Action Replay fast loader/saver protocols
Documented by Ingo Korb
Note 1: This document is currently incomplete, many of the loaders
supported by the AR6 are missing.
Note 2: The contents of this document have been tested only on a PAL
system, because the author currently has no NTSC Action Replay
cartridge.
Note 3: An Action Replay 6 cartridge has been used as reference, other
versions may or may not use different fast loaders.
1541 fastloader
The default 1541 fast loader is a track loader that does the file name
matching on the C64 instead of the drive. It has not been further
analyzed due to this limitation.
1581 fastloader
The 1581 fastloader opens the target file on secondary address 0 to
read the start address. When the loader is uploaded, it will pull the
clock line low and the data line high to signal that it's currently
busy processing. It is recommended to add a short delay (one
millisecond is sufficient) at this point because the C64 will miss the
drive becoming ready if the time between M-E and the first byte
transmission is too short.
Bytes are transmitted according to this timing, synchronized by the
low-to-high transision of the data line initated by the C64:
   Time  Clock Data
    0us    1   0->1 (timing reference)
    5us    b0   b1
   13us    b2   b3
   21us    b4   b5
   29us    b6   b7
 37.5us    0    1
  ~47us    0    1   (bus settle delay)
Each sector of the file is transferred by sending the number of valid
bytes in the current sector (i.e. 254 for a full sector or the second
byte minus one for the last one on a D64-style disk) followed by the
data bytes of the sector in forward order.
After transmitting the last sector a single byte with value 0 is sent
to the computer to mark the end of the transmission. There is no way
to signal read errors to the computer. The computer will send a
command to close the file itself.
Note: The final bus settle delay doesn't need to be explicit if your
CPU is slow enough, but a fast processor might see its own data high
as start condition because of the slow rise times of the
open-collector serial bus.
1581 fastsaver
Note: This fastsaver is known to use different timing on PAL and NTSC.
The 1581 fastsaver opens the target file on secondary address 1 for
writing. When the loader is uploaded, it will pull the clock line low
and the data line high. The original code waits approximately 800
microseonds at this point.
For every sector of the file (254 bytes of data), 256(!) bytes are
received in forward order. The first two bytes of this data block are
not part of file contents. If the first byte is non-zero, more sectors
will follow. If the first byte is zero, the second byte is the offset
in the received data buffer (including the two initial bytes) of the
first byte that is not part of the file anymore (0 if everything is
part of the file).
The timing for receiving a single byte in the PAL version is:
   Time  Clock Data
  setup    1    1   (set lines high on the drive side)
    0us    1   0->1 (wait for change, not level! - timing reference)
   12us   !b7  !b5
   22us   !b6  !b4
   38us   !b3  !b1
   48us   !b2  !b0
   53us    0    1   (set by drive)
