Arduino: 1.8.8 (Windows 7), Board: "WEMOS LOLIN32, 80MHz, Default, 921600"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\T430\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\T430\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\T430\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,UploadSpeed=921600 -ide-version=10808 -build-path C:\Users\T430\AppData\Local\Temp\arduino_build_457126 -warnings=none -build-cache C:\Users\T430\AppData\Local\Temp\arduino_cache_31005 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -prefs=runtime.tools.esptool_py-2.6.0.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\T430\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\T430\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\T430\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,UploadSpeed=921600 -ide-version=10808 -build-path C:\Users\T430\AppData\Local\Temp\arduino_build_457126 -warnings=none -build-cache C:\Users\T430\AppData\Local\Temp\arduino_cache_31005 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -prefs=runtime.tools.esptool_py-2.6.0.path=C:\Users\T430\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.0 -verbose C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino
Using board 'lolin32' from platform in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1
Using core 'esp32' from platform in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1
Detecting libraries used...
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src\\SD.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src\\sd_diskio.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src\\sd_diskio_crc.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src\\FS.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src\\vfs_api.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0\\RTClib.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM\\EEPROM.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master\\MechaQMC5883.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library\\MS5837.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\U8x8lib.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_bitmap.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_box.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_buffer.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_circle.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_cleardisplay.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_d_memory.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_d_setup.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_font.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_fonts.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_hvline.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_input_value.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_intersection.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_kerning.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_line.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_ll_hvline.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_message.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_polygon.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_selection_list.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8g2_setup.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8log.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8log_u8g2.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8log_u8x8.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_8x8.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_byte.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_cad.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_a2printer.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_il3820_296x128.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ist3020.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ks0108.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_lc7981.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ld7032_60x32.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ls013b7dh03.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_max7219.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_pcd8544_84x48.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_pcf8812.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_pcf8814_hx1230.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sbn1661.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sed1330.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sh1106_64x32.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sh1106_72x40.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sh1107.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sh1108.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_sh1122.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1305.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_128x32.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_128x64_noname.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_48x64.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_64x32.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_64x48.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1306_96x16.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1309.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1317.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1322.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1325.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1326.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1327.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1329.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1606_172x72.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_ssd1607_200x200.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st75256.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7565.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7567.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7586s_erc240160.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7586s_s028hn118a.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7588.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_st7920.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_t6963.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1601.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1604.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1608.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1610.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1611.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1617.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1638.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1701_dogs102.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_d_uc1701_mini12864.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_debounce.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_display.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_fonts.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_gpio.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_input_value.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_message.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_selection_list.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_setup.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_string.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_u16toa.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src\\clib\\u8x8_u8toa.c" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\ETH.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFi.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiAP.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiGeneric.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiMulti.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiSTA.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiScan.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src\\Parsing.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src\\WebServer.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src\\detail\\mimetable.cpp" -o nul
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src\\SPIFFS.cpp" -o nul
Generating function prototypes...
