<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="16" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="14" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="56" name="wert" color="7" fill="1" visible="no" active="no"/>
<layer number="57" name="tCAD" color="7" fill="1" visible="no" active="no"/>
<layer number="59" name="tCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="60" name="bCarbon" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="7" fill="1" visible="yes" active="yes"/>
<layer number="100" name="Muster" color="7" fill="1" visible="no" active="no"/>
<layer number="101" name="Patch_Top" color="12" fill="4" visible="yes" active="yes"/>
<layer number="102" name="Vscore" color="7" fill="1" visible="yes" active="yes"/>
<layer number="103" name="tMap" color="7" fill="1" visible="yes" active="yes"/>
<layer number="104" name="Name" color="16" fill="1" visible="yes" active="yes"/>
<layer number="105" name="tPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="106" name="bPlate" color="7" fill="1" visible="yes" active="yes"/>
<layer number="107" name="Crop" color="7" fill="1" visible="yes" active="yes"/>
<layer number="108" name="tplace-old" color="10" fill="1" visible="yes" active="yes"/>
<layer number="109" name="ref-old" color="11" fill="1" visible="yes" active="yes"/>
<layer number="110" name="fp0" color="7" fill="1" visible="yes" active="yes"/>
<layer number="111" name="LPC17xx" color="7" fill="1" visible="yes" active="yes"/>
<layer number="112" name="tSilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="113" name="IDFDebug" color="4" fill="1" visible="yes" active="yes"/>
<layer number="114" name="Badge_Outline" color="7" fill="1" visible="yes" active="yes"/>
<layer number="115" name="ReferenceISLANDS" color="7" fill="1" visible="yes" active="yes"/>
<layer number="116" name="Patch_BOT" color="9" fill="4" visible="yes" active="yes"/>
<layer number="118" name="Rect_Pads" color="7" fill="1" visible="yes" active="yes"/>
<layer number="121" name="_tsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="122" name="_bsilk" color="7" fill="1" visible="yes" active="yes"/>
<layer number="123" name="tTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="124" name="bTestmark" color="7" fill="1" visible="yes" active="yes"/>
<layer number="125" name="_tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="126" name="_bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="127" name="_tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="128" name="_bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="129" name="Mask" color="7" fill="1" visible="yes" active="yes"/>
<layer number="131" name="tAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="132" name="bAdjust" color="7" fill="1" visible="yes" active="yes"/>
<layer number="144" name="Drill_legend" color="7" fill="1" visible="yes" active="yes"/>
<layer number="150" name="Notes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="151" name="HeatSink" color="7" fill="1" visible="yes" active="yes"/>
<layer number="152" name="_bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="153" name="FabDoc1" color="7" fill="1" visible="yes" active="yes"/>
<layer number="154" name="FabDoc2" color="7" fill="1" visible="yes" active="yes"/>
<layer number="155" name="FabDoc3" color="7" fill="1" visible="yes" active="yes"/>
<layer number="199" name="Contour" color="7" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="201" name="201bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="4" fill="10" visible="yes" active="yes"/>
<layer number="204" name="204bmp" color="5" fill="10" visible="yes" active="yes"/>
<layer number="205" name="205bmp" color="6" fill="10" visible="yes" active="yes"/>
<layer number="206" name="206bmp" color="7" fill="10" visible="yes" active="yes"/>
<layer number="207" name="207bmp" color="8" fill="10" visible="yes" active="yes"/>
<layer number="208" name="208bmp" color="9" fill="10" visible="yes" active="yes"/>
<layer number="209" name="209bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="210" name="210bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="211" name="211bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="212" name="212bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="213" name="213bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="214" name="214bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="215" name="215bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="216" name="216bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="217" name="217bmp" color="18" fill="1" visible="no" active="no"/>
<layer number="218" name="218bmp" color="19" fill="1" visible="no" active="no"/>
<layer number="219" name="219bmp" color="20" fill="1" visible="no" active="no"/>
<layer number="220" name="220bmp" color="21" fill="1" visible="no" active="no"/>
<layer number="221" name="221bmp" color="22" fill="1" visible="no" active="no"/>
<layer number="222" name="222bmp" color="23" fill="1" visible="no" active="no"/>
<layer number="223" name="223bmp" color="24" fill="1" visible="no" active="no"/>
<layer number="224" name="224bmp" color="25" fill="1" visible="no" active="no"/>
<layer number="225" name="225bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="226" name="226bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="227" name="227bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="228" name="228bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="229" name="229bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="230" name="230bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="231" name="231bmp" color="7" fill="1" visible="yes" active="yes"/>
<layer number="248" name="Housing" color="7" fill="1" visible="yes" active="yes"/>
<layer number="249" name="Edge" color="7" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="yes" active="yes"/>
<layer number="255" name="routoute" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>&lt;h3&gt;SparkFun Electronics' preferred foot prints&lt;/h3&gt;
In this library you'll find connectors and sockets- basically anything that can be plugged into or onto.&lt;br&gt;&lt;br&gt;
We've spent an enormous amount of time creating and checking these footprints and parts, but it is the end user's responsibility to ensure correctness and suitablity for a given componet or application. If you enjoy using this library, please buy one of our products at www.sparkfun.com.
&lt;b&gt;Licensing:&lt;/b&gt; Creative Commons ShareAlike 4.0 International - https://creativecommons.org/licenses/by-sa/4.0/
You are welcome to use this library for commercial purposes. For attribution, we ask that when you begin to sell your device using our footprint, you email us with a link to the product being sold. We want bragging rights that we helped (in a very small part) to create your 8th world wonder. We would like the opportunity to feature your device on our homepage.</description>
<packages>
<package name="1X06-SMD">
<wire x1="7.62" y1="1.25" x2="-7.62" y2="1.25" width="0.127" layer="51"/>
<wire x1="-7.62" y1="1.25" x2="-7.62" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-7.62" y1="-1.25" x2="-6.35" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-1.25" x2="-3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="6.35" y2="-1.25" width="0.127" layer="51"/>
<wire x1="6.35" y1="-1.25" x2="7.62" y2="-1.25" width="0.127" layer="51"/>
<wire x1="7.62" y1="-1.25" x2="7.62" y2="1.25" width="0.127" layer="51"/>
<wire x1="6.35" y1="-1.25" x2="6.35" y2="-7.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="-1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-1.25" x2="-6.35" y2="-7.25" width="0.127" layer="51"/>
<smd name="4" x="1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="5" x="3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="6" x="6.35" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="3" x="-1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="1" x="-6.35" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<hole x="-5.08" y="0" drill="1.4"/>
<hole x="5.08" y="0" drill="1.4"/>
<text x="-1.905" y="1.905" size="0.8128" layer="25">&gt;NAME</text>
<text x="-1.905" y="0.635" size="0.8128" layer="27">&gt;VALUE</text>
</package>
<package name="1X06">
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
<package name="MOLEX-1X6-RA_LOCK">
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="3.175" width="0.127" layer="21"/>
<wire x1="13.97" y1="0.635" x2="-1.27" y2="0.635" width="0.127" layer="21"/>
<wire x1="13.97" y1="3.175" x2="12.7" y2="3.175" width="0.127" layer="21"/>
<wire x1="12.7" y1="3.175" x2="0" y2="3.175" width="0.127" layer="21"/>
<wire x1="0" y1="3.175" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="0" y1="3.175" x2="0" y2="7.62" width="0.127" layer="21"/>
<wire x1="0" y1="7.62" x2="12.7" y2="7.62" width="0.127" layer="21"/>
<wire x1="12.7" y1="7.62" x2="12.7" y2="3.175" width="0.127" layer="21"/>
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796"/>
<pad name="5" x="10.16" y="0.127" drill="1.016" diameter="1.8796"/>
<pad name="6" x="12.7" y="-0.127" drill="1.016" diameter="1.8796"/>
<text x="-0.889" y="-2.794" size="1.27" layer="25">&gt;NAME</text>
<text x="8.001" y="-2.794" size="1.27" layer="25">&gt;VALUE</text>
</package>
<package name="1X06_LONGPADS">
<pad name="1" x="0" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-1.3462" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X06_LOCK">
<description>This footprint was designed to help hold the alignment of a through-hole component (i.e.  6-pin header) while soldering it into place.
You may notice that each hole has been shifted either up or down by 0.005 of an inch from it's more standard position (which is a perfectly straight line).
This slight alteration caused the pins (the squares in the middle) to touch the edges of the holes.  Because they are alternating, it causes a "brace"
to hold the component in place.  0.005 has proven to be the perfect amount of "off-center" position when using our standard breakaway headers.
Although looks a little odd when you look at the bare footprint, once you have a header in there, the alteration is very hard to notice.  Also,
if you push a header all the way into place, it is covered up entirely on the bottom side.  This idea of altering the position of holes to aid alignment
will be further integrated into the Sparkfun Library for other footprints.  It can help hold any component with 3 or more connection pins.</description>
<wire x1="-1.27" y1="0.508" x2="-0.635" y2="1.143" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.143" x2="0.635" y2="1.143" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.143" x2="1.27" y2="0.508" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.508" x2="1.905" y2="1.143" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.143" x2="3.175" y2="1.143" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.143" x2="3.81" y2="0.508" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.508" x2="4.445" y2="1.143" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.143" x2="5.715" y2="1.143" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.143" x2="6.35" y2="0.508" width="0.2032" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.985" y2="1.143" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.143" x2="8.255" y2="1.143" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.143" x2="8.89" y2="0.508" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.508" x2="9.525" y2="1.143" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.143" x2="10.795" y2="1.143" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.143" x2="11.43" y2="0.508" width="0.2032" layer="21"/>
<wire x1="11.43" y1="0.508" x2="12.065" y2="1.143" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.143" x2="13.335" y2="1.143" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.143" x2="13.97" y2="0.508" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0.508" x2="13.97" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.762" x2="13.335" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.397" x2="12.065" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.397" x2="11.43" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.762" x2="10.795" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.397" x2="9.525" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.397" x2="8.89" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.762" x2="8.255" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.397" x2="6.985" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-1.397" x2="6.35" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.762" x2="5.715" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.397" x2="4.445" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.397" x2="3.81" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.762" x2="3.175" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.397" x2="1.905" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.397" x2="1.27" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.762" x2="0.635" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.397" x2="-0.635" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.397" x2="-1.27" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.762" x2="-1.27" y2="0.508" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.508" x2="1.27" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.508" x2="3.81" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.35" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.508" x2="8.89" y2="-0.762" width="0.2032" layer="21"/>
<wire x1="11.43" y1="0.508" x2="11.43" y2="-0.762" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796"/>
<pad name="2" x="2.54" y="-0.254" drill="1.016" diameter="1.8796"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796"/>
<pad name="4" x="7.62" y="-0.254" drill="1.016" diameter="1.8796"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796"/>
<pad name="6" x="12.7" y="-0.254" drill="1.016" diameter="1.8796"/>
<text x="-1.27" y="1.778" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-3.302" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="-0.2921" y1="-0.4191" x2="0.2921" y2="0.1651" layer="51"/>
<rectangle x1="2.2479" y1="-0.4191" x2="2.8321" y2="0.1651" layer="51"/>
<rectangle x1="4.7879" y1="-0.4191" x2="5.3721" y2="0.1651" layer="51"/>
<rectangle x1="7.3279" y1="-0.4191" x2="7.9121" y2="0.1651" layer="51"/>
<rectangle x1="9.8679" y1="-0.4191" x2="10.4521" y2="0.1651" layer="51"/>
<rectangle x1="12.4079" y1="-0.4191" x2="12.9921" y2="0.1651" layer="51"/>
</package>
<package name="1X06-KIT">
<description>&lt;h3&gt;1X06-KIT&lt;/h3&gt;
&lt;b&gt;Warning:&lt;/b&gt; This is the KIT version of this package. This package has a smaller diameter top stop mask, which doesn't cover the diameter of the pad. This means only the bottom side of the pads' copper will be exposed. You'll only be able to solder to the bottom side.</description>
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="51"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="51"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="51"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="51"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="51"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="51"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="51"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="51"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="51"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="51"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="51"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="51"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="51"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="51"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="51"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="51"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="51"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="51"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="51"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="51"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="-0.635" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<polygon width="0.127" layer="30">
<vertex x="0.0025" y="-0.9525" curve="-90"/>
<vertex x="-0.9524" y="-0.0228" curve="-90.011749"/>
<vertex x="0" y="0.9526" curve="-90"/>
<vertex x="0.95" y="-0.0254" curve="-90.024193"/>
</polygon>
<polygon width="0.127" layer="29">
<vertex x="0" y="-0.4445" curve="-90.012891"/>
<vertex x="-0.4445" y="-0.0203" curve="-90"/>
<vertex x="0" y="0.447" curve="-90"/>
<vertex x="0.4419" y="-0.0101" curve="-90.012967"/>
</polygon>
<vertex x="2.5425" y="-0.9525" curve="-90"/>
<vertex x="1.5876" y="-0.0228" curve="-90.011749"/>
<vertex x="2.54" y="0.9526" curve="-90"/>
<vertex x="3.49" y="-0.0254" curve="-90.024193"/>
</polygon>
<vertex x="2.54" y="-0.4445" curve="-90.012891"/>
<vertex x="2.0955" y="-0.0203" curve="-90"/>
<vertex x="2.54" y="0.447" curve="-90"/>
<vertex x="2.9819" y="-0.0101" curve="-90.012967"/>
</polygon>
<vertex x="5.0825" y="-0.9525" curve="-90"/>
<vertex x="4.1276" y="-0.0228" curve="-90.011749"/>
<vertex x="5.08" y="0.9526" curve="-90"/>
<vertex x="6.03" y="-0.0254" curve="-90.024193"/>
</polygon>
<vertex x="5.08" y="-0.4445" curve="-90.012891"/>
<vertex x="4.6355" y="-0.0203" curve="-90"/>
<vertex x="5.08" y="0.447" curve="-90"/>
<vertex x="5.5219" y="-0.0101" curve="-90.012967"/>
</polygon>
<vertex x="7.6225" y="-0.9525" curve="-90"/>
<vertex x="6.6676" y="-0.0228" curve="-90.011749"/>
<vertex x="7.62" y="0.9526" curve="-90"/>
<vertex x="8.57" y="-0.0254" curve="-90.024193"/>
</polygon>
<vertex x="7.62" y="-0.4445" curve="-90.012891"/>
<vertex x="7.1755" y="-0.0203" curve="-90"/>
<vertex x="7.62" y="0.447" curve="-90"/>
<vertex x="8.0619" y="-0.0101" curve="-90.012967"/>
</polygon>
<vertex x="10.1625" y="-0.9525" curve="-90"/>
<vertex x="9.2076" y="-0.0228" curve="-90.011749"/>
<vertex x="10.16" y="0.9526" curve="-90"/>
<vertex x="11.11" y="-0.0254" curve="-90.024193"/>
</polygon>
<vertex x="10.16" y="-0.4445" curve="-90.012891"/>
<vertex x="9.7155" y="-0.0203" curve="-90"/>
<vertex x="10.16" y="0.447" curve="-90"/>
<vertex x="10.6019" y="-0.0101" curve="-90.012967"/>
</polygon>
<vertex x="12.7025" y="-0.9525" curve="-90"/>
<vertex x="11.7476" y="-0.0228" curve="-90.011749"/>
<vertex x="12.7" y="0.9526" curve="-90"/>
<vertex x="13.65" y="-0.0254" curve="-90.024193"/>
</polygon>
<vertex x="12.7" y="-0.4445" curve="-90.012891"/>
<vertex x="12.2555" y="-0.0203" curve="-90"/>
<vertex x="12.7" y="0.447" curve="-90"/>
<vertex x="13.1419" y="-0.0101" curve="-90.012967"/>
</polygon>
</package>
<package name="ATARI_CONNECTOR">
<wire x1="-3.175" y1="7.62" x2="13.335" y2="7.62" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0" x2="11.43" y2="0" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0" x2="-3.175" y2="7.62" width="0.127" layer="21"/>
<wire x1="11.43" y1="0" x2="13.335" y2="7.62" width="0.127" layer="21"/>
<pad name="P$1" x="1.27" y="2.54" drill="0.8" diameter="1.8796"/>
<pad name="P$2" x="3.81" y="2.54" drill="0.8" diameter="1.8796"/>
<pad name="P$3" x="6.35" y="2.54" drill="0.8" diameter="1.8796"/>
<pad name="P$4" x="8.89" y="2.54" drill="0.8" diameter="1.8796"/>
<pad name="P$5" x="0" y="5.08" drill="0.8" diameter="1.8796"/>
<pad name="P$6" x="2.54" y="5.08" drill="0.8" diameter="1.8796"/>
<pad name="P$7" x="5.08" y="5.08" drill="0.8" diameter="1.8796"/>
<pad name="P$8" x="7.62" y="5.08" drill="0.8" diameter="1.8796"/>
<pad name="P$9" x="10.16" y="5.08" drill="0.8" diameter="1.8796"/>
</package>
<package name="ATX24_RIGHT_ANGLE">
<wire x1="-25.9" y1="3.4" x2="-25.9" y2="-9.14" width="0.254" layer="21"/>
<wire x1="-25.9" y1="-9.14" x2="25.9" y2="-9.14" width="0.254" layer="21"/>
<wire x1="25.9" y1="-9.14" x2="25.9" y2="3.4" width="0.254" layer="21"/>
<wire x1="25.9" y1="3.4" x2="-25.9" y2="3.4" width="0.2032" layer="51"/>
<wire x1="-25" y1="4" x2="-25" y2="12" width="0.127" layer="51"/>
<wire x1="-25" y1="12" x2="25" y2="12" width="0.127" layer="51"/>
<wire x1="25" y1="12" x2="25" y2="4" width="0.127" layer="51"/>
<wire x1="25.9" y1="3.4" x2="24" y2="3.4" width="0.254" layer="21"/>
<wire x1="-25.9" y1="3.4" x2="-24" y2="3.4" width="0.254" layer="21"/>
<wire x1="-20" y1="3.4" x2="-22" y2="3.4" width="0.254" layer="21"/>
<wire x1="-15.8" y1="3.4" x2="-17.8" y2="3.4" width="0.254" layer="21"/>
<wire x1="-11.5" y1="3.4" x2="-13.5" y2="3.4" width="0.254" layer="21"/>
<wire x1="-7.4" y1="3.4" x2="-9.4" y2="3.4" width="0.254" layer="21"/>
<wire x1="-3.2" y1="3.4" x2="-5.2" y2="3.4" width="0.254" layer="21"/>
<wire x1="1" y1="3.4" x2="-1" y2="3.4" width="0.254" layer="21"/>
<wire x1="5.2" y1="3.4" x2="3.2" y2="3.4" width="0.254" layer="21"/>
<wire x1="9.4" y1="3.4" x2="7.4" y2="3.4" width="0.254" layer="21"/>
<wire x1="13.6" y1="3.4" x2="11.6" y2="3.4" width="0.254" layer="21"/>
<wire x1="17.8" y1="3.4" x2="15.8" y2="3.4" width="0.254" layer="21"/>
<wire x1="22" y1="3.4" x2="20" y2="3.4" width="0.254" layer="21"/>
<wire x1="-1.7" y1="-9" x2="-1.7" y2="-6" width="0.254" layer="21"/>
<wire x1="-1.7" y1="-6" x2="1.7" y2="-6" width="0.254" layer="21"/>
<wire x1="1.7" y1="-6" x2="1.7" y2="-9" width="0.254" layer="21"/>
<pad name="1" x="23.1" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="2" x="18.9" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="3" x="14.7" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="4" x="10.5" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="5" x="6.3" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="6" x="2.1" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="7" x="-2.1" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="8" x="-6.3" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="9" x="-10.5" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="10" x="-14.7" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="11" x="-18.9" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="12" x="-23.1" y="4.76" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="13" x="23.1" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="14" x="18.9" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="15" x="14.7" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="16" x="10.5" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="17" x="6.3" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="18" x="2.1" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="19" x="-2.1" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="20" x="-6.3" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="21" x="-10.5" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="22" x="-14.7" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="23" x="-18.9" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<pad name="24" x="-23.1" y="10.26" drill="1.8" diameter="2.9" rot="R180"/>
<text x="-25.4" y="-11.43" size="1.27" layer="25">&gt;Name</text>
<text x="20.32" y="-11.43" size="1.27" layer="27">&gt;Value</text>
<hole x="-23.1" y="-2.54" drill="3"/>
<hole x="23.1" y="-2.54" drill="3"/>
<polygon width="0.254" layer="21">
<vertex x="-1.7" y="-7"/>
<vertex x="1.7" y="-7"/>
<vertex x="1.7" y="-6"/>
<vertex x="-1.7" y="-6"/>
</polygon>
</package>
<package name="AUDIO-JACK">
<wire x1="7.5" y1="6" x2="7.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="6" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-4.5" x2="-3.5" y2="-6" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="4.5" x2="-4.5" y2="3" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-3" x2="-4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-4.5" x2="-3.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="4.5" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="3" x2="-6.5" y2="-3" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-3" x2="-4.5" y2="-3" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="3" x2="-4.5" y2="3" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="6" x2="3.5" y2="6" width="0.2032" layer="21"/>
<wire x1="7.5" y1="6" x2="6.5" y2="6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="6" x2="-3.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-6" x2="3.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="7.5" y1="-6" x2="6.5" y2="-6" width="0.2032" layer="21"/>
<pad name="SLEEVE" x="0" y="0" drill="1.3" diameter="2.1844"/>
<pad name="RSH" x="5" y="2.5" drill="1.3" diameter="2.1844"/>
<pad name="RING" x="5" y="5" drill="1.3" diameter="2.1844"/>
<pad name="TSH" x="5" y="-2.5" drill="1.3" diameter="2.1844"/>
<pad name="TIP" x="5" y="-5" drill="1.3" diameter="2.1844"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
<hole x="0" y="5" drill="1.2"/>
<hole x="-2.5" y="5" drill="1.2"/>
<hole x="-2.5" y="-5" drill="1.2"/>
<hole x="0" y="-5" drill="1.2"/>
<hole x="5" y="0" drill="1.2"/>
</package>
<package name="STEREOJACK2.5MM_STEREOJACK2.5MM">
<wire x1="4.4" y1="2.5" x2="4.2" y2="2.5" width="0.127" layer="21"/>
<wire x1="4.2" y1="2.5" x2="-3.3" y2="2.5" width="0.127" layer="21"/>
<wire x1="-3.3" y1="2.5" x2="-3.3" y2="1.7" width="0.127" layer="21"/>
<wire x1="-3.3" y1="1.7" x2="-3.3" y2="-1.9" width="0.127" layer="21"/>
<wire x1="-3.3" y1="-1.9" x2="-3.3" y2="-2.6" width="0.127" layer="21"/>
<wire x1="-3.3" y1="-2.6" x2="4.6" y2="-2.6" width="0.127" layer="21"/>
<wire x1="4.6" y1="-2.6" x2="4.6" y2="-1.5" width="0.127" layer="21"/>
<wire x1="4.6" y1="1.5" x2="4.6" y2="2.5" width="0.127" layer="21"/>
<wire x1="4.6" y1="2.5" x2="4.2" y2="2.5" width="0.127" layer="21"/>
<wire x1="-3.3" y1="1.7" x2="-6.3" y2="1.7" width="0.127" layer="21"/>
<wire x1="-6.3" y1="1.7" x2="-6.3" y2="-1.9" width="0.127" layer="21"/>
<wire x1="-6.3" y1="-1.9" x2="-3.3" y2="-1.9" width="0.127" layer="21"/>
<pad name="RING1" x="2.5" y="-1.85" drill="1.1" diameter="1.9304"/>
<pad name="RING2" x="2.5" y="1.85" drill="1.1" diameter="1.9304"/>
<pad name="SHIELD" x="-2.4" y="0" drill="1" diameter="1.9304"/>
<pad name="TIP" x="4.5" y="0" drill="1.1" diameter="1.9304"/>
<hole x="0" y="0" drill="1.2"/>
</package>
<package name="STEREOJACK2.5MM_SPECIA_POGOPINS">
<wire x1="4.6" y1="2.5" x2="-3.3" y2="2.5" width="0.127" layer="21"/>
<pad name="RING1" x="2.5" y="-1.85" drill="1.1176" diameter="1.9304" shape="offset" rot="R270"/>
<pad name="RING2" x="2.5" y="1.85" drill="1.1176" diameter="1.9304" shape="offset" rot="R90"/>
<pad name="SHIELD" x="-2.4" y="0" drill="1.1176" diameter="1.9304" shape="offset" rot="R180"/>
<pad name="TIP" x="4.5" y="0" drill="1.1176" diameter="1.9304" shape="offset"/>
</package>
<package name="STEREOJACK2.5MM_SPECIAL_HOLES-ONLY">
<pad name="RING1" x="2.5" y="-1.85" drill="0.889" diameter="0.8128" rot="R270"/>
<pad name="RING2" x="2.5" y="1.85" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="SHIELD" x="-2.4" y="0" drill="0.889" diameter="0.8128" rot="R180"/>
<pad name="TIP" x="4.5" y="0" drill="0.889" diameter="0.8128"/>
<hole x="0" y="0" drill="0.889"/>
<hole x="-2.4" y="0" drill="1.4732"/>
<hole x="2.5" y="1.85" drill="1.4732"/>
<hole x="4.5" y="0" drill="1.4732"/>
<hole x="2.5" y="-1.85" drill="1.4732"/>
</package>
<package name="STEREOJACK2.5MM_SMD">
<wire x1="-1.5" y1="0" x2="-1.5" y2="1.3" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="1.3" x2="-1.5" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="2.5" x2="-0.35" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="0" x2="-1.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-1.3" x2="-1.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-2.5" x2="-0.4" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="2.25" y1="2.5" x2="4.95" y2="2.5" width="0.2032" layer="21"/>
<wire x1="2.2" y1="-2.5" x2="4.95" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="0" x2="-2.5" y2="1.3" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="1.3" x2="-1.5" y2="1.3" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="0" x2="-2.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="-1.3" x2="-1.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="6.9" y1="2.5" x2="7.9" y2="2.5" width="0.2032" layer="21"/>
<wire x1="7.9" y1="2.5" x2="7.9" y2="1.05" width="0.2032" layer="21"/>
<wire x1="6.95" y1="-2.5" x2="7.9" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="7.9" y1="-2.5" x2="7.9" y2="-1" width="0.2032" layer="21"/>
<smd name="5" x="1" y="2.85" dx="2" dy="2.3" layer="1"/>
<smd name="A" x="1" y="-2.85" dx="2" dy="2.3" layer="1"/>
<smd name="4" x="6" y="-2.25" dx="2.1" dy="1.5" layer="1" rot="R90"/>
<smd name="1" x="6" y="2.25" dx="2.1" dy="1.5" layer="1" rot="R90"/>
<smd name="3" x="8.55" y="0" dx="2.1" dy="1.5" layer="1" rot="R180"/>
<text x="-1" y="-6" size="1.016" layer="27">&gt;Value</text>
<text x="-1" y="5" size="1.016" layer="25">&gt;Name</text>
<hole x="4" y="0" drill="1.2"/>
</package>
<package name="AUDIO-JACK-3.5MM-SMD">
<wire x1="3.9" y1="-3" x2="10.2" y2="-3" width="0.254" layer="21"/>
<wire x1="14.5" y1="-0.635" x2="14.5" y2="-3" width="0.254" layer="21"/>
<wire x1="14.5" y1="-3" x2="13.2" y2="-3" width="0.254" layer="21"/>
<wire x1="14.5" y1="2.2098" x2="14.5" y2="3" width="0.254" layer="21"/>
<wire x1="14.5" y1="3" x2="5.7" y2="3" width="0.254" layer="21"/>
<wire x1="0.5" y1="3" x2="0" y2="3" width="0.254" layer="51"/>
<wire x1="0" y1="3" x2="0" y2="-2.5" width="0.254" layer="51"/>
<wire x1="0" y1="-2.5" x2="0" y2="-3" width="0.254" layer="51"/>
<wire x1="0" y1="-3" x2="1" y2="-3" width="0.254" layer="51"/>
<wire x1="-0.1524" y1="2.5" x2="-2.5" y2="2.5" width="0.254" layer="51"/>
<wire x1="-2.5" y1="2.5" x2="-2.5" y2="-2.5" width="0.254" layer="51"/>
<wire x1="-2.5" y1="-2.5" x2="0" y2="-2.5" width="0.254" layer="51"/>
<smd name="SLEEVE" x="2.4" y="-3.45" dx="2" dy="2.5" layer="1"/>
<smd name="TIP" x="11.7" y="-3.45" dx="2" dy="2.5" layer="1"/>
<smd name="RING" x="4.3" y="3.45" dx="2" dy="2.5" layer="1"/>
<smd name="TSH" x="15.75" y="0.75" dx="2" dy="2.5" layer="1" rot="R90"/>
<smd name="RSH" x="1.5" y="3.45" dx="1.2" dy="2.5" layer="1" rot="R180"/>
<hole x="3.5" y="0" drill="2"/>
<hole x="10.5" y="0" drill="2"/>
<text x="6.35" y="3.81" size="0.8128" layer="25" font="vector">&gt;Name</text>
<text x="6.35" y="1.27" size="0.8128" layer="27" font="vector">&gt;Value</text>
</package>
<package name="AVR_MINI_PROG">
<wire x1="-1" y1="1" x2="-1" y2="-1" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1" x2="8.5" y2="-1" width="0.2032" layer="21"/>
<wire x1="8.5" y1="-1" x2="8.5" y2="1" width="0.2032" layer="21"/>
<wire x1="8.5" y1="1" x2="-1" y2="1" width="0.2032" layer="21"/>
<wire x1="0.62" y1="0.76" x2="-0.65" y2="0.76" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" diameter="1.27" shape="square"/>
<pad name="2" x="1.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="3" x="3" y="0" drill="0.8" diameter="1.27"/>
<pad name="4" x="4.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="5" x="6" y="0" drill="0.8" diameter="1.27"/>
<pad name="6" x="7.5" y="0.01" drill="0.8" diameter="1.27"/>
</package>
<package name="2X3">
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-0.635" y2="3.81" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.2032" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.905" y2="3.81" width="0.2032" layer="21"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="3.81" width="0.2032" layer="21"/>
<wire x1="3.175" y1="3.81" x2="3.81" y2="3.175" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="4.445" y2="3.81" width="0.2032" layer="21"/>
<wire x1="4.445" y1="3.81" x2="5.715" y2="3.81" width="0.2032" layer="21"/>
<wire x1="5.715" y1="3.81" x2="6.35" y2="3.175" width="0.2032" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.605" x2="-0.635" y2="-1.605" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="0" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="2.54" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="2.54" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="5.08" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="5.08" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-1.27" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-0.254" y1="2.286" x2="0.254" y2="2.794" layer="51"/>
<rectangle x1="2.286" y1="2.286" x2="2.794" y2="2.794" layer="51"/>
<rectangle x1="4.826" y1="2.286" x2="5.334" y2="2.794" layer="51"/>
</package>
<package name="2X3-NS">
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="0.635" y1="-2.54" x2="1.27" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="3.175" y1="-2.54" x2="3.81" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.2032" layer="51"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.2032" layer="51"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.2032" layer="51"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.2032" layer="51"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.2032" layer="51"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.2032" layer="51"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.2032" layer="51"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.2032" layer="51"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.2032" layer="51"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.2032" layer="51"/>
<wire x1="-1.905" y1="-2.875" x2="-3.175" y2="-2.875" width="0.2032" layer="51"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-3.81" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
</package>
<package name="2X3_OFFSET">
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="-4.78" x2="-3.175" y2="-4.78" width="0.2032" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="2" x="-2.54" y="1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R90"/>
<pad name="3" x="0" y="-1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="4" x="0" y="1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R90"/>
<pad name="5" x="2.54" y="-1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="6" x="2.54" y="1.27" drill="1.1176" diameter="1.8796" shape="offset" rot="R90"/>
<text x="-4.445" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.715" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="2X3_LOCK">
<pad name="3" x="2.54" y="-0.254" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="2.54" y="2.286" drill="1.016" diameter="1.8796" shape="octagon"/>
</package>
<package name="AVR_ICSP">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-1.905" y1="6.35" x2="-2.54" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="4.445" x2="-1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.81" x2="-2.54" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.175" x2="-1.905" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="6.35" x2="1.905" y2="6.35" width="0.1524" layer="21"/>
<wire x1="1.905" y1="6.35" x2="2.54" y2="5.715" width="0.1524" layer="21"/>
<wire x1="2.54" y1="5.715" x2="2.54" y2="4.445" width="0.1524" layer="21"/>
<wire x1="2.54" y1="4.445" x2="1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.81" x2="2.54" y2="3.175" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.175" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.175" x2="1.905" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.81" x2="-1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-3.81" x2="-1.905" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-2.54" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.175" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="5.715" x2="-2.54" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-3.81" x2="-2.54" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-5.715" x2="-1.905" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-3.81" x2="2.54" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-4.445" x2="2.54" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-5.715" x2="1.905" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-6.35" x2="-1.905" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-4.445" x2="-2.54" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="5.715" x2="-3.175" y2="4.445" width="0.2032" layer="21"/>
<pad name="1" x="-1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.794" y="-3.302" size="0.4064" layer="25" rot="R90">&gt;NAME</text>
<text x="-2.794" y="-0.254" size="0.4064" layer="27" font="vector" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.524" y1="4.826" x2="-1.016" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="4.826" x2="1.524" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="2.286" x2="1.524" y2="2.794" layer="51"/>
<rectangle x1="-1.524" y1="2.286" x2="-1.016" y2="2.794" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="21"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-4.826" layer="51"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-4.826" layer="51"/>
<rectangle x1="-1.524" y1="-2.794" x2="-1.016" y2="-2.286" layer="51"/>
<rectangle x1="1.016" y1="-2.794" x2="1.524" y2="-2.286" layer="51"/>
</package>
<package name="2X3-SHROUDED">
<wire x1="-2.775" y1="3.175" x2="-2.775" y2="1.905" width="0.2032" layer="21"/>
<wire x1="4.5" y1="7.56" x2="4.5" y2="-7.56" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-7.56" x2="-4.5" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-2.2" x2="-4.5" y2="2.2" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="2.2" x2="-4.5" y2="7.56" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="7.56" x2="4.4" y2="7.56" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-7.56" x2="-4.5" y2="-7.56" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="6.46" x2="3.4" y2="6.46" width="0.2032" layer="51"/>
<wire x1="3.4" y1="6.46" x2="3.4" y2="-6.46" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-6.46" x2="3.4" y2="-6.46" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="2.2" x2="-3" y2="2.2" width="0.2032" layer="21"/>
<wire x1="-3" y1="2.2" x2="-3" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-3" y1="-2.2" x2="-4.5" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="6.46" x2="-3.4" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-6.46" x2="-3.4" y2="-2.2" width="0.2032" layer="51"/>
<pad name="1" x="-1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.921" y="7.874" size="0.4064" layer="27" font="vector">&gt;VALUE</text>
<text x="-2.921" y="-8.382" size="0.4064" layer="25">&gt;NAME</text>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
</package>
<package name="2X5-SHROUDED">
<wire x1="-2.775" y1="5.715" x2="-2.775" y2="4.445" width="0.2032" layer="21"/>
<wire x1="4.5" y1="10.1" x2="4.5" y2="-10.1" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-10.1" x2="-4.5" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="2.2" x2="-4.5" y2="10.1" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="10.1" x2="4.4" y2="10.1" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-10.1" x2="-4.5" y2="-10.1" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="9" x2="3.4" y2="9" width="0.2032" layer="51"/>
<wire x1="3.4" y1="9" x2="3.4" y2="-9" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-9" x2="3.4" y2="-9" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="9" x2="-3.4" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-9" x2="-3.4" y2="-2.2" width="0.2032" layer="51"/>
<text x="-2.921" y="10.414" size="0.4064" layer="27" font="vector">&gt;VALUE</text>
<text x="-2.921" y="-10.922" size="0.4064" layer="25">&gt;NAME</text>
</package>
<package name="2X5-SHROUDED_LOCK">
<pad name="1" x="-1.397" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.397" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.397" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.397" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.397" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.397" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.397" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.397" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.397" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.397" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.921" y="-10.922" size="0.4064" layer="104">&gt;NAME</text>
<rectangle x1="-1.524" y1="4.826" x2="-1.016" y2="5.334" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="4.826" x2="1.524" y2="5.334" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="2.286" x2="1.524" y2="2.794" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="2.286" x2="-1.016" y2="2.794" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-2.794" x2="1.524" y2="-2.286" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-2.794" x2="-1.016" y2="-2.286" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-4.826" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-4.826" layer="51" rot="R270"/>
</package>
<package name="2X5-SHROUDED_SMD">
<smd name="1" x="-2.794" y="5.08" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="2" x="2.794" y="5.08" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="3" x="-2.794" y="2.54" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="4" x="2.794" y="2.54" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="5" x="-2.794" y="0" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="6" x="2.794" y="0" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="7" x="-2.794" y="-2.54" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="8" x="2.794" y="-2.54" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="9" x="-2.794" y="-5.08" dx="4.15" dy="1" layer="1" roundness="50"/>
<smd name="10" x="2.794" y="-5.08" dx="4.15" dy="1" layer="1" roundness="50"/>
</package>
<package name="BANANA_CONN">
<circle x="0" y="0" radius="2.8398" width="0.127" layer="21"/>
<pad name="P$1" x="0" y="0" drill="3.81" diameter="5.461"/>
</package>
<package name="BC9VPC">
<wire x1="0" y1="0" x2="0" y2="29.972" width="0.127" layer="21"/>
<wire x1="0" y1="29.972" x2="54.864" y2="29.972" width="0.127" layer="21"/>
<wire x1="54.864" y1="29.972" x2="54.864" y2="0" width="0.127" layer="21"/>
<wire x1="54.864" y1="0" x2="0" y2="0" width="0.127" layer="21"/>
<pad name="V+" x="53.086" y="21.336" drill="2.032" shape="square"/>
<pad name="V-" x="53.086" y="8.382" drill="2.032" shape="square"/>
<text x="49.276" y="20.828" size="1.27" layer="21">V+</text>
<text x="49.276" y="7.874" size="1.27" layer="21">V-</text>
<hole x="27.178" y="3.81" drill="2.286"/>
<hole x="13.716" y="26.162" drill="2.286"/>
<hole x="40.64" y="26.162" drill="2.286"/>
</package>
<package name="BNC">
<description>Fits Mouser Part#5227161</description>
<wire x1="-7.493" y1="-2.9718" x2="7.493" y2="-2.9718" width="0.127" layer="21"/>
<wire x1="7.493" y1="-2.9718" x2="7.493" y2="10.8712" width="0.127" layer="21"/>
<wire x1="7.493" y1="10.8712" x2="-7.493" y2="10.8712" width="0.127" layer="21"/>
<wire x1="-7.493" y1="10.8712" x2="-7.493" y2="-2.9718" width="0.127" layer="21"/>
<wire x1="-7.112" y1="10.8712" x2="-7.112" y2="19.8882" width="0.127" layer="51"/>
<wire x1="-7.112" y1="19.8882" x2="-6.604" y2="19.8882" width="0.127" layer="51"/>
<wire x1="-6.604" y1="19.8882" x2="6.604" y2="19.8882" width="0.127" layer="51"/>
<wire x1="6.604" y1="19.8882" x2="7.0866" y2="19.8882" width="0.127" layer="51"/>
<wire x1="7.0866" y1="19.8882" x2="7.112" y2="19.8882" width="0.127" layer="51"/>
<wire x1="7.112" y1="19.8882" x2="7.112" y2="10.8712" width="0.127" layer="51"/>
<wire x1="6.604" y1="19.8882" x2="6.604" y2="33.7312" width="0.127" layer="51"/>
<wire x1="6.604" y1="33.7312" x2="-6.604" y2="33.7312" width="0.127" layer="51"/>
<wire x1="-6.604" y1="33.7312" x2="-6.604" y2="19.8882" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="17.7546" x2="7.0866" y2="18.6182" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="16.4846" x2="7.0866" y2="17.3482" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="15.2146" x2="7.0866" y2="16.0782" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="13.9446" x2="7.0866" y2="14.8082" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="12.6746" x2="7.0866" y2="13.5382" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="11.4046" x2="7.0866" y2="12.2682" width="0.127" layer="51"/>
<wire x1="-7.0866" y1="19.0246" x2="7.0866" y2="19.8882" width="0.127" layer="51"/>
<circle x="0" y="30.48" radius="0.8179" width="0.127" layer="51"/>
<pad name="GND" x="-2.54" y="0" drill="0.8" shape="long" rot="R90"/>
<pad name="S" x="0" y="0" drill="0.8" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="5.08" drill="2.2"/>
<pad name="4" x="5.08" y="5.08" drill="2.2"/>
<text x="-6.35" y="8.89" size="0.4064" layer="25">&gt;NAME</text>
<text x="-6.35" y="7.62" size="0.4064" layer="27" rot="SR0">&gt;VALUE</text>
</package>
<package name="DB9">
<description>&lt;b&gt;SUB-D&lt;/b&gt;</description>
<wire x1="-8.128" y1="15.299" x2="-7.62" y2="15.807" width="0.2032" layer="51" curve="-90"/>
<wire x1="7.62" y1="15.807" x2="8.128" y2="15.299" width="0.2032" layer="51" curve="-90"/>
<wire x1="-15.4" y1="-2.8" x2="-15.4" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-15.4" y1="2.5426" x2="-15.4" y2="9.5" width="0.2032" layer="51"/>
<wire x1="15.4" y1="-2.8" x2="15.4" y2="2.54" width="0.2032" layer="21"/>
<wire x1="15.4" y1="2.54" x2="15.4" y2="9.5" width="0.2032" layer="51"/>
<wire x1="-8.128" y1="10.219" x2="-8.128" y2="15.299" width="0.2032" layer="51"/>
<wire x1="-8.763" y1="9.584" x2="-8.128" y2="10.219" width="0.2032" layer="51" curve="90"/>
<wire x1="-15.4" y1="9.5" x2="15.4" y2="9.5" width="0.2032" layer="51"/>
<wire x1="8.128" y1="10.219" x2="8.128" y2="15.299" width="0.2032" layer="51"/>
<wire x1="8.128" y1="10.219" x2="8.763" y2="9.584" width="0.2032" layer="51" curve="90"/>
<wire x1="-7.62" y1="15.807" x2="7.62" y2="15.807" width="0.2032" layer="51"/>
<wire x1="-15.4" y1="-2.8" x2="15.4" y2="-2.8" width="0.2032" layer="21"/>
<pad name="1" x="-5.54" y="-1.42" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="-2.77" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="3" x="0" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="4" x="2.77" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="5" x="5.54" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="6" x="-4.15" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="7" x="-1.38" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="8" x="1.38" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="9" x="4.15" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="G1" x="-12.5" y="0" drill="3.302" diameter="5.08"/>
<pad name="G2" x="12.5" y="0" drill="3.302" diameter="5.08"/>
<text x="-0.795" y="2.62" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.69" y="3.415" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DB9_MALE">
<pad name="5" x="-5.54" y="-1.42" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="4" x="-2.77" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="2" x="2.77" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="1" x="5.54" y="-1.42" drill="1.016" diameter="1.8796"/>
<pad name="9" x="-4.15" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="8" x="-1.38" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="7" x="1.38" y="1.42" drill="1.016" diameter="1.8796"/>
<pad name="6" x="4.15" y="1.42" drill="1.016" diameter="1.8796"/>
</package>
<package name="M25D">
<wire x1="-19.304" y1="7.253" x2="-19.812" y2="6.745" width="0.1524" layer="51" curve="90"/>
<wire x1="19.812" y1="6.745" x2="19.304" y2="7.253" width="0.1524" layer="51" curve="90"/>
<wire x1="19.812" y1="2.046" x2="19.812" y2="6.745" width="0.1524" layer="51"/>
<wire x1="19.812" y1="2.046" x2="20.447" y2="1.411" width="0.1524" layer="51" curve="90"/>
<wire x1="-19.812" y1="2.046" x2="-19.812" y2="6.745" width="0.1524" layer="51"/>
<wire x1="-20.447" y1="1.411" x2="-19.812" y2="2.046" width="0.1524" layer="51" curve="90"/>
<wire x1="-19.304" y1="7.253" x2="19.304" y2="7.253" width="0.1524" layer="51"/>
<wire x1="-24.6888" y1="-2.7432" x2="-23.3172" y2="-4.1148" width="0.254" layer="52"/>
<wire x1="-23.3172" y1="-4.1148" x2="-21.9456" y2="-2.7432" width="0.254" layer="52"/>
<wire x1="-21.9456" y1="-2.7432" x2="-20.574" y2="-4.1148" width="0.254" layer="52"/>
<wire x1="-20.574" y1="-4.1148" x2="-19.2024" y2="-2.7432" width="0.254" layer="52"/>
<wire x1="19.2024" y1="-2.7432" x2="20.574" y2="-4.1148" width="0.254" layer="52"/>
<wire x1="20.574" y1="-4.1148" x2="21.9456" y2="-2.7432" width="0.254" layer="52"/>
<wire x1="21.9456" y1="-2.7432" x2="23.3172" y2="-4.1148" width="0.254" layer="52"/>
<wire x1="23.3172" y1="-4.1148" x2="24.6888" y2="-2.7432" width="0.254" layer="52"/>
<wire x1="5.08" y1="3.669" x2="2.794" y2="3.669" width="0.1524" layer="51"/>
<wire x1="2.794" y1="3.669" x2="2.794" y2="5.955" width="0.1524" layer="51"/>
<wire x1="5.08" y1="5.955" x2="5.08" y2="3.669" width="0.1524" layer="51"/>
<wire x1="1.143" y1="3.669" x2="-1.143" y2="3.669" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="3.669" x2="-1.143" y2="5.955" width="0.1524" layer="51"/>
<wire x1="1.143" y1="5.955" x2="1.143" y2="3.669" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="3.669" x2="-5.08" y2="3.669" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="3.669" x2="-5.08" y2="5.955" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="5.955" x2="-2.794" y2="3.669" width="0.1524" layer="51"/>
<wire x1="-18.6436" y1="0.508" x2="-18.6436" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-18.6436" y1="0.508" x2="-18.5166" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-18.5166" y1="-1.905" x2="-17.8816" y2="-2.54" width="0.1524" layer="51" curve="90"/>
<wire x1="-18.5166" y1="-1.905" x2="-18.5166" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-17.901" y1="-2.54" x2="17.8816" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="17.8816" y1="-2.54" x2="17.901" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="18.6436" y1="0.508" x2="18.6436" y2="1.016" width="0.1524" layer="51"/>
<wire x1="18.5166" y1="-1.905" x2="18.5166" y2="0.508" width="0.1524" layer="51"/>
<wire x1="18.5166" y1="0.508" x2="18.6436" y2="0.508" width="0.1524" layer="51"/>
<wire x1="17.8816" y1="-2.54" x2="18.5166" y2="-1.905" width="0.1524" layer="51" curve="90"/>
<smd name="1" x="16.4594" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="2" x="13.716" y="-6.045" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="3" x="10.9726" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="4" x="8.2298" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="5" x="5.4862" y="-6.0446" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="6" x="2.7434" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="7" x="0" y="-6.045" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="8" x="-2.7434" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="9" x="-5.4862" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="10" x="-8.2298" y="-6.0446" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="11" x="-10.9726" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="12" x="-13.716" y="-6.045" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="13" x="-16.4594" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="14" x="15.0876" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="15" x="12.3444" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="16" x="9.6012" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="17" x="6.858" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="18" x="4.1148" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="19" x="1.3716" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="20" x="-1.3716" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="21" x="-4.1148" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="22" x="-6.858" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="23" x="-9.6012" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="24" x="-12.3444" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="25" x="-15.0876" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<text x="-5.08" y="-8.89" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="-8.89" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
<text x="16.0256" y="-2.1786" size="1.27" layer="51" ratio="10">1</text>
<text x="19.6596" y="-2.54" size="1.27" layer="52">Board</text>
<text x="-14.6606" y="-0.825" size="1.27" layer="52" ratio="10" rot="MR0">25</text>
<text x="-16.8606" y="-2.1786" size="1.27" layer="51" ratio="10">13</text>
<text x="15.6256" y="-0.825" size="1.27" layer="52" ratio="10" rot="MR0">14</text>
<text x="-17.2212" y="4.5974" size="1.27" layer="51" ratio="10">M25D</text>
<text x="-24.7396" y="-2.54" size="1.27" layer="52">Board </text>
<rectangle x1="-26.5" y1="0.9" x2="26.5" y2="1.4" layer="51"/>
<rectangle x1="-17.5" y1="-4.1" x2="17.5" y2="-2.5" layer="51"/>
</package>
<package name="M25H">
<wire x1="19.304" y1="-17.526" x2="19.05" y2="-17.526" width="0.1524" layer="21"/>
<wire x1="19.304" y1="-17.526" x2="19.812" y2="-17.018" width="0.1524" layer="21" curve="90"/>
<wire x1="-19.812" y1="-17.018" x2="-19.304" y2="-17.526" width="0.1524" layer="21" curve="90"/>
<wire x1="19.431" y1="-11.684" x2="-19.431" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-7.62" x2="21.463" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-7.62" x2="26.543" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-7.62" x2="26.543" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-10.668" x2="26.543" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-11.176" x2="26.543" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-11.684" x2="-26.543" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-11.176" x2="-26.543" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-10.668" x2="-26.543" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-7.62" x2="-26.543" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="21.463" y1="-10.668" x2="21.463" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="21.463" y1="-10.668" x2="21.336" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="20.701" y1="-7.62" x2="21.336" y2="-8.255" width="0.1524" layer="21" curve="-90"/>
<wire x1="21.463" y1="-7.62" x2="20.574" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="20.574" y1="-7.62" x2="20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="21.336" y1="-8.255" x2="21.336" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="20.32" y2="-6.858" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-6.858" x2="-20.32" y2="-6.858" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.62" x2="-20.32" y2="-6.858" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.62" x2="-20.574" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.574" y1="-7.62" x2="-21.463" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-10.668" x2="-21.463" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-21.336" y1="-8.255" x2="-21.336" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-21.336" y1="-10.668" x2="-21.463" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-21.336" y1="-8.255" x2="-20.701" y2="-7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="25.908" y1="3.175" x2="26.543" y2="2.54" width="0.1524" layer="21"/>
<wire x1="26.543" y1="2.54" x2="26.543" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="21.082" y1="3.175" x2="25.908" y2="3.175" width="0.1524" layer="21"/>
<wire x1="21.082" y1="3.175" x2="20.574" y2="2.667" width="0.1524" layer="21"/>
<wire x1="20.574" y1="2.667" x2="20.574" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.574" y1="2.667" x2="-20.574" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.574" y1="2.667" x2="-21.082" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="3.175" x2="-26.035" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-26.035" y1="3.175" x2="-26.543" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="2.667" x2="-26.543" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="-2.7686" y1="1.143" x2="-2.7686" y2="0.127" width="0.8128" layer="51"/>
<wire x1="0" y1="1.143" x2="0" y2="0.127" width="0.8128" layer="51"/>
<wire x1="2.7686" y1="1.143" x2="2.7686" y2="0.127" width="0.8128" layer="51"/>
<wire x1="1.3716" y1="-1.397" x2="1.3716" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="-1.3716" y1="-1.397" x2="-1.3716" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="-4.1402" y1="-1.397" x2="-4.1402" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="-5.5118" y1="1.143" x2="-5.5118" y2="0.127" width="0.8128" layer="51"/>
<wire x1="-6.9088" y1="-1.397" x2="-6.9088" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="-8.2804" y1="1.143" x2="-8.2804" y2="0.127" width="0.8128" layer="51"/>
<wire x1="-21.463" y1="-7.62" x2="-26.543" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-19.431" y1="-11.684" x2="-26.543" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.319" x2="-19.812" y2="-17.018" width="0.1524" layer="21"/>
<wire x1="-20.447" y1="-11.684" x2="-19.812" y2="-12.319" width="0.1524" layer="21" curve="-90"/>
<wire x1="26.543" y1="-11.684" x2="19.431" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.319" x2="19.812" y2="-17.018" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.319" x2="20.447" y2="-11.684" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="-1.3716" x2="-9.652" y2="-2.3876" width="0.8128" layer="51"/>
<wire x1="-11.049" y1="1.143" x2="-11.049" y2="0.127" width="0.8128" layer="51"/>
<wire x1="4.1402" y1="-1.397" x2="4.1402" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="5.5118" y1="1.143" x2="5.5118" y2="0.127" width="0.8128" layer="51"/>
<wire x1="6.9088" y1="-1.397" x2="6.9088" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="8.2804" y1="1.143" x2="8.2804" y2="0.127" width="0.8128" layer="51"/>
<wire x1="9.652" y1="-1.397" x2="9.652" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="11.049" y1="1.143" x2="11.049" y2="0.127" width="0.8128" layer="51"/>
<wire x1="13.7922" y1="1.143" x2="13.7922" y2="0.127" width="0.8128" layer="51"/>
<wire x1="12.4206" y1="-1.397" x2="12.4206" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="16.5608" y1="1.143" x2="16.5608" y2="0.127" width="0.1524" layer="51"/>
<wire x1="15.1892" y1="-1.397" x2="15.1892" y2="-2.413" width="0.8128" layer="51"/>
<wire x1="-13.7922" y1="1.143" x2="-13.7922" y2="0.127" width="0.8128" layer="51"/>
<wire x1="-12.4206" y1="-1.3716" x2="-12.4206" y2="-2.3876" width="0.8128" layer="51"/>
<wire x1="-15.1892" y1="-1.3716" x2="-15.1892" y2="-2.3876" width="0.8128" layer="51"/>
<wire x1="-16.5608" y1="1.143" x2="-16.5608" y2="0.127" width="0.8128" layer="51"/>
<wire x1="-19.05" y1="-17.526" x2="-19.304" y2="-17.526" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-17.526" x2="-19.05" y2="-17.526" width="0.1524" layer="21"/>
<circle x="23.5204" y="0" radius="1.651" width="0.1524" layer="21"/>
<circle x="23.5204" y="0" radius="2.667" width="0" layer="42"/>
<circle x="23.5204" y="0" radius="2.667" width="0" layer="43"/>
<circle x="-23.5204" y="0" radius="2.667" width="0" layer="42"/>
<circle x="-23.5204" y="0" radius="2.667" width="0" layer="43"/>
<circle x="-23.5204" y="0" radius="1.651" width="0.1524" layer="21"/>
<pad name="13" x="16.5608" y="1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="13.7922" y="1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="11.049" y="1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="8.2804" y="1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="5.5118" y="1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="2.7686" y="1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.7686" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.5118" y="1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.2804" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.049" y="1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-13.7922" y="1.27" drill="1.016" shape="octagon"/>
<pad name="1" x="-16.5608" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="15.1892" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="12.4206" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="9.652" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="6.9088" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="4.1402" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="1.3716" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.3716" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-4.1402" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-6.9088" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-9.652" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-12.4206" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-15.1892" y="-1.27" drill="1.016" shape="octagon"/>
<text x="-26.416" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-17.78" y="-20.447" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-18.669" y="0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="17.907" y="0.635" size="1.27" layer="21" ratio="10">13</text>
<text x="-19.812" y="-2.032" size="1.27" layer="21" ratio="10">14</text>
<text x="17.653" y="-1.905" size="1.27" layer="21" ratio="10">25</text>
<text x="-24.638" y="-6.858" size="1.27" layer="21" ratio="10" rot="R90">2,54</text>
<text x="-18.669" y="-9.779" size="1.27" layer="21" ratio="10">M25</text>
<rectangle x1="-26.543" y1="-11.684" x2="26.543" y2="-11.176" layer="21"/>
<rectangle x1="-20.32" y1="-7.62" x2="20.32" y2="-6.858" layer="21"/>
<rectangle x1="-16.9672" y1="-6.858" x2="-16.1544" y2="0.381" layer="21"/>
<rectangle x1="-15.5956" y1="-6.858" x2="-14.7828" y2="-2.159" layer="21"/>
<rectangle x1="-14.1986" y1="-6.858" x2="-13.3858" y2="0.381" layer="21"/>
<rectangle x1="-12.827" y1="-6.858" x2="-12.0142" y2="-2.159" layer="21"/>
<rectangle x1="-11.4554" y1="-6.858" x2="-10.6426" y2="0.381" layer="21"/>
<rectangle x1="-10.0584" y1="-6.858" x2="-9.2456" y2="-2.159" layer="21"/>
<rectangle x1="-8.6868" y1="-6.858" x2="-7.874" y2="0.381" layer="21"/>
<rectangle x1="-7.3152" y1="-6.858" x2="-6.5024" y2="-2.159" layer="21"/>
<rectangle x1="-5.9182" y1="-6.858" x2="-5.1054" y2="0.381" layer="21"/>
<rectangle x1="-4.5466" y1="-6.858" x2="-3.7338" y2="-2.159" layer="21"/>
<rectangle x1="-3.175" y1="-6.858" x2="-2.3622" y2="0.381" layer="21"/>
<rectangle x1="-1.778" y1="-6.858" x2="-0.9652" y2="-2.159" layer="21"/>
<rectangle x1="-0.4064" y1="-6.858" x2="0.4064" y2="0.381" layer="21"/>
<rectangle x1="0.9652" y1="-6.858" x2="1.778" y2="-2.159" layer="21"/>
<rectangle x1="2.3622" y1="-6.858" x2="3.175" y2="0.381" layer="21"/>
<rectangle x1="3.7338" y1="-6.858" x2="4.5466" y2="-2.159" layer="21"/>
<rectangle x1="5.1054" y1="-6.858" x2="5.9182" y2="0.381" layer="21"/>
<rectangle x1="6.5024" y1="-6.858" x2="7.3152" y2="-2.159" layer="21"/>
<rectangle x1="7.874" y1="-6.858" x2="8.6868" y2="0.381" layer="21"/>
<rectangle x1="9.2456" y1="-6.858" x2="10.0584" y2="-2.159" layer="21"/>
<rectangle x1="10.6426" y1="-6.858" x2="11.4554" y2="0.381" layer="21"/>
<rectangle x1="12.0142" y1="-6.858" x2="12.827" y2="-2.159" layer="21"/>
<rectangle x1="13.3858" y1="-6.858" x2="14.1986" y2="0.381" layer="21"/>
<rectangle x1="14.7828" y1="-6.858" x2="15.5956" y2="-2.159" layer="21"/>
<rectangle x1="16.1544" y1="-6.858" x2="16.9672" y2="0.381" layer="21"/>
<hole x="23.5204" y="0" drill="3.302"/>
<hole x="-23.5204" y="0" drill="3.302"/>
</package>
<package name="M25HP">
<wire x1="19.431" y1="-11.684" x2="19.431" y2="-17.018" width="0.1524" layer="21"/>
<wire x1="-19.431" y1="-11.684" x2="-19.431" y2="-17.018" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-10.668" x2="24.003" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="24.003" y1="-10.414" x2="21.463" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-11.176" x2="24.003" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="24.003" y1="-11.176" x2="21.463" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="24.003" y1="-10.668" x2="24.003" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="24.003" y1="-10.668" x2="24.003" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="21.463" y1="-10.414" x2="21.463" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-7.493" x2="21.463" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="21.463" y1="-7.493" x2="21.463" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="21.336" y1="-10.668" x2="-21.336" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-7.493" x2="-26.543" y2="-7.493" width="0.1524" layer="21"/>
<wire x1="-24.003" y1="-10.668" x2="-24.003" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-24.003" y1="-10.668" x2="-26.543" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-24.003" y1="-11.176" x2="-26.543" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-10.414" x2="-24.003" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-24.003" y1="-10.668" x2="-24.003" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="21.463" y1="-11.176" x2="-21.463" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-11.176" x2="-24.003" y2="-11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-10.414" x2="-21.463" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-13.97" x2="-2.794" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-13.97" x2="-2.794" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-16.256" x2="-3.175" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-16.256" x2="-3.175" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-14.351" x2="-4.699" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-14.351" x2="-4.699" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-16.256" x2="-5.08" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-16.256" x2="-5.08" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-13.97" x2="1.143" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-13.97" x2="1.143" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-16.256" x2="0.762" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-16.256" x2="0.762" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-14.351" x2="-0.762" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-14.351" x2="-0.762" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-16.256" x2="-1.143" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-16.256" x2="-1.143" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-13.97" x2="5.08" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-13.97" x2="5.08" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-16.256" x2="4.699" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-16.256" x2="4.699" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-14.351" x2="3.175" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-14.351" x2="3.175" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-16.256" x2="2.794" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-16.256" x2="2.794" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="-7.493" x2="-21.463" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-13.97" x2="-6.731" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-13.97" x2="-6.731" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-16.256" x2="-7.112" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="-16.256" x2="-7.112" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="-14.351" x2="-8.636" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-14.351" x2="-8.636" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-16.256" x2="-9.017" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-16.256" x2="-9.017" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-13.97" x2="9.017" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-13.97" x2="9.017" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-16.256" x2="8.636" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-16.256" x2="8.636" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-14.351" x2="7.112" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-14.351" x2="7.112" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="7.112" y1="-16.256" x2="6.731" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-16.256" x2="6.731" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="-13.97" x2="-10.668" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-10.668" y1="-13.97" x2="-10.668" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-10.668" y1="-16.256" x2="-11.049" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-16.256" x2="-11.049" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-14.351" x2="-12.573" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-14.351" x2="-12.573" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-16.256" x2="-12.954" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="-16.256" x2="-12.954" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="10.668" y1="-13.97" x2="12.954" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="12.954" y1="-13.97" x2="12.954" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="12.954" y1="-16.256" x2="12.573" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-16.256" x2="12.573" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-14.351" x2="11.049" y2="-14.351" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-14.351" x2="11.049" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-16.256" x2="10.668" y2="-16.256" width="0.1524" layer="21"/>
<wire x1="10.668" y1="-16.256" x2="10.668" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-19.05" y2="-17.526" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-12.192" x2="19.05" y2="-17.526" width="0.1524" layer="21"/>
<pad name="G1" x="-23.5204" y="0" drill="3.302" diameter="5.08"/>
<pad name="G2" x="23.5204" y="0" drill="3.302" diameter="5.08"/>
<rectangle x1="20.701" y1="-10.668" x2="20.955" y2="-8.255" layer="21"/>
<rectangle x1="-20.955" y1="-10.668" x2="-20.701" y2="-8.255" layer="21"/>
<rectangle x1="23.0632" y1="-7.62" x2="24.0792" y2="-5.969" layer="21"/>
<rectangle x1="-24.0792" y1="-7.62" x2="-23.0632" y2="-5.969" layer="21"/>
</package>
<package name="M25V">
<wire x1="-18.5674" y1="-2.9464" x2="-19.3548" y2="2.3368" width="0.1524" layer="21"/>
<wire x1="17.272" y1="-3.937" x2="18.5807" y2="-2.905" width="0.1524" layer="21" curve="76.489196" cap="flat"/>
<wire x1="18.034" y1="3.937" x2="19.3495" y2="2.3038" width="0.1524" layer="21" curve="-102.298925" cap="flat"/>
<wire x1="19.3548" y1="2.3114" x2="18.5674" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="3.937" x2="18.034" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-19.3541" y1="2.3268" x2="-18.034" y2="3.937" width="0.1524" layer="21" curve="-101.30773" cap="flat"/>
<wire x1="-18.5749" y1="-2.9295" x2="-17.272" y2="-3.937" width="0.1524" layer="21" curve="75.428151" cap="flat"/>
<wire x1="-17.272" y1="-3.937" x2="17.272" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.223" x2="-23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.223" x2="-21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.096" x2="-21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.096" x2="-21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.223" x2="21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-25.908" y1="-6.223" x2="-23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-5.588" x2="-25.908" y2="-6.223" width="0.1524" layer="21" curve="90"/>
<wire x1="25.908" y1="-6.223" x2="26.543" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="25.908" y1="6.223" x2="23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="26.543" y1="5.588" x2="26.543" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="25.908" y1="6.223" x2="26.543" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-26.543" y1="5.588" x2="-26.543" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="5.588" x2="-25.908" y2="6.223" width="0.1524" layer="21" curve="-90"/>
<wire x1="21.209" y1="-6.223" x2="21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="-6.223" x2="23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="-6.096" x2="23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.096" x2="23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.223" x2="25.908" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.223" x2="21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.223" x2="-21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.096" x2="23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.096" x2="23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.223" x2="21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.223" x2="-23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.223" x2="-25.908" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.096" x2="-21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.096" x2="-21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.223" x2="-23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="4.318" x2="18.034" y2="4.318" width="0.1524" layer="21"/>
<wire x1="19.7358" y1="2.3114" x2="18.9738" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="18.034" y1="4.318" x2="19.728" y2="2.2521" width="0.1524" layer="21" curve="-101.297755" cap="flat"/>
<wire x1="-18.9484" y1="-2.9464" x2="-19.7358" y2="2.3368" width="0.1524" layer="21"/>
<wire x1="-19.7277" y1="2.2521" x2="-18.034" y2="4.318" width="0.1524" layer="21" curve="-101.307706" cap="flat"/>
<wire x1="-17.272" y1="-4.318" x2="17.272" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-18.984" y1="-2.8191" x2="-17.272" y2="-4.318" width="0.1524" layer="21" curve="82.402958" cap="flat"/>
<wire x1="17.272" y1="-4.318" x2="18.9963" y2="-2.6849" width="0.1524" layer="21" curve="86.865803" cap="flat"/>
<circle x="-23.5204" y="-0.0254" radius="1.651" width="0.1524" layer="21"/>
<circle x="-2.7686" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-4.1402" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-5.5118" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="0" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-1.3716" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="1.3716" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="2.7686" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="5.5118" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="4.1402" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="6.9088" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="8.2804" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="9.652" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="11.049" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="12.4206" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="13.7922" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="16.5608" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="15.1892" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-8.2804" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-6.9088" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-9.652" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-11.049" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-13.7922" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-16.5608" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-12.4206" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-15.1892" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<pad name="13" x="16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="-13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="1" x="-16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="25" x="15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="24" x="12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="23" x="9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="22" x="6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="21" x="4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="20" x="1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="18" x="-4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="17" x="-6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="16" x="-9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="-12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="-15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<text x="-26.289" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="6.985" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.764" y="2.413" size="0.9906" layer="21" ratio="12">1</text>
<text x="-14.097" y="2.413" size="0.9906" layer="21" ratio="12">2</text>
<text x="-11.43" y="2.413" size="0.9906" layer="21" ratio="12">3</text>
<text x="-8.763" y="2.413" size="0.9906" layer="21" ratio="12">4</text>
<text x="-5.969" y="2.413" size="0.9906" layer="21" ratio="12">5</text>
<text x="-3.175" y="2.413" size="0.9906" layer="21" ratio="12">6</text>
<text x="-0.381" y="2.413" size="0.9906" layer="21" ratio="12">7</text>
<text x="2.413" y="2.413" size="0.9906" layer="21" ratio="12">8</text>
<text x="5.08" y="2.413" size="0.9906" layer="21" ratio="12">9</text>
<text x="7.62" y="2.413" size="0.9906" layer="21" ratio="12">10</text>
<text x="10.287" y="2.413" size="0.9906" layer="21" ratio="12">11</text>
<text x="12.954" y="2.413" size="0.9906" layer="21" ratio="12">12</text>
<text x="15.875" y="2.413" size="0.9906" layer="21" ratio="12">13</text>
<text x="-16.002" y="-3.429" size="0.9906" layer="21" ratio="12">14</text>
<text x="-13.208" y="-3.429" size="0.9906" layer="21" ratio="12">15</text>
<text x="-10.414" y="-3.429" size="0.9906" layer="21" ratio="12">16</text>
<text x="-7.747" y="-3.429" size="0.9906" layer="21" ratio="12">17</text>
<text x="-5.08" y="-3.429" size="0.9906" layer="21" ratio="12">18</text>
<text x="-2.159" y="-3.429" size="0.9906" layer="21" ratio="12">19</text>
<text x="0.508" y="-3.429" size="0.9906" layer="21" ratio="12">20</text>
<text x="3.302" y="-3.429" size="0.9906" layer="21" ratio="12">21</text>
<text x="6.096" y="-3.429" size="0.9906" layer="21" ratio="12">22</text>
<text x="8.89" y="-3.429" size="0.9906" layer="21" ratio="12">23</text>
<text x="11.557" y="-3.429" size="0.9906" layer="21" ratio="12">24</text>
<text x="14.351" y="-3.429" size="0.9906" layer="21" ratio="12">25</text>
</package>
<package name="M25VP">
</package>
<package name="M25VB">
<wire x1="18.5674" y1="2.9464" x2="19.3548" y2="-2.3368" width="0.1524" layer="21"/>
<wire x1="-18.5807" y1="2.905" x2="-17.272" y2="3.937" width="0.1524" layer="21" curve="-76.489196" cap="flat"/>
<wire x1="-19.3495" y1="-2.3038" x2="-18.034" y2="-3.937" width="0.1524" layer="21" curve="102.298925" cap="flat"/>
<wire x1="-19.3548" y1="-2.3114" x2="-18.5674" y2="2.921" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-3.937" x2="-18.034" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-3.937" x2="19.3541" y2="-2.3268" width="0.1524" layer="21" curve="101.30773" cap="flat"/>
<wire x1="17.272" y1="3.937" x2="18.5749" y2="2.9295" width="0.1524" layer="21" curve="-75.428151" cap="flat"/>
<wire x1="17.272" y1="3.937" x2="-17.272" y2="3.937" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.223" x2="23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="6.096" x2="21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="6.096" x2="21.209" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-5.588" x2="-26.543" y2="5.588" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-5.588" x2="26.543" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.223" x2="-21.209" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="6.096" x2="-23.749" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="6.096" x2="-23.749" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.223" x2="-21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-6.096" x2="-23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-23.749" y1="-6.096" x2="-23.749" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.223" x2="23.749" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="23.749" y1="-6.096" x2="21.209" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="21.209" y1="-6.096" x2="21.209" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-4.318" x2="-18.034" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-19.7358" y1="-2.3114" x2="-18.9738" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-19.728" y1="-2.2521" x2="-18.034" y2="-4.318" width="0.1524" layer="21" curve="101.297755" cap="flat"/>
<wire x1="18.9484" y1="2.9464" x2="19.7358" y2="-2.3368" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-4.318" x2="19.7277" y2="-2.2521" width="0.1524" layer="21" curve="101.307706" cap="flat"/>
<wire x1="17.272" y1="4.318" x2="-17.272" y2="4.318" width="0.1524" layer="21"/>
<wire x1="17.272" y1="4.318" x2="18.984" y2="2.8191" width="0.1524" layer="21" curve="-82.402958" cap="flat"/>
<wire x1="-18.9963" y1="2.6849" x2="-17.272" y2="4.318" width="0.1524" layer="21" curve="-86.865803" cap="flat"/>
<circle x="2.7686" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="4.1402" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="5.5118" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="0" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="1.3716" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-1.3716" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-2.7686" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-5.5118" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-4.1402" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-6.9088" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-8.2804" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-9.652" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-11.049" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-12.4206" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-13.7922" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-16.5608" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="-15.1892" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="8.2804" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="6.9088" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="9.652" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="11.049" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="13.7922" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="16.5608" y="-1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="12.4206" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<circle x="15.1892" y="1.4224" radius="0.254" width="0.4064" layer="51"/>
<pad name="13" x="-16.5608" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="-13.7922" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.049" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="-8.2804" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="-5.5118" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="-2.7686" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="2.7686" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="5.5118" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="8.2804" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="11.049" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="13.7922" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="1" x="16.5608" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="25" x="-15.1892" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="24" x="-12.4206" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="23" x="-9.652" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="22" x="-6.9088" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="21" x="-4.1402" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="19" x="1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="18" x="4.1402" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="17" x="6.9088" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="16" x="9.652" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="12.4206" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="15.1892" y="1.4224" drill="1.016" shape="octagon"/>
<text x="16.764" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">1</text>
<text x="14.097" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">2</text>
<text x="11.43" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">3</text>
<text x="8.763" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">4</text>
<text x="5.969" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">5</text>
<text x="3.175" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">6</text>
<text x="0.381" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">7</text>
<text x="-2.413" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">8</text>
<text x="-5.08" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">9</text>
<text x="-7.62" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">10</text>
<text x="-10.287" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">11</text>
<text x="-12.954" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">12</text>
<text x="-15.875" y="-2.413" size="0.9906" layer="21" ratio="12" rot="R180">13</text>
<text x="16.002" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">14</text>
<text x="13.208" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">15</text>
<text x="10.414" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">16</text>
<text x="7.747" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">17</text>
<text x="5.08" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">18</text>
<text x="2.159" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">19</text>
<text x="-0.508" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">20</text>
<text x="-3.302" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">21</text>
<text x="-6.096" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">22</text>
<text x="-8.89" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">23</text>
<text x="-11.557" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">24</text>
<text x="-14.351" y="3.429" size="0.9906" layer="21" ratio="12" rot="R180">25</text>
</package>
<package name="DIN7">
<wire x1="-7.5" y1="1.8" x2="7.5" y2="1.8" width="0.127" layer="21"/>
<wire x1="7.5" y1="1.8" x2="7.5" y2="0.85" width="0.127" layer="21"/>
<wire x1="-7.5" y1="1.8" x2="-7.5" y2="0.85" width="0.127" layer="21"/>
<wire x1="-7.5" y1="-8.3" x2="7.5" y2="-8.3" width="0.127" layer="21"/>
<wire x1="7.5" y1="-8.3" x2="7.5" y2="-2.45" width="0.127" layer="21"/>
<wire x1="-7.5" y1="-8.3" x2="-7.5" y2="-2.45" width="0.127" layer="21"/>
<pad name="P$1" x="0" y="0" drill="2.2"/>
<pad name="P$2" x="-6.75" y="-0.8" drill="2.2"/>
<pad name="P$3" x="6.75" y="-0.8" drill="2.2"/>
<pad name="2" x="-1.3" y="-3.8" drill="0.9"/>
<pad name="1" x="1.3" y="-3.8" drill="0.9"/>
<pad name="3" x="-3.4" y="-3.8" drill="0.9"/>
<pad name="4" x="3.4" y="-3.8" drill="0.9"/>
<pad name="5" x="-3.4" y="-6.3" drill="0.9"/>
<pad name="6" x="0.9" y="-6.3" drill="0.9"/>
<pad name="7" x="3.4" y="-6.3" drill="0.9"/>
</package>
<package name="DS_TOUCH_CONNECTOR">
<description>4-pin DS touch screen connector</description>
<wire x1="-4.25" y1="-2.23" x2="-4.25" y2="-2.8" width="0.127" layer="21"/>
<wire x1="-4.25" y1="-2.8" x2="4.25" y2="-2.8" width="0.127" layer="21"/>
<wire x1="4.25" y1="-2.23" x2="4.25" y2="-2.8" width="0.127" layer="21"/>
<smd name="3" x="-0.25" y="2.45" dx="1.5" dy="0.3" layer="1" rot="R90"/>
<smd name="2" x="0.25" y="2.45" dx="1.5" dy="0.3" layer="1" rot="R90"/>
<smd name="1" x="0.75" y="2.45" dx="1.5" dy="0.3" layer="1" rot="R90"/>
<smd name="4" x="-0.75" y="2.45" dx="1.5" dy="0.3" layer="1" rot="R90"/>
<smd name="P$5" x="-2.525" y="0.7" dx="1.85" dy="2.6" layer="1"/>
<smd name="P$6" x="2.525" y="0.7" dx="1.85" dy="2.6" layer="1"/>
<text x="-3.895" y="-3.485" size="0.4" layer="25">&gt;NAME</text>
<text x="-3.915" y="-2.5" size="0.4" layer="27">&gt;VALUE</text>
</package>
<package name="EB-85A">
<wire x1="0" y1="-4.25" x2="7" y2="-4.25" width="0.254" layer="21"/>
<wire x1="-1" y1="-2" x2="-1" y2="0" width="0.254" layer="21"/>
<wire x1="7.625" y1="0" x2="8" y2="0" width="0.254" layer="21"/>
<wire x1="8" y1="0" x2="8" y2="-2" width="0.254" layer="21"/>
<wire x1="-1" y1="0" x2="-0.6" y2="0" width="0.254" layer="21"/>
<smd name="P$1" x="-1.3" y="-3.775" dx="1.2" dy="2" layer="1"/>
<smd name="P$2" x="8.3" y="-3.775" dx="1.2" dy="2" layer="1"/>
<smd name="1" x="0" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="2" x="1" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="3" x="2" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="4" x="3" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="5" x="4" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="6" x="5" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="7" x="6" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="8" x="7" y="0" dx="0.6" dy="1.55" layer="1"/>
<text x="0" y="1.27" size="0.4064" layer="25">&gt;Name</text>
<text x="3.81" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="EM406">
<wire x1="0" y1="-2.921" x2="5.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="-1.778" y1="-0.762" x2="-1.778" y2="0.635" width="0.254" layer="21"/>
<wire x1="5.842" y1="0.635" x2="6.858" y2="0.635" width="0.254" layer="21"/>
<wire x1="6.858" y1="0.635" x2="6.858" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-0.762" y2="0.635" width="0.254" layer="21"/>
<circle x="0" y="1.27" radius="0.1047" width="0.4064" layer="21"/>
<smd name="P$1" x="-1.3" y="-2.225" dx="1.2" dy="1.8" layer="1"/>
<smd name="P$2" x="6.3" y="-2.225" dx="1.2" dy="1.8" layer="1"/>
<text x="1.27" y="1.27" size="0.4064" layer="25">&gt;Name</text>
<text x="1.27" y="-3.81" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="EM408_CON">
<wire x1="0" y1="-2.921" x2="4.08" y2="-2.921" width="0.254" layer="21"/>
<wire x1="4.842" y1="0.635" x2="5.858" y2="0.635" width="0.254" layer="21"/>
<wire x1="5.858" y1="0.635" x2="5.858" y2="-0.762" width="0.254" layer="21"/>
<smd name="P$2" x="5.3" y="-2.225" dx="1.2" dy="1.8" layer="1"/>
<smd name="5" x="0" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="4" x="1" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="2" x="3" y="0" dx="0.6" dy="1.55" layer="1"/>
<smd name="1" x="4" y="0" dx="0.6" dy="1.55" layer="1"/>
<text x="-1.27" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="2.54" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="F25D">
<wire x1="-19.177" y1="6.9342" x2="-18.669" y2="7.4422" width="0.1524" layer="51" curve="-90"/>
<wire x1="18.542" y1="7.4422" x2="19.05" y2="6.9342" width="0.1524" layer="51" curve="-90"/>
<wire x1="-19.177" y1="1.8542" x2="-19.177" y2="6.9342" width="0.1524" layer="51"/>
<wire x1="-19.812" y1="1.2192" x2="-19.177" y2="1.8542" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="19.05" y1="1.8542" x2="19.05" y2="6.9342" width="0.1524" layer="51"/>
<wire x1="19.05" y1="1.8542" x2="19.685" y2="1.2192" width="0.1524" layer="51" curve="90" cap="flat"/>
<wire x1="-18.669" y1="7.4422" x2="18.542" y2="7.4422" width="0.1524" layer="51"/>
<wire x1="-17.901" y1="-2.54" x2="17.901" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-24.6888" y1="-2.7432" x2="-23.3172" y2="-4.1148" width="0" layer="48"/>
<wire x1="-23.3172" y1="-4.1148" x2="-21.9456" y2="-2.7432" width="0" layer="48"/>
<wire x1="-21.9456" y1="-2.7432" x2="-20.574" y2="-4.1148" width="0" layer="48"/>
<wire x1="-20.574" y1="-4.1148" x2="-19.2024" y2="-2.7432" width="0" layer="48"/>
<wire x1="19.2024" y1="-2.7432" x2="20.574" y2="-4.1148" width="0" layer="48"/>
<wire x1="20.574" y1="-4.1148" x2="21.9456" y2="-2.7432" width="0" layer="48"/>
<wire x1="21.9456" y1="-2.7432" x2="23.3172" y2="-4.1148" width="0" layer="48"/>
<wire x1="23.3172" y1="-4.1148" x2="24.6888" y2="-2.7432" width="0" layer="48"/>
<smd name="1" x="-16.4594" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="2" x="-13.716" y="-6.045" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="3" x="-10.9726" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="4" x="-8.2298" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="5" x="-5.4862" y="-6.0446" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="6" x="-2.7434" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="8" x="2.7434" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="14" x="-15.0876" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="9" x="5.4862" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="10" x="8.2298" y="-6.0446" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="11" x="10.9726" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="12" x="13.716" y="-6.045" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="13" x="16.4594" y="-6.0448" dx="1.7" dy="3.5" layer="1" cream="no"/>
<smd name="15" x="-12.3444" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="16" x="-9.6012" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="17" x="-6.858" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="18" x="-4.1148" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="19" x="-1.3716" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="20" x="1.3716" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="21" x="4.1148" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="22" x="6.858" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="23" x="9.6012" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="24" x="12.3444" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<smd name="25" x="15.0876" y="-6.0452" dx="1.7" dy="3.5" layer="16" cream="no"/>
<text x="-6.35" y="-8.89" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-8.89" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.8928" y="-2.1786" size="1.27" layer="51" ratio="10">1</text>
<text x="19.6596" y="-2.54" size="1.27" layer="48">Board</text>
<text x="-17.2212" y="4.5974" size="1.27" layer="51" ratio="10">F25D</text>
<text x="15.5578" y="-2.0786" size="1.27" layer="51" ratio="10">13</text>
<text x="15.9146" y="-0.825" size="1.27" layer="22" ratio="10" rot="MR0">25</text>
<text x="-14.0496" y="-0.825" size="1.27" layer="22" ratio="10" rot="MR0">14</text>
<text x="-24.7396" y="-2.54" size="1.27" layer="48">Board </text>
<rectangle x1="-17.0592" y1="-6.56" x2="-15.8592" y2="-4.06" layer="51"/>
<rectangle x1="-15.6876" y1="-6.56" x2="-14.4876" y2="-4.06" layer="52"/>
<rectangle x1="-12.9444" y1="-6.56" x2="-11.7444" y2="-4.06" layer="52"/>
<rectangle x1="-10.2012" y1="-6.56" x2="-9.0012" y2="-4.06" layer="52"/>
<rectangle x1="-14.316" y1="-6.56" x2="-13.116" y2="-4.06" layer="51"/>
<rectangle x1="-11.5728" y1="-6.56" x2="-10.3728" y2="-4.06" layer="51"/>
<rectangle x1="-8.8296" y1="-6.56" x2="-7.6296" y2="-4.06" layer="51"/>
<rectangle x1="-6.0864" y1="-6.56" x2="-4.8864" y2="-4.06" layer="51"/>
<rectangle x1="-7.458" y1="-6.56" x2="-6.258" y2="-4.06" layer="52"/>
<rectangle x1="-4.7148" y1="-6.56" x2="-3.5148" y2="-4.06" layer="52"/>
<rectangle x1="-1.9716" y1="-6.56" x2="-0.7716" y2="-4.06" layer="52"/>
<rectangle x1="0.7716" y1="-6.56" x2="1.9716" y2="-4.06" layer="52"/>
<rectangle x1="-3.3432" y1="-6.56" x2="-2.1432" y2="-4.06" layer="51"/>
<rectangle x1="-0.6" y1="-6.56" x2="0.6" y2="-4.06" layer="51"/>
<rectangle x1="2.1432" y1="-6.56" x2="3.3432" y2="-4.06" layer="51"/>
<rectangle x1="-26.6" y1="0.7" x2="26.6" y2="1.3" layer="51"/>
<rectangle x1="-17.4" y1="-4.1" x2="17.4" y2="-2.5" layer="51"/>
<rectangle x1="3.5148" y1="-6.56" x2="4.7148" y2="-4.06" layer="52"/>
<rectangle x1="4.8864" y1="-6.56" x2="6.0864" y2="-4.06" layer="51"/>
<rectangle x1="7.6296" y1="-6.56" x2="8.8296" y2="-4.06" layer="51"/>
<rectangle x1="6.258" y1="-6.56" x2="7.458" y2="-4.06" layer="52"/>
<rectangle x1="9.0012" y1="-6.56" x2="10.2012" y2="-4.06" layer="52"/>
<rectangle x1="11.7444" y1="-6.56" x2="12.9444" y2="-4.06" layer="52"/>
<rectangle x1="10.3728" y1="-6.56" x2="11.5728" y2="-4.06" layer="51"/>
<rectangle x1="13.116" y1="-6.56" x2="14.316" y2="-4.06" layer="51"/>
<rectangle x1="14.4876" y1="-6.56" x2="15.6876" y2="-4.06" layer="52"/>
<rectangle x1="15.8592" y1="-6.56" x2="17.0592" y2="-4.06" layer="51"/>
</package>
<package name="F25H">
<wire x1="-18.669" y1="17.907" x2="-18.415" y2="17.907" width="0.1524" layer="21"/>
<wire x1="-19.177" y1="17.399" x2="-18.669" y2="17.907" width="0.1524" layer="21" curve="-90"/>
<wire x1="18.669" y1="17.907" x2="19.177" y2="17.399" width="0.1524" layer="21" curve="-90"/>
<wire x1="-18.796" y1="11.684" x2="18.796" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="7.62" x2="-21.463" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="7.62" x2="-26.543" y2="10.668" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="7.62" x2="-26.543" y2="7.493" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="10.668" x2="-26.543" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="11.176" x2="-26.543" y2="11.684" width="0.1524" layer="21"/>
<wire x1="26.543" y1="11.684" x2="26.543" y2="11.176" width="0.1524" layer="21"/>
<wire x1="26.543" y1="11.176" x2="26.543" y2="10.668" width="0.1524" layer="21"/>
<wire x1="26.543" y1="10.668" x2="26.543" y2="7.62" width="0.1524" layer="21"/>
<wire x1="26.543" y1="7.62" x2="26.543" y2="7.493" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="11.176" x2="-24.003" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-24.003" y1="11.176" x2="-21.463" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="10.414" x2="-21.463" y2="10.668" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="10.668" x2="-21.463" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="10.668" x2="-21.336" y2="10.668" width="0.1524" layer="21"/>
<wire x1="-21.336" y1="8.255" x2="-20.701" y2="7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-21.463" y1="7.62" x2="-20.574" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-20.574" y1="7.62" x2="-20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-21.336" y1="8.255" x2="-21.336" y2="10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.62" x2="-20.32" y2="6.858" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="6.858" x2="20.32" y2="6.858" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.32" y2="6.858" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.574" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.574" y1="7.62" x2="21.463" y2="7.62" width="0.1524" layer="21"/>
<wire x1="24.003" y1="11.176" x2="26.543" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-21.463" y1="11.176" x2="21.463" y2="11.176" width="0.1524" layer="21"/>
<wire x1="21.463" y1="11.176" x2="24.003" y2="11.176" width="0.1524" layer="21"/>
<wire x1="21.463" y1="10.414" x2="21.463" y2="10.668" width="0.1524" layer="21"/>
<wire x1="21.463" y1="10.668" x2="21.463" y2="11.176" width="0.1524" layer="21"/>
<wire x1="21.336" y1="8.255" x2="21.336" y2="10.668" width="0.1524" layer="21"/>
<wire x1="21.336" y1="10.668" x2="21.463" y2="10.668" width="0.1524" layer="21"/>
<wire x1="20.701" y1="7.62" x2="21.336" y2="8.255" width="0.1524" layer="21" curve="90"/>
<wire x1="-25.908" y1="-3.175" x2="-26.543" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="-2.54" x2="-26.543" y2="7.493" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-3.175" x2="-25.908" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-3.175" x2="-20.574" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-20.574" y1="-2.667" x2="-20.574" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.574" y1="-2.667" x2="20.574" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.574" y1="-2.667" x2="21.082" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="21.082" y1="-3.175" x2="26.035" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="26.035" y1="-3.175" x2="26.543" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="26.543" y1="-2.667" x2="26.543" y2="7.493" width="0.1524" layer="21"/>
<wire x1="-2.7686" y1="-1.143" x2="-2.7686" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="-8.2804" y1="-1.143" x2="-8.2804" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="-11.049" y1="-1.143" x2="-11.049" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="-9.652" y1="1.397" x2="-9.652" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-6.9088" y1="1.397" x2="-6.9088" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-1.3716" y1="1.397" x2="-1.3716" y2="2.413" width="0.8128" layer="51"/>
<wire x1="2.7686" y1="-1.143" x2="2.7686" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="6.8834" y1="1.397" x2="6.8834" y2="2.413" width="0.8128" layer="51"/>
<wire x1="8.2804" y1="-1.143" x2="8.2804" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="4.1402" y1="1.397" x2="4.1402" y2="2.413" width="0.8128" layer="51"/>
<wire x1="5.5118" y1="-1.143" x2="5.5118" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="1.3716" y1="1.397" x2="1.3716" y2="2.413" width="0.8128" layer="51"/>
<wire x1="0" y1="-1.143" x2="0" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="-4.1402" y1="1.397" x2="-4.1402" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-5.5118" y1="-1.143" x2="-5.5118" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="21.463" y1="7.62" x2="26.543" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-26.543" y1="11.684" x2="-18.796" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.177" y1="12.319" x2="-19.177" y2="17.399" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.684" x2="-19.177" y2="12.319" width="0.1524" layer="21" curve="90"/>
<wire x1="18.796" y1="11.684" x2="26.543" y2="11.684" width="0.1524" layer="21"/>
<wire x1="19.177" y1="12.319" x2="19.177" y2="17.399" width="0.1524" layer="21"/>
<wire x1="19.177" y1="12.319" x2="19.812" y2="11.684" width="0.1524" layer="21" curve="90"/>
<wire x1="-12.4206" y1="1.397" x2="-12.4206" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-15.1892" y1="1.397" x2="-15.1892" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-13.7922" y1="-1.143" x2="-13.7922" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="-16.5608" y1="-1.143" x2="-16.5608" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="9.652" y1="1.397" x2="9.652" y2="2.413" width="0.8128" layer="51"/>
<wire x1="11.049" y1="-1.143" x2="11.049" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="13.7922" y1="-1.143" x2="13.7922" y2="-0.127" width="0.8128" layer="51"/>
<wire x1="16.5608" y1="-1.143" x2="16.5608" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="12.4206" y1="1.397" x2="12.4206" y2="2.413" width="0.8128" layer="51"/>
<wire x1="15.1892" y1="1.397" x2="15.1892" y2="2.413" width="0.8128" layer="51"/>
<wire x1="-18.415" y1="17.907" x2="18.415" y2="17.907" width="0.1524" layer="21"/>
<wire x1="18.415" y1="17.907" x2="18.669" y2="17.907" width="0.1524" layer="21"/>
<pad name="1" x="-16.5608" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="2" x="-13.7922" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.049" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.2804" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.5118" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.7686" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="7" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="8" x="2.7686" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="9" x="5.5118" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="10" x="8.2804" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="11" x="11.049" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="12" x="13.7922" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="13" x="16.5608" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="14" x="-15.1892" y="1.27" drill="1.016" shape="octagon"/>
<pad name="15" x="-12.4206" y="1.27" drill="1.016" shape="octagon"/>
<pad name="16" x="-9.652" y="1.27" drill="1.016" shape="octagon"/>
<pad name="17" x="-6.9088" y="1.27" drill="1.016" shape="octagon"/>
<pad name="18" x="-4.1402" y="1.27" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.3716" y="1.27" drill="1.016" shape="octagon"/>
<pad name="20" x="1.3716" y="1.27" drill="1.016" shape="octagon"/>
<pad name="21" x="4.1402" y="1.27" drill="1.016" shape="octagon"/>
<pad name="22" x="6.9088" y="1.27" drill="1.016" shape="octagon"/>
<pad name="23" x="9.652" y="1.27" drill="1.016" shape="octagon"/>
<pad name="24" x="12.4206" y="1.27" drill="1.016" shape="octagon"/>
<pad name="25" x="15.1892" y="1.27" drill="1.016" shape="octagon"/>
<text x="-26.289" y="-6.35" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.382" y="13.97" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-18.669" y="-1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="17.78" y="-1.905" size="1.27" layer="21" ratio="10">13</text>
<text x="-19.558" y="0.635" size="1.27" layer="21" ratio="10">14</text>
<text x="17.78" y="0.635" size="1.27" layer="21" ratio="10">25</text>
<text x="26.035" y="2.54" size="1.27" layer="21" ratio="10" rot="R90">2,54</text>
<text x="-18.669" y="8.509" size="1.27" layer="21" ratio="10">F25</text>
<rectangle x1="-20.32" y1="6.858" x2="20.32" y2="7.62" layer="21"/>
<rectangle x1="-26.543" y1="11.176" x2="26.543" y2="11.684" layer="21"/>
<rectangle x1="-16.9672" y1="-0.381" x2="-16.1544" y2="6.858" layer="21"/>
<rectangle x1="-15.5956" y1="2.159" x2="-14.7828" y2="6.858" layer="21"/>
<rectangle x1="-14.1986" y1="-0.381" x2="-13.3858" y2="6.858" layer="21"/>
<rectangle x1="-12.827" y1="2.159" x2="-12.0142" y2="6.858" layer="21"/>
<rectangle x1="-11.4554" y1="-0.381" x2="-10.6426" y2="6.858" layer="21"/>
<rectangle x1="-10.0584" y1="2.159" x2="-9.2456" y2="6.858" layer="21"/>
<rectangle x1="-8.6868" y1="-0.381" x2="-7.874" y2="6.858" layer="21"/>
<rectangle x1="-7.3152" y1="2.159" x2="-6.5024" y2="6.858" layer="21"/>
<rectangle x1="-5.9182" y1="-0.381" x2="-5.1054" y2="6.858" layer="21"/>
<rectangle x1="-4.5466" y1="2.159" x2="-3.7338" y2="6.858" layer="21"/>
<rectangle x1="-3.175" y1="-0.381" x2="-2.3622" y2="6.858" layer="21"/>
<rectangle x1="-1.778" y1="2.159" x2="-0.9652" y2="6.858" layer="21"/>
<rectangle x1="-0.4064" y1="-0.381" x2="0.4064" y2="6.858" layer="21"/>
<rectangle x1="0.9652" y1="2.159" x2="1.778" y2="6.858" layer="21"/>
<rectangle x1="2.3622" y1="-0.381" x2="3.175" y2="6.858" layer="21"/>
<rectangle x1="3.7338" y1="2.159" x2="4.5466" y2="6.858" layer="21"/>
<rectangle x1="5.1054" y1="-0.381" x2="5.9182" y2="6.858" layer="21"/>
<rectangle x1="6.477" y1="2.159" x2="7.2898" y2="6.858" layer="21"/>
<rectangle x1="7.874" y1="-0.381" x2="8.6868" y2="6.858" layer="21"/>
<rectangle x1="9.2456" y1="2.159" x2="10.0584" y2="6.858" layer="21"/>
<rectangle x1="10.6426" y1="-0.381" x2="11.4554" y2="6.858" layer="21"/>
<rectangle x1="12.0142" y1="2.159" x2="12.827" y2="6.858" layer="21"/>
<rectangle x1="13.3858" y1="-0.381" x2="14.1986" y2="6.858" layer="21"/>
<rectangle x1="14.7828" y1="2.159" x2="15.5956" y2="6.858" layer="21"/>
<rectangle x1="16.1544" y1="-0.381" x2="16.9672" y2="6.858" layer="21"/>
</package>
<package name="F25HP">
<description>&lt;b&gt;SUB-D&lt;/b&gt;</description>
<wire x1="6.9088" y1="1.397" x2="6.9088" y2="2.413" width="0.8128" layer="51"/>
<wire x1="12.3952" y1="1.397" x2="12.3952" y2="2.413" width="0.8128" layer="51"/>
<wire x1="15.1638" y1="1.397" x2="15.1638" y2="2.413" width="0.8128" layer="51"/>
<rectangle x1="-3.1496" y1="-0.381" x2="-2.3368" y2="6.858" layer="21"/>
<rectangle x1="6.5024" y1="2.159" x2="7.3152" y2="6.858" layer="21"/>
<rectangle x1="11.9888" y1="2.159" x2="12.8016" y2="6.858" layer="21"/>
<rectangle x1="14.7574" y1="2.159" x2="15.5702" y2="6.858" layer="21"/>
</package>
<package name="F25V">
<circle x="1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="0" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="2.7686" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-2.7686" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="4.1402" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-4.1402" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="5.5118" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="8.2804" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="6.9088" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="9.652" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="11.049" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="12.4206" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="13.7922" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="15.1892" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="16.5608" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-5.5118" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-8.2804" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-11.049" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-6.9088" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-9.652" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-12.4206" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-13.7922" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-16.5608" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-15.1892" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<pad name="1" x="16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="-2.7686" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="-5.5118" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="-8.2804" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="-11.049" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="-13.7922" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="13" x="-16.5608" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="16" x="9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="17" x="6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="18" x="4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="19" x="1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="20" x="-1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="21" x="-4.1402" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="22" x="-6.9088" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="23" x="-9.652" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="24" x="-12.4206" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="25" x="-15.1892" y="-1.4224" drill="1.016" shape="octagon"/>
<text x="16.256" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="13.335" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="10.668" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<text x="7.874" y="2.54" size="0.9906" layer="21" ratio="12">4</text>
<text x="5.08" y="2.54" size="0.9906" layer="21" ratio="12">5</text>
<text x="2.286" y="2.54" size="0.9906" layer="21" ratio="12">6</text>
<text x="-0.381" y="2.54" size="0.9906" layer="21" ratio="12">7</text>
<text x="-3.175" y="2.54" size="0.9906" layer="21" ratio="12">8</text>
<text x="-5.969" y="2.54" size="0.9906" layer="21" ratio="12">9</text>
<text x="-26.416" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-9.017" y="2.54" size="0.9906" layer="21" ratio="12">10</text>
<text x="-11.684" y="2.54" size="0.9906" layer="21" ratio="12">11</text>
<text x="-14.478" y="2.54" size="0.9906" layer="21" ratio="12">12</text>
<text x="-17.272" y="2.54" size="0.9906" layer="21" ratio="12">13</text>
<text x="-16.129" y="-3.556" size="0.9906" layer="21" ratio="12">25</text>
<text x="-13.335" y="-3.556" size="0.9906" layer="21" ratio="12">24</text>
<text x="-10.414" y="-3.556" size="0.9906" layer="21" ratio="12">23</text>
<text x="-7.62" y="-3.556" size="0.9906" layer="21" ratio="12">22</text>
<text x="-4.953" y="-3.556" size="0.9906" layer="21" ratio="12">21</text>
<text x="-2.286" y="-3.556" size="0.9906" layer="21" ratio="12">20</text>
<text x="0.635" y="-3.556" size="0.9906" layer="21" ratio="12">19</text>
<text x="3.302" y="-3.556" size="0.9906" layer="21" ratio="12">18</text>
<text x="5.969" y="-3.556" size="0.9906" layer="21" ratio="12">17</text>
<text x="8.763" y="-3.556" size="0.9906" layer="21" ratio="12">16</text>
<text x="11.557" y="-3.556" size="0.9906" layer="21" ratio="12">15</text>
<text x="14.351" y="-3.556" size="0.9906" layer="21" ratio="12">14</text>
</package>
<package name="F25VP">
</package>
<package name="F25VB">
<circle x="-1.3716" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="0" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="1.3716" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-2.7686" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="2.7686" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-4.1402" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="4.1402" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-5.5118" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-8.2804" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-6.9088" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-9.652" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-11.049" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-12.4206" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-13.7922" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-15.1892" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-16.5608" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="5.5118" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="8.2804" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="11.049" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="6.9088" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="9.652" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="12.4206" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="13.7922" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="16.5608" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="15.1892" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<pad name="1" x="-16.5608" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="-13.7922" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="-11.049" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="-8.2804" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="-5.5118" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="-2.7686" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="2.7686" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="5.5118" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="8.2804" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="11.049" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="13.7922" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="13" x="16.5608" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="-15.1892" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="-12.4206" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="16" x="-9.652" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="17" x="-6.9088" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="18" x="-4.1402" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="19" x="-1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="20" x="1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="21" x="4.1402" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="22" x="6.9088" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="23" x="9.652" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="24" x="12.4206" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="25" x="15.1892" y="1.4224" drill="1.016" shape="octagon"/>
<text x="-16.256" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">1</text>
<text x="-13.335" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">2</text>
<text x="-10.668" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">3</text>
<text x="-7.874" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">4</text>
<text x="-5.08" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">5</text>
<text x="-2.286" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">6</text>
<text x="0.381" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">7</text>
<text x="3.175" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">8</text>
<text x="5.969" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">9</text>
<text x="-25.146" y="8.255" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.43" y="8.255" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="9.017" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">10</text>
<text x="11.684" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">11</text>
<text x="14.478" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">12</text>
<text x="17.272" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">13</text>
<text x="16.129" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">25</text>
<text x="13.335" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">24</text>
<text x="10.414" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">23</text>
<text x="7.62" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">22</text>
<text x="4.953" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">21</text>
<text x="2.286" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">20</text>
<text x="-0.635" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">19</text>
<text x="-3.302" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">18</text>
<text x="-5.969" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">17</text>
<text x="-8.763" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">16</text>
<text x="-11.557" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">15</text>
<text x="-14.351" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">14</text>
</package>
<package name="FTDI_BASIC">
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<pad name="DTR" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="RXI" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="TXO" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="VCC" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="CTS" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="GND" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="1.1938" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<text x="0.635" y="1.905" size="1.27" layer="51" rot="R90">GRN</text>
<text x="13.335" y="1.905" size="1.27" layer="51" rot="R90">BLK</text>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
<package name="IPOD_FEMALE_CONNECTOR">
<wire x1="-10.7" y1="6.625" x2="10.7" y2="6.625" width="0.2032" layer="51"/>
<wire x1="10.7" y1="6.625" x2="10.7" y2="0.575" width="0.2032" layer="51"/>
<wire x1="10.7" y1="0.575" x2="-10.7" y2="0.575" width="0.2032" layer="51"/>
<wire x1="-10.7" y1="0.575" x2="-10.7" y2="6.625" width="0.2032" layer="51"/>
<smd name="1" x="-7.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="2" x="-6.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="3" x="-6.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="4" x="-5.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="5" x="-5.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="6" x="-4.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="7" x="-4.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="8" x="-3.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="9" x="-3.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="10" x="-2.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="11" x="-2.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="12" x="-1.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="13" x="-1.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="14" x="-0.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="15" x="-0.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="16" x="0.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="17" x="0.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="18" x="1.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="19" x="1.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="20" x="2.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="21" x="2.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="22" x="3.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="23" x="3.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="24" x="4.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="25" x="4.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="26" x="5.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="27" x="5.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="28" x="6.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="31" x="-11.65" y="2.475" dx="1.4" dy="2.05" layer="1"/>
<smd name="32" x="11.65" y="2.475" dx="1.4" dy="2.05" layer="1"/>
<smd name="29" x="6.75" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<smd name="30" x="7.25" y="0" dx="0.35" dy="1.75" layer="1" rot="R180"/>
<text x="-6.35" y="5.08" size="0.4064" layer="25">&gt;Name</text>
<text x="-6.35" y="3.81" size="0.4064" layer="27">&gt;Value</text>
<hole x="6.25" y="2.125" drill="1.1"/>
<hole x="-6.25" y="2.125" drill="1.1"/>
<hole x="10.825" y="5.025" drill="1.3"/>
<hole x="-10.825" y="5.025" drill="1.3"/>
</package>
<package name="IPOD_MALE_CONNECTOR">
<wire x1="8.725" y1="1.1" x2="8.725" y2="4.1" width="0.2032" layer="51"/>
<wire x1="-9.225" y1="1.1" x2="-9.225" y2="11.1" width="0.2032" layer="51"/>
<wire x1="-9.2288" y1="11.0779" x2="-9.2288" y2="11.4968" width="0.2032" layer="51"/>
<wire x1="-9.2288" y1="11.4968" x2="8.7273" y2="11.4968" width="0.2032" layer="51"/>
<wire x1="8.7273" y1="11.4968" x2="8.7273" y2="4.8832" width="0.2032" layer="51"/>
<wire x1="8.7273" y1="4.8832" x2="8.7273" y2="4.0891" width="0.2032" layer="51"/>
<wire x1="-9.2319" y1="5.2242" x2="8.7273" y2="5.2242" width="0.2032" layer="51"/>
<wire x1="8.7273" y1="5.2242" x2="8.7273" y2="4.8832" width="0.2032" layer="51"/>
<wire x1="-9.2288" y1="2.0272" x2="8.7331" y2="2.0272" width="0.2032" layer="51"/>
<wire x1="8.7331" y1="2.0272" x2="8.7331" y2="1.9143" width="0.2032" layer="51"/>
<smd name="1" x="7.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="3" x="6.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="5" x="5.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="7" x="4.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="9" x="3.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="11" x="2.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="13" x="1.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="15" x="0.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="17" x="-0.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="19" x="-1.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="21" x="-2.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="23" x="-3.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="25" x="-4.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="27" x="-5.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="2" x="7" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="4" x="6" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="6" x="5" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="8" x="4" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="10" x="3" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="12" x="2" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="14" x="1" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="16" x="0" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="18" x="-1" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="20" x="-2" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="22" x="-3" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="24" x="-4" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="26" x="-5" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="28" x="-6" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
<smd name="29" x="-6.5" y="0" dx="0.6" dy="3" layer="16" cream="no"/>
<smd name="30" x="-7" y="0" dx="0.6" dy="3" layer="1" cream="no"/>
</package>
<package name="FFC_16">
<wire x1="-11.4" y1="-3.2" x2="11.4" y2="-3.2" width="0.127" layer="21"/>
<wire x1="-11.4" y1="-3.2" x2="-11.4" y2="-0.5" width="0.127" layer="21"/>
<wire x1="11.4" y1="-3.2" x2="11.4" y2="-0.5" width="0.127" layer="21"/>
<circle x="7.493" y="5.715" radius="0.3592" width="0.127" layer="21"/>
<smd name="16" x="-7.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="15" x="-6.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="14" x="-5.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="13" x="-4.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="12" x="-3.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="11" x="-2.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="10" x="-1.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="9" x="-0.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="8" x="0.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="7" x="1.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="6" x="2.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="5" x="3.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="4" x="4.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="3" x="5.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="2" x="6.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<smd name="1" x="7.5" y="3.9" dx="0.6" dy="1.8" layer="1"/>
<rectangle x1="-11.3" y1="-0.4" x2="-9" y2="2.1" layer="1"/>
<rectangle x1="9" y1="-0.4" x2="11.3" y2="2.1" layer="1"/>
<polygon width="0.127" layer="29">
<vertex x="-11.43" y="2.286"/>
<vertex x="-8.89" y="2.286"/>
<vertex x="-8.89" y="-0.508"/>
<vertex x="-11.43" y="-0.508"/>
</polygon>
<vertex x="8.89" y="2.286"/>
<vertex x="11.43" y="2.286"/>
<vertex x="11.43" y="-0.508"/>
<vertex x="8.89" y="-0.508"/>
</polygon>
<polygon width="0.0254" layer="31">
<vertex x="-11.303" y="2.159"/>
<vertex x="-9.017" y="2.159"/>
<vertex x="-9.017" y="-0.381"/>
<vertex x="-11.303" y="-0.381"/>
</polygon>
<vertex x="9.017" y="2.159"/>
<vertex x="11.303" y="2.159"/>
<vertex x="11.303" y="-0.381"/>
<vertex x="9.017" y="-0.381"/>
</polygon>
</package>
<package name="LITTLE_BITS_FEMALE">
<wire x1="5.5" y1="5.5" x2="5" y2="5" width="0.25" layer="21"/>
<wire x1="5" y1="5" x2="4.5" y2="5.5" width="0.25" layer="21"/>
<wire x1="5" y1="5" x2="5" y2="7" width="0.25" layer="21"/>
<wire x1="-9.075" y1="3.61" x2="-9.075" y2="0" width="0.2032" layer="20"/>
<wire x1="-7.075" y1="3.61" x2="-7.075" y2="0" width="0.2032" layer="20"/>
<wire x1="9.075" y1="3.61" x2="7.075" y2="3.61" width="0.2032" layer="20"/>
<wire x1="-7.075" y1="3.61" x2="-9.075" y2="3.61" width="0.2032" layer="20"/>
<wire x1="7.075" y1="0" x2="7.075" y2="3.61" width="0.2032" layer="20"/>
<wire x1="7.075" y1="0" x2="-7.075" y2="0" width="0.2032" layer="20"/>
<wire x1="9.075" y1="3.61" x2="9.075" y2="0" width="0.2032" layer="20"/>
<wire x1="-8.875" y1="4.5" x2="-8.875" y2="3.61" width="0.001" layer="51"/>
<wire x1="-8.875" y1="4.5" x2="8.875" y2="4.5" width="0.001" layer="51"/>
<wire x1="8.875" y1="4.5" x2="8.875" y2="3.61" width="0.001" layer="51"/>
<smd name="V-" x="-2.54" y="6" dx="3" dy="1.7" layer="1" rot="R90" cream="no"/>
<smd name="SIG" x="0" y="6" dx="3" dy="1.7" layer="1" rot="R90" cream="no"/>
<smd name="V+" x="2.54" y="6" dx="3" dy="1.7" layer="1" rot="R90" cream="no"/>
<text x="-0.4" y="1.4" size="1.27" layer="21" ratio="15">F</text>
<hole x="4.79" y="2.41" drill="1.37"/>
<hole x="-4.79" y="2.41" drill="1.37"/>
</package>
<package name="LITTLE_BITS_MALE">
<wire x1="-2.7968" y1="-0.1038" x2="-2.7968" y2="-0.8658" width="0" layer="51"/>
<wire x1="-2.7968" y1="-0.8658" x2="-1.8062" y2="-0.8658" width="0" layer="51"/>
<wire x1="-1.8062" y1="-0.1038" x2="-1.8062" y2="-0.8658" width="0" layer="51"/>
<wire x1="-2.7968" y1="-0.8658" x2="-1.8062" y2="-0.8658" width="0" layer="51" curve="154.31848"/>
<wire x1="-0.4854" y1="-0.1038" x2="-0.4854" y2="-0.8658" width="0" layer="51"/>
<wire x1="-0.4854" y1="-0.8658" x2="0.5052" y2="-0.8658" width="0" layer="51"/>
<wire x1="0.5052" y1="-0.1038" x2="0.5052" y2="-0.8658" width="0" layer="51"/>
<wire x1="-0.4854" y1="-0.8658" x2="0.5052" y2="-0.8658" width="0" layer="51" curve="154.31848"/>
<wire x1="1.8006" y1="-0.1038" x2="1.8006" y2="-0.8658" width="0" layer="51"/>
<wire x1="1.8006" y1="-0.8658" x2="2.7912" y2="-0.8658" width="0" layer="51"/>
<wire x1="2.7912" y1="-0.1038" x2="2.7912" y2="-0.8658" width="0" layer="51"/>
<wire x1="1.8006" y1="-0.8658" x2="2.7912" y2="-0.8658" width="0" layer="51" curve="154.31848"/>
<wire x1="-5.5" y1="6.5" x2="-5" y2="7" width="0.25" layer="21"/>
<wire x1="-5" y1="7" x2="-4.5" y2="6.5" width="0.25" layer="21"/>
<wire x1="-5" y1="7" x2="-5" y2="5" width="0.25" layer="21"/>
<smd name="V-" x="2.54" y="6" dx="3" dy="1.7" layer="1" rot="R90" cream="no"/>
<smd name="V+" x="-2.54" y="6" dx="3" dy="1.7" layer="1" rot="R90" cream="no"/>
<text x="-0.4826" y="1.3208" size="1.27" layer="21" ratio="15" rot="SR0">M</text>
</package>
<package name="LITTLEBITS">
<wire x1="-9.1868" y1="1.4994" x2="-9.1868" y2="0.5469" width="0" layer="51"/>
<wire x1="-9.1868" y1="-0.0881" x2="-9.1868" y2="-1.0406" width="0" layer="51"/>
<wire x1="-8.2978" y1="1.4994" x2="-8.2978" y2="-1.0406" width="0" layer="51"/>
<wire x1="-8.2978" y1="-1.0406" x2="-8.2978" y2="-2.1836" width="0" layer="51"/>
<wire x1="-7.2818" y1="-2.1836" x2="-7.2818" y2="-2.4376" width="0" layer="51"/>
<wire x1="-6.2446" y1="-2.4376" x2="-6.2446" y2="-2.463" width="0" layer="51"/>
<wire x1="-6.0065" y1="-2.4376" x2="-6.0065" y2="-2.463" width="0" layer="51"/>
<wire x1="-5.345" y1="-2.4376" x2="-5.345" y2="-2.463" width="0" layer="51"/>
<wire x1="-5.1863" y1="-2.4376" x2="-5.1863" y2="-2.463" width="0" layer="51"/>
<wire x1="-4.1068" y1="-2.1836" x2="-4.1068" y2="-2.4376" width="0" layer="51"/>
<wire x1="-3.3895" y1="-2.0566" x2="-3.4911" y2="-1.9804" width="0" layer="51"/>
<wire x1="-3.0146" y1="-2.1836" x2="-3.0146" y2="-2.9456" width="0" layer="51"/>
<wire x1="-2.9003" y1="2.1344" x2="-2.9003" y2="3.4044" width="0" layer="51"/>
<wire x1="-3.0146" y1="-2.9456" x2="-2.024" y2="-2.9456" width="0" layer="51"/>
<wire x1="-0.4746" y1="-2.9456" x2="0.1941" y2="-2.9456" width="0" layer="51"/>
<wire x1="-3.3162" y1="-1.9311" x2="-3.4324" y2="-1.88" width="0" layer="51"/>
<wire x1="-3.4324" y1="-1.88" x2="-3.4325" y2="-1.88" width="0" layer="51"/>
<wire x1="-2.1383" y1="2.1344" x2="-2.1383" y2="3.4044" width="0" layer="51"/>
<wire x1="-2.024" y1="-2.1836" x2="-2.024" y2="-2.9456" width="0" layer="51"/>
<wire x1="6.2437" y1="-2.463" x2="6.085" y2="-2.463" width="0" layer="51"/>
<wire x1="6.085" y1="-2.463" x2="5.4235" y2="-2.463" width="0" layer="51"/>
<wire x1="5.4235" y1="-2.463" x2="5.1854" y2="-2.463" width="0" layer="51"/>
<wire x1="-5.1863" y1="-2.463" x2="-6.2446" y2="-2.463" width="0" layer="51"/>
<wire x1="7.3232" y1="-2.4376" x2="6.2437" y2="-2.4376" width="0" layer="51"/>
<wire x1="6.2437" y1="-2.4376" x2="6.085" y2="-2.4376" width="0" layer="51"/>
<wire x1="6.085" y1="-2.4376" x2="5.4235" y2="-2.4376" width="0" layer="51"/>
<wire x1="5.4235" y1="-2.4376" x2="5.1854" y2="-2.4376" width="0" layer="51"/>
<wire x1="5.1854" y1="-2.4376" x2="4.1482" y2="-2.4376" width="0" layer="51"/>
<wire x1="-4.1068" y1="-2.4376" x2="-7.2818" y2="-2.4376" width="0" layer="51"/>
<wire x1="-8.2978" y1="-2.1836" x2="-3.8975" y2="-2.1836" width="0" layer="51"/>
<wire x1="-3.8975" y1="-2.1836" x2="-0.4746" y2="-2.1836" width="0" layer="51"/>
<wire x1="-0.4746" y1="-2.1836" x2="0.0207" y2="-2.1836" width="0" layer="51"/>
<wire x1="0.0207" y1="-2.1836" x2="0.0211" y2="-2.1836" width="0" layer="51"/>
<wire x1="4.0276" y1="-2.1836" x2="4.1482" y2="-2.1836" width="0" layer="51"/>
<wire x1="4.1482" y1="-2.1836" x2="7.3232" y2="-2.1836" width="0" layer="51"/>
<wire x1="7.3232" y1="-2.1836" x2="8.3392" y2="-2.1836" width="0" layer="51"/>
<wire x1="-3.3895" y1="-2.0566" x2="-0.149" y2="-2.0566" width="0" layer="51"/>
<wire x1="-8.2978" y1="-1.0406" x2="-9.1868" y2="-1.0406" width="0" layer="51"/>
<wire x1="8.3392" y1="-1.0406" x2="9.2282" y2="-1.0406" width="0" layer="51"/>
<wire x1="-0.4746" y1="-2.1836" x2="-0.4746" y2="-2.9456" width="0" layer="51"/>
<wire x1="-0.3603" y1="2.1344" x2="-0.3603" y2="3.4044" width="0" layer="51"/>
<wire x1="0.4017" y1="2.1344" x2="0.4017" y2="3.4044" width="0" layer="51"/>
<wire x1="-0.149" y1="-2.0566" x2="-0.0359" y2="-2.0172" width="0" layer="51"/>
<wire x1="-9.1868" y1="1.4994" x2="-8.2871" y2="1.4994" width="0" layer="51"/>
<wire x1="8.3286" y1="1.4994" x2="8.3392" y2="1.4994" width="0" layer="51"/>
<wire x1="8.3392" y1="1.4994" x2="9.2282" y2="1.4994" width="0" layer="51"/>
<wire x1="2.1797" y1="2.1344" x2="2.1797" y2="3.4044" width="0" layer="51"/>
<wire x1="-7.5358" y1="2.1344" x2="2.9417" y2="2.1344" width="0" layer="51"/>
<wire x1="2.9417" y1="2.1344" x2="7.5772" y2="2.1344" width="0" layer="51"/>
<wire x1="2.9417" y1="2.1344" x2="2.9417" y2="3.4044" width="0" layer="51"/>
<wire x1="-2.9003" y1="3.4044" x2="-2.1383" y2="3.4044" width="0" layer="51"/>
<wire x1="-0.3603" y1="3.4044" x2="0.4017" y2="3.4044" width="0" layer="51"/>
<wire x1="2.1797" y1="3.4044" x2="2.9417" y2="3.4044" width="0" layer="51"/>
<wire x1="4.1482" y1="-2.1836" x2="4.1482" y2="-2.4376" width="0" layer="51"/>
<wire x1="5.1854" y1="-2.4376" x2="5.1854" y2="-2.463" width="0" layer="51"/>
<wire x1="5.4235" y1="-2.4376" x2="5.4235" y2="-2.463" width="0" layer="51"/>
<wire x1="6.085" y1="-2.4376" x2="6.085" y2="-2.463" width="0" layer="51"/>
<wire x1="6.2437" y1="-2.4376" x2="6.2437" y2="-2.463" width="0" layer="51"/>
<wire x1="7.3232" y1="-2.1836" x2="7.3232" y2="-2.4376" width="0" layer="51"/>
<wire x1="8.3392" y1="1.4994" x2="8.3392" y2="-2.1836" width="0" layer="51"/>
<wire x1="9.2282" y1="1.4994" x2="9.2282" y2="0.5469" width="0" layer="51"/>
<wire x1="9.2282" y1="-0.0881" x2="9.2282" y2="-1.0406" width="0" layer="51"/>
<wire x1="0.0207" y1="-2.1836" x2="-3.4325" y2="-1.88" width="0" layer="51" curve="142.577485"/>
<wire x1="-0.149" y1="-2.0566" x2="-3.3162" y2="-1.9311" width="0" layer="51" curve="137.065577"/>
<wire x1="-3.3895" y1="-2.0566" x2="-3.3162" y2="-1.9311" width="0" layer="51" curve="13.144324"/>
<wire x1="-3.8975" y1="-2.1836" x2="-3.4324" y2="-1.88" width="0" layer="51" curve="66.278112"/>
<wire x1="-3.0146" y1="-2.9456" x2="-2.024" y2="-2.9456" width="0" layer="51" curve="154.31848"/>
<wire x1="-7.5358" y1="2.1344" x2="-8.2871" y2="1.4994" width="0" layer="51" curve="80.402764"/>
<wire x1="-9.1868" y1="-0.0881" x2="-9.1868" y2="0.5469" width="0" layer="51" curve="180"/>
<wire x1="0.0207" y1="-2.1836" x2="3.5322" y2="-2.5787" width="0" layer="51" curve="167.160614"/>
<wire x1="4.0276" y1="-2.1836" x2="3.5323" y2="-2.5787" width="0" layer="51" curve="77.159639"/>
<wire x1="-0.4746" y1="-2.9456" x2="0.354" y2="-3.2161" width="0" layer="51" curve="118.159978"/>
<wire x1="8.3286" y1="1.4994" x2="7.5772" y2="2.1345" width="0" layer="51" curve="80.403928"/>
<wire x1="9.2282" y1="0.5469" x2="9.2282" y2="-0.0881" width="0" layer="51" curve="180"/>
<wire x1="-9.3726" y1="-1.2573" x2="9.8806" y2="-1.2573" width="0" layer="51"/>
<wire x1="-8.1026" y1="-1.1557" x2="-8.1026" y2="1.2573" width="0.2032" layer="21"/>
<wire x1="-8.1026" y1="1.2573" x2="-7.4676" y2="1.8923" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.4676" y1="1.8923" x2="7.5438" y2="1.8923" width="0.2032" layer="21"/>
<wire x1="7.5438" y1="1.8923" x2="8.1788" y2="1.2573" width="0.2032" layer="21" curve="-90"/>
<wire x1="8.1788" y1="1.2573" x2="8.1788" y2="-1.1557" width="0.2032" layer="21"/>
<circle x="-2.5193" y="0.2294" radius="0.635" width="0.0254" layer="51"/>
<circle x="-2.5193" y="0.2294" radius="0.381" width="0.0254" layer="51"/>
<circle x="2.5607" y="0.2294" radius="0.635" width="0.0254" layer="51"/>
<circle x="2.5607" y="0.2294" radius="0.381" width="0.0254" layer="51"/>
<smd name="P$1" x="-8.7884" y="0.2413" dx="2.7686" dy="1.016" layer="1" rot="R90"/>
<smd name="P$2" x="8.8392" y="0.2413" dx="2.7686" dy="1.016" layer="1" rot="R90"/>
<smd name="P$3" x="-2.54" y="2.8321" dx="1.397" dy="1.016" layer="1" rot="R90"/>
<smd name="P$4" x="0.0254" y="2.8575" dx="1.397" dy="1.016" layer="1" rot="R90"/>
<smd name="P$5" x="2.5654" y="2.8321" dx="1.397" dy="1.016" layer="1" rot="R90"/>
<hole x="2.5654" y="0.2159" drill="1.374"/>
<hole x="-2.5146" y="0.2159" drill="1.374"/>
</package>
<package name="1X01_LONGPAD">
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="LUXEON-PAD">
<smd name="P$1" x="0" y="0" dx="3.9" dy="2.4" layer="1" roundness="25"/>
<text x="-1.5" y="2" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.5" y="-3" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SMTRA-256-8-6">
<pad name="P$1" x="-1.9939" y="0" drill="1.3462"/>
<pad name="P$2" x="1.9939" y="0" drill="1.3462"/>
<smd name="P$3" x="0" y="0" dx="6.6548" dy="4.3434" layer="1" cream="no"/>
<text x="1.27" y="2.54" size="0.4064" layer="27">&gt;Value</text>
<text x="-2.54" y="2.54" size="0.4064" layer="25">&gt;Name</text>
<rectangle x1="-3.302" y1="0.762" x2="3.302" y2="2.032" layer="31"/>
<rectangle x1="-1.016" y1="0.508" x2="1.016" y2="0.762" layer="31"/>
<rectangle x1="-1.016" y1="-1.016" x2="1.016" y2="-0.762" layer="31"/>
<rectangle x1="-3.302" y1="-2.032" x2="3.302" y2="-0.762" layer="31"/>
<rectangle x1="-1.016" y1="-0.762" x2="1.016" y2="-0.508" layer="31"/>
<rectangle x1="2.794" y1="0.508" x2="3.302" y2="0.762" layer="31"/>
<rectangle x1="2.794" y1="-0.762" x2="3.302" y2="-0.508" layer="31"/>
<rectangle x1="-3.302" y1="-0.762" x2="-2.794" y2="-0.508" layer="31"/>
<rectangle x1="-3.302" y1="0.508" x2="-2.794" y2="0.762" layer="31"/>
</package>
<package name="1X01NS">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X01">
<wire x1="1.27" y1="0.635" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="-0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<text x="1.1938" y="1.8288" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="1X01_2MM">
<pad name="1" x="0" y="0" drill="2" diameter="3.302" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="1X01_OFFSET">
<pad name="1" x="0" y="0" drill="1.1176" diameter="1.8796" shape="offset" rot="R90"/>
</package>
<package name="PAD-1.5X4.5">
<smd name="P$1" x="0" y="0" dx="1.5" dy="2" layer="1"/>
</package>
<package name="1X01_POGOPIN_HOLE_LARGE">
<circle x="0" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="1" x="0" y="0" drill="0.9" diameter="0.8128" rot="R90" thermals="no"/>
<hole x="0" y="0" drill="1.5494"/>
</package>
<package name="1X01_POGOPIN_HOLE_0.58">
<hole x="0" y="0" drill="1.4732"/>
</package>
<package name="SNAP-FEMALE">
<pad name="1" x="0" y="0" drill="2.921" diameter="4.572"/>
<polygon width="0.254" layer="1">
<vertex x="-4.0005" y="0" curve="-89.997136"/>
<vertex x="0" y="4.0005" curve="-90.002865"/>
<vertex x="4.0005" y="0" curve="-89.997136"/>
<vertex x="0" y="-4.0005" curve="-89.997136"/>
</polygon>
<polygon width="0.3556" layer="29">
<vertex x="-4.0005" y="0" curve="-90.002865"/>
</polygon>
<polygon width="0.3556" layer="31">
</polygon>
<polygon width="0.3556" layer="41">
</polygon>
</package>
<package name="SNAP-MALE">
<smd name="2" x="0" y="0" dx="7.62" dy="7.62" layer="1" roundness="100"/>
</package>
<package name="1X02">
<wire x1="3.81" y1="0.635" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="MOLEX-1X2">
<wire x1="-1.27" y1="3.048" x2="-1.27" y2="-2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="3.048" x2="3.81" y2="-2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="3.048" x2="-1.27" y2="3.048" width="0.127" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="2.54" y2="-2.54" width="0.127" layer="21"/>
<wire x1="2.54" y1="-2.54" x2="0" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.27" width="0.127" layer="21"/>
<wire x1="0" y1="-1.27" x2="2.54" y2="-1.27" width="0.127" layer="21"/>
<wire x1="2.54" y1="-1.27" x2="2.54" y2="-2.54" width="0.127" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796"/>
</package>
<package name="SCREWTERMINAL-3.5MM-2">
<circle x="2" y="3" radius="0.2828" width="0.127" layer="51"/>
<wire x1="-1.75" y1="3.4" x2="5.25" y2="3.4" width="0.2032" layer="21"/>
<wire x1="5.25" y1="3.4" x2="5.25" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-2.8" x2="5.25" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-3.6" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-2.8" x2="-1.75" y2="3.4" width="0.2032" layer="21"/>
<wire x1="5.25" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-1.35" x2="-2.25" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.35" x2="-2.25" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-2.35" x2="-1.75" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="5.25" y1="3.15" x2="5.75" y2="3.15" width="0.2032" layer="51"/>
<wire x1="5.75" y1="3.15" x2="5.75" y2="2.15" width="0.2032" layer="51"/>
<wire x1="5.75" y1="2.15" x2="5.25" y2="2.15" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.2" diameter="2.032" shape="square"/>
<pad name="2" x="3.5" y="0" drill="1.2" diameter="2.032"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="JST-2-SMD">
<description>2mm SMD side-entry connector. tDocu layer indicates the actual physical plastic housing. +/- indicate SparkFun standard batteries and wiring.</description>
<wire x1="-4" y1="-1" x2="-4" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-4" y1="-4.5" x2="-3.2" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-4.5" x2="-3.2" y2="-2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-2" x2="-2" y2="-2" width="0.2032" layer="21"/>
<wire x1="2" y1="-2" x2="3.2" y2="-2" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-2" x2="3.2" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-4.5" x2="4" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="4" y1="-4.5" x2="4" y2="-1" width="0.2032" layer="21"/>
<wire x1="2" y1="3" x2="-2" y2="3" width="0.2032" layer="21"/>
<smd name="1" x="-1" y="-3.7" dx="1" dy="4.6" layer="1"/>
<smd name="2" x="1" y="-3.7" dx="1" dy="4.6" layer="1"/>
<smd name="NC1" x="-3.4" y="1.5" dx="3.4" dy="1.6" layer="1" rot="R90"/>
<smd name="NC2" x="3.4" y="1.5" dx="3.4" dy="1.6" layer="1" rot="R90"/>
<text x="-1.27" y="1.27" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="0" size="0.4064" layer="27">&gt;Value</text>
</package>
<package name="1X02_BIG">
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="5.08" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.127" layer="21"/>
<wire x1="5.08" y1="1.27" x2="-1.27" y2="1.27" width="0.127" layer="21"/>
<pad name="P$1" x="0" y="0" drill="1.0668"/>
<pad name="P$2" x="3.81" y="0" drill="1.0668"/>
</package>
<package name="JST-2-SMD-VERT">
<wire x1="-4.1" y1="2.97" x2="4.2" y2="2.97" width="0.2032" layer="51"/>
<wire x1="4.2" y1="2.97" x2="4.2" y2="-2.13" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-2.13" x2="-4.1" y2="-2.13" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="-2.13" x2="-4.1" y2="2.97" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="3" x2="4.2" y2="3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3" x2="4.2" y2="2.3" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="3" x2="-4.1" y2="2.3" width="0.2032" layer="21"/>
<wire x1="2" y1="-2.1" x2="4.2" y2="-2.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-2.1" x2="4.2" y2="-1.7" width="0.2032" layer="21"/>
<wire x1="-2" y1="-2.1" x2="-4.1" y2="-2.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-2.1" x2="-4.1" y2="-1.8" width="0.2032" layer="21"/>
<smd name="P$1" x="-3.4" y="0.27" dx="3" dy="1.6" layer="1" rot="R90"/>
<smd name="P$2" x="3.4" y="0.27" dx="3" dy="1.6" layer="1" rot="R90"/>
<smd name="VCC" x="-1" y="-2" dx="1" dy="5.5" layer="1"/>
<smd name="GND" x="1" y="-2" dx="1" dy="5.5" layer="1"/>
<text x="2.54" y="-5.08" size="1.27" layer="25">&gt;Name</text>
<text x="2.24" y="3.48" size="1.27" layer="27">&gt;Value</text>
</package>
<package name="R_SW_TH">
<wire x1="-1.651" y1="19.2532" x2="-1.651" y2="-1.3716" width="0.2032" layer="21"/>
<wire x1="-1.651" y1="-1.3716" x2="-1.651" y2="-2.2352" width="0.2032" layer="21"/>
<wire x1="-1.651" y1="19.2532" x2="13.589" y2="19.2532" width="0.2032" layer="21"/>
<wire x1="13.589" y1="19.2532" x2="13.589" y2="-2.2352" width="0.2032" layer="21"/>
<wire x1="13.589" y1="-2.2352" x2="-1.651" y2="-2.2352" width="0.2032" layer="21"/>
<pad name="P$1" x="0" y="0" drill="1.6002"/>
<pad name="P$2" x="0" y="16.9926" drill="1.6002"/>
<pad name="P$3" x="12.0904" y="15.494" drill="1.6002"/>
<pad name="P$4" x="12.0904" y="8.4582" drill="1.6002"/>
</package>
<package name="SCREWTERMINAL-5MM-2">
<wire x1="-3.1" y1="4.2" x2="8.1" y2="4.2" width="0.2032" layer="21"/>
<wire x1="8.1" y1="4.2" x2="8.1" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="8.1" y1="-2.3" x2="8.1" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="8.1" y1="-3.3" x2="-3.1" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-3.3" x2="-3.1" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-2.3" x2="-3.1" y2="4.2" width="0.2032" layer="21"/>
<wire x1="8.1" y1="-2.3" x2="-3.1" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-1.35" x2="-3.7" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-3.7" y1="-1.35" x2="-3.7" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-3.7" y1="-2.35" x2="-3.1" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="8.1" y1="4" x2="8.7" y2="4" width="0.2032" layer="51"/>
<wire x1="8.7" y1="4" x2="8.7" y2="3" width="0.2032" layer="51"/>
<wire x1="8.7" y1="3" x2="8.1" y2="3" width="0.2032" layer="51"/>
<circle x="2.5" y="3.7" radius="0.2828" width="0.127" layer="51"/>
<pad name="1" x="0" y="0" drill="1.3" diameter="2.032" shape="square"/>
<pad name="2" x="5" y="0" drill="1.3" diameter="2.032"/>
</package>
<package name="1X02_LOCK">
<pad name="1" x="-0.1778" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.7178" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="-0.2921" y1="-0.2921" x2="0.2921" y2="0.2921" layer="51"/>
<rectangle x1="2.2479" y1="-0.2921" x2="2.8321" y2="0.2921" layer="51"/>
</package>
<package name="MOLEX-1X2_LOCK">
<pad name="1" x="-0.127" y="0" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="2.667" y="0" drill="1.016" diameter="1.8796"/>
</package>
<package name="1X02_LOCK_LONGPADS">
<description>This footprint was designed to help hold the alignment of a through-hole component (i.e.  6-pin header) while soldering it into place.
