The Final Cartridge III Fast Loader and Saver Protocol
analysed by Thomas Giesel
notes about the Freezer-variation and EXOS V3 by Ingo Korb
This document describes the fast loader and saver protocol of the FC3. The
description may not be accurate in any point.
LOADING
First of all the FC3 opens the file and reads the first two bytes to check the
load address. It does not close the file before starting the fast loader, so
that one just starts with the last sector loaded.
When the loader starts it sets both data and clock to high to signal that it
is currently busy.
The FC3 does always transfer whole blocks, even if not all bytes are used.
Each block is transferred in 65 tuples with 4 bytes each.
Before sending a block the drives pulls CLOCK low and waits for the host to
respond by pulling DATA low. Then drive and host release these lines.
The first tuple is sent about 180 us after this handshake. As each tuple has
its own synchronization this timing doesn't need to be accurate. Between two
tuples there are about 190 us. In sd2iec these to delays were originally
reduced to 150 us which works fine for the FC3, but fails with EXOS.
1st tuple:
0: not used (always 7, data marker on disk)
1: block counter, starting at 0
2: 0 if all bytes must be used, number of bytes otherwise
3: First byte of block
The protocol is able to transfer sectors out-of-file-order as they are read
from disk, the block counter is used to store them in the correct order on
the C64 side.
2nd..64th tuple:
4 bytes from block
65th tuple:
0: last byte of block
1..3: not used
Each tuple is syncronized by the drive pulling CLOCK low, then 2 bits are
transfered at once until the 4 bytes are done. Bit 0 is on CLOCK, Bit 1 on
DATA and so on. Electrical 0 means binary 0. Finally CLOCK and DATA are
released to high level.
EOF is marked by pulling DATA low instead of starting a new handshake.
I/O errors are marked by pulling DATA and CLOCK low.
The "|" marks are the point of time when the bus is written or read.
C64 read (PAL)
 1   (+12)   13  (+12)   25  (+12)    37  (+12)   49   (+14)    63 (+12)  cycle
 1..7        13.2..19.2  25.4..31.4   37.6..43.6  49.7..55.7    63.9..69.9   us
 (sync)
1541 write
0   (+12)   12  (+12)   24   (+13)   37  (+12)   49   (+13)   62  (+12)      us
CLK low     1st pair    2nd pair     3rd pair    4th pair     5th pair
sd2iec write
0  (+12)    12  (+12)   24  (+12)   36  (+12)   48   (+14)    62  (+12)      us
C64 read (PAL) cont'd
     75  (+12)   87  (+12)   99   (+14)     113  (+12)   125   (+12)      cycle
     76.1..82.1  88.3..94.3  00.5..06.5     14.7..20.7   26.9..32.9          us
1541 write
   74   (+13)   87   (+12)  99   (+13)   112  (+12)  124  (+13)              us
   6th pair     7th pair    8th pair     9th pair    10th pair
sd2iec write
   74  (+12)   86  (+12)   98   (+14)    112  (+12)  124  (+12)              us
        137  (+12)  149   (+14)   163  (+12)   175  (+12)  187  (+12)     cycle
        39.1..45.1  51.2..57.2    65.4..71.4   77.6..83.6  89.8..95.8        us
1541 write
      137  (+12)  149  (+13)   162  (+12)  174  (+13)   187  (+12)           us
      11th pair   12th pair    13th pair   14th pair    15th pair
sd2iec write
     136  (+12)  148  (+14)    162  (+12)  174  (+12)  186  (+12)            us
           199                                                            cycle
           02.0..08.0                                                        us
1541 write
        199  (+16)                                                           us
        16th pair
sd2iec write
       198   (+14)                                                           us
Fastloader in freezed files
Programs freezed using the "F.DISK" command of the FC3 use a fast loader
similiar to the normal FC3 fastloader. Like the normal fastloader it opens
the target file for reading with the standard protocol and it also uses
the same protocol and timing to transmit a four-byte tuple to the C64.
