G.I. Joe Loader Protocol
Documented by Ingo Korb
Said to be the most-ripped IRQ loader, although only three programs using
it have been located yet:
- G.I. Joe
- Crown (cracked by Sharks)
- Cucumber Juice II by Hitmen (switch to IRQ loader mode manually)
Each of these uploads the drive code with M-W statements of different
length, but all of them send the commands in increasing memory address
order. A CRC-based detection scheme may need to compare the CRC after
every byte instead of every command to trigger reliably.
The protocol used in this loader is completely synchronous, triggered
by both edges of the CLK line; ATN is unused but may change anyway
in some implementations of the C64 side.
High Level
After the M-E command has been received, set both DATA and CLK high
and disable ATN acknowledge. The original drive code uses a slightly
weird loop to wait until the bus is completely idle at this point,
simply waiting 10 milliseconds and then looping until both DATA and
CLK are high seems to be sufficient.
Main loop
1) Set CLK low
2) Wait until DATA is low
3) Set CLK high
4) Read a byte, discard it
5) Read two bytes
6) Set CLK low
7) Try to open a file whose name starts with the two bytes received in step 5
8) If not successful, send error and restart main loop
9) Send file contents
10) Send 0xac 0xff
11) (Close file if neccessary)
12) Restart main loop
Sending file contents
1) Send file in blocks of 254 bytes (or less for the last block):
  2) Set CLK high
  3) Send all bytes in file order - if byte is 0xac, send twice
  4) If another block is available to send:
    5) Send 0xac 0xc3
    6) Set CLK low
5) Send 0xac 0xff as end marker
6) (Close file if necessary)
If a read error is encountered while sending the file contents,
send error and return to main loop.
Sending error
1) Set CLK high
2) Send 0xfe 0xfe 0xac 0xf7
3) (Close file if neccessary)
Low Level
Receiving a byte
1) byte = 0
2) Repeat 4 times:
  3) Wait until CLK is low
  4) delay ~2-5 microseconds
  5) byte = byte >> 1
  6) Read DATA
  7) If DATA was low in step 6: byte = byte | 0x80
  8) Wait until CLK is high
  9) delay ~2-5 microseconds
 10) byte = byte >> 1
 11) Read DATA
 12) If DATA was low in step 11: byte = byte | 0x80
Note: The delays in step 4 and 9 are recommended because the C64 sets
      both the clock and data line at the same time. A small
      difference in propagation time between the two lines can easily
      cause data corruption when the delay is too small.
Sending a byte
1) Repeat 4 times:
  2) Wait until CLK is high
  3) Set data to (byte & 1)
  4) byte = byte >> 1
  5) Wait until CLK is low
  6) Set data to (byte & 1)
  7) byte = byte >> 1