You may notice that each hole has been shifted either up or down by 0.005 of an inch from it's more standard position (which is a perfectly straight line).
This slight alteration caused the pins (the squares in the middle) to touch the edges of the holes.  Because they are alternating, it causes a "brace"
to hold the component in place.  0.005 has proven to be the perfect amount of "off-center" position when using our standard breakaway headers.
Although looks a little odd when you look at the bare footprint, once you have a header in there, the alteration is very hard to notice.  Also,
if you push a header all the way into place, it is covered up entirely on the bottom side.  This idea of altering the position of holes to aid alignment
will be further integrated into the Sparkfun Library for other footprints.  It can help hold any component with 3 or more connection pins.</description>
<wire x1="1.651" y1="0" x2="0.889" y2="0" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.016" y2="0" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.9906" x2="-0.9906" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.9906" x2="-0.9906" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0" x2="3.556" y2="0" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.9906" x2="3.5306" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0" x2="3.81" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.9906" x2="3.5306" y2="1.27" width="0.2032" layer="21"/>
<pad name="1" x="-0.127" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.667" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-1.27" y="1.778" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-3.302" size="1.27" layer="27" font="vector">&gt;VALUE</text>
</package>
<package name="SCREWTERMINAL-3.5MM-2_LOCK">
<wire x1="-1.75" y1="-1.35" x2="-2.15" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-1.35" x2="-2.15" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-2.35" x2="-1.75" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="5.25" y1="3.15" x2="5.65" y2="3.15" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.15" x2="5.65" y2="2.15" width="0.2032" layer="51"/>
<wire x1="5.65" y1="2.15" x2="5.25" y2="2.15" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="0.4318" width="0.0254" layer="51"/>
<circle x="3.5" y="0" radius="0.4318" width="0.0254" layer="51"/>
<pad name="1" x="-0.1778" y="0" drill="1.2" diameter="2.032" shape="square"/>
<pad name="2" x="3.6778" y="0" drill="1.2" diameter="2.032"/>
</package>
<package name="1X02_LONGPADS">
<pad name="2" x="2.54" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="1X02_NO_SILK">
</package>
<package name="JST-2-PTH">
<pad name="1" x="-1" y="0" drill="0.7" diameter="1.6"/>
<pad name="2" x="1" y="0" drill="0.7" diameter="1.6"/>
<text x="-1.27" y="5.27" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="4" size="0.4064" layer="27">&gt;Value</text>
<text x="0.6" y="0.7" size="1.27" layer="51">+</text>
<text x="-1.4" y="0.7" size="1.27" layer="51">-</text>
<wire x1="-2.95" y1="-1.6" x2="-2.95" y2="6" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="6" x2="2.95" y2="6" width="0.2032" layer="21"/>
<wire x1="2.95" y1="6" x2="2.95" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-1.6" x2="-2.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="2.95" y1="-1.6" x2="2.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-2.3" y1="-1.6" x2="-2.3" y2="0" width="0.2032" layer="21"/>
<wire x1="2.3" y1="-1.6" x2="2.3" y2="0" width="0.2032" layer="21"/>
</package>
<package name="1X02_XTRA_BIG">
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="5.08" y2="-2.54" width="0.127" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.127" layer="21"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="2.0574" diameter="3.556"/>
<pad name="2" x="2.54" y="0" drill="2.0574" diameter="3.556"/>
</package>
<package name="1X02_PP_HOLES_ONLY">
<circle x="2.54" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="1" x="0" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<hole x="2.54" y="0" drill="1.4732"/>
</package>
<package name="SCREWTERMINAL-3.5MM-2-NS">
<wire x1="-1.75" y1="3.4" x2="5.25" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.25" y1="3.4" x2="5.25" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-2.8" x2="5.25" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="51"/>
<wire x1="-1.75" y1="-3.6" x2="-1.75" y2="-2.8" width="0.2032" layer="51"/>
<wire x1="-1.75" y1="-2.8" x2="-1.75" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.25" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="51"/>
</package>
<package name="JST-2-PTH-NS">
<wire x1="-2" y1="0" x2="-2" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-2" y1="-1.8" x2="-3" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3" y1="-1.8" x2="-3" y2="6" width="0.2032" layer="51"/>
<wire x1="-3" y1="6" x2="3" y2="6" width="0.2032" layer="51"/>
<wire x1="3" y1="6" x2="3" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="3" y1="-1.8" x2="2" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="2" y1="-1.8" x2="2" y2="0" width="0.2032" layer="51"/>
</package>
<package name="JST-2-PTH-KIT">
<description>&lt;H3&gt;JST-2-PTH-KIT&lt;/h3&gt;
2-Pin JST, through-hole connector&lt;br&gt;
&lt;br&gt;
&lt;b&gt;Warning:&lt;/b&gt; This is the KIT version of this package. This package has a smaller diameter top stop mask, which doesn't cover the diameter of the pad. This means only the bottom side of the pads' copper will be exposed. You'll only be able to solder to the bottom side.</description>
<pad name="1" x="-1" y="0" drill="0.7" diameter="1.4478" stop="no"/>
<pad name="2" x="1" y="0" drill="0.7" diameter="1.4478" stop="no"/>
<polygon width="0.127" layer="30">
<vertex x="-0.9975" y="-0.6604" curve="-90.025935"/>
<vertex x="-1.6604" y="0" curve="-90.017354"/>
<vertex x="-1" y="0.6604" curve="-90"/>
<vertex x="-0.3396" y="0" curve="-90.078137"/>
</polygon>
<vertex x="-1" y="-0.2865" curve="-90.08005"/>
<vertex x="-1.2865" y="0" curve="-90.040011"/>
<vertex x="-1" y="0.2865" curve="-90"/>
<vertex x="-0.7135" y="0" curve="-90"/>
</polygon>
<vertex x="1.0025" y="-0.6604" curve="-90.025935"/>
<vertex x="0.3396" y="0" curve="-90.017354"/>
<vertex x="1" y="0.6604" curve="-90"/>
<vertex x="1.6604" y="0" curve="-90.078137"/>
</polygon>
<vertex x="1" y="-0.2865" curve="-90.08005"/>
<vertex x="0.7135" y="0" curve="-90.040011"/>
<vertex x="1" y="0.2865" curve="-90"/>
<vertex x="1.2865" y="0" curve="-90"/>
</polygon>
</package>
<package name="SPRINGTERMINAL-2.54MM-2">
<wire x1="-4.2" y1="7.88" x2="-4.2" y2="-2.8" width="0.254" layer="21"/>
<wire x1="-4.2" y1="-2.8" x2="-4.2" y2="-4.72" width="0.254" layer="51"/>
<wire x1="-4.2" y1="-4.72" x2="3.44" y2="-4.72" width="0.254" layer="51"/>
<wire x1="3.44" y1="-4.72" x2="3.44" y2="-2.8" width="0.254" layer="51"/>
<wire x1="3.44" y1="7.88" x2="-4.2" y2="7.88" width="0.254" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="5.08" width="0.254" layer="1"/>
<wire x1="0" y1="0" x2="0" y2="5.08" width="0.254" layer="16"/>
<wire x1="2.54" y1="0" x2="2.54" y2="5.08" width="0.254" layer="16"/>
<wire x1="2.54" y1="0" x2="2.54" y2="5.08" width="0.254" layer="1"/>
<wire x1="-4.2" y1="-2.8" x2="3.44" y2="-2.8" width="0.254" layer="21"/>
<wire x1="3.44" y1="4" x2="3.44" y2="1" width="0.254" layer="21"/>
<wire x1="3.44" y1="7.88" x2="3.44" y2="6" width="0.254" layer="21"/>
<wire x1="3.44" y1="-0.9" x2="3.44" y2="-2.8" width="0.254" layer="21"/>
<pad name="1" x="0" y="0" drill="1.1" diameter="1.9"/>
<pad name="P$2" x="0" y="5.08" drill="1.1" diameter="1.9"/>
<pad name="P$3" x="2.54" y="5.08" drill="1.1" diameter="1.9"/>
<pad name="2" x="2.54" y="0" drill="1.1" diameter="1.9"/>
</package>
<package name="1X03">
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="MOLEX-1X3">
<wire x1="6.35" y1="3.048" x2="6.35" y2="-2.54" width="0.127" layer="21"/>
<wire x1="6.35" y1="3.048" x2="-1.27" y2="3.048" width="0.127" layer="21"/>
<wire x1="6.35" y1="-2.54" x2="5.08" y2="-2.54" width="0.127" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="0" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0" y1="-1.27" x2="5.08" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="-2.54" width="0.127" layer="21"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796"/>
</package>
<package name="SCREWTERMINAL-3.5MM-3">
<wire x1="-1.75" y1="3.4" x2="8.75" y2="3.4" width="0.2032" layer="21"/>
<wire x1="8.75" y1="3.4" x2="8.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="8.75" y1="-2.8" x2="8.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.75" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="8.75" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="8.75" y1="3.15" x2="9.25" y2="3.15" width="0.2032" layer="51"/>
<wire x1="9.25" y1="3.15" x2="9.25" y2="2.15" width="0.2032" layer="51"/>
<wire x1="9.25" y1="2.15" x2="8.75" y2="2.15" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.2" diameter="2.413" shape="square"/>
<pad name="2" x="3.5" y="0" drill="1.2" diameter="2.413"/>
<pad name="3" x="7" y="0" drill="1.2" diameter="2.413"/>
</package>
<package name="1X03_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X03_LOCK_LONGPADS">
<wire x1="1.524" y1="-0.127" x2="1.016" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="4.064" y1="-0.127" x2="3.556" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.127" x2="-1.016" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.127" x2="-1.27" y2="0.8636" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.8636" x2="-0.9906" y2="1.143" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.127" x2="-1.27" y2="-1.1176" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-1.1176" x2="-0.9906" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.127" x2="6.096" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.127" x2="6.35" y2="-1.1176" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-1.1176" x2="6.0706" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.127" x2="6.35" y2="0.8636" width="0.2032" layer="21"/>
<wire x1="6.35" y1="0.8636" x2="6.0706" y2="1.143" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.254" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="-0.2921" y1="-0.4191" x2="0.2921" y2="0.1651" layer="51"/>
<rectangle x1="2.2479" y1="-0.4191" x2="2.8321" y2="0.1651" layer="51"/>
<rectangle x1="4.7879" y1="-0.4191" x2="5.3721" y2="0.1651" layer="51"/>
</package>
<package name="MOLEX-1X3_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796"/>
<rectangle x1="4.7879" y1="-0.2921" x2="5.3721" y2="0.2921" layer="51"/>
</package>
<package name="SCREWTERMINAL-3.5MM-3_LOCK.007S">
<circle x="0" y="0" radius="0.425" width="0.001" layer="51"/>
<circle x="3.5" y="0" radius="0.425" width="0.001" layer="51"/>
<circle x="7" y="0" radius="0.425" width="0.001" layer="51"/>
<pad name="3" x="7.1778" y="0" drill="1.2" diameter="2.032"/>
</package>
<package name="1X03_NO_SILK">
</package>
<package name="1X03_LONGPADS">
<pad name="3" x="5.08" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-1.3462" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="JST-3-PTH">
<wire x1="-3.95" y1="-1.6" x2="-3.95" y2="6" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="6" x2="3.95" y2="6" width="0.2032" layer="21"/>
<wire x1="3.95" y1="6" x2="3.95" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="-1.6" x2="-3.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-1.6" x2="3.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.6" x2="-3.3" y2="0" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-1.6" x2="3.3" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="-2" y="0" drill="0.7" diameter="1.6"/>
<pad name="2" x="0" y="0" drill="0.7" diameter="1.6"/>
<pad name="3" x="2" y="0" drill="0.7" diameter="1.6"/>
<text x="-1.27" y="5.24" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="3.97" size="0.4064" layer="27">&gt;Value</text>
<text x="-2.4" y="0.67" size="1.27" layer="51">+</text>
<text x="-0.4" y="0.67" size="1.27" layer="51">-</text>
<text x="1.7" y="0.87" size="0.8" layer="51">S</text>
</package>
<package name="1X03_PP_HOLES_ONLY">
<circle x="5.08" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="1" x="0" y="0" drill="0.9" diameter="0.8128" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.9" diameter="0.8128" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="0.9" diameter="0.8128" rot="R90"/>
<hole x="5.08" y="0" drill="1.4732"/>
</package>
<package name="SCREWTERMINAL-5MM-3">
<wire x1="-3.1" y1="4.2" x2="13.1" y2="4.2" width="0.2032" layer="21"/>
<wire x1="13.1" y1="4.2" x2="13.1" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="13.1" y1="-2.3" x2="13.1" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="13.1" y1="-3.3" x2="-3.1" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="13.1" y1="-2.3" x2="-3.1" y2="-2.3" width="0.2032" layer="21"/>
<wire x1="13.1" y1="4" x2="13.7" y2="4" width="0.2032" layer="51"/>
<wire x1="13.7" y1="4" x2="13.7" y2="3" width="0.2032" layer="51"/>
<wire x1="13.7" y1="3" x2="13.1" y2="3" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.3" diameter="2.413" shape="square"/>
<pad name="2" x="5" y="0" drill="1.3" diameter="2.413"/>
<pad name="3" x="10" y="0" drill="1.3" diameter="2.413"/>
</package>
<package name="1X03_LOCK_NO_SILK">
</package>
<package name="JST-3-SMD">
<wire x1="-4.99" y1="-2.07" x2="-4.99" y2="-5.57" width="0.2032" layer="21"/>
<wire x1="-4.99" y1="-5.57" x2="-4.19" y2="-5.57" width="0.2032" layer="21"/>
<wire x1="-4.19" y1="-5.57" x2="-4.19" y2="-3.07" width="0.2032" layer="21"/>
<wire x1="-4.19" y1="-3.07" x2="-2.99" y2="-3.07" width="0.2032" layer="21"/>
<wire x1="3.01" y1="-3.07" x2="4.21" y2="-3.07" width="0.2032" layer="21"/>
<wire x1="4.21" y1="-3.07" x2="4.21" y2="-5.57" width="0.2032" layer="21"/>
<wire x1="4.21" y1="-5.57" x2="5.01" y2="-5.57" width="0.2032" layer="21"/>
<wire x1="5.01" y1="-5.57" x2="5.01" y2="-2.07" width="0.2032" layer="21"/>
<wire x1="3.01" y1="1.93" x2="-2.99" y2="1.93" width="0.2032" layer="21"/>
<smd name="1" x="-1.99" y="-4.77" dx="1" dy="4.6" layer="1"/>
<smd name="3" x="2.01" y="-4.77" dx="1" dy="4.6" layer="1"/>
<smd name="NC1" x="-4.39" y="0.43" dx="3.4" dy="1.6" layer="1" rot="R90"/>
<smd name="NC2" x="4.41" y="0.43" dx="3.4" dy="1.6" layer="1" rot="R90"/>
<smd name="2" x="0.01" y="-4.77" dx="1" dy="4.6" layer="1"/>
<text x="-2.26" y="0.2" size="0.4064" layer="25">&gt;Name</text>
<text x="-2.26" y="-1.07" size="0.4064" layer="27">&gt;Value</text>
</package>
<package name="1X03-1MM-RA">
<wire x1="-1" y1="-4.6" x2="1" y2="-4.6" width="0.254" layer="21"/>
<wire x1="-2.5" y1="-2" x2="-2.5" y2="-0.35" width="0.254" layer="21"/>
<wire x1="1.75" y1="-0.35" x2="2.4997" y2="-0.35" width="0.254" layer="21"/>
<wire x1="2.4997" y1="-0.35" x2="2.4997" y2="-2" width="0.254" layer="21"/>
<wire x1="-2.5" y1="-0.35" x2="-1.75" y2="-0.35" width="0.254" layer="21"/>
<circle x="-2" y="0.3" radius="0.1414" width="0.4" layer="21"/>
<smd name="NC2" x="-2.3" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="NC1" x="2.3" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="1" x="-1" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="2" x="0" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="3" x="1" y="0" dx="0.6" dy="1.35" layer="1"/>
<text x="-1.73" y="1.73" size="0.4064" layer="25" rot="R180">&gt;NAME</text>
<text x="3.46" y="1.73" size="0.4064" layer="27" rot="R180">&gt;VALUE</text>
</package>
<package name="1X04">
<wire x1="8.89" y1="0.635" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="MOLEX-1X4">
<wire x1="8.89" y1="3.048" x2="8.89" y2="-2.54" width="0.127" layer="21"/>
<wire x1="8.89" y1="3.048" x2="-1.27" y2="3.048" width="0.127" layer="21"/>
<wire x1="8.89" y1="-2.54" x2="7.62" y2="-2.54" width="0.127" layer="21"/>
<wire x1="7.62" y1="-2.54" x2="0" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0" y1="-1.27" x2="7.62" y2="-1.27" width="0.127" layer="21"/>
<wire x1="7.62" y1="-1.27" x2="7.62" y2="-2.54" width="0.127" layer="21"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796"/>
</package>
<package name="SCREWTERMINAL-3.5MM-4">
<wire x1="-1.75" y1="3.4" x2="12.25" y2="3.4" width="0.2032" layer="21"/>
<wire x1="12.25" y1="3.4" x2="12.25" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="12.25" y1="-2.8" x2="12.25" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="12.25" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="12.25" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="12.25" y1="3.15" x2="12.75" y2="3.15" width="0.2032" layer="51"/>
<wire x1="12.75" y1="3.15" x2="12.75" y2="2.15" width="0.2032" layer="51"/>
<wire x1="12.75" y1="2.15" x2="12.25" y2="2.15" width="0.2032" layer="51"/>
<circle x="10.5" y="0" radius="0.425" width="0.001" layer="51"/>
<pad name="3" x="7" y="0" drill="1.2" diameter="2.032"/>
<pad name="4" x="10.5" y="0" drill="1.2" diameter="2.032"/>
</package>
<package name="1X04-1.27MM">
<wire x1="-0.381" y1="-0.889" x2="0.381" y2="-0.889" width="0.127" layer="21"/>
<wire x1="0.381" y1="-0.889" x2="0.635" y2="-0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.889" y2="-0.889" width="0.127" layer="21"/>
<wire x1="0.889" y1="-0.889" x2="1.651" y2="-0.889" width="0.127" layer="21"/>
<wire x1="1.651" y1="-0.889" x2="1.905" y2="-0.635" width="0.127" layer="21"/>
<wire x1="1.905" y1="-0.635" x2="2.159" y2="-0.889" width="0.127" layer="21"/>
<wire x1="2.159" y1="-0.889" x2="2.921" y2="-0.889" width="0.127" layer="21"/>
<wire x1="2.921" y1="-0.889" x2="3.175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="3.175" y1="-0.635" x2="3.429" y2="-0.889" width="0.127" layer="21"/>
<wire x1="3.429" y1="-0.889" x2="4.191" y2="-0.889" width="0.127" layer="21"/>
<wire x1="4.191" y1="0.889" x2="3.429" y2="0.889" width="0.127" layer="21"/>
<wire x1="3.429" y1="0.889" x2="3.175" y2="0.635" width="0.127" layer="21"/>
<wire x1="3.175" y1="0.635" x2="2.921" y2="0.889" width="0.127" layer="21"/>
<wire x1="2.921" y1="0.889" x2="2.159" y2="0.889" width="0.127" layer="21"/>
<wire x1="2.159" y1="0.889" x2="1.905" y2="0.635" width="0.127" layer="21"/>
<wire x1="1.905" y1="0.635" x2="1.651" y2="0.889" width="0.127" layer="21"/>
<wire x1="1.651" y1="0.889" x2="0.889" y2="0.889" width="0.127" layer="21"/>
<wire x1="0.889" y1="0.889" x2="0.635" y2="0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.381" y2="0.889" width="0.127" layer="21"/>
<wire x1="0.381" y1="0.889" x2="-0.381" y2="0.889" width="0.127" layer="21"/>
<wire x1="-0.381" y1="0.889" x2="-0.889" y2="0.381" width="0.127" layer="21"/>
<wire x1="-0.889" y1="-0.381" x2="-0.381" y2="-0.889" width="0.127" layer="21"/>
<wire x1="-0.889" y1="0.381" x2="-0.889" y2="-0.381" width="0.127" layer="21"/>
<wire x1="4.191" y1="0.889" x2="4.699" y2="0.381" width="0.127" layer="21"/>
<wire x1="4.699" y1="0.381" x2="4.699" y2="-0.381" width="0.127" layer="21"/>
<wire x1="4.699" y1="-0.381" x2="4.191" y2="-0.889" width="0.127" layer="21"/>
<pad name="4" x="3.81" y="0" drill="0.508" diameter="1"/>
<pad name="3" x="2.54" y="0" drill="0.508" diameter="1"/>
<pad name="2" x="1.27" y="0" drill="0.508" diameter="1"/>
<pad name="1" x="0" y="0" drill="0.508" diameter="1"/>
<text x="-0.508" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="-0.508" y="-1.651" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X04_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X04_LOCK_LONGPADS">
<wire x1="6.604" y1="-0.127" x2="6.096" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.127" x2="8.636" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.127" x2="8.89" y2="-1.1176" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-1.1176" x2="8.6106" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.127" x2="8.89" y2="0.8636" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.8636" x2="8.6106" y2="1.143" width="0.2032" layer="21"/>
<pad name="4" x="7.62" y="-0.254" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="7.3279" y1="-0.4191" x2="7.9121" y2="0.1651" layer="51" rot="R90"/>
</package>
<package name="MOLEX-1X4_LOCK">
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796"/>
</package>
<package name="1X04-SMD">
<wire x1="5.08" y1="1.25" x2="-5.08" y2="1.25" width="0.127" layer="51"/>
<wire x1="-5.08" y1="1.25" x2="-5.08" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-5.08" y1="-1.25" x2="-3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="5.08" y2="-1.25" width="0.127" layer="51"/>
<wire x1="5.08" y1="-1.25" x2="5.08" y2="1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="-1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-3.81" y2="-7.25" width="0.127" layer="51"/>
<smd name="4" x="3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="3" x="1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="1" x="-3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<hole x="-2.54" y="0" drill="1.4"/>
<hole x="2.54" y="0" drill="1.4"/>
</package>
<package name="1X04_LONGPADS">
<pad name="4" x="7.62" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="1X04_NO_SILK">
</package>
<package name="JST-4-PTH">
<pad name="1" x="-3" y="0" drill="0.7" diameter="1.6"/>
<pad name="2" x="-1" y="0" drill="0.7" diameter="1.6"/>
<pad name="3" x="1" y="0" drill="0.7" diameter="1.6"/>
<pad name="4" x="3" y="0" drill="0.7" diameter="1.6"/>
<text x="-2.27" y="5.27" size="0.4064" layer="25">&gt;Name</text>
<text x="-2.27" y="4" size="0.4064" layer="27">&gt;Value</text>
<text x="-3.4" y="0.7" size="1.27" layer="51">+</text>
<text x="0.7" y="0.9" size="0.8" layer="51">S</text>
<text x="2.7" y="0.9" size="0.8" layer="51">S</text>
<wire x1="-4.95" y1="-1.6" x2="-4.95" y2="6" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="6" x2="4.95" y2="6" width="0.2032" layer="21"/>
<wire x1="4.95" y1="6" x2="4.95" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="-1.6" x2="-4.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-1.6" x2="4.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-4.3" y1="-1.6" x2="-4.3" y2="0" width="0.2032" layer="21"/>
<wire x1="4.3" y1="-1.6" x2="4.3" y2="0" width="0.2032" layer="21"/>
</package>
<package name="SCREWTERMINAL-3.5MM-4_LOCK">
<wire x1="-2.3" y1="3.4" x2="12.8" y2="3.4" width="0.2032" layer="21"/>
<wire x1="12.8" y1="3.4" x2="12.8" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="12.8" y1="-2.8" x2="12.8" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="12.8" y1="-3.6" x2="-2.3" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-2.3" y1="-3.6" x2="-2.3" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-2.3" y1="-2.8" x2="-2.3" y2="3.4" width="0.2032" layer="21"/>
<wire x1="12.8" y1="-2.8" x2="-2.3" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-2.3" y1="-1.35" x2="-2.7" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-2.7" y1="-1.35" x2="-2.7" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-2.7" y1="-2.35" x2="-2.3" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="12.8" y1="3.15" x2="13.2" y2="3.15" width="0.2032" layer="51"/>
<wire x1="13.2" y1="3.15" x2="13.2" y2="2.15" width="0.2032" layer="51"/>
<wire x1="13.2" y1="2.15" x2="12.8" y2="2.15" width="0.2032" layer="51"/>
<pad name="3" x="6.8222" y="0" drill="1.2" diameter="2.032"/>
<pad name="4" x="10.6778" y="0" drill="1.2" diameter="2.032"/>
</package>
<package name="1X04-1MM-RA">
<wire x1="-1.5" y1="-4.6" x2="1.5" y2="-4.6" width="0.254" layer="21"/>
<wire x1="-3" y1="-2" x2="-3" y2="-0.35" width="0.254" layer="21"/>
<wire x1="2.25" y1="-0.35" x2="3" y2="-0.35" width="0.254" layer="21"/>
<wire x1="3" y1="-0.35" x2="3" y2="-2" width="0.254" layer="21"/>
<wire x1="-3" y1="-0.35" x2="-2.25" y2="-0.35" width="0.254" layer="21"/>
<circle x="-2.5" y="0.3" radius="0.1414" width="0.4" layer="21"/>
<smd name="NC2" x="-2.8" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="NC1" x="2.8" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="1" x="-1.5" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="2" x="-0.5" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="3" x="0.5" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="4" x="1.5" y="0" dx="0.6" dy="1.35" layer="1"/>
</package>
<package name="2X4">
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
</package>
<package name="1X05">
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="11.43" y1="0.635" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
<package name="1X05_NO_SILK">
<description>No outline in silkscreen</description>
</package>
<package name="1X05-1.27MM">
<description>Header for OS4000-T</description>
<wire x1="4.191" y1="-0.889" x2="4.445" y2="-0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.699" y2="-0.889" width="0.127" layer="21"/>
<wire x1="4.699" y1="-0.889" x2="5.461" y2="-0.889" width="0.127" layer="21"/>
<wire x1="5.461" y1="0.889" x2="4.699" y2="0.889" width="0.127" layer="21"/>
<wire x1="4.699" y1="0.889" x2="4.445" y2="0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.191" y2="0.889" width="0.127" layer="21"/>
<wire x1="5.461" y1="0.889" x2="5.969" y2="0.381" width="0.127" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.969" y2="-0.381" width="0.127" layer="21"/>
<wire x1="5.969" y1="-0.381" x2="5.461" y2="-0.889" width="0.127" layer="21"/>
<pad name="5" x="5.08" y="0" drill="0.508" diameter="1"/>
</package>
<package name="1X05_LOCK">
<pad name="5" x="10.16" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X05_LOCK_LONGPADS">
<wire x1="9.144" y1="-0.127" x2="8.636" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.127" x2="11.176" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.127" x2="11.43" y2="-1.1176" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-1.1176" x2="11.1506" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.127" x2="11.43" y2="0.8636" width="0.2032" layer="21"/>
<wire x1="11.43" y1="0.8636" x2="11.1506" y2="1.143" width="0.2032" layer="21"/>
<pad name="5" x="10.16" y="0" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="9.8679" y1="-0.4191" x2="10.4521" y2="0.1651" layer="51"/>
</package>
<package name="1X05_LONGPADS">
<pad name="5" x="10.16" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="1X05-1MM">
<wire x1="2" y1="2.921" x2="-2.08" y2="2.921" width="0.254" layer="21"/>
<wire x1="3.778" y1="0.762" x2="3.778" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-2.842" y1="-0.635" x2="-3.858" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-3.858" y1="-0.635" x2="-3.858" y2="0.762" width="0.254" layer="21"/>
<wire x1="3.778" y1="-0.635" x2="2.762" y2="-0.635" width="0.254" layer="21"/>
<smd name="NC2" x="3.3" y="2.225" dx="1.2" dy="1.8" layer="1" rot="R180"/>
<smd name="NC1" x="-3.3" y="2.225" dx="1.2" dy="1.8" layer="1" rot="R180"/>
<smd name="5" x="2" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="4" x="1" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="3" x="0" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="2" x="-1" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="1" x="-2" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<text x="1.73" y="-1.73" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.46" y="-1.73" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X05-1MM-RA">
<wire x1="-2" y1="-4.6" x2="2" y2="-4.6" width="0.254" layer="21"/>
<wire x1="-3.5" y1="-2" x2="-3.5" y2="-0.35" width="0.254" layer="21"/>
<wire x1="2.75" y1="-0.35" x2="3.5" y2="-0.35" width="0.254" layer="21"/>
<wire x1="3.5" y1="-0.35" x2="3.5" y2="-2" width="0.254" layer="21"/>
<wire x1="-3.5" y1="-0.35" x2="-2.75" y2="-0.35" width="0.254" layer="21"/>
<circle x="-3" y="0.3" radius="0.1414" width="0.4" layer="21"/>
<smd name="NC2" x="-3.3" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="NC1" x="3.3" y="-3.675" dx="1.2" dy="2" layer="1"/>
<smd name="1" x="-2" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="2" x="-1" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="3" x="0" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="4" x="1" y="0" dx="0.6" dy="1.35" layer="1"/>
<smd name="5" x="2" y="0" dx="0.6" dy="1.35" layer="1"/>
<text x="-3.27" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="1.54" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="2X5-RA">
<wire x1="-3.175" y1="5.715" x2="-3.175" y2="4.445" width="0.2032" layer="21"/>
<wire x1="2.8" y1="6.3" x2="5.3" y2="6.3" width="0.2032" layer="21"/>
<wire x1="5.3" y1="6.3" x2="5.3" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="5.3" y1="-6.3" x2="2.8" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="2.8" y1="-6.3" x2="2.8" y2="6.3" width="0.2032" layer="21"/>
<wire x1="5.3" y1="0" x2="11.3" y2="0" width="0.127" layer="51"/>
<wire x1="5.3" y1="-2.54" x2="11.3" y2="-2.54" width="0.127" layer="51"/>
<wire x1="5.3" y1="-5.08" x2="11.3" y2="-5.08" width="0.127" layer="51"/>
<wire x1="5.3" y1="2.54" x2="11.3" y2="2.54" width="0.127" layer="51"/>
<wire x1="5.3" y1="5.08" x2="11.3" y2="5.08" width="0.127" layer="51"/>
<wire x1="8.2" y1="7" x2="8.2" y2="-6.9" width="0.127" layer="51"/>
<wire x1="13.8" y1="6.3" x2="13.8" y2="-6.3" width="0.127" layer="51"/>
<wire x1="5.3" y1="6.3" x2="13.8" y2="6.3" width="0.127" layer="51"/>
<wire x1="5.3" y1="-6.3" x2="13.8" y2="-6.3" width="0.127" layer="51"/>
<pad name="1" x="-1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2" y="-8.2" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.9" y="7" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="-1.524" y1="4.826" x2="-1.016" y2="5.334" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="4.826" x2="1.524" y2="5.334" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="2.286" x2="1.524" y2="2.794" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="2.286" x2="-1.016" y2="2.794" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-2.794" x2="1.524" y2="-2.286" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-2.794" x2="-1.016" y2="-2.286" layer="51" rot="R270"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-4.826" layer="51" rot="R270"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-4.826" layer="51" rot="R270"/>
</package>
<package name="2X5-RAF">
<wire x1="2.7" y1="6.3" x2="11.2" y2="6.3" width="0.2032" layer="21"/>
<wire x1="11.2" y1="6.3" x2="11.2" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="11.2" y1="-6.3" x2="2.7" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="2.7" y1="-6.3" x2="2.7" y2="6.3" width="0.2032" layer="21"/>
</package>
<package name="MOLEX-1X6">
<wire x1="13.97" y1="3.048" x2="13.97" y2="-2.54" width="0.127" layer="21"/>
<wire x1="13.97" y1="3.048" x2="-1.27" y2="3.048" width="0.127" layer="21"/>
<wire x1="13.97" y1="-2.54" x2="12.7" y2="-2.54" width="0.127" layer="21"/>
<wire x1="12.7" y1="-2.54" x2="0" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0" y1="-1.27" x2="12.7" y2="-1.27" width="0.127" layer="21"/>
<wire x1="12.7" y1="-1.27" x2="12.7" y2="-2.54" width="0.127" layer="21"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796"/>
</package>
<package name="MOLEX-1X6-RA">
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="3.175" width="0.127" layer="21"/>
<wire x1="13.97" y1="0.635" x2="-1.27" y2="0.635" width="0.127" layer="21"/>
<wire x1="13.97" y1="3.175" x2="12.7" y2="3.175" width="0.127" layer="21"/>
<wire x1="12.7" y1="3.175" x2="0" y2="3.175" width="0.127" layer="21"/>
<wire x1="0" y1="3.175" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="0" y1="3.175" x2="0" y2="7.62" width="0.127" layer="21"/>
<wire x1="0" y1="7.62" x2="12.7" y2="7.62" width="0.127" layer="21"/>
<wire x1="12.7" y1="7.62" x2="12.7" y2="3.175" width="0.127" layer="21"/>
<text x="-0.889" y="-2.794" size="1.27" layer="25">&gt;NAME</text>
<text x="8.001" y="-2.794" size="1.27" layer="25">&gt;VALUE</text>
</package>
<package name="1X06_LOCK_LONGPADS">
<wire x1="11.684" y1="-0.127" x2="11.176" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.127" x2="13.716" y2="-0.127" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.127" x2="13.97" y2="-1.1176" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-1.1176" x2="13.6906" y2="-1.397" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.127" x2="13.97" y2="0.8636" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0.8636" x2="13.6906" y2="1.143" width="0.2032" layer="21"/>
<pad name="6" x="12.7" y="-0.254" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="12.4079" y1="-0.4191" x2="12.9921" y2="0.1651" layer="51"/>
</package>
<package name="MOLEX-1X6_LOCK">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796"/>
<pad name="2" x="2.54" y="-0.254" drill="1.016" diameter="1.8796"/>
<pad name="4" x="7.62" y="-0.254" drill="1.016" diameter="1.8796"/>
<pad name="6" x="12.7" y="-0.254" drill="1.016" diameter="1.8796"/>
<text x="-1.27" y="3.302" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-4.064" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="7.3279" y1="-0.4191" x2="7.9121" y2="0.1651" layer="51"/>
</package>
<package name="1X06-SIP_LOCK">
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0.635" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<text x="-1.27" y="1.524" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27" font="vector">&gt;VALUE</text>
</package>
<package name="1X06_FEMALE_LOCK.010">
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="13.97" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-1.27" x2="-1.27" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.97" y1="1.27" x2="13.97" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="-0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="-0.254" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="-0.3175" y1="-0.1905" x2="0.3175" y2="0.1905" layer="51"/>
<rectangle x1="2.2225" y1="-0.1905" x2="2.8575" y2="0.1905" layer="51"/>
<rectangle x1="4.7625" y1="-0.1905" x2="5.3975" y2="0.1905" layer="51"/>
<rectangle x1="7.3025" y1="-0.1905" x2="7.9375" y2="0.1905" layer="51"/>
<rectangle x1="9.8425" y1="-0.1905" x2="10.4775" y2="0.1905" layer="51"/>
<rectangle x1="12.3825" y1="-0.1905" x2="13.0175" y2="0.1905" layer="51"/>
</package>
<package name="1X06-SMD_EDGE">
<wire x1="13.97" y1="-2.54" x2="-1.27" y2="-2.54" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-2.54" x2="-1.27" y2="-11.176" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-11.176" x2="13.97" y2="-11.176" width="0.127" layer="51"/>
<wire x1="13.97" y1="-11.176" x2="13.97" y2="-2.54" width="0.127" layer="51"/>
<smd name="4" x="7.62" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="5" x="10.16" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="6" x="12.7" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="3" x="5.08" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="2" x="2.54" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="1" x="0" y="-0.08" dx="3" dy="1" layer="1" rot="R90"/>
<text x="0" y="-6.35" size="0.4064" layer="51">thru-hole vertical Female Header</text>
<text x="0" y="-7.62" size="0.4064" layer="51">used as an SMD part </text>
<text x="0" y="-8.89" size="0.4064" layer="51">(placed horizontally, at board's edge)</text>
<rectangle x1="-0.381" y1="-2.4892" x2="0.381" y2="0.2794" layer="51"/>
<rectangle x1="2.159" y1="-2.4892" x2="2.921" y2="0.2794" layer="51"/>
<rectangle x1="4.699" y1="-2.4892" x2="5.461" y2="0.2794" layer="51"/>
<rectangle x1="7.239" y1="-2.4892" x2="8.001" y2="0.2794" layer="51"/>
<rectangle x1="9.779" y1="-2.4892" x2="10.541" y2="0.2794" layer="51"/>
<rectangle x1="12.319" y1="-2.4892" x2="13.081" y2="0.2794" layer="51"/>
</package>
<package name="SCREWTERMINAL-3.5MM-6">
<wire x1="-1.75" y1="3.4" x2="19.25" y2="3.4" width="0.2032" layer="21"/>
<wire x1="19.25" y1="3.4" x2="19.25" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="19.25" y1="-2.8" x2="19.25" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="19.25" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="19.25" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="19.25" y1="3.15" x2="19.75" y2="3.15" width="0.2032" layer="51"/>
<wire x1="19.75" y1="3.15" x2="19.75" y2="2.15" width="0.2032" layer="51"/>
<wire x1="19.75" y1="2.15" x2="19.25" y2="2.15" width="0.2032" layer="51"/>
<pad name="5" x="14" y="0" drill="1.2" diameter="2.032"/>
<pad name="6" x="17.5" y="0" drill="1.2" diameter="2.032"/>
</package>
<package name="1X06-SMD-FEMALE">
<wire x1="-7.62" y1="4.05" x2="7.62" y2="4.05" width="0.2032" layer="51"/>
<wire x1="7.62" y1="4.05" x2="7.62" y2="-4.05" width="0.2032" layer="51"/>
<wire x1="7.62" y1="-4.05" x2="-7.62" y2="-4.05" width="0.2032" layer="51"/>
<wire x1="-7.62" y1="-4.05" x2="-7.62" y2="4.05" width="0.2032" layer="51"/>
<wire x1="-6.85" y1="-3" x2="-6.85" y2="-2" width="0.2032" layer="21"/>
<wire x1="-6.85" y1="-2" x2="-5.85" y2="-2" width="0.2032" layer="21"/>
<wire x1="-5.85" y1="-2" x2="-5.85" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.1" y1="4" x2="-7.6" y2="4" width="0.2032" layer="21"/>
<wire x1="-7.6" y1="4" x2="-7.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="-7.6" y1="-4" x2="-7.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="7.1" y1="4" x2="7.6" y2="4" width="0.2032" layer="21"/>
<wire x1="7.6" y1="4" x2="7.6" y2="-4" width="0.2032" layer="21"/>
<wire x1="7.6" y1="-4" x2="7.1" y2="-4" width="0.2032" layer="21"/>
<wire x1="-0.3" y1="4" x2="0.3" y2="4" width="0.2032" layer="21"/>
<wire x1="-2.8" y1="4" x2="-2.2" y2="4" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="4" x2="-4.8" y2="4" width="0.2032" layer="21"/>
<wire x1="2.3" y1="4" x2="2.9" y2="4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="4" x2="5.4" y2="4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="-4" x2="5.4" y2="-4" width="0.2032" layer="21"/>
<wire x1="2.2" y1="-4" x2="2.8" y2="-4" width="0.2032" layer="21"/>
<wire x1="-0.3" y1="-4" x2="0.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-2.8" y1="-4" x2="-2.2" y2="-4" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-4" x2="-4.8" y2="-4" width="0.2032" layer="21"/>
<smd name="6" x="6.35" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="5" x="3.81" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="4" x="1.27" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="3" x="-1.27" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="2" x="-3.81" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="1" x="-6.35" y="-4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A1" x="-6.35" y="4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A2" x="-3.81" y="4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A3" x="-1.27" y="4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A4" x="1.27" y="4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A5" x="3.81" y="4.62" dx="1.02" dy="2.16" layer="1"/>
<smd name="A6" x="6.35" y="4.62" dx="1.02" dy="2.16" layer="1"/>
</package>
<package name="1X06-SMD-FEMALE-V2">
<description>Package for 4UCONN part #19686&lt;br /&gt;
Used on FTDI breakouts</description>
<wire x1="-7.5" y1="0.45" x2="-7.5" y2="-8.05" width="0.127" layer="21"/>
<wire x1="7.5" y1="0.45" x2="-7.5" y2="0.45" width="0.127" layer="21"/>
<wire x1="7.5" y1="-8.05" x2="7.5" y2="0.45" width="0.127" layer="21"/>
<wire x1="-7.5" y1="-8.05" x2="7.5" y2="-8.05" width="0.127" layer="21"/>
<smd name="4" x="-1.27" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="5" x="-3.81" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="6" x="-6.35" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="3" x="1.27" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="2" x="3.81" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="1" x="6.35" y="3.425" dx="1.25" dy="3" layer="1" rot="R180"/>
<text x="7.6" y="-8.3" size="1" layer="27" rot="R180">&gt;Value</text>
<text x="-7.4" y="-9.3" size="1" layer="25">&gt;Name</text>
</package>
<package name="1X06_HOLES_ONLY">
<circle x="7.62" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="10.16" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="12.7" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="3" x="5.08" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<hole x="7.62" y="0" drill="1.4732"/>
<hole x="10.16" y="0" drill="1.4732"/>
<hole x="12.7" y="0" drill="1.4732"/>
</package>
<package name="1X06_SMD_STRAIGHT">
<wire x1="1.37" y1="1.25" x2="-14.07" y2="1.25" width="0.127" layer="51"/>
<wire x1="-14.07" y1="1.25" x2="-14.07" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-14.07" y1="-1.25" x2="1.37" y2="-1.25" width="0.127" layer="51"/>
<wire x1="1.37" y1="-1.25" x2="1.37" y2="1.25" width="0.127" layer="51"/>
<wire x1="1.37" y1="1.25" x2="1.37" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-14.07" y1="-1.25" x2="-14.07" y2="1.25" width="0.127" layer="21"/>
<wire x1="0.85" y1="1.25" x2="1.37" y2="1.25" width="0.127" layer="21"/>
<wire x1="-14.07" y1="1.25" x2="-10.883" y2="1.25" width="0.127" layer="21"/>
<wire x1="-13.55" y1="-1.25" x2="-14.07" y2="-1.25" width="0.127" layer="21"/>
<wire x1="1.37" y1="-1.25" x2="-1.817" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-4.377" y1="1.25" x2="-0.703" y2="1.25" width="0.127" layer="21"/>
<wire x1="-9.457" y1="1.25" x2="-5.783" y2="1.25" width="0.127" layer="21"/>
<wire x1="-3.329" y1="-1.25" x2="-6.831" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-8.409" y1="-1.25" x2="-11.911" y2="-1.25" width="0.127" layer="21"/>
<smd name="5" x="-10.16" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="3" x="-5.08" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="1" x="0" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="6" x="-12.7" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="4" x="-7.62" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-2.54" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<text x="-13.97" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-13.97" y="-4.191" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X06_SMD_STRAIGHT_ALT">
<wire x1="-14.07" y1="1.25" x2="-14.07" y2="-1.25" width="0.127" layer="21"/>
<wire x1="1.37" y1="-1.25" x2="1.37" y2="1.25" width="0.127" layer="21"/>
<wire x1="-13.55" y1="1.25" x2="-14.07" y2="1.25" width="0.127" layer="21"/>
<wire x1="1.37" y1="1.25" x2="-1.817" y2="1.25" width="0.127" layer="21"/>
<wire x1="0.85" y1="-1.25" x2="1.37" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-14.07" y1="-1.25" x2="-10.883" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-8.323" y1="1.25" x2="-11.997" y2="1.25" width="0.127" layer="21"/>
<wire x1="-3.243" y1="1.25" x2="-6.917" y2="1.25" width="0.127" layer="21"/>
<wire x1="-9.371" y1="-1.25" x2="-5.869" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-4.291" y1="-1.25" x2="-0.789" y2="-1.25" width="0.127" layer="21"/>
<smd name="5" x="-10.16" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="3" x="-5.08" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1" x="0" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="6" x="-12.7" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="4" x="-7.62" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2" x="-2.54" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
</package>
<package name="1X06_SMD_STRAIGHT_COMBO">
<wire x1="12.7" y1="1.27" x2="12.7" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="10.16" y1="1.27" x2="10.16" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="0" y1="1.27" x2="0" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="-1.37" y1="-1.25" x2="-1.37" y2="1.25" width="0.1778" layer="21"/>
<wire x1="14.07" y1="1.25" x2="14.07" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="-0.73" y1="-1.25" x2="-1.37" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="14.07" y1="-1.25" x2="13.4" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="13.4" y1="1.25" x2="14.07" y2="1.25" width="0.1778" layer="21"/>
<wire x1="-1.37" y1="1.25" x2="-0.73" y2="1.25" width="0.1778" layer="21"/>
<wire x1="10.949" y1="1.25" x2="11.911" y2="1.25" width="0.1778" layer="21"/>
<wire x1="10.949" y1="-1.29" x2="11.911" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="8.409" y1="1.25" x2="9.371" y2="1.25" width="0.1778" layer="21"/>
<wire x1="8.409" y1="-1.29" x2="9.371" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="5.869" y1="-1.29" x2="6.831" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="5.869" y1="1.25" x2="6.831" y2="1.25" width="0.1778" layer="21"/>
<wire x1="3.329" y1="-1.29" x2="4.291" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="3.329" y1="1.25" x2="4.291" y2="1.25" width="0.1778" layer="21"/>
<wire x1="0.789" y1="-1.29" x2="1.751" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="0.789" y1="1.25" x2="1.751" y2="1.25" width="0.1778" layer="21"/>
<smd name="5" x="10.16" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="3" x="5.08" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="6" x="12.7" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="4" x="7.62" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2" x="2.54" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1-2" x="0" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="2-2" x="2.54" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="3-2" x="5.08" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="4-2" x="7.62" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="5-2" x="10.16" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="6-2" x="12.7" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<text x="0" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="-4.191" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X07">
<wire x1="14.605" y1="1.27" x2="15.875" y2="1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0.635" x2="16.51" y2="-0.635" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
</package>
<package name="1X07_LOCK">
<pad name="6" x="12.7" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X07_LOCK_LONGPADS">
<wire x1="1.524" y1="0" x2="1.016" y2="0" width="0.2032" layer="21"/>
<wire x1="4.064" y1="0" x2="3.556" y2="0" width="0.2032" layer="21"/>
<wire x1="6.604" y1="0" x2="6.096" y2="0" width="0.2032" layer="21"/>
<wire x1="9.144" y1="0" x2="8.636" y2="0" width="0.2032" layer="21"/>
<wire x1="11.684" y1="0" x2="11.176" y2="0" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0" x2="16.256" y2="0" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0" x2="16.51" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.9906" x2="16.2306" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0" x2="16.51" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0.9906" x2="16.2306" y2="1.27" width="0.2032" layer="21"/>
<wire x1="14.224" y1="0" x2="13.716" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0.127" drill="1.016" shape="long" rot="R90"/>
<text x="-1.27" y="1.905" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="7.3279" y1="-0.2921" x2="7.9121" y2="0.2921" layer="51" rot="R90"/>
<rectangle x1="9.8679" y1="-0.2921" x2="10.4521" y2="0.2921" layer="51"/>
<rectangle x1="12.4079" y1="-0.2921" x2="12.9921" y2="0.2921" layer="51"/>
<rectangle x1="14.9479" y1="-0.2921" x2="15.5321" y2="0.2921" layer="51"/>
</package>
<package name="1X07_LONGPADS">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="1X07_HOLES_ONLY">
<circle x="0" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="15.24" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="7" x="15.24" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<hole x="0" y="0" drill="1.4732"/>
<hole x="15.24" y="0" drill="1.4732"/>
</package>
<package name="1X08">
<wire x1="17.145" y1="1.27" x2="18.415" y2="1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.05" y2="0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0.635" x2="19.05" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
</package>
<package name="1X08_LOCK">
<pad name="8" x="17.78" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X08_LOCK_LONGPADS">
<wire x1="-1.27" y1="0" x2="-1.016" y2="0" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.9906" x2="-0.9906" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.9906" x2="-0.9906" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="16.764" y1="0" x2="16.256" y2="0" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0" x2="19.05" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.9906" x2="18.7706" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0" x2="19.05" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0.9906" x2="18.7706" y2="1.27" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0" x2="18.796" y2="0" width="0.2032" layer="21"/>
<pad name="8" x="17.78" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="-0.2921" y1="-0.2921" x2="0.2921" y2="0.2921" layer="51"/>
<rectangle x1="2.2479" y1="-0.2921" x2="2.8321" y2="0.2921" layer="51"/>
<rectangle x1="17.4879" y1="-0.2921" x2="18.0721" y2="0.2921" layer="51"/>
</package>
<package name="1X08_LONGPADS">
<pad name="1" x="0" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="SCREWTERMINAL-3.5MM-8">
<wire x1="-1.75" y1="3.4" x2="26.25" y2="3.4" width="0.2032" layer="21"/>
<wire x1="26.25" y1="3.4" x2="26.25" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="26.25" y1="-2.8" x2="26.25" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="26.25" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-3.6" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-2.8" x2="-1.75" y2="3.4" width="0.2032" layer="21"/>
<wire x1="26.25" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-1.35" x2="-2.25" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.35" x2="-2.25" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-2.35" x2="-1.75" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="26.25" y1="3.15" x2="26.75" y2="3.15" width="0.2032" layer="51"/>
<wire x1="26.75" y1="3.15" x2="26.75" y2="2.15" width="0.2032" layer="51"/>
<wire x1="26.75" y1="2.15" x2="26.25" y2="2.15" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.2" diameter="2.032" shape="square"/>
<pad name="2" x="3.5" y="0" drill="1.2" diameter="2.032"/>
<pad name="7" x="21" y="0" drill="1.2" diameter="2.032"/>
<pad name="8" x="24.5" y="0" drill="1.2" diameter="2.032"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X08_SMD">
<wire x1="1.37" y1="1.25" x2="-19.15" y2="1.25" width="0.127" layer="51"/>
<wire x1="-19.15" y1="1.25" x2="-19.15" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-19.15" y1="-1.25" x2="1.37" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-19.15" y1="-1.25" x2="-19.15" y2="1.25" width="0.127" layer="21"/>
<wire x1="-19.15" y1="1.25" x2="-15.963" y2="1.25" width="0.127" layer="21"/>
<wire x1="-18.63" y1="-1.25" x2="-19.15" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-14.537" y1="1.25" x2="-10.863" y2="1.25" width="0.127" layer="21"/>
<wire x1="-13.489" y1="-1.25" x2="-16.991" y2="-1.25" width="0.127" layer="21"/>
<smd name="7" x="-15.24" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="8" x="-17.78" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<text x="-19.05" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-19.05" y="-4.191" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X08_SMD_ALT">
<wire x1="-19.15" y1="1.25" x2="-19.15" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-18.63" y1="1.25" x2="-19.15" y2="1.25" width="0.127" layer="21"/>
<wire x1="-19.15" y1="-1.25" x2="-15.963" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-13.403" y1="1.25" x2="-17.077" y2="1.25" width="0.127" layer="21"/>
<wire x1="-14.451" y1="-1.25" x2="-10.949" y2="-1.25" width="0.127" layer="21"/>
<smd name="7" x="-15.24" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="8" x="-17.78" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
</package>
<package name="1X08_SMD_COMBINED">
<wire x1="-1.37" y1="-1.25" x2="-1.37" y2="1.25" width="0.127" layer="21"/>
<wire x1="19.15" y1="1.25" x2="19.15" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-0.85" y1="-1.25" x2="-1.37" y2="-1.25" width="0.127" layer="21"/>
<wire x1="19.15" y1="-1.25" x2="18.503" y2="-1.25" width="0.127" layer="21"/>
<wire x1="18.63" y1="1.25" x2="19.15" y2="1.25" width="0.127" layer="21"/>
<wire x1="-1.37" y1="1.25" x2="-0.723" y2="1.25" width="0.127" layer="21"/>
<wire x1="14.537" y1="-1.25" x2="13.403" y2="-1.25" width="0.127" layer="21"/>
<wire x1="0.789" y1="1.25" x2="1.751" y2="1.25" width="0.127" layer="21"/>
<wire x1="3.329" y1="1.25" x2="4.291" y2="1.25" width="0.127" layer="21"/>
<wire x1="5.869" y1="1.25" x2="6.831" y2="1.25" width="0.127" layer="21"/>
<wire x1="8.409" y1="1.25" x2="9.371" y2="1.25" width="0.127" layer="21"/>
<wire x1="10.949" y1="1.25" x2="11.911" y2="1.25" width="0.127" layer="21"/>
<wire x1="13.489" y1="1.25" x2="14.451" y2="1.25" width="0.127" layer="21"/>
<wire x1="16.029" y1="1.25" x2="16.991" y2="1.25" width="0.127" layer="21"/>
<wire x1="17.077" y1="-1.25" x2="15.943" y2="-1.25" width="0.127" layer="21"/>
<wire x1="11.997" y1="-1.25" x2="10.863" y2="-1.25" width="0.127" layer="21"/>
<wire x1="9.457" y1="-1.25" x2="8.323" y2="-1.25" width="0.127" layer="21"/>
<wire x1="6.917" y1="-1.25" x2="5.783" y2="-1.25" width="0.127" layer="21"/>
<wire x1="4.377" y1="-1.25" x2="3.243" y2="-1.25" width="0.127" layer="21"/>
<wire x1="1.837" y1="-1.25" x2="0.703" y2="-1.25" width="0.127" layer="21"/>
<wire x1="17.78" y1="1.27" x2="17.78" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="15.24" y1="1.27" x2="15.24" y2="-1.27" width="0.4064" layer="1"/>
<smd name="7@2" x="15.24" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="5@2" x="10.16" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="3@2" x="5.08" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="8@2" x="17.78" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="6@2" x="12.7" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="4@2" x="7.62" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2@2" x="2.54" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2" x="2.54" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="3" x="5.08" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="4" x="7.62" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="5" x="10.16" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="6" x="12.7" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="7" x="15.24" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="8" x="17.78" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1@2" x="0" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
</package>
<package name="BM08B-SRSS-TB">
<description>JST crimp connector: 1mm pitch, top entry</description>
<wire x1="-5" y1="3.3" x2="5" y2="3.3" width="0.127" layer="51"/>
<wire x1="-5" y1="0.4" x2="-5" y2="3.3" width="0.127" layer="51"/>
<wire x1="5" y1="0.4" x2="5" y2="3.3" width="0.127" layer="51"/>
<wire x1="-5" y1="0.4" x2="5" y2="0.4" width="0.127" layer="51"/>
<wire x1="-4.1" y1="0.35" x2="-5.05" y2="0.35" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="0.35" x2="-5.05" y2="1.35" width="0.2032" layer="21"/>
<wire x1="5.05" y1="0.35" x2="4.15" y2="0.35" width="0.2032" layer="21"/>
<wire x1="5.05" y1="0.35" x2="5.05" y2="1.35" width="0.2032" layer="21"/>
<wire x1="-3.9" y1="3.4" x2="3.9" y2="3.4" width="0.2032" layer="21"/>
<circle x="-4.4" y="-0.35" radius="0.1118" width="0.4064" layer="21"/>
<smd name="1" x="-3.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="2" x="-2.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="3" x="-1.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="4" x="-0.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="5" x="0.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="6" x="1.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="7" x="2.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="8" x="3.5" y="0" dx="0.6" dy="1.55" layer="1" rot="R180"/>
<smd name="P$9" x="4.8" y="2.525" dx="1.8" dy="1.2" layer="1" rot="R90"/>
<smd name="P$10" x="-4.8" y="2.525" dx="1.8" dy="1.2" layer="1" rot="R90"/>
<text x="-3.8" y="2.5" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.8" y="1.3" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="2X8">
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.27" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-0.635" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.1524" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.81" x2="3.81" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.81" y1="3.175" x2="4.445" y2="3.81" width="0.1524" layer="21"/>
<wire x1="4.445" y1="3.81" x2="5.715" y2="3.81" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.81" x2="6.35" y2="3.175" width="0.1524" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.985" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.81" x2="8.255" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.255" y1="3.81" x2="8.89" y2="3.175" width="0.1524" layer="21"/>
<wire x1="8.89" y1="3.175" x2="9.525" y2="3.81" width="0.1524" layer="21"/>
<wire x1="9.525" y1="3.81" x2="10.795" y2="3.81" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.81" x2="11.43" y2="3.175" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.175" x2="12.065" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.065" y1="3.81" x2="13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.97" y2="3.175" width="0.1524" layer="21"/>
<wire x1="13.97" y1="3.175" x2="14.605" y2="3.81" width="0.1524" layer="21"/>
<wire x1="14.605" y1="3.81" x2="15.875" y2="3.81" width="0.1524" layer="21"/>
<wire x1="15.875" y1="3.81" x2="16.51" y2="3.175" width="0.1524" layer="21"/>
<wire x1="16.51" y1="3.175" x2="17.145" y2="3.81" width="0.1524" layer="21"/>
<wire x1="17.145" y1="3.81" x2="18.415" y2="3.81" width="0.1524" layer="21"/>
<wire x1="18.415" y1="3.81" x2="19.05" y2="3.175" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="8.89" y1="3.175" x2="8.89" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.175" x2="11.43" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="13.97" y1="3.175" x2="13.97" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="16.51" y1="3.175" x2="16.51" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="19.05" y1="3.175" x2="19.05" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="0" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="2.54" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="2.54" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="5.08" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="5.08" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="7.62" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="7.62" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="10.16" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="10.16" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="12.7" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="12.7" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="15.24" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="15.24" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="17.78" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="17.78" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-1.27" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-0.254" y1="2.286" x2="0.254" y2="2.794" layer="51"/>
<rectangle x1="2.286" y1="2.286" x2="2.794" y2="2.794" layer="51"/>
<rectangle x1="4.826" y1="2.286" x2="5.334" y2="2.794" layer="51"/>
<rectangle x1="7.366" y1="2.286" x2="7.874" y2="2.794" layer="51"/>
<rectangle x1="9.906" y1="2.286" x2="10.414" y2="2.794" layer="51"/>
<rectangle x1="12.446" y1="2.286" x2="12.954" y2="2.794" layer="51"/>
<rectangle x1="14.986" y1="2.286" x2="15.494" y2="2.794" layer="51"/>
<rectangle x1="17.526" y1="2.286" x2="18.034" y2="2.794" layer="51"/>
</package>
<package name="1X09">
<wire x1="19.685" y1="1.27" x2="20.955" y2="1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="1.27" x2="19.05" y2="0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0.635" x2="21.59" y2="-0.635" width="0.2032" layer="21"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
</package>
<package name="1X09_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X09_LOCK_LONGPADS">
<wire x1="19.304" y1="0" x2="18.796" y2="0" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0" x2="21.59" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.9906" x2="21.3106" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0" x2="21.59" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0.9906" x2="21.3106" y2="1.27" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0" x2="21.336" y2="0" width="0.2032" layer="21"/>
<pad name="9" x="20.32" y="0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="4.7879" y1="-0.2921" x2="5.3721" y2="0.2921" layer="51"/>
<rectangle x1="20.0279" y1="-0.2921" x2="20.6121" y2="0.2921" layer="51"/>
</package>
<package name="1X09_LONGPADS">
<pad name="2" x="2.54" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-1.3462" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X10">
<wire x1="22.225" y1="1.27" x2="23.495" y2="1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0.635" x2="24.13" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
</package>
<package name="1X10-2MM">
<wire x1="-1.25" y1="1.25" x2="19.25" y2="1.25" width="0.2032" layer="21"/>
<wire x1="19.25" y1="-1.25" x2="-1.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="1.25" x2="-1.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="19.25" y1="1.25" x2="19.25" y2="-1.25" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="0.8" shape="square" rot="R90"/>
<pad name="2" x="2" y="0" drill="0.8" rot="R90"/>
<pad name="3" x="4" y="0" drill="0.8" rot="R90"/>
<pad name="4" x="6" y="0" drill="0.8" rot="R90"/>
<pad name="5" x="8" y="0" drill="0.8" rot="R90"/>
<pad name="6" x="10" y="0" drill="0.8" rot="R90"/>
<pad name="7" x="12" y="0" drill="0.8" rot="R90"/>
<pad name="8" x="14" y="0" drill="0.8" rot="R90"/>
<pad name="9" x="16" y="0" drill="0.8" rot="R90"/>
<pad name="10" x="18" y="0" drill="0.8" rot="R90"/>
<rectangle x1="3.746" y1="-0.254" x2="4.254" y2="0.254" layer="51"/>
<rectangle x1="1.746" y1="-0.254" x2="2.254" y2="0.254" layer="51"/>
<rectangle x1="5.746" y1="-0.254" x2="6.254" y2="0.254" layer="51"/>
<rectangle x1="7.746" y1="-0.254" x2="8.254" y2="0.254" layer="51"/>
<rectangle x1="9.746" y1="-0.254" x2="10.254" y2="0.254" layer="51"/>
<rectangle x1="11.746" y1="-0.254" x2="12.254" y2="0.254" layer="51"/>
<rectangle x1="13.746" y1="-0.254" x2="14.254" y2="0.254" layer="51"/>
<rectangle x1="15.746" y1="-0.254" x2="16.254" y2="0.254" layer="51"/>
<rectangle x1="17.746" y1="-0.254" x2="18.254" y2="0.254" layer="51"/>
</package>
<package name="1X10-2MM-SMD">
<wire x1="-1.25" y1="1.25" x2="19.25" y2="1.25" width="0.2032" layer="51"/>
<wire x1="19.25" y1="-1.25" x2="-1.25" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="-1.25" y1="1.25" x2="-1.25" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="19.25" y1="1.25" x2="19.25" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="-1.25" y1="1.25" x2="-0.7" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.25" y1="-1.25" x2="-0.7" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="18.6" y1="-1.25" x2="19.25" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="19.25" y1="-1.25" x2="19.25" y2="1.25" width="0.2032" layer="21"/>
<wire x1="19.25" y1="1.25" x2="18.6" y2="1.25" width="0.2032" layer="21"/>
<smd name="1" x="0" y="-1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="2" x="2" y="1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="3" x="4" y="-1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="4" x="6" y="1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="5" x="8" y="-1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="6" x="10" y="1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="7" x="12" y="-1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="8" x="14" y="1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="9" x="16" y="-1.5" dx="0.85" dy="2.1" layer="1"/>
<smd name="10" x="18" y="1.5" dx="0.85" dy="2.1" layer="1"/>
<text x="1.143" y="1.524" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="4.953" y="1.524" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="1X10_LOCK">
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X10_LOCK_LONGPADS">
<wire x1="21.844" y1="0" x2="21.336" y2="0" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0" x2="24.13" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.9906" x2="23.8506" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0" x2="24.13" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0.9906" x2="23.8506" y2="1.27" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0" x2="23.876" y2="0" width="0.2032" layer="21"/>
<pad name="10" x="22.86" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="22.5679" y1="-0.2921" x2="23.1521" y2="0.2921" layer="51" rot="R90"/>
</package>
<package name="2X10">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-12.7" y1="-1.905" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.54" x2="12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.7" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="-6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="-6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="-3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="-3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="-1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="17" x="8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="18" x="8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="19" x="11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="20" x="11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-12.7" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.7" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-11.684" y1="-1.524" x2="-11.176" y2="-1.016" layer="51"/>
<rectangle x1="-11.684" y1="1.016" x2="-11.176" y2="1.524" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
<rectangle x1="11.176" y1="1.016" x2="11.684" y2="1.524" layer="51"/>
<rectangle x1="11.176" y1="-1.524" x2="11.684" y2="-1.016" layer="51"/>
</package>
<package name="2X10_LOCK">
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-11.43" y="1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-8.89" y="-1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-8.89" y="1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="-6.35" y="-1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="-6.35" y="1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="-3.81" y="-1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="-3.81" y="1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="-1.27" y="-1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="-1.27" y="1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="1.27" y="-1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="1.27" y="1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="3.81" y="-1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="3.81" y="1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="6.35" y="-1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="6.35" y="1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="17" x="8.89" y="-1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="18" x="8.89" y="1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="19" x="11.43" y="-1.397" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="20" x="11.43" y="1.143" drill="1.016" diameter="1.8796" shape="octagon"/>
</package>
<package name="2X10_LOCK_SPECIAL">
<wire x1="-12.7" y1="-2.0574" x2="-12.065" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.6924" x2="-10.16" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.0574" x2="-9.525" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.6924" x2="-7.62" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.0574" x2="-6.985" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.6924" x2="-5.08" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.0574" x2="-4.445" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.6924" x2="-2.54" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.0574" x2="-1.905" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.6924" x2="0" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="0" y1="-2.0574" x2="0.635" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.6924" x2="2.54" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.0574" x2="-12.7" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.0574" x2="-12.065" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.6924" x2="-10.795" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.6924" x2="-10.16" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.0574" x2="-9.525" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.6924" x2="-8.255" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.6924" x2="-7.62" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.0574" x2="-6.985" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.6924" x2="-5.715" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.6924" x2="-5.08" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.0574" x2="-4.445" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.6924" x2="-3.175" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.6924" x2="-2.54" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.0574" x2="-1.905" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.6924" x2="-0.635" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.6924" x2="0" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="0" y1="2.0574" x2="0.635" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.6924" x2="1.905" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.6924" x2="2.54" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.0574" x2="3.175" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.6924" x2="4.445" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.6924" x2="5.08" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.0574" x2="5.715" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.6924" x2="6.985" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.6924" x2="7.62" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="7.62" y1="2.0574" x2="8.255" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.6924" x2="9.525" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.6924" x2="10.16" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-2.0574" x2="9.525" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.0574" x2="8.255" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.0574" x2="6.985" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.0574" x2="5.715" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.0574" x2="4.445" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-2.0574" x2="3.175" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.0574" x2="-10.16" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.0574" x2="-7.62" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.0574" x2="-5.08" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.0574" x2="-2.54" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="0" y1="2.0574" x2="0" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.0574" x2="2.54" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.0574" x2="5.08" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="7.62" y1="2.0574" x2="7.62" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.0574" x2="10.16" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.6924" x2="9.525" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.6924" x2="6.985" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.6924" x2="4.445" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.6924" x2="1.905" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.6924" x2="-0.635" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.6924" x2="-3.175" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.6924" x2="-5.715" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.6924" x2="-8.255" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.6924" x2="-10.795" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.0574" x2="10.795" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.6924" x2="12.065" y2="2.6924" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.6924" x2="12.7" y2="2.0574" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-2.0574" x2="12.065" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-2.0574" x2="10.795" y2="-2.6924" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.0574" x2="12.7" y2="-2.0574" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.6924" x2="12.065" y2="-2.6924" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-11.43" y="1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-8.89" y="-1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-8.89" y="1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="-6.35" y="-1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="-6.35" y="1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="-3.81" y="-1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="-3.81" y="1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="-1.27" y="-1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="-1.27" y="1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="1.27" y="-1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="1.27" y="1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="3.81" y="-1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="3.81" y="1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="6.35" y="-1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="6.35" y="1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="17" x="8.89" y="-1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="18" x="8.89" y="1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="19" x="11.43" y="-1.6764" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="20" x="11.43" y="1.4224" drill="1.016" diameter="1.8796" shape="octagon"/>
<rectangle x1="-11.684" y1="-1.8034" x2="-11.176" y2="-1.2954" layer="51"/>
<rectangle x1="-11.684" y1="1.2954" x2="-11.176" y2="1.8034" layer="51"/>
<rectangle x1="-9.144" y1="1.2954" x2="-8.636" y2="1.8034" layer="51"/>
<rectangle x1="-9.144" y1="-1.8034" x2="-8.636" y2="-1.2954" layer="51"/>
<rectangle x1="-6.604" y1="1.2954" x2="-6.096" y2="1.8034" layer="51"/>
<rectangle x1="-6.604" y1="-1.8034" x2="-6.096" y2="-1.2954" layer="51"/>
<rectangle x1="-4.064" y1="1.2954" x2="-3.556" y2="1.8034" layer="51"/>
<rectangle x1="-1.524" y1="1.2954" x2="-1.016" y2="1.8034" layer="51"/>
<rectangle x1="1.016" y1="1.2954" x2="1.524" y2="1.8034" layer="51"/>
<rectangle x1="-4.064" y1="-1.8034" x2="-3.556" y2="-1.2954" layer="51"/>
<rectangle x1="-1.524" y1="-1.8034" x2="-1.016" y2="-1.2954" layer="51"/>
<rectangle x1="1.016" y1="-1.8034" x2="1.524" y2="-1.2954" layer="51"/>
<rectangle x1="3.556" y1="1.2954" x2="4.064" y2="1.8034" layer="51"/>
<rectangle x1="3.556" y1="-1.8034" x2="4.064" y2="-1.2954" layer="51"/>
<rectangle x1="6.096" y1="1.2954" x2="6.604" y2="1.8034" layer="51"/>
<rectangle x1="6.096" y1="-1.8034" x2="6.604" y2="-1.2954" layer="51"/>
<rectangle x1="8.636" y1="1.2954" x2="9.144" y2="1.8034" layer="51"/>
<rectangle x1="8.636" y1="-1.8034" x2="9.144" y2="-1.2954" layer="51"/>
<rectangle x1="11.176" y1="1.2954" x2="11.684" y2="1.8034" layer="51"/>
<rectangle x1="11.176" y1="-1.8034" x2="11.684" y2="-1.2954" layer="51"/>
<rectangle x1="-14.224" y1="1.2954" x2="-13.716" y2="1.8034" layer="51"/>
<rectangle x1="-14.224" y1="-1.8034" x2="-13.716" y2="-1.2954" layer="51"/>
<rectangle x1="13.716" y1="1.2954" x2="14.224" y2="1.8034" layer="51"/>
<rectangle x1="13.716" y1="-1.8034" x2="14.224" y2="-1.2954" layer="51"/>
</package>
<package name="2X10_NOSILK">
</package>
<package name="1X11">
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="26.035" y2="1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="26.67" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="0.635" x2="26.67" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="-1.27" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="25.146" y1="-0.254" x2="25.654" y2="0.254" layer="51"/>
</package>
<package name="1X11-1.27MM">
<description>Header for the OS4000-T</description>
<wire x1="-0.381" y1="-0.889" x2="0.381" y2="-0.889" width="0.127" layer="21"/>
<wire x1="0.381" y1="-0.889" x2="0.635" y2="-0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="0.889" y2="-0.889" width="0.127" layer="21"/>
<wire x1="0.889" y1="-0.889" x2="1.651" y2="-0.889" width="0.127" layer="21"/>
<wire x1="1.651" y1="-0.889" x2="1.905" y2="-0.635" width="0.127" layer="21"/>
<wire x1="1.905" y1="-0.635" x2="2.159" y2="-0.889" width="0.127" layer="21"/>
<wire x1="2.159" y1="-0.889" x2="2.921" y2="-0.889" width="0.127" layer="21"/>
<wire x1="2.921" y1="-0.889" x2="3.175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="3.175" y1="-0.635" x2="3.429" y2="-0.889" width="0.127" layer="21"/>
<wire x1="3.429" y1="-0.889" x2="4.191" y2="-0.889" width="0.127" layer="21"/>
<wire x1="4.191" y1="-0.889" x2="4.445" y2="-0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.699" y2="-0.889" width="0.127" layer="21"/>
<wire x1="4.699" y1="-0.889" x2="5.461" y2="-0.889" width="0.127" layer="21"/>
<wire x1="5.461" y1="-0.889" x2="5.715" y2="-0.635" width="0.127" layer="21"/>
<wire x1="5.715" y1="-0.635" x2="5.969" y2="-0.889" width="0.127" layer="21"/>
<wire x1="5.969" y1="-0.889" x2="6.731" y2="-0.889" width="0.127" layer="21"/>
<wire x1="6.731" y1="-0.889" x2="6.985" y2="-0.635" width="0.127" layer="21"/>
<wire x1="6.985" y1="-0.635" x2="7.239" y2="-0.889" width="0.127" layer="21"/>
<wire x1="7.239" y1="-0.889" x2="8.001" y2="-0.889" width="0.127" layer="21"/>
<wire x1="8.001" y1="-0.889" x2="8.255" y2="-0.635" width="0.127" layer="21"/>
<wire x1="8.255" y1="-0.635" x2="8.509" y2="-0.889" width="0.127" layer="21"/>
<wire x1="8.509" y1="-0.889" x2="9.271" y2="-0.889" width="0.127" layer="21"/>
<wire x1="9.271" y1="-0.889" x2="9.525" y2="-0.635" width="0.127" layer="21"/>
<wire x1="9.525" y1="-0.635" x2="9.779" y2="-0.889" width="0.127" layer="21"/>
<wire x1="9.779" y1="-0.889" x2="10.541" y2="-0.889" width="0.127" layer="21"/>
<wire x1="10.541" y1="-0.889" x2="10.795" y2="-0.635" width="0.127" layer="21"/>
<wire x1="10.795" y1="-0.635" x2="11.049" y2="-0.889" width="0.127" layer="21"/>
<wire x1="11.049" y1="-0.889" x2="11.811" y2="-0.889" width="0.127" layer="21"/>
<wire x1="11.811" y1="-0.889" x2="12.065" y2="-0.635" width="0.127" layer="21"/>
<wire x1="12.065" y1="-0.635" x2="12.319" y2="-0.889" width="0.127" layer="21"/>
<wire x1="12.319" y1="-0.889" x2="13.081" y2="-0.889" width="0.127" layer="21"/>
<wire x1="13.081" y1="-0.889" x2="13.589" y2="-0.381" width="0.127" layer="21"/>
<wire x1="13.589" y1="-0.381" x2="13.589" y2="0.381" width="0.127" layer="21"/>
<wire x1="13.589" y1="0.381" x2="13.081" y2="0.889" width="0.127" layer="21"/>
<wire x1="13.081" y1="0.889" x2="12.319" y2="0.889" width="0.127" layer="21"/>
<wire x1="12.319" y1="0.889" x2="12.065" y2="0.635" width="0.127" layer="21"/>
<wire x1="12.065" y1="0.635" x2="11.811" y2="0.889" width="0.127" layer="21"/>
<wire x1="11.811" y1="0.889" x2="11.049" y2="0.889" width="0.127" layer="21"/>
<wire x1="11.049" y1="0.889" x2="10.795" y2="0.635" width="0.127" layer="21"/>
<wire x1="10.795" y1="0.635" x2="10.541" y2="0.889" width="0.127" layer="21"/>
<wire x1="10.541" y1="0.889" x2="9.779" y2="0.889" width="0.127" layer="21"/>
<wire x1="9.779" y1="0.889" x2="9.525" y2="0.635" width="0.127" layer="21"/>
<wire x1="9.525" y1="0.635" x2="9.271" y2="0.889" width="0.127" layer="21"/>
<wire x1="9.271" y1="0.889" x2="8.509" y2="0.889" width="0.127" layer="21"/>
<wire x1="8.509" y1="0.889" x2="8.255" y2="0.635" width="0.127" layer="21"/>
<wire x1="8.255" y1="0.635" x2="8.001" y2="0.889" width="0.127" layer="21"/>
<wire x1="8.001" y1="0.889" x2="7.239" y2="0.889" width="0.127" layer="21"/>
<wire x1="7.239" y1="0.889" x2="6.985" y2="0.635" width="0.127" layer="21"/>
<wire x1="6.985" y1="0.635" x2="6.731" y2="0.889" width="0.127" layer="21"/>
<wire x1="6.731" y1="0.889" x2="5.969" y2="0.889" width="0.127" layer="21"/>
<wire x1="5.969" y1="0.889" x2="5.715" y2="0.635" width="0.127" layer="21"/>
<wire x1="5.715" y1="0.635" x2="5.461" y2="0.889" width="0.127" layer="21"/>
<wire x1="5.461" y1="0.889" x2="4.699" y2="0.889" width="0.127" layer="21"/>
<wire x1="4.699" y1="0.889" x2="4.445" y2="0.635" width="0.127" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.191" y2="0.889" width="0.127" layer="21"/>
<wire x1="4.191" y1="0.889" x2="3.429" y2="0.889" width="0.127" layer="21"/>
<wire x1="3.429" y1="0.889" x2="3.175" y2="0.635" width="0.127" layer="21"/>
<wire x1="3.175" y1="0.635" x2="2.921" y2="0.889" width="0.127" layer="21"/>
<wire x1="2.921" y1="0.889" x2="2.159" y2="0.889" width="0.127" layer="21"/>
<wire x1="2.159" y1="0.889" x2="1.905" y2="0.635" width="0.127" layer="21"/>
<wire x1="1.905" y1="0.635" x2="1.651" y2="0.889" width="0.127" layer="21"/>
<wire x1="1.651" y1="0.889" x2="0.889" y2="0.889" width="0.127" layer="21"/>
<wire x1="0.889" y1="0.889" x2="0.635" y2="0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.381" y2="0.889" width="0.127" layer="21"/>
<wire x1="0.381" y1="0.889" x2="-0.381" y2="0.889" width="0.127" layer="21"/>
<wire x1="-0.381" y1="0.889" x2="-0.889" y2="0.381" width="0.127" layer="21"/>
<wire x1="-0.889" y1="0.381" x2="-0.889" y2="-0.381" width="0.127" layer="21"/>
<wire x1="-0.889" y1="-0.381" x2="-0.381" y2="-0.889" width="0.127" layer="21"/>
<pad name="5" x="5.08" y="0" drill="0.508" diameter="1"/>
<pad name="6" x="6.35" y="0" drill="0.508" diameter="1"/>
<pad name="4" x="3.81" y="0" drill="0.508" diameter="1"/>
<pad name="7" x="7.62" y="0" drill="0.508" diameter="1"/>
<pad name="3" x="2.54" y="0" drill="0.508" diameter="1"/>
<pad name="8" x="8.89" y="0" drill="0.508" diameter="1"/>
<pad name="2" x="1.27" y="0" drill="0.508" diameter="1"/>
<pad name="9" x="10.16" y="0" drill="0.508" diameter="1"/>
<pad name="1" x="0" y="0" drill="0.508" diameter="1"/>
<pad name="10" x="11.43" y="0" drill="0.508" diameter="1"/>
<pad name="11" x="12.7" y="0" drill="0.508" diameter="1"/>
<text x="-0.508" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="-0.508" y="-1.651" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X11_LOCK">
<pad name="5" x="10.16" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X11_LOCK_LONGPADS">
<wire x1="24.384" y1="0" x2="23.876" y2="0" width="0.2032" layer="21"/>
<wire x1="26.67" y1="0" x2="26.67" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.9906" x2="26.3906" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.67" y1="0" x2="26.67" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="26.67" y1="0.9906" x2="26.3906" y2="1.27" width="0.2032" layer="21"/>
<wire x1="26.67" y1="0" x2="26.416" y2="0" width="0.2032" layer="21"/>
<pad name="11" x="25.4" y="0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="25.1079" y1="-0.2921" x2="25.6921" y2="0.2921" layer="51"/>
</package>
<package name="1X11_SMD_PTHCOMBO">
<wire x1="-1.27" y1="-1.27" x2="26.67" y2="-1.27" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="1.23" width="0.127" layer="51"/>
<wire x1="26.67" y1="-1.27" x2="26.67" y2="1.23" width="0.127" layer="51"/>
<wire x1="-1.27" y1="1.23" x2="26.67" y2="1.23" width="0.127" layer="51"/>
<wire x1="-0.7366" y1="1.2192" x2="-1.27" y2="1.2192" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="1.2192" x2="-1.27" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-0.762" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.6954" y1="1.2192" x2="26.6954" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.6954" y1="1.2192" x2="26.162" y2="1.2192" width="0.2032" layer="21"/>
<wire x1="26.6954" y1="-1.27" x2="26.162" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="-0.0025" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-1.552" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="3" x="5.0775" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="-1.552" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="5" x="10.1575" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="-1.552" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="7" x="15.2375" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="-1.552" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="9" x="20.3175" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="10" x="22.86" y="-1.552" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<pad name="11" x="25.3975" y="1.5468" drill="0.5334" diameter="0.9144" shape="long" rot="R90"/>
<text x="-1.3462" y="5.6388" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.127" layer="31">
<vertex x="0.3885" y="1.0998"/>
<vertex x="0.3886" y="1.9762" curve="89.931718"/>
<vertex x="0.0204" y="2.3955" curve="90.027349"/>
<vertex x="-0.3987" y="2.0042"/>
<vertex x="-0.3988" y="1.1506" curve="90.088312"/>
<vertex x="-0.028" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="5.4685" y="1.0998"/>
<vertex x="5.4686" y="1.9762" curve="89.931718"/>
<vertex x="5.1004" y="2.3955" curve="90.027349"/>
<vertex x="4.6813" y="2.0042"/>
<vertex x="4.6812" y="1.1506" curve="90.088312"/>
<vertex x="5.052" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="10.5485" y="1.0998"/>
<vertex x="10.5486" y="1.9762" curve="89.931718"/>
<vertex x="10.1804" y="2.3955" curve="90.027349"/>
<vertex x="9.7613" y="2.0042"/>
<vertex x="9.7612" y="1.1506" curve="90.088312"/>
<vertex x="10.132" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="15.6285" y="1.0998"/>
<vertex x="15.6286" y="1.9762" curve="89.931718"/>
<vertex x="15.2604" y="2.3955" curve="90.027349"/>
<vertex x="14.8413" y="2.0042"/>
<vertex x="14.8412" y="1.1506" curve="90.088312"/>
<vertex x="15.212" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="20.7085" y="1.0998"/>
<vertex x="20.7086" y="1.9762" curve="89.931718"/>
<vertex x="20.3404" y="2.3955" curve="90.027349"/>
<vertex x="19.9213" y="2.0042"/>
<vertex x="19.9212" y="1.1506" curve="90.088312"/>
<vertex x="20.292" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="25.7885" y="1.0998"/>
<vertex x="25.7886" y="1.9762" curve="89.931718"/>
<vertex x="25.4204" y="2.3955" curve="90.027349"/>
<vertex x="25.0013" y="2.0042"/>
<vertex x="25.0012" y="1.1506" curve="90.088312"/>
<vertex x="25.372" y="0.6961" curve="89.972494"/>
</polygon>
<vertex x="2.931" y="-1.9965"/>
<vertex x="2.9311" y="-1.1201" curve="89.931718"/>
<vertex x="2.5629" y="-0.7008" curve="90.027349"/>
<vertex x="2.1438" y="-1.0921"/>
<vertex x="2.1437" y="-1.9457" curve="90.088312"/>
<vertex x="2.5145" y="-2.4002" curve="89.972494"/>
</polygon>
<vertex x="8.011" y="-1.9965"/>
<vertex x="8.0111" y="-1.1201" curve="89.931718"/>
<vertex x="7.6429" y="-0.7008" curve="90.027349"/>
<vertex x="7.2238" y="-1.0921"/>
<vertex x="7.2237" y="-1.9457" curve="90.088312"/>
<vertex x="7.5945" y="-2.4002" curve="89.972494"/>
</polygon>
<vertex x="13.091" y="-1.9965"/>
<vertex x="13.0911" y="-1.1201" curve="89.931718"/>
<vertex x="12.7229" y="-0.7008" curve="90.027349"/>
<vertex x="12.3038" y="-1.0921"/>
<vertex x="12.3037" y="-1.9457" curve="90.088312"/>
<vertex x="12.6745" y="-2.4002" curve="89.972494"/>
</polygon>
<vertex x="18.171" y="-1.9965"/>
<vertex x="18.1711" y="-1.1201" curve="89.931718"/>
<vertex x="17.8029" y="-0.7008" curve="90.027349"/>
<vertex x="17.3838" y="-1.0921"/>
<vertex x="17.3837" y="-1.9457" curve="90.088312"/>
<vertex x="17.7545" y="-2.4002" curve="89.972494"/>
</polygon>
<vertex x="23.251" y="-1.9965"/>
<vertex x="23.2511" y="-1.1201" curve="89.931718"/>
<vertex x="22.8829" y="-0.7008" curve="90.027349"/>
<vertex x="22.4638" y="-1.0921"/>
<vertex x="22.4637" y="-1.9457" curve="90.088312"/>
<vertex x="22.8345" y="-2.4002" curve="89.972494"/>
</polygon>
</package>
<package name="1X11_LONGPADS">
<pad name="4" x="7.62" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
</package>
<package name="1X11_SMD_NO_HOLES">
<smd name="P$1" x="0" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$2" x="2.54" y="-1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$3" x="5.08" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$4" x="7.62" y="-1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$5" x="10.16" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$6" x="12.7" y="-1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$7" x="15.24" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$8" x="17.78" y="-1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$9" x="20.32" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$10" x="22.86" y="-1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<smd name="P$11" x="25.4" y="1.5494" dx="1.8414" dy="0.9144" layer="1" roundness="100" rot="R90"/>
<text x="-1.27" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
</package>
<package name="1X11_HOLES_ONLY">
<circle x="0" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="2.54" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="5.08" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="7.62" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="10.16" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="12.7" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="15.24" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="17.78" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="20.32" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="22.86" y="0" radius="0.635" width="0.127" layer="51"/>
<circle x="25.4" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="1" x="0" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<hole x="0" y="0" drill="1.4732"/>
<hole x="2.54" y="0" drill="1.4732"/>
<hole x="5.08" y="0" drill="1.4732"/>
<hole x="7.62" y="0" drill="1.4732"/>
<hole x="10.16" y="0" drill="1.4732"/>
<hole x="12.7" y="0" drill="1.4732"/>
<hole x="15.24" y="0" drill="1.4732"/>
<hole x="17.78" y="0" drill="1.4732"/>
<hole x="20.32" y="0" drill="1.4732"/>
<hole x="22.86" y="0" drill="1.4732"/>
<hole x="25.4" y="0" drill="1.4732"/>
</package>
<package name="1X12">
<wire x1="14.605" y1="1.27" x2="15.875" y2="1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="18.415" y2="1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.05" y2="0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="28.575" y2="1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="1.27" x2="29.21" y2="0.635" width="0.2032" layer="21"/>
<wire x1="29.21" y1="0.635" x2="29.21" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="29.21" y1="-0.635" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="26.67" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="-1.27" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="27.686" y1="-0.254" x2="28.194" y2="0.254" layer="51"/>
</package>
<package name="1X12_LOCK">
<pad name="6" x="12.7" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51" rot="R90"/>
</package>
<package name="1X12_LOCK_LONGPADS">
<wire x1="1.524" y1="0" x2="1.016" y2="0" width="0.2032" layer="21"/>
<wire x1="4.064" y1="0" x2="3.556" y2="0" width="0.2032" layer="21"/>
<wire x1="6.604" y1="0" x2="6.096" y2="0" width="0.2032" layer="21"/>
<wire x1="9.144" y1="0" x2="8.636" y2="0" width="0.2032" layer="21"/>
<wire x1="11.684" y1="0" x2="11.176" y2="0" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.016" y2="0" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.9906" x2="-0.9906" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.9906" x2="-0.9906" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="14.224" y1="0" x2="13.716" y2="0" width="0.2032" layer="21"/>
<wire x1="16.764" y1="0" x2="16.256" y2="0" width="0.2032" layer="21"/>
<wire x1="26.924" y1="0" x2="26.416" y2="0" width="0.2032" layer="21"/>
<wire x1="29.21" y1="0" x2="29.21" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="29.21" y1="-0.9906" x2="28.9306" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.21" y1="0" x2="29.21" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="29.21" y1="0.9906" x2="28.9306" y2="1.27" width="0.2032" layer="21"/>
<wire x1="29.21" y1="0" x2="28.956" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="27.94" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<text x="-1.27" y="1.905" size="1.27" layer="25" font="vector">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27" font="vector">&gt;VALUE</text>
<rectangle x1="-0.2921" y1="-0.2921" x2="0.2921" y2="0.2921" layer="51"/>
<rectangle x1="2.2479" y1="-0.2921" x2="2.8321" y2="0.2921" layer="51"/>
<rectangle x1="7.3279" y1="-0.2921" x2="7.9121" y2="0.2921" layer="51" rot="R90"/>
<rectangle x1="9.8679" y1="-0.2921" x2="10.4521" y2="0.2921" layer="51"/>
<rectangle x1="12.4079" y1="-0.2921" x2="12.9921" y2="0.2921" layer="51"/>
<rectangle x1="14.9479" y1="-0.2921" x2="15.5321" y2="0.2921" layer="51"/>
<rectangle x1="17.4879" y1="-0.2921" x2="18.0721" y2="0.2921" layer="51"/>
<rectangle x1="27.6479" y1="-0.2921" x2="28.2321" y2="0.2921" layer="51"/>
</package>
<package name="1X12_MACHINE-PIN-HEADER_LOCK.004">
<wire x1="26.67" y1="0.635" x2="27.305" y2="1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.67" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="0.635" x2="24.765" y2="1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="24.13" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="0.635" x2="19.685" y2="1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="19.05" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="0.635" x2="17.145" y2="1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="16.51" y2="-0.635" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="2.54" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="5.08" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="7.62" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="10.16" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="12.7" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="15.24" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="17.78" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="20.32" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="22.86" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="25.4" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="27.94" y="0" radius="0.3302" width="0.0254" layer="51"/>
<pad name="1" x="0" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="-0.1016" drill="0.889" diameter="1.8796" rot="R90"/>
</package>
<package name="1X12_LONGPADS">
<pad name="1" x="0" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="12" x="27.94" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
</package>
<package name="1X12_HOLES_ONLY">
<circle x="27.94" y="0" radius="0.635" width="0.127" layer="51"/>
<pad name="12" x="27.94" y="0" drill="0.889" diameter="0.8128" rot="R90"/>
<hole x="27.94" y="0" drill="1.4732"/>
</package>
<package name="1X13">
<wire x1="29.21" y1="0.635" x2="29.845" y2="1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="1.27" x2="31.115" y2="1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="-1.27" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="29.21" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="0.635" x2="22.225" y2="1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="21.59" y2="-0.635" width="0.2032" layer="21"/>
<pad name="13" x="30.48" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="30.226" y1="-0.254" x2="30.734" y2="0.254" layer="51"/>
</package>
<package name="1X13-LONGPADS">
<pad name="1" x="0" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="12" x="27.94" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="13" x="30.48" y="0" drill="1.1176" shape="long" rot="R90"/>
</package>
<package name="1X14">
<wire x1="32.385" y1="1.27" x2="33.655" y2="1.27" width="0.2032" layer="21"/>
<wire x1="33.655" y1="1.27" x2="34.29" y2="0.635" width="0.2032" layer="21"/>
<wire x1="34.29" y1="-0.635" x2="33.655" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="32.385" y1="1.27" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="32.385" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="33.655" y1="-1.27" x2="32.385" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0.635" x2="34.29" y2="-0.635" width="0.2032" layer="21"/>
<pad name="14" x="33.02" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="32.766" y1="-0.254" x2="33.274" y2="0.254" layer="51"/>
</package>
<package name="1X14_LOCK">
<pad name="13" x="30.48" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="33.02" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X14_LOCK_LONGPADS">
<wire x1="29.464" y1="0" x2="28.956" y2="0" width="0.2032" layer="21"/>
<wire x1="32.004" y1="0" x2="31.496" y2="0" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0" x2="34.29" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="34.29" y1="-0.9906" x2="34.0106" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0" x2="34.29" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0.9906" x2="34.0106" y2="1.27" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0" x2="34.036" y2="0" width="0.2032" layer="21"/>
<pad name="13" x="30.48" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="33.02" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="30.1879" y1="-0.2921" x2="30.7721" y2="0.2921" layer="51"/>
<rectangle x1="32.7279" y1="-0.2921" x2="33.3121" y2="0.2921" layer="51"/>
</package>
<package name="1X14-LONGPADS">
<pad name="14" x="33.02" y="0" drill="1.1176" shape="long" rot="R90"/>
</package>
<package name="1X15">
<wire x1="34.925" y1="1.27" x2="34.29" y2="0.635" width="0.2032" layer="21"/>
<wire x1="34.925" y1="1.27" x2="36.195" y2="1.27" width="0.2032" layer="21"/>
<wire x1="36.195" y1="1.27" x2="36.83" y2="0.635" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0.635" x2="36.83" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="36.83" y1="-0.635" x2="36.195" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="36.195" y1="-1.27" x2="34.925" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="34.29" y1="-0.635" x2="34.925" y2="-1.27" width="0.2032" layer="21"/>
<pad name="15" x="35.56" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="35.306" y1="-0.254" x2="35.814" y2="0.254" layer="51"/>
</package>
<package name="1X15_LOCK">
<wire x1="19.685" y1="1.27" x2="20.955" y2="1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<pad name="15" x="35.56" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X15_LOCK_LONGPADS">
<wire x1="34.544" y1="0" x2="34.036" y2="0" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0" x2="36.83" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="36.83" y1="-0.9906" x2="36.5506" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0" x2="36.83" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0.9906" x2="36.5506" y2="1.27" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0" x2="36.576" y2="0" width="0.2032" layer="21"/>
<pad name="15" x="35.56" y="0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="35.2679" y1="-0.2921" x2="35.8521" y2="0.2921" layer="51"/>
</package>
<package name="1X16">
<wire x1="39.37" y1="0.635" x2="39.37" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="37.465" y1="1.27" x2="36.83" y2="0.635" width="0.2032" layer="21"/>
<wire x1="37.465" y1="1.27" x2="38.735" y2="1.27" width="0.2032" layer="21"/>
<wire x1="38.735" y1="1.27" x2="39.37" y2="0.635" width="0.2032" layer="21"/>
<wire x1="39.37" y1="-0.635" x2="38.735" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="38.735" y1="-1.27" x2="37.465" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="36.83" y1="-0.635" x2="37.465" y2="-1.27" width="0.2032" layer="21"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="38.1" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
<rectangle x1="37.846" y1="-0.254" x2="38.354" y2="0.254" layer="51"/>
</package>
<package name="1X16_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="38.1" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X16_LOCK_LONGPADS">
<wire x1="19.304" y1="0" x2="18.796" y2="0" width="0.2032" layer="21"/>
<wire x1="37.084" y1="0" x2="36.576" y2="0" width="0.2032" layer="21"/>
<wire x1="39.37" y1="0" x2="39.37" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="39.37" y1="-0.9906" x2="39.0906" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="39.37" y1="0" x2="39.37" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="39.37" y1="0.9906" x2="39.0906" y2="1.27" width="0.2032" layer="21"/>
<wire x1="39.37" y1="0" x2="39.116" y2="0" width="0.2032" layer="21"/>
<pad name="9" x="20.32" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="38.1" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="4.7879" y1="-0.2921" x2="5.3721" y2="0.2921" layer="51"/>
<rectangle x1="20.0279" y1="-0.2921" x2="20.6121" y2="0.2921" layer="51"/>
<rectangle x1="37.8079" y1="-0.2921" x2="38.3921" y2="0.2921" layer="51" rot="R90"/>
</package>
<package name="1X16_MACHINE-PIN-HEADER_LOCK.004">
<wire x1="22.225" y1="1.27" x2="23.495" y2="1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="36.83" y1="0.635" x2="37.465" y2="1.27" width="0.2032" layer="21"/>
<wire x1="37.465" y1="-1.27" x2="36.83" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="34.29" y1="0.635" x2="34.925" y2="1.27" width="0.2032" layer="21"/>
<wire x1="34.925" y1="-1.27" x2="34.29" y2="-0.635" width="0.2032" layer="21"/>
<circle x="30.48" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="33.02" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="35.56" y="0" radius="0.3302" width="0.0254" layer="51"/>
<circle x="38.1" y="0" radius="0.3302" width="0.0254" layer="51"/>
<pad name="1" x="0" y="0.1016" drill="0.889" rot="R90"/>
<pad name="2" x="2.54" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="3" x="5.08" y="0.1016" drill="0.889" rot="R90"/>
<pad name="4" x="7.62" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="5" x="10.16" y="0.1016" drill="0.889" rot="R90"/>
<pad name="6" x="12.7" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="7" x="15.24" y="0.1016" drill="0.889" rot="R90"/>
<pad name="8" x="17.78" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="9" x="20.32" y="0.1016" drill="0.889" rot="R90"/>
<pad name="10" x="22.86" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="11" x="25.4" y="0.1016" drill="0.889" rot="R90"/>
<pad name="12" x="27.94" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="13" x="30.48" y="0.1016" drill="0.889" rot="R90"/>
<pad name="14" x="33.02" y="-0.1016" drill="0.889" rot="R90"/>
<pad name="15" x="35.56" y="0.1016" drill="0.889" rot="R90"/>
<pad name="16" x="38.1" y="-0.1016" drill="0.889" rot="R90"/>
</package>
<package name="1X16_LONGPADS">
<pad name="2" x="2.54" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="13" x="30.48" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="14" x="33.02" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="15" x="35.56" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="16" x="38.1" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-1.3462" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
</package>
<package name="1X17">
<wire x1="40.005" y1="1.27" x2="39.37" y2="0.635" width="0.2032" layer="21"/>
<wire x1="40.005" y1="1.27" x2="41.275" y2="1.27" width="0.2032" layer="21"/>
<wire x1="41.275" y1="1.27" x2="41.91" y2="0.635" width="0.2032" layer="21"/>
<wire x1="41.91" y1="-0.635" x2="41.275" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="41.275" y1="-1.27" x2="40.005" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="39.37" y1="-0.635" x2="40.005" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="41.91" y1="0.635" x2="41.91" y2="-0.635" width="0.2032" layer="21"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="40.64" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="40.386" y1="-0.254" x2="40.894" y2="0.254" layer="51"/>