However, the handshaking inbetween and the contents of the first tuple
are different. The freezer-variant transmits the data from disk directly
which means that the first tuple contains a 0x07, the track and sector
of the next sector in a file and the first data byte. Everything but
the data byte is ignored by the C64-side code, so the blocks must
be sent in file order.
Both end-of-file and error conditions are signalled by pulling DATA low.
A full clock/data handshake is done before the transmission of every tuple
which means that the fixed delays between tuples can be dropped.
The freeze-loader closes and reopens the data file using the standard
protocol after the fast protocol has finished transmitting the file.
Old Fastloader in freezed files
Some older versions of the Final Cartridge 3 appear to use a different
fast loader in freezed files. This has been confirmed for a cartridge
ROM that reports itself as "SEP 1987", Disk Operations V1.0. This
particular loader is a simple 2-bit fastloader using the following
timing tables:
PAL:
   Time  Clock Data
    0us  0->1  (1)  (timing reference)
   14us   !b0  !b1
   22us   !b2  !b3
   30us   !b4  !b5
   38us   !b6  !b7
   46us    1    0   (busy marker)
NTSC:
   Time  Clock Data
   14us   !b0  !b1
   24us   !b2  !b3
   34us   !b4  !b5
   44us   !b6  !b7
   52us    1    0   (busy marker)
The timing reference check on the clock line should be implemented as
an actual check for a transition as the C64 sets the clock line low 53
cycles (PAL) after the timing reference - if the sending device is fast
enough, a simple check for clock high will misread the busy marker at
the end as a start signal for the next byte.
Sectors are read in sequence, only the data is transferred. Upon
start and between the transmission of two bytes, the loader sets clock
high, data low as "busy" marker. It appears that this loader does not
transmit any end-of-file indication. No specific file is opened,
instead the transfer starts with the last track/sector that was
accessed which should correspond to the file open on secondary address
0. The specific specs for a file transfer are as follows:
- set clock high, data low
- read current sector
- transmit all bytes in file:
  - set clock and data high
  - (maybe delay clock check until 17us after clock/data high)
  - wait until clock is high
  - follow timing table above
- exit (implicitly resets clock/data to high)
EXOS V3
The protocol used by the EXOS V3 kernal by J. Schemmel is exactly the same
as the one used by the FC3, but it seems that the C64-side code is slightly
less efficient - the delay between two tuples must be increased a bit
(150us fails, 190us works, exact limit not tested) or loading will hang.
Judging from the code differences and the relative release dates both
are probably derived from a common source whose code was optimized in
different ways by the two authors.
There is also a kernal called "The Beast System" which is based on EXOS
and uses the same fast loader code.
SAVING
The FC3 first opens the file for writing, if this works well, it starts its
drive code. This code receives and saves the data.
The first byte marks the size of the block. If this byte is 0, a full block of
254 bytes follows which is not the last one. If other numbers are received,
n - 1 bytes will follow and this will be the last block. Note that transferred
blocks do not correspond to disk sectors, as each full block has 254 bytes,
also the first one which contains the start address.
The drive releases DATA to show that it's ready to receive data. Then the C64
releases CLOCK to synchronize the file transfer.
The following diagram shows the position of each bit being transfered. The bits
are send low-active.
C64 write (PAL)
0   (+12)   12  (+10) 22    (+16)    38  (+10) 48  (+10) 58               cycle
0           11.8      21.7           37.4      47.3      57.1                us
CLOCK high  D=5       D=4            D=1       D=0       CLOCK low
(sync)      C=7       C=6            C=3       C=2       (busy)
sd2iec read
0     (+17)      17   (+13)   30  (+12)   42  (+10) 52                       us
After reading the last pair of bits the drive pulls DATA down to show it's
busy. Apparently there's no mechanism to signal situations like "disk full".
