="26.79" y="0.91"/>
<vertex x="26.7" y="0.85"/>
<vertex x="26.62" y="0.8"/>
<vertex x="26.52" y="0.76"/>
<vertex x="26.42" y="0.73"/>
<vertex x="26.3" y="0.7"/>
<vertex x="26.19" y="0.69"/>
<vertex x="26.06" y="0.68"/>
<vertex x="25.97" y="1.18"/>
<vertex x="26.05" y="1.18"/>
<vertex x="26.12" y="1.19"/>
<vertex x="26.19" y="1.2"/>
<vertex x="26.25" y="1.21"/>
<vertex x="26.31" y="1.23"/>
<vertex x="26.36" y="1.26"/>
<vertex x="26.4" y="1.29"/>
<vertex x="26.44" y="1.33"/>
<vertex x="26.48" y="1.37"/>
<vertex x="26.5" y="1.41"/>
<vertex x="26.53" y="1.46"/>
<vertex x="26.55" y="1.52"/>
<vertex x="26.56" y="1.58"/>
<vertex x="26.57" y="1.64"/>
<vertex x="26.58" y="1.71"/>
<vertex x="26.58" y="1.79"/>
<vertex x="26.58" y="1.87"/>
<vertex x="26.57" y="1.94"/>
<vertex x="26.56" y="2"/>
<vertex x="26.54" y="2.07"/>
<vertex x="26.52" y="2.12"/>
<vertex x="26.49" y="2.17"/>
<vertex x="26.46" y="2.22"/>
<vertex x="26.42" y="2.26"/>
<vertex x="26.38" y="2.29"/>
<vertex x="26.34" y="2.32"/>
<vertex x="26.29" y="2.35"/>
<vertex x="26.23" y="2.37"/>
<vertex x="26.17" y="2.38"/>
<vertex x="26.11" y="2.39"/>
<vertex x="26.04" y="2.4"/>
<vertex x="25.97" y="2.4"/>
<vertex x="25.68" y="2.4"/>
<vertex x="25.68" y="1.18"/>
<vertex x="25.12" y="0.68"/>
<vertex x="25.12" y="2.9"/>
<vertex x="24.74" y="2.26"/>
<vertex x="24.18" y="2.26"/>
<vertex x="24.17" y="2.3"/>
<vertex x="24.17" y="2.33"/>
<vertex x="24.16" y="2.36"/>
<vertex x="24.14" y="2.38"/>
<vertex x="24.13" y="2.41"/>
<vertex x="24.11" y="2.43"/>
<vertex x="24.09" y="2.45"/>
<vertex x="24.06" y="2.46"/>
<vertex x="24.04" y="2.48"/>
<vertex x="24.01" y="2.49"/>
<vertex x="23.98" y="2.5"/>
<vertex x="23.95" y="2.51"/>
<vertex x="23.92" y="2.51"/>
<vertex x="23.89" y="2.52"/>
<vertex x="23.85" y="2.52"/>
<vertex x="23.82" y="2.52"/>
<vertex x="23.8" y="2.52"/>
<vertex x="23.78" y="2.52"/>
<vertex x="23.75" y="2.52"/>
<vertex x="23.73" y="2.51"/>
<vertex x="23.71" y="2.51"/>
<vertex x="23.68" y="2.5"/>
<vertex x="23.66" y="2.49"/>
<vertex x="23.64" y="2.48"/>
<vertex x="23.62" y="2.47"/>
<vertex x="23.6" y="2.45"/>
<vertex x="23.58" y="2.44"/>
<vertex x="23.57" y="2.42"/>
<vertex x="23.56" y="2.4"/>
<vertex x="23.55" y="2.38"/>
<vertex x="23.54" y="2.36"/>
<vertex x="23.54" y="2.33"/>
<vertex x="23.54" y="2.3"/>
<vertex x="23.56" y="2.28"/>
<vertex x="23.57" y="2.25"/>
<vertex x="23.6" y="2.23"/>
<vertex x="23.63" y="2.21"/>
<vertex x="23.66" y="2.19"/>
<vertex x="23.7" y="2.17"/>
<vertex x="23.74" y="2.16"/>
<vertex x="23.79" y="2.14"/>
<vertex x="23.84" y="2.13"/>
<vertex x="23.89" y="2.11"/>
<vertex x="23.95" y="2.1"/>
<vertex x="24" y="2.09"/>
<vertex x="24.06" y="2.08"/>
<vertex x="24.12" y="2.06"/>
<vertex x="24.18" y="2.05"/>
<vertex x="24.24" y="2.03"/>
<vertex x="24.3" y="2.01"/>
<vertex x="24.36" y="1.99"/>
<vertex x="24.41" y="1.97"/>
<vertex x="24.47" y="1.94"/>
<vertex x="24.52" y="1.91"/>
<vertex x="24.57" y="1.88"/>
<vertex x="24.62" y="1.85"/>
<vertex x="24.66" y="1.81"/>
<vertex x="24.7" y="1.77"/>
<vertex x="24.73" y="1.72"/>
<vertex x="24.76" y="1.67"/>
<vertex x="24.78" y="1.61"/>
<vertex x="24.8" y="1.55"/>
<vertex x="24.81" y="1.49"/>
<vertex x="24.81" y="1.41"/>
<vertex x="24.81" y="1.31"/>
<vertex x="24.8" y="1.21"/>
<vertex x="24.78" y="1.12"/>
<vertex x="24.74" y="1.04"/>
<vertex x="24.7" y="0.97"/>
<vertex x="24.66" y="0.91"/>
<vertex x="24.6" y="0.85"/>
<vertex x="24.54" y="0.8"/>
<vertex x="24.47" y="0.76"/>
<vertex x="24.39" y="0.73"/>
<vertex x="24.31" y="0.7"/>
<vertex x="24.23" y="0.67"/>
<vertex x="24.14" y="0.66"/>
<vertex x="24.05" y="0.65"/>
<vertex x="23.96" y="0.64"/>
<vertex x="23.87" y="0.64"/>
<vertex x="23.78" y="0.64"/>
<vertex x="23.69" y="0.65"/>
<vertex x="23.6" y="0.66"/>
<vertex x="23.51" y="0.68"/>
<vertex x="23.43" y="0.7"/>
<vertex x="23.35" y="0.73"/>
<vertex x="23.27" y="0.77"/>
<vertex x="23.2" y="0.82"/>
<vertex x="23.14" y="0.87"/>
<vertex x="23.08" y="0.92"/>
<vertex x="23.03" y="0.99"/>
<vertex x="22.99" y="1.06"/>
<vertex x="22.95" y="1.14"/>
<vertex x="22.93" y="1.23"/>
<vertex x="22.91" y="1.33"/>
<vertex x="22.9" y="1.44"/>
<vertex x="21.75" y="1.79"/>
<vertex x="21.74" y="1.67"/>
<vertex x="21.73" y="1.56"/>
<vertex x="21.71" y="1.45"/>
<vertex x="21.68" y="1.34"/>
<vertex x="21.64" y="1.24"/>
<vertex x="21.59" y="1.15"/>
<vertex x="21.53" y="1.06"/>
<vertex x="21.46" y="0.97"/>
<vertex x="21.39" y="0.9"/>
<vertex x="21.31" y="0.83"/>
<vertex x="21.22" y="0.78"/>
<vertex x="21.12" y="0.73"/>
<vertex x="21.02" y="0.69"/>
<vertex x="20.91" y="0.66"/>
<vertex x="20.79" y="0.64"/>
<vertex x="20.67" y="0.64"/>
<vertex x="20.67" y="1.13"/>
<vertex x="20.73" y="1.13"/>
<vertex x="20.8" y="1.15"/>
<vertex x="20.85" y="1.16"/>
<vertex x="20.91" y="1.19"/>
<vertex x="20.95" y="1.22"/>
<vertex x="21" y="1.25"/>
<vertex x="21.03" y="1.29"/>
<vertex x="21.07" y="1.34"/>
<vertex x="21.1" y="1.39"/>
<vertex x="21.12" y="1.44"/>
<vertex x="21.14" y="1.49"/>
<vertex x="21.16" y="1.55"/>
<vertex x="21.17" y="1.61"/>
<vertex x="21.18" y="1.67"/>
<vertex x="21.18" y="1.73"/>
<vertex x="21.18" y="1.79"/>
<vertex x="21.18" y="1.85"/>
<vertex x="21.18" y="1.91"/>
<vertex x="21.17" y="1.97"/>
<vertex x="21.16" y="2.03"/>
<vertex x="21.14" y="2.09"/>
<vertex x="21.12" y="2.14"/>
<vertex x="21.1" y="2.2"/>
<vertex x="21.07" y="2.24"/>
<vertex x="21.03" y="2.29"/>
<vertex x="21" y="2.33"/>
<vertex x="20.95" y="2.36"/>
<vertex x="20.91" y="2.39"/>
<vertex x="20.85" y="2.42"/>
<vertex x="20.8" y="2.44"/>
<vertex x="20.73" y="2.45"/>
<vertex x="20.67" y="2.45"/>
<vertex x="20.6" y="2.45"/>
<vertex x="20.53" y="2.44"/>
<vertex x="20.48" y="2.42"/>
<vertex x="20.43" y="2.39"/>
<vertex x="20.38" y="2.36"/>
<vertex x="20.34" y="2.33"/>
<vertex x="20.3" y="2.29"/>
<vertex x="20.26" y="2.24"/>
<vertex x="20.24" y="2.2"/>
<vertex x="20.21" y="2.14"/>
<vertex x="20.19" y="2.09"/>
<vertex x="20.17" y="2.03"/>
<vertex x="20.16" y="1.97"/>
<vertex x="20.15" y="1.91"/>
<vertex x="20.15" y="1.85"/>
<vertex x="20.15" y="1.79"/>
<vertex x="20.15" y="1.73"/>
<vertex x="20.15" y="1.67"/>
<vertex x="20.16" y="1.61"/>
<vertex x="20.17" y="1.55"/>
<vertex x="20.19" y="1.49"/>
<vertex x="20.21" y="1.44"/>
<vertex x="20.24" y="1.39"/>
<vertex x="20.26" y="1.34"/>
<vertex x="20.3" y="1.29"/>
<vertex x="20.34" y="1.25"/>
<vertex x="20.38" y="1.22"/>
<vertex x="20.43" y="1.19"/>
<vertex x="20.48" y="1.16"/>
<vertex x="20.53" y="1.15"/>
<vertex x="20.6" y="1.13"/>
<vertex x="20.54" y="0.64"/>
<vertex x="20.42" y="0.66"/>
<vertex x="20.31" y="0.69"/>
<vertex x="20.21" y="0.73"/>
<vertex x="20.11" y="0.78"/>
<vertex x="20.02" y="0.83"/>
<vertex x="19.94" y="0.9"/>
<vertex x="19.87" y="0.97"/>
<vertex x="19.8" y="1.06"/>
<vertex x="19.74" y="1.15"/>
<vertex x="19.7" y="1.24"/>
<vertex x="19.65" y="1.34"/>
<vertex x="19.62" y="1.45"/>
<vertex x="19.6" y="1.56"/>
<vertex x="19.59" y="1.67"/>
<vertex x="19.58" y="1.79"/>
<vertex x="19.32" y="2.29"/>
<vertex x="19.32" y="2.24"/>
<vertex x="19.32" y="2.2"/>
<vertex x="19.31" y="2.15"/>
<vertex x="19.3" y="2.11"/>
<vertex x="19.29" y="2.07"/>
<vertex x="19.27" y="2.03"/>
<vertex x="19.25" y="1.99"/>
<vertex x="19.23" y="1.95"/>
<vertex x="19.21" y="1.91"/>
<vertex x="19.18" y="1.88"/>
<vertex x="19.16" y="1.85"/>
<vertex x="19.12" y="1.82"/>
<vertex x="19.09" y="1.79"/>
<vertex x="19.05" y="1.76"/>
<vertex x="19.01" y="1.74"/>
<vertex x="18.97" y="1.72"/>
<vertex x="19.01" y="1.71"/>
<vertex x="19.05" y="1.69"/>
<vertex x="19.08" y="1.67"/>
<vertex x="19.12" y="1.65"/>
<vertex x="19.14" y="1.62"/>
<vertex x="19.17" y="1.58"/>
<vertex x="19.19" y="1.55"/>
<vertex x="19.21" y="1.51"/>
<vertex x="19.23" y="1.47"/>
<vertex x="19.25" y="1.43"/>
<vertex x="19.26" y="1.39"/>
<vertex x="19.27" y="1.35"/>
<vertex x="19.28" y="1.3"/>
<vertex x="19.29" y="1.26"/>
<vertex x="19.29" y="1.22"/>
<vertex x="19.3" y="1.18"/>
<vertex x="19.3" y="1.16"/>
<vertex x="19.3" y="1.13"/>
<vertex x="19.3" y="1.1"/>
<vertex x="19.3" y="1.07"/>
<vertex x="19.31" y="1.04"/>
<vertex x="19.31" y="1"/>
<vertex x="19.31" y="0.96"/>
<vertex x="19.32" y="0.92"/>
<vertex x="19.33" y="0.88"/>
<vertex x="19.33" y="0.85"/>
<vertex x="19.34" y="0.81"/>
<vertex x="19.35" y="0.78"/>
<vertex x="19.36" y="0.75"/>
<vertex x="19.37" y="0.72"/>
<vertex x="19.38" y="0.7"/>
<vertex x="19.39" y="0.68"/>
<vertex x="18.83" y="0.68"/>
<vertex x="18.82" y="0.7"/>
<vertex x="18.81" y="0.72"/>
<vertex x="18.81" y="0.74"/>
<vertex x="18.8" y="0.76"/>
<vertex x="18.8" y="0.78"/>
<vertex x="18.79" y="0.81"/>
<vertex x="18.79" y="0.83"/>
<vertex x="18.78" y="0.86"/>
<vertex x="18.78" y="0.89"/>
<vertex x="18.78" y="0.91"/>
<vertex x="18.77" y="0.94"/>
<vertex x="18.77" y="0.96"/>
<vertex x="18.77" y="0.98"/>
<vertex x="18.76" y="1"/>
<vertex x="18.76" y="1.02"/>
<vertex x="18.76" y="1.04"/>
<vertex x="18.75" y="1.08"/>
<vertex x="18.75" y="1.12"/>
<vertex x="18.74" y="1.16"/>
<vertex x="18.74" y="1.2"/>
<vertex x="18.73" y="1.23"/>
<vertex x="18.72" y="1.27"/>
<vertex x="18.7" y="1.31"/>
<vertex x="18.69" y="1.34"/>
<vertex x="18.67" y="1.37"/>
<vertex x="18.65" y="1.4"/>
<vertex x="18.62" y="1.42"/>
<vertex x="18.59" y="1.44"/>
<vertex x="18.56" y="1.46"/>
<vertex x="18.52" y="1.47"/>
<vertex x="18.48" y="1.48"/>
<vertex x="18.43" y="1.48"/>
<vertex x="17.98" y="1.48"/>
<vertex x="18" y="1.96"/>
<vertex x="18.5" y="1.96"/>
<vertex x="18.53" y="1.96"/>
<vertex x="18.56" y="1.96"/>
<vertex x="18.58" y="1.97"/>
<vertex x="18.61" y="1.97"/>
<vertex x="18.63" y="1.98"/>
<vertex x="18.65" y="1.99"/>
<vertex x="18.67" y="2.01"/>
<vertex x="18.69" y="2.02"/>
<vertex x="18.7" y="2.04"/>
<vertex x="18.72" y="2.06"/>
<vertex x="18.73" y="2.08"/>
<vertex x="18.74" y="2.1"/>
<vertex x="18.75" y="2.13"/>
<vertex x="18.75" y="2.16"/>
<vertex x="18.76" y="2.18"/>
<vertex x="18.76" y="2.21"/>
<vertex x="18.75" y="2.24"/>
<vertex x="18.74" y="2.27"/>
<vertex x="18.73" y="2.3"/>
<vertex x="18.72" y="2.32"/>
<vertex x="18.71" y="2.34"/>
<vertex x="18.69" y="2.36"/>
<vertex x="18.68" y="2.38"/>
<vertex x="18.66" y="2.39"/>
<vertex x="18.64" y="2.41"/>
<vertex x="18.61" y="2.42"/>
<vertex x="18.59" y="2.43"/>
<vertex x="18.56" y="2.44"/>
<vertex x="18.54" y="2.44"/>
<vertex x="18.51" y="2.45"/>
<vertex x="18.48" y="2.45"/>
<vertex x="18.45" y="2.45"/>
<vertex x="18" y="2.45"/>
<vertex x="17.98" y="0.68"/>
<vertex x="17.41" y="0.68"/>
<vertex x="17.41" y="2.9"/>
<vertex x="17.11" y="2.1"/>
<vertex x="16.54" y="2.1"/>
<vertex x="16.54" y="2.14"/>
<vertex x="16.53" y="2.17"/>
<vertex x="16.51" y="2.21"/>
<vertex x="16.49" y="2.24"/>
<vertex x="16.47" y="2.27"/>
<vertex x="16.45" y="2.29"/>
<vertex x="16.43" y="2.32"/>
<vertex x="16.4" y="2.34"/>
<vertex x="16.37" y="2.36"/>
<vertex x="16.33" y="2.38"/>
<vertex x="16.3" y="2.39"/>
<vertex x="16.26" y="2.41"/>
<vertex x="16.22" y="2.41"/>
<vertex x="16.18" y="2.42"/>
<vertex x="16.14" y="2.43"/>
<vertex x="16.09" y="2.43"/>
<vertex x="16.03" y="2.42"/>
<vertex x="15.96" y="2.41"/>
<vertex x="15.91" y="2.39"/>
<vertex x="15.85" y="2.37"/>
<vertex x="15.81" y="2.34"/>
<vertex x="15.76" y="2.3"/>
<vertex x="15.73" y="2.26"/>
<vertex x="15.69" y="2.22"/>
<vertex x="15.66" y="2.17"/>
<vertex x="15.64" y="2.12"/>
<vertex x="15.62" y="2.07"/>
<vertex x="15.6" y="2.01"/>
<vertex x="15.59" y="1.95"/>
<vertex x="15.58" y="1.89"/>
<vertex x="15.58" y="1.83"/>
<vertex x="15.58" y="1.77"/>
<vertex x="15.58" y="1.71"/>
<vertex x="15.58" y="1.65"/>
<vertex x="15.59" y="1.59"/>
<vertex x="15.6" y="1.53"/>
<vertex x="15.62" y="1.47"/>
<vertex x="15.64" y="1.42"/>
<vertex x="15.66" y="1.37"/>
<vertex x="15.69" y="1.33"/>
<vertex x="15.73" y="1.28"/>
<vertex x="15.76" y="1.25"/>
<vertex x="15.81" y="1.21"/>
<vertex x="15.85" y="1.18"/>
<vertex x="15.91" y="1.16"/>
<vertex x="15.96" y="1.14"/>
<vertex x="16.03" y="1.13"/>
<vertex x="16.09" y="1.13"/>
<vertex x="16.15" y="1.13"/>
<vertex x="16.19" y="1.14"/>
<vertex x="16.24" y="1.15"/>
<vertex x="16.28" y="1.16"/>
<vertex x="16.32" y="1.17"/>
<vertex x="16.35" y="1.19"/>
<vertex x="16.39" y="1.21"/>
<vertex x="16.42" y="1.23"/>
<vertex x="16.44" y="1.26"/>
<vertex x="16.46" y="1.29"/>
<vertex x="16.48" y="1.32"/>
<vertex x="16.5" y="1.36"/>
<vertex x="16.52" y="1.4"/>
<vertex x="16.53" y="1.44"/>
<vertex x="16.54" y="1.48"/>
<vertex x="16.54" y="1.53"/>
<vertex x="17.11" y="1.53"/>
<vertex x="17.1" y="1.43"/>
<vertex x="17.08" y="1.33"/>
<vertex x="17.05" y="1.24"/>
<vertex x="17.02" y="1.15"/>
<vertex x="16.98" y="1.07"/>
<vertex x="16.93" y="1"/>
<vertex x="16.87" y="0.93"/>
<vertex x="16.8" y="0.87"/>
<vertex x="16.73" y="0.82"/>
<vertex x="16.66" y="0.77"/>
<vertex x="16.57" y="0.73"/>
<vertex x="16.49" y="0.7"/>
<vertex x="16.4" y="0.67"/>
<vertex x="16.3" y="0.65"/>
<vertex x="16.2" y="0.64"/>
<vertex x="16.09" y="0.64"/>
<vertex x="15.97" y="0.64"/>
<vertex x="15.85" y="0.66"/>
<vertex x="15.74" y="0.69"/>
<vertex x="15.63" y="0.73"/>
<vertex x="15.53" y="0.78"/>
<vertex x="15.44" y="0.83"/>
<vertex x="15.36" y="0.9"/>
<vertex x="15.28" y="0.97"/>
<vertex x="15.22" y="1.06"/>
<vertex x="15.16" y="1.15"/>
<vertex x="15.11" y="1.24"/>
<vertex x="15.06" y="1.34"/>
<vertex x="15.03" y="1.45"/>
<vertex x="15.01" y="1.56"/>
<vertex x="14.99" y="1.67"/>
<vertex x="14.99" y="1.79"/>
<vertex x="14.66" y="2.9"/>
<vertex x="14.66" y="0.68"/>
<vertex x="14.09" y="0.68"/>
<vertex x="14.09" y="2.9"/>
<vertex x="13.69" y="2.9"/>
<vertex x="13.69" y="0.68"/>
<vertex x="13.15" y="0.68"/>
<vertex x="13.15" y="2.36"/>
<vertex x="12.68" y="0.68"/>
<vertex x="12.23" y="0.68"/>
<vertex x="11.76" y="2.36"/>
<vertex x="11.76" y="0.68"/>
<vertex x="11.22" y="0.68"/>
<vertex x="11.22" y="2.9"/>
<vertex x="9.83" y="2.9"/>
<vertex x="9.83" y="0.68"/>
<vertex x="9.85" y="0.68"/>
<vertex x="9.28" y="0.68"/>
<vertex x="9.28" y="1.6"/>
<vertex x="8.51" y="1.6"/>
<vertex x="8.51" y="0.68"/>
<vertex x="7.94" y="0.68"/>
<vertex x="7.94" y="2.9"/>
<vertex x="7.71" y="2.9"/>
<vertex x="7.71" y="2.4"/>
<vertex x="7.68" y="2.4"/>
<vertex x="7.02" y="2.4"/>
<vertex x="7.02" y="0.68"/>
<vertex x="6.46" y="0.68"/>
<vertex x="6.46" y="2.4"/>
<vertex x="5.8" y="2.4"/>
<vertex x="5.8" y="2.9"/>
<vertex x="5.51" y="2.9"/>
<vertex x="5.51" y="0.68"/>
<vertex x="4.95" y="0.68"/>
<vertex x="4.95" y="2.9"/>
<vertex x="4.71" y="2.9"/>
<vertex x="4.15" y="0.68"/>
<vertex x="3.56" y="0.68"/>
<vertex x="3.25" y="2.21"/>
<vertex x="2.95" y="0.68"/>
<vertex x="2.36" y="0.68"/>
<vertex x="1.77" y="2.9"/>
</polygon>
<vertex x="28.82" y="3.79"/>
<vertex x="28.58" y="3.6"/>
<vertex x="0.21" y="3.6"/>
<vertex x="0" y="3.6"/>
<vertex x="2.33" y="2.9"/>
<vertex x="2.64" y="1.27"/>
<vertex x="2.97" y="2.9"/>
<vertex x="3.51" y="2.9"/>
<vertex x="3.84" y="1.27"/>
<vertex x="4.15" y="2.9"/>
<vertex x="8.51" y="2.9"/>
<vertex x="8.51" y="2.1"/>
<vertex x="9.26" y="2.1"/>
<vertex x="9.26" y="2.9"/>
<vertex x="12.06" y="2.9"/>
<vertex x="12.44" y="1.41"/>
<vertex x="12.82" y="2.9"/>
<vertex x="14.99" y="1.91"/>
<vertex x="15.01" y="2.02"/>
<vertex x="15.03" y="2.13"/>
<vertex x="15.06" y="2.24"/>
<vertex x="15.11" y="2.34"/>
<vertex x="15.16" y="2.44"/>
<vertex x="15.22" y="2.52"/>
<vertex x="15.28" y="2.61"/>
<vertex x="15.36" y="2.68"/>
<vertex x="15.44" y="2.75"/>
<vertex x="15.53" y="2.81"/>
<vertex x="15.63" y="2.85"/>
<vertex x="15.74" y="2.89"/>
<vertex x="15.85" y="2.92"/>
<vertex x="15.97" y="2.94"/>
<vertex x="16.09" y="2.95"/>
<vertex x="16.18" y="2.94"/>
<vertex x="16.27" y="2.93"/>
<vertex x="16.36" y="2.91"/>
<vertex x="16.45" y="2.89"/>
<vertex x="16.53" y="2.86"/>
<vertex x="16.62" y="2.82"/>
<vertex x="16.69" y="2.78"/>
<vertex x="16.77" y="2.72"/>
<vertex x="16.84" y="2.67"/>
<vertex x="16.9" y="2.6"/>
<vertex x="16.96" y="2.53"/>
<vertex x="17" y="2.46"/>
<vertex x="17.05" y="2.38"/>
<vertex x="17.08" y="2.29"/>
<vertex x="17.1" y="2.2"/>
<vertex x="18.54" y="2.9"/>
<vertex x="18.62" y="2.9"/>
<vertex x="18.69" y="2.89"/>
<vertex x="18.76" y="2.88"/>
<vertex x="18.83" y="2.86"/>
<vertex x="18.89" y="2.84"/>
<vertex x="18.96" y="2.82"/>
<vertex x="19.02" y="2.79"/>
<vertex x="19.07" y="2.75"/>
<vertex x="19.13" y="2.71"/>
<vertex x="19.18" y="2.67"/>
<vertex x="19.22" y="2.62"/>
<vertex x="19.25" y="2.56"/>
<vertex x="19.28" y="2.5"/>
<vertex x="19.3" y="2.43"/>
<vertex x="19.32" y="2.36"/>
<vertex x="19.59" y="1.91"/>
<vertex x="19.6" y="2.02"/>
<vertex x="19.62" y="2.13"/>
<vertex x="19.65" y="2.24"/>
<vertex x="19.7" y="2.34"/>
<vertex x="19.74" y="2.44"/>
<vertex x="19.8" y="2.52"/>
<vertex x="19.87" y="2.61"/>
<vertex x="19.94" y="2.68"/>
<vertex x="20.02" y="2.75"/>
<vertex x="20.11" y="2.81"/>
<vertex x="20.21" y="2.85"/>
<vertex x="20.31" y="2.89"/>
<vertex x="20.42" y="2.92"/>
<vertex x="20.54" y="2.94"/>
<vertex x="20.67" y="2.95"/>
<vertex x="20.79" y="2.94"/>
<vertex x="20.91" y="2.92"/>
<vertex x="21.03" y="2.89"/>
<vertex x="21.13" y="2.85"/>
<vertex x="21.23" y="2.81"/>
<vertex x="21.32" y="2.75"/>
<vertex x="21.4" y="2.68"/>
<vertex x="21.47" y="2.61"/>
<vertex x="21.54" y="2.52"/>
<vertex x="21.59" y="2.44"/>
<vertex x="21.64" y="2.34"/>
<vertex x="21.68" y="2.24"/>
<vertex x="21.71" y="2.13"/>
<vertex x="21.73" y="2.02"/>
<vertex x="21.74" y="1.91"/>
<vertex x="23.47" y="1.44"/>
<vertex x="23.48" y="1.39"/>
<vertex x="23.48" y="1.35"/>
<vertex x="23.5" y="1.31"/>
<vertex x="23.51" y="1.27"/>
<vertex x="23.53" y="1.24"/>
<vertex x="23.55" y="1.21"/>
<vertex x="23.57" y="1.19"/>
<vertex x="23.59" y="1.16"/>
<vertex x="23.62" y="1.14"/>
<vertex x="23.65" y="1.13"/>
<vertex x="23.69" y="1.11"/>
<vertex x="23.72" y="1.1"/>
<vertex x="23.76" y="1.09"/>
<vertex x="23.8" y="1.09"/>
<vertex x="23.85" y="1.09"/>
<vertex x="23.89" y="1.08"/>
<vertex x="23.93" y="1.08"/>
<vertex x="23.96" y="1.09"/>
<vertex x="23.99" y="1.09"/>
<vertex x="24.02" y="1.1"/>
<vertex x="24.05" y="1.11"/>
<vertex x="24.08" y="1.11"/>
<vertex x="24.11" y="1.13"/>
<vertex x="24.13" y="1.14"/>
<vertex x="24.16" y="1.16"/>
<vertex x="24.18" y="1.17"/>
<vertex x="24.2" y="1.19"/>
<vertex x="24.22" y="1.21"/>
<vertex x="24.23" y="1.24"/>
<vertex x="24.24" y="1.26"/>
<vertex x="24.24" y="1.29"/>
<vertex x="24.25" y="1.32"/>
<vertex x="24.24" y="1.35"/>
<vertex x="24.23" y="1.38"/>
<vertex x="24.22" y="1.41"/>
<vertex x="24.19" y="1.44"/>
<vertex x="24.17" y="1.46"/>
<vertex x="24.13" y="1.48"/>
<vertex x="24.1" y="1.5"/>
<vertex x="24.05" y="1.52"/>
<vertex x="24.01" y="1.54"/>
<vertex x="23.96" y="1.55"/>
<vertex x="23.9" y="1.57"/>
<vertex x="23.85" y="1.58"/>
<vertex x="23.79" y="1.6"/>
<vertex x="23.73" y="1.62"/>
<vertex x="23.67" y="1.63"/>
<vertex x="23.61" y="1.65"/>
<vertex x="23.55" y="1.67"/>
<vertex x="23.49" y="1.69"/>
<vertex x="23.44" y="1.71"/>
<vertex x="23.38" y="1.73"/>
<vertex x="23.32" y="1.76"/>
<vertex x="23.27" y="1.79"/>
<vertex x="23.22" y="1.82"/>
<vertex x="23.17" y="1.85"/>
<vertex x="23.12" y="1.89"/>
<vertex x="23.08" y="1.93"/>
<vertex x="23.04" y="1.98"/>
<vertex x="23.01" y="2.03"/>
<vertex x="22.99" y="2.09"/>
<vertex x="22.97" y="2.15"/>
<vertex x="22.96" y="2.21"/>
<vertex x="22.95" y="2.29"/>
<vertex x="22.96" y="2.37"/>
<vertex x="22.97" y="2.46"/>
<vertex x="23" y="2.53"/>
<vertex x="23.04" y="2.6"/>
<vertex x="23.08" y="2.66"/>
<vertex x="23.13" y="2.72"/>
<vertex x="23.19" y="2.77"/>
<vertex x="23.25" y="2.81"/>
<vertex x="23.32" y="2.85"/>
<vertex x="23.39" y="2.88"/>
<vertex x="23.46" y="2.91"/>
<vertex x="23.54" y="2.93"/>
<vertex x="23.62" y="2.95"/>
<vertex x="23.69" y="2.96"/>
<vertex x="23.77" y="2.97"/>
<vertex x="23.85" y="2.97"/>
<vertex x="23.93" y="2.97"/>
<vertex x="24.01" y="2.96"/>
<vertex x="24.1" y="2.95"/>
<vertex x="24.18" y="2.93"/>
<vertex x="24.25" y="2.9"/>
<vertex x="24.33" y="2.88"/>
<vertex x="24.4" y="2.84"/>
<vertex x="24.46" y="2.8"/>
<vertex x="24.52" y="2.75"/>
<vertex x="24.58" y="2.7"/>
<vertex x="24.62" y="2.65"/>
<vertex x="24.67" y="2.58"/>
<vertex x="24.7" y="2.51"/>
<vertex x="24.72" y="2.43"/>
<vertex x="24.74" y="2.35"/>
<vertex x="26.06" y="2.9"/>
<vertex x="26.19" y="2.89"/>
<vertex x="26.3" y="2.88"/>
<vertex x="26.42" y="2.85"/>
<vertex x="26.52" y="2.82"/>
<vertex x="26.62" y="2.78"/>
<vertex x="26.7" y="2.73"/>
<vertex x="26.79" y="2.67"/>
<vertex x="26.86" y="2.6"/>
<vertex x="26.93" y="2.52"/>
<vertex x="26.98" y="2.44"/>
<vertex x="27.03" y="2.35"/>
<vertex x="27.07" y="2.25"/>
<vertex x="27.1" y="2.15"/>
<vertex x="27.13" y="2.03"/>
<vertex x="27.14" y="1.92"/>
</polygon>
<vertex x="28.82" y="10.23"/>
<vertex x="0" y="10.23"/>
<vertex x="0.21" y="10.01"/>
<vertex x="28.58" y="10.01"/>
</polygon>
<vertex x="3.82" y="5.32"/>
<vertex x="2.4" y="5.32"/>
<vertex x="2.4" y="8.67"/>
<vertex x="1.58" y="8.67"/>
<vertex x="1.58" y="4.67"/>
<vertex x="3.82" y="4.67"/>
</polygon>
<vertex x="5.42" y="4.59"/>
<vertex x="5.43" y="4.59"/>
<vertex x="5.44" y="4.59"/>
<vertex x="5.45" y="4.59"/>
<vertex x="5.46" y="4.59"/>
<vertex x="5.47" y="4.59"/>
<vertex x="5.68" y="4.6"/>
<vertex x="5.88" y="4.63"/>
<vertex x="6.05" y="4.68"/>
<vertex x="6.2" y="4.75"/>
<vertex x="6.33" y="4.83"/>
<vertex x="6.44" y="4.93"/>
<vertex x="6.53" y="5.05"/>
<vertex x="6.61" y="5.18"/>
<vertex x="6.67" y="5.33"/>
<vertex x="6.72" y="5.49"/>
<vertex x="6.76" y="5.66"/>
<vertex x="6.79" y="5.85"/>
<vertex x="6.81" y="6.04"/>
<vertex x="6.82" y="6.25"/>
<vertex x="6.83" y="6.47"/>
<vertex x="6.83" y="6.69"/>
<vertex x="6.83" y="6.92"/>
<vertex x="6.82" y="7.13"/>
<vertex x="6.81" y="7.34"/>
<vertex x="6.79" y="7.54"/>
<vertex x="6.76" y="7.72"/>
<vertex x="6.72" y="7.89"/>
<vertex x="6.67" y="8.05"/>
<vertex x="6.61" y="8.2"/>
<vertex x="6.53" y="8.33"/>
<vertex x="6.44" y="8.45"/>
<vertex x="6.33" y="8.55"/>
<vertex x="6.2" y="8.63"/>
<vertex x="6.05" y="8.7"/>
<vertex x="5.88" y="8.75"/>
<vertex x="5.68" y="8.78"/>
<vertex x="5.47" y="8.79"/>
<vertex x="5.46" y="8.79"/>
<vertex x="5.45" y="8.79"/>
<vertex x="5.44" y="8.79"/>
<vertex x="5.43" y="8.79"/>
<vertex x="5.42" y="8.79"/>
<vertex x="5.42" y="8.15"/>
<vertex x="5.43" y="8.15"/>
<vertex x="5.44" y="8.15"/>
<vertex x="5.45" y="8.15"/>
<vertex x="5.46" y="8.15"/>
<vertex x="5.47" y="8.15"/>
<vertex x="5.55" y="8.15"/>
<vertex x="5.63" y="8.13"/>
<vertex x="5.69" y="8.11"/>
<vertex x="5.75" y="8.07"/>
<vertex x="5.81" y="8.02"/>
<vertex x="5.85" y="7.96"/>
<vertex x="5.89" y="7.89"/>
<vertex x="5.93" y="7.81"/>
<vertex x="5.95" y="7.71"/>
<vertex x="5.98" y="7.6"/>
<vertex x="6" y="7.48"/>
<vertex x="6.01" y="7.35"/>
<vertex x="6.02" y="7.2"/>
<vertex x="6.03" y="7.04"/>
<vertex x="6.03" y="6.86"/>
<vertex x="6.03" y="6.67"/>
<vertex x="6.03" y="6.47"/>
<vertex x="6.03" y="6.29"/>
<vertex x="6.02" y="6.13"/>
<vertex x="6.01" y="5.98"/>
<vertex x="6" y="5.84"/>
<vertex x="5.98" y="5.72"/>
<vertex x="5.96" y="5.61"/>
<vertex x="5.93" y="5.52"/>
<vertex x="5.9" y="5.44"/>
<vertex x="5.86" y="5.37"/>
<vertex x="5.82" y="5.31"/>
<vertex x="5.76" y="5.26"/>
<vertex x="5.7" y="5.23"/>
<vertex x="5.63" y="5.2"/>
<vertex x="5.55" y="5.19"/>
<vertex x="5.47" y="5.18"/>
<vertex x="5.46" y="5.18"/>
<vertex x="5.45" y="5.18"/>
<vertex x="5.44" y="5.18"/>
<vertex x="5.43" y="5.18"/>
<vertex x="5.42" y="5.18"/>
</polygon>
<vertex x="5.35" y="5.19"/>
<vertex x="5.28" y="5.21"/>
<vertex x="5.21" y="5.24"/>
<vertex x="5.16" y="5.28"/>
<vertex x="5.11" y="5.33"/>
<vertex x="5.07" y="5.39"/>
<vertex x="5.03" y="5.46"/>
<vertex x="5" y="5.54"/>
<vertex x="4.97" y="5.64"/>
<vertex x="4.95" y="5.74"/>
<vertex x="4.94" y="5.86"/>
<vertex x="4.92" y="6"/>
<vertex x="4.91" y="6.14"/>
<vertex x="4.91" y="6.3"/>
<vertex x="4.9" y="6.48"/>
<vertex x="4.9" y="6.67"/>
<vertex x="4.9" y="6.86"/>
<vertex x="4.91" y="7.03"/>
<vertex x="4.91" y="7.19"/>
<vertex x="4.92" y="7.34"/>
<vertex x="4.94" y="7.47"/>
<vertex x="4.95" y="7.59"/>
<vertex x="4.97" y="7.7"/>
<vertex x="5" y="7.79"/>
<vertex x="5.03" y="7.88"/>
<vertex x="5.07" y="7.95"/>
<vertex x="5.11" y="8.01"/>
<vertex x="5.16" y="8.06"/>
<vertex x="5.21" y="8.1"/>
<vertex x="5.28" y="8.12"/>
<vertex x="5.35" y="8.14"/>
<vertex x="5.21" y="8.78"/>
<vertex x="5.02" y="8.74"/>
<vertex x="4.86" y="8.69"/>
<vertex x="4.72" y="8.62"/>
<vertex x="4.59" y="8.54"/>
<vertex x="4.48" y="8.43"/>
<vertex x="4.39" y="8.32"/>
<vertex x="4.32" y="8.19"/>
<vertex x="4.26" y="8.04"/>
<vertex x="4.21" y="7.88"/>
<vertex x="4.17" y="7.71"/>
<vertex x="4.14" y="7.53"/>
<vertex x="4.12" y="7.33"/>
<vertex x="4.11" y="7.13"/>
<vertex x="4.1" y="6.91"/>
<vertex x="4.1" y="6.69"/>
<vertex x="4.1" y="6.47"/>
<vertex x="4.11" y="6.26"/>
<vertex x="4.12" y="6.05"/>
<vertex x="4.14" y="5.86"/>
<vertex x="4.17" y="5.67"/>
<vertex x="4.21" y="5.5"/>
<vertex x="4.26" y="5.34"/>
<vertex x="4.33" y="5.2"/>
<vertex x="4.4" y="5.07"/>
<vertex x="4.49" y="4.95"/>
<vertex x="4.6" y="4.85"/>
<vertex x="4.73" y="4.76"/>
<vertex x="4.87" y="4.69"/>
<vertex x="5.03" y="4.64"/>
<vertex x="5.21" y="4.61"/>
</polygon>
<vertex x="8.46" y="4.59"/>
<vertex x="8.53" y="4.6"/>
<vertex x="8.6" y="4.6"/>
<vertex x="8.66" y="4.61"/>
<vertex x="8.72" y="4.62"/>
<vertex x="8.78" y="4.64"/>
<vertex x="8.84" y="4.66"/>
<vertex x="8.89" y="4.68"/>
<vertex x="8.95" y="4.7"/>
<vertex x="9" y="4.73"/>
<vertex x="9.05" y="4.77"/>
<vertex x="9.09" y="4.8"/>
<vertex x="9.14" y="4.84"/>
<vertex x="9.18" y="4.89"/>
<vertex x="9.23" y="4.93"/>
<vertex x="9.27" y="4.99"/>
<vertex x="9.31" y="5.04"/>
<vertex x="9.31" y="4.67"/>
<vertex x="9.92" y="4.67"/>
<vertex x="9.92" y="6.83"/>
<vertex x="8.6" y="6.83"/>
<vertex x="8.6" y="6.24"/>
<vertex x="9.14" y="6.24"/>
<vertex x="9.14" y="5.84"/>
<vertex x="9.14" y="5.77"/>
<vertex x="9.13" y="5.69"/>
<vertex x="9.11" y="5.63"/>
<vertex x="9.09" y="5.57"/>
<vertex x="9.07" y="5.51"/>
<vertex x="9.04" y="5.46"/>
<vertex x="9" y="5.41"/>
<vertex x="8.97" y="5.37"/>
<vertex x="8.93" y="5.33"/>
<vertex x="8.89" y="5.3"/>
<vertex x="8.85" y="5.27"/>
<vertex x="8.8" y="5.25"/>
<vertex x="8.76" y="5.23"/>
<vertex x="8.72" y="5.22"/>
<vertex x="8.68" y="5.21"/>
<vertex x="8.65" y="5.21"/>
<vertex x="8.56" y="5.21"/>
<vertex x="8.49" y="5.24"/>
<vertex x="8.42" y="5.27"/>
<vertex x="8.36" y="5.32"/>
<vertex x="8.31" y="5.38"/>
<vertex x="8.26" y="5.45"/>
<vertex x="8.22" y="5.54"/>
<vertex x="8.19" y="5.63"/>
<vertex x="8.16" y="5.74"/>
<vertex x="8.14" y="5.86"/>
<vertex x="8.12" y="5.99"/>
<vertex x="8.1" y="6.13"/>
<vertex x="8.09" y="6.28"/>
<vertex x="8.09" y="6.44"/>
<vertex x="8.08" y="6.61"/>
<vertex x="8.08" y="6.79"/>
<vertex x="8.08" y="6.97"/>
<vertex x="8.09" y="7.14"/>
<vertex x="8.1" y="7.29"/>
<vertex x="8.11" y="7.43"/>
<vertex x="8.13" y="7.56"/>
<vertex x="8.15" y="7.68"/>
<vertex x="8.18" y="7.78"/>
<vertex x="8.21" y="7.87"/>
<vertex x="8.25" y="7.95"/>
<vertex x="8.29" y="8.02"/>
<vertex x="8.33" y="8.08"/>
<vertex x="8.38" y="8.12"/>
<vertex x="8.43" y="8.16"/>
<vertex x="8.49" y="8.18"/>
<vertex x="8.56" y="8.2"/>
<vertex x="8.62" y="8.2"/>
<vertex x="8.68" y="8.2"/>
<vertex x="8.74" y="8.18"/>
<vertex x="8.79" y="8.16"/>
<vertex x="8.84" y="8.14"/>
<vertex x="8.88" y="8.1"/>
<vertex x="8.92" y="8.06"/>
<vertex x="8.95" y="8.02"/>
<vertex x="8.98" y="7.97"/>
<vertex x="9.01" y="7.92"/>
<vertex x="9.03" y="7.87"/>
<vertex x="9.05" y="7.81"/>
<vertex x="9.07" y="7.75"/>
<vertex x="9.08" y="7.69"/>
<vertex x="9.09" y="7.63"/>
<vertex x="9.09" y="7.57"/>
<vertex x="9.1" y="7.52"/>
<vertex x="9.87" y="7.52"/>
<vertex x="9.87" y="7.67"/>
<vertex x="9.86" y="7.81"/>
<vertex x="9.83" y="7.94"/>
<vertex x="9.8" y="8.06"/>
<vertex x="9.76" y="8.18"/>
<vertex x="9.71" y="8.28"/>
<vertex x="9.65" y="8.38"/>
<vertex x="9.58" y="8.46"/>
<vertex x="9.49" y="8.54"/>
<vertex x="9.4" y="8.6"/>
<vertex x="9.3" y="8.66"/>
<vertex x="9.19" y="8.71"/>
<vertex x="9.06" y="8.74"/>
<vertex x="8.93" y="8.77"/>
<vertex x="8.78" y="8.78"/>
<vertex x="8.62" y="8.79"/>
<vertex x="8.44" y="8.78"/>
<vertex x="8.27" y="8.76"/>
<vertex x="8.12" y="8.72"/>
<vertex x="7.98" y="8.66"/>
<vertex x="7.85" y="8.59"/>
<vertex x="7.74" y="8.5"/>
<vertex x="7.65" y="8.4"/>
<vertex x="7.56" y="8.28"/>
<vertex x="7.49" y="8.14"/>
<vertex x="7.43" y="7.99"/>
<vertex x="7.38" y="7.82"/>
<vertex x="7.35" y="7.64"/>
<vertex x="7.32" y="7.44"/>
<vertex x="7.3" y="7.22"/>
<vertex x="7.28" y="6.99"/>
<vertex x="7.28" y="6.74"/>
<vertex x="7.28" y="6.48"/>
<vertex x="7.29" y="6.24"/>
<vertex x="7.3" y="6.02"/>
<vertex x="7.33" y="5.81"/>
<vertex x="7.35" y="5.61"/>
<vertex x="7.39" y="5.44"/>
<vertex x="7.44" y="5.28"/>
<vertex x="7.5" y="5.14"/>
<vertex x="7.57" y="5.01"/>
<vertex x="7.65" y="4.9"/>
<vertex x="7.75" y="4.81"/>
<vertex x="7.86" y="4.73"/>
<vertex x="7.98" y="4.67"/>
<vertex x="8.12" y="4.63"/>
<vertex x="8.28" y="4.6"/>
</polygon>
<vertex x="11.67" y="8.15"/>
<vertex x="11.68" y="8.15"/>
<vertex x="11.69" y="8.15"/>
<vertex x="11.7" y="8.15"/>
<vertex x="11.71" y="8.15"/>
<vertex x="11.72" y="8.15"/>
<vertex x="11.73" y="8.15"/>
<vertex x="11.82" y="8.15"/>
<vertex x="11.89" y="8.13"/>
<vertex x="11.96" y="8.11"/>
<vertex x="12.02" y="8.07"/>
<vertex x="12.08" y="8.02"/>
<vertex x="12.12" y="7.96"/>
<vertex x="12.16" y="7.89"/>
<vertex x="12.19" y="7.81"/>
<vertex x="12.22" y="7.71"/>
<vertex x="12.25" y="7.6"/>
<vertex x="12.26" y="7.48"/>
<vertex x="12.28" y="7.35"/>
<vertex x="12.29" y="7.2"/>
<vertex x="12.3" y="7.04"/>
<vertex x="12.3" y="6.86"/>
<vertex x="12.3" y="6.67"/>
<vertex x="12.3" y="6.47"/>
<vertex x="12.3" y="6.29"/>
<vertex x="12.29" y="6.13"/>
<vertex x="12.28" y="5.98"/>
<vertex x="12.27" y="5.84"/>
<vertex x="12.25" y="5.72"/>
<vertex x="12.23" y="5.61"/>
<vertex x="12.2" y="5.52"/>
<vertex x="12.17" y="5.44"/>
<vertex x="12.13" y="5.37"/>
<vertex x="12.09" y="5.31"/>
<vertex x="12.03" y="5.26"/>
<vertex x="11.97" y="5.23"/>
<vertex x="11.9" y="5.2"/>
<vertex x="11.82" y="5.19"/>
<vertex x="11.73" y="5.18"/>
<vertex x="11.72" y="5.18"/>
<vertex x="11.71" y="5.18"/>
<vertex x="11.7" y="5.18"/>
<vertex x="11.69" y="5.18"/>
<vertex x="11.68" y="5.19"/>
<vertex x="11.67" y="5.19"/>
<vertex x="11.67" y="4.6"/>
<vertex x="11.68" y="4.6"/>
<vertex x="11.68" y="4.59"/>
<vertex x="11.69" y="4.59"/>
<vertex x="11.7" y="4.59"/>
<vertex x="11.71" y="4.59"/>
<vertex x="11.72" y="4.59"/>
<vertex x="11.73" y="4.59"/>
<vertex x="11.95" y="4.6"/>
<vertex x="12.15" y="4.63"/>
<vertex x="12.32" y="4.68"/>
<vertex x="12.47" y="4.75"/>
<vertex x="12.59" y="4.83"/>
<vertex x="12.71" y="4.94"/>
<vertex x="12.8" y="5.05"/>
<vertex x="12.88" y="5.18"/>
<vertex x="12.94" y="5.33"/>
<vertex x="12.99" y="5.49"/>
<vertex x="13.03" y="5.66"/>
<vertex x="13.06" y="5.85"/>
<vertex x="13.08" y="6.04"/>
<vertex x="13.09" y="6.25"/>
<vertex x="13.1" y="6.47"/>
<vertex x="13.1" y="6.69"/>
<vertex x="13.1" y="6.92"/>
<vertex x="13.09" y="7.13"/>
<vertex x="13.08" y="7.34"/>
<vertex x="13.06" y="7.54"/>
<vertex x="13.03" y="7.72"/>
<vertex x="12.99" y="7.89"/>
<vertex x="12.94" y="8.05"/>
<vertex x="12.88" y="8.2"/>
<vertex x="12.8" y="8.33"/>
<vertex x="12.71" y="8.45"/>
<vertex x="12.59" y="8.55"/>
<vertex x="12.47" y="8.63"/>
<vertex x="12.32" y="8.7"/>
<vertex x="12.15" y="8.75"/>
<vertex x="11.95" y="8.78"/>
<vertex x="11.73" y="8.79"/>
<vertex x="11.72" y="8.79"/>
<vertex x="11.71" y="8.79"/>
<vertex x="11.7" y="8.79"/>
<vertex x="11.69" y="8.79"/>
<vertex x="11.68" y="8.79"/>
<vertex x="11.67" y="8.79"/>
</polygon>
<vertex x="11.6" y="5.2"/>
<vertex x="11.53" y="5.22"/>
<vertex x="11.47" y="5.25"/>
<vertex x="11.42" y="5.29"/>
<vertex x="11.37" y="5.34"/>
<vertex x="11.33" y="5.4"/>
<vertex x="11.29" y="5.47"/>
<vertex x="11.26" y="5.55"/>
<vertex x="11.24" y="5.65"/>
<vertex x="11.22" y="5.75"/>
<vertex x="11.2" y="5.87"/>
<vertex x="11.19" y="6"/>
<vertex x="11.18" y="6.15"/>
<vertex x="11.17" y="6.31"/>
<vertex x="11.17" y="6.48"/>
<vertex x="11.17" y="6.67"/>
<vertex x="11.17" y="6.86"/>
<vertex x="11.17" y="7.03"/>
<vertex x="11.18" y="7.19"/>
<vertex x="11.19" y="7.33"/>
<vertex x="11.2" y="7.47"/>
<vertex x="11.21" y="7.58"/>
<vertex x="11.23" y="7.69"/>
<vertex x="11.26" y="7.79"/>
<vertex x="11.29" y="7.87"/>
<vertex x="11.32" y="7.94"/>
<vertex x="11.36" y="8"/>
<vertex x="11.41" y="8.05"/>
<vertex x="11.46" y="8.09"/>
<vertex x="11.53" y="8.12"/>
<vertex x="11.6" y="8.14"/>
<vertex x="11.46" y="8.77"/>
<vertex x="11.28" y="8.74"/>
<vertex x="11.12" y="8.69"/>
<vertex x="10.98" y="8.62"/>
<vertex x="10.85" y="8.53"/>
<vertex x="10.75" y="8.43"/>
<vertex x="10.66" y="8.31"/>
<vertex x="10.58" y="8.18"/>
<vertex x="10.52" y="8.03"/>
<vertex x="10.47" y="7.88"/>
<vertex x="10.44" y="7.71"/>
<vertex x="10.41" y="7.52"/>
<vertex x="10.39" y="7.33"/>
<vertex x="10.38" y="7.13"/>
<vertex x="10.37" y="6.91"/>
<vertex x="10.37" y="6.69"/>
<vertex x="10.37" y="6.47"/>
<vertex x="10.38" y="6.26"/>
<vertex x="10.39" y="6.05"/>
<vertex x="10.41" y="5.86"/>
<vertex x="10.44" y="5.68"/>
<vertex x="10.47" y="5.51"/>
<vertex x="10.52" y="5.35"/>
<vertex x="10.58" y="5.2"/>
<vertex x="10.66" y="5.07"/>
<vertex x="10.75" y="4.95"/>
<vertex x="10.85" y="4.85"/>
<vertex x="10.98" y="4.77"/>
<vertex x="11.12" y="4.7"/>
<vertex x="11.28" y="4.64"/>
<vertex x="11.47" y="4.61"/>
</polygon>
<vertex x="14.33" y="7.87"/>
<vertex x="14.35" y="7.87"/>
<vertex x="15.06" y="4.67"/>
<vertex x="15.69" y="4.67"/>
<vertex x="16.4" y="7.87"/>
<vertex x="16.4" y="4.67"/>
<vertex x="17.15" y="4.67"/>
<vertex x="17.15" y="8.67"/>
<vertex x="15.95" y="8.67"/>
<vertex x="15.36" y="5.84"/>
<vertex x="14.8" y="8.67"/>
<vertex x="13.6" y="8.67"/>
<vertex x="13.6" y="4.67"/>
<vertex x="14.33" y="4.67"/>
</polygon>
<vertex x="18.92" y="7.51"/>
<vertex x="19.02" y="7.99"/>
<vertex x="19.12" y="7.51"/>
<vertex x="19.82" y="7.51"/>
<vertex x="19.51" y="8.67"/>
<vertex x="18.52" y="8.67"/>
<vertex x="18.21" y="7.51"/>
</polygon>
<vertex x="19.42" y="6.17"/>
<vertex x="18.64" y="6.17"/>
<vertex x="17.46" y="4.67"/>
<vertex x="18.31" y="4.67"/>
<vertex x="18.47" y="5.51"/>
<vertex x="19.53" y="5.51"/>
<vertex x="19.72" y="4.67"/>
<vertex x="20.57" y="4.67"/>
</polygon>
<vertex x="21.21" y="4.67"/>
<vertex x="22.03" y="4.67"/>
<vertex x="22.03" y="8.01"/>
<vertex x="22.9" y="8.01"/>
<vertex x="22.9" y="8.67"/>
<vertex x="20.34" y="8.67"/>
<vertex x="20.34" y="8.01"/>
<vertex x="21.21" y="8.01"/>
</polygon>
<vertex x="23.28" y="8.67"/>
<vertex x="24.08" y="8.67"/>
<vertex x="24.08" y="4.67"/>
<vertex x="23.28" y="4.67"/>
</polygon>
<vertex x="25.99" y="4.59"/>
<vertex x="26.18" y="4.6"/>
<vertex x="26.35" y="4.63"/>
<vertex x="26.5" y="4.67"/>
<vertex x="26.64" y="4.73"/>
<vertex x="26.76" y="4.8"/>
<vertex x="26.86" y="4.88"/>
<vertex x="26.95" y="4.97"/>
<vertex x="27.02" y="5.08"/>
<vertex x="27.09" y="5.19"/>
<vertex x="27.14" y="5.32"/>
<vertex x="27.18" y="5.45"/>
<vertex x="27.21" y="5.59"/>
<vertex x="27.24" y="5.73"/>
<vertex x="27.25" y="5.88"/>
<vertex x="27.26" y="6.04"/>
<vertex x="27.26" y="6.2"/>
<vertex x="26.46" y="6.2"/>
<vertex x="26.46" y="6.04"/>
<vertex x="26.45" y="5.9"/>
<vertex x="26.44" y="5.78"/>
<vertex x="26.42" y="5.67"/>
<vertex x="26.4" y="5.58"/>
<vertex x="26.38" y="5.49"/>
<vertex x="26.35" y="5.42"/>
<vertex x="26.32" y="5.36"/>
<vertex x="26.29" y="5.31"/>
<vertex x="26.25" y="5.27"/>
<vertex x="26.21" y="5.24"/>
<vertex x="26.16" y="5.22"/>
<vertex x="26.12" y="5.2"/>
<vertex x="26.07" y="5.19"/>
<vertex x="26.02" y="5.19"/>
<vertex x="25.97" y="5.18"/>
<vertex x="25.9" y="5.19"/>
<vertex x="25.84" y="5.19"/>
<vertex x="25.79" y="5.21"/>
<vertex x="25.74" y="5.24"/>
<vertex x="25.69" y="5.27"/>
<vertex x="25.65" y="5.32"/>
<vertex x="25.61" y="5.37"/>
<vertex x="25.58" y="5.44"/>
<vertex x="25.55" y="5.53"/>
<vertex x="25.52" y="5.63"/>
<vertex x="25.5" y="5.75"/>
<vertex x="25.48" y="5.88"/>
<vertex x="25.47" y="6.03"/>
<vertex x="25.46" y="6.21"/>
<vertex x="25.45" y="6.4"/>
<vertex x="25.45" y="6.62"/>
<vertex x="25.45" y="6.83"/>
<vertex x="25.45" y="7.01"/>
<vertex x="25.46" y="7.19"/>
<vertex x="25.47" y="7.34"/>
<vertex x="25.48" y="7.48"/>
<vertex x="25.5" y="7.61"/>
<vertex x="25.52" y="7.72"/>
<vertex x="25.55" y="7.82"/>
<vertex x="25.58" y="7.91"/>
<vertex x="25.61" y="7.98"/>
<vertex x="25.65" y="8.04"/>
<vertex x="25.7" y="8.09"/>
<vertex x="25.75" y="8.13"/>
<vertex x="25.81" y="8.16"/>
<vertex x="25.87" y="8.17"/>
<vertex x="25.94" y="8.18"/>
<vertex x="26.01" y="8.17"/>
<vertex x="26.07" y="8.16"/>
<vertex x="26.13" y="8.15"/>
<vertex x="26.18" y="8.13"/>
<vertex x="26.23" y="8.1"/>
<vertex x="26.27" y="8.06"/>
<vertex x="26.3" y="8.02"/>
<vertex x="26.33" y="7.97"/>
<vertex x="26.36" y="7.92"/>
<vertex x="26.38" y="7.86"/>
<vertex x="26.4" y="7.79"/>
<vertex x="26.41" y="7.71"/>
<vertex x="26.43" y="7.63"/>
<vertex x="26.43" y="7.53"/>
<vertex x="26.44" y="7.43"/>
<vertex x="26.44" y="7.33"/>
<vertex x="27.24" y="7.33"/>
<vertex x="27.24" y="7.44"/>
<vertex x="27.23" y="7.56"/>
<vertex x="27.22" y="7.68"/>
<vertex x="27.21" y="7.8"/>
<vertex x="27.18" y="7.92"/>
<vertex x="27.15" y="8.04"/>
<vertex x="27.1" y="8.16"/>
<vertex x="27.05" y="8.27"/>
<vertex x="26.98" y="8.37"/>
<vertex x="26.89" y="8.47"/>
<vertex x="26.79" y="8.55"/>
<vertex x="26.67" y="8.62"/>
<vertex x="26.53" y="8.68"/>
<vertex x="26.38" y="8.73"/>
<vertex x="26.19" y="8.76"/>
<vertex x="25.99" y="8.77"/>
<vertex x="25.77" y="8.76"/>
<vertex x="25.58" y="8.73"/>
<vertex x="25.41" y="8.68"/>
<vertex x="25.26" y="8.61"/>
<vertex x="25.13" y="8.53"/>
<vertex x="25.02" y="8.42"/>
<vertex x="24.93" y="8.31"/>
<vertex x="24.85" y="8.18"/>
<vertex x="24.78" y="8.03"/>
<vertex x="24.73" y="7.87"/>
<vertex x="24.69" y="7.7"/>
<vertex x="24.67" y="7.51"/>
<vertex x="24.65" y="7.32"/>
<vertex x="24.63" y="7.11"/>
<vertex x="24.63" y="6.89"/>
<vertex x="24.62" y="6.67"/>
<vertex x="24.63" y="6.44"/>
<vertex x="24.63" y="6.23"/>
<vertex x="24.65" y="6.02"/>
<vertex x="24.67" y="5.83"/>
<vertex x="24.69" y="5.64"/>
<vertex x="24.73" y="5.47"/>
<vertex x="24.78" y="5.32"/>
<vertex x="24.85" y="5.17"/>
<vertex x="24.93" y="5.04"/>
<vertex x="25.02" y="4.93"/>
<vertex x="25.13" y="4.83"/>
<vertex x="25.26" y="4.75"/>
<vertex x="25.41" y="4.68"/>
<vertex x="25.58" y="4.63"/>
<vertex x="25.77" y="4.6"/>
</polygon>
</package>
<package name="GESTURESENSE_TEXT">
<polygon width="0.075" layer="21">
<vertex x="6.68" y="1.51"/>
<vertex x="6.65" y="1.51"/>
<vertex x="6.62" y="1.5"/>
<vertex x="6.59" y="1.5"/>
<vertex x="6.57" y="1.49"/>
<vertex x="6.54" y="1.48"/>
<vertex x="6.52" y="1.47"/>
<vertex x="6.5" y="1.45"/>
<vertex x="6.48" y="1.43"/>
<vertex x="6.46" y="1.42"/>
<vertex x="6.44" y="1.4"/>
<vertex x="6.43" y="1.37"/>
<vertex x="6.42" y="1.35"/>
<vertex x="6.41" y="1.32"/>
<vertex x="6.4" y="1.3"/>
<vertex x="6.4" y="1.27"/>
<vertex x="6.39" y="1.24"/>
<vertex x="6.4" y="1.19"/>
<vertex x="6.41" y="1.14"/>
<vertex x="6.43" y="1.11"/>
<vertex x="6.46" y="1.07"/>
<vertex x="6.49" y="1.05"/>
<vertex x="6.53" y="1.03"/>
<vertex x="6.57" y="1.01"/>
<vertex x="6.61" y="0.99"/>
<vertex x="6.65" y="0.97"/>
<vertex x="6.69" y="0.95"/>
<vertex x="6.72" y="0.94"/>
<vertex x="6.76" y="0.92"/>
<vertex x="6.78" y="0.89"/>
<vertex x="6.81" y="0.87"/>
<vertex x="6.82" y="0.84"/>
<vertex x="6.82" y="0.8"/>
<vertex x="6.82" y="0.78"/>
<vertex x="6.82" y="0.77"/>
<vertex x="6.82" y="0.75"/>
<vertex x="6.81" y="0.74"/>
<vertex x="6.81" y="0.73"/>
<vertex x="6.8" y="0.72"/>
<vertex x="6.79" y="0.7"/>
<vertex x="6.78" y="0.69"/>
<vertex x="6.77" y="0.69"/>
<vertex x="6.76" y="0.68"/>
<vertex x="6.74" y="0.67"/>
<vertex x="6.73" y="0.67"/>
<vertex x="6.72" y="0.66"/>
<vertex x="6.7" y="0.66"/>
<vertex x="6.69" y="0.66"/>
<vertex x="6.67" y="0.65"/>
<vertex x="6.65" y="0.66"/>
<vertex x="6.63" y="0.66"/>
<vertex x="6.62" y="0.66"/>
<vertex x="6.6" y="0.67"/>
<vertex x="6.59" y="0.67"/>
<vertex x="6.57" y="0.68"/>
<vertex x="6.56" y="0.69"/>
<vertex x="6.55" y="0.7"/>
<vertex x="6.54" y="0.71"/>
<vertex x="6.53" y="0.72"/>
<vertex x="6.52" y="0.73"/>
<vertex x="6.51" y="0.74"/>
<vertex x="6.5" y="0.76"/>
<vertex x="6.49" y="0.77"/>
<vertex x="6.48" y="0.79"/>
<vertex x="6.48" y="0.81"/>
<vertex x="6.33" y="0.75"/>
<vertex x="6.34" y="0.72"/>
<vertex x="6.35" y="0.69"/>
<vertex x="6.37" y="0.67"/>
<vertex x="6.38" y="0.64"/>
<vertex x="6.4" y="0.62"/>
<vertex x="6.42" y="0.6"/>
<vertex x="6.44" y="0.59"/>
<vertex x="6.46" y="0.57"/>
<vertex x="6.48" y="0.55"/>
<vertex x="6.5" y="0.54"/>
<vertex x="6.53" y="0.53"/>
<vertex x="6.56" y="0.52"/>
<vertex x="6.58" y="0.51"/>
<vertex x="6.61" y="0.51"/>
<vertex x="6.64" y="0.51"/>
<vertex x="6.67" y="0.5"/>
<vertex x="6.7" y="0.51"/>
<vertex x="6.73" y="0.51"/>
<vertex x="6.76" y="0.52"/>
<vertex x="6.79" y="0.53"/>
<vertex x="6.82" y="0.54"/>
<vertex x="6.85" y="0.55"/>
<vertex x="6.87" y="0.57"/>
<vertex x="6.9" y="0.59"/>
<vertex x="6.92" y="0.61"/>
<vertex x="6.94" y="0.64"/>
<vertex x="6.95" y="0.66"/>
<vertex x="6.96" y="0.69"/>
<vertex x="6.98" y="0.72"/>
<vertex x="6.98" y="0.75"/>
<vertex x="6.99" y="0.78"/>
<vertex x="6.99" y="0.81"/>
<vertex x="6.99" y="0.84"/>
<vertex x="6.99" y="0.87"/>
<vertex x="6.98" y="0.9"/>
<vertex x="6.97" y="0.92"/>
<vertex x="6.96" y="0.94"/>
<vertex x="6.95" y="0.96"/>
<vertex x="6.94" y="0.98"/>
<vertex x="6.92" y="0.99"/>
<vertex x="6.91" y="1.01"/>
<vertex x="6.89" y="1.02"/>
<vertex x="6.87" y="1.04"/>
<vertex x="6.85" y="1.05"/>
<vertex x="6.83" y="1.06"/>
<vertex x="6.81" y="1.07"/>
<vertex x="6.79" y="1.08"/>
<vertex x="6.77" y="1.09"/>
<vertex x="6.75" y="1.1"/>
<vertex x="6.73" y="1.11"/>
<vertex x="6.71" y="1.11"/>
<vertex x="6.69" y="1.12"/>
<vertex x="6.67" y="1.13"/>
<vertex x="6.65" y="1.14"/>
<vertex x="6.63" y="1.15"/>
<vertex x="6.62" y="1.16"/>
<vertex x="6.6" y="1.17"/>
<vertex x="6.59" y="1.18"/>
<vertex x="6.58" y="1.19"/>
<vertex x="6.57" y="1.2"/>
<vertex x="6.56" y="1.21"/>
<vertex x="6.55" y="1.22"/>
<vertex x="6.55" y="1.24"/>
<vertex x="6.55" y="1.25"/>
<vertex x="6.55" y="1.27"/>
<vertex x="6.55" y="1.28"/>
<vertex x="6.55" y="1.29"/>
<vertex x="6.56" y="1.3"/>
<vertex x="6.56" y="1.31"/>
<vertex x="6.57" y="1.31"/>
<vertex x="6.58" y="1.32"/>
<vertex x="6.59" y="1.33"/>
<vertex x="6.59" y="1.34"/>
<vertex x="6.6" y="1.34"/>
<vertex x="6.61" y="1.35"/>
<vertex x="6.62" y="1.35"/>
<vertex x="6.63" y="1.35"/>
<vertex x="6.64" y="1.36"/>
<vertex x="6.66" y="1.36"/>
<vertex x="6.67" y="1.36"/>
<vertex x="6.68" y="1.36"/>
<vertex x="6.69" y="1.36"/>
<vertex x="6.7" y="1.35"/>
<vertex x="6.71" y="1.35"/>
<vertex x="6.72" y="1.35"/>
<vertex x="6.73" y="1.34"/>
<vertex x="6.74" y="1.34"/>
<vertex x="6.74" y="1.33"/>
<vertex x="6.75" y="1.32"/>
<vertex x="6.76" y="1.32"/>
<vertex x="6.77" y="1.31"/>
<vertex x="6.77" y="1.3"/>
<vertex x="6.78" y="1.29"/>
<vertex x="6.79" y="1.28"/>
<vertex x="6.79" y="1.27"/>
<vertex x="6.8" y="1.26"/>
<vertex x="6.93" y="1.33"/>
<vertex x="6.92" y="1.35"/>
<vertex x="6.91" y="1.37"/>
<vertex x="6.9" y="1.39"/>
<vertex x="6.89" y="1.4"/>
<vertex x="6.88" y="1.42"/>
<vertex x="6.86" y="1.43"/>
<vertex x="6.85" y="1.45"/>
<vertex x="6.83" y="1.46"/>
<vertex x="6.81" y="1.47"/>
<vertex x="6.8" y="1.48"/>
<vertex x="6.78" y="1.49"/>
<vertex x="6.76" y="1.5"/>
<vertex x="6.74" y="1.5"/>
<vertex x="6.72" y="1.51"/>
<vertex x="6.7" y="1.51"/>
</polygon>
<vertex x="10.13" y="1.27"/>
<vertex x="10.12" y="1.26"/>
<vertex x="10.11" y="1.24"/>
<vertex x="10.11" y="1.23"/>
<vertex x="10.1" y="1.21"/>
<vertex x="10.09" y="1.19"/>
<vertex x="10.09" y="1.18"/>
<vertex x="10.08" y="1.16"/>
<vertex x="10.08" y="1.14"/>
<vertex x="10.08" y="1.12"/>
<vertex x="10.07" y="1.11"/>
<vertex x="10.07" y="1.09"/>
<vertex x="10.07" y="1.07"/>
<vertex x="10.07" y="1.05"/>
<vertex x="10.07" y="1.03"/>
<vertex x="10.06" y="1.01"/>
<vertex x="10.06" y="1"/>
<vertex x="10.07" y="0.94"/>
<vertex x="10.07" y="0.9"/>
<vertex x="10.08" y="0.85"/>
<vertex x="10.1" y="0.8"/>
<vertex x="10.12" y="0.76"/>
<vertex x="10.14" y="0.72"/>
<vertex x="10.16" y="0.68"/>
<vertex x="10.19" y="0.65"/>
<vertex x="10.22" y="0.62"/>
<vertex x="10.26" y="0.59"/>
<vertex x="10.3" y="0.56"/>
<vertex x="10.34" y="0.54"/>
<vertex x="10.38" y="0.53"/>
<vertex x="10.43" y="0.51"/>
<vertex x="10.48" y="0.51"/>
<vertex x="10.53" y="0.5"/>
<vertex x="10.57" y="0.51"/>
<vertex x="10.6" y="0.51"/>
<vertex x="10.64" y="0.51"/>
<vertex x="10.67" y="0.52"/>
<vertex x="10.7" y="0.53"/>
<vertex x="10.73" y="0.54"/>
<vertex x="10.76" y="0.56"/>
<vertex x="10.79" y="0.57"/>
<vertex x="10.82" y="0.59"/>
<vertex x="10.84" y="0.61"/>
<vertex x="10.87" y="0.63"/>
<vertex x="10.89" y="0.66"/>
<vertex x="10.91" y="0.68"/>
<vertex x="10.93" y="0.71"/>
<vertex x="10.95" y="0.74"/>
<vertex x="10.97" y="0.77"/>
<vertex x="10.83" y="0.85"/>
<vertex x="10.82" y="0.83"/>
<vertex x="10.81" y="0.81"/>
<vertex x="10.79" y="0.79"/>
<vertex x="10.78" y="0.77"/>
<vertex x="10.77" y="0.76"/>
<vertex x="10.75" y="0.74"/>
<vertex x="10.73" y="0.72"/>
<vertex x="10.72" y="0.71"/>
<vertex x="10.7" y="0.7"/>
<vertex x="10.68" y="0.69"/>
<vertex x="10.66" y="0.68"/>
<vertex x="10.64" y="0.67"/>
<vertex x="10.62" y="0.66"/>
<vertex x="10.59" y="0.66"/>
<vertex x="10.57" y="0.66"/>
<vertex x="10.54" y="0.65"/>
<vertex x="10.51" y="0.66"/>
<vertex x="10.48" y="0.66"/>
<vertex x="10.45" y="0.67"/>
<vertex x="10.42" y="0.68"/>
<vertex x="10.39" y="0.69"/>
<vertex x="10.36" y="0.71"/>
<vertex x="10.34" y="0.73"/>
<vertex x="10.32" y="0.75"/>
<vertex x="10.3" y="0.77"/>
<vertex x="10.28" y="0.79"/>
<vertex x="10.27" y="0.82"/>
<vertex x="10.25" y="0.85"/>
<vertex x="10.24" y="0.88"/>
<vertex x="10.24" y="0.91"/>
<vertex x="10.23" y="0.94"/>
<vertex x="10.23" y="0.97"/>
<vertex x="10.98" y="0.97"/>
<vertex x="10.98" y="1.02"/>
<vertex x="10.98" y="1.07"/>
<vertex x="10.97" y="1.12"/>
<vertex x="10.96" y="1.17"/>
<vertex x="10.95" y="1.21"/>
<vertex x="10.93" y="1.26"/>
<vertex x="10.91" y="1.3"/>
<vertex x="10.88" y="1.33"/>
<vertex x="10.85" y="1.37"/>
<vertex x="10.82" y="1.4"/>
<vertex x="10.79" y="1.43"/>
<vertex x="10.75" y="1.45"/>
<vertex x="10.71" y="1.47"/>
<vertex x="10.66" y="1.49"/>
<vertex x="10.62" y="1.5"/>
<vertex x="10.56" y="1.51"/>
<vertex x="10.56" y="1.36"/>
<vertex x="10.59" y="1.35"/>
<vertex x="10.61" y="1.35"/>
<vertex x="10.63" y="1.34"/>
<vertex x="10.65" y="1.33"/>
<vertex x="10.67" y="1.32"/>
<vertex x="10.69" y="1.3"/>
<vertex x="10.71" y="1.29"/>
<vertex x="10.73" y="1.27"/>
<vertex x="10.74" y="1.26"/>
<vertex x="10.76" y="1.24"/>
<vertex x="10.77" y="1.22"/>
<vertex x="10.78" y="1.2"/>
<vertex x="10.79" y="1.18"/>
<vertex x="10.8" y="1.16"/>
<vertex x="10.8" y="1.13"/>
<vertex x="10.81" y="1.11"/>
<vertex x="10.24" y="1.11"/>
<vertex x="10.24" y="1.12"/>
<vertex x="10.24" y="1.13"/>
<vertex x="10.25" y="1.14"/>
<vertex x="10.25" y="1.16"/>
<vertex x="10.25" y="1.17"/>
<vertex x="10.26" y="1.18"/>
<vertex x="10.26" y="1.19"/>
<vertex x="10.27" y="1.2"/>
<vertex x="10.27" y="1.21"/>
<vertex x="10.28" y="1.22"/>
<vertex x="10.29" y="1.23"/>
<vertex x="10.29" y="1.24"/>
<vertex x="10.3" y="1.25"/>
<vertex x="10.31" y="1.25"/>
<vertex x="10.32" y="1.26"/>
<vertex x="10.32" y="1.27"/>
</polygon>
<vertex x="10.33" y="1.28"/>
<vertex x="10.35" y="1.29"/>
<vertex x="10.36" y="1.3"/>
<vertex x="10.37" y="1.31"/>
<vertex x="10.38" y="1.32"/>
<vertex x="10.39" y="1.32"/>
<vertex x="10.41" y="1.33"/>
<vertex x="10.42" y="1.34"/>
<vertex x="10.43" y="1.34"/>
<vertex x="10.44" y="1.35"/>
<vertex x="10.46" y="1.35"/>
<vertex x="10.47" y="1.35"/>
<vertex x="10.49" y="1.36"/>
<vertex x="10.5" y="1.36"/>
<vertex x="10.51" y="1.36"/>
<vertex x="10.53" y="1.36"/>
<vertex x="10.54" y="1.36"/>
<vertex x="10.55" y="1.36"/>
<vertex x="10.55" y="1.51"/>
<vertex x="10.54" y="1.51"/>
<vertex x="10.53" y="1.51"/>
<vertex x="10.49" y="1.51"/>
<vertex x="10.46" y="1.51"/>
<vertex x="10.43" y="1.5"/>
<vertex x="10.39" y="1.49"/>
<vertex x="10.36" y="1.48"/>
<vertex x="10.34" y="1.47"/>
<vertex x="10.31" y="1.46"/>
<vertex x="10.28" y="1.45"/>
<vertex x="10.26" y="1.43"/>
<vertex x="10.24" y="1.41"/>
<vertex x="10.21" y="1.39"/>
<vertex x="10.19" y="1.37"/>
<vertex x="10.18" y="1.35"/>
<vertex x="10.16" y="1.32"/>
<vertex x="10.14" y="1.3"/>
</polygon>
<vertex x="9.72" y="1.27"/>
<vertex x="9.72" y="1.26"/>
<vertex x="9.73" y="1.26"/>
<vertex x="9.74" y="1.27"/>
</polygon>
<vertex x="9.33" y="1.27"/>
<vertex x="9.33" y="1.26"/>
<vertex x="9.33" y="1.25"/>
<vertex x="9.32" y="1.25"/>
<vertex x="9.32" y="1.24"/>
<vertex x="9.33" y="1.19"/>
<vertex x="9.34" y="1.14"/>
<vertex x="9.36" y="1.11"/>
<vertex x="9.39" y="1.07"/>
<vertex x="9.42" y="1.05"/>
<vertex x="9.46" y="1.03"/>
<vertex x="9.5" y="1.01"/>
<vertex x="9.54" y="0.99"/>
<vertex x="9.58" y="0.97"/>
<vertex x="9.62" y="0.95"/>
<vertex x="9.65" y="0.94"/>
<vertex x="9.69" y="0.92"/>
<vertex x="9.71" y="0.89"/>
<vertex x="9.74" y="0.87"/>
<vertex x="9.75" y="0.84"/>
<vertex x="9.75" y="0.8"/>
<vertex x="9.75" y="0.78"/>
<vertex x="9.75" y="0.77"/>
<vertex x="9.75" y="0.75"/>
<vertex x="9.74" y="0.74"/>
<vertex x="9.74" y="0.73"/>
<vertex x="9.73" y="0.72"/>
<vertex x="9.72" y="0.7"/>
<vertex x="9.71" y="0.69"/>
<vertex x="9.7" y="0.69"/>
<vertex x="9.69" y="0.68"/>
<vertex x="9.67" y="0.67"/>
<vertex x="9.66" y="0.67"/>
<vertex x="9.65" y="0.66"/>
<vertex x="9.63" y="0.66"/>
<vertex x="9.62" y="0.66"/>
<vertex x="9.6" y="0.65"/>
<vertex x="9.58" y="0.66"/>
<vertex x="9.56" y="0.66"/>
<vertex x="9.55" y="0.66"/>
<vertex x="9.53" y="0.67"/>
<vertex x="9.52" y="0.67"/>
<vertex x="9.5" y="0.68"/>
<vertex x="9.49" y="0.69"/>
<vertex x="9.48" y="0.7"/>
<vertex x="9.47" y="0.71"/>
<vertex x="9.46" y="0.72"/>
<vertex x="9.45" y="0.73"/>
<vertex x="9.44" y="0.74"/>
<vertex x="9.43" y="0.76"/>
<vertex x="9.42" y="0.77"/>
<vertex x="9.41" y="0.79"/>
<vertex x="9.41" y="0.81"/>
<vertex x="9.26" y="0.75"/>
<vertex x="9.27" y="0.72"/>
<vertex x="9.28" y="0.69"/>
<vertex x="9.3" y="0.67"/>
<vertex x="9.31" y="0.64"/>
<vertex x="9.33" y="0.62"/>
<vertex x="9.35" y="0.6"/>
<vertex x="9.37" y="0.59"/>
<vertex x="9.39" y="0.57"/>
<vertex x="9.41" y="0.55"/>
<vertex x="9.44" y="0.54"/>
<vertex x="9.46" y="0.53"/>
<vertex x="9.49" y="0.52"/>
<vertex x="9.51" y="0.51"/>
<vertex x="9.54" y="0.51"/>
<vertex x="9.57" y="0.51"/>
<vertex x="9.6" y="0.5"/>
<vertex x="9.63" y="0.51"/>
<vertex x="9.66" y="0.51"/>
<vertex x="9.69" y="0.52"/>
<vertex x="9.72" y="0.53"/>
<vertex x="9.75" y="0.54"/>
<vertex x="9.78" y="0.55"/>
<vertex x="9.8" y="0.57"/>
<vertex x="9.83" y="0.59"/>
<vertex x="9.85" y="0.61"/>
<vertex x="9.87" y="0.64"/>
<vertex x="9.88" y="0.66"/>
<vertex x="9.9" y="0.69"/>
<vertex x="9.91" y="0.72"/>
<vertex x="9.91" y="0.75"/>
<vertex x="9.92" y="0.78"/>
<vertex x="9.92" y="0.81"/>
<vertex x="9.92" y="0.84"/>
<vertex x="9.92" y="0.87"/>
<vertex x="9.91" y="0.9"/>
<vertex x="9.9" y="0.92"/>
<vertex x="9.89" y="0.94"/>
<vertex x="9.88" y="0.96"/>
<vertex x="9.87" y="0.98"/>
<vertex x="9.85" y="0.99"/>
<vertex x="9.84" y="1.01"/>
<vertex x="9.82" y="1.02"/>
<vertex x="9.8" y="1.04"/>
<vertex x="9.78" y="1.05"/>
<vertex x="9.76" y="1.06"/>
<vertex x="9.74" y="1.07"/>
<vertex x="9.72" y="1.08"/>
<vertex x="9.7" y="1.09"/>
<vertex x="9.68" y="1.1"/>
<vertex x="9.66" y="1.11"/>
<vertex x="9.64" y="1.11"/>
<vertex x="9.62" y="1.12"/>
<vertex x="9.6" y="1.13"/>
<vertex x="9.58" y="1.14"/>
<vertex x="9.56" y="1.15"/>
<vertex x="9.55" y="1.16"/>
<vertex x="9.53" y="1.17"/>
<vertex x="9.52" y="1.18"/>
<vertex x="9.51" y="1.19"/>
<vertex x="9.5" y="1.2"/>
<vertex x="9.49" y="1.21"/>
<vertex x="9.48" y="1.22"/>
<vertex x="9.48" y="1.24"/>
<vertex x="9.48" y="1.25"/>
<vertex x="9.48" y="1.26"/>
<vertex x="9.48" y="1.27"/>
</polygon>
<vertex x="9.49" y="1.28"/>
<vertex x="9.49" y="1.29"/>
<vertex x="9.49" y="1.3"/>
<vertex x="9.5" y="1.31"/>
<vertex x="9.51" y="1.32"/>
<vertex x="9.52" y="1.33"/>
<vertex x="9.53" y="1.34"/>
<vertex x="9.54" y="1.35"/>
<vertex x="9.55" y="1.35"/>
<vertex x="9.56" y="1.35"/>
<vertex x="9.57" y="1.36"/>
<vertex x="9.58" y="1.36"/>
<vertex x="9.59" y="1.36"/>
<vertex x="9.6" y="1.36"/>
<vertex x="9.61" y="1.36"/>
<vertex x="9.62" y="1.36"/>
<vertex x="9.63" y="1.36"/>
<vertex x="9.64" y="1.35"/>
<vertex x="9.65" y="1.34"/>
<vertex x="9.66" y="1.34"/>
<vertex x="9.67" y="1.33"/>
<vertex x="9.68" y="1.33"/>
<vertex x="9.69" y="1.32"/>
<vertex x="9.69" y="1.31"/>
<vertex x="9.7" y="1.31"/>
<vertex x="9.7" y="1.3"/>
<vertex x="9.71" y="1.29"/>
<vertex x="9.72" y="1.28"/>
<vertex x="9.86" y="1.33"/>
<vertex x="9.85" y="1.35"/>
<vertex x="9.84" y="1.37"/>
<vertex x="9.83" y="1.39"/>
<vertex x="9.82" y="1.4"/>
<vertex x="9.81" y="1.42"/>
<vertex x="9.79" y="1.43"/>
<vertex x="9.78" y="1.45"/>
<vertex x="9.76" y="1.46"/>
<vertex x="9.74" y="1.47"/>
<vertex x="9.73" y="1.48"/>
<vertex x="9.71" y="1.49"/>
<vertex x="9.69" y="1.5"/>
<vertex x="9.67" y="1.5"/>
<vertex x="9.65" y="1.51"/>
<vertex x="9.63" y="1.51"/>
<vertex x="9.61" y="1.51"/>
<vertex x="9.58" y="1.51"/>
<vertex x="9.56" y="1.51"/>
<vertex x="9.53" y="1.5"/>
<vertex x="9.51" y="1.49"/>
<vertex x="9.48" y="1.48"/>
<vertex x="9.46" y="1.47"/>
<vertex x="9.44" y="1.46"/>
<vertex x="9.42" y="1.44"/>
<vertex x="9.4" y="1.43"/>
<vertex x="9.39" y="1.41"/>
<vertex x="9.37" y="1.39"/>
<vertex x="9.36" y="1.37"/>
<vertex x="9.35" y="1.35"/>
<vertex x="9.34" y="1.32"/>
<vertex x="9.33" y="1.3"/>
</polygon>
<vertex x="8.84" y="1.27"/>
<vertex x="8.85" y="1.26"/>
<vertex x="8.85" y="1.25"/>
<vertex x="8.85" y="1.24"/>
<vertex x="8.86" y="1.23"/>
<vertex x="8.86" y="1.22"/>
<vertex x="8.86" y="1.2"/>
<vertex x="8.86" y="1.19"/>
<vertex x="8.87" y="1.18"/>
<vertex x="8.87" y="1.17"/>
<vertex x="8.87" y="1.15"/>
<vertex x="8.87" y="1.14"/>
<vertex x="8.87" y="1.12"/>
<vertex x="8.87" y="1.11"/>
<vertex x="8.87" y="1.1"/>
<vertex x="8.87" y="1.08"/>
<vertex x="8.87" y="1.07"/>
<vertex x="8.87" y="0.53"/>
<vertex x="9.03" y="0.53"/>
<vertex x="9.03" y="1.1"/>
<vertex x="9.03" y="1.11"/>
<vertex x="9.03" y="1.12"/>
<vertex x="9.03" y="1.13"/>
<vertex x="9.03" y="1.14"/>
<vertex x="9.03" y="1.15"/>
<vertex x="9.03" y="1.16"/>
<vertex x="9.03" y="1.18"/>
<vertex x="9.03" y="1.19"/>
<vertex x="9.03" y="1.2"/>
<vertex x="9.03" y="1.21"/>
<vertex x="9.02" y="1.22"/>
<vertex x="9.02" y="1.23"/>
<vertex x="9.02" y="1.24"/>
<vertex x="9.02" y="1.25"/>
<vertex x="9.02" y="1.26"/>
<vertex x="9.01" y="1.27"/>
</polygon>
<vertex x="8.27" y="1.27"/>
<vertex x="8.27" y="0.53"/>
<vertex x="8.43" y="0.53"/>
<vertex x="8.43" y="0.98"/>
<vertex x="8.43" y="1"/>
<vertex x="8.43" y="1.02"/>
<vertex x="8.43" y="1.04"/>
<vertex x="8.44" y="1.06"/>
<vertex x="8.44" y="1.08"/>
<vertex x="8.44" y="1.1"/>
<vertex x="8.44" y="1.12"/>
<vertex x="8.44" y="1.14"/>
<vertex x="8.45" y="1.16"/>
<vertex x="8.45" y="1.17"/>
<vertex x="8.45" y="1.19"/>
<vertex x="8.46" y="1.21"/>
<vertex x="8.47" y="1.23"/>
<vertex x="8.47" y="1.24"/>
<vertex x="8.48" y="1.26"/>
<vertex x="8.49" y="1.27"/>
</polygon>
<vertex x="8.5" y="1.28"/>
<vertex x="8.5" y="1.29"/>
<vertex x="8.51" y="1.3"/>
<vertex x="8.52" y="1.31"/>
<vertex x="8.53" y="1.32"/>
<vertex x="8.54" y="1.32"/>
<vertex x="8.55" y="1.33"/>
<vertex x="8.56" y="1.34"/>
<vertex x="8.57" y="1.34"/>
<vertex x="8.58" y="1.35"/>
<vertex x="8.59" y="1.35"/>
<vertex x="8.61" y="1.35"/>
<vertex x="8.62" y="1.36"/>
<vertex x="8.64" y="1.36"/>
<vertex x="8.65" y="1.36"/>
<vertex x="8.67" y="1.36"/>
<vertex x="8.69" y="1.36"/>
<vertex x="8.7" y="1.36"/>
<vertex x="8.72" y="1.36"/>
<vertex x="8.73" y="1.35"/>
<vertex x="8.75" y="1.35"/>
<vertex x="8.76" y="1.35"/>
<vertex x="8.77" y="1.34"/>
<vertex x="8.78" y="1.34"/>
<vertex x="8.79" y="1.33"/>
<vertex x="8.8" y="1.32"/>
<vertex x="8.81" y="1.32"/>
<vertex x="8.82" y="1.31"/>
<vertex x="8.82" y="1.3"/>
<vertex x="8.83" y="1.29"/>
<vertex x="8.84" y="1.28"/>
<vertex x="9.01" y="1.3"/>
<vertex x="9" y="1.32"/>
<vertex x="8.99" y="1.35"/>
<vertex x="8.98" y="1.37"/>
<vertex x="8.97" y="1.39"/>
<vertex x="8.95" y="1.41"/>
<vertex x="8.94" y="1.43"/>
<vertex x="8.92" y="1.44"/>
<vertex x="8.9" y="1.46"/>
<vertex x="8.88" y="1.47"/>
<vertex x="8.86" y="1.48"/>
<vertex x="8.83" y="1.49"/>
<vertex x="8.8" y="1.5"/>
<vertex x="8.78" y="1.51"/>
<vertex x="8.74" y="1.51"/>
<vertex x="8.71" y="1.51"/>
<vertex x="8.69" y="1.51"/>
<vertex x="8.67" y="1.51"/>
<vertex x="8.65" y="1.5"/>
<vertex x="8.63" y="1.5"/>
<vertex x="8.61" y="1.5"/>
<vertex x="8.59" y="1.49"/>
<vertex x="8.57" y="1.48"/>
<vertex x="8.55" y="1.47"/>
<vertex x="8.54" y="1.46"/>
<vertex x="8.52" y="1.45"/>
<vertex x="8.51" y="1.44"/>
<vertex x="8.49" y="1.43"/>
<vertex x="8.48" y="1.41"/>
<vertex x="8.46" y="1.4"/>
<vertex x="8.45" y="1.38"/>
<vertex x="8.44" y="1.37"/>
<vertex x="8.43" y="1.37"/>
<vertex x="8.43" y="1.48"/>
<vertex x="8.27" y="1.48"/>
</polygon>
<vertex x="7.2" y="1.27"/>
<vertex x="7.19" y="1.26"/>
<vertex x="7.18" y="1.24"/>
<vertex x="7.18" y="1.23"/>
<vertex x="7.17" y="1.21"/>
<vertex x="7.16" y="1.19"/>
<vertex x="7.16" y="1.18"/>
<vertex x="7.15" y="1.16"/>
<vertex x="7.15" y="1.14"/>
<vertex x="7.15" y="1.12"/>
<vertex x="7.14" y="1.11"/>
<vertex x="7.14" y="1.09"/>
<vertex x="7.14" y="1.07"/>
<vertex x="7.14" y="1.05"/>
<vertex x="7.14" y="1.03"/>
<vertex x="7.13" y="1.01"/>
<vertex x="7.13" y="1"/>
<vertex x="7.14" y="0.94"/>
<vertex x="7.14" y="0.9"/>
<vertex x="7.15" y="0.85"/>
<vertex x="7.17" y="0.8"/>
<vertex x="7.19" y="0.76"/>
<vertex x="7.21" y="0.72"/>
<vertex x="7.23" y="0.68"/>
<vertex x="7.26" y="0.65"/>
<vertex x="7.29" y="0.62"/>
<vertex x="7.33" y="0.59"/>
<vertex x="7.37" y="0.56"/>
<vertex x="7.41" y="0.54"/>
<vertex x="7.45" y="0.53"/>
<vertex x="7.5" y="0.51"/>
<vertex x="7.55" y="0.51"/>
<vertex x="7.6" y="0.5"/>
<vertex x="7.64" y="0.51"/>
<vertex x="7.67" y="0.51"/>
<vertex x="7.71" y="0.51"/>
<vertex x="7.74" y="0.52"/>
<vertex x="7.77" y="0.53"/>
<vertex x="7.8" y="0.54"/>
<vertex x="7.83" y="0.56"/>
<vertex x="7.86" y="0.57"/>
<vertex x="7.89" y="0.59"/>
<vertex x="7.91" y="0.61"/>
<vertex x="7.94" y="0.63"/>
<vertex x="7.96" y="0.66"/>
<vertex x="7.98" y="0.68"/>
<vertex x="8" y="0.71"/>
<vertex x="8.02" y="0.74"/>
<vertex x="8.04" y="0.77"/>
<vertex x="7.9" y="0.85"/>
<vertex x="7.89" y="0.83"/>
<vertex x="7.88" y="0.81"/>
<vertex x="7.86" y="0.79"/>
<vertex x="7.85" y="0.77"/>
<vertex x="7.83" y="0.76"/>
<vertex x="7.82" y="0.74"/>
<vertex x="7.8" y="0.72"/>
<vertex x="7.79" y="0.71"/>
<vertex x="7.77" y="0.7"/>
<vertex x="7.75" y="0.69"/>
<vertex x="7.73" y="0.68"/>
<vertex x="7.71" y="0.67"/>
<vertex x="7.69" y="0.66"/>
<vertex x="7.66" y="0.66"/>
<vertex x="7.64" y="0.66"/>
<vertex x="7.61" y="0.65"/>
<vertex x="7.58" y="0.66"/>
<vertex x="7.55" y="0.66"/>
<vertex x="7.52" y="0.67"/>
<vertex x="7.49" y="0.68"/>
<vertex x="7.46" y="0.69"/>
<vertex x="7.43" y="0.71"/>
<vertex x="7.41" y="0.73"/>
<vertex x="7.39" y="0.75"/>
<vertex x="7.37" y="0.77"/>
<vertex x="7.35" y="0.79"/>
<vertex x="7.34" y="0.82"/>
<vertex x="7.32" y="0.85"/>
<vertex x="7.31" y="0.88"/>
<vertex x="7.31" y="0.91"/>
<vertex x="7.3" y="0.94"/>
<vertex x="7.3" y="0.97"/>
<vertex x="8.05" y="0.97"/>
<vertex x="8.05" y="0.99"/>
<vertex x="8.05" y="1.01"/>
<vertex x="8.05" y="1.03"/>
<vertex x="8.05" y="1.05"/>
<vertex x="8.05" y="1.07"/>
<vertex x="8.04" y="1.09"/>
<vertex x="8.04" y="1.11"/>
<vertex x="8.04" y="1.13"/>
<vertex x="8.03" y="1.15"/>
<vertex x="8.03" y="1.17"/>
<vertex x="8.02" y="1.19"/>
<vertex x="8.02" y="1.2"/>
<vertex x="8.01" y="1.22"/>
<vertex x="8.01" y="1.24"/>
<vertex x="8" y="1.26"/>
<vertex x="7.99" y="1.27"/>
<vertex x="7.8" y="1.27"/>
<vertex x="7.8" y="1.26"/>
<vertex x="7.81" y="1.25"/>
<vertex x="7.82" y="1.25"/>
<vertex x="7.83" y="1.24"/>
<vertex x="7.83" y="1.23"/>
<vertex x="7.84" y="1.22"/>
<vertex x="7.84" y="1.21"/>
<vertex x="7.85" y="1.2"/>
<vertex x="7.85" y="1.19"/>
<vertex x="7.86" y="1.18"/>
<vertex x="7.86" y="1.17"/>
<vertex x="7.87" y="1.16"/>
<vertex x="7.87" y="1.14"/>
<vertex x="7.87" y="1.13"/>
<vertex x="7.88" y="1.12"/>
<vertex x="7.88" y="1.11"/>
<vertex x="7.31" y="1.11"/>
<vertex x="7.31" y="1.12"/>
<vertex x="7.31" y="1.13"/>
<vertex x="7.32" y="1.14"/>
<vertex x="7.32" y="1.16"/>
<vertex x="7.32" y="1.17"/>
<vertex x="7.33" y="1.18"/>
<vertex x="7.33" y="1.19"/>
<vertex x="7.34" y="1.2"/>
<vertex x="7.34" y="1.21"/>
<vertex x="7.35" y="1.22"/>
<vertex x="7.36" y="1.23"/>
<vertex x="7.36" y="1.24"/>
<vertex x="7.37" y="1.25"/>
<vertex x="7.38" y="1.25"/>
<vertex x="7.39" y="1.26"/>
<vertex x="7.39" y="1.27"/>
</polygon>
<vertex x="7.4" y="1.28"/>
<vertex x="7.42" y="1.29"/>
<vertex x="7.43" y="1.3"/>
<vertex x="7.44" y="1.31"/>
<vertex x="7.45" y="1.32"/>
<vertex x="7.46" y="1.32"/>
<vertex x="7.47" y="1.33"/>
<vertex x="7.49" y="1.34"/>
<vertex x="7.5" y="1.34"/>
<vertex x="7.51" y="1.35"/>
<vertex x="7.53" y="1.35"/>
<vertex x="7.54" y="1.35"/>
<vertex x="7.56" y="1.36"/>
<vertex x="7.57" y="1.36"/>
<vertex x="7.58" y="1.36"/>
<vertex x="7.6" y="1.36"/>
<vertex x="7.61" y="1.36"/>
<vertex x="7.63" y="1.36"/>
<vertex x="7.64" y="1.36"/>
<vertex x="7.66" y="1.35"/>
<vertex x="7.67" y="1.35"/>
<vertex x="7.68" y="1.35"/>
<vertex x="7.7" y="1.34"/>
<vertex x="7.71" y="1.34"/>
<vertex x="7.72" y="1.33"/>
<vertex x="7.73" y="1.32"/>
<vertex x="7.74" y="1.32"/>
<vertex x="7.76" y="1.31"/>
<vertex x="7.77" y="1.3"/>
<vertex x="7.78" y="1.29"/>
<vertex x="7.79" y="1.28"/>
<vertex x="7.98" y="1.3"/>
<vertex x="7.96" y="1.32"/>
<vertex x="7.94" y="1.35"/>
<vertex x="7.93" y="1.37"/>
<vertex x="7.91" y="1.39"/>
<vertex x="7.88" y="1.41"/>
<vertex x="7.86" y="1.43"/>
<vertex x="7.84" y="1.44"/>
<vertex x="7.81" y="1.46"/>
<vertex x="7.79" y="1.47"/>
<vertex x="7.76" y="1.48"/>
<vertex x="7.73" y="1.49"/>
<vertex x="7.7" y="1.5"/>
<vertex x="7.66" y="1.51"/>
<vertex x="7.63" y="1.51"/>
<vertex x="7.6" y="1.51"/>
<vertex x="7.56" y="1.51"/>
<vertex x="7.53" y="1.51"/>
<vertex x="7.5" y="1.5"/>
<vertex x="7.46" y="1.49"/>
<vertex x="7.43" y="1.48"/>
<vertex x="7.41" y="1.47"/>
<vertex x="7.38" y="1.46"/>
<vertex x="7.35" y="1.44"/>
<vertex x="7.33" y="1.43"/>
<vertex x="7.31" y="1.41"/>
<vertex x="7.28" y="1.39"/>
<vertex x="7.26" y="1.37"/>
<vertex x="7.25" y="1.35"/>
<vertex x="7.23" y="1.32"/>
<vertex x="7.21" y="1.3"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="7.32" y="4.78"/>
<vertex x="6.52" y="2.81"/>
<vertex x="6.51" y="2.79"/>
<vertex x="6.49" y="2.75"/>
<vertex x="6.45" y="2.69"/>
<vertex x="6.39" y="2.62"/>
<vertex x="6.32" y="2.53"/>
<vertex x="6.23" y="2.44"/>
<vertex x="6.13" y="2.34"/>
<vertex x="6.01" y="2.25"/>
<vertex x="5.87" y="2.16"/>
<vertex x="5.72" y="2.08"/>
<vertex x="5.55" y="2.02"/>
<vertex x="5.36" y="1.98"/>
<vertex x="5.16" y="1.96"/>
<vertex x="4.94" y="1.98"/>
<vertex x="4.71" y="2.02"/>
<vertex x="4.46" y="2.1"/>
<vertex x="4.22" y="2.22"/>
<vertex x="4.02" y="2.35"/>
<vertex x="3.86" y="2.5"/>
<vertex x="3.73" y="2.66"/>
<vertex x="3.63" y="2.83"/>
<vertex x="3.55" y="3"/>
<vertex x="3.5" y="3.17"/>
<vertex x="3.47" y="3.34"/>
<vertex x="3.46" y="3.51"/>
<vertex x="3.46" y="3.66"/>
<vertex x="3.47" y="3.8"/>
<vertex x="3.48" y="3.92"/>
<vertex x="3.5" y="4.02"/>
<vertex x="3.51" y="4.1"/>
<vertex x="3.52" y="4.14"/>
<vertex x="3.53" y="4.16"/>
<vertex x="4.71" y="7.08"/>
<vertex x="4.71" y="7.09"/>
<vertex x="4.72" y="7.11"/>
<vertex x="4.73" y="7.12"/>
<vertex x="4.73" y="7.14"/>
<vertex x="4.75" y="7.17"/>
<vertex x="4.76" y="7.19"/>
<vertex x="4.78" y="7.21"/>
<vertex x="4.8" y="7.23"/>
<vertex x="4.82" y="7.25"/>
<vertex x="4.85" y="7.27"/>
<vertex x="4.88" y="7.28"/>
<vertex x="4.92" y="7.29"/>
<vertex x="4.95" y="7.29"/>
<vertex x="5" y="7.28"/>
<vertex x="5.04" y="7.27"/>
<vertex x="5.09" y="7.24"/>
<vertex x="5.13" y="7.22"/>
<vertex x="5.16" y="7.19"/>
<vertex x="5.18" y="7.16"/>
<vertex x="5.2" y="7.13"/>
<vertex x="5.21" y="7.1"/>
<vertex x="5.22" y="7.07"/>
<vertex x="5.22" y="7.04"/>
<vertex x="5.22" y="7.01"/>
<vertex x="5.21" y="6.99"/>
<vertex x="5.21" y="6.96"/>
<vertex x="5.2" y="6.94"/>
<vertex x="5.19" y="6.92"/>
<vertex x="5.19" y="6.91"/>
<vertex x="5.18" y="6.9"/>
<vertex x="4.56" y="5.37"/>
<vertex x="4.56" y="5.36"/>
<vertex x="4.55" y="5.35"/>
<vertex x="4.55" y="5.34"/>
<vertex x="4.55" y="5.33"/>
<vertex x="4.54" y="5.32"/>
<vertex x="4.54" y="5.31"/>
<vertex x="4.54" y="5.29"/>
<vertex x="4.55" y="5.28"/>
<vertex x="4.55" y="5.27"/>
<vertex x="4.55" y="5.26"/>
<vertex x="4.56" y="5.25"/>
<vertex x="4.57" y="5.24"/>
<vertex x="4.59" y="5.24"/>
<vertex x="4.61" y="5.23"/>
<vertex x="4.63" y="5.22"/>
<vertex x="4.65" y="5.22"/>
<vertex x="4.66" y="5.22"/>
<vertex x="4.68" y="5.22"/>
<vertex x="4.69" y="5.23"/>
<vertex x="4.7" y="5.23"/>
<vertex x="4.7" y="5.24"/>
<vertex x="4.71" y="5.25"/>
<vertex x="4.71" y="5.26"/>
<vertex x="4.72" y="5.26"/>
<vertex x="4.72" y="5.27"/>
<vertex x="4.72" y="5.28"/>
<vertex x="4.72" y="5.29"/>
<vertex x="5.55" y="7.32"/>
<vertex x="5.55" y="7.33"/>
<vertex x="5.56" y="7.33"/>
<vertex x="5.56" y="7.35"/>
<vertex x="5.57" y="7.36"/>
<vertex x="5.58" y="7.38"/>
<vertex x="5.59" y="7.4"/>
<vertex x="5.6" y="7.42"/>
<vertex x="5.62" y="7.44"/>
<vertex x="5.64" y="7.46"/>
<vertex x="5.66" y="7.48"/>
<vertex x="5.69" y="7.5"/>
<vertex x="5.72" y="7.51"/>
<vertex x="5.75" y="7.52"/>
<vertex x="5.79" y="7.52"/>
<vertex x="5.83" y="7.51"/>
<vertex x="5.88" y="7.5"/>
<vertex x="5.92" y="7.48"/>
<vertex x="5.96" y="7.46"/>
<vertex x="5.99" y="7.43"/>
<vertex x="6.01" y="7.41"/>
<vertex x="6.03" y="7.38"/>
<vertex x="6.04" y="7.35"/>
<vertex x="6.05" y="7.33"/>
<vertex x="6.05" y="7.3"/>
<vertex x="6.05" y="7.27"/>
<vertex x="6.05" y="7.25"/>
<vertex x="6.05" y="7.23"/>
<vertex x="6.04" y="7.21"/>
<vertex x="6.04" y="7.2"/>
<vertex x="6.03" y="7.18"/>
<vertex x="6.03" y="7.17"/>
<vertex x="5.19" y="5.11"/>
<vertex x="5.19" y="5.1"/>
<vertex x="5.18" y="5.1"/>
<vertex x="5.18" y="5.09"/>
<vertex x="5.17" y="5.08"/>
<vertex x="5.17" y="5.07"/>
<vertex x="5.17" y="5.05"/>
<vertex x="5.16" y="5.04"/>
<vertex x="5.16" y="5.03"/>
<vertex x="5.16" y="5.02"/>
<vertex x="5.17" y="5"/>
<vertex x="5.17" y="4.99"/>
<vertex x="5.18" y="4.98"/>
<vertex x="5.19" y="4.96"/>
<vertex x="5.21" y="4.95"/>
<vertex x="5.23" y="4.94"/>
<vertex x="5.25" y="4.94"/>
<vertex x="5.27" y="4.93"/>
<vertex x="5.28" y="4.93"/>
<vertex x="5.3" y="4.94"/>
<vertex x="5.31" y="4.94"/>
<vertex x="5.32" y="4.95"/>
<vertex x="5.33" y="4.96"/>
<vertex x="5.34" y="4.96"/>
<vertex x="5.35" y="4.97"/>
<vertex x="5.35" y="4.98"/>
<vertex x="5.36" y="4.99"/>
<vertex x="5.36" y="5"/>
<vertex x="5.37" y="5.01"/>
<vertex x="5.37" y="5.02"/>
<vertex x="6.27" y="7.24"/>
<vertex x="6.27" y="7.25"/>
<vertex x="6.27" y="7.26"/>
<vertex x="6.28" y="7.28"/>
<vertex x="6.29" y="7.29"/>
<vertex x="6.3" y="7.31"/>
<vertex x="6.31" y="7.33"/>
<vertex x="6.33" y="7.35"/>
<vertex x="6.35" y="7.36"/>
<vertex x="6.37" y="7.38"/>
<vertex x="6.4" y="7.39"/>
<vertex x="6.43" y="7.4"/>
<vertex x="6.46" y="7.4"/>
<vertex x="6.5" y="7.4"/>
<vertex x="6.54" y="7.39"/>
<vertex x="6.59" y="7.38"/>
<vertex x="6.63" y="7.36"/>
<vertex x="6.67" y="7.33"/>
<vertex x="6.7" y="7.31"/>
<vertex x="6.72" y="7.29"/>
<vertex x="6.73" y="7.26"/>
<vertex x="6.74" y="7.24"/>
<vertex x="6.75" y="7.21"/>
<vertex x="6.75" y="7.19"/>
<vertex x="6.75" y="7.17"/>
<vertex x="6.75" y="7.15"/>