</package>
<package name="1X18">
<wire x1="42.545" y1="1.27" x2="41.91" y2="0.635" width="0.2032" layer="21"/>
<wire x1="42.545" y1="1.27" x2="43.815" y2="1.27" width="0.2032" layer="21"/>
<wire x1="43.815" y1="1.27" x2="44.45" y2="0.635" width="0.2032" layer="21"/>
<wire x1="44.45" y1="-0.635" x2="43.815" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="43.815" y1="-1.27" x2="42.545" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="41.91" y1="-0.635" x2="42.545" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="44.45" y1="0.635" x2="44.45" y2="-0.635" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="18" x="43.18" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="42.926" y1="-0.254" x2="43.434" y2="0.254" layer="51"/>
</package>
<package name="1X19">
<wire x1="45.085" y1="1.27" x2="44.45" y2="0.635" width="0.2032" layer="21"/>
<wire x1="45.085" y1="1.27" x2="46.355" y2="1.27" width="0.2032" layer="21"/>
<wire x1="46.355" y1="1.27" x2="46.99" y2="0.635" width="0.2032" layer="21"/>
<wire x1="46.99" y1="-0.635" x2="46.355" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="46.355" y1="-1.27" x2="45.085" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="44.45" y1="-0.635" x2="45.085" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="46.99" y1="0.635" x2="46.99" y2="-0.635" width="0.2032" layer="21"/>
<pad name="19" x="45.72" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="45.466" y1="-0.254" x2="45.974" y2="0.254" layer="51"/>
</package>
<package name="1X20">
<wire x1="47.625" y1="1.27" x2="46.99" y2="0.635" width="0.2032" layer="21"/>
<wire x1="47.625" y1="1.27" x2="48.895" y2="1.27" width="0.2032" layer="21"/>
<wire x1="48.895" y1="1.27" x2="49.53" y2="0.635" width="0.2032" layer="21"/>
<wire x1="49.53" y1="0.635" x2="49.53" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="49.53" y1="-0.635" x2="48.895" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="48.895" y1="-1.27" x2="47.625" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="46.99" y1="-0.635" x2="47.625" y2="-1.27" width="0.2032" layer="21"/>
<pad name="20" x="48.26" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="48.006" y1="-0.254" x2="48.514" y2="0.254" layer="51"/>
</package>
<package name="1X20_LOCK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="40.64" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="43.18" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="45.72" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="48.26" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X20_LOCK_LONGPADS">
<wire x1="21.844" y1="0" x2="21.336" y2="0" width="0.2032" layer="21"/>
<wire x1="31.75" y1="0" x2="31.496" y2="0" width="0.2032" layer="21"/>
<wire x1="32.004" y1="0" x2="31.75" y2="0" width="0.2032" layer="21"/>
<wire x1="39.624" y1="0" x2="39.116" y2="0" width="0.2032" layer="21"/>
<wire x1="42.164" y1="0" x2="41.656" y2="0" width="0.2032" layer="21"/>
<wire x1="44.704" y1="0" x2="44.196" y2="0" width="0.2032" layer="21"/>
<wire x1="49.53" y1="0" x2="49.53" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="49.53" y1="-0.9906" x2="49.2506" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="49.53" y1="0" x2="49.53" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="49.53" y1="0.9906" x2="49.2506" y2="1.27" width="0.2032" layer="21"/>
<wire x1="49.53" y1="0" x2="49.276" y2="0" width="0.2032" layer="21"/>
<wire x1="47.244" y1="0" x2="46.736" y2="0" width="0.2032" layer="21"/>
<pad name="10" x="22.86" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="40.64" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="43.18" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="45.72" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="48.26" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="22.5679" y1="-0.2921" x2="23.1521" y2="0.2921" layer="51" rot="R90"/>
<rectangle x1="40.3479" y1="-0.2921" x2="40.9321" y2="0.2921" layer="51"/>
<rectangle x1="42.8879" y1="-0.2921" x2="43.4721" y2="0.2921" layer="51"/>
<rectangle x1="45.4279" y1="-0.2921" x2="46.0121" y2="0.2921" layer="51"/>
<rectangle x1="47.9679" y1="-0.2921" x2="48.5521" y2="0.2921" layer="51"/>
</package>
<package name="1X20_LOCK_SPECIAL">
<pad name="19" x="45.593" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="48.387" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X24">
<wire x1="-14.605" y1="1.27" x2="-13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.145" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-15.875" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-17.78" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-20.955" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-19.685" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-18.415" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.32" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-24.765" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-23.495" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="-1.27" x2="-24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="-1.27" x2="-25.4" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.305" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-26.035" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-26.035" y1="1.27" x2="-25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-26.035" y1="-1.27" x2="-27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.305" y1="-1.27" x2="-27.94" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.2032" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.16" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="14.605" y2="1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="17.145" y2="1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.685" y2="1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="22.225" y2="1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.765" y2="1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="27.305" y2="1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="27.94" y2="0.635" width="0.2032" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="1.27" x2="27.94" y2="0.635" width="0.2032" layer="21"/>
<wire x1="28.575" y1="1.27" x2="29.845" y2="1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="1.27" x2="30.48" y2="0.635" width="0.2032" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="30.48" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="32.385" y2="1.27" width="0.2032" layer="21"/>
<wire x1="32.385" y1="1.27" x2="33.02" y2="0.635" width="0.2032" layer="21"/>
<wire x1="33.02" y1="0.635" x2="33.02" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="32.385" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="32.385" y1="-1.27" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.94" y2="-0.635" width="0.2032" layer="21"/>
<pad name="2" x="-26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="31.75" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-28.0162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-27.94" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="-16.764" y1="-0.254" x2="-16.256" y2="0.254" layer="51"/>
<rectangle x1="-19.304" y1="-0.254" x2="-18.796" y2="0.254" layer="51"/>
<rectangle x1="-21.844" y1="-0.254" x2="-21.336" y2="0.254" layer="51"/>
<rectangle x1="-24.384" y1="-0.254" x2="-23.876" y2="0.254" layer="51"/>
<rectangle x1="-26.924" y1="-0.254" x2="-26.416" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
<rectangle x1="26.416" y1="-0.254" x2="26.924" y2="0.254" layer="51"/>
<rectangle x1="28.956" y1="-0.254" x2="29.464" y2="0.254" layer="51"/>
<rectangle x1="31.496" y1="-0.254" x2="32.004" y2="0.254" layer="51"/>
</package>
<package name="1X24_LONGPADS">
<pad name="2" x="-26.67" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="25" x="31.75" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-28.0162" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-27.94" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X25">
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="26.035" y2="1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="26.67" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="-1.27" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="50.165" y1="1.27" x2="49.53" y2="0.635" width="0.2032" layer="21"/>
<wire x1="50.165" y1="1.27" x2="51.435" y2="1.27" width="0.2032" layer="21"/>
<wire x1="51.435" y1="1.27" x2="52.07" y2="0.635" width="0.2032" layer="21"/>
<wire x1="52.07" y1="-0.635" x2="51.435" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="51.435" y1="-1.27" x2="50.165" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="49.53" y1="-0.635" x2="50.165" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="52.705" y1="1.27" x2="52.07" y2="0.635" width="0.2032" layer="21"/>
<wire x1="52.705" y1="1.27" x2="53.975" y2="1.27" width="0.2032" layer="21"/>
<wire x1="53.975" y1="1.27" x2="54.61" y2="0.635" width="0.2032" layer="21"/>
<wire x1="54.61" y1="-0.635" x2="53.975" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="53.975" y1="-1.27" x2="52.705" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="52.07" y1="-0.635" x2="52.705" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="55.245" y1="1.27" x2="54.61" y2="0.635" width="0.2032" layer="21"/>
<wire x1="55.245" y1="1.27" x2="56.515" y2="1.27" width="0.2032" layer="21"/>
<wire x1="56.515" y1="1.27" x2="57.15" y2="0.635" width="0.2032" layer="21"/>
<wire x1="57.15" y1="-0.635" x2="56.515" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="56.515" y1="-1.27" x2="55.245" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="54.61" y1="-0.635" x2="55.245" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="57.785" y1="1.27" x2="57.15" y2="0.635" width="0.2032" layer="21"/>
<wire x1="57.785" y1="1.27" x2="59.055" y2="1.27" width="0.2032" layer="21"/>
<wire x1="59.055" y1="1.27" x2="59.69" y2="0.635" width="0.2032" layer="21"/>
<wire x1="59.69" y1="-0.635" x2="59.055" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="59.055" y1="-1.27" x2="57.785" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="57.15" y1="-0.635" x2="57.785" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="60.325" y1="1.27" x2="59.69" y2="0.635" width="0.2032" layer="21"/>
<wire x1="60.325" y1="1.27" x2="61.595" y2="1.27" width="0.2032" layer="21"/>
<wire x1="61.595" y1="1.27" x2="62.23" y2="0.635" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0.635" x2="62.23" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="62.23" y1="-0.635" x2="61.595" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="61.595" y1="-1.27" x2="60.325" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="59.69" y1="-0.635" x2="60.325" y2="-1.27" width="0.2032" layer="21"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="50.8" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="53.34" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="55.88" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="58.42" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="60.96" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="25.146" y1="-0.254" x2="25.654" y2="0.254" layer="51"/>
<rectangle x1="50.546" y1="-0.254" x2="51.054" y2="0.254" layer="51"/>
<rectangle x1="53.086" y1="-0.254" x2="53.594" y2="0.254" layer="51"/>
<rectangle x1="55.626" y1="-0.254" x2="56.134" y2="0.254" layer="51"/>
<rectangle x1="58.166" y1="-0.254" x2="58.674" y2="0.254" layer="51"/>
<rectangle x1="60.706" y1="-0.254" x2="61.214" y2="0.254" layer="51"/>
</package>
<package name="1X25_LOCK">
<pad name="21" x="50.8" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="53.34" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="55.88" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="58.42" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="60.96" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X25_LOCK_LONGPADS">
<wire x1="49.784" y1="0" x2="49.276" y2="0" width="0.2032" layer="21"/>
<wire x1="52.324" y1="0" x2="51.816" y2="0" width="0.2032" layer="21"/>
<wire x1="54.864" y1="0" x2="54.356" y2="0" width="0.2032" layer="21"/>
<wire x1="59.69" y1="0" x2="59.436" y2="0" width="0.2032" layer="21"/>
<wire x1="57.404" y1="0" x2="56.896" y2="0" width="0.2032" layer="21"/>
<wire x1="59.944" y1="0" x2="59.436" y2="0" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0" x2="62.23" y2="-0.9906" width="0.2032" layer="21"/>
<wire x1="62.23" y1="-0.9906" x2="61.9506" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0" x2="62.23" y2="0.9906" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0.9906" x2="61.9506" y2="1.27" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0" x2="61.976" y2="0" width="0.2032" layer="21"/>
<pad name="11" x="25.4" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="50.8" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="53.34" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="55.88" y="0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="58.42" y="-0.127" drill="1.016" shape="long" rot="R90"/>
<pad name="25" x="60.96" y="0.127" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="25.1079" y1="-0.2921" x2="25.6921" y2="0.2921" layer="51"/>
<rectangle x1="50.5079" y1="-0.2921" x2="51.0921" y2="0.2921" layer="51"/>
<rectangle x1="53.0479" y1="-0.2921" x2="53.6321" y2="0.2921" layer="51"/>
<rectangle x1="55.5879" y1="-0.2921" x2="56.1721" y2="0.2921" layer="51"/>
<rectangle x1="58.1279" y1="-0.2921" x2="58.7121" y2="0.2921" layer="51"/>
<rectangle x1="60.6679" y1="-0.2921" x2="61.2521" y2="0.2921" layer="51"/>
</package>
<package name="1X25_LONGPAD">
<pad name="15" x="35.56" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="16" x="38.1" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="17" x="40.64" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="18" x="43.18" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="19" x="45.72" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="20" x="48.26" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="21" x="50.8" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="22" x="53.34" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="23" x="55.88" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="24" x="58.42" y="0" drill="1.1176" shape="long" rot="R90"/>
<pad name="25" x="60.96" y="0" drill="1.1176" shape="long" rot="R90"/>
</package>
<package name="1X27">
<wire x1="62.865" y1="1.27" x2="64.135" y2="1.27" width="0.2032" layer="21"/>
<wire x1="64.135" y1="1.27" x2="64.77" y2="0.635" width="0.2032" layer="21"/>
<wire x1="64.77" y1="-0.635" x2="64.135" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="64.135" y1="-1.27" x2="62.865" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="65.405" y1="1.27" x2="64.77" y2="0.635" width="0.2032" layer="21"/>
<wire x1="65.405" y1="1.27" x2="66.675" y2="1.27" width="0.2032" layer="21"/>
<wire x1="66.675" y1="1.27" x2="67.31" y2="0.635" width="0.2032" layer="21"/>
<wire x1="67.31" y1="0.635" x2="67.31" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="67.31" y1="-0.635" x2="66.675" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="66.675" y1="-1.27" x2="65.405" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="64.77" y1="-0.635" x2="65.405" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="57.15" y1="0.635" x2="57.785" y2="1.27" width="0.2032" layer="21"/>
<wire x1="62.23" y1="0.635" x2="62.865" y2="1.27" width="0.2032" layer="21"/>
<wire x1="62.23" y1="-0.635" x2="62.865" y2="-1.27" width="0.2032" layer="21"/>
<pad name="26" x="63.5" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="27" x="66.04" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="63.246" y1="-0.254" x2="63.754" y2="0.254" layer="51"/>
<rectangle x1="65.786" y1="-0.254" x2="66.294" y2="0.254" layer="51"/>
</package>
<package name="1X29">
<wire x1="67.945" y1="1.27" x2="69.215" y2="1.27" width="0.2032" layer="21"/>
<wire x1="69.215" y1="1.27" x2="69.85" y2="0.635" width="0.2032" layer="21"/>
<wire x1="69.85" y1="-0.635" x2="69.215" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="69.215" y1="-1.27" x2="67.945" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="70.485" y1="1.27" x2="69.85" y2="0.635" width="0.2032" layer="21"/>
<wire x1="70.485" y1="1.27" x2="71.755" y2="1.27" width="0.2032" layer="21"/>
<wire x1="71.755" y1="1.27" x2="72.39" y2="0.635" width="0.2032" layer="21"/>
<wire x1="72.39" y1="-0.635" x2="71.755" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="71.755" y1="-1.27" x2="70.485" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="69.85" y1="-0.635" x2="70.485" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="67.31" y1="0.635" x2="67.945" y2="1.27" width="0.2032" layer="21"/>
<wire x1="67.31" y1="-0.635" x2="67.945" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="72.39" y1="0.635" x2="72.39" y2="-0.635" width="0.2032" layer="21"/>
<pad name="28" x="68.58" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="29" x="71.12" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="68.326" y1="-0.254" x2="68.834" y2="0.254" layer="51"/>
<rectangle x1="70.866" y1="-0.254" x2="71.374" y2="0.254" layer="51"/>
</package>
<package name="1X29_NO_SILK">
</package>
<package name="1X30">
<wire x1="73.025" y1="1.27" x2="72.39" y2="0.635" width="0.2032" layer="21"/>
<wire x1="73.025" y1="1.27" x2="74.295" y2="1.27" width="0.2032" layer="21"/>
<wire x1="74.295" y1="1.27" x2="74.93" y2="0.635" width="0.2032" layer="21"/>
<wire x1="74.93" y1="0.635" x2="74.93" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="74.93" y1="-0.635" x2="74.295" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="74.295" y1="-1.27" x2="73.025" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="72.39" y1="-0.635" x2="73.025" y2="-1.27" width="0.2032" layer="21"/>
<pad name="30" x="73.66" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="73.406" y1="-0.254" x2="73.914" y2="0.254" layer="51"/>
</package>
<package name="1X30_NO_SILK">
</package>
<package name="1X40_OFFSET">
<wire x1="1.27" y1="1.27" x2="-1.27" y2="1.27" width="0.127" layer="49"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.127" layer="49"/>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.127" layer="49"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.127" layer="49"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="13" x="30.48" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="14" x="33.02" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="15" x="35.56" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="16" x="38.1" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="17" x="40.64" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="18" x="43.18" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="19" x="45.72" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="20" x="48.26" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="21" x="50.8" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="22" x="53.34" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="23" x="55.88" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="24" x="58.42" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="25" x="60.96" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="26" x="63.5" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="27" x="66.04" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="28" x="68.58" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="29" x="71.12" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="30" x="73.66" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="31" x="76.2" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="32" x="78.74" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="33" x="81.28" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="34" x="83.82" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="35" x="86.36" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="36" x="88.9" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="37" x="91.44" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="38" x="93.98" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="39" x="96.52" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<pad name="40" x="99.06" y="0" drill="1.016" diameter="1.8796" shape="offset" rot="R270"/>
<text x="-1.27" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
<rectangle x1="75.946" y1="-0.254" x2="76.454" y2="0.254" layer="51"/>
<rectangle x1="78.486" y1="-0.254" x2="78.994" y2="0.254" layer="51"/>
<rectangle x1="81.026" y1="-0.254" x2="81.534" y2="0.254" layer="51"/>
<rectangle x1="83.566" y1="-0.254" x2="84.074" y2="0.254" layer="51"/>
<rectangle x1="86.106" y1="-0.254" x2="86.614" y2="0.254" layer="51"/>
<rectangle x1="88.646" y1="-0.254" x2="89.154" y2="0.254" layer="51"/>
<rectangle x1="91.186" y1="-0.254" x2="91.694" y2="0.254" layer="51"/>
<rectangle x1="93.726" y1="-0.254" x2="94.234" y2="0.254" layer="51"/>
<rectangle x1="96.266" y1="-0.254" x2="96.774" y2="0.254" layer="51"/>
<rectangle x1="98.806" y1="-0.254" x2="99.314" y2="0.254" layer="51"/>
</package>
<package name="1X40">
<pad name="1" x="-49.53" y="0" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="2" x="-46.99" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-44.45" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-41.91" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-39.37" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-36.83" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-34.29" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="-31.75" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="-29.21" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="-26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="-24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="-21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="-19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="-16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="-13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="-11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="-8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="-6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="-3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="-1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="26" x="13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="27" x="16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="28" x="19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="29" x="21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="30" x="24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="31" x="26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="32" x="29.21" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="33" x="31.75" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="34" x="34.29" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="35" x="36.83" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="36" x="39.37" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="37" x="41.91" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="38" x="44.45" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="39" x="46.99" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="40" x="49.53" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-50.8762" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-50.8" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-34.544" y1="-0.254" x2="-34.036" y2="0.254" layer="51"/>
<rectangle x1="-37.084" y1="-0.254" x2="-36.576" y2="0.254" layer="51"/>
<rectangle x1="-39.624" y1="-0.254" x2="-39.116" y2="0.254" layer="51"/>
<rectangle x1="-42.164" y1="-0.254" x2="-41.656" y2="0.254" layer="51"/>
<rectangle x1="-44.704" y1="-0.254" x2="-44.196" y2="0.254" layer="51"/>
<rectangle x1="-47.244" y1="-0.254" x2="-46.736" y2="0.254" layer="51"/>
<rectangle x1="-49.784" y1="-0.254" x2="-49.276" y2="0.254" layer="51"/>
<rectangle x1="-29.464" y1="-0.254" x2="-28.956" y2="0.254" layer="51"/>
<rectangle x1="-32.004" y1="-0.254" x2="-31.496" y2="0.254" layer="51"/>
<rectangle x1="34.036" y1="-0.254" x2="34.544" y2="0.254" layer="51"/>
<rectangle x1="36.576" y1="-0.254" x2="37.084" y2="0.254" layer="51"/>
<rectangle x1="39.116" y1="-0.254" x2="39.624" y2="0.254" layer="51"/>
<rectangle x1="41.656" y1="-0.254" x2="42.164" y2="0.254" layer="51"/>
<rectangle x1="44.196" y1="-0.254" x2="44.704" y2="0.254" layer="51"/>
<rectangle x1="46.736" y1="-0.254" x2="47.244" y2="0.254" layer="51"/>
<rectangle x1="49.276" y1="-0.254" x2="49.784" y2="0.254" layer="51"/>
</package>
<package name="MAGJACK">
<wire x1="0" y1="21.095" x2="15.14" y2="21.095" width="0.2032" layer="21"/>
<wire x1="0" y1="5.895" x2="15.24" y2="5.895" width="0.2032" layer="21"/>
<wire x1="0" y1="8.095" x2="0" y2="-0.105" width="0.2032" layer="51"/>
<wire x1="0" y1="-0.105" x2="15.24" y2="-0.105" width="0.2032" layer="51"/>
<wire x1="15.24" y1="-0.105" x2="15.24" y2="8.095" width="0.2032" layer="51"/>
<wire x1="0" y1="21" x2="0" y2="15.5" width="0.2032" layer="21"/>
<wire x1="15.2" y1="21.1" x2="15.2" y2="15.5" width="0.2032" layer="21"/>
<wire x1="0" y1="6" x2="0" y2="12.7" width="0.2032" layer="21"/>
<wire x1="15.2" y1="5.9" x2="15.2" y2="12.7" width="0.2032" layer="21"/>
<pad name="8" x="12.065" y="19.985" drill="1" diameter="1.8796"/>
<pad name="7" x="10.795" y="17.445" drill="1" diameter="1.8796"/>
<pad name="6" x="9.525" y="19.985" drill="1" diameter="1.8796"/>
<pad name="4" x="6.985" y="19.985" drill="1" diameter="1.8796"/>
<pad name="2" x="4.445" y="19.985" drill="1" diameter="1.8796"/>
<pad name="5" x="8.255" y="17.445" drill="1" diameter="1.8796"/>
<pad name="3" x="5.715" y="17.445" drill="1" diameter="1.8796"/>
<pad name="1" x="3.175" y="17.445" drill="1" diameter="1.8796" shape="square"/>
<pad name="M1" x="0" y="14.1" drill="1.6" diameter="2.1844"/>
<pad name="M2" x="15.2" y="14.1" drill="1.6" diameter="2.1844"/>
<pad name="9" x="1" y="7.1" drill="1" diameter="1.27"/>
<pad name="12" x="14.2" y="7.1" drill="1" diameter="1.27"/>
<pad name="11" x="11.7" y="7.1" drill="1" diameter="1.27"/>
<pad name="10" x="3.5" y="7.1" drill="1" diameter="1.27"/>
<hole x="1.905" y="11.095" drill="3.2"/>
<hole x="13.335" y="11.095" drill="3.2"/>
</package>
<package name="MAGJACK-19938">
<wire x1="-19.69" y1="-3.655" x2="-10.9" y2="-3.655" width="0.2032" layer="51"/>
<wire x1="-10.9" y1="12.545" x2="-19.69" y2="12.545" width="0.2032" layer="51"/>
<wire x1="-19.69" y1="12.545" x2="-19.69" y2="-3.655" width="0.2032" layer="51"/>
<wire x1="5.61" y1="12.545" x2="-4.35" y2="12.545" width="0.2032" layer="21"/>
<wire x1="-7.32" y1="12.545" x2="-10.99" y2="12.545" width="0.2032" layer="21"/>
<wire x1="-10.99" y1="12.545" x2="-10.99" y2="-3.655" width="0.2032" layer="21"/>
<wire x1="-10.99" y1="-3.655" x2="-7.32" y2="-3.655" width="0.2032" layer="21"/>
<wire x1="-4.35" y1="-3.61" x2="5.61" y2="-3.61" width="0.2032" layer="21"/>
<wire x1="5.61" y1="-3.61" x2="5.61" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.61" y1="-0.145" x2="5.61" y2="0.635" width="0.2032" layer="21"/>
<wire x1="5.61" y1="2.455" x2="5.61" y2="6.435" width="0.2032" layer="21"/>
<wire x1="5.61" y1="8.255" x2="5.61" y2="9.035" width="0.2032" layer="21"/>
<wire x1="5.61" y1="12.545" x2="5.61" y2="10.835" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="0.9" shape="square"/>
<pad name="2" x="-2.54" y="1.27" drill="0.9"/>
<pad name="3" x="0" y="2.54" drill="0.9"/>
<pad name="4" x="-2.54" y="3.81" drill="0.9"/>
<pad name="5" x="0" y="5.08" drill="0.9"/>
<pad name="6" x="-2.54" y="6.35" drill="0.9"/>
<pad name="7" x="0" y="7.62" drill="0.9"/>
<pad name="8" x="-2.54" y="8.89" drill="0.9"/>
<pad name="9" x="4.83" y="-1.02" drill="1.02"/>
<pad name="12" x="4.83" y="9.91" drill="1.02"/>
<pad name="11" x="4.83" y="7.37" drill="1.02"/>
<pad name="10" x="4.83" y="1.52" drill="1.02"/>
<pad name="P$1" x="-5.84" y="-3.455" drill="1.6"/>
<pad name="P$2" x="-5.84" y="12.345" drill="1.6"/>
<text x="-10.16" y="6.35" size="0.4064" layer="25">&gt;Name</text>
<text x="-10.16" y="2.54" size="0.4064" layer="27">&gt;Value</text>
<hole x="-8.89" y="-1.27" drill="3.15"/>
<hole x="-8.89" y="10.16" drill="3.15"/>
</package>
<package name="MAGJACK-POE">
<description>&lt;h3&gt;PoE Compatible MagJack&lt;/h3&gt;
This RJ-45 jack with magnetics has 10 pins, gives you access to the unused twisted pair (10BASE-T, and 100BASE-T) which usually carries power in a power-over-ethernet system.
&lt;br&gt;
&lt;br&gt;
&lt;b&gt;Footprint is Proven&lt;/b&gt;</description>
<wire x1="-8.05" y1="-1.7" x2="-8.05" y2="10.8" width="0.1778" layer="21"/>
<wire x1="-8.05" y1="10.8" x2="8.05" y2="10.8" width="0.1778" layer="21"/>
<wire x1="8.05" y1="10.8" x2="8.05" y2="-1.7" width="0.1778" layer="21"/>
<wire x1="9.24" y1="3.98" x2="8.7868" y2="5.3192" width="0.1778" layer="51" curve="-59.756232"/>
<wire x1="8.7868" y1="5.3192" x2="9.34" y2="9.31" width="0.1778" layer="51"/>
<wire x1="9.34" y1="9.31" x2="8.05" y2="10.8" width="0.1778" layer="51" curve="89.99231"/>
<wire x1="-9.24" y1="3.98" x2="-8.7868" y2="5.3192" width="0.1778" layer="51" curve="59.756232"/>
<wire x1="-8.7868" y1="5.3192" x2="-9.34" y2="9.31" width="0.1778" layer="51"/>
<wire x1="-9.34" y1="9.31" x2="-8.05" y2="10.8" width="0.1778" layer="51" curve="-89.99231"/>
<wire x1="8.05" y1="-10.8" x2="-8.05" y2="-10.8" width="0.1778" layer="21"/>
<wire x1="-8.05" y1="-10.8" x2="-8.05" y2="-4.7" width="0.1778" layer="21"/>
<wire x1="8.05" y1="-10.8" x2="8.05" y2="-4.7" width="0.1778" layer="21"/>
<pad name="GND0" x="-7.745" y="-3.17" drill="1.63"/>
<pad name="GND1" x="7.745" y="-3.17" drill="1.63"/>
<pad name="5" x="0.64" y="-8.89" drill="0.89"/>
<pad name="4" x="1.91" y="-6.35" drill="0.89"/>
<pad name="2" x="4.45" y="-6.35" drill="0.89"/>
<pad name="6" x="-0.63" y="-6.35" drill="0.89"/>
<pad name="8" x="-3.17" y="-6.35" drill="0.89"/>
<pad name="10" x="-5.71" y="-6.35" drill="0.89"/>
<pad name="3" x="3.18" y="-8.89" drill="0.89"/>
<pad name="1" x="5.72" y="-8.89" drill="0.89"/>
<pad name="7" x="-1.9" y="-8.89" drill="0.89"/>
<pad name="9" x="-4.44" y="-8.89" drill="0.89"/>
<pad name="14" x="-6.625" y="4.08" drill="1.02"/>
<pad name="11" x="6.625" y="4.08" drill="1.02"/>
<pad name="12" x="4.085" y="4.08" drill="1.02"/>
<pad name="13" x="-4.085" y="4.08" drill="1.02"/>
<hole x="-5.715" y="-0.12" drill="3.25"/>
<hole x="5.715" y="-0.12" drill="3.25"/>
</package>
<package name="DIN_5_FEMALE_SUPPORT">
<wire x1="0.44" y1="3.6" x2="0.46" y2="3.6" width="0.09" layer="51"/>
<wire x1="-10.16" y1="-8.89" x2="11.04" y2="-8.89" width="0.2032" layer="21"/>
<wire x1="11.04" y1="-8.89" x2="11.04" y2="7.59" width="0.2032" layer="21"/>
<wire x1="11.04" y1="7.59" x2="-10.16" y2="7.59" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="7.59" x2="-10.16" y2="-8.89" width="0.2032" layer="21"/>
<pad name="2" x="0.46" y="3.61" drill="1.4" diameter="2.286"/>
<pad name="1" x="7.94" y="3.6" drill="1.4" diameter="2.286"/>
<pad name="3" x="-7.07" y="3.6" drill="1.4" diameter="2.286"/>
<pad name="5" x="-4.53" y="6.12" drill="1.4" diameter="2.286"/>
<pad name="4" x="5.47" y="6.13" drill="1.4" diameter="2.286"/>
<pad name="6" x="-4.53" y="-6.3822" drill="1.4" diameter="2.286"/>
<pad name="7" x="5.4776" y="-6.3822" drill="1.4" diameter="2.286"/>
<text x="-2.94" y="-2.56" size="1.6764" layer="21" ratio="15">DIN-5</text>
</package>
<package name="DIN_5_FEMALE">
<wire x1="-10.16" y1="-8.89" x2="11.04" y2="-8.89" width="0.127" layer="21"/>
<wire x1="11.04" y1="-8.89" x2="11.04" y2="7.59" width="0.127" layer="21"/>
<wire x1="11.04" y1="7.59" x2="-10.16" y2="7.59" width="0.127" layer="21"/>
<wire x1="-10.16" y1="7.59" x2="-10.16" y2="-8.89" width="0.127" layer="21"/>
<pad name="2" x="0.46" y="3.61" drill="1.4"/>
<pad name="1" x="7.94" y="3.6" drill="1.4"/>
<pad name="3" x="-7.07" y="3.6" drill="1.4"/>
<pad name="5" x="-4.53" y="6.12" drill="1.4"/>
<pad name="4" x="5.47" y="6.13" drill="1.4"/>
<hole x="-4.52" y="-6.38" drill="1.4"/>
<hole x="5.47" y="-6.38" drill="1.4"/>
</package>
<package name="MINI-DIN6">
<wire x1="-7" y1="0" x2="-7" y2="-12.4" width="0.2032" layer="21"/>
<wire x1="7" y1="0" x2="7" y2="-12.4" width="0.2032" layer="21"/>
<wire x1="-7" y1="0" x2="7" y2="0" width="0.2032" layer="21"/>
<wire x1="-7" y1="-12.4" x2="7" y2="-12.4" width="0.2032" layer="21"/>
<wire x1="-7" y1="-1" x2="7" y2="-1" width="0.2032" layer="51"/>
<pad name="3" x="-3.4" y="-8.5" drill="0.9"/>
<pad name="1" x="-1.3" y="-8.5" drill="0.9"/>
<pad name="2" x="1.3" y="-8.5" drill="0.9"/>
<pad name="4" x="3.4" y="-8.5" drill="0.9"/>
<pad name="5" x="-3.4" y="-11" drill="0.9"/>
<pad name="6" x="3.4" y="-11" drill="0.9"/>
<pad name="P$1" x="0" y="-4.7" drill="2.2"/>
<text x="-5.08" y="-5.08" size="0.4064" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="MIRF">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-0.635" y1="3.81" x2="-1.27" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="4.445" x2="-1.27" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="5.715" x2="-0.635" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="6.35" x2="0.635" y2="6.35" width="0.1524" layer="21"/>
<wire x1="0.635" y1="6.35" x2="1.27" y2="5.715" width="0.1524" layer="21"/>
<wire x1="1.27" y1="5.715" x2="1.27" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.27" y1="4.445" x2="0.635" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-0.635" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.1524" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.81" x2="-1.27" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.27" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="0.635" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-8.255" x2="-1.27" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-6.985" x2="-0.635" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-6.35" x2="1.27" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-6.35" x2="-1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-5.715" x2="-1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-4.445" x2="-0.635" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.81" x2="0.635" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.81" x2="1.27" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-4.445" x2="1.27" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-5.715" x2="0.635" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-8.89" x2="0.635" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-8.255" x2="-0.635" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-8.89" x2="1.27" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-6.985" x2="1.27" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="8.255" x2="-0.635" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="8.89" x2="0.635" y2="8.89" width="0.1524" layer="21"/>
<wire x1="0.635" y1="8.89" x2="1.27" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-0.635" y2="6.35" width="0.1524" layer="21"/>
<wire x1="0.635" y1="6.35" x2="1.27" y2="6.985" width="0.1524" layer="21"/>
<wire x1="1.27" y1="8.255" x2="1.27" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="8.89" x2="-2.159" y2="-8.89" width="0.127" layer="51"/>
<wire x1="-2.159" y1="-8.89" x2="33.274" y2="-8.89" width="0.127" layer="51"/>
<wire x1="33.274" y1="-8.89" x2="33.274" y2="8.89" width="0.127" layer="51"/>
<wire x1="33.274" y1="8.89" x2="-2.159" y2="8.89" width="0.127" layer="51"/>
<pad name="1" x="0" y="-7.62" drill="1.016" rot="R180"/>
<pad name="2" x="0" y="-5.08" drill="1.016" rot="R180"/>
<pad name="3" x="0" y="-2.54" drill="1.016" rot="R180"/>
<pad name="4" x="0" y="0" drill="1.016" rot="R180"/>
<pad name="5" x="0" y="2.54" drill="1.016" rot="R180"/>
<pad name="6" x="0" y="5.08" drill="1.016" rot="R180"/>
<pad name="7" x="0" y="7.62" drill="1.016" rot="R180"/>
<text x="2.3862" y="10.5912" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
<text x="2.54" y="7.62" size="0.6096" layer="25">3.3V</text>
<text x="2.54" y="5.08" size="0.6096" layer="25">CE</text>
<text x="2.54" y="2.54" size="0.6096" layer="25">CS</text>
<text x="2.54" y="0" size="0.6096" layer="25">DR1</text>
<text x="2.54" y="-2.54" size="0.6096" layer="25">CLK1</text>
<text x="2.54" y="-5.08" size="0.6096" layer="25">DATA</text>
<text x="2.54" y="-7.62" size="0.6096" layer="25">GND</text>
<rectangle x1="-0.254" y1="4.826" x2="0.254" y2="5.334" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="2.286" x2="0.254" y2="2.794" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="-2.794" x2="0.254" y2="-2.286" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="-5.334" x2="0.254" y2="-4.826" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="-7.874" x2="0.254" y2="-7.366" layer="51" rot="R90"/>
<rectangle x1="-0.254" y1="7.366" x2="0.254" y2="7.874" layer="51" rot="R90"/>
</package>
<package name="OBDII">
<description>OBDII Connector footprint, for your late model automotive needs</description>
<pad name="8" x="-13.97" y="-3.81" drill="2.2"/>
<pad name="7" x="-10.02" y="-3.81" drill="2.2"/>
<pad name="6" x="-6.07" y="-3.81" drill="2.2"/>
<pad name="5" x="-2.12" y="-3.81" drill="2.2"/>
<pad name="4" x="1.83" y="-3.81" drill="2.2"/>
<pad name="3" x="5.78" y="-3.81" drill="2.2"/>
<pad name="2" x="9.73" y="-3.81" drill="2.2"/>
<pad name="1" x="13.68" y="-3.81" drill="2.2"/>
<pad name="16" x="-13.97" y="4.59" drill="2.2"/>
<pad name="15" x="-10.02" y="4.59" drill="2.2"/>
<pad name="14" x="-6.07" y="4.59" drill="2.2"/>
<pad name="13" x="-2.12" y="4.59" drill="2.2"/>
<pad name="12" x="1.83" y="4.59" drill="2.2"/>
<pad name="11" x="5.78" y="4.59" drill="2.2"/>
<pad name="10" x="9.73" y="4.59" drill="2.2"/>
<pad name="9" x="13.68" y="4.59" drill="2.2"/>
<text x="13.335" y="-1.905" size="1.27" layer="21">1</text>
<text x="-15.24" y="1.27" size="1.27" layer="21">16</text>
</package>
<package name="PIC-ICSP-MINI">
<wire x1="-4" y1="1" x2="-4" y2="-1" width="0.2032" layer="51"/>
<wire x1="-4" y1="-1" x2="4" y2="-1" width="0.2032" layer="51"/>
<wire x1="4" y1="-1" x2="4" y2="1" width="0.2032" layer="51"/>
<wire x1="4" y1="1" x2="-4" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1" x2="-3.6" y2="1" width="0.2032" layer="21"/>
<pad name="1" x="-3" y="0" drill="0.7" shape="square"/>
<pad name="2" x="-1.5" y="0" drill="0.7"/>
<pad name="3" x="0" y="0" drill="0.7"/>
<pad name="4" x="1.5" y="0" drill="0.7"/>
<pad name="5" x="3" y="0" drill="0.7"/>
</package>
<package name="2X12">
<wire x1="-15.24" y1="-1.905" x2="-14.605" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.065" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.24" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="1.905" x2="-14.605" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="2.54" x2="-13.335" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="2.54" x2="-12.7" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.065" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-10.795" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-10.795" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-13.335" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="-2.875" x2="-14.605" y2="-2.875" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.2032" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.2032" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.2032" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.2032" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.2032" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.2032" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.795" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="13.335" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.2032" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.2032" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.795" y2="2.54" width="0.2032" layer="21"/>
<wire x1="10.795" y1="2.54" x2="12.065" y2="2.54" width="0.2032" layer="21"/>
<wire x1="12.065" y1="2.54" x2="12.7" y2="1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="1.905" x2="13.335" y2="2.54" width="0.2032" layer="21"/>
<wire x1="13.335" y1="2.54" x2="14.605" y2="2.54" width="0.2032" layer="21"/>
<wire x1="14.605" y1="2.54" x2="15.24" y2="1.905" width="0.2032" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="14.605" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="12.065" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.2032" layer="21"/>
<pad name="1" x="-13.97" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-13.97" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="-8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="-8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="-6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="-6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="-3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="-3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="-1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="17" x="6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="18" x="6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="19" x="8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="20" x="8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="21" x="11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="22" x="11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="23" x="13.97" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="24" x="13.97" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-15.24" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-15.24" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-14.224" y1="-1.524" x2="-13.716" y2="-1.016" layer="51"/>
<rectangle x1="-14.224" y1="1.016" x2="-13.716" y2="1.524" layer="51"/>
<rectangle x1="-11.684" y1="1.016" x2="-11.176" y2="1.524" layer="51"/>
<rectangle x1="-11.684" y1="-1.524" x2="-11.176" y2="-1.016" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="11.176" y1="1.016" x2="11.684" y2="1.524" layer="51"/>
<rectangle x1="11.176" y1="-1.524" x2="11.684" y2="-1.016" layer="51"/>
<rectangle x1="13.716" y1="1.016" x2="14.224" y2="1.524" layer="51"/>
<rectangle x1="13.716" y1="-1.524" x2="14.224" y2="-1.016" layer="51"/>
</package>
<package name="2X03">
<wire x1="-3.81" y1="-1.905" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.905" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.905" x2="-3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.905" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.27" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.905" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.905" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-3.81" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
<wire x1="-3.81" y1="-3.175" x2="-1.27" y2="-3.175" width="0.1524" layer="21"/>
</package>
<package name="2X26">
<wire x1="-12.7" y1="-1.905" x2="-12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="8.255" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="6.985" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="4.445" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="1.905" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-0.635" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-2.54" x2="-5.715" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-2.54" x2="-8.255" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.795" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.54" x2="12.065" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.065" y1="2.54" x2="12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="10.795" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="12.065" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-1.905" x2="15.875" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-2.54" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="18.415" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-2.54" x2="20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="20.955" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-2.54" x2="22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-1.905" x2="23.495" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="24.765" y1="-2.54" x2="25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="26.035" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="27.305" y1="-2.54" x2="27.94" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.7" y2="1.905" width="0.1524" layer="21"/>
<wire x1="12.7" y1="1.905" x2="13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="14.605" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.605" y1="2.54" x2="15.24" y2="1.905" width="0.1524" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.875" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="2.54" x2="17.145" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.145" y1="2.54" x2="17.78" y2="1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.905" x2="18.415" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="2.54" x2="19.685" y2="2.54" width="0.1524" layer="21"/>
<wire x1="19.685" y1="2.54" x2="20.32" y2="1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.955" y2="2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="2.54" x2="22.225" y2="2.54" width="0.1524" layer="21"/>
<wire x1="22.225" y1="2.54" x2="22.86" y2="1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="1.905" x2="23.495" y2="2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="2.54" x2="24.765" y2="2.54" width="0.1524" layer="21"/>
<wire x1="24.765" y1="2.54" x2="25.4" y2="1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="1.905" x2="26.035" y2="2.54" width="0.1524" layer="21"/>
<wire x1="26.035" y1="2.54" x2="27.305" y2="2.54" width="0.1524" layer="21"/>
<wire x1="27.305" y1="2.54" x2="27.94" y2="1.905" width="0.1524" layer="21"/>
<wire x1="27.94" y1="1.905" x2="28.575" y2="2.54" width="0.1524" layer="21"/>
<wire x1="28.575" y1="2.54" x2="29.845" y2="2.54" width="0.1524" layer="21"/>
<wire x1="29.845" y1="2.54" x2="30.48" y2="1.905" width="0.1524" layer="21"/>
<wire x1="30.48" y1="1.905" x2="31.115" y2="2.54" width="0.1524" layer="21"/>
<wire x1="31.115" y1="2.54" x2="32.385" y2="2.54" width="0.1524" layer="21"/>
<wire x1="32.385" y1="2.54" x2="33.02" y2="1.905" width="0.1524" layer="21"/>
<wire x1="33.02" y1="1.905" x2="33.655" y2="2.54" width="0.1524" layer="21"/>
<wire x1="33.655" y1="2.54" x2="34.925" y2="2.54" width="0.1524" layer="21"/>
<wire x1="34.925" y1="2.54" x2="35.56" y2="1.905" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-1.905" x2="34.925" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-1.905" x2="33.655" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="33.02" y1="-1.905" x2="32.385" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-1.905" x2="31.115" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="30.48" y1="-1.905" x2="29.845" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="27.94" y1="-1.905" x2="28.575" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.24" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.905" x2="17.78" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.32" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="22.86" y1="1.905" x2="22.86" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="25.4" y1="1.905" x2="25.4" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="27.94" y1="1.905" x2="27.94" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="30.48" y1="1.905" x2="30.48" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="33.02" y1="1.905" x2="33.02" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="35.56" y1="1.905" x2="35.56" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="33.655" y1="-2.54" x2="34.925" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="31.115" y1="-2.54" x2="32.385" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="28.575" y1="-2.54" x2="29.845" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="26.035" y1="-2.54" x2="27.305" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="23.495" y1="-2.54" x2="24.765" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="20.955" y1="-2.54" x2="22.225" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="19.685" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="17.145" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="14.605" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="35.56" y1="1.905" x2="36.195" y2="2.54" width="0.1524" layer="21"/>
<wire x1="36.195" y1="2.54" x2="37.465" y2="2.54" width="0.1524" layer="21"/>
<wire x1="35.56" y1="-1.905" x2="36.195" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="36.195" y1="-2.54" x2="37.465" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="37.465" y1="-2.54" x2="38.1" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="38.1" y1="-1.905" x2="38.735" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="40.005" y1="-2.54" x2="40.64" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="40.64" y1="-1.905" x2="41.275" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="42.545" y1="-2.54" x2="43.18" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="37.465" y1="2.54" x2="38.1" y2="1.905" width="0.1524" layer="21"/>
<wire x1="38.1" y1="1.905" x2="38.735" y2="2.54" width="0.1524" layer="21"/>
<wire x1="38.735" y1="2.54" x2="40.005" y2="2.54" width="0.1524" layer="21"/>
<wire x1="40.005" y1="2.54" x2="40.64" y2="1.905" width="0.1524" layer="21"/>
<wire x1="40.64" y1="1.905" x2="41.275" y2="2.54" width="0.1524" layer="21"/>
<wire x1="41.275" y1="2.54" x2="42.545" y2="2.54" width="0.1524" layer="21"/>
<wire x1="42.545" y1="2.54" x2="43.18" y2="1.905" width="0.1524" layer="21"/>
<wire x1="43.18" y1="1.905" x2="43.815" y2="2.54" width="0.1524" layer="21"/>
<wire x1="43.815" y1="2.54" x2="45.085" y2="2.54" width="0.1524" layer="21"/>
<wire x1="45.085" y1="2.54" x2="45.72" y2="1.905" width="0.1524" layer="21"/>
<wire x1="45.72" y1="1.905" x2="46.355" y2="2.54" width="0.1524" layer="21"/>
<wire x1="46.355" y1="2.54" x2="47.625" y2="2.54" width="0.1524" layer="21"/>
<wire x1="47.625" y1="2.54" x2="48.26" y2="1.905" width="0.1524" layer="21"/>
<wire x1="48.26" y1="1.905" x2="48.895" y2="2.54" width="0.1524" layer="21"/>
<wire x1="48.895" y1="2.54" x2="50.165" y2="2.54" width="0.1524" layer="21"/>
<wire x1="50.165" y1="2.54" x2="50.8" y2="1.905" width="0.1524" layer="21"/>
<wire x1="50.8" y1="-1.905" x2="50.165" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-1.905" x2="48.895" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="48.26" y1="-1.905" x2="47.625" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="45.72" y1="-1.905" x2="46.355" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="45.72" y1="-1.905" x2="45.085" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="43.18" y1="-1.905" x2="43.815" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="38.1" y1="1.905" x2="38.1" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="40.64" y1="1.905" x2="40.64" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="43.18" y1="1.905" x2="43.18" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="45.72" y1="1.905" x2="45.72" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="48.26" y1="1.905" x2="48.26" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="50.8" y1="1.905" x2="50.8" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="48.895" y1="-2.54" x2="50.165" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="46.355" y1="-2.54" x2="47.625" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="43.815" y1="-2.54" x2="45.085" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="41.275" y1="-2.54" x2="42.545" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="38.735" y1="-2.54" x2="40.005" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="50.8" y1="1.905" x2="51.435" y2="2.54" width="0.1524" layer="21"/>
<wire x1="51.435" y1="2.54" x2="52.705" y2="2.54" width="0.1524" layer="21"/>
<wire x1="52.705" y1="2.54" x2="53.34" y2="1.905" width="0.1524" layer="21"/>
<wire x1="53.34" y1="-1.905" x2="52.705" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="50.8" y1="-1.905" x2="51.435" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="53.34" y1="1.905" x2="53.34" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="51.435" y1="-2.54" x2="52.705" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="-11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="-8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="-8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="-6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="-6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="-3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="-3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="-1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="13" x="3.81" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="14" x="3.81" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="15" x="6.35" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="16" x="6.35" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="17" x="8.89" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="18" x="8.89" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="19" x="11.43" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="20" x="11.43" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="21" x="13.97" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="22" x="13.97" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="23" x="16.51" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="24" x="16.51" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="25" x="19.05" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="26" x="19.05" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="27" x="21.59" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="28" x="21.59" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="29" x="24.13" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="30" x="24.13" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="31" x="26.67" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="32" x="26.67" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="33" x="29.21" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="34" x="29.21" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="35" x="31.75" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="36" x="31.75" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="37" x="34.29" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="38" x="34.29" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="39" x="36.83" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="40" x="36.83" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="41" x="39.37" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="42" x="39.37" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="43" x="41.91" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="44" x="41.91" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="45" x="44.45" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="46" x="44.45" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="47" x="46.99" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="48" x="46.99" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="49" x="49.53" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="50" x="49.53" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="51" x="52.07" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="52" x="52.07" y="1.27" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-12.7" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.7" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="16.256" y1="1.016" x2="16.764" y2="1.524" layer="51"/>
<rectangle x1="16.256" y1="-1.524" x2="16.764" y2="-1.016" layer="51"/>
<rectangle x1="18.796" y1="1.016" x2="19.304" y2="1.524" layer="51"/>
<rectangle x1="18.796" y1="-1.524" x2="19.304" y2="-1.016" layer="51"/>
<rectangle x1="21.336" y1="1.016" x2="21.844" y2="1.524" layer="51"/>
<rectangle x1="23.876" y1="1.016" x2="24.384" y2="1.524" layer="51"/>
<rectangle x1="26.416" y1="1.016" x2="26.924" y2="1.524" layer="51"/>
<rectangle x1="21.336" y1="-1.524" x2="21.844" y2="-1.016" layer="51"/>
<rectangle x1="23.876" y1="-1.524" x2="24.384" y2="-1.016" layer="51"/>
<rectangle x1="26.416" y1="-1.524" x2="26.924" y2="-1.016" layer="51"/>
<rectangle x1="28.956" y1="1.016" x2="29.464" y2="1.524" layer="51"/>
<rectangle x1="28.956" y1="-1.524" x2="29.464" y2="-1.016" layer="51"/>
<rectangle x1="31.496" y1="1.016" x2="32.004" y2="1.524" layer="51"/>
<rectangle x1="31.496" y1="-1.524" x2="32.004" y2="-1.016" layer="51"/>
<rectangle x1="34.036" y1="1.016" x2="34.544" y2="1.524" layer="51"/>
<rectangle x1="34.036" y1="-1.524" x2="34.544" y2="-1.016" layer="51"/>
<rectangle x1="36.576" y1="1.016" x2="37.084" y2="1.524" layer="51"/>
<rectangle x1="36.576" y1="-1.524" x2="37.084" y2="-1.016" layer="51"/>
<rectangle x1="39.116" y1="1.016" x2="39.624" y2="1.524" layer="51"/>
<rectangle x1="41.656" y1="1.016" x2="42.164" y2="1.524" layer="51"/>
<rectangle x1="39.116" y1="-1.524" x2="39.624" y2="-1.016" layer="51"/>
<rectangle x1="41.656" y1="-1.524" x2="42.164" y2="-1.016" layer="51"/>
<rectangle x1="44.196" y1="1.016" x2="44.704" y2="1.524" layer="51"/>
<rectangle x1="44.196" y1="-1.524" x2="44.704" y2="-1.016" layer="51"/>
<rectangle x1="46.736" y1="1.016" x2="47.244" y2="1.524" layer="51"/>
<rectangle x1="46.736" y1="-1.524" x2="47.244" y2="-1.016" layer="51"/>
<rectangle x1="49.276" y1="1.016" x2="49.784" y2="1.524" layer="51"/>
<rectangle x1="49.276" y1="-1.524" x2="49.784" y2="-1.016" layer="51"/>
<rectangle x1="51.816" y1="1.016" x2="52.324" y2="1.524" layer="51"/>
<rectangle x1="51.816" y1="-1.524" x2="52.324" y2="-1.016" layer="51"/>
</package>
<package name="POWER_JACK_SMD">
<wire x1="-5" y1="4.5" x2="-5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-5" y1="4.5" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="9.8" y1="4.5" x2="9.8" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-4.5" x2="-5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="4.5" x2="-3.5" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-2.5" x2="-3.5" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="2.5" x2="0" y2="2.5" width="0.2032" layer="21"/>
<wire x1="0" y1="2.5" x2="2.286" y2="0" width="0.2032" layer="21" curve="-90"/>
<wire x1="2.286" y1="0" x2="0" y2="-2.5" width="0.2032" layer="21" curve="-90"/>
<wire x1="0" y1="-2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="4.5" x2="-2" y2="4.5" width="0.2032" layer="21"/>
<wire x1="2" y1="4.5" x2="4.1" y2="4.5" width="0.2032" layer="21"/>
<wire x1="8.2" y1="4.5" x2="9.8" y2="4.5" width="0.2032" layer="21"/>
<wire x1="9.8" y1="-4.5" x2="8.1" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-4.5" x2="2" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-2" y1="-4.5" x2="-3.5" y2="-4.5" width="0.2032" layer="21"/>
<smd name="VIN0" x="0" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="GND" x="0" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="VIN1" x="6.1" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="P$4" x="6.1" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<hole x="0" y="0" drill="2.032"/>
<hole x="4.572" y="0" drill="2.032"/>
</package>
<package name="POWER_JACK_SLOT">
<wire x1="9.33" y1="13.7" x2="4.83" y2="13.7" width="0.2032" layer="21"/>
<wire x1="4.83" y1="13.7" x2="0.83" y2="13.7" width="0.2032" layer="51"/>
<wire x1="0.83" y1="13.7" x2="0.83" y2="12.7" width="0.2032" layer="51"/>
<wire x1="0.83" y1="12.7" x2="0.83" y2="8.4" width="0.2032" layer="21"/>
<wire x1="0.83" y1="8.4" x2="0.83" y2="6.55" width="0.2032" layer="51"/>
<wire x1="0.98" y1="13.8" x2="4.18" y2="13.8" width="0" layer="46"/>
<wire x1="0.98" y1="13.8" x2="1.48" y2="14.3" width="0" layer="46" curve="-90"/>
<wire x1="1.48" y1="14.3" x2="3.68" y2="14.3" width="0" layer="46"/>
<wire x1="3.68" y1="14.3" x2="4.18" y2="13.8" width="0" layer="46" curve="-90"/>
<wire x1="4.18" y1="13.8" x2="3.68" y2="13.3" width="0" layer="46" curve="-90"/>
<wire x1="3.68" y1="13.3" x2="1.48" y2="13.3" width="0" layer="46"/>
<wire x1="1.48" y1="13.3" x2="0.98" y2="13.8" width="0" layer="46" curve="-90"/>
<wire x1="0.98" y1="7.5" x2="1.48" y2="8" width="0" layer="46" curve="-90"/>
<wire x1="1.48" y1="8" x2="3.68" y2="8" width="0" layer="46"/>
<wire x1="3.68" y1="8" x2="4.18" y2="7.5" width="0" layer="46" curve="-90"/>
<wire x1="4.18" y1="7.5" x2="3.68" y2="7" width="0" layer="46" curve="-90"/>
<wire x1="3.68" y1="7" x2="1.48" y2="7" width="0" layer="46"/>
<wire x1="1.48" y1="7" x2="0.98" y2="7.5" width="0" layer="46" curve="-90"/>
<wire x1="7.58" y1="12.4" x2="8.08" y2="11.9" width="0" layer="46" curve="-90"/>
<wire x1="8.08" y1="11.9" x2="8.08" y2="9.7" width="0" layer="46"/>
<wire x1="8.08" y1="9.7" x2="7.58" y2="9.2" width="0" layer="46" curve="-90"/>
<wire x1="7.58" y1="9.2" x2="7.08" y2="9.7" width="0" layer="46" curve="-90"/>
<wire x1="7.08" y1="9.7" x2="7.08" y2="11.9" width="0" layer="46"/>
<wire x1="7.08" y1="11.9" x2="7.58" y2="12.4" width="0" layer="46" curve="-90"/>
<wire x1="0.83" y1="3.1" x2="0.83" y2="0.1" width="0.2032" layer="51"/>
<wire x1="9.33" y1="0.1" x2="9.33" y2="3.1" width="0.2032" layer="51"/>
<wire x1="9.33" y1="0.1" x2="0.83" y2="0.1" width="0.2032" layer="51"/>
<wire x1="0.83" y1="6.51" x2="0.83" y2="3.1" width="0.2032" layer="21"/>
<wire x1="9.33" y1="3.1" x2="9.33" y2="13.7" width="0.2032" layer="21"/>
<wire x1="0.83" y1="3.1" x2="9.33" y2="3.1" width="0.2032" layer="21"/>
<wire x1="9.33" y1="3.1" x2="9.28" y2="3.1" width="0.2032" layer="21"/>
<pad name="PWR" x="2.58" y="13.8" drill="1" diameter="2" shape="long"/>
<pad name="GND@1" x="2.58" y="7.5" drill="1" diameter="2" shape="long"/>
<pad name="GND@2" x="7.58" y="10.8" drill="1" diameter="2" shape="long" rot="R90"/>
<text x="0" y="0" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="11.43" y="0" size="1.778" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="POWER_JACK_PTH">
<wire x1="4.5" y1="13.7" x2="2.4" y2="13.7" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3" x2="-4.5" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.5" y1="0.1" x2="4.5" y2="3" width="0.2032" layer="51"/>
<wire x1="4.5" y1="0.1" x2="-4.5" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.5" y1="3" x2="4.5" y2="8.3" width="0.2032" layer="21"/>
<wire x1="4.5" y1="13.7" x2="4.5" y2="13" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3" x2="-4.5" y2="13.7" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="13.7" x2="-2.4" y2="13.7" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3" x2="4.5" y2="3" width="0.2032" layer="21"/>
<pad name="PWR" x="0" y="13.7" drill="2.9972" diameter="4.318"/>
<pad name="GND" x="0" y="7.7" drill="2.9972" diameter="4.318"/>
<pad name="GNDBREAK" x="4.7" y="10.7" drill="2.9972" diameter="4.318" rot="R90"/>
<text x="-3.81" y="5.08" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.81" y="3.81" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="POWER_JACK_COMBO">
<wire x1="9.8" y1="4.5" x2="9.8" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="4.5" x2="-3.5" y2="2.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-2.5" x2="-3.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="2.5" x2="0" y2="2.5" width="0.2032" layer="51"/>
<wire x1="0" y1="2.5" x2="2.286" y2="0" width="0.2032" layer="51" curve="-90"/>
<wire x1="2.286" y1="0" x2="0" y2="-2.5" width="0.2032" layer="51" curve="-90"/>
<wire x1="0" y1="-2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="4.5" x2="-2" y2="4.5" width="0.2032" layer="51"/>
<wire x1="2" y1="4.5" x2="4.1" y2="4.5" width="0.2032" layer="51"/>
<wire x1="8.2" y1="4.5" x2="9.8" y2="4.5" width="0.2032" layer="51"/>
<wire x1="9.8" y1="-4.5" x2="8.1" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-4.5" x2="2" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-2" y1="-4.5" x2="-3.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="8.62" y1="-1.96" x2="8.62" y2="0.14" width="0.2032" layer="51"/>
<wire x1="-2.08" y1="7.04" x2="-4.98" y2="7.04" width="0.2032" layer="51"/>
<wire x1="-4.98" y1="-1.96" x2="-2.08" y2="-1.96" width="0.2032" layer="51"/>
<wire x1="-4.98" y1="-1.96" x2="-4.98" y2="7.04" width="0.2032" layer="51"/>
<wire x1="-2.08" y1="-1.96" x2="3.22" y2="-1.96" width="0.2032" layer="51"/>
<wire x1="8.62" y1="-1.96" x2="7.92" y2="-1.96" width="0.2032" layer="51"/>
<wire x1="-2.08" y1="7.04" x2="8.62" y2="7.04" width="0.2032" layer="51"/>
<wire x1="8.62" y1="7.04" x2="8.62" y2="4.94" width="0.2032" layer="51"/>
<wire x1="-2.08" y1="7.04" x2="-2.08" y2="-1.96" width="0.2032" layer="51"/>
<wire x1="0" y1="5.715" x2="6.35" y2="5.715" width="1.27" layer="1"/>
<wire x1="6.35" y1="5.715" x2="6.35" y2="5.08" width="1.27" layer="1"/>
<wire x1="6.35" y1="5.08" x2="8.89" y2="2.54" width="1.27" layer="1"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="-1.905" width="1.27" layer="1"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-5.715" width="1.27" layer="1"/>
<wire x1="2.54" y1="-5.715" x2="0" y2="-5.715" width="1.27" layer="1"/>
<wire x1="6.35" y1="-5.715" x2="2.54" y2="-5.715" width="1.27" layer="1"/>
<wire x1="5.715" y1="-1.905" x2="2.54" y2="-1.905" width="1.27" layer="1"/>
<pad name="POWER" x="8.62" y="2.54" drill="2.9972" rot="R270"/>
<pad name="GND@1" x="2.62" y="2.54" drill="2.9972" rot="R270"/>
<pad name="GND" x="5.62" y="-2.16" drill="2.9972"/>
<smd name="POWER@1" x="0" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="GND@3" x="0" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="POWER@2" x="6.1" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="GND@4" x="6.1" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<text x="-5.08" y="7.62" size="1.778" layer="25">&gt;NAME</text>
<hole x="0" y="0" drill="1.6"/>
<hole x="5.08" y="0" drill="1.6"/>
</package>
<package name="POWER_JACK_PTH_LOCK">
<wire x1="4.3476" y1="14.2588" x2="2.4" y2="14.2588" width="0.2032" layer="21"/>
<wire x1="-4.3476" y1="3.2794" x2="-4.3476" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.3476" y1="0.1" x2="4.3476" y2="3.2794" width="0.2032" layer="51"/>
<wire x1="4.3476" y1="0.1" x2="-4.3476" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.3476" y1="3.254" x2="4.3476" y2="8.3" width="0.2032" layer="21"/>
<wire x1="4.3476" y1="14.2588" x2="4.3476" y2="13" width="0.2032" layer="21"/>
<wire x1="-4.3476" y1="3.254" x2="-4.3476" y2="14.2588" width="0.2032" layer="21"/>
<wire x1="-4.3476" y1="14.2588" x2="-2.4" y2="14.2588" width="0.2032" layer="21"/>
<wire x1="-4.3476" y1="3.254" x2="4.3476" y2="3.254" width="0.2032" layer="21"/>
<pad name="PWR" x="0" y="13.8778" drill="3.2" diameter="4.1148"/>
<pad name="GND" x="0.0254" y="6.557" drill="2.9972" diameter="4.1148"/>
<pad name="GNDBREAK" x="3.7616" y="10.7" drill="2.9972" diameter="4.1148" rot="R90"/>
<rectangle x1="-0.2159" y1="12.1793" x2="0.2413" y2="15.1003" layer="51" rot="R90"/>
<rectangle x1="-0.1397" y1="6.3119" x2="0.1397" y2="8.7503" layer="51" rot="R90"/>
<rectangle x1="4.4704" y1="9.4742" x2="4.7498" y2="11.9126" layer="51" rot="R180"/>
</package>
<package name="PSP_CONNECTOR">
<smd name="DISP" x="1" y="8" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="CK" x="1" y="8.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="HSYNC" x="1" y="7.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="GND3" x="1" y="9" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B6" x="1" y="10" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="B5" x="1" y="10.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B7" x="1" y="9.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B4" x="1" y="11" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="TEST2" x="1" y="4" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="TEST1" x="1" y="4.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="TEST3" x="1" y="3.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="NC2" x="1" y="5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="AVDD" x="1" y="6" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="NC" x="1" y="6.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="AVDD2" x="1" y="5.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="VSYNC" x="1" y="7" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B2" x="1" y="12" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="B1" x="1" y="12.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B3" x="1" y="11.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="B0" x="1" y="13" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R6" x="1" y="18" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="R5" x="1" y="18.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R7" x="1" y="17.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R4" x="1" y="19" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R2" x="1" y="20" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="R1" x="1" y="20.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R3" x="1" y="19.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="R0" x="1" y="21" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G6" x="1" y="14" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="G5" x="1" y="14.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G7" x="1" y="13.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G4" x="1" y="15" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G2" x="1" y="16" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="G1" x="1" y="16.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G3" x="1" y="15.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="G0" x="1" y="17" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="VCC" x="1" y="22" dx="0.254" dy="1.27" layer="1" rot="R90"/>
<smd name="GND2" x="1" y="22.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="VCC2" x="1" y="21.5" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="GND" x="1" y="23" dx="0.254" dy="1.27" layer="1" rot="R270"/>
<smd name="." x="4.4" y="25.3" dx="0.001" dy="0.001" layer="16" rot="R180"/>
<smd name="GND4" x="4.2" y="25.3" dx="2.2" dy="1.8" layer="1"/>
<smd name="GND5" x="4.2" y="1.3" dx="2.2" dy="1.8" layer="1"/>
</package>
<package name="PSP_TOUCH_CONNECTOR">
<description>4-Pin connector for PSP touch screen</description>
<wire x1="-3.5" y1="-4" x2="3.5" y2="-4" width="0.127" layer="51"/>
<wire x1="-3.5" y1="-4" x2="-3.5" y2="1.5" width="0.127" layer="51"/>
<wire x1="3.5" y1="-4" x2="3.5" y2="1.5" width="0.127" layer="51"/>
<wire x1="-3.5" y1="1.5" x2="3.5" y2="1.5" width="0.127" layer="51"/>
<wire x1="-3" y1="-4.25" x2="-3.7" y2="-4.25" width="0.127" layer="21"/>
<wire x1="-3.7" y1="-3.55" x2="-3.7" y2="-4.25" width="0.127" layer="21"/>
<wire x1="3.7" y1="-3.55" x2="3.7" y2="-4.25" width="0.127" layer="21"/>
<wire x1="3" y1="-4.25" x2="3.7" y2="-4.25" width="0.127" layer="21"/>
<smd name="X2" x="-0.5" y="2.85" dx="2.3" dy="0.6" layer="1" rot="R90"/>
<smd name="Y2" x="0.5" y="2.85" dx="2.3" dy="0.6" layer="1" rot="R90"/>
<smd name="X1" x="1.5" y="2.85" dx="2.3" dy="0.6" layer="1" rot="R90"/>
<smd name="Y1" x="-1.5" y="2.85" dx="2.3" dy="0.6" layer="1" rot="R90"/>
<text x="-3.25" y="0.9" size="0.4" layer="25">&gt;NAME</text>
<text x="-3.35" y="-3.85" size="0.4" layer="27">&gt;VALUE</text>
</package>
<package name="RJ9">
<description>Footprint for RJ9 simple connector. Common with telephone handsets. SparkFun SKU: PRT-08694</description>
<wire x1="5.64" y1="-6.477" x2="5.64" y2="10.16" width="0.2032" layer="21"/>
<wire x1="5.64" y1="10.16" x2="-5.64" y2="10.16" width="0.2032" layer="21"/>
<wire x1="-5.64" y1="10.16" x2="-5.64" y2="-6.477" width="0.2032" layer="21"/>
<wire x1="5.64" y1="-6.477" x2="-5.64" y2="-6.477" width="0.2032" layer="21"/>
<wire x1="-5.64" y1="-6.477" x2="-5.64" y2="-10.41" width="0.2032" layer="51"/>
<wire x1="-5.64" y1="-10.41" x2="5.64" y2="-10.41" width="0.2032" layer="51"/>
<wire x1="5.64" y1="-10.41" x2="5.64" y2="-6.477" width="0.2032" layer="51"/>
<pad name="1" x="-1.905" y="6.35" drill="0.889"/>
<pad name="2" x="-0.635" y="8.89" drill="0.889"/>
<pad name="3" x="0.635" y="6.35" drill="0.889"/>
<pad name="4" x="1.905" y="8.89" drill="0.889"/>
<hole x="-3.81" y="0" drill="3.2"/>
<hole x="3.81" y="0" drill="3.2"/>
</package>
<package name="RJ11-6">
<wire x1="6.858" y1="-5.207" x2="6.858" y2="10.414" width="0.2032" layer="21"/>
<wire x1="6.858" y1="10.414" x2="-6.858" y2="10.414" width="0.2032" layer="21"/>
<wire x1="-6.858" y1="10.414" x2="-6.858" y2="-5.207" width="0.2032" layer="21"/>
<wire x1="6.858" y1="-5.207" x2="-6.858" y2="-5.207" width="0.2032" layer="21"/>
<wire x1="-6.858" y1="-5.207" x2="-6.858" y2="-8.128" width="0.2032" layer="51"/>
<wire x1="-6.858" y1="-8.128" x2="6.858" y2="-8.128" width="0.2032" layer="51"/>
<wire x1="6.858" y1="-8.128" x2="6.858" y2="-5.207" width="0.2032" layer="51"/>
<pad name="1" x="-3.175" y="8.89" drill="1.016" diameter="1.8796"/>
<pad name="2" x="-1.905" y="6.35" drill="1.016" diameter="1.8796"/>
<pad name="3" x="-0.635" y="8.89" drill="1.016" diameter="1.8796"/>
<pad name="4" x="0.635" y="6.35" drill="1.016" diameter="1.8796"/>
<pad name="5" x="1.905" y="8.89" drill="1.016" diameter="1.8796"/>
<pad name="6" x="3.175" y="6.35" drill="1.016" diameter="1.8796"/>
<hole x="-5.08" y="0" drill="3.2512"/>
<hole x="5.08" y="0" drill="3.2512"/>
<text x="-2.54" y="2.54" size="0.4064" layer="25">&gt;Name</text>
<text x="-2.54" y="1.27" size="0.4064" layer="27">&gt;Value</text>
</package>
<package name="RJ45-8">
<wire x1="-7.62" y1="10" x2="7.62" y2="10" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-3" x2="-7.62" y2="10" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-3" x2="7.62" y2="-3" width="0.2032" layer="21"/>
<wire x1="7.62" y1="10" x2="7.62" y2="-3" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-3" x2="-7.62" y2="-10.8" width="0.2032" layer="51"/>
<wire x1="-7.62" y1="-10.8" x2="7.62" y2="-10.8" width="0.2032" layer="51"/>
<wire x1="7.62" y1="-10.8" x2="7.62" y2="-3" width="0.2032" layer="51"/>
<pad name="8" x="4.445" y="8.89" drill="1" diameter="1.8796"/>
<pad name="7" x="3.175" y="6.35" drill="1" diameter="1.8796"/>
<pad name="6" x="1.905" y="8.89" drill="1" diameter="1.8796"/>
<pad name="4" x="-0.635" y="8.89" drill="1" diameter="1.8796"/>
<pad name="2" x="-3.175" y="8.89" drill="1" diameter="1.8796"/>
<pad name="5" x="0.635" y="6.35" drill="1" diameter="1.8796"/>
<pad name="3" x="-1.905" y="6.35" drill="1" diameter="1.8796"/>
<pad name="1" x="-4.445" y="6.35" drill="1" diameter="1.8796" shape="square"/>
<hole x="-5.715" y="0" drill="3.2"/>
<hole x="5.715" y="0" drill="3.2"/>
</package>
<package name="SCREENKEYMATINGCONNECTOR">
<wire x1="0" y1="0.127" x2="10" y2="0.127" width="0.2032" layer="21"/>
<wire x1="10" y1="0.127" x2="10" y2="2.032" width="0.2032" layer="21"/>
<wire x1="10" y1="3.7846" x2="10" y2="5.5" width="0.2032" layer="21"/>
<wire x1="10" y1="5.5" x2="0" y2="5.5" width="0.2032" layer="21"/>
<wire x1="0" y1="2.1082" x2="0" y2="0.127" width="0.2032" layer="21"/>
<wire x1="0" y1="5.4864" x2="0" y2="3.937" width="0.2032" layer="21"/>
<smd name="1" x="1.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="2" x="2.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="3" x="2.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="4" x="3.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="5" x="3.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="6" x="4.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="7" x="4.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="8" x="5.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="9" x="5.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="10" x="6.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="11" x="6.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="12" x="7.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="13" x="7.76" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="14" x="8.26" y="-0.36" dx="0.2" dy="0.5" layer="1" rot="R180"/>
<smd name="P$15" x="0" y="3" dx="1.28" dy="1.28" layer="1"/>
<smd name="P$16" x="10.1" y="2.9" dx="1.28" dy="1.28" layer="1"/>
</package>
<package name="SD-MMC_SOCKET-PP">
<wire x1="-13.6" y1="10.5" x2="-13.6" y2="19" width="0.2032" layer="21"/>
<wire x1="-13.6" y1="20.5" x2="-13.6" y2="23.5" width="0.2032" layer="21"/>
<wire x1="-13.6" y1="26.5" x2="-13.6" y2="29.1" width="0.2032" layer="21"/>
<wire x1="-13.6" y1="29.1" x2="14.75" y2="29.1" width="0.2032" layer="21"/>
<wire x1="14.75" y1="29.1" x2="14.75" y2="26.5" width="0.2032" layer="21"/>
<wire x1="14.75" y1="11.176" x2="14.75" y2="23.5" width="0.2032" layer="21"/>
<wire x1="-13.6" y1="6" x2="-13.6" y2="0" width="0.2032" layer="21"/>
<wire x1="-13.6" y1="0" x2="-9.34" y2="0" width="0.2032" layer="21"/>
<wire x1="10.48" y1="0" x2="14.75" y2="0" width="0.2032" layer="21"/>
<wire x1="14.75" y1="0" x2="14.75" y2="8.128" width="0.2032" layer="21"/>
<wire x1="-9.34" y1="0" x2="10.48" y2="0" width="0.2032" layer="21" curve="-176.563284"/>
<smd name="12" x="-13.1" y="7.6" dx="1.5" dy="2.5" layer="1"/>
<smd name="13" x="14.4018" y="9.525" dx="1.5" dy="2.5" layer="1"/>
<smd name="WP" x="-13.18" y="9.8" dx="1" dy="1.05" layer="1"/>
<smd name="CD" x="-13.18" y="19.8" dx="1.15" dy="1" layer="1"/>
<smd name="14" x="-14" y="25" dx="2" dy="2.5" layer="1"/>
<smd name="15" x="15.3" y="25" dx="2" dy="2.5" layer="1"/>
<smd name="SW" x="-11.938" y="30.0482" dx="1.3" dy="1.1" layer="1"/>
<smd name="8" x="-9.7282" y="29.8704" dx="1.2" dy="1.5" layer="1"/>
<smd name="7" x="-8.04" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="6" x="-5.62" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="5" x="-3.12" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="4" x="-0.62" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="3" x="1.88" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="2" x="4.38" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="1" x="6.88" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<smd name="9" x="9.38" y="29.85" dx="1.2" dy="1.5" layer="1"/>
<text x="-14" y="12" size="1.27" layer="25" rot="R90">&gt;Name</text>
<hole x="-12.1" y="5.5" drill="1.5"/>
<hole x="12.1" y="5.5" drill="1.5"/>
</package>
<package name="SIMHOLDER">
<wire x1="-11.25" y1="8.6" x2="16.09" y2="8.6" width="0.2032" layer="21"/>
<wire x1="16.09" y1="8.6" x2="16.09" y2="4.7" width="0.2032" layer="21"/>
<wire x1="16.09" y1="-4.7" x2="16.09" y2="-8.6" width="0.2032" layer="21"/>
<wire x1="16.09" y1="-8.6" x2="-11.25" y2="-8.6" width="0.2032" layer="21"/>
<wire x1="-13.61" y1="-7.625" x2="-13.61" y2="-4.7" width="0.2032" layer="21"/>
<wire x1="-13.61" y1="7.625" x2="-13.61" y2="4.7" width="0.2032" layer="21"/>
<wire x1="-13.61" y1="-7.625" x2="-11.25" y2="-7.625" width="0.2032" layer="21"/>
<wire x1="-11.25" y1="-7.625" x2="-11.25" y2="-8.6" width="0.2032" layer="21"/>
<wire x1="-11.25" y1="8.6" x2="-11.25" y2="7.625" width="0.2032" layer="21"/>
<wire x1="-11.25" y1="7.625" x2="-13.61" y2="7.625" width="0.2032" layer="21"/>
<smd name="C2" x="-12.61" y="-1.27" dx="1.2" dy="2" layer="1" rot="R90"/>
<smd name="C1" x="-12.61" y="-3.81" dx="1.2" dy="2" layer="1" rot="R90"/>
<smd name="C3" x="-12.61" y="1.27" dx="1.2" dy="2" layer="1" rot="R90"/>
<smd name="C7" x="12.61" y="1.27" dx="1.2" dy="2" layer="1" rot="R90"/>
<smd name="C6" x="12.61" y="-1.27" dx="1.2" dy="2" layer="1" rot="R90"/>
<smd name="C5" x="12.61" y="-3.81" dx="1.2" dy="2" layer="1" rot="R90"/>
<wire x1="-13.61" y1="4.7" x2="-11.25" y2="4.7" width="0.2032" layer="21"/>
<wire x1="-11.25" y1="-4.7" x2="-11.25" y2="4.7" width="0.2032" layer="21"/>
<wire x1="-11.25" y1="-4.7" x2="-13.61" y2="-4.7" width="0.2032" layer="21"/>
<wire x1="16.09" y1="4.7" x2="11.25" y2="4.7" width="0.2032" layer="21"/>
<wire x1="11.25" y1="4.7" x2="11.25" y2="-4.7" width="0.2032" layer="21"/>
<wire x1="11.25" y1="-4.7" x2="16.09" y2="-4.7" width="0.2032" layer="21"/>
<text x="-4" y="-3" size="1.27" layer="25">&gt;Name</text>
<text x="-4" y="-5" size="1.27" layer="27">&gt;Value</text>
<wire x1="-10" y1="7.5" x2="-10" y2="-7.5" width="0.2032" layer="51"/>
<wire x1="-10" y1="7.5" x2="12" y2="7.5" width="0.2032" layer="51"/>
<wire x1="12" y1="7.5" x2="15" y2="4.5" width="0.2032" layer="51"/>
<wire x1="15" y1="4.5" x2="15" y2="-7.5" width="0.2032" layer="51"/>
<wire x1="15" y1="-7.5" x2="-10" y2="-7.5" width="0.2032" layer="51"/>
</package>
<package name="SMARTCARD">
<description>&lt;b&gt;Description:&lt;/b&gt; S..m..r..t. I am so smrt!</description>
<wire x1="-28.15" y1="15.55" x2="-18.89" y2="15.55" width="0.2032" layer="21"/>
<wire x1="2.71" y1="15.55" x2="28.15" y2="15.55" width="0.2032" layer="21"/>
<wire x1="28.15" y1="15.55" x2="28.15" y2="-15.55" width="0.2032" layer="21"/>
<wire x1="28.15" y1="-15.55" x2="2.71" y2="-15.55" width="0.2032" layer="21"/>
<wire x1="-18.89" y1="-15.55" x2="-28.15" y2="-15.55" width="0.2032" layer="21"/>
<wire x1="-28.15" y1="-15.55" x2="-28.15" y2="15.55" width="0.2032" layer="21"/>
<wire x1="-18.89" y1="10.7" x2="-18.89" y2="15.55" width="0.2032" layer="21"/>
<wire x1="-18.89" y1="-13.35" x2="-18.89" y2="-15.55" width="0.2032" layer="21"/>
<wire x1="2.71" y1="-13.35" x2="2.71" y2="-15.55" width="0.2032" layer="21"/>
<wire x1="2.71" y1="10.7" x2="2.71" y2="15.55" width="0.2032" layer="21"/>
<wire x1="-18.89" y1="10.7" x2="-8.29" y2="10.7" width="0.2032" layer="21"/>
<wire x1="2.11" y1="10.7" x2="2.71" y2="10.7" width="0.2032" layer="21"/>
<wire x1="-18.89" y1="-13.35" x2="-8.29" y2="-13.35" width="0.2032" layer="21"/>
<wire x1="2.11" y1="-13.35" x2="2.71" y2="-13.35" width="0.2032" layer="21"/>
<wire x1="-15" y1="-12" x2="-15" y2="-7" width="0.2032" layer="51"/>
<wire x1="-15" y1="-7" x2="-14" y2="-8" width="0.2032" layer="51"/>
<wire x1="-15" y1="-7" x2="-16" y2="-8" width="0.2032" layer="51"/>
<wire x1="21" y1="-12" x2="21" y2="-7" width="0.2032" layer="51"/>
<wire x1="21" y1="-7" x2="22" y2="-8" width="0.2032" layer="51"/>
<wire x1="21" y1="-7" x2="20" y2="-8" width="0.2032" layer="51"/>
<wire x1="-14.3" y1="-6.11" x2="-14.3" y2="14" width="0.127" layer="51"/>
<wire x1="-14.3" y1="14" x2="-22.5" y2="14" width="0.127" layer="51"/>
<wire x1="-22.5" y1="14" x2="-22.5" y2="-15" width="0.127" layer="51"/>
<smd name="C1" x="-6.92" y="11.4" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C2" x="-4.38" y="11.4" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C3" x="-1.84" y="11.4" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C4" x="0.7" y="11.4" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C8" x="0.7" y="-14.3" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C7" x="-1.84" y="-14.3" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C6" x="-4.38" y="-14.3" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="C5" x="-6.92" y="-14.3" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="P2" x="8.32" y="3.91" dx="2.1" dy="1" layer="1" rot="R90"/>
<smd name="P1" x="5.78" y="3.91" dx="2.1" dy="1" layer="1" rot="R90"/>
<text x="-11.43" y="3.81" size="1.27" layer="25">&gt;Name</text>
<text x="-11.43" y="1.27" size="1.27" layer="27">&gt;Value</text>
<text x="-14.478" y="-12.192" size="1.016" layer="51">Card inserts this direction, up side down</text>
<text x="-18.034" y="-6.604" size="1.016" layer="51" rot="R90">Card Mag Stripe</text>
<hole x="23.56" y="8.75" drill="2.2"/>
<hole x="-20.89" y="-11.57" drill="2.2"/>
</package>
<package name="SMA-EDGE">
<description>&lt;b&gt;SMA Antenna Connector&lt;/b&gt;&lt;p&gt;
This is a footprint for an edge mount RF antenna. Works pretty well with SMA type connectors but may also work with other edge mount RF connectors. Keep in mind, these edge mount connectors assume you are using a 0.062" PCB thickness.</description>
<smd name="GND@0" x="0" y="0" dx="1.524" dy="4.064" layer="1" cream="no"/>
<smd name="SIG" x="2.54" y="0" dx="1.524" dy="4.064" layer="1" cream="no"/>
<smd name="GND@1" x="5.08" y="0" dx="1.524" dy="4.064" layer="1" cream="no"/>
<smd name="GND@2" x="0" y="0" dx="1.524" dy="4.064" layer="16"/>
<smd name="GND@3" x="5.08" y="0" dx="1.524" dy="4.064" layer="16"/>
</package>
<package name="STARBOARD_GROUND">
<smd name="GROUND" x="0" y="12.065" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<polygon width="0.2032" layer="1">
<vertex x="0" y="0"/>
<vertex x="-0.5334" y="0" curve="-90"/>
<vertex x="-3.0734" y="2.54"/>
<vertex x="-3.0734" y="20.574" curve="-90"/>
<vertex x="-0.5334" y="23.114"/>
<vertex x="0" y="23.114"/>
<vertex x="0.5334" y="23.114" curve="-90"/>
<vertex x="3.0734" y="20.574"/>
<vertex x="3.0734" y="2.54" curve="-90"/>
<vertex x="0.5334" y="0"/>
</polygon>
<polygon width="0.127" layer="29">
</polygon>
</package>
<package name="STARBOARD_GROUND_SMALL">
<smd name="GROUND" x="0" y="5.715" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<polygon width="0.127" layer="1">
<vertex x="0.1778" y="0" curve="90"/>
<vertex x="1.4478" y="1.27"/>
<vertex x="1.4478" y="9.906"/>
<vertex x="1.4478" y="9.9822" curve="90"/>
<vertex x="0" y="11.43" curve="90"/>
<vertex x="-1.4478" y="9.9822"/>
<vertex x="-1.4478" y="9.906"/>
<vertex x="-1.4478" y="1.27" curve="90"/>
<vertex x="-0.1778" y="0"/>
</polygon>
</polygon>
</package>
<package name="STARBOARD_GROUND_WIDE">
<smd name="GROUND" x="0" y="7.112" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<vertex x="-1.0698" y="0" curve="-5.71033"/>
<vertex x="-1.4694" y="0.0199"/>
<vertex x="-2.54" y="0.127"/>
<vertex x="-3.5099" y="0.321" curve="-10.489176"/>
<vertex x="-4.0941" y="0.4946"/>
<vertex x="-4.2465" y="0.5556" curve="-23.19361"/>
<vertex x="-5.715" y="1.524"/>
<vertex x="-5.715" y="2.667"/>
<vertex x="-5.715" y="7.874"/>
<vertex x="-5.715" y="10.16"/>
<vertex x="-5.715" y="12.6365" curve="-45.000116"/>
<vertex x="-5.6701" y="12.7449" curve="-23.000298"/>
<vertex x="-4.3051" y="13.645"/>
<vertex x="-4.0424" y="13.7501" curve="-10.488486"/>
<vertex x="-3.5646" y="13.8921"/>
<vertex x="-2.6679" y="14.0714" curve="-5.599851"/>
<vertex x="-2.4102" y="14.11"/>
<vertex x="-1.4087" y="14.2101" curve="-5.712609"/>
<vertex x="-1.1306" y="14.224"/>
<vertex x="0" y="14.224"/>
<vertex x="1.1306" y="14.224" curve="-5.712404"/>
<vertex x="1.4087" y="14.2101"/>
<vertex x="2.3963" y="14.1114" curve="-5.600505"/>
<vertex x="2.6817" y="14.0687"/>
<vertex x="3.4591" y="13.9132" curve="-10.484425"/>
<vertex x="4.1415" y="13.7104"/>
<vertex x="4.2462" y="13.6685" curve="-23.000256"/>
<vertex x="5.715" y="12.7"/>
<vertex x="5.715" y="8.509"/>
<vertex x="5.715" y="5.207"/>
<vertex x="5.715" y="1.524"/>
<vertex x="5.7005" y="1.5095" curve="-23.197899"/>
<vertex x="4.2653" y="0.5631" curve="-10.491083"/>
<vertex x="3.3291" y="0.2848"/>
<vertex x="2.7268" y="0.1644" curve="-5.598338"/>
<vertex x="2.3505" y="0.1081" curve="-5.713213"/>
<vertex x="0.1841" y="0"/>
</polygon>
</polygon>
</package>
<package name="STARBOARD_GROUND_SMALL2">
<smd name="GROUND" x="0" y="5.2705" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<vertex x="-0.381" y="0" curve="-90"/>
<vertex x="-1.651" y="1.27"/>
<vertex x="-1.651" y="9.271" curve="-90"/>
<vertex x="-0.381" y="10.541"/>
<vertex x="0" y="10.541"/>
<vertex x="0.381" y="10.541" curve="-90"/>
<vertex x="1.651" y="9.271"/>
<vertex x="1.651" y="1.27" curve="-90"/>
<vertex x="0.381" y="0"/>
</polygon>
</polygon>
</package>
<package name="STARBOARD_PWR_WIDE">
<smd name="GROUND" x="0" y="6.985" dx="1.27" dy="0.635" layer="1" rot="R90"/>
<vertex x="-0.7356" y="0" curve="-5.714055"/>
<vertex x="-1.8017" y="0.0532" curve="-5.601848"/>
<vertex x="-3.2676" y="0.2726"/>
<vertex x="-3.3493" y="0.2889" curve="-10.494112"/>
<vertex x="-4.2462" y="0.5555" curve="-23.197905"/>
<vertex x="-5.715" y="12.7" curve="-23.198535"/>
<vertex x="-4.2462" y="13.6685"/>
<vertex x="-3.81" y="13.843"/>
<vertex x="-3.0657" y="13.9919" curve="-5.59598"/>
<vertex x="-2.0065" y="14.1504"/>
<vertex x="-1.8634" y="14.1647" curve="-5.711081"/>
<vertex x="-0.6736" y="14.224"/>
<vertex x="0.751" y="14.224" curve="-5.706545"/>
<vertex x="1.7865" y="14.1724"/>
<vertex x="1.9815" y="14.1529" curve="-5.601753"/>
<vertex x="3.0904" y="13.9869"/>
<vertex x="3.3493" y="13.9351" curve="-10.494112"/>
<vertex x="4.2462" y="13.6685" curve="-23.197905"/>
<vertex x="5.715" y="2.921"/>
<vertex x="5.0292" y="2.921"/>
<vertex x="3.302" y="3.9624"/>
<vertex x="3.2512" y="3.9878"/>
<vertex x="3.6576" y="5.969"/>
<vertex x="2.1844" y="4.6228"/>
<vertex x="0.5334" y="5.6134"/>
<vertex x="1.27" y="3.7338"/>
<vertex x="-0.1016" y="2.4892"/>
<vertex x="1.7526" y="2.6416"/>
<vertex x="2.4892" y="0.7874"/>
<vertex x="2.9718" y="2.7686"/>
<vertex x="5.5331" y="1.3421" curve="-23.197547"/>
<vertex x="4.485" y="0.651" curve="-10.489784"/>
<vertex x="3.0971" y="0.2384" curve="-5.602495"/>
<vertex x="1.9747" y="0.0705" curve="-5.710587"/>
<vertex x="0.5618" y="0"/>
</polygon>
</polygon>
</package>
<package name="STARBOARD_PWR">
<smd name="PWR" x="0" y="22.225" dx="1.27" dy="0.635" layer="1"/>
<vertex x="3.0734" y="20.32"/>
<vertex x="0.508" y="20.32"/>
<vertex x="0" y="21.844"/>
<vertex x="-0.508" y="20.32"/>
<vertex x="-2.159" y="20.32"/>
<vertex x="-0.8382" y="19.3294"/>
<vertex x="-1.397" y="17.653"/>
<vertex x="0" y="18.6944"/>
<vertex x="1.397" y="17.653"/>
<vertex x="0.8382" y="19.3294"/>
<vertex x="2.1336" y="20.2946"/>
<vertex x="3.0734" y="20.2946"/>
</polygon>
</polygon>
</package>
<package name="TOUCH-SCREEN">
<wire x1="-4.5" y1="1.25" x2="7.5" y2="1.25" width="0.127" layer="21"/>
<wire x1="7.5" y1="1.25" x2="7.5" y2="-8" width="0.127" layer="21"/>
<wire x1="7.5" y1="-8" x2="-4.5" y2="-8" width="0.127" layer="21"/>
<wire x1="-4.5" y1="-8" x2="-4.5" y2="1.25" width="0.127" layer="21"/>
<smd name="P$1" x="0" y="0" dx="0.6" dy="1.9" layer="1" rot="R180"/>
<smd name="P$2" x="1" y="0" dx="0.6" dy="1.9" layer="1"/>
<smd name="P$3" x="2" y="0" dx="0.6" dy="1.9" layer="1"/>
<smd name="P$4" x="3" y="0" dx="0.6" dy="1.9" layer="1"/>
<smd name="P$5" x="-3.15" y="-2.35" dx="2.8" dy="2.1" layer="1" rot="R90"/>
<smd name="P$6" x="6.15" y="-2.35" dx="2.8" dy="2.1" layer="1" rot="R90"/>
</package>
<package name="U.FL">
<wire x1="1.3" y1="0.7" x2="1.3" y2="2" width="0.127" layer="21"/>
<wire x1="1.3" y1="2" x2="-1.3" y2="2" width="0.127" layer="21"/>
<wire x1="-1.3" y1="-2" x2="1.3" y2="-2" width="0.127" layer="21"/>
<wire x1="1.3" y1="-2" x2="1.3" y2="-0.7" width="0.127" layer="21"/>
<wire x1="-1.3" y1="0.7" x2="-1.3" y2="2" width="0.127" layer="21"/>
<wire x1="-1.3" y1="-2" x2="-1.3" y2="-0.7" width="0.127" layer="21"/>
<wire x1="1.4" y1="0.7" x2="1.4" y2="2" width="0.127" layer="21"/>
<wire x1="1.4" y1="-2" x2="1.4" y2="-0.7" width="0.127" layer="21"/>
<wire x1="1.5" y1="0.7" x2="1.5" y2="2" width="0.127" layer="21"/>
<wire x1="1.5" y1="-2" x2="1.5" y2="-0.7" width="0.127" layer="21"/>
<wire x1="1.5" y1="2" x2="1.3" y2="2" width="0.127" layer="21"/>
<wire x1="1.5" y1="0.7" x2="1.3" y2="0.7" width="0.127" layer="21"/>
<wire x1="1.5" y1="-0.7" x2="1.3" y2="-0.7" width="0.127" layer="21"/>
<wire x1="1.5" y1="-2" x2="1.3" y2="-2" width="0.127" layer="21"/>
<smd name="P$1" x="0" y="1.375" dx="2.2" dy="0.85" layer="1"/>
<smd name="P$2" x="0" y="-1.375" dx="2.2" dy="0.85" layer="1"/>
<smd name="P$3" x="1.525" y="0" dx="1.05" dy="1" layer="1"/>
<smd name="P$4" x="-1.525" y="0" dx="1.05" dy="1" layer="1"/>
</package>
<package name="USB-A-H">
<description>&lt;b&gt;USB Series A Hole Mounted&lt;/b&gt;</description>
<wire x1="-17.8" y1="6" x2="-17.8" y2="-6" width="0.2032" layer="51"/>
<wire x1="-3" y1="6" x2="-3" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3" y1="6" x2="-17.8" y2="6" width="0.2032" layer="51"/>
<wire x1="-3" y1="-6" x2="-17.8" y2="-6" width="0.2032" layer="51"/>
<wire x1="-3" y1="6" x2="-2" y2="6" width="0.2032" layer="21"/>
<wire x1="-3" y1="-6" x2="-2" y2="-6" width="0.2032" layer="21"/>
<wire x1="1" y1="-4" x2="1" y2="4" width="0.2032" layer="21"/>
<wire x1="-13.5" y1="4.3" x2="-13.5" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-13.5" y1="1.9" x2="-11.2" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-11.2" y1="1.9" x2="-11.2" y2="4.3" width="0.2032" layer="51"/>
<wire x1="-11.2" y1="4.3" x2="-13.5" y2="4.3" width="0.2032" layer="51"/>
<wire x1="-13.5" y1="-1.9" x2="-13.5" y2="-4.3" width="0.2032" layer="51"/>
<wire x1="-13.5" y1="-4.3" x2="-11.2" y2="-4.3" width="0.2032" layer="51"/>
<wire x1="-11.2" y1="-4.3" x2="-11.2" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-11.2" y1="-1.9" x2="-13.5" y2="-1.9" width="0.2032" layer="51"/>
<pad name="GND" x="2.4" y="3.5" drill="0.9144" diameter="1.8796" rot="R270"/>
<pad name="D+" x="2.4" y="1.127" drill="0.9144" diameter="1.8796" rot="R270"/>
<pad name="D-" x="2.4" y="-1.127" drill="0.9144" diameter="1.8796" rot="R270"/>
<pad name="VBUS" x="2.4" y="-3.5" drill="0.9144" diameter="1.8796" rot="R270"/>
<pad name="GND2" x="0" y="-5.8" drill="2.2" rot="R270"/>
<pad name="GND3" x="0" y="5.8" drill="2.2" rot="R270"/>
<text x="5.85" y="-2.7" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-3.9" y="-4.4" size="1.27" layer="51" rot="R90">PCB Edge</text>
<hole x="-0.1" y="2.25" drill="1.1"/>
<hole x="-0.1" y="-2.25" drill="1.1"/>
</package>
<package name="USB-A-S">
<description>&lt;b&gt;USB Series A Surface Mounted&lt;/b&gt;</description>
<wire x1="3.6957" y1="6.5659" x2="-10.287" y2="6.5659" width="0.127" layer="21"/>
<wire x1="3.6957" y1="-6.5659" x2="-10.287" y2="-6.5659" width="0.127" layer="21"/>
<wire x1="-10.287" y1="6.477" x2="-10.287" y2="-6.477" width="0.127" layer="21"/>
<wire x1="3.7084" y1="6.5024" x2="3.7084" y2="-6.5024" width="0.127" layer="21"/>
<wire x1="-2.54" y1="-5.08" x2="-8.89" y2="-4.445" width="0.127" layer="21"/>
<wire x1="-8.89" y1="-4.445" x2="-8.89" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-8.89" y1="-1.27" x2="-2.54" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-2.54" y1="5.08" x2="-8.89" y2="4.445" width="0.127" layer="21"/>
<wire x1="-8.89" y1="4.445" x2="-8.89" y2="1.27" width="0.127" layer="21"/>
<wire x1="-8.89" y1="1.27" x2="-2.54" y2="0.635" width="0.127" layer="21"/>
<pad name="P$5" x="0" y="-6.5659" drill="2.3114" rot="R270"/>
<pad name="P$6" x="0" y="6.5659" drill="2.3114" rot="R270"/>
<smd name="D-" x="3.45" y="1" dx="3" dy="0.9" layer="1"/>
<smd name="VBUS" x="3.45" y="3" dx="3" dy="0.9" layer="1"/>
<smd name="D+" x="3.45" y="-1" dx="3" dy="0.9" layer="1"/>
<smd name="GND" x="3.45" y="-3" dx="3" dy="0.9" layer="1"/>
<text x="5.715" y="3.81" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="USB-MB-H">
<description>&lt;b&gt;USB Series Mini-B Hole Mounted&lt;/b&gt;</description>
<wire x1="-3.75" y1="3.9" x2="-3.75" y2="-3.9" width="0.127" layer="22"/>
<wire x1="5.25" y1="3.9" x2="5.25" y2="-3.9" width="0.127" layer="22"/>
<wire x1="-3.75" y1="3.9" x2="5.25" y2="3.9" width="0.127" layer="22"/>
<wire x1="-3.75" y1="-3.9" x2="5.25" y2="-3.9" width="0.127" layer="22"/>
<wire x1="0.75" y1="3.5" x2="-3.25" y2="3" width="0.127" layer="22"/>
<wire x1="-3.25" y1="3" x2="-3.25" y2="2" width="0.127" layer="22"/>
<wire x1="-3.25" y1="2" x2="0.75" y2="1.5" width="0.127" layer="22"/>
<wire x1="1.25" y1="-3.5" x2="-3.25" y2="-3" width="0.127" layer="22"/>
<wire x1="-3.25" y1="-3" x2="-3.25" y2="-2" width="0.127" layer="22"/>
<wire x1="-3.25" y1="-2" x2="1.25" y2="-1.5" width="0.127" layer="22"/>
<wire x1="-3.25" y1="1.25" x2="1.75" y2="0.75" width="0.127" layer="22"/>
<wire x1="1.75" y1="0.75" x2="1.75" y2="-0.75" width="0.127" layer="22"/>
<wire x1="1.75" y1="-0.75" x2="-3.25" y2="-1.25" width="0.127" layer="22"/>
<pad name="VBUS" x="5.1" y="1.6" drill="0.8"/>
<pad name="D+" x="5.1" y="0" drill="0.8"/>
<pad name="GND" x="5.1" y="-1.6" drill="0.8"/>
<pad name="D-" x="3.9" y="0.8" drill="0.8"/>
<pad name="ID" x="3.9" y="-0.8" drill="0.8"/>
<pad name="P$6" x="0" y="-3.65" drill="1.9"/>
<pad name="P$7" x="0" y="3.65" drill="1.9"/>
<text x="7.25" y="1.5" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<rectangle x1="3.25" y1="3" x2="5.75" y2="4.4" layer="43"/>
<rectangle x1="3.25" y1="-4.4" x2="5.75" y2="-3" layer="43"/>
<rectangle x1="-3.75" y1="-3.1" x2="-1.425" y2="3.1" layer="43"/>
<rectangle x1="-1.425" y1="-2.325" x2="-0.65" y2="2.325" layer="43"/>
</package>
<package name="USB-B-SMT">
<description>USB Series B Surface Mounted</description>
<wire x1="-1" y1="-6" x2="2.4" y2="-6" width="0.2032" layer="51"/>
<wire x1="2.4" y1="6" x2="-1" y2="6" width="0.2032" layer="51"/>
<wire x1="2.4" y1="6" x2="2.4" y2="7.3" width="0.2032" layer="51"/>
<wire x1="2.4" y1="7.3" x2="2.2" y2="7.5" width="0.2032" layer="51"/>
<wire x1="2.2" y1="7.5" x2="1.9" y2="7.5" width="0.2032" layer="51"/>
<wire x1="1.9" y1="7.5" x2="1.4" y2="7" width="0.2032" layer="51"/>
<wire x1="-1" y1="6" x2="-1" y2="7.3" width="0.2032" layer="51"/>
<wire x1="-0.8" y1="7.5" x2="-0.5" y2="7.5" width="0.2032" layer="51"/>
<wire x1="-0.5" y1="7.5" x2="0" y2="7" width="0.2032" layer="51"/>
<wire x1="0" y1="7" x2="1.4" y2="7" width="0.2032" layer="51"/>
<wire x1="-1" y1="-6" x2="-1" y2="-7.3" width="0.2032" layer="51"/>
<wire x1="-1" y1="-7.3" x2="-0.8" y2="-7.5" width="0.2032" layer="51"/>
<wire x1="-0.8" y1="-7.5" x2="-0.5" y2="-7.5" width="0.2032" layer="51"/>
<wire x1="-0.5" y1="-7.5" x2="0" y2="-7" width="0.2032" layer="51"/>
<wire x1="1.9" y1="-7.5" x2="1.4" y2="-7" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-7" x2="0" y2="-7" width="0.2032" layer="51"/>
<wire x1="-1" y1="7.3" x2="-0.8" y2="7.5" width="0.2032" layer="51"/>
<wire x1="2.2" y1="-7.5" x2="1.9" y2="-7.5" width="0.2032" layer="51"/>
<wire x1="2.2" y1="-7.5" x2="2.4" y2="-7.3" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-6" x2="2.4" y2="-7.3" width="0.2032" layer="51"/>
<wire x1="-5" y1="6" x2="-5" y2="-6" width="0.2032" layer="51"/>
<wire x1="-5" y1="6" x2="-9" y2="6" width="0.2032" layer="51"/>
<wire x1="-9" y1="6" x2="-9" y2="-6" width="0.2032" layer="51"/>
<wire x1="-9" y1="-6" x2="-5" y2="-6" width="0.2032" layer="51"/>
<wire x1="-5" y1="6" x2="-3" y2="6" width="0.2032" layer="21"/>
<wire x1="-5" y1="-6" x2="-3" y2="-6" width="0.2032" layer="21"/>
<wire x1="4" y1="-6" x2="7" y2="-6" width="0.2032" layer="21"/>
<wire x1="7" y1="-6" x2="7" y2="-3" width="0.2032" layer="21"/>
<wire x1="7" y1="3" x2="7" y2="6" width="0.2032" layer="21"/>
<wire x1="7" y1="6" x2="4" y2="6" width="0.2032" layer="21"/>
<smd name="5" x="0.58" y="6.8" dx="6.04" dy="3.4" layer="1"/>
<smd name="6" x="0.58" y="-6.8" dx="6.04" dy="3.4" layer="1"/>
<smd name="D+" x="7" y="1.875" dx="3" dy="0.7" layer="1"/>
<smd name="D-" x="7" y="0.625" dx="3" dy="0.7" layer="1"/>
<smd name="GND" x="7" y="-0.625" dx="3" dy="0.7" layer="1"/>
<smd name="VUSB" x="7" y="-1.875" dx="3" dy="0.7" layer="1"/>
<text x="4.3" y="-7.795" size="1.27" layer="25">&gt;NAME</text>
<hole x="0" y="2.25" drill="1.4"/>
<hole x="0" y="-2.25" drill="1.4"/>
</package>
<package name="USB-MINIB-OLD">
<description>&lt;b&gt;USB Series Mini-B Surface Mounted&lt;/b&gt;</description>
<wire x1="-1.5" y1="3.8" x2="0.9" y2="3.8" width="0.127" layer="21"/>
<wire x1="3.3" y1="3.1" x2="3.3" y2="2.1" width="0.127" layer="21"/>
<wire x1="3.3" y1="-2.1" x2="3.3" y2="-3.1" width="0.127" layer="21"/>
<wire x1="1" y1="-3.8" x2="-1.5" y2="-3.8" width="0.127" layer="21"/>
<wire x1="-5.9" y1="3.8" x2="-5.9" y2="-3.8" width="0.127" layer="51"/>
<wire x1="-5.9" y1="-3.8" x2="-4.5" y2="-3.8" width="0.127" layer="51"/>
<wire x1="-5.9" y1="3.8" x2="-4.5" y2="3.8" width="0.127" layer="51"/>
<smd name="1" x="-3" y="-4.5" dx="2.5" dy="2" layer="1"/>
<smd name="2" x="-3" y="4.5" dx="2.5" dy="2" layer="1"/>
<smd name="3" x="3" y="-4.5" dx="3.5" dy="2" layer="1"/>
<smd name="4" x="3" y="4.5" dx="3.5" dy="2" layer="1"/>
<smd name="D+" x="3" y="0" dx="3.5" dy="0.5" layer="1"/>
<smd name="D-" x="3" y="0.8" dx="3.5" dy="0.5" layer="1"/>
<smd name="VBUS" x="3.01" y="1.61" dx="3.5" dy="0.5" layer="1"/>
<smd name="ID" x="3" y="-0.8" dx="3.5" dy="0.5" layer="1"/>
<smd name="GND" x="3" y="-1.6" dx="3.5" dy="0.5" layer="1"/>
<text x="-3.81" y="-1.27" size="0.4064" layer="27">&gt;VALUE</text>
<text x="-3.81" y="0" size="0.4064" layer="25">&gt;NAME</text>
<hole x="0" y="2.2" drill="0.9"/>
<hole x="0" y="-2.2" drill="0.9"/>
</package>
<package name="USB-B-PTH">
<description>&lt;b&gt;USB Series B Hole Mounted&lt;/b&gt;</description>
<wire x1="-12.5" y1="6" x2="-8.6" y2="6" width="0.2032" layer="51"/>
<wire x1="-8.6" y1="6" x2="-8.6" y2="-6" width="0.2032" layer="51"/>
<wire x1="-8.6" y1="-6" x2="-12.5" y2="-6" width="0.2032" layer="51"/>
<wire x1="-12.5" y1="-6" x2="-12.5" y2="6" width="0.2032" layer="51"/>
<wire x1="-8.6" y1="6" x2="-4.8" y2="6" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="-6" x2="-4.8" y2="-6" width="0.2032" layer="21"/>
<wire x1="-0.6" y1="-6" x2="3.3" y2="-6" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-6" x2="3.3" y2="6" width="0.2032" layer="21"/>
<wire x1="3.3" y1="6" x2="-0.6" y2="6" width="0.2032" layer="21"/>
<pad name="VBUS" x="1.9812" y="-1.25" drill="0.9144" diameter="1.6764" rot="R90"/>
<pad name="D-" x="1.9812" y="1.25" drill="0.9144" diameter="1.6764" rot="R90"/>
<pad name="D+" x="0" y="1.25" drill="0.9144" diameter="1.6764" rot="R270"/>
<pad name="GND" x="0" y="-1.25" drill="0.9144" diameter="1.6764" rot="R270"/>
<pad name="S1" x="-2.7178" y="-6.0198" drill="2.286"/>
<pad name="S2" x="-2.7178" y="6.0198" drill="2.286"/>
<text x="-1.27" y="3.81" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="2.54" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="S4B-PH">
<wire x1="-6" y1="2" x2="-6" y2="-7" width="0.3048" layer="51"/>
<wire x1="-6" y1="-7" x2="6" y2="-7" width="0.3048" layer="51"/>
<wire x1="6" y1="-7" x2="6" y2="2" width="0.3048" layer="51"/>
<wire x1="6" y1="2" x2="-6" y2="2" width="0.3048" layer="51"/>
<smd name="1" x="-3" y="-4.7" dx="1" dy="4.6" layer="1"/>
<smd name="2" x="-1" y="-4.7" dx="1" dy="4.6" layer="1"/>
<smd name="3" x="1" y="-4.7" dx="1" dy="4.6" layer="1"/>
<smd name="4" x="3" y="-4.7" dx="1" dy="4.6" layer="1"/>
<smd name="P$1" x="-5.4" y="0.5" dx="3.4" dy="1.6" layer="1" rot="R90"/>
<smd name="P$2" x="5.4" y="0.5" dx="3.4" dy="1.6" layer="1" rot="R90"/>
</package>
<package name="USB-MINIB">
<wire x1="-1.3" y1="3.8" x2="0.8" y2="3.8" width="0.2032" layer="21"/>
<wire x1="3.3" y1="3.1" x2="3.3" y2="2.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.2" x2="3.3" y2="-3.1" width="0.2032" layer="21"/>
<wire x1="0.8" y1="-3.8" x2="-1.3" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-5.9" y1="3.8" x2="-5.9" y2="-3.8" width="0.2032" layer="51"/>
<wire x1="-5.9" y1="-3.8" x2="-4.5" y2="-3.8" width="0.2032" layer="51"/>
<wire x1="-5.9" y1="3.8" x2="-4.5" y2="3.8" width="0.2032" layer="51"/>
<smd name="D+" x="2.5" y="0" dx="2.5" dy="0.5" layer="1"/>
<smd name="D-" x="2.5" y="0.8" dx="2.5" dy="0.5" layer="1"/>
<smd name="GND" x="2.5" y="-1.6" dx="2.5" dy="0.5" layer="1"/>
<smd name="ID" x="2.5" y="-0.8" dx="2.5" dy="0.5" layer="1"/>
<smd name="MTN3" x="-3" y="-4.5" dx="2.5" dy="2" layer="1"/>
<smd name="MTN1" x="-3" y="4.5" dx="2.5" dy="2" layer="1"/>
<smd name="MTN4" x="2.5" y="-4.5" dx="2.5" dy="2" layer="1"/>
<smd name="MTN2" x="2.5" y="4.5" dx="2.5" dy="2" layer="1"/>
<smd name="VBUS" x="2.5" y="1.6" dx="2.5" dy="0.5" layer="1"/>
<text x="-3.81" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.81" y="0" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="USB-A-PCB">
<description>Card-edge USB A connector.
