# From original gitignore in libraries repo, not sure what they are from.
*.orig
SyncToy*
SFE_Testing_Eagle_Library
## SparkFun Useful stuff
## AVR Development
*.eep
*.elf
*.lst
*.lss
*.sym
*.d
*.o
*.srec
*.map
## Notepad++ backup files
*.bak
## BOM files
*bom*
## Eclipse
*.pydevproject
.project
.metadata
bin/
tmp/
*.tmp
*.bak
*.swp
*~.nib
local.properties
.classpath
.settings/
.loadpath
# External tool builders
.externalToolBuilders/
# Locally stored "Eclipse launch configurations"
*.launch
# CDT-specific
.cproject
# PDT-specific
.buildpath
## Eagle
# Ignore the board and schematic backup files and lock files
*.b#?
*.s#?
*.l#?
*.lck
## Visual Studio
## Ignore Visual Studio temporary files, build results, and
## files generated by popular Visual Studio add-ons.
# User-specific files
*.suo
*.user
*.sln.docstates
# Build results
[Dd]ebug/
[Rr]elease/
*_i.c
*_p.c
*.ilk
*.meta
*.obj
*.pch
*.pdb
*.pgc
*.pgd
*.rsp
*.sbr
*.tlb
*.tli
*.tlh
*.tmp
*.vspscc
.builds
*.dotCover
## TODO: If you have NuGet Package Restore enabled, uncomment this
#packages/
# Visual C++ cache files
ipch/
*.aps
*.ncb
*.opensdf
*.sdf
# Visual Studio profiler
*.psess
*.vsp
# ReSharper is a .NET coding add-in
_ReSharper*
# Installshield output folder
[Ee]xpress
# DocProject is a documentation generator add-in
DocProject/buildhelp/
DocProject/Help/*.HxT
DocProject/Help/*.HxC
DocProject/Help/*.hhc
DocProject/Help/*.hhk
DocProject/Help/*.hhp
DocProject/Help/Html2
DocProject/Help/html
# Click-Once directory
publish
# Others
[Bb]in
[Oo]bj
sql
TestResults
*.Cache
ClientBin
stylecop.*
*.dbmdl
Generated_Code #added for RIA/Silverlight projects
# Backup & report files from converting an old project file to a newer
# Visual Studio version. Backup files are not needed, because we have git ;-)
_UpgradeReport_Files/
Backup*/
UpgradeLog*.XML
## Windows
# Windows image file caches
Thumbs.db
# Folder config file
Desktop.ini
## Mac OS
.DS_Store
## Linux
# backup files (*.bak on Win)
## Python
*.py[co]
# Packages
*.egg
*.egg-info
dist
build
eggs
parts
bin
var
sdist
develop-eggs
.installed.cfg
# Installer logs
pip-log.txt
# Unit test / coverage reports
.coverage
.tox
#Translations
*.mo
#Mr Developer
.mr.developer.cfg