<vertex x="6.75" y="7.13"/>
<vertex x="6.74" y="7.11"/>
<vertex x="6.73" y="7.1"/>
<vertex x="6.73" y="7.09"/>
<vertex x="6.73" y="7.08"/>
<vertex x="5.82" y="4.86"/>
<vertex x="5.82" y="4.85"/>
<vertex x="5.81" y="4.85"/>
<vertex x="5.81" y="4.84"/>
<vertex x="5.81" y="4.83"/>
<vertex x="5.81" y="4.81"/>
<vertex x="5.81" y="4.8"/>
<vertex x="5.81" y="4.79"/>
<vertex x="5.81" y="4.77"/>
<vertex x="5.81" y="4.76"/>
<vertex x="5.82" y="4.75"/>
<vertex x="5.84" y="4.73"/>
<vertex x="5.85" y="4.72"/>
<vertex x="5.87" y="4.71"/>
<vertex x="5.89" y="4.7"/>
<vertex x="5.91" y="4.69"/>
<vertex x="5.92" y="4.69"/>
<vertex x="5.94" y="4.69"/>
<vertex x="5.95" y="4.7"/>
<vertex x="5.96" y="4.7"/>
<vertex x="5.97" y="4.71"/>
<vertex x="5.98" y="4.72"/>
<vertex x="5.99" y="4.73"/>
<vertex x="5.99" y="4.74"/>
<vertex x="6" y="4.75"/>
<vertex x="6.01" y="4.75"/>
<vertex x="6.01" y="4.76"/>
<vertex x="6.01" y="4.77"/>
<vertex x="6.02" y="4.78"/>
<vertex x="6.78" y="6.67"/>
<vertex x="6.78" y="6.68"/>
<vertex x="6.79" y="6.69"/>
<vertex x="6.79" y="6.7"/>
<vertex x="6.8" y="6.72"/>
<vertex x="6.81" y="6.74"/>
<vertex x="6.83" y="6.76"/>
<vertex x="6.85" y="6.78"/>
<vertex x="6.87" y="6.8"/>
<vertex x="6.89" y="6.82"/>
<vertex x="6.91" y="6.84"/>
<vertex x="6.94" y="6.86"/>
<vertex x="6.97" y="6.87"/>
<vertex x="7.01" y="6.88"/>
<vertex x="7.05" y="6.88"/>
<vertex x="7.09" y="6.87"/>
<vertex x="7.13" y="6.86"/>
<vertex x="7.18" y="6.83"/>
<vertex x="7.21" y="6.81"/>
<vertex x="7.24" y="6.78"/>
<vertex x="7.26" y="6.76"/>
<vertex x="7.27" y="6.73"/>
<vertex x="7.28" y="6.69"/>
<vertex x="7.29" y="6.66"/>
<vertex x="7.29" y="6.63"/>
<vertex x="7.28" y="6.6"/>
<vertex x="7.28" y="6.58"/>
<vertex x="7.27" y="6.55"/>
<vertex x="7.27" y="6.53"/>
<vertex x="7.26" y="6.51"/>
<vertex x="7.26" y="6.5"/>
<vertex x="7.25" y="6.49"/>
<vertex x="6.29" y="4.13"/>
<vertex x="6.29" y="4.12"/>
<vertex x="6.28" y="4.12"/>
<vertex x="6.28" y="4.11"/>
<vertex x="6.27" y="4.1"/>
<vertex x="6.27" y="4.08"/>
<vertex x="6.27" y="4.07"/>
<vertex x="6.26" y="4.06"/>
<vertex x="6.26" y="4.04"/>
<vertex x="6.27" y="4.03"/>
<vertex x="6.27" y="4.01"/>
<vertex x="6.28" y="4"/>
<vertex x="6.29" y="3.98"/>
<vertex x="6.3" y="3.97"/>
<vertex x="6.32" y="3.96"/>
<vertex x="6.35" y="3.95"/>
<vertex x="6.37" y="3.94"/>
<vertex x="6.39" y="3.94"/>
<vertex x="6.41" y="3.93"/>
<vertex x="6.42" y="3.94"/>
<vertex x="6.43" y="3.94"/>
<vertex x="6.44" y="3.95"/>
<vertex x="6.45" y="3.95"/>
<vertex x="6.46" y="3.96"/>
<vertex x="6.47" y="3.97"/>
<vertex x="6.47" y="3.98"/>
<vertex x="6.48" y="3.99"/>
<vertex x="6.48" y="4"/>
<vertex x="6.48" y="4.01"/>
<vertex x="6.49" y="4.01"/>
<vertex x="6.87" y="4.97"/>
<vertex x="6.88" y="4.98"/>
<vertex x="6.88" y="4.99"/>
<vertex x="6.89" y="5.01"/>
<vertex x="6.9" y="5.02"/>
<vertex x="6.91" y="5.04"/>
<vertex x="6.93" y="5.05"/>
<vertex x="6.94" y="5.07"/>
<vertex x="6.96" y="5.09"/>
<vertex x="6.98" y="5.1"/>
<vertex x="7" y="5.11"/>
<vertex x="7.03" y="5.12"/>
<vertex x="7.06" y="5.13"/>
<vertex x="7.09" y="5.13"/>
<vertex x="7.12" y="5.12"/>
<vertex x="7.15" y="5.11"/>
<vertex x="7.2" y="5.09"/>
<vertex x="7.24" y="5.07"/>
<vertex x="7.27" y="5.04"/>
<vertex x="7.29" y="5.02"/>
<vertex x="7.31" y="4.99"/>
<vertex x="7.32" y="4.96"/>
<vertex x="7.33" y="4.93"/>
<vertex x="7.34" y="4.91"/>
<vertex x="7.34" y="4.88"/>
<vertex x="7.34" y="4.86"/>
<vertex x="7.33" y="4.84"/>
<vertex x="7.33" y="4.82"/>
<vertex x="7.33" y="4.8"/>
<vertex x="7.32" y="4.79"/>
</polygon>
<vertex x="7.98" y="3.39"/>
<vertex x="8.03" y="3.43"/>
<vertex x="8.09" y="3.48"/>
<vertex x="8.14" y="3.53"/>
<vertex x="8.19" y="3.59"/>
<vertex x="8.24" y="3.65"/>
<vertex x="8.28" y="3.71"/>
<vertex x="8.32" y="3.78"/>
<vertex x="8.36" y="3.85"/>
<vertex x="8.4" y="3.93"/>
<vertex x="8.43" y="4.01"/>
<vertex x="8.46" y="4.09"/>
<vertex x="8.48" y="4.18"/>
<vertex x="8.51" y="4.26"/>
<vertex x="8.53" y="4.35"/>
<vertex x="8.54" y="4.44"/>
<vertex x="8.55" y="4.54"/>
<vertex x="8.56" y="4.63"/>
<vertex x="8.56" y="4.72"/>
<vertex x="8.56" y="4.81"/>
<vertex x="8.56" y="4.9"/>
<vertex x="8.55" y="4.99"/>
<vertex x="8.54" y="5.07"/>
<vertex x="8.53" y="5.16"/>
<vertex x="8.51" y="5.24"/>
<vertex x="8.49" y="5.32"/>
<vertex x="8.46" y="5.39"/>
<vertex x="8.43" y="5.47"/>
<vertex x="8.4" y="5.54"/>
<vertex x="8.36" y="5.6"/>
<vertex x="8.32" y="5.66"/>
<vertex x="8.28" y="5.72"/>
<vertex x="8.23" y="5.78"/>
<vertex x="8.29" y="5.84"/>
<vertex x="8.36" y="5.77"/>
<vertex x="8.42" y="5.71"/>
<vertex x="8.48" y="5.64"/>
<vertex x="8.53" y="5.56"/>
<vertex x="8.58" y="5.49"/>
<vertex x="8.62" y="5.41"/>
<vertex x="8.66" y="5.33"/>
<vertex x="8.69" y="5.25"/>
<vertex x="8.72" y="5.16"/>
<vertex x="8.74" y="5.07"/>
<vertex x="8.75" y="4.98"/>
<vertex x="8.77" y="4.89"/>
<vertex x="8.77" y="4.8"/>
<vertex x="8.77" y="4.71"/>
<vertex x="8.77" y="4.61"/>
<vertex x="8.76" y="4.52"/>
<vertex x="8.76" y="4.51"/>
<vertex x="8.75" y="4.42"/>
<vertex x="8.73" y="4.32"/>
<vertex x="8.71" y="4.23"/>
<vertex x="8.69" y="4.14"/>
<vertex x="8.66" y="4.05"/>
<vertex x="8.62" y="3.97"/>
<vertex x="8.58" y="3.89"/>
<vertex x="8.54" y="3.81"/>
<vertex x="8.49" y="3.73"/>
<vertex x="8.44" y="3.66"/>
<vertex x="8.38" y="3.59"/>
<vertex x="8.32" y="3.53"/>
<vertex x="8.25" y="3.47"/>
<vertex x="8.18" y="3.41"/>
<vertex x="8.1" y="3.36"/>
<vertex x="8.02" y="3.31"/>
</polygon>
<vertex x="7.42" y="3.84"/>
<vertex x="7.45" y="3.87"/>
<vertex x="7.49" y="3.9"/>
<vertex x="7.52" y="3.93"/>
<vertex x="7.55" y="3.96"/>
<vertex x="7.58" y="4"/>
<vertex x="7.6" y="4.04"/>
<vertex x="7.63" y="4.08"/>
<vertex x="7.65" y="4.13"/>
<vertex x="7.68" y="4.17"/>
<vertex x="7.7" y="4.22"/>
<vertex x="7.71" y="4.27"/>
<vertex x="7.73" y="4.33"/>
<vertex x="7.75" y="4.38"/>
<vertex x="7.76" y="4.43"/>
<vertex x="7.77" y="4.49"/>
<vertex x="7.77" y="4.55"/>
<vertex x="7.78" y="4.6"/>
<vertex x="7.78" y="4.66"/>
<vertex x="7.78" y="4.71"/>
<vertex x="7.78" y="4.77"/>
<vertex x="7.77" y="4.82"/>
<vertex x="7.76" y="4.88"/>
<vertex x="7.75" y="4.93"/>
<vertex x="7.74" y="4.98"/>
<vertex x="7.73" y="5.03"/>
<vertex x="7.71" y="5.07"/>
<vertex x="7.69" y="5.12"/>
<vertex x="7.67" y="5.16"/>
<vertex x="7.65" y="5.2"/>
<vertex x="7.63" y="5.24"/>
<vertex x="7.6" y="5.27"/>
<vertex x="7.57" y="5.31"/>
<vertex x="7.62" y="5.36"/>
<vertex x="7.67" y="5.32"/>
<vertex x="7.72" y="5.28"/>
<vertex x="7.76" y="5.23"/>
<vertex x="7.79" y="5.19"/>
<vertex x="7.83" y="5.14"/>
<vertex x="7.86" y="5.09"/>
<vertex x="7.89" y="5.03"/>
<vertex x="7.91" y="4.98"/>
<vertex x="7.93" y="4.93"/>
<vertex x="7.94" y="4.87"/>
<vertex x="7.96" y="4.82"/>
<vertex x="7.96" y="4.76"/>
<vertex x="7.97" y="4.7"/>
<vertex x="7.97" y="4.64"/>
<vertex x="7.97" y="4.59"/>
<vertex x="7.97" y="4.53"/>
<vertex x="7.97" y="4.52"/>
<vertex x="7.96" y="4.47"/>
<vertex x="7.95" y="4.41"/>
<vertex x="7.93" y="4.35"/>
<vertex x="7.92" y="4.3"/>
<vertex x="7.9" y="4.24"/>
<vertex x="7.87" y="4.19"/>
<vertex x="7.85" y="4.14"/>
<vertex x="7.82" y="4.09"/>
<vertex x="7.78" y="4.04"/>
<vertex x="7.75" y="4"/>
<vertex x="7.71" y="3.96"/>
<vertex x="7.66" y="3.91"/>
<vertex x="7.62" y="3.88"/>
<vertex x="7.57" y="3.84"/>
<vertex x="7.51" y="3.81"/>
<vertex x="7.46" y="3.78"/>
</polygon>
<vertex x="8.48" y="2.9"/>
<vertex x="8.56" y="2.95"/>
<vertex x="8.63" y="3.02"/>
<vertex x="8.7" y="3.09"/>
<vertex x="8.77" y="3.16"/>
<vertex x="8.83" y="3.24"/>
<vertex x="8.89" y="3.33"/>
<vertex x="8.94" y="3.42"/>
<vertex x="9" y="3.52"/>
<vertex x="9.04" y="3.62"/>
<vertex x="9.09" y="3.73"/>
<vertex x="9.13" y="3.84"/>
<vertex x="9.16" y="3.95"/>
<vertex x="9.19" y="4.07"/>
<vertex x="9.21" y="4.18"/>
<vertex x="9.24" y="4.3"/>
<vertex x="9.25" y="4.43"/>
<vertex x="9.26" y="4.55"/>
<vertex x="9.27" y="4.67"/>
<vertex x="9.27" y="4.79"/>
<vertex x="9.26" y="4.91"/>
<vertex x="9.25" y="5.03"/>
<vertex x="9.24" y="5.14"/>
<vertex x="9.22" y="5.25"/>
<vertex x="9.19" y="5.36"/>
<vertex x="9.16" y="5.47"/>
<vertex x="9.13" y="5.57"/>
<vertex x="9.09" y="5.67"/>
<vertex x="9.04" y="5.76"/>
<vertex x="8.99" y="5.85"/>
<vertex x="8.94" y="5.93"/>
<vertex x="8.88" y="6.01"/>
<vertex x="8.82" y="6.08"/>
<vertex x="8.9" y="6.16"/>
<vertex x="8.99" y="6.07"/>
<vertex x="9.07" y="5.99"/>
<vertex x="9.15" y="5.89"/>
<vertex x="9.22" y="5.8"/>
<vertex x="9.29" y="5.7"/>
<vertex x="9.34" y="5.59"/>
<vertex x="9.39" y="5.48"/>
<vertex x="9.43" y="5.37"/>
<vertex x="9.47" y="5.26"/>
<vertex x="9.5" y="5.14"/>
<vertex x="9.52" y="5.02"/>
<vertex x="9.53" y="4.9"/>
<vertex x="9.54" y="4.78"/>
<vertex x="9.54" y="4.66"/>
<vertex x="9.54" y="4.53"/>
<vertex x="9.53" y="4.4"/>
<vertex x="9.51" y="4.27"/>
<vertex x="9.49" y="4.14"/>
<vertex x="9.46" y="4.02"/>
<vertex x="9.43" y="3.9"/>
<vertex x="9.39" y="3.79"/>
<vertex x="9.34" y="3.67"/>
<vertex x="9.29" y="3.56"/>
<vertex x="9.23" y="3.46"/>
<vertex x="9.17" y="3.36"/>
<vertex x="9.1" y="3.26"/>
<vertex x="9.02" y="3.17"/>
<vertex x="8.94" y="3.09"/>
<vertex x="8.85" y="3.01"/>
<vertex x="8.75" y="2.93"/>
<vertex x="8.65" y="2.87"/>
<vertex x="8.54" y="2.8"/>
</polygon>
<vertex x="2.49" y="2.38"/>
<vertex x="2.44" y="2.42"/>
<vertex x="2.39" y="2.48"/>
<vertex x="2.34" y="2.53"/>
<vertex x="2.29" y="2.59"/>
<vertex x="2.25" y="2.66"/>
<vertex x="2.22" y="2.73"/>
<vertex x="2.18" y="2.8"/>
<vertex x="2.15" y="2.88"/>
<vertex x="2.12" y="2.96"/>
<vertex x="2.1" y="3.04"/>
<vertex x="2.08" y="3.12"/>
<vertex x="2.06" y="3.21"/>
<vertex x="2.04" y="3.3"/>
<vertex x="2.03" y="3.39"/>
<vertex x="2.03" y="3.48"/>
<vertex x="2.02" y="3.57"/>
<vertex x="2.03" y="3.67"/>
<vertex x="2.03" y="3.76"/>
<vertex x="2.04" y="3.85"/>
<vertex x="2.05" y="3.94"/>
<vertex x="2.07" y="4.02"/>
<vertex x="2.09" y="4.11"/>
<vertex x="2.11" y="4.19"/>
<vertex x="2.14" y="4.27"/>
<vertex x="2.17" y="4.35"/>
<vertex x="2.2" y="4.42"/>
<vertex x="2.24" y="4.49"/>
<vertex x="2.28" y="4.56"/>
<vertex x="2.32" y="4.62"/>
<vertex x="2.37" y="4.68"/>
<vertex x="2.41" y="4.73"/>
<vertex x="2.47" y="4.78"/>
<vertex x="2.41" y="4.84"/>
<vertex x="2.34" y="4.79"/>
<vertex x="2.27" y="4.73"/>
<vertex x="2.2" y="4.66"/>
<vertex x="2.14" y="4.6"/>
<vertex x="2.09" y="4.53"/>
<vertex x="2.04" y="4.45"/>
<vertex x="1.99" y="4.37"/>
<vertex x="1.96" y="4.29"/>
<vertex x="1.92" y="4.21"/>
<vertex x="1.89" y="4.13"/>
<vertex x="1.87" y="4.04"/>
<vertex x="1.85" y="3.95"/>
<vertex x="1.83" y="3.86"/>
<vertex x="1.82" y="3.77"/>
<vertex x="1.82" y="3.67"/>
<vertex x="1.81" y="3.57"/>
<vertex x="1.82" y="3.47"/>
<vertex x="1.82" y="3.38"/>
<vertex x="1.84" y="3.29"/>
<vertex x="1.85" y="3.19"/>
<vertex x="1.88" y="3.1"/>
<vertex x="1.9" y="3.02"/>
<vertex x="1.93" y="2.93"/>
<vertex x="1.97" y="2.85"/>
<vertex x="2.01" y="2.77"/>
<vertex x="2.05" y="2.69"/>
<vertex x="2.11" y="2.62"/>
<vertex x="2.16" y="2.55"/>
<vertex x="2.22" y="2.48"/>
<vertex x="2.29" y="2.42"/>
<vertex x="2.36" y="2.36"/>
<vertex x="2.44" y="2.31"/>
</polygon>
<vertex x="3.09" y="2.77"/>
<vertex x="3.06" y="2.8"/>
<vertex x="3.03" y="2.83"/>
<vertex x="3" y="2.87"/>
<vertex x="2.97" y="2.91"/>
<vertex x="2.95" y="2.95"/>
<vertex x="2.92" y="2.99"/>
<vertex x="2.9" y="3.04"/>
<vertex x="2.88" y="3.08"/>
<vertex x="2.86" y="3.13"/>
<vertex x="2.85" y="3.18"/>
<vertex x="2.83" y="3.23"/>
<vertex x="2.82" y="3.29"/>
<vertex x="2.81" y="3.34"/>
<vertex x="2.81" y="3.4"/>
<vertex x="2.8" y="3.45"/>
<vertex x="2.8" y="3.51"/>
<vertex x="2.8" y="3.57"/>
<vertex x="2.8" y="3.62"/>
<vertex x="2.81" y="3.68"/>
<vertex x="2.82" y="3.73"/>
<vertex x="2.83" y="3.79"/>
<vertex x="2.84" y="3.84"/>
<vertex x="2.86" y="3.89"/>
<vertex x="2.87" y="3.94"/>
<vertex x="2.89" y="3.98"/>
<vertex x="2.91" y="4.03"/>
<vertex x="2.94" y="4.07"/>
<vertex x="2.96" y="4.11"/>
<vertex x="2.99" y="4.15"/>
<vertex x="3.01" y="4.19"/>
<vertex x="3.04" y="4.22"/>
<vertex x="3.07" y="4.25"/>
<vertex x="3.03" y="4.3"/>
<vertex x="2.98" y="4.27"/>
<vertex x="2.93" y="4.23"/>
<vertex x="2.88" y="4.19"/>
<vertex x="2.84" y="4.15"/>
<vertex x="2.8" y="4.1"/>
<vertex x="2.77" y="4.06"/>
<vertex x="2.74" y="4.01"/>
<vertex x="2.71" y="3.96"/>
<vertex x="2.68" y="3.9"/>
<vertex x="2.66" y="3.85"/>
<vertex x="2.65" y="3.8"/>
<vertex x="2.63" y="3.74"/>
<vertex x="2.62" y="3.68"/>
<vertex x="2.61" y="3.63"/>
<vertex x="2.61" y="3.57"/>
<vertex x="2.61" y="3.51"/>
<vertex x="2.61" y="3.45"/>
<vertex x="2.61" y="3.39"/>
<vertex x="2.62" y="3.33"/>
<vertex x="2.63" y="3.28"/>
<vertex x="2.65" y="3.22"/>
<vertex x="2.67" y="3.17"/>
<vertex x="2.69" y="3.11"/>
<vertex x="2.71" y="3.06"/>
<vertex x="2.74" y="3.01"/>
<vertex x="2.78" y="2.96"/>
<vertex x="2.81" y="2.92"/>
<vertex x="2.85" y="2.87"/>
<vertex x="2.89" y="2.83"/>
<vertex x="2.94" y="2.79"/>
<vertex x="2.99" y="2.75"/>
<vertex x="3.04" y="2.72"/>
</polygon>
<vertex x="1.94" y="1.94"/>
<vertex x="1.87" y="2"/>
<vertex x="1.8" y="2.07"/>
<vertex x="1.74" y="2.15"/>
<vertex x="1.68" y="2.23"/>
<vertex x="1.63" y="2.32"/>
<vertex x="1.57" y="2.41"/>
<vertex x="1.53" y="2.51"/>
<vertex x="1.49" y="2.61"/>
<vertex x="1.45" y="2.71"/>
<vertex x="1.42" y="2.82"/>
<vertex x="1.39" y="2.93"/>
<vertex x="1.36" y="3.05"/>
<vertex x="1.35" y="3.17"/>
<vertex x="1.33" y="3.29"/>
<vertex x="1.32" y="3.41"/>
<vertex x="1.32" y="3.53"/>
<vertex x="1.32" y="3.66"/>
<vertex x="1.33" y="3.78"/>
<vertex x="1.34" y="3.9"/>
<vertex x="1.36" y="4.02"/>
<vertex x="1.38" y="4.13"/>
<vertex x="1.4" y="4.24"/>
<vertex x="1.43" y="4.35"/>
<vertex x="1.47" y="4.46"/>
<vertex x="1.51" y="4.56"/>
<vertex x="1.55" y="4.66"/>
<vertex x="1.6" y="4.75"/>
<vertex x="1.66" y="4.84"/>
<vertex x="1.71" y="4.92"/>
<vertex x="1.77" y="5"/>
<vertex x="1.84" y="5.07"/>
<vertex x="1.91" y="5.13"/>
<vertex x="1.84" y="5.22"/>
<vertex x="1.74" y="5.15"/>
<vertex x="1.64" y="5.07"/>
<vertex x="1.56" y="4.98"/>
<vertex x="1.48" y="4.89"/>
<vertex x="1.41" y="4.8"/>
<vertex x="1.34" y="4.7"/>
<vertex x="1.28" y="4.6"/>
<vertex x="1.23" y="4.49"/>
<vertex x="1.18" y="4.38"/>
<vertex x="1.14" y="4.27"/>
<vertex x="1.11" y="4.15"/>
<vertex x="1.08" y="4.03"/>
<vertex x="1.06" y="3.91"/>
<vertex x="1.05" y="3.79"/>
<vertex x="1.04" y="3.66"/>
<vertex x="1.04" y="3.53"/>
<vertex x="1.04" y="3.4"/>
<vertex x="1.05" y="3.27"/>
<vertex x="1.07" y="3.15"/>
<vertex x="1.09" y="3.03"/>
<vertex x="1.12" y="2.91"/>
<vertex x="1.16" y="2.79"/>
<vertex x="1.2" y="2.68"/>
<vertex x="1.24" y="2.57"/>
<vertex x="1.3" y="2.46"/>
<vertex x="1.36" y="2.36"/>
<vertex x="1.43" y="2.26"/>
<vertex x="1.5" y="2.17"/>
<vertex x="1.58" y="2.08"/>
<vertex x="1.67" y="2"/>
<vertex x="1.77" y="1.92"/>
<vertex x="1.87" y="1.85"/>
</polygon>
<vertex x="5.31" y="1.27"/>
<vertex x="5.3" y="1.26"/>
<vertex x="5.29" y="1.24"/>
<vertex x="5.29" y="1.23"/>
<vertex x="5.28" y="1.21"/>
<vertex x="5.27" y="1.19"/>
<vertex x="5.27" y="1.18"/>
<vertex x="5.26" y="1.16"/>
<vertex x="5.26" y="1.14"/>
<vertex x="5.26" y="1.12"/>
<vertex x="5.25" y="1.11"/>
<vertex x="5.25" y="1.09"/>
<vertex x="5.25" y="1.07"/>
<vertex x="5.25" y="1.05"/>
<vertex x="5.25" y="1.03"/>
<vertex x="5.24" y="1.01"/>
<vertex x="5.24" y="0.99"/>
<vertex x="5.25" y="0.94"/>
<vertex x="5.25" y="0.9"/>
<vertex x="5.26" y="0.85"/>
<vertex x="5.28" y="0.8"/>
<vertex x="5.3" y="0.76"/>
<vertex x="5.32" y="0.72"/>
<vertex x="5.34" y="0.68"/>
<vertex x="5.37" y="0.65"/>
<vertex x="5.4" y="0.62"/>
<vertex x="5.44" y="0.59"/>
<vertex x="5.48" y="0.56"/>
<vertex x="5.52" y="0.54"/>
<vertex x="5.56" y="0.53"/>
<vertex x="5.61" y="0.51"/>
<vertex x="5.66" y="0.51"/>
<vertex x="5.71" y="0.5"/>
<vertex x="5.75" y="0.51"/>
<vertex x="5.78" y="0.51"/>
<vertex x="5.82" y="0.51"/>
<vertex x="5.85" y="0.52"/>
<vertex x="5.88" y="0.53"/>
<vertex x="5.91" y="0.54"/>
<vertex x="5.94" y="0.56"/>
<vertex x="5.97" y="0.57"/>
<vertex x="6" y="0.59"/>
<vertex x="6.02" y="0.61"/>
<vertex x="6.05" y="0.63"/>
<vertex x="6.07" y="0.66"/>
<vertex x="6.09" y="0.68"/>
<vertex x="6.11" y="0.71"/>
<vertex x="6.13" y="0.74"/>
<vertex x="6.15" y="0.77"/>
<vertex x="6.01" y="0.85"/>
<vertex x="6" y="0.83"/>
<vertex x="5.99" y="0.81"/>
<vertex x="5.97" y="0.79"/>
<vertex x="5.96" y="0.77"/>
<vertex x="5.95" y="0.76"/>
<vertex x="5.93" y="0.74"/>
<vertex x="5.91" y="0.72"/>
<vertex x="5.9" y="0.71"/>
<vertex x="5.88" y="0.7"/>
<vertex x="5.86" y="0.69"/>
<vertex x="5.84" y="0.68"/>
<vertex x="5.82" y="0.67"/>
<vertex x="5.8" y="0.66"/>
<vertex x="5.77" y="0.66"/>
<vertex x="5.75" y="0.66"/>
<vertex x="5.72" y="0.65"/>
<vertex x="5.69" y="0.66"/>
<vertex x="5.66" y="0.66"/>
<vertex x="5.63" y="0.67"/>
<vertex x="5.6" y="0.68"/>
<vertex x="5.57" y="0.69"/>
<vertex x="5.54" y="0.71"/>
<vertex x="5.52" y="0.73"/>
<vertex x="5.5" y="0.75"/>
<vertex x="5.48" y="0.77"/>
<vertex x="5.46" y="0.79"/>
<vertex x="5.45" y="0.82"/>
<vertex x="5.43" y="0.85"/>
<vertex x="5.42" y="0.88"/>
<vertex x="5.42" y="0.91"/>
<vertex x="5.41" y="0.94"/>
<vertex x="5.41" y="0.97"/>
<vertex x="6.16" y="0.97"/>
<vertex x="6.16" y="0.99"/>
<vertex x="6.16" y="1.01"/>
<vertex x="6.16" y="1.03"/>
<vertex x="6.16" y="1.05"/>
<vertex x="6.16" y="1.07"/>
<vertex x="6.15" y="1.09"/>
<vertex x="6.15" y="1.11"/>
<vertex x="6.15" y="1.13"/>
<vertex x="6.14" y="1.15"/>
<vertex x="6.14" y="1.17"/>
<vertex x="6.13" y="1.19"/>
<vertex x="6.13" y="1.2"/>
<vertex x="6.12" y="1.22"/>
<vertex x="6.12" y="1.24"/>
<vertex x="6.11" y="1.26"/>
<vertex x="6.1" y="1.27"/>
<vertex x="5.91" y="1.27"/>
<vertex x="5.91" y="1.26"/>
<vertex x="5.92" y="1.25"/>
<vertex x="5.93" y="1.25"/>
<vertex x="5.94" y="1.24"/>
<vertex x="5.94" y="1.23"/>
<vertex x="5.95" y="1.22"/>
<vertex x="5.95" y="1.21"/>
<vertex x="5.96" y="1.2"/>
<vertex x="5.96" y="1.19"/>
<vertex x="5.97" y="1.18"/>
<vertex x="5.97" y="1.17"/>
<vertex x="5.98" y="1.16"/>
<vertex x="5.98" y="1.14"/>
<vertex x="5.98" y="1.13"/>
<vertex x="5.99" y="1.12"/>
<vertex x="5.99" y="1.11"/>
<vertex x="5.42" y="1.11"/>
<vertex x="5.42" y="1.12"/>
<vertex x="5.42" y="1.13"/>
<vertex x="5.43" y="1.14"/>
<vertex x="5.43" y="1.16"/>
<vertex x="5.43" y="1.17"/>
<vertex x="5.44" y="1.18"/>
<vertex x="5.44" y="1.19"/>
<vertex x="5.45" y="1.2"/>
<vertex x="5.45" y="1.21"/>
<vertex x="5.46" y="1.22"/>
<vertex x="5.47" y="1.23"/>
<vertex x="5.47" y="1.24"/>
<vertex x="5.48" y="1.25"/>
<vertex x="5.49" y="1.25"/>
<vertex x="5.5" y="1.26"/>
<vertex x="5.5" y="1.27"/>
</polygon>
<vertex x="5.51" y="1.28"/>
<vertex x="5.53" y="1.29"/>
<vertex x="5.54" y="1.3"/>
<vertex x="5.55" y="1.31"/>
<vertex x="5.56" y="1.32"/>
<vertex x="5.57" y="1.32"/>
<vertex x="5.58" y="1.33"/>
<vertex x="5.6" y="1.34"/>
<vertex x="5.61" y="1.34"/>
<vertex x="5.62" y="1.35"/>
<vertex x="5.64" y="1.35"/>
<vertex x="5.65" y="1.35"/>
<vertex x="5.67" y="1.36"/>
<vertex x="5.68" y="1.36"/>
<vertex x="5.69" y="1.36"/>
<vertex x="5.71" y="1.36"/>
<vertex x="5.72" y="1.36"/>
<vertex x="5.74" y="1.36"/>
<vertex x="5.75" y="1.36"/>
<vertex x="5.77" y="1.35"/>
<vertex x="5.78" y="1.35"/>
<vertex x="5.79" y="1.35"/>
<vertex x="5.81" y="1.34"/>
<vertex x="5.82" y="1.34"/>
<vertex x="5.83" y="1.33"/>
<vertex x="5.84" y="1.32"/>
<vertex x="5.85" y="1.32"/>
<vertex x="5.87" y="1.31"/>
<vertex x="5.88" y="1.3"/>
<vertex x="5.89" y="1.29"/>
<vertex x="5.9" y="1.28"/>
<vertex x="6.09" y="1.3"/>
<vertex x="6.07" y="1.32"/>
<vertex x="6.05" y="1.35"/>
<vertex x="6.04" y="1.37"/>
<vertex x="6.02" y="1.39"/>
<vertex x="5.99" y="1.41"/>
<vertex x="5.97" y="1.43"/>
<vertex x="5.95" y="1.44"/>
<vertex x="5.92" y="1.46"/>
<vertex x="5.9" y="1.47"/>
<vertex x="5.87" y="1.48"/>
<vertex x="5.84" y="1.49"/>
<vertex x="5.81" y="1.5"/>
<vertex x="5.77" y="1.51"/>
<vertex x="5.74" y="1.51"/>
<vertex x="5.71" y="1.51"/>
<vertex x="5.67" y="1.51"/>
<vertex x="5.64" y="1.51"/>
<vertex x="5.61" y="1.5"/>
<vertex x="5.57" y="1.49"/>
<vertex x="5.54" y="1.48"/>
<vertex x="5.52" y="1.47"/>
<vertex x="5.49" y="1.46"/>
<vertex x="5.46" y="1.44"/>
<vertex x="5.44" y="1.43"/>
<vertex x="5.42" y="1.41"/>
<vertex x="5.39" y="1.39"/>
<vertex x="5.37" y="1.37"/>
<vertex x="5.36" y="1.35"/>
<vertex x="5.34" y="1.32"/>
<vertex x="5.32" y="1.3"/>
</polygon>
<vertex x="4.64" y="1.27"/>
<vertex x="4.64" y="0.53"/>
<vertex x="4.8" y="0.53"/>
<vertex x="4.8" y="1.01"/>
<vertex x="4.8" y="1.02"/>
<vertex x="4.8" y="1.04"/>
<vertex x="4.81" y="1.05"/>
<vertex x="4.81" y="1.07"/>
<vertex x="4.81" y="1.09"/>
<vertex x="4.81" y="1.1"/>
<vertex x="4.81" y="1.12"/>
<vertex x="4.81" y="1.14"/>
<vertex x="4.81" y="1.16"/>
<vertex x="4.82" y="1.17"/>
<vertex x="4.82" y="1.19"/>
<vertex x="4.83" y="1.21"/>
<vertex x="4.83" y="1.22"/>
<vertex x="4.84" y="1.24"/>
<vertex x="4.84" y="1.26"/>
<vertex x="4.85" y="1.27"/>
</polygon>
<vertex x="4.86" y="1.28"/>
<vertex x="4.86" y="1.29"/>
<vertex x="4.87" y="1.3"/>
<vertex x="4.87" y="1.31"/>
<vertex x="4.88" y="1.31"/>
<vertex x="4.89" y="1.32"/>
<vertex x="4.9" y="1.33"/>
<vertex x="4.91" y="1.34"/>
<vertex x="4.92" y="1.35"/>
<vertex x="4.93" y="1.35"/>
<vertex x="4.94" y="1.35"/>
<vertex x="4.95" y="1.36"/>
<vertex x="4.97" y="1.36"/>
<vertex x="4.98" y="1.36"/>
<vertex x="4.99" y="1.36"/>
<vertex x="5" y="1.36"/>
<vertex x="5.01" y="1.36"/>
<vertex x="5.02" y="1.36"/>
<vertex x="5.03" y="1.35"/>
<vertex x="5.04" y="1.35"/>
<vertex x="5.05" y="1.34"/>
<vertex x="5.06" y="1.34"/>
<vertex x="5.07" y="1.33"/>
<vertex x="5.08" y="1.33"/>
<vertex x="5.08" y="1.32"/>
<vertex x="5.09" y="1.32"/>
<vertex x="5.17" y="1.47"/>
<vertex x="5.16" y="1.47"/>
<vertex x="5.15" y="1.47"/>
<vertex x="5.14" y="1.48"/>
<vertex x="5.13" y="1.48"/>
<vertex x="5.12" y="1.49"/>
<vertex x="5.11" y="1.49"/>
<vertex x="5.1" y="1.49"/>
<vertex x="5.1" y="1.5"/>
<vertex x="5.09" y="1.5"/>
<vertex x="5.08" y="1.5"/>
<vertex x="5.07" y="1.5"/>
<vertex x="5.06" y="1.51"/>
<vertex x="5.05" y="1.51"/>
<vertex x="5.04" y="1.51"/>
<vertex x="5.03" y="1.51"/>
<vertex x="5.02" y="1.51"/>
<vertex x="5" y="1.51"/>
<vertex x="4.98" y="1.51"/>
<vertex x="4.97" y="1.5"/>
<vertex x="4.95" y="1.5"/>
<vertex x="4.94" y="1.49"/>
<vertex x="4.92" y="1.49"/>
<vertex x="4.91" y="1.48"/>
<vertex x="4.9" y="1.47"/>
<vertex x="4.88" y="1.46"/>
<vertex x="4.87" y="1.45"/>
<vertex x="4.86" y="1.44"/>
<vertex x="4.85" y="1.43"/>
<vertex x="4.84" y="1.42"/>
<vertex x="4.83" y="1.41"/>
<vertex x="4.82" y="1.39"/>
<vertex x="4.81" y="1.38"/>
<vertex x="4.8" y="1.38"/>
<vertex x="4.8" y="1.48"/>
<vertex x="4.64" y="1.48"/>
</polygon>
<vertex x="4.19" y="1.27"/>
<vertex x="4.35" y="1.27"/>
<vertex x="4.35" y="1.48"/>
<vertex x="4.19" y="1.48"/>
</polygon>
<vertex x="3.6" y="1.27"/>
<vertex x="3.6" y="0.93"/>
<vertex x="3.6" y="0.89"/>
<vertex x="3.61" y="0.84"/>
<vertex x="3.61" y="0.8"/>
<vertex x="3.62" y="0.76"/>
<vertex x="3.63" y="0.72"/>
<vertex x="3.65" y="0.69"/>
<vertex x="3.66" y="0.65"/>
<vertex x="3.68" y="0.62"/>
<vertex x="3.71" y="0.6"/>
<vertex x="3.73" y="0.57"/>
<vertex x="3.77" y="0.55"/>
<vertex x="3.8" y="0.54"/>
<vertex x="3.84" y="0.52"/>
<vertex x="3.88" y="0.51"/>
<vertex x="3.93" y="0.51"/>
<vertex x="3.98" y="0.5"/>
<vertex x="4.03" y="0.51"/>
<vertex x="4.07" y="0.51"/>
<vertex x="4.12" y="0.52"/>
<vertex x="4.16" y="0.54"/>
<vertex x="4.19" y="0.55"/>
<vertex x="4.22" y="0.57"/>
<vertex x="4.25" y="0.6"/>
<vertex x="4.27" y="0.62"/>
<vertex x="4.29" y="0.65"/>
<vertex x="4.31" y="0.69"/>
<vertex x="4.32" y="0.72"/>
<vertex x="4.34" y="0.76"/>
<vertex x="4.34" y="0.8"/>
<vertex x="4.35" y="0.84"/>
<vertex x="4.35" y="0.89"/>
<vertex x="4.35" y="0.93"/>
<vertex x="4.19" y="0.95"/>
<vertex x="4.19" y="0.92"/>
<vertex x="4.19" y="0.89"/>
<vertex x="4.19" y="0.87"/>
<vertex x="4.19" y="0.84"/>
<vertex x="4.18" y="0.81"/>
<vertex x="4.18" y="0.79"/>
<vertex x="4.17" y="0.76"/>
<vertex x="4.16" y="0.74"/>
<vertex x="4.15" y="0.72"/>
<vertex x="4.13" y="0.71"/>
<vertex x="4.11" y="0.69"/>
<vertex x="4.09" y="0.68"/>
<vertex x="4.07" y="0.67"/>
<vertex x="4.04" y="0.66"/>
<vertex x="4.01" y="0.66"/>
<vertex x="3.98" y="0.65"/>
<vertex x="3.94" y="0.66"/>
<vertex x="3.91" y="0.66"/>
<vertex x="3.88" y="0.67"/>
<vertex x="3.86" y="0.68"/>
<vertex x="3.84" y="0.69"/>
<vertex x="3.82" y="0.71"/>
<vertex x="3.81" y="0.72"/>
<vertex x="3.8" y="0.74"/>
<vertex x="3.79" y="0.76"/>
<vertex x="3.78" y="0.79"/>
<vertex x="3.77" y="0.81"/>
<vertex x="3.77" y="0.84"/>
<vertex x="3.77" y="0.87"/>
<vertex x="3.76" y="0.89"/>
<vertex x="3.76" y="0.92"/>
<vertex x="3.76" y="0.95"/>
<vertex x="3.76" y="1.27"/>
</polygon>
<vertex x="3.76" y="1.48"/>
<vertex x="3.6" y="1.48"/>
</polygon>
<vertex x="3.13" y="1.27"/>
<vertex x="3.13" y="0.53"/>
<vertex x="3.3" y="0.53"/>
<vertex x="3.3" y="1.27"/>
</polygon>
<vertex x="3.3" y="1.33"/>
<vertex x="3.47" y="1.33"/>
<vertex x="3.47" y="1.48"/>
<vertex x="3.3" y="1.48"/>
<vertex x="3.3" y="1.83"/>
<vertex x="3.13" y="1.83"/>
<vertex x="3.13" y="1.48"/>
<vertex x="3.04" y="1.48"/>
<vertex x="3.04" y="1.33"/>
<vertex x="3.13" y="1.33"/>
</polygon>
<vertex x="2.7" y="1.27"/>
<vertex x="2.7" y="1.26"/>
<vertex x="2.72" y="1.27"/>
</polygon>
<vertex x="2.31" y="1.27"/>
<vertex x="2.3" y="1.27"/>
<vertex x="2.3" y="1.26"/>
<vertex x="2.3" y="1.25"/>
<vertex x="2.3" y="1.24"/>
<vertex x="2.31" y="1.19"/>
<vertex x="2.32" y="1.14"/>
<vertex x="2.34" y="1.11"/>
<vertex x="2.37" y="1.07"/>
<vertex x="2.4" y="1.05"/>
<vertex x="2.44" y="1.03"/>
<vertex x="2.48" y="1.01"/>
<vertex x="2.52" y="0.99"/>
<vertex x="2.56" y="0.97"/>
<vertex x="2.6" y="0.95"/>
<vertex x="2.63" y="0.94"/>
<vertex x="2.66" y="0.92"/>
<vertex x="2.69" y="0.89"/>
<vertex x="2.71" y="0.87"/>
<vertex x="2.73" y="0.84"/>
<vertex x="2.73" y="0.8"/>
<vertex x="2.73" y="0.78"/>
<vertex x="2.73" y="0.77"/>
<vertex x="2.72" y="0.75"/>
<vertex x="2.72" y="0.74"/>
<vertex x="2.71" y="0.73"/>
<vertex x="2.71" y="0.72"/>
<vertex x="2.7" y="0.7"/>
<vertex x="2.69" y="0.69"/>
<vertex x="2.68" y="0.69"/>
<vertex x="2.66" y="0.68"/>
<vertex x="2.65" y="0.67"/>
<vertex x="2.64" y="0.67"/>
<vertex x="2.62" y="0.66"/>
<vertex x="2.61" y="0.66"/>
<vertex x="2.59" y="0.66"/>
<vertex x="2.58" y="0.65"/>
<vertex x="2.56" y="0.66"/>
<vertex x="2.54" y="0.66"/>
<vertex x="2.52" y="0.66"/>
<vertex x="2.51" y="0.67"/>
<vertex x="2.49" y="0.67"/>
<vertex x="2.48" y="0.68"/>
<vertex x="2.47" y="0.69"/>
<vertex x="2.46" y="0.7"/>
<vertex x="2.44" y="0.71"/>
<vertex x="2.43" y="0.72"/>
<vertex x="2.42" y="0.73"/>
<vertex x="2.42" y="0.74"/>
<vertex x="2.41" y="0.76"/>
<vertex x="2.4" y="0.77"/>
<vertex x="2.39" y="0.79"/>
<vertex x="2.38" y="0.81"/>
<vertex x="2.24" y="0.75"/>
<vertex x="2.25" y="0.72"/>
<vertex x="2.26" y="0.69"/>
<vertex x="2.28" y="0.67"/>
<vertex x="2.29" y="0.64"/>
<vertex x="2.31" y="0.62"/>
<vertex x="2.33" y="0.6"/>
<vertex x="2.35" y="0.59"/>
<vertex x="2.37" y="0.57"/>
<vertex x="2.39" y="0.55"/>
<vertex x="2.41" y="0.54"/>
<vertex x="2.44" y="0.53"/>
<vertex x="2.46" y="0.52"/>
<vertex x="2.49" y="0.51"/>
<vertex x="2.52" y="0.51"/>
<vertex x="2.55" y="0.51"/>
<vertex x="2.58" y="0.5"/>
<vertex x="2.61" y="0.51"/>
<vertex x="2.64" y="0.51"/>
<vertex x="2.67" y="0.52"/>
<vertex x="2.7" y="0.53"/>
<vertex x="2.73" y="0.54"/>
<vertex x="2.75" y="0.55"/>
<vertex x="2.78" y="0.57"/>
<vertex x="2.8" y="0.59"/>
<vertex x="2.82" y="0.61"/>
<vertex x="2.84" y="0.64"/>
<vertex x="2.86" y="0.66"/>
<vertex x="2.87" y="0.69"/>
<vertex x="2.88" y="0.72"/>
<vertex x="2.89" y="0.75"/>
<vertex x="2.9" y="0.78"/>
<vertex x="2.9" y="0.81"/>
<vertex x="2.9" y="0.84"/>
<vertex x="2.89" y="0.87"/>
<vertex x="2.89" y="0.9"/>
<vertex x="2.88" y="0.92"/>
<vertex x="2.87" y="0.94"/>
<vertex x="2.86" y="0.96"/>
<vertex x="2.84" y="0.98"/>
<vertex x="2.83" y="0.99"/>
<vertex x="2.81" y="1.01"/>
<vertex x="2.8" y="1.02"/>
<vertex x="2.78" y="1.04"/>
<vertex x="2.76" y="1.05"/>
<vertex x="2.74" y="1.06"/>
<vertex x="2.72" y="1.07"/>
<vertex x="2.7" y="1.08"/>
<vertex x="2.68" y="1.09"/>
<vertex x="2.66" y="1.1"/>
<vertex x="2.64" y="1.11"/>
<vertex x="2.62" y="1.11"/>
<vertex x="2.6" y="1.12"/>
<vertex x="2.58" y="1.13"/>
<vertex x="2.56" y="1.14"/>
<vertex x="2.54" y="1.15"/>
<vertex x="2.52" y="1.16"/>
<vertex x="2.51" y="1.17"/>
<vertex x="2.5" y="1.18"/>
<vertex x="2.49" y="1.19"/>
<vertex x="2.48" y="1.2"/>
<vertex x="2.47" y="1.21"/>
<vertex x="2.46" y="1.22"/>
<vertex x="2.46" y="1.24"/>
<vertex x="2.46" y="1.25"/>
<vertex x="2.46" y="1.26"/>
<vertex x="2.46" y="1.27"/>
</polygon>
<vertex x="2.46" y="1.28"/>
<vertex x="2.47" y="1.29"/>
<vertex x="2.47" y="1.3"/>
<vertex x="2.48" y="1.31"/>
<vertex x="2.49" y="1.32"/>
<vertex x="2.49" y="1.33"/>
<vertex x="2.5" y="1.33"/>
<vertex x="2.51" y="1.34"/>
<vertex x="2.52" y="1.35"/>
<vertex x="2.53" y="1.35"/>
<vertex x="2.54" y="1.35"/>
<vertex x="2.55" y="1.36"/>
<vertex x="2.56" y="1.36"/>
<vertex x="2.57" y="1.36"/>
<vertex x="2.58" y="1.36"/>
<vertex x="2.59" y="1.36"/>
<vertex x="2.6" y="1.36"/>
<vertex x="2.61" y="1.35"/>
<vertex x="2.62" y="1.35"/>
<vertex x="2.63" y="1.34"/>
<vertex x="2.64" y="1.34"/>
<vertex x="2.65" y="1.33"/>
<vertex x="2.66" y="1.32"/>
<vertex x="2.67" y="1.31"/>
<vertex x="2.68" y="1.31"/>
<vertex x="2.68" y="1.3"/>
<vertex x="2.69" y="1.29"/>
<vertex x="2.69" y="1.28"/>
<vertex x="2.84" y="1.33"/>
<vertex x="2.83" y="1.35"/>
<vertex x="2.82" y="1.37"/>
<vertex x="2.81" y="1.39"/>
<vertex x="2.8" y="1.4"/>
<vertex x="2.78" y="1.42"/>
<vertex x="2.77" y="1.43"/>
<vertex x="2.75" y="1.45"/>
<vertex x="2.74" y="1.46"/>
<vertex x="2.72" y="1.47"/>
<vertex x="2.7" y="1.48"/>
<vertex x="2.68" y="1.49"/>
<vertex x="2.67" y="1.5"/>
<vertex x="2.65" y="1.5"/>
<vertex x="2.63" y="1.51"/>
<vertex x="2.61" y="1.51"/>
<vertex x="2.59" y="1.51"/>
<vertex x="2.56" y="1.51"/>
<vertex x="2.53" y="1.51"/>
<vertex x="2.51" y="1.5"/>
<vertex x="2.48" y="1.49"/>
<vertex x="2.46" y="1.48"/>
<vertex x="2.44" y="1.47"/>
<vertex x="2.42" y="1.46"/>
<vertex x="2.4" y="1.44"/>
<vertex x="2.38" y="1.43"/>
<vertex x="2.36" y="1.41"/>
<vertex x="2.35" y="1.39"/>
<vertex x="2.34" y="1.37"/>
<vertex x="2.32" y="1.35"/>
<vertex x="2.32" y="1.32"/>
<vertex x="2.31" y="1.3"/>
</polygon>
<vertex x="1.24" y="1.27"/>
<vertex x="1.24" y="1.26"/>
<vertex x="1.23" y="1.24"/>
<vertex x="1.22" y="1.23"/>
<vertex x="1.22" y="1.21"/>
<vertex x="1.21" y="1.19"/>
<vertex x="1.21" y="1.18"/>
<vertex x="1.2" y="1.16"/>
<vertex x="1.2" y="1.14"/>
<vertex x="1.19" y="1.12"/>
<vertex x="1.19" y="1.11"/>
<vertex x="1.19" y="1.09"/>
<vertex x="1.19" y="1.07"/>
<vertex x="1.18" y="1.05"/>
<vertex x="1.18" y="1.03"/>
<vertex x="1.18" y="1.01"/>
<vertex x="1.18" y="0.99"/>
<vertex x="1.18" y="0.94"/>
<vertex x="1.19" y="0.9"/>
<vertex x="1.2" y="0.85"/>
<vertex x="1.21" y="0.8"/>
<vertex x="1.23" y="0.76"/>
<vertex x="1.25" y="0.72"/>
<vertex x="1.28" y="0.68"/>
<vertex x="1.31" y="0.65"/>
<vertex x="1.34" y="0.62"/>
<vertex x="1.38" y="0.59"/>
<vertex x="1.41" y="0.56"/>
<vertex x="1.46" y="0.54"/>
<vertex x="1.5" y="0.53"/>
<vertex x="1.55" y="0.51"/>
<vertex x="1.6" y="0.51"/>
<vertex x="1.65" y="0.5"/>
<vertex x="1.68" y="0.51"/>
<vertex x="1.72" y="0.51"/>
<vertex x="1.75" y="0.51"/>
<vertex x="1.79" y="0.52"/>
<vertex x="1.82" y="0.53"/>
<vertex x="1.85" y="0.54"/>
<vertex x="1.88" y="0.56"/>
<vertex x="1.91" y="0.57"/>
<vertex x="1.93" y="0.59"/>
<vertex x="1.96" y="0.61"/>
<vertex x="1.98" y="0.63"/>
<vertex x="2.01" y="0.66"/>
<vertex x="2.03" y="0.68"/>
<vertex x="2.05" y="0.71"/>
<vertex x="2.07" y="0.74"/>
<vertex x="2.09" y="0.77"/>
<vertex x="1.95" y="0.85"/>
<vertex x="1.94" y="0.83"/>
<vertex x="1.92" y="0.81"/>
<vertex x="1.91" y="0.79"/>
<vertex x="1.9" y="0.77"/>
<vertex x="1.88" y="0.76"/>
<vertex x="1.87" y="0.74"/>
<vertex x="1.85" y="0.72"/>
<vertex x="1.83" y="0.71"/>
<vertex x="1.81" y="0.7"/>
<vertex x="1.8" y="0.69"/>
<vertex x="1.78" y="0.68"/>
<vertex x="1.75" y="0.67"/>
<vertex x="1.73" y="0.66"/>
<vertex x="1.71" y="0.66"/>
<vertex x="1.69" y="0.66"/>
<vertex x="1.66" y="0.65"/>
<vertex x="1.63" y="0.66"/>
<vertex x="1.59" y="0.66"/>
<vertex x="1.56" y="0.67"/>
<vertex x="1.53" y="0.68"/>
<vertex x="1.51" y="0.69"/>
<vertex x="1.48" y="0.71"/>
<vertex x="1.46" y="0.73"/>
<vertex x="1.44" y="0.75"/>
<vertex x="1.42" y="0.77"/>
<vertex x="1.4" y="0.79"/>
<vertex x="1.38" y="0.82"/>
<vertex x="1.37" y="0.85"/>
<vertex x="1.36" y="0.88"/>
<vertex x="1.35" y="0.91"/>
<vertex x="1.35" y="0.94"/>
<vertex x="1.35" y="0.97"/>
<vertex x="2.1" y="0.97"/>
<vertex x="2.1" y="0.99"/>
<vertex x="2.1" y="1.01"/>
<vertex x="2.1" y="1.03"/>
<vertex x="2.1" y="1.05"/>
<vertex x="2.09" y="1.07"/>
<vertex x="2.09" y="1.09"/>
<vertex x="2.09" y="1.11"/>
<vertex x="2.09" y="1.13"/>
<vertex x="2.08" y="1.15"/>
<vertex x="2.08" y="1.17"/>
<vertex x="2.07" y="1.19"/>
<vertex x="2.07" y="1.2"/>
<vertex x="2.06" y="1.22"/>
<vertex x="2.05" y="1.24"/>
<vertex x="2.05" y="1.26"/>
<vertex x="2.04" y="1.27"/>
<vertex x="1.84" y="1.27"/>
<vertex x="1.85" y="1.26"/>
<vertex x="1.86" y="1.25"/>
<vertex x="1.87" y="1.25"/>
<vertex x="1.87" y="1.24"/>
<vertex x="1.88" y="1.23"/>
<vertex x="1.89" y="1.22"/>
<vertex x="1.89" y="1.21"/>
<vertex x="1.9" y="1.2"/>
<vertex x="1.9" y="1.19"/>
<vertex x="1.91" y="1.18"/>
<vertex x="1.91" y="1.17"/>
<vertex x="1.91" y="1.16"/>
<vertex x="1.92" y="1.14"/>
<vertex x="1.92" y="1.13"/>
<vertex x="1.92" y="1.12"/>
<vertex x="1.93" y="1.11"/>
<vertex x="1.36" y="1.11"/>
<vertex x="1.36" y="1.12"/>
<vertex x="1.36" y="1.13"/>
<vertex x="1.36" y="1.14"/>
<vertex x="1.37" y="1.16"/>
<vertex x="1.37" y="1.17"/>
<vertex x="1.38" y="1.18"/>
<vertex x="1.38" y="1.19"/>
<vertex x="1.39" y="1.2"/>
<vertex x="1.39" y="1.21"/>
<vertex x="1.4" y="1.22"/>
<vertex x="1.4" y="1.23"/>
<vertex x="1.41" y="1.24"/>
<vertex x="1.42" y="1.25"/>
<vertex x="1.43" y="1.25"/>
<vertex x="1.43" y="1.26"/>
<vertex x="1.44" y="1.27"/>
</polygon>
<vertex x="1.45" y="1.28"/>
<vertex x="1.46" y="1.29"/>
<vertex x="1.47" y="1.3"/>
<vertex x="1.49" y="1.31"/>
<vertex x="1.5" y="1.32"/>
<vertex x="1.51" y="1.32"/>
<vertex x="1.52" y="1.33"/>
<vertex x="1.53" y="1.34"/>
<vertex x="1.55" y="1.34"/>
<vertex x="1.56" y="1.35"/>
<vertex x="1.57" y="1.35"/>
<vertex x="1.59" y="1.35"/>
<vertex x="1.6" y="1.36"/>
<vertex x="1.62" y="1.36"/>
<vertex x="1.63" y="1.36"/>
<vertex x="1.65" y="1.36"/>
<vertex x="1.66" y="1.36"/>
<vertex x="1.67" y="1.36"/>
<vertex x="1.69" y="1.36"/>
<vertex x="1.7" y="1.35"/>
<vertex x="1.72" y="1.35"/>
<vertex x="1.73" y="1.35"/>
<vertex x="1.74" y="1.34"/>
<vertex x="1.75" y="1.34"/>
<vertex x="1.77" y="1.33"/>
<vertex x="1.78" y="1.32"/>
<vertex x="1.79" y="1.32"/>
<vertex x="1.8" y="1.31"/>
<vertex x="1.81" y="1.3"/>
<vertex x="1.82" y="1.29"/>
<vertex x="1.83" y="1.28"/>
<vertex x="2.02" y="1.3"/>
<vertex x="2.01" y="1.32"/>
<vertex x="1.99" y="1.35"/>
<vertex x="1.97" y="1.37"/>
<vertex x="1.95" y="1.39"/>
<vertex x="1.93" y="1.41"/>
<vertex x="1.91" y="1.43"/>
<vertex x="1.88" y="1.44"/>
<vertex x="1.86" y="1.46"/>
<vertex x="1.83" y="1.47"/>
<vertex x="1.8" y="1.48"/>
<vertex x="1.77" y="1.49"/>
<vertex x="1.74" y="1.5"/>
<vertex x="1.71" y="1.51"/>
<vertex x="1.68" y="1.51"/>
<vertex x="1.64" y="1.51"/>
<vertex x="1.61" y="1.51"/>
<vertex x="1.57" y="1.51"/>
<vertex x="1.54" y="1.5"/>
<vertex x="1.51" y="1.49"/>
<vertex x="1.48" y="1.48"/>
<vertex x="1.45" y="1.47"/>
<vertex x="1.43" y="1.46"/>
<vertex x="1.4" y="1.44"/>
<vertex x="1.38" y="1.43"/>
<vertex x="1.35" y="1.41"/>
<vertex x="1.33" y="1.39"/>
<vertex x="1.31" y="1.37"/>
<vertex x="1.29" y="1.35"/>
<vertex x="1.28" y="1.32"/>
<vertex x="1.26" y="1.3"/>
</polygon>
<vertex x="0.07" y="1.27"/>
<vertex x="0.06" y="1.26"/>
<vertex x="0.05" y="1.24"/>
<vertex x="0.04" y="1.23"/>
<vertex x="0.04" y="1.21"/>
<vertex x="0.03" y="1.19"/>
<vertex x="0.03" y="1.18"/>
<vertex x="0.02" y="1.16"/>
<vertex x="0.02" y="1.14"/>
<vertex x="0.01" y="1.13"/>
<vertex x="0.01" y="1.11"/>
<vertex x="0.01" y="1.09"/>
<vertex x="0" y="1.07"/>
<vertex x="0" y="1.06"/>
<vertex x="0" y="1.04"/>
<vertex x="0" y="1.02"/>
<vertex x="0" y="1"/>
<vertex x="0" y="0.95"/>
<vertex x="0.01" y="0.91"/>
<vertex x="0.02" y="0.86"/>
<vertex x="0.03" y="0.81"/>
<vertex x="0.05" y="0.77"/>
<vertex x="0.07" y="0.73"/>
<vertex x="0.1" y="0.69"/>
<vertex x="0.12" y="0.65"/>
<vertex x="0.15" y="0.62"/>
<vertex x="0.19" y="0.59"/>
<vertex x="0.23" y="0.57"/>
<vertex x="0.27" y="0.55"/>
<vertex x="0.31" y="0.53"/>
<vertex x="0.35" y="0.51"/>
<vertex x="0.4" y="0.51"/>
<vertex x="0.45" y="0.5"/>
<vertex x="0.48" y="0.51"/>
<vertex x="0.5" y="0.51"/>
<vertex x="0.53" y="0.51"/>
<vertex x="0.55" y="0.52"/>
<vertex x="0.57" y="0.52"/>
<vertex x="0.59" y="0.53"/>
<vertex x="0.62" y="0.54"/>
<vertex x="0.64" y="0.55"/>
<vertex x="0.66" y="0.56"/>
<vertex x="0.68" y="0.57"/>
<vertex x="0.7" y="0.58"/>
<vertex x="0.72" y="0.6"/>
<vertex x="0.74" y="0.61"/>
<vertex x="0.75" y="0.63"/>
<vertex x="0.77" y="0.64"/>
<vertex x="0.78" y="0.66"/>
<vertex x="0.79" y="0.66"/>
<vertex x="0.79" y="0.55"/>
<vertex x="0.79" y="0.51"/>
<vertex x="0.79" y="0.47"/>
<vertex x="0.78" y="0.43"/>
<vertex x="0.78" y="0.4"/>
<vertex x="0.77" y="0.36"/>
<vertex x="0.76" y="0.33"/>
<vertex x="0.74" y="0.3"/>
<vertex x="0.73" y="0.27"/>
<vertex x="0.71" y="0.24"/>
<vertex x="0.69" y="0.22"/>
<vertex x="0.66" y="0.2"/>
<vertex x="0.64" y="0.18"/>
<vertex x="0.6" y="0.17"/>
<vertex x="0.57" y="0.16"/>
<vertex x="0.53" y="0.15"/>
<vertex x="0.48" y="0.15"/>
<vertex x="0.45" y="0.15"/>
<vertex x="0.42" y="0.15"/>
<vertex x="0.39" y="0.16"/>
<vertex x="0.36" y="0.17"/>
<vertex x="0.34" y="0.18"/>
<vertex x="0.31" y="0.19"/>
<vertex x="0.29" y="0.21"/>
<vertex x="0.27" y="0.23"/>
<vertex x="0.25" y="0.25"/>
<vertex x="0.23" y="0.27"/>
<vertex x="0.21" y="0.29"/>
<vertex x="0.2" y="0.32"/>
<vertex x="0.19" y="0.35"/>
<vertex x="0.18" y="0.37"/>
<vertex x="0.18" y="0.41"/>
<vertex x="0.18" y="0.44"/>
<vertex x="0.02" y="0.44"/>
<vertex x="0.02" y="0.39"/>
<vertex x="0.03" y="0.34"/>
<vertex x="0.04" y="0.3"/>
<vertex x="0.05" y="0.26"/>
<vertex x="0.07" y="0.22"/>
<vertex x="0.1" y="0.18"/>
<vertex x="0.12" y="0.15"/>
<vertex x="0.15" y="0.12"/>
<vertex x="0.19" y="0.09"/>
<vertex x="0.22" y="0.07"/>
<vertex x="0.26" y="0.05"/>
<vertex x="0.3" y="0.03"/>
<vertex x="0.34" y="0.02"/>
<vertex x="0.39" y="0.01"/>
<vertex x="0.44" y="0"/>
<vertex x="0.48" y="0"/>
<vertex x="0.51" y="0"/>
<vertex x="0.54" y="0"/>
<vertex x="0.56" y="0.01"/>
<vertex x="0.59" y="0.01"/>
<vertex x="0.61" y="0.02"/>
<vertex x="0.64" y="0.02"/>
<vertex x="0.66" y="0.03"/>
<vertex x="0.69" y="0.04"/>
<vertex x="0.71" y="0.05"/>
<vertex x="0.73" y="0.06"/>
<vertex x="0.76" y="0.08"/>
<vertex x="0.78" y="0.09"/>
<vertex x="0.8" y="0.11"/>
<vertex x="0.82" y="0.13"/>
<vertex x="0.84" y="0.15"/>
<vertex x="0.85" y="0.17"/>
<vertex x="0.87" y="0.19"/>
<vertex x="0.89" y="0.22"/>
<vertex x="0.9" y="0.24"/>
<vertex x="0.91" y="0.26"/>
<vertex x="0.92" y="0.29"/>
<vertex x="0.93" y="0.31"/>
<vertex x="0.93" y="0.34"/>
<vertex x="0.94" y="0.36"/>
<vertex x="0.94" y="0.39"/>
<vertex x="0.95" y="0.41"/>
<vertex x="0.95" y="0.44"/>
<vertex x="0.95" y="0.47"/>
<vertex x="0.95" y="0.49"/>
<vertex x="0.95" y="0.52"/>
<vertex x="0.95" y="0.55"/>
<vertex x="0.95" y="0.58"/>
<vertex x="0.95" y="1.27"/>
<vertex x="0.7" y="1.27"/>
<vertex x="0.71" y="1.26"/>
<vertex x="0.72" y="1.25"/>
<vertex x="0.73" y="1.23"/>
<vertex x="0.74" y="1.22"/>
<vertex x="0.75" y="1.2"/>
<vertex x="0.76" y="1.19"/>
<vertex x="0.76" y="1.17"/>
<vertex x="0.77" y="1.16"/>
<vertex x="0.78" y="1.14"/>
<vertex x="0.78" y="1.12"/>
<vertex x="0.79" y="1.11"/>
<vertex x="0.79" y="1.09"/>
<vertex x="0.79" y="1.07"/>
<vertex x="0.79" y="1.05"/>
<vertex x="0.8" y="1.03"/>
<vertex x="0.8" y="1.01"/>
<vertex x="0.8" y="0.98"/>
<vertex x="0.79" y="0.94"/>
<vertex x="0.79" y="0.91"/>
<vertex x="0.78" y="0.88"/>
<vertex x="0.76" y="0.85"/>
<vertex x="0.75" y="0.82"/>
<vertex x="0.73" y="0.79"/>
<vertex x="0.72" y="0.76"/>
<vertex x="0.69" y="0.74"/>
<vertex x="0.67" y="0.72"/>
<vertex x="0.64" y="0.7"/>
<vertex x="0.62" y="0.68"/>
<vertex x="0.59" y="0.67"/>
<vertex x="0.55" y="0.66"/>
<vertex x="0.52" y="0.66"/>
<vertex x="0.48" y="0.65"/>
<vertex x="0.44" y="0.66"/>
<vertex x="0.41" y="0.66"/>
<vertex x="0.37" y="0.67"/>
<vertex x="0.34" y="0.69"/>
<vertex x="0.32" y="0.7"/>
<vertex x="0.29" y="0.72"/>
<vertex x="0.27" y="0.74"/>
<vertex x="0.25" y="0.77"/>
<vertex x="0.23" y="0.79"/>
<vertex x="0.21" y="0.82"/>
<vertex x="0.2" y="0.85"/>
<vertex x="0.19" y="0.88"/>
<vertex x="0.18" y="0.91"/>
<vertex x="0.17" y="0.95"/>
<vertex x="0.17" y="0.98"/>
<vertex x="0.17" y="1.02"/>
<vertex x="0.17" y="1.04"/>
<vertex x="0.17" y="1.05"/>
<vertex x="0.17" y="1.07"/>
<vertex x="0.17" y="1.09"/>
<vertex x="0.18" y="1.11"/>
<vertex x="0.18" y="1.12"/>
<vertex x="0.19" y="1.14"/>
<vertex x="0.19" y="1.16"/>
<vertex x="0.2" y="1.17"/>
<vertex x="0.21" y="1.19"/>
<vertex x="0.22" y="1.2"/>
<vertex x="0.23" y="1.22"/>
<vertex x="0.23" y="1.23"/>
<vertex x="0.25" y="1.25"/>
<vertex x="0.26" y="1.26"/>
<vertex x="0.27" y="1.27"/>
</polygon>
<vertex x="0.28" y="1.28"/>
<vertex x="0.29" y="1.29"/>
<vertex x="0.3" y="1.3"/>
<vertex x="0.31" y="1.31"/>
<vertex x="0.32" y="1.32"/>
<vertex x="0.33" y="1.32"/>
<vertex x="0.35" y="1.33"/>
<vertex x="0.36" y="1.34"/>
<vertex x="0.37" y="1.34"/>
<vertex x="0.39" y="1.35"/>
<vertex x="0.4" y="1.35"/>
<vertex x="0.42" y="1.35"/>
<vertex x="0.43" y="1.36"/>
<vertex x="0.44" y="1.36"/>
<vertex x="0.46" y="1.36"/>
<vertex x="0.48" y="1.36"/>
<vertex x="0.49" y="1.36"/>
<vertex x="0.51" y="1.36"/>
<vertex x="0.53" y="1.36"/>
<vertex x="0.54" y="1.35"/>
<vertex x="0.56" y="1.35"/>
<vertex x="0.57" y="1.35"/>
<vertex x="0.59" y="1.34"/>
<vertex x="0.6" y="1.34"/>
<vertex x="0.61" y="1.33"/>
<vertex x="0.63" y="1.32"/>
<vertex x="0.64" y="1.32"/>
<vertex x="0.65" y="1.31"/>
<vertex x="0.66" y="1.3"/>
<vertex x="0.68" y="1.29"/>
<vertex x="0.69" y="1.28"/>
<vertex x="0.95" y="1.48"/>
<vertex x="0.79" y="1.48"/>
<vertex x="0.79" y="1.35"/>
<vertex x="0.78" y="1.35"/>
<vertex x="0.77" y="1.37"/>
<vertex x="0.75" y="1.38"/>
<vertex x="0.74" y="1.4"/>
<vertex x="0.72" y="1.42"/>
<vertex x="0.7" y="1.43"/>
<vertex x="0.68" y="1.44"/>
<vertex x="0.66" y="1.46"/>
<vertex x="0.64" y="1.47"/>
<vertex x="0.62" y="1.48"/>
<vertex x="0.6" y="1.49"/>
<vertex x="0.58" y="1.49"/>
<vertex x="0.56" y="1.5"/>
<vertex x="0.53" y="1.5"/>
<vertex x="0.51" y="1.51"/>
<vertex x="0.48" y="1.51"/>
<vertex x="0.46" y="1.51"/>
<vertex x="0.43" y="1.51"/>
<vertex x="0.39" y="1.51"/>
<vertex x="0.36" y="1.5"/>
<vertex x="0.33" y="1.49"/>
<vertex x="0.3" y="1.48"/>
<vertex x="0.28" y="1.47"/>
<vertex x="0.25" y="1.46"/>
<vertex x="0.22" y="1.44"/>
<vertex x="0.2" y="1.43"/>
<vertex x="0.18" y="1.41"/>
<vertex x="0.16" y="1.39"/>
<vertex x="0.14" y="1.37"/>
<vertex x="0.12" y="1.35"/>
<vertex x="0.1" y="1.32"/>
<vertex x="0.08" y="1.3"/>
</polygon>
<vertex x="11.07" y="1.54"/>
<vertex x="11.07" y="1.79"/>
<vertex x="10.98" y="1.79"/>
<vertex x="10.98" y="1.82"/>
<vertex x="11.2" y="1.82"/>
<vertex x="11.2" y="1.79"/>
<vertex x="11.11" y="1.79"/>
<vertex x="11.11" y="1.54"/>
</polygon>
<vertex x="11.24" y="1.54"/>
<vertex x="11.24" y="1.82"/>
<vertex x="11.3" y="1.82"/>
<vertex x="11.36" y="1.62"/>
<vertex x="11.37" y="1.62"/>
<vertex x="11.37" y="1.61"/>
<vertex x="11.37" y="1.6"/>
<vertex x="11.37" y="1.59"/>
<vertex x="11.38" y="1.59"/>
<vertex x="11.38" y="1.58"/>
<vertex x="11.38" y="1.6"/>
<vertex x="11.39" y="1.61"/>
<vertex x="11.39" y="1.62"/>
<vertex x="11.39" y="1.63"/>
<vertex x="11.46" y="1.82"/>
<vertex x="11.51" y="1.82"/>
<vertex x="11.51" y="1.54"/>
<vertex x="11.47" y="1.54"/>
<vertex x="11.47" y="1.78"/>
<vertex x="11.39" y="1.54"/>
<vertex x="11.36" y="1.54"/>
<vertex x="11.28" y="1.78"/>
<vertex x="11.28" y="1.54"/>
</polygon>
</package>
<package name="GESTURESENSE_NOTEXT">
<vertex x="8.45" y="3.85"/>
<vertex x="7.41" y="1.28"/>
<vertex x="7.4" y="1.26"/>
<vertex x="7.37" y="1.21"/>
<vertex x="7.24" y="1.03"/>
<vertex x="7.15" y="0.92"/>
<vertex x="7.03" y="0.8"/>
<vertex x="6.9" y="0.67"/>
<vertex x="6.74" y="0.55"/>
<vertex x="6.56" y="0.44"/>
<vertex x="6.36" y="0.34"/>
<vertex x="6.14" y="0.26"/>
<vertex x="5.9" y="0.2"/>
<vertex x="5.64" y="0.18"/>
<vertex x="5.35" y="0.2"/>
<vertex x="5.05" y="0.26"/>
<vertex x="4.73" y="0.37"/>
<vertex x="4.41" y="0.52"/>
<vertex x="4.16" y="0.69"/>
<vertex x="3.94" y="0.88"/>
<vertex x="3.78" y="1.09"/>
<vertex x="3.65" y="1.31"/>
<vertex x="3.55" y="1.53"/>
<vertex x="3.49" y="1.75"/>
<vertex x="3.45" y="1.97"/>
<vertex x="3.43" y="2.19"/>
<vertex x="3.43" y="2.38"/>
<vertex x="3.44" y="2.56"/>
<vertex x="3.45" y="2.72"/>
<vertex x="3.48" y="2.85"/>
<vertex x="3.5" y="2.95"/>
<vertex x="3.51" y="3.02"/>
<vertex x="3.52" y="3.04"/>
<vertex x="5.05" y="6.83"/>
<vertex x="5.06" y="6.85"/>
<vertex x="5.06" y="6.86"/>
<vertex x="5.07" y="6.89"/>
<vertex x="5.09" y="6.91"/>
<vertex x="5.1" y="6.94"/>
<vertex x="5.12" y="6.97"/>
<vertex x="5.14" y="7"/>
<vertex x="5.17" y="7.03"/>
<vertex x="5.2" y="7.06"/>
<vertex x="5.24" y="7.08"/>
<vertex x="5.28" y="7.09"/>
<vertex x="5.32" y="7.1"/>
<vertex x="5.37" y="7.1"/>
<vertex x="5.42" y="7.09"/>
<vertex x="5.48" y="7.08"/>
<vertex x="5.55" y="7.04"/>
<vertex x="5.6" y="7.01"/>
<vertex x="5.64" y="6.97"/>
<vertex x="5.67" y="6.94"/>
<vertex x="5.69" y="6.9"/>
<vertex x="5.71" y="6.86"/>
<vertex x="5.71" y="6.82"/>
<vertex x="5.71" y="6.78"/>
<vertex x="5.71" y="6.74"/>
<vertex x="5.71" y="6.71"/>
<vertex x="5.7" y="6.68"/>
<vertex x="5.69" y="6.65"/>
<vertex x="5.68" y="6.63"/>
<vertex x="5.67" y="6.61"/>
<vertex x="5.67" y="6.6"/>
<vertex x="4.86" y="4.61"/>
<vertex x="4.86" y="4.6"/>
<vertex x="4.85" y="4.59"/>
<vertex x="4.85" y="4.58"/>
<vertex x="4.84" y="4.57"/>
<vertex x="4.84" y="4.55"/>
<vertex x="4.84" y="4.54"/>
<vertex x="4.84" y="4.53"/>
<vertex x="4.84" y="4.51"/>
<vertex x="4.84" y="4.5"/>
<vertex x="4.84" y="4.48"/>
<vertex x="4.85" y="4.47"/>
<vertex x="4.86" y="4.45"/>
<vertex x="4.88" y="4.44"/>
<vertex x="4.89" y="4.43"/>
<vertex x="4.92" y="4.42"/>
<vertex x="4.95" y="4.42"/>
<vertex x="4.97" y="4.41"/>
<vertex x="4.99" y="4.42"/>
<vertex x="5.01" y="4.42"/>
<vertex x="5.02" y="4.42"/>
<vertex x="5.04" y="4.43"/>
<vertex x="5.04" y="4.44"/>
<vertex x="5.05" y="4.45"/>
<vertex x="5.06" y="4.46"/>
<vertex x="5.06" y="4.47"/>
<vertex x="5.06" y="4.48"/>
<vertex x="5.06" y="4.49"/>
<vertex x="5.07" y="4.5"/>
<vertex x="6.15" y="7.15"/>
<vertex x="6.15" y="7.16"/>
<vertex x="6.16" y="7.18"/>
<vertex x="6.17" y="7.2"/>
<vertex x="6.18" y="7.22"/>
<vertex x="6.19" y="7.25"/>
<vertex x="6.21" y="7.28"/>
<vertex x="6.23" y="7.31"/>
<vertex x="6.26" y="7.33"/>
<vertex x="6.29" y="7.36"/>
<vertex x="6.32" y="7.37"/>
<vertex x="6.36" y="7.39"/>
<vertex x="6.41" y="7.4"/>
<vertex x="6.51" y="7.39"/>
<vertex x="6.57" y="7.37"/>
<vertex x="6.63" y="7.35"/>
<vertex x="6.68" y="7.32"/>
<vertex x="6.75" y="7.26"/>
<vertex x="6.77" y="7.22"/>
<vertex x="6.78" y="7.19"/>
<vertex x="6.79" y="7.15"/>
<vertex x="6.8" y="7.12"/>
<vertex x="6.8" y="7.08"/>
<vertex x="6.79" y="7.05"/>
<vertex x="6.79" y="7.03"/>
<vertex x="6.78" y="7"/>
<vertex x="6.78" y="6.98"/>
<vertex x="6.77" y="6.97"/>
<vertex x="6.77" y="6.96"/>
<vertex x="6.77" y="6.95"/>
<vertex x="5.67" y="4.27"/>
<vertex x="5.67" y="4.26"/>
<vertex x="5.66" y="4.25"/>
<vertex x="5.66" y="4.24"/>
<vertex x="5.65" y="4.23"/>
<vertex x="5.65" y="4.21"/>
<vertex x="5.64" y="4.2"/>
<vertex x="5.64" y="4.18"/>
<vertex x="5.64" y="4.17"/>
<vertex x="5.64" y="4.15"/>
<vertex x="5.65" y="4.13"/>
<vertex x="5.65" y="4.11"/>
<vertex x="5.66" y="4.1"/>
<vertex x="5.68" y="4.08"/>
<vertex x="5.7" y="4.07"/>
<vertex x="5.72" y="4.06"/>
<vertex x="5.75" y="4.05"/>
<vertex x="5.78" y="4.04"/>
<vertex x="5.8" y="4.04"/>
<vertex x="5.82" y="4.05"/>
<vertex x="5.83" y="4.05"/>
<vertex x="5.85" y="4.06"/>
<vertex x="5.86" y="4.07"/>
<vertex x="5.87" y="4.08"/>
<vertex x="5.88" y="4.09"/>
<vertex x="5.89" y="4.11"/>
<vertex x="5.9" y="4.12"/>
<vertex x="5.9" y="4.13"/>
<vertex x="5.9" y="4.14"/>
<vertex x="5.91" y="4.15"/>
<vertex x="7.07" y="7.04"/>
<vertex x="7.08" y="7.04"/>
<vertex x="7.08" y="7.05"/>
<vertex x="7.08" y="7.07"/>
<vertex x="7.09" y="7.09"/>
<vertex x="7.1" y="7.11"/>
<vertex x="7.12" y="7.13"/>
<vertex x="7.14" y="7.16"/>
<vertex x="7.16" y="7.18"/>
<vertex x="7.18" y="7.2"/>
<vertex x="7.21" y="7.22"/>
<vertex x="7.25" y="7.24"/>
<vertex x="7.29" y="7.25"/>
<vertex x="7.33" y="7.25"/>
<vertex x="7.38" y="7.25"/>
<vertex x="7.43" y="7.24"/>
<vertex x="7.49" y="7.22"/>
<vertex x="7.55" y="7.19"/>
<vertex x="7.6" y="7.16"/>
<vertex x="7.63" y="7.13"/>
<vertex x="7.66" y="7.1"/>
<vertex x="7.68" y="7.07"/>
<vertex x="7.7" y="7.04"/>
<vertex x="7.71" y="7.01"/>
<vertex x="7.71" y="6.97"/>
<vertex x="7.71" y="6.95"/>
<vertex x="7.7" y="6.92"/>
<vertex x="7.7" y="6.9"/>
<vertex x="7.69" y="6.87"/>
<vertex x="7.68" y="6.86"/>
<vertex x="7.68" y="6.85"/>
<vertex x="7.67" y="6.84"/>
<vertex x="7.67" y="6.83"/>
<vertex x="6.5" y="3.95"/>
<vertex x="6.49" y="3.94"/>
<vertex x="6.49" y="3.93"/>
<vertex x="6.48" y="3.92"/>
<vertex x="6.48" y="3.9"/>
<vertex x="6.48" y="3.89"/>
<vertex x="6.48" y="3.87"/>
<vertex x="6.48" y="3.85"/>
<vertex x="6.48" y="3.84"/>
<vertex x="6.49" y="3.82"/>
<vertex x="6.5" y="3.8"/>
<vertex x="6.52" y="3.78"/>
<vertex x="6.54" y="3.76"/>
<vertex x="6.56" y="3.75"/>
<vertex x="6.59" y="3.73"/>
<vertex x="6.61" y="3.73"/>
<vertex x="6.63" y="3.73"/>
<vertex x="6.65" y="3.73"/>
<vertex x="6.66" y="3.73"/>
<vertex x="6.68" y="3.74"/>
<vertex x="6.69" y="3.75"/>
<vertex x="6.7" y="3.76"/>
<vertex x="6.71" y="3.77"/>
<vertex x="6.72" y="3.78"/>
<vertex x="6.73" y="3.8"/>
<vertex x="6.74" y="3.81"/>
<vertex x="6.74" y="3.82"/>
<vertex x="6.75" y="3.83"/>
<vertex x="6.75" y="3.84"/>
<vertex x="7.75" y="6.31"/>
<vertex x="7.75" y="6.32"/>
<vertex x="7.76" y="6.34"/>
<vertex x="7.77" y="6.36"/>
<vertex x="7.79" y="6.39"/>
<vertex x="7.81" y="6.41"/>
<vertex x="7.83" y="6.44"/>
<vertex x="7.85" y="6.47"/>
<vertex x="7.88" y="6.5"/>
<vertex x="7.92" y="6.52"/>
<vertex x="7.95" y="6.54"/>
<vertex x="8" y="6.56"/>
<vertex x="8.04" y="6.57"/>
<vertex x="8.09" y="6.57"/>
<vertex x="8.15" y="6.56"/>
<vertex x="8.2" y="6.54"/>
<vertex x="8.26" y="6.51"/>
<vertex x="8.3" y="6.48"/>
<vertex x="8.34" y="6.45"/>
<vertex x="8.36" y="6.41"/>
<vertex x="8.38" y="6.37"/>
<vertex x="8.39" y="6.33"/>
<vertex x="8.4" y="6.29"/>
<vertex x="8.4" y="6.25"/>
<vertex x="8.4" y="6.21"/>
<vertex x="8.39" y="6.18"/>
<vertex x="8.39" y="6.14"/>
<vertex x="8.38" y="6.12"/>
<vertex x="8.37" y="6.09"/>
<vertex x="8.36" y="6.07"/>
<vertex x="8.36" y="6.06"/>
<vertex x="7.1" y="2.99"/>
<vertex x="7.09" y="2.98"/>
<vertex x="7.09" y="2.97"/>
<vertex x="7.08" y="2.95"/>
<vertex x="7.08" y="2.94"/>
<vertex x="7.07" y="2.92"/>
<vertex x="7.07" y="2.9"/>
<vertex x="7.07" y="2.88"/>
<vertex x="7.07" y="2.86"/>
<vertex x="7.08" y="2.84"/>
<vertex x="7.09" y="2.82"/>
<vertex x="7.1" y="2.81"/>
<vertex x="7.12" y="2.79"/>
<vertex x="7.15" y="2.77"/>
<vertex x="7.18" y="2.76"/>
<vertex x="7.21" y="2.75"/>
<vertex x="7.23" y="2.74"/>
<vertex x="7.26" y="2.74"/>
<vertex x="7.28" y="2.75"/>
<vertex x="7.29" y="2.75"/>
<vertex x="7.31" y="2.76"/>
<vertex x="7.32" y="2.77"/>
<vertex x="7.33" y="2.78"/>
<vertex x="7.34" y="2.79"/>
<vertex x="7.35" y="2.8"/>
<vertex x="7.35" y="2.81"/>
<vertex x="7.35" y="2.82"/>
<vertex x="7.36" y="2.83"/>
<vertex x="7.36" y="2.84"/>
<vertex x="7.87" y="4.09"/>
<vertex x="7.87" y="4.1"/>
<vertex x="7.87" y="4.11"/>
<vertex x="7.88" y="4.12"/>
<vertex x="7.89" y="4.14"/>
<vertex x="7.9" y="4.16"/>
<vertex x="7.92" y="4.18"/>
<vertex x="7.93" y="4.2"/>
<vertex x="7.95" y="4.22"/>
<vertex x="7.98" y="4.24"/>
<vertex x="8.01" y="4.26"/>
<vertex x="8.04" y="4.28"/>
<vertex x="8.07" y="4.29"/>
<vertex x="8.1" y="4.29"/>
<vertex x="8.14" y="4.29"/>
<vertex x="8.18" y="4.29"/>
<vertex x="8.23" y="4.27"/>
<vertex x="8.29" y="4.25"/>
<vertex x="8.34" y="4.22"/>
<vertex x="8.37" y="4.18"/>
<vertex x="8.41" y="4.15"/>
<vertex x="8.43" y="4.11"/>
<vertex x="8.45" y="4.08"/>
<vertex x="8.46" y="4.04"/>
<vertex x="8.47" y="4.01"/>
<vertex x="8.47" y="3.97"/>
<vertex x="8.47" y="3.94"/>
<vertex x="8.46" y="3.92"/>
<vertex x="8.46" y="3.89"/>
<vertex x="8.45" y="3.87"/>
<vertex x="8.45" y="3.86"/>
</polygon>
<vertex x="9.3" y="2.03"/>
<vertex x="9.37" y="2.09"/>
<vertex x="9.44" y="2.15"/>
<vertex x="9.51" y="2.22"/>
<vertex x="9.58" y="2.29"/>
<vertex x="9.64" y="2.37"/>
<vertex x="9.69" y="2.46"/>
<vertex x="9.75" y="2.55"/>
<vertex x="9.8" y="2.64"/>
<vertex x="9.84" y="2.74"/>
<vertex x="9.89" y="2.84"/>
<vertex x="9.92" y="2.95"/>
<vertex x="9.96" y="3.06"/>
<vertex x="9.99" y="3.17"/>
<vertex x="10.01" y="3.29"/>
<vertex x="10.03" y="3.4"/>
<vertex x="10.05" y="3.52"/>
<vertex x="10.06" y="3.64"/>
<vertex x="10.06" y="3.76"/>
<vertex x="10.06" y="3.88"/>
<vertex x="10.06" y="4"/>
<vertex x="10.05" y="4.11"/>
<vertex x="10.03" y="4.22"/>
<vertex x="10.01" y="4.33"/>
<vertex x="9.99" y="4.44"/>
<vertex x="9.96" y="4.54"/>
<vertex x="9.93" y="4.64"/>
<vertex x="9.89" y="4.74"/>
<vertex x="9.84" y="4.83"/>
<vertex x="9.8" y="4.91"/>
<vertex x="9.74" y="4.99"/>
<vertex x="9.69" y="5.07"/>
<vertex x="9.63" y="5.14"/>
<vertex x="9.7" y="5.21"/>
<vertex x="9.79" y="5.13"/>
<vertex x="9.88" y="5.05"/>
<vertex x="9.95" y="4.96"/>
<vertex x="10.02" y="4.86"/>
<vertex x="10.08" y="4.76"/>
<vertex x="10.14" y="4.66"/>
<vertex x="10.19" y="4.56"/>
<vertex x="10.23" y="4.45"/>
<vertex x="10.26" y="4.34"/>
<vertex x="10.29" y="4.22"/>
<vertex x="10.31" y="4.11"/>
<vertex x="10.32" y="3.99"/>
<vertex x="10.33" y="3.87"/>
<vertex x="10.33" y="3.75"/>
<vertex x="10.33" y="3.62"/>
<vertex x="10.32" y="3.5"/>
<vertex x="10.3" y="3.37"/>
<vertex x="10.28" y="3.25"/>
<vertex x="10.25" y="3.13"/>
<vertex x="10.22" y="3.01"/>
<vertex x="10.18" y="2.9"/>
<vertex x="10.14" y="2.79"/>
<vertex x="10.09" y="2.68"/>
<vertex x="10.03" y="2.58"/>
<vertex x="9.97" y="2.48"/>
<vertex x="9.9" y="2.39"/>
<vertex x="9.82" y="2.3"/>
<vertex x="9.74" y="2.22"/>
<vertex x="9.66" y="2.14"/>
<vertex x="9.56" y="2.07"/>
<vertex x="9.46" y="2"/>
<vertex x="9.36" y="1.94"/>
</polygon>
<vertex x="8.57" y="2.62"/>
<vertex x="8.62" y="2.65"/>
<vertex x="8.66" y="2.69"/>
<vertex x="8.7" y="2.73"/>
<vertex x="8.74" y="2.78"/>
<vertex x="8.78" y="2.83"/>
<vertex x="8.81" y="2.88"/>
<vertex x="8.85" y="2.94"/>
<vertex x="8.88" y="2.99"/>
<vertex x="8.91" y="3.06"/>
<vertex x="8.93" y="3.12"/>
<vertex x="8.96" y="3.18"/>
<vertex x="8.98" y="3.25"/>
<vertex x="9" y="3.32"/>
<vertex x="9.01" y="3.39"/>
<vertex x="9.03" y="3.46"/>
<vertex x="9.04" y="3.54"/>
<vertex x="9.04" y="3.61"/>
<vertex x="9.04" y="3.68"/>
<vertex x="9.04" y="3.76"/>
<vertex x="9.04" y="3.83"/>
<vertex x="9.03" y="3.9"/>
<vertex x="9.02" y="3.97"/>
<vertex x="9.01" y="4.03"/>
<vertex x="8.99" y="4.1"/>
<vertex x="8.98" y="4.16"/>
<vertex x="8.95" y="4.22"/>
<vertex x="8.93" y="4.28"/>
<vertex x="8.9" y="4.34"/>
<vertex x="8.87" y="4.39"/>
<vertex x="8.84" y="4.44"/>
<vertex x="8.81" y="4.48"/>
<vertex x="8.77" y="4.53"/>
<vertex x="8.84" y="4.59"/>
<vertex x="8.9" y="4.54"/>
<vertex x="8.96" y="4.49"/>
<vertex x="9.01" y="4.43"/>
<vertex x="9.06" y="4.37"/>
<vertex x="9.11" y="4.31"/>
<vertex x="9.15" y="4.24"/>
<vertex x="9.18" y="4.17"/>
<vertex x="9.21" y="4.1"/>
<vertex x="9.23" y="4.03"/>
<vertex x="9.26" y="3.96"/>
<vertex x="9.27" y="3.89"/>
<vertex x="9.28" y="3.81"/>
<vertex x="9.29" y="3.74"/>
<vertex x="9.29" y="3.66"/>
<vertex x="9.29" y="3.59"/>
<vertex x="9.29" y="3.51"/>
<vertex x="9.28" y="3.44"/>
<vertex x="9.26" y="3.36"/>
<vertex x="9.24" y="3.29"/>
<vertex x="9.22" y="3.22"/>
<vertex x="9.19" y="3.15"/>
<vertex x="9.16" y="3.08"/>
<vertex x="9.13" y="3.01"/>
<vertex x="9.09" y="2.95"/>
<vertex x="9.05" y="2.89"/>
<vertex x="9" y="2.83"/>
<vertex x="8.95" y="2.77"/>
<vertex x="8.89" y="2.72"/>
<vertex x="8.83" y="2.67"/>
<vertex x="8.77" y="2.62"/>
<vertex x="8.7" y="2.58"/>
<vertex x="8.62" y="2.54"/>
</polygon>
<polygon width="0" layer="21">
<vertex x="9.96" y="1.4"/>
<vertex x="10.06" y="1.47"/>
<vertex x="10.15" y="1.55"/>
<vertex x="10.24" y="1.64"/>
<vertex x="10.33" y="1.74"/>
<vertex x="10.41" y="1.85"/>
<vertex x="10.48" y="1.96"/>
<vertex x="10.56" y="2.08"/>
<vertex x="10.62" y="2.21"/>
<vertex x="10.68" y="2.34"/>
<vertex x="10.74" y="2.48"/>
<vertex x="10.79" y="2.62"/>
<vertex x="10.84" y="2.76"/>
<vertex x="10.87" y="2.91"/>
<vertex x="10.91" y="3.07"/>
<vertex x="10.93" y="3.22"/>
<vertex x="10.95" y="3.38"/>
<vertex x="10.97" y="3.54"/>
<vertex x="10.97" y="3.7"/>
<vertex x="10.97" y="3.86"/>
<vertex x="10.97" y="4.01"/>
<vertex x="10.95" y="4.16"/>
<vertex x="10.93" y="4.31"/>
<vertex x="10.91" y="4.46"/>
<vertex x="10.88" y="4.6"/>
<vertex x="10.84" y="4.74"/>
<vertex x="10.79" y="4.87"/>
<vertex x="10.74" y="5"/>
<vertex x="10.68" y="5.12"/>
<vertex x="10.62" y="5.23"/>
<vertex x="10.55" y="5.34"/>
<vertex x="10.47" y="5.44"/>
<vertex x="10.39" y="5.53"/>
<vertex x="10.49" y="5.63"/>
<vertex x="10.61" y="5.52"/>
<vertex x="10.73" y="5.41"/>
<vertex x="10.83" y="5.29"/>
<vertex x="10.92" y="5.16"/>
<vertex x="11" y="5.03"/>
<vertex x="11.07" y="4.9"/>
<vertex x="11.14" y="4.76"/>
<vertex x="11.19" y="4.61"/>
<vertex x="11.24" y="4.46"/>
<vertex x="11.27" y="4.31"/>
<vertex x="11.3" y="4.16"/>
<vertex x="11.32" y="4"/>
<vertex x="11.33" y="3.84"/>
<vertex x="11.34" y="3.68"/>
<vertex x="11.33" y="3.52"/>
<vertex x="11.32" y="3.35"/>
<vertex x="11.29" y="3.18"/>
<vertex x="11.27" y="3.02"/>
<vertex x="11.23" y="2.86"/>
<vertex x="11.19" y="2.7"/>
<vertex x="11.13" y="2.55"/>
<vertex x="11.07" y="2.4"/>
<vertex x="11.01" y="2.26"/>
<vertex x="10.93" y="2.13"/>
<vertex x="10.85" y="2"/>
<vertex x="10.76" y="1.87"/>
<vertex x="10.66" y="1.75"/>
<vertex x="10.55" y="1.64"/>
<vertex x="10.43" y="1.54"/>
<vertex x="10.31" y="1.44"/>
<vertex x="10.18" y="1.35"/>
<vertex x="10.03" y="1.27"/>
</polygon>
<vertex x="2.17" y="0.72"/>
<vertex x="2.1" y="0.78"/>
<vertex x="2.03" y="0.85"/>
<vertex x="1.97" y="0.92"/>
<vertex x="1.91" y="1"/>
<vertex x="1.86" y="1.09"/>
<vertex x="1.81" y="1.18"/>
<vertex x="1.77" y="1.27"/>
<vertex x="1.73" y="1.37"/>
<vertex x="1.69" y="1.47"/>
<vertex x="1.66" y="1.58"/>
<vertex x="1.63" y="1.69"/>
<vertex x="1.61" y="1.8"/>
<vertex x="1.59" y="1.92"/>
<vertex x="1.58" y="2.04"/>
<vertex x="1.57" y="2.15"/>
<vertex x="1.56" y="2.27"/>
<vertex x="1.56" y="2.4"/>
<vertex x="1.57" y="2.51"/>
<vertex x="1.58" y="2.63"/>
<vertex x="1.6" y="2.75"/>
<vertex x="1.62" y="2.86"/>
<vertex x="1.64" y="2.97"/>
<vertex x="1.67" y="3.08"/>
<vertex x="1.71" y="3.18"/>
<vertex x="1.75" y="3.28"/>
<vertex x="1.79" y="3.37"/>
<vertex x="1.84" y="3.46"/>
<vertex x="1.89" y="3.55"/>
<vertex x="1.95" y="3.63"/>
<vertex x="2.01" y="3.71"/>
<vertex x="2.07" y="3.78"/>
<vertex x="2.14" y="3.84"/>
<vertex x="2.07" y="3.92"/>
<vertex x="1.97" y="3.85"/>
<vertex x="1.88" y="3.77"/>
<vertex x="1.8" y="3.69"/>
<vertex x="1.72" y="3.6"/>
<vertex x="1.65" y="3.51"/>
<vertex x="1.58" y="3.41"/>
<vertex x="1.52" y="3.31"/>
<vertex x="1.47" y="3.21"/>
<vertex x="1.43" y="3.1"/>
<vertex x="1.39" y="2.99"/>
<vertex x="1.36" y="2.88"/>
<vertex x="1.33" y="2.76"/>
<vertex x="1.31" y="2.65"/>
<vertex x="1.3" y="2.52"/>
<vertex x="1.29" y="2.4"/>
<vertex x="1.29" y="2.28"/>
<vertex x="1.29" y="2.27"/>
<vertex x="1.29" y="2.15"/>
<vertex x="1.3" y="2.02"/>
<vertex x="1.32" y="1.9"/>
<vertex x="1.34" y="1.78"/>
<vertex x="1.37" y="1.66"/>
<vertex x="1.4" y="1.55"/>
<vertex x="1.44" y="1.44"/>
<vertex x="1.49" y="1.33"/>
<vertex x="1.54" y="1.23"/>
<vertex x="1.6" y="1.13"/>
<vertex x="1.67" y="1.04"/>
<vertex x="1.74" y="0.94"/>
<vertex x="1.82" y="0.86"/>
<vertex x="1.91" y="0.78"/>
<vertex x="2" y="0.7"/>
<vertex x="2.1" y="0.63"/>
</polygon>
<vertex x="2.94" y="1.23"/>
<vertex x="2.9" y="1.27"/>
<vertex x="2.86" y="1.31"/>
<vertex x="2.83" y="1.36"/>
<vertex x="2.79" y="1.41"/>
<vertex x="2.76" y="1.46"/>
<vertex x="2.73" y="1.52"/>
<vertex x="2.7" y="1.58"/>
<vertex x="2.68" y="1.64"/>
<vertex x="2.65" y="1.7"/>
<vertex x="2.63" y="1.77"/>
<vertex x="2.62" y="1.83"/>
<vertex x="2.6" y="1.9"/>
<vertex x="2.59" y="1.97"/>
<vertex x="2.58" y="2.04"/>
<vertex x="2.57" y="2.12"/>
<vertex x="2.57" y="2.19"/>
<vertex x="2.57" y="2.26"/>
<vertex x="2.58" y="2.34"/>
<vertex x="2.58" y="2.41"/>
<vertex x="2.6" y="2.48"/>
<vertex x="2.61" y="2.55"/>
<vertex x="2.63" y="2.62"/>
<vertex x="2.64" y="2.68"/>
<vertex x="2.67" y="2.75"/>
<vertex x="2.69" y="2.81"/>
<vertex x="2.72" y="2.87"/>
<vertex x="2.75" y="2.92"/>
<vertex x="2.78" y="2.98"/>
<vertex x="2.81" y="3.02"/>
<vertex x="2.85" y="3.07"/>
<vertex x="2.89" y="3.11"/>
<vertex x="2.93" y="3.15"/>
<vertex x="2.87" y="3.22"/>
<vertex x="2.8" y="3.18"/>
<vertex x="2.74" y="3.13"/>
<vertex x="2.68" y="3.08"/>
<vertex x="2.62" y="3.02"/>
<vertex x="2.57" y="2.96"/>
<vertex x="2.53" y="2.9"/>
<vertex x="2.49" y="2.84"/>
<vertex x="2.45" y="2.77"/>
<vertex x="2.42" y="2.7"/>
<vertex x="2.39" y="2.63"/>
<vertex x="2.37" y="2.56"/>
<vertex x="2.35" y="2.49"/>
<vertex x="2.34" y="2.42"/>
<vertex x="2.33" y="2.34"/>
<vertex x="2.32" y="2.27"/>
<vertex x="2.32" y="2.19"/>
<vertex x="2.32" y="2.11"/>
<vertex x="2.33" y="2.04"/>
<vertex x="2.34" y="1.96"/>
<vertex x="2.36" y="1.89"/>
<vertex x="2.38" y="1.82"/>
<vertex x="2.4" y="1.75"/>
<vertex x="2.43" y="1.68"/>
<vertex x="2.46" y="1.61"/>
<vertex x="2.5" y="1.54"/>
<vertex x="2.54" y="1.48"/>
<vertex x="2.59" y="1.42"/>
<vertex x="2.64" y="1.36"/>
<vertex x="2.69" y="1.31"/>
<vertex x="2.75" y="1.26"/>
<vertex x="2.82" y="1.21"/>
<vertex x="2.89" y="1.16"/>
</polygon>
<vertex x="1.45" y="0.15"/>
<vertex x="1.36" y="0.23"/>
<vertex x="1.27" y="0.32"/>
<vertex x="1.19" y="0.42"/>
<vertex x="1.11" y="0.53"/>
<vertex x="1.04" y="0.64"/>
<vertex x="0.98" y="0.76"/>
<vertex x="0.92" y="0.89"/>
<vertex x="0.86" y="1.02"/>
<vertex x="0.82" y="1.16"/>
<vertex x="0.77" y="1.3"/>
<vertex x="0.74" y="1.44"/>
<vertex x="0.71" y="1.59"/>
<vertex x="0.68" y="1.75"/>
<vertex x="0.66" y="1.9"/>
<vertex x="0.65" y="2.06"/>
<vertex x="0.65" y="2.22"/>
<vertex x="0.65" y="2.38"/>
<vertex x="0.66" y="2.54"/>
<vertex x="0.67" y="2.7"/>
<vertex x="0.69" y="2.85"/>
<vertex x="0.72" y="3"/>
<vertex x="0.76" y="3.15"/>
<vertex x="0.8" y="3.29"/>
<vertex x="0.84" y="3.43"/>
<vertex x="0.89" y="3.56"/>
<vertex x="0.95" y="3.68"/>
<vertex x="1.01" y="3.81"/>
<vertex x="1.08" y="3.92"/>
<vertex x="1.16" y="4.03"/>
<vertex x="1.24" y="4.13"/>
<vertex x="1.32" y="4.22"/>
<vertex x="1.41" y="4.3"/>
<vertex x="1.32" y="4.42"/>
<vertex x="1.19" y="4.32"/>
<vertex x="1.07" y="4.22"/>
<vertex x="0.96" y="4.11"/>
<vertex x="0.85" y="3.99"/>
<vertex x="0.76" y="3.87"/>
<vertex x="0.67" y="3.74"/>
<vertex x="0.6" y="3.61"/>
<vertex x="0.53" y="3.47"/>
<vertex x="0.47" y="3.33"/>
<vertex x="0.42" y="3.18"/>
<vertex x="0.37" y="3.03"/>
<vertex x="0.34" y="2.87"/>
<vertex x="0.31" y="2.71"/>
<vertex x="0.3" y="2.55"/>
<vertex x="0.29" y="2.39"/>
<vertex x="0.28" y="2.22"/>
<vertex x="0.29" y="2.05"/>
<vertex x="0.3" y="1.88"/>
<vertex x="0.32" y="1.72"/>
<vertex x="0.35" y="1.56"/>
<vertex x="0.39" y="1.41"/>
<vertex x="0.43" y="1.26"/>
<vertex x="0.49" y="1.11"/>
<vertex x="0.55" y="0.97"/>
<vertex x="0.62" y="0.83"/>
<vertex x="0.7" y="0.7"/>
<vertex x="0.79" y="0.57"/>
<vertex x="0.88" y="0.45"/>
<vertex x="0.99" y="0.34"/>
<vertex x="1.1" y="0.23"/>
<vertex x="1.23" y="0.13"/>
<vertex x="1.36" y="0.03"/>
</polygon>
</package>
<package name="BREADBOARD_SPACING">
<wire x1="-24.13" y1="1.27" x2="-24.13" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-21.59" y1="1.27" x2="-21.59" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-13.97" y1="1.27" x2="-13.97" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-11.43" y1="1.27" x2="-11.43" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-8.89" y1="1.27" x2="-8.89" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-6.35" y1="1.27" x2="-6.35" y2="-1.27" width="0.254" layer="51"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="-1.27" width="0.254" layer="51"/>
<wire x1="13.97" y1="1.27" x2="13.97" y2="-1.27" width="0.254" layer="51"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-1.27" width="0.254" layer="51"/>
<wire x1="6.35" y1="1.27" x2="6.35" y2="-1.27" width="0.254" layer="51"/>
<wire x1="8.89" y1="1.27" x2="8.89" y2="-1.27" width="0.254" layer="51"/>
<wire x1="11.43" y1="1.27" x2="11.43" y2="-1.27" width="0.254" layer="51"/>
<wire x1="24.13" y1="1.27" x2="24.13" y2="-1.27" width="0.254" layer="51"/>
<wire x1="21.59" y1="1.27" x2="21.59" y2="-1.27" width="0.254" layer="51"/>
<text x="0" y="1.905" size="1.27" layer="51" font="vector" ratio="15" align="bottom-center">Breadboard row spacing:</text>
</package>
</packages>
<symbols>
<symbol name="ANDROID-ELECTRIC_SHEEP_LOGO">
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-2.54" x2="3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="2.54" x2="-3.81" y2="2.54" width="0.254" layer="94"/>
<text x="-1.778" y="-1.016" size="1.778" layer="94">ES</text>
</symbol>
<symbol name="CREATIVE_COMMONS">
<text x="0" y="5.08" size="1.778" layer="95">Released under the Creative Commons Attribution Share-Alike 3.0 License</text>
<text x="0" y="2.54" size="1.778" layer="95">http://creativecommons.org/licenses/by-sa/3.0</text>
<text x="0" y="0" size="1.778" layer="95">Design by:</text>
</symbol>
<symbol name="DGND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="FIDUCIAL">
<wire x1="-0.762" y1="0.762" x2="0.762" y2="-0.762" width="0.254" layer="94"/>
<wire x1="0.762" y1="0.762" x2="-0.762" y2="-0.762" width="0.254" layer="94"/>
<circle x="0" y="0" radius="1.27" width="0.254" layer="94"/>
</symbol>
<symbol name="FIDUCIALTAB">
<circle x="0" y="0" radius="0.8032" width="0.254" layer="94"/>
</symbol>
<symbol name="FIO_LOGO">
<text x="0" y="0" size="1.778" layer="94">FIO_LOGO</text>
</symbol>
<symbol name="FKIT-LOGO">
<text x="0" y="0" size="2.54" layer="94" font="vector">Fabrickit logo</text>
</symbol>
<symbol name="FKIT-LOGOTYPE">
<text x="0" y="0" size="2.54" layer="94" font="vector">Fabrickit logotype</text>
</symbol>
<symbol name="A3L-LOC">
<wire x1="0" y1="0" x2="50.8" y2="0" width="0.1016" layer="94"/>
<wire x1="50.8" y1="0" x2="98.425" y2="0" width="0.1016" layer="94"/>
<wire x1="98.425" y1="0" x2="146.05" y2="0" width="0.1016" layer="94"/>
<wire x1="146.05" y1="0" x2="193.675" y2="0" width="0.1016" layer="94"/>
<wire x1="193.675" y1="0" x2="241.3" y2="0" width="0.1016" layer="94"/>
<wire x1="241.3" y1="0" x2="288.925" y2="0" width="0.1016" layer="94"/>
<wire x1="288.925" y1="0" x2="336.55" y2="0" width="0.1016" layer="94"/>
<wire x1="336.55" y1="0" x2="387.35" y2="0" width="0.1016" layer="94"/>
<wire x1="387.35" y1="0" x2="387.35" y2="53.975" width="0.1016" layer="94"/>
<wire x1="387.35" y1="53.975" x2="387.35" y2="104.775" width="0.1016" layer="94"/>
<wire x1="387.35" y1="104.775" x2="387.35" y2="155.575" width="0.1016" layer="94"/>