For boards designed to be plugged directly into a USB slot. If possible, ensure that your PCB is about 2.4mm thick to fit snugly.</description>
<wire x1="-5" y1="6" x2="3.7" y2="6" width="0.127" layer="51"/>
<wire x1="3.7" y1="6" x2="3.7" y2="-6" width="0.127" layer="51" style="shortdash"/>
<wire x1="3.7" y1="-6" x2="-5" y2="-6" width="0.127" layer="51"/>
<wire x1="-5" y1="-6" x2="-5" y2="6" width="0.127" layer="51"/>
<smd name="5V" x="-0.2" y="-3.5" dx="7.5" dy="1.5" layer="1"/>
<smd name="USB_M" x="0.3" y="-1" dx="6.5" dy="1" layer="1"/>
<smd name="USB_P" x="0.3" y="1" dx="6.5" dy="1" layer="1"/>
<smd name="GND" x="-0.2" y="3.5" dx="7.5" dy="1.5" layer="1"/>
<text x="-1.27" y="5.08" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="-5.08" size="0.4064" layer="27">&gt;Value</text>
<text x="-6.35" y="-3.81" size="1.016" layer="48" rot="R90">Card edge</text>
</package>
<package name="USB-B-PTH-VERTICAL">
<wire x1="0" y1="0" x2="11.938" y2="0" width="0.254" layer="21"/>
<wire x1="11.938" y1="0" x2="11.938" y2="11.303" width="0.254" layer="21"/>
<wire x1="11.938" y1="11.303" x2="0" y2="11.303" width="0.254" layer="21"/>
<wire x1="0" y1="11.303" x2="0" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="10.795" y2="1.27" width="0.254" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="8.255" width="0.254" layer="51"/>
<wire x1="10.795" y1="8.255" x2="8.89" y2="10.16" width="0.254" layer="51"/>
<wire x1="8.89" y1="10.16" x2="3.175" y2="10.16" width="0.254" layer="51"/>
<wire x1="3.175" y1="10.16" x2="1.27" y2="8.255" width="0.254" layer="51"/>
<wire x1="1.27" y1="8.255" x2="1.27" y2="1.27" width="0.254" layer="51"/>
<pad name="GND" x="7.3152" y="4.3942" drill="0.9144" diameter="1.6764" rot="R90"/>
<pad name="VBUS" x="7.3152" y="7.5946" drill="0.9144" diameter="1.6764" rot="R90"/>
<pad name="D-" x="4.826" y="7.5946" drill="0.9144" diameter="1.6764" rot="R270"/>
<pad name="D+" x="4.826" y="4.3942" drill="0.9144" diameter="1.6764" rot="R270"/>
<pad name="P$1" x="0" y="4.9022" drill="2.286"/>
<pad name="P$2" x="12.0396" y="4.9022" drill="2.286"/>
<text x="8.89" y="-1.27" size="0.8128" layer="25">&gt;NAME</text>
<text x="0" y="-1.27" size="0.8128" layer="27">&gt;VALUE</text>
</package>
<package name="USB-A-S-NOSILK">
<wire x1="3.6957" y1="6.5659" x2="-10.287" y2="6.5659" width="0.127" layer="51"/>
<wire x1="3.6957" y1="-6.5659" x2="-10.287" y2="-6.5659" width="0.127" layer="51"/>
<wire x1="-10.287" y1="6.477" x2="-10.287" y2="-6.477" width="0.127" layer="51"/>
<wire x1="3.7084" y1="6.5024" x2="3.7084" y2="-6.5024" width="0.127" layer="51"/>
<wire x1="-2.54" y1="-5.08" x2="-8.89" y2="-4.445" width="0.127" layer="51"/>
<wire x1="-8.89" y1="-4.445" x2="-8.89" y2="-1.27" width="0.127" layer="51"/>
<wire x1="-8.89" y1="-1.27" x2="-2.54" y2="-0.635" width="0.127" layer="51"/>
<wire x1="-2.54" y1="5.08" x2="-8.89" y2="4.445" width="0.127" layer="51"/>
<wire x1="-8.89" y1="4.445" x2="-8.89" y2="1.27" width="0.127" layer="51"/>
<wire x1="-8.89" y1="1.27" x2="-2.54" y2="0.635" width="0.127" layer="51"/>
<text x="5.715" y="3.81" size="1.27" layer="51" rot="R90">&gt;NAME</text>
</package>
<package name="USB-A-S-NOSILK-FEMALE">
<pad name="S1" x="0" y="-6.5659" drill="2.3114" rot="R270"/>
<pad name="S2" x="0" y="6.5659" drill="2.3114" rot="R270"/>
<smd name="D-" x="4.212" y="1" dx="3" dy="0.9" layer="1"/>
<smd name="VBUS" x="4.212" y="3.5" dx="3" dy="0.9" layer="1"/>
<smd name="D+" x="4.212" y="-1" dx="3" dy="0.9" layer="1"/>
<smd name="GND" x="4.212" y="-3.5" dx="3" dy="0.9" layer="1"/>
<text x="8.46" y="-7.205" size="1.27" layer="51" rot="R180">&gt;NAME</text>
</package>
<package name="USB-MINIB-NOSTOP">
<circle x="0" y="2.2" radius="0.35" width="0.41" layer="29"/>
<circle x="0" y="-2.2" radius="0.35" width="0.41" layer="29"/>
<pad name="H1" x="0" y="2.2" drill="0.9" diameter="0.8" stop="no"/>
<pad name="H2" x="0" y="-2.2" drill="0.9" diameter="0.7874" stop="no"/>
<smd name="G1" x="-3" y="-4.5" dx="2.5" dy="2" layer="1"/>
<smd name="G2" x="-3" y="4.5" dx="2.5" dy="2" layer="1"/>
<smd name="G4" x="2.5" y="-4.5" dx="2.5" dy="2" layer="1"/>
<smd name="G3" x="2.5" y="4.5" dx="2.5" dy="2" layer="1"/>
</package>
<package name="USB-A-S-SILK-FEMALE">
<wire x1="6.6957" y1="6.5659" x2="-7.287" y2="6.5659" width="0.127" layer="51"/>
<wire x1="6.6957" y1="-6.5659" x2="-7.287" y2="-6.5659" width="0.127" layer="51"/>
<wire x1="-7.287" y1="6.477" x2="-7.287" y2="-6.477" width="0.127" layer="51"/>
<wire x1="6.7084" y1="6.5024" x2="6.7084" y2="-6.5024" width="0.127" layer="51"/>
<wire x1="0.46" y1="-5.08" x2="-5.89" y2="-4.445" width="0.127" layer="51"/>
<wire x1="-5.89" y1="-4.445" x2="-5.89" y2="-1.27" width="0.127" layer="51"/>
<wire x1="-5.89" y1="-1.27" x2="0.46" y2="-0.635" width="0.127" layer="51"/>
<wire x1="0.46" y1="5.08" x2="-5.89" y2="4.445" width="0.127" layer="51"/>
<wire x1="-5.89" y1="4.445" x2="-5.89" y2="1.27" width="0.127" layer="51"/>
<wire x1="-5.89" y1="1.27" x2="0.46" y2="0.635" width="0.127" layer="51"/>
<wire x1="-7.366" y1="6.604" x2="0.508" y2="6.604" width="0.2032" layer="21"/>
<wire x1="-7.366" y1="6.604" x2="-7.366" y2="-6.604" width="0.2032" layer="21"/>
<wire x1="-7.366" y1="-6.604" x2="0.508" y2="-6.604" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-6.604" x2="6.858" y2="-6.604" width="0.2032" layer="21"/>
<wire x1="6.858" y1="-6.604" x2="6.858" y2="-4.318" width="0.2032" layer="21"/>
<wire x1="6.858" y1="4.318" x2="6.858" y2="6.604" width="0.2032" layer="21"/>
<wire x1="6.858" y1="6.604" x2="5.08" y2="6.604" width="0.2032" layer="21"/>
<pad name="P$5" x="3" y="-6.5659" drill="2.3114" rot="R270"/>
<pad name="P$6" x="3" y="6.5659" drill="2.3114" rot="R270"/>
<smd name="D-" x="7.212" y="1" dx="3" dy="0.9" layer="1"/>
<smd name="VBUS" x="7.212" y="3.5" dx="3" dy="0.9" layer="1"/>
<smd name="D+" x="7.212" y="-1" dx="3" dy="0.9" layer="1"/>
<smd name="GND" x="7.212" y="-3.5" dx="3" dy="0.9" layer="1"/>
<text x="-3.81" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="USB-MICROB">
<description>Micro USB Package</description>
<wire x1="-3.4" y1="-2.15" x2="-3" y2="-2.15" width="0.127" layer="51"/>
<wire x1="3" y1="-2.15" x2="3.4" y2="-2.15" width="0.127" layer="51"/>
<wire x1="-3.4" y1="-2.15" x2="-3.4" y2="-1.45" width="0.127" layer="51"/>
<wire x1="-3.4" y1="-1.45" x2="-3.4" y2="2.85" width="0.127" layer="51"/>
<wire x1="3.4" y1="2.85" x2="2.2" y2="2.85" width="0.127" layer="51"/>
<wire x1="3.4" y1="2.85" x2="3.4" y2="-1.45" width="0.127" layer="51"/>
<wire x1="3.4" y1="-1.45" x2="3.4" y2="-2.15" width="0.127" layer="51"/>
<wire x1="-3.4" y1="-1.45" x2="3.4" y2="-1.45" width="0.127" layer="51"/>
<wire x1="-3.4" y1="1.25" x2="-3.4" y2="2.85" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="2.85" x2="-2.2" y2="2.85" width="0.2032" layer="21"/>
<wire x1="3.4" y1="2.85" x2="2.2" y2="2.85" width="0.2032" layer="21"/>
<wire x1="3.4" y1="1.25" x2="3.4" y2="2.85" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-1.45" x2="3.4" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="1.45" x2="2.2" y2="1.45" width="0.127" layer="51"/>
<wire x1="2.2" y1="1.45" x2="2.2" y2="2.85" width="0.127" layer="51"/>
<wire x1="-2.2" y1="1.45" x2="-2.2" y2="2.85" width="0.127" layer="51"/>
<wire x1="-3.4" y1="2.85" x2="-2.2" y2="2.85" width="0.127" layer="51"/>
<wire x1="-2.2" y1="2.85" x2="-2.2" y2="1.45" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="1.45" x2="2.2" y2="1.45" width="0.2032" layer="21"/>
<wire x1="2.2" y1="1.45" x2="2.2" y2="2.85" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-2.15" x2="-4" y2="-2.75" width="0.2032" layer="51"/>
<wire x1="3.4" y1="-2.15" x2="4" y2="-2.75" width="0.2032" layer="51"/>
<wire x1="-3" y1="-2.15" x2="-3" y2="-2.55" width="0.127" layer="51"/>
<wire x1="-2.8" y1="-2.8" x2="2.75" y2="-2.8" width="0.127" layer="51"/>
<wire x1="3" y1="-2.6" x2="3" y2="-2.15" width="0.127" layer="51"/>
<wire x1="-3" y1="-2.55" x2="-2.8" y2="-2.8" width="0.127" layer="51" curve="84.547378"/>
<wire x1="2.75" y1="-2.8" x2="3" y2="-2.6" width="0.127" layer="51" curve="84.547378"/>
<smd name="VBUS" x="-1.3" y="2.65" dx="1.4" dy="0.35" layer="1" rot="R90"/>
<smd name="GND" x="1.3" y="2.65" dx="1.4" dy="0.35" layer="1" rot="R90"/>
<smd name="D-" x="-0.65" y="2.65" dx="1.4" dy="0.35" layer="1" rot="R90"/>
<smd name="D+" x="0" y="2.65" dx="1.4" dy="0.35" layer="1" rot="R90"/>
<smd name="ID" x="0.65" y="2.65" dx="1.4" dy="0.35" layer="1" rot="R90"/>
<smd name="MT1" x="-4" y="0" dx="1.8" dy="1.9" layer="1"/>
<smd name="MT2" x="4" y="0" dx="1.8" dy="1.9" layer="1"/>
<text x="-1.6" y="-0.35" size="0.762" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="0.762" layer="27">&gt;VALUE</text>
<smd name="P$1" x="-1.27" y="0" dx="1.9" dy="1.9" layer="1"/>
<smd name="P$2" x="1.27" y="0" dx="1.9" dy="1.9" layer="1"/>
</package>
<package name="MICRO-B-RA-SMT">
<description>Package for an SMT Micro-B connector.  Digikey part #H11613-ND
*** Unproven***</description>
<wire x1="-3.4" y1="-3" x2="3.4" y2="-3" width="0.127" layer="51"/>
<wire x1="-3.4" y1="-3" x2="-3.4" y2="3" width="0.127" layer="51"/>
<wire x1="3.4" y1="3" x2="-3.4" y2="3" width="0.127" layer="51"/>
<wire x1="3.4" y1="3" x2="3.4" y2="-3" width="0.127" layer="51"/>
<smd name="5" x="-1.3" y="-1.95" dx="1.1" dy="0.35" layer="1" rot="R90"/>
<smd name="1" x="1.3" y="-1.95" dx="1.1" dy="0.35" layer="1" rot="R90"/>
<smd name="4" x="-0.65" y="-1.75" dx="1.5" dy="0.35" layer="1" rot="R90"/>
<smd name="3" x="0" y="-1.75" dx="1.5" dy="0.35" layer="1" rot="R90"/>
<smd name="2" x="0.65" y="-1.75" dx="1.5" dy="0.35" layer="1" rot="R90"/>
<text x="-3.6" y="-1.8" size="0.762" layer="25" rot="R90">&gt;NAME</text>
<text x="4.3" y="-1.8" size="0.762" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="MICRO-B-RA-TH">
<description>&lt;h3&gt;Micro B Right Angle through-hole PCB plug connector&lt;/h3&gt;
&lt;b&gt;**Unproven**&lt;/b&gt;&lt;br&gt;
See digikey part #H11673TR-ND</description>
<wire x1="-1.525" y1="0" x2="-1.525" y2="1.55" width="0.127" layer="51"/>
<wire x1="1.525" y1="0" x2="1.525" y2="1.55" width="0.127" layer="51"/>
<wire x1="-1.525" y1="1.55" x2="1.525" y2="1.55" width="0.127" layer="51"/>
<wire x1="-1.525" y1="0" x2="-3.65" y2="0" width="0.127" layer="51"/>
<wire x1="1.525" y1="0" x2="3.65" y2="0" width="0.127" layer="51"/>
<wire x1="-3.65" y1="0" x2="-3.65" y2="-0.95" width="0.127" layer="51"/>
<wire x1="3.65" y1="0" x2="3.65" y2="-0.95" width="0.127" layer="51"/>
<wire x1="-2.5" y1="-3.35" x2="2.5" y2="-3.35" width="0.127" layer="51"/>
<wire x1="-3.65" y1="-0.95" x2="-2.5" y2="-3.35" width="0.127" layer="51"/>
<wire x1="3.65" y1="-0.95" x2="2.5" y2="-3.35" width="0.127" layer="51"/>
<pad name="3" x="0" y="-1.25" drill="0.508" diameter="0.9"/>
<pad name="4" x="0.65" y="0.6" drill="0.508" diameter="0.9"/>
<pad name="2" x="-0.65" y="0.6" drill="0.508" diameter="0.9"/>
<pad name="5" x="1.3" y="-0.95" drill="0.508" diameter="0.9"/>
<pad name="1" x="-1.3" y="-0.95" drill="0.508" diameter="0.9"/>
<text x="-1.651" y="0.635" size="0.381" layer="25" rot="R180">&gt;Name</text>
<text x="1.651" y="0.254" size="0.381" layer="27">&gt;Value</text>
</package>
<package name="MICRO-B-TH">
<description>&lt;h3&gt;Micro B USB Plug Assembly - Straight Through-hole&lt;/h3&gt;
&lt;b&gt;**UNPROVEN**&lt;/b&gt;&lt;Br&gt;
See Digikey part #H11497-ND</description>
<wire x1="-5.125" y1="-2.1" x2="5.125" y2="-2.1" width="0.127" layer="51"/>
<wire x1="-5.125" y1="2.1" x2="5.125" y2="2.1" width="0.127" layer="51"/>
<wire x1="-5.125" y1="-2.1" x2="-5.125" y2="2.1" width="0.127" layer="51"/>
<wire x1="5.125" y1="-2.1" x2="5.125" y2="2.1" width="0.127" layer="51"/>
<pad name="1" x="-1.3" y="-0.775" drill="0.6" diameter="1"/>
<pad name="3" x="0" y="-0.775" drill="0.6" diameter="1"/>
<pad name="5" x="1.3" y="-0.775" drill="0.6" diameter="1"/>
<pad name="4" x="0.65" y="0.775" drill="0.6" diameter="1"/>
<pad name="2" x="-0.65" y="0.775" drill="0.6" diameter="1"/>
<pad name="P$1" x="-4.1" y="0" drill="1.2" rot="R90"/>
<pad name="P$2" x="4.1" y="0" drill="1.2" rot="R90"/>
<text x="-5.08" y="2.286" size="0.381" layer="25">&gt;Name</text>
<text x="-5.08" y="-2.667" size="0.381" layer="27">&gt;Value</text>
</package>
<package name="MICRO-B-SMT">
<description>&lt;h3&gt;USB Micro-B Plug Connector&lt;/h3&gt;
Manufacturer part #: ZX80-B-5SA&lt;br&gt;
Manufacturer: Hirose&lt;br&gt;&lt;br&gt;
&lt;b&gt;***Unproven***&lt;/b&gt; (Passed 1:1 printout test though!)</description>
<wire x1="-9.7" y1="3.77" x2="-8.275" y2="3.77" width="0.127" layer="51"/>
<wire x1="-9.7" y1="0.57" x2="-8.275" y2="0.57" width="0.127" layer="51"/>
<wire x1="-9.7" y1="3.77" x2="-10.275" y2="4.3" width="0.127" layer="51"/>
<wire x1="-10.275" y1="4.3" x2="-10.275" y2="5.38" width="0.127" layer="51"/>
<wire x1="-9.7" y1="0.57" x2="-10.275" y2="0" width="0.127" layer="51"/>
<wire x1="-10.275" y1="0" x2="-10.275" y2="-0.9" width="0.127" layer="51"/>
<wire x1="-8.275" y1="3.77" x2="-8.275" y2="0.57" width="0.127" layer="51" curve="-180"/>
<wire x1="9.7" y1="0.57" x2="8.275" y2="0.57" width="0.127" layer="51"/>
<wire x1="8.275" y1="0.57" x2="8.275" y2="3.77" width="0.127" layer="51" curve="-180"/>
<wire x1="9.7" y1="3.77" x2="8.275" y2="3.77" width="0.127" layer="51"/>
<wire x1="9.7" y1="0.57" x2="10.275" y2="0" width="0.127" layer="51"/>
<wire x1="10.275" y1="0" x2="10.275" y2="-0.9" width="0.127" layer="51"/>
<wire x1="9.7" y1="3.77" x2="10.275" y2="4.4" width="0.127" layer="51"/>
<wire x1="10.275" y1="4.4" x2="10.275" y2="5.38" width="0.127" layer="51"/>
<wire x1="-10.275" y1="5.38" x2="-4.275" y2="5.38" width="0.127" layer="51"/>
<wire x1="10.275" y1="5.38" x2="4.275" y2="5.38" width="0.127" layer="51"/>
<wire x1="-10.275" y1="-0.9" x2="-4.275" y2="-0.9" width="0.127" layer="51"/>
<wire x1="10.275" y1="-0.9" x2="4.275" y2="-0.9" width="0.127" layer="51"/>
<wire x1="-4.275" y1="-0.9" x2="-4.275" y2="0" width="0.127" layer="51"/>
<wire x1="4.275" y1="-0.9" x2="4.275" y2="0" width="0.127" layer="51"/>
<wire x1="-4.275" y1="0" x2="4.275" y2="0" width="0.127" layer="51"/>
<wire x1="-4.275" y1="5.38" x2="-4.275" y2="4.48" width="0.127" layer="51"/>
<wire x1="4.275" y1="5.38" x2="4.275" y2="4.48" width="0.127" layer="51"/>
<wire x1="-4.275" y1="4.48" x2="4.275" y2="4.48" width="0.127" layer="51"/>
<pad name="P$6" x="-3.12053125" y="3.18301875" drill="1.016" diameter="2.2" rot="R90"/>
<pad name="P$7" x="-3.097921875" y="-0.026921875" drill="1.016" diameter="2.2" rot="R90"/>
<pad name="P$8" x="3.1218" y="3.160159375" drill="1.016" diameter="2.2" rot="R90"/>
<pad name="P$9" x="3.10783125" y="-0.02565625" drill="1.016" diameter="2.2" rot="R90"/>
<smd name="3" x="0" y="0" dx="2.2" dy="0.4" layer="1" rot="R90"/>
<smd name="2" x="-0.65" y="0" dx="2.2" dy="0.4" layer="1" rot="R90"/>
<smd name="1" x="-1.3" y="0" dx="2.2" dy="0.4" layer="1" rot="R90"/>
<smd name="5" x="1.3" y="0" dx="2.2" dy="0.4" layer="1" rot="R90"/>
<smd name="4" x="0.65" y="0" dx="2.2" dy="0.4" layer="1" rot="R90"/>
<text x="-10.29" y="5.58" size="0.4064" layer="25">&gt;Name</text>
<text x="10.39" y="5.988" size="0.4064" layer="27" rot="R180">&gt;Value</text>
<hole x="-8.275" y="2.17" drill="3.3"/>
<hole x="8.275" y="2.17" drill="3.3"/>
</package>
<package name="USD-SOCKET-PP">
<description>OLD Production Socket. DO NOT USE for production boards.</description>
<wire x1="-6.725" y1="5.5" x2="-6.725" y2="17" width="0.2032" layer="21"/>
<wire x1="4" y1="17" x2="7.825" y2="17" width="0.2032" layer="21"/>
<wire x1="7.825" y1="17" x2="7.825" y2="1.7" width="0.2032" layer="21"/>
<wire x1="6" y1="0" x2="4" y2="0" width="0.2032" layer="21"/>
<wire x1="4" y1="0" x2="4" y2="1.65" width="0.2032" layer="21"/>
<wire x1="-4" y1="1.65" x2="-4" y2="1" width="0.2032" layer="21"/>
<wire x1="-4" y1="1" x2="-5" y2="1" width="0.2032" layer="21"/>
<wire x1="-4" y1="1.65" x2="4" y2="1.65" width="0.2032" layer="21" curve="-69.416099"/>
<wire x1="4" y1="-0.7" x2="-4" y2="-0.7" width="0.127" layer="51"/>
<wire x1="4" y1="-1.6" x2="-4" y2="-1.6" width="0.127" layer="51"/>
<wire x1="4" y1="-5.4" x2="-4" y2="-5.4" width="0.127" layer="51"/>
<wire x1="-6.725" y1="3.6" x2="-6.725" y2="2.6" width="0.2032" layer="21"/>
<smd name="GND1" x="-6.275" y="1.475" dx="1.5" dy="1.35" layer="1"/>
<smd name="GND2" x="7.375" y="0.475" dx="1.5" dy="1.35" layer="1"/>
<smd name="CD2" x="-6.425" y="4.5" dx="1.4" dy="1" layer="1"/>
<smd name="CD1" x="-5.85" y="16.75" dx="1" dy="1.3" layer="1"/>
<smd name="8" x="-4.5" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="7" x="-3.4" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="6" x="-2.3" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="5" x="-1.2" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="4" x="-0.1" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="3" x="1" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="2" x="2.1" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<smd name="1" x="3.2" y="16.8" dx="0.75" dy="1.5" layer="1"/>
<text x="-5.08" y="7.62" size="0.4064" layer="25">&gt;Name</text>
<text x="-5.08" y="6.35" size="0.4064" layer="27">&gt;Value</text>
</package>
<package name="MICRO-SD-SOCKET-PP">
<wire x1="-14" y1="0" x2="-14" y2="13.2" width="0.2032" layer="21"/>
<wire x1="0" y1="12.1" x2="0" y2="0" width="0.2032" layer="21"/>
<wire x1="-11.7" y1="15.3" x2="-12.5" y2="15.3" width="0.2032" layer="21"/>
<wire x1="-11" y1="16" x2="0" y2="16" width="0.2032" layer="51"/>
<wire x1="-10" y1="13.6" x2="-1.6" y2="13.6" width="0.2032" layer="21"/>
<wire x1="-14" y1="0" x2="-9.1" y2="0" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="0" x2="-6.4" y2="0" width="0.2032" layer="21"/>
<wire x1="0" y1="0" x2="-0.7" y2="0" width="0.2032" layer="21"/>
<wire x1="0" y1="17.6" x2="-11" y2="17.6" width="0.2032" layer="51"/>
<wire x1="0" y1="20.7" x2="-11" y2="20.7" width="0.2032" layer="51"/>
<wire x1="-11.7" y1="15.3" x2="-11" y2="14.6" width="0.2032" layer="21" curve="-98.797411"/>
<wire x1="-11" y1="14.6" x2="-10" y2="13.6" width="0.2032" layer="21" curve="87.205638"/>
<smd name="CD2" x="-7.75" y="0.4" dx="1.8" dy="1.4" layer="1"/>
<smd name="CD1" x="-2.05" y="0.4" dx="1.8" dy="1.4" layer="1"/>
<smd name="GND3" x="-0.45" y="13.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="GND1" x="-13.6" y="14.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="RSV1" x="-8.94" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="CS" x="-7.84" y="10.3" dx="0.8" dy="1.5" layer="1"/>
<smd name="DI" x="-6.74" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="VCC" x="-5.64" y="10.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="SCLK" x="-4.54" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="GND" x="-3.44" y="10.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="DO" x="-2.34" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="RSV2" x="-1.24" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<text x="-8.89" y="6.35" size="0.8128" layer="25">&gt;Name</text>
<text x="-8.89" y="5.08" size="0.8128" layer="27">&gt;Value</text>
<text x="0.635" y="15.875" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Pressed</text>
<text x="0.635" y="17.78" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Locked</text>
<text x="0.635" y="20.955" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Unlocked</text>
</package>
<package name="FFC26">
<description>&lt;b&gt;26-pin FFC connector&lt;/b&gt;
&lt;br&gt;See 4UCONN part #08630</description>
<wire x1="-9.75" y1="5.15" x2="9.75" y2="5.15" width="0.127" layer="21"/>
<wire x1="-9.75" y1="3.7" x2="-9.75" y2="5.15" width="0.127" layer="21"/>
<wire x1="9.75" y1="3.7" x2="9.75" y2="5.15" width="0.127" layer="21"/>
<wire x1="-9.75" y1="5.15" x2="9.75" y2="5.15" width="0.127" layer="51"/>
<wire x1="-9.75" y1="5.15" x2="-9.75" y2="3.65" width="0.127" layer="51"/>
<wire x1="-9.75" y1="3.65" x2="-9.05" y2="3.65" width="0.127" layer="51"/>
<wire x1="-9.05" y1="3.65" x2="-9.05" y2="0.65" width="0.127" layer="51"/>
<wire x1="9.05" y1="0.65" x2="9.05" y2="2.87" width="0.127" layer="51"/>
<wire x1="9.05" y1="2.87" x2="9.05" y2="3.7" width="0.127" layer="51"/>
<wire x1="9.05" y1="3.7" x2="9.75" y2="3.7" width="0.127" layer="51"/>
<wire x1="9.75" y1="3.7" x2="9.75" y2="5.15" width="0.127" layer="51"/>
<wire x1="-9.05" y1="0.65" x2="9.05" y2="0.65" width="0.127" layer="51"/>
<smd name="1" x="6.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="2" x="5.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="3" x="5.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="4" x="4.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="5" x="4.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="6" x="3.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="7" x="3.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="8" x="2.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="9" x="2.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="10" x="1.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="11" x="1.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="12" x="0.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="13" x="0.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="14" x="-0.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="15" x="-0.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="16" x="-1.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="17" x="-1.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="18" x="-2.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="19" x="-2.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="20" x="-3.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="21" x="-3.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="22" x="-4.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="23" x="-4.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="24" x="-5.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="25" x="-5.75" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="26" x="-6.25" y="0" dx="0.28" dy="1.3" layer="1" rot="R180"/>
<smd name="P$1" x="8.025" y="1.55" dx="2.6" dy="1.85" layer="1" rot="R90"/>
<smd name="P$3" x="-8.025" y="1.55" dx="2.6" dy="1.85" layer="1" rot="R90"/>
<rectangle x1="0.15" y1="-0.45" x2="0.35" y2="0.65" layer="51"/>
<rectangle x1="-0.85" y1="-0.45" x2="-0.65" y2="0.65" layer="51"/>
<rectangle x1="-1.85" y1="-0.45" x2="-1.65" y2="0.65" layer="51"/>
<rectangle x1="-2.85" y1="-0.45" x2="-2.65" y2="0.65" layer="51"/>
<rectangle x1="-3.85" y1="-0.45" x2="-3.65" y2="0.65" layer="51"/>
<rectangle x1="-4.85" y1="-0.45" x2="-4.65" y2="0.65" layer="51"/>
<rectangle x1="-5.85" y1="-0.45" x2="-5.65" y2="0.65" layer="51"/>
<rectangle x1="1.15" y1="-0.45" x2="1.35" y2="0.65" layer="51"/>
<rectangle x1="2.15" y1="-0.45" x2="2.35" y2="0.65" layer="51"/>
<rectangle x1="3.15" y1="-0.45" x2="3.35" y2="0.65" layer="51"/>
<rectangle x1="4.15" y1="-0.45" x2="4.35" y2="0.65" layer="51"/>
<rectangle x1="5.15" y1="-0.45" x2="5.35" y2="0.65" layer="51"/>
<rectangle x1="6.15" y1="-0.45" x2="6.35" y2="0.65" layer="51"/>
<rectangle x1="-6.35" y1="-0.45" x2="-6.15" y2="0.65" layer="51"/>
<rectangle x1="-5.35" y1="-0.45" x2="-5.15" y2="0.65" layer="51"/>
<rectangle x1="-4.35" y1="-0.45" x2="-4.15" y2="0.65" layer="51"/>
<rectangle x1="-3.35" y1="-0.45" x2="-3.15" y2="0.65" layer="51"/>
<rectangle x1="-2.35" y1="-0.45" x2="-2.15" y2="0.65" layer="51"/>
<rectangle x1="-1.35" y1="-0.45" x2="-1.15" y2="0.65" layer="51"/>
<rectangle x1="-0.35" y1="-0.45" x2="-0.15" y2="0.65" layer="51"/>
<rectangle x1="0.65" y1="-0.45" x2="0.85" y2="0.65" layer="51"/>
<rectangle x1="1.65" y1="-0.45" x2="1.85" y2="0.65" layer="51"/>
<rectangle x1="2.65" y1="-0.45" x2="2.85" y2="0.65" layer="51"/>
<rectangle x1="3.65" y1="-0.45" x2="3.85" y2="0.65" layer="51"/>
<rectangle x1="4.65" y1="-0.45" x2="4.85" y2="0.65" layer="51"/>
<rectangle x1="5.65" y1="-0.45" x2="5.85" y2="0.65" layer="51"/>
<rectangle x1="-8.88" y1="0.65" x2="-7.18" y2="2.55" layer="51"/>
<rectangle x1="7.16" y1="0.65" x2="8.86" y2="2.55" layer="51"/>
</package>
<package name="XLR3_NC3FAH2">
<wire x1="-8.89" y1="-12.7" x2="10.287" y2="-12.7" width="0.2032" layer="21"/>
<wire x1="10.287" y1="-12.7" x2="10.287" y2="12.065" width="0.2032" layer="21"/>
<wire x1="10.287" y1="12.065" x2="-8.89" y2="12.065" width="0.2032" layer="21"/>
<wire x1="-8.89" y1="12.065" x2="-8.89" y2="-12.7" width="0.2032" layer="21"/>
<wire x1="10.414" y1="-11.176" x2="13.081" y2="-11.176" width="0.2032" layer="51"/>
<wire x1="13.081" y1="-11.176" x2="13.081" y2="-1.016" width="0.2032" layer="51"/>
<wire x1="13.081" y1="-1.016" x2="13.081" y2="10.414" width="0.2032" layer="51"/>
<wire x1="13.081" y1="10.414" x2="10.414" y2="10.414" width="0.2032" layer="51"/>
<pad name="2" x="-2.794" y="-4.191" drill="1.6002"/>
<pad name="3" x="-6.604" y="-0.381" drill="1.1938"/>
<pad name="1" x="-2.159" y="3.429" drill="1.6002"/>
<pad name="G" x="3.556" y="7.874" drill="1.1938"/>
<hole x="1.651" y="-4.191" drill="1.6002"/>
<hole x="6.731" y="3.429" drill="1.6002"/>
</package>
<package name="DIL28-3-ZIF_SOCKET">
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-1.27" x2="-17.78" y2="1.27" width="0.2032" layer="21" curve="180"/>
<wire x1="17.78" y1="-3.048" x2="17.78" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="3.048" x2="-17.78" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="3.048" x2="-17.526" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-3.048" x2="-17.526" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-3.048" x2="17.526" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="17.78" y1="3.048" x2="17.526" y2="3.048" width="0.2032" layer="21"/>
<wire x1="-26.111" y1="-8" x2="25.889" y2="-8" width="0.127" layer="51"/>
<wire x1="25.889" y1="-8" x2="25.889" y2="8" width="0.127" layer="51"/>
<wire x1="25.889" y1="8" x2="-26.111" y2="8" width="0.127" layer="51"/>
<wire x1="-26.111" y1="8" x2="-26.111" y2="-8" width="0.127" layer="51"/>
<wire x1="-21.59" y1="-5.08" x2="-36.83" y2="-5.08" width="0.254" layer="51" style="shortdash"/>
<wire x1="-36.83" y1="-5.08" x2="-36.83" y2="-7.62" width="0.254" layer="51" style="shortdash"/>
<wire x1="-36.83" y1="-7.62" x2="-21.59" y2="-7.62" width="0.254" layer="51" style="shortdash"/>
<wire x1="-21.59" y1="-7.62" x2="-21.59" y2="-5.08" width="0.254" layer="51" style="shortdash"/>
<pad name="1" x="-16.51" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-15.24" y="0" size="0.6096" layer="25" ratio="10">&gt;NAME</text>
<text x="-15.24" y="-1.27" size="0.6096" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL40-6-ZIF_SOCKET">
<wire x1="-25.4" y1="-1.27" x2="-25.4" y2="-6.858" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="-1.27" x2="-25.4" y2="1.27" width="0.2032" layer="21" curve="180"/>
<wire x1="25.4" y1="-6.858" x2="25.4" y2="6.858" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="6.858" x2="-25.4" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-34.762" y1="-11.381" x2="30.968" y2="-11.381" width="0.254" layer="51"/>
<wire x1="30.968" y1="-11.381" x2="30.968" y2="11.619" width="0.254" layer="51"/>
<wire x1="30.968" y1="11.619" x2="-34.762" y2="11.619" width="0.254" layer="51"/>
<wire x1="-34.762" y1="11.619" x2="-34.762" y2="-11.381" width="0.254" layer="51"/>
<wire x1="-29.21" y1="-8.89" x2="-48.26" y2="-8.89" width="0.254" layer="51" style="shortdash"/>
<wire x1="-48.26" y1="-8.89" x2="-48.26" y2="-11.43" width="0.254" layer="51" style="shortdash"/>
<wire x1="-48.26" y1="-11.43" x2="-29.21" y2="-11.43" width="0.254" layer="51" style="shortdash"/>
<wire x1="-29.21" y1="-11.43" x2="-29.21" y2="-8.89" width="0.254" layer="51" style="shortdash"/>
<pad name="1" x="-24.13" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="-21.59" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-19.05" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-16.51" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-13.97" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-11.43" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-8.89" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="-6.35" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="-3.81" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="-1.27" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="1.27" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="3.81" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="6.35" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="8.89" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="11.43" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="13.97" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="16.51" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="19.05" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="21.59" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="24.13" y="-7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="24.13" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="21.59" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="19.05" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="16.51" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="13.97" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="26" x="11.43" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="27" x="8.89" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="28" x="6.35" y="7.366" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="30" x="1.27" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="31" x="-1.27" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="32" x="-3.81" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="33" x="-6.35" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="34" x="-8.89" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="35" x="-11.43" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="36" x="-13.97" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="37" x="-16.51" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="38" x="-19.05" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="39" x="-21.59" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="40" x="-24.13" y="7.366" drill="1.1" diameter="1.8796"/>
<pad name="29" x="3.81" y="7.366" drill="1.1" diameter="1.8796"/>
<text x="-22.86" y="0" size="0.6096" layer="25" ratio="10">&gt;NAME</text>
<text x="-22.86" y="-1.27" size="0.6096" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZUNE_CONNECTOR_MALE">
<wire x1="-4.8" y1="1.4" x2="16.6" y2="1.4" width="0.127" layer="51"/>
<wire x1="16.6" y1="1.4" x2="16.6" y2="9.1" width="0.127" layer="51"/>
<wire x1="16.6" y1="9.1" x2="-4.8" y2="9.1" width="0.127" layer="51"/>
<wire x1="-4.8" y1="9.1" x2="-4.8" y2="1.5" width="0.127" layer="51"/>
<smd name="P$1" x="0" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$2" x="0.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$3" x="1" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$4" x="1.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$5" x="2" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$6" x="2.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$7" x="3" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$8" x="3.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$9" x="4" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$10" x="4.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$11" x="5" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$12" x="5.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$13" x="6" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$14" x="6.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$15" x="7" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$16" x="7.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$17" x="8" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$18" x="8.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$19" x="9" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$20" x="9.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$21" x="10" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$22" x="10.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<smd name="P$23" x="11" y="0" dx="0.6" dy="2.5" layer="1" rot="R180"/>
<smd name="P$24" x="11.5" y="0" dx="0.6" dy="2.5" layer="16" rot="R180"/>
<text x="-0.9" y="1.8" size="0.3048" layer="51">Connector should be used only with 1.2mm PCB thickness.</text>
</package>
<package name="50-PIN-CENTRONICS-F">
<wire x1="-2.828" y1="-16.51" x2="-2.828" y2="66.19" width="0.127" layer="51"/>
<wire x1="-2.828" y1="-16.51" x2="13.572" y2="-16.51" width="0.127" layer="51"/>
<wire x1="-2.828" y1="66.19" x2="13.572" y2="66.19" width="0.127" layer="51"/>
<wire x1="13.572" y1="-16.51" x2="13.572" y2="66.19" width="0.127" layer="51"/>
<wire x1="13.63" y1="-7.62" x2="23.63" y2="-7.62" width="0.127" layer="51"/>
<wire x1="13.63" y1="-7.62" x2="13.63" y2="58.08" width="0.127" layer="51"/>
<wire x1="23.63" y1="-7.62" x2="23.63" y2="58.08" width="0.127" layer="51"/>
<wire x1="13.63" y1="58.08" x2="23.63" y2="58.08" width="0.127" layer="51"/>
<pad name="P$1" x="0" y="0" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$2" x="0" y="2.159" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$3" x="0" y="4.318" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$4" x="0" y="6.477" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$5" x="0" y="8.636" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$6" x="0" y="10.795" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$7" x="0" y="12.954" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$8" x="0" y="15.113" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$9" x="0" y="17.272" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$10" x="0" y="19.431" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$11" x="0" y="21.59" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$12" x="0" y="23.749" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$13" x="0" y="25.908" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$14" x="0" y="28.067" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$15" x="0" y="30.226" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$16" x="0" y="32.385" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$17" x="0" y="34.544" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$18" x="0" y="36.703" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$19" x="0" y="38.862" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$20" x="0" y="41.021" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$21" x="0" y="43.18" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$22" x="0" y="45.339" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$23" x="0" y="47.498" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$24" x="0" y="49.657" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$25" x="0" y="51.816" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$26" x="4.318" y="0" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$27" x="4.318" y="2.159" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$28" x="4.318" y="4.318" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$29" x="4.318" y="6.477" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$30" x="4.318" y="8.636" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$31" x="4.318" y="10.795" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$32" x="4.318" y="12.954" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$33" x="4.318" y="15.113" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$34" x="4.318" y="17.272" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$35" x="4.318" y="19.431" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$36" x="4.318" y="21.59" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$37" x="4.318" y="23.749" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$38" x="4.318" y="25.908" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$39" x="4.318" y="28.067" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$40" x="4.318" y="30.226" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$41" x="4.318" y="32.385" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$42" x="4.318" y="34.544" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$43" x="4.318" y="36.703" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$44" x="4.318" y="38.862" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$45" x="4.318" y="41.021" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$46" x="4.318" y="43.18" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$47" x="4.318" y="45.339" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$48" x="4.318" y="47.498" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$49" x="4.318" y="49.657" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$50" x="4.318" y="51.816" drill="0.9" diameter="1.6764" shape="square"/>
<text x="-1.905" y="-0.635" size="1.016" layer="21" ratio="15">1</text>
<text x="-3.302" y="48.768" size="1.016" layer="21" ratio="15">25</text>
<text x="7.366" y="-0.508" size="1.016" layer="21" ratio="15">26</text>
<text x="7.62" y="48.768" size="1.016" layer="21" font="vector" ratio="15">50</text>
</package>
<package name="50-PIN-CENTRONICS-M">
<wire x1="-2.88" y1="-7.62" x2="-13.2" y2="-7.62" width="0.127" layer="51"/>
<wire x1="-2.88" y1="-7.62" x2="-2.88" y2="58.08" width="0.127" layer="51"/>
<wire x1="-13.2" y1="-7.62" x2="-13.2" y2="58.08" width="0.127" layer="51"/>
<wire x1="-2.88" y1="58.08" x2="-13.2" y2="58.08" width="0.127" layer="51"/>
<pad name="P$1" x="4.318" y="0" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$2" x="4.318" y="2.159" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$3" x="4.318" y="4.318" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$4" x="4.318" y="6.477" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$5" x="4.318" y="8.636" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$6" x="4.318" y="10.795" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$7" x="4.318" y="12.954" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$8" x="4.318" y="15.113" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$9" x="4.318" y="17.272" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$10" x="4.318" y="19.431" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$11" x="4.318" y="21.59" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$12" x="4.318" y="23.749" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$13" x="4.318" y="25.908" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$14" x="4.318" y="28.067" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$15" x="4.318" y="30.226" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$16" x="4.318" y="32.385" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$17" x="4.318" y="34.544" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$18" x="4.318" y="36.703" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$19" x="4.318" y="38.862" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$20" x="4.318" y="41.021" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$21" x="4.318" y="43.18" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$22" x="4.318" y="45.339" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$23" x="4.318" y="47.498" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$24" x="4.318" y="49.657" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$25" x="4.318" y="51.816" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$26" x="0" y="0" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$27" x="0" y="2.159" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$28" x="0" y="4.318" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$29" x="0" y="6.477" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$30" x="0" y="8.636" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$31" x="0" y="10.795" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$32" x="0" y="12.954" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$33" x="0" y="15.113" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$34" x="0" y="17.272" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$35" x="0" y="19.431" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$36" x="0" y="21.59" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$37" x="0" y="23.749" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$38" x="0" y="25.908" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$39" x="0" y="28.067" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$40" x="0" y="30.226" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$41" x="0" y="32.385" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$42" x="0" y="34.544" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$43" x="0" y="36.703" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$44" x="0" y="38.862" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$45" x="0" y="41.021" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$46" x="0" y="43.18" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$47" x="0" y="45.339" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$48" x="0" y="47.498" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$49" x="0" y="49.657" drill="0.9" diameter="1.6764" shape="square"/>
<pad name="P$50" x="0" y="51.816" drill="0.9" diameter="1.6764" shape="square"/>
<text x="7.439" y="-0.381" size="1.016" layer="21" ratio="15">1</text>
<text x="7.312" y="48.768" size="1.016" layer="21" ratio="15">25</text>
<text x="-3.248" y="-0.508" size="1.016" layer="21" ratio="15">26</text>
<text x="-2.994" y="49.022" size="1.016" layer="21" font="vector" ratio="15">50</text>
</package>
<package name="RCA">
<wire x1="-4" y1="5" x2="-4" y2="-5" width="0.2032" layer="51"/>
<wire x1="-4" y1="-5" x2="5.8" y2="-5" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-5" x2="5.8" y2="5" width="0.2032" layer="51"/>
<wire x1="5.8" y1="5" x2="-4" y2="5" width="0.2032" layer="51"/>
<wire x1="-4" y1="4" x2="-13.4" y2="4" width="0.2032" layer="51"/>
<wire x1="-13.4" y1="4" x2="-13.4" y2="-4" width="0.2032" layer="51"/>
<wire x1="-13.4" y1="-4" x2="-4" y2="-4" width="0.2032" layer="51"/>
<wire x1="-2" y1="5" x2="2" y2="5" width="0.2032" layer="21"/>
<wire x1="5.8" y1="5" x2="5.8" y2="-5" width="0.2032" layer="21"/>
<wire x1="-2" y1="-5" x2="2" y2="-5" width="0.2032" layer="21"/>
<wire x1="-4" y1="3" x2="-4" y2="-3" width="0.2032" layer="21"/>
<pad name="SHELL" x="0" y="0" drill="2.3"/>
<pad name="PIN" x="3.7" y="3.7" drill="2.3"/>
<pad name="SWITCH" x="3.7" y="-3.7" drill="2.3"/>
<hole x="-3.1" y="4.25" drill="2.1"/>
<hole x="-3.1" y="-4.25" drill="2.1"/>
</package>
<package name="RCA_LOCK">
<wire x1="4.4704" y1="-3.5052" x2="2.8702" y2="-3.5052" width="0.0254" layer="51"/>
<wire x1="4.4704" y1="3.4544" x2="2.8702" y2="3.4544" width="0.0254" layer="51"/>
<pad name="SHELL" x="0.2032" y="0" drill="2.3"/>
<pad name="PIN" x="4.0302" y="3.8016" drill="2.3"/>
<pad name="SWITCH" x="4.0302" y="-3.827" drill="2.3"/>
<rectangle x1="-3.8608" y1="3.4798" x2="-2.3622" y2="4.9784" layer="51"/>
<rectangle x1="-3.8608" y1="-5.0292" x2="-2.3622" y2="-3.5306" layer="51"/>
<rectangle x1="-1.2446" y1="-1.1176" x2="0.254" y2="1.1176" layer="51"/>
<rectangle x1="2.8702" y1="-3.8862" x2="5.1054" y2="-3.5306" layer="51"/>
<rectangle x1="2.8702" y1="3.4798" x2="5.1054" y2="3.8354" layer="51"/>
<hole x="-3.1" y="4.25" drill="2.1336"/>
<hole x="-3.1" y="-4.25" drill="2.1336"/>
</package>
<package name="USB-AB-MICRO-SMD">
<description>micro USB AB connector for OTG support. 5-pins: USBVCC, GND, D+, D-, USBID. Can act as host or device</description>
<smd name="D+" x="2.85" y="0" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="D-" x="2.85" y="0.65" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="VBUS" x="2.85" y="1.3" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="ID" x="2.85" y="-0.65" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="GND" x="2.85" y="-1.3" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="SHIELD2" x="0" y="1.25" dx="2" dy="1.9" layer="1" rot="R90"/>
<smd name="SHIELD3" x="0" y="-1.25" dx="2" dy="1.9" layer="1" rot="R90"/>
<wire x1="-2.75" y1="4" x2="-2.75" y2="-4" width="0.2032" layer="51"/>
<wire x1="-2.05" y1="5" x2="-2.05" y2="-5" width="0.2032" layer="51"/>
<text x="-5.2" y="5.5" size="0.3048" layer="51">PCB Front</text>
<wire x1="-3" y1="5.6" x2="-2.3" y2="5.3" width="0.08" layer="51"/>
<wire x1="-2.3" y1="5.3" x2="-2.4" y2="5.5" width="0.08" layer="51"/>
<wire x1="-2.3" y1="5.3" x2="-2.5" y2="5.2" width="0.08" layer="51"/>
<smd name="SHIELD1" x="0" y="4" dx="2.2" dy="1.9" layer="1" rot="R90"/>
<smd name="SHIELD4" x="0" y="-4" dx="2.2" dy="1.9" layer="1" rot="R90"/>
<wire x1="2.9" y1="4" x2="2.9" y2="-4" width="0.2032" layer="51"/>
<wire x1="-2.7" y1="4" x2="-0.6" y2="4" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="4" x2="0.6" y2="4" width="0.2032" layer="51"/>
<wire x1="0.6" y1="4" x2="2.9" y2="4" width="0.2032" layer="51"/>
<wire x1="-2.7" y1="-4" x2="2.9" y2="-4" width="0.2032" layer="51"/>
<wire x1="1.2" y1="4.1" x2="3" y2="4.1" width="0.254" layer="21"/>
<wire x1="3" y1="4.1" x2="3" y2="1.8" width="0.254" layer="21"/>
<wire x1="3" y1="-1.8" x2="3" y2="-4.1" width="0.254" layer="21"/>
<wire x1="3" y1="-4.1" x2="1.2" y2="-4.1" width="0.254" layer="21"/>
<wire x1="-1.2" y1="-4.1" x2="-1.9" y2="-4.1" width="0.254" layer="21"/>
<wire x1="-1.2" y1="4.1" x2="-1.9" y2="4.1" width="0.254" layer="21"/>
<wire x1="-0.6" y1="4" x2="-0.6" y2="4.6" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="4.6" x2="0.6" y2="4.6" width="0.2032" layer="51"/>
<wire x1="0.6" y1="4.6" x2="0.6" y2="4" width="0.2032" layer="51"/>
<wire x1="0.6" y1="-4" x2="0.6" y2="-4.6" width="0.2032" layer="51"/>
<wire x1="0.6" y1="-4.6" x2="-0.6" y2="-4.6" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="-4.6" x2="-0.6" y2="-4" width="0.2032" layer="51"/>
<text x="-1.27" y="5.969" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="5.461" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X16_NO_SILK">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="30.48" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="33.02" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="35.56" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="38.1" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="32.766" y1="-0.254" x2="33.274" y2="0.254" layer="51"/>
<rectangle x1="30.226" y1="-0.254" x2="30.734" y2="0.254" layer="51"/>
<rectangle x1="27.686" y1="-0.254" x2="28.194" y2="0.254" layer="51"/>
<rectangle x1="25.146" y1="-0.254" x2="25.654" y2="0.254" layer="51"/>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
<rectangle x1="35.306" y1="-0.254" x2="35.814" y2="0.254" layer="51"/>
<rectangle x1="37.846" y1="-0.254" x2="38.354" y2="0.254" layer="51"/>
</package>
<package name="1X19_NO_SILK">
<pad name="17" x="40.64" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="43.18" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="45.72" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="40.386" y1="-0.254" x2="40.894" y2="0.254" layer="51"/>
<rectangle x1="42.926" y1="-0.254" x2="43.434" y2="0.254" layer="51"/>
<rectangle x1="45.466" y1="-0.254" x2="45.974" y2="0.254" layer="51"/>
</package>
<package name="1X11_NO_SILK">
</package>
<package name="SDCARD_4UCONN">
<description>4UConn part#19646</description>
<smd name="1" x="-1" y="6.77" dx="1.8" dy="0.9" layer="1"/>
<smd name="2" x="-1" y="4.27" dx="1.8" dy="0.9" layer="1"/>
<smd name="3" x="-1" y="2.52" dx="1.8" dy="0.9" layer="1"/>
<smd name="CD" x="-1" y="1.02" dx="1.8" dy="0.9" layer="1"/>
<smd name="4" x="-1" y="-0.73" dx="1.8" dy="0.9" layer="1"/>
<smd name="5" x="-1" y="-3.23" dx="1.8" dy="0.9" layer="1"/>
<smd name="6" x="-1" y="-5.73" dx="1.8" dy="0.9" layer="1"/>
<smd name="7" x="-1" y="-8.15" dx="1.8" dy="0.9" layer="1"/>
<smd name="8" x="-1" y="-9.85" dx="1.8" dy="0.9" layer="1"/>
<smd name="SH@1" x="20" y="14.75" dx="2" dy="1.4" layer="1"/>
<smd name="SH@2" x="21.15" y="-14.75" dx="2" dy="1.4" layer="1"/>
<smd name="WP" x="-1" y="-13" dx="1.8" dy="1.1" layer="1"/>
<smd name="9" x="-1" y="9.27" dx="1.8" dy="0.9" layer="1"/>
<wire x1="0" y1="14.25" x2="28.8" y2="14.25" width="0.127" layer="51"/>
<wire x1="28.8" y1="14.25" x2="28.8" y2="10" width="0.127" layer="51"/>
<wire x1="28.8" y1="10" x2="28.8" y2="-8" width="0.127" layer="51"/>
<wire x1="28.8" y1="-8" x2="28.8" y2="-10.5" width="0.127" layer="51"/>
<wire x1="28.8" y1="-10.5" x2="28.8" y2="-14.25" width="0.127" layer="51"/>
<wire x1="28.8" y1="-14.25" x2="0" y2="-14.25" width="0.127" layer="51"/>
<wire x1="0" y1="-14.25" x2="0" y2="14.25" width="0.127" layer="51"/>
<hole x="23.3" y="11.94" drill="1.55"/>
<hole x="23.3" y="-12.32" drill="1.55"/>
<text x="0.54" y="12.94" size="0.4064" layer="25">&gt;NAME</text>
<text x="0.54" y="11.67" size="0.4064" layer="27">&gt;VALUE</text>
<wire x1="-0.095" y1="10.019" x2="-0.095" y2="14.418" width="0.254" layer="21"/>
<wire x1="-0.095" y1="14.418" x2="5.239" y2="14.418" width="0.254" layer="21"/>
<wire x1="21.849" y1="14.318" x2="28.888" y2="14.318" width="0.254" layer="21"/>
<wire x1="28.888" y1="14.318" x2="28.9" y2="12.9" width="0.254" layer="21"/>
<wire x1="23.011" y1="-14.327" x2="28.888" y2="-14.327" width="0.254" layer="21"/>
<wire x1="28.888" y1="-14.327" x2="28.888" y2="-13.349" width="0.254" layer="21"/>
<wire x1="-0.095" y1="-14.238" x2="-0.095" y2="-14.327" width="0.254" layer="21"/>
<wire x1="-0.095" y1="-14.327" x2="5.239" y2="-14.327" width="0.254" layer="21"/>
<wire x1="35.6" y1="12" x2="35.6" y2="-13" width="0.127" layer="51"/>
<text x="34.9" y="-9.3" size="1.27" layer="51" rot="R90">card lock position</text>
<wire x1="28.8" y1="10" x2="28" y2="10" width="0.127" layer="51"/>
<wire x1="28" y1="10" x2="18" y2="0" width="0.127" layer="51" curve="90"/>
<wire x1="28" y1="-10.5" x2="18" y2="-0.5" width="0.127" layer="51" curve="-90"/>
<wire x1="18" y1="0" x2="18" y2="-0.5" width="0.127" layer="51"/>
<wire x1="28" y1="-10.5" x2="28.8" y2="-10.5" width="0.127" layer="51"/>
</package>
<package name="COMPUTER-PERIPHERAL-POWER-RA">
<hole x="-10.16" y="0" drill="2.54"/>
<hole x="10.16" y="0" drill="2.54"/>
<hole x="-5.08" y="7.62" drill="3.9878"/>
<hole x="5.08" y="7.62" drill="3.9878"/>
<wire x1="-11.6332" y1="-3.048" x2="-11.6332" y2="10.16" width="0.2032" layer="21"/>
<wire x1="-11.6332" y1="10.16" x2="11.6332" y2="10.16" width="0.2032" layer="21"/>
<wire x1="11.6332" y1="10.16" x2="11.6332" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="11.6332" y1="-3.048" x2="-11.6332" y2="-3.048" width="0.2032" layer="51"/>
<wire x1="-11.6332" y1="-3.048" x2="-8.89" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="-3.81" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="1.27" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-3.048" x2="6.35" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="11.6332" y1="-3.048" x2="8.89" y2="-3.048" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="16.51" x2="-5.08" y2="11.43" width="0.508" layer="51"/>
<wire x1="-5.08" y1="11.43" x2="-3.81" y2="12.7" width="0.508" layer="51"/>
<wire x1="-5.08" y1="11.43" x2="-6.35" y2="12.7" width="0.508" layer="51"/>
<wire x1="5.08" y1="16.51" x2="5.08" y2="11.43" width="0.508" layer="51"/>
<wire x1="5.08" y1="11.43" x2="6.35" y2="12.7" width="0.508" layer="51"/>
<wire x1="5.08" y1="11.43" x2="3.81" y2="12.7" width="0.508" layer="51"/>
<text x="-3.048" y="13.335" size="1.27" layer="51" ratio="15">INSERT</text>
<pad name="5V" x="-7.62" y="-2.54" drill="1.524" diameter="3.048"/>
<pad name="GND" x="-2.54" y="-2.54" drill="1.524" diameter="3.048"/>
<pad name="NC" x="2.54" y="-2.54" drill="1.524" diameter="3.048"/>
<pad name="12V" x="7.62" y="-2.54" drill="1.524" diameter="3.048"/>
</package>
<package name="COMPUTER-PERIPHERAL-POWER">
<pad name="NC" x="-2.54" y="0" drill="1.778" diameter="3.302"/>
<pad name="12V" x="-7.62" y="0" drill="1.778" diameter="3.302"/>
<pad name="GND" x="2.54" y="0" drill="1.778" diameter="3.302"/>
<pad name="5V" x="7.62" y="0" drill="1.778" diameter="3.302"/>
<wire x1="-11.7475" y1="4.191" x2="11.7475" y2="4.191" width="0.2032" layer="21"/>
<wire x1="11.7475" y1="4.191" x2="11.7475" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="11.7475" y1="-2.159" x2="9.652" y2="-4.191" width="0.2032" layer="21"/>
<wire x1="9.652" y1="-4.191" x2="-9.652" y2="-4.191" width="0.2032" layer="21"/>
<wire x1="-9.652" y1="-4.191" x2="-11.7475" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-11.7475" y1="-2.159" x2="-11.7475" y2="4.191" width="0.2032" layer="21"/>
</package>
<package name="FTDI_DEVICE_SIDE">
<description>Package for devices meant to mate to an FTDI connector.</description>
<pad name="P$1" x="-6.35" y="0" drill="1.016" diameter="1.8796" shape="square"/>
<pad name="P$2" x="-3.81" y="0" drill="1.016" diameter="1.8796"/>
<pad name="P$3" x="-1.27" y="0" drill="1.016" diameter="1.8796"/>
<pad name="P$4" x="1.27" y="0" drill="1.016" diameter="1.8796"/>
<pad name="P$5" x="3.81" y="0" drill="1.016" diameter="1.8796"/>
<pad name="P$6" x="6.35" y="0" drill="1.016" diameter="1.8796"/>
<wire x1="-7.62" y1="1.27" x2="7.62" y2="1.27" width="0.127" layer="21"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.127" layer="21"/>
<wire x1="7.62" y1="-1.27" x2="-7.62" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-1.27" x2="-7.62" y2="1.27" width="0.127" layer="21"/>
<text x="-7.874" y="-0.889" size="1.27" layer="21" font="vector" ratio="15" rot="R90">GRN</text>
<text x="9.144" y="-0.889" size="1.27" layer="21" font="vector" ratio="15" rot="R90">BLK</text>
<text x="-4.826" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">TXO</text>
<text x="-2.286" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">RXI</text>
<text x="0.254" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">VCC</text>
<text x="-7.366" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">DTR</text>
<text x="5.334" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">GND</text>
<text x="2.794" y="1.524" size="0.8128" layer="21" font="vector" ratio="15">CTS</text>
</package>
<package name="3.81MM_TERMINAL_BLOCK_FEMALE_LOCKING">
<wire x1="-7.9756" y1="38.4949" x2="-7.9756" y2="-38.4949" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="38.4949" x2="-1.27" y2="-38.4949" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="38.4949" x2="-7.9756" y2="38.4949" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="-38.4949" x2="-7.9756" y2="-38.4949" width="0.2032" layer="51"/>
<wire x1="-1.27" y1="38.4949" x2="6.5278" y2="38.4949" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-38.4949" x2="6.5278" y2="-38.4949" width="0.2032" layer="21"/>
<wire x1="6.5278" y1="-38.4949" x2="6.5278" y2="38.4949" width="0.2032" layer="21"/>
<pad name="19" x="4.5212" y="32.3863" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@19" x="1.9812" y="32.3863" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="20" x="4.7244" y="36.1963" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@20" x="2.1844" y="36.1963" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="17" x="4.5212" y="24.7663" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@17" x="1.9812" y="24.7663" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="18" x="4.7244" y="28.5763" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@18" x="2.1844" y="28.5763" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="15" x="4.5212" y="17.1463" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@15" x="1.9812" y="17.1463" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="16" x="4.7244" y="20.9563" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@16" x="2.1844" y="20.9563" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="13" x="4.5212" y="9.5263" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@13" x="1.9812" y="9.5263" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="14" x="4.7244" y="13.3363" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@14" x="2.1844" y="13.3363" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="11" x="4.5212" y="1.9063" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@11" x="1.9812" y="1.9063" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="12" x="4.7244" y="5.7163" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@12" x="2.1844" y="5.7163" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="9" x="4.5212" y="-5.7137" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@9" x="1.9812" y="-5.7137" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="10" x="4.7244" y="-1.9037" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@10" x="2.1844" y="-1.9037" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="7" x="4.5212" y="-13.3337" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@7" x="1.9812" y="-13.3337" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="8" x="4.7244" y="-9.5237" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@8" x="2.1844" y="-9.5237" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="5" x="4.5212" y="-20.9537" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@5" x="1.9812" y="-20.9537" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="6" x="4.7244" y="-17.1437" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@6" x="2.1844" y="-17.1437" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="3" x="4.5212" y="-28.5737" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@3" x="1.9812" y="-28.5737" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="4" x="4.7244" y="-24.7637" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@4" x="2.1844" y="-24.7637" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="1" x="4.5212" y="-36.1937" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@1" x="1.9812" y="-36.1937" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="2" x="4.7244" y="-32.3837" drill="1.2" diameter="2.1844" rot="R270"/>
<pad name="@2" x="2.1844" y="-32.3837" drill="1.2" diameter="2.1844" rot="R270"/>
<text x="-7.78" y="-41.41" size="1.27" layer="25">&gt;NAME</text>
<rectangle x1="4.1529" y1="32.1704" x2="5.0927" y2="32.6022" layer="51"/>
<rectangle x1="4.1529" y1="35.9804" x2="5.0927" y2="36.4122" layer="51"/>
<rectangle x1="1.6129" y1="32.1704" x2="2.5527" y2="32.6022" layer="51"/>
<rectangle x1="1.6129" y1="35.9804" x2="2.5527" y2="36.4122" layer="51"/>
<rectangle x1="4.1529" y1="24.5504" x2="5.0927" y2="24.9822" layer="51"/>
<rectangle x1="4.1529" y1="28.3604" x2="5.0927" y2="28.7922" layer="51"/>
<rectangle x1="1.6129" y1="24.5504" x2="2.5527" y2="24.9822" layer="51"/>
<rectangle x1="1.6129" y1="28.3604" x2="2.5527" y2="28.7922" layer="51"/>
<rectangle x1="4.1529" y1="16.9304" x2="5.0927" y2="17.3622" layer="51"/>
<rectangle x1="4.1529" y1="20.7404" x2="5.0927" y2="21.1722" layer="51"/>
<rectangle x1="1.6129" y1="16.9304" x2="2.5527" y2="17.3622" layer="51"/>
<rectangle x1="1.6129" y1="20.7404" x2="2.5527" y2="21.1722" layer="51"/>
<rectangle x1="4.1529" y1="9.3104" x2="5.0927" y2="9.7422" layer="51"/>
<rectangle x1="4.1529" y1="13.1204" x2="5.0927" y2="13.5522" layer="51"/>
<rectangle x1="1.6129" y1="9.3104" x2="2.5527" y2="9.7422" layer="51"/>
<rectangle x1="1.6129" y1="13.1204" x2="2.5527" y2="13.5522" layer="51"/>
<rectangle x1="4.1529" y1="1.6904" x2="5.0927" y2="2.1222" layer="51"/>
<rectangle x1="4.1529" y1="5.5004" x2="5.0927" y2="5.9322" layer="51"/>
<rectangle x1="1.6129" y1="1.6904" x2="2.5527" y2="2.1222" layer="51"/>
<rectangle x1="1.6129" y1="5.5004" x2="2.5527" y2="5.9322" layer="51"/>
<rectangle x1="4.1529" y1="-5.9296" x2="5.0927" y2="-5.4978" layer="51"/>
<rectangle x1="4.1529" y1="-2.1196" x2="5.0927" y2="-1.6878" layer="51"/>
<rectangle x1="1.6129" y1="-5.9296" x2="2.5527" y2="-5.4978" layer="51"/>
<rectangle x1="1.6129" y1="-2.1196" x2="2.5527" y2="-1.6878" layer="51"/>
<rectangle x1="4.1529" y1="-13.5496" x2="5.0927" y2="-13.1178" layer="51"/>
<rectangle x1="4.1529" y1="-9.7396" x2="5.0927" y2="-9.3078" layer="51"/>
<rectangle x1="1.6129" y1="-13.5496" x2="2.5527" y2="-13.1178" layer="51"/>
<rectangle x1="1.6129" y1="-9.7396" x2="2.5527" y2="-9.3078" layer="51"/>
<rectangle x1="4.1529" y1="-21.1696" x2="5.0927" y2="-20.7378" layer="51"/>
<rectangle x1="4.1529" y1="-17.3596" x2="5.0927" y2="-16.9278" layer="51"/>
<rectangle x1="1.6129" y1="-21.1696" x2="2.5527" y2="-20.7378" layer="51"/>
<rectangle x1="1.6129" y1="-17.3596" x2="2.5527" y2="-16.9278" layer="51"/>
<rectangle x1="4.1529" y1="-28.7896" x2="5.0927" y2="-28.3578" layer="51"/>
<rectangle x1="4.1529" y1="-24.9796" x2="5.0927" y2="-24.5478" layer="51"/>
<rectangle x1="1.6129" y1="-28.7896" x2="2.5527" y2="-28.3578" layer="51"/>
<rectangle x1="1.6129" y1="-24.9796" x2="2.5527" y2="-24.5478" layer="51"/>
<rectangle x1="4.1529" y1="-36.4096" x2="5.0927" y2="-35.9778" layer="51"/>
<rectangle x1="4.1529" y1="-32.5996" x2="5.0927" y2="-32.1678" layer="51"/>
<rectangle x1="1.6129" y1="-36.4096" x2="2.5527" y2="-35.9778" layer="51"/>
<rectangle x1="1.6129" y1="-32.5996" x2="2.5527" y2="-32.1678" layer="51"/>
</package>
<package name="1X04_SMD_STRAIGHT_COMBO">
<wire x1="7.62" y1="1.27" x2="7.62" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="0" y1="1.27" x2="0" y2="-1.27" width="0.4064" layer="1"/>
<wire x1="-1.37" y1="-1.25" x2="-1.37" y2="1.25" width="0.1778" layer="21"/>
<wire x1="8.99" y1="1.25" x2="8.99" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="-0.73" y1="-1.25" x2="-1.37" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="8.99" y1="-1.25" x2="8.32" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="8.32" y1="1.25" x2="8.99" y2="1.25" width="0.1778" layer="21"/>
<wire x1="-1.37" y1="1.25" x2="-0.73" y2="1.25" width="0.1778" layer="21"/>
<wire x1="5.869" y1="-1.29" x2="6.831" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="5.869" y1="1.25" x2="6.831" y2="1.25" width="0.1778" layer="21"/>
<wire x1="3.329" y1="-1.29" x2="4.291" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="3.329" y1="1.25" x2="4.291" y2="1.25" width="0.1778" layer="21"/>
<wire x1="0.789" y1="-1.29" x2="1.751" y2="-1.29" width="0.1778" layer="21"/>
<wire x1="0.789" y1="1.25" x2="1.751" y2="1.25" width="0.1778" layer="21"/>
<smd name="3" x="5.08" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1" x="0" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="4" x="7.62" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2" x="2.54" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1-2" x="0" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="2-2" x="2.54" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="3-2" x="5.08" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="4-2" x="7.62" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<text x="0" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="-4.191" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DB15">
<wire x1="-8.128" y1="12.079" x2="-7.62" y2="12.587" width="0.2032" layer="51" curve="-90"/>
<wire x1="7.62" y1="12.587" x2="8.128" y2="12.079" width="0.2032" layer="51" curve="-90"/>
<wire x1="-15.4" y1="-9.65" x2="-15.4" y2="2.38" width="0.2032" layer="21"/>
<wire x1="-15.4" y1="2.38" x2="-15.4" y2="6.35" width="0.2032" layer="51"/>
<wire x1="15.4" y1="-9.65" x2="15.4" y2="2.38" width="0.2032" layer="21"/>
<wire x1="15.4" y1="2.38" x2="15.4" y2="6.35" width="0.2032" layer="51"/>
<wire x1="-8.128" y1="6.999" x2="-8.128" y2="12.079" width="0.2032" layer="51"/>
<wire x1="-8.763" y1="6.364" x2="-8.128" y2="6.999" width="0.2032" layer="51" curve="90"/>
<wire x1="-15.4" y1="6.35" x2="15.4" y2="6.35" width="0.2032" layer="51"/>
<wire x1="8.128" y1="6.999" x2="8.128" y2="12.079" width="0.2032" layer="51"/>
<wire x1="8.128" y1="6.999" x2="8.763" y2="6.364" width="0.2032" layer="51" curve="90"/>
<wire x1="-7.62" y1="12.587" x2="7.62" y2="12.587" width="0.2032" layer="51"/>
<wire x1="-15.4" y1="-9.65" x2="15.4" y2="-9.65" width="0.2032" layer="21"/>
<pad name="7" x="-3.17" y="-5.08" drill="1.016" diameter="1.8796"/>
<pad name="8" x="-0.88" y="-5.08" drill="1.016" diameter="1.8796"/>
<pad name="9" x="1.41" y="-5.08" drill="1.016" diameter="1.8796"/>
<pad name="10" x="3.7" y="-5.08" drill="1.016" diameter="1.8796"/>
<pad name="11" x="-4.32" y="-2.54" drill="1.016" diameter="1.8796"/>
<pad name="12" x="-2.03" y="-2.54" drill="1.016" diameter="1.8796"/>
<pad name="13" x="0.26" y="-2.54" drill="1.016" diameter="1.8796"/>
<pad name="14" x="2.55" y="-2.54" drill="1.016" diameter="1.8796"/>
<pad name="G1" x="-12.5" y="-5.08" drill="3.302" diameter="5.08"/>
<pad name="G2" x="12.5" y="-5.08" drill="3.302" diameter="5.08"/>
<text x="-0.795" y="-1.19" size="0.4064" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.69" y="-0.395" size="0.4064" layer="27" ratio="10">&gt;VALUE</text>
<pad name="6" x="-5.46" y="-5.08" drill="1.016" diameter="1.8796"/>
<pad name="15" x="4.84" y="-2.54" drill="1.016" diameter="1.8796"/>
<pad name="1" x="-4.32" y="-7.62" drill="1.016" diameter="1.8796"/>
<pad name="2" x="-2.03" y="-7.62" drill="1.016" diameter="1.8796"/>
<pad name="3" x="0.26" y="-7.62" drill="1.016" diameter="1.8796"/>
<pad name="4" x="2.55" y="-7.62" drill="1.016" diameter="1.8796"/>
<pad name="5" x="4.84" y="-7.62" drill="1.016" diameter="1.8796"/>
</package>
<package name="AUDIO-JACK-TRRS-SMD">
<wire x1="0.5" y1="-3.3" x2="10.5" y2="-3.3" width="0.254" layer="21"/>
<wire x1="12.2" y1="3.3" x2="12.2" y2="-3.3" width="0.254" layer="21"/>
<wire x1="12.2" y1="3.3" x2="11" y2="3.3" width="0.254" layer="21"/>
<wire x1="0.5" y1="3.3" x2="0" y2="3.3" width="0.254" layer="51"/>
<wire x1="0" y1="3.3" x2="0" y2="2.8" width="0.254" layer="51"/>
<wire x1="0" y1="2.8" x2="0" y2="-2.8" width="0.254" layer="51"/>
<wire x1="0" y1="-2.8" x2="0" y2="-3.3" width="0.254" layer="51"/>
<wire x1="0" y1="-3.3" x2="0.5" y2="-3.3" width="0.254" layer="51"/>
<wire x1="0" y1="2.8" x2="-2" y2="2.8" width="0.254" layer="51"/>
<wire x1="-2" y1="2.8" x2="-2" y2="-2.8" width="0.254" layer="51"/>
<wire x1="-2" y1="-2.8" x2="0" y2="-2.8" width="0.254" layer="51"/>
<smd name="TIP" x="10.2" y="3.25" dx="1.2" dy="2.5" layer="1"/>
<smd name="EARTH" x="11.3" y="-3.25" dx="1.2" dy="2.5" layer="1"/>
<smd name="RING1" x="6.2" y="3.25" dx="1.2" dy="2.5" layer="1"/>
<smd name="RING2" x="3.2" y="3.25" dx="1.2" dy="2.5" layer="1" rot="R180"/>
<hole x="1.6" y="0" drill="1.2"/>
<hole x="8.6" y="0" drill="1.2"/>
<wire x1="7" y1="3.3" x2="9.4" y2="3.3" width="0.254" layer="21"/>
<wire x1="4" y1="3.3" x2="5.4" y2="3.3" width="0.254" layer="21"/>
<wire x1="0.5" y1="3.3" x2="2.4" y2="3.3" width="0.254" layer="21"/>
<text x="3.81" y="-2.54" size="0.4064" layer="25">&gt;NAME</text>
</package>
<package name="1X03_SMD_RA_FEMALE">
<wire x1="-3.935" y1="4.25" x2="-3.935" y2="-4.25" width="0.1778" layer="21"/>
<wire x1="3.935" y1="4.25" x2="-3.935" y2="4.25" width="0.1778" layer="21"/>
<wire x1="3.935" y1="-4.25" x2="3.935" y2="4.25" width="0.1778" layer="21"/>
<wire x1="-3.935" y1="-4.25" x2="3.935" y2="-4.25" width="0.1778" layer="21"/>
<rectangle x1="-0.32" y1="6.8" x2="0.32" y2="7.65" layer="51"/>
<rectangle x1="2.22" y1="6.8" x2="2.86" y2="7.65" layer="51"/>
<rectangle x1="-2.86" y1="6.8" x2="-2.22" y2="7.65" layer="51"/>
<smd name="3" x="2.54" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="2" x="0" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="1" x="-2.54" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<text x="-3.155" y="2.775" size="1" layer="27">&gt;Value</text>
<text x="-2.955" y="-3.395" size="1" layer="25">&gt;Name</text>
</package>
<package name="1X03_SMD_RA_MALE">
<wire x1="3.81" y1="1.25" x2="-3.81" y2="1.25" width="0.1778" layer="51"/>
<wire x1="-3.81" y1="1.25" x2="-3.81" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="2.53" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="2.53" y1="-1.25" x2="-0.01" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="-0.01" y1="-1.25" x2="-2.55" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="-2.55" y1="-1.25" x2="-3.81" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="1.25" width="0.1778" layer="51"/>
<wire x1="2.53" y1="-1.25" x2="2.53" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-0.01" y1="-1.25" x2="-0.01" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-2.55" y1="-1.25" x2="-2.55" y2="-7.25" width="0.127" layer="51"/>
<rectangle x1="-0.32" y1="4.15" x2="0.32" y2="5.95" layer="51"/>
<rectangle x1="-2.86" y1="4.15" x2="-2.22" y2="5.95" layer="51"/>
<rectangle x1="2.22" y1="4.15" x2="2.86" y2="5.95" layer="51"/>
<smd name="1" x="-2.54" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="2" x="0" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="3" x="2.54" y="5" dx="3" dy="1" layer="1" rot="R90"/>
</package>
<package name="2X3_SMT_POSTS">
<description>4UCON 15881&lt;br&gt;
Male .1" spaced SMT&lt;br&gt;
Keying posts into board</description>
<hole x="-1.27" y="0" drill="1.8"/>
<hole x="1.27" y="0" drill="1.8"/>
<smd name="4" x="0" y="2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<smd name="3" x="0" y="-2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<smd name="5" x="2.54" y="-2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<smd name="6" x="2.54" y="2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-2.54" y="2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<smd name="1" x="-2.54" y="-2.54" dx="3.17" dy="1" layer="1" rot="R90"/>
<text x="0" y="-5.08" size="0.6096" layer="27">&gt;VALUE</text>
<text x="0" y="-6.35" size="0.6096" layer="25">&gt;NAME</text>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="2.54" width="0.127" layer="21"/>
<wire x1="0.762" y1="2.54" x2="1.778" y2="2.54" width="0.127" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.889" y2="-2.54" width="0.127" layer="21"/>
<wire x1="0.762" y1="-2.54" x2="1.778" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-3.81" y2="2.54" width="0.127" layer="21"/>
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="-3.175" y2="-2.54" width="0.127" layer="21"/>
<wire x1="3.175" y1="2.54" x2="3.81" y2="2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-2.54" width="0.127" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="3.175" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-3.429" y1="-4.064" x2="-3.429" y2="-2.794" width="0.127" layer="21"/>
</package>
<package name="2X13">
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="-1.27" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="29.21" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.21" y1="-0.635" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="-1.27" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.67" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="21.59" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="-1.27" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="19.05" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="7" x="7.62" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="11" x="12.7" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="13" x="15.24" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="15" x="17.78" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="17" x="20.32" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="19" x="22.86" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="21" x="25.4" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="23" x="27.94" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="25" x="30.48" y="0" drill="1.016" diameter="1.651" rot="R90"/>
<text x="-1.3462" y="4.3688" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<wire x1="14.605" y1="3.81" x2="15.875" y2="3.81" width="0.2032" layer="21"/>
<wire x1="15.875" y1="3.81" x2="16.51" y2="3.175" width="0.2032" layer="21"/>
<wire x1="11.43" y1="3.175" x2="12.065" y2="3.81" width="0.2032" layer="21"/>
<wire x1="12.065" y1="3.81" x2="13.335" y2="3.81" width="0.2032" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.97" y2="3.175" width="0.2032" layer="21"/>
<wire x1="14.605" y1="3.81" x2="13.97" y2="3.175" width="0.2032" layer="21"/>
<wire x1="6.985" y1="3.81" x2="8.255" y2="3.81" width="0.2032" layer="21"/>
<wire x1="8.255" y1="3.81" x2="8.89" y2="3.175" width="0.2032" layer="21"/>
<wire x1="8.89" y1="3.175" x2="9.525" y2="3.81" width="0.2032" layer="21"/>
<wire x1="9.525" y1="3.81" x2="10.795" y2="3.81" width="0.2032" layer="21"/>
<wire x1="10.795" y1="3.81" x2="11.43" y2="3.175" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="4.445" y2="3.81" width="0.2032" layer="21"/>
<wire x1="4.445" y1="3.81" x2="5.715" y2="3.81" width="0.2032" layer="21"/>
<wire x1="5.715" y1="3.81" x2="6.35" y2="3.175" width="0.2032" layer="21"/>
<wire x1="6.985" y1="3.81" x2="6.35" y2="3.175" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.2032" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.905" y2="3.81" width="0.2032" layer="21"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="3.81" width="0.2032" layer="21"/>
<wire x1="3.175" y1="3.81" x2="3.81" y2="3.175" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-1.27" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="-1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="29.21" y1="3.175" x2="29.845" y2="3.81" width="0.2032" layer="21"/>
<wire x1="29.845" y1="3.81" x2="31.115" y2="3.81" width="0.2032" layer="21"/>
<wire x1="31.115" y1="3.81" x2="31.75" y2="3.175" width="0.2032" layer="21"/>
<wire x1="31.75" y1="1.905" x2="31.115" y2="1.27" width="0.2032" layer="21"/>
<wire x1="31.75" y1="1.905" x2="31.75" y2="3.175" width="0.2032" layer="21"/>
<wire x1="24.765" y1="3.81" x2="26.035" y2="3.81" width="0.2032" layer="21"/>
<wire x1="26.035" y1="3.81" x2="26.67" y2="3.175" width="0.2032" layer="21"/>
<wire x1="26.67" y1="3.175" x2="27.305" y2="3.81" width="0.2032" layer="21"/>
<wire x1="27.305" y1="3.81" x2="28.575" y2="3.81" width="0.2032" layer="21"/>
<wire x1="28.575" y1="3.81" x2="29.21" y2="3.175" width="0.2032" layer="21"/>
<wire x1="21.59" y1="3.175" x2="22.225" y2="3.81" width="0.2032" layer="21"/>
<wire x1="22.225" y1="3.81" x2="23.495" y2="3.81" width="0.2032" layer="21"/>
<wire x1="23.495" y1="3.81" x2="24.13" y2="3.175" width="0.2032" layer="21"/>
<wire x1="24.765" y1="3.81" x2="24.13" y2="3.175" width="0.2032" layer="21"/>
<wire x1="17.145" y1="3.81" x2="18.415" y2="3.81" width="0.2032" layer="21"/>
<wire x1="18.415" y1="3.81" x2="19.05" y2="3.175" width="0.2032" layer="21"/>
<wire x1="19.05" y1="3.175" x2="19.685" y2="3.81" width="0.2032" layer="21"/>
<wire x1="19.685" y1="3.81" x2="20.955" y2="3.81" width="0.2032" layer="21"/>
<wire x1="20.955" y1="3.81" x2="21.59" y2="3.175" width="0.2032" layer="21"/>
<wire x1="17.145" y1="3.81" x2="16.51" y2="3.175" width="0.2032" layer="21"/>
<pad name="26" x="30.48" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="24" x="27.94" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="22" x="25.4" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="20" x="22.86" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="18" x="20.32" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="16" x="17.78" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="14" x="15.24" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="12" x="12.7" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="10" x="10.16" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="8" x="7.62" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="6" x="5.08" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="4" x="2.54" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="2" x="0" y="2.54" drill="1.016" diameter="1.651" rot="R270"/>
<rectangle x1="14.986" y1="2.286" x2="15.494" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="17.526" y1="2.286" x2="18.034" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="20.066" y1="2.286" x2="20.574" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="22.606" y1="2.286" x2="23.114" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="25.146" y1="2.286" x2="25.654" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="27.686" y1="2.286" x2="28.194" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="30.226" y1="2.286" x2="30.734" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="-0.254" y1="2.286" x2="0.254" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="2.286" y1="2.286" x2="2.794" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="4.826" y1="2.286" x2="5.334" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="7.366" y1="2.286" x2="7.874" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="9.906" y1="2.286" x2="10.414" y2="2.794" layer="51" rot="R180"/>
<rectangle x1="12.446" y1="2.286" x2="12.954" y2="2.794" layer="51" rot="R180"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="3.175" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="3.175" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="3.175" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="3.175" x2="16.51" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="3.175" x2="19.05" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="3.175" x2="21.59" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="3.175" x2="24.13" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="3.175" x2="26.67" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="29.21" y1="3.175" x2="29.21" y2="-0.635" width="0.2032" layer="21"/>
</package>
<package name="USB-A-SMT-MALE">
<wire x1="6" y1="14.58" x2="-6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="6" y1="0" x2="-6" y2="0" width="0.2032" layer="21"/>
<wire x1="6" y1="0" x2="6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="-6" y1="0" x2="-6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="6" y1="0" x2="6" y2="-1.22" width="0.2032" layer="21"/>
<wire x1="-6" y1="0" x2="-6" y2="-1.22" width="0.2032" layer="21"/>
<wire x1="-4" y1="-4.22" x2="4" y2="-4.22" width="0.2032" layer="21"/>
<wire x1="4.3" y1="10.28" x2="1.9" y2="10.28" width="0.2032" layer="51"/>
<wire x1="1.9" y1="10.28" x2="1.9" y2="7.98" width="0.2032" layer="51"/>
<wire x1="1.9" y1="7.98" x2="4.3" y2="7.98" width="0.2032" layer="51"/>
<wire x1="4.3" y1="7.98" x2="4.3" y2="10.28" width="0.2032" layer="51"/>
<wire x1="-1.9" y1="10.28" x2="-4.3" y2="10.28" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="10.28" x2="-4.3" y2="7.98" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="7.98" x2="-1.9" y2="7.98" width="0.2032" layer="51"/>
<wire x1="-1.9" y1="7.98" x2="-1.9" y2="10.28" width="0.2032" layer="51"/>
<smd name="D+1" x="1.027" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<smd name="D-1" x="-1.027" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<smd name="GND1" x="3.5508" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<pad name="P$1" x="5.85" y="-3.05" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$3" x="-5.85" y="-3.05" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<smd name="VBUS1" x="-3.5" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<text x="-2.7" y="-9.07" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.4" y="0.68" size="1.27" layer="51">PCB Edge</text>
<hole x="2.25" y="-3.12" drill="1.1"/>
<hole x="-2.25" y="-3.12" drill="1.1"/>
<hole x="-5.85" y="-3.45" drill="0.8"/>
<hole x="-5.85" y="-3.85" drill="0.8"/>
<hole x="-5.85" y="-2.65" drill="0.8"/>
<hole x="-5.85" y="-2.25" drill="0.8"/>
<hole x="5.85" y="-3.45" drill="0.8"/>
<hole x="5.85" y="-3.85" drill="0.8"/>
<hole x="5.85" y="-2.65" drill="0.8"/>
<hole x="5.85" y="-2.25" drill="0.8"/>
</package>
<package name="2X3_POGO">
<pad name="P$1" x="0" y="0" drill="1.2" diameter="1.8288" shape="octagon"/>
<pad name="P$3" x="2.54" y="0" drill="1.2" diameter="1.8288" shape="octagon"/>
<pad name="P$5" x="5.08" y="0" drill="1.2" diameter="1.8288" shape="octagon"/>
<pad name="P$6" x="5.08" y="2.54" drill="1.2" diameter="1.8288" shape="octagon"/>
<pad name="P$4" x="2.54" y="2.54" drill="1.2" diameter="1.8288" shape="octagon"/>
<pad name="P$2" x="0" y="2.54" drill="1.2" diameter="1.8288" shape="octagon"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="1.905" width="0.127" layer="21"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-0.635" y2="3.81" width="0.127" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.127" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.905" y2="3.81" width="0.127" layer="21"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="3.81" width="0.127" layer="21"/>
<wire x1="3.175" y1="3.81" x2="3.81" y2="3.175" width="0.127" layer="21"/>
<wire x1="3.81" y1="3.175" x2="4.445" y2="3.81" width="0.127" layer="21"/>
<wire x1="4.445" y1="3.81" x2="5.715" y2="3.81" width="0.127" layer="21"/>
<wire x1="5.715" y1="3.81" x2="6.35" y2="3.175" width="0.127" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="1.905" width="0.127" layer="21"/>
<wire x1="6.35" y1="1.905" x2="5.715" y2="1.27" width="0.127" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.127" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.127" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.127" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.127" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.127" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.127" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.27" y2="0.635" width="0.127" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.127" layer="21"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="0" width="0.127" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="0" width="0.127" layer="21"/>
<wire x1="-0.635" y1="-1.651" x2="0.635" y2="-1.651" width="0.127" layer="21"/>
<text x="-0.508" y="4.064" size="0.4064" layer="25">&gt;NAME</text>
<text x="1.778" y="4.064" size="0.4064" layer="25">&gt;VALUE</text>
</package>
<package name="2X5_NOSILK">
<pad name="1" x="-1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.794" y="-3.302" size="0.4064" layer="25" rot="R90">&gt;NAME</text>
<text x="-2.794" y="-0.254" size="0.4064" layer="27" font="vector" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.524" y1="4.826" x2="-1.016" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="4.826" x2="1.524" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="2.286" x2="1.524" y2="2.794" layer="51"/>
<rectangle x1="-1.524" y1="2.286" x2="-1.016" y2="2.794" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-4.826" layer="51"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-4.826" layer="51"/>
<rectangle x1="-1.524" y1="-2.794" x2="-1.016" y2="-2.286" layer="51"/>
<rectangle x1="1.016" y1="-2.794" x2="1.524" y2="-2.286" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
</package>
<package name="SPRING-CONNECTOR">
<smd name="P$2" x="0" y="0" dx="7.112" dy="7.112" layer="1" roundness="100"/>
<text x="-1.3462" y="5.6388" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="1X02_2.54_SCREWTERM">
<pad name="P2" x="0" y="0" drill="1.016" shape="square"/>
<pad name="P1" x="2.54" y="0" drill="1.016" shape="square"/>
<wire x1="-1.5" y1="3.25" x2="4" y2="3.25" width="0.2032" layer="21"/>
<wire x1="4" y1="3.25" x2="4" y2="2.5" width="0.2032" layer="21"/>
<wire x1="4" y1="2.5" x2="4" y2="-3.25" width="0.2032" layer="21"/>
<wire x1="4" y1="-3.25" x2="-1.5" y2="-3.25" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-3.25" x2="-1.5" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="2.5" x2="-1.5" y2="3.25" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="2.5" x2="4" y2="2.5" width="0.2032" layer="21"/>
</package>
<package name="BTA">
<description>British Telecom connector, used for Vernier sensors (analog)</description>
<hole x="6.45" y="0" drill="3.2"/>
<hole x="-6.45" y="0" drill="3.2"/>
<pad name="1" x="4.75" y="9" drill="1.4" diameter="2.54" shape="square" rot="R90"/>
<pad name="2" x="3.25" y="6" drill="1.4" diameter="2.54"/>
<pad name="3" x="1.75" y="9" drill="1.4" diameter="2.54"/>
<pad name="5" x="-1.25" y="9" drill="1.4" diameter="2.54"/>
<pad name="4" x="0.25" y="6" drill="1.4" diameter="2.54"/>
<pad name="6" x="-2.75" y="6" drill="1.4" diameter="2.54"/>
<wire x1="-8" y1="-7.5" x2="-8" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-3.8" x2="-7.95" y2="9.9" width="0.2032" layer="21"/>
<wire x1="-8" y1="-7.5" x2="7.9" y2="-7.5" width="0.2032" layer="21"/>
<wire x1="7.9" y1="-7.5" x2="7.9" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-3.8" x2="7.95" y2="9.9" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="9.9" x2="7.95" y2="9.9" width="0.2032" layer="21"/>
<wire x1="-8.925" y1="-3.8" x2="-8.925" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="8.925" y1="-3.8" x2="8.925" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-8.925" y1="-5.1" x2="-8" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="7.9" y1="-5.1" x2="8.925" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-8.925" y1="-3.8" x2="-7.95" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-3.8" x2="7.95" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-3.8" x2="8.925" y2="-3.8" width="0.2032" layer="21"/>
<text x="-2.92" y="-7.07" size="1.27" layer="25">&gt;NAME</text>
<wire x1="-8" y1="-5.1" x2="7.9" y2="-5.1" width="0.2032" layer="21"/>
</package>
<package name="BTD">
<description>British Telecom connector, used for Vernier sensors (digital)</description>
<wire x1="-7.95" y1="-7.5" x2="7.95" y2="-7.5" width="0.2032" layer="21"/>
<wire x1="-8.975" y1="-3.8" x2="-8.975" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="8.875" y1="-3.8" x2="8.875" y2="-5.1" width="0.2032" layer="21"/>
<pad name="2" x="-3.25" y="9" drill="1.4" diameter="2.54" rot="R180"/>
<pad name="1" x="-4.75" y="6" drill="1.4" diameter="2.54" shape="square" rot="R180"/>
<pad name="4" x="-0.25" y="9" drill="1.4" diameter="2.54" rot="R180"/>
<pad name="6" x="2.75" y="9" drill="1.4" diameter="2.54" rot="R180"/>
<pad name="3" x="-1.75" y="6" drill="1.4" diameter="2.54" rot="R180"/>
<pad name="5" x="1.25" y="6" drill="1.4" diameter="2.54" rot="R180"/>
<wire x1="-8.975" y1="-5.1" x2="-7.95" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-5.1" x2="7.95" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-5.1" x2="8.875" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-8.975" y1="-3.8" x2="-7.95" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-7.5" x2="7.95" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="-7.95" y1="-7.5" x2="-7.95" y2="-5.1" width="0.2032" layer="21"/>
<wire x1="7.95" y1="-3.8" x2="8.875" y2="-3.8" width="0.2032" layer="21"/>
<text x="-3" y="-7" size="1.27" layer="25">&gt;Name</text>
</package>
<package name="1X06_SMD_MALE">
<text x="-1" y="3.321" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1" y="-4.591" size="1.27" layer="27">&gt;VALUE</text>
<wire x1="-1.27" y1="1.25" x2="-1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="13.97" y2="-1.25" width="0.127" layer="51"/>
<wire x1="13.97" y1="-1.25" x2="13.97" y2="1.25" width="0.127" layer="51"/>
<wire x1="13.97" y1="1.25" x2="-1.27" y2="1.25" width="0.127" layer="51"/>
<circle x="0" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="2.54" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="5.08" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="7.62" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="10.16" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="12.7" y="0" radius="0.64" width="0.127" layer="51"/>
<rectangle x1="-0.32" y1="0" x2="0.32" y2="2.75" layer="51"/>
<rectangle x1="4.76" y1="0" x2="5.4" y2="2.75" layer="51"/>
<rectangle x1="9.84" y1="0" x2="10.48" y2="2.75" layer="51"/>
<rectangle x1="2.22" y1="-2.75" x2="2.86" y2="0" layer="51" rot="R180"/>
<rectangle x1="7.3" y1="-2.75" x2="7.94" y2="0" layer="51" rot="R180"/>
<rectangle x1="12.38" y1="-2.75" x2="13.02" y2="0" layer="51" rot="R180"/>
<smd name="1" x="0" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="2" x="2.54" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="3" x="5.08" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="4" x="7.62" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="5" x="10.16" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="6" x="12.7" y="0" dx="1.02" dy="6" layer="1"/>
<wire x1="-1.27" y1="1.25" x2="-1.27" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="-1.27" y1="-1.25" x2="-0.635" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="-1.27" y1="1.25" x2="-0.635" y2="1.25" width="0.1778" layer="21"/>
<wire x1="0.762" y1="1.25" x2="1.778" y2="1.25" width="0.1778" layer="21"/>
<wire x1="3.302" y1="1.25" x2="4.318" y2="1.25" width="0.1778" layer="21"/>
<wire x1="5.842" y1="1.25" x2="6.858" y2="1.25" width="0.1778" layer="21"/>
<wire x1="8.382" y1="1.25" x2="9.398" y2="1.25" width="0.1778" layer="21"/>
<wire x1="10.922" y1="1.25" x2="11.938" y2="1.25" width="0.1778" layer="21"/>
<wire x1="1.778" y1="-1.25" x2="0.762" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="4.318" y1="-1.25" x2="3.302" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="6.858" y1="-1.25" x2="5.842" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="9.398" y1="-1.25" x2="8.382" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="11.938" y1="-1.25" x2="10.922" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="13.97" y1="-1.25" x2="13.97" y2="1.25" width="0.1778" layer="21"/>
<wire x1="13.97" y1="-1.25" x2="13.335" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="13.97" y1="1.25" x2="13.335" y2="1.25" width="0.1778" layer="21"/>
</package>
<package name="1X10_SMD_MALE">
<wire x1="-1.27" y1="-1.25" x2="24.13" y2="-1.25" width="0.127" layer="51"/>
<wire x1="24.13" y1="-1.25" x2="24.13" y2="1.25" width="0.127" layer="51"/>
<wire x1="24.13" y1="1.25" x2="-1.27" y2="1.25" width="0.127" layer="51"/>
<wire x1="24.13" y1="-1.25" x2="24.13" y2="1.25" width="0.1778" layer="21"/>
<circle x="15.24" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="17.78" y="0" radius="0.64" width="0.127" layer="51"/>
<rectangle x1="14.92" y1="0" x2="15.56" y2="2.75" layer="51"/>
<rectangle x1="17.46" y1="-2.75" x2="18.1" y2="0" layer="51" rot="R180"/>
<smd name="7" x="15.24" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="8" x="17.78" y="0" dx="1.02" dy="6" layer="1"/>
<wire x1="16.002" y1="1.25" x2="17.018" y2="1.25" width="0.1778" layer="21"/>
<wire x1="17.018" y1="-1.25" x2="16.002" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="24.13" y1="-1.25" x2="23.495" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="24.13" y1="1.25" x2="23.495" y2="1.25" width="0.1778" layer="21"/>
<wire x1="13.462" y1="1.25" x2="14.478" y2="1.25" width="0.1778" layer="21"/>
<wire x1="14.478" y1="-1.25" x2="13.462" y2="-1.25" width="0.1778" layer="21"/>
<smd name="9" x="20.32" y="0" dx="1.02" dy="6" layer="1"/>
<smd name="10" x="22.86" y="0" dx="1.02" dy="6" layer="1"/>
<rectangle x1="22.54" y1="-2.75" x2="23.18" y2="0" layer="51" rot="R180"/>
<rectangle x1="20" y1="0" x2="20.64" y2="2.75" layer="51"/>
<circle x="20.32" y="0" radius="0.64" width="0.127" layer="51"/>
<circle x="22.86" y="0" radius="0.64" width="0.127" layer="51"/>
<wire x1="18.542" y1="1.25" x2="19.558" y2="1.25" width="0.1778" layer="21"/>
<wire x1="21.082" y1="1.25" x2="22.098" y2="1.25" width="0.1778" layer="21"/>
<wire x1="19.558" y1="-1.25" x2="18.542" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="22.098" y1="-1.25" x2="21.082" y2="-1.25" width="0.1778" layer="21"/>
</package>
<package name="1X08_SMD_MALE">
<wire x1="-1.27" y1="-1.25" x2="19.05" y2="-1.25" width="0.127" layer="51"/>
<wire x1="19.05" y1="-1.25" x2="19.05" y2="1.25" width="0.127" layer="51"/>
<wire x1="19.05" y1="1.25" x2="-1.27" y2="1.25" width="0.127" layer="51"/>
<wire x1="19.05" y1="-1.25" x2="19.05" y2="1.25" width="0.1778" layer="21"/>
<wire x1="19.05" y1="-1.25" x2="18.415" y2="-1.25" width="0.1778" layer="21"/>
<wire x1="19.05" y1="1.25" x2="18.415" y2="1.25" width="0.1778" layer="21"/>
</package>
<package name="1X10_SMD_COMBINED">
<wire x1="-1.37" y1="-1.25" x2="-1.37" y2="1.25" width="0.127" layer="21"/>
<wire x1="24.23" y1="1.25" x2="24.23" y2="-1.25" width="0.127" layer="21"/>
<wire x1="-0.85" y1="-1.25" x2="-1.37" y2="-1.25" width="0.127" layer="21"/>
<wire x1="24.23" y1="-1.25" x2="23.583" y2="-1.25" width="0.127" layer="21"/>
<wire x1="23.71" y1="1.25" x2="24.23" y2="1.25" width="0.127" layer="21"/>
<wire x1="-1.37" y1="1.25" x2="-0.723" y2="1.25" width="0.127" layer="21"/>
<wire x1="14.537" y1="-1.25" x2="13.403" y2="-1.25" width="0.127" layer="21"/>
<wire x1="0.789" y1="1.25" x2="1.751" y2="1.25" width="0.127" layer="21"/>
<wire x1="3.329" y1="1.25" x2="4.291" y2="1.25" width="0.127" layer="21"/>
<wire x1="5.869" y1="1.25" x2="6.831" y2="1.25" width="0.127" layer="21"/>
<wire x1="8.409" y1="1.25" x2="9.371" y2="1.25" width="0.127" layer="21"/>
<wire x1="10.949" y1="1.25" x2="11.911" y2="1.25" width="0.127" layer="21"/>
<wire x1="13.489" y1="1.25" x2="14.451" y2="1.25" width="0.127" layer="21"/>
<wire x1="16.029" y1="1.25" x2="16.991" y2="1.25" width="0.127" layer="21"/>
<wire x1="17.077" y1="-1.25" x2="15.943" y2="-1.25" width="0.127" layer="21"/>
<wire x1="11.997" y1="-1.25" x2="10.863" y2="-1.25" width="0.127" layer="21"/>
<wire x1="9.457" y1="-1.25" x2="8.323" y2="-1.25" width="0.127" layer="21"/>
<wire x1="6.917" y1="-1.25" x2="5.783" y2="-1.25" width="0.127" layer="21"/>
<wire x1="4.377" y1="-1.25" x2="3.243" y2="-1.25" width="0.127" layer="21"/>
<wire x1="1.837" y1="-1.25" x2="0.703" y2="-1.25" width="0.127" layer="21"/>
<smd name="7B" x="15.24" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="5B" x="10.16" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="3B" x="5.08" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="8A" x="17.78" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="6A" x="12.7" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="4A" x="7.62" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="2A" x="2.54" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1A" x="0" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="2B" x="2.54" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="3A" x="5.08" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="4B" x="7.62" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="5A" x="10.16" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="6B" x="12.7" y="-1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="7A" x="15.24" y="1.65" dx="2" dy="1" layer="1" rot="R90"/>
<smd name="8B" x="17.78" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="1B" x="0" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="9A" x="20.32" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="10A" x="22.86" y="1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="9B" x="20.32" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<smd name="10B" x="22.86" y="-1.65" dx="2" dy="1" layer="1" rot="R270"/>
<wire x1="18.569" y1="1.25" x2="19.531" y2="1.25" width="0.127" layer="21"/>
<wire x1="21.109" y1="1.25" x2="22.071" y2="1.25" width="0.127" layer="21"/>
<wire x1="19.617" y1="-1.25" x2="18.483" y2="-1.25" width="0.127" layer="21"/>
<wire x1="22.157" y1="-1.25" x2="21.023" y2="-1.25" width="0.127" layer="21"/>
</package>
<package name="USB_AB_MICRO_1:1_V2">
<smd name="SHIELD1" x="0" y="4" dx="2.2" dy="1.27" layer="1" rot="R90"/>
<smd name="SHIELD4" x="0" y="-4" dx="2.2" dy="1.27" layer="1" rot="R90"/>
</package>
<package name="1X03_SMD_RA_MALE_POST">
<description>&lt;h3&gt;SMD 3-Pin Male Right-Angle Header w/ Alignment posts&lt;/h3&gt;
Matches 4UCONN part # 11026&lt;br&gt;
&lt;a href="http://www.4uconnector.com/online/object/4udrawing/11026.pdf"&gt;http://www.4uconnector.com/online/object/4udrawing/11026.pdf&lt;/a&gt;</description>
<smd name="1" x="-2.54" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<smd name="2" x="0" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<smd name="3" x="2.54" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<hole x="-1.27" y="0" drill="1.6"/>
<hole x="1.27" y="0" drill="1.6"/>
</package>
<package name="AUDIO-JACK-.25-INCH-HORIZ-PTH">
<pad name="RING-NORM" x="10.5" y="4.35" drill="1.6"/>
<pad name="SLEEVE" x="4.2" y="-6.95" drill="1.6"/>
<pad name="SLEEVE-NORM" x="4.2" y="4.35" drill="1.6"/>
<pad name="RING" x="10.5" y="-6.95" drill="1.6"/>
<pad name="TIP-NORM" x="16.8" y="4.35" drill="1.6"/>
<pad name="TIP" x="16.8" y="-6.95" drill="1.6"/>
<wire x1="0" y1="6.23" x2="0" y2="-8.77" width="0.127" layer="21"/>
<wire x1="0" y1="-8.77" x2="21" y2="-8.77" width="0.127" layer="21"/>
<wire x1="21" y1="-8.77" x2="21" y2="-3.97" width="0.127" layer="21"/>
<wire x1="21" y1="-3.97" x2="21" y2="4.03" width="0.127" layer="21"/>
<wire x1="21" y1="4.03" x2="21" y2="6.23" width="0.127" layer="21"/>
<wire x1="21" y1="6.23" x2="0" y2="6.23" width="0.127" layer="21"/>
<wire x1="0.73" y1="0.03" x2="24" y2="0.03" width="0.127" layer="21"/>
<wire x1="24" y1="0.03" x2="24" y2="3.03" width="0.127" layer="21"/>
<wire x1="24" y1="0.03" x2="24" y2="-2.97" width="0.127" layer="21"/>
<wire x1="-9" y1="5.53" x2="0" y2="5.53" width="0.127" layer="51"/>
<wire x1="0" y1="5.53" x2="0" y2="-5.47" width="0.127" layer="51"/>
<wire x1="0" y1="-5.47" x2="-9" y2="-5.47" width="0.127" layer="51"/>
<wire x1="-9" y1="-5.47" x2="-9" y2="0.03" width="0.127" layer="51"/>
<wire x1="-9" y1="0.03" x2="-9" y2="5.53" width="0.127" layer="51"/>
<wire x1="-8" y1="4.53" x2="-7" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-7" y1="4.53" x2="-6" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-6" y1="4.53" x2="-5" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-5" y1="4.53" x2="-4" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-4" y1="4.53" x2="-3" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-3" y1="4.53" x2="-2" y2="-4.47" width="0.127" layer="51"/>
<wire x1="-2" y1="4.53" x2="-1" y2="-4.47" width="0.127" layer="51"/>
<wire x1="24" y1="3.03" x2="21" y2="4.03" width="0.127" layer="21"/>
<wire x1="24" y1="-2.97" x2="21" y2="-3.97" width="0.127" layer="21"/>
<wire x1="-9" y1="0.03" x2="-8.1" y2="0.03" width="0.127" layer="51"/>
<text x="2.54" y="0" size="1.778" layer="25" font="vector">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.778" layer="27" font="vector">&gt;VALUE</text>
<hole x="7.4" y="4" drill="2.2"/>
<hole x="7.4" y="-6.6" drill="2.2"/>
<wire x1="-6" y1="8.75" x2="0" y2="8.75" width="0.127" layer="51"/>
<wire x1="-6" y1="-8.75" x2="0" y2="-8.75" width="0.127" layer="51"/>
<wire x1="-6" y1="8.75" x2="-6" y2="-8.75" width="0.127" layer="51"/>
<wire x1="0" y1="8.75" x2="0" y2="-8.75" width="0.127" layer="51"/>
</package>
<package name="AUDIO-JACK-.25-INCH-VERT-PTH">
<wire x1="0" y1="0" x2="11.6" y2="0" width="0.127" layer="21"/>
<wire x1="11.6" y1="0" x2="15.8" y2="0" width="0.127" layer="21"/>
<wire x1="15.8" y1="0" x2="15.8" y2="4.2" width="0.127" layer="21"/>
<wire x1="15.8" y1="4.2" x2="15.8" y2="15.8" width="0.127" layer="21"/>
<wire x1="15.8" y1="15.8" x2="0" y2="15.8" width="0.127" layer="21"/>
<wire x1="0" y1="15.8" x2="0" y2="0" width="0.127" layer="21"/>
<wire x1="11.6" y1="0" x2="15.8" y2="4.2" width="0.127" layer="21"/>
<circle x="7.9" y="7.9" radius="3.215" width="0.127" layer="21"/>
<circle x="7.9" y="7.9" radius="5.9" width="0.127" layer="21"/>
<text x="1" y="16" size="1.778" layer="21" font="vector">&gt;NAME</text>
<text x="1" y="-2" size="1.778" layer="21" font="vector">&gt;VALUE</text>
<pad name="TIP" x="1.4" y="7.4" drill="2.2"/>
<pad name="RING" x="8.4" y="14.4" drill="2.2"/>
<pad name="RING-NORM" x="14.4" y="10.4" drill="2.2"/>
<pad name="SLEEVE" x="12.496" y="3.304" drill="2.2"/>
<pad name="TIP-NORM" x="5.4" y="1.4" drill="2.2"/>
<wire x1="4.7" y1="7.9" x2="11.1" y2="7.9" width="0.127" layer="21"/>
<wire x1="7.9" y1="11.1" x2="7.9" y2="4.7" width="0.127" layer="21"/>
</package>
<package name="USB-AB-MICRO-SMD_V03">
<text x="-4.66" y="5.96" size="0.3048" layer="51">PCB Front</text>
<wire x1="-3" y1="5.6" x2="-2.3" y2="5.3" width="0.08" layer="51"/>
<wire x1="-2.3" y1="5.3" x2="-2.4" y2="5.5" width="0.08" layer="51"/>
<wire x1="-2.3" y1="5.3" x2="-2.5" y2="5.2" width="0.08" layer="51"/>
<text x="-1.27" y="5.969" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="5.461" size="0.4064" layer="27">&gt;VALUE</text>
<smd name="D+1" x="2.7" y="0" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="D-1" x="2.7" y="0.65" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="VBUS1" x="2.7" y="1.3" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="ID1" x="2.7" y="-0.65" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<smd name="GND1" x="2.7" y="-1.3" dx="0.4" dy="1.4" layer="1" rot="R90"/>
<hole x="2.2" y="1.9" drill="0.85"/>
<hole x="2.2" y="-1.9" drill="0.85"/>
<rectangle x1="-0.75" y1="2.784" x2="0.75" y2="4.584" layer="31"/>
<rectangle x1="-0.35" y1="-0.75" x2="0.35" y2="0.75" layer="31"/>
<rectangle x1="-0.75" y1="-4.584" x2="0.75" y2="-2.784" layer="31"/>
<wire x1="-2.15" y1="3.9" x2="-2.15" y2="-3.9" width="0.127" layer="49"/>
<wire x1="2.85" y1="3.9" x2="2.85" y2="-3.9" width="0.127" layer="49"/>
<wire x1="2.85" y1="3.9" x2="-2.15" y2="3.9" width="0.127" layer="49"/>
<wire x1="2.85" y1="-3.9" x2="-2.15" y2="-3.9" width="0.127" layer="49"/>
<wire x1="2.981959375" y1="3.99288125" x2="2" y2="3.99288125" width="0.3048" layer="21"/>
<wire x1="2" y1="3.99288125" x2="2" y2="4" width="0.3048" layer="21"/>
<wire x1="3" y1="4" x2="3" y2="3" width="0.3048" layer="21"/>
<wire x1="2" y1="-4" x2="3" y2="-4" width="0.3048" layer="21"/>
<wire x1="3" y1="-4" x2="3" y2="-3" width="0.3048" layer="21"/>
<wire x1="-1" y1="4" x2="-2" y2="4" width="0.3048" layer="21"/>
<wire x1="-1" y1="-4" x2="-2" y2="-4" width="0.3048" layer="21"/>
<rectangle x1="-0.85" y1="2.684" x2="0.85" y2="4.684" layer="29"/>
<rectangle x1="-0.85" y1="-4.684" x2="0.85" y2="-2.684" layer="29"/>
<rectangle x1="-0.85" y1="-1.35" x2="0.85" y2="1.35" layer="29"/>
<smd name="SHIELD1" x="0" y="3.68" dx="1.5" dy="1.8" layer="1"/>
<smd name="SHIELD3" x="0" y="-3.68" dx="1.5" dy="1.8" layer="1"/>
<smd name="SHIELD2" x="0" y="0" dx="1.5" dy="2.5" layer="1"/>
</package>
<package name="1X06-1MM">
<description>Works with part #579 (https://www.sparkfun.com/products/579). Commonly used on GPS modules EM408, EM406 and GP-635T. Also compatible with cable 9123 (https://www.sparkfun.com/products/9123) and cable 574 (https://www.sparkfun.com/products/574).</description>
<circle x="-3.6" y="1.2" radius="0.1047" width="0.4064" layer="51"/>
<wire x1="-2.54" y1="-1.651" x2="2.54" y2="-1.651" width="0.254" layer="21"/>
<wire x1="-4.318" y1="0.508" x2="-4.318" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.302" y1="1.905" x2="4.318" y2="1.905" width="0.254" layer="21"/>
<wire x1="4.318" y1="1.905" x2="4.318" y2="0.508" width="0.254" layer="21"/>
<wire x1="-4.318" y1="1.905" x2="-3.302" y2="1.905" width="0.254" layer="21"/>
<smd name="1" x="-2.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="2" x="-1.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="3" x="-0.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="4" x="0.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="5" x="1.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="6" x="2.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="P$1" x="-3.84" y="-0.955" dx="1.2" dy="1.8" layer="1"/>
<smd name="P$2" x="3.76" y="-0.955" dx="1.2" dy="1.8" layer="1"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="-2.54" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="USB-B-MICRO-SMD_V03">
<smd name="D+" x="2.725" y="0" dx="0.4" dy="1.45" layer="1" rot="R90"/>
<smd name="D-" x="2.725" y="0.65" dx="0.4" dy="1.45" layer="1" rot="R90"/>
<smd name="VBUS" x="2.725" y="1.3" dx="0.4" dy="1.45" layer="1" rot="R90"/>
<smd name="ID" x="2.725" y="-0.65" dx="0.4" dy="1.45" layer="1" rot="R90"/>
<smd name="GND" x="2.725" y="-1.3" dx="0.4" dy="1.45" layer="1" rot="R90"/>
<smd name="SHIELD1" x="0" y="3.685" dx="1.8" dy="1.5" layer="1" rot="R90" stop="no" cream="no"/>
<smd name="SHIELD3" x="0" y="0" dx="2.5" dy="1.5" layer="1" rot="R90" stop="no" cream="no"/>
<smd name="SHIELD2" x="0" y="-3.685" dx="1.8" dy="1.5" layer="1" rot="R90" stop="no" cream="no"/>
<wire x1="-2" y1="7" x2="-2" y2="0" width="0" layer="51"/>
</package>
<package name="1X01NS-KIT">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<circle x="0" y="0" radius="0.508" width="0" layer="29"/>
<circle x="0" y="0" radius="0.9398" width="0" layer="30"/>
</package>
<package name="AUDIO-JACK-KIT">
<description>Kit footprint for 1/8" audio jack.
