Nippon Loader (by Joerg Jungermann)
This document describes the reverse engineered portion of the loader used
in the german adventure role playing game "Nippon".
It is unknown if this loader is used in other releases.
The loader is not fast, but the timing is relaxed.
It works without crystal and allows IRQs to be enabled on the C64 side.
State machine
The code executed in the 15x1 implements the following state machine.
ATN low and CLOCK are used to syncronise C64 and Floppy. The data is transmitted via DATA.
The state machine is started by uploading multiple chunks of code in 16byte blocks to drives
memory from $0300 to $041f. The last block uploaded begins at $0410 and has the checksum $43c1.
Therefor it is used to identify the loader, if a successive call using M-E executes code at $0300.
       START
 +->--|idle loop|
 |       | ATN low
 |       V
 |    +-------+  T > $80       +-----------------+
 |    |get T/S|--------------->| exit to CBM-DOS |
 ^       | S < $80             | S > $80
 |       V                     V
 +-<--|write T/S|            |read T/S with S &= $7f|
 |                                   V
Idle loop
The idle loop set ATN,CLOCK and DATA high, and waits for ATN low to get track, sector and command.
Get track & sector
In this state the drive code expects two bytes from the C64. Before any bit is received or sent over
the IEC bus a special handshake is done to synchronize drive and computer.
The first byte identifies the track for the next action.
If the track byte is larger than $80 (bit 7 is set) the drive code jumps to the 1541 reset vector.
This is usually called, if the game is left throug the in game menu.
The second byte fetched contains the command and the sector information: Bit 7 determines if command
read or write. if bit 7 is set the command is read, otherwise write.
The sector is the 2nd byte & $80.
Synchronisatiion handshake
This handshake is done before any bit transfer.
1. If ATN low, set CLOCK low and jump back to idle loop. Drive code is out of sync with Cevi.
   Strangly nothing is done to detect such errors an C64 side, except for a endless loop,
   so the game will work or simply crash.
2. Wait CLOCK to become low
Read byte
1. CLK, DATA are set high
2. Until 8 bits are received via IEC
 a. Wait for syncronisation handshake to finish, first bit received is bit 0.
 b. read one bit from DATA
3. set CLK low and DATA high
Write byte
2. Until 8 bits are send over IEC
 b. write one bit to DATA, first bit sent is bit 0
Read T/S
1. Sector T/S is fetched into buffer
2. Byte after byte is tranfered starting with byte 0 to byte $ff. A full sector is transfered.
Write T/S
1. $ff bytes are fetched into a buffer.
2. Buffer is written as sector T/S.
Disassembled floppy code
; CBM Dasm V2.24
*=$0300
; $1800 bits
;   bit 7  - ATN in inverted, to read bus bit 4 must be 0
;   bit 4  - ATN out inverted
;   bit 3  - Clock out inverted
;   bit 2  - Clock in inverted, to read bus bit 3 must be 0
;   bit 1  - Data out inverted
;   bit 0  - Data in inverted, to read bus bit 1 must be 0
; $C6 = tmp ? counter ? transfer byte
; set drive led off and IRQs off
0300    20  ED  03   JSR $03ED
0303    A2  45       LDX #$45
0305    86  C6       STX $C6
; stack pointer init
0307    9A           TXS
; idle loop - wait for ATN low
; set ATN = CLK = Data = high
0308    A9  00       LDA #$00
030A    8D  00  18   STA $1800
030D    AD  00  18   LDA $1800
; when ATN low Acc > $80 branch
0310    30  18       BMI $032A
0312    C6  C6       DEC $C6
; branch when $c6 is not $00
0314    D0  F2       BNE $0308
; set CLK to 0
0316    09  08       ORA #$08
0318    8D  00  18   STA $1800
031B    EA           NOP
031C    EA           NOP
031D    EA           NOP
031E    EA           NOP
; branch if ATN low
031F    AD  00  18   LDA $1800
0322    30  0B       BMI $032F
; ab undzumal nen irq zulassen
0324    58           CLI
0325    EA           NOP
0326    78           SEI
0327    4C  08  03   JMP $0308
; fetch track byte
; CLK to low
032A    09  08       ORA #$08
032C    8D  00  18   STA $1800
; wait for ATN high
032F    AD  00  18   LDA $1800
0332    30  FB       BMI $032F
; drive LED on
0334    20  F7  03   JSR $03F7
; fetch track byte from IEC
0337    20  6D  03   JSR $036D
; if Accu > $80 reset floppy, exit this code
033A    10  03       BPL $033F
033C    4C  A0  EA   JMP $EAA0
; store track byte in command for buffer 4
033F    85  0E       STA $0E
; fetch a byte from IEC
0341    20  6D  03   JSR $036D
; if Acc < $80 fetch $100 bytes in buffer 4, else read sector to buffer 4
0344    30  13       BMI $0359
; store sector in command for buffer 4
0346    85  0F       STA $0F
; fetch $100 bytes via IEC to $0700 buffer 4
0348    A0  00       LDY #$00