<wire x1="387.35" y1="155.575" x2="387.35" y2="206.375" width="0.1016" layer="94"/>
<wire x1="387.35" y1="206.375" x2="387.35" y2="260.35" width="0.1016" layer="94"/>
<wire x1="146.05" y1="260.35" x2="98.425" y2="260.35" width="0.1016" layer="94"/>
<wire x1="98.425" y1="260.35" x2="50.8" y2="260.35" width="0.1016" layer="94"/>
<wire x1="50.8" y1="260.35" x2="0" y2="260.35" width="0.1016" layer="94"/>
<wire x1="0" y1="260.35" x2="0" y2="206.375" width="0.1016" layer="94"/>
<wire x1="0" y1="206.375" x2="0" y2="155.575" width="0.1016" layer="94"/>
<wire x1="0" y1="155.575" x2="0" y2="104.775" width="0.1016" layer="94"/>
<wire x1="0" y1="104.775" x2="0" y2="53.975" width="0.1016" layer="94"/>
<wire x1="0" y1="53.975" x2="0" y2="0" width="0.1016" layer="94"/>
<wire x1="3.175" y1="3.175" x2="50.8" y2="3.175" width="0.1016" layer="94"/>
<wire x1="50.8" y1="3.175" x2="98.425" y2="3.175" width="0.1016" layer="94"/>
<wire x1="98.425" y1="3.175" x2="146.05" y2="3.175" width="0.1016" layer="94"/>
<wire x1="146.05" y1="3.175" x2="193.675" y2="3.175" width="0.1016" layer="94"/>
<wire x1="193.675" y1="3.175" x2="241.3" y2="3.175" width="0.1016" layer="94"/>
<wire x1="241.3" y1="3.175" x2="288.925" y2="3.175" width="0.1016" layer="94"/>
<wire x1="288.925" y1="3.175" x2="307.34" y2="3.175" width="0.1016" layer="94"/>
<wire x1="336.55" y1="3.175" x2="307.34" y2="3.175" width="0.1016" layer="94"/>
<wire x1="307.34" y1="3.175" x2="366.395" y2="3.175" width="0.1016" layer="94"/>
<wire x1="366.395" y1="3.175" x2="384.175" y2="3.175" width="0.1016" layer="94"/>
<wire x1="384.175" y1="3.175" x2="384.175" y2="8.255" width="0.1016" layer="94"/>
<wire x1="384.175" y1="8.255" x2="384.175" y2="13.335" width="0.1016" layer="94"/>
<wire x1="384.175" y1="13.335" x2="384.175" y2="18.415" width="0.1016" layer="94"/>
<wire x1="384.175" y1="18.415" x2="384.175" y2="23.495" width="0.1016" layer="94"/>
<wire x1="384.175" y1="23.495" x2="384.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="384.175" y1="53.975" x2="384.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="384.175" y1="104.775" x2="384.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="384.175" y1="155.575" x2="384.175" y2="206.375" width="0.1016" layer="94"/>
<wire x1="384.175" y1="206.375" x2="384.175" y2="257.175" width="0.1016" layer="94"/>
<wire x1="384.175" y1="257.175" x2="336.55" y2="257.175" width="0.1016" layer="94"/>
<wire x1="336.55" y1="257.175" x2="288.925" y2="257.175" width="0.1016" layer="94"/>
<wire x1="288.925" y1="257.175" x2="241.3" y2="257.175" width="0.1016" layer="94"/>
<wire x1="241.3" y1="257.175" x2="193.675" y2="257.175" width="0.1016" layer="94"/>
<wire x1="193.675" y1="257.175" x2="146.05" y2="257.175" width="0.1016" layer="94"/>
<wire x1="146.05" y1="257.175" x2="98.425" y2="257.175" width="0.1016" layer="94"/>
<wire x1="98.425" y1="257.175" x2="50.8" y2="257.175" width="0.1016" layer="94"/>
<wire x1="50.8" y1="257.175" x2="3.175" y2="257.175" width="0.1016" layer="94"/>
<wire x1="3.175" y1="257.175" x2="3.175" y2="206.375" width="0.1016" layer="94"/>
<wire x1="3.175" y1="206.375" x2="3.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="3.175" y1="155.575" x2="3.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="3.175" y1="104.775" x2="3.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="3.175" y1="53.975" x2="3.175" y2="3.175" width="0.1016" layer="94"/>
<wire x1="387.35" y1="260.35" x2="336.55" y2="260.35" width="0.1016" layer="94"/>
<wire x1="336.55" y1="260.35" x2="288.925" y2="260.35" width="0.1016" layer="94"/>
<wire x1="288.925" y1="260.35" x2="241.3" y2="260.35" width="0.1016" layer="94"/>
<wire x1="241.3" y1="260.35" x2="193.675" y2="260.35" width="0.1016" layer="94"/>
<wire x1="193.675" y1="260.35" x2="146.05" y2="260.35" width="0.1016" layer="94"/>
<wire x1="193.675" y1="260.35" x2="193.675" y2="257.175" width="0.1016" layer="94"/>
<wire x1="193.675" y1="3.175" x2="193.675" y2="0" width="0.1016" layer="94"/>
<wire x1="0" y1="104.775" x2="3.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="384.175" y1="155.575" x2="387.35" y2="155.575" width="0.1016" layer="94"/>
<wire x1="98.425" y1="257.175" x2="98.425" y2="260.35" width="0.1016" layer="94"/>
<wire x1="98.425" y1="3.175" x2="98.425" y2="0" width="0.1016" layer="94"/>
<wire x1="288.925" y1="260.35" x2="288.925" y2="257.175" width="0.1016" layer="94"/>
<wire x1="288.925" y1="3.175" x2="288.925" y2="0" width="0.1016" layer="94"/>
<wire x1="0" y1="53.975" x2="3.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="384.175" y1="104.775" x2="387.35" y2="104.775" width="0.1016" layer="94"/>
<wire x1="0" y1="155.575" x2="3.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="384.175" y1="206.375" x2="387.35" y2="206.375" width="0.1016" layer="94"/>
<wire x1="50.8" y1="257.175" x2="50.8" y2="260.35" width="0.1016" layer="94"/>
<wire x1="0" y1="206.375" x2="3.175" y2="206.375" width="0.1016" layer="94"/>
<wire x1="384.175" y1="53.975" x2="387.35" y2="53.975" width="0.1016" layer="94"/>
<wire x1="146.05" y1="257.175" x2="146.05" y2="260.35" width="0.1016" layer="94"/>
<wire x1="241.3" y1="260.35" x2="241.3" y2="257.175" width="0.1016" layer="94"/>
<wire x1="336.55" y1="260.35" x2="336.55" y2="257.175" width="0.1016" layer="94"/>
<wire x1="336.55" y1="3.175" x2="336.55" y2="0" width="0.1016" layer="94"/>
<wire x1="241.3" y1="3.175" x2="241.3" y2="0" width="0.1016" layer="94"/>
<wire x1="146.05" y1="3.175" x2="146.05" y2="0" width="0.1016" layer="94"/>
<wire x1="50.8" y1="0" x2="50.8" y2="3.175" width="0.1016" layer="94"/>
<wire x1="288.925" y1="3.175" x2="288.925" y2="23.495" width="0.6096" layer="94"/>
<wire x1="288.925" y1="23.495" x2="307.34" y2="23.495" width="0.6096" layer="94"/>
<wire x1="307.34" y1="23.495" x2="384.175" y2="23.495" width="0.6096" layer="94"/>
<wire x1="366.395" y1="3.175" x2="366.395" y2="8.255" width="0.1016" layer="94"/>
<wire x1="366.395" y1="8.255" x2="384.175" y2="8.255" width="0.1016" layer="94"/>
<wire x1="366.395" y1="8.255" x2="307.34" y2="8.255" width="0.1016" layer="94"/>
<wire x1="307.34" y1="8.255" x2="307.34" y2="3.175" width="0.6096" layer="94"/>
<wire x1="307.34" y1="8.255" x2="307.34" y2="13.335" width="0.6096" layer="94"/>
<wire x1="307.34" y1="13.335" x2="384.175" y2="13.335" width="0.1016" layer="94"/>
<wire x1="307.34" y1="13.335" x2="307.34" y2="18.415" width="0.6096" layer="94"/>
<wire x1="307.34" y1="18.415" x2="384.175" y2="18.415" width="0.1016" layer="94"/>
<wire x1="307.34" y1="18.415" x2="307.34" y2="23.495" width="0.6096" layer="94"/>
<text x="24.384" y="0.254" size="2.54" layer="94" font="vector">A</text>
<text x="74.422" y="0.254" size="2.54" layer="94" font="vector">B</text>
<text x="121.158" y="0.254" size="2.54" layer="94" font="vector">C</text>
<text x="169.418" y="0.254" size="2.54" layer="94" font="vector">D</text>
<text x="216.916" y="0.254" size="2.54" layer="94" font="vector">E</text>
<text x="263.652" y="0.254" size="2.54" layer="94" font="vector">F</text>
<text x="310.642" y="0.254" size="2.54" layer="94" font="vector">G</text>
<text x="360.934" y="0.254" size="2.54" layer="94" font="vector">H</text>
<text x="385.064" y="28.702" size="2.54" layer="94" font="vector">1</text>
<text x="384.81" y="79.502" size="2.54" layer="94" font="vector">2</text>
<text x="384.81" y="130.302" size="2.54" layer="94" font="vector">3</text>
<text x="384.81" y="181.864" size="2.54" layer="94" font="vector">4</text>
<text x="384.81" y="231.14" size="2.54" layer="94" font="vector">5</text>
<text x="361.188" y="257.556" size="2.54" layer="94" font="vector">H</text>
<text x="311.404" y="257.556" size="2.54" layer="94" font="vector">G</text>
<text x="262.89" y="257.556" size="2.54" layer="94" font="vector">F</text>
<text x="215.9" y="257.556" size="2.54" layer="94" font="vector">E</text>
<text x="168.148" y="257.556" size="2.54" layer="94" font="vector">D</text>
<text x="120.904" y="257.556" size="2.54" layer="94" font="vector">C</text>
<text x="72.898" y="257.556" size="2.54" layer="94" font="vector">B</text>
<text x="24.384" y="257.556" size="2.54" layer="94" font="vector">A</text>
<text x="0.762" y="231.14" size="2.54" layer="94" font="vector">5</text>
<text x="0.762" y="181.61" size="2.54" layer="94" font="vector">4</text>
<text x="0.762" y="130.302" size="2.54" layer="94" font="vector">3</text>
<text x="0.762" y="79.248" size="2.54" layer="94" font="vector">2</text>
<text x="1.016" y="26.67" size="2.54" layer="94" font="vector">1</text>
<text x="319.151" y="19.431" size="2.54" layer="94" font="vector">&gt;DRAWING_NAME</text>
<text x="309.753" y="9.525" size="2.286" layer="94" font="vector">&gt;LAST_DATE_TIME</text>
<text x="368.3" y="4.445" size="2.54" layer="94" font="vector">&gt;SHEET</text>
<text x="309.626" y="4.318" size="2.54" layer="94">Drawn By:</text>
<text x="309.88" y="19.558" size="2.54" layer="94">Title:</text>
<text x="310.134" y="14.478" size="2.54" layer="94">Version:</text>
</symbol>
<symbol name="LETTER_L">
<wire x1="0" y1="185.42" x2="248.92" y2="185.42" width="0.4064" layer="94"/>
<wire x1="248.92" y1="185.42" x2="248.92" y2="0" width="0.4064" layer="94"/>
<wire x1="0" y1="185.42" x2="0" y2="0" width="0.4064" layer="94"/>
<wire x1="0" y1="0" x2="248.92" y2="0" width="0.4064" layer="94"/>
</symbol>
<symbol name="DOCFIELD">
<wire x1="0" y1="0" x2="71.12" y2="0" width="0.254" layer="94"/>
<wire x1="101.6" y1="15.24" x2="87.63" y2="15.24" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="71.12" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="15.24" width="0.254" layer="94"/>
<wire x1="101.6" y1="15.24" x2="101.6" y2="5.08" width="0.254" layer="94"/>
<wire x1="71.12" y1="5.08" x2="71.12" y2="0" width="0.254" layer="94"/>
<wire x1="71.12" y1="5.08" x2="87.63" y2="5.08" width="0.254" layer="94"/>
<wire x1="71.12" y1="0" x2="101.6" y2="0" width="0.254" layer="94"/>
<wire x1="87.63" y1="15.24" x2="87.63" y2="5.08" width="0.254" layer="94"/>
<wire x1="87.63" y1="15.24" x2="0" y2="15.24" width="0.254" layer="94"/>
<wire x1="87.63" y1="5.08" x2="101.6" y2="5.08" width="0.254" layer="94"/>
<wire x1="101.6" y1="5.08" x2="101.6" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="15.24" x2="0" y2="22.86" width="0.254" layer="94"/>
<wire x1="101.6" y1="35.56" x2="0" y2="35.56" width="0.254" layer="94"/>
<wire x1="101.6" y1="35.56" x2="101.6" y2="22.86" width="0.254" layer="94"/>
<wire x1="0" y1="22.86" x2="101.6" y2="22.86" width="0.254" layer="94"/>
<wire x1="0" y1="22.86" x2="0" y2="35.56" width="0.254" layer="94"/>
<wire x1="101.6" y1="22.86" x2="101.6" y2="15.24" width="0.254" layer="94"/>
<text x="1.27" y="1.27" size="2.54" layer="94" font="vector">Date:</text>
<text x="12.7" y="1.27" size="2.54" layer="94" font="vector">&gt;LAST_DATE_TIME</text>
<text x="72.39" y="1.27" size="2.54" layer="94" font="vector">Sheet:</text>
<text x="86.36" y="1.27" size="2.54" layer="94" font="vector">&gt;SHEET</text>
<text x="88.9" y="11.43" size="2.54" layer="94" font="vector">REV:</text>
<text x="1.524" y="17.78" size="2.54" layer="94" font="vector">TITLE:</text>
<text x="15.494" y="17.78" size="2.7432" layer="94" font="vector">&gt;DRAWING_NAME</text>
<text x="2.54" y="31.75" size="1.9304" layer="94">Released under the Creative Commons</text>
<text x="2.54" y="27.94" size="1.9304" layer="94">Attribution Share-Alike 4.0 License</text>
<text x="2.54" y="24.13" size="1.9304" layer="94"> https://creativecommons.org/licenses/by-sa/4.0/</text>
<text x="1.27" y="11.43" size="2.54" layer="94">Design by:</text>
</symbol>
<symbol name="GND_CONNECT">
<wire x1="5.08" y1="10.16" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="10.16" width="0.254" layer="94"/>
<wire x1="-5.08" y1="10.16" x2="5.08" y2="10.16" width="0.254" layer="94"/>
<pin name="IN" x="-10.16" y="2.54" length="middle"/>
<pin name="AGND" x="10.16" y="7.62" length="middle" rot="R180"/>
<pin name="DGND" x="10.16" y="-2.54" length="middle" rot="R180"/>
</symbol>
<symbol name="FIRST">
<wire x1="0" y1="7.62" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="10.16" y2="0" width="0.254" layer="94"/>
<wire x1="10.16" y1="0" x2="10.16" y2="7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="7.62" x2="0" y2="7.62" width="0.254" layer="94"/>
<text x="1.27" y="2.54" size="1.9304" layer="94">FIRST</text>
</symbol>
<symbol name="OVERTONE_LOGO">
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.9304" layer="94">OTL</text>
</symbol>
<symbol name="LOGO1">
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="7.62" y2="-2.54" width="0.254" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-2.54" y2="5.08" width="0.254" layer="94"/>
<text x="0" y="0" size="1.9304" layer="94">SFE</text>
</symbol>
<symbol name="OSHW-LOGO">
<rectangle x1="-9.5059" y1="-9.0106" x2="-9.4043" y2="-8.9979" layer="94"/>
<rectangle x1="-9.5186" y1="-8.9979" x2="-9.3916" y2="-8.9852" layer="94"/>
<rectangle x1="-9.5313" y1="-8.9852" x2="-9.3789" y2="-8.9725" layer="94"/>
<rectangle x1="-9.5313" y1="-8.9725" x2="-9.3535" y2="-8.9598" layer="94"/>
<rectangle x1="-9.544" y1="-8.9598" x2="-9.3281" y2="-8.9471" layer="94"/>
<rectangle x1="-9.544" y1="-8.9471" x2="-9.29" y2="-8.9344" layer="94"/>
<rectangle x1="-9.544" y1="-8.9344" x2="-9.2392" y2="-8.9217" layer="94"/>
<rectangle x1="-9.544" y1="-8.9217" x2="-9.2138" y2="-8.909" layer="94"/>
<rectangle x1="-9.544" y1="-8.909" x2="-9.2011" y2="-8.8963" layer="94"/>
<rectangle x1="-9.544" y1="-8.8963" x2="-9.1884" y2="-8.8836" layer="94"/>
<rectangle x1="-9.544" y1="-8.8836" x2="-9.1757" y2="-8.8709" layer="94"/>
<rectangle x1="-9.544" y1="-8.8709" x2="-9.1757" y2="-8.8582" layer="94"/>
<rectangle x1="-9.544" y1="-8.8582" x2="-9.163" y2="-8.8455" layer="94"/>
<rectangle x1="-9.544" y1="-8.8455" x2="-9.163" y2="-8.8328" layer="94"/>
<rectangle x1="-9.544" y1="-8.8328" x2="-9.163" y2="-8.8201" layer="94"/>
<rectangle x1="-9.544" y1="-8.8201" x2="-9.163" y2="-8.8074" layer="94"/>
<rectangle x1="-9.544" y1="-8.8074" x2="-9.163" y2="-8.7947" layer="94"/>
<rectangle x1="-9.544" y1="-8.7947" x2="-9.163" y2="-8.782" layer="94"/>
<rectangle x1="-9.544" y1="-8.782" x2="-9.163" y2="-8.7693" layer="94"/>
<rectangle x1="-9.544" y1="-8.7693" x2="-9.163" y2="-8.7566" layer="94"/>
<rectangle x1="-9.544" y1="-8.7566" x2="-9.163" y2="-8.7439" layer="94"/>
<rectangle x1="-9.544" y1="-8.7439" x2="-9.163" y2="-8.7312" layer="94"/>
<rectangle x1="-9.544" y1="-8.7312" x2="-9.163" y2="-8.7185" layer="94"/>
<rectangle x1="-9.544" y1="-8.7185" x2="-9.163" y2="-8.7058" layer="94"/>
<rectangle x1="-9.544" y1="-8.7058" x2="-9.163" y2="-8.6931" layer="94"/>
<rectangle x1="-9.544" y1="-8.6931" x2="-9.163" y2="-8.6804" layer="94"/>
<rectangle x1="-9.544" y1="-8.6804" x2="-9.163" y2="-8.6677" layer="94"/>
<rectangle x1="-9.544" y1="-8.6677" x2="-9.163" y2="-8.655" layer="94"/>
<rectangle x1="-9.544" y1="-8.655" x2="-9.163" y2="-8.6423" layer="94"/>
<rectangle x1="-9.544" y1="-8.6423" x2="-9.163" y2="-8.6296" layer="94"/>
<rectangle x1="-9.544" y1="-8.6296" x2="-9.163" y2="-8.6169" layer="94"/>
<rectangle x1="-9.544" y1="-8.6169" x2="-9.163" y2="-8.6042" layer="94"/>
<rectangle x1="-9.544" y1="-8.6042" x2="-9.163" y2="-8.5915" layer="94"/>
<rectangle x1="-9.544" y1="-8.5915" x2="-9.163" y2="-8.5788" layer="94"/>
<rectangle x1="-9.544" y1="-8.5788" x2="-9.163" y2="-8.5661" layer="94"/>
<rectangle x1="-9.544" y1="-8.5661" x2="-9.163" y2="-8.5534" layer="94"/>
<rectangle x1="-9.544" y1="-8.5534" x2="-9.163" y2="-8.5407" layer="94"/>
<rectangle x1="-9.544" y1="-8.5407" x2="-9.163" y2="-8.528" layer="94"/>
<rectangle x1="-9.544" y1="-8.528" x2="-9.163" y2="-8.5153" layer="94"/>
<rectangle x1="-9.544" y1="-8.5153" x2="-9.163" y2="-8.5026" layer="94"/>
<rectangle x1="-9.544" y1="-8.5026" x2="-9.163" y2="-8.4899" layer="94"/>
<rectangle x1="-9.544" y1="-8.4899" x2="-9.163" y2="-8.4772" layer="94"/>
<rectangle x1="-9.544" y1="-8.4772" x2="-9.163" y2="-8.4645" layer="94"/>
<rectangle x1="-9.544" y1="-8.4645" x2="-9.163" y2="-8.4518" layer="94"/>
<rectangle x1="-9.544" y1="-8.4518" x2="-9.163" y2="-8.4391" layer="94"/>
<rectangle x1="-9.544" y1="-8.4391" x2="-9.163" y2="-8.4264" layer="94"/>
<rectangle x1="-9.544" y1="-8.4264" x2="-9.163" y2="-8.4137" layer="94"/>
<rectangle x1="-9.544" y1="-8.4137" x2="-9.163" y2="-8.401" layer="94"/>
<rectangle x1="-9.544" y1="-8.401" x2="-9.163" y2="-8.3883" layer="94"/>
<rectangle x1="-9.544" y1="-8.3883" x2="-9.163" y2="-8.3756" layer="94"/>
<rectangle x1="-9.544" y1="-8.3756" x2="-9.163" y2="-8.3629" layer="94"/>
<rectangle x1="-9.544" y1="-8.3629" x2="-9.163" y2="-8.3502" layer="94"/>
<rectangle x1="-9.544" y1="-8.3502" x2="-9.163" y2="-8.3375" layer="94"/>
<rectangle x1="-0.2984" y1="-8.3502" x2="-0.2349" y2="-8.3375" layer="94"/>
<rectangle x1="-0.2095" y1="-8.3502" x2="-0.1968" y2="-8.3375" layer="94"/>
<rectangle x1="-0.1714" y1="-8.3502" x2="-0.1206" y2="-8.3375" layer="94"/>
<rectangle x1="-0.1079" y1="-8.3502" x2="-0.0698" y2="-8.3375" layer="94"/>
<rectangle x1="3.4481" y1="-8.3502" x2="3.4608" y2="-8.3375" layer="94"/>
<rectangle x1="3.4989" y1="-8.3502" x2="3.5116" y2="-8.3375" layer="94"/>
<rectangle x1="3.5497" y1="-8.3502" x2="3.5878" y2="-8.3375" layer="94"/>
<rectangle x1="4.8832" y1="-8.3502" x2="4.934" y2="-8.3375" layer="94"/>
<rectangle x1="5.0102" y1="-8.3502" x2="5.0229" y2="-8.3375" layer="94"/>
<rectangle x1="5.7214" y1="-8.3502" x2="5.7722" y2="-8.3375" layer="94"/>
<rectangle x1="7.0041" y1="-8.3502" x2="7.0422" y2="-8.3375" layer="94"/>
<rectangle x1="7.0549" y1="-8.3502" x2="7.0803" y2="-8.3375" layer="94"/>
<rectangle x1="7.1057" y1="-8.3502" x2="7.1311" y2="-8.3375" layer="94"/>
<rectangle x1="10.6363" y1="-8.3502" x2="10.6871" y2="-8.3375" layer="94"/>
<rectangle x1="10.7252" y1="-8.3502" x2="10.7379" y2="-8.3375" layer="94"/>
<rectangle x1="10.7506" y1="-8.3502" x2="10.7887" y2="-8.3375" layer="94"/>
<rectangle x1="10.8141" y1="-8.3502" x2="10.8522" y2="-8.3375" layer="94"/>
<rectangle x1="-9.544" y1="-8.3375" x2="-9.163" y2="-8.3248" layer="94"/>
<rectangle x1="-1.4922" y1="-8.3375" x2="-1.4541" y2="-8.3248" layer="94"/>
<rectangle x1="-0.3873" y1="-8.3375" x2="0.0318" y2="-8.3248" layer="94"/>
<rectangle x1="1.0478" y1="-8.3375" x2="1.0859" y2="-8.3248" layer="94"/>
<rectangle x1="3.2957" y1="-8.3375" x2="3.7148" y2="-8.3248" layer="94"/>
<rectangle x1="4.7943" y1="-8.3375" x2="5.1499" y2="-8.3248" layer="94"/>
<rectangle x1="5.5055" y1="-8.3375" x2="5.8484" y2="-8.3248" layer="94"/>
<rectangle x1="6.8771" y1="-8.3375" x2="7.2708" y2="-8.3248" layer="94"/>
<rectangle x1="7.5629" y1="-8.3375" x2="7.6137" y2="-8.3248" layer="94"/>
<rectangle x1="8.3122" y1="-8.3375" x2="8.3376" y2="-8.3248" layer="94"/>
<rectangle x1="10.5728" y1="-8.3375" x2="10.9792" y2="-8.3248" layer="94"/>
<rectangle x1="-10.8267" y1="-8.3248" x2="-10.6362" y2="-8.3121" layer="94"/>
<rectangle x1="-9.544" y1="-8.3248" x2="-9.163" y2="-8.3121" layer="94"/>
<rectangle x1="-8.8963" y1="-8.3248" x2="-8.7312" y2="-8.3121" layer="94"/>
<rectangle x1="-7.0167" y1="-8.3248" x2="-6.8008" y2="-8.3121" layer="94"/>
<rectangle x1="-2.5844" y1="-8.3248" x2="-2.5336" y2="-8.3121" layer="94"/>
<rectangle x1="-1.5049" y1="-8.3248" x2="-1.4287" y2="-8.3121" layer="94"/>
<rectangle x1="-0.4127" y1="-8.3248" x2="0.0572" y2="-8.3121" layer="94"/>
<rectangle x1="0.2858" y1="-8.3248" x2="0.362" y2="-8.3121" layer="94"/>
<rectangle x1="1.0351" y1="-8.3248" x2="1.1113" y2="-8.3121" layer="94"/>
<rectangle x1="3.2703" y1="-8.3248" x2="3.7402" y2="-8.3121" layer="94"/>
<rectangle x1="4.7689" y1="-8.3248" x2="5.1753" y2="-8.3121" layer="94"/>
<rectangle x1="5.4674" y1="-8.3248" x2="5.8738" y2="-8.3121" layer="94"/>
<rectangle x1="6.839" y1="-8.3248" x2="7.2962" y2="-8.3121" layer="94"/>
<rectangle x1="7.5502" y1="-8.3248" x2="7.6264" y2="-8.3121" layer="94"/>
<rectangle x1="8.2868" y1="-8.3248" x2="8.363" y2="-8.3121" layer="94"/>
<rectangle x1="10.5347" y1="-8.3248" x2="11.0046" y2="-8.3121" layer="94"/>
<rectangle x1="-10.8648" y1="-8.3121" x2="-10.5981" y2="-8.2994" layer="94"/>
<rectangle x1="-9.544" y1="-8.3121" x2="-9.1503" y2="-8.2994" layer="94"/>
<rectangle x1="-8.9471" y1="-8.3121" x2="-8.6804" y2="-8.2994" layer="94"/>
<rectangle x1="-7.0421" y1="-8.3121" x2="-6.7754" y2="-8.2994" layer="94"/>
<rectangle x1="-2.5971" y1="-8.3121" x2="-2.5082" y2="-8.2994" layer="94"/>
<rectangle x1="-1.5176" y1="-8.3121" x2="-1.416" y2="-8.2994" layer="94"/>
<rectangle x1="-0.4254" y1="-8.3121" x2="0.0699" y2="-8.2994" layer="94"/>
<rectangle x1="0.2858" y1="-8.3121" x2="0.3874" y2="-8.2994" layer="94"/>
<rectangle x1="1.0224" y1="-8.3121" x2="1.124" y2="-8.2994" layer="94"/>
<rectangle x1="3.2576" y1="-8.3121" x2="3.7656" y2="-8.2994" layer="94"/>
<rectangle x1="4.7562" y1="-8.3121" x2="5.188" y2="-8.2994" layer="94"/>
<rectangle x1="5.4547" y1="-8.3121" x2="5.8865" y2="-8.2994" layer="94"/>
<rectangle x1="6.8263" y1="-8.3121" x2="7.3216" y2="-8.2994" layer="94"/>
<rectangle x1="7.5375" y1="-8.3121" x2="7.6518" y2="-8.2994" layer="94"/>
<rectangle x1="8.2741" y1="-8.3121" x2="8.3884" y2="-8.2994" layer="94"/>
<rectangle x1="10.5093" y1="-8.3121" x2="11.0173" y2="-8.2994" layer="94"/>
<rectangle x1="-10.9029" y1="-8.2994" x2="-10.56" y2="-8.2867" layer="94"/>
<rectangle x1="-9.544" y1="-8.2994" x2="-9.1503" y2="-8.2867" layer="94"/>
<rectangle x1="-8.9852" y1="-8.2994" x2="-8.6423" y2="-8.2867" layer="94"/>
<rectangle x1="-7.0675" y1="-8.2994" x2="-6.75" y2="-8.2867" layer="94"/>
<rectangle x1="-5.6578" y1="-8.2994" x2="-5.607" y2="-8.2867" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2994" x2="-2.4828" y2="-8.2867" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2994" x2="-1.4033" y2="-8.2867" layer="94"/>
<rectangle x1="-0.4508" y1="-8.2994" x2="0.0826" y2="-8.2867" layer="94"/>
<rectangle x1="0.2731" y1="-8.2994" x2="0.4128" y2="-8.2867" layer="94"/>
<rectangle x1="1.0224" y1="-8.2994" x2="1.1494" y2="-8.2867" layer="94"/>
<rectangle x1="3.2322" y1="-8.2994" x2="3.791" y2="-8.2867" layer="94"/>
<rectangle x1="4.7308" y1="-8.2994" x2="5.2007" y2="-8.2867" layer="94"/>
<rectangle x1="5.442" y1="-8.2994" x2="5.9119" y2="-8.2867" layer="94"/>
<rectangle x1="6.8009" y1="-8.2994" x2="7.3343" y2="-8.2867" layer="94"/>
<rectangle x1="7.5375" y1="-8.2994" x2="7.6645" y2="-8.2867" layer="94"/>
<rectangle x1="8.2741" y1="-8.2994" x2="8.4011" y2="-8.2867" layer="94"/>
<rectangle x1="10.4839" y1="-8.2994" x2="11.0427" y2="-8.2867" layer="94"/>
<rectangle x1="-10.941" y1="-8.2867" x2="-10.5219" y2="-8.274" layer="94"/>
<rectangle x1="-9.544" y1="-8.2867" x2="-9.1376" y2="-8.274" layer="94"/>
<rectangle x1="-9.036" y1="-8.2867" x2="-8.6042" y2="-8.274" layer="94"/>
<rectangle x1="-7.1056" y1="-8.2867" x2="-6.6992" y2="-8.274" layer="94"/>
<rectangle x1="-5.6832" y1="-8.2867" x2="-5.5943" y2="-8.274" layer="94"/>
<rectangle x1="-4.6164" y1="-8.2867" x2="-4.5148" y2="-8.274" layer="94"/>
<rectangle x1="-2.6098" y1="-8.2867" x2="-2.4574" y2="-8.274" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2867" x2="-1.3779" y2="-8.274" layer="94"/>
<rectangle x1="-0.4635" y1="-8.2867" x2="0.0826" y2="-8.274" layer="94"/>
<rectangle x1="0.2731" y1="-8.2867" x2="0.4382" y2="-8.274" layer="94"/>
<rectangle x1="1.0224" y1="-8.2867" x2="1.1748" y2="-8.274" layer="94"/>
<rectangle x1="3.2195" y1="-8.2867" x2="3.8164" y2="-8.274" layer="94"/>
<rectangle x1="4.7181" y1="-8.2867" x2="5.2261" y2="-8.274" layer="94"/>
<rectangle x1="5.4166" y1="-8.2867" x2="5.9246" y2="-8.274" layer="94"/>
<rectangle x1="6.7755" y1="-8.2867" x2="7.347" y2="-8.274" layer="94"/>
<rectangle x1="7.5375" y1="-8.2867" x2="7.6899" y2="-8.274" layer="94"/>
<rectangle x1="8.2741" y1="-8.2867" x2="8.4138" y2="-8.274" layer="94"/>
<rectangle x1="10.4585" y1="-8.2867" x2="11.0554" y2="-8.274" layer="94"/>
<rectangle x1="-10.9918" y1="-8.274" x2="-10.4711" y2="-8.2613" layer="94"/>
<rectangle x1="-9.544" y1="-8.274" x2="-9.1122" y2="-8.2613" layer="94"/>
<rectangle x1="-9.0741" y1="-8.274" x2="-8.5534" y2="-8.2613" layer="94"/>
<rectangle x1="-7.1564" y1="-8.274" x2="-6.6484" y2="-8.2613" layer="94"/>
<rectangle x1="-5.6959" y1="-8.274" x2="-5.5562" y2="-8.2613" layer="94"/>
<rectangle x1="-4.6291" y1="-8.274" x2="-4.464" y2="-8.2613" layer="94"/>
<rectangle x1="-2.6098" y1="-8.274" x2="-2.4193" y2="-8.2613" layer="94"/>
<rectangle x1="-1.5176" y1="-8.274" x2="-1.3398" y2="-8.2613" layer="94"/>
<rectangle x1="-0.5016" y1="-8.274" x2="0.0953" y2="-8.2613" layer="94"/>
<rectangle x1="0.2731" y1="-8.274" x2="0.4636" y2="-8.2613" layer="94"/>
<rectangle x1="1.0224" y1="-8.274" x2="1.2002" y2="-8.2613" layer="94"/>
<rectangle x1="3.1814" y1="-8.274" x2="3.8545" y2="-8.2613" layer="94"/>
<rectangle x1="4.6927" y1="-8.274" x2="5.2388" y2="-8.2613" layer="94"/>
<rectangle x1="5.3912" y1="-8.274" x2="5.95" y2="-8.2613" layer="94"/>
<rectangle x1="6.7501" y1="-8.274" x2="7.347" y2="-8.2613" layer="94"/>
<rectangle x1="7.5375" y1="-8.274" x2="7.728" y2="-8.2613" layer="94"/>
<rectangle x1="8.2741" y1="-8.274" x2="8.4519" y2="-8.2613" layer="94"/>
<rectangle x1="10.4331" y1="-8.274" x2="11.0808" y2="-8.2613" layer="94"/>
<rectangle x1="-11.0426" y1="-8.2613" x2="-10.4203" y2="-8.2486" layer="94"/>
<rectangle x1="-9.544" y1="-8.2613" x2="-8.5026" y2="-8.2486" layer="94"/>
<rectangle x1="-7.2072" y1="-8.2613" x2="-6.5976" y2="-8.2486" layer="94"/>
<rectangle x1="-5.7086" y1="-8.2613" x2="-5.5054" y2="-8.2486" layer="94"/>
<rectangle x1="-4.6418" y1="-8.2613" x2="-4.4259" y2="-8.2486" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2613" x2="-2.3812" y2="-8.2486" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2613" x2="-1.3017" y2="-8.2486" layer="94"/>
<rectangle x1="-0.527" y1="-8.2613" x2="0.108" y2="-8.2486" layer="94"/>
<rectangle x1="0.2731" y1="-8.2613" x2="0.5271" y2="-8.2486" layer="94"/>
<rectangle x1="1.0224" y1="-8.2613" x2="1.2383" y2="-8.2486" layer="94"/>
<rectangle x1="3.156" y1="-8.2613" x2="3.8799" y2="-8.2486" layer="94"/>
<rectangle x1="4.6673" y1="-8.2613" x2="5.2896" y2="-8.2486" layer="94"/>
<rectangle x1="5.3277" y1="-8.2613" x2="5.9754" y2="-8.2486" layer="94"/>
<rectangle x1="6.712" y1="-8.2613" x2="7.347" y2="-8.2486" layer="94"/>
<rectangle x1="7.5375" y1="-8.2613" x2="7.7534" y2="-8.2486" layer="94"/>
<rectangle x1="8.2741" y1="-8.2613" x2="8.5027" y2="-8.2486" layer="94"/>
<rectangle x1="10.395" y1="-8.2613" x2="11.1189" y2="-8.2486" layer="94"/>
<rectangle x1="-11.068" y1="-8.2486" x2="-10.3822" y2="-8.2359" layer="94"/>
<rectangle x1="-9.544" y1="-8.2486" x2="-8.4772" y2="-8.2359" layer="94"/>
<rectangle x1="-7.2453" y1="-8.2486" x2="-6.5595" y2="-8.2359" layer="94"/>
<rectangle x1="-5.7213" y1="-8.2486" x2="-5.48" y2="-8.2359" layer="94"/>
<rectangle x1="-4.6418" y1="-8.2486" x2="-4.4005" y2="-8.2359" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2486" x2="-2.3558" y2="-8.2359" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2486" x2="-1.289" y2="-8.2359" layer="94"/>
<rectangle x1="-0.5651" y1="-8.2486" x2="0.108" y2="-8.2359" layer="94"/>
<rectangle x1="0.2731" y1="-8.2486" x2="0.5525" y2="-8.2359" layer="94"/>
<rectangle x1="1.0224" y1="-8.2486" x2="1.2637" y2="-8.2359" layer="94"/>
<rectangle x1="3.1306" y1="-8.2486" x2="3.8926" y2="-8.2359" layer="94"/>
<rectangle x1="4.6546" y1="-8.2486" x2="5.9881" y2="-8.2359" layer="94"/>
<rectangle x1="6.6993" y1="-8.2486" x2="7.3597" y2="-8.2359" layer="94"/>
<rectangle x1="7.5375" y1="-8.2486" x2="7.7788" y2="-8.2359" layer="94"/>
<rectangle x1="8.2741" y1="-8.2486" x2="8.5281" y2="-8.2359" layer="94"/>
<rectangle x1="10.3696" y1="-8.2486" x2="11.1443" y2="-8.2359" layer="94"/>
<rectangle x1="-11.0934" y1="-8.2359" x2="-10.3695" y2="-8.2232" layer="94"/>
<rectangle x1="-9.544" y1="-8.2359" x2="-8.4518" y2="-8.2232" layer="94"/>
<rectangle x1="-7.2707" y1="-8.2359" x2="-6.5468" y2="-8.2232" layer="94"/>
<rectangle x1="-5.734" y1="-8.2359" x2="-5.4546" y2="-8.2232" layer="94"/>
<rectangle x1="-4.6545" y1="-8.2359" x2="-4.3751" y2="-8.2232" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2359" x2="-2.3431" y2="-8.2232" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2359" x2="-1.2763" y2="-8.2232" layer="94"/>
<rectangle x1="-0.5778" y1="-8.2359" x2="0.108" y2="-8.2232" layer="94"/>
<rectangle x1="0.2731" y1="-8.2359" x2="0.5652" y2="-8.2232" layer="94"/>
<rectangle x1="1.0224" y1="-8.2359" x2="1.2764" y2="-8.2232" layer="94"/>
<rectangle x1="3.1179" y1="-8.2359" x2="3.918" y2="-8.2232" layer="94"/>
<rectangle x1="4.6419" y1="-8.2359" x2="6.0008" y2="-8.2232" layer="94"/>
<rectangle x1="6.6866" y1="-8.2359" x2="7.3597" y2="-8.2232" layer="94"/>
<rectangle x1="7.5375" y1="-8.2359" x2="7.7915" y2="-8.2232" layer="94"/>
<rectangle x1="8.2741" y1="-8.2359" x2="8.5281" y2="-8.2232" layer="94"/>
<rectangle x1="10.3569" y1="-8.2359" x2="11.157" y2="-8.2232" layer="94"/>
<rectangle x1="-11.1061" y1="-8.2232" x2="-10.3568" y2="-8.2105" layer="94"/>
<rectangle x1="-9.544" y1="-8.2232" x2="-8.4391" y2="-8.2105" layer="94"/>
<rectangle x1="-7.2834" y1="-8.2232" x2="-6.5341" y2="-8.2105" layer="94"/>
<rectangle x1="-5.734" y1="-8.2232" x2="-5.4292" y2="-8.2105" layer="94"/>
<rectangle x1="-4.6545" y1="-8.2232" x2="-4.3624" y2="-8.2105" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2232" x2="-2.3304" y2="-8.2105" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2232" x2="-1.2636" y2="-8.2105" layer="94"/>
<rectangle x1="-0.5905" y1="-8.2232" x2="0.108" y2="-8.2105" layer="94"/>
<rectangle x1="0.2731" y1="-8.2232" x2="0.5652" y2="-8.2105" layer="94"/>
<rectangle x1="1.0224" y1="-8.2232" x2="1.2891" y2="-8.2105" layer="94"/>
<rectangle x1="3.1052" y1="-8.2232" x2="3.9307" y2="-8.2105" layer="94"/>
<rectangle x1="4.6292" y1="-8.2232" x2="6.0135" y2="-8.2105" layer="94"/>
<rectangle x1="6.6739" y1="-8.2232" x2="7.3597" y2="-8.2105" layer="94"/>
<rectangle x1="7.5375" y1="-8.2232" x2="7.7915" y2="-8.2105" layer="94"/>
<rectangle x1="8.2741" y1="-8.2232" x2="8.5408" y2="-8.2105" layer="94"/>
<rectangle x1="10.3442" y1="-8.2232" x2="11.1697" y2="-8.2105" layer="94"/>
<rectangle x1="-11.1188" y1="-8.2105" x2="-10.3441" y2="-8.1978" layer="94"/>
<rectangle x1="-9.544" y1="-8.2105" x2="-8.4264" y2="-8.1978" layer="94"/>
<rectangle x1="-7.2961" y1="-8.2105" x2="-6.5214" y2="-8.1978" layer="94"/>
<rectangle x1="-5.734" y1="-8.2105" x2="-5.4165" y2="-8.1978" layer="94"/>
<rectangle x1="-4.6545" y1="-8.2105" x2="-4.337" y2="-8.1978" layer="94"/>
<rectangle x1="-2.5971" y1="-8.2105" x2="-2.3304" y2="-8.1978" layer="94"/>
<rectangle x1="-1.5176" y1="-8.2105" x2="-1.2636" y2="-8.1978" layer="94"/>
<rectangle x1="-0.6032" y1="-8.2105" x2="0.108" y2="-8.1978" layer="94"/>
<rectangle x1="0.2731" y1="-8.2105" x2="0.5779" y2="-8.1978" layer="94"/>
<rectangle x1="1.0224" y1="-8.2105" x2="1.3018" y2="-8.1978" layer="94"/>
<rectangle x1="3.0925" y1="-8.2105" x2="3.9434" y2="-8.1978" layer="94"/>
<rectangle x1="4.6165" y1="-8.2105" x2="6.0262" y2="-8.1978" layer="94"/>
<rectangle x1="6.6612" y1="-8.2105" x2="7.3597" y2="-8.1978" layer="94"/>
<rectangle x1="7.5375" y1="-8.2105" x2="7.7915" y2="-8.1978" layer="94"/>
<rectangle x1="8.2741" y1="-8.2105" x2="8.5408" y2="-8.1978" layer="94"/>
<rectangle x1="10.3315" y1="-8.2105" x2="11.1697" y2="-8.1978" layer="94"/>
<rectangle x1="-11.1315" y1="-8.1978" x2="-10.3187" y2="-8.1851" layer="94"/>
<rectangle x1="-9.544" y1="-8.1978" x2="-8.4137" y2="-8.1851" layer="94"/>
<rectangle x1="-7.3215" y1="-8.1978" x2="-6.5087" y2="-8.1851" layer="94"/>
<rectangle x1="-5.734" y1="-8.1978" x2="-5.3911" y2="-8.1851" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1978" x2="-4.3116" y2="-8.1851" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1978" x2="-2.3304" y2="-8.1851" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1978" x2="-1.2636" y2="-8.1851" layer="94"/>
<rectangle x1="-0.6159" y1="-8.1978" x2="0.0953" y2="-8.1851" layer="94"/>
<rectangle x1="0.2731" y1="-8.1978" x2="0.5779" y2="-8.1851" layer="94"/>
<rectangle x1="1.0224" y1="-8.1978" x2="1.3018" y2="-8.1851" layer="94"/>
<rectangle x1="3.0798" y1="-8.1978" x2="3.9561" y2="-8.1851" layer="94"/>
<rectangle x1="4.6038" y1="-8.1978" x2="6.0389" y2="-8.1851" layer="94"/>
<rectangle x1="6.6358" y1="-8.1978" x2="7.347" y2="-8.1851" layer="94"/>
<rectangle x1="7.5375" y1="-8.1978" x2="7.8042" y2="-8.1851" layer="94"/>
<rectangle x1="8.2741" y1="-8.1978" x2="8.5408" y2="-8.1851" layer="94"/>
<rectangle x1="10.3188" y1="-8.1978" x2="11.1951" y2="-8.1851" layer="94"/>
<rectangle x1="-11.1569" y1="-8.1851" x2="-10.2933" y2="-8.1724" layer="94"/>
<rectangle x1="-9.544" y1="-8.1851" x2="-8.3883" y2="-8.1724" layer="94"/>
<rectangle x1="-7.3342" y1="-8.1851" x2="-6.4833" y2="-8.1724" layer="94"/>
<rectangle x1="-5.734" y1="-8.1851" x2="-5.3657" y2="-8.1724" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1851" x2="-4.2862" y2="-8.1724" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1851" x2="-2.3304" y2="-8.1724" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1851" x2="-1.2636" y2="-8.1724" layer="94"/>
<rectangle x1="-0.6413" y1="-8.1851" x2="0.0826" y2="-8.1724" layer="94"/>
<rectangle x1="0.2731" y1="-8.1851" x2="0.5779" y2="-8.1724" layer="94"/>
<rectangle x1="1.0224" y1="-8.1851" x2="1.3018" y2="-8.1724" layer="94"/>
<rectangle x1="3.0544" y1="-8.1851" x2="3.9688" y2="-8.1724" layer="94"/>
<rectangle x1="4.5911" y1="-8.1851" x2="6.0516" y2="-8.1724" layer="94"/>
<rectangle x1="6.6231" y1="-8.1851" x2="7.347" y2="-8.1724" layer="94"/>
<rectangle x1="7.5375" y1="-8.1851" x2="7.8042" y2="-8.1724" layer="94"/>
<rectangle x1="8.2741" y1="-8.1851" x2="8.5408" y2="-8.1724" layer="94"/>
<rectangle x1="10.3061" y1="-8.1851" x2="11.2078" y2="-8.1724" layer="94"/>
<rectangle x1="-11.1823" y1="-8.1724" x2="-10.2679" y2="-8.1597" layer="94"/>
<rectangle x1="-9.544" y1="-8.1724" x2="-8.3502" y2="-8.1597" layer="94"/>
<rectangle x1="-7.3596" y1="-8.1724" x2="-6.4579" y2="-8.1597" layer="94"/>
<rectangle x1="-5.734" y1="-8.1724" x2="-5.353" y2="-8.1597" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1724" x2="-4.2608" y2="-8.1597" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1724" x2="-2.3304" y2="-8.1597" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1724" x2="-1.2636" y2="-8.1597" layer="94"/>
<rectangle x1="-0.654" y1="-8.1724" x2="0.0826" y2="-8.1597" layer="94"/>
<rectangle x1="0.2731" y1="-8.1724" x2="0.5779" y2="-8.1597" layer="94"/>
<rectangle x1="1.0224" y1="-8.1724" x2="1.3145" y2="-8.1597" layer="94"/>
<rectangle x1="3.0417" y1="-8.1724" x2="3.9815" y2="-8.1597" layer="94"/>
<rectangle x1="4.5784" y1="-8.1724" x2="6.0643" y2="-8.1597" layer="94"/>
<rectangle x1="6.6104" y1="-8.1724" x2="7.347" y2="-8.1597" layer="94"/>
<rectangle x1="7.5375" y1="-8.1724" x2="7.8042" y2="-8.1597" layer="94"/>
<rectangle x1="8.2741" y1="-8.1724" x2="8.5408" y2="-8.1597" layer="94"/>
<rectangle x1="10.2934" y1="-8.1724" x2="11.2205" y2="-8.1597" layer="94"/>
<rectangle x1="-11.2077" y1="-8.1597" x2="-10.2552" y2="-8.147" layer="94"/>
<rectangle x1="-9.544" y1="-8.1597" x2="-8.3375" y2="-8.147" layer="94"/>
<rectangle x1="-7.3723" y1="-8.1597" x2="-6.4452" y2="-8.147" layer="94"/>
<rectangle x1="-5.734" y1="-8.1597" x2="-5.353" y2="-8.147" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1597" x2="-4.2608" y2="-8.147" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1597" x2="-2.3177" y2="-8.147" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1597" x2="-1.2636" y2="-8.147" layer="94"/>
<rectangle x1="-0.6667" y1="-8.1597" x2="0.0826" y2="-8.147" layer="94"/>
<rectangle x1="0.2731" y1="-8.1597" x2="0.5779" y2="-8.147" layer="94"/>
<rectangle x1="1.0224" y1="-8.1597" x2="1.3145" y2="-8.147" layer="94"/>
<rectangle x1="3.029" y1="-8.1597" x2="3.9942" y2="-8.147" layer="94"/>
<rectangle x1="4.5784" y1="-8.1597" x2="6.077" y2="-8.147" layer="94"/>
<rectangle x1="6.5977" y1="-8.1597" x2="7.347" y2="-8.147" layer="94"/>
<rectangle x1="7.5375" y1="-8.1597" x2="7.8042" y2="-8.147" layer="94"/>
<rectangle x1="8.2741" y1="-8.1597" x2="8.5408" y2="-8.147" layer="94"/>
<rectangle x1="10.268" y1="-8.1597" x2="11.2332" y2="-8.147" layer="94"/>
<rectangle x1="-11.2204" y1="-8.147" x2="-10.2425" y2="-8.1343" layer="94"/>
<rectangle x1="-9.544" y1="-8.147" x2="-8.3248" y2="-8.1343" layer="94"/>
<rectangle x1="-7.385" y1="-8.147" x2="-6.4325" y2="-8.1343" layer="94"/>
<rectangle x1="-5.734" y1="-8.147" x2="-5.3403" y2="-8.1343" layer="94"/>
<rectangle x1="-4.6545" y1="-8.147" x2="-4.2481" y2="-8.1343" layer="94"/>
<rectangle x1="-2.5971" y1="-8.147" x2="-2.3177" y2="-8.1343" layer="94"/>
<rectangle x1="-1.5176" y1="-8.147" x2="-1.2509" y2="-8.1343" layer="94"/>
<rectangle x1="-0.6794" y1="-8.147" x2="0.0699" y2="-8.1343" layer="94"/>
<rectangle x1="0.2731" y1="-8.147" x2="0.5779" y2="-8.1343" layer="94"/>
<rectangle x1="1.0224" y1="-8.147" x2="1.3145" y2="-8.1343" layer="94"/>
<rectangle x1="3.0163" y1="-8.147" x2="4.0069" y2="-8.1343" layer="94"/>
<rectangle x1="4.5657" y1="-8.147" x2="6.077" y2="-8.1343" layer="94"/>
<rectangle x1="6.585" y1="-8.147" x2="7.3343" y2="-8.1343" layer="94"/>
<rectangle x1="7.5375" y1="-8.147" x2="7.8042" y2="-8.1343" layer="94"/>
<rectangle x1="8.2741" y1="-8.147" x2="8.5408" y2="-8.1343" layer="94"/>
<rectangle x1="10.2553" y1="-8.147" x2="11.2459" y2="-8.1343" layer="94"/>
<rectangle x1="-11.2331" y1="-8.1343" x2="-10.2298" y2="-8.1216" layer="94"/>
<rectangle x1="-9.544" y1="-8.1343" x2="-8.3121" y2="-8.1216" layer="94"/>
<rectangle x1="-7.3977" y1="-8.1343" x2="-6.4198" y2="-8.1216" layer="94"/>
<rectangle x1="-5.734" y1="-8.1343" x2="-5.3403" y2="-8.1216" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1343" x2="-4.2481" y2="-8.1216" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1343" x2="-2.3177" y2="-8.1216" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1343" x2="-1.2509" y2="-8.1216" layer="94"/>
<rectangle x1="-0.6794" y1="-8.1343" x2="0.0699" y2="-8.1216" layer="94"/>
<rectangle x1="0.2731" y1="-8.1343" x2="0.5779" y2="-8.1216" layer="94"/>
<rectangle x1="1.0224" y1="-8.1343" x2="1.3145" y2="-8.1216" layer="94"/>
<rectangle x1="3.0036" y1="-8.1343" x2="4.0196" y2="-8.1216" layer="94"/>
<rectangle x1="4.5657" y1="-8.1343" x2="6.0897" y2="-8.1216" layer="94"/>
<rectangle x1="6.5723" y1="-8.1343" x2="7.3343" y2="-8.1216" layer="94"/>
<rectangle x1="7.5375" y1="-8.1343" x2="7.8042" y2="-8.1216" layer="94"/>
<rectangle x1="8.2741" y1="-8.1343" x2="8.5408" y2="-8.1216" layer="94"/>
<rectangle x1="10.2553" y1="-8.1343" x2="11.2586" y2="-8.1216" layer="94"/>
<rectangle x1="-11.2458" y1="-8.1216" x2="-10.2171" y2="-8.1089" layer="94"/>
<rectangle x1="-9.544" y1="-8.1216" x2="-8.3121" y2="-8.1089" layer="94"/>
<rectangle x1="-7.4104" y1="-8.1216" x2="-6.4071" y2="-8.1089" layer="94"/>
<rectangle x1="-5.734" y1="-8.1216" x2="-5.3403" y2="-8.1089" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1216" x2="-4.2481" y2="-8.1089" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1216" x2="-2.3177" y2="-8.1089" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1216" x2="-1.2509" y2="-8.1089" layer="94"/>
<rectangle x1="-0.6921" y1="-8.1216" x2="0.0699" y2="-8.1089" layer="94"/>
<rectangle x1="0.2731" y1="-8.1216" x2="0.5779" y2="-8.1089" layer="94"/>
<rectangle x1="1.0224" y1="-8.1216" x2="1.3145" y2="-8.1089" layer="94"/>
<rectangle x1="2.9909" y1="-8.1216" x2="4.0323" y2="-8.1089" layer="94"/>
<rectangle x1="4.553" y1="-8.1216" x2="6.0897" y2="-8.1089" layer="94"/>
<rectangle x1="6.5596" y1="-8.1216" x2="7.3343" y2="-8.1089" layer="94"/>
<rectangle x1="7.5375" y1="-8.1216" x2="7.8042" y2="-8.1089" layer="94"/>
<rectangle x1="8.2741" y1="-8.1216" x2="8.5408" y2="-8.1089" layer="94"/>
<rectangle x1="10.2426" y1="-8.1216" x2="11.2586" y2="-8.1089" layer="94"/>
<rectangle x1="-11.2585" y1="-8.1089" x2="-10.2044" y2="-8.0962" layer="94"/>
<rectangle x1="-9.544" y1="-8.1089" x2="-8.2994" y2="-8.0962" layer="94"/>
<rectangle x1="-7.4231" y1="-8.1089" x2="-6.3944" y2="-8.0962" layer="94"/>
<rectangle x1="-5.734" y1="-8.1089" x2="-5.3403" y2="-8.0962" layer="94"/>
<rectangle x1="-4.6545" y1="-8.1089" x2="-4.2481" y2="-8.0962" layer="94"/>
<rectangle x1="-2.5971" y1="-8.1089" x2="-2.3177" y2="-8.0962" layer="94"/>
<rectangle x1="-1.5176" y1="-8.1089" x2="-1.2509" y2="-8.0962" layer="94"/>
<rectangle x1="-0.7048" y1="-8.1089" x2="0.0699" y2="-8.0962" layer="94"/>
<rectangle x1="0.2731" y1="-8.1089" x2="0.5779" y2="-8.0962" layer="94"/>
<rectangle x1="1.0224" y1="-8.1089" x2="1.3145" y2="-8.0962" layer="94"/>
<rectangle x1="2.9782" y1="-8.1089" x2="4.045" y2="-8.0962" layer="94"/>
<rectangle x1="4.553" y1="-8.1089" x2="6.0897" y2="-8.0962" layer="94"/>
<rectangle x1="6.5469" y1="-8.1089" x2="7.3216" y2="-8.0962" layer="94"/>
<rectangle x1="7.5375" y1="-8.1089" x2="7.8042" y2="-8.0962" layer="94"/>
<rectangle x1="8.2741" y1="-8.1089" x2="8.5408" y2="-8.0962" layer="94"/>
<rectangle x1="10.2426" y1="-8.1089" x2="11.2713" y2="-8.0962" layer="94"/>
<rectangle x1="-11.2585" y1="-8.0962" x2="-10.1917" y2="-8.0835" layer="94"/>
<rectangle x1="-9.544" y1="-8.0962" x2="-8.2867" y2="-8.0835" layer="94"/>
<rectangle x1="-7.4358" y1="-8.0962" x2="-6.3817" y2="-8.0835" layer="94"/>
<rectangle x1="-5.734" y1="-8.0962" x2="-5.3403" y2="-8.0835" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0962" x2="-4.2481" y2="-8.0835" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0962" x2="-2.3177" y2="-8.0835" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0962" x2="-1.2509" y2="-8.0835" layer="94"/>
<rectangle x1="-0.7175" y1="-8.0962" x2="0.0699" y2="-8.0835" layer="94"/>
<rectangle x1="0.2731" y1="-8.0962" x2="0.5779" y2="-8.0835" layer="94"/>
<rectangle x1="1.0224" y1="-8.0962" x2="1.3145" y2="-8.0835" layer="94"/>
<rectangle x1="2.9655" y1="-8.0962" x2="4.0577" y2="-8.0835" layer="94"/>
<rectangle x1="4.5403" y1="-8.0962" x2="6.1024" y2="-8.0835" layer="94"/>
<rectangle x1="6.5342" y1="-8.0962" x2="7.3089" y2="-8.0835" layer="94"/>
<rectangle x1="7.5375" y1="-8.0962" x2="7.8042" y2="-8.0835" layer="94"/>
<rectangle x1="8.2741" y1="-8.0962" x2="8.5408" y2="-8.0835" layer="94"/>
<rectangle x1="10.2299" y1="-8.0962" x2="11.2967" y2="-8.0835" layer="94"/>
<rectangle x1="-11.2712" y1="-8.0835" x2="-10.179" y2="-8.0708" layer="94"/>
<rectangle x1="-9.544" y1="-8.0835" x2="-8.2613" y2="-8.0708" layer="94"/>
<rectangle x1="-7.4485" y1="-8.0835" x2="-6.369" y2="-8.0708" layer="94"/>
<rectangle x1="-5.734" y1="-8.0835" x2="-5.3403" y2="-8.0708" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0835" x2="-4.2481" y2="-8.0708" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0835" x2="-2.3177" y2="-8.0708" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0835" x2="-1.2509" y2="-8.0708" layer="94"/>
<rectangle x1="-0.7302" y1="-8.0835" x2="0.0572" y2="-8.0708" layer="94"/>
<rectangle x1="0.2731" y1="-8.0835" x2="0.5779" y2="-8.0708" layer="94"/>
<rectangle x1="1.0224" y1="-8.0835" x2="1.3145" y2="-8.0708" layer="94"/>
<rectangle x1="2.9655" y1="-8.0835" x2="4.0577" y2="-8.0708" layer="94"/>
<rectangle x1="4.5276" y1="-8.0835" x2="6.1151" y2="-8.0708" layer="94"/>
<rectangle x1="6.5215" y1="-8.0835" x2="7.2962" y2="-8.0708" layer="94"/>
<rectangle x1="7.5375" y1="-8.0835" x2="7.8042" y2="-8.0708" layer="94"/>
<rectangle x1="8.2741" y1="-8.0835" x2="8.5408" y2="-8.0708" layer="94"/>
<rectangle x1="10.2172" y1="-8.0835" x2="11.3094" y2="-8.0708" layer="94"/>
<rectangle x1="-11.2839" y1="-8.0708" x2="-10.1663" y2="-8.0581" layer="94"/>
<rectangle x1="-9.544" y1="-8.0708" x2="-8.2486" y2="-8.0581" layer="94"/>
<rectangle x1="-7.4612" y1="-8.0708" x2="-6.3563" y2="-8.0581" layer="94"/>
<rectangle x1="-5.734" y1="-8.0708" x2="-5.3403" y2="-8.0581" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0708" x2="-4.2481" y2="-8.0581" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0708" x2="-2.3177" y2="-8.0581" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0708" x2="-1.2509" y2="-8.0581" layer="94"/>
<rectangle x1="-0.7429" y1="-8.0708" x2="0.0572" y2="-8.0581" layer="94"/>
<rectangle x1="0.2731" y1="-8.0708" x2="0.5779" y2="-8.0581" layer="94"/>
<rectangle x1="1.0224" y1="-8.0708" x2="1.3145" y2="-8.0581" layer="94"/>
<rectangle x1="2.9528" y1="-8.0708" x2="4.0704" y2="-8.0581" layer="94"/>
<rectangle x1="4.5276" y1="-8.0708" x2="6.1278" y2="-8.0581" layer="94"/>
<rectangle x1="6.5215" y1="-8.0708" x2="7.2962" y2="-8.0581" layer="94"/>
<rectangle x1="7.5375" y1="-8.0708" x2="7.8042" y2="-8.0581" layer="94"/>
<rectangle x1="8.2741" y1="-8.0708" x2="8.5408" y2="-8.0581" layer="94"/>
<rectangle x1="10.2045" y1="-8.0708" x2="11.3221" y2="-8.0581" layer="94"/>
<rectangle x1="-11.2966" y1="-8.0581" x2="-10.1663" y2="-8.0454" layer="94"/>
<rectangle x1="-9.544" y1="-8.0581" x2="-8.2359" y2="-8.0454" layer="94"/>
<rectangle x1="-7.4739" y1="-8.0581" x2="-6.3563" y2="-8.0454" layer="94"/>
<rectangle x1="-5.734" y1="-8.0581" x2="-5.3403" y2="-8.0454" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0581" x2="-4.2481" y2="-8.0454" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0581" x2="-2.3177" y2="-8.0454" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0581" x2="-1.2509" y2="-8.0454" layer="94"/>
<rectangle x1="-0.7429" y1="-8.0581" x2="-0.2603" y2="-8.0454" layer="94"/>
<rectangle x1="-0.1841" y1="-8.0581" x2="0.0445" y2="-8.0454" layer="94"/>
<rectangle x1="0.2731" y1="-8.0581" x2="0.5779" y2="-8.0454" layer="94"/>
<rectangle x1="1.0224" y1="-8.0581" x2="1.3145" y2="-8.0454" layer="94"/>
<rectangle x1="2.9528" y1="-8.0581" x2="3.4735" y2="-8.0454" layer="94"/>
<rectangle x1="3.5624" y1="-8.0581" x2="4.0831" y2="-8.0454" layer="94"/>
<rectangle x1="4.5149" y1="-8.0581" x2="6.1278" y2="-8.0454" layer="94"/>
<rectangle x1="6.5088" y1="-8.0581" x2="7.2835" y2="-8.0454" layer="94"/>
<rectangle x1="7.5375" y1="-8.0581" x2="7.8042" y2="-8.0454" layer="94"/>
<rectangle x1="8.2741" y1="-8.0581" x2="8.5408" y2="-8.0454" layer="94"/>
<rectangle x1="10.1918" y1="-8.0581" x2="10.7379" y2="-8.0454" layer="94"/>
<rectangle x1="10.8268" y1="-8.0581" x2="11.3221" y2="-8.0454" layer="94"/>
<rectangle x1="-11.3093" y1="-8.0454" x2="-10.1536" y2="-8.0327" layer="94"/>
<rectangle x1="-9.544" y1="-8.0454" x2="-8.2359" y2="-8.0327" layer="94"/>
<rectangle x1="-7.4739" y1="-8.0454" x2="-6.3436" y2="-8.0327" layer="94"/>
<rectangle x1="-5.734" y1="-8.0454" x2="-5.3403" y2="-8.0327" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0454" x2="-4.2481" y2="-8.0327" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0454" x2="-2.3177" y2="-8.0327" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0454" x2="-1.2509" y2="-8.0327" layer="94"/>
<rectangle x1="-0.7556" y1="-8.0454" x2="-0.2984" y2="-8.0327" layer="94"/>
<rectangle x1="-0.1333" y1="-8.0454" x2="0.0318" y2="-8.0327" layer="94"/>
<rectangle x1="0.2731" y1="-8.0454" x2="0.5779" y2="-8.0327" layer="94"/>
<rectangle x1="1.0224" y1="-8.0454" x2="1.3145" y2="-8.0327" layer="94"/>
<rectangle x1="2.9401" y1="-8.0454" x2="3.4227" y2="-8.0327" layer="94"/>
<rectangle x1="3.6132" y1="-8.0454" x2="4.0958" y2="-8.0327" layer="94"/>
<rectangle x1="4.5149" y1="-8.0454" x2="4.9086" y2="-8.0327" layer="94"/>
<rectangle x1="5.0102" y1="-8.0454" x2="5.6325" y2="-8.0327" layer="94"/>
<rectangle x1="5.7214" y1="-8.0454" x2="6.1405" y2="-8.0327" layer="94"/>
<rectangle x1="6.5088" y1="-8.0454" x2="6.9533" y2="-8.0327" layer="94"/>
<rectangle x1="7.1184" y1="-8.0454" x2="7.2708" y2="-8.0327" layer="94"/>
<rectangle x1="7.5375" y1="-8.0454" x2="7.8042" y2="-8.0327" layer="94"/>
<rectangle x1="8.2741" y1="-8.0454" x2="8.5408" y2="-8.0327" layer="94"/>
<rectangle x1="10.1791" y1="-8.0454" x2="10.6744" y2="-8.0327" layer="94"/>
<rectangle x1="10.8776" y1="-8.0454" x2="11.3348" y2="-8.0327" layer="94"/>
<rectangle x1="-11.322" y1="-8.0327" x2="-10.1409" y2="-8.02" layer="94"/>
<rectangle x1="-9.544" y1="-8.0327" x2="-8.2232" y2="-8.02" layer="94"/>
<rectangle x1="-7.4866" y1="-8.0327" x2="-6.3309" y2="-8.02" layer="94"/>
<rectangle x1="-5.734" y1="-8.0327" x2="-5.3403" y2="-8.02" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0327" x2="-4.2481" y2="-8.02" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0327" x2="-2.3177" y2="-8.02" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0327" x2="-1.2509" y2="-8.02" layer="94"/>
<rectangle x1="-0.7556" y1="-8.0327" x2="-0.3492" y2="-8.02" layer="94"/>
<rectangle x1="-0.0571" y1="-8.0327" x2="-0.0063" y2="-8.02" layer="94"/>
<rectangle x1="0.2731" y1="-8.0327" x2="0.5779" y2="-8.02" layer="94"/>
<rectangle x1="1.0224" y1="-8.0327" x2="1.3145" y2="-8.02" layer="94"/>
<rectangle x1="2.9274" y1="-8.0327" x2="3.3719" y2="-8.02" layer="94"/>
<rectangle x1="3.664" y1="-8.0327" x2="4.1085" y2="-8.02" layer="94"/>
<rectangle x1="4.5022" y1="-8.0327" x2="4.8832" y2="-8.02" layer="94"/>
<rectangle x1="5.061" y1="-8.0327" x2="5.5817" y2="-8.02" layer="94"/>
<rectangle x1="5.7595" y1="-8.0327" x2="6.1532" y2="-8.02" layer="94"/>
<rectangle x1="6.4961" y1="-8.0327" x2="6.9152" y2="-8.02" layer="94"/>
<rectangle x1="7.1946" y1="-8.0327" x2="7.2454" y2="-8.02" layer="94"/>
<rectangle x1="7.5375" y1="-8.0327" x2="7.8042" y2="-8.02" layer="94"/>
<rectangle x1="8.2741" y1="-8.0327" x2="8.5408" y2="-8.02" layer="94"/>
<rectangle x1="10.1791" y1="-8.0327" x2="10.6109" y2="-8.02" layer="94"/>
<rectangle x1="10.9284" y1="-8.0327" x2="11.3348" y2="-8.02" layer="94"/>
<rectangle x1="-11.3347" y1="-8.02" x2="-10.1282" y2="-8.0073" layer="94"/>
<rectangle x1="-9.544" y1="-8.02" x2="-8.2232" y2="-8.0073" layer="94"/>
<rectangle x1="-7.4993" y1="-8.02" x2="-6.3182" y2="-8.0073" layer="94"/>
<rectangle x1="-5.734" y1="-8.02" x2="-5.3403" y2="-8.0073" layer="94"/>
<rectangle x1="-4.6545" y1="-8.02" x2="-4.2481" y2="-8.0073" layer="94"/>
<rectangle x1="-2.5971" y1="-8.02" x2="-2.3177" y2="-8.0073" layer="94"/>
<rectangle x1="-1.5176" y1="-8.02" x2="-1.2509" y2="-8.0073" layer="94"/>
<rectangle x1="-0.7556" y1="-8.02" x2="-0.3873" y2="-8.0073" layer="94"/>
<rectangle x1="0.2731" y1="-8.02" x2="0.5779" y2="-8.0073" layer="94"/>
<rectangle x1="1.0224" y1="-8.02" x2="1.3145" y2="-8.0073" layer="94"/>
<rectangle x1="2.9147" y1="-8.02" x2="3.3338" y2="-8.0073" layer="94"/>
<rectangle x1="3.7021" y1="-8.02" x2="4.1085" y2="-8.0073" layer="94"/>
<rectangle x1="4.5022" y1="-8.02" x2="4.8451" y2="-8.0073" layer="94"/>
<rectangle x1="5.0864" y1="-8.02" x2="5.5563" y2="-8.0073" layer="94"/>
<rectangle x1="5.7849" y1="-8.02" x2="6.1532" y2="-8.0073" layer="94"/>
<rectangle x1="6.4961" y1="-8.02" x2="6.8771" y2="-8.0073" layer="94"/>
<rectangle x1="7.5375" y1="-8.02" x2="7.8042" y2="-8.0073" layer="94"/>
<rectangle x1="8.2741" y1="-8.02" x2="8.5408" y2="-8.0073" layer="94"/>
<rectangle x1="10.1664" y1="-8.02" x2="10.5855" y2="-8.0073" layer="94"/>
<rectangle x1="10.9665" y1="-8.02" x2="11.3348" y2="-8.0073" layer="94"/>
<rectangle x1="-11.3347" y1="-8.0073" x2="-10.1155" y2="-7.9946" layer="94"/>
<rectangle x1="-9.544" y1="-8.0073" x2="-8.2105" y2="-7.9946" layer="94"/>
<rectangle x1="-7.512" y1="-8.0073" x2="-6.3055" y2="-7.9946" layer="94"/>
<rectangle x1="-5.734" y1="-8.0073" x2="-5.3403" y2="-7.9946" layer="94"/>
<rectangle x1="-4.6545" y1="-8.0073" x2="-4.2481" y2="-7.9946" layer="94"/>
<rectangle x1="-2.5971" y1="-8.0073" x2="-2.3177" y2="-7.9946" layer="94"/>
<rectangle x1="-1.5176" y1="-8.0073" x2="-1.2509" y2="-7.9946" layer="94"/>
<rectangle x1="-0.7683" y1="-8.0073" x2="-0.4" y2="-7.9946" layer="94"/>
<rectangle x1="0.2731" y1="-8.0073" x2="0.5779" y2="-7.9946" layer="94"/>
<rectangle x1="1.0224" y1="-8.0073" x2="1.3145" y2="-7.9946" layer="94"/>
<rectangle x1="2.902" y1="-8.0073" x2="3.3084" y2="-7.9946" layer="94"/>
<rectangle x1="3.7148" y1="-8.0073" x2="4.1212" y2="-7.9946" layer="94"/>
<rectangle x1="4.5022" y1="-8.0073" x2="4.8324" y2="-7.9946" layer="94"/>
<rectangle x1="5.0991" y1="-8.0073" x2="5.5436" y2="-7.9946" layer="94"/>
<rectangle x1="5.8103" y1="-8.0073" x2="6.1532" y2="-7.9946" layer="94"/>
<rectangle x1="6.4961" y1="-8.0073" x2="6.8517" y2="-7.9946" layer="94"/>
<rectangle x1="7.5375" y1="-8.0073" x2="7.8042" y2="-7.9946" layer="94"/>
<rectangle x1="8.2741" y1="-8.0073" x2="8.5408" y2="-7.9946" layer="94"/>
<rectangle x1="10.1664" y1="-8.0073" x2="10.5601" y2="-7.9946" layer="94"/>
<rectangle x1="10.9792" y1="-8.0073" x2="11.3475" y2="-7.9946" layer="94"/>
<rectangle x1="-11.3474" y1="-7.9946" x2="-10.1028" y2="-7.9819" layer="94"/>
<rectangle x1="-9.544" y1="-7.9946" x2="-8.1978" y2="-7.9819" layer="94"/>
<rectangle x1="-7.5247" y1="-7.9946" x2="-6.2928" y2="-7.9819" layer="94"/>
<rectangle x1="-5.734" y1="-7.9946" x2="-5.3403" y2="-7.9819" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9946" x2="-4.2481" y2="-7.9819" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9946" x2="-2.3177" y2="-7.9819" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9946" x2="-1.2509" y2="-7.9819" layer="94"/>
<rectangle x1="-0.7683" y1="-7.9946" x2="-0.4127" y2="-7.9819" layer="94"/>
<rectangle x1="0.2731" y1="-7.9946" x2="0.5779" y2="-7.9819" layer="94"/>
<rectangle x1="1.0224" y1="-7.9946" x2="1.3145" y2="-7.9819" layer="94"/>
<rectangle x1="2.902" y1="-7.9946" x2="3.2957" y2="-7.9819" layer="94"/>
<rectangle x1="3.7402" y1="-7.9946" x2="4.1212" y2="-7.9819" layer="94"/>
<rectangle x1="4.4895" y1="-7.9946" x2="4.8197" y2="-7.9819" layer="94"/>
<rectangle x1="5.1118" y1="-7.9946" x2="5.5182" y2="-7.9819" layer="94"/>
<rectangle x1="5.823" y1="-7.9946" x2="6.1659" y2="-7.9819" layer="94"/>
<rectangle x1="6.4834" y1="-7.9946" x2="6.839" y2="-7.9819" layer="94"/>
<rectangle x1="7.5375" y1="-7.9946" x2="7.8042" y2="-7.9819" layer="94"/>
<rectangle x1="8.2741" y1="-7.9946" x2="8.5408" y2="-7.9819" layer="94"/>
<rectangle x1="10.1537" y1="-7.9946" x2="10.5474" y2="-7.9819" layer="94"/>
<rectangle x1="10.9919" y1="-7.9946" x2="11.3475" y2="-7.9819" layer="94"/>
<rectangle x1="-11.3474" y1="-7.9819" x2="-10.0901" y2="-7.9692" layer="94"/>
<rectangle x1="-9.544" y1="-7.9819" x2="-8.1978" y2="-7.9692" layer="94"/>
<rectangle x1="-7.5247" y1="-7.9819" x2="-6.2928" y2="-7.9692" layer="94"/>
<rectangle x1="-5.734" y1="-7.9819" x2="-5.3403" y2="-7.9692" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9819" x2="-4.2481" y2="-7.9692" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9819" x2="-2.3177" y2="-7.9692" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9819" x2="-1.2509" y2="-7.9692" layer="94"/>
<rectangle x1="-0.7683" y1="-7.9819" x2="-0.4254" y2="-7.9692" layer="94"/>
<rectangle x1="0.2731" y1="-7.9819" x2="0.5779" y2="-7.9692" layer="94"/>
<rectangle x1="1.0224" y1="-7.9819" x2="1.3145" y2="-7.9692" layer="94"/>
<rectangle x1="2.8893" y1="-7.9819" x2="3.283" y2="-7.9692" layer="94"/>
<rectangle x1="3.7402" y1="-7.9819" x2="4.1339" y2="-7.9692" layer="94"/>
<rectangle x1="4.4895" y1="-7.9819" x2="4.8197" y2="-7.9692" layer="94"/>
<rectangle x1="5.1245" y1="-7.9819" x2="5.5182" y2="-7.9692" layer="94"/>
<rectangle x1="5.8357" y1="-7.9819" x2="6.1659" y2="-7.9692" layer="94"/>
<rectangle x1="6.4707" y1="-7.9819" x2="6.8263" y2="-7.9692" layer="94"/>
<rectangle x1="7.5375" y1="-7.9819" x2="7.8042" y2="-7.9692" layer="94"/>
<rectangle x1="8.2741" y1="-7.9819" x2="8.5408" y2="-7.9692" layer="94"/>
<rectangle x1="10.1537" y1="-7.9819" x2="10.5347" y2="-7.9692" layer="94"/>
<rectangle x1="11.0046" y1="-7.9819" x2="11.3602" y2="-7.9692" layer="94"/>
<rectangle x1="-11.3601" y1="-7.9692" x2="-10.0901" y2="-7.9565" layer="94"/>
<rectangle x1="-9.544" y1="-7.9692" x2="-8.1851" y2="-7.9565" layer="94"/>
<rectangle x1="-7.5374" y1="-7.9692" x2="-6.2801" y2="-7.9565" layer="94"/>
<rectangle x1="-5.734" y1="-7.9692" x2="-5.3403" y2="-7.9565" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9692" x2="-4.2481" y2="-7.9565" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9692" x2="-2.3177" y2="-7.9565" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9692" x2="-1.2509" y2="-7.9565" layer="94"/>
<rectangle x1="-0.7683" y1="-7.9692" x2="-0.4254" y2="-7.9565" layer="94"/>
<rectangle x1="0.2731" y1="-7.9692" x2="0.5779" y2="-7.9565" layer="94"/>
<rectangle x1="1.0224" y1="-7.9692" x2="1.3145" y2="-7.9565" layer="94"/>
<rectangle x1="2.8893" y1="-7.9692" x2="3.2703" y2="-7.9565" layer="94"/>
<rectangle x1="3.7656" y1="-7.9692" x2="4.1339" y2="-7.9565" layer="94"/>
<rectangle x1="4.4895" y1="-7.9692" x2="4.807" y2="-7.9565" layer="94"/>
<rectangle x1="5.1372" y1="-7.9692" x2="5.5055" y2="-7.9565" layer="94"/>
<rectangle x1="5.8357" y1="-7.9692" x2="6.1659" y2="-7.9565" layer="94"/>
<rectangle x1="6.4707" y1="-7.9692" x2="6.8263" y2="-7.9565" layer="94"/>
<rectangle x1="7.5375" y1="-7.9692" x2="7.8042" y2="-7.9565" layer="94"/>
<rectangle x1="8.2741" y1="-7.9692" x2="8.5408" y2="-7.9565" layer="94"/>
<rectangle x1="10.1537" y1="-7.9692" x2="10.522" y2="-7.9565" layer="94"/>
<rectangle x1="11.0173" y1="-7.9692" x2="11.3729" y2="-7.9565" layer="94"/>
<rectangle x1="-11.3601" y1="-7.9565" x2="-10.0901" y2="-7.9438" layer="94"/>
<rectangle x1="-9.544" y1="-7.9565" x2="-8.1724" y2="-7.9438" layer="94"/>
<rectangle x1="-7.5374" y1="-7.9565" x2="-6.2801" y2="-7.9438" layer="94"/>
<rectangle x1="-5.734" y1="-7.9565" x2="-5.3403" y2="-7.9438" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9565" x2="-4.2481" y2="-7.9438" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9565" x2="-2.3177" y2="-7.9438" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9565" x2="-1.2509" y2="-7.9438" layer="94"/>
<rectangle x1="-0.781" y1="-7.9565" x2="-0.4381" y2="-7.9438" layer="94"/>
<rectangle x1="0.2731" y1="-7.9565" x2="0.5779" y2="-7.9438" layer="94"/>
<rectangle x1="1.0224" y1="-7.9565" x2="1.3145" y2="-7.9438" layer="94"/>
<rectangle x1="2.8893" y1="-7.9565" x2="3.2449" y2="-7.9438" layer="94"/>
<rectangle x1="3.7783" y1="-7.9565" x2="4.1339" y2="-7.9438" layer="94"/>
<rectangle x1="4.4895" y1="-7.9565" x2="4.807" y2="-7.9438" layer="94"/>
<rectangle x1="5.1499" y1="-7.9565" x2="5.5055" y2="-7.9438" layer="94"/>
<rectangle x1="5.8357" y1="-7.9565" x2="6.1659" y2="-7.9438" layer="94"/>
<rectangle x1="6.458" y1="-7.9565" x2="6.8136" y2="-7.9438" layer="94"/>
<rectangle x1="7.5375" y1="-7.9565" x2="7.8042" y2="-7.9438" layer="94"/>
<rectangle x1="8.2741" y1="-7.9565" x2="8.5408" y2="-7.9438" layer="94"/>
<rectangle x1="10.141" y1="-7.9565" x2="10.4966" y2="-7.9438" layer="94"/>
<rectangle x1="11.03" y1="-7.9565" x2="11.3729" y2="-7.9438" layer="94"/>
<rectangle x1="-11.3728" y1="-7.9438" x2="-10.0774" y2="-7.9311" layer="94"/>
<rectangle x1="-9.544" y1="-7.9438" x2="-8.1597" y2="-7.9311" layer="94"/>
<rectangle x1="-7.5501" y1="-7.9438" x2="-6.2674" y2="-7.9311" layer="94"/>
<rectangle x1="-5.734" y1="-7.9438" x2="-5.3403" y2="-7.9311" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9438" x2="-4.2481" y2="-7.9311" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9438" x2="-2.3177" y2="-7.9311" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9438" x2="-1.2509" y2="-7.9311" layer="94"/>
<rectangle x1="-0.781" y1="-7.9438" x2="-0.4381" y2="-7.9311" layer="94"/>
<rectangle x1="0.2731" y1="-7.9438" x2="0.5779" y2="-7.9311" layer="94"/>
<rectangle x1="1.0224" y1="-7.9438" x2="1.3145" y2="-7.9311" layer="94"/>
<rectangle x1="2.8766" y1="-7.9438" x2="3.2322" y2="-7.9311" layer="94"/>
<rectangle x1="3.791" y1="-7.9438" x2="4.1339" y2="-7.9311" layer="94"/>
<rectangle x1="4.4895" y1="-7.9438" x2="4.807" y2="-7.9311" layer="94"/>
<rectangle x1="5.1499" y1="-7.9438" x2="5.4928" y2="-7.9311" layer="94"/>
<rectangle x1="5.8484" y1="-7.9438" x2="6.1659" y2="-7.9311" layer="94"/>
<rectangle x1="6.458" y1="-7.9438" x2="6.8009" y2="-7.9311" layer="94"/>
<rectangle x1="7.5375" y1="-7.9438" x2="7.8042" y2="-7.9311" layer="94"/>
<rectangle x1="8.2741" y1="-7.9438" x2="8.5408" y2="-7.9311" layer="94"/>
<rectangle x1="10.141" y1="-7.9438" x2="10.4839" y2="-7.9311" layer="94"/>
<rectangle x1="11.0427" y1="-7.9438" x2="11.3856" y2="-7.9311" layer="94"/>
<rectangle x1="-11.3728" y1="-7.9311" x2="-10.7886" y2="-7.9184" layer="94"/>
<rectangle x1="-10.6489" y1="-7.9311" x2="-10.0774" y2="-7.9184" layer="94"/>
<rectangle x1="-9.544" y1="-7.9311" x2="-8.8836" y2="-7.9184" layer="94"/>
<rectangle x1="-8.7439" y1="-7.9311" x2="-8.1597" y2="-7.9184" layer="94"/>
<rectangle x1="-7.5501" y1="-7.9311" x2="-6.9786" y2="-7.9184" layer="94"/>
<rectangle x1="-6.8135" y1="-7.9311" x2="-6.2674" y2="-7.9184" layer="94"/>
<rectangle x1="-5.734" y1="-7.9311" x2="-5.3403" y2="-7.9184" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9311" x2="-4.2481" y2="-7.9184" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9311" x2="-2.3177" y2="-7.9184" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9311" x2="-1.2509" y2="-7.9184" layer="94"/>
<rectangle x1="-0.781" y1="-7.9311" x2="-0.4508" y2="-7.9184" layer="94"/>
<rectangle x1="0.2731" y1="-7.9311" x2="0.5779" y2="-7.9184" layer="94"/>
<rectangle x1="1.0224" y1="-7.9311" x2="1.3145" y2="-7.9184" layer="94"/>
<rectangle x1="2.8766" y1="-7.9311" x2="3.2195" y2="-7.9184" layer="94"/>
<rectangle x1="3.8037" y1="-7.9311" x2="4.1466" y2="-7.9184" layer="94"/>
<rectangle x1="4.4895" y1="-7.9311" x2="4.807" y2="-7.9184" layer="94"/>
<rectangle x1="5.1499" y1="-7.9311" x2="5.4928" y2="-7.9184" layer="94"/>
<rectangle x1="5.8484" y1="-7.9311" x2="6.1659" y2="-7.9184" layer="94"/>
<rectangle x1="6.458" y1="-7.9311" x2="6.7882" y2="-7.9184" layer="94"/>
<rectangle x1="7.5375" y1="-7.9311" x2="7.8042" y2="-7.9184" layer="94"/>
<rectangle x1="8.2741" y1="-7.9311" x2="8.5408" y2="-7.9184" layer="94"/>
<rectangle x1="10.1283" y1="-7.9311" x2="10.4712" y2="-7.9184" layer="94"/>
<rectangle x1="11.0681" y1="-7.9311" x2="11.3983" y2="-7.9184" layer="94"/>
<rectangle x1="-11.3855" y1="-7.9184" x2="-10.8267" y2="-7.9057" layer="94"/>
<rectangle x1="-10.6108" y1="-7.9184" x2="-10.0774" y2="-7.9057" layer="94"/>
<rectangle x1="-9.544" y1="-7.9184" x2="-8.9217" y2="-7.9057" layer="94"/>
<rectangle x1="-8.7058" y1="-7.9184" x2="-8.147" y2="-7.9057" layer="94"/>
<rectangle x1="-7.5628" y1="-7.9184" x2="-7.0167" y2="-7.9057" layer="94"/>
<rectangle x1="-6.7881" y1="-7.9184" x2="-6.2674" y2="-7.9057" layer="94"/>
<rectangle x1="-5.734" y1="-7.9184" x2="-5.3403" y2="-7.9057" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9184" x2="-4.2481" y2="-7.9057" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9184" x2="-2.3177" y2="-7.9057" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9184" x2="-1.2509" y2="-7.9057" layer="94"/>
<rectangle x1="-0.781" y1="-7.9184" x2="-0.4635" y2="-7.9057" layer="94"/>
<rectangle x1="0.2731" y1="-7.9184" x2="0.5779" y2="-7.9057" layer="94"/>
<rectangle x1="1.0224" y1="-7.9184" x2="1.3145" y2="-7.9057" layer="94"/>
<rectangle x1="2.8766" y1="-7.9184" x2="3.2068" y2="-7.9057" layer="94"/>
<rectangle x1="3.8164" y1="-7.9184" x2="4.1466" y2="-7.9057" layer="94"/>
<rectangle x1="4.4895" y1="-7.9184" x2="4.7943" y2="-7.9057" layer="94"/>
<rectangle x1="5.1626" y1="-7.9184" x2="5.4928" y2="-7.9057" layer="94"/>
<rectangle x1="5.8484" y1="-7.9184" x2="6.1659" y2="-7.9057" layer="94"/>
<rectangle x1="6.458" y1="-7.9184" x2="6.7755" y2="-7.9057" layer="94"/>
<rectangle x1="7.5375" y1="-7.9184" x2="7.8042" y2="-7.9057" layer="94"/>
<rectangle x1="8.2741" y1="-7.9184" x2="8.5408" y2="-7.9057" layer="94"/>
<rectangle x1="10.1283" y1="-7.9184" x2="10.4712" y2="-7.9057" layer="94"/>
<rectangle x1="11.0808" y1="-7.9184" x2="11.3983" y2="-7.9057" layer="94"/>
<rectangle x1="-11.3982" y1="-7.9057" x2="-10.8521" y2="-7.893" layer="94"/>
<rectangle x1="-10.5981" y1="-7.9057" x2="-10.0647" y2="-7.893" layer="94"/>
<rectangle x1="-9.544" y1="-7.9057" x2="-8.9471" y2="-7.893" layer="94"/>
<rectangle x1="-8.6804" y1="-7.9057" x2="-8.147" y2="-7.893" layer="94"/>
<rectangle x1="-7.5755" y1="-7.9057" x2="-7.0294" y2="-7.893" layer="94"/>
<rectangle x1="-6.7754" y1="-7.9057" x2="-6.2547" y2="-7.893" layer="94"/>
<rectangle x1="-5.734" y1="-7.9057" x2="-5.3403" y2="-7.893" layer="94"/>
<rectangle x1="-4.6545" y1="-7.9057" x2="-4.2481" y2="-7.893" layer="94"/>
<rectangle x1="-2.5971" y1="-7.9057" x2="-2.3177" y2="-7.893" layer="94"/>
<rectangle x1="-1.5176" y1="-7.9057" x2="-1.2509" y2="-7.893" layer="94"/>
<rectangle x1="-0.781" y1="-7.9057" x2="-0.4635" y2="-7.893" layer="94"/>
<rectangle x1="0.2731" y1="-7.9057" x2="0.5779" y2="-7.893" layer="94"/>
<rectangle x1="1.0224" y1="-7.9057" x2="1.3145" y2="-7.893" layer="94"/>
<rectangle x1="2.8766" y1="-7.9057" x2="3.2068" y2="-7.893" layer="94"/>
<rectangle x1="3.8164" y1="-7.9057" x2="4.1466" y2="-7.893" layer="94"/>
<rectangle x1="4.4895" y1="-7.9057" x2="4.7943" y2="-7.893" layer="94"/>
<rectangle x1="5.1626" y1="-7.9057" x2="5.4928" y2="-7.893" layer="94"/>
<rectangle x1="5.8484" y1="-7.9057" x2="6.1659" y2="-7.893" layer="94"/>
<rectangle x1="6.4453" y1="-7.9057" x2="6.7755" y2="-7.893" layer="94"/>
<rectangle x1="7.5375" y1="-7.9057" x2="7.8042" y2="-7.893" layer="94"/>
<rectangle x1="8.2741" y1="-7.9057" x2="8.5408" y2="-7.893" layer="94"/>
<rectangle x1="10.1156" y1="-7.9057" x2="10.4585" y2="-7.893" layer="94"/>
<rectangle x1="11.0808" y1="-7.9057" x2="11.411" y2="-7.893" layer="94"/>
<rectangle x1="-11.4109" y1="-7.893" x2="-10.8648" y2="-7.8803" layer="94"/>
<rectangle x1="-10.5854" y1="-7.893" x2="-10.0647" y2="-7.8803" layer="94"/>
<rectangle x1="-9.544" y1="-7.893" x2="-8.9598" y2="-7.8803" layer="94"/>
<rectangle x1="-8.6677" y1="-7.893" x2="-8.147" y2="-7.8803" layer="94"/>
<rectangle x1="-7.5755" y1="-7.893" x2="-7.0421" y2="-7.8803" layer="94"/>
<rectangle x1="-6.75" y1="-7.893" x2="-6.2547" y2="-7.8803" layer="94"/>
<rectangle x1="-5.734" y1="-7.893" x2="-5.3403" y2="-7.8803" layer="94"/>
<rectangle x1="-4.6545" y1="-7.893" x2="-4.2481" y2="-7.8803" layer="94"/>
<rectangle x1="-2.5971" y1="-7.893" x2="-2.3177" y2="-7.8803" layer="94"/>
<rectangle x1="-1.5176" y1="-7.893" x2="-1.2509" y2="-7.8803" layer="94"/>
<rectangle x1="-0.7937" y1="-7.893" x2="-0.4762" y2="-7.8803" layer="94"/>
<rectangle x1="0.2731" y1="-7.893" x2="0.5779" y2="-7.8803" layer="94"/>
<rectangle x1="1.0224" y1="-7.893" x2="1.3145" y2="-7.8803" layer="94"/>
<rectangle x1="2.8639" y1="-7.893" x2="3.1941" y2="-7.8803" layer="94"/>
<rectangle x1="3.8291" y1="-7.893" x2="4.1593" y2="-7.8803" layer="94"/>
<rectangle x1="4.4895" y1="-7.893" x2="4.7943" y2="-7.8803" layer="94"/>
<rectangle x1="5.1626" y1="-7.893" x2="5.4928" y2="-7.8803" layer="94"/>
<rectangle x1="5.8611" y1="-7.893" x2="6.1659" y2="-7.8803" layer="94"/>
<rectangle x1="6.4453" y1="-7.893" x2="6.7628" y2="-7.8803" layer="94"/>
<rectangle x1="7.5375" y1="-7.893" x2="7.8042" y2="-7.8803" layer="94"/>
<rectangle x1="8.2741" y1="-7.893" x2="8.5408" y2="-7.8803" layer="94"/>
<rectangle x1="10.1029" y1="-7.893" x2="10.4458" y2="-7.8803" layer="94"/>
<rectangle x1="11.0935" y1="-7.893" x2="11.411" y2="-7.8803" layer="94"/>
<rectangle x1="-11.4109" y1="-7.8803" x2="-10.8902" y2="-7.8676" layer="94"/>
<rectangle x1="-10.5727" y1="-7.8803" x2="-10.052" y2="-7.8676" layer="94"/>
<rectangle x1="-9.544" y1="-7.8803" x2="-8.9725" y2="-7.8676" layer="94"/>