Reduced openings in tStop, pins spread a tiny bit out to hold part on PCB during assembly</description>
<wire x1="7.5" y1="6" x2="7.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="6" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="-4.5" x2="-3.5" y2="-6" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="4.5" x2="-4.5" y2="3" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-3" x2="-4.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-4.5" x2="-3.5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="4.5" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="3" x2="-6.5" y2="-3" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="-3" x2="-4.5" y2="-3" width="0.2032" layer="51"/>
<wire x1="-6.5" y1="3" x2="-4.5" y2="3" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="6" x2="3.5" y2="6" width="0.2032" layer="21"/>
<wire x1="7.5" y1="6" x2="6.5" y2="6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="6" x2="-3.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-6" x2="3.5" y2="-6" width="0.2032" layer="21"/>
<wire x1="7.5" y1="-6" x2="6.5" y2="-6" width="0.2032" layer="21"/>
<pad name="SLEEVE" x="0" y="0" drill="1.3" diameter="2.1844" stop="no"/>
<pad name="RSH" x="5" y="2.5" drill="1.3" diameter="2.1844" stop="no"/>
<pad name="RING" x="5" y="5.1" drill="1.3" diameter="2.1844" stop="no"/>
<pad name="TSH" x="5" y="-2.5" drill="1.3" diameter="2.1844" stop="no"/>
<pad name="TIP" x="5" y="-5.1" drill="1.3" diameter="2.1844" stop="no"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
<hole x="0" y="5" drill="1.2"/>
<hole x="-2.5" y="5" drill="1.2"/>
<hole x="-2.5" y="-5" drill="1.2"/>
<hole x="0" y="-5" drill="1.2"/>
<hole x="5" y="0" drill="1.2"/>
<circle x="0" y="0" radius="0.6604" width="0" layer="29"/>
<circle x="5" y="5.1" radius="0.6604" width="0" layer="29"/>
<circle x="5" y="2.5" radius="0.6604" width="0" layer="29"/>
<circle x="5" y="-2.5" radius="0.6604" width="0" layer="29"/>
<circle x="5" y="-5.1" radius="0.6604" width="0" layer="29"/>
<circle x="0" y="0" radius="1.2192" width="0" layer="30"/>
<circle x="5" y="5.1" radius="1.2192" width="0" layer="30"/>
<circle x="5" y="-5.1" radius="1.2192" width="0" layer="30"/>
<circle x="5" y="-2.5" radius="1.2192" width="0" layer="30"/>
<circle x="5" y="2.5" radius="1.2192" width="0" layer="30"/>
</package>
<package name="1X04-SMD_LONG">
<wire x1="5.08" y1="1.25" x2="-5.08" y2="1.25" width="0.127" layer="51"/>
<wire x1="-5.08" y1="1.25" x2="-5.08" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-5.08" y1="-1.25" x2="-3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="5.08" y2="-1.25" width="0.127" layer="51"/>
<wire x1="5.08" y1="-1.25" x2="5.08" y2="1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="-1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-3.81" y2="-7.25" width="0.127" layer="51"/>
<smd name="4" x="3.81" y="5.5" dx="4" dy="1" layer="1" rot="R90"/>
<smd name="3" x="1.27" y="5.5" dx="4" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-1.27" y="5.5" dx="4" dy="1" layer="1" rot="R90"/>
<smd name="1" x="-3.81" y="5.5" dx="4" dy="1" layer="1" rot="R90"/>
<hole x="-2.54" y="0" drill="1.4"/>
<hole x="2.54" y="0" drill="1.4"/>
</package>
<package name="POWER_JACK_SMD_OVERPASTE_REDBOARD_0603">
<rectangle x1="5.7531" y1="-6.6675" x2="6.8707" y2="-6.6421" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-6.6421" x2="6.9215" y2="-6.6167" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="-6.6167" x2="6.9723" y2="-6.5913" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="-6.5913" x2="6.9723" y2="-6.5659" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="-6.5659" x2="6.9977" y2="-6.5405" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-6.5405" x2="7.0231" y2="-6.5151" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-6.5151" x2="7.0231" y2="-6.4897" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4897" x2="7.0231" y2="-6.4643" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4643" x2="7.0231" y2="-6.4389" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="-6.4643" x2="0.4445" y2="-6.4389" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4389" x2="7.0231" y2="-6.4135" layer="200" rot="R180"/>
<rectangle x1="-0.8001" y1="-6.4389" x2="0.5207" y2="-6.4135" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.4135" x2="7.0231" y2="-6.3881" layer="200" rot="R180"/>
<rectangle x1="-0.8255" y1="-6.4135" x2="0.5461" y2="-6.3881" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3881" x2="7.0231" y2="-6.3627" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-6.3881" x2="0.5715" y2="-6.3627" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3627" x2="7.0231" y2="-6.3373" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-6.3627" x2="0.5969" y2="-6.3373" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3373" x2="7.0231" y2="-6.3119" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.3373" x2="0.6223" y2="-6.3119" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3119" x2="7.0231" y2="-6.2865" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.3119" x2="0.6223" y2="-6.2865" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2865" x2="7.0231" y2="-6.2611" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.2865" x2="0.6223" y2="-6.2611" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2611" x2="7.0231" y2="-6.2357" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2611" x2="0.6477" y2="-6.2357" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2357" x2="7.0231" y2="-6.2103" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2357" x2="0.6477" y2="-6.2103" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2103" x2="7.0231" y2="-6.1849" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2103" x2="0.6477" y2="-6.1849" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1849" x2="7.0231" y2="-6.1595" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1849" x2="0.6477" y2="-6.1595" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1595" x2="7.0231" y2="-6.1341" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1595" x2="0.6477" y2="-6.1341" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1341" x2="7.0231" y2="-6.1087" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1341" x2="0.6477" y2="-6.1087" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1087" x2="7.0231" y2="-6.0833" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1087" x2="0.6477" y2="-6.0833" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0833" x2="7.0231" y2="-6.0579" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0833" x2="0.6477" y2="-6.0579" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0579" x2="7.0231" y2="-6.0325" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0579" x2="0.6477" y2="-6.0325" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0325" x2="7.0231" y2="-6.0071" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0325" x2="0.6477" y2="-6.0071" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0071" x2="7.0231" y2="-5.9817" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0071" x2="0.6477" y2="-5.9817" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9817" x2="7.0231" y2="-5.9563" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9817" x2="0.6731" y2="-5.9563" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9563" x2="7.0231" y2="-5.9309" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9563" x2="0.6731" y2="-5.9309" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9309" x2="7.0231" y2="-5.9055" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9309" x2="0.6731" y2="-5.9055" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9055" x2="7.0231" y2="-5.8801" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9055" x2="0.6731" y2="-5.8801" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.8801" x2="7.0231" y2="-5.8547" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8801" x2="0.6731" y2="-5.8547" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8547" x2="7.0231" y2="-5.8293" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8547" x2="0.6731" y2="-5.8293" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8293" x2="7.0231" y2="-5.8039" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8293" x2="0.6731" y2="-5.8039" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8039" x2="7.0231" y2="-5.7785" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8039" x2="0.6731" y2="-5.7785" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7785" x2="7.0231" y2="-5.7531" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.7785" x2="0.6731" y2="-5.7531" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7531" x2="7.0231" y2="-5.7277" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7531" x2="0.6731" y2="-5.7277" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7277" x2="7.0231" y2="-5.7023" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7277" x2="0.6731" y2="-5.7023" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7023" x2="7.0231" y2="-5.6769" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7023" x2="0.6731" y2="-5.6769" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6769" x2="7.0231" y2="-5.6515" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6769" x2="0.6731" y2="-5.6515" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6515" x2="7.0231" y2="-5.6261" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6515" x2="0.6731" y2="-5.6261" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6261" x2="7.0231" y2="-5.6007" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6261" x2="0.6731" y2="-5.6007" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6007" x2="7.0231" y2="-5.5753" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6007" x2="0.6731" y2="-5.5753" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5753" x2="7.0231" y2="-5.5499" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5753" x2="0.6731" y2="-5.5499" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5499" x2="7.0231" y2="-5.5245" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5499" x2="0.6731" y2="-5.5245" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5245" x2="7.0231" y2="-5.4991" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5245" x2="0.6731" y2="-5.4991" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4991" x2="7.0231" y2="-5.4737" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4991" x2="0.6731" y2="-5.4737" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4737" x2="7.0231" y2="-5.4483" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4737" x2="0.6731" y2="-5.4483" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4483" x2="7.0231" y2="-5.4229" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4483" x2="0.6731" y2="-5.4229" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4229" x2="7.0231" y2="-5.3975" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4229" x2="0.6731" y2="-5.3975" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3975" x2="7.0231" y2="-5.3721" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3975" x2="0.6731" y2="-5.3721" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3721" x2="7.0231" y2="-5.3467" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3721" x2="0.6731" y2="-5.3467" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3467" x2="7.0231" y2="-5.3213" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3467" x2="0.6731" y2="-5.3213" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3213" x2="7.0231" y2="-5.2959" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3213" x2="0.6731" y2="-5.2959" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2959" x2="7.0231" y2="-5.2705" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2959" x2="0.6731" y2="-5.2705" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2705" x2="7.0231" y2="-5.2451" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2705" x2="0.6731" y2="-5.2451" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2451" x2="7.0231" y2="-5.2197" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2451" x2="0.6731" y2="-5.2197" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2197" x2="7.0231" y2="-5.1943" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.2197" x2="0.6731" y2="-5.1943" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1943" x2="7.0231" y2="-5.1689" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1943" x2="0.6731" y2="-5.1689" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1689" x2="7.0231" y2="-5.1435" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1689" x2="0.6731" y2="-5.1435" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1435" x2="7.0231" y2="-5.1181" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1435" x2="0.6731" y2="-5.1181" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1181" x2="7.0231" y2="-5.0927" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1181" x2="0.6731" y2="-5.0927" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0927" x2="7.0231" y2="-5.0673" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0927" x2="0.6731" y2="-5.0673" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0673" x2="7.0231" y2="-5.0419" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0673" x2="0.6731" y2="-5.0419" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0419" x2="7.0231" y2="-5.0165" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0419" x2="0.6731" y2="-5.0165" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0165" x2="6.9977" y2="-4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0165" x2="0.6731" y2="-4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-4.9911" x2="0.6731" y2="-4.9657" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-4.9657" x2="0.5207" y2="-4.9403" layer="200" rot="R180"/>
<rectangle x1="4.3815" y1="-4.7879" x2="7.0739" y2="-4.7625" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-4.7879" x2="1.3335" y2="-4.7625" layer="200" rot="R180"/>
<rectangle x1="-4.4069" y1="-4.7625" x2="7.0993" y2="-4.7371" layer="200" rot="R180"/>
<rectangle x1="-4.4577" y1="-4.7371" x2="7.0993" y2="-4.7117" layer="200" rot="R180"/>
<rectangle x1="-4.5085" y1="-4.7117" x2="7.0993" y2="-4.6863" layer="200" rot="R180"/>
<rectangle x1="-4.5593" y1="-4.6863" x2="7.0993" y2="-4.6609" layer="200" rot="R180"/>
<rectangle x1="-4.5847" y1="-4.6609" x2="7.0993" y2="-4.6355" layer="200" rot="R180"/>
<rectangle x1="-4.6355" y1="-4.6355" x2="7.0993" y2="-4.6101" layer="200" rot="R180"/>
<rectangle x1="-4.6609" y1="-4.6101" x2="7.0993" y2="-4.5847" layer="200" rot="R180"/>
<rectangle x1="-4.6863" y1="-4.5847" x2="7.0993" y2="-4.5593" layer="200" rot="R180"/>
<rectangle x1="-4.7117" y1="-4.5593" x2="7.0739" y2="-4.5339" layer="200" rot="R180"/>
<rectangle x1="-4.7371" y1="-4.5339" x2="7.0739" y2="-4.5085" layer="200" rot="R180"/>
<rectangle x1="-4.7625" y1="-4.5085" x2="7.0739" y2="-4.4831" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="-4.4831" x2="7.0739" y2="-4.4577" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="-4.4577" x2="7.0739" y2="-4.4323" layer="200" rot="R180"/>
<rectangle x1="-4.8133" y1="-4.4323" x2="7.5057" y2="-4.4069" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="-4.4069" x2="9.7155" y2="-4.3815" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="-4.3815" x2="9.7663" y2="-4.3561" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="-4.3561" x2="9.7917" y2="-4.3307" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="-4.3307" x2="9.8171" y2="-4.3053" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="-4.3053" x2="9.8425" y2="-4.2799" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="-4.2799" x2="9.8679" y2="-4.2545" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2545" x2="9.8933" y2="-4.2291" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2291" x2="9.8933" y2="-4.2037" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2037" x2="9.8933" y2="-4.1783" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1783" x2="9.8933" y2="-4.1529" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1529" x2="9.8933" y2="-4.1275" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1275" x2="9.8933" y2="-4.1021" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.1021" x2="9.8933" y2="-4.0767" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0767" x2="9.8933" y2="-4.0513" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0513" x2="9.8933" y2="-4.0259" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0259" x2="9.8933" y2="-4.0005" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0005" x2="9.8933" y2="-3.9751" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9751" x2="9.8933" y2="-3.9497" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9497" x2="9.8933" y2="-3.9243" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9243" x2="9.8933" y2="-3.8989" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.8989" x2="9.8933" y2="-3.8735" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.8735" x2="9.8933" y2="-3.8481" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.8481" x2="9.8933" y2="-3.8227" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.8227" x2="9.8933" y2="-3.7973" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7973" x2="9.8933" y2="-3.7719" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7719" x2="9.8933" y2="-3.7465" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7465" x2="9.8933" y2="-3.7211" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7211" x2="9.8933" y2="-3.6957" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6957" x2="9.8933" y2="-3.6703" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6703" x2="9.8933" y2="-3.6449" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6449" x2="9.8933" y2="-3.6195" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6195" x2="9.8933" y2="-3.5941" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5941" x2="9.8933" y2="-3.5687" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5687" x2="9.8933" y2="-3.5433" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5433" x2="9.8933" y2="-3.5179" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5179" x2="9.8933" y2="-3.4925" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4925" x2="9.8933" y2="-3.4671" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4671" x2="9.8933" y2="-3.4417" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4417" x2="9.8933" y2="-3.4163" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4163" x2="9.8933" y2="-3.3909" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3909" x2="9.8933" y2="-3.3655" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3655" x2="9.8933" y2="-3.3401" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3401" x2="9.8933" y2="-3.3147" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3147" x2="9.8933" y2="-3.2893" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2893" x2="9.8933" y2="-3.2639" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2639" x2="9.8933" y2="-3.2385" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2385" x2="9.8933" y2="-3.2131" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2131" x2="9.8933" y2="-3.1877" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1877" x2="9.8933" y2="-3.1623" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1623" x2="9.8933" y2="-3.1369" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1369" x2="9.8933" y2="-3.1115" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1115" x2="9.8933" y2="-3.0861" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0861" x2="9.8933" y2="-3.0607" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0607" x2="9.8933" y2="-3.0353" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0353" x2="9.8933" y2="-3.0099" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0099" x2="9.8933" y2="-2.9845" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9845" x2="9.8933" y2="-2.9591" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9591" x2="9.8933" y2="-2.9337" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9337" x2="9.8933" y2="-2.9083" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9083" x2="9.8933" y2="-2.8829" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8829" x2="9.8933" y2="-2.8575" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8575" x2="9.8933" y2="-2.8321" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8321" x2="9.8933" y2="-2.8067" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8067" x2="9.8933" y2="-2.7813" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7813" x2="9.8933" y2="-2.7559" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7559" x2="9.8933" y2="-2.7305" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7305" x2="9.8933" y2="-2.7051" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7051" x2="9.8933" y2="-2.6797" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6797" x2="9.8933" y2="-2.6543" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6543" x2="9.8933" y2="-2.6289" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6289" x2="9.8933" y2="-2.6035" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6035" x2="9.8933" y2="-2.5781" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5781" x2="9.8933" y2="-2.5527" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5527" x2="9.8933" y2="-2.5273" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5273" x2="9.8933" y2="-2.5019" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5019" x2="9.8933" y2="-2.4765" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4765" x2="9.8933" y2="-2.4511" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4511" x2="9.8933" y2="-2.4257" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4257" x2="9.8933" y2="-2.4003" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4003" x2="9.8933" y2="-2.3749" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3749" x2="9.8933" y2="-2.3495" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3495" x2="9.8933" y2="-2.3241" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3241" x2="9.8933" y2="-2.2987" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2987" x2="9.8933" y2="-2.2733" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2733" x2="9.8933" y2="-2.2479" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2479" x2="9.8933" y2="-2.2225" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2225" x2="9.8933" y2="-2.1971" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1971" x2="9.8933" y2="-2.1717" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1717" x2="9.8933" y2="-2.1463" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1463" x2="9.8933" y2="-2.1209" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1209" x2="9.8933" y2="-2.0955" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0955" x2="9.8933" y2="-2.0701" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0701" x2="9.8933" y2="-2.0447" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0447" x2="9.8933" y2="-2.0193" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0193" x2="9.8933" y2="-1.9939" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9939" x2="9.8933" y2="-1.9685" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9685" x2="9.8933" y2="-1.9431" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9431" x2="9.8933" y2="-1.9177" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9177" x2="9.8933" y2="-1.8923" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8923" x2="9.8933" y2="-1.8669" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8669" x2="9.8933" y2="-1.8415" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8415" x2="9.8933" y2="-1.8161" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8161" x2="9.8933" y2="-1.7907" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7907" x2="9.8933" y2="-1.7653" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7653" x2="9.8933" y2="-1.7399" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7399" x2="9.8933" y2="-1.7145" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7145" x2="9.8933" y2="-1.6891" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6891" x2="9.8933" y2="-1.6637" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6637" x2="9.8933" y2="-1.6383" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6383" x2="9.8679" y2="-1.6129" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6129" x2="8.8773" y2="-1.5875" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5875" x2="8.8773" y2="-1.5621" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5621" x2="8.8773" y2="-1.5367" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5367" x2="8.8773" y2="-1.5113" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5113" x2="8.8773" y2="-1.4859" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4859" x2="8.8773" y2="-1.4605" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4605" x2="8.8773" y2="-1.4351" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4351" x2="8.8773" y2="-1.4097" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4097" x2="8.8773" y2="-1.3843" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3843" x2="8.8773" y2="-1.3589" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3589" x2="8.8773" y2="-1.3335" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3335" x2="8.8773" y2="-1.3081" layer="200" rot="R180"/>
<rectangle x1="4.8133" y1="-1.3081" x2="8.8773" y2="-1.2827" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3081" x2="4.3815" y2="-1.2827" layer="200" rot="R180"/>
<rectangle x1="4.9149" y1="-1.2827" x2="8.8773" y2="-1.2573" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2827" x2="4.2799" y2="-1.2573" layer="200" rot="R180"/>
<rectangle x1="5.0165" y1="-1.2573" x2="8.8773" y2="-1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2573" x2="4.1783" y2="-1.2319" layer="200" rot="R180"/>
<rectangle x1="5.0927" y1="-1.2319" x2="8.8773" y2="-1.2065" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2319" x2="4.1275" y2="-1.2065" layer="200" rot="R180"/>
<rectangle x1="5.1435" y1="-1.2065" x2="8.8773" y2="-1.1811" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2065" x2="4.0513" y2="-1.1811" layer="200" rot="R180"/>
<rectangle x1="5.1943" y1="-1.1811" x2="8.8773" y2="-1.1557" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1811" x2="4.0005" y2="-1.1557" layer="200" rot="R180"/>
<rectangle x1="5.2197" y1="-1.1557" x2="8.8773" y2="-1.1303" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1557" x2="3.9497" y2="-1.1303" layer="200" rot="R180"/>
<rectangle x1="5.2705" y1="-1.1303" x2="8.8773" y2="-1.1049" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1303" x2="3.8989" y2="-1.1049" layer="200" rot="R180"/>
<rectangle x1="5.2959" y1="-1.1049" x2="8.8773" y2="-1.0795" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1049" x2="3.8735" y2="-1.0795" layer="200" rot="R180"/>
<rectangle x1="5.3467" y1="-1.0795" x2="8.8773" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="0.1143" y1="-1.0795" x2="3.8227" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0795" x2="-0.1143" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="5.3721" y1="-1.0541" x2="8.8773" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="0.2413" y1="-1.0541" x2="3.7973" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0541" x2="-0.2413" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="-1.0287" x2="8.8773" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="0.3429" y1="-1.0287" x2="3.7465" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0287" x2="-0.3429" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="5.4229" y1="-1.0033" x2="8.8773" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="0.4191" y1="-1.0033" x2="3.7211" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0033" x2="-0.4191" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-0.9779" x2="8.8773" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="0.4699" y1="-0.9779" x2="3.6957" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9779" x2="-0.4699" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-0.9525" x2="8.8773" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="0.5207" y1="-0.9525" x2="3.6703" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9525" x2="-0.5207" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="-0.9271" x2="8.8773" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="0.5715" y1="-0.9271" x2="3.6449" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9271" x2="-0.5715" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="-0.9017" x2="8.8773" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="0.6223" y1="-0.9017" x2="3.6195" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9017" x2="-0.6223" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="-0.8763" x2="8.8773" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="0.6477" y1="-0.8763" x2="3.5941" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8763" x2="-0.6477" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="-0.8509" x2="8.8773" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="0.6985" y1="-0.8509" x2="3.5687" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8509" x2="-0.6985" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-0.8255" x2="8.8773" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="0.7239" y1="-0.8255" x2="3.5433" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8255" x2="-0.7239" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-0.8001" x2="8.8773" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="0.7493" y1="-0.8001" x2="3.5179" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8001" x2="-0.7493" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="-0.7747" x2="8.8773" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="-0.7747" x2="3.4925" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7747" x2="-0.7747" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="-0.7493" x2="8.8773" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="0.8255" y1="-0.7493" x2="3.4925" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7493" x2="-0.8001" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="-0.7239" x2="8.8773" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="0.8509" y1="-0.7239" x2="3.4671" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7239" x2="-0.8255" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="-0.6985" x2="8.8773" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="-0.6985" x2="3.4671" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6985" x2="-0.8509" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="-0.6731" x2="8.8773" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="-0.6731" x2="3.4417" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6731" x2="-0.8763" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="-0.6477" x2="8.8773" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="-0.6477" x2="3.4417" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6477" x2="-0.9017" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="-0.6223" x2="8.8773" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="-0.6223" x2="3.4163" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6223" x2="-0.9017" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="-0.5969" x2="8.8773" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="-0.5969" x2="3.4163" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5969" x2="-0.9271" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="-0.5715" x2="8.8773" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="-0.5715" x2="3.3909" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5715" x2="-0.9525" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="-0.5461" x2="8.8773" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="-0.5461" x2="3.3655" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5461" x2="-0.9525" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="-0.5207" x2="8.8773" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="-0.5207" x2="3.3655" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5207" x2="-0.9779" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4953" x2="8.8773" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="-0.4953" x2="3.3401" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4953" x2="-0.9779" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4699" x2="8.8773" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="-0.4699" x2="3.3401" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4699" x2="-1.0033" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4445" x2="8.8773" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="-0.4445" x2="3.3401" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4445" x2="-1.0033" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.4191" x2="8.8773" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.4191" x2="3.3147" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4191" x2="-1.0033" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3937" x2="8.8773" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.3937" x2="3.3147" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3937" x2="-1.0033" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3683" x2="8.8773" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.3683" x2="3.3147" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3683" x2="-1.0287" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3429" x2="8.8773" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.3429" x2="3.3147" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3429" x2="-1.0287" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.3175" x2="8.8773" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.3175" x2="3.3147" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3175" x2="-1.0287" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2921" x2="8.8773" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2921" x2="3.2893" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2921" x2="-1.0287" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2667" x2="8.8773" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2667" x2="3.2893" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2667" x2="-1.0287" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2413" x2="8.8773" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2413" x2="3.2893" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2413" x2="-1.0287" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2159" x2="8.8773" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.2159" x2="3.2893" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2159" x2="-1.0541" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1905" x2="8.8773" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1905" x2="3.2893" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1905" x2="-1.0541" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1651" x2="8.8773" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1651" x2="3.2893" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1651" x2="-1.0541" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1397" x2="8.8773" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1397" x2="3.2893" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1397" x2="-1.0541" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1143" x2="8.8773" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1143" x2="3.2893" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1143" x2="-1.0541" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0889" x2="8.8773" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0889" x2="3.2893" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0889" x2="-1.0541" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0635" x2="8.8773" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0635" x2="3.2893" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0635" x2="-1.0541" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0381" x2="8.8773" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0381" x2="3.2893" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0381" x2="-1.0541" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0127" x2="8.8773" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0127" x2="3.2893" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0127" x2="-1.0541" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0127" x2="8.8773" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0127" x2="3.2893" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0127" x2="-1.0541" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0381" x2="8.8773" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0381" x2="3.2893" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0381" x2="-1.0541" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0635" x2="8.8773" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0635" x2="3.2893" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0635" x2="-1.0541" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0889" x2="8.8773" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0889" x2="3.2893" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0889" x2="-1.0541" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1143" x2="8.8773" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.1143" x2="3.2893" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1143" x2="-1.0541" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1397" x2="8.8773" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1397" x2="3.2893" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1397" x2="-1.0541" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1651" x2="8.8773" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1651" x2="3.3147" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1651" x2="-1.0541" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1905" x2="8.8773" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1905" x2="3.3147" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1905" x2="-1.0541" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.2159" x2="8.9027" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.2159" x2="3.3147" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2159" x2="-1.0541" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2413" x2="8.9027" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.2413" x2="3.3147" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2413" x2="-1.0541" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2667" x2="8.9027" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.2667" x2="3.3401" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2667" x2="-1.0541" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2921" x2="8.9027" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.2921" x2="3.3401" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2921" x2="-1.0287" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="0.3175" x2="8.9027" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.3175" x2="3.3401" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3175" x2="-1.0287" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="0.3429" x2="8.9027" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.3429" x2="3.3655" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3429" x2="-1.0287" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="0.3683" x2="8.9027" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.3683" x2="3.3909" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3683" x2="-1.0287" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="0.3937" x2="8.9027" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.3937" x2="3.3655" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3937" x2="-1.0287" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4191" x2="8.9027" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.4191" x2="3.3909" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4191" x2="-1.0033" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4445" x2="8.9027" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="0.4445" x2="3.4163" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4445" x2="-1.0033" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4699" x2="8.9027" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="0.4699" x2="3.4163" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4699" x2="-1.0033" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="0.4953" x2="8.9027" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="0.4953" x2="3.4163" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4953" x2="-0.9779" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="0.5207" x2="8.9027" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="0.5207" x2="3.4417" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5207" x2="-0.9779" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="0.5461" x2="8.9027" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="0.5461" x2="3.4417" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5461" x2="-0.9525" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="0.5715" x2="8.9027" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="0.5715" x2="3.4671" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5715" x2="-0.9525" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="0.5969" x2="8.9027" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="0.5969" x2="3.4671" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5969" x2="-0.9271" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="0.6223" x2="8.9027" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="0.6223" x2="3.4925" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6223" x2="-0.9271" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="0.6477" x2="8.9027" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="0.6477" x2="3.4925" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6477" x2="-0.9017" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="0.6731" x2="8.9027" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="0.6731" x2="3.5179" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6731" x2="-0.8763" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="0.6985" x2="8.9027" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="0.6985" x2="3.5433" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6985" x2="-0.8763" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7239" x2="8.9027" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="0.8509" y1="0.7239" x2="3.5433" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7239" x2="-0.8509" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7493" x2="8.9027" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="0.8255" y1="0.7493" x2="3.5687" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7493" x2="-0.8255" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7747" x2="8.9027" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="0.7747" x2="3.5941" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7747" x2="-0.8001" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="0.8001" x2="8.9027" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="0.8001" x2="3.6195" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8001" x2="-0.7747" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="0.8255" x2="8.9027" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="0.7747" y1="0.8255" x2="3.6195" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8255" x2="-0.7493" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="0.8509" x2="8.9027" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="0.7493" y1="0.8509" x2="3.6449" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8509" x2="-0.7239" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="0.8763" x2="8.9027" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="0.7239" y1="0.8763" x2="3.6703" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8763" x2="-0.6731" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="5.4229" y1="0.9017" x2="8.9027" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="0.6731" y1="0.9017" x2="3.6957" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9017" x2="-0.6477" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="0.9271" x2="8.9027" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="0.6477" y1="0.9271" x2="3.7211" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9271" x2="-0.5969" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="0.9525" x2="8.9027" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="0.5969" y1="0.9525" x2="3.7465" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9525" x2="-0.5461" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="5.3213" y1="0.9779" x2="8.9027" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="0.5715" y1="0.9779" x2="3.7973" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9779" x2="-0.4953" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="5.2959" y1="1.0033" x2="8.9027" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="0.5207" y1="1.0033" x2="3.8227" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0033" x2="-0.4191" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="5.2705" y1="1.0287" x2="8.9027" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="0.4445" y1="1.0287" x2="3.8481" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0287" x2="-0.3429" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="5.2197" y1="1.0541" x2="8.9027" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="0.3937" y1="1.0541" x2="3.8989" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0541" x2="-0.2413" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="5.1689" y1="1.0795" x2="8.9027" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="0.2921" y1="1.0795" x2="3.9497" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0795" x2="-0.0889" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="5.1181" y1="1.1049" x2="8.9027" y2="1.1303" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1049" x2="4.0005" y2="1.1303" layer="200" rot="R180"/>
<rectangle x1="5.0673" y1="1.1303" x2="8.9027" y2="1.1557" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1303" x2="4.0513" y2="1.1557" layer="200" rot="R180"/>
<rectangle x1="5.0165" y1="1.1557" x2="8.9027" y2="1.1811" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1557" x2="4.1275" y2="1.1811" layer="200" rot="R180"/>
<rectangle x1="4.9149" y1="1.1811" x2="8.9027" y2="1.2065" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1811" x2="4.2037" y2="1.2065" layer="200" rot="R180"/>
<rectangle x1="4.7625" y1="1.2065" x2="8.9027" y2="1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2065" x2="4.3307" y2="1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2319" x2="8.9027" y2="1.2573" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2573" x2="8.9027" y2="1.2827" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2827" x2="8.9027" y2="1.3081" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3081" x2="8.9027" y2="1.3335" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3335" x2="8.9027" y2="1.3589" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3589" x2="8.9027" y2="1.3843" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3843" x2="8.9027" y2="1.4097" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4097" x2="8.9027" y2="1.4351" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4351" x2="8.9027" y2="1.4605" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4605" x2="8.9027" y2="1.4859" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4859" x2="8.9027" y2="1.5113" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5113" x2="8.9027" y2="1.5367" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5367" x2="8.9027" y2="1.5621" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5621" x2="8.9027" y2="1.5875" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5875" x2="8.9027" y2="1.6129" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6129" x2="8.9027" y2="1.6383" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6383" x2="8.9027" y2="1.6637" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6637" x2="8.9027" y2="1.6891" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6891" x2="8.9027" y2="1.7145" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7145" x2="8.9027" y2="1.7399" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7399" x2="8.9027" y2="1.7653" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7653" x2="8.9027" y2="1.7907" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7907" x2="8.9027" y2="1.8161" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8161" x2="8.9027" y2="1.8415" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8415" x2="8.9027" y2="1.8669" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8669" x2="8.9027" y2="1.8923" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8923" x2="8.9027" y2="1.9177" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9177" x2="8.9027" y2="1.9431" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9431" x2="8.9027" y2="1.9685" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9685" x2="8.9027" y2="1.9939" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9939" x2="8.9027" y2="2.0193" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="2.0193" x2="8.9027" y2="2.0447" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0447" x2="8.9027" y2="2.0701" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0701" x2="8.9027" y2="2.0955" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0955" x2="8.9027" y2="2.1209" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1209" x2="8.9027" y2="2.1463" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1463" x2="8.9281" y2="2.1717" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1717" x2="8.9281" y2="2.1971" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1971" x2="8.9281" y2="2.2225" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2225" x2="8.9281" y2="2.2479" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2479" x2="8.9281" y2="2.2733" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2733" x2="8.9281" y2="2.2987" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2987" x2="8.9281" y2="2.3241" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3241" x2="8.9281" y2="2.3495" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3495" x2="8.9281" y2="2.3749" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3749" x2="8.9281" y2="2.4003" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4003" x2="8.9281" y2="2.4257" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4257" x2="8.9281" y2="2.4511" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4511" x2="8.9281" y2="2.4765" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4765" x2="8.9281" y2="2.5019" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5019" x2="8.9281" y2="2.5273" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5273" x2="8.9281" y2="2.5527" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5527" x2="8.9281" y2="2.5781" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5781" x2="8.9281" y2="2.6035" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6035" x2="8.9281" y2="2.6289" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6289" x2="8.9281" y2="2.6543" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6543" x2="8.9281" y2="2.6797" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6797" x2="8.9281" y2="2.7051" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7051" x2="8.9281" y2="2.7305" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7305" x2="8.9281" y2="2.7559" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7559" x2="8.9281" y2="2.7813" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7813" x2="8.9281" y2="2.8067" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8067" x2="8.9281" y2="2.8321" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8321" x2="8.9281" y2="2.8575" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8575" x2="8.9281" y2="2.8829" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8829" x2="8.9281" y2="2.9083" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9083" x2="8.9281" y2="2.9337" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9337" x2="8.9281" y2="2.9591" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9591" x2="8.9281" y2="2.9845" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9845" x2="8.9281" y2="3.0099" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0099" x2="8.9281" y2="3.0353" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0353" x2="8.9281" y2="3.0607" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0607" x2="8.9281" y2="3.0861" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0861" x2="8.9281" y2="3.1115" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1115" x2="8.9281" y2="3.1369" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1369" x2="8.9281" y2="3.1623" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1623" x2="8.9281" y2="3.1877" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1877" x2="8.9281" y2="3.2131" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2131" x2="8.9281" y2="3.2385" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2385" x2="8.9281" y2="3.2639" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2639" x2="8.9281" y2="3.2893" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2893" x2="8.9281" y2="3.3147" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3147" x2="8.9281" y2="3.3401" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3401" x2="8.9281" y2="3.3655" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3655" x2="8.9281" y2="3.3909" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3909" x2="8.9281" y2="3.4163" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4163" x2="8.9281" y2="3.4417" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4417" x2="8.9281" y2="3.4671" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4671" x2="8.9281" y2="3.4925" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4925" x2="8.9281" y2="3.5179" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5179" x2="8.9281" y2="3.5433" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5433" x2="8.9281" y2="3.5687" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5687" x2="8.9281" y2="3.5941" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5941" x2="8.9281" y2="3.6195" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6195" x2="8.9281" y2="3.6449" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6449" x2="8.9281" y2="3.6703" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6703" x2="8.9281" y2="3.6957" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6957" x2="8.9281" y2="3.7211" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7211" x2="8.9281" y2="3.7465" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7465" x2="8.9281" y2="3.7719" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7719" x2="8.9281" y2="3.7973" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7973" x2="8.9281" y2="3.8227" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8227" x2="8.9281" y2="3.8481" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8481" x2="8.9281" y2="3.8735" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8735" x2="8.9281" y2="3.8989" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8989" x2="8.9281" y2="3.9243" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.9243" x2="8.9281" y2="3.9497" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="3.9497" x2="8.9281" y2="3.9751" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="3.9751" x2="8.9281" y2="4.0005" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0005" x2="8.9281" y2="4.0259" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0259" x2="8.9281" y2="4.0513" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0513" x2="8.9281" y2="4.0767" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0767" x2="8.9281" y2="4.1021" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.1021" x2="8.9281" y2="4.1275" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.1275" x2="8.9281" y2="4.1529" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="4.1529" x2="8.9281" y2="4.1783" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="4.1783" x2="8.9281" y2="4.2037" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="4.2037" x2="8.9027" y2="4.2291" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="4.2291" x2="8.9027" y2="4.2545" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="4.2545" x2="8.8773" y2="4.2799" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="4.2799" x2="8.8773" y2="4.3053" layer="200" rot="R180"/>
<rectangle x1="-4.8133" y1="4.3053" x2="8.8519" y2="4.3307" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="4.3307" x2="8.8265" y2="4.3561" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="4.3561" x2="8.8011" y2="4.3815" layer="200" rot="R180"/>
<rectangle x1="-4.7625" y1="4.3815" x2="8.7757" y2="4.4069" layer="200" rot="R180"/>
<rectangle x1="-4.7371" y1="4.4069" x2="8.7249" y2="4.4323" layer="200" rot="R180"/>
<rectangle x1="-4.7117" y1="4.4323" x2="8.6741" y2="4.4577" layer="200" rot="R180"/>
<rectangle x1="-4.6863" y1="4.4577" x2="8.6233" y2="4.4831" layer="200" rot="R180"/>
<rectangle x1="-4.6609" y1="4.4831" x2="7.1247" y2="4.5085" layer="200" rot="R180"/>
<rectangle x1="-4.6101" y1="4.5085" x2="7.1247" y2="4.5339" layer="200" rot="R180"/>
<rectangle x1="-4.5847" y1="4.5339" x2="7.1247" y2="4.5593" layer="200" rot="R180"/>
<rectangle x1="-4.5339" y1="4.5593" x2="7.1247" y2="4.5847" layer="200" rot="R180"/>
<rectangle x1="-4.4577" y1="4.5847" x2="7.1247" y2="4.6101" layer="200" rot="R180"/>
<rectangle x1="-4.3815" y1="4.6101" x2="6.9215" y2="4.6355" layer="200" rot="R180"/>
<rectangle x1="-3.0607" y1="4.6355" x2="-1.6637" y2="4.6609" layer="200" rot="R180"/>
<rectangle x1="-3.8989" y1="4.6355" x2="-3.3655" y2="4.6609" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="4.8133" x2="7.0739" y2="4.8387" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8387" x2="7.0993" y2="4.8641" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8641" x2="7.0993" y2="4.8895" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8895" x2="7.0993" y2="4.9149" layer="200" rot="R180"/>
<rectangle x1="-0.1651" y1="4.8895" x2="0.7239" y2="4.9149" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9149" x2="7.0993" y2="4.9403" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9149" x2="0.7239" y2="4.9403" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9403" x2="7.0993" y2="4.9657" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9403" x2="0.7239" y2="4.9657" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9657" x2="7.0993" y2="4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9657" x2="0.7239" y2="4.9911" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9911" x2="7.0993" y2="5.0165" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9911" x2="0.7239" y2="5.0165" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0165" x2="7.0993" y2="5.0419" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0165" x2="0.7239" y2="5.0419" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0419" x2="7.0993" y2="5.0673" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0419" x2="0.7239" y2="5.0673" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0673" x2="7.0993" y2="5.0927" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0673" x2="0.7239" y2="5.0927" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0927" x2="7.0993" y2="5.1181" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0927" x2="0.7239" y2="5.1181" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1181" x2="7.0993" y2="5.1435" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1181" x2="0.7239" y2="5.1435" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1435" x2="7.0993" y2="5.1689" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1435" x2="0.7239" y2="5.1689" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1689" x2="7.0993" y2="5.1943" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1689" x2="0.7239" y2="5.1943" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1943" x2="7.0993" y2="5.2197" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1943" x2="0.7239" y2="5.2197" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2197" x2="7.0993" y2="5.2451" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2197" x2="0.7239" y2="5.2451" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2451" x2="7.0993" y2="5.2705" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2451" x2="0.7239" y2="5.2705" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2705" x2="7.0993" y2="5.2959" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2705" x2="0.7239" y2="5.2959" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2959" x2="7.0739" y2="5.3213" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2959" x2="0.7239" y2="5.3213" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3213" x2="7.0739" y2="5.3467" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3213" x2="0.7239" y2="5.3467" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3467" x2="7.0739" y2="5.3721" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3467" x2="0.7239" y2="5.3721" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3721" x2="7.0739" y2="5.3975" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3721" x2="0.7239" y2="5.3975" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3975" x2="7.0739" y2="5.4229" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3975" x2="0.7239" y2="5.4229" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4229" x2="7.0739" y2="5.4483" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4229" x2="0.7239" y2="5.4483" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4483" x2="7.0739" y2="5.4737" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4483" x2="0.7239" y2="5.4737" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4737" x2="7.0739" y2="5.4991" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4737" x2="0.7239" y2="5.4991" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4991" x2="7.0739" y2="5.5245" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4991" x2="0.7239" y2="5.5245" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5245" x2="7.0739" y2="5.5499" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5245" x2="0.7239" y2="5.5499" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5499" x2="7.0739" y2="5.5753" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5499" x2="0.7239" y2="5.5753" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5753" x2="7.0739" y2="5.6007" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5753" x2="0.7239" y2="5.6007" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6007" x2="7.0739" y2="5.6261" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6007" x2="0.7239" y2="5.6261" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6261" x2="7.0739" y2="5.6515" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6261" x2="0.7239" y2="5.6515" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6515" x2="7.0739" y2="5.6769" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6515" x2="0.7239" y2="5.6769" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6769" x2="7.0739" y2="5.7023" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6769" x2="0.7239" y2="5.7023" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7023" x2="7.0739" y2="5.7277" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7023" x2="0.7239" y2="5.7277" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7277" x2="7.0739" y2="5.7531" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7277" x2="0.7239" y2="5.7531" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7531" x2="7.0739" y2="5.7785" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7531" x2="0.7239" y2="5.7785" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7785" x2="7.0739" y2="5.8039" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7785" x2="0.7239" y2="5.8039" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8039" x2="7.0739" y2="5.8293" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8039" x2="0.7239" y2="5.8293" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8293" x2="7.0739" y2="5.8547" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8293" x2="0.7239" y2="5.8547" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8547" x2="7.0739" y2="5.8801" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8547" x2="0.7239" y2="5.8801" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8801" x2="7.0739" y2="5.9055" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8801" x2="0.7239" y2="5.9055" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9055" x2="7.0739" y2="5.9309" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9055" x2="0.6985" y2="5.9309" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9309" x2="7.0739" y2="5.9563" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9309" x2="0.6985" y2="5.9563" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9563" x2="7.0739" y2="5.9817" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9563" x2="0.6985" y2="5.9817" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9817" x2="7.0739" y2="6.0071" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9817" x2="0.6985" y2="6.0071" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0071" x2="7.0739" y2="6.0325" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0071" x2="0.6985" y2="6.0325" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0325" x2="7.0739" y2="6.0579" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0325" x2="0.6985" y2="6.0579" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0579" x2="7.0739" y2="6.0833" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0579" x2="0.6985" y2="6.0833" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0833" x2="7.0739" y2="6.1087" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0833" x2="0.6985" y2="6.1087" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1087" x2="7.0739" y2="6.1341" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1087" x2="0.6985" y2="6.1341" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1341" x2="7.0739" y2="6.1595" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1341" x2="0.6985" y2="6.1595" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1595" x2="7.0739" y2="6.1849" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1595" x2="0.6985" y2="6.1849" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.1849" x2="7.0739" y2="6.2103" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1849" x2="0.6985" y2="6.2103" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2103" x2="7.0485" y2="6.2357" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2103" x2="0.6985" y2="6.2357" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2357" x2="7.0485" y2="6.2611" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2357" x2="0.6985" y2="6.2611" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2611" x2="7.0485" y2="6.2865" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2611" x2="0.6985" y2="6.2865" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="6.2865" x2="7.0231" y2="6.3119" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="6.2865" x2="0.6731" y2="6.3119" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="6.3119" x2="7.0231" y2="6.3373" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="6.3119" x2="0.6731" y2="6.3373" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="6.3373" x2="6.9977" y2="6.3627" layer="200" rot="R180"/>
<rectangle x1="-0.7239" y1="6.3373" x2="0.6477" y2="6.3627" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="6.3627" x2="6.9723" y2="6.3881" layer="200" rot="R180"/>
<rectangle x1="-0.6985" y1="6.3627" x2="0.6223" y2="6.3881" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="6.3881" x2="6.9215" y2="6.4135" layer="200" rot="R180"/>
<rectangle x1="-0.6223" y1="6.3881" x2="0.5461" y2="6.4135" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="6.4135" x2="6.8707" y2="6.4389" layer="200" rot="R180"/>
<text x="9.906" y="-6.8072" size="0.0508" layer="200" font="vector" rot="MR0">//kentro/work/Production/AOI Parts/Tyler/Breadboard power 5v/barreljack.bmp</text>
<wire x1="-5" y1="4.5" x2="-5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-5" y1="4.5" x2="-3.5" y2="4.5" width="0.2032" layer="51"/>
<wire x1="9.8" y1="4.5" x2="9.8" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-4.5" x2="-5" y2="-4.5" width="0.2032" layer="51"/>
<wire x1="-3.5" y1="4.5" x2="-3.5" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="-2.5" x2="-3.5" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="2.5" x2="0" y2="2.5" width="0.2032" layer="21"/>
<wire x1="0" y1="2.5" x2="2.286" y2="0" width="0.2032" layer="21" curve="-90"/>
<wire x1="2.286" y1="0" x2="0" y2="-2.5" width="0.2032" layer="21" curve="-90"/>
<wire x1="0" y1="-2.5" x2="-3.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-3.5" y1="4.5" x2="-2" y2="4.5" width="0.2032" layer="21"/>
<wire x1="2" y1="4.5" x2="4.1" y2="4.5" width="0.2032" layer="21"/>
<wire x1="8.2" y1="4.5" x2="9.8" y2="4.5" width="0.2032" layer="21"/>
<wire x1="9.8" y1="-4.5" x2="8.1" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-4.5" x2="2" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-2" y1="-4.5" x2="-3.5" y2="-4.5" width="0.2032" layer="21"/>
<smd name="VIN0" x="0" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="GND" x="0" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="VIN1" x="6.1" y="5.7" dx="2.8" dy="2.4" layer="1"/>
<smd name="P$4" x="6.1" y="-5.7" dx="2.8" dy="2.4" layer="1"/>
<hole x="0" y="0" drill="2.032"/>
<hole x="4.572" y="0" drill="2.032"/>
<rectangle x1="7.470140625" y1="4.83108125" x2="8.41501875" y2="6.48461875" layer="31"/>
<rectangle x1="-0.481328125" y1="6.493509375" x2="0.463546875" y2="8.147046875" layer="31" rot="R90"/>
<rectangle x1="-0.570228125" y1="-8.187690625" x2="0.374646875" y2="-6.534153125" layer="31" rot="R90"/>
<rectangle x1="5.76453125" y1="-8.18515" x2="6.70940625" y2="-6.5316125" layer="31" rot="R90"/>
</package>
<package name="POWER_JACK_SMD_OVERPASTE_TOE">
<rectangle x1="-1.399540625" y1="-8.382" x2="1.399540625" y2="-6.8961" layer="31"/>
<rectangle x1="4.701540625" y1="-8.384540625" x2="7.500621875" y2="-6.898640625" layer="31"/>
<rectangle x1="4.7015375" y1="6.8961" x2="7.50061875" y2="8.382" layer="31" rot="R180"/>
<rectangle x1="-1.39954375" y1="6.8961" x2="1.3995375" y2="8.382" layer="31" rot="R180"/>
<rectangle x1="5.7531" y1="-6.6675" x2="6.8707" y2="-6.6421" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-6.6421" x2="6.9215" y2="-6.6167" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="-6.6167" x2="6.9723" y2="-6.5913" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="-6.5913" x2="6.9723" y2="-6.5659" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="-6.5659" x2="6.9977" y2="-6.5405" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-6.5405" x2="7.0231" y2="-6.5151" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-6.5151" x2="7.0231" y2="-6.4897" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4897" x2="7.0231" y2="-6.4643" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4643" x2="7.0231" y2="-6.4389" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="-6.4643" x2="0.4445" y2="-6.4389" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-6.4389" x2="7.0231" y2="-6.4135" layer="200" rot="R180"/>
<rectangle x1="-0.8001" y1="-6.4389" x2="0.5207" y2="-6.4135" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.4135" x2="7.0231" y2="-6.3881" layer="200" rot="R180"/>
<rectangle x1="-0.8255" y1="-6.4135" x2="0.5461" y2="-6.3881" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3881" x2="7.0231" y2="-6.3627" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-6.3881" x2="0.5715" y2="-6.3627" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3627" x2="7.0231" y2="-6.3373" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-6.3627" x2="0.5969" y2="-6.3373" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3373" x2="7.0231" y2="-6.3119" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.3373" x2="0.6223" y2="-6.3119" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.3119" x2="7.0231" y2="-6.2865" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.3119" x2="0.6223" y2="-6.2865" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2865" x2="7.0231" y2="-6.2611" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-6.2865" x2="0.6223" y2="-6.2611" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2611" x2="7.0231" y2="-6.2357" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2611" x2="0.6477" y2="-6.2357" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2357" x2="7.0231" y2="-6.2103" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2357" x2="0.6477" y2="-6.2103" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.2103" x2="7.0231" y2="-6.1849" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.2103" x2="0.6477" y2="-6.1849" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1849" x2="7.0231" y2="-6.1595" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1849" x2="0.6477" y2="-6.1595" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1595" x2="7.0231" y2="-6.1341" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1595" x2="0.6477" y2="-6.1341" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1341" x2="7.0231" y2="-6.1087" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1341" x2="0.6477" y2="-6.1087" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.1087" x2="7.0231" y2="-6.0833" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.1087" x2="0.6477" y2="-6.0833" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0833" x2="7.0231" y2="-6.0579" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0833" x2="0.6477" y2="-6.0579" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0579" x2="7.0231" y2="-6.0325" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0579" x2="0.6477" y2="-6.0325" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0325" x2="7.0231" y2="-6.0071" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0325" x2="0.6477" y2="-6.0071" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-6.0071" x2="7.0231" y2="-5.9817" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-6.0071" x2="0.6477" y2="-5.9817" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9817" x2="7.0231" y2="-5.9563" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9817" x2="0.6731" y2="-5.9563" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9563" x2="7.0231" y2="-5.9309" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9563" x2="0.6731" y2="-5.9309" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9309" x2="7.0231" y2="-5.9055" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9309" x2="0.6731" y2="-5.9055" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.9055" x2="7.0231" y2="-5.8801" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.9055" x2="0.6731" y2="-5.8801" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="-5.8801" x2="7.0231" y2="-5.8547" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8801" x2="0.6731" y2="-5.8547" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8547" x2="7.0231" y2="-5.8293" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8547" x2="0.6731" y2="-5.8293" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8293" x2="7.0231" y2="-5.8039" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8293" x2="0.6731" y2="-5.8039" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.8039" x2="7.0231" y2="-5.7785" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.8039" x2="0.6731" y2="-5.7785" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7785" x2="7.0231" y2="-5.7531" layer="200" rot="R180"/>
<rectangle x1="-0.9017" y1="-5.7785" x2="0.6731" y2="-5.7531" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7531" x2="7.0231" y2="-5.7277" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7531" x2="0.6731" y2="-5.7277" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7277" x2="7.0231" y2="-5.7023" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7277" x2="0.6731" y2="-5.7023" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.7023" x2="7.0231" y2="-5.6769" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.7023" x2="0.6731" y2="-5.6769" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6769" x2="7.0231" y2="-5.6515" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6769" x2="0.6731" y2="-5.6515" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6515" x2="7.0231" y2="-5.6261" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6515" x2="0.6731" y2="-5.6261" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6261" x2="7.0231" y2="-5.6007" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6261" x2="0.6731" y2="-5.6007" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.6007" x2="7.0231" y2="-5.5753" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.6007" x2="0.6731" y2="-5.5753" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5753" x2="7.0231" y2="-5.5499" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5753" x2="0.6731" y2="-5.5499" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5499" x2="7.0231" y2="-5.5245" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5499" x2="0.6731" y2="-5.5245" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.5245" x2="7.0231" y2="-5.4991" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.5245" x2="0.6731" y2="-5.4991" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4991" x2="7.0231" y2="-5.4737" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4991" x2="0.6731" y2="-5.4737" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4737" x2="7.0231" y2="-5.4483" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4737" x2="0.6731" y2="-5.4483" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4483" x2="7.0231" y2="-5.4229" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4483" x2="0.6731" y2="-5.4229" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.4229" x2="7.0231" y2="-5.3975" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.4229" x2="0.6731" y2="-5.3975" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3975" x2="7.0231" y2="-5.3721" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3975" x2="0.6731" y2="-5.3721" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3721" x2="7.0231" y2="-5.3467" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3721" x2="0.6731" y2="-5.3467" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3467" x2="7.0231" y2="-5.3213" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3467" x2="0.6731" y2="-5.3213" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.3213" x2="7.0231" y2="-5.2959" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.3213" x2="0.6731" y2="-5.2959" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2959" x2="7.0231" y2="-5.2705" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2959" x2="0.6731" y2="-5.2705" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2705" x2="7.0231" y2="-5.2451" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2705" x2="0.6731" y2="-5.2451" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2451" x2="7.0231" y2="-5.2197" layer="200" rot="R180"/>
<rectangle x1="-0.8763" y1="-5.2451" x2="0.6731" y2="-5.2197" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.2197" x2="7.0231" y2="-5.1943" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.2197" x2="0.6731" y2="-5.1943" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1943" x2="7.0231" y2="-5.1689" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1943" x2="0.6731" y2="-5.1689" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1689" x2="7.0231" y2="-5.1435" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1689" x2="0.6731" y2="-5.1435" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1435" x2="7.0231" y2="-5.1181" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1435" x2="0.6731" y2="-5.1181" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.1181" x2="7.0231" y2="-5.0927" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.1181" x2="0.6731" y2="-5.0927" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0927" x2="7.0231" y2="-5.0673" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0927" x2="0.6731" y2="-5.0673" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0673" x2="7.0231" y2="-5.0419" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0673" x2="0.6731" y2="-5.0419" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0419" x2="7.0231" y2="-5.0165" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0419" x2="0.6731" y2="-5.0165" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-5.0165" x2="6.9977" y2="-4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-5.0165" x2="0.6731" y2="-4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-4.9911" x2="0.6731" y2="-4.9657" layer="200" rot="R180"/>
<rectangle x1="-0.8509" y1="-4.9657" x2="0.5207" y2="-4.9403" layer="200" rot="R180"/>
<rectangle x1="4.3815" y1="-4.7879" x2="7.0739" y2="-4.7625" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-4.7879" x2="1.3335" y2="-4.7625" layer="200" rot="R180"/>
<rectangle x1="-4.4069" y1="-4.7625" x2="7.0993" y2="-4.7371" layer="200" rot="R180"/>
<rectangle x1="-4.4577" y1="-4.7371" x2="7.0993" y2="-4.7117" layer="200" rot="R180"/>
<rectangle x1="-4.5085" y1="-4.7117" x2="7.0993" y2="-4.6863" layer="200" rot="R180"/>
<rectangle x1="-4.5593" y1="-4.6863" x2="7.0993" y2="-4.6609" layer="200" rot="R180"/>
<rectangle x1="-4.5847" y1="-4.6609" x2="7.0993" y2="-4.6355" layer="200" rot="R180"/>
<rectangle x1="-4.6355" y1="-4.6355" x2="7.0993" y2="-4.6101" layer="200" rot="R180"/>
<rectangle x1="-4.6609" y1="-4.6101" x2="7.0993" y2="-4.5847" layer="200" rot="R180"/>
<rectangle x1="-4.6863" y1="-4.5847" x2="7.0993" y2="-4.5593" layer="200" rot="R180"/>
<rectangle x1="-4.7117" y1="-4.5593" x2="7.0739" y2="-4.5339" layer="200" rot="R180"/>
<rectangle x1="-4.7371" y1="-4.5339" x2="7.0739" y2="-4.5085" layer="200" rot="R180"/>
<rectangle x1="-4.7625" y1="-4.5085" x2="7.0739" y2="-4.4831" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="-4.4831" x2="7.0739" y2="-4.4577" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="-4.4577" x2="7.0739" y2="-4.4323" layer="200" rot="R180"/>
<rectangle x1="-4.8133" y1="-4.4323" x2="7.5057" y2="-4.4069" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="-4.4069" x2="9.7155" y2="-4.3815" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="-4.3815" x2="9.7663" y2="-4.3561" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="-4.3561" x2="9.7917" y2="-4.3307" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="-4.3307" x2="9.8171" y2="-4.3053" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="-4.3053" x2="9.8425" y2="-4.2799" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="-4.2799" x2="9.8679" y2="-4.2545" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2545" x2="9.8933" y2="-4.2291" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2291" x2="9.8933" y2="-4.2037" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="-4.2037" x2="9.8933" y2="-4.1783" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1783" x2="9.8933" y2="-4.1529" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1529" x2="9.8933" y2="-4.1275" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="-4.1275" x2="9.8933" y2="-4.1021" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.1021" x2="9.8933" y2="-4.0767" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0767" x2="9.8933" y2="-4.0513" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0513" x2="9.8933" y2="-4.0259" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0259" x2="9.8933" y2="-4.0005" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-4.0005" x2="9.8933" y2="-3.9751" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9751" x2="9.8933" y2="-3.9497" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9497" x2="9.8933" y2="-3.9243" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.9243" x2="9.8933" y2="-3.8989" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.8989" x2="9.8933" y2="-3.8735" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-3.8735" x2="9.8933" y2="-3.8481" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.8481" x2="9.8933" y2="-3.8227" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.8227" x2="9.8933" y2="-3.7973" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7973" x2="9.8933" y2="-3.7719" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7719" x2="9.8933" y2="-3.7465" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7465" x2="9.8933" y2="-3.7211" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.7211" x2="9.8933" y2="-3.6957" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6957" x2="9.8933" y2="-3.6703" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6703" x2="9.8933" y2="-3.6449" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6449" x2="9.8933" y2="-3.6195" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.6195" x2="9.8933" y2="-3.5941" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5941" x2="9.8933" y2="-3.5687" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5687" x2="9.8933" y2="-3.5433" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5433" x2="9.8933" y2="-3.5179" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.5179" x2="9.8933" y2="-3.4925" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4925" x2="9.8933" y2="-3.4671" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4671" x2="9.8933" y2="-3.4417" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4417" x2="9.8933" y2="-3.4163" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.4163" x2="9.8933" y2="-3.3909" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3909" x2="9.8933" y2="-3.3655" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3655" x2="9.8933" y2="-3.3401" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3401" x2="9.8933" y2="-3.3147" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.3147" x2="9.8933" y2="-3.2893" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2893" x2="9.8933" y2="-3.2639" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2639" x2="9.8933" y2="-3.2385" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2385" x2="9.8933" y2="-3.2131" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.2131" x2="9.8933" y2="-3.1877" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1877" x2="9.8933" y2="-3.1623" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1623" x2="9.8933" y2="-3.1369" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1369" x2="9.8933" y2="-3.1115" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.1115" x2="9.8933" y2="-3.0861" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0861" x2="9.8933" y2="-3.0607" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0607" x2="9.8933" y2="-3.0353" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0353" x2="9.8933" y2="-3.0099" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-3.0099" x2="9.8933" y2="-2.9845" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9845" x2="9.8933" y2="-2.9591" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9591" x2="9.8933" y2="-2.9337" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9337" x2="9.8933" y2="-2.9083" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.9083" x2="9.8933" y2="-2.8829" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8829" x2="9.8933" y2="-2.8575" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8575" x2="9.8933" y2="-2.8321" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8321" x2="9.8933" y2="-2.8067" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.8067" x2="9.8933" y2="-2.7813" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7813" x2="9.8933" y2="-2.7559" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7559" x2="9.8933" y2="-2.7305" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7305" x2="9.8933" y2="-2.7051" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.7051" x2="9.8933" y2="-2.6797" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6797" x2="9.8933" y2="-2.6543" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6543" x2="9.8933" y2="-2.6289" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6289" x2="9.8933" y2="-2.6035" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.6035" x2="9.8933" y2="-2.5781" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5781" x2="9.8933" y2="-2.5527" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5527" x2="9.8933" y2="-2.5273" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5273" x2="9.8933" y2="-2.5019" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.5019" x2="9.8933" y2="-2.4765" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4765" x2="9.8933" y2="-2.4511" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4511" x2="9.8933" y2="-2.4257" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4257" x2="9.8933" y2="-2.4003" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.4003" x2="9.8933" y2="-2.3749" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3749" x2="9.8933" y2="-2.3495" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3495" x2="9.8933" y2="-2.3241" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.3241" x2="9.8933" y2="-2.2987" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2987" x2="9.8933" y2="-2.2733" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2733" x2="9.8933" y2="-2.2479" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2479" x2="9.8933" y2="-2.2225" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.2225" x2="9.8933" y2="-2.1971" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1971" x2="9.8933" y2="-2.1717" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1717" x2="9.8933" y2="-2.1463" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1463" x2="9.8933" y2="-2.1209" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.1209" x2="9.8933" y2="-2.0955" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0955" x2="9.8933" y2="-2.0701" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0701" x2="9.8933" y2="-2.0447" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0447" x2="9.8933" y2="-2.0193" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-2.0193" x2="9.8933" y2="-1.9939" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9939" x2="9.8933" y2="-1.9685" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9685" x2="9.8933" y2="-1.9431" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9431" x2="9.8933" y2="-1.9177" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.9177" x2="9.8933" y2="-1.8923" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8923" x2="9.8933" y2="-1.8669" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8669" x2="9.8933" y2="-1.8415" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8415" x2="9.8933" y2="-1.8161" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.8161" x2="9.8933" y2="-1.7907" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7907" x2="9.8933" y2="-1.7653" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7653" x2="9.8933" y2="-1.7399" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7399" x2="9.8933" y2="-1.7145" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.7145" x2="9.8933" y2="-1.6891" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6891" x2="9.8933" y2="-1.6637" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6637" x2="9.8933" y2="-1.6383" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6383" x2="9.8679" y2="-1.6129" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.6129" x2="8.8773" y2="-1.5875" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5875" x2="8.8773" y2="-1.5621" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5621" x2="8.8773" y2="-1.5367" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5367" x2="8.8773" y2="-1.5113" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.5113" x2="8.8773" y2="-1.4859" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4859" x2="8.8773" y2="-1.4605" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4605" x2="8.8773" y2="-1.4351" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4351" x2="8.8773" y2="-1.4097" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.4097" x2="8.8773" y2="-1.3843" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3843" x2="8.8773" y2="-1.3589" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3589" x2="8.8773" y2="-1.3335" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3335" x2="8.8773" y2="-1.3081" layer="200" rot="R180"/>
<rectangle x1="4.8133" y1="-1.3081" x2="8.8773" y2="-1.2827" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.3081" x2="4.3815" y2="-1.2827" layer="200" rot="R180"/>
<rectangle x1="4.9149" y1="-1.2827" x2="8.8773" y2="-1.2573" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2827" x2="4.2799" y2="-1.2573" layer="200" rot="R180"/>
<rectangle x1="5.0165" y1="-1.2573" x2="8.8773" y2="-1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2573" x2="4.1783" y2="-1.2319" layer="200" rot="R180"/>
<rectangle x1="5.0927" y1="-1.2319" x2="8.8773" y2="-1.2065" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2319" x2="4.1275" y2="-1.2065" layer="200" rot="R180"/>
<rectangle x1="5.1435" y1="-1.2065" x2="8.8773" y2="-1.1811" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.2065" x2="4.0513" y2="-1.1811" layer="200" rot="R180"/>
<rectangle x1="5.1943" y1="-1.1811" x2="8.8773" y2="-1.1557" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1811" x2="4.0005" y2="-1.1557" layer="200" rot="R180"/>
<rectangle x1="5.2197" y1="-1.1557" x2="8.8773" y2="-1.1303" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1557" x2="3.9497" y2="-1.1303" layer="200" rot="R180"/>
<rectangle x1="5.2705" y1="-1.1303" x2="8.8773" y2="-1.1049" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1303" x2="3.8989" y2="-1.1049" layer="200" rot="R180"/>
<rectangle x1="5.2959" y1="-1.1049" x2="8.8773" y2="-1.0795" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.1049" x2="3.8735" y2="-1.0795" layer="200" rot="R180"/>
<rectangle x1="5.3467" y1="-1.0795" x2="8.8773" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="0.1143" y1="-1.0795" x2="3.8227" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0795" x2="-0.1143" y2="-1.0541" layer="200" rot="R180"/>
<rectangle x1="5.3721" y1="-1.0541" x2="8.8773" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="0.2413" y1="-1.0541" x2="3.7973" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0541" x2="-0.2413" y2="-1.0287" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="-1.0287" x2="8.8773" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="0.3429" y1="-1.0287" x2="3.7465" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0287" x2="-0.3429" y2="-1.0033" layer="200" rot="R180"/>
<rectangle x1="5.4229" y1="-1.0033" x2="8.8773" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="0.4191" y1="-1.0033" x2="3.7211" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-1.0033" x2="-0.4191" y2="-0.9779" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="-0.9779" x2="8.8773" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="0.4699" y1="-0.9779" x2="3.6957" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9779" x2="-0.4699" y2="-0.9525" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="-0.9525" x2="8.8773" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="0.5207" y1="-0.9525" x2="3.6703" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9525" x2="-0.5207" y2="-0.9271" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="-0.9271" x2="8.8773" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="0.5715" y1="-0.9271" x2="3.6449" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9271" x2="-0.5715" y2="-0.9017" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="-0.9017" x2="8.8773" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="0.6223" y1="-0.9017" x2="3.6195" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.9017" x2="-0.6223" y2="-0.8763" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="-0.8763" x2="8.8773" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="0.6477" y1="-0.8763" x2="3.5941" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8763" x2="-0.6477" y2="-0.8509" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="-0.8509" x2="8.8773" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="0.6985" y1="-0.8509" x2="3.5687" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8509" x2="-0.6985" y2="-0.8255" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-0.8255" x2="8.8773" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="0.7239" y1="-0.8255" x2="3.5433" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8255" x2="-0.7239" y2="-0.8001" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="-0.8001" x2="8.8773" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="0.7493" y1="-0.8001" x2="3.5179" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.8001" x2="-0.7493" y2="-0.7747" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="-0.7747" x2="8.8773" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="-0.7747" x2="3.4925" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7747" x2="-0.7747" y2="-0.7493" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="-0.7493" x2="8.8773" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="0.8255" y1="-0.7493" x2="3.4925" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7493" x2="-0.8001" y2="-0.7239" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="-0.7239" x2="8.8773" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="0.8509" y1="-0.7239" x2="3.4671" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.7239" x2="-0.8255" y2="-0.6985" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="-0.6985" x2="8.8773" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="-0.6985" x2="3.4671" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6985" x2="-0.8509" y2="-0.6731" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="-0.6731" x2="8.8773" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="-0.6731" x2="3.4417" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6731" x2="-0.8763" y2="-0.6477" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="-0.6477" x2="8.8773" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="-0.6477" x2="3.4417" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6477" x2="-0.9017" y2="-0.6223" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="-0.6223" x2="8.8773" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="-0.6223" x2="3.4163" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.6223" x2="-0.9017" y2="-0.5969" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="-0.5969" x2="8.8773" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="-0.5969" x2="3.4163" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5969" x2="-0.9271" y2="-0.5715" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="-0.5715" x2="8.8773" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="-0.5715" x2="3.3909" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5715" x2="-0.9525" y2="-0.5461" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="-0.5461" x2="8.8773" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="-0.5461" x2="3.3655" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5461" x2="-0.9525" y2="-0.5207" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="-0.5207" x2="8.8773" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="-0.5207" x2="3.3655" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="-4.9911" y1="-0.5207" x2="-0.9779" y2="-0.4953" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4953" x2="8.8773" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="-0.4953" x2="3.3401" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4953" x2="-0.9779" y2="-0.4699" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4699" x2="8.8773" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="-0.4699" x2="3.3401" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4699" x2="-1.0033" y2="-0.4445" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="-0.4445" x2="8.8773" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="-0.4445" x2="3.3401" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4445" x2="-1.0033" y2="-0.4191" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.4191" x2="8.8773" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.4191" x2="3.3147" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.4191" x2="-1.0033" y2="-0.3937" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3937" x2="8.8773" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.3937" x2="3.3147" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3937" x2="-1.0033" y2="-0.3683" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3683" x2="8.8773" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="-0.3683" x2="3.3147" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3683" x2="-1.0287" y2="-0.3429" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="-0.3429" x2="8.8773" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.3429" x2="3.3147" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3429" x2="-1.0287" y2="-0.3175" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.3175" x2="8.8773" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.3175" x2="3.3147" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.3175" x2="-1.0287" y2="-0.2921" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2921" x2="8.8773" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2921" x2="3.2893" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2921" x2="-1.0287" y2="-0.2667" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2667" x2="8.8773" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2667" x2="3.2893" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2667" x2="-1.0287" y2="-0.2413" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2413" x2="8.8773" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="-0.2413" x2="3.2893" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2413" x2="-1.0287" y2="-0.2159" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.2159" x2="8.8773" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.2159" x2="3.2893" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.2159" x2="-1.0541" y2="-0.1905" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1905" x2="8.8773" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1905" x2="3.2893" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1905" x2="-1.0541" y2="-0.1651" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1651" x2="8.8773" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1651" x2="3.2893" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1651" x2="-1.0541" y2="-0.1397" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1397" x2="8.8773" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1397" x2="3.2893" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1397" x2="-1.0541" y2="-0.1143" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.1143" x2="8.8773" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.1143" x2="3.2893" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.1143" x2="-1.0541" y2="-0.0889" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0889" x2="8.8773" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0889" x2="3.2893" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0889" x2="-1.0541" y2="-0.0635" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0635" x2="8.8773" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0635" x2="3.2893" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0635" x2="-1.0541" y2="-0.0381" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0381" x2="8.8773" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0381" x2="3.2893" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0381" x2="-1.0541" y2="-0.0127" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="-0.0127" x2="8.8773" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="-0.0127" x2="3.2893" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="-0.0127" x2="-1.0541" y2="0.0127" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0127" x2="8.8773" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0127" x2="3.2893" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0127" x2="-1.0541" y2="0.0381" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0381" x2="8.8773" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0381" x2="3.2893" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0381" x2="-1.0541" y2="0.0635" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0635" x2="8.8773" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0635" x2="3.2893" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0635" x2="-1.0541" y2="0.0889" layer="200" rot="R180"/>
<rectangle x1="5.8801" y1="0.0889" x2="8.8773" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.0889" x2="3.2893" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.0889" x2="-1.0541" y2="0.1143" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1143" x2="8.8773" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="1.1049" y1="0.1143" x2="3.2893" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1143" x2="-1.0541" y2="0.1397" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1397" x2="8.8773" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1397" x2="3.2893" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1397" x2="-1.0541" y2="0.1651" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1651" x2="8.8773" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1651" x2="3.3147" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1651" x2="-1.0541" y2="0.1905" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.1905" x2="8.8773" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.1905" x2="3.3147" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.1905" x2="-1.0541" y2="0.2159" layer="200" rot="R180"/>
<rectangle x1="5.8547" y1="0.2159" x2="8.9027" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.2159" x2="3.3147" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2159" x2="-1.0541" y2="0.2413" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2413" x2="8.9027" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="1.0795" y1="0.2413" x2="3.3147" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2413" x2="-1.0541" y2="0.2667" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2667" x2="8.9027" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.2667" x2="3.3401" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2667" x2="-1.0541" y2="0.2921" layer="200" rot="R180"/>
<rectangle x1="5.8293" y1="0.2921" x2="8.9027" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.2921" x2="3.3401" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.2921" x2="-1.0287" y2="0.3175" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="0.3175" x2="8.9027" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.3175" x2="3.3401" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3175" x2="-1.0287" y2="0.3429" layer="200" rot="R180"/>
<rectangle x1="5.8039" y1="0.3429" x2="8.9027" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="1.0541" y1="0.3429" x2="3.3655" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3429" x2="-1.0287" y2="0.3683" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="0.3683" x2="8.9027" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.3683" x2="3.3909" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3683" x2="-1.0287" y2="0.3937" layer="200" rot="R180"/>
<rectangle x1="5.7785" y1="0.3937" x2="8.9027" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.3937" x2="3.3655" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.3937" x2="-1.0287" y2="0.4191" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4191" x2="8.9027" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="1.0287" y1="0.4191" x2="3.3909" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4191" x2="-1.0033" y2="0.4445" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4445" x2="8.9027" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="0.4445" x2="3.4163" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4445" x2="-1.0033" y2="0.4699" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="0.4699" x2="8.9027" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="1.0033" y1="0.4699" x2="3.4163" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4699" x2="-1.0033" y2="0.4953" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="0.4953" x2="8.9027" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="0.4953" x2="3.4163" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.4953" x2="-0.9779" y2="0.5207" layer="200" rot="R180"/>
<rectangle x1="5.7277" y1="0.5207" x2="8.9027" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="0.9779" y1="0.5207" x2="3.4417" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5207" x2="-0.9779" y2="0.5461" layer="200" rot="R180"/>
<rectangle x1="5.7023" y1="0.5461" x2="8.9027" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="0.5461" x2="3.4417" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5461" x2="-0.9525" y2="0.5715" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="0.5715" x2="8.9027" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="0.9525" y1="0.5715" x2="3.4671" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5715" x2="-0.9525" y2="0.5969" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="0.5969" x2="8.9027" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="0.5969" x2="3.4671" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.5969" x2="-0.9271" y2="0.6223" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="0.6223" x2="8.9027" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="0.9271" y1="0.6223" x2="3.4925" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6223" x2="-0.9271" y2="0.6477" layer="200" rot="R180"/>
<rectangle x1="5.6515" y1="0.6477" x2="8.9027" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="0.6477" x2="3.4925" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6477" x2="-0.9017" y2="0.6731" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="0.6731" x2="8.9027" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="0.9017" y1="0.6731" x2="3.5179" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6731" x2="-0.8763" y2="0.6985" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="0.6985" x2="8.9027" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="0.8763" y1="0.6985" x2="3.5433" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.6985" x2="-0.8763" y2="0.7239" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7239" x2="8.9027" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="0.8509" y1="0.7239" x2="3.5433" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7239" x2="-0.8509" y2="0.7493" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7493" x2="8.9027" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="0.8255" y1="0.7493" x2="3.5687" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7493" x2="-0.8255" y2="0.7747" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="0.7747" x2="8.9027" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="0.7747" x2="3.5941" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.7747" x2="-0.8001" y2="0.8001" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="0.8001" x2="8.9027" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="0.8001" y1="0.8001" x2="3.6195" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8001" x2="-0.7747" y2="0.8255" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="0.8255" x2="8.9027" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="0.7747" y1="0.8255" x2="3.6195" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8255" x2="-0.7493" y2="0.8509" layer="200" rot="R180"/>
<rectangle x1="5.4737" y1="0.8509" x2="8.9027" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="0.7493" y1="0.8509" x2="3.6449" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8509" x2="-0.7239" y2="0.8763" layer="200" rot="R180"/>
<rectangle x1="5.4483" y1="0.8763" x2="8.9027" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="0.7239" y1="0.8763" x2="3.6703" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.8763" x2="-0.6731" y2="0.9017" layer="200" rot="R180"/>
<rectangle x1="5.4229" y1="0.9017" x2="8.9027" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="0.6731" y1="0.9017" x2="3.6957" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9017" x2="-0.6477" y2="0.9271" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="0.9271" x2="8.9027" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="0.6477" y1="0.9271" x2="3.7211" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9271" x2="-0.5969" y2="0.9525" layer="200" rot="R180"/>
<rectangle x1="5.3975" y1="0.9525" x2="8.9027" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="0.5969" y1="0.9525" x2="3.7465" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9525" x2="-0.5461" y2="0.9779" layer="200" rot="R180"/>
<rectangle x1="5.3213" y1="0.9779" x2="8.9027" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="0.5715" y1="0.9779" x2="3.7973" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="0.9779" x2="-0.4953" y2="1.0033" layer="200" rot="R180"/>
<rectangle x1="5.2959" y1="1.0033" x2="8.9027" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="0.5207" y1="1.0033" x2="3.8227" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0033" x2="-0.4191" y2="1.0287" layer="200" rot="R180"/>
<rectangle x1="5.2705" y1="1.0287" x2="8.9027" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="0.4445" y1="1.0287" x2="3.8481" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0287" x2="-0.3429" y2="1.0541" layer="200" rot="R180"/>
<rectangle x1="5.2197" y1="1.0541" x2="8.9027" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="0.3937" y1="1.0541" x2="3.8989" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0541" x2="-0.2413" y2="1.0795" layer="200" rot="R180"/>
<rectangle x1="5.1689" y1="1.0795" x2="8.9027" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="0.2921" y1="1.0795" x2="3.9497" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.0795" x2="-0.0889" y2="1.1049" layer="200" rot="R180"/>
<rectangle x1="5.1181" y1="1.1049" x2="8.9027" y2="1.1303" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1049" x2="4.0005" y2="1.1303" layer="200" rot="R180"/>
<rectangle x1="5.0673" y1="1.1303" x2="8.9027" y2="1.1557" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1303" x2="4.0513" y2="1.1557" layer="200" rot="R180"/>
<rectangle x1="5.0165" y1="1.1557" x2="8.9027" y2="1.1811" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1557" x2="4.1275" y2="1.1811" layer="200" rot="R180"/>
<rectangle x1="4.9149" y1="1.1811" x2="8.9027" y2="1.2065" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.1811" x2="4.2037" y2="1.2065" layer="200" rot="R180"/>
<rectangle x1="4.7625" y1="1.2065" x2="8.9027" y2="1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2065" x2="4.3307" y2="1.2319" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2319" x2="8.9027" y2="1.2573" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2573" x2="8.9027" y2="1.2827" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.2827" x2="8.9027" y2="1.3081" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3081" x2="8.9027" y2="1.3335" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3335" x2="8.9027" y2="1.3589" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3589" x2="8.9027" y2="1.3843" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.3843" x2="8.9027" y2="1.4097" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4097" x2="8.9027" y2="1.4351" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4351" x2="8.9027" y2="1.4605" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4605" x2="8.9027" y2="1.4859" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.4859" x2="8.9027" y2="1.5113" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5113" x2="8.9027" y2="1.5367" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5367" x2="8.9027" y2="1.5621" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5621" x2="8.9027" y2="1.5875" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.5875" x2="8.9027" y2="1.6129" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6129" x2="8.9027" y2="1.6383" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6383" x2="8.9027" y2="1.6637" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6637" x2="8.9027" y2="1.6891" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.6891" x2="8.9027" y2="1.7145" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7145" x2="8.9027" y2="1.7399" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7399" x2="8.9027" y2="1.7653" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7653" x2="8.9027" y2="1.7907" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.7907" x2="8.9027" y2="1.8161" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8161" x2="8.9027" y2="1.8415" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8415" x2="8.9027" y2="1.8669" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8669" x2="8.9027" y2="1.8923" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.8923" x2="8.9027" y2="1.9177" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9177" x2="8.9027" y2="1.9431" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9431" x2="8.9027" y2="1.9685" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9685" x2="8.9027" y2="1.9939" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="1.9939" x2="8.9027" y2="2.0193" layer="200" rot="R180"/>
<rectangle x1="-4.9657" y1="2.0193" x2="8.9027" y2="2.0447" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0447" x2="8.9027" y2="2.0701" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0701" x2="8.9027" y2="2.0955" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.0955" x2="8.9027" y2="2.1209" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1209" x2="8.9027" y2="2.1463" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1463" x2="8.9281" y2="2.1717" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1717" x2="8.9281" y2="2.1971" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.1971" x2="8.9281" y2="2.2225" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2225" x2="8.9281" y2="2.2479" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2479" x2="8.9281" y2="2.2733" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2733" x2="8.9281" y2="2.2987" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.2987" x2="8.9281" y2="2.3241" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3241" x2="8.9281" y2="2.3495" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3495" x2="8.9281" y2="2.3749" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.3749" x2="8.9281" y2="2.4003" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4003" x2="8.9281" y2="2.4257" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4257" x2="8.9281" y2="2.4511" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4511" x2="8.9281" y2="2.4765" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.4765" x2="8.9281" y2="2.5019" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5019" x2="8.9281" y2="2.5273" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5273" x2="8.9281" y2="2.5527" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5527" x2="8.9281" y2="2.5781" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.5781" x2="8.9281" y2="2.6035" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6035" x2="8.9281" y2="2.6289" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6289" x2="8.9281" y2="2.6543" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6543" x2="8.9281" y2="2.6797" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.6797" x2="8.9281" y2="2.7051" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7051" x2="8.9281" y2="2.7305" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7305" x2="8.9281" y2="2.7559" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7559" x2="8.9281" y2="2.7813" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.7813" x2="8.9281" y2="2.8067" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8067" x2="8.9281" y2="2.8321" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8321" x2="8.9281" y2="2.8575" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8575" x2="8.9281" y2="2.8829" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.8829" x2="8.9281" y2="2.9083" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9083" x2="8.9281" y2="2.9337" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9337" x2="8.9281" y2="2.9591" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9591" x2="8.9281" y2="2.9845" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="2.9845" x2="8.9281" y2="3.0099" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0099" x2="8.9281" y2="3.0353" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0353" x2="8.9281" y2="3.0607" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0607" x2="8.9281" y2="3.0861" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.0861" x2="8.9281" y2="3.1115" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1115" x2="8.9281" y2="3.1369" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1369" x2="8.9281" y2="3.1623" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1623" x2="8.9281" y2="3.1877" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.1877" x2="8.9281" y2="3.2131" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2131" x2="8.9281" y2="3.2385" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2385" x2="8.9281" y2="3.2639" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2639" x2="8.9281" y2="3.2893" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.2893" x2="8.9281" y2="3.3147" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3147" x2="8.9281" y2="3.3401" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3401" x2="8.9281" y2="3.3655" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3655" x2="8.9281" y2="3.3909" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.3909" x2="8.9281" y2="3.4163" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4163" x2="8.9281" y2="3.4417" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4417" x2="8.9281" y2="3.4671" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4671" x2="8.9281" y2="3.4925" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.4925" x2="8.9281" y2="3.5179" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5179" x2="8.9281" y2="3.5433" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5433" x2="8.9281" y2="3.5687" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5687" x2="8.9281" y2="3.5941" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.5941" x2="8.9281" y2="3.6195" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6195" x2="8.9281" y2="3.6449" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6449" x2="8.9281" y2="3.6703" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6703" x2="8.9281" y2="3.6957" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.6957" x2="8.9281" y2="3.7211" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7211" x2="8.9281" y2="3.7465" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7465" x2="8.9281" y2="3.7719" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7719" x2="8.9281" y2="3.7973" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.7973" x2="8.9281" y2="3.8227" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8227" x2="8.9281" y2="3.8481" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8481" x2="8.9281" y2="3.8735" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8735" x2="8.9281" y2="3.8989" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.8989" x2="8.9281" y2="3.9243" layer="200" rot="R180"/>
<rectangle x1="-4.9403" y1="3.9243" x2="8.9281" y2="3.9497" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="3.9497" x2="8.9281" y2="3.9751" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="3.9751" x2="8.9281" y2="4.0005" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0005" x2="8.9281" y2="4.0259" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0259" x2="8.9281" y2="4.0513" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0513" x2="8.9281" y2="4.0767" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.0767" x2="8.9281" y2="4.1021" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.1021" x2="8.9281" y2="4.1275" layer="200" rot="R180"/>
<rectangle x1="-4.9149" y1="4.1275" x2="8.9281" y2="4.1529" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="4.1529" x2="8.9281" y2="4.1783" layer="200" rot="R180"/>
<rectangle x1="-4.8895" y1="4.1783" x2="8.9281" y2="4.2037" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="4.2037" x2="8.9027" y2="4.2291" layer="200" rot="R180"/>
<rectangle x1="-4.8641" y1="4.2291" x2="8.9027" y2="4.2545" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="4.2545" x2="8.8773" y2="4.2799" layer="200" rot="R180"/>
<rectangle x1="-4.8387" y1="4.2799" x2="8.8773" y2="4.3053" layer="200" rot="R180"/>
<rectangle x1="-4.8133" y1="4.3053" x2="8.8519" y2="4.3307" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="4.3307" x2="8.8265" y2="4.3561" layer="200" rot="R180"/>
<rectangle x1="-4.7879" y1="4.3561" x2="8.8011" y2="4.3815" layer="200" rot="R180"/>
<rectangle x1="-4.7625" y1="4.3815" x2="8.7757" y2="4.4069" layer="200" rot="R180"/>
<rectangle x1="-4.7371" y1="4.4069" x2="8.7249" y2="4.4323" layer="200" rot="R180"/>
<rectangle x1="-4.7117" y1="4.4323" x2="8.6741" y2="4.4577" layer="200" rot="R180"/>
<rectangle x1="-4.6863" y1="4.4577" x2="8.6233" y2="4.4831" layer="200" rot="R180"/>
<rectangle x1="-4.6609" y1="4.4831" x2="7.1247" y2="4.5085" layer="200" rot="R180"/>
<rectangle x1="-4.6101" y1="4.5085" x2="7.1247" y2="4.5339" layer="200" rot="R180"/>
<rectangle x1="-4.5847" y1="4.5339" x2="7.1247" y2="4.5593" layer="200" rot="R180"/>
<rectangle x1="-4.5339" y1="4.5593" x2="7.1247" y2="4.5847" layer="200" rot="R180"/>
<rectangle x1="-4.4577" y1="4.5847" x2="7.1247" y2="4.6101" layer="200" rot="R180"/>
<rectangle x1="-4.3815" y1="4.6101" x2="6.9215" y2="4.6355" layer="200" rot="R180"/>
<rectangle x1="-3.0607" y1="4.6355" x2="-1.6637" y2="4.6609" layer="200" rot="R180"/>
<rectangle x1="-3.8989" y1="4.6355" x2="-3.3655" y2="4.6609" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="4.8133" x2="7.0739" y2="4.8387" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8387" x2="7.0993" y2="4.8641" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8641" x2="7.0993" y2="4.8895" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.8895" x2="7.0993" y2="4.9149" layer="200" rot="R180"/>
<rectangle x1="-0.1651" y1="4.8895" x2="0.7239" y2="4.9149" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9149" x2="7.0993" y2="4.9403" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9149" x2="0.7239" y2="4.9403" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9403" x2="7.0993" y2="4.9657" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9403" x2="0.7239" y2="4.9657" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9657" x2="7.0993" y2="4.9911" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9657" x2="0.7239" y2="4.9911" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="4.9911" x2="7.0993" y2="5.0165" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="4.9911" x2="0.7239" y2="5.0165" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0165" x2="7.0993" y2="5.0419" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0165" x2="0.7239" y2="5.0419" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0419" x2="7.0993" y2="5.0673" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0419" x2="0.7239" y2="5.0673" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0673" x2="7.0993" y2="5.0927" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0673" x2="0.7239" y2="5.0927" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.0927" x2="7.0993" y2="5.1181" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.0927" x2="0.7239" y2="5.1181" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1181" x2="7.0993" y2="5.1435" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1181" x2="0.7239" y2="5.1435" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1435" x2="7.0993" y2="5.1689" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1435" x2="0.7239" y2="5.1689" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1689" x2="7.0993" y2="5.1943" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1689" x2="0.7239" y2="5.1943" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.1943" x2="7.0993" y2="5.2197" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.1943" x2="0.7239" y2="5.2197" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2197" x2="7.0993" y2="5.2451" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2197" x2="0.7239" y2="5.2451" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2451" x2="7.0993" y2="5.2705" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2451" x2="0.7239" y2="5.2705" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2705" x2="7.0993" y2="5.2959" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2705" x2="0.7239" y2="5.2959" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.2959" x2="7.0739" y2="5.3213" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.2959" x2="0.7239" y2="5.3213" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3213" x2="7.0739" y2="5.3467" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3213" x2="0.7239" y2="5.3467" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3467" x2="7.0739" y2="5.3721" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3467" x2="0.7239" y2="5.3721" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3721" x2="7.0739" y2="5.3975" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3721" x2="0.7239" y2="5.3975" layer="200" rot="R180"/>