034A    20  6D  03   JSR $036D
034D    99  00  07   STA $0700,Y
0350    C8           INY
0351    D0  F7       BNE $034A
; store bytes in buffer 4 to track/sector job 4
0353    20  01  04   JSR $0401
; restart idle loop
0356    4C  00  03   JMP $0300
0359    29  7F       AND #$7F
035B    85  0F       STA $0F
; read sector to buffer 4
035D    20  04  04   JSR $0404
; transfer $100 bytes via IEC
0360    A0  00       LDY #$00
0362    B9  00  07   LDA $0700,Y
; send byte
0365    20  93  03   JSR $0393
0368    C8           INY
0369    D0  F7       BNE $0362
; branch always to idle loop
036B    F0  93       BEQ $0300
; fetch a byte to Accu via IEC
; bit counter to 8 count down
036D    A2  08       LDX #$08
; set CLK DATA high
036F    AD  00  18   LDA $1800
0372    29  F5       AND #$F5
0374    8D  00  18   STA $1800
; wait for ATN, CLOCK low
0377    20  C2  03   JSR $03C2
; fetch DATA in to Carry-Flag
037A    AD  00  18   LDA $1800
037D    4A           LSR
; push carry to bit 7 of $c6
037E    66  C6       ROR $C6
; wait Clock high
0380    20  BA  03   JSR $03BA
; bit count decrement
0383    CA           DEX
; fetch next bit
0384    D0  F1       BNE $0377
; data out high, clock low
0386    AD  00  18   LDA $1800
0389    29  FD       AND #$FD
038B    09  08       ORA #$08
038D    8D  00  18   STA $1800
; byte in accu holen
0390    A5  C6       LDA $C6
0392    60           RTS
; tranfer byte in Accu via IEC
; invert Accu and store to $c6
0393    49  FF       EOR #$FF
0395    85  C6       STA $C6
; byte counter
0397    A2  08       LDX #$08
; set CLK high
0399    A9  F7       LDA #$F7
039B    2D  00  18   AND $1800
039E    8D  00  18   STA $1800
03A1    20  C2  03   JSR $03C2
; fetch a bit from $C6
03A4    A9  00       LDA #$00
03A6    46  C6       LSR $C6
; bracch if bit to transfer 0 carry clear
03A8    90  05       BCC $03AF
; bit = 1
03AA    20  E4  03   JSR $03E4
; branch always
03AD    D0  03       BNE $03B2
; bit = 0
03AF    20  DB  03   JSR $03DB
; wait for clock high
03B2    20  BA  03   JSR $03BA
; decrement byte counter
03B5    CA           DEX
; do it till 8 bytes are transfered
03B6    D0  E9       BNE $03A1
; branch always
03B8    F0  CC       BEQ $0386
; wait for Clock high
03BA    A9  04       LDA #$04
03BC    2C  00  18   BIT $1800
03BF    D0  F9       BNE $03BA
03C1    60           RTS
; wait for atn, clock low
; when ATN high and Clock high reinit
03C2    A9  04       LDA #$04
03C4    2C  00  18   BIT $1800
; branch if ATN low
03C7    30  03       BMI $03CC
; when CLOCK high wait again for ATN high
03C9    F0  F7       BEQ $03C2
; when ATN, Clock low return
03CB    60           RTS
; set clock low
03CC    0A           ASL
03CD    0D  00  18   ORA $1800
03D0    8D  00  18   STA $1800
; wait for ATN high
03D3    2C  00  18   BIT $1800
03D6    30  FB       BMI $03D3
; reinit
03D8    4C  00  03   JMP $0300
; set Data high
03DB    A9  FD       LDA #$FD
03DD    2D  00  18   AND $1800
03E0    8D  00  18   STA $1800
03E3    60           RTS
; set Data low
03E4    A9  02       LDA #$02
03E6    0D  00  18   ORA $1800
03E9    8D  00  18   STA $1800
03EC    60           RTS
; drive LED off
03ED    78           SEI
03EE    A9  F7       LDA #$F7
03F0    2D  00  1C   AND $1C00
03F3    8D  00  1C   STA $1C00
03F6    60           RTS
; drive LED on
03F7    78           SEI
03F8    A9  08       LDA #$08
03FA    0D  00  1C   ORA $1C00
03FD    8D  00  1C   STA $1C00
0400    60           RTS
; exec write sector job code, wait for end
0401    A9  90       LDA #$90
0403    2C  A9  80   BIT $80A9
; exec read sector job code, wait for end
  0404 LDA #$80
0406    85  04       STA $04
0408    58           CLI
0409    A5  04       LDA $04
040B    30  FC       BMI $0409
040D    78           SEI
040E    60           RTS
040F    50  85       BVC $0396
0411    48           PHA
0412    60           RTS
0413    0D  00  18   ORA $1800
0416    8D  00  18   STA $1800
0419    2C  00  18   BIT $1800
041C    30  FB       BMI $0419
041E    4C  00  03   JMP $0300
0421    A9  FD       LDA #$FD
0423    2D  00  18   AND $1800
0426    8D  00  18   STA $1800
0429    60           RTS
042A    A9  02       LDA #$02
042C    0D  00  18   ORA $1800
042F    8D  00  18   STA $1800
0432    60           RTS
0433    78           SEI
0434    A9  F7       LDA #$F7
0436    2D  00  1C   AND $1C00
0439    8D  00  1C   STA $1C00
043C    60           RTS
043D    A9  90       LDA #$90
043F    2C  A9  80   BIT $80A9
0442    85  04       STA $04
0444    A5  04       LDA $04
0446    30  FC       BMI $0444
0448    60           RTS
0449    04
044A    30  FC       BMI $0448
044C    60           RTS
044D    FF
044E    FF
044F    FF
0450-04FF    00           BRK
; End of file.