<rectangle x1="-8.6423" y1="-7.8803" x2="-8.1343" y2="-7.8676" layer="94"/>
<rectangle x1="-7.5882" y1="-7.8803" x2="-7.0675" y2="-7.8676" layer="94"/>
<rectangle x1="-6.7373" y1="-7.8803" x2="-6.242" y2="-7.8676" layer="94"/>
<rectangle x1="-5.734" y1="-7.8803" x2="-5.3403" y2="-7.8676" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8803" x2="-4.2481" y2="-7.8676" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8803" x2="-2.3177" y2="-7.8676" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8803" x2="-1.2509" y2="-7.8676" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8803" x2="-0.4889" y2="-7.8676" layer="94"/>
<rectangle x1="0.2731" y1="-7.8803" x2="0.5779" y2="-7.8676" layer="94"/>
<rectangle x1="1.0224" y1="-7.8803" x2="1.3145" y2="-7.8676" layer="94"/>
<rectangle x1="2.8639" y1="-7.8803" x2="3.1941" y2="-7.8676" layer="94"/>
<rectangle x1="3.8418" y1="-7.8803" x2="4.1593" y2="-7.8676" layer="94"/>
<rectangle x1="4.4895" y1="-7.8803" x2="4.7816" y2="-7.8676" layer="94"/>
<rectangle x1="5.1626" y1="-7.8803" x2="5.4801" y2="-7.8676" layer="94"/>
<rectangle x1="5.8611" y1="-7.8803" x2="6.1659" y2="-7.8676" layer="94"/>
<rectangle x1="6.4453" y1="-7.8803" x2="6.7628" y2="-7.8676" layer="94"/>
<rectangle x1="7.5375" y1="-7.8803" x2="7.8042" y2="-7.8676" layer="94"/>
<rectangle x1="8.2741" y1="-7.8803" x2="8.5408" y2="-7.8676" layer="94"/>
<rectangle x1="10.1029" y1="-7.8803" x2="10.4331" y2="-7.8676" layer="94"/>
<rectangle x1="11.0935" y1="-7.8803" x2="11.411" y2="-7.8676" layer="94"/>
<rectangle x1="-11.4109" y1="-7.8676" x2="-10.9156" y2="-7.8549" layer="94"/>
<rectangle x1="-10.5473" y1="-7.8676" x2="-10.0393" y2="-7.8549" layer="94"/>
<rectangle x1="-9.544" y1="-7.8676" x2="-8.9979" y2="-7.8549" layer="94"/>
<rectangle x1="-8.6296" y1="-7.8676" x2="-8.1343" y2="-7.8549" layer="94"/>
<rectangle x1="-7.6009" y1="-7.8676" x2="-7.0929" y2="-7.8549" layer="94"/>
<rectangle x1="-6.7119" y1="-7.8676" x2="-6.2293" y2="-7.8549" layer="94"/>
<rectangle x1="-5.734" y1="-7.8676" x2="-5.3403" y2="-7.8549" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8676" x2="-4.2481" y2="-7.8549" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8676" x2="-2.3177" y2="-7.8549" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8676" x2="-1.2509" y2="-7.8549" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8676" x2="-0.4889" y2="-7.8549" layer="94"/>
<rectangle x1="0.2731" y1="-7.8676" x2="0.5779" y2="-7.8549" layer="94"/>
<rectangle x1="1.0224" y1="-7.8676" x2="1.3145" y2="-7.8549" layer="94"/>
<rectangle x1="2.8639" y1="-7.8676" x2="3.1814" y2="-7.8549" layer="94"/>
<rectangle x1="3.8545" y1="-7.8676" x2="4.172" y2="-7.8549" layer="94"/>
<rectangle x1="4.4895" y1="-7.8676" x2="4.7816" y2="-7.8549" layer="94"/>
<rectangle x1="5.1626" y1="-7.8676" x2="5.4801" y2="-7.8549" layer="94"/>
<rectangle x1="5.8611" y1="-7.8676" x2="6.1659" y2="-7.8549" layer="94"/>
<rectangle x1="6.4453" y1="-7.8676" x2="6.7628" y2="-7.8549" layer="94"/>
<rectangle x1="7.5375" y1="-7.8676" x2="7.8042" y2="-7.8549" layer="94"/>
<rectangle x1="8.2741" y1="-7.8676" x2="8.5408" y2="-7.8549" layer="94"/>
<rectangle x1="10.0902" y1="-7.8676" x2="10.4204" y2="-7.8549" layer="94"/>
<rectangle x1="11.0935" y1="-7.8676" x2="11.411" y2="-7.8549" layer="94"/>
<rectangle x1="-11.4236" y1="-7.8549" x2="-10.9283" y2="-7.8422" layer="94"/>
<rectangle x1="-10.5219" y1="-7.8549" x2="-10.0393" y2="-7.8422" layer="94"/>
<rectangle x1="-9.544" y1="-7.8549" x2="-9.0233" y2="-7.8422" layer="94"/>
<rectangle x1="-8.5915" y1="-7.8549" x2="-8.1343" y2="-7.8422" layer="94"/>
<rectangle x1="-7.6009" y1="-7.8549" x2="-7.1183" y2="-7.8422" layer="94"/>
<rectangle x1="-6.6865" y1="-7.8549" x2="-6.2166" y2="-7.8422" layer="94"/>
<rectangle x1="-5.734" y1="-7.8549" x2="-5.3403" y2="-7.8422" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8549" x2="-4.2481" y2="-7.8422" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8549" x2="-2.3177" y2="-7.8422" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8549" x2="-1.2509" y2="-7.8422" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8549" x2="-0.5016" y2="-7.8422" layer="94"/>
<rectangle x1="0.2731" y1="-7.8549" x2="0.5779" y2="-7.8422" layer="94"/>
<rectangle x1="1.0224" y1="-7.8549" x2="1.3145" y2="-7.8422" layer="94"/>
<rectangle x1="2.8639" y1="-7.8549" x2="3.1687" y2="-7.8422" layer="94"/>
<rectangle x1="3.8672" y1="-7.8549" x2="4.172" y2="-7.8422" layer="94"/>
<rectangle x1="4.4895" y1="-7.8549" x2="4.7689" y2="-7.8422" layer="94"/>
<rectangle x1="5.1626" y1="-7.8549" x2="5.4801" y2="-7.8422" layer="94"/>
<rectangle x1="5.8738" y1="-7.8549" x2="6.1659" y2="-7.8422" layer="94"/>
<rectangle x1="6.4453" y1="-7.8549" x2="6.7628" y2="-7.8422" layer="94"/>
<rectangle x1="7.5375" y1="-7.8549" x2="7.8042" y2="-7.8422" layer="94"/>
<rectangle x1="8.2741" y1="-7.8549" x2="8.5408" y2="-7.8422" layer="94"/>
<rectangle x1="10.0902" y1="-7.8549" x2="10.4204" y2="-7.8422" layer="94"/>
<rectangle x1="11.1062" y1="-7.8549" x2="11.411" y2="-7.8422" layer="94"/>
<rectangle x1="-11.4236" y1="-7.8422" x2="-10.941" y2="-7.8295" layer="94"/>
<rectangle x1="-10.5092" y1="-7.8422" x2="-10.0266" y2="-7.8295" layer="94"/>
<rectangle x1="-9.544" y1="-7.8422" x2="-9.0487" y2="-7.8295" layer="94"/>
<rectangle x1="-8.5788" y1="-7.8422" x2="-8.1343" y2="-7.8295" layer="94"/>
<rectangle x1="-7.6009" y1="-7.8422" x2="-7.131" y2="-7.8295" layer="94"/>
<rectangle x1="-6.6738" y1="-7.8422" x2="-6.2166" y2="-7.8295" layer="94"/>
<rectangle x1="-5.734" y1="-7.8422" x2="-5.3403" y2="-7.8295" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8422" x2="-4.2481" y2="-7.8295" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8422" x2="-2.3177" y2="-7.8295" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8422" x2="-1.2509" y2="-7.8295" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8422" x2="-0.5016" y2="-7.8295" layer="94"/>
<rectangle x1="0.2731" y1="-7.8422" x2="0.5779" y2="-7.8295" layer="94"/>
<rectangle x1="1.0224" y1="-7.8422" x2="1.3145" y2="-7.8295" layer="94"/>
<rectangle x1="2.8639" y1="-7.8422" x2="3.156" y2="-7.8295" layer="94"/>
<rectangle x1="3.8672" y1="-7.8422" x2="4.172" y2="-7.8295" layer="94"/>
<rectangle x1="4.4895" y1="-7.8422" x2="4.7689" y2="-7.8295" layer="94"/>
<rectangle x1="5.1626" y1="-7.8422" x2="5.4801" y2="-7.8295" layer="94"/>
<rectangle x1="5.8738" y1="-7.8422" x2="6.1659" y2="-7.8295" layer="94"/>
<rectangle x1="6.4453" y1="-7.8422" x2="6.7628" y2="-7.8295" layer="94"/>
<rectangle x1="7.5375" y1="-7.8422" x2="7.8042" y2="-7.8295" layer="94"/>
<rectangle x1="8.2741" y1="-7.8422" x2="8.5408" y2="-7.8295" layer="94"/>
<rectangle x1="10.0902" y1="-7.8422" x2="10.4077" y2="-7.8295" layer="94"/>
<rectangle x1="11.1062" y1="-7.8422" x2="11.4237" y2="-7.8295" layer="94"/>
<rectangle x1="-11.4236" y1="-7.8295" x2="-10.9537" y2="-7.8168" layer="94"/>
<rectangle x1="-10.4965" y1="-7.8295" x2="-10.0266" y2="-7.8168" layer="94"/>
<rectangle x1="-9.544" y1="-7.8295" x2="-9.0614" y2="-7.8168" layer="94"/>
<rectangle x1="-8.5661" y1="-7.8295" x2="-8.1216" y2="-7.8168" layer="94"/>
<rectangle x1="-7.6136" y1="-7.8295" x2="-7.1437" y2="-7.8168" layer="94"/>
<rectangle x1="-6.6611" y1="-7.8295" x2="-6.2039" y2="-7.8168" layer="94"/>
<rectangle x1="-5.734" y1="-7.8295" x2="-5.3403" y2="-7.8168" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8295" x2="-4.2481" y2="-7.8168" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8295" x2="-2.3177" y2="-7.8168" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8295" x2="-1.2509" y2="-7.8168" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8295" x2="-0.5143" y2="-7.8168" layer="94"/>
<rectangle x1="0.2731" y1="-7.8295" x2="0.5779" y2="-7.8168" layer="94"/>
<rectangle x1="1.0224" y1="-7.8295" x2="1.3145" y2="-7.8168" layer="94"/>
<rectangle x1="2.8512" y1="-7.8295" x2="3.1433" y2="-7.8168" layer="94"/>
<rectangle x1="3.8799" y1="-7.8295" x2="4.1847" y2="-7.8168" layer="94"/>
<rectangle x1="4.4768" y1="-7.8295" x2="4.7562" y2="-7.8168" layer="94"/>
<rectangle x1="5.1626" y1="-7.8295" x2="5.4674" y2="-7.8168" layer="94"/>
<rectangle x1="5.8865" y1="-7.8295" x2="6.1659" y2="-7.8168" layer="94"/>
<rectangle x1="6.4453" y1="-7.8295" x2="6.7628" y2="-7.8168" layer="94"/>
<rectangle x1="7.5375" y1="-7.8295" x2="7.8042" y2="-7.8168" layer="94"/>
<rectangle x1="8.2741" y1="-7.8295" x2="8.5408" y2="-7.8168" layer="94"/>
<rectangle x1="10.0902" y1="-7.8295" x2="10.4077" y2="-7.8168" layer="94"/>
<rectangle x1="11.1189" y1="-7.8295" x2="11.4237" y2="-7.8168" layer="94"/>
<rectangle x1="-11.4236" y1="-7.8168" x2="-10.9664" y2="-7.8041" layer="94"/>
<rectangle x1="-10.4838" y1="-7.8168" x2="-10.0266" y2="-7.8041" layer="94"/>
<rectangle x1="-9.544" y1="-7.8168" x2="-9.0741" y2="-7.8041" layer="94"/>
<rectangle x1="-8.5534" y1="-7.8168" x2="-8.1216" y2="-7.8041" layer="94"/>
<rectangle x1="-7.6136" y1="-7.8168" x2="-7.1564" y2="-7.8041" layer="94"/>
<rectangle x1="-6.6484" y1="-7.8168" x2="-6.2039" y2="-7.8041" layer="94"/>
<rectangle x1="-5.734" y1="-7.8168" x2="-5.3403" y2="-7.8041" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8168" x2="-4.2481" y2="-7.8041" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8168" x2="-2.3177" y2="-7.8041" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8168" x2="-1.2509" y2="-7.8041" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8168" x2="-0.5143" y2="-7.8041" layer="94"/>
<rectangle x1="0.2731" y1="-7.8168" x2="0.5779" y2="-7.8041" layer="94"/>
<rectangle x1="1.0224" y1="-7.8168" x2="1.3145" y2="-7.8041" layer="94"/>
<rectangle x1="2.8512" y1="-7.8168" x2="3.1433" y2="-7.8041" layer="94"/>
<rectangle x1="3.8799" y1="-7.8168" x2="4.1847" y2="-7.8041" layer="94"/>
<rectangle x1="4.4768" y1="-7.8168" x2="4.7562" y2="-7.8041" layer="94"/>
<rectangle x1="5.1626" y1="-7.8168" x2="5.4674" y2="-7.8041" layer="94"/>
<rectangle x1="5.8992" y1="-7.8168" x2="6.1659" y2="-7.8041" layer="94"/>
<rectangle x1="6.4453" y1="-7.8168" x2="6.7628" y2="-7.8041" layer="94"/>
<rectangle x1="7.5375" y1="-7.8168" x2="7.8042" y2="-7.8041" layer="94"/>
<rectangle x1="8.2741" y1="-7.8168" x2="8.5408" y2="-7.8041" layer="94"/>
<rectangle x1="10.0902" y1="-7.8168" x2="10.395" y2="-7.8041" layer="94"/>
<rectangle x1="11.1316" y1="-7.8168" x2="11.4237" y2="-7.8041" layer="94"/>
<rectangle x1="-11.4363" y1="-7.8041" x2="-10.9791" y2="-7.7914" layer="94"/>
<rectangle x1="-10.4711" y1="-7.8041" x2="-10.0139" y2="-7.7914" layer="94"/>
<rectangle x1="-9.544" y1="-7.8041" x2="-9.0741" y2="-7.7914" layer="94"/>
<rectangle x1="-8.5534" y1="-7.8041" x2="-8.1216" y2="-7.7914" layer="94"/>
<rectangle x1="-7.6136" y1="-7.8041" x2="-7.1691" y2="-7.7914" layer="94"/>
<rectangle x1="-6.6357" y1="-7.8041" x2="-6.2039" y2="-7.7914" layer="94"/>
<rectangle x1="-5.734" y1="-7.8041" x2="-5.3403" y2="-7.7914" layer="94"/>
<rectangle x1="-4.6545" y1="-7.8041" x2="-4.2481" y2="-7.7914" layer="94"/>
<rectangle x1="-2.5971" y1="-7.8041" x2="-2.3177" y2="-7.7914" layer="94"/>
<rectangle x1="-1.5176" y1="-7.8041" x2="-1.2509" y2="-7.7914" layer="94"/>
<rectangle x1="-0.7937" y1="-7.8041" x2="-0.5143" y2="-7.7914" layer="94"/>
<rectangle x1="0.2731" y1="-7.8041" x2="0.5779" y2="-7.7914" layer="94"/>
<rectangle x1="1.0224" y1="-7.8041" x2="1.3145" y2="-7.7914" layer="94"/>
<rectangle x1="2.8512" y1="-7.8041" x2="3.1306" y2="-7.7914" layer="94"/>
<rectangle x1="3.8926" y1="-7.8041" x2="4.1847" y2="-7.7914" layer="94"/>
<rectangle x1="4.4768" y1="-7.8041" x2="4.7562" y2="-7.7914" layer="94"/>
<rectangle x1="5.1753" y1="-7.8041" x2="5.4674" y2="-7.7914" layer="94"/>
<rectangle x1="5.8992" y1="-7.8041" x2="6.1659" y2="-7.7914" layer="94"/>
<rectangle x1="6.4453" y1="-7.8041" x2="6.7628" y2="-7.7914" layer="94"/>
<rectangle x1="7.5375" y1="-7.8041" x2="7.8042" y2="-7.7914" layer="94"/>
<rectangle x1="8.2741" y1="-7.8041" x2="8.5408" y2="-7.7914" layer="94"/>
<rectangle x1="10.0775" y1="-7.8041" x2="10.395" y2="-7.7914" layer="94"/>
<rectangle x1="11.1316" y1="-7.8041" x2="11.4237" y2="-7.7914" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7914" x2="-10.9918" y2="-7.7787" layer="94"/>
<rectangle x1="-10.4711" y1="-7.7914" x2="-10.0139" y2="-7.7787" layer="94"/>
<rectangle x1="-9.544" y1="-7.7914" x2="-9.0868" y2="-7.7787" layer="94"/>
<rectangle x1="-8.5407" y1="-7.7914" x2="-8.1089" y2="-7.7787" layer="94"/>
<rectangle x1="-7.6136" y1="-7.7914" x2="-7.1818" y2="-7.7787" layer="94"/>
<rectangle x1="-6.623" y1="-7.7914" x2="-6.2039" y2="-7.7787" layer="94"/>
<rectangle x1="-5.734" y1="-7.7914" x2="-5.3403" y2="-7.7787" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7914" x2="-4.2481" y2="-7.7787" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7914" x2="-2.3177" y2="-7.7787" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7914" x2="-1.2509" y2="-7.7787" layer="94"/>
<rectangle x1="-0.7937" y1="-7.7914" x2="-0.5143" y2="-7.7787" layer="94"/>
<rectangle x1="0.2731" y1="-7.7914" x2="0.5779" y2="-7.7787" layer="94"/>
<rectangle x1="1.0224" y1="-7.7914" x2="1.3145" y2="-7.7787" layer="94"/>
<rectangle x1="2.8512" y1="-7.7914" x2="3.1306" y2="-7.7787" layer="94"/>
<rectangle x1="3.8926" y1="-7.7914" x2="4.1974" y2="-7.7787" layer="94"/>
<rectangle x1="4.4768" y1="-7.7914" x2="4.7562" y2="-7.7787" layer="94"/>
<rectangle x1="5.1753" y1="-7.7914" x2="5.4674" y2="-7.7787" layer="94"/>
<rectangle x1="5.8992" y1="-7.7914" x2="6.1659" y2="-7.7787" layer="94"/>
<rectangle x1="6.4453" y1="-7.7914" x2="6.7628" y2="-7.7787" layer="94"/>
<rectangle x1="7.5375" y1="-7.7914" x2="7.8042" y2="-7.7787" layer="94"/>
<rectangle x1="8.2741" y1="-7.7914" x2="8.5408" y2="-7.7787" layer="94"/>
<rectangle x1="10.0775" y1="-7.7914" x2="10.395" y2="-7.7787" layer="94"/>
<rectangle x1="11.1443" y1="-7.7914" x2="11.4237" y2="-7.7787" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7787" x2="-11.0045" y2="-7.766" layer="94"/>
<rectangle x1="-10.4457" y1="-7.7787" x2="-10.0139" y2="-7.766" layer="94"/>
<rectangle x1="-9.544" y1="-7.7787" x2="-9.0868" y2="-7.766" layer="94"/>
<rectangle x1="-8.5407" y1="-7.7787" x2="-8.1089" y2="-7.766" layer="94"/>
<rectangle x1="-7.6136" y1="-7.7787" x2="-7.1945" y2="-7.766" layer="94"/>
<rectangle x1="-6.623" y1="-7.7787" x2="-6.1912" y2="-7.766" layer="94"/>
<rectangle x1="-5.734" y1="-7.7787" x2="-5.3403" y2="-7.766" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7787" x2="-4.2481" y2="-7.766" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7787" x2="-2.3177" y2="-7.766" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7787" x2="-1.2509" y2="-7.766" layer="94"/>
<rectangle x1="-0.7937" y1="-7.7787" x2="-0.5016" y2="-7.766" layer="94"/>
<rectangle x1="0.2731" y1="-7.7787" x2="0.5779" y2="-7.766" layer="94"/>
<rectangle x1="1.0224" y1="-7.7787" x2="1.3145" y2="-7.766" layer="94"/>
<rectangle x1="2.8385" y1="-7.7787" x2="3.1306" y2="-7.766" layer="94"/>
<rectangle x1="3.8926" y1="-7.7787" x2="4.1974" y2="-7.766" layer="94"/>
<rectangle x1="4.4768" y1="-7.7787" x2="4.7562" y2="-7.766" layer="94"/>
<rectangle x1="5.1753" y1="-7.7787" x2="5.4674" y2="-7.766" layer="94"/>
<rectangle x1="5.8992" y1="-7.7787" x2="6.1659" y2="-7.766" layer="94"/>
<rectangle x1="6.4453" y1="-7.7787" x2="6.7628" y2="-7.766" layer="94"/>
<rectangle x1="7.5375" y1="-7.7787" x2="7.8042" y2="-7.766" layer="94"/>
<rectangle x1="8.2741" y1="-7.7787" x2="8.5408" y2="-7.766" layer="94"/>
<rectangle x1="10.0775" y1="-7.7787" x2="10.395" y2="-7.766" layer="94"/>
<rectangle x1="11.1443" y1="-7.7787" x2="11.4364" y2="-7.766" layer="94"/>
<rectangle x1="-11.4363" y1="-7.766" x2="-11.0172" y2="-7.7533" layer="94"/>
<rectangle x1="-10.433" y1="-7.766" x2="-10.0139" y2="-7.7533" layer="94"/>
<rectangle x1="-9.544" y1="-7.766" x2="-9.0995" y2="-7.7533" layer="94"/>
<rectangle x1="-8.528" y1="-7.766" x2="-8.1089" y2="-7.7533" layer="94"/>
<rectangle x1="-7.6136" y1="-7.766" x2="-7.1945" y2="-7.7533" layer="94"/>
<rectangle x1="-6.6103" y1="-7.766" x2="-6.1912" y2="-7.7533" layer="94"/>
<rectangle x1="-5.734" y1="-7.766" x2="-5.3403" y2="-7.7533" layer="94"/>
<rectangle x1="-4.6545" y1="-7.766" x2="-4.2481" y2="-7.7533" layer="94"/>
<rectangle x1="-2.5971" y1="-7.766" x2="-2.3177" y2="-7.7533" layer="94"/>
<rectangle x1="-1.5176" y1="-7.766" x2="-1.2509" y2="-7.7533" layer="94"/>
<rectangle x1="-0.7937" y1="-7.766" x2="-0.5016" y2="-7.7533" layer="94"/>
<rectangle x1="0.2731" y1="-7.766" x2="0.5779" y2="-7.7533" layer="94"/>
<rectangle x1="1.0224" y1="-7.766" x2="1.3145" y2="-7.7533" layer="94"/>
<rectangle x1="2.8385" y1="-7.766" x2="3.1179" y2="-7.7533" layer="94"/>
<rectangle x1="3.8926" y1="-7.766" x2="4.1974" y2="-7.7533" layer="94"/>
<rectangle x1="4.4768" y1="-7.766" x2="4.7562" y2="-7.7533" layer="94"/>
<rectangle x1="5.1753" y1="-7.766" x2="5.4674" y2="-7.7533" layer="94"/>
<rectangle x1="5.8992" y1="-7.766" x2="6.1659" y2="-7.7533" layer="94"/>
<rectangle x1="6.4453" y1="-7.766" x2="6.7628" y2="-7.7533" layer="94"/>
<rectangle x1="7.5375" y1="-7.766" x2="7.8042" y2="-7.7533" layer="94"/>
<rectangle x1="8.2741" y1="-7.766" x2="8.5408" y2="-7.7533" layer="94"/>
<rectangle x1="10.0775" y1="-7.766" x2="10.3823" y2="-7.7533" layer="94"/>
<rectangle x1="11.157" y1="-7.766" x2="11.4364" y2="-7.7533" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7533" x2="-11.0172" y2="-7.7406" layer="94"/>
<rectangle x1="-10.4203" y1="-7.7533" x2="-10.0139" y2="-7.7406" layer="94"/>
<rectangle x1="-9.544" y1="-7.7533" x2="-9.1122" y2="-7.7406" layer="94"/>
<rectangle x1="-8.5153" y1="-7.7533" x2="-8.0962" y2="-7.7406" layer="94"/>
<rectangle x1="-7.6136" y1="-7.7533" x2="-7.2072" y2="-7.7406" layer="94"/>
<rectangle x1="-6.5976" y1="-7.7533" x2="-6.1912" y2="-7.7406" layer="94"/>
<rectangle x1="-5.734" y1="-7.7533" x2="-5.3403" y2="-7.7406" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7533" x2="-4.2481" y2="-7.7406" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7533" x2="-2.3177" y2="-7.7406" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7533" x2="-1.2509" y2="-7.7406" layer="94"/>
<rectangle x1="-0.7937" y1="-7.7533" x2="-0.4889" y2="-7.7406" layer="94"/>
<rectangle x1="0.2731" y1="-7.7533" x2="0.5779" y2="-7.7406" layer="94"/>
<rectangle x1="1.0224" y1="-7.7533" x2="1.3145" y2="-7.7406" layer="94"/>
<rectangle x1="2.8385" y1="-7.7533" x2="3.1179" y2="-7.7406" layer="94"/>
<rectangle x1="3.8926" y1="-7.7533" x2="4.1974" y2="-7.7406" layer="94"/>
<rectangle x1="4.4768" y1="-7.7533" x2="4.7562" y2="-7.7406" layer="94"/>
<rectangle x1="5.1753" y1="-7.7533" x2="5.4674" y2="-7.7406" layer="94"/>
<rectangle x1="5.8992" y1="-7.7533" x2="6.1659" y2="-7.7406" layer="94"/>
<rectangle x1="6.4453" y1="-7.7533" x2="6.7628" y2="-7.7406" layer="94"/>
<rectangle x1="7.5375" y1="-7.7533" x2="7.8042" y2="-7.7406" layer="94"/>
<rectangle x1="8.2741" y1="-7.7533" x2="8.5408" y2="-7.7406" layer="94"/>
<rectangle x1="10.0775" y1="-7.7533" x2="10.3823" y2="-7.7406" layer="94"/>
<rectangle x1="11.157" y1="-7.7533" x2="11.4364" y2="-7.7406" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7406" x2="-11.0299" y2="-7.7279" layer="94"/>
<rectangle x1="-10.4203" y1="-7.7406" x2="-10.0139" y2="-7.7279" layer="94"/>
<rectangle x1="-9.544" y1="-7.7406" x2="-9.1249" y2="-7.7279" layer="94"/>
<rectangle x1="-8.5026" y1="-7.7406" x2="-8.0962" y2="-7.7279" layer="94"/>
<rectangle x1="-7.6263" y1="-7.7406" x2="-7.2072" y2="-7.7279" layer="94"/>
<rectangle x1="-6.5976" y1="-7.7406" x2="-6.1912" y2="-7.7279" layer="94"/>
<rectangle x1="-5.734" y1="-7.7406" x2="-5.3403" y2="-7.7279" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7406" x2="-4.2481" y2="-7.7279" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7406" x2="-2.3177" y2="-7.7279" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7406" x2="-1.2509" y2="-7.7279" layer="94"/>
<rectangle x1="-0.7937" y1="-7.7406" x2="-0.4889" y2="-7.7279" layer="94"/>
<rectangle x1="0.2731" y1="-7.7406" x2="0.5779" y2="-7.7279" layer="94"/>
<rectangle x1="1.0224" y1="-7.7406" x2="1.3145" y2="-7.7279" layer="94"/>
<rectangle x1="2.8258" y1="-7.7406" x2="3.1179" y2="-7.7279" layer="94"/>
<rectangle x1="3.8926" y1="-7.7406" x2="4.1974" y2="-7.7279" layer="94"/>
<rectangle x1="4.4768" y1="-7.7406" x2="4.7562" y2="-7.7279" layer="94"/>
<rectangle x1="5.1753" y1="-7.7406" x2="5.4674" y2="-7.7279" layer="94"/>
<rectangle x1="5.8992" y1="-7.7406" x2="6.1659" y2="-7.7279" layer="94"/>
<rectangle x1="6.4453" y1="-7.7406" x2="6.7628" y2="-7.7279" layer="94"/>
<rectangle x1="7.5375" y1="-7.7406" x2="7.8042" y2="-7.7279" layer="94"/>
<rectangle x1="8.2741" y1="-7.7406" x2="8.5408" y2="-7.7279" layer="94"/>
<rectangle x1="10.0775" y1="-7.7406" x2="10.3823" y2="-7.7279" layer="94"/>
<rectangle x1="11.157" y1="-7.7406" x2="11.4364" y2="-7.7279" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7279" x2="-11.0299" y2="-7.7152" layer="94"/>
<rectangle x1="-10.4203" y1="-7.7279" x2="-10.0139" y2="-7.7152" layer="94"/>
<rectangle x1="-9.544" y1="-7.7279" x2="-9.1376" y2="-7.7152" layer="94"/>
<rectangle x1="-8.5026" y1="-7.7279" x2="-8.0835" y2="-7.7152" layer="94"/>
<rectangle x1="-7.6263" y1="-7.7279" x2="-7.2199" y2="-7.7152" layer="94"/>
<rectangle x1="-6.5976" y1="-7.7279" x2="-6.1912" y2="-7.7152" layer="94"/>
<rectangle x1="-5.734" y1="-7.7279" x2="-5.3403" y2="-7.7152" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7279" x2="-4.2481" y2="-7.7152" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7279" x2="-2.3177" y2="-7.7152" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7279" x2="-1.2509" y2="-7.7152" layer="94"/>
<rectangle x1="-0.7937" y1="-7.7279" x2="-0.4762" y2="-7.7152" layer="94"/>
<rectangle x1="0.2731" y1="-7.7279" x2="0.5779" y2="-7.7152" layer="94"/>
<rectangle x1="1.0224" y1="-7.7279" x2="1.3145" y2="-7.7152" layer="94"/>
<rectangle x1="2.8258" y1="-7.7279" x2="3.1179" y2="-7.7152" layer="94"/>
<rectangle x1="3.8926" y1="-7.7279" x2="4.1974" y2="-7.7152" layer="94"/>
<rectangle x1="4.4768" y1="-7.7279" x2="4.7562" y2="-7.7152" layer="94"/>
<rectangle x1="5.1626" y1="-7.7279" x2="5.4674" y2="-7.7152" layer="94"/>
<rectangle x1="5.8992" y1="-7.7279" x2="6.1659" y2="-7.7152" layer="94"/>
<rectangle x1="6.4453" y1="-7.7279" x2="6.7628" y2="-7.7152" layer="94"/>
<rectangle x1="7.5375" y1="-7.7279" x2="7.8042" y2="-7.7152" layer="94"/>
<rectangle x1="8.2741" y1="-7.7279" x2="8.5408" y2="-7.7152" layer="94"/>
<rectangle x1="10.0775" y1="-7.7279" x2="10.3823" y2="-7.7152" layer="94"/>
<rectangle x1="11.1697" y1="-7.7279" x2="11.4491" y2="-7.7152" layer="94"/>
<rectangle x1="-11.4363" y1="-7.7152" x2="-11.0299" y2="-7.7025" layer="94"/>
<rectangle x1="-10.4076" y1="-7.7152" x2="-10.0012" y2="-7.7025" layer="94"/>
<rectangle x1="-9.544" y1="-7.7152" x2="-9.1376" y2="-7.7025" layer="94"/>
<rectangle x1="-8.4899" y1="-7.7152" x2="-8.0835" y2="-7.7025" layer="94"/>
<rectangle x1="-7.6263" y1="-7.7152" x2="-7.2199" y2="-7.7025" layer="94"/>
<rectangle x1="-6.5849" y1="-7.7152" x2="-6.1912" y2="-7.7025" layer="94"/>
<rectangle x1="-5.734" y1="-7.7152" x2="-5.3403" y2="-7.7025" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7152" x2="-4.2481" y2="-7.7025" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7152" x2="-2.3177" y2="-7.7025" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7152" x2="-1.2509" y2="-7.7025" layer="94"/>
<rectangle x1="-0.781" y1="-7.7152" x2="-0.4635" y2="-7.7025" layer="94"/>
<rectangle x1="0.2731" y1="-7.7152" x2="0.5779" y2="-7.7025" layer="94"/>
<rectangle x1="1.0224" y1="-7.7152" x2="1.3145" y2="-7.7025" layer="94"/>
<rectangle x1="2.8258" y1="-7.7152" x2="3.1179" y2="-7.7025" layer="94"/>
<rectangle x1="3.8926" y1="-7.7152" x2="4.1974" y2="-7.7025" layer="94"/>
<rectangle x1="4.4768" y1="-7.7152" x2="4.7562" y2="-7.7025" layer="94"/>
<rectangle x1="5.1626" y1="-7.7152" x2="5.4674" y2="-7.7025" layer="94"/>
<rectangle x1="5.8992" y1="-7.7152" x2="6.1659" y2="-7.7025" layer="94"/>
<rectangle x1="6.4453" y1="-7.7152" x2="6.7755" y2="-7.7025" layer="94"/>
<rectangle x1="7.5375" y1="-7.7152" x2="7.8042" y2="-7.7025" layer="94"/>
<rectangle x1="8.2741" y1="-7.7152" x2="8.5408" y2="-7.7025" layer="94"/>
<rectangle x1="10.0775" y1="-7.7152" x2="10.3823" y2="-7.7025" layer="94"/>
<rectangle x1="11.1697" y1="-7.7152" x2="11.4491" y2="-7.7025" layer="94"/>
<rectangle x1="-11.449" y1="-7.7025" x2="-11.0426" y2="-7.6898" layer="94"/>
<rectangle x1="-10.4076" y1="-7.7025" x2="-10.0012" y2="-7.6898" layer="94"/>
<rectangle x1="-9.544" y1="-7.7025" x2="-9.1503" y2="-7.6898" layer="94"/>
<rectangle x1="-8.4899" y1="-7.7025" x2="-8.0835" y2="-7.6898" layer="94"/>
<rectangle x1="-7.6263" y1="-7.7025" x2="-7.2199" y2="-7.6898" layer="94"/>
<rectangle x1="-6.5849" y1="-7.7025" x2="-6.1912" y2="-7.6898" layer="94"/>
<rectangle x1="-5.734" y1="-7.7025" x2="-5.3403" y2="-7.6898" layer="94"/>
<rectangle x1="-4.6545" y1="-7.7025" x2="-4.2481" y2="-7.6898" layer="94"/>
<rectangle x1="-2.5971" y1="-7.7025" x2="-2.3177" y2="-7.6898" layer="94"/>
<rectangle x1="-1.5176" y1="-7.7025" x2="-1.2509" y2="-7.6898" layer="94"/>
<rectangle x1="-0.781" y1="-7.7025" x2="-0.4635" y2="-7.6898" layer="94"/>
<rectangle x1="0.2731" y1="-7.7025" x2="0.5779" y2="-7.6898" layer="94"/>
<rectangle x1="1.0224" y1="-7.7025" x2="1.3145" y2="-7.6898" layer="94"/>
<rectangle x1="2.8258" y1="-7.7025" x2="3.1179" y2="-7.6898" layer="94"/>
<rectangle x1="3.9053" y1="-7.7025" x2="4.1974" y2="-7.6898" layer="94"/>
<rectangle x1="4.4768" y1="-7.7025" x2="4.7562" y2="-7.6898" layer="94"/>
<rectangle x1="5.1753" y1="-7.7025" x2="5.4674" y2="-7.6898" layer="94"/>
<rectangle x1="5.8992" y1="-7.7025" x2="6.1659" y2="-7.6898" layer="94"/>
<rectangle x1="6.4453" y1="-7.7025" x2="6.7755" y2="-7.6898" layer="94"/>
<rectangle x1="7.5375" y1="-7.7025" x2="7.8042" y2="-7.6898" layer="94"/>
<rectangle x1="8.2741" y1="-7.7025" x2="8.5408" y2="-7.6898" layer="94"/>
<rectangle x1="10.0775" y1="-7.7025" x2="10.3823" y2="-7.6898" layer="94"/>
<rectangle x1="11.1697" y1="-7.7025" x2="11.4491" y2="-7.6898" layer="94"/>
<rectangle x1="-11.449" y1="-7.6898" x2="-11.0426" y2="-7.6771" layer="94"/>
<rectangle x1="-10.4076" y1="-7.6898" x2="-10.0012" y2="-7.6771" layer="94"/>
<rectangle x1="-9.544" y1="-7.6898" x2="-9.1503" y2="-7.6771" layer="94"/>
<rectangle x1="-8.4772" y1="-7.6898" x2="-8.0835" y2="-7.6771" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6898" x2="-7.2199" y2="-7.6771" layer="94"/>
<rectangle x1="-6.5849" y1="-7.6898" x2="-6.1912" y2="-7.6771" layer="94"/>
<rectangle x1="-5.734" y1="-7.6898" x2="-5.3403" y2="-7.6771" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6898" x2="-4.2481" y2="-7.6771" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6898" x2="-2.3177" y2="-7.6771" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6898" x2="-1.2509" y2="-7.6771" layer="94"/>
<rectangle x1="-0.781" y1="-7.6898" x2="-0.4508" y2="-7.6771" layer="94"/>
<rectangle x1="0.2731" y1="-7.6898" x2="0.5779" y2="-7.6771" layer="94"/>
<rectangle x1="1.0224" y1="-7.6898" x2="1.3145" y2="-7.6771" layer="94"/>
<rectangle x1="2.8258" y1="-7.6898" x2="3.1179" y2="-7.6771" layer="94"/>
<rectangle x1="3.9053" y1="-7.6898" x2="4.1974" y2="-7.6771" layer="94"/>
<rectangle x1="4.4768" y1="-7.6898" x2="4.7562" y2="-7.6771" layer="94"/>
<rectangle x1="5.1753" y1="-7.6898" x2="5.4674" y2="-7.6771" layer="94"/>
<rectangle x1="5.8992" y1="-7.6898" x2="6.1659" y2="-7.6771" layer="94"/>
<rectangle x1="6.458" y1="-7.6898" x2="6.7882" y2="-7.6771" layer="94"/>
<rectangle x1="7.5375" y1="-7.6898" x2="7.8042" y2="-7.6771" layer="94"/>
<rectangle x1="8.2741" y1="-7.6898" x2="8.5408" y2="-7.6771" layer="94"/>
<rectangle x1="10.0775" y1="-7.6898" x2="10.395" y2="-7.6771" layer="94"/>
<rectangle x1="11.1697" y1="-7.6898" x2="11.4491" y2="-7.6771" layer="94"/>
<rectangle x1="-11.449" y1="-7.6771" x2="-11.0553" y2="-7.6644" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6771" x2="-10.0012" y2="-7.6644" layer="94"/>
<rectangle x1="-9.544" y1="-7.6771" x2="-9.1503" y2="-7.6644" layer="94"/>
<rectangle x1="-8.4772" y1="-7.6771" x2="-8.0835" y2="-7.6644" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6771" x2="-7.2326" y2="-7.6644" layer="94"/>
<rectangle x1="-6.5722" y1="-7.6771" x2="-6.1912" y2="-7.6644" layer="94"/>
<rectangle x1="-5.734" y1="-7.6771" x2="-5.3403" y2="-7.6644" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6771" x2="-4.2481" y2="-7.6644" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6771" x2="-2.3177" y2="-7.6644" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6771" x2="-1.2509" y2="-7.6644" layer="94"/>
<rectangle x1="-0.781" y1="-7.6771" x2="-0.4381" y2="-7.6644" layer="94"/>
<rectangle x1="0.2731" y1="-7.6771" x2="0.5779" y2="-7.6644" layer="94"/>
<rectangle x1="1.0224" y1="-7.6771" x2="1.3145" y2="-7.6644" layer="94"/>
<rectangle x1="2.8258" y1="-7.6771" x2="3.1179" y2="-7.6644" layer="94"/>
<rectangle x1="3.9053" y1="-7.6771" x2="4.1974" y2="-7.6644" layer="94"/>
<rectangle x1="4.4768" y1="-7.6771" x2="4.7562" y2="-7.6644" layer="94"/>
<rectangle x1="5.1626" y1="-7.6771" x2="5.4674" y2="-7.6644" layer="94"/>
<rectangle x1="5.8992" y1="-7.6771" x2="6.1659" y2="-7.6644" layer="94"/>
<rectangle x1="6.458" y1="-7.6771" x2="6.8136" y2="-7.6644" layer="94"/>
<rectangle x1="7.5375" y1="-7.6771" x2="7.8042" y2="-7.6644" layer="94"/>
<rectangle x1="8.2741" y1="-7.6771" x2="8.5408" y2="-7.6644" layer="94"/>
<rectangle x1="10.0775" y1="-7.6771" x2="10.395" y2="-7.6644" layer="94"/>
<rectangle x1="11.1697" y1="-7.6771" x2="11.4491" y2="-7.6644" layer="94"/>
<rectangle x1="-11.449" y1="-7.6644" x2="-11.068" y2="-7.6517" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6644" x2="-10.0012" y2="-7.6517" layer="94"/>
<rectangle x1="-9.544" y1="-7.6644" x2="-9.1503" y2="-7.6517" layer="94"/>
<rectangle x1="-8.4772" y1="-7.6644" x2="-8.0835" y2="-7.6517" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6644" x2="-7.2326" y2="-7.6517" layer="94"/>
<rectangle x1="-6.5722" y1="-7.6644" x2="-6.1912" y2="-7.6517" layer="94"/>
<rectangle x1="-5.734" y1="-7.6644" x2="-5.3403" y2="-7.6517" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6644" x2="-4.2481" y2="-7.6517" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6644" x2="-2.3177" y2="-7.6517" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6644" x2="-1.2509" y2="-7.6517" layer="94"/>
<rectangle x1="-0.781" y1="-7.6644" x2="-0.4254" y2="-7.6517" layer="94"/>
<rectangle x1="0.2731" y1="-7.6644" x2="0.5779" y2="-7.6517" layer="94"/>
<rectangle x1="1.0224" y1="-7.6644" x2="1.3145" y2="-7.6517" layer="94"/>
<rectangle x1="2.8131" y1="-7.6644" x2="3.1179" y2="-7.6517" layer="94"/>
<rectangle x1="3.9053" y1="-7.6644" x2="4.1974" y2="-7.6517" layer="94"/>
<rectangle x1="4.4768" y1="-7.6644" x2="4.7562" y2="-7.6517" layer="94"/>
<rectangle x1="5.1753" y1="-7.6644" x2="5.4674" y2="-7.6517" layer="94"/>
<rectangle x1="5.8992" y1="-7.6644" x2="6.1659" y2="-7.6517" layer="94"/>
<rectangle x1="6.458" y1="-7.6644" x2="6.8263" y2="-7.6517" layer="94"/>
<rectangle x1="7.5375" y1="-7.6644" x2="7.8042" y2="-7.6517" layer="94"/>
<rectangle x1="8.2741" y1="-7.6644" x2="8.5408" y2="-7.6517" layer="94"/>
<rectangle x1="10.0775" y1="-7.6644" x2="10.4077" y2="-7.6517" layer="94"/>
<rectangle x1="11.1697" y1="-7.6644" x2="11.4491" y2="-7.6517" layer="94"/>
<rectangle x1="-11.449" y1="-7.6517" x2="-11.068" y2="-7.639" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6517" x2="-10.0012" y2="-7.639" layer="94"/>
<rectangle x1="-9.544" y1="-7.6517" x2="-9.163" y2="-7.639" layer="94"/>
<rectangle x1="-8.4772" y1="-7.6517" x2="-8.0835" y2="-7.639" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6517" x2="-7.2326" y2="-7.639" layer="94"/>
<rectangle x1="-6.5595" y1="-7.6517" x2="-6.1912" y2="-7.639" layer="94"/>
<rectangle x1="-5.734" y1="-7.6517" x2="-5.3403" y2="-7.639" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6517" x2="-4.2481" y2="-7.639" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6517" x2="-2.3177" y2="-7.639" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6517" x2="-1.2509" y2="-7.639" layer="94"/>
<rectangle x1="-0.7683" y1="-7.6517" x2="-0.4127" y2="-7.639" layer="94"/>
<rectangle x1="0.2731" y1="-7.6517" x2="0.5779" y2="-7.639" layer="94"/>
<rectangle x1="1.0224" y1="-7.6517" x2="1.3145" y2="-7.639" layer="94"/>
<rectangle x1="2.8131" y1="-7.6517" x2="3.1179" y2="-7.639" layer="94"/>
<rectangle x1="3.9053" y1="-7.6517" x2="4.1974" y2="-7.639" layer="94"/>
<rectangle x1="4.4768" y1="-7.6517" x2="4.7562" y2="-7.639" layer="94"/>
<rectangle x1="5.1753" y1="-7.6517" x2="5.4674" y2="-7.639" layer="94"/>
<rectangle x1="5.8992" y1="-7.6517" x2="6.1659" y2="-7.639" layer="94"/>
<rectangle x1="6.4707" y1="-7.6517" x2="6.839" y2="-7.639" layer="94"/>
<rectangle x1="7.5375" y1="-7.6517" x2="7.8042" y2="-7.639" layer="94"/>
<rectangle x1="8.2741" y1="-7.6517" x2="8.5408" y2="-7.639" layer="94"/>
<rectangle x1="10.0775" y1="-7.6517" x2="10.4204" y2="-7.639" layer="94"/>
<rectangle x1="11.1824" y1="-7.6517" x2="11.4491" y2="-7.639" layer="94"/>
<rectangle x1="-11.4617" y1="-7.639" x2="-11.0807" y2="-7.6263" layer="94"/>
<rectangle x1="-10.3949" y1="-7.639" x2="-10.0012" y2="-7.6263" layer="94"/>
<rectangle x1="-9.544" y1="-7.639" x2="-9.163" y2="-7.6263" layer="94"/>
<rectangle x1="-8.4772" y1="-7.639" x2="-8.0835" y2="-7.6263" layer="94"/>
<rectangle x1="-7.6263" y1="-7.639" x2="-7.2326" y2="-7.6263" layer="94"/>
<rectangle x1="-6.5595" y1="-7.639" x2="-6.1912" y2="-7.6263" layer="94"/>
<rectangle x1="-5.734" y1="-7.639" x2="-5.3403" y2="-7.6263" layer="94"/>
<rectangle x1="-4.6545" y1="-7.639" x2="-4.2481" y2="-7.6263" layer="94"/>
<rectangle x1="-2.5971" y1="-7.639" x2="-2.3177" y2="-7.6263" layer="94"/>
<rectangle x1="-1.5176" y1="-7.639" x2="-1.2509" y2="-7.6263" layer="94"/>
<rectangle x1="-0.7683" y1="-7.639" x2="-0.4127" y2="-7.6263" layer="94"/>
<rectangle x1="0.2731" y1="-7.639" x2="0.5779" y2="-7.6263" layer="94"/>
<rectangle x1="1.0224" y1="-7.639" x2="1.3145" y2="-7.6263" layer="94"/>
<rectangle x1="2.8131" y1="-7.639" x2="3.1179" y2="-7.6263" layer="94"/>
<rectangle x1="3.8926" y1="-7.639" x2="4.1974" y2="-7.6263" layer="94"/>
<rectangle x1="4.4768" y1="-7.639" x2="4.7562" y2="-7.6263" layer="94"/>
<rectangle x1="5.1753" y1="-7.639" x2="5.4674" y2="-7.6263" layer="94"/>
<rectangle x1="5.8992" y1="-7.639" x2="6.1659" y2="-7.6263" layer="94"/>
<rectangle x1="6.4707" y1="-7.639" x2="6.8517" y2="-7.6263" layer="94"/>
<rectangle x1="7.5375" y1="-7.639" x2="7.8042" y2="-7.6263" layer="94"/>
<rectangle x1="8.2741" y1="-7.639" x2="8.5408" y2="-7.6263" layer="94"/>
<rectangle x1="10.0775" y1="-7.639" x2="10.4204" y2="-7.6263" layer="94"/>
<rectangle x1="11.1824" y1="-7.639" x2="11.4491" y2="-7.6263" layer="94"/>
<rectangle x1="-11.4617" y1="-7.6263" x2="-11.0807" y2="-7.6136" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6263" x2="-10.0012" y2="-7.6136" layer="94"/>
<rectangle x1="-9.544" y1="-7.6263" x2="-9.163" y2="-7.6136" layer="94"/>
<rectangle x1="-8.4645" y1="-7.6263" x2="-8.0835" y2="-7.6136" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6263" x2="-7.2199" y2="-7.6136" layer="94"/>
<rectangle x1="-6.5468" y1="-7.6263" x2="-6.1912" y2="-7.6136" layer="94"/>
<rectangle x1="-5.734" y1="-7.6263" x2="-5.3403" y2="-7.6136" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6263" x2="-4.2481" y2="-7.6136" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6263" x2="-2.3177" y2="-7.6136" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6263" x2="-1.2509" y2="-7.6136" layer="94"/>
<rectangle x1="-0.7683" y1="-7.6263" x2="-0.4" y2="-7.6136" layer="94"/>
<rectangle x1="0.2731" y1="-7.6263" x2="0.5779" y2="-7.6136" layer="94"/>
<rectangle x1="1.0224" y1="-7.6263" x2="1.3145" y2="-7.6136" layer="94"/>
<rectangle x1="2.8131" y1="-7.6263" x2="3.1179" y2="-7.6136" layer="94"/>
<rectangle x1="3.9053" y1="-7.6263" x2="4.1974" y2="-7.6136" layer="94"/>
<rectangle x1="4.4768" y1="-7.6263" x2="4.7562" y2="-7.6136" layer="94"/>
<rectangle x1="5.1626" y1="-7.6263" x2="5.4674" y2="-7.6136" layer="94"/>
<rectangle x1="5.8992" y1="-7.6263" x2="6.1659" y2="-7.6136" layer="94"/>
<rectangle x1="6.4834" y1="-7.6263" x2="6.8517" y2="-7.6136" layer="94"/>
<rectangle x1="7.5375" y1="-7.6263" x2="7.8042" y2="-7.6136" layer="94"/>
<rectangle x1="8.2741" y1="-7.6263" x2="8.5408" y2="-7.6136" layer="94"/>
<rectangle x1="10.0775" y1="-7.6263" x2="10.4458" y2="-7.6136" layer="94"/>
<rectangle x1="11.1951" y1="-7.6263" x2="11.4491" y2="-7.6136" layer="94"/>
<rectangle x1="-11.4617" y1="-7.6136" x2="-11.0807" y2="-7.6009" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6136" x2="-10.0012" y2="-7.6009" layer="94"/>
<rectangle x1="-9.544" y1="-7.6136" x2="-9.163" y2="-7.6009" layer="94"/>
<rectangle x1="-8.4645" y1="-7.6136" x2="-8.0835" y2="-7.6009" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6136" x2="-7.2199" y2="-7.6009" layer="94"/>
<rectangle x1="-6.5468" y1="-7.6136" x2="-6.1912" y2="-7.6009" layer="94"/>
<rectangle x1="-5.734" y1="-7.6136" x2="-5.3403" y2="-7.6009" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6136" x2="-4.2481" y2="-7.6009" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6136" x2="-2.3177" y2="-7.6009" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6136" x2="-1.2509" y2="-7.6009" layer="94"/>
<rectangle x1="-0.7683" y1="-7.6136" x2="-0.3746" y2="-7.6009" layer="94"/>
<rectangle x1="0.2731" y1="-7.6136" x2="0.5779" y2="-7.6009" layer="94"/>
<rectangle x1="1.0224" y1="-7.6136" x2="1.3145" y2="-7.6009" layer="94"/>
<rectangle x1="2.8131" y1="-7.6136" x2="3.1179" y2="-7.6009" layer="94"/>
<rectangle x1="3.9053" y1="-7.6136" x2="4.1974" y2="-7.6009" layer="94"/>
<rectangle x1="4.4768" y1="-7.6136" x2="4.7562" y2="-7.6009" layer="94"/>
<rectangle x1="5.1753" y1="-7.6136" x2="5.4674" y2="-7.6009" layer="94"/>
<rectangle x1="5.8992" y1="-7.6136" x2="6.1659" y2="-7.6009" layer="94"/>
<rectangle x1="6.4961" y1="-7.6136" x2="6.8644" y2="-7.6009" layer="94"/>
<rectangle x1="7.5375" y1="-7.6136" x2="7.8042" y2="-7.6009" layer="94"/>
<rectangle x1="8.2741" y1="-7.6136" x2="8.5408" y2="-7.6009" layer="94"/>
<rectangle x1="10.0775" y1="-7.6136" x2="10.4585" y2="-7.6009" layer="94"/>
<rectangle x1="11.2205" y1="-7.6136" x2="11.4491" y2="-7.6009" layer="94"/>
<rectangle x1="-11.4617" y1="-7.6009" x2="-11.0807" y2="-7.5882" layer="94"/>
<rectangle x1="-10.3949" y1="-7.6009" x2="-10.0012" y2="-7.5882" layer="94"/>
<rectangle x1="-9.544" y1="-7.6009" x2="-9.163" y2="-7.5882" layer="94"/>
<rectangle x1="-8.4645" y1="-7.6009" x2="-8.0835" y2="-7.5882" layer="94"/>
<rectangle x1="-7.6263" y1="-7.6009" x2="-7.2072" y2="-7.5882" layer="94"/>
<rectangle x1="-6.5468" y1="-7.6009" x2="-6.1912" y2="-7.5882" layer="94"/>
<rectangle x1="-5.734" y1="-7.6009" x2="-5.3403" y2="-7.5882" layer="94"/>
<rectangle x1="-4.6545" y1="-7.6009" x2="-4.2481" y2="-7.5882" layer="94"/>
<rectangle x1="-2.5971" y1="-7.6009" x2="-2.3177" y2="-7.5882" layer="94"/>
<rectangle x1="-1.5176" y1="-7.6009" x2="-1.2509" y2="-7.5882" layer="94"/>
<rectangle x1="-0.7556" y1="-7.6009" x2="-0.3492" y2="-7.5882" layer="94"/>
<rectangle x1="0.2731" y1="-7.6009" x2="0.5779" y2="-7.5882" layer="94"/>
<rectangle x1="1.0224" y1="-7.6009" x2="1.3145" y2="-7.5882" layer="94"/>
<rectangle x1="2.8131" y1="-7.6009" x2="3.1179" y2="-7.5882" layer="94"/>
<rectangle x1="3.8926" y1="-7.6009" x2="4.1974" y2="-7.5882" layer="94"/>
<rectangle x1="4.4768" y1="-7.6009" x2="4.7562" y2="-7.5882" layer="94"/>
<rectangle x1="5.1626" y1="-7.6009" x2="5.4674" y2="-7.5882" layer="94"/>
<rectangle x1="5.8992" y1="-7.6009" x2="6.1659" y2="-7.5882" layer="94"/>
<rectangle x1="6.4961" y1="-7.6009" x2="6.8898" y2="-7.5882" layer="94"/>
<rectangle x1="7.5375" y1="-7.6009" x2="7.8042" y2="-7.5882" layer="94"/>
<rectangle x1="8.2741" y1="-7.6009" x2="8.5408" y2="-7.5882" layer="94"/>
<rectangle x1="10.0775" y1="-7.6009" x2="10.4839" y2="-7.5882" layer="94"/>
<rectangle x1="11.2713" y1="-7.6009" x2="11.4491" y2="-7.5882" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5882" x2="-11.0807" y2="-7.5755" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5882" x2="-10.0012" y2="-7.5755" layer="94"/>
<rectangle x1="-9.544" y1="-7.5882" x2="-9.163" y2="-7.5755" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5882" x2="-8.0835" y2="-7.5755" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5882" x2="-7.1818" y2="-7.5755" layer="94"/>
<rectangle x1="-6.5468" y1="-7.5882" x2="-6.1912" y2="-7.5755" layer="94"/>
<rectangle x1="-5.734" y1="-7.5882" x2="-5.3403" y2="-7.5755" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5882" x2="-4.2481" y2="-7.5755" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5882" x2="-2.3177" y2="-7.5755" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5882" x2="-1.2509" y2="-7.5755" layer="94"/>
<rectangle x1="-0.7556" y1="-7.5882" x2="-0.3111" y2="-7.5755" layer="94"/>
<rectangle x1="0.2731" y1="-7.5882" x2="0.5779" y2="-7.5755" layer="94"/>
<rectangle x1="1.0224" y1="-7.5882" x2="1.3145" y2="-7.5755" layer="94"/>
<rectangle x1="2.8131" y1="-7.5882" x2="3.1179" y2="-7.5755" layer="94"/>
<rectangle x1="3.9053" y1="-7.5882" x2="4.1974" y2="-7.5755" layer="94"/>
<rectangle x1="4.4768" y1="-7.5882" x2="4.7562" y2="-7.5755" layer="94"/>
<rectangle x1="5.1626" y1="-7.5882" x2="5.4674" y2="-7.5755" layer="94"/>
<rectangle x1="5.8992" y1="-7.5882" x2="6.1659" y2="-7.5755" layer="94"/>
<rectangle x1="6.4961" y1="-7.5882" x2="6.9279" y2="-7.5755" layer="94"/>
<rectangle x1="7.5375" y1="-7.5882" x2="7.8042" y2="-7.5755" layer="94"/>
<rectangle x1="8.2741" y1="-7.5882" x2="8.5408" y2="-7.5755" layer="94"/>
<rectangle x1="10.0775" y1="-7.5882" x2="10.522" y2="-7.5755" layer="94"/>
<rectangle x1="11.2967" y1="-7.5882" x2="11.4491" y2="-7.5755" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5755" x2="-11.0807" y2="-7.5628" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5755" x2="-10.0012" y2="-7.5628" layer="94"/>
<rectangle x1="-9.544" y1="-7.5755" x2="-9.163" y2="-7.5628" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5755" x2="-8.0835" y2="-7.5628" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5755" x2="-7.1564" y2="-7.5628" layer="94"/>
<rectangle x1="-6.5468" y1="-7.5755" x2="-6.1912" y2="-7.5628" layer="94"/>
<rectangle x1="-5.734" y1="-7.5755" x2="-5.3403" y2="-7.5628" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5755" x2="-4.2481" y2="-7.5628" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5755" x2="-2.3177" y2="-7.5628" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5755" x2="-1.2509" y2="-7.5628" layer="94"/>
<rectangle x1="-0.7556" y1="-7.5755" x2="-0.273" y2="-7.5628" layer="94"/>
<rectangle x1="0.2731" y1="-7.5755" x2="0.5779" y2="-7.5628" layer="94"/>
<rectangle x1="1.0224" y1="-7.5755" x2="1.3145" y2="-7.5628" layer="94"/>
<rectangle x1="2.8131" y1="-7.5755" x2="3.1179" y2="-7.5628" layer="94"/>
<rectangle x1="3.8926" y1="-7.5755" x2="4.1974" y2="-7.5628" layer="94"/>
<rectangle x1="4.4768" y1="-7.5755" x2="4.7562" y2="-7.5628" layer="94"/>
<rectangle x1="5.1753" y1="-7.5755" x2="5.4674" y2="-7.5628" layer="94"/>
<rectangle x1="5.8992" y1="-7.5755" x2="6.1659" y2="-7.5628" layer="94"/>
<rectangle x1="6.5088" y1="-7.5755" x2="6.9787" y2="-7.5628" layer="94"/>
<rectangle x1="7.5375" y1="-7.5755" x2="7.8042" y2="-7.5628" layer="94"/>
<rectangle x1="8.2741" y1="-7.5755" x2="8.5408" y2="-7.5628" layer="94"/>
<rectangle x1="10.0775" y1="-7.5755" x2="10.5728" y2="-7.5628" layer="94"/>
<rectangle x1="11.3221" y1="-7.5755" x2="11.4364" y2="-7.5628" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5628" x2="-11.0807" y2="-7.5501" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5628" x2="-10.0012" y2="-7.5501" layer="94"/>
<rectangle x1="-9.544" y1="-7.5628" x2="-9.163" y2="-7.5501" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5628" x2="-8.0835" y2="-7.5501" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5628" x2="-7.131" y2="-7.5501" layer="94"/>
<rectangle x1="-6.5468" y1="-7.5628" x2="-6.1912" y2="-7.5501" layer="94"/>
<rectangle x1="-5.734" y1="-7.5628" x2="-5.3403" y2="-7.5501" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5628" x2="-4.2481" y2="-7.5501" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5628" x2="-2.3177" y2="-7.5501" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5628" x2="-1.2509" y2="-7.5501" layer="94"/>
<rectangle x1="-0.7556" y1="-7.5628" x2="-0.2476" y2="-7.5501" layer="94"/>
<rectangle x1="0.2731" y1="-7.5628" x2="0.5779" y2="-7.5501" layer="94"/>
<rectangle x1="1.0224" y1="-7.5628" x2="1.3145" y2="-7.5501" layer="94"/>
<rectangle x1="2.8131" y1="-7.5628" x2="3.1179" y2="-7.5501" layer="94"/>
<rectangle x1="3.9053" y1="-7.5628" x2="4.1974" y2="-7.5501" layer="94"/>
<rectangle x1="4.4768" y1="-7.5628" x2="4.7562" y2="-7.5501" layer="94"/>
<rectangle x1="5.1626" y1="-7.5628" x2="5.4674" y2="-7.5501" layer="94"/>
<rectangle x1="5.8992" y1="-7.5628" x2="6.1659" y2="-7.5501" layer="94"/>
<rectangle x1="6.5088" y1="-7.5628" x2="7.0041" y2="-7.5501" layer="94"/>
<rectangle x1="7.5375" y1="-7.5628" x2="7.8042" y2="-7.5501" layer="94"/>
<rectangle x1="8.2741" y1="-7.5628" x2="8.5408" y2="-7.5501" layer="94"/>
<rectangle x1="10.0775" y1="-7.5628" x2="10.5982" y2="-7.5501" layer="94"/>
<rectangle x1="11.3348" y1="-7.5628" x2="11.4364" y2="-7.5501" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5501" x2="-11.0807" y2="-7.5374" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5501" x2="-10.0012" y2="-7.5374" layer="94"/>
<rectangle x1="-9.544" y1="-7.5501" x2="-9.163" y2="-7.5374" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5501" x2="-8.0835" y2="-7.5374" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5501" x2="-7.1183" y2="-7.5374" layer="94"/>
<rectangle x1="-6.5341" y1="-7.5501" x2="-6.1912" y2="-7.5374" layer="94"/>
<rectangle x1="-5.734" y1="-7.5501" x2="-5.3403" y2="-7.5374" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5501" x2="-4.2481" y2="-7.5374" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5501" x2="-2.3177" y2="-7.5374" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5501" x2="-1.2509" y2="-7.5374" layer="94"/>
<rectangle x1="-0.7429" y1="-7.5501" x2="-0.2349" y2="-7.5374" layer="94"/>
<rectangle x1="0.2731" y1="-7.5501" x2="0.5779" y2="-7.5374" layer="94"/>
<rectangle x1="1.0224" y1="-7.5501" x2="1.3145" y2="-7.5374" layer="94"/>
<rectangle x1="2.8131" y1="-7.5501" x2="3.1179" y2="-7.5374" layer="94"/>
<rectangle x1="3.8926" y1="-7.5501" x2="4.1974" y2="-7.5374" layer="94"/>
<rectangle x1="4.4768" y1="-7.5501" x2="4.7562" y2="-7.5374" layer="94"/>
<rectangle x1="5.1753" y1="-7.5501" x2="5.4674" y2="-7.5374" layer="94"/>
<rectangle x1="5.8992" y1="-7.5501" x2="6.1659" y2="-7.5374" layer="94"/>
<rectangle x1="6.5215" y1="-7.5501" x2="7.0168" y2="-7.5374" layer="94"/>
<rectangle x1="7.5375" y1="-7.5501" x2="7.8042" y2="-7.5374" layer="94"/>
<rectangle x1="8.2741" y1="-7.5501" x2="8.5408" y2="-7.5374" layer="94"/>
<rectangle x1="10.0775" y1="-7.5501" x2="10.6236" y2="-7.5374" layer="94"/>
<rectangle x1="11.3602" y1="-7.5501" x2="11.4237" y2="-7.5374" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5374" x2="-11.0807" y2="-7.5247" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5374" x2="-10.0012" y2="-7.5247" layer="94"/>
<rectangle x1="-9.544" y1="-7.5374" x2="-9.163" y2="-7.5247" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5374" x2="-8.0835" y2="-7.5247" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5374" x2="-7.0929" y2="-7.5247" layer="94"/>
<rectangle x1="-6.5341" y1="-7.5374" x2="-6.1912" y2="-7.5247" layer="94"/>
<rectangle x1="-5.734" y1="-7.5374" x2="-5.3403" y2="-7.5247" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5374" x2="-4.2481" y2="-7.5247" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5374" x2="-2.3177" y2="-7.5247" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5374" x2="-1.2509" y2="-7.5247" layer="94"/>
<rectangle x1="-0.7302" y1="-7.5374" x2="-0.2095" y2="-7.5247" layer="94"/>
<rectangle x1="0.2731" y1="-7.5374" x2="0.5779" y2="-7.5247" layer="94"/>
<rectangle x1="1.0224" y1="-7.5374" x2="1.3145" y2="-7.5247" layer="94"/>
<rectangle x1="2.8131" y1="-7.5374" x2="3.1179" y2="-7.5247" layer="94"/>
<rectangle x1="3.8926" y1="-7.5374" x2="4.1974" y2="-7.5247" layer="94"/>
<rectangle x1="4.4768" y1="-7.5374" x2="4.7562" y2="-7.5247" layer="94"/>
<rectangle x1="5.1753" y1="-7.5374" x2="5.4674" y2="-7.5247" layer="94"/>
<rectangle x1="5.8992" y1="-7.5374" x2="6.1659" y2="-7.5247" layer="94"/>
<rectangle x1="6.5215" y1="-7.5374" x2="7.0295" y2="-7.5247" layer="94"/>
<rectangle x1="7.5375" y1="-7.5374" x2="7.8042" y2="-7.5247" layer="94"/>
<rectangle x1="8.2741" y1="-7.5374" x2="8.5408" y2="-7.5247" layer="94"/>
<rectangle x1="10.0775" y1="-7.5374" x2="10.6363" y2="-7.5247" layer="94"/>
<rectangle x1="-11.4617" y1="-7.5247" x2="-11.0807" y2="-7.512" layer="94"/>
<rectangle x1="-10.3949" y1="-7.5247" x2="-10.0012" y2="-7.512" layer="94"/>
<rectangle x1="-9.544" y1="-7.5247" x2="-9.163" y2="-7.512" layer="94"/>
<rectangle x1="-8.4645" y1="-7.5247" x2="-8.0835" y2="-7.512" layer="94"/>
<rectangle x1="-7.6263" y1="-7.5247" x2="-7.0802" y2="-7.512" layer="94"/>
<rectangle x1="-6.5087" y1="-7.5247" x2="-6.1912" y2="-7.512" layer="94"/>
<rectangle x1="-5.734" y1="-7.5247" x2="-5.3403" y2="-7.512" layer="94"/>
<rectangle x1="-4.6545" y1="-7.5247" x2="-4.2481" y2="-7.512" layer="94"/>
<rectangle x1="-2.5971" y1="-7.5247" x2="-2.3177" y2="-7.512" layer="94"/>
<rectangle x1="-1.5176" y1="-7.5247" x2="-1.2509" y2="-7.512" layer="94"/>
<rectangle x1="-0.7175" y1="-7.5247" x2="-0.1841" y2="-7.512" layer="94"/>
<rectangle x1="0.2731" y1="-7.5247" x2="0.5779" y2="-7.512" layer="94"/>
<rectangle x1="1.0224" y1="-7.5247" x2="1.3145" y2="-7.512" layer="94"/>
<rectangle x1="2.8131" y1="-7.5247" x2="3.1179" y2="-7.512" layer="94"/>
<rectangle x1="3.9053" y1="-7.5247" x2="4.1974" y2="-7.512" layer="94"/>
<rectangle x1="4.4768" y1="-7.5247" x2="4.7562" y2="-7.512" layer="94"/>
<rectangle x1="5.1626" y1="-7.5247" x2="5.4674" y2="-7.512" layer="94"/>
<rectangle x1="5.8992" y1="-7.5247" x2="6.1659" y2="-7.512" layer="94"/>
<rectangle x1="6.5342" y1="-7.5247" x2="7.0549" y2="-7.512" layer="94"/>
<rectangle x1="7.5375" y1="-7.5247" x2="7.8042" y2="-7.512" layer="94"/>
<rectangle x1="8.2741" y1="-7.5247" x2="8.5408" y2="-7.512" layer="94"/>
<rectangle x1="10.0775" y1="-7.5247" x2="10.6617" y2="-7.512" layer="94"/>
<rectangle x1="-11.4617" y1="-7.512" x2="-11.0807" y2="-7.4993" layer="94"/>
<rectangle x1="-10.3949" y1="-7.512" x2="-10.0012" y2="-7.4993" layer="94"/>
<rectangle x1="-9.544" y1="-7.512" x2="-9.163" y2="-7.4993" layer="94"/>
<rectangle x1="-8.4645" y1="-7.512" x2="-8.0835" y2="-7.4993" layer="94"/>
<rectangle x1="-7.6263" y1="-7.512" x2="-7.0421" y2="-7.4993" layer="94"/>
<rectangle x1="-6.496" y1="-7.512" x2="-6.1912" y2="-7.4993" layer="94"/>
<rectangle x1="-5.734" y1="-7.512" x2="-5.3403" y2="-7.4993" layer="94"/>
<rectangle x1="-4.6545" y1="-7.512" x2="-4.2481" y2="-7.4993" layer="94"/>
<rectangle x1="-2.5971" y1="-7.512" x2="-2.3177" y2="-7.4993" layer="94"/>
<rectangle x1="-1.5176" y1="-7.512" x2="-1.2509" y2="-7.4993" layer="94"/>
<rectangle x1="-0.7048" y1="-7.512" x2="-0.146" y2="-7.4993" layer="94"/>
<rectangle x1="0.2731" y1="-7.512" x2="0.5779" y2="-7.4993" layer="94"/>
<rectangle x1="1.0224" y1="-7.512" x2="1.3145" y2="-7.4993" layer="94"/>
<rectangle x1="2.8131" y1="-7.512" x2="3.1179" y2="-7.4993" layer="94"/>
<rectangle x1="3.9053" y1="-7.512" x2="4.1974" y2="-7.4993" layer="94"/>
<rectangle x1="4.4768" y1="-7.512" x2="4.7562" y2="-7.4993" layer="94"/>
<rectangle x1="5.1753" y1="-7.512" x2="5.4674" y2="-7.4993" layer="94"/>
<rectangle x1="5.8992" y1="-7.512" x2="6.1659" y2="-7.4993" layer="94"/>
<rectangle x1="6.5342" y1="-7.512" x2="7.093" y2="-7.4993" layer="94"/>
<rectangle x1="7.5375" y1="-7.512" x2="7.8042" y2="-7.4993" layer="94"/>
<rectangle x1="8.2741" y1="-7.512" x2="8.5408" y2="-7.4993" layer="94"/>
<rectangle x1="10.0775" y1="-7.512" x2="10.6871" y2="-7.4993" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4993" x2="-11.0807" y2="-7.4866" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4993" x2="-10.0012" y2="-7.4866" layer="94"/>
<rectangle x1="-9.544" y1="-7.4993" x2="-9.163" y2="-7.4866" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4993" x2="-8.0835" y2="-7.4866" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4993" x2="-6.9913" y2="-7.4866" layer="94"/>
<rectangle x1="-6.4706" y1="-7.4993" x2="-6.1912" y2="-7.4866" layer="94"/>
<rectangle x1="-5.734" y1="-7.4993" x2="-5.3403" y2="-7.4866" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4993" x2="-4.2481" y2="-7.4866" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4993" x2="-2.3177" y2="-7.4866" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4993" x2="-1.2509" y2="-7.4866" layer="94"/>
<rectangle x1="-0.6921" y1="-7.4993" x2="-0.0952" y2="-7.4866" layer="94"/>
<rectangle x1="0.2731" y1="-7.4993" x2="0.5779" y2="-7.4866" layer="94"/>
<rectangle x1="1.0224" y1="-7.4993" x2="1.3145" y2="-7.4866" layer="94"/>
<rectangle x1="2.8131" y1="-7.4993" x2="3.1179" y2="-7.4866" layer="94"/>
<rectangle x1="3.9053" y1="-7.4993" x2="4.1974" y2="-7.4866" layer="94"/>
<rectangle x1="4.4768" y1="-7.4993" x2="4.7562" y2="-7.4866" layer="94"/>
<rectangle x1="5.1753" y1="-7.4993" x2="5.4674" y2="-7.4866" layer="94"/>
<rectangle x1="5.8992" y1="-7.4993" x2="6.1659" y2="-7.4866" layer="94"/>
<rectangle x1="6.5469" y1="-7.4993" x2="7.1565" y2="-7.4866" layer="94"/>
<rectangle x1="7.5375" y1="-7.4993" x2="7.8042" y2="-7.4866" layer="94"/>
<rectangle x1="8.2741" y1="-7.4993" x2="8.5408" y2="-7.4866" layer="94"/>
<rectangle x1="10.0775" y1="-7.4993" x2="10.7379" y2="-7.4866" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4866" x2="-11.0807" y2="-7.4739" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4866" x2="-10.0012" y2="-7.4739" layer="94"/>
<rectangle x1="-9.544" y1="-7.4866" x2="-9.163" y2="-7.4739" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4866" x2="-8.0835" y2="-7.4739" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4866" x2="-6.9532" y2="-7.4739" layer="94"/>
<rectangle x1="-6.4579" y1="-7.4866" x2="-6.1912" y2="-7.4739" layer="94"/>
<rectangle x1="-5.734" y1="-7.4866" x2="-5.3403" y2="-7.4739" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4866" x2="-4.2481" y2="-7.4739" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4866" x2="-2.3177" y2="-7.4739" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4866" x2="-1.2509" y2="-7.4739" layer="94"/>
<rectangle x1="-0.6794" y1="-7.4866" x2="-0.0698" y2="-7.4739" layer="94"/>
<rectangle x1="0.2731" y1="-7.4866" x2="0.5779" y2="-7.4739" layer="94"/>
<rectangle x1="1.0224" y1="-7.4866" x2="1.3145" y2="-7.4739" layer="94"/>
<rectangle x1="2.8131" y1="-7.4866" x2="3.1179" y2="-7.4739" layer="94"/>
<rectangle x1="3.9053" y1="-7.4866" x2="4.1974" y2="-7.4739" layer="94"/>
<rectangle x1="4.4768" y1="-7.4866" x2="4.7562" y2="-7.4739" layer="94"/>
<rectangle x1="5.1753" y1="-7.4866" x2="5.4674" y2="-7.4739" layer="94"/>
<rectangle x1="5.8992" y1="-7.4866" x2="6.1659" y2="-7.4739" layer="94"/>
<rectangle x1="6.5596" y1="-7.4866" x2="7.1946" y2="-7.4739" layer="94"/>
<rectangle x1="7.5375" y1="-7.4866" x2="7.8042" y2="-7.4739" layer="94"/>
<rectangle x1="8.2741" y1="-7.4866" x2="8.5408" y2="-7.4739" layer="94"/>
<rectangle x1="10.0775" y1="-7.4866" x2="10.7633" y2="-7.4739" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4739" x2="-11.0807" y2="-7.4612" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4739" x2="-10.0012" y2="-7.4612" layer="94"/>
<rectangle x1="-9.544" y1="-7.4739" x2="-9.163" y2="-7.4612" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4739" x2="-8.0835" y2="-7.4612" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4739" x2="-6.9405" y2="-7.4612" layer="94"/>
<rectangle x1="-6.4452" y1="-7.4739" x2="-6.1912" y2="-7.4612" layer="94"/>
<rectangle x1="-5.734" y1="-7.4739" x2="-5.3403" y2="-7.4612" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4739" x2="-4.2481" y2="-7.4612" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4739" x2="-2.3177" y2="-7.4612" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4739" x2="-1.2509" y2="-7.4612" layer="94"/>
<rectangle x1="-0.6794" y1="-7.4739" x2="-0.0444" y2="-7.4612" layer="94"/>
<rectangle x1="0.2731" y1="-7.4739" x2="0.5779" y2="-7.4612" layer="94"/>
<rectangle x1="1.0224" y1="-7.4739" x2="1.3145" y2="-7.4612" layer="94"/>
<rectangle x1="2.8131" y1="-7.4739" x2="3.1179" y2="-7.4612" layer="94"/>
<rectangle x1="3.8926" y1="-7.4739" x2="4.1974" y2="-7.4612" layer="94"/>
<rectangle x1="4.4768" y1="-7.4739" x2="4.7562" y2="-7.4612" layer="94"/>
<rectangle x1="5.1626" y1="-7.4739" x2="5.4674" y2="-7.4612" layer="94"/>
<rectangle x1="5.8992" y1="-7.4739" x2="6.1659" y2="-7.4612" layer="94"/>
<rectangle x1="6.5723" y1="-7.4739" x2="7.2073" y2="-7.4612" layer="94"/>
<rectangle x1="7.5375" y1="-7.4739" x2="7.8042" y2="-7.4612" layer="94"/>
<rectangle x1="8.2741" y1="-7.4739" x2="8.5408" y2="-7.4612" layer="94"/>
<rectangle x1="10.0775" y1="-7.4739" x2="10.7887" y2="-7.4612" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4612" x2="-11.0807" y2="-7.4485" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4612" x2="-10.0012" y2="-7.4485" layer="94"/>
<rectangle x1="-9.544" y1="-7.4612" x2="-9.163" y2="-7.4485" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4612" x2="-8.0835" y2="-7.4485" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4612" x2="-6.9278" y2="-7.4485" layer="94"/>
<rectangle x1="-6.4198" y1="-7.4612" x2="-6.1912" y2="-7.4485" layer="94"/>
<rectangle x1="-5.734" y1="-7.4612" x2="-5.3403" y2="-7.4485" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4612" x2="-4.2481" y2="-7.4485" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4612" x2="-2.3177" y2="-7.4485" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4612" x2="-1.2509" y2="-7.4485" layer="94"/>
<rectangle x1="-0.6667" y1="-7.4612" x2="-0.019" y2="-7.4485" layer="94"/>
<rectangle x1="0.2731" y1="-7.4612" x2="0.5779" y2="-7.4485" layer="94"/>
<rectangle x1="1.0224" y1="-7.4612" x2="1.3145" y2="-7.4485" layer="94"/>
<rectangle x1="2.8131" y1="-7.4612" x2="3.1179" y2="-7.4485" layer="94"/>
<rectangle x1="3.9053" y1="-7.4612" x2="4.1974" y2="-7.4485" layer="94"/>
<rectangle x1="4.4768" y1="-7.4612" x2="4.7562" y2="-7.4485" layer="94"/>
<rectangle x1="5.1626" y1="-7.4612" x2="5.4674" y2="-7.4485" layer="94"/>
<rectangle x1="5.8992" y1="-7.4612" x2="6.1659" y2="-7.4485" layer="94"/>
<rectangle x1="6.585" y1="-7.4612" x2="7.2327" y2="-7.4485" layer="94"/>
<rectangle x1="7.5375" y1="-7.4612" x2="7.8042" y2="-7.4485" layer="94"/>
<rectangle x1="8.2741" y1="-7.4612" x2="8.5408" y2="-7.4485" layer="94"/>
<rectangle x1="10.0775" y1="-7.4612" x2="10.8141" y2="-7.4485" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4485" x2="-11.0807" y2="-7.4358" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4485" x2="-10.0012" y2="-7.4358" layer="94"/>
<rectangle x1="-9.544" y1="-7.4485" x2="-9.163" y2="-7.4358" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4485" x2="-8.0835" y2="-7.4358" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4485" x2="-6.9024" y2="-7.4358" layer="94"/>
<rectangle x1="-6.3944" y1="-7.4485" x2="-6.1912" y2="-7.4358" layer="94"/>
<rectangle x1="-5.734" y1="-7.4485" x2="-5.3403" y2="-7.4358" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4485" x2="-4.2481" y2="-7.4358" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4485" x2="-2.3177" y2="-7.4358" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4485" x2="-1.2509" y2="-7.4358" layer="94"/>
<rectangle x1="-0.654" y1="-7.4485" x2="-0.0063" y2="-7.4358" layer="94"/>
<rectangle x1="0.2731" y1="-7.4485" x2="0.5779" y2="-7.4358" layer="94"/>
<rectangle x1="1.0224" y1="-7.4485" x2="1.3145" y2="-7.4358" layer="94"/>
<rectangle x1="2.8131" y1="-7.4485" x2="3.1179" y2="-7.4358" layer="94"/>
<rectangle x1="3.8926" y1="-7.4485" x2="4.1974" y2="-7.4358" layer="94"/>
<rectangle x1="4.4768" y1="-7.4485" x2="4.7562" y2="-7.4358" layer="94"/>
<rectangle x1="5.1753" y1="-7.4485" x2="5.4674" y2="-7.4358" layer="94"/>
<rectangle x1="5.8992" y1="-7.4485" x2="6.1659" y2="-7.4358" layer="94"/>
<rectangle x1="6.5977" y1="-7.4485" x2="7.2454" y2="-7.4358" layer="94"/>
<rectangle x1="7.5375" y1="-7.4485" x2="7.8042" y2="-7.4358" layer="94"/>
<rectangle x1="8.2741" y1="-7.4485" x2="8.5408" y2="-7.4358" layer="94"/>
<rectangle x1="10.0775" y1="-7.4485" x2="10.8268" y2="-7.4358" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4358" x2="-11.0807" y2="-7.4231" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4358" x2="-10.0012" y2="-7.4231" layer="94"/>
<rectangle x1="-9.544" y1="-7.4358" x2="-9.163" y2="-7.4231" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4358" x2="-8.0835" y2="-7.4231" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4358" x2="-6.877" y2="-7.4231" layer="94"/>
<rectangle x1="-6.3563" y1="-7.4358" x2="-6.2039" y2="-7.4231" layer="94"/>
<rectangle x1="-5.734" y1="-7.4358" x2="-5.3403" y2="-7.4231" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4358" x2="-4.2481" y2="-7.4231" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4358" x2="-2.3177" y2="-7.4231" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4358" x2="-1.2509" y2="-7.4231" layer="94"/>
<rectangle x1="-0.6413" y1="-7.4358" x2="0.0318" y2="-7.4231" layer="94"/>
<rectangle x1="0.2731" y1="-7.4358" x2="0.5779" y2="-7.4231" layer="94"/>
<rectangle x1="1.0224" y1="-7.4358" x2="1.3145" y2="-7.4231" layer="94"/>
<rectangle x1="2.8131" y1="-7.4358" x2="3.1179" y2="-7.4231" layer="94"/>
<rectangle x1="3.9053" y1="-7.4358" x2="4.1974" y2="-7.4231" layer="94"/>
<rectangle x1="4.4768" y1="-7.4358" x2="4.7562" y2="-7.4231" layer="94"/>
<rectangle x1="5.1626" y1="-7.4358" x2="5.4674" y2="-7.4231" layer="94"/>
<rectangle x1="5.8992" y1="-7.4358" x2="6.1659" y2="-7.4231" layer="94"/>
<rectangle x1="6.6231" y1="-7.4358" x2="7.2708" y2="-7.4231" layer="94"/>
<rectangle x1="7.5375" y1="-7.4358" x2="7.8042" y2="-7.4231" layer="94"/>
<rectangle x1="8.2741" y1="-7.4358" x2="8.5408" y2="-7.4231" layer="94"/>
<rectangle x1="10.0775" y1="-7.4358" x2="10.8522" y2="-7.4231" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4231" x2="-11.0807" y2="-7.4104" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4231" x2="-10.0012" y2="-7.4104" layer="94"/>
<rectangle x1="-9.544" y1="-7.4231" x2="-9.163" y2="-7.4104" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4231" x2="-8.0835" y2="-7.4104" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4231" x2="-6.8516" y2="-7.4104" layer="94"/>
<rectangle x1="-6.3055" y1="-7.4231" x2="-6.2039" y2="-7.4104" layer="94"/>
<rectangle x1="-5.734" y1="-7.4231" x2="-5.3403" y2="-7.4104" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4231" x2="-4.2481" y2="-7.4104" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4231" x2="-2.3177" y2="-7.4104" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4231" x2="-1.2509" y2="-7.4104" layer="94"/>
<rectangle x1="-0.6159" y1="-7.4231" x2="0.0699" y2="-7.4104" layer="94"/>
<rectangle x1="0.2604" y1="-7.4231" x2="0.5779" y2="-7.4104" layer="94"/>
<rectangle x1="1.0224" y1="-7.4231" x2="1.3145" y2="-7.4104" layer="94"/>
<rectangle x1="2.8131" y1="-7.4231" x2="3.1179" y2="-7.4104" layer="94"/>
<rectangle x1="3.9053" y1="-7.4231" x2="4.1974" y2="-7.4104" layer="94"/>
<rectangle x1="4.4768" y1="-7.4231" x2="4.7562" y2="-7.4104" layer="94"/>
<rectangle x1="5.1626" y1="-7.4231" x2="5.4674" y2="-7.4104" layer="94"/>
<rectangle x1="5.8992" y1="-7.4231" x2="6.1659" y2="-7.4104" layer="94"/>
<rectangle x1="6.6358" y1="-7.4231" x2="7.3216" y2="-7.4104" layer="94"/>
<rectangle x1="7.5375" y1="-7.4231" x2="7.8042" y2="-7.4104" layer="94"/>
<rectangle x1="8.2741" y1="-7.4231" x2="8.5408" y2="-7.4104" layer="94"/>
<rectangle x1="10.0775" y1="-7.4231" x2="10.8903" y2="-7.4104" layer="94"/>
<rectangle x1="-11.4617" y1="-7.4104" x2="-11.0807" y2="-7.3977" layer="94"/>
<rectangle x1="-10.3949" y1="-7.4104" x2="-10.0012" y2="-7.3977" layer="94"/>
<rectangle x1="-9.544" y1="-7.4104" x2="-9.163" y2="-7.3977" layer="94"/>
<rectangle x1="-8.4645" y1="-7.4104" x2="-8.0835" y2="-7.3977" layer="94"/>
<rectangle x1="-7.6263" y1="-7.4104" x2="-6.8008" y2="-7.3977" layer="94"/>
<rectangle x1="-6.2674" y1="-7.4104" x2="-6.2293" y2="-7.3977" layer="94"/>
<rectangle x1="-5.734" y1="-7.4104" x2="-5.3403" y2="-7.3977" layer="94"/>
<rectangle x1="-4.6545" y1="-7.4104" x2="-4.2481" y2="-7.3977" layer="94"/>
<rectangle x1="-2.5971" y1="-7.4104" x2="-2.3177" y2="-7.3977" layer="94"/>
<rectangle x1="-1.5176" y1="-7.4104" x2="-1.2509" y2="-7.3977" layer="94"/>
<rectangle x1="-0.5905" y1="-7.4104" x2="0.1207" y2="-7.3977" layer="94"/>
<rectangle x1="0.2604" y1="-7.4104" x2="0.5779" y2="-7.3977" layer="94"/>
<rectangle x1="1.0224" y1="-7.4104" x2="1.3145" y2="-7.3977" layer="94"/>
<rectangle x1="2.8131" y1="-7.4104" x2="3.1179" y2="-7.3977" layer="94"/>
<rectangle x1="3.9053" y1="-7.4104" x2="4.1974" y2="-7.3977" layer="94"/>
<rectangle x1="4.4768" y1="-7.4104" x2="4.7562" y2="-7.3977" layer="94"/>
<rectangle x1="5.1626" y1="-7.4104" x2="5.4674" y2="-7.3977" layer="94"/>
<rectangle x1="5.8992" y1="-7.4104" x2="6.1659" y2="-7.3977" layer="94"/>
<rectangle x1="6.6612" y1="-7.4104" x2="7.3724" y2="-7.3977" layer="94"/>
<rectangle x1="7.5248" y1="-7.4104" x2="7.8042" y2="-7.3977" layer="94"/>
<rectangle x1="8.2741" y1="-7.4104" x2="8.5408" y2="-7.3977" layer="94"/>
<rectangle x1="10.0775" y1="-7.4104" x2="10.9411" y2="-7.3977" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3977" x2="-11.0807" y2="-7.385" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3977" x2="-10.0012" y2="-7.385" layer="94"/>
<rectangle x1="-9.544" y1="-7.3977" x2="-9.163" y2="-7.385" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3977" x2="-8.0835" y2="-7.385" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3977" x2="-6.7627" y2="-7.385" layer="94"/>
<rectangle x1="-5.734" y1="-7.3977" x2="-5.3403" y2="-7.385" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3977" x2="-4.2481" y2="-7.385" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3977" x2="-2.3177" y2="-7.385" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3977" x2="-1.2509" y2="-7.385" layer="94"/>
<rectangle x1="-0.5778" y1="-7.3977" x2="0.1461" y2="-7.385" layer="94"/>
<rectangle x1="0.2477" y1="-7.3977" x2="0.5779" y2="-7.385" layer="94"/>
<rectangle x1="1.0224" y1="-7.3977" x2="1.3145" y2="-7.385" layer="94"/>
<rectangle x1="2.8131" y1="-7.3977" x2="3.1179" y2="-7.385" layer="94"/>
<rectangle x1="3.9053" y1="-7.3977" x2="4.1974" y2="-7.385" layer="94"/>
<rectangle x1="4.4768" y1="-7.3977" x2="4.7562" y2="-7.385" layer="94"/>
<rectangle x1="5.1753" y1="-7.3977" x2="5.4674" y2="-7.385" layer="94"/>
<rectangle x1="5.8992" y1="-7.3977" x2="6.1659" y2="-7.385" layer="94"/>