<rectangle x1="5.4991" y1="5.3975" x2="7.0739" y2="5.4229" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.3975" x2="0.7239" y2="5.4229" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4229" x2="7.0739" y2="5.4483" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4229" x2="0.7239" y2="5.4483" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4483" x2="7.0739" y2="5.4737" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4483" x2="0.7239" y2="5.4737" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4737" x2="7.0739" y2="5.4991" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4737" x2="0.7239" y2="5.4991" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.4991" x2="7.0739" y2="5.5245" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.4991" x2="0.7239" y2="5.5245" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5245" x2="7.0739" y2="5.5499" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5245" x2="0.7239" y2="5.5499" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5499" x2="7.0739" y2="5.5753" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5499" x2="0.7239" y2="5.5753" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.5753" x2="7.0739" y2="5.6007" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.5753" x2="0.7239" y2="5.6007" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6007" x2="7.0739" y2="5.6261" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6007" x2="0.7239" y2="5.6261" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6261" x2="7.0739" y2="5.6515" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6261" x2="0.7239" y2="5.6515" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6515" x2="7.0739" y2="5.6769" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6515" x2="0.7239" y2="5.6769" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.6769" x2="7.0739" y2="5.7023" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.6769" x2="0.7239" y2="5.7023" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7023" x2="7.0739" y2="5.7277" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7023" x2="0.7239" y2="5.7277" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7277" x2="7.0739" y2="5.7531" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7277" x2="0.7239" y2="5.7531" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7531" x2="7.0739" y2="5.7785" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7531" x2="0.7239" y2="5.7785" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.7785" x2="7.0739" y2="5.8039" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.7785" x2="0.7239" y2="5.8039" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8039" x2="7.0739" y2="5.8293" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8039" x2="0.7239" y2="5.8293" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8293" x2="7.0739" y2="5.8547" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8293" x2="0.7239" y2="5.8547" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8547" x2="7.0739" y2="5.8801" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8547" x2="0.7239" y2="5.8801" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.8801" x2="7.0739" y2="5.9055" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.8801" x2="0.7239" y2="5.9055" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9055" x2="7.0739" y2="5.9309" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9055" x2="0.6985" y2="5.9309" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9309" x2="7.0739" y2="5.9563" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9309" x2="0.6985" y2="5.9563" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9563" x2="7.0739" y2="5.9817" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9563" x2="0.6985" y2="5.9817" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="5.9817" x2="7.0739" y2="6.0071" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="5.9817" x2="0.6985" y2="6.0071" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0071" x2="7.0739" y2="6.0325" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0071" x2="0.6985" y2="6.0325" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0325" x2="7.0739" y2="6.0579" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0325" x2="0.6985" y2="6.0579" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0579" x2="7.0739" y2="6.0833" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0579" x2="0.6985" y2="6.0833" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.0833" x2="7.0739" y2="6.1087" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.0833" x2="0.6985" y2="6.1087" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1087" x2="7.0739" y2="6.1341" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1087" x2="0.6985" y2="6.1341" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1341" x2="7.0739" y2="6.1595" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1341" x2="0.6985" y2="6.1595" layer="200" rot="R180"/>
<rectangle x1="5.5245" y1="6.1595" x2="7.0739" y2="6.1849" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1595" x2="0.6985" y2="6.1849" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.1849" x2="7.0739" y2="6.2103" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.1849" x2="0.6985" y2="6.2103" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2103" x2="7.0485" y2="6.2357" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2103" x2="0.6985" y2="6.2357" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2357" x2="7.0485" y2="6.2611" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2357" x2="0.6985" y2="6.2611" layer="200" rot="R180"/>
<rectangle x1="5.5499" y1="6.2611" x2="7.0485" y2="6.2865" layer="200" rot="R180"/>
<rectangle x1="-0.7747" y1="6.2611" x2="0.6985" y2="6.2865" layer="200" rot="R180"/>
<rectangle x1="5.5753" y1="6.2865" x2="7.0231" y2="6.3119" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="6.2865" x2="0.6731" y2="6.3119" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="6.3119" x2="7.0231" y2="6.3373" layer="200" rot="R180"/>
<rectangle x1="-0.7493" y1="6.3119" x2="0.6731" y2="6.3373" layer="200" rot="R180"/>
<rectangle x1="5.6007" y1="6.3373" x2="6.9977" y2="6.3627" layer="200" rot="R180"/>
<rectangle x1="-0.7239" y1="6.3373" x2="0.6477" y2="6.3627" layer="200" rot="R180"/>
<rectangle x1="5.6261" y1="6.3627" x2="6.9723" y2="6.3881" layer="200" rot="R180"/>
<rectangle x1="-0.6985" y1="6.3627" x2="0.6223" y2="6.3881" layer="200" rot="R180"/>
<rectangle x1="5.6769" y1="6.3881" x2="6.9215" y2="6.4135" layer="200" rot="R180"/>
<rectangle x1="-0.6223" y1="6.3881" x2="0.5461" y2="6.4135" layer="200" rot="R180"/>
<rectangle x1="5.7531" y1="6.4135" x2="6.8707" y2="6.4389" layer="200" rot="R180"/>
<text x="9.906" y="-6.8072" size="0.0508" layer="200" font="vector" rot="MR0">//kentro/work/Production/AOI Parts/Tyler/Breadboard power 5v/barreljack.bmp</text>
</package>
<package name="1X24_LOCK">
<wire x1="-14.605" y1="1.27" x2="-13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="1.27" x2="-12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="0.635" x2="-17.145" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="1.27" x2="-15.875" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="1.27" x2="-15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="-1.27" x2="-17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-17.78" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="1.27" x2="-15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-0.635" x2="-14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="-1.27" x2="-14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-20.955" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="1.27" x2="-20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="-0.635" x2="-20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="0.635" x2="-19.685" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="1.27" x2="-18.415" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="1.27" x2="-17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-0.635" x2="-18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="-1.27" x2="-19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-20.32" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-24.765" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="1.27" x2="-23.495" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="1.27" x2="-22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="-1.27" x2="-24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="-1.27" x2="-25.4" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="1.27" x2="-22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="-0.635" x2="-22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="-1.27" x2="-22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.305" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-27.305" y1="1.27" x2="-26.035" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-26.035" y1="1.27" x2="-25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-26.035" y1="-1.27" x2="-27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.305" y1="-1.27" x2="-27.94" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-2.54" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.2032" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="0.635" x2="-6.985" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="1.27" x2="-5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-7.62" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="1.27" x2="-10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="0.635" x2="-9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="1.27" x2="-8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="1.27" x2="-7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-0.635" x2="-8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="-1.27" x2="-9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-10.16" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="1.27" x2="-12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-0.635" x2="-12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="-1.27" x2="-12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="5.08" y2="0.635" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.985" y2="1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="7.62" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="10.16" y2="0.635" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="12.7" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="14.605" y2="1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="1.27" x2="15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="14.605" y1="-1.27" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="15.24" y2="0.635" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="17.145" y2="1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.24" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="17.78" y2="0.635" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.685" y2="1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="-1.27" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="20.32" y2="0.635" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="22.225" y2="1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-1.27" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.32" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="22.86" y2="0.635" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.765" y2="1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="-1.27" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.86" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="27.305" y2="1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="27.94" y2="0.635" width="0.2032" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="-1.27" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="25.4" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="1.27" x2="27.94" y2="0.635" width="0.2032" layer="21"/>
<wire x1="28.575" y1="1.27" x2="29.845" y2="1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="1.27" x2="30.48" y2="0.635" width="0.2032" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="-1.27" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.94" y1="-0.635" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="30.48" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="32.385" y2="1.27" width="0.2032" layer="21"/>
<wire x1="32.385" y1="1.27" x2="33.02" y2="0.635" width="0.2032" layer="21"/>
<wire x1="33.02" y1="0.635" x2="33.02" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="33.02" y1="-0.635" x2="32.385" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="32.385" y1="-1.27" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="30.48" y1="-0.635" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-27.94" y1="0.635" x2="-27.94" y2="-0.635" width="0.2032" layer="21"/>
<pad name="2" x="-26.67" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-24.13" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-21.59" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-19.05" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-16.51" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-13.97" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="-11.43" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="-8.89" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="-6.35" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="-3.81" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="-1.27" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="1.27" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="3.81" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="6.35" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="8.89" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="11.43" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="13.97" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="16.51" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="19.05" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="21.59" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="24.13" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="26.67" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="29.21" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="25" x="31.75" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-28.0162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-27.94" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-14.224" y1="-0.254" x2="-13.716" y2="0.254" layer="51"/>
<rectangle x1="-16.764" y1="-0.254" x2="-16.256" y2="0.254" layer="51"/>
<rectangle x1="-19.304" y1="-0.254" x2="-18.796" y2="0.254" layer="51"/>
<rectangle x1="-21.844" y1="-0.254" x2="-21.336" y2="0.254" layer="51"/>
<rectangle x1="-24.384" y1="-0.254" x2="-23.876" y2="0.254" layer="51"/>
<rectangle x1="-26.924" y1="-0.254" x2="-26.416" y2="0.254" layer="51"/>
<rectangle x1="3.556" y1="-0.254" x2="4.064" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="-4.064" y1="-0.254" x2="-3.556" y2="0.254" layer="51"/>
<rectangle x1="-6.604" y1="-0.254" x2="-6.096" y2="0.254" layer="51"/>
<rectangle x1="-9.144" y1="-0.254" x2="-8.636" y2="0.254" layer="51"/>
<rectangle x1="-11.684" y1="-0.254" x2="-11.176" y2="0.254" layer="51"/>
<rectangle x1="6.096" y1="-0.254" x2="6.604" y2="0.254" layer="51"/>
<rectangle x1="8.636" y1="-0.254" x2="9.144" y2="0.254" layer="51"/>
<rectangle x1="11.176" y1="-0.254" x2="11.684" y2="0.254" layer="51"/>
<rectangle x1="13.716" y1="-0.254" x2="14.224" y2="0.254" layer="51"/>
<rectangle x1="16.256" y1="-0.254" x2="16.764" y2="0.254" layer="51"/>
<rectangle x1="18.796" y1="-0.254" x2="19.304" y2="0.254" layer="51"/>
<rectangle x1="21.336" y1="-0.254" x2="21.844" y2="0.254" layer="51"/>
<rectangle x1="23.876" y1="-0.254" x2="24.384" y2="0.254" layer="51"/>
<rectangle x1="26.416" y1="-0.254" x2="26.924" y2="0.254" layer="51"/>
<rectangle x1="28.956" y1="-0.254" x2="29.464" y2="0.254" layer="51"/>
<rectangle x1="31.496" y1="-0.254" x2="32.004" y2="0.254" layer="51"/>
</package>
<package name="1X11_NO_SILK_KIT">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<circle x="0" y="0" radius="0.508" width="0" layer="29"/>
<circle x="0" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="2.54" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="5.08" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="7.62" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="10.16" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="12.7" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="15.24" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="17.78" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="20.32" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="22.86" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="25.4" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="2.54" y="0" radius="0.508" width="0" layer="29"/>
<circle x="5.08" y="0" radius="0.508" width="0" layer="29"/>
<circle x="7.62" y="0" radius="0.508" width="0" layer="29"/>
<circle x="10.16" y="0" radius="0.508" width="0" layer="29"/>
<circle x="12.7" y="0" radius="0.508" width="0" layer="29"/>
<circle x="15.24" y="0" radius="0.508" width="0" layer="29"/>
<circle x="17.78" y="0" radius="0.508" width="0" layer="29"/>
<circle x="20.32" y="0" radius="0.508" width="0" layer="29"/>
<circle x="22.86" y="0" radius="0.508" width="0" layer="29"/>
<circle x="25.4" y="0" radius="0.508" width="0" layer="29"/>
</package>
<package name="JST-6-SMD-VERT-1.0MM">
<circle x="-2.54" y="2.54" radius="0.1047" width="0.4064" layer="21"/>
<wire x1="-2.54" y1="-1.651" x2="2.54" y2="-1.651" width="0.254" layer="21"/>
<wire x1="-4.318" y1="0.508" x2="-4.318" y2="1.905" width="0.254" layer="21"/>
<wire x1="3.302" y1="1.905" x2="4.318" y2="1.905" width="0.254" layer="21"/>
<wire x1="4.318" y1="1.905" x2="4.318" y2="0.508" width="0.254" layer="21"/>
<wire x1="-4.318" y1="1.905" x2="-3.302" y2="1.905" width="0.254" layer="21"/>
<smd name="1" x="-2.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="2" x="-1.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="3" x="-0.54" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="4" x="0.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="5" x="1.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="6" x="2.46" y="1.27" dx="0.6" dy="1.55" layer="1"/>
<smd name="P$1" x="-3.84" y="-0.955" dx="1.2" dy="1.8" layer="1"/>
<smd name="P$2" x="3.76" y="-0.955" dx="1.2" dy="1.8" layer="1"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="-2.54" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="2X3_SMD">
<circle x="0" y="1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="-2.54" y="1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="-2.54" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="0" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="2.54" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="2.54" y="1.27" radius="0.7" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-2.5" x2="-3.81" y2="2.5" width="0.127" layer="51"/>
<wire x1="-3.81" y1="2.5" x2="3.81" y2="2.5" width="0.127" layer="51"/>
<wire x1="3.81" y1="2.5" x2="3.81" y2="-2.5" width="0.127" layer="51"/>
<wire x1="3.81" y1="-2.5" x2="-3.81" y2="-2.5" width="0.127" layer="51"/>
<rectangle x1="-0.3" y1="2.55" x2="0.3" y2="3.35" layer="51"/>
<rectangle x1="-2.84" y1="2.55" x2="-2.24" y2="3.35" layer="51"/>
<rectangle x1="2.24" y1="2.55" x2="2.84" y2="3.35" layer="51"/>
<rectangle x1="-2.84" y1="-3.35" x2="-2.24" y2="-2.55" layer="51" rot="R180"/>
<rectangle x1="-0.3" y1="-3.35" x2="0.3" y2="-2.55" layer="51" rot="R180"/>
<rectangle x1="2.24" y1="-3.35" x2="2.84" y2="-2.55" layer="51" rot="R180"/>
<smd name="1" x="-2.54" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="2" x="-2.54" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="3" x="0" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="4" x="0" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="5" x="2.54" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="6" x="2.54" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<text x="-3.502" y="0.1" size="0.4064" layer="25">&gt;Name</text>
<text x="-3.502" y="-0.408" size="0.4064" layer="27">&gt;Value</text>
</package>
<package name="POWER_JACK_PTH_BREAD">
<description>&lt;h1&gt;DC Barrel Jack Adapter - Breadboard Compatible&lt;/h1&gt;
&lt;h2&gt;PRT-10811&lt;/h2&gt;</description>
<wire x1="4.5" y1="14.6" x2="0.9" y2="14.6" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3.6" x2="-4.5" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.5" y1="0.1" x2="4.5" y2="3.4" width="0.2032" layer="51"/>
<wire x1="4.5" y1="0.1" x2="-4.5" y2="0.1" width="0.2032" layer="51"/>
<wire x1="4.5" y1="3.6" x2="4.5" y2="9.5" width="0.2032" layer="21"/>
<wire x1="4.5" y1="14.6" x2="4.5" y2="11.9" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3.6" x2="-4.5" y2="14.6" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="14.6" x2="-0.9" y2="14.6" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="3.6" x2="4.5" y2="3.6" width="0.2032" layer="21"/>
<pad name="PWR" x="0" y="13.7" drill="1.3"/>
<pad name="GND" x="0" y="7.9" drill="1.3"/>
<pad name="GNDBREAK" x="4.8" y="10.7" drill="1.3" rot="R90"/>
<text x="-3.81" y="5.08" size="0.4064" layer="25">&gt;NAME</text>
<text x="-3.81" y="4.06" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X08_NO_SILK">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
</package>
<package name="1X10_NO_SILK">
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
</package>
<package name="1X08_PIN1_NO_SILK">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
</package>
<package name="1X23">
<wire x1="30.48" y1="0.635" x2="30.48" y2="-0.635" width="0.2032" layer="21"/>
<pad name="2" x="-26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="-24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X23_LOCK">
</package>
<package name="1X23_LONGPADS">
<pad name="2" x="-26.67" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<pad name="25" x="31.75" y="0" drill="1.1176" diameter="1.8796" shape="long" rot="R90"/>
<text x="-28.0162" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-27.94" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="JST-3-PTH-VERT">
<description>This 3-pin connector mates with the JST cable sold on SparkFun.</description>
<wire x1="-3.95" y1="-2.25" x2="-3.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="-3.95" y1="2.25" x2="3.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="3.95" y1="2.25" x2="3.95" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="3.95" y1="-2.25" x2="1" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1" y1="-2.25" x2="-3.95" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1.75" x2="1" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-1.75" x2="1" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1.75" x2="-1" y2="-2.25" width="0.2032" layer="21"/>
<pad name="1" x="-2" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="2" x="0" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="3" x="2" y="-0.55" drill="0.7" diameter="1.6"/>
<text x="-3" y="3" size="0.4064" layer="25">&gt;Name</text>
<text x="1" y="3" size="0.4064" layer="27">&gt;Value</text>
<text x="-2.4" y="0.75" size="1.27" layer="51">+</text>
<text x="-0.4" y="0.75" size="1.27" layer="51">-</text>
<text x="1.7" y="0.95" size="0.8" layer="51">S</text>
</package>
<package name="JST-2-PTH-VERT">
<wire x1="-2.95" y1="-2.25" x2="-2.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="2.25" x2="2.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="2.95" y1="2.25" x2="2.95" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="2.95" y1="-2.25" x2="1" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1" y1="-2.25" x2="-2.95" y2="-2.25" width="0.2032" layer="21"/>
<pad name="1" x="-1" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="2" x="1" y="-0.55" drill="0.7" diameter="1.6"/>
<text x="-1.984" y="3" size="0.4064" layer="25">&gt;Name</text>
<text x="2.016" y="3" size="0.4064" layer="27">&gt;Value</text>
<text x="0.616" y="0.75" size="1.27" layer="51">+</text>
<text x="-1.384" y="0.75" size="1.27" layer="51">-</text>
</package>
<package name="JST-4-PTH-VERT">
<wire x1="-4.95" y1="-2.25" x2="-4.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="-4.95" y1="2.25" x2="4.95" y2="2.25" width="0.2032" layer="21"/>
<wire x1="4.95" y1="-2.25" x2="1" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="-1" y1="-2.25" x2="-4.95" y2="-2.25" width="0.2032" layer="21"/>
<wire x1="4.95" y1="2.25" x2="4.95" y2="-2.25" width="0.2032" layer="21"/>
<pad name="1" x="-3" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="2" x="-1" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="3" x="1" y="-0.55" drill="0.7" diameter="1.6"/>
<pad name="4" x="3" y="-0.55" drill="0.7" diameter="1.6"/>
<text x="-1.4" y="0.75" size="1.27" layer="51">+</text>
<text x="0.6" y="0.75" size="1.27" layer="51">-</text>
<text x="2.7" y="0.95" size="0.8" layer="51">Y</text>
<text x="-3.3" y="0.95" size="0.8" layer="51">B</text>
</package>
<package name="STEREOJACK2.5MM">
<wire x1="-1.5" y1="1.3" x2="-1.5" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="2.5" x2="-0.096" y2="2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="1.3" x2="-1.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-1.3" x2="-1.5" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-1.5" y1="-2.5" x2="-0.1206" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="1.996" y1="2.5" x2="5.0516" y2="2.5" width="0.2032" layer="21"/>
<wire x1="2.073" y1="-2.5" x2="5.077" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="1.3" x2="-1.5" y2="1.3" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="1.3" x2="-2.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="-1.3" x2="-1.5" y2="-1.3" width="0.2032" layer="21"/>
<wire x1="6.773" y1="2.5" x2="7.9" y2="2.5" width="0.2032" layer="21"/>
<wire x1="7.9" y1="2.5" x2="7.9" y2="0.9738" width="0.2032" layer="21"/>
<wire x1="6.8484" y1="-2.5" x2="7.9" y2="-2.5" width="0.2032" layer="21"/>
<wire x1="7.9" y1="-2.5" x2="7.9" y2="-0.873" width="0.2032" layer="21"/>
<smd name="5" x="1" y="2.9516" dx="1.4666" dy="2.3" layer="1"/>
<smd name="A" x="1.016" y="-2.9516" dx="1.4666" dy="2.3" layer="1"/>
<smd name="4" x="5.9492" y="-2.54" dx="2.1" dy="1.119" layer="1" rot="R90"/>
<smd name="1" x="5.8984" y="2.54" dx="2.1" dy="1.1444" layer="1" rot="R90"/>
<smd name="3" x="8.55" y="0" dx="1.9984" dy="1.1698" layer="1" rot="R180"/>
<hole x="0" y="0" drill="1.2"/>
<hole x="4" y="0" drill="1.2"/>
</package>
<package name="1X12_NO_SILK_KIT">
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<circle x="27.94" y="0" radius="0.9525" width="0" layer="30"/>
<circle x="27.94" y="0" radius="0.508" width="0" layer="29"/>
</package>
<package name="1X06_NO_SILK">
</package>
<package name="BC9VPC_KIT">
<wire x1="0" y1="0" x2="0" y2="29.972" width="0.127" layer="21"/>
<wire x1="0" y1="29.972" x2="54.864" y2="29.972" width="0.127" layer="21"/>
<wire x1="54.864" y1="29.972" x2="54.864" y2="0" width="0.127" layer="21"/>
<wire x1="54.864" y1="0" x2="0" y2="0" width="0.127" layer="21"/>
<pad name="V+" x="53.086" y="21.336" drill="2.032" shape="square" stop="no"/>
<pad name="V-" x="53.086" y="8.382" drill="2.032" shape="square" stop="no"/>
<text x="49.276" y="20.828" size="1.27" layer="21">V+</text>
<text x="49.276" y="7.874" size="1.27" layer="21">V-</text>
<hole x="27.178" y="3.81" drill="2.286"/>
<hole x="13.716" y="26.162" drill="2.286"/>
<hole x="40.64" y="26.162" drill="2.286"/>
<rectangle x1="51.562" y1="19.812" x2="54.61" y2="22.86" layer="30"/>
<rectangle x1="51.562" y1="6.858" x2="54.61" y2="9.906" layer="30"/>
</package>
<package name="SD_1:1">
<smd name="1" x="-1" y="6.77" dx="1.8" dy="0.9" layer="1"/>
<smd name="2" x="-1" y="4.27" dx="1.8" dy="0.9" layer="1"/>
<smd name="3" x="-1" y="2.52" dx="1.8" dy="0.9" layer="1"/>
<smd name="CD" x="-1" y="1.02" dx="1.8" dy="0.9" layer="1"/>
<smd name="4" x="-1" y="-0.73" dx="1.8" dy="0.9" layer="1"/>
<smd name="5" x="-1" y="-3.23" dx="1.8" dy="0.9" layer="1"/>
<smd name="6" x="-1" y="-5.73" dx="1.8" dy="0.9" layer="1"/>
<smd name="7" x="-1" y="-8.15" dx="1.8" dy="0.9" layer="1"/>
<smd name="8" x="-1" y="-9.85" dx="1.8" dy="0.9" layer="1"/>
<smd name="SH@1" x="20" y="14.496" dx="2" dy="1.4" layer="1"/>
<smd name="SH@2" x="21.15" y="-13.589" dx="2" dy="1.527" layer="1"/>
<smd name="WP" x="-1" y="-13" dx="1.8" dy="1.1" layer="1"/>
<smd name="9" x="-1" y="9.27" dx="1.8" dy="0.9" layer="1"/>
<wire x1="0" y1="14.25" x2="28.8" y2="14.25" width="0.127" layer="51"/>
<wire x1="28.8" y1="14.25" x2="28.8" y2="10" width="0.127" layer="51"/>
<wire x1="28.8" y1="10" x2="28.8" y2="-10.5" width="0.127" layer="51"/>
<wire x1="28.8" y1="-10.5" x2="28.8" y2="-14.25" width="0.127" layer="51"/>
<wire x1="28.8" y1="-14.25" x2="0" y2="-14.25" width="0.127" layer="51"/>
<wire x1="0" y1="-14.25" x2="0" y2="14.25" width="0.127" layer="51"/>
<hole x="23.3" y="11.94" drill="1.55"/>
<hole x="23.3" y="-12.32" drill="1.55"/>
<text x="0.54" y="12.94" size="0.4064" layer="25">&gt;NAME</text>
<text x="0.54" y="11.67" size="0.4064" layer="27">&gt;VALUE</text>
<wire x1="-0.095" y1="10.019" x2="-0.095" y2="14.418" width="0.254" layer="21"/>
<wire x1="-0.095" y1="14.418" x2="5.239" y2="14.418" width="0.254" layer="21"/>
<wire x1="21.849" y1="14.318" x2="28.888" y2="14.318" width="0.254" layer="21"/>
<wire x1="28.888" y1="14.318" x2="28.9" y2="12.9" width="0.254" layer="21"/>
<wire x1="23.011" y1="-14.327" x2="28.888" y2="-14.327" width="0.254" layer="21"/>
<wire x1="28.888" y1="-14.327" x2="28.888" y2="-13.349" width="0.254" layer="21"/>
<wire x1="-0.095" y1="-14.238" x2="-0.095" y2="-14.327" width="0.254" layer="21"/>
<wire x1="-0.095" y1="-14.327" x2="5.239" y2="-14.327" width="0.254" layer="21"/>
<wire x1="35.6" y1="12" x2="35.6" y2="-13" width="0.127" layer="51"/>
<text x="34.9" y="-9.3" size="1.27" layer="51" rot="R90">card lock position</text>
<wire x1="28.8" y1="10" x2="28" y2="10" width="0.127" layer="51"/>
<wire x1="28" y1="10" x2="18" y2="0" width="0.127" layer="51" curve="90"/>
<wire x1="28" y1="-10.5" x2="18" y2="-0.5" width="0.127" layer="51" curve="-90"/>
<wire x1="18" y1="0" x2="18" y2="-0.5" width="0.127" layer="51"/>
<wire x1="28" y1="-10.5" x2="28.8" y2="-10.5" width="0.127" layer="51"/>
</package>
<package name="2X3_TEST_POINTS">
<pad name="1" x="-2.54" y="-1.27" drill="0.508" stop="no"/>
<pad name="2" x="-2.54" y="1.27" drill="0.508" stop="no"/>
<pad name="3" x="0" y="-1.27" drill="0.508" stop="no"/>
<pad name="4" x="0" y="1.27" drill="0.508" stop="no"/>
<pad name="5" x="2.54" y="-1.27" drill="0.508" stop="no"/>
<pad name="6" x="2.54" y="1.27" drill="0.508" stop="no"/>
<wire x1="-2.8956" y1="-2.0574" x2="-2.2098" y2="-2.0574" width="0.2032" layer="21"/>
<circle x="-2.54" y="1.27" radius="0.61065625" width="0" layer="29"/>
<circle x="0" y="1.27" radius="0.61065625" width="0" layer="29"/>
<circle x="2.54" y="1.27" radius="0.61065625" width="0" layer="29"/>
<circle x="-2.54" y="-1.27" radius="0.61065625" width="0" layer="29"/>
<circle x="0" y="-1.27" radius="0.61065625" width="0" layer="29"/>
<circle x="2.54" y="-1.27" radius="0.61065625" width="0" layer="29"/>
</package>
<package name="USB-A-SMT-MALE-LOCKING">
<wire x1="6" y1="14.58" x2="-6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="6" y1="0" x2="-6" y2="0" width="0.2032" layer="21"/>
<wire x1="6" y1="0" x2="6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="-6" y1="0" x2="-6" y2="14.58" width="0.2032" layer="51"/>
<wire x1="6" y1="0" x2="6" y2="-1.22" width="0.2032" layer="21"/>
<wire x1="-6" y1="0" x2="-6" y2="-1.22" width="0.2032" layer="21"/>
<wire x1="-4" y1="-4.22" x2="4" y2="-4.22" width="0.2032" layer="21"/>
<wire x1="4.3" y1="10.28" x2="1.9" y2="10.28" width="0.2032" layer="51"/>
<wire x1="1.9" y1="10.28" x2="1.9" y2="7.98" width="0.2032" layer="51"/>
<wire x1="1.9" y1="7.98" x2="4.3" y2="7.98" width="0.2032" layer="51"/>
<wire x1="4.3" y1="7.98" x2="4.3" y2="10.28" width="0.2032" layer="51"/>
<wire x1="-1.9" y1="10.28" x2="-4.3" y2="10.28" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="10.28" x2="-4.3" y2="7.98" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="7.98" x2="-1.9" y2="7.98" width="0.2032" layer="51"/>
<wire x1="-1.9" y1="7.98" x2="-1.9" y2="10.28" width="0.2032" layer="51"/>
<smd name="D+1" x="1.027" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<smd name="D-1" x="-1.027" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<smd name="GND1" x="3.5508" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<pad name="P$1" x="5.6468" y="-3.05" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<pad name="P$3" x="-5.6468" y="-3.05" drill="0.8" diameter="1.778" shape="long" rot="R90"/>
<smd name="VBUS1" x="-3.5" y="-5.87" dx="2.5" dy="0.8" layer="1" rot="R270"/>
<text x="-2.7" y="-9.07" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.4" y="0.68" size="1.27" layer="51">PCB Edge</text>
<hole x="2.25" y="-3.12" drill="1.1"/>
<hole x="-2.25" y="-3.12" drill="1.1"/>
<hole x="-5.6468" y="-3.45" drill="0.8"/>
<hole x="-5.6468" y="-3.85" drill="0.8"/>
<hole x="-5.6468" y="-2.65" drill="0.8"/>
<hole x="-5.6468" y="-2.25" drill="0.8"/>
<hole x="5.6468" y="-3.45" drill="0.8"/>
<hole x="5.6468" y="-3.85" drill="0.8"/>
<hole x="5.6468" y="-2.65" drill="0.8"/>
<hole x="5.6468" y="-2.25" drill="0.8"/>
<wire x1="-5.9944" y1="-4.064" x2="-5.9944" y2="-2.0828" width="0" layer="51"/>
<wire x1="-6.1849" y1="-4.064" x2="-6.1849" y2="-2.032" width="0" layer="51"/>
<wire x1="-5.6642" y1="-4.064" x2="-5.6642" y2="-2.0828" width="0" layer="51"/>
<rectangle x1="-5.9944" y1="-4.064" x2="-5.6642" y2="-2.032" layer="51"/>
<wire x1="6.1849" y1="-2.032" x2="6.1849" y2="-4.064" width="0" layer="51"/>
<rectangle x1="5.6642" y1="-4.064" x2="5.9944" y2="-2.032" layer="51" rot="R180"/>
</package>
<package name="1X03_SMD_RA_MALE_POST_SMALLER">
<wire x1="3.81" y1="1.25" x2="-3.81" y2="1.25" width="0.1778" layer="51"/>
<wire x1="-3.81" y1="1.25" x2="-3.81" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="2.53" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="2.53" y1="-1.25" x2="-0.01" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="-0.01" y1="-1.25" x2="-2.55" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="-2.55" y1="-1.25" x2="-3.81" y2="-1.25" width="0.1778" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="1.25" width="0.1778" layer="51"/>
<wire x1="2.53" y1="-1.25" x2="2.53" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-0.01" y1="-1.25" x2="-0.01" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-2.55" y1="-1.25" x2="-2.55" y2="-7.25" width="0.127" layer="51"/>
<rectangle x1="-0.32" y1="4.15" x2="0.32" y2="5.95" layer="51"/>
<rectangle x1="-2.86" y1="4.15" x2="-2.22" y2="5.95" layer="51"/>
<rectangle x1="2.22" y1="4.15" x2="2.86" y2="5.95" layer="51"/>
<smd name="1" x="-2.54" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<smd name="2" x="0" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<smd name="3" x="2.54" y="5.07" dx="2.5" dy="1.27" layer="1" rot="R90"/>
<hole x="-1.27" y="0" drill="1.3589"/>
<hole x="1.27" y="0" drill="1.3589"/>
</package>
<package name="1X03_SMD_RA_MALE_POST_SMALLEST">
<hole x="-1.27" y="0" drill="1.3462"/>
<hole x="1.27" y="0" drill="1.3462"/>
</package>
<package name="1X13_LOCK">
<wire x1="14.605" y1="1.27" x2="15.875" y2="1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="15.875" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="11.43" y1="0.635" x2="12.065" y2="1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="1.27" x2="13.335" y2="1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="14.605" y1="1.27" x2="13.97" y2="0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="-0.635" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="14.605" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="8.255" y2="1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="1.27" x2="8.89" y2="0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.89" y1="0.635" x2="9.525" y2="1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="1.27" x2="10.795" y2="1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="1.27" x2="11.43" y2="0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.985" y1="1.27" x2="6.35" y2="0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="6.985" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.905" y2="1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="18.415" y2="1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="1.27" x2="19.05" y2="0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="18.415" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="17.145" y1="1.27" x2="16.51" y2="0.635" width="0.2032" layer="21"/>
<wire x1="16.51" y1="-0.635" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="17.145" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="1.27" x2="20.955" y2="1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="20.955" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.685" y1="1.27" x2="19.05" y2="0.635" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-0.635" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="20.955" y1="-1.27" x2="19.685" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="23.495" y2="1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="23.495" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="22.225" y1="1.27" x2="21.59" y2="0.635" width="0.2032" layer="21"/>
<wire x1="21.59" y1="-0.635" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="23.495" y1="-1.27" x2="22.225" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="26.035" y2="1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="1.27" x2="26.67" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="26.035" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="24.765" y1="1.27" x2="24.13" y2="0.635" width="0.2032" layer="21"/>
<wire x1="24.13" y1="-0.635" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="26.035" y1="-1.27" x2="24.765" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="28.575" y2="1.27" width="0.2032" layer="21"/>
<wire x1="31.75" y1="0.635" x2="31.75" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="27.305" y1="1.27" x2="26.67" y2="0.635" width="0.2032" layer="21"/>
<wire x1="26.67" y1="-0.635" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="28.575" y1="-1.27" x2="27.305" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="5" x="10.16" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="7" x="15.24" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="11" x="25.4" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51" rot="R90"/>
<rectangle x1="25.146" y1="-0.254" x2="25.654" y2="0.254" layer="51"/>
<rectangle x1="27.686" y1="-0.254" x2="28.194" y2="0.254" layer="51"/>
<wire x1="28.575" y1="1.27" x2="29.21" y2="0.635" width="0.2032" layer="21"/>
<wire x1="29.21" y1="-0.635" x2="28.575" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="1.27" x2="31.115" y2="1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="1.27" x2="31.75" y2="0.635" width="0.2032" layer="21"/>
<wire x1="31.75" y1="-0.635" x2="31.115" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="29.845" y1="1.27" x2="29.21" y2="0.635" width="0.2032" layer="21"/>
<wire x1="29.21" y1="-0.635" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="31.115" y1="-1.27" x2="29.845" y2="-1.27" width="0.2032" layer="21"/>
<pad name="13" x="30.48" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="30.226" y1="-0.254" x2="30.734" y2="0.254" layer="51"/>
</package>
<package name="BINDING_POST">
<wire x1="-0.5" y1="-3.5" x2="0.5" y2="-3.5" width="0.127" layer="20"/>
<wire x1="0.5" y1="-3.5" x2="4" y2="0" width="0.127" layer="20" curve="90"/>
<wire x1="4" y1="0" x2="0.5" y2="3.5" width="0.127" layer="20" curve="90"/>
<wire x1="-0.5" y1="3.5" x2="-4" y2="0" width="0.127" layer="20" curve="90"/>
<wire x1="-4" y1="0" x2="-0.5" y2="-3.5" width="0.127" layer="20" curve="90"/>
<pad name="P$1" x="0" y="7.62" drill="1.5"/>
<circle x="0" y="0" radius="6.300790625" width="0.127" layer="40"/>
<circle x="0" y="0" radius="5.5" width="0.127" layer="39"/>
<circle x="0" y="0" radius="5.5" width="0.254" layer="21"/>
<text x="2" y="9" size="1.27" layer="25">&gt;NAME</text>
<text x="2" y="6.46" size="1.27" layer="25">&gt;VALUE</text>
<wire x1="0.5" y1="3.5" x2="-0.5" y2="3.5" width="0.127" layer="20"/>
<wire x1="0.5" y1="-3.5" x2="4" y2="0" width="0.127" layer="21" curve="90"/>
<wire x1="4" y1="0" x2="0.5" y2="3.5" width="0.127" layer="21" curve="90"/>
<wire x1="-0.5" y1="3.5" x2="-4" y2="0" width="0.127" layer="21" curve="90"/>
<wire x1="0.5" y1="3.5" x2="-0.5" y2="3.5" width="0.127" layer="21"/>
<wire x1="-4" y1="0" x2="-0.5" y2="-3.5" width="0.127" layer="21" curve="90"/>
<wire x1="-0.5" y1="-3.5" x2="0.5" y2="-3.5" width="0.127" layer="21"/>
</package>
<package name="1X04_SMD_RA_FEMALE">
<wire x1="-5.205" y1="4.25" x2="-5.205" y2="-4.25" width="0.1778" layer="21"/>
<wire x1="5.205" y1="4.25" x2="-5.205" y2="4.25" width="0.1778" layer="21"/>
<wire x1="5.205" y1="-4.25" x2="5.205" y2="4.25" width="0.1778" layer="21"/>
<wire x1="-5.205" y1="-4.25" x2="5.205" y2="-4.25" width="0.1778" layer="21"/>
<rectangle x1="-1.59" y1="6.8" x2="-0.95" y2="7.65" layer="51"/>
<rectangle x1="0.95" y1="6.8" x2="1.59" y2="7.65" layer="51"/>
<rectangle x1="-4.13" y1="6.8" x2="-3.49" y2="7.65" layer="51"/>
<smd name="3" x="1.27" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="2" x="-1.27" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<smd name="1" x="-3.81" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
<text x="-4.425" y="2.775" size="1" layer="27">&gt;Value</text>
<text x="-4.225" y="-3.395" size="1" layer="25">&gt;Name</text>
<rectangle x1="3.49" y1="6.8" x2="4.13" y2="7.65" layer="51"/>
<smd name="4" x="3.81" y="7.225" dx="1.25" dy="3" layer="1" rot="R180"/>
</package>
<package name="1X04-1.5MM_JST">
<pad name="4" x="4.5" y="0" drill="0.7"/>
<pad name="3" x="3" y="0" drill="0.7"/>
<pad name="2" x="1.5" y="0" drill="0.7"/>
<pad name="1" x="0" y="0" drill="0.7"/>
<text x="-0.508" y="1.27" size="0.4064" layer="25">&gt;NAME</text>
<text x="-0.508" y="-1.651" size="0.4064" layer="27">&gt;VALUE</text>
<wire x1="-1.5" y1="2.2" x2="6" y2="2.2" width="0.3048" layer="21"/>
<wire x1="6" y1="2.2" x2="6" y2="-1.5" width="0.3048" layer="21"/>
<wire x1="6" y1="-1.5" x2="4.5" y2="-1.5" width="0.3048" layer="21"/>
<wire x1="4.5" y1="-1.5" x2="4.5" y2="-1" width="0.3048" layer="21"/>
<wire x1="4.5" y1="-1" x2="0" y2="-1" width="0.3048" layer="21"/>
<wire x1="0" y1="-1" x2="0" y2="-1.5" width="0.3048" layer="21"/>
<wire x1="0" y1="-1.5" x2="-1.5" y2="-1.5" width="0.3048" layer="21"/>
<wire x1="-1.5" y1="-1.5" x2="-1.5" y2="2.2" width="0.3048" layer="21"/>
</package>
<package name="1X17_NO_SILK">
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="13" x="30.48" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="14" x="33.02" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="35.56" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="16" x="38.1" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="40.64" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="32.766" y1="-0.254" x2="33.274" y2="0.254" layer="51"/>
<rectangle x1="35.306" y1="-0.254" x2="35.814" y2="0.254" layer="51"/>
<rectangle x1="37.846" y1="-0.254" x2="38.354" y2="0.254" layer="51"/>
<rectangle x1="40.386" y1="-0.254" x2="40.894" y2="0.254" layer="51"/>
</package>
<package name="1X17_NO_SILK_KIT">
<pad name="13" x="30.48" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="14" x="33.02" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="15" x="35.56" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="16" x="38.1" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="17" x="40.64" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<circle x="0" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="2.54" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="5.08" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="7.62" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="10.16" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="12.7" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="15.24" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="17.78" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="20.32" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="22.86" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="25.4" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="27.94" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="30.48" y="0" radius="0.508" width="0" layer="29"/>
<circle x="30.48" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="33.02" y="0" radius="0.508" width="0" layer="29"/>
<circle x="33.02" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="35.56" y="0" radius="0.508" width="0" layer="29"/>
<circle x="35.56" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="38.1" y="0" radius="0.508" width="0" layer="29"/>
<circle x="38.1" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="40.64" y="0" radius="0.508" width="0" layer="29"/>
<circle x="40.64" y="0" radius="0.9398" width="0" layer="30"/>
</package>
<package name="JST-5-PTH">
<pad name="1" x="-4" y="0" drill="0.7" diameter="1.6"/>
<pad name="2" x="-2" y="0" drill="0.7" diameter="1.6"/>
<pad name="3" x="0" y="0" drill="0.7" diameter="1.6"/>
<pad name="4" x="2" y="0" drill="0.7" diameter="1.6"/>
<text x="-3.27" y="5.27" size="0.4064" layer="25">&gt;Name</text>
<text x="-3.27" y="4" size="0.4064" layer="27">&gt;Value</text>
<pad name="5" x="4" y="0" drill="0.7" diameter="1.6"/>
<wire x1="-5.95" y1="-1.6" x2="-5.95" y2="6" width="0.2032" layer="21"/>
<wire x1="-5.95" y1="6" x2="5.95" y2="6" width="0.2032" layer="21"/>
<wire x1="5.95" y1="6" x2="5.95" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-5.95" y1="-1.6" x2="-5.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-1.6" x2="5.3" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-5.3" y1="-1.6" x2="-5.3" y2="0" width="0.2032" layer="21"/>
<wire x1="5.3" y1="-1.6" x2="5.3" y2="0" width="0.2032" layer="21"/>
</package>
<package name="JST-5-PTH-VERT">
<wire x1="-5.95" y1="-1.52" x2="-5.95" y2="2.98" width="0.2032" layer="21"/>
<wire x1="-5.95" y1="2.98" x2="5.95" y2="2.98" width="0.2032" layer="21"/>
<wire x1="5.95" y1="-1.52" x2="1" y2="-1.52" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1.52" x2="-5.95" y2="-1.52" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1.02" x2="1" y2="-1.02" width="0.2032" layer="21"/>
<wire x1="1" y1="-1.02" x2="1" y2="-1.52" width="0.2032" layer="21"/>
<wire x1="-1" y1="-1.02" x2="-1" y2="-1.52" width="0.2032" layer="21"/>
<wire x1="5.95" y1="2.98" x2="5.95" y2="-1.52" width="0.2032" layer="21"/>
<pad name="1" x="-4" y="0.18" drill="0.7" diameter="1.6"/>
<pad name="2" x="-2" y="0.18" drill="0.7" diameter="1.6"/>
<pad name="3" x="0" y="0.18" drill="0.7" diameter="1.6"/>
<pad name="4" x="2" y="0.18" drill="0.7" diameter="1.6"/>
<text x="-4" y="3.73" size="0.4064" layer="25">&gt;Name</text>
<text x="0" y="3.73" size="0.4064" layer="27">&gt;Value</text>
<pad name="5" x="4" y="0.18" drill="0.7" diameter="1.6"/>
</package>
<package name="1X12_NO_SILK">
</package>
<package name="2X5_SMD">
<circle x="-5.08" y="1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="-5.08" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-2.5" x2="-6.35" y2="2.5" width="0.127" layer="51"/>
<wire x1="-6.35" y1="2.5" x2="6.35" y2="2.5" width="0.127" layer="51"/>
<wire x1="6.35" y1="2.5" x2="6.35" y2="-2.5" width="0.127" layer="51"/>
<wire x1="6.35" y1="-2.5" x2="-6.35" y2="-2.5" width="0.127" layer="51"/>
<rectangle x1="-5.38" y1="2.55" x2="-4.78" y2="3.35" layer="51"/>
<rectangle x1="-5.38" y1="-3.35" x2="-4.78" y2="-2.55" layer="51" rot="R180"/>
<smd name="1" x="-5.08" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="2" x="-5.08" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="3" x="-2.54" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="4" x="-2.54" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="5" x="0" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="6" x="0" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<text x="-6.042" y="0.1" size="0.4064" layer="25">&gt;Name</text>
<text x="-6.042" y="-0.408" size="0.4064" layer="27">&gt;Value</text>
<smd name="7" x="2.54" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="8" x="2.54" y="2.85" dx="1.02" dy="1.9" layer="1"/>
<circle x="5.08" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="5.08" y="1.27" radius="0.7" width="0.127" layer="51"/>
<rectangle x1="4.78" y1="2.55" x2="5.38" y2="3.35" layer="51"/>
<rectangle x1="4.78" y1="-3.35" x2="5.38" y2="-2.55" layer="51" rot="R180"/>
<smd name="9" x="5.08" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="10" x="5.08" y="2.85" dx="1.02" dy="1.9" layer="1"/>
</package>
<package name="2X6_SMD">
<wire x1="-6.35" y1="2.5" x2="8.89" y2="2.5" width="0.127" layer="51"/>
<wire x1="8.89" y1="2.5" x2="8.89" y2="-2.5" width="0.127" layer="51"/>
<wire x1="8.89" y1="-2.5" x2="-6.35" y2="-2.5" width="0.127" layer="51"/>
<circle x="7.62" y="-1.27" radius="0.7" width="0.127" layer="51"/>
<circle x="7.62" y="1.27" radius="0.7" width="0.127" layer="51"/>
<rectangle x1="7.32" y1="2.55" x2="7.92" y2="3.35" layer="51"/>
<rectangle x1="7.32" y1="-3.35" x2="7.92" y2="-2.55" layer="51" rot="R180"/>
<smd name="11" x="7.62" y="-2.85" dx="1.02" dy="1.9" layer="1"/>
<smd name="12" x="7.62" y="2.85" dx="1.02" dy="1.9" layer="1"/>
</package>
<package name="2X5_PTH_SILK_.05">
<pad name="1" x="0" y="6.35" drill="0.4318" shape="square"/>
<pad name="2" x="1.27" y="6.35" drill="0.4318"/>
<pad name="3" x="0" y="5.08" drill="0.4318"/>
<pad name="4" x="1.27" y="5.08" drill="0.4318"/>
<pad name="5" x="0" y="3.81" drill="0.4318"/>
<pad name="6" x="1.27" y="3.81" drill="0.4318"/>
<pad name="7" x="0" y="2.54" drill="0.4318"/>
<pad name="8" x="1.27" y="2.54" drill="0.4318"/>
<pad name="9" x="0" y="1.27" drill="0.4318"/>
<pad name="10" x="1.27" y="1.27" drill="0.4318"/>
<wire x1="0.635" y1="6.985" x2="0.762" y2="7.112" width="0.127" layer="21"/>
<wire x1="0.762" y1="7.112" x2="1.778" y2="7.112" width="0.127" layer="21"/>
<wire x1="1.778" y1="7.112" x2="2.032" y2="6.858" width="0.127" layer="21"/>
<wire x1="2.032" y1="6.858" x2="2.032" y2="5.842" width="0.127" layer="21"/>
<wire x1="2.032" y1="5.842" x2="1.905" y2="5.715" width="0.127" layer="21"/>
<wire x1="1.905" y1="5.715" x2="2.032" y2="5.588" width="0.127" layer="21"/>
<wire x1="2.032" y1="5.588" x2="2.032" y2="4.572" width="0.127" layer="21"/>
<wire x1="2.032" y1="4.572" x2="1.905" y2="4.445" width="0.127" layer="21"/>
<wire x1="1.905" y1="4.445" x2="2.032" y2="4.318" width="0.127" layer="21"/>
<wire x1="2.032" y1="4.318" x2="2.032" y2="3.302" width="0.127" layer="21"/>
<wire x1="2.032" y1="3.302" x2="1.905" y2="3.175" width="0.127" layer="21"/>
<wire x1="1.905" y1="3.175" x2="2.032" y2="3.048" width="0.127" layer="21"/>
<wire x1="2.032" y1="3.048" x2="2.032" y2="2.032" width="0.127" layer="21"/>
<wire x1="2.032" y1="2.032" x2="1.905" y2="1.905" width="0.127" layer="21"/>
<wire x1="1.905" y1="1.905" x2="2.032" y2="1.778" width="0.127" layer="21"/>
<wire x1="2.032" y1="1.778" x2="2.032" y2="0.762" width="0.127" layer="21"/>
<wire x1="2.032" y1="0.762" x2="1.778" y2="0.508" width="0.127" layer="21"/>
<wire x1="1.778" y1="0.508" x2="0.762" y2="0.508" width="0.127" layer="21"/>
<wire x1="0.762" y1="0.508" x2="0.635" y2="0.635" width="0.127" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.508" y2="0.508" width="0.127" layer="21"/>
<wire x1="0.508" y1="0.508" x2="-0.508" y2="0.508" width="0.127" layer="21"/>
<wire x1="-0.508" y1="0.508" x2="-0.762" y2="0.762" width="0.127" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-0.762" y2="1.778" width="0.127" layer="21"/>
<wire x1="-0.762" y1="1.778" x2="-0.635" y2="1.905" width="0.127" layer="21"/>
<wire x1="-0.635" y1="1.905" x2="-0.762" y2="2.032" width="0.127" layer="21"/>
<wire x1="-0.762" y1="2.032" x2="-0.762" y2="3.048" width="0.127" layer="21"/>
<wire x1="-0.762" y1="3.048" x2="-0.635" y2="3.175" width="0.127" layer="21"/>
<wire x1="-0.635" y1="3.175" x2="-0.762" y2="3.302" width="0.127" layer="21"/>
<wire x1="-0.762" y1="3.302" x2="-0.762" y2="4.318" width="0.127" layer="21"/>
<wire x1="-0.762" y1="4.318" x2="-0.635" y2="4.445" width="0.127" layer="21"/>
<wire x1="-0.635" y1="4.445" x2="-0.762" y2="4.572" width="0.127" layer="21"/>
<wire x1="-0.762" y1="4.572" x2="-0.762" y2="5.588" width="0.127" layer="21"/>
<wire x1="-0.762" y1="5.588" x2="-0.635" y2="5.715" width="0.127" layer="21"/>
<wire x1="-0.635" y1="5.715" x2="-0.762" y2="5.842" width="0.127" layer="21"/>
<wire x1="-0.762" y1="5.842" x2="-0.762" y2="6.858" width="0.127" layer="21"/>
<wire x1="-0.762" y1="6.858" x2="-0.508" y2="7.112" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.112" x2="0.508" y2="7.112" width="0.127" layer="21"/>
<wire x1="0.508" y1="7.112" x2="0.635" y2="6.985" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.366" x2="0.508" y2="7.366" width="0.127" layer="21"/>
</package>
<package name="2X6">
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="4.445" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="-0.635" x2="9.525" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="-0.635" x2="12.065" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="-0.635" y2="3.81" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="3.81" x2="0.635" y2="3.81" width="0.2032" layer="21"/>
<wire x1="0.635" y1="3.81" x2="1.27" y2="3.175" width="0.2032" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.905" y2="3.81" width="0.2032" layer="21"/>
<wire x1="1.905" y1="3.81" x2="3.175" y2="3.81" width="0.2032" layer="21"/>
<wire x1="3.175" y1="3.81" x2="3.81" y2="3.175" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="4.445" y2="3.81" width="0.2032" layer="21"/>
<wire x1="4.445" y1="3.81" x2="5.715" y2="3.81" width="0.2032" layer="21"/>
<wire x1="5.715" y1="3.81" x2="6.35" y2="3.175" width="0.2032" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.985" y2="3.81" width="0.2032" layer="21"/>
<wire x1="6.985" y1="3.81" x2="8.255" y2="3.81" width="0.2032" layer="21"/>
<wire x1="8.255" y1="3.81" x2="8.89" y2="3.175" width="0.2032" layer="21"/>
<wire x1="8.89" y1="3.175" x2="9.525" y2="3.81" width="0.2032" layer="21"/>
<wire x1="9.525" y1="3.81" x2="10.795" y2="3.81" width="0.2032" layer="21"/>
<wire x1="10.795" y1="3.81" x2="11.43" y2="3.175" width="0.2032" layer="21"/>
<wire x1="11.43" y1="3.175" x2="12.065" y2="3.81" width="0.2032" layer="21"/>
<wire x1="12.065" y1="3.81" x2="13.335" y2="3.81" width="0.2032" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.97" y2="3.175" width="0.2032" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="8.89" y1="3.175" x2="8.89" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="11.43" y1="3.175" x2="11.43" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="13.97" y1="3.175" x2="13.97" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-1.27" x2="13.335" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-1.27" x2="10.795" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-1.27" x2="8.255" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="2" x="0" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="3" x="2.54" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="4" x="2.54" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="5" x="5.08" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="6" x="5.08" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="7" x="7.62" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="8" x="7.62" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="9" x="10.16" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="10" x="10.16" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="11" x="12.7" y="0" drill="1.016" diameter="1.8796" shape="octagon"/>
<pad name="12" x="12.7" y="2.54" drill="1.016" diameter="1.8796" shape="octagon"/>
<text x="-1.27" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-0.254" y1="2.286" x2="0.254" y2="2.794" layer="51"/>
<rectangle x1="2.286" y1="2.286" x2="2.794" y2="2.794" layer="51"/>
<rectangle x1="4.826" y1="2.286" x2="5.334" y2="2.794" layer="51"/>
<rectangle x1="7.366" y1="2.286" x2="7.874" y2="2.794" layer="51"/>
<rectangle x1="9.906" y1="2.286" x2="10.414" y2="2.794" layer="51"/>
<rectangle x1="12.446" y1="2.286" x2="12.954" y2="2.794" layer="51"/>
</package>
<package name="1X08_ROUND">
<wire x1="19.05" y1="0.635" x2="19.05" y2="-0.635" width="0.2032" layer="21"/>
</package>
<package name="1X13_LOCK_NO_SILK">
</package>
<package name="1X15_LOCK_NO_SILK">
<pad name="14" x="33.02" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="15" x="35.56" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="1X08_LOCK_NO_SILK">
</package>
<package name="MICROSD_1:1">
<wire x1="-0.03" y1="0" x2="-0.03" y2="13.2" width="0.2032" layer="21"/>
<wire x1="13.97" y1="12.1" x2="13.97" y2="0" width="0.2032" layer="21"/>
<wire x1="2.27" y1="15.3" x2="1.47" y2="15.3" width="0.2032" layer="21"/>
<wire x1="2.97" y1="16" x2="13.97" y2="16" width="0.2032" layer="51"/>
<wire x1="3.97" y1="13.6" x2="12.37" y2="13.6" width="0.2032" layer="21"/>
<wire x1="-0.03" y1="0" x2="4.87" y2="0" width="0.2032" layer="21"/>
<wire x1="10.57" y1="0" x2="7.57" y2="0" width="0.2032" layer="21"/>
<wire x1="13.97" y1="0" x2="13.27" y2="0" width="0.2032" layer="21"/>
<wire x1="13.97" y1="17.6" x2="2.97" y2="17.6" width="0.2032" layer="51"/>
<wire x1="13.97" y1="20.7" x2="2.97" y2="20.7" width="0.2032" layer="51"/>
<wire x1="2.27" y1="15.3" x2="2.97" y2="14.6" width="0.2032" layer="21" curve="-98.797411"/>
<wire x1="2.97" y1="14.6" x2="3.97" y2="13.6" width="0.2032" layer="21" curve="87.205638"/>
<smd name="CD2" x="6.22" y="0.4" dx="1.8" dy="1.4" layer="1"/>
<smd name="CD1" x="11.92" y="0.4" dx="1.8" dy="1.4" layer="1"/>
<smd name="GND3" x="13.52" y="13.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="GND1" x="0.497" y="14.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="1" x="5.095784375" y="10.919203125" dx="0.8" dy="1.5" layer="1"/>
<smd name="2" x="6.21763125" y="10.51945625" dx="0.8" dy="1.5" layer="1"/>
<smd name="3" x="7.2736875" y="10.853415625" dx="0.8" dy="1.5" layer="1"/>
<smd name="4" x="8.366575" y="10.982296875" dx="0.8" dy="1.5" layer="1"/>
<smd name="5" x="9.42085625" y="10.828015625" dx="0.8" dy="1.5" layer="1"/>
<smd name="6" x="10.53914375" y="10.973153125" dx="0.8" dy="1.5" layer="1"/>
<smd name="7" x="11.6482875" y="10.818871875" dx="0.8" dy="1.5" layer="1"/>
<smd name="8" x="12.72085625" y="10.818871875" dx="0.8" dy="1.5" layer="1"/>
<text x="5.08" y="6.35" size="0.8128" layer="25">&gt;Name</text>
<text x="5.08" y="5.08" size="0.8128" layer="27">&gt;Value</text>
</package>
<package name="1X09_NO_SILK">
</package>
<package name="2X20_SHROUDED">
<wire x1="-2.775" y1="24.765" x2="-2.775" y2="23.495" width="0.2032" layer="21"/>
<wire x1="4.5" y1="29.15" x2="4.5" y2="-29.15" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="-29.15" x2="-4.5" y2="29.15" width="0.2032" layer="21"/>
<wire x1="-4.5" y1="29.15" x2="4.4" y2="29.15" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-29.15" x2="-4.5" y2="-29.15" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="28.05" x2="3.4" y2="28.05" width="0.2032" layer="51"/>
<wire x1="3.4" y1="28.05" x2="3.4" y2="-28.05" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-28.05" x2="3.4" y2="-28.05" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="28.05" x2="-3.4" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-28.05" x2="-3.4" y2="-2.2" width="0.2032" layer="51"/>
<pad name="1" x="-1.27" y="24.13" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="24.13" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="21.59" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="21.59" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="19.05" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="19.05" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.27" y="16.51" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.27" y="16.51" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.27" y="13.97" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.27" y="13.97" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.921" y="29.464" size="0.4064" layer="27" font="vector">&gt;VALUE</text>
<text x="-2.921" y="-29.972" size="0.4064" layer="104">&gt;NAME</text>
<rectangle x1="-1.524" y1="23.876" x2="-1.016" y2="24.384" layer="51"/>
<rectangle x1="1.016" y1="23.876" x2="1.524" y2="24.384" layer="51"/>
<rectangle x1="1.016" y1="21.336" x2="1.524" y2="21.844" layer="51"/>
<rectangle x1="-1.524" y1="21.336" x2="-1.016" y2="21.844" layer="51"/>
<rectangle x1="1.016" y1="18.796" x2="1.524" y2="19.304" layer="51"/>
<rectangle x1="-1.524" y1="18.796" x2="-1.016" y2="19.304" layer="51"/>
<rectangle x1="1.016" y1="16.256" x2="1.524" y2="16.764" layer="51"/>
<rectangle x1="-1.524" y1="16.256" x2="-1.016" y2="16.764" layer="51"/>
<rectangle x1="1.016" y1="13.716" x2="1.524" y2="14.224" layer="51"/>
<rectangle x1="-1.524" y1="13.716" x2="-1.016" y2="14.224" layer="51"/>
<pad name="11" x="-1.27" y="11.43" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="12" x="1.27" y="11.43" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="13" x="-1.27" y="8.89" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="14" x="1.27" y="8.89" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="15" x="-1.27" y="6.35" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="16" x="1.27" y="6.35" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="17" x="-1.27" y="3.81" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="18" x="1.27" y="3.81" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="19" x="-1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="20" x="1.27" y="1.27" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<rectangle x1="-1.524" y1="11.176" x2="-1.016" y2="11.684" layer="51"/>
<rectangle x1="1.016" y1="11.176" x2="1.524" y2="11.684" layer="51"/>
<rectangle x1="1.016" y1="8.636" x2="1.524" y2="9.144" layer="51"/>
<rectangle x1="-1.524" y1="8.636" x2="-1.016" y2="9.144" layer="51"/>
<rectangle x1="1.016" y1="6.096" x2="1.524" y2="6.604" layer="51"/>
<rectangle x1="-1.524" y1="6.096" x2="-1.016" y2="6.604" layer="51"/>
<rectangle x1="1.016" y1="3.556" x2="1.524" y2="4.064" layer="51"/>
<rectangle x1="-1.524" y1="3.556" x2="-1.016" y2="4.064" layer="51"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51"/>
<pad name="21" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="22" x="1.27" y="-1.27" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="23" x="-1.27" y="-3.81" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="24" x="1.27" y="-3.81" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="25" x="-1.27" y="-6.35" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="26" x="1.27" y="-6.35" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<rectangle x1="1.016" y1="-1.524" x2="1.524" y2="-1.016" layer="51"/>
<rectangle x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.016" layer="51"/>
<rectangle x1="1.016" y1="-4.064" x2="1.524" y2="-3.556" layer="51"/>
<rectangle x1="-1.524" y1="-4.064" x2="-1.016" y2="-3.556" layer="51"/>
<rectangle x1="1.016" y1="-6.604" x2="1.524" y2="-6.096" layer="51"/>
<rectangle x1="-1.524" y1="-6.604" x2="-1.016" y2="-6.096" layer="51"/>
<pad name="27" x="-1.27" y="-8.89" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="28" x="1.27" y="-8.89" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="29" x="-1.27" y="-11.43" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="30" x="1.27" y="-11.43" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="31" x="-1.27" y="-13.97" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="32" x="1.27" y="-13.97" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="33" x="-1.27" y="-16.51" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="34" x="1.27" y="-16.51" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="35" x="-1.27" y="-19.05" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="36" x="1.27" y="-19.05" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="37" x="-1.27" y="-21.59" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="38" x="1.27" y="-21.59" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="39" x="-1.27" y="-24.13" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="40" x="1.27" y="-24.13" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<rectangle x1="1.016" y1="-9.144" x2="1.524" y2="-8.636" layer="51"/>
<rectangle x1="1.016" y1="-11.684" x2="1.524" y2="-11.176" layer="51"/>
<rectangle x1="1.016" y1="-14.224" x2="1.524" y2="-13.716" layer="51"/>
<rectangle x1="1.016" y1="-16.764" x2="1.524" y2="-16.256" layer="51"/>
<rectangle x1="1.016" y1="-19.304" x2="1.524" y2="-18.796" layer="51"/>
<rectangle x1="1.016" y1="-21.844" x2="1.524" y2="-21.336" layer="51"/>
<rectangle x1="1.016" y1="-24.384" x2="1.524" y2="-23.876" layer="51"/>
<rectangle x1="-1.524" y1="-9.144" x2="-1.016" y2="-8.636" layer="51"/>
<rectangle x1="-1.524" y1="-11.684" x2="-1.016" y2="-11.176" layer="51"/>
<rectangle x1="-1.524" y1="-14.224" x2="-1.016" y2="-13.716" layer="51"/>
<rectangle x1="-1.524" y1="-16.764" x2="-1.016" y2="-16.256" layer="51"/>
<rectangle x1="-1.524" y1="-19.304" x2="-1.016" y2="-18.796" layer="51"/>
<rectangle x1="-1.524" y1="-21.844" x2="-1.016" y2="-21.336" layer="51"/>
<rectangle x1="-1.524" y1="-24.384" x2="-1.016" y2="-23.876" layer="51"/>
<wire x1="-4.5" y1="2.2" x2="-3" y2="2.2" width="0.2032" layer="21"/>
<wire x1="-3" y1="-2.2" x2="-4.5" y2="-2.2" width="0.2032" layer="21"/>
<wire x1="-3" y1="2.2" x2="-3" y2="-2.2" width="0.2032" layer="21"/>
</package>
<package name="2X20_NOSILK">
<text x="-1.651" y="25.654" size="0.4064" layer="27" font="vector">&gt;VALUE</text>
<text x="-1.651" y="-26.416" size="0.4064" layer="25" font="vector">&gt;NAME</text>
</package>
<package name="2X20">
<wire x1="-7.62" y1="-1.905" x2="-8.255" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-10.795" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="-2.54" x2="-12.065" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="-2.54" x2="-12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="-1.905" x2="-9.525" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="-2.54" x2="-9.525" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="-1.905" x2="-15.875" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="-1.905" x2="-13.335" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-14.605" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="-2.54" x2="-15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-18.415" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="-2.54" x2="-19.685" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="-2.54" x2="-20.32" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="-1.905" x2="-17.145" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="-2.54" x2="-17.145" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="-1.905" x2="-23.495" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="-1.905" x2="-20.955" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="-2.54" x2="-22.225" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="-2.54" x2="-22.86" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="-0.635" x2="-25.4" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="0" x2="-25.4" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="-1.905" x2="-24.765" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="-2.54" x2="-24.765" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="7.62" y1="-1.905" x2="6.985" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="6.985" y1="-2.54" x2="5.715" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="5.715" y1="-2.54" x2="5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="1.905" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="5.08" y1="-1.905" x2="4.445" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="4.445" y1="-2.54" x2="3.175" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-2.54" x2="2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="-1.905" x2="-0.635" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="-2.54" x2="-1.905" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="-2.54" x2="-2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="-1.905" x2="0.635" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="1.905" y1="-2.54" x2="0.635" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="-1.905" x2="-5.715" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="-1.905" x2="-3.175" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="-2.54" x2="-4.445" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="-2.54" x2="-5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="-1.905" x2="-6.985" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="-2.54" x2="-6.985" y2="-2.54" width="0.2032" layer="21"/>
<pad name="1" x="-24.13" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="3" x="-21.59" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="5" x="-19.05" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="7" x="-16.51" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="9" x="-13.97" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="11" x="-11.43" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="13" x="-8.89" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="15" x="-6.35" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="17" x="-3.81" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="19" x="-1.27" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="21" x="1.27" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="23" x="3.81" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<pad name="25" x="6.35" y="-1.27" drill="1.016" diameter="1.651" rot="R90"/>
<text x="-25.4762" y="3.0988" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-25.4" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-9.144" y1="-1.524" x2="-8.636" y2="-1.016" layer="51"/>
<rectangle x1="-11.684" y1="-1.524" x2="-11.176" y2="-1.016" layer="51"/>
<rectangle x1="-14.224" y1="-1.524" x2="-13.716" y2="-1.016" layer="51"/>
<rectangle x1="-16.764" y1="-1.524" x2="-16.256" y2="-1.016" layer="51"/>
<rectangle x1="-19.304" y1="-1.524" x2="-18.796" y2="-1.016" layer="51"/>
<rectangle x1="-21.844" y1="-1.524" x2="-21.336" y2="-1.016" layer="51"/>
<rectangle x1="-24.384" y1="-1.524" x2="-23.876" y2="-1.016" layer="51"/>
<rectangle x1="6.096" y1="-1.524" x2="6.604" y2="-1.016" layer="51"/>
<rectangle x1="3.556" y1="-1.524" x2="4.064" y2="-1.016" layer="51"/>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.016" layer="51"/>
<rectangle x1="-6.604" y1="-1.524" x2="-6.096" y2="-1.016" layer="51"/>
<wire x1="-9.525" y1="2.54" x2="-8.255" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-8.255" y1="2.54" x2="-7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.065" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-12.065" y1="2.54" x2="-10.795" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-10.795" y1="2.54" x2="-10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-9.525" y1="2.54" x2="-10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="2.54" x2="-15.875" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-15.875" y1="2.54" x2="-15.24" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="1.905" x2="-14.605" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-14.605" y1="2.54" x2="-13.335" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-13.335" y1="2.54" x2="-12.7" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="1.905" x2="-19.685" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-19.685" y1="2.54" x2="-18.415" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-18.415" y1="2.54" x2="-17.78" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-17.145" y1="2.54" x2="-17.78" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="2.54" x2="-23.495" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-23.495" y1="2.54" x2="-22.86" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-22.86" y1="1.905" x2="-22.225" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-22.225" y1="2.54" x2="-20.955" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-20.955" y1="2.54" x2="-20.32" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="1.905" x2="-25.4" y2="0.635" width="0.2032" layer="21"/>
<wire x1="-24.765" y1="2.54" x2="-25.4" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-25.4" y1="0.635" x2="-24.765" y2="0" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.715" y2="2.54" width="0.2032" layer="21"/>
<wire x1="5.715" y1="2.54" x2="6.985" y2="2.54" width="0.2032" layer="21"/>
<wire x1="6.985" y1="2.54" x2="7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="0.635" y1="2.54" x2="1.905" y2="2.54" width="0.2032" layer="21"/>
<wire x1="1.905" y1="2.54" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="1.905" x2="3.175" y2="2.54" width="0.2032" layer="21"/>
<wire x1="3.175" y1="2.54" x2="4.445" y2="2.54" width="0.2032" layer="21"/>
<wire x1="4.445" y1="2.54" x2="5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-1.905" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-1.905" y1="2.54" x2="-0.635" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="0" y2="1.905" width="0.2032" layer="21"/>
<wire x1="0.635" y1="2.54" x2="0" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-5.715" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-5.715" y1="2.54" x2="-5.08" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-4.445" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="2.54" x2="-2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="-6.985" y1="2.54" x2="-7.62" y2="1.905" width="0.2032" layer="21"/>
<pad name="26" x="6.35" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="24" x="3.81" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="22" x="1.27" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="20" x="-1.27" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="18" x="-3.81" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="16" x="-6.35" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="14" x="-8.89" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="12" x="-11.43" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="10" x="-13.97" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="8" x="-16.51" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="6" x="-19.05" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="4" x="-21.59" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="2" x="-24.13" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-1.524" y1="1.016" x2="-1.016" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="1.016" y1="1.016" x2="1.524" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-24.384" y1="1.016" x2="-23.876" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-21.844" y1="1.016" x2="-21.336" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-19.304" y1="1.016" x2="-18.796" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-16.764" y1="1.016" x2="-16.256" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-14.224" y1="1.016" x2="-13.716" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="-11.684" y1="1.016" x2="-11.176" y2="1.524" layer="51" rot="R180"/>
<wire x1="-22.86" y1="1.905" x2="-22.86" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-20.32" y1="1.905" x2="-20.32" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-17.78" y1="1.905" x2="-17.78" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-15.24" y1="1.905" x2="-15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-10.16" y1="1.905" x2="-10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-5.08" y1="1.905" x2="-5.08" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="0" y1="1.905" x2="0" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="-1.905" width="0.2032" layer="21"/>
<pad name="27" x="8.89" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="28" x="8.89" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="29" x="11.43" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="30" x="11.43" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="31" x="13.97" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="32" x="13.97" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="33" x="16.51" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="34" x="16.51" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="35" x="19.05" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="36" x="19.05" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="37" x="21.59" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="38" x="21.59" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="39" x="24.13" y="-1.27" drill="1.016" diameter="1.651" rot="R270"/>
<pad name="40" x="24.13" y="1.27" drill="1.016" diameter="1.651" rot="R270"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="11.176" y1="1.016" x2="11.684" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="13.716" y1="1.016" x2="14.224" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="16.256" y1="1.016" x2="16.764" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="18.796" y1="1.016" x2="19.304" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="21.336" y1="1.016" x2="21.844" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="23.876" y1="1.016" x2="24.384" y2="1.524" layer="51" rot="R180"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="11.176" y1="-1.524" x2="11.684" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="13.716" y1="-1.524" x2="14.224" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="16.256" y1="-1.524" x2="16.764" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="18.796" y1="-1.524" x2="19.304" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="21.336" y1="-1.524" x2="21.844" y2="-1.016" layer="51" rot="R180"/>
<rectangle x1="23.876" y1="-1.524" x2="24.384" y2="-1.016" layer="51" rot="R180"/>
<wire x1="25.4" y1="0.635" x2="25.4" y2="1.905" width="0.2032" layer="21"/>
<wire x1="25.4" y1="-1.905" x2="25.4" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="24.765" y1="0" x2="25.4" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="25.4" y1="0.635" x2="24.765" y2="0" width="0.2032" layer="21"/>
<wire x1="8.255" y1="2.54" x2="9.525" y2="2.54" width="0.2032" layer="21"/>
<wire x1="9.525" y1="2.54" x2="10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="8.255" y1="2.54" x2="7.62" y2="1.905" width="0.2032" layer="21"/>
<wire x1="22.86" y1="1.905" x2="23.495" y2="2.54" width="0.2032" layer="21"/>
<wire x1="23.495" y1="2.54" x2="24.765" y2="2.54" width="0.2032" layer="21"/>
<wire x1="24.765" y1="2.54" x2="25.4" y2="1.905" width="0.2032" layer="21"/>
<wire x1="18.415" y1="2.54" x2="19.685" y2="2.54" width="0.2032" layer="21"/>
<wire x1="19.685" y1="2.54" x2="20.32" y2="1.905" width="0.2032" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.955" y2="2.54" width="0.2032" layer="21"/>
<wire x1="20.955" y1="2.54" x2="22.225" y2="2.54" width="0.2032" layer="21"/>
<wire x1="22.225" y1="2.54" x2="22.86" y2="1.905" width="0.2032" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.875" y2="2.54" width="0.2032" layer="21"/>
<wire x1="15.875" y1="2.54" x2="17.145" y2="2.54" width="0.2032" layer="21"/>
<wire x1="17.145" y1="2.54" x2="17.78" y2="1.905" width="0.2032" layer="21"/>
<wire x1="18.415" y1="2.54" x2="17.78" y2="1.905" width="0.2032" layer="21"/>
<wire x1="10.795" y1="2.54" x2="12.065" y2="2.54" width="0.2032" layer="21"/>
<wire x1="12.065" y1="2.54" x2="12.7" y2="1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="1.905" x2="13.335" y2="2.54" width="0.2032" layer="21"/>
<wire x1="13.335" y1="2.54" x2="14.605" y2="2.54" width="0.2032" layer="21"/>
<wire x1="14.605" y1="2.54" x2="15.24" y2="1.905" width="0.2032" layer="21"/>
<wire x1="10.795" y1="2.54" x2="10.16" y2="1.905" width="0.2032" layer="21"/>
<wire x1="7.62" y1="1.905" x2="7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="10.16" y1="1.905" x2="10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="1.905" x2="12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="15.24" y1="1.905" x2="15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="17.78" y1="1.905" x2="17.78" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="20.32" y1="1.905" x2="20.32" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="22.86" y1="1.905" x2="22.86" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="24.765" y1="-2.54" x2="23.495" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="23.495" y1="-2.54" x2="22.86" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="24.765" y1="-2.54" x2="25.4" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="10.16" y1="-1.905" x2="9.525" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="8.255" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="8.255" y1="-2.54" x2="7.62" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="13.335" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="13.335" y1="-2.54" x2="12.7" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="12.7" y1="-1.905" x2="12.065" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="12.065" y1="-2.54" x2="10.795" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="10.795" y1="-2.54" x2="10.16" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="17.78" y1="-1.905" x2="17.145" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="17.145" y1="-2.54" x2="15.875" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="15.875" y1="-2.54" x2="15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="14.605" y1="-2.54" x2="15.24" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-2.54" x2="20.955" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="20.955" y1="-2.54" x2="20.32" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="20.32" y1="-1.905" x2="19.685" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="19.685" y1="-2.54" x2="18.415" y2="-2.54" width="0.2032" layer="21"/>
<wire x1="18.415" y1="-2.54" x2="17.78" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="22.225" y1="-2.54" x2="22.86" y2="-1.905" width="0.2032" layer="21"/>
</package>
<package name="1X20_NO_SILK_KIT">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="11" x="25.4" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="12" x="27.94" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<circle x="0" y="0" radius="0.508" width="0" layer="29"/>
<circle x="2.54" y="0" radius="0.508" width="0" layer="29"/>
<circle x="5.08" y="0" radius="0.508" width="0" layer="29"/>
<circle x="7.62" y="0" radius="0.508" width="0" layer="29"/>
<circle x="10.16" y="0" radius="0.508" width="0" layer="29"/>
<circle x="12.7" y="0" radius="0.508" width="0" layer="29"/>
<circle x="15.24" y="0" radius="0.508" width="0" layer="29"/>
<circle x="17.78" y="0" radius="0.508" width="0" layer="29"/>
<circle x="20.32" y="0" radius="0.508" width="0" layer="29"/>
<circle x="22.86" y="0" radius="0.508" width="0" layer="29"/>
<circle x="25.4" y="0" radius="0.508" width="0" layer="29"/>
<circle x="27.94" y="0" radius="0.508" width="0" layer="29"/>
<pad name="18" x="43.18" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="19" x="45.72" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<pad name="20" x="48.26" y="0" drill="1.016" diameter="1.8796" rot="R90" stop="no"/>
<circle x="43.18" y="0" radius="0.508" width="0" layer="29"/>
<circle x="43.18" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="45.72" y="0" radius="0.508" width="0" layer="29"/>
<circle x="45.72" y="0" radius="0.9398" width="0" layer="30"/>
<circle x="48.26" y="0" radius="0.508" width="0" layer="29"/>
<circle x="48.26" y="0" radius="0.9398" width="0" layer="30"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="1X04_NO_SILK_ALL_ROUND">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="2" x="2.54" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="3" x="5.08" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="4" x="7.62" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="7.366" y1="-0.254" x2="7.874" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
<package name="JST_POLARITY_MARKS">
<text x="1.8415" y="0" size="1.27" layer="51" font="vector">+</text>
<text x="-1.8415" y="0" size="1.27" layer="51" font="vector" align="bottom-right">-</text>
<text x="1.8415" y="0" size="1.27" layer="21" font="vector" ratio="15">+</text>
<text x="-1.8415" y="0" size="1.27" layer="21" font="vector" ratio="15" align="bottom-right">-</text>
</package>
<package name="1X12_LOCK_NO_SILK">
<rectangle x1="14.986" y1="-0.254" x2="15.494" y2="0.254" layer="51"/>
<rectangle x1="12.446" y1="-0.254" x2="12.954" y2="0.254" layer="51"/>
<rectangle x1="9.906" y1="-0.254" x2="10.414" y2="0.254" layer="51"/>
<rectangle x1="22.606" y1="-0.254" x2="23.114" y2="0.254" layer="51"/>
<rectangle x1="20.066" y1="-0.254" x2="20.574" y2="0.254" layer="51"/>
<rectangle x1="17.526" y1="-0.254" x2="18.034" y2="0.254" layer="51"/>
</package>
<package name="DEANS">
<pad name="+" x="0" y="0" drill="1.27" diameter="3.556" shape="long"/>
<pad name="-" x="0.7366" y="-6.9215" drill="1.27" diameter="3.556" shape="long" rot="R90"/>
<wire x1="-3.81" y1="2.3622" x2="3.81" y2="2.3622" width="0.2032" layer="21"/>
<wire x1="-3.81" y1="-3.9878" x2="-3.81" y2="2.3622" width="0.2032" layer="21"/>
<wire x1="3.81" y1="-3.9878" x2="3.81" y2="2.3622" width="0.2032" layer="21"/>
<wire x1="-3.2004" y1="-10.922" x2="3.2004" y2="-10.922" width="0.2032" layer="21"/>
<wire x1="-3.2004" y1="-10.922" x2="-3.2004" y2="-3.9878" width="0.2032" layer="21"/>
<wire x1="3.2004" y1="-10.922" x2="3.2004" y2="-3.9878" width="0.2032" layer="21"/>
<wire x1="-3.81" y1="-3.9878" x2="-3.2004" y2="-3.9878" width="0.2032" layer="21"/>
<wire x1="3.2004" y1="-3.9878" x2="3.81" y2="-3.9878" width="0.2032" layer="21"/>
<wire x1="-1.778" y1="-2.286" x2="-1.778" y2="-3.302" width="0.127" layer="21"/>
<wire x1="-2.286" y1="-2.794" x2="-1.27" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-2.032" y1="-7.62" x2="-2.032" y2="-6.604" width="0.127" layer="21"/>
<wire x1="0.0508" y1="-9.7536" x2="0.0508" y2="-4.064" width="0.127" layer="20"/>
<wire x1="0.0508" y1="-4.064" x2="1.4224" y2="-4.064" width="0.127" layer="20"/>
<wire x1="1.4224" y1="-4.064" x2="1.4224" y2="-9.7536" width="0.127" layer="20"/>
<wire x1="0.0508" y1="-9.7536" x2="1.4224" y2="-9.7536" width="0.127" layer="20"/>
<wire x1="2.8448" y1="-0.6858" x2="-2.8448" y2="-0.6858" width="0.127" layer="20"/>
<wire x1="-2.8448" y1="-0.6858" x2="-2.8448" y2="0.6858" width="0.127" layer="20"/>
<wire x1="-2.8448" y1="0.6858" x2="2.8448" y2="0.6858" width="0.127" layer="20"/>
<wire x1="2.8448" y1="-0.6858" x2="2.8448" y2="0.6858" width="0.127" layer="20"/>
</package>
<package name="2X5-SHROUDED-NS">
<wire x1="-2.775" y1="5.715" x2="-2.775" y2="4.445" width="0.2032" layer="21"/>
<wire x1="4.5" y1="10.1" x2="4.5" y2="-10.1" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-10.1" x2="-4.5" y2="-2.2" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="-2.2" x2="-4.5" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="2.2" x2="-4.5" y2="10.1" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="10.1" x2="4.4" y2="10.1" width="0.2032" layer="51"/>
<wire x1="4.5" y1="-10.1" x2="-4.5" y2="-10.1" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="9" x2="3.4" y2="9" width="0.2032" layer="51"/>
<wire x1="3.4" y1="9" x2="3.4" y2="-9" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-9" x2="3.4" y2="-9" width="0.2032" layer="51"/>
<wire x1="-4.5" y1="2.2" x2="-3" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-3" y1="2.2" x2="-3" y2="-2.2" width="0.2032" layer="51"/>
<wire x1="-3" y1="-2.2" x2="-4.5" y2="-2.2" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="9" x2="-3.4" y2="2.2" width="0.2032" layer="51"/>
<wire x1="-3.4" y1="-9" x2="-3.4" y2="-2.2" width="0.2032" layer="51"/>
<pad name="1" x="-1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="2" x="1.27" y="5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="3" x="-1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="4" x="1.27" y="2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="5" x="-1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="6" x="1.27" y="0" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="7" x="-1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="8" x="1.27" y="-2.54" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="9" x="-1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<pad name="10" x="1.27" y="-5.08" drill="1.016" diameter="1.8796" shape="octagon" rot="R270"/>
<text x="-2.921" y="10.414" size="0.4064" layer="27" font="vector">&gt;VALUE</text>
<text x="-2.921" y="-10.922" size="0.4064" layer="25">&gt;NAME</text>
<rectangle x1="-1.524" y1="4.826" x2="-1.016" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="4.826" x2="1.524" y2="5.334" layer="51"/>
<rectangle x1="1.016" y1="2.286" x2="1.524" y2="2.794" layer="51"/>
<rectangle x1="-1.524" y1="2.286" x2="-1.016" y2="2.794" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-2.794" x2="1.524" y2="-2.286" layer="51"/>
<rectangle x1="-1.524" y1="-2.794" x2="-1.016" y2="-2.286" layer="51"/>
<rectangle x1="1.016" y1="-5.334" x2="1.524" y2="-4.826" layer="51"/>
<rectangle x1="-1.524" y1="-5.334" x2="-1.016" y2="-4.826" layer="51"/>
</package>
<package name="1X20_LOCK_NOSILK">
<pad name="1" x="0" y="0.127" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="16" x="38.1" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="17" x="40.64" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="43.18" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="45.72" y="0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="48.26" y="-0.127" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="42.926" y1="-0.254" x2="43.434" y2="0.254" layer="51"/>
<rectangle x1="45.466" y1="-0.254" x2="45.974" y2="0.254" layer="51"/>
<rectangle x1="48.006" y1="-0.254" x2="48.514" y2="0.254" layer="51"/>
</package>
<package name="2X10_ROUND_NOSILK">
<pad name="1" x="-11.43" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="2" x="-11.43" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="3" x="-8.89" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="4" x="-8.89" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="5" x="-6.35" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="6" x="-6.35" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="7" x="-3.81" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="8" x="-3.81" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="9" x="-1.27" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="10" x="-1.27" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="11" x="1.27" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="12" x="1.27" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="13" x="3.81" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="14" x="3.81" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="15" x="6.35" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="16" x="6.35" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="17" x="8.89" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="18" x="8.89" y="1.27" drill="1.016" diameter="1.8796"/>
<pad name="19" x="11.43" y="-1.27" drill="1.016" diameter="1.8796"/>
<pad name="20" x="11.43" y="1.27" drill="1.016" diameter="1.8796"/>
<text x="-12.7" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-12.7" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-11.684" y1="1.016" x2="-11.176" y2="1.524" layer="51"/>
<rectangle x1="-9.144" y1="1.016" x2="-8.636" y2="1.524" layer="51"/>
<rectangle x1="-6.604" y1="1.016" x2="-6.096" y2="1.524" layer="51"/>
<rectangle x1="-4.064" y1="1.016" x2="-3.556" y2="1.524" layer="51"/>
<rectangle x1="3.556" y1="1.016" x2="4.064" y2="1.524" layer="51"/>
<rectangle x1="6.096" y1="1.016" x2="6.604" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="1.016" x2="9.144" y2="1.524" layer="51"/>
<rectangle x1="8.636" y1="-1.524" x2="9.144" y2="-1.016" layer="51"/>
<rectangle x1="11.176" y1="1.016" x2="11.684" y2="1.524" layer="51"/>
<rectangle x1="11.176" y1="-1.524" x2="11.684" y2="-1.016" layer="51"/>
</package>
<package name="1X01_NO_SILK">
<text x="1.1938" y="1.8288" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="1X06_NO_SILK_YES_STOP">
<pad name="5" x="10.16" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="6" x="12.7" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
</package>
<package name="SCREWTERMINAL-3.5MM-5">
<wire x1="-1.75" y1="3.4" x2="15.75" y2="3.4" width="0.2032" layer="21"/>
<wire x1="15.75" y1="3.4" x2="15.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="15.75" y1="-2.8" x2="15.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="15.75" y1="-3.6" x2="-1.75" y2="-3.6" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-3.6" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-2.8" x2="-1.75" y2="3.4" width="0.2032" layer="21"/>
<wire x1="15.75" y1="-2.8" x2="-1.75" y2="-2.8" width="0.2032" layer="21"/>
<wire x1="-1.75" y1="-1.35" x2="-2.25" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-1.35" x2="-2.25" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="-2.25" y1="-2.35" x2="-1.75" y2="-2.35" width="0.2032" layer="51"/>
<wire x1="15.75" y1="3.15" x2="16.25" y2="3.15" width="0.2032" layer="51"/>
<wire x1="16.25" y1="3.15" x2="16.25" y2="2.15" width="0.2032" layer="51"/>
<wire x1="16.25" y1="2.15" x2="15.75" y2="2.15" width="0.2032" layer="51"/>
<pad name="1" x="0" y="0" drill="1.2" diameter="2.032" shape="square"/>
<pad name="2" x="3.5" y="0" drill="1.2" diameter="2.032"/>
<pad name="3" x="7" y="0" drill="1.2" diameter="2.032"/>
<pad name="4" x="10.5" y="0" drill="1.2" diameter="2.032"/>
<pad name="5" x="14" y="0" drill="1.2" diameter="2.032"/>
<text x="-1.27" y="2.54" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="1.27" size="0.4064" layer="27">&gt;VALUE</text>
</package>
<package name="1X20_NOSILK">
<pad name="1" x="0" y="0" drill="1.016" diameter="1.8796" shape="square" rot="R90"/>
<pad name="7" x="15.24" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="8" x="17.78" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="9" x="20.32" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="10" x="22.86" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="18" x="43.18" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="19" x="45.72" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<pad name="20" x="48.26" y="0" drill="1.016" diameter="1.8796" rot="R90"/>
<rectangle x1="30.226" y1="-0.254" x2="30.734" y2="0.254" layer="51"/>
<rectangle x1="27.686" y1="-0.254" x2="28.194" y2="0.254" layer="51"/>
<rectangle x1="25.146" y1="-0.254" x2="25.654" y2="0.254" layer="51"/>
</package>
<package name="FTDI_DEVICE_RA_SMT">
<description>Package for devices meant to mate to an FTDI connector.</description>
<wire x1="7.62" y1="1.25" x2="-7.62" y2="1.25" width="0.127" layer="51"/>
<wire x1="-7.62" y1="1.25" x2="-7.62" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-7.62" y1="-1.25" x2="-6.35" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-1.25" x2="-3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="1.27" y2="-1.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="3.81" y2="-1.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="6.35" y2="-1.25" width="0.127" layer="51"/>
<wire x1="6.35" y1="-1.25" x2="7.62" y2="-1.25" width="0.127" layer="51"/>
<wire x1="7.62" y1="-1.25" x2="7.62" y2="1.25" width="0.127" layer="51"/>
<wire x1="6.35" y1="-1.25" x2="6.35" y2="-7.25" width="0.127" layer="51"/>
<wire x1="3.81" y1="-1.25" x2="3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="1.27" y1="-1.25" x2="1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-1.27" y1="-1.25" x2="-1.27" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-3.81" y1="-1.25" x2="-3.81" y2="-7.25" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-1.25" x2="-6.35" y2="-7.25" width="0.127" layer="51"/>
<smd name="4" x="1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="5" x="3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="6" x="6.35" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="3" x="-1.27" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="2" x="-3.81" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<smd name="1" x="-6.35" y="5" dx="3" dy="1" layer="1" rot="R90"/>
<text x="-1.905" y="1.905" size="0.8128" layer="25">&gt;NAME</text>
<text x="-1.905" y="0.635" size="0.8128" layer="27">&gt;VALUE</text>
<text x="-3.81" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">TXO</text>
<text x="-1.27" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">RXI</text>
<text x="1.27" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">VCC</text>
<text x="-6.35" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">DTR</text>
<text x="6.35" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">GND</text>
<text x="3.81" y="-1.016" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="center-left">CTS</text>
<text x="-7.366" y="-2.54" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="top-center">GRN</text>
<text x="7.366" y="-2.54" size="0.8128" layer="51" font="vector" ratio="15" rot="R90" align="bottom-center">BLK</text>
<hole x="-5.08" y="0" drill="1.4"/>
<hole x="5.08" y="0" drill="1.4"/>
</package>
<package name="2X20_SHROUDED_SMT">
<smd name="1" x="-3.5687" y="24.13" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="2" x="3.5687" y="24.13" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="3" x="-3.5687" y="21.59" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="4" x="3.5687" y="21.59" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="5" x="-3.5687" y="19.05" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="6" x="3.5687" y="19.05" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="7" x="-3.5687" y="16.51" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="8" x="3.5687" y="16.51" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="9" x="-3.5687" y="13.97" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="10" x="3.5687" y="13.97" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="11" x="-3.5687" y="11.43" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="12" x="3.5687" y="11.43" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="13" x="-3.5687" y="8.89" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="14" x="3.5687" y="8.89" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="15" x="-3.5687" y="6.35" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="16" x="3.5687" y="6.35" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="17" x="-3.5687" y="3.81" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="18" x="3.5687" y="3.81" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="19" x="-3.5687" y="1.27" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="20" x="3.5687" y="1.27" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="21" x="-3.5687" y="-1.27" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="22" x="3.5687" y="-1.27" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="23" x="-3.5687" y="-3.81" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="24" x="3.5687" y="-3.81" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="25" x="-3.5687" y="-6.35" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="26" x="3.5687" y="-6.35" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="27" x="-3.5687" y="-8.89" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="28" x="3.5687" y="-8.89" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="29" x="-3.5687" y="-11.43" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="30" x="3.5687" y="-11.43" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="31" x="-3.5687" y="-13.97" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="32" x="3.5687" y="-13.97" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="33" x="-3.5687" y="-16.51" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="34" x="3.5687" y="-16.51" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="35" x="-3.5687" y="-19.05" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="36" x="3.5687" y="-19.05" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="37" x="-3.5687" y="-21.59" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="38" x="3.5687" y="-21.59" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="39" x="-3.5687" y="-24.13" dx="4.1402" dy="0.9906" layer="1"/>
<smd name="40" x="3.5687" y="-24.13" dx="4.1402" dy="0.9906" layer="1"/>
</package>
<package name="BHNB-26M642">
</package>
<package name="SMTSO-256-ET-0.165DIA">
<circle x="0" y="0" radius="1.016" width="0.127" layer="51"/>
<wire x1="-1.016" y1="2.286" x2="-2.286" y2="1.016" width="1.016" layer="31" curve="42.075022"/>
<wire x1="2.286" y1="1.016" x2="1.016" y2="2.286" width="1.016" layer="31" curve="42.075022"/>
<wire x1="1.016" y1="-2.286" x2="2.286" y2="-1.016" width="1.016" layer="31" curve="42.075022"/>
<wire x1="-2.286" y1="-1.016" x2="-1.016" y2="-2.286" width="1.016" layer="31" curve="42.075022"/>
<pad name="P$1" x="0" y="0" drill="4.191" diameter="6.1976"/>
<text x="-2.54" y="1.27" size="0.8128" layer="49">.165 drill</text>
</package>
<package name="USB-A-PCB-NOPASTE">
<wire x1="-5" y1="6" x2="3.7" y2="6" width="0.127" layer="51"/>
<wire x1="3.7" y1="6" x2="3.7" y2="-6" width="0.127" layer="51" style="shortdash"/>
<wire x1="3.7" y1="-6" x2="-5" y2="-6" width="0.127" layer="51"/>
<wire x1="-5" y1="-6" x2="-5" y2="6" width="0.127" layer="51"/>
<smd name="5V" x="-0.2" y="-3.5" dx="7.5" dy="1.5" layer="1" cream="no"/>
<smd name="USB_M" x="0.3" y="-1" dx="6.5" dy="1" layer="1" cream="no"/>
<smd name="USB_P" x="0.3" y="1" dx="6.5" dy="1" layer="1" cream="no"/>
<smd name="GND" x="-0.2" y="3.5" dx="7.5" dy="1.5" layer="1" cream="no"/>
<text x="-1.27" y="5.08" size="0.4064" layer="25">&gt;Name</text>
<text x="-1.27" y="-5.08" size="0.4064" layer="27">&gt;Value</text>
<text x="-6.35" y="-3.81" size="1.016" layer="48" rot="R90">Card edge</text>
</package>
<package name="1X07_NO_SILK">
</package>
<package name="1X08_FEMALE_LOCK">
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="19.05" y2="1.27" width="0.2032" layer="21"/>
<wire x1="19.05" y1="-1.27" x2="-1.27" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="19.05" y1="1.27" x2="19.05" y2="-1.27" width="0.2032" layer="21"/>
<pad name="1" x="0" y="0.2286" drill="1.016" rot="R90"/>
<pad name="2" x="2.54" y="-0.2286" drill="1.016" rot="R90"/>
<pad name="3" x="5.08" y="0.2286" drill="1.016" rot="R90"/>
<pad name="4" x="7.62" y="-0.2286" drill="1.016" rot="R90"/>
<pad name="5" x="10.16" y="0.2286" drill="1.016" rot="R90"/>
<pad name="6" x="12.7" y="-0.2286" drill="1.016" rot="R90"/>
<rectangle x1="-0.3175" y1="-0.1905" x2="0.3175" y2="0.1905" layer="51"/>
<rectangle x1="2.2225" y1="-0.1905" x2="2.8575" y2="0.1905" layer="51"/>
<rectangle x1="4.7625" y1="-0.1905" x2="5.3975" y2="0.1905" layer="51"/>
<rectangle x1="7.3025" y1="-0.1905" x2="7.9375" y2="0.1905" layer="51"/>
<rectangle x1="9.8425" y1="-0.1905" x2="10.4775" y2="0.1905" layer="51"/>
<rectangle x1="12.3825" y1="-0.1905" x2="13.0175" y2="0.1905" layer="51"/>
<pad name="7" x="15.24" y="0.2286" drill="1.016" rot="R90"/>
<pad name="8" x="17.78" y="-0.2286" drill="1.016" rot="R90"/>
<rectangle x1="14.9225" y1="-0.1905" x2="15.5575" y2="0.1905" layer="51"/>
<rectangle x1="17.4625" y1="-0.1905" x2="18.0975" y2="0.1905" layer="51"/>
</package>
<package name="SAMTECH_FTSH-105-01">
<description>&lt;h3&gt;2x5 Connector (Cortex Debug Connector)&lt;/h3&gt;
&lt;p&gt;&lt;a href="https://www.samtec.com/ftppub/cpdf/FTSH-1XX-XX-XXX-DV-XXX-MKT.pdf"&gt;Datasheet&lt;/a&gt;&lt;/p&gt;</description>
<wire x1="3.175" y1="1.7145" x2="3.175" y2="-1.7145" width="0.127" layer="51"/>
<wire x1="3.175" y1="-1.7145" x2="-3.175" y2="-1.7145" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-1.7145" x2="-3.175" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="-3.175" y1="1.7145" x2="3.175" y2="1.7145" width="0.127" layer="51"/>
<rectangle x1="-0.2032" y1="1.7145" x2="0.2032" y2="2.921" layer="51"/>
<rectangle x1="1.0668" y1="1.7145" x2="1.4732" y2="2.921" layer="51"/>
<rectangle x1="2.3368" y1="1.7145" x2="2.7432" y2="2.921" layer="51"/>
<rectangle x1="-1.4732" y1="1.7145" x2="-1.0668" y2="2.921" layer="51"/>
<rectangle x1="-2.7432" y1="1.7145" x2="-2.3368" y2="2.921" layer="51"/>
<rectangle x1="-0.2032" y1="-2.921" x2="0.2032" y2="-1.7145" layer="51" rot="R180"/>
<rectangle x1="-1.4732" y1="-2.921" x2="-1.0668" y2="-1.7145" layer="51" rot="R180"/>
<rectangle x1="-2.7432" y1="-2.921" x2="-2.3368" y2="-1.7145" layer="51" rot="R180"/>
<rectangle x1="1.0668" y1="-2.921" x2="1.4732" y2="-1.7145" layer="51" rot="R180"/>
<rectangle x1="2.3368" y1="-2.921" x2="2.7432" y2="-1.7145" layer="51" rot="R180"/>
<smd name="6" x="0" y="2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="8" x="1.27" y="2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="10" x="2.54" y="2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="4" x="-1.27" y="2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="2" x="-2.54" y="2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="1" x="-2.54" y="-2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="3" x="-1.27" y="-2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="5" x="0" y="-2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="7" x="1.27" y="-2.413" dx="0.508" dy="1.27" layer="1"/>
<smd name="9" x="2.54" y="-2.413" dx="0.508" dy="1.27" layer="1"/>
<wire x1="-3.175" y1="-1.7145" x2="-3.175" y2="1.7145" width="0.127" layer="51"/>
<wire x1="-3.175" y1="1.7145" x2="-3.0226" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="3.0226" y1="1.7145" x2="3.175" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="3.175" y1="1.7145" x2="3.175" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="3.175" y1="-1.7145" x2="3.0226" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="-3.0226" y1="-1.7145" x2="-3.175" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="-2.0574" y1="1.7145" x2="-1.7526" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="-0.7874" y1="1.7145" x2="-0.4826" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="0.4826" y1="1.7145" x2="0.7874" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="1.7526" y1="1.7145" x2="2.0574" y2="1.7145" width="0.2032" layer="21"/>
<wire x1="2.0574" y1="-1.7145" x2="1.7526" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="0.7874" y1="-1.7145" x2="0.4826" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="-0.4826" y1="-1.7145" x2="-0.7874" y2="-1.7145" width="0.2032" layer="21"/>
<wire x1="-1.7526" y1="-1.7145" x2="-2.0574" y2="-1.7145" width="0.2032" layer="21"/>
<text x="0" y="0" size="0.8128" layer="25" align="bottom-center">&gt;Name</text>
<text x="0" y="0" size="0.8128" layer="27" align="top-center">&gt;Value</text>
</package>
<package name="2X5-PTH-1.27MM">
<description>&lt;h3&gt;ARM Cortex Debug Connector (10-pin)&lt;/h3&gt;
&lt;p&gt;For debuggers and/or programemrs that support the Cortex Debug Connector (10-pin) interface.&lt;/p&gt;
&lt;p&gt;tDoc (51) layer border represents maximum dimensions of plastic housing.&lt;/p&gt;
&lt;p&gt;&lt;a href="http://www.digikey.com/product-detail/en/20021111-00010T4LF/609-3712-ND/2209072"&gt;Example Digikey Part&lt;/a&gt;&lt;/p&gt;</description>
<pad name="8" x="1.27" y="0.635" drill="0.508" diameter="1"/>
<pad name="6" x="0" y="0.635" drill="0.508" diameter="1"/>
<pad name="4" x="-1.27" y="0.635" drill="0.508" diameter="1"/>
<pad name="2" x="-2.54" y="0.635" drill="0.508" diameter="1"/>
<text x="-3.048" y="1.397" size="0.8128" layer="25">&gt;NAME</text>
<text x="-2.921" y="-1.397" size="0.8128" layer="27" align="top-left">&gt;VALUE</text>
<pad name="10" x="2.54" y="0.635" drill="0.508" diameter="1"/>
<pad name="7" x="1.27" y="-0.635" drill="0.508" diameter="1"/>
<pad name="5" x="0" y="-0.635" drill="0.508" diameter="1"/>
<pad name="3" x="-1.27" y="-0.635" drill="0.508" diameter="1"/>
<pad name="1" x="-2.54" y="-0.635" drill="0.508" diameter="1"/>
<pad name="9" x="2.54" y="-0.635" drill="0.508" diameter="1"/>
<wire x1="-3.403" y1="-1.021" x2="-3.403" y2="-0.259" width="0.254" layer="21"/>
<wire x1="3.175" y1="1.715" x2="-3.175" y2="1.715" width="0.127" layer="51"/>
<wire x1="-3.175" y1="1.715" x2="-3.175" y2="-1.715" width="0.127" layer="51"/>
<wire x1="-3.175" y1="-1.715" x2="3.175" y2="-1.715" width="0.127" layer="51"/>
<wire x1="3.175" y1="-1.715" x2="3.175" y2="1.715" width="0.127" layer="51"/>
</package>
<package name="MICRO-SD-SOCKET-SDIO">
<smd name="GND1" x="0.37" y="14.55" dx="1.4" dy="1.9" layer="1"/>
<smd name="DAT2" x="5.03" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="CD/DAT3" x="6.13" y="10.3" dx="0.8" dy="1.5" layer="1"/>
<smd name="CMD" x="7.23" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="VCC" x="8.33" y="10.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="CLK" x="9.43" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="GND" x="10.53" y="10.9" dx="0.8" dy="1.5" layer="1"/>
<smd name="DAT0" x="11.63" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<smd name="DAT1" x="12.73" y="10.7" dx="0.8" dy="1.5" layer="1"/>
<text x="14.605" y="15.875" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Pressed</text>
<text x="14.605" y="17.78" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Locked</text>
<text x="14.605" y="20.955" size="1.27" layer="51" font="vector" ratio="10" align="center-left">Unlocked</text>
</package>
<package name="1X02_POKEHOME">
<description>2 pin poke-home connector
part number 2062-2P from STA</description>
<wire x1="-7" y1="-4" x2="-7" y2="2" width="0.2032" layer="21"/>
<wire x1="-7" y1="2" x2="-7" y2="4" width="0.2032" layer="21"/>
<wire x1="4.7" y1="4" x2="4.7" y2="-4" width="0.2032" layer="21"/>
<wire x1="4.7" y1="-4" x2="-7" y2="-4" width="0.2032" layer="21"/>
<smd name="P2" x="5.25" y="-2" dx="3.5" dy="2" layer="1"/>
<smd name="P1" x="5.25" y="2" dx="3.5" dy="2" layer="1"/>
<smd name="P4" x="-4" y="-2" dx="6" dy="2" layer="1"/>
<smd name="P3" x="-4" y="2" dx="6" dy="2" layer="1"/>
<wire x1="-7" y1="4" x2="4.7" y2="4" width="0.2032" layer="21"/>
<text x="0.635" y="-3.175" size="0.4064" layer="25">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="ARDUINO_SERIAL_PROGRAM">
<wire x1="1.27" y1="-7.62" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="0" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="0" y2="5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="0" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="7.62" x2="0" y2="7.62" width="0.6096" layer="94"/>
<text x="-5.08" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="10.922" size="1.778" layer="95">&gt;NAME</text>
<pin name="DTR" x="5.08" y="-5.08" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="RXI" x="5.08" y="-2.54" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="TXO" x="5.08" y="0" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="VCC" x="5.08" y="2.54" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="CTS" x="5.08" y="5.08" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="GND" x="5.08" y="7.62" visible="pin" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="ATARI_CONNECTOR">
<wire x1="-9.398" y1="-12.7" x2="2.54" y2="-12.7" width="0.254" layer="94"/>
<wire x1="2.54" y1="-12.7" x2="2.54" y2="12.7" width="0.254" layer="94"/>
<wire x1="2.54" y1="12.7" x2="-9.398" y2="12.7" width="0.254" layer="94"/>
<wire x1="-9.398" y1="12.7" x2="-9.398" y2="-12.7" width="0.254" layer="94"/>
<wire x1="8.382" y1="10.922" x2="7.62" y2="10.16" width="0.254" layer="94"/>
<wire x1="6.858" y1="9.398" x2="7.62" y2="10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="10.16" x2="6.858" y2="10.922" width="0.254" layer="94"/>
<wire x1="7.62" y1="10.16" x2="8.382" y2="9.398" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="8.382" y2="4.318" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="8.382" y2="5.842" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="6.858" y2="5.842" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="6.858" y2="4.318" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="8.382" y2="0.762" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="8.382" y2="-0.762" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="6.858" y2="-0.762" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="6.858" y2="0.762" width="0.254" layer="94"/>
<text x="-7.874" y="13.716" size="1.778" layer="95">&gt;NAME</text>
<text x="-8.382" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<pin name="UP" x="7.62" y="-10.16" visible="pin" length="middle" rot="R180"/>
<pin name="DOWN" x="7.62" y="-7.62" visible="pin" length="middle" rot="R180"/>
<pin name="LEFT" x="7.62" y="-5.08" visible="pin" length="middle" rot="R180"/>
<pin name="RIGHT" x="7.62" y="-2.54" visible="pin" length="middle" rot="R180"/>
<pin name="NC1" x="7.62" y="0" visible="pin" length="middle" rot="R180"/>
<pin name="BUTTON" x="7.62" y="2.54" visible="pin" length="middle" rot="R180"/>
<pin name="NC2" x="7.62" y="5.08" visible="pin" length="middle" rot="R180"/>
<pin name="GND" x="7.62" y="7.62" visible="pin" length="middle" rot="R180"/>
<pin name="NC3" x="7.62" y="10.16" visible="pin" length="middle" rot="R180"/>
</symbol>
<symbol name="ATX24-1">
<wire x1="-12.7" y1="-22.86" x2="-12.7" y2="20.32" width="0.254" layer="94"/>
<wire x1="-12.7" y1="20.32" x2="10.16" y2="20.32" width="0.254" layer="94"/>
<wire x1="10.16" y1="20.32" x2="10.16" y2="-22.86" width="0.254" layer="94"/>
<wire x1="10.16" y1="-22.86" x2="-12.7" y2="-22.86" width="0.254" layer="94"/>
<text x="-12.7" y="20.32" size="1.27" layer="95">&gt;Name</text>
<text x="-12.7" y="-25.4" size="1.27" layer="96">&gt;Value</text>
<pin name="-12V" x="12.7" y="-7.62" length="short" rot="R180"/>
<pin name="3.3V@0" x="12.7" y="17.78" length="short" rot="R180"/>
<pin name="3.3V@1" x="12.7" y="15.24" length="short" rot="R180"/>
<pin name="3.3V@2" x="12.7" y="12.7" length="short" rot="R180"/>
<pin name="3.3V@3" x="12.7" y="10.16" length="short" rot="R180"/>
<pin name="5V@0" x="-15.24" y="7.62" length="short"/>
<pin name="5V@1" x="-15.24" y="10.16" length="short"/>
<pin name="5V@2" x="-15.24" y="12.7" length="short"/>
<pin name="5V@3" x="-15.24" y="15.24" length="short"/>
<pin name="5V@4" x="-15.24" y="17.78" length="short"/>
<pin name="5V_STDBY" x="-15.24" y="2.54" length="short"/>
<pin name="12V@0" x="12.7" y="0" length="short" rot="R180"/>
<pin name="12V@1" x="12.7" y="-2.54" length="short" rot="R180"/>
<pin name="GND@0" x="-15.24" y="-20.32" length="short"/>
<pin name="GND@1" x="-15.24" y="-17.78" length="short"/>
<pin name="GND@2" x="-15.24" y="-15.24" length="short"/>
<pin name="GND@3" x="-15.24" y="-12.7" length="short"/>
<pin name="GND@4" x="-15.24" y="-10.16" length="short"/>
<pin name="GND@5" x="-15.24" y="-7.62" length="short"/>
<pin name="GND@6" x="-15.24" y="-5.08" length="short"/>
<pin name="GND@7" x="-15.24" y="-2.54" length="short"/>
<pin name="NC" x="12.7" y="-20.32" length="short" rot="R180"/>
<pin name="PS_ON" x="12.7" y="-12.7" length="short" rot="R180"/>
<pin name="PWR_OK" x="12.7" y="-15.24" length="short" rot="R180"/>
</symbol>
<symbol name="AUDIO-JACK">
<wire x1="-1.27" y1="-2.54" x2="0" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.27" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="-1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="-3.81" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="94"/>
<text x="-5.08" y="3.048" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="2.286" y="-2.286" size="1.016" layer="94" ratio="15">L</text>
<text x="2.286" y="0.254" size="1.016" layer="94" ratio="15">R</text>
<rectangle x1="-7.62" y1="-0.762" x2="-2.54" y2="0.762" layer="94" rot="R90"/>
<pin name="RIGHT" x="5.08" y="0" visible="off" length="short" rot="R180"/>
<pin name="LEFT" x="5.08" y="-2.54" visible="off" length="short" rot="R180"/>
<pin name="SLEEVE" x="5.08" y="2.54" visible="off" length="short" rot="R180"/>
</symbol>
<symbol name="AUDIO-JACK2">
<wire x1="-1.27" y1="-5.08" x2="0" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="0" y1="-3.81" x2="1.27" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="-1.27" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-3.81" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="-5.08" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<text x="-5.08" y="5.588" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-6.35" y1="-5.08" x2="-5.08" y2="5.08" layer="94"/>
<pin name="RING" x="5.08" y="2.54" visible="off" length="short" rot="R180"/>
<pin name="TIP" x="5.08" y="-5.08" visible="off" length="short" rot="R180"/>
<pin name="SLEEVE" x="5.08" y="5.08" visible="off" length="short" rot="R180"/>
<pin name="RSH" x="5.08" y="0" visible="off" length="short" rot="R180"/>
<pin name="TSH" x="5.08" y="-2.54" visible="off" length="short" rot="R180"/>
</symbol>
<symbol name="AVR_MINI_PROGRAMMER">
<wire x1="-3.81" y1="7.62" x2="5.08" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="5.08" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="7.62" x2="-3.81" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="-3.81" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="-2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="-2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-7.62" x2="-2.54" y2="-7.62" width="0.6096" layer="94"/>
<text x="6.096" y="10.414" size="1.778" layer="96" rot="R180">&gt;VALUE</text>
<text x="5.08" y="-10.922" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="VCC" x="-7.62" y="5.08" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="GND" x="-7.62" y="2.54" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="RST" x="-7.62" y="0" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="MOSI" x="-7.62" y="-2.54" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="SCK" x="-7.62" y="-5.08" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="MISO" x="-7.62" y="-7.62" visible="pin" length="middle" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="AVR_SPI_PROGRAMMER_6">
<wire x1="-5.08" y1="-5.08" x2="7.62" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<text x="-4.318" y="5.842" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.064" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="8.89" y="0.635" size="1.27" layer="94">MOSI</text>
<text x="-11.938" y="-2.032" size="1.27" layer="94">RESET</text>
<text x="-11.938" y="0.508" size="1.27" layer="94">SCK</text>
<text x="-11.938" y="3.302" size="1.27" layer="94">MISO</text>
<text x="8.89" y="3.048" size="1.27" layer="94">+5</text>
<text x="8.89" y="-2.032" size="1.27" layer="94">GND</text>
<pin name="1" x="-7.62" y="2.54" visible="pad" direction="pas" function="dot"/>
<pin name="2" x="10.16" y="2.54" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-7.62" y="0" visible="pad" direction="pas" function="dot"/>
<pin name="4" x="10.16" y="0" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-7.62" y="-2.54" visible="pad" direction="pas" function="dot"/>
<pin name="6" x="10.16" y="-2.54" visible="pad" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="AVR_SPI_PROGRAMMER">
<wire x1="-5.08" y1="-7.62" x2="7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="7.62" x2="-5.08" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<text x="-4.318" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.064" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-11.43" y="5.715" size="1.27" layer="94">MOSI</text>
<text x="-12.7" y="0.635" size="1.27" layer="94">RESET</text>
<text x="-10.795" y="-1.905" size="1.27" layer="94">SCK</text>
<text x="-11.43" y="-4.445" size="1.27" layer="94">MISO</text>
<text x="9.525" y="5.715" size="1.27" layer="94">+5</text>
<text x="9.525" y="3.175" size="1.27" layer="94">GND</text>
<text x="9.525" y="0.635" size="1.27" layer="94">GND</text>
<text x="9.525" y="-1.905" size="1.27" layer="94">GND</text>
<text x="9.525" y="-4.445" size="1.27" layer="94">GND</text>
<pin name="1" x="-7.62" y="5.08" visible="pad" direction="pas" function="dot"/>
<pin name="2" x="10.16" y="5.08" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-7.62" y="2.54" visible="pad" direction="pas" function="dot"/>
<pin name="4" x="10.16" y="2.54" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-7.62" y="0" visible="pad" direction="pas" function="dot"/>
<pin name="6" x="10.16" y="0" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-7.62" y="-2.54" visible="pad" direction="pas" function="dot"/>
<pin name="8" x="10.16" y="-2.54" visible="pad" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" direction="pas" function="dot"/>
<pin name="10" x="10.16" y="-5.08" visible="pad" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="AVR_SPI_PROGRAMMER-1">
<text x="-4.318" y="8.382" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="9.525" y="5.715" size="1.27" layer="94">VCC</text>
<pin name="MOSI" x="-7.62" y="5.08" visible="pad" direction="pas" function="dot"/>
<pin name="VCC" x="10.16" y="5.08" visible="pad" direction="pwr" function="dot" rot="R180"/>
<pin name="NC" x="-7.62" y="2.54" visible="pad" direction="nc" function="dot"/>
<pin name="GND@1" x="10.16" y="2.54" visible="pad" direction="pwr" function="dot" rot="R180"/>
<pin name="RESET" x="-7.62" y="0" visible="pad" direction="pas" function="dot"/>
<pin name="GND@2" x="10.16" y="0" visible="pad" direction="pwr" function="dot" rot="R180"/>
<pin name="SCK" x="-7.62" y="-2.54" visible="pad" direction="pas" function="dot"/>
<pin name="GND@3" x="10.16" y="-2.54" visible="pad" direction="pwr" function="dot" rot="R180"/>
<pin name="MISO" x="-7.62" y="-5.08" visible="pad" direction="pas" function="dot"/>
<pin name="GND@4" x="10.16" y="-5.08" visible="pad" direction="pwr" function="dot" rot="R180"/>
</symbol>
<symbol name="BANANA_CONN">
<circle x="0" y="0" radius="1.2951" width="0.254" layer="94"/>
<text x="-1.016" y="1.778" size="1.27" layer="95">&gt;NAME</text>
<text x="-1.016" y="-3.048" size="1.27" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
</symbol>
<symbol name="BC9VPC">
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="5.08" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="2.54" y1="5.842" x2="2.54" y2="4.318" width="0.254" layer="94"/>
<wire x1="1.778" y1="5.08" x2="3.302" y2="5.08" width="0.254" layer="94"/>
<text x="-10.16" y="-7.62" size="1.778" layer="94">&gt;VALUE</text>
<text x="-10.16" y="3.556" size="1.778" layer="94">&gt;NAME</text>
<pin name="V+" x="0" y="7.62" visible="off" length="middle" rot="R270"/>
<pin name="V-" x="0" y="-10.16" visible="off" length="middle" rot="R90"/>
</symbol>
<symbol name="BNC">
<circle x="0" y="0" radius="2.54" width="0.254" layer="94"/>
<circle x="0" y="0" radius="0.5679" width="0.254" layer="94"/>
<text x="-2.54" y="5.08" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="-2.54" size="1.778" layer="94" rot="MR180">GND</text>
<text x="2.54" y="0" size="1.778" layer="94">OUT</text>
<pin name="OUT" x="5.08" y="0" visible="off" length="middle" rot="R180"/>
<pin name="GND" x="0" y="-5.08" visible="off" length="short" rot="R90"/>
</symbol>
<symbol name="F09G">
<wire x1="-1.651" y1="3.429" x2="-1.651" y2="1.651" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="1.651" x2="1.524" y2="3.429" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="5.969" x2="-1.651" y2="4.191" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-3.429" x2="1.524" y2="-1.651" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="-0.889" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-1.651" x2="-1.651" y2="-3.429" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-5.969" x2="1.524" y2="-4.191" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-4.191" x2="-1.651" y2="-5.969" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-4.064" y1="6.9312" x2="-2.5226" y2="8.172" width="0.4064" layer="94" curve="-102.324066" cap="flat"/>
<wire x1="-2.5226" y1="8.1718" x2="0" y2="7.62" width="0.4064" layer="94"/>
<wire x1="0" y1="7.62" x2="3.0654" y2="6.9494" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="6.9495" x2="4.0642" y2="5.7088" width="0.4064" layer="94" curve="-77.655139" cap="flat"/>
<wire x1="4.064" y1="-5.7088" x2="4.064" y2="5.7088" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="-6.9494" x2="4.064" y2="-5.7088" width="0.4064" layer="94" curve="77.657889"/>
<wire x1="-4.064" y1="-6.9312" x2="-4.064" y2="6.9312" width="0.4064" layer="94"/>
<wire x1="-2.5226" y1="-8.1718" x2="0" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="0" y1="-7.62" x2="3.0654" y2="-6.9494" width="0.4064" layer="94"/>
<wire x1="-4.064" y1="-6.9312" x2="-2.5226" y2="-8.1719" width="0.4064" layer="94" curve="102.337599" cap="flat"/>
<text x="-3.81" y="-10.795" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas"/>
<pin name="6" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="2" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="7" x="7.62" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="3" x="-7.62" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="8" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="4" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="9" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="5" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="DB25">
<wire x1="1.27" y1="12.7" x2="2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-1.27" y2="12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="10.16" x2="-1.27" y2="10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-1.27" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-1.27" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.27" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-12.7" x2="2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-17.78" x2="2.54" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-1.27" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-1.27" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-1.27" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-10.16" x2="-1.27" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-12.7" x2="-1.27" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="-15.24" x2="-1.27" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-15.24" x2="2.54" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="2.5226" y1="-20.8718" x2="4.0637" y2="-19.6312" width="0.4064" layer="94" curve="102.322193" cap="flat"/>
<wire x1="2.5226" y1="-20.8718" x2="-3.0654" y2="-19.6494" width="0.4064" layer="94"/>
<wire x1="-4.064" y1="-18.4088" x2="-3.0654" y2="-19.6494" width="0.4064" layer="94" curve="77.657889"/>
<wire x1="-4.064" y1="13.3288" x2="-4.064" y2="-18.4088" width="0.4064" layer="94"/>
<wire x1="-4.064" y1="13.3288" x2="-3.0654" y2="14.5694" width="0.4064" layer="94" curve="-77.657889"/>
<wire x1="4.064" y1="14.5512" x2="4.064" y2="-19.6312" width="0.4064" layer="94"/>
<wire x1="2.5226" y1="15.7918" x2="-3.0654" y2="14.5694" width="0.4064" layer="94"/>
<wire x1="2.5226" y1="15.7919" x2="4.064" y2="14.5512" width="0.4064" layer="94" curve="-102.337599" cap="flat"/>
<text x="-3.81" y="-23.495" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="16.51" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="14" x="-7.62" y="12.7" visible="pad" length="middle" direction="pas"/>
<pin name="2" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="15" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas"/>
<pin name="3" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="16" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas"/>
<pin name="4" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="17" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas"/>
<pin name="5" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="18" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="6" x="7.62" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="19" x="-7.62" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="7" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="20" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="8" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="21" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="9" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="22" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas"/>
<pin name="10" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="23" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas"/>
<pin name="11" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="24" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas"/>
<pin name="12" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="25" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas"/>
<pin name="13" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIN7">
<wire x1="-5.08" y1="10.16" x2="-5.08" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-10.16" x2="0" y2="-10.16" width="0.254" layer="94"/>
<wire x1="0" y1="-10.16" x2="0" y2="10.16" width="0.254" layer="94"/>
<wire x1="0" y1="10.16" x2="-5.08" y2="10.16" width="0.254" layer="94"/>
<text x="-5.334" y="10.668" size="1.27" layer="95">&gt;NAME</text>
<text x="-6.096" y="-11.938" size="1.27" layer="96">&gt;VALUE</text>
<pin name="1" x="-10.16" y="7.62" length="middle"/>
<pin name="2" x="-10.16" y="5.08" length="middle"/>
<pin name="3" x="-10.16" y="2.54" length="middle"/>
<pin name="4" x="-10.16" y="0" length="middle"/>
<pin name="5" x="-10.16" y="-2.54" length="middle"/>
<pin name="6" x="-10.16" y="-5.08" length="middle"/>
<pin name="7" x="-10.16" y="-7.62" length="middle"/>
</symbol>
<symbol name="DS_TOUCH_CONNECTOR">
<wire x1="-5.08" y1="10.16" x2="-5.08" y2="-10.16" width="0.381" layer="94"/>
<wire x1="-5.08" y1="-10.16" x2="5.08" y2="-10.16" width="0.381" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="5.08" y2="10.16" width="0.381" layer="94"/>
<wire x1="5.08" y1="10.16" x2="-5.08" y2="10.16" width="0.381" layer="94"/>
<text x="-4.826" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="X1" x="-10.16" y="7.62" length="middle"/>
<pin name="Y2" x="-10.16" y="2.54" length="middle"/>
<pin name="X2" x="-10.16" y="-2.54" length="middle"/>
<pin name="Y1" x="-10.16" y="-7.62" length="middle"/>
</symbol>
<symbol name="EB-85A">
<wire x1="-5.08" y1="12.7" x2="5.08" y2="12.7" width="0.254" layer="94"/>
<wire x1="5.08" y1="12.7" x2="5.08" y2="-10.16" width="0.254" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="-5.08" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-10.16" x2="-5.08" y2="12.7" width="0.254" layer="94"/>
<text x="-5.08" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="-10.16" y="7.62" length="middle" direction="pwr"/>
<pin name="TX2" x="-10.16" y="0" length="middle" direction="out"/>
<pin name="RX1" x="-10.16" y="2.54" length="middle" direction="in"/>
<pin name="TX1" x="-10.16" y="5.08" length="middle" direction="out"/>
<pin name="RX2" x="-10.16" y="-2.54" length="middle" direction="in"/>
<pin name="VCC" x="-10.16" y="10.16" length="middle" direction="pwr"/>
<pin name="PPS" x="-10.16" y="-5.08" length="middle" direction="out"/>
<pin name="BATT" x="-10.16" y="-7.62" length="middle" direction="pwr"/>
</symbol>
<symbol name="EM406">
<wire x1="-7.62" y1="7.62" x2="2.54" y2="7.62" width="0.254" layer="94"/>
<wire x1="2.54" y1="7.62" x2="2.54" y2="-10.16" width="0.254" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="-7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-10.16" x2="-7.62" y2="7.62" width="0.254" layer="94"/>
<text x="-7.62" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND1" x="-12.7" y="5.08" length="middle"/>
<pin name="GND2" x="-12.7" y="-5.08" length="middle"/>
<pin name="TX" x="-12.7" y="-2.54" length="middle"/>
<pin name="RX" x="-12.7" y="0" length="middle"/>
<pin name="1PPS" x="-12.7" y="-7.62" length="middle"/>
<pin name="VCC" x="-12.7" y="2.54" length="middle"/>
</symbol>
<symbol name="EM408_CON">
<wire x1="0" y1="7.62" x2="0" y2="-7.62" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="10.16" y2="-7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="-7.62" x2="10.16" y2="7.62" width="0.254" layer="94"/>
<wire x1="10.16" y1="7.62" x2="0" y2="7.62" width="0.254" layer="94"/>
<text x="0" y="-11.43" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<pin name="EN" x="-5.08" y="5.08" length="middle"/>
<pin name="GND" x="-5.08" y="2.54" length="middle"/>
<pin name="RX" x="-5.08" y="0" length="middle"/>
<pin name="TX" x="-5.08" y="-2.54" length="middle"/>
<pin name="VCC" x="-5.08" y="-5.08" length="middle"/>
</symbol>
<symbol name="F25">
<wire x1="-1.651" y1="16.129" x2="-1.651" y2="14.351" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="14.351" x2="1.524" y2="16.129" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="13.589" x2="-1.651" y2="11.811" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="11.811" x2="1.524" y2="13.589" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="11.049" x2="-1.651" y2="9.271" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="9.271" x2="1.524" y2="11.049" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="8.509" x2="-1.651" y2="6.731" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="6.731" x2="1.524" y2="8.509" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="4.191" x2="1.524" y2="5.969" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-6.731" x2="-1.651" y2="-8.509" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-8.509" x2="1.524" y2="-6.731" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-9.271" x2="-1.651" y2="-11.049" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-11.049" x2="1.524" y2="-9.271" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-11.811" x2="-1.651" y2="-13.589" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="1.524" y1="-13.589" x2="1.524" y2="-11.811" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-14.351" x2="-1.651" y2="-16.129" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-4.064" y1="17.7262" x2="-2.5226" y2="18.967" width="0.4064" layer="94" curve="-102.324066" cap="flat"/>