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/config" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_trace" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/app_update" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/asio" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bootloader_support" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/bt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/coap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/console" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/driver" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-tls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_event" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_client" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_http_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_ota" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_https_server" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ethernet" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/expat" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fatfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freemodbus" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/freertos" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/heap" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/idf_test" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/jsmn" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/json" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/libsodium" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/log" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/lwip" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mbedtls" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mdns" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/micro-ecc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/mqtt" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/newlib" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nghttp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/nvs_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/openssl" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protobuf-c" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/protocomm" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/pthread" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/sdmmc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/soc" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spi_flash" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/spiffs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcp_transport" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/ulp" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/unity" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/vfs" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wear_levelling" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp32-camera" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/esp-face" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10808 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LOLIN32\"" "-DARDUINO_VARIANT=\"lolin32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\cores\\esp32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\variants\\lolin32" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPI\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SD\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\FS\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\Wire\\src" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\RTClib-1.2.0" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\EEPROM" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\Mecha_QMC5883L-master" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\T430\\Documents\\Arduino\\libraries\\U8g2\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WiFi\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\WebServer\\src" "-IC:\\Users\\T430\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.1\\libraries\\SPIFFS\\src" "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp" -o "C:\\Users\\T430\\AppData\\Local\\Temp\\arduino_build_457126\\sketch\\logger_10_ESP32.ino.cpp.o"
In file included from C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino:35:0:
C:\Users\T430\AppData\Local\Temp\arduino_build_457126\sketch\CSS.h: In function 'void append_page_header()':
CSS.h:2:3: error: 'webpage' was not declared in this scope
   webpage  = F("<!DOCTYPE html><html>");
CSS.h:33:76: error: 'ServerVersion' was not declared in this scope
   webpage += F("</style></head><body><h1>File Server "); webpage += String(ServerVersion) + "</h1>";
C:\Users\T430\AppData\Local\Temp\arduino_build_457126\sketch\CSS.h: In function 'void append_page_footer()':
CSS.h:37:3: error: 'webpage' was not declared in this scope
   webpage += F("<ul>");
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void HomePage()':
logger_10_ESP32:732:3: error: 'webpage' was not declared in this scope
   webpage += F("<a href='/download'><button>Download</button></a>");
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void File_Upload()':
logger_10_ESP32:764:3: error: 'webpage' was not declared in this scope
   webpage += F("<h3>Select File to Upload</h3>"); 
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void handleFileUpload()':
logger_10_ESP32:795:7: error: 'webpage' was not declared in this scope
       webpage = "";
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void SPIFFS_dir()':
logger_10_ESP32:818:7: error: 'webpage' was not declared in this scope
       webpage += F("<table align='center'>");
logger_10_ESP32:829:7: error: 'webpage' was not declared in this scope
       webpage += F("<h3>No Files Found</h3>");
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void printDirectory(const char*, uint8_t)':
logger_10_ESP32:847:9: error: 'webpage' was not declared in this scope
     if (webpage.length() > 1000) {
logger_10_ESP32:851:7: error: 'webpage' was not declared in this scope
       webpage += "<tr><td>"+String(file.isDirectory()?"Dir":"File")+"</td><td>"+String(file.name())+"</td><td></td></tr>";
logger_10_ESP32:856:7: error: 'webpage' was not declared in this scope
       webpage += "<tr><td>"+String(file.name())+"</td>";
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void SPIFFS_file_delete(String)':
logger_10_ESP32:946:9: error: 'webpage' was not declared in this scope
         webpage += "<h3>File '"+filename+"' has been erased</h3>"; 
logger_10_ESP32:951:9: error: 'webpage' was not declared in this scope
         webpage += F("<h3>File was not deleted - error</h3>");
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void SendHTML_Header()':
logger_10_ESP32:968:22: error: 'webpage' was not declared in this scope
   server.sendContent(webpage);
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void SendHTML_Content()':
logger_10_ESP32:973:22: error: 'webpage' was not declared in this scope
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void SelectInput(String, String, String)':
logger_10_ESP32:984:3: error: 'webpage' was not declared in this scope
   webpage += F("<h3>"); webpage += heading1 + "</h3>"; 
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void ReportSPIFFSNotPresent()':
logger_10_ESP32:996:3: error: 'webpage' was not declared in this scope
   webpage += F("<h3>No SPIFFS Card present</h3>"); 
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void ReportFileNotPresent(String)':
logger_10_ESP32:1005:3: error: 'webpage' was not declared in this scope
   webpage += F("<h3>File does not exist</h3>"); 
C:\Users\T430\Documents\Arduino\logger_10_ESP32\logger_10_ESP32.ino: In function 'void ReportCouldNotCreateFile(String)':
logger_10_ESP32:1014:3: error: 'webpage' was not declared in this scope
   webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>"); 
Multiple libraries were found for "SD.h"
 Used: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SD
 Not used: C:\Program Files (x86)\Arduino\libraries\SD
Multiple libraries were found for "MechaQMC5883.h"
 Used: C:\Users\T430\Documents\Arduino\libraries\Mecha_QMC5883L-master
 Not used: C:\Users\T430\Documents\Arduino\libraries\Mecha_QMC5883-master
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\WiFi
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Multiple libraries were found for "WebServer.h"
 Used: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\WebServer
 Not used: C:\Users\T430\Documents\Arduino\libraries\WebServer-esp32-master
Using library SPI at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPI 
Using library SD at version 1.0.5 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SD 
Using library FS at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\FS 
Using library Wire at version 1.0.1 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\Wire 
Using library RTClib-1.2.0 at version 1.2.0 in folder: C:\Users\T430\Documents\Arduino\libraries\RTClib-1.2.0 
Using library EEPROM at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\EEPROM 
Using library Mecha_QMC5883L-master in folder: C:\Users\T430\Documents\Arduino\libraries\Mecha_QMC5883L-master (legacy)
Using library BlueRobotics_MS5837_Library at version 1.1.0 in folder: C:\Users\T430\Documents\Arduino\libraries\BlueRobotics_MS5837_Library 
Using library U8g2 at version 2.24.3 in folder: C:\Users\T430\Documents\Arduino\libraries\U8g2 
Using library WiFi at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\WiFi 
Using library WebServer at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\WebServer 
Using library SPIFFS at version 1.0 in folder: C:\Users\T430\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.1\libraries\SPIFFS 
exit status 1
Invalid library found in C:\Users\T430\Documents\Arduino\libraries\arduino-esp32-master: no headers files (.h) found in C:\Users\T430\Documents\Arduino\libraries\arduino-esp32-master
Invalid library found in C:\Users\T430\Documents\Arduino\libraries\Arduino-master: no headers files (.h) found in C:\Users\T430\Documents\Arduino\libraries\Arduino-master