<rectangle x1="6.6739" y1="-7.3977" x2="7.4105" y2="-7.385" layer="94"/>
<rectangle x1="7.5248" y1="-7.3977" x2="7.8042" y2="-7.385" layer="94"/>
<rectangle x1="8.2741" y1="-7.3977" x2="8.5408" y2="-7.385" layer="94"/>
<rectangle x1="10.0775" y1="-7.3977" x2="10.9792" y2="-7.385" layer="94"/>
<rectangle x1="-11.4617" y1="-7.385" x2="-11.0807" y2="-7.3723" layer="94"/>
<rectangle x1="-10.3949" y1="-7.385" x2="-10.0012" y2="-7.3723" layer="94"/>
<rectangle x1="-9.544" y1="-7.385" x2="-9.163" y2="-7.3723" layer="94"/>
<rectangle x1="-8.4645" y1="-7.385" x2="-8.0835" y2="-7.3723" layer="94"/>
<rectangle x1="-7.6263" y1="-7.385" x2="-6.7373" y2="-7.3723" layer="94"/>
<rectangle x1="-5.734" y1="-7.385" x2="-5.3403" y2="-7.3723" layer="94"/>
<rectangle x1="-4.6545" y1="-7.385" x2="-4.2481" y2="-7.3723" layer="94"/>
<rectangle x1="-2.5971" y1="-7.385" x2="-2.3177" y2="-7.3723" layer="94"/>
<rectangle x1="-1.5176" y1="-7.385" x2="-1.2509" y2="-7.3723" layer="94"/>
<rectangle x1="-0.5651" y1="-7.385" x2="0.1715" y2="-7.3723" layer="94"/>
<rectangle x1="0.2477" y1="-7.385" x2="0.5779" y2="-7.3723" layer="94"/>
<rectangle x1="1.0224" y1="-7.385" x2="1.3145" y2="-7.3723" layer="94"/>
<rectangle x1="2.8131" y1="-7.385" x2="3.1179" y2="-7.3723" layer="94"/>
<rectangle x1="3.9053" y1="-7.385" x2="4.1974" y2="-7.3723" layer="94"/>
<rectangle x1="4.4768" y1="-7.385" x2="4.7562" y2="-7.3723" layer="94"/>
<rectangle x1="5.1753" y1="-7.385" x2="5.4674" y2="-7.3723" layer="94"/>
<rectangle x1="5.8992" y1="-7.385" x2="6.1659" y2="-7.3723" layer="94"/>
<rectangle x1="6.6866" y1="-7.385" x2="7.4232" y2="-7.3723" layer="94"/>
<rectangle x1="7.5248" y1="-7.385" x2="7.8042" y2="-7.3723" layer="94"/>
<rectangle x1="8.2741" y1="-7.385" x2="8.5408" y2="-7.3723" layer="94"/>
<rectangle x1="10.0775" y1="-7.385" x2="10.9919" y2="-7.3723" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3723" x2="-11.0807" y2="-7.3596" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3723" x2="-10.0012" y2="-7.3596" layer="94"/>
<rectangle x1="-9.544" y1="-7.3723" x2="-9.163" y2="-7.3596" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3723" x2="-8.0835" y2="-7.3596" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3723" x2="-6.7246" y2="-7.3596" layer="94"/>
<rectangle x1="-5.734" y1="-7.3723" x2="-5.3403" y2="-7.3596" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3723" x2="-4.2481" y2="-7.3596" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3723" x2="-2.3177" y2="-7.3596" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3723" x2="-1.2509" y2="-7.3596" layer="94"/>
<rectangle x1="-0.5524" y1="-7.3723" x2="0.1969" y2="-7.3596" layer="94"/>
<rectangle x1="0.2223" y1="-7.3723" x2="0.5779" y2="-7.3596" layer="94"/>
<rectangle x1="1.0224" y1="-7.3723" x2="1.3145" y2="-7.3596" layer="94"/>
<rectangle x1="2.8131" y1="-7.3723" x2="3.1179" y2="-7.3596" layer="94"/>
<rectangle x1="3.9053" y1="-7.3723" x2="4.1974" y2="-7.3596" layer="94"/>
<rectangle x1="4.4768" y1="-7.3723" x2="4.7562" y2="-7.3596" layer="94"/>
<rectangle x1="5.1753" y1="-7.3723" x2="5.4674" y2="-7.3596" layer="94"/>
<rectangle x1="5.8992" y1="-7.3723" x2="6.1659" y2="-7.3596" layer="94"/>
<rectangle x1="6.6993" y1="-7.3723" x2="7.4359" y2="-7.3596" layer="94"/>
<rectangle x1="7.5121" y1="-7.3723" x2="7.8042" y2="-7.3596" layer="94"/>
<rectangle x1="8.2741" y1="-7.3723" x2="8.5408" y2="-7.3596" layer="94"/>
<rectangle x1="10.0775" y1="-7.3723" x2="11.0046" y2="-7.3596" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3596" x2="-11.0807" y2="-7.3469" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3596" x2="-10.0012" y2="-7.3469" layer="94"/>
<rectangle x1="-9.544" y1="-7.3596" x2="-9.163" y2="-7.3469" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3596" x2="-8.0835" y2="-7.3469" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3596" x2="-6.7119" y2="-7.3469" layer="94"/>
<rectangle x1="-5.734" y1="-7.3596" x2="-5.3403" y2="-7.3469" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3596" x2="-4.2481" y2="-7.3469" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3596" x2="-2.3177" y2="-7.3469" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3596" x2="-1.2509" y2="-7.3469" layer="94"/>
<rectangle x1="-0.5143" y1="-7.3596" x2="0.5779" y2="-7.3469" layer="94"/>
<rectangle x1="1.0224" y1="-7.3596" x2="1.3145" y2="-7.3469" layer="94"/>
<rectangle x1="2.8131" y1="-7.3596" x2="3.1179" y2="-7.3469" layer="94"/>
<rectangle x1="3.8926" y1="-7.3596" x2="4.1974" y2="-7.3469" layer="94"/>
<rectangle x1="4.4768" y1="-7.3596" x2="4.7562" y2="-7.3469" layer="94"/>
<rectangle x1="5.1753" y1="-7.3596" x2="5.4674" y2="-7.3469" layer="94"/>
<rectangle x1="5.8992" y1="-7.3596" x2="6.1659" y2="-7.3469" layer="94"/>
<rectangle x1="6.7247" y1="-7.3596" x2="7.474" y2="-7.3469" layer="94"/>
<rectangle x1="7.4994" y1="-7.3596" x2="7.8042" y2="-7.3469" layer="94"/>
<rectangle x1="8.2741" y1="-7.3596" x2="8.5408" y2="-7.3469" layer="94"/>
<rectangle x1="10.0775" y1="-7.3596" x2="11.03" y2="-7.3469" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3469" x2="-11.0807" y2="-7.3342" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3469" x2="-10.0012" y2="-7.3342" layer="94"/>
<rectangle x1="-9.544" y1="-7.3469" x2="-9.163" y2="-7.3342" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3469" x2="-8.0835" y2="-7.3342" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3469" x2="-6.6865" y2="-7.3342" layer="94"/>
<rectangle x1="-5.734" y1="-7.3469" x2="-5.3403" y2="-7.3342" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3469" x2="-4.2481" y2="-7.3342" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3469" x2="-2.3177" y2="-7.3342" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3469" x2="-1.2509" y2="-7.3342" layer="94"/>
<rectangle x1="-0.4762" y1="-7.3469" x2="0.5779" y2="-7.3342" layer="94"/>
<rectangle x1="1.0224" y1="-7.3469" x2="1.3145" y2="-7.3342" layer="94"/>
<rectangle x1="2.8131" y1="-7.3469" x2="3.1179" y2="-7.3342" layer="94"/>
<rectangle x1="3.9053" y1="-7.3469" x2="4.1974" y2="-7.3342" layer="94"/>
<rectangle x1="4.4768" y1="-7.3469" x2="4.7562" y2="-7.3342" layer="94"/>
<rectangle x1="5.1753" y1="-7.3469" x2="5.4674" y2="-7.3342" layer="94"/>
<rectangle x1="5.8992" y1="-7.3469" x2="6.1659" y2="-7.3342" layer="94"/>
<rectangle x1="6.7755" y1="-7.3469" x2="7.8042" y2="-7.3342" layer="94"/>
<rectangle x1="8.2741" y1="-7.3469" x2="8.5408" y2="-7.3342" layer="94"/>
<rectangle x1="10.0775" y1="-7.3469" x2="11.0554" y2="-7.3342" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3342" x2="-11.0807" y2="-7.3215" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3342" x2="-10.0012" y2="-7.3215" layer="94"/>
<rectangle x1="-9.544" y1="-7.3342" x2="-9.163" y2="-7.3215" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3342" x2="-8.0835" y2="-7.3215" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3342" x2="-6.6357" y2="-7.3215" layer="94"/>
<rectangle x1="-5.734" y1="-7.3342" x2="-5.3403" y2="-7.3215" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3342" x2="-4.2481" y2="-7.3215" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3342" x2="-2.3177" y2="-7.3215" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3342" x2="-1.2509" y2="-7.3215" layer="94"/>
<rectangle x1="-0.4381" y1="-7.3342" x2="0.5779" y2="-7.3215" layer="94"/>
<rectangle x1="1.0224" y1="-7.3342" x2="1.3145" y2="-7.3215" layer="94"/>
<rectangle x1="2.8131" y1="-7.3342" x2="3.1179" y2="-7.3215" layer="94"/>
<rectangle x1="3.9053" y1="-7.3342" x2="4.1974" y2="-7.3215" layer="94"/>
<rectangle x1="4.4768" y1="-7.3342" x2="4.7562" y2="-7.3215" layer="94"/>
<rectangle x1="5.1753" y1="-7.3342" x2="5.4674" y2="-7.3215" layer="94"/>
<rectangle x1="5.8992" y1="-7.3342" x2="6.1659" y2="-7.3215" layer="94"/>
<rectangle x1="6.8136" y1="-7.3342" x2="7.8042" y2="-7.3215" layer="94"/>
<rectangle x1="8.2741" y1="-7.3342" x2="8.5408" y2="-7.3215" layer="94"/>
<rectangle x1="10.0775" y1="-7.3342" x2="11.0935" y2="-7.3215" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3215" x2="-11.0807" y2="-7.3088" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3215" x2="-10.0012" y2="-7.3088" layer="94"/>
<rectangle x1="-9.544" y1="-7.3215" x2="-9.163" y2="-7.3088" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3215" x2="-8.0835" y2="-7.3088" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3215" x2="-6.5976" y2="-7.3088" layer="94"/>
<rectangle x1="-5.734" y1="-7.3215" x2="-5.3403" y2="-7.3088" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3215" x2="-4.2481" y2="-7.3088" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3215" x2="-2.3177" y2="-7.3088" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3215" x2="-1.2509" y2="-7.3088" layer="94"/>
<rectangle x1="-0.4127" y1="-7.3215" x2="0.5779" y2="-7.3088" layer="94"/>
<rectangle x1="1.0224" y1="-7.3215" x2="1.3145" y2="-7.3088" layer="94"/>
<rectangle x1="2.8131" y1="-7.3215" x2="3.1179" y2="-7.3088" layer="94"/>
<rectangle x1="3.9053" y1="-7.3215" x2="4.1974" y2="-7.3088" layer="94"/>
<rectangle x1="4.4768" y1="-7.3215" x2="4.7562" y2="-7.3088" layer="94"/>
<rectangle x1="5.1753" y1="-7.3215" x2="5.4674" y2="-7.3088" layer="94"/>
<rectangle x1="5.8992" y1="-7.3215" x2="6.1659" y2="-7.3088" layer="94"/>
<rectangle x1="6.839" y1="-7.3215" x2="7.8042" y2="-7.3088" layer="94"/>
<rectangle x1="8.2741" y1="-7.3215" x2="8.5408" y2="-7.3088" layer="94"/>
<rectangle x1="10.0775" y1="-7.3215" x2="11.1443" y2="-7.3088" layer="94"/>
<rectangle x1="-11.4617" y1="-7.3088" x2="-11.0807" y2="-7.2961" layer="94"/>
<rectangle x1="-10.3949" y1="-7.3088" x2="-10.0012" y2="-7.2961" layer="94"/>
<rectangle x1="-9.544" y1="-7.3088" x2="-9.163" y2="-7.2961" layer="94"/>
<rectangle x1="-8.4645" y1="-7.3088" x2="-8.0835" y2="-7.2961" layer="94"/>
<rectangle x1="-7.6263" y1="-7.3088" x2="-6.5722" y2="-7.2961" layer="94"/>
<rectangle x1="-5.734" y1="-7.3088" x2="-5.3403" y2="-7.2961" layer="94"/>
<rectangle x1="-4.6545" y1="-7.3088" x2="-4.2481" y2="-7.2961" layer="94"/>
<rectangle x1="-2.5971" y1="-7.3088" x2="-2.3177" y2="-7.2961" layer="94"/>
<rectangle x1="-1.5176" y1="-7.3088" x2="-1.2509" y2="-7.2961" layer="94"/>
<rectangle x1="-0.3873" y1="-7.3088" x2="0.5779" y2="-7.2961" layer="94"/>
<rectangle x1="1.0224" y1="-7.3088" x2="1.3145" y2="-7.2961" layer="94"/>
<rectangle x1="2.8131" y1="-7.3088" x2="3.1179" y2="-7.2961" layer="94"/>
<rectangle x1="3.9053" y1="-7.3088" x2="4.1974" y2="-7.2961" layer="94"/>
<rectangle x1="4.4768" y1="-7.3088" x2="4.7562" y2="-7.2961" layer="94"/>
<rectangle x1="5.1753" y1="-7.3088" x2="5.4674" y2="-7.2961" layer="94"/>
<rectangle x1="5.8992" y1="-7.3088" x2="6.1659" y2="-7.2961" layer="94"/>
<rectangle x1="6.8517" y1="-7.3088" x2="7.8042" y2="-7.2961" layer="94"/>
<rectangle x1="8.2741" y1="-7.3088" x2="8.5408" y2="-7.2961" layer="94"/>
<rectangle x1="10.0775" y1="-7.3088" x2="11.1697" y2="-7.2961" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2961" x2="-11.0807" y2="-7.2834" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2961" x2="-10.0012" y2="-7.2834" layer="94"/>
<rectangle x1="-9.544" y1="-7.2961" x2="-9.163" y2="-7.2834" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2961" x2="-8.0835" y2="-7.2834" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2961" x2="-6.5468" y2="-7.2834" layer="94"/>
<rectangle x1="-5.734" y1="-7.2961" x2="-5.3403" y2="-7.2834" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2961" x2="-4.2481" y2="-7.2834" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2961" x2="-2.3177" y2="-7.2834" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2961" x2="-1.2509" y2="-7.2834" layer="94"/>
<rectangle x1="-0.3746" y1="-7.2961" x2="0.5779" y2="-7.2834" layer="94"/>
<rectangle x1="1.0224" y1="-7.2961" x2="1.3145" y2="-7.2834" layer="94"/>
<rectangle x1="2.8131" y1="-7.2961" x2="3.1179" y2="-7.2834" layer="94"/>
<rectangle x1="3.8926" y1="-7.2961" x2="4.1974" y2="-7.2834" layer="94"/>
<rectangle x1="4.4768" y1="-7.2961" x2="4.7562" y2="-7.2834" layer="94"/>
<rectangle x1="5.1753" y1="-7.2961" x2="5.4674" y2="-7.2834" layer="94"/>
<rectangle x1="5.8992" y1="-7.2961" x2="6.1659" y2="-7.2834" layer="94"/>
<rectangle x1="6.8644" y1="-7.2961" x2="7.8042" y2="-7.2834" layer="94"/>
<rectangle x1="8.2741" y1="-7.2961" x2="8.5408" y2="-7.2834" layer="94"/>
<rectangle x1="10.0775" y1="-7.2961" x2="10.4331" y2="-7.2834" layer="94"/>
<rectangle x1="10.4712" y1="-7.2961" x2="11.1951" y2="-7.2834" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2834" x2="-11.0807" y2="-7.2707" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2834" x2="-10.0012" y2="-7.2707" layer="94"/>
<rectangle x1="-9.544" y1="-7.2834" x2="-9.163" y2="-7.2707" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2834" x2="-8.0835" y2="-7.2707" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2834" x2="-6.5341" y2="-7.2707" layer="94"/>
<rectangle x1="-5.734" y1="-7.2834" x2="-5.3403" y2="-7.2707" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2834" x2="-4.2481" y2="-7.2707" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2834" x2="-2.3177" y2="-7.2707" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2834" x2="-1.2509" y2="-7.2707" layer="94"/>
<rectangle x1="-0.3492" y1="-7.2834" x2="0.5779" y2="-7.2707" layer="94"/>
<rectangle x1="1.0224" y1="-7.2834" x2="1.3145" y2="-7.2707" layer="94"/>
<rectangle x1="2.8131" y1="-7.2834" x2="3.1179" y2="-7.2707" layer="94"/>
<rectangle x1="3.9053" y1="-7.2834" x2="4.1974" y2="-7.2707" layer="94"/>
<rectangle x1="4.4768" y1="-7.2834" x2="4.7562" y2="-7.2707" layer="94"/>
<rectangle x1="5.1753" y1="-7.2834" x2="5.4674" y2="-7.2707" layer="94"/>
<rectangle x1="5.8992" y1="-7.2834" x2="6.1659" y2="-7.2707" layer="94"/>
<rectangle x1="6.8898" y1="-7.2834" x2="7.8042" y2="-7.2707" layer="94"/>
<rectangle x1="8.2741" y1="-7.2834" x2="8.5408" y2="-7.2707" layer="94"/>
<rectangle x1="10.0775" y1="-7.2834" x2="10.4077" y2="-7.2707" layer="94"/>
<rectangle x1="10.4966" y1="-7.2834" x2="11.2078" y2="-7.2707" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2707" x2="-11.0807" y2="-7.258" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2707" x2="-10.0012" y2="-7.258" layer="94"/>
<rectangle x1="-9.544" y1="-7.2707" x2="-9.163" y2="-7.258" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2707" x2="-8.0835" y2="-7.258" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2707" x2="-6.5087" y2="-7.258" layer="94"/>
<rectangle x1="-5.734" y1="-7.2707" x2="-5.3403" y2="-7.258" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2707" x2="-4.2481" y2="-7.258" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2707" x2="-2.3177" y2="-7.258" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2707" x2="-1.2509" y2="-7.258" layer="94"/>
<rectangle x1="-0.3111" y1="-7.2707" x2="0.5779" y2="-7.258" layer="94"/>
<rectangle x1="1.0224" y1="-7.2707" x2="1.3145" y2="-7.258" layer="94"/>
<rectangle x1="2.8131" y1="-7.2707" x2="3.1179" y2="-7.258" layer="94"/>
<rectangle x1="3.8926" y1="-7.2707" x2="4.1974" y2="-7.258" layer="94"/>
<rectangle x1="4.4768" y1="-7.2707" x2="4.7562" y2="-7.258" layer="94"/>
<rectangle x1="5.1753" y1="-7.2707" x2="5.4674" y2="-7.258" layer="94"/>
<rectangle x1="5.8992" y1="-7.2707" x2="6.1659" y2="-7.258" layer="94"/>
<rectangle x1="6.9279" y1="-7.2707" x2="7.8042" y2="-7.258" layer="94"/>
<rectangle x1="8.2741" y1="-7.2707" x2="8.5408" y2="-7.258" layer="94"/>
<rectangle x1="10.0775" y1="-7.2707" x2="10.395" y2="-7.258" layer="94"/>
<rectangle x1="10.522" y1="-7.2707" x2="11.2332" y2="-7.258" layer="94"/>
<rectangle x1="-11.4617" y1="-7.258" x2="-11.0807" y2="-7.2453" layer="94"/>
<rectangle x1="-10.3949" y1="-7.258" x2="-10.0012" y2="-7.2453" layer="94"/>
<rectangle x1="-9.544" y1="-7.258" x2="-9.163" y2="-7.2453" layer="94"/>
<rectangle x1="-8.4645" y1="-7.258" x2="-8.0835" y2="-7.2453" layer="94"/>
<rectangle x1="-7.6263" y1="-7.258" x2="-6.4706" y2="-7.2453" layer="94"/>
<rectangle x1="-5.734" y1="-7.258" x2="-5.3403" y2="-7.2453" layer="94"/>
<rectangle x1="-4.6545" y1="-7.258" x2="-4.2481" y2="-7.2453" layer="94"/>
<rectangle x1="-2.5971" y1="-7.258" x2="-2.3177" y2="-7.2453" layer="94"/>
<rectangle x1="-1.5176" y1="-7.258" x2="-1.2509" y2="-7.2453" layer="94"/>
<rectangle x1="-0.2603" y1="-7.258" x2="0.5779" y2="-7.2453" layer="94"/>
<rectangle x1="1.0224" y1="-7.258" x2="1.3145" y2="-7.2453" layer="94"/>
<rectangle x1="2.8131" y1="-7.258" x2="3.1179" y2="-7.2453" layer="94"/>
<rectangle x1="3.9053" y1="-7.258" x2="4.1974" y2="-7.2453" layer="94"/>
<rectangle x1="4.4768" y1="-7.258" x2="4.7562" y2="-7.2453" layer="94"/>
<rectangle x1="5.188" y1="-7.258" x2="5.4674" y2="-7.2453" layer="94"/>
<rectangle x1="5.8992" y1="-7.258" x2="6.1659" y2="-7.2453" layer="94"/>
<rectangle x1="6.9914" y1="-7.258" x2="7.8042" y2="-7.2453" layer="94"/>
<rectangle x1="8.2741" y1="-7.258" x2="8.5408" y2="-7.2453" layer="94"/>
<rectangle x1="10.0775" y1="-7.258" x2="10.395" y2="-7.2453" layer="94"/>
<rectangle x1="10.5601" y1="-7.258" x2="11.2586" y2="-7.2453" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2453" x2="-11.0807" y2="-7.2326" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2453" x2="-10.0012" y2="-7.2326" layer="94"/>
<rectangle x1="-9.544" y1="-7.2453" x2="-9.163" y2="-7.2326" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2453" x2="-8.0835" y2="-7.2326" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2453" x2="-6.4325" y2="-7.2326" layer="94"/>
<rectangle x1="-5.734" y1="-7.2453" x2="-5.3403" y2="-7.2326" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2453" x2="-4.2481" y2="-7.2326" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2453" x2="-2.3177" y2="-7.2326" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2453" x2="-1.2509" y2="-7.2326" layer="94"/>
<rectangle x1="-0.2349" y1="-7.2453" x2="0.5779" y2="-7.2326" layer="94"/>
<rectangle x1="1.0224" y1="-7.2453" x2="1.3145" y2="-7.2326" layer="94"/>
<rectangle x1="2.8131" y1="-7.2453" x2="3.1179" y2="-7.2326" layer="94"/>
<rectangle x1="3.9053" y1="-7.2453" x2="4.1974" y2="-7.2326" layer="94"/>
<rectangle x1="4.4768" y1="-7.2453" x2="4.7562" y2="-7.2326" layer="94"/>
<rectangle x1="5.188" y1="-7.2453" x2="5.4674" y2="-7.2326" layer="94"/>
<rectangle x1="5.8992" y1="-7.2453" x2="6.1659" y2="-7.2326" layer="94"/>
<rectangle x1="7.0168" y1="-7.2453" x2="7.8042" y2="-7.2326" layer="94"/>
<rectangle x1="8.2741" y1="-7.2453" x2="8.5408" y2="-7.2326" layer="94"/>
<rectangle x1="10.0775" y1="-7.2453" x2="10.3823" y2="-7.2326" layer="94"/>
<rectangle x1="10.5982" y1="-7.2453" x2="11.3094" y2="-7.2326" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2326" x2="-11.0807" y2="-7.2199" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2326" x2="-10.0012" y2="-7.2199" layer="94"/>
<rectangle x1="-9.544" y1="-7.2326" x2="-9.163" y2="-7.2199" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2326" x2="-8.0835" y2="-7.2199" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2326" x2="-6.3944" y2="-7.2199" layer="94"/>
<rectangle x1="-5.734" y1="-7.2326" x2="-5.3403" y2="-7.2199" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2326" x2="-4.2481" y2="-7.2199" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2326" x2="-2.3177" y2="-7.2199" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2326" x2="-1.2509" y2="-7.2199" layer="94"/>
<rectangle x1="-0.2095" y1="-7.2326" x2="0.5779" y2="-7.2199" layer="94"/>
<rectangle x1="1.0224" y1="-7.2326" x2="1.3145" y2="-7.2199" layer="94"/>
<rectangle x1="2.8131" y1="-7.2326" x2="3.1179" y2="-7.2199" layer="94"/>
<rectangle x1="3.8926" y1="-7.2326" x2="4.1974" y2="-7.2199" layer="94"/>
<rectangle x1="4.4768" y1="-7.2326" x2="4.7562" y2="-7.2199" layer="94"/>
<rectangle x1="5.188" y1="-7.2326" x2="5.4674" y2="-7.2199" layer="94"/>
<rectangle x1="5.8992" y1="-7.2326" x2="6.1659" y2="-7.2199" layer="94"/>
<rectangle x1="7.0422" y1="-7.2326" x2="7.8042" y2="-7.2199" layer="94"/>
<rectangle x1="8.2741" y1="-7.2326" x2="8.5408" y2="-7.2199" layer="94"/>
<rectangle x1="10.0775" y1="-7.2326" x2="10.3823" y2="-7.2199" layer="94"/>
<rectangle x1="10.6109" y1="-7.2326" x2="11.3475" y2="-7.2199" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2199" x2="-11.0807" y2="-7.2072" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2199" x2="-10.0012" y2="-7.2072" layer="94"/>
<rectangle x1="-9.544" y1="-7.2199" x2="-9.163" y2="-7.2072" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2199" x2="-8.0835" y2="-7.2072" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2199" x2="-6.369" y2="-7.2072" layer="94"/>
<rectangle x1="-5.734" y1="-7.2199" x2="-5.3403" y2="-7.2072" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2199" x2="-4.2481" y2="-7.2072" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2199" x2="-2.3177" y2="-7.2072" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2199" x2="-1.2509" y2="-7.2072" layer="94"/>
<rectangle x1="-0.1841" y1="-7.2199" x2="0.5779" y2="-7.2072" layer="94"/>
<rectangle x1="1.0224" y1="-7.2199" x2="1.3145" y2="-7.2072" layer="94"/>
<rectangle x1="2.8131" y1="-7.2199" x2="3.1179" y2="-7.2072" layer="94"/>
<rectangle x1="3.9053" y1="-7.2199" x2="4.1974" y2="-7.2072" layer="94"/>
<rectangle x1="4.4768" y1="-7.2199" x2="4.7562" y2="-7.2072" layer="94"/>
<rectangle x1="5.188" y1="-7.2199" x2="5.4674" y2="-7.2072" layer="94"/>
<rectangle x1="5.8992" y1="-7.2199" x2="6.1659" y2="-7.2072" layer="94"/>
<rectangle x1="7.0676" y1="-7.2199" x2="7.8042" y2="-7.2072" layer="94"/>
<rectangle x1="8.2741" y1="-7.2199" x2="8.5408" y2="-7.2072" layer="94"/>
<rectangle x1="10.0775" y1="-7.2199" x2="10.3823" y2="-7.2072" layer="94"/>
<rectangle x1="10.6363" y1="-7.2199" x2="11.3729" y2="-7.2072" layer="94"/>
<rectangle x1="-11.4617" y1="-7.2072" x2="-11.0807" y2="-7.1945" layer="94"/>
<rectangle x1="-10.3949" y1="-7.2072" x2="-10.0012" y2="-7.1945" layer="94"/>
<rectangle x1="-9.544" y1="-7.2072" x2="-9.163" y2="-7.1945" layer="94"/>
<rectangle x1="-8.4645" y1="-7.2072" x2="-8.0835" y2="-7.1945" layer="94"/>
<rectangle x1="-7.6263" y1="-7.2072" x2="-6.3563" y2="-7.1945" layer="94"/>
<rectangle x1="-5.734" y1="-7.2072" x2="-5.3403" y2="-7.1945" layer="94"/>
<rectangle x1="-4.6545" y1="-7.2072" x2="-4.2481" y2="-7.1945" layer="94"/>
<rectangle x1="-2.5971" y1="-7.2072" x2="-2.3177" y2="-7.1945" layer="94"/>
<rectangle x1="-1.5176" y1="-7.2072" x2="-1.2509" y2="-7.1945" layer="94"/>
<rectangle x1="-0.1714" y1="-7.2072" x2="0.5779" y2="-7.1945" layer="94"/>
<rectangle x1="1.0224" y1="-7.2072" x2="1.3145" y2="-7.1945" layer="94"/>
<rectangle x1="2.8131" y1="-7.2072" x2="3.1179" y2="-7.1945" layer="94"/>
<rectangle x1="3.8926" y1="-7.2072" x2="4.1974" y2="-7.1945" layer="94"/>
<rectangle x1="4.4768" y1="-7.2072" x2="4.7562" y2="-7.1945" layer="94"/>
<rectangle x1="5.188" y1="-7.2072" x2="5.4674" y2="-7.1945" layer="94"/>
<rectangle x1="5.8992" y1="-7.2072" x2="6.1659" y2="-7.1945" layer="94"/>
<rectangle x1="7.0803" y1="-7.2072" x2="7.8042" y2="-7.1945" layer="94"/>
<rectangle x1="8.2741" y1="-7.2072" x2="8.5408" y2="-7.1945" layer="94"/>
<rectangle x1="10.0775" y1="-7.2072" x2="10.3823" y2="-7.1945" layer="94"/>
<rectangle x1="10.649" y1="-7.2072" x2="11.3856" y2="-7.1945" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1945" x2="-11.0807" y2="-7.1818" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1945" x2="-10.0012" y2="-7.1818" layer="94"/>
<rectangle x1="-9.544" y1="-7.1945" x2="-9.163" y2="-7.1818" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1945" x2="-8.0835" y2="-7.1818" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1945" x2="-6.3309" y2="-7.1818" layer="94"/>
<rectangle x1="-5.734" y1="-7.1945" x2="-5.3403" y2="-7.1818" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1945" x2="-4.2481" y2="-7.1818" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1945" x2="-2.3177" y2="-7.1818" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1945" x2="-1.2509" y2="-7.1818" layer="94"/>
<rectangle x1="-0.1333" y1="-7.1945" x2="0.5779" y2="-7.1818" layer="94"/>
<rectangle x1="1.0224" y1="-7.1945" x2="1.3145" y2="-7.1818" layer="94"/>
<rectangle x1="2.8131" y1="-7.1945" x2="3.1179" y2="-7.1818" layer="94"/>
<rectangle x1="3.9053" y1="-7.1945" x2="4.1974" y2="-7.1818" layer="94"/>
<rectangle x1="4.4768" y1="-7.1945" x2="4.7562" y2="-7.1818" layer="94"/>
<rectangle x1="5.188" y1="-7.1945" x2="5.4674" y2="-7.1818" layer="94"/>
<rectangle x1="5.8992" y1="-7.1945" x2="6.1659" y2="-7.1818" layer="94"/>
<rectangle x1="7.1184" y1="-7.1945" x2="7.8042" y2="-7.1818" layer="94"/>
<rectangle x1="8.2741" y1="-7.1945" x2="8.5408" y2="-7.1818" layer="94"/>
<rectangle x1="10.0775" y1="-7.1945" x2="10.3823" y2="-7.1818" layer="94"/>
<rectangle x1="10.6871" y1="-7.1945" x2="11.3983" y2="-7.1818" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1818" x2="-11.0807" y2="-7.1691" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1818" x2="-10.0012" y2="-7.1691" layer="94"/>
<rectangle x1="-9.544" y1="-7.1818" x2="-9.163" y2="-7.1691" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1818" x2="-8.0835" y2="-7.1691" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1818" x2="-6.3055" y2="-7.1691" layer="94"/>
<rectangle x1="-5.734" y1="-7.1818" x2="-5.3403" y2="-7.1691" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1818" x2="-4.2481" y2="-7.1691" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1818" x2="-2.3177" y2="-7.1691" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1818" x2="-1.2509" y2="-7.1691" layer="94"/>
<rectangle x1="-0.0952" y1="-7.1818" x2="0.5779" y2="-7.1691" layer="94"/>
<rectangle x1="1.0224" y1="-7.1818" x2="1.3145" y2="-7.1691" layer="94"/>
<rectangle x1="2.8131" y1="-7.1818" x2="3.1179" y2="-7.1691" layer="94"/>
<rectangle x1="3.9053" y1="-7.1818" x2="4.1974" y2="-7.1691" layer="94"/>
<rectangle x1="4.4768" y1="-7.1818" x2="4.7562" y2="-7.1691" layer="94"/>
<rectangle x1="5.188" y1="-7.1818" x2="5.4674" y2="-7.1691" layer="94"/>
<rectangle x1="5.8992" y1="-7.1818" x2="6.1659" y2="-7.1691" layer="94"/>
<rectangle x1="7.1565" y1="-7.1818" x2="7.8042" y2="-7.1691" layer="94"/>
<rectangle x1="8.2741" y1="-7.1818" x2="8.5408" y2="-7.1691" layer="94"/>
<rectangle x1="10.0775" y1="-7.1818" x2="10.3823" y2="-7.1691" layer="94"/>
<rectangle x1="10.7252" y1="-7.1818" x2="11.411" y2="-7.1691" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1691" x2="-11.0807" y2="-7.1564" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1691" x2="-10.0012" y2="-7.1564" layer="94"/>
<rectangle x1="-9.544" y1="-7.1691" x2="-9.163" y2="-7.1564" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1691" x2="-8.0835" y2="-7.1564" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1691" x2="-6.2674" y2="-7.1564" layer="94"/>
<rectangle x1="-5.734" y1="-7.1691" x2="-5.3403" y2="-7.1564" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1691" x2="-4.2481" y2="-7.1564" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1691" x2="-2.3177" y2="-7.1564" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1691" x2="-1.2509" y2="-7.1564" layer="94"/>
<rectangle x1="-0.0571" y1="-7.1691" x2="0.5779" y2="-7.1564" layer="94"/>
<rectangle x1="1.0224" y1="-7.1691" x2="1.3145" y2="-7.1564" layer="94"/>
<rectangle x1="2.8131" y1="-7.1691" x2="3.1179" y2="-7.1564" layer="94"/>
<rectangle x1="3.9053" y1="-7.1691" x2="4.1974" y2="-7.1564" layer="94"/>
<rectangle x1="4.4768" y1="-7.1691" x2="4.7562" y2="-7.1564" layer="94"/>
<rectangle x1="5.188" y1="-7.1691" x2="5.4674" y2="-7.1564" layer="94"/>
<rectangle x1="5.8992" y1="-7.1691" x2="6.1659" y2="-7.1564" layer="94"/>
<rectangle x1="7.2073" y1="-7.1691" x2="7.8042" y2="-7.1564" layer="94"/>
<rectangle x1="8.2741" y1="-7.1691" x2="8.5408" y2="-7.1564" layer="94"/>
<rectangle x1="10.0775" y1="-7.1691" x2="10.3823" y2="-7.1564" layer="94"/>
<rectangle x1="10.776" y1="-7.1691" x2="11.4237" y2="-7.1564" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1564" x2="-11.0807" y2="-7.1437" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1564" x2="-10.0012" y2="-7.1437" layer="94"/>
<rectangle x1="-9.544" y1="-7.1564" x2="-9.163" y2="-7.1437" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1564" x2="-8.0835" y2="-7.1437" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1564" x2="-6.2293" y2="-7.1437" layer="94"/>
<rectangle x1="-5.734" y1="-7.1564" x2="-5.3403" y2="-7.1437" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1564" x2="-4.2481" y2="-7.1437" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1564" x2="-2.3177" y2="-7.1437" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1564" x2="-1.2509" y2="-7.1437" layer="94"/>
<rectangle x1="-0.019" y1="-7.1564" x2="0.5779" y2="-7.1437" layer="94"/>
<rectangle x1="1.0224" y1="-7.1564" x2="1.3145" y2="-7.1437" layer="94"/>
<rectangle x1="2.8131" y1="-7.1564" x2="3.1179" y2="-7.1437" layer="94"/>
<rectangle x1="3.9053" y1="-7.1564" x2="4.1974" y2="-7.1437" layer="94"/>
<rectangle x1="4.4768" y1="-7.1564" x2="4.7562" y2="-7.1437" layer="94"/>
<rectangle x1="5.188" y1="-7.1564" x2="5.4674" y2="-7.1437" layer="94"/>
<rectangle x1="5.8992" y1="-7.1564" x2="6.1659" y2="-7.1437" layer="94"/>
<rectangle x1="7.2327" y1="-7.1564" x2="7.8042" y2="-7.1437" layer="94"/>
<rectangle x1="8.2741" y1="-7.1564" x2="8.5408" y2="-7.1437" layer="94"/>
<rectangle x1="10.0775" y1="-7.1564" x2="10.3823" y2="-7.1437" layer="94"/>
<rectangle x1="10.8014" y1="-7.1564" x2="11.4237" y2="-7.1437" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1437" x2="-11.0807" y2="-7.131" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1437" x2="-10.0012" y2="-7.131" layer="94"/>
<rectangle x1="-9.544" y1="-7.1437" x2="-9.163" y2="-7.131" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1437" x2="-8.0835" y2="-7.131" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1437" x2="-6.2166" y2="-7.131" layer="94"/>
<rectangle x1="-5.734" y1="-7.1437" x2="-5.3403" y2="-7.131" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1437" x2="-4.2481" y2="-7.131" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1437" x2="-2.3177" y2="-7.131" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1437" x2="-1.2509" y2="-7.131" layer="94"/>
<rectangle x1="-0.0063" y1="-7.1437" x2="0.5779" y2="-7.131" layer="94"/>
<rectangle x1="1.0224" y1="-7.1437" x2="1.3145" y2="-7.131" layer="94"/>
<rectangle x1="2.8131" y1="-7.1437" x2="3.1179" y2="-7.131" layer="94"/>
<rectangle x1="3.9053" y1="-7.1437" x2="4.1974" y2="-7.131" layer="94"/>
<rectangle x1="4.4768" y1="-7.1437" x2="4.7562" y2="-7.131" layer="94"/>
<rectangle x1="5.188" y1="-7.1437" x2="5.4674" y2="-7.131" layer="94"/>
<rectangle x1="5.8992" y1="-7.1437" x2="6.1659" y2="-7.131" layer="94"/>
<rectangle x1="7.2454" y1="-7.1437" x2="7.8042" y2="-7.131" layer="94"/>
<rectangle x1="8.2741" y1="-7.1437" x2="8.5408" y2="-7.131" layer="94"/>
<rectangle x1="10.0775" y1="-7.1437" x2="10.3823" y2="-7.131" layer="94"/>
<rectangle x1="10.8141" y1="-7.1437" x2="11.4364" y2="-7.131" layer="94"/>
<rectangle x1="-11.4617" y1="-7.131" x2="-11.0807" y2="-7.1183" layer="94"/>
<rectangle x1="-10.3949" y1="-7.131" x2="-10.0012" y2="-7.1183" layer="94"/>
<rectangle x1="-9.544" y1="-7.131" x2="-9.163" y2="-7.1183" layer="94"/>
<rectangle x1="-8.4645" y1="-7.131" x2="-8.0835" y2="-7.1183" layer="94"/>
<rectangle x1="-7.6263" y1="-7.131" x2="-7.2326" y2="-7.1183" layer="94"/>
<rectangle x1="-7.1564" y1="-7.131" x2="-6.2039" y2="-7.1183" layer="94"/>
<rectangle x1="-5.734" y1="-7.131" x2="-5.3403" y2="-7.1183" layer="94"/>
<rectangle x1="-4.6545" y1="-7.131" x2="-4.2481" y2="-7.1183" layer="94"/>
<rectangle x1="-2.5971" y1="-7.131" x2="-2.3177" y2="-7.1183" layer="94"/>
<rectangle x1="-1.5176" y1="-7.131" x2="-1.2509" y2="-7.1183" layer="94"/>
<rectangle x1="-0.7683" y1="-7.131" x2="-0.7048" y2="-7.1183" layer="94"/>
<rectangle x1="0.0191" y1="-7.131" x2="0.5779" y2="-7.1183" layer="94"/>
<rectangle x1="1.0224" y1="-7.131" x2="1.3145" y2="-7.1183" layer="94"/>
<rectangle x1="2.8131" y1="-7.131" x2="3.1179" y2="-7.1183" layer="94"/>
<rectangle x1="3.9053" y1="-7.131" x2="4.1974" y2="-7.1183" layer="94"/>
<rectangle x1="4.4768" y1="-7.131" x2="4.7562" y2="-7.1183" layer="94"/>
<rectangle x1="5.188" y1="-7.131" x2="5.4674" y2="-7.1183" layer="94"/>
<rectangle x1="5.8992" y1="-7.131" x2="6.1659" y2="-7.1183" layer="94"/>
<rectangle x1="6.4707" y1="-7.131" x2="6.5215" y2="-7.1183" layer="94"/>
<rectangle x1="7.2708" y1="-7.131" x2="7.8042" y2="-7.1183" layer="94"/>
<rectangle x1="8.2741" y1="-7.131" x2="8.5408" y2="-7.1183" layer="94"/>
<rectangle x1="10.0775" y1="-7.131" x2="10.3823" y2="-7.1183" layer="94"/>
<rectangle x1="10.8268" y1="-7.131" x2="11.4364" y2="-7.1183" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1183" x2="-11.0807" y2="-7.1056" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1183" x2="-10.0012" y2="-7.1056" layer="94"/>
<rectangle x1="-9.544" y1="-7.1183" x2="-9.163" y2="-7.1056" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1183" x2="-8.0835" y2="-7.1056" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1183" x2="-7.2453" y2="-7.1056" layer="94"/>
<rectangle x1="-7.131" y1="-7.1183" x2="-6.1912" y2="-7.1056" layer="94"/>
<rectangle x1="-5.734" y1="-7.1183" x2="-5.3403" y2="-7.1056" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1183" x2="-4.2481" y2="-7.1056" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1183" x2="-2.3177" y2="-7.1056" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1183" x2="-1.2509" y2="-7.1056" layer="94"/>
<rectangle x1="-0.781" y1="-7.1183" x2="-0.6921" y2="-7.1056" layer="94"/>
<rectangle x1="0.0445" y1="-7.1183" x2="0.5779" y2="-7.1056" layer="94"/>
<rectangle x1="1.0224" y1="-7.1183" x2="1.3145" y2="-7.1056" layer="94"/>
<rectangle x1="2.8131" y1="-7.1183" x2="3.1179" y2="-7.1056" layer="94"/>
<rectangle x1="3.8926" y1="-7.1183" x2="4.1974" y2="-7.1056" layer="94"/>
<rectangle x1="4.4768" y1="-7.1183" x2="4.7562" y2="-7.1056" layer="94"/>
<rectangle x1="5.188" y1="-7.1183" x2="5.4674" y2="-7.1056" layer="94"/>
<rectangle x1="5.8992" y1="-7.1183" x2="6.1659" y2="-7.1056" layer="94"/>
<rectangle x1="6.458" y1="-7.1183" x2="6.5469" y2="-7.1056" layer="94"/>
<rectangle x1="7.2962" y1="-7.1183" x2="7.8042" y2="-7.1056" layer="94"/>
<rectangle x1="8.2741" y1="-7.1183" x2="8.5408" y2="-7.1056" layer="94"/>
<rectangle x1="10.0775" y1="-7.1183" x2="10.3823" y2="-7.1056" layer="94"/>
<rectangle x1="10.8522" y1="-7.1183" x2="11.4491" y2="-7.1056" layer="94"/>
<rectangle x1="-11.4617" y1="-7.1056" x2="-11.0807" y2="-7.0929" layer="94"/>
<rectangle x1="-10.3949" y1="-7.1056" x2="-10.0012" y2="-7.0929" layer="94"/>
<rectangle x1="-9.544" y1="-7.1056" x2="-9.163" y2="-7.0929" layer="94"/>
<rectangle x1="-8.4645" y1="-7.1056" x2="-8.0835" y2="-7.0929" layer="94"/>
<rectangle x1="-7.6263" y1="-7.1056" x2="-7.258" y2="-7.0929" layer="94"/>
<rectangle x1="-7.0929" y1="-7.1056" x2="-6.1912" y2="-7.0929" layer="94"/>
<rectangle x1="-5.734" y1="-7.1056" x2="-5.3403" y2="-7.0929" layer="94"/>
<rectangle x1="-4.6545" y1="-7.1056" x2="-4.2481" y2="-7.0929" layer="94"/>
<rectangle x1="-2.5971" y1="-7.1056" x2="-2.3177" y2="-7.0929" layer="94"/>
<rectangle x1="-1.5176" y1="-7.1056" x2="-1.2509" y2="-7.0929" layer="94"/>
<rectangle x1="-0.781" y1="-7.1056" x2="-0.6667" y2="-7.0929" layer="94"/>
<rectangle x1="0.0826" y1="-7.1056" x2="0.5779" y2="-7.0929" layer="94"/>
<rectangle x1="1.0224" y1="-7.1056" x2="1.3145" y2="-7.0929" layer="94"/>
<rectangle x1="2.8131" y1="-7.1056" x2="3.1179" y2="-7.0929" layer="94"/>
<rectangle x1="3.9053" y1="-7.1056" x2="4.1974" y2="-7.0929" layer="94"/>
<rectangle x1="4.4768" y1="-7.1056" x2="4.7562" y2="-7.0929" layer="94"/>
<rectangle x1="5.188" y1="-7.1056" x2="5.4674" y2="-7.0929" layer="94"/>
<rectangle x1="5.8992" y1="-7.1056" x2="6.1659" y2="-7.0929" layer="94"/>
<rectangle x1="6.458" y1="-7.1056" x2="6.585" y2="-7.0929" layer="94"/>
<rectangle x1="7.3343" y1="-7.1056" x2="7.8042" y2="-7.0929" layer="94"/>
<rectangle x1="8.2741" y1="-7.1056" x2="8.5408" y2="-7.0929" layer="94"/>
<rectangle x1="10.0775" y1="-7.1056" x2="10.3823" y2="-7.0929" layer="94"/>
<rectangle x1="10.8903" y1="-7.1056" x2="11.4491" y2="-7.0929" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0929" x2="-11.0807" y2="-7.0802" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0929" x2="-10.0012" y2="-7.0802" layer="94"/>
<rectangle x1="-9.544" y1="-7.0929" x2="-9.163" y2="-7.0802" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0929" x2="-8.0835" y2="-7.0802" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0929" x2="-7.258" y2="-7.0802" layer="94"/>
<rectangle x1="-7.0421" y1="-7.0929" x2="-6.1912" y2="-7.0802" layer="94"/>
<rectangle x1="-5.734" y1="-7.0929" x2="-5.3403" y2="-7.0802" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0929" x2="-4.2481" y2="-7.0802" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0929" x2="-2.3177" y2="-7.0802" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0929" x2="-1.2509" y2="-7.0802" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0929" x2="-0.6413" y2="-7.0802" layer="94"/>
<rectangle x1="0.1334" y1="-7.0929" x2="0.5779" y2="-7.0802" layer="94"/>
<rectangle x1="1.0224" y1="-7.0929" x2="1.3145" y2="-7.0802" layer="94"/>
<rectangle x1="2.1273" y1="-7.0929" x2="2.2035" y2="-7.0802" layer="94"/>
<rectangle x1="2.8131" y1="-7.0929" x2="3.1179" y2="-7.0802" layer="94"/>
<rectangle x1="3.9053" y1="-7.0929" x2="4.1974" y2="-7.0802" layer="94"/>
<rectangle x1="4.4768" y1="-7.0929" x2="4.7562" y2="-7.0802" layer="94"/>
<rectangle x1="5.188" y1="-7.0929" x2="5.4674" y2="-7.0802" layer="94"/>
<rectangle x1="5.8992" y1="-7.0929" x2="6.1659" y2="-7.0802" layer="94"/>
<rectangle x1="6.458" y1="-7.0929" x2="6.6104" y2="-7.0802" layer="94"/>
<rectangle x1="7.3851" y1="-7.0929" x2="7.8042" y2="-7.0802" layer="94"/>
<rectangle x1="8.2741" y1="-7.0929" x2="8.5408" y2="-7.0802" layer="94"/>
<rectangle x1="9.3536" y1="-7.0929" x2="9.4552" y2="-7.0802" layer="94"/>
<rectangle x1="10.0775" y1="-7.0929" x2="10.3823" y2="-7.0802" layer="94"/>
<rectangle x1="10.9284" y1="-7.0929" x2="11.4491" y2="-7.0802" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0802" x2="-11.0807" y2="-7.0675" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0802" x2="-10.0012" y2="-7.0675" layer="94"/>
<rectangle x1="-9.544" y1="-7.0802" x2="-9.163" y2="-7.0675" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0802" x2="-8.0835" y2="-7.0675" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0802" x2="-7.258" y2="-7.0675" layer="94"/>
<rectangle x1="-7.004" y1="-7.0802" x2="-6.1912" y2="-7.0675" layer="94"/>
<rectangle x1="-5.734" y1="-7.0802" x2="-5.3403" y2="-7.0675" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0802" x2="-4.2481" y2="-7.0675" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0802" x2="-2.3177" y2="-7.0675" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0802" x2="-1.2509" y2="-7.0675" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0802" x2="-0.5905" y2="-7.0675" layer="94"/>
<rectangle x1="0.1715" y1="-7.0802" x2="0.5779" y2="-7.0675" layer="94"/>
<rectangle x1="1.0224" y1="-7.0802" x2="1.3145" y2="-7.0675" layer="94"/>
<rectangle x1="2.1273" y1="-7.0802" x2="2.2416" y2="-7.0675" layer="94"/>
<rectangle x1="2.8131" y1="-7.0802" x2="3.1179" y2="-7.0675" layer="94"/>
<rectangle x1="3.9053" y1="-7.0802" x2="4.1974" y2="-7.0675" layer="94"/>
<rectangle x1="4.4768" y1="-7.0802" x2="4.7562" y2="-7.0675" layer="94"/>
<rectangle x1="5.188" y1="-7.0802" x2="5.4674" y2="-7.0675" layer="94"/>
<rectangle x1="5.8992" y1="-7.0802" x2="6.1659" y2="-7.0675" layer="94"/>
<rectangle x1="6.458" y1="-7.0802" x2="6.6485" y2="-7.0675" layer="94"/>
<rectangle x1="7.4232" y1="-7.0802" x2="7.8042" y2="-7.0675" layer="94"/>
<rectangle x1="8.2741" y1="-7.0802" x2="8.5408" y2="-7.0675" layer="94"/>
<rectangle x1="9.3536" y1="-7.0802" x2="9.4933" y2="-7.0675" layer="94"/>
<rectangle x1="10.0775" y1="-7.0802" x2="10.3823" y2="-7.0675" layer="94"/>
<rectangle x1="10.9665" y1="-7.0802" x2="11.4491" y2="-7.0675" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0675" x2="-11.0807" y2="-7.0548" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0675" x2="-10.0012" y2="-7.0548" layer="94"/>
<rectangle x1="-9.544" y1="-7.0675" x2="-9.163" y2="-7.0548" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0675" x2="-8.0835" y2="-7.0548" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0675" x2="-7.2707" y2="-7.0548" layer="94"/>
<rectangle x1="-6.9913" y1="-7.0675" x2="-6.1912" y2="-7.0548" layer="94"/>
<rectangle x1="-5.734" y1="-7.0675" x2="-5.3403" y2="-7.0548" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0675" x2="-4.2481" y2="-7.0548" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0675" x2="-2.3177" y2="-7.0548" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0675" x2="-1.2509" y2="-7.0548" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0675" x2="-0.5524" y2="-7.0548" layer="94"/>
<rectangle x1="0.1969" y1="-7.0675" x2="0.5779" y2="-7.0548" layer="94"/>
<rectangle x1="1.0224" y1="-7.0675" x2="1.3145" y2="-7.0548" layer="94"/>
<rectangle x1="2.1146" y1="-7.0675" x2="2.2797" y2="-7.0548" layer="94"/>
<rectangle x1="2.8131" y1="-7.0675" x2="3.1179" y2="-7.0548" layer="94"/>
<rectangle x1="3.9053" y1="-7.0675" x2="4.1974" y2="-7.0548" layer="94"/>
<rectangle x1="4.4768" y1="-7.0675" x2="4.7562" y2="-7.0548" layer="94"/>
<rectangle x1="5.188" y1="-7.0675" x2="5.4674" y2="-7.0548" layer="94"/>
<rectangle x1="5.8992" y1="-7.0675" x2="6.1659" y2="-7.0548" layer="94"/>
<rectangle x1="6.458" y1="-7.0675" x2="6.6739" y2="-7.0548" layer="94"/>
<rectangle x1="7.4486" y1="-7.0675" x2="7.8042" y2="-7.0548" layer="94"/>
<rectangle x1="8.2741" y1="-7.0675" x2="8.5408" y2="-7.0548" layer="94"/>
<rectangle x1="9.3409" y1="-7.0675" x2="9.5314" y2="-7.0548" layer="94"/>
<rectangle x1="10.0775" y1="-7.0675" x2="10.3823" y2="-7.0548" layer="94"/>
<rectangle x1="10.9919" y1="-7.0675" x2="11.4491" y2="-7.0548" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0548" x2="-11.0807" y2="-7.0421" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0548" x2="-10.0012" y2="-7.0421" layer="94"/>
<rectangle x1="-9.544" y1="-7.0548" x2="-9.163" y2="-7.0421" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0548" x2="-8.0835" y2="-7.0421" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0548" x2="-7.2707" y2="-7.0421" layer="94"/>
<rectangle x1="-6.9659" y1="-7.0548" x2="-6.1912" y2="-7.0421" layer="94"/>
<rectangle x1="-5.734" y1="-7.0548" x2="-5.3403" y2="-7.0421" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0548" x2="-4.2481" y2="-7.0421" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0548" x2="-2.3177" y2="-7.0421" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0548" x2="-1.2509" y2="-7.0421" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0548" x2="-0.5397" y2="-7.0421" layer="94"/>
<rectangle x1="0.2096" y1="-7.0548" x2="0.5779" y2="-7.0421" layer="94"/>
<rectangle x1="1.0224" y1="-7.0548" x2="1.3145" y2="-7.0421" layer="94"/>
<rectangle x1="2.1146" y1="-7.0548" x2="2.3051" y2="-7.0421" layer="94"/>
<rectangle x1="2.8131" y1="-7.0548" x2="3.1179" y2="-7.0421" layer="94"/>
<rectangle x1="3.9053" y1="-7.0548" x2="4.1974" y2="-7.0421" layer="94"/>
<rectangle x1="4.4768" y1="-7.0548" x2="4.7562" y2="-7.0421" layer="94"/>
<rectangle x1="5.188" y1="-7.0548" x2="5.4674" y2="-7.0421" layer="94"/>
<rectangle x1="5.8992" y1="-7.0548" x2="6.1659" y2="-7.0421" layer="94"/>
<rectangle x1="6.458" y1="-7.0548" x2="6.6993" y2="-7.0421" layer="94"/>
<rectangle x1="7.4613" y1="-7.0548" x2="7.8042" y2="-7.0421" layer="94"/>
<rectangle x1="8.2741" y1="-7.0548" x2="8.5408" y2="-7.0421" layer="94"/>
<rectangle x1="9.3409" y1="-7.0548" x2="9.5568" y2="-7.0421" layer="94"/>
<rectangle x1="10.0775" y1="-7.0548" x2="10.3823" y2="-7.0421" layer="94"/>
<rectangle x1="11.0046" y1="-7.0548" x2="11.4491" y2="-7.0421" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0421" x2="-11.0807" y2="-7.0294" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0421" x2="-10.0012" y2="-7.0294" layer="94"/>
<rectangle x1="-9.544" y1="-7.0421" x2="-9.163" y2="-7.0294" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0421" x2="-8.0835" y2="-7.0294" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0421" x2="-7.2707" y2="-7.0294" layer="94"/>
<rectangle x1="-6.9532" y1="-7.0421" x2="-6.1912" y2="-7.0294" layer="94"/>
<rectangle x1="-5.734" y1="-7.0421" x2="-5.3403" y2="-7.0294" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0421" x2="-4.2481" y2="-7.0294" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0421" x2="-2.3177" y2="-7.0294" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0421" x2="-1.2509" y2="-7.0294" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0421" x2="-0.527" y2="-7.0294" layer="94"/>
<rectangle x1="0.2223" y1="-7.0421" x2="0.5779" y2="-7.0294" layer="94"/>
<rectangle x1="1.0224" y1="-7.0421" x2="1.3145" y2="-7.0294" layer="94"/>
<rectangle x1="2.1146" y1="-7.0421" x2="2.3178" y2="-7.0294" layer="94"/>
<rectangle x1="2.8131" y1="-7.0421" x2="3.1179" y2="-7.0294" layer="94"/>
<rectangle x1="3.8926" y1="-7.0421" x2="4.1974" y2="-7.0294" layer="94"/>
<rectangle x1="4.4768" y1="-7.0421" x2="4.7562" y2="-7.0294" layer="94"/>
<rectangle x1="5.188" y1="-7.0421" x2="5.4674" y2="-7.0294" layer="94"/>
<rectangle x1="5.8992" y1="-7.0421" x2="6.1659" y2="-7.0294" layer="94"/>
<rectangle x1="6.458" y1="-7.0421" x2="6.712" y2="-7.0294" layer="94"/>
<rectangle x1="7.4867" y1="-7.0421" x2="7.8042" y2="-7.0294" layer="94"/>
<rectangle x1="8.2741" y1="-7.0421" x2="8.5408" y2="-7.0294" layer="94"/>
<rectangle x1="9.3409" y1="-7.0421" x2="9.5695" y2="-7.0294" layer="94"/>
<rectangle x1="10.0775" y1="-7.0421" x2="10.3823" y2="-7.0294" layer="94"/>
<rectangle x1="11.03" y1="-7.0421" x2="11.4491" y2="-7.0294" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0294" x2="-11.0807" y2="-7.0167" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0294" x2="-10.0012" y2="-7.0167" layer="94"/>
<rectangle x1="-9.544" y1="-7.0294" x2="-9.163" y2="-7.0167" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0294" x2="-8.0835" y2="-7.0167" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0294" x2="-7.2707" y2="-7.0167" layer="94"/>
<rectangle x1="-6.9278" y1="-7.0294" x2="-6.1912" y2="-7.0167" layer="94"/>
<rectangle x1="-5.734" y1="-7.0294" x2="-5.3403" y2="-7.0167" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0294" x2="-4.2481" y2="-7.0167" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0294" x2="-2.3177" y2="-7.0167" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0294" x2="-1.2509" y2="-7.0167" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0294" x2="-0.527" y2="-7.0167" layer="94"/>
<rectangle x1="0.235" y1="-7.0294" x2="0.5779" y2="-7.0167" layer="94"/>
<rectangle x1="1.0224" y1="-7.0294" x2="1.3145" y2="-7.0167" layer="94"/>
<rectangle x1="2.1146" y1="-7.0294" x2="2.3305" y2="-7.0167" layer="94"/>
<rectangle x1="2.8131" y1="-7.0294" x2="3.1179" y2="-7.0167" layer="94"/>
<rectangle x1="3.9053" y1="-7.0294" x2="4.1974" y2="-7.0167" layer="94"/>
<rectangle x1="4.4768" y1="-7.0294" x2="4.7562" y2="-7.0167" layer="94"/>
<rectangle x1="5.188" y1="-7.0294" x2="5.4674" y2="-7.0167" layer="94"/>
<rectangle x1="5.8992" y1="-7.0294" x2="6.1659" y2="-7.0167" layer="94"/>
<rectangle x1="6.458" y1="-7.0294" x2="6.712" y2="-7.0167" layer="94"/>
<rectangle x1="7.4994" y1="-7.0294" x2="7.8042" y2="-7.0167" layer="94"/>
<rectangle x1="8.2741" y1="-7.0294" x2="8.5408" y2="-7.0167" layer="94"/>
<rectangle x1="9.3409" y1="-7.0294" x2="9.5822" y2="-7.0167" layer="94"/>
<rectangle x1="10.0775" y1="-7.0294" x2="10.3823" y2="-7.0167" layer="94"/>
<rectangle x1="11.0554" y1="-7.0294" x2="11.4491" y2="-7.0167" layer="94"/>
<rectangle x1="-11.4617" y1="-7.0167" x2="-11.0807" y2="-7.004" layer="94"/>
<rectangle x1="-10.3949" y1="-7.0167" x2="-10.0012" y2="-7.004" layer="94"/>
<rectangle x1="-9.544" y1="-7.0167" x2="-9.163" y2="-7.004" layer="94"/>
<rectangle x1="-8.4645" y1="-7.0167" x2="-8.0835" y2="-7.004" layer="94"/>
<rectangle x1="-7.6263" y1="-7.0167" x2="-7.2707" y2="-7.004" layer="94"/>
<rectangle x1="-6.8897" y1="-7.0167" x2="-6.1912" y2="-7.004" layer="94"/>
<rectangle x1="-5.734" y1="-7.0167" x2="-5.3403" y2="-7.004" layer="94"/>
<rectangle x1="-4.6545" y1="-7.0167" x2="-4.2481" y2="-7.004" layer="94"/>
<rectangle x1="-2.5971" y1="-7.0167" x2="-2.3177" y2="-7.004" layer="94"/>
<rectangle x1="-1.5176" y1="-7.0167" x2="-1.2509" y2="-7.004" layer="94"/>
<rectangle x1="-0.7937" y1="-7.0167" x2="-0.527" y2="-7.004" layer="94"/>
<rectangle x1="0.2477" y1="-7.0167" x2="0.5779" y2="-7.004" layer="94"/>
<rectangle x1="1.0224" y1="-7.0167" x2="1.3145" y2="-7.004" layer="94"/>
<rectangle x1="2.1019" y1="-7.0167" x2="2.3432" y2="-7.004" layer="94"/>
<rectangle x1="2.8131" y1="-7.0167" x2="3.1179" y2="-7.004" layer="94"/>
<rectangle x1="3.9053" y1="-7.0167" x2="4.1974" y2="-7.004" layer="94"/>
<rectangle x1="4.4768" y1="-7.0167" x2="4.7562" y2="-7.004" layer="94"/>
<rectangle x1="5.188" y1="-7.0167" x2="5.4674" y2="-7.004" layer="94"/>
<rectangle x1="5.8992" y1="-7.0167" x2="6.1659" y2="-7.004" layer="94"/>
<rectangle x1="6.458" y1="-7.0167" x2="6.7247" y2="-7.004" layer="94"/>
<rectangle x1="7.5121" y1="-7.0167" x2="7.8042" y2="-7.004" layer="94"/>
<rectangle x1="8.2741" y1="-7.0167" x2="8.5408" y2="-7.004" layer="94"/>
<rectangle x1="9.3409" y1="-7.0167" x2="9.6076" y2="-7.004" layer="94"/>
<rectangle x1="10.0775" y1="-7.0167" x2="10.3823" y2="-7.004" layer="94"/>
<rectangle x1="11.0808" y1="-7.0167" x2="11.4491" y2="-7.004" layer="94"/>
<rectangle x1="-11.4617" y1="-7.004" x2="-11.0807" y2="-6.9913" layer="94"/>
<rectangle x1="-10.3949" y1="-7.004" x2="-10.0012" y2="-6.9913" layer="94"/>
<rectangle x1="-9.544" y1="-7.004" x2="-9.163" y2="-6.9913" layer="94"/>
<rectangle x1="-8.4645" y1="-7.004" x2="-8.0835" y2="-6.9913" layer="94"/>
<rectangle x1="-7.6263" y1="-7.004" x2="-7.2707" y2="-6.9913" layer="94"/>
<rectangle x1="-6.8389" y1="-7.004" x2="-6.1912" y2="-6.9913" layer="94"/>
<rectangle x1="-5.734" y1="-7.004" x2="-5.3403" y2="-6.9913" layer="94"/>
<rectangle x1="-4.6545" y1="-7.004" x2="-4.2481" y2="-6.9913" layer="94"/>
<rectangle x1="-2.5971" y1="-7.004" x2="-2.3177" y2="-6.9913" layer="94"/>
<rectangle x1="-1.5303" y1="-7.004" x2="-1.2509" y2="-6.9913" layer="94"/>
<rectangle x1="-0.7937" y1="-7.004" x2="-0.5143" y2="-6.9913" layer="94"/>
<rectangle x1="0.2604" y1="-7.004" x2="0.5779" y2="-6.9913" layer="94"/>
<rectangle x1="1.0224" y1="-7.004" x2="1.3145" y2="-6.9913" layer="94"/>
<rectangle x1="2.1019" y1="-7.004" x2="2.3559" y2="-6.9913" layer="94"/>
<rectangle x1="2.8258" y1="-7.004" x2="3.1179" y2="-6.9913" layer="94"/>
<rectangle x1="3.9053" y1="-7.004" x2="4.1974" y2="-6.9913" layer="94"/>
<rectangle x1="4.4768" y1="-7.004" x2="4.7562" y2="-6.9913" layer="94"/>
<rectangle x1="5.188" y1="-7.004" x2="5.4674" y2="-6.9913" layer="94"/>
<rectangle x1="5.8992" y1="-7.004" x2="6.1659" y2="-6.9913" layer="94"/>
<rectangle x1="6.458" y1="-7.004" x2="6.7374" y2="-6.9913" layer="94"/>
<rectangle x1="7.5248" y1="-7.004" x2="7.8042" y2="-6.9913" layer="94"/>
<rectangle x1="8.2741" y1="-7.004" x2="8.5408" y2="-6.9913" layer="94"/>
<rectangle x1="9.3409" y1="-7.004" x2="9.6203" y2="-6.9913" layer="94"/>
<rectangle x1="10.0775" y1="-7.004" x2="10.3823" y2="-6.9913" layer="94"/>
<rectangle x1="11.1189" y1="-7.004" x2="11.4491" y2="-6.9913" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9913" x2="-11.0807" y2="-6.9786" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9913" x2="-10.0012" y2="-6.9786" layer="94"/>
<rectangle x1="-9.544" y1="-6.9913" x2="-9.163" y2="-6.9786" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9913" x2="-8.0835" y2="-6.9786" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9913" x2="-7.2707" y2="-6.9786" layer="94"/>
<rectangle x1="-6.8135" y1="-6.9913" x2="-6.1912" y2="-6.9786" layer="94"/>
<rectangle x1="-5.734" y1="-6.9913" x2="-5.3403" y2="-6.9786" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9913" x2="-4.2481" y2="-6.9786" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9913" x2="-2.3177" y2="-6.9786" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9913" x2="-1.2509" y2="-6.9786" layer="94"/>
<rectangle x1="-0.7937" y1="-6.9913" x2="-0.5143" y2="-6.9786" layer="94"/>
<rectangle x1="0.2731" y1="-6.9913" x2="0.5779" y2="-6.9786" layer="94"/>
<rectangle x1="1.0224" y1="-6.9913" x2="1.3145" y2="-6.9786" layer="94"/>
<rectangle x1="2.1019" y1="-6.9913" x2="2.3686" y2="-6.9786" layer="94"/>
<rectangle x1="2.8258" y1="-6.9913" x2="3.1179" y2="-6.9786" layer="94"/>
<rectangle x1="3.9053" y1="-6.9913" x2="4.1974" y2="-6.9786" layer="94"/>
<rectangle x1="4.4768" y1="-6.9913" x2="4.7562" y2="-6.9786" layer="94"/>
<rectangle x1="5.188" y1="-6.9913" x2="5.4674" y2="-6.9786" layer="94"/>
<rectangle x1="5.8992" y1="-6.9913" x2="6.1659" y2="-6.9786" layer="94"/>
<rectangle x1="6.458" y1="-6.9913" x2="6.7374" y2="-6.9786" layer="94"/>
<rectangle x1="7.5248" y1="-6.9913" x2="7.8042" y2="-6.9786" layer="94"/>
<rectangle x1="8.2741" y1="-6.9913" x2="8.5408" y2="-6.9786" layer="94"/>
<rectangle x1="9.3409" y1="-6.9913" x2="9.6203" y2="-6.9786" layer="94"/>
<rectangle x1="10.0775" y1="-6.9913" x2="10.3823" y2="-6.9786" layer="94"/>
<rectangle x1="11.1316" y1="-6.9913" x2="11.4491" y2="-6.9786" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9786" x2="-11.0807" y2="-6.9659" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9786" x2="-10.0012" y2="-6.9659" layer="94"/>
<rectangle x1="-9.544" y1="-6.9786" x2="-9.163" y2="-6.9659" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9786" x2="-8.0835" y2="-6.9659" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9786" x2="-7.2707" y2="-6.9659" layer="94"/>
<rectangle x1="-6.7881" y1="-6.9786" x2="-6.1912" y2="-6.9659" layer="94"/>
<rectangle x1="-5.734" y1="-6.9786" x2="-5.3403" y2="-6.9659" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9786" x2="-4.2481" y2="-6.9659" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9786" x2="-2.3177" y2="-6.9659" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9786" x2="-1.2509" y2="-6.9659" layer="94"/>
<rectangle x1="-0.7937" y1="-6.9786" x2="-0.5143" y2="-6.9659" layer="94"/>
<rectangle x1="0.2731" y1="-6.9786" x2="0.5779" y2="-6.9659" layer="94"/>
<rectangle x1="1.0224" y1="-6.9786" x2="1.3145" y2="-6.9659" layer="94"/>
<rectangle x1="2.1019" y1="-6.9786" x2="2.3686" y2="-6.9659" layer="94"/>
<rectangle x1="2.8258" y1="-6.9786" x2="3.1179" y2="-6.9659" layer="94"/>
<rectangle x1="3.8926" y1="-6.9786" x2="4.1974" y2="-6.9659" layer="94"/>
<rectangle x1="4.4768" y1="-6.9786" x2="4.7562" y2="-6.9659" layer="94"/>
<rectangle x1="5.188" y1="-6.9786" x2="5.4674" y2="-6.9659" layer="94"/>
<rectangle x1="5.8992" y1="-6.9786" x2="6.1659" y2="-6.9659" layer="94"/>
<rectangle x1="6.458" y1="-6.9786" x2="6.7501" y2="-6.9659" layer="94"/>
<rectangle x1="7.5375" y1="-6.9786" x2="7.8042" y2="-6.9659" layer="94"/>
<rectangle x1="8.2741" y1="-6.9786" x2="8.5408" y2="-6.9659" layer="94"/>
<rectangle x1="9.3409" y1="-6.9786" x2="9.633" y2="-6.9659" layer="94"/>
<rectangle x1="10.0775" y1="-6.9786" x2="10.3823" y2="-6.9659" layer="94"/>
<rectangle x1="11.1443" y1="-6.9786" x2="11.4491" y2="-6.9659" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9659" x2="-11.0807" y2="-6.9532" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9659" x2="-10.0012" y2="-6.9532" layer="94"/>
<rectangle x1="-9.544" y1="-6.9659" x2="-9.163" y2="-6.9532" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9659" x2="-8.0835" y2="-6.9532" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9659" x2="-7.2707" y2="-6.9532" layer="94"/>
<rectangle x1="-6.7754" y1="-6.9659" x2="-6.1912" y2="-6.9532" layer="94"/>
<rectangle x1="-5.734" y1="-6.9659" x2="-5.3403" y2="-6.9532" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9659" x2="-4.2481" y2="-6.9532" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9659" x2="-2.305" y2="-6.9532" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9659" x2="-1.2509" y2="-6.9532" layer="94"/>
<rectangle x1="-0.7937" y1="-6.9659" x2="-0.5143" y2="-6.9532" layer="94"/>
<rectangle x1="0.2731" y1="-6.9659" x2="0.5779" y2="-6.9532" layer="94"/>
<rectangle x1="1.0224" y1="-6.9659" x2="1.3145" y2="-6.9532" layer="94"/>
<rectangle x1="2.1019" y1="-6.9659" x2="2.3686" y2="-6.9532" layer="94"/>
<rectangle x1="2.8258" y1="-6.9659" x2="3.1179" y2="-6.9532" layer="94"/>
<rectangle x1="3.8926" y1="-6.9659" x2="4.1974" y2="-6.9532" layer="94"/>
<rectangle x1="4.4768" y1="-6.9659" x2="4.7562" y2="-6.9532" layer="94"/>
<rectangle x1="5.188" y1="-6.9659" x2="5.4674" y2="-6.9532" layer="94"/>
<rectangle x1="5.8992" y1="-6.9659" x2="6.1659" y2="-6.9532" layer="94"/>
<rectangle x1="6.458" y1="-6.9659" x2="6.7501" y2="-6.9532" layer="94"/>
<rectangle x1="7.5375" y1="-6.9659" x2="7.8042" y2="-6.9532" layer="94"/>
<rectangle x1="8.2741" y1="-6.9659" x2="8.5408" y2="-6.9532" layer="94"/>
<rectangle x1="9.3409" y1="-6.9659" x2="9.633" y2="-6.9532" layer="94"/>
<rectangle x1="10.0775" y1="-6.9659" x2="10.3823" y2="-6.9532" layer="94"/>
<rectangle x1="11.157" y1="-6.9659" x2="11.4491" y2="-6.9532" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9532" x2="-11.0807" y2="-6.9405" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9532" x2="-10.0012" y2="-6.9405" layer="94"/>
<rectangle x1="-9.544" y1="-6.9532" x2="-9.163" y2="-6.9405" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9532" x2="-8.0835" y2="-6.9405" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9532" x2="-7.258" y2="-6.9405" layer="94"/>
<rectangle x1="-6.7627" y1="-6.9532" x2="-6.1912" y2="-6.9405" layer="94"/>
<rectangle x1="-5.734" y1="-6.9532" x2="-5.3403" y2="-6.9405" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9532" x2="-4.2481" y2="-6.9405" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9532" x2="-2.305" y2="-6.9405" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9532" x2="-1.2509" y2="-6.9405" layer="94"/>
<rectangle x1="-0.781" y1="-6.9532" x2="-0.5143" y2="-6.9405" layer="94"/>
<rectangle x1="0.2731" y1="-6.9532" x2="0.5779" y2="-6.9405" layer="94"/>
<rectangle x1="1.0224" y1="-6.9532" x2="1.3272" y2="-6.9405" layer="94"/>
<rectangle x1="2.1019" y1="-6.9532" x2="2.3813" y2="-6.9405" layer="94"/>
<rectangle x1="2.8258" y1="-6.9532" x2="3.1179" y2="-6.9405" layer="94"/>
<rectangle x1="3.8926" y1="-6.9532" x2="4.1974" y2="-6.9405" layer="94"/>
<rectangle x1="4.4768" y1="-6.9532" x2="4.7562" y2="-6.9405" layer="94"/>
<rectangle x1="5.188" y1="-6.9532" x2="5.4674" y2="-6.9405" layer="94"/>
<rectangle x1="5.8992" y1="-6.9532" x2="6.1659" y2="-6.9405" layer="94"/>
<rectangle x1="6.458" y1="-6.9532" x2="6.7501" y2="-6.9405" layer="94"/>
<rectangle x1="7.5375" y1="-6.9532" x2="7.8042" y2="-6.9405" layer="94"/>
<rectangle x1="8.2741" y1="-6.9532" x2="8.5535" y2="-6.9405" layer="94"/>
<rectangle x1="9.3282" y1="-6.9532" x2="9.633" y2="-6.9405" layer="94"/>
<rectangle x1="10.0775" y1="-6.9532" x2="10.3823" y2="-6.9405" layer="94"/>
<rectangle x1="11.157" y1="-6.9532" x2="11.4364" y2="-6.9405" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9405" x2="-11.0807" y2="-6.9278" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9405" x2="-10.0012" y2="-6.9278" layer="94"/>
<rectangle x1="-9.544" y1="-6.9405" x2="-9.163" y2="-6.9278" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9405" x2="-8.0835" y2="-6.9278" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9405" x2="-7.258" y2="-6.9278" layer="94"/>
<rectangle x1="-6.7373" y1="-6.9405" x2="-6.1912" y2="-6.9278" layer="94"/>
<rectangle x1="-5.734" y1="-6.9405" x2="-5.3403" y2="-6.9278" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9405" x2="-4.2481" y2="-6.9278" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9405" x2="-2.305" y2="-6.9278" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9405" x2="-1.2509" y2="-6.9278" layer="94"/>
<rectangle x1="-0.781" y1="-6.9405" x2="-0.5143" y2="-6.9278" layer="94"/>
<rectangle x1="0.2731" y1="-6.9405" x2="0.5779" y2="-6.9278" layer="94"/>
<rectangle x1="1.0224" y1="-6.9405" x2="1.3272" y2="-6.9278" layer="94"/>
<rectangle x1="2.1019" y1="-6.9405" x2="2.3813" y2="-6.9278" layer="94"/>
<rectangle x1="2.8258" y1="-6.9405" x2="3.1179" y2="-6.9278" layer="94"/>
<rectangle x1="3.8926" y1="-6.9405" x2="4.1974" y2="-6.9278" layer="94"/>
<rectangle x1="4.4768" y1="-6.9405" x2="4.7562" y2="-6.9278" layer="94"/>
<rectangle x1="5.188" y1="-6.9405" x2="5.4674" y2="-6.9278" layer="94"/>
<rectangle x1="5.8992" y1="-6.9405" x2="6.1659" y2="-6.9278" layer="94"/>
<rectangle x1="6.458" y1="-6.9405" x2="6.7501" y2="-6.9278" layer="94"/>
<rectangle x1="7.5375" y1="-6.9405" x2="7.8042" y2="-6.9278" layer="94"/>
<rectangle x1="8.2741" y1="-6.9405" x2="8.5535" y2="-6.9278" layer="94"/>
<rectangle x1="9.3282" y1="-6.9405" x2="9.633" y2="-6.9278" layer="94"/>
<rectangle x1="10.0775" y1="-6.9405" x2="10.3823" y2="-6.9278" layer="94"/>
<rectangle x1="11.157" y1="-6.9405" x2="11.4364" y2="-6.9278" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9278" x2="-11.0807" y2="-6.9151" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9278" x2="-10.0012" y2="-6.9151" layer="94"/>
<rectangle x1="-9.544" y1="-6.9278" x2="-9.163" y2="-6.9151" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9278" x2="-8.0835" y2="-6.9151" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9278" x2="-7.258" y2="-6.9151" layer="94"/>
<rectangle x1="-6.6738" y1="-6.9278" x2="-6.1912" y2="-6.9151" layer="94"/>
<rectangle x1="-5.734" y1="-6.9278" x2="-5.3403" y2="-6.9151" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9278" x2="-4.2481" y2="-6.9151" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9278" x2="-2.305" y2="-6.9151" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9278" x2="-1.2509" y2="-6.9151" layer="94"/>
<rectangle x1="-0.781" y1="-6.9278" x2="-0.5016" y2="-6.9151" layer="94"/>
<rectangle x1="0.2731" y1="-6.9278" x2="0.5779" y2="-6.9151" layer="94"/>
<rectangle x1="1.0224" y1="-6.9278" x2="1.3272" y2="-6.9151" layer="94"/>
<rectangle x1="2.0892" y1="-6.9278" x2="2.3686" y2="-6.9151" layer="94"/>
<rectangle x1="2.8385" y1="-6.9278" x2="3.1179" y2="-6.9151" layer="94"/>
<rectangle x1="3.8926" y1="-6.9278" x2="4.1974" y2="-6.9151" layer="94"/>
<rectangle x1="4.4768" y1="-6.9278" x2="4.7562" y2="-6.9151" layer="94"/>
<rectangle x1="5.188" y1="-6.9278" x2="5.4674" y2="-6.9151" layer="94"/>
<rectangle x1="5.8992" y1="-6.9278" x2="6.1659" y2="-6.9151" layer="94"/>
<rectangle x1="6.458" y1="-6.9278" x2="6.7628" y2="-6.9151" layer="94"/>
<rectangle x1="7.5375" y1="-6.9278" x2="7.8042" y2="-6.9151" layer="94"/>
<rectangle x1="8.2741" y1="-6.9278" x2="8.5535" y2="-6.9151" layer="94"/>
<rectangle x1="9.3282" y1="-6.9278" x2="9.633" y2="-6.9151" layer="94"/>
<rectangle x1="10.0775" y1="-6.9278" x2="10.3823" y2="-6.9151" layer="94"/>
<rectangle x1="11.1443" y1="-6.9278" x2="11.4364" y2="-6.9151" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9151" x2="-11.0807" y2="-6.9024" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9151" x2="-10.0012" y2="-6.9024" layer="94"/>
<rectangle x1="-9.544" y1="-6.9151" x2="-9.163" y2="-6.9024" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9151" x2="-8.0835" y2="-6.9024" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9151" x2="-7.258" y2="-6.9024" layer="94"/>
<rectangle x1="-6.6357" y1="-6.9151" x2="-6.1912" y2="-6.9024" layer="94"/>
<rectangle x1="-5.734" y1="-6.9151" x2="-5.3403" y2="-6.9024" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9151" x2="-4.2481" y2="-6.9024" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9151" x2="-2.305" y2="-6.9024" layer="94"/>
<rectangle x1="-1.5303" y1="-6.9151" x2="-1.2509" y2="-6.9024" layer="94"/>
<rectangle x1="-0.781" y1="-6.9151" x2="-0.5016" y2="-6.9024" layer="94"/>
<rectangle x1="0.2604" y1="-6.9151" x2="0.5779" y2="-6.9024" layer="94"/>
<rectangle x1="1.0224" y1="-6.9151" x2="1.3272" y2="-6.9024" layer="94"/>
<rectangle x1="2.0892" y1="-6.9151" x2="2.3686" y2="-6.9024" layer="94"/>
<rectangle x1="2.8385" y1="-6.9151" x2="3.1306" y2="-6.9024" layer="94"/>
<rectangle x1="3.8926" y1="-6.9151" x2="4.1974" y2="-6.9024" layer="94"/>
<rectangle x1="4.4768" y1="-6.9151" x2="4.7562" y2="-6.9024" layer="94"/>
<rectangle x1="5.188" y1="-6.9151" x2="5.4674" y2="-6.9024" layer="94"/>
<rectangle x1="5.8992" y1="-6.9151" x2="6.1659" y2="-6.9024" layer="94"/>
<rectangle x1="6.458" y1="-6.9151" x2="6.7628" y2="-6.9024" layer="94"/>
<rectangle x1="7.5248" y1="-6.9151" x2="7.8042" y2="-6.9024" layer="94"/>
<rectangle x1="8.2868" y1="-6.9151" x2="8.5535" y2="-6.9024" layer="94"/>
<rectangle x1="9.3282" y1="-6.9151" x2="9.633" y2="-6.9024" layer="94"/>
<rectangle x1="10.0775" y1="-6.9151" x2="10.3823" y2="-6.9024" layer="94"/>
<rectangle x1="11.1443" y1="-6.9151" x2="11.4364" y2="-6.9024" layer="94"/>
<rectangle x1="-11.4617" y1="-6.9024" x2="-11.0807" y2="-6.8897" layer="94"/>
<rectangle x1="-10.3949" y1="-6.9024" x2="-10.0012" y2="-6.8897" layer="94"/>
<rectangle x1="-9.544" y1="-6.9024" x2="-9.163" y2="-6.8897" layer="94"/>
<rectangle x1="-8.4645" y1="-6.9024" x2="-8.0835" y2="-6.8897" layer="94"/>
<rectangle x1="-7.6263" y1="-6.9024" x2="-7.2453" y2="-6.8897" layer="94"/>
<rectangle x1="-6.623" y1="-6.9024" x2="-6.1912" y2="-6.8897" layer="94"/>
<rectangle x1="-5.734" y1="-6.9024" x2="-5.3403" y2="-6.8897" layer="94"/>
<rectangle x1="-4.6545" y1="-6.9024" x2="-4.2481" y2="-6.8897" layer="94"/>
<rectangle x1="-2.5971" y1="-6.9024" x2="-2.305" y2="-6.8897" layer="94"/>
<rectangle x1="-1.543" y1="-6.9024" x2="-1.2509" y2="-6.8897" layer="94"/>
<rectangle x1="-0.781" y1="-6.9024" x2="-0.5016" y2="-6.8897" layer="94"/>
<rectangle x1="0.2604" y1="-6.9024" x2="0.5652" y2="-6.8897" layer="94"/>
<rectangle x1="1.0224" y1="-6.9024" x2="1.3272" y2="-6.8897" layer="94"/>
<rectangle x1="2.0765" y1="-6.9024" x2="2.3686" y2="-6.8897" layer="94"/>
<rectangle x1="2.8385" y1="-6.9024" x2="3.1306" y2="-6.8897" layer="94"/>
<rectangle x1="3.8926" y1="-6.9024" x2="4.1974" y2="-6.8897" layer="94"/>
<rectangle x1="4.4768" y1="-6.9024" x2="4.7562" y2="-6.8897" layer="94"/>
<rectangle x1="5.188" y1="-6.9024" x2="5.4674" y2="-6.8897" layer="94"/>
<rectangle x1="5.8992" y1="-6.9024" x2="6.1659" y2="-6.8897" layer="94"/>
<rectangle x1="6.458" y1="-6.9024" x2="6.7628" y2="-6.8897" layer="94"/>
<rectangle x1="7.5248" y1="-6.9024" x2="7.8042" y2="-6.8897" layer="94"/>
<rectangle x1="8.2868" y1="-6.9024" x2="8.5662" y2="-6.8897" layer="94"/>
<rectangle x1="9.3282" y1="-6.9024" x2="9.633" y2="-6.8897" layer="94"/>
<rectangle x1="10.0775" y1="-6.9024" x2="10.395" y2="-6.8897" layer="94"/>
<rectangle x1="11.1443" y1="-6.9024" x2="11.4237" y2="-6.8897" layer="94"/>
<rectangle x1="-11.4617" y1="-6.8897" x2="-11.0807" y2="-6.877" layer="94"/>
<rectangle x1="-10.3949" y1="-6.8897" x2="-10.0012" y2="-6.877" layer="94"/>
<rectangle x1="-9.544" y1="-6.8897" x2="-9.163" y2="-6.877" layer="94"/>