<wire x1="-2.5226" y1="18.9668" x2="3.0654" y2="17.7444" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="17.7445" x2="4.0642" y2="16.5038" width="0.4064" layer="94" curve="-77.655139" cap="flat"/>
<wire x1="4.064" y1="-16.5038" x2="4.064" y2="16.5038" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="-17.7444" x2="4.064" y2="-16.5038" width="0.4064" layer="94" curve="77.657889"/>
<wire x1="-4.064" y1="-17.7262" x2="-4.064" y2="17.7262" width="0.4064" layer="94"/>
<wire x1="-2.5226" y1="-18.9668" x2="3.0654" y2="-17.7444" width="0.4064" layer="94"/>
<wire x1="-4.064" y1="-17.7262" x2="-2.5226" y2="-18.9669" width="0.4064" layer="94" curve="102.337599" cap="flat"/>
<text x="-3.81" y="-21.59" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="19.685" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="15.24" visible="pad" length="middle" direction="pas"/>
<pin name="14" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="2" x="-7.62" y="12.7" visible="pad" length="middle" direction="pas"/>
<pin name="15" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="3" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas"/>
<pin name="16" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="4" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas"/>
<pin name="17" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="5" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas"/>
<pin name="18" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="6" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="19" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="7" x="-7.62" y="0" visible="pad" length="middle" direction="pas"/>
<pin name="20" x="7.62" y="0" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="8" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="21" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas"/>
<pin name="22" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="10" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas"/>
<pin name="23" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="11" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas"/>
<pin name="24" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="12" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas"/>
<pin name="25" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" rot="R180"/>
<pin name="13" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas"/>
</symbol>
<symbol name="M06">
<wire x1="1.27" y1="-7.62" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="10.16" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="10.16" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<pin name="1" x="5.08" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="5.08" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="5.08" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="5.08" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="5.08" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="5.08" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="IPOD_CONNECTOR_FEMALE">
<wire x1="-12.7" y1="38.1" x2="-12.7" y2="-40.64" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-40.64" x2="12.7" y2="-40.64" width="0.254" layer="94"/>
<wire x1="12.7" y1="-40.64" x2="12.7" y2="38.1" width="0.254" layer="94"/>
<wire x1="12.7" y1="38.1" x2="-12.7" y2="38.1" width="0.254" layer="94"/>
<pin name="LEFT_IN" x="-17.78" y="22.86" length="middle"/>
<pin name="VIDEO_OUT" x="-17.78" y="17.78" length="middle"/>
<pin name="RIGHT_IN" x="-17.78" y="25.4" length="middle"/>
<pin name="SCHROME_OUT" x="-17.78" y="15.24" length="middle"/>
<pin name="GND@1" x="-17.78" y="35.56" length="middle"/>
<pin name="SLUM_OUT" x="-17.78" y="12.7" length="middle"/>
<pin name="GND@2" x="-17.78" y="33.02" length="middle"/>
<pin name="GND@11" x="-17.78" y="10.16" length="middle"/>
<pin name="LEFT_OUT" x="-17.78" y="27.94" length="middle"/>
<pin name="GND@16" x="-17.78" y="-2.54" length="middle"/>
<pin name="RIGHT_OUT" x="-17.78" y="30.48" length="middle"/>
<pin name="FW_12V@20" x="-17.78" y="-12.7" length="middle"/>
<pin name="ACC_INDICATOR" x="-17.78" y="-15.24" length="middle"/>
<pin name="FW_TPA-" x="-17.78" y="-17.78" length="middle"/>
<pin name="USB_5V" x="-17.78" y="-20.32" length="middle"/>
<pin name="17" x="-17.78" y="-5.08" length="middle"/>
<pin name="3.3V" x="-17.78" y="-7.62" length="middle"/>
<pin name="FW_12V@19" x="-17.78" y="-10.16" length="middle"/>
<pin name="GND@15" x="-17.78" y="0" length="middle"/>
<pin name="RX" x="-17.78" y="5.08" length="middle"/>
<pin name="TX" x="-17.78" y="7.62" length="middle"/>
<pin name="FW_TPA+" x="-17.78" y="-22.86" length="middle"/>
<pin name="USB_D-" x="-17.78" y="-25.4" length="middle"/>
<pin name="FW_TPB-" x="-17.78" y="-27.94" length="middle"/>
<pin name="USB_D+" x="-17.78" y="-30.48" length="middle"/>
<pin name="FW_TPB+" x="-17.78" y="-33.02" length="middle"/>
<pin name="GND@29" x="-17.78" y="-35.56" length="middle"/>
<pin name="GND@30" x="-17.78" y="-38.1" length="middle"/>
<pin name="14" x="-17.78" y="2.54" length="middle"/>
<pin name="7" x="-17.78" y="20.32" length="middle"/>
</symbol>
<symbol name="KENT_LCD_CONN">
<wire x1="-10.16" y1="-15.24" x2="-10.16" y2="12.7" width="0.254" layer="94"/>
<wire x1="-10.16" y1="12.7" x2="10.16" y2="12.7" width="0.254" layer="94"/>
<wire x1="10.16" y1="12.7" x2="10.16" y2="-15.24" width="0.254" layer="94"/>
<wire x1="10.16" y1="-15.24" x2="-10.16" y2="-15.24" width="0.254" layer="94"/>
<text x="-3.556" y="13.716" size="1.27" layer="94">&gt;VALUE</text>
<text x="-3.302" y="-17.272" size="1.27" layer="94">&gt;NAME</text>
<pin name="VSS1" x="-15.24" y="-5.08" length="middle"/>
<pin name="VSS2" x="-15.24" y="-7.62" length="middle"/>
<pin name="VSS3" x="-15.24" y="-10.16" length="middle"/>
<pin name="VSS4" x="-15.24" y="-12.7" length="middle"/>
<pin name="VCC" x="-15.24" y="10.16" length="middle"/>
<pin name="VPWR1" x="-15.24" y="5.08" length="middle"/>
<pin name="VPWR2" x="-15.24" y="2.54" length="middle"/>
<pin name="VPWR3" x="-15.24" y="0" length="middle"/>
<pin name="/RESET" x="15.24" y="10.16" length="middle" rot="R180"/>
<pin name="BUSY" x="15.24" y="7.62" length="middle" rot="R180"/>
<pin name="SCK" x="15.24" y="2.54" length="middle" rot="R180"/>
<pin name="SO" x="15.24" y="0" length="middle" rot="R180"/>
<pin name="SI" x="15.24" y="-2.54" length="middle" rot="R180"/>
<pin name="CS" x="15.24" y="-5.08" length="middle" rot="R180"/>
<pin name="NC1" x="15.24" y="-10.16" length="middle" rot="R180"/>
<pin name="NC2" x="15.24" y="-12.7" length="middle" rot="R180"/>
</symbol>
<symbol name="LITTLEBITS_FEMALE">
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="5.08" x2="-5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<text x="-5.842" y="-7.62" size="1.778" layer="96">littleBits</text>
<text x="-4.064" y="-9.906" size="1.778" layer="95">Female</text>
<pin name="VCC" x="-7.62" y="2.54" visible="pin" length="short"/>
<pin name="SIG" x="-7.62" y="0" visible="pin" length="short"/>
<pin name="GND" x="-7.62" y="-2.54" visible="pin" length="short"/>
</symbol>
<symbol name="LITTLEBITS_MALE">
<text x="-2.794" y="-9.906" size="1.778" layer="95">Male</text>
<pin name="GND" x="7.62" y="-2.54" visible="pin" length="short" rot="R180"/>
<pin name="SIG" x="7.62" y="0" visible="pin" length="short" rot="R180"/>
<pin name="VCC" x="7.62" y="2.54" visible="pin" length="short" rot="R180"/>
</symbol>
<symbol name="LITTLEBITS">
<wire x1="-2.54" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-2.54" y2="5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<text x="-2.032" y="6.096" size="1.778" layer="94">&gt;NAME</text>
<text x="-2.794" y="-7.62" size="1.778" layer="94">LB MALE</text>
<pin name="GND" x="12.7" y="-2.54" length="middle" rot="R180"/>
<pin name="SIG" x="12.7" y="0" length="middle" rot="R180"/>
<pin name="VCC" x="12.7" y="2.54" length="middle" rot="R180"/>
</symbol>
<symbol name="M01">
<wire x1="3.81" y1="-2.54" x2="-2.54" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="3.81" y2="2.54" width="0.4064" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="3.302" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="0" visible="off" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M02">
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<text x="-2.54" y="5.842" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M03">
<wire x1="3.81" y1="-5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="5.08" width="0.4064" layer="94"/>
<text x="-2.54" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M04">
<wire x1="1.27" y1="-5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<text x="-5.08" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="5.08" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="5.08" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="5.08" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="5.08" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M04X2">
<wire x1="-3.81" y1="7.62" x2="-3.81" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="-3.81" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="7.62" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<text x="-4.572" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="-4.064" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="2" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="4" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="6" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="8" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M05">
<wire x1="3.81" y1="-7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-7.62" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<text x="-2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M05X2">
<wire x1="3.81" y1="-7.62" x2="-3.81" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="7.62" x2="-3.81" y2="-7.62" width="0.4064" layer="94"/>
<pin name="10" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="M07">
<wire x1="-5.08" y1="12.7" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="12.7" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="10.16" x2="0" y2="10.16" width="0.6096" layer="94"/>
<text x="-5.08" y="13.462" size="1.778" layer="95">&gt;NAME</text>
<pin name="7" x="5.08" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M08">
<wire x1="1.27" y1="-10.16" x2="-5.08" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-7.62" x2="0" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="-5.08" y1="12.7" x2="-5.08" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="1.27" y2="12.7" width="0.4064" layer="94"/>
<text x="-5.08" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="5.08" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="5.08" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="5.08" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="5.08" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="5.08" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="5.08" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="5.08" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="5.08" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M2X8">
<wire x1="-1.27" y1="7.62" x2="-2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="10.16" x2="-2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="-3.81" y1="12.7" x2="-3.81" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-10.16" x2="-3.81" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-10.16" x2="3.81" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="12.7" x2="3.81" y2="12.7" width="0.4064" layer="94"/>
<text x="-2.54" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="2" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="4" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="6" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="8" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="10" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="12" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="14" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="16" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M09">
<wire x1="6.35" y1="-12.7" x2="0" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="5.08" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-7.62" x2="5.08" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-10.16" x2="5.08" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="0" y1="12.7" x2="0" y2="-12.7" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-12.7" x2="6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="0" y1="12.7" x2="6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="3.81" y1="0" x2="5.08" y2="0" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-2.54" x2="5.08" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="3.81" y1="2.54" x2="5.08" y2="2.54" width="0.6096" layer="94"/>
<wire x1="3.81" y1="5.08" x2="5.08" y2="5.08" width="0.6096" layer="94"/>
<wire x1="3.81" y1="7.62" x2="5.08" y2="7.62" width="0.6096" layer="94"/>
<wire x1="3.81" y1="10.16" x2="5.08" y2="10.16" width="0.6096" layer="94"/>
<text x="0" y="-15.24" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="16.51" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M10">
<wire x1="6.35" y1="-20.32" x2="0" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-12.7" x2="5.08" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-15.24" x2="5.08" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-17.78" x2="5.08" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="0" y1="7.62" x2="0" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-20.32" x2="6.35" y2="7.62" width="0.4064" layer="94"/>
<wire x1="0" y1="7.62" x2="6.35" y2="7.62" width="0.4064" layer="94"/>
<text x="0" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M10X2">
<wire x1="-3.81" y1="12.7" x2="-3.81" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-10.16" x2="-2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-12.7" x2="-2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-15.24" x2="-3.81" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-15.24" x2="3.81" y2="12.7" width="0.4064" layer="94"/>
<text x="-2.54" y="-17.78" size="1.778" layer="96">&gt;VALUE</text>
<pin name="17" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="18" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="20" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M11">
<wire x1="6.35" y1="-15.24" x2="0" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="0" y1="15.24" x2="0" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-15.24" x2="6.35" y2="15.24" width="0.4064" layer="94"/>
<wire x1="0" y1="15.24" x2="6.35" y2="15.24" width="0.4064" layer="94"/>
<wire x1="3.81" y1="12.7" x2="5.08" y2="12.7" width="0.6096" layer="94"/>
<text x="0" y="-17.78" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="16.002" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M12">
<wire x1="6.35" y1="-17.78" x2="0" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="0" y1="15.24" x2="0" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-17.78" x2="6.35" y2="15.24" width="0.4064" layer="94"/>
<text x="0" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M13">
<wire x1="0" y1="17.78" x2="0" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-17.78" x2="6.35" y2="17.78" width="0.4064" layer="94"/>
<wire x1="0" y1="17.78" x2="6.35" y2="17.78" width="0.4064" layer="94"/>
<wire x1="3.81" y1="15.24" x2="5.08" y2="15.24" width="0.6096" layer="94"/>
<text x="0" y="18.542" size="1.778" layer="95">&gt;NAME</text>
<pin name="13" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M14">
<wire x1="0" y1="17.78" x2="0" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-20.32" x2="6.35" y2="17.78" width="0.4064" layer="94"/>
<pin name="11" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M15">
<wire x1="0" y1="20.32" x2="0" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-20.32" x2="6.35" y2="20.32" width="0.4064" layer="94"/>
<wire x1="0" y1="20.32" x2="6.35" y2="20.32" width="0.4064" layer="94"/>
<wire x1="3.81" y1="17.78" x2="5.08" y2="17.78" width="0.6096" layer="94"/>
<text x="0" y="21.082" size="1.778" layer="95">&gt;NAME</text>
<pin name="15" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M16">
<wire x1="6.35" y1="-22.86" x2="0" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-20.32" x2="5.08" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="0" y1="20.32" x2="0" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-22.86" x2="6.35" y2="20.32" width="0.4064" layer="94"/>
<text x="0" y="-25.4" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="10.16" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M17">
<wire x1="0" y1="22.86" x2="0" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-22.86" x2="6.35" y2="22.86" width="0.4064" layer="94"/>
<wire x1="0" y1="22.86" x2="6.35" y2="22.86" width="0.4064" layer="94"/>
<wire x1="3.81" y1="20.32" x2="5.08" y2="20.32" width="0.6096" layer="94"/>
<text x="0" y="23.622" size="1.778" layer="95">&gt;NAME</text>
<pin name="17" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M18">
<wire x1="3.81" y1="-25.4" x2="-2.54" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-20.32" x2="2.54" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="22.86" x2="-2.54" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-25.4" x2="3.81" y2="22.86" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="22.86" x2="3.81" y2="22.86" width="0.4064" layer="94"/>
<wire x1="1.27" y1="15.24" x2="2.54" y2="15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="17.78" x2="2.54" y2="17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="20.32" x2="2.54" y2="20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-22.86" x2="2.54" y2="-22.86" width="0.6096" layer="94"/>
<text x="-2.54" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="24.13" size="1.778" layer="95">&gt;NAME</text>
<pin name="2" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M19">
<wire x1="6.35" y1="-25.4" x2="0" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-22.86" x2="5.08" y2="-22.86" width="0.6096" layer="94"/>
<wire x1="0" y1="25.4" x2="0" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-25.4" x2="6.35" y2="25.4" width="0.4064" layer="94"/>
<wire x1="0" y1="25.4" x2="6.35" y2="25.4" width="0.4064" layer="94"/>
<wire x1="3.81" y1="22.86" x2="5.08" y2="22.86" width="0.6096" layer="94"/>
<text x="0" y="-27.94" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="26.67" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="10.16" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M20">
<wire x1="6.35" y1="2.54" x2="0" y2="2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="25.4" x2="5.08" y2="25.4" width="0.6096" layer="94"/>
<wire x1="3.81" y1="27.94" x2="5.08" y2="27.94" width="0.6096" layer="94"/>
<wire x1="3.81" y1="35.56" x2="5.08" y2="35.56" width="0.6096" layer="94"/>
<wire x1="3.81" y1="33.02" x2="5.08" y2="33.02" width="0.6096" layer="94"/>
<wire x1="3.81" y1="30.48" x2="5.08" y2="30.48" width="0.6096" layer="94"/>
<wire x1="0" y1="55.88" x2="0" y2="2.54" width="0.4064" layer="94"/>
<wire x1="6.35" y1="2.54" x2="6.35" y2="55.88" width="0.4064" layer="94"/>
<wire x1="0" y1="55.88" x2="6.35" y2="55.88" width="0.4064" layer="94"/>
<wire x1="3.81" y1="40.64" x2="5.08" y2="40.64" width="0.6096" layer="94"/>
<wire x1="3.81" y1="38.1" x2="5.08" y2="38.1" width="0.6096" layer="94"/>
<wire x1="3.81" y1="43.18" x2="5.08" y2="43.18" width="0.6096" layer="94"/>
<wire x1="3.81" y1="45.72" x2="5.08" y2="45.72" width="0.6096" layer="94"/>
<wire x1="3.81" y1="48.26" x2="5.08" y2="48.26" width="0.6096" layer="94"/>
<wire x1="3.81" y1="50.8" x2="5.08" y2="50.8" width="0.6096" layer="94"/>
<wire x1="3.81" y1="53.34" x2="5.08" y2="53.34" width="0.6096" layer="94"/>
<text x="0" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="57.15" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="38.1" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="40.64" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="43.18" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="10.16" y="45.72" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="10.16" y="48.26" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="10.16" y="50.8" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="10.16" y="53.34" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M24">
<wire x1="3.81" y1="-30.48" x2="-2.54" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-25.4" x2="2.54" y2="-25.4" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-27.94" x2="2.54" y2="-27.94" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="33.02" x2="-2.54" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-30.48" x2="3.81" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="33.02" x2="3.81" y2="33.02" width="0.4064" layer="94"/>
<wire x1="1.27" y1="22.86" x2="2.54" y2="22.86" width="0.6096" layer="94"/>
<wire x1="1.27" y1="25.4" x2="2.54" y2="25.4" width="0.6096" layer="94"/>
<wire x1="1.27" y1="27.94" x2="2.54" y2="27.94" width="0.6096" layer="94"/>
<wire x1="1.27" y1="30.48" x2="2.54" y2="30.48" width="0.6096" layer="94"/>
<text x="-2.54" y="-33.02" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="33.782" size="1.778" layer="95">&gt;NAME</text>
<pin name="2" x="7.62" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="7.62" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="7.62" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M25">
<wire x1="6.35" y1="-33.02" x2="0" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-25.4" x2="5.08" y2="-25.4" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-27.94" x2="5.08" y2="-27.94" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-30.48" x2="5.08" y2="-30.48" width="0.6096" layer="94"/>
<wire x1="0" y1="33.02" x2="0" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-33.02" x2="6.35" y2="33.02" width="0.4064" layer="94"/>
<wire x1="0" y1="33.02" x2="6.35" y2="33.02" width="0.4064" layer="94"/>
<text x="0" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="33.782" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="10.16" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="10.16" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="10.16" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="10.16" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M27">
<wire x1="6.35" y1="-35.56" x2="0" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-33.02" x2="5.08" y2="-33.02" width="0.6096" layer="94"/>
<wire x1="0" y1="35.56" x2="0" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-35.56" x2="6.35" y2="35.56" width="0.4064" layer="94"/>
<wire x1="0" y1="35.56" x2="6.35" y2="35.56" width="0.4064" layer="94"/>
<text x="0" y="-38.1" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="36.322" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="-33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="10.16" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="10.16" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="10.16" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="26" x="10.16" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="27" x="10.16" y="33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M29">
<wire x1="3.81" y1="-38.1" x2="-2.54" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-30.48" x2="2.54" y2="-30.48" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-33.02" x2="2.54" y2="-33.02" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-35.56" x2="2.54" y2="-35.56" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="38.1" x2="-2.54" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-38.1" x2="3.81" y2="38.1" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="38.1" x2="3.81" y2="38.1" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="12.7" x2="2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="33.02" x2="2.54" y2="33.02" width="0.6096" layer="94"/>
<wire x1="1.27" y1="35.56" x2="2.54" y2="35.56" width="0.6096" layer="94"/>
<text x="-2.54" y="-40.64" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="39.37" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="-33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="7.62" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="26" x="7.62" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="27" x="7.62" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="28" x="7.62" y="33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="29" x="7.62" y="35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M30">
<wire x1="3.81" y1="-40.64" x2="-2.54" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-38.1" x2="2.54" y2="-38.1" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-17.78" x2="2.54" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-15.24" x2="2.54" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-12.7" x2="2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="38.1" x2="-2.54" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-40.64" x2="3.81" y2="38.1" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="2.54" y2="10.16" width="0.6096" layer="94"/>
<text x="-2.54" y="-43.18" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="7.62" y="-38.1" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="-35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="26" x="7.62" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="27" x="7.62" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="28" x="7.62" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="29" x="7.62" y="33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="30" x="7.62" y="35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="M40">
<wire x1="6.35" y1="-48.26" x2="0" y2="-48.26" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-40.64" x2="5.08" y2="-40.64" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-43.18" x2="5.08" y2="-43.18" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-45.72" x2="5.08" y2="-45.72" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-35.56" x2="5.08" y2="-35.56" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-38.1" x2="5.08" y2="-38.1" width="0.6096" layer="94"/>
<wire x1="0" y1="55.88" x2="0" y2="-48.26" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-48.26" x2="6.35" y2="55.88" width="0.4064" layer="94"/>
<text x="0" y="-50.8" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="10.16" y="-45.72" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="-43.18" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="-40.64" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="-38.1" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="10.16" y="-35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="-33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="10.16" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="10.16" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="10.16" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="10.16" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="10.16" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="10.16" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="10.16" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="10.16" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="10.16" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="10.16" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="10.16" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="25" x="10.16" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="26" x="10.16" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="27" x="10.16" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="28" x="10.16" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="29" x="10.16" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="30" x="10.16" y="27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="31" x="10.16" y="30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="32" x="10.16" y="33.02" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="33" x="10.16" y="35.56" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="34" x="10.16" y="38.1" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="35" x="10.16" y="40.64" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="36" x="10.16" y="43.18" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="37" x="10.16" y="45.72" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="38" x="10.16" y="48.26" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="39" x="10.16" y="50.8" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="40" x="10.16" y="53.34" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="MAGJACK">
<wire x1="-12.7" y1="-15.24" x2="12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="-15.24" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="2.54" width="0.254" layer="94"/>
<wire x1="12.7" y1="2.54" x2="12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="12.7" x2="-12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="10.668" y2="10.16" width="0.254" layer="94"/>
<wire x1="10.668" y1="10.16" x2="10.668" y2="7.112" width="0.254" layer="94"/>
<wire x1="10.668" y1="7.112" x2="9.398" y2="7.112" width="0.254" layer="94"/>
<wire x1="9.398" y1="7.112" x2="10.668" y2="5.842" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="11.938" y2="7.112" width="0.254" layer="94"/>
<wire x1="11.938" y1="7.112" x2="10.668" y2="7.112" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="11.938" y2="5.842" width="0.254" layer="94"/>
<wire x1="9.398" y1="5.842" x2="10.668" y2="5.842" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="10.668" y2="2.54" width="0.254" layer="94"/>
<wire x1="10.668" y1="2.54" x2="12.7" y2="2.54" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="10.668" y2="-5.08" width="0.254" layer="94"/>
<wire x1="10.668" y1="-5.08" x2="10.668" y2="-8.128" width="0.254" layer="94"/>
<wire x1="10.668" y1="-8.128" x2="9.398" y2="-8.128" width="0.254" layer="94"/>
<wire x1="9.398" y1="-8.128" x2="10.668" y2="-9.398" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="11.938" y2="-8.128" width="0.254" layer="94"/>
<wire x1="11.938" y1="-8.128" x2="10.668" y2="-8.128" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="11.938" y2="-9.398" width="0.254" layer="94"/>
<wire x1="9.398" y1="-9.398" x2="10.668" y2="-9.398" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="10.668" y2="-12.7" width="0.254" layer="94"/>
<wire x1="10.668" y1="-12.7" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="8.89" y1="6.35" x2="8.128" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.128" y1="6.604" x2="8.128" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.128" y1="7.112" x2="8.636" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.89" y1="5.334" x2="8.128" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.128" y1="5.588" x2="8.128" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.128" y1="6.096" x2="8.636" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.89" y1="-8.89" x2="8.128" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.128" y1="-8.636" x2="8.128" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.128" y1="-8.128" x2="8.636" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.89" y1="-9.906" x2="8.128" y2="-9.144" width="0.254" layer="94"/>
<wire x1="8.128" y1="-9.652" x2="8.128" y2="-9.144" width="0.254" layer="94"/>
<wire x1="8.128" y1="-9.144" x2="8.636" y2="-9.144" width="0.254" layer="94"/>
<text x="-12.7" y="13.208" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-17.526" size="1.778" layer="96">&gt;VALUE</text>
<pin name="YLED-" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="YLED+" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="GLED-" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="GLED+" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="RD-" x="-17.78" y="-5.08" length="middle"/>
<pin name="RCT" x="-17.78" y="-2.54" length="middle"/>
<pin name="RD+" x="-17.78" y="0" length="middle"/>
<pin name="TD-" x="-17.78" y="5.08" length="middle"/>
<pin name="TCT" x="-17.78" y="7.62" length="middle"/>
<pin name="TD+" x="-17.78" y="10.16" length="middle"/>
<pin name="SHIELD@0" x="-17.78" y="-10.16" length="middle"/>
<pin name="SHIELD@1" x="-17.78" y="-12.7" length="middle"/>
</symbol>
<symbol name="MAGJACK-2">
<pin name="SHIELD" x="-17.78" y="-12.7" length="middle"/>
</symbol>
<symbol name="MAGJACK-POE">
<wire x1="-12.7" y1="-17.78" x2="12.7" y2="-17.78" width="0.254" layer="94"/>
<wire x1="12.7" y1="-17.78" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="5.08" width="0.254" layer="94"/>
<wire x1="12.7" y1="5.08" x2="12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="12.7" x2="12.7" y2="17.78" width="0.254" layer="94"/>
<wire x1="12.7" y1="17.78" x2="-12.7" y2="17.78" width="0.254" layer="94"/>
<wire x1="-12.7" y1="17.78" x2="-12.7" y2="-17.78" width="0.254" layer="94"/>
<wire x1="12.7" y1="12.7" x2="10.668" y2="12.7" width="0.254" layer="94"/>
<wire x1="10.668" y1="12.7" x2="10.668" y2="9.652" width="0.254" layer="94"/>
<wire x1="10.668" y1="9.652" x2="9.398" y2="9.652" width="0.254" layer="94"/>
<wire x1="9.398" y1="9.652" x2="10.668" y2="8.382" width="0.254" layer="94"/>
<wire x1="10.668" y1="8.382" x2="11.938" y2="9.652" width="0.254" layer="94"/>
<wire x1="11.938" y1="9.652" x2="10.668" y2="9.652" width="0.254" layer="94"/>
<wire x1="10.668" y1="8.382" x2="11.938" y2="8.382" width="0.254" layer="94"/>
<wire x1="9.398" y1="8.382" x2="10.668" y2="8.382" width="0.254" layer="94"/>
<wire x1="10.668" y1="8.382" x2="10.668" y2="5.08" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.08" x2="12.7" y2="5.08" width="0.254" layer="94"/>
<wire x1="8.89" y1="8.89" x2="8.128" y2="9.652" width="0.254" layer="94"/>
<wire x1="8.128" y1="9.144" x2="8.128" y2="9.652" width="0.254" layer="94"/>
<wire x1="8.128" y1="9.652" x2="8.636" y2="9.652" width="0.254" layer="94"/>
<wire x1="8.89" y1="7.874" x2="8.128" y2="8.636" width="0.254" layer="94"/>
<wire x1="8.128" y1="8.128" x2="8.128" y2="8.636" width="0.254" layer="94"/>
<wire x1="8.128" y1="8.636" x2="8.636" y2="8.636" width="0.254" layer="94"/>
<text x="-12.7" y="18.288" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-20.066" size="1.778" layer="96">&gt;VALUE</text>
<pin name="YLED-" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="YLED+" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="RD-" x="-17.78" y="-7.62" length="middle"/>
<pin name="RCT" x="-17.78" y="-5.08" length="middle"/>
<pin name="RD+" x="-17.78" y="-2.54" length="middle"/>
<pin name="TD-" x="-17.78" y="2.54" length="middle"/>
<pin name="TCT" x="-17.78" y="5.08" length="middle"/>
<pin name="TD+" x="-17.78" y="7.62" length="middle"/>
<pin name="SHIELD@0" x="-17.78" y="-12.7" length="middle"/>
<pin name="SHIELD@1" x="-17.78" y="-15.24" length="middle"/>
<pin name="V+" x="-17.78" y="15.24" length="middle"/>
<pin name="V-" x="-17.78" y="12.7" length="middle"/>
</symbol>
<symbol name="MIDI_CONN_FEMALE">
<wire x1="-7.62" y1="-7.62" x2="7.62" y2="-7.62" width="0.254" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="7.62" width="0.254" layer="94"/>
<wire x1="7.62" y1="7.62" x2="-7.62" y2="7.62" width="0.254" layer="94"/>
<wire x1="-7.62" y1="7.62" x2="-7.62" y2="-7.62" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="11.684" y2="-6.096" width="0.254" layer="94"/>
<wire x1="13.716" y1="-4.064" x2="12.7" y2="-5.08" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="11.938" y2="-4.318" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="13.716" y2="-6.096" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="11.684" y2="-4.064" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="11.684" y2="-1.016" width="0.254" layer="94"/>
<wire x1="13.716" y1="1.016" x2="12.7" y2="0" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="11.938" y2="0.762" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="13.716" y2="-1.016" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="11.684" y2="1.016" width="0.254" layer="94"/>
<text x="-3.556" y="8.636" size="1.27" layer="94" ratio="15">&gt;NAME</text>
<text x="-3.81" y="-9.398" size="1.27" layer="94" ratio="15">&gt;VALUE</text>
<pin name="NC3" x="12.7" y="-5.08" length="middle" rot="R180"/>
<pin name="GND" x="12.7" y="-2.54" length="middle" rot="R180"/>
<pin name="NC1" x="12.7" y="0" length="middle" rot="R180"/>
<pin name="CSNK" x="12.7" y="2.54" length="middle" rot="R180"/>
<pin name="CSRC" x="12.7" y="5.08" length="middle" rot="R180"/>
</symbol>
<symbol name="MIRF">
<wire x1="-6.35" y1="-10.16" x2="1.27" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="1.27" y2="10.16" width="0.4064" layer="94"/>
<wire x1="1.27" y1="10.16" x2="-6.35" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="10.16" x2="-6.35" y2="-10.16" width="0.4064" layer="94"/>
<text x="-6.35" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.905" y="6.985" size="1.27" layer="94">3.3V</text>
<text x="1.905" y="4.445" size="1.27" layer="94">CE</text>
<text x="1.905" y="1.905" size="1.27" layer="94">CS</text>
<text x="1.905" y="-0.635" size="1.27" layer="94">DR1</text>
<text x="1.905" y="-3.175" size="1.27" layer="94">CLK1</text>
<text x="1.905" y="-5.715" size="1.27" layer="94">DATA</text>
<text x="1.905" y="-8.255" size="1.27" layer="94">GND</text>
<pin name="1" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="3" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="5" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="7" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="MMA_CON">
<wire x1="1.27" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="12.7" x2="-6.35" y2="-10.16" width="0.4064" layer="94"/>
<text x="-6.35" y="13.335" size="1.778" layer="95">&gt;NAME</text>
<pin name="VCC" x="-2.54" y="10.16" length="short" direction="pas" function="dot"/>
<pin name="GND" x="-2.54" y="7.62" length="short" direction="pas" function="dot"/>
<pin name="X" x="-2.54" y="5.08" length="short" direction="pas" function="dot"/>
<pin name="Y" x="-2.54" y="2.54" length="short" direction="pas" function="dot"/>
<pin name="Z" x="-2.54" y="0" length="short" direction="pas" function="dot"/>
<pin name="GS1" x="-2.54" y="-2.54" length="short" direction="pas" function="dot"/>
<pin name="GS2" x="-2.54" y="-5.08" length="short" direction="pas" function="dot"/>
<pin name="SLP" x="-2.54" y="-7.62" length="short" direction="pas" function="dot"/>
</symbol>
<symbol name="OBDII">
<wire x1="-17.78" y1="12.7" x2="-17.78" y2="-12.7" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-12.7" x2="17.78" y2="-12.7" width="0.254" layer="94"/>
<wire x1="17.78" y1="-12.7" x2="17.78" y2="12.7" width="0.254" layer="94"/>
<wire x1="17.78" y1="12.7" x2="-17.78" y2="12.7" width="0.254" layer="94"/>
<pin name="1" x="-22.86" y="10.16" length="middle"/>
<pin name="J1850BUS+" x="-22.86" y="7.62" length="middle"/>
<pin name="3" x="-22.86" y="5.08" length="middle"/>
<pin name="CHASGND" x="-22.86" y="2.54" length="middle"/>
<pin name="SIGGND" x="-22.86" y="0" length="middle"/>
<pin name="CANHIGH" x="-22.86" y="-2.54" length="middle"/>
<pin name="ISOK-LINE" x="-22.86" y="-5.08" length="middle"/>
<pin name="8" x="-22.86" y="-7.62" length="middle"/>
<pin name="9" x="22.86" y="10.16" length="middle" rot="R180"/>
<pin name="J1850BUS" x="22.86" y="7.62" length="middle" rot="R180"/>
<pin name="11" x="22.86" y="5.08" length="middle" rot="R180"/>
<pin name="12" x="22.86" y="2.54" length="middle" rot="R180"/>
<pin name="13" x="22.86" y="0" length="middle" rot="R180"/>
<pin name="CANLOW" x="22.86" y="-2.54" length="middle" rot="R180"/>
<pin name="ISOL-LINE" x="22.86" y="-5.08" length="middle" rot="R180"/>
<pin name="BATTPOWER" x="22.86" y="-7.62" length="middle" rot="R180"/>
</symbol>
<symbol name="ICSP-PIC">
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-10.16" x2="2.54" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="2.54" y2="7.62" width="0.4064" layer="94"/>
<wire x1="2.54" y1="7.62" x2="-5.08" y2="7.62" width="0.4064" layer="94"/>
<text x="2.54" y="10.16" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<text x="-5.08" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="7.62" y="0" visible="pin" length="middle" rot="R180"/>
<pin name="PGC" x="7.62" y="-5.08" visible="pin" length="middle" rot="R180"/>
<pin name="PGD" x="7.62" y="-2.54" visible="pin" length="middle" rot="R180"/>
<pin name="PGM" x="7.62" y="-7.62" visible="pin" length="middle" rot="R180"/>
<pin name="VCC" x="7.62" y="2.54" visible="pin" length="middle" rot="R180"/>
<pin name="VPP" x="7.62" y="5.08" visible="pin" length="middle" rot="R180"/>
</symbol>
<symbol name="PIC-ISCP-MINI">
<wire x1="-3.81" y1="7.62" x2="5.08" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="5.08" y1="-7.62" x2="5.08" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-3.81" y1="7.62" x2="-3.81" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-7.62" x2="-3.81" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="-2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="-2.54" y2="-2.54" width="0.6096" layer="94"/>
<text x="6.096" y="10.414" size="1.778" layer="96" rot="R180">&gt;VALUE</text>
<text x="5.08" y="-8.382" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="VPP" x="-7.62" y="5.08" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="VCC" x="-7.62" y="2.54" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="GND" x="-7.62" y="0" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="PGD" x="-7.62" y="-2.54" visible="pin" length="middle" direction="pas" swaplevel="1"/>
<pin name="PGC" x="-7.62" y="-5.08" visible="pin" length="middle" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="PINH2X12">
<wire x1="-8.89" y1="-17.78" x2="8.89" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-17.78" x2="8.89" y2="15.24" width="0.4064" layer="94"/>
<wire x1="8.89" y1="15.24" x2="-8.89" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="15.24" x2="-8.89" y2="-17.78" width="0.4064" layer="94"/>
<text x="-8.89" y="15.875" size="1.778" layer="95">&gt;NAME</text>
<text x="-8.89" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-5.08" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X3">
<wire x1="-6.35" y1="-5.08" x2="8.89" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-5.08" x2="8.89" y2="5.08" width="0.4064" layer="94"/>
<wire x1="8.89" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-5.08" width="0.4064" layer="94"/>
<text x="-6.35" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="6" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X10">
<wire x1="-6.35" y1="-15.24" x2="8.89" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-15.24" x2="8.89" y2="12.7" width="0.4064" layer="94"/>
<wire x1="8.89" y1="12.7" x2="-6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="12.7" x2="-6.35" y2="-15.24" width="0.4064" layer="94"/>
<text x="-6.35" y="-17.78" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-2.54" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-2.54" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-2.54" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-2.54" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="PINH2X26">
<wire x1="-8.89" y1="-35.56" x2="8.89" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="8.89" y1="-35.56" x2="8.89" y2="33.02" width="0.4064" layer="94"/>
<wire x1="8.89" y1="33.02" x2="-8.89" y2="33.02" width="0.4064" layer="94"/>
<wire x1="-8.89" y1="33.02" x2="-8.89" y2="-35.56" width="0.4064" layer="94"/>
<text x="-8.89" y="33.655" size="1.778" layer="95">&gt;NAME</text>
<text x="-8.89" y="-38.1" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="5.08" y="30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="3" x="-5.08" y="27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="4" x="5.08" y="27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="5" x="-5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="6" x="5.08" y="25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="7" x="-5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="8" x="5.08" y="22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="9" x="-5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="10" x="5.08" y="20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="11" x="-5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="12" x="5.08" y="17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="13" x="-5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="14" x="5.08" y="15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="15" x="-5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="16" x="5.08" y="12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="17" x="-5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="18" x="5.08" y="10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="19" x="-5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="20" x="5.08" y="7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="21" x="-5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="22" x="5.08" y="5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="23" x="-5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="25" x="-5.08" y="0" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="27" x="-5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="29" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="31" x="-5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="33" x="-5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="35" x="-5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="37" x="-5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="39" x="-5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="41" x="-5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="43" x="-5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="45" x="-5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="47" x="-5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="49" x="-5.08" y="-30.48" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="51" x="-5.08" y="-33.02" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="24" x="5.08" y="2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="26" x="5.08" y="0" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="28" x="5.08" y="-2.54" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="30" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="32" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="34" x="5.08" y="-10.16" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="36" x="5.08" y="-12.7" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="38" x="5.08" y="-15.24" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="40" x="5.08" y="-17.78" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="42" x="5.08" y="-20.32" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="44" x="5.08" y="-22.86" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="46" x="5.08" y="-25.4" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="48" x="5.08" y="-27.94" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="50" x="5.08" y="-30.48" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
<pin name="52" x="5.08" y="-33.02" visible="pad" length="short" direction="pas" function="dot" rot="R180"/>
</symbol>
<symbol name="POWERJACK">
<wire x1="-10.16" y1="2.54" x2="-7.62" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="5.08" x2="-5.08" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="0" y2="5.08" width="0.1524" layer="94"/>
<text x="-10.16" y="10.16" size="1.778" layer="96">&gt;Value</text>
<text x="-10.16" y="0" size="1.778" layer="95">&gt;Name</text>
<rectangle x1="-10.16" y1="6.858" x2="0" y2="8.382" layer="94"/>
<pin name="GNDBREAK" x="2.54" y="5.08" visible="off" length="short" rot="R180"/>
<pin name="GND" x="2.54" y="2.54" visible="off" length="short" rot="R180"/>
<pin name="PWR" x="2.54" y="7.62" visible="off" length="short" rot="R180"/>
</symbol>
<symbol name="PSP_CONNECTOR">
<wire x1="-13.97" y1="25.4" x2="-13.97" y2="-27.94" width="0.254" layer="94"/>
<wire x1="-13.97" y1="-27.94" x2="13.97" y2="-27.94" width="0.254" layer="94"/>
<wire x1="13.97" y1="-27.94" x2="13.97" y2="25.4" width="0.254" layer="94"/>
<wire x1="13.97" y1="25.4" x2="-13.97" y2="25.4" width="0.254" layer="94"/>
<pin name="G7" x="-19.05" y="-25.4" length="middle"/>
<pin name="G6" x="-19.05" y="-22.86" length="middle"/>
<pin name="G5" x="-19.05" y="-20.32" length="middle"/>
<pin name="G4" x="-19.05" y="-17.78" length="middle"/>
<pin name="G3" x="-19.05" y="-15.24" length="middle"/>
<pin name="G2" x="-19.05" y="-12.7" length="middle"/>
<pin name="G1" x="-19.05" y="-10.16" length="middle"/>
<pin name="G0" x="-19.05" y="-7.62" length="middle"/>
<pin name="R7" x="-19.05" y="-5.08" length="middle"/>
<pin name="R6" x="-19.05" y="-2.54" length="middle"/>
<pin name="R5" x="-19.05" y="0" length="middle"/>
<pin name="R4" x="-19.05" y="2.54" length="middle"/>
<pin name="R3" x="-19.05" y="5.08" length="middle"/>
<pin name="R2" x="-19.05" y="7.62" length="middle"/>
<pin name="R1" x="-19.05" y="10.16" length="middle"/>
<pin name="R0" x="-19.05" y="12.7" length="middle"/>
<pin name="VCC2" x="-19.05" y="15.24" length="middle"/>
<pin name="VCC" x="-19.05" y="17.78" length="middle"/>
<pin name="GND2" x="-19.05" y="20.32" length="middle"/>
<pin name="GND" x="-19.05" y="22.86" length="middle"/>
<pin name="TEST3" x="19.05" y="22.86" length="middle" rot="R180"/>
<pin name="TEST2" x="19.05" y="20.32" length="middle" rot="R180"/>
<pin name="TEST1" x="19.05" y="17.78" length="middle" rot="R180"/>
<pin name="NC2" x="19.05" y="15.24" length="middle" rot="R180"/>
<pin name="AVDD2" x="19.05" y="12.7" length="middle" rot="R180"/>
<pin name="AVDD" x="19.05" y="10.16" length="middle" rot="R180"/>
<pin name="NC" x="19.05" y="7.62" length="middle" rot="R180"/>
<pin name="VSYNC" x="19.05" y="5.08" length="middle" rot="R180"/>
<pin name="HSYNC" x="19.05" y="2.54" length="middle" rot="R180"/>
<pin name="DISP" x="19.05" y="0" length="middle" rot="R180"/>
<pin name="CK" x="19.05" y="-2.54" length="middle" rot="R180"/>
<pin name="GND3" x="19.05" y="-5.08" length="middle" rot="R180"/>
<pin name="B7" x="19.05" y="-7.62" length="middle" rot="R180"/>
<pin name="B6" x="19.05" y="-10.16" length="middle" rot="R180"/>
<pin name="B5" x="19.05" y="-12.7" length="middle" rot="R180"/>
<pin name="B4" x="19.05" y="-15.24" length="middle" rot="R180"/>
<pin name="B3" x="19.05" y="-17.78" length="middle" rot="R180"/>
<pin name="B2" x="19.05" y="-20.32" length="middle" rot="R180"/>
<pin name="B1" x="19.05" y="-22.86" length="middle" rot="R180"/>
<pin name="B0" x="19.05" y="-25.4" length="middle" rot="R180"/>
</symbol>
<symbol name="PSP_TOUCH_CONNECTOR">
<wire x1="-5.08" y1="-10.16" x2="5.08" y2="-10.16" width="0.254" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="5.08" y2="10.16" width="0.254" layer="94"/>
<wire x1="5.08" y1="10.16" x2="-5.08" y2="10.16" width="0.254" layer="94"/>
<wire x1="-5.08" y1="10.16" x2="-5.08" y2="-10.16" width="0.254" layer="94"/>
<text x="-4.826" y="10.922" size="1.27" layer="95">&gt;NAME</text>
<text x="-4.826" y="-11.938" size="1.27" layer="96">&gt;VALUE</text>
<pin name="X1" x="-10.16" y="7.62" length="middle"/>
<pin name="Y2" x="-10.16" y="2.54" length="middle"/>
<pin name="X2" x="-10.16" y="-2.54" length="middle"/>
<pin name="Y1" x="-10.16" y="-7.62" length="middle"/>
</symbol>
<symbol name="M04-1">
<wire x1="1.27" y1="-5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="0" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="7.62" x2="1.27" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="0" y2="5.08" width="0.6096" layer="94"/>
<text x="-5.08" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="5.08" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="5.08" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="5.08" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="5.08" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="RJ45-8">
<wire x1="-5.08" y1="-12.7" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="-5.08" y2="10.16" width="0.254" layer="94"/>
<wire x1="-5.08" y1="10.16" x2="-5.08" y2="-12.7" width="0.254" layer="94"/>
<text x="-5.08" y="10.668" size="1.778" layer="95">&gt;Name</text>
<text x="-5.08" y="-15.24" size="1.778" layer="95">&gt;Value</text>
<pin name="1" x="-7.62" y="7.62" visible="pin" length="short"/>
<pin name="2" x="-7.62" y="5.08" visible="pin" length="short"/>
<pin name="3" x="-7.62" y="2.54" visible="pin" length="short"/>
<pin name="4" x="-7.62" y="0" visible="pin" length="short"/>
<pin name="8" x="-7.62" y="-10.16" visible="pin" length="short"/>
<pin name="7" x="-7.62" y="-7.62" visible="pin" length="short"/>
<pin name="6" x="-7.62" y="-5.08" visible="pin" length="short"/>
<pin name="5" x="-7.62" y="-2.54" visible="pin" length="short"/>
<wire x1="0" y1="-10.16" x2="2.54" y2="-10.16" width="0.254" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="5.08" y2="-7.62" width="0.254" layer="94"/>
<wire x1="0" y1="-7.62" x2="2.54" y2="-7.62" width="0.254" layer="94"/>
<wire x1="2.54" y1="-7.62" x2="5.08" y2="-10.16" width="0.254" layer="94"/>
<wire x1="0" y1="7.62" x2="2.54" y2="7.62" width="0.254" layer="94"/>
<wire x1="2.54" y1="7.62" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="2.54" y2="5.08" width="0.254" layer="94"/>
<wire x1="2.54" y1="5.08" x2="5.08" y2="7.62" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="5.08" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="5.08" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="-5.08" x2="2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="2.54" y2="2.54" width="0.254" layer="94"/>
<text x="6.096" y="5.334" size="1.778" layer="94">Org</text>
<text x="6.096" y="-2.286" size="1.778" layer="94">Blu</text>
<text x="6.096" y="-9.906" size="1.778" layer="94">Brn</text>
<text x="3.302" y="1.778" size="1.778" layer="94">W/Grn</text>
<text x="3.302" y="-5.842" size="1.778" layer="94">Grn</text>
</symbol>
<symbol name="SCREENKEYMATINGCONNECTOR">
<wire x1="5.08" y1="-17.78" x2="12.7" y2="-17.78" width="0.254" layer="94"/>
<wire x1="12.7" y1="-17.78" x2="12.7" y2="20.32" width="0.254" layer="94"/>
<wire x1="12.7" y1="20.32" x2="5.08" y2="20.32" width="0.254" layer="94"/>
<wire x1="5.08" y1="20.32" x2="5.08" y2="-17.78" width="0.254" layer="94"/>
<pin name="1" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="2" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="3" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="4" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="5" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="6" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="7" x="17.78" y="0" length="middle" rot="R180"/>
<pin name="8" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="9" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="10" x="17.78" y="7.62" length="middle" rot="R180"/>
<pin name="11" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="12" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="13" x="17.78" y="15.24" length="middle" rot="R180"/>
<pin name="14" x="17.78" y="17.78" length="middle" rot="R180"/>
</symbol>
<symbol name="SDCARD">
<wire x1="-2.54" y1="15.24" x2="10.16" y2="15.24" width="0.254" layer="94"/>
<wire x1="10.16" y1="15.24" x2="10.16" y2="-20.32" width="0.254" layer="94"/>
<wire x1="10.16" y1="-20.32" x2="-2.54" y2="-20.32" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-20.32" x2="-2.54" y2="15.24" width="0.254" layer="94"/>
<pin name="CS" x="-7.62" y="12.7" length="middle"/>
<pin name="DI" x="-7.62" y="10.16" length="middle"/>
<pin name="GND" x="-7.62" y="7.62" length="middle"/>
<pin name="VCC" x="-7.62" y="5.08" length="middle"/>
<pin name="SCK" x="-7.62" y="2.54" length="middle"/>
<pin name="GND1" x="-7.62" y="0" length="middle"/>
<pin name="DO" x="-7.62" y="-2.54" length="middle"/>
<pin name="IRQ" x="-7.62" y="-5.08" length="middle"/>
<pin name="WP" x="-7.62" y="-10.16" length="middle"/>
<pin name="CD" x="-7.62" y="-12.7" length="middle"/>
<pin name="SW" x="-7.62" y="-15.24" length="middle"/>
<pin name="SHIELD" x="-7.62" y="-17.78" length="middle"/>
<pin name="P9" x="-7.62" y="-7.62" length="middle"/>
</symbol>
<symbol name="SIMHOLDER">
<wire x1="-7.62" y1="-5.08" x2="7.62" y2="-5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-7.62" y2="5.08" width="0.254" layer="94"/>
<wire x1="-7.62" y1="5.08" x2="-7.62" y2="-5.08" width="0.254" layer="94"/>
<text x="-7.112" y="5.588" size="1.778" layer="95">&gt;Name</text>
<text x="-7.112" y="-7.62" size="1.778" layer="96">&gt;Value</text>
<pin name="VCC" x="-10.16" y="2.54" visible="pin" length="short" direction="pwr"/>
<pin name="RST" x="-10.16" y="0" visible="pin" length="short" direction="in"/>
<pin name="CLK" x="-10.16" y="-2.54" visible="pin" length="short" direction="in"/>
<pin name="GND" x="10.16" y="2.54" visible="pin" length="short" direction="pwr" rot="R180"/>
<pin name="VPP" x="10.16" y="0" visible="pin" length="short" direction="in" rot="R180"/>
<pin name="I/O" x="10.16" y="-2.54" visible="pin" length="short" rot="R180"/>
</symbol>
<symbol name="SMARTCARD">
<wire x1="-7.62" y1="7.62" x2="-7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-10.16" x2="7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="7.62" y2="7.62" width="0.254" layer="94"/>
<text x="-7.62" y="8.636" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-12.7" size="1.778" layer="96">&gt;Value</text>
<pin name="VCC" x="-10.16" y="5.08" visible="pin" length="short"/>
<pin name="RST" x="-10.16" y="2.54" visible="pin" length="short"/>
<pin name="CLK" x="-10.16" y="0" visible="pin" length="short"/>
<pin name="SW1" x="-10.16" y="-7.62" visible="pin" length="short"/>
<pin name="SW2" x="10.16" y="-7.62" visible="pin" length="short" rot="R180"/>
<pin name="I/O" x="10.16" y="0" visible="pin" length="short" rot="R180"/>
<pin name="VPP" x="10.16" y="2.54" visible="pin" length="short" rot="R180"/>
<pin name="GND" x="10.16" y="5.08" visible="pin" length="short" rot="R180"/>
<pin name="C4" x="-10.16" y="-2.54" visible="pin" length="short"/>
<pin name="C8" x="10.16" y="-2.54" visible="pin" length="short" rot="R180"/>
</symbol>
<symbol name="SMA_EDGE">
<wire x1="0" y1="-2.54" x2="0" y2="-12.7" width="0.254" layer="94"/>
<circle x="0" y="0" radius="1.1359" width="0.254" layer="94"/>
<circle x="0" y="0" radius="2.54" width="0.254" layer="94"/>
<pin name="GND@0" x="-2.54" y="-5.08" visible="off" length="short"/>
<pin name="SIGNAL" x="5.08" y="0" visible="off" length="middle" rot="R180"/>
<pin name="GND@1" x="-2.54" y="-7.62" visible="off" length="short"/>
<pin name="GND@2" x="-2.54" y="-10.16" visible="off" length="short"/>
<pin name="GND@3" x="-2.54" y="-12.7" visible="off" length="short"/>
</symbol>
<symbol name="STARBOARD_PAD">
<wire x1="-0.762" y1="2.032" x2="1.016" y2="0.254" width="1.016" layer="94" curve="-75.749967" cap="flat"/>
<wire x1="-3.048" y1="0.254" x2="-1.27" y2="2.032" width="1.016" layer="94" curve="-75.749967" cap="flat"/>
<wire x1="-3.048" y1="-0.254" x2="-1.27" y2="-2.032" width="1.016" layer="94" curve="75.749967" cap="flat"/>
<wire x1="-0.762" y1="-2.032" x2="1.016" y2="-0.254" width="1.016" layer="94" curve="75.749967" cap="flat"/>
<circle x="-1.016" y="0" radius="1.524" width="0.0508" layer="94"/>
<text x="1.778" y="0.5842" size="1.778" layer="95">&gt;NAME</text>
<text x="1.778" y="-2.4638" size="1.778" layer="96">&gt;VALUE</text>
<pin name="MOUNT" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
</symbol>
<symbol name="STARBOARD_PAD+">
<wire x1="0" y1="-1.016" x2="0.254" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="-2.286" y1="-1.27" x2="-2.032" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="1.524" x2="-2.032" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-1.016" x2="0.508" y2="0.508" width="0.1524" layer="94"/>
<wire x1="0.508" y1="0.508" x2="-2.54" y2="0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0.508" x2="0" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.016" x2="-1.016" y2="1.524" width="0.1524" layer="94"/>
</symbol>
<symbol name="TOUCH-SCREEN">
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="7.62" width="0.254" layer="94"/>
<wire x1="5.08" y1="7.62" x2="-5.08" y2="7.62" width="0.254" layer="94"/>
<text x="-5.08" y="8.128" size="1.778" layer="95">&gt;Name</text>
<text x="-5.08" y="-7.62" size="1.778" layer="95">&gt;Value</text>
<pin name="TS4" x="-10.16" y="5.08" visible="pin" length="middle"/>
<pin name="TS3" x="-10.16" y="2.54" visible="pin" length="middle"/>
<pin name="TS2" x="-10.16" y="0" visible="pin" length="middle"/>
<pin name="TS1" x="-10.16" y="-2.54" visible="pin" length="middle"/>
</symbol>
<symbol name="U.FL">
<wire x1="0" y1="-2.54" x2="0" y2="-7.62" width="0.254" layer="94"/>
<text x="-3.81" y="4.064" size="1.778" layer="95">&gt;NAME</text>
</symbol>
<symbol name="USB">
<wire x1="5.08" y1="8.89" x2="0" y2="8.89" width="0.254" layer="94"/>
<wire x1="0" y1="8.89" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="5.08" y2="-1.27" width="0.254" layer="94"/>
<text x="3.81" y="0" size="2.54" layer="94" rot="R90">USB</text>
<pin name="D+" x="-2.54" y="7.62" visible="pad" length="short"/>
<pin name="D-" x="-2.54" y="5.08" visible="pad" length="short"/>
<pin name="VBUS" x="-2.54" y="2.54" visible="pad" length="short"/>
<pin name="GND" x="-2.54" y="0" visible="pad" length="short"/>
<text x="0" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<text x="0" y="-3.81" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="USB+SHIELD">
<wire x1="7.62" y1="10.16" x2="0" y2="10.16" width="0.254" layer="94"/>
<wire x1="0" y1="10.16" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="7.62" y2="-2.54" width="0.254" layer="94"/>
<pin name="S1" x="2.54" y="-5.08" visible="pad" length="short" rot="R90"/>
<pin name="S2" x="5.08" y="-5.08" visible="pad" length="short" rot="R90"/>
</symbol>
<symbol name="USB-5PIN">
<wire x1="7.62" y1="12.7" x2="0" y2="12.7" width="0.254" layer="94"/>
<wire x1="0" y1="12.7" x2="0" y2="-2.54" width="0.254" layer="94"/>
<text x="5.334" y="1.778" size="2.54" layer="94" rot="R90">USB</text>
<pin name="D+" x="-2.54" y="5.08" visible="pad" length="short"/>
<pin name="D-" x="-2.54" y="7.62" visible="pad" length="short"/>
<pin name="VBUS" x="-2.54" y="10.16" visible="pad" length="short"/>
<pin name="ID" x="-2.54" y="2.54" visible="pad" length="short"/>
<pin name="MTN1" x="2.54" y="15.24" visible="pad" length="short" rot="R270"/>
<pin name="MTN2" x="5.08" y="15.24" visible="pad" length="short" rot="R270"/>
<pin name="MTN3" x="2.54" y="-5.08" visible="pad" length="short" rot="R90"/>
<pin name="MTN4" x="5.08" y="-5.08" visible="pad" length="short" rot="R90"/>
<text x="7.62" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="7.62" y="0" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="MICROB-PLUG">
<wire x1="-5.08" y1="7.62" x2="-5.08" y2="-7.62" width="0.508" layer="94"/>
<wire x1="-5.08" y1="-7.62" x2="5.08" y2="-7.62" width="0.508" layer="94"/>
<wire x1="5.08" y1="-7.62" x2="5.08" y2="7.62" width="0.508" layer="94"/>
<wire x1="5.08" y1="7.62" x2="-5.08" y2="7.62" width="0.508" layer="94"/>
<text x="-4.826" y="8.128" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="-9.906" size="1.778" layer="96">&gt;VALUE</text>
<pin name="VCC" x="-7.62" y="5.08" visible="off" length="short"/>
<pin name="D-" x="-7.62" y="2.54" visible="off" length="short"/>
<pin name="D+" x="-7.62" y="0" visible="off" length="short"/>
<pin name="ID" x="-7.62" y="-2.54" visible="off" length="short"/>
<pin name="GND" x="-7.62" y="-5.08" visible="off" length="short"/>
<pin name="SHIELD" x="7.62" y="0" visible="off" length="short" rot="R180"/>
<text x="4.064" y="0" size="0.8128" layer="95" rot="R90" align="bottom-center">SHIELD</text>
<text x="-3.81" y="5.08" size="1.4224" layer="95" font="vector" ratio="12" align="center-left">VCC</text>
<text x="-3.81" y="2.54" size="1.4224" layer="95" font="vector" ratio="12" align="center-left">D-</text>
<text x="-3.81" y="0" size="1.4224" layer="95" font="vector" ratio="12" align="center-left">D+</text>
<text x="-3.81" y="-2.54" size="1.4224" layer="95" font="vector" ratio="12" align="center-left">ID</text>
<text x="-3.81" y="-5.08" size="1.4224" layer="95" font="vector" ratio="12" align="center-left">GND</text>
</symbol>
<symbol name="USDCARD">
<text x="-2.54" y="15.748" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-22.86" size="1.778" layer="96">&gt;VALUE</text>
<pin name="CS" x="-7.62" y="10.16" length="middle"/>
<pin name="DI" x="-7.62" y="7.62" length="middle"/>
<pin name="GND" x="-7.62" y="0" length="middle"/>
<pin name="RSV" x="-7.62" y="-5.08" length="middle"/>
<pin name="NC" x="-7.62" y="12.7" length="middle"/>
<pin name="SHIELD@3" x="-7.62" y="-15.24" length="middle"/>
<pin name="SHIELD@1" x="-7.62" y="-10.16" length="middle"/>
<pin name="CD1" x="-7.62" y="-12.7" length="middle"/>
<pin name="CD2" x="-7.62" y="-17.78" length="middle"/>
<wire x1="-0.762" y1="-12.7" x2="-0.762" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-17.78" x2="-2.032" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-12.7" x2="-2.032" y2="-12.7" width="0.254" layer="94"/>
</symbol>
<symbol name="WATN001001">
<wire x1="-15.24" y1="17.78" x2="-15.24" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-17.78" x2="15.24" y2="-17.78" width="0.254" layer="94"/>
<wire x1="15.24" y1="-17.78" x2="15.24" y2="17.78" width="0.254" layer="94"/>
<wire x1="15.24" y1="17.78" x2="-15.24" y2="17.78" width="0.254" layer="94"/>
<text x="-15.24" y="18.542" size="1.778" layer="95">&gt;Name</text>
<text x="-15.24" y="-20.32" size="1.778" layer="96">&gt;Value</text>
<pin name="V0@1" x="-20.32" y="15.24" length="middle"/>
<pin name="V1@1" x="-20.32" y="12.7" length="middle"/>
<pin name="V2@1" x="-20.32" y="10.16" length="middle"/>
<pin name="VSSE@1" x="-20.32" y="7.62" length="middle"/>
<pin name="VSS@1" x="-20.32" y="5.08" length="middle"/>
<pin name="EIO1" x="-20.32" y="2.54" length="middle"/>
<pin name="XCK" x="-20.32" y="0" length="middle"/>
<pin name="VDD" x="-20.32" y="-2.54" length="middle"/>
<pin name="LATCH" x="-20.32" y="-5.08" length="middle"/>
<pin name="RESERVED@1" x="-20.32" y="-7.62" length="middle"/>
<pin name="SHL" x="-20.32" y="-10.16" length="middle"/>
<pin name="SLEEPB" x="-20.32" y="-12.7" length="middle"/>
<pin name="DLY0" x="-20.32" y="-15.24" length="middle"/>
<pin name="DLY1" x="20.32" y="-15.24" length="middle" rot="R180"/>
<pin name="RESERVED@2" x="20.32" y="-12.7" length="middle" rot="R180"/>
<pin name="DI0" x="20.32" y="-10.16" length="middle" rot="R180"/>
<pin name="DI1" x="20.32" y="-7.62" length="middle" rot="R180"/>
<pin name="DI2" x="20.32" y="-5.08" length="middle" rot="R180"/>
<pin name="RESERVED@3" x="20.32" y="-2.54" length="middle" rot="R180"/>
<pin name="EIO2" x="20.32" y="0" length="middle" rot="R180"/>
<pin name="VSS@2" x="20.32" y="2.54" length="middle" rot="R180"/>
<pin name="VSSE@2" x="20.32" y="5.08" length="middle" rot="R180"/>
<pin name="V0@2" x="20.32" y="12.7" length="middle" rot="R180"/>
<pin name="V1@2" x="20.32" y="10.16" length="middle" rot="R180"/>
<pin name="V2@2" x="20.32" y="7.62" length="middle" rot="R180"/>
<pin name="RESERVED@4" x="20.32" y="15.24" length="middle" rot="R180"/>
</symbol>
<symbol name="XLR3_NCFAH2">
<wire x1="-5.08" y1="-5.08" x2="-4.064" y2="-4.318" width="0.2032" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="1.016" y2="2.54" width="0.2032" layer="94"/>
<wire x1="-5.08" y1="0" x2="-2.794" y2="0" width="0.2032" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="1.016" y2="-2.54" width="0.2032" layer="94"/>
<circle x="0" y="0" radius="5.7079" width="0.254" layer="94"/>
<circle x="1.778" y="2.54" radius="0.7184" width="0.2032" layer="94"/>
<circle x="-2.032" y="0" radius="0.7184" width="0.2032" layer="94"/>
<circle x="1.778" y="-2.54" radius="0.7184" width="0.2032" layer="94"/>
<text x="-3.81" y="-7.62" size="1.27" layer="96">&gt;VALUE</text>
<pin name="3" x="-10.16" y="0" visible="pad" length="middle"/>
<pin name="2" x="-10.16" y="2.54" visible="pad" length="middle"/>
<pin name="1" x="-10.16" y="-2.54" visible="pad" length="middle"/>
<pin name="G" x="-10.16" y="-5.08" visible="pad" length="middle"/>
</symbol>
<symbol name="DIL-28-3">
<wire x1="0" y1="0" x2="22.86" y2="0" width="0.254" layer="94"/>
<wire x1="22.86" y1="0" x2="22.86" y2="76.2" width="0.254" layer="94"/>
<wire x1="22.86" y1="76.2" x2="15.24" y2="76.2" width="0.254" layer="94"/>
<wire x1="15.24" y1="76.2" x2="7.62" y2="76.2" width="0.254" layer="94"/>
<wire x1="7.62" y1="76.2" x2="0" y2="76.2" width="0.254" layer="94"/>
<wire x1="0" y1="76.2" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="15.24" y1="76.2" x2="7.62" y2="76.2" width="0.254" layer="94" curve="-180"/>
<pin name="P$1" x="-5.08" y="71.12" length="middle"/>
<pin name="P$2" x="-5.08" y="66.04" length="middle"/>
<pin name="P$3" x="-5.08" y="60.96" length="middle"/>
<pin name="P$4" x="-5.08" y="55.88" length="middle"/>
<pin name="P$5" x="-5.08" y="50.8" length="middle"/>
<pin name="P$6" x="-5.08" y="45.72" length="middle"/>
<pin name="P$7" x="-5.08" y="40.64" length="middle"/>
<pin name="P$8" x="-5.08" y="35.56" length="middle"/>
<pin name="P$9" x="-5.08" y="30.48" length="middle"/>
<pin name="P$10" x="-5.08" y="25.4" length="middle"/>
<pin name="P$11" x="-5.08" y="20.32" length="middle"/>
<pin name="P$12" x="-5.08" y="15.24" length="middle"/>
<pin name="P$13" x="-5.08" y="10.16" length="middle"/>
<pin name="P$14" x="-5.08" y="5.08" length="middle"/>
<pin name="P$15" x="27.94" y="5.08" length="middle" rot="R180"/>
<pin name="P$16" x="27.94" y="10.16" length="middle" rot="R180"/>
<pin name="P$17" x="27.94" y="15.24" length="middle" rot="R180"/>
<pin name="P$18" x="27.94" y="20.32" length="middle" rot="R180"/>
<pin name="P$19" x="27.94" y="25.4" length="middle" rot="R180"/>
<pin name="P$20" x="27.94" y="30.48" length="middle" rot="R180"/>
<pin name="P$21" x="27.94" y="35.56" length="middle" rot="R180"/>
<pin name="P$22" x="27.94" y="40.64" length="middle" rot="R180"/>
<pin name="P$23" x="27.94" y="45.72" length="middle" rot="R180"/>
<pin name="P$24" x="27.94" y="50.8" length="middle" rot="R180"/>
<pin name="P$25" x="27.94" y="55.88" length="middle" rot="R180"/>
<pin name="P$26" x="27.94" y="60.96" length="middle" rot="R180"/>
<pin name="P$27" x="27.94" y="66.04" length="middle" rot="R180"/>
<pin name="P$28" x="27.94" y="71.12" length="middle" rot="R180"/>
</symbol>
<symbol name="DIL-40-6">
<wire x1="-10.16" y1="-50.8" x2="10.16" y2="-50.8" width="0.254" layer="94"/>
<wire x1="10.16" y1="-50.8" x2="10.16" y2="55.88" width="0.254" layer="94"/>
<wire x1="10.16" y1="55.88" x2="2.54" y2="55.88" width="0.254" layer="94"/>
<wire x1="2.54" y1="55.88" x2="-2.54" y2="55.88" width="0.254" layer="94"/>
<wire x1="-2.54" y1="55.88" x2="-10.16" y2="55.88" width="0.254" layer="94"/>
<wire x1="-10.16" y1="55.88" x2="-10.16" y2="-50.8" width="0.254" layer="94"/>
<wire x1="2.54" y1="55.88" x2="-2.54" y2="55.88" width="0.254" layer="94" curve="-180"/>
<pin name="P$1" x="-15.24" y="50.8" length="middle"/>
<pin name="P$2" x="-15.24" y="45.72" length="middle"/>
<pin name="P$3" x="-15.24" y="40.64" length="middle"/>
<pin name="P$4" x="-15.24" y="35.56" length="middle"/>
<pin name="P$5" x="-15.24" y="30.48" length="middle"/>
<pin name="P$6" x="-15.24" y="25.4" length="middle"/>
<pin name="P$7" x="-15.24" y="20.32" length="middle"/>
<pin name="P$8" x="-15.24" y="15.24" length="middle"/>
<pin name="P$9" x="-15.24" y="10.16" length="middle"/>
<pin name="P$10" x="-15.24" y="5.08" length="middle"/>
<pin name="P$11" x="-15.24" y="0" length="middle"/>
<pin name="P$12" x="-15.24" y="-5.08" length="middle"/>
<pin name="P$13" x="-15.24" y="-10.16" length="middle"/>
<pin name="P$14" x="-15.24" y="-15.24" length="middle"/>
<pin name="P$15" x="-15.24" y="-20.32" length="middle"/>
<pin name="P$16" x="-15.24" y="-25.4" length="middle"/>
<pin name="P$17" x="-15.24" y="-30.48" length="middle"/>
<pin name="P$18" x="-15.24" y="-35.56" length="middle"/>
<pin name="P$19" x="-15.24" y="-40.64" length="middle"/>
<pin name="P$20" x="-15.24" y="-45.72" length="middle"/>
<pin name="P$21" x="15.24" y="-45.72" length="middle" rot="R180"/>
<pin name="P$22" x="15.24" y="-40.64" length="middle" rot="R180"/>
<pin name="P$23" x="15.24" y="-35.56" length="middle" rot="R180"/>
<pin name="P$24" x="15.24" y="-30.48" length="middle" rot="R180"/>
<pin name="P$25" x="15.24" y="-25.4" length="middle" rot="R180"/>
<pin name="P$26" x="15.24" y="-20.32" length="middle" rot="R180"/>
<pin name="P$27" x="15.24" y="-15.24" length="middle" rot="R180"/>
<pin name="P$28" x="15.24" y="-10.16" length="middle" rot="R180"/>
<pin name="P$29" x="15.24" y="-5.08" length="middle" rot="R180"/>
<pin name="P$30" x="15.24" y="0" length="middle" rot="R180"/>
<pin name="P$31" x="15.24" y="5.08" length="middle" rot="R180"/>
<pin name="P$32" x="15.24" y="10.16" length="middle" rot="R180"/>
<pin name="P$33" x="15.24" y="15.24" length="middle" rot="R180"/>
<pin name="P$34" x="15.24" y="20.32" length="middle" rot="R180"/>
<pin name="P$35" x="15.24" y="25.4" length="middle" rot="R180"/>
<pin name="P$36" x="15.24" y="30.48" length="middle" rot="R180"/>
<pin name="P$37" x="15.24" y="35.56" length="middle" rot="R180"/>
<pin name="P$38" x="15.24" y="40.64" length="middle" rot="R180"/>
<pin name="P$39" x="15.24" y="45.72" length="middle" rot="R180"/>
<pin name="P$40" x="15.24" y="50.8" length="middle" rot="R180"/>
</symbol>
<symbol name="ZUNE_CONNECTOR_MALE">
<wire x1="-10.16" y1="30.48" x2="10.16" y2="30.48" width="0.254" layer="94"/>
<wire x1="10.16" y1="30.48" x2="10.16" y2="-33.02" width="0.254" layer="94"/>
<wire x1="10.16" y1="-33.02" x2="-10.16" y2="-33.02" width="0.254" layer="94"/>
<wire x1="-10.16" y1="-33.02" x2="-10.16" y2="30.48" width="0.254" layer="94"/>
<text x="-10.16" y="-35.56" size="1.778" layer="96">&gt;Value</text>
<text x="-10.16" y="30.988" size="1.778" layer="95">&gt;Name</text>
<pin name="USB_5V@1" x="-15.24" y="27.94" visible="pin" length="middle"/>
<pin name="USB_5V@2" x="-15.24" y="25.4" visible="pin" length="middle"/>
<pin name="USB_5V@3" x="-15.24" y="22.86" visible="pin" length="middle"/>
<pin name="4" x="-15.24" y="20.32" visible="pin" length="middle"/>
<pin name="5" x="-15.24" y="17.78" visible="pin" length="middle"/>
<pin name="6" x="-15.24" y="15.24" visible="pin" length="middle"/>
<pin name="7" x="-15.24" y="12.7" visible="pin" length="middle"/>
<pin name="8" x="-15.24" y="10.16" visible="pin" length="middle"/>
<pin name="VIDEO+" x="-15.24" y="7.62" visible="pin" length="middle"/>
<pin name="10" x="-15.24" y="5.08" visible="pin" length="middle"/>
<pin name="11" x="-15.24" y="2.54" visible="pin" length="middle"/>
<pin name="12" x="-15.24" y="0" visible="pin" length="middle"/>
<pin name="AUDIO_L" x="-15.24" y="-2.54" visible="pin" length="middle"/>
<pin name="AUDIO_R" x="-15.24" y="-5.08" visible="pin" length="middle"/>
<pin name="15" x="-15.24" y="-7.62" visible="pin" length="middle"/>
<pin name="16" x="-15.24" y="-10.16" visible="pin" length="middle"/>
<pin name="17" x="-15.24" y="-12.7" visible="pin" length="middle"/>
<pin name="18" x="-15.24" y="-15.24" visible="pin" length="middle"/>
<pin name="GND@19" x="-15.24" y="-17.78" visible="pin" length="middle"/>
<pin name="USB_DATA-" x="-15.24" y="-20.32" visible="pin" length="middle"/>
<pin name="USB_DATA+" x="-15.24" y="-22.86" visible="pin" length="middle"/>
<pin name="GND@22" x="-15.24" y="-25.4" visible="pin" length="middle"/>
<pin name="GND@23" x="-15.24" y="-27.94" visible="pin" length="middle"/>
<pin name="GND@24" x="-15.24" y="-30.48" visible="pin" length="middle"/>
</symbol>
<symbol name="50-PIN-CENTRONICS">
<wire x1="2.54" y1="127" x2="2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="12.7" y2="-2.54" width="0.254" layer="94"/>
<wire x1="12.7" y1="-2.54" x2="12.7" y2="127" width="0.254" layer="94"/>
<wire x1="12.7" y1="127" x2="2.54" y2="127" width="0.254" layer="94"/>
<pin name="P$1" x="-2.54" y="0" length="middle"/>
<pin name="P$2" x="-2.54" y="2.54" length="middle"/>
<pin name="P$3" x="-2.54" y="5.08" length="middle"/>
<pin name="P$4" x="-2.54" y="7.62" length="middle"/>
<pin name="P$5" x="-2.54" y="10.16" length="middle"/>
<pin name="P$6" x="-2.54" y="12.7" length="middle"/>
<pin name="P$7" x="-2.54" y="15.24" length="middle"/>
<pin name="P$8" x="-2.54" y="17.78" length="middle"/>
<pin name="P$9" x="-2.54" y="20.32" length="middle"/>
<pin name="P$10" x="-2.54" y="22.86" length="middle"/>
<pin name="P$11" x="-2.54" y="25.4" length="middle"/>
<pin name="P$12" x="-2.54" y="27.94" length="middle"/>
<pin name="P$13" x="-2.54" y="30.48" length="middle"/>
<pin name="P$14" x="-2.54" y="33.02" length="middle"/>
<pin name="P$15" x="-2.54" y="35.56" length="middle"/>
<pin name="P$16" x="-2.54" y="38.1" length="middle"/>
<pin name="P$17" x="-2.54" y="40.64" length="middle"/>
<pin name="P$18" x="-2.54" y="43.18" length="middle"/>
<pin name="P$19" x="-2.54" y="45.72" length="middle"/>
<pin name="P$20" x="-2.54" y="48.26" length="middle"/>
<pin name="P$21" x="-2.54" y="50.8" length="middle"/>
<pin name="P$22" x="-2.54" y="53.34" length="middle"/>
<pin name="P$23" x="-2.54" y="55.88" length="middle"/>
<pin name="P$24" x="-2.54" y="58.42" length="middle"/>
<pin name="P$25" x="-2.54" y="60.96" length="middle"/>
<pin name="P$26" x="-2.54" y="63.5" length="middle"/>
<pin name="P$27" x="-2.54" y="66.04" length="middle"/>
<pin name="P$28" x="-2.54" y="68.58" length="middle"/>
<pin name="P$29" x="-2.54" y="71.12" length="middle"/>
<pin name="P$30" x="-2.54" y="73.66" length="middle"/>
<pin name="P$31" x="-2.54" y="76.2" length="middle"/>
<pin name="P$32" x="-2.54" y="78.74" length="middle"/>
<pin name="P$33" x="-2.54" y="81.28" length="middle"/>
<pin name="P$34" x="-2.54" y="83.82" length="middle"/>
<pin name="P$35" x="-2.54" y="86.36" length="middle"/>
<pin name="P$36" x="-2.54" y="88.9" length="middle"/>
<pin name="P$37" x="-2.54" y="91.44" length="middle"/>
<pin name="P$38" x="-2.54" y="93.98" length="middle"/>
<pin name="P$39" x="-2.54" y="96.52" length="middle"/>
<pin name="P$40" x="-2.54" y="99.06" length="middle"/>
<pin name="P$41" x="-2.54" y="101.6" length="middle"/>
<pin name="P$42" x="-2.54" y="104.14" length="middle"/>
<pin name="P$43" x="-2.54" y="106.68" length="middle"/>
<pin name="P$44" x="-2.54" y="109.22" length="middle"/>
<pin name="P$45" x="-2.54" y="111.76" length="middle"/>
<pin name="P$46" x="-2.54" y="114.3" length="middle"/>
<pin name="P$47" x="-2.54" y="116.84" length="middle"/>
<pin name="P$48" x="-2.54" y="119.38" length="middle"/>
<pin name="P$49" x="-2.54" y="121.92" length="middle"/>
<pin name="P$50" x="-2.54" y="124.46" length="middle"/>
</symbol>
<symbol name="RCA">
<wire x1="-12.7" y1="-2.54" x2="-10.16" y2="0" width="0.1524" layer="94"/>
<wire x1="-10.16" y1="0" x2="-7.62" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<text x="-12.7" y="5.08" size="1.778" layer="96">&gt;Value</text>
<text x="-12.7" y="-5.08" size="1.778" layer="95">&gt;Name</text>
<rectangle x1="-12.7" y1="1.778" x2="-2.54" y2="3.302" layer="94"/>
<pin name="SWITCH" x="0" y="0" visible="off" length="short" rot="R180"/>
<pin name="SHELL" x="0" y="-2.54" visible="off" length="short" rot="R180"/>
<pin name="PIN" x="0" y="2.54" visible="off" length="short" rot="R180"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="2.54" width="0.1524" layer="94"/>
<text x="-4.826" y="1.016" size="0.6096" layer="94">OPEN WHEN</text>
<text x="-4.826" y="0.254" size="0.6096" layer="94">CONNECTED</text>
</symbol>
<symbol name="USB_AB">
<description>USB AB, 5-pins: USBVCC, GND, D+, D-, USBID.</description>
<wire x1="2.54" y1="6.35" x2="-2.54" y2="6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="6.35" x2="-2.54" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-8.89" x2="2.54" y2="-8.89" width="0.254" layer="94"/>
<text x="1.27" y="-7.366" size="2.54" layer="94" rot="R90">USBAB</text>
<pin name="D+" x="-5.08" y="0" visible="pad" length="short"/>
<pin name="D-" x="-5.08" y="-2.54" visible="pad" length="short"/>
<pin name="VBUS" x="-5.08" y="-5.08" visible="pad" length="short"/>
<pin name="GND" x="-5.08" y="5.08" visible="pad" length="short"/>
<pin name="USBID" x="-5.08" y="2.54" visible="pad" length="short"/>
<pin name="SHIELD" x="-5.08" y="-7.62" visible="pad" length="short"/>
<text x="-2.54" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-12.7" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="SDCARD-1">
<wire x1="-7.62" y1="17.78" x2="7.62" y2="17.78" width="0.254" layer="94"/>
<wire x1="7.62" y1="17.78" x2="7.62" y2="-17.78" width="0.254" layer="94"/>
<wire x1="7.62" y1="-17.78" x2="-7.62" y2="-17.78" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-17.78" x2="-7.62" y2="17.78" width="0.254" layer="94"/>
<pin name="CD/DAT3" x="-12.7" y="0" length="middle"/>
<pin name="CMD" x="-12.7" y="2.54" length="middle"/>
<pin name="VSS1" x="-12.7" y="-7.62" length="middle" direction="pwr"/>
<pin name="VDD" x="-12.7" y="15.24" length="middle" direction="pwr"/>
<pin name="CLK" x="-12.7" y="5.08" length="middle"/>
<pin name="VSS2" x="-12.7" y="-10.16" length="middle" direction="pwr"/>
<pin name="DAT0" x="-12.7" y="12.7" length="middle"/>
<pin name="DAT1" x="-12.7" y="10.16" length="middle"/>
<pin name="DAT2" x="-12.7" y="7.62" length="middle"/>
<text x="-7.366" y="18.288" size="1.778" layer="95">&gt;Name</text>
<pin name="WP" x="-12.7" y="-5.08" length="middle"/>
<pin name="CD" x="-12.7" y="-2.54" length="middle"/>
<text x="-7.112" y="-20.32" size="1.778" layer="96">&gt;Value</text>
<pin name="SH@1" x="-12.7" y="-15.24" length="middle"/>
<pin name="SH@2" x="-12.7" y="-12.7" length="middle"/>
</symbol>
<symbol name="COMPUTER-PERIPHERAL-POWER">
<wire x1="5.08" y1="-7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="-7.62" x2="-3.302" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-3.302" y1="-7.62" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="3.302" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="3.302" x2="-5.08" y2="-5.842" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-5.842" x2="-5.08" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-7.62" x2="5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-3.302" y2="5.08" width="0.4064" layer="94"/>
<text x="-5.08" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="5.842" size="1.778" layer="95">&gt;NAME</text>
<pin name="12V" x="7.62" y="2.54" visible="pin" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="NC" x="7.62" y="0" visible="pin" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="GND" x="7.62" y="-2.54" visible="pin" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5V" x="7.62" y="-5.08" visible="pin" length="short" direction="pas" swaplevel="1" rot="R180"/>
<text x="-2.794" y="-5.08" size="1.778" layer="94" ratio="15" rot="R90">4-Pin</text>
<wire x1="-3.302" y1="5.08" x2="-2.54" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="5.08" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-3.302" y1="5.08" x2="-5.08" y2="3.302" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-5.842" x2="-3.302" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
</symbol>
<symbol name="FTDI_DEVICE">
<pin name="DTR" x="-5.08" y="5.08" visible="pin" length="middle"/>
<pin name="TXO" x="-5.08" y="2.54" visible="pin" length="middle"/>
<pin name="RXI" x="-5.08" y="0" visible="pin" length="middle"/>
<pin name="VCC" x="-5.08" y="-2.54" visible="pin" length="middle"/>
<pin name="CTS" x="-5.08" y="-5.08" visible="pin" length="middle"/>
<pin name="GND" x="-5.08" y="-7.62" visible="pin" length="middle"/>
<wire x1="0" y1="7.62" x2="0" y2="-10.16" width="0.254" layer="94"/>
<wire x1="0" y1="-10.16" x2="7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="7.62" y1="7.62" x2="0" y2="7.62" width="0.254" layer="94"/>
<text x="0" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="0" y="7.62" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="MYDAQ_CONNECTOR">
<wire x1="-7.62" y1="25.4" x2="-7.62" y2="-27.94" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-27.94" x2="7.62" y2="-27.94" width="0.254" layer="94"/>
<wire x1="7.62" y1="-27.94" x2="7.62" y2="25.4" width="0.254" layer="94"/>
<wire x1="7.62" y1="25.4" x2="-7.62" y2="25.4" width="0.254" layer="94"/>
<text x="-7.62" y="26.035" size="1.778" layer="95" font="vector">&gt;NAME</text>
<text x="-7.62" y="-30.48" size="1.778" layer="96" font="vector">&gt;VALUE</text>
<pin name="AN1-" x="-10.16" y="0" length="short" direction="in"/>
<pin name="+15V" x="-10.16" y="22.86" length="short" direction="pwr"/>
<pin name="-15V" x="-10.16" y="20.32" length="short" direction="pwr"/>
<pin name="AGND_15V" x="-10.16" y="17.78" length="short" direction="pwr"/>
<pin name="DIO2" x="-10.16" y="-7.62" length="short"/>
<pin name="DIO3" x="-10.16" y="-10.16" length="short"/>
<pin name="DIO4" x="-10.16" y="-12.7" length="short"/>
<pin name="DIO5" x="-10.16" y="-15.24" length="short"/>
<pin name="DIO6" x="-10.16" y="-17.78" length="short"/>
<pin name="DIO7" x="-10.16" y="-20.32" length="short"/>
<pin name="DGND" x="-10.16" y="-22.86" length="short" direction="pwr"/>
<pin name="DIO0" x="-10.16" y="-2.54" length="short"/>
<pin name="DIO1" x="-10.16" y="-5.08" length="short"/>
<pin name="5V" x="-10.16" y="-25.4" length="short" direction="pwr"/>
<pin name="AO0" x="-10.16" y="15.24" length="short" direction="out"/>
<pin name="AO1" x="-10.16" y="12.7" length="short" direction="out"/>
<pin name="AGND_IO" x="-10.16" y="10.16" length="short" direction="pwr"/>
<pin name="AI0+" x="-10.16" y="7.62" length="short" direction="in"/>
<pin name="AI0-" x="-10.16" y="5.08" length="short" direction="in"/>
<pin name="AI1+" x="-10.16" y="2.54" length="short" direction="in"/>
</symbol>
<symbol name="DB15">
<wire x1="-1.651" y1="3.429" x2="-1.651" y2="1.651" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-0.508" y1="4.191" x2="-0.508" y2="5.969" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="8.509" x2="-1.651" y2="6.731" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-0.508" y1="-5.969" x2="-0.508" y2="-4.191" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-1.651" x2="-1.651" y2="-3.429" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-0.508" y1="-0.889" x2="-0.508" y2="0.889" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-6.731" x2="-1.651" y2="-8.509" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-0.508" y1="-11.049" x2="-0.508" y2="-9.271" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-1.651" y1="-11.811" x2="-1.651" y2="-13.589" width="0.254" layer="94" curve="180" cap="flat"/>
<wire x1="-4.064" y1="12.0112" x2="-2.5226" y2="13.252" width="0.4064" layer="94" curve="-102.324066" cap="flat"/>
<wire x1="-2.5226" y1="13.2518" x2="0" y2="12.7" width="0.4064" layer="94"/>
<wire x1="0" y1="12.7" x2="3.0654" y2="12.0294" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="12.0295" x2="4.0642" y2="10.7888" width="0.4064" layer="94" curve="-77.655139" cap="flat"/>
<wire x1="4.064" y1="-13.3288" x2="4.064" y2="10.7888" width="0.4064" layer="94"/>
<wire x1="3.0654" y1="-14.5694" x2="4.064" y2="-13.3288" width="0.4064" layer="94" curve="77.657889"/>
<wire x1="-4.064" y1="-14.5512" x2="-4.064" y2="12.0112" width="0.4064" layer="94"/>
<wire x1="-2.5226" y1="-15.7918" x2="0" y2="-15.24" width="0.4064" layer="94"/>
<wire x1="0" y1="-15.24" x2="3.0654" y2="-14.5694" width="0.4064" layer="94"/>
<wire x1="-4.064" y1="-14.5512" x2="-2.5226" y2="-15.7919" width="0.4064" layer="94" curve="102.337599" cap="flat"/>
<text x="-3.81" y="-18.415" size="1.778" layer="96">&gt;VALUE</text>
<text x="-3.81" y="13.97" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas"/>
<pin name="7" x="7.874" y="5.08" visible="pad" direction="pas" rot="R180"/>
<pin name="2" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas"/>
<pin name="8" x="7.874" y="0" visible="pad" direction="pas" rot="R180"/>
<pin name="3" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas"/>
<pin name="9" x="7.874" y="-5.08" visible="pad" direction="pas" rot="R180"/>
<pin name="4" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas"/>
<pin name="10" x="7.874" y="-10.16" visible="pad" direction="pas" rot="R180"/>
<pin name="5" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas"/>
<wire x1="-0.508" y1="9.271" x2="-0.508" y2="11.049" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="6" x="7.874" y="10.16" visible="pad" direction="pas" rot="R180"/>
<wire x1="1.778" y1="1.651" x2="1.778" y2="3.429" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="12" x="7.874" y="2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<wire x1="1.778" y1="-3.429" x2="1.778" y2="-1.651" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="13" x="7.874" y="-2.54" visible="pad" length="middle" direction="pas" rot="R180"/>
<wire x1="1.778" y1="-8.509" x2="1.778" y2="-6.731" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="14" x="7.874" y="-7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
<wire x1="1.778" y1="-13.589" x2="1.778" y2="-11.811" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="15" x="7.874" y="-12.7" visible="pad" length="middle" direction="pas" rot="R180"/>
<wire x1="1.778" y1="6.731" x2="1.778" y2="8.509" width="0.254" layer="94" curve="180" cap="flat"/>
<pin name="11" x="7.874" y="7.62" visible="pad" length="middle" direction="pas" rot="R180"/>
</symbol>
<symbol name="AUDIO-JACK3-TRRS">
<wire x1="-3.81" y1="-5.08" x2="-2.54" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-3.81" x2="-1.27" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="-1.27" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="-5.08" y2="5.08" width="0.1524" layer="94"/>
<text x="-5.08" y="5.588" size="1.778" layer="95">&gt;NAME</text>
<rectangle x1="-6.35" y1="-5.08" x2="-5.08" y2="5.08" layer="94"/>
<pin name="RING1" x="5.08" y="2.54" visible="off" length="short" rot="R180"/>
<pin name="RING2" x="5.08" y="-5.08" visible="off" length="short" rot="R180"/>
<pin name="EARTH" x="5.08" y="5.08" visible="off" length="short" rot="R180"/>
<pin name="TIP" x="5.08" y="-2.54" visible="off" length="short" rot="R180"/>
<wire x1="-1.27" y1="-2.54" x2="0" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.27" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
</symbol>
<symbol name="M03X2">
<wire x1="-5.08" y1="5.08" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="5.08" x2="5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="0" width="0.254" layer="94"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="-5.08" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="-2.54" width="0.254" layer="94"/>
<pin name="1" x="-7.62" y="2.54" visible="off" length="short"/>
<pin name="3" x="-7.62" y="0" visible="off" length="short"/>
<pin name="5" x="-7.62" y="-2.54" visible="off" length="short"/>
<pin name="6" x="7.62" y="-2.54" visible="off" length="short" rot="R180"/>
<pin name="4" x="7.62" y="0" visible="off" length="short" rot="R180"/>
<pin name="2" x="7.62" y="2.54" visible="off" length="short" rot="R180"/>
<text x="-5.08" y="5.588" size="1.27" layer="95">&gt;NAME</text>
<text x="-5.08" y="-7.112" size="1.27" layer="96">&gt;VALUE</text>
<circle x="-1.778" y="2.54" radius="1.016" width="0.1524" layer="94"/>
<circle x="1.778" y="2.54" radius="1.016" width="0.1524" layer="94"/>
<circle x="1.778" y="0" radius="1.016" width="0.1524" layer="94"/>
<circle x="1.778" y="-2.54" radius="1.016" width="0.1524" layer="94"/>
<circle x="-1.778" y="-2.54" radius="1.016" width="0.1524" layer="94"/>
<circle x="-1.778" y="0" radius="1.016" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="0" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="2.54" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-2.794" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="0" x2="-2.794" y2="0" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-2.794" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="2.794" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="2.794" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="2.54" x2="2.794" y2="2.54" width="0.1524" layer="94"/>
<text x="-4.318" y="2.794" size="1.4224" layer="95">1</text>
<text x="3.302" y="2.794" size="1.4224" layer="95">2</text>
<text x="-4.318" y="0.254" size="1.4224" layer="95">3</text>
<text x="3.302" y="0.254" size="1.4224" layer="95">4</text>
<text x="-4.318" y="-2.286" size="1.4224" layer="95">5</text>
<text x="3.302" y="-2.286" size="1.4224" layer="95">6</text>
</symbol>
<symbol name="JST_2MM_MALE">
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="1.778" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.778" x2="-2.54" y2="3.302" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.302" x2="-2.54" y2="5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="5.08" y2="5.08" width="0.254" layer="94"/>
<wire x1="5.08" y1="5.08" x2="5.08" y2="3.302" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.302" x2="5.08" y2="1.778" width="0.254" layer="94"/>
<wire x1="5.08" y1="1.778" x2="5.08" y2="-2.54" width="0.254" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="4.064" y2="-2.54" width="0.254" layer="94"/>
<wire x1="4.064" y1="-2.54" x2="4.064" y2="0" width="0.254" layer="94"/>
<wire x1="4.064" y1="0" x2="-1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-1.524" y2="-2.54" width="0.254" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="middle" rot="R90"/>
<pin name="+" x="2.54" y="-5.08" visible="off" length="middle" rot="R90"/>
<pin name="PAD2" x="5.08" y="2.54" visible="off" length="point" rot="R90"/>
<pin name="PAD1" x="-2.54" y="2.54" visible="off" length="point" rot="R90"/>
<wire x1="-2.54" y1="1.778" x2="-1.778" y2="1.778" width="0.254" layer="94"/>
<wire x1="-1.778" y1="1.778" x2="-1.778" y2="3.302" width="0.254" layer="94"/>
<wire x1="-1.778" y1="3.302" x2="-2.54" y2="3.302" width="0.254" layer="94"/>
<wire x1="5.08" y1="1.778" x2="4.318" y2="1.778" width="0.254" layer="94"/>
<wire x1="4.318" y1="1.778" x2="4.318" y2="3.302" width="0.254" layer="94"/>
<wire x1="4.318" y1="3.302" x2="5.08" y2="3.302" width="0.254" layer="94"/>
<wire x1="2.032" y1="1.016" x2="3.048" y2="1.016" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.508" x2="2.54" y2="1.524" width="0.254" layer="94"/>
<wire x1="0" y1="0.508" x2="0" y2="1.524" width="0.254" layer="94"/>
<text x="-2.54" y="5.842" size="1.778" layer="95">&gt;NAME</text>
</symbol>
<symbol name="M13X2">
<wire x1="3.81" y1="-17.78" x2="0" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-10.16" x2="2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-12.7" x2="2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-15.24" x2="2.54" y2="-15.24" width="0.6096" layer="94"/>
<wire x1="3.81" y1="-17.78" x2="3.81" y2="17.78" width="0.4064" layer="94"/>
<wire x1="0" y1="17.78" x2="3.81" y2="17.78" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-7.62" x2="2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="12.7" x2="2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="15.24" x2="2.54" y2="15.24" width="0.6096" layer="94"/>
<text x="-5.08" y="-20.32" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="18.542" size="1.778" layer="95">&gt;NAME</text>
<pin name="26" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<wire x1="-3.81" y1="17.78" x2="0" y2="17.78" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="10.16" x2="-2.54" y2="10.16" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="12.7" x2="-2.54" y2="12.7" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="15.24" x2="-2.54" y2="15.24" width="0.6096" layer="94"/>
<wire x1="-3.81" y1="17.78" x2="-3.81" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="0" y1="-17.78" x2="-3.81" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="5.08" x2="-2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="7.62" x2="-2.54" y2="7.62" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-2.54" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="-2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-5.08" x2="-2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-7.62" x2="-2.54" y2="-7.62" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-10.16" x2="-2.54" y2="-10.16" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-12.7" x2="-2.54" y2="-12.7" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-15.24" x2="-2.54" y2="-15.24" width="0.6096" layer="94"/>
<pin name="1" x="-7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="3" x="-7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="5" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="7" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="9" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="11" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="13" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="15" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="17" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="19" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="21" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="23" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="25" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="AUDIO-JACK4-TRS-NORMALED-GND">
<description>1/4" TRS Jack - with normals on each conductor..</description>
<wire x1="-3.81" y1="-2.54" x2="-2.54" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-3.81" x2="-1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="7.62" x2="-5.08" y2="7.62" width="0.1524" layer="94"/>
<text x="-5.08" y="8.128" size="1.778" layer="95">&gt;NAME</text>
<rectangle x1="-6.35" y1="-5.08" x2="-5.08" y2="7.62" layer="94"/>
<pin name="RING" x="5.08" y="-2.54" visible="off" length="short" rot="R180"/>
<pin name="EARTH" x="5.08" y="7.62" visible="off" length="short" rot="R180"/>
<pin name="TIP" x="5.08" y="2.54" visible="off" length="short" rot="R180"/>
<wire x1="-1.27" y1="2.54" x2="0" y2="1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="1.27" x2="1.27" y2="2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="3.048" y2="1.27" width="0.1524" layer="94"/>
<wire x1="3.048" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.032" y1="1.27" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="5.08" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="3.048" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="3.048" y1="-3.81" x2="2.032" y2="-3.81" width="0.1524" layer="94"/>
<wire x1="2.032" y1="-3.81" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<pin name="TIP-NORM" x="5.08" y="0" visible="off" length="short" rot="R180"/>
<wire x1="5.08" y1="5.08" x2="2.54" y2="5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="7.62" width="0.1524" layer="94"/>
<wire x1="2.54" y1="7.62" x2="2.032" y2="6.35" width="0.1524" layer="94"/>
<wire x1="2.032" y1="6.35" x2="3.048" y2="6.35" width="0.1524" layer="94"/>
<wire x1="3.048" y1="6.35" x2="2.54" y2="7.62" width="0.1524" layer="94"/>
<pin name="EARTH-NORM" x="5.08" y="5.08" visible="off" length="short" rot="R180"/>
<pin name="RING-NORM" x="5.08" y="-5.08" visible="off" length="short" rot="R180"/>
<text x="0" y="2.54" size="1.27" layer="94" align="bottom-center">T</text>
<text x="-2.54" y="-2.54" size="1.27" layer="94" align="bottom-center">R</text>
</symbol>
<symbol name="AUDIO-JACK5-TRS-NORMALED">
</symbol>
<symbol name="JST_6_1MM_VERT">
<wire x1="-7.62" y1="7.62" x2="2.54" y2="7.62" width="0.254" layer="94"/>
<wire x1="2.54" y1="7.62" x2="2.54" y2="-10.16" width="0.254" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="-7.62" y2="-10.16" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-10.16" x2="-7.62" y2="7.62" width="0.254" layer="94"/>
<pin name="1" x="-12.7" y="5.08" length="middle"/>
<pin name="2" x="-12.7" y="2.54" length="middle"/>
<pin name="3" x="-12.7" y="0" length="middle"/>
<pin name="4" x="-12.7" y="-2.54" length="middle"/>
<pin name="5" x="-12.7" y="-5.08" length="middle"/>
<pin name="6" x="-12.7" y="-7.62" length="middle"/>
<text x="-7.62" y="8.89" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="M23">
<wire x1="3.81" y1="-33.02" x2="-2.54" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-27.94" x2="2.54" y2="-27.94" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-30.48" x2="2.54" y2="-30.48" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="27.94" x2="-2.54" y2="-33.02" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-33.02" x2="3.81" y2="27.94" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="27.94" x2="3.81" y2="27.94" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-22.86" x2="2.54" y2="-22.86" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-25.4" x2="2.54" y2="-25.4" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-20.32" x2="2.54" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-17.78" x2="2.54" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="17.78" x2="2.54" y2="17.78" width="0.6096" layer="94"/>
<wire x1="1.27" y1="20.32" x2="2.54" y2="20.32" width="0.6096" layer="94"/>
<wire x1="1.27" y1="22.86" x2="2.54" y2="22.86" width="0.6096" layer="94"/>
<text x="-2.54" y="-35.56" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="28.702" size="1.778" layer="95">&gt;NAME</text>
<pin name="2" x="7.62" y="-30.48" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="-27.94" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="7" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="11" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="13" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="15" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="16" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="17" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="19" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="21" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="23" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="STAND-OFF">
<circle x="0" y="0" radius="1.27" width="0.254" layer="94"/>
</symbol>
<symbol name="MAGJACK_NOLABELS">
<wire x1="-12.7" y1="-15.24" x2="12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="-15.24" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="2.54" width="0.254" layer="94"/>
<wire x1="12.7" y1="2.54" x2="12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="12.7" y1="12.7" x2="-12.7" y2="12.7" width="0.254" layer="94"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="10.16" x2="10.668" y2="10.16" width="0.254" layer="94"/>
<wire x1="10.668" y1="10.16" x2="10.668" y2="7.112" width="0.254" layer="94"/>
<wire x1="10.668" y1="7.112" x2="9.398" y2="7.112" width="0.254" layer="94"/>
<wire x1="9.398" y1="7.112" x2="10.668" y2="5.842" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="11.938" y2="7.112" width="0.254" layer="94"/>
<wire x1="11.938" y1="7.112" x2="10.668" y2="7.112" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="11.938" y2="5.842" width="0.254" layer="94"/>
<wire x1="9.398" y1="5.842" x2="10.668" y2="5.842" width="0.254" layer="94"/>
<wire x1="10.668" y1="5.842" x2="10.668" y2="2.54" width="0.254" layer="94"/>
<wire x1="10.668" y1="2.54" x2="12.7" y2="2.54" width="0.254" layer="94"/>
<wire x1="12.7" y1="-5.08" x2="10.668" y2="-5.08" width="0.254" layer="94"/>
<wire x1="10.668" y1="-5.08" x2="10.668" y2="-8.128" width="0.254" layer="94"/>
<wire x1="10.668" y1="-8.128" x2="9.398" y2="-8.128" width="0.254" layer="94"/>
<wire x1="9.398" y1="-8.128" x2="10.668" y2="-9.398" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="11.938" y2="-8.128" width="0.254" layer="94"/>
<wire x1="11.938" y1="-8.128" x2="10.668" y2="-8.128" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="11.938" y2="-9.398" width="0.254" layer="94"/>
<wire x1="9.398" y1="-9.398" x2="10.668" y2="-9.398" width="0.254" layer="94"/>
<wire x1="10.668" y1="-9.398" x2="10.668" y2="-12.7" width="0.254" layer="94"/>
<wire x1="10.668" y1="-12.7" x2="12.7" y2="-12.7" width="0.254" layer="94"/>
<wire x1="8.89" y1="6.35" x2="8.128" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.128" y1="6.604" x2="8.128" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.128" y1="7.112" x2="8.636" y2="7.112" width="0.254" layer="94"/>
<wire x1="8.89" y1="5.334" x2="8.128" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.128" y1="5.588" x2="8.128" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.128" y1="6.096" x2="8.636" y2="6.096" width="0.254" layer="94"/>
<wire x1="8.89" y1="-8.89" x2="8.128" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.128" y1="-8.636" x2="8.128" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.128" y1="-8.128" x2="8.636" y2="-8.128" width="0.254" layer="94"/>
<wire x1="8.89" y1="-9.906" x2="8.128" y2="-9.144" width="0.254" layer="94"/>
<wire x1="8.128" y1="-9.652" x2="8.128" y2="-9.144" width="0.254" layer="94"/>
<wire x1="8.128" y1="-9.144" x2="8.636" y2="-9.144" width="0.254" layer="94"/>
<text x="-12.7" y="13.208" size="1.778" layer="95">&gt;NAME</text>
<text x="-12.7" y="-17.526" size="1.778" layer="96">&gt;VALUE</text>
<pin name="YLED-" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="YLED+" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="GLED-" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="GLED+" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="6" x="-17.78" y="-2.54" length="middle"/>
<pin name="5" x="-17.78" y="0" length="middle"/>
<pin name="4" x="-17.78" y="2.54" length="middle"/>
<pin name="3" x="-17.78" y="5.08" length="middle"/>
<pin name="2" x="-17.78" y="7.62" length="middle"/>
<pin name="1" x="-17.78" y="10.16" length="middle"/>
<pin name="SHIELD@0" x="-17.78" y="-10.16" length="middle"/>
<pin name="SHIELD@1" x="-17.78" y="-12.7" length="middle"/>
<pin name="7" x="-17.78" y="-5.08" length="middle"/>
<pin name="8" x="-17.78" y="-7.62" length="middle"/>
</symbol>
<symbol name="BINDING_POST">
<pin name="P$1" x="-2.54" y="0" visible="off" length="short"/>
<circle x="0" y="0" radius="1.27" width="0.6096" layer="94"/>
<text x="-2.54" y="2.54" size="1.27" layer="95">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="95">&gt;VALUE</text>
</symbol>
<symbol name="M06X2">
<wire x1="6.35" y1="-2.54" x2="-1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="7.62" x2="5.08" y2="7.62" width="0.6096" layer="94"/>
<wire x1="3.81" y1="5.08" x2="5.08" y2="5.08" width="0.6096" layer="94"/>
<wire x1="3.81" y1="2.54" x2="5.08" y2="2.54" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="15.24" x2="-1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="6.35" y1="-2.54" x2="6.35" y2="15.24" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="15.24" x2="6.35" y2="15.24" width="0.4064" layer="94"/>
<wire x1="3.81" y1="12.7" x2="5.08" y2="12.7" width="0.6096" layer="94"/>
<wire x1="3.81" y1="10.16" x2="5.08" y2="10.16" width="0.6096" layer="94"/>
<wire x1="1.27" y1="7.62" x2="0" y2="7.62" width="0.6096" layer="94"/>
<wire x1="1.27" y1="5.08" x2="0" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="0" y2="2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="12.7" x2="0" y2="12.7" width="0.6096" layer="94"/>
<wire x1="1.27" y1="10.16" x2="0" y2="10.16" width="0.6096" layer="94"/>
<text x="0" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="0" y="16.002" size="1.778" layer="95">&gt;NAME</text>
<pin name="10" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="10.16" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="9" x="-5.08" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="7" x="-5.08" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="5" x="-5.08" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="3" x="-5.08" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="1" x="-5.08" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="11" x="-5.08" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="12" x="10.16" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<wire x1="3.81" y1="0" x2="5.08" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.6096" layer="94"/>
</symbol>
<symbol name="I2C_STANDARD">
<wire x1="6.35" y1="0" x2="-2.54" y2="0" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="-2.54" y2="0" width="0.4064" layer="94"/>
<wire x1="6.35" y1="0" x2="6.35" y2="12.7" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="12.7" x2="6.35" y2="12.7" width="0.4064" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="13.462" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="10.16" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="10.16" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="10.16" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<text x="-2.032" y="7.62" size="1.778" layer="94" align="center-left">SDA</text>
<text x="-2.032" y="5.08" size="1.778" layer="94" align="center-left">VCC</text>
<text x="-2.032" y="2.54" size="1.778" layer="94" align="center-left">GND</text>
<text x="-2.032" y="10.16" size="1.778" layer="94" align="center-left">SCL</text>
</symbol>
<symbol name="M20X2">
<wire x1="3.81" y1="-27.94" x2="3.81" y2="25.4" width="0.4064" layer="94"/>
<text x="-5.08" y="-30.48" size="1.778" layer="96">&gt;VALUE</text>
<text x="-5.08" y="26.162" size="1.778" layer="95">&gt;NAME</text>
<pin name="26" x="7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="24" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="22" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="20" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="18" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="14" x="7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="12" x="7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="10" x="7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="8" x="7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="6" x="7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<wire x1="-3.81" y1="25.4" x2="3.81" y2="25.4" width="0.4064" layer="94"/>
<wire x1="-1.27" y1="17.78" x2="-2.54" y2="17.78" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="20.32" x2="-2.54" y2="20.32" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="22.86" x2="-2.54" y2="22.86" width="0.6096" layer="94"/>
<wire x1="-3.81" y1="25.4" x2="-3.81" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-27.94" x2="-3.81" y2="-27.94" width="0.4064" layer="94"/>
<pin name="1" x="-7.62" y="22.86" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="3" x="-7.62" y="20.32" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="5" x="-7.62" y="17.78" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="7" x="-7.62" y="15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="9" x="-7.62" y="12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="11" x="-7.62" y="10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="13" x="-7.62" y="7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="15" x="-7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="17" x="-7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="19" x="-7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="21" x="-7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="23" x="-7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="25" x="-7.62" y="-7.62" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="27" x="-7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="28" x="7.62" y="-10.16" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="29" x="-7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="30" x="7.62" y="-12.7" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="31" x="-7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="32" x="7.62" y="-15.24" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="33" x="-7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="34" x="7.62" y="-17.78" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="35" x="-7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="36" x="7.62" y="-20.32" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="37" x="-7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="38" x="7.62" y="-22.86" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="39" x="-7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1"/>
<pin name="40" x="7.62" y="-25.4" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<wire x1="-1.27" y1="-17.78" x2="-2.54" y2="-17.78" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-20.32" x2="-2.54" y2="-20.32" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-22.86" x2="-2.54" y2="-22.86" width="0.6096" layer="94"/>
<wire x1="-1.27" y1="-25.4" x2="-2.54" y2="-25.4" width="0.6096" layer="94"/>
</symbol>
<symbol name="BATTERY_CONN">
<wire x1="-2.54" y1="2.54" x2="3.81" y2="2.54" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="3.81" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<text x="-2.54" y="-7.62" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="3.302" size="1.778" layer="95">&gt;NAME</text>
<pin name="+" x="7.62" y="0" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="-" x="7.62" y="-2.54" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
<symbol name="USD_CARD">
<description>Newer version of USDCARD symbol that moves pins for easier routing and uses more accurate pin names.&lt;br /&gt;
Renamed DAT2 from NC to RSV to remove the implication that you should leave it not connected.</description>
<wire x1="-12.7" y1="10.16" x2="15.24" y2="10.16" width="0.254" layer="94"/>
<wire x1="15.24" y1="10.16" x2="15.24" y2="-12.7" width="0.254" layer="94"/>
<wire x1="15.24" y1="-12.7" x2="-12.7" y2="-12.7" width="0.254" layer="94"/>
<text x="-12.7" y="10.668" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.874" y="10.668" size="1.778" layer="96">&gt;VALUE</text>
<pin name="!CS" x="-15.24" y="2.54" visible="pin" length="short"/>
<pin name="DI" x="-15.24" y="0" visible="pin" length="short"/>
<pin name="GND" x="2.54" y="-15.24" visible="pin" length="short" rot="R90"/>
<pin name="VCC" x="-15.24" y="5.08" visible="pin" length="short"/>
<pin name="SCK" x="-15.24" y="-2.54" visible="pin" length="short"/>
<pin name="RSV@2" x="17.78" y="0" visible="pin" length="short" rot="R180"/>
<pin name="DO" x="-15.24" y="-5.08" visible="pin" length="short"/>
<pin name="RSV@1" x="17.78" y="5.08" visible="pin" length="short" rot="R180"/>
<pin name="SHIELD@3" x="0" y="-15.24" visible="pin" length="short" rot="R90"/>
<pin name="SHIELD@1" x="-2.54" y="-15.24" visible="pin" length="short" rot="R90"/>
<pin name="CD1" x="17.78" y="-5.08" visible="pin" length="short" rot="R180"/>
<pin name="CD2" x="17.78" y="-10.16" visible="pin" length="short" rot="R180"/>
<wire x1="-12.7" y1="-12.7" x2="-12.7" y2="10.16" width="0.254" layer="94"/>
<wire x1="13.462" y1="-10.16" x2="13.462" y2="-5.08" width="0.254" layer="94"/>
<wire x1="13.462" y1="-5.08" x2="14.732" y2="-5.08" width="0.254" layer="94"/>
<wire x1="13.462" y1="-10.16" x2="14.732" y2="-10.16" width="0.254" layer="94"/>
</symbol>
<symbol name="CORTEX_DEBUG">
<description>&lt;h3&gt;Cortex Debug Connector&lt;/h3&gt;
&lt;p&gt;&lt;a href="http://infocenter.arm.com/help/topic/com.arm.doc.faqs/attached/13634/cortex_debug_connectors.pdf"&gt;Datasheet&lt;/a&gt;&lt;/p&gt;</description>
<pin name="VCC" x="-15.24" y="5.08" length="short"/>
<pin name="GND@3" x="-15.24" y="2.54" length="short"/>
<pin name="GND@5" x="-15.24" y="0" length="short"/>
<pin name="KEY" x="-15.24" y="-2.54" length="short"/>
<pin name="GNDDTCT" x="-15.24" y="-5.08" length="short"/>
<pin name="NRESET" x="17.78" y="-5.08" length="short" rot="R180"/>
<pin name="NC/TDI" x="17.78" y="-2.54" length="short" rot="R180"/>
<pin name="SWO/TDO" x="17.78" y="0" length="short" rot="R180"/>
<pin name="SWDCLK/TCK" x="17.78" y="2.54" length="short" rot="R180"/>
<pin name="SWDIO/TMS" x="17.78" y="5.08" length="short" rot="R180"/>
<wire x1="-12.7" y1="-7.62" x2="-12.7" y2="7.62" width="0.254" layer="94"/>
<wire x1="-12.7" y1="7.62" x2="15.24" y2="7.62" width="0.254" layer="94"/>
<wire x1="15.24" y1="7.62" x2="15.24" y2="-7.62" width="0.254" layer="94"/>
<wire x1="15.24" y1="-7.62" x2="-12.7" y2="-7.62" width="0.254" layer="94"/>
<text x="-12.7" y="7.874" size="1.778" layer="95">&gt;Name</text>
<text x="-12.7" y="-7.874" size="1.778" layer="96" align="top-left">&gt;Value</text>
</symbol>
<symbol name="USB-MICROB">
<wire x1="2.54" y1="8.89" x2="-2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-6.35" x2="2.54" y2="-6.35" width="0.254" layer="94"/>
<text x="1.524" y="-3.556" size="2.54" layer="94" rot="R90">USB B</text>
<pin name="D+" x="-5.08" y="2.54" visible="pad" length="short"/>
<pin name="D-" x="-5.08" y="0" visible="pad" length="short"/>
<pin name="VBUS" x="-5.08" y="-2.54" visible="pad" length="short"/>
<pin name="GND" x="-5.08" y="7.62" visible="pad" length="short"/>
<pin name="USBID" x="-5.08" y="5.08" visible="pad" length="short"/>
<pin name="SHIELD" x="-5.08" y="-5.08" visible="pad" length="short"/>
<text x="-2.54" y="10.16" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="USDCARD_SDIO">
<wire x1="0" y1="35.56" x2="12.7" y2="35.56" width="0.254" layer="94"/>
<wire x1="12.7" y1="35.56" x2="12.7" y2="0" width="0.254" layer="94"/>
<wire x1="12.7" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<text x="0" y="36.068" size="1.778" layer="95">&gt;NAME</text>
<text x="0" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="CD/DAT3" x="-5.08" y="30.48" length="middle"/>
<pin name="CMD" x="-5.08" y="27.94" length="middle"/>
<pin name="GND" x="-5.08" y="20.32" length="middle"/>
<pin name="VCC" x="-5.08" y="25.4" length="middle"/>
<pin name="CLK" x="-5.08" y="22.86" length="middle"/>
<pin name="DAT1" x="-5.08" y="15.24" length="middle"/>
<pin name="DAT0" x="-5.08" y="17.78" length="middle"/>
<pin name="DAT2" x="-5.08" y="33.02" length="middle"/>
<pin name="SHIELD@3" x="-5.08" y="5.08" length="middle"/>
<pin name="SHIELD@1" x="-5.08" y="10.16" length="middle"/>
<pin name="CD1" x="-5.08" y="7.62" length="middle"/>
<pin name="CD2" x="-5.08" y="2.54" length="middle"/>
<wire x1="0" y1="0" x2="0" y2="35.56" width="0.254" layer="94"/>
<wire x1="1.778" y1="7.62" x2="1.778" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.778" y1="2.54" x2="0.508" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.778" y1="7.62" x2="0.508" y2="7.62" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ARDUINO_SERIAL_PROGRAM" prefix="J" uservalue="yes">
<description>FTDI connector footprints</description>
<gates>
<gate name="G$1" symbol="ARDUINO_SERIAL_PROGRAM" x="0" y="-2.54"/>
</gates>
<devices>
<device name="SMD" package="1X06-SMD">
<connects>
<connect gate="G$1" pin="CTS" pad="5"/>
<connect gate="G$1" pin="DTR" pad="1"/>
<connect gate="G$1" pin="GND" pad="6"/>
<connect gate="G$1" pin="RXI" pad="2"/>
<connect gate="G$1" pin="TXO" pad="3"/>
<connect gate="G$1" pin="VCC" pad="4"/>
</connects>
<technologies>
<technology name="">
<attribute name="PROD_ID" value="CONN-08971" constant="no"/>
</technology>
</technologies>
</device>
<device name="PTH" package="1X06">
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="RA_LOCK" package="MOLEX-1X6-RA_LOCK">
<connects>
<connect gate="G$1" pin="CTS" pad="2"/>
<connect gate="G$1" pin="DTR" pad="6"/>
<connect gate="G$1" pin="GND" pad="1"/>
<connect gate="G$1" pin="RXI" pad="5"/>
<connect gate="G$1" pin="TXO" pad="4"/>
<connect gate="G$1" pin="VCC" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X06_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X06_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH-KIT" package="1X06-KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ATARI_CONNECTOR">
<description>DB9 labeled for Atari joystick</description>
<gates>
<gate name="G$1" symbol="ATARI_CONNECTOR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ATARI_CONNECTOR">
<connects>
<connect gate="G$1" pin="BUTTON" pad="P$1"/>
<connect gate="G$1" pin="DOWN" pad="P$6"/>
<connect gate="G$1" pin="GND" pad="P$3"/>
<connect gate="G$1" pin="LEFT" pad="P$7"/>
<connect gate="G$1" pin="NC1" pad="P$9"/>
<connect gate="G$1" pin="NC2" pad="P$2"/>
<connect gate="G$1" pin="NC3" pad="P$4"/>
<connect gate="G$1" pin="RIGHT" pad="P$8"/>
<connect gate="G$1" pin="UP" pad="P$5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ATX24" prefix="J">
<description>&lt;b&gt;ATX24 Pin Power Supply Connector&lt;/b&gt; This is a good connector for connecting a computer power supply to a PCB. It's massive, but provides many amps of power at 5V and 12V. SKU: PRT-09498</description>
<gates>
<gate name="G$1" symbol="ATX24-1" x="-12.7" y="-22.86"/>
</gates>
<devices>
<device name="RH" package="ATX24_RIGHT_ANGLE">
<connects>
<connect gate="G$1" pin="-12V" pad="14"/>
<connect gate="G$1" pin="12V@0" pad="10"/>
<connect gate="G$1" pin="12V@1" pad="11"/>
<connect gate="G$1" pin="3.3V@0" pad="1"/>
<connect gate="G$1" pin="3.3V@1" pad="2"/>
<connect gate="G$1" pin="3.3V@2" pad="12"/>
<connect gate="G$1" pin="3.3V@3" pad="13"/>
<connect gate="G$1" pin="5V@0" pad="4"/>
<connect gate="G$1" pin="5V@1" pad="6"/>
<connect gate="G$1" pin="5V@2" pad="21"/>
<connect gate="G$1" pin="5V@3" pad="22"/>
<connect gate="G$1" pin="5V@4" pad="23"/>
<connect gate="G$1" pin="5V_STDBY" pad="9"/>
<connect gate="G$1" pin="GND@0" pad="3"/>
<connect gate="G$1" pin="GND@1" pad="5"/>
<connect gate="G$1" pin="GND@2" pad="7"/>
<connect gate="G$1" pin="GND@3" pad="15"/>
<connect gate="G$1" pin="GND@4" pad="17"/>
<connect gate="G$1" pin="GND@5" pad="18"/>
<connect gate="G$1" pin="GND@6" pad="19"/>
<connect gate="G$1" pin="GND@7" pad="24"/>
<connect gate="G$1" pin="NC" pad="20"/>
<connect gate="G$1" pin="PS_ON" pad="16"/>
<connect gate="G$1" pin="PWR_OK" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AUDIO-JACK" prefix="J" uservalue="yes">
<description>&lt;b&gt;3.5mm Audio Jack&lt;/b&gt;
Simple 3.5mm common PCB mount audio jack. &lt;br&gt;
Variant PTH is our storefront SKU PRT-08032</description>
<gates>
<gate name="G$1" symbol="AUDIO-JACK" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="AUDIO-JACK">
<connects>
<connect gate="G$1" pin="LEFT" pad="TIP"/>
<connect gate="G$1" pin="RIGHT" pad="RING"/>
<connect gate="G$1" pin="SLEEVE" pad="SLEEVE"/>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5MM" package="STEREOJACK2.5MM_STEREOJACK2.5MM">
<connects>
<connect gate="G$1" pin="LEFT" pad="SHIELD"/>
<connect gate="G$1" pin="RIGHT" pad="TIP"/>
<connect gate="G$1" pin="SLEEVE" pad="RING1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SPECIAL_POGO_PINS" package="STEREOJACK2.5MM_SPECIA_POGOPINS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HOLESONLY" package="STEREOJACK2.5MM_SPECIAL_HOLES-ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="STEREOJACK2.5MM_SMD">
<connects>
<connect gate="G$1" pin="LEFT" pad="1"/>
<connect gate="G$1" pin="RIGHT" pad="4"/>
<connect gate="G$1" pin="SLEEVE" pad="5"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10062" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMD2" package="AUDIO-JACK-3.5MM-SMD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10353"/>
</technology>
</technologies>
</device>
<device name="1:1" package="STEREOJACK2.5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AUDIO-JACK2" prefix="J">
<description>Stereo audio jack with bypass switches.&lt;br&gt;
SMT version used on LilyPad MP3 board.&lt;br&gt;</description>
<gates>
<gate name="G$1" symbol="AUDIO-JACK2" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="RING" pad="RING"/>
<connect gate="G$1" pin="RSH" pad="RSH"/>
<connect gate="G$1" pin="TIP" pad="TIP"/>
<connect gate="G$1" pin="TSH" pad="TSH"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08774" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMD" package="AUDIO-JACK-3.5MM-SMD">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="KIT" package="AUDIO-JACK-KIT">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AVR_MINI_PROG">
<description>AVR ISP 6-pin inline header</description>
<gates>
<gate name="G$1" symbol="AVR_MINI_PROGRAMMER" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="AVR_MINI_PROG">
<connects>
<connect gate="G$1" pin="GND" pad="2"/>
<connect gate="G$1" pin="MISO" pad="6"/>
<connect gate="G$1" pin="MOSI" pad="4"/>
<connect gate="G$1" pin="RST" pad="3"/>
<connect gate="G$1" pin="SCK" pad="5"/>
<connect gate="G$1" pin="VCC" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AVR_SPI_PRG_6" prefix="J">
<description>&lt;b&gt;AVR ISP 6 Pin&lt;/b&gt;
This is the reduced ISP connector for AVR programming. Common on Arduino. This footprint will take up less PCB space and can be used with a 10-pin to 6-pin adapter such as SKU: BOB-08508
&lt;b&gt;**Special note about "TEST_POINT" package.&lt;/b&gt; The stop mask is on the top side, so if you want your programming test points to be on the bottom of your board, make sure to place this package on the bottom side of the board. This also ensure that the orientation to program from the bottom side will be correct.</description>
<gates>
<gate name="G$1" symbol="AVR_SPI_PROGRAMMER_6" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="2X3">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<device name="NS" package="2X3-NS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="OFFSET_PADS" package="2X3_OFFSET">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2X3_LOCK" package="2X3_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TESTPOINTS" package="2X3_TEST_POINTS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AVR_SPI_PROG">
<description>&lt;b&gt;AVR 10-pin ICSP Header&lt;/b&gt;
This is the standard AVR In Circuit Serial Programming header. Minimal, but includes pin one indicator. Works with standard Olimex programmers. Also look for the 6-pin reduced version. Spark Fun Electronics SKU: PRT-00778</description>
<gates>
<gate name="A" symbol="AVR_SPI_PROGRAMMER" x="0" y="0"/>
</gates>
<devices>
<device name="" package="AVR_ICSP">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="10" pad="10"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="6" pad="6"/>
<connect gate="A" pin="7" pad="7"/>
<connect gate="A" pin="8" pad="8"/>
<connect gate="A" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AVR_SPI_PROG2" prefix="J">
<gates>
<gate name="G$1" symbol="AVR_SPI_PROGRAMMER-1" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="AVR_ICSP">
<connects>
<connect gate="G$1" pin="GND@1" pad="4"/>
<connect gate="G$1" pin="GND@2" pad="6"/>
<connect gate="G$1" pin="GND@3" pad="8"/>
<connect gate="G$1" pin="GND@4" pad="10"/>
<connect gate="G$1" pin="MISO" pad="9"/>
<connect gate="G$1" pin="MOSI" pad="1"/>
<connect gate="G$1" pin="NC" pad="3"/>
<connect gate="G$1" pin="RESET" pad="5"/>
<connect gate="G$1" pin="SCK" pad="7"/>
<connect gate="G$1" pin="VCC" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH2" package="2X5-SHROUDED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="2X5-SHROUDED_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="2X5-SHROUDED_SMD">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BANANA_CONN" prefix="J" uservalue="yes">
<description>Through-hole banana jack</description>
<gates>
<gate name="G$1" symbol="BANANA_CONN" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="BANANA_CONN">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BC9VPC" prefix="BAT" uservalue="yes">
<description>9V board-mount battery cradle</description>
<gates>
<gate name="G$1" symbol="BC9VPC" x="0" y="0"/>
</gates>
<devices>
<device name="" package="BC9VPC">
<connects>
<connect gate="G$1" pin="V+" pad="V+"/>
<connect gate="G$1" pin="V-" pad="V-"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="BATT-10855" constant="no"/>
</technology>
</technologies>
</device>
<device name="KIT_SOLDERMASK" package="BC9VPC_KIT">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BNC">
<description>BNC Connector, Mouser Part# 5227161</description>
<gates>
<gate name="G$1" symbol="BNC" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="BNC">
<connects>
<connect gate="G$1" pin="GND" pad="GND"/>
<connect gate="G$1" pin="OUT" pad="S"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DB9" prefix="J" uservalue="yes">
<description>&lt;b&gt;DB9 Connector&lt;/b&gt;
Standard DB9 (D-Sub 9) serial connector. Can be used for CAN bus as well as RS485 and RS232. Footprint production proven. Spark Fun Electronics SKU : PRT-00429</description>
<gates>
<gate name="G$1" symbol="F09G" x="0" y="0"/>
</gates>
<devices>
<device name="FEMALE" package="DB9">
<connects>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08194" constant="no"/>
</technology>
</technologies>
</device>
<device name="MALE" package="DB9_MALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09904" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DB25" prefix="X" uservalue="yes">
<description>Various DB25 connectors</description>
<gates>
<gate name="-1" symbol="DB25" x="0" y="0"/>
</gates>
<devices>
<device name="D" package="M25D">
<connects>
<connect gate="-1" pin="1" pad="1"/>
<connect gate="-1" pin="10" pad="10"/>
<connect gate="-1" pin="11" pad="11"/>
<connect gate="-1" pin="12" pad="12"/>
<connect gate="-1" pin="13" pad="13"/>
<connect gate="-1" pin="14" pad="14"/>
<connect gate="-1" pin="15" pad="15"/>
<connect gate="-1" pin="16" pad="16"/>
<connect gate="-1" pin="17" pad="17"/>
<connect gate="-1" pin="18" pad="18"/>
<connect gate="-1" pin="19" pad="19"/>
<connect gate="-1" pin="2" pad="2"/>
<connect gate="-1" pin="20" pad="20"/>
<connect gate="-1" pin="21" pad="21"/>
<connect gate="-1" pin="22" pad="22"/>
<connect gate="-1" pin="23" pad="23"/>
<connect gate="-1" pin="24" pad="24"/>
<connect gate="-1" pin="25" pad="25"/>
<connect gate="-1" pin="3" pad="3"/>
<connect gate="-1" pin="4" pad="4"/>
<connect gate="-1" pin="5" pad="5"/>
<connect gate="-1" pin="6" pad="6"/>
<connect gate="-1" pin="7" pad="7"/>
<connect gate="-1" pin="8" pad="8"/>
<connect gate="-1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="H" package="M25H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HP" package="M25HP">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V" package="M25V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VP" package="M25VP">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VB" package="M25VB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIN7">
<description>Mini-DIN7 connector</description>
<gates>
<gate name="G$1" symbol="DIN7" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIN7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DS_TOUCH_CONNECTOR" prefix="J">
<description>4-pin DS touch screen connector (LCD-09105)</description>
<gates>
<gate name="G$1" symbol="DS_TOUCH_CONNECTOR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DS_TOUCH_CONNECTOR">
<connects>
<connect gate="G$1" pin="X1" pad="1"/>
<connect gate="G$1" pin="X2" pad="3"/>
<connect gate="G$1" pin="Y1" pad="4"/>
<connect gate="G$1" pin="Y2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EB-85A">
<description>&lt;b&gt;EB-85A Connector&lt;/b&gt;
Proven layout and schematic for ETek 5Hz GPS receiver connector. Spark Fun Electronics SKU : GPS-08297</description>
<gates>
<gate name="G$1" symbol="EB-85A" x="0" y="-2.54"/>
</gates>
<devices>
<device name="SMD" package="EB-85A">
<connects>
<connect gate="G$1" pin="BATT" pad="8"/>
<connect gate="G$1" pin="PPS" pad="7"/>
<connect gate="G$1" pin="RX1" pad="4"/>
<connect gate="G$1" pin="RX2" pad="6"/>
<connect gate="G$1" pin="TX1" pad="3"/>
<connect gate="G$1" pin="TX2" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EM406" prefix="U">
<description>&lt;b&gt;EM406 GPS Connector&lt;/b&gt;
Proven layout and schematic for EM406 connector. Spark Fun Electronics SKU : GPS-00579</description>
<gates>
<gate name="G$1" symbol="EM406" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="EM406">
<connects>
<connect gate="G$1" pin="1PPS" pad="6"/>
<connect gate="G$1" pin="GND1" pad="1"/>
<connect gate="G$1" pin="GND2" pad="5"/>
<connect gate="G$1" pin="RX" pad="3"/>
<connect gate="G$1" pin="TX" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EM408_CON" prefix="U">
<description>This is the mating connector for the EM408 GPS receiver.  The EM408 connects to the board via a cable,
this connector footprint does not include the outline of the receiver.
