%PDF-1.4
1 0 obj
endobj
2 0 obj
<>stream
Mother Boards and Desktop Servers
Graphic Cards
Switching Power Supply
Generic DC/DC Power Regulator
Single IC Supply Voltage ( 5V to 12V)
Drive Two N-MOSFETs
Fixed Operating Frequency at 200kHz
300kHz and 500kHz
Voltage Mode PWM Control with External Feedback Loop Compensation
Over Current Protection by Sensing MOSFET RDS(ON)
Hardware Pin for On/Off Control
Full 0 to 90% Duty Cycle
Fast Transient Response
RoHS Compliant and Halogen Free
5V to 12V Single Synchronous Buck PWM Controller
The RT8108 series are single-phase synchronous buck PWM DC/DC controllers ,designed to drive two N-MOSFETs. They provide a highly accurate, programmable ,output voltage precisely regulated to low voltage requirement with an internal ,0.6V or 0.8V reference.The RT8108 series use a single feedback loop voltage ,mode PWM control for fast transient response. The high driving capability makes ,it suitable for large output current applications. An oscillator with fixed ,frequency 200kHz / 300kHz / 500kHz reduces the component size of the external ,inductor and capacitor for saving PCB board area and cost.,,The RT8108 series integrate complete protection functions such as OCP, OVP ,and OTP UVP into SOP-8 and SOP-8 (Exposed Pad) surface mount packages.,,
endstream
endobj
3 0 obj
endobj
6 0 obj
<>/ColorSpace<>/Font<>/ProcSet[/PDF/Text/ImageC]/ExtGState<>>>
endobj
5 0 obj
<>stream
HWr7}Wqn3rI%>yEJW$%ӍH*474ӧ_zūZe諕lWogItЭQIN"։ś73%>źC`Μm?NًR%3 'i}{^zbWYv8B ˧YWϳKr
MveGD)Fρ-;v*rP&}?Zb6Gs}\,(yga#4ۏ/W-ͳ͎BIZo{߲"23\:]8u
q~k}8zcO[}:qC:(BzOwm1x+q*Kզ=<7Vs*}ΡQ1GsmsGf`unL+_[|mLn҄ׄH2PD̘1
.drw.
5tU<2fvn3ZZi=03sߎ2ПxXOz"|v]Dg#6̥xq{nF$8=]@A!}_ӭG*D]wV֪wG_GYOeY/[.-O7=RHH{~PK96\
FyG 4`4QsE ;zXΘԥrDԡh bg~B5F'bFboa,
"1|/^H
+ <+/` 4JcDwQt'qL,H'{)[$DcJw5rPT.J̞0MZDhURv*"dpWbf;g͜M)H[7ؘߏ`N`().Z]BLUZ_ݯO DXleO+
1?DWRj%m|ȫz<#\3],܌E~]H{
~ʿBA4NWG[#Jt(=8Rd8FJ~q5a,^FV:Ŝ|VJ8T|cDgF>8Td8E23IX5Ʋ-OMʊvx(o+HjL.+-[|LzZ,'_uaOHCZ%Q{`뛈8 VAL/QЦ*m
P8n5S} d}@J\JbL
pNJf!JZ8g:"}R7C6%VhԊ,~s+drdNi)&2,畲:(xF*<JN_H呫Kb@=k~x[ŕǭTDݱy-Q\AtOֺj-kIGs'赝Bϭ>
[@P$=BPQU *ծKrAi3gAA*#P@@W1B.?ԎA=H}7+/-X?a^P
A|h$܋:4|[LtӓI'
1
MS㸪7aNMHaAC3rnL6[H&Px'Z10#ҧIuo"cӻ&z'Egoyv<lдq(cQ/G