<rectangle x1="-8.4772" y1="-6.8897" x2="-8.0835" y2="-6.877" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8897" x2="-7.2453" y2="-6.877" layer="94"/>
<rectangle x1="-6.6103" y1="-6.8897" x2="-6.1912" y2="-6.877" layer="94"/>
<rectangle x1="-5.734" y1="-6.8897" x2="-5.3403" y2="-6.877" layer="94"/>
<rectangle x1="-4.6545" y1="-6.8897" x2="-4.2481" y2="-6.877" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8897" x2="-2.305" y2="-6.877" layer="94"/>
<rectangle x1="-1.543" y1="-6.8897" x2="-1.2509" y2="-6.877" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8897" x2="-0.4889" y2="-6.877" layer="94"/>
<rectangle x1="0.2604" y1="-6.8897" x2="0.5652" y2="-6.877" layer="94"/>
<rectangle x1="1.0224" y1="-6.8897" x2="1.3272" y2="-6.877" layer="94"/>
<rectangle x1="2.0765" y1="-6.8897" x2="2.3686" y2="-6.877" layer="94"/>
<rectangle x1="2.8512" y1="-6.8897" x2="3.1306" y2="-6.877" layer="94"/>
<rectangle x1="3.8926" y1="-6.8897" x2="4.1974" y2="-6.877" layer="94"/>
<rectangle x1="4.4768" y1="-6.8897" x2="4.7562" y2="-6.877" layer="94"/>
<rectangle x1="5.188" y1="-6.8897" x2="5.4674" y2="-6.877" layer="94"/>
<rectangle x1="5.8992" y1="-6.8897" x2="6.1659" y2="-6.877" layer="94"/>
<rectangle x1="6.4707" y1="-6.8897" x2="6.7628" y2="-6.877" layer="94"/>
<rectangle x1="7.5248" y1="-6.8897" x2="7.8042" y2="-6.877" layer="94"/>
<rectangle x1="8.2868" y1="-6.8897" x2="8.5662" y2="-6.877" layer="94"/>
<rectangle x1="9.3155" y1="-6.8897" x2="9.633" y2="-6.877" layer="94"/>
<rectangle x1="10.0775" y1="-6.8897" x2="10.395" y2="-6.877" layer="94"/>
<rectangle x1="11.1316" y1="-6.8897" x2="11.4237" y2="-6.877" layer="94"/>
<rectangle x1="-11.4617" y1="-6.877" x2="-11.0807" y2="-6.8643" layer="94"/>
<rectangle x1="-10.3949" y1="-6.877" x2="-10.0012" y2="-6.8643" layer="94"/>
<rectangle x1="-9.544" y1="-6.877" x2="-9.163" y2="-6.8643" layer="94"/>
<rectangle x1="-8.4772" y1="-6.877" x2="-8.0835" y2="-6.8643" layer="94"/>
<rectangle x1="-7.6263" y1="-6.877" x2="-7.2326" y2="-6.8643" layer="94"/>
<rectangle x1="-6.6103" y1="-6.877" x2="-6.1912" y2="-6.8643" layer="94"/>
<rectangle x1="-5.734" y1="-6.877" x2="-5.3403" y2="-6.8643" layer="94"/>
<rectangle x1="-4.6545" y1="-6.877" x2="-4.2481" y2="-6.8643" layer="94"/>
<rectangle x1="-2.5971" y1="-6.877" x2="-2.2923" y2="-6.8643" layer="94"/>
<rectangle x1="-1.543" y1="-6.877" x2="-1.2636" y2="-6.8643" layer="94"/>
<rectangle x1="-0.7683" y1="-6.877" x2="-0.4889" y2="-6.8643" layer="94"/>
<rectangle x1="0.2604" y1="-6.877" x2="0.5652" y2="-6.8643" layer="94"/>
<rectangle x1="1.0224" y1="-6.877" x2="1.3399" y2="-6.8643" layer="94"/>
<rectangle x1="2.0638" y1="-6.877" x2="2.3686" y2="-6.8643" layer="94"/>
<rectangle x1="2.8512" y1="-6.877" x2="3.1306" y2="-6.8643" layer="94"/>
<rectangle x1="3.8926" y1="-6.877" x2="4.1974" y2="-6.8643" layer="94"/>
<rectangle x1="4.4768" y1="-6.877" x2="4.7562" y2="-6.8643" layer="94"/>
<rectangle x1="5.188" y1="-6.877" x2="5.4674" y2="-6.8643" layer="94"/>
<rectangle x1="5.8992" y1="-6.877" x2="6.1659" y2="-6.8643" layer="94"/>
<rectangle x1="6.4707" y1="-6.877" x2="6.7628" y2="-6.8643" layer="94"/>
<rectangle x1="7.5121" y1="-6.877" x2="7.8042" y2="-6.8643" layer="94"/>
<rectangle x1="8.2868" y1="-6.877" x2="8.5789" y2="-6.8643" layer="94"/>
<rectangle x1="9.3155" y1="-6.877" x2="9.633" y2="-6.8643" layer="94"/>
<rectangle x1="10.0902" y1="-6.877" x2="10.395" y2="-6.8643" layer="94"/>
<rectangle x1="11.1316" y1="-6.877" x2="11.4237" y2="-6.8643" layer="94"/>
<rectangle x1="-11.449" y1="-6.8643" x2="-11.068" y2="-6.8516" layer="94"/>
<rectangle x1="-10.3949" y1="-6.8643" x2="-10.0012" y2="-6.8516" layer="94"/>
<rectangle x1="-9.544" y1="-6.8643" x2="-9.163" y2="-6.8516" layer="94"/>
<rectangle x1="-8.4772" y1="-6.8643" x2="-8.0835" y2="-6.8516" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8643" x2="-7.2326" y2="-6.8516" layer="94"/>
<rectangle x1="-6.5976" y1="-6.8643" x2="-6.1912" y2="-6.8516" layer="94"/>
<rectangle x1="-5.734" y1="-6.8643" x2="-5.3403" y2="-6.8516" layer="94"/>
<rectangle x1="-4.6545" y1="-6.8643" x2="-4.2481" y2="-6.8516" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8643" x2="-2.2923" y2="-6.8516" layer="94"/>
<rectangle x1="-1.5557" y1="-6.8643" x2="-1.2636" y2="-6.8516" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8643" x2="-0.4762" y2="-6.8516" layer="94"/>
<rectangle x1="0.2477" y1="-6.8643" x2="0.5652" y2="-6.8516" layer="94"/>
<rectangle x1="1.0224" y1="-6.8643" x2="1.3399" y2="-6.8516" layer="94"/>
<rectangle x1="2.0638" y1="-6.8643" x2="2.3686" y2="-6.8516" layer="94"/>
<rectangle x1="2.8512" y1="-6.8643" x2="3.1433" y2="-6.8516" layer="94"/>
<rectangle x1="3.8926" y1="-6.8643" x2="4.1974" y2="-6.8516" layer="94"/>
<rectangle x1="4.4768" y1="-6.8643" x2="4.7562" y2="-6.8516" layer="94"/>
<rectangle x1="5.188" y1="-6.8643" x2="5.4674" y2="-6.8516" layer="94"/>
<rectangle x1="5.8992" y1="-6.8643" x2="6.1659" y2="-6.8516" layer="94"/>
<rectangle x1="6.4707" y1="-6.8643" x2="6.7628" y2="-6.8516" layer="94"/>
<rectangle x1="7.5121" y1="-6.8643" x2="7.8042" y2="-6.8516" layer="94"/>
<rectangle x1="8.2868" y1="-6.8643" x2="8.5789" y2="-6.8516" layer="94"/>
<rectangle x1="9.3155" y1="-6.8643" x2="9.633" y2="-6.8516" layer="94"/>
<rectangle x1="10.0902" y1="-6.8643" x2="10.395" y2="-6.8516" layer="94"/>
<rectangle x1="11.1189" y1="-6.8643" x2="11.4237" y2="-6.8516" layer="94"/>
<rectangle x1="-11.449" y1="-6.8516" x2="-11.068" y2="-6.8389" layer="94"/>
<rectangle x1="-10.3949" y1="-6.8516" x2="-10.0012" y2="-6.8389" layer="94"/>
<rectangle x1="-9.544" y1="-6.8516" x2="-9.1503" y2="-6.8389" layer="94"/>
<rectangle x1="-8.4772" y1="-6.8516" x2="-8.0835" y2="-6.8389" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8516" x2="-7.2326" y2="-6.8389" layer="94"/>
<rectangle x1="-6.5976" y1="-6.8516" x2="-6.1912" y2="-6.8389" layer="94"/>
<rectangle x1="-5.7213" y1="-6.8516" x2="-5.3403" y2="-6.8389" layer="94"/>
<rectangle x1="-4.6545" y1="-6.8516" x2="-4.2481" y2="-6.8389" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8516" x2="-2.2923" y2="-6.8389" layer="94"/>
<rectangle x1="-1.5684" y1="-6.8516" x2="-1.2636" y2="-6.8389" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8516" x2="-0.4635" y2="-6.8389" layer="94"/>
<rectangle x1="0.2477" y1="-6.8516" x2="0.5652" y2="-6.8389" layer="94"/>
<rectangle x1="1.0224" y1="-6.8516" x2="1.3399" y2="-6.8389" layer="94"/>
<rectangle x1="2.0511" y1="-6.8516" x2="2.3559" y2="-6.8389" layer="94"/>
<rectangle x1="2.8639" y1="-6.8516" x2="3.156" y2="-6.8389" layer="94"/>
<rectangle x1="3.8799" y1="-6.8516" x2="4.1974" y2="-6.8389" layer="94"/>
<rectangle x1="4.4768" y1="-6.8516" x2="4.7562" y2="-6.8389" layer="94"/>
<rectangle x1="5.188" y1="-6.8516" x2="5.4674" y2="-6.8389" layer="94"/>
<rectangle x1="5.8992" y1="-6.8516" x2="6.1659" y2="-6.8389" layer="94"/>
<rectangle x1="6.4834" y1="-6.8516" x2="6.7755" y2="-6.8389" layer="94"/>
<rectangle x1="7.4994" y1="-6.8516" x2="7.8042" y2="-6.8389" layer="94"/>
<rectangle x1="8.2995" y1="-6.8516" x2="8.5916" y2="-6.8389" layer="94"/>
<rectangle x1="9.3155" y1="-6.8516" x2="9.6203" y2="-6.8389" layer="94"/>
<rectangle x1="10.0902" y1="-6.8516" x2="10.395" y2="-6.8389" layer="94"/>
<rectangle x1="11.1189" y1="-6.8516" x2="11.4237" y2="-6.8389" layer="94"/>
<rectangle x1="-11.449" y1="-6.8389" x2="-11.0553" y2="-6.8262" layer="94"/>
<rectangle x1="-10.4076" y1="-6.8389" x2="-10.0012" y2="-6.8262" layer="94"/>
<rectangle x1="-9.544" y1="-6.8389" x2="-9.1503" y2="-6.8262" layer="94"/>
<rectangle x1="-8.4772" y1="-6.8389" x2="-8.0835" y2="-6.8262" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8389" x2="-7.2199" y2="-6.8262" layer="94"/>
<rectangle x1="-6.5976" y1="-6.8389" x2="-6.1912" y2="-6.8262" layer="94"/>
<rectangle x1="-5.7213" y1="-6.8389" x2="-5.3276" y2="-6.8262" layer="94"/>
<rectangle x1="-4.6545" y1="-6.8389" x2="-4.2608" y2="-6.8262" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8389" x2="-2.2796" y2="-6.8262" layer="94"/>
<rectangle x1="-1.5811" y1="-6.8389" x2="-1.2636" y2="-6.8262" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8389" x2="-0.4635" y2="-6.8262" layer="94"/>
<rectangle x1="0.2477" y1="-6.8389" x2="0.5652" y2="-6.8262" layer="94"/>
<rectangle x1="1.0351" y1="-6.8389" x2="1.3399" y2="-6.8262" layer="94"/>
<rectangle x1="2.0511" y1="-6.8389" x2="2.3559" y2="-6.8262" layer="94"/>
<rectangle x1="2.8639" y1="-6.8389" x2="3.1687" y2="-6.8262" layer="94"/>
<rectangle x1="3.8672" y1="-6.8389" x2="4.1974" y2="-6.8262" layer="94"/>
<rectangle x1="4.4768" y1="-6.8389" x2="4.7562" y2="-6.8262" layer="94"/>
<rectangle x1="5.188" y1="-6.8389" x2="5.4674" y2="-6.8262" layer="94"/>
<rectangle x1="5.8992" y1="-6.8389" x2="6.1659" y2="-6.8262" layer="94"/>
<rectangle x1="6.4834" y1="-6.8389" x2="6.7755" y2="-6.8262" layer="94"/>
<rectangle x1="7.4867" y1="-6.8389" x2="7.7915" y2="-6.8262" layer="94"/>
<rectangle x1="8.2995" y1="-6.8389" x2="8.6043" y2="-6.8262" layer="94"/>
<rectangle x1="9.3028" y1="-6.8389" x2="9.6203" y2="-6.8262" layer="94"/>
<rectangle x1="10.0902" y1="-6.8389" x2="10.4077" y2="-6.8262" layer="94"/>
<rectangle x1="11.1062" y1="-6.8389" x2="11.4237" y2="-6.8262" layer="94"/>
<rectangle x1="-11.449" y1="-6.8262" x2="-11.0553" y2="-6.8135" layer="94"/>
<rectangle x1="-10.4076" y1="-6.8262" x2="-10.0012" y2="-6.8135" layer="94"/>
<rectangle x1="-9.544" y1="-6.8262" x2="-9.1503" y2="-6.8135" layer="94"/>
<rectangle x1="-8.4772" y1="-6.8262" x2="-8.0835" y2="-6.8135" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8262" x2="-7.2199" y2="-6.8135" layer="94"/>
<rectangle x1="-6.5976" y1="-6.8262" x2="-6.1912" y2="-6.8135" layer="94"/>
<rectangle x1="-5.7213" y1="-6.8262" x2="-5.3276" y2="-6.8135" layer="94"/>
<rectangle x1="-4.6545" y1="-6.8262" x2="-4.2608" y2="-6.8135" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8262" x2="-2.2796" y2="-6.8135" layer="94"/>
<rectangle x1="-1.5811" y1="-6.8262" x2="-1.2763" y2="-6.8135" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8262" x2="-0.4508" y2="-6.8135" layer="94"/>
<rectangle x1="0.235" y1="-6.8262" x2="0.5525" y2="-6.8135" layer="94"/>
<rectangle x1="1.0351" y1="-6.8262" x2="1.3526" y2="-6.8135" layer="94"/>
<rectangle x1="2.0384" y1="-6.8262" x2="2.3559" y2="-6.8135" layer="94"/>
<rectangle x1="2.8639" y1="-6.8262" x2="3.1814" y2="-6.8135" layer="94"/>
<rectangle x1="3.8672" y1="-6.8262" x2="4.1974" y2="-6.8135" layer="94"/>
<rectangle x1="4.4768" y1="-6.8262" x2="4.7562" y2="-6.8135" layer="94"/>
<rectangle x1="5.188" y1="-6.8262" x2="5.4674" y2="-6.8135" layer="94"/>
<rectangle x1="5.8992" y1="-6.8262" x2="6.1659" y2="-6.8135" layer="94"/>
<rectangle x1="6.4961" y1="-6.8262" x2="6.7882" y2="-6.8135" layer="94"/>
<rectangle x1="7.4867" y1="-6.8262" x2="7.7915" y2="-6.8135" layer="94"/>
<rectangle x1="8.2995" y1="-6.8262" x2="8.6043" y2="-6.8135" layer="94"/>
<rectangle x1="9.3028" y1="-6.8262" x2="9.6203" y2="-6.8135" layer="94"/>
<rectangle x1="10.0902" y1="-6.8262" x2="10.4077" y2="-6.8135" layer="94"/>
<rectangle x1="11.1062" y1="-6.8262" x2="11.4237" y2="-6.8135" layer="94"/>
<rectangle x1="-11.449" y1="-6.8135" x2="-11.0553" y2="-6.8008" layer="94"/>
<rectangle x1="-10.4076" y1="-6.8135" x2="-10.0012" y2="-6.8008" layer="94"/>
<rectangle x1="-9.544" y1="-6.8135" x2="-9.1503" y2="-6.8008" layer="94"/>
<rectangle x1="-8.4899" y1="-6.8135" x2="-8.0835" y2="-6.8008" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8135" x2="-7.2199" y2="-6.8008" layer="94"/>
<rectangle x1="-6.5976" y1="-6.8135" x2="-6.1912" y2="-6.8008" layer="94"/>
<rectangle x1="-5.7213" y1="-6.8135" x2="-5.3276" y2="-6.8008" layer="94"/>
<rectangle x1="-4.6672" y1="-6.8135" x2="-4.2608" y2="-6.8008" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8135" x2="-2.2669" y2="-6.8008" layer="94"/>
<rectangle x1="-1.5938" y1="-6.8135" x2="-1.2763" y2="-6.8008" layer="94"/>
<rectangle x1="-0.7683" y1="-6.8135" x2="-0.4508" y2="-6.8008" layer="94"/>
<rectangle x1="0.235" y1="-6.8135" x2="0.5525" y2="-6.8008" layer="94"/>
<rectangle x1="1.0351" y1="-6.8135" x2="1.3526" y2="-6.8008" layer="94"/>
<rectangle x1="2.0384" y1="-6.8135" x2="2.3559" y2="-6.8008" layer="94"/>
<rectangle x1="2.8639" y1="-6.8135" x2="3.1814" y2="-6.8008" layer="94"/>
<rectangle x1="3.8545" y1="-6.8135" x2="4.1974" y2="-6.8008" layer="94"/>
<rectangle x1="4.4768" y1="-6.8135" x2="4.7562" y2="-6.8008" layer="94"/>
<rectangle x1="5.188" y1="-6.8135" x2="5.4674" y2="-6.8008" layer="94"/>
<rectangle x1="5.8992" y1="-6.8135" x2="6.1659" y2="-6.8008" layer="94"/>
<rectangle x1="6.4961" y1="-6.8135" x2="6.8009" y2="-6.8008" layer="94"/>
<rectangle x1="7.474" y1="-6.8135" x2="7.7915" y2="-6.8008" layer="94"/>
<rectangle x1="8.2995" y1="-6.8135" x2="8.617" y2="-6.8008" layer="94"/>
<rectangle x1="9.3028" y1="-6.8135" x2="9.6203" y2="-6.8008" layer="94"/>
<rectangle x1="10.1029" y1="-6.8135" x2="10.4204" y2="-6.8008" layer="94"/>
<rectangle x1="11.0935" y1="-6.8135" x2="11.4237" y2="-6.8008" layer="94"/>
<rectangle x1="-11.449" y1="-6.8008" x2="-11.0426" y2="-6.7881" layer="94"/>
<rectangle x1="-10.4076" y1="-6.8008" x2="-10.0012" y2="-6.7881" layer="94"/>
<rectangle x1="-9.544" y1="-6.8008" x2="-9.1376" y2="-6.7881" layer="94"/>
<rectangle x1="-8.4899" y1="-6.8008" x2="-8.0835" y2="-6.7881" layer="94"/>
<rectangle x1="-7.6263" y1="-6.8008" x2="-7.2199" y2="-6.7881" layer="94"/>
<rectangle x1="-6.6103" y1="-6.8008" x2="-6.1912" y2="-6.7881" layer="94"/>
<rectangle x1="-5.7086" y1="-6.8008" x2="-5.3149" y2="-6.7881" layer="94"/>
<rectangle x1="-4.6672" y1="-6.8008" x2="-4.2608" y2="-6.7881" layer="94"/>
<rectangle x1="-2.5971" y1="-6.8008" x2="-2.2542" y2="-6.7881" layer="94"/>
<rectangle x1="-1.5938" y1="-6.8008" x2="-1.2763" y2="-6.7881" layer="94"/>
<rectangle x1="-0.7556" y1="-6.8008" x2="-0.4381" y2="-6.7881" layer="94"/>
<rectangle x1="0.2223" y1="-6.8008" x2="0.5398" y2="-6.7881" layer="94"/>
<rectangle x1="1.0478" y1="-6.8008" x2="1.3653" y2="-6.7881" layer="94"/>
<rectangle x1="2.0257" y1="-6.8008" x2="2.3559" y2="-6.7881" layer="94"/>
<rectangle x1="2.8639" y1="-6.8008" x2="3.1941" y2="-6.7881" layer="94"/>
<rectangle x1="3.8418" y1="-6.8008" x2="4.1974" y2="-6.7881" layer="94"/>
<rectangle x1="4.4768" y1="-6.8008" x2="4.7562" y2="-6.7881" layer="94"/>
<rectangle x1="5.188" y1="-6.8008" x2="5.4674" y2="-6.7881" layer="94"/>
<rectangle x1="5.8992" y1="-6.8008" x2="6.1659" y2="-6.7881" layer="94"/>
<rectangle x1="6.4961" y1="-6.8008" x2="6.8136" y2="-6.7881" layer="94"/>
<rectangle x1="7.4613" y1="-6.8008" x2="7.7915" y2="-6.7881" layer="94"/>
<rectangle x1="8.2995" y1="-6.8008" x2="8.617" y2="-6.7881" layer="94"/>
<rectangle x1="9.2901" y1="-6.8008" x2="9.6076" y2="-6.7881" layer="94"/>
<rectangle x1="10.1029" y1="-6.8008" x2="10.4204" y2="-6.7881" layer="94"/>
<rectangle x1="11.0935" y1="-6.8008" x2="11.4237" y2="-6.7881" layer="94"/>
<rectangle x1="-11.449" y1="-6.7881" x2="-11.0426" y2="-6.7754" layer="94"/>
<rectangle x1="-10.4203" y1="-6.7881" x2="-10.0139" y2="-6.7754" layer="94"/>
<rectangle x1="-9.544" y1="-6.7881" x2="-9.1376" y2="-6.7754" layer="94"/>
<rectangle x1="-8.5026" y1="-6.7881" x2="-8.0835" y2="-6.7754" layer="94"/>
<rectangle x1="-7.6263" y1="-6.7881" x2="-7.2072" y2="-6.7754" layer="94"/>
<rectangle x1="-6.6103" y1="-6.7881" x2="-6.1912" y2="-6.7754" layer="94"/>
<rectangle x1="-5.7086" y1="-6.7881" x2="-5.3022" y2="-6.7754" layer="94"/>
<rectangle x1="-4.6672" y1="-6.7881" x2="-4.2608" y2="-6.7754" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7881" x2="-2.2415" y2="-6.7754" layer="94"/>
<rectangle x1="-1.6065" y1="-6.7881" x2="-1.2763" y2="-6.7754" layer="94"/>
<rectangle x1="-0.7556" y1="-6.7881" x2="-0.4381" y2="-6.7754" layer="94"/>
<rectangle x1="0.2096" y1="-6.7881" x2="0.5398" y2="-6.7754" layer="94"/>
<rectangle x1="1.0478" y1="-6.7881" x2="1.378" y2="-6.7754" layer="94"/>
<rectangle x1="2.0257" y1="-6.7881" x2="2.3559" y2="-6.7754" layer="94"/>
<rectangle x1="2.8766" y1="-6.7881" x2="3.1941" y2="-6.7754" layer="94"/>
<rectangle x1="3.8291" y1="-6.7881" x2="4.1974" y2="-6.7754" layer="94"/>
<rectangle x1="4.4768" y1="-6.7881" x2="4.7562" y2="-6.7754" layer="94"/>
<rectangle x1="5.188" y1="-6.7881" x2="5.4674" y2="-6.7754" layer="94"/>
<rectangle x1="5.8992" y1="-6.7881" x2="6.1659" y2="-6.7754" layer="94"/>
<rectangle x1="6.5088" y1="-6.7881" x2="6.8136" y2="-6.7754" layer="94"/>
<rectangle x1="7.4613" y1="-6.7881" x2="7.7788" y2="-6.7754" layer="94"/>
<rectangle x1="8.2995" y1="-6.7881" x2="8.6297" y2="-6.7754" layer="94"/>
<rectangle x1="9.2774" y1="-6.7881" x2="9.6076" y2="-6.7754" layer="94"/>
<rectangle x1="10.1156" y1="-6.7881" x2="10.4331" y2="-6.7754" layer="94"/>
<rectangle x1="11.0808" y1="-6.7881" x2="11.411" y2="-6.7754" layer="94"/>
<rectangle x1="-11.4363" y1="-6.7754" x2="-11.0299" y2="-6.7627" layer="94"/>
<rectangle x1="-10.4203" y1="-6.7754" x2="-10.0139" y2="-6.7627" layer="94"/>
<rectangle x1="-9.544" y1="-6.7754" x2="-9.1249" y2="-6.7627" layer="94"/>
<rectangle x1="-8.5026" y1="-6.7754" x2="-8.0962" y2="-6.7627" layer="94"/>
<rectangle x1="-7.6263" y1="-6.7754" x2="-7.2072" y2="-6.7627" layer="94"/>
<rectangle x1="-6.6103" y1="-6.7754" x2="-6.1912" y2="-6.7627" layer="94"/>
<rectangle x1="-5.7086" y1="-6.7754" x2="-5.2895" y2="-6.7627" layer="94"/>
<rectangle x1="-4.6799" y1="-6.7754" x2="-4.2608" y2="-6.7627" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7754" x2="-2.2288" y2="-6.7627" layer="94"/>
<rectangle x1="-1.6065" y1="-6.7754" x2="-1.289" y2="-6.7627" layer="94"/>
<rectangle x1="-0.7556" y1="-6.7754" x2="-0.4254" y2="-6.7627" layer="94"/>
<rectangle x1="0.1969" y1="-6.7754" x2="0.5271" y2="-6.7627" layer="94"/>
<rectangle x1="1.0605" y1="-6.7754" x2="1.3907" y2="-6.7627" layer="94"/>
<rectangle x1="2.013" y1="-6.7754" x2="2.3559" y2="-6.7627" layer="94"/>
<rectangle x1="2.8766" y1="-6.7754" x2="3.2068" y2="-6.7627" layer="94"/>
<rectangle x1="3.8164" y1="-6.7754" x2="4.1974" y2="-6.7627" layer="94"/>
<rectangle x1="4.4768" y1="-6.7754" x2="4.7562" y2="-6.7627" layer="94"/>
<rectangle x1="5.188" y1="-6.7754" x2="5.4674" y2="-6.7627" layer="94"/>
<rectangle x1="5.8992" y1="-6.7754" x2="6.1659" y2="-6.7627" layer="94"/>
<rectangle x1="6.5088" y1="-6.7754" x2="6.8263" y2="-6.7627" layer="94"/>
<rectangle x1="7.4486" y1="-6.7754" x2="7.7788" y2="-6.7627" layer="94"/>
<rectangle x1="8.2995" y1="-6.7754" x2="8.6297" y2="-6.7627" layer="94"/>
<rectangle x1="9.2647" y1="-6.7754" x2="9.5949" y2="-6.7627" layer="94"/>
<rectangle x1="10.1156" y1="-6.7754" x2="10.4458" y2="-6.7627" layer="94"/>
<rectangle x1="11.0808" y1="-6.7754" x2="11.411" y2="-6.7627" layer="94"/>
<rectangle x1="-11.4363" y1="-6.7627" x2="-11.0299" y2="-6.75" layer="94"/>
<rectangle x1="-10.4203" y1="-6.7627" x2="-10.0139" y2="-6.75" layer="94"/>
<rectangle x1="-9.5313" y1="-6.7627" x2="-9.1122" y2="-6.75" layer="94"/>
<rectangle x1="-8.5153" y1="-6.7627" x2="-8.0962" y2="-6.75" layer="94"/>
<rectangle x1="-7.6136" y1="-6.7627" x2="-7.2072" y2="-6.75" layer="94"/>
<rectangle x1="-6.6103" y1="-6.7627" x2="-6.1912" y2="-6.75" layer="94"/>
<rectangle x1="-5.6959" y1="-6.7627" x2="-5.2895" y2="-6.75" layer="94"/>
<rectangle x1="-4.6926" y1="-6.7627" x2="-4.2735" y2="-6.75" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7627" x2="-2.2288" y2="-6.75" layer="94"/>
<rectangle x1="-1.6192" y1="-6.7627" x2="-1.289" y2="-6.75" layer="94"/>
<rectangle x1="-0.7556" y1="-6.7627" x2="-0.4127" y2="-6.75" layer="94"/>
<rectangle x1="0.1842" y1="-6.7627" x2="0.5271" y2="-6.75" layer="94"/>
<rectangle x1="1.0605" y1="-6.7627" x2="1.4034" y2="-6.75" layer="94"/>
<rectangle x1="2.013" y1="-6.7627" x2="2.3432" y2="-6.75" layer="94"/>
<rectangle x1="2.8766" y1="-6.7627" x2="3.2068" y2="-6.75" layer="94"/>
<rectangle x1="3.8164" y1="-6.7627" x2="4.1974" y2="-6.75" layer="94"/>
<rectangle x1="4.4768" y1="-6.7627" x2="4.7562" y2="-6.75" layer="94"/>
<rectangle x1="5.188" y1="-6.7627" x2="5.4674" y2="-6.75" layer="94"/>
<rectangle x1="5.8992" y1="-6.7627" x2="6.1659" y2="-6.75" layer="94"/>
<rectangle x1="6.5088" y1="-6.7627" x2="6.839" y2="-6.75" layer="94"/>
<rectangle x1="7.4486" y1="-6.7627" x2="7.7788" y2="-6.75" layer="94"/>
<rectangle x1="8.2995" y1="-6.7627" x2="8.6424" y2="-6.75" layer="94"/>
<rectangle x1="9.252" y1="-6.7627" x2="9.5822" y2="-6.75" layer="94"/>
<rectangle x1="10.1283" y1="-6.7627" x2="10.4585" y2="-6.75" layer="94"/>
<rectangle x1="11.0681" y1="-6.7627" x2="11.411" y2="-6.75" layer="94"/>
<rectangle x1="-11.4363" y1="-6.75" x2="-11.0299" y2="-6.7373" layer="94"/>
<rectangle x1="-10.433" y1="-6.75" x2="-10.0139" y2="-6.7373" layer="94"/>
<rectangle x1="-9.5313" y1="-6.75" x2="-9.0995" y2="-6.7373" layer="94"/>
<rectangle x1="-8.528" y1="-6.75" x2="-8.1089" y2="-6.7373" layer="94"/>
<rectangle x1="-7.6136" y1="-6.75" x2="-7.1945" y2="-6.7373" layer="94"/>
<rectangle x1="-6.623" y1="-6.75" x2="-6.1912" y2="-6.7373" layer="94"/>
<rectangle x1="-5.6959" y1="-6.75" x2="-5.2768" y2="-6.7373" layer="94"/>
<rectangle x1="-4.7053" y1="-6.75" x2="-4.2735" y2="-6.7373" layer="94"/>
<rectangle x1="-2.5971" y1="-6.75" x2="-2.2161" y2="-6.7373" layer="94"/>
<rectangle x1="-1.6319" y1="-6.75" x2="-1.289" y2="-6.7373" layer="94"/>
<rectangle x1="-0.7429" y1="-6.75" x2="-0.4" y2="-6.7373" layer="94"/>
<rectangle x1="0.1715" y1="-6.75" x2="0.5144" y2="-6.7373" layer="94"/>
<rectangle x1="1.0732" y1="-6.75" x2="1.4161" y2="-6.7373" layer="94"/>
<rectangle x1="1.9876" y1="-6.75" x2="2.3432" y2="-6.7373" layer="94"/>
<rectangle x1="2.8766" y1="-6.75" x2="3.2195" y2="-6.7373" layer="94"/>
<rectangle x1="3.8037" y1="-6.75" x2="4.1974" y2="-6.7373" layer="94"/>
<rectangle x1="4.4768" y1="-6.75" x2="4.7562" y2="-6.7373" layer="94"/>
<rectangle x1="5.188" y1="-6.75" x2="5.4674" y2="-6.7373" layer="94"/>
<rectangle x1="5.8992" y1="-6.75" x2="6.1659" y2="-6.7373" layer="94"/>
<rectangle x1="6.5215" y1="-6.75" x2="6.8517" y2="-6.7373" layer="94"/>
<rectangle x1="7.4359" y1="-6.75" x2="7.7788" y2="-6.7373" layer="94"/>
<rectangle x1="8.3122" y1="-6.75" x2="8.6678" y2="-6.7373" layer="94"/>
<rectangle x1="9.2393" y1="-6.75" x2="9.5822" y2="-6.7373" layer="94"/>
<rectangle x1="10.141" y1="-6.75" x2="10.4712" y2="-6.7373" layer="94"/>
<rectangle x1="11.0554" y1="-6.75" x2="11.411" y2="-6.7373" layer="94"/>
<rectangle x1="-11.4363" y1="-6.7373" x2="-11.0172" y2="-6.7246" layer="94"/>
<rectangle x1="-10.4457" y1="-6.7373" x2="-10.0139" y2="-6.7246" layer="94"/>
<rectangle x1="-9.5313" y1="-6.7373" x2="-9.0868" y2="-6.7246" layer="94"/>
<rectangle x1="-8.5407" y1="-6.7373" x2="-8.1089" y2="-6.7246" layer="94"/>
<rectangle x1="-7.6136" y1="-6.7373" x2="-7.1945" y2="-6.7246" layer="94"/>
<rectangle x1="-6.6357" y1="-6.7373" x2="-6.1912" y2="-6.7246" layer="94"/>
<rectangle x1="-5.6959" y1="-6.7373" x2="-5.2641" y2="-6.7246" layer="94"/>
<rectangle x1="-4.718" y1="-6.7373" x2="-4.2735" y2="-6.7246" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7373" x2="-2.2034" y2="-6.7246" layer="94"/>
<rectangle x1="-1.6446" y1="-6.7373" x2="-1.289" y2="-6.7246" layer="94"/>
<rectangle x1="-0.7429" y1="-6.7373" x2="-0.3873" y2="-6.7246" layer="94"/>
<rectangle x1="0.1588" y1="-6.7373" x2="0.5144" y2="-6.7246" layer="94"/>
<rectangle x1="1.0732" y1="-6.7373" x2="1.4288" y2="-6.7246" layer="94"/>
<rectangle x1="1.9749" y1="-6.7373" x2="2.3305" y2="-6.7246" layer="94"/>
<rectangle x1="2.8893" y1="-6.7373" x2="3.2449" y2="-6.7246" layer="94"/>
<rectangle x1="3.791" y1="-6.7373" x2="4.1974" y2="-6.7246" layer="94"/>
<rectangle x1="4.4768" y1="-6.7373" x2="4.7562" y2="-6.7246" layer="94"/>
<rectangle x1="5.188" y1="-6.7373" x2="5.4674" y2="-6.7246" layer="94"/>
<rectangle x1="5.8992" y1="-6.7373" x2="6.1659" y2="-6.7246" layer="94"/>
<rectangle x1="6.5215" y1="-6.7373" x2="6.8644" y2="-6.7246" layer="94"/>
<rectangle x1="7.4105" y1="-6.7373" x2="7.7661" y2="-6.7246" layer="94"/>
<rectangle x1="8.3122" y1="-6.7373" x2="8.6805" y2="-6.7246" layer="94"/>
<rectangle x1="9.2266" y1="-6.7373" x2="9.5695" y2="-6.7246" layer="94"/>
<rectangle x1="10.141" y1="-6.7373" x2="10.4839" y2="-6.7246" layer="94"/>
<rectangle x1="11.03" y1="-6.7373" x2="11.411" y2="-6.7246" layer="94"/>
<rectangle x1="-11.4363" y1="-6.7246" x2="-11.0172" y2="-6.7119" layer="94"/>
<rectangle x1="-10.4584" y1="-6.7246" x2="-10.0139" y2="-6.7119" layer="94"/>
<rectangle x1="-9.5186" y1="-6.7246" x2="-9.0868" y2="-6.7119" layer="94"/>
<rectangle x1="-8.5407" y1="-6.7246" x2="-8.1216" y2="-6.7119" layer="94"/>
<rectangle x1="-7.6136" y1="-6.7246" x2="-7.1818" y2="-6.7119" layer="94"/>
<rectangle x1="-6.6484" y1="-6.7246" x2="-6.1912" y2="-6.7119" layer="94"/>
<rectangle x1="-5.6959" y1="-6.7246" x2="-5.2641" y2="-6.7119" layer="94"/>
<rectangle x1="-4.718" y1="-6.7246" x2="-4.2862" y2="-6.7119" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7246" x2="-2.1907" y2="-6.7119" layer="94"/>
<rectangle x1="-1.6573" y1="-6.7246" x2="-1.289" y2="-6.7119" layer="94"/>
<rectangle x1="-0.7302" y1="-6.7246" x2="-0.3746" y2="-6.7119" layer="94"/>
<rectangle x1="0.1461" y1="-6.7246" x2="0.5017" y2="-6.7119" layer="94"/>
<rectangle x1="1.0859" y1="-6.7246" x2="1.4415" y2="-6.7119" layer="94"/>
<rectangle x1="1.9622" y1="-6.7246" x2="2.3305" y2="-6.7119" layer="94"/>
<rectangle x1="2.8893" y1="-6.7246" x2="3.2576" y2="-6.7119" layer="94"/>
<rectangle x1="3.7783" y1="-6.7246" x2="4.1974" y2="-6.7119" layer="94"/>
<rectangle x1="4.4768" y1="-6.7246" x2="4.7562" y2="-6.7119" layer="94"/>
<rectangle x1="5.188" y1="-6.7246" x2="5.4674" y2="-6.7119" layer="94"/>
<rectangle x1="5.8992" y1="-6.7246" x2="6.1659" y2="-6.7119" layer="94"/>
<rectangle x1="6.5215" y1="-6.7246" x2="6.8771" y2="-6.7119" layer="94"/>
<rectangle x1="7.3978" y1="-6.7246" x2="7.7661" y2="-6.7119" layer="94"/>
<rectangle x1="8.3249" y1="-6.7246" x2="8.6932" y2="-6.7119" layer="94"/>
<rectangle x1="9.2139" y1="-6.7246" x2="9.5695" y2="-6.7119" layer="94"/>
<rectangle x1="10.1537" y1="-6.7246" x2="10.4966" y2="-6.7119" layer="94"/>
<rectangle x1="11.0173" y1="-6.7246" x2="11.3983" y2="-6.7119" layer="94"/>
<rectangle x1="-11.4363" y1="-6.7119" x2="-11.0045" y2="-6.6992" layer="94"/>
<rectangle x1="-10.4711" y1="-6.7119" x2="-10.0139" y2="-6.6992" layer="94"/>
<rectangle x1="-9.5186" y1="-6.7119" x2="-9.0741" y2="-6.6992" layer="94"/>
<rectangle x1="-8.5534" y1="-6.7119" x2="-8.1216" y2="-6.6992" layer="94"/>
<rectangle x1="-7.6136" y1="-6.7119" x2="-7.1691" y2="-6.6992" layer="94"/>
<rectangle x1="-6.6611" y1="-6.7119" x2="-6.1912" y2="-6.6992" layer="94"/>
<rectangle x1="-5.6832" y1="-6.7119" x2="-5.2514" y2="-6.6992" layer="94"/>
<rectangle x1="-4.7307" y1="-6.7119" x2="-4.2862" y2="-6.6992" layer="94"/>
<rectangle x1="-2.5971" y1="-6.7119" x2="-2.178" y2="-6.6992" layer="94"/>
<rectangle x1="-1.67" y1="-6.7119" x2="-1.3017" y2="-6.6992" layer="94"/>
<rectangle x1="-0.7175" y1="-6.7119" x2="-0.3619" y2="-6.6992" layer="94"/>
<rectangle x1="0.1334" y1="-6.7119" x2="0.5017" y2="-6.6992" layer="94"/>
<rectangle x1="1.0859" y1="-6.7119" x2="1.4542" y2="-6.6992" layer="94"/>
<rectangle x1="1.9495" y1="-6.7119" x2="2.3178" y2="-6.6992" layer="94"/>
<rectangle x1="2.8893" y1="-6.7119" x2="3.2703" y2="-6.6992" layer="94"/>
<rectangle x1="3.7656" y1="-6.7119" x2="4.1974" y2="-6.6992" layer="94"/>
<rectangle x1="4.4768" y1="-6.7119" x2="4.7562" y2="-6.6992" layer="94"/>
<rectangle x1="5.188" y1="-6.7119" x2="5.4674" y2="-6.6992" layer="94"/>
<rectangle x1="5.8992" y1="-6.7119" x2="6.1659" y2="-6.6992" layer="94"/>
<rectangle x1="6.5215" y1="-6.7119" x2="6.8898" y2="-6.6992" layer="94"/>
<rectangle x1="7.3851" y1="-6.7119" x2="7.7661" y2="-6.6992" layer="94"/>
<rectangle x1="8.3249" y1="-6.7119" x2="8.7059" y2="-6.6992" layer="94"/>
<rectangle x1="9.2012" y1="-6.7119" x2="9.5568" y2="-6.6992" layer="94"/>
<rectangle x1="10.1537" y1="-6.7119" x2="10.5093" y2="-6.6992" layer="94"/>
<rectangle x1="11.0046" y1="-6.7119" x2="11.3983" y2="-6.6992" layer="94"/>
<rectangle x1="-11.4236" y1="-6.6992" x2="-10.9918" y2="-6.6865" layer="94"/>
<rectangle x1="-10.4711" y1="-6.6992" x2="-10.0139" y2="-6.6865" layer="94"/>
<rectangle x1="-9.5059" y1="-6.6992" x2="-9.0614" y2="-6.6865" layer="94"/>
<rectangle x1="-8.5534" y1="-6.6992" x2="-8.1216" y2="-6.6865" layer="94"/>
<rectangle x1="-7.6136" y1="-6.6992" x2="-7.1564" y2="-6.6865" layer="94"/>
<rectangle x1="-6.6611" y1="-6.6992" x2="-6.2039" y2="-6.6865" layer="94"/>
<rectangle x1="-5.6832" y1="-6.6992" x2="-5.2514" y2="-6.6865" layer="94"/>
<rectangle x1="-4.7307" y1="-6.6992" x2="-4.2862" y2="-6.6865" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6992" x2="-2.1653" y2="-6.6865" layer="94"/>
<rectangle x1="-1.6827" y1="-6.6992" x2="-1.3017" y2="-6.6865" layer="94"/>
<rectangle x1="-0.7175" y1="-6.6992" x2="-0.3492" y2="-6.6865" layer="94"/>
<rectangle x1="0.1207" y1="-6.6992" x2="0.5017" y2="-6.6865" layer="94"/>
<rectangle x1="1.0859" y1="-6.6992" x2="1.4669" y2="-6.6865" layer="94"/>
<rectangle x1="1.9368" y1="-6.6992" x2="2.3051" y2="-6.6865" layer="94"/>
<rectangle x1="2.902" y1="-6.6992" x2="3.283" y2="-6.6865" layer="94"/>
<rectangle x1="3.7529" y1="-6.6992" x2="4.1974" y2="-6.6865" layer="94"/>
<rectangle x1="4.4768" y1="-6.6992" x2="4.7562" y2="-6.6865" layer="94"/>
<rectangle x1="5.188" y1="-6.6992" x2="5.4674" y2="-6.6865" layer="94"/>
<rectangle x1="5.8992" y1="-6.6992" x2="6.1659" y2="-6.6865" layer="94"/>
<rectangle x1="6.5342" y1="-6.6992" x2="6.9025" y2="-6.6865" layer="94"/>
<rectangle x1="7.3724" y1="-6.6992" x2="7.7534" y2="-6.6865" layer="94"/>
<rectangle x1="8.3376" y1="-6.6992" x2="8.7186" y2="-6.6865" layer="94"/>
<rectangle x1="9.1885" y1="-6.6992" x2="9.5568" y2="-6.6865" layer="94"/>
<rectangle x1="10.1537" y1="-6.6992" x2="10.522" y2="-6.6865" layer="94"/>
<rectangle x1="10.9919" y1="-6.6992" x2="11.3856" y2="-6.6865" layer="94"/>
<rectangle x1="-11.4236" y1="-6.6865" x2="-10.9791" y2="-6.6738" layer="94"/>
<rectangle x1="-10.4838" y1="-6.6865" x2="-10.0266" y2="-6.6738" layer="94"/>
<rectangle x1="-9.5059" y1="-6.6865" x2="-9.0614" y2="-6.6738" layer="94"/>
<rectangle x1="-8.5661" y1="-6.6865" x2="-8.1216" y2="-6.6738" layer="94"/>
<rectangle x1="-7.6009" y1="-6.6865" x2="-7.1437" y2="-6.6738" layer="94"/>
<rectangle x1="-6.6738" y1="-6.6865" x2="-6.2039" y2="-6.6738" layer="94"/>
<rectangle x1="-5.6832" y1="-6.6865" x2="-5.2387" y2="-6.6738" layer="94"/>
<rectangle x1="-4.7434" y1="-6.6865" x2="-4.2989" y2="-6.6738" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6865" x2="-2.1399" y2="-6.6738" layer="94"/>
<rectangle x1="-1.6954" y1="-6.6865" x2="-1.3144" y2="-6.6738" layer="94"/>
<rectangle x1="-0.7048" y1="-6.6865" x2="-0.3365" y2="-6.6738" layer="94"/>
<rectangle x1="0.108" y1="-6.6865" x2="0.489" y2="-6.6738" layer="94"/>
<rectangle x1="1.0986" y1="-6.6865" x2="1.4796" y2="-6.6738" layer="94"/>
<rectangle x1="1.9241" y1="-6.6865" x2="2.2924" y2="-6.6738" layer="94"/>
<rectangle x1="2.902" y1="-6.6865" x2="3.2957" y2="-6.6738" layer="94"/>
<rectangle x1="3.7402" y1="-6.6865" x2="4.1974" y2="-6.6738" layer="94"/>
<rectangle x1="4.4768" y1="-6.6865" x2="4.7562" y2="-6.6738" layer="94"/>
<rectangle x1="5.188" y1="-6.6865" x2="5.4674" y2="-6.6738" layer="94"/>
<rectangle x1="5.8992" y1="-6.6865" x2="6.1659" y2="-6.6738" layer="94"/>
<rectangle x1="6.5342" y1="-6.6865" x2="6.9152" y2="-6.6738" layer="94"/>
<rectangle x1="7.3597" y1="-6.6865" x2="7.7534" y2="-6.6738" layer="94"/>
<rectangle x1="8.3503" y1="-6.6865" x2="8.7313" y2="-6.6738" layer="94"/>
<rectangle x1="9.1758" y1="-6.6865" x2="9.5568" y2="-6.6738" layer="94"/>
<rectangle x1="10.1664" y1="-6.6865" x2="10.5347" y2="-6.6738" layer="94"/>
<rectangle x1="10.9919" y1="-6.6865" x2="11.3729" y2="-6.6738" layer="94"/>
<rectangle x1="-11.4236" y1="-6.6738" x2="-10.9664" y2="-6.6611" layer="94"/>
<rectangle x1="-10.4965" y1="-6.6738" x2="-10.0266" y2="-6.6611" layer="94"/>
<rectangle x1="-9.5059" y1="-6.6738" x2="-9.0487" y2="-6.6611" layer="94"/>
<rectangle x1="-8.5788" y1="-6.6738" x2="-8.1343" y2="-6.6611" layer="94"/>
<rectangle x1="-7.6009" y1="-6.6738" x2="-7.131" y2="-6.6611" layer="94"/>
<rectangle x1="-6.6865" y1="-6.6738" x2="-6.2039" y2="-6.6611" layer="94"/>
<rectangle x1="-5.6832" y1="-6.6738" x2="-5.2133" y2="-6.6611" layer="94"/>
<rectangle x1="-4.7561" y1="-6.6738" x2="-4.3116" y2="-6.6611" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6738" x2="-2.1272" y2="-6.6611" layer="94"/>
<rectangle x1="-1.7081" y1="-6.6738" x2="-1.3271" y2="-6.6611" layer="94"/>
<rectangle x1="-0.6921" y1="-6.6738" x2="-0.3238" y2="-6.6611" layer="94"/>
<rectangle x1="0.0953" y1="-6.6738" x2="0.489" y2="-6.6611" layer="94"/>
<rectangle x1="1.0986" y1="-6.6738" x2="1.4923" y2="-6.6611" layer="94"/>
<rectangle x1="1.9114" y1="-6.6738" x2="2.2924" y2="-6.6611" layer="94"/>
<rectangle x1="2.9147" y1="-6.6738" x2="3.3084" y2="-6.6611" layer="94"/>
<rectangle x1="3.7148" y1="-6.6738" x2="4.1974" y2="-6.6611" layer="94"/>
<rectangle x1="4.4768" y1="-6.6738" x2="4.7562" y2="-6.6611" layer="94"/>
<rectangle x1="5.188" y1="-6.6738" x2="5.4674" y2="-6.6611" layer="94"/>
<rectangle x1="5.8992" y1="-6.6738" x2="6.1659" y2="-6.6611" layer="94"/>
<rectangle x1="6.5469" y1="-6.6738" x2="6.9279" y2="-6.6611" layer="94"/>
<rectangle x1="7.347" y1="-6.6738" x2="7.7407" y2="-6.6611" layer="94"/>
<rectangle x1="8.363" y1="-6.6738" x2="8.744" y2="-6.6611" layer="94"/>
<rectangle x1="9.1631" y1="-6.6738" x2="9.5441" y2="-6.6611" layer="94"/>
<rectangle x1="10.1664" y1="-6.6738" x2="10.5601" y2="-6.6611" layer="94"/>
<rectangle x1="10.9665" y1="-6.6738" x2="11.3602" y2="-6.6611" layer="94"/>
<rectangle x1="-11.4236" y1="-6.6611" x2="-10.941" y2="-6.6484" layer="94"/>
<rectangle x1="-10.5092" y1="-6.6611" x2="-10.0393" y2="-6.6484" layer="94"/>
<rectangle x1="-9.4932" y1="-6.6611" x2="-9.0233" y2="-6.6484" layer="94"/>
<rectangle x1="-8.5915" y1="-6.6611" x2="-8.1343" y2="-6.6484" layer="94"/>
<rectangle x1="-7.6009" y1="-6.6611" x2="-7.1183" y2="-6.6484" layer="94"/>
<rectangle x1="-6.6992" y1="-6.6611" x2="-6.2039" y2="-6.6484" layer="94"/>
<rectangle x1="-5.6705" y1="-6.6611" x2="-5.2006" y2="-6.6484" layer="94"/>
<rectangle x1="-4.7815" y1="-6.6611" x2="-4.3116" y2="-6.6484" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6611" x2="-2.1018" y2="-6.6484" layer="94"/>
<rectangle x1="-1.7462" y1="-6.6611" x2="-1.3398" y2="-6.6484" layer="94"/>
<rectangle x1="-0.6794" y1="-6.6611" x2="-0.2984" y2="-6.6484" layer="94"/>
<rectangle x1="0.0572" y1="-6.6611" x2="0.489" y2="-6.6484" layer="94"/>
<rectangle x1="1.1113" y1="-6.6611" x2="1.5177" y2="-6.6484" layer="94"/>
<rectangle x1="1.8733" y1="-6.6611" x2="2.2797" y2="-6.6484" layer="94"/>
<rectangle x1="2.9274" y1="-6.6611" x2="3.3338" y2="-6.6484" layer="94"/>
<rectangle x1="3.6894" y1="-6.6611" x2="4.1974" y2="-6.6484" layer="94"/>
<rectangle x1="4.4768" y1="-6.6611" x2="4.7562" y2="-6.6484" layer="94"/>
<rectangle x1="5.188" y1="-6.6611" x2="5.4674" y2="-6.6484" layer="94"/>
<rectangle x1="5.8992" y1="-6.6611" x2="6.1659" y2="-6.6484" layer="94"/>
<rectangle x1="6.5596" y1="-6.6611" x2="6.966" y2="-6.6484" layer="94"/>
<rectangle x1="7.3089" y1="-6.6611" x2="7.728" y2="-6.6484" layer="94"/>
<rectangle x1="8.363" y1="-6.6611" x2="8.7821" y2="-6.6484" layer="94"/>
<rectangle x1="9.1377" y1="-6.6611" x2="9.5441" y2="-6.6484" layer="94"/>
<rectangle x1="10.1664" y1="-6.6611" x2="10.5855" y2="-6.6484" layer="94"/>
<rectangle x1="10.9411" y1="-6.6611" x2="11.3475" y2="-6.6484" layer="94"/>
<rectangle x1="-11.4236" y1="-6.6484" x2="-10.9283" y2="-6.6357" layer="94"/>
<rectangle x1="-10.5346" y1="-6.6484" x2="-10.052" y2="-6.6357" layer="94"/>
<rectangle x1="-9.4932" y1="-6.6484" x2="-9.0106" y2="-6.6357" layer="94"/>
<rectangle x1="-8.6169" y1="-6.6484" x2="-8.1343" y2="-6.6357" layer="94"/>
<rectangle x1="-7.5882" y1="-6.6484" x2="-7.0929" y2="-6.6357" layer="94"/>
<rectangle x1="-6.7119" y1="-6.6484" x2="-6.2166" y2="-6.6357" layer="94"/>
<rectangle x1="-5.6705" y1="-6.6484" x2="-5.1752" y2="-6.6357" layer="94"/>
<rectangle x1="-4.8069" y1="-6.6484" x2="-4.3116" y2="-6.6357" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6484" x2="-2.0637" y2="-6.6357" layer="94"/>
<rectangle x1="-1.7843" y1="-6.6484" x2="-1.3525" y2="-6.6357" layer="94"/>
<rectangle x1="-0.6794" y1="-6.6484" x2="-0.2476" y2="-6.6357" layer="94"/>
<rectangle x1="0.0191" y1="-6.6484" x2="0.4763" y2="-6.6357" layer="94"/>
<rectangle x1="1.1113" y1="-6.6484" x2="1.5685" y2="-6.6357" layer="94"/>
<rectangle x1="1.8352" y1="-6.6484" x2="2.2797" y2="-6.6357" layer="94"/>
<rectangle x1="2.9401" y1="-6.6484" x2="3.3719" y2="-6.6357" layer="94"/>
<rectangle x1="3.6513" y1="-6.6484" x2="4.1974" y2="-6.6357" layer="94"/>
<rectangle x1="4.4768" y1="-6.6484" x2="4.7562" y2="-6.6357" layer="94"/>
<rectangle x1="5.188" y1="-6.6484" x2="5.4674" y2="-6.6357" layer="94"/>
<rectangle x1="5.8992" y1="-6.6484" x2="6.1659" y2="-6.6357" layer="94"/>
<rectangle x1="6.5723" y1="-6.6484" x2="7.0041" y2="-6.6357" layer="94"/>
<rectangle x1="7.2708" y1="-6.6484" x2="7.7153" y2="-6.6357" layer="94"/>
<rectangle x1="8.3757" y1="-6.6484" x2="8.8202" y2="-6.6357" layer="94"/>
<rectangle x1="9.0869" y1="-6.6484" x2="9.5441" y2="-6.6357" layer="94"/>
<rectangle x1="10.1791" y1="-6.6484" x2="10.6236" y2="-6.6357" layer="94"/>
<rectangle x1="10.8903" y1="-6.6484" x2="11.3475" y2="-6.6357" layer="94"/>
<rectangle x1="-11.4109" y1="-6.6357" x2="-10.9029" y2="-6.623" layer="94"/>
<rectangle x1="-10.56" y1="-6.6357" x2="-10.052" y2="-6.623" layer="94"/>
<rectangle x1="-9.4932" y1="-6.6357" x2="-8.9852" y2="-6.623" layer="94"/>
<rectangle x1="-8.6423" y1="-6.6357" x2="-8.1343" y2="-6.623" layer="94"/>
<rectangle x1="-7.5882" y1="-6.6357" x2="-7.0675" y2="-6.623" layer="94"/>
<rectangle x1="-6.7373" y1="-6.6357" x2="-6.2166" y2="-6.623" layer="94"/>
<rectangle x1="-5.6705" y1="-6.6357" x2="-5.1625" y2="-6.623" layer="94"/>
<rectangle x1="-4.8196" y1="-6.6357" x2="-4.3243" y2="-6.623" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6357" x2="-2.0256" y2="-6.623" layer="94"/>
<rectangle x1="-1.8224" y1="-6.6357" x2="-1.3525" y2="-6.623" layer="94"/>
<rectangle x1="-0.6794" y1="-6.6357" x2="-0.2095" y2="-6.623" layer="94"/>
<rectangle x1="-0.019" y1="-6.6357" x2="0.4763" y2="-6.623" layer="94"/>
<rectangle x1="1.124" y1="-6.6357" x2="1.6066" y2="-6.623" layer="94"/>
<rectangle x1="1.7971" y1="-6.6357" x2="2.2797" y2="-6.623" layer="94"/>
<rectangle x1="2.9528" y1="-6.6357" x2="3.41" y2="-6.623" layer="94"/>
<rectangle x1="3.6005" y1="-6.6357" x2="4.1974" y2="-6.623" layer="94"/>
<rectangle x1="4.4768" y1="-6.6357" x2="4.7562" y2="-6.623" layer="94"/>
<rectangle x1="5.188" y1="-6.6357" x2="5.4674" y2="-6.623" layer="94"/>
<rectangle x1="5.8992" y1="-6.6357" x2="6.1659" y2="-6.623" layer="94"/>
<rectangle x1="6.585" y1="-6.6357" x2="7.0295" y2="-6.623" layer="94"/>
<rectangle x1="7.22" y1="-6.6357" x2="7.7026" y2="-6.623" layer="94"/>
<rectangle x1="8.3757" y1="-6.6357" x2="8.8583" y2="-6.623" layer="94"/>
<rectangle x1="9.0488" y1="-6.6357" x2="9.5314" y2="-6.623" layer="94"/>
<rectangle x1="10.1791" y1="-6.6357" x2="10.6617" y2="-6.623" layer="94"/>
<rectangle x1="10.8522" y1="-6.6357" x2="11.3348" y2="-6.623" layer="94"/>
<rectangle x1="-11.4109" y1="-6.623" x2="-10.8902" y2="-6.6103" layer="94"/>
<rectangle x1="-10.5854" y1="-6.623" x2="-10.0647" y2="-6.6103" layer="94"/>
<rectangle x1="-9.4805" y1="-6.623" x2="-8.9725" y2="-6.6103" layer="94"/>
<rectangle x1="-8.655" y1="-6.623" x2="-8.147" y2="-6.6103" layer="94"/>
<rectangle x1="-7.5755" y1="-6.623" x2="-7.0548" y2="-6.6103" layer="94"/>
<rectangle x1="-6.7627" y1="-6.623" x2="-6.2293" y2="-6.6103" layer="94"/>
<rectangle x1="-5.6705" y1="-6.623" x2="-5.1371" y2="-6.6103" layer="94"/>
<rectangle x1="-4.8323" y1="-6.623" x2="-4.3243" y2="-6.6103" layer="94"/>
<rectangle x1="-2.5971" y1="-6.623" x2="-2.0002" y2="-6.6103" layer="94"/>
<rectangle x1="-1.8478" y1="-6.623" x2="-1.3652" y2="-6.6103" layer="94"/>
<rectangle x1="-0.6667" y1="-6.623" x2="-0.1841" y2="-6.6103" layer="94"/>
<rectangle x1="-0.0444" y1="-6.623" x2="0.4636" y2="-6.6103" layer="94"/>
<rectangle x1="1.124" y1="-6.623" x2="1.6447" y2="-6.6103" layer="94"/>
<rectangle x1="1.7717" y1="-6.623" x2="2.267" y2="-6.6103" layer="94"/>
<rectangle x1="2.9528" y1="-6.623" x2="3.4481" y2="-6.6103" layer="94"/>
<rectangle x1="3.5751" y1="-6.623" x2="4.1974" y2="-6.6103" layer="94"/>
<rectangle x1="4.4768" y1="-6.623" x2="4.7562" y2="-6.6103" layer="94"/>
<rectangle x1="5.188" y1="-6.623" x2="5.4674" y2="-6.6103" layer="94"/>
<rectangle x1="5.8992" y1="-6.623" x2="6.1659" y2="-6.6103" layer="94"/>
<rectangle x1="6.5977" y1="-6.623" x2="7.0676" y2="-6.6103" layer="94"/>
<rectangle x1="7.1946" y1="-6.623" x2="7.7026" y2="-6.6103" layer="94"/>
<rectangle x1="8.3757" y1="-6.623" x2="8.8837" y2="-6.6103" layer="94"/>
<rectangle x1="9.0107" y1="-6.623" x2="9.5314" y2="-6.6103" layer="94"/>
<rectangle x1="10.1918" y1="-6.623" x2="10.6871" y2="-6.6103" layer="94"/>
<rectangle x1="10.8268" y1="-6.623" x2="11.3348" y2="-6.6103" layer="94"/>
<rectangle x1="-11.3982" y1="-6.6103" x2="-10.8648" y2="-6.5976" layer="94"/>
<rectangle x1="-10.5981" y1="-6.6103" x2="-10.0647" y2="-6.5976" layer="94"/>
<rectangle x1="-9.4805" y1="-6.6103" x2="-8.9598" y2="-6.5976" layer="94"/>
<rectangle x1="-8.6804" y1="-6.6103" x2="-8.147" y2="-6.5976" layer="94"/>
<rectangle x1="-7.5628" y1="-6.6103" x2="-7.0421" y2="-6.5976" layer="94"/>
<rectangle x1="-6.7754" y1="-6.6103" x2="-6.2293" y2="-6.5976" layer="94"/>
<rectangle x1="-5.6578" y1="-6.6103" x2="-5.1244" y2="-6.5976" layer="94"/>
<rectangle x1="-4.845" y1="-6.6103" x2="-4.3243" y2="-6.5976" layer="94"/>
<rectangle x1="-2.5971" y1="-6.6103" x2="-1.9621" y2="-6.5976" layer="94"/>
<rectangle x1="-1.8859" y1="-6.6103" x2="-1.3652" y2="-6.5976" layer="94"/>
<rectangle x1="-0.6667" y1="-6.6103" x2="-0.146" y2="-6.5976" layer="94"/>
<rectangle x1="-0.0825" y1="-6.6103" x2="0.4509" y2="-6.5976" layer="94"/>
<rectangle x1="1.1367" y1="-6.6103" x2="1.6828" y2="-6.5976" layer="94"/>
<rectangle x1="1.7463" y1="-6.6103" x2="2.267" y2="-6.5976" layer="94"/>
<rectangle x1="2.9655" y1="-6.6103" x2="3.4735" y2="-6.5976" layer="94"/>
<rectangle x1="3.537" y1="-6.6103" x2="4.1974" y2="-6.5976" layer="94"/>
<rectangle x1="4.4768" y1="-6.6103" x2="4.7562" y2="-6.5976" layer="94"/>
<rectangle x1="5.188" y1="-6.6103" x2="5.4674" y2="-6.5976" layer="94"/>
<rectangle x1="5.8992" y1="-6.6103" x2="6.1659" y2="-6.5976" layer="94"/>
<rectangle x1="6.5977" y1="-6.6103" x2="7.1057" y2="-6.5976" layer="94"/>
<rectangle x1="7.1692" y1="-6.6103" x2="7.6899" y2="-6.5976" layer="94"/>
<rectangle x1="8.3884" y1="-6.6103" x2="8.9091" y2="-6.5976" layer="94"/>
<rectangle x1="8.9726" y1="-6.6103" x2="9.5187" y2="-6.5976" layer="94"/>
<rectangle x1="10.2045" y1="-6.6103" x2="10.7125" y2="-6.5976" layer="94"/>
<rectangle x1="10.8014" y1="-6.6103" x2="11.3221" y2="-6.5976" layer="94"/>
<rectangle x1="-11.3855" y1="-6.5976" x2="-10.8521" y2="-6.5849" layer="94"/>
<rectangle x1="-10.6235" y1="-6.5976" x2="-10.0774" y2="-6.5849" layer="94"/>
<rectangle x1="-9.4805" y1="-6.5976" x2="-8.9471" y2="-6.5849" layer="94"/>
<rectangle x1="-8.7058" y1="-6.5976" x2="-8.147" y2="-6.5849" layer="94"/>
<rectangle x1="-7.5628" y1="-6.5976" x2="-7.0167" y2="-6.5849" layer="94"/>
<rectangle x1="-6.8008" y1="-6.5976" x2="-6.242" y2="-6.5849" layer="94"/>
<rectangle x1="-5.6578" y1="-6.5976" x2="-5.099" y2="-6.5849" layer="94"/>
<rectangle x1="-4.8704" y1="-6.5976" x2="-4.337" y2="-6.5849" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5976" x2="-1.3779" y2="-6.5849" layer="94"/>
<rectangle x1="-0.654" y1="-6.5976" x2="0.4382" y2="-6.5849" layer="94"/>
<rectangle x1="1.1494" y1="-6.5976" x2="2.2543" y2="-6.5849" layer="94"/>
<rectangle x1="2.9655" y1="-6.5976" x2="4.1974" y2="-6.5849" layer="94"/>
<rectangle x1="4.4768" y1="-6.5976" x2="4.7562" y2="-6.5849" layer="94"/>
<rectangle x1="5.188" y1="-6.5976" x2="5.4674" y2="-6.5849" layer="94"/>
<rectangle x1="5.8992" y1="-6.5976" x2="6.1659" y2="-6.5849" layer="94"/>
<rectangle x1="6.6104" y1="-6.5976" x2="7.6899" y2="-6.5849" layer="94"/>
<rectangle x1="8.4011" y1="-6.5976" x2="9.4933" y2="-6.5849" layer="94"/>
<rectangle x1="10.2172" y1="-6.5976" x2="11.3221" y2="-6.5849" layer="94"/>
<rectangle x1="-11.3855" y1="-6.5849" x2="-10.8013" y2="-6.5722" layer="94"/>
<rectangle x1="-10.687" y1="-6.5849" x2="-10.0774" y2="-6.5722" layer="94"/>
<rectangle x1="-9.4678" y1="-6.5849" x2="-8.8963" y2="-6.5722" layer="94"/>
<rectangle x1="-8.7566" y1="-6.5849" x2="-8.1597" y2="-6.5722" layer="94"/>
<rectangle x1="-7.5501" y1="-6.5849" x2="-6.9659" y2="-6.5722" layer="94"/>
<rectangle x1="-6.8389" y1="-6.5849" x2="-6.2547" y2="-6.5722" layer="94"/>
<rectangle x1="-5.6451" y1="-6.5849" x2="-5.0482" y2="-6.5722" layer="94"/>
<rectangle x1="-4.9212" y1="-6.5849" x2="-4.337" y2="-6.5722" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5849" x2="-1.3906" y2="-6.5722" layer="94"/>
<rectangle x1="-0.6286" y1="-6.5849" x2="0.4255" y2="-6.5722" layer="94"/>
<rectangle x1="1.1621" y1="-6.5849" x2="2.2416" y2="-6.5722" layer="94"/>
<rectangle x1="2.9782" y1="-6.5849" x2="4.1974" y2="-6.5722" layer="94"/>
<rectangle x1="4.4768" y1="-6.5849" x2="4.7562" y2="-6.5722" layer="94"/>
<rectangle x1="5.188" y1="-6.5849" x2="5.4674" y2="-6.5722" layer="94"/>
<rectangle x1="5.8992" y1="-6.5849" x2="6.1659" y2="-6.5722" layer="94"/>
<rectangle x1="6.6104" y1="-6.5849" x2="7.6772" y2="-6.5722" layer="94"/>
<rectangle x1="8.4138" y1="-6.5849" x2="9.4806" y2="-6.5722" layer="94"/>
<rectangle x1="10.2299" y1="-6.5849" x2="11.3094" y2="-6.5722" layer="94"/>
<rectangle x1="-11.3728" y1="-6.5722" x2="-10.0901" y2="-6.5595" layer="94"/>
<rectangle x1="-9.4678" y1="-6.5722" x2="-8.1597" y2="-6.5595" layer="94"/>
<rectangle x1="-7.5374" y1="-6.5722" x2="-6.2547" y2="-6.5595" layer="94"/>
<rectangle x1="-5.6451" y1="-6.5722" x2="-4.337" y2="-6.5595" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5722" x2="-1.3906" y2="-6.5595" layer="94"/>
<rectangle x1="-0.6159" y1="-6.5722" x2="0.4128" y2="-6.5595" layer="94"/>
<rectangle x1="1.1748" y1="-6.5722" x2="2.2289" y2="-6.5595" layer="94"/>
<rectangle x1="2.9782" y1="-6.5722" x2="4.1974" y2="-6.5595" layer="94"/>
<rectangle x1="4.4768" y1="-6.5722" x2="4.7562" y2="-6.5595" layer="94"/>
<rectangle x1="5.188" y1="-6.5722" x2="5.4674" y2="-6.5595" layer="94"/>
<rectangle x1="5.8992" y1="-6.5722" x2="6.1659" y2="-6.5595" layer="94"/>
<rectangle x1="6.6231" y1="-6.5722" x2="7.6772" y2="-6.5595" layer="94"/>
<rectangle x1="8.4265" y1="-6.5722" x2="9.4679" y2="-6.5595" layer="94"/>
<rectangle x1="10.2426" y1="-6.5722" x2="11.2967" y2="-6.5595" layer="94"/>
<rectangle x1="-11.3601" y1="-6.5595" x2="-10.0901" y2="-6.5468" layer="94"/>
<rectangle x1="-9.4678" y1="-6.5595" x2="-8.1724" y2="-6.5468" layer="94"/>
<rectangle x1="-7.5374" y1="-6.5595" x2="-6.2674" y2="-6.5468" layer="94"/>
<rectangle x1="-5.6324" y1="-6.5595" x2="-4.3497" y2="-6.5468" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5595" x2="-1.4033" y2="-6.5468" layer="94"/>
<rectangle x1="-0.6032" y1="-6.5595" x2="0.4001" y2="-6.5468" layer="94"/>
<rectangle x1="1.1875" y1="-6.5595" x2="2.2162" y2="-6.5468" layer="94"/>
<rectangle x1="2.9909" y1="-6.5595" x2="4.1974" y2="-6.5468" layer="94"/>
<rectangle x1="4.4768" y1="-6.5595" x2="4.7562" y2="-6.5468" layer="94"/>
<rectangle x1="5.188" y1="-6.5595" x2="5.4674" y2="-6.5468" layer="94"/>
<rectangle x1="5.8992" y1="-6.5595" x2="6.1659" y2="-6.5468" layer="94"/>
<rectangle x1="6.6358" y1="-6.5595" x2="7.6645" y2="-6.5468" layer="94"/>
<rectangle x1="8.4392" y1="-6.5595" x2="9.4679" y2="-6.5468" layer="94"/>
<rectangle x1="10.2553" y1="-6.5595" x2="11.284" y2="-6.5468" layer="94"/>
<rectangle x1="-11.3601" y1="-6.5468" x2="-10.0901" y2="-6.5341" layer="94"/>
<rectangle x1="-9.4551" y1="-6.5468" x2="-8.1851" y2="-6.5341" layer="94"/>
<rectangle x1="-7.5374" y1="-6.5468" x2="-6.2674" y2="-6.5341" layer="94"/>
<rectangle x1="-5.6197" y1="-6.5468" x2="-4.3497" y2="-6.5341" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5468" x2="-1.416" y2="-6.5341" layer="94"/>
<rectangle x1="-0.6032" y1="-6.5468" x2="0.4001" y2="-6.5341" layer="94"/>
<rectangle x1="1.1875" y1="-6.5468" x2="2.2035" y2="-6.5341" layer="94"/>
<rectangle x1="3.0036" y1="-6.5468" x2="4.1974" y2="-6.5341" layer="94"/>
<rectangle x1="4.4768" y1="-6.5468" x2="4.7562" y2="-6.5341" layer="94"/>
<rectangle x1="5.188" y1="-6.5468" x2="5.4674" y2="-6.5341" layer="94"/>
<rectangle x1="5.8992" y1="-6.5468" x2="6.1659" y2="-6.5341" layer="94"/>
<rectangle x1="6.6358" y1="-6.5468" x2="7.6518" y2="-6.5341" layer="94"/>
<rectangle x1="8.4519" y1="-6.5468" x2="9.4552" y2="-6.5341" layer="94"/>
<rectangle x1="10.2553" y1="-6.5468" x2="11.2713" y2="-6.5341" layer="94"/>
<rectangle x1="-11.3474" y1="-6.5341" x2="-10.1028" y2="-6.5214" layer="94"/>
<rectangle x1="-9.4424" y1="-6.5341" x2="-8.1978" y2="-6.5214" layer="94"/>
<rectangle x1="-7.5247" y1="-6.5341" x2="-6.2801" y2="-6.5214" layer="94"/>
<rectangle x1="-5.607" y1="-6.5341" x2="-4.3624" y2="-6.5214" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5341" x2="-1.4287" y2="-6.5214" layer="94"/>
<rectangle x1="-0.5905" y1="-6.5341" x2="0.3874" y2="-6.5214" layer="94"/>
<rectangle x1="1.2002" y1="-6.5341" x2="2.2035" y2="-6.5214" layer="94"/>
<rectangle x1="3.0163" y1="-6.5341" x2="4.1974" y2="-6.5214" layer="94"/>
<rectangle x1="4.4768" y1="-6.5341" x2="4.7562" y2="-6.5214" layer="94"/>
<rectangle x1="5.188" y1="-6.5341" x2="5.4674" y2="-6.5214" layer="94"/>
<rectangle x1="5.8992" y1="-6.5341" x2="6.1659" y2="-6.5214" layer="94"/>
<rectangle x1="6.6485" y1="-6.5341" x2="7.6391" y2="-6.5214" layer="94"/>
<rectangle x1="8.4519" y1="-6.5341" x2="9.4425" y2="-6.5214" layer="94"/>
<rectangle x1="10.268" y1="-6.5341" x2="11.2586" y2="-6.5214" layer="94"/>
<rectangle x1="-11.3474" y1="-6.5214" x2="-10.1028" y2="-6.5087" layer="94"/>
<rectangle x1="-9.4297" y1="-6.5214" x2="-8.2105" y2="-6.5087" layer="94"/>
<rectangle x1="-7.5247" y1="-6.5214" x2="-6.2801" y2="-6.5087" layer="94"/>
<rectangle x1="-5.607" y1="-6.5214" x2="-4.3751" y2="-6.5087" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5214" x2="-1.4414" y2="-6.5087" layer="94"/>
<rectangle x1="-0.5778" y1="-6.5214" x2="0.3747" y2="-6.5087" layer="94"/>
<rectangle x1="1.2129" y1="-6.5214" x2="2.1908" y2="-6.5087" layer="94"/>
<rectangle x1="3.029" y1="-6.5214" x2="4.1974" y2="-6.5087" layer="94"/>
<rectangle x1="4.4768" y1="-6.5214" x2="4.7562" y2="-6.5087" layer="94"/>
<rectangle x1="5.188" y1="-6.5214" x2="5.4674" y2="-6.5087" layer="94"/>
<rectangle x1="5.8992" y1="-6.5214" x2="6.1659" y2="-6.5087" layer="94"/>
<rectangle x1="6.6739" y1="-6.5214" x2="7.6264" y2="-6.5087" layer="94"/>
<rectangle x1="8.4646" y1="-6.5214" x2="9.4298" y2="-6.5087" layer="94"/>
<rectangle x1="10.2807" y1="-6.5214" x2="11.2459" y2="-6.5087" layer="94"/>
<rectangle x1="-11.3347" y1="-6.5087" x2="-10.1155" y2="-6.496" layer="94"/>
<rectangle x1="-9.417" y1="-6.5087" x2="-8.2105" y2="-6.496" layer="94"/>
<rectangle x1="-7.512" y1="-6.5087" x2="-6.2928" y2="-6.496" layer="94"/>
<rectangle x1="-5.5943" y1="-6.5087" x2="-4.3878" y2="-6.496" layer="94"/>
<rectangle x1="-2.5971" y1="-6.5087" x2="-1.4668" y2="-6.496" layer="94"/>
<rectangle x1="-0.5651" y1="-6.5087" x2="0.3493" y2="-6.496" layer="94"/>
<rectangle x1="1.2256" y1="-6.5087" x2="2.1781" y2="-6.496" layer="94"/>
<rectangle x1="3.0417" y1="-6.5087" x2="4.1974" y2="-6.496" layer="94"/>
<rectangle x1="4.4768" y1="-6.5087" x2="4.7562" y2="-6.496" layer="94"/>
<rectangle x1="5.188" y1="-6.5087" x2="5.4674" y2="-6.496" layer="94"/>
<rectangle x1="5.8992" y1="-6.5087" x2="6.1659" y2="-6.496" layer="94"/>
<rectangle x1="6.6866" y1="-6.5087" x2="7.6137" y2="-6.496" layer="94"/>
<rectangle x1="8.4773" y1="-6.5087" x2="9.4171" y2="-6.496" layer="94"/>
<rectangle x1="10.3061" y1="-6.5087" x2="11.2332" y2="-6.496" layer="94"/>
<rectangle x1="-11.3347" y1="-6.496" x2="-10.1282" y2="-6.4833" layer="94"/>
<rectangle x1="-9.4043" y1="-6.496" x2="-8.2232" y2="-6.4833" layer="94"/>
<rectangle x1="-7.4993" y1="-6.496" x2="-6.2928" y2="-6.4833" layer="94"/>
<rectangle x1="-5.5943" y1="-6.496" x2="-4.4005" y2="-6.4833" layer="94"/>
<rectangle x1="-2.5971" y1="-6.496" x2="-1.4795" y2="-6.4833" layer="94"/>
<rectangle x1="-0.5524" y1="-6.496" x2="0.3366" y2="-6.4833" layer="94"/>
<rectangle x1="1.2383" y1="-6.496" x2="2.1527" y2="-6.4833" layer="94"/>
<rectangle x1="3.0671" y1="-6.496" x2="4.1974" y2="-6.4833" layer="94"/>
<rectangle x1="4.4768" y1="-6.496" x2="4.7562" y2="-6.4833" layer="94"/>
<rectangle x1="5.188" y1="-6.496" x2="5.4674" y2="-6.4833" layer="94"/>
<rectangle x1="5.8992" y1="-6.496" x2="6.1659" y2="-6.4833" layer="94"/>
<rectangle x1="6.6993" y1="-6.496" x2="7.5883" y2="-6.4833" layer="94"/>
<rectangle x1="8.49" y1="-6.496" x2="9.4044" y2="-6.4833" layer="94"/>
<rectangle x1="10.3188" y1="-6.496" x2="11.2078" y2="-6.4833" layer="94"/>
<rectangle x1="-11.322" y1="-6.4833" x2="-10.1409" y2="-6.4706" layer="94"/>
<rectangle x1="-9.4043" y1="-6.4833" x2="-8.2232" y2="-6.4706" layer="94"/>
<rectangle x1="-7.4866" y1="-6.4833" x2="-6.3055" y2="-6.4706" layer="94"/>
<rectangle x1="-5.5816" y1="-6.4833" x2="-4.4005" y2="-6.4706" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4833" x2="-1.4922" y2="-6.4706" layer="94"/>
<rectangle x1="-0.5397" y1="-6.4833" x2="0.3239" y2="-6.4706" layer="94"/>
<rectangle x1="1.2637" y1="-6.4833" x2="2.14" y2="-6.4706" layer="94"/>
<rectangle x1="3.0798" y1="-6.4833" x2="4.1974" y2="-6.4706" layer="94"/>
<rectangle x1="4.4895" y1="-6.4833" x2="4.7562" y2="-6.4706" layer="94"/>
<rectangle x1="5.188" y1="-6.4833" x2="5.4674" y2="-6.4706" layer="94"/>
<rectangle x1="5.8992" y1="-6.4833" x2="6.1659" y2="-6.4706" layer="94"/>
<rectangle x1="6.712" y1="-6.4833" x2="7.5756" y2="-6.4706" layer="94"/>
<rectangle x1="8.5154" y1="-6.4833" x2="9.3917" y2="-6.4706" layer="94"/>
<rectangle x1="10.3315" y1="-6.4833" x2="11.1951" y2="-6.4706" layer="94"/>
<rectangle x1="-11.322" y1="-6.4706" x2="-10.1536" y2="-6.4579" layer="94"/>
<rectangle x1="-9.3916" y1="-6.4706" x2="-8.2359" y2="-6.4579" layer="94"/>
<rectangle x1="-7.4739" y1="-6.4706" x2="-6.3182" y2="-6.4579" layer="94"/>
<rectangle x1="-5.5816" y1="-6.4706" x2="-4.4132" y2="-6.4579" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4706" x2="-1.5049" y2="-6.4579" layer="94"/>
<rectangle x1="-0.527" y1="-6.4706" x2="0.3112" y2="-6.4579" layer="94"/>
<rectangle x1="1.2764" y1="-6.4706" x2="2.1273" y2="-6.4579" layer="94"/>
<rectangle x1="3.0925" y1="-6.4706" x2="4.1974" y2="-6.4579" layer="94"/>
<rectangle x1="4.4895" y1="-6.4706" x2="4.7562" y2="-6.4579" layer="94"/>
<rectangle x1="5.188" y1="-6.4706" x2="5.4674" y2="-6.4579" layer="94"/>
<rectangle x1="5.8992" y1="-6.4706" x2="6.1659" y2="-6.4579" layer="94"/>
<rectangle x1="6.7247" y1="-6.4706" x2="7.5629" y2="-6.4579" layer="94"/>
<rectangle x1="8.5281" y1="-6.4706" x2="9.379" y2="-6.4579" layer="94"/>
<rectangle x1="10.3315" y1="-6.4706" x2="11.1824" y2="-6.4579" layer="94"/>
<rectangle x1="-11.3093" y1="-6.4579" x2="-10.1663" y2="-6.4452" layer="94"/>
<rectangle x1="-9.3916" y1="-6.4579" x2="-8.2359" y2="-6.4452" layer="94"/>
<rectangle x1="-7.4612" y1="-6.4579" x2="-6.3309" y2="-6.4452" layer="94"/>
<rectangle x1="-5.5689" y1="-6.4579" x2="-4.4132" y2="-6.4452" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4579" x2="-1.5176" y2="-6.4452" layer="94"/>
<rectangle x1="-0.5143" y1="-6.4579" x2="0.2985" y2="-6.4452" layer="94"/>
<rectangle x1="1.2891" y1="-6.4579" x2="2.1146" y2="-6.4452" layer="94"/>
<rectangle x1="3.1052" y1="-6.4579" x2="4.1974" y2="-6.4452" layer="94"/>
<rectangle x1="4.4895" y1="-6.4579" x2="4.7562" y2="-6.4452" layer="94"/>
<rectangle x1="5.2007" y1="-6.4579" x2="5.4674" y2="-6.4452" layer="94"/>
<rectangle x1="5.9119" y1="-6.4579" x2="6.1659" y2="-6.4452" layer="94"/>
<rectangle x1="6.7374" y1="-6.4579" x2="7.5502" y2="-6.4452" layer="94"/>
<rectangle x1="8.5408" y1="-6.4579" x2="9.3663" y2="-6.4452" layer="94"/>
<rectangle x1="10.3442" y1="-6.4579" x2="11.1697" y2="-6.4452" layer="94"/>
<rectangle x1="-11.2966" y1="-6.4452" x2="-10.1663" y2="-6.4325" layer="94"/>
<rectangle x1="-9.3789" y1="-6.4452" x2="-8.2486" y2="-6.4325" layer="94"/>
<rectangle x1="-7.4612" y1="-6.4452" x2="-6.3436" y2="-6.4325" layer="94"/>
<rectangle x1="-5.5562" y1="-6.4452" x2="-4.4259" y2="-6.4325" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4452" x2="-1.5303" y2="-6.4325" layer="94"/>
<rectangle x1="-0.5016" y1="-6.4452" x2="0.2858" y2="-6.4325" layer="94"/>
<rectangle x1="1.3018" y1="-6.4452" x2="2.1019" y2="-6.4325" layer="94"/>
<rectangle x1="3.1179" y1="-6.4452" x2="4.1974" y2="-6.4325" layer="94"/>
<rectangle x1="4.5022" y1="-6.4452" x2="4.7562" y2="-6.4325" layer="94"/>
<rectangle x1="5.2134" y1="-6.4452" x2="5.4674" y2="-6.4325" layer="94"/>
<rectangle x1="5.9246" y1="-6.4452" x2="6.1659" y2="-6.4325" layer="94"/>
<rectangle x1="6.7501" y1="-6.4452" x2="7.5375" y2="-6.4325" layer="94"/>
<rectangle x1="8.5535" y1="-6.4452" x2="9.3536" y2="-6.4325" layer="94"/>
<rectangle x1="10.3569" y1="-6.4452" x2="11.157" y2="-6.4325" layer="94"/>
<rectangle x1="-11.2712" y1="-6.4325" x2="-10.179" y2="-6.4198" layer="94"/>
<rectangle x1="-9.3789" y1="-6.4325" x2="-8.274" y2="-6.4198" layer="94"/>
<rectangle x1="-7.4485" y1="-6.4325" x2="-6.3563" y2="-6.4198" layer="94"/>
<rectangle x1="-5.5435" y1="-6.4325" x2="-4.4386" y2="-6.4198" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4325" x2="-1.5557" y2="-6.4198" layer="94"/>
<rectangle x1="-0.4889" y1="-6.4325" x2="0.2731" y2="-6.4198" layer="94"/>
<rectangle x1="1.3145" y1="-6.4325" x2="2.0765" y2="-6.4198" layer="94"/>
<rectangle x1="3.1433" y1="-6.4325" x2="4.1974" y2="-6.4198" layer="94"/>
<rectangle x1="4.5149" y1="-6.4325" x2="4.7562" y2="-6.4198" layer="94"/>
<rectangle x1="5.2388" y1="-6.4325" x2="5.4674" y2="-6.4198" layer="94"/>
<rectangle x1="5.9373" y1="-6.4325" x2="6.1659" y2="-6.4198" layer="94"/>
<rectangle x1="6.7755" y1="-6.4325" x2="7.5121" y2="-6.4198" layer="94"/>
<rectangle x1="8.5662" y1="-6.4325" x2="9.3409" y2="-6.4198" layer="94"/>
<rectangle x1="10.3823" y1="-6.4325" x2="11.1443" y2="-6.4198" layer="94"/>
<rectangle x1="-11.2585" y1="-6.4198" x2="-10.1917" y2="-6.4071" layer="94"/>
<rectangle x1="-9.3535" y1="-6.4198" x2="-8.2867" y2="-6.4071" layer="94"/>
<rectangle x1="-7.4358" y1="-6.4198" x2="-6.369" y2="-6.4071" layer="94"/>
<rectangle x1="-5.5308" y1="-6.4198" x2="-4.4513" y2="-6.4071" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4198" x2="-1.5811" y2="-6.4071" layer="94"/>
<rectangle x1="-0.4508" y1="-6.4198" x2="0.235" y2="-6.4071" layer="94"/>
<rectangle x1="1.3526" y1="-6.4198" x2="2.0511" y2="-6.4071" layer="94"/>
<rectangle x1="3.1687" y1="-6.4198" x2="4.1974" y2="-6.4071" layer="94"/>
<rectangle x1="4.553" y1="-6.4198" x2="4.7562" y2="-6.4071" layer="94"/>
<rectangle x1="5.2642" y1="-6.4198" x2="5.4674" y2="-6.4071" layer="94"/>
<rectangle x1="5.9627" y1="-6.4198" x2="6.1659" y2="-6.4071" layer="94"/>
<rectangle x1="6.8009" y1="-6.4198" x2="7.4867" y2="-6.4071" layer="94"/>
<rectangle x1="8.6043" y1="-6.4198" x2="9.3028" y2="-6.4071" layer="94"/>
<rectangle x1="10.4077" y1="-6.4198" x2="11.1062" y2="-6.4071" layer="94"/>
<rectangle x1="-11.2458" y1="-6.4071" x2="-10.2044" y2="-6.3944" layer="94"/>
<rectangle x1="-9.3408" y1="-6.4071" x2="-8.2994" y2="-6.3944" layer="94"/>
<rectangle x1="-7.4104" y1="-6.4071" x2="-6.3817" y2="-6.3944" layer="94"/>
<rectangle x1="-5.5181" y1="-6.4071" x2="-4.4767" y2="-6.3944" layer="94"/>
<rectangle x1="-2.5971" y1="-6.4071" x2="-1.6065" y2="-6.3944" layer="94"/>
<rectangle x1="-0.4254" y1="-6.4071" x2="0.2096" y2="-6.3944" layer="94"/>
<rectangle x1="1.3907" y1="-6.4071" x2="2.013" y2="-6.3944" layer="94"/>
<rectangle x1="3.1941" y1="-6.4071" x2="3.8164" y2="-6.3944" layer="94"/>
<rectangle x1="3.8545" y1="-6.4071" x2="4.1974" y2="-6.3944" layer="94"/>
<rectangle x1="4.6038" y1="-6.4071" x2="4.7562" y2="-6.3944" layer="94"/>
<rectangle x1="5.3023" y1="-6.4071" x2="5.4674" y2="-6.3944" layer="94"/>
<rectangle x1="6.0008" y1="-6.4071" x2="6.1659" y2="-6.3944" layer="94"/>
<rectangle x1="6.8263" y1="-6.4071" x2="7.4486" y2="-6.3944" layer="94"/>
<rectangle x1="8.6297" y1="-6.4071" x2="9.2647" y2="-6.3944" layer="94"/>
<rectangle x1="10.4458" y1="-6.4071" x2="11.0681" y2="-6.3944" layer="94"/>
<rectangle x1="-11.2458" y1="-6.3944" x2="-10.2171" y2="-6.3817" layer="94"/>
<rectangle x1="-9.3281" y1="-6.3944" x2="-8.3121" y2="-6.3817" layer="94"/>
<rectangle x1="-7.3977" y1="-6.3944" x2="-6.3944" y2="-6.3817" layer="94"/>
<rectangle x1="-5.5054" y1="-6.3944" x2="-4.4894" y2="-6.3817" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3944" x2="-2.2923" y2="-6.3817" layer="94"/>
<rectangle x1="-2.2034" y1="-6.3944" x2="-1.6319" y2="-6.3817" layer="94"/>
<rectangle x1="-0.4" y1="-6.3944" x2="0.1842" y2="-6.3817" layer="94"/>
<rectangle x1="1.4161" y1="-6.3944" x2="2.0003" y2="-6.3817" layer="94"/>
<rectangle x1="3.2322" y1="-6.3944" x2="3.791" y2="-6.3817" layer="94"/>
<rectangle x1="3.8799" y1="-6.3944" x2="4.1974" y2="-6.3817" layer="94"/>
<rectangle x1="4.6292" y1="-6.3944" x2="4.7562" y2="-6.3817" layer="94"/>
<rectangle x1="5.3277" y1="-6.3944" x2="5.4674" y2="-6.3817" layer="94"/>
<rectangle x1="6.0262" y1="-6.3944" x2="6.1659" y2="-6.3817" layer="94"/>
<rectangle x1="6.8517" y1="-6.3944" x2="7.4232" y2="-6.3817" layer="94"/>
<rectangle x1="8.6424" y1="-6.3944" x2="9.2393" y2="-6.3817" layer="94"/>
<rectangle x1="10.4712" y1="-6.3944" x2="11.0427" y2="-6.3817" layer="94"/>
<rectangle x1="-11.2331" y1="-6.3817" x2="-10.2298" y2="-6.369" layer="94"/>
<rectangle x1="-9.3154" y1="-6.3817" x2="-8.3248" y2="-6.369" layer="94"/>
<rectangle x1="-7.385" y1="-6.3817" x2="-6.4071" y2="-6.369" layer="94"/>
<rectangle x1="-5.4927" y1="-6.3817" x2="-4.4894" y2="-6.369" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3817" x2="-2.305" y2="-6.369" layer="94"/>
<rectangle x1="-2.1907" y1="-6.3817" x2="-1.6446" y2="-6.369" layer="94"/>
<rectangle x1="-0.3873" y1="-6.3817" x2="0.1715" y2="-6.369" layer="94"/>
<rectangle x1="1.4288" y1="-6.3817" x2="1.9749" y2="-6.369" layer="94"/>
<rectangle x1="3.2449" y1="-6.3817" x2="3.7783" y2="-6.369" layer="94"/>
<rectangle x1="3.8799" y1="-6.3817" x2="4.1974" y2="-6.369" layer="94"/>
<rectangle x1="4.6419" y1="-6.3817" x2="4.7562" y2="-6.369" layer="94"/>
<rectangle x1="5.3404" y1="-6.3817" x2="5.4674" y2="-6.369" layer="94"/>
<rectangle x1="6.0389" y1="-6.3817" x2="6.1659" y2="-6.369" layer="94"/>
<rectangle x1="6.8771" y1="-6.3817" x2="7.4105" y2="-6.369" layer="94"/>
<rectangle x1="8.6678" y1="-6.3817" x2="9.2266" y2="-6.369" layer="94"/>
<rectangle x1="10.4839" y1="-6.3817" x2="11.03" y2="-6.369" layer="94"/>
<rectangle x1="-11.2204" y1="-6.369" x2="-10.2425" y2="-6.3563" layer="94"/>
<rectangle x1="-9.3027" y1="-6.369" x2="-8.3248" y2="-6.3563" layer="94"/>
<rectangle x1="-7.3723" y1="-6.369" x2="-6.4198" y2="-6.3563" layer="94"/>
<rectangle x1="-5.48" y1="-6.369" x2="-4.5021" y2="-6.3563" layer="94"/>
<rectangle x1="-2.5971" y1="-6.369" x2="-2.3177" y2="-6.3563" layer="94"/>
<rectangle x1="-2.1653" y1="-6.369" x2="-1.67" y2="-6.3563" layer="94"/>
<rectangle x1="-0.3619" y1="-6.369" x2="0.1461" y2="-6.3563" layer="94"/>
<rectangle x1="1.4415" y1="-6.369" x2="1.9622" y2="-6.3563" layer="94"/>
<rectangle x1="3.2576" y1="-6.369" x2="3.7656" y2="-6.3563" layer="94"/>
<rectangle x1="3.8926" y1="-6.369" x2="4.1974" y2="-6.3563" layer="94"/>
<rectangle x1="4.6546" y1="-6.369" x2="4.7435" y2="-6.3563" layer="94"/>
<rectangle x1="5.3531" y1="-6.369" x2="5.4674" y2="-6.3563" layer="94"/>
<rectangle x1="6.0516" y1="-6.369" x2="6.1532" y2="-6.3563" layer="94"/>
<rectangle x1="6.8898" y1="-6.369" x2="7.3978" y2="-6.3563" layer="94"/>
<rectangle x1="8.6805" y1="-6.369" x2="9.2139" y2="-6.3563" layer="94"/>
<rectangle x1="10.5093" y1="-6.369" x2="11.0046" y2="-6.3563" layer="94"/>
<rectangle x1="-11.195" y1="-6.3563" x2="-10.2552" y2="-6.3436" layer="94"/>
<rectangle x1="-9.29" y1="-6.3563" x2="-8.3375" y2="-6.3436" layer="94"/>
<rectangle x1="-7.3723" y1="-6.3563" x2="-6.4325" y2="-6.3436" layer="94"/>
<rectangle x1="-5.4673" y1="-6.3563" x2="-4.5148" y2="-6.3436" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3563" x2="-2.3177" y2="-6.3436" layer="94"/>
<rectangle x1="-2.1399" y1="-6.3563" x2="-1.6954" y2="-6.3436" layer="94"/>
<rectangle x1="-0.3492" y1="-6.3563" x2="0.1334" y2="-6.3436" layer="94"/>
<rectangle x1="1.4669" y1="-6.3563" x2="1.9241" y2="-6.3436" layer="94"/>
<rectangle x1="3.283" y1="-6.3563" x2="3.7402" y2="-6.3436" layer="94"/>
<rectangle x1="3.8926" y1="-6.3563" x2="4.1974" y2="-6.3436" layer="94"/>
<rectangle x1="4.6673" y1="-6.3563" x2="4.7308" y2="-6.3436" layer="94"/>
<rectangle x1="5.3912" y1="-6.3563" x2="5.442" y2="-6.3436" layer="94"/>
<rectangle x1="6.077" y1="-6.3563" x2="6.1532" y2="-6.3436" layer="94"/>
<rectangle x1="6.9152" y1="-6.3563" x2="7.3724" y2="-6.3436" layer="94"/>
<rectangle x1="8.7059" y1="-6.3563" x2="9.1885" y2="-6.3436" layer="94"/>
<rectangle x1="10.522" y1="-6.3563" x2="10.9792" y2="-6.3436" layer="94"/>
<rectangle x1="-11.1823" y1="-6.3436" x2="-10.2679" y2="-6.3309" layer="94"/>
<rectangle x1="-9.2646" y1="-6.3436" x2="-8.3629" y2="-6.3309" layer="94"/>
<rectangle x1="-7.3469" y1="-6.3436" x2="-6.4452" y2="-6.3309" layer="94"/>
<rectangle x1="-5.4546" y1="-6.3436" x2="-4.5402" y2="-6.3309" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3436" x2="-2.3177" y2="-6.3309" layer="94"/>
<rectangle x1="-2.1018" y1="-6.3436" x2="-1.7462" y2="-6.3309" layer="94"/>
<rectangle x1="-0.2984" y1="-6.3436" x2="0.0699" y2="-6.3309" layer="94"/>
<rectangle x1="1.5177" y1="-6.3436" x2="1.8733" y2="-6.3309" layer="94"/>
<rectangle x1="3.3211" y1="-6.3436" x2="3.7021" y2="-6.3309" layer="94"/>
<rectangle x1="3.8926" y1="-6.3436" x2="4.1974" y2="-6.3309" layer="94"/>
<rectangle x1="6.9533" y1="-6.3436" x2="7.3216" y2="-6.3309" layer="94"/>
<rectangle x1="8.7567" y1="-6.3436" x2="9.1377" y2="-6.3309" layer="94"/>
<rectangle x1="10.5855" y1="-6.3436" x2="10.9284" y2="-6.3309" layer="94"/>
<rectangle x1="-11.1569" y1="-6.3309" x2="-10.2933" y2="-6.3182" layer="94"/>
<rectangle x1="-9.2392" y1="-6.3309" x2="-8.3883" y2="-6.3182" layer="94"/>
<rectangle x1="-7.3342" y1="-6.3309" x2="-6.4706" y2="-6.3182" layer="94"/>
<rectangle x1="-5.4292" y1="-6.3309" x2="-4.5656" y2="-6.3182" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3309" x2="-2.3177" y2="-6.3182" layer="94"/>
<rectangle x1="-1.9748" y1="-6.3309" x2="-1.8859" y2="-6.3182" layer="94"/>
<rectangle x1="-0.1587" y1="-6.3309" x2="-0.0317" y2="-6.3182" layer="94"/>
<rectangle x1="1.632" y1="-6.3309" x2="1.7463" y2="-6.3182" layer="94"/>
<rectangle x1="3.4481" y1="-6.3309" x2="3.5624" y2="-6.3182" layer="94"/>
<rectangle x1="3.8926" y1="-6.3309" x2="4.1974" y2="-6.3182" layer="94"/>