You should include the "EM408_Outline" device in your schematic if you are to use the EM408 in your design.</description>
<gates>
<gate name="G$1" symbol="EM408_CON" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="EM408_CON">
<connects>
<connect gate="G$1" pin="EN" pad="1"/>
<connect gate="G$1" pin="VCC" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="F25" prefix="X" uservalue="yes">
<description>25 Pin male connector. PCB edge mount for regular PCB thicknesses. This connector will connect directly to the back of a PC parallel port or through a normal DB25 extension cable (M/F). SKU: PRT-08287</description>
<gates>
<gate name="-1" symbol="F25" x="0" y="0"/>
</gates>
<devices>
<device name="D" package="F25D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="H" package="F25H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HP" package="F25HP">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V" package="F25V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VP" package="F25VP">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VB" package="F25VB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FTDI_BASIC" prefix="J">
<description>FTDI Basic header with labels</description>
<gates>
<gate name="G$1" symbol="M06" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="FTDI_BASIC">
<connects>
<connect gate="G$1" pin="1" pad="DTR"/>
<connect gate="G$1" pin="2" pad="RXI"/>
<connect gate="G$1" pin="3" pad="TXO"/>
<connect gate="G$1" pin="4" pad="VCC"/>
<connect gate="G$1" pin="5" pad="CTS"/>
<connect gate="G$1" pin="6" pad="GND"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IPOD_CONNECTOR_FEMALE">
<description>&lt;b&gt;iPod Female Connector&lt;/b&gt;
This is the connector found inside current iPods. Use this connector to attach to iPod accessories like Nike+iPods, etc. Schematic and footprint are not yet production proven. Spark Fun Electronics SKU : DEV-08035</description>
<gates>
<gate name="G$1" symbol="IPOD_CONNECTOR_FEMALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="IPOD_FEMALE_CONNECTOR">
<connects>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="3.3V" pad="18"/>
<connect gate="G$1" pin="ACC_INDICATOR" pad="21"/>
<connect gate="G$1" pin="FW_12V@19" pad="19"/>
<connect gate="G$1" pin="FW_12V@20" pad="20"/>
<connect gate="G$1" pin="FW_TPA+" pad="24"/>
<connect gate="G$1" pin="FW_TPA-" pad="22"/>
<connect gate="G$1" pin="FW_TPB+" pad="28"/>
<connect gate="G$1" pin="FW_TPB-" pad="26"/>
<connect gate="G$1" pin="GND@1" pad="1"/>
<connect gate="G$1" pin="GND@11" pad="11"/>
<connect gate="G$1" pin="GND@15" pad="15"/>
<connect gate="G$1" pin="GND@16" pad="16"/>
<connect gate="G$1" pin="GND@2" pad="2"/>
<connect gate="G$1" pin="GND@29" pad="29"/>
<connect gate="G$1" pin="GND@30" pad="30"/>
<connect gate="G$1" pin="LEFT_IN" pad="6"/>
<connect gate="G$1" pin="LEFT_OUT" pad="4"/>
<connect gate="G$1" pin="RIGHT_IN" pad="5"/>
<connect gate="G$1" pin="RIGHT_OUT" pad="3"/>
<connect gate="G$1" pin="RX" pad="13"/>
<connect gate="G$1" pin="SCHROME_OUT" pad="9"/>
<connect gate="G$1" pin="SLUM_OUT" pad="10"/>
<connect gate="G$1" pin="TX" pad="12"/>
<connect gate="G$1" pin="USB_5V" pad="23"/>
<connect gate="G$1" pin="USB_D+" pad="27"/>
<connect gate="G$1" pin="USB_D-" pad="25"/>
<connect gate="G$1" pin="VIDEO_OUT" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IPOD_CONNECTOR_MALE">
<description>&lt;b&gt;iPod Male Connector&lt;/b&gt;
This is the connector that will insert into an iPods. Use this connector to gain access to the various iPod pins. Schematic and footprint are not yet production proven. The PCB thickness must be more thin than the standard 0.062" FR4. Spark Fun Electronics SKU : DEV-00633</description>
<gates>
</gates>
<devices>
<device name="" package="IPOD_MALE_CONNECTOR">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="KENT_LCD_CONN">
<description>Connector for Kent display (LCD-09560)</description>
<gates>
<gate name="G$1" symbol="KENT_LCD_CONN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="FFC_16">
<connects>
<connect gate="G$1" pin="/RESET" pad="1"/>
<connect gate="G$1" pin="BUSY" pad="2"/>
<connect gate="G$1" pin="CS" pad="7"/>
<connect gate="G$1" pin="NC1" pad="15"/>
<connect gate="G$1" pin="NC2" pad="16"/>
<connect gate="G$1" pin="SCK" pad="4"/>
<connect gate="G$1" pin="SI" pad="6"/>
<connect gate="G$1" pin="SO" pad="5"/>
<connect gate="G$1" pin="VCC" pad="9"/>
<connect gate="G$1" pin="VPWR1" pad="10"/>
<connect gate="G$1" pin="VPWR2" pad="11"/>
<connect gate="G$1" pin="VPWR3" pad="13"/>
<connect gate="G$1" pin="VSS1" pad="3"/>
<connect gate="G$1" pin="VSS2" pad="8"/>
<connect gate="G$1" pin="VSS3" pad="12"/>
<connect gate="G$1" pin="VSS4" pad="14"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LITTLEBITS_FEMALE" prefix="J">
<description>Female end for LittleBits boards</description>
<gates>
<gate name="G$1" symbol="LITTLEBITS_FEMALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LITTLE_BITS_FEMALE">
<connects>
<connect gate="G$1" pin="GND" pad="V-"/>
<connect gate="G$1" pin="SIG" pad="SIG"/>
<connect gate="G$1" pin="VCC" pad="V+"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LITTLEBITS_MALE">
<description>Male end for LittleBits boards</description>
<gates>
<gate name="G$1" symbol="LITTLEBITS_MALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LITTLE_BITS_MALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LITTLE_BITS_CONN">
<description>Connector used in LittleBits</description>
<gates>
<gate name="G$1" symbol="LITTLEBITS" x="-7.62" y="-10.16"/>
</gates>
<devices>
<device name="" package="LITTLEBITS">
<connects>
<connect gate="G$1" pin="SIG" pad="P$4"/>
<connect gate="G$1" pin="VCC" pad="P$5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M01" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 1&lt;/b&gt;
Standard 1-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115). SMTSO-256-ET is a "flush mount" nut for a 4-40 screw. The older package used to be too tight, and did not allow it to sit properly thru the drill hit. The latest (0.165DIA) fits nice and snug.</description>
<gates>
<gate name="G$1" symbol="M01" x="0" y="0"/>
</gates>
<devices>
<device name="PTH_LONGPAD" package="1X01_LONGPAD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="LUXEON-PAD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMTRA-256-8-6" package="SMTRA-256-8-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMDNS" package="1X01NS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH" package="1X01">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_2MM" package="1X01_2MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="OFFSET" package="1X01_OFFSET">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD-4.5X1.5" package="PAD-1.5X4.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POGOPIN_HOLE_LARGE" package="1X01_POGOPIN_HOLE_LARGE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POGOPIN_HOLE_0.58" package="1X01_POGOPIN_HOLE_0.58">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SNAP-FEMALE" package="SNAP-FEMALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SNAP-MALE" package="SNAP-MALE">
<connects>
<connect gate="G$1" pin="1" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SPRING-CONN" package="SPRING-CONNECTOR">
<connects>
<connect gate="G$1" pin="1" pad="P$2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="NOSILK-KIT" package="1X01NS-KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_NO_SILK_YES_STOP" package="1X01_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMTSO-256-ET-0.165DIA" package="SMTSO-256-ET-0.165DIA">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M02" prefix="J" uservalue="yes">
<description>Standard 2-pin 0.1" header. Use with &lt;br&gt;
- straight break away headers ( PRT-00116)&lt;br&gt;
- right angle break away headers (PRT-00553)&lt;br&gt;
- swiss pins (PRT-00743)&lt;br&gt;
- machine pins (PRT-00117)&lt;br&gt;
- female headers (PRT-00115)&lt;br&gt;&lt;br&gt;
 Molex polarized connector foot print use with: PRT-08233 with associated crimp pins and housings.&lt;br&gt;&lt;br&gt;
2.54_SCREWTERM for use with  PRT-10571.&lt;br&gt;&lt;br&gt;
3.5mm Screw Terminal footprints for  PRT-08084&lt;br&gt;&lt;br&gt;
5mm Screw Terminal footprints for use with PRT-08432</description>
<gates>
<gate name="G$1" symbol="M02" x="-2.54" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X02">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POLAR" package="MOLEX-1X2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3.5MM" package="SCREWTERMINAL-3.5MM-2">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08399" constant="no"/>
</technology>
</technologies>
</device>
<device name="-JST-2MM-SMT" package="JST-2-SMD">
<connects>
<connect gate="G$1" pin="2" pad="1"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11443"/>
</technology>
</technologies>
</device>
<device name="PTH2" package="1X02_BIG">
<connects>
<connect gate="G$1" pin="2" pad="P$2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="4UCON-15767" package="JST-2-SMD-VERT">
<connects>
<connect gate="G$1" pin="1" pad="GND"/>
<connect gate="G$1" pin="2" pad="VCC"/>
</connects>
<technologies>
</technologies>
</device>
<device name="ROCKER" package="R_SW_TH">
<connects>
<connect gate="G$1" pin="1" pad="P$3"/>
<connect gate="G$1" pin="2" pad="P$4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="SCREWTERMINAL-5MM-2">
<connects>
</connects>
<technologies>
<attribute name="STOREFRONT_ID" value="PRT-08432" constant="no"/>
</technology>
</technologies>
</device>
<device name="LOCK" package="1X02_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POLAR_LOCK" package="MOLEX-1X2_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X02_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3.5MM_LOCK" package="SCREWTERMINAL-3.5MM-2_LOCK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="PTH3" package="1X02_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X02_NO_SILK" package="1X02_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH-2" package="JST-2-PTH">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09863" constant="no"/>
<attribute name="SKU" value="PRT-09914" constant="no"/>
</technology>
</technologies>
</device>
<device name="PTH4" package="1X02_XTRA_BIG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POGO_PIN_HOLES_ONLY" package="1X02_PP_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3.5MM-NO_SILK" package="SCREWTERMINAL-3.5MM-2-NS">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="-JST-2-PTH-NO_SILK" package="JST-2-PTH-NS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH-2-KIT" package="JST-2-PTH-KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SPRING-2.54-RA" package="SPRINGTERMINAL-2.54MM-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.54MM_SCREWTERM" package="1X02_2.54_SCREWTERM">
<connects>
<connect gate="G$1" pin="1" pad="P1"/>
<connect gate="G$1" pin="2" pad="P2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH-VERT" package="JST-2-PTH-VERT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMALL_POKEHOME" package="1X02_POKEHOME">
<connects>
<connect gate="G$1" pin="1" pad="P1 P3"/>
<connect gate="G$1" pin="2" pad="P2 P4"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-13512"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M03" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 3&lt;/b&gt;
Standard 3-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115). Molex polarized connector foot print use with SKU : PRT-08232 with associated crimp pins and housings.</description>
<gates>
<gate name="J$1" symbol="M03" x="-2.54" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X03">
<connects>
<connect gate="J$1" pin="1" pad="1"/>
<connect gate="J$1" pin="2" pad="2"/>
<connect gate="J$1" pin="3" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="POLAR" package="MOLEX-1X3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SCREW" package="SCREWTERMINAL-3.5MM-3">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08288" constant="no"/>
</technology>
</technologies>
</device>
<device name="LOCK" package="1X03_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X03_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POLAR_LOCK" package="MOLEX-1X3_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SCREW_LOCK" package="SCREWTERMINAL-3.5MM-3_LOCK.007S">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="1X03_NO_SILK" package="1X03_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X03_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH" package="JST-3-PTH">
<connects>
</connects>
<technologies>
<attribute name="SKU" value="PRT-09915" constant="no"/>
</technology>
</technologies>
</device>
<device name="POGO_PIN_HOLES_ONLY" package="1X03_PP_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-SCREW-5MM" package="SCREWTERMINAL-5MM-3">
<connects>
</connects>
<technologies>
<attribute name="STOREFRONT_ID" value="PRT-08433" constant="no"/>
</technology>
</technologies>
</device>
<device name="LOCK_NO_SILK" package="1X03_LOCK_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-SMD" package="JST-3-SMD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12591" constant="no"/>
<attribute name="VALUE" value="3-PIN SMD" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMD" package="1X03-1MM-RA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD_RA_FEMALE" package="1X03_SMD_RA_FEMALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10926"/>
<attribute name="VALUE" value="1x3 RA Female .1&quot;"/>
</technology>
</technologies>
</device>
<device name="SMD_RA_MALE" package="1X03_SMD_RA_MALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10925"/>
</technology>
</technologies>
</device>
<device name="SMD_RA_MALE_POST" package="1X03_SMD_RA_MALE_POST">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH-VERT" package="JST-3-PTH-VERT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X03_SMD_RA_MALE_POST_SMALLER" package="1X03_SMD_RA_MALE_POST_SMALLER">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X03_SMD_RA_MALE_POST_SMALLEST" package="1X03_SMD_RA_MALE_POST_SMALLEST">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M04" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 4&lt;/b&gt;
Standard 4-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115). Molex polarized connector foot print use with SKU : PRT-08231 with associated crimp pins and housings. 1MM SMD Version SKU: PRT-10208</description>
<gates>
<gate name="G$1" symbol="M04" x="-2.54" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X04">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09696" constant="no"/>
</technology>
</technologies>
</device>
<device name="POLAR" package="MOLEX-1X4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SCREW" package="SCREWTERMINAL-3.5MM-4">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="Combine 2x8399" constant="no"/>
</technology>
</technologies>
</device>
<device name="1.27MM" package="1X04-1.27MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X04_LOCK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X04_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="POLAR_LOCK" package="MOLEX-1X4_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="1X04-SMD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X04_LONGPADS">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="1X04_NO_SILK" package="1X04_NO_SILK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="JST-PTH" package="JST-4-PTH">
<connects>
</connects>
<technologies>
<attribute name="SKU" value="PRT-09916" constant="no"/>
</technology>
</technologies>
</device>
<device name="SCREW_LOCK" package="SCREWTERMINAL-3.5MM-4_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD2" package="1X04-1MM-RA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD_STRAIGHT_COMBO" package="1X04_SMD_STRAIGHT_COMBO">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08511"/>
<attribute name="VALUE" value="1X04_SMD_STRAIGHT_COMBO"/>
</technology>
</technologies>
</device>
<device name="SMD_LONG" package="1X04-SMD_LONG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-PTH-VERT" package="JST-4-PTH-VERT">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-13251"/>
</technology>
</technologies>
</device>
<device name="SMD_RA_FEMALE" package="1X04_SMD_RA_FEMALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST" package="1X04-1.5MM_JST">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12477"/>
</technology>
</technologies>
</device>
<device name="NO_SILK_ALL_ROUND" package="1X04_NO_SILK_ALL_ROUND">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M04X2" prefix="J" uservalue="yes">
<description>.1" header, two rows of four.</description>
<gates>
<gate name="G$1" symbol="M04X2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M05" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 5&lt;/b&gt;
Standard 5-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115). Molex polarized connector foot print use with SKU : PRT-08230 with associated crimp pins and housings.</description>
<gates>
<gate name="G$1" symbol="M05" x="-2.54" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1.27MM" package="1X05-1.27MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X05_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X05_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_LONGPADS" package="1X05_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="1X05-1MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD2" package="1X05-1MM-RA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X05_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST" package="JST-5-PTH">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="JST-VERT" package="JST-5-PTH-VERT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SCREW" package="SCREWTERMINAL-3.5MM-5">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="Combine 8288+8399" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M05X2" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 5x2&lt;/b&gt;
Standard 10-pin dual row 0.1" header. Commonly used with AVR-ISP. Use with Spark Fun Electronics SKU: PRT-00778</description>
<gates>
<gate name="G$1" symbol="M05X2" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="10" pad="10"/>
</connects>
<technologies>
</technologies>
</device>
<device name="RA" package="2X5-RA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RAF" package="2X5-RAF">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SHD" package="2X5-SHROUDED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SHD_LOCK" package="2X5-SHROUDED_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SHD_SMD" package="2X5-SHROUDED_SMD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="2X5_NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0.05_IN_PTH_SILK" package="2X5_PTH_SILK_.05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SHD-NS" package="2X5-SHROUDED-NS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M06" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 6&lt;/b&gt;&lt;br&gt;
Standard 6-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115). Molex polarized connector foot print use with SKU : PRT-08094 with associated crimp pins and housings.&lt;p&gt;
NOTES ON THE VARIANTS LOCK and LOCK_LONGPADS...
This footprint was designed to help hold the alignment of a through-hole component (i.e.  6-pin header) while soldering it into place. You may notice that each hole has been shifted either up or down by 0.005 of an inch from it's more standard position (which is a perfectly straight line).  This slight alteration caused the pins (the squares in the middle) to touch the edges of the holes.  Because they are alternating, it causes a "brace" to hold the component in place.  0.005 has proven to be the perfect amount of "off-center" position when using our standard breakaway headers. Although looks a little odd when you look at the bare footprint, once you have a header in there, the alteration is very hard to notice.  Also,if you push a header all the way into place, it is covered up entirely on the bottom side.  This idea of altering the position of holes to aid alignment
will be further integrated into the Sparkfun Library for other footprints.  It can help hold any component with 3 or more connection pins.</description>
<gates>
<gate name="G$1" symbol="M06" x="-2.54" y="0"/>
</gates>
<devices>
<device name="SILK_FEMALE_PTH" package="1X06">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08437"/>
</technology>
</technologies>
</device>
<device name="POLAR" package="MOLEX-1X6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RA" package="MOLEX-1X6-RA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
<attribute name="VALUE" value="RA 6Pin SMD" constant="no"/>
</technology>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X06_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POLAR_LOCK" package="MOLEX-1X6_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SIP_LOCK" package="1X06-SIP_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FEMALE_LOCK" package="1X06_FEMALE_LOCK.010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X06-SMD_EDGE_FEMALE" package="1X06-SMD_EDGE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3.5MM-6" package="SCREWTERMINAL-3.5MM-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMDF" package="1X06-SMD-FEMALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD-FEMALE-V2" package="1X06-SMD-FEMALE-V2">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09668"/>
</technology>
</technologies>
</device>
<device name="POGOPIN_HOLES_ONLY" package="1X06_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="SMD-STRAIGHT-FEMALE" package="1X06_SMD_STRAIGHT">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10203"/>
</technology>
</technologies>
</device>
<device name="SMD-STRAIGHT-ALT-FEMALE" package="1X06_SMD_STRAIGHT_ALT">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="SMD-STRAIGHT-COMBO-FEMALE" package="1X06_SMD_STRAIGHT_COMBO">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="VERNIER-ANALOG" package="BTA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VERNIER-DIGITAL" package="BTD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD_MALE" package="1X06_SMD_MALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11293"/>
</technology>
</technologies>
</device>
<device name="SMD-1MM" package="1X06-1MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK_FEMALE_PTH" package="1X06_NO_SILK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="NO_SILK_YES_STOP" package="1X06_NO_SILK_YES_STOP">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M07" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 7&lt;/b&gt;
Standard 7-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).  NOTES ON THE VARIANTS LOCK and LOCK_LONGPADS... This footprint was designed to help hold the alignment of a through-hole component (i.e. 7-pin header) while soldering it into place. You may notice that each hole has been shifted either up or down by 0.005 of an inch from it's more standard position (which is usually a perfectly straight line). This slight alteration caused the pins (the squares in the middle) to touch the edges of the holes. Because they are alternating, it causes a "brace" to hold the header in place. 0.005 has proven to be the perfect amount of "off-center" position when using our standard breakaway headers. Although looks a little odd when you look at the bare footprint, once you have a header in there, the alteration is very hard to notice. Also, if you push a header all the way into place, it is covered up entirely on the bottom side. This idea of altering the position of holes to aid alignment will be further integrated into the Sparkfun Library for other footprints. It can help hold any component with 3 or more connection pins.</description>
<gates>
<gate name="G$1" symbol="M07" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="1X07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X07_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X07_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X07_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POGOPINS_HOLES_ONLY" package="1X07_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X07_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M08" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 8&lt;/b&gt;
Standard 8-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M08" x="-2.54" y="0"/>
</gates>
<devices>
<device name="SILK_FEMALE_PTH" package="1X08">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08438"/>
</technology>
</technologies>
</device>
<device name="LOCK" package="1X08_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X08_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X08_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3.5MM-8" package="SCREWTERMINAL-3.5MM-8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD-STRAIGHT-FEMALE" package="1X08_SMD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10204"/>
</technology>
</technologies>
</device>
<device name="SMD-STRAIGHT-ALT-FEMALE" package="1X08_SMD_ALT">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="SMD-COMBO-FEMALE" package="1X08_SMD_COMBINED">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="BM08B-SRSS-TB" package="BM08B-SRSS-TB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD-MALE" package="1X08_SMD_MALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11292"/>
</technology>
</technologies>
</device>
<device name="NO_SILK_FEMALE_PTH" package="1X08_NO_SILK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="NO_SILK" package="1X08_PIN1_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="1X08_ROUND">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08437" constant="no"/>
</technology>
</technologies>
</device>
<device name="LOCK_NO_SILK" package="1X08_LOCK_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FEMALE_LOCK" package="1X08_FEMALE_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M08X2" prefix="J" uservalue="yes">
<description>.1" headers, two rows of 8 each</description>
<gates>
<gate name="G$1" symbol="M2X8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X8">
<connects>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M09" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 9&lt;/b&gt;
Standard 9-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M09" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X09">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X09_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK-LONGPADS" package="1X09_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X09_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X09_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M10" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 10&lt;/b&gt;
Standard 10-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M10" x="0" y="7.62"/>
</gates>
<devices>
<device name="SILK_FEMALE_PTH" package="1X10">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11563"/>
</technology>
</technologies>
</device>
<device name="2MM" package="1X10-2MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2MMSMD" package="1X10-2MM-SMD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X10_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X10_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD_COMBO-FEMALE" package="1X10_SMD_COMBINED">
<connects>
<connect gate="G$1" pin="1" pad="1A 1B"/>
<connect gate="G$1" pin="10" pad="10A 10B"/>
<connect gate="G$1" pin="2" pad="2A 2B"/>
<connect gate="G$1" pin="3" pad="3A 3B"/>
<connect gate="G$1" pin="4" pad="4A 4B"/>
<connect gate="G$1" pin="5" pad="5A 5B"/>
<connect gate="G$1" pin="6" pad="6A 6B"/>
<connect gate="G$1" pin="7" pad="7A 7B"/>
<connect gate="G$1" pin="8" pad="8A 8B"/>
<connect gate="G$1" pin="9" pad="9A 9B"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11219"/>
</technology>
</technologies>
</device>
<device name="SMD_MALE" package="1X10_SMD_MALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11291"/>
</technology>
</technologies>
</device>
<device name="NO_SILK_PTH_FEMALE" package="1X10_NO_SILK">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M10X2" prefix="J" uservalue="yes">
<description>This was SPECIALLY designed to be used with our Graphic LCD Backpack.  Be sure you want to use this!  It is not only staggered on each line of header holes, but IT IS ALSO offset of the center point of the top and bottom lines by 5 mil.  This causes the headers to lock into place on the "standard" footprint on the LCD screen.  The extra squares on the tdocu layer are there simply to reference other pins (if you were to actually populate a longer header than ten long - this is what we do with the backpacks).</description>
<gates>
<gate name="G$1" symbol="M10X2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X10">
<connects>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="20" pad="20"/>
</connects>
<technologies>
</technologies>
</device>
<device name="2X10_LOCK" package="2X10_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SPECIAL" package="2X10_LOCK_SPECIAL">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NOSILK" package="2X10_NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ROUND_NOSILK" package="2X10_ROUND_NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M12" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 12&lt;/b&gt;
Standard 12-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M12" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X12_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X12_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MACHINE-PIN_LOCK" package="1X12_MACHINE-PIN-HEADER_LOCK.004">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X12_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="POGOPIN_HOLES_ONLY" package="1X12_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X12_NO_SILK_KIT" package="1X12_NO_SILK_KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X12_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_NO_SILK" package="1X12_LOCK_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M13" prefix="J" uservalue="yes">
<description>13-pin single row .1" header</description>
<gates>
<gate name="G$1" symbol="M13" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X13-LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X13_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_NO_SILK" package="1X13_LOCK_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M14" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 14&lt;/b&gt;
Standard 14-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M14" x="0" y="-2.54"/>
</gates>
<devices>
<device name="" package="1X14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X14_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X14_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X14-LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M15" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 15&lt;/b&gt;
Standard 15-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M15" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X15_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X15_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_NO_SILK" package="1X15_LOCK_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M17" prefix="J" uservalue="yes">
<description>1x17 .1" header</description>
<gates>
<gate name="G$1" symbol="M17" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NOSILK" package="1X17_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="KIT" package="1X17_NO_SILK_KIT">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12294" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M18" prefix="J" uservalue="yes">
<description>1x18 .1" header</description>
<gates>
<gate name="G$1" symbol="M18" x="0" y="0"/>
</gates>
<devices>
<device name="_" package="1X18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M20" prefix="J" uservalue="yes">
<description>1x20 .1" header&lt;br&gt;
This is just like the LOCK variant in that the holes are staggared by 5 mil, but except for the last two holes.  They are not altered from the "standard" footprint layout.  This is used for a special purpose on the layout of our Graphic LCD Backpack.  Make sure you want to use this device before selecting it for you project!</description>
<gates>
<gate name="G$1" symbol="M20" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X20_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X20_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SPECIAL" package="1X20_LOCK_SPECIAL">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK_KIT" package="1X20_NO_SILK_KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_NOSILK" package="1X20_LOCK_NOSILK">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09864" constant="no"/>
</technology>
</technologies>
</device>
<device name="NOSILK" package="1X20_NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M24" prefix="J" uservalue="yes">
<description>1x24 .1" header</description>
<gates>
<gate name="G$1" symbol="M24" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X24">
<connects>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="25" pad="25"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X24_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X24_LOCK">
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M25" prefix="J" uservalue="yes">
<description>1x25 .1" header</description>
<gates>
<gate name="G$1" symbol="M25" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X25_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X25_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_LONGPADS" package="1X25_LONGPAD">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M27" prefix="J" uservalue="yes">
<description>1x27 .1" header</description>
<gates>
<gate name="G$1" symbol="M27" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X27">
<connects>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="27" pad="27"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M29" prefix="J" uservalue="yes">
<description>1x29 .1" header</description>
<gates>
<gate name="G$1" symbol="M29" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X30">
<connects>
<connect gate="G$1" pin="28" pad="28"/>
<connect gate="G$1" pin="29" pad="29"/>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X29_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M30" prefix="J" uservalue="yes">
<description>1x30 .1" header</description>
<gates>
<gate name="G$1" symbol="M30" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="30" pad="30"/>
</connects>
<technologies>
</technologies>
</device>
<device name="NO_SILK" package="1X30_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M40" prefix="J" uservalue="yes">
<description>1x40 .1" header</description>
<gates>
<gate name="G$1" symbol="M40" x="0" y="-50.8"/>
</gates>
<devices>
<device name="OFFSET" package="1X40_OFFSET">
<connects>
<connect gate="G$1" pin="31" pad="31"/>
<connect gate="G$1" pin="32" pad="32"/>
<connect gate="G$1" pin="33" pad="33"/>
<connect gate="G$1" pin="34" pad="34"/>
<connect gate="G$1" pin="35" pad="35"/>
<connect gate="G$1" pin="36" pad="36"/>
<connect gate="G$1" pin="37" pad="37"/>
<connect gate="G$1" pin="38" pad="38"/>
<connect gate="G$1" pin="39" pad="39"/>
<connect gate="G$1" pin="40" pad="40"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="1X40">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MAGJACK" prefix="J">
<description>RJ-45 with LEDs</description>
<gates>
<gate name="G$1" symbol="MAGJACK" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MAGJACK">
<connects>
<connect gate="G$1" pin="GLED+" pad="11"/>
<connect gate="G$1" pin="GLED-" pad="12"/>
<connect gate="G$1" pin="RCT" pad="3"/>
<connect gate="G$1" pin="RD+" pad="1"/>
<connect gate="G$1" pin="RD-" pad="2"/>
<connect gate="G$1" pin="SHIELD@0" pad="M1"/>
<connect gate="G$1" pin="SHIELD@1" pad="M2"/>
<connect gate="G$1" pin="TCT" pad="6"/>
<connect gate="G$1" pin="TD+" pad="7"/>
<connect gate="G$1" pin="TD-" pad="8"/>
<connect gate="G$1" pin="YLED+" pad="9"/>
<connect gate="G$1" pin="YLED-" pad="10"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MAGJACK-2" prefix="J">
<gates>
<gate name="G$1" symbol="MAGJACK-2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MAGJACK-19938">
<connects>
<connect gate="G$1" pin="GLED+" pad="10"/>
<connect gate="G$1" pin="GLED-" pad="9"/>
<connect gate="G$1" pin="RCT" pad="2"/>
<connect gate="G$1" pin="RD-" pad="3"/>
<connect gate="G$1" pin="SHIELD" pad="8"/>
<connect gate="G$1" pin="TCT" pad="5"/>
<connect gate="G$1" pin="TD+" pad="4"/>
<connect gate="G$1" pin="TD-" pad="6"/>
<connect gate="G$1" pin="YLED+" pad="12"/>
<connect gate="G$1" pin="YLED-" pad="11"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MAGJACK-POE" prefix="U">
<description>&lt;h3&gt;PoE compatible MagJack&lt;/h3&gt;</description>
<gates>
<gate name="G$1" symbol="MAGJACK-POE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MAGJACK-POE">
<connects>
<connect gate="G$1" pin="GLED+" pad="13"/>
<connect gate="G$1" pin="GLED-" pad="14"/>
<connect gate="G$1" pin="SHIELD@0" pad="GND0"/>
<connect gate="G$1" pin="SHIELD@1" pad="GND1"/>
<connect gate="G$1" pin="TCT" pad="4"/>
<connect gate="G$1" pin="TD+" pad="5"/>
<connect gate="G$1" pin="V+" pad="9"/>
<connect gate="G$1" pin="V-" pad="10"/>
<connect gate="G$1" pin="YLED+" pad="11"/>
<connect gate="G$1" pin="YLED-" pad="12"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MIDI_CONN_FEMALE_SUPPORT">
<description>MIDI connector with strain relief (DIN-5 female)</description>
<gates>
<gate name="G$1" symbol="MIDI_CONN_FEMALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIN_5_FEMALE_SUPPORT">
<connects>
<connect gate="G$1" pin="CSNK" pad="5"/>
<connect gate="G$1" pin="CSRC" pad="4"/>
<connect gate="G$1" pin="NC1" pad="3"/>
<connect gate="G$1" pin="NC3" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MIDI_CONN_FEMALE">
<description>MIDI connector, no strain relieve (DIN-5 female)</description>
<gates>
</gates>
<devices>
<device name="" package="DIN_5_FEMALE">
<connects>
<connect gate="G$1" pin="CSNK" pad="4"/>
<connect gate="G$1" pin="CSRC" pad="5"/>
<connect gate="G$1" pin="GND" pad="3"/>
<connect gate="G$1" pin="NC1" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MINI-DIN6">
<description>&lt;b&gt;mini DIN 6 Connector&lt;/b&gt;
Commonly found on the back of a computer for PS2 keyboard and mice. Schematic and footprint are proven. Spark Fun Electronics SKU : PRT-08509</description>
<gates>
</gates>
<devices>
<device name="PTH" package="MINI-DIN6">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MMA_ACCEL_CONNECTOR">
<gates>
<gate name="G$1" symbol="MMA_CON" x="2.54" y="-2.54"/>
</gates>
<devices>
<device name="" package="1X08">
<connects>
<connect gate="G$1" pin="GND" pad="2"/>
<connect gate="G$1" pin="GS1" pad="6"/>
<connect gate="G$1" pin="GS2" pad="7"/>
<connect gate="G$1" pin="SLP" pad="8"/>
<connect gate="G$1" pin="VCC" pad="1"/>
<connect gate="G$1" pin="X" pad="3"/>
<connect gate="G$1" pin="Y" pad="4"/>
<connect gate="G$1" pin="Z" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="OBDII">
<description>OBDII connector footprint</description>
<gates>
<gate name="G$1" symbol="OBDII" x="0" y="0"/>
</gates>
<devices>
<device name="" package="OBDII">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="BATTPOWER" pad="16"/>
<connect gate="G$1" pin="CANHIGH" pad="6"/>
<connect gate="G$1" pin="CANLOW" pad="14"/>
<connect gate="G$1" pin="CHASGND" pad="4"/>
<connect gate="G$1" pin="ISOK-LINE" pad="7"/>
<connect gate="G$1" pin="ISOL-LINE" pad="15"/>
<connect gate="G$1" pin="J1850BUS" pad="10"/>
<connect gate="G$1" pin="J1850BUS+" pad="2"/>
<connect gate="G$1" pin="SIGGND" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PIC-ICSP">
<description>ISCP Programming connector for UAV, UBW Kit, etc.</description>
<gates>
<gate name="G$1" symbol="ICSP-PIC" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="MOLEX-1X6">
<connects>
<connect gate="G$1" pin="GND" pad="4"/>
<connect gate="G$1" pin="PGC" pad="2"/>
<connect gate="G$1" pin="PGD" pad="3"/>
<connect gate="G$1" pin="PGM" pad="1"/>
<connect gate="G$1" pin="VPP" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PIC-ICSP-MINI">
<description>&lt;b&gt;PIC-ICSP-Mini&lt;/b&gt;
Miniature 5-pin connection for temporary programming of PICs. Use this device in your design to save space. Program the PIC with this adapter Spark Fun Electronics SKU : BOB-00194</description>
<gates>
<gate name="G$1" symbol="PIC-ISCP-MINI" x="0" y="0"/>
</gates>
<devices>
<device name="" package="PIC-ICSP-MINI">
<connects>
<connect gate="G$1" pin="PGC" pad="5"/>
<connect gate="G$1" pin="PGD" pad="4"/>
<connect gate="G$1" pin="VPP" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINH2X12">
<gates>
<gate name="G$1" symbol="PINH2X12" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X12">
<connects>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X3" prefix="J" uservalue="yes">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="PINH2X3" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X03">
<connects>
<connect gate="A" pin="1" pad="1"/>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X10" prefix="J" uservalue="yes">
<gates>
<gate name="A" symbol="PINH2X10" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="10" pad="10"/>
<connect gate="A" pin="11" pad="11"/>
<connect gate="A" pin="12" pad="12"/>
<connect gate="A" pin="13" pad="13"/>
<connect gate="A" pin="14" pad="14"/>
<connect gate="A" pin="15" pad="15"/>
<connect gate="A" pin="16" pad="16"/>
<connect gate="A" pin="17" pad="17"/>
<connect gate="A" pin="18" pad="18"/>
<connect gate="A" pin="19" pad="19"/>
<connect gate="A" pin="20" pad="20"/>
<connect gate="A" pin="7" pad="7"/>
<connect gate="A" pin="8" pad="8"/>
<connect gate="A" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PINHD-2X26">
<gates>
<gate name="G$1" symbol="PINH2X26" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X26">
<connects>
<connect gate="G$1" pin="41" pad="41"/>
<connect gate="G$1" pin="42" pad="42"/>
<connect gate="G$1" pin="43" pad="43"/>
<connect gate="G$1" pin="44" pad="44"/>
<connect gate="G$1" pin="45" pad="45"/>
<connect gate="G$1" pin="46" pad="46"/>
<connect gate="G$1" pin="47" pad="47"/>
<connect gate="G$1" pin="48" pad="48"/>
<connect gate="G$1" pin="49" pad="49"/>
<connect gate="G$1" pin="50" pad="50"/>
<connect gate="G$1" pin="51" pad="51"/>
<connect gate="G$1" pin="52" pad="52"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="POWER_JACK" prefix="J">
<description>&lt;b&gt;Power Jack&lt;/b&gt;
This is the standard 5.5mm barrel jack for power.&lt;br&gt;
The PTH is the most common, proven, reliable, footprint.&lt;br&gt;
The Slot footprint only works if the mill layer is transmitted to the PCB fab house so be warned.&lt;br&gt;
Mating wall wart : TOL-00298 (and others)</description>
<gates>
<gate name="G$1" symbol="POWERJACK" x="7.62" y="-2.54"/>
</gates>
<devices>
<device name="SMD" package="POWER_JACK_SMD">
<connects>
<connect gate="G$1" pin="GND" pad="P$4"/>
<connect gate="G$1" pin="GNDBREAK" pad="GND"/>
<connect gate="G$1" pin="PWR" pad="VIN0"/>
</connects>
<technologies>
<technology name="">
<attribute name="PROD_ID" value="CONN-08106"/>
<attribute name="SF_ID" value="PRT-12748" constant="no"/>
<attribute name="VALUE" value="5.5x2.1mm Barrel" constant="no"/>
</technology>
</technologies>
</device>
<device name="SLT" package="POWER_JACK_SLOT">
<connects>
<connect gate="G$1" pin="GND" pad="GND@2"/>
<connect gate="G$1" pin="GNDBREAK" pad="GND@1"/>
<connect gate="G$1" pin="PWR" pad="PWR"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="PRT-00119" constant="no"/>
</technology>
</technologies>
</device>
<device name="PTH" package="POWER_JACK_PTH">
<connects>
<connect gate="G$1" pin="GND" pad="GND"/>
<connect gate="G$1" pin="GNDBREAK" pad="GNDBREAK"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08197"/>
</technology>
</technologies>
</device>
<device name="COMBO" package="POWER_JACK_COMBO">
<connects>
<connect gate="G$1" pin="GND" pad="GND@1"/>
<connect gate="G$1" pin="PWR" pad="POWER"/>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_LOCK" package="POWER_JACK_PTH_LOCK">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08197" constant="no"/>
<attribute name="SF_ID" value="PRT-00119" constant="no"/>
</technology>
</technologies>
</device>
<device name="1" package="POWER_JACK_SMD_OVERPASTE_REDBOARD_0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOE" package="POWER_JACK_SMD_OVERPASTE_TOE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08106" constant="no"/>
</technology>
</technologies>
</device>
<device name="PTH_BREAD" package="POWER_JACK_PTH_BREAD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="PRT-10811" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PSP_CONNECTOR">
<description>Connector for LCD-08335</description>
<gates>
<gate name="G$1" symbol="PSP_CONNECTOR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="PSP_CONNECTOR">
<connects>
<connect gate="G$1" pin="AVDD" pad="AVDD"/>
<connect gate="G$1" pin="AVDD2" pad="AVDD2"/>
<connect gate="G$1" pin="B0" pad="B0"/>
<connect gate="G$1" pin="B1" pad="B1"/>
<connect gate="G$1" pin="B2" pad="B2"/>
<connect gate="G$1" pin="B3" pad="B3"/>
<connect gate="G$1" pin="B4" pad="B4"/>
<connect gate="G$1" pin="B5" pad="B5"/>
<connect gate="G$1" pin="B6" pad="B6"/>
<connect gate="G$1" pin="B7" pad="B7"/>
<connect gate="G$1" pin="CK" pad="CK"/>
<connect gate="G$1" pin="DISP" pad="DISP"/>
<connect gate="G$1" pin="G0" pad="G0"/>
<connect gate="G$1" pin="G1" pad="G1"/>
<connect gate="G$1" pin="G2" pad="G2"/>
<connect gate="G$1" pin="G3" pad="G3"/>
<connect gate="G$1" pin="G4" pad="G4"/>
<connect gate="G$1" pin="G5" pad="G5"/>
<connect gate="G$1" pin="G6" pad="G6"/>
<connect gate="G$1" pin="G7" pad="G7"/>
<connect gate="G$1" pin="GND2" pad="GND2"/>
<connect gate="G$1" pin="GND3" pad="GND3"/>
<connect gate="G$1" pin="HSYNC" pad="HSYNC"/>
<connect gate="G$1" pin="NC" pad="NC"/>
<connect gate="G$1" pin="NC2" pad="NC2"/>
<connect gate="G$1" pin="R0" pad="R0"/>
<connect gate="G$1" pin="R1" pad="R1"/>
<connect gate="G$1" pin="R2" pad="R2"/>
<connect gate="G$1" pin="R3" pad="R3"/>
<connect gate="G$1" pin="R4" pad="R4"/>
<connect gate="G$1" pin="R5" pad="R5"/>
<connect gate="G$1" pin="R6" pad="R6"/>
<connect gate="G$1" pin="R7" pad="R7"/>
<connect gate="G$1" pin="TEST1" pad="TEST1"/>
<connect gate="G$1" pin="TEST2" pad="TEST2"/>
<connect gate="G$1" pin="TEST3" pad="TEST3"/>
<connect gate="G$1" pin="VCC" pad="VCC"/>
<connect gate="G$1" pin="VCC2" pad="VCC2"/>
<connect gate="G$1" pin="VSYNC" pad="VSYNC"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PSP_TOUCH_CONNECTOR">
<description>4-Pin Connector for PSP Touch Screen (LCD-08448)</description>
<gates>
<gate name="G$1" symbol="PSP_TOUCH_CONNECTOR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="PSP_TOUCH_CONNECTOR">
<connects>
<connect gate="G$1" pin="X1" pad="X1"/>
<connect gate="G$1" pin="X2" pad="X2"/>
<connect gate="G$1" pin="Y1" pad="Y1"/>
<connect gate="G$1" pin="Y2" pad="Y2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RJ9">
<description>RJ9 connector (e.g., phone handsets)</description>
<gates>
<gate name="G$1" symbol="M04-1" x="2.54" y="0"/>
</gates>
<devices>
<device name="PTH" package="RJ9">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RJ11-6" prefix="J">
<description>&lt;b&gt;RJ11 Jack&lt;/b&gt;
Simple 6 pin RJ11 jack. Commonly found on CAT3 devices and Microchip programmers. SKU: PRT-00132</description>
<gates>
</gates>
<devices>
<device name="PTH" package="RJ11-6">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08590" constant="no"/>
<attribute name="VALUE" value="RJ11" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RJ45-8" prefix="J">
<description>&lt;b&gt;RJ45 Jack&lt;/b&gt;
Simple RJ45, 8-pin connection - connector for common Cat5, Cat5e, and Cat6 Ethernet cables. Footprint not yet proven in production. Connector sku is PRT-00643; Breakout PCB sku is BOB-00716.</description>
<gates>
<gate name="JP1" symbol="RJ45-8" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="RJ45-8">
<connects>
<connect gate="JP1" pin="1" pad="1"/>
<connect gate="JP1" pin="2" pad="2"/>
<connect gate="JP1" pin="3" pad="3"/>
<connect gate="JP1" pin="4" pad="4"/>
<connect gate="JP1" pin="5" pad="5"/>
<connect gate="JP1" pin="6" pad="6"/>
<connect gate="JP1" pin="7" pad="7"/>
<connect gate="JP1" pin="8" pad="8"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08506" constant="no"/>
<attribute name="VALUE" value="RJ45" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SCREENKEYMATINGCONNECTOR">
<description>ScreenKey mating connector- PRT-09586</description>
<gates>
<gate name="G$1" symbol="SCREENKEYMATINGCONNECTOR" x="-10.16" y="-10.16"/>
</gates>
<devices>
<device name="" package="SCREENKEYMATINGCONNECTOR">
<connects>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SIMHOLDER" prefix="J" uservalue="yes">
<description>&lt;b&gt;SIM Socket&lt;/b&gt;
Socket for SIM cellular cards. Schematic element and footprint production proven. Spark Fun Electronics SKU : PRT-00548</description>
<gates>
<gate name="J1" symbol="SIMHOLDER" x="0" y="0"/>
</gates>
<devices>
<device name="SIM" package="SIMHOLDER">
<connects>
<connect gate="J1" pin="CLK" pad="C3"/>
<connect gate="J1" pin="GND" pad="C5"/>
<connect gate="J1" pin="I/O" pad="C7"/>
<connect gate="J1" pin="RST" pad="C2"/>
<connect gate="J1" pin="VCC" pad="C1"/>
<connect gate="J1" pin="VPP" pad="C6"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08536" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SMARTCARD" prefix="J">
<description>Smart card socket- PRT-09368</description>
<gates>
<gate name="G$1" symbol="SMARTCARD" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="SMARTCARD">
<connects>
<connect gate="G$1" pin="C4" pad="C4"/>
<connect gate="G$1" pin="C8" pad="C8"/>
<connect gate="G$1" pin="CLK" pad="C3"/>
<connect gate="G$1" pin="GND" pad="C5"/>
<connect gate="G$1" pin="I/O" pad="C7"/>
<connect gate="G$1" pin="RST" pad="C2"/>
<connect gate="G$1" pin="SW1" pad="P1"/>
<connect gate="G$1" pin="SW2" pad="P2"/>
<connect gate="G$1" pin="VCC" pad="C1"/>
<connect gate="G$1" pin="VPP" pad="C6"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SMA_EDGE" prefix="J$">
<description>&lt;b&gt;SMA Antenna Connector&lt;/b&gt;
End launch SMA connector. The paste layer has been removed so that the connector can be hand soldered onto the board after reflow.</description>
<gates>
<gate name="1" symbol="SMA_EDGE" x="-2.54" y="7.62"/>
</gates>
<devices>
<device name="" package="SMA-EDGE">
<connects>
<connect gate="1" pin="GND@0" pad="GND@0"/>
<connect gate="1" pin="GND@1" pad="GND@1"/>
<connect gate="1" pin="GND@2" pad="GND@2"/>
<connect gate="1" pin="GND@3" pad="GND@3"/>
<connect gate="1" pin="SIGNAL" pad="SIG"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="STARBOARD_GND" prefix="J" uservalue="yes">
<description>&lt;h3&gt;StarBoard ground Pad&lt;/h3&gt;
Starboard pads sans the star cutout in top layer</description>
<gates>
<gate name="G$1" symbol="STARBOARD_PAD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="STARBOARD_GROUND">
<connects>
<connect gate="G$1" pin="MOUNT" pad="GROUND"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-SMALL" package="STARBOARD_GROUND_SMALL">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-WIDE" package="STARBOARD_GROUND_WIDE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-SMALL2" package="STARBOARD_GROUND_SMALL2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="STARBOARD_PWR" prefix="J" uservalue="yes">
<description>&lt;h3&gt;StarbBoard Power pad&lt;/h3&gt;
Power pads are designated by the star cutout in the top layer.</description>
<gates>
<gate name="G$1" symbol="STARBOARD_PAD+" x="0" y="0"/>
</gates>
<devices>
<device name="-WIDE" package="STARBOARD_PWR_WIDE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-TALL" package="STARBOARD_PWR">
<connects>
<connect gate="G$1" pin="MOUNT" pad="PWR"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TOUCH-SCREEN">
<description>Nintendo DS touch screen connector LCD-09105</description>
<gates>
<gate name="G$1" symbol="TOUCH-SCREEN" x="0" y="-10.16"/>
</gates>
<devices>
<device name="" package="TOUCH-SCREEN">
<connects>
<connect gate="G$1" pin="TS1" pad="P$4"/>
<connect gate="G$1" pin="TS2" pad="P$3"/>
<connect gate="G$1" pin="TS3" pad="P$2"/>
<connect gate="G$1" pin="TS4" pad="P$1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="U.FL" prefix="J" uservalue="yes">
<description>SMD antenna connector- WRL-09144</description>
<gates>
<gate name="G$1" symbol="U.FL" x="0" y="0"/>
</gates>
<devices>
<device name="" package="U.FL">
<connects>
<connect gate="G$1" pin="GND@0" pad="P$1"/>
<connect gate="G$1" pin="GND@1" pad="P$2"/>
<connect gate="G$1" pin="SIGNAL" pad="P$3"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09193"/>
<attribute name="VALUE" value="U.FL"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB" prefix="J">
<description>&lt;b&gt;USB Connectors&lt;/b&gt;
&lt;p&gt;USB-B-PTH is fully proven SKU : PRT-00139/CONN-08278
&lt;p&gt;USB-miniB is fully proven SKU : PRT-00587
&lt;p&gt;USB-A-PCB is untested.
&lt;p&gt;USB-A-H is throughly reviewed, but untested. Spark Fun Electronics SKU : PRT-00437
&lt;p&gt;USB-B-SMT is throughly reviewed, but untested. Needs silkscreen touching up.
&lt;p&gt;USB-A-S has not been used/tested
&lt;p&gt;USB-MB-H has not been used/tested
&lt;P&gt;USB-MICROB has been used. CONN-09505</description>
<gates>
<gate name="G$1" symbol="USB" x="0" y="0"/>
</gates>
<devices>
<device name="-A-H" package="USB-A-H">
<connects>
<connect gate="G$1" pin="D+" pad="D+"/>
<connect gate="G$1" pin="D-" pad="D-"/>
<connect gate="G$1" pin="VBUS" pad="VBUS"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08367"/>
</technology>
</technologies>
</device>
<device name="-A-S" package="USB-A-S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-MB-H" package="USB-MB-H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-B-S" package="USB-B-SMT">
<connects>
<connect gate="G$1" pin="VBUS" pad="VUSB"/>
</connects>
<technologies>
</technologies>
</device>
<device name="OLD" package="USB-MINIB-OLD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH" package="USB-B-PTH">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08278" constant="no"/>
<attribute name="VALUE" value="USB-B" constant="no"/>
</technology>
</technologies>
</device>
<device name="-JST-2MM-SMT" package="S4B-PH">
<connects>
<connect gate="G$1" pin="D+" pad="2"/>
<connect gate="G$1" pin="D-" pad="3"/>
<connect gate="G$1" pin="GND" pad="1"/>
<connect gate="G$1" pin="VBUS" pad="4"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08193" constant="no"/>
</technology>
</technologies>
</device>
<device name="SMD" package="USB-MINIB">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
<device name="PCB" package="USB-A-PCB">
<connects>
<connect gate="G$1" pin="D+" pad="USB_P"/>
<connect gate="G$1" pin="D-" pad="USB_M"/>
<connect gate="G$1" pin="VBUS" pad="5V"/>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH-VERTICAL" package="USB-B-PTH-VERTICAL">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="USB-A-S-NOSILK" package="USB-A-S-NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-A-SMD" package="USB-A-S-NOSILK-FEMALE">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09520"/>
</technology>
</technologies>
</device>
<device name="-SMD-NS" package="USB-MINIB-NOSTOP">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="_" package="USB-A-S-SILK-FEMALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-MICROB" package="USB-MICROB">
<connects>
<connect gate="G$1" pin="GND" pad="GND MT1 MT2"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09505"/>
</technology>
</technologies>
</device>
<device name="A-SMD-MALE" package="USB-A-SMT-MALE">
<connects>
<connect gate="G$1" pin="D+" pad="D+1"/>
<connect gate="G$1" pin="D-" pad="D-1"/>
<connect gate="G$1" pin="GND" pad="GND1"/>
<connect gate="G$1" pin="VBUS" pad="VBUS1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="A-SMD-MALE-LOCKING" package="USB-A-SMT-MALE-LOCKING">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PCB_NOPASTE" package="USB-A-PCB-NOPASTE">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB+SHIELD">
<description>&lt;h3&gt;USB+Shield&lt;/h3&gt;
USB connector with shield pins connectable</description>
<gates>
<gate name="G$1" symbol="USB+SHIELD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="USB-B-PTH">
<connects>
<connect gate="G$1" pin="S1" pad="S1"/>
<connect gate="G$1" pin="S2" pad="S2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="USB-A-S-NOSILK-FEMALE" package="USB-A-S-NOSILK-FEMALE">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB-MINIB" prefix="J">
<description>&lt;b&gt;Mini-USB "B" connector with 5th pin broken out.&lt;/b&gt;&lt;p&gt;
Created new symbol breaking out 5th "ID" pin in mini/micro USB connector spec.  See: http://en.wikipedia.org/wiki/Mini_usb#Cables.  Uses same footprint as 4-pin symbol.&lt;p&gt;
Also added pins to connect to mounting / shield pads if required (probably not generally needed as signals aren't shielded once they leave the connector).</description>
<gates>
<gate name="G$1" symbol="USB-5PIN" x="0" y="0"/>
</gates>
<devices>
<device name="-5PIN" package="USB-MINIB">
<connects>
<connect gate="G$1" pin="ID" pad="ID"/>
<connect gate="G$1" pin="MTN1" pad="MTN3"/>
<connect gate="G$1" pin="MTN2" pad="MTN1"/>
<connect gate="G$1" pin="MTN3" pad="MTN2"/>
<connect gate="G$1" pin="MTN4" pad="MTN4"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08193"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB_MICROB_PLUG" prefix="J" uservalue="yes">
<description>USB Micro-B connectors&lt;br&gt;
Some male, some female. Watch your step!</description>
<gates>
<gate name="G$1" symbol="MICROB-PLUG" x="7.62" y="0"/>
</gates>
<devices>
<device name="&quot;" package="MICRO-B-RA-SMT">
<connects>
<connect gate="G$1" pin="D+" pad="3"/>
<connect gate="G$1" pin="D-" pad="2"/>
<connect gate="G$1" pin="GND" pad="5"/>
<connect gate="G$1" pin="ID" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-PTH" package="MICRO-B-RA-TH">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-PTH2" package="MICRO-B-TH">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-SMT" package="MICRO-B-SMT">
<connects>
<connect gate="G$1" pin="SHIELD" pad="P$6"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09900"/>
</technology>
</technologies>
</device>
<device name="CONN-11752" package="USB-B-MICRO-SMD_V03">
<connects>
<connect gate="G$1" pin="SHIELD" pad="SHIELD1 SHIELD2 SHIELD3"/>
<connect gate="G$1" pin="VCC" pad="VBUS"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11752" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USD-SOCKET" prefix="JP">
<description>&lt;b&gt;microSD Socket&lt;/b&gt;
Push-push type uSD socket. Schematic element and footprint production proven. Spark Fun Electronics SKU : PRT-00127. tDoc lines correctly indicate media card edge positions when inserting (unlocked, locked, depressed).
NOTE: CD1 and CD2 are connected internally</description>
<gates>
<gate name="G$1" symbol="USDCARD" x="0" y="0"/>
</gates>
<devices>
<device name="USD" package="USD-SOCKET-PP">
<connects>
<connect gate="G$1" pin="CD1" pad="CD2"/>
<connect gate="G$1" pin="CD2" pad="GND2"/>
<connect gate="G$1" pin="CS" pad="2"/>
<connect gate="G$1" pin="DI" pad="3"/>
<connect gate="G$1" pin="DO" pad="7"/>
<connect gate="G$1" pin="GND" pad="6"/>
<connect gate="G$1" pin="NC" pad="1"/>
<connect gate="G$1" pin="RSV" pad="8"/>
<connect gate="G$1" pin="SCK" pad="5"/>
<connect gate="G$1" pin="SHIELD@1" pad="CD1"/>
<connect gate="G$1" pin="SHIELD@3" pad="GND1"/>
<connect gate="G$1" pin="VCC" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="NEW" package="MICRO-SD-SOCKET-PP">
<connects>
<connect gate="G$1" pin="CD1" pad="CD1"/>
<connect gate="G$1" pin="CD2" pad="CD2"/>
<connect gate="G$1" pin="CS" pad="CS"/>
<connect gate="G$1" pin="DI" pad="DI"/>
<connect gate="G$1" pin="DO" pad="DO"/>
<connect gate="G$1" pin="NC" pad="RSV1"/>
<connect gate="G$1" pin="RSV" pad="RSV2"/>
<connect gate="G$1" pin="SCK" pad="SCLK"/>
<connect gate="G$1" pin="SHIELD@1" pad="GND3"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-07820" constant="no"/>
</technology>
</technologies>
</device>
<device name="" package="MICROSD_1:1">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-07820"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="WATN001002BF" prefix="U">
<description>connector for 10x2 16-segment E-paper Display (LCD-10150)&lt;br&gt;
&lt;b&gt;***Unproven!!!***&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="WATN001001" x="0" y="0"/>
</gates>
<devices>
<device name="" package="FFC26">
<connects>
<connect gate="G$1" pin="DI0" pad="16"/>
<connect gate="G$1" pin="DI1" pad="17"/>
<connect gate="G$1" pin="DI2" pad="18"/>
<connect gate="G$1" pin="DLY0" pad="13"/>
<connect gate="G$1" pin="DLY1" pad="14"/>
<connect gate="G$1" pin="EIO1" pad="6"/>
<connect gate="G$1" pin="EIO2" pad="20"/>
<connect gate="G$1" pin="LATCH" pad="9"/>
<connect gate="G$1" pin="RESERVED@1" pad="10"/>
<connect gate="G$1" pin="RESERVED@2" pad="15"/>
<connect gate="G$1" pin="RESERVED@3" pad="19"/>
<connect gate="G$1" pin="RESERVED@4" pad="26"/>
<connect gate="G$1" pin="SHL" pad="11"/>
<connect gate="G$1" pin="SLEEPB" pad="12"/>
<connect gate="G$1" pin="V0@1" pad="1"/>
<connect gate="G$1" pin="V0@2" pad="25"/>
<connect gate="G$1" pin="V1@1" pad="2"/>
<connect gate="G$1" pin="V1@2" pad="24"/>
<connect gate="G$1" pin="V2@1" pad="3"/>
<connect gate="G$1" pin="V2@2" pad="23"/>
<connect gate="G$1" pin="VDD" pad="8"/>
<connect gate="G$1" pin="VSS@1" pad="5"/>
<connect gate="G$1" pin="VSS@2" pad="21"/>
<connect gate="G$1" pin="VSSE@1" pad="4"/>
<connect gate="G$1" pin="VSSE@2" pad="22"/>
<connect gate="G$1" pin="XCK" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="XLR3_NCFAH2" prefix="XLR">
<description>XLR connector</description>
<gates>
<gate name="G$1" symbol="XLR3_NCFAH2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="XLR3_NC3FAH2">
<connects>
<connect gate="G$1" pin="G" pad="G"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZIFSOCKET-28-3">
<description>Lever-action ZIF socket for 28-pin ICs</description>
<gates>
<gate name="G$1" symbol="DIL-28-3" x="-10.16" y="-38.1"/>
</gates>
<devices>
<device name="ZIFFSOCKET-28-3" package="DIL28-3-ZIF_SOCKET">
<connects>
<connect gate="G$1" pin="P$1" pad="1"/>
<connect gate="G$1" pin="P$10" pad="10"/>
<connect gate="G$1" pin="P$11" pad="11"/>
<connect gate="G$1" pin="P$12" pad="12"/>
<connect gate="G$1" pin="P$13" pad="13"/>
<connect gate="G$1" pin="P$14" pad="14"/>
<connect gate="G$1" pin="P$15" pad="15"/>
<connect gate="G$1" pin="P$16" pad="16"/>
<connect gate="G$1" pin="P$17" pad="17"/>
<connect gate="G$1" pin="P$18" pad="18"/>
<connect gate="G$1" pin="P$19" pad="19"/>
<connect gate="G$1" pin="P$2" pad="2"/>
<connect gate="G$1" pin="P$20" pad="20"/>
<connect gate="G$1" pin="P$21" pad="21"/>
<connect gate="G$1" pin="P$22" pad="22"/>
<connect gate="G$1" pin="P$23" pad="23"/>
<connect gate="G$1" pin="P$24" pad="24"/>
<connect gate="G$1" pin="P$25" pad="25"/>
<connect gate="G$1" pin="P$26" pad="26"/>
<connect gate="G$1" pin="P$27" pad="27"/>
<connect gate="G$1" pin="P$28" pad="28"/>
<connect gate="G$1" pin="P$3" pad="3"/>
<connect gate="G$1" pin="P$4" pad="4"/>
<connect gate="G$1" pin="P$5" pad="5"/>
<connect gate="G$1" pin="P$6" pad="6"/>
<connect gate="G$1" pin="P$7" pad="7"/>
<connect gate="G$1" pin="P$8" pad="8"/>
<connect gate="G$1" pin="P$9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZIFSOCKET-40-6">
<description>Lever-action ZIF socket for 40-pin ICs</description>
<gates>
<gate name="G$1" symbol="DIL-40-6" x="0" y="0"/>
</gates>
<devices>
<device name="DIL40-6-ZIF_SOCKET" package="DIL40-6-ZIF_SOCKET">
<connects>
<connect gate="G$1" pin="P$29" pad="29"/>
<connect gate="G$1" pin="P$30" pad="30"/>
<connect gate="G$1" pin="P$31" pad="31"/>
<connect gate="G$1" pin="P$32" pad="32"/>
<connect gate="G$1" pin="P$33" pad="33"/>
<connect gate="G$1" pin="P$34" pad="34"/>
<connect gate="G$1" pin="P$35" pad="35"/>
<connect gate="G$1" pin="P$36" pad="36"/>
<connect gate="G$1" pin="P$37" pad="37"/>
<connect gate="G$1" pin="P$38" pad="38"/>
<connect gate="G$1" pin="P$39" pad="39"/>
<connect gate="G$1" pin="P$40" pad="40"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZUNE_CONNECTOR_MALE">
<description>Male connector for the Zune media player.  UNPROVEN FOOTPRINT!  This connector must be used only with a 1.2mm PCB thickness.</description>
<gates>
<gate name="G$1" symbol="ZUNE_CONNECTOR_MALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ZUNE_CONNECTOR_MALE">
<connects>
<connect gate="G$1" pin="10" pad="P$10"/>
<connect gate="G$1" pin="11" pad="P$11"/>
<connect gate="G$1" pin="12" pad="P$12"/>
<connect gate="G$1" pin="15" pad="P$15"/>
<connect gate="G$1" pin="16" pad="P$16"/>
<connect gate="G$1" pin="17" pad="P$17"/>
<connect gate="G$1" pin="18" pad="P$18"/>
<connect gate="G$1" pin="4" pad="P$4"/>
<connect gate="G$1" pin="5" pad="P$5"/>
<connect gate="G$1" pin="6" pad="P$6"/>
<connect gate="G$1" pin="7" pad="P$7"/>
<connect gate="G$1" pin="8" pad="P$8"/>
<connect gate="G$1" pin="AUDIO_L" pad="P$13"/>
<connect gate="G$1" pin="AUDIO_R" pad="P$14"/>
<connect gate="G$1" pin="GND@19" pad="P$19"/>
<connect gate="G$1" pin="GND@22" pad="P$22"/>
<connect gate="G$1" pin="GND@23" pad="P$23"/>
<connect gate="G$1" pin="GND@24" pad="P$24"/>
<connect gate="G$1" pin="USB_5V@1" pad="P$1"/>
<connect gate="G$1" pin="USB_5V@2" pad="P$2"/>
<connect gate="G$1" pin="USB_5V@3" pad="P$3"/>
<connect gate="G$1" pin="USB_DATA+" pad="P$21"/>
<connect gate="G$1" pin="USB_DATA-" pad="P$20"/>
<connect gate="G$1" pin="VIDEO+" pad="P$9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="50-PIN-CENTRONICS-F">
<gates>
<gate name="G$1" symbol="50-PIN-CENTRONICS" x="-7.62" y="-60.96"/>
</gates>
<devices>
<device name="FEMALE" package="50-PIN-CENTRONICS-F">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$10" pad="P$10"/>
<connect gate="G$1" pin="P$11" pad="P$11"/>
<connect gate="G$1" pin="P$12" pad="P$12"/>
<connect gate="G$1" pin="P$13" pad="P$13"/>
<connect gate="G$1" pin="P$14" pad="P$14"/>
<connect gate="G$1" pin="P$15" pad="P$15"/>
<connect gate="G$1" pin="P$16" pad="P$16"/>
<connect gate="G$1" pin="P$17" pad="P$17"/>
<connect gate="G$1" pin="P$18" pad="P$18"/>
<connect gate="G$1" pin="P$19" pad="P$19"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$20" pad="P$20"/>
<connect gate="G$1" pin="P$21" pad="P$21"/>
<connect gate="G$1" pin="P$22" pad="P$22"/>
<connect gate="G$1" pin="P$23" pad="P$23"/>
<connect gate="G$1" pin="P$24" pad="P$24"/>
<connect gate="G$1" pin="P$25" pad="P$25"/>
<connect gate="G$1" pin="P$26" pad="P$26"/>
<connect gate="G$1" pin="P$27" pad="P$27"/>
<connect gate="G$1" pin="P$28" pad="P$28"/>
<connect gate="G$1" pin="P$29" pad="P$29"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
<connect gate="G$1" pin="P$30" pad="P$30"/>
<connect gate="G$1" pin="P$31" pad="P$31"/>
<connect gate="G$1" pin="P$32" pad="P$32"/>
<connect gate="G$1" pin="P$33" pad="P$33"/>
<connect gate="G$1" pin="P$34" pad="P$34"/>
<connect gate="G$1" pin="P$35" pad="P$35"/>
<connect gate="G$1" pin="P$36" pad="P$36"/>
<connect gate="G$1" pin="P$37" pad="P$37"/>
<connect gate="G$1" pin="P$38" pad="P$38"/>
<connect gate="G$1" pin="P$39" pad="P$39"/>
<connect gate="G$1" pin="P$4" pad="P$4"/>
<connect gate="G$1" pin="P$40" pad="P$40"/>
<connect gate="G$1" pin="P$41" pad="P$41"/>
<connect gate="G$1" pin="P$42" pad="P$42"/>
<connect gate="G$1" pin="P$43" pad="P$43"/>
<connect gate="G$1" pin="P$44" pad="P$44"/>
<connect gate="G$1" pin="P$45" pad="P$45"/>
<connect gate="G$1" pin="P$46" pad="P$46"/>
<connect gate="G$1" pin="P$47" pad="P$47"/>
<connect gate="G$1" pin="P$48" pad="P$48"/>
<connect gate="G$1" pin="P$49" pad="P$49"/>
<connect gate="G$1" pin="P$5" pad="P$5"/>
<connect gate="G$1" pin="P$50" pad="P$50"/>
<connect gate="G$1" pin="P$6" pad="P$6"/>
<connect gate="G$1" pin="P$7" pad="P$7"/>
<connect gate="G$1" pin="P$8" pad="P$8"/>
<connect gate="G$1" pin="P$9" pad="P$9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="50-PIN-CENTRONICS-M">
<gates>
<gate name="G$1" symbol="50-PIN-CENTRONICS" x="-7.62" y="-58.42"/>
</gates>
<devices>
<device name="MALE" package="50-PIN-CENTRONICS-M">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RCA" prefix="J">
<gates>
<gate name="G$1" symbol="RCA" x="0" y="0"/>
</gates>
<devices>
<device name="" package="RCA">
<connects>
<connect gate="G$1" pin="PIN" pad="PIN"/>
<connect gate="G$1" pin="SHELL" pad="SHELL"/>
<connect gate="G$1" pin="SWITCH" pad="SWITCH"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-LOCK" package="RCA_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M16" prefix="J" uservalue="yes">
<description>1x16 .1" header</description>
<gates>
<gate name="G$1" symbol="M16" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X16">
<connects>
<connect gate="G$1" pin="10" pad="10"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X16_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X16_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MACHIINE-PIN_LOCK" package="1X16_MACHINE-PIN-HEADER_LOCK.004">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X16_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X16_NO_SILK" package="1X16_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M19" prefix="J" uservalue="yes">
<description>1x19 .1" header</description>
<gates>
<gate name="G$1" symbol="M19" x="0" y="0"/>
</gates>
<devices>
<device name="1X19" package="1X19">
<connects>
<connect gate="G$1" pin="17" pad="17"/>
</connects>
<technologies>
</technologies>
</device>
<device name="1X19_NO_SILK" package="1X19_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M11" prefix="J" uservalue="yes">
<description>&lt;b&gt;Header 11&lt;/b&gt;
Standard 11-pin 0.1" header. Use with straight break away headers (SKU : PRT-00116), right angle break away headers (PRT-00553), swiss pins (PRT-00743), machine pins (PRT-00117), and female headers (PRT-00115).</description>
<gates>
<gate name="G$1" symbol="M11" x="0" y="0"/>
</gates>
<devices>
<device name="PTH" package="1X11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1.27MM" package="1X11-1.27MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X11_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK_LONGPADS" package="1X11_LOCK_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="1X11_SMD_PTHCOMBO">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X11_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD_NO_HOLES" package="1X11_SMD_NO_HOLES">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
<connect gate="G$1" pin="2" pad="P$2"/>
<connect gate="G$1" pin="3" pad="P$3"/>
<connect gate="G$1" pin="9" pad="P$9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="POGOPIN_HOLES_ONLY" package="1X11_HOLES_ONLY">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X11_NO_SILK" package="1X11_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1X11_NO_SILK_KIT" package="1X11_NO_SILK_KIT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="COMPUTER-PERIPHERAL-POWER" prefix="J">
<gates>
<gate name="G$1" symbol="COMPUTER-PERIPHERAL-POWER" x="0" y="0"/>
</gates>
<devices>
<device name="RA" package="COMPUTER-PERIPHERAL-POWER-RA">
<connects>
<connect gate="G$1" pin="12V" pad="12V"/>
<connect gate="G$1" pin="5V" pad="5V"/>
</connects>
<technologies>
</technologies>
</device>
<device name="VERTICAL" package="COMPUTER-PERIPHERAL-POWER">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SD_CARD_SOCKET" prefix="U">
<description>SD Memory Card Connector, push-push normal type, CD enable, WP enable</description>
<gates>
<gate name="G$1" symbol="SDCARD-1" x="-66.04" y="10.16"/>
</gates>
<devices>
<device name="4UCON" package="SDCARD_4UCONN">
<connects>
<connect gate="G$1" pin="CD" pad="CD"/>
<connect gate="G$1" pin="CD/DAT3" pad="1"/>
<connect gate="G$1" pin="CLK" pad="5"/>
<connect gate="G$1" pin="CMD" pad="2"/>
<connect gate="G$1" pin="DAT0" pad="7"/>
<connect gate="G$1" pin="DAT1" pad="8"/>
<connect gate="G$1" pin="DAT2" pad="9"/>
<connect gate="G$1" pin="SH@1" pad="SH@1"/>
<connect gate="G$1" pin="SH@2" pad="SH@2"/>
<connect gate="G$1" pin="VDD" pad="4"/>
<connect gate="G$1" pin="VSS1" pad="3"/>
<connect gate="G$1" pin="VSS2" pad="6"/>
<connect gate="G$1" pin="WP" pad="WP"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="SD_1:1">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FTDI_DEVICE" prefix="J">
<description>Connector which mates to FTDI basic or FTDI cable.</description>
<gates>
<gate name="G$1" symbol="FTDI_DEVICE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="FTDI_DEVICE_SIDE">
<connects>
<connect gate="G$1" pin="CTS" pad="P$5"/>
<connect gate="G$1" pin="DTR" pad="P$1"/>
<connect gate="G$1" pin="GND" pad="P$6"/>
<connect gate="G$1" pin="RXI" pad="P$3"/>
<connect gate="G$1" pin="TXO" pad="P$2"/>
<connect gate="G$1" pin="VCC" pad="P$4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="RA_SMT" package="FTDI_DEVICE_RA_SMT">
<connects>
<connect gate="G$1" pin="CTS" pad="5"/>
<connect gate="G$1" pin="DTR" pad="1"/>
<connect gate="G$1" pin="RXI" pad="3"/>
<connect gate="G$1" pin="TXO" pad="2"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08971" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MYDAQ" prefix="J">
<gates>
<gate name="G$1" symbol="MYDAQ_CONNECTOR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="3.81MM_TERMINAL_BLOCK_FEMALE_LOCKING">
<connects>
<connect gate="G$1" pin="+15V" pad="1"/>
<connect gate="G$1" pin="-15V" pad="2"/>
<connect gate="G$1" pin="5V" pad="20"/>
<connect gate="G$1" pin="AGND_15V" pad="3"/>
<connect gate="G$1" pin="AGND_IO" pad="6"/>
<connect gate="G$1" pin="AI0+" pad="7"/>
<connect gate="G$1" pin="AI0-" pad="8"/>
<connect gate="G$1" pin="AI1+" pad="9"/>
<connect gate="G$1" pin="AN1-" pad="10"/>
<connect gate="G$1" pin="AO0" pad="4"/>
<connect gate="G$1" pin="AO1" pad="5"/>
<connect gate="G$1" pin="DGND" pad="19"/>
<connect gate="G$1" pin="DIO0" pad="11"/>
<connect gate="G$1" pin="DIO1" pad="12"/>
<connect gate="G$1" pin="DIO2" pad="13"/>
<connect gate="G$1" pin="DIO3" pad="14"/>
<connect gate="G$1" pin="DIO4" pad="15"/>
<connect gate="G$1" pin="DIO5" pad="16"/>
<connect gate="G$1" pin="DIO6" pad="17"/>
<connect gate="G$1" pin="DIO7" pad="18"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB-AB" prefix="J" uservalue="yes">
<description>This is a USB AB connector that is compatible with USB OTG. i.e. this connector can serve as a host or device</description>
<gates>
<gate name="G$1" symbol="USB_AB" x="0" y="0"/>
</gates>
<devices>
<device name="" package="USB-AB-MICRO-SMD">
<connects>
<connect gate="G$1" pin="SHIELD" pad="SHIELD1 SHIELD2 SHIELD3 SHIELD4"/>
<connect gate="G$1" pin="USBID" pad="ID"/>
</connects>
<technologies>
</technologies>
</device>
<device name="&quot;" package="USB_AB_MICRO_1:1_V2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CONN-11794" package="USB-AB-MICRO-SMD_V03">
<connects>
<connect gate="G$1" pin="USBID" pad="ID1"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11794"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DB15">
<description>DB15 / VGA right angle through-hole female connector.</description>
<gates>
<gate name="G$1" symbol="DB15" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DB15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M03X2" prefix="J" uservalue="yes">
<description>2x3 .1" header.&lt;br&gt;
Shrouded, with keying- CONN-10681&lt;br&gt;
SMT- CONN-11415&lt;br&gt;
Pogo pins- HW-11044</description>
<gates>
<gate name="G$1" symbol="M03X2" x="0" y="0"/>
</gates>
<devices>
<device name="SHROUD" package="2X3-SHROUDED">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10681"/>
</technology>
</technologies>
</device>
<device name="SMT" package="2X3_SMT_POSTS">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11415"/>
</technology>
</technologies>
</device>
<device name="POGO_PINS" package="2X3_POGO">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="HW-11044"/>
</technology>
</technologies>
</device>
<device name="2X3_SILK_MALE_PTH" package="2X3">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09701"/>
</technology>
</technologies>
</device>
<device name="NO_SILK" package="2X3-NS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="FEMALE_SMD" package="2X3_SMD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11290"/>
</technology>
</technologies>
</device>
<device name="" package="2X3_SMD">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11290" constant="no"/>
</technology>
</technologies>
</device>
<device name="FEMALE" package="2X3">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-11566"/>
<attribute name="VALUE" value="FEMALE 2x3"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AUDIO-JACK3">
<description>Audio jack - 3.5mm TRRS variety - two rings.</description>
<gates>
<gate name="G$1" symbol="AUDIO-JACK3-TRRS" x="0" y="0"/>
</gates>
<devices>
<device name="" package="AUDIO-JACK-TRRS-SMD">
<connects>
<connect gate="G$1" pin="EARTH" pad="EARTH"/>
<connect gate="G$1" pin="RING1" pad="RING1"/>
<connect gate="G$1" pin="RING2" pad="RING2"/>
<connect gate="G$1" pin="TIP" pad="TIP"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-10676"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="JST_2MM_MALE" prefix="J" uservalue="yes">
<description>Mates to single-cell LiPo batteries.&lt;br&gt;
CONN-11443&lt;br /&gt;
Now with smashable polarity marks!</description>
<gates>
<gate name="G$1" symbol="JST_2MM_MALE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="JST-2-SMD">
<connects>
<connect gate="G$1" pin="+" pad="2"/>
<connect gate="G$1" pin="-" pad="1"/>
<connect gate="G$1" pin="PAD1" pad="NC1"/>
<connect gate="G$1" pin="PAD2" pad="NC2"/>
</connects>
<technologies>
<attribute name="BTM_NEG" value="-"/>
<attribute name="BTM_POS" value="+"/>
<attribute name="PROD_ID" value="CONN-11443"/>
<attribute name="TOP_NEG" value="-"/>
<attribute name="TOP_POS" value="+"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M13X2" prefix="J" uservalue="yes">
<description>0.1" spaced headers</description>
<gates>
<gate name="G$1" symbol="M13X2" x="0" y="0"/>
</gates>
<devices>
<device name="2X13" package="2X13">
<connects>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AUDIO-JACK4-.25-HORIZ-TRS" prefix="J">
<description>1/4" TRS jack, horizontal
Production SKU: COM-11144
Footprint unproven - datasheet and part seem to be slightly different</description>
<gates>
<gate name="G$1" symbol="AUDIO-JACK4-TRS-NORMALED-GND" x="0" y="-1.27"/>
</gates>
<devices>
<device name="" package="AUDIO-JACK-.25-INCH-HORIZ-PTH">
<connects>
<connect gate="G$1" pin="EARTH" pad="SLEEVE"/>
<connect gate="G$1" pin="EARTH-NORM" pad="SLEEVE-NORM"/>
<connect gate="G$1" pin="RING" pad="RING"/>
<connect gate="G$1" pin="RING-NORM" pad="RING-NORM"/>
<connect gate="G$1" pin="TIP-NORM" pad="TIP-NORM"/>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12339" constant="no"/>
<attribute name="SF_ID" value="COM-11144" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AUDIO-JACK5-.25-VERT-TRS" prefix="J" uservalue="yes">
<description>1/4" TRS jack, vertical
Production SKU: COM-11152
<gates>
<gate name="G$1" symbol="AUDIO-JACK5-TRS-NORMALED" x="0" y="0"/>
</gates>
<devices>
<device name="" package="AUDIO-JACK-.25-INCH-VERT-PTH">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="COM-11152" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="JST_VERTICAL">
<gates>
<gate name="G$1" symbol="JST_6_1MM_VERT" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="JST-6-SMD-VERT-1.0MM">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-08249" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M23" prefix="J" uservalue="yes">
<gates>
<gate name="G$1" symbol="M23" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X23">
<connects>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="20" pad="20"/>
</connects>
<technologies>
</technologies>
</device>
<device name="LOCK" package="1X23_LOCK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LONGPADS" package="1X23_LONGPADS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MAGJACK-NOLABELS" prefix="J">
<gates>
<gate name="G$1" symbol="MAGJACK_NOLABELS" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-09556"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BINDING_POST" prefix="J">
<description>Single Banana jack.  &lt;br&gt;&lt;br&gt;
PRT-09739 (red) or PRT-09740 (blk) &lt;br&gt;&lt;br&gt;
Footprint is a bit strange.  The component itself has an threaded, insulated body that goes through the board, with a small threaded metal stud coming off the back.  The intent of this package is that the post goes through a milled obling hole, and a small wire would be used to connect from the PCB pad to the metal contact on the post.</description>
<gates>
<gate name="G$1" symbol="BINDING_POST" x="0" y="0"/>
</gates>
<devices>
<device name="" package="BINDING_POST">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M06X2" prefix="J" uservalue="yes">
<gates>
<gate name="G$1" symbol="M06X2" x="0" y="0"/>
</gates>
<devices>
<device name="FEMALE-SMT" package="2X6_SMD">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH_FEMALE" package="2X6">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12423"/>
<attribute name="VALUE" value="2X6 FEMALE"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="I2C_STANDARD" prefix="J" uservalue="yes">
<description>SparkFun has standardized on a pinout for all I&lt;sup&gt;2&lt;/sup&gt;C based sensor breakouts.&lt;br&gt;
&lt;br&gt;
This pinout allows I&lt;sup&gt;2&lt;/sup&gt;C boards to be plugged directly into the headers on Arduino Uno compatible boards, and
to be daisy chained easily.</description>
<gates>
<gate name="G$1" symbol="I2C_STANDARD" x="2.54" y="0"/>
</gates>
<devices>
<device name="" package="1X04">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="_NO_SILK" package="1X04_NO_SILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="M20X2" prefix="J">
<gates>
<gate name="G$1" symbol="M20X2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="2X20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="NOSILK" package="2X20_NOSILK">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SHROUDED" package="2X20_SHROUDED">
<connects>
</connects>
<technologies>
<attribute name="PROD_ID" value="CONN-12263" constant="no"/>
</technology>
</technologies>
</device>
<device name="SHROUDED_SMT" package="2X20_SHROUDED_SMT">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BATTERY_CONN" prefix="J">
<description>Various footprints for battery connectors</description>
<gates>
<gate name="G$1" symbol="BATTERY_CONN" x="0" y="0"/>
</gates>
<devices>
<device name="DEANS" package="DEANS">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USD_CONNECTOR" prefix="J">
<description>&lt;b&gt;microSD Socket&lt;/b&gt;&lt;br /&gt;
Push-push type µSD socket. Footprint production proven. Symbol has new and improved layout and naming accuracy. SparkFun Electronics SKU : PRT-00127. tDoc lines correctly indicate media card edge positions when inserting (unlocked, locked, depressed).&lt;br /&gt;
<gates>
<gate name="1" symbol="USD_CARD" x="-5.08" y="-7.62"/>
</gates>
<devices>
<device name="" package="MICRO-SD-SOCKET-PP">
<connects>
<connect gate="1" pin="!CS" pad="CS"/>
<connect gate="1" pin="CD1" pad="CD1"/>
<connect gate="1" pin="CD2" pad="CD2"/>
<connect gate="1" pin="DI" pad="DI"/>
<connect gate="1" pin="DO" pad="DO"/>
<connect gate="1" pin="GND" pad="GND"/>
<connect gate="1" pin="RSV@1" pad="RSV1"/>
<connect gate="1" pin="RSV@2" pad="RSV2"/>
<connect gate="1" pin="SCK" pad="SCLK"/>
<connect gate="1" pin="SHIELD@1" pad="GND1"/>
<connect gate="1" pin="SHIELD@3" pad="GND3"/>
<connect gate="1" pin="VCC" pad="VCC"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="CORTEX_DEBUG" prefix="J">
<description>&lt;h3&gt;Cortex Debug Connector&lt;/h3&gt;
&lt;p&gt;&lt;a href="http://infocenter.arm.com/help/topic/com.arm.doc.faqs/attached/13634/cortex_debug_connectors.pdf"&gt;Datasheet&lt;/a&gt;&lt;/p&gt;</description>
<gates>
<gate name="G$1" symbol="CORTEX_DEBUG" x="0" y="0"/>
</gates>
<devices>
<device name="SMD" package="SAMTECH_FTSH-105-01">
<connects>
<connect gate="G$1" pin="GND@3" pad="3"/>
<connect gate="G$1" pin="GND@5" pad="5"/>
<connect gate="G$1" pin="GNDDTCT" pad="9"/>
<connect gate="G$1" pin="KEY" pad="7"/>
<connect gate="G$1" pin="NC/TDI" pad="8"/>
<connect gate="G$1" pin="NRESET" pad="10"/>
<connect gate="G$1" pin="SWDCLK/TCK" pad="4"/>
<connect gate="G$1" pin="SWDIO/TMS" pad="2"/>
<connect gate="G$1" pin="SWO/TDO" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<device name="PTH" package="2X5-PTH-1.27MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USB-MICROB" prefix="J">
<gates>
<gate name="G$1" symbol="USB-MICROB" x="0" y="0"/>
</gates>
<devices>
<device name="&quot;" package="USB-B-MICRO-SMD_V03">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="USD-SDIO-SOCKET" prefix="J">
<description>microSD Socket
Push-push type uSD socket with full SDIO signal mapping. Spark Fun Electronics SKU : PRT-00127. tDoc lines correctly indicate media card edge positions when inserting (unlocked, locked, depressed). NOTE: CD1 and CD2 are connected internally, and short to ground when card is removed.</description>
<gates>
<gate name="G$1" symbol="USDCARD_SDIO" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MICRO-SD-SOCKET-SDIO">
<connects>
<connect gate="G$1" pin="CD/DAT3" pad="CD/DAT3"/>
<connect gate="G$1" pin="CLK" pad="CLK"/>
<connect gate="G$1" pin="CMD" pad="CMD"/>
<connect gate="G$1" pin="DAT0" pad="DAT0"/>
<connect gate="G$1" pin="DAT1" pad="DAT1"/>
<connect gate="G$1" pin="DAT2" pad="DAT2"/>
<connect gate="G$1" pin="SHIELD@3" pad="GND3"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
