http://www.girder.nl/phpBB2/viewtopic.php?p=17229#17229
http://www.girder.nl/phpBB2/viewtopic.php?p=17079#17079
* make loading a class so we do not care what kind of file we are dealing
  with
* import binary file on drag and drop
* use binary file when copy and pasting.
* rewrite interface to parse_reg_string... it's brain dead right now,   especially since the back end (GVMS) works correctly.
* Setfocus does not work when Girder is the foreground window.
* Robert DeLuca:
  > A typematic feature would be great on a per-command basis. Instead of just
  > having "Antirepeat wait time", you could have "Antirepeat intial wait time"
  > and "Antirepeat wait time".
* display more information when plugin fails
* add default antirepeat value
* add variable support to window resize.
Girder 3.3/4.0
* Add abstraction layer between plugin numbers and processing.
* OSD also configurable from variables.
* Insert multi-event-eventstrings
* Completely overhaul the UI