<rectangle x1="7.093" y1="-6.3309" x2="7.1819" y2="-6.3182" layer="94"/>
<rectangle x1="8.8964" y1="-6.3309" x2="9.0234" y2="-6.3182" layer="94"/>
<rectangle x1="10.6871" y1="-6.3309" x2="10.8141" y2="-6.3182" layer="94"/>
<rectangle x1="-11.1442" y1="-6.3182" x2="-10.3187" y2="-6.3055" layer="94"/>
<rectangle x1="-9.2265" y1="-6.3182" x2="-8.4137" y2="-6.3055" layer="94"/>
<rectangle x1="-7.3088" y1="-6.3182" x2="-6.496" y2="-6.3055" layer="94"/>
<rectangle x1="-5.4038" y1="-6.3182" x2="-4.5783" y2="-6.3055" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3182" x2="-2.3177" y2="-6.3055" layer="94"/>
<rectangle x1="3.8926" y1="-6.3182" x2="4.1974" y2="-6.3055" layer="94"/>
<rectangle x1="-11.1315" y1="-6.3055" x2="-10.3314" y2="-6.2928" layer="94"/>
<rectangle x1="-9.2138" y1="-6.3055" x2="-8.4264" y2="-6.2928" layer="94"/>
<rectangle x1="-7.2961" y1="-6.3055" x2="-6.5087" y2="-6.2928" layer="94"/>
<rectangle x1="-5.3911" y1="-6.3055" x2="-4.6037" y2="-6.2928" layer="94"/>
<rectangle x1="-2.5971" y1="-6.3055" x2="-2.3177" y2="-6.2928" layer="94"/>
<rectangle x1="3.8926" y1="-6.3055" x2="4.1974" y2="-6.2928" layer="94"/>
<rectangle x1="-11.1061" y1="-6.2928" x2="-10.3441" y2="-6.2801" layer="94"/>
<rectangle x1="-9.1884" y1="-6.2928" x2="-8.4391" y2="-6.2801" layer="94"/>
<rectangle x1="-7.2834" y1="-6.2928" x2="-6.5214" y2="-6.2801" layer="94"/>
<rectangle x1="-5.3784" y1="-6.2928" x2="-4.6037" y2="-6.2801" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2928" x2="-2.3177" y2="-6.2801" layer="94"/>
<rectangle x1="3.8926" y1="-6.2928" x2="4.1974" y2="-6.2801" layer="94"/>
<rectangle x1="-11.0934" y1="-6.2801" x2="-10.3568" y2="-6.2674" layer="94"/>
<rectangle x1="-9.1757" y1="-6.2801" x2="-8.4518" y2="-6.2674" layer="94"/>
<rectangle x1="-7.2707" y1="-6.2801" x2="-6.5341" y2="-6.2674" layer="94"/>
<rectangle x1="-5.353" y1="-6.2801" x2="-4.6291" y2="-6.2674" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2801" x2="-2.3177" y2="-6.2674" layer="94"/>
<rectangle x1="3.8926" y1="-6.2801" x2="4.1974" y2="-6.2674" layer="94"/>
<rectangle x1="-11.0807" y1="-6.2674" x2="-10.3822" y2="-6.2547" layer="94"/>
<rectangle x1="-9.163" y1="-6.2674" x2="-8.4772" y2="-6.2547" layer="94"/>
<rectangle x1="-7.258" y1="-6.2674" x2="-6.5595" y2="-6.2547" layer="94"/>
<rectangle x1="-5.3403" y1="-6.2674" x2="-4.6545" y2="-6.2547" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2674" x2="-2.3177" y2="-6.2547" layer="94"/>
<rectangle x1="3.9053" y1="-6.2674" x2="4.1974" y2="-6.2547" layer="94"/>
<rectangle x1="-11.0426" y1="-6.2547" x2="-10.4203" y2="-6.242" layer="94"/>
<rectangle x1="-9.1249" y1="-6.2547" x2="-8.5026" y2="-6.242" layer="94"/>
<rectangle x1="-7.2199" y1="-6.2547" x2="-6.5976" y2="-6.242" layer="94"/>
<rectangle x1="-5.3149" y1="-6.2547" x2="-4.6926" y2="-6.242" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2547" x2="-2.3177" y2="-6.242" layer="94"/>
<rectangle x1="3.9053" y1="-6.2547" x2="4.1974" y2="-6.242" layer="94"/>
<rectangle x1="-10.9918" y1="-6.242" x2="-10.4711" y2="-6.2293" layer="94"/>
<rectangle x1="-9.0614" y1="-6.242" x2="-8.5534" y2="-6.2293" layer="94"/>
<rectangle x1="-7.1691" y1="-6.242" x2="-6.6484" y2="-6.2293" layer="94"/>
<rectangle x1="-5.2514" y1="-6.242" x2="-4.7434" y2="-6.2293" layer="94"/>
<rectangle x1="-2.5971" y1="-6.242" x2="-2.3177" y2="-6.2293" layer="94"/>
<rectangle x1="3.9053" y1="-6.242" x2="4.1974" y2="-6.2293" layer="94"/>
<rectangle x1="-10.9537" y1="-6.2293" x2="-10.5092" y2="-6.2166" layer="94"/>
<rectangle x1="-9.0233" y1="-6.2293" x2="-8.6042" y2="-6.2166" layer="94"/>
<rectangle x1="-7.1183" y1="-6.2293" x2="-6.6992" y2="-6.2166" layer="94"/>
<rectangle x1="-5.2133" y1="-6.2293" x2="-4.7815" y2="-6.2166" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2293" x2="-2.3177" y2="-6.2166" layer="94"/>
<rectangle x1="3.9053" y1="-6.2293" x2="4.1974" y2="-6.2166" layer="94"/>
<rectangle x1="-10.9156" y1="-6.2166" x2="-10.5473" y2="-6.2039" layer="94"/>
<rectangle x1="-8.9979" y1="-6.2166" x2="-8.6296" y2="-6.2039" layer="94"/>
<rectangle x1="-7.0802" y1="-6.2166" x2="-6.7373" y2="-6.2039" layer="94"/>
<rectangle x1="-5.1752" y1="-6.2166" x2="-4.8069" y2="-6.2039" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2166" x2="-2.3177" y2="-6.2039" layer="94"/>
<rectangle x1="3.8926" y1="-6.2166" x2="4.1974" y2="-6.2039" layer="94"/>
<rectangle x1="-10.8775" y1="-6.2039" x2="-10.5727" y2="-6.1912" layer="94"/>
<rectangle x1="-8.9725" y1="-6.2039" x2="-8.6677" y2="-6.1912" layer="94"/>
<rectangle x1="-7.0421" y1="-6.2039" x2="-6.7627" y2="-6.1912" layer="94"/>
<rectangle x1="-5.1498" y1="-6.2039" x2="-4.8323" y2="-6.1912" layer="94"/>
<rectangle x1="-2.5971" y1="-6.2039" x2="-2.3177" y2="-6.1912" layer="94"/>
<rectangle x1="3.9053" y1="-6.2039" x2="4.1974" y2="-6.1912" layer="94"/>
<rectangle x1="-10.814" y1="-6.1912" x2="-10.6235" y2="-6.1785" layer="94"/>
<rectangle x1="-8.9344" y1="-6.1912" x2="-8.7312" y2="-6.1785" layer="94"/>
<rectangle x1="-7.004" y1="-6.1912" x2="-6.8135" y2="-6.1785" layer="94"/>
<rectangle x1="-5.0863" y1="-6.1912" x2="-4.8704" y2="-6.1785" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1912" x2="-2.3177" y2="-6.1785" layer="94"/>
<rectangle x1="3.9053" y1="-6.1912" x2="4.1974" y2="-6.1785" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1785" x2="-2.3177" y2="-6.1658" layer="94"/>
<rectangle x1="3.8926" y1="-6.1785" x2="4.1974" y2="-6.1658" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1658" x2="-2.3177" y2="-6.1531" layer="94"/>
<rectangle x1="3.9053" y1="-6.1658" x2="4.1974" y2="-6.1531" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1531" x2="-2.3177" y2="-6.1404" layer="94"/>
<rectangle x1="3.9053" y1="-6.1531" x2="4.1974" y2="-6.1404" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1404" x2="-2.3177" y2="-6.1277" layer="94"/>
<rectangle x1="3.8926" y1="-6.1404" x2="4.1974" y2="-6.1277" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1277" x2="-2.3177" y2="-6.115" layer="94"/>
<rectangle x1="3.9053" y1="-6.1277" x2="4.1974" y2="-6.115" layer="94"/>
<rectangle x1="-2.5971" y1="-6.115" x2="-2.3177" y2="-6.1023" layer="94"/>
<rectangle x1="3.8926" y1="-6.115" x2="4.1974" y2="-6.1023" layer="94"/>
<rectangle x1="-2.5971" y1="-6.1023" x2="-2.3177" y2="-6.0896" layer="94"/>
<rectangle x1="3.8926" y1="-6.1023" x2="4.1974" y2="-6.0896" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0896" x2="-2.3177" y2="-6.0769" layer="94"/>
<rectangle x1="3.9053" y1="-6.0896" x2="4.1974" y2="-6.0769" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0769" x2="-2.3177" y2="-6.0642" layer="94"/>
<rectangle x1="3.9053" y1="-6.0769" x2="4.1974" y2="-6.0642" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0642" x2="-2.3177" y2="-6.0515" layer="94"/>
<rectangle x1="3.8926" y1="-6.0642" x2="4.1974" y2="-6.0515" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0515" x2="-2.3177" y2="-6.0388" layer="94"/>
<rectangle x1="3.9053" y1="-6.0515" x2="4.1974" y2="-6.0388" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0388" x2="-2.3177" y2="-6.0261" layer="94"/>
<rectangle x1="3.9053" y1="-6.0388" x2="4.1974" y2="-6.0261" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0261" x2="-2.3177" y2="-6.0134" layer="94"/>
<rectangle x1="3.9053" y1="-6.0261" x2="4.1974" y2="-6.0134" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0134" x2="-2.3177" y2="-6.0007" layer="94"/>
<rectangle x1="3.8926" y1="-6.0134" x2="4.1974" y2="-6.0007" layer="94"/>
<rectangle x1="-2.5971" y1="-6.0007" x2="-2.3177" y2="-5.988" layer="94"/>
<rectangle x1="3.9053" y1="-6.0007" x2="4.1974" y2="-5.988" layer="94"/>
<rectangle x1="-2.5971" y1="-5.988" x2="-2.3177" y2="-5.9753" layer="94"/>
<rectangle x1="3.9053" y1="-5.988" x2="4.1974" y2="-5.9753" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9753" x2="-2.3177" y2="-5.9626" layer="94"/>
<rectangle x1="3.9053" y1="-5.9753" x2="4.1974" y2="-5.9626" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9626" x2="-2.3177" y2="-5.9499" layer="94"/>
<rectangle x1="3.8926" y1="-5.9626" x2="4.1974" y2="-5.9499" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9499" x2="-2.3177" y2="-5.9372" layer="94"/>
<rectangle x1="3.9053" y1="-5.9499" x2="4.1974" y2="-5.9372" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9372" x2="-2.3177" y2="-5.9245" layer="94"/>
<rectangle x1="3.8926" y1="-5.9372" x2="4.1974" y2="-5.9245" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9245" x2="-2.3177" y2="-5.9118" layer="94"/>
<rectangle x1="3.9053" y1="-5.9245" x2="4.1974" y2="-5.9118" layer="94"/>
<rectangle x1="-2.5971" y1="-5.9118" x2="-2.3177" y2="-5.8991" layer="94"/>
<rectangle x1="3.9053" y1="-5.9118" x2="4.1974" y2="-5.8991" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8991" x2="-2.3177" y2="-5.8864" layer="94"/>
<rectangle x1="3.9053" y1="-5.8991" x2="4.1974" y2="-5.8864" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8864" x2="-2.3177" y2="-5.8737" layer="94"/>
<rectangle x1="3.9053" y1="-5.8864" x2="4.1974" y2="-5.8737" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8737" x2="-2.3177" y2="-5.861" layer="94"/>
<rectangle x1="3.9053" y1="-5.8737" x2="4.1974" y2="-5.861" layer="94"/>
<rectangle x1="-2.5971" y1="-5.861" x2="-2.3177" y2="-5.8483" layer="94"/>
<rectangle x1="3.8926" y1="-5.861" x2="4.1974" y2="-5.8483" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8483" x2="-2.3177" y2="-5.8356" layer="94"/>
<rectangle x1="3.8926" y1="-5.8483" x2="4.1974" y2="-5.8356" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8356" x2="-2.3177" y2="-5.8229" layer="94"/>
<rectangle x1="3.8926" y1="-5.8356" x2="4.1974" y2="-5.8229" layer="94"/>
<rectangle x1="-2.6098" y1="-5.8229" x2="-2.3177" y2="-5.8102" layer="94"/>
<rectangle x1="3.8926" y1="-5.8229" x2="4.1974" y2="-5.8102" layer="94"/>
<rectangle x1="-2.5971" y1="-5.8102" x2="-2.3177" y2="-5.7975" layer="94"/>
<rectangle x1="3.8926" y1="-5.8102" x2="4.1974" y2="-5.7975" layer="94"/>
<rectangle x1="-2.5971" y1="-5.7975" x2="-2.3177" y2="-5.7848" layer="94"/>
<rectangle x1="3.8926" y1="-5.7975" x2="4.1974" y2="-5.7848" layer="94"/>
<rectangle x1="-2.5971" y1="-5.7848" x2="-2.3177" y2="-5.7721" layer="94"/>
<rectangle x1="3.9053" y1="-5.7848" x2="4.1974" y2="-5.7721" layer="94"/>
<rectangle x1="-2.5971" y1="-5.7721" x2="-2.3177" y2="-5.7594" layer="94"/>
<rectangle x1="3.9053" y1="-5.7721" x2="4.1974" y2="-5.7594" layer="94"/>
<rectangle x1="-2.5844" y1="-5.7594" x2="-2.3177" y2="-5.7467" layer="94"/>
<rectangle x1="3.9053" y1="-5.7594" x2="4.1974" y2="-5.7467" layer="94"/>
<rectangle x1="-2.5717" y1="-5.7467" x2="-2.3177" y2="-5.734" layer="94"/>
<rectangle x1="3.918" y1="-5.7467" x2="4.1974" y2="-5.734" layer="94"/>
<rectangle x1="-2.559" y1="-5.734" x2="-2.3177" y2="-5.7213" layer="94"/>
<rectangle x1="3.9434" y1="-5.734" x2="4.1974" y2="-5.7213" layer="94"/>
<rectangle x1="-2.5463" y1="-5.7213" x2="-2.3177" y2="-5.7086" layer="94"/>
<rectangle x1="3.9688" y1="-5.7213" x2="4.1974" y2="-5.7086" layer="94"/>
<rectangle x1="-2.5336" y1="-5.7086" x2="-2.3177" y2="-5.6959" layer="94"/>
<rectangle x1="3.9815" y1="-5.7086" x2="4.1974" y2="-5.6959" layer="94"/>
<rectangle x1="-2.5082" y1="-5.6959" x2="-2.3177" y2="-5.6832" layer="94"/>
<rectangle x1="4.0069" y1="-5.6959" x2="4.1974" y2="-5.6832" layer="94"/>
<rectangle x1="-2.4955" y1="-5.6832" x2="-2.3304" y2="-5.6705" layer="94"/>
<rectangle x1="4.0196" y1="-5.6832" x2="4.1974" y2="-5.6705" layer="94"/>
<rectangle x1="-2.4701" y1="-5.6705" x2="-2.3304" y2="-5.6578" layer="94"/>
<rectangle x1="4.0577" y1="-5.6705" x2="4.1847" y2="-5.6578" layer="94"/>
<rectangle x1="-2.4066" y1="-5.6578" x2="-2.3558" y2="-5.6451" layer="94"/>
<rectangle x1="4.1085" y1="-5.6578" x2="4.1593" y2="-5.6451" layer="94"/>
<polygon width="0.381" layer="94">
<vertex x="1.5036" y="-3.63" curve="9.499632"/>
<vertex x="2.0821" y="-3.3321"/>
<vertex x="3.5185" y="-4.5035"/>
<vertex x="4.5035" y="-3.5185"/>
<vertex x="3.3321" y="-2.0821" curve="18.999117"/>
<vertex x="3.8284" y="-0.8839"/>
<vertex x="5.6724" y="-0.6965"/>
<vertex x="5.6724" y="0.6965"/>
<vertex x="3.8284" y="0.8839" curve="18.999117"/>
<vertex x="3.3321" y="2.0821"/>
<vertex x="4.5035" y="3.5185"/>
<vertex x="3.5185" y="4.5035"/>
<vertex x="2.0821" y="3.3321" curve="18.999117"/>
<vertex x="0.8839" y="3.8284"/>
<vertex x="0.6965" y="5.6724"/>
<vertex x="-0.6965" y="5.6724"/>
<vertex x="-0.8839" y="3.8284" curve="18.999117"/>
<vertex x="-2.0821" y="3.3321"/>
<vertex x="-3.5185" y="4.5035"/>
<vertex x="-4.5035" y="3.5185"/>
<vertex x="-3.3321" y="2.0821" curve="18.999117"/>
<vertex x="-3.8284" y="0.8839"/>
<vertex x="-5.6724" y="0.6965"/>
<vertex x="-5.6724" y="-0.6965"/>
<vertex x="-3.8284" y="-0.8839" curve="18.999117"/>
<vertex x="-3.3321" y="-2.0821"/>
<vertex x="-4.5035" y="-3.5185"/>
<vertex x="-3.5185" y="-4.5035"/>
<vertex x="-2.0821" y="-3.3321" curve="9.499632"/>
<vertex x="-1.5036" y="-3.63"/>
<vertex x="-0.6834" y="-1.65" curve="-67.502133"/>
<vertex x="-1.7859" y="0" curve="-247.502133"/>
<vertex x="0.6834" y="-1.65"/>
</polygon>
</symbol>
<symbol name="SPARKFUN-EAGLE-RULES">
<wire x1="0" y1="284.48" x2="248.92" y2="284.48" width="0.254" layer="94"/>
<wire x1="248.92" y1="284.48" x2="248.92" y2="0" width="0.254" layer="94"/>
<wire x1="248.92" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="284.48" width="0.254" layer="94"/>
<text x="2.54" y="269.24" size="2.54" layer="92">File Names</text>
<text x="7.62" y="266.7" size="1.778" layer="94">1. Directory names will be: "Thingy"</text>
<text x="10.16" y="264.16" size="1.778" layer="94"> 1. No version number or production variation like 'Thingy with Chip Antenna'</text>
<text x="7.62" y="261.62" size="1.778" layer="94">2. File names are</text>
<text x="10.16" y="259.08" size="1.778" layer="94">1. Thingy-v10.sch</text>
<text x="10.16" y="256.54" size="1.778" layer="94">2. Thingy-v10.brd</text>
<text x="7.62" y="254" size="1.778" layer="94">3. Panel names are: Thingy-Panel-v10.brd</text>
<text x="7.62" y="251.46" size="1.778" layer="94">4. Minor versions are: Thingy-v11, v12, v13</text>
<text x="7.62" y="248.92" size="1.778" layer="94">5. Major versions are v10, v20, v30.</text>
<text x="7.62" y="246.38" size="1.778" layer="94">6. Prototypes/New Products start in the sandbox then migrate to the store front specific category once listed in the storefront. </text>
<text x="2.54" y="241.3" size="2.54" layer="92">Schematic Layout</text>
<text x="7.62" y="238.76" size="1.778" layer="94">1. All parts stay on a 0.1" grid. Do not violate this rule.</text>
<text x="7.62" y="236.22" size="1.778" layer="94">2. All GND connections use the GND symbol.</text>
<text x="7.62" y="233.68" size="1.778" layer="94">3. All VCC, 5V, 3.3V etc. will use the appropriate power symbol.</text>
<text x="7.62" y="231.14" size="1.778" layer="94">4. Name all components with standard names (No dollars signs allowed!):</text>
<text x="10.16" y="228.6" size="1.778" layer="94">1. U# - ICs</text>
<text x="10.16" y="226.06" size="1.778" layer="94">2. Q# - Transistors</text>
<text x="10.16" y="223.52" size="1.778" layer="94">3. R#/C#/L# - Resistors/Capacitors/Inductors</text>
<text x="10.16" y="220.98" size="1.778" layer="94">4. Y# - Antennas and Crystals/Resonators</text>
<text x="10.16" y="218.44" size="1.778" layer="94">5. D# - LEDs and Diodes</text>
<text x="10.16" y="215.9" size="1.778" layer="94">6. S# - Switches</text>
<text x="10.16" y="213.36" size="1.778" layer="94">7. JP# - Connectors and Headers</text>
<text x="10.16" y="210.82" size="1.778" layer="94">8. 'U$3' is bad. If a part automatically puts a "$" in the name, it needs to be fixed.</text>
<text x="7.62" y="205.74" size="1.778" layer="94">5. Every schematic will have the part FRAME-LETTER added to it.</text>
<text x="7.62" y="203.2" size="1.778" layer="94">6. Use two fiducials on each board where applicable. Use your judgement. Small boards (less than 1x1") can skip this rule.</text>
<text x="10.16" y="200.66" size="1.778" layer="94">1. Add the part FIDUCIAL to the schematic. It's OK to use the smallest 1x2mm footprint.</text>
<text x="7.62" y="198.12" size="1.778" layer="94">7. If board is larger than 1", then seriously consider standoffs. Use your judgement.</text>
<text x="10.16" y="195.58" size="1.778" layer="94">1. Add part STANDOFF to the schematic. This part has a keepout layer to show you where the head of the standoff screw will be. </text>
<text x="7.62" y="193.04" size="1.778" layer="94">8. Add fiducials, standoff components and logo box to the lower right area of the schematic sheet.</text>
<text x="7.62" y="190.5" size="1.778" layer="94">9. Use dashed gray lines to separate a complex design into various smaller bits.</text>
<text x="10.16" y="187.96" size="1.778" layer="94">1. For example: charge circuit, accelerometer, microcontroller, etc. </text>
<text x="2.54" y="180.34" size="2.54" layer="92">PCB Layout</text>
<text x="7.62" y="177.8" size="1.778" layer="94">1. Create the board frame on a 0.1" grid.</text>
<text x="10.16" y="175.26" size="1.778" layer="94">1. Make the lower left corner start at 0,0. </text>
<text x="7.62" y="172.72" size="1.778" layer="94">2. Change the line width of the board frame to .008"</text>
<text x="7.62" y="170.18" size="1.778" layer="94">3. Board frame will be square unless called for by special requirements of the design.</text>
<text x="7.62" y="162.56" size="1.778" layer="94">5. All parts are place on a 0.05" grid. You may not break this rule unless you have a very good reason.</text>
<text x="7.62" y="160.02" size="1.778" layer="94">6. Use 10 mil (0.010") traces.</text>
<text x="10.16" y="157.48" size="1.778" layer="94">1. 8 mil traces can be used when necessary, 7 mil is absolute minimum.</text>
<text x="10.16" y="154.94" size="1.778" layer="94">2. Use thicker traces (as thick as possible) on power and charging traces.</text>
<text x="15.24" y="152.4" size="1.778" layer="94">1. 10 mil = 100mA</text>
<text x="15.24" y="149.86" size="1.778" layer="94">2. 12 mil = 500mA </text>
<text x="7.62" y="147.32" size="1.778" layer="94">7. Keep at least 8 mil of space between traces.</text>
<text x="7.62" y="144.78" size="1.778" layer="94">8. Route with straight lines and 45 degree corners.</text>
<text x="10.16" y="142.24" size="1.778" layer="94">1. Avoid 90 degree corners. </text>
<text x="7.62" y="139.7" size="1.778" layer="94">9. Route from the center of pads. Avoid routing into the pads - this causes traces to be not centered on a pad.</text>
<text x="7.62" y="137.16" size="1.778" layer="94">10. If something is soldered into a hole (header, connector, prototype vias, etc), use a via with a larger annular ring so that it is easier to solder.</text>
<text x="7.62" y="132.08" size="1.778" layer="94">11. Use ground pours on the top and bottom layers.</text>
<text x="10.16" y="129.54" size="1.778" layer="94">1. Change the Isolate setting on ground pours to 12 mil (0.012"). </text>
<text x="7.62" y="127" size="1.778" layer="94">12. Set the default via size to 0.020."</text>
<text x="10.16" y="124.46" size="1.778" layer="94">1. 0.015 is the smallest allowed via size. Only change from the default if absolutely necessary.</text>
<text x="10.16" y="121.92" size="1.778" layer="94">2. Tip: Via size is defined by the Drill parameter.</text>
<text x="7.62" y="119.38" size="1.778" layer="94">13. Add a Date Code on the bottom layer of the board</text>
<text x="10.16" y="116.84" size="1.778" layer="94">1. Revise the Date code on every minor and major revision!</text>
<text x="7.62" y="114.3" size="1.778" layer="94">14. In the PCB Layout Editor use the following colors:</text>
<text x="10.16" y="111.76" size="1.778" layer="94">1. White for top silkscreen (tPlace)</text>
<text x="10.16" y="109.22" size="1.778" layer="94">2. Yellow for bottom silkscreen (bPlace)</text>
<text x="10.16" y="106.68" size="1.778" layer="94">3. Mellow Yellow for tDocu </text>
<text x="7.62" y="104.14" size="1.778" layer="94">15. Every board should have the full SparkFun logo or at least the smaller SFE Flame</text>
<text x="10.16" y="101.6" size="1.778" layer="94">1. To do this, add the LOGO-SFE part to the schematic. Make sure to put this part in the lower right hand corner of the schematic.</text>
<text x="7.62" y="99.06" size="1.778" layer="94">16. Components that are grouped together in the schematic will be grouped together in the PCB layout.</text>
<text x="7.62" y="96.52" size="1.778" layer="94">17. The autorouter can only be used on prototypes.</text>
<text x="10.16" y="93.98" size="1.778" layer="94">1. Hand routing and touch-up of the autorouter is expected for production boards. </text>
<text x="7.62" y="91.44" size="1.778" layer="94">18. Make sure to load the SparkFun.dru for the DRC check. Don't use the default settings! </text>
<text x="2.54" y="86.36" size="2.54" layer="92">PCB Aesthetics (Labeling)</text>
<text x="7.62" y="81.28" size="1.778" layer="94">2. Label any LED with its purpose (power, status, D4, Lock, etc).</text>
<text x="7.62" y="78.74" size="1.778" layer="94">3. Label all connectors (VIN, Port1, Batt, 5-9V, etc).</text>
<text x="7.62" y="76.2" size="1.778" layer="94">4. Label pins where applicable (Tx, Rx, Power, +, Charger, etc).</text>
<text x="7.62" y="73.66" size="1.778" layer="94">5. Label switches and switch states (On/Off, USB, etc).</text>
<text x="7.62" y="71.12" size="1.778" layer="94">6. Makes sure labels are on a straight line</text>
<text x="10.16" y="68.58" size="1.778" layer="94">1. Add a line in the tDocu layer to make sure the labels line up. </text>
<text x="2.54" y="63.5" size="2.54" layer="92">New Footprints</text>
<text x="7.62" y="60.96" size="1.778" layer="94">1. All footprints need &gt;Name (on the tNames layer).</text>
<text x="10.16" y="58.42" size="1.778" layer="94">1. Size should be 0.016" </text>
<text x="7.62" y="55.88" size="1.778" layer="94">2. All footprints need &gt;Value (on the tValues layer).</text>
<text x="10.16" y="53.34" size="1.778" layer="94">1. Size should be 0.016" </text>
<text x="7.62" y="50.8" size="1.778" layer="94">3. All footprints need silkscreen or tDocu indicators showing mechanical sizes, dimensions or anything weird about the part.</text>
<text x="7.62" y="45.72" size="1.778" layer="94">5. Silkscreen within a footprint or board should NOT go over pads or metal that will be exposed.</text>
<text x="7.62" y="43.18" size="1.778" layer="94">6. Every new footprint and part will have a description containing part information (SparkFun SKU) and whether the footprint has been proven.</text>
<text x="12.7" y="208.28" size="1.778" layer="94">1. Open the library, click on the "device." Select the problem device. Click on "Prefix" button. Type the correct prefix letter. Save and update the library. </text>
<text x="10.16" y="134.62" size="1.778" layer="94">1. For normal prototyping vias, use 0.04" hole with a 0.074" diameter (not auto).</text>
<text x="2.54" y="38.1" size="2.54" layer="92">New Schematic Components</text>
<text x="7.62" y="35.56" size="1.778" layer="94">1. All schematic components need &gt;Name and &gt;Value (on the tNames/tValues layer).</text>
<text x="10.16" y="33.02" size="1.778" layer="94">1. Size should be 0.07" </text>
<text x="7.62" y="27.94" size="1.778" layer="94">2. Pin length on a component should be 'short' unless otherwise needed.</text>
<text x="7.62" y="167.64" size="1.778" layer="94">4. If it's a 2-layer board (it should be) then remove all internal layers.</text>
<text x="10.16" y="165.1" size="1.778" layer="94">1. See SparkFun tutorial: "Removing Layers in Eagle"</text>
<text x="10.16" y="30.48" size="1.778" layer="94">2. Give some space between the &gt;Name and &gt;Value identifier and the component frame.</text>
<text x="2.54" y="17.78" size="2.54" layer="92">Printing Schematics</text>
<text x="7.62" y="12.7" size="1.778" layer="94">2. Select 'Print to file (PDF)' as the printer</text>
<text x="7.62" y="10.16" size="1.778" layer="94">3. Make sure 'Rotate' is NOT checked</text>
<text x="7.62" y="7.62" size="1.778" layer="94">4. Make sure 'Caption' is NOT checked</text>
<text x="7.62" y="5.08" size="1.778" layer="94">5. Select Sheets : 'All' to print all sheets</text>
<text x="7.62" y="2.54" size="1.778" layer="94">6. Make sure scale factor is '1'</text>
<text x="7.62" y="15.24" size="1.778" layer="94">1. If you see any 'U$2' part indentifiers, do not print. See Schematic Layout rule #4-8.</text>
<text x="2.54" y="279.4" size="2.54" layer="92">SparkFun Eagle Rules</text>
<text x="7.62" y="276.86" size="1.778" layer="94">These are the rules that all engineers must follow at SparkFun when designing a PCB.</text>
<text x="7.62" y="274.32" size="1.778" layer="94">Last updated 4-26-2010</text>
<text x="7.62" y="83.82" size="1.778" layer="94">1. All label text sizes will not be smaller than 0.04" for readability. 0.032" is the hard minimum. 0.05" is good and large.</text>
<text x="7.62" y="25.4" size="1.778" layer="94">3. Group power pins together on left side of component. Group I/O pins to right side.</text>
<text x="7.62" y="22.86" size="1.778" layer="94">4. Group banks of functionally similar pins together (all VCC, all GND, all NCs, I2C, analog, PORTC, etc).</text>
<text x="7.62" y="185.42" size="1.778" layer="94">10. Components must have correct values assigned to each part. For example a capacitor value would be: 0.1uF/25V </text>
<text x="7.62" y="48.26" size="1.778" layer="94">4. Origin of the footprint must be located in the center of the footprint. Where possible, the footprint should be symmetric on both axises.</text>
</symbol>
<symbol name="STARBOARD_LOGO">
<wire x1="-7.62" y1="2.54" x2="-7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="2.54" width="0.254" layer="94"/>
<wire x1="7.62" y1="2.54" x2="-7.62" y2="2.54" width="0.254" layer="94"/>
<text x="-6.604" y="-2.032" size="1.778" layer="94" font="vector">StarBoard</text>
</symbol>
<symbol name="VCC2">
<wire x1="0.762" y1="1.27" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="-0.762" y2="1.27" width="0.254" layer="94"/>
<text x="-1.016" y="3.556" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VCC2" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="VNEG">
<wire x1="0.762" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-0.762" y2="1.27" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VNEG" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
<symbol name="V_BATT">
<pin name="V_BATT" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="1.0V">
<pin name="1.0V" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="1.8V">
<pin name="1.8V" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="2.8V">
<pin name="2.8V" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="3.3V">
<pin name="3.3V" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="5V">
<pin name="5V" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="VIN">
<pin name="VIN" x="0" y="0" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="IOIO-OTG">
<wire x1="0" y1="5.08" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="17.78" y2="0" width="0.254" layer="94"/>
<wire x1="17.78" y1="0" x2="17.78" y2="5.08" width="0.254" layer="94"/>
<wire x1="17.78" y1="5.08" x2="0" y2="5.08" width="0.254" layer="94"/>
<text x="2.032" y="1.778" size="1.778" layer="94" ratio="18">IOIO label</text>
</symbol>
<symbol name="FOUR_LAYER_WARNING">
<text x="0" y="0" size="1.778" layer="94">THIS IS A FOUR-LAYER BOARD!</text>
</symbol>
<symbol name="GND">
<pin name="3.3V" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
<wire x1="-2.032" y1="0" x2="2.032" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-0.762" x2="1.27" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-0.508" y1="-1.524" x2="0.508" y2="-1.524" width="0.254" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="94">&gt;NAME</text>
</symbol>
<symbol name="SFE_LOGO_NAME">
<polygon width="0" layer="94">
<vertex x="3.84" y="6.5"/>
<vertex x="3.88" y="6.21"/>
<vertex x="3.97" y="5.96"/>
<vertex x="4.12" y="5.75"/>
<vertex x="4.31" y="5.59"/>
<vertex x="4.53" y="5.46"/>
<vertex x="4.78" y="5.38"/>
<vertex x="5.05" y="5.33"/>
<vertex x="5.33" y="5.31"/>
<vertex x="5.54" y="5.32"/>
<vertex x="5.76" y="5.36"/>
<vertex x="5.97" y="5.42"/>
<vertex x="6.17" y="5.51"/>
<vertex x="6.34" y="5.63"/>
<vertex x="6.48" y="5.78"/>
<vertex x="6.57" y="5.98"/>
<vertex x="6.6" y="6.21"/>
<vertex x="6.56" y="6.42"/>
<vertex x="6.45" y="6.59"/>
<vertex x="6.27" y="6.74"/>
<vertex x="6.02" y="6.87"/>
<vertex x="5.7" y="6.99"/>
<vertex x="5.33" y="7.1"/>
<vertex x="4.89" y="7.2"/>
<vertex x="4.4" y="7.3"/>
<vertex x="3.98" y="7.41"/>
<vertex x="3.58" y="7.53"/>
<vertex x="3.2" y="7.68"/>
<vertex x="2.86" y="7.87"/>
<vertex x="2.58" y="8.11"/>
<vertex x="2.36" y="8.4"/>
<vertex x="2.22" y="8.76"/>
<vertex x="2.17" y="9.19"/>
<vertex x="2.24" y="9.8"/>
<vertex x="2.43" y="10.3"/>
<vertex x="2.74" y="10.7"/>
<vertex x="3.13" y="10.99"/>
<vertex x="3.6" y="11.21"/>
<vertex x="4.12" y="11.35"/>
<vertex x="4.67" y="11.43"/>
<vertex x="5.23" y="11.45"/>
<vertex x="5.8" y="11.43"/>
<vertex x="6.34" y="11.35"/>
<vertex x="6.85" y="11.2"/>
<vertex x="7.31" y="10.98"/>
<vertex x="7.7" y="10.68"/>
<vertex x="8.01" y="10.29"/>
<vertex x="8.23" y="9.8"/>
<vertex x="8.34" y="9.2"/>
<vertex x="8.11" y="9.2"/>
<vertex x="7.88" y="9.2"/>
<vertex x="7.65" y="9.2"/>
<vertex x="7.42" y="9.2"/>
<vertex x="7.19" y="9.2"/>
<vertex x="6.96" y="9.2"/>
<vertex x="6.73" y="9.2"/>
<vertex x="6.5" y="9.2"/>
<vertex x="6.46" y="9.46"/>
<vertex x="6.37" y="9.67"/>
<vertex x="6.24" y="9.84"/>
<vertex x="6.08" y="9.96"/>
<vertex x="5.89" y="10.05"/>
<vertex x="5.67" y="10.11"/>
<vertex x="5.43" y="10.15"/>
<vertex x="5.18" y="10.16"/>
<vertex x="5.01" y="10.16"/>
<vertex x="4.83" y="10.15"/>
<vertex x="4.65" y="10.11"/>
<vertex x="4.48" y="10.06"/>
<vertex x="4.33" y="9.98"/>
<vertex x="4.21" y="9.86"/>
<vertex x="4.13" y="9.71"/>
<vertex x="4.1" y="9.51"/>
<vertex x="4.15" y="9.28"/>
<vertex x="4.29" y="9.09"/>
<vertex x="4.51" y="8.94"/>
<vertex x="4.79" y="8.82"/>
<vertex x="5.12" y="8.72"/>
<vertex x="5.5" y="8.64"/>
<vertex x="5.89" y="8.55"/>
<vertex x="6.3" y="8.46"/>
<vertex x="6.72" y="8.36"/>
<vertex x="7.13" y="8.23"/>
<vertex x="7.5" y="8.07"/>
<vertex x="7.84" y="7.87"/>
<vertex x="8.13" y="7.62"/>
<vertex x="8.34" y="7.31"/>
<vertex x="8.49" y="6.93"/>
<vertex x="8.54" y="6.48"/>
<vertex x="8.46" y="5.85"/>
<vertex x="8.26" y="5.32"/>
<vertex x="7.94" y="4.89"/>
<vertex x="7.52" y="4.56"/>
<vertex x="7.04" y="4.32"/>
<vertex x="6.49" y="4.15"/>
<vertex x="5.91" y="4.06"/>
<vertex x="5.31" y="4.03"/>
<vertex x="4.71" y="4.06"/>
<vertex x="4.12" y="4.15"/>
<vertex x="3.57" y="4.32"/>
<vertex x="3.07" y="4.57"/>
<vertex x="2.65" y="4.9"/>
<vertex x="2.32" y="5.33"/>
<vertex x="2.1" y="5.87"/>
<vertex x="2" y="6.5"/>
<vertex x="2.23" y="6.5"/>
<vertex x="2.46" y="6.5"/>
<vertex x="2.69" y="6.5"/>
<vertex x="2.92" y="6.5"/>
<vertex x="3.15" y="6.5"/>
<vertex x="3.38" y="6.5"/>
<vertex x="3.61" y="6.5"/>
</polygon>
<vertex x="14.35" y="6.5"/>
<vertex x="14.46" y="6.88"/>
<vertex x="14.53" y="7.28"/>
<vertex x="14.55" y="7.71"/>
<vertex x="16.48" y="7.65"/>
<vertex x="16.44" y="6.96"/>
<vertex x="16.29" y="6.29"/>
<vertex x="16.05" y="5.67"/>
</polygon>
<vertex x="16.05" y="5.68"/>
<vertex x="15.71" y="5.13"/>
<vertex x="15.28" y="4.67"/>
<vertex x="14.75" y="4.32"/>
<vertex x="14.12" y="4.09"/>
<vertex x="13.39" y="4.01"/>
<vertex x="13.07" y="4.03"/>
<vertex x="12.76" y="4.08"/>
<vertex x="12.47" y="4.17"/>
<vertex x="12.19" y="4.29"/>
<vertex x="11.93" y="4.44"/>
<vertex x="11.68" y="4.62"/>
<vertex x="11.47" y="4.83"/>
<vertex x="11.27" y="5.08"/>
<vertex x="11.26" y="5.08"/>
<vertex x="11.26" y="4.44"/>
<vertex x="11.26" y="3.81"/>
<vertex x="11.26" y="3.17"/>
<vertex x="11.26" y="2.54"/>
<vertex x="11.26" y="1.9"/>
<vertex x="11.26" y="1.27"/>
<vertex x="11.26" y="0.63"/>
<vertex x="11.26" y="0"/>
<vertex x="11.02" y="0.22"/>
<vertex x="10.78" y="0.43"/>
<vertex x="10.54" y="0.65"/>
<vertex x="10.29" y="0.86"/>
<vertex x="10.05" y="1.08"/>
<vertex x="9.81" y="1.29"/>
<vertex x="9.57" y="1.51"/>
<vertex x="9.33" y="1.72"/>
<vertex x="9.33" y="2.87"/>
<vertex x="9.33" y="4.02"/>
<vertex x="9.33" y="5.18"/>
<vertex x="9.33" y="6.33"/>
<vertex x="9.33" y="7.48"/>
<vertex x="9.33" y="8.63"/>
<vertex x="9.33" y="9.78"/>
<vertex x="9.33" y="10.93"/>
<vertex x="9.56" y="10.97"/>
<vertex x="9.79" y="11.01"/>
<vertex x="10.02" y="11.05"/>
<vertex x="10.25" y="11.09"/>
<vertex x="10.48" y="11.13"/>
<vertex x="10.71" y="11.17"/>
<vertex x="10.94" y="11.22"/>
<vertex x="11.17" y="11.26"/>
<vertex x="11.17" y="11.14"/>
<vertex x="11.17" y="11.03"/>
<vertex x="11.17" y="10.92"/>
<vertex x="11.17" y="10.81"/>
<vertex x="11.17" y="10.69"/>
<vertex x="11.17" y="10.58"/>
<vertex x="11.17" y="10.47"/>
<vertex x="11.17" y="10.35"/>
<vertex x="11.18" y="10.35"/>
<vertex x="11.37" y="10.62"/>
<vertex x="11.59" y="10.85"/>
<vertex x="11.82" y="11.03"/>
<vertex x="12.08" y="11.19"/>
<vertex x="12.36" y="11.3"/>
<vertex x="12.65" y="11.38"/>
<vertex x="12.96" y="11.43"/>
<vertex x="13.28" y="11.45"/>
<vertex x="14.05" y="11.36"/>
<vertex x="14.71" y="11.14"/>
<vertex x="15.27" y="10.77"/>
<vertex x="15.71" y="10.3"/>
<vertex x="16.05" y="9.73"/>
<vertex x="16.3" y="9.09"/>
<vertex x="16.44" y="8.39"/>
<vertex x="16.49" y="7.65"/>
<vertex x="14.52" y="8.13"/>
<vertex x="14.46" y="8.54"/>
<vertex x="14.34" y="8.92"/>
<vertex x="14.17" y="9.27"/>
<vertex x="13.94" y="9.56"/>
<vertex x="13.64" y="9.79"/>
<vertex x="13.29" y="9.93"/>
<vertex x="12.86" y="9.98"/>
<vertex x="12.42" y="9.93"/>
<vertex x="12.06" y="9.79"/>
<vertex x="11.77" y="9.57"/>
<vertex x="11.54" y="9.28"/>
<vertex x="11.37" y="8.93"/>
<vertex x="11.26" y="8.55"/>
<vertex x="11.2" y="8.13"/>
<vertex x="11.18" y="7.71"/>
<vertex x="11.2" y="7.28"/>
<vertex x="11.27" y="6.88"/>
<vertex x="11.38" y="6.5"/>
<vertex x="11.55" y="6.16"/>
<vertex x="11.78" y="5.88"/>
<vertex x="12.08" y="5.66"/>
<vertex x="12.44" y="5.52"/>
<vertex x="12.87" y="5.47"/>
<vertex x="13.31" y="5.52"/>
<vertex x="13.67" y="5.66"/>
<vertex x="13.96" y="5.88"/>
<vertex x="14.18" y="6.16"/>
</polygon>
<vertex x="19.43" y="8.25"/>
<vertex x="19.87" y="8.31"/>
<vertex x="20.29" y="8.35"/>
<vertex x="20.69" y="8.41"/>
<vertex x="20.92" y="7.36"/>
<vertex x="20.81" y="7.35"/>
<vertex x="20.7" y="7.33"/>
<vertex x="20.58" y="7.31"/>
<vertex x="20.47" y="7.3"/>
<vertex x="20.35" y="7.28"/>
<vertex x="20.24" y="7.26"/>
<vertex x="20.12" y="7.24"/>
<vertex x="20.01" y="7.22"/>
<vertex x="19.9" y="7.2"/>
<vertex x="19.79" y="7.17"/>
</polygon>
<vertex x="19.69" y="7.13"/>
<vertex x="19.59" y="7.09"/>
<vertex x="19.5" y="7.05"/>
<vertex x="19.41" y="7"/>
<vertex x="19.33" y="6.95"/>
<vertex x="19.25" y="6.89"/>
<vertex x="19.18" y="6.81"/>
<vertex x="19.12" y="6.74"/>
<vertex x="19.07" y="6.65"/>
<vertex x="19.03" y="6.55"/>
<vertex x="19" y="6.45"/>
<vertex x="18.98" y="6.33"/>
<vertex x="18.98" y="6.2"/>
<vertex x="18.98" y="6.08"/>
<vertex x="19" y="5.96"/>
<vertex x="19.03" y="5.86"/>
<vertex x="19.07" y="5.76"/>
<vertex x="19.13" y="5.68"/>
<vertex x="19.19" y="5.61"/>
<vertex x="19.26" y="5.54"/>
<vertex x="19.34" y="5.49"/>
<vertex x="19.42" y="5.44"/>
<vertex x="19.51" y="5.4"/>
<vertex x="19.61" y="5.37"/>
<vertex x="19.71" y="5.35"/>
<vertex x="19.82" y="5.33"/>
<vertex x="19.93" y="5.31"/>
<vertex x="20.05" y="5.31"/>
<vertex x="20.16" y="5.31"/>
<vertex x="20.43" y="5.33"/>
<vertex x="20.67" y="5.36"/>
<vertex x="20.87" y="5.42"/>
<vertex x="21.05" y="5.5"/>
<vertex x="21.2" y="5.6"/>
<vertex x="21.33" y="5.71"/>
<vertex x="21.43" y="5.83"/>
<vertex x="21.52" y="5.96"/>
<vertex x="21.58" y="6.09"/>
<vertex x="21.64" y="6.23"/>
<vertex x="21.67" y="6.37"/>
<vertex x="21.7" y="6.5"/>
<vertex x="21.72" y="6.62"/>
<vertex x="21.73" y="6.74"/>
<vertex x="21.73" y="6.84"/>
<vertex x="21.73" y="6.93"/>
<vertex x="21.73" y="6.98"/>
<vertex x="21.73" y="7.02"/>
<vertex x="21.73" y="7.07"/>
<vertex x="21.73" y="7.11"/>
<vertex x="21.73" y="7.16"/>
<vertex x="21.73" y="7.2"/>
<vertex x="21.73" y="7.25"/>
<vertex x="21.73" y="7.29"/>
<vertex x="21.73" y="7.34"/>
<vertex x="21.73" y="7.39"/>
<vertex x="21.73" y="7.43"/>
<vertex x="21.73" y="7.48"/>
<vertex x="21.73" y="7.52"/>
<vertex x="21.73" y="7.57"/>
<vertex x="21.73" y="7.61"/>
<vertex x="21.73" y="7.66"/>
<vertex x="21.67" y="7.6"/>
<vertex x="21.59" y="7.56"/>
<vertex x="21.51" y="7.52"/>
<vertex x="21.43" y="7.48"/>
<vertex x="21.33" y="7.45"/>
<vertex x="21.24" y="7.43"/>
<vertex x="21.14" y="7.4"/>
<vertex x="21.03" y="7.38"/>
<vertex x="20.92" y="7.37"/>
<vertex x="21.04" y="8.5"/>
<vertex x="21.33" y="8.6"/>
<vertex x="21.55" y="8.74"/>
<vertex x="21.69" y="8.93"/>
<vertex x="21.73" y="9.19"/>
<vertex x="21.73" y="9.34"/>
<vertex x="21.71" y="9.47"/>
<vertex x="21.68" y="9.58"/>
<vertex x="21.63" y="9.69"/>
<vertex x="21.58" y="9.78"/>
<vertex x="21.52" y="9.86"/>
<vertex x="21.44" y="9.92"/>
<vertex x="21.36" y="9.98"/>
<vertex x="21.27" y="10.03"/>
<vertex x="21.18" y="10.06"/>
<vertex x="21.07" y="10.09"/>
<vertex x="20.96" y="10.11"/>
<vertex x="20.85" y="10.13"/>
<vertex x="20.73" y="10.15"/>
<vertex x="20.61" y="10.15"/>
<vertex x="20.48" y="10.15"/>
<vertex x="20.34" y="10.15"/>
<vertex x="20.21" y="10.13"/>
<vertex x="20.09" y="10.11"/>
<vertex x="19.97" y="10.08"/>
<vertex x="19.86" y="10.05"/>
<vertex x="19.76" y="10.01"/>
<vertex x="19.67" y="9.96"/>
<vertex x="19.58" y="9.9"/>
<vertex x="19.5" y="9.83"/>
<vertex x="19.44" y="9.75"/>
<vertex x="19.37" y="9.66"/>
<vertex x="19.32" y="9.57"/>
<vertex x="19.28" y="9.46"/>
<vertex x="19.24" y="9.34"/>
<vertex x="19.21" y="9.22"/>
<vertex x="19.2" y="9.08"/>
<vertex x="19.08" y="9.08"/>
<vertex x="18.96" y="9.08"/>
<vertex x="18.83" y="9.08"/>
<vertex x="18.71" y="9.08"/>
<vertex x="18.59" y="9.08"/>
<vertex x="18.47" y="9.08"/>
<vertex x="18.35" y="9.08"/>
<vertex x="18.23" y="9.08"/>
<vertex x="18.11" y="9.08"/>
<vertex x="17.99" y="9.08"/>
<vertex x="17.87" y="9.08"/>
<vertex x="17.75" y="9.08"/>
<vertex x="17.63" y="9.08"/>
<vertex x="17.51" y="9.08"/>
<vertex x="17.38" y="9.08"/>
<vertex x="17.26" y="9.08"/>
<vertex x="17.3" y="9.4"/>
<vertex x="17.37" y="9.7"/>
<vertex x="17.47" y="9.96"/>
<vertex x="17.61" y="10.21"/>
<vertex x="17.76" y="10.42"/>
<vertex x="17.94" y="10.62"/>
<vertex x="18.15" y="10.79"/>
<vertex x="18.37" y="10.93"/>
<vertex x="18.61" y="11.06"/>
<vertex x="18.86" y="11.16"/>
<vertex x="19.13" y="11.25"/>
<vertex x="19.41" y="11.32"/>
<vertex x="19.69" y="11.37"/>
<vertex x="19.99" y="11.41"/>
<vertex x="20.28" y="11.43"/>
<vertex x="20.58" y="11.43"/>
<vertex x="20.84" y="11.43"/>
<vertex x="21.11" y="11.42"/>
<vertex x="21.39" y="11.39"/>
<vertex x="21.66" y="11.36"/>
<vertex x="21.92" y="11.31"/>
<vertex x="22.18" y="11.24"/>
<vertex x="22.42" y="11.16"/>
<vertex x="22.65" y="11.06"/>
<vertex x="22.87" y="10.95"/>
<vertex x="23.07" y="10.81"/>
<vertex x="23.24" y="10.64"/>
<vertex x="23.39" y="10.46"/>
<vertex x="23.51" y="10.24"/>
<vertex x="23.6" y="10"/>
<vertex x="23.66" y="9.73"/>
<vertex x="23.68" y="9.43"/>
<vertex x="23.68" y="9.2"/>
<vertex x="23.68" y="8.97"/>
<vertex x="23.68" y="8.74"/>
<vertex x="23.68" y="8.51"/>
<vertex x="23.68" y="8.28"/>
<vertex x="23.68" y="8.05"/>
<vertex x="23.68" y="7.82"/>
<vertex x="23.68" y="7.59"/>
<vertex x="23.68" y="7.36"/>
<vertex x="23.68" y="7.14"/>
<vertex x="23.68" y="6.91"/>
<vertex x="23.68" y="6.68"/>
<vertex x="23.68" y="6.45"/>
<vertex x="23.68" y="6.22"/>
<vertex x="23.68" y="5.99"/>
<vertex x="23.68" y="5.76"/>
<vertex x="23.68" y="5.64"/>
<vertex x="23.68" y="5.52"/>
<vertex x="23.68" y="5.4"/>
<vertex x="23.68" y="5.28"/>
<vertex x="23.69" y="5.17"/>
<vertex x="23.7" y="5.06"/>
<vertex x="23.71" y="4.95"/>
<vertex x="23.73" y="4.84"/>
<vertex x="23.75" y="4.74"/>
<vertex x="23.76" y="4.64"/>
<vertex x="23.78" y="4.55"/>
<vertex x="23.8" y="4.47"/>
<vertex x="23.83" y="4.39"/>
<vertex x="23.86" y="4.31"/>
<vertex x="23.88" y="4.25"/>
<vertex x="23.92" y="4.19"/>
<vertex x="23.79" y="4.19"/>
<vertex x="23.67" y="4.19"/>
<vertex x="23.55" y="4.19"/>
<vertex x="23.43" y="4.19"/>
<vertex x="23.3" y="4.19"/>
<vertex x="23.18" y="4.19"/>
<vertex x="23.06" y="4.19"/>
<vertex x="22.94" y="4.19"/>
<vertex x="22.81" y="4.19"/>
<vertex x="22.69" y="4.19"/>
<vertex x="22.57" y="4.19"/>
<vertex x="22.45" y="4.19"/>
<vertex x="22.32" y="4.19"/>
<vertex x="22.2" y="4.19"/>
<vertex x="22.08" y="4.19"/>
<vertex x="21.96" y="4.19"/>
<vertex x="21.94" y="4.23"/>
<vertex x="21.93" y="4.27"/>
<vertex x="21.91" y="4.32"/>
<vertex x="21.9" y="4.36"/>
<vertex x="21.88" y="4.4"/>
<vertex x="21.87" y="4.44"/>
<vertex x="21.86" y="4.48"/>
<vertex x="21.85" y="4.53"/>
<vertex x="21.84" y="4.57"/>
<vertex x="21.84" y="4.61"/>
<vertex x="21.83" y="4.66"/>
<vertex x="21.83" y="4.7"/>
<vertex x="21.83" y="4.74"/>
<vertex x="21.82" y="4.79"/>
<vertex x="21.82" y="4.83"/>
<vertex x="21.82" y="4.88"/>
<vertex x="21.7" y="4.76"/>
<vertex x="21.58" y="4.65"/>
<vertex x="21.45" y="4.56"/>
<vertex x="21.31" y="4.47"/>
<vertex x="21.17" y="4.39"/>
<vertex x="21.03" y="4.32"/>
<vertex x="20.88" y="4.25"/>
<vertex x="20.73" y="4.2"/>
<vertex x="20.58" y="4.15"/>
<vertex x="20.42" y="4.11"/>
<vertex x="20.26" y="4.08"/>
<vertex x="20.1" y="4.05"/>
<vertex x="19.94" y="4.03"/>
<vertex x="19.77" y="4.01"/>
<vertex x="19.61" y="4"/>
<vertex x="19.45" y="4"/>
<vertex x="19.2" y="4"/>
<vertex x="18.96" y="4.02"/>
<vertex x="18.72" y="4.06"/>
<vertex x="18.5" y="4.12"/>
<vertex x="18.29" y="4.19"/>
<vertex x="18.09" y="4.28"/>
<vertex x="17.91" y="4.38"/>
<vertex x="17.74" y="4.51"/>
<vertex x="17.59" y="4.65"/>
<vertex x="17.45" y="4.8"/>
<vertex x="17.33" y="4.98"/>
<vertex x="17.23" y="5.17"/>
<vertex x="17.15" y="5.37"/>
<vertex x="17.1" y="5.6"/>
<vertex x="17.06" y="5.84"/>
<vertex x="17.04" y="6.11"/>
<vertex x="17.1" y="6.65"/>
<vertex x="17.26" y="7.09"/>
<vertex x="17.49" y="7.44"/>
<vertex x="17.8" y="7.72"/>
<vertex x="18.16" y="7.92"/>
<vertex x="18.56" y="8.07"/>
<vertex x="18.99" y="8.17"/>
</polygon>
<vertex x="24.77" y="10.93"/>
<vertex x="25" y="10.97"/>
<vertex x="25.23" y="11.01"/>
<vertex x="25.46" y="11.05"/>
<vertex x="25.69" y="11.09"/>
<vertex x="25.92" y="11.13"/>
<vertex x="26.15" y="11.17"/>
<vertex x="26.38" y="11.21"/>
<vertex x="26.61" y="11.25"/>
<vertex x="26.61" y="11.09"/>
<vertex x="26.61" y="10.93"/>
<vertex x="26.61" y="10.76"/>
<vertex x="26.61" y="10.6"/>
<vertex x="26.61" y="10.43"/>
<vertex x="26.61" y="10.27"/>
<vertex x="26.61" y="10.11"/>
<vertex x="26.61" y="9.94"/>
<vertex x="26.62" y="9.94"/>
<vertex x="26.78" y="10.26"/>
<vertex x="26.99" y="10.55"/>
<vertex x="27.24" y="10.81"/>
<vertex x="27.52" y="11.03"/>
<vertex x="27.83" y="11.2"/>
<vertex x="28.16" y="11.33"/>
<vertex x="28.51" y="11.42"/>
<vertex x="28.87" y="11.44"/>
<vertex x="28.93" y="11.44"/>
<vertex x="28.98" y="11.44"/>
<vertex x="29.03" y="11.44"/>
<vertex x="29.09" y="11.44"/>
<vertex x="29.14" y="11.43"/>
<vertex x="29.19" y="11.41"/>
<vertex x="29.24" y="11.4"/>
<vertex x="29.29" y="11.38"/>
<vertex x="29.29" y="11.16"/>
<vertex x="29.29" y="10.93"/>
<vertex x="29.29" y="10.71"/>
<vertex x="29.29" y="10.48"/>
<vertex x="29.29" y="10.26"/>
<vertex x="29.29" y="10.03"/>
<vertex x="29.29" y="9.81"/>
<vertex x="29.29" y="9.58"/>
<vertex x="29.22" y="9.6"/>
<vertex x="29.14" y="9.61"/>
<vertex x="29.06" y="9.63"/>
<vertex x="28.97" y="9.64"/>
<vertex x="28.87" y="9.64"/>
<vertex x="28.78" y="9.64"/>
<vertex x="28.69" y="9.64"/>
<vertex x="28.6" y="9.64"/>
<vertex x="28.11" y="9.6"/>
<vertex x="27.7" y="9.47"/>
<vertex x="27.37" y="9.26"/>
<vertex x="27.11" y="8.98"/>
<vertex x="26.92" y="8.65"/>
<vertex x="26.79" y="8.26"/>
<vertex x="26.71" y="7.84"/>
<vertex x="26.69" y="7.38"/>
<vertex x="26.69" y="6.98"/>
<vertex x="26.69" y="6.59"/>
<vertex x="26.69" y="6.19"/>
<vertex x="26.69" y="5.79"/>
<vertex x="26.69" y="5.39"/>
<vertex x="26.69" y="5"/>
<vertex x="26.69" y="4.6"/>
<vertex x="26.69" y="4.2"/>
<vertex x="26.45" y="4.2"/>
<vertex x="26.2" y="4.2"/>
<vertex x="25.96" y="4.2"/>
<vertex x="25.72" y="4.2"/>
<vertex x="25.48" y="4.2"/>
<vertex x="25.24" y="4.2"/>
<vertex x="24.99" y="4.2"/>
<vertex x="24.75" y="4.2"/>
<vertex x="24.75" y="5.04"/>
<vertex x="24.75" y="5.88"/>
<vertex x="24.75" y="6.72"/>
<vertex x="24.75" y="7.56"/>
<vertex x="24.75" y="8.4"/>
<vertex x="24.75" y="9.24"/>
<vertex x="24.75" y="10.09"/>
</polygon>
<vertex x="30.06" y="12.88"/>
<vertex x="31.99" y="13.94"/>
<vertex x="31.99" y="8.72"/>
<vertex x="34.44" y="11.26"/>
<vertex x="36.73" y="11.26"/>
<vertex x="34.07" y="8.66"/>
<vertex x="37.03" y="4.2"/>
<vertex x="34.68" y="4.2"/>
<vertex x="32.74" y="7.35"/>
<vertex x="31.99" y="6.63"/>
<vertex x="31.99" y="4.2"/>
<vertex x="30.06" y="4.2"/>
</polygon>
<vertex x="38.2" y="9.96"/>
<vertex x="37.97" y="9.96"/>
<vertex x="37.73" y="9.96"/>
<vertex x="37.49" y="9.96"/>
<vertex x="37.25" y="9.96"/>
<vertex x="37.01" y="9.96"/>
<vertex x="36.77" y="9.96"/>
<vertex x="36.53" y="9.96"/>
<vertex x="36.3" y="9.96"/>
<vertex x="36.46" y="10.12"/>
<vertex x="36.63" y="10.28"/>
<vertex x="36.79" y="10.45"/>
<vertex x="36.95" y="10.61"/>
<vertex x="37.12" y="10.77"/>
<vertex x="37.28" y="10.93"/>
<vertex x="37.45" y="11.09"/>
<vertex x="37.61" y="11.26"/>
<vertex x="37.69" y="11.26"/>
<vertex x="37.76" y="11.26"/>
<vertex x="37.84" y="11.26"/>
<vertex x="37.91" y="11.26"/>
<vertex x="37.98" y="11.26"/>
<vertex x="38.06" y="11.26"/>
<vertex x="38.13" y="11.26"/>
<vertex x="38.2" y="11.26"/>
<vertex x="38.2" y="11.32"/>
<vertex x="38.2" y="11.39"/>
<vertex x="38.2" y="11.46"/>
<vertex x="38.2" y="11.53"/>
<vertex x="38.2" y="11.59"/>
<vertex x="38.2" y="11.66"/>
<vertex x="38.2" y="11.73"/>
<vertex x="38.2" y="11.8"/>
<vertex x="38.24" y="12.25"/>
<vertex x="38.35" y="12.66"/>
<vertex x="38.53" y="13.03"/>
<vertex x="38.79" y="13.34"/>
<vertex x="39.12" y="13.59"/>
<vertex x="39.53" y="13.78"/>
<vertex x="40.01" y="13.9"/>
<vertex x="40.56" y="13.94"/>
<vertex x="40.69" y="13.94"/>
<vertex x="40.82" y="13.94"/>
<vertex x="40.95" y="13.94"/>
<vertex x="41.08" y="13.93"/>
<vertex x="41.21" y="13.91"/>
<vertex x="41.34" y="13.9"/>
<vertex x="41.46" y="13.9"/>
<vertex x="41.59" y="13.9"/>
<vertex x="41.59" y="13.72"/>
<vertex x="41.59" y="13.54"/>
<vertex x="41.59" y="13.36"/>
<vertex x="41.59" y="13.17"/>
<vertex x="41.59" y="12.99"/>
<vertex x="41.59" y="12.81"/>
<vertex x="41.59" y="12.63"/>
<vertex x="41.59" y="12.45"/>
<vertex x="41.5" y="12.47"/>
<vertex x="41.41" y="12.48"/>
<vertex x="41.32" y="12.48"/>
<vertex x="41.23" y="12.48"/>
<vertex x="41.14" y="12.48"/>
<vertex x="41.05" y="12.48"/>
<vertex x="40.97" y="12.48"/>
<vertex x="40.88" y="12.48"/>
<vertex x="40.69" y="12.47"/>
<vertex x="40.54" y="12.43"/>
<vertex x="40.41" y="12.38"/>
<vertex x="40.31" y="12.3"/>
<vertex x="40.23" y="12.19"/>
<vertex x="40.18" y="12.05"/>
<vertex x="40.15" y="11.88"/>
<vertex x="40.14" y="11.67"/>
<vertex x="40.14" y="11.62"/>
<vertex x="40.14" y="11.57"/>
<vertex x="40.14" y="11.52"/>
<vertex x="40.14" y="11.46"/>
<vertex x="40.14" y="11.41"/>
<vertex x="40.14" y="11.36"/>
<vertex x="40.14" y="11.3"/>
<vertex x="40.14" y="11.25"/>
<vertex x="40.31" y="11.25"/>
<vertex x="40.47" y="11.25"/>
<vertex x="40.64" y="11.25"/>
<vertex x="40.81" y="11.25"/>
<vertex x="40.98" y="11.25"/>
<vertex x="41.14" y="11.25"/>
<vertex x="41.31" y="11.25"/>
<vertex x="41.48" y="11.25"/>
<vertex x="41.48" y="11.09"/>
<vertex x="41.48" y="10.93"/>
<vertex x="41.48" y="10.77"/>
<vertex x="41.48" y="10.6"/>
<vertex x="41.48" y="10.44"/>
<vertex x="41.48" y="10.28"/>
<vertex x="41.48" y="10.12"/>
<vertex x="41.48" y="9.96"/>
<vertex x="41.31" y="9.96"/>
<vertex x="41.14" y="9.96"/>
<vertex x="40.98" y="9.96"/>
<vertex x="40.81" y="9.96"/>
<vertex x="40.64" y="9.96"/>
<vertex x="40.47" y="9.96"/>
<vertex x="40.31" y="9.96"/>
<vertex x="40.14" y="9.96"/>
<vertex x="40.14" y="9.24"/>
<vertex x="40.14" y="8.52"/>
<vertex x="40.14" y="7.8"/>
<vertex x="40.14" y="7.08"/>
<vertex x="40.14" y="6.36"/>
<vertex x="40.14" y="5.64"/>
<vertex x="40.14" y="4.92"/>
<vertex x="40.14" y="4.2"/>
<vertex x="39.9" y="4.2"/>
<vertex x="39.66" y="4.2"/>
<vertex x="39.41" y="4.2"/>
<vertex x="39.17" y="4.2"/>
<vertex x="38.93" y="4.2"/>
<vertex x="38.69" y="4.2"/>
<vertex x="38.45" y="4.2"/>
<vertex x="38.2" y="4.2"/>
<vertex x="38.2" y="4.92"/>
<vertex x="38.2" y="5.64"/>
<vertex x="38.2" y="6.36"/>
<vertex x="38.2" y="7.08"/>
<vertex x="38.2" y="7.8"/>
<vertex x="38.2" y="8.52"/>
<vertex x="38.2" y="9.24"/>
</polygon>
<vertex x="48.64" y="4.2"/>
<vertex x="48.41" y="4.2"/>
<vertex x="48.18" y="4.2"/>
<vertex x="47.95" y="4.2"/>
<vertex x="47.72" y="4.2"/>
<vertex x="47.49" y="4.2"/>
<vertex x="47.26" y="4.2"/>
<vertex x="47.03" y="4.2"/>
<vertex x="46.79" y="4.2"/>
<vertex x="46.79" y="4.33"/>
<vertex x="46.79" y="4.45"/>
<vertex x="46.79" y="4.57"/>
<vertex x="46.79" y="4.69"/>
<vertex x="46.79" y="4.82"/>
<vertex x="46.79" y="4.94"/>
<vertex x="46.79" y="5.06"/>
<vertex x="46.79" y="5.18"/>
<vertex x="46.78" y="5.18"/>
<vertex x="46.77" y="5.18"/>
<vertex x="46.57" y="4.9"/>
<vertex x="46.34" y="4.66"/>
<vertex x="46.09" y="4.46"/>
<vertex x="45.82" y="4.3"/>
<vertex x="45.53" y="4.17"/>
<vertex x="45.23" y="4.08"/>
<vertex x="44.92" y="4.03"/>
<vertex x="44.62" y="4.01"/>
<vertex x="43.92" y="4.06"/>
<vertex x="43.35" y="4.22"/>
<vertex x="42.9" y="4.47"/>
<vertex x="42.56" y="4.81"/>
<vertex x="42.31" y="5.23"/>
<vertex x="42.15" y="5.73"/>
<vertex x="42.07" y="6.29"/>
<vertex x="42.04" y="6.92"/>
<vertex x="42.04" y="7.46"/>
<vertex x="42.04" y="8"/>
<vertex x="42.04" y="8.54"/>
<vertex x="42.04" y="9.08"/>
<vertex x="42.04" y="9.63"/>
<vertex x="42.04" y="10.17"/>
<vertex x="42.04" y="10.71"/>
<vertex x="42.04" y="11.25"/>
<vertex x="42.28" y="11.25"/>
<vertex x="42.52" y="11.25"/>
<vertex x="42.77" y="11.25"/>
<vertex x="43.01" y="11.25"/>
<vertex x="43.25" y="11.25"/>
<vertex x="43.49" y="11.25"/>
<vertex x="43.74" y="11.25"/>
<vertex x="43.98" y="11.25"/>
<vertex x="43.98" y="10.76"/>
<vertex x="43.98" y="10.26"/>
<vertex x="43.98" y="9.76"/>
<vertex x="43.98" y="9.26"/>
<vertex x="43.98" y="8.76"/>
<vertex x="43.98" y="8.27"/>
<vertex x="43.98" y="7.77"/>
<vertex x="43.98" y="7.27"/>
<vertex x="43.99" y="6.86"/>
<vertex x="44.04" y="6.51"/>
<vertex x="44.13" y="6.21"/>
<vertex x="44.26" y="5.97"/>
<vertex x="44.43" y="5.78"/>
<vertex x="44.64" y="5.65"/>
<vertex x="44.9" y="5.57"/>
<vertex x="45.22" y="5.54"/>
<vertex x="45.59" y="5.57"/>
<vertex x="45.9" y="5.65"/>
<vertex x="46.16" y="5.8"/>
<vertex x="46.36" y="6.01"/>
<vertex x="46.52" y="6.29"/>
<vertex x="46.63" y="6.64"/>
<vertex x="46.7" y="7.06"/>
<vertex x="46.72" y="7.56"/>
<vertex x="46.72" y="8.02"/>
<vertex x="46.72" y="8.48"/>
<vertex x="46.72" y="8.94"/>
<vertex x="46.72" y="9.41"/>
<vertex x="46.72" y="9.87"/>
<vertex x="46.72" y="10.33"/>
<vertex x="46.72" y="10.79"/>
<vertex x="46.72" y="11.25"/>
<vertex x="46.96" y="11.25"/>
<vertex x="47.2" y="11.25"/>
<vertex x="47.45" y="11.25"/>
<vertex x="47.69" y="11.25"/>
<vertex x="47.93" y="11.25"/>
<vertex x="48.17" y="11.25"/>
<vertex x="48.42" y="11.25"/>
<vertex x="48.66" y="11.25"/>
<vertex x="48.66" y="10.37"/>
<vertex x="48.66" y="9.49"/>
<vertex x="48.66" y="8.61"/>
<vertex x="48.66" y="7.73"/>
<vertex x="48.66" y="6.85"/>
<vertex x="48.66" y="5.96"/>
<vertex x="48.66" y="5.08"/>
</polygon>
<vertex x="49.71" y="11.26"/>
<vertex x="49.94" y="11.26"/>
<vertex x="50.17" y="11.26"/>
<vertex x="50.4" y="11.26"/>
<vertex x="50.63" y="11.26"/>
<vertex x="50.86" y="11.26"/>
<vertex x="51.09" y="11.26"/>
<vertex x="51.32" y="11.26"/>
<vertex x="51.55" y="11.26"/>
<vertex x="51.55" y="11.13"/>
<vertex x="51.55" y="11.01"/>
<vertex x="51.55" y="10.89"/>
<vertex x="51.55" y="10.76"/>
<vertex x="51.55" y="10.64"/>
<vertex x="51.55" y="10.52"/>
<vertex x="51.55" y="10.4"/>
<vertex x="51.55" y="10.27"/>
<vertex x="51.56" y="10.27"/>
<vertex x="51.57" y="10.27"/>
<vertex x="51.77" y="10.56"/>
<vertex x="52" y="10.8"/>
<vertex x="52.25" y="11"/>
<vertex x="52.52" y="11.16"/>
<vertex x="52.81" y="11.29"/>
<vertex x="53.11" y="11.38"/>
<vertex x="53.42" y="11.43"/>
<vertex x="53.73" y="11.45"/>
<vertex x="54.43" y="11.39"/>
<vertex x="55" y="11.24"/>
<vertex x="55.45" y="10.99"/>
<vertex x="55.79" y="10.65"/>
<vertex x="56.03" y="10.23"/>
<vertex x="56.19" y="9.73"/>
<vertex x="56.28" y="9.17"/>
<vertex x="56.3" y="8.54"/>
<vertex x="56.3" y="8"/>
<vertex x="56.3" y="7.46"/>
<vertex x="56.3" y="6.92"/>
<vertex x="56.3" y="6.37"/>
<vertex x="56.3" y="5.83"/>
<vertex x="56.3" y="5.29"/>
<vertex x="56.3" y="4.75"/>
<vertex x="56.3" y="4.2"/>
<vertex x="56.06" y="4.2"/>
<vertex x="55.82" y="4.2"/>
<vertex x="55.58" y="4.2"/>
<vertex x="55.33" y="4.2"/>
<vertex x="55.09" y="4.2"/>
<vertex x="54.85" y="4.2"/>
<vertex x="54.61" y="4.2"/>
<vertex x="54.37" y="4.2"/>
<vertex x="54.37" y="4.7"/>
<vertex x="54.37" y="5.2"/>
<vertex x="54.37" y="5.7"/>
<vertex x="54.37" y="6.2"/>
<vertex x="54.37" y="6.69"/>
<vertex x="54.37" y="7.19"/>
<vertex x="54.37" y="7.69"/>
<vertex x="54.37" y="8.19"/>
<vertex x="54.35" y="8.59"/>
<vertex x="54.3" y="8.95"/>
<vertex x="54.21" y="9.24"/>
<vertex x="54.09" y="9.49"/>
<vertex x="53.92" y="9.68"/>
<vertex x="53.7" y="9.81"/>
<vertex x="53.44" y="9.89"/>
<vertex x="53.12" y="9.92"/>
<vertex x="52.76" y="9.89"/>
<vertex x="52.45" y="9.81"/>
<vertex x="52.19" y="9.66"/>
<vertex x="51.98" y="9.45"/>
<vertex x="51.82" y="9.17"/>
<vertex x="51.71" y="8.82"/>
<vertex x="51.65" y="8.4"/>
<vertex x="51.62" y="7.9"/>
<vertex x="51.62" y="7.44"/>
<vertex x="51.62" y="6.98"/>
<vertex x="51.62" y="6.51"/>
<vertex x="51.62" y="6.05"/>
<vertex x="51.62" y="5.59"/>
<vertex x="51.62" y="5.13"/>
<vertex x="51.62" y="4.67"/>
<vertex x="51.62" y="4.2"/>
<vertex x="51.38" y="4.2"/>
<vertex x="51.14" y="4.2"/>
<vertex x="50.9" y="4.2"/>
<vertex x="50.66" y="4.2"/>
<vertex x="50.41" y="4.2"/>
<vertex x="50.17" y="4.2"/>
<vertex x="49.93" y="4.2"/>
<vertex x="49.69" y="4.2"/>
<vertex x="49.69" y="5.09"/>
<vertex x="49.69" y="5.97"/>
<vertex x="49.69" y="6.85"/>
<vertex x="49.69" y="7.73"/>
<vertex x="49.69" y="8.61"/>
<vertex x="49.69" y="9.49"/>
<vertex x="49.69" y="10.37"/>
</polygon>
</symbol>
<symbol name="SFE_LOGO_NAME_FLAME">
<vertex x="2.54" y="6.88"/>
<vertex x="2.58" y="6.59"/>
<vertex x="2.67" y="6.34"/>
<vertex x="2.82" y="6.14"/>
<vertex x="3.01" y="5.97"/>
<vertex x="3.23" y="5.85"/>
<vertex x="3.48" y="5.76"/>
<vertex x="3.75" y="5.71"/>
<vertex x="4.03" y="5.69"/>
<vertex x="4.25" y="5.7"/>
<vertex x="4.46" y="5.73"/>
<vertex x="4.68" y="5.79"/>
<vertex x="4.87" y="5.88"/>
<vertex x="5.05" y="6.01"/>
<vertex x="5.18" y="6.16"/>
<vertex x="5.27" y="6.36"/>
<vertex x="5.31" y="6.59"/>
<vertex x="5.27" y="6.79"/>
<vertex x="5.16" y="6.97"/>
<vertex x="4.97" y="7.12"/>
<vertex x="4.72" y="7.25"/>
<vertex x="4.41" y="7.37"/>
<vertex x="4.03" y="7.48"/>
<vertex x="3.59" y="7.58"/>
<vertex x="3.1" y="7.68"/>
<vertex x="2.68" y="7.79"/>
<vertex x="2.27" y="7.91"/>
<vertex x="1.9" y="8.07"/>
<vertex x="1.56" y="8.26"/>
<vertex x="1.27" y="8.49"/>
<vertex x="1.05" y="8.78"/>
<vertex x="0.91" y="9.14"/>
<vertex x="0.86" y="9.57"/>
<vertex x="0.93" y="10.19"/>
<vertex x="1.13" y="10.69"/>
<vertex x="1.43" y="11.08"/>
<vertex x="1.83" y="11.38"/>
<vertex x="2.3" y="11.6"/>
<vertex x="2.82" y="11.74"/>
<vertex x="3.37" y="11.82"/>
<vertex x="3.94" y="11.84"/>
<vertex x="4.5" y="11.82"/>
<vertex x="5.05" y="11.73"/>
<vertex x="5.56" y="11.59"/>
<vertex x="6.01" y="11.37"/>
<vertex x="6.41" y="11.06"/>
<vertex x="6.72" y="10.67"/>
<vertex x="6.94" y="10.18"/>
<vertex x="7.06" y="9.59"/>
<vertex x="6.83" y="9.59"/>
<vertex x="6.59" y="9.59"/>
<vertex x="6.36" y="9.59"/>
<vertex x="6.13" y="9.59"/>
<vertex x="5.9" y="9.59"/>
<vertex x="5.67" y="9.59"/>
<vertex x="5.44" y="9.59"/>
<vertex x="5.21" y="9.59"/>
<vertex x="5.17" y="9.84"/>
<vertex x="5.08" y="10.05"/>
<vertex x="4.95" y="10.22"/>
<vertex x="4.79" y="10.35"/>
<vertex x="4.59" y="10.44"/>
<vertex x="4.38" y="10.5"/>
<vertex x="4.14" y="10.54"/>
<vertex x="3.88" y="10.54"/>
<vertex x="3.71" y="10.54"/>
<vertex x="3.53" y="10.52"/>
<vertex x="3.35" y="10.49"/>
<vertex x="3.18" y="10.44"/>
<vertex x="3.03" y="10.35"/>
<vertex x="2.91" y="10.24"/>
<vertex x="2.83" y="10.08"/>
<vertex x="2.8" y="9.89"/>
<vertex x="2.85" y="9.65"/>
<vertex x="2.99" y="9.46"/>
<vertex x="3.21" y="9.32"/>
<vertex x="3.49" y="9.2"/>
<vertex x="3.83" y="9.1"/>
<vertex x="4.2" y="9.01"/>
<vertex x="4.6" y="8.93"/>
<vertex x="5" y="8.84"/>
<vertex x="5.43" y="8.73"/>
<vertex x="5.83" y="8.6"/>
<vertex x="6.21" y="8.44"/>
<vertex x="6.55" y="8.24"/>
<vertex x="6.84" y="7.99"/>
<vertex x="7.06" y="7.68"/>
<vertex x="7.2" y="7.3"/>
<vertex x="7.25" y="6.85"/>
<vertex x="7.17" y="6.21"/>
<vertex x="6.97" y="5.68"/>
<vertex x="6.65" y="5.26"/>
<vertex x="6.23" y="4.92"/>
<vertex x="5.74" y="4.68"/>
<vertex x="5.2" y="4.51"/>
<vertex x="4.62" y="4.42"/>
<vertex x="4.02" y="4.39"/>
<vertex x="3.41" y="4.42"/>
<vertex x="2.82" y="4.52"/>
<vertex x="2.26" y="4.68"/>
<vertex x="1.77" y="4.93"/>
<vertex x="1.35" y="5.27"/>
<vertex x="1.01" y="5.7"/>
<vertex x="0.79" y="6.23"/>
<vertex x="0.7" y="6.88"/>
<vertex x="0.93" y="6.88"/>
<vertex x="1.16" y="6.88"/>
<vertex x="1.39" y="6.88"/>
<vertex x="1.62" y="6.88"/>
<vertex x="1.85" y="6.88"/>
<vertex x="2.08" y="6.88"/>
<vertex x="2.31" y="6.88"/>
</polygon>
<vertex x="13.08" y="6.88"/>
<vertex x="13.19" y="7.26"/>
<vertex x="13.25" y="7.67"/>
<vertex x="13.27" y="8.1"/>
<vertex x="15.22" y="8.04"/>
<vertex x="15.17" y="7.34"/>
<vertex x="15.02" y="6.68"/>
<vertex x="14.78" y="6.06"/>
</polygon>
<vertex x="14.44" y="5.51"/>
<vertex x="14.01" y="5.05"/>
<vertex x="13.47" y="4.7"/>
<vertex x="12.84" y="4.47"/>
<vertex x="12.11" y="4.39"/>
<vertex x="11.79" y="4.41"/>
<vertex x="11.48" y="4.46"/>
<vertex x="11.19" y="4.55"/>
<vertex x="10.91" y="4.66"/>
<vertex x="10.65" y="4.81"/>
<vertex x="10.4" y="5"/>
<vertex x="10.19" y="5.21"/>
<vertex x="9.99" y="5.46"/>
<vertex x="9.98" y="5.46"/>
<vertex x="9.98" y="4.82"/>
<vertex x="9.98" y="4.19"/>
<vertex x="9.98" y="3.55"/>
<vertex x="9.98" y="2.91"/>
<vertex x="9.98" y="2.28"/>
<vertex x="9.98" y="1.64"/>
<vertex x="9.98" y="1"/>
<vertex x="9.98" y="0.37"/>
<vertex x="9.74" y="0.58"/>
<vertex x="9.5" y="0.8"/>
<vertex x="9.25" y="1.02"/>
<vertex x="9.01" y="1.23"/>
<vertex x="8.77" y="1.45"/>
<vertex x="8.53" y="1.66"/>
<vertex x="8.28" y="1.88"/>
<vertex x="8.04" y="2.1"/>
<vertex x="8.04" y="3.25"/>
<vertex x="8.04" y="4.4"/>
<vertex x="8.04" y="5.56"/>
<vertex x="8.04" y="6.71"/>
<vertex x="8.04" y="7.86"/>
<vertex x="8.04" y="9.02"/>
<vertex x="8.04" y="10.17"/>
<vertex x="8.04" y="11.32"/>
<vertex x="8.27" y="11.37"/>
<vertex x="8.5" y="11.41"/>
<vertex x="8.73" y="11.45"/>
<vertex x="8.96" y="11.49"/>
<vertex x="9.19" y="11.53"/>
<vertex x="9.43" y="11.57"/>
<vertex x="9.66" y="11.61"/>
<vertex x="9.89" y="11.65"/>
<vertex x="9.89" y="11.54"/>
<vertex x="9.89" y="11.43"/>
<vertex x="9.89" y="11.31"/>
<vertex x="9.89" y="11.2"/>
<vertex x="9.89" y="11.09"/>
<vertex x="9.89" y="10.98"/>
<vertex x="9.89" y="10.86"/>
<vertex x="9.89" y="10.75"/>
<vertex x="9.9" y="10.75"/>
<vertex x="10.09" y="11.02"/>
<vertex x="10.31" y="11.24"/>
<vertex x="10.54" y="11.43"/>
<vertex x="10.8" y="11.58"/>
<vertex x="11.08" y="11.7"/>
<vertex x="11.37" y="11.78"/>
<vertex x="11.68" y="11.83"/>
<vertex x="12" y="11.84"/>
<vertex x="12.78" y="11.76"/>
<vertex x="13.44" y="11.53"/>
<vertex x="13.99" y="11.17"/>
<vertex x="14.44" y="10.7"/>
<vertex x="14.78" y="10.13"/>
<vertex x="15.03" y="9.49"/>
<vertex x="15.17" y="8.78"/>
<vertex x="13.25" y="8.52"/>
<vertex x="13.18" y="8.93"/>
<vertex x="13.07" y="9.32"/>
<vertex x="12.89" y="9.66"/>
<vertex x="12.66" y="9.96"/>
<vertex x="12.37" y="10.18"/>
<vertex x="12.01" y="10.33"/>
<vertex x="11.58" y="10.38"/>
<vertex x="11.14" y="10.33"/>
<vertex x="10.78" y="10.18"/>
<vertex x="10.49" y="9.96"/>
<vertex x="10.26" y="9.67"/>
<vertex x="10.09" y="9.32"/>
<vertex x="9.98" y="8.94"/>
<vertex x="9.92" y="8.52"/>
<vertex x="9.9" y="8.1"/>
<vertex x="9.92" y="7.67"/>
<vertex x="9.99" y="7.26"/>
<vertex x="10.1" y="6.88"/>
<vertex x="10.27" y="6.55"/>
<vertex x="10.5" y="6.26"/>
<vertex x="10.8" y="6.04"/>
<vertex x="11.16" y="5.9"/>
<vertex x="11.59" y="5.86"/>
<vertex x="12.03" y="5.9"/>
<vertex x="12.39" y="6.04"/>
<vertex x="12.68" y="6.26"/>
<vertex x="12.91" y="6.55"/>
</polygon>
<vertex x="18.17" y="8.64"/>
<vertex x="18.61" y="8.69"/>
<vertex x="19.03" y="8.74"/>
<vertex x="19.43" y="8.8"/>
<vertex x="19.66" y="7.75"/>
<vertex x="19.55" y="7.73"/>
<vertex x="19.44" y="7.72"/>
<vertex x="19.32" y="7.7"/>
<vertex x="19.21" y="7.68"/>
<vertex x="19.09" y="7.66"/>
<vertex x="18.98" y="7.65"/>
<vertex x="18.86" y="7.63"/>
<vertex x="18.75" y="7.6"/>
<vertex x="18.64" y="7.58"/>
<vertex x="18.53" y="7.55"/>
</polygon>
<vertex x="18.43" y="7.52"/>
<vertex x="18.33" y="7.48"/>
<vertex x="18.24" y="7.44"/>
<vertex x="18.15" y="7.39"/>
<vertex x="18.06" y="7.33"/>
<vertex x="17.99" y="7.27"/>
<vertex x="17.92" y="7.2"/>
<vertex x="17.86" y="7.12"/>
<vertex x="17.81" y="7.03"/>
<vertex x="17.77" y="6.94"/>
<vertex x="17.74" y="6.83"/>
<vertex x="17.72" y="6.71"/>
<vertex x="17.72" y="6.59"/>
<vertex x="17.72" y="6.46"/>
<vertex x="17.74" y="6.34"/>
<vertex x="17.77" y="6.24"/>
<vertex x="17.81" y="6.15"/>
<vertex x="17.86" y="6.06"/>
<vertex x="17.93" y="5.99"/>
<vertex x="18" y="5.92"/>
<vertex x="18.07" y="5.87"/>
<vertex x="18.16" y="5.82"/>
<vertex x="18.25" y="5.78"/>
<vertex x="18.35" y="5.75"/>
<vertex x="18.45" y="5.72"/>
<vertex x="18.56" y="5.71"/>
<vertex x="18.67" y="5.69"/>
<vertex x="18.79" y="5.69"/>
<vertex x="18.91" y="5.68"/>
<vertex x="19.17" y="5.7"/>
<vertex x="19.41" y="5.74"/>
<vertex x="19.61" y="5.8"/>
<vertex x="19.79" y="5.88"/>
<vertex x="19.94" y="5.98"/>
<vertex x="20.07" y="6.09"/>
<vertex x="20.17" y="6.21"/>
<vertex x="20.26" y="6.34"/>
<vertex x="20.33" y="6.47"/>
<vertex x="20.38" y="6.61"/>
<vertex x="20.42" y="6.74"/>
<vertex x="20.45" y="6.88"/>
<vertex x="20.46" y="7"/>
<vertex x="20.47" y="7.12"/>
<vertex x="20.48" y="7.22"/>
<vertex x="20.48" y="7.31"/>
<vertex x="20.48" y="7.36"/>
<vertex x="20.48" y="7.41"/>
<vertex x="20.48" y="7.45"/>
<vertex x="20.48" y="7.5"/>
<vertex x="20.48" y="7.54"/>
<vertex x="20.48" y="7.59"/>
<vertex x="20.48" y="7.63"/>
<vertex x="20.48" y="7.68"/>
<vertex x="20.48" y="7.72"/>
<vertex x="20.48" y="7.77"/>
<vertex x="20.48" y="7.81"/>
<vertex x="20.48" y="7.86"/>
<vertex x="20.48" y="7.9"/>
<vertex x="20.48" y="7.95"/>
<vertex x="20.48" y="7.99"/>
<vertex x="20.48" y="8.04"/>
<vertex x="20.41" y="7.99"/>
<vertex x="20.34" y="7.94"/>
<vertex x="20.26" y="7.9"/>
<vertex x="20.17" y="7.87"/>
<vertex x="20.08" y="7.84"/>
<vertex x="19.98" y="7.81"/>
<vertex x="19.88" y="7.79"/>
<vertex x="19.77" y="7.76"/>
<vertex x="19.78" y="8.88"/>
<vertex x="20.07" y="8.98"/>
<vertex x="20.3" y="9.12"/>
<vertex x="20.44" y="9.32"/>
<vertex x="20.48" y="9.58"/>
<vertex x="20.47" y="9.73"/>
<vertex x="20.45" y="9.86"/>
<vertex x="20.42" y="9.97"/>
<vertex x="20.38" y="10.08"/>
<vertex x="20.33" y="10.17"/>
<vertex x="20.26" y="10.24"/>
<vertex x="20.19" y="10.31"/>
<vertex x="20.11" y="10.37"/>
<vertex x="20.02" y="10.41"/>
<vertex x="19.92" y="10.45"/>
<vertex x="19.82" y="10.48"/>
<vertex x="19.71" y="10.5"/>
<vertex x="19.59" y="10.52"/>
<vertex x="19.47" y="10.53"/>
<vertex x="19.35" y="10.53"/>
<vertex x="19.22" y="10.54"/>
<vertex x="19.08" y="10.53"/>
<vertex x="18.95" y="10.52"/>
<vertex x="18.83" y="10.5"/>
<vertex x="18.71" y="10.47"/>
<vertex x="18.6" y="10.44"/>
<vertex x="18.5" y="10.4"/>
<vertex x="18.41" y="10.35"/>
<vertex x="18.32" y="10.29"/>
<vertex x="18.24" y="10.22"/>
<vertex x="18.17" y="10.14"/>
<vertex x="18.11" y="10.05"/>
<vertex x="18.06" y="9.95"/>
<vertex x="18.02" y="9.85"/>
<vertex x="17.98" y="9.73"/>
<vertex x="17.95" y="9.6"/>
<vertex x="17.94" y="9.46"/>
<vertex x="17.81" y="9.46"/>
<vertex x="17.69" y="9.46"/>
<vertex x="17.57" y="9.46"/>
<vertex x="17.45" y="9.46"/>
<vertex x="17.33" y="9.46"/>
<vertex x="17.21" y="9.46"/>
<vertex x="17.09" y="9.46"/>
<vertex x="16.97" y="9.46"/>
<vertex x="16.85" y="9.46"/>
<vertex x="16.72" y="9.46"/>
<vertex x="16.6" y="9.46"/>
<vertex x="16.48" y="9.46"/>
<vertex x="16.36" y="9.46"/>
<vertex x="16.24" y="9.46"/>
<vertex x="16.12" y="9.46"/>
<vertex x="16" y="9.46"/>
<vertex x="16.03" y="9.79"/>
<vertex x="16.11" y="10.08"/>
<vertex x="16.21" y="10.35"/>
<vertex x="16.34" y="10.6"/>
<vertex x="16.5" y="10.81"/>
<vertex x="16.68" y="11.01"/>
<vertex x="16.88" y="11.18"/>
<vertex x="17.1" y="11.32"/>
<vertex x="17.35" y="11.45"/>
<vertex x="17.6" y="11.56"/>
<vertex x="17.87" y="11.64"/>
<vertex x="18.15" y="11.71"/>
<vertex x="18.43" y="11.77"/>
<vertex x="18.73" y="11.8"/>
<vertex x="19.02" y="11.82"/>
<vertex x="19.32" y="11.83"/>
<vertex x="19.59" y="11.83"/>
<vertex x="19.86" y="11.81"/>
<vertex x="20.13" y="11.79"/>
<vertex x="20.4" y="11.75"/>
<vertex x="20.66" y="11.7"/>
<vertex x="20.92" y="11.64"/>
<vertex x="21.17" y="11.56"/>
<vertex x="21.4" y="11.46"/>
<vertex x="21.62" y="11.34"/>
<vertex x="21.81" y="11.2"/>
<vertex x="21.99" y="11.03"/>
<vertex x="22.14" y="10.85"/>
<vertex x="22.26" y="10.63"/>
<vertex x="22.35" y="10.39"/>
<vertex x="22.41" y="10.12"/>
<vertex x="22.43" y="9.82"/>
<vertex x="22.43" y="9.59"/>
<vertex x="22.43" y="9.36"/>
<vertex x="22.43" y="9.13"/>
<vertex x="22.43" y="8.9"/>
<vertex x="22.43" y="8.67"/>
<vertex x="22.43" y="8.44"/>
<vertex x="22.43" y="8.21"/>
<vertex x="22.43" y="7.98"/>
<vertex x="22.43" y="7.75"/>
<vertex x="22.43" y="7.52"/>
<vertex x="22.43" y="7.29"/>
<vertex x="22.43" y="7.06"/>
<vertex x="22.43" y="6.83"/>
<vertex x="22.43" y="6.6"/>
<vertex x="22.43" y="6.37"/>
<vertex x="22.43" y="6.14"/>
<vertex x="22.43" y="6.02"/>
<vertex x="22.43" y="5.9"/>
<vertex x="22.43" y="5.78"/>
<vertex x="22.43" y="5.66"/>
<vertex x="22.44" y="5.55"/>
<vertex x="22.45" y="5.43"/>
<vertex x="22.46" y="5.32"/>
<vertex x="22.48" y="5.22"/>
<vertex x="22.5" y="5.12"/>
<vertex x="22.51" y="5.02"/>
<vertex x="22.53" y="4.93"/>
<vertex x="22.55" y="4.84"/>
<vertex x="22.58" y="4.76"/>
<vertex x="22.61" y="4.69"/>
<vertex x="22.63" y="4.62"/>
<vertex x="22.67" y="4.57"/>
<vertex x="22.54" y="4.57"/>
<vertex x="22.42" y="4.57"/>
<vertex x="22.3" y="4.57"/>
<vertex x="22.18" y="4.57"/>
<vertex x="22.05" y="4.57"/>
<vertex x="21.93" y="4.57"/>
<vertex x="21.81" y="4.57"/>
<vertex x="21.68" y="4.57"/>
<vertex x="21.56" y="4.57"/>
<vertex x="21.44" y="4.57"/>
<vertex x="21.31" y="4.57"/>
<vertex x="21.19" y="4.57"/>
<vertex x="21.07" y="4.57"/>
<vertex x="20.95" y="4.57"/>
<vertex x="20.82" y="4.57"/>
<vertex x="20.7" y="4.57"/>
<vertex x="20.69" y="4.61"/>
<vertex x="20.67" y="4.65"/>
<vertex x="20.66" y="4.69"/>
<vertex x="20.64" y="4.73"/>
<vertex x="20.63" y="4.78"/>
<vertex x="20.62" y="4.82"/>
<vertex x="20.61" y="4.86"/>
