Notes on buffer_t and its use
buffer_t is the struct holding all information for the dynamically allocated
buffers in sd2iec. Usually they are associated with a secondary address,
but they can also be used for internal purposes, e.g. to read the file
names in a swaplist or to store the BAM of a mounted disk image.
If you allocate a temporary buffer or do an early return from a function
that has allocated a buffer for some purpose you do not need to do
anything - every buffer returned from alloc_buffer or alloc_system_buffer
is maked as "not sticky" which means that it will get freed without calling
the cleanup function at the end of the IEC mainloop.
If you do need a buffer that should stay around for longer than that
(e.g. for a buffer associated with a file), call stick_buffer(buffer_t *)
on it. After doing this you need to make sure that free_buffer(buffer_t *)
is called on the buffer when it isn't needed anymore.
Another independent distinction in buffer types is system buffers vs.
user buffers. alloc_system_buffer will return a buffer with the secondary
field set to BUFFER_SEC_SYSTEM while alloc_buffer returns a buffer
with the secondary field set to 0. This difference is used when updating
the device LEDs - the number of allocated user buffers is tracked in
active_buffers and the BUSY LED will be turned on by alloc_buffer
and off by free_buffer as long as at least one user buffer is allocated.
Similiar to that the DIRTY LED is controlled by mark_write_buffer and
free_buffer - please do not call mark_write_buffer on a system buffer.
free_multiple_buffers takes a flag parameter which specifies which buffer(s)
should be freed. It is a bit field with the following base values:
 - FMB_CLEAN
     Call the cleanup callback before freeing the buffer. If this is
     specified, the return value of free_multiple_buffers will be 1 if
     any of the called cleanup functions returned a non-zero value
     or 0 otherwise.
 - FMB_FREE_STICKY
     Free sticky buffers too (will free only not-sticky buffers otherwise)
 - FMB_FREE_SYSTEM
     Free system buffers too (will free only non-system buffers otherwise)
For convenience there are a few macros for common use cases:
 - FMB_ALL
     free all buffers, no cleanups
 - FMB_ALL_CLEAN
     free all buffers and call their cleanup functions
 - FMB_USER
     free all non-system buffers, no cleanups
 - FMB_USER_CLEAN
     free all non-system buffers and call their cleanup functions
 - FMB_UNSTICKY
     free all non-sticky buffers, no cleanups
 - FMB_UNSTICKY_CLEAN
     free all non-sticky buffers and call their cleanup functions
