# This may not look like it, but it's a -*- makefile -*-
# sd2iec - SD/MMC to Commodore serial bus interface/controller
# Copyright (C) 2007-2014  Ingo Korb <ingo@akana.de>
#  Inspired by MMC2IEC by Lars Pontoppidan et al.
#  FAT filesystem access based on code from ChaN, see tff.c|h.
#  This program is free software; you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation; version 2 of the License only.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software
#  Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
# config-arduino_mega2560: sd2iec configuration for Arduino MEGA2560 (AVR) board or compatible clone.
# This file is included in the main sd2iec Makefile and also parsed
# into autoconf.h.
CONFIG_ARCH=avr
CONFIG_MCU=atmega2560
CONFIG_HARDWARE_VARIANT=10
CONFIG_HARDWARE_NAME=arduino_mega2560
CONFIG_LINKER_RELAX=y
CONFIG_MCU_FREQ=8000000
# We do not provide boot loader. Use the original arduino one, we don't want to mess that up.
#CONFIG_BOOTLOADER=y
#CONFIG_BOOT_DEVID=0x5053524c
# Enable UART debugging - requires 24 bytes plus buffer size in RAM
CONFIG_UART_DEBUG=y
# Baud rate of the UART, not used if CONFIG_UART_DEBUG is disabled
CONFIG_UART_BAUDRATE=57600
# log2 of the UART buffer size, i.e. 6 for 64, 7 for 128, 8 for 256 etc.
CONFIG_UART_BUF_SHIFT=7
#CONFIG_DEADLOCK_ME_HARDER=y
CONFIG_COMMAND_CHANNEL_DUMP=y
# If the on board (external) osciallator deviates from chip to chip (enough to cause a few cycles variance),
# the turbos must be adapted cycle wise in the fastloader-ii.S implementation.
# However, this must be TESTED thorougly on several mega's.
CONFIG_LOADER_TURBODISK=y
CONFIG_LOADER_FC3=y
CONFIG_LOADER_DREAMLOAD=n
CONFIG_LOADER_ULOAD3=y
CONFIG_LOADER_GIJOE=y
CONFIG_LOADER_EPYXCART=y
CONFIG_LOADER_GEOS=y
CONFIG_LOADER_WHEELS=y
CONFIG_LOADER_NIPPON=y
CONFIG_LOADER_AR6=y
CONFIG_LOADER_ELOAD1=y
CONFIG_LOADER_MMZAK=y
CONFIG_LOADER_N0SDOS=y
# Define this to adjust the turbo (loading part) of the arduino mega with a few cycles.
# This MAY be dependant on crystal individuality.
CONFIG_MEGA_CYCLE_ADJUST=y
# Define this if using the Itead Stackable SD Card Shield v3.0
#CONFIG_MEGA_SHIELD_ITEAD_V3=y
CONFIG_SD_AUTO_RETRIES=10
CONFIG_SD_DATACRC=y
CONFIG_ERROR_BUFFER_SIZE=100
CONFIG_COMMAND_BUFFER_SIZE=120
CONFIG_BUFFER_COUNT=6
CONFIG_MAX_PARTITIONS=2
# The RTC ise optional, but can be provided as a shield (DS1307 compatible).
#CONFIG_RTC_DSRTC=y
#CONFIG_RTC_PCF8583=y
#CONFIG_REMOTE_DISPLAY=y
#CONFIG_DISPLAY_BUFFER_SIZE=40
CONFIG_HAVE_IEC=y
CONFIG_M2I=y
# There is not room in RAM for a P00CACHE.
CONFIG_P00CACHE=n
#CONFIG_P00CACHE_SIZE=12000
CONFIG_HAVE_EEPROMFS=y