<vertex x="20.6" y="4.9"/>
<vertex x="20.59" y="4.95"/>
<vertex x="20.58" y="4.99"/>
<vertex x="20.58" y="5.03"/>
<vertex x="20.57" y="5.08"/>
<vertex x="20.57" y="5.12"/>
<vertex x="20.57" y="5.16"/>
<vertex x="20.57" y="5.21"/>
<vertex x="20.56" y="5.25"/>
<vertex x="20.45" y="5.13"/>
<vertex x="20.32" y="5.03"/>
<vertex x="20.19" y="4.93"/>
<vertex x="20.06" y="4.84"/>
<vertex x="19.92" y="4.76"/>
<vertex x="19.77" y="4.69"/>
<vertex x="19.62" y="4.63"/>
<vertex x="19.47" y="4.57"/>
<vertex x="19.32" y="4.52"/>
<vertex x="19.16" y="4.48"/>
<vertex x="19" y="4.45"/>
<vertex x="18.84" y="4.42"/>
<vertex x="18.68" y="4.4"/>
<vertex x="18.51" y="4.38"/>
<vertex x="18.35" y="4.37"/>
<vertex x="18.19" y="4.37"/>
<vertex x="17.94" y="4.38"/>
<vertex x="17.69" y="4.4"/>
<vertex x="17.46" y="4.44"/>
<vertex x="17.24" y="4.5"/>
<vertex x="17.03" y="4.57"/>
<vertex x="16.83" y="4.66"/>
<vertex x="16.65" y="4.76"/>
<vertex x="16.48" y="4.89"/>
<vertex x="16.32" y="5.03"/>
<vertex x="16.18" y="5.18"/>
<vertex x="16.07" y="5.36"/>
<vertex x="15.97" y="5.55"/>
<vertex x="15.89" y="5.76"/>
<vertex x="15.83" y="5.98"/>
<vertex x="15.79" y="6.23"/>
<vertex x="15.78" y="6.49"/>
<vertex x="15.84" y="7.04"/>
<vertex x="15.99" y="7.48"/>
<vertex x="16.23" y="7.83"/>
<vertex x="16.53" y="8.1"/>
<vertex x="16.9" y="8.31"/>
<vertex x="17.3" y="8.46"/>
<vertex x="17.73" y="8.56"/>
</polygon>
<vertex x="23.52" y="11.32"/>
<vertex x="23.75" y="11.36"/>
<vertex x="23.98" y="11.4"/>
<vertex x="24.21" y="11.44"/>
<vertex x="24.44" y="11.49"/>
<vertex x="24.67" y="11.53"/>
<vertex x="24.9" y="11.57"/>
<vertex x="25.13" y="11.61"/>
<vertex x="25.37" y="11.65"/>
<vertex x="25.37" y="11.49"/>
<vertex x="25.37" y="11.32"/>
<vertex x="25.37" y="11.16"/>
<vertex x="25.37" y="10.99"/>
<vertex x="25.37" y="10.83"/>
<vertex x="25.37" y="10.66"/>
<vertex x="25.37" y="10.5"/>
<vertex x="25.37" y="10.34"/>
<vertex x="25.38" y="10.34"/>
<vertex x="25.54" y="10.66"/>
<vertex x="25.75" y="10.95"/>
<vertex x="26" y="11.2"/>
<vertex x="26.28" y="11.42"/>
<vertex x="26.59" y="11.6"/>
<vertex x="26.92" y="11.73"/>
<vertex x="27.27" y="11.81"/>
<vertex x="27.63" y="11.84"/>
<vertex x="27.69" y="11.84"/>
<vertex x="27.74" y="11.84"/>
<vertex x="27.8" y="11.83"/>
<vertex x="27.85" y="11.83"/>
<vertex x="27.9" y="11.82"/>
<vertex x="27.96" y="11.8"/>
<vertex x="28.01" y="11.79"/>
<vertex x="28.06" y="11.77"/>
<vertex x="28.06" y="11.55"/>
<vertex x="28.06" y="11.32"/>
<vertex x="28.06" y="11.1"/>
<vertex x="28.06" y="10.87"/>
<vertex x="28.06" y="10.64"/>
<vertex x="28.06" y="10.42"/>
<vertex x="28.06" y="10.19"/>
<vertex x="28.06" y="9.97"/>
<vertex x="27.99" y="9.98"/>
<vertex x="27.91" y="10"/>
<vertex x="27.82" y="10.01"/>
<vertex x="27.73" y="10.02"/>
<vertex x="27.64" y="10.03"/>
<vertex x="27.54" y="10.03"/>
<vertex x="27.45" y="10.03"/>
<vertex x="27.36" y="10.04"/>
<vertex x="26.87" y="9.99"/>
<vertex x="26.46" y="9.86"/>
<vertex x="26.12" y="9.65"/>
<vertex x="25.87" y="9.37"/>
<vertex x="25.67" y="9.04"/>
<vertex x="25.54" y="8.65"/>
<vertex x="25.47" y="8.22"/>
<vertex x="25.44" y="7.77"/>
<vertex x="25.44" y="7.37"/>
<vertex x="25.44" y="6.97"/>
<vertex x="25.44" y="6.57"/>
<vertex x="25.44" y="6.17"/>
<vertex x="25.44" y="5.77"/>
<vertex x="25.44" y="5.38"/>
<vertex x="25.44" y="4.98"/>
<vertex x="25.44" y="4.58"/>
<vertex x="25.2" y="4.58"/>
<vertex x="24.96" y="4.58"/>
<vertex x="24.72" y="4.58"/>
<vertex x="24.47" y="4.58"/>
<vertex x="24.23" y="4.58"/>
<vertex x="23.99" y="4.58"/>
<vertex x="23.75" y="4.58"/>
<vertex x="23.5" y="4.58"/>
<vertex x="23.5" y="5.42"/>
<vertex x="23.5" y="6.26"/>
<vertex x="23.5" y="7.11"/>
<vertex x="23.5" y="7.95"/>
<vertex x="23.5" y="8.79"/>
<vertex x="23.5" y="9.63"/>
<vertex x="23.5" y="10.48"/>
</polygon>
<vertex x="28.82" y="13.28"/>
<vertex x="30.76" y="14.35"/>
<vertex x="30.76" y="9.11"/>
<vertex x="33.21" y="11.65"/>
<vertex x="35.51" y="11.65"/>
<vertex x="32.84" y="9.05"/>
<vertex x="35.81" y="4.58"/>
<vertex x="33.46" y="4.58"/>
<vertex x="31.52" y="7.74"/>
<vertex x="30.76" y="7.02"/>
<vertex x="30.76" y="4.58"/>
<vertex x="28.82" y="4.58"/>
</polygon>
<vertex x="36.99" y="10.35"/>
<vertex x="36.75" y="10.35"/>
<vertex x="36.51" y="10.35"/>
<vertex x="36.27" y="10.35"/>
<vertex x="36.03" y="10.35"/>
<vertex x="35.79" y="10.35"/>
<vertex x="35.55" y="10.35"/>
<vertex x="35.32" y="10.35"/>
<vertex x="35.08" y="10.35"/>
<vertex x="35.24" y="10.52"/>
<vertex x="35.41" y="10.68"/>
<vertex x="35.57" y="10.84"/>
<vertex x="35.74" y="11"/>
<vertex x="35.9" y="11.16"/>
<vertex x="36.07" y="11.33"/>
<vertex x="36.23" y="11.49"/>
<vertex x="36.4" y="11.65"/>
<vertex x="36.47" y="11.65"/>
<vertex x="36.55" y="11.65"/>
<vertex x="36.62" y="11.65"/>
<vertex x="36.7" y="11.65"/>
<vertex x="36.77" y="11.65"/>
<vertex x="36.84" y="11.65"/>
<vertex x="36.92" y="11.65"/>
<vertex x="36.99" y="11.65"/>
<vertex x="36.99" y="11.72"/>
<vertex x="36.99" y="11.79"/>
<vertex x="36.99" y="11.86"/>
<vertex x="36.99" y="11.92"/>
<vertex x="36.99" y="11.99"/>
<vertex x="36.99" y="12.06"/>
<vertex x="36.99" y="12.13"/>
<vertex x="36.99" y="12.2"/>
<vertex x="37.03" y="12.65"/>
<vertex x="37.14" y="13.06"/>
<vertex x="37.32" y="13.43"/>
<vertex x="37.58" y="13.74"/>
<vertex x="37.91" y="14"/>
<vertex x="38.32" y="14.19"/>
<vertex x="38.8" y="14.3"/>
<vertex x="39.36" y="14.34"/>
<vertex x="39.48" y="14.34"/>
<vertex x="39.61" y="14.34"/>
<vertex x="39.74" y="14.34"/>
<vertex x="39.87" y="14.33"/>
<vertex x="40" y="14.32"/>
<vertex x="40.13" y="14.31"/>
<vertex x="40.26" y="14.3"/>
<vertex x="40.38" y="14.3"/>
<vertex x="40.38" y="14.12"/>
<vertex x="40.38" y="13.94"/>
<vertex x="40.38" y="13.75"/>
<vertex x="40.38" y="13.57"/>
<vertex x="40.38" y="13.39"/>
<vertex x="40.38" y="13.21"/>
<vertex x="40.38" y="13.03"/>
<vertex x="40.38" y="12.85"/>
<vertex x="40.29" y="12.86"/>
<vertex x="40.21" y="12.87"/>
<vertex x="40.12" y="12.87"/>
<vertex x="40.03" y="12.88"/>
<vertex x="39.94" y="12.88"/>
<vertex x="39.85" y="12.88"/>
<vertex x="39.76" y="12.88"/>
<vertex x="39.67" y="12.88"/>
<vertex x="39.49" y="12.87"/>
<vertex x="39.33" y="12.84"/>
<vertex x="39.2" y="12.78"/>
<vertex x="39.1" y="12.7"/>
<vertex x="39.03" y="12.59"/>
<vertex x="38.97" y="12.45"/>
<vertex x="38.94" y="12.28"/>
<vertex x="38.93" y="12.08"/>
<vertex x="38.93" y="12.02"/>
<vertex x="38.93" y="11.97"/>
<vertex x="38.93" y="11.92"/>
<vertex x="38.93" y="11.86"/>
<vertex x="38.93" y="11.81"/>
<vertex x="38.93" y="11.76"/>
<vertex x="38.93" y="11.7"/>
<vertex x="38.93" y="11.65"/>
<vertex x="39.1" y="11.65"/>
<vertex x="39.27" y="11.65"/>
<vertex x="39.43" y="11.65"/>
<vertex x="39.6" y="11.65"/>
<vertex x="39.77" y="11.65"/>
<vertex x="39.94" y="11.65"/>
<vertex x="40.1" y="11.65"/>
<vertex x="40.27" y="11.65"/>
<vertex x="40.27" y="11.49"/>
<vertex x="40.27" y="11.33"/>
<vertex x="40.27" y="11.16"/>
<vertex x="40.27" y="11"/>
<vertex x="40.27" y="10.84"/>
<vertex x="40.27" y="10.68"/>
<vertex x="40.27" y="10.51"/>
<vertex x="40.27" y="10.35"/>
<vertex x="40.1" y="10.35"/>
<vertex x="39.94" y="10.35"/>
<vertex x="39.77" y="10.35"/>
<vertex x="39.6" y="10.35"/>
<vertex x="39.43" y="10.35"/>
<vertex x="39.27" y="10.35"/>
<vertex x="39.1" y="10.35"/>
<vertex x="38.93" y="10.35"/>
<vertex x="38.93" y="9.63"/>
<vertex x="38.93" y="8.91"/>
<vertex x="38.93" y="8.19"/>
<vertex x="38.93" y="7.47"/>
<vertex x="38.93" y="6.75"/>
<vertex x="38.93" y="6.02"/>
<vertex x="38.93" y="5.3"/>
<vertex x="38.93" y="4.58"/>
<vertex x="38.69" y="4.58"/>
<vertex x="38.45" y="4.58"/>
<vertex x="38.2" y="4.58"/>
<vertex x="37.96" y="4.58"/>
<vertex x="37.72" y="4.58"/>
<vertex x="37.47" y="4.58"/>
<vertex x="37.23" y="4.58"/>
<vertex x="36.99" y="4.58"/>
<vertex x="36.99" y="5.3"/>
<vertex x="36.99" y="6.02"/>
<vertex x="36.99" y="6.75"/>
<vertex x="36.99" y="7.47"/>
<vertex x="36.99" y="8.19"/>
<vertex x="36.99" y="8.91"/>
<vertex x="36.99" y="9.63"/>
</polygon>
<vertex x="47.45" y="4.58"/>
<vertex x="47.22" y="4.58"/>
<vertex x="46.99" y="4.58"/>
<vertex x="46.76" y="4.58"/>
<vertex x="46.53" y="4.58"/>
<vertex x="46.3" y="4.58"/>
<vertex x="46.06" y="4.58"/>
<vertex x="45.83" y="4.58"/>
<vertex x="45.6" y="4.58"/>
<vertex x="45.6" y="4.71"/>
<vertex x="45.6" y="4.83"/>
<vertex x="45.6" y="4.95"/>
<vertex x="45.6" y="5.07"/>
<vertex x="45.6" y="5.2"/>
<vertex x="45.6" y="5.32"/>
<vertex x="45.6" y="5.44"/>
<vertex x="45.6" y="5.57"/>
<vertex x="45.58" y="5.57"/>
<vertex x="45.38" y="5.28"/>
<vertex x="45.15" y="5.04"/>
<vertex x="44.9" y="4.84"/>
<vertex x="44.62" y="4.68"/>
<vertex x="44.33" y="4.55"/>
<vertex x="44.03" y="4.46"/>
<vertex x="43.73" y="4.41"/>
<vertex x="43.42" y="4.39"/>
<vertex x="42.72" y="4.44"/>
<vertex x="42.14" y="4.6"/>
<vertex x="41.69" y="4.85"/>
<vertex x="41.35" y="5.19"/>
<vertex x="41.11" y="5.61"/>
<vertex x="40.95" y="6.11"/>
<vertex x="40.86" y="6.67"/>
<vertex x="40.84" y="7.3"/>
<vertex x="40.84" y="7.84"/>
<vertex x="40.84" y="8.39"/>
<vertex x="40.84" y="8.93"/>
<vertex x="40.84" y="9.48"/>
<vertex x="40.84" y="10.02"/>
<vertex x="40.84" y="10.56"/>
<vertex x="40.84" y="11.11"/>
<vertex x="40.84" y="11.65"/>
<vertex x="41.08" y="11.65"/>
<vertex x="41.32" y="11.65"/>
<vertex x="41.56" y="11.65"/>
<vertex x="41.81" y="11.65"/>
<vertex x="42.05" y="11.65"/>
<vertex x="42.29" y="11.65"/>
<vertex x="42.53" y="11.65"/>
<vertex x="42.78" y="11.65"/>
<vertex x="42.78" y="11.15"/>
<vertex x="42.78" y="10.65"/>
<vertex x="42.78" y="10.15"/>
<vertex x="42.78" y="9.65"/>
<vertex x="42.78" y="9.16"/>
<vertex x="42.78" y="8.66"/>
<vertex x="42.78" y="8.16"/>
<vertex x="42.78" y="7.66"/>
<vertex x="42.8" y="7.25"/>
<vertex x="42.84" y="6.9"/>
<vertex x="42.93" y="6.6"/>
<vertex x="43.06" y="6.35"/>
<vertex x="43.23" y="6.16"/>
<vertex x="43.44" y="6.03"/>
<vertex x="43.71" y="5.95"/>
<vertex x="44.02" y="5.92"/>
<vertex x="44.39" y="5.95"/>
<vertex x="44.7" y="6.04"/>
<vertex x="44.96" y="6.18"/>
<vertex x="45.17" y="6.39"/>
<vertex x="45.33" y="6.67"/>
<vertex x="45.44" y="7.02"/>
<vertex x="45.51" y="7.45"/>
<vertex x="45.53" y="7.94"/>
<vertex x="45.53" y="8.41"/>
<vertex x="45.53" y="8.87"/>
<vertex x="45.53" y="9.33"/>
<vertex x="45.53" y="9.8"/>
<vertex x="45.53" y="10.26"/>
<vertex x="45.53" y="10.72"/>
<vertex x="45.53" y="11.19"/>
<vertex x="45.53" y="11.65"/>
<vertex x="45.77" y="11.65"/>
<vertex x="46.01" y="11.65"/>
<vertex x="46.26" y="11.65"/>
<vertex x="46.5" y="11.65"/>
<vertex x="46.74" y="11.65"/>
<vertex x="46.98" y="11.65"/>
<vertex x="47.23" y="11.65"/>
<vertex x="47.47" y="11.65"/>
<vertex x="47.47" y="10.77"/>
<vertex x="47.47" y="9.88"/>
<vertex x="47.47" y="9"/>
<vertex x="47.47" y="8.12"/>
<vertex x="47.47" y="7.23"/>
<vertex x="47.47" y="6.35"/>
<vertex x="47.47" y="5.46"/>
</polygon>
<vertex x="48.52" y="11.65"/>
<vertex x="48.75" y="11.65"/>
<vertex x="48.98" y="11.65"/>
<vertex x="49.21" y="11.65"/>
<vertex x="49.44" y="11.65"/>
<vertex x="49.67" y="11.65"/>
<vertex x="49.91" y="11.65"/>
<vertex x="50.14" y="11.65"/>
<vertex x="50.37" y="11.65"/>
<vertex x="50.37" y="11.53"/>
<vertex x="50.37" y="11.41"/>
<vertex x="50.37" y="11.28"/>
<vertex x="50.37" y="11.16"/>
<vertex x="50.37" y="11.04"/>
<vertex x="50.37" y="10.91"/>
<vertex x="50.37" y="10.79"/>
<vertex x="50.37" y="10.67"/>
<vertex x="50.38" y="10.67"/>
<vertex x="50.39" y="10.67"/>
<vertex x="50.59" y="10.95"/>
<vertex x="50.82" y="11.19"/>
<vertex x="51.07" y="11.39"/>
<vertex x="51.35" y="11.56"/>
<vertex x="51.63" y="11.68"/>
<vertex x="51.93" y="11.77"/>
<vertex x="52.24" y="11.83"/>
<vertex x="52.55" y="11.84"/>
<vertex x="53.25" y="11.79"/>
<vertex x="53.82" y="11.64"/>
<vertex x="54.27" y="11.38"/>
<vertex x="54.62" y="11.04"/>
<vertex x="54.86" y="10.62"/>
<vertex x="55.02" y="10.13"/>
<vertex x="55.11" y="9.56"/>
<vertex x="55.13" y="8.93"/>
<vertex x="55.13" y="8.39"/>
<vertex x="55.13" y="7.85"/>
<vertex x="55.13" y="7.3"/>
<vertex x="55.13" y="6.76"/>
<vertex x="55.13" y="6.22"/>
<vertex x="55.13" y="5.67"/>
<vertex x="55.13" y="5.13"/>
<vertex x="55.13" y="4.58"/>
<vertex x="54.89" y="4.58"/>
<vertex x="54.65" y="4.58"/>
<vertex x="54.41" y="4.58"/>
<vertex x="54.16" y="4.58"/>
<vertex x="53.92" y="4.58"/>
<vertex x="53.68" y="4.58"/>
<vertex x="53.43" y="4.58"/>
<vertex x="53.19" y="4.58"/>
<vertex x="53.19" y="5.08"/>
<vertex x="53.19" y="5.58"/>
<vertex x="53.19" y="6.08"/>
<vertex x="53.19" y="6.58"/>
<vertex x="53.19" y="7.08"/>
<vertex x="53.19" y="7.58"/>
<vertex x="53.19" y="8.08"/>
<vertex x="53.19" y="8.58"/>
<vertex x="53.17" y="8.98"/>
<vertex x="53.12" y="9.34"/>
<vertex x="53.04" y="9.64"/>
<vertex x="52.91" y="9.88"/>
<vertex x="52.74" y="10.07"/>
<vertex x="52.53" y="10.21"/>
<vertex x="52.26" y="10.29"/>
<vertex x="51.95" y="10.31"/>
<vertex x="51.58" y="10.29"/>
<vertex x="51.27" y="10.2"/>
<vertex x="51.01" y="10.05"/>
<vertex x="50.8" y="9.84"/>
<vertex x="50.64" y="9.56"/>
<vertex x="50.53" y="9.21"/>
<vertex x="50.47" y="8.79"/>
<vertex x="50.44" y="8.29"/>
<vertex x="50.44" y="7.83"/>
<vertex x="50.44" y="7.36"/>
<vertex x="50.44" y="6.9"/>
<vertex x="50.44" y="6.44"/>
<vertex x="50.44" y="5.97"/>
<vertex x="50.44" y="5.51"/>
<vertex x="50.44" y="5.05"/>
<vertex x="50.44" y="4.58"/>
<vertex x="50.2" y="4.58"/>
<vertex x="49.96" y="4.58"/>
<vertex x="49.72" y="4.58"/>
<vertex x="49.47" y="4.58"/>
<vertex x="49.23" y="4.58"/>
<vertex x="48.99" y="4.58"/>
<vertex x="48.74" y="4.58"/>
<vertex x="48.5" y="4.58"/>
<vertex x="48.5" y="5.47"/>
<vertex x="48.5" y="6.35"/>
<vertex x="48.5" y="7.24"/>
<vertex x="48.5" y="8.12"/>
<vertex x="48.5" y="9"/>
<vertex x="48.5" y="9.89"/>
<vertex x="48.5" y="10.77"/>
</polygon>
<vertex x="39.74" y="23.79"/>
<vertex x="39.75" y="23.75"/>
<vertex x="39.76" y="23.66"/>
<vertex x="39.77" y="23.54"/>
<vertex x="39.76" y="23.39"/>
<vertex x="39.72" y="23.24"/>
<vertex x="39.65" y="23.1"/>
<vertex x="39.53" y="22.99"/>
<vertex x="39.34" y="22.92"/>
<vertex x="39.18" y="22.91"/>
<vertex x="39.01" y="22.95"/>
<vertex x="38.82" y="23.01"/>
<vertex x="38.63" y="23.11"/>
<vertex x="38.44" y="23.22"/>
<vertex x="38.27" y="23.35"/>
<vertex x="38.11" y="23.5"/>
<vertex x="37.97" y="23.64"/>
<vertex x="37.84" y="23.82"/>
<vertex x="37.75" y="23.99"/>
<vertex x="37.7" y="24.15"/>
<vertex x="37.68" y="24.31"/>
<vertex x="37.7" y="24.45"/>
<vertex x="37.75" y="24.59"/>
<vertex x="37.83" y="24.73"/>
<vertex x="37.93" y="24.86"/>
<vertex x="38.12" y="25.02"/>
<vertex x="38.33" y="25.13"/>
<vertex x="38.54" y="25.19"/>
<vertex x="38.74" y="25.21"/>
<vertex x="38.92" y="25.21"/>
<vertex x="39.07" y="25.2"/>
<vertex x="39.16" y="25.18"/>
<vertex x="39.2" y="25.18"/>
<vertex x="39.13" y="25.23"/>
<vertex x="38.95" y="25.36"/>
<vertex x="38.65" y="25.53"/>
<vertex x="38.27" y="25.69"/>
<vertex x="37.82" y="25.8"/>
<vertex x="37.31" y="25.82"/>
<vertex x="36.77" y="25.7"/>
<vertex x="36.2" y="25.41"/>
<vertex x="35.77" y="25.04"/>
<vertex x="35.49" y="24.65"/>
<vertex x="35.36" y="24.24"/>
<vertex x="35.36" y="23.81"/>
<vertex x="35.48" y="23.37"/>
<vertex x="35.71" y="22.94"/>
<vertex x="36.04" y="22.5"/>
<vertex x="36.46" y="22.08"/>
<vertex x="36.78" y="21.7"/>
<vertex x="36.94" y="21.32"/>
<vertex x="36.96" y="20.97"/>
<vertex x="36.85" y="20.66"/>
<vertex x="36.63" y="20.4"/>
<vertex x="36.33" y="20.21"/>
<vertex x="35.97" y="20.11"/>
<vertex x="35.57" y="20.1"/>
<vertex x="35.3" y="20.16"/>
<vertex x="35.08" y="20.26"/>
<vertex x="34.9" y="20.39"/>
<vertex x="34.76" y="20.54"/>
<vertex x="34.67" y="20.71"/>
<vertex x="34.63" y="20.88"/>
<vertex x="34.63" y="21.04"/>
<vertex x="34.67" y="21.19"/>
<vertex x="34.75" y="21.31"/>
<vertex x="34.85" y="21.41"/>
<vertex x="34.97" y="21.5"/>
<vertex x="35.09" y="21.58"/>
<vertex x="35.2" y="21.64"/>
<vertex x="35.29" y="21.68"/>
<vertex x="35.36" y="21.71"/>
<vertex x="35.38" y="21.72"/>
<vertex x="35.35" y="21.73"/>
<vertex x="35.27" y="21.75"/>
<vertex x="35.14" y="21.78"/>
<vertex x="34.97" y="21.81"/>
<vertex x="34.77" y="21.83"/>
<vertex x="34.53" y="21.82"/>
<vertex x="34.28" y="21.78"/>
<vertex x="34.01" y="21.69"/>
<vertex x="33.76" y="21.59"/>
<vertex x="33.53" y="21.44"/>
<vertex x="33.33" y="21.26"/>
<vertex x="33.15" y="21.03"/>
<vertex x="33.01" y="20.74"/>
<vertex x="32.9" y="20.4"/>
<vertex x="32.84" y="19.99"/>
<vertex x="32.83" y="19.51"/>
<vertex x="32.83" y="18.71"/>
<vertex x="32.83" y="17.91"/>
<vertex x="32.83" y="17.11"/>
<vertex x="32.83" y="16.31"/>
<vertex x="32.83" y="15.51"/>
<vertex x="32.83" y="14.7"/>
<vertex x="32.83" y="13.9"/>
<vertex x="32.83" y="13.1"/>
<vertex x="32.86" y="13.14"/>
<vertex x="32.95" y="13.25"/>
<vertex x="33.09" y="13.42"/>
<vertex x="33.28" y="13.64"/>
<vertex x="33.5" y="13.9"/>
<vertex x="33.76" y="14.19"/>
<vertex x="34.04" y="14.5"/>
<vertex x="34.33" y="14.82"/>
<vertex x="34.65" y="15.17"/>
<vertex x="34.94" y="15.48"/>
<vertex x="35.2" y="15.76"/>
<vertex x="35.45" y="15.99"/>
<vertex x="35.7" y="16.18"/>
<vertex x="35.97" y="16.3"/>
<vertex x="36.26" y="16.37"/>
<vertex x="36.59" y="16.38"/>
<vertex x="37.23" y="16.38"/>
<vertex x="37.82" y="16.45"/>
<vertex x="38.37" y="16.61"/>
<vertex x="38.88" y="16.83"/>
<vertex x="39.34" y="17.11"/>
<vertex x="39.77" y="17.46"/>
<vertex x="40.15" y="17.86"/>
<vertex x="40.5" y="18.31"/>
<vertex x="40.57" y="18.42"/>
<vertex x="40.99" y="19.22"/>
<vertex x="41.24" y="20.13"/>
<vertex x="41.28" y="21.01"/>
<vertex x="41.16" y="21.82"/>
<vertex x="40.91" y="22.54"/>
<vertex x="40.56" y="23.12"/>
<vertex x="40.16" y="23.55"/>
</polygon>
</symbol>
<symbol name="SFE_LOGO_FLAME">
<vertex x="7.28" y="11.18"/>
<vertex x="7.28" y="11.15"/>
<vertex x="7.29" y="11.06"/>
<vertex x="7.3" y="10.94"/>
<vertex x="7.29" y="10.79"/>
<vertex x="7.25" y="10.64"/>
<vertex x="7.18" y="10.49"/>
<vertex x="7.06" y="10.38"/>
<vertex x="6.88" y="10.31"/>
<vertex x="6.72" y="10.31"/>
<vertex x="6.54" y="10.35"/>
<vertex x="6.35" y="10.41"/>
<vertex x="6.16" y="10.5"/>
<vertex x="5.97" y="10.62"/>
<vertex x="5.8" y="10.75"/>
<vertex x="5.64" y="10.89"/>
<vertex x="5.5" y="11.04"/>
<vertex x="5.37" y="11.22"/>
<vertex x="5.28" y="11.39"/>
<vertex x="5.23" y="11.55"/>
<vertex x="5.21" y="11.7"/>
<vertex x="5.23" y="11.85"/>
<vertex x="5.28" y="11.99"/>
<vertex x="5.36" y="12.13"/>
<vertex x="5.46" y="12.26"/>
<vertex x="5.65" y="12.42"/>
<vertex x="5.86" y="12.52"/>
<vertex x="6.07" y="12.58"/>
<vertex x="6.27" y="12.61"/>
<vertex x="6.45" y="12.61"/>
<vertex x="6.6" y="12.59"/>
<vertex x="6.7" y="12.58"/>
<vertex x="6.73" y="12.58"/>
<vertex x="6.67" y="12.63"/>
<vertex x="6.48" y="12.76"/>
<vertex x="6.19" y="12.93"/>
<vertex x="5.81" y="13.09"/>
<vertex x="5.35" y="13.2"/>
<vertex x="4.85" y="13.22"/>
<vertex x="4.3" y="13.1"/>
<vertex x="3.73" y="12.81"/>
<vertex x="3.3" y="12.44"/>
<vertex x="3.02" y="12.05"/>
<vertex x="2.89" y="11.64"/>
<vertex x="2.89" y="11.21"/>
<vertex x="3.01" y="10.77"/>
<vertex x="3.24" y="10.34"/>
<vertex x="3.57" y="9.9"/>
<vertex x="3.99" y="9.48"/>
<vertex x="4.32" y="9.1"/>
<vertex x="4.48" y="8.72"/>
<vertex x="4.49" y="8.37"/>
<vertex x="4.38" y="8.06"/>
<vertex x="4.16" y="7.8"/>
<vertex x="3.87" y="7.61"/>
<vertex x="3.5" y="7.51"/>
<vertex x="3.1" y="7.51"/>
<vertex x="2.83" y="7.57"/>
<vertex x="2.61" y="7.67"/>
<vertex x="2.43" y="7.8"/>
<vertex x="2.3" y="7.95"/>
<vertex x="2.2" y="8.11"/>
<vertex x="2.16" y="8.28"/>
<vertex x="2.16" y="8.44"/>
<vertex x="2.2" y="8.6"/>
<vertex x="2.28" y="8.71"/>
<vertex x="2.38" y="8.82"/>
<vertex x="2.5" y="8.9"/>
<vertex x="2.62" y="8.98"/>
<vertex x="2.73" y="9.04"/>
<vertex x="2.82" y="9.08"/>
<vertex x="2.89" y="9.11"/>
<vertex x="2.91" y="9.12"/>
<vertex x="2.88" y="9.14"/>
<vertex x="2.8" y="9.16"/>
<vertex x="2.67" y="9.19"/>
<vertex x="2.5" y="9.22"/>
<vertex x="2.3" y="9.24"/>
<vertex x="2.07" y="9.22"/>
<vertex x="1.81" y="9.18"/>
<vertex x="1.54" y="9.1"/>
<vertex x="1.29" y="8.99"/>
<vertex x="1.07" y="8.85"/>
<vertex x="0.86" y="8.66"/>
<vertex x="0.68" y="8.43"/>
<vertex x="0.54" y="8.15"/>
<vertex x="0.43" y="7.8"/>
<vertex x="0.37" y="7.4"/>
<vertex x="0.36" y="6.92"/>
<vertex x="0.36" y="6.12"/>
<vertex x="0.36" y="5.31"/>
<vertex x="0.36" y="4.51"/>
<vertex x="0.36" y="3.71"/>
<vertex x="0.36" y="2.91"/>
<vertex x="0.36" y="2.11"/>
<vertex x="0.36" y="1.31"/>
<vertex x="0.36" y="0.51"/>
<vertex x="0.4" y="0.55"/>
<vertex x="0.49" y="0.66"/>
<vertex x="0.63" y="0.82"/>
<vertex x="0.81" y="1.04"/>
<vertex x="1.03" y="1.3"/>
<vertex x="1.29" y="1.59"/>
<vertex x="1.57" y="1.9"/>
<vertex x="1.86" y="2.23"/>
<vertex x="2.18" y="2.58"/>
<vertex x="2.47" y="2.89"/>
<vertex x="2.73" y="3.17"/>
<vertex x="2.98" y="3.4"/>
<vertex x="3.24" y="3.58"/>
<vertex x="3.5" y="3.71"/>
<vertex x="3.79" y="3.78"/>
<vertex x="4.12" y="3.78"/>
<vertex x="4.76" y="3.78"/>
<vertex x="5.35" y="3.86"/>
<vertex x="5.9" y="4.01"/>
<vertex x="6.41" y="4.23"/>
<vertex x="6.88" y="4.52"/>
<vertex x="7.3" y="4.86"/>
<vertex x="7.68" y="5.26"/>
<vertex x="8.03" y="5.71"/>
<vertex x="8.11" y="5.83"/>
<vertex x="8.52" y="6.63"/>
<vertex x="8.77" y="7.54"/>
<vertex x="8.82" y="8.42"/>
<vertex x="8.69" y="9.23"/>
<vertex x="8.44" y="9.94"/>
<vertex x="8.1" y="10.53"/>
<vertex x="7.69" y="10.96"/>
<vertex x="7.27" y="11.2"/>
</polygon>
</symbol>
<symbol name="FRAME_LEDGER">
<wire x1="0" y1="0" x2="0" y2="279.4" width="0.4064" layer="94"/>
<wire x1="0" y1="279.4" x2="431.8" y2="279.4" width="0.4064" layer="94"/>
<wire x1="431.8" y1="279.4" x2="431.8" y2="0" width="0.4064" layer="94"/>
<wire x1="431.8" y1="0" x2="0" y2="0" width="0.4064" layer="94"/>
</symbol>
<symbol name="REVISION">
<text x="0" y="0" size="2.54" layer="94">Revision By: </text>
</symbol>
<symbol name="REDBOT_LOGO">
<wire x1="36.412" y1="3.5" x2="0.252" y2="3.5" width="0.262" layer="94"/>
<polygon width="0.003" layer="94">
<vertex x="3.552" y="2.03"/>
<vertex x="3.512" y="1.9"/>
<vertex x="3.432" y="1.8"/>
<vertex x="3.312" y="1.72"/>
<vertex x="3.182" y="1.69"/>
<vertex x="3.052" y="1.68"/>
<vertex x="2.872" y="1.68"/>
<vertex x="2.872" y="1.03"/>
<vertex x="2.552" y="1.03"/>
<vertex x="2.552" y="2.65"/>
<vertex x="3.122" y="2.65"/>
<vertex x="3.242" y="2.64"/>
<vertex x="3.362" y="2.59"/>
<vertex x="3.452" y="2.51"/>
<vertex x="3.522" y="2.41"/>
<vertex x="3.552" y="2.29"/>
<vertex x="3.562" y="2.16"/>
<vertex x="3.242" y="2.16"/>
<vertex x="3.222" y="2.29"/>
<vertex x="3.142" y="2.38"/>
<vertex x="3.012" y="2.41"/>
<vertex x="2.872" y="2.41"/>
<vertex x="2.872" y="1.92"/>
<vertex x="3.022" y="1.92"/>
<vertex x="3.142" y="1.95"/>
<vertex x="3.222" y="2.04"/>
</polygon>
<vertex x="3.932" y="2.65"/>
<vertex x="4.532" y="2.65"/>
<vertex x="4.672" y="2.64"/>
<vertex x="4.802" y="2.59"/>
<vertex x="4.902" y="2.49"/>
<vertex x="4.952" y="2.37"/>
<vertex x="4.972" y="2.23"/>
<vertex x="4.952" y="2.1"/>
<vertex x="4.912" y="1.98"/>
<vertex x="4.822" y="1.88"/>
<vertex x="4.702" y="1.83"/>
<vertex x="4.822" y="1.79"/>
<vertex x="4.902" y="1.71"/>
<vertex x="4.942" y="1.59"/>
<vertex x="4.962" y="1.33"/>
<vertex x="4.962" y="1.23"/>
<vertex x="4.972" y="1.13"/>
<vertex x="5.032" y="1.04"/>
<vertex x="5.032" y="1.03"/>
<vertex x="4.682" y="1.03"/>
<vertex x="4.642" y="1.11"/>
<vertex x="4.632" y="1.2"/>
<vertex x="4.632" y="1.51"/>
<vertex x="4.602" y="1.61"/>
<vertex x="4.542" y="1.69"/>
<vertex x="4.432" y="1.72"/>
<vertex x="4.262" y="1.72"/>
<vertex x="4.262" y="1.03"/>
<vertex x="3.932" y="1.03"/>
<vertex x="4.262" y="2.41"/>
<vertex x="4.262" y="1.94"/>
<vertex x="4.392" y="1.94"/>
<vertex x="4.522" y="1.96"/>
<vertex x="4.622" y="2.06"/>
<vertex x="4.642" y="2.19"/>
<vertex x="4.622" y="2.3"/>
<vertex x="4.532" y="2.39"/>
<vertex x="4.412" y="2.41"/>
</polygon>
<vertex x="6.022" y="2.67"/>
<vertex x="6.152" y="2.64"/>
<vertex x="6.262" y="2.57"/>
<vertex x="6.342" y="2.47"/>
<vertex x="6.392" y="2.35"/>
<vertex x="6.422" y="2.23"/>
<vertex x="6.442" y="2.1"/>
<vertex x="6.442" y="1.58"/>
<vertex x="6.422" y="1.45"/>
<vertex x="6.392" y="1.33"/>
<vertex x="6.342" y="1.21"/>
<vertex x="6.262" y="1.11"/>
<vertex x="6.152" y="1.04"/>
<vertex x="6.022" y="1.01"/>
<vertex x="5.892" y="1"/>
<vertex x="5.762" y="1.01"/>
<vertex x="5.642" y="1.04"/>
<vertex x="5.532" y="1.11"/>
<vertex x="5.452" y="1.21"/>
<vertex x="5.392" y="1.33"/>
<vertex x="5.362" y="1.45"/>
<vertex x="5.342" y="1.71"/>
<vertex x="5.342" y="1.97"/>
<vertex x="5.362" y="2.23"/>
<vertex x="5.392" y="2.35"/>
<vertex x="5.452" y="2.47"/>
<vertex x="5.532" y="2.57"/>
<vertex x="5.642" y="2.64"/>
<vertex x="5.762" y="2.67"/>
<vertex x="5.892" y="2.68"/>
<vertex x="5.892" y="2.44"/>
<vertex x="5.782" y="2.41"/>
<vertex x="5.712" y="2.31"/>
<vertex x="5.682" y="2.2"/>
<vertex x="5.672" y="2.08"/>
<vertex x="5.672" y="1.6"/>
<vertex x="5.682" y="1.48"/>
<vertex x="5.712" y="1.37"/>
<vertex x="5.782" y="1.27"/>
<vertex x="5.892" y="1.24"/>
<vertex x="6.012" y="1.27"/>
<vertex x="6.072" y="1.37"/>
<vertex x="6.102" y="1.48"/>
<vertex x="6.122" y="1.72"/>
<vertex x="6.122" y="1.96"/>
<vertex x="6.102" y="2.2"/>
<vertex x="6.072" y="2.31"/>
<vertex x="6.012" y="2.41"/>
</polygon>
<vertex x="7.552" y="2.17"/>
<vertex x="7.542" y="2.29"/>
<vertex x="7.482" y="2.4"/>
<vertex x="7.372" y="2.44"/>
<vertex x="7.252" y="2.39"/>
<vertex x="7.182" y="2.27"/>
<vertex x="7.162" y="2.14"/>
<vertex x="7.152" y="2.01"/>
<vertex x="7.142" y="1.87"/>
<vertex x="7.152" y="1.75"/>
<vertex x="7.152" y="1.63"/>
<vertex x="7.172" y="1.5"/>
<vertex x="7.192" y="1.39"/>
<vertex x="7.262" y="1.28"/>
<vertex x="7.372" y="1.24"/>
<vertex x="7.482" y="1.28"/>
<vertex x="7.552" y="1.38"/>
<vertex x="7.572" y="1.5"/>
<vertex x="7.572" y="1.66"/>
<vertex x="7.362" y="1.66"/>
<vertex x="7.362" y="1.9"/>
<vertex x="7.892" y="1.9"/>
<vertex x="7.892" y="1.03"/>
<vertex x="7.642" y="1.03"/>
<vertex x="7.642" y="1.18"/>
<vertex x="7.552" y="1.08"/>
<vertex x="7.432" y="1.01"/>
<vertex x="7.302" y="1"/>
<vertex x="7.172" y="1.01"/>
<vertex x="7.062" y="1.05"/>
<vertex x="6.962" y="1.13"/>
<vertex x="6.902" y="1.24"/>
<vertex x="6.862" y="1.36"/>
<vertex x="6.842" y="1.48"/>
<vertex x="6.822" y="1.61"/>
<vertex x="6.822" y="1.98"/>
<vertex x="6.832" y="2.11"/>
<vertex x="6.852" y="2.23"/>
<vertex x="6.882" y="2.36"/>
<vertex x="6.932" y="2.47"/>
<vertex x="7.012" y="2.57"/>
<vertex x="7.122" y="2.64"/>
<vertex x="7.242" y="2.67"/>
<vertex x="7.362" y="2.68"/>
<vertex x="7.502" y="2.67"/>
<vertex x="7.632" y="2.63"/>
<vertex x="7.742" y="2.55"/>
<vertex x="7.822" y="2.44"/>
<vertex x="7.862" y="2.31"/>
<vertex x="7.872" y="2.17"/>
</polygon>
<vertex x="8.302" y="2.65"/>
<vertex x="8.912" y="2.65"/>
<vertex x="9.042" y="2.64"/>
<vertex x="9.172" y="2.59"/>
<vertex x="9.272" y="2.49"/>
<vertex x="9.322" y="2.37"/>
<vertex x="9.342" y="2.23"/>
<vertex x="9.332" y="2.1"/>
<vertex x="9.282" y="1.98"/>
<vertex x="9.192" y="1.88"/>
<vertex x="9.072" y="1.83"/>
<vertex x="9.192" y="1.79"/>
<vertex x="9.282" y="1.71"/>
<vertex x="9.312" y="1.59"/>
<vertex x="9.332" y="1.33"/>
<vertex x="9.332" y="1.23"/>
<vertex x="9.352" y="1.13"/>
<vertex x="9.402" y="1.04"/>
<vertex x="9.402" y="1.03"/>
<vertex x="9.052" y="1.03"/>
<vertex x="9.012" y="1.11"/>
<vertex x="9.012" y="1.2"/>
<vertex x="9.002" y="1.3"/>
<vertex x="9.002" y="1.51"/>
<vertex x="8.982" y="1.61"/>
<vertex x="8.912" y="1.69"/>
<vertex x="8.802" y="1.72"/>
<vertex x="8.632" y="1.72"/>
<vertex x="8.632" y="1.03"/>
<vertex x="8.302" y="1.03"/>
<vertex x="8.632" y="2.41"/>
<vertex x="8.632" y="1.94"/>
<vertex x="8.772" y="1.94"/>
<vertex x="8.902" y="1.96"/>
<vertex x="8.992" y="2.06"/>
<vertex x="9.012" y="2.19"/>
<vertex x="8.992" y="2.3"/>
<vertex x="8.902" y="2.39"/>
<vertex x="8.782" y="2.41"/>
</polygon>
<vertex x="10.182" y="1.64"/>
<vertex x="10.502" y="1.64"/>
<vertex x="10.562" y="1.37"/>
<vertex x="10.132" y="1.37"/>
<vertex x="10.052" y="1.03"/>
<vertex x="9.712" y="1.03"/>
<vertex x="10.142" y="2.65"/>
<vertex x="10.552" y="2.65"/>
<vertex x="10.972" y="1.03"/>
<vertex x="10.632" y="1.03"/>
<vertex x="10.342" y="2.37"/>
</polygon>
<vertex x="11.322" y="2.65"/>
<vertex x="11.812" y="2.65"/>
<vertex x="12.042" y="1.51"/>
<vertex x="12.282" y="2.65"/>
<vertex x="12.762" y="2.65"/>
<vertex x="12.762" y="1.03"/>
<vertex x="12.462" y="1.03"/>
<vertex x="12.462" y="2.32"/>
<vertex x="12.172" y="1.03"/>
<vertex x="11.912" y="1.03"/>
<vertex x="11.622" y="2.32"/>
<vertex x="11.622" y="1.03"/>
<vertex x="11.322" y="1.03"/>
</polygon>
<vertex x="13.202" y="2.65"/>
<vertex x="13.682" y="2.65"/>
<vertex x="13.922" y="1.51"/>
<vertex x="14.152" y="2.65"/>
<vertex x="14.642" y="2.65"/>
<vertex x="14.642" y="1.03"/>
<vertex x="14.342" y="1.03"/>
<vertex x="14.342" y="2.32"/>
<vertex x="14.332" y="2.32"/>
<vertex x="14.052" y="1.03"/>
<vertex x="13.792" y="1.03"/>
<vertex x="13.502" y="2.32"/>
<vertex x="13.502" y="1.03"/>
<vertex x="13.202" y="1.03"/>
</polygon>
<vertex x="15.982" y="2.65"/>
<vertex x="15.982" y="2.38"/>
<vertex x="15.402" y="2.38"/>
<vertex x="15.402" y="2"/>
<vertex x="15.952" y="2"/>
<vertex x="15.952" y="1.73"/>
<vertex x="15.402" y="1.73"/>
<vertex x="15.402" y="1.3"/>
<vertex x="16.002" y="1.3"/>
<vertex x="16.002" y="1.03"/>
<vertex x="15.072" y="1.03"/>
<vertex x="15.072" y="2.65"/>
</polygon>
<vertex x="17.052" y="2.64"/>
<vertex x="17.182" y="2.6"/>
<vertex x="17.292" y="2.52"/>
<vertex x="17.372" y="2.4"/>
<vertex x="17.412" y="2.27"/>
<vertex x="17.442" y="2.14"/>
<vertex x="17.452" y="2"/>
<vertex x="17.452" y="1.73"/>
<vertex x="17.442" y="1.61"/>
<vertex x="17.422" y="1.48"/>
<vertex x="17.392" y="1.35"/>
<vertex x="17.342" y="1.24"/>
<vertex x="17.262" y="1.14"/>
<vertex x="17.152" y="1.07"/>
<vertex x="17.022" y="1.04"/>
<vertex x="16.892" y="1.03"/>
<vertex x="16.382" y="1.03"/>
<vertex x="16.382" y="2.65"/>
<vertex x="16.912" y="2.65"/>
<vertex x="16.882" y="2.53"/>
<vertex x="16.842" y="2.41"/>
<vertex x="16.702" y="2.41"/>
<vertex x="16.702" y="1.27"/>
<vertex x="16.852" y="1.27"/>
<vertex x="16.972" y="1.29"/>
<vertex x="17.062" y="1.37"/>
<vertex x="17.102" y="1.49"/>
<vertex x="17.122" y="1.61"/>
<vertex x="17.122" y="1.97"/>
<vertex x="17.102" y="2.21"/>
<vertex x="17.052" y="2.32"/>
<vertex x="16.962" y="2.39"/>
</polygon>
<vertex x="18.532" y="2.65"/>
<vertex x="18.842" y="2.65"/>
<vertex x="19.022" y="1.45"/>
<vertex x="19.212" y="2.65"/>
<vertex x="19.532" y="2.65"/>
<vertex x="19.722" y="1.45"/>
<vertex x="19.902" y="2.65"/>
<vertex x="20.222" y="2.65"/>
<vertex x="19.922" y="1.03"/>
<vertex x="19.552" y="1.03"/>
<vertex x="19.372" y="2.21"/>
<vertex x="19.192" y="1.03"/>
<vertex x="18.822" y="1.03"/>
</polygon>
<vertex x="20.582" y="1.03"/>
<vertex x="20.582" y="2.65"/>
<vertex x="20.902" y="2.65"/>
<vertex x="20.902" y="1.03"/>
</polygon>
<vertex x="22.302" y="2.65"/>
<vertex x="22.302" y="2.38"/>
<vertex x="21.952" y="2.38"/>
<vertex x="21.952" y="1.03"/>
<vertex x="21.622" y="1.03"/>
<vertex x="21.622" y="2.38"/>
<vertex x="21.262" y="2.38"/>
<vertex x="21.262" y="2.65"/>
</polygon>
<vertex x="22.652" y="2.65"/>
<vertex x="22.982" y="2.65"/>
<vertex x="22.982" y="2.03"/>
<vertex x="23.362" y="2.03"/>
<vertex x="23.362" y="2.65"/>
<vertex x="23.692" y="2.65"/>
<vertex x="23.692" y="1.03"/>
<vertex x="23.362" y="1.03"/>
<vertex x="23.362" y="1.75"/>
<vertex x="22.982" y="1.75"/>
<vertex x="22.982" y="1.03"/>
<vertex x="22.652" y="1.03"/>
</polygon>
<vertex x="25.232" y="1.64"/>
<vertex x="25.552" y="1.64"/>
<vertex x="25.612" y="1.37"/>
<vertex x="25.172" y="1.37"/>
<vertex x="25.102" y="1.03"/>
<vertex x="24.762" y="1.03"/>
<vertex x="25.192" y="2.65"/>
<vertex x="25.592" y="2.65"/>
<vertex x="26.022" y="1.03"/>
<vertex x="25.682" y="1.03"/>
<vertex x="25.392" y="2.37"/>
</polygon>
<vertex x="26.362" y="2.65"/>
<vertex x="26.972" y="2.65"/>
<vertex x="27.102" y="2.64"/>
<vertex x="27.232" y="2.59"/>
<vertex x="27.332" y="2.49"/>
<vertex x="27.382" y="2.37"/>
<vertex x="27.402" y="2.23"/>
<vertex x="27.392" y="2.1"/>
<vertex x="27.342" y="1.98"/>
<vertex x="27.252" y="1.88"/>
<vertex x="27.132" y="1.83"/>
<vertex x="27.252" y="1.79"/>
<vertex x="27.342" y="1.71"/>
<vertex x="27.372" y="1.59"/>
<vertex x="27.392" y="1.46"/>
<vertex x="27.392" y="1.23"/>
<vertex x="27.412" y="1.13"/>
<vertex x="27.462" y="1.04"/>
<vertex x="27.462" y="1.03"/>
<vertex x="27.112" y="1.03"/>
<vertex x="27.072" y="1.11"/>
<vertex x="27.072" y="1.2"/>
<vertex x="27.062" y="1.3"/>
<vertex x="27.062" y="1.51"/>
<vertex x="27.042" y="1.61"/>
<vertex x="26.972" y="1.69"/>
<vertex x="26.862" y="1.72"/>
<vertex x="26.692" y="1.72"/>
<vertex x="26.692" y="1.03"/>
<vertex x="26.362" y="1.03"/>
<vertex x="26.692" y="2.41"/>
<vertex x="26.692" y="1.94"/>
<vertex x="26.832" y="1.94"/>
<vertex x="26.962" y="1.96"/>
<vertex x="27.052" y="2.06"/>
<vertex x="27.072" y="2.19"/>
<vertex x="27.052" y="2.3"/>
<vertex x="26.962" y="2.39"/>
<vertex x="26.842" y="2.41"/>
</polygon>
<vertex x="28.512" y="2.64"/>
<vertex x="28.642" y="2.6"/>
<vertex x="28.752" y="2.52"/>
<vertex x="28.832" y="2.4"/>
<vertex x="28.872" y="2.27"/>
<vertex x="28.902" y="2.14"/>
<vertex x="28.912" y="2"/>
<vertex x="28.912" y="1.73"/>
<vertex x="28.902" y="1.61"/>
<vertex x="28.882" y="1.48"/>
<vertex x="28.852" y="1.35"/>
<vertex x="28.802" y="1.24"/>
<vertex x="28.712" y="1.14"/>
<vertex x="28.602" y="1.07"/>
<vertex x="28.482" y="1.04"/>
<vertex x="28.352" y="1.03"/>
<vertex x="27.842" y="1.03"/>
<vertex x="27.842" y="2.65"/>
<vertex x="28.372" y="2.65"/>
<vertex x="28.342" y="2.53"/>
<vertex x="28.302" y="2.41"/>
<vertex x="28.162" y="2.41"/>
<vertex x="28.162" y="1.27"/>
<vertex x="28.312" y="1.27"/>
<vertex x="28.432" y="1.29"/>
<vertex x="28.522" y="1.37"/>
<vertex x="28.562" y="1.49"/>
<vertex x="28.582" y="1.73"/>
<vertex x="28.582" y="1.97"/>
<vertex x="28.562" y="2.21"/>
<vertex x="28.512" y="2.32"/>
<vertex x="28.422" y="2.39"/>
</polygon>
<vertex x="29.632" y="2.65"/>
<vertex x="29.632" y="1.52"/>
<vertex x="29.642" y="1.39"/>
<vertex x="29.702" y="1.28"/>
<vertex x="29.822" y="1.24"/>
<vertex x="29.942" y="1.28"/>
<vertex x="30.002" y="1.39"/>
<vertex x="30.012" y="1.52"/>
<vertex x="30.012" y="2.65"/>
<vertex x="30.342" y="2.65"/>
<vertex x="30.342" y="1.52"/>
<vertex x="30.332" y="1.4"/>
<vertex x="30.302" y="1.28"/>
<vertex x="30.252" y="1.18"/>
<vertex x="30.162" y="1.09"/>
<vertex x="30.062" y="1.04"/>
<vertex x="29.942" y="1.01"/>
<vertex x="29.822" y="1"/>
<vertex x="29.702" y="1"/>
<vertex x="29.582" y="1.03"/>
<vertex x="29.472" y="1.09"/>
<vertex x="29.392" y="1.17"/>
<vertex x="29.342" y="1.28"/>
<vertex x="29.312" y="1.4"/>
<vertex x="29.302" y="1.52"/>
<vertex x="29.302" y="2.65"/>
</polygon>
<vertex x="30.772" y="1.03"/>
<vertex x="30.772" y="2.65"/>
<vertex x="31.092" y="2.65"/>
<vertex x="31.092" y="1.03"/>
</polygon>
<vertex x="31.912" y="2.65"/>
<vertex x="32.302" y="1.54"/>
<vertex x="32.312" y="1.54"/>
<vertex x="32.312" y="2.65"/>
<vertex x="32.612" y="2.65"/>
<vertex x="32.612" y="1.03"/>
<vertex x="32.232" y="1.03"/>
<vertex x="31.832" y="2.16"/>
<vertex x="31.832" y="1.03"/>
<vertex x="31.532" y="1.03"/>
<vertex x="31.532" y="2.65"/>
</polygon>
<vertex x="33.682" y="2.67"/>
<vertex x="33.812" y="2.64"/>
<vertex x="33.922" y="2.57"/>
<vertex x="34.002" y="2.47"/>
<vertex x="34.052" y="2.35"/>
<vertex x="34.082" y="2.23"/>
<vertex x="34.102" y="2.1"/>
<vertex x="34.112" y="1.97"/>
<vertex x="34.112" y="1.71"/>
<vertex x="34.102" y="1.58"/>
<vertex x="34.082" y="1.45"/>
<vertex x="34.052" y="1.33"/>
<vertex x="34.002" y="1.21"/>
<vertex x="33.922" y="1.11"/>
<vertex x="33.812" y="1.04"/>
<vertex x="33.682" y="1.01"/>
<vertex x="33.562" y="1"/>
<vertex x="33.432" y="1.01"/>
<vertex x="33.302" y="1.04"/>
<vertex x="33.192" y="1.11"/>
<vertex x="33.112" y="1.21"/>
<vertex x="33.062" y="1.33"/>
<vertex x="33.032" y="1.45"/>
<vertex x="33.012" y="1.58"/>
<vertex x="33.012" y="1.71"/>
<vertex x="33.002" y="1.84"/>
<vertex x="33.012" y="1.97"/>
<vertex x="33.012" y="2.1"/>
<vertex x="33.032" y="2.23"/>
<vertex x="33.062" y="2.35"/>
<vertex x="33.112" y="2.47"/>
<vertex x="33.192" y="2.57"/>
<vertex x="33.302" y="2.64"/>
<vertex x="33.432" y="2.67"/>
<vertex x="33.562" y="2.68"/>
<vertex x="33.562" y="2.44"/>
<vertex x="33.442" y="2.41"/>
<vertex x="33.372" y="2.31"/>
<vertex x="33.352" y="2.2"/>
<vertex x="33.332" y="1.96"/>
<vertex x="33.332" y="1.72"/>
<vertex x="33.352" y="1.48"/>
<vertex x="33.372" y="1.37"/>
<vertex x="33.442" y="1.27"/>
<vertex x="33.562" y="1.24"/>
<vertex x="33.672" y="1.27"/>
<vertex x="33.742" y="1.37"/>
<vertex x="33.762" y="1.48"/>
<vertex x="33.782" y="1.72"/>
<vertex x="33.782" y="1.96"/>
<vertex x="33.762" y="2.2"/>
<vertex x="33.742" y="2.31"/>
<vertex x="33.672" y="2.41"/>
</polygon>
<polygon width="0.033" layer="94">
<vertex x="21.802" y="6.74"/>
<vertex x="21.782" y="6.61"/>
<vertex x="21.752" y="6.48"/>
<vertex x="21.702" y="6.37"/>
<vertex x="21.622" y="6.26"/>
<vertex x="21.522" y="6.18"/>
<vertex x="21.412" y="6.12"/>
<vertex x="21.292" y="6.07"/>
<vertex x="21.162" y="6.05"/>
<vertex x="20.902" y="6.03"/>
<vertex x="20.512" y="6.03"/>
<vertex x="20.512" y="7.7"/>
<vertex x="20.952" y="7.7"/>
<vertex x="21.092" y="7.69"/>
<vertex x="21.232" y="7.67"/>
<vertex x="21.362" y="7.64"/>
<vertex x="21.482" y="7.58"/>
<vertex x="21.592" y="7.5"/>
<vertex x="21.682" y="7.4"/>
<vertex x="21.742" y="7.27"/>
<vertex x="21.782" y="7.14"/>
<vertex x="21.802" y="7.01"/>
<vertex x="21.812" y="6.87"/>
<vertex x="21.992" y="6.86"/>
<vertex x="23.292" y="6.83"/>
<vertex x="23.292" y="6.96"/>
<vertex x="23.252" y="7.22"/>
<vertex x="23.192" y="7.48"/>
<vertex x="23.142" y="7.6"/>
<vertex x="23.072" y="7.72"/>
<vertex x="23.002" y="7.83"/>
<vertex x="22.922" y="7.93"/>
<vertex x="22.822" y="8.03"/>
<vertex x="22.722" y="8.11"/>
<vertex x="22.612" y="8.18"/>
<vertex x="22.492" y="8.24"/>
<vertex x="22.372" y="8.29"/>
<vertex x="22.482" y="8.35"/>
<vertex x="22.592" y="8.43"/>
<vertex x="22.692" y="8.52"/>
<vertex x="22.782" y="8.62"/>
<vertex x="22.862" y="8.73"/>
<vertex x="22.932" y="8.84"/>
<vertex x="22.982" y="8.97"/>
<vertex x="23.032" y="9.09"/>
<vertex x="23.062" y="9.22"/>
<vertex x="23.082" y="9.36"/>
<vertex x="23.102" y="9.49"/>
<vertex x="23.102" y="9.62"/>
<vertex x="22.972" y="9.61"/>
<vertex x="22.842" y="9.59"/>
<vertex x="22.582" y="9.57"/>
<vertex x="22.452" y="9.55"/>
<vertex x="22.322" y="9.54"/>
<vertex x="22.192" y="9.52"/>
<vertex x="21.932" y="9.5"/>
<vertex x="21.802" y="9.48"/>
<vertex x="21.672" y="9.47"/>
<vertex x="21.662" y="9.33"/>
<vertex x="21.642" y="9.2"/>
<vertex x="21.592" y="9.08"/>
<vertex x="21.522" y="8.97"/>
<vertex x="21.422" y="8.88"/>
<vertex x="21.302" y="8.82"/>
<vertex x="21.042" y="8.76"/>
<vertex x="20.902" y="8.75"/>
<vertex x="20.512" y="8.75"/>
<vertex x="20.512" y="10.17"/>
<vertex x="20.992" y="10.17"/>
<vertex x="21.112" y="10.16"/>
<vertex x="21.242" y="10.14"/>
<vertex x="21.362" y="10.1"/>
<vertex x="21.462" y="10.03"/>
<vertex x="21.552" y="9.94"/>
<vertex x="21.612" y="9.83"/>
<vertex x="21.652" y="9.72"/>
<vertex x="21.662" y="9.59"/>
<vertex x="21.932" y="9.49"/>
<vertex x="22.062" y="9.51"/>
<vertex x="23.102" y="9.76"/>
<vertex x="23.092" y="9.89"/>
<vertex x="23.072" y="10.03"/>
<vertex x="23.042" y="10.16"/>
<vertex x="23.002" y="10.29"/>
<vertex x="22.952" y="10.42"/>
<vertex x="22.892" y="10.54"/>
<vertex x="22.822" y="10.65"/>
<vertex x="22.742" y="10.76"/>
<vertex x="22.652" y="10.85"/>
<vertex x="22.542" y="10.94"/>
<vertex x="22.432" y="11.01"/>
<vertex x="22.312" y="11.08"/>
<vertex x="22.182" y="11.13"/>
<vertex x="22.062" y="11.17"/>
<vertex x="21.932" y="11.21"/>
<vertex x="21.792" y="11.24"/>
<vertex x="21.662" y="11.26"/>
<vertex x="21.522" y="11.27"/>
<vertex x="21.392" y="11.28"/>
<vertex x="19.172" y="11.28"/>
<vertex x="19.112" y="11.25"/>
<vertex x="19.082" y="11.18"/>
<vertex x="19.082" y="5.02"/>
<vertex x="19.112" y="4.95"/>
<vertex x="19.172" y="4.93"/>
<vertex x="21.412" y="4.93"/>
<vertex x="21.552" y="4.94"/>
<vertex x="21.682" y="4.95"/>
<vertex x="21.822" y="4.97"/>
<vertex x="21.952" y="5"/>
<vertex x="22.092" y="5.03"/>
<vertex x="22.222" y="5.08"/>
<vertex x="22.342" y="5.13"/>
<vertex x="22.462" y="5.19"/>
<vertex x="22.582" y="5.27"/>
<vertex x="22.692" y="5.35"/>
<vertex x="22.792" y="5.44"/>
<vertex x="22.892" y="5.54"/>
<vertex x="22.972" y="5.65"/>
<vertex x="23.042" y="5.77"/>
<vertex x="23.102" y="5.89"/>
<vertex x="23.162" y="6.02"/>
<vertex x="23.202" y="6.15"/>
<vertex x="23.262" y="6.41"/>
<vertex x="23.282" y="6.55"/>
<vertex x="23.292" y="6.69"/>
<vertex x="23.112" y="6.83"/>
</polygon>
<vertex x="25.992" y="7.34"/>
<vertex x="25.992" y="7.07"/>
<vertex x="25.982" y="6.93"/>
<vertex x="25.982" y="6.79"/>
<vertex x="25.972" y="6.65"/>
<vertex x="25.952" y="6.52"/>
<vertex x="25.932" y="6.38"/>
<vertex x="25.902" y="6.25"/>
<vertex x="25.862" y="6.11"/>
<vertex x="25.802" y="5.99"/>
<vertex x="25.712" y="5.89"/>
<vertex x="25.592" y="5.82"/>
<vertex x="25.452" y="5.81"/>
<vertex x="25.322" y="5.82"/>
<vertex x="25.202" y="5.87"/>
<vertex x="25.112" y="5.96"/>
<vertex x="25.052" y="6.07"/>
<vertex x="25.002" y="6.19"/>
<vertex x="24.972" y="6.32"/>
<vertex x="24.952" y="6.44"/>
<vertex x="24.932" y="6.57"/>
<vertex x="24.912" y="6.83"/>
<vertex x="24.912" y="7.21"/>
<vertex x="24.902" y="7.34"/>
<vertex x="24.912" y="7.47"/>
<vertex x="24.912" y="7.86"/>
<vertex x="24.922" y="7.99"/>
<vertex x="24.932" y="8.11"/>
<vertex x="24.972" y="8.37"/>
<vertex x="25.002" y="8.49"/>
<vertex x="25.052" y="8.62"/>
<vertex x="25.112" y="8.73"/>
<vertex x="25.202" y="8.81"/>
<vertex x="25.322" y="8.87"/>
<vertex x="25.452" y="8.88"/>
<vertex x="25.592" y="8.86"/>
<vertex x="25.712" y="8.8"/>
<vertex x="25.802" y="8.7"/>
<vertex x="25.862" y="8.57"/>
<vertex x="25.902" y="8.44"/>
<vertex x="25.932" y="8.31"/>
<vertex x="25.972" y="8.03"/>
<vertex x="25.982" y="7.9"/>
<vertex x="25.982" y="7.76"/>
<vertex x="25.992" y="7.62"/>
<vertex x="27.372" y="7.34"/>
<vertex x="27.372" y="7.61"/>
<vertex x="27.362" y="7.75"/>
<vertex x="27.362" y="7.88"/>
<vertex x="27.352" y="8.01"/>
<vertex x="27.332" y="8.15"/>
<vertex x="27.292" y="8.41"/>
<vertex x="27.262" y="8.55"/>
<vertex x="27.232" y="8.68"/>
<vertex x="27.192" y="8.8"/>
<vertex x="27.142" y="8.93"/>
<vertex x="27.092" y="9.05"/>
<vertex x="27.022" y="9.17"/>
<vertex x="26.942" y="9.28"/>
<vertex x="26.862" y="9.38"/>
<vertex x="26.762" y="9.48"/>
<vertex x="26.662" y="9.56"/>
<vertex x="26.552" y="9.64"/>
<vertex x="26.432" y="9.7"/>
<vertex x="26.312" y="9.75"/>
<vertex x="26.182" y="9.8"/>
<vertex x="26.052" y="9.83"/>
<vertex x="25.912" y="9.85"/>
<vertex x="25.782" y="9.87"/>
<vertex x="25.652" y="9.88"/>
<vertex x="25.312" y="9.88"/>
<vertex x="25.182" y="9.87"/>
<vertex x="25.042" y="9.85"/>
<vertex x="24.912" y="9.83"/>
<vertex x="24.782" y="9.8"/>
<vertex x="24.652" y="9.76"/>
<vertex x="24.522" y="9.7"/>
<vertex x="24.402" y="9.64"/>
<vertex x="24.292" y="9.57"/>
<vertex x="24.182" y="9.48"/>
<vertex x="24.092" y="9.39"/>
<vertex x="24.002" y="9.28"/>
<vertex x="23.922" y="9.17"/>
<vertex x="23.852" y="9.06"/>
<vertex x="23.792" y="8.94"/>
<vertex x="23.692" y="8.68"/>
<vertex x="23.662" y="8.55"/>
<vertex x="23.622" y="8.42"/>
<vertex x="23.602" y="8.29"/>
<vertex x="23.582" y="8.15"/>
<vertex x="23.562" y="8.02"/>
<vertex x="23.552" y="7.88"/>
<vertex x="23.542" y="7.75"/>
<vertex x="23.532" y="7.61"/>
<vertex x="23.532" y="7.48"/>
<vertex x="23.522" y="7.34"/>
<vertex x="23.532" y="7.21"/>
<vertex x="23.532" y="6.94"/>
<vertex x="23.542" y="6.81"/>
<vertex x="23.552" y="6.67"/>
<vertex x="23.572" y="6.54"/>
<vertex x="23.582" y="6.4"/>
<vertex x="23.612" y="6.27"/>
<vertex x="23.632" y="6.14"/>
<vertex x="23.712" y="5.88"/>
<vertex x="23.762" y="5.76"/>
<vertex x="23.812" y="5.63"/>
<vertex x="23.952" y="5.41"/>
<vertex x="24.042" y="5.3"/>
<vertex x="24.132" y="5.21"/>
<vertex x="24.242" y="5.12"/>
<vertex x="24.352" y="5.05"/>
<vertex x="24.472" y="4.98"/>
<vertex x="24.592" y="4.93"/>
<vertex x="24.722" y="4.89"/>
<vertex x="24.982" y="4.83"/>
<vertex x="25.122" y="4.82"/>
<vertex x="25.252" y="4.81"/>
<vertex x="25.582" y="4.81"/>
<vertex x="25.722" y="4.82"/>
<vertex x="25.852" y="4.83"/>
<vertex x="25.992" y="4.86"/>
<vertex x="26.122" y="4.89"/>
<vertex x="26.252" y="4.93"/>
<vertex x="26.372" y="4.98"/>
<vertex x="26.612" y="5.12"/>
<vertex x="26.712" y="5.2"/>
<vertex x="26.812" y="5.3"/>
<vertex x="26.902" y="5.4"/>
<vertex x="26.982" y="5.51"/>
<vertex x="27.052" y="5.63"/>
<vertex x="27.112" y="5.75"/>
<vertex x="27.162" y="5.88"/>
<vertex x="27.202" y="6"/>
<vertex x="27.242" y="6.13"/>
<vertex x="27.272" y="6.27"/>
<vertex x="27.302" y="6.4"/>
<vertex x="27.322" y="6.53"/>
<vertex x="27.342" y="6.67"/>
<vertex x="27.352" y="6.8"/>
<vertex x="27.362" y="6.94"/>
<vertex x="27.372" y="7.07"/>
</polygon>
<vertex x="30.152" y="8.8"/>
<vertex x="30.152" y="9.88"/>
<vertex x="29.442" y="9.88"/>
<vertex x="29.442" y="11.24"/>
<vertex x="27.972" y="11.24"/>
<vertex x="27.972" y="9.88"/>
<vertex x="27.362" y="9.88"/>
<vertex x="27.362" y="8.8"/>
<vertex x="27.972" y="8.8"/>
<vertex x="27.972" y="6.21"/>
<vertex x="27.982" y="6.07"/>
<vertex x="27.982" y="5.93"/>
<vertex x="27.992" y="5.79"/>
<vertex x="28.012" y="5.66"/>
<vertex x="28.032" y="5.52"/>
<vertex x="28.072" y="5.39"/>
<vertex x="28.132" y="5.26"/>
<vertex x="28.212" y="5.15"/>
<vertex x="28.312" y="5.05"/>
<vertex x="28.422" y="4.98"/>
<vertex x="28.552" y="4.92"/>
<vertex x="28.682" y="4.88"/>
<vertex x="28.822" y="4.86"/>
<vertex x="28.952" y="4.84"/>
<vertex x="29.092" y="4.83"/>
<vertex x="29.352" y="4.83"/>
<vertex x="29.472" y="4.84"/>
<vertex x="29.592" y="4.84"/>
<vertex x="29.832" y="4.86"/>
<vertex x="29.952" y="4.88"/>
<vertex x="30.052" y="4.89"/>
<vertex x="30.152" y="4.89"/>
<vertex x="30.152" y="6"/>
<vertex x="30.012" y="5.98"/>
<vertex x="29.752" y="5.96"/>
<vertex x="29.632" y="5.97"/>
<vertex x="29.522" y="6.01"/>
<vertex x="29.462" y="6.12"/>
<vertex x="29.442" y="6.36"/>
<vertex x="29.442" y="8.8"/>
</polygon>
<wire x1="7.942" y1="10.27" x2="8.482" y2="10.27" width="0.262" layer="94"/>
<wire x1="8.482" y1="10.27" x2="8.612" y2="10.26" width="0.262" layer="94"/>
<wire x1="8.612" y1="10.26" x2="8.752" y2="10.24" width="0.262" layer="94"/>
<wire x1="8.752" y1="10.24" x2="8.882" y2="10.2" width="0.262" layer="94"/>
<wire x1="8.882" y1="10.2" x2="9.002" y2="10.14" width="0.262" layer="94"/>
<wire x1="9.002" y1="10.14" x2="9.112" y2="10.06" width="0.262" layer="94"/>
<wire x1="9.112" y1="10.06" x2="9.192" y2="9.95" width="0.262" layer="94"/>
<wire x1="9.192" y1="9.95" x2="9.252" y2="9.83" width="0.262" layer="94"/>
<wire x1="9.252" y1="9.83" x2="9.292" y2="9.7" width="0.262" layer="94"/>
<wire x1="9.292" y1="9.7" x2="9.322" y2="9.57" width="0.262" layer="94"/>
<wire x1="9.322" y1="9.57" x2="9.322" y2="9.26" width="0.262" layer="94"/>
<wire x1="9.322" y1="9.26" x2="9.302" y2="9.13" width="0.262" layer="94"/>
<wire x1="9.302" y1="9.13" x2="9.272" y2="9" width="0.262" layer="94"/>
<wire x1="9.272" y1="9" x2="9.212" y2="8.88" width="0.262" layer="94"/>
<wire x1="9.212" y1="8.88" x2="9.142" y2="8.77" width="0.262" layer="94"/>
<wire x1="9.142" y1="8.77" x2="9.052" y2="8.68" width="0.262" layer="94"/>
<wire x1="9.052" y1="8.68" x2="8.942" y2="8.6" width="0.262" layer="94"/>
<wire x1="8.942" y1="8.6" x2="8.822" y2="8.55" width="0.262" layer="94"/>
<wire x1="8.822" y1="8.55" x2="8.692" y2="8.52" width="0.262" layer="94"/>
<wire x1="8.692" y1="8.52" x2="8.562" y2="8.5" width="0.262" layer="94"/>
<wire x1="8.562" y1="8.5" x2="8.432" y2="8.49" width="0.262" layer="94"/>
<wire x1="8.432" y1="8.49" x2="7.982" y2="8.49" width="0.262" layer="94"/>
<wire x1="7.982" y1="8.49" x2="7.892" y2="8.52" width="0.262" layer="94"/>
<wire x1="7.892" y1="8.52" x2="7.872" y2="8.58" width="0.262" layer="94"/>
<wire x1="7.872" y1="8.58" x2="7.872" y2="10.13" width="0.262" layer="94"/>
<wire x1="7.872" y1="10.13" x2="7.892" y2="10.21" width="0.262" layer="94"/>
<wire x1="7.892" y1="10.21" x2="7.942" y2="10.27" width="0.262" layer="94"/>
<wire x1="12.962" y1="8.96" x2="13.092" y2="8.92" width="0.262" layer="94"/>
<wire x1="13.092" y1="8.92" x2="13.202" y2="8.85" width="0.262" layer="94"/>
<wire x1="13.202" y1="8.85" x2="13.282" y2="8.74" width="0.262" layer="94"/>
<wire x1="13.282" y1="8.74" x2="13.332" y2="8.62" width="0.262" layer="94"/>
<wire x1="13.332" y1="8.62" x2="13.372" y2="8.49" width="0.262" layer="94"/>
<wire x1="13.372" y1="8.49" x2="13.412" y2="8.23" width="0.262" layer="94"/>
<wire x1="13.412" y1="8.23" x2="13.422" y2="8.09" width="0.262" layer="94"/>
<wire x1="13.422" y1="8.09" x2="13.432" y2="7.96" width="0.262" layer="94"/>
<wire x1="13.432" y1="7.96" x2="13.422" y2="7.9" width="0.262" layer="94"/>
<wire x1="13.422" y1="7.9" x2="13.402" y2="7.89" width="0.262" layer="94"/>
<wire x1="13.402" y1="7.89" x2="13.322" y2="7.87" width="0.262" layer="94"/>
<wire x1="13.322" y1="7.87" x2="12.322" y2="7.87" width="0.262" layer="94"/>
<wire x1="12.322" y1="7.87" x2="12.232" y2="7.9" width="0.262" layer="94"/>
<wire x1="12.232" y1="7.9" x2="12.222" y2="7.96" width="0.262" layer="94"/>
<wire x1="12.222" y1="7.96" x2="12.222" y2="8.11" width="0.262" layer="94"/>
<wire x1="12.222" y1="8.11" x2="12.242" y2="8.37" width="0.262" layer="94"/>
<wire x1="12.242" y1="8.37" x2="12.272" y2="8.5" width="0.262" layer="94"/>
<wire x1="12.272" y1="8.5" x2="12.322" y2="8.62" width="0.262" layer="94"/>
<wire x1="12.322" y1="8.62" x2="12.382" y2="8.74" width="0.262" layer="94"/>
<wire x1="12.382" y1="8.74" x2="12.472" y2="8.84" width="0.262" layer="94"/>
<wire x1="12.472" y1="8.84" x2="12.582" y2="8.92" width="0.262" layer="94"/>
<wire x1="12.582" y1="8.92" x2="12.702" y2="8.96" width="0.262" layer="94"/>
<wire x1="12.702" y1="8.96" x2="12.832" y2="8.97" width="0.262" layer="94"/>
<wire x1="12.832" y1="8.97" x2="12.962" y2="8.96" width="0.262" layer="94"/>
<wire x1="13.442" y1="6.5" x2="13.402" y2="6.41" width="0.262" layer="94"/>
<wire x1="13.402" y1="6.41" x2="13.382" y2="6.28" width="0.262" layer="94"/>
<wire x1="13.382" y1="6.28" x2="13.302" y2="6.04" width="0.262" layer="94"/>
<wire x1="13.302" y1="6.04" x2="13.232" y2="5.93" width="0.262" layer="94"/>
<wire x1="13.232" y1="5.93" x2="13.152" y2="5.84" width="0.262" layer="94"/>
<wire x1="13.152" y1="5.84" x2="13.042" y2="5.77" width="0.262" layer="94"/>
<wire x1="13.042" y1="5.77" x2="12.912" y2="5.74" width="0.262" layer="94"/>
<wire x1="12.912" y1="5.74" x2="12.792" y2="5.73" width="0.262" layer="94"/>
<wire x1="12.792" y1="5.73" x2="12.662" y2="5.75" width="0.262" layer="94"/>
<wire x1="12.662" y1="5.75" x2="12.552" y2="5.8" width="0.262" layer="94"/>
<wire x1="12.552" y1="5.8" x2="12.452" y2="5.87" width="0.262" layer="94"/>
<wire x1="12.452" y1="5.87" x2="12.382" y2="5.98" width="0.262" layer="94"/>
<wire x1="12.382" y1="5.98" x2="12.332" y2="6.09" width="0.262" layer="94"/>
<wire x1="12.332" y1="6.09" x2="12.292" y2="6.2" width="0.262" layer="94"/>
<wire x1="12.292" y1="6.2" x2="12.262" y2="6.33" width="0.262" layer="94"/>
<wire x1="12.262" y1="6.33" x2="12.242" y2="6.45" width="0.262" layer="94"/>
<wire x1="12.242" y1="6.45" x2="12.232" y2="6.57" width="0.262" layer="94"/>
<wire x1="12.232" y1="6.57" x2="12.222" y2="6.7" width="0.262" layer="94"/>
<wire x1="12.222" y1="6.7" x2="12.222" y2="7.02" width="0.262" layer="94"/>
<wire x1="12.222" y1="7.02" x2="12.232" y2="7.1" width="0.262" layer="94"/>
<wire x1="12.232" y1="7.1" x2="12.282" y2="7.16" width="0.262" layer="94"/>
<wire x1="12.282" y1="7.16" x2="14.382" y2="7.16" width="0.262" layer="94"/>
<wire x1="14.382" y1="7.16" x2="14.462" y2="7.18" width="0.262" layer="94"/>
<wire x1="14.462" y1="7.18" x2="14.532" y2="7.23" width="0.262" layer="94"/>
<wire x1="14.532" y1="7.23" x2="14.572" y2="7.27" width="0.262" layer="94"/>
<wire x1="14.572" y1="7.27" x2="14.572" y2="7.7" width="0.262" layer="94"/>
<wire x1="14.572" y1="7.7" x2="14.562" y2="7.84" width="0.262" layer="94"/>
<wire x1="14.562" y1="7.84" x2="14.552" y2="7.97" width="0.262" layer="94"/>
<wire x1="14.552" y1="7.97" x2="14.542" y2="8.11" width="0.262" layer="94"/>
<wire x1="14.542" y1="8.11" x2="14.532" y2="8.24" width="0.262" layer="94"/>
<wire x1="14.532" y1="8.24" x2="14.512" y2="8.37" width="0.262" layer="94"/>
<wire x1="14.512" y1="8.37" x2="14.422" y2="8.76" width="0.262" layer="94"/>
<wire x1="14.422" y1="8.76" x2="14.372" y2="8.89" width="0.262" layer="94"/>
<wire x1="14.372" y1="8.89" x2="14.322" y2="9.01" width="0.262" layer="94"/>
<wire x1="14.322" y1="9.01" x2="14.252" y2="9.13" width="0.262" layer="94"/>
<wire x1="14.252" y1="9.13" x2="14.182" y2="9.24" width="0.262" layer="94"/>
<wire x1="14.182" y1="9.24" x2="14.102" y2="9.34" width="0.262" layer="94"/>
<wire x1="14.102" y1="9.34" x2="14.002" y2="9.44" width="0.262" layer="94"/>
<wire x1="14.002" y1="9.44" x2="13.892" y2="9.52" width="0.262" layer="94"/>
<wire x1="13.892" y1="9.52" x2="13.782" y2="9.59" width="0.262" layer="94"/>
<wire x1="13.782" y1="9.59" x2="13.662" y2="9.65" width="0.262" layer="94"/>
<wire x1="13.662" y1="9.65" x2="13.532" y2="9.7" width="0.262" layer="94"/>
<wire x1="13.532" y1="9.7" x2="13.412" y2="9.73" width="0.262" layer="94"/>
<wire x1="13.412" y1="9.73" x2="13.272" y2="9.76" width="0.262" layer="94"/>
<wire x1="13.272" y1="9.76" x2="13.012" y2="9.78" width="0.262" layer="94"/>
<wire x1="13.012" y1="9.78" x2="12.872" y2="9.79" width="0.262" layer="94"/>
<wire x1="12.872" y1="9.79" x2="12.742" y2="9.78" width="0.262" layer="94"/>
<wire x1="12.742" y1="9.78" x2="12.462" y2="9.76" width="0.262" layer="94"/>
<wire x1="12.462" y1="9.76" x2="12.202" y2="9.7" width="0.262" layer="94"/>
<wire x1="12.202" y1="9.7" x2="12.072" y2="9.66" width="0.262" layer="94"/>
<wire x1="12.072" y1="9.66" x2="11.942" y2="9.6" width="0.262" layer="94"/>
<wire x1="11.942" y1="9.6" x2="11.822" y2="9.54" width="0.262" layer="94"/>
<wire x1="11.822" y1="9.54" x2="11.712" y2="9.46" width="0.262" layer="94"/>
<wire x1="11.712" y1="9.46" x2="11.602" y2="9.37" width="0.262" layer="94"/>
<wire x1="11.602" y1="9.37" x2="11.512" y2="9.28" width="0.262" layer="94"/>
<wire x1="11.512" y1="9.28" x2="11.422" y2="9.17" width="0.262" layer="94"/>
<wire x1="11.422" y1="9.17" x2="11.352" y2="9.06" width="0.262" layer="94"/>
<wire x1="11.352" y1="9.06" x2="11.282" y2="8.93" width="0.262" layer="94"/>
<wire x1="11.282" y1="8.93" x2="11.232" y2="8.81" width="0.262" layer="94"/>
<wire x1="11.232" y1="8.81" x2="11.182" y2="8.68" width="0.262" layer="94"/>
<wire x1="11.182" y1="8.68" x2="11.142" y2="8.55" width="0.262" layer="94"/>
<wire x1="11.142" y1="8.55" x2="11.112" y2="8.42" width="0.262" layer="94"/>
<wire x1="11.112" y1="8.42" x2="11.092" y2="8.28" width="0.262" layer="94"/>
<wire x1="11.092" y1="8.28" x2="11.072" y2="8.15" width="0.262" layer="94"/>
<wire x1="11.072" y1="8.15" x2="11.052" y2="8.01" width="0.262" layer="94"/>
<wire x1="11.052" y1="8.01" x2="11.042" y2="7.88" width="0.262" layer="94"/>
<wire x1="11.042" y1="7.88" x2="11.032" y2="7.74" width="0.262" layer="94"/>
<wire x1="11.032" y1="7.74" x2="11.032" y2="6.88" width="0.262" layer="94"/>
<wire x1="11.032" y1="6.88" x2="11.042" y2="6.74" width="0.262" layer="94"/>
<wire x1="11.042" y1="6.74" x2="11.052" y2="6.61" width="0.262" layer="94"/>
<wire x1="11.052" y1="6.61" x2="11.092" y2="6.33" width="0.262" layer="94"/>
<wire x1="11.092" y1="6.33" x2="11.112" y2="6.2" width="0.262" layer="94"/>
<wire x1="11.112" y1="6.2" x2="11.142" y2="6.06" width="0.262" layer="94"/>
<wire x1="11.142" y1="6.06" x2="11.182" y2="5.93" width="0.262" layer="94"/>
<wire x1="11.182" y1="5.93" x2="11.232" y2="5.8" width="0.262" layer="94"/>
<wire x1="11.232" y1="5.8" x2="11.292" y2="5.68" width="0.262" layer="94"/>
<wire x1="11.292" y1="5.68" x2="11.362" y2="5.56" width="0.262" layer="94"/>
<wire x1="11.362" y1="5.56" x2="11.442" y2="5.45" width="0.262" layer="94"/>
<wire x1="11.442" y1="5.45" x2="11.532" y2="5.34" width="0.262" layer="94"/>
<wire x1="11.532" y1="5.34" x2="11.632" y2="5.25" width="0.262" layer="94"/>
<wire x1="11.632" y1="5.25" x2="11.742" y2="5.17" width="0.262" layer="94"/>
<wire x1="11.742" y1="5.17" x2="11.862" y2="5.1" width="0.262" layer="94"/>
<wire x1="11.862" y1="5.1" x2="11.982" y2="5.04" width="0.262" layer="94"/>
<wire x1="11.982" y1="5.04" x2="12.112" y2="5" width="0.262" layer="94"/>
<wire x1="12.112" y1="5" x2="12.252" y2="4.96" width="0.262" layer="94"/>
<wire x1="12.252" y1="4.96" x2="12.382" y2="4.94" width="0.262" layer="94"/>
<wire x1="12.382" y1="4.94" x2="12.522" y2="4.92" width="0.262" layer="94"/>
<wire x1="12.522" y1="4.92" x2="12.662" y2="4.91" width="0.262" layer="94"/>
<wire x1="12.662" y1="4.91" x2="13.012" y2="4.91" width="0.262" layer="94"/>
<wire x1="13.012" y1="4.91" x2="13.152" y2="4.93" width="0.262" layer="94"/>
<wire x1="13.152" y1="4.93" x2="13.282" y2="4.95" width="0.262" layer="94"/>
<wire x1="13.282" y1="4.95" x2="13.422" y2="4.98" width="0.262" layer="94"/>
<wire x1="13.422" y1="4.98" x2="13.552" y2="5.02" width="0.262" layer="94"/>
<wire x1="13.552" y1="5.02" x2="13.672" y2="5.07" width="0.262" layer="94"/>
<wire x1="13.672" y1="5.07" x2="13.792" y2="5.13" width="0.262" layer="94"/>
<wire x1="13.792" y1="5.13" x2="13.912" y2="5.21" width="0.262" layer="94"/>
<wire x1="13.912" y1="5.21" x2="14.012" y2="5.29" width="0.262" layer="94"/>
<wire x1="14.012" y1="5.29" x2="14.112" y2="5.39" width="0.262" layer="94"/>
<wire x1="14.112" y1="5.39" x2="14.192" y2="5.5" width="0.262" layer="94"/>
<wire x1="14.192" y1="5.5" x2="14.262" y2="5.61" width="0.262" layer="94"/>
<wire x1="14.262" y1="5.61" x2="14.322" y2="5.73" width="0.262" layer="94"/>
<wire x1="14.322" y1="5.73" x2="14.372" y2="5.86" width="0.262" layer="94"/>
<wire x1="14.372" y1="5.86" x2="14.412" y2="5.99" width="0.262" layer="94"/>
<wire x1="14.412" y1="5.99" x2="14.442" y2="6.12" width="0.262" layer="94"/>
<wire x1="14.442" y1="6.12" x2="14.472" y2="6.26" width="0.262" layer="94"/>
<wire x1="14.472" y1="6.26" x2="14.482" y2="6.39" width="0.262" layer="94"/>
<wire x1="14.482" y1="6.39" x2="14.472" y2="6.48" width="0.262" layer="94"/>
<wire x1="14.472" y1="6.48" x2="14.432" y2="6.54" width="0.262" layer="94"/>
<wire x1="14.432" y1="6.54" x2="14.392" y2="6.58" width="0.262" layer="94"/>
<wire x1="14.392" y1="6.58" x2="13.492" y2="6.58" width="0.262" layer="94"/>
<wire x1="13.492" y1="6.58" x2="13.442" y2="6.5" width="0.262" layer="94"/>
<wire x1="10.572" y1="9.6" x2="10.552" y2="9.86" width="0.262" layer="94"/>
<wire x1="10.552" y1="9.86" x2="10.532" y2="10" width="0.262" layer="94"/>
<wire x1="10.532" y1="10" x2="10.512" y2="10.13" width="0.262" layer="94"/>
<wire x1="10.512" y1="10.13" x2="10.472" y2="10.26" width="0.262" layer="94"/>
<wire x1="10.472" y1="10.26" x2="10.422" y2="10.38" width="0.262" layer="94"/>
<wire x1="10.422" y1="10.38" x2="10.362" y2="10.5" width="0.262" layer="94"/>
<wire x1="10.362" y1="10.5" x2="10.292" y2="10.61" width="0.262" layer="94"/>
<wire x1="10.292" y1="10.61" x2="10.202" y2="10.72" width="0.262" layer="94"/>
<wire x1="10.202" y1="10.72" x2="10.112" y2="10.81" width="0.262" layer="94"/>
<wire x1="10.112" y1="10.81" x2="9.892" y2="10.97" width="0.262" layer="94"/>
<wire x1="9.892" y1="10.97" x2="9.772" y2="11.03" width="0.262" layer="94"/>
<wire x1="9.772" y1="11.03" x2="9.652" y2="11.08" width="0.262" layer="94"/>
<wire x1="9.652" y1="11.08" x2="9.392" y2="11.14" width="0.262" layer="94"/>
<wire x1="9.392" y1="11.14" x2="9.262" y2="11.16" width="0.262" layer="94"/>
<wire x1="9.262" y1="11.16" x2="9.122" y2="11.18" width="0.262" layer="94"/>
<wire x1="9.122" y1="11.18" x2="6.692" y2="11.18" width="0.262" layer="94"/>
<wire x1="6.692" y1="11.18" x2="6.642" y2="11.12" width="0.262" layer="94"/>
<wire x1="6.642" y1="11.12" x2="6.632" y2="11.03" width="0.262" layer="94"/>
<wire x1="6.632" y1="11.03" x2="6.632" y2="5.17" width="0.262" layer="94"/>
<wire x1="6.632" y1="5.17" x2="6.642" y2="5.09" width="0.262" layer="94"/>
<wire x1="6.642" y1="5.09" x2="6.692" y2="5.02" width="0.262" layer="94"/>
<wire x1="6.692" y1="5.02" x2="7.712" y2="5.02" width="0.262" layer="94"/>
<wire x1="7.712" y1="5.02" x2="7.782" y2="5.05" width="0.262" layer="94"/>
<wire x1="7.782" y1="5.05" x2="7.812" y2="5.12" width="0.262" layer="94"/>
<wire x1="7.812" y1="5.12" x2="7.862" y2="5.19" width="0.262" layer="94"/>
<wire x1="7.862" y1="5.19" x2="7.872" y2="5.28" width="0.262" layer="94"/>
<wire x1="7.872" y1="5.28" x2="7.872" y2="7.42" width="0.262" layer="94"/>
<wire x1="7.872" y1="7.42" x2="7.892" y2="7.51" width="0.262" layer="94"/>
<wire x1="7.892" y1="7.51" x2="7.942" y2="7.59" width="0.262" layer="94"/>
<wire x1="7.942" y1="7.59" x2="7.982" y2="7.63" width="0.262" layer="94"/>
<wire x1="7.982" y1="7.63" x2="8.572" y2="7.63" width="0.262" layer="94"/>
<wire x1="8.572" y1="7.63" x2="8.702" y2="7.62" width="0.262" layer="94"/>
<wire x1="8.702" y1="7.62" x2="8.832" y2="7.58" width="0.262" layer="94"/>
<wire x1="8.832" y1="7.58" x2="8.952" y2="7.53" width="0.262" layer="94"/>
<wire x1="8.952" y1="7.53" x2="9.052" y2="7.44" width="0.262" layer="94"/>
<wire x1="9.052" y1="7.44" x2="9.132" y2="7.34" width="0.262" layer="94"/>
<wire x1="9.132" y1="7.34" x2="9.182" y2="7.22" width="0.262" layer="94"/>
<wire x1="9.182" y1="7.22" x2="9.222" y2="7.1" width="0.262" layer="94"/>
<wire x1="9.222" y1="7.1" x2="9.252" y2="6.97" width="0.262" layer="94"/>
<wire x1="9.252" y1="6.97" x2="9.262" y2="6.85" width="0.262" layer="94"/>
<wire x1="9.262" y1="6.85" x2="9.282" y2="6.59" width="0.262" layer="94"/>
<wire x1="9.282" y1="6.59" x2="9.282" y2="6.46" width="0.262" layer="94"/>
<wire x1="9.282" y1="6.46" x2="9.292" y2="6.33" width="0.262" layer="94"/>
<wire x1="9.292" y1="6.33" x2="9.292" y2="6.08" width="0.262" layer="94"/>
<wire x1="9.292" y1="6.08" x2="9.302" y2="5.95" width="0.262" layer="94"/>
<wire x1="9.302" y1="5.95" x2="9.302" y2="5.83" width="0.262" layer="94"/>
<wire x1="9.302" y1="5.83" x2="9.332" y2="5.5" width="0.262" layer="94"/>
<wire x1="9.332" y1="5.5" x2="9.352" y2="5.39" width="0.262" layer="94"/>
<wire x1="9.352" y1="5.39" x2="9.372" y2="5.31" width="0.262" layer="94"/>
<wire x1="9.372" y1="5.31" x2="9.402" y2="5.23" width="0.262" layer="94"/>
<wire x1="9.402" y1="5.23" x2="9.462" y2="5.15" width="0.262" layer="94"/>
<wire x1="9.462" y1="5.15" x2="9.532" y2="5.07" width="0.262" layer="94"/>
<wire x1="9.532" y1="5.07" x2="9.632" y2="5.02" width="0.262" layer="94"/>
<wire x1="9.632" y1="5.02" x2="10.682" y2="5.02" width="0.262" layer="94"/>
<wire x1="10.682" y1="5.02" x2="10.712" y2="5.09" width="0.262" layer="94"/>
<wire x1="10.712" y1="5.09" x2="10.712" y2="5.17" width="0.262" layer="94"/>
<wire x1="10.712" y1="5.17" x2="10.702" y2="5.22" width="0.262" layer="94"/>
<wire x1="10.702" y1="5.22" x2="10.662" y2="5.34" width="0.262" layer="94"/>
<wire x1="10.662" y1="5.34" x2="10.602" y2="5.47" width="0.262" layer="94"/>
<wire x1="10.602" y1="5.47" x2="10.572" y2="5.6" width="0.262" layer="94"/>
<wire x1="10.572" y1="5.6" x2="10.552" y2="5.74" width="0.262" layer="94"/>
<wire x1="10.552" y1="5.74" x2="10.542" y2="5.87" width="0.262" layer="94"/>
<wire x1="10.542" y1="5.87" x2="10.542" y2="6.01" width="0.262" layer="94"/>
<wire x1="10.542" y1="6.01" x2="10.532" y2="6.12" width="0.262" layer="94"/>
<wire x1="10.532" y1="6.12" x2="10.532" y2="6.34" width="0.262" layer="94"/>
<wire x1="10.532" y1="6.34" x2="10.522" y2="6.48" width="0.262" layer="94"/>
<wire x1="10.522" y1="6.48" x2="10.522" y2="6.62" width="0.262" layer="94"/>
<wire x1="10.522" y1="6.62" x2="10.512" y2="6.75" width="0.262" layer="94"/>
<wire x1="10.512" y1="6.75" x2="10.492" y2="6.89" width="0.262" layer="94"/>
<wire x1="10.492" y1="6.89" x2="10.482" y2="7.02" width="0.262" layer="94"/>
<wire x1="10.482" y1="7.02" x2="10.462" y2="7.16" width="0.262" layer="94"/>
<wire x1="10.462" y1="7.16" x2="10.432" y2="7.29" width="0.262" layer="94"/>
<wire x1="10.432" y1="7.29" x2="10.392" y2="7.42" width="0.262" layer="94"/>
<wire x1="10.392" y1="7.42" x2="10.342" y2="7.55" width="0.262" layer="94"/>
<wire x1="10.342" y1="7.55" x2="10.272" y2="7.67" width="0.262" layer="94"/>
<wire x1="10.272" y1="7.67" x2="10.182" y2="7.77" width="0.262" layer="94"/>
<wire x1="10.182" y1="7.77" x2="10.072" y2="7.85" width="0.262" layer="94"/>
<wire x1="10.072" y1="7.85" x2="9.952" y2="7.92" width="0.262" layer="94"/>
<wire x1="9.952" y1="7.92" x2="9.822" y2="7.97" width="0.262" layer="94"/>
<wire x1="9.822" y1="7.97" x2="9.752" y2="8.01" width="0.262" layer="94"/>
<wire x1="9.752" y1="8.01" x2="9.682" y2="8.08" width="0.262" layer="94"/>
<wire x1="9.682" y1="8.08" x2="9.742" y2="8.14" width="0.262" layer="94"/>
<wire x1="9.742" y1="8.14" x2="9.802" y2="8.19" width="0.262" layer="94"/>
<wire x1="9.802" y1="8.19" x2="9.922" y2="8.24" width="0.262" layer="94"/>
<wire x1="9.922" y1="8.24" x2="10.042" y2="8.31" width="0.262" layer="94"/>
<wire x1="10.042" y1="8.31" x2="10.142" y2="8.39" width="0.262" layer="94"/>
<wire x1="10.142" y1="8.39" x2="10.232" y2="8.49" width="0.262" layer="94"/>
<wire x1="10.232" y1="8.49" x2="10.312" y2="8.59" width="0.262" layer="94"/>
<wire x1="10.312" y1="8.59" x2="10.382" y2="8.7" width="0.262" layer="94"/>
<wire x1="10.382" y1="8.7" x2="10.442" y2="8.82" width="0.262" layer="94"/>
<wire x1="10.442" y1="8.82" x2="10.482" y2="8.95" width="0.262" layer="94"/>
<wire x1="10.482" y1="8.95" x2="10.512" y2="9.07" width="0.262" layer="94"/>
<wire x1="10.512" y1="9.07" x2="10.542" y2="9.2" width="0.262" layer="94"/>
<wire x1="10.542" y1="9.2" x2="10.552" y2="9.33" width="0.262" layer="94"/>
<wire x1="10.552" y1="9.33" x2="10.562" y2="9.47" width="0.262" layer="94"/>
<wire x1="10.562" y1="9.47" x2="10.572" y2="9.6" width="0.262" layer="94"/>
<wire x1="18.572" y1="5.09" x2="18.592" y2="5.18" width="0.262" layer="94"/>
<wire x1="18.592" y1="5.18" x2="18.592" y2="11.12" width="0.262" layer="94"/>
<wire x1="18.592" y1="11.12" x2="18.532" y2="11.17" width="0.262" layer="94"/>
<wire x1="18.532" y1="11.17" x2="18.462" y2="11.18" width="0.262" layer="94"/>
<wire x1="18.462" y1="11.18" x2="17.462" y2="11.18" width="0.262" layer="94"/>
<wire x1="17.462" y1="11.18" x2="17.402" y2="11.11" width="0.262" layer="94"/>
<wire x1="17.402" y1="11.11" x2="17.392" y2="11.01" width="0.262" layer="94"/>
<wire x1="17.392" y1="11.01" x2="17.392" y2="9.49" width="0.262" layer="94"/>
<wire x1="17.392" y1="9.49" x2="17.382" y2="9.4" width="0.262" layer="94"/>
<wire x1="17.382" y1="9.4" x2="17.332" y2="9.34" width="0.262" layer="94"/>
<wire x1="17.332" y1="9.34" x2="17.222" y2="9.41" width="0.262" layer="94"/>
<wire x1="17.222" y1="9.41" x2="17.122" y2="9.51" width="0.262" layer="94"/>
<wire x1="17.122" y1="9.51" x2="17.012" y2="9.59" width="0.262" layer="94"/>
<wire x1="17.012" y1="9.59" x2="16.902" y2="9.66" width="0.262" layer="94"/>
<wire x1="16.902" y1="9.66" x2="16.772" y2="9.72" width="0.262" layer="94"/>
<wire x1="16.772" y1="9.72" x2="16.642" y2="9.75" width="0.262" layer="94"/>
<wire x1="16.642" y1="9.75" x2="16.512" y2="9.77" width="0.262" layer="94"/>
<wire x1="16.512" y1="9.77" x2="16.372" y2="9.78" width="
